01-AAA命令
本章节下载: 01-AAA命令 (2.28 MB)
1.1.1 aaa abnormal-offline-record enable
1.1.2 aaa authorize user-name netstream-sampler
1.1.3 aaa de-authorize user-name netstream-sampler
1.1.6 aaa login-failed alarm-threshold
1.1.11 aaa normal-offline-record enable
1.1.12 aaa offline-record enable
1.1.13 aaa online-fail-record enable
1.1.17 aaa shared-account-user no-family
1.1.20 access-user auto-save enable
1.1.35 authen-radius-unavailable online domain
1.1.38 authentication lan-access
1.1.42 authentication-method none authorization-attribute
1.1.46 authorization lan-access
1.1.49 authorization-attribute (ISP domain view)
1.1.52 display aaa abnormal-offline-record
1.1.53 display aaa normal-offline-record
1.1.54 display aaa offline-record
1.1.55 display aaa online-fail-record
1.1.56 display aaa online-offline-reason
1.1.58 display domain access-user statistics
1.1.62 dynamic-authorization effective-attribute
1.1.64 ipv6 nd autoconfig managed-address-flag
1.1.65 ipv6 nd autoconfig other-flag
1.1.67 ipv6cp assign-interface-id
1.1.71 load-sharing user-group
1.1.72 local-server log change-password-prompt
1.1.76 redirect move-temporarily enable
1.1.78 reset aaa abnormal-offline-record
1.1.79 reset aaa normal-offline-record
1.1.80 reset aaa offline-record
1.1.81 reset aaa online-fail-record
1.1.82 secondary-web-server { ip | ipv6 }
1.1.83 service rate-limit mode (ISP domain view)
1.1.84 service-type (ISP domain view)
1.1.85 session-time include-idle-time
1.1.86 snmp-agent trap enable aaa
1.1.87 snmp-agent trap enable domain
1.1.88 state (ISP domain view)
1.1.89 state block time-range name
1.1.90 strict-check access-interface vpn-instance
1.1.93 web-server { ip | ipv6 }
1.1.94 web-server { url | ipv6-url }
1.1.95 web-server url-parameter
1.2.2 authorization-attribute (Local user view/user group view)
1.2.8 display user-group identity-active
1.2.12 local-guest auto-delete enable
1.2.13 local-guest email format
1.2.14 local-guest email sender
1.2.15 local-guest email smtp-server
1.2.21 password (Device management user view)
1.2.22 password (Network access user view)
1.2.24 service-type (Local user view)
1.2.25 snmp-agent trap enable user-group
1.2.29 state (Local user view)
1.2.31 validity-datetime (Local guest view)
1.2.32 validity-datetime (Device management user view)
1.3.2 aaa nas-port-id vlanid uppercase
1.3.12 attribute convert (RADIUS DAE server view)
1.3.13 attribute convert (RADIUS scheme view)
1.3.14 attribute reject (RADIUS DAE server view)
1.3.15 attribute reject (RADIUS scheme view)
1.3.16 attribute remanent-volume
1.3.18 attribute vendor-id 2011 version
1.3.21 data-flow-format (RADIUS scheme view)
1.3.23 display radius server-load statistics
1.3.24 display radius statistics
1.3.25 display stop-accounting-buffer (for RADIUS)
1.3.28 key (RADIUS scheme view)
1.3.29 nas-ip (RADIUS scheme view)
1.3.31 pppoe-agency reply-port
1.3.32 primary accounting (RADIUS scheme view)
1.3.33 primary authentication (RADIUS scheme view)
1.3.34 radius attribute extended
1.3.35 radius attribute-test-group
1.3.36 radius authentication-request first
1.3.38 radius dynamic-author server
1.3.40 radius offline-reason-convert user-type ppp
1.3.42 radius session-control client
1.3.43 radius session-control enable
1.3.45 radius stop-accounting-buffer cache
1.3.46 radius stop-accounting-buffer overwrite-oldest
1.3.47 radius stop-accounting-buffer warning-threshold
1.3.49 radius-server authen-state-check interval
1.3.50 radius-server test-profile
1.3.51 reset radius server-load statistics
1.3.52 reset radius statistics
1.3.53 reset stop-accounting-buffer (for RADIUS)
1.3.56 retry realtime-accounting
1.3.57 retry stop-accounting (RADIUS scheme view)
1.3.58 secondary accounting (RADIUS scheme view)
1.3.59 secondary authentication (RADIUS scheme view)
1.3.60 server-block-action (RADIUS scheme view)
1.3.61 server-load-sharing enable
1.3.62 server-load-sharing mode
1.3.63 snmp-agent trap enable radius
1.3.67 stop-accounting-buffer enable (RADIUS scheme view)
1.3.68 stop-accounting-packet send-force
1.3.70 threshold remanent-volume
1.3.71 timer quiet (RADIUS scheme view)
1.3.72 timer realtime-accounting (RADIUS scheme view)
1.3.73 timer response-timeout (RADIUS scheme view)
1.3.76 username-authorization apply
1.3.77 user-name-format (RADIUS scheme view)
1.3.78 vpn-instance (RADIUS scheme view)
1.4.1 data-flow-format (HWTACACS scheme view)
1.4.3 display stop-accounting-buffer (for HWTACACS)
1.4.6 hwtacacs-user change-password
1.4.7 key (HWTACACS scheme view)
1.4.8 nas-ip (HWTACACS scheme view)
1.4.9 primary accounting (HWTACACS scheme view)
1.4.10 primary authentication (HWTACACS scheme view)
1.4.12 reset hwtacacs statistics
1.4.13 reset stop-accounting-buffer (for HWTACACS )
1.4.14 retry stop-accounting (HWTACACS scheme view)
1.4.15 secondary accounting (HWTACACS scheme view)
1.4.16 secondary authentication (HWTACACS scheme view)
1.4.17 secondary authorization
1.4.18 stop-accounting-buffer enable (HWTACACS scheme view)
1.4.19 timer quiet (HWTACACS scheme view)
1.4.20 timer realtime-accounting (HWTACACS scheme view)
1.4.21 timer response-timeout (HWTACACS scheme view)
1.4.22 user-name-format (HWTACACS scheme view)
1.4.23 vpn-instance (HWTACACS scheme view)
1.6.4 local-bill export-interval
1.6.6 snmp-agent trap enable local-bill
1.7.3 display radius-proxy statistics
1.7.4 display radius-proxy user
1.7.5 reset radius-proxy statistics
aaa abnormal-offline-record enable命令用来开启用户异常下线记录功能。
undo aaa abnormal-offline-record enable命令用来关闭用户异常下线记录功能。
用户异常下线记录功能处于开启状态。
开启本功能后,系统会将所有异常下线的用户信息(用户基本信息、下线原因等)记录到系统内存中,方便管理员进行管理和故障定位,具体内容可通过display aaa abnormal-offline-record命令进行查看。当管理员需要分析用户下线原因以及解决用户异常下线问题时,建议开启本功能。
只有用户下线记录功能处于开启状态,本功能才能生效。
设备最多可存储的用户异常下线记录条目数与设备的型号有关,超过该数目后,新的记录会覆盖旧的记录。
关闭本功能后,系统停止记录用户异常下线信息,可提高当前可用内存容量,但管理员将看不到用户异常下线信息,存在一定风险。
# 开启用户异常下线记录功能。
[Sysname] aaa abnormal-offline-record enable
· aaa offline-record enable
· display aaa abnormal-offline-record
aaa authorize user-name netstream-sampler命令用来为指定用户授权Netstream采样规则,并启动Netstream采样。
aaa authorize user-name user-name netstream-sampler sampler-name [ inbound | outbound ]
user-name:待采样的用户名,为1~253个字符的字符串,区分大小写。
sampler-name:采样器名称,为1~31个字符的字符串,不区分大小写。有关采样器的详细介绍,请参见“网络管理和监控配置指导”中的“Sampler”。
inbound:入方向上网流量。
outbound:出方向上网流量。
执行本命令后,系统会向该用户下发相应的流量采样规则,并根据采样器的配置对指定方向的用户流量进行Netstream采样,除非用户下线、下发新的规则或管理员通过命令行取消该采样规则,否则采样过程持续进行。
通过本命令下发的规则可独立生效,不依赖于任何NetStream的相关配置。如果用户上线的接口上存在其它方式的NetStream采样配置,则该用户的流量仅依据本命令下发的规则采样,接口上的其它流量会依据其它规则采样。有关Netstream采样功能的详细配置,请参见“网络管理和监控配置指导”中的“Netstream”。
若不指定inbound或outbound参数,则表示对入方向及出方向的上网流量都进行采样。
对同一个用户的一个方向的流量,每一次成功执行本命令后,系统都会立即下发新的流量采样规则对该用户流量进行采样,已下发的采样规则将被覆盖。
流量采样规则所引用的采样器配置发生变化时,并不会影响已下发的采样规则。
# 为用户user1授权流量采样规则,对入方向上的流量进行NetStream采样,使用的采样器名称为sam1。
<Sysname> aaa authorize user-name user1 netstream-sampler sam1 inbound
· aaa de-authorize user-name netstream-sampler
aaa de-authorize user-name netstream-sampler命令用来取消为指定用户授权的Netstream采样规则。
aaa de-authorize user-name user-name netstream-sampler [ inbound | outbound ]
user-name:用户名,为1~253个字符的字符串,区分大小写。
inbound:入方向上网流量。
outbound:出方向上网流量。
执行本命令后,系统会删除向该用户下发的所有流量采样规则,并立即停止对指定方向的用户流量进行NetStream采样。有关Netstream采样的详细介绍,请参见“网络管理和监控配置指导”中的“Netstream”。
若不指定inbound或outbound参数,则表示同时对该用户入方向及出方向的上网流量取消采样规则。
# 取消为用户user1授权的出/入方向的流量采样规则,停止Netstream采样。
<Sysname> aaa de-authorize user-name user1 netstream-sampler
· aaa authorize user-name netstream-sampler
aaa default-domain命令用来配置接口上的缺省ISP域。
undo aaa default-domain命令用来删除接口上指定类型的缺省ISP域。
aaa default-domain { authentication [ force | replace ] isp-name | pre-authentication isp-name } *
undo aaa default-domain [ authentication | pre-authentication ]
接口上未配置缺省ISP域。
authentication:表示缺省认证域。若后面不携带任何参数,则仅适用于用户名中不携带域名的用户。
authentication force:表示缺省强制认证域,即强制对用户进行认证的域但不替换用户原始域名。
authentication replace:表示缺省强制替换认证域,即强制对用户进行认证的域,且替换用户原始域名的域。
isp-name:ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符,且该域必须已经存在。
pre-authentication:表示缺省认证前域,即用户认证前使用的域,该域主要用于为未认证用户分配IP地址。
设备支持在接口上配置用户接入时使用的缺省ISP域,当接入模块未指定认证域的情况下,可为用户提供缺省的AAA服务。
本配置仅适用于PPP、IPoE、lan-access网络接入类用户。其中,认证前域仅适用于IPoE用户。
在同一个接口上,缺省认证域、缺省强制认证域和缺省强制替换认证域不能同时配置,且各类域最多只能配置一个,后配置的会覆盖已有的配置。
# 指定接口Ten-GigabitEthernet3/0/1上接入用户使用的缺省强制认证域为my-domain。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] aaa default-domain authentication force my-domain
· domain
aaa deny-domain命令用来配置接口上禁止用户接入的ISP域。
undo aaa deny-domain命令用来删除接口上禁止用户接入的ISP域。
aaa deny-domain isp-name
undo aaa deny-domain [ isp-name ]
接口上未限制用户接入的ISP域。
isp-name:ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符,且必须已经存在。
如果希望禁止某些域的用户接入某接口,则可以通过本配置实现。如果指定接口下配置禁止接入的域,则该接口使用此认证域接入的用户不能够进行AAA处理。
同一个接口下,最多可配置16个禁止接入的ISP域。
执行undo命令时,若不指定isp-name参数,则表示删除接口下配置的所有禁止接入的域。
同一个接口下,aaa deny-domain命令不能与aaa permit-domain命令同时配置。
# 配置接口Ten-GigabitEthernet3/0/1上禁止用户接入的ISP域为my-domain2。
[Sysname-Ten-GigabitEthernet3/0/1] aaa deny-domain my-domain2
· aaa permit-domain
· domain
aaa login-failed alarm-threshold命令用来配置设备管理类用户登录失败次数告警参数。
undo aaa login-failed alarm-threshold命令用来恢复缺省情况。
aaa login-failed alarm-threshold trigger-threshold trigger-threshold clear-threshold clear-threshold period period
如果5分钟内的设备管理类用户登录失败次数等于或大于30,则产生上限告警;如果5分钟内的设备管理类用户登录失败次数小于20,则产生恢复告警。
trigger-threshold trigger-threshold:表示统计周期内用户登录失败次数告警上限阈值,取值范围为0~100。取值为0表示不上报告警。
clear-threshold clear-threshold:表示统计周期内用户登录失败次数告警恢复阈值,取值范围为0~100,恢复阈值必须小于等于上限阈值。取值为0与取值为1的作用相同,表示统计周期内无登录失败情况时发送恢复告警。
period period:表示用户登录失败次数统计周期,取值范围为1~120,单位是分钟。如果trigger-threshold取值为0,则period的配置实际不生效。
通过配置管理类用户登录失败频率阈值告警功能,可以对一定周期内频繁发生的管理用户登录失败情况给予告警,用于及时提醒网络管理员采取相关措施。
通过snmp-agent trap enable aaa命令开启设备上管理类用户登录失败频率到达阈值时的告警功能后,系统将会以指定的周期(period)对管理类用户登录失败次数进行统计,并在如下情况发生时生成相应的告警信息:
· 当统计周期内登录失败次数首次达到指定的上限阈值(trigger-threshold),或者从低于恢复次数增长到上限阈值时,将触发上限告警。
· 当统计周期内登录失败次数从大于等于上限阈值下降到小于恢复阈值时(clear-threshold),将触发恢复告警。
# 配置设备管理类用户登录失败次数的上限告警阈值为40、恢复告警阈值为20、统计周期为10分钟。
[Sysname] aaa login-failed alarm-threshold trigger-threshold 40 clear-threshold 20 period 10
· snmp-agent trap enable aaa
aaa nas-id命令用来在接口上配置NAS-ID。
undo aaa nas-id命令用来恢复缺省情况。
aaa nas-id nas-identifier
undo aaa nas-id
接口上未配置NAS-ID。
三层接口视图
nas-identifier:NAS-ID名称,为1~253个字符的字符串,不区分大小写。
用户进行RADIUS认证时,系统会获取设备的NAS-ID来设置RADIUS报文中的NAS-Identifier属性,该属性用于向RADIUS服务器标识用户的接入位置。
设备支持多种途径配置NAS-ID,按照获取优先级从高到低的顺序依次包括:NAS-ID Profile中与用户接入VLAN绑定的NAS-ID、接口视图下的NAS-ID、ISP域视图下的NAS-ID。其中,接口视图下配置的NAS-ID仅对PPP和IPoE用户有效。若以上配置都不存在,则使用设备的名称作为NAS-ID。
# 在接口Ten-GigabitEthernet3/0/1上配置NAS-ID为test。
[Sysname-Ten-GigabitEthernet3/0/1] aaa nas-id test
· aaa nas-id profile
· nas-id
aaa nas-id profile命令用来创建NAS-ID Profile,并进入NAS-ID-Profile视图。如果指定的NAS-ID Profile已经存在,则直接进入NAS-ID-Profile视图。
undo aaa nas-id profile命令用来删除指定的NAS-ID Profile。
undo aaa nas-id profile profile-name
不存在NAS-ID Profile。
profile-name:Profile名称,为1~31个字符的字符串,不区分大小写。
在某些应用环境中,网络运营商需要使用接入设备发送给RADIUS服务器的NAS-Identifier属性值来获知用户的接入位置,而用户的接入VLAN可标识用户的接入位置,因此接入设备上可通过建立用户接入VLAN与指定的NAS-ID之间的绑定关系来实现接入位置信息的映射。NAS-ID Profile用于保存NAS-ID和VLAN的绑定关系。
设备支持多种途径配置NAS-ID,按照获取优先级从高到低的顺序依次包括:NAS-ID Profile中与用户接入VLAN绑定的NAS-ID、接口视图下的设备的NAS-ID、ISP域视图下的NAS-ID。
# 创建一个名称为aaa的NAS-ID Profile,并进入NAS-ID-Profile视图。
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa]
· aaa nas-id
· aaa nas-id-profile
· nas-id bind
aaa nas-id-profile命令用来指定接口引用的NAS-ID Profile。
undo aaa nas-id-profile命令用来恢复缺省情况。
aaa nas-id-profile profile-name
未指定引用的NAS-ID Profile。
三层接口视图
profile-name:标识指定VLAN和NAS-ID绑定关系的NAS-ID Profile名称,为1~31个字符的字符串,不区分大小写。
本配置仅对PPP和IPoE用户有效。
# 在接口Ten-GigabitEthernet3/0/1上引用名为 bbb的NAS-ID Profile。
[Sysname–Ten-GigabitEthernet3/0/1] aaa nas-id-profile bbb
· nas-id bind
aaa nas-ip命令用来在接口上配置设备的NAS-IP地址。
undo aaa nas-ip命令用来删除接口上配置的NAS-IP地址。
aaa nas-ip { ipv4-address | ipv6 ipv6-address }
undo aaa nas-ip [ ipv6 ]
接口上未配置设备的NAS-IP地址。
三层接口视图
ipv4-address:指定的IPv4 NAS-IP地址,不能为全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6 ipv6-address:指定的IPv6 NAS-IP地址,必须是单播地址,不能为环回地址与本地链路地址。
可通过本命令配置设备发送的RADIUS报文中携带的NAS-IP-Address或NAS-IPv6-Address属性内容,简称为NAS-IP地址,该地址用于标识用户接入的设备,且在RADIUS服务器上必须全局唯一。
RADIUS服务器发送的DAE请求报文中若携带该属性,则表示该请求报文要发送给指定的接入设备。当接入设备收到DAE请求报文后,会获取报文中携带的NAS-IP地址与本地保存的NAS-IP地址进行比较,若相同则接受该请求报文并进行后续的处理,否则不对其进行处理。
接口视图、RADIUS方案视图以及系统视图下均可以配置发送RADIUS报文携带的NAS-IP地址,具体生效情况如下:
· 接口视图下配置的NAS-IP地址(通过aaa nas-ip命令)只对在本接口上线的用户有效。
· RADIUS方案视图下配置的NAS-IP地址(通过nas-ip命令)只对本方案有效。
· 系统视图下的配置的NAS-IP地址(通过radius nas-ip命令)对所有RADIUS方案有效。
· 以上各视图下的配置优先级从高到低依次为:接口视图->RADIUS方案视图->系统视图。
一个接口视图下,最多允许指定一个IPv4 NAS-IP地址和一个IPv6 NAS-IP地址。
如果undo aaa nas-ip命令中不指定ipv6参数,则表示删除配置的IPv4 NAS-IP地址。
# 在接口Ten-GigabitEthernet3/0/1上配置设备的NAS-IP地址为1.1.1.1。
[sysname] interface ten-gigabitethernet 3/0/1
[sysname-Ten-GigabitEthernet3/0/1] aaa nas-ip 1.1.1.1
· nas-ip (RADIUS scheme view)
· radius nas-ip
aaa normal-offline-record enable命令用来开启用户正常下线记录功能。
undo aaa normal-offline-record enable命令用来关闭用户正常下线记录功能。
用户正常下线记录功能处于开启状态。
开启本功能后,设备会将所有用户正常下线信息(用户基本信息、下线原因等)记录到系统内存中,具体内容可通过display aaa normal-offline-record命令进行查看。当管理员需要分析用户下线原因时,建议开启本功能。
设备最多可存储的用户正常下线记录条目数与设备的型号有关,超过该数目后,新的记录会覆盖旧的记录。
关闭本功能后,系统停止记录用户正常下线信息,可提高当前可用内存容量,但管理员将看不到用户正常下线信息。
# 开启用户正常下线记录功能。
[Sysname] aaa normal-offline-record enable
· display aaa normal-offline-record
aaa offline-record enable命令用来开启用户下线记录功能。
undo aaa offline-record enable命令用来关闭用户下线记录功能。
用户下线记录功能处于开启状态。
本功能用于总体控制用户下线记录功能是否开启。只有本功能处于开启状态,用户正常下线记录功能和用户异常下线记录功能才能生效。
开启本功能后,若用户正常下线记录功能、用户异常下线记录功能处于开启状态,设备会将所有用户正常下线、用户异常下线的信息(用户基本信息、下线原因等)记录到系统内存中,具体内容可通过display aaa offline-record命令进行查看。
设备最多支持存储65536条用户下线记录,超过该数目后,新的记录会覆盖旧的记录。
关闭本功能后,用户下线信息不会被记录到系统内存中,可提高系统当前可用内存容量,但管理员将看不到用户下线信息。
# 开启用户下线记录功能。
[Sysname] aaa offline-record enable
· aaa abnormal-offline-record enable
· aaa normal-offline-record enable
· display aaa offline-record
aaa online-fail-record enable命令用来开启用户上线失败记录功能。
undo aaa online-fail-record enable命令用来关闭用户上线失败记录功能。
用户上线失败记录功能处于开启状态。
开启本功能后,设备会将所有用户上线失败信息(用户基本信息、上线失败原因等)记录到系统内存中,具体内容可通过display aaa online-fail-record命令进行查看。当管理员需要获取用户上线失败记录,以对恶意用户进行初步排查时,建议开启本功能。
设备最多可存储的用户上线失败记录条目数与设备的型号有关,超过该数目后,新的记录会覆盖旧的记录。
关闭本功能后,系统停止记录用户上线失败信息,可提高当前可用内存容量,但管理员将看不到用户上线失败信息,存在一定风险。
# 开启用户上线失败记录功能
[Sysname] aaa online-fail-record enable
· display aaa online-fail-record
aaa permit-domain命令用来配置接口上允许用户接入的ISP域。
undo aaa permit-domain命令用来删除接口上允许用户接入的ISP域。
aaa permit-domain isp-name
undo aaa permit-domain [ isp-name ]
接口上未限制用户接入的ISP域。
如果希望仅允许某些域的用户可以接入某接口,则可以通过本配置实现。
同一个接口下,最多可配置16个允许接入的ISP域。
执行undo命令时,若不指定isp-name参数,则表示删除接口下配置的所有允许接入的域,即不对接口上用户可接入的ISP域进行限制。
同一个接口下,aaa permit-domain命令不能与aaa deny-domain命令同时配置。
# 配置接口Ten-GigabitEthernet3/0/1上允许用户接入的ISP域为my-domain。
[Sysname-Ten-GigabitEthernet3/0/1] aaa permit-domain my-domain
· aaa deny-domain
· domain
aaa roam-domain命令用来配置接口上的漫游域。
undo aaa roam-domain命令用来删除接口上的漫游域。
aaa roam-domain isp-name
接口上未配置漫游域。
如果从接口上线的用户需要使用用户名中携带的ISP域进行认证,但该域在设备上不存在,则可以通过接口上指定的漫游域作为用户的归属域进行认证。
# 配置接口Ten-GigabitEthernet3/0/1上的漫游域为domain1。
[Sysname-Ten-GigabitEthernet3/0/1] aaa roam-domain domain1
· domain
aaa session-limit命令用来配置同时在线的最大用户连接数,即采用指定登录方式登录设备并同时在线的用户数。
undo aaa session-limit命令用来将指定登录方式的同时在线的最大用户连接数恢复为缺省情况。
aaa session-limit { ftp | http | https | ssh [ service-type { netconf | scp | sftp | stelnet } ] | telnet } max-sessions
undo aaa session-limit { ftp | http | https | ssh [ service-type { netconf | scp | sftp | stelnet } ] | telnet }
同时在线的各类型最大用户连接数均为32。
ftp:表示FTP用户。
http:表示HTTP用户。
https:表示HTTPS用户。
ssh:表示SSH用户,包括NETCONF over SSH、SCP、SFTP、Stelnet四种子服务类型。
service-type:表示SSH子服务类型。
· netconf:表示NETCONF over SSH用户。
· scp:表示SCP用户。
· sftp:表示SFTP用户。
· stelnet:表示Stelnet用户。
telnet:表示Telnet用户。
max-sessions:允许同时在线的最大用户连接数,FTP/SSH/Telnet用户的取值范围为1~32,HTTP/HTTPS用户的取值范围为1~64。
当指定类型的接入用户的用户数超过当前配置的最大连接数后,新的接入请求将被拒绝。
对于HTTP/HTTPS用户,不同上层应用的最大用户连接数单独受限。例如,若设置允许同时在线的HTTP最大用户连接数为20,则基于HTTP的RESTful用户、Web用户、NETCONF用户的最大连接数将均为20。
可以对SSH用户和各类SSH子服务用户(NETCONF over SSH/SCP/SFTP/Stelnet用户)分别设置最大连接数。对于SSH子服务用户,需要受子服务用户最大连接数和SSH用户最大连接数的双重限制。子服务用户上线时,系统首先检查在线的SSH子服务用户连接数之和是否已经达到了SSH用户的最大连接数,然后再检查对应的子服务连接数是否已经达到该服务的最大连接数。
# 设置同时在线的最大FTP用户连接数为4。
[Sysname] aaa session-limit ftp 4
aaa shared-account-user no-family命令用来配置使用相同账号的用户为非家庭用户。
undo aaa shared-account-user no-family命令用来恢复缺省情况。
使用相同账号的用户为家庭用户。
若RADIUS服务器为用户下发了最大用户数(通过标准属性62号属性Port-Limit),或者用户使用的ISP域下限制了单个帐号允许接入的最大用户数(通过配置users-per-account命令),则共享此账号的所有用户将作为家庭用户共享指定带宽。如果实际应用中,只希望限制使用同一账号的接入用户数量,但这些用户不共享指定带宽,则需要通过本功能将这类用户配置为非家庭用户。每个非家庭用户的带宽均由上网账号的授权流量监管参数单独限制。
目前,该配置仅适用于PPPoE、IPoE和L2TP用户,且仅对新上线用户生效。
本命令生效的前提是,RADIUS服务器为用户下发了Port-Limit属性或者该用户使用的ISP域下配置了users-per-account命令。
# 配置使用相同账号的用户为非家庭用户。
[Sysname] aaa shared-account-user no-family
· users-per-account
aaa ssid命令用来在接口上配置SSID。
undo aaa ssid命令用来删除接口上配置的SSID。
aaa ssid ssid-name
undo aaa ssid
接口上未配置SSID。
三层接口视图
ssid-name:SSID的名称,为1~32个字符的字符串,区分大小写。
在用户通过无线方式接入的组网环境中,可通过在用户接入的接口上配置本命令来指定设备重定向给用户的Web服务器的URL中携带的SSID信息,以及指定接入设备发送的RADIUS认证请求报文中的30号标准属性Called-Station-Id携带的SSID信息(格式为“00-00-00-00-00-00:ssid-name)。
接入设备重定向给用户的Web服务器的URL中是否携带SSID信息,由用户认证域下的web-server url-parameter命令中是否指定了ssid参数决定。
如果用户不属于无线方式接入,则不建议通过本命令在接口上配置SSID。
# 在接口Ten-GigabitEthernet3/0/1上配置SSID为test11。
[Sysname-Ten-GigabitEthernet3/0/1] aaa ssid test11
· web-server url-parameter
access-limit用来配置ISP域下允许接入的最大用户数。
undo access-limit命令用来恢复缺省情况。
access-limit limit-number
undo access-limit
该域下未限制接入的用户数。
ISP域视图
limit-number:表示允许接入的最大用户数,取值范围为1~2147483647。
ISP域下允许接入的用户数并不区分接入用户的类型,只要接入用户总数超过限定值后,新接入的用户将被拒绝认证。对于login用户,还需要受到系统视图下aaa session-limit的限制。
在线用户重认证时,不受所在域的最大用户数限制。
ITA以及ESDG类增值业务用户数不受所在域的最大用户数限制。
# 配置ISP域my-domain下允许接入的最大用户数为100。
[Sysname] domain name my-domain
[Sysname-isp-my-domain] access-limit 100
· display domain
access-user auto-save enable命令用来开启用户信息自动备份功能。
undo access-user dhcp auto-save enable命令用来关闭用户信息自动备份功能。
undo access-user auto-save enable
用户信息自动备份功能处于开启状态。
ISP域视图
当设备内存空间紧张时,开启DHCP用户信息自动备份功能,可能会影响其它业务,请谨慎使用。
在DHCPv4/DHCPv6/IPv6 ND RS用户接入场景中,设备重启或单板、子卡、接口故障会导致用户异常下线,用户信息丢失。如果客户端未感知到此故障,待故障恢复后,客户端并不会重新向设备发起认证请求,而设备会因为查寻不到该用户信息而不允许这些用户上线。开启本功能且接入模块配置了允许自动备份的最大用户数目的情况下(通过ip subscriber auto-save max-user命令),用户认证通过后,设备会向接入模块下发一个授权指令,通知接入模块将该用户的认证信息备份到内存中。
为了避免设备重启后备份信息的丢失,还可以通过执行ip subscriber save-file命令将当前备份到内存中的用信息保存到非易失存储介质中。之后,当单板、子卡、接口发生故障并恢复正常时,接入模块将直接使用内存中备份的用户信息直接为这些用户重新发起认证。如果设备重启了,就需要使用从非易失存储介质中恢复到内存中的用户信息为用户重新发起认证。
· 本配置只对IPoE用户生效。
· 建议在系统刚启动或业务轻载时开启本功能,避免后续业务繁忙时内存空间紧张导致本配置失败。
# 在ISP域test下配置允许将用户信息备份到高端内存。
[Sysname] domain name test
[Sysname-isp-test] access-user auto-save enable
· display domain
· ip subscriber auto-save max-user(BRAS业务命令参考/IPoE)
· ip subscriber save-file(BRAS业务命令参考/IPoE)
accounting command命令用来配置命令行计费方法。
undo accounting command命令用来恢复缺省情况。
accounting command hwtacacs-scheme hwtacacs-scheme-name
命令行计费采用当前ISP域的缺省计费方法。
ISP域视图
hwtacacs-scheme hwtacacs-scheme-name:指定HWTACACS方案。其中,hwtacacs-scheme-name表示HWTACACS方案名,为1~32个字符的字符串,不区分大小写。
命令行计费过程是指,用户执行过的合法命令会被发送给计费服务器进行记录。若未开启命令行授权功能,则计费服务器对用户执行过的所有合法命令进行记录;若开启了命令行授权功能,则计费服务器仅对授权通过的命令进行记录。
目前,仅支持使用远程HWTACACS服务器完成命令行计费功能。
# 在ISP域test下,配置使用HWTACACS计费方案hwtac进行命令行计费。
[Sysname-isp-test] accounting command hwtacacs-scheme hwtac
· accounting default
· command accounting(基础配置命令参考/登录设备)
· hwtacacs scheme
accounting default命令用来为当前ISP域配置缺省的计费方法。
undo accounting default命令用来恢复缺省情况。
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
当前ISP域的缺省计费方法为local。
ISP域视图
local:本地计费。
none:不计费。
radius-scheme radius-scheme-name:指定RADIUS方案。其中,radius-scheme-name表示RADIUS方案名,为1~32个字符的字符串,不区分大小写。
当前ISP域的缺省计费方法对于该域中未指定具体计费方法的所有接入用户都起作用,但是如果某类型的用户不支持指定的计费方法,则该计费方法对于这类用户不能生效。
本地计费只是为了支持本地用户的连接数管理,没有实际的计费相关的统计功能。
可以指定多个备选的计费方法,在当前的计费方法无效时按照配置顺序尝试使用备选的方法完成计费。例如,radius-scheme radius-scheme-name local none表示,先进行RADIUS计费,若RADIUS计费无效则进行本地计费,若本地计费也无效则不进行计费。远程计费无效是指,指定的计费方案不存在、计费报文发送失败或者服务器无响应。本地计费无效是指没有找到对应的本地用户配置。
当采用本地计费方法为主计费方法,且配置了备选计费方法时,仅当AAA本地计费处理过程异常或者没有本地用户配置的情况下,用户本地计费失败后才会尝试使用备选方法进行认证,其它情况下不会转换计费方法,直接认为计费失败。
# 在ISP域system下,配置缺省计费方法为local。
[Sysname] domain name system
[Sysname-isp-system] accounting default local
# 在ISP域test下,配置缺省计费方法为使用RADIUS方案rd进行计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting default radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
accounting dual-stack命令用来配置双协议栈用户的计费方式。
undo accounting dual-stack命令用来恢复缺省情况。
accounting dual-stack { merge | separate }
双协议栈用户的计费方式为统一计费。
ISP域视图
merge:统一计费方式,表示将双协议栈用户的IPv4流量和IPv6流量统一汇总后上送给计费服务器。
separate:分别计费方式,表示将双协议栈用户的IPv4流量和IPv6流量分别上送给计费服务器。
双协议栈用户的主机上同时支持IPv4和IPv6两种协议,可能产生两种协议类型的流量。分别计费模式通常应用于IPv4流量费率和IPv6流量费率不一样的情况;统一计费模式通常应用于不需要区分IPv4流量和IPv6流量的情况。
需要注意的是,如果配置双协议栈用户的计费方式为分别计费,则该域下PPP和IPoE用户主业务会话的IPv4流量和IPv6流量,除了会分别计费,还将分别应用授权CAR参数。
# 在ISP域test下,配置双栈用户的计费方式为统一计费。
[Sysname-isp-test] accounting dual-stack merge
accounting ipoe命令用来为IPoE用户配置计费方法。
undo accounting ipoe命令用来恢复缺省情况。
accounting ipoe { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
IPoE用户采用当前ISP域的缺省计费方法。
ISP域视图
broadcast:指定广播RADIUS方案,即同时向指定的两个RADIUS方案中的计费服务器发送计费请求。
radius-scheme radius-scheme-name1:表示主送计费RADIUS方案名,为1~32个字符的字符串,不区分大小写;
radius-scheme radius-scheme-name2:表示抄送计费RADIUS方案名,为1~32个字符的字符串,不区分大小写。
local:本地计费。
none:不计费。
可以指定多个备选的计费方法。在当前的计费方法无效时按照配置顺序尝试使用备选的方法完成计费。例如,radius-scheme radius-scheme-name local none表示,先进行RADIUS计费,若RADIUS计费无效则进行本地计费,若本地计费也无效则不进行计费。远程计费无效是指,指定的计费方案不存在、计费报文发送失败或者服务器无响应。本地计费无效是指没有找到对应的本地用户配置。
指定broadcast关键字的情况下,设备将以主送RADIUS方案中的实时计费间隔同时向指定的两个RADIUS方案里的主计费服务器发送计费开始/更新/停止请求,若某RADIUS方案里的主计费服务器不可达,则按照配置顺序依次尝试向该RADIUS方案里的从计费服务器发送计费请求。主送计费方案计费成功时,表示用户计费成功;抄送计费方案的计费结果对用户无影响。
# 在ISP域test下,为IPoE用户配置计费方法为local。
[Sysname-isp-test] accounting ipoe local
# 在ISP域test下,配置IPoE用户使用RADIUS方案rd进行计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting ipoe radius-scheme rd local
# 在ISP域test下,配置IPoE用户使用RADIUS方案rd1和rd2进行广播计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting ipoe broadcast radius-scheme rd1 radius-scheme rd2 local
· local-user
· radius scheme
· timer realtime-accounting (RADIUS scheme view)
accounting lan-access命令用来为lan-access用户配置计费方法。
undo accounting lan-access命令用来恢复缺省情况。
accounting lan-access { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
lan-access用户采用当前ISP域的缺省计费方法。
ISP域视图
local:本地计费。
none:不计费。
# 在ISP域test下,为lan-access用户配置计费方法为local。
[Sysname-isp-test] accounting lan-access local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd进行计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting lan-access radius-scheme rd local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd1和rd2进行广播计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting lan-access broadcast radius-scheme rd1 radius-scheme rd2 local
· local-user
· radius scheme
accounting login命令用来为login用户配置计费方法。
undo accounting login命令用来恢复缺省情况。
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
login用户采用当前ISP域的缺省计费方法。
ISP域视图
local:本地计费。
none:不计费。
不支持对FTP、SFTP以及SCP类型的login用户进行计费。
# 在ISP域test下,为login用户配置计费方法为local。
[Sysname-isp-test] accounting login local
# 在ISP域test下,配置login用户使用RADIUS方案rd进行计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting login radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
accounting ppp命令用来为PPP用户配置计费方法。
undo accounting ppp命令用来恢复缺省情况。
accounting ppp { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] | hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
undo accounting ppp
PPP用户采用当前ISP域的缺省计费方法。
ISP域视图
hwtacacs-scheme hwtacacs-scheme-name:指定HWTACACS方案。其中hwtacacs-scheme-name表示HWTACACS方案名,为1~32个字符的字符串,不区分大小写。
local:本地计费。
none:不计费。
指定broadcast关键字的情况下,设备将以主送RADIUS方案中的实时计费间隔同时向指定的两个RADIUS方案里的主计费服务器发送计费开始/更新/停止请求,若某RADIUS方案里的主计费服务器不可达,则按照配置顺序依次尝试向RADIUS方案里的从计费服务器发送计费请求。主送计费方案计费成功时,表示用户计费成功;抄送计费方案的计费结果对用户无影响。
# 在ISP域test下,为PPP用户配置计费方法为local。
[Sysname-isp-test] accounting ppp local
# 在ISP域test下,配置PPP用户使用RADIUS方案rd进行计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting ppp radius-scheme rd local
# 在ISP域test下,配置PPP用户使用RADIUS方案rd1和rd2进行广播计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting ppp broadcast radius-scheme rd1 radius-scheme rd2 local
· hwtacacs scheme
· local-user
· radius scheme
accounting pppoea命令用来配置PPPoE代拨用户的计费方法。
undo accounting pppoea命令用来恢复缺省情况。
accounting pppoea { none | radius-scheme radius-scheme-name [ none ] }
PPPoE代拨计费采用当前ISP域的缺省计费方法。
ISP域视图
none:不计费。
为满足校园网用户对网络出口多样化的需求,以及学校自身简化校园网搭建和维护的需要,越来越多的高校选择与运营商联合运营,共同建设校园网。联合运营场景下,通过在校园网BRAS设备上部署PPPoE代拨功能,可以为校园网用户提供自主选择运营商网络,以及自动为其发起PPPoE拨号上网的服务。该功能不仅简化了校方和运营商的联合运营模式,又为学生提供了极佳的网络体验。
对于校园网的IPoE用户,如果用户认证上线时校园网内的AAA服务器为其授权了标识PPPoE代拨策略的用户组,则表示该类用户有访问运营商网络的需求,BRAS设备需要为该类用户做PPPoE代拨处理。此时,校园网的BRAS设备将模拟PPPoE client,并根据校园网AAA服务器发送给BRAS设备的COA请求消息中携带的信息,向对应运营商网络中的PPPoE server发起PPPoE拨号上线的过程,该阶段的用户称为PPPoE代拨用户。BRAS设备会在代拨成功后,根据指定域下配置的PPPoE代拨用户计费方法对PPPoE代拨发起计费或不计费。
对于域下的PPPoE代拨用户,目前只支持为其配置计费方法,不支持配置认证、授权方法。系统默认为域下的PPPoE代拨用户采用不认证、不授权方法。
对于PPPoE代拨用户,可选择配置RADIUS计费,也可以选择不计费。如果校方希望使用校园网内的AAA服务器对学生访问运营商网络的外网流量进行同步监管,则建议配置RADIUS计费方案。
如果PPPoE代拨用户使用的认证域下,没有设置PPPoE代拨用户的计费方案,则使用域下的缺省计费方法进行计费,如果域下的缺省计费方法不为RADIUS或None,则计费失败。
# 在ISP域test下,为PPPoE代拨用户使用RADIUS方案rd进行计费。
[Sysname-isp-test] accounting pppoea radius-scheme rd
# 在ISP域test下,配置PPPoE代拨用户使用RADIUS方案rd进行计费,并且使用none作为备选计费方法。
[Sysname-isp-test] accounting pppoea radius-scheme rd none
· radius scheme
accounting quota-out命令用来配置用户计费配额(流量或时长)耗尽策略。
undo accounting quota-out命令用来恢复缺省情况。
accounting quota-out { offline | online | redirect-url url-string [ stop-accounting ] [ user-profile profile-name ] } [ no-accounting-update ]
用户的当前计费配额耗尽后,设备会向服务器发送计费更新报文来获取新的配额,若计费回应报文未携带新的配额,则该用户被强制下线。
ISP域视图
offline:当用户的整体配额耗尽后,强制用户下线。
online:当用户的整体配额耗尽后,允许用户保持在线状态。
redirect-url url-string:当用户的整体流量配额耗尽后,向用户推送重定向Web页面。其中,url-string表示重定向URL,为1~255个字符的字符串,区分大小写。该参数仅对PPPoE、IPoE、L2TP用户生效。
stop-accounting:表示向计费服务器发送停止计费报文。若不指定该参数,则表示不发送停止计费报文。
user-profile profile-name:指定下发给用户的User Profile。其中,profile-name为User Profile名称,为1~31个字符的字符串,只能包含英文字母、数字、下划线、减号和英文句号,支持以字母和数字开头,但不能为纯数字,区分大小写。若指定了该参数,用户的整体流量配额耗尽后,该用户的访问行为将受到User Profile配置的限制。若不指定该参数,在用户重新获取流量配额之前,用户的访问行为不受任何User Profile配置的限制。
no-accounting-update:不发送用于获取新配额的计费更新报文。
若服务器不支持分多次向在线用户授权下发计费配额,则建议配置用户计费配额耗尽策略时指定no-accounting-update参数,以减小服务器的负担。
若通过本命令配置的用户计费配额耗尽策略为向用户推送重定向Web页面,且同时指定了stop-accounting和user-profile参数,则在用户计费配额耗尽后,设备会将设置的User Profile名称通过RADIUS属性携带在停止计费请求报文中上传给RADIUS服务器。该场景下,RADIUS属性的携带情况与RADIUS服务器为在线用户授权User Profile的状态相关,具体如下:
· 如果RADIUS服务器授权了User Profile,则设备会向服务器上传指定的User Profile名称:
¡ 若RADIUS服务器授权的出方向User Profile和入方向User Profile名称相同,则设备会同时使用两个私有RADIUS属性(Inbound-User-Profile-Name、Outbound-User-Profile-Name)和一个标准RADIUS属性(Filter-ID)来携带设置的User Profile名称,且这三个属性值相同。
¡ 如果RADIUS服务器授权的出方向User Profile和入方向User Profile名称不同,则设备会同时使用两个私有RADIUS属性(Inbound-User-Profile-Name、Outbound-User-Profile-Name)分别携带设置的User Profile名称,且这两个属性值相同。
¡ 如果RADIUS服务器仅授权了某个方向的User Profile,则设备仅会使用相同方向的私有RADIUS属性(Inbound-User-Profile-Name或Outbound-User-Profile-Name)来携带设置的User Profile名称。
· 如果RADIUS服务器未授权User Profile,设备不会向服务器上传指定的User Profile名称。
# 在ISP域test下,配置用户计费配额耗尽策略为:当配额耗尽后用户仍能保持在线状态。
[Sysname-isp-test] accounting quota-out online
accounting start-delay命令用来配置发送计费开始请求报文的延迟时间。
undo accounting start-delay命令用来恢复缺省情况。
accounting start-delay delay-time
计费开始请求报文不延迟发送。
ISP域视图
delay-time:表示延迟时间,取值范围为1~300,单位为秒。
缺省情况下,当认证通过的IPoE、PPPoE双栈用户获取到第一个IP地址后,设备会向计费服务器发送一个计费开始请求报文。之后,该用户每获取到一个IP地址,设备会向计费服务器发送一个实时计费请求报文。如果服务器端并不希望因为用户获取多个IP地址而收到多个计费报文,则可以配置设备发送计费开始报文的延迟时间,使得设备在该延迟时间内,等待用户获取到所有该分配的IP地址后,再统一发送一个计费开始请求报文。如果在该延迟时间到达后,用户未能获取到所有该分配的IP地址,设备将发送一个计费开始请求报文,后续该用户获取到IP地址时设备发送计费更新报文。用户地址分配的完成情况,由用户接入模块决定。
本配置仅对IPoE、PPPoE双栈用户场景生效,不会影响该域下的其它接入用户的计费过程。
过大的延迟时间会对用户的计费准确度有一定的影响,过小的延迟时间可能导致无法实现统一发送计费开始请求报文的效果,因此延迟时间的取值需要结合双栈用户地址分配所需总时长来合理设置。
# 在ISP域test下,配置发送计费开始请求报文的延迟发送时间为10秒。
[Sysname-isp-test] accounting start-delay 10
· display domain
accounting start-fail命令用来配置用户计费开始失败策略,即设备向计费服务器发送计费开始请求失败后,是否允许用户接入网络。
undo accounting start-fail命令用来恢复缺省情况。
accounting start-fail { offline | online }
如果用户计费开始失败,允许用户保持在线状态。
ISP域视图
offline:强制用户下线。
online:允许用户保持在线状态。
# 在ISP域test下,配置计费开始失败策略为:用户计费开始失败时允许用户保持在线状态。
[Sysname-isp-test] accounting start-fail online
accounting update-fail命令用来配置用户计费更新失败策略,即设备向计费服务器发送用户的计费更新报文失败时,是否允许用户接入网络。
undo accounting update-fail命令用来恢复缺省情况。
accounting update-fail { [ max-times max-times ] offline | online }
如果用户计费更新失败,允许用户保持在线状态。
ISP域视图
max-times max-times:允许用户连续计费更新失败的次数,取值范围1~255,缺省值为1。该参数仅对IPoE、PPP用户生效,其它用户固定取值为1。
offline:如果用户连续计费更新失败的次数达到了指定的次数,则强制用户下线。
online:如果用户计费更新失败,允许用户保持在线状态。
假设设备发送RADIUS报文的最大尝试次数(retry命令设置)为x,设备的实时计费间隔(timer realtime-accounting命令设置)为y分钟,设备允许实时计费无响应的最大次数为z次(retry realtime-accounting命令设置),本命令设置的连续计费更新失败次数max-times为m,则:
· 对于IPoE、PPP用户
设备每隔y分钟发起一次计费请求,如果在RADIUS服务器应答超时时长内得不到回应就重新发送一次计费请求报文。如果设备发送的x个计费请求报文都没有得到回应,就认为该次实时计费失败。如果连续(z×m)次尝试均失败,设备将认为用户计费更新失败。
· 对于其它用户
设备每隔y分钟发起一次计费请求,如果在RADIUS服务器应答超时时长内得不到回应就重新发送一次计费请求报文。如果设备发送的x个计费请求报文都没有得到回应,就认为该次实时计费失败。如果连续z次尝试均失败,设备将认为用户计费更新失败。
# 在ISP域test下,配置计费更新失败策略为:用户计费更新失败时允许用户保持在线状态。
[Sysname-isp-test] accounting update-fail online
· retry
· retry realtime-accounting
authen-fail命令用来配置用户认证失败后采取的处理策略。
undo authen-fail命令用来恢复缺省情况。
authen-fail { offline | online domain new-isp-name }
undo authen-fail
用户认证失败后采取的处理策略是直接下线。
ISP域视图
offline:用户认证失败后直接下线。
online:用户认证失败后保持在线。
domain new-isp-name:指定认证失败域,即认证失败后重新加入的域。new-isp-name表示ISP域的名称,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符,且必须已经存在。
不同的组网环境中,对于用户认证失败后的处理策略有所不同。缺省情况下,用户将会直接下线。但如果希望用户在首次认证失败后,还有机会尝试其它的认证/授权/计费方案,则可以使其保持在线,并转至指定的认证失败域内重新进行认证/授权/计费。
被指定为认证失败后的二次认证域的域不允许删除。若要删除该域,请先执行undo authen-fail命令取消对该域的引用。
以下情况不会采用认证失败域:
· 管理类用户认证失败。
· 因认证超时导致的认证失败,例如认证服务器无响应、无本地用户等。
· 因认证域的状态为block或认证域属于接口下指定的deny域而引起的认证失败。
· 域内的接入用户数已经达到最大值而引起的认证失败。
· 用户认证失败后转到认证失败域内重新认证仍然失败。
· 用户重认证失败。
# 在ISP域视图test下,配置用户认证失败后采取的处理策略为采用域dm1对用户进行重新认证/授权/计费。
[Sysname-isp-test] authen-fail online domain dm1
· display domain
authen-radius-recover命令用来指定当用户因为RADIUS服务器不可达逃生后,在服务器恢复可达时的处理策略。
undo authen-radius-recover命令用来恢复缺省情况。
authen-radius-recover { offline | online domain new-isp-name }
未指定用户因为RADIUS服务器不可达逃生后,在服务器又恢复可达时的处理策略。
ISP域视图
offline:用户直接下线。
online:用户保持在线,并切换到逃生恢复域。
domain new-isp-name:指定逃生恢复域。new-isp-name表示ISP域的名称,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符,且必须已经存在。
本特性仅对IPoE、PPPoE用户生效。
不同的组网环境中,对于用户因为RADIUS服务器不可达切换到逃生域后,任一服务器又恢复可达时的处理策略有所不同:
· 如果希望用户重新进行认证/授权/计费,则可以直接使其下线。
· 如果希望用户还能返回到原认证域中,则可以使其保持在线,并将该逃生恢复域指定为用户首次认证所在的域。该处理策略下,用户进入逃生恢复域后,不会重新进行认证/授权/计费,但可以获得逃生恢复域中指定生效的一些授权属性(通过dynamic-authorization effective-attribute命令设置)。
关于逃生恢复域的配置,有如下使用指导和限制:
· 如果用户逃生之前所在的原认证域中,为RADIUS认证方案配置了none备份方案,则RADIUS服务器从不可达恢复为可达时,用户也会进入配置的逃生恢复域。
· 为了准确地判断RADIUS认证服务器是否可达,使得逃生恢复措施及时生效,建议配置RADIUS服务器探测功能。
· 如果逃生恢复域未指定为用户首次认证所在的域,则用户将进入新域,但不会重新进行认证、授权和计费。
· 被指定为逃生恢复域的域不允许删除。若要删除该域,请先执行undo authen-radius-recover命令取消对该域的引用。
# 在ISP域test下,指定当用户因为RADIUS服务器不可达逃生后,在服务器恢复可达时用户下线。
[Sysname-isp-test] authen-radius-recover offline
· authen-radius-unavailable online domain
· display domain
· radius-server test-profile
authen-radius-unavailable online domain命令用来配置用户认证过程中,RADIUS服务器不可达时的逃生域。
undo authen-radius-unavailable online domain命令用来恢复缺省情况。
authen-radius-unavailable online domain new-isp-name
未指定用户认证过程中RADIUS服务器不可达时的逃生域。
ISP域视图
new-isp-name:ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符,且必须已经存在。
在用户认证过程中,如果出现认证方案下的所有RADIUS服务器不可达状况,设备发出的RADIUS认证请求报文将无法得到回应,从而影响用户正常上线。通过在当前域下配置逃生域,可以在这种情况发生时,保证用户能够“逃离”当前域,在新域中进行上线。通常情况下,逃生行为只是一个应急措施,因此用户可以无需再次认证而直接上线。
用户逃生后,仅当原认证域中的认证RADIUS服务器恢复可达,且原认证域中配置了逃生恢复域,用户才会离开逃生域。
关于逃生域的配置,有如下使用指导和限制:
· 逃生域不支持嵌套配置,包括两种情况:逃生域中配置的逃生域不会生效,已经配置了逃生域的认证域被指定为其它认证域的逃生域时不会生效。
· 被指定为逃生域的ISP域不允许删除。若要删除该域,请先执行undo authen-radius-unavailable online domain命令取消对该域的引用。
· 如果逃生域中配置了非none的认证/授权/计费方案,用户将不会使用该域的方案重新进行认证、授权,而是保持在线的情况下使用该域的计费方案进行计费。
# 在ISP域test下,指定用户认证过程中,RADIUS服务器不可达时的逃生域为dm1。
[Sysname-isp-test] authen-radius-unavailable online domain dm1
· authen-radius-recover
· display domain
authentication default命令用来为当前ISP域配置缺省的认证方法。
undo authentication default命令用来为恢复缺省情况。
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
当前ISP域的缺省认证方法为local。
ISP域视图
ldap-scheme ldap-scheme-name:指定LDAP方案。其中ldap-scheme-name表示LDAP方案名,为1~32个字符的字符串,不区分大小写。
local:本地认证。
none:不进行认证。
当前ISP域的缺省的认证方法对于该域中未指定具体认证方法的所有接入用户都起作用,但是如果某类型的用户不支持指定的认证方法,则该认证方法对于这类用户不能生效。
可以指定多个备选的认证方法,在当前的认证方法无效时按照配置顺序尝试使用备选的方法完成认证。例如,radius-scheme radius-scheme-name local none表示,先进行RADIUS认证,若RADIUS认证无效则进行本地认证,若本地认证也无效则不进行认证。远程认证无效是指,指定的认证方案不存在、认证报文发送失败或者服务器无响应。本地认证无效是指没有找到对应的本地用户配置。
当采用本地认证方案为主认证方法,且配置了备选认证方法时,仅当AAA本地认证处理过程异常或者没有本地用户配置的情况下,用户本地认证失败后才会尝试使用备选方法进行认证,其它情况下不会转换认证方法,直接认为认证失败。
# 在ISP域system下,配置缺省认证方法为local。
[Sysname-isp-system] authentication default local
# 在ISP域test下,配置缺省认证方法为使用RADIUS方案rd进行认证,并且使用local作为备选认证方法。
[Sysname-isp-test] authentication default radius-scheme rd local
· hwtacacs scheme
· ldap scheme
· local-user
· radius scheme
authentication ipoe命令用来为IPoE用户配置认证方法。
undo authentication ipoe命令用来恢复缺省情况。
authentication ipoe { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-proxy [ radius-scheme radius-scheme-name | local ] * [ none ] | radius-scheme radius-scheme-name [ local ] [ none ] }
IPoE用户采用当前ISP域的缺省认证方法。
ISP域视图
local:本地认证。
none:不认证。
radius-proxy:RADIUS代理认证。
在设备上开启了RADIUS代理功能时,需要将IPoE用户的认证方法指定为RADIUS代理认证。指定为RADIUS代理认证后,该域的IPoE用户上线时,设备首先根据该用户的MAC地址和RADIUS代理客户端IP地址与已有的本地代理用户表项进行匹配,若匹配成功,则表示该用户认证成功,否则按照配置顺序尝试使用备选的认证方法完成认证。例如,radius-proxy radius-scheme radius-scheme-name local表示,先进行RADIUS代理认证,若RADIUS代理认证无效则进行RADIUS认证,若RADIUS认证也无效则进行本地认证。
# 在ISP域test下,为IPoE用户配置认证方法为local。
[Sysname-isp-test] authentication ipoe local
# 在ISP域test下,配置IPoE用户使用RADIUS方案rd进行认证,并且使用local作为备选认证方法。
[Sysname-isp-test] authentication ipoe radius-scheme rd local
· authentication default
· local-user
· radius scheme
· radius-proxy
authentication lan-access命令用来为lan-access用户配置认证方法。
undo authentication lan-access命令用来恢复缺省情况。
authentication lan-access { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
lan-access用户采用当前ISP域的缺省认证方法。
ISP域视图
local:本地认证。
none:不进行认证。
# 在ISP域test下,为lan-access用户配置认证方法为local。
[Sysname-isp-test] authentication lan-access local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd进行认证,并且使用local作为备选认证方法。
[Sysname-isp-test] authentication lan-access radius-scheme rd local
· ldap scheme
· local-user
· radius scheme
authentication login命令用来为login用户配置认证方法。
undo authentication login命令用来恢复缺省情况。
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
login用户采用当前ISP域的缺省认证方法。
ISP域视图
local:本地认证。
none:不进行认证。
# 在ISP域test下,为login用户配置认证方法为local。
[Sysname-isp-test] authentication login local
# 在ISP域test下,配置login用户使用RADIUS方案rd进行认证,并且使用local作为备选认证方法。
[Sysname-isp-test] authentication login radius-scheme rd local
· hwtacacs scheme
· ldap scheme
· local-user
· radius scheme
authentication ppp命令用来为PPP用户配置认证方法。
undo authentication ppp命令用来恢复缺省情况。
authentication ppp { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
PPP用户采用当前ISP域的缺省认证方法。
ISP域视图
local:本地认证。
none:不进行认证。
# 在ISP域test下,为PPP用户配置认证方法为local。
[Sysname-isp-test] authentication ppp local
# 在ISP域test下,配置PPP用户使用RADIUS方案rd进行认证,并且使用local作为备选认证方法。
[Sysname-isp-test] authentication ppp radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authentication super命令用来配置用户角色切换认证方法。
undo authentication super命令用来恢复缺省情况。
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name } *
用户角色切换认证采用当前ISP域的缺省认证方法。
ISP域视图
切换用户角色是指在不退出当前登录、不断开当前连接的前提下修改用户的用户角色,改变用户所拥有的命令行权限。为了保证切换操作的安全性,需要在用户执行用户角色切换时进行身份认证。设备支持本地和远程两种认证方式,关于用户角色切换的详细介绍请参见“基础配置分册”中的“RBAC”。
可以指定一个备选的认证方法,在当前的认证方法无效时尝试使用备选的方法完成认证。
# 在ISP域test下,配置使用HWTACACS方案tac进行用户角色切换认证。
[Sysname] super authentication-mode scheme
[Sysname-isp-test] authentication super hwtacacs-scheme tac
· hwtacacs scheme
· radius scheme
authentication-method none authorization-attribute命令用来配置采用none认证方法时的用户授权属性。
undo authentication-method none authorization-attribute命令用来恢复缺省情况。
authentication-method none authorization-attribute session-timeout timeout
undo authentication-method none authorization-attribute session-timeout
ISP域下的用户授权属性由服务器授权,若服务器未授权该属性,则采用ISP域下的授权属性设置。
ISP域视图
session-timeout timeout:用户的会话超时时间,取值范围为1~4294967294,单位为秒。如果用户在线时长超过该值,设备会强制该用户下线。此属性只对PPP、IPoE、lan-access用户生效。
缺省情况下,认证用户的授权属性可由服务器下发或在ISP域下由authorization-attribute命令设置,设备并未区分该用户使用的认证方法。为了满足采用none认证方法时设置用户授权属性的灵活性,可以配置本特性。目前,本特性仅支持对用户会话超时时间属性进行设置。
对于采用none认证方法的用户,如果通过本命令设置了指定的授权属性,则该授权属性优先级高于ISP域下由authorization-attribute命令设置的对应授权属性。
# 在ISP域test下,配置采用none认证方法时的用户会话超时时间为60秒。
[Sysname-isp-test] authentication-method none authorization-attribute session-timeout 60
· authorization-attribute
authorization command命令用来配置命令行授权方法。
undo authorization command命令用来恢复缺省情况。
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] [ none ] | local [ none ] | none }
命令行授权采用当前ISP域的缺省授权方法。
ISP域视图
local:本地授权。
none:不授权。用户执行角色所允许的命令时,无须接受授权服务器的检查。
命令行授权是指,用户执行的每一条命令都需要接受授权服务器的检查,只有授权成功的命令才被允许执行。用户登录后可以执行的命令受登录授权的用户角色和命令行授权的用户角色的双重限制,即,仅登录授权的用户角色和命令行授权的用户角色均允许执行的命令行,才能被执行。需要注意的是,命令行授权功能只利用角色中的权限规则对命令行执行权限检查,不进行其它方面的权限检查,例如资源控制策略等。
对用户采用本地命令行授权时,设备将根据用户登录设备时输入的用户名对应的本地用户配置来对用户输入的命令进行检查,只有本地用户中配置的授权用户角色所允许的命令才被允许执行。
可以指定多个备选的命令行授权方法,在当前的授权方法无效时按照配置顺序尝试使用备选的方法完成命令授权。例如,hwtacacs-scheme hwtacacs-scheme-name local none表示,先进行HWTACACS授权,若HWTACACS授权无效则进行本地授权,若本地授权也无效则不进行授权。远程授权无效是指,指定的授权方案不存在、授权报文发送失败或者服务器无响应。本地授权无效是指没有找到对应的本地用户配置。
# 在ISP域test下,配置命令行授权方法为local。
[Sysname-isp-test] authorization command local
# 在ISP域test下,配置使用HWTACACS方案hwtac进行命令行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization command hwtacacs-scheme hwtac local
· command authorization(基础配置命令参考/登录设备)
· hwtacacs scheme
· local-user
authorization default命令用来为当前ISP域配置缺省的授权方法。
