04-DHCP命令
本章节下载: 04-DHCP命令 (567.57 KB)
1.2.12 dhcp server always-broadcast
1.2.13 dhcp server apply ip-pool
1.2.14 dhcp server bootp ignore
1.2.15 dhcp server bootp reply-rfc-1048
1.2.16 dhcp server database filename
1.2.17 dhcp server database update interval
1.2.18 dhcp server database update now
1.2.19 dhcp server database update stop
1.2.20 dhcp server forbidden-ip
1.2.22 dhcp server ping packets
1.2.23 dhcp server ping timeout
1.2.24 dhcp server relay information enable
1.2.25 dhcp server reply-exclude-option60
1.2.26 display dhcp server conflict
1.2.27 display dhcp server database
1.2.28 display dhcp server expired
1.2.29 display dhcp server free-ip
1.2.30 display dhcp server ip-in-use
1.2.31 display dhcp server pool
1.2.32 display dhcp server statistics
1.2.47 reset dhcp server conflict
1.2.48 reset dhcp server expired
1.2.49 reset dhcp server ip-in-use
1.2.50 reset dhcp server statistics
1.2.52 tftp-server domain-name
1.3.1 dhcp relay check mac-address
1.3.2 dhcp relay check mac-address aging-time
1.3.3 dhcp relay client-information record
1.3.4 dhcp relay client-information refresh
1.3.5 dhcp relay client-information refresh enable
1.3.6 dhcp relay forward reply by-option82
1.3.8 dhcp relay information circuit-id
1.3.9 dhcp relay information enable
1.3.10 dhcp relay information remote-id
1.3.11 dhcp relay information strategy
1.3.13 dhcp relay server-address
1.3.14 dhcp relay source-address
1.3.15 dhcp smart-relay enable
1.3.16 display dhcp relay check mac-address
1.3.17 display dhcp relay client-information
1.3.18 display dhcp relay information
1.3.19 display dhcp relay server-address
1.3.20 display dhcp relay statistics
1.3.23 reset dhcp relay client-information
1.3.24 reset dhcp relay statistics
dhcp client-detect命令用来开启DHCP服务器或DHCP中继的用户下线探测功能。
undo dhcp client-detect命令用来关闭DHCP服务器或DHCP中继的用户下线探测功能。
dhcp client-detect
DHCP服务器或DHCP中继的用户下线探测功能处于关闭状态。
DHCP服务器开启该功能后,当设备上的ARP表项老化时,DHCP服务器认为该表项对应的DHCP客户端已经下线,DHCP服务器会删除对应的IP地址租约。
DHCP中继开启该功能后,当设备上的ARP表项老化时,DHCP中继认为该表项对应的DHCP客户端已经下线,DHCP中继会删除对应的用户地址表项,并通过发Release报文通知DHCP服务器删除下线用户的IP地址租约。
# 开启用户下线探测功能。
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] dhcp client-detect
dhcp dscp命令用来配置DHCP服务器或DHCP中继发送DHCP报文的DSCP优先级。
undo dhcp dscp命令用来恢复缺省情况。
dhcp dscp dscp-value
undo dhcp dscp
