01-DDoS攻击检测与防范命令
本章节下载: 01-DDoS攻击检测与防范命令 (753.42 KB)
1.1.1 ack-flood defense session-check
1.1.2 ack-flood detection threshold
1.1.6 anti-ddos blacklist timeout
1.1.7 anti-ddos cleaner deploy-mode
1.1.8 anti-ddos default-zone enable
1.1.9 anti-ddos detection-mode
1.1.11 anti-ddos log-server-ip
1.1.12 anti-ddos out-of-band interface
1.1.13 anti-ddos user-defined attack-type protocol
1.1.14 anti-ddos user-defined attack-type protocol icmp
1.1.15 anti-ddos user-defined attack-type protocol icmpv6
1.1.16 anti-ddos user-defined attack-type protocol tcp
1.1.17 anti-ddos user-defined attack-type protocol udp
1.1.19 anti-ddos whitelist timeout
1.1.21 bandwidth-detection destination-ip threshold
1.1.22 bandwidth-limit destination-ip type max-rate
1.1.28 display anti-ddos blacklist
1.1.29 display anti-ddos blacklist zone
1.1.30 display anti-ddos dynamic-blacklist
1.1.31 display anti-ddos filter statistics
1.1.32 display anti-ddos ssl-defend illegal-session-stat-nodes
1.1.33 display anti-ddos ssl-defend session-stat-nodes
1.1.34 display anti-ddos statistics
1.1.35 display anti-ddos statistics bandwidth-limit destination-ip
1.1.36 display anti-ddos statistics destination-ip
1.1.37 display anti-ddos statistics http-slow-attack
1.1.38 display anti-ddos whitelist
1.1.39 display anti-ddos whitelist zone
1.1.40 display anti-ddos zone configuration
1.1.41 dns-query-flood defense source-verify
1.1.42 dns-query-flood detection threshold
1.1.43 dns-reply-flood defense source-verify
1.1.44 dns-reply-flood detection threshold
1.1.47 fingerprint (filter view)
1.1.48 fingerprint (fingerprint-group view)
1.1.50 fingerprint-group apply
1.1.53 http-flood defense source-verify
1.1.54 http-flood detection threshold
1.1.55 https-flood defense source-verify
1.1.56 https-flood defense ssl-defend
1.1.57 https-flood detection threshold
1.1.58 http-slow-attack defense threshold
1.1.59 icmp-flood detection threshold
1.1.60 icmp-frag-flood detection threshold
1.1.70 reset anti-ddos dynamic-blacklist
1.1.71 reset anti-ddos filter statistics zone
1.1.72 rst-flood detection threshold
1.1.73 sip-flood defense source-verify
1.1.74 sip-flood detection threshold
1.1.77 syn-ack-flood detection threshold
1.1.78 syn-flood defense source-verify
1.1.79 syn-flood detection threshold
1.1.81 tcp-frag-flood detection threshold
1.1.82 threshold-learning enable
1.1.85 udp-flood detection threshold
1.1.86 udp-frag-flood detection threshold
1.1.88 user-defined attack-type detection threshold
· AFC2040-D-G设备为DDoS攻击检测设备,仅支持检测设备相关命令行。
· AFC2200-G设备为DDoS攻击清洗设备,仅支持清洗设备相关命令行。
ack-flood defense session-check命令用来开启ACK泛洪攻击的会话检测功能。
undo ack-flood defense命令用来关闭ACK泛洪攻击的会话检测功能。
undo ack-flood defense session-check
ACK泛洪攻击的会话检测功能处于关闭状态。
DDoS攻击防护对象视图。
仅DDoS攻击清洗设备支持配置本命令。
开启本功能后,设备会对接收到的ACK报文进行会话查找,若能够命中相应会话则放行该报文,否则丢弃该报文。
在清洗设备旁路部署的组网环境中,对于动态引流前已经建立的会话,ACK报文会因为在清洗设备上查不到会话而被错误丢弃,建议此种组网下不要开启ACK泛洪攻击的会话检测功能。
#在ID为5的DDoS攻击防护对象视图下开启ACK泛洪攻击的会话检测功能。
[Sysname] anti-ddos zone id 5
[Sysname-anti-ddos-id-5] ack-flood defense session-check
· ack-flood detection threshold
ack-flood detection threshold命令用来配置ACK泛洪攻击防范阈值,并开启ACK泛洪攻击检测功能。
undo ack-flood detection threshold命令用来关闭ACK泛洪攻击检测功能。
ack-flood detection threshold { bit-based value | packet-based value}
ACK泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示ACK泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示ACK泛洪攻击的统计方式为按照报文个数进行统计。
value:表示ACK泛洪攻击防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
DDoS攻击检测设备和DDoS攻击清洗设备均支持配置本命令。
开启ACK泛洪攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行ACK泛洪攻击检测。当设备检测到向某IP地址发送ACK报文的速率持续超过了配置的阈值时,即认为该IP地址受到了ACK泛洪攻击,继而启动相应的防范措施:
· DDoS攻击检测设备会向管理中心发送攻击告警日志,管理中心收到攻击告警日志后向DDoS攻击清洗设备下发引流策略,将攻击流量引流到DDoS攻击清洗设备上进行流量清洗。
· 直路部署的DDoS攻击清洗设备在设备本地对攻击流量进行清洗。
· 此后,当设备检测到向该IP地址发送报文的速率持续低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在ID为3的DDoS攻击防护对象视图下,开启ACK泛洪攻击检测功能,并配置ACK泛洪攻击防范阈值为20个报文。
[Sysname] anti-ddos zone id 3
[Sysname-anti-ddos-zone-id-3] ack-flood detection threshold packet-based 20
· display anti-ddos zone configuration
action命令用来配置对命中DDoS攻击防护过滤器的报文所执行的动作。
undo action命令用来恢复缺省情况。
action { drop | limit { bit-based value | packet-based value } | pass | source-verify }
undo action
对命中DDoS攻击防护过滤器的报文进行丢弃。
DDoS攻击防护过滤器视图
drop:对命中过滤器的报文进行丢弃。
limit:对命中过滤器的报文进行限速。
bit-based value:指定限速阈值,取值范围为1~4294967295,单位为Mbps。
packet-based value:指定限速阈值,取值范围为1~4294967295,单位为pps。
pass:允许命中过滤器的报文通过。
source-verify:对命中过滤器的报文进行源验证。该参数仅对HTTP过滤器有效。
本命令用于配置指定过滤器的处理动作,设备可对命中过滤器的报文执行如下三种操作中的一种:
· 丢弃:将命中过滤器的报文丢弃。
· 限速:对命中过滤器的报文进行限速,丢弃超出阈值部分的报文。
· 源验证:对命中过滤器的报文进行源合法性检查,检查报文源是否真实。设备将放行来自真实源的报文,丢弃来自虚假源的报文。仅可为HTTP过滤器配置源验证功能。
多次执行本命令,最后一次执行的命令生效。
# 配置HTTP过滤器test的处理动作为源验证。
[Sysname] anti-ddos filter name test type http
[Sysname-anti-ddos-filter-http-test] action source-verify
· anti-ddos filter
· display anti-ddos filter statistics
anti-ddos apply filter命令用来在DDoS攻击防护对象下应用DDoS攻击防护过滤器,并配置过滤器的匹配优先级。
undo anti-ddos apply filter命令用来取消应用在DDoS攻击防护对象下的指定DDoS攻击防护过滤器。
anti-ddos apply filter filter-name preference preference
undo anti-ddos apply filter filter-name
DDoS攻击防护对象未应用DDoS攻击防护过滤器。
DDoS攻击防护对象视图
filter-name:指定过滤器的名称,不区分大小写。该名称的过滤器必须已经存在。
preference preference:指定过滤器的匹配优先级,取值范围为1~255。preference值越小,匹配优先级越高。
在DDoS攻击防护对象下应用的过滤器将按匹配优先级的降序依次对报文进行匹配:
· 若报文命中某过滤器,则对报文执行该过滤器下所配置的动作。
· 若报文未命中某过滤器,则继续将其与优先级更低的过滤器进行匹配,直至不存在优先级更低的过滤器,此时设备将报文递交后续流程处理。
对于在一个DDoS攻击防护对象下所应用的过滤器,其匹配优先级必须唯一。一个DDoS攻击防护对象下最多应用10个过滤器。
# 在ID为3的DDoS攻击防护对象下应用名称为test的过滤器,并指定其匹配优先级为10。
[Sysname-anti-ddos-zone-id-3] anti-ddos apply filter test preference 10
· anti-ddos filter
anti-ddos blacklist命令用来添加DDoS全局静态黑名单表项。
undo anti-ddos blacklist命令用来删除DDoS全局静态黑名单表项。
anti-ddos blacklist { ip source-ip-address ip-mask-length | ipv6 source-ipv6-address ipv6-mask-length }
undo anti-ddos blacklist { all | ip source-ip-address ip-mask-length | ipv6 source-ipv6-address ipv6-mask-length }
不存在DDoS全局静态黑名单表项。
all:表示删除所有全局静态黑名单表项,包括IPv4表项和IPv6表项。
ip source-ip-address ip-mask-length:DDoS全局静态黑名单表项的IPv4地址及掩码长度,用于匹配报文的源IPv4地址。其中ip-mask-length的取值范围为8~32。
ipv6 source-ipv6-address ipv6-mask-length:DDoS全局静态黑名单表项的IPv6地址及掩码长度,用于匹配报文的源IPv6地址。其中ipv6-mask-length的取值范围为8~128。
若报文源地址匹配上DDoS全局静态黑名单表项,则进行丢包操作,未匹配则放行。
DDoS全局静态黑名单表项的IP地址范围不能与DDoS全局静态白名单表项的IP地址范围重叠。对于IPv4表项,不可配置地址0.0.0.0和255.255.255.255;对于IPv6表项,不可配置未指定地址(::/128)以及组播地址(FF00::/8)。
设备支持的DDoS全局静态黑名单与DDoS全局静态白名单表项数目之和最多为1024个。
# 将1.1.1.1/24网段添加进DDoS全局静态黑名单中。
[Sysname] anti-ddos blacklist ip 1.1.1.1 24
· anti-ddos whitelist
· display anti-ddos blacklist
anti-ddos blacklist timeout命令用来配置动态黑名单表项的老化时间。
undo anti-ddos blacklist timeout命令用来恢复缺省情况。
anti-ddos blacklist timeout aging-time
动态黑名单表项的老化时间为1分钟。
aging-time:动态黑名单表项的老化时间,取值范围为1~1000,单位为分钟。
# 配置动态黑名单表项的老化时间为2分钟。
[Sysname] anti-ddos blacklist timeout 2
anti-ddos cleaner deploy-mode命令用来配置DDoS攻击清洗设备的部署模式。
undo anti-ddos cleaner deploy-mode命令用来恢复缺省情况。
anti-ddos cleaner deploy-mode { inline | out-of-path }
DDoS攻击清洗设备的部署模式为直路部署。
inline:指定部署模式为直路部署。
out-of-path:指定部署模式为旁路部署。
仅DDoS攻击清洗设备支持配置本命令,若DDoS攻击清洗设备采用旁路方式连接在组网中,则需要配置部署模式为旁路部署;若DDoS攻击清洗设备采用直路方式连接在组网中,则需要配置部署模式为直路部署。
在部署模式为旁路部署或直路部署模式时,DDoS攻击清洗设备配置的检测功能都会生效。
# 配置DDoS攻击清洗设备的部署模式为旁路部署。
[Sysname] anti-ddos cleaner deploy-mode out-of-path
anti-ddos default-zone enable命令用来开启缺省DDoS攻击防护对象功能。
undo anti-ddos default-zone enable命令用来关闭缺省DDoS攻击防护对象功能。
缺省DDoS攻击防护对象功能处于关闭状态。
通过开启缺省DDoS攻击防护对象功能,可在流量未匹配自定义DDoS攻击防护对象时,采用缺省DDoS攻击防护对象下配置的DDoS攻击检测与防范策略对其进行DDoS攻击检测与防范。
在配置该命令前,缺省DDoS攻击防护对象下的配置不生效。
# 开启缺省DDoS攻击防护对象功能。
[Sysname] anti-ddos default-zone enable
· anti-ddos zone default
anti-ddos detection-mode命令用来配置DDoS攻击检测模式。
undo anti-ddos detection-mode命令用来恢复缺省情况。
anti-ddos detection-mode { flow | mirror }
DDoS攻击检测模式为深度流检测模式。
flow:表示深度流检测模式,即基于Netflow、NetStream和sFlow等流统计报文进行DDoS攻击检测。
mirror:表示深度报文检测模式,即基于镜像报文进行DDoS攻击检测。
若采用mirror模式即深度报文检测模式,需执行undo mac-address-filter enable命令关闭目的MAC地址过滤功能。
模式切换期间可能会有部分报文因未经DDoS检测而导致攻击行为未被识别出。
仅DDoS攻击检测设备支持配置本命令。
# 配置DDoS攻击的检测模式为深度报文检测。
[Sysname] anti-ddos detection-mode mirror
anti-ddos log-local-ip命令用来配置上报日志的设备源IP地址。
undo anti-ddos log-local-ip命令用来恢复缺省情况。
anti-ddos log-local-ip { ip ipv4-address | ipv6 ipv6-address }
未配置上报日志的设备源IP地址。
ip ipv4-address:指定上报日志的源IPv4地址,该IP须为设备已配IP。
ipv6 ipv6-address:指定上报日志的源IPv6地址,该IP须为设备已配IP。
DDoS攻击检测设备和DDoS攻击清洗设备支持均配置本命令。
本命令用来指定设备向管理中心发送DDoS日志报文的源IP地址。
仅支持配置一个IPv4地址或者一个IPv6地址。多次执行本命令,最后一次执行的命令生效。
# 配置上报日志的设备源IP地址为192.168.1.2。
[Sysname] anti-ddos log-local-ip ip 192.168.1.2
· anti-ddos log-server-ip
anti-ddos log-server-ip命令用来配置上报日志的服务端IP地址。
undo anti-ddos log-server-ip命令用来恢复缺省情况。
anti-ddos log-server-ip { ip ipv4-address | ipv6 ipv6-address } [ port port-number ]
