01-WLAN接入命令
本章节下载: 01-WLAN接入命令 (731.02 KB)
1.1.8 client association-location
1.1.9 client behavior-local network-flow-forwarding enable
1.1.10 client forwarding-location
1.1.11 client forwarding-policy enable
1.1.12 client forwarding-policy-name
1.1.16 client keep-alive interval
1.1.18 client preferred-vlan authorized
1.1.19 client report-mandatory
1.1.20 client smart-access enable
1.1.23 client-statistics-report
1.1.24 client-statistics-report smart-maintenance
1.1.27 display wlan ap all client-number
1.1.28 display wlan ap all radio client-number
1.1.29 display wlan ap-group all client-number
1.1.33 display wlan client device-information
1.1.34 display wlan client ipv6
1.1.35 display wlan client online-duration
1.1.36 display wlan client status
1.1.37 display wlan forwarding-policy
1.1.38 display wlan guest-tunnel
1.1.39 display wlan lite-control-mode status
1.1.40 display wlan service-template
1.1.41 display wlan statistics client
1.1.42 display wlan statistics connect-history
1.1.43 display wlan statistics service-template
1.1.44 display wlan statistics vip-client
1.1.45 display wlan virtual-ap-group all client-number
1.1.48 inherit exclude service-template
1.1.55 qinq ethernet-type service-tag
1.1.56 quick-association enable
1.1.59 reset wlan dynamic-blacklist
1.1.60 reset wlan guest-tunnel
1.1.61 reset wlan statistics client
1.1.62 reset wlan statistics service-template
1.1.65 service-template enable
1.1.66 snmp-agent trap enable wlan client
1.1.67 snmp-agent trap enable wlan client-audit
1.1.73 wlan apply accounting-policy
1.1.74 wlan association optimization
1.1.75 wlan client bss-load-ie enable
1.1.76 wlan client forwarding enable
1.1.77 wlan client forwarding-policy-name
1.1.78 wlan client reauthentication-period
1.1.79 wlan dynamic-blacklist active-on-ap
1.1.80 wlan dynamic-blacklist lifetime
1.1.83 wlan guest-tunnel flow-distribute enable
1.1.86 wlan lite-control-mode enable
1.1.87 wlan management-wifi ssid-hide
1.1.88 wlan nas-port-id format
1.1.92 wlan static-blacklist mac-address
1.1.94 wlan web-server api-path
· 由于WX1800H系列、WX2500H系列、MAK系列和WX3000H系列无线控制器不支持IRF功能,因此不支持IRF模式的命令行配置。
· 本手册中的AP型号和序列号仅为举例,具体支持的AP型号和序列号请以设备的实际情况为准。
access-control acl命令用来配置基于ACL的接入控制。
undo access-control acl命令用来恢复缺省情况。
access-control acl acl-number
未配置基于ACL的接入控制。
无线服务模板视图
AP视图
acl-number:二层ACL的编号,取值范围为4000~4999。
基于ACL的接入控制是指设备根据指定ACL中配置的规则对新接入的无线客户端进行接入控制。
当无线客户端接入无线网络时,设备会判断无线客户端的MAC地址是否在ACL访问控制列表的规则中,具体的过滤机制如下:
· 如果在permit规则中,则允许无线客户端接入无线网络;
· 如果在deny规则中,则拒绝无线客户端接入无线网络;
· 如果未匹配任何已配置的规则,则拒绝其接入。
设备支持MAC地址匹配和OUI匹配。当ACL访问控制列表中存在OUI匹配时,只要客户端与OUI匹配,就可以接入网络。
需要注意的是,当在ACL中配置deny规则来拒绝指定客户端接入时,请在deny规则之后配置允许所有客户端接入的permit规则,否则会导致所有客户端无法接入。
基于ACL的接入控制的优先级高于基于名单的接入控制的优先级。当设备上没有配置无线客户端访问控制规则时,按照基于名单的接入控制规则对无线客户端进行访问控制。
多次执行本命令,最后一次执行的命令生效。
AP视图下配置的优先级高于无线服务模板视图下的配置。
# 在无线服务模板下,配置基于ACL的接入控制为4000,仅允许MAC地址为000e-35b2-000e以及匹配OUI控制方式的无线客户端接入。(无线服务模板视图)
[Syname] acl mac 4000
[Syname-acl-mac-4000] rule 0 permit source-mac 000e-35b2-000e ffff-ffff-ffff
[Syname-acl-mac-4000] rule 1 permit source-mac 000e-35b2-000f ffff-ff00-0000
[Syname-acl-mac-4000] rule 2 deny
[Syname-acl-mac-4000] quit
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] access-control acl 4000
# 在ap1上,配置基于ACL的接入控制为4000,仅允许MAC地址为000e-35b2-000e以及匹配OUI控制方式的无线客户端接入。(AP视图)
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] access-control acl 4000
accounting-level命令用来指定需要进行计费的流量计费级别。
undo accounting-level命令用来删除需要进行计费的计费级别。
accounting-level level acl { acl-number | ipv6 ipv6-acl-number }
undo accounting-level level
未指定需要进行计费的流量计费级别。
计费策略视图
level:流量计费级别,取值范围为1~8。
acl-number:IPv4 ACL的编号,取值范围为3000~3999。
ipv6 ipv6-acl-number:IPv6 ACL的编号,取值范围为3000~3999。
计费策略仅识别ACL规则中的匹配条件,不识别允许和拒绝操作,即只要是匹配条件的报文,无论在ACL规则中是被允许还是被拒绝,都会被按计费策略处理。其中,计费策略不识别ACL规则中的源地址这个匹配条件。对于从AP接收的无线报文,ACL规则匹配报文目的地址,从AP发送的无线报文,ACL规则匹配报文源地址。
# 在计费策略视图abc中,指定需要进行计费的流量计费级别为1并匹配ACL 3000。
[Sysname] wlan accounting-policy abc
[Sysname-wlan-acctpolicy-abc] accounting-level 1 acl 3000
· wlan accounting-policy
aggregation-ac命令用来配置汇聚AC信息。
undo aggregation-ac命令用来删除汇聚AC信息。
aggregation-ac ip ipv4-address tunnel-source ip ipv4-address vlan vlan-id-list
undo aggregation-ac { all | ip ipv4-address [ vlan vlan-id-list ] }
本命令的支持情况与设备型号有关,请以设备的实际情况为准。
| 产品系列 | 产品型号 | 产品代码 | 说明 |
| WX1800H系列 | WX1804H-PWR | EWP-WX1804H-PWR-CN | 支持 |
| WX2500H系列 | WX2508H-PWR-LTE WX2510H-PWR WX2510H-F-PWR WX2540H WX2540H-F WX2560H | EWP-WX2508H-PWR-LTE EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H | 支持 |
| MAK系列 | MAK204 MAK206 | EWP-MAK204 EWP-MAK206 | 支持 |
| WX3000H系列 | WX3010H WX3010H-X-PWR WX3010H-L-PWR WX3024H WX3024H-L-PWR WX3024H-F | EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F | 不支持 |
| WX3500H系列 | WX3508H WX3508H WX3510H WX3510H WX3520H WX3520H-F WX3540H WX3540H | EWP-WX3508H EWP-WX3508H-F EWP-WX3510H EWP-WX3510H-F EWP-WX3520H EWP-WX3520H-F EWP-WX3540H EWP-WX3540H-F | 支持 |
| WX5500E系列 | WX5510E WX5540E | EWP-WX5510E EWP-WX5540E | 支持 |
| WX5500H系列 | WX5540H WX5560H WX5580H | EWP-WX5540H EWP-WX5560H EWP-WX5580H | 支持 |
| AC插卡系列 | LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F | LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F | 不支持 |
| WX1800H系列 | WX1804H-PWR WX1810H-PWR WX1820H WX1840H | EWP-WX1804H-PWR EWP-WX1810H-PWR EWP-WX1820H EWP-WX1840H-GL | 不支持 |
| WX3800H系列 | WX3820H WX3840H | EWP-WX3820H-GL EWP-WX3840H-GL | 不支持 |
| WX5800H系列 | WX5860H | EWP-WX5860H-GL | 不支持 |
未配置汇聚AC信息。
边缘AC视图
ip ipv4-address:汇聚AC的IPv4地址。
tunnel-source ip ipv4-address:访客隧道的源IPv4地址,即边缘AC将使用该地址与汇聚AC建立访客隧道。
vlan vlan-id-list:访客VLAN列表,表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>,vlan-id取值范围为1~4094,&<1-10>表示前面的参数最多可以重复输入10次。
all:指定所有汇聚AC的信息。
每个边缘AC可以与汇聚AC建立多条访客隧道,每个访客隧道必须属于不同的VLAN。
每个边缘AC可以与同一个汇聚AC建立多条隧道,但必须使用不同的源接口IP地址和该汇聚AC的不同接口IP地址建立访客隧道。
当配置的多个不同汇聚AC地址属于同一台AC时,汇聚AC使用接收到的第一个保活请求报文的IP地址与边缘AC建立隧道。
# 在源IPv4地址为192.168.2.20的边缘AC上指定汇聚AC的IPv4地址为192.168.2.21,访客VLAN为VLAN 7。
[Sysname] wlan guest-tunnel edge-ac
[Sysname-wlan-edge-ac] aggregation-ac ip 192.168.2.21 tunnel-source ip 192.168.2.20 vlan 7
· edge-ac
· keep-alive interval
beacon ssid-advertise命令用来配置在信标帧中通告SSID。
undo beacon ssid-advertise命令用来恢复缺省情况。
信标帧不强制通告SSID。
无线服务模板视图
当射频或无线服务模板下关联的客户端数目达到最大值时,AP会在Beacon帧中隐藏SSID信息,导致客户端无法发现并关联AP,配置本命令可以强制AP在Beacon帧中通告SSID信息,使客户端可以发现AP,但无法进行关联。
# 配置在信标帧中通告SSID。
[Sysname-wlan-st-s1] beacon ssid-advertise
· client max-count
beacon ssid-hide命令用来配置在信标帧中隐藏SSID,即不通告SSID。
undo beacon ssid-hide命令用来恢复缺省情况。
beacon ssid-hide
信标帧不隐藏SSID。
无线服务模板视图
服务模板配置SSID隐藏,即将无线服务模板绑定到某个射频后,该射频发送的Beacon帧将不携带SSID信息,而且不回复广播Probe Request帧。
# 配置在信标帧中隐藏SSID。
[Sysname-wlan-st-service1] beacon ssid-hide
broadcast-probe reply enable命令用来开启AP回复广播Probe request报文功能。
broadcast-probe reply disable命令用来关闭AP回复广播Probe request报文功能。
undo broadcast-probe reply命令用来恢复缺省情况。
broadcast-probe reply { disable | enable [ rssi-threshold rssi-value ] } [ frequency-band { 2.4 | 5 } ]
AP视图:继承AP组配置。
AP组视图:AP回复所有工作频段的客户端的广播Probe request报文。
AP视图
AP组视图
rssi-threshold rssi-value:AP只回复RSSI值高于指定RSSI门限值的客户端的广播Probe request报文。rssi-value为RSSI门限值,取值范围为1~100。若不指定该参数,则表示回复所有RSSI值的客户端的广播Probe request报文。
frequency-band:开启或关闭AP回复指定工作频段的客户端的广播Probe request报文功能。若不指定该参数,则表示开启或关闭AP回复所有工作频段的客户端的广播Probe request报文功能。
2.4:工作频段为2.4GHz。
5:工作频段为5GHz。
广播Probe request报文中不携带服务的SSID。AP收到该广播报文后,将AP提供的所有服务的信息封装在Probe response报文中,回应给客户端。
关闭AP回复广播Probe request报文功能,可以减少AP回复的Probe response报文。但是,如果AP不回复所有客户端的广播Probe request报文,则可能会导致终端无法漫游,长时间关联在信号比较弱的AP上。可以通过配置RSSI门限值引导客户端关联到信号比较强的AP上,同时又可以减少AP回复的Probe response报文。
通过本命令还可以配置AP仅回复指定工作频段的客户端的广播Probe request报文。例如,关闭AP回复2.4GHz工作频段的客户端的广播Probe request报文功能,并开启AP回复5GHz工作频段的客户端的广播Probe request报文功能,可以引导客户端关联到AP的5GHz射频。
AP视图下配置的优先级高于AP组视图下的配置。
# 在ap1上关闭AP回复所有工作频段的客户端的广播Probe request报文功能。(AP视图)
[Sysname-wlan-ap-ap1] broadcast-probe reply disable
# 在AP组上关闭AP回复所有工作频段的客户端的广播Probe request报文功能。(AP组视图)
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] broadcast-probe reply disable
classifier acl命令用来配置无线转发规则。
undo classifier acl用来删除指定的无线转发规则。
classifier acl { acl-number | ipv6 ipv6-acl-number } behavior { local | remote }
undo classifier acl { acl-number | ipv6 ipv6-acl-number }
| WX3000H系列 | WX3010H WX3010H-X-PWR WX3010H-L-PWR WX3024H WX3024H-L-PWR WX3024H-F | EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F | WX3010H支持 WX3010H-X-PWR支持 WX3010H-L-PWR不支持 WX3024H支持 WX3024H-L-PWR不支持 WX3024H-F支持 |
| AC插卡系列 | LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F | LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F | 支持 |
| WX1800H系列 | WX1804H-PWR WX1810H-PWR WX1820H WX1840H | EWP-WX1804H-PWR EWP-WX1810H-PWR EWP-WX1820H EWP-WX1840H-GL | 支持 |
| WX3800H系列 | WX3820H WX3840H | EWP-WX3820H-GL EWP-WX3840H-GL | 支持 |
| WX5800H系列 | WX5860H | EWP-WX5860H-GL | 支持 |
未配置无线转发规则。
转发策略视图
acl-number:IPv4 ACL及二层ACL的编号,取值范围为2000~4999。
ipv6 ipv6-acl-number:IPv6 ACL的编号,取值范围为2000~3999。
behavior:配置对匹配ACL规则的客户端数据所执行的转发方式。
local:表示本地转发。
remote:表示集中式转发。
无线转发策略仅识别ACL规则中的匹配条件,不识别允许和拒绝操作,即只要是匹配条件的报文,无论在ACL规则中是被允许还是被拒绝,都会被按转发策略处理。
无线转发规则在配置后将立即生效。
一个无线转发策略中最多可以配置1000条无线转发规则。
# 在无线转发策略abc中配置无线转发规则,对匹配ACL 2000的客户端数据报文进行本地转发。
<sysname> system-view
[sysname] wlan forwarding-policy abc
[sysname-wlan-fp-abc] classifier acl 2000 behavior local
client association-location命令用来配置客户端的关联位置。
undo client association-location命令用来恢复缺省情况。
client association-location { ac | ap }
客户端的关联位置在AC上。
无线服务模板视图
ac:客户端关联位置在AC上。
ap:客户端关联位置在AP上。
本命令只能在无线服务模板处于关闭状态时配置。
# 配置客户端的关联位置在AC上。
[Sysname-wlan-st-service1] client association-location ac
client behavior-local network-flow-forwarding enable命令用来开启本地转发模式下的外网流量转发功能。
undo client behavior-local network-flow-forwarding enable命令用来关闭本地转发模式下的外网流量转发功能。
本地转发模式下的外网流量转发功能处于关闭状态。
无线转发策略视图
当客户端需要访问外网,但客户端数据报文转发位置又在AP上时,需要开启本功能。
开启本功能后,设备会将客户端数据报文中的目的地址替换成AP的MAC地址,再通过NAT地址转换功能,将客户端数据报文的源地址自动转换成和AP同网段的IP地址。完成以上配置后,客户端可以正常访问外网,否则,访问外网的报文将被AP丢弃。
本功能需要与支持NAT功能的AP配合使用。
# 开启本地转发模式下的外网流量转发功能。
[Sysname] wlan forwarding-policy abc
[Sysname-wlan-fp-abc] client behavior-local network-flow-forwarding enable
· wlan forwarding-policy
client forwarding-location命令用来配置客户端数据报文的转发位置。
undo client forwarding-location命令用来恢复缺省情况。
client forwarding-location { ac | ap [ vlan { start-vlan [ to end-vlan ] } ] }
本命令的缺省情况与设备型号有关,请以设备的实际情况为准。
| WX1800H系列 | WX1804H-PWR | EWP-WX1804H-PWR-CN | 客户端数据报文的转发位置在AC上 |
| WX2500H系列 | WX2508H-PWR-LTE WX2510H-PWR WX2510H-F-PWR WX2540H WX2540H-F WX2560H | EWP-WX2508H-PWR-LTE EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H | 客户端数据报文的转发位置在AC上 |
| MAK系列 | MAK204 MAK206 | EWP-MAK204 EWP-MAK206 | 客户端数据报文的转发位置在AC上 |
