07-IP组播命令参考
08-MLD Snooping命令
本章节下载 08-MLD Snooping命令  (643.39 KB)
08-MLD Snooping命令
1 MLD Snooping
1.1 MLD Snooping配置命令
1.1.1 display ipv6 l2-multicast fast-forwarding cache
1.1.2 display ipv6 l2-multicast ip
1.1.3 display ipv6 l2-multicast ip forwarding
1.1.4 display ipv6 l2-multicast mac
1.1.5 display ipv6 l2-multicast mac forwarding
1.1.6 display mld-snooping
1.1.7 display mld-snooping group
1.1.8 display mld-snooping host-tracking
1.1.9 display mld-snooping router-port
1.1.10 display mld-snooping static-group
1.1.11 display mld-snooping static-router-port
1.1.12 display mld-snooping statistics
1.1.13 dot1p-priority (MLD-Snooping view)
1.1.14 dscp
1.1.15 enable (MLD-Snooping view)
1.1.16 entry-limit (MLD-Snooping view)
1.1.17 fast-leave (MLD-Snooping view)
1.1.18 global-enable (MLD-Snooping view)
1.1.19 group-policy (MLD-Snooping view)
1.1.20 host-aging-time (MLD-Snooping view)
1.1.21 host-tracking (MLD-Snooping view)
1.1.22 last-listener-query-interval (MLD-Snooping view)
1.1.23 max-response-time (MLD-Snooping view)
1.1.24 mld-snooping
1.1.25 mld-snooping done source-ip
1.1.26 mld-snooping dot1p-priority
1.1.27 mld-snooping drop-unknown
1.1.28 mld-snooping { disable | enable }
1.1.29 mld-snooping fast-leave
1.1.30 mld-snooping general-query source-ip
1.1.31 mld-snooping group-limit
1.1.32 mld-snooping group-policy
1.1.33 mld-snooping host-aging-time
1.1.34 mld-snooping host-join
1.1.35 mld-snooping host-tracking
1.1.36 mld-snooping last-listener-query-interval
1.1.37 mld-snooping log enable
1.1.38 mld-snooping log suppress
1.1.39 mld-snooping max-response-time
1.1.40 mld-snooping overflow-replace
1.1.41 mld-snooping proxy enable
1.1.42 mld-snooping querier
1.1.43 mld-snooping querier-election
1.1.44 mld-snooping query-interval
1.1.45 mld-snooping report source-ip
1.1.46 mld-snooping router-aging-time
1.1.47 mld-snooping router-port-deny
1.1.48 mld-snooping router-port-discard
1.1.49 mld-snooping source-deny
1.1.50 mld-snooping special-query source-ip
1.1.51 mld-snooping static-group
1.1.52 mld-snooping static-router-port
1.1.53 mld-snooping triggered-query enable
1.1.54 mld-snooping version
1.1.55 overflow-replace (MLD-Snooping view)
1.1.56 report-aggregation (MLD-Snooping view)
1.1.57 reset ipv6 l2-multicast fast-forwarding cache
1.1.58 reset mld-snooping group
1.1.59 reset mld-snooping router-port
1.1.60 reset mld-snooping statistics
1.1.61 router-aging-time (MLD-Snooping view)
1.1.62 send-query enable
1.1.63 snmp-agent trap enable mld-snooping
1.1.64 source-deny (MLD-Snooping view)
1.1.65 version (MLD-Snooping view)
1 MLD Snooping
设备仅在独立运行模式下支持MDC。关于MDC的详细介绍,请参见“虚拟化技术配置指导”中的“MDC”。
display ipv6 l2-multicast fast-forwarding cache命令用来显示IPv6二层快速转发表信息。
(独立运行模式)
display ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] [ ipv6-source-address | ipv6-group-address ] * [ slot slot-number ]
display ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] [ ipv6-source-address | ipv6-group-address ] * [ chassis chassis-number slot slot-number ]
vlan vlan-id:显示指定VLAN内的状态信息。vlan-id为VLAN的编号,取值范围为1~4094。
ipv6-source-address:组播源地址,显示包含指定组播源的二层组播快速转发表项。如果未指定本参数,将显示所有组播源的信息。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播快速转发表项,取值范围为FFxy::/16(但不包括FFx1::/16和FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有组播组的信息。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上维护的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示全局主用主控板上维护的信息。(IRF模式)
# 显示IPv6二层组播快速转发表项的信息。
<Sysname> display ipv6 l2-multicast fast-forwarding cache
Total 1 entries, 1 matched
  (1::6, FF1E::2)
    Status      : Enable                VLAN            : 1
    Source port : 9876                  Destination port: 5432
    Protocol    : 17                    Flag            : 0x2
    Ingress port: Ten-GigabitEthernet3/0/2
    List of 1 egress ports:
        Ten-GigabitEthernet3/0/3
          Status: Enable                Flag: 0x10
表1-1 display ipv6 l2-multicast fast-forwarding cache命令显示信息描述表
二层组播快速转发表中(S,G)表项的总数和匹配数
(1::6, FF1E::2)
二层组播快速转发表的(S,G)表项
Source port
源端口号
Destination port
目的端口号
Protocol
协议号
VLAN
VLAN的编号
Flag
(S,G)表项入端口状态,通过将不同的比特位置位来表示不同的状态:
·     0x1:表示由板间透传的报文触发创建的表项
·     0x2:表示组播转发流程添加的表项
(S,G)表项出端口状态,通过将不同的比特位置位来表示不同的状态:
·     0x1:表示由板间透传的报文触发创建的出端口
·     0x2:表示向已存在的快转表项增添的出端口
·     0x10:表示出端口已经与会话建立关联关系
·     0x20:表示待删除的出端口
Status
二层组播快速转表项入cache和出cache的状态,包括Enabled和Disabled
Ingress port
表示(S,G)表项的入端口
表示(S,G)表项的出端口列表
·     reset ipv6 l2-multicast fast-forwarding cache all
display ipv6 l2-multicast ip命令用来显示IPv6二层组播的IP组播组信息。
(独立运行模式)
display ipv6 l2-multicast ip [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
display ipv6 l2-multicast ip [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ]
group ipv6-group-address:显示指定IPv6组播组的信息。如果未指定本参数,将显示所有IPv6组播组的信息。
source ipv6-source-address:显示指定IPv6组播源的信息。如果未指定本参数,将显示所有IPv6组播源的信息。
vlan vlan-id:显示指定VLAN内的信息。vlan-id为VLAN的编号,取值范围为1~4094。如果未指定本参数,将显示所有VLAN内的信息。
vsi vsi-name:显示指定VSI内的信息。vsi-name为VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有VSI内的信息。
# 显示VLAN 2内IPv6二层组播的IP组播组信息。
<Sysname> display ipv6 l2-multicast ip vlan 2
Total 1 entries.
VLAN 2: Total 1 entries.
   (::, FF1E::101)
    Attribute: static, success
    Host ports (1 in total):
      XGE3/0/1                             (S, SUC)
# 显示VSI aaa内IPv6二层组播的IP组播组信息。
<Sysname> display ipv6 l2-multicast ip vsi aaa
Total 1 entries.
VSI aaa: Total 1 entries.
  (::, FF1E::101)
    Attribute: dynamic, success
    Host ports (3 in total):
      XGE3/0/3 (Link ID 0)                  (D, SUC)
      NPW (Link ID 8)                      (D, SUC)
      UPW (Link ID 9)                      (D, SUC)
# 显示VSI bbb内IPv6二层组播的IP组播组信息。
<Sysname> display ipv6 l2-multicast ip vsi bbb
Total 2 entries.
VSI bbb: Total 2 entries.
  (::, FF1E::101)
    Host ports (2 in total):
      Tun1 (VXLAN ID 0)                    (D, SUC)
  (1::1, FF1E::101)
      XGE3/0/3 (Link ID 0)                  (DE)
      Tun1 (VXLAN ID 0)                    (DE)
表1-2 display ipv6 l2-multicast ip命令显示信息描述表
Total 1 entries
表项总数
VLAN 2内的表项总数
VSI aaa内的表项总数
(::, FF1E::101)
(S,G)表项,::表示所有IPv6组播源
Attribute
表项属性,包括:
·     dynamic:表示由动态协议创建的表项
·     static:表示由静态协议创建的表项
·     pim:表示由IPv6 PIM协议创建的表项
·     kernel:表示从内核中获取的表项
·     success:表示处理成功
·     fail:表示处理失败
成员端口及总数
(S, SUC)
端口属性,包括:
·     D:表示动态端口
·     DE:表示动态EXCLUDE模式端口
·     S:表示静态端口
·     P:表示IPv6 PIM端口
·     K:表示从内核中获取的端口
·     R:表示从(**)表项扩展的端口
·     W:表示从(*,G)表项扩展的端口
·     SUC:表示处理成功
·     F:表示处理失败
·     BC:VSI内表示VXLAN核心复制模式下组播隧道扩展的端口
成员端口名称和链路标识符
NPW (Link ID 8)
N-PW(Network Pseudowire,网络侧伪线)的链路标识符
UPW (Link ID 9)
U-PW(User facing Pseudowire,用户侧伪线)的链路标识符
Tun1 (VXLAN ID 0)
与VXLAN关联的隧道名称和VXLAN编号
display ipv6 l2-multicast ip forwarding命令用来显示IPv6二层组播的IP转发表信息。
(独立运行模式)
display ipv6 l2-multicast ip forwarding [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
display ipv6 l2-multicast ip forwarding [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ]
# 显示VLAN 2内IPv6二层组播的IP转发表信息。
<Sysname> display ipv6 l2-multicast ip forwarding vlan 2
Total 1 entries.