DHCP服务器或DHCP中继发送DHCP报文的DSCP优先级为56。
dscp-value:DHCP报文的DSCP优先级,取值范围为0~63。
# 配置DHCP服务器或DHCP中继发送的DHCP报文的DSCP优先级为30。
[Sysname] dhcp dscp 30
dhcp enable命令用来开启DHCP服务。
undo dhcp enable命令用来关闭DHCP服务。
dhcp enable
undo dhcp enable
DHCP服务处于关闭状态。
只有开启DHCP服务后,其它相关的DHCP配置才能生效。
配置DHCP服务器和DHCP中继时,都需要先开启DHCP服务。
# 开启DHCP服务。
[Sysname] dhcp enable
dhcp log enable命令用来开启DHCP服务器日志信息功能。
undo dhcp log enable命令用来关闭DHCP服务器日志信息功能。
dhcp log enable
DHCP服务器日志信息功能处于关闭状态。
DHCP服务器日志可以方便管理员定位问题和解决问题。设备生成DHCP日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启DHCP服务器日志信息功能。
[Sysname] dhcp log enable
dhcp select命令用来配置接口工作在DHCP服务器或DHCP中继模式。
undo dhcp select命令用来取消接口工作在DHCP服务器或DHCP中继模式,即接口将丢弃DHCP客户端发来的DHCP报文。
dhcp select { relay | server }
undo dhcp select { relay | server }
接口工作在DHCP服务器模式,即当接口收到DHCP客户端发来的DHCP报文时,将从DHCP服务器的地址池中分配地址等参数。
relay:配置接口工作在DHCP中继模式。
server:配置接口工作在DHCP服务器模式。
接口从DHCP服务器模式切换到DHCP中继模式后,设备不会删除IP地址绑定信息,也不会删除相应的授权ARP表项。这些表项可能会与DHCP中继新生成的ARP表项冲突。因此,建议接口从DHCP服务器模式切换到DHCP中继模式之前,通过reset dhcp server ip-in-use命令清除已有的IP地址绑定信息。
# 配置接口GigabitEthernet1/0工作在DHCP中继模式。
[Sysname-GigabitEthernet1/0] dhcp select relay
· dhcp smart-relay enable
· reset dhcp server ip-in-use
address range命令用来配置地址池动态分配的IP地址范围。
undo address range命令用来恢复缺省情况。
undo address range
未配置动态分配的IP地址范围。
DHCP地址池视图
start-ip-address:动态分配范围的起始IP地址。
end-ip-address:动态分配范围的结束IP地址。
如果未通过本命令配置地址池动态分配的IP地址范围,则地址池下network命令指定的网段地址都可以分配给DHCP客户端;如果通过本命令配置了地址池动态分配的IP地址范围,则只能从本命令指定的IP地址范围内选择地址分配给客户端。
配置address range命令后,不能再通过network secondary命令在地址池中配置从网段。
多次执行本命令,最后一次执行的命令生效。
address range命令指定的地址范围应该在network命令指定的网段范围内,网段范围外的地址将无法被分配。
# 配置地址池1动态分配的地址范围为192.168.8.1到192.168.8.150。
[Sysname] dhcp server ip-pool 1
[Sysname-dhcp-pool-1] network 192.168.8.1 mask 255.255.255.0
[Sysname-dhcp-pool-1] address range 192.168.8.1 192.168.8.150
· class
· dhcp class
· display dhcp server pool
· network
bims-server命令用来配置DHCP地址池为DHCP客户端分配的BIMS服务器IP地址、端口及共享密钥信息。
undo bims-server命令用来恢复缺省情况。
undo bims-server
未配置DHCP地址池为DHCP客户端分配的BIMS服务器信息。
DHCP地址池视图
ip ip-address:指定BIMS服务器的IP地址。
port port-number:指定BIMS服务器的端口号。port-number为端口号,取值范围为1~65534。
cipher:以密文形式设置密钥。
simple:以明文形式设置密钥,该密钥将以密文方式存储。
string:密钥字符串,区分大小写。明文密钥为1~16个字符的字符串,密文密钥为1~53个字符的字符串。DHCP客户端获取到BIMS服务器的信息后,与BIMS服务器通信时,采用共享密钥对传递的消息进行加密,以保证消息传递的安全性。
# 配置DHCP地址池0为DHCP客户端分配的BIMS服务器的IP地址为1.1.1.1,端口号为80,共享密钥为aabbcc。
[Sysname] dhcp server ip-pool 0