| WX3000H系列 | WX3010H WX3010H-X-PWR WX3010H-L-PWR WX3024H WX3024H-L-PWR WX3024H-F | EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F | WX3010H客户端数据报文转发位置在AC上 WX3010H-X-PWR客户端数据报文转发位置在AC上 WX3010H-L-PWR客户端数据报文转发位置在AP上 WX3024H客户端数据报文转发位置在AC上 WX3024H-L-PWR客户端数据报文转发位置在AP上 WX3024H-F客户端数据报文转发位置在AC上 |
| WX3500H系列 | WX3508H WX3508H WX3510H WX3510H WX3520H WX3520H-F WX3540H WX3540H | EWP-WX3508H EWP-WX3508H-F EWP-WX3510H EWP-WX3510H-F EWP-WX3520H EWP-WX3520H-F EWP-WX3540H EWP-WX3540H-F | 客户端数据报文的转发位置在AC上 |
| WX5500E系列 | WX5510E WX5540E | EWP-WX5510E EWP-WX5540E | 客户端数据报文的转发位置在AC上 |
| WX5500H系列 | WX5540H WX5560H WX5580H | EWP-WX5540H EWP-WX5560H EWP-WX5580H | 客户端数据报文的转发位置在AC上 |
| AC插卡系列 | LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F | LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F | 客户端数据报文的转发位置在AC上 |
| WX1800H系列 | WX1804H-PWR WX1810H-PWR WX1820H WX1840H | EWP-WX1804H-PWR EWP-WX1810H-PWR EWP-WX1820H EWP-WX1840H-GL | 客户端数据报文的转发位置在AC上 |
| WX3800H系列 | WX3820H WX3840H | EWP-WX3820H-GL EWP-WX3840H-GL | 客户端数据报文的转发位置在AC上 |
| WX5800H系列 | WX5860H | EWP-WX5860H-GL | 客户端数据报文的转发位置在AC上 |
无线服务模板视图
ac:配置客户端数据报文的转发位置在AC上。
本参数的支持情况与设备型号有关,请以设备的实际情况为准。
ap:配置客户端数据报文的转发位置在AP上。
vlan start-vlan to end-vlan:配置指定VLAN的客户端在AP上转发数据报文。start-vlan表示指定VLAN的起始编号,取值范围为1~4094。end-vlan表示指定VLAN的结束编号,取值范围为1~4094。如果未指定本参数,表示所有VLAN的客户端数据报文的转发位置都在AP上。
若配置客户端数据报文转发位置在AC上,则需要保证客户端数据报文转发功能处于开启状态,否则配置不生效。
# 配置无线客户端的数据报文转发位置在AP上。
[Sysname-wlan-st-service1] client forwarding-location ap
client forwarding-policy enable命令用来开启无线转发策略功能。
undo client forwarding-policy enable命令用来关闭无线转发策略功能。
无线转发策略功能处于关闭状态。
无线服务模板视图
只有开启了无线转发策略功能后,无线服务模板或User Profile上应用的无线转发策略才会在该服务模板生效,AP会对关联到该服务模板的客户端流量应用无线转发策略。
# 在无线服务模板下开启无线转发策略功能。
[Sysname-wlan-st-service1] client forwarding-policy enable
· client-security authentication-location
client forwarding-policy-name命令用来在无线服务模板下应用无线转发策略。
undo client forwarding-policy-name命令用来恢复缺省状态。
client forwarding-policy-name policy-name
无线服务模板下未应用无线转发策略。
无线服务模板视图
policy-name:无线转发策略的名称,为1~31个字符的字符串,不区分大小写。
当配置无线转发策略时,AC和AP必须处于不同网段中。
只有服务模板处于关闭的情况下,才能够应用或取消应用的无线转发策略。
需要在无线服务模板上开启无线转发策略功能并且配置用户接入认证位置在AC上,无线服务模板下应用的无线转发策略才会生效。
# 在无线服务模板下应用名称为strategy的无线转发策略。
[Sysname-wlan-st-service1] client forwarding-policy-name strategy
· client forwarding-policy enable
client frame-format命令用来配置客户端数据报文在CAPWAP隧道中的封装格式。
undo client frame-format命令用来恢复缺省情况。
client frame-format { dot3 | dot11 }
客户端数据报文在CAPWAP隧道中的封装格式为802.3格式。
无线服务模板视图
dot3:客户端数据报文在CAPWAP隧道中的封装格式为802.3格式。
dot11:客户端数据报文在CAPWAP隧道中的封装格式为802.11格式。
只有在集中式转发架构下配置客户端数据报文封装格式才生效。
# 配置客户端数据报文在CAPWAP隧道中的封装格式为802.11格式。
[Sysname-wlan-st-service1] client frame-format dot11
· client forwarding-location
client idle-timeout命令用来配置AP和客户端之间连接允许的最大空闲时间。
undo client idle-timeout命令用来恢复缺省情况。
client idle-timeout timeout
AP视图:继承AP组配置。
AP组视图:AP和客户端之间连接允许的最大空闲时间为3600秒。
AP视图
AP组视图
timeout:AP和客户端之间连接允许的最大空闲的时间间隔,取值范围为60~86400,单位为秒。
当客户端处于空闲状态,即客户端与AP无任何报文交互,当达到最大空闲时间时,AP会自动与客户端断开连接。
# 设置AP和客户端之间连接允许的最大空闲时间为2000秒。(AP视图)
[sysname] wlan ap ap1 model WA6320
[sysname-wlan-ap-ap1] client idle-timeout 2000
# 设置AP和客户端之间连接允许的最大空闲时间为2000秒。(AP组视图)
[Sysname-wlan-ap-group-group1] client idle-timeout 2000
client keep-alive enable命令用来开启客户端保活功能。
client keep-alive disable命令用来关闭客户端保活功能。
undo client keep-alive命令用来恢复缺省情况。
client keep-alive { disable | enable }
AP视图:继承AP组配置。
AP组视图:客户端保活功能处于关闭状态。
AP视图
AP组视图
disable:关闭客户端保活功能。
enable:开启客户端保活功能。
保活机制通常用来检测客户端是否在线。导致客户端异常离线原因有电源故障、系统崩溃等。
AP会定期给客户端发送保活报文,以确认其是否在线。如果在保活时间内未收到客户端回应的应答报文,则断开与客户端的连接。
# 开启客户端保活功能。(AP视图)
[Sysname-wlan-ap-ap1] client keep-alive enable
# 开启AP组客户端保活功能。(AP组视图)
[Sysname-wlan-ap-group-group1] client keep-alive enable
· client keep-alive interval
client keep-alive interval命令用来配置客户端保活时间。
undo client keep-alive interval命令用来恢复缺省情况。
client keep-alive interval interval
AP视图:继承AP组配置。
AP组视图:客户端保活时间为300秒。
AP视图
AP组视图
interval:向客户端发送保活报文的时间间隔,取值范围为3~1800,单位为秒。
保活机制通常用来断开与长期未响应的客户端的连接,释放资源。导致客户端异常离线原因有电源故障、系统崩溃等。
AP会定期给客户端发送保活报文,以确认其是否在线。如果在三个保活时间内未收到客户端回应的应答报文,则断开与客户端的连接。
保活时间间隔小于10秒时,部分终端在线不稳定,建议配置保活时间间隔大于10秒。
配置本命令前,必须先开启客户端保活功能。
# 设置AP客户端保活时间为20秒。(AP视图)
[Sysname-wlan-ap-ap1] client keep-alive interval 20
# 配置AP组客户端保活时间为20秒。(AP组视图)
[Sysname-wlan-ap-group-group1] client keep-alive interval 20
· client keep-alive enable
client max-count命令用来配置单个射频下单个无线服务模板允许关联的最大客户端数目。
undo client max-count命令用来恢复缺省情况。
client max-count max-number
不限制无线服务模板允许关联的最大客户端数目。
无线服务模板视图
max-number:单个射频下单个无线服务模板所允许关联的最大客户端数目,取值范围为1~512。
射频下单个无线服务模板上关联的客户端数达到允许关联的最大客户端数目后,将不再接受新的客户端接入且SSID会自动隐藏。
# 配置单个射频下单个无线服务模板允许关联的最大客户端数目为38。
[Sysname-wlan-st-service1] client max-count 38
· beacon ssid-hide
client preferred-vlan authorized命令用来配置客户端优先使用授权VLAN。
undo client preferred-vlan authorized命令用来配置客户端优先使用漫游VLAN。
客户端优先使用授权VLAN。
无线服务模板视图
该配置只对采用802.1X或MAC地址认证方式上线的无线客户端生效。
AC为客户端选择VLAN的优先级从高到低依次为:授权VLAN(授权服务器下发的VLAN或者iMC安全策略服务器下发的VLAN)、漫游VLAN(漫游表项中记录的VLAN)、初始VLAN(无线服务模板绑定的VLAN)。
客户端上线时,如果客户端进行漫游,由于授权VLAN的优先级高于漫游VLAN,此时如果iMC安全策略服务器配置了安全策略,客户端执行了iMC安全策略中对其的限制操作进而触发安全告警时,iMC安全策略服务器重新下发的用于隔离客户端的授权VLAN将生效。例如,iMC安全策略服务器设置了一个安全策略,不允许使用客户端的计算器功能。如果打开计算器功能就会触发安全告警,iMC安全策略服务器重新下发的授权VLAN无法生效。
关闭本功能后,客户端将优先使用漫游VLAN,当iMC安全策略服务器对客户端下发授权VLAN时,授权VLAN不生效。
# 配置客户端优先使用授权VLAN。
[Sysname-wlan-st-service1] client preferred-vlan authorized
client report-mandatory命令用来开启仅本地认证无线客户端信息上报成功才允许客户端上线功能。
undo client report-mandatory命令用来关闭仅本地认证无线客户端信息上报成功才允许客户端上线功能。
仅本地认证无线客户端信息上报成功才允许客户端上线功能处于开启状态。
无线服务模板视图
对于本地认证的无线客户端,客户端认证完成后,AP会上报客户端信息给AC,由AC创建客户端表项并通知AP允许客户端上线。若CAPWAP隧道异常,则客户端信息上报失败,客户端上线失败。
关闭仅本地认证无线客户端信息上报成功才允许客户端上线功能后,当CAPWAP隧道异常时,允许通过本地认证的客户端在AP上线。此时AP可以为客户端转发数据并提供接入功能。当CAPWAP隧道恢复正常后,AP会同步已上线客户端信息给AC。
# 关闭仅本地认证无线客户端信息上报成功才允许客户端上线功能。
[Sysname-wlan-st-service1] undo client report-mandatory
client smart-access enable命令用来开启无线客户端智能接入功能。
undo client smart-access enable命令用来恢复缺省情况。
无线客户端智能接入功能处于关闭状态。
无线服务模板视图
对于某些物联网应用场景,用户希望我司配套的无线客户端产品能自动发现并连接当前网络中的缺省SSID。开启本功能后,可以在仅创建无线服务模板或身份认证与密钥管理模式配置为PSK的情况下,自动将我司配套的无线客户端接入到无线网络。
# 在无线服务模板视图下,开启无线客户端智能接入功能。
[Sysname-wlan-st-service1] client smart-access enable
client vlan-alloc命令用来配置客户端的VLAN分配方式。
undo client vlan-alloc命令用来恢复缺省情况。
client vlan-alloc { dynamic | static | static-compatible }
客户端的VLAN分配方式为动态分配方式。
无线服务模板视图
dynamic:表示动态分配方式。
static:表示静态分配方式。
static-compatible:表示静态兼容分配方式。
| WX3000H系列 | WX3010H WX3010H-X-PWR WX3010H-L-PWR WX3024H WX3024H-L-PWR WX3024H-F | EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F | 支持 |
客户端首次上线时,AP会为动态分配方式下的客户端随机分配无线服务模板绑定Radio时指定的VLAN组内的一个VLAN,根据客户端的MAC地址为静态分配、静态兼容分配方式下的客户端分配VLAN。客户端再次上线时被分配的VLAN将由配置的VLAN分配方式决定:
· 静态分配方式下,直接继承上次VLAN组分配的VLAN。若客户端的IP地址在租约内,仍为客户端分配同一个IP地址。采用该分配方式,可以减少IP地址的消耗。
· 动态分配方式下,VLAN组再次随机为客户端分配VLAN。采用该分配方式,客户端会被均衡地分配在VLAN组的所有VLAN中。
· 静态兼容分配方式下,可以保证客户端在采用静态分配方式的ComwareV5版本AC设备与ComwareV7版本的AC之间漫游时,被分配相同的VLAN。
# 配置客户端的VLAN分配方式为动态分配方式。
[Sysname-wlan-st-service1] client vlan-alloc dynamic
· service-template
client-mac命令用来添加客户端的MAC地址。
undo client-mac命令用来删除客户端的MAC地址。
client-mac mac-address [ level level ]
undo client-mac mac-address
未添加客户端的MAC地址。
VIP客户端组视图
mac-address:客户端的MAC地址,形式为H-H-H。每段中的前导“0”可以省略。
level level:VIP客户端的级别。取值范围为1~2,缺省值为1。
通过本命令,可以添加已上线和未上线客户端到VIP客户端组,最多可以添加128个level 1级别的客户端,对于level 2级别的客户端没有数量限制。
VIP客户端分为两个级别,其中level 1是默认的最高级别,即不对VIP客户端限速。
当Radio下的客户端接入数达到最大值后:
· 新的非VIP客户端无法上线。
· 新的VIP客户端会以挤占当前已在线客户端资源的方式上线:
¡ Level 1的VIP客户端优先级最高,会首先将非VIP客户端踢下线后上线,如果当前不存在非VIP客户端,则会将Level 2的VIP客户端踢下线后上线。
¡ Level 2的VIP客户端优先级次之,会将非VIP客户端踢下线后上线。
¡ 如果所有客户端均为Level 1的VIP客户端,则新的客户端将无法上线。
仅当客户端的关联位置在AC上时,VIP客户端功能才会生效。
# 在VIP客户端组视图下,添加需监控客户端的MAC地址为a0cc-2bca-a305。
[Sysname] wlan vip-client-group
[Sysname-wlan vip-client-group] client-mac a0cc-2bca-a305
client-statistics-report enable命令用来开启AP向AC上报无线客户端统计信息功能。
client-statistics-report disable命令用来关闭AP向AC上报无线客户端统计信息功能。
undo client-statistics-report命令用来恢复缺省情况。
client-statistics-report { disable | enable [ interval interval ] }
AP视图:继承AP组配置。
AP组视图:AP向AC上报客户端统计信息功能处于开启状态。
AP视图
AP组视图
interval interval:AP向AC上报无线客户端统计信息的时间间隔,取值范围为2~120,单位为秒,缺省值为50。
为了对无线客户端的状态进行有效的监控,通过开启本功能,AP会周期性的向AC上报客户端统计信息。AC接收到客户端统计信息后会对本地客户端表项进行更新,未与本地客户端表项匹配上的客户端将被强制下线。当用户网络状况较差时,请关闭本功能,AP会停止上报客户端统计信息且AC不在更新本地客户端表项,客户端正常在线。
# 开启AP向AC上报客户端统计信息功能,并配置AP向AC上报客户端统计信息的时间间隔为20秒。(AP视图)
[Sysname-wlan-ap-ap1] client-statistics-report enable interval 20
# 开启AP向AC上报客户端统计信息功能,并配置AP向AC上报客户端统计信息的时间间隔为20秒。(AP组视图)
[Sysname-wlan-ap-group-group1] client-statistics-report enable interval 20
client-statistics-report smart-maintenance enable命令用来开启AP向AC上报无线客户端智能运维统计信息功能。
client-statistics-report smart-maintenance disable命令用来关闭AP向AC上报无线客户端智能运维统计信息功能。
undo client-statistics-report smart-maintenance命令用来恢复缺省情况。
client-imstatistics-report smart-maintenance { disable | enable }
undo client-imstatistics-report smart-maintenance
AP视图:继承AP组配置。
AP组视图:AP向AC上报无线客户端智能运维统计信息功能处于开启状态。
AP视图
AP组视图
开启本功能后,AP会按client-statistics-report命令配置的时间间隔周期性的向AC上报无线客户端智能运维统计信息,AC会将统计信息上报给云平台,用户可以在云平台智能运维页面查看上报的无线客户端相关统计信息。当用户网络状况较差时,请关闭本功能,AP将停止上报无线客户端智能运维统计信息且AC不再向云平台上报该部分统计信息。
因为VIP客户端功能需要使用到部分无线客户端智能运维统计信息,因此当使用VIP客户端功能时,本功能需要处于开启状态。
# 开启AP向AC上报客户端的智能运维相关统计信息的功能。(AP视图)
[Sysname-wlan-ap-ap1] client-statistics-report smart-maintenance enable
# 开启AP向AC上报客户端的智能运维相关统计信息的功能。(AP组视图)
[Sysname-wlan-ap-group-group1] client-statistics-report smart-maintenance enable
· client-statistics-report
customlog format wlan命令用来配置客户端上线日志的格式。
undo customlog format wlan命令用来恢复缺省情况。
customlog format wlan { normal | sangfor }
输出H3C格式的客户端上线日志。
normal:指定日志格式为normal格式。
sangfor:指定日志格式为sangfor格式。
配置本功能后,设备支持同时输出H3C格式和指定格式的客户端上线日志信息。
· H3C格式的日志内容主要包含客户端上线的AP名称、Radio ID、客户端MAC地址、关联的SSID、BSSID及客户端的上线状态变化。
· 指定格式的日志有两种类型。
¡ normal格式:日志内容为客户端上线的AP的MAC地址、AP名称、客户端IP地址、客户端MAC地址、关联的SSID及BSSID。
¡ sangfor格式:日志内容为客户端上线的AP的MAC地址、客户端IP地址和客户端MAC地址。
# 配置客户端上线日志的格式为sangfor格式。
[Sysname] customlog format wlan sangfor
description命令用来配置无线服务模板的描述信息。
undo description命令用来恢复缺省情况。
未配置无线服务模板的描述信息。
无线服务模板视图
text:无线服务模板的描述信息,为1~64个字符的字符串,区分大小写。
# 配置无线服务模板service1的描述信息为wlanst。
[Sysname-wlan-st-service1] description wlanst
display wlan ap all client-number命令用来显示AP上2.4GHz及5GHz频段的在线客户端数量。
# 显示AP上2.4GHz及5GHz频段的在线客户端数量。
<System> display wlan ap all client-number
AP name Clients 2.4GHz 5GHz
ap1 2 2 0
表1-1 display wlan ap clients-number命令显示信息描述表
| 字段 | 描述 |
| AP name | AP名称 |
| Clients | AP上所有在线客户端数量 |
| 2.4GHz | AP上2.4GHz频段的在线客户端数量 |
| 5GHz | AP上5GHz频段的在线客户端数量 |
display wlan ap all radio client-number命令用来显示AP的所有Radio接口下在线客户端数量和信道信息。
# 显示AP的所有Radio接口下在线客户端数量和信道信息。
<Sysname> display wlan ap all radio client-number
AP name RID Channel Clients
ap1 1 44 12
ap1 2 11 4
表1-2 display wlan ap all radio client-number命令显示信息描述表
| 字段 | 描述 |
| AP name | AP名称 |
| RID | 射频ID |
| Channel | 射频工作信道 |
| Clients | 在线客户端数量 |
display wlan ap-group all client-number命令用来显示所有AP组内在线客户端数量。
# 显示所有AP组内在线客户端数量。
<Sysname> display wlan ap-group all client-number