undo authorization default命令用来恢复缺省情况。
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
当前ISP域的缺省授权方法为local。
ISP域视图
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权。此时,认证通过的Login用户(通过Console口或者Telnet、FTP/SFTP/SCP访问设备的用户)只有系统给予的缺省用户角色level-0,其中FTP/SFTP/SCP用户的工作目录是设备的根目录,但并无访问权限;认证通过的非Login用户可直接访问网络。关于用户角色level-0的详细介绍请参见“基础配置指导”中的“RBAC”。
当前ISP域的缺省的授权方法对于该域中未指定具体授权方法的所有接入用户都起作用,但是如果某类型的用户不支持指定的授权方法,则该授权方法对于这类用户不能生效。
在一个ISP域中,只有配置的认证和授权方法中引用了相同的RADIUS方案时,RADIUS授权过程才能生效。
可以指定多个备选的授权方法,在当前的授权方法无效时按照配置顺序尝试使用备选的方法完成授权。例如,radius-scheme radius-scheme-name local none表示,先进行RADIUS授权,若RADIUS授权无效则进行本地授权,若本地授权也无效则不进行授权。远程授权无效是指,指定的授权方案不存在、授权报文发送失败或者服务器无响应。本地授权无效是指没有找到对应的本地用户配置。
当采用本地授权方案为主授权方法,且配置了备选授权方法时,仅当AAA本地授权处理过程异常或者没有本地用户配置的情况下,用户本地授权失败后才会尝试使用备选方法进行授权,其它情况下不会转换授权方法,直接认为授权失败。
# 在ISP域system下,配置缺省授权方法为local。
[Sysname-isp-system] authorization default local
# 在ISP域test下,配置缺省授权方法为使用RADIUS方案rd进行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization default radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authorization ipoe命令用来为IPoE用户配置授权方法。
undo authorization ipoe命令用来恢复缺省情况。
authorization ipoe { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-proxy [ radius-scheme radius-scheme-name | local ] * [ none ] | radius-scheme radius-scheme-name [ local ] [ none ] }
IPoE用户采用当前ISP域的缺省授权方法。
ISP域视图
local:本地授权。
none:不授权。
radius-proxy:RADIUS代理授权。
在一个ISP域中,只有配置的认证和授权方法中引用了相同的RADIUS方案时,RADIUS授权过程才能生效。若指定了RADIUS代理授权,则只有配置的认证和授权方法都为RADIUS代理方式时,RADIUS代理授权过程才能生效。
将IPoE用户的授权方法指定为RADIUS代理授权后,设备将会根据该用户匹配上的本地代理用户表项中的授权信息对其进行授权。若RADIUS代理授权无效,则按照配置顺序尝试使用备选的授权方法完成授权。例如,radius-proxy radius-scheme radius-scheme-name local 表示,先进行RADIUS代理授权,若RADIUS代理授权无效则进行RADIUS授权,若RADIUS授权也无效则进行本地授权。
# 在ISP域test下,为IPoE用户配置授权方法为local。
[Sysname-isp-test] authorization ipoe local
# 在ISP域test下,配置IPoE用户使用RADIUS方案rd进行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization ipoe radius-scheme rd local
· authorization default
· local-user
· radius scheme
· radius-proxy
authorization lan-access命令用来为lan-access用户配置授权方法。
undo authorization lan-access命令用来恢复缺省情况。
authorization lan-access { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
lan-access用户采用当前ISP域的缺省授权方法。
ISP域视图
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权,认证通过的lan-access用户可直接访问网络。
# 在ISP域test下,为lan-access用户配置授权方法为local。
[Sysname-isp-test] authorization lan-access local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd进行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization lan-access radius-scheme rd local
· local-user
· radius scheme
authorization login命令用来为login用户配置授权方法。
undo authorization login命令用来恢复缺省情况。
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
login用户采用当前ISP域的缺省授权方法。
ISP域视图
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权。此时,认证通过的Login用户(通过Console口或者Telnet、FTP/SFTP/SCP访问设备的用户)只有系统给予的缺省用户角色level-0,其中FTP/SFTP/SCP用户的工作目录是设备的根目录,但并无访问权限。关于用户角色level-0的详细介绍请参见“基础配置指导”中的“RBAC”。
# 在ISP域test下,为login用户配置授权方法为local。
[Sysname-isp-test] authorization login local
# 在ISP域test下,配置login用户使用RADIUS方案rd进行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization login radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authorization ppp命令用来为PPP用户配置授权方法。
undo authorization ppp命令用来恢复缺省情况。
authorization ppp { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
PPP用户采用当前ISP域的缺省授权方法。
ISP域视图
local:本地授权。
# 在ISP域test下,为PPP用户配置授权方法为local。
[Sysname-isp-test] authorization ppp local
# 在ISP域test下,配置PPP用户使用RADIUS方案rd进行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization ppp radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authorization-attribute命令用来设置当前ISP域下的用户授权属性。
undo authorization-attribute命令用来删除指定的授权属性,恢复用户具有的缺省访问权限。
authorization-attribute { acl acl-number | car inbound cir committed-information-rate [ pir peak-information-rate ] outbound cir committed-information-rate [ pir peak-information-rate ] | idle-cut minutes [ flow ] [ traffic { both | inbound | outbound } ] | igmp max-access-number max-access-number | ip-pool ipv4-pool-name | ip-pool-group ipv4-pool-group-name | { ipv4 | ipv6 } multicast-user-profile profile-name | ipv6-nd-prefix-pool ipv6-prefix-pool-name | ipv6-nd-prefix-pool-group ipv6-prefix-pool-group-name | ipv6-pool ipv6-pool-name | ipv6-pool-group ipv6-pool-group-name | ipv6-prefix ipv6-prefix prefix-length | mld max-access-number max-access-number | { primary-dns | secondary-dns } { ip ipv4-address | ipv6 ipv6-address } | redirect-times times | session-group-profile session-group-profile-name | session-timeout timeout | url url-string [ unlimited ] | user-group user-group-name | user-priority { inbound | outbound } priority | user-profile [ inbound | outbound ] profile-name | vpn-instance vpn-instance-name }
undo authorization-attribute { acl | car | idle-cut | igmp | ip-pool | ip-pool-group | ipv6-nd-prefix-pool | ipv6-nd-prefix-pool-group | ipv6-pool | ipv6-pool-group | { ipv4 | ipv6 } multicast-user-profile | ipv6-prefix | mld | primary-dns | redirect-times | secondary-dns | session-group-profile | session-timeout | url | user-group | user-priority { inbound | outbound } | user-profile [ inbound | outbound ] | vpn-instance }
当前ISP域下的用户闲置切换功能处于关闭状态,IPv4用户可以同时点播的最大节目数为4,IPv6用户可以同时点播的最大节目数为4,对用户的Web访问请求重定向的次数为2,无其它授权属性。
ISP域视图
acl acl-number:指定用于匹配用户流量的ACL。其中acl-number表示ACL编号,取值范围2000~4999。此属性只对lan-access用户生效。与授权ACL规则匹配的流量,将按照规则中指定的permit或deny动作进行处理。
car:指定授权用户的流量监管动作。此属性只对PPP、IPoE用户生效。
inbound:表示用户的上传速率。
outbound:表示用户的下载速率。
cir committed-information-rate:承诺信息速率,单位为kbps。此参数的取值范围为为8~300000000。
pir peak-information-rate:峰值信息速率,单位为kbps,且不能小于承诺信息速率。若不指定该参数,则表示不对峰值信息速率进行限制。此参数的取值范围为8~300000000。
idle-cut minutes:指定用户的闲置切断时间。其中,minutes的取值范围为1~600,单位为分钟。此属性只对PPP、IPoE用户生效。
flow:用户在闲置切断时间内产生的最小数据流量,取值范围1~10240000,单位为字节,缺省值为10240。
traffic:指定闲置切断时间内用户数据流量的统计方向。若不指定该参数,则表示统计用户双向数据流量。
· both:表示用户双向数据流量。
· inbound:表示用户上行数据流量。
· outbound:表示用户下行数据流量。
igmp max-access-number max-access-number:指定IPv4用户可以同时点播的最大节目数。其中,max-access-number的取值范围为1~64。此属性只对PPP和IPoE用户生效。
ip-pool ipv4-pool-name:指定为用户分配IPv4地址的地址池。其中,ipv4-pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。此属性只对PPP、IPoE用户生效。
ip-pool-group ipv4-pool-group-name:指定为用户分配IPv4地址的地址池组,其中,ipv4-pool-group-name为IP地址池组名称,为1~63个字符的字符串,不区分大小写。此属性仅对PPP和IPoE用户适用。
ipv4:表示用户的IPv4可控组播User Profile。
ipv6:表示用户的IPv6可控组播User Profile。
multicast-user-profile profile-name:指定用户的可控组播User Profile。其中,profile-name为User Profile名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线、减号和英文句号,支持以字母和数字开头,但不能为纯数字,区分大小写。此属性只对IPoE、PPP用户的组播业务报文生效。
ipv6-nd-prefix-pool ipv6-prefix-pool-name:指定为IPv6用户授权的ND前缀池。其中,ipv6-prefix-pool-name表示分配ND前缀的IPv6地址池的名称,为1~63个字符的字符串,不区分大小写。此属性只对PPP和IPoE用户生效,用于每用户每前缀应用场景,该场景中每个用户都独占一个IPv6前缀。
ipv6-nd-prefix-pool-group ipv6-prefix-pool-group-name:指定为IPv6用户授权的ND前缀池组。其中,ipv6-prefix-pool-group-name表示分配ND前缀的IPv6地址池组的名称,为1~63个字符的字符串,不区分大小写。此属性只对PPP和IPoE用户生效,优先级低于ipv6-nd-prefix-pool,用于每用户每前缀应用场景,该场景中每个用户都独占一个IPv6前缀。
ipv6-pool ipv6-pool-name:指定为用户分配IPv6地址的地址池。其中,ipv6-pool-name表示分配IPv6地址的IPv6地址池名称,为1~63个字符的字符串,不区分大小写。此属性只对PPP、IPoE用户生效。
ipv6-pool-group ipv6-pool-group-name:指定为用户分配IPv6地址的地址池组,其中,ipv6-pool-group-name为IPv6地址池组名称,为1~63个字符的字符串,不区分大小写。此属性仅对PPP、L2TP和IPoE用户适用。
ipv6-prefix ipv6-prefix prefix-length:指定为用户分配的IPv6前缀。其中,ipv6-prefix prefix-length为前缀地址和前缀长度,前缀长度取值范围是1~128。此属性只对PPP、L2TP和IPoE用户生效。
mld max-access-number max-access-number:指定IPv6用户可以同时点播的最大节目数。其中,max-access-number的取值范围为1~64。此属性只对PPP、IPoE用户生效。
primary-dns ip ipv4-address:指定用户的主DNS服务器IPv4地址。此属性只对PPPoE、L2TP和IPoE用户生效。
primary-dns ipv6 ipv6-address:指定用户的主DNS服务器IPv6地址。此属性只对PPPoE、L2TP和IPoE用户生效。
secondary-dns ip ipv4-address:指定用户的从DNS服务器IPv4地址。此属性只对PPPoE、L2TP和IPoE用户生效。
secondary-dns ipv6 ipv6-address:指定用户的从DNS服务器IPv6地址。此属性只对PPPoE、L2TP和IPoE用户生效。
redirect-times times:表示对用户的Web访问请求重定向的次数进行限制,超过指定次数之后,若还未收到用户向重定向URL发起的Web请求,将停止向该用户重定向URL。其中,times表示允许对用户的Web访问请求重定向的最大次数,取值范围为1~10。此属性仅对PPPoE、L2TP和IPoE用户生效。
session-group-profile session-group-profile-name:指定用户的授权Session Group Profile。其中,session-group-profile-name为Session Group Profile名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线和英文句号,支持以字母和数字开头,但不能为纯数字,区分大小写。此属性只对PPP、IPoE用户生效。
session-timeout timeout:指定用户的会话超时时间。其中,timeout为设定的会话超时时间,取值范围为1~4294967294,单位为秒。如果用户在线时长超过该值,设备会强制该用户下线。如果RADIUS服务器通过Session-Timeout属性给用户下发了会话超时时间,则服务器下发的会话超时时间优先生效。此属性只对PPP、L2TP、IPoE、lan-access用户生效。
url url-string:指定用户的重定向URL,为1~255个字符的字符串,区分大小写,且必须携带http://或https://前缀才可生效。重定向URL主要用于Web页面推送,例如,用户认证成功后首次访问网络时用于推送广告、通知类页面,或者用户欠费时将用于推送欠费提醒页面。此URL只对PPPoE、L2TP和IPoE用户生效,且对于PPPoE和L2TP用户仅使用80或8080端口号的URL生效,对于IPoE用户仅使用80或443端口号的URL生效。
unlimited:表示对用户的所有Web访问请求进行重定向,并不限制次数。若不指定该参数,则表示对用户的Web访问请求重定向的次数进行限制,具体次数由redirect-times参数指定,缺省为2次。
user-group user-group-name:表示用户所属用户组。其中,user-group-name表示用户组名,为1~32个字符的字符串,不区分大小写。用户认证成功后,将继承该用户组中的所有属性。
user-priority:指定授权用户优先级。该用户优先级通过QoS优先级映射之后,可用于指定报文进入的优先级队列,高优先级队列中的报文在流量拥塞处理时优先得到处理。另外,用户上行报文的IP Precedence字段取值也会被该属性值替换。上行和下行用户优先级可以同时配置。缺省情况下,用户未被授予用户优先级。授权用户优先级属性只对PPPoE、L2TP、IPoE用户生效。
inbound:表示用户上行流量的优先级。
outbound:表示用户下行流量的优先级。L2TP用户不支持此参数。
priority:表示用户流量的优先级,取值范围为0~7,7的优先级最高。
user-profile:指定用户的授权User Profile。此属性只对PPP、IPoE、lan-access用户生效。如果user-profile后未指定方向参数inbound或outbound,则表示该授权User Profile无方向属性,可应用于上下行两个方向的流量。
inbound:表示用户上行流量的User Profile。
outbound:表示用户下行流量的User Profile。
profile-name :表示User Profile名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线、减号和英文句号,支持以字母和数字开头,但不能为纯数字,区分大小写。
vpn-instance vpn-instance-name:指定用户所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。用户认证成功后,将被授权允许访问指定VPN中的网络资源。此属性只对PPP、IPoE用户生效。
用户上线后,设备会周期性检测用户的流量,若域内某用户在指定的闲置检测时间内产生的流量小于本命令中指定的最小数据流量,则会被强制下线。需要注意的是,服务器上也可以配置最大空闲时间实现对用户的闲置切断功能,具体为当用户在指定的闲置检测时间内产生的流量小于10240个字节(服务器上该阈值为固定值,不可配置)时,会被强制下线。但是,只有在设备上的闲置切断功能处于关闭状态时,服务器才会根据自身的配置来控制用户的闲置切断。
对于IPoE Web认证用户,首先会通过认证前域的认证处理,通过认证前域认证之后,将获得IP地址,并被授予指定认证前域中配置的相关授权属性。
如果当前ISP域的用户认证成功,但认证服务器(包括本地认证下的接入设备)未对该ISP域下发授权属性,则系统使用当前ISP下指定的授权属性为用户授权。对于CAR授权属性以及用户优先级授权属性而言,只要认证服务器下发了任意方向的CAR/用户优先级参数,无论是否同时下发了该属性两个方向的参数,系统均以服务器的授权值为准,不再采用ISP域下配置的对应属性的授权值。
PPPoE/IPoE用户上线时,重定向URL授权属性的下发情况如下:
· 若服务器对该域中的用户下发了重定向URL,且下发了永久重定向的属性,则表示对该用户的Web访问请求进行重定向,且不限定重定向次数。实际采用的重定向URL为服务器下发的URL。
· 若服务器对该域中的用户下发了重定向URL,且下发了限定次数重定向属性,则按照域中的redirect-times参数设置对该用户的Web访问请求进行重定向。实际采用的重定向URL为服务器下发的URL。若域中未配置redirect-times参数,则重定向次数为2。
· 若服务器未对该域中的用户下发重定向URL,则使用域中的url和redirect-times参数设置对该用户的Web访问请求进行重定向,且忽略服务器下发的其它重定向属性。
¡ 若域中配置的url属性携带unlimited参数,则不限定重定向次数。
¡ 若域中配置的url属性未携带unlimited参数,则按照redirect-times参数设置对该用户的Web访问请求进行重定向。
PPPoE/IPoE用户在线时,重定向URL授权属性的下发情况如下:
· 若服务器对该域中的用户下发了停止重定向的属性,则停止对该用户的Web访问请求进行重定向。
· 若服务器对该域中的用户下发了永久重定向的属性:
¡ 且服务器同时下发了重定向URL,则对该用户的Web访问请求进行重定向,且不限定重定向次数。实际采用的重定向URL为服务器下发的URL。
¡ 但服务器未同时下发重定向URL,则忽略服务器下发的重定向属性,并向服务器返回重定向属性下发失败消息。
· 若服务器对该域中的用户下发了限定次数重定向属性:
¡ 且服务器同时下发了重定向URL,则按照用户上线时的redirect-times参数设置对该用户的Web访问请求进行重定向。实际采用的重定向URL为服务器下发的URL。若用户上线时该域中未配置redirect-times参数,则重定向次数为2。
· 可通过多次执行本命令配置多个授权属性,但对于相同授权属性,最后一次执行的命令生效。
· 若对用户同时下发了授权地址池和地址池组,则地址池优先生效。
· 如果用户的认证域下同时配置了重定向次数(通过authorization-attribute redirect-times命令)和重定向URL的有效时长(通过redirect active-time),则有效时长的优先级高,重定向次数不会生效。
· 可支持两种类型的授权User Profile,指定方向的User Profile和无方向的User Profile。
¡ 两种类型的授权User Profile配置互斥,后配置的会覆盖已配置的。以名称为abc和xyz的两个User Profile为例,先后配置如下两个授权User Profile时,仅abc会存在:
- authorization-attribute user-profile xyz
- authorization-attribute user-profile inbound abc
¡ 不同方向的授权User Profile可以共存。以名称为abc和def的两个User Profile为例,先后配置如下两个授权User Profile时,两者可以同时存在:
- authorization-attribute user-profile outbound def
· 对于从开启了可控组播功能的接口上接入的用户,其组播业务流量将受到授权可控组播User Profile的限制。如果该用户的认证域下同时配置了授权可控组播User Profile和User Profile,则仅可控组播User Profile生效。若域下未配置授权可控组播User Profile,则配置的授权User Profile生效。
指定授权ACL时,需要注意的是:
· 若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示未授权ACL规则。
在ISP域下通过authorization-attribute url命令配置授权URL来实现PPPoE或IPOE WEB后域推广告功能时,为了确保该URL可以正常被终端识别,从而弹出URL广告页面,请遵循以下配置原则:
在URL中,问号("?")字符用来分隔URL的路径部分和参数部分。authorization-attribute url仅允许包含路径部分,不允许包含参数部分。如需参数部分,可通过web-server url-parameter命令配置。
例如,需要配置的完整URL为http://77.2.2.2/portal/?testkey=testvalue的情况下,正确的配置为:
authorization-attribute url http://77.2.2.2/portal/
web-server url-parameter testkey value testvalue
# 指定ISP域test下的用户闲置切断时间为30分钟,闲置切断时间内产生的流量为10240字节。
[Sysname-isp-test] authorization-attribute idle-cut 30 10240
· display domain
· redirect active-time
basic-service-ip-type命令用来设置PPPoE/L2TP用户主业务依赖的IP地址类型。当配置主业务依赖于某IP地址类型时,如果该类型的IP地址分配失败,则不允许用户上线。
undo basic-service-ip-type命令用来恢复缺省情况。
basic-service-ip-type { ipv4 | ipv6 | ipv6-pd } *
PPPoE/L2TP用户主业务不依赖于任何IP地址类型。
ISP域视图
ipv4:IPv4地址类型。
ipv6:IPv6地址类型。
ipv6-pd:IPv6 PD(Prefix Delegation,前缀授权)类型。该类型的用户通过DHCPv6服务器为其分配的前缀信息生成IPv6地址。
该特性仅在设备作为PPPoE Server或L2TP LNS时有效。
缺省情况下,如果PPP用户上线后没有获取到相应业务类型对应的IP地址,设备将会强制其下线。
当PPPoE/L2TP用户可能请求多种IP地址类型的业务,且并非所有IP类型的业务均为其主业务时,为了保证非主业务的IP地址获取失败的情况下用户也能够上线,则需要通过本特性来满足该需求。
当配置主业务依赖于某IP类型时,如果该IP类型的地址分配失败,则不允许用户上线。例如,在某ISP下配置basic-service-ip-type ipv6后,则不允许该域中IPv6地址分配失败的PPPoE/L2TP用户上线。
如果同时指定了ipv6和ipv6-pd,则表示不允许该域中IPv6地址协商失败或者PD协商失败的PPPoE/L2TP用户上线。
# 在ISP域test下,设置PPPoE/L2TP用户主业务依赖的IP地址类型为IPv4。
[Sysname-isp-domain-test] basic-service-ip-type ipv4
· display domain
dhcpv6-follow-ipv6cp命令用来设置PPPoE/L2TP用户等待分配IPv6地址/PD的最大时长。
undo dhcpv6-follow-ipv6cp命令用来恢复缺省情况。
dhcpv6-follow-ipv6cp timeout delay-time
PPPoE/L2TP接入用户等待分配IPv6地址/PD的最大时长为60秒。
ISP域视图
timeout delay-time:最大等待时长,取值范围30~1000,单位秒。
PPPoE/L2TP用户与设备完成IPv6CP协商之后,如果在一定的时长内未能成功分配到主业务依赖类型的IPv6地址/PD,则被强制下线,否则使用分配到的IP地址上线。
在设备与PPPoE/L2TP用户连接所在网络质量比较差,使用DHCPv6为用户分配IPv6地址,或者PPPoE/L2TP用户数量比较大时,可以适当增加此等待时长避免用户因为地址分配失败而下线。
# 在ISP域test下,设置PPPoE/L2TP用户等待分配IPv6地址/PD的最大时长为90秒。
[Sysname-isp-domain-test] dhcpv6-follow-ipv6cp timeout 90
· basic-service-ip-type
· display domain
display aaa abnormal-offline-record命令用来显示用户异常下线记录。
display aaa abnormal-offline-record { access-type { ipoe | lan-access | login | ppp } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa abnormal-offline-record offline-reason { idle-cut | quota-out | realtime-acct-fail | session-timeout | user-detect-fail } [ brief ]
display aaa abnormal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
access-type:显示指定用户接入类型的异常下线记录。
ipoe:IPoE接入用户。
lan-access:LAN接入用户。
login:登录设备的用户,如SSH、Telnet、FTP用户。
ppp:PPP接入用户。
domain domain-name:显示通过指定ISP域上线的用户的异常下线记录。domain-name表示ISP域名,为1~255个字符的字符串,不区分大小写。
interface interface-type interface-number:显示通过指定接口上线的用户的异常下线信息。interface-type interface-number表示用户接入接口的类型和接口编号。
ip ipv4-address:显示指定IPv4地址的用户异常下线记录。
ipv6 ipv6-address:显示指定IPv6地址的用户异常下线记录。
mac-address mac-address:显示指定MAC地址的异常下线失败记录。mac-address为用户的MAC地址,格式为H-H-H。
slot slot-number:指定单板。slot-number为单板所在的槽位号。
s-vlan svlan-id:显示通过指定服务提供商VLAN上线的用户的异常下线记录。svlan-id表示VLAN ID,取值范围为1~4094。
c-vlan cvlan-id:显示通过指定用户VLAN上线的用户的异常下线记录。cvlan-id表示VLAN ID,取值范围为1~4094。
username user-name:显示指定用户名的异常下线记录。user-name表示用户名,为1~253个字符的字符串,区分大小写。
fuzzy-match:表示松散匹配用户名,即只要user-name字符串能连续匹配用户记录中的部分或者完整用户名,则匹配成功。若不指定该参数,则表示精确匹配用户名,即user-name字符串必须完全匹配上完整的用户名,才表示匹配成功。
offline-reason:显示指定下线原因的用户异常下线记录。
· idle-cut:闲置超时后切断。
· quota-out:流量配额耗尽。
· realtime-acct-fail:实时计费失败。
· session-timeout:用户会话超时。
· user-detect-fail:用户探测失败。
time:显示指定时间范围内下线用户的异常下线记录。
begin-time:起始时间,格式为hh:mm:ss(小时:分钟:秒),hh取值范围为0~23,mm和ss取值范围为0~59。
end-time:结束时间,格式为hh:mm:ss(小时:分钟:秒),hh取值范围为0~23,mm和ss取值范围为0~59。
date:显示指定日期范围的异常下线记录。若不指定该参数,则表示仅查看当天的记录。
begin-date:起始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
end-date:结束日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
brief:显示用户异常下线记录的简要信息。若不指定该参数,则表示显示用户异常下线记录的详细信息。
count count:显示指定数量的异常下线记录。count为记录的条目,取值范围为1~32768。
可通过指定多种组合条件按需查询用户的异常下线记录。系统将从最新的一条记录开始显示符合查询条件的记录。
无论当前系统中的用户异常下线记录功能是否处于开启状态,只要系统中存在用户异常下线记录,就能通过本命令进行查看。
若不指定任何参数,则显示当前系统中的所有用户异常下线记录的详细信息。
如果服务器传递给设备的用户名中携带不可见字符,则使用指定用户名方式查看该类用户信息时,必须指定fuzzy-match关键字,否则无法查看到该用户信息。
# 显示所有用户异常下线记录的详细信息。
<Sysname> display aaa abnormal-offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: SSH
Access interface: Ten-GigabitEthernet3/0/1
SVLAN/CVLAN: -/-
IP address: 19.19.0.2
IPv6 address: -
Online request time: 2019/01/02 15:20:33
Offline time: 2019/02/28 15:20:56
Offline reason: User disconnected from the server.
# 显示login用户异常下线记录的简要信息。
<Sysname> display aaa abnormal-offline-record access-type login brief
Username: jay
MAC address: -
IP address: 11.2.2.41
IPv6 address: -
表1-1 display aaa abnormal-offline-record命令显示信息描述表
Total count |
用户异常下线记录总计数 |
Username |
用户名(若不存在,则显示为空) |
Domain |
ISP域名(若不存在,则显示为空) |
MAC address |
用户的MAC地址(若不存在,则显示“-”) |
Access type |
用户的接入类型: · PPPoPhy:物理链路直接承载的PPP接入用户 · PPPoE:PPPoE接入用户 · PPPoL2TP:PPP over L2TP接入用户 · PPPoEA:PPPoE代拨接入用户 · PPPoFR:PPP over FR接入用户 · VPPP:L2TP自动拨号链路接入用户 · 802.1X:802.1X用户 · Web authentication:Web认证用户 · Telnet:Telnet用户 · FTP:FTP用户 · SSH:SSH用户 · IPoE:IPoE普通用户 · IPoE static:IPoE静态用户 · IPoE interface leased:IPoE接口专线用户 · IPoE subnet leased:IPoE子网专线用户 · IPoE L2VPN leased:IPoE L2VPN专线用户 · NETCONF over SOAP:NETCONF over SOAP用户 · NETCONF over RESTful:NETCONF over RESTful用户 · Terminal:Terminal用户,例如从Console口登录设备的终端用户 |
Access interface |
用户接入的接口名(若不存在,则显示“-”) |
SVLAN/CVLAN |
服务提供商VLAN/用户VLAN(若不存在,则显示“-”) |
IP address |
用户的IPv4地址(若不存在,则显示“-”) |
IPv6 address |
用户的IPv6地址(若不存在,则显示“-”) |
Online request time |
用户发起上线请求的时间 |
Offline time |
用户下线的时间 |
Offline reason |
用户的下线原因,详细介绍请参见表1-2 |
Detailed message |
用户下线的详细原因 目前,仅当接口板或者UP发生故障导致用户下线时才会显示本字段,包括如下信息: · 接口板的位置 · 详细原因 |
下表罗列内容为所有产品可支持上/下线原因的合集,具体产品支持情况有所不同。
表1-2 用户上/下线原因描述表
Lost carrier. |
物理链路DOWN |
Lost service. |
用户业务不支持 |
NAS error. |
设备错误 |
NAS reboot. |
设备重启 |
Admin reboot. |
管理员重启设备 |
Process exit. |
接入进程退出 |
NAS request. |
设备请求用户下线 |
Cut command. |
管理员手动执行命令强制用户下线 |
Logged off by the RADIUS server. |
RADIUS服务器要求用户下线 |
User request. |
用户请求下线 |
Authentication failed |
认证失败 |
Authorization failed. |
授权失败 |
Start accounting failed. |
开始计费失败 |
No AAA response during authentication. |
用户在进行远端服务器认证时,设备在认证超时时间内未收到认证服务器的回应 |
RADIUS authentication rejected. |
用户名或密码与RADIUS服务器上的信息不一致,导致认证失败 |
AAA authorization information invalid. |
授权信息错误或者设备上没有对应的授权配置 |
No AAA response for accounting start. |
用户向远端服务器发送计费开始时,设备在计费开始超时时间内未收到认证服务器的回应 |
Authentication request to AAA failed. |
由于设备与RADIUS服务器间路由不可达,导致认证请求发送失败 |
Accounting request to AAA failed. |
由于设备与RADIUS服务器间路由不可达,导致计费请求发送失败 |
TACACS authentication rejected. |
用户名或密码与HWTACACS服务器上的信息不一致,导致认证失败 |
Authentication method error. |
接入模块的认证配置错误。可能是用户请求的认证类型与端口下配置的认证类型不一致 |
No AAA response for accounting stop. |
未收到服务器对停止计费请求的回应 |
The local user doesn't exist. |
设备上未配置该本地用户 |
Local authentication request was rejected. |
用户密码错误导致本地认证被拒绝 |
IP assignment failed. |
IP地址分配失败 |
Concurrent user login limit reached. |
一个本地用户帐号允许接入的用户数超过了限制 |
NAS interface access limit reached. |
NAS接口下上线的用户数已达到了该接口下配置的允许上线用户数目最大限制 |
Maximum number of concurrent users that use this account already reached. |
使用该账户的用户达到了上限个数 |
PPP negotiation terminated. |
PPP协商过程失败 |
Insufficient hardware resources. |
硬件资源不足 |
Failed to obtain IPv6 prefix. |
没有可用的IPv6地址前缀用来为用户分配 |
No response from DHCP server. |
设备向远端DHCP服务器申请IP地址时,没有收到远端服务器的响应 |
DHCP IP address allocation failure. |
DHCPv6地址分配失败,可能的原因包括: · AAA域下没有配置授权IPv6地址池 · IPv6地址池被锁定 |
DHCP session conflict. |
新建的DHCP会话与已有的会话冲突 |
DHCP user request. |
DHCP用户请求下线 |
DHCP lease timeout. |
DHCP用户地址租期到期下线 |
DHCP declined. |
已有主机使用服务器分配的IP地址 设备收到用户的DHCP-DECLINE报文,可能是客户端检测到用户网络中存在另一个相同的IP地址 |
DHCP configuration changed. |
DHCP配置变化触发用户下线 |
UP ID synchronization between DHCP and UPLB failed. |
DHCP与UPLB平滑UP ID失败 |
DHCP configuration synchronization between CTRL-VM and BRAS-VM failed. |
CTRL-VM和BRAS-VM平滑配置失败 |
DHCP VSRP status changed to Down. |
DHCP VSRP的状态改变,主设备down或备用设备down |
Address leases deleted in bulk on the VSRP backup device. |
在VSRP备用设备上批量删除用户的IP地址租约 |
Address leases deleted upon CPDR backup mode change from hot to cold. |
CP灾备从热备模式切换为冷备模式,用户的IP地址租约被删除 |
Network for the DHCP pool was deleted. |
删除IP地址池下的网段配置,导致网段下的IP地址租约一同被删除 |
All subnets in the DHCP address pool have been allocated. |
ODAP类型的IP地址池中无空闲子网段可分配 |
All subnets in the DHCP address pool group have been allocated. |
ODAP类型的IP地址池组中无空闲子网段可分配 |
All subnets in the DHCPv6 address pool have been allocated. |
ODAP类型的IPv6地址池中无空闲子网段可分配 |
All subnets in the DHCPv6 address pool group have been allocated. |
ODAP类型的IPv6地址池组中无空闲子网段可分配 |
All prefix ranges in the DHCPv6 address pool have been allocated. |
ODAP类型的IPv6地址池中无空闲前缀段可分配 |
All prefix ranges in the DHCPv6 address pool group have been allocated. |
ODAP类型的IPv6地址池组中无空闲前缀段可分配 |
NAK from the DHCP server or tenant duration is 0. |
客户端请求的IP地址与设备分配的IP地址网段不一致或续租时间为0 |
IP conflict on DHCP server. |
设备检测到IP地址冲突 |
DHCP server notified. |
DHCP服务器通知用户下线 |
DHCP server notified, and the device deleted the user. |
DHCP服务器端通知用户下线,设备删除用户 |
Force user offline by up switch unbind. |
UP备份策略模板下主备接口解绑,强制用户下线 |
Force user offline by deleting the remote interface. |
UP管理视图下的远端接口被删除,强制用户下线 |
Force user offline by removing the interface from up-backup-profile in warm-standby mode. |
温备模式下,接口从UP备份策略模板中删除,强制用户下线 |
DHCPv6 requests with DUID mismatch. |
配置ipv6 dhcp duid-mismatch offline命令后,DHCPv6服务器收到了与用户MAC相同但DUID不同的DHCPv6请求报文,删除在线用户租约 |
DHCP with dhcp user offline configured. |
配置dhcp user offline命令后,DHCP设备收到了相同MAC地址的DHCP-DISCOVER或REBOOT-REQUEST报文,删除在线用户租约 |
DHCP with the fast-renew method specified for roaming users. |
配置(ipv6)dhcp session-mismatch action fast-renew命令后,DHCP设备收到了物理位置变化、MAC地址不变的用户DHCP/DHCPv6请求报文,删除在线用户租约 |
DHCP with dhcp conflict-ip-address offline configured. |
配置dhcp conflict-ip-address offline命令后,设备检测到分配的地址与已在线用户地址冲突,删除在线用户 |
DHCP-UCM smooth aging by equal MAC. |
DHCP与UCM平滑时,DHCP已存在与UCM推送的用户同MAC的表项时,删除DHCP上的用户表项 |
DHCP request interface address. |
DHCP用户请求的地址是设备的接口地址 |
DHCP lease release with ICMP. |
通过ICMP报文探测到用户地址冲突,释放租约 |
DHCP request IP is used. |
用户请求的地址已被使用 |
DHCP request info mismatch. |
DHCP已存在该PPP用户,且用户信息(VLAN等)不匹配 |
DHCP request IP conflict of NDRA relogin user. |
NDRA用户重上线请求的地址是冲突地址 |
DHCP reserve IP in detect subnet table. |
请求的占位地址已在detect subnet表中 |
DHCP reserve prefix failed due to share type conflict. |
用户请求的占位前缀共享类型与该前缀实际的共享类型不一致,请求占位前缀失败 |
DHCP reserve unshare prefix is used. |
请求的非共享占位前缀已被使用 |
DHCP reserve share prefix already used by another type user. |
请求的共享占位前缀已被其他类型的用户使用 |
DHCP reserve subnet is used. |
申请的占位子网段已被使用 |
DHCP reserve subnet in detect IP table. |
申请的占位子网段已在detect ip表中 |
DHCP reserve subnet is used by unknown source. |
申请的占位子网段已被未知源用户使用 |
Invalid DHCP request info, pool-group not exist. |
用户请求的地址池组不存在 |
DHCP temporarily not process the user request. |
暂未处理该用户请求 |
Invalid DHCP request info, pool VPN not exist. |
地址池下配置的VPN不存在 |
Invalid DHCP request info, VPN mismatch. |
用户所属VPN和地址池下配置的VPN不一致 |
Invalid DHCP request info, network not exist. |
用户请求的地址池下未配置network |
Invalid DHCP request info, pool not exist. |
用户请求的地址池不存在 |
DHCP smooth failed, IP mismatch. |
PPP用户租约平滑失败,DHCP模块用户租约与UCM平滑中携带的租约不一致 |
DHCP smooth failed, lease not exist. |
PPP用户租约平滑失败,DHCP模块不存在该用户租约 |
DHCP reserve subnet not exist. |
申请的占位子网段不存在 |
DHCP lease initialization failed. |
初始化租约失败 |
DHCP reserve IP failed, invalid reserved ip. |
申请的占位地址是无效地址 |
DHCP PPP online failed, request lease failed. |
PPP用户租约申请失败,上线失败 |
DHCP delete user, VT interface deactive. |
DHCP收到虚拟模板接口的deactive事件,删除该接口下的用户 |
DHCP proxy entry timeout. |
Proxy表项老化删除 |
DHCP delete proxy entry upon NAK. |
中继收到DHCP-NAK报文,删除proxy表项 |
DHCP delete proxy entry. |
Proxy表项被删除 |
DHCP delete MAC-port entry. |
MAC-port表项被删除 |
DHCP delete timeout MAC-port entry. |
MAC-port表项老化删除 |
DHCP pool-group delete. |
上线地址池所属的地址池组被删除 |
DHCP delete pool from pool-group. |
上线地址池从地址池组下被删除 |
DHCP delete pool. |
上线地址池被删除 |
DHCP start ICMP failed. |
DHCP启动ICMP探测失败 |
DHCP NDRS request exceed maximum. |
NDRS的待处理请求数已达到最大,暂不接收新请求 |
DHCP NDRS online timeout. |
NDRS用户上线超时 |
DHCP pool locked. |
地址池被锁定 |
DHCP reserve subnet failed, subnet mask lower than network mask. |
因申请的子网段掩码比network网段的掩码小,占位子网段申请失败 |
DHCP reserve subnet failed, unusable network. |
网段可用性检查失败,占位子网段申请失败 |
DHCP reserve prefix failed, unusable prefix. |
前缀池可用性检查失败,占位前缀申请失败 |
DHCP NDRA relogin failed, no available pool in pool-group. |
地址池组中未匹配上地址池,NDRA用户重上线失败 |
DHCP NDRA relogin failed, lease pool not found. |
租约所属地址池不存在,NDRA用户重上线失败 |
DHCP NDRA relogin failed. |
NDRA用户重上线失败 |
DHCP NDRA smooth failed, another address lease already exist. |
NDRA用户平滑失败:该用户已有地址不一致的租约 |
DHCP prefix lease initialization failed. |
初始化前缀租约失败 |
DHCP delete lease after another module notify. |
其它模块通知DHCP删除租约 |
DHCP NDRA smooth failed. |
NDRA用户平滑失败 |
DHCP dual NDRS backup request failed. |
双活NDRS用户,备设备将地址请求消息发送给主设备失败 |
DHCP static reserve IP failed, unsable IP. |
因地址可用性检查失败,静态占位地址申请失败 |
DHCP alloc mode error. |
分配模式不正确 |
DHCP request timeout in pool-group. |
PPPOE地址池组上线的情况下,上线请求处理不及时,上线失败 |
DHCP request timeout in pool. |
PPPOE地址池上线的情况下,上线请求处理不及时,上线失败 |
DHCP Cinfo refresh by detecting lease released. |
相同租约分配给新用户,Cinfo信息刷新,原用户下线 |
DHCPv6 REPLY packet info invalid. |
DHCPv6 REPLY报文中携带的信息无效,导致上线/续约失败(租约时间或者status code中携带了失败的错误码) |
DHCP inform request has no response. |
因处理inform报文生成的临时用户,在未收到inform回复时,删除该用户 |
DHCP inform request process successfully. |
因处理inform报文生成的临时用户,inform处理完毕后,删除该用户 |
DHCP has not received the smooth end message from the CPDR module. |
DHCP未收到CP灾备模块通知的smooth end消息 |
DHCP has not received the smooth end message from the UP Backup module. |
DHCP未收到UP备份模块通知的smooth end消息 |
AM configuration error. |
AM模块配置错误 |
The static session already exists. |
新建IPoE动态会话与已有静态会话配置冲突 |
NAT444 failed. |
IPoE与NAT444联动失败 |
The ND RS session is updated. |
ND用户在线时,又收到该用户的ND上线请求,触发用户下线 |
L2TP tunnel terminated by the peer. |
对端拆除了L2TP隧道,可能是对端设备检测到用户下线 |
The peer did not respond to control packets. |
对端设备未回应本端的PPP控制报文 |
Failed to set up an L2TP session. |
L2TP会话创建失败 |
Repeated LCP negotiation packets. |
收到重复的LCP协商报文,可能是客户端断开后重新发起连接 |
COA failure. |
设备处理COA授权消息失败 |
Failed to update authorization information. |
更新用户授权信息失败 |
Realtime accounting request to AAA failed. |
实时计费请求失败 |
Session timeout. |
用户会话超时 |
Data quota limit reached. |
用户可用流量额度已经达到限定值 |
Session idle cut. |
闲置切断,即单位时间内用户的流量小于指定值,设备强制用户下线 |
User online detection failure. |
用户在线探测失败 |
Port was removed from VLAN. |
用户上线的物理端口被移出所在VLAN |
Port error. |
端口错误 |
Interface down or deactive. |
接口协议down、链路down或接口未激活 |
VSRP status changed. |
VSRP状态变化 |
Backup device deleted user data that is inconsistent with data on the master device. |
VSRP备设备删除了与主设备上不一致的用户数据 |
MAC address change. |
用户MAC地址变化 |
Failed to recover AAA resources. |
恢复用户的AAA资源失败 |
Deleted users because of inter-card session conflict. |
不同单板上的会话冲突导致用户下线 |
User aged out before coming online. |
达到了接入模块的上线超时时间 |
MPU-LPU data synchronization failure. |
板间数据平滑失败 |
Failed to synchronize data with DHCP server. |
与DHCP服务器之间数据同步失败 |
Failed to synchronize user information with the server. |
与服务器同步用户信息失败 |
User recovery failure. |
用户数据恢复失败 |
Failed to obtain physical information. |
获取物理信息失败 |
Authorization ACL for the online user changed. |
授权的ACL配置变化 |
Authorization user profile for the online user changed. |
授权的User Profile配置变化 |
Magic number check failed. |
魔术字检查失败 |
Reauthentication failed. |
重认证失败 |
No AAA response during realtime accounting. |
实时计费无响应 |
Invalid username or password. |
无效用户名或者密码 |
No VTY line available. |
没有VTY资源,登录VTY的用户数达到了最大值 |
SSH server received a packet with an incorrect message authentication code. |
SSH客户端报文的消息认证码(Message Authentication Code)错误 |
User disconnected from the server. |
SSH或FTP用户与服务器断开连接 |
No working directory available. |
无可用工作路径错误 |
PTY allocation failed. |
PTY(伪终端)申请失败 |
FTP server error. |
用户连接的FTP服务器异常,由于FTP服务器自身的原因导致用户无法登录 |
Server is disabled. |
服务未开启 |
Service type not supported. |
服务类型不支持 |
RBAC denied file management operations in the login command. |
登录命令中的文件系统操作权限被RBAC禁止 |
Failed to issue RBAC access permissions to the login user. |
登录命令行执行权限被RBAC禁止 |
NETCONF inner error. |
NETCONF内部错误 |
NETCONF session was terminated by another NETCONF session. |
用户的Netconf会话被其它Netconf会话打断 |
Failed to allocate public network ports in a CGN network. |
CGN公网端口分配失败 |
Failed to obtain an IP address of the type specified for basic services of users. |
用户主业务依赖的IP地址分配失败 |
UserGroup configuration changed. |
用户组配置变化 |
MAC conflict. |
MAC地址冲突 |
RedisDBM clear. |
在数据迁出设备上执行RedisDBM的clear操作导致用户下线 |
RedisDBM conflict. |
在数据迁入设备上恢复Redis数据时发生数据冲突 |
RedisDBM block. |
在数据迁出设备上执行RedisDBM的block操作导致用户下线 |
Logged out by the RADIUS proxy |
被RADIUS代理强制下线 |
Logged out by the RADIUS proxy because of username change |
由于用户名变化,导致用户被RADIUS代理强制下线 |
NAT failed to issue the user port block info to the driver. |
用户上线成功之后,端口块会下发驱动,如果下发驱动失败,用户会下线 |
Failed to match NAT configuration. |
用户上线没有匹配上NAT的配置(比如nat outbound 3000 address-group 1配置的ACL与用户信息不符),或者用户平滑时没有匹配上NAT的配置 |
Failed to come online by using CGN because the matching NAT doesn't support port block-based NAT. |
用户上线时命中的NAT配置不支持端口块方式,导致用户联动上线失败 |
Failed to get NAT instance or NAT instance configuration is not correct. |
负载分担用户组获取NAT实例失败或者NAT实例配置有误,导致用户上线失败 |
The NAT address was released. |
由于NAT地址被回收,导致用户下线 |
NAT configured with flow-triggered port block assignment doesn't support CGN. |
目前仅有端口块方式支持联动上线,端口块的分配方式由命令行决定,如果开启了流量触发分配端口块,那么被重定向到这个实例的用户上线失败 |
Failed to come online by using CGN because of session service-location configuration matching failure. |
匹配session service-location命令失败,导致用户上线失败 |
Online failed because of matched CGN configuration doesn't support port block. |
用户上线匹配到的NAT配置因没有配置端口块方式导致用户上线失败 |
Memory allocation failed for AFT. |
当前内存资源不足,AFT为上线用户申请资源失败 |
Failed to add NAT user data (invalid private network address). |
添加NAT用户数据失败,原因是用户地址无效 |
NAT obtained an invalid backup instance ID from the user online request message in a UP hot backup environment. |
双机环境中,地址转换模块从用户上线消息中获取的备份实例ID无效,用户上线失败 |
NAT instance state error. |
NAT实例状态错误 |
The NAT instance was unbound from CGN-UP backup profile. |
CGN-UP备份策略模板与NAT实例解绑 |
Failed to obtain user group information. |
获取用户组信息失败 |
NAT and BRAS unification failed due to UCM and CGN backup mode mismatch. |
UCM备份模式与CGN备份模式的组合,不支持接入与NAT联动 |
User authentication and NAT unification failed due to nat instance is sub type. |
联动上线消息中的NAT实例为子实例,用户上线失败 |
Login time beyond validity period. |
登录时间不在本地用户的有效期内 |
Maximum number of concurrent SSH users already reached. |
已达到同时在线的最大SSH用户连接数 |
BRAS user offline. |
BRAS上的IPoE用户下线导致对应的PPPoE代拨用户下线 |
User is in local-user blacklist |
本地用户处于Password Control黑名单中 |
The user's 802.1X client has not come online. |
在802.1X认证组网中,对于通过开启了静态802.1X用户认证功能(由ip subscriber static-dot1x-user enable命令配置)的接口接入的用户,如果在该用户的802.1X客户端认证上线前,BRAS设备收到该用户发送的ARP报文、未知源IP报文或NS/NA报文,将拒绝该用户作为静态802.1X用户上线 |
The source IP address of the L2TP tunnel does not support backup. |
1:1热备、N:1温备和1:N温备组网中,在LAC UP使用tunnel up-id up-id source-ip source-ip-address [ vpn-instance vpn-instance-name ]命令配置的源端IP地址建立L2TP隧道的情况下,LAC UP发送主备切换时,L2TP用户切换到新主LAC UP后,会被下线 |
Layer2 IPoE leased subusers do not support access through IA_PD or the NDRS scenario of one prefix per user. |
由于二层IPoE专线子用户不支持通过IA_PD方式以及NDRS每用户每前缀方式接入,配置错误导致二层IPoE专线子用户通过IA_PD方式或者NDRS每用户每前缀方式接入时子用户上线失败 |
Fail to add to RADIUS buffer queue |
加入Radius缓存队列失败 |
· reset aaa abnormal-offline-record
display aaa normal-offline-record命令用来显示用户正常下线记录。
display aaa normal-offline-record { access-type { ipoe | lan-access | login | ppp } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa normal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
access-type:显示指定用户接入类型的正常下线记录。
ipoe:IPoE接入用户。
lan-access:LAN接入用户。
ppp:PPP接入用户。
domain domain-name:显示通过指定ISP域上线的用户的正常下线记录。domain-name表示ISP域名,为1~255个字符的字符串,不区分大小写。
interface interface-type interface-number:显示通过指定接口上线的用户的正常下线信息。interface-type interface-number表示用户接入接口的类型和接口编号。
ip ipv4-address:显示指定IPv4地址的用户正常下线记录。
ipv6 ipv6-address:显示指定IPv6地址的用户正常下线记录。
mac-address mac-address:显示指定MAC地址的正常下线记录。mac-address为用户的MAC地址,格式为H-H-H。
s-vlan svlan-id:显示通过指定服务提供商VLAN上线的用户的正常下线记录。svlan-id表示VLAN ID,取值范围为1~4094。
c-vlan cvlan-id:显示通过指定用户VLAN上线的用户的正常下线记录。cvlan-id表示VLAN ID,取值范围为1~4094。
username user-name:显示指定用户名的正常下线记录。user-name表示用户名,为1~253个字符的字符串,区分大小写。
time:显示指定时间范围内上线用户的正常下线记录。
date:显示指定日期范围的正常下线记录。若不指定该参数,则表示仅查看当天的记录。
brief:显示用户正常下线记录的简要信息。若不指定该参数,则表示显示用户正常下线记录的详细信息。
count count:显示指定数量的正常下线失败记录。count为记录的条目,取值范围为1~32768。
可通过指定多种组合条件按需查询用户的正常下线记录。系统将从最新的一条记录开始显示符合查询条件的记录。
无论当前系统中的用户正常下线记录功能是否处于开启状态,只要系统中存在用户正常下线记录,就能通过本命令进行查看。
若不指定任何参数,则显示当前系统中的所有用户正常下线记录的详细信息。
# 显示所有用户正常下线记录的详细信息。
<Sysname> display aaa normal-offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
Offline reason: User request.
# 显示login用户正常下线记录的简要信息。
<Sysname> display aaa offline-record access-type login brief
Username: jay
MAC address: -
IPv6 address: -
表1-3 display aaa normal-offline-record命令显示信息描述表
Total count |
用户正常下线记录总计数 |
Username |
用户名(若不存在,则显示为空) |
Domain |
ISP域名(若不存在,则显示为空) |
MAC address |
Access type |
用户的接入类型: · PPPoPhy:物理链路直接承载的PPP接入用户 · PPPoE:PPPoE接入用户 · PPPoL2TP:PPP over L2TP接入用户 · PPPoFR:PPP over FR接入用户 · PPPoEA:PPPoE代拨接入用户 · VPPP:L2TP自动拨号链路接入用户 · 802.1X:802.1X用户 · Web authentication:Web认证用户 · Telnet:Telnet用户 · FTP:FTP用户 · SSH:SSH用户 · IPoE:IPoE普通用户 · IPoE static:IPoE静态用户 · IPoE interface leased:IPoE接口专线用户 · IPoE subnet leased:IPoE子网专线用户 · IPoE L2VPN leased:IPoE L2VPN专线用户 · NETCONF over SOAP:NETCONF over SOAP用户 · NETCONF over RESTful:NETCONF over RESTful用户 · Terminal:Terminal用户,例如从Console口登录设备的终端用户 |
Access interface |
SVLAN/CVLAN |
IP address |
IPv6 address |
用户发起上线请求的时间 |
Offline time |
用户下线的时间 |
Offline reason |
· reset aaa normal-offline-record
display aaa offline-record命令用来显示用户下线记录。
display aaa offline-record { access-type { ipoe | lan-access | login | ppp } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
access-type:显示指定用户接入类型的下线记录。
lan-access:LAN接入用户。
ipoe:IPoE接入用户。
ppp:PPP接入用户。
domain domain-name:显示通过指定ISP域上线的用户的下线记录。domain-name表示ISP域名,为1~255个字符的字符串,不区分大小写。
interface interface-type interface-number:显示通过指定接口上线的用户的下线信息。interface-type interface-number表示用户接入接口的类型和接口编号。
ip ipv4-address:显示指定IPv4地址的用户下线记录。
ipv6 ipv6-address:显示指定IPv6地址的用户下线记录。
mac-address mac-address:显示指定MAC地址的下线记录。mac-address为用户的MAC地址,格式为H-H-H。
s-vlan svlan-id:显示通过指定服务提供商VLAN上线的用户的下线记录。svlan-id表示VLAN ID,取值范围为1~4094。
c-vlan cvlan-id:显示通过指定用户VLAN上线的用户的下线记录。cvlan-id表示VLAN ID,取值范围为1~4094。
username user-name:显示指定用户名的下线记录。user-name表示用户名,为1~253个字符的字符串,区分大小写。
time:显示指定时间范围内下线用户的下线记录。
date:显示指定日期范围的下线记录。若不指定该参数,则表示仅查看当天的记录。
brief:显示用户下线记录的简要信息。若不指定该参数,则表示显示用户下线记录的详细信息。
count count:显示指定数量的下线记录。count为记录的条目,取值范围为1~65536。
可通过指定多种组合条件按需查询用户的下线记录。系统将从最新的一条记录开始显示符合查询条件的记录。
无论当前系统中的用户下线记录功能是否处于开启状态,只要系统中存在用户下线记录,就能通过本命令进行查看。
若不指定任何参数,则显示当前系统中的所有用户下线记录的详细信息。
如果服务器传递给设备的用户名中携带不可见字符,因此使用指定用户名方式查看该类用户信息时,必须指定fuzzy-match关键字,否则无法查看到该用户信息。
# 显示所有用户下线记录的详细信息。
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
# 显示login用户下线记录的简要信息。
Username: jay
MAC address: -
IP address: 20.20.20.1
IPv6 address: -
Username: test
MAC address: -
IP address: 20.20.20.3
IPv6 address: -
表1-4 display aaa offline-record命令显示信息描述表
Total count |
用户下线记录总计数 |
Username |
用户名(若不存在,则显示为空) |
Domain |
ISP域名(若不存在,则显示为空) |
MAC address |
Access type |
用户的接入类型: · PPPoPhy:物理链路直接承载的PPP接入用户 · PPPoE:PPPoE接入用户 · PPPoEA:PPPoE代拨接入用户 · PPPoL2TP:PPP over L2TP接入用户 · PPPoFR:PPP over FR接入用户 · VPPP:L2TP自动拨号链路接入用户 · 802.1X:802.1X用户 · Web authentication:Web认证用户 · Telnet:Telnet用户 · FTP:FTP用户 · SSH:SSH用户 · IPoE:IPoE普通用户 · IPoE static:IPoE静态用户 · IPoE interface leased:IPoE接口专线用户 · IPoE subnet leased:IPoE子网专线用户 · IPoE L2VPN leased:IPoE L2VPN专线用户 · NETCONF over SOAP:NETCONF over SOAP用户 · NETCONF over RESTful:NETCONF over RESTful用户 · Terminal:Terminal用户,例如从Console口登录设备的终端用户 |
Access interface |
SVLAN/CVLAN |
IP address |
IPv6 address |
用户发起上线请求的时间 |
Offline time |
用户下线的时间 |
Offline reason |
Detailed message |
· reset aaa offline-record
display aaa online-fail-record命令用来显示用户上线失败记录。
display aaa online-fail-record { access-type { ipoe | lan-access | login | ppp } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa online-fail-record time begin-time end-time [ date begin-date end-date ] [ brief ]
access-type:显示指定用户接入类型的上线失败记录。
ipoe:IPoE接入用户。
lan-access:LAN接入用户。
ppp:PPP接入用户。
domain domain-name:显示通过指定ISP域上线的用户的上线失败记录。domain-name表示ISP域名,为1~255个字符的字符串,不区分大小写。
interface interface-type interface-number:显示通过指定接口上线的用户的上线失败信息。interface-type interface-number表示用户接入接口的类型和接口编号。
ip ipv4-address:显示指定IPv4地址的用户上线失败记录。
ipv6 ipv6-address:显示指定IPv6地址的用户上线失败记录。
mac-address mac-address:显示指定MAC地址的上线失败记录。mac-address为用户的MAC地址,格式为H-H-H。
s-vlan svlan-id:显示通过指定服务提供商VLAN上线的用户的上线失败记录。svlan-id表示VLAN ID,取值范围为1~4094。
c-vlan cvlan-id:显示通过指定用户VLAN上线的用户的上线失败记录。cvlan-id表示VLAN ID,取值范围为1~4094。
username user-name:显示指定用户名的上线失败记录。user-name表示用户名,为1~253个字符的字符串,区分大小写。
time:显示指定时间范围内上线用户的上线失败记录。
date:显示指定日期范围的上线失败记录。若不指定该参数,则表示仅查看当天的记录。
brief:显示用户上线失败记录的简要信息。若不指定该参数,则表示显示用户上线失败记录的详细信息。
count count:显示指定数量的上线失败记录。count为记录的条目,取值范围为1~32768。
可通过指定多种组合条件按需查询用户的上线失败记录。系统将从最新的一条记录开始显示符合查询条件的记录。
无论当前系统中的用户上线失败记录功能是否处于开启状态,只要系统中存在用户上线失败记录,就能通过本命令进行查看。
若不指定任何参数,则显示当前系统中的所有用户上线失败记录的详细信息。
# 显示2条用户名为aaa的login用户上线失败记录的详细信息。
<Sysname> display aaa online-fail-record username aaa access-type login count 2
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: 100/-
IP address: 19.19.0.1
IPv6 address: -
Online request time: 2019/01/02 15:20:37
Online failure reason: Authentication failed.