未配置上报日志的服务端IP地址。
ip ipv4-address:指定日志上报的服务端IPv4地址。
ipv6 ipv6-address:指定日志上报的服务端IPv6地址。
port port-number:指定日志上报服务端的端口号,取值范围为1~65535,缺省为10083。
本命令用来在设备上指定接收DDoS日志报文的管理中心的IP地址和端口号。
设备上只支持配置一个IPv4地址或者一个IPv6地址。当已存在一个配置时,再次下发配置则覆盖原有配置。
# 配置上报日志的服务端IP地址为192.168.1.1。
[Sysname] anti-ddos log-server-ip ip 192.168.1.1
· anti-ddos log-local-ip
anti-ddos out-of-band interface命令用于向DDoS攻击检测与防范业务中添加带外接口。
undo anti-ddos out-of-band interface命令用于从DDoS攻击检测与防范业务中移除带外接口。
anti-ddos out-of-band interface { interface-type interface-number } &<1-10>
undo anti-ddos out-of-band interface [ interface-type interface-number ]
DDoS攻击检测与防范业务的带外接口仅包括GigabitEthernet1/0/0接口。
interface-type interface-number &<1-10>:指定带外接口的接口类型和接口编号。&<1-10>表示之前的参数最多可以输入10次。
检测设备和清洗设备均支持配置本命令。
仅支持将物理接口配置为带外接口。
执行undo命令时,如果未配置接口类型和接口编号参数,设备将删除DDoS攻击检测与防范业务的所有带外接口。
# 将接口GigabitEthernet1/0/1、GigabitEthernet1/0/4和LoopBack 1配置为DDoS攻击检测与防范业务的带外接口。
[Sysname] anti-ddos out-of-band interface gigabitethernet 1/0/1 gigabitethernet 1/0/4 loopback 1
anti-ddos user-defined attack-type protocol命令用来配置基于指定协议的自定义DDoS攻击类型。
undo anti-ddos user-defined attack-type命令用来删除自定义DDoS攻击类型。
anti-ddos user-defined attack-type id id protocol protocol-number [ packet-length { equal | greater-than | less-than } packet-length ]
undo anti-ddos user-defined attack-type [ id id ]
不存在基于指定协议的自定义DDoS攻击类型。
id id:指定自定义DDoS攻击类型的ID,取值范围为0~15。攻击类型ID必须全局唯一。
protocol-number:协议编号,取值范围为0~255。
packet-length:指定报文长度信息。
equal:等于报文长度参考值。
greater-than:大于报文长度参考值。
less-than:小于报文长度参考值。
packet-length:报文长度参考值,取值范围为20~65535,单位为字节。
检测设备和清洗设备均支持配置本命令。
本命令用来配置基于指定协议的自定义DDoS攻击类型。在基于协议来识别攻击报文的同时,还可以指定报文长度作为识别报文的特征,报文长度的识别方法包括判断报文长度小于、大于和等于指定参考值三种类型。
对同一ID的自定义DDoS攻击类型进行多次配置,最后一次配置生效。
执行undo命令时,如果未配置id参数,设备将删除全部自定义DDoS攻击类型配置。
# 配置ID为3,基于VRRP协议(协议号为112),报文长度小于28字节的自定义DDoS攻击类型。
[Sysname] anti-ddos user-defined attack-type id 3 protocol 112 packet-length less-than 28
anti-ddos user-defined attack-type protocol icmp命令用来配置基于ICMP协议的自定义DDoS攻击类型。
anti-ddos user-defined attack-type id id protocol icmp [ packet-length { equal | greater-than | less-than } packet-length ] [ icmp-type icmp-type icmp-code icmp-code ]
不存在基于ICMP协议的自定义DDoS攻击类型。
equal:等于报文长度参考值。
icmp-type icmp-type:指定ICMP消息类型,取值范围为0~255。
icmp-code icmp-code:指定ICMP消息代码,取值范围为0~255。
检测设备和清洗设备均支持配置本命令。
本命令用来配置基于ICMP协议的自定义DDoS攻击类型。在基于报文长度来识别攻击报文的同时,还可以指定ICMP消息类型和消息代码作为识别报文的特征。报文长度的识别方法包括判断报文长度小于、大于和等于指定参考值三种类型。
# 配置ID为3,基于ICMP协议,类型为8,代码为0的自定义DDoS攻击类型。
[Sysname] anti-ddos user-defined attack-type id 3 protocol icmp icmp-type 8 icmp-code 0
anti-ddos user-defined attack-type protocol icmpv6命令用来配置基于ICMPv6协议的自定义DDoS攻击类型。
anti-ddos user-defined attack-type id id protocol icmpv6 [ packet-length { equal | greater-than | less-than } packet-length ] [ icmpv6-type icmpv6-type icmpv6-code icmpv6-code ]
不存在基于ICMPv6协议的自定义DDoS攻击类型。
equal:等于报文长度参考值。
icmpv6-type icmp-type:指定ICMPv6消息类型,取值范围为0~255。
icmpv6-code icmp-code:指定ICMPv6消息代码,取值范围为0~255。
检测设备和清洗设备均支持配置本命令。
本命令用来配置基于ICMPv6协议的自定义DDoS攻击类型。在基于报文长度来识别攻击报文的同时,还可以指定ICMPv6消息类型和消息代码作为识别报文的特征。报文长度的识别方法包括判断报文长度小于、大于和等于指定参考值三种类型。
# 配置ID为3,基于ICMPv6协议,报文长度大于65535字节的自定义DDoS攻击类型。
[Sysname] anti-ddos user-defined attack-type id 3 protocol icmpv6 packet-length greater-than 65535
anti-ddos user-defined attack-type protocol tcp命令用来配置基于TCP协议的自定义DDoS攻击类型。
anti-ddos user-defined attack-type id id protocol tcp [ packet-length { equal | greater-than | less-than } packet-length ] [ port port-num port-type { source | destination } ] [ tcp-flag flag-value ]
不存在基于TCP协议的自定义DDoS攻击类型
equal:等于报文长度参考值。
port port-num:指定端口号,取值范围为1~65535。
port-type:指定端口类型。
source:端口类型为源端口。
destination:端口类型为目的端口。
tcp-flag flag-value:指定TCP flag字段的值,取值范围为0~63。
检测设备和清洗设备均支持配置本命令。
本命令用来配置基于TCP协议的自定义DDoS攻击类型。在基于TCP协议来识别攻击报文的同时,还可以指定报文长度、端口及TCP flag作为识别攻击报文的特征。设备将同时满足所有指定特征的报文视作攻击报文:
· 报文长度特征:报文长度小于、大于或等于攻击报文长度参考值。
· 端口特征:源端口号或目的端口号。
· TCP flag:TCP flag字段取值。
# 配置ID为3,基于TCP协议,报文长度大于65535字节,目的端口为80的自定义DDoS攻击类型。
[Sysname] anti-ddos user-defined attack-type id 3 protocol tcp packet-length greater-than 65535 port 80 port-type destination
anti-ddos user-defined attack-type protocol udp命令用来配置基于UDP协议的自定义DDoS攻击类型。
anti-ddos user-defined attack-type id id protocol udp [ packet-length { equal | greater-than | less-than } packet-length ] [ port port-num port-type { source | destination } ]
不存在基于UDP协议的自定义DDoS攻击类型。
equal:等于报文长度参考值。
port-type:指定端口类型。
source:端口类型为源端口。
检测设备和清洗设备均支持配置本命令。
本命令用来配置基于UDP协议的自定义DDoS攻击类型。在基于UDP协议来识别攻击报文的同时,还可以指定报文长度和端口作为识别攻击报文的特征。设备将同时满足所有指定特征的报文视作攻击报文:
· 端口特征:源端口号或目的端口号。
# 配置ID为3,基于UDP协议,报文长度等于48的自定义DDoS攻击类型。
[Sysname] anti-ddos user-defined attack-type id 3 protocol udp packet-length equal 48
anti-ddos whitelist命令用来添加DDoS全局静态白名单表项。
undo anti-ddos whitelist命令用来删除DDoS全局静态白名单表项。
anti-ddos whitelist { ip source-ip-address ip-mask-length | ipv6 source-ipv6-address ipv6-mask-length }
undo anti-ddos whitelist { all | ip source-ip-address ip-mask-length | ipv6 source-ipv6-address ipv6-mask-length }
不存在DDoS全局静态白名单表项。
all:表示删除所有全局静态白名单表项,包括IPv4表项和IPv6表项。
ip source-ip-address ip-mask-length:DDoS全局静态白名单的IPv4地址及掩码长度,用于匹配报文的源IPv4地址。其中ip-mask-length的取值范围为8~32。
ipv6 source-ipv6-address ipv6-mask-length:DDoS全局静态白名单的IPv6地址及掩码长度,用于匹配报文的源IPv6地址。其中ipv6-mask-length的取值范围为8~128。
若报文匹配上DDoS全局白名单表项,则跳过其他DDoS攻击检测与防范功能(不包括IP限速),执行后续报文处理。
# 将1.1.1.1/24网段添加进DDoS全局静态白名单中。
[Sysname] anti-ddos whitelist ip 1.1.1.1 24
· anti-ddos blacklist
· display anti-ddos whitelist
anti-ddos whitelist timeout命令用来配置动态白名单表项的老化时间。
undo anti-ddos whitelist timeout命令用来恢复缺省情况。
anti-ddos whitelist timeout aging-time
动态白名单表项的老化时间为10分钟。
aging-time:动态白名单表项的老化时间,取值范围为1~1000,单位为分钟。
仅DDoS攻击清洗设备支持配置本命令。
通过DDoS攻击源验证的报文源IP地址将被加入动态白名单(即信任IP地址列表)中,设备会放行源地址匹配动态白名单表项的报文,不对其进行除IP报文限速外的DDoS攻击检测与防范处理。
目前只有DDoS攻击源验证功能会触发生成动态白名单表项。
# 配置动态白名单表项的老化时间为2分钟。
[Sysname] anti-ddos whitelist timeout 2
· display anti-ddos source-verify trusted ip
· display anti-ddos source-verify trusted ipv6
anti-ddos zone命令用来创建一个DDoS攻击防护对象,并进入DDoS攻击防护对象视图。如果指定的DDoS攻击防护对象已经存在,则直接进入DDoS攻击防护对象视图。
undo anti-ddos zone命令用来删除指定的DDoS攻击防护对象。
anti-ddos zone { id zone-id | default }
undo anti-ddos zone [ id zone-id ]
仅存在名称为default的缺省DDoS攻击防护对象。
id zone-id:DDoS攻击防护对象的ID,取值范围为2~1024。
default:缺省DDoS攻击防护对象,其ID值为1。
未配置任何防护对象时,设备对收到的流量不采取任何防护措施。
设备最多支持创建1024个DDoS攻击防护对象(包括default)
在执行undo ddos-zone命令时,若未指定DDoS攻击防护对象的ID,则表示删除所有自定义的DDoS攻击防护对象。
缺省DDoS攻击防护对象(default)不需要创建,也不能删除。
# 创建ID值为3的DDoS攻击防护对象,并进入DDoS攻击防护对象视图。
bandwidth-detection destination-ip threshold命令用来配置IP流量攻击的防范触发阈值,并开启IP流量攻击检测功能。
undo bandwidth-detection destination-ip threshold命令用来恢复缺省情况。
bandwidth-detection destination-ip threshold threshold-value
IP流量攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
threshold-value:表示IP流量攻击的防范触发阈值,取值范围为1~4294967295,单位为Mbps。
开启IP流量攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行IP流量攻击检测。当设备检测到向某IP地址发送IP报文的速率持续超过了该触发阈值时,即认为该IP地址受到了IP流量攻击,继而启动相应的防范措施:
· 对于旁路部署的DDoS攻击检测设备:会向管理中心发送攻击告警日志,管理中心收到攻击告警日志后向DDoS攻击清洗设备下发引流策略,将攻击流量引流到DDoS攻击清洗设备上进行流量清洗。
· 对于直路部署的DDoS攻击清洗设备:在设备本地对攻击流量进行检测和清洗。此时需检查是否开启了IP流量限速功能,若未开启,则全部放行;若开启,则对设备收到的IP流量进行限速。
此后,当设备检测到向该IP地址发送IP报文的速率持续低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,停止执行防范措施。
# 在DDoS攻击防护对象视图下,开启IP流量攻击检测功能,并配置IP流量攻击的防范触发阈值为20Mbps。
[Sysname-anti-ddos-zone-id-3] bandwidth-detection destination-ip threshold 20
bandwidth-limit destination-ip type max-rate命令用来开启指定类型报文的流量限速功能,并配置最大带宽限制。
undo bandwidth-limit destination-ip type命令用来关闭指定类型报文的流量限速功能。
bandwidth-limit destination-ip type { icmp | icmp-fragment | other | tcp | tcp-fragment | total | udp | udp-fragment } max-rate value
undo bandwidth-limit destination-ip [ type { icmp | icmp-fragment | other | tcp | tcp-fragment | total | udp | udp-fragment } ]
指定类型报文的限速功能处于关闭状态。
DDoS攻击防护对象视图
icmp:表示限制ICMP报文的速率。
icmp-fragment:表示限制ICMP分片报文的速率。
other:表示限制基于IP协议的其他非TCP、UDP和ICMP报文的速率。
tcp:表示限制TCP报文的速率。
tcp-fragment:表示限制TCP分片报文的速率。
total:表示限制报文的总速率,即所有基于IP协议的报文速率。
udp:表示限制UDP报文的速率。
udp-fragment:表示限制UDP分片报文的速率。
value:指定发往每目的IP地址的报文的速率上限,取值范围为1~4294967295,单位为Mbps。
仅清洗设备支持配置本命令。
执行本命令后,设备会对发往DDoS攻击防护对象内IP地址的指定类型的报文进行限速,将向每个IP地址发送该类型报文的最大速率限制为所配置的value参数的值,超出速率上限的报文将被设备丢弃。
一个防护对象下可以开启多种类型报文的限速功能:
· 对于TCP、UDP、ICMP和其他非分片报文,首先基于协议类型进行限速,然后进行报文总速率限制。
· 对于TCP、UDP和ICMP分片报文,首先基于协议类型进行限速,再进行分片报文限速,最后进行报文总速率限制。建议分片报文限速阈值小于协议类型限速阈值。
执行undo命令时,若不配置任何参数将关闭该DDoS攻击防护对象下所有报文类型的限速功能。
# 在ID为3的DDoS攻击防护对象视图下开启TCP报文的限速功能,并配置速率上限为50Mbps。
[Sysname-anti-ddos-zone-id-3] bandwidth-limit destination-ip type tcp max-rate 50
· bandwidth-detect destination-ip threshold
callee命令用来创建SIP报文会话接收方字段匹配规则。
undo callee命令用来删除SIP报文会话接收方字段匹配规则。