   (::, FF1E::101)
      Ten-GigabitEthernet3/0/1
# 显示VSI aaa内IPv6二层组播的IP转发表信息。
<Sysname> display ipv6 l2-multicast ip forwarding vsi aaa
Total 1 entries.
  (::, FF1E::101)
      Ten-GigabitEthernet3/0/3 (Link ID 0)
      NPW (Link ID 8)
      UPW (Link ID 9)
# 显示VSI bbb内IPv6二层组播的IP转发表信息。
<Sysname> display ipv6 l2-multicast ip forwarding vsi bbb
Total 1 entries.
VSI bbb: Total 1 entries.
  (::, FF1E::101)
      Tunnel1 (VXLAN ID 0)
表1-3 display ipv6 l2-multicast ip forwarding命令显示信息描述表
Total 1 entries
表项总数
VLAN 2内的表项总数
VSI aaa内的表项总数
(::, FF1E::101)
成员端口及总数
成员端口名称和链路标识符
NPW (Link ID 8)
UPW (Link ID 9)
display ipv6 l2-multicast mac命令用来显示IPv6二层组播的MAC组播组信息。
(独立运行模式)
display ipv6 l2-multicast mac [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
display ipv6 l2-multicast mac [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ]
mac-address:显示指定MAC组播组的信息。如果未指定本参数,将显示所有MAC组播组的信息。
# 显示VLAN 2内IPv6二层组播的MAC组播组信息。
<Sysname> display ipv6 l2-multicast mac vlan 2
Total 1 entries.
  MAC group address: 3333-0000-0101
    Attribute: success
      XGE3/0/1
# 显示VSI aaa内IPv6二层组播的MAC组播组信息。
<Sysname> display ipv6 l2-multicast mac vsi aaa
Total 1 entries.
  MAC group address: 0100-5e01-0101
    Attribute: success
      XGE3/0/3 ( Link ID 0)
      NPW (Link ID 8)
      UPW (Link ID 9)
# 显示VSI bbb内IPv6二层组播的MAC组播组信息。
<Sysname> display ipv6 l2-multicast mac vsi bbb
Total 1 entries.
    Attribute: success
      Tun1 (VXLAN ID 0)
表1-4 display ipv6 l2-multicast mac命令显示信息描述表
Total 1 entries
表项总数
VLAN 2内的表项总数
VSI aaa内的表项总数
MAC group address
MAC组播组的地址
Attribute
表项属性,包括:
·     success:表示处理成功
·     fail:表示处理失败
成员端口及总数
成员端口名称和链路标识符
NPW (Link ID 8)
UPW (Link ID 9)
Tun1 (VXLAN ID 0)
display ipv6 l2-multicast mac forwarding命令用来显示IPv6二层组播的MAC转发表信息。
(独立运行模式)
display ipv6 l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
display ipv6 l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ]
# 显示VLAN 2内IPv6二层组播的MAC转发表信息。
<Sysname> display ipv6 l2-multicast mac forwarding vlan 2
Total 1 entries.
# 显示VSI aaa内IPv6二层组播的MAC转发表信息。
<Sysname> display ipv6 l2-multicast mac forwarding vsi aaa
Total 1 entries.
      NPW (Link ID 8)
      UPW (Link ID 9)
# 显示VSI bbb内IPv6二层组播的MAC转发表信息。
<Sysname> display ipv6 l2-multicast mac forwarding vsi bbb
Total 1 entries.
表1-5 display ipv6 l2-multicast mac forwarding命令显示信息描述表
Total 1 entries
表项总数
VLAN 2内的表项总数
VSI aaa内的表项总数
MAC group address
MAC组播组的地址
成员端口及总数
成员端口名称和链路标识符
NPW (Link ID 8)
UPW (Link ID 9)
display mld-snooping命令用来显示MLD Snooping的状态信息。
display mld-snooping [ global | vlan vlan-id | vsi vsi-name ]
global:显示MLD Snooping的全局状态信息。
vlan vlan-id:显示MLD Snooping在指定VLAN内的状态信息。vlan-id为VLAN的编号,取值范围为1~4094。
vsi vsi-name:显示MLD Snooping在指定VSI内的状态信息。vsi-name为VSI的名称,为1~31个字符的字符串,区分大小写。
如果未指定任何可选参数,将显示MLD Snooping在全局以及所有VLAN和VSI内的状态信息。
# 显示MLD Snooping在全局以及所有VLAN和VSI内的状态信息。
<Sysname> display mld-snooping
MLD snooping information: Global
 Global-enable: Enabled
 Host-aging-time: 260s
 Router-aging-time: 260s
 Max-response-time: 10s
 Last-listener-query-interval: 1s
 Report-aggregation: Enabled
 Host-tracking: Disabled
 Dot1p-priority: --
 M-LAG: Enabled (Peer-link interface: Bridge-Aggregation 1)
MLD snooping information: VLAN 1
 MLD snooping: Enabled
 Drop-unknown: Disabled
 Version: 1
 Querier: Enabled (IP: FE80::2FF:FFFF:FE00:1, Expires: 00:02:05)
 Querier-election: Enabled
 Query-interval: 125s
 General-query source IP: FE80::2FF:FFFF:FE00:1
 Special-query source IP: FE80::2FF:FFFF:FE00:1
 Report source IP: FE80::2FF:FFFF:FE00:2
 Done source IP: FE80::2FF:FFFF:FE00:3
 Dot1p-priority: 2
 Router-port-discard: Disabled
 Proxy: Disabled
MLD snooping information: VLAN 10
 Drop-unknown: Enabled
 Version: 1
 Dot1p-priority: --
 Proxy: Disabled
MLD snooping information: VSI aaa
 Version: 1
 Querier: Disabled
 Querier-election: Disabled
 Proxy: Disabled
 Peer-link interface: Bridge-Aggregation 1 (Link ID: 0x1001)
表1-6 display mld-snooping命令显示信息描述表
MLD Snooping的状态信息
Global-enable
MLD Snooping的全局使能状态:
·     Enabled:表示全局已使能
·     Disabled:表示全局未使能
MLD snooping
MLD Snooping在单个VLAN/VSI内的使能状态:
·     Enabled:表示已使能
·     Disabled:表示未使能
·     Globally enabled:表示全局使能
·     Inactive:MLD Snooping配置未生效
Drop-unknown
丢弃未知组播数据报文功能的开启状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
Version
MLD Snooping的版本
Host-aging-time
动态成员端口的老化时间
Router-aging-time
动态路由器端口老化时间
Max-response-time
MLD普遍组查询的最大响应时间
MLD特定组查询报文的发送间隔
Report-aggregation
MLD成员关系报告报文抑制功能的开启状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
Dot1p-priority
MLD报文的802.1p优先级,“--”表示没有配置
Querier
MLD Snooping查询器的开启状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
MLD Snooping查询器信息:
·     IP:表示查询器的IPv6地址
·     Expires:表示查询器老化剩余时间
当MLD Snooping查询器为未开启状态时,以上字段不显示
Querier-election
MLD Snooping查询器选举功能开启状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
Query-interval
MLD普遍组查询报文的发送间隔
MLD普遍组查询报文的源IPv6地址
MLD特定组查询报文的源IPv6地址
Report source IP
MLD成员关系报告报文的源IPv6地址
Done source IP
MLD离开组报文的源IPv6地址
Host-tracking
‌MLD Snooping主机跟踪功能的开启状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
·     Globally enabled:表示全局开启
Router-port-discard
MLD Snooping组播数据不向路由器端口转发功能的开启状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
Proxy
‌MLD Snooping Proxy的开启状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
M-LAG
M-LAG的开启状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
Peer-link interface
M-LAG中peer-link接口名
Link ID
M-LAG中peer-link接口在对应VSI内的Link ID信息
display mld-snooping group命令用来显示动态MLD Snooping IPv6组播组的信息。
(独立运行模式)
display mld-snooping group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ interface interface-type interface-number | [ verbose ] [ slot slot-number  ] ]
display mld-snooping group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ interface interface-type interface-number | [ verbose ] [ chassis chassis-number slot slot-number  ] ]
ipv6-group-address:显示指定IPv6组播组的信息,取值范围为FFxy::/16(但不包括FFx1::/16和FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的信息。
interface interface-type interface-number:显示指定接口所属动态MLD Snooping组播组的简要信息。如果未指定本参数,将显示所有接口的对应信息。
verbose:显示详细信息。如果未指定本参数,将显示简要信息。
# 显示接口Ten-GigabitEthernet3/0/1所属的动态MLD Snooping组播组的信息。
<Sysname> display mld-snooping group interface ten-gigabitethernet 3/0/1
Total 1 entries.
XGE3/0/1:
   (::,FF1E::101)                    (00:03:23)
# 显示VLAN 2内动态MLD Snooping IPv6组播组的详细信息。
<Sysname> display mld-snooping group vlan 2 verbose
Total 2 entries.
VLAN 2: Total 2 entries.
  (::,FF1E::101)
    Attribute: local port
    FSM information: normal
    Host slots (0 in total):
      XGE3/0/2                             (00:03:23)
  (12::, FF1E::101)
      XGE3/0/2                            (00:04:02)
    Exclude host ports (1 in total):
      XGE3/0/2                             (00:03:23)
# 显示名称为aaa的VSI内动态MLD Snooping组播组的简要信息。
<Sysname> display mld-snooping group vsi aaa
Total 2 entries.