Reply message: no user exists.
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
# 显示2019/3/1的13:20:50 到2019/3/2的10:20:30这段时间内的上线失败用户记录的简要信息。
<Sysname> display aaa online-fail-record time 13:20:50 10:20:30 date 2019/3/1 2019/3/2 brief
Username: aaa
MAC address: -
IPv6 address: -
# 显示2019/3/1的13:20:50至2019/3/2的17:20:30期间的用户上线失败记录。
<Sysname> display aaa online-fail-record time 13:20:50 17:20:30 date 2019/3/1 2019/3/2
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
Online request time: 2019/03/02 16:20:33
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
Online request time: 2019/03/01 15:20:51
表1-5 display aaa online-fail-record命令显示信息描述表
Total count |
用户上线失败记录总数 |
Username |
用户名(若不存在,则显示为空) |
Domain |
用户上线使用的ISP域名(若不存在,则显示为空) |
MAC address |
Access type |
Access interface |
SVLAN/CVLAN |
IP address |
IPv6 address |
用户发起上线请求的时间 |
Online failure reason |
用户的上线失败原因,详细介绍请参见表1-2 |
Reply message |
服务器下发的消息(若未下发,则不显示) |
· reset aaa online-fail-record
display aaa online-offline-reason命令用来显示用户上下线原因码的描述信息。
display aaa online-offline-reason [ code code-id ]
code code-id:上下线原因码的编号,最小值为1,具体取值范围请在参数位置输入<?>查看。
用户上线失败以及正常或异常下线时,设备会细分原因并使用原因码标识它们。在用户下线时,设备还会在计费停止请求报文中携带该原因码向服务器端告知用户下线的原因。管理员可以在设备上通过执行本命令来查看这些原因码所代表的含义。
若不指定任何参数,则表示显示所有的用户上下线原因码描述信息(不包括预留原因码)。因此,在使用本命令查看用户上下线原因码的描述信息时,建议通过指定原因编号的方式对显示信息进行过滤,避免信息过多,不易查找。
# 显示编号为1的用户上下线原因码的描述信息。
<Sysname> display aaa online-offline-reason code 1
Code Description
1 user logoff
display domain命令用来显示所有或指定ISP域的配置信息。
display domain [ name isp-name ]
name isp-name:ISP域名,为1~255个字符的字符串,不区分大小写。如果不指定该参数,则表示所有ISP域。
若要查看ISP域中的负载分担用户组及组内用户数目信息,执行本命令时必须指定该域的名称。
# 显示系统中所有ISP域的配置信息。
<Sysname> display domain
Total 2 domains
Domain: system
Current state: Active
State configuration: Active
PPPoEA authentication scheme: None
PPPoEA authorization scheme: None
Default authentication scheme: Local
Default authorization scheme: Local
Default accounting scheme: Local
Accounting start failure action: Online
Accounting update failure action: Online
Accounting quota out policy: Offline
Send accounting update:Yes
Service type: HSI
Session time: Exclude idle time
DHCPv6-follow-IPv6CP timeout: 60 seconds
IPv6CP interface ID assignment: Enable
Dual-stack accounting method: Merge
NAS-ID: N/A
Service rate-limit mode: Separate
Web server IPv4 URL : Not configured
Track : Not configured
Web server IPv6 URL : Not configured
Web server URL parameters : Not configured
Web server IPv4 address : Not configured
Web server IPv6 address : Not configured
Secondary Web server IPv4 URL : Not configured
Secondary Web server IPv6 URL : Not configured
Secondary Web server IPv4 address : Not configured
Secondary Web server secondary IPv4 address: Not configured
Secondary Web server IPv6 address : Not configured
Secondary Web server secondary IPv6 address: Not configured
Redirect active time : Not configured
Redirect server IPv4 address : Not configured
Temporary redirect : Disabled
Redirect server IPv6 address : Not configured
Access user auto-save : Enabled
Authorization attributes:
Idle cut: Disabled
IGMP access limit: 4
MLD access limit: 4
Inbound user profile: a
Outbound user profile: b
IPv4 multicast user profile: c
IPv6 multicast user profile: d
Access limit: Not configured
Access interface VPN instance strict check: Disabled
Dynamic authorization effective attributes: Not configured
Authen-radius-unavailable: Not configured
Authen-radius-recover: Not configured
IP resource usage warning thresholds:
High threshold: Not configured
Low threshold: Not configured
IPv6 resource usage warning thresholds:
Authen-fail action: Offline
L2TP-user RADIUS-force: Disabled
IPv6 ND autoconfiguration:
Managed-address flag: Unset
Other flag : Unset
Domain: dm
State configuration: Blocked during specific time ranges
Time ranges:
t1
t2
Online-user logoff: Enabled
Login authentication scheme: RADIUS=rad
Login authorization scheme: HWTACACS=hw
Super authentication scheme: RADIUS=rad
PPP accounting scheme: RADIUS=r1, (RADIUS=r2), HWTACACS=tc, Local
Command authorization scheme: HWTACACS=hw
LAN access authentication scheme: RADIUS=r4
IPoE authentication scheme: RADIUS=rad, Local, None
PPPoEA accounting scheme: RADIUS=rad, None
Default authentication scheme: RADIUS=rad, Local, None
Default accounting scheme: None
Accounting quota out policy: Redirect
Redirect URL : http://3.3.3.3/web
Stop accounting: Yes
User profile : abc
ITA service policy: ita1
Service type: HSI
Session time: Include idle time
User basic service IP type: IPv4 IPv6 IPv6-PD
DHCPv6-follow-IPv6CP timeout: 33 seconds
Accounting start delay: 60 seconds
NAS-ID: test
Web server IPv4 URL : http://1.2.3.4
Track : 11 (Positive)
Web server IPv6 URL : http://1:2::3:4
Track : 12 (Positive)
Web server URL parameters : userurl=http://www.test.com/welcome
userip=source-address
usermac=source-mac (format: XXXX-XXXX-XXXX)
userlct=user-location (format: port:vlan1.vlan2)
Web server IPv4 address : 1.2.3.4
Redirect active time : 60 seconds
Redirect server IPv4 address : 1.1.1.2
Temporary redirect : Enabled
Redirect server IPv6 address : 1:2::3:2
Authorization attributes :
Idle cut : Enabled
Idle timeout: 2 minutes
Flow: 10240 bytes
Traffic direction: Both
IP pool: appy
User profile: test
Session group profile: abc
Inbound CAR: CIR 64000 bps PIR 640000 bps
Outbound CAR: CIR 64000 bps PIR 640000 bps
ACL number: 3000
User group: ugg
IPv6 prefix: 1::/34
IPv6 pool: ipv6pool
IPv6 ND prefix pool: rnd
Primary DNS server: 6.6.6.6
Secondary DNS server: 3.6.2.3
URL: http://abc
Redirect limit: 5
VPN instance: vpn1
IGMP access limit: 12
MLD access limit: 35
User session timeout: 28 seconds
Access limit: 400
Access interface VPN instance strict check: Enabled
CAR
URL
User group
Authen-radius-unavailable: Online domain dm2
Authen-radius-recover: Online domain dm
High threshold: 70%
Low threshold: 10%
High threshold: 70%
Low threshold: 10%
Authen-fail action: Online on domain dm1
L2TP-user RADIUS-force: Enabled
L2TP-group group-number: 1
Access limit per account (case-sensitive): 5
Authorization attributes specific to none authentication:
Managed-address flag: Set
Other flag : Unset
Default domain name: system
# 显示ISP域bbb的配置信息及负载分担用户组的信息。
<Sysname> display domain name bbb
Domain: bbb
Service type: HSI
NAS-ID: N/A
Web server secondary IPv4 address: 1.2.3.5
Secondary Web server secondary IPv4 address: 1.2.3.6
Idle cut: Disabled
MLD access limit: 4
Authen-radius-recover: Offline
Load-sharing user groups:
g1: 323 user(s)
g2: 324 user(s)
Other flag : Unset
表1-6 display domain命令显示信息描述表
Total x domains |
总计X个ISP域 |
Domain |
ISP域名 |
Current state |
ISP域的当前状态,包括以下取值: · Blocked:阻塞状态 · Active:活动状态 |
State configuration |
ISP域的状态配置,包括以下取值: · Active:活动状态 · Blocked during specific time ranges:在指定时间段处于阻塞状态 · Blocked:阻塞状态 |
Time ranges |
ISP域处于阻塞状态的时间段名称 |
Online-user logoff |
ISP域处于阻塞状态后强制在线用户下线功能的状态,包括以下取值: · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Default authentication scheme |
缺省的认证方案 |
Default authorization scheme |
缺省的授权方案 |
Default accounting scheme |
缺省的计费方案 |
Login authentication scheme |
Login用户认证方案 |
Login authorization scheme |
Login用户授权方案 |
Login accounting scheme |
Login用户计费方案 |
Super authentication scheme |
用户角色切换认证方案 |
PPP authentication scheme |
PPP用户的认证方案 |
PPP authorization scheme |
PPP用户的授权方案 |
PPP accounting scheme |
PPP用户的计费方案 |
Command authorization scheme |
命令行授权方案 |
Command accounting scheme |
命令行计费方案 |
LAN access authentication scheme |
lan-access用户认证方案 |
LAN access authorization scheme |
lan-access用户授权方案 |
LAN access accounting scheme |
lan-access用户计费方案 |
IPoE authentication scheme |
IPoE用户认证方案 |
IPoE authorization scheme |
IPoE用户授权方案 |
IPoE accounting scheme |
IPoE用户计费方案 |
PPPoEA authentication scheme |
PPPoE代拨用户认证方案 |
PPPoEA authorization scheme |
PPPoE代拨用户授权方案 |
PPPoEA accounting scheme |
PPPoE代拨用户计费方案 |
RADIUS |
RADIUS方案 |
HWTACACS |
HWTACACS方案 |
LDAP |
LDAP方案 |
Local |
本地方案 |
None |
不认证、不授权和不计费 |
Accounting start failure action |
用户计费开始失败的动作,包括以下取值: · Online:如果用户计费开始失败,则保持用户在线 · Offline:如果用户计费开始失败,则强制用户下线 |
Accounting update failure max-times |
允许用户连续计费更新失败的次数 |
Accounting update failure action |
用户计费更新失败的动作,包括以下取值: · Online:如果用户计费更新失败,则保持用户在线 · Offline:如果用户计费更新失败,则强制用户下线 |
Accounting quota out policy |
用户计费配额耗尽策略,包括以下取值: · Online:如果用户计费配额耗尽,则保持用户在线 · Offline:如果用户计费配额耗尽,则强制用户下线 · Redirect:发送重定向URL |
Redirect URL |
强制重定向的URL |
Stop accounting |
向计费服务器发送停止计费报文 |
User profile |
下发给用户的User Profile的名称 |
Send accounting update |
用户配额耗尽后是否发送获取新配额的计费更新报文: · Yes:发送 · No:不发送 |
ITA service policy |
采用的ITA业务策略 |
Service type |
ISP域的业务类型,取值为HSI,STB和VoIP |
Session time |
当用户异常下线时,设备上传到服务器的用户在线时间情况: · Include idle time:保留用户闲置切断时间 · Exclude idle time:扣除用户闲置切断时间 |
User address type |
用户地址类型 |
User basic service IP type |
用户主业务依赖的IP地址类型 · IPv4:IPv4地址类型 · IPv6:IPv6地址类型 · IPv6-PD:IPv6 PD前缀 |
DHCPv6-follow-IPv6CP timeout |
PPPoE/L2TP用户等待分配IPv6地址/PD的时间(单位为秒) |
IPv6CP interface ID assignment |
IPv6CP协商时由设备强制分配接口ID功能,包括以下取值: · Enable:处于开启状态,表示IPv6CP协商时,由BRAS强制分配接口ID,不接受用户携带的非0且不冲突接口ID · Disable:处于关闭状态,表示IPv6CP协商时接受用户携带的非0且不冲突接口ID |
Dual-stack accounting method |
双协议栈用户的计费方式,包括以下取值: · Merge:统一计费,即将双协议栈用户的IPv4流量和IPv6流量统一汇总后上送给计费服务器 · Separate:分别计费,即将双协议栈用户的IPv4流量和IPv6流量分别上送给计费服务器 |
Accounting start delay |
发送计费开始请求报文的延迟时间 若未配置,则不显示该字段 |
NAS-ID |
设备的NAS-ID 若未配置,则显示为N/A |
Service rate-limit mode |
EDSG业务流量限速模式,包括以下取值: · Merge:带内限速,即在用户可用总带宽内,对EDSG业务流量和普通业务流量同时限速,且优先保证EDSG业务带宽 · Separate:带外限速,即对EDSG业务流量进行独立限速,用户普通业务流量带宽不受影响 |
Web server IPv4 URL |
Web服务器的IPv4 URL |
Web server IPv6 URL |
Web服务器的IPv6 URL |
Track |
Web服务器URL关联的Track项的序号(Track项的状态) 若Web服务器URL未关联Track项,则显示为Not configured |
Web server URL parameters |
Web服务器的URL携带的参数信息 |
format |
携带的MAC地址格式,其中3段式和6段式的分隔符可配,取值如下三例所示: · XXXXXXXXXXXX或xxxxxxxxxxxx:1段式 · XXXX-XXXX-XXXX或xxxx-xxxx-xxxx:3段式 · XX-XX-XX-XX-XX-XX或xx-xx-xx-xx-xx-xx:6段式 |
Web server IPv4 address |
Web服务器的IPv4地址 若提供Web认证页面的服务器IPv4地址有两个,则还需要将其中一个指定为备份的IPv4地址 |
Web server secondary IPv4 address |
Web服务器备份的IPv4地址 |
Web server IPv6 address |
Web服务器的IPv6地址 若提供Web认证页面的服务器IPv6地址有两个,则还需要将其中一个指定为备份的IPv6地址 |
Web server secondary IPv6 address |
Web服务器备份的IPv6地址 |
Secondary Web server IPv4 URL |
备用Web服务器的IPv4 URL |
Secondary Web server IPv6 URL |
备用Web服务器的IPv6 URL |
Secondary Web server IPv4 address |
备用Web服务器的IPv4地址 若提供Web认证页面的服务器IPv4地址有两个,则还需要将其中一个指定为备份的IPv4地址 |
Secondary Web server secondary IPv4 address |
备用Web服务器备份的IPv4地址 |
Secondary Web server IPv6 address |
备用Web服务器的IPv6地址 若提供Web认证页面的服务器IPv6地址有两个,则还需要将其中一个指定为备份的IPv6地址 |
Secondary Web server secondary IPv6 address |
备用Web服务器备份的IPv6地址 |
Redirect active time |
推送Web重定向URL的有效时长,单位为秒 |
Redirect server IPv4 address |
Web重定向页面的服务器IPv4地址 |
Temporary redirect |
临时重定向功能,包括以下取值: · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Redirect server IPv6 address |
Web重定向页面的服务器IPv6地址 |
Access user auto-save |
DHCP用户信息自动备份功能 · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Authorization attributes |
ISP的用户授权属性 |
Idle cut |
用户闲置切断功能,包括以下取值: · Enabled:处于开启状态,表示当ISP域中的用户在指定的最大闲置切断时间内产生的流量小于指定的最小数据流量时,会被强制下线 · Disabled:处于关闭状态,表示不对用户进行闲置切断控制,它为缺省状态 |
Idle timeout |
用户闲置切断时间(单位为分钟) |
Flow |
用户数据流量阈值(单位为字节) |
Traffic direction |
用户数据流量的统计方向,包括以下取值: · Both:表示用户双向数据流量 · Inbound:表示用户上行数据流量 · Outbound:表示用户下行数据流量 |
IP pool |
授权IPv4地址池的名称 |
IP pool group |
授权IPv4地址池组的名称 |
Inbound user profile |
授权入方向的User Profile名称 |
Outbound user profile |
授权出方向的User Profile名称 |
User profile |
授权User Profile的名称 |
IPv4 multicast user profile |
授权IPv4可控组播的User Profile名称 |
IPv6 multicast user profile |
授权IPv6可控组播的User Profile名称 |
Session group profile |
授权Session Group Profile的名称 |
Inbound CAR |
授权的入方向CAR(CIR:承诺信息速率,单位为bps;PIR:峰值信息速率,单位为bps)。若未授权入方向CAR,则显示为N/A |
Outbound CAR |
授权的出方向CAR(CIR:承诺信息速率,单位为bps;PIR:峰值信息速率,单位为bps)。若未授权出方向CAR,则显示为N/A |
ACL number |
授权ACL编号 |
User group |
授权User group的名称 |
IPv6 prefix |
授权IPv6前缀 |
IPv6 pool |
授权IPv6地址池的名称 |
IPv6 pool group |
授权IPv6地址池组的名称 |
IPv6 ND prefix pool |
授权ND前缀池的名称 |
IPv6 ND prefix pool group |
授权ND前缀池组的名称 |
Primary DNS server |
授权主DNS服务器IPv4地址 |
Secondary DNS server |
授权从DNS服务器IPv4地址 |
Primary DNSV6 server |
授权主DNS服务器IPv6地址 |
Secondary DNSV6 server |
授权从DNS服务器IPv6地址 |
URL |
授权重定向URL |
Redirect limit |
最大重定向次数,若不限制次数,则显示为Unlimited |
VPN instance |
授权VPN实例名称 |
IGMP access limit |
授权IPv4用户可以同时点播的最大节目数 |
MLD access limit |
授权IPv6用户可以同时点播的最大节目数 |
Inbound user priority |
授权上行用户优先级 |
Outbound user priority |
授权下行用户优先级 |
User session timeout |
授权用户会话超时时间,单位为秒 |
Access limit |
允许接入的最大用户数 |
Access interface VPN instance strict check |
对用户上线接口的VPN配置进行严格一致性检查功能,包括以下取值: · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Dynamic authorization effective attributes |
通过COA授权该域时需要生效的授权属性 |
Authen-radius-unavailable |
RADIUS认证服务器不可达时,用户的逃生域 |
Authen-radius-recover |
逃生域中的用户,在RADIUS认证服务器恢复可达后,采取的策略,包括以下取值: · Offline:直接下线 · Online domain isp-name:保持在线,且用户切换到逃生恢复域isp-name |
IP resource usage warning thresholds |
授权IPv4地址池/IPv4地址池组的地址使用率告警阈值 |
IPv6 resource usage warning thresholds |
授权IPv6地址和前缀使用率告警阈值 |
High threshold |
告警上限阈值。若未配置,则显示为Not configured |
Low threshold |
告警下限阈值。若未配置,则显示为Not configured |
Load-sharing user groups |
负载分担用户组及组内用户数目 |
User group and NAT instance bindings |
负载分担用户组(组内用户数目)以及当前该组绑定的NAT实例 |
Authen-fail action |
用户认证失败后采取的策略,包括以下取值: · Offline:直接下线 · Online on domain isp-name:保持在线,且采用指定的域重新进行认证/授权/计费 |
L2TP-user RADIUS-force |
RADIUS服务器授权L2TP用户功能,包括以下取值: · Enabled:处于开启状态,完全由RADIUS服务器决定用户是否为L2TP用户 · Disabled:处于关闭状态 |
L2TP-group group-number |
当前ISP域下L2TP用户使用的L2TP组号 |
L2TP-group group-name |
当前ISP域下L2TP用户使用的L2TP组名称 |
Access limit per account (case-sensitive) |
单个帐号允许接入的最大用户数(用户名区分大小写) |
Access limit per account (case-insensitive) |
单个帐号允许接入的最大用户数(用户名不区分大小写) |
Authorization attributes specific to none authentication |
采用none认证方法时的用户授权属性 |
IPv6 ND autoconfiguration |
RA消息中的自动配置标志位状态 |
Managed-address flag |
被管理地址的配置标志位: · Set:主机通过有状态自动配置(例如DHCPv6服务器)获取IPv6地址 · Unset:主机可以通过无状态或有状态自动配置获取IPv6地址 |
Other flag |
其他信息配置标志位 · Set:主机通过有状态自动配置(例如DHCPv6服务器)获取除IPv6地址外的其他信息 · Unset:主机可以通过无状态或有状态自动配置获取其他信息 |
Default domain name |
缺省ISP域名 |
display domain access-user statistics命令用来显示ISP域的在线接入用户统计信息。
display domain [ name isp-name ] access-user statistics
目前仅支持对PPP、IPoE接入类型在线用户的计数信息进行详细统计。
对于有增值业务的用户,比如EDSG、ITA业务,系统会采用独立的业务会话标识对这些业务流量进行独立的认证、授权、计费,但此类增值业务的会话数目并不会被本命令视为用户数目进行统计。
# 显示所有ISP域中的在线接入用户统计信息。
<Sysname> display domain access-user statistics
Total online access users: 20
IPoE users: 8
PPP users: 8
Others: 4
Total domains: 3
Domain State Online user count
system Active 15
isp1 Active 0
isp2 Active 5
Domain: system
IPoE users: 3 (Bind 0, Pre-auth 0, Web 0, 802.1X 0, Leased 3)
PPP users: 8 (PPPoE 4, PPPoA 2, PPPoFR 0, LAC 0, LNS 2, PPPoEA 0)
Others: 4
Domain: isp2
IPoE users: 5 (Bind 0, Pre-auth 0, Web 0, 802.1X 0, Leased 5)
PPP users: 0
Others: 0
# 显示ISP域isp2中的在线接入用户统计信息。
<Sysname> display domain name isp2 access-user statistics
Domain: isp2
Online user count: 5
PPP users: 0
Others: 0
表1-7 display domain access-user statistics命令显示信息描述表
Total online access users |
在线用户总数,其中包括以下接入用户类型: · IPoE users:IPoe在线用户数 · PPP users::PPP在线用户数 · Others:其它接入在线用户数 |
Total domains |
ISP域的数目 |
Domain |
ISP域的名称 |
State |
Online user count |
在线用户数 |
IPoE users |
IPoE接入用户,包括以下类型: · Bind:绑定认证方式的IPoE接入用户 · Pre-auth:Web认证或IPoE 802.1X认证前域用户 · Web:Web认证方式的IPoE接入用户 · 802.1X认证方式的IPoE接入用户 · Leased:IPoE专线用户 |
PPP users |
PPP接入用户,包括以下类型: · PPPoE:PPPoE接入用户 · PPPoA:PPP over ATM接入用户 · PPPoFR:PPP over FR接入用户 · LAC:LAC上的L2TP接入用户 · LNS:LNS上的L2TP接入用户 · PPPoEA:PPPoE代拨接入用户 |
Others |
其它接入用户 |
· ppp account-statistics enable(BRAS业务分册命令参考/PPP)
domain命令用来创建ISP域,并进入ISP域视图。如果指定的ISP域已经存在,则直接进入ISP域视图。
undo domain命令用来删除指定的ISP域。
domain name isp-name
undo domain name isp-name
存在一个ISP域,名称为system。
name isp-name:ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符。
所有的ISP域在创建后即处于active状态。
不能删除系统中预定义的ISP域system,只能修改该域的配置。
不能删除作为系统缺省ISP域的ISP域。如需删除一个系统缺省ISP域,请先使用undo domain default enable命令将其恢复为非缺省的ISP域。
建议设备上配置的ISP域名尽量短,避免用户输入的包含域名的用户名长度超过客户端可支持的最大用户名长度。用户名长度不超过253字符的ISP域名才能生效。
不能通过undo domain name命令直接删除被接口视图下的aaa default-domain、aaa permit-domain、aaa deny-domain、aaa roam-domain命令指定的ISP域。如需删除该域,请先在接口视图下使用对应的undo命令取消对它的引用。
ISP域中有在线用户时,不能通过undo domain name命令直接删除该域。
# 创建一个名称为test的ISP域,并进入其视图。
[Sysname] domain name test
· aaa default-domain
· aaa deny-domain
· aaa permit-domain
· aaa roam-domain
· display domain
· domain default enable
· domain if-unknown
· state (ISP domain view)
domain default enable命令用来配置系统缺省的ISP域,所有在登录时没有提供ISP域名的用户都属于这个域。
undo domain default enable命令用来恢复缺省情况。
domain default enable isp-name
存在一个系统缺省的ISP域,名称为system。
isp-name:ISP域名,为1~255个字符的字符串,不区分大小写,且必须已经存在。
系统中只能存在一个缺省的ISP域。
配置为缺省的ISP域不能被删除。如需删除一个系统缺省ISP域,请先使用undo domain default enable命令将其恢复为非缺省的ISP域。
# 创建一个新的ISP域test,并设置为系统缺省的ISP域。
[Sysname-isp-test] quit
[Sysname] domain default enable test
· display domain
· domain
domain if-unknown命令用来为未知域名的用户指定ISP域。
undo domain if-unknown命令用来恢复缺省情况。
domain if-unknown isp-name
没有为未知域名的用户指定ISP域。
isp-name:ISP域名。为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符。
用户认证时,设备将按照一定的规则为用户选择认证域,详情请见“BRAS业务指导”中的“AAA”。
如果系统为用户选择的认证域在设备上不存在,但设备上为未知域名的用户指定了ISP域,则使用该指定的ISP域认证,否则,用户将无法认证。
# 为未知域名的用户指定ISP域为test。
[Sysname] domain if-unknown test
· display domain
dynamic-authorization effective-attribute命令用来指定用户切换域后需要生效的授权属性。
undo dynamic-authorization effective-attribute命令用来恢复缺省情况。
dynamic-authorization effective-attribute { car | session-group-profile | session-timeout | url | user-group | user-priority | user-profile | web-server } *
undo dynamic-authorization effective-attribute { car | session-group-profile | session-timeout | url | user-group | user-priority | user-profile | web-server } *
未指定用户切换域后需要生效的授权属性。
ISP域视图
car:指定ISP域下配置的CAR授权属性。
session-group-profile:指定ISP域下配置的Session Group Profile授权属性。
session-timeout:指定ISP域下配置的用户的会话超时时间授权属性。
url:指定ISP域下配置的重定向URL授权属性。
user-group:指定ISP域下配置的用户组授权属性。
user-priority:指定ISP域下配置的用户优先级授权属性。
user-profile:指定ISP域下配置的User Profile授权属性。
web-server:重定向Web服务器授权属性,包括重定向给用户的Web服务器的IP地址、Web服务器的URL以及URL中携带的参数信息。
本特性仅对IPoE用户生效。
如下用户所在域发生切换的场景下,若希望对用户重新授权,则需要指定新域中可生效的授权属性:
· 认证服务器恢复可达时用户进入到新域
逃生用户在原认证域的RADIUS认证服务器恢复可达后进入到指定的逃生恢复域时,如果希望用户在逃生恢复域中获取一定的授权属性,则需要在逃生恢复域下执行dynamic-authorization effect-attribute命令指定要生效的授权属性。
· 用户业务发生切换时服务器下发新域
设备上开启RADIUS DAE服务后,设备将在指定的UDP端口监听指定的RADIUS服务器发送的COA(Change of Authorization)请求消息,根据请求消息查找用户,进行用户授权信息的修改。若服务器通过COA下发新的授权域来修改在线用户的访问权限,则需要在该授权域下执行dynamic-authorization effect-attribute命令指定要生效的授权属性。
这些要生效的授权属性取值由该域下的authorization-attribute以及web-server { ip | ipv6 }、web-server { url | ipv6-url }、web-server url-parameter命令指定。
如果以上场景下的新域中未指定任何要生效的授权属性,则:
· 对于进入到逃生恢复域中的用户,将没有授权属性。
· 对于通过COA授权新域的用户,其授权属性将保持之前所在域的状态。
如果通过COA授权的新域中指定了要生效的属性,则用户的这些授权属性状态会发生相应的变化:
· 如果服务器没有通过COA授权这些属性,则新域中指定的属性将以域中设置的授权属性值生效。如果域中未设置该授权值,则该授权属性保持之前所在域的状态。
· 只要服务器通过COA授权了某属性,则服务器授权的属性值将优先于指定的授权属性值生效。
需要注意的是,对于授权属性user-group,设备基于用户所属的NAT实例查询新域中与之绑定的负载分担用户组进行授权:
· 如果新域下查询到该NAT实例绑定的负载分担用户组,则授权该用户组;若未查询到该NAT实例绑定的负载分担用户组,则不授权用户组。
· 如果用户没有所属的NAT实例,则采用新域中设置的负载分担用户组(通过load-sharing user-group命令设置)。若新域中没有设置负载分担用户组,则采用该域中设置的授权用户组。
每次执行本命令均可以指定多个授权属性,多次执行本命令后最终需要生效的属性为所有已指定属性的合集。
# 在ISP域test下,指定用户切换域后需要生效的授权属性为user-group。
[Sysname-isp-test] dynamic-authorization effective-attribute user-group
· authorization-attribute
· display domain
· web-server { ip | ipv6 }
· web-server url
· web-server url-parameter
ip-usage-warning命令用来配置授权IPv4地址使用率告警阈值。
undo ip-usage-warning命令用来取消指定的授权IPv4地址使用率告警阈值设置。
ip-usage-warning { high-threshold high-value | low-threshold low-value }
undo ip-usage-warning { high-threshold | low-threshold }
未设置授权IPv4地址使用率告警阈值,系统不会对该域的授权IPv4地址池/IPv4地址池组中的地址使用情况进行告警。
ISP域视图
high-threshold high-value:授权IPv4地址使用率告警上限阈值,取值范围1~100,单位为百分比,且必须大于使用率告警下限阈值。
low-threshold low-value:授权IPv4地址使用率告警下限阈值,取值范围0~99,单位为百分比。
如果域下配置了授权IPv4地址池/IPv4地址池组,则可以通过配置该域的IPv4地址使用率告警阈值并开启相应的告警功能,实现基于域对授权IPv4地址池/IPv4地址池使用率事件的监控。具体实现为,DHCP模块会定期检查该授权IPv4地址池/IPv4地址池组的地址使用率,并在下述情况下输出相应的告警信息和日志信息:
· 若IPv4地址使用率首次达到或超过告警上限阈值,则触发一次上限告警。之后,当IPv4地址使用率<=(上限阈值–告警差值)时,触发一次上限恢复告警。
· 若IPv4地址使用率首次达到或低于告警下限阈值,则触发一次下限告警。之后,当IPv4地址使用率>=(下限阈值+告警差值)时,触发一次下限恢复告警。
其中,告警差值=(上限阈值–下限阈值)*10%。如果仅配置了上限阈值,则计算告警差值时下限阈值取值为0;如果仅配置了下限阈值,则计算告警差值时上限阈值取值为100。
假设,告警上限阈值设置为70,告警下限阈值设置为20,则告警差值为(70-20)*10%=5。因此,当授权IP地址使用率首次达到或超过70%时,触发一次上限告警,当使用率恢复到65%或者更低时,触发一次上限恢复告警;当域中的授权IP地址使用率首次达到或低于20%时,触发一次下限告警,当使用率恢复到25%或者更高时,触发一次下限恢复告警。
首次触发上限或下限告警后,若配置不发生变化,且使用率并未恢复,则不再重复触发告警。当如下配置发生变化时,告警的生成会发生相应的变化:
· 取消域下的某授权IPv4地址使用率告警阈值配置后,如果此前已经触发过相应的告警且使用率并未恢复,则在DHCP模块再次检查地址使用率时触发一次恢复告警,否则不会触发任何告警。
· 修改域下的授权IPv4地址使用率告警阈值配置、修改域引用的授权IPv4地址池/IPv4地址池组或者修改引用的授权IPv4地址池/IPv4地址池组中的配置后,DHCP模块再次检查地址使用率时,将使用修改后的配置判断是否触发告警。
域下的授权IPv4地址池通过authorization-attribute ip-pool命令配置,授权IPv4地址池组通过authorization-attribute ip-pool-group命令配置。
需要注意的是,本特性针对的授权IPv4地址必须为最终通过DHCP地址池分配的IPv4地址。
域下的授权IPv4地址使用率告警功能通过snmp-agent trap enable domain ip-pool-warning命令开启。
# 在ISP域test下,配置授权IPv4地址使用率告警上限阈值为70%、下限阈值为20%。
[Sysname-isp-test] ip-usage-warning high-threshold 70
[Sysname-isp-test] ip-usage-warning low-threshold 20
· authorization-attribute (ISP domain)
· display domain
· snmp-agent trap enable domain
ipv6 nd autoconfig managed-address-flag命令用来配置RA消息中的被管理地址的配置标志位为1,即主机通过有状态自动配置(例如DHCPv6服务器)获取IPv6地址。
undo ipv6 nd autoconfig managed-address-flag命令用来恢复缺省情况。
被管理地址的配置标志位为0,即主机通过无状态自动配置获取IPv6地址。
ISP域视图
可以根据实际情况,配置通告给主机的RA消息中的相关参数。当主机接收到RA消息后,就可以采用这些参数进行相应操作。
RA消息中的被管理地址配置标志位(M flag)用于确定主机是否采用有状态自动配置获取IPv6地址:
· 如果设置该标志位为1,主机将通过有状态自动配置(例如DHCPv6服务器)来获取IPv6地址。
· 如果设置该标志位为0,则主机将通过无状态自动配置获取IPv6地址。
需要注意的是,ISP域下的本配置只针对于PPP用户生效。
PPP用户对应的VT接口视图下也可以配置ipv6 nd autoconfig managed-address-flag命令,只要域视图或接口视图下配置了ipv6 nd autoconfig managed-address-flag命令,则通告给用户的RA消息中被管理地址配置标志位就为1。
# 在ISP域test下,配置主机通过有状态自动配置(例如DHCPv6服务器)获取IPv6地址。
[Sysname-isp-test] ipv6 nd autoconfig managed-address-flag
· ipv6 nd autoconfig managed-address-flag(三层技术-IP业务命令参考/IPv6基础)
ipv6 nd autoconfig other-flag命令用来配置RA消息中的其他信息配置标志位为1,即主机通过有状态自动配置(例如DHCPv6服务器)获取除IPv6地址外的其他信息。
undo ipv6 nd autoconfig other-flag命令用来恢复该缺省情况。
其他信息配置标志位为0,即主机通过无状态自动配置获取其他信息。
ISP域视图
RA消息中的其他信息配置标志位(O flag)用于确定主机是否采用有状态自动配置获取除IPv6地址外的其他信息:
· 如果设置该标志位为1,主机将通过有状态自动配置(例如DHCPv6服务器)来获取除IPv6地址外的其他信息。
· 如果设置该标志位为0,则主机将通过无状态自动配置获取其他信息。
PPP用户对应的VT接口视图下也可以配置ipv6 nd autoconfig other-flag命令,只要域视图或接口视图下配置了ipv6 nd autoconfig other-flag命令,则通告给用户的RA消息中其他信息配置标志位就为1。
# 在ISP域test下,配置主机通过有状态自动配置(例如DHCPv6服务器)获取除IPv6地址外的其他信息。
[Sysname-isp-test] ipv6 nd autoconfig other-flag
· ipv6 nd autoconfig other-flag(三层技术-IP业务命令参考/IPv6基础)
ipv6-usage-warning命令用来配置授权IPv6地址和前缀使用率告警阈值。
undo ipv6-usage-warning命令用来取消指定的授权IPv6地址和前缀使用率告警阈值设置。
ipv6-usage-warning { high-threshold high-value | low-threshold low-value }
undo ipv6-usage-warning { high-threshold | low-threshold }
未设置授权IPv6地址和前缀使用率告警阈值,系统不会对该域的授权IPv6地址池/IPv6地址池组/ND前缀地址池/ND前缀地址池组中的IPv6地址及前缀使用情况进行告警。
ISP域视图
high-threshold high-value:授权IPv6地址和前缀使用率告警上限阈值,取值范围1~100,单位为百分比,且必须大于使用率告警下限阈值。
low-threshold low-value:授权IPv6地址和前缀使用率告警下限阈值,取值范围0~99,单位为百分比。
如果域下配置了授权IPv6地址池/IPv6地址池组/ND前缀地址池/ND前缀地址池组,则可以通过配置该域的IPv6地址和前缀使用率告警阈值并开启相应的告警功能,实现基于域对授权IPv6地址池/IPv6地址池组/ND前缀地址池/ND前缀地址池组使用率事件的监控。具体实现为,DHCP模块会定期检查该授权IPv6地址池/IPv6地址池组/ND前缀地址池/ND前缀地址池组的IPv6地址和前缀使用率,在下述情况下输出相应的告警信息和日志信息:
· 若IPv6地址或前缀使用率首次达到或超过告警上限阈值,则触发一次上限告警。之后,当IPv6地址或前缀使用率<=(上限阈值–告警差值)时,触发一次上限恢复告警。
· 若IPv6地址或前缀使用率首次达到或低于告警下限阈值,则触发一次下限告警。之后,当IPv6地址或前缀使用率>=(下限阈值+告警差值)时,触发一次下限恢复告警。
假设,告警上限阈值设置为70,告警下限阈值设置为20,则告警差值为(70-20)*10%=5。因此,当授权IPv6地址和前缀使用率首次达到或超过70%时,触发一次上限告警,当使用率恢复到65%或者更低时,触发一次上限恢复告警;当域中的授权IPv6地址和前缀使用率首次达到或低于20%时,触发一次下限告警,当使用率恢复到25%或者更高时,触发一次下限恢复告警。
· 取消域下的某授权IPv6地址和前缀使用率告警阈值配置后,如果此前已经触发过相应的告警且使用率并未恢复,则会触发一次恢复告警,否则不会触发任何告警。
· 修改域下的授权IPv6地址和前缀使用率告警阈值配置、修改域引用的授权IPv6地址池/IPv6地址池组/ND前缀地址池/ND前缀地址池组或者修改引用的IPv6地址池/IPv6地址池组/ND前缀地址池/ND前缀地址池组中的配置后,DHCP模块再次检查地址使用率时,将使用修改后的配置判断是否触发告警。
域下的授权IPv6地址池通过authorization-attribute ipv6-pool命令配置;域下的授权前缀池通过authorization-attribute ipv6-nd-prefix-pool命令配置;域下的授权IPv6地址池组通过authorization-attribute ipv6-pool-group命令配置;域下的授权前缀池组通过authorization-attribute ipv6-nd-prefix-pool-group命令配置。
域下的授权IPv6地址和前缀使用率告警功能通过snmp-agent trap enable domain ipv6-pool-warning命令开启。
# 在ISP域test下,配置授权IPv6地址和前缀使用率告警上限阈值为70%、下限阈值为20%。
[Sysname-isp-test] ipv6-usage-warning high-threshold 70
[Sysname-isp-test] ipv6-usage-warning low-threshold 20
· display domain
ipv6cp assign-interface-id命令用来配置IPv6CP协商时,由设备强制为PPP用户分配接口ID,不接受用户报文携带的非0且不冲突接口ID。
undo ipv6cp assign-interface-id命令用来恢复缺省情况。
IPv6CP协商时接受用户报文携带的非0且不冲突接口ID。
ISP域视图
缺省情况下,如果RADIUS服务器通过Framed-Interface-Id属性向PPP用户授权接口ID(Interface-Identifier),该用户就必须采用RADIUS服务器授权的接口ID;如果RADIUS服务器没有给PPP用户授权接口ID,且用户的Configure-Request报文中携带了非0且不冲突的接口ID,则该用户将使用自带的接口ID。当RADIUS服务器未给PPP用户授权接口ID,且用户报文中也未携带接口ID时,由设备自动为该PPP用户生成一个接口ID。
配置ipv6cp assign-interface-id命令后,PPP用户进行IPv6CP协商时,设备将忽略用户报文中携带的接口ID。若RADIUS服务器授权了接口ID,则采用RADIUS服务器授权的接口ID;若RADIUS服务器没有授权接口ID,则由设备自动为其生成一个接口ID。通常,如果网络运营商希望对PPP用户的接口ID统一管理,建议配置本命令。
# 在ISP域test下,配置IPv6CP协商时由设备强制为PPP用户分配接口ID。
[System] domain name test
[System-isp-test] ipv6cp assign-interface-id
· display domain
ita-policy命令用来指定当前ISP域采用的ITA业务策略。
undo ita-policy命令用来恢复缺省情况。
ita-policy policy-name
undo ita-policy
当前ISP域中未采用ITA业务策略。
ISP域视图
service-policy-name:ITA业务策略名称,由1~31个字符组成,不区分大小写。
当RADIUS服务器为当前用户动态授权了ITA业务策略时,将使用RADIUS服务器授权的ITA业务策略,否则使用用户认证域中指定的ITA业务策略。
若RADIUS服务器为当前用户授权了ITA业务策略,但该策略在设备上不存在,则即使认证域中指定了ITA业务策略且存在,设备也不会对该用户进行ITA业务计费。
若RADIUS服务器为当前用户授权了EDSG业务策略但未授权ITA业务策略,则认证域中指定的ITA业务策略将不会生效。
# 在ISP域test中,指定采用ITA业务策略ita1。
[Sysname-isp-test] ita-policy ita1
· ita policy
l2tp-group命令用来指定当前ISP域下L2TP用户使用的L2TP组。
undo l2tp-group命令用来恢复缺省情况。
l2tp-group { group-name group-name | group-number group-number }
undo l2tp-group
当前ISP域下未指定L2TP用户使用的L2TP组。
ISP域视图
group-name group-name:L2TP组名,为1~32个字符的字符串,不区分大小写。
group-number group-number:L2TP组号,取值范围为1~65535。
本配置仅对PPP接入用户生效。
当网络管理员希望由RADIUS服务器强制授权L2TP用户时,为了避免因服务器授权的L2TP隧道相关属性不完备而无法成功建立L2TP隧道,建议通过本配置在域下指定用户使用的L2TP组。同时,还可以通过将多个ISP域同时关联到同一个L2TP组上简化L2TP配置。
若ISP域下配置了l2tp-user radius-force命令,当RADIUS服务器下发的L2TP属性不完备时,设备将按照如下原则为授权的L2TP用户选择用于建立L2TP隧道的L2TP属性:
· RADIUS服务器授权的L2TP组(通过183号属性H3C-Tunnel-Group-Name下发)。
· 域视图下指定的L2TP组(通过l2tp-group命令配置)。
· 根据用户名或域名匹配到系统视图下配置的L2TP组(通过l2tp-group命令配置)
· 系统视图下配置的缺省L2TP组(通过系统视图下的l2tp-group命令和L2TP组视图下的default-lac-group enable命令配置)
一个ISP域下只支持配置一个L2TP组,要么通过group-number指定,要么通过group-name指定,即l2tp-group group-number和l2tp-group group-name配置相互覆盖。
修改或删除ISP域下指定的l2tp-group组,对已基于此组建立的L2TP隧道无影响。
# 在ISP域test下,指定L2TP用户使用L2TP组1。
[Sysname-isp-test] l2tp-group group-number 1
· display domain
· l2tp-user radius-force
l2tp-user radius-force命令用来开启RADIUS服务器授权L2TP用户功能,即由RADIUS服务器来决定该用户是否为作为L2TP用户。
undo l2tp-user radius-force命令用来关闭RADIUS服务器授权L2TP用户功能。
RADIUS服务器授权L2TP用户功能处于关闭状态。
ISP域视图
本配置仅对PPP接入用户生效。
缺省情况下,PPP用户认证成功后,可以由设备上的L2TP配置或RADIUS服务器授权来决定该用户是否作为L2TP用户进行后续的L2TP处理,以及决定建立L2TP隧道使用的相关属性参数。其中,服务器的授权优先级高。
如果网络管理员希望仅由RADIUS服务器来决定该用户是否为作为L2TP用户,则需要在用户认证域下开启RADIUS服务器授权L2TP用户功能。开启本功能后,若RADIUS服务器通过64号标准属性为用户下发了隧道类型L2TP,则表示该用户为L2TP用户,且需要进行后续的L2TP处理。该功能可以实现对L2TP用户的集中授权,以及多域L2TP隧道参数的统一规划。
ISP域下开启了RADIUS服务器授权L2TP用户功能后,被授权的L2TP用户将优先使用服务器授权的L2TP隧道相关属性建立L2TP隧道。当RADIUS服务器下发的L2TP属性不完备时,设备将从RADIUS服务器授权的L2TP组(通过183号私有属性Tunnel-Group-Name下发)或用户认证域下指定的L2TP组中获取其它的L2TP属性,并使用这些属性建立L2TP隧道。其中,服务器授权下发的L2TP组的优先级高于ISP域下指定L2TP组。如果RADIUS服务器既未授权L2TP组,域下也未指定L2TP组,则该用户上线失败。关于L2TP组及相关L2TP隧道属性的具体介绍,请参见“BRAS业务命令参考”中的“L2TP”。
若ISP域下未开启RADIUS服务器授权L2TP用户功能,但设备上开启了L2TP功能,则只要存在如下情况之一,PPP用户也可被判定为L2TP用户:
(1) RADIUS服务器为其授权了L2TP组。
(2) 认证域下指定了L2TP组(通过l2tp-group命令)。
(3) 用户的完整用户名或认证域匹配上了本地某L2TP组中设置的隧道建立触发条件。
判定成功之后,L2TP用户将获取所需的L2TP属性来建立L2TP隧道,属性获取方式优先级从高到低依次为:RADIUS服务器授权的L2TP属性->RADIUS授权的L2TP组->认证域下指定的L2TP组->触发条件匹配上的L2TP组。
# 在ISP域test下,开启RADIUS服务器授权L2TP用户功能。
[Sysname-isp-test] l2tp-user radius-force
· display domain
· l2tp-group
load-sharing user-group命令用来配置负载分担用户组,且开启用户组负载分担功能。
undo load-sharing user-group命令用来删除配置的负载分担用户组。
load-sharing user-group group-name
undo load-sharing user-group [ group-name ]
未配置负载分担用户组,用户组负载分担功能处于关闭状态。
ISP域视图
group-name:指定用户组名,为1~32个字符的字符串,不区分大小写。指定的用户组必须已经存在,否则负载分担用户组的配置不生效。undo命令中若不指定该参数,则表示删除所有配置的负载分担用户组。
在一个ISP域视图下,将任意一个用户组配置为负载分担用户组后,该域的用户组负载分担功能将处于开启状态。一个ISP域中,可以配置多个负载分担用户组,采用该域认证上线的用户,将会加入到当前用户数最少的负载分担用户组中。如果当前用户数最少的负载分担用户组存在多个,则将用户加入其中最先配置的用户负载分担组中。
负载分担用户组用于配合业务模块实现分担用户业务流量的目的。
本用户组负载分担功能与NAT业务配合时,仅适用于基于接口配置NAT的组网环境中。
一个ISP域视图下最多配置32个负载分担用户组。
用户最终加入的用户组与实际配置相关,各类型用户组的生效先后顺序依次为:服务器下发的授权用户组、ISP域中配置的负载分担用户组、ISP中配置的授权用户组。
# 在ISP域视图test下,配置用户组g1和g2为负载分担用户组。
[Sysname-isp-test] load-sharing user-group g1
[Sysname-isp-test] load-sharing user-group g2
· display domain
· user-group
local-server log change-password-prompt命令用来开启密码修改周期性提醒日志功能。
undo local-server log change-password-prompt命令用来关闭密码修改周期性提醒日志功能。
密码修改周期性提醒日志功能处于开启状态。
为了提高系统的安全性,用户通过Telnet、SSH、NETCONF over SSH、NETCONF over SOAP方式登录设备时,系统会根据指定的安全要求对用户密码进行检查。为了及时提醒用户修改不符合系统要求的密码,建议开启密码修改周期性提醒日志功能。
开启本功能后,系统将每隔24小时,对所有不符合密码检查策略的用户打印日志,提醒这些用户尽快修改当前密码。除了周期性提醒之外,系统还会在每个用户登录时,针对不符合密码检查策略的情况立即打印日志进行提醒。
· 对于通过Telnet、SSH方式登录设备的用户,如果用户密码为弱密码,且系统在用户登录时未要求其立即更改密码,系统会打印此提醒日志。弱密码是指不符合如下任意一项要求的密码:
¡ 密码组合检测策略。
¡ 密码最小长度限制。
¡ 密码复杂度检查策略。
· 对于通过NETCONF over SSH、NETCONF over SOAP方式登录设备的用户,如果出现以下情况,系统会打印此提醒日志:
¡ 用户密码为弱密码。
¡ 全局密码管理功能开启后,用户首次登录或使用被更改过的密码。
¡ 用户密码已经过期。
仅当以下情况发生时,系统才会停止打印此提醒日志:
· 关闭了密码修改周期性提醒日志功能。
· 用户密码修改为符合系统安全要求的密码。
· 密码检查策略相关功能的开启状态发生变化,使得密码检查策略变得宽松。
· 密码检查策略的参数设置发生变化。
当前系统中的密码检查策略可通过display password-control命令查看。弱密码检查使用的密码组合检测策略、密码最小长度限制、密码复杂度检查策略可分别通过password-control composition、password-control length、password-control complexity命令修改。关于密码检查策略的具体介绍,请参见“安全命令参考”的“Password Control”。
# 开启密码修改周期性提醒日志功能。
[Sysname] local-server log change-password-prompt
· display password-control(安全命令参考/Password Control)
· password-control composition(安全命令参考/Password Control)
· password-control length(安全命令参考/Password Control)
nas-id命令用来在ISP域视图下配置NAS-ID。
undo nas-id命令用来删除ISP域视图下配置的NAS-ID。
nas-id nas-identifier
undo nas-id
未配置ISP域下的NAS-ID。
ISP域视图
nas-identifier:NAS-ID名称,为1~253个字符的字符串,区分大小写。
用户进行RADIUS认证时,系统会获取设备的NAS-ID来设置RADIUS报文中的NAS-Identifier属性,该属性用于向RADIUS服务器标识用户的接入位置。
设备支持多种途径配置NAS-ID,按照获取优先级从高到低的顺序依次包括:NAS-ID Profile中与用户接入VLAN绑定的NAS-ID、接口视图下的NAS-ID、ISP域视图下的NAS-ID。其中,接口视图下配置的NAS-ID仅对PPP和IPoE用户有效。若以上配置都不存在,则使用设备的名称作为NAS-ID。
# 在ISP域test下配置NAS-ID为test。
[Sysname-isp-test] nas-id test
· aaa nas-id
· aaa nas-id profile(BRAS业务命令参考/AAA)
nas-id bind命令用来设置NAS-ID与VLAN的绑定关系。
undo nas-id bind命令用来删除指定的NAS-ID和VLAN的绑定关系。
nas-id nas-identifier bind { { c-vid vlan-id | s-vid vlan-id } * | vlan vlan-id }
undo nas-id nas-identifier bind { { c-vid vlan-id | s-vid vlan-id } * | vlan vlan-id }
不存在NAS-ID与VLAN的绑定关系。
NAS-ID Profile视图
c-vid vlan-id:与NAS-ID绑定的内层VLAN标签(Customer VLAN ID),取值范围为1~4094。
s-vid vlan-id:与NAS-ID绑定的外层VLAN标签(Service VLAN ID),取值范围为1~4094。
vlan vlan-id:与NAS-ID绑定的VLAN ID,取值范围为1~4094。
一个NAS-ID Profile视图下,可以指定多个NAS-ID与VLAN的绑定关系。
QinQ组网情况下,建议指定s-vid和c-vid参数或两者之一;非QinQ组网情况下,只能指定vlan参数。
指定了s-vid或c-vid参数的NAS-ID Profile,仅能与aaa nas-id-profile命令配合使用。
一个NAS-ID可以与多个VLAN或多个内层VLAN和外层VLAN的组合绑定,但是一个VLAN或一个内层VLAN和外层VLAN的组合只能与一个NAS-ID绑定。若多次将一个VLAN或一个内层VLAN和外层VLAN的组合与不同的NAS-ID进行绑定,则最后的绑定关系生效。
若报文中携带了双层VLAN标签,则优先匹配与s-vid和c-vid参数同时绑定的NAS-ID,其次匹配仅与s-vid参数绑定的NAS-ID,最后尝试匹配与c-vid参数绑定的NAS-ID。
# 在名称为aaa的NAS-ID Profile视图下,配置NAS-ID 222与VLAN 2的绑定关系。
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa] nas-id 222 bind vlan 2
redirect active-time命令用来配置推送Web重定向URL的有效时长。
undo redirect active-time命令用来恢复缺省情况。
redirect active-time time
未配置推送Web重定向URL的有效时长。
ISP域视图
time:向用户推送Web重定向URL的有效时长,取值范围为1~900,单位为秒。
用户认证成功后首次访问网络时,服务器可以通过向用户推送Web重定向URL来强制用户访问指定业务站点页面、广告等通知类页面,或者在用户欠费时推送欠费提醒页面。在实际组网中,用户端的部分应用程序(比如输入法软件)会在后台自动发起访问指定服务器Web页面的请求,提前触发了设备对该用户的Web重定向操作,减少了服务器对用户强推Web页面的机会,导致用户主动发起的Web访问请求有可能不会被重定向。为了避免此问题的发生,可以配置向用户推送Web重定向URL的有效时长,使得自服务器或ISP域向用户下发重定向URL属性起(包括用户上线时或服务器后续进行COA授权时),在该时长内用户端发起的所有HTTP访问请求都会被重定向。
· 本配置只对PPP、IPoE用户生效。
· 本配置在以下两种情况下生效:
¡ 服务器向用户下发了重定向URL,且下发了限定次数重定向属性。
¡ 服务器未向用户下发了重定向URL,但用户认证域下配置了url属性,且未携带unlimited参数。
· 如果用户的认证域下同时还配置了重定向次数(通过authorization-attribute redirect-times命令),则本配置的优先级高,重定向次数不会生效。因此,如果需要限定对用户的Web重定向次数,则必须确保该域下未进行本配置。
# 在ISP域test下配置推送Web重定向URL的有效时长为60秒。
[Sysname-isp-test] redirect active-time 60
· authorization-attribute (ISP domain view)
· display domain
· redirect server
redirect move-temporarily enable命令用来开启暂时重定向功能。
undo redirect move-temporarily enable命令用来关闭暂时重定向功能。
暂时重定向功能处于关闭状态。
ISP域视图
缺省情况下,设备向用户发送HTTP/HTTPS重定向报文时采用Java Script的方式携带重定向URL,用户终端通过解析HTTP/HTTPS报文中Java Script来获取重定向URL。如果用户访问网络的终端(例如APP)不支持解析HTTP/HTTPS报文中Java Script,将无法获取重定向URL,也就无法完成设备预期的重定向行为。这种情况下,设备管理员可以开启暂时重定向功能,改变设备发送HTTP/HTTPS重定向报文时携带重定向URL的方式来适配这些终端。
开启暂时重定向功能后,设备将通过发送状态码为302的暂时重定向响应报文向用户终端推送重定向URL。
目前,本功能仅对PPP和IPoE用户生效。
# 在ISP域test下,开启暂时重定向功能。
[Sysname-isp-test] redirect move-temporarily enable