callee { equal | include } callee-string
undo callee [ { equal | include } callee-string ]
DDoS攻击防护过滤器中不存在SIP报文的会话接收方字段匹配规则。
SIP过滤器视图
equal:表示SIP报文的接收方字段的内容与指定URI完全一致。
include:表示SIP报文的接收方字段的内容包含指定URI。
callee-string:指定SIP会话接收方的URI,为2~63个字符的字符串,不区分大小写。
SIP报文会话接收方字段匹配规则用于匹配会话接收方为指定URI的SIP报文。
每个SIP过滤器中最多可以创建32条会话接收方字段匹配规则。SIP报文满足其中任意一条匹配规则,即被视作满足SIP报文会话接收方字段匹配条件。
如果执行undo callee命令时不指定任何参数,则表示删除该过滤器视图下所有的SIP报文会话接收方字段匹配规则。
# 在SIP过滤器test中创建一条会话接收方字段匹配规则:SIP报文的接收方字段的内容包含字符串abc.example.com。
[Sysname] anti-ddos filter name test type sip
[Sysname-anti-ddos-filter-sip-test] callee include abc.example.com
· anti-ddos filter
caller命令用来创建SIP报文会话发起方字段匹配规则。
undo caller命令用来删除SIP报文会话发起方字段匹配规则。
caller { equal | include } caller-string
undo caller [ { equal | include } caller-string ]
DDoS攻击防护过滤器中不存在SIP报文会话发起方字段匹配规则。
SIP过滤器视图
equal:表示SIP报文的发起方字段的内容与指定URI完全一致。
include:表示SIP报文的发起方字段的内容包含指定URI。
caller-string:指定SIP会话发起方的URI,为2~63个字符的字符串,不区分大小写。
SIP报文会话发起方字段匹配规则用于匹配会话发起方为指定URI的SIP报文。
每个SIP过滤器中最多可以创建32条会话发送方字段匹配规则。SIP报文满足其中任意一条匹配规则,即被视作满足SIP报文会话发起方字段匹配条件。
如果执行undo caller命令时不指定任何参数,则表示删除该过滤器视图下所有的SIP报文会话发送方字段匹配规则。
# 在SIP过滤器test中创建一条会话发送方字段匹配规则:SIP报文的发送方字段的内容包含字符串abc.example.com。
[Sysname-anti-ddos-filter-sip-test] caller include abc.example.com
· anti-ddos filter
cookie命令用来创建HTTP报文Cookie字段匹配规则。
undo cookie命令用来删除HTTP报文Cookie字段匹配规则。
cookie include cookie-string
undo cookie [ include cookie-string ]
DDoS攻击防护过滤器中不存在HTTP报文Cookie字段匹配规则。
HTTP过滤器视图
include:表示HTTP报文的Cookie字段的内容包含指定关键字。
cookie-string:指定Cookie关键字,为2~63个字符的字符串,不区分大小写。
HTTP报文Cookie字段匹配规则用于匹配Cookie字段包含指定关键字的HTTP报文。
每个HTTP过滤器中最多可以创建32条Cookie字段匹配规则。HTTP报文满足其中任意一条匹配规则,即被视作满足HTTP报文Cookie字段匹配条件。
如果执行undo cookie命令时不指定任何参数,则表示删除该过滤器视图下所有的HTTP报文Cookie字段匹配规则。
# 在HTTP过滤器test中创建一条Cookie字段匹配规则:HTTP报文的Cookie字段的内容包含字符串abc。
[Sysname-anti-ddos-filter-http-test] cookie include abc
· anti-ddos filter
destination-ip命令用来创建报文目的IP地址匹配规则。
undo destination-ip命令用来删除报文目的IP地址匹配规则。
destination-ip { ip-range start-ip end-ip | ipv6-range start-ipv6 end-ipv6 }
undo destination-ip [ ip-range start-ip end-ip | ipv6-range start-ipv6 end-ipv6 ]
DDoS攻击防护过滤器中不存在报文目的IP地址匹配规则。
DDoS攻击防护过滤器视图
ip-range:目的IPv4地址范围。
start-ip:起始IPv4地址,且不能大于结束IPv4地址。
end-ip:结束IPv4地址。
ipv6-range:目的IPv6地址范围。
start-ipv6:起始IPv6地址,且不能大于结束IPv6地址。
end-ipv6:结束IPv6地址。
报文目的IP地址匹配规则用于匹配目的IP地址在指定范围内的报文。
每个过滤器中最多可以创建100条报文目的IP地址匹配规则。满足其中任意一条匹配规则,即被视作满足报文目的IP地址匹配条件。
在同一个过滤器视图下多次执行本命令所配置的目的地址范围不允许重叠。
如果执行undo destination-ip命令时不指定任何参数,则表示删除该过滤器视图下所有的报文目的IP地址匹配规则。
# 在HTTP过滤器test中创建一条报文目的IP地址匹配规则:报文目的IPv4地址在2.2.2.10~2.2.2.20的范围内。
[Sysname-anti-ddos-filter-http-test] destination-ip ip-range 2.2.2.10 2.2.2.20
· anti-ddos filter
destination-port命令用来创建报文目的端口匹配规则。
undo destination-port命令用来删除报文目的端口匹配规则。
destination-port range start-port end-port
undo destination-port [ range start-port end-port ]
DDoS攻击防护过滤器中不存在报文目的端口匹配规则。
TCP过滤器视图
UDP过滤器视图
range:目的端口范围。
start-port:指定起始端口号,取值范围为1~65535,且不能大于结束端口号。
end-port:指定结束端口号,取值范围为1~65535。
报文目的端口匹配规则用于匹配目的端口号在指定范围内的报文。
每个过滤器中最多可以创建10条报文目的端口匹配规则。满足其中任意一条匹配规则,即被视作满足报文目的端口匹配条件。
在同一个过滤器视图下多次执行本命令所配置的目的端口号范围不允许重叠。
如果执行undo destination-port命令时不指定任何参数,则表示删除该过滤器视图下所有的报文目的端口匹配规则。
# 在TCP过滤器test中创建一条报文目的端口匹配规则:报文目的端口号在10~20的范围内。
[Sysname] anti-ddos filter name test type tcp
[Sysname-anti-ddos-filter-tcp-test] destination-port range 10 20
· anti-ddos filter
display anti-ddos blacklist命令用来显示DDoS全局静态黑名单表项。
display anti-ddos blacklist [ ip source-ip-address | ipv6 source-ipv6-address ]
ip souce-ip-address:显示指定源IPv4地址的DDoS全局静态黑名单表项。
ipv6 source-ipv6-address:显示指定源IPv6地址的DDoS全局静态黑名单表项。
仅清洗设备支持配置本命令。
若未指定IPv4地址或IPv6地址参数,则表示显示所有的IPv4或IPv6全局静态黑名单表项。
# 显示所有全局静态黑名单。
<Sysname> display anti-ddos blacklist
Total: 4 Blacklist: 3 Whitelist: 1
Source-ip/MaskLen Black/White
3.3.3.3/32 Black
10.0.0.0/24 Black
8000::/64 Black
# 显示指定IP对应的全局静态黑名单。
<Sysname> display anti-ddos blacklist ip 10.0.0.3
10.0.0.0/24 Black
#显示指定IPv6对应的全局静态黑名单。
<Sysname> display anti-ddos blacklist ipv6 8000::1
8000::/64 Black
表1-1 display anti-ddos blacklist命令显示信息描述表
Total |
IPv4或IPv6黑名单表项与白名单表项数目之和 |
Blacklist |
IPv4或IPv6黑名单表项数目 |
Whitelist |
IPv4或IPv6白名单表项数目 |
Source-ip/MaskLen |
源IP地址及掩码长度 |
Black/White |
表项类型,即黑名单类型或白名单类型 |
display anti-ddos blacklist zone命令用来显示DDoS攻击防护对象静态黑名单表项。
display anti-ddos blacklist zone [ { id zone-id | default } [ ip source-ip-address | ipv6 source-ipv6-address ] ]
id zone-id:DDoS攻击防护对象ID,取值范围为2~1024。
ip souce-ip-address:显示指定源IPv4地址的DDoS攻击防护对象静态黑名单表项。
ipv6 source-ipv6-address:显示指定源IPv6地址的DDoS攻击防护对象静态黑名单表项。
仅DDoS攻击清洗设备支持配置本命令。
若未指定DDoS攻击防护对象,则显示所有DDoS攻击防护对象下的静态黑名单表项。
若未指定IPv4地址或IPv6地址参数,则表示显示DDoS攻击防护对象下的所有静态黑名单表项。
# 显示所有DDoS攻击防护对象的静态黑名单表项。
<Sysname> display anti-ddos blacklist zone
Total:4 Blacklist:3 Whitelist:1
ZoneID Source-ip/MaskLen Black/White
default 3.3.3.3/32 Black
2 10.0.0.0/24 Black
2 8000::/64 Black
# 显示ID为2的DDoS攻击防护对象下匹配IP地址10.0.0.3的静态黑名单表项。
<Sysname> display anti-ddos blacklist zone id 2 ip 10.0.0.3
2 10.0.0.0/24 Black
# 显示缺省DDoS攻击防护对象下匹配IPv6地址8000::1的静态黑名单表项。
<Sysname> display anti-ddos blacklist zone default ipv6 8000::1
default 8000::/64 Black
表1-2 display anti-ddos blacklist zone命令显示信息描述表
Total |
DDoS攻击防护对象下IPv4或IPv6黑名单表项与白名单表项数目之和 |
Blacklist |
DDoS攻击防护对象下IPv4或IPv6黑名单表项数目 |
Whitelist |
DDoS攻击防护对象下IPv4或IPv6白名单表项数目 |
ZoneID |
DDoS攻击防护对象ID |
Source-ip/MaskLen |
源IP地址及掩码长度 |
Black/White |
表项类型,即黑名单类型或白名单类型 |
· zone-blacklist
display anti-ddos dynamic-blacklist命令用来显示DDoS攻击防护对象的动态黑名单表项。
display anti-ddos dynamic-blacklist { ip | ipv6 } [ zone [ default | id zone-id ] ]
任意视图。
ip:显示IPv4动态黑名单表项。
ipv6:显示IPv6动态黑名单表项。
zone:显示指定DDoS攻击防护对象的动态黑名单表项。若不指定DDoS攻击防护对象,则显示所有DDoS攻击防护对象的动态黑名单表项。
default:指定缺省DDoS攻击防护对象。
id zone-id:DDoS攻击防护对象ID,取值范围2~1024。
仅DDoS攻击清洗设备支持配置本命令。
# 显示DDoS攻击防护对象的IPv4动态黑名单表项。
<sysname> display anti-ddos dynamic-blacklist ip
Zone ID Source-ip Aging time (min) Reason
2 192.168.8.9 10 -
2 192.168.3.6 20 -
3 192.168.9.6 5 -
# 显示ID为2的DDoS攻击防护对象的IPv6动态黑名单表项。
<sysname> display anti-ddosdynamic-blacklist ipv6 zone id 2
Source-ipv6 Aging time (min) Reason
fe80::64fb:D5cf:3131:c1af 10 -
表1-3 display anti-ddos dynamic-blacklist命令显示信息描述表
Zone ID |
DDoS攻击防护对象ID |
Source-ip |
IPv4黑名单表项 |
Source-ipv6 |
IPv6黑名单表项 |
Aging time(min) |
剩余老化时间,单位为分钟 |
Reason |
加入防护对象动态黑名单原因 |
display anti-ddos filter statistics命令用来显示DDoS攻击防护过滤器的统计信息。
display anti-ddos filter statistics name name anti-ddos-zone { id zone-id | default }
name name:指定过滤器的名称,为1~63个字符的字符串,由字母、数字和下划线组成,名称必须以字母开头,字母不区分大小写。
anti-ddos-zone:DDoS攻击防护对象。
id zone-id:指定DDoS攻击防护对象的ID,取值范围为2~1024。
default:缺省DDoS攻击防护对象。
# 显示指定ID为3的DDoS攻击防护对象下过滤器test的统计计数。
<Sysname> display anti-ddos filter statistics name test anti-ddos-zone id 3
Type : HTTP
Action : drop
PPS : 100000
Bps : 200000000
Dropped packets : 20750
Dropped bytes : 5
表1-4 display anti-ddos filter statistics命令显示信息描述表
Type |
过滤器的协议类型,包括: · IP · TCP · UDP · HTTP · DNS · ICMP · SIP |
Action |
表示过滤器执行的动作,其取值包括如下: · drop:丢弃 · pass:放行 · limit:限速 · source-verify:源验证 |
PPS |
过滤器匹配到的报文速率,单位为pps |
Bps |
过滤器匹配到的报文速率,单位为Bps |
Dropped packets |
过滤器丢弃的包数 |
Dropped bytes |
过滤器丢弃的字节数 |
display anti-ddos ssl-defend illegal-session-stat-nodes命令用来显示SSL重协商防护的异常会话统计节点列表。
display anti-ddos ssl-defend illegal-session-stat-nodes { ip | ipv6 } [ count | zone { default | id zone-id } ] [ slot slot-number [ cpu cpu-number ] ]
任意视图。
ip:显示SSL重协商防护的IPv4异常会话统计节点列表。
ipv6:显示SSL重协商防护的IPv6异常会话统计节点列表。
count:显示SSL重协商防护的异常会话统计节点数。
zone:显示指定DDoS攻击防护对象下SSL重协商防护的异常会话统计节点列表。
id zone-id:指定DDoS攻击防护对象ID,取值范围为2~1024。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示指定所有成员设备。
仅DDoS攻击清洗设备支持配置本命令。
若不指定DDoS攻击防护对象,则显示所有DDoS攻击防护对象下SSL重协商防护的异常会话统计节点列表。
# 显示所有DDoS攻击防护对象下SSL重协商防护的IPv6异常会话统计节点列表。
<Sysname> display anti-ddos ssl-defend illegal-session-stat-nodes ipv6 zone id 2
Slot 1:
Zone ID Source-ipv6 Illegal sessions
3 3::2:1 8
Slot 2:
6 5:1::ff 10
表1-5 display anti-ddos ssl-defend illegal-session-stat-nodes命令显示信息描述表
Zone ID |
DDoS攻击防护对象ID |
Source-ip |
异常IPv4会话的源IP地址 |
Source-ipv6 |
异常IPv6会话的源IP地址 |
Illegal-num |
SSL异常会话数 |
· https-flood defense ssl-defend
display anti-ddos ssl-defend session-stat-nodes命令用来显示SSL重协商防护的会话统计节点列表。
display anti-ddos ssl-defend session-stat-nodes { ip | ipv6 } [ count | zone { default | id zone-id } ] [ slot slot-number [ cpu cpu-number ] ]
任意视图。
ip:显示SSL重协商防护的IPv4会话统计节点列表。
ipv6:显示SSL重协商防护的IPv6会话统计节点列表。
count:显示SSL重协商防护的会话统计节点数。
zone:显示指定DDoS攻击防护对象下SSL重协商防护的会话统计节点列表。
仅DDoS攻击清洗设备支持配置本命令。
若不指定DDoS攻击防护对象,则显示所有DDoS攻击防护对象的SSL重协商防护的会话统计节点信息。
#显示所有DDoS攻击防护对象下SSL重协商防护的IPv6会话统计节点信息。
<Sysname> display anti-ddos ssl-defend session-stat-node ipv6 zone id 2
Slot 1:
Zone ID Source-ipv6 Negotiation-num State
2 1::1 8 normal
Slot 2:
3 ff::1 8 illegal
表1-6 display anti-ddos ssl-defend session-stat-nodes命令显示信息描述表
Zone ID |
DDoS攻击防护对象ID |
Source-ip |
异常IPv4会话的源IP地址 |
Source-ipv6 |
异常IPv6会话的源IP地址 |
Negotiation-num |
SSL会话的协商数目 |
State |
SSL会话统计节点状态,有以下取值: · Normal:表示状态正常 · Illegal:表示状态异常 |
display anti-ddos statistics命令用来显示DDoS攻击防护统计信息。
display anti-ddos statistics { destination-ip { ipv4 [ ip-address ] | ipv6 [ ipv6-address ] } | destination-port | source-ip { ipv4 | ipv6 } | source-port } [ slot slot-number [ cpu cpu-number ] ]
destination-ip:表示基于目的IP地址进行统计
destination-port:表示基于目的端口进行统计。
source-ip:表示基于源IP地址进行统计。
source-port:表示基于源端口进行统计。
ipv4:指定IP地址类型为IPv4。
ipv4-address:显示指定目的IPv4地址的DDoS攻击防护统计信息。若未指定本参数,则显示所有目的IPv4地址的DDoS攻击防护统计信息。
ipv6:指定IP地址类型为IPv6。
ipv6-address:显示指定目的IPv6地址的DDoS攻击防护统计信息。若未指定本参数,则显示所有目的IPv6地址的DDoS攻击防护统计信息。
slot slot-number:显示指定成员设备上的DDoS攻击防护统计信息,slot-number表示设备在IRF中的成员编号。如果不指定该参数,则表示显示所有成员设备上的DDoS攻击防护统计信息
DDoS攻击检测设备支持该命令。DDoS攻击清洗设备上只支持部分display anti-ddos statistics { destination-ip { ipv4 [ ip-address ] | ipv6 [ ipv6-address ] }
# 显示基于源IPv4地址的DDoS攻击防护统计信息。
<Sysname> display anti-ddos statistics source-ip ipv4
Slot 1:
Source IP Dest IP Packet type Input(bps) Output(bps) Input(pps) Output(pps)
3.3.3.3 4.4.4.4 - 100 20 100 30
Slot 2:
2.2.2.2 4.4.4.4 - 100 30 100 30
# 显示基于源IPv6地址的DDoS攻击防护统计信息。
<Sysname> display anti-ddos statistics source-ip ipv6
Slot 1:
Source IPv6 Packet type Input(bps) Output(bps) Input(pps) Output(pps)
3::3 - 100 20 100 30
3::5 - 100 20 100 30
2::6 - 100 30 100 30
Slot 2:
8::3 ACK 100 20 100 30
#显示基于源端口的DDoS攻击防护统计信息。
<Sysname> display anti-ddos statistics source-port
Slot 1:
Source Port Dest addr Packet type Input(bps) Output(bps) Input(pps) Output(pps)
78 3.3.3.3 - 100 20 100 30
54321 3.3.3.3 - 100 20 100 30
Slot 2:
8080 3.3.3.3 - 100 30 100 30
#显示所有基于目的IPv4地址的DDoS攻击防护统计信息。
<Sysname> display anti-ddos statistics destination-ip ipv4
Slot 1:
3.3.3.3 UDP 100 20 60 10
3.3.3.3 IP 100 20 60 10
3.3.3.2 ACK 100 20 60 10
3.3.3.2 IP 100 20 60 10
6.6.6.6 HTTPS 500 50 60 10
6.6.6.6 TCP-FRAG 500 50 60 10
6.6.6.6 User-defined 2 500 50 60 10
6.6.6.6 IP 1500 150 180 30
Slot 2:
4.3.2.3 UDP 100 20 60 10
4.3.2.3 IP 100 20 60 10
5.3.2.3 ACK 100 20 60 10
5.3.2.3 IP 100 20 60 10
表1-7 display anti-ddos statistics 命令显示信息描述表
Source IP |
源IPv4地址 |
Source IPv6 |
源IPv6地址 |
Source port |
源端口号 |
Dest IP |
目的IPv4地址 |
Dest IPv6 |
目的IPv6地址 |
Dest addr |
目的地址 |
Dest port |
目的端口号 |
Packet type |
接收的报文类型,包括: · ACK · DNS query · DNS reply · ICMP · HTTP · SYN · SYN-ACK · UDP · RST · SIP · HTTPS · TCP fragment · UDP fragment · ICMP fragment · User-defined,即自定义DDoS攻击类型 · IP,即IP报文类型 |
Input(bps) |
每秒接收的报文比特数目 |
Output(bps) |
清洗后的报文比特数目 |
Input(pps) |
每秒接收的报文数目 |
Output (pps) |
清洗后的报文数目 |
display anti-ddos statistics bandwidth-limit destination-ip { ipv4 ipv4-address | ipv6 ipv6-address } 命令用来显示指定目的IP地址的限速统计信息。
display anti-ddos statistics bandwidth-limit destination-ip { ipv4 ipv4-address | ipv6 ipv6-address } [ slot slot-number ]
ipv4 ipv4-address:显示指定IPv4地址的限速统计信息。
ipv6 ipv6-address:显示指定IPv6地址的限速统计信息。
slot slot-number:显示指定成员设备上的指定目的IP地址的限速统计信息,slot-number表示设备在IRF中的成员编号。如果不指定该参数,则表示显示所有成员设备上的指定目的IP地址的限速统计信息。
仅清洗设备支持配置本命令,只显示已配置指定类型的限速策略的统计信息。
当清洗设备中有报文通过时,会生成对应报文目的IP的统计节点,若老化时间内无对应目的IP的报文再经过设备,则该目的IP的统计节点会被删除。
若存在指定目的IP的统计节点,输入本命令行能够显示对应的限速阈值配置以及报文流量统计信息;若不存在指定的目的IP的统计节点,输入本命令行不显示数据。
# 显示指定目的IPv4地址的速率限制统计信息。
<Sysname> display anti-ddos statistics bandwidth-limit destination-ip ipv4 10.10.10.10
slot 1:
Type Input(bps) Output(bps) Input(pps) Output(pps) Threshold(Mbps)
TCP 50000 50000 100 100 50
UDP 400000 393216 800 786 3
TCP-FRAG 50000 50000 100 100 50
IP 493216 493216 986 986 50
slot 2:
TCP 20000 20000 40 40 50
UDP 420000 393216 840 786 3
IP 453216 453216 906 906 50
表1-8 display anti-ddos statistics bandwidth-limit destination-ip命令显示信息描述表
Type |
报文类型,包括: · TCP · UDP · ICMP · TCP-FRAG · UDP-FRAG · ICMP-FRAG · Other · IP |
Input(bps) |
综合限速或单类报文限速前的报文速率,单位为bps |
Input(pps) |
综合限速或单类报文限速前的报文速率,单位为pps |
Output(bps) |
综合限速或单类报文限速后的报文速率,单位为bps |
Output(pps) |
综合限速或单类报文限速后的报文速率,单位为pps |
Threhold(Mbps) |
综合速率上限或单类报文速率上限,单位为Mbps |
display anti-ddos statistics destination-ip命令用来显示指定被攻击者的DDoS攻击防护统计信息。
display anti-ddos statistics destination-ip { ipv4 ip-address | ipv6 ipv6-address } { destination-port | source-ip | source-port } [ slot slot-number [ cpu cpu-number ] ]
ipv4 ip-address:指定被攻击者的IPv4地址。
ipv6 ipv6-address:指定被攻击者的IPv6地址。
slot slot-number:显示指定成员设备上指定被攻击者的DDoS攻击防护统计信息,slot-number表示设备在IRF中的成员编号。如果不指定该参数,则表示显示所有成员设备上指定被攻击者的DDoS攻击防护统计信息。
#显示IPv4地址为1.1.1.1的被攻击者基于源IP地址的DDoS攻击防护统计信息。
<Sysname> display anti-ddos statistics destination-ip ipv4 1.1.1.1 source-ip
Slot 1:
Source IP Packet type Input(bps) Output(bps) Input(pps) Output(pps)
3.3.3.3 - 100 20 60 10
Slot 2:
1.1.1.2 - 100 20 60 10
2.2.2.3 - 100 20 60 10
#显示IPv6地址为1::1的被攻击者基于源IP地址的DDoS攻击防护统计信息。
<Sysname> display anti-ddos statistics destination-ip ipv6 1::1 source-ip
Slot 1:
3::3 - 100 20 60 10
4::4 - 100 20 60 10
Slot 2:
3::6 - 100 20 60 10
4::5 - 100 20 60 10
表1-9 display ddos statistics命令显示信息描述表
Source IP |
源IPv4地址 |
Source IPv6 |
源IPv6地址 |
Source port |
源端口号 |
Dest port |
目的端口号 |
Packet type |
接收的报文种类 |
Input(bps) |
每秒接收的报文比特数目 |
Output(bps) |
清洗后的报文比特数目 |
Input(pps) |
每秒接收的数目 |
Output(pps) |
清洗后的数目 |
display anti-ddos statistics http-slow-attack命令用来显示HTTP慢速攻击防范统计信息。
display anti-ddos statistics http-slow-attack destination-ip { ip [ ipv4-address ] | ipv6 [ ipv6-address ] } [ slot slot-number [ cpu cpu-number ] ]
任意视图。
destination-ip:基于目的IP地址显示HTTP慢速攻击防范统计信息。
ip [ ipv4-address ]:显示基于指定IPv4地址的HTTP慢速攻击防范统计信息。若未指定ipv4-address,则显示所有目的IPv4地址的HTTP慢速攻击防范统计信息。
ipv6 [ ipv6-address ]:显示基于指定IPv6地址的HTTP慢速攻击防范统计信息。若未指定ipv6-address,则显示所有目的IPv6地址的HTTP慢速攻击防范统计信息。
cpu cpu-number:指定CPU,cpu-number表示单板上的CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
仅DDoS攻击清洗设备支持配置本命令。
# 查看IPv4慢速防护相关信息。
<Sysname> display anti-ddos statistics http-slow-attack destination-ip ip
Slot 1:
Zone ID Dest-ip Concurrent-num Illegal requests
3 192.168.8.9 100 80
3 192.168.3.6 200 90
Slot 2:
4 192.168.9.6 5 0
表1-10 display anti-ddos statistics http-slow-attack命令显示信息描述表
Zone ID |
DDoS攻击防护对象ID |
Dest-ip |
攻击的目的IPv4地址 |
Dest-ipv6 |
攻击的目的IPv6地址 |
Concurrent-num |
并发连接数 |
Illegal requests |
非法请求数 |
· http-slow-attack defense threshold
display anti-ddos whitelist命令用来显示全局静态白名单表项。
display anti-ddos whitelist [ ip source-ip-address | ipv6 source-ipv6-address ]
ip source-ip-address:显示指定源IPv4地址的DDoS全局静态白名单表项。
ipv6 source-ipv6-address:显示指定源IPv4地址的DDoS全局静态白名单表项。
仅清洗设备支持配置本命令。
若未指定IPv4地址或IPv6地址参数,则表示显示所有的IPv4或IPv6白名单表项。
# 显示所有全局静态白名单。
<Sysname> display anti-ddos whitelist
3.3.3.4/32 White
# 显示指定IP对应的全局静态白名单。
<Sysname> display anti-ddos whitelist ip 3.3.3.4
3.3.3.4/32 White
#显示指定IPv6对应的全局静态白名单。
<Sysname> display anti-ddos whitelist ipv6 8000::1
Total: 4 Blacklist: 3 Whitelist: 0
表1-11 display anti-ddos blacklist命令显示信息描述表
Total |
Blacklist |
IPv4或IPv6黑名单表项数目 |
Whitelist |
IPv4或IPv6白名单表项数目 |
Source-ip/MaskLen |
源IP地址及掩码长度 |
Black/White |
表项类型,即黑名单或白名单 |
display anti-ddos whitelist zone命令用来显示DDoS攻击防护对象静态白名单表项。
display anti-ddos whitelist zone [ { id zone-id | default } [ ip source-ip-address | ipv6 source-ipv6-address ] ]
ip source-ip-address:显示指定源IPv4地址的DDoS攻击防护对象静态白名单表项。
ipv6 source-ipv6-address:显示指定源IPv4地址的DDoS攻击防护对象静态白名单表项。
仅DDoS攻击清洗设备支持配置本命令。
若未指定DDoS攻击防护对象,则显示所有DDoS攻击防护对象下的静态白名单表项。
若未指定IPv4地址或IPv6地址参数,则显示DDoS攻击防护对象下的所有静态白名单表项。
# 显示所有DDoS攻击防护对象下的静态白名单表项。
<Sysname> display anti-ddos whitelist zone
2 3.3.3.4/32 White
# 显示ID为2的DDoS攻击防护对象下匹配IP地址3.3.3.4的静态白名单表项。
<Sysname> display anti-ddos whitelist zone 2 ip 3.3.3.4
2 3.3.3.4/32 White
#显示ID为2的DDoS攻击防护对象下匹配IPv6地址8000::1的静态白名单表项。
<Sysname> display anti-ddos whitelist zone 2 ipv6 8000::1
2 8000::/64 White
表1-12 display anti-ddos whitelist zone命令显示信息描述表
Total |
Blacklist |
Whitelist |
ZoneID |
DDoS攻击防护对象ID |
Source-ip/MaskLen |
源IP地址及掩码长度 |
Black/White |
表项类型,即黑名单或白名单 |
· zone-whitelist
display anti-ddos zone configuration命令用于显示DDoS攻击防护对象的配置信息。
display anti-ddos zone configuration [ default | id zone-id ]
DDoS攻击检测设备和DDoS攻击清洗设备上都支持该命令。
若未指定default和id zone-id,则显示所有DDoS攻击防护对象的概要配置信息。
# 显示指定DDoS攻击防护对象的配置信息。
<Sysname> display anti-ddos zone configuration id 2
Anti-DDoS zone configuration information
Zone ID : 2
Zone name : abc
IP range configuration:
Start IP End IP
1.1.1.1 1.1.1.100
2.2.2.2 2.2.2.10
Flood detection destination-ip configuration:
Flood type Thres(pps/Mbps)
DNS query 1000 pps
DNS reply 1000 pps
HTTP 1000 bps
SYN 1000 pps
ACK 1000 Mbps