[Sysname-dhcp-pool-0] bims-server ip 1.1.1.1 port 80 sharekey simple aabbcc
bootfile-name命令用来配置DHCP客户端使用的启动文件名或远程启动文件的HTTP形式URL。
undo bootfile-name命令用来恢复缺省情况。
bootfile-name { bootfile-name | url }
undo bootfile-name
未配置DHCP客户端使用的启动文件名或远程启动文件的HTTP形式URL。
DHCP地址池视图
bootfile-name:启动文件名,为1~63个字符的字符串,区分大小写。
url:远程启动文件的HTTP形式URL,为1~63个字符的字符串,区分大小写。
当启动文件在TFTP服务器上,使用bootfile-name参数指定DHCP客户端使用的启动文件名;当启动文件在HTTP服务器上,使用url参数指定远程启动文件的HTTP形式URL。
# 配置DHCP地址池0为DHCP客户端分配的启动文件名为boot.cfg。
[Sysname-dhcp-pool-0] bootfile-name boot.cfg
# 配置DHCP地址池0为DHCP客户端分配的启动文件的HTTP URL为http://10.1.1.1/boot.cfg。
[Sysname-dhcp-pool-0] bootfile-name http://10.1.1.1/boot.cfg
· next-server
· tftp-server domain-name
· tftp-server ip-address
class ip-pool命令用来指定DHCP用户类关联的DHCP地址池。
undo class ip-pool命令删除为指定DHCP用户类关联的DHCP地址池。
undo class class-name ip-pool
未指定DHCP用户类关联的DHCP地址池。
DHCP策略视图
class-name:DHCP用户类名称,为1~63个字符的字符串,不区分大小写。
pool-name:DHCP地址池名称,为1~63个字符的字符串,不区分大小写。
对于一个DHCP用户类,在一个DHCP策略中只能关联一个DHCP地址池。
多次执行本命令为同一个DHCP用户类关联不同的DHCP地址池,最后一次执行的命令生效。
# 在DHCP策略1中,配置DHCP用户类test关联DHCP地址池pool1。
[Sysname] dhcp policy 1
[Sysname-dhcp-policy-1] class test ip-pool pool1
· default ip-pool
· dhcp policy
· dhcp server ip-pool
class option-group命令用来配置DHCP地址池下DHCP用户类和DHCP选项组的关联。
undo class option-group命令用来删除DHCP地址池下DHCP用户类和DHCP选项组的关联。
undo class class-name option-group
未配置DHCP地址池的DHCP用户类和DHCP选项组的关联。
DHCP地址池视图
option-group-number:DHCP选项组编号,取值范围为1~32768。
DHCP服务器应答DHCP客户端报文时,首先根据配置顺序逐个匹配通过class option-group命令指定的DHCP用户类。如果匹配成功,则将该用户类对应的选项组中的选项填充到应答报文中;如果同时匹配多个DHCP用户类,且各用户类对应的选项组中有相同编号的选项,以最先匹配到DHCP用户类对应的选项组中的选项为准。
需要注意的是,对于一个DHCP用户类,在一个DHCP地址池中只能指定一个选项组。多次执行本命令为同一个DHCP用户类指定不同的选项组,最后一次执行的命令生效。
# 在DHCP地址池0中,配置DHCP用户类user和DHCP选项组1的关联。
[Sysname-dhcp-pool-0] class user option-group 1
· dhcp option-group
class range命令用来配置DHCP地址池为指定DHCP用户类动态分配的IP地址范围。
undo class range命令用来删除为指定DHCP用户类动态分配的IP地址范围。
undo class class-name range
未配置为指定DHCP用户类动态分配的IP地址范围。
DHCP地址池视图
class-name:DHCP用户类名称,为1~63个字符的字符串,不区分大小写。如果指定的DHCP用户类不存在,则为该用户类指定的地址范围不能分配给任何DHCP客户端。
DHCP服务器从地址池中选择地址分配给客户端时,首先根据配置顺序逐个匹配通过class range命令指定的DHCP用户类。如果匹配成功,则从为该用户类指定的地址范围内选择地址分配给DHCP客户端;如果该用户类中没有可供分配的地址,则继续匹配下一个用户类;如果所有匹配上的用户类地址范围都没有可供分配的地址,则从公共地址范围中选择地址分配给客户端;如果不匹配任何DHCP用户类,则会从地址池动态分配的IP地址范围(通过address range命令配置)中选择地址分配给DHCP客户端;如果address range命令指定的地址范围内也没有空闲地址,或者未配置address range命令,则地址分配失败,即DHCP服务器无法为DHCP客户端分配地址。