· display domain
redirect server命令用来配置提供Web重定向页面的服务器IP地址。
undo redirect server命令用来删除配置的Web重定向页面的服务器IP地址。
redirect server { ip ipv4-address | ipv6 ipv6-address }
undo redirect server { ip | ipv6 }
未配置提供Web重定向页面的服务器IP地址。
ISP域视图
ip ipv4-address:重定向服务器的IPv4地址。
ipv6 ipv6-address:重定向服务器的IPv6地址。
当AAA授权给用户的重定向URL中未携带服务器的IP地址时,可通过本配置直接指定该URL对应的服务器IP地址,以提高设备对用户进行Web重定向时的效率和准确度。当设备需要对用户的Web访问请求进行重定向时,首先判断该用户的Web访问请求报文的目的地址是否为本命令配置的服务器IP地址,如果是,则直接允许其访问该地址,否则向其推送授权的重定向URL。
· 如果授权的重定向URL中未携带服务器的IP地址,则使用本配置指定的服务器IP地址作为重定向的目的IP地址。因此,需要保证本配置指定的服务器IP地址与该URL解析出的服务器IP地址保持一致。
· 如果授权的重定向URL中携带了服务器的IP地址,但与本配置指定的服务器IP地址不同,则使用本配置指定的服务器IP地址作为重定向的目的IP地址。
· 如果授权的重定向URL中未携带服务器的IP地址,且设备上未配置提供Web重定向页面的服务器IP地址,则可能会因为无法获取重定向服务器IP地址而导致该重定向操作失败。
· 一个ISP域下,只能配置一个Web重定向服务器IPv4地址,以及一个Web重定向服务器IPv6地址。
# 在ISP域test下配置提供Web重定向页面的服务器IP地址为5.1.1.1。
[Sysname-isp-test] redirect server ip 5.1.1.1
· display domain
· redirect aging-time
reset aaa abnormal-offline-record命令用来清除当前所有用户异常下线记录。
除非主控板重启,否则已保存的用户异常下线记录将会一直保存在内存中,而记录的信息过多时不便于查看,且占用内存过多,为方便管理员仅获取后续某个时间段内的用户异常下线记录,可执行本命令清除系统当前所有的用户异常下线记录。
执行完该命令后,已被清除的记录不能恢复,因此需要谨慎使用。
# 清除当前所有用户异常下线记录。
<Sysname> reset aaa abnormal-offline-record
· display aaa abnormal-offline-record
reset aaa normal-offline-record命令用来清除当前所有用户正常下线记录。
除非主控板重启,否则已保存的用户正常下线记录将会一直保存在内存中,而记录的信息过多时不便于查看,且占用内存过多,为方便管理员仅获取后续某个时间段内的用户正常下线记录,可以执行本命令清除系统当前所有的用户正常下线记录。
# 清除当前所有用户正常下线记录。
<Sysname> reset aaa normal-offline-record
· display aaa normal-offline-record
reset aaa offline-record命令用来清除当前所有用户下线记录。
除非主控板重启,否则已保存的用户下线失败记录将会一直保存在内存中,而记录的信息过多时不便于查看,且占用内存过多,为方便管理员仅获取后续某个时间段内的用户下线记录,可以执行本命令清除系统当前所有的用户下线记录。
# 清除当前所有用户下线记录。
<Sysname> reset aaa offline-record
· display aaa offline-record
reset aaa online-fail-record命令用来清除当前所有用户上线失败记录。
除非主控板重启,否则已保存的用户上线失败记录将会一直保存在内存中,而记录的信息过多时不便于查看,且占用内存过多,为了方便管理员仅获取后续某个时间段内的用户上线失败记录,可以执行本命令清除系统当前所有的用户上线失败记录。
# 清除当前所有用户上线失败记录。
<Sysname> reset aaa online-fail-record
· display aaa online-fail-record
secondary-web-server { ip | ipv6 }命令用来指定备用Web服务器的IP地址。
undo secondary-web-server { ip | ipv6 }命令用来删除指定的备用Web服务器的IP地址。
secondary-web-server [ secondary ] { ip ipv4-address | ipv6 ipv6-address }
undo secondary-web-server [ secondary ] { ip | ipv6 }
未指定备用Web服务器的IP地址。
ISP域视图
secondary:备用Web服务器的备份IP地址。若在实际组网环境中,提供备用Web认证页面的服务器IP地址有两个(一般互为备份),则可以通过该参数将另外一个备用Web服务器的IP地址也在域中指定。
ip ipv4-address:备用Web服务器的IPv4地址。
ipv6 ipv6-address:备用Web服务器的IPv6地址。
若在ISP域中指定了备用Web服务器的IP地址,在备用Web服务器生效的情况下,用户的Web请求URL中携带该IP地址时,该Web请求报文将不会被重定向,而是直接转发。因此,通过指定备用Web服务器的IP地址,在备用Web服务器生效的情况下,可以避免用户Web请求的目的地址就是Web服务器时,设备将该Web请求进行一次无意义的重定向。
最多只能配置一个备用Web服务器的IPv4地址、一个备用Web服务器的IPv6地址、一个备用Web服务器的备份IPv4地址和一个备用Web服务器的备份IPv6地址。
# 在ISP域test中,指定备用Web服务器的IP地址为192.168.1.1
[Sysname-isp-test] secondary-web-server ip 192.168.1.1
· display domain
service rate-limit mode命令用来配置EDSG业务流量限速模式。
undo service rate-limit mode命令用来恢复缺省情况。
service rate-limit mode { merge | separate }
仅对EDSG业务流量限速,且不影响普通业务流量带宽。
ISP域视图
merge:带内限速,即在用户可用总带宽内,对EDSG业务流量和普通业务流量同时限速,且优先保证EDSG业务带宽。
separate:带外限速,即对EDSG业务流量进行独立限速,用户普通业务流量带宽不受影响。
假如用户最大可用基础带宽为20M,EDSG业务最大可用带宽为12M,不同流量限速模式下的限速效果不同:
· 在separate模式下,EDSG业务的12M带宽是独立于20M之外,实际用户可用带宽为32M,但这12M带宽也只能用于EDSG业务,不能用于普通业务。
· 在merge模式下,EDSG业务的12M带宽包含在20M内,若某时刻EDSG业务占用了12M带宽,则普通业务可用带宽将下降为8M。
EDSG业务流量限速模式在EDSG业务策略视图下的配置优先级高于ISP域视图下的配置。
# 在ISP域test中,配置EDSG业务流量限速模式为merge,即对EDSG业务流量限速的同时,也对普通业务流量限速,但优先保证EDSG业务。
[Sysname-isp-test] service rate-limit mode merge
· service policy
· service rate-limit mode (EDSG service policy view)
service-type命令用来设置当前ISP域的业务类型。
undo service-type命令用来恢复缺省情况。
service-type { hsi | stb | voip }
undo service-type
当前ISP域的业务类型为hsi。
ISP域视图
hsi:表示HSI(High Speed Internet,高速上网)业务,主要指使用PPP、IPoE专线方式接入网络的用户业务。
stb:表示STB(Set Top Box,机顶盒)业务,专指使用数字机顶盒接入网络的用户业务。
voip:表示(Voice over IP,IP电话)业务,指使用IP电话的用户业务。
本命令用来配置当前认证域的用户使用的业务类型,用来决定接入模块是否开启组播功能。
用户使用HSI业务类型的ISP域接入时,接入模块不会开启组播功能,可节省系统资源。
用户使用STB业务类型的ISP域接入时,接入模块会开启组播功能,可提高系统处理组播业务的性能。
用户使用VoIP业务类型的ISP域接入时,QoS功能会开启保证用户语音数据的低延迟传送。
对于IPoE专线用户、PPP用户(非PPPoE用户),ISP域中配置的业务类型无效,系统强制使用HSI业务类型。
一个ISP域中,仅能配置一种类型的业务类型。
# 设置域test下用户业务类型为STB终端业务。
[Sysname-isp-test] service-type stb
session-time include-idle-time命令用来配置设备上传到服务器的用户在线时间中保留闲置切断时间。
undo session-time include-idle-time命令用来恢复缺省情况。
设备上传到服务器的用户在线时间中扣除闲置切断时间。
ISP域视图
请根据实际的计费策略决定是否在用户在线时间中保留该闲置切换时间。该闲置切断时间在用户认证成功后由AAA授权。
当用户正常下线时,设备上传到服务器上的用户在线时间为实际在线时间;当用户异常下线时,上传到服务器的用户在线时间具体如下:
· 若配置为保留闲置切断时间,则上传到服务器上的用户在线时间中包含了一定的闲置切断检测间隔。此时,服务器上记录的用户时长将大于用户实际在线时长。
· 若配置为扣除闲置切断时间,则上传到服务器上的用户在线时间为,闲置切断检测机制计算出的用户已在线时长扣除掉一个闲置切断检测间隔。此时,服务器上记录的用户时长将小于用户实际在线时长。
#在ISP域test下,配置设备上传到服务器的用户在线时间中保留闲置切断时间。
[Sysname-isp-test] session-time include-idle-time
· display domain
snmp-agent trap enable aaa命令用来开启AAA告警功能。
undo snmp-agent trap enable aaa命令用来关闭AAA告警功能。
snmp-agent trap enable aaa [ login-failed-threshold ]
undo snmp-agent trap enable aaa [ login-failed-threshold ]
AAA告警功能处于开启状态。
login-failed-threshold:表示当设备管理类用户登录失败频率到达设置的阈值时发送告警信息。
开启设备管理类用户登录失败频率阈值告警功能后,系统将会生成以下几种告警信息:
· 设备管理类用户登录失败频率到达上限阈值时的告警:使用命令aaa login-failed alarm-threshold配置了管理类用户登录失败次数阈值和统计周期时长后,当周期时长内管理类用户登录失败次数首次到达上限阈值,或从低于恢复阈值增长到上限阈值时,将输出相应的告警信息。
· 设备管理类用户登录失败频率回落到恢复阈值时的告警:使用命令aaa login-failed alarm-threshold配置了管理类用户登录失败次数阈值和统计周期时长后,当周期时长内管理类用户登录失败次数从大于等于上限阈值下降到小于恢复阈值时,将输出相应的告警信息。
若不指定任何参数,则表示开启或关闭所有AAA告警功能。
# 开启设备管理类用户登录失败频率阈值告警功能。
[Sysname] snmp-agent trap enable aaa login-failed-threshold
· aaa login-failed alarm-threshold
snmp-agent trap enable domain命令用来开启ISP域告警功能。
undo snmp-agent trap enable domain命令用来关闭ISP域告警功能。
snmp-agent trap enable domain { ip-usage-warning | ipv6-usage-warning | web-server-ipv6-url-warning | web-server-url-warning } *
undo snmp-agent trap enable domain { ip-usage-warning | ipv6-usage-warning | web-server-ipv6-url-warning | web-server-url-warning } *
ISP域告警功能处于关闭状态。
ip-usage-warning:表示授权IPv4地址使用率告警,即ISP域下授权IPv4地址池/IPv4地址池组中的IPv4地址使用率达到或超过上限阈值、达到或小于下限阈值,以及恢复到正常范围时产生对应的告警信息。
ipv6-usage-warning:表示授权IPv6地址和前缀使用率告警,即ISP域下授权IPv6地址池/ND前缀地址池/IPv6地址池组/ND前缀地址池组中的IPv6地址或前缀使用率达到或超过上限阈值、达到或小于下限阈值,以及恢复到正常范围时产生对应的告警信息。
web-server-url-ipv6-warning:表示Web服务器IPv6 URL可用情况变化告警,即当ISP域下重定向给用户的Web服务器的IPv6 URL状态由不可用变为可用或由可用变为不可用,以及可用的Web服务器的IPv6 URL发生变化时,产生对应的告警信息。
web-server-url-warning:表示Web服务器IPv4 URL可用情况变化告警,即当ISP域下重定向给用户的Web服务器的IPv4 URL状态由不可用变为可用或由可用变为不可用,以及可用的Web服务器的IPv4 URL发生变化时,产生对应的告警信息。
开启ISP域告警功能后,ISP域下发生的指定类型的重要事件将会生成告警信息。生成的告警信息将被送到设备的SNMP模块,通过设置SNMP中的告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
若要基于ISP域生成授权IPv4地址使用率告警信息,还需要在指定的域下配置授权IPv4地址使用率告警阈值。
若要基于ISP域生成授权IPv6地址和前缀使用率告警信息,还需要在指定的域下配置授权IPv6地址和前缀使用率告警阈值。
当设备作为DHCP中继时,为保证本功能生效,还需要在使用的中继地址池内通过network命令配置和中继地址池关联的服务器相同的网段信息。
若要更好地使用Web服务器URL可用情况变化告警功能,在ISP域下配置Web服务器URL时,建议配置关联Track项与HTTP类型的NQA测试组联动,由NQA测试组来判断Web重定向服务器的连通性及性能。
# 开启ISP域的授权IPv4地址使用率告警功能。
[Sysname] snmp-agent trap enable domain ip-usage-warning
· ip-usage-warning
· ipv6-usage-warning
· network(BRAS业务命令参考/DHCP中继)
state命令用来设置当前ISP域的状态。
undo state命令用来恢复缺省情况。
state { active | block [ time-range ][ offline ] }
undo state
当前ISP域处于活动状态。
ISP域视图
active:指定当前ISP域处于活动状态,即系统允许该域下的用户请求网络服务。
block:指定当前ISP域处于阻塞状态,即系统不允许该域下的用户请求网络服务。该参数对除采用公钥认证的SSH用户之外的所有接入类型的用户都生效。
time-range:指定ISP域基于时间段阻塞。若不指定该参数,则表示ISP域一直处于阻塞状态。
offline:表示ISP域从活动状态切换为阻塞状态后,通过该ISP域接入的网络接入类(包括IPoE、PPP)用户将被强制下线。若不指定该参数,则表示ISP域状态切换为阻塞状态后,不影响当前用户状态。
若通过time-range关键字指定ISP域基于时间段阻塞,则该ISP域只在通过state block time-range name命令指定的时间段内处于阻塞状态。
# 设置当前ISP域test处于阻塞状态。
[Sysname-isp-test] state block
· display domain
· state block time-range name
state block time-range name命令用来配置ISP域处于阻塞状态的时间段。
undo state block time-range name命令用来删除配置的ISP域处于阻塞状态的时间段。
state block time-range name time-range-name
undo state block time-range { all | name time-range-name }
未配置ISP域处于阻塞的时间段。
ISP域视图
time-range-name:时间段的名称,为1~32个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,时间段的名称不允许使用英文单词all。
all:表示所有时间段。
本命令配置的时间段,在ISP域基于时间段阻塞的情况下才能生效。可通过state block time-range命令配置ISP域基于时间段阻塞。
可通过多次执行本命令,指定ISP域处于阻塞状态的多个时间段。
# 配置ISP域test处于阻塞状态的时间段为t1和t2。
[Sysname-isp-test] state block time-range name t1
[Sysname-isp-test] state block time-range name t2
· state
· time-range(QoS和ACL命令参考/时间段)
strict-check access-interface vpn-instance命令用来开启对用户上线接口的VPN配置进行严格一致性检查功能。
undo strict-check access-interface vpn-instance命令用来关闭对用户上线接口的VPN配置进行严格一致性检查功能。
对用户上线接口的VPN配置进行严格一致性检查功能处于关闭状态。
ISP域视图
本功能仅对IPoE静态接入用户(包括静态个人接入用户和静态专线用户)生效。
对于IPoE静态接入用户,设备支持三种方式为其分配上线后所属的VPN实例:用户的IPoE静态会话配置中绑定VPN实例、AAA授权VPN实例、用户上线的接口上绑定VPN实例。
缺省情况下,静态IPoE用户上线时,设备根据不同的VPN配置和VPN授权情况为用户分配不同的VPN实例:
· 若用户的IPoE静态会话未绑定VPN实例、AAA未授权VPN实例,则用户上线后属于接口绑定的VPN实例。若接口未绑定VPN实例,则用户上线后属于公网。
· 若用户的IPoE静态会话绑定VPN实例,或者AAA授权了VPN实例,用户上线后属于对应的VPN实例。该情况下,接口上是否绑定了VPN实例不影响用户的VPN归属。
· 若用户的IPoE静态会话绑定VPN实例,且AAA授权了相同的VPN实例,则用户上线后属于该VPN实例。若两种方式指定的VPN实例不同,则不允许用户上线。
如果IPoE用户认证成功后,要求具备相同VPN配置和VPN授权情况的用户才能上线,则需要在用户认证域下开启本功能。
本功能开启后,当该域的静态IPoE用户上线时,设备会检查用户上线接口绑定的VPN实例与用户被授权的VPN实例、用户IPoE静态会话绑定的VPN实例是否一致,并严格按照统一的VPN分配策略,控制用户报文走私网路由还是走公网路由:
· 若用户的IPoE静态会话绑定VPN实例,或者AAA授权了VPN实例,且与接口绑定的VPN实例相同,用户上线后属于对应的VPN实例。若检查结果不一致,则不允许用户上线。
· 若用户的IPoE静态会话绑定VPN实例,且AAA授权了VPN实例,在两者均与接口绑定的VPN实例相同的情况下,用户上线后属于对应的VPN实例。若三种方式指定的VPN实例不同,则不允许用户上线。
# 开启对IPoE用户上线接口的VPN配置进行严格一致性检查功能。
[Sysname-isp-test] strict-check access-interface vpn-instance
· display domain
· ip subscriber session static(BRAS命令参考/IPoE)
user-address-type命令用来设置当前ISP域的用户地址类型。
undo user-address-type命令用来恢复缺省情况。
user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 }
未指定当前ISP域的用户地址类型。
ISP域视图
ds-lite:表示当前用户的地址类型为轻量级双栈地址。
ipv6:表示当前用户的地址类型为IPv6地址。
nat64:表示当前用户的地址类型为NAT64地址。
private-ds:表示当前用户的地址类型为私网双栈地址。
private-ipv4:表示当前用户的地址类型为私网IPv4地址。
public-ds:表示当前用户的地址类型为公网双栈地址。
public-ipv4:表示当前用户的地址类型为公网IPv4地址。
需要根据用户接入侧的组网环境和用户的地址分配策略选择配置相应的地址类型参数。
更改当前ISP域的用户地址类型,不影响已经在线的用户。
# 设置当前ISP域用户地址类型为私网IPv4地址。
[Sysname-isp-test] user-address-type private-ipv4
· display domain
users-per-account命令用来配置单个帐号允许接入的最大用户数。
undo users-per-account命令用来恢复缺省情况。
users-per-account max-user-number [ case-insensitive ]
ISP域下的用户不共享账号,每个用户独享各自的授权流量监管参数。
ISP域视图
max-user-number:最大用户数,取值范围为1~512。
case-insensitive:表示用户名不区分大小写。若不指定该参数,则表示用户名区分大小写。
ISP域下配置了单个帐号允许接入的最大用户数后,该域内使用同一账户接入的用户数受限,同时这些用户只能共享指定带宽,即这些用户的总业务流量将受到该账户的授权流量监管参数的限制。这类用户被简称为共享账户用户。目前,该配置仅适用于PPPoE、IPoE和L2TP用户。
共享账户的用户必须拥有相同的用户名和授权域名,其中的授权域是指服务器给用户授权的域。如果服务器未给用户授权域,则选用该用户的认证域作为授权域。对于共享账户用户,授权限制切断功能不生效。
如果RADIUS服务器下发了最大用户数(通过标准属性62号属性Port-Limit),则服务器的配置优先。如果RADIUS服务器下发的最大用户数大于512,则实际生效值为512。
建议配置单个账号允许接入的最大用户数不超过16。
# 在ISP域test下,配置单个帐号允许接入的最大用户数为5,且用户名不区分大小写。
[Sysname-isp-test] users-per-account 5 case-insensitive
· display domain
web-server { ip | ipv6 }命令用来指定Web服务器的IP地址。
undo web-server { ip | ipv6 }命令用来删除指定的Web服务器的IP地址。
web-server { ip ipv4-address | ipv6 ipv6-address } [ secondary ]
undo web-server { ip | ipv6 } [ secondary ]
未指定Web服务器的IP地址。
ISP域视图
ipv4-address:Web服务器的IPv4地址。
ipv6-address:Web服务器的IPv6地址。
secondary:Web服务器的备份IP地址。若在实际组网环境中,提供Web认证页面的服务器IP地址有两个(一般互为备份),则可以通过该参数将另外一个Web服务器的IP地址也在域中指定。
若在ISP域中指定了Web服务器的IP地址,则用户的Web请求URL中携带该IP地址时,该Web请求报文将不会被重定向,而是直接转发。因此,通过指定Web服务器的IP地址,可以避免用户Web请求的目的地址就是Web服务器时,设备将该Web请求进行一次无意义的重定向。
最多只能配置一个Web服务器的IPv4地址、一个Web服务器的IPv6地址、一个Web服务器的备份IPv4地址和一个Web服务器的备份IPv6地址。
# 在ISP域test中,指定Web服务器的IP地址为192.168.1.1。
[Sysname-isp-test] web-server ip 192.168.1.1
· display domain
web-server { url | ipv6-url }命令用来指定重定向给用户的Web服务器的URL。
undo web-server { url | ipv6-url }命令用来删除指定的Web服务器的URL。
web-server { url ipv4-url-string | ipv6-url ipv6-url-string } [ secondary ] [ track track-entry-number ]
undo web-server { url | ipv6-url } [ secondary ]
未指定重定向给用户的Web服务器的URL。
ISP域视图
ipv4-url-string:Web服务器的IPv4 URL,为1~255个字符的字符串,区分大小写,不能“?”字符开头。若输入的URL未以http://或者https://开头,则默认为以http://开头。
ipv6-url-string:Web服务器的IPv6 URL,为1~255个字符的字符串,区分大小写,不能“?”字符开头。若输入的URL未以http://或者https://开头,则默认为以http://开头。
secondary:表示指定备用Web服务器的IPv4/IPv6 URL。若不指定该参数,则表示主用Web服务器的IPv4/IPv6 URL。
track track-entry-number:指定Web服务器的IPv4/IPv6 URL关联的Track项。track-entry-number表示Track项的序号,取值范围为1~1024。若不指定该参数,则表示重定向IPv4/IPv6 URL不关联Track项。
若在IPoE用户的认证前域中指定了Web服务器的IPv4 URL,则用户在认证之前发送的目的端口为80的IPv4 HTTP请求和目的端口为443的HTTPS请求将被重定向到指定的Web服务器IPv4 URL,该URL向用户提供Web认证页面。为了提高重定向的可靠性,可以指定主备两个Web服务器IPv4 URL页面。
若在IPoE用户的认证前域中指定Web服务器IPv6 URL,则用户的IPv6 HTTP/HTTPS请求将被重定向到指定的Web服务器的IPv6 URL;未指定Web服务器IPv6 URL的情况下,用户的IPv6 HTTP/HTTPS请求将被重定向到指定的Web服务器的IPv4 URL。因此,请根据实际组网需要,准确配置相应协议的URL。为了兼容已有配置,纯IPv6环境中,也支持通过web-server url指定Web服务器的IPv6 URL。
通过对重定向IPv4/IPv6 URL关联Track项,AAA模块能够根据Track项的状态及时确定Web重定向服务器的可达性,以便设备实现主备重定向IPv4/IPv6 URL的快速切换。建议将被关联的Track项与HTTP类型的NQA测试组联动,由NQA测试组来判断Web重定向服务器的连通性及性能。有关Track项的详细介绍,请参见“可靠性配置指导”中的“Track”。有关NQA的详细介绍,请参见“网络管理和监控配置指导”中的“NQA”。
系统中实际生效的重定向URL与主备重定向URL的配置以及所关联的Track项的状态相关:
· 同时配置了主用和备用重定向URL,且均未关联Track项,则主用重定向URL生效。
· 仅配置了主用或备用重定向URL,且未关联Track项,则配置的重定向URL生效。
· 只要配置了主用重定向URL,且关联的Track项状态为Positive或NotReady,或者未关联的Track项,则主用重定向URL生效。
· 如果未配置主用重定向URL,或者主用重定向URL关联的Track项状态为Negative,则需要判断备用重定向URL的状态:
¡ 若备用重定向URL未关联Track项,或关联的Track项状态为Positive或NotReady,则备用重定向URL生效。
¡ 若未配置备用重定向URL或备用重定向URL关联的Track项状态为Negative,则认为无可用重定向URL。
同时配置了主用和备用重定向URL且均关联Track项情况下,若IPoE用户在前域上线且被授权了主用重定向URL后,主用重定向URL不可达,系统并不会立即为这些已在线用户授权备用重定向URL。此时,建议管理员强制该类IPoE用户下线,然后待用户再次上线时,若系统已经通过Track检测并将该域的重定向URL切换为备用重定向URL,则新上线的IPoE用户将能够访问备用重定向URL。
# 在ISP域test中,指定重定向给用户的Web服务器的URL为http://1.2.3.4,IPv6 URL为http://[10:110::1:2]。
[Sysname-isp-test] web-server url http://1.2.3.4
[Sysname-isp-test] web-server ipv6-url http://[10:110::1:2]
· display domain
· ip subscriber pre-auth domain(BRAS业务命令参考/IPoE)
web-server url-parameter命令用来配置设备重定向给用户的Web服务器的URL中携带的参数信息。
undo web-server url-parameter命令用来删除配置的Web服务器URL携带的参数信息。
web-server url-parameter param-name { nas-id | nas-port-id | original-url | remote-id | source-address | source-mac [ encryption { aes | des } key { cipher | simple } string ] [ section { 1 | { 3 | 6 } [ separator separator-character ] } { lowercase | uppercase } ] | ssid | user-location | value expression }
undo web-server url-parameter param-name
未配置设备重定向给用户的Web服务器的URL中携带的参数信息。
ISP域视图
param-name:URL参数名,为1~32个字符的字符串,区分大小写。URL参数名对应的参数内容由param-name后的参数指定。
nas-id:网络接入服务器标识。
nas-port-id:网络接入服务器端口标识。
original-url:用户初始访问的Web页面的URL。
remote-id:用户DHCP报文中的Remote ID子选项。
source-address:用户的IP地址。
source-mac:用户的MAC地址。
encryption:表示以密文的方式携带用户的MAC地址。若不指定该参数,则表示以明文的方式携带用户的MAC地址。
aes:指定加密算法为AES算法。
des:指定加密算法为DES算法。
key:指定加密密钥。
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。密钥的长度范围和选择的加密方式有关,具体关系如下:
· 对于des算法,密文密钥为41个字符的字符串。
· 对于des算法,明文密钥为8个字符的字符串。
· 对于aes算法,密文密钥为1~73个字符的字符串。
· 对于aes算法,明文为1~31个字符的字符串。
section:指定MAC地址分段数。若不指定该参数,则MAC地址采用3段形式且为大写字母,如XXXX-XXXX-XXXX。
1:MAC地址被分为1段,如XXXXXXXXXXXX。
3:MAC地址被分为3段,如XXXX-XXXX-XXXX。
6:MAC地址被分为6段,如XX-XX-XX-XX-XX-XX。
separator separator-character:MAC地址的分隔符,为单个字符,区分大小写。若不指定该参数,则表示分隔符为“-”。
lowercase:MAC地址为小写字母形式。
uppercase:MAC地址为大写字母形式。
ssid:用户所属的SSID(Service Set Indentifier,服务集标识符)。
user-location:用户接入的物理位置信息,包含物理接口和VLAN信息,具体格式为port:vlan1.vlan2。其中,port表示接口类型及接口编号,例如eth/6/0/4,vlan1表示外层VLAN编号,vlan2表示内层VLAN编号。若没有VLAN信息,则vlan1和vlan2均取值为0,例如eth/6/0/4:0.0;若仅有单层VLAN信息,则vlan2取值为0,例如eth/6/0/4:10.0;若为聚合接口,则接口类型为ethtrunk,例如ethtrunk/44:11.10。
value expression:自定义字符串,为1~255个字符的字符串,区分大小写。
该命令用于配置用户访问Web服务器时,要求携带的一些参数,比较常用的是要求携带用户的IP地址、MAC地址、用户原始访问的URL信息。用户也可以手工指定,携带一些特定的字符信息。可以通过多次执行本命令配置多条参数信息。配置完成后,在设备给用户重定向URL时会携带这些参数,例如配置Web服务器的URL为:http://1.2.3.4/,若同时配置如下两个参数信息:url-parameter userip source-address和url-parameter userurl value http://www.abc.com/welcome,则设备给源IP为1.1.1.1的用户重定向时回应的URL格式即为:http://1.2.3.4/?userip=1.1.1.1&userurl=http%3a%2f%2fwww%2eabc%2ecom%2fwelcome。重定向URL携带的自定义字符串中,除字母、数字、“=”和“&”之外的字符均被设备进行了编码处理(以%加字符编码的形式),这可以确保携带了自定义字符串的重定向URL在各类浏览器上能被正确解析。
需要注意的是,为了使携带自定义参数的重定向URL生效,配置的Web服务器URL必需以/结尾。
param-name这个URL参数名必须与具体应用环境中的Web服务器所支持的URL参数名保持一致,不同的服务器支持URL参数名是不一样的,请根据具体情况配置URL参数名。例如iMC服务器支持的URL参数名如下:
· userurl:表示original-url
· userip:表示source-address
· usermac:表示source-mac
在Web服务器为iMC服务器的组网环境中,如果设备重定向给用户的Web服务器的URL中需要携带用户的IP地址参数信息时,必须把param-name参数配置成userip,否则,iMC服务器不能识别用户的IP地址。
如果需要在重定向给用户的Web服务器的URL中携带用户的SSID信息,还需要在用户接入的接口上通过aaa ssid命令配置SSID。
对于同一个参数名param-name后的参数设置,最后配置的生效。
# 在ISP域test中,指定重定向给用户的Web服务器的URL中携带参数userip和userurl,其值分别为用户IP地址和自定义字符串http://www.abc.com/welcome。
[Sysname-isp-test] web-server url-parameter userip source-address
[Sysname-isp-test] web-server url-parameter userurl value http://www.abc.com/welcome
# 在ISP域test中,指定重定向给用户的Web服务器的URL中携带参数usermac,其值为用户MAC地址,并使用des算法进行加密。
[Sysname-isp-test] web-server url-parameter usermac source-mac encryption des key simple 12345678
· aaa ssid
· display domain
· web-server url
access-limit命令用来设置使用当前本地用户名接入设备的最大用户数。
undo access-limit命令用来恢复缺省情况。
access-limit max-user-number
undo access-limit
不限制使用当前本地用户名接入的用户数。
本地用户视图
max-user-number:表示使用当前本地用户名接入设备的最大用户数,取值范围为1~1024。
本地用户视图下的access-limit命令只在该用户采用了本地计费方法的情况下生效。
对于网络接入类本地用户,还需要在用户接入的ISP域视图下配置accounting start-fail offline命令,否则使用当前用户名接入的用户数并不受access-limit命令的限制。
由于FTP/SFTP/SCP用户不支持计费,因此FTP/SFTP/SCP用户不受此属性限制。
# 允许同时以本地用户名abc在线的用户数为5。
[Sysname] local-user abc
[Sysname-luser-manage-abc] access-limit 5
· accounting start-fail offline
· display local-user
authorization-attribute命令用来设置本地用户或用户组的授权属性,该属性在本地用户认证通过之后,由设备下发给用户。
undo authorization-attribute命令用来删除指定的授权属性,恢复用户具有的缺省访问权限。
authorization-attribute { acl acl-number | callback-number callback-number | idle-cut minutes | ip ipv4-address | ip-pool ipv4-pool-name | ipv6 ipv6-address | ipv6-pool ipv6-pool-name | ipv6-prefix ipv6-prefix prefix-length | netstream-sampler sampler-name [ inbound | outbound ] | { primary-dns | secondary-dns } { ip ipv4-address | ipv6 ipv6-address } | session-group-profile session-group-profile-name | session-timeout minutes | subscriber-id subscriber-id | url url-string | user-profile user-profile-name | user-role role-name | vlan vlan-id | vpn-instance vpn-instance-name | work-directory directory-name } *
undo authorization-attribute { acl | callback-number | idle-cut | ip | ip-pool | ipv6 | ipv6-pool | ipv6-prefix | netstream-sampler | { primary-dns | secondary-dns } { ip | ipv6 } | session-group-profile | session-timeout | subscriber-id | url | user-profile | user-role role-name | vlan | vpn-instance | work-directory } *
授权FTP/SFTP/SCP用户可以访问的目录为设备的根目录,但无访问权限。
由用户角色为network-admin或level-15的用户创建的本地用户被授权用户角色network-operator。
本地用户视图
用户组视图
acl acl-number:指定本地用户的授权ACL。其中,acl-number为授权ACL的编号,取值范围为2000~5999。与授权ACL规则匹配的流量,将按照规则中指定的permit或deny动作进行处理。
callback-number callback-number:指定本地用户的授权PPP回呼号码。其中,callback-number为1~64个字符的字符串,区分大小写。本地用户认证成功后,设备将可以使用该用户的授权PPP回呼号码向PPP协商的对端设备发起回呼。
idle-cut minutes:设置本地用户的闲置切断时间。其中,minutes为设定的闲置切断时间,取值范围为1~120,单位为分钟。如果用户在线后连续闲置的时长超过该值,设备会强制该用户下线。
ip ipv4-address:指定本地用户的静态IP地址。本地用户认证成功后,将允许使用该IP地址。该授权属性只能在本地用户视图下配置,不能在本地用户组视图下配置。
ip-pool ipv4-pool-name:指定本地用户的IPv4地址池信息。本地用户认证成功后,将允许使用该IPv4地址池分配地址。其中,ipv4-pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。
ipv6 ipv6-address:指定本地用户的静态IPv6地址。本地用户认证成功后,将允许使用该IPv6地址。该授权属性只能在本地用户视图下配置,不能在本地用户组视图下配置。
ipv6-pool ipv6-pool-name:指定本地用户的IPv6地址池信息。本地用户认证成功后,将允许使用该IPv6地址池分配地址。其中,ipv6-pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。
ipv6-prefix ipv6-prefix prefix-length:指定本地用户的IPv6前缀信息。ipv6-prefix prefix-length为前缀地址和前缀长度,前缀长度取值范围是1~128。本地用户认证成功后,将允许使用该IPv6前缀。
netstream-sampler sampler-name:指定本地用户的授权NetStream采样器。其中sampler-name表示采样器名称,为1~31个字符的字符串,不区分大小写。有关采样器的详细介绍,请参见“网络管理和监控配置指导”中的“Sampler”。若该参数后不指定inbound或outbound参数,则表示对出/入方向的上网流量均进行采样。该授权属性只能在网络接入类本地用户视图下配置,不能在设备管理类本地用户以及本地用户组视图下配置。
inbound:入方向上网流量。
outbound:出方向上网流量。
primary-dns ip ipv4-address:指定本地用户的主DNS服务器IPv4地址。本地用户认证成功后,将被授权使用该主DNS服务器。
primary-dns ipv6 ipv6-address:指定本地用户的主DNS服务器IPv6地址。本地用户认证成功后,将被授权使用该主DNS服务器。
secondary-dns ip ipv4-address:指定本地用户的从DNS服务器IPv4地址。本地用户认证成功后,将被授权使用该从DNS服务器。
secondary-dns ipv6 ipv6-address:指定本地用户的从DNS服务器IPv6地址。本地用户认证成功后,将被授权使用该从DNS服务器。
session-group-profile session-group-profile-name:指定本地用户的授权Session Group Profile。其中,session-group-profile-name为Session Group Profile名称,为1~31个字符的字符串,区分大小写。关于Session Group Profile的详细介绍请参见“BRAS业务配置指导”中的“User Profile”。
session-timeout minutes:设置本地用户的会话超时时间。其中,minutes为设定的会话超时时间,取值范围为1~1440,单位为分钟。如果用户在线时长超过该值,设备会强制该用户下线。
subscriber-id subscriber-id:设置本地用户授权Subscriber ID,取值范围为1~4095。授权Subscriber ID用于配合为家庭用户配置的Session Group Profile实现家庭级别的QoS。关于QoS配置的详细介绍请参见“ACL和QoS配置指导”中的“QoS”。关于HQoS配置的详细介绍请参见“ACL和QoS配置指导”中的“HQoS”。
url url-string:指定本地用户的授权PADM(PPPoE Active Discovery Message) URL,为1~255个字符的字符串,区分大小写,且必须携带http://或https://前缀才可生效。用户认证成功后,此URL将被推送至PPPoE客户端,且仅支持默认的80和8080端口。
user-profile user-profile-name:指定本地用户的授权User Profile。其中,user-profile-name表示User Profile名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线、减号和英文句号,支持以字母和数字开头,但不能为纯数字,区分大小写。当用户认证成功后,其访问行为将受到User Profile中的预设配置的限制。关于User Profile的详细介绍请参见“BRAS业务配置指导”中的“User Profile”。
user-role role-name:指定本地用户的授权用户角色。其中,role-name表示用户角色名称,为1~63个字符的字符串,区分大小写。可以为每个用户最多指定64个用户角色。本地用户角色的相关命令请参见“基础配置命令参考”中的“RBAC”。该授权属性只能在本地用户视图下配置,不能在本地用户组视图下配置。
vlan vlan-id:指定本地用户的授权VLAN。其中,vlan-id为VLAN编号,取值范围为1~4094。本地用户认证成功后,将被授权仅可以访问指定VLAN内的网络资源。
vpn-instance vpn-instance-name:指定本地用户所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。本地用户认证成功后,将允许访问指定VPN中的网络资源。
work-directory directory-name:授权FTP/SFTP/SCP用户可以访问的目录。其中,directory-name表示FTP/SFTP/SCP用户可以访问的目录,为1~255个字符的字符串,不区分大小写,且该目录必须已经存在。缺省情况下,FTP/SFTP/SCP用户可访问设备的根目录,可通过本参数来修改用户可以访问的目录。
可配置的授权属性都有其明确的使用环境和用途,请针对用户的服务类型配置对应的授权属性:
· 对于PPP用户,仅授权属性callback-number、idle-cut、ip、ipv6、ip-pool、ipv6-pool、ipv6-prefix、netstream-sampler、primary-dns、secondary-dns、session-group-profile、session-timeout、subscriber-id、url、user-profile、vpn-instance有效。
· 对于IPoE用户,仅授权属性idle-cut、ipv6、ip-pool、ipv6-pool、ipv6-prefix、netstream-sampler、primary-dns、secondary-dns、session-group-profile、session-timeout、subscriber-id、user-profile、vpn-instance有效。当IPoE用户为专线接入用户时,授权属性vpn-instance不生效。
· 对于lan-access用户,仅授权属性acl、session-timeout、vlan、user-profile有效。
· 对于Telnet、Terminal、SSH用户,仅授权属性idle-cut、user-role有效。
· 对于HTTP、HTTPS用户,仅授权属性user-role有效。
· 对于FTP用户,仅授权属性user-role、work-directory有效。
· 对于其它类型的本地用户,所有授权属性均无效。
用户组的授权属性对于组内的所有本地用户生效,因此具有相同属性的用户可通过加入相同的用户组来统一配置和管理。
本地用户视图下未配置的授权属性继承所属用户组的授权属性配置,但是如果本地用户视图与所属的用户组视图下都配置了某授权属性,则本地用户视图下的授权属性生效。
指定授权ACL时,需要注意的是:
· 若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示未授权ACL规则。
为了避免设备上进行主备倒换后FTP/SFTP/SCP用户无法正常登录,建议用户在指定工作目录时不要携带slot信息。
为确保本地用户仅使用本命令指定的授权用户角色,请先使用undo authorization-attribute user-role命令删除该用户已有的缺省用户角色。
被授权安全日志管理员的本地用户登录设备后,仅可执行安全日志文件管理相关的命令以及安全日志文件操作相关的命令,具体命令可通过display role name security-audit命令查看。安全日志文件管理相关命令的介绍,请参见“网络管理与监控”中的“信息中心”。文件系统管理相关命令的介绍,请参见“基础配置命令参考”中的“文件系统管理”。
为本地用户授权安全日志管理员角色时,需要注意的是:
· 安全日志管理员角色和其它用户角色互斥:
¡ 为一个用户授权安全日志管理员角色时,系统会通过提示信息请求确认是否删除当前用户的所有其它他用户角色;
¡ 如果已经授权当前用户安全日志管理员角色,再授权其它的用户角色时,系统会通过提示信息请求确认是否删除当前用户的安全日志管理员角色。
系统中的最后一个安全日志管理员角色的本地用户不可被删除。
# 配置网络接入类本地用户abc的授权VLAN为VLAN 2。
[Sysname] local-user abc class network
[Sysname-luser-network-abc] authorization-attribute vlan 2
# 配置用户组abc的授权VLAN为VLAN 3。
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
# 配置设备管理类本地用户xyz的授权用户角色为security-audit(安全日志管理员)。
[Sysname] local-user xyz class manage
[Sysname-luser-manage-xyz]authorization-attribute user-role security-audit
This operation will delete all other roles of the user. Are you sure? [Y/N]:y
· display user-group
bind-attribute命令用来设置用户的绑定属性。
undo bind-attribute命令用来删除指定的用户绑定属性。
bind-attribute { call-number call-number [ : subcall-number ] | location interface interface-type interface-number | mac mac-address | vlan vlan-id } *
undo bind-attribute { call-number | location | mac | vlan } *
未设置用户的绑定属性。
本地用户视图
call-number call-number:指定PPP用户认证的主叫号码。其中call-number为1~64个字符的字符串。该绑定属性仅适用于PPP用户。
subcall-number:指定子主叫号码。如果配置了子主叫号码,则主叫号码与子主叫号码的总长度不能大于62个字符。
location interface interface-type interface-number:指定用户绑定的接口。其中interface-type interface-number表示接口类型和接口编号。如果用户接入的接口与此处绑定的接口不一致,则认证失败。该绑定属性仅适用于lan-access、PPP、IPoE类型的用户。
mac mac-address:指定用户的MAC地址。其中,mac-address为H-H-H格式。该绑定属性仅适用于lan-access、PPP、IPoE类型的用户。
vlan vlan-id:指定用户所属于的VLAN。其中,vlan-id为VLAN编号,取值范围为1~4094。该绑定属性仅适用于lan-access、PPP、IPoE类型的用户。
设备对用户进行本地认证时,会检查用户的实际属性与配置的绑定属性是否一致,如果不一致或用户未携带该绑定属性则认证失败。
绑定属性的检测不区分用户的接入服务类型,因此在配置绑定属性时要考虑某接入类型的用户是否需要绑定某些属性。
# 配置网络接入类本地用户abc的绑定MAC地址为0001-0002-0003。
[Sysname-luser-network-abc] bind-attribute mac 0001-0002-0003
company命令用来配置本地来宾用户所属公司。
undo company命令用来恢复缺省情况。
company company-name
undo company
未配置本地来宾用户所属公司。
本地来宾用户视图
company-name:本地来宾用户所属公司名称,为1~255个字符的字符串,区分大小写。
# 配置本地来宾用户abc所属的公司名称为yyy。
[Sysname] local-user abc class network guest
[Sysname-luser-network(guest)-abc] company yyy
description命令用来配置本地来宾用户的描述信息。
undo description命令用来恢复缺省情况。
未配置本地来宾用户的描述信息。
本地来宾用户视图
text:本地来宾用户的描述信息,为1~255个字符的字符串,区分大小写。
# 配置本地来宾用户abc的描述信息为Manager of MSC company。
[Sysname-luser-network(guest)-abc] description Manager of MSC company
display local-user命令用来显示本地用户的配置信息和在线用户数的统计信息。
display local-user [ class { manage | network [ guest ] } | idle-cut { disable | enable } | service-type { ftp | http | https | ipoe | lan-access | ppp | ssh | telnet | terminal } | state { active | block } | user-name user-name class { manage | network [ guest ] } | vlan vlan-id ]
class:显示指定用户类别的本地用户信息。
manage:设备管理类用户。
network:网络接入类用户。
guest:来宾用户。
idle-cut { disable | enable }:显示开启或关闭闲置切断功能的本地用户信息。其中,disable表示未启用闲置切断功能的本地用户;enable表示启用了闲置切断功能并配置了闲置切断时间的本地用户。
service-type:显示指定用户类型的本地用户信息。
· ftp:FTP用户。
· http:HTTP用户。
· https:HTTPS用户。
· ipoe:IPoE用户(主要指IP接入用户,比如二/三层专线用户,数字机顶盒接入用户)。
· lan-access:lan-access类型用户(主要指以太网接入用户)。
· ppp:PPP用户。
· ssh:SSH用户。
· telnet:Telnet用户。
· terminal:从Console口登录的终端用户。
state { active | block }:显示处于指定状态的本地用户信息。其中,active表示用户处于活动状态,即系统允许该用户请求网络服务;block表示用户处于阻塞状态,即系统不允许用户请求网络服务。
user-name user-name:显示指定用户名的本地用户信息。user-name表示本地用户名,为1~80个字符的字符串,可以为“纯用户名@域名”或者纯用户名。其中,纯用户名区分大小写,不能包含符号“\”、“|”、“/”、“*”、“?”、“<”、“>”和“@”,并且不能为“a”、“al”或“all”;域名不区分大小写,不能包含符号“@”。
vlan vlan-id:显示指定VLAN内的所有本地用户信息。其中,vlan-id为VLAN编号,取值范围为1~4094。
如果不指定任何参数,则显示所有本地用户信息。
# 显示所有本地用户的相关信息。
<Sysname> display local-user
Total 3 local users matched.
Device management user root:
State: Active
Service type: SSH/Telnet/Terminal
Access limit: Enabled Max access number: 3
Current access number: 1
User group: system
Bind attributes:
Work directory: flash:
User role list: network-admin
Password aging: 3 days
Password remaining lifetime: 2 days 12 hours 30 minutes 30 seconds
Password history was last reset: 0 days ago
Validity period:
Start date and time: 2022/03/08-11:11:11
Expiration date and time: 2022/03/08-12:00:00
Network access user jj:
State: Active
Service type: LAN access
User group: system
Bind attributes:
Location bound: Ten-GigabitEthernet3/0/1
MAC address: 0001-0001-0001
VLAN ID: 2
Idle timeout: 33 minutes
ACL number: 2000
User profile: pp
Network access guest user user1:
State: Active
User group: guest1
Full name: Jack
Company: cc
Email: Jack@cc.com
Phone: 131129237
Description: A guest from company cc
Sponsor full name: Sam
Sponsor department: security
Sponsor email: Sam@aa.com
Period of validity:
Start date and time: 2019/04/01-08:00:00
Expiration date and time:2019/04/03-18:00:00
表1-8 display local-user命令显示信息描述表
Total x local users matched. |
总计有x个本地用户匹配 |
State |
本地用户状态 · Active:活动状态 · Block:阻塞状态 |
Service type |
本地用户使用的服务类型 |
Access limit |
是否对使用该用户名的接入用户数进行限制 |
Max access number |
最大接入用户数 |
Current access number |
使用该用户名的当前接入用户数 |
User group |
本地用户所属的用户组 |
Bind attributes |
本地用户的绑定属性 |
IP address |
本地用户的IP地址 |
Location bound |
本地用户绑定的端口 |
MAC address |
本地用户的MAC地址 |
VLAN ID |
本地用户绑定的VLAN |
Calling number |
(暂不支持)ISDN用户的主叫号码 |
本地用户的授权属性 |
Idle timeout |
本地用户闲置切断时间(单位为分钟) |
Session-timeout |
本地用户的会话超时时间(单位为分钟) |
Callback number |
本地用户的授权PPP回呼号码 |
Work directory |
FTP/SFTP/SCP用户可以访问的目录 |
ACL number |
本地用户授权ACL |
VLAN ID |
本地用户授权VLAN |
User profile |
本地用户授权User Profile |
User role list |
本地用户的授权用户角色列表 |
IP pool |
本地用户的授权IPv4地址池 |
NetStream sampler |
本地用户的授权采样器及NetStream流量统计方向 |
IP address |
本地用户的授权IPv4地址 |
IPv6 address |
本地用户的授权IPv6地址 |
IPv6 prefix |
本地用户的授权IPv6前缀 |
IPv6 pool |
本地用户的授权IPv6地址池 |
本地用户的授权主DNS服务器IPv4地址 |
本地用户的授权从DNS服务器IPv4地址 |
本地用户的授权主DNS服务器IPv6地址 |
本地用户的授权从DNS服务器IPv6地址 |
URL |
本地用户的授权PADM URL |
VPN instance |
本地用户的授权VPN实例 |
Subscriber ID |
本地用户的授权Subscriber ID |
本地用户的授权Session Group Profile |
Password control configurations |
本地用户的密码控制属性 |
Password aging |
密码老化时间 |
Password length |
密码最小长度 |
Password composition |
密码组合策略(密码元素的组合类型、至少要包含每种元素的个数) |
Password complexity |
密码复杂度检查策略(是否包含用户名或者颠倒的用户名;是否包含三个或以上相同字符) |
Maximum login attempts |
用户最大登录尝试次数 |
Action for exceeding login attempts |
登录尝试次数达到设定次数后的用户账户锁定行为 |
Password history was last reset |
上一次清除密码历史记录的时间 |
Password remaining lifetime |
剩余密码老化时间 |
上一次清除密码历史记录的时间 |
Validity period |
设备管理类本地用户有效期 |
Start date and time |
设备管理类本地用户开始生效的日期和时间 |
Expiration date and time |
设备管理类本地用户的失效日期和时间 |
Full name |
本地来宾用户的姓名 |
Company |
本地来宾用户的公司 |
本地来宾用户的Email地址 |
Phone |
本地来宾用户的电话号码 |
本地来宾用户的描述信息 |
Sponsor full name |
本地来宾用户接待人的姓名 |
Sponsor department |
本地来宾用户接待人所属部门 |
Sponsor email |
本地来宾用户接待人的Email地址 |
Period of validity |
本地来宾用户有效期 |
本地来宾用户开始生效的日期和时间 |
本地来宾用户的失效日期和时间 |
display user-group命令用来显示用户组的配置信息。
display user-group { all | name group-name }
all:显示所有用户组的配置信息。
name group-name:显示指定用户组的配置。group-name表示用户组名称,为1~32个字符的字符串,不区分大小写。
# 显示所有用户组的相关配置。
<Sysname> display user-group all
Total 2 user groups matched.
User group: system
Authorization attributes:
User group: jj
Callback number: 2:2
Work directory: flash:/
ACL number: 2000
VLAN ID: 2
User profile: pp
PPPoE agency authentication domain: dm1
Forwarding policies for PPPoE agency dialup:
IPv4 ACL: 3000 (private)
IPv6 ACL: testacl (public)
Password aging: 2 days
表1-9 display user-group命令显示信息描述表
Total 2 user groups matched. |
总计有2个用户组匹配 |
授权属性信息 |
Idle timeout |
闲置切断时间(单位:分钟) |
Session-timeout |
Callback number |
PPP回呼号码 |
Work directory |
ACL number |
授权ACL号 |
VLAN ID |
授权VLAN ID |
User profile |
授权User Profile名称 |
IP pool |
授权IPv4地址池 |
IPv6 prefix |
授权IPv6前缀 |
IPv6 pool |
授权IPv6地址池 |
授权主DNS服务器IPv4地址 |
授权从DNS服务器IPv4地址 |
授权主DNS服务器IPv6地址 |
授权从DNS服务器IPv6地址 |
URL |
授权强制URL |
Subscriber ID |
授权Subscriber ID |
授权Session Group Profile名称 |
VPN instance |
授权VPN实例 |
PPPoE agency authentication domain |
PPPoE代拨用户的认证域 若不配置,则不显示该字段 |
Forwarding policies for PPPoE agency dialup |
PPPoE代拨转发策略 若不配置,则不显示该字段 |
IPv4 ACL |
匹配用户流量的IPv4 ACL编号或名称(流量类型) 流量类型取值包括: · private:内网流量,不需要PPPoE代拨转发 · public:外网流量,需要PPPoE代拨转发 |
IPv6 ACL |
匹配用户流量的IPv6 ACL编号或名称(流量类型) 流量类型取值包括: · private:内网流量,不需要PPPoE代拨转发 · public:外网流量,需要PPPoE代拨转发 |
用户组的密码控制属性 |
Password aging |
密码老化时间 |
Password length |
密码最小长度 |
用户最大登录尝试次数 |
display user-group identity-active命令用来显示处于激活状态的身份识别用户组。
当身份识别用户组被安全特性引用之后,若该引用配置生效,则该用户组将处于激活状态。只有身份识别用户组处于激活状态时,该用户组才能在基于用户身份的访问控制过程中生效。
# 显示处于激活状态的身份识别用户组。
<Sysname> display user-group identity-active
Group ID Group name
0x1 group1
0x567 group2
表1-10 display user-group identity-active命令显示信息描述表
总计有2个身份识别用户组匹配 |
Group ID |
身份识别用户组的ID |
Group name |
身份识别用户组的名称 |
email命令用来配置本地来宾用户的Email地址。
undo email命令用来恢复缺省情况。
email email-string
undo email
未配置本地来宾用户的Email地址。
本地来宾用户视图
email-string:本地来宾用户的Email地址,为按照RFC 822定义的1~255个字符的字符串,区分大小写,例如sec@abc.com。
设备可以通过本命令配置的Email地址给来宾用户发送通知邮件。
# 配置本地来宾用户abc的Email地址为abc@yyy.com。
[Sysname-luser-network(guest)-abc] email abc@yyy.com
full-name命令用来配置本地来宾用户的姓名。
undo full-name命令用来恢复缺省情况。
full-name name-string
undo full-name
未配置本地来宾用户的姓名。
本地来宾用户视图
name-string:本地来宾用户的姓名,为1~255个字符的字符串,区分大小写。
# 配置本地来宾用户abc的姓名为abc Snow。
[Sysname-luser-network(guest)-abc] full-name abc Snow
group命令用来设置本地用户所属的用户组。
undo group命令用来恢复缺省配置。
group group-name
undo group
本地用户属于用户组system。
本地用户视图
group-name:用户组名称,为1~32个字符的字符串,不区分大小写。
# 设置设备管理类本地用户111所属的用户组为abc。
[Sysname] local-user 111 class manage
[Sysname-luser-manage-111] group abc
local-guest auto-delete enable用来开启来宾用户过期自动删除功能。
undo local-guest auto-delete enable用来恢复缺省情况。
来宾用户过期自动删除功能处于关闭状态。
来宾用户过期自动删除功能处于开启状态时,设备会在来宾用户有效期结束后自动删除用户。
# 开启来宾用户过期自动删除功能。
[Sysname] local-guest auto-delete enable
· validity-datatime
local-guest email format命令用来配置本地来宾用户通知邮件的主题和内容。
undo local-guest email format命令用来删除指定的本地来宾用户通知邮件的主题和内容。
local-guest email format to { guest | sponsor } { body body-string | subject sub-string }
undo local-guest email format to { guest | sponsor } { body | subject }
未配置本地来宾用户通知邮件的主题和内容。
to:指定邮件的收件人。
· guest:表示来宾用户。
· sponsor:表示来宾接待人。
body body-string:邮件的内容。其中,body-string为1~255个字符的字符串,区分大小写。
subject sub-string:邮件的主题。其中,sub-string为1~127个字符的字符串,区分大小写。
在本地来宾用户创建过程中,设备需要向不同角色的用户发送通知邮件,邮件的主题和内容通过本命令设置。
可对不同的收件人指定不同的邮件主题和内容。同一类收件人的邮件格式只能存在一种配置,新配置将覆盖已有配置。
必须同时配置收件人的邮件主题和内容,否则设备不会给该收件人发送邮件。
# 配置本地来宾用户通知邮件的主题和内容。
[Sysname] local-guest email format to guest subject Guest account information
[Sysname] local-guest email format to guest body A guest account has been created for you. The username, password, and validity period of the account are given below.