SYN-ACK 1000 pps
RST 1000 pps
UDP 1000 Mbps
ICMP 1000 Mbps
SIP 1000 Mbps
TCP fragment 1000 Mbps
UDP fragment 1000 Mbps
ICMP fragment 1000 Mbps
User-defined 2 1000 pps
ACK session check configuration: Enabled
Source verification configuration:
Type Status
TCP Enabled
HTTP Enabled
DNS query Enabled
DNS reply Enabled
SIP Enabled
HTTPS Enabled
Bandwidth configuration:
bandwidth-detection destination-ip threshold: 20
bandwidth-limit destination-ip max-rate: 10
Threshold Learning: Enabled
表1-13 display anti-ddos zone命令显示信息描述表
Anti-ddos zone Information |
DDoS攻击防护对象配置信息 |
Zone name |
DDoS攻击防护对象名称 |
Zone ID |
DDoS攻击防护对象ID |
IP configuration |
DDoS攻击防护对象的IP地址范围 |
Start IP |
起始IP地址 |
End IP |
结束IP地址 |
Flood detection destination-ip configuration |
目的IP方向泛洪攻击防范配置信息 |
Flood type |
泛洪攻击类型,包括: · ACK flood · DNS-QUERY flood · DNS-REPLY flood · ICMP flood · SYN flood · SYN-ACK flood · UDP flood · RST flood · HTTP flood · SIP flood · HTTPS flood · TCP fragment flood · UDP fragment flood · ICMP fragment flood · User-defined flood,即自定义DDoS攻击类型 |
Thres(pps/Mbps) |
泛洪攻击防范阈值,单位为pps或Mbps |
Ack session check configuration |
ACK状态防护开启状态,包括: · Enabled:启用 · Disabled:关闭 |
Bandwidth configuration |
DDoS攻击防护对象下带宽阈值的配置 |
Bandwidth-detection destination-ip threshold |
IP流量攻击的防范触发阈值 |
Bandwidth-limit destination-ip max-rate |
IP流量限速的最大带宽限制 |
Threshold Learning |
阈值学习功能的开启状态,取值包括: · Enabled:启用 · Disabled:关闭 |
# 显示所有DDoS攻击防护对象的概要配置信息。
Anti-ddos Zone Brief information
Zone ID Zone Name
2 abc
100 p1
10 p12
表1-14 display anti-ddos zone configuration命令显示信息描述表
Zone ID |
DDoS攻击防护对象ID |
Zone Name |
DDoS攻击防护对象名称 |
dns-query-flood defense source-verify命令用来开启DNS query泛洪攻击的源验证功能。
undo dns-query-flood defense source-verify命令用来关闭DNS query泛洪攻击的源验证功能。
DNS query泛洪攻击的源验证功能处于关闭状态。
DDoS攻击防护对象视图
该命令只在DDoS攻击清洗设备上支持。
该功能用来保护内部网络的DNS服务器免受外部网络中非法客户端发起的DNS query泛洪攻击。若在DDoS攻击清洗设备上开启了DNS query泛洪攻击的源验证功能,则设备会对发往受攻击IP地址的DNS query报文进行源地址验证,通过源地址验证的IP地址将被加入信任IP地址列表中,之后设备将放行来自该IP地址的DNS query报文。未通过源地址验证的DNS query报文会被丢弃。
# 在DDoS攻击防护对象视图下,开启DNS query泛洪攻击的源验证功能。
[Sysname-anti-ddos-zone-id-3] dns-query-flood defense source-verify
dns-query-flood detection threshold命令用来配置DNS query泛洪攻击防范阈值,并开启DNS query泛洪攻击检测功能。
undo dns-query-flood detection threshold命令用来关闭DNS query泛洪攻击检测功能。
dns-query-flood detection threshold { bit-based value | packet-based value}
DNS query泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示DNS query泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示DNS query泛洪攻击的统计方式为按照报文个数进行统计。
value:表示DNS query泛洪攻击防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
开启DNS query泛洪攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行DNS query泛洪攻击检测。当设备检测到向某IP地址发送DNS query报文的速率持续超过了配置的阈值时,即认为该IP地址受到了DNS query泛洪攻击,继而启动相应的防范措施:
此后,当设备检测到向该IP地址发送报文的速率持续低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,并停止执行防范措施。
# 在ID为3的DDoS攻击防护对象视图下,开启DNS query泛洪攻击检测功能,并配置DNS query泛洪攻击防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] dns-query-flood detection threshold packet-based 20
dns-reply-flood defense source-verify命令用来开启DNS reply泛洪攻击的源验证功能。
undo dns-reply-flood defense source-verify命令用来关闭DNS reply泛洪攻击的源验证功能。
DNS reply泛洪攻击的源验证功能处于关闭状态。
DDoS攻击防护对象视图
该命令只在DDoS攻击清洗设备上支持。
本功能用来防御客户端受到的DNS reply泛洪攻击。若在DDoS攻击清洗设备上开启了DNS reply泛洪攻击的源验证功能,则设备会对发往受攻击IP地址的DNS reply 报文进行源地址验证,通过源地址验证的IP地址将被加入信任IP地址列表中,之后设备将放行来自该IP地址的DNS reply 报文。未通过源地址验证的DNS reply报文会被丢弃。
# 在DDoS攻击防护对象视图下,开启DNS reply泛洪攻击的源验证功能。
[Sysname-anti-ddos-zone-id-3] dns-reply-flood defense source-verify
dns-reply-flood detection threshold命令用来配置DNS reply泛洪攻击防范阈值,并开启DNS reply泛洪攻击检测功能。
undo dns-reply-flood detection threshold命令用来关闭DNS reply泛洪攻击检测功能。
dns-reply-flood detection threshold { bit-based value | packet-based value}
DNS reply泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示DNS reply泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示DNS reply泛洪攻击的统计方式为按照报文个数进行统计。
value:表示DNS reply泛洪攻击防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
开启DNS reply泛洪攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行DNS reply泛洪攻击检测。当设备检测到向某IP地址发送DNS reply报文的速率持续超过了配置的阈值时,即认为该IP地址受到了DNS reply泛洪攻击,继而启动相应的防范措施:
# 在ID为3的DDoS攻击防护对象视图下,开启DNS reply泛洪攻击检测功能,并配置DNS reply泛洪攻击防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] dns-reply-flood detection threshold packet-based 20
domain命令用来创建DNS报文Domain字段匹配规则。
undo domain命令用来删除DNS报文Domain字段匹配规则。
domain { equal | include } domain-string
undo domain [ { equal | include } domain-string ]
DDoS攻击防护过滤器中不存在DNS报文Domain字段匹配规则。
DNS过滤器视图
equal:表示DNS报文的Domain字段的内容与指定关键字完全一致。
include:表示DNS报文的Domain字段的内容包含指定关键字。
domain-string:指定Domain关键字,为2~63个字符的字符串,不区分大小写。
DNS报文Domain字段匹配规则用于匹配Domain字段拥有指定关键字的DNS报文。
每个DNS过滤器中最多可以创建32条Domain字段匹配规则。DNS报文满足其中任意一条匹配规则,即被视作满足DNS报文Domain字段匹配条件。
如果执行undo domain命令时不指定任何参数,则表示删除该过滤器视图下所有的DNS报文Domain字段匹配规则。
# 在DNS过滤器test中创建一条DNS报文Domain字段匹配规则:DNS报文的Domain字段的内容包含字符串abc.example.com。
[Sysname] anti-ddos filter name test type dns
[Sysname-anti-ddos-filter-dns-test] domain include abc.example.com
· anti-ddos filter
dscp命令用来创建DSCP匹配规则。
undo dscp命令用来删除DSCP匹配规则。
dscp dscp
undo dscp [ dscp ]
DDoS攻击防护过滤器中不存在DSCP匹配规则。
DDoS攻击防护过滤器视图
dscp:指定报文的差分服务等级,取值范围为0~63。
DSCP匹配规则用于匹配拥有指定差分服务等级的报文。
每个过滤器中最多可以创建10条DSCP匹配规则。报文满足其中任意一条匹配规则,即被视作满足DSCP匹配条件。
如果执行undo dscp命令时不指定dscp参数,则表示删除该过滤器视图下所有的DSCP匹配规则。
# 在HTTP过滤器test中创建一条DSCP匹配规则:报文的差分服务等级为20。
[Sysname-anti-ddos-filter-http-test] dscp 20
· anti-ddos filter
fingerprint命令用来创建报文指纹匹配规则。
undo fingerprint命令用来删除报文指纹匹配规则。
fingerprint id { offset offset-value content content [ depth depth-value ] } &<1-4>
undo fingerprint [ id ]
DDoS攻击防护过滤器中不存在报文指纹匹配规则。
DDoS攻击防护过滤器视图
offset offset-value:指定报文指纹的偏移量,取值范围为0~1500。
content content:指定报文指纹的内容,取值范围为4~16个字节,每个字节由2个十六进制数表示。
depth depth-value:指定报文指纹的深度,取值范围为1~1500,缺省值为0。
&<1-4>:表示前面的参数最多可以输入四次,即最多可以指定4段匹配内容,每段均可包括指纹的偏移量、内容和深度。
报文指纹匹配规则用于匹配在指定位置范围内包含所配指纹内容的报文。每个过滤器中最多可以创建10条报文指纹匹配规则,每条规则最多可以配置4段报文指纹,设备最多可以配置512段报文指纹。
对于每段报文指纹,设备以报文头部第offset字节作为起点开始搜索:
· 若该段报文指纹中配置了depth-value参数,则设备在搜索起点后长度为depth-value的范围内搜索指纹内容。
· 若该段报文指纹中未配置depth-value参数,则设备直接将指纹内容与搜索起点后相同长度的内容对比。
若搜索到指纹内容,则称报文匹配该段指纹。
若规则中配置了多段指纹,则报文必须同时匹配这几段指纹,才算满足该匹配规则。报文满足过滤器下任意一条指纹匹配规则,即被视作满足报文指纹匹配条件。
如果执行undo fingerprint命令时不指定id参数,则表示删除该过滤器视图下所有的报文指纹匹配规则。
# 在HTTP过滤器test中创建一条报文指纹匹配规则,规则内包含两段报文指纹:其中一段指纹的偏移量为10,内容为aabbccdd;另一段指纹的偏移量为20,内容为2233,深度为10。
[Sysname-anti-ddos-filter-http-test] fingerprint 20 offset 10 content aabbccdd offset 20 content 22334455 depth 10
· anti-ddos filter
fingerprint命令用来创建一条指纹防护策略。
undo fingerprint命令用来删除指定的指纹防护策略。
fingerprint policy-id protocol { icmp | other | tcp | udp } { offset offset-value length length-value [ content content ] } &<1-3> threshold threshold-value action { bandwidth-limit | drop | watch }
undo fingerprint id
不存在指纹防护策略。
指纹防护策略组视图
policy-id:指纹防护策略ID,取值范围为0~31。
protocol { icmp | other | tcp | udp }:表示报文指纹的协议类型,包括ICMP、其他、TCP、UDP类型。
offset offset-value:表示报文指纹的偏移量,取值范围为0~254。
length length-value :表示报文指纹的长度,取值范围为1~4,单位为字节。
content content:表示报文指纹的内容,1~4个字节,每个字节由2个十六进制数表示。
&<1-3>:表示前面的参数最多可以输入三次。即每条指纹防护策略最多可以指定3段匹配内容,每段均可包括指纹的偏移量、长度和内容。
threshold threshold-value:配置指纹防护防范阈值。其中,threshold-value为每秒匹配上指定指纹的报文数目,取值范围1~10000000,单位为pps。
action:配置匹配指纹特征的报文速率超过阈值时的处理行为。
bandwidth-limit:表示限制报文速率,即匹配指纹特征的报文速率超过阈值时,后续匹配该指纹的流量将被限制为阈值速率,每秒内超出阈值的流量将会被丢弃。
drop:表示丢弃报文,即匹配指纹特征的报文速率超过阈值时,后续匹配该指纹的流量将会被丢弃。
watch:表示不会对匹配该指纹的后续流量采取任何处理行为。
仅DDoS攻击清洗设备支持配置本命令。
一条指纹防护策略中,定义了报文的特征以及触发指纹防护的阈值和设备的处理行为。对于匹配上指纹特征的报文,若报文速率超过指纹防护防范阈值,则采取相应的处理行为。
若一条指纹防护策略中,同时指定多段匹配内容,则报文必须同时匹配多段内容,才算匹配上指纹。
配置指纹防护的处理行为时,无论指定哪种动作,设备均会发送日志信息。
报文指纹中不支持配置IP option或IPv6扩展头的匹配。
每个指纹防护策略组下面最多可以配置32条指纹防护策略,对于TCP、UDP、ICMP及其他协议类型各限制为8条。
在同一条指纹防护策略中,不允许配置多段内容重复的指纹。
# 配置IPv4类型ID为10的指纹防护策略组,并进入指纹防护策略组视图,之后配置ID为5的指纹防护策略:当匹配上指定指纹特征的报文速率超过指纹防护防范阈值2000时,采取的指纹防护的处理行为为观察。
[Sysname] fingerprint-group ip 10
[Sysname-fingerprint-group-ip-10] fingerprint 5 protocol tcp offset 40 length 4 content 01ab3f0c threshold 2000 action watch
· bandwidth-limit destination-ip max-rate
fingerprint-group命令用来创建一个指纹防护策略组,并进入指纹防护策略组视图。如果指定的指纹防护策略组已经存在,则直接进入指纹防护策略组视图。
undo fingerprint-group命令用来删除指定的指纹防护策略组。
fingerprint-group { ip | ipv6 } group-id
undo fingerprint-group { ip | ipv6 } group-id
不存在指纹防护策略组。
ip:指纹防护策略组的类型为IPv4。
ipv6:指纹防护策略组的类型为IPv6。
group-id:指纹防护策略组ID,取值范围为0~31。
仅DDoS攻击清洗设备支持配置本命令。
设备最多允许配置64个指纹防护策略组,IPv4和IPv6各32个。
# 配置IPv4类型ID为10的指纹防护策略组,并进入指纹防护策略组视图。
· fingerprint
· fingerprint-group { ip | ipv6 }
fingerprint-group apply命令用来引用一个指纹防护策略组。
undo fingerprint-group apply命令用来删除对指定指纹防护策略组的引用。
fingerprint-group apply { ip | ipv6 } group-id
undo fingerprint-group apply { ip | ipv6 }
未引用指纹防护策略组。
DDoS攻击防护对象视图