通过本配置可以实现将一个地址池下的地址范围划分成多个地址段,分别分配给属于不同DHCP用户类的DHCP客户端。
配置class range命令后,不能再通过network secondary命令在地址池中配置从网段。
配置class range命令后,只能从class range命令或address range命令指定的地址范围内选择地址分配给客户端。
一个地址池中只能为一个DHCP用户类指定一个地址范围。多次执行本命令为同一个DHCP用户类指定不同的地址范围,最后一次执行的命令生效。
一个地址池中可以为多个不同的DHCP用户类指定地址范围。
class range命令指定的地址范围应该在network命令指定的主网段范围内,主网段范围外的地址将无法被分配。
# 在地址池1中配置为DHCP用户类user动态分配的地址范围为192.168.8.1到192.168.8.150。
[Sysname-dhcp-pool-1] class user range 192.168.8.1 192.168.8.150
· address range
· dhcp class
default ip-pool命令用来指定默认DHCP地址池。
undo default ip-pool命令用来恢复缺省情况。
default ip-pool pool-name
未指定默认DHCP地址池。
DHCP策略视图
pool-name:默认DHCP地址池名称,为1~63个字符的字符串,不区分大小写。
若匹配DHCP策略中的所有DHCP用户类失败,当配置了默认DHCP地址池时,则从该地址池中分配IP地址和其他参数;当未配置默认DHCP地址池或默认DHCP地址池中不存在可供分配的地址信息时,IP地址和其他参数分配失败。
在一个DHCP策略视图中,只能配置一个默认DHCP地址池。多次执行本命令,最后一次执行的命令生效。
# 在DHCP策略1中指定默认DHCP地址池pool1。
[Sysname-dhcp-policy-1] default ip-pool pool1
· class ip-pool
· dhcp policy
dhcp apply-policy命令用来指定接口引用的DHCP策略。
undo dhcp apply-policy命令用来恢复缺省情况。
dhcp apply-policy policy-name
接口未引用DHCP策略。
policy-name:DHCP策略名称,为1~63个字符的字符串,不区分大小写。
在一个接口上只能引用一条DHCP策略。在同一个接口上多次执行本命令,最后一次执行的命令生效。
# 指定接口GigabitEthernet1/0引用的DHCP策略test。
[Sysname-GigabitEthernet1/0] dhcp apply-policy test
· dhcp policy
dhcp class命令用来创建DHCP用户类并进入DHCP用户类视图,如果指定的DHCP用户类已存在,则直接进入用户类视图。
undo dhcp class命令用来删除指定的DHCP用户类。
dhcp class class-name
undo dhcp class class-name
不存在DHCP用户类。
class-name:DHCP用户类的名称,为1~63个字符的字符串,不区分大小写。
在DHCP用户类视图下,可以通过if-match命令配置DHCP用户类的匹配规则,根据匹配规则判断DHCP客户端属于的DHCP用户类,从而实现灵活的用户分类策略。
# 创建名称为test的DHCP用户类,并进入DHCP用户类视图。
[Sysname] dhcp class test
[Sysname-dhcp-class-test]
· address range
· class ip-pool
· class option-group
· class range
· dhcp policy
· if-match
dhcp option-group命令用来创建DHCP选项组并进入DHCP选项组视图,如果指定的DHCP选项组已存在,则直接进入DHCP选项组视图。
undo dhcp option-group命令用来删除指定的DHCP选项组。
undo dhcp option-group option-group-number
不存在DHCP选项组。
# 创建DHCP选项组1并进入该选项组视图。
[Sysname] dhcp option-group 1
[Sysname-dhcp-option-group-1]
· option
dhcp policy命令用来创建DHCP策略,并进入DHCP策略视图。如果指定的DHCP策略已存在,则直接进入DHCP策略视图。
undo dhcp policy命令用来删除已创建的DHCP策略。
dhcp policy policy-name
undo dhcp policy policy-name
不存在DHCP策略。
在DHCP策略视图下,可以通过class ip-pool命令指定DHCP用户类关联的DHCP地址池,使匹配该DHCP用户类的客户端可以从关联的地址池中获取到IP地址和其他参数。
