15-VCF Fabric命令
本章节下载: 15-VCF Fabric命令 (200.95 KB)
1.1.2 display vcf-fabric underlay autoconfigure
1.1.3 display vcf-fabric underlay template-version
1.1.4 vcf-fabric topology enable
1.1.5 vcf-fabric underlay autoconfigure
1.1.6 vcf-fabric underlay netconf-username
1.1.7 vcf-fabric underlay netconf-password
1.1.8 vcf-fabric underlay pause
display vcf-fabric role命令用来查看设备在VCF Fabric中的角色。
设备在VCF Fabric中的角色可通过vcf-fabric role命令进行配置,配置后的角色可以通过本命令查看。
# 查看设备在VCF Fabric中的角色。
<System> display vcf-fabric role
Default role: access
Current role: access
表1-1 display vcf-fabric role命令显示信息描述表
Default role |
设备缺省的VCF Fabric角色 |
Current role |
设备当前配置的VCF Fabric角色 |
display vcf-fabric underlay autoconfigure命令用来查看Underlay网络的自动化配置信息。
通过模板文件进行Underlay网络的自动配置后,可通过本命令查看Underlay网络的自动化配置信息。
# 查看Underlay网络自动化配置信息。
<Sysname> display vcf-fabric underlay autoconfigure
success command:
system
clock timezone beijing add 08:00:00
system
lldp global enable
lldp compliance cdp
system
ospf 1
graceful-restart ietf
area 0.0.0.0
system
interface LoopBack0
system
l2vpn enable
system
vxlan tunnel arp-learning disable
system
stp global enable
system
ntp-service enable
ntp-service unicast-peer 172.16.1.136
system
netconf soap https enable
restful https enable
system
info-center loghost 172.16.1.136
system
local-user aaa
password ******
service-type https
system
line vty 0 63
authentication-mode scheme
system
bgp 100
graceful-restart
address-family l2vpn evpn
system
system
neutron
rabbit user openstack
rabbit password ******
rabbit host ip 172.16.1.136
restful user aaa password ******
vpn-target 1:1 export-extcommunity
vsi-mac 789c-2f5f-0200
network-type distributed-vxlan
proxy-arp enable
l2agent enable
l3agent enable
system
snmp-agent
snmp-agent packet max-size 4096
snmp-agent community read public
snmp-agent community write private
snmp-agent sys-info version all
Uplink interface:
Ten-GigabitEthernet1/0/1
Ten-GigabitEthernet1/0/2
Downlink interface:
Ten-GigabitEthernet1/0/3
Ten-GigabitEthernet1/0/4
AP-side interfaces:
GigabitEthernet1/0/7
GigabitEthernet1/0/8
Loopback0 IP allocation:
Device_MAC Loopback_IP Management_IP State
a43c-adae-0400 200.1.1.6 172.16.1.193 Up
a43c-9aa7-0100 200.1.1.4 172.16.1.152 Up
Loopback1 IP allocation:
a43c-adae-0400 100.1.1.6 172.16.1.193 Up
a43c-9aa7-0100 100.1.1.4 172.16.1.152 Up
Aggregation configuration:
AggrID: 7
interface: Ten-GigabitEthernet1/0/5
interface: Ten-GigabitEthernet1/0/6
IRF allocation:
Self Bridge Mac: a43c-adae-0400
IRF Status: Yes
Member List: [1, 2]
BGP peer configuration:
Device_MAC: 265b-208d-0300
Device_role:leaf
BGP peer list:
200.1.4.5
Device_MAC: 1ea6-06a4-0500
Device_role:spine
BGP peer list:
200.1.4.4
200.1.4.7
Device_MAC: 1ead-aed1-0600
Device_role:leaf
BGP peer list:
200.1.4.5
Device_role:leaf
BGP peer list:
200.1.4.5
Device_role:spine
BGP peer list:
200.1.4.4
200.1.4.7
Device_role:leaf
BGP peer list:
200.1.4.5
表1-2 display vcf-fabric underlay autoconfigure命令显示信息描述表
success command |
配置自动化过程中,已经成功执行的命令行 |
Uplink interface |
设备的上行口 |
Downlink interface |
设备的下行口 |
AP-side interfaces |
设备连接AP的接口 |
Loopback0 IP allocation |
为Loopback接口分配的IP地址列表 |
Loopback1 IP allocation |
为Loopback1接口分配的IP地址列表 |
Aggregation configurations |
二层聚合组信息 |
IRF allocation |
IRF配置信息,包括:IRF的桥MAC地址、IRF状态和成员设备编号 |
BGP peer configuration |