ip:指纹防护策略组的类型为IPv4。
仅DDoS攻击清洗设备支持配置本命令。
一个DDoS防护对象只能引用一个IPv4指纹防护策略组和IPv6指纹防护策略组。
# 在ID为3的DDoS防护对象视图下,引用ID为10的指纹防护策略组。
[Sysname-ddos-zone-3] fingerprint-group apply ip 10
fragment命令用来创建分片报文匹配规则。
undo fragment命令用来删除分片报文匹配规则。
fragment { donot | first | last | middle | non }
undo fragment [ donot | first | last | middle | non ]
DDoS攻击防护过滤器中不存在分片报文匹配规则。
DDoS攻击防护过滤器视图
donot:表示IP头部的DF位为1的报文,即不能分片的报文。
first:表示IP头部片偏移字段为0,MF位为1的报文,即报文首个分片。
last:表示IP头部片偏移字段为非0,MF位为0的报文,即报文最后一个分片。
middle:表示IP头部片偏移字段为非0,MF位为1的报文,即报文的中间分片。
non:表示IP头部片偏移字段为0,MF位为0的报文,即非分片报文。
分片报文匹配规则用于匹配满足指定分片情况的报文。
每个过滤器中最多可以创建5条分片报文匹配规则。报文满足其中任意一条匹配规则,即被视作满足分片报文匹配条件。
如果执行undo fragment命令时不指定任何参数,则表示删除该过滤器视图下所有的分片报文匹配规则。
# 在HTTP过滤器test中创建一条匹配非分片报文的规则。
[Sysname-anti-ddos-filter-http-test] fragment non
· anti-ddos filter
host命令用来创建HTTP报文Host字段匹配规则。
undo host命令用来删除HTTP报文Host字段匹配规则。
host include host-name
undo host [ include host-name ]
DDoS攻击防护过滤器中不存在HTTP报文Host字段匹配规则。
HTTP过滤器视图
include:表示HTTP报文的Host字段的内容包含指定的关键字。
host-name:指定Host关键字,为2~63个字符的字符串,不区分大小写。
HTTP报文Host字段匹配规则用于匹配Host字段包含指定关键字的HTTP报文。
每个HTTP过滤器中最多可以创建32条Host字段匹配规则。HTTP报文满足其中任意一条匹配规则,即被视作满足HTTP报文Host字段匹配条件。
如果执行undo host命令时不指定任何参数,则表示删除该过滤器视图下所有的HTTP报文Host字段匹配规则。
# 在HTTP过滤器test中创建一条Host字段匹配规则:HTTP报文的Host字段的内容包含字符串abc.example.com。
[Sysname-anti-ddos-filter-http-test] host include abc.example.com
· anti-ddos filter
http-flood defense source-verify命令用来开启HTTP泛洪攻击的源验证功能。
undo http-flood defense source-verify命令用来关闭HTTP泛洪攻击的源验证功能。
HTTP泛洪攻击的源验证功能处于关闭状态。
DDoS攻击防护对象视图
该命令只在DDoS攻击清洗设备上支持。
该功能用来保护内部网络的服务器免受外部网络中非法客户端发起的HTTP泛洪攻击。若在DDoS攻击清洗设备上开启了HTTP泛洪攻击的源验证功能,则设备会对发往受攻击IP地址的HTTP GET请求报文进行源地址验证,通过源地址验证的客户端将被加入信任IP地址列表中,之后设备将放行来自该IP地址的HTTP GET请求报文。未通过源地址验证的HTTP GET请求报文会被丢弃。
# 在DDoS攻击防护对象视图下,开启HTTP泛洪攻击的源验证功能。
[Sysname-anti-ddos-zone-id-3] http-flood defense source-verify
http-flood detection threshold命令用来配置HTTP泛洪攻击防范阈值,并开启HTTP泛洪攻击检测功能。
undo http-flood detection threshold命令用来关闭HTTP泛洪攻击检测功能。
http-flood detection threshold { bit-based value | packet-based value}
HTTP泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示HTTP泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示HTTP泛洪攻击的统计方式为按照报文个数进行统计。
value:表示HTTP泛洪攻击防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
开启HTTP泛洪攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行HTTP泛洪攻击检测。当设备检测到向某IP地址发送HTTP报文的速率持续超过了配置的阈值时,即认为该IP地址受到了HTTP泛洪攻击,继而启动相应的防范措施:
# 在ID为3的DDoS攻击防护对象视图下,开启HTTP泛洪攻击检测功能,并配置HTTP泛洪攻击防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] http-flood detection threshold packet-based 20
https-flood defense source-verify命令用来开启HTTPS flood攻击的源验证功能。
undo https-flood defense source-verify命令用来关闭HTTPS flood攻击的源验证功能。
HTTPS flood攻击的源验证功能处于关闭状态。
防护对象视图
仅DDoS攻击清洗设备支持配置本命令。
该功能用来保护内部网络的服务器免受外部网络中非法客户端发起的HTTPS flood攻击。若在清洗设备上开启了HTTPS flood攻击的源验证功能,则设备会对发往受攻击IP地址的HTTPS报文进行源地址验证,通过源地址验证的客户端将被加入信任IP地址列表中,之后设备将放行来自该IP地址的HTTPS报文,未通过源地址验证的HTTPS报文会被丢弃。
# 在ID为5的防护对象视图下开启HTTPS flood攻击的源验证功能。
[Sysname-anti-ddos-id-5] https-flood defense source-verify
· https-flood detection threshold
https-flood defense ssl-defend命令用来开启HTTPS flood攻击的SSL重协商防护功能。
undo https-flood defense ssl-defend命令用来关闭HTTPS flood攻击的SSL重协商防护功能。
https-flood defense ssl-defend [ negotiation-num negotiation-num [ interval interval ] | illegal-session-num illegal-session-num [ interval interval2 ] ]*
HTTPS flood攻击的SSL重协商防护功能处于关闭状态。
DDoS攻击防护对象视图。
negotiation-num negotiation-num:表示一个SSL会话允许协商的最大次数,取值范围为1~10,缺省值为3。
interval interval:表示SSL重协商检查的周期,取值范围为1~240,单位为秒,缺省值为30。
illegal-session-num illegal-session-num:表示SSL异常会话数阈值,取值范围为1~10,缺省值为3。
interval interval2:表示SSL异常会话检查的周期,取值范围为1~240,单位为秒,缺省值为15。
仅DDoS攻击清洗设备支持配置本命令。
本功能检查在重协商检查周期内SSL会话的协商次数是否超过指定阈值,若超过阈值则将该会话标记为异常会话,如果源自同一IP地址的异常会话数在指定SSL异常会话检查周期内超过阈值,则将该源IP地址加入黑名单。
执行本命令前请先开启HTTPS源认证功能(执行https-flood defense source-verify命令),否则本功能不生效。
# 在ID为5的DDoS攻击防护对象视图下开启HTTPS源认证防护功能和SSL重协商防御,且设置SSL重协商的最大次数为20,检测周期为3,最大异常会话数为5,检测周期为5。
[Sysname-anti-ddos-id-5] https-flood defense ssl-defend negotiation-num 20 interval 3 illegal-session-num 5 interval 5
· https-flood defense source-verify
https-flood detection threshold命令用来开启HTTPS泛洪攻击检测功能,并配置HTTPS 泛洪攻击防范阈值。
undo https-flood detection threshold命令用来关闭HTTPS泛洪攻击检测功能。
https-flood detection threshold { bit-based | packet-based } value
HTTPS泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示HTTPS泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示HTTPS泛洪攻击的统计方式为按照报文个数进行统计。
value:表示HTTPS泛洪攻击的防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
检测设备和清洗设备均支持配置本命令。
开启HTTPS泛洪攻击检测功能后,会对设备收到的指定DDoS防护对象的流量进行HTTPS泛洪攻击检测。
当设备检测到向某IP地址发送HTTPS报文的速率超过了配置的阈值时,即认为该IP地址受到了HTTPS泛洪攻击,然后启动相应的防范措施:
对于旁路部署的检测设备,会向管理中心发送攻击告警通知,管理中心收到攻击告警通知后向清洗设备下发引流策略,将攻击流量引流到清洗设备上进行流量检测和流量清洗。
对于直路部署的清洗设备:在设备本地对攻击流量进行清洗。
# 在ID为3的DDoS攻击防护对象视图下,开启HTTPS泛洪攻击检测功能,并配置防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] https-flood detection threshold packet-based 20
http-slow-attack defense threshold命令用来开启HTTP慢速攻击检测功能,并配置HTTP慢速攻击防范阈值和防范动作。
undo http-slow-attack defense命令用来关闭HTTP慢速攻击检测功能。
http-slow-attack defense threshold alert-number alert-number [ content-length content-length | packet-number packet-number | payload-length payload-length ] * [ action block-source ]
HTTP慢速攻击检测功能处于关闭状态。
DDoS攻击防护对象视图。
alert-number alert-number:指定触发HTTP慢速攻击防范的HTTP并发连接数阈值,取值范围为1~1200000。
content-length content-length:指定HTTP报文Content-Length字段取值的阈值,取值范围为100~100000000,缺省值为10000。
packet-number packet-number:指定异常报文数目的防范阈值,取值范围为1~1000,缺省值为10。
payload-length payload-length:指定实际载荷长度的阈值,取值范围为1~1000,缺省为50。
action block-source:指定HTTP慢速攻击的防范动作为阻断并丢弃来自该IP地址的后续报文。
仅DDoS攻击清洗设备支持配置本命令。
开启HTTP慢速攻击检测功能后,设备首先根据目的IP地址统计HTTP并发连接数,若连接数超过指定阈值,则对如下HTTP慢速攻击进行检测,并统计异常HTTP报文数:
· Slow header:如果HTTP请求头没有以“\r\n\r\n”结束,则将其判定为异常报文。
· Slow post:如果HTTP请求头部的Content-Length大于阈值且报文携带的实际负载长度小于阈值,则将其判定为异常报文。
然后,如果访问某IP地址的异常HTTP报文数超过指定阈值,则将后续访问该IP地址的流量阻断,并发送HTTP慢速攻击告警日志。若开启HTTP慢速攻击检测功能时指定了block-source动作,则还会将报文源IP地址加入动态黑名单中。
# 在ID为3的DDoS攻击防护对象视图下,配置HTTP慢速攻击防范的触发阈值为3000,HTTP报文首部Content-Length字段的阈值为10000,HTTP报文实际载荷阈值为20,异常报文的防范阈值为10,并将异常报文源IP地址加入动态黑名单。
[Sysname-anti-ddos-zone-id-3] http-slow-attack defense threshold alert-number 3000 content-length 10000 payload-length 20 packet-number 10 action block-source
· anti-ddos zone id
icmp-flood detection threshold命令用来配置ICMP泛洪攻击防范阈值,并开启ICMP泛洪攻击检测功能。
undo icmp-flood detection threshold命令用来关闭ICMP泛洪攻击检测功能。
icmp-flood detection threshold { bit-based value | packet-based value}
ICMP泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示ICMP泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示ICMP泛洪攻击的统计方式为按照报文个数进行统计。
value:表示ICMP泛洪攻击防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
开启ICMP泛洪攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行ICMP泛洪攻击检测。当设备检测到向某IP地址发送ICMP报文的速率持续超过了配置的阈值时,即认为该IP地址受到了ICMP泛洪攻击,继而启动相应的防范措施:
· 旁路部署的DDoS攻击检测设备会向管理中心发送攻击告警日志,管理中心收到攻击告警日志后向DDoS攻击清洗设备下发引流策略,将攻击流量引流到DDoS攻击清洗设备上进行流量清洗。
# 在ID为3的DDoS攻击防护对象视图下,开启ICMP泛洪攻击检测功能,并配置ICMP泛洪攻击防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] icmp-flood detection threshold packet-based 20
icmp-frag-flood detection threshold命令用来开启ICMP分片泛洪攻击检测功能,并配置ICMP分片泛洪攻击防范阈值。
undo icmp-frag-flood detection threshold命令用来关闭ICMP分片泛洪攻击检测功能。
icmp-frag-flood detection threshold { bit-based | packet-based } value
ICMP分片泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示ICMP分片泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示ICMP分片泛洪攻击的统计方式为按照报文个数进行统计。
value:表示ICMP分片泛洪攻击的防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
检测设备和清洗设备均支持配置本命令。
开启ICMP分片泛洪攻击检测功能后,会对设备收到的指定DDoS防护对象的流量进行ICMP分片泛洪攻击检测。
当设备检测到向某IP地址发送ICMP分片报文的速率超过了配置的阈值时,即认为该IP地址受到了ICMP分片泛洪攻击,启动相应的防范措施:
· 对于旁路部署的检测设备,会向管理中心发送攻击告警通知,管理中心收到攻击告警通知后向清洗设备下发引流策略,将攻击流量引流到清洗设备上进行流量检测和流量清洗。
· 对于直路部署的清洗设备:在设备本地对攻击流量进行清洗。
# 在ID为3的DDoS攻击防护对象视图下,开启ICMP分片泛洪攻击检测功能,并配置防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] icmp-frag-flood detection threshold packet-based 20
ip-range命令用来添加DDoS攻击防护对象的IPv4地址范围。
undo ip-range命令用来删除DDoS攻击防护对象的IPv4地址范围。
undo ip-range start-ip end-ip
未配置DDoS攻击防护对象的IPv4地址范围。
DDoS攻击防护对象视图
start-ip:表示IPv4地址范围的起始IPv4地址。
end-ip:表示IPv4地址范围的结束IPv4地址。
每个防护对象最多允许配置128段IPv4地址范围,每个地址范围内IPv4地址的前16位必须相同,各个DDoS攻击防护对象下的IPv4地址范围不允许重叠,设备最多支持512个前16位不同的IPv4和IPv6地址范围。
缺省DDoS攻击防护对象不支持配置本命令。
# 在ID为3的DDoS攻击防护对象视图下,添加DDoS攻击防护对象的IPv4地址范围为192.168.30.10~192.168.30.120。
[Sysname-anti-ddos-zone-id-3] ip-range 192.168.30.10 192.168.30.120
· ipv6-range
ipv6-range命令用来添加DDoS攻击防护对象的IPv6地址范围。
undo ipv6-range命令用来删除DDoS攻击防护对象的IPv6地址范围。
ipv6-range start-ip end-ip
undo ipv6-range start-ip end-ip
未配置DDoS攻击防护对象的IPv6地址范围。
DDoS攻击防护对象视图
start-ip:表示IPv6地址范围的起始IPv6地址。
end-ip:表示IPv6地址范围的结束IPv6地址。