AP group name Group ID Clients 2.4GHz 5GHz
default-group 1 150 100 50
1 2 250 50 200
表1-3 display wlan ap-group client-number命令显示信息描述表
| 字段 | 描述 | |
| AP group name | AP组名称 | |
| Group ID | AP组的ID号,用于在AC上唯一标识一个AP组 | |
| Clients | AP组内所有在线客户端数量 | |
| 2.4GHz | AP组内2.4GHz频段的在线客户端数量 | |
| 5GHz | AP组内5GHz频段的在线客户端数量 |
display wlan blacklist命令用来显示黑名单。
display wlan blacklist { dynamic | static }
dynamic:显示动态黑名单。
static:显示静态黑名单。
# 显示静态黑名单。
<Sysname> display wlan blacklist static
Total number of clients: 3
MAC addresses:
000e-35b2-000e
0019-5b8e-b709
001c-f0bf-9c92
表1-4 display wlan blacklist static命令显示信息描述表
| 字段 | 描述 |
| Total number of clients | 静态黑名单中的客户端数量 |
| MAC addresses | 黑名单列表中的客户端MAC地址 |
# 显示动态黑名单。
<Sysname> display wlan blacklist dynamic
MAC address APID RID Lifetime (s) Duration (hh:mm:ss)
000f-e2cc-0001 1 1 300 00:02:11
000f-e2cc-0002 2 1 300 00:01:17
000f-e2cc-0003 3 1 300 00:02:08
表1-5 display wlan blacklist dynamic命令显示信息描述表
| 字段 | 描述 |
| Total number of clients | 动态黑名单中的客户端数量 |
| MAC address | 客户端MAC地址 |
| APID | 检测到非法客户端的AP的序列号 |
| RID | 检测到非法客户端的AP的Radio ID |
| Lifetime (s) | 动态黑名单表项的老化时间,单位为秒 |
| Duration (hh:mm:ss) | 动态黑名单表项的存活时间 |
display wlan bss命令用来显示BSS(Basic Service Set,基本服务集)信息。
(独立运行模式)
display wlan bss { all | ap ap-name | bssid bssid } [ verbose ]
display wlan bss { all | ap ap-name | bssid bssid } [ slot slot-number ] [ verbose ]
all:显示所有BSS信息。
ap ap-name:显示指定AP上的BSS信息,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
bssid bssid:显示指定BSSID(Basic Service Set ID,基本服务集标识)的BSS信息,bssid为48位的16进制数,格式为H-H-H。
slot slot-number:显示指定成员设备上的BSS信息,如果不指定本参数,则显示所有成员设备上的BSS信息。(IRF模式)
verbose:显示BSS的详细信息。如果不指定本参数,则显示BSS的简要信息。
# 显示所有BSS的简要信息。
<Sysname> display wlan bss all
Total number of BSSs: 4
AP name RID SSID BSSID
ap1 1 SSID1 001c-f08f-f804
ap1 2 SSID1 001c-f08f-f806
ap2 1 SSID1 001c-f0bf-9c92
ap2 2 SSID1 001c-f0bf-9c94
表1-6 display wlan bss all命令显示信息描述表
| 字段 | 描述 |
| AP name | AP名称 |
| RID | AP的Radio ID |
| SSID | 无线服务模板的SSID |
| BSSID | 基本服务集标识 |
# 显示成员设备1上的BSSID为001c-f08f-f804的BSS的详细信息。
<Sysname> display wlan bss bssid 001c-f08f-f804 slot 1 verbose
AP name : ap1
BSSID : 001c-f08f-f804
Radio ID : 1
Service template name : servcie1
SSID : SSID1
VLAN ID : 1
VLAN ID2 : 4
AKM mode : Not configured
User authentication mode : Bypass
表1-7 display wlan bss bssid verbose命令显示信息描述表
| 字段 | 描述 |
| AP name | AP名称 |
| BSSID | 基本服务集标识 |
| Radio ID | AP的Radio ID |
| Service template name | 无线服务模板的名称 |
| VLAN ID | 无线客户端接入的内层VLAN |
| VLAN ID2 | 无线客户端接入的外层VLAN,未配置外层VLAN时,显示为N/A |
| AKM mode | 身份认证与密钥管理模式: · 802.1X:表示用户认证与密钥管理模式是802.1X方式 · PSK:表示身份认证与密钥管理模式是PSK方式 · Not configured:未配置身份认证与密钥管理模式 |
| User authentication mode | 用户认证模式: · Bypass:不做用户认证 · MAC:MAC地址认证 · 802.1X:802.1X认证 · OUI:OUI认证 |
display wlan client命令用来查看客户端的信息。
display wlan client [ ap ap-name [ radio radio-id ] | mac-address mac-address | service-template service-template-name | frequency-band { 2.4 | 5 } ] [ verbose ]
ap ap-name:显示连接到指定AP的客户端信息。为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
radio radio-id:显示连接到指定射频的客户端信息,其中radio-id为为射频编号,本参数的取值范围与AP型号有关,请以设备的实际情况为准。如果未指定本参数,表示显示连接到指定AP的客户端信息。
mac-address mac-address:显示指定MAC地址的客户端信息。
service-template service-template-name:显示连接到指定无线服务模板的客户端信息,为1~63个字符的字符串,不区分大小写。
frequency-band:显示指定工作频段的客户端信息。
2.4:工作频段为2.4GHz。
5:工作频段为5GHz。
verbose:显示客户端的详细信息。如果未指定本参数,表示显示客户端的简要信息。
# 显示所有客户端的简要信息。
<Sysname> display wlan client
MAC address Username AP name R IP address VLAN
000f-e265-6400 N/A ap1 1 1.1.1.1 100
000f-e265-6401 user ap2 1 3.0.0.3 200
84db-ac14-dd08 N/A ap1 1 5.5.5.3 1
表1-8 display wlan client命令显示信息描述表
| 字段 | 描述 |
| MAC address | 客户端的MAC地址 |
| Username | 客户端的用户名,若客户端采用802.1X认证或MAC地址认证,则显示认证使用的用户名,若客户端不进行802.1X认证或MAC地址认证,则显示为N/A 需要注意的是,如果客户端采用Portal认证方式,Username字段不会显示客户端的Portal用户名,显示为N/A |
| AP name | 客户端关联AP的名称 |
| R | 客户端关联的Radio ID |
| IP address | 客户端的IPv4地址 |
| VLAN ID | 客户端所属VLAN |
# 显示指定客户端的详细信息。
<Sysname> display wlan client mac-address 000f-e265-6400 verbose
Total number of clients: 1
MAC address : 000f-e265-6400
IPv4 address : 10.1.1.114
IPv6 address : 2001::1234:5678:0102:0304
Username : N/A
AID : 1
AP ID : 1
AP name : ap1
Radio ID : 1
Channel : 36
SSID : office
BSSID : 0026-3e08-1150
VLAN ID : 3
VLAN ID2 : N/A
Sleep count :3
Wireless mode : 802.11gn
Channel bandwidth : 20MHz
20/40 BSS Coexistence Management : Not supported
SM power save : Enabled
Short GI for 20MHz : Supported
Short GI for 40MHz : Supported
Short GI for 80MHz : Supported
Short GI for 160/80+80MHz : Not supported
STBC RX capability : Not supported
STBC TX capability : Not supported
LDPC RX capability : Not supported
SU beamformee capability : Not supported
MU beamformee capability : Not supported
Beamformee STS capability : N/A
Block Ack : TID 0 In
Supported VHT-MCS set : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Supported HT MCS set : 0, 1, 2, 3, 4, 5, 6, 7,
8, 9, 10, 11, 12, 13, 14,
15
Supported rates : 1, 2, 5.5, 6, 9, 11,
12, 18, 24, 36, 48, 54 Mbps
QoS mode : WMM
Listen interval : 10
RSSI : 62
Rx/Tx rate : 130/195 Mbps
Speed :N/A
Authentication method : Open system
Security mode : PRE-RSNA
Cipher suite : N/A
WPA3 status : Disabled
Authorization ACL ID : 3001(Not effective)
Authorization user profile : N/A
Authorization CAR :
Average input rate : 102400 bps
Average output rate : 102400 bps
Roam status : N/A
Key derivation : SHA1
PMF status : Enabled
Forwarding policy name : Not configured
Online time : 0days 0hours 1minutes 13seconds
FT status : Inactive
BTM status : Disabled
表1-9 display wlan client verbose命令显示信息描述表
| 字段 | 描述 |
| IPv4 address | 客户端的IPv4地址 |
| IPv6 address | 客户端的IPv6地址 |
| AID | 关联标识符 |
| AP ID | 客户端关联的AP ID |
| Radio ID | 客户端关联的Radio ID |
| Channel | 客户端关联的信道 |
| SSID | 客户端关联的SSID |
| BSSID | 基本服务集识别码 |
| VLAN ID | 客户端所属的内层VLAN |
| VLAN ID2 | 客户端所属的外层VLAN,未配置外层VLAN时,显示为N/A |
| Sleep count | 客户端睡眠次数 |
| Wireless mode | 客户端工作的模式: · 802.11a:工作模式为 802.11a · 802.11b:工作模式为 802.11b · 802.11g:工作模式为 802.11g · 802.11gn:工作模式为 802.11gn · 802.11an:工作模式为 802.11an · 802.11ac:工作模式为802.11ac · 802.11ax:工作模式为802.11ax |
| Channel bandwidth | 客户端的工作带宽模式: · 20MHz:工作带宽为20MHz · 40MHz:工作带宽为40MHz · 80MHz:工作带宽为80MHz · 160MHz:工作带宽为160MHz |
| 20/40 BSS Coexistence Management | 客户端是否支持20M和40M带宽共存管理 |
| SM Power Save | 省电模式状态: · Enabled:省电模式处于开启状态,省电模式开启后客户端上只有一个天线处于工作状态,其余天线均处于休眠状态,从而达到节电的目的 · Disabled:省电模式处于关闭状态 |
| Short GI for 20MHz | 客户端工作带宽为20MHz时,对于Short GI的支持情况: · Supported:客户端支持Short GI · Not supported:客户端不支持Short GI |
| Short GI for 40MHz | 客户端工作带宽为40MHz时,对于Short GI的支持情况: · Supported:客户端支持Short GI · Not supported:客户端不支持Short GI |
| Short GI for 80MHz | 客户端工作带宽为80MHz时,对于Short GI的支持情况: · Supported:客户端支持Short GI · Not supported:客户端不支持Short GI |
| Short GI for 160/80+80MHz | 客户端工作带宽为160或80+80MHz时,对于Short GI的支持情况: · Supported:客户端支持Short GI · Not supported:客户端不支持Short GI |
| STBC RX capability | 客户端STBC接收能力情况: · Supported:客户端支持STBC接收 · Not Supported:客户端不支持STBC接收 |
| STBC Tx capability | 客户端STBC发送能力情况: · Supported:客户端支持STBC发送 · Not Supported:客户端不支持STBC发送 |
| LDPC Rx capability | 客户端LDPC接收能力情况: · Supported:客户端支持LDPC接收 · Not Supported:客户端不支持LDPC接收 |
| SU beamformee capability | 客户端单用户波束成形能力情况: · Supported:客户端支持单用户波束成形 · Not Supported:客户端不支持单用户波束成形 |
| MU beamformee capability | 客户端多用户波束成形能力情况: · Supported:客户端支持多用户波束成形 · Not Supported:客户端不支持多用户波束成形 |
| Beamformee STS capability | 客户端作为波束成形接收者,支持的空间流数: · N/A:表示客户端不支持作为波束成形接收者 · 0~7:波束成形空间流最大值减1 |
| Number of Sounding Dimensions | 客户端作为波束成形发送者,支持的空间流数: · N/A:表示客户端不支持作为波束成形发送者 · 0~7:波束成形空间流最大值减1 |
| Block Ack | QoS TID的Block Ack协商结果: · TID 0 In:表示上行数据报文支持Block Ack · TID 0 Out:表示下行数据报文支持Block Ack · TID 0 Both:表示上行和下行数据报文都支持Block Ack · N/A:表示上行和下行数据报文都不支持Block Ack |
| Supported VHT-MCS set | 客户端支持VHT-MCS |
| Supported HT MCS set | 客户端支持MCS |
| Supported rates | 客户端支持的速率 |
| 2.4G 40MHz Channel bandwidth | 客户端对11ax模式2.4G频率带宽支持情况: · Supported:客户端支持 · Not supported:客户端不支持 |
| 5G 40And80MHz Channel bandwidth | 客户端对11ax模式5G频率40MHz与80MHz带宽支持情况: · Supported:客户端支持 · Not supported:客户端不支持 |
| 5G 160MHz Channel bandwidth | 客户端对11ax模式5G频率160MHz带宽支持情况: · Supported:客户端支持 · Not supported:客户端不支持 |
| 5G 8080MHz Channel bandwidth | 客户端对11ax模式5G频率80MHz加80MHz带宽支持情况: · Supported:客户端支持 · Not supported:客户端不支持 |
| OFDMA random access RUs | 是否支持HE 随机选址 · Supported:不支持 · Not Supported:不支持 |
| Supported HE80MHz-MCS set | 11ax模式80MHz带宽下速率集信息 |
| Supported HE160MHz-MCS set | 11ax模式160MHz带宽下速率集信息 |
| Supported HE 8080MHz-MCS set | 11ax模式80MHz加80MHz带宽下速率集信息 |
| TWT scheduled | 11ax模式客户端是否为调度终端(即可计算、协商TWT调度信息的终端) · Yes:客户端为TWT调度终端 · No:客户端为非TWT调度终端 |
| QoS mode | QoS模式: · N/A:不支持WMM协议 · WMM:支持WMM协议 对于WMM的支持情况,AP和客户端会进行协商。只有AP和客户端同时支持WMM时,才能协商成功 |
| Listen interval | 处于睡眠模式的客户端定期醒来,接收缓存在AP中的数据帧的时间间隔,间隔时间单位为信标发送时间间隔 |
| RSSI | 客户端信号强度指示,该值表明了AP检测到客户端的信号强度 |
| Rx/Tx rate | 客户端发送/接收报文的速率(包括数据、管理和控制报文) |
| Speed | 最近2分钟内客户端发送/接收报文的速率(以Kbps为单位显示,保留小数点后三位),当显示N/A时,表示设备获取到的客户端发送/接收报文的速率为0 |
| Authentication method | 链路层认证方法: · Open system:开放系统认证 · Shared key:共享密钥认证 · SAE:SAE密钥认证 · FT:FT认证 |
| Security mode | 安全模式: · RSN:信标和探查响应帧携带RSN IE · WPA:信标和探查响应帧携带WPA IE · PRE-RSNA:信标和探查响应帧不携带RSN IE或WPA IE |
| AKM mode | 身份认证与密钥管理模式: · 802.1X:表示身份认证与密钥管理模式是802.1X方式 · PSK:表示身份认证与密钥管理模式是PSK方式 · OWE:表示身份证与密钥管理模式是机会性无线机密方式 · Not configured:未配置身份认证与密钥管理模式 |
| Cipher suite | 加密套件: · N/A:明文方式,不加密 · WEP40:使用WEP40加密套件 · WEP104:使用WEP104加密套件 · WEP128:使用WEP128加密套件 · CCMP:使用AES-CCMP加密套件 · TKIP:使用TKIP加密套件 · GCMP:使用GCMP加密套件 |
| User authentication mode | 用户认证模式: · Bypass:不做用户认证 · MAC:MAC认证 · 802.1X:802.1X认证 · OUI :OUI认证 |
| WPA3 status | WPA3安全模式状态: · Disabled:关闭状态 · Enabled:开启状态 · N/A:不涉及WPA3安全模式 |
| Authorization ACL ID | 授权ACL对应的ACL编号: · 授权ACL生效,则显示ACL编号 · 授权ACL未生效,则显示ACL编号 + Not effective · 不配置授权ACL,显示N/A |
| Authorization user profile | 授权User profile名称: · 如果下发授权User Profile生效,显示Authorization User Profile名称 · 如果下发授权User Profile未生效,显示Authorization User Profile名称+Not effective · 不配置授权User profile,显示N/A |
| Authorization CAR | 当服务器未授权用户CAR属性时,该字段显示为N/A。 当服务器授权用户CAR属性,将分为以下两个字段: · Average input rate :上行平均速率,单位为bps · Average output rate:下行平均速率,单位为bps |
| Roam status | 漫游状态: · Roaming in progress:漫游切换中 · Inter-AC roam:AC间漫游 · Inter-MA roam:MA间漫游 · Intra-AC roam:AC内漫游 · Intra-MA roam:MA内漫游 · N/A:客户端正常上线 |
| Key derivation | 密钥衍生类型,包括以下几种: · SHA1:SHA1 Key Derivation · SHA256:SHA256 Key Derivation · SHA384:SHA384Key Derivation · N/A:不涉及密钥衍生算法 |
| PMF status | 保护管理帧状态,包括以下几种: · Enabled:保护管理帧功能开启 · Disabled:保护管理帧功能关闭 · N/A:不涉及保护管理帧功能 |
| Forwarding policy name | 无线转发策略: · Not configured:未配置无线转发策略 · policy-name:无线转发策略名称 |
| Online time | 客户端在线的时间 |