VSI aaa: Total 2 entries.
  (::,FF1E::101)
      XGE3/0/3 (Link ID 1)                (00:03:35)
      NPW (Link ID 8)                    (00:02:35)
      UPW (Link ID 9)                    (00:01:35)
  (1::1,FF1E::101)
    Exclude host ports (3 in total):
# 显示名称为bbb的VSI内动态MLD Snooping组播组的详细信息。
<Sysname> display mld-snooping group vsi bbb verbose
Total 2 entries.
  (::,FF1E::101)
    Attribute: global port
      XGE3/0/3 (Link ID 0)                        (00:03:35)
        VLAN pairs (1 in total):
          Outer VLAN:5   , Inner VLAN:2          (00:03:35)
      Tun1 (VXLAN ID 0)                          (00:03:35)
  (1::1,FF1E::101)
    Exclude host ports (2 in total):
          Outer VLAN:5   , Inner VLAN:N/A          (00:03:35)
表1-7 display mld-snooping group命令显示信息描述表
Total 1 entries
表项总数
VLAN 2内的表项总数
VSI aaa内的表项总数
(::,FF1E::101)
Attribute
表项属性,包括:
·     global port:表示表项中存在全局口
·     local port:表示表项中存在指定单板的端口;如果命令中未指定单板槽位编号,则表示表项中存在主控板/主用主控板的端口
·     slot:表示表项中存在其它单板的端口
FSM information
表项状态机,包括:
·     delete:表示所有成员属性均已删除
·     dummy:表示新创建的临时表项
·     no info:表示没有表项存在
·     normal:表示创建的正式表项
·     除指定单板外,其它所有有成员端口的单板总数,以及各单板的槽位号;如果命令中未指定单板槽位编号,则表示除主控板外,其它所有有成员端口的单板总数,以及各单板的槽位号(独立运行模式)
·     除指定单板外,其它所有有成员端口的单板总数,以及各单板所在成员设备的编号和单板的槽位号;如果命令中未指任何成员设备的编号和单板的槽位编号,则表示除主用主控板外,其它所有有成员端口的单板总数,以及各单板所在成员设备的编号和单板的槽位号(IRF模式)
成员端口及总数
EXCLUDE模式的成员端口及总数
(00:03:23)
成员端口的老化剩余时间
需要注意的是,本字段对于全局口(如二层聚合接口、AC、N-PW、U-PW等)将无条件显示,而对于非全局口:
·     若该口属于主控板,且在未指定任何单板槽位号时,会显示;而对于其它单板上的端口,则须指定其所在单板的槽位号才会显示(独立运行模式)
·     若该口属于全局主用主控板,且在未指定任何成员设备的任何单板槽位号时,会显示;而对于其它单板上的端口,则须指定其所在成员设备的编号和单板的槽位号才会显示(IRF模式)
成员端口名称和链路标识符
NPW (Link ID 8)
UPW (Link ID 9)
Tun1 (VXLAN ID 0)
VLAN对及总数
外层VLAN为5,内层VLAN为2;N/A表示报文中未封装该层VLAN
·     reset mld-snooping group
display mld-snooping host-tracking命令用来查看MLD Snooping主机跟踪信息。
(独立运行模式)
display mld-snooping host-tracking vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ slot slot-number ]
display mld-snooping host-tracking vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ chassis chassis-number slot slot-number ]
vlan vlan-id:显示指定VLAN内MLD Snooping主机跟踪信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
group ipv6-group-address:显示MLD Snooping跟踪的加入指定组播组的主机信息。ipv6-group-address为组播组的地址,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
# 查看VLAN 2内MLD Snooping跟踪的加入组播组FF1E::2的主机信息。
<Sysname> display mld-snooping host-tracking vlan 2 group FF1E::2
VLAN 2
 (1::6, FF1E::2)
    Port: XGE3/0/1
      Host                                    Uptime          Expires
      1::2                                    00:02:20        00:00:40
      1::3                                    00:02:21        00:00:39
表1-8 display mld-snooping host命令显示信息描述表
VLAN
VLAN的编号
(1::6, FF1E::2)
(S,G)表项,0::0代表任意组播源
Port
成员端口的名称
Host
主机的IP地址
Uptime
主机加入组播组的运行时长
Expires
主机的超时剩余时间,在收到主机的成员关系报告报文时会进行刷新(与端口老化时间一致),timeout表示已超时
·     host-tracking (MLD-Snooping view)
·     mld-snooping enable
·     mld-snooping host-tracking
display mld-snooping router-port命令用来显示IPv6动态路由器端口的信息。
(独立运行模式)
display mld-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ slot slot-number ]
display mld-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ chassis chassis-number slot slot-number ]
# 显示VLAN 2内IPv6动态路由器端口的简要信息。
<Sysname> display mld-snooping router-port vlan 2
VLAN 2:
  Router ports (2 in total):
    XGE3/0/1                             (00:01:30)
    XGE3/0/2                             (00:00:23)
# 显示VLAN 2内IPv6动态路由器端口的详细信息。
<Sysname> display mld-snooping router-port vlan 2 verbose
VLAN 2:
  Router slots (0 in total):
    XGE3/0/1                             (00:01:30)
    XGE3/0/2                             (00:00:23)
# 显示VSI aaa内IPv6动态路由器端口的简要信息。
<Sysname> display mld-snooping router-port vsi aaa
VSI aaa:
  Router ports (3 in total):
    NPW (Link ID 8)                               (00:03:35)
    UPW (Link ID 9)                               (00:03:35)
# 显示VSI bbb内IPv6动态路由器端口的详细信息。
<Sysname> display mld-snooping router-port vsi bbb verbose
VSI bbb:
表1-9 display mld-snooping router-port命令显示信息描述表
VLAN 2
VLAN的编号
VSI aaa
VSI的名称
·     除指定单板外,其它所有有动态路由器端口的单板总数,以及各单板的槽位号;如果命令中未指定单板槽位编号,则表示除主控板外,其它所有有动态路由器端口的单板总数,以及各单板的槽位号(独立运行模式)
·     除指定单板外,其它所有有动态路由器端口的单板总数,以及各单板所在成员设备的编号和单板的槽位号;如果命令中未指任何成员设备的编号和单板的槽位编号,则表示除主用主控板外,其它所有有动态路由器端口的单板总数,以及各单板所在成员设备的编号和单板的槽位号(IRF模式)
动态路由器端口及总数
(00:01:30)
动态路由器端口的老化剩余时间:
·     全局口:(如二层聚合接口、AC、N-PW、U-PW等):
¡     仅当未指定任何单板槽位号或者指定主用主控板槽位号时,会显示(独立运行模式)
¡     仅当未指定任何单板槽位号或者指定全局主用主控板槽位号时,会显示(IRF模式)
·     非全局口:
¡     若该口属于主控板,且在未指定任何单板槽位号时,会显示;而对于其它单板上的端口,则须指定其所在单板的槽位号才会显示(独立运行模式)
¡     若该口属于全局主用主控板,且在未指定任何成员设备的任何单板槽位号时,会显示;而对于其它单板上的端口,则须指定其所在成员设备的编号和单板的槽位号才会显示(IRF模式)
成员端口名称和链路标识符
NPW (Link ID 8)
UPW (Link ID 9)
Tun1 (VXLAN ID 0)
VLAN及总数
·     reset mld-snooping router-port
display mld-snooping static-group命令用来显示静态MLD Snooping IPv6组播组的信息。
(独立运行模式)
display mld-snooping static-group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ slot slot-number ]
display mld-snooping static-group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ chassis chassis-number slot slot-number ]
# 显示VLAN 2内静态MLD Snooping IPv6组播组的详细信息。
<Sysname> display mld-snooping static-group vlan 2 verbose
Total 1 entries.
  (::,FF1E::101)
    FSM information: dummy
      XGE3/0/2
# 显示VSI aaa内静态MLD Snooping IPv6组播组的详细信息。
<Sysname> display mld-snooping static-group vsi aaa verbose
Total 1 entries.