每个防护对象最多允许配置128段IPv6地址范围,每个地址范围内IPv6地址的前16位必须相同,
各个DDoS攻击防护对象下的IPv6地址范围不允许重叠,设备最多支持512个前16位不同的IPv4和IPv6地址范围。
# 在ID为3的DDoS攻击防护对象视图下,添加DDoS攻击防护对象的IPv6地址范围为192:168:30::10~192:168:30::120。
[Sysname-anti-ddos-zone-id-3] ipv6-range 192:168:30::10 192:168:30::120
· ip-range
name命令用来配置DDoS攻击防护对象的名称。
undo name命令用来恢复缺省情况。
name zone-name
undo name
不存在DDoS攻击防护对象的名称。
DDoS攻击防护对象视图
zone-name:DDoS攻击防护对象名称,为1~31个字符的字符串,不区分大小写。合法取值包括大写字母、小写字母、数字、特殊字符“_”和“-”。名称不能为“default”。
不支持配置缺省DDoS攻击防护对象的名称。
# 在ID为3的DDoS攻击防护对象视图下,配置DDoS攻击防护对象的名称为test。
[Sysname-anti-ddos-zone-id-3] name test
· anti-ddos zone
opcode命令用来创建HTTP报文操作码匹配规则。
undo opcode命令用来删除HTTP报文操作码匹配规则。
opcode { connect | delete | get | head | options | post | put | trace }
undo opcode { connect | delete | get | head | options | post | put | trace }
DDoS攻击防护过滤器中不存在HTTP报文操作码匹配规则。
HTTP过滤器视图
conncet:表示HTTP CONNECT请求报文。
delete:表示HTTP DELETE请求报文。
get:表示HTTP GET请求报文。
head:表示HTTP HEAD请求报文。
options:表示HTTP OPTIONS请求报文。
post:表示HTTP POST请求报文。
put:表示HTTP PUT请求报文。
trace:表示HTTP TRACE请求报文。
HTTP报文操作码匹配规则用于匹配指定类型的HTTP请求报文。
每个HTTP过滤器中最多可以创建8条HTTP报文操作码匹配规则。报文满足其中任意一条匹配规则,即被视作满足HTTP报文操作码匹配条件。
# 在HTTP过滤器test中创建一条匹配HTTP PUT请求报文的规则。
[Sysname-anti-ddos-filter-http-test] opcode put
· anti-ddos filter
packet-length命令用来创建报文长度匹配规则。
undo packet-length命令用来删除报文长度匹配规则。
packet-length range length1 length2
undo packet-length [ range length1 length2 ]
DDoS攻击防护过滤器中不存在报文长度匹配规则。
DDoS攻击防护过滤器视图
range:报文长度范围。
length1:指定报文长度下限,取值范围为1~1500,单位为字节。
length2:指定报文长度上限,取值范围为1~1500,单位为字节。
报文长度匹配规则用于匹配报文长度在指定范围内的报文。
每个过滤器中最多可以创建10条报文长度匹配规则。报文满足其中任意一条匹配规则,即被视作满足报文长度匹配条件。
本命令所配置的报文长度上限不能大于报文长度下限。在同一个过滤器视图下多次执行本命令所配置的报文长度范围不允许重叠。
如果执行undo packet-length命令时不指定任何参数,则表示删除该过滤器视图下所有的报文长度匹配规则。
# 在HTTP过滤器test中创建一条报文长度匹配规则:报文长度处在50~500字节范围内。
[Sysname-anti-ddos-filter-http-test] packet-length range 50 500
· anti-ddos filter
protocol命令用来创建报文协议匹配规则。
undo protocol命令用来删除报文协议匹配规则。
undo protocol [ protocol-number ]
DDoS攻击防护过滤器未配置报文协议限制。
IP过滤器视图
protocol-number:指定报文的协议号,取值范围为0~255。
报文协议匹配规则用于匹配指定协议号的报文。
每个过滤器中最多可以创建10条报文协议匹配规则。IP报文满足其中任意一条匹配规则,即被视作满足报文协议匹配条件。
如果执行undo protocol命令时不指定protocol-number参数,则表示删除该过滤器视图下所有的报文协议匹配规则。
# 在IP过滤器test中创建匹配VRRP协议(协议号112)报文的规则。
[Sysname] anti-ddos filter name test type ip
[Sysname-anti-ddos-filter-ip-test] protocol 112
· anti-ddos filter
qr命令用来创建DNS报文操作码匹配规则。
undo qr命令用来删除DNS报文操作码匹配规则。
qr { query | reply }
undo qr { query | reply }
DDoS攻击防护过滤器中不存在DNS报文操作码匹配规则。
DNS过滤器视图
query:表示DNS查询报文。
reply:表示DNS应答报文。
DNS报文操作码匹配规则用来匹配指定操作码的DNS报文。
每个DNS过滤器中最多可以创建2条DNS报文操作码匹配规则。DNS报文满足其中任意一条匹配规则,即被视作满足DNS报文操作码匹配条件。
# 在DNS过滤器test中创建用于匹配DNS应答报文的规则。
[Sysname-anti-ddos-filter-dns-test] qr query
· anti-ddos filter
referer命令用来创建HTTP报文Referer字段匹配规则。
undo referer命令用来删除HTTP报文Referer字段匹配规则。
referer include referrer-string
undo referer [ include referrer-string ]
DDoS攻击防护过滤器中不存在HTTP报文Referer字段匹配规则。
HTTP过滤器视图
include:表示HTTP报文的Referer字段的内容包含指定的关键字。
referrer-string:指定Referer关键字,为2~63个字符的字符串,不区分大小写。
HTTP报文Referer字段匹配规则用于匹配Referer字段包含指定关键字的HTTP报文。
每个HTTP过滤器中最多可以创建32条对Referer字段匹配规则。HTTP报文满足其中任意一条匹配规则,即被视作满足HTTP报文Referer字段匹配条件。
如果执行undo referer命令时不指定任何参数,则表示删除该过滤器视图下所有的HTTP报文Referer字段匹配规则。
# 在HTTP过滤器test中创建一条Referer字段匹配规则:HTTP报文的Referer字段的内容包含字符串abc.example.com。
[Sysname-anti-ddos-filter-http-test] referer include abc.example.com
· anti-ddos filter
request-uri命令用来创建HTTP报文URI匹配规则。
undo request-uri命令用来删除HTTP报文URI匹配规则。
request-uri include uri
undo request-uri [ include uri ]
DDoS攻击防护过滤器中不存在HTTP报文URI匹配规则。
HTTP过滤器视图
include:表示HTTP报文的URI包含指定的关键字。
uri:指定URI关键字,为2~63个字符的字符串,不区分大小写。
HTTP报文URI匹配规则用于匹配URI包含指定关键字的HTTP报文。
每个HTTP过滤器中最多可以创建32条URI匹配规则。HTTP报文满足其中任意一条匹配规则,即被视作满足HTTP报文URI匹配条件。
如果执行undo request-uri命令时不指定任何参数,则表示删除该过滤器视图下所有的URI匹配规则。
# 在HTTP过滤器test中创建一条URI匹配规则:HTTP报文的URI中包含字符串favicon.ico。
[Sysname-anti-ddos-filter-http-test] request-uri include favicon.ico
· anti-ddos filter
reset anti-ddos dynamic-blacklist命令用来清空DDoS攻击防护对象的动态黑名单表项。
reset anti-ddos dynamic-blacklist { ipv4 | ipv6 } [ zone [ default | id zone-id ] ]
不清除动态黑名单表项。
用户视图。
ip:清空IPv4动态黑名单表项。
ipv6:清空IPv6动态黑名单表项。
zone:清空指定DDoS攻击防护对象的动态黑名单表项。
仅DDoS攻击清洗设备支持配置本命令。
在配置该命令时,若未指定DDoS攻击防护对象,则删除所有DDoS攻击防护对象下的动态黑名单表项。
# 清除ID为3的DDoS攻击防护对象下的IPv4动态黑名单表项。
<Sysname> reset anti-ddos dynamic-blacklist ip zone id 3
reset anti-ddos filter statistics命令用来清除指定DDoS攻击防护对象下指定过滤器的统计信息。
reset anti-ddos filter statistics name name zone { id zone-id | default }
zone:DDoS攻击防护对象。
# 清除ID为3的DDoS攻击防护对象下过滤器test的统计计数。
<Sysname> reset anti-ddos filter statistics name test zone id 3
rst-flood detection threshold命令用来配置RST泛洪攻击防范阈值,并开启RST泛洪攻击检测功能。
undo rst-flood detection threshold命令用来关闭RST泛洪攻击检测功能。
rst-flood detection threshold { bit-based value | packet-based value}
RST泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示RST泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示RST泛洪攻击的统计方式为按照报文个数进行统计。
value:表示RST泛洪攻击防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
开启RST泛洪攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行RST泛洪攻击检测。当设备检测到向某IP地址发送RST报文的速率持续超过了配置的阈值时,即认为该IP地址受到了RST泛洪攻击,继而启动相应的防范措施:
# 在ID为3的DDoS攻击防护对象视图下,开启RST泛洪攻击检测功能,并配置RST泛洪攻击防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] rst-flood detection threshold packet-based 20
sip-flood defense source-verify命令用来开启SIP泛洪攻击的源验证功能。
undo sip-flood defense source-verify命令用来关闭SIP泛洪攻击的源验证功能。
SIP泛洪攻击的源验证功能处于关闭状态。
DDoS攻击防护对象视图
该命令只在DDoS攻击清洗设备上支持。
该功能用来保护内部网络的服务器免受外部网络中非法客户端发起的SIP泛洪攻击。若在DDoS攻击清洗设备上开启了SIP泛洪攻击的源验证功能,则设备会对发往受攻击IP地址的SIP报文进行源地址验证,通过源地址验证的客户端将被加入信任IP地址列表中,之后设备将放行来自该IP地址的SIP报文。未通过源地址验证的SIP报文会被丢弃。
# 在DDoS攻击防护对象视图下,开启SIP泛洪攻击的源验证功能。
[Sysname-anti-ddos-zone-id-3] sip-flood defense source-verify
sip-flood detection threshold命令用来配置SIP泛洪攻击防范阈值,并开启SIP泛洪攻击检测功能。
undo sip-flood detection threshold命令用来关闭SIP泛洪攻击检测功能。
sip-flood detection threshold { bit-based value | packet-based value}
SIP泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示SIP泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示SIP泛洪攻击的统计方式为按照报文个数进行统计。
value:表示SIP泛洪攻击防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
开启SIP泛洪攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行SIP泛洪攻击检测。当设备检测到向某IP地址发送SIP报文的速率持续超过了配置的阈值时,即认为该IP地址受到了SIP泛洪攻击,继而启动相应的防范措施:
# 在ID为3的DDoS攻击防护对象视图下,开启SIP泛洪攻击检测功能,并配置SIP泛洪攻击防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] sip-flood detection threshold packet-based 20
source-ip命令用来创建报文源IP地址匹配规则。
undo source-ip命令用来删除报文源IP地址匹配规则。
source-ip { ip-range start-ip end-ip | ipv6-range start-ipv6 end-ipv6 }
undo source-ip [ ip-range start-ip end-ip | ipv6-range start-ipv6 end-ipv6 ]
DDoS攻击防护过滤器中不存在报文源IP地址匹配规则。
DDoS攻击防护过滤器视图
ip-range:源IPv4地址范围。
start-ip:指定起始IPv4地址,且不能大于结束IPv4地址。
end-ip:指定结束IPv4地址。
ipv6-range:源IPv6地址范围。
start-ipv6:指定起始IPv6地址,且不能大于结束IPv6地址。
end-ipv6:指定结束IPv6地址。
报文源IP地址匹配规则用于匹配源IP地址在指定范围内的报文。
每个过滤器中最多可以创建512条报文源IP地址匹配规则。报文满足其中任意一条匹配规则,即被视作满足报文源IP地址匹配条件。
在同一个过滤器视图下多次执行本命令所配置的源地址范围不允许重叠。
如果执行undo source-ip命令时不指定任何参数,则表示删除该过滤器视图下所有的报文源IP地址匹配规则。
# 在HTTP过滤器test中创建一条报文源IP地址匹配规则:报文源IPv4地址在1.1.1.10~1.1.1.20的范围内。
[Sysname-anti-ddos-filter-http-test] source-ip ip-range 1.1.1.10 1.1.1.20
· anti-ddos filter
source-port命令用来创建报文源端口匹配规则。
undo source-port命令用来删除报文源端口匹配规则。
source-port range start-port end-port
undo source-port [ range start-port end-port ]
DDoS攻击防护过滤器中不存在报文源端口匹配规则。
TCP过滤器视图
UDP过滤器视图
DNS过滤器视图
HTTP过滤器视图
SIP过滤器视图
range:源端口范围。
报文源端口匹配规则用于匹配源端口号在指定范围内的报文。
每个过滤器中最多可以创建10条报文源端口匹配规则。满足其中任意一条匹配规则,即被视作满足报文源端口匹配条件。
在同一个过滤器视图下多次执行本命令所配置的源端口号范围不允许重叠。
如果执行undo source-port命令时不指定任何参数,则表示删除该过滤器视图下所有的报文源端口匹配规则。
# 在HTTP过滤器test中创建一条报文源端口匹配规则:报文源端口号在10~20的范围内。
[Sysname-anti-ddos-filter-http-test] source-port range 10 20
· anti-ddos filter
syn-ack-flood detection threshold命令用来配置SYN-ACK泛洪攻击防范阈值,并开启SYN-ACK泛洪攻击检测功能。
undo syn-ack-flood detection threshold命令用来关闭SYN-ACK泛洪攻击检测功能。
syn-ack-flood detection threshold { bit-based value | packet-based value}
SYN-ACK泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示SYN-ACK泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示SYN-ACK泛洪攻击的统计方式为按照报文个数进行统计。
value:表示SYN-ACK泛洪攻击防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
DDoS攻击检测设备和DDoS攻击清洗设备均支持配置本命令。
开启SYN-ACK泛洪攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行SYN-ACK泛洪攻击检测。当设备检测到向某IP地址发送SYN-ACK报文的速率持续超过了配置的阈值时,即认为该IP地址受到了SYN-ACK泛洪攻击,继而启动相应的防范措施:
# 在ID为3的DDoS攻击防护对象视图下,开启SYN-ACK泛洪攻击检测功能,并配置SYN-ACK泛洪攻击防范阈值为20个报文。
[Sysname-anti-ddos-zoneid--3] syn-ack-flood detection threshold packet-based 20
syn-flood defense source-verify命令用来开启SYN泛洪攻击的源验证功能。
undo syn-flood defense source-verify命令用来关闭SYN泛洪攻击的源验证功能。
DDoS攻击防护对象视图
SYN泛洪攻击的源验证功能处于关闭状态。
该命令只在DDoS攻击清洗设备上支持。