| FT status | 快速BSS切换功能状态: · Active:开启状态 · Inactive:关闭状态 |
| BTM status | BTM功能状态: · Disabled:关闭状态 · Enabled:开启状态 |
display wlan client device-information命令用来显示无线客户端的设备信息。
display wlan client device-information [ mac-address mac-address ]
mac-address mac-address:显示指定MAC地址的无线客户端设备信息。如果不指定本参数,则显示所有无线客户端的设备信息。
# 显示所有无线客户端的设备信息。
<Sysname> display wlan client device-information
Total number of clients: 2
MAC_Address : 0000-0000-0001
Vendor Name : Oppo
Host Name : OPPO-Find-X2-Pro
MAC_Address : 0000-0000-0002
Vendor Name : Oppo
表1-10 display wlan client device-information命令显示信息描述表
| 字段 | 描述 |
| Vendor Name | 客户端型号,若终端的操作系统为IOS,或者配置了随机MAC,则该字段显示为Unknown |
| Host Name | 客户端名称,若终端的操作系统为IOS,该字段显示为Unknown |
display wlan client ipv6命令用来显示客户端的IPv6地址信息。
# 显示客户端的IPv6地址信息。
<Sysname> display wlan client ipv6
MAC address AP name IPv6 address VLAN
84db-ac14-dd08 ap1 1::2:0:0:3 300
表1-11 display wlan client ipv6命令显示信息描述表
| 字段 | 描述 |
| VLAN | 客户端所属VLAN |
display wlan client online-duration命令用来显示客户端在线时长。
display wlan client online-duration [ ap ap-name ] [ verbose ]
ap ap-name:指定AP的名称。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。如果不支持该参数,则显示所有客户端在线时长。
# 显示客户端在线时长。
<Sysname> display wlan client online-duration
Total number of online clients: 2
MAC address IPv4 address Online duration
a4c1-5b79-fa5b-1d62 192.168.11.123 0days 0hours 2minutes 23seconds
22d3-c5b7-a4b5-96fa 192.168.11.234 0days 0hours 5minutes 34seconds
表1-12 display wlan client online-duration命令显示信息描述表
| 字段 | 描述 |
| IPv4 address | 客户端IP地址 |
| Online duration | 客户端在线时长 |
display wlan client status命令用来显示客户端状态信息。
display wlan client status [ mac-address mac-address ] [ verbose ]
mac-address mac-address:显示指定客户端的状态信息,mac-address表示客户端的MAC地址,格式为H-H-H。如果未指定本参数,则显示所有客户端的状态信息。
verbose:显示客户端的详细状态信息。如果未指定本参数,则显示客户端的简要状态信息。
# 显示指定客户端的简要状态信息。
<Sysname> display wlan client status mac-address 001c-f08f-f804
MAC address RSSI Rx/Tx rate Speed(bps) Discard AP name RID
001c-f08f-f804 0 39M/117M N/A 0.00% ap2 2
# 显示所有客户端的简要状态信息。
000b-c002-9d09 65 39M/117M N/A 0.00% ap2 2
000f-e265-6401 62 130M/195M N/A 0.00% ap1 1
表1-13 display wlan client status命令显示信息描述表
| 字段 | 描述 |
| RSSI | 客户端发送关联请求报文时,AP检测到的客户端的信号强度 |
| Speed(bps) | 最近2分钟内客户端发送/接收报文的速率。 · 当报文速率小于1M时,以K为单位显示,并保留一位小数 · 当报文速率大于等于1M时,以M为单位显示,保留一位小数 · 当报文速率大于等于1G时,以G为单位显示,保留一位小数 · 当显示N/A时,表示设备获取到的客户端发送/接收报文的速率为0 |
| Discard | 客户端丢弃报文百分比 |
| AP name | 客户端关联的AP名称 |
| RID | 客户端关联的Radio ID |
# 显示指定客户端的详细状态信息。
<Sysname> display wlan client status mac-address 001c-f08f-f804 verbose
MAC address : 001c-f08f-f804
AP name : ap2
Radio ID : 2
RSSI : 0
Rx/Tx rate : 39/117 Mbps
Speed :N/A
Received:
Retransmitted packets : 84
Retransmitted packet ratio : 64.12 %
Sent:
Retransmitted packets : 0
Retransmitted packet ratio : 0.00 %
Discarded:
Discarded packets : 0
Discarded packet ratio : 0.00 %
表1-14 display wlan client status命令显示信息描述表
| 字段 | 描述 |
| AP name | 客户端的关联AP名称 |
| Radio ID | 客户端的关联的Radio ID |
| Speed | 最近2分钟内客户端发送/接收报文的速率。 · 当报文速率小于1M时,以K为单位显示,并保留一位小数 · 当报文速率大于等于1M时,以M为单位显示,保留一位小数 · 当报文速率大于等于1G时,以G为单位显示,保留一位小数 · 当显示N/A时,表示设备获取到的客户端发送/接收报文的速率为0 |
| Received | AP接收报文统计: Retransmitted packets:重传报文数 Retransmitted packet ratio:重传报文占接收报文的百分比 |
| Sent | AP发送报文统计: Retransmitted packets:重传报文数 Retransmitted packet ratio:重传报文占发送报文的百分比 |
| Discarded | 客户端丢弃报文统计: Discarded packets:丢弃报文数 Discarded packet ratio:丢弃报文占所有接收和发送报文百分比 |
display wlan forwarding-policy命令用来显示无线转发策略信息。
display wlan forwarding-policy [ policy-name ]
policy-name:无线转发策略名称,为1~31个字符的字符串,不区分大小写。如果未指定本参数,则显示所有无线转发策略的信息。
# 显示所有无线转发策略的信息。
<Sysname> display wlan forwarding-policy
Total number of forwarding policies: 2
Forwarding policy name: fwd1
Classifier ACL 2000: Local
Classifier ACL 2004: Local
Classifier IPv6 ACL 2001: Remote
Classifier IPv6 ACL 2002: Remote
Forwarding policy name: fwd2
Classifier ACL 4021: Local
Classifier IPv6 ACL 2000: Remote
Classifier IPv6 ACL 3024: Remote
表1-15 display wlan forwarding-policy命令显示信息描述表
| 字段 | |
| Forwarding policy name | 无线转发策略的名称 |
| IPv4报文转发方式: · Local:本地转发 · Remote:集中式转发 | |
| IPv6报文转发方式: · Local:本地转发 · Remote:集中式转发 |
display wlan guest-tunnel用来显示当前AC上的访客隧道信息。
display wlan guest-tunnel { all | ip ipv4-address }
all:表示所有访客隧道的信息。
ip ipv4-address:指定访客隧道的对端IPv4地址信息。
# 在边缘AC上显示所有访客隧道的信息。
<Sysname> display wlan guest-tunnel all
Guest access tunnel information
Local mode: Edge AC Tunnels: 2
Peer IP address Local IP address VLANs State Interface
2.2.2.2 5.5.5.1 4 Up WLAN-Tunnel9
2.2.2.3 5.5.5.1 5 Down WLAN-Tunnel10
# 在汇聚AC上显示所有访客隧道的信息。
Local mode: Aggregation AC Tunnels: 2
Peer IP address VLANs State Interface
1.1.1.1 4-5 Down WLAN-Tunnel9
1.1.1.2 6 Down WLAN-Tunnel10
# 显示和IPv4地址为1.1.1.1的AC建立的访客隧道的信息。
<Sysname> display wlan guest-tunnel ip 1.1.1.1
Local mode: Edge AC
Peer IP address : 1.1.1.1
Local IP address : 1.1.1.2
VLANs : 4
State : Down
Interface : WLAN-Tunnel9
Online duration : 00:32:05
表1-16 display wlan guest-tunnel命令显示信息描述表
| 字段 | 描述 |
| Local mode | AC的模式: · Edge AC:边缘AC · Aggregation AC:汇聚AC |
| Tunnels | 访客隧道的数量 |
| Peer IP address | 访客隧道的对端IPv4地址 |
| Local IP address | 访客隧道的本端IPv4地址 |
| VLANs | 配置的访客VLAN |
| State | 访客隧道的状态: · Up:已建立访客隧道 · Down:未建立访客隧道 |
| Interface | 建立访客隧道创建的本端接口,N/A表示建立访客隧道接口失败 |
| Online duration | 访客隧道Up的时长 |
display wlan lite-control-mode status命令用来查看轻量控制模式状态。
| WX1800H系列 | WX1804H-PWR | EWP-WX1804H-PWR-CN | 不支持 |
| WX2500H系列 | WX2508H-PWR-LTE WX2510H-PWR WX2510H-F-PWR WX2540H WX2540H-F WX2560H | EWP-WX2508H-PWR-LTE EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H | 不支持 |
| WX3500H系列 | WX3508H WX3508H WX3510H WX3510H WX3520H WX3520H-F WX3540H WX3540H | EWP-WX3508H EWP-WX3508H-F EWP-WX3510H EWP-WX3510H-F EWP-WX3520H EWP-WX3520H-F EWP-WX3540H EWP-WX3540H-F | 不支持 |
| WX5500E系列 | WX5510E WX5540E | EWP-WX5510E EWP-WX5540E | 不支持 |
| WX5500H系列 | WX5540H WX5560H WX5580H | EWP-WX5540H EWP-WX5560H EWP-WX5580H | 不支持 |
# 查看设备是否处于轻量控制模式。
[Sysname] display wlan lite-control-mode status
Lite-control-mode is enabled.
表1-17 display wlan lite-control-mode status显示命令显示信息描述表
| 字段 | 描述 |
| Lite-control-mode is enabled. | 轻量控制模式处于开启状态 |
| Lite-control-mode is disabled. | 轻量控制模式处于关闭状态 |
display wlan service-template命令用来显示无线服务模板信息。
display wlan service-template [ service-template-name ] [ verbose ]
service-template-name:无线服务模板名称,为1~63个字符的字符串。不区分大小写。如果未指定本参数,则显示所有无线服务模板的信息。
verbose:显示无线服务模板的详细信息。如果未指定本参数,则显示无线服务模板的概要信息。
# 显示无线服务模板的概要信息。
[Sysname] display wlan service-template
Total number of service templates: 2
Service template name SSID Status
1 2333 Enabled
2 3222 Enabled
表1-18 display wlan service-template命令显示信息描述表
| 字段 | 描述 |
| Service template name | 无线服务模板名称 |
| Status | 无线服务模板状态: · Disabled:关闭状态 · Enabled:开启状态 |
# 显示无线服务模板详细信息。
<Sysname> display wlan service-template verbose
Service template name : service1
Description : Not configured
SSID : wuxianfuwu
SSID-hide : Disabled
User-isolation : Disabled
Service template status : Disabled
Maximum clients per BSS : 64
Frame format : Dot3
Seamless roam status : Disabled
Seamless roam RSSI threshold : 50
Seamless roam RSSI gap : 20
VLAN ID : 1
Service VLAN ID : N/A
Service VLAN TPID : dot1q
AKM mode : PSK
Security IE : RSN
Cipher suite : CCMP
WEP key ID : 1
TKIP countermeasure time : 100 sec
PTK lifetime : 43200 sec
PTK rekey : Enabled
GTK rekey : Enabled
GTK rekey method : Time-based
GTK rekey time : 86400 sec
GTK rekey client-offline : Enabled
PPSK : Disabled
PPSK Fail Permit : Disabled
Enhance-open status : Enabled
Enhanced-open transition-mode service-template : N/A
Intrusion protection : Disabled
Intrusion protection mode : Temporary-block
Temporary block time : 180 sec
Temporary service stop time : 20 sec
Fail VLAN ID : 1
802.1X handshake : Enabled
802.1X handshake secure : Disabled
802.1X domain : my-domain
MAC-auth domain : Not configured
Max 802.1X users per BSS : 4096
Max MAC-auth users per BSS : 4096
802.1X re-authenticate : Enabled
Authorization fail mode : Online
Accounting fail mode : Online
Authorization : Permitted
PMF status : Optional
Hotspot policy number : Not configured
Forwarding policy status : Disabled
Forwarder : AP
FT status : Disabled
QoS trust : Port
QoS priority : 0
表1-19 display wlan service-template verbose命令显示信息描述表
| 字段 | 描述 |
| Description | 无线服务模板的描述信息 |
| SSID-hide | SSID隐藏: · Disabled:启用SSID通告 · Enabled:禁用SSID通告 |
| User-isolation | 用户隔离功能状态: · Disabled:关闭状态 · Enabled:开启状态 |
| Service template status | 无线服务模板状态: · Disabled:关闭状态 · Enabled:开启状态 |
| Maximum clients per BSS | 一个BSS中能够连接的最大客户端数 |
| Frame format | 客户端数据报文封装格式: · Dot3:802.3格式 · Dot11:802.11格式 |
| Seamless-roam | 零漫游功能: · Disabled:关闭状态 · Enabled:开启状态 |
| Seamless-roam RSSI threshold | 零漫游RSSI门限 |
| Seamless-roam RSSI gap | 零漫游RSSI差值门限 |
| VLAN ID | 无线客户端从指定无线服务模板上线后所属的内层VLAN |
| Service VLAN ID | 无线客户端从指定无线服务模板上线后所属的外层VLAN,未配置外层VLAN时,显示为N/A |
| Service VLAN TPID | 外层VLAN的TPID值 · dot1q:TPID值为0x8100 · dot1ad:TPID值为0x88A8 |
| AKM mode | 身份认证与密钥管理模式: · 802.1X:以802.1X作为身份认证与密钥管理模式 · PSK:以PSK作为身份认证与密钥管理模式 |
| Security IE | 安全IE类型: · RSN:RSN类型 · WPA:WPA类型 |
| Cipher suite | 加密套件: · WEP40:使用WEP40作为加密套件 · WEP104:使用WEP104作为加密套件 · WEP128:使用WEP128作为加密套件 · TKIP:使用TKIP作为加密套件 · CCMP:使用CCMP作为加密套件 · GCMP:使用GCMP作为加密套件 |
| WEP key ID | WEP密钥ID |
| TKIP countermeasure time | TKIP反制策略的时间,0表示不启动反制策略 |
| PTK life time | PTK的生存时间 |
| PTK rekey | PTK更新功能状态: · Enabled:开启状态 · Disabled:关闭状态 |
| GTK rekey | GTK更新功能状态: · Enabled:开启状态 · Disabled:关闭状态 |
| GTK rekey method | GTK更新方法: · Time-based:基于时间更新 · Packet-based:基于报文数更新 |
| GTK rekey time | GTK更新的时间间隔 |
| GTK rekey packets | 触发GTK更新的最大报文数量 |
| GTK rekey client-offline | 客户端离线更新功能状态: · Enabled:开启状态 · Disabled:关闭状态 |
| WPA3 status | WPA3安全模式状态: · Disabled:关闭状态 · Mandatory:强制模式 · Optional:可选模式 |
| PPSK | PPSK功能状态: · Disabled:关闭状态 · Enabled:开启状态 |
| PPSK Fail Permit | PPSK无线用户逃生功能状态: · Disabled:关闭状态 · Enabled:开启状态 |
| Enhance-open status | Enhanced-open功能状态: · Disabled:关闭状态 · Enabled:开启状态 |
| Enhanced-open transition-mode service-template | 过渡模式下推荐的无线服务模板。未配置,则显示N/A |
| User authentication mode | 认证模式,包括以下几种: · Bypass:不认证模式 · MAC:只进行MAC地址认证 · MAC-or-802.1X:先进行MAC地址认证,如果失败在进行802.1X认证 · 802.1X:只进行802.1X认证 · 802.1X-or-MAC:先进行802.1X认证,如果失败,再进行MAC地址认证 · OUI-or-802.1X:先进行OUI认证,如果失败,再进行802.1X认证 · MAC-and-802.1X:表示既进行MAC地址认证,又进行802.1X认证。先进行MAC地址认证,如果失败,则不再进行认证。如果认证成功,则再进行802.1X认证 |
| Intrusion protection | 入侵检测功能状态: · Enabled:开启状态 · Disabled:关闭状态 |
| Intrusion protection mode | 入侵检测特性模式,包括以下三种: · Temporary-block:表示临时将用户MAC加入阻止MAC列表中 · Service-stop:表示直接关闭对应BSS上的所有服务,直到重启该BSS · Temporary-service-stop:表示临时关闭收到非法报文的BSS所提供的接入服务 |
| Temporary block time | 临时阻塞非法入侵用户的时长,单位为秒 |
| Temporary service stop time | 临时关闭BSS服务时长,单位为秒 |