  (::,FF1E::101)
      XGE3/0/2 (Link ID 0)
表1-10 display mld-snooping static-group命令显示信息描述表
Total 1 entries
表项总数
VLAN 2内的表项总数
VSI aaa内的表项总数
(::,FF1E::101)
Attribute
表项属性,包括:
FSM information
表项状态机,包括:
·     dummy:表示新创建的临时表项
·     no info:表示没有表项存在
·     normal:表示创建的正式表项
成员端口及总数
GE1/0/2 (Link ID 0)
成员端口名称和链路标识符
·     mld-snooping static-group
display mld-snooping static-router-port命令用来显示IPv6静态路由器端口的信息。
(独立运行模式)
display mld-snooping static-router-port [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
display mld-snooping static-router-port [ vlan vlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
# 显示VLAN 2内IPv6静态路由器端口的简要信息。
<Sysname> display mld-snooping static-router-port vlan 2
VLAN 2:
    XGE3/0/1
    XGE3/0/2
# 显示VLAN 2内IPv6静态路由器端口的详细信息。
<Sysname> display mld-snooping static-router-port vlan 2 verbose
VLAN 2:
    XGE3/0/1
    XGE3/0/2
表1-11 display mld-snooping static-router-port命令显示信息描述表
VLAN 2
VLAN的编号
·     除指定单板外,其它所有有静态路由器端口的单板总数,以及各单板的槽位号;如果命令中未指定单板槽位编号,则表示除主控板外,其它所有有静态路由器端口的单板总数,以及各单板的槽位号(独立运行模式)
·     除指定单板外,其它所有有静态路由器端口的单板总数,以及各单板所在成员设备的编号和单板的槽位号;如果命令中未指任何成员设备的编号和单板的槽位编号,则表示除主用主控板外,其它所有有静态路由器端口的单板总数,以及各单板所在成员设备的编号和单板的槽位号(IRF模式)
静态路由器端口及总数
display mld-snooping statistics命令用来显示MLD Snooping监听到的MLD报文和IPv6 PIM hello报文的统计信息。
# 显示MLD Snooping监听到的MLD报文和IPv6 PIM hello报文的统计信息。
<Sysname> display mld-snooping statistics
Received MLD messages:
  MLD general queries: 19
    M-LAG: 19
  MLDv1 specific queries: 0
    M-LAG: 0
  MLDv2 specific queries: 0
    M-LAG: 0
  MLDv2 specific sg queries: 0
    M-LAG: 0
  MLDv1 reports: 19
    M-LAG: 19
  MLDv2 reports: 0
    M-LAG: 0
  MLDv2 reports with right and wrong records: 0
    M-LAG: 0
  MLD dones: 5
    M-LAG: 5
  Error MLD messages: 1
    M-LAG: 1
Sent MLD messages:
Received IPv6 PIM hello: 0
表1-12 display mld-snooping statistics命令显示信息描述表
MLD Snooping监听到的设备接收的MLD报文
Sent MLD messages
MLD Snooping监听到的设备发送的MLD报文
general queries
MLD普遍组查询报文的数量
specific queries
MLD特定组查询报文的数量
reports
MLD成员关系报告报文的数量
dones
MLD离开组报文的数量
包含错误和正确纪录的MLD成员关系报告报文数量
specific sg queries
MLD特定源组查询报文的数量
MLD Snooping监听到的设备接收的IPv6 PIM hello报文的数量
error MLD messages
错误MLD报文的数量
M-LAG
MLD Snooping监听到的设备通过M-LAG的peer-link接口接收的MLD报文
·     reset mld-snooping statistics
dot1p-priority命令用来全局配置MLD报文的802.1p优先级。
undo dot1p-priority命令用来恢复缺省情况。
dot1p-priority priority
undo dot1p-priority
MLD报文的802.1p优先级为6。
MLD-Snooping视图
priority:MLD报文的802.1p优先级,取值范围为0~7。该数值越大,优先级越高。
对于基于VLAN的配置,本命令与mld-snooping dot1p-priority命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有VLAN都有效,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高;对于基于VSI的配置,MLD-Snooping视图下的全局配置对所有VSI都有效。
# 全局配置MLD报文的802.1p优先级为3。
[Sysname] mld-snooping
[Sysname-mld-snooping] dot1p-priority 3
·     mld-snooping dot1p-priority
1.1.14  dscp
dscp命令用来配置设备发送MLD协议报文的DSCP优先级。
undo dscp命令用来恢复缺省情况。
dscp dscp-value
undo dscp
设备发送MLD协议报文的DSCP优先级为48。
MLD Snooping视图
dscp-value:DSCP值,取值范围为0~63。
DSCP(Differentiated Services Code Point,差分服务编码点)携带在IP报文中的ToS字段,用来体现报文自身的优先等级,决定报文传输的优先程度。DSCP优先级的取值越大,报文的优先级越高。
# 配置设备发送MLD协议报文的DSCP优先级为63。
[Sysname-mld-snooping] dscp 63
enable命令用来使能单个或多个VLAN内的MLD Snooping。
undo enable命令用来关闭单个或多个VLAN内的MLD Snooping。
enable vlan vlan-list
undo enable vlan vlan-list
VLAN内的MLD Snooping状态与全局MLD Snooping的状态保持一致。
MLD-Snooping视图
vlan vlan-list:表示对指定VLAN进行配置。vlan-list为VLAN列表,表示一或多个VLAN,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
在使能VLAN内的MLD Snooping之前,必须先开启设备的MLD Snooping特性。
对于基于VLAN的配置,本命令与mld-snooping enable命令的功能相同,只是作用范围不同:MLD-Snooping视图下可以对指定VLAN进行配置,VLAN视图下只能对当前VLAN进行配置,二者的配置优先级相同。
# 开启设备的MLD Snooping特性,并使能VLAN 2~10内的MLD Snooping。
[Sysname-mld-snooping] enable vlan 2 to 10
·     mld-snooping
entry-limit命令用来配置MLD Snooping转发表项(包括动态表项和静态表项)的全局最大数量。
undo entry-limit命令用来恢复缺省情况。
entry-limit limit
undo entry-limit
MLD Snooping转发表项的全局最大数量为4294967295。
MLD-Snooping视图
limit:表示MLD Snooping转发表项的全局最大数量,取值范围为0~4294967295。
# 配置MLD Snooping转发表项的全局最大数量为512个。
[Sysname-mld-snooping] entry-limit 512
fast-leave命令用来全局开启IPv6端口快速离开功能。
undo fast-leave命令用来全局关闭IPv6端口快速离开功能。
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
IPv6端口快速离开功能处于关闭状态。
MLD-Snooping视图
vlan vlan-list:表示对指定VLAN进行配置。vlan-list为VLAN列表,表示一或多个VLAN,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果未指定本参数,则表示对所有VLAN和VSI进行配置。
开启IPv6端口快速离开功能的端口,在收到主机发来的离开指定IPv6组播组的MLD离开组报文时,设备直接将该端口从相应转发表项的出端口列表中删除。
本命令与mld-snooping fast-leave命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
# 全局开启VLAN 2内的IPv6端口快速离开功能。
[Sysname-mld-snooping] fast-leave vlan 2
·     mld-snooping fast-leave
global-enable命令用来使能全局MLD Snooping。
undo global-enable命令用来关闭全局MLD Snooping。
global-enable
undo global-enable
全局MLD Snooping处于关闭状态。
MLD-Snooping视图
使能全局MLD Snooping后,若要在某些指定的VLAN/VSI内配置其他MLD Snooping功能,必须还要在这些指定的VLAN/VSI下再使能MLD Snooping。
# 使能全局MLD Snooping。
[Sysname-mld-snooping] global-enable
·     enable (MLD-Snooping view)
·     mld-snooping
·     mld-snooping disable
group-policy命令用来全局配置IPv6组播组过滤器,以限定主机所能加入的IPv6组播组。
undo group-policy命令用来全局删除IPv6组播组过滤器。
undo group-policy [ vlan vlan-list ]
未配置IPv6组播组过滤器,即主机可以加入任意合法的IPv6组播组。
MLD-Snooping视图
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。主机只能加入该ACL规则所允许的IPv6组播组。当指定的ACL不存在或ACL中未配置有效规则,将过滤掉所有IPv6组播组。
本命令只对IPv6动态组播组有效,对IPv6静态组播组无效。
本命令与mld-snooping group-policy命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
指定IPv6 ACL时,需要注意的是:
·     对于IPv6基本ACL,该ACL规则中的source参数用来指定MLD报文中的IPv6组播组地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
·     对于IPv6高级ACL,该ACL规则中的source参数用来指定MLD报文中的IPv6组播源地址(对于MLDv1报文和未携带IPv6组播源地址的IS_EX/TO_EX类型的MLDv2报文,视其IPv6组播源地址为0::0)范围,destination参数用来指定IPv6组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
·     可以为端口在不同的VLAN内配置不同的ACL规则,但在相同VLAN内所配置的新规则会取代旧规则。
# 全局配置IPv6组播组过滤器,以限定VLAN 2内的主机只能加入IPv6组播组FF03::101。
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source ff03::101 128
[Sysname-mld-snooping] group-policy 2000 vlan 2
·     mld-snooping group-policy
host-aging-time命令用来全局配置IPv6动态成员端口的老化时间。
undo host-aging-time命令用来恢复缺省情况。
host-aging-time seconds
IPv6动态成员端口的老化时间为260秒。
MLD-Snooping视图
seconds:表示IPv6动态成员端口的老化时间,取值范围为1~8097894,单位为秒。
本命令与mld-snooping host-aging-time命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有VLAN和VSI都有效,VLAN视图/VSI视图下的配置只对当前VLAN/VSI有效,后者的配置优先级较高。