需要注意的是,需要配置dhcp apply-policy命令在接口上引用DHCP策略后,DHCP策略才能生效。
# 创建DHCP策略test,并进入该DHCP策略视图。
[Sysname] dhcp policy test
[Sysname-dhcp-policy-test]
· class ip-pool
· default ip-pool
· dhcp apply-policy
· dhcp class
dhcp server always-broadcast命令用来开启DHCP服务器的广播回应报文功能。
undo dhcp server always-broadcast命令用来恢复缺省情况。
DHCP服务器的广播回应报文功能处于关闭状态。DHCP服务器根据请求报文中的广播标志位来决定以广播还是单播的形式发送应答报文。
开启DHCP服务器的广播回应报文功能后,DHCP服务器忽略请求报文中的广播标志位,以广播的形式发送应答报文。
# 开启DHCP服务器的广播回应报文功能。
[Sysname] dhcp server always-broadcast
dhcp server apply ip-pool命令用来指定接口引用的地址池。
undo dhcp server apply ip-pool命令用来恢复缺省情况。
接口未引用地址池。
如果接口上配置了本命令,则接口接收到DHCP请求后,将优先为客户端分配静态绑定的IP地址;如果不存在静态绑定的IP地址,则从引用的地址池中选择IP地址分配给客户端。引用的地址池中不存在可供分配的IP地址时,设备无法为客户端分配IP地址。
接口上配置了dhcp server apply ip-pool命令后,如果接口引用的地址池不存在,则无法为客户端动态分配IP地址。
# 配置接口GigabitEthernet1/0引用DHCP地址池0。
[Sysname-GigabitEthernet1/0] dhcp server apply ip-pool 0
dhcp server bootp ignore命令用来配置DHCP服务器忽略BOOTP请求。
undo dhcp server bootp ignore命令用来恢复缺省情况。
DHCP服务器不会忽略BOOTP请求。
BOOTP客户端申请到的地址的租约是无限期的。在特殊的组网环境中,可能不希望出现无限期的地址租约。此时,可以通过配置DHCP服务器忽略BOOTP请求报文,避免分配无限期的地址租约。
# 配置DHCP服务器忽略BOOTP请求。
[Sysname] dhcp server bootp ignore
dhcp server bootp reply-rfc-1048命令用来开启DHCP服务器回应RFC 1048格式报文功能。
undo dhcp server bootp reply-rfc-1048命令用来关闭DHCP服务器回应RFC 1048格式报文功能。
DHCP服务器回应RFC 1048格式报文功能处于关闭状态。
# 开启DHCP服务器的回应RFC 1048格式报文功能。
[Sysname] dhcp server bootp reply-rfc-1048
dhcp server database filename命令用来指定存储DHCP服务器表项的文件名称。
undo dhcp server database filename命令用来恢复缺省情况。
未指定存储DHCP服务器表项的文件名称。
url url:配置远程目标文件URL,为1~255个字符的字符串,区分大小写,该配置用于远程文件系统模式。此参数中不能包含用户名和密码,和参数username和string配合使用。
username username:配置远程目标文件URL时的用户名,为1~32个字符的字符串,区分大小写。如果未指定本参数,则表示登录远程目标文件URL时无需使用用户名。
cipher:表示以密文方式设置用户密码。
string:密码字符串,区分大小写。明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串。如果未指定本参数,则表示登录远程目标文件URL时无需使用密码。
存储DHCP服务器表项时,如果设备中还不存在对应名称的文件,则设备会自动创建该文件。
执行本命令后,会立即触发一次表项备份。之后,如果未配置dhcp server database update interval命令,若表项发生变化,默认在300秒之后刷新存储文件;若表项未发生变化,则不再刷新存储文件。如果配置了dhcp server database update interval命令,若表项发生变化,则到达刷新时间间隔后刷新存储文件;若表项未发生变化,则不再刷新存储文件。
参数filename不支持远程目标文件URL,配置远程目标文件URL请使用url、username、string配合使用。
频繁擦写本地存储介质可能会影响存储介质寿命,建议使用远程文件系统模式存储DHCP服务器表项文件。
当进行远程存储时,支持FTP和TFTP协议:
· 当采用FTP或TFTP协议时,服务器地址支持IPv4形式或IPv6形式,并且支持DNS域名方式。服务器地址为IPv6地址形式时需使用方括号(“[”和“]”)引用。配置服务器地址为DNS域名格式时请勿使用方括号引用。