BGP配置信息,当组网为spine-aggr-leaf三层拓扑时,仅在master spine设备上显示,显示信息包含所有spine和leaf设备的bgp peer信息 |
· vcf-fabric underlay autoconfigure
display vcf-fabric underlay template-version命令用来查看VCF Fabric自动配置功能支持的模板版本和当前自动部署使用的模板版本。
通过此命令查看到的VCF Fabric自动配置功能支持的模板版本为最高版本,格式为“x.y”。实际部署时,采用的模板版本中的“x”可小于等于最高版本;若大于最高版本,可能导致通过模板文件进行自动部署失败。模板版本中的“y”取值不影响兼容性,不同取值仅对应不同的静态配置组合。
# VCF Fabric的Underlay自动部署未启动时,查看模板版本。
<Sysname> display vcf-fabric underlay template-version
Supported template version: 14.0
Current template version: Not available
# VCF Fabric的Underlay自动部署完成后,查看模板版本。
Supported template version: 1.0
Current template version: 1.0
表1-3 display vcf-fabric underlay template-version命令显示信息描述表
Supported template version |
支持的模板版本 |
Current template version |
当前运行的模板版本 · 若显示为Not available表示Underlay自动部署未启动 · 若显示为None表示Underlay自动部署已完成,但模板未包含版本号 |
vcf-fabric topology enable命令用来开启VCF Fabric网络拓扑发现功能。
undo vcf-fabric topology enable命令用来关闭VCF Fabric网络拓扑发现功能。
VCF Fabric网络拓扑发现功能处于关闭状态。
# 开启VCF Fabric网络拓扑发现功能。
[Sysname] vcf-fabric topology enable
vcf-fabric underlay autoconfigure命令用来采用指定的模板文件进行Underlay网络的自动配置。
undo vcf-fabric underlay autoconfigure命令用来取消自动化配置。
vcf-fabric underlay autoconfigure template
未指定进行Underlay网络自动配置的模板文件。
template:模板文件名,以“.template”为后缀,从存储介质名称开始包括后缀名最多可输入127个字符,不区分大小写。
用户预先通过TFTP等方式将模板文件保存到本地设备,执行本命令后,设备将采用指定的模板文件进行Underlay网络的自动配置。
执行undo vcf-fabric underlay autoconfigure命令取消自动化配置后,如果再次使用vcf-fabric underlay autoconfigure重新指定模板文件,会导致Spine分配给Leaf设备的Loopback IP地址变化,从而使Leaf设备暂时下线再重新上线。
# 采用模板文件vlan_leaf.template进行Underlay网络的自动配置。
[Sysname] vcf-fabric underlay autoconfigure vlan_leaf.template
vcf-fabric underlay netconf-username命令用来设置Spine设备通过Netconf收集全局拓扑时使用的用户名。
undo vcf-fabric underlay netconf-username命令用来恢复缺省情况。
vcf-fabric underlay netconf-username username
Spine设备通过Netconf收集全局拓扑时,使用模板文件中定义的用户名。
username:Spine设备通过Netconf收集全局拓扑时使用的用户名,为1~63个字符的字符串,区分大小写。
在VCF Fabric组网中,Underlay网络自动化部署时,Spine设备使用模板中定义的用户名和密码与Underlay网络中的设备建立Netconf连接,通过Netconf收集全局拓扑信息。自动化部署完成后,若用户手动更改Underlay网络设备上的用户名或密码,会导致Spine设备与其断开Netconf连接,Spine设备无法感知Underlay网络的拓扑变化。此时,可以在Spine设备上执行本命令修改Netconf操作使用的用户名,使其与Underlay网络设备上的用户名保持一致,并重新建立Netconf连接,以便进行拓扑收集。
在VCF Fabric组网中,所有Underlay网络设备上用于建立Netconf连接的用户名和密码必须相同。
# 设置Spine设备通过Netconf收集全局拓扑时,使用的用户名为aaa。
[Sysname] vcf-fabric underlay netconf-username aaa
vcf-fabric underlay netconf-password命令用来设置Spine设备通过Netconf收集全局拓扑时使用的密码。
undo vcf-fabric netconf-underlay password命令用来恢复缺省情况。
vcf-fabric underlay netconf-password { cipher | simple } string
undo vcf-fabric underlay netconf-password
Spine设备通过Netconf收集全局拓扑时,使用模板文件中定义的密码。
cipher:以密文方式设置密码。
simple:以明文方式设置密码,该密码将以密文形式存储。
string:Spine设备通过Netconf收集全局拓扑时使用的密码,区分大小写。明文密码为1~63个字符的字符串;密文密码为1~127个字符的字符串。
在VCF Fabric组网中,Underlay网络自动化部署时,Spine设备使用模板中定义的用户名和密码与Underlay网络中的设备建立Netconf连接,通过Netconf收集全局拓扑信息。自动化部署完成后,若用户手动更改Underlay网络设备上的用户名或密码,会导致Spine设备与其断开Netconf连接,Spine设备无法感知Underlay网络的拓扑变化。此时,可以在Spine设备上执行本命令修改Netconf操作使用的密码,使其与Underlay网络设备上的密码保持一致,并重新建立Netconf连接,以便进行拓扑收集。
# 设置Spine设备通过Netconf收集全局拓扑时,使用的密码为明文aaa。
[Sysname] vcf-fabric underlay netconf-password simple aaa
vcf-fabric underlay pause命令用来暂停Underlay网络的自动配置功能。
undo vcf-fabric underlay pause命令用来重新启动Underlay网络的自动配置功能。
Underlay网络的自动配置功能处于非暂停状态。
设备已经启动Underlay网络的自动配置功能后,可利用本命令暂停自动配置功能。
# 暂停Underlay网络的自动配置功能。
<sysname> system-view
[sysname] vcf-fabric underlay pause