该功能用来保护内部网络的服务器免受外部网络中非法客户端发起的SYN泛洪攻击。若在DDoS攻击清洗设备上开启了SYN泛洪攻击的源验证功能,则设备会对发往受攻击IP地址的SYN报文进行源地址验证,通过源地址验证的客户端将被加入信任IP地址列表中,之后设备将放行来自该IP地址的SYN 报文。未通过源地址验证的SYN报文会被丢弃。
# 在DDoS攻击防护对象视图下,开启SYN泛洪攻击的源验证功能。
[Sysname] anti-ddos zone id 3
[Sysname-anti-ddos-zone-id-3] syn-flood defense source-verify
· display anti-ddos zone configuration
syn-flood detection threshold命令用来配置SYN泛洪攻击防范阈值,并开启SYN泛洪攻击检测功能。
undo syn-flood detection threshold命令用来关闭SYN泛洪攻击检测功能。
syn-flood detection threshold { bit-based value | packet-based value}
SYN泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示SYN泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示SYN泛洪攻击的统计方式为按照报文个数进行统计。
value:表示SYN泛洪攻击防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
开启SYN泛洪攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行SYN泛洪攻击检测。当设备检测到向某IP地址发送SYN报文的速率持续超过了配置的阈值时,即认为该IP地址受到了SYN泛洪攻击,继而启动相应的防范措施:
· 直路部署的DDoS攻击清洗设备在设备本地对攻击流量进行清洗。
# 在ID为3的DDoS攻击防护对象视图下,开启SYN泛洪攻击检测功能,并配置SYN泛洪攻击防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] syn-flood detection threshold packet-based 20
tcp-flag命令用来创建报文TCP标记字段匹配规则。
undo tcp-flag命令用来删除报文TCP标记字段匹配规则。
tcp-flag tcp-flag
undo tcp-flag [ tcp-flag ]
DDoS攻击防护过滤器中不存在报文TCP标记字段匹配规则。
TCP过滤器视图
HTTP过滤器视图
tcp-flag:指定TCP标记,取值范围为0~63。
报文TCP标记字段匹配规则用于匹配拥有指定TCP标记的报文。
每个过滤器中最多可以创建10条报文TCP标记字段匹配规则。报文满足其中任意一条匹配规则,即被视作满足报文TCP标记字段匹配条件。
如果执行undo tcp-flag命令时不指定tcp-flag参数,则表示删除该过滤器视图下所有的报文TCP标记字段匹配规则。
# 在HTTP过滤器test中创建一条报文TCP标记字段匹配规则:报文的TCP标记为20。
[Sysname] anti-ddos filter name test type http
[Sysname-anti-ddos-filter-http-test] tcp-flag 20
· anti-ddos filter
· display anti-ddos filter statistics
tcp-frag-flood detection threshold命令用来开启TCP分片泛洪攻击检测功能,并配置TCP分片泛洪攻击防范阈值。
undo tcp-frag-flood detection threshold 命令用来关闭TCP分片泛洪攻击检测功能。
tcp-frag-flood detection threshold { bit-based | packet-based } value
TCP分片泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示TCP分片泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示TCP分片泛洪攻击的统计方式为按照报文个数进行统计。
value:表示TCP分片泛洪攻击的防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
检测设备和清洗设备均支持配置本命令。
开启TCP分片泛洪攻击检测功能后,会对设备收到的指定DDoS防护对象的流量进行TCP分片泛洪攻击检测。
当设备检测到向某IP地址发送TCP分片报文的速率超过了配置的阈值时,即认为该IP地址受到了TCP分片泛洪攻击,启动相应的防范措施:
# 在ID为3的DDoS攻击防护对象视图下,开启TCP分片泛洪攻击检测功能,并配置防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] tcp-frag-flood detection threshold packet-based 20
threshold-learning enable命令用来开启DDoS攻击防护对象的防范阈值学习功能。
undo threshold-learning enable命令用来关闭DDoS攻击防护对象的防范阈值学习功能。
DDoS攻击防护对象的防范阈值学习功能处于关闭状态。
DDoS攻击防护对象视图
防范阈值学习功能根据当前网络的实际情况自动计算针对不同DDoS攻击类型的建议防范阈值。计算出的防范阈值比用户凭经验配置的防范阈值更符合当前网络环境。建议用户在不了解实际网络流量大小的情况下开启本功能。
在非缺省DDoS攻击防护对象视图下开启本功能后,设备以五分钟为周期统计访问DDoS攻击防护对象内IP地址的流量的基线值,并将统计值上报给DDoS管理中心,由DDoS管理中心进行数据分析、防范阈值计算和策略下发。
目前仅支持开启非缺省DDoS攻击防护对象的防范阈值学习功能。
# 在ID为6的DDoS攻击防护对象下开启防范阈值学习功能。
[Sysname] anti-ddos zone id 6
[Sysname-anti-ddos-zone-id-6] threshold-learning enable
ttl命令用来创建报文TTL字段匹配规则。
undo ttl命令用来删除报文TTL字段匹配规则。
ttl ttl-value
undo ttl [ ttl-value ]
DDoS攻击防护过滤器中不存在报文TTL字段匹配规则。
DDoS攻击防护过滤器视图
ttl-value:指定报文的TTL值,取值范围为1~255。
报文TTL字段匹配规则用于匹配TTL字段为指定值的报文。
每个过滤器中最多可以创建10条报文TTL字段匹配规则。报文满足其中任意一条匹配规则,即被视作满足报文TTL字段匹配条件。
如果执行undo ttl命令时不指定ttl-value参数,则表示删除该过滤器视图下所有的报文TTL字段匹配规则。
# 在HTTP过滤器test中创建一条报文TTL字段匹配规则:报文TTL字段的值为63。
[Sysname-anti-ddos-filter-http-test] ttl 63
· anti-ddos filter
type命令用来创建DNS报文类型匹配规则。
undo type命令用来删除DNS报文类型匹配规则。
type type-value
undo type [ type-value ]
DDoS攻击防护过滤器中不存在DNS报文类型匹配规则。
DNS过滤器视图
type-value:指定DNS报文类型ID,取值范围为0~255。
DNS报文类型匹配规则用来匹配指定类型的DNS报文。
每个DNS过滤器中最多可以创建10条DNS报文类型匹配规则。DNS报文满足其中任意一条匹配规则,即被视作满足DNS报文类型配条件。
如果执行undo type命令时不指定type-value参数,则表示删除该过滤器视图下所有的DNS报文类型匹配规则。
# 在DNS过滤器test中创建用于匹配DNS type 6报文的规则。
[Sysname-anti-ddos-filter-dns-test] type 6
· anti-ddos filter
udp-flood detection threshold命令用来配置UDP泛洪攻击防范阈值,并开启UDP泛洪攻击检测功能。
undo udp-flood detection threshold命令用来关闭UDP泛洪攻击检测功能。
udp-flood detection threshold { bit-based value | packet-based value}
DDoS攻击防护对象视图
bit-based:表示UDP泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示UDP flood的统计方式为按照报文个数进行统计。
value:表示UDP泛洪攻击防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
开启UDP泛洪攻击检测功能后,设备会对收到的发往指定DDoS防护对象的流量进行UDP泛洪攻击检测。当设备检测到向某IP地址发送UDP报文的速率持续超过了配置的阈值时,即认为该IP地址受到了UDP泛洪攻击,继而启动相应的防范措施:
# 在ID为3的DDoS攻击防护对象视图下,开启UDP泛洪攻击检测功能,并配置UDP泛洪攻击防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] udp-flood detection threshold packet-based 20
udp-frag-flood detection threshold命令用来开启UDP分片泛洪攻击检测功能,并配置UDP分片泛洪攻击防范阈值。
undo upd-frag-flood detection threshold 命令用来关闭UDP分片泛洪攻击检测功能。
udp-frag-flood detection threshold { bit-based | packet-based } value
undo udp-frag-flood detection threshold
UDP分片泛洪攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
bit-based:表示UDP分片泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示UDP分片泛洪攻击的统计方式为按照报文个数进行统计。
value:表示UDP分片泛洪攻击的防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
检测设备和清洗设备均支持配置本命令。
开启UDP分片泛洪攻击检测功能后,会对设备收到的指定DDoS防护对象的流量进行UDP分片泛洪攻击检测。
当设备检测到向某IP地址发送UDP分片报文的速率超过了配置的阈值时,即认为该IP地址受到了UDP分片泛洪攻击,启动相应的防范措施:
# 在ID为3的DDoS攻击防护对象视图下,开启UDP分片 泛洪攻击检测功能,并配置防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] udp-frag-flood detection threshold packet-based 20
user-agent命令用来创建HTTP报文User-Agent字段匹配规则。
undo user-agent命令用来删除HTTP报文User-Agent字段匹配规则。
user-agent include user-agent
undo user-agent [ include user-agent ]
DDoS攻击防护过滤器中不存在HTTP报文User-Agent字段匹配规则。
HTTP过滤器视图
include:表示HTTP报文的User-Agent字段的内容包含指定的关键字。
user-agent:指定User-Agent关键字,为2~63个字符的字符串,不区分大小写。
HTTP报文User-Agent字段匹配规则用于匹配User-Agent字段包含指定关键字的HTTP报文。
每个HTTP过滤器中最多可以创建32条对User-Agent字段匹配规则。HTTP报文满足其中任意一条匹配规则,即被视作满足HTTP报文User-Agent字段匹配条件。
如果执行undo user-agent命令时不指定任何参数,则表示删除该过滤器视图下所有的HTTP报文User-Agent字段匹配规则。
# 在HTTP过滤器test中创建一条User-Agent字段匹配规则:HTTP报文的User-Agent字段包含字符串Linux。
[Sysname-anti-ddos-filter-http-test] user-agent include Linux
· anti-ddos filter
user-defined attack-type detection threshold命令用来开启指定自定义DDoS攻击类型的攻击检测功能,并配置指定自定义DDoS攻击类型的攻击防范阈值。
undo user-defined attack-type detection threshold命令用来关闭自定义DDoS攻击类型的攻击检测功能。
user-defined attack-type id id detection threshold { bit-based | packet-based } value
undo user-defined attack-type [ id id ] detection threshold
自定义DDoS攻击类型的攻击检测功能处于关闭状态。
DDoS攻击防护对象视图
id id:指定自定义DDoS攻击类型的ID,取值范围为0~15。
bit-based:表示指定自定义DDoS攻击类型的泛洪攻击的统计方式为按照比特数进行统计。
packet-based:表示指定自定义DDoS攻击类型的泛洪攻击的统计方式为按照报文个数进行统计。
value:表示指定自定义DDoS攻击类型的泛洪攻击的防范阈值。当统计方式为packet-based时,取值范围为1~4294967295,单位为pps;当统计方式为bit-based时,取值范围为1~4294967295,单位为Mbps。
检测设备和清洗设备均支持配置本命令。
开启指定自定义DDoS攻击类型的泛洪攻击检测功能后,设备会对收到的指定DDoS防护对象的流量进行指定自定义DDoS攻击类型的泛洪攻击检测。
当设备检测到向某IP地址发送指定自定义DDoS攻击类型的报文的速率超过了配置的阈值时,即认为该IP地址受到了指定自定义DDoS攻击类型的泛洪攻击,启动相应的防范措施:
# 在ID为3的DDoS攻击防护对象视图下,开启ID为2的自定义DDoS攻击类型的泛洪攻击检测功能,并配置防范阈值为20个报文。
[Sysname-anti-ddos-zone-id-3] user-defined attack-type id 2 detection threshold packet-based 20
zone-blacklist命令用来添加DDoS攻击防护对象静态黑名单表项。
undo zone-blacklist命令用来删除DDoS攻击防护对象静态黑名单表项。
zone-blacklist { ip source-ip-address ip-mask-length | ipv6 source-ipv6-address ipv6-mask-length }
undo zone-blacklist { all | ip source-ip-address ip-mask-length | ipv6 source-ipv6-address ipv6-mask-length }
不存在DDoS攻击防护对象静态黑名单表项。
DDoS攻击防护对象视图
all:表示该DDoS攻击防护对象下所有静态黑名单表项,包括IPv4表项和IPv6表项。
ip source-ip-address ip-mask-length:静态黑名单表项的IPv4地址及掩码长度,用于匹配报文的源IPv4地址。其中ip-mask-length的取值范围为8~32。
ipv6 source-ipv6-address ipv6-mask-length:静态黑名单表项的IPv6地址及掩码长度,用于匹配报文的源IPv6地址。其中ipv6-mask-length的取值范围为8~128。
仅DDoS攻击清洗设备支持配置本命令。
对于匹配上DDoS攻击防护对象的报文,若其源IP地址与该防护对象下的静态黑名单表项匹配,则设备丢弃该报文。
同一个DDoS攻击防护对象下配置的静态黑名单表项与静态白名单表项的IP地址范围不能重叠。
对于IPv4表项,不可配置地址0.0.0.0和255.255.255.255;对于IPv6表项,不可配置未指定地址(::/128)以及组播地址(FF00::/8)。
每个DDoS攻击防护对象下配置的静态黑名单与静态白名单表项数目之和最多为10个,所有DDoS攻击防护对象下配置的静态黑名单与静态白名单表项数目之和最多为10240个。
# 将1.1.1.1/24网段添加进ID为2的DDoS攻击防护对象的静态黑名单中。
[Sysname] anti-ddos zone id 2
[Sysname-anti-ddos-zone-id-2] zone-blacklist ip 1.1.1.1 24
· zone-whitelist
· display anti-ddos blacklist zone
zone-whitelist命令用来添加DDoS攻击防护对象静态白名单表项。
undo zone-whitelist命令用来删除DDoS攻击防护对象静态白名单表项。
zone-whitelist { ip source-ip-address ip-mask-length | ipv6 source-ipv6-address ipv6-mask-length }
undo zone-whitelist { all | ip source-ip-address ip-mask-length | ipv6 source-ipv6-address ipv6-mask-length }
不存在DDoS攻击防护对象静态白名单表项。
DDoS攻击防护对象视图
all:表示该DDoS攻击防护对象下所有静态白名单表项,包括IPv4表项和IPv6表项。
ip source-ip-address ip-mask-length:DDoS攻击防护对象静态白名单表项的IPv4地址及掩码长度,用于匹配报文的源IPv4地址。其中ip-mask-length的取值范围为8~32。
ipv6 source-ipv6-address ipv6-mask-length:DDoS攻击防护对象静态白名单表项的IPv6地址及掩码长度,用于匹配报文的源IPv6地址。其中ipv6-mask-length的取值范围为8~128。
仅DDoS攻击清洗设备支持配置本命令。
对于匹配上DDoS攻击防护对象的报文,若其源IP地址与该防护对象下的静态白名单表项匹配,则跳过其他DDoS攻击检测与防范功能(不包括报文限速),执行后续报文处理。
# 将1.1.1.1/24网段添加进ID为2的DDoS攻击防护对象的静态白名单中。
[Sysname-anti-ddos-zone-id-2] zone-whitelist ip 1.1.1.1 24
· zone-blacklist
· display anti-ddos whitelist zone