| Fail VLAN ID | 认证失败的VLAN ID。未配置,则显示“Not configured” |
| 802.1X handshake | 802.1X握手功能状态 · Enabled:开启状态 · Disabled:关闭状态 |
| 802.1X handshake secure | 802.1X安全握手功能状态 · Enabled:开启状态 · Disabled:关闭状态 |
| 802.1X domain | 802.1X认证域的域名。未配置,则显示“Not configured” |
| MAC-auth domain | MAC地址认证域的域名。未配置,则显示“Not configured” |
| Max 802.1X users per BSS | 一个BSS中能够进行802.1X认证的最大用户数 |
| Max MAC-auth users per BSS | 一个BSS中能够进行MAC地址认证的最大用户数 |
| 802.1X re-authenticate | 802.1X重认证功能状态: · Enabled:开启状态 · Disabled:关闭状态 |
| Authorization fail mode | 授权失败处理模式包括以下两种模式: · Offline:强制下线模式 · Online:非强制下线模式 |
| Accounting fail mode | 计费请求失败处理模式包括以下两种模式: · Offline:下线模式 · Online:非下线模式 |
| Authorization | 服务器的授权信息: · Permitted:应用RADIUS服务器或本地设备下发的授权信息 · Ignored:忽略RADIUS服务器或本地设备下发的授权信息 |
| Key derivation | 密钥衍生类型,包括以下几种: · SHA1:表示使用SHA1算法衍生密钥 · SHA256:表示使用SHA256算法衍生密钥 · SHA1-AND-SHA256:表示使用SHA1 and SHA256算法衍生密钥 |
| PMF status | 保护管理帧状态,包括以下几种: · Disabled:保护管理帧功能关闭 · Optional:保护管理帧功能可选 · Mandatory:保护管理帧功能强制 |
| Hotspot policy number | Hotspot 2.0策略号 |
| Forwarding policy status | 无线转发策略状态: · Disabled:关闭状态 · Enabled:开启状态 |
| Forward policy name | 无线转发策略名称: · Not configured:未配置无线转发策略 · policy-name:无线转发策略名称 |
| Forwarder | 客户端数据报文的转发位置: · AC:在分层AC架构中,表示转发位置在Local AC上;在非分层AC架构中,表示转发位置在AC上 · AP:转发位置在AP上 · Central AC:转发位置在Central AC上 |
| FT status | FT功能状态: · Disabled:关闭状态 · Enabled:开启状态 |
| FT method | 快速BSS切换的方式: · over-the-air:Over-the-Air方式 · over-the-ds:Over-the-DS方式 |
| FT reassociation deadline | 重关联超时时间,单位为秒 |
| QoS trust | QoS信任模式: · Port:信任端口优先级 · Dot11e:信任报文的802.11e优先级 |
| QoS priority | 端口优先级,取值范围为0~7 |
display wlan statistics client命令用来查看无线客户端的统计信息。
display wlan statistics client [ mac-address mac-address ]
mac-address mac-address:显示指定MAC地址的客户端统计信息。如果未指定本参数,则显示所有客户端统计信息。
# 显示所有无线客户端的统计信息。
<Sysname> display wlan statistics client
MAC address : 0014-6c8a-43ff
AP name : ap1
Radio ID : 1
SSID : office
BSSID : 000f-e2ff-7700
RSSI : 31
Sent frames:
Back ground : 0/0 (frames/bytes)
Best effort : 9/1230 (frames/bytes)
Video : 0/0 (frames/bytes)
Voice : 2/76 (frames/bytes)
Received frames:
Best effort : 18/2437 (frames/bytes)
Voice : 7/468 (frames/bytes)
Discarded frames:
Best effort : 0/0 (frames/bytes)
Voice : 5/389 (frames/bytes)
表1-20 display wlan statistics client命令显示信息描述表
| 字段 | 描述 |
| AP name | 接入点名称 |
| RadioID | 射频ID号 |
| SSID | 无线客户端关联的SSID |
| BSSID | 基本服务集识别码 |
| MAC address | 无线客户端的MAC地址 |
| RSSI | 接收信号强度指示,该值表明AP检测到Client的信号强度 |
| Sent frames | 发送帧的数目 |
| Back ground | 以帧或字节为单位对背景流优先级队列进行统计 |
| Best effort | 以帧或字节为单位对尽力而为流优先级队列进行统计 |
| Video | 以帧或字节为单位对视频流优先级队列进行统计 |
| Voice | 以帧或字节为单位对语音流优先级队列进行统计 |
| Received frames | 收到的帧的数目 |
| Discarded frames | 丢弃的帧的数目 |
display wlan statistics connect-history命令用来查看客户端连接历史信息。
display wlan statistics connect-history { ap { all | name ap-name } | service-template service-template-name }
ap:指定AP。
all:指定所有AP。
name ap-name:指定AP的名称,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
service-template service-template-name:显示无线服务模板的客户端连接历史信息。
# 显示服务模板1的AP的客户端连接历史信息。
<Sysname> display wlan statistics connect-history service-template 1
AP name : ap1
Radio ID : 1
Associations : 132
Association failures : 3
Reassociations : 30
Rejections : 12
Abnormal disassociations : 2
Current associations : 57
表1-21 display wlan statistics connect-history service-template 1命令显示信息描述
| 字段 | 描述 |
| AP name | AP名称 |
| Radio ID | 射频ID号 |
| Associations | 累计关联次数 |
| Association failures | 累计关联失败次数 |
| Reassociations | 累计重关联次数 |
| Rejections | 累计拒绝客户端连接次数 |
| Abnormal disassociations | 累计异常中断关联次数 |
| Current associations | 当前关联次数 |
# 显示AP 1的客户端连接历史信息。
<Sysname> display wlan statistics connect-history ap name ap1
AP name : ap1
Associations : 1
Reassociations : 0
Failures : 0
Rejections : 0
Abnormal disassociations : 0
Current associations : 1
Current 2G sta : 0
11b sta : 0
11g sta : 0
11gn sta : 0
11gac sta : 0
11gax sta : 0
Current 5G sta : 0
11a sta : 0
11an sta : 0
11ac sta : 2
11ax sta : 0
Received bytes :1000
Sent bytes : 2000
表1-22 display wlan statistics connect-history ap name ap1命令显示信息描述
| 字段 | 描述 |
| AP name | AP名称 |
| Failures | 累计关联失败次数 |
| Current 2G sta | 当前2.4GHz频段客户端总数 |
| 11b sta | 当前802.11b客户端数量 |
| 11g sta | 当前802.11g客户端数量 |
| 11gn sta | 当前802.11gn客户端数量 |
| 11gac sta | 当前802.11gac客户端数量 |
| 11gax sta | 当前802.11gax客户端数量 |
| Current 5G sta | 当前5GHz频段客户端总数 |
| 11a sta | 当前802.11a客户端数量 |
| 11an sta | 当前802.11an客户端数量 |
| 11ac sta | 当前802.11ac客户端数量 |
| 11ax sta | 当前802.11ax客户端数量 |
| Received bytes | 累计接收的数据帧字节数 |
| Sent bytes | 累计发送的数据帧字节数 |
display wlan statistics service-template命令用来查看无线服务模板的统计信息。
display wlan statistics service-template service-template-name
service-template-name:显示指定无线服务模板的统计信息。
# 显示服务模板1的统计信息。
<Sysname> display wlan statistics service-template 1
AP name : ap1
Radio ID : 1
Received:
Frame count : 1713
Frame bytes : 487061
Data frame count : 1683
Data frame bytes : 485761
Association request count : 2
Sent:
Frame count : 62113
Frame bytes : 25142076
Data frame count : 55978
Data frame bytes : 22626600
Association response count : 2
表1-23 display wlan statistics service-template命令显示信息描述
| 字段 | 描述 |
| AP name | AP名称 |
| Radio ID | 射频ID号 |
| Received | 接收统计: · Frame count:接收帧数 · Frame bytes:接收帧字节数 · Data frame count:接收数据帧数 · Data frame bytes:接收数据帧字节数 · Association request count:接收连接请求帧数 |
| Sent | 发送统计: · Frame count:发送帧数 · Frame bytes:发送帧字节数 · Data frame count:发送数据帧数 · Data frame bytes:发送数据帧字节数 · Association response count:发送连接响应帧数 |
display wlan statistics vip-client命令用来显示AP向AC上报的VIP客户端的统计信息。
display wlan statistics vip-client [ mac-address mac-address ] [ history-record ]
mac-address mac-address:客户端的MAC地址,形式为H-H-H。每段中的前导“0”可以省略。
history-record:AP向AC上报的VIP客户端统计信息的历史记录。如果未指定本参数,则显示当前VIP客户端的最新统计信息。
当指定history-record参数时,最多可以显示同一VIP客户端的300条历史记录。
# 显示AP向AC上报的MAC地址为1234-4321-1234 VIP客户端的统计信息。
<Sysname> display wlan statistics vip-client mac-address 1234-4321-1234
Total number of configured VIP clients: 1
Total number of online VIP clients: 1
MAC address : 1234-4321-1234
Data reporting time : 2018-8-15 12:20:15
AP name : ap1
Radio ID : 1
SSID : val-problem
Rx/Tx rate : 114.2/120.2 Mbps
Rx/Tx traffic : 16584/901021 Bytes
RSSI : 33
Clients on radio : 5
Channel utilization : 20%
Packet loss rate : 0.25%
Packet error rate : 0.01%
Retransmission rate : 1.29%
Delay : 5us
VIP client level : 1
表1-24 display wlan vip-statistics client命令显示信息描述表
| 字段 | 描述 |
| Total number of configured VIP clients | 已配置的VIP客户端数量 |
| Total number of online VIP clients | 在线的VIP客户端数量 |
| MAC address | VIP客户端的MAC地址 |
| Data reporting time | AP通过CAPWAP隧道向AC上报VIP客户端信息的时间 |
| AP name | VIP客户端关联AP的名称 |
| Radio ID | VIP客户端关联的Radio ID |
| SSID | VIP客户端关联的SSID |
| Rx/Tx rate | VIP客户端发送/接收报文的速率(包括数据、管理和控制报文) |
| Rx/Tx traffic | 数据上报周期内VIP客户端产生的上行/下行流量,单位Byte |
| RSSI | VIP客户端信号强度指示,该值表明了AP检测到客户端的信号强度 |
| Clients on radio | 当前射频的客户端数量 |
| Channel utilization | 当前信道的信道使用率 |
| Packet loss rate | 丢包率 |
| Packet error rate | 错包率 |
| Retransmission rate | 重传率 |
| Delay | AP向VIP客户端发送报文的时延,单位为微秒 |
| VIP client level | VIP客户端的VIP级别,具体说明可参见client-mac命令 |
· wlan vip-client-group
· client-mac
display wlan virtual-ap-group all client-number命令用来显示所有虚拟AP组内在线客户端数量。
本命令的支持情况与设备型号有关,请以实际情况为准。
| MAK系列 | MAK204 MAK206 | EWP-MAK204 EWP-MAK206 | 不支持 |
# 显示所有虚拟AP组内在线客户端数量。
<Sysname> display wlan virtual-ap-group all client-number
default-virtualapgroup 1 150 100 50
1 2 250 50 200
表1-25 display wlan virtual-ap-group client-number命令显示信息描述表
| 字段 | 描述 | |
| AP group name | 虚拟AP组名称 | |
| Group ID | 虚拟AP组的ID号,用于在AC上唯一标识一个虚拟AP组 | |
| Clients | 虚拟AP组内所有在线客户端数量 | |
| 2.4GHz | 虚拟AP组内2.4GHz频段的在线客户端数量 | |
| 5GHz | 虚拟AP组内5GHz频段的在线客户端数量 |
display wlan whitelist命令用来显示白名单。
# 显示白名单。
<Sysname> display wlan whitelist
MAC addresses:
000e-35b2-000e
0019-5b8e-b709
001c-f0bf-9c92
表1-26 display wlan whitelist命令显示信息描述表
| 字段 | 描述 |
| Total number of clients | 白名单中的客户端数量 |
| MAC addresses | 白名单列表中的客户端MAC地址 |
edge-ac命令用来配置边缘AC信息。
undo edge-ac命令用来删除边缘AC信息。
edge-ac ip ipv4-address vlan vlan-id-list
undo edge-ac { all | ip ipv4-address [ vlan vlan-id-list ] }
未配置边缘AC信息。
汇聚AC视图
ip ipv4-address:指定边缘AC的IPv4地址。
all:指定所有的边缘AC信息。
每个汇聚AC可以与同一个边缘AC建立多条隧道,但必须使用不同的源接口IP地址和该边缘AC的不同接口IP地址建立访客隧道。
# 在汇聚AC上指定边缘AC的IPv4地址为192.168.2.20,访客VLAN为VLAN 7。
[Sysname] wlan guest-tunnel aggregation-ac
[Sysname-wlan-aggregation-ac] edge-ac ip 192.168.2.20 vlan 7
· aggregation-ac
inherit exclude service-template命令用来配置AP不继承AP组下绑定的指定无线服务模板。
undo inherit exclude service-template命令用来恢复缺省情况。
inherit exclude service-template service-template-name
undo inherit exclude service-template service-template-name
AP继承AP组下绑定的无线服务模板。
Radio视图
service-template-name:无线服务模板名称,为1~63个字符的字符串,不区分大小写。
当Radio不需要继承AP组下绑定的指定无线服务模板时,可以使用本命令对AP进行配置。
# 配置AP不继承AP组下绑定的st无线服务模板。
[Sysname-ap-ap1] radio 1
[Sysname-ap-ap1-radio-1] inherit exclude service-template st
keep-alive interval命令用来配置访客隧道保活请求报文的发送周期。
undo keep-alive interval命令用来恢复缺省情况。
访客隧道保活请求报文的发送周期为10秒。
边缘AC视图
interval:访客隧道保活请求报文的发送周期,取值范围为5~80,单位为秒。
在边缘AC上完成汇聚AC信息的配置后,边缘AC会向汇聚AC发送用于建立访客隧道的保活请求报文,边缘AC收到保活回应报文后,访客隧道建立成功。访客隧道成功建立后,边缘AC会周期性的向汇聚AC发送保活请求报文,如果在三个保活时间内未收到汇聚AC的保活回应报文,则删除与该汇聚AC建立的访客隧道。对于汇聚AC,如果在向边缘AC发送保活回应报文之后的三个保活周期内未收到来自该边缘AC的保活请求报文,则会删除与其建立的访客隧道。
# 配置访客隧道保活请求报文的发送周期为7秒。
[Sysname-wlan-edge-ac] keep-alive interval 7
nas-id命令用来配置网络接入服务器标识。
undo nas-id命令用来恢复缺省情况。
nas-id nas-id
undo nas-id
AP视图:AP组有配置的情况下,继承AP组配置;AP组无配置的情况下,继承全局配置。
AP组视图:继承全局配置。
虚拟AP视图:虚拟AP组有配置的情况下,继承虚拟AP组配置;虚拟AP组无配置的情况下,继承全局配置。
虚拟AP组视图:继承全局配置。
全局配置视图:未配置网络接入服务器标识。
AP视图
AP组视图
虚拟AP视图
虚拟AP组视图
全局配置视图
nas-id:指定网络接入服务器标识,为1~63个字符的字符串,区分大小写。
无线客户端上线时,会通过发送给RADIUS服务器的RADIUS请求报文中携带的NAS-ID(Network Access Server Identifier,网络接入服务器标识)属性,标识客户端的接入位置。
本命令可在全局配置视图、AP组视图、AP视图和绑定无线服务模板时配置,优先级高的视图下的配置生效。优先级从高到低为绑定无线服务模板时的配置、AP视图下的配置、AP组视图下的配置、全局视图下的配置。
AP视图下配置的优先级高于AP组视图下的配置,AP组视图下配置的优先级高于全局配置视图下的配置。
本命令可在全局配置视图、虚拟AP组视图、虚拟AP视图和绑定无线服务模板时配置,优先级高的视图下的配置生效。优先级从高到低为绑定无线服务模板时的配置、虚拟AP视图下的配置、虚拟AP组视图下的配置、全局视图下的配置。
虚拟AP视图下配置的优先级高于虚拟AP组视图下的配置,虚拟AP组视图下配置的优先级高于全局配置视图下的配置。
# 配置网络接入服务器标识为abc123。(AP视图)
[Sysname-wlan-ap-ap1] nas-id abc123
# 配置网络接入服务器标识为abc123。(AP组视图)
[Sysname-wlan-ap-group-group1] nas-id abc123
# 配置网络接入服务器标识为abc123。(虚拟AP视图)
[Sysname] wlan virtual-ap ap1 model WA6320
[Sysname-wlan-virtual-ap-ap1] nas-id abc123
# 配置网络接入服务器标识为abc123。(虚拟AP组视图)
[Sysname] wlan virtual-ap-group group1
[Sysname-wlan-virtual-ap-group-group1] nas-id abc123
# 配置网络接入服务器标识为abc123。(全局配置视图)
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] nas-id abc123
nas-port-id命令用来配置网络接入服务器端口标识。
undo nas-port-id命令用来恢复缺省情况。
nas-port-id nas-port-id
undo nas-port-id
AP组视图:继承全局配置。
虚拟AP组视图:继承全局配置。