· local-guest email sender
· local-guest email smtp-server
· local-guest send-email
local-guest email sender命令用来配置本地来宾用户通知邮件的发件人地址。
undo local-guest email sender命令用来恢复缺省情况。
local-guest email sender email-address
未配置本地来宾用户通知邮件的发件人地址。
email-address:邮件发件人地址,为1~255个字符的字符串,区分大小写。
未配置发件人地址的情况下,设备无法向任何收件人发送关于本地来宾用户的通知邮件。
只能存在一个本地来宾用户的发件人地址。多次执行本命令,最后一次执行的命令生效。
# 配置本地来宾用户通知邮件的发件人地址为abc@yyy.com。
[Sysname] local-guest email sender abc@yyy.com
· local-guest email format
local-guest email smtp-server命令用来配置为本地来宾用户发送Email使用的SMTP服务器。
undo local-guest send-email smtp-server命令用来恢复缺省情况。
local-guest email smtp-server url-string
undo local-guest email smtp-server
未配置为本地来宾用户发送Email使用的SMTP服务器。
url-string:STMP服务器的URL,为1~255个字符的字符串,区分大小写,符合标准SMTP协议规范,以smtp://开头。
只能存在一个为本地来宾用户发送Email使用的SMTP服务器。多次执行本命令,最后一次执行的命令生效。
# 配置为本地来宾用户发送Email使用的SMTP服务器URL为smtp://www.test.com/smtp。
[Sysname] local-guest email smtp-server smtp://www.test.com/smtp
local-guest generate命令用来批量创建本地来宾用户。
local-guest generate username-prefix name-prefix [ password-prefix password-prefix ] suffix suffix-number [ group group-name ] count user-count validity-datetime start-date start-time to expiration-date expiration-time
username-prefix name-prefix:用户名前缀,name-prefix为1~70个字符的字符串,区分大小写,不能含有字符\、|、/、*、?、<、>或@。
password-prefix password-prefix:明文密码前缀,password-prefix为1~53个字符的字符串,区分大小写。若不指定该参数,则由系统为用户逐一生成随机密码
suffix suffix-string:用户名和密码的递增编号后缀,suffix-string为1~10个数字的字符串。
group group-name:用户所属用户组名,group-name为1~32个字符的字符串,区分大小写。若不指定该参数,则表示用户属于system组。
count user-count:批量创建用户的数量,user-count的取值范围为1~256。
validity-datetime:用户有效期。
start-date:用户有效期的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
start-time:用户有效期的开始时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。比如将start-time参数设置为0表示零点。
to:指定用户有效期的结束日期和结束时间。
expiration-date:用户有效期的结束日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
expiration-time:用户有效期的结束时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。比如将expiration-time参数设置为0表示零点。
批量创建的本地来宾用户名由指定的用户名前缀和编号后缀组合而成,且每创建一个用户,用户名编号后缀递增1。例如,当用户名前缀为abc,递增编号后缀为1,生成用户数量为3时,生成的用户名分别为abc1、abc2和abc3。如果指定了密码前缀,则批量创建的本地来宾用户密码由密码前缀和编号后缀组合而成,且逐用户递增。
如果申请创建的本地来宾用户数量过多,导致资源不足时,部分本地来宾用户的批量创建将会失败。
如果批量创建的本地来宾用户与设备上已有的本地来宾用户重名,则批量创建的用户会覆盖已有的同名用户。
# 批量创建20个本地来宾用户,用户名从abc01递增到abc20,属于用户组visit,有效期为2019/05/01 00:00:00到2019/05/02 12:00:00。
[Sysname] local-guest generate username-prefix abc suffix 01 group visit count 20 validity-datetime 2019/05/01 00:00:00 to 2019/05/02 12:00:00
· local-user
local-guest send-email命令用来配置向本地来宾用户邮箱和来宾接待人邮箱发送邮件。
local-guest send-email user-name user-name to { guest | sponsor }
user-name user-name:本地来宾用户的用户名,为1~80个字符的字符串,可以为“纯用户名@域名”或者纯用户名。其中,纯用户名区分大小写,不能包含符号“\”、“|”、“/”、“*”、“?”、“<”、“>”和“@”,并且不能为“a”、“al”或“all”;域名不区分大小写,不能包含符号“@”。
to:指定邮件的收件人。
· guest:本地来宾用户。
· sponsor:来宾接待人。
当本地来宾用户创建之后,来宾管理员可通过此命令将用户的密码及有效期信息发送到本地来宾用户或来宾接待人邮箱中。
# 向本地来宾用户abc的邮箱发送有关该用户帐号信息的通知邮件。
<Sysname> local-guest send-email user-name abc to guest
· sponsor-email
local-user命令用来添加本地用户,并进入本地用户视图。如果指定的本地用户已经存在,则直接进入本地用户视图。
undo local-user命令用来删除指定的本地用户。
local-user user-name [ class { manage | network [ guest ] } ]
undo local-user { user-name class { manage | network [ guest ] } | all [ service-type ftp | http | https | ipoe | lan-access | ppp | ssh | telnet | terminal } | class { manage | network [ guest ] } ] }
不存在本地用户。
user-name:表示本地用户名,为1~80个字符的字符串,可以为“纯用户名@域名”或者纯用户名。其中,纯用户名区分大小写,不能包含符号“\”、“|”、“/”、“*”、“?”、“<”、“>”和“@”,并且不能为“a”、“al”或“all”;域名不区分大小写,不能包含符号“@”。
class:指定本地用户的类别。若不指定本参数,则表示设备管理类用户。
manage:设备管理类用户,用于登录设备,对设备进行配置和监控。此类用户可以提供ftp、http、https、telnet、ssh、terminal服务。
network:网络接入类用户,用于通过设备接入网络,访问网络资源。此类用户可以提供ipoe、lan-access服务。
guest:来宾用户,仅能在账户有效期内提供lan-access服务。
all:所有的用户。
service-type:指定用户的类型。
· ftp:表示FTP类型用户。
· http:表示HTTP类型用户。
· https:表示HTTPS类型用户。
· ipoe:表示IPoE类型用户(主要指以IP接入用户,比如二三层专线,数字机顶盒接入的用户)。
· lan-access:表示lan-access类型用户(主要指以太网接入用户)。
· ppp:PPP用户。
· ssh:表示SSH用户。
· telnet:表示Telnet用户。
· terminal:表示从Console口登录的终端用户。
设备支持配置多个本地用户,设备管理类本地用户的最大数目为1024,网络接入类本地用户的最大数目为1024。
如果配置的本地用户名中包含中文,则需要该本地用户登录设备时使用的终端软件采用的字符集编码格式和设备保存该本地用户配置时采用的编码格式(GB18030)保持一致,否则,可能导致包含中文字符的用户名在设备上不能按照预期解析,甚至导致本地认证失败。
# 添加名称为user1的设备管理类本地用户。
[Sysname-luser-manage-user1]
# 添加名称为user2的网络接入类本地用户。
[Sysname] local-user user2 class network
[Sysname-luser-network-user2]
# 添加名称为user3的网络接入类本地来宾用户。
[Sysname] local-user user3 class network guest
[Sysname-luser-network(guest)-user3]
· service-type
local-user-export命令用来从设备导出本地来宾用户信息到指定路径的CSV文件。
local-user-export class network guest url url-string
class:指定本地用户的类别。
network:网络接入类用户。
guest:本地来宾用户。
url url-string:保存本地用户信息文件的URL,为1~255个字符的字符串,不区分大小写。
导出的CSV文件可直接或在编辑之后通过local-user-import命令导入到本设备或其它支持该命令的设备上使用,但文件内容必须符合该命令的要求。
本命令支持TFTP和FTP两种文件上传方式,具体的URL格式要求如下:
· TFTP协议URL格式:tftp://server/path/filename,server为TFTP服务器IP地址或主机名,path为TFTP工作目录的相对路径,例如tftp://1.1.1.1/user/user.csv。
· FTP协议URL格式:
¡ 携带用户名和密码的格式为ftp://username:password@server/path/filename。其中,username为FTP用户名,password为FTP认证密码,server为FTP服务器IP地址或主机名,path为FTP工作目录的相对路径,例如ftp://1:1@1.1.1.1/user/user.csv。如果FTP用户名中携带域名,则该域名会被设备忽略,例如ftp://1@abc:1@1.1.1.1/user/user.csv将被当作ftp://1:1@1.1.1.1/user/user.csv处理。
¡ 不需要携带用户名和密码的格式为ftp://server/path/filename,例如ftp://1.1.1.1/user/user.csv。
# 导出本地来宾用户信息到ftp://1.1.1.1/user/路径的guest.csv文件中。
[Sysname] local-user-export class network guest url ftp://1.1.1.1/user/guest.csv
· local-user-import
local-user-import命令用来从指定路径的文件中导入用户信息并创建本地用户。
local-user-import class network guest url url-string validity-datetime start-date start-time to expiration-date expiration-time [ auto-create-group | override | start-line line-number ] *
class:指定本地用户的类别。
network:网络接入类用户。
guest:本地来宾用户。
url url-string:要导入用户信息文件的URL。其中,url-string为1~255个字符的字符串,不区分大小写。
validity-datetime:指定用户的有效期。
auto-create-group:表示当设备上不存在用户所属的用户组时,系统会自动创建用户组,并将用户加入该用户组。若不指定该参数,则表示当设备上不存在用户所属的用户组时,系统不会创建对应的用户组,而是将该用户加入缺省用户组system。
override:表示当导入的用户名已经存在于设备上时,系统使用导入的用户信息覆盖掉已有的同名用户配置。若不指定该参数,则表示不导入文件中的同名用户信息,即保留设备上已有的同名用户配置。
start-line line-number:表示从文件的指定行开始导入用户信息。其中,line-number为文件内容的行编号。若不指定该参数,则表示导入文件中的所有用户信息。
用于导入的CSV文件中包含多个用户信息,每个用户的各项字段严格按照以下顺序出现:
· Username:用户名。该字段必须存在。
· Password:明文用户密码。若该字段为空,则导入时系统会生成一个密文随机密码。
· User group:所属用户组,用于本地授权。若该字段为空,则表示属于system组。
· Guest full name:来宾用户姓名。
· Guest company:来宾用户公司。
· Guest email:来宾用户Email地址。
· Guest phone:来宾用户电话号码。
· Guest description:来宾用户描述信息。
· Sponsor full name:接待人姓名。
· Sponsor department:接待人部门。
· Sponsor email:接待人Email地址。
以上所有字段的取值必须满足设备上本地用户相应属性的取值要求,否则当前用户的导入操作将会失败,且导入操作中止。之后,可以根据系统提示信息中的出错行编号选择下次从指定行开始导入剩余用户信息。
CSV文件中的不同用户信息之间用回车换行分隔,且每项信息之间以逗号分隔。如果某项信息中包含逗号,则必须在该条信息两端加双引号。例如:Jack,abc,visit,Jack Chen,ETP,jack@etp.com,1399899,”The manager of ETP, come from TP.”,Sam Wang,Ministry of personnel,Sam@yy.com
本命令支持TFTP和FTP两种文件下载方式,具体的文件URL格式要求如下:
· FTP协议URL格式:
¡ 不需要携带用户名和密码的格式为ftp://path/filename,例如ftp://1.1.1.1/user/user.csv。
# 从ftp://1.1.1.1/user/guest.csv路径中导入本地来宾用户信息,用户的有效期为2019/05/01 00:00:00到2019/05/02 12:00:00。
[Sysname] local-user-import class network guest url ftp://1.1.1.1/user/guest.csv validity-datetime 2019/05/01 00:00:00 to 2019/05/02 12:00:00
· local-user-export
password命令用来设置本地用户的密码。
undo password命令用来恢复缺省情况。
password [ { hash | simple } string ]
undo password
不存在本地用户密码,即本地用户认证时无需输入密码,只要用户名有效且其它属性验证通过即可认证成功。
设备管理类本地用户视图
hash:表示以哈希方式设置密码。
simple:表示以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为x~63个字符的字符串;哈希密码为1~110个字符的字符串。若Password Control的密码最小长度管理功能处于开启状态,则x取值由password-control length命令取值决定;若Password Control的密码最小长度管理功能处于关闭状态,则x取值为1。 Password Control相关命令的详细介绍,请参见“安全命令参考”中的“Password Control”。
如果不指定任何参数,则表示以交互式设置明文形式的密码。
可以不为本地用户设置密码。若不为本地用户设置密码,则该用户认证时无需输入密码,只要用户名有效且其它属性验证通过即可认证成功。为提高用户账户的安全性,建议设置本地用户密码。
# 设置设备管理类本地用户user1的密码为明文123456TESTplat&!。
# 以交互式方式设置设备管理类本地用户test的密码。
[Sysname-luser-manage-test] password
Password:
confirm :
undo password
网络接入类本地用户视图
cipher:表示以密文方式设置密码。
string:密码字符串,区分大小写。明文密码为1~63个字符的字符串;密文密码为1~117个字符的字符串。
# 设置网络接入类本地用户user1的密码为明文123456TESTuser&!。
[Sysname] local-user user1 class network
[Sysname-luser-network-user1] password simple 123456TESTuser&!
phone命令用来配置本地来宾用户的电话号码。
undo phone命令用来恢复缺省情况。
phone phone-number
undo phone
未配置本地来宾用户电话号码。
本地来宾用户视图
phone-number:本地来宾用户的电话号码,为1~32个字符的字符串。
# 配置本地来宾用户abc的电话号码为13813723920。
[Sysname-luser-network(guest)-abc] phone 13813723920
service-type命令用来设置用户可以使用的服务类型。
undo service-type命令用来删除用户可以使用的服务类型。
service-type { ftp | ipoe | lan-access | { http | https | ssh | telnet | terminal } * | ppp }
undo service-type { ftp | ipoe | lan-access | { http | https | ssh | telnet | terminal } * | ppp }
系统不对用户授权任何服务,即用户不能使用任何服务。
本地用户视图
ftp:指定用户可以使用FTP服务。若授权FTP服务,缺省授权FTP用户可访问设备的根目录,授权目录可以通过authorization-attribute work-directory命令来修改。
http:指定用户可以使用HTTP服务。
https:指定用户可以使用HTTPS服务。
ipoe:指定用户可以使用IPoE服务。
lan-access:指定用户可以使用lan-access服务。主要指以太网接入。
ssh:指定用户可以使用SSH服务。
telnet:指定用户可以使用Telnet服务。
terminal:指定用户可以使用terminal服务(即从Console口登录)。
ppp:指定用户可以使用PPP服务。
可以通过多次执行本命令,设置用户可以使用多种服务类型。
# 指定设备管理类用户可以使用Telnet服务和FTP服务。
[Sysname-luser-manage-user1] service-type telnet
[Sysname-luser-manage-user1] service-type ftp
snmp-agent trap enable user-group命令用来开启用户组告警功能。
undo snmp-agent trap enable user-group命令用来关闭用户组告警功能。
snmp-agent trap enable user-group [ max-count-threshold ]
undo snmp-agent trap enable user-group [ max-count-threshold ]
用户组告警功能处于关闭状态。
max-count-threshold:表示用户组数目阈值告警功能。
开启用户组数目阈值告警功能后,系统将会生成以下几种告警信息:
· 当设备上配置的用户组数目达到允许的最大值时,将输出对应的告警信息。此时,系统中不允许配置新的用户组。
· 当设备上配置的用户组数目回落到最大值的90%以下时,将输出对应的恢复告警信息。
若不指定任何参数,则表示开启或关闭所有用户组告警功能。
# 开启用户组数目阈值告警功能。
[Sysname] snmp-agent trap enable user-group max-count-threshold
· user-group
sponsor-department命令用来配置本地来宾用户接待人所属部门。
undo sponsor-department命令用来恢复缺省情况。
sponsor-department department-string
未配置本地来宾用户接待人所属部门。
department-string:本地来宾用户接待人所属部门名称,为1~127个字符的字符串,区分大小写。
# 配置本地来宾用户abc的接待人所属部门为test。
[Sysname-luser-network(guest)-abc] sponsor-department test
sponsor-email命令用来配置本地来宾用户接待人的Email地址。
undo sponsor-email命令用来恢复缺省情况。
sponsor-email email-string
undo sponsor-email
未配置本地来宾用户接待人的Email地址。
本地来宾用户视图
email-string:本地来宾接待人的Email地址,为按照RFC 822定义的1~255个字符的字符串,区分大小写。
# 配置本地来宾用户abc的接待人Email地址为Sam@a.com。
[Sysname-luser-network(guest)-abc] sponsor-email Sam@a.com
sponsor-full-name命令用来配置本地来宾用户的接待人姓名。
undo sponsor-full-name命令用来恢复缺省情况。
sponsor-full-name name-string
未配置本地来宾用户的接待人姓名。
本地来宾用户视图
name-string:本地来宾用户接待人姓名,为1~255个字符的字符串,区分大小写。
# 配置本地来宾用户abc的接待人姓名为Sam Li。
[Sysname-luser-network(guest)-abc] sponsor-full-name Sam Li
state命令用来设置当前本地用户的状态。
undo state
本地用户处于活动状态。
本地用户视图/本地来宾用户视图
active:指定当前本地用户处于活动状态,即系统允许当前本地用户请求网络服务。
block:指定当前本地用户处于“阻塞”状态,即系统不允许当前本地用户请求网络服务。
# 设置设备管理类本地用户user1处于“阻塞”状态。
[Sysname-luser-manage-user1] state block
user-group命令用来创建用户组,并进入用户组视图。如果指定的用户组已经存在,则直接进入用户组视图。
undo user-group命令用来删除指定的用户组。
undo user-group group-name
存在一个用户组,名称为system。
用户组是一个本地用户的集合,某些需要集中管理的属性可在用户组中统一配置和管理。
不允许删除一个包含本地用户的用户组。
不能删除系统中存在的默认用户组system,但可以修改该用户组的配置。
# 创建名称为abc的用户组并进入其视图。
validity-datetime命令用来配置本地来宾用户的有效期。
undo validity-datetime命令用来恢复缺省情况。
未限制本地来宾用户的有效期,该用户始终有效。
本地来宾用户视图
本地来宾用户有效期的结束时间必须晚于起始时间。
本地来宾用户在有效期内才能认证成功。
# 配置本地来宾用户abc的有效期为2019/05/01 00:00:00到2019/05/02 12:00:00。
[Sysname-luser-network(guest)-abc] validity-datetime 2019/05/01 00:00:00 to 2019/05/02 12:00:00
validity-datetime命令用来配置设备管理类本地用户的有效期。
validity-datetime { from start-date start-time to expiration-date expiration-time | from start-date start-time | to expiration-date expiration-time }
未限制设备管理类本地用户的有效期,该用户始终有效。
设备管理类本地用户视图
设备管理类本地用户有效期的结束时间必须晚于起始时间。
设备管理类本地用户在有效期内才能认证成功。
# 配置设备管理类本地用户abc的有效期为2022/03/01 00:00:00到2022/05/02 12:00:00。
[Sysname] local-user abc class manage
[Sysname-luser-manage-abc] validity-datetime 2022/03/01 00:00:00 to 2022/05/02 12:00:00
aaa device-id命令用来配置设备ID。
undo aaa device-id命令用来恢复缺省情况。
aaa device-id device-id
undo aaa device-id
设备ID为0。
device-id:设备ID,取值范围为1~255。
RADIUS计费过程使用Acct-Session-Id属性作为用户的计费ID。设备使用系统时间、随机数以及设备ID为每个在线用户生成一个唯一的Acct-Session-Id值。
修改后的设备ID仅对新上线用户生效。
# 配置设备ID为1。
[Sysname] aaa device-id 1
aaa nas-port-id vlanid uppercase命令用来设置NAS-Port-ID属性中携带的VLANID字符串为大写。
undo aaa nas-port-id vlanid uppercase命令用来恢复缺省情况。
NAS-Port-ID属性中携带的VLANID字符串为小写。
某些组网环境中,RADIUS服务器要求接入设备发送的NAS-Port-ID属性携带的vlanid字符串均为大写字母,此时就需要通过配置aaa nas-port-id vlanid uppercase命令将NAS-Port-ID属性中携带的小写“vlanid”转换为大写“VLANID”。例如,缺省情况下某NAS-Port-ID属性的内容为slot=xx;subslot=xx;port=xx;vlanid=xx(xx表示各字段取值),则转换后为slot=xx;subslot=xx;port=xx;VLANID=xx。
# 设置NAS-Port-ID属性中携带的VLANID字符串为大写。
[Sysname] aaa nas-port-id vlanid uppercase
accounting-on enable命令用来开启accounting-on功能。
undo accounting-on enable命令用来关闭accounting-on功能。
accounting-on enable [ interval interval | send send-times ] *
accounting-on功能处于关闭状态。
RADIUS方案视图
interval interval:指定accounting-on报文重发时间间隔,取值范围为1~15,单位为秒,缺省值为3。
send send-times:指定accounting-on报文的最大发送次数,取值范围为1~255,缺省值为50。
accounting-on功能使得整个设备在重启之后通过发送accounting-on报文通知该方案所使用的RADIUS计费服务器,要求RADIUS服务器停止计费且强制该设备的用户下线。
开启accounting-on功能后,请执行save命令保证accounting-on功能在整个设备下次重启后生效。关于命令的详细介绍请参见“基础配置命令参考”中的“配置文件管理”。
本命令设置的accounting-on参数会立即生效。
# 在RADIUS方案radius1中,开启accounting-on功能并配置accounting-on报文重发时间间隔为5秒、accounting-on报文的最大发送次数为15次。
[Sysname] radius scheme radius1
[Sysname-radius-radius1] accounting-on enable interval 5 send 15
· display radius scheme
accounting-on extended命令用来开启accounting-on扩展功能。
undo accounting-on extended命令用来关闭accounting-on扩展功能。
accounting-on扩展功能处于关闭状态。
RADIUS方案视图
accounting-on扩展功能是为了适应分布式架构而对accounting-on功能的增强。只有在accounting-on功能开启的情况下,accounting-on扩展功能才能生效。
accounting-on扩展功能适用于lan-access用户,该类型的用户数据均保存在用户接入的单板上。开启accounting-on扩展功能后,当有用户发起接入认证的单板重启时(整机未重启),设备会向RADIUS服务器发送携带单板标识的accounting-on报文,用于通知RADIUS服务器对该单板的用户停止计费且强制用户下线。accounting-on报文的重发间隔时间以及最大发送次数由accounting-on enable命令指定。如果自上一次重启之后,单板上没有用户接入认证的记录,则该单板再次重启,并不会触发设备向RADIUS服务器发送携带单板标识的accounting-on报文。
开启accounting-on扩展功能后,请执行save命令保证accounting-on扩展功能在单板下次重启后生效。关于save命令的详细介绍请参见“基础配置命令参考”中的“配置文件管理”。
# 在RADIUS方案radius1中,开启accounting-on扩展功能。
[Sysname-radius-radius1] accounting-on extended
· accounting-on enable
attribute 5 format命令用来配置RADIUS Attribute 5的封装格式。
undo attribute 5 format命令用来恢复缺省情况。
attribute 5 format qinq
采用单层VLAN格式封装RADIUS Attribute 5,具体为:槽位号(8bit)+子槽位号(4bit)+端口号(8bit)+VLAN ID(12bit)。
RADIUS方案视图
qinq:表示采用QinQ格式封装RADIUS Attribute 5,具体为:槽位号(3bit)+子槽位号(1bit)+端口号(4bit)+S-VLAN ID(12bit)+C-VLAN ID(12bit)。
RADIUS Attribute 5为NAS-Port属性。QinQ组网情况下,建议配置采用QinQ格式封装RADIUS Attribute 5。
如果配置了采用QinQ格式封装RADIUS Attribute 5,但实际用户接入网络为非QINQ组网,系统仍然会按照QinQ格式填充RADIUS Attribute 5,考虑到用户认证报文仅携带一层VLAN信息,S-VLAN区段将会用0填充。
# 在RADIUS方案rad中,配置采用QinQ格式封装RADIUS Attribute 5。
[Sysname-radius-rad] attribute 5 format qinq
attribute 6 value命令用来配置RADIUS Attribute 6的值。
undo attribute 6 value命令用来恢复缺省情况。
attribute 6 value outbound user-type ipoe [ value-added-service ]
undo attribute 6 value outbound user-type ipoe
设备向服务器发送RADIUS报文时,针对不同的用户,RADIUS Attribute 6的取值不同:对于设备管理用户,取值为Login(1);其他用户取值为Framed(2)。
RADIUS方案视图
outbound:表示取值为Outbound,对应取值编码为5。目前仅支持取值为Outbound。
user-type ipoe:表示接入用户类型为IPoE。目前,仅支持对IPoE用户进行设置。
value-added-service:表示本属性值对用户增值业务的RADIUS报文也生效。若不指定该参数,则表示本属性值仅对用户普通业务的RADIUS报文生效。
RADIUS的6号属性是Service-Type属性。不同的RADIUS服务器对填充在RADIUS Attribute 6中的属性值有不同的要求,为了保证RADIUS报文的正常交互,设备发送给服务器的RADIUS Attribute 6号属性值必须与服务器的要求保持一致。
如果运营商希望设备发送的IPoE用户的认证请求报文和计费请求报文中的Service-Type属性值为Outbound(5),就需要在对应的RADIUS方案视图下配置attribute 6 value outbound user-type ipoe。如果还希望该设置对用户增值业务的RADIUS报文也生效,则需要该命令携带value-added-service参数。
# 在RADIUS方案radius1中,配置设备向服务器发送IPoE用户的RADIUS报文时,RADIUS Attribute 6的取值为Outbound,且该取值对用户的增值业务也生效。
[Sysname-radius-radius1] attribute 6 value outbound user-type ipoe value-added-service
attribute 15 check-mode命令用来配置对RADIUS Attribute 15的检查方式。
undo attribute 15 check-mode命令用来恢复缺省情况。
attribute 15 check-mode { loose | strict }
对RADIUS Attribute 15的检查方式为strict方式。
RADIUS方案视图
loose:松散检查方式,设备使用RADIUS Attribute 15的标准属性值对用户业务类型进行检查。 对于SSH、FTP、Terminal用户,在RADIUS服务器下发的Login-Service属性值为0(表示用户业务类型为Telnet)时,这类用户才能够通过认证。
strict:严格检查方式,设备使用RADIUS Attribute 15的标准属性值以及扩展属性值对用户业务类型进行检查。对于SSH、FTP、Terminal用户,当RADIUS服务器下发的Login-Service属性值为对应的扩展取值时,这类用户才能够通过认证。
由于某些RADIUS服务器不支持自定义的属性,无法下发扩展的Login-Service属性,若要使用这类RADIUS服务器对SSH、FTP、Terminal用户进行认证,建议设备上对RADIUS 15号属性值采用松散检查方式。
# 在RADIUS方案radius1中,配置对RADIUS Attribute 15采用松散检查方式。
[Sysname-radius-radius1] attribute 15 check-mode loose
attribute 25 car命令用来开启RADIUS Attribute 25的CAR参数解析功能。
undo attribute 25 car命令用来关闭RADIUS Attribute 25的CAR参数解析功能。
attribute 25 car
RADIUS Attribute 25的CAR参数解析功能处于关闭状态。
RADIUS方案视图
RADIUS的25号属性为class属性,该属性由RADIUS服务器下发给设备。目前,某些RADIUS服务器利用class属性来对用户下发CAR参数,可以通过本特性来控制设备是否将RADIUS 25号属性解析为CAR参数,解析出的CAR参数可被用来进行基于用户的流量监管控制。
目前,设备可以成功解析的class属性格式为string1string2string3string4,每个string的长度为8个字符,且每个字符必须为0~9之间的数字。
开启了本功能的情况下,如果设备成功将某RADIUS服务器下发的class属性解析为CAR参数,则后续发送给该RADIUS服务器的计费报文中除了携带class属性之外,还将会通过私有属性携带解析后的CAR参数。
# 在RADIUS方案radius1中,开启RADIUS Attribute 25的CAR参数解析功能。
[Sysname-radius-radius1] attribute 25 car
attribute 31 mac-format命令用来配置RADIUS Attribute 31中的MAC地址格式。
undo attribute 31 mac-format命令用来恢复缺省情况。
attribute 31 mac-format section { six | three } separator separator-character { lowercase | uppercase }
RADIUS Attribute 31中的MAC地址为大写字母格式,且被分隔符“-”分成6段,即为HH-HH-HH-HH-HH-HH的格式。
RADIUS方案视图
section:指定MAC地址分段数。
six:表示MAC地址被分为6段,格式为HH-HH-HH-HH-HH-HH。
three:表示MAC地址被分为3段,格式为HHHH-HHHH-HHHH。
lowercase:表示MAC地址为小写字母格式。
uppercase:表示MAC地址为大写字母格式。
不同的RADIUS服务器对填充在RADIUS Attribute 31中的MAC地址有不同的格式要求,为了保证RADIUS报文的正常交互,设备发送给服务器的RADIUS Attribute 31号属性中MAC地址的格式必须与服务器的要求保持一致。
# 在RADIUS方案radius1中,配置RADIUS Attribute 31的MAC地址格式为hh:hh:hh:hh:hh:hh。
[Sysname-radius-radius1] attribute 31 mac-format section six separator : lowercase
attribute 85 preferred命令用来配置通过RADIUS Attribute 85号属性下发的实时计费间隔优先生效。
undo attribute 85 preferred命令用来恢复缺省情况。
RADIUS方案下配置的计费间隔优先级高于由RADIUS服务器通过Attribute 85号属性下发的实时计费间隔。
RADIUS方案视图
设备会通过实时计费更新报文定期向RADIUS服务器发送在线用户的计费信息,发送周期可以通过RADIUS方案下的实时计费间隔命令设置(timer realtime-accounting),也可以由RADIUS服务器下通过85号属性(Acct-Interim-Interval)下发。缺省情况下,如果RADIUS方案下配置了非0的实时计费间隔,则该值优先级高于服务器下发的实时计费间隔。如果需要支持服务器下发的配置优先级高于RADIUS方案下的配置,则可以通过执行attribute 85 preferred命令来实现。
# 在RADIUS方案radius1中,配置通过Attribute 85号属性下发的实时计费间隔优先生效。
[Sysname-radius-radius1] attribute 85 preferred
· timer realtime-accounting
attribute 87 format命令用来配置RADIUS Attribute 87的格式。
undo attribute 87 format命令用来恢复缺省情况。
attribute 87 format { custom { c-vid [ delimiter ] | interface-type [ delimiter ] | port [ delimiter ] | s-vid [ delimiter ] | slot [ delimiter ] | string string [ delimiter ] | subslot [ delimiter ] | vxlan-id [ delimiter ] } * | vendor vendor-id }
未配置RADIUS Attribute 87的格式,直接采用接入模块定义的RADIUS Attribute 87格式,具体为:
· 对于IPoE、PPP:slot=xx;subslot=xx;port=xx;vlanid=xx;vlanid2=xx;
· 对于Login:不填充任何内容。
RADIUS方案视图
custom:表示采用自定义的属性格式。
c-vid:用户报文的内层VLAN ID。
interface-type:用户接入的接口类型。
port:用户接入的端口号。
s-vid:用户报文的外层VLAN ID。
slot:用户接入单板所在槽位号。
string string:自定义的属性字符串,其中string为1~63个字符的字符串,区分大小写。
subslot:用户接入单板所在子槽位号。
vxlan-id:用户所属的VXLAN ID。
delimiter:本属性字段与下一个属性字段之间的分隔符,为除问号之外的任意可输入字符。若不指定该参数,则表示不使用分隔符。
vendor vendor-id:表示采用指定设备厂商的属性格式,其中vendor-id厂商标识号码,取值范围目前仅为9(Cisco)和2636(Juniper)。
RADIUS Attribute 87为NAS-Port-ID属性。不同的RADIUS服务器对NAS-Port-ID属性的解析格式要求不同,为了保证RADIUS报文的正常交互,设备发送给服务器的NAS-Port-ID属性的格式必须与服务器的要求保持一致。
可通过本命令修改设备发送的RADIUS NAS-Port-ID属性的格式,具体情况如下:
· 如果采用指定设备厂商的属性格式,则NAS-Port-ID属性内容完全按照厂商要求填充。
· 如果采用自定义属性格式,则NAS-Port-ID属性中可携带哪些属性字段、各字段之间使用的分隔符以及各字段的排列顺序,由配置决定。其中,各字段的填充先后顺序,与本命令中对应关键字的配置顺序一致。
指定厂商ID为2636(Juniper)时,NAS-Port-ID属性填充格式如下:
· 对于以太网接口以及聚合接口:
¡ 双层VLAN情况下,格式为{fastEthernet|gigabitEthernet|ethernet|trunk} slot/port.vpivci:vpi-vci。其中,slot为槽位号,port为端口号,vpi为外层VLAN编号,vci为内层VLAN编号,例如gigabitEthernet 1/5.40940001:4094-1。需要注意的是,冒号前的vci必须通过填充0凑成4位,比如内层VLAN=1,则此处为0001。
¡ 单层VLAN情况下,格式为{fastEthernet|gigabitEthernet|ethernet|trunk} slot/port.subinterface:vlan。其中,slot为槽位号,port为端口号,subinterface为子接口号,vlan为VLAN编号,例如gigabitEthernet 1/5.4:4。在L2TP组网中,NAS-Port-ID属性中填充的subinterface字段取值无效。
¡ 无VLAN信息时,格式为{fastEthernet|gigabitEthernet|ethernet|trunk} slot/port.0,例如gigabitEthernet 1/5.0。
指定厂商为ID为9(Cisco)时,NAS-Port-ID属性填充格式为{ethernet|trunk} slot/subslot/port。其中,{ethernet|trunk}表示端口类型,slot表示槽位号,subslot表示子槽位号,port表示端口号,例如ethernet 1/0/5。
配置自定义属性格式时,请综合考虑用户的实际组网环境以及设备形态,避免指定无效的属性字段。
如果配置了本命令,则发送给RADIUS服务器的NAS-Port-ID属性的格式完全由本命令决定,接入模块定义的RADIUS NAS-Port-ID属性格式不再生效。
# 在RADIUS方案rad中,配置使用Cisco的RADIUS Attribute 87格式。
[Sysname-radius-rad] attribute 87 format vendor 9
# 在RADIUS方案rad2中,配置使用自定义的RADIUS Attribute 87格式,属性中依次携带用户报文的内层VLAN ID和接口类型,属性分隔符为;。
[Sysname] radius scheme rad2
[Sysname-radius-rad2] attribute 87 format custom c-vid ; interface-type ;
attribute convert命令用来配置RADIUS属性转换规则。
undo attribute convert命令用来删除RADIUS属性转换规则。
attribute convert src-attr-name to dest-attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute convert [ src-attr-name ]
不存在RADIUS属性转换规则,系统按照标准RADIUS协议对RADIUS属性进行处理。
RADIUS DAE服务器视图
src-attr-name:源属性名称,为1~63个字符的字符串,不区分大小写。该属性必须为系统支持的属性。
dest-attr-name:目的属性名称,为1~63个字符的字符串,不区分大小写。该属性必须为系统支持的属性。
coa-ack:COA应答报文。
coa-request:COA请求报文。
received:接收到的DAE报文。
sent:发送的DAE报文。
RADIUS属性转换规则中的源属性内容将被按照目的属性的含义来处理。
只有在RADIUS属性解释功能开启之后,RADIUS属性转换规则才能生效。
配置RADIUS属性转换规则时,需要遵循以下原则:
· 源属性内容和目的属性内容的数据类型必须相同。
· 源属性和目的属性的名称不能相同。
· 一个属性只能按照一种方式(按报文类型或报文处理方向)进行转换。
· 一个源属性不能同时转换为多个目的属性。
执行undo attribute convert命令时,如果不指定源属性名称,则表示删除所有RADIUS属性转换规则。
# 在RADIUS DAE服务器视图下,配置一条RADIUS属性转换规则,指定将接收到的DAE报文中的Hw-Server-String属性转换为Connect-Info属性。
[Sysname] radius dynamic-author server
[Sysname-radius-da-server] attribute convert Hw-Server-String to Connect-Info received
· attribute translate
attribute convert src-attr-name to dest-attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
RADIUS方案视图
access-accept:RADIUS认证成功报文。
access-request:RADIUS认证请求报文。
accounting:RADIUS计费报文。
received:接收到的RADIUS报文。
sent:发送的RADIUS报文。
· 源属性和目的属性的名称不能相同。
# 在RADIUS方案radius1中,配置一条RADIUS属性转换规则,指定将接收到的RADIUS报文中的Hw-Server-String属性转换为User-Address-Type属性。
[Sysname-radius-radius1] attribute convert Hw-Server-String to User-Address-Type received
attribute reject命令用来配置RADIUS属性禁用。
undo attribute reject命令用来取消配置的RADIUS属性禁用。
attribute reject attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute reject [ attr-name ]
不存在RADIUS属性禁用规则。
RADIUS DAE服务器视图
attr-name:RADIUS属性名称,为1~63个字符的字符串,不区分大小写。该属性必须为系统支持的属性。
coa-ack:COA应答报文。
received:接收到的DAE报文。
sent:发送的DAE报文。
当设备发送的RADIUS报文中携带了RADIUS服务器无法识别的属性时,可以定义基于发送方向的属性禁用规则,使得设备发送RADIUS报文时,将该属性从报文中删除。
当RADIUS服务器发送给设备的某些属性是设备不希望收到的属性时,可以定义基于接收方向的属性禁用规则,使得设备接收RADIUS报文时,不处理报文中的该属性。
当某些类型的属性是设备不希望处理的属性时,可以定义基于类型的属性禁用规则。
只有在RADIUS属性解释功能开启之后,RADIUS属性禁用规则才能生效。
一个属性只能按照一种方式(按报文类型或报文处理方向)进行禁用。
执行undo attribute reject命令时,如果不指定属性名称,则表示删除所有RADIUS属性禁用规则。
# 在RADIUS DAE服务器视图下,配置一条RADIUS属性禁用规则,指定禁用发送的DAE报文中的Connect-Info属性。
[Sysname-radius-da-server] attribute reject Connect-Info sent
attribute reject命令用来配置RADIUS属性禁用规则。
undo attribute reject命令用来删除RADIUS属性禁用规则。
attribute reject attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
不存在RADIUS属性禁用规则。
RADIUS方案视图
sent:发送的RADIUS报文。
当RADIUS服务器发送给设备的某些属性是不希望收到的属性时,可以定义基于接收方向的属性禁用规则,使得设备接收RADIUS报文时,不处理报文中的该属性。
# 在RADIUS方案radius1中,配置一条RADIUS属性禁用规则,指定禁用发送的RADIUS报文中的Connect-Info属性。
[Sysname-radius-radius1] attribute reject Connect-Info sent
attribute remanent-volume命令用来配置RADIUS Remanent-Volume属性的流量单位。
undo attribute remanent-volume命令用来恢复缺省情况。
attribute remanent-volume unit { byte | giga-byte | kilo-byte | mega-byte }
undo attribute remanent-volume unit
Remanent-Volume属性的流量单位是千字节。
RADIUS方案视图
byte:表示流量单位为字节。
giga-byte:表示流量单位为千兆字节。
kilo-byte:表示流量单位为千字节。
mega-byte:表示流量单位为兆字节。
Remanent-Volume属性为H3C自定义RADIUS属性,携带在RADIUS服务器发送给接入设备的认证响应或实时计费响应报文中,用于向接入设备通知在线用户的剩余流量值。设备管理员通过本命令设置的流量单位应与RADIUS服务器上统计用户流量的单位保持一致,否则设备无法正确使用Remanent-Volume属性值对用户进行计费。
# 在RADIUS方案radius1中,设置RADIUS服务器下发的Remanent-Volume属性的流量单位为千字节。
[Sysname-radius-radius1] attribute remanent-volume unit kilo-byte
attribute translate命令用来开启RADIUS属性解释功能。
undo attribute translate命令用来关闭RADIUS属性解释功能。
attribute translate
RADIUS属性解释功能处于关闭状态。
RADIUS方案视图/RADIUS DAE服务器视图
不同厂商的RADIUS服务器所支持的RADIUS属性集有所不同,而且相同属性的用途也可能不同。为了兼容不同厂商的服务器的RADIUS属性,需要开启RADIUS属性解释功能,并定义相应的RADIUS属性转换规则和RADIUS属性禁用规则。
# 在RADIUS方案radius1中,开启RADIUS属性解释功能。
[Sysname-radius-radius1] attribute translate
· attribute convert
· attribute reject
attribute vendor-id 2011 version命令用来设置Vendor ID为2011的RADIUS服务器版本号。
undo attribute vendor-id 2011 version命令用来恢复缺省情况。
attribute vendor-id 2011 version { 1.0 | 1.1 }
设备采用版本1.0与Vendor ID为2011的RADIUS服务器交互。
RADIUS方案视图
1.0:版本1.0。
1.1:版本1.1。
当设备与Vendor ID为2011的RADIUS服务器交互时,需要保证本命令设置的服务器版本号与对端服务器的实际版本号一致,否则会导致部分RADIUS属性解析错误。该厂商相关RADIUS属性在设备上的解析情况如下:
· 当RADIUS服务器下发属性HW_ARRT_26_1时,如果设备采用1.0版本,则将该属性解析为用户的上行峰值速率;如果设备采用1.1版本,则将其解析为上行突发尺寸。
· 当RADIUS服务器下发属性HW_ARRT_26_2时,无论设备采用1.0版本或1.1版本,均将该属性解析为用户的上行平均速率。
· 当RADIUS服务器下发属性HW_ARRT_26_3时,如果设备采用1.0版本,则不处理该属性;如果设备采用1.1版本,则将其解析为上行峰值速率。
· 当RADIUS服务器下发属性HW_ARRT_26_4时,如果设备采用1.0版本,则将该属性解析为用户的下行峰值速率;如果设备采用1.1版本,则将其解析为下行突发尺寸。
· 当RADIUS服务器下发属性HW_ARRT_26_5时,无论设备采用1.0版本或1.1版本,均将该属性解析为用户的下行平均速率。
· 当RADIUS服务器下发属性HW_ARRT_26_6时,如果设备采用1.0版本,则不处理该属性;如果设备采用1.1版本,则将其解析为下行峰值速率。
# 在RADIUS方案radius1中,设置Vendor ID为2011的RADIUS服务器版本号为1.1。
[Sysname-radius-radius1] attribute vendor-id 2011 version 1.1
· client
client命令用来指定RADIUS DAE客户端。
undo client命令用来删除指定的RADIUS DAE客户端。
client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | vendor-id 2011 version { 1.0 | 1.1 } | vpn-instance vpn-instance-name ] *
undo client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未指定RADIUS DAE客户端。
RADIUS DAE服务器视图
ip ipv4-address:RADIUS DAE客户端IPv4地址。
ipv6 ipv6-address:RADIUS DAE客户端IPv6地址。
key:与RADIUS DAE客户端交互DAE报文时使用的共享密钥。此共享密钥的设置必须与RADIUS DAE客户端的共享密钥设置保持一致。如果此处未指定本参数,则对应的RADIUS DAE客户端上也必须未指定。
cipher:以密文方式设置密钥。
string:密钥字符串,区分大小写。明文密钥为1~64个字符的字符串;密文密钥为1~117个字符的字符串。
vendor-id 2011:表示RADIUS DAE客户端的Vendor-ID为2011。
version:版本号。
1.0:版本1.0。
1.1:版本1.1。
vpn-instance vpn-instance-name:RADIUS DAE客户端所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示RADIUS DAE客户端位于公网中。
开启RADIUS DAE服务之后,设备会监听并处理指定的RADIUS DAE客户端发起的DAE请求消息(用于动态授权修改或断开连接),并向其发送应答消息。对于非指定的RADIUS DAE客户端的DAE报文进行丢弃处理。
可通过多次执行本命令指定多个RADIUS DAE客户端。
缺省情况下,设备支持与版本1.0的Vendor-ID为2011的RADIUS服务器通信,若对端为1.1版本,则需要通过指定vendor-id 2011 version 1.1参数来保证版本的一致性,否则无法正确解析部分DAE请求。
# 设置RADIUS DAE客户端的IP地址为10.110.1.2,与RADIUS DAE客户端交互DAE报文时使用的共享密钥为明文123456。
[Sysname-radius-da-server] client ip 10.110.1.2 key simple 123456
· attribute vendor-id 2011 version
· radius dynamic-author server
· port
dae-loose-check enable命令用来开启DAE报文的宽松检查功能。
undo dae-loose-check enable命令用来关闭DAE报文的宽松检查功能。
DAE报文的宽松检查功能处于关闭状态。
RADIUS DAE服务器视图
设备作为DAE服务器接收到DAE请求报文后,可根据报文中携带的用户标识信息(用户名、用户IP地址、Acct-Session-Id、Acct-Multi-Session-Id、EDSG策略名)在本地查找对应的用户,并对用户进行强制下线或者更改授权信息。如果设备没有查找到对应的用户,则不处理该DAE请求。
缺省情况下,设备对DAE请求报文中的所有用户标识信息都进行校验,只有在设备上查找到了严格匹配所有信息的用户才会处理该DAE请求。
如果设备上开启了宽松检查功能,则设备只会校验DAE报文中的部分用户标识信息,包括用户IP地址、Acct-Session-Id以及Acct-Multi-Session-Id。
有些DAE客户端上记录的用户以及设备信息可能与设备上用户的实际信息不完全一致,为了避免DAE客户端发送的DAE请求因无法进行完全匹配式校验而被丢弃,建议在这种情况下开启DAE请求报文的宽松检查功能。
# 开启DAE报文的宽松检查功能。
[Sysname-radius-da-server] dae-loose-check enable
data-flow-format命令用来配置发送到RADIUS服务器的数据流及数据包的单位。
undo data-flow-format命令用来恢复缺省情况。
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
数据流的单位为字节,数据包的单位为包。
RADIUS方案视图
data:设置数据流的单位。
· byte:数据流的单位为字节。
· giga-byte:数据流的单位千兆字节。
· kilo-byte:数据流的单位为千字节。
· mega-byte:数据流的单位为兆字节。
packet:设置数据包的单位。
· giga-packet:数据包的单位为千兆包。
· kilo-packet:数据包的单位为千包。
· mega-packet:数据包的单位为兆包。
· one-packet:数据包的单位为包。
设备上配置的发送给RADIUS服务器的数据流单位及数据包单位应与RADIUS服务器上的流量统计单位保持一致,否则无法正确计费。
# 在RADIUS方案radius1中,设置发往RADIUS服务器的数据流单位为千字节、数据包单位为千包。
[Sysname-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
display radius scheme命令用来显示RADIUS方案的配置信息。
display radius scheme [ radius-scheme-name ]
显示指定RADIUS方案配置信息时,会同时显示每一个RADIUS服务器当前Active状态的持续时间以及最近5次状态变化信息;显示所有RADIUS方案配置信息时,会同时显示每一个RADIUS服务器当前Active状态的持续时间以及最近1次Block状态的开始时间和结束时间。
radius-scheme-name:RADIUS方案名,为1~32个字符的字符串,不区分大小写。如果不指定该参数,则表示所有RADIUS方案。
# 显示所有RADIUS方案的配置信息。
<Sysname> display radius scheme
Total 1 RADIUS schemes
RADIUS scheme name: radius1
Index : 0
Primary authentication server:
IP : 2.2.2.2 Port: 1812
VPN : vpn1
State: Active (duration: 1 weeks 2 days 1 hours 32 minutes 34 seconds)
Most recent blocked period: 2021/08/15 20:33:45 –2021/08/15 20:38:45
Test profile: 132
Probe username: test
Probe interval: 60 seconds
Weight: 40
Primary accounting server:
IP : 1.1.1.1 Port: 1813
VPN : Not configured
Most recent blocked period: 2021/08/15 20:33:45 - 2021/08/15 20:38:45
Weight: 40
Second authentication server:
IP: 3.3.3.3 Port: 1812
State: Blocked
Most recent blocked period: 2021/08/15 20:33:45 - now
Test profile: Not configured
Weight: 40
Second accounting server:
IP : 3.3.3.3 Port: 1813
State: Blocked (mandatory)
Weight: 0
Accounting-On function : Enabled
extended function : Disabled
retransmission times : 5
retransmission interval(seconds) : 2
Timeout Interval(seconds) : 3
Retransmission Times : 3
Retransmission Times for Accounting Update : 5
Server Quiet Period(minutes) : 5
Realtime Accounting Interval(seconds) : 22
Stop-accounting packets buffering : Enabled
Retransmission times : 500
NAS IP Address : 1.1.1.1
Source IP address : Not configured
Username format : with-domain
Data flow unit : Megabyte
Packet unit : One
Attribute 5 format : QinQ
Attribute 6:
IPoE : Outbound (value-added services included)
Attribute 15 check-mode : Strict
Attribute 25 : CAR
Remanent-Volume threshold : 1024
Attribute Remanent-Volume unit : Mega
Server-load-sharing : Disabled
Server-load-sharing mode : Session-based
Attribute 31 MAC format : hh:hh:hh:hh:hh:hh
Stop-accounting-packet send-force : Disabled
RADIUS server version (vendor ID 2011) : 1.0
Attribute 85 preferred : Enabled
Attribute 87 format customized : c-vid@interface-type/s-vid
Authentication response pending limit : Not configured
Accounting response pending limit : Not configured
Username authorization : Not applied
All-server-block action : Attempt the top-priority server
# 显示RADIUS方案radius1的配置信息。
<Sysname> display radius scheme radius1
Index : 0
VPN : vpn1
Most recent state changes:
2021/08/15 20:38:45 Changed to active state
2021/08/15 20:33:45 Changed to blocked state
2021/08/15 20:31:19 Changed to active state
2021/08/15 20:26:19 Changed to blocked state
2021/08/15 20:26:00 Changed to active state
Test profile: 132
Weight: 40
Weight: 40
State: Blocked
2021/08/15 20:56:22 Changed to blocked state
2021/08/15 20:48:45 Changed to active state
2021/08/15 20:43:45 Changed to blocked state
2021/08/15 20:41:19 Changed to active state
2021/08/15 20:46:19 Changed to blocked state
Weight: 40
Weight: 0
Packet unit : One
Attribute 6:
Attribute 25 : CAR
表1-11 display radius scheme命令显示信息描述表
Total 1 RADIUS schemes. |
共计1个RADIUS方案 |
RADIUS scheme name |
RADIUS方案的名称 |
Index |
RADIUS方案的索引号 |
Primary authentication server |
主RADIUS认证服务器 |
Primary accounting server |
主RADIUS计费服务器 |
Second authentication server |
从RADIUS认证服务器 |
Second accounting server |
从RADIUS计费服务器 |
IP |
RADIUS认证/计费服务器IP地址 未配置时,显示为Not configured |
Port |
RADIUS认证/计费服务器接入端口号 未配置时,显示缺省值 |
State |
RADIUS认证/计费服务器目前状态 · Active:激活状态 · Blocked:自动转换的静默状态 · Blocked (mandatory):手工配置的静默状态 若状态为Active,则同时显示该状态的持续时间 |
duration |
RADIUS服务器当前Active状态的持续时间 |
Most recent blocked period |
RADIUS服务器最后一次转换为Block状态的开始时间及结束时间。若最终状态为Block状态,则结束时间用“now”表示 |
Most recent state changes |
RADIUS服务器最近5次的状态变化信息 |
VPN |
RADIUS认证/计费服务器所在的VPN 未配置时,显示为Not configured |
Test profile |
探测服务器状态使用的模板名称 |
Probe username |
探测服务器状态使用的用户名 |
Probe interval |
探测服务器状态的周期(单位为秒) |
Weight |
RADIUS服务器权重值 |
Accounting-On function |
accounting-on功能的开启情况 |
extended function |
accounting-on扩展功能的开启情况 |
retransmission times |
accounting-on报文的发送尝试次数 |
retransmission interval(seconds) |
accounting-on报文的重发间隔(单位为秒) |
Timeout Interval(seconds) |
RADIUS服务器超时时间(单位为秒) |
Retransmission Times |
发送RADIUS报文的最大尝试次数 |
Retransmission Times for Accounting Update |
实时计费更新报文的最大尝试次数 |
Server Quiet Period(minutes) |
RADIUS服务器恢复激活状态的时间(单位为分钟) |
Realtime Accounting Interval(seconds) |
实时计费更新报文的发送间隔(单位为秒) |
Stop-accounting packets buffering |
RADIUS停止计费请求报文缓存功能的开启情况 |
Retransmission times |
发起RADIUS停止计费请求的最大尝试次数 |
NAS IP Address |
发送RADIUS报文携带的NAS-IP地址 未配置时,显示为Not configured |
Source IP address |
发送RADIUS报文使用的源IP地址 未配置时,显示为Not configured |
VPN |
RADIUS方案所属的VPN名称 未配置时,显示为Not configured |
Username format |
发送给RADIUS服务器的用户名格式 · with-domain:携带域名 · without-domain:不携带域名 · keep-original:与用户输入保持一致 |
Data flow unit |
数据流的单位 |
Packet unit |
数据包的单位 |
Attribute 5 format |
RADIUS Attribute 5的封装格式: · QinQ:表示使用QinQ格式 · Default:表示使用缺省格式 |
Attribute 6 |
对IPoE用户的RADIUS Attribute 6取值的设置,包括以下两种情况: · Outbound (value-added services included):表示IPoE用户的认证请求和计费请求报文中的Service-Type属性值为Outbound(5),且适用于增值业务 · Outbound (value-added services excluded):表示IPoE用户的认证请求和计费请求报文中的Service-Type属性值为Outbound(5),但不适用于增值业务 |
Attribute 15 check-mode |
对RADIUS Attribute 15的检查方式,包括以下两种取值: · Strict:表示使用RADIUS标准属性值和私有扩展的属性值进行检查 · Loose:表示使用RADIUS标准属性值进行检查 |
Attribute 25 |
对RADIUS Attribute 25的处理,包括以下两种取值: · Standard:表示不对RADIUS Attribute 25进行解析 · CAR:表示将RADIUS 25号属性解析为CAR参数 |
Remanent-Volume threshold |
用户剩余流量阈值(单位为Attribute Remanent-Volume unit的取值) |
Attribute Remanent-Volume unit |
RADIUS Remanent-Volume属性的流量单位 |
Server-load-sharing |
RADIUS服务器负载分担功能的开启情况 · Disabled:关闭状态,服务器工作于主/从模式 · Enabled:开启状态,服务器工作于负载分担模式 |
Server-load-sharing mode |
RADIUS认证服务器负载分担模式 · Session-based:基于会话的负载分担模式 · Packet-based:基于报文的负载分担模式 |
Attribute 31 MAC format |
RADIUS Attribute 31中携带的MAC地址格式 |
Stop-accounting-packets send-force |
用户下线时设备强制发送RADIUS计费停止报文功能的开启情况 |
RADIUS server version (vendor ID 2011) |
Vendor ID为2011的RADIUS服务器版本号 |
Attribute 85 preferred |
是否优先使用通过RADIUS Attribute 85下发的实时计费间隔: · Enabled:优先使用 · Disabled:不优先使用 |
Attribute 87 format vendor-specific |
RADIUS Attribute 87的设备厂商编号 |
Attribute 87 format customized |
用户自定义的RADIUS Attribute 87格式 |
Authentication response pending limit |
未收到认证服务器响应的请求报文的最大数目 未配置时,显示为Not configured |
Accounting response pending limit |
未收到计费服务器响应的请求报文的最大数目 未配置时,显示为Not configured |
Username authorization |
设备对RADIUS服务器下发的用户名的处理机制 · Applied:表示接受RADIUS服务器下发的用户名 · Not applied:表示不接受RADIUS服务器下发的用户名 |
All-server-block action |
当前方案中的RADIUS服务器都处于block状态后的设备处理动作: · Attempt the top-priority server:尝试与当前方案中高优先级的服务器建立一次连接 · Skip all servers in the scheme:跳过当前方案中的所有服务器 |
display radius server-load statistics命令用来显示RADIUS服务器的负载统计信息。
本命令用来显示上一个5秒统计周期内设备发往RADIUS认证/计费服务器的认证/计费请求统计信息和自从设备启动后记录的历史认证/计费请求统计信息,具体统计过程如下:
· 系统从第一个用户认证请求开始,每隔5秒钟统计一次RADIUS认证/计费请求数目,并在下一个5秒内提供该统计值供查看。
· 只要设备发起一次用户认证请求或用户计费开始请求,对应服务器的历史负载统计数值随之加1,但后续不会因为用户下线、服务器响应或超时而减小该值。
前5秒的统计信息提供了RADIUS认证/计费服务器最近5秒的负载分担效果,管理员可以根据此统计信息调控RADIUS服务器的配置参数,比如配置顺序、权重参数等。当没有用户触发认证/计费时,前5秒的统计数据就不能给管理员提供有效的负载分担信息了,此时管理员可以参考历史负载统计信息对RADIUS认证/计费服务器的配置做调整。
· 只要该RADIUS认证/计费服务器的配置被某RADIUS方案所引用,则就可以通过本命令查看到它的负载统计数据。
· 若RADIUS认证/计费服务器的配置被删除,或主认证/计费服务器的VPN、IP、端口配置发生变化,则该服务器的前5秒的统计数据及历史负载统计数据将会被删除。
· 主备倒换后,历史统计数据不会被删除,但会不准确。
# 显示RADIUS服务器的负载统计信息。
<Sysname> display radius server-load statistics
Authentication servers: 2
IP VPN Port Last 5 sec History
1.1.1.1 N/A 1812 20 100
1::1 ABC 1812 0 20
Accounting servers: 2
1.1.1.1 N/A 1813 20 100
1::1 ABC 1813 0 20
表1-12 display radius server-load statistics命令显示信息描述表
Authentication servers |
RADIUS认证服务器总个数 |
Accounting servers |
RADIUS计费服务器总个数 |
IP |
RADIUS认证/计费服务器的IP地址 |
VPN |
RADIUS认证/计费服务器所在的VPN 若未配置该参数,则显示N/A |
Port |
RADIUS认证/计费服务器的UDP端口号 |
Last 5 sec |
上一个5秒统计周期内发往RADIUS认证/计费服务器的请求数 |
History |
RADIUS认证/计费服务器的历史负载统计值 |
· reset radius server-load statistics
display radius statistics命令用来显示RADIUS报文的统计信息。
display radius statistics [ server { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-number ] { accounting | authentication } ]
ip ipv4-address:指定RADIUS服务器的IPv4地址。
ipv6 ipv6-address:指定RADIUS服务器的IPv6地址。
vpn-instance vpn-instance-name:指定RADIUS服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示RADIUS服务器位于公网中。
port port-number:指定RADIUS服务器的UDP端口号,取值范围为1~65535,对于认证报文,缺省值为1812,对于计费报文,缺省值为1813。
accounting:表示RADIUS计费报文统计信息。
authentication:表示RADIUS认证报文统计信息。
可通过本命令查看设备和RADIUS服务器之间交互的报文统计信息,包括RADIUS认证报文、RADIUS计费报文、DAE报文、session control和PPPoE代拨报文的统计信息。
若不指定任何参数,则表示显示设备和所有RADIUS服务器交互的所有类型的RADIUS报文统计信息;若指定了服务器参数,则表示仅显示设备和指定RADIUS服务器之间交互的RADIUS认证报文或RADIUS计费报文统计信息。
# 显示设备和所有RADIUS服务器交互的报文统计信息。
<Sysname> display radius statistics
Authentication packets:
Requests : 8 Retransmissions : 0
Pending requests : 0 Packet timeouts : 0
Request failures : 0 Challenge packets : 0
Packets without responses : 0 Packets with responses : 0
Accept responses : 8 Reject responses : 0
Unknown-type responses : 0 Malformed responses : 0
Bad authenticators : 0 Dropped responses : 0
Invalid server addresses : 0
Accounting packets:
Requests : 16 Retransmissions : 0
Start requests : 8 Realtime requests : 0
Stop requests : 8 Pending requests : 0
Packet timeouts : 0 Request failures : 0
Buffered unsent requests : 0
DAE packets:
DM:
Requests : 0 Request retransmissions: 0
ACKs : 0 NAKs : 0
Timeouts : 0 Malformed requests : 0
Bad authenticators : 0 Dropped requests : 0
CoA:
ACKs : 0 NAKs : 0
Unknown-type requests : 0
Session-control packets:
Terminate:
Requests : 0 Successes : 0
Failures : 0 Timeouts : 0
Set-policy:
Unknown-type requests : 0 Malformed requests : 0
PPPoEA packets:
COA requests : 0 COA responses : 0
PPPoE agent responses:
Successes : 0 Failures : 0
Offlines : 0
DM requests : 0 DM responses : 0
Authentication servers: 1
IP: 1.1.1.1 Port: 1812
VPN:
Accounting servers: 1
IP: 1.1.1.1 Port: 1813
VPN:
Accounting packets:
Accept responses : 16
# 显示设备与IP地址为1.1.1.1、端口号为1812的RADIUS服务器之间交互的认证报文统计信息。
<Sysname> display radius statistics server ip 1.1.1.1 port 1812 authentication
表1-13 display radius statistics命令显示信息描述表
Authentication packets |
认证报文统计信息 |
Accounting packets |
计费报文统计信息 |
Requests |
认证/计费请求报文数 该计数不包含报文重传计数,但增加时Pending Requests计数也会增加 |
Retransmissions |
重传的认证/计费请求报文数 该计数不会叠加在Requests计数中 |
Start requests |
开始计费请求报文数 |
Realtime requests |
实时计费请求报文数 |
Stop requests |
计费停止请求报文数 |
Pending requests |
未得到服务器响应且未超时的认证/计费请求报文数 |
Packet timeouts |
超时的认证/计费请求报文数 |
Request failures |
发送失败的认证/计费请求报文数 |
Challenge packets |
认证挑战报文数 |
Packets without responses |
无响应的认证/计费请求报文数 当所有服务器都不响应某认证/计费请求报文时,该计数才会增加 “-”表示未统计该值 |
Packets with responses |
合法的认证/计费响应报文数 “-”表示未统计该值 |
Accept responses |
认证接受报文数/计费响应报文数 |
Reject responses |
认证拒绝报文数 |
Unknown-type responses |
非标准定义的认证/计费响应报文数 |
Malformed responses |
长度不合法的认证/计费响应报文数 |
Bad authenticators |
验证字错误的认证/计费响应报文数 验证字错误的响应报文也属于不合法的响应报文 |
Dropped responses |
因为其它原因丢弃的认证/计费响应报文数 |
Invalid server addresses |
无效服务器地址报文数 |
Buffered unsent requests |
当前缓存的未发送给服务器的请求报文数 |
DAE packets |
DAE报文统计信息 |
DM |
DM报文统计信息 |
CoA |
CoA报文统计信息 |
Requests |
DAE请求报文数 此计数不包括重传的DAE请求报文数 |
Request retransmissions |
重传的DAE请求报文数 |
ACKs |
DAE请求接受报文数 |
NAKs |
DAE请求拒绝报文数 |
Session-control packets |
session control报文统计信息 |
Terminate |
强制用户下线报文统计信息 |
Set-policy |
更新用户授权信息报文统计信息 |
Requests |
session control请求报文数 |
Successes |
session control请求接受报文数 |
Failures |
session control请求拒绝报文数 |
Timeouts |
DAE/session control请求超时报文数 |
Unknown-type requests |
非标准定义的DAE/session control请求报文数 |
Malformed requests |
长度不合法的DAE/session control请求报文数 |
验证字错误的DAE/session control请求报文数 |
Dropped requests |
丢弃的DAE/session control请求报文数 |
PPPoEA packets |
PPPoE代拨报文统计信息 |
COA requests |
收到服务器的代拨请求COA报文数 |
COA responses |
发送给服务器的代拨应答COA报文数 |
PPPoE agent responses |
收到的PPPoE代拨应答消息数 |
Successes |
PPPoE代拨上线成功消息数 |
Failures |
PPPoE代拨上线失败消息数 |
Offlines |
PPPoE代拨下线消息数 |
DM requests |
收到服务器强制代拨用户下线的DM请求 |
DM responses |
发送给服务器的强制代拨用户下线结果的DM应答 |
认证服务器数目 |
计费服务器数目 |
IP |
服务器的IP地址 |
Port |
服务器的端口号 |
VPN |
服务器所在的VPN 若服务器属于公网,则该字段取值为空 |
认证服务器报文统计信息 |
计费服务器报文统计信息 |
· reset radius statistics
display stop-accounting-buffer命令用来显示缓存的RADIUS停止计费请求报文的相关信息。
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
radius-scheme radius-scheme-name:表示指定RADIUS方案的停止计费请求报文。其中,radius-scheme-name为RADIUS方案名,为1~32个字符的字符串,不区分大小写。
session-id session-id:表示指定会话的停止计费请求报文。其中,session-id表示会话ID,为1~64个字符的字符串,不包含字母。会话ID用于唯一标识当前的在线用户。
time-range start-time end-time:表示指定时间段内发送且被缓存的停止计费请求报文。其中,start-time为请求时间段的起始时间,end-time为请求时间段的结束时间,格式为hh:mm:ss-mm/dd/yyyy(时:分:秒-月/日/年)或hh:mm:ss-yyyy/mm/dd(时:分:秒-年/月/日)。
user-name user-name:表示指定用户的停止计费请求报文。其中,user-name表示用户名,为1~255个字符的字符串,区分大小写。输入的用户名是否携带ISP域名,必须与RADIUS方案中的user-name-format配置保持一致。
# 显示缓存的用户名为abc的RADIUS停止计费请求报文的相关信息。
<Sysname> display stop-accounting-buffer user-name abc
Total entries: 2
Scheme Session ID Username First sending time Attempts
rad1 1000326232325010 abc 23:27:16-08/31/2019 19
aaa 1000326232326010 abc 23:33:01-08/31/2019 20
表1-14 display stop-accounting-buffer命令显示信息描述表
Total entries: 2 |
共有两条记录匹配 |
Scheme |
RADIUS方案名 |
Session ID |
会话ID(Acct-Session-Id属性值) |
Username |
用户名 |
First sending time |
首次发送停止计费请求的时间 |
Attempts |
发起停止计费请求的次数 |
· reset stop-accounting-buffer (for RADIUS)
· retry
· retry stop-accounting (for RADIUS)
· stop-accounting-buffer enable (RADIUS scheme view)
· user-name-format (RADIUS scheme view)
exclude命令用来配置RADIUS报文中不能携带的属性。
undo exclude命令用来取消在RADIUS报文中不能携带的属性配置。
exclude { accounting | authentication } name attribute-name
undo exclude { accounting | authentication } name attribute-name
未配置RADIUS报文中不能携带的属性。
RADIUS属性测试组视图
accounting:表示RADIUS计费请求报文。
authentication:表示RADIUS认证请求报文。
name attribute-name:RADIUS属性名称,为1~63个字符的字符串,不区分大小写。这些属性为RADIUS报文中缺省携带的属性,具体包括:Service-Type、Framed-Protocol、NAS-Identifier、Acct-Delay-Time、Acct-Session-Id、Acct-Terminate-Cause和NAS-Port-Type,其中Service-Type、Framed-Protocol、NAS-Identifier,Acct-Session-Id和NAS-Port-Type为认证请求报文缺省携带的属性,NAS-Identifier、Acct-Delay-Time、Acct-Session-Id和Acct-Terminate-Cause为计费请求报文缺省携带的属性。
通过本命令配置的RADIUS属性将不会在属性测试过程中被携带在相应的RADIUS请求报文中发送给RADIUS服务器。在实际测试过程中,可通过本命令排除掉RADIUS报文中携带的一些基础属性,来辅助排查认证/计费故障。
如果一个属性已经被配置为需要携带在RADIUS报文中(通过include命令),则需要先执行undo include命令取消该配置,才能将其配置为不携带在RADIUS报文中。
# 在RADIUS属性测试组t1中,配置在RADIUS认证请求报文中不携带属性名称为Service-Type的标准属性。
[Sysname] radius attribute-test-group t1
[Sysname-radius-attr-test-grp-t1] exclude authentication name Service-Type
· include
· test-aaa
include命令用来配置RADIUS报文中携带的属性。
undo include命令用来取消指定的属性配置。
include { accounting | authentication } { name attribute-name | [ vendor vendor-id ] code attribute-code } type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string } value attribute-value
undo include { accounting | authentication} { name attribute-name | [ vendor vendor-id ] code attribute-code }
未配置RADIUS报文中携带的属性。
RADIUS属性测试组视图
name attribute-name:标准RADIUS属性名称,为1~63个字符的字符串,不区分大小写。
vendor vendor-id:RADIUS属性所属的设备厂商标识。vendor-id为厂商标识号码,取值范围为1~65535。如果不指定该参数,则表示RADIUS属性为标准属性。其中,2011表示HUAWEI,25506表示H3C,9表示Cisco,311表示Microsoft,43表示3COM,3561表示DSL论坛,20942表示中国电信,40808表示WFA无线,2636表示Juniper,28357表示CMCC。
code attribute-code:RADIUS属性编号,取值范围为1~255。
type:属性内容的数据类型,包括以下取值:
· binary:二进制类型。
· date:时间类型。
· integer:整数类型。
· interface-id:接口ID类型。
· ip:IPv4地址类型。
· ipv6:IPv6地址类型。
· ipv6-prefix:IPv6地址前缀类型。
· octets:八进制类型。
· string:字符串类型。
value attribute-value:RADIUS属性值,取值与数据类型有关,具体如下:
· 二进制属性值:1~256个十六进制字符,表示最多128个字节的二进制数。
· 时间类型属性值:0~4294967295。
· 整数类型属性值:0~4294967295。
· 接口ID类型属性值:1~ffffffffffffffff。
· IPv6地址前缀类型属性值:prefix/prefix-length样式。
· 八进制属性值:1~256个十六进制字符,表示最多128个字节的八进制数。
· 字符串类型属性值:1~253个字符。
可以通过本命令配置RADIUS报文中携带的属性以及对应的属性值,具体情况如下:
· 对于RADIUS报文中默认携带的属性,可通过include命令来修改属性取值,并可通过undo include命令将该属性值恢复为缺省值。RADIUS报文中默认携带的能够修改的属性包括:
¡ 认证请求报文默认携带的属性:User-Name、CHAP-Password(User-Password)、CHAP-Challenge、NAS-IP-Address(NAS-IPv6-Address)、Service-Type、Framed-Protocol、NAS-Identifier、NAS-Port-Type、Acct-Session-Id。
¡ 计费请求报文默认携带的属性:User-Name、Acct-Status-Type、NAS-IP-Address(NAS-IPv6-Address)、NAS-Identifier、Acct-Session-Id、Acct-Delay-Time、Acct-Terminate-Cause。
· 对于并非RADIUS报文中默认携带的属性,可通过include命令将其添加在RADIUS报文中,并可通过undo include命令将该属性从RADIUS报文中删除。
为了保证测试效果的准确性,请务必保证各属性参数的匹配性,比如属性值要匹配属性类型。
保存在配置文件中的标准属性的属性名称将被转换为属性编号的形式。
如果一个属性已经被配置为不能携带在RADIUS报文中(通过exclude命令),则需要先执行undo exclude命令取消该配置,才能将其配置为携带在RADIUS报文中。
设备按照配置的先后顺序在RADIUS报文中添加RADIUS属性,由于RADIUS报文最大长度为4096个字节,如果配置了过多的RADIUS属性,则在报文长度超过最大值后,部分属性将不会被添加在报文中。因此,请合理规划要添加的RADIUS报文属性数目。
# 在RADIUS属性测试组t1中,配置在RADIUS认证请求报文中携带一个标准属性:名称为Calling-Station-Id,属性值为08-00-27-00-34-D8。
[Sysname-radius-attr-test-grp-t1] include authentication name Calling-Station-Id type string value 08-00-27-00-34-d8
· exclude
· test-aaa
key命令用来配置RADIUS报文的共享密钥。
undo key命令用来删除RADIUS报文的共享密钥。
key { accounting | authentication } { cipher | simple } string
undo key { accounting | authentication }
未配置RADIUS报文的共享密钥。
RADIUS方案视图
accounting:指定RADIUS计费报文的共享密钥。
authentication:指定RADIUS认证报文的共享密钥。
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
设备优先采用配置RADIUS认证/计费服务器时指定的报文共享密钥,本配置中指定的报文共享密钥仅在配置RADIUS认证/计费服务器时未指定相应密钥的情况下使用。
必须保证设备上设置的共享密钥与RADIUS服务器上的完全一致。
# 在RADIUS方案radius1中,配置计费报文的共享密钥为明文ok。
[Sysname-radius-radius1] key accounting simple ok
nas-ip命令用来设置RADIUS报文中携带的NAS-IP地址。
undo nas-ip命令用来删除指定类型的NAS-IP地址。
nas-ip { ipv4-address | ipv6 ipv6-address }
undo nas-ip [ ipv6 ]
未设置RADIUS报文中携带的NAS-IP地址,使用系统视图下由命令radius nas-ip指定的NAS-IP地址。
RADIUS方案视图
ipv4-address:指定RADIUS报文中携带的IPv4 NAS-IP地址,不能为全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6 ipv6-address:指定RADIUS报文中携带的IPv6 NAS-IP地址,必须是单播地址,不能为环回地址与本地链路地址。
可通过本命令配置设备发送的RADIUS报文中携带的NAS-IP-Address或NAS-IPv6-Address属性内容,简称为NAS-IP地址,该地址用于标识用户接入的设备,且在RADIUS服务器上必须全局唯一。
RADIUS服务器发送的DAE请求报文中若携带该属性,则表示该请求报文要发送给指定的接入设备。当接入设备收到DAE请求报文后,会获取报文中携带的NAS-IP地址与本地保存的NAS-IP地址进行比较,若相同则接受该请求报文并进行后续的处理,否则不对其进行处理。
接口视图、RADIUS方案视图和系统视图下均可以配置发送RADIUS报文携带的NAS-IP地址,具体生效情况如下:
· 接口视图下配置的NAS-IP地址(通过aaa nas-ip命令)只对在本接口上线的用户有效。
· RADIUS方案视图下配置的NAS-IP地址(通过nas-ip命令)只对本方案有效。
· 系统视图下的配置的NAS-IP地址(通过radius nas-ip命令)对所有RADIUS方案有效。
· 以上各视图下的配置优先级从高到低依次为:接口视图->RADIUS方案视图->系统视图。
一个RADIUS方案视图下,最多允许指定一个IPv4 NAS-IP地址和一个IPv6 NAS-IP地址。
如果undo nas-ip命令中不指定ipv6参数,则表示删除配置的IPv4 NAS-IP地址。
# 在RADIUS方案radius1中,设置RADIUS报文携带的IPv4 NAS-IP地址为10.1.1.1。
[Sysname-radius-radius1] nas-ip 10.1.1.1
· aaa nas-ip
· radius nas-ip
port命令用来指定RADIUS DAE服务端口。
undo port命令用来恢复缺省情况。
port port-number
undo port
RADIUS DAE服务端口为3799。
RADIUS DAE服务器视图
port-number:DAE服务器接收DAE请求消息的UDP端口,取值范围为1~65535。
必须保证设备上的RADIUS DAE服务端口与RADIUS DAE客户端发送DAE报文的目的UDP端口一致。
# 开启RADIUS DAE服务后,指定DAE服务端口为3790。
[Sysname-radius-da-server] port 3790
· clientClient
pppoe-agency reply-port命令用来配置PPPoE代拨过程中,服务器监听代拨应答报文的目的端口。
undo pppoe-agency reply-port命令用来恢复缺省情况。
pppoe-agency reply-port port-number
PPPoE代拨过程中,服务器监听代拨应答报文的目的为3799。
RADIUS DAE服务器视图
port-number:服务器接收DAE请求消息的UDP端口,取值范围为1~65535。
设备对用户进行PPPoE代拨过程中,将通过DAE请求消息向AAA服务器应答代拨结果(PPPoE代拨用户上线成功、PPPoE代拨用户上线失败、PPPoE代拨用户下线)。该报文的目的端口必须为AAA服务器监听DAE请求消息的端口。
# 配置PPPoE代拨过程中,服务器监听代拨应答报文的目的端口为3790。
[Sysname-radius-da-server] pppoe-agency reply-port 3790
· radius dynamic-author proxy(安全命令参考/DAE代理)
primary accounting命令用来配置主RADIUS计费服务器。
undo primary accounting命令用来恢复缺省情况。
primary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name | weight weight-value ] *
未配置主RADIUS计费服务器。
RADIUS方案视图
ipv4-address:主RADIUS计费服务器的IPv4地址。
ipv6 ipv6-address:主RADIUS计费服务器的IPv6地址。
port-number:主RADIUS计费服务器的UDP端口号,取值范围为1~65535,缺省值为1813。
key:与主RADIUS计费服务器交互的计费报文的共享密钥。
cipher:以密文方式设置密钥。
vpn-instance vpn-instance-name:主RADIUS计费服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主RADIUS计费服务器位于公网中。
weight weight-value:RADIUS服务器负载分担的权重。weight-value表示权重值,取值范围为0~100,缺省值为0。0表示该服务器在负载分担调度时将不被使用。开启服务器负载分担功能后,该参数才能生效,且权重值越大的服务器可以处理的计费请求报文越多。
配置的主计费服务器的UDP端口号以及计费报文的共享密钥必须与服务器的配置保持一致。
在同一个方案中指定的主计费服务器和从计费服务器的VPN、IP地址、端口号不能完全相同。
设备与主计费服务器通信时优先使用本命令设置的共享密钥,如果此处未设置,则使用key accounting命令设置的共享密钥。
若服务器位于MPLS VPN私网中,为保证RADIUS报文被发送到指定的私网服务器,必须指定服务器所属的VPN实例。本命令指定的服务器所属的VPN实例比RADIUS方案所属的VPN实例具有更高的优先级。
当RADIUS服务器负载分担功能处于关闭状态时,如果在计费开始请求报文发送过程中修改或删除了正在使用的主计费服务器配置,则设备在与当前服务器通信超时后,将会重新按照优先级顺序开始依次查找状态为active的服务器进行通信;当RADIUS服务器负载分担功能处于开启状态时,设备将仅与发起计费开始请求的服务器通信。
如果在线用户正在使用的计费服务器被删除,则设备将无法发送用户的实时计费请求和停止计费请求,且停止计费报文不会被缓存到本地,这将造成对用户计费的不准确。
# 在RADIUS方案radius1中,配置主计费服务器的IP地址为10.110.1.2,使用UDP端口1813提供RADIUS计费服务,计费报文的共享密钥为明文123456TESTacct&!。
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813 key simple 123456TESTacct&!