为避免误删组播组成员,请确保配置动态成员端口的老化时间大于MLD普遍组查询报文的发送间隔与MLD普遍组查询的最大响应时间之和。建议配置动态成员端口的老化时间为MLD普遍组查询报文的发送间隔的2倍与MLD普遍组查询的最大响应时间之和。
# 全局配置IPv6动态成员端口的老化时间为300秒。
[Sysname-mld-snooping] host-aging-time 300
·     mld-snooping host-aging-time
host-tracking命令用来全局开启MLD Snooping主机跟踪功能。
undo host-tracking命令用来全局关闭MLD Snooping主机跟踪功能。
host-tracking
undo host-tracking
MLD Snooping主机跟踪功能处于关闭状态
MLD-Snooping视图
本命令与mld-snooping host-tracking命令的功能相同,只是作用范围不同:host-tracking命令对所有VLAN都有效,mld-snooping host-tracking命令只对当前VLAN有效,二者的配置优先级相同。
# 全局开启MLD Snooping主机跟踪功能。
[Sysname-mld-snooping] host-tracking
·     display mld-snooping host-tracking
last-listener-query-interval命令用来全局配置MLD特定组查询报文的发送间隔。
undo last-listener-query-interval命令用来恢复缺省情况。
MLD特定组查询报文的发送间隔为1秒。
MLD-Snooping视图
interval:表示MLD特定组查询报文的发送间隔,取值范围为1~25,单位为秒。
本命令与mld-snooping last-listener-query-interval命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有VLAN和VSI都有效,VLAN视图/VSI视图下的配置只对当前VLAN/VSI有效,后者的配置优先级较高。
# 全局配置MLD特定组查询报文的发送间隔为3秒。
[Sysname-mld-snooping] last-listener-query-interval 3
·     mld-snooping last-listener-query-interval
max-response-time命令用来全局配置MLD普遍组查询的最大响应时间。
undo max-response-time命令用来恢复缺省情况。
max-response-time seconds
MLD普遍组查询的最大响应时间为10秒。
MLD-Snooping视图
seconds:表示MLD普遍组查询的最大响应时间,取值范围为1~3174,单位为秒。
本命令与mld-snooping max-response-time命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有VLAN和VSI都有效,VLAN视图/VSI视图下的配置只对当前VLAN/VSI有效,后者的配置优先级较高。
为避免误删IPv6组播组成员,请确保MLD普遍组查询的最大响应时间小于MLD普遍组查询报文的发送间隔,否则配置虽能生效但系统会给出提示。
# 全局配置MLD普遍组查询的最大响应时间为5秒。
[Sysname-mld-snooping] max-response-time 5
·     mld-snooping max-response-time
·     mld-snooping query-interval
1.1.24  mld-snooping
mld-snooping命令用来开启设备的MLD Snooping特性,并进入MLD-Snooping视图。
undo mld-snooping命令用来关闭设备的MLD Snooping特性。
mld-snooping
undo mld-snooping
设备的MLD Snooping特性处于关闭状态。
关闭设备的MLD Snooping特性后所有VLAN/VSI的MLD Snooping都将关闭。
# 开启设备的MLD Snooping特性,并进入MLD-Snooping视图。
mld-snooping done source-ip命令用来配置MLD离开组报文的源IPv6地址。
undo mld-snooping done source-ip命令用来恢复缺省情况。
在VLAN内,MLD离开组报文的源IPv6地址为当前VLAN接口的IPv6链路本地地址;若当前VLAN接口没有IPv6链路本地地址,则采用FE80::02FF:FFFF:FE00:0001。
在VSI内,MLD离开组报文的源IPv6地址为VSI绑定的VSI接口的IPv6链路本地地址;若绑定的VSI接口没有IPv6链路本地地址,则采用FE80::02FF:FFFF:FE00:0001。
VLAN视图
VSI视图
ipv6-address:表示MLD离开组报文的源IPv6地址。
在配置本命令之前,必须先在VLAN内使能MLD Snooping。
# 在VLAN 2内使能MLD Snooping,并配置MLD离开组报文的源IPv6地址为FE80:0:0:1::1。
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] mld-snooping done source-ip fe80:0:0:1::1
# 在VSI aaa内使能MLD Snooping,并配置MLD离开组报文的源IPv6地址为FE80:0:0:1::1。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping enable
[Sysname-vsi-aaa] mld-snooping done source-ip fe80:0:0:1::1
mld-snooping dot1p-priority命令用来在VLAN内配置MLD报文的802.1p优先级。
undo mld-snooping dot1p-priority命令用来恢复缺省情况。
VLAN内MLD报文的802.1p优先级为6。
VLAN视图
对于基于VLAN的配置,本命令与dot1p-priority命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有VLAN都有效,VLAN视图下的配置只对当前VLAN有效,后者的配置优先级较高。
# 在VLAN 2内使能MLD Snooping,并配置MLD报文的802.1p优先级为3。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping dot1p-priority 3
·     dot1p-priority (MLD-Snooping view)
mld-snooping drop-unknown命令用来在VLAN/VSI内开启丢弃未知IPv6组播数据报文功能。
undo mld-snooping drop-unknown命令用来在VLAN/VSI内关闭丢弃未知IPv6组播数据报文功能。
丢弃未知IPv6组播数据报文功能处于关闭状态,即对未知IPv6组播数据报文进行广播。
VLAN视图
VSI视图
在配置本命令之前,必须先在VLAN/VSI内使能MLD Snooping。
IPv6组播VLAN视图下,不支持配置本命令。有关IPv6组播VLAN的详细介绍,请参见“IP组播配置指导”中的“IPv6组播VLAN”。
# 在VLAN 2内使能MLD Snooping,并开启丢弃未知IPv6组播数据报文功能。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping drop-unknown
# 在VSI aaa内使能MLD Snooping,并开启丢弃未知IPv6组播数据报文功能。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping drop-unknown
mld-snooping enable命令用来使能单个VLAN/VSI内的MLD Snooping。
mld-snooping disable命令用来在单个VLAN/VSI内关闭MLD Snooping。
undo mld-snooping命令用来将单个VLAN/VSI内MLD Snooping状态恢复成当前全局MLD Snooping的状态。
undo mld-snooping
VLAN/VSI内MLD Snooping的状态与全局MLD Snooping的状态保持一致。
VLAN视图
VSI视图
使能单个VLAN/VSI内的MLD Snooping之前,必须先在系统视图下配置mld-snooping
对于基于VLAN的配置,本命令与enable命令的功能相同,只是作用范围不同:MLD-Snooping视图下可以对指定VLAN进行配置,VLAN视图下只能对当前VLAN进行配置,二者的配置优先级相同。
# 开启设备的MLD Snooping特性,并在VLAN 2内使能MLD Snooping。
[Sysname] vlan 2
# 在VLAN 2内关闭MLD Snooping。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping disable
# 开启设备的MLD Snooping特性,并在VSI aaa内使能MLD Snooping。
[Sysname] vsi aaa
# 在VSI aaa内关闭MLD Snooping。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping disable
·     mld-snooping
mld-snooping fast-leave命令用来在端口上开启IPv6端口快速离开功能。
undo mld-snooping fast-leave命令用来在端口上关闭IPv6端口快速离开功能。
undo mld-snooping fast-leave [ vlan vlan-list ]
IPv6端口快速离开功能处于关闭状态。
二层以太网接口视图
二层聚合接口视图
vlan vlan-list:表示对指定VLAN进行配置。vlan-list为VLAN列表,表示一或多个VLAN,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果未指定本参数,则表示对所有VLAN进行配置。
本命令与fast-leave命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
# 将端口Ten-GigabitEthernet3/0/1在VLAN 2内开启IPv6端口快速离开功能。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] mld-snooping fast-leave vlan 2
·     fast-leave (MLD-Snooping view)
mld-snooping general-query source-ip命令用来配置MLD普遍组查询报文的源IPv6地址。
undo mld-snooping general-query source-ip命令用来恢复缺省情况。
在VLAN内,MLD普遍组查询报文的源IPv6地址为当前VLAN接口的IPv6链路本地地址;若当前VLAN接口没有IPv6链路本地地址,则采用FE80::02FF:FFFF:FE00:0001。
在VSI内,MLD普遍组查询报文的源IPv6地址为VSI绑定的VSI接口的IPv6链路本地地址;若绑定的VSI接口没有IPv6链路本地地址,则采用FE80::02FF:FFFF:FE00:0001。
VLAN视图
VSI视图
ipv6-address:表示MLD普遍组查询报文的源IPv6地址。
# 在VLAN 2内使能MLD Snooping,并配置MLD普遍组查询报文的源IPv6地址为FE80:0:0:1::1。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping general-query source-ip fe80:0:0:1::1
# 在VSI aaa内使能MLD Snooping,并配置MLD普遍组查询报文的源IPv6地址为FE80:0:0:1::1。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping general-query source-ip fe80:0:0:1::1
mld-snooping group-limit命令用来配置端口加入的IPv6组播组最大数量。
undo mld-snooping group-limit命令用来取消对端口加入IPv6组播组最大数量的限制。
undo mld-snooping group-limit [ vlan vlan-list ]
未对端口加入的IPv6组播组最大数量进行限制。
二层以太网接口视图
二层聚合接口视图
limit:表示端口加入的IPv6组播组最大数量,取值范围为0~4294967295。
# 配置端口Ten-GigabitEthernet3/0/1在VLAN 2内加入的IPv6组播组最大数量为10个。
[Sysname-Ten-GigabitEthernet3/0/1] mld-snooping group-limit 10 vlan 2
mld-snooping group-policy命令用来在端口上配置IPv6组播组过滤器,以限定主机所能加入的IPv6组播组。
undo mld-snooping group-policy命令用来在端口上删除IPv6组播组过滤器。
undo mld-snooping group-policy [ vlan vlan-list ]
二层以太网接口视图
二层聚合接口视图
本命令与group-policy命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