全局配置视图:未配置网络接入服务器端口标识。
AP视图
AP组视图
虚拟AP视图
虚拟AP组视图
全局配置视图
nas-port-id:指定网络接入服务器端口标识,为1~63个字符的字符串,区分大小写。
当客户端上线时,会通过RADIUS请求报文携带的NAS-Port-ID(Network Access Server Port Identifier,网络接入服务器端口标识)属性发送给RADIUS服务器,标识客户端的接入位置。
本命令可在全局配置视图、AP组视图、AP视图、绑定无线服务模板时配置,优先级高的视图下的配置生效。优先级从高到低为绑定无线服务模板时的配置、AP视图下的配置、AP组视图下的配置、全局视图下的配置。
# 配置网络接入服务器端口标识为abcd1234(AP视图)。
[Sysname-wlan-ap-ap1] nas-port-id abcd1234
# 配置网络接入服务器端口标识为abcd1234(AP组视图)。
[Sysname-wlan-ap-group-group1] nas-port-id abcd1234
# 配置网络接入服务器端口标识为abcd1234。(虚拟AP视图)
[Sysname-wlan-virtual-ap-ap1] nas-port-id abc123
# 配置网络接入服务器端口标识为abcd1234。(虚拟AP组视图)
[Sysname-wlan-virtual-ap-group-group1] nas-port-id abc123
# 配置网络接入服务器端口标识为abcd1234(全局配置视图)。
[Sysname-wlan-global-configuration] nas-port-id abcd1234
nas-port-type命令用来配置设备发送的RADUIS请求报文中的NAS-Port-Type属性值。
undo nas-port-type命令用来恢复缺省情况。
nas-port-type value
undo nas-port-type
设备发送的RADIUS请求报文中的NAS-Port-Type属性值为19。
无线服务模板视图
value:NAS-Port-Type属性值,取值范围为0~255。
对于要使用RADIUS服务器进行802.1X或者MAC地址认证的用户,需要通过本命令将RADIUS请求报文的NAT-Port-Type类型配置为RADIUS服务器支持的类型。
本命令只能在无线服务模板状态关闭的状态下配置。
NAS-Port-Type常用属性值如下:Async(0)、Sync(1)、ISDN Sync(2)、ISDN Async V.120(3)、ISDN Async V.110(4)、Virtual(5)、PIAFS(6)、HDLC Clear Channel(7)、X.25(8)、X.75(9)、G.3 Fax(10)、SDSL(11)、ADSL-CAP(12)、ADSL-DMT(13)、IDSL(14)、Ethernet(15)、xDSL(16)、Cable(17)、Wireless-Other(18)、Wireless-IEEE 802.11(19)。
# 配置设备发送的RADIUS请求报文中的NAS-Port-Type的属性值为15。
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] nas-port-type 15
nas-vlan命令用来配置网络接入服务器的VLAN ID。
undo nas-vlan命令用来恢复缺省情况。
nas-vlan vlan-id
undo nas-vlan
未配置网络接入服务器的VLAN ID,即AC向RADIUS服务器发送的请求认证报文中未携带NAS-VLAN-ID字段。
AP视图
vlan-id:网络接入服务器的VLAN ID,取值范围为1~4094。
当使用某个第三方厂商的SAM(Security Accounting Management,安全审计管理)系统作为RADIUS服务器时,需要在我司设备上配置NAS-VLAN-ID(Network Access Server VLAN Identifier,网络接入服务器VLAN标识),以便SAM服务器使用该VLAN ID定位客户端位置。
# 配置网络接入服务器的VLAN ID为1234。
[Sysname-wlan-ap-ap1] nas-vlan 1234
non-vip limit rate命令用来开启非VIP客户端限速功能。
undo non-vip limit rate命令用来关闭非VIP客户端限速功能。
non-vip limit rate { inbound | outbound } [ mode { dynamic [ min min-cir ] [ max max-cir ] | static } ] cir cir
undo non-vip limit rate { inbound | outbound } cir
非VIP客户端限速功能处于关闭状态。
VIP客户端组视图
inbound:入方向,即限制客户端发送数据的速率。
outbound:出方向,即限制客户端接收数据的速率。
mode dynamic:配置限速模式为动态模式,在该模式下,每个客户端的限速速率为总限速速率/客户端总数。如果不指定本参数,则限速模式为静态模式。
min min-cir:配置所有客户端的动态限速速率最小值。在动态模式下表示配置每个客户端的限速速率最小值。min-cir的取值范围为16~1700000,单位为kbps。
max max-cir:配置所有客户端的动态限速速率最大值。在动态模式下表示配置每个客户端的限速速率最大值。max-cir的取值范围为16~1700000,单位为kbps。配置的max-cir需要大于min-cir。
mode static:配置限速模式为静态模式,所有客户端的限速速率为固定值。
cir cir:配置非VIP客户端的限速速率。静态模式下,该速率值为每个客户端的限速速率,动态模式下,该速率为所有客户端的限速速率总和。cir的取值范围为16~1700000,单位为Kbps。
配置本功能后,当射频接口下有VIP终端上线时,该接口下的非VIP客户端的速率会被限制;当接口上没有VIP终端在线时,该接口下的非VIP客户端的速率不会被限制。
限速模式为动态限速时,如果同时配置了min min-cir、max max-cir和cir cir参数:
· 当cir/客户端总数<min,则客户端动态限速速率为min。
· 如果min<cir/客户端总数<max,则客户端动态限速速率为cir/客户端总数。
· 如果cir/客户端总数>max,则客户端动态限速速率为max。
同时配置非VIP客户端限速功能和基于射频的客户端限速功能时,仅会对非VIP客户端进行限速,不会对VIP客户端进行限速。对非VIP客户端限速参数选择原则如下:
· 配置的限速模式不同,以非VIP客户端限速功能配置为准。
· 配置的限速模式相同,当均为静态模式时,限速速率取两种配置的最小值;当均为动态模式时,限速速率以非VIP客户端限速功能配置为准。
可以同时指定出方向和入方向的速率限制。
# 在VIP客户端组视图下,开启非VIP客户端限速功能,使单个客户端发送数据的最大速率为500Kbps,所有客户端接收数据的总速率为100Kbps。
[Sysname-wlan vip-client-group] non-vip limit rate inbound mode static cir 500
[Sysname-wlan vip-client-group] non-vip limit rate outbound mode dynamic cir 100
· client-rate-limit (radio view/AP group radio view)
qinq ethernet-type service-tag命令用来配置QinQ组网下无线客户端从指定无线服务模板上线后外层VLAN Tag的TPID值。
undo qinq ethernet-type service-tag命令用来恢复缺省情况。
qinq ethernet-type service-tag { dot1ad | dot1q }
QinQ组网下无线客户端从指定无线服务模板上线后外层VLAN Tag的TPID值为0x8100。
无线服务模板视图
dot1ad:指定外层VLAN Tag的TPID值为0x88A8。
dot1q:指定外层VLAN Tag的TPID值为0x8100。
本命令只能在无线服务模板处于关闭状态下配置。
若需要对接入的无线客户端的报文进行QinQ封装,且对外层VLAN Tag的TPID值有固定要求时,需要使用本命令调整外层VLAN Tag取值。
# 配置QinQ组网下无线客户端从无线服务模板service1上线后,外层VLAN Tag的TPID值为0x88A8。
[Sysname-wlan-st-service1] qinq ethernet-type service-tag dot1ad
· vlan
quick-association enable命令用来开启快速关联功能。
undo quick-association enable命令用来关闭快速关联功能。
快速关联处于关闭状态。
无线服务模板视图
服务模板上开启快速关联功能后,设备不会对关联到此服务模板的客户端进行频谱导航和负载均衡计算,从而让客户端可以快速地关联到AP上。
# 开启服务模板1的快速关联功能。
[Sysname-wlan-st-service1] quick-association enable
report-interval命令用来配置AP向AC上报VIP客户端信息的时间间隔。
undo report-interval命令用来恢复缺省情况。
report-interval interval
AP向AC上报VIP客户端信息的时间间隔为50秒。
VIP客户端组视图
interval:AP向AC上报VIP客户端信息的时间间隔,取值范围为10~120,单位为秒。
本命令仅对Level 1的VIP客户端生效。
通过配置本参数,AP会按照配置的时间间隔将收集到的VIP客户端信息上报给AC,由AC整理后,再将数据每隔5分钟统一上报给云平台。
# 在VIP客户端组视图下,配置AP向AC上报VIP客户端信息的时间间隔为36秒。
[Sysname-wlan vip-client-group] report-interval 36
reset wlan client命令用来断开与客户端的连接。
reset wlan client { all | mac-address mac-address }
all:断开与所有客户端的连接。
mac-address mac-address:断开与指定客户端的连接。
# 断开与所有客户端的连接。
<Sysname> reset wlan client all
· display wlan client
reset wlan dynamic-blacklist命令用来清除动态黑名单表项。
reset wlan dynamic-blacklist [ mac-address mac-address ]
mac-address mac-address:清除动态黑名单中指定客户端的MAC地址。如果未指定本参数,则表示清除所有动态黑名单中的客户端。
# 清除动态黑名单表项。
<Sysname> reset wlan dynamic-blacklist
# 清除指定的动态黑名单表项。
<Sysname> reset wlan dynamic-blacklist mac-address b8ca-32a2-df69
· display wlan blacklist
reset wlan guest-tunnel命令用来删除访客隧道。
reset wlan guest-tunnel { all | ip ipv4-address }
all:表示所有访客隧道。
ip ipv4-address:指定访客隧道的对端IPv4地址。
# 删除所有访客隧道。
<Sysname> reset wlan guest-tunnel all
reset wlan statistics client命令用来清除无线客户端的统计信息。
reset wlan statistics client { all | mac-address mac-address }
all:清除所有无线客户端的统计信息。
mac-address mac-address:清除指定无线客户端的统计信息。
# 清除所有无线客户端的统计信息。
<Sysname> reset wlan statistics client all
· display wlan statistics
reset wlan statistics service-template命令用来清除无线服务模板的统计信息。
reset wlan statistics service-template service-template-name
配置该功能后,无线服务模板的最新统计信息和历史统计信息将被清除。
# 清除无线服务模板service1的统计信息。
<Sysname> reset wlan statistics service-template service1
roam-enhance命令用来开启漫游增强功能并指定漫游增强的SSID。
undo roam-enhance命令用来恢复缺省情况。
roam-enhance ssid ssid
undo roam-enhance
Radio视图下,继承AP组Radio配置。
AP组Radio视图下,漫游增强功能处于关闭状态。
Radio视图
AP组Radio视图
ssid:漫游增强的SSID,为1~32个字符的字符串,区分大小写。
本命令只能在网络侧设备的2.4G射频下配置,多次执行本命令,最后一次执行的命令生效。
配置本命令时,绑定指定SSID对应的服务模板的5G射频不能工作在雷达信道。建议手工配置非雷达信道或者配置自动信道以及信道黑白名单。
仅当AP的5G射频绑定指定SSID对应的服务模板后,漫游增强功能才会生效。
AP的5G射频最多只能绑定指定SSID对应的5个不同服务模板。
配置漫游增强功能后,将绑定指定SSID的服务模板的5G射频不要用作业务扫描射频,否则会导致报文丢包数量增加,影响漫游效果。
# 开启Radio 2的漫游增强功能并指定漫游增强的SSID为agv。(Radio视图)
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] roam-enhance ssid agv
# 开启Radio 2的漫游增强功能并指定漫游增强的SSID为agv。(AP组Radio视图)
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA6320
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 2
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-2] roam-enhance ssid agv
service-template命令用来将无线服务模板绑定到当前Radio上。
undo service-template命令用来解除当前Radio与无线服务模板的绑定关系。
service-template service-template-name [ vlan vlan-id1 [ vlan-id2 ] | vlan-group vlan-group-name ] [ ssid-hide ] [ nas-port-id nas-port-id ] [ nas-id nas-id ]
undo service-template service-template-name
Radio视图:继承AP组配置。
AP组Radio视图:未绑定无线服务模板。
虚拟AP Radio视图:继承虚拟AP组Radio配置。
虚拟AP组Radio视图:未绑定无线服务模板。
Radio视图
AP组Radio视图
虚拟AP Radio视图
虚拟AP组Radio视图
vlan vlan-id1 vlan-id2:无线服务模板绑定Radio时指定的外层VLAN ID和内层VLAN ID,其中vlan-id1为外层VLAN ID,vlan-id2为内层VLAN ID,取值范围为1~4094。
vlan-id2的支持情况与设备型号有关,请以设备的实际情况为准。
| WX2500H系列 | WX2508H-PWR-LTE WX2510H WX2510H-F WX2540H WX2540H-F WX2560H | EWP-WX2508H-PWR-LTE EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H | 不支持 |
| WX3000H系列 | WX3010H WX3010H-X WX3010H-L WX3024H WX3024H-L WX3024H-F | EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F | 不支持 |
| WX3500H系列 | WX3508H WX3510H WX3520H WX3520H-F WX3540H | EWP-WX3508H EWP-WX3508H-F EWP-WX3510H EWP-WX3510H-F EWP-WX3520H EWP-WX3520H-F EWP-WX3540H EWP-WX3540H-F | 支持 |
vlan-group vlan-group-name:指定无线服务模板绑定Radio时指定的VLAN组,为1~31个字符的字符串,不区分大小写。有关该命令的详细介绍,请参见“网络互通命令参考”中的“VLAN”。
ssid-hide:隐藏绑定的无线服务模板的SSID。
nas-port-id nas-port-id:无线服务模板绑定Radio时指定的NAS-Port-ID,为1~63个字符的字符串,不区分大小写,不能包含空格。
nas-id nas-id:无线服务模板绑定Radio时指定的NAS-ID,为1~63个字符的字符串,不区分大小写,不能包含空格。
当只指定无线服务模板名称时,该无线服务模板须先被创建才可完成绑定。
当指定VLAN ID时,若指定的VLAN不存在,则在客户端上线时会自动创建指定的VLAN。需要注意的是,只有在集中式转发的场景下,外层VLAN的配置才生效。
将无线服务模板绑定到Radio上时,若指定了VLAN ID或VLAN组,则该VLAN ID或VLAN组的优先级高于无线服务模板下配置的VLAN ID。
Radio视图下配置的优先级高于AP组Radio视图下的配置。
虚拟AP Radio视图下配置的优先级高于虚拟AP组Radio视图下的配置。
# 将无线服务模板service1绑定到Radio1上,并指定VLAN组为vg1。(Radio视图)
[Sysname] wlan ap ap1
[Sysname-ap-ap1-radio-1] service-template service1 vlan-group vg1
# 将无线服务模板service1绑定到AP组apgroup1下的Radio1上,并指定VLAN组为vg1。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] service-template service1 vlan-group vg1
# 将无线服务模板service1绑定到Radio1上,并指定VLAN组为vg1。(虚拟AP Radio视图)
[Sysname-virtual-ap-ap1] radio 1
[Sysname-virtual-ap-ap1-radio-1] service-template service1 vlan-group vg1
# 将无线服务模板service1绑定到虚拟AP组apgroup1下的Radio1上,并指定VLAN组为vg1。(虚拟AP组Radio视图)
[Sysname] wlan virtual-ap-group apgroup1
[Sysname-wlan-virtual-ap-group-apgroup1] ap-model WA6320
[Sysname-wlan-virtual-ap-group-apgroup1-ap-model-WA6320] radio 1
[Sysname-wlan-virtual-ap-group-apgroup1-ap-model-WA6320-radio-1] service-template service1 vlan-group vg1
service-template enable命令用来开启无线服务模板。
undo service-template enable命令用来关闭无线服务模板。
无线服务模板处于关闭状态。
无线服务模板视图
若设备上所能创建的BSS已达上限,则不能打开其它处于关闭状态的无线服务模板。
# 开启无线服务模板开关。
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] service-template enable
snmp-agent trap enable wlan client命令用来开启客户端的告警功能。
undo snmp-agent trap enable wlan client命令用来关闭客户端的告警功能。
客户端的告警功能处于关闭状态。
开启了告警功能之后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。(有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。)
# 开启客户端的告警功能。
[Sysname] snmp-agent trap enable wlan client
snmp-agent trap enable wlan client-audit命令用来开启客户端审计的告警功能。
undo snmp-agent trap enable wlan client-audit命令用来关闭客户端审计的告警功能。
客户端审计的告警功能处于关闭状态。
开启客户端审计告警功能之后,设备会生成告警信息,用于报告有关客户端审计的重要事件。这些告警信息可用于对客户端进行审计、监控和统计等操作。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 开启客户端审计的告警功能。
[Sysname] snmp-agent trap enable wlan client-audit
ssid命令用来在无线服务模板视图下配置SSID。
undo ssid命令用来恢复缺省情况。
ssid ssid-name
undo ssid
未配置SSID。
无线服务模板视图
ssid-name:指定无线服务模板的SSID,为1~32个字符的字符串,区分大小写。
可以通过" 字符串"的方式,配置以空格开头的SSID。例如:希望配置SSID为 12345,则在设备上配置" 12345"。
可以通过\"字符串的方式,配置为以"为开头的SSID。例如:希望配置SSID为"12345,则在设备上配置\"12345。
配置完成后,可以通过display wlan service-template命令查看SSID。
# 设置无线服务模版service1的SSID为lynn。
[Sysname-wlan-st-service1] ssid lynn
unknown-client命令用来配置对未知客户端数据报文处理方式。
undo unknown-client命令用来恢复缺省情况。
unknown-client { deauthenticate | drop }
undo unknown-client
丢弃未知客户端发送的数据报文并向客户端发送解除认证报文。
无线服务模板视图
deauthenticate:丢弃未知客户端发送的数据报文并向客户端发送解除认证报文。
drop:仅丢弃未知客户端发送的数据报文。
# 仅丢弃未知客户端发送的数据报文。
[Sysname] wlan service-template example
[Sysname-wlan-st-example] unknown-client drop
vip limit rate命令用来开启VIP客户端限速功能。
undo vip limit rate命令用来关闭VIP客户端的限速功能。