· key (RADIUS scheme view)
· secondary accounting (RADIUS scheme view)
· server-load-sharing enable
· vpn-instance (RADIUS scheme view)
primary authentication命令用来配置主RADIUS认证服务器。
undo primary authentication命令用来恢复缺省情况。
primary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
未配置RADIUS主认证服务器。
RADIUS方案视图
ipv4-address:主RADIUS认证服务器的IPv4地址。
ipv6 ipv6-address:主RADIUS认证服务器的IPv6地址。
port-number:主RADIUS认证服务器的UDP端口号,取值范围为1~65535,缺省值为1812。此端口号必须与服务器提供认证服务的端口号保持一致。
key:与主RADIUS认证服务器交互的认证报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
cipher:以密文方式设置密钥。
test-profile profile-name:RADIUS服务器探测模板名称,为1~31个字符的字符串,区分大小写。
vpn-instance vpn-instance-name:主RADIUS认证服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主RADIUS认证服务器位于公网中。
weight weight-value:RADIUS服务器负载分担的权重。weight-value表示权重值,取值范围为0~100,缺省值为0。0表示该服务器在负载分担调度时将不被使用。开启服务器负载分担功能后,该参数才能生效,且权重值越大的服务器可以处理的认证请求报文越多。
配置的主认证服务器的UDP端口号以及认证报文的共享密钥必须与服务器的配置保持一致。
在同一个方案中指定的主认证服务器和从认证服务器的VPN、IP地址、端口号不能完全相同。
设备与主认证服务器通信时优先使用本命令设置的共享密钥,如果本命令中未设置,则使用key authenticaiton命令设置的共享密钥。
RADIUS认证服务器引用了存在的服务器探测模板后,将会触发对该服务器的探测功能。
若服务器位于MPLS VPN私网中,为保证RADIUS报文被发送到指定的私网服务器,必须指定服务器所属的VPN实例。本命令指定的服务器所属的VPN比RADIUS方案所属的VPN优先级高。
当RADIUS服务器负载分担功能处于关闭状态时,如果在认证过程中修改或删除了正在使用的主认证服务器配置,则设备在与当前服务器通信超时后,将会重新按照优先级顺序开始依次查找状态为active的服务器进行通信;当RADIUS服务器负载分担功能处于开启状态时,如果在认证过程中修改或删除了正在使用的认证服务器配置,则设备在与当前服务器通信超时后,将会根据各服务器的权重以及服务器承载的用户负荷重新选择状态为active的服务器进行通信。
# 在RADIUS方案radius1中,配置主认证服务器的IP地址为10.110.1.1,使用UDP端口1812提供RADIUS认证/授权服务,认证报文的共享密钥为明文123456TESTauth&!。
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812 key simple 123456TESTauth&!
· radius-server test-profile
· secondary authentication (RADIUS scheme view)
radius attribute extended命令用来定义RADIUS扩展属性。
undo radius attribute extended命令用来删除定义的RADIUS扩展属性。
radius attribute extended attribute-name [ vendor vendor-id ] code attribute-code type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string }
undo radius attribute extended [ attribute-name ]
不存在自定义RADIUS扩展属性。
attribute-name:RADIUS属性名称,为1~63个字符的字符串,不区分大小写。该名称不能与系统已支持的(包括标准的以及自定义的)RADIUS属性名称相同。
code attribute-code:RADIUS属性在RADIUS属性集里的序号,取值范围为1~255。
· binary:二进制类型。
· date:时间类型。
· integer:整数类型。
· ip:IPv4地址类型。
· ipv6:IPv6地址类型。
· octets:八进制类型。
· string:字符串类型。
当系统需要支持其他厂商的私有RADIUS属性时,可以通过radius attribute extended命令为其定义为一个扩展属性,并通过attribute convert命令将其映射到系统可以识别的一个已知属性。这样,当RADIUS服务器发送给设备的RADIUS报文中携带了此类不可识别的私有属性时,设备将根据已定义的属性转换规则将其转换为可处理的属性。同理,设备在发送RADIUS报文时也可以将自己可识别的属性转换为服务器能识别的属性。
每一个RADIUS属性有唯一的属性名称,且该属性的名称、设备厂商标识以及序号的组合必须在设备上唯一。
执行undo radius attribute extended命令时,如果不指定属性名称,则表示删除所有已定义RADIUS扩展属性。
# 配置一个RADIUS扩展属性,名称为Owner-Password,Vendor ID为122,属性序号为80,类型为字符串。
[Sysname] radius attribute extended Owner-Password vendor 122 code 80 type string
· attribute convert
· attribute reject
radius attribute-test-group命令用来创建RADIUS属性测试组,并进入RADIUS属性测试组视图。如果指定的RADIUS属性测试组视图已经存在,则直接进入RADIUS属性测试组视图。
undo radius attribute-test-group命令用来删除指定的RADIUS属性测试组。
radius attribute-test-group attr-test-group-name
undo radius attribute-test-group attr-test-group-name
不存在RADIUS属性测试组。
attr-test-group-name:测试组名称,为1~31个字符的字符串,不区分大小写。
RADIUS属性测试组用于配置向RADIUS服务器发送的认证/计费请求报文中需要携带的RADIUS属性的集合。
系统支持配置多个RADIUS属性测试组。
# 创建名称为t1的RADIUS属性测试组,并进入该视图。
· exclude
· include
· test-aaa
radius authentication-request first命令用来开启RADIUS认证请求优先处理功能。
undo radius authentication-request first命令用来关闭RADIUS认证请求优先处理功能。
RADIUS认证请求优先处理功能处于关闭状态,设备依次处理接入模块发起的所有RADIUS请求。
接入模块发起的RADIUS请求包括RADIUS认证请求、RADIUS计费开始请求、RADIUS计费更新请求和RADIUS计费结束请求。缺省情况下,设备依次处理各接入模块发起的所有类型的RADIUS请求。此时,如果有大量用户下线后立即再次上线的情况发生,则会由于设备首先处理较早的停止计费请求,而导致处理后续的认证请求时,接入模块的认证请求已经超时。认证请求超时后,用户认证失败。为了解决这个问题,建议在有大量用户频繁上下线的组网环境中开启本功能,使得设备优先处理RADIUS认证请求,从而保证用户可以正常上线。
需要注意的是,当RADIUS服务器上以用户名标识用户,并且不允许相同用户名的用户重复认证的情况下,不建议开启此功能,否则可能会导致用户下线后再次认证失败。
当设备上有用户在线时,不建议修改此配置。
# 开启RADIUS认证请求优先处理功能。
[Sysname] radius authentication-request first
radius dscp命令用来配置RADIUS协议报文的DSCP优先级。
undo radius dscp命令用来恢复缺省情况。
radius [ ipv6 ] dscp dscp-value
undo radius [ ipv6 ] dscp
RADIUS报文的DSCP优先级为0。
ipv6:表示设置IPv6 RADIUS报文。若不指定该参数,则表示设置IPv4 RADIUS报文。
dscp-value:RADIUS报文的DSCP优先级,取值范围为0~63。取值越大,优先级越高。
DSCP携带在IP报文中的ToS字段,用来体现报文自身的优先等级,决定报文传输的优先程度。通过本命令可以指定设备发送的RADIUS报文携带的DSCP优先级的取值。
# 配置IPv4 RADIUS报文的DSCP优先级为10。
[Sysname] radius dscp 10
radius dynamic-author server命令用来开启RADIUS DAE服务,并进入RADIUS DAE服务器视图。
undo radius dynamic-author server命令用来关闭RADIUS DAE服务。
RADIUS DAE服务处于关闭状态。
开启RADIUS DAE服务后,设备将会监听指定的RADIUS DAE客户端发送的DAE请求消息,然后根据请求消息进行用户授权信息的修改、断开用户连接请求或关闭/重启用户接入端口。
# 开启RADIUS DAE服务,并进入RADIUS DAE服务器视图。
· client
· port
radius nas-ip命令用来设置RADIUS报文中携带的NAS-IP地址。
undo radius nas-ip命令用来删除指定的NAS-IP地址。
radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未设置RADIUS报文中携带的NAS-IP地址,设备将以发送RADIUS报文的接口的主IPv4地址或IPv6地址作为NAS-IP地址。
ipv4-address:指定的IPv4 NAS-IP地址,不能为全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6 ipv6-address:指定的IPv6 NAS-IP地址,必须是单播地址,不能为环回地址与本地链路地址。
vpn-instance vpn-instance-name:指定私网NAS-IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示配置的是公网NAS-IP地址。
接口视图、RADIUS方案视图和系统视图下均可以配置发送RADIUS报文携带的NAS-IP地址,具体情况如下:
· RADIUS方案视图下配置的NAS-IP地址(通过nas-ip命令)只对本RADIUS方案有效。
系统视图下最多允许指定16个NAS-IP地址。其中,最多包括一个IPv4公网NAS-IP地址和一个IPv6公网NAS-IP地址,其余为私网NAS-IP地址。对于同一个VPN,系统视图下最多允许指定一个IPv4私网NAS-IP地址和一个IPv6私网NAS-IP地址。
# 设置设备发送RADIUS报文使用的IPv4 NAS-IP地址为129.10.10.1。
[Sysname] radius nas-ip 129.10.10.1
· aaa nas-ip
· nas-ip (RADIUS scheme view)
radius offline-reason-convert user-type ppp命令用来开启PPP用户下线原因转换功能。
undo radius offline-reason-convert user-type ppp命令用来关闭PPP用户下线原因转换功能。
PPP用户下线原因转换功能处于关闭状态。
开启本功能后,握手失败导致的PPP用户下线原因(Lost Carrier)将被转换为用户请求下线原因(User Request)上报给RADIUS服务器。请按照RADIUS服务器对用户下线原因的具体定义和要求,慎重选择是否开启本功能。
需要注意的是,本功能仅用于转换携带在RADIUS报文中上报给服务器的下线原因,不改变设备上通过其它途径显示的此类错误原因。
# 开启PPP用户下线原因转换功能。
[Sysname] radius offline-reason-conver user-type ppp
radius scheme命令用来创建RADIUS方案,并进入RADIUS方案视图。如果指定的RADIUS方案已经存在,则直接进入RADIUS方案视图。
undo radius scheme命令用来删除指定的RADIUS方案。
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
不存在RADIUS方案。
radius-scheme-name:RADIUS方案的名称,为1~32个字符的字符串,不区分大小写。
一个RADIUS方案可以同时被多个ISP域引用。
系统最多支持配置16个RADIUS方案。
# 创建名为radius1的RADIUS方案并进入其视图。
radius session-control client命令用来指定session control客户端。
undo radius session-control client命令用来删除指定的session control客户端。
radius session-control client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | vpn-instance vpn-instance-name ] *
undo radius session-control client { all | { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
未指定session control客户端。
ip ipv4-address:session control客户端的IPv4地址。
ipv6 ipv6-address:session control客户端的IPv6地址。
key:与session control客户端交互的计费报文的共享密钥。
cipher:以密文方式设置密钥。
vpn-instance vpn-instance-name:session control客户端所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示session control客户端属于公网。
all:表示所有session control客户端。
设备和H3C的iMC RADIUS服务器配合使用时,将作为session control服务器端与其交互,因此需要指定session control客户端来验证收到的session control报文的合法性。当设备收到服务器发送的session control报文时,直接根据报文的源IP地址、VPN属性与已有的session control客户端配置进行匹配,并使用匹配到的客户端共享密钥对报文进行验证。如果报文匹配失败或设备上未配置session control客户端,则使用已有的RADIUS方案配置进行匹配,并使用匹配到的认证服务器的共享密钥对报文进行验证。
指定的session control客户端仅在RADIUS session control功能处于开启状态时生效。
配置的session control客户端参数必须与服务器的配置保持一致。
系统支持指定多个session control客户端。
# 指定一个session control客户端IP地址为10.110.1.2,共享密钥为明文12345。
[Sysname] radius session-control client ip 10.110.1.2 key simple 12345
· radius session-control enable
radius session-control enable命令用来开启RADIUS session control功能。
undo radius session-control enable命令用来关闭RADIUS session control功能。
RADIUS session control功能处于关闭状态。
H3C iMC RADIUS服务器使用session control报文向设备发送授权信息的动态修改请求以及断开连接请求。开启RADIUS session control功能后,设备会打开知名UDP端口1812来监听并接收RADIUS服务器发送的session control报文。
该功能仅能和H3C iMC的RADIUS服务器配合使用。
# 开启RADIUS session control功能。
[Sysname] radius session-control enable
radius source-ip命令用来设置设备发送RADIUS报文使用的源IP地址。
undo radius source-ip命令用来删除指定的发送RADIUS报文使用的源IP地址。
radius source-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo radius source-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未指定发送RADIUS报文使用的源IP地址。
ipv4-address:指定的源IPv4地址,为本机的地址,不能为全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6 ipv6-address:指定的源IPv6地址,为本机的地址,必须是单播地址,不能为环回地址与本地链路地址。
vpn-instance vpn-instance-name:指定私网源IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示配置的是公网源地址。
RADIUS服务器上通过IP地址来标识接入设备,并根据收到的RADIUS报文的源IP地址是否与服务器所管理的接入设备的IP地址匹配,来决定是否处理来自该接入设备的认证或计费请求。为保证RADIUS报文可被服务器正常接收并处理,接入设备上发送RADIUS报文使用的源地址必须与RADIUS服务器上指定的接入设备的IP地址保持一致。
为避免物理接口故障时从服务器返回的报文不可达,推荐使用Loopback接口地址为发送RADIUS报文使用的源IP地址。
设备按照以下顺序选择发送RADIUS报文实际使用的源IP地址:
(1) RADIUS方案视图下配置的源IP地址(通过source-ip命令)。
(2) 系统视图下的配置的源IP地址(通过radius source-ip命令)。
(3) RADIUS方案视图下配置的NAS-IP地址(通过nas-ip命令)。
(4) 系统视图下的配置的源NAS-IP地址(通过radius nas-ip命令)。
(5) 发送RADIUS报文的出接口的IP地址。
系统视图下的配置的源IP地址对所有RADIUS方案有效。
系统视图下最多允许指定16个源地址。其中,最多包括一个IPv4公网源地址和一个IPv6公网源地址,其余为私网源地址。对于同一个VPN,系统视图下最多允许指定一个IPv4私网源地址和一个IPv6私网源地址。
# 设置设备发送RADIUS报文使用的源IPv4地址为129.10.10.1。
[Sysname] radius source-ip 129.10.10.1
· radius nas-ip
· source-ip (RADIUS scheme view)
radius stop-accounting-buffer cache命令用来配置RADIUS停止计费报文的最大缓存数目。
undo radius stop-accounting-buffer cache命令用来恢复缺省配置。
radius stop-accounting-buffer cache max-packet-number
设备允许缓存的最大停止计费报文个数为256000。
max-packet-number:最大RADIUS停止计费报文数,范围为取值范围是256~2147483647。
在RADIUS计费场景下,若开启了对无响应的RADIUS停止计费报文缓存功能,设备会将停止计费报文缓存在本机上,然后多次尝试向服务器发起停止计费请求。为了限制RADIUS停止计费报文对系统资源的占用,支持对设备可缓存的停止计费报文的最大数目进行设置。在网络连接质量不太稳定,且用户下线请求比较集中的环境中,建议提前规划并配置可缓存的报文数目,以避免用户下线业务短期内占用过多系统缓存资源。
当期望配置的缓存数目小于设备上已有的停止计费报文缓存数目时,配置将会失败。这种情况下,可以等待缓存报文数目减小或者手动清空部分缓存报文后,再次重新配置。通过reset stop-accounting-buffer命令清除缓存的RADIUS停止计费请求报文前,请首先通过display stop-accounting-buffer命令了解已缓存的RADIUS停止计费请求报文状况。
# 配置RADIUS停止计费报文的最大缓存数目为9000。
[Sysname] radius stop-accounting-buffer cache 9000
· display stop-accounting-buffer (for RADIUS)
radius stop-accounting-buffer overwrite-oldest命令用来配置当RADIUS停止计费报文个数达到最大缓存数目时,新产生的停止计费报文覆盖缓存时间最久的停止计费报文。
undo radius stop-accounting-buffer overwrite-oldest命令用来删除指定的覆盖缓存相关配置。
radius stop-accounting-buffer { exceed | memory-minor-threshold } overwrite-oldest
undo radius stop-accounting-buffer { exceed | memory-minor-threshold } overwrite-oldest
当RADIUS停止计费报文个数达到最大缓存数目时,新产生的停止计费报文缓存失败。
exceed:表示停止计费报文个数达到最大缓存数目。
memory-minor-threshold:表示设备剩余内存触发一级告警。
当设备上已缓存的RADIUS停止计费报文数目达到最大值或设备产生一级内存告警时,对于新产生的需要缓存的停止计费报文,有两种处理方式供选择:
· 缺省模式:新增加的停止计费报文缓存失败。如果对较早下线用户的计费准确度要求更高,建议采用此方式。
· 覆盖模式:新增加的停止计费报文覆盖原有已缓存的停止计费报文,且从缓存时间最久的停止计费报文开始覆盖。如果对较晚下线的用户的计费准确度要求更高,建议采用此方式。
指定exceed和指定memory-minor-threshold的命令行可以同时存在,任何一个条件满足时,都可以允许新产生的停止计费报文覆盖式保存。
RADIUS停止计费报文的最大缓存数目由radius stop-accounting-buffer cache命令配置。
设备的内存告警门限情况可通过display memory-threshold命令查看。
# 配置当RADIUS停止计费报文个数达到最大缓存数目时,让新产生的停止计费报文覆盖缓存时间最久的停止计费报文。
[Sysname] radius stop-accounting-buffer exceed overwrite-oldest
# 配置当设备产生一级内存告警时,让新产生的停止计费报文覆盖缓存时间最久的停止计费报文。
[Sysname] radius stop-accounting-buffer memory-minor-threshold overwrite-oldest
· display memory-threshold(基础配置命令参考/设备管理)
· radius stop-accounting-buffer cache
radius stop-accounting-buffer warning-threshold命令用来配置RADIUS停止计费报文缓存告警阈值。
undo radius stop-accounting-buffer warning-threshold命令用来恢复缺省情况。
radius stop-accounting-buffer warning-threshold upper upper-threshold lower lower-threshold
未配置RADIUS停止计费报文缓存告警阈值。
upper upper-threshold:触发RADIUS停止计费报文缓存告警的上限阈值,取值范围为1~100,单位为百分比。
lower lower-threshold:触发RADIUS停止计费报文缓存告警的恢复阈值,取值0~99,单位为百分比。取值为0表示设备上没有缓存RADIUS停止计费报文时,触发恢复告警。
为了限制RADIUS停止计费报文对系统资源的占用,可以对设备上缓存的停止计费报文的最大数目进行限制。为了及时掌握停止计费报文的资源占用情况,需要开启RADIUS停止计费报文缓存告警并设置合理的缓存告警阈值。缓存告警阈值是一种预警门限,此时RADIUS停止计费报文仍然处于正常缓存的状态,但需要提醒设备管理员提前关注设备和RADIUS服务器之间的链路状态是否异常。
通过snmp-agent trap enable radius命令开启对应的RADIUS停止计费报文缓存告警后,当设备上已缓存的RADIUS停止计费报文数目与radius stop-accounting-buffer cache命令配置的最大缓存数目的比值达到指定的百分比时,将触发设备输出相应的SNMP告警信息:
· 当该比值首次达到指定的上限阈值(upper-threshold),或者从低于等于恢复阈值增长到上限阈值时,将触发上限告警。
· 当该比值从大于等于上限阈值下降到恢复阈值时(lower-threshold),将触发输出恢复告警。
通常情况下,建议上限阈值与恢复阈值的差值为30左右。
# 配置RADIUS停止计费报文缓存告警的上限阈值为90、恢复阈值为50。
[Sysname] radius stop-accounting-buffer warning-threshold upper 90 lower 50
· snmp-agent trap enable radius
radius trap-version命令用来配置发送RADIUS告警信息采用的MIB节点版本。
undo radius trap-version命令用来恢复缺省情况。
radius trap-version { v1 | v2 } [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up ] *
undo radius trap-version { v1 | v2 } [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up ] *
使用v1版本的MIB节点发送RADIUS告警信息。
v1:采用v1版本的MIB节点发送RADIUS告警信息。
v2:采用v2版本的MIB节点发送RADIUS告警信息。
accounting-server-down:表示RADIUS计费服务器可达状态变为down时发送告警信息。
accounting-server-up:表示RADIUS计费服务器可达状态变为up时发送告警信息。
authentication-server-down:表示RADIUS认证服务器可达状态变为down时发送告警信息。
authentication-server-up:表示RADIUS认证服务器可达状态变为up时发送告警信息。
请按照NMS(Network Management System,网络管理系统)的要求,选择设备需要采用的发送RADIUS告警信息采用的MIB节点版本。
表1-15 v1版本的MIB节点
MIB节点名 |
OID |
hh3cRadiusAuthServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.1 |
hh3cRadiusAccServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.2 |
hh3cRadiusAuthServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.1 |
hh3cRadiusAccServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.2 |
表1-16 v2版本的MIB节点
MIB节点名 |
OID |
hh3cRadiusAuthenticationServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.4 |
hh3cRadiusAccountingServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.5 |
hh3cRadiusAuthenticationServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.0.6 |
hh3cRadiusAccountingServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.0.7 |
若不指定任何参数,则表示设备发送所有类型的RADIUS服务器状态变化告警信息时,均采用相同版本的MIB节点。
多次执行本命令,最后一次执行的命令生效。
# 配置在RADIUS计费服务器可达状态变为down时发送告警信息采用v2版本的MIB节点。
[Sysname] radius trap-version v2 accounting-server-down
radius-server authen-state-check interval命令用来设置RADIUS认证服务器状态检查的时间间隔。
undo radius-server authen-state-check interval命令用来恢复缺省情况。
radius-server authen-state-check interval interval
RADIUS认证服务器状态检查的时间间隔为10分钟。
interval:状态检查的时间间隔,取值范围为1~120,单位为分钟。
本特性仅对IPoE、PPPoE用户生效。
系统将以指定的时间间隔定期检查各RADIUS方案下的RADIUS认证服务器的状态,并通知接入模块将存在可达认证服务器的RADIUS方案下的已逃生用户取消逃生。
设备对RADIUS认证服务器状态变化的及时感知影响到用户逃生处理的准确性。配置了用户逃生功能的情况下,可能会有如下情况发生:
· RADIUS服务器探测功能开启后,如果RADIUS服务器的探测周期过长,那么在设备还未获得探测结果的情况下,如果服务器状态变为不可达,在此期间上线的用户将会进入逃生域,但是探测周期内设备上记录的服务器状态一直为active。
· RADIUS服务器探测功能未开启时,在RADIUS服务器响应超时时间内没有收到响应报文的认证用户将会进入逃生域,但是如果设备在此期间收到了来自该服务器对其它用户的认证请求响应报文,则设备上记录的服务器的状态将不会被置为block。如果后续用户的认证服务器状态一直保持可达,设备记录的服务器状态会一直为active。
以上两种情况下,设备均无法及时感知到服务器实际状态的变化,因而已经逃生的用户也无法在RADIUS认证服务器恢复可达后离开逃生域。RADIUS认证服务器状态检查功能可以解决这个问题,
如果设置的状态检查时间间隔过小,将会占用接入业务处理的系统资源;如果设置的状态检查时间间隔过大,对于服务器实际状态变化的感知将不够及时。
在有大量用户集中上线的情况下,建议综合考虑接入业务的处理效率和逃生处理的准确性。
# 设置RADIUS认证服务器状态检查的时间间隔为2分钟。
[Sysname] radius-server authen-state-check interval 2
· authen-radius-unavailable online domain
radius-server test-profile命令用来配置RADIUS服务器探测模板。
undo radius-server test-profile命令用来删除指定的RADIUS服务器探测模板。
radius-server test-profile profile-name username name [ interval [ second ] interval ]
undo radius-server test-profile profile-name
不存在RADIUS服务器探测模板。
profile-name:探测模板名称,为1~31个字符的字符串,区分大小写。
username name:探测报文中的用户名,为1~253个字符的字符串,区分大小写。
interval:发送探测报文的周期,缺省值为60分钟。
second:单位为秒。若不指定该参数,则表示单位为分钟。
interval:探测周期。以分钟为单位时,取值范围为1~3600;以秒为单位时,取值范围为10~216000。
系统支持配置多个RADIUS服务器探测模板。
RADIUS方案视图下的RADIUS服务器配置成功引用了某探测模板后,若被引用的探测模板不存在,则暂不启动探测功能。之后,当该探测模板被成功配置时,针对该服务器的探测过程将会立即开始。
删除一个RADIUS服务器探测模板时,引用该探测模板的所有RADIUS方案中的RADIUS服务器的探测功能也会被关闭。
# 配置RADIUS服务器探测模板abc,探测报文中携带的用户名为admin,探测报文的发送间隔为10分钟。
[Sysname] radius-server test-profile abc username admin interval 10
· primary authentication (RADIUS scheme view)
reset radius server-load statistics命令用来清除所有RADIUS服务器的历史负载统计信息。
该命令只会清除所有RADIUS认证/计费服务器的历史负载统计数据,不会清除前5秒钟负载统计数据。
# 清除所有RADIUS服务器上的历史负载统计信息。
<Sysname> reset radius server-load statistics
· display radius server-load statistics
reset radius statistics命令用来清除RADIUS报文的统计信息。
reset radius statistics [ server { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-number ] { accounting | authentication } ]
vpn-instance vpn-instance-name:指定RADIUS服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主RADIUS计费服务器位于公网中。
可通过本命令清除设备和RADIUS服务器之间交互的报文统计信息,包括RADIUS认证报文、RADIUS计费报文、DAE报文和session control报文的统计信息。
若不指定任何参数,则表示清除设备和所有RADIUS服务器交互的所有RADIUS报文统计信息。
当需要精确了解某段时间内指定的RADIUS报文统计信息时,可以先使用reset radius statistics命令清除该统计数,然后再使用display radius statistics命令精确查看当前时间段的RADIUS报文统计信息。
需要注意的是,清除设备与某个RADIUS服务器交互的RADIUS报文统计信息时,通过display radius statistics命令查看到的RADIUS报文总体统计计数并不会发生改变。
# 清除所有RADIUS报文统计信息。
<Sysname> reset radius statistics
# 清除设备与IP地址为1.1.1.1、端口号为1813的RADIUS服务器之间交互的计费报文统计信息。
<Sysname> reset radius statistics server ip 1.1.1.1 port 1813 accounting
· display radius statistics
reset stop-accounting-buffer命令用来清除缓存的RADIUS停止计费请求报文。
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
radius-scheme radius-scheme-name:表示指定RADIUS方案的停止计费响应报文。其中,radius-scheme-name为RADIUS方案名,为1~32个字符的字符串,不区分大小写。
session-id session-id:表示指定会话的停止计费响应报文。其中,session-id表示会话ID,为1~64个字符的字符串,不包含字母。会话ID用于唯一标识当前的在线用户。
time-range start-time end-time:表示指定时间段内发送且被缓存的停止计费请求报文。其中,start-time为请求时间段的起始时间;end-time为请求时间段的结束时间,格式为hh:mm:ss-mm/dd/yyyy(时:分:秒-月/日/年)或hh:mm:ss-yyyy/mm/dd(时:分:秒-年/月/日)。
user-name user-name:表示指定用户名的停止计费响应报文。其中,user-name表示用户名,为1~255个字符的字符串,区分大小写。输入的用户名是否携带ISP域名,必须与RADIUS方案中配置的发送给RADIUS服务器的用户名格式保持一致。
# 清除缓存的用户user0001@test的RADIUS停止计费请求报文。
<Sysname> reset stop-accounting-buffer user-name user0001@test
# 清除从2019年5月31日0点0分0秒到2019年5月31日23点59分59秒期间内缓存的停止计费请求报文。
<Sysname> reset stop-accounting-buffer time-range 00:00:00-05/31/2019 23:59:59-05/31/2019
response-pending-limit命令用来配置发送给RADIUS服务器且未收到响应的请求报文的最大数目。
undo response-pending-limit命令用来取消配置的指定类型请求报文的最大数目。
response-pending-limit { accounting | authentication } max-number
undo response-pending-limit { accounting | authentication }
未限制发送给RADIUS服务器且未收到响应的请求报文的最大数目。
RADIUS方案视图
accounting:指定未收到计费服务器响应的请求报文的最大数目。
authentication:指定未收到认证服务器响应的请求报文的最大数目。
max-number:请求报文的最大值,取值范围为1~255。
如果RADIUS服务器处理能力有限,不能并发处理过多的RADIUS请求报文,则可以通过本配置控制设备发送给RADIUS服务器的请求报文的速率。系统中存在两类Pending报文计数器,分别服务于RADIUS认证服务器和计费服务器,用于统计已发送给RADIUS服务器但还未收到响应的请求报文数,其最大值由本配置决定。在一个RADIUS方案下指定了认证/计费Pending报文计数器的最大值后,针对该方案下的每一个RADIUS认证/计费服务器,设备均会在向其发送首个认证/计费请求报文后启动一个Pending报文计数器。Pending报文计数器的具体工作机制如下:
(1) 设备向RADIUS服务器每发送一个请求报文后,都会将对应的Pending报文计数器加一,且在每收到一个响应报文或者该请求响应超时后,又将该Pending报文计数器减一。
(2) 当该计数器值达到最大值时,设备停止向对应的服务器发送请求报文,并将后续准备发送的请求报文缓存起来。
(3) 等到该计数器值低于最大值后,设备再按照缓存的先后顺序依次发送那些缓存的请求报文。当前可发送的请求报文数,取决于计数器值与最大值的差值。
删除本配置后,将不再限制发送给RADIUS服务器且未收到响应的请求报文的最大数目。
仅支持对PPP、IPoE、lan-access类型的接入用户请求速率进行控制。
由于接入用户数据均保存在用户接入的单板上,因此配置的速率基于单板生效。
# 在RADIUS方案radius1中,配置发送给RADIUS认证服务器且未收到响应的请求报文的最大数为100。
[Sysname-radius-radius1] response-pending-limit authentication 100
retry命令用来设置发送RADIUS报文的最大尝试次数。
undo retry命令用来恢复缺省情况。
retry retries
undo retry
发送RADIUS报文的最大尝试次数为3次。
RADIUS方案视图
retries:发送RADIUS报文的最大尝试次数,取值范围为1~20。
由于RADIUS协议采用UDP报文来承载数据,因此其通信过程是不可靠的。如果设备在应答超时定时器规定的时长内(由timer response-timeout命令配置)没有收到RADIUS服务器的响应,则设备有必要向RADIUS服务器重传RADIUS请求报文。如果累计的传送次数已达到最大传送次数而RADIUS服务器仍旧没有响应,则设备将认为本次请求失败。
· 发送RADIUS报文的最大尝试次数、RADIUS服务器响应超时时间以及配置的RADIUS服务器总数,三者的乘积不能超过接入模块定义的用户认证超时时间,否则在RADIUS认证过程完成之前用户就有可能被强制下线。
· 设备在按照配置顺序尝试与下一个RADIUS服务器通信之前,会首先判断当前累计尝试持续时间是否达到或超过300秒,如果超过或达到300秒,将不再向下一个RADIUS服务器发送RADIUS请求报文,即认为该RADIUS请求发送失败。因此,为了避免某些已部署的RADIUS服务器由于此超时机制而无法被使用到,建议基于配置的RADIUS服务器总数,合理设置发送RADIUS报文的最大尝试次数以及RADIUS服务器响应超时时间。
# 在RADIUS方案radius1中,设置发送RADIUS报文的最大尝试次数为5次。
[Sysname-radius-radius1] retry 5
· radius scheme
· timer response-timeout (RADIUS scheme view)
retry realtime-accounting命令用来设置允许发起实时计费请求的最大尝试次数。
undo retry realtime-accounting命令用来恢复缺省情况。
retry realtime-accounting retries
设备允许发起实时计费请求的最大尝试次数为5。
RADIUS方案视图
retries:允许发起实时计费请求的最大尝试次数,取值范围为1~255。
RADIUS服务器通常通过连接超时定时器来判断用户是否在线。如果RADIUS服务器在连接超时时间之内一直收不到设备传来的实时计费报文,它会认为线路或设备故障并停止对用户记帐。为了配合RADIUS服务器的这种特性,有必要在不可预见的故障条件下,尽量保持设备端与RADIUS服务器同步切断用户连接。设备提供对实时计费请求连续无响应次数限制的设置,保证设备尽可能得在RADIUS服务器的连接超时时长内向RADIUS服务器尝试发出实时计费请求。如果设备没有收到响应的次数超过了设定的限度,才会认为用户的实时计费失败,然后采用设置的计费更新失败策略决定是否切断用户连接(由accounting update-fail命令设置)。
以lan-access用户为例,假设RADIUS服务器的应答超时时长(timer response-timeout命令设置)为3秒,发送RADIUS报文的最大尝试次数(retry命令设置)为3,设备的实时计费间隔(timer realtime-accounting命令设置)为12分钟,设备允许实时计费无响应的最大次数为5次(retry realtime-accounting命令设置),则其含义为:设备每隔12分钟发起一次计费请求,如果3秒钟得不到回应就重新发起一次请求,如果3次发送都没有得到回应就认为该次实时计费失败,然后每隔12分钟再发送一次,5次均失败以后,设备将认为用户实时计费失败。
# 在RADIUS方案radius1中,设置允许发起实时计费请求的最大尝试次数为10。
[Sysname-radius-radius1] retry realtime-accounting 10
· accounting update-fail
· retry
· timer realtime-accounting (RADIUS scheme view)
retry stop-accounting命令用来设置发起RADIUS停止计费请求的最大尝试次数。
undo retry stop-accounting命令用来恢复缺省情况。
retry stop-accounting retries
发起RADIUS停止计费请求的最大尝试次数为500。
RADIUS方案视图
retries:允许停止计费请求无响应的最大次数,取值范围为10~65535。
设备通过发起RADIUS停止计费请求的最大尝试次数与其它相关参数一起控制停止计费请求报文的发送。假设存在如下配置:
· RADIUS服务器的应答超时时长(由timer response-timeout命令设置)为3秒;
· 发送RADIUS报文的最大尝试次数(由retry命令设置)为5;
· 开启了对无响应的RADIUS停止计费请求报文的缓存功能;
· 设备发起停止计费请求的最大尝试次数为20(由retry stop-accounting命令设置)。
则,如果设备发送停止计费请求报文后的3秒内得不到服务器响应就重新发送该报文。如果设备发送5次之后仍然没有得到响应,会将该报文缓存在本机上,然后再发起一轮停止计费请求。20次请求尝试均失败以后,设备将缓存的报文丢弃。
# 在RADIUS方案radius1中,设置发起RADIUS停止计费请求的最大尝试次数为1000。
[Sysname-radius-radius1] retry stop-accounting 1000
· retry
secondary accounting命令用来配置从RADIUS计费服务器。
undo secondary accounting命令用来删除指定的从RADIUS计费服务器。
secondary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary accounting [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
未配置从RADIUS计费服务器。
RADIUS方案视图
ipv4-address:从RADIUS计费服务器的IPv4地址。
ipv6 ipv6-address:从RADIUS计费服务器的IPv6地址。
port-number:从RADIUS计费服务器的UDP端口号,取值范围为1~65535,缺省值为1813。
key:与从RADIUS计费服务器交互的计费报文的共享密钥。
cipher:以密文方式设置密钥。
vpn-instance vpn-instance-name:从RADIUS计费服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从RADIUS计费服务器位于公网中。
配置的从计费服务器的UDP端口号以及计费报文的共享密钥必须与服务器的配置保持一致。
每个RADIUS方案中最多支持配置16个从RADIUS计费服务器。当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。
在同一个方案中指定的主计费服务器和从计费服务器的VPN、IP地址、端口号不能完全相同,并且各从计费服务器的VPN、IP地址、端口号也不能完全相同。
设备与从计费服务器通信时优先使用本命令设置的共享密钥,如果此处未设置,则使用命令key accounting命令设置的共享密钥。
当RADIUS服务器负载分担功能处于关闭状态时,如果在计费开始请求报文发送过程中删除了正在使用的从服务器配置,则设备在与当前服务器通信超时后,将会重新按照优先级顺序开始依次查找状态为active的服务器进行通信;在RADIUS服务器负载分担功能处于开启状态时,设备将仅与发起计费开始请求的服务器通信。
如果在线用户正在使用的计费服务器被删除,则设备将无法发送用户的实时计费请求和停止计费请求,且停止计费报文不会被缓存到本地。
# 在RADIUS方案radius1中,配置从计费服务器的IP地址为10.110.1.1,使用UDP端口1813提供RADIUS计费服务。
[Sysname] radius scheme radius1
[Sysname-radius-radius1] secondary accounting 10.110.1.1 1813
# 在RADIUS方案radius2中,配置两个从计费服务器,IP地址分别为10.110.1.1、10.110.1.2,且均使用UDP端口1813提供RADIUS计费服务。
[Sysname] radius scheme radius2
[Sysname-radius-radius2] secondary accounting 10.110.1.1 1813
[Sysname-radius-radius2] secondary accounting 10.110.1.2 1813
· display radius scheme
· primary accounting
secondary authentication命令用来配置从RADIUS认证服务器。
undo secondary authentication命令用来删除指定的从RADIUS认证服务器。
secondary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary authentication [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
未配置从RADIUS认证服务器。
RADIUS方案视图
ipv4-address:从RADIUS认证服务器的IPv4地址。
ipv6 ipv6-address:从RADIUS认证服务器的IPv6地址。
port-number:从RADIUS认证服务器的UDP端口号,取值范围为1~65535,缺省值为1812。
key:与从RADIUS认证服务器交互的认证报文的共享密钥。
cipher:以密文方式设置密钥。
vpn-instance vpn-instance-name:从RADIUS认证服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从RADIUS认证服务器位于公网中。
配置的从认证服务器的UDP端口号以及认证报文的共享密钥必须与服务器的配置保持一致。
每个RADIUS方案中最多支持配置16个从RADIUS认证服务器。当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。
在同一个方案中指定的主认证服务器和从认证服务器的VPN、IP地址、端口号不能完全相同,并且各从认证服务器的VPN、IP地址、端口号也不能完全相同。
设备与从认证服务器通信时优先使用本命令设置的共享密钥,如果此处未设置,则使用命令key authentication命令设置的共享密钥。
当RADIUS服务器负载分担功能处于关闭状态时,如果在认证过程中删除了正在使用的从服务器配置,则设备在与当前服务器通信超时后,将会重新按照优先级顺序开始依次查找状态为active的服务器进行通信;在RADIUS服务器负载分担功能处于开启状态时,如果在认证过程中修改或删除了正在使用的认证服务器配置,则设备在与当前服务器通信超时后,将会根据各服务器的权重以及服务器承载的用户负荷重新选择状态为active的服务器进行通信。
# 在RADIUS方案radius1中,配置从认证服务器的IP地址为10.110.1.2,使用UDP端口1812提供RADIUS认证/授权服务。
[Sysname-radius-radius1] secondary authentication 10.110.1.2 1812
# 在RADIUS方案radius2中,配置两个从认证服务器,IP地址分别为10.110.1.1、10.110.1.2,且均使用UDP端口1812提供RADIUS认证/授权服务。
[Sysname-radius-radius2] secondary authentication 10.110.1.1 1812
[Sysname-radius-radius2] secondary authentication 10.110.1.2 1812
server-block-action命令用来设置RADIUS服务器都处于block状态后的请求动作。
undo server-block-action命令用来恢复缺省情况。
server-block-action { attempt | skip }
所有RADIUS服务器都处于block状态后的请求动作为attempt。
RADIUS方案视图
attempt:Attempt方式,表示该方案下的所有服务器都处于block状态后,设备收到用户的认证/计费请求时,仍然会尝试向当前方案中的一个认证/计费服务器发送认证/计费请求(手工置于block状态的服务器除外)。
skip:Skip方式,表示该方案下的所有服务器都处于block状态后,设备收到用户的认证/计费请求时,会跳过当前方案中的所有服务器,直接使用为该用户配置的下一个认证/计费方法去处理这个请求。
Attempt方式下,由于该方案下的所有RADIUS服务器都处于block状态后,设备仍会首先尝试与高优先级的服务器建立连接,与该服务器建立连接失败后,才会切换到配置的下一个认证/计费方法,此方法保证了设备尽量优先使用第一个认证/计费方法处理用户请求,但同时会增加请求的响应时间。因此,对于对AAA响应时间要求比较高的场合,建议选择Skip方式。
设备处理一个认证/计费请求的过程中,如果已经跳过了当前方案中的所有服务器,则后续就算该方案中有服务器状态切换回active,设备也不会再使用该方案来处理它。
# 在RADIUS方案radius1中,设置RADIUS服务器都处于block状态后的动作为跳过当前方案中的所有服务器。
[Sysname-radius-radius1] server-block-action skip
· retry
server-load-sharing enable命令用来开启RADIUS服务器负载分担功能。
undo server-load-sharing enable命令用来关闭RADIUS服务器负载分担功能。
RADIUS服务器负载分担功能处于关闭状态。
RADIUS方案视图
缺省情况下,RADIUS服务器负载分担功能处于关闭状态,RADIUS服务器的调度采用主/从模式。
主/从模式下,设备优先选取状态为active的主服务器进行交互,若主服务器不可达则尝试与从服务器交互。设备尝试与从服务器交互时,按照从服务器的配置顺序依次选择,先配置的服务器将优先被选取。
在主/从模式下,设备选择服务器的逻辑比较单一。如果RADIUS方案中的主服务器或者某一配置顺序靠前的从服务器始终可达,则该服务器将独立承载该方案下所有用户的AAA业务。在大用户量下,这类服务器的负荷过重,将会影响处理用户上线的整体性能。
RADIUS方案中开启服务器负载分担功能后,设备将根据当前各服务器承载的用户负荷调度合适的服务器发送认证/计费请求。考虑到各服务器的性能可能存在差异,设备支持管理员配置服务器时为各个服务器指定适应其性能的权重值(由weight关键字指定),权重值较大的服务器具备较大的被选取可能性。设备在处理用户认证/计费请求时,将综合各个服务器的权重值及当前用户负荷情况,按比例进行用户负荷分配并选择要交互的服务器。
需要注意的是,负载分担模式下,某台计费服务器开始对某用户计费后,该用户后续计费请求报文均会发往同一计费服务器。如果该计费服务器不可达,则直接返回计费失败。
# 在RADIUS方案radius1中,开启RADIUS服务器负载分担功能。
[Sysname-radius-radius1] server-load-sharing enable
· primary accounting (RADIUS scheme view)
· server-load-sharing mode
server-load-sharing mode命令用来配置RADIUS认证服务器的负载分担方式。
undo server-load-sharing mode命令用来恢复缺省情况。
server-load-sharing mode { packet-based | session-based }
RADIUS认证服务器的负载分担方式为session-based。
RADIUS方案视图
packet-based:表示认证基于报文进行负载分担。
session-based:表示认证基于会话进行负载分担。
RADIUS服务器负载分担功能处于开启状态时,设备支持两种负载分担方式选择向该方案中的哪个认证服务器发送认证请求报文:
· 基于会话负载分担:根据各认证服务器当前承载的并发会话数,基于权重比例调度服务器。每当设备向某服务器发送一个认证请求报文后,该服务器承载的会话数增加一;若设备收到该服务器的认证响应报文,则会将它承载的会话数减去一。因此,该方式适用于并发用户数大且各服务器性能较为均衡的情况。
· 基于报文负载分担:根据各认证服务器已承载的请求报文数,基于权重比例调度服务器。每当设备向某服务器发送一个认证请求报文后,该服务器承载的请求报文数增加一;若设备重启,则所有服务器承载的请求报文数将被清零。这种方式可以满足希望用户认证报文均匀分配到各服务器上,避免某一个服务器一直处于工作状态的需求。
该命令只有在RADIUS服务器负载分担功能开启状态下有效,并且只用来控制认证负载分担的算法。
# 在RADIUS方案radius1中,配置RADIUS认证服务器采用基于报文的负载分担方式。
[Sysname-radius-radius1] server-load-sharing mode packet-based
snmp-agent trap enable radius命令用来开启RADIUS告警功能。
undo snmp-agent trap enable radius命令用来关闭指定的RADIUS告警功能。
snmp-agent trap enable radius [ accounting-cache-discard | accounting-cache-lower-threshold | accounting-cache-upper-threshold | accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
undo snmp-agent trap enable radius [ accounting-cache-discard | accounting-cache-lower-threshold | accounting-cache-upper-threshold | accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
所有类型的RADIUS告警功能处于关闭状态。
accounting-cache-discard:表示设备产生一级内存告警且丢弃RADIUS停止计费报文时发送告警信息。
accounting-cache-lower-threshold:表示RADIUS停止计费报文缓存率到达恢复阈值时发送告警信息。
accounting-cache-upper-threshold:表示RADIUS停止计费报文缓存率到达上限阈值时发送告警信息。
authentication-error-threshold:表示认证失败次数超过阈值时发送告警信息。该阈值为认证失败次数占认证请求总数的百分比数值,目前仅能通过MIB方式配置,取值范围为1~100,缺省为30。
不指定任何参数时,表示开启或关闭所有类型的RADIUS告警功能。
系统可以生成以下几种RADIUS告警信息:
· 设备触发一级内存门限的告警:设备产生一级内存告警,且开始丢弃已缓存或待缓存的RADIUS停止计费报文时,会发送该告警信息。
· RADIUS停止计费报文缓存率到达阈值的告警:当设备上的RADIUS停止计费报文缓存率到达预设的百分比时,会发送该类告警信息。相关阈值由radius accounting cache-warning-threshold命令设置。
· RADIUS服务器不可达的告警:当NAS向RADIUS服务器发送计费或认证请求没有收到响应时,会重传请求,当重传次数达到最大传送次数时仍然没有收到响应时,则发送该告警信息。
· RADIUS服务器可达的告警:当timer quiet定时器设定的时间到达后,NAS将服务器的状态置为激活状态并发送该告警信息。
· 认证失败次数超过阈值的告警:当NAS发现认证失败次数与认证请求总数的百分比超过阈值时,会发送该告警信息。
# 开启RADIUS计费服务器可达状态变为down时的告警功能。
[Sysname] snmp-agent trap enable radius accounting-server-down
· radius accounting cache-warning-threshold
undo source-ip命令用来删除指定类型的发送RADIUS报文使用的源IP地址。
undo source-ip [ ipv6 ]
未指定设备发送RADIUS报文使用的源IP地址,使用系统视图下由命令radius source-ip指定的源IP地址。
RADIUS方案视图
ipv4-address:源IPv4地址,为本机地址,不能为全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6 ipv6-address:源IPv6地址,为本机地址,且必须是单播地址,不能为环回地址与本地链路地址。
RADIUS服务器上通过IP地址来标识接入设备,并根据收到的RADIUS报文的源IP地址是否与服务器所管理的接入设备的IP地址匹配,来决定是否处理来自该接入设备的认证或计费请求。因此,为保证RADIUS报文可被服务器正常接收并处理,接入设备上发送RADIUS报文使用的源地址必须与RADIUS服务器上指定的接入设备的IP地址保持一致。
一个RADIUS方案视图下,最多允许指定一个IPv4源地址和一个IPv6源地址。
如果undo source-ip命令中不指定ipv6参数,则表示删除配置的发送RADIUS报文使用的源IPv4地址。
#在RADIUS方案radius1中,设置设备发送RADIUS报文使用的源IPv4地址为10.1.1.1。
[Sysname-radius-radius1] source-ip 10.1.1.1
· radius nas-ip
· radius source-ip
state primary命令用来设置主RADIUS服务器的状态。
state primary { accounting | authentication } { active | block }
主RADIUS服务器状态为active。
RADIUS方案视图
accounting:主RADIUS计费服务器。
authentication:主RADIUS认证服务器。
active:正常工作状态。
block:通信中断状态。
当RADIUS服务器负载分担功能处于关闭状态时,每次用户发起认证或计费,如果主服务器状态为active,则设备都会首先尝试与主服务器进行通信,如果主服务器不可达,则将主服务器的状态置为block,同时启动主服务器的timer quiet定时器,然后设备会严格按照从服务器的配置先后顺序依次查找状态为active的从服务器。在timer quiet定时器设定的时间到达之后,主服务器状态将由block恢复为active。若该定时器超时之前,通过本命令将主服务器的状态手工设置为block,则定时器超时之后主服务器状态不会自动恢复为active,除非通过本命令手工将其设置为active。
当RADIUS服务器负载分担功能处于开启状态时,若当前存在状态为active的认证/计费服务器,则设备仅根据当前各服务器承载的用户负荷来选择与之通信的服务器。
认证服务器的状态会影响设备对该服务器可达性探测功能的开启。当指定的服务器状态为active,且该服务器通过radius-server test-profile命令成功引用了一个已存在的服务器探测模板时,则设备会开启对该服务器的可达性探测功能。当手工将该服务器状态置为block时,会关闭对该服务器的可达性探测功能。
当主RADIUS服务器状态变化时,引用该服务器的所有RADIUS方案均生效。
# 在RADIUS方案radius1中,设置主认证服务器的状态为block。
[Sysname-radius-radius1] state primary authentication block
· state secondary
state secondary命令用来设置从RADIUS服务器的状态。
state secondary { accounting | authentication } [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ] { active | block }
从RADIUS服务器状态为active。
RADIUS方案视图
accounting:从RADIUS计费服务器。
authentication:从RADIUS认证服务器。
ipv4-address:从RADIUS服务器的IPv4地址。
ipv6 ipv6-address:从RADIUS服务器的IPv6地址。
port-number:从RADIUS服务器的UDP端口号,取值范围为1~65535,从RADIUS计费服务器的缺省UDP端口号为1813,从RADIUS认证服务器的缺省UDP端口号为1812。
vpn-instance vpn-instance-name:从RADIUS服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN实例名称,为1~31个字符的字符串,区分大小写。
active:正常工作状态。
block:通信中断状态。
如果不指定从服务器IP地址,那么本命令将会修改所有已配置的从认证服务器或从计费服务器的状态。
当RADIUS服务器负载分担功能处于关闭状态时,如果设备查找到的状态为active的从服务器不可达,则设备会将该从服务器的状态置为block,同时启动该服务器的timer quiet定时器,并继续查找下一个状态为active的从服务器。在timer quiet定时器设定的时间到达之后,从服务器状态将由block恢复为active。若该定时器超时之前,通过本命令将从服务器的状态手工设置为block,则定时器超时之后从服务器状态不会自动恢复为active,除非通过本命令手工将其设置为active。如果所有已配置的从服务器都不可达,则本次认证或计费失败。
当从RADIUS服务器状态变化时,引用该服务器的所有RADIUS方案均生效。
# 在RADIUS方案radius1中,设置从认证服务器的状态设置为block。
[Sysname-radius-radius1] state secondary authentication block
· state primary
stop-accounting-buffer enable命令用来开启对无响应的RADIUS停止计费请求报文的缓存功能。
undo stop-accounting-buffer enable命令用来关闭对无响应的RADIUS停止计费请求报文的缓存功能。
设备缓存未得到响应的RADIUS停止计费请求报文。
RADIUS方案视图
设备在发送停止计费请求报文而RADIUS服务器没有响应时,会尝试重传该报文,最大尝试次数由retry命令设置。如果设备发送该RADIUS报文的最大尝试次数超过最大值后,仍然没有得到响应,则该功能处于开启状态的情况下设备会缓存该报文,然后再发起一次请求,若仍然未得到响应,则重复上述过程,一定次数(由retry stop-accounting命令设置)之后,设备将其丢弃。
如果RADIUS方案中的某计费服务器被删除,则设备将会丢弃相应的已缓存停止计费请求报文。
# 开启对无响应的RADIUS停止计费请求报文的缓存功能。
[Sysname-radius-radius1] stop-accounting-buffer enable
stop-accounting-packet send-force命令用来配置用户下线时设备强制发送RADIUS计费停止报文。
undo stop-accounting-packet send-force命令用来恢复缺省情况。
用户下线时设备不会强制发送计费停止报文。
RADIUS方案视图
通常,RADIUS服务器在收到用户的计费开始报文后才会生成用户表项,但有一些RADIUS服务器在用户认证成功后会立即生成用户表项。如果设备使用该类RADIUS服务器进行认证/授权/计费,则在用户认证后,因为一些原因(比如授权失败)并未发送计费开始报文,则在该用户下线时设备也不会发送RADIUS计费停止报文,就会导致RADIUS服务器上该用户表项不能被及时释放,形成服务器和设备上用户信息不一致的问题。为了解决这个问题,建议开启本功能。
开启本功能后,只要用户使用RADIUS服务器进行计费,且设备未向RADIUS服务器发送计费开始报文,则在用户下线时设备会强制发送一个RADIUS计费停止报文给服务器,使得服务器收到此报文后及时释放用户表项。
# 在RADIUS方案radius1中,配置用户下线时设备强制发送RADIUS计费停止报文。
[Sysname-radius-radius1] stop-accounting-packet send-force
test-aaa命令用来发起一次AAA请求测试。
test-aaa user user-name password password radius-scheme radius-scheme-name [ radius-server { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ] ] [ chap | pap ] [ attribute-test-group attr-test-group-name ] [ trace ]
user user-name:待测试的用户名,为1~80个字符的字符串,区分大小写。用户名中可以携带域名,形式为“纯用户名@域名”,其中纯用户名区分大小写,域名不区分大小写。
password password:待测试用户的明文密码,为1~63个字符的字符串,区分大小写。
radius-scheme radius-scheme-name:RADIUS方案名称,为1~32个字符的字符串,不区分大小写。
radius-server:指定具体的RADIUS服务器。
ipv4-address:RADIUS服务器的IPv4地址。
ipv6 ipv6-address:RADIUS服务器的IPv6地址。
port-number:RADIUS服务器的UDP端口号,取值范围为1~65535。
vpn-instance vpn-instance-name:RADIUS服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示待探测RADIUS服务器位于公网中。
chap:采用CHAP认证方式。该方式也是缺省认证方式。
pap:采用PAP认证方式。
attribute-test-group attr-test-group-name:RADIUS属性测试组的名称,为1~31个字符的字符串,不区分大小写。
trace:显示详细的RADIUS报文交互信息。若不指定该参数,则表示仅显示报文收发结果及最终的测试结果。
本命令主要用于排查设备与AAA服务器交互时的故障原因,目前仅支持对RADIUS服务器的测试。当故障发生时,执行本命令发起一次RADIUS请求测试,通过查看打印出的认证/计费请求结果以及报文交互信息,有利于快速定位故障发生的关键环节,以及及时排查影响认证/计费结果的RADIUS属性。
可以在执行本命令时指定RADIUS属性测试组,指定的测试组中定义了RADIUS请求报文中要携带的属性。如果本命令中未指定RADIUS属性测试组或指定的RADIUS属性测试组不存在,则测试过程中发送的RADIUS请求报文中将会携带一些缺省属性,缺省属性的介绍请参见AAA配置手册。
由于测试期间不能保证设备与AAA服务器可以正常通信,因此不建议同时允许用户进行正常的上线、下线操作。
测试过程中,如果引用的RADIUS方案配置发生变化,则仅在下次测试中生效,并不影响本次探测。
仅允许在同一时间内存在一个测试过程,下一次测试只能在当前测试过程完成后执行。
# 发起一次AAA请求测试,使用的测试用户名为user1,密码为123456,RADIUS方案名为test,同时打印详细的RADIUS报文交互信息。
<Sysname> test-aaa user user1 password 123456 radius-scheme test chap trace
Sent a RADIUS authentication request.