指定IPv6  ACL时,需要注意的是:
# 在端口Ten-GigabitEthernet3/0/1上配置IPv6组播组过滤器,以限定端口Ten-GigabitEthernet3/0/1下VLAN 2内的主机只能加入IPv6组播组FF03::101。
[Sysname-Ten-GigabitEthernet3/0/1] mld-snooping group-policy 2000 vlan 2
·     group-policy (MLD-Snooping view)
mld-snooping host-aging-time命令用来在VLAN/VSI内配置IPv6动态成员端口的老化时间。
undo mld-snooping host-aging-time命令用来恢复缺省情况。
VLAN或VSI视图下,IPv6动态成员端口的老化时间以MLD-Snooping视图下配置的老化时间(通过host-aging-time命令配置)为准。
VLAN视图
VSI视图
本命令与host-aging-time命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有VLAN和VSI都有效,VLAN视图/VSI视图下的配置只对当前VLAN/VSI有效,后者的配置优先级较高。
# 在VLAN 2内使能MLD Snooping,并配置IPv6动态成员端口的老化时间为300秒。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-aging-time 300
# 在VSI aaa内使能MLD Snooping,并配置IPv6动态成员端口的老化时间为300秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping host-aging-time 300
·     host-aging-time (MLD-Snooping view)
mld-snooping host-join命令用来配置模拟主机加入IPv6组播组或IPv6组播源组。模拟主机加入就是将二层设备的端口配置为IPv6组播组的成员。
undo mld-snooping host-join命令用来删除模拟主机加入的配置。
undo mld-snooping host-join { ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id | all }
未配置模拟主机加入IPv6组播组或IPv6组播源组。
二层以太网接口视图
二层聚合接口视图
ipv6-group-address:表示模拟主机要加入的IPv6组播组的地址,取值范围为FFxy::/16(但不包括下FFx1::/16和FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。
source-ip ipv6-source-address:表示模拟主机要加入的IPv6组播源的地址。如果指定了本参数,表示加入IPv6组播源组;如果未指定本参数,则表示加入IPv6组播组。配置有本参数的模拟主机,只在MLD Snooping版本2下生效。当前暂不支持配置该参数。
vlan vlan-id:表示对指定VLAN进行配置。vlan-id为VLAN的编号,取值范围为1~4094。
all:表示对所有IPv6组播组和IPv6组播源组进行配置。
与静态成员端口不同,配置了模拟主机加入的端口将作为动态成员端口参与动态成员端口的老化过程。
模拟主机所采用的MLD版本与MLD Snooping的版本一致。
# 在端口Ten-GigabitEthernet3/0/1上配置模拟主机加入VLAN 2内的IPv6组播组(*,FF3E::101)。
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Ten-GigabitEthernet3/0/1] mld-snooping host-join ff3e::101 vlan 2
mld-snooping host-tracking命令用来在VLAN内开启MLD Snooping主机跟踪功能。
undo mld-snooping host-tracking命令用来在VLAN内关闭MLD Snooping主机跟踪功能。
MLD Snooping主机跟踪功能处于关闭状态。
VLAN视图
本命令与host-tracking命令的功能相同,只是作用范围不同:host-tracking命令对所有VLAN都有效,mld-snooping host-tracking命令只对当前VLAN有效,二者的配置优先级相同。
# 在VLAN 2内使能MLD Snooping,并开启MLD Snooping主机跟踪功能。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-tracking
mld-snooping last-listener-query-interval命令用来在VLAN/VSI内配置MLD特定组查询报文的发送间隔。
undo mld-snooping last-listener-query-interval命令用来恢复缺省情况。
MLD特定组查询报文的发送间隔为1秒。
VLAN视图
VSI视图
本命令与last-listener-query-interval命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有VLAN和VSI都有效,VLAN视图/VSI视图下的配置只对当前VLAN/VSI有效,后者的配置优先级较高。
# 在VLAN 2内使能MLD Snooping,并配置MLD特定组查询报文的发送间隔为3秒。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping last-listener-query-interval 3
# 在VSI aaa内使能MLD Snooping,并配置MLD特定组查询报文的发送间隔为3秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping last-listener-query-interval 3
·     last-listener-query-interval (MLD-Snooping view)
mld-snooping log enable命令用来开启MLD Snooping日志信息功能。
undo mld-snooping log enable命令用来关闭MLD Snooping日志信息功能。
mld-snooping log enable [ group ]
undo mld-snooping log enable [ group ]
MLD Snooping日志信息功能处于开启状态。
MLD Snooping视图
group:MLD Snooping二层组播转发表项相关的日志信息。如果未指定本参数,则表示开启或关闭MLD Snooping所有日志信息功能。
MLD Snooping日志信息可以方便管理员定位问题和解决问题,生成的日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
当设备输出大量MLD Snooping日志信息时,会降低设备性能。此时,用户可以关闭MLD Snooping日志信息功能。
# 开启MLD Snooping所有日志信息功能。
[Sysname-mld-snooping] mld-snooping log enable
·     mld-snooping log suppress
mld-snooping log suppress命令用来开启MLD Snooping日志限速功能。
undo mld-snooping log suppress命令用来关闭MLD Snooping日志限速功能。
mld-snooping log suppress [ group ]
undo mld-snooping log suppress [ group ]
MLD Snooping的日志限速功能处于开启状态。
MLD Snooping视图
group:MLD Snooping二层组播转发表项相关的日志信息。如果未指定本参数,则表示开启或关闭MLD Snooping所有类型日志限速功能。
当设备输出大量MLD Snooping日志信息时,会降低设备性能。此时,可以通过本命令开启MLD Snooping日志限速功能。开启本功能后,MLD Snooping模块输出到信息中心的日志速度将会被限制,从而减轻设备的负担。
# 关闭MLD Snooping的日志限速功能。
[Sysname-mld-snooping] undo mld-snooping log suppress
·     mld-snooping log enable
mld-snooping max-response-time命令用来在VLAN/VSI内配置MLD普遍组查询的最大响应时间。
undo mld-snooping max-response-time命令用来恢复缺省情况。
VLAN视图
VSI视图
本命令与max-response-time命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有VLAN和VSI都有效,VLAN视图/VSI视图下的配置只对当前VLAN/VSI有效,后者的配置优先级较高。
# 在VLAN 2内使能MLD Snooping,并配置MLD普遍组查询的最大响应时间为5秒。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping max-response-time 5
# 在VSI aaa内使能MLD Snooping,并配置MLD普遍组查询的最大响应时间为5秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping max-response-time 5
·     max-response-time (MLD-Snooping view)
mld-snooping overflow-replace命令用来在端口上开启IPv6组播组替换功能。
undo mld-snooping overflow-replace命令用来在端口上关闭IPv6组播组替换功能。
undo mld-snooping overflow-replace [ vlan vlan-list ]
IPv6组播组替换功能处于关闭状态。
二层以太网接口视图
二层聚合接口视图
本命令与overflow-replace命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
# 将端口Ten-GigabitEthernet3/0/1在VLAN2内开启IPv6组播组替换功能。
[Sysname-Ten-GigabitEthernet3/0/1] mld-snooping overflow-replace vlan 2
·     overflow-replace (MLD-Snooping view)
mld-snooping proxy enable命令用来在VLAN/VSI内开启MLD Snooping Proxy功能。
undo mld-snooping proxy enable命令用来在VLAN/VSI内关闭MLD Snooping Proxy功能。
MLD Snooping Proxy功能处于关闭状态。
VLAN视图
VSI视图
如果配置MLD Snooping Proxy功能的VLAN是IPv6组播VLAN的子VLAN,则MLD Snooping Proxy功能不会生效。
# 在VLAN 2内使能MLD Snooping,并开启MLD Snooping Proxy功能。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping proxy enable
# 在VSI aaa内使能MLD Snooping,并开启MLD Snooping Proxy功能。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping proxy enable
·     subvlan (IPv6 multicast-VLAN view)(IP组播命令参考/IPv6组播VLAN)
mld-snooping querier命令用来开启MLD Snooping查询器。
undo mld-snooping querier命令用来关闭MLD Snooping查询器。
MLD Snooping查询器处于关闭状态。
VLAN视图
VSI视图
如果在IPv6组播VLAN的子VLAN内配置了本命令,只有当该子VLAN从IPv6组播VLAN中删除后,MLD Snooping查询器才会生效。
# 在VLAN 2内使能MLD Snooping,并开启MLD Snooping查询器。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier
# 在VSI aaa内使能MLD Snooping,并开启MLD Snooping查询器。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping querier
mld-snooping querier-election命令用来在VLAN/VSI内开启MLD Snooping查询器选举功能。
undo mld-snooping querier-election命令用来在VLAN/VSI内关闭MLD Snooping查询器选举功能。
MLD Snooping查询器选举功能处于关闭状态。
VLAN视图
VSI视图
只有MLD Snooping查询器功能开启时,MLD Snooping查询器选举功能才能生效。
# 在VLAN 2内使能MLD Snooping,并开启查询器选举功能。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier-election
# 在VSI aaa内使能MLD Snooping,并开启查询器选举功能。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping querier-election
·     mld-snooping querier