vip limit rate level level { inbound | outbound } mode { dynamic [ min min-cir ] [ max max-cir ] | static } cir cir
undo vip limit rate level level { inbound | outbound }
VIP客户端的限速功能处于关闭状态。
VIP客户端组视图
level level:VIP客户端的级别。取值只能为2。
inbound:入方向,即限制接收客户端数据的速率。
outbound:出方向,即限制向客户端发送数据的速率。
dynamic:配置限速模式为动态模式。在该模式下,单个客户端的限速速率为总限速速率/客户端总数。
min min-cir:所有客户端的动态限速速率最小值,取值范围为16~1700000,单位为Kbps。若未指定本参数,则不限制所有客户端的动态限速速率的最小值。
max max-cir:所有客户端的动态限速速率最大值,取值范围为16~1700000,单位为Kbps,配置的max-cir需要大于min-cir。若未指定本参数,则不限制所有客户端的动态限速速率的最大值。
cir cir:配置VIP客户端限速速率。静态模式下,该速率为每个客户端的限速速率;动态模式下,该速率为所有客户端的限速速率总和。cir的取值范围为16~1700000,单位为Kbps。
当有大量VIP客户端上线时,可以开启VIP客户端限速功能,使每一个VIP客户端都能获得相应的传输速率,保证VIP客户端的使用体验。
· 如果(cir/客户端总数)<min-cir,则客户端动态限速速率为min-cir;
· 如果min-cir<(cir/客户端总数)<max-cir,则客户端动态限速速率为cir/客户端总数;
· 如果(cir/客户端总数)>max-cir,则客户端动态限速速率为max-cir。
多次执行本命令,同时指定出方向和入方向的速率限制。
同时配置VIP客户端限速功能和基于射频的客户端限速功能时,对VIP客户端限速参数选择原则如下:
· 如果配置的限速模式不同,则以VIP客户端限速功能配置为准;
· 如果配置的限速模式均为静态模式,则限速速率取两种配置的最小值;如果配置的限速模式均为动态模式,则限速速率以VIP客户端限速功能配置为准。
# 在VIP客户端组视图下,开启VIP客户端限速功能,限速模式为静态模式,每个客户端发送数据的最大速率为500Kbps,接收数据的最大速率为100Kbps。
[Sysname-vip-client-group] vip limit rate level 2 inbound mode static cir 500
[Sysname-vip-client-group] vip limit rate level 2 outbound mode static cir 100
vlan命令用来配置无线客户端从指定无线服务模板上线后所属的VLAN。
undo vlan命令用来恢复缺省情况。
vlan vlan-id1 [ service-vlan vlan-id2 ]
undo vlan [ vlan-id1 ]
无线客户端从指定无线服务模板上线后将被加入到VLAN 1。
无线服务模板视图
vlan-id1:指定无线客户端从指定无线服务模板上线后将被加入的内层VLAN ID,取值范围为1~4094。
vlan-id2:指定无线客户端从指定无线服务模板上线后被加入的外层VLAN ID,取值范围为1~4094。
配置无线客户端从指定无线服务模板上线后将被加入的VLAN后,如果指定的VLAN已经存在,则客户端在该服务模板上线后会被加入此VLAN;如果指定的VLAN不存在,则客户端上线时会自动创建指定的VLAN,并将客户端加入此VLAN。
# 无线客户端从无线服务模板service1上线后将被加入到VLAN 2。
[Sysname-wlan-st-service1] vlan 2
wlan accounting-policy命令用来创建计费策略,并进入计费策略视图。如果指定的计费策略已经存在,则直接进入计费策略视图。
undo wlan accounting-policy命令用来删除计费策略。
wlan accounting-policy policy-name
undo wlan accounting-policy policy-name
不存在计费策略。
policy-name:计费策略的名称,为1~31个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
在一个计费策略视图下可以指定多个需要进行计费的流量计费级别,计费服务器通过不同的计费级别可以对用户不同流量进行区别计费。
可创建计费策略的个数与设备型号有关,请以设备实际情况为准。
# 创建计费策略abc,并进入计费策略视图。
[Sysname] wlan accounting-policy abc
[Sysname-wlan-acctpolicy-abc]
· accounting-level
· wlan apply accounting-policy
wlan apply accounting-policy命令用来在User Profile下应用计费策略。
undo wlan apply accounting-policy命令用来恢复缺省情况。
wlan apply accounting-policy policy-name
User Profile下未应用计费策略。
User Profile视图
policy-name:指定计费策略名称,为1~31个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
在User Profile下应用计费策略,当客户端准备接入网络并通过身份认证后:
· 客户端认证位置在AC上时,认证服务器会将客户端账户绑定的User Profile名称下发给AC,由AC再将User Profile下发给AP,AP根据指定User Profile下应用的计费策略对客户端进行流量统计并将数据上报给AC,AC最终将数据上报给计费服务器进行计费。
· 客户端认证位置在AP上时,认证服务器会将客户端账户绑定的User Profile名称下发给AP,AP根据指定User Profile下应用的计费策略对客户端进行流量统计并将数据上报给计费服务器进行计费。
如果未匹配上User Profile,则采用AAA进行计费。
修改或删除User Profile下应用的计费策略时,对于再次认证上线或新认证上线的客户端使用新的计费策略。
# 在User Profile下应用计费策略abc。
[Sysname] user-profile 123
[Sysname-user-profile-123] wlan apply accounting-policy abc
· wlan accounting-policy
wlan association optimization命令用来配置客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率的优化参数值。
undo wlan association optimization命令用来恢复缺省情况。
wlan association optimization value
客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率的优化参数值为0,即不对客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率进行优化,采用实际值。
value:客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率的优化参数值,取值范围为900~1000。该数值配置越小,客户端关联AP的关联成功率越小、关联拥塞率越大、终端异常下线率越大。
关联成功率是指客户端关联AP成功的次数占客户端关联AP的总次数的百分比。关联拥塞率是指在AP满载的情况下,客户端在关联AP过程中被拒绝的次数占关联AP的总次数的百分比。终端异常下线率是指终端异常断开连接的总次数占终端关联成功的总次数与当前在线用户总数之和的百分比。
配置本命令后,设备会重新对客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率进行优化计算。
# 配置客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率的优化参数值为950。
[Sysname] wlan association optimization 950
wlan client bss-load-ie enable命令用来开启Beacon和Probe Response报文携带BSS Load IE功能。
undo wlan client bss-load-ie enable命令用来关闭Beacon和Probe Response报文携带BSS Load IE功能。
wlan client bss-load-ie enable [ update-interval interval ]
Beacon和Probe Response报文中不携带BSS Load IE。
update-interval interval:BSS Load IE更新时间间隔,取值范围为5~30,单位为秒,缺省值为15。
开启本功能后,设备发送的Beacon或Probe Response报文中会携带BSS Load IE。BSS Load IE主要包含一个射频下的每个BSS的客户端数量、信道利用率和剩余媒体可用时间等内容。
在漫游网络和Hotspot 2.0网络中,建议开启本功能,以便客户端根据BSS Load IE自动选择可接入的最优网络。
# 开启Beacon和Probe Response报文携带BSS load IE功能。
[Sysname] wlan client bss-load-ie enable
wlan client forwarding enable命令用来开启客户端数据报文转发功能。
undo wlan client forwarding enable命令用来关闭客户端数据报文转发功能。
本命令的支持情况与设备型号有关,请以设备的实际情况为准。
| 产品系列 | 产品型号 | 产品代码 | 说明 |
| WX1800H系列 | WX1804H-PWR | EWP-WX1804H-PWR-CN | 支持 |
| WX2500H系列 | WX2508H-PWR-LTE WX2510H-PWR WX2510H-F-PWR WX2540H WX2540H-F WX2560H | EWP-WX2508H-PWR-LTE EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H | 支持 |
| MAK系列 | MAK204 MAK206 | EWP-MAK204 EWP-MAK206 | 支持 |
| WX3000H系列 | WX3010H WX3010H-X-PWR WX3010H-L-PWR WX3024H WX3024H-L-PWR WX3024H-F | EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F | WX3010H支持 WX3010H-X-PWR支持 WX3010H-L-PWR不支持 WX3024H支持 WX3024H-L-PWR不支持 WX3024H-F支持 |
| WX3500H系列 | WX3508H WX3508H WX3510H WX3510H WX3520H WX3520H-F WX3540H WX3540H | EWP-WX3508H EWP-WX3508H-F EWP-WX3510H EWP-WX3510H-F EWP-WX3520H EWP-WX3520H-F EWP-WX3540H EWP-WX3540H-F | 支持 |
| WX5500E系列 | WX5510E WX5540E | EWP-WX5510E EWP-WX5540E | 支持 |
| WX5500H系列 | WX5540H WX5560H WX5580H | EWP-WX5540H EWP-WX5560H EWP-WX5580H | 支持 |
| AC插卡系列 | LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F | LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F | 支持 |
| WX1800H系列 | WX1804H-PWR WX1810H-PWR WX1820H WX1840H | EWP-WX1804H-PWR EWP-WX1810H-PWR EWP-WX1820H EWP-WX1840H-GL | 支持 |
| WX3800H系列 | WX3820H WX3840H | EWP-WX3820H-GL EWP-WX3840H-GL | 支持 |
| WX5800H系列 | WX5860H | EWP-WX5860H-GL | 支持 |
客户端数据报文转发功能处于开启状态。
若指定了客户端数据报文转发位置在AC上,则必须开启此功能才能使得AC能够转发客户端数据报文;若指定了客户端数据报文转发位置在AP上,则此功能无效。
在分层AC架构下,如果客户端数据报文转发位置在AC(Central AC或Local AC)上,则建议在Central AC上关闭客户端数据报文转发功能,Local AC上开启此功能。当AP与管理员所指定的Local AC关联时,由Local AC转发客户端报文。如果指定的Local AC发生故障,AP将关联到Central AC上,由于Central AC上的客户端数据报文转发功能处于关闭状态,客户端数据报文的转发位置将自动迁移到AP上,从而保障Central AC对整个无线网络的管理性能。
有关分层AC的配置请参见“WLAN高级功能配置指导”中的“分层AC”。
# 关闭客户端数据报文转发功能。
[Sysname] undo wlan client forwarding enable
wlan client forwarding-policy-name命令用来在User Profile下应用无线转发策略。
undo wlan client forwarding-policy-name命令用来恢复缺省情况。
wlan client forwarding-policy-name policy-name
User Profile下未应用无线转发策略。
User Profile视图
policy-name:指定策略名称,为1~31个字符的字符串,不区分大小写。
当配置无线转发策略时,AC和AP必须处于不同网段中。
在User Profile下应用无线转发策略,当客户端准备接入网络并通过身份认证后,认证服务器会将与客户端账户绑定的User Profile名称下发给AC,AC根据指定User Profile下应用的无线转发策略对客户端数据报文进行转发。
User Profile下应用的无线转发策略,只有在开启了无线转发策略和配置用户认证位置在AC上的无线服务模板上才会生效。修改或删除User Profile下应用的无线转发策略时,该配置会在客户端再次上线时生效。
设备优先使用User Profile下应用的无线转发策略对客户端数据进行处理。如果上线用户的User Profile下没有应用无线转发策略,则设备将使用无线服务模板下的无线转发策略处理客户端数据。
# 在User Profile下应用无线转发策略policyname。
[Sysname] user-profile profilename
[Sysname-user-profile-profilename] wlan client forward-policy-name policyname
· client forwarding-policy enable
· client-security authentication-location
wlan client reauthentication-period命令用来配置客户端二次接入认证的时间间隔。
undo wlan client reauthentication-period命令用来恢复缺省情况。
wlan client reauthentication-period [ period-value ]
客户端二次接入认证的时间间隔为10秒。
period-value:客户端二次接入认证的时间间隔,取值范围为1~3600,单位为秒,缺省值为10。
在客户端进行二次接入认证并切换VLAN的组网环境中,建议配置客户端二次接入认证的时间间隔。
客户端二次接入认证的时间间隔是指客户端通过802.1X认证或MAC地址认证(包括通过URL重定向功能完成MAC地址认证)后,RADIUS服务器强制客户端下线到再次对其进行认证的时间间隔。
配置了客户端二次接入认证的时间间隔之后,设备将已通过认证的客户端的MAC地址加入到动态黑名单中,并在指定的时间间隔内禁止客户端接入。通过此方式加入动态黑名单的MAC地址不受动态黑名单老化时间的影响。
# 配置客户端二次接入认证的时间间隔为100秒。
[Sysname] wlan client reauthentication-period 100
wlan dynamic-blacklist active-on-ap命令用来配置动态黑名单基于AP生效。
undo wlan dynamic-blacklist active-on-ap命令用来配置动态黑名单基于AC生效。
动态黑名单基于AP生效。
当配置了客户端二次接入认证的时间间隔或者AP收到客户端的攻击报文时,AC会将该客户端的MAC地址添加到动态黑名单中:
· 配置动态黑名单基于AP生效,AP将拒绝该客户端的接入,但仍可以从AC下的其他AP接入。
· 配置动态黑名单基于AC生效,AC下相连的所有AP都将拒绝该客户端接入。
在AP分布密集的无线网络环境下,建议用户配置动态黑名单基于AC生效。
# 配置动态黑名单基于AC生效。
[Sysname] undo wlan dynamic-blacklist active-on-ap
wlan dynamic-blacklist lifetime命令用来配置动态黑名单表项的老化时间。
undo wlan dynamic-blacklist lifetime命令用来恢复缺省情况。
wlan dynamic-blacklist lifetime lifetime
动态黑名单表项的老化时间为300秒。
lifetime:动态黑名单表项的老化时间,取值范围为1~3600,单位为秒。
若更新动态黑名单表项老化时间,新配置的时间只对新加入动态黑名单的客户端生效。
# 配置动态黑名单表项的老化时间为3600秒。
[Sysname] wlan dynamic-blacklist lifetime 3600
wlan forwarding-policy命令用来创建无线转发策略,并进入无线转发策略视图。如果指定的无线转发策略已经存在,则直接进入无线转发策略视图。
undo wlan forwarding-policy命令用来删除已创建的无线转发策略。
wlan forwarding-policy policy-name
undo wlan forwarding-policy policy-name
不存在无线转发策略。
无线转发策略仅识别ACL规则中的匹配条件,不识别允许和拒绝操作,即只要是匹配条件的报文,无论在ACL规则中是被允许还是被拒绝,都会被按转发策略处理。
最多能创建1000个无线转发策略。
# 创建无线转发策略abc,并进入无线转发策略视图。
[Sysname] wlan forwarding-policy abc
[Sysname-wlan-fp-abc]
wlan guest-tunnel { aggregation-ac | edge-ac }命令用来指定当前AC角色,并创建AC角色视图。如果视图已创建,则直接进入视图。
undo wlan guest-tunnel命令用来恢复缺省情况。
| WX3000H系列 | WX3010H WX3010H-X-PWR WX3010H-L-PWR WX3024H WX3024H-L-PWR WX3024H-F | EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F | 不支持 |
| AC插卡系列 | LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F | LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F | 不支持 |
| WX1800H系列 | WX1804H-PWR WX1810H-PWR WX1820H WX1840H | EWP-WX1804H-PWR EWP-WX1810H-PWR EWP-WX1820H EWP-WX1840H-GL | 不支持 |
| WX3800H系列 | WX3820H WX3840H | EWP-WX3820H-GL EWP-WX3840H-GL | 不支持 |
| WX5800H系列 | WX5860H | EWP-WX5860H-GL | 不支持 |
当前AC不是汇聚AC或者边缘AC。
aggreation-ac:指定当前AC为汇聚AC。
edge-ac:指定当前AC为边缘AC。
当已经将AC指定为某种角色时就不能再指定成另一种角色,如果要修改AC角色,请先恢复缺省情况,再进行配置。
删除AC角色视图时,视图下的所有配置和所有已建立的访客隧道也会被删除。
# 指定当前AC为汇聚AC,并创建汇聚AC视图。
wlan guest-tunnel flow-distribute enable命令用来开启访客隧道加密时的流量分发功能。
undo wlan guest-tunnel flow-distribute enable命令用来关闭访客隧道加密时的流量分发功能。
访客隧道加密时的流量分发功能处于关闭状态。
边缘AC视图
汇聚AC视图
开启本功能后,设备会先将访客隧道的流量分发到设备不同CPU上,然后通过IPSec进行加密,因为业务流量进行了分流,所以提高了IPSec隧道加密流量的转发性能。
本功能当且仅当对访客隧道配置了IPSec加密的情况下需要开启。
本功能需要同时在边缘AC和对应的汇聚AC上开启或关闭。
# 在边缘AC视图上,开启访客隧道加密时的流量分发功能。
[Sysname] wlan guest-tunnel edge-ac
[Sysname-wlan-edge-ac] wlan guest-tunnel flow-distribute enable
wlan imc命令用来配置iMC服务器的IP地址和端口号。
undo wlan imc命令用来恢复缺省情况。
wlan imc ip ip-address port port-number
undo wlan imc
未配置iMC服务器的IP地址和端口号。
ip ip-address:iMC服务器的IP地址。
port port-number:iMC服务器的端口号,取值范围为1025~65535。
配置iMC服务器的IP地址和端口号后,设备可以将AP上下线、客户端上下线以及Portal认证用户上下线等消息同步到iMC服务器,用户可以在iMC业务软件上查看到相关信息。
# 配置iMC服务器的IP地址和端口号。
[Sysname] wlan imc ip 1.1.1.1 port 65535
wlan link-test命令用来对客户端进行无线链路质量检测。
wlan link-test mac-address
mac-address:客户端MAC地址,格式为H-H-H。
无线链路质量检测,即AP根据客户端上线时协商的速率集,以每个速率发送5个空数据报文进行链路质量检测。AP根据客户端的响应报文可以获取AP客户端之间的无线链路质量信息,如信号强度、报文重传次数、RTT(Round-Trip Time,往返时间)等。
无线链路质量检测的超时时间为10秒,如果AP在超时时间内没有完成链路质量检测,将无法得到链路质量检测结果。
# 对MAC地址为60a4-4cda-eff0的客户端进行无线链路质量检测。
<Sysname> wlan link-test 60a4-4cda-eff0
Testing link to 60a4-4cda-eff0. Press CTRL + C to break.