Server IP : 192.168.1.110
Source IP : 192.168.1.166
VPN instance : N/A
Server port : 1812
Packet type : Authentication request
Packet length: 118 bytes
Packet ID : 0
Attribute list:
[User-Name(1)] [6] [user1]
[CHAP-Password(3)] [19] [******]
[NAS-IP-Address(4)] [6] [192.168.1.166]
[Service-Type(6)] [6] [2] [Framed]
[Framed-Protocol(7)] [6] [1] [PPP]
[NAS-Identifier(32)] [5] [Sysname]
[Acct-Session-Id(44)] [40] [00000008201707241008280000000c16100171]
[CHAP-Challenge(60)] [18] [******]
[NAS-Port-Type(61)] [6] [15] [Ethernet]
Received a RADIUS authentication response.
VPN instance : N/A
Server port : 1812
Packet type : Access-Reject
Packet length: 20 bytes
Packet ID : 0
Reply-Message: "E63032: Incorrect password. You can retry 9 times."
Sent a RADIUS start-accounting request.
VPN instance : N/A
Server port : 1813
Packet type : Start-accounting request
Packet length: 63 bytes
Packet ID : 1
Attribute list:
[Acct-Status-Type(40)] [6] [1] [Start]
Received a RADIUS start-accounting response.
VPN instance : N/A
Server port : 1813
Packet type : Start-accounting response
Packet ID : 1
Sent a RADIUS stop-accounting request.
VPN instance : N/A
Server port : 1813
Packet type : Stop-accounting request
Packet length: 91 bytes
Packet ID : 1
Attribute list:
[Acct-Status-Type(40)] [6] [2] [Stop]
[Acct-Delay-Time(41)] [6] [0]
[Acct-Terminate-Cause(49)] [6] [1] [User Request]
Received a RADIUS stop-accounting response.
VPN instance : N/A
Server port : 1813
Packet type : Stop-accounting response
Packet ID : 1
Test result: Failed
# 发起一次AAA请求测试,使用的测试用户名为user1,密码为123456 ,RADIUS方案名为test,指定探测test下认证服务器192.168.1.110,且不打印详细的RADIUS报文交互信息。
<Sysname> test-aaa user user1 password 123456 radius-scheme test radius-server 192.168.1.110 1812
Test result: Successful
表1-17 test-aaa命令显示信息描述表
Server IP |
服务器的IP地址 |
Source IP |
RADIUS报文源IP地址 |
VPN instance |
RADIUS认证/计费服务器所在的VPN,服务器位于公网时,显示为N/A |
Server port |
Packet type |
RADIUS报文类型: · Authentication request:认证请求报文 · Access-Accept:认证接受报文 · Access-Reject:认证拒绝报文 · Start-accounting request:开始计费请求报文 · Start-accounting response:开始计费响应报文 · Stop-accounting request:停止计费请求报文 · Stop-accounting response:停止计费响应报文 |
Packet length |
报文总长度,单位为字节 |
Packet ID |
报文ID,用于匹配响应报文和对应的请求报文 |
[attribute-name (code)] [length] [value] [description] |
RADIUS属性信息: · attribute-name:属性名称 · code:属性编号 · length:属性值的长度,单位为字节 · value:属性值 · description:特殊属性值的描述信息 |
Sent a RADIUS authentication request. |
成功发送了一个认证请求报文 |
Failed to receive a RADIUS authentication response. |
认证请求已超时,未收到应答 |
Received a RADIUS authentication response. |
接收到一个认证响应报文 |
Sent a RADIUS start-accounting request. |
成功发送了一个计费开始请求报文 |
Failed to receive a RADIUS start-accounting response. |
计费开始请求已超时,未收到应答 |
Received a RADIUS start-accounting response. |
接收到一个计费开始请求报文 |
Sent a RADIUS stop-accounting request. |
成功发送了一个计费停止请求报文 |
Failed to receive a RADIUS stop-accounting response. |
计费停止请求已超时,未收到应答 |
Received a RADIUS stop-accounting response. |
接收到一个计费停止请求报文 |
Reply-Message: |
RADIUS服务器拒绝此认证请求,并下发提示信息 |
The authentication server is not configured. |
指定的RADIUS方案中未配置要探测的认证服务器 |
The accounting server is not configured. |
指定的RADIUS方案中未配置要探测的计费服务器 |
Test result |
测试结果: · Successful:当前用户的AAA测试成功 · Failed:当前用户的AAA测试失败(只要有一个请求报文测试失败,即为失败) |
· radius attribute-test-group
· radius scheme
threshold remanent-volume命令用来配置用户剩余流量阈值。
undo threshold remanent-volume命令用来恢复缺省情况。
threshold remanent-volume threshold-value
用户剩余流量阈值为0。
RADIUS方案视图
threshold-value:剩余流量阈值,取值范围为0~4294967295,单位由attribute remanent-volume unit命令决定。
用户认证上线后,若RADIUS服务器分多次向用户授权下发流量配额,则每当用户可用流量达到指定的剩余流量阈值时,设备会立即向服务器为该用户申请新的流量配额。例如,RADIUS服务器上设置某用户可用的总流量为50M,且每次向用户下发的流量配额为10M,同时设备上配置的剩余流量阈值为2M,则当该用户剩余流量为2M时,设备会向RADIUS服务器发起实时计费请求来获取新的配额。之后,RADIUS服务器服务器再次向用户授权下发10M的配额,此过程循环进行,直到用户耗尽所有可用流量配额。
# 在RADIUS方案radius1中,配置用户剩余流量阈值为2048兆字节。
[Sysname-radius-radius1] threshold remanent-volume 2048
[Sysname-radius-radius1] attribute remanent-volume unit mega-byte
· attribute remanent-volume unit
timer quiet命令用来设置服务器恢复激活状态的时间。
undo timer quiet命令用来恢复缺省情况。
timer quiet minutes
undo timer quiet
服务器恢复激活状态的时间为5分钟。
RADIUS方案视图
minutes:恢复激活状态的时间,取值范围为1~255,单位为分钟。
建议合理设置服务器恢复激活状态的时间:
· 如果服务器恢复激活状态时间设置的过短,就会出现设备反复尝试与状态active但实际不可达的服务器通信而导致的认证或计费频繁失败的问题。
· 如果服务器恢复激活状态时间设置的过长,当服务器恢复可达后,设备不能及时与其进行通信,会降低对用户进行认证或计费的效率。
# 在RADIUS方案radius1中,配置服务器恢复激活状态的时间为10分钟。
[Sysname-radius-radius1] timer quiet 10
timer realtime-accounting命令用来设置实时计费的时间间隔。
undo timer realtime-accounting命令用来恢复缺省情况。
timer realtime-accounting interval [ second ]
实时计费的时间间隔为12分钟。
RADIUS方案视图
interval:实时计费的时间间隔,取值范围为0~71582。
second:表示实时计费的时间间隔以秒为单位,缺省以分钟为单位。
为了对用户实施实时计费,有必要设置实时计费的时间间隔。不同的取值的处理有所不同:
· 若实时计费间隔不为0,则每隔设定的时间,设备会向RADIUS服务器发送一次在线用户的计费信息。
· 若实时计费间隔设置为0,且服务器上配置了实时计费间隔,则设备按照服务器上配置的实时计费间隔向RADIUS服务器发送在线用户的计费信息;如果服务器上没有配置该值,则设备不向RADIUS服务器发送在线用户的计费信息。
实时计费间隔的取值小,计费准确性高,但对设备和RADIUS服务器的性能要求就高。建议实时计费间隔取值大于发送RADIUS报文的最大尝试次数与RADIUS服务器响应超时时间的乘积。
用户数 |
实时计费间隔(分钟) |
1~99 |
3 |
100~499 |
6 |
500~999 |
12 |
大于等于1000 |
大于等于15 |
不同情况下修改的实时计费间隔,对于已在线用户的生效情况有所不同:
· 将实时计费间隔从非0有效值改为0,或者从0修改为非0有效值后,已在线用户会依然采用原有取值,修改后的取值对其不生效。
· 将实时计费间隔从某非0有效值修改为其它非0有效值后,已在线用户将会采用修改后的取值。
需要注意的是,无论实时计费间隔取值为多少,对于双栈用户,设备缺省会在用户申请到IPv4地址时为其发送一个计费开始报文,并在随后用户申请到IPv6地址/PD时再发送一个计费更新报文,反之亦然。
对于未进行RADIUS认证和授权,仅进行RADIUS计费的用户,只能使用计费方案下设置的实时计费间隔,不会使用RADIUS服务器设置的实时计费间隔。
# 在RADIUS方案radius1中,设置实时计费的时间间隔为51分钟。
[Sysname-radius-radius1] timer realtime-accounting 51
· retry
· retry realtime-accounting
timer response-timeout命令用来设置RADIUS服务器响应超时时间。
undo timer response-timeout命令用来恢复缺省情况。
timer response-timeout seconds
RADIUS服务器响应超时时间为3秒。
RADIUS方案视图
seconds:RADIUS服务器响应超时时间,取值范围为1~10,单位为秒。
如果在RADIUS请求报文传送出去一段时间后,设备还没有得到RADIUS服务器的响应,则有必要重传RADIUS请求报文,以保证用户尽可能地获得RADIUS服务,这段时间被称为RADIUS服务器响应超时时间,本命令用于调整这个时间。
# 在RADIUS方案radius1中,设置服务器响应超时时间设置为5秒。
[Sysname-radius-radius1] timer response-timeout 5
· retry
trust ip命令用来配置免校验RADIUS DAE客户端的IP地址。
undo trust ip命令用来删除指定的免校验RADIUS DAE客户端的IP地址。
trust ip ipv4-address [ vpn-instance vpn-instance-name ]
undo trust ip ipv4-address [ vpn-instance vpn-instance-name ]
未配置免校验RADIUS DAE客户端的IP地址。
RADIUS DAE服务器视图
ipv4-address:免校验的RADIUS DAE客户端IPv4地址,不能为全0地址、全1地址、D类地址、E类地址和环回地址。
vpn-instance vpn-instance-name:RADIUS DAE客户端所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示RADIUS DAE客户端位于公网中。
在DAE代理组网环境中,作为DAE代理的设备收到DAE请求报文后,必须校验报文的合法性,校验合法的报文才会被转发给RADIUS DAE服务器。如果RADIUS DAE服务器信任DAE代理转发的DAE请求报文,则可以通过配置免校验DAE客户端的IP地址来决定不对哪些报文进行重复校验。当RADIUS DAE服务器收到DAE请求报文后,如果报文的源地址在配置的免校验DAE客户端的IP地址列表中,则不校验该报文,否则正常校验。
通过多次执行本命令可配置多个免校验的RADIUS DAE客户端的IP地址。
# 配置免校验DAE客户端的IP地址10.110.1.2。
[Sysname] radius dynamic-author server
[Sysname-radius-da-server] trust ip 10.110.1.2
· trust ipv6
trust ipv6命令用来配置免校验RADIUS DAE客户端的IPv6地址。
undo trust ipv6命令用来删除指定的免校验RADIUS DAE客户端的IPv6地址。
trust ipv6 ipv6-address [ vpn-instance vpn-instance-name ]
undo trust ipv6 ipv6-address [ vpn-instance vpn-instance-name ]
未配置免校验RADIUS DAE客户端的IPv6地址。
RADIUS DAE服务器视图
ipv6-address:免校验的RADIUS DAE客户端IPv6地址,必须是单播地址,不能为环回地址与本地链路地址。
通过多次执行本命令可配置多个免校验的RADIUS DAE客户端的IPv6地址。
# 配置免校验DAE客户端的IPv6地址10:110::1:2。
[Sysname-radius-da-server] trust ipv6 10:110::1:2
· trust ip
username-authorization apply命令用来配置接受RADIUS服务器下发的用户名。
undo username-authorization apply命令用来恢复缺省情况。
不接受RADIUS服务器下发的用户名,而是采用用户认证时使用的用户名进行AAA处理。
RADIUS方案视图
在某些运营商组网环境中,RADIUS服务器希望接入设备在用户认证成功后采用指定的用户名进行后续的AAA处理,该用户名与用户认证时采用的用户名不同。因此,需要设备端可以接受这种用户名,并且使用此用户名进行计费、用户信息的查询和显示等AAA处理。
配置了本功能后,如果RADIUS服务器发送给设备的认证应答报文中携带了User-Name属性,则设备会将此属性的内容告知给接入模块,且在后续的AAA处理过程中使用服务器下发的用户名进行处理。例如,这种情况下,设备发送给RADIUS服务器的计费开始请求报文中将会携带服务器下发的用户名,具体封装在User-Name属性中的内容需要结合RADIUS方案中的用户名格式(通过user-name-format配置)进行处理:
· 如果用户名格式为keep-original,则User-Name属性内容为服务器下发的用户名。
· 如果用户名格式为without-domain,则将服务器下发的用户名去掉域名后封装在User-Name属性中。
· 如果用户名格式为with-domain,则首先将服务器下发的用户名中的域名替换为认证时采用的域名,然后将此用户名封装在User-Name属性中。
目前,本功能仅对IPoE用户生效。
配置本功能后,通过display ip subscriber命令查询IPoE在线用户信息时,显示信息中的用户名将是RADIUS服务器下发的用户名。
# 在RADIUS方案radius1中,配置接受RADIUS服务器下发的用户名。
[Sysname-radius-radius1] username-authorization apply
· display ip subscriber(BRAS业务分册/IPoE)
user-name-format命令用来设置发送给RADIUS服务器的用户名格式。
undo user-name-format命令用来恢复缺省情况。
user-name-format { keep-original | with-domain | without-domain }
发送给RADIUS服务器的用户名携带ISP域名。
RADIUS方案视图
keep-original:发送给RADIUS服务器的用户名与用户的输入保持一致。
with-domain:发送给RADIUS服务器的用户名携带ISP域名。
without-domain:发送给RADIUS服务器的用户名不携带ISP域名。
接入用户通常以“userid@isp-name”的格式命名,“@”后面的部分为ISP域名,设备就是通过该域名来决定将用户归于哪个ISP域的。但是,有些较早期的RADIUS服务器不能接受携带有ISP域名的用户名,在这种情况下,有必要将用户名中携带的域名去除后再传送给RADIUS服务器。因此,设备提供此命令以指定发送给RADIUS服务器的用户名是否携带有ISP域名。
如果指定某个RADIUS方案不允许用户名中携带有ISP域名,那么请不要在两个或两个以上的ISP域中同时设置使用该RADIUS方案。否则,会出现虽然实际用户不同(在不同的ISP域中),但RADIUS服务器认为用户相同(因为传送到它的用户名相同)的错误。
# 在RADIUS方案radius1中,设置发送给RADIUS服务器的用户名不得携带域名。
[Sysname-radius-radius1] user-name-format without-domain
vpn-instance命令用来配置RADIUS方案所属的VPN。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
RADIUS方案属于公网。
RADIUS方案视图
vpn-instance-name:MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
本命令配置的VPN对于该方案下的所有RADIUS认证/计费服务器生效,但设备优先使用配置RADIUS认证/计费服务器时为各服务器单独指定的VPN。
# 配置RADIUS方案radius1所属的VPN为test。
[Sysname-radius-radius1] vpn-instance test
data-flow-format命令用来配置发送到HWTACACS服务器的数据流或者数据包的单位。
undo data-flow-format命令用来恢复缺省情况。
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
数据流的单位为byte,数据包的单位为one-packet。
HWTACACS方案视图
data:设置数据流的单位。
· byte:数据流的单位为字节。
· giga-byte:数据流的单位千兆字节。
· kilo-byte:数据流的单位为千字节。
· mega-byte:数据流的单位为兆字节。
packet:设置数据包的单位。
· giga-packet:数据包的单位为千兆包。
· kilo-packet:数据包的单位为千包。
· mega-packet:数据包的单位为兆包。
· one-packet:数据包的单位为包。
设备上配置的发送给HWTACACS服务器的数据流单位及数据包单位应与HWTACACS服务器上的流量统计单位保持一致,否则无法正确计费。
# 在HWTACACS方案hwt1中,设置发往HWTACACS服务器的数据流的数据单位为千字节、数据包的单位为千包。
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1] data-flow-format data kilo-byte packet kilo-packet
· display hwtacacs scheme
display hwtacacs scheme命令用来查看HWTACACS方案的配置信息或HWTACACS服务相关的统计信息。
display hwtacacs scheme [ hwtacacs-scheme-name [ statistics ] ]
hwtacacs-scheme-name:HWTACACS方案的名称,为1~32个字符的字符串,不区分大小写。如果不指定该参数,则显示所有HWTACACS方案的配置信息。
statistics:显示HWTACACS服务相关的统计信息。不指定该参数,则显示HWTACACS方案的配置信息。
显示指定HWTACACS方案配置信息时,会同时显示每一个HWTACACS服务器当前Active状态的持续时间以及最近5次状态变化信息;显示所有HWTACACS方案配置信息时,会同时显示每一个HWTACACS服务器当前Active状态的持续时间以及最近1次Block状态的开始时间和结束时间。
# 查看所有HWTACACS方案的配置情况。
<Sysname> display hwtacacs scheme
Total 1 HWTACACS schemes
HWTACACS scheme name: hwtac
Index : 0
Primary authentication server:
IP : 2.2.2.2 Port: 49
VPN Instance: 2
State: Active (duration: 1 weeks 2 days 1 hours 32 minutes 34 seconds)
Most recent blocked period: 2021/08/15 20:33:45 - 2021/08/15 20:38:45
Single-connection: Enabled
Primary authorization server:
VPN Instance: 2
Single-connection: Disabled
Primary accounting server:
IP : Not Configured Port: 49
VPN Instance: Not configured
State: Blocked
VPN Instance : 2
NAS IP Address : 2.2.2.3
Server Quiet Period(minutes) : 5
Realtime Accounting Interval(minutes) : 12
Stop-accounting packets buffering : Enabled
Retransmission times : 100
Response Timeout Interval(seconds) : 5
Username Format : with-domain
Data flow unit : Byte
Packet unit : One
#显示HWTACACS方案hwtac的配置情况。
<Sysname> display hwtacacs scheme hwtac
Index : 0
VPN Instance: 2
Most recent state changes:
2021/08/15 21:01:23 Changed to active state
2021/08/15 20:56:22 Changed to blocked stat
VPN Instance: 2
2021/08/15 20:56:22 Changed to blocked state
State: Blocked
VPN Instance : 2
Packet unit : One
表1-19 display hwtacacs scheme命令显示信息描述表
Total 1 HWTACACS schemes |
共计1个HWTACACS方案 |
HWTACACS scheme name |
HWTACACS方案的名称 |
Index |
HWTACACS方案的索引号 |
Primary authentication server |
主HWTACACS认证服务器 |
Primary authorization server |
主HWTACACS授权服务器 |
Primary accounting server |
主HWTACACS计费服务器 |
Secondary authentication server |
从HWTACACS认证服务器 |
Secondary authorization server |
从HWTACACS授权服务器 |
Secondary accounting server |
从HWTACACS计费服务器 |
IP |
HWTACACS服务器的IP地址 未配置时,显示为Not configured |
Port |
HWTACACS服务器的端口号 未配置时,显示缺省值 |
State |
HWTACACS服务器目前状态 · Active:激活状态 · Blocked:静默状态 若状态为Active,则同时显示该状态的持续时间 |
duration |
HWTACACS服务器当前Active状态的持续时间 |
Most recent blocked period |
HWTACACS服务器最后一次转换为Block状态的开始时间及结束时间。若最终状态为Block状态,则结束时间用“now”表示 |
Most recent state changes |
HWTACACS服务器最近5次的状态变化信息 |
VPN Instance |
HWTACACS服务器所在的VPN 未配置时,显示为Not configured |
Single-connection |
单连接状态 · Enabled:使用一条TCP连接与服务器通信 · Disabled:每次新建TCP连接与服务器通信 |
VPN Instance |
HWTACACS方案所属的VPN名称 未配置时,显示为Not configured |
NAS IP Address |
发送HWTACACS报文的源IP地址 |
Server Quiet Period(minutes) |
主HWTACACS服务器恢复激活状态的时间(分钟) |
Realtime Accounting Interval(minutes) |
实时HWTACACS计费更新报文的发送间隔(分钟) |
Stop-accounting packets buffering |
HWTACACS停止计费请求报文缓存功能的开启情况 |
Retransmission times |
发起HWTACACS停止计费请求的最大尝试次数 |
Response Timeout Interval(seconds) |
HWTACACS服务器超时时间(秒) |
Username Format |
用户名格式 · with-domain:携带域名 · without-domain:不携带域名 · keep-original:与用户输入保持一致 |
Data flow unit |
数据流的单位 · Byte:字节 · Kilobyte:千字节 · Megabyte:兆字节 · Gigabyte:十亿字节 |
Packet unit |
数据包的单位 · One:个 · Kilo:千 · Mega:兆 · Giga:十亿 |
<Sysname> display hwtacacs scheme tac statistics
HWTACACS scheme name: tac
Primary authentication server: 3.3.3.3
Round trip time: 0 seconds
Request packets: 1
Login request packets: 1
Change-password request packets: 0
Request packets including plaintext password: 0
Request packets including ciphertext password: 0
Response packets: 2
Pass response packets: 1
Failure response packets: 0
Get-data response packets: 0
Get-username response packets: 0
Get-password response packets: 1
Restart response packets: 0
Error response packets: 0
Follow response packets: 0
Malformed response packets: 0
Continue packets: 1
Continue-abort packets: 0
Pending request packets: 0
Timeout packets: 0
Unknown type response packets: 0
Dropped response packets: 0
Primary authorization server: 3.3.3.3
Round trip time: 1 seconds
Request packets: 1
Response packets: 1
PassAdd response packets: 1
PassReply response packets: 0
Timeout packets: 0
Primary accounting server: 3.3.3.3
Request packets: 2
Accounting start request packets: 1
Accounting stop request packets: 1
Accounting update request packets: 0
Response packets: 2
Success response packets: 2
Timeout response packets: 0
表1-20 display hwtacacs scheme statistics命令显示信息描述表
HWTACACS方案名称 |
主HWTACACS认证服务器 |
主HWTACACS授权服务器 |
主HWTACACS计费服务器 |
从HWTACACS认证服务器 |
从HWTACACS授权服务器 |
从HWTACACS计费服务器 |
Round trip time |
设备处理最近一组响应报文和请求报文的时间间隔(单位为秒) |
Request packets |
发送的请求报文个数 |
Response packets |
接收到的响应报文个数 |
Failure response packets |
认证或授权失败的响应报文个数 |
Error response packets |
错误类型的响应报文个数 |
Follow response packets |
Follow类型的响应报文的个数 |
Malformed response packets |
不合法的响应报文个数 |
Pending request packets |
等待响应的请求报文个数 |
Timeout packets |
超时的请求报文个数 |
Unknown type response packets |
未知报文类型的响应报文个数 |
Dropped response packets |
被丢弃响应报文个数 |
Login request packets |
登录认证的请求报文个数 |
Change-password request packets |
更改密码的请求报文个数 |
Request packets including plaintext passwords |
发送明文密码的请求报文个数 |
Request packets including ciphertext passwords |
发送密文密码的请求报文个数 |
Pass response packets |
表示认证通过的响应报文个数 |
Get-data response packets |
表示获取数据的响应报文个数 |
Get-username response packets |
表示获取用户名的响应报文个数 |
Get-password response packets |
表示获取密码的响应报文个数 |
Restart response packets |
要求重认证的响应报文个数 |
Continue packets |
发送的Continue报文个数 |
Continue-abort packets |
发送的Continue-abort报文个数 |
PassAdd response packets |
接收到的PassAdd类型的响应报文个数。此报文表示同意授权所有请求的属性,并添加其他授权属性 |
PassReply response packets |
接收到的PassReply类型的响应报文个数。此报文表示采用响应报文中指定的授权属性替换请求的授权属性 |
Accounting start request packets |
发送的计费开始请求报文个数 |
Accounting stop request packets |
发送的计费结束请求报文个数 |
Accounting update request packets |
发送的计费更新报文个数 |
Accounting start-and-update request packets |
发送的赋值的计费开始报文的个数 |
Success response packets |
接收到的计费成功的响应报文个数 |
· reset hwtacacs statistics
display stop-accounting-buffer命令用来显示缓存的HWTACACS停止计费请求报文的相关信息。
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
hwtacacs-scheme hwtacacs-scheme-name:表示HWTACACS方案名,为1~32个字符的字符串,不区分大小写。
# 显示HWTACACS方案hwt1缓存的HWTACACS停止计费请求报文。
<Sysname> display stop-accounting-buffer hwtacacs-scheme hwt1
Total entries: 2
Scheme IP address Username First sending time Attempts
hwt1 192.168.100.1 abc 23:27:16-05/31/2019 19
hwt1 192.168.90.6 bob 23:33:01-05/31/2019 20
表1-21 display stop-accounting-buffer命令显示信息描述表
Total entries: 2 |
共有两条记录匹配 |
Scheme |
HWTACACS方案名 |
IP address |
用户IP地址 |
Username |
用户名 |
First sending time |
首次发送停止计费请求的时间 |
Attempts |
发送停止计费请求报文的次数 |
· retry stop-accounting (HWTACACS scheme view)
· reset stop-accounting-buffer (for HWTACACS)
· stop-accounting-buffer enable (HWTACACS scheme view)
· user-name-format (HWTACACS scheme view)
hwtacacs nas-ip命令用来设置设备发送HWTACACS报文使用的源地址。
undo hwtacacs nas-ip命令用来删除指定的发送HWTACACS报文使用的源地址。
hwtacacs nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo hwtacacs nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未设置发送HWTACACS报文使用的源地址,设备将以发送报文的接口的主IP地址作为源地址。
ipv4-address:指定的源IPv4地址,应该为本机的地址,不能为全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6 ipv6-address:指定的源IPv6地址,应该为本机的地址,必须是单播地址,不能为环回地址与本地链路地址。
HWTACACS服务器上通过IP地址来标识接入设备,并根据收到的HWTACACS报文的源IP地址是否与服务器所管理的接入设备的IP地址匹配,来决定是否处理来自该接入设备的认证或计费请求。因此,为保证HWTACACS报文可被服务器正常接收并处理,接入设备上发送HWTACACS报文使用的源地址必须与HWTACACS服务器上指定的接入设备的IP地址保持一致。
为避免物理接口故障时从服务器返回的报文不可达,推荐使用Loopback接口地址为发送HWTACACS报文使用的源IP地址。
HWTACACS方案视图和系统视图下均可以配置发送HWTACACS报文使用的源IP地址,具体生效情况如下:
· HWTACACS方案视图下配置的源IP地址(通过nas-ip命令)只对本方案有效。
· 系统视图下的配置的源IP地址(通过hwtacacs nas-ip命令)对所有HWTACACS方案有效。
· HWTACACS方案视图下的设置具有更高的优先级。
# 设置设备发送HWTACACS报文使用的源地址为129.10.10.1。
[Sysname] hwtacacs nas-ip 129.10.10.1
· nas-ip (HWTACACS scheme view)
hwtacacs scheme命令用来创建HWTACACS方案,并进入HWTACACS方案视图。如果指定的HWTACACS方案已经存在,则直接进入HWTACACS方案视图。
undo hwtacacs scheme命令用来删除指定的HWTACACS方案。
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
不存在HWTACACS方案。
hwtacacs-scheme-name:HWTACACS方案名称,为1~32个字符的字符串,不区分大小写。
一个HWTACACS方案可以同时被多个ISP域引用。
最多可以配置16个HWTACACS方案。
# 创建名称为hwt1的HWTACACS方案并进入相应的HWTACACS视图。
hwtacacs-user change-password命令用来修改HWTACACS服务器上存储的用户密码。
hwtacacs-user change-password hwtacacs-scheme hwtacacs-scheme-name { all-servers | first-server | server-ip { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * }
hwtacacs-scheme hwtacacs-scheme-name:指定HWTACACS认证服务器所属的HWTACACS方案。hwtacacs-scheme-name表示HWTACACS方案名称,为1~32个字符的字符串,不区分大小写。指定的HWTACACS方案必须已存在。
all-servers:表示要遍历修改指定HWTACACS方案下所有认证服务器上的用户密码。
first-server:表示仅修改指定HWTACACS方案下配置的首个可达的认证服务器上的用户密码。
server-ip:表示要修改指定IP地址的HWTACACS认证服务器上的用户密码。
ipv4-address:HWTACACS认证服务器的IPv4地址。
ipv6 ipv6-address:HWTACACS认证服务器的IPv6地址。
port-number:HWTACACS认证服务器的TCP端口号,取值范围为1~65535,缺省值为49。
vpn-instance vpn-instance-name:HWTACACS认证服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示指定的HWTACACS认证服务器位于公网中。
管理用户可以通过在设备上执行本命令主动修改远程HWTACACS认证服务器上存储的用户密码。
执行本命令后,设备会根据设置的服务器参数,向指定的HWTACACS方案下对应的HWTACACS认证服务器发起连接请求。若此服务器可达,设备会提示用户输入待修改的用户信息(用户名、旧密码、新密码、确认密码,具体信息形式各服务器实现不同),然后使用该用户信息向服务器发起密码修改请求,完成对应的用户密码修改操作。设置的服务器参数不同,密码修改流程有所不同:
· 如果设置了server-ip参数,设备将使用用户输入的信息与指定的一个认证服务器交互,完成其上指定用户密码的修改。
· 如果设置了first-server参数,设备将使用用户输入的信息与方案下首个可达的认证服务器交互修改用户密码,然后结束整个过程。若方案下的首个认证服务器不可达,设备会遍历查找该方案下的其他认证服务器来执行修改动作,直到遍历完毕或遇到一个可达的认证服务器为止。
· 如果设置了all-servers参数,设备将使用用户输入的信息与该方案下的认证服务器交互修改用户密码,如果当前服务器上的密码修改成功,则立即提示用户是否继续修改下一个服务器上的用户密码,每次提示等待3秒:
¡ 如果3秒内用户选择继续修改,或未输入任何信息,则直接使用相同的用户信息轮询下一个服务器。
¡ 如果3秒内用户选择不继续修改,则整个过程结束。
如果某个服务器不可达或密码修改失败,则同上提示,并根据用户选择决定是否跳过此服务器继续后续的过程。
执行本命令的用户必须是经过HWTACACS认证登录设备的用户。仅network-admin、level-15角色的用户可以通过本命令修改其他HWTACACS用户的密码,其它角色的用户仅具有修改自身密码的权限。
执行本命令时,指定的HWTACACS认证服务器参数必须与指定的HWTACACS方案下设置的参数一致,否则命令无法成功执行。
执行本命令后,如果要修改的用户密码已过期,HWTACACS认证服务器将返回用户密码过期错误信息,且不允许更改该用户密码。
修改用户密码的过程中,如果设备等待超过30秒后,用户仍未按照系统提示输入用户名、旧密码、新密码或确认密码,当前的密码修改过程将自动终止。
可以通过输入Ctrl+C终止当前的密码修改流程。
# 修改HWTACACS方案hw1下指定HWTACACS认证服务器上的用户密码:服务器IP地址为10.1.1.2、服务器TCP端口号为49、待修改用户名为tacacs1。
<Sysname> hwtacacs-user change-password hwtacacs-scheme hw1 server-ip 10.1.1.2 49
Connected to the HWTACACS server at 10.1.1.2.
Interacting with the server... Please wait.
Username: tacacs1
Old password:
New password:
Confirm new password:
Changed the password successfully.
<Sysname>
# 修改HWTACACS方案下所有HWTACACS认证服务器上的用户密码:待修改用户名为tacacs2。
<Sysname> hwtacacs-user change-password hwtacacs-scheme hw1 all-servers
Username: tacacs2
Old password:
New password:
Continue to change the user's password on the next HWTACACS server? [Y/N] Y
Connected to the HWTACACS server at 10.1.1.6.
Connected to the HWTACACS server at 10.1.1.10.
Changed the password successfully on all HWTACACS servers.
<Sysname>
key命令用来配置HWTACACS认证、授权、计费报文的共享密钥。
undo key命令用来删除指定的HWTACACS报文的共享密钥。
key { accounting | authentication | authorization } { cipher | simple } string
undo key { accounting | authentication | authorization }
未配置HWTACACS报文的共享密钥。
HWTACACS方案视图
accounting:指定HWTACACS计费报文的共享密钥。
authentication:指定HWTACACS认证报文的共享密钥。
authorization:指定HWTACACS授权报文的共享密钥。
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~255个字符的字符串;密文密钥为1~373个字符的字符串。
必须保证设备上设置的共享密钥与HWTACACS服务器上的完全一致。
# 在HWTACACS方案hwt1中,配置HWTACACS认证报文共享密钥为明文123456TESTauth&!。
[Sysname-hwtacacs-hwt1] key authentication simple 123456TESTauth&!
# 配置HWTACACS授权报文共享密钥为明文123456TESTautr&!。
[Sysname-hwtacacs-hwt1] key authorization simple 123456TESTautr&!
# 配置HWTACACS计费报文共享密钥为明文123456TESTacct&!。
[Sysname-hwtacacs-hwt1] key accounting simple 123456TESTacct&!
nas-ip命令用来设置设备发送HWTACACS报文使用的源IP地址。
undo nas-ip命令用来删除指定类型的发送HWTACACS报文使用的源IP地址。
undo nas-ip [ ipv6 ]
使用系统视图下由命令hwtacacs nas-ip指定的源地址,若系统视图下未指定源地址,则使用发送HWTACACS报文的接口的主IP地址。
HWTACACS方案视图
HWTACACS服务器上通过IP地址来标识接入设备,并根据收到的HWTACACS报文的源IP地址是否与服务器所管理的接入设备的IP地址匹配,来决定是否处理来自该接入设备的认证、授权、计费请求。因此,为保证HWTACACS报文可被服务器正常接收并处理,接入设备上发送HWTACACS报文使用的源地址必须与HWTACACS服务器上指定的接入设备的IP地址保持一致。
一个HWTACACS方案视图下,最多允许指定一个IPv4源地址和一个IPv6源地址。
如果undo nas-ip命令中不指定ipv6关键字,则表示删除发送HWTACACS报文使用的源IPv4地址。
# 在HWTACACS方案hwt1中,设置设备发送HWTACACS报文使用的源IP地址为10.1.1.1。
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
· hwtacacs nas-ip
primary accounting命令用来配置主HWTACACS计费服务器。
undo primary accounting命令用来恢复缺省情况。
primary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
未配置HWTACACS主计费服务器。
HWTACACS方案视图
ipv4-address:主HWTACACS计费服务器的IPv4地址。
ipv6 ipv6-address:主HWTACACS计费服务器的IPv6地址。
port-number:主HWTACACS计费服务器的TCP端口号,取值范围为1~65535,缺省值为49。
key:与主HWTACACS计费服务器交互的计费报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与主HWTACACS计费服务器交互的计费报文使用同一个TCP连接。如果未指定本参数,则表示每次计费都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:主HWTACACS计费服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主HWTACACS计费服务器位于公网中。
配置的主计费服务器的TCP端口号以及计费报文的共享密钥必须与服务器的配置保持一致。
在同一个方案中指定的主计费服务器和从计费服务器的VPN、IP地址、端口号不能完全相同。
若服务器位于MPLS VPN私网中,为保证HWTACACS报文被发送到指定的私网服务器,必须指定服务器所属的VPN实例。本命令指定的服务器所属的VPN比HWTACACS方案所属的VPN优先级高。
只有在设备与计费服务器没有报文交互时,才允许删除该服务器。计费服务器删除后,只对之后的计费过程有影响。
配置single-connection参数后可节省TCP连接资源,但有些HWTACACS服务器不支持这种方式,需要根据服务器支持情况进行配置。在服务器支持这种方式的情况下,建议配置single-connection参数,以提高性能和效率。
# 在HWTACACS方案hwt1中,配置主HWTACACS计费服务器的IP地址为10.163.155.12,使用TCP端口49与HWTACACS计费服务器通信,计费报文的共享密钥为明文123456TESTacct&!。
[Sysname] hwtacacs scheme hw1
[Sysname-hwtacacs-hw1] primary accounting 10.163.155.12 49 key simple 123456TESTacct&!
· key (HWTACACS scheme view)
· secondary accounting
· vpn-instance (HWTACACS scheme view)
primary authentication命令用来配置主HWTACACS认证服务器。
undo primary authentication命令用来恢复缺省情况。
primary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
未配置主HWTACACS认证服务器。
HWTACACS方案视图
ipv4-address:主HWTACACS认证服务器的IPv4地址。
ipv6 ipv6-address:主HWTACACS认证服务器的IPv6地址。
port-number:主HWTACACS认证服务器的TCP端口号,取值范围为1~65535,缺省值为49。
key:与主HWTACACS认证服务器交互的认证报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与主HWTACACS认证服务器交互的认证报文使用同一个TCP连接。如果未指定本参数,则表示每次认证都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:主HWTACACS认证服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主HWTACACS认证服务器位于公网中。
配置的主认证服务器的TCP端口号以及认证报文的共享密钥必须与服务器的配置保持一致。
只有在设备与认证服务器没有报文交互时,才允许删除该服务器。认证服务器删除后,只对之后的认证过程有影响。
# 在HWTACACS方案hwt1中,配置主HWTACACS认证服务器的IP地址为10.163.155.13,使用TCP端口49与HWTACACS认证服务器通信,认证报文的共享密钥为明文123456TESTauth&!。
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49 key simple 123456TESTauth&!
primary authorization命令用来配置主HWTACACS授权服务器。
undo primary authorization命令用来恢复缺省情况。
primary authorization { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
未配置主HWTACACS授权服务器。
HWTACACS方案视图
ipv4-address:主HWTACACS授权服务器的IPv4地址。
ipv6 ipv6-address:主HWTACACS授权服务器的IPv6地址。
port-number:主HWTACACS授权服务器的TCP端口号,取值范围为1~65535,缺省值为49。
key:与主HWTACACS授权服务器交互的授权报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与主HWTACACS授权服务器交互的授权报文使用同一个TCP连接。如果未指定本参数,则表示每次授权都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:主HWTACACS授权服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主HWTACACS授权服务器位于公网中。
配置的主授权服务器的TCP端口号以及授权报文的共享密钥必须与服务器的配置保持一致。
在同一个方案中指定的主授权服务器和从授权服务器的VPN、IP地址、端口号不能完全相同。
只有在设备与授权服务器没有报文交互时,才允许删除该服务器。授权服务器删除后,只对之后的授权过程有影响。
# 在HWTACACS方案hwt1中,配置主HWTACACS授权服务器的IP地址为10.163.155.13,使用TCP端口49与HWTACACS授权服务器通信,授权报文的共享密钥为明文123456TESTautr&!。
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49 key simple 123456TESTautr&!
· secondary authorization
reset hwtacacs statistics命令用来清除HWTACACS协议的统计信息。
reset hwtacacs statistics { accounting | all | authentication | authorization }
accounting:清除HWTACACS协议关于计费的统计信息。
all:清除HWTACACS的所有统计信息。
authentication:清除HWTACACS协议关于认证的统计信息。
authorization:清除HWTACACS协议关于授权的统计信息。
# 清除HWTACACS协议的所有统计信息。
<Sysname> reset hwtacacs statistics all
reset stop-accounting-buffer命令用来清除缓存的HWTACACS停止计费请求报文。
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
hwtacacs-scheme hwtacacs-scheme-name:表示指定HWTACACS方案的停止计费请求报文。其中,hwtacacs-scheme-name为HWTACACS方案名,为1~32个字符的字符串,不区分大小写。
# 清除缓存的HWTACACS方案hwt1的HWTACACS停止计费请求报文。
<Sysname> reset stop-accounting-buffer hwtacacs-scheme hwt1
· display stop-accounting-buffer (for HWTACACS)
retry stop-accounting命令用来设置发起HWTACACS停止计费请求的最大尝试次数。
发起HWTACACS停止计费请求的最大尝试次数为100。
HWTACACS方案视图
retries:允许停止计费请求无响应的最大次数,取值范围为1~300。
设备发送HWTACACS停止计费请求报文无响应后,将会缓存该报文并尝试重复发送该报文,当发送的停止计费请求总数达到指定的最大尝试次数之后仍未得到响应时,将其丢弃。
# 在HWTACACS方案hwt1中,设置发起HWTACACS停止计费请求的最大尝试次数为300。
[Sysname-hwtacacs-hwt1] retry stop-accounting 300
· timer response-timeout (HWTACACS scheme view)
secondary accounting命令用来配置从HWTACACS计费服务器。
undo secondary accounting命令用来删除指定的从HWTACACS计费服务器。
secondary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
未配置从HWTACACS计费服务器。
HWTACACS方案视图
ipv4-address:从HWTACACS计费服务器的IPv4地址。
ipv6 ipv6-address:从HWTACACS计费服务器的IPv6地址。
port-number:从HWTACACS计费服务器的端口号,取值范围为1~65535,缺省值为49。
key:与从HWTACACS计费服务器交互的计费报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与从HWTACACS计费服务器交互的计费报文使用同一个TCP连接。如果未指定本参数,则表示每次计费都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:从HWTACACS计费服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从HWTACACS计费服务器位于公网中。
配置的从计费服务器的TCP端口号以及计费报文的共享密钥必须与服务器的配置保持一致。
每个HWTACACS方案中最多支持配置16个从HWTACACS计费服务器。当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。
如果不指定任何参数,则undo命令将删除所有从计费服务器。
配置single-connection参数后可节省TCP连接资源,但有些TACACS服务器不支持这种方式,需要根据服务器支持情况进行配置。在服务器支持这种方式的情况下,建议配置single-connection参数,以提高性能和效率。
# 在HWTACACS方案hwt1中,配置从HWTACACS计费服务器的IP地址为10.163.155.12,使用TCP端口49与HWTACACS计费服务器通信,计费报文的共享密钥为明文123456TESTacct&!。
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49 key simple 123456TESTacct&!
· primary accounting (HWTACACS scheme view)
secondary authentication命令用来配置从HWTACACS认证服务器。
undo secondary authentication命令用来删除指定的从HWTACACS认证服务器。
secondary authentication { ipv4-address | ipv6 ipv6-address } [ port-number I key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
未配置从HWTACACS认证服务器。
HWTACACS方案视图
ipv4-address:从HWTACACS认证服务器的IPv4地址。
ipv6 ipv6-address:从HWTACACS认证服务器的IPv6地址。
port-number:从HWTACACS认证服务器的TCP端口号,取值范围为1~65535,缺省值为49。
key:与从HWTACACS认证服务器交互的认证报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与从HWTACACS认证服务器交互的认证报文使用同一个TCP连接。如果未指定本参数,则表示每次认证都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:从HWTACACS认证服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从HWTACACS服务器位于公网中。
配置的从认证服务器的TCP端口号以及认证报文的共享密钥必须与服务器的配置保持一致。
每个HWTACACS方案中最多支持配置16个从HWTACACS认证服务器。当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。
如果不指定任何参数,则undo命令将删除所有从认证服务器。
# 在HWTACACS方案hwt1中,配置从HWTACACS认证服务器的IP地址为10.163.155.13,使用TCP端口49与HWTACACS认证服务器通信,认证报文的共享密钥为明文123456TESTauth&!。
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49 key simple 123456TESTauth&!
· primary authentication (HWTACACS scheme view)
secondary authorization命令用来配置从HWTACACS授权服务器。
undo secondary authorization命令用来删除指定的从HWTACACS授权服务器。
secondary authorization { ipv4-address | ipv6 ipv6-address } [ port-number I key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary authorization [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
未配置从HWTACACS授权服务器。
HWTACACS方案视图
ipv4-address:从HWTACACS授权服务器的IPv4地址。
ipv6 ipv6-address:从HWTACACS授权服务器的IPv6地址。
port-number:从HWTACACS授权服务器的TCP端口号,取值范围为1~65535,缺省值为49。
key:与从HWTACACS授权服务器交互的授权报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与从HWTACACS授权服务器交互的授权报文使用同一个TCP连接。如果未指定本参数,则表示每次授权都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:从HWTACACS授权服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从HWTACACS授权服务器位于公网中。
配置的从授权服务器的TCP端口号以及授权报文的共享密钥必须与服务器的配置保持一致。
每个HWTACACS方案中最多支持配置16个从HWTACACS授权服务器。当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。
如果不指定任何参数,则undo命令将删除所有从授权服务器。
在同一个方案中指定的主授权服务器和从授权服务器的VPN、IP地址、端口号不能完全相同,并且各从授权服务器的VPN、IP地址、端口号也不能完全相同。
# 在HWTACACS方案hwt1中,配置从HWTACACS授权服务器的IP地址为10.163.155.13,使用TCP端口49与HWTACACS授权服务器通信,授权报文的共享密钥为明文123456TESTautr&!。
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49 key simple 123456TESTautr&!