mld-snooping query-interval命令用来在VLAN/VSI内配置MLD普遍组查询报文的发送间隔。
undo mld-snooping query-interval命令用来恢复缺省情况。
MLD普遍组查询报文的发送间隔为125秒。
VLAN视图
VSI视图
interval:表示MLD普遍组查询报文的发送间隔,取值范围为2~31744,单位为秒。
为避免误删IPv6组播组成员,请确保MLD普遍组查询报文的发送间隔大于MLD普遍组查询的最大响应时间,否则配置虽能生效但系统会给出提示。
# 在VLAN 2内使能MLD Snooping,并配置MLD普遍组查询报文的发送间隔为20秒。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping query-interval 20
# 在VSI aaa内使能MLD Snooping,并配置MLD普遍组查询报文的发送间隔为20秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping query-interval 20
·     max-response-time
mld-snooping report source-ip命令用来配置MLD成员关系报告报文的源IPv6地址。
undo mld-snooping report source-ip命令用来恢复缺省情况。
在VLAN内MLD成员关系报告报文的源IPv6地址为当前VLAN接口的IPv6链路本地地址;若当前VLAN接口没有IPv6链路本地地址,则采用FE80::02FF:FFFF:FE00:0001。
在VSI内,MLD成员关系报告报文的源IPv6地址为VSI绑定的VSI接口的IPv6链路本地地址;若绑定的VSI接口没有IPv6链路本地地址,则采用FE80::02FF:FFFF:FE00:0001。
VLAN视图
VSI视图
ipv6-address:表示MLD成员关系报告报文的源IPv6地址。
# 在VLAN 2内使能MLD Snooping,并配置MLD成员关系报告报文的源IPv6地址为FE80:0:0:1::1。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping report source-ip fe80:0:0:1::1
# 在VSI aaa内使能MLD Snooping,并配置MLD成员关系报告报文的源IPv6地址为FE80:0:0:1::1。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping report source-ip fe80:0:0:1::1
mld-snooping router-aging-time命令用来在VLAN/VSI内配置IPv6动态路由器端口的老化时间。
undo mld-snooping router-aging-time命令用来恢复缺省情况。
IPv6动态路由器端口的老化时间为260秒。
VLAN视图
VSI视图
seconds:表示IPv6动态路由器端口的老化时间,取值范围为1~8097894,单位为秒。
本命令与router-aging-time命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有VLAN和VSI都有效,VLAN视图/VSI视图下的配置只对当前VLAN/VSI有效,后者的配置优先级较高。
# 在VLAN 2内使能MLD Snooping,并配置IPv6动态路由器端口的老化时间为100秒。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping router-aging-time 100
# 在VSI aaa内使能MLD Snooping,并配置IPv6动态路由器端口的老化时间为100秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping router-aging-time 100
·     router-aging-time (MLD-Snooping view)
mld-snooping router-port-deny命令用来禁止端口成为动态路由器端口。
undo mld-snooping router-port-deny命令用来允许端口成为动态路由器端口。
undo mld-snooping router-port-deny [ vlan vlan-list ]
二层以太网接口视图
二层聚合接口视图
端口可以成为动态路由器端口。
vlan vlan-list:表示对指定VLAN进行配置。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果指定了本参数,只有当该端口属于指定VLAN时,本配置才生效;如果未指定本参数,则本配置将对该端口所属的所有VLAN都生效。
# 禁止端口Ten-GigabitEthernet3/0/1在VLAN 2内成为动态路由器端口。
[Sysname-Ten-GigabitEthernet3/0/1] mld-snooping router-port-deny vlan 2
mld-snooping router-port-discard命令用来配置组播数据不向VLAN内的路由器端口转发。
undo mld-snooping router-port-discard命令用来恢复缺省情况。
VLAN视图
组播数据向VLAN内的路由器端口转发。
缺省情况下,二层组播设备在从上游收到组播数据后,会向VLAN内的所有路由器端口进行转发。在某些情况下,比如二层组播设备上所有的接口都被配置为了静态路由器端口,组播数据会向设备上所有的路由器端口转发,造成带宽的浪费。此时,如果不需要组播数据向某些VLAN中的路由器端口转发,可以通过在这些VLAN下配置本命令来实现。
在配置本命令之前,必须先在VLAN内开启MLD Snooping功能。
# 配置组播数据不向VLAN内的路由器端口转发。
[Sysname] vlan 10
[Sysname-vlan10] mld-snooping enable
[Sysname-vlan10] mld-snooping router-port-discard
·     mld-snooping
mld-snooping source-deny命令用来开启端口的IPv6组播数据报文源端口过滤功能。
undo mld-snooping source-deny命令用来关闭端口的IPv6组播数据报文源端口过滤功能。
IPv6组播数据报文源端口过滤功能处于关闭状态。
二层以太网接口视图
本命令与source-deny命令的功能相同,只是作用范围不同:MLD-Snooping视图下可以对指定端口进行配置,端口视图下只能对当前端口进行配置,二者的配置优先级相同。
# 在端口Ten-GigabitEthernet3/0/1上开启IPv6组播数据报文源端口过滤功能。
[Sysname-Ten-GigabitEthernet3/0/1] mld-snooping source-deny
·     source-deny (MLD-Snooping view)
mld-snooping special-query source-ip命令用来配置MLD特定组查询报文的源IPv6地址。
undo mld-snooping special-query source-ip命令用来恢复缺省情况。
在VLAN内,如果收到过MLD普遍组查询报文,则以其源IPv6地址作为MLD特定组查询报文的源IPv6地址;否则,采用当前VLAN接口的IPv6链路本地地址;若当前VLAN接口没有IPv6链路本地地址,则采用FE80::02FF:FFFF:FE00:0001。
在VSI内,如果收到过MLD普遍组查询报文,则以其源IPv6地址作为MLD特定组查询报文的源IPv6地址;否则,采用VSI绑定的VSI接口的IPv6链路本地地址;若绑定的VSI接口没有IPv6链路本地地址,则采用FE80::02FF:FFFF:FE00:0001。
VLAN视图
VSI视图
ipv6-address:表示MLD特定组查询报文的源IPv6地址。
# 在VLAN 2内使能MLD Snooping,并配置MLD特定组查询报文的源IPv6地址为FE80:0:0:1::1。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping special-query source-ip fe80:0:0:1::1
# 在VSI aaa内使能MLD Snooping,并配置MLD特定组查询报文的源IPv6地址为FE80:0:0:1::1。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping special-query source-ip fe80:0:0:1::1
mld-snooping static-group命令用来配置IPv6静态成员端口,即配置端口静态加入IPv6组播组或IPv6组播源组。
undo mld-snooping static-group命令用来删除静态成员端口的配置。
mld-snooping static-group ipv6-group-address [ source-ip ipv6-source-address ] { vlan vlan-id | service-instance instance-id }
undo mld-snooping static-group { ipv6-group-address [ source-ip ipv6-source-address ] { vlan vlan-id | service-instance instance-id } | all }
端口不是IPv6静态成员端口。
二层以太网接口视图
二层聚合接口视图
ipv6-group-address:表示静态加入的IPv6组播组地址,取值范围为FFxy::/16(但不包括FFx1::/16和FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。
source-ip ipv6-source-address:表示静态加入的IPv6组播源地址。如果指定了本参数,表示加入IPv6组播源组;如果未指定本参数,则表示加入IPv6组播组。配置有本参数的静态成员端口,只在MLD Snooping版本2下生效。当前暂不支持配置该参数。
service-instance instance-id:表示对指定以太网服务实例进行配置。instance-id表示以太网服务实例的编号,取值范围为1~4096。
通过指定service-instance参数将接口配置为VSI内指定组播源组的静态成员端口时,请确保该以太网服务实例关联了已存在的VSI。
# 将端口Ten-GigabitEthernet3/0/1配置为IPv6组播组(*,FF3E::101)在VLAN 2内的静态成员端口。
[Sysname] vlan 2
[Sysname-Ten-GigabitEthernet3/0/1] mld-snooping static-group ff3e::101 vlan 2
# 将端口Ten-GigabitEthernet3/0/1配置为IPv6组播组(*,FF3E::101)在VSI aaa内的静态成员端口。
[Sysname] l2vpn enable
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping version 3
[Sysname-vsi-aaa] quit
[Sysname-Ten-GigabitEthernet3/0/1] service-instance 2
[Sysname-Ten-GigabitEthernet3/0/1-srv2] encapsulation s-vid 2
[Sysname-Ten-GigabitEthernet3/0/1-srv2] xconnect vsi aaa
[Sysname-Ten-GigabitEthernet3/0/1-srv2] quit
[Sysname-Ten-GigabitEthernet3/0/1] mld-snooping static-group ff3e::101 service-instance 2
mld-snooping static-router-port命令用来配置IPv6静态路由器端口。
undo mld-snooping static-router-port命令用来删除静态路由器端口的配置。
undo mld-snooping static-router-port { all | vlan vlan-id }
端口不是IPv6静态路由器端口。
二层以太网接口视图
二层聚合接口视图
all:表示对所有VLAN进行配置。
# 将端口Ten-GigabitEthernet3/0/1配置为VLAN 2内的IPv6静态路由器端口。
[Sysname-Ten-GigabitEthernet3/0/1] mld-snooping static-router-port vlan 2
mld-snooping triggered-query enable命令用来配置设备在端口链路状态发生变化时立刻发送MLD普遍组查询报文,以及时更新组播转发表项。
undo mld-snooping triggered-query enable命令用来恢复缺省情况。
mld-snooping triggered-query enable { port-down | port-up } *
undo mld-snooping triggered-query enable [ port-down | port-up ] *
端口链路状态发生变化时,设备不会立刻发送MLD普遍组查询报文。
VLAN视图
port-down:VLAN内若有端口链路状态变为down,设备会立刻发送MLD普遍组查询报文。