Link Status
MAC address: 60a4-4cda-eff0
VHT-MCS Rate(Mbps) Tx packets Rx packets RSSI Retries RTT(ms)
NSS = 1
0 32.5 5 5 54 0 0
1 65 5 5 51 0 0
2 97.5 5 5 49 0 0
3 130 5 5 47 0 0
4 195 5 5 45 0 0
5 260 5 5 45 0 0
6 292.5 5 5 44 0 0
7 325 5 5 44 0 0
8 390 5 5 44 0 0
9 433.3 5 5 43 0 0
NSS = 2
0 65 5 5 44 0 0
1 130 5 5 44 0 0
2 195 5 5 44 0 0
3 260 5 5 44 0 0
4 390 5 5 44 0 0
5 520 5 5 44 0 0
6 585 5 5 43 0 0
7 650 5 5 43 0 0
8 780 5 5 43 0 0
9 866.7 5 5 43 0 0
<Sysname> wlan link-test 784f-43b6-077c
Testing link to 784f-43b6-077c. Press CTRL + C to break.
Link Status
MAC address: 784f-43b6-077c
0 6.5 5 5 54 0 0
1 13 5 5 51 0 0
2 19.5 5 5 49 0 0
3 26 5 5 47 0 0
4 39 5 5 45 0 0
5 52 5 5 45 0 0
6 58.5 5 5 44 0 0
7 72.2 5 5 44 0 0
8 13 5 5 44 0 0
9 26 5 5 43 0 0
10 39 5 5 44 0 0
11 52 5 5 44 0 0
12 78 5 5 44 0 0
13 104 5 5 44 0 0
14 117 5 5 44 0 0
15 144.4 5 5 44 11 0
表1-27 链路质量检测结果
| 字段 | 描述 |
| No./MCS/VHT-MCS | · No:对802.11a、802.11b或802.11g客户端进行链路质量检测的速率编号 · MCS:对802.11n客户端进行链路质量检测的MCS索引值 · VHT-MCS:对802.11ac客户端进行链路质量检测的VHT-MCS索引值 |
| Rate(Mbps) | AP发送无线链路质量检测包的速率 |
| Tx packets | AP发送无线链路质量检测包的个数 |
| Rx packets | AP收到客户端响应报文的个数 |
| RSSI | 接收信号强度指示,表示AP检测到客户端的信号强度 |
| AP重传无线链路质量检测包的次数 | |
| RTT(ms) | 从AP发出无线链路质量检测包到收到客户端回应的平均往返时间 |
| NSS | 对802.11n或802.11ac客户端进行链路质量检测的空间流数 |
wlan lite-control-mode enable命令用来开启轻量控制模式。
undo wlan lite-control-mode enable命令用来关闭轻量控制模式。
轻量控制模式处于关闭状态。
在开启或者关闭轻量控制模式时,会清空当前配置并重启,该操作会导致AP下线和业务中断。
轻量控制模式是一种客户端数据报文仅支持在AP上进行转发的控制模式。开启轻量控制模式功能后,配置client forwarding-location命令时,配置不生效。该模式适用于客户业务需求不依赖于集中式转发模式,且同时需要管理更多AP的场景。
# 开启轻量控制模式。
[Sysname] wlan lite-control-mode enable
Enabling the lite control mode will clear current configuration and restart the device. Continue? [Y/N]:y
# 关闭轻量控制模式。
[Sysname] undo wlan lite-control-mode enable
Disabling the lite control mode will clear current configuration and restart the device. Continue? [Y/N]:y
· client forwarding-location
本命令的支持情况与AP设备的型号有关,请以设备的实际情况为准。
wlan management-wifi ssid-hide命令用来隐藏AP管理Wi-Fi的SSID。
undo wlan management-wifi ssid-hide命令用来取消隐藏AP管理Wi-Fi的SSID。
AP不会隐藏管理Wi-Fi的SSID。
全局配置视图
AP发射的无线信号中,提供给管理员和员工接入的Wi-Fi属于管理Wi-Fi,提供给访客接入的Wi-Fi不属于管理Wi-Fi。在以下情形下可以隐藏AP管理Wi-Fi的SSID:
· 出于安全考虑,隐藏管理Wi-Fi的SSID,以防止访客接入管理Wi-Fi。管理员和员工首次接入管理Wi-Fi时需要手工输入SSID和接入密码。
· 访客接入无线网络前,若搜索到过多管理Wi-Fi的SSID,可能会影响访客选择。隐藏管理Wi-Fi的SSID,可以方便访客搜索到访客专用Wi-Fi并接入。
使用本命令前,请先将云AP在AC上完成上线。
# 隐藏AP管理Wi-Fi的SSID。
[Sysname] wlan global-configuraiton
[Sysname-wlan-global-configuraiton] wlan management-wifi ssid-hide
wlan nas-port-id format命令用来配置无线客户端的NAS-Port-ID属性的格式。
undo wlan nas-port-id format命令用来恢复缺省情况。
wlan nas-port-id format { 2 | 4 }
NAS-Port-ID的消息格式为格式2。
2:表示格式2,具体为SlotID00IfNOVlanID。
4:表示格式4,具体为slot=**;subslot=**;port=**;vlanid=**;vlanid2=**。
不同厂商的RADIUS服务器对于NAS-Port-ID格式有不同的要求。可通过本命令修改无线802.1X或MAC地址认证用户发送的RADIUS报文中填充的NAS-Port-ID属性的格式。
· 格式2
SlotID00IfNOVlanID
各项含义如下:
¡ SlotID:用户接入的槽位号,为两个字符的字符串。
¡ IfNO:用户接入的接口编号,为3个字符的字符串。
¡ VlanID:用户接入的VLAN ID,为9个字符的字符串。
· 格式4
对于在未终结VLAN的接口上接的用户:其格式为slot=**;subslot=**;port=**;vlanid=**。
对于在终结了外层VLAN的接口上接入的用户:其格式为slot=**;subslot=**;port=**;vlanid=**;vlanid2=**。
需要注意的是,如果有配置过nas-port-id命令,以nas-port-id命令配置的为准。
# 配置无线客户端的NAS-Port-ID属性的格式为格式4。
[Sysname] wlan nas-port-id format 4
· nas-port-id
wlan permit-ap-group命令用来配置允许用户接入的AP组。
undo wlan permit-ap-group命令用来删除指定的允许用户接入的AP组。
wlan permit-ap-group ap-group-name
undo wlan permit-ap-group [ ap-group-name ]
未配置允许用户接入的AP组。
User Profile视图
ap-group-name:允许用户接入的AP组的名称,为1~31个字符的字符串,不区分大小写。
当配置undo wlan permit-ap-group命令时,如果未指定允许用户接入的AP组,则删除所有允许用户接入的AP组。
当配置允许用户接入的AP组时,只有用户关联的AP在某个AP组内,用户才可接入。
当未配置允许用户接入的AP组时,不对用户接入进行限制。
# 配置允许用户接入的AP组为group1。
[Sysname] user-profile profile1
[Sysname-user-profile-profile1] wlan permit-ap-group group1
wlan permit-ssid命令用来配置允许用户接入的SSID名称。
undo wlan permit-ssid命令用来删除指定的允许用户接入的SSID名称。
wlan permit-ssid ssid-name
undo wlan permit-ssid [ ssid-name ]
未配置允许用户接入的SSID名称。
User Profile视图
当配置undo wlan permit-ssid命令时,如果未指定允许用户接入的SSID名称,则删除所有允许用户接入的SSID名称。
当配置允许用户接入的SSID名称时,只有用户关联的SSID与配置的某一个SSID匹配,用户才可接入。
当未配置允许用户接入的SSID名称,不对用户接入进行限制。
# 配置允许接入的SSID名称为ssid1。
[Sysname-user-profile-profile1] wlan permit-ssid ssid1
wlan service-template命令用来创建无线服务模板,并进入无线服务模板视图。如果指定的无线服务模板已经存在,则直接进入无线服务模板视图。
undo wlan service-template命令用来删除无线服务模板。
wlan service-template service-template-name
undo wlan service-template service-template-name
不存在无线服务模板。
删除无线服务模板时,如果指定的无线服务模板映射到射频,则在解除映射之前不能删除此无线服务模板。
# 创建无线服务模板service1,并进入无线服务模板视图。
wlan static-blacklist mac-address命令用来添加静态黑名单表项。
undo wlan static-blacklist命令用来删除静态黑名单。
wlan static-blacklist mac-address mac-address
undo wlan static-blacklist [ mac-address mac-address ]
不存在静态黑名单。
mac-address mac-address:将指定MAC地址的客户端添加到静态黑名单,mac-address
的格式为H-H-H。
配置静态黑名单后,名单中的客户端将不允许上线,如果静态黑名单中的客户端在线,设备会解除与该客户端的关联。undo wlan static-blacklist命令中,如果未指定本参数,则表示将静态黑名单中所有客户端从静态黑名单中删除。
同一个客户端不能同时存在静态黑名单和白名单中。
黑名单的MAC地址不能设置为组播或者广播地址。
# 添加静态黑名单表项001c-f0bf-9c92。
[Sysname] wlan static-blacklist mac-address 001c-f0bf-9c92
wlan vip-client-group命令用来创建VIP客户端组,并进入VIP客户端组视图。如果VIP客户端组已经存在,则直接进入VIP客户端组视图。
undo wlan vip-client-group命令用来删除VIP客户端组。
不存在VIP客户端组。
VIP客户端组为一些客户端的集合,用户可以通过云平台VIP客户端页面查看添加到VIP客户端组中的上线客户端信息。
# 创建VIP客户端组,并进入VIP客户端组视图。
[Sysname] wlan vip-client-group
wlan web-server api-path命令用来指定接收客户端信息的Web服务器的路径。
undo wlan web-server api-path命令用来恢复缺省情况。
wlan web-server api-path path
未指定接收客户端信息的Web服务器的路径。
path:接收客户端信息的Web服务器的路径,为1~256个字符的字符串,区分大小写。
指定接收客户端信息的Web服务器的路径后,服务器才会接收并保存客户端信息。
# 指定接收客户端信息的Web服务器的路径为wlan/dev-cfg(Web服务器的URL为http://www.abc.com:668/wlan/dev-cfg)。
[Sysname] wlan web-server api-path /wlan/dev-cfg
· wlan web-server host
· wlan web-server max-client-entry
wlan web-server host命令用来配置接收客户端信息的Web服务器的域名和端口号。
undo wlan web-server host命令用来恢复缺省情况。
wlan web-server host host-name port port-number
未配置接收客户端信息的Web服务器的域名和端口号。
host host-name:指定Web服务器的域名,host-name为3~127个字符的字符串,不区分大小写,可以包含字母、数字、“-”、“_”和“.”。
port port-number:指定Web服务器的端口号,port-number取值范围为1~65534。
配置接收客户端信息的Web服务器的域名和端口号后,设备将与Web服务器建立连接并上报关联客户端的信息。
设备与Web服务器建立连接后,如果已关联客户端的信息发生变化或有新的客户端关联,设备会将变化和新增客户端的信息实时上报给Web服务器。
# 配置接收客户端信息的Web服务器的域名为www.abc.com,端口号为668。
[Sysname] wlan web-server host www.abc.com port 668
· wlan web-server api-path
wlan web-server max-client-entry命令用来配置设备一次向Web服务器上报客户端信息的最大数目。
undo wlan web-server max-client-entry命令用来恢复缺省情况。
wlan web-server max-client-entry number
设备一次向Web服务器上报客户端信息的最大数目为10。
number:一次向Web服务器上报客户端信息的数目,取值范围为1~25。
# 配置设备一次向Web服务器上报客户端信息的最大数目为12。
[Sysname] wlan web-server max-client-entry 12
wlan whitelist mac-address命令用来添加白名单表项。
undo wlan whitelist命令用来删除白名单表项。
wlan whitelist mac-address mac-address
undo wlan whitelist [ mac-address mac-address ]
不存在白名单。
mac-address mac-address:白名单中的客户端的MAC地址,mac-address的格式为H-H-H。如果没有指定本参数,则表示所有白名单表项。
第一次配置白名单时,设备会先解除与当前在线的所有客户端的关联,并且只有在白名单内的客户端才允许上线。
删除某个白名单表项时,如果对应的客户端在线,则设备会解除与该客户端的关联;如果没有指定参数,则表示所有白名单表项。删除所有白名单时,不会解除与任何在线客户端的关联。至于是否允许客户端上线,还得看有没有黑名单。
白名单的MAC地址不能设置为组播或者广播地址。
# 添加白名单表项。
[Sysname] wlan whitelist mac-address 001c-f0bf-9c92
This command will disconnect all clients. Continue? [Y/N]:
· display wlan whiteliest