· primary authorization (HWTACACS scheme view)
stop-accounting-buffer enable命令用来开启对无响应的HWTACACS停止计费请求报文的缓存功能。
undo stop-accounting-buffer enable命令用来关闭对无响应的HWTACACS停止计费请求报文的缓存功能。
设备缓存未得到响应的HWTACACS停止计费请求报文。
HWTACACS方案视图
开启对无响应的HWTACACS停止计费请求报文的缓存功能后,设备在发送停止计费请求报文而HWTACACS服务器没有响应时,会将其缓存在本机上,然后发送直到HWTACACS计费服务器产生响应,或者在发送的次数达到指定的次数限制(由retry stop-accounting命令设置)后将其丢弃。
如果HWTACACS方案中的某计费服务器被删除,则设备将会丢弃相应的已缓存停止计费报文。
# 开启对无响应的HWTACACS停止计费请求报文的缓存功能。
[Sysname-hwtacacs-hwt1] stop-accounting-buffer enable
timer quiet minutes
undo timer quiet
服务器恢复激活状态的时间为5分钟。
HWTACACS方案视图
# 设置服务器恢复激活状态的时间为10分钟。
[Sysname-hwtacacs-hwt1] timer quiet 10
timer realtime-accounting minutes
实时计费的时间间隔为12分钟。
HWTACACS方案视图
minutes:实时计费的时间间隔,取值范围为0~60,单位为分钟。0表示设备不向HWTACACS服务器发送在线用户的计费信息。
为了对用户实施实时计费,有必要设置实时计费的时间间隔。在设置了该属性以后,每隔设定的时间,设备会向HWTACACS服务器发送一次在线用户的计费信息。
实时计费间隔的取值小,计费准确性高,但对设备和HWTACACS服务器的性能要求就高。
用户数 |
实时计费间隔(分钟) |
1~99 |
3 |
100~499 |
6 |
500~999 |
12 |
大于等于1000 |
大于等于15 |
# 在HWTACACS方案hwt1中,设置实时计费的时间间隔为51分钟。
[Sysname-hwtacacs-hwt1] timer realtime-accounting 51
timer response-timeout命令用来设置HWTACACS服务器响应超时时间。
HWTACACS服务器响应超时时间为5秒。
HWTACACS方案视图
seconds:HWTACACS服务器响应超时时间,取值范围为1~300,单位为秒。
由于HWTACACS是基于TCP实现的,因此,服务器响应超时或TCP超时都可能导致与HWTACACS服务器的连接断开。
HWTACACS服务器响应超时时间与配置的HWTACACS服务器总数的乘积不能超过接入模块定义的用户认证超时时间,否则在HWTACACS认证过程完成之前用户就有可能被强制下线。
# 在HWTACACS方案hwt1中,设置HWTACACS服务器响应超时时间为30秒。
[Sysname-hwtacacs-hwt1] timer response-timeout 30
user-name-format命令用来设置发送给HWTACACS服务器的用户名格式。
发送给HWTACACS服务器的用户名携带ISP域名。
HWTACACS方案视图
keep-original:发送给HWTACACS服务器的用户名与用户输入的保持一致。
with-domain:发送给HWTACACS服务器的用户名携带ISP域名。
without-domain:发送给HWTACACS服务器的用户名不携带ISP域名。
接入用户通常以“userid@isp-name”的格式命名,“@”后面的部分为ISP域名,设备就是通过该域名来决定将用户归于哪个ISP域的。但是,有些HWTACACS服务器不能接受携带有ISP域名的用户名,在这种情况下,有必要将用户名中携带的域名去除后再传送给HWTACACS服务器。因此,设备提供此命令以指定发送给HWTACACS服务器的用户名是否携带有ISP域名。
如果指定某个HWTACACS方案不允许用户名中携带有ISP域名,那么请不要在两个乃至两个以上的ISP域中同时设置使用该HWTACACS方案。否则,会出现虽然实际用户不同(在不同的ISP域中),但HWTACACS服务器认为用户相同(因为传送到它的用户名相同)的错误。
# 在HWTACACS方案hwt1中,设置发送给HWTACACS服务器的用户名不携带ISP域名。
[Sysname-hwtacacs-hwt1] user-name-format without-domain
vpn-instance命令用来配置HWTACACS方案所属的VPN。
undo vpn-instance
HWTACACS方案属于公网。
HWTACACS方案视图
本命令配置的VPN对于该方案下的所有HWTACACS认证/授权/计费服务器生效,但设备优先使用配置认证/授权/计费服务器时指定的各服务器所属的VPN。
# 配置HWTACACS方案hw1所属的VPN为test。
[Sysname-hwtacacs-hwt1] vpn-instance test
attribute-map命令用来在LDAP方案中引用LDAP属性映射表。
undo attribute-map命令用来恢复缺省情况。
attribute-map map-name
undo attribute-map
未引用任何LDAP属性映射表。
LDAP方案视图
map-name:LDAP属性映射表的名称,为1~31个字符的字符串,不区分大小写。
在使用LDAP授权方案的情况下,可以通过在LDAP方案中引用LDAP属性映射表,将LDAP授权服务器下发给用户的LDAP属性映射为AAA模块可以解析的某类属性。
一个LDAP方案视图中只能引用一个LDAP属性映射表,后配置的生效。
如果在LDAP授权过程中修改了引用的LDAP属性映射表,或者修改了引用的LDAP属性映射表的内容,则该修改对当前的授权过程不会生效,只对修改后新的LDAP授权过程生效。
# 在LDAP方案ldap1中,引用名称为map1的LDAP属性映射表。
[Sysname] ldap scheme ldap1
[Sysname-ldap-ldap1] attribute-map map1
· display ldap scheme
· ldap attribute-map
authentication-server命令用来指定LDAP认证服务器。
undo authentication-server命令用来恢复缺省情况。
authentication-server server-name
未指定LDAP认证服务器。
LDAP方案视图
server-name:LDAP服务器的名称,为1~64个字符的字符串,不区分大小写。
一个LDAP方案视图下仅能指定一个LDAP认证服务器,多次执行本命令,最后一次执行的命令生效。
# 在LDAP方案ldap1中,指定LDAP认证服务器为ccc。
[Sysname-ldap-ldap1] authentication-server ccc
· ldap server
authorization-server命令用来指定LDAP授权服务器。
undo authorization-server命令用来恢复缺省情况。
authorization-server server-name
未指定LDAP授权服务器。
LDAP方案视图
一个LDAP方案视图下仅能指定一个LDAP授权服务器,多次执行本命令,最后一次执行的命令生效。
# 在LDAP方案ldap1中,指定LDAP授权服务器为ccc。
[Sysname-ldap-ldap1] authorization-server ccc
· ldap server
display ldap scheme命令用来查看LDAP方案的配置信息。
display ldap scheme [ ldap-scheme-name ]
ldap-scheme-name:LDAP方案的名称,为1~32个字符的字符串,不区分大小写。如果不指定该参数,则显示所有LDAP方案的配置信息。
# 查看所有LDAP方案的配置信息。
<Sysname> display ldap scheme
Total 1 LDAP schemes
LDAP scheme name : aaa
Authentication server : aaa
IP : 1.1.1.1
Port : 111
VPN instance : Not configured
LDAP protocol version : LDAPv3
Server timeout interval : 10 seconds
Login account DN : Not configured
Base DN : Not configured
Search scope : all-level
User searching parameters:
User object class : Not configured
Username attribute : cn
Username format : with-domain
Authorization server : aaa
IP : 1.1.1.1
Port : 111
Attribute map : map1
表1-23 display ldap scheme命令显示信息描述表
Total 1 LDAP schemes |
总共有1个LDAP方案 |
LDAP Scheme Name |
LDAP方案名称 |
Authentication Server |
LDAP认证服务器名称 未配置时,显示为Not configured |
Authorization server |
LDAP授权服务器名称 未配置时,显示为Not configured |
IP |
LDAP认证服务器的IP地址 未配置认证服务器IP时,IP地址显示为Not configured |
Port |
LDAP认证服务器的端口号 未配置认证服务器IP时,端口号显示为缺省值 |
VPN Instance |
VPN实例名称 未配置时,显示为Not configured |
LDAP Protocol Version |
LDAP协议的版本号(LDAPv2、LDAPv3) |
Server Timeout Interval |
LDAP服务器连接超时时间(单位为秒) |
Login Account DN |
管理员用户的DN |
Base DN |
用户DN查询的起始DN |
Search Scope |
用户DN查询的范围(all-level:所有子目录查询,single-level:下级目录查询) |
User Searching Parameters |
用户查询参数 |
User Object Class |
查询用户DN时使用的用户对象类型 未配置时,显示为Not configured |
Username Attribute |
用户登录帐号的属性类型 |
Username Format |
发送给服务器的用户名格式 |
Attribute map |
引用的LDAP属性映射表名称 未配置时,显示为Not configured |
ip命令用来配置LDAP服务器的IP地址。
undo ip命令用来恢复缺省情况。
ip ip-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ip
未配置LDAP服务器的IP地址。
LDAP服务器视图
ip-address:LDAP服务器的IP地址。
port port-number:LDAP服务器所使用的TCP端口号,取值范围为1~65535,缺省值为389。
vpn-instance vpn-instance-name:LDAP服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN实例的名称,为1~31个字符的字符串,区分大小写。不指定该参数时,表示LDAP服务器属于公网。
需保证设备上的LDAP服务端口与LDAP服务器上使用的端口设置一致。
更改后的服务器IP地址和端口号,只对更改之后进行的LDAP认证生效。
# 配置LDAP服务器ccc的IP地址为192.168.0.10、端口号为4300。
[Sysname] ldap server ccc
[Sysname-ldap-server-ccc] ip 192.168.0.10 port 4300
· ldap server
ipv6命令用来配置LDAP服务器的IPv6地址。
undo ipv6命令用来恢复缺省情况。
ipv6 ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv6
未配置LDAP服务器的IP地址。
LDAP服务器视图
ipv6-address:LDAP服务器的IPv6地址。
更改后的服务器IP地址和端口号,只对更改之后的LDAP认证生效。
# 配置LDAP服务器ccc的IPv6地址为1:2::3:4、端口号为4300。
[Sysname-ldap-server-ccc] ipv6 1:2::3:4 port 4300
· ldap server
ldap attribute-map命令用来创建LDAP属性映射表,并进入LDAP属性映射表视图。如果指定的LDAP属性映射表已经存在,则直接进入LDAP属性映射表视图。
undo ldap attribute-map命令用来删除指定的LDAP属性映射表。
ldap attribute-map map-name
undo ldap attribute-map map-name
不存在LDAP属性映射表。
一个LDAP的属性映射表中可以添加多个LDAP属性映射表项,每个表项表示一个LDAP 属性和一个AAA属性的映射关系。
可以通过多次执行本命令配置多个LDAP的属性映射表。
# 创建名称为map1的LDAP属性映射表,并进入该属性映射表视图。
[Sysname] ldap attribute-map map1
[Sysname-ldap-map-map1]
· attribute-map
· ldap scheme
· map
ldap scheme命令用来创建LDAP方案,并进入LDAP方案视图。如果指定的LDAP方案已经存在,则直接进入LDAP方案视图。
undo ldap scheme命令用来删除指定的LDAP方案。
ldap scheme ldap-scheme-name
undo ldap scheme ldap-scheme-name
不存在LDAP方案。
一个LDAP方案可以同时被多个ISP域引用。
系统最多支持配置16个LDAP方案。
# 创建名称为ldap1的LDAP方案并进入其视图。
ldap server用来创建LDAP服务器,并进入LDAP服务器视图。如果指定的LDAP服务器已经存在,则直接进入LDAP服务器视图。
undo ldap server命令用来删除指定的LDAP服务器。
ldap server server-name
undo ldap server server-name
不存在LDAP服务器。
# 创建LDAP服务器ccc并进入其视图。
login-dn命令用来配置具有管理员权限的用户DN。
undo login-dn命令用来恢复缺省情况。
login-dn dn-string
undo login-dn
未配置具有管理员权限的用户DN。
LDAP服务器视图
dn-string:具有管理员权限的用户DN,是绑定服务器时使用的用户标识名,为1~255个字符的字符串,不区分大小写。
设备上的管理员DN必须与服务器上管理员的DN一致。
更改后的管理员DN,只对更改之后的LDAP认证生效。
# 在LDAP服务器视图ccc下,配置管理员权限的用户DN为uid=test, ou=people, o=example, c=city。
[Sysname-ldap-server-ccc] login-dn uid=test,ou=people,o=example,c=city
login-password命令用来配置LDAP认证中,绑定服务器时所使用的具有管理员权限的用户密码。
undo login-password命令用来恢复缺省情况。
login-password { cipher | simple } string
undo login-password
未配置具有管理权限的用户密码。
LDAP服务器视图
cipher:表示以密文方式设置密码。
simple:表示以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为1~128个字符的字符串,密文密码为1~201个字符的字符串。
该命令只有在配置了login-dn的情况下生效。当未配置login-dn时,该命令不生效。
# 在LDAP服务器视图ccc下,配置具有管理员权限的用户密码为明文abcdefg。
[Sysname-ldap-server-ccc] login-password simple abcdefg
· login-dn
map命令用来配置LDAP属性映射表项。
undo map命令用来删除指定的LDAP属性映射表项。
map ldap-attribute ldap-attribute-name [ prefix prefix-value delimiter delimiter-value ] aaa-attribute { user-group | user-profile }
undo map [ ldap-attribute ldap-attribute-name ]
未指定LDAP属性映射关系。
LDAP属性映射表视图
ldap-attribute ldap-attribute-name:表示要映射的LDAP属性。其中,ldap-attribute-name表示LDAP属性名称,为1~63个字符的字符串,不区分大小写。
prefix prefix-value delimiter delimiter-value:表示按照一定的格式提取LDAP属性字符串中的内容映射为AAA属性。其中,prefix-value表示LDAP属性字符串中的某内容前缀(例如cn=),为1~7个字符的字符串,不区分大小写;delimiter-value表示LDAP属性字符串中的内容分隔符(例如逗号)。若不指定该可选参数,则表示要将一个完整的LDAP属性字符串映射为指定的AAA属性。
aaa-attribute:表示要映射为的AAA属性。
user-group:表示User group类型的AAA属性。
user-profile:表示User Profile类型的AAA属性。
如果某LDAP服务器下发给用户的属性不能被AAA模块解析,则该属性将被忽略。因此,需要通过本命令指定要获取哪些LDAP属性,以及LDAP服务器下发的这些属性将被AAA模块解析为什么类型的AAA属性,具体映射为哪种类型的AAA属性由实际应用需求决定。
一个LDAP服务器属性只能映射为一个AAA属性,但不同的LDAP服务器属性可映射为同一个AAA属性。
如果undo map命令中不指定ldap-attribute参数,则表示删除所有的LDAP属性映射表项。
# 在LDAP属性映射表视图map1下,配置将LDAP服务器属性memberof按照前缀为cn=、分隔符为逗号(,)的格式提取出的内容映射成AAA属性User group。
[Sysname-ldap-map-map1] map ldap-attribute memberof prefix cn= delimiter , aaa-attribute user-group
· user-group
· user-profile(BRAS业务命令参考/User Profile)
protocol-version命令用来配置LDAP认证中所支持的LDAP协议的版本号。
undo protocol-version命令用来恢复缺省情况。
protocol-version { v2 | v3 }
LDAP版本号为LDAPv3。
LDAP服务器视图
v2:表示LDAP协议版本号为LDAPv2。
v3:表示LDAP协议版本号为LDAPv3。
为保证LDAP认证成功,请保证设备上的LDAP版本号与LDAP服务器上使用的版本号一致。
更改后的服务器版本号,只对更改之后的LDAP认证生效。
Microsoft的LDAP服务器只支持LDAPv3,配置LDAP版本为v2时无效。
# 在LDAP服务器视图ccc下,配置LDAP协议版本号为LDAPv2。
[Sysname-ldap-server-ccc] protocol-version v2
search-base-dn命令用来配置用户查询的起始DN。
undo search-base-dn命令用来恢复缺省情况。
search-base-dn base-dn
undo search-base-dn
未指定用户查询的起始DN。
LDAP服务器视图
base-dn:查询待认证用户的起始DN值,为1~255个字符的字符串,不区分大小写。
# 在LDAP服务器视图ccc下,配置用户查询的起始DN为dc=ldap,dc=com。
[Sysname-ldap-server-ccc] search-base-dn dc=ldap,dc=com
· ldap server
search-scope命令用来配置用户查询的范围。
undo search-scope命令用来恢复缺省情况。
search-scope { all-level | single-level }
undo search-scope
用户查询的范围为all-level。
LDAP服务器视图
all-level:表示在起始DN的所有子目录下进行查询。
single-level:表示只在起始DN的下一级子目录下进行查询。
# 在LDAP服务器视图ccc下,配置在起始DN的所有子目录下查询LDAP认证用户。
[Sysname-ldap-server-ccc] search-scope all-level
· ldap server
server-timeout命令用来配置LDAP服务器连接超时时间,即认证、授权时等待LDAP服务器回应的最大时间。
undo server-timeout命令用来恢复缺省情况。
server-timeout time-interval
undo server-timeout
LDAP服务器连接超时时间为10秒。
LDAP服务器视图
time-interval:LDAP服务器连接超时时间,取值范围为5~20,单位为秒。
更改后的连接超时时间,只对更改之后的LDAP认证生效。
# 在LDAP服务器视图ccc下,配置LDAP服务器连接超时时间为15秒。
[Sysname-ldap-server-ccc] server-timeout 15
user-parameters命令用来配置LDAP用户查询的属性参数,包括用户名属性、用户名格式和自定义用户对象类型。
undo user-parameters命令用来将指定的LDAP用户查询的属性参数恢复为缺省值。
user-parameters { user-name-attribute { name-attribute | cn | uid } | user-name-format { with-domain | without-domain } | user-object-class object-class-name }
undo user-parameters { user-name-attribute | user-name-format | user-object-class }
user-name-attribute为cn;user-name-format为without-domain;未指定自定义user-object-class,根据使用的LDAP服务器的类型使用各服务器缺省的用户对象类型。
LDAP服务器视图
user-name-attribute { name-attribute | cn | uid }:表示用户名的属性类型。其中,name-attribute表示属性类型值,为1~64个字符的字符串,不区分大小写;cn表示用户登录帐号的属性为cn(Common Name);uid表示用户登录帐号的属性为uid(User ID)。
user-name-format { with-domain | without-domain }:表示发送给服务器的用户名格式。其中,with-domain表示发送给服务器的用户名带ISP域名;without-domain表示发送给服务器的用户名不带ISP域名。
user-object-class object-class-name:表示查询用户DN时使用的用户对象类型。其中,object-class-name表示对象类型值,为1~64个字符的字符串,不区分大小写。
如果LDAP服务器上的用户名不包含域名,必须配置user-name-format为without-domain,将用户名的域名去除后再传送给LDAP服务器;如果包含域名则需配置user-name-format为with-domain。
# 在LDAP服务器视图ccc下,配置用户对象类型为person。
[Sysname-ldap-server-ccc] user-parameters user-object-class person
· login-dn
display local-bill命令用来显示缓存中指定的具体话单信息或者缓存中话单资源的使用情况。
display local-bill { cache-usage | verbose start-number count count }
cache-usage:查看本地缓存中话单资源的使用情况。
verbose:查看本地缓存中的具体话单信息。
start-number:指定显示话单的起始位置,即从第几个话单开始显示,取值范围为1~50000。
count count:连续显示的话单总数目,取值范围为1~100。
# 从本地缓存的第一个话单开始显示连续2个话单的详细信息。
<Sysname> display local-bill verbose 1 count 2
Bill 1 details:
Session ID : 00000005201801181806480000195e6176100378
User name : user1@h3c
Start time : 2019-05-21 18:04:10
Stop time : 2019-05-21 18:05:35 Duration : 0:01:35
IP address : 111.8.10.125 MAC address: 0016-ecb7-a879
IPv6 address: N/A
Service type: PPP Access type: PPP
Interface : Ten-GigabitEthernet3/0/1
SVLAN/CVLAN : -/-
Status : Offline Reason code: 6 Ref: 98
User traffic:
Received: 0 bytes, 0 packets
Sent : 0 bytes, 0 packets
Bill 2 details:
Session ID : 00000005201801181806480000195e6176100379
User name : user2
Start time : 2019-05-21 18:14:15
Stop time : 2019-05-21 18:15:35 Duration : 0:01:20
IP address : 111.8.10.124 MAC address: 0016-ec89-a8e9
IPv6 address: N/A
Interface : Ten-GigabitEthernet3/0/2
SVLAN/CVLAN : 100/100
User traffic:
Total bills: 2.
表1-24 display local-bill verbose命令显示信息描述表
Bill 1 details |
第n个话单的详细内容 |
Session ID |
会话ID,用户的唯一标识 |
User name |
用户名称 |
Start time |
开始计费时间 |
Stop time |
停止计费时间 |
Duration |
用户在线时长 |
IP address |
用户IP地址 |
MAC address |
用户MAC地址 |
IPv6 address |
用户IPv6地址 |
Service type |
用户使用的服务类型 |
Access type |
用户使用的接入类型 |
用户接入到设备的接口 |
SVLAN/CVLAN |
用户接入的Service-VLAN/Customer-VLAN(“-”表示无对应的VLAN信息) |
Status |
话单类型,取值如下: · Invalid:无效 · Realtime:实时计费话单 · Offline:下线话单 · CRC Failed:错误话单,即CRC校验错误的话单 目前,仅支持Offline |
Reason code |
设备外部的下线原因代码。为按照RFC 2866远端计费提供的标准下线原因,具体请参考RFC 2866 |
Ref |
设备内部的下线原因代码,作为外部下线原因的补充,提供更加详细的原因,一般无需使用 |
User traffic |
用户流量统计信息,包括上行字节数、上行包数、下行字节数、下行包数 |
Received |
下行流量,即用户收到报文的流量 |
Sent |
上行流量,即用户发送出去的流量 |
Total bills |
当前显示的话单总数 |
# 显示本地缓存中的话单资源的使用情况。
<Sysname> display local-bill cache-usage
Cache usage:
Existing bills: 0 Available bills : 50000
Max bills : 50000 Auto export threshold: 4000
Bytes per bill: 448
表1-25 display local-bill cache-usage命令显示信息描述表
Cache usage |
缓存的使用情况 |
Existing bills |
当前缓存中已保存的话单数目 |
Available bills |
当前缓存中还可以保存的话单数目 |
Max bills |
当前缓存中可保存的话单总数 |
Auto export threshold |
自动上传阈值,取值为触发自动上传的话单数 |
Bytes per bill |
缓存中每个话单的存储空间大小 (单位:字节) |
· local-bill enable
· local-bill export
· local-bill export-interval
· local-bill export-url
local-bill enable命令用来开启本地话单缓存功能。
undo local-bill enable命令用来关闭本地话单缓存功能。
local-bill enable
本地话单缓存功能处于关闭状态。
开启本地话单缓存功能后,当AAA服务器不能提供计费服务时(例如计费服务器不可达时),接入设备会将用户计费停止时产生的话单保存在本地。本地保存的话单可以通过FTP或TFTP的方式自动或手动上传到指定服务器上,上传的话单将以文本格式保存在指定路径中供计费、审校或分析。
本功能可以支持对lan-access、PPP、IPoE用户进行本地话单缓存。
# 开启本地话单缓存功能。
[Sysname] local-bill enable
· local-bill export
local-bill export命令用来执行话单手动上传。
local-bill export [ url ] [ clear-cache ]
url:手动上传话单的URL,为1~256个字符的字符串。若不指定该参数,则会将本地缓存的话单上传到local-bill export-url命令指定的路径上。
clear-cache:手动上传话单后,清除本地缓存的话单信息。若不指定该参数,则表示手动上传话单后,不清除本地缓存的话单信息。
通常情况下,使用话单自动上传功能即可,在自动上传路径不可达(例如存储话单的服务器故障)、有临时审计、数据分析等需求的情况下,可通过本命令进行手工上传话单。
具体上传URL格式要求如下:
· TFTP协议URL格式:tftp://server/path,其中server为TFTP服务器的IP地址或主机名。例如tftp://1.1.1.1/lbill。
· FTP协议URL格式:
¡ 携带用户名和密码的格式为ftp://username:password@server/path,例如ftp://1:1@1.1.1.1/lbill。其中,username为FTP用户名,password为FTP认证密码,server为FTP服务器IP地址或主机名。如果FTP用户名中携带域名,则该域名会被设备忽略,例如ftp://1@abc:1@1.1.1.1/lbill将被当作ftp://1:1@1.1.1.1/lbill处理。
¡ 不需要携带用户名和密码的格式为ftp://server/path,例如ftp://1.1.1.1/lbill。
在上传的话单用于计费或审计等用途的情况下,建议执行话单手动上传的同时,指定clear-cache参数清除本地缓存的话单信息;在上传的话单用于数据分析、故障排除等用途的情况下,建议执行话单手工上传的同时,不要指定clear-cache参数,保留本地缓存的话单信息用于正常的话单上传。
手动上传操作仅能同时在一个用户线上执行。某用户线上的用户执行了该操作后,系统需要一定的时间进行上传,在此期间,该用户线上的用户必须等待上传结果,不能执行命令行操作,且正在进行的自动上传也会暂停等待。同时,其它用户线上的用户执行手动上传话单命令时,系统会提示当前正在处理手动上传话单不能执行本次命令。
# 将本地缓存话单手动上传到URL为tftp://10.10.10.10/tftp的服务器上,并在上传后清除缓存的话单信息。
[Sysname] local-bill export tftp://10.10.10.10/tftp clear-cache
· local-bill enable
local-bill export-interval命令用来配置话单自动上传的周期。
undo local-bill export-interval命令用来恢复缺省情况。
local-bill export-interval interval
自动上传话单的周期为1440分钟。
interval:话单自动上传的周期,取值范围为1~65535,单位为分钟。
本地话单缓存功能开启之后,系统将以本命令指定的周期向指定路径上进行话单上传。
# 配置本地缓存话单自动上传的周期为100分钟。
[Sysname] local-bill export-interval 100
· local-bill enable
· local-bill export
local-bill export-url命令用来配置对本地缓存话单进行上传的URL。
undo local-bill export-url命令用来恢复缺省情况。
local-bill export-url url
未指定对话单上传的URL,对缓存话单的自动上传会失败。
url:对本地缓存话单进行上传的URL,为1~256个字符的字符串,且不能以?开头。
本地话单缓存功能处于开启状态的情况下,指定合法的上传话单的URL后,系统将定期向该指定路径上进行话单上传,或当本地缓存话单数目达到系统设定的阈值时,系统也会自动向该指定路径上进行话单上传。上传的话单将以文本格式保存在指定路径中供计费、审校或分析。每次话单信息上传完成之后,系统将自动清除当前本地话单缓存中的所有话单信息。
具体上传URL格式要求如下:
· FTP协议URL格式:
# 配置本地缓存话单的上传URL为tftp://10.10.10.10/tftp。
[Sysname] local-bill export-url tftp://10.10.10.10/tftp
· local-bill enable
snmp-agent trap enable local-bill命令用来开启本地话单缓存告警功能。
undo snmp-agent trap enable local-bill用来关闭本地话单缓存告警功能。
本地话单缓存告警功能处于开启状态。
开启本地话单上传缓存告警功能后,当系统定时自动上传或超过阈值时自动上传本地缓存的话单到服务器失败时,会发送表示本地话单上传失败的告警信息。
发送告警信息的最小时间间隔为10秒。当出现上传话单失败而需要发送告警信息时,如果距离上次上传失败发送告警信息间隔不足10秒,则本次不会发送告警信息。
# 开启本地话单缓存告警功能。
[Sysname] snmp-agent trap enable local-bill
radius-proxy命令用来开启RADIUS代理功能,并进入RADIUS代理视图。
undo radius-proxy命令用来关闭RADIUS代理功能。
radius-proxy
undo radius-proxy
RADIUS代理功能处于关闭状态。
在同时存在无线802.1X和IPoE接入认证的组网环境中,如果开启了IPoE认证的接入设备上不支持802.1X认证,则需要在接入设备上开启RADIUS代理功能对无线802.1X客户端的RADIUS认证/授权/计费过程进行代理。设备上开启RADIUS代理功能后:
(1) 将会监听指定RADIUS客户端发送的认证请求报文并转发至RADIUS服务器,再将RADIUS服务器发送的认证回应报文转发至RADIUS客户端。在此过程中,设备还会生成用户的本地代理用户表项,用于记录用户的用户名、IP地址、MAC地址、RADIUS客户端以及授权信息。
(2) 收到该RADIUS客户端发送的计费请求报文时,对其直接进行响应,不转发至RADIUS服务器。
目前,RADIUS代理功能只支持无线802.1X和IPoE接入认证同时存在的应用场景,暂不支持其他组网方式。对于非802.1X和IPoE双重认证的组网环境,建议不要开启RADIUS代理功能,否则会导致不需要认证代理的接入用户的计费报文无法正常发送。
设备的RADIUS代理功能和RADIUS session control功能缺省使用同一个UDP端口1812分别监听认证请求报文和session control报文,所以若要同时使用RADIUS代理功能和RADIUS session control功能,请保证这两个功能使用了不同的监听端口。
关闭RADIUS代理功能后,RADIUS代理视图下的所有配置将被删除。
# 开启RADIUS代理服务,并进入RADIUS代理视图。
[Sysname] radius-proxy
[Sysname-radius-proxy]
· client
client命令用来指定RADIUS客户端。
undo client命令用来删除指定的RADIUS客户端。
client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] radius-scheme radius-scheme-name [ key { cipher | simple } string ] [ authentication-port authentication-port-num ] [ accounting-port accounting-port-num ] [ dae-server-port dae-server-port-num ]
undo client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未指定RADIUS客户端。
RADIUS代理视图
ip ipv4-address:RADIUS客户端的IPv4地址。
ipv6 ipv6-address:RADIUS客户端的IPv6地址
radius-scheme radius-scheme-name:指定用于认证和授权的RADIUS方案。其中,radius-scheme-name表示RADIUS方案名,为1~32个字符的字符串,不区分大小写。
vpn-instance vpn-instance-name:RADIUS客户端所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示RADIUS客户端位于公网中。
key:与RADIUS客户端交互的认证/计费报文的共享密钥。此共享密钥必须与RADIUS客户端使用的RADIUS认证/计费共享密钥保持一致。若不指定该参数,则表示未设置RADIUS报文的共享密钥。
cipher:以密文方式设置密钥。
string:密钥字符串,区分大小写。明文密钥为1~64个字符的字符串;密文密钥为1~117个字符的字符串。
authentication-port authentication-port-num:监听RADIUS客户端认证请求报文的UDP端口,取值范围为1~65535,缺省值为1812。
accounting-port accounting-port-num:监听RADIUS客户端计费请求报文的UDP端口,取值范围为1~65535,缺省值为1813。
dae-server-port dae-server-port-num:RADIUS客户端(作为DAE服务器)监听DAE报文的端口,即RADIUS代理向RADIUS客户端转发DAE报文时使用的目的UDP端口,取值范围为1~65535,缺省值为3799。
开启RADIUS代理服务之后,设备会监听并处理指定的RADIUS客户端发起的认证、计费请求报文。
· 设备收到RADIUS客户端的认证请求报文时,首先根据报文的源IP地址、VPN属性与已有的RADIUS客户端配置进行匹配,然后使用匹配到的客户端共享密钥对报文进行验证:
¡ 如果报文匹配失败或设备上未配置RADIUS客户端,则对报文进行丢弃处理。
¡ 如果报文匹配成功,则根据该客户端配置中指定的radius-scheme方案把校验通过的报文转发至指定的RADIUS服务器,同时将服务器的回应报文再转发给RADIUS客户端。
· 设备收到RADIUS客户端的计费请求报文时,首先会同认证报文处理过程一样进行报文合法性验证,然后根据验证结果直接向RADIUS客户端回应计费成功或计费失败报文,但不会将验证通过的报文转发至指定的RADIUS服务器处理。
RADIUS客户端上为无线客户端配置的认证/授权/计费RADIUS方案必须相同,这样才能保证RADIUS代理监听到在线用户的计费停止请求报文,从而能够及时清理对应的本地代理用户表项、减少内存占用。同时,建议在RADIUS客户端上配置stop-accounting-packet send-force命令,使得无线客户端下线时RADIUS客户端会强制发送一个RADIUS计费停止请求报文给RADIUS代理,及时清理RADIUS代理设备上的残留用户信息。
必须保证设备上配置的RADIUS代理认证、计费服务端口分别与RADIUS客户端发送认证、计费报文的目的UDP端口一致。同时,必须保证RADIUS代理认证和计费端口不相同。
可通过多次执行本命令指定多个RADIUS客户端。系统最多支持配置32个RADIUS客户端。
后配置的RADIUS客户端,若与已有的RADIUS客户端的IP地址、VPN属性相同,则会将其覆盖。
RADIUS代理向RADIUS客户端(作为DAE服务器)转发DAE请求报文的目的端口必须和RADIUS客户端监听和接收DAE报文的端口(由RADIUS DAE服务器视图下的port命令设置)一致。
# 指定RADIUS客户端的IP地址为3.3.3.3,与RADIUS方案rs1下所指定的远端RADIUS服务器交互,与RADIUS客户端交互报文时使用的共享密钥为明文123456。
[Sysname-radius-proxy] client ip 3.3.3.3 radius-scheme rs1 key simple 123456
· port
· stop-accounting-packet send-force
display radius-proxy statistics命令用来显示RADIUS客户端和RADIUS代理之间的RADIUS报文统计信息。
display radius-proxy statistics client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
client:指定RADIUS客户端。
ip ipv4-address:RADIUS客户端IPv4地址。
ipv6 ipv6-address:RADIUS客户端IPv6地址。
# 显示RADIUS代理与RADIUS客户端之间的报文统计信息,RADIUS客户端的IP地址为3.3.3.3,所属VPN名称为v1。
<Sysname> display radius-proxy statistics client ip 169.168.92.1 vpn-instance v1
Authentication packets:
Requests : 10 Accept responses : 2
Challenge packets : 8 Reject responses : 0
Bad authenticators : 0 Dropped requests : 0
Accounting packets:
Requests : 2 Responses : 2
DAE packets:
Requests : 1 ACKs : 1
NAKs : 0
表1-26 display radius-proxy statistics命令显示信息描述表
Authentication packets |
认证报文统计信息 |
Accounting packets |
计费报文统计信息 |
DAE packets |
DAE报文统计信息 |
Requests |
请求报文数 |
Accept responses |
认证接受报文数 |
Challenge packets |
认证挑战报文数 |
Reject responses |
认证拒绝报文数 |
Responses |
计费响应报文数 |
Bad authenticators |
验证字错误的报文数 |
Dropped requests |
丢弃的请求报文数 |
ACKs |
DAE请求接受报文数 |
NAKs |
DAE请求拒绝报文数 |
· reset radius-proxy statistics
display radius-proxy user命令用来显示RADIUS客户端的代理用户信息。
display radius-proxy user [ client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ count ]
client:指定RADIUS客户端。若不指定该参数,则表示显示所有RADIUS客户端的代理用户信息。
count:仅显示RADIUS客户端的代理用户数目。若不指定该参数,则表示显示详细的代理用户信息。
# 显示IP地址为3.3.3.3的RADIUS客户端的代理用户信息。
<Sysname> display radius-proxy user client ip 3.3.3.3
Username MAC address IP address Client IP Client VPN
Yyy1 1-1-1 2.2.2.2 3.3.3.3 abc
Yyy2 1-1-2 - 3.3.3.3 -
# 显示IP地址为3.3.3.3的RADIUS客户端的代理用户数目。
<Sysname> display radius-proxy user client ip 3.3.3.3 count
Total RADIUS users: 2
表1-27 display radius-proxy user命令显示信息描述表
Username |
用户名 |
MAC address |
用户的MAC地址 |
IP address |
用户的IP地址 若未获取到用户IP地址,则显示为“-”;若用户同时拥有IPv4地址和IPv6地址,则仅显示其中到IPv4地址 |
Client IP |
用户接入的RADIUS客户端IP地址 |
Client VPN |
用户接入的RADIUS客户端所属的VPN名称 若属于公网,则显示为“-” |
Total RADIUS users |
RADIUS客户端上的代理用户数目 |
· reset radius-proxy user
reset radius-proxy statistics命令用来清除RADIUS客户端和RADIUS代理之间的RADIUS报文统计信息。
reset radius-proxy statistics [ client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ]
client:指定RADIUS客户端。
若未指定任何参数,则表示清除所有RADIUS客户端和RADIUS代理之间的RADIUS报文统计信息。
# 清除IP地址为3.3.3.3的RADIUS客户端和RADIUS代理之间的RADIUS报文统计信息。
<Sysname> reset radius-proxy statistics client ip 3.3.3.3
· display radius-proxy statistics
reset radius-proxy user命令用来清除RADIUS代理上的代理用户信息。.
reset radius-proxy user [ mac mac-address [ client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] | client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ]
mac mac-address:代理用户的MAC地址,格式为H-H-H。
client:指定RADIUS客户端。
本命令来清除RADIUS代理上指定客户端的代理用户信息,有以下两种典型的应用场景:
· 未开启RADIUS代理忽略停止计费报文功能的情况下,发现RADIUS代理设备上残留用户信息,即RADIUS代理设备上保存的代理用户数量大于RADIUS客户端上的在线用户数。
· 开启了RADIUS代理忽略停止计费报文功能的情况下,RADIUS代理设备上存在短时间内不会再次上线用户的本地代理用户表项,且配置的本地代理用户表项老化时间较长。
在执行本命令前,务必完成RADIUS代理设备和RADIUS客户端上用户信息的比对,确认要删除的用户信息为已下线的用户信息,避免误删而造成用户认证失败。
若未指定任何参数,则表示清除RADIUS代理上的所有代理用户信息。
# 清除IP地址为3.3.3.3的RADIUS客户端的代理用户信息。
<Sysname> reset radius-proxy user client ip 3.3.3.3
· display radius-proxy user
· stop-accounting ignore
· timer aging
stop-accounting ignore命令用来开启RADIUS代理忽略停止计费报文功能,即设备收到停止计费报文时,不删除本地代理用户表项。
undo stop-accounting ignore命令用来关闭RADIUS代理忽略停止计费报文功能。
RADIUS代理设备收到停止计费报文时,会删除本地代理用户表项。
RADIUS代理视图
缺省情况下,无线客户端下线时,RADIUS代理收到AC发送的停止计费请求报文后,将会立即删除相关联的本地代理用户表项,但不联动删除IPoE会话。如果BRAS上开启了允许IPoE用户异常下线后通过报文重新触发上线功能,那么后续因接入接口Down等原因异常下线的IPoE用户,将可以通过DHCP用户的IP、ARP、NS/NA报文或ND RS用户的IP、NS/NA报文重新触发IPoE认证。但是,由于BRAS为其重新生成的IPoE会话没有与之匹配的本地代理用户表项,此类IPoE用户重新上线将会失败。
因此,在开启了RADIUS代理功能的设备上,如果同时希望支持IPoE用户异常下线后重新触发上线的功能,建议开启RADIUS代理忽略停止计费报文功能。
开启本功能后,设备收到停止计费报文时,不再主动删除本地代理用户表项,一定时间内这些表项会占用更多的内存资源。未被删除的本地代理用户表项将在本地代理用户表项的老化定时器超时后删除。
# 配置RADIUS代理设备收到停止计费报文时,不删除本地代理用户表项。
[Sysname-radius-proxy] stop-accounting ignore
· timer aging
timer aging命令用来配置本地代理用户表项的老化时间。
undo timer aging命令用来恢复缺省情况。
timer aging aging-time
undo timer aging
本地代理用户表项的老化时间为720分钟。
RADIUS代理视图
aging-time:本地代理用户表项的老化时间,取值范围为0~65535,单位为分钟。老化时间取值为0时,表示本地代理用户表项不老化。
如果短时间内有大量无线客户端通过RADIUS代理设备集中上线,同时又有大量老用户集中下线,那么BRAS上在一定时间内会累计大量的本地代理用户表项,导致系统内存资源被大量占用。这种情况下,建议通过本命令减小本地代理用户表项的老化时间,以便尽快释放系统内存资源。其它情况下,建议保持缺省值,或者适当调大本地代理用户表项的老化时间,确保无线客户端有长期在线需求时,用户不会因为表项老化而需要反复认证。
RADIUS代理为认证成功的用户创建本地代理用户表项之后,会立即为该表项启动一个老化定时器。后续,当无线客户端的数据流量触发IPoE认证,且IPoE用户成功上线后,RADIUS代理将终止用户的本地代理表项老化定时器。当IPoE用户下线时,BRAS会根据当时本命令的配置重新启动该表项的老化定时器。如果该IPoE用户再次上线,且匹配到对应的本地代理表项,则会再次终止该老化定时器;如果该IPoE用户不再上线,则对应的本地代理表项将在老化定时器超时后被删除。
更改后的老化时间,不会影响正在老化计时的本地代理表项,只会对新建的本地代理表项以及重启老化定时器的本地代理表项生效。
通常情况下,不建议将老化时间设置为0,此值仅适用于上线用户群体固定的场景。如果后续需要将老化时间从0恢复为非0值,那么修改老化时间后,建议排查设备上是否残留一些已经下线的本地代理用户表项,并使用reset radius-proxy user将其清除掉。
UCM进程重启或主备倒换后,会以当前本命令的配置重新启动所有本地代理表项的老化定时器。
如下事件发生后,最新的老化时间配置将会立即生效:
· 本地代理表项对应的IPoE用户下线。
· 802.1X用户重认证成功。
· 802.1X用户在AC间发生漫游后。
# 配置本地代理用户表项的老化时间为60分钟。
[Sysname-radius-proxy] timer aging 60
username-change action force-logout命令用来配置代理用户表项记录的用户名变化时,强制IPoE用户下线。
undo username-change action force-logout命令用来恢复缺省情况。
代理用户表项记录的用户名变化时,不强制IPoE用户下线。
RADIUS代理视图
缺省情况下,当无线客户端下线时,IPoE不会自动删除相应的IPoE会话。举个例子,当用户A下线后,用户B登录上线,IPoE仍然会使用用户A的账号进行计费,无法满足账号借用的需求。为了解决以上问题,可以配置本功能。配置本功能后,当设备检测到无线客户端更换用户名进行登录时,会强制下线对应的IPoE用户,并重新触发IPoE上线流程。同时,设备会获取新的用户名和授权信息,以满足账号借用的需求。
当同一个无线客户端需要使用不同用户名登录时,建议开启本功能。
设备检测无线客户端是否更换了用户名的原则是,查看代理用户表项记录的用户名和新上线用户的用户名是否相同,如果不同则判断无线客户端更换了用户名。因此,本功能生效需要满足如下条件:
· 通过stop-accounting ignore命令开启RADIUS代理忽略停止计费报文功能。
· 通过timer aging配置的本地代理用户表项的老化时间需要大于通过ip subscriber user-detect命令配置的IPoE在线探测功能的探测时间间隔。有关IPoE在线探测功能的详细介绍,请参见“BRAS业务”配置指导中的“IPoE”。
# 配置代理用户表项记录的用户名变化时,强制IPoE用户下线。
[Sysname-radius-proxy] username-change action force-logout
· ip subscriber user-detect(BRAS业务命令参考/IPoE)
· radius-proxy
· timer aging
本节命令是为了兼容网管软件保留的旧风格命令。推荐仅在网管软件不支持对应的新风格命令,且希望能够使用旧风格命令对BRAS设备进行管理的情况下使用。
display domain命令用来显示指定ISP域的配置信息。
display domain isp-name
isp-name:ISP域名,为1~255个字符的字符串,不区分大小写。
display domain name isp-name
命令和display domain isp-name命令都可以用于显示指定ISP域的配置信息。display domain isp-name是为了兼容网管软件保留的旧风格命令,旧风格命令推荐仅在网管软件不支持display domain name isp-name命令的情况下使用,除此之外均推荐使用display domain name isp-name命令。
# 显示ISP域test的配置信息及负载分担用户组的信息。
<Sysname> display domain test
Domain: test
Current state: Active
State configuration: Active
Default authentication scheme: Local
Default authorization scheme: Local
Default accounting scheme: Local
Accounting start failure action: Online
Accounting update failure action: Online
Accounting quota out policy: Offline
Send accounting update:Yes
Service type: HSI
Session time: Exclude idle time
DHCPv6-follow-IPv6CP timeout: 60 seconds
Dual-stack accounting method: Merge
NAS-ID: N/A
Service rate-limit mode: Separate
Web server IPv4 URL : Not configured
Web server IPv6 URL : Not configured
Web server URL parameters : Not configured
Web server IPv4 address : Not configured
Web server IPv6 address : Not configured
Redirect active time : Not configured
Redirect server IPv4 address: Not configured
Redirect server IPv6 address: Not configured
Temporary redirect : Enabled
L2TP-user RADIUS-force : Enabled
Authorization attributes:
Idle cut: Disabled
IGMP access limit: 4
MLD access limit: 4
Dynamic authorization effective attributes: Not configured
Authen-radius-unavailable: Online domain dm2
Authen-radius-recover: Online domain dm
IP resource usage warning thresholds:
High threshold: Not configured
Low threshold: Not configured
IPv6 resource usage warning thresholds:
Low threshold: 10%
Load-sharing user groups:
g1: 323 user(s)
g2: 324 user(s)
Authorization attributes specific to none authentication:
User session timeout: 28 seconds
Access limit per account (case-sensitive): 5
表1-28 display domain命令显示信息描述表
Domain |
ISP域名 |
Current state |
ISP域的当前状态,包括以下取值: · Blocked:阻塞状态 · Active:活动状态 |
State configuration |
ISP域的状态配置,包括以下取值: · Active:活动状态 · Blocked during specific time ranges:在指定时间段处于阻塞状态 · Blocked:阻塞状态 |
Time ranges |
ISP域处于阻塞状态的时间段名称 |
Online-user logoff |
ISP域处于阻塞状态后强制在线用户下线功能的状态,包括以下取值: · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Default authentication scheme |
缺省的认证方案 |
Default authorization scheme |
缺省的授权方案 |
Default accounting scheme |
缺省的计费方案 |
ADVPN authentication scheme |
ADVPN用户认证方案 |
ADVPN authorization scheme |
ADVPN用户授权方案 |
ADVPN accounting scheme |
ADVPN用户计费方案 |
Login authentication scheme |
Login用户认证方案 |
Login authorization scheme |
Login用户授权方案 |
Login accounting scheme |
Login用户计费方案 |
Super authentication scheme |
用户角色切换认证方案 |
PPP authentication scheme |
PPP用户的认证方案 |
PPP authorization scheme |
PPP用户的授权方案 |
PPP accounting scheme |
PPP用户的计费方案 |
Command authorization scheme |
命令行授权方案 |
Command accounting scheme |
命令行计费方案 |
LAN access authentication scheme |
lan-access用户认证方案 |
LAN access authorization scheme |
lan-access用户授权方案 |
LAN access accounting scheme |
lan-access用户计费方案 |
Portal authentication scheme |
Portal用户认证方案 |
Portal authorization scheme |
Portal用户授权方案 |
Portal accounting scheme |
Portal用户计费方案 |
IKE authentication scheme |
IKE扩展认证方案 |
IKE authorization scheme |
IKE扩展认证的授权方案 |
IPoE authentication scheme |
IPoE用户认证方案 |
IPoE authorization scheme |
IPoE用户授权方案 |
IPoE accounting scheme |
IPoE用户计费方案 |
SSL VPN authentication scheme |
SSL VPN用户认证方案 |
SSL VPN authorization scheme |
SSL VPN用户授权方案 |
SSL VPN accounting scheme |
SSL VPN用户计费方案 |
RADIUS |
RADIUS方案 |
HWTACACS |
HWTACACS方案 |
LDAP |
LDAP方案 |
Local |
本地方案 |
None |
不认证、不授权和不计费 |
Accounting start failure action |
用户计费开始失败的动作,包括以下取值: · Online:如果用户计费开始失败,则保持用户在线 · Offline:如果用户计费开始失败,则强制用户下线 |
Accounting update failure max-times |
允许用户连续计费更新失败的次数 |
Accounting update failure action |
用户计费更新失败的动作,包括以下取值: · Online:如果用户计费更新失败,则保持用户在线 · Offline:如果用户计费更新失败,则强制用户下线 |
Accounting quota out policy |
用户计费配额耗尽策略,包括以下取值: · Online:如果用户计费配额耗尽,则保持用户在线 · Offline:如果用户计费配额耗尽,则强制用户下线 · Redirect:发送重定向URL |
Redirect URL |
强制重定向的URL |
Stop accounting |
向计费服务器发送停止计费报文 |
User profile |
下发给用户的User Profile的名称 |
Send accounting update |
用户配额耗尽后是否发送获取新配额的计费更新报文: · Yes:发送 · No:不发送 |
ITA service policy |
采用的ITA业务策略 |
Service type |
ISP域的业务类型,取值为HSI,STB和VoIP |
Session time |
当用户异常下线时,设备上传到服务器的用户在线时间情况: · Include idle time:保留用户闲置切断时间 · Exclude idle time:扣除用户闲置切断时间 |
User address type |
用户地址类型 |
User basic service IP type |
用户主业务依赖的IP地址类型 · IPv4:IPv4地址类型 · IPv6:IPv6地址类型 · IPv6-PD:IPv6 PD前缀 |
DHCPv6-follow-IPv6CP timeout |
PPPoE/L2TP用户等待分配IPv6地址/PD的时间(单位为秒) |
Accounting start delay |
发送计费开始请求报文的延迟时间 若未配置,则不显示该字段 |
Dual-stack accounting method |
双协议栈用户的计费方式,包括以下取值: · Merge:统一计费,即将双协议栈用户的IPv4流量和IPv6流量统一汇总后上送给计费服务器 · Separate:分别计费,即将双协议栈用户的IPv4流量和IPv6流量分别上送给计费服务器 |
NAS-ID |
设备的NAS-ID 若未配置,则显示为N/A |
Service rate-limit mode |
EDSG业务流量限速模式,包括以下取值: · Merge:带内限速,即在用户可用总带宽内,对EDSG业务流量和普通业务流量同时限速,且优先保证EDSG业务带宽 · Separate:带外限速,即对EDSG业务流量进行独立限速,用户普通业务流量带宽不受影响 |
Web server IPv4 URL |
Web服务器的URL |
Web server IPv6 URL |
Web服务器的IPv6 URL |
Web server URL parameters |
Web服务器的URL携带的参数信息 |
format |
携带的MAC地址格式,其中3段式和6段式的分隔符可配,取值如下三例所示: · XXXXXXXXXXXX或xxxxxxxxxxxx:1段式 · XXXX-XXXX-XXXX或xxxx-xxxx-xxxx:3段式 · XX-XX-XX-XX-XX-XX或xx-xx-xx-xx-xx-xx:6段式 |
Web server IPv4 address |
Web服务器的IPv4地址 |
Web server IPv6 address |
Web服务器的IPv6地址 |
Redirect active time |
推送Web重定向URL的有效时长,单位为秒 |
Redirect server IPv4 address |
Web重定向页面的服务器IPv4地址 |
Redirect server IPv6 address |
Web重定向页面的服务器IPv6地址 |
Temporary redirect |
临时重定向功能,包括以下取值: · Enabled:处于开启状态 · Disabled:处于关闭状态 |
L2TP-user RADIUS-force |
RADIUS服务器授权L2TP用户功能,包括以下取值: · Enabled:处于开启状态,完全由RADIUS服务器决定用户是否为L2TP用户 · Disabled:处于关闭状态 |
Authorization attributes |
ISP的用户授权属性 |
Idle cut |
用户闲置切断功能,包括以下取值: · Enabled:处于开启状态,表示当ISP域中的用户在指定的最大闲置切断时间内产生的流量小于指定的最小数据流量时,会被强制下线 · Disabled:处于关闭状态,表示不对用户进行闲置切断控制,它为缺省状态 |
Idle timeout |
用户闲置切断时间(单位为分钟) |
Flow |
用户数据流量阈值(单位为字节) |
Traffic direction |
用户数据流量的统计方向,包括以下取值: · Both:表示用户双向数据流量 · Inbound:表示用户上行数据流量 · Outbound:表示用户下行数据流量 |
IP pool |
授权IPv4地址池的名称 |
IP pool group |
授权IPv4地址池组的名称 |
User profile |
授权User Profile的名称 |
Session group profile |
授权Session Group Profile的名称 |
Inbound CAR |
授权的入方向CAR(CIR:承诺信息速率,单位为bps;PIR:峰值信息速率,单位为bps)。若未授权入方向CAR,则显示为N/A |
Outbound CAR |
授权的出方向CAR(CIR:承诺信息速率,单位为bps;PIR:峰值信息速率,单位为bps)。若未授权出方向CAR,则显示为N/A |
ACL number |
授权ACL编号 |
User group |
授权User group的名称 |
IPv6 prefix |
授权IPv6前缀 |
IPv6 pool |
授权IPv6地址池的名称 |
IPv6 pool group |
授权IPv6地址池组的名称 |
IPv6 ND prefix pool |
授权ND前缀池的名称 |
IPv6 ND prefix pool group |
授权ND前缀池组的名称 |
Primary DNS server |
授权主DNS服务器IPv4地址 |
Secondary DNS server |
授权从DNS服务器IPv4地址 |
Primary DNSV6 server |
授权主DNS服务器IPv6地址 |
Secondary DNSV6 server |
授权从DNS服务器IPv6地址 |
URL |
授权重定向URL |
Redirect limit |
最大重定向次数,若不限制次数,则显示为Unlimited |
VPN instance |
授权VPN实例名称 |
IGMP access limit |
授权IPv4用户可以同时点播的最大节目数 |
MLD access limit |
授权IPv6用户可以同时点播的最大节目数 |
Inbound user priority |
授权上行用户优先级 |
Outbound user priority |
授权下行用户优先级 |
User session timeout |
授权用户会话超时时间,单位为秒 |
Dynamic authorization effective attributes |
通过COA授权该域时需要生效的授权属性 |
Authen-radius-unavailable |
RADIUS认证服务器不可达时,用户的逃生域 |
Authen-radius-recover |
逃生域中的用户,在RADIUS认证服务器恢复可达后,采取的策略,包括以下取值: · Offline:直接下线 · Online domain isp-name:保持在线,且用户切换到逃生恢复域 |
IP resource usage warning thresholds |
授权IPv4地址池/IPv4地址池组的地址使用率告警阈值 |
IPv6 resource usage warning thresholds |
授权IPv6地址和前缀使用率告警阈值 |
High threshold |
告警上限阈值,若未配置,则显示为Not configured |
Low threshold |
告警下限阈值,若未配置,则显示为Not configured |
Load-sharing user groups |
负载分担用户组及组内用户数目 |
User group and NAT instance bindings |
负载分担用户组(组内用户数目)以及当前该组绑定的NAT实例 |
Authorization attributes specific to none authentication |
采用none认证方法时的用户授权属性 |
Access limit per account (case-sensitive) |
单个帐号允许接入的最大用户数(用户名区分大小写) |
Access limit per account (case-insensitive) |
单个帐号允许接入的最大用户数(用户名不区分大小写) |
· display domain name
display user-group命令用来显示指定用户组的配置信息。
display user-group name group-name
name group-name:显示指定用户组的配置。group-name表示用户组名称,为1~32个字符的字符串,不区分大小写。
在通过bras compatible old-style-commands enable命令用开启了BRAS设备兼容旧风格命令功能的情况下,执行本命令将按照旧风格显示指定用户组的配置信息。有关BRAS设备兼容旧风格命令功能的详细介绍,请参考“BRAS业务配置指导”中的“UCM”。
# 旧风格显示指定用户组的相关配置。
<Sysname> display user-group name test
Total 1 user groups matched.
User group: test
Idle timeout: 2 minutes
Callback number: 2:2
Work directory: flash:/
ACL number: 2000
VLAN ID: 2
User profile: pp
SSL VPN policy group: policygroup1
Password aging: 2 days
表1-29 display user-group命令显示信息描述表
Total 1 user groups matched. |
总计有1个用户组匹配 |
授权属性信息 |
Idle timeout |
闲置切断时间(单位:分钟) |
Session-timeout |
本地用户的会话超时时间(单位为分钟) |
Callback number |
PPP回呼号码 |
Work directory |
FTP/SFTP/SCP用户可以访问的目录 |
ACL number |
授权ACL号 |
VLAN ID |
授权VLAN ID |
User profile |
授权User Profile名称 |
IP pool |
授权IPv4地址池 |
SSL VPN policy group |
授权SSL VPN策略组名称 |
IPv6 prefix |
授权IPv6前缀 |
IPv6 pool |
授权IPv6地址池 |
授权主DNS服务器IPv4地址 |
授权从DNS服务器IPv4地址 |
授权主DNS服务器IPv6地址 |
授权从DNS服务器IPv6地址 |
URL |
授权强制URL |
Subscriber ID |
授权Subscriber ID |
授权Session Group Profile名称 |
VPN instance |
授权VPN实例 |
Password control configurations |
用户组的密码控制属性 |
Password aging |
密码老化时间 |
Password length |
密码最小长度 |
Password composition |
密码组合策略(密码元素的组合类型、至少要包含每种元素的个数) |
Password complexity |
密码复杂度检查策略(是否包含用户名或者颠倒的用户名;是否包含三个或以上相同字符) |
Maximum login attempts |
用户最大登录尝试次数 |
Action for exceeding login attempts |
登录尝试次数达到设定次数后的用户账户锁定行为 |
bras compatible old-style-commands enable(BRAS业务命令参考/UCM)