port-up:VLAN内若有端口链路变为up,设备会立刻发送MLD普遍组查询报文。
为了提高可靠性,组播接收者侧的设备通过以太网冗余接口接入二层组播设备。以太网冗余接口中包含两个成员端口。通常组播数据会通过处于激活状态的成员接口,转发给下游的接收者。当处于激活状态的接口链路发生故障时,由于二层组播设备不会立即发送MLD普遍组查询报文,无法及时将另一个成员接口学习到组播转发表项的成员端口中,导致组播数据无法不能及时切换到另一个成员接口所在的链路上进行传输。有关以太网冗余接口的详细说明,请参见“可靠性配置指导”中的“冗余备份”。
配置本命令后,当设备感知到VLAN内的端口链路状态发生变化时,会立刻发送MLD普遍组查询报文,更新网络中成员端口信息,将组播数据流迅速切换到新的转发链路上。
执行undo mld-snooping triggered-query enable命令时,如果没有指定任何参数,则表示VLAN内的端口状态无论是变为down还是up,设备都不会立刻发送MLD普遍组查询报文。
# 配置设备在端口链路状态发生变化时,立刻发送MLD普遍组查询报文。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping triggered-query enable port-down port-up
mld-snooping version命令用来在VLAN/VSI内配置MLD Snooping的版本。
undo mld-snooping version命令用来恢复缺省情况。
VLAN/VSI内MLD Snooping的版本为1。
VLAN视图
VSI视图
version-number:表示MLD Snooping的版本号,取值范围为1~2。
对于基于VLAN的配置,本命令与version命令的功能相同,只是作用范围不同:MLD-Snooping视图下可以对指定VLAN进行配置,VLAN视图下只能对当前VLAN进行配置,二者的配置优先级相同。
# 在VLAN 2内使能MLD Snooping,并配置该VLAN内的MLD Snooping版本为2。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping version 2
# 在VSI aaa内使能MLD Snooping,并配置该VSI内的MLD Snooping版本为2。
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping version 2
·     version (MLD-Snooping view)
overflow-replace命令用来全局开启IPv6组播组替换功能。
undo overflow-replace命令用来全局关闭IPv6组播组替换功能。
undo overflow-replace [ vlan vlan-list ]
IPv6组播组替换功能处于关闭状态。
MLD-Snooping视图
本命令与mld-snooping overflow-replace命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有端口都有效,端口视图下的配置只对当前端口有效,后者的配置优先级较高。
# 全局开启VLAN 2内的IPv6组播组替换功能。
[Sysname-mld-snooping] overflow-replace vlan 2
·     mld-snooping overflow-replace
report-aggregation命令用来开启MLD成员关系报告报文抑制功能。
undo report-aggregation命令用来关闭MLD成员关系报告报文抑制功能。
report-aggregation
MLD成员关系报告报文抑制功能处于开启状态。
MLD-Snooping视图
# 关闭MLD成员关系报告报文抑制功能。
[Sysname-mld-snooping] undo report-aggregation
reset ipv6 l2-multicast fast-forwarding cache命令用来清除IPv6二层组播快速转发表中的转发项。
(独立运行模式)
reset ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] { { ipv6-source-address | ipv6-group-address } * | all } [ slot slot-number ]
reset ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] { { ipv6-source-address | ipv6-group-address } * | all } [ chassis chassis-number slot slot-number ]
vlan vlan-id:清除指定VLAN内的状态信息。vlan-id为VLAN的编号,取值范围为1~4094。
ipv6-source-address:组播源地址,清除包含指定IPv6组播源的二层组播快速转发表项。
ipv6-group-address:IPv6组播组地址,清除指定IPv6组播组的二层组播快速转发表项,取值范围为FFxy::/16(但不包括FFx1::/16和FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。
slot slot-number:清除指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将清除主控板上的信息。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除全局主用主控板上的信息。(IRF模式)
all:清除二层组播快速转发表中的所有组播转发项。
# 从IPv6二层组播快速转发表中清除所有组播转发表项。
<Sysname> reset ipv6 l2-multicast fast-forwarding cache all
# 从IPv6二层组播快速转发表中清除组播组为(*, FF1E::2)的转发表项。
<Sysname> reset ipv6 l2-multicast fast-forwarding cache FF1E::2
·     display ipv6 l2-multicast fast-forwarding cache
reset mld-snooping group命令用来清除动态MLD Snooping IPv6组播组的信息。
reset mld-snooping group { ipv6-group-address [ ipv6-source-address ] | all } [ vlan vlan-id | vsi vsi-name ]
ipv6-group-address:清除指定IPv6组播组的信息,取值范围为FFxy::/16(但不包括FFx1::/16和FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。
ipv6-source-address:清除指定IPv6组播源的信息。如果未指定本参数,将清除所有IPv6组播源的信息。
all:清除所有IPv6组播组的信息。
vlan vlan-id:清除指定VLAN内的信息。vlan-id为VLAN的编号,取值范围为1~4094。如果未指定本参数,将清除所有VLAN内的信息。
vsi vsi-name:清除指定VSI内的信息。vsi-name为VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将清除所有VSI内的信息。
# 清除所有动态MLD Snooping IPv6组播组的信息。
<Sysname> reset mld-snooping group all
·     display mld-snooping group
reset mld-snooping router-port命令用来清除IPv6动态路由器端口的信息。
reset mld-snooping router-port { all | vlan vlan-id | vsi vsi-name }
all:清除所有动态路由器端口的信息。
# 清除所有IPv6动态路由器端口的信息。
<Sysname> reset mld-snooping router-port all
·     display mld-snooping router-port
reset mld-snooping statistics命令用来清除MLD Snooping监听到的MLD报文和IPv6 PIM hello报文的统计信息。
# 清除MLD Snooping监听到的MLD报文和IPv6 PIM hello报文的统计信息。
<Sysname> reset mld-snooping statistics
·     display mld-snooping statistics
router-aging-time命令用来全局配置IPv6动态路由器端口的老化时间。
undo router-aging-time命令用来恢复缺省情况。
MLD-Snooping视图
本命令与mld-snooping router-aging-time命令的功能相同,只是作用范围不同:MLD-Snooping视图下的全局配置对所有VLAN和VSI都有效,VLAN视图/VSI视图下的配置只对当前VLAN/VSI有效,后者的配置优先级较高。
# 全局配置IPv6动态路由器端口的老化时间为100秒。
[Sysname-mld-snooping] router-aging-time 100
·     mld-snooping router-aging-time
send-query enable命令用来配置设备在链路拓扑发生变化时立刻发送MLD普遍组查询报文,以及时更新组播转发。
undo send-query enable命令用来恢复缺省情况。
send-query enable
设备不会因为链路拓扑发生变化而立刻发送MLD普遍组查询报文。
MLD-Snooping视图
当链路拓扑发生变化时,STP等协议会重新计算路径,将流量切换到新的路径。但是,在这种情况下,设备通常不会立即发送MLD普遍组查询报文,导致IPv6组播数据不能及时切换到变更后的路径上。通过配置本命令,可以配置设备在链路变化时主动发送MLD普遍组查询报文,更新网络中成员端口信息,将IPv6组播数据流迅速切换到新的转发路径上。
# 配置设备在链路拓扑发生变化时立刻发送MLD普遍组查询报文。
[Sysname-mld-snooping] send-query enable
·     mld-snooping
snmp-agent trap enable mld-snooping命令用来开启MLD Snooping告警功能。
undo snmp-agent trap enable mld-snooping命令用来关闭MLD Snooping告警功能。
snmp-agent trap enable mld-snooping [ entry-refresh-failed ]
undo snmp-agent trap enable mld-snooping [ entry-refresh-failed ]
MLD Snooping告警功能处于开启状态。
entry-refresh-failed:IPv6二层组播转发表项下发失败告警信息。未指定本参数时,表示开启或关闭MLD Snooping的所有告警功能。
开启了MLD Snooping告警功能之后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭MLD Snooping所有告警功能。
[Sysname] undo snmp-agent trap enable mld-snooping
source-deny命令用来开启指定端口的IPv6组播数据报文源端口过滤功能。
undo source-deny命令用来关闭指定端口的IPv6组播数据报文源端口过滤功能。
undo source-deny port interface-list
MLD-Snooping视图
port interface-list:表示对指定端口进行配置。interface-list为端口列表,表示一或多个端口,表示方式为interface-list = { interface-type interface-number [ to interface-type interface-number ] },其中,interface-type为接口类型,interface-number为接口编号。
本命令与mld-snooping source-deny命令的功能相同,只是作用范围不同:MLD-Snooping视图下可以对指定端口进行配置,端口视图下只能对当前端口进行配置,二者的配置优先级相同。
# 开启端口Ten-GigabitEthernet3/0/1~Ten-GigabitEthernet3/0/4上的IPv6组播数据报文源端口过滤功能。
[Sysname-mld-snooping] source-deny port ten-gigabitethernet 3/0/1 to ten-gigabitethernet 3/0/4
·     mld-snooping source-deny
version命令用来配置指定VLAN内的MLD Snooping的版本。
undo version命令用来恢复缺省情况。
undo version vlan vlan-list
VLAN内MLD Snooping的版本为1。
MLD-Snooping视图
对于基于VLAN的配置,本命令与mld-snooping version命令的功能相同,只是作用范围不同:MLD-Snooping视图下可以对指定VLAN进行配置,VLAN视图下只能对当前VLAN进行配置,二者的配置优先级相同。
# 使能VLAN 2~10内的MLD Snooping,并配置这些VLAN内的MLD Snooping版本为2。
[Sysname-mld-snooping] version 2 vlan 2 to 10
·     mld-snooping version