· 当采用FTP协议时,URL采用“ftp://服务器地址[:端口号]/文件路径”的形式,如有用户名和密码请分别使用参数username和参数string进行配置,用户名和密码必须和服务器上的配置一致,如果服务器只对用户名进行认证,则不用输入密码。
· 当采用TFTP协议时,URL采用“tftp://服务器地址[:端口号]/文件路径”的形式。
# 配置存储DHCP服务器表项的文件名为database.dhcp。
[Sysname] dhcp server database filename database.dhcp
# 配置远程存储DHCP服务器表项至IP地址为10.1.1.1的FTP服务器工作目录下,用户名为1,密码为1,文件名为database.dhcp。
[Sysname] dhcp server database filename url ftp://10.1.1.1/database.dhcp username 1 password simple 1
· dhcp server database update interval
· dhcp server database update now
· dhcp server database update stop
dhcp server database update interval命令用来配置刷新DHCP服务器表项存储文件的延迟时间。
undo dhcp server database update interval命令用来恢复缺省情况。
若DHCP服务器表项不变化,则不刷新表项存储文件;若DHCP服务器表项发生变化,默认在300秒后刷新表项存储文件。
执行本命令后,当服务器表项发生变化后,DHCP服务器开始计时,当本命令配置的延迟时间到达后,DHCP服务器会把这个时间段内表项所有的变化信息备份到固化文件中。
如果未通过dhcp server database filename命令指定存储表项的文件,则本命令的配置不会生效。
# 若DHCP服务器表项发生变化,在10分钟后刷新表项存储文件。
[Sysname] dhcp server database update interval 600
· dhcp server database filename
dhcp server database update now命令用来将当前DHCP服务器表项保存到用户指定的文件中。
本命令只用来触发一次DHCP服务器表项的备份。
# 将当前的DHCP服务器表项保存到文件中。
[Sysname] dhcp server database update now
dhcp server database update stop命令用来终止当前的DHCP服务器表项恢复操作。
本命令只用来触发一次终止DHCP服务器表项的恢复操作。
从固化文件恢复表项的连接超时的最长时间为60分钟,可以通过本命令立刻终止远程恢复。DHCP服务器从固化文件中恢复表项的过程中,DHCP服务器不会学习新的表项。
# 终止当前的DHCP服务器表项恢复操作。
[Sysname] dhcp server database update stop
dhcp server forbidden-ip命令用来配置全局不参与自动分配的IP地址。
undo dhcp server forbidden-ip命令用来取消全局不参与自动分配的IP地址的配置。
undo dhcp server forbidden-ip start-ip-address [ end-ip-address ] [ vpn-instance vpn-instance-name ]
未配置全局不参与自动分配的IP地址。
start-ip-address:不参与自动分配的起始IP地址。
end-ip-address:不参与自动分配的结束IP地址,不能小于start-ip-address。如果未指定本参数,则表示只有一个不参与自动分配的IP地址,即start-ip-address;否则,表示start-ip-address到end-ip-address之间的IP地址均不能参与自动分配。
vpn-instance vpn-instance-name:指定不参与自动分配的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示配置的是公网中不参与自动分配的IP地址。
某些服务器占用的IP地址(如网关地址、FTP服务器地址),不能分配给DHCP客户端。通过本命令可以避免这些地址参与自动分配。
如果通过dhcp server forbidden-ip命令将已经静态绑定的IP地址配置为不参与自动分配的地址,则该地址仍然可以分配给静态绑定的用户。
执行undo dhcp server forbidden-ip命令取消不参与自动分配IP地址的配置时,指定的地址/地址范围必须与执行dhcp server forbidden-ip命令时指定的地址/地址范围保持一致。如果配置不参与自动分配的IP地址为某一地址范围,则只能同时取消该地址范围内所有IP地址的配置,不能单独取消其中某个IP地址的配置。
# 配置10.110.1.1到10.110.1.63之间的IP地址不参与地址自动分配。
[Sysname] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
· forbidden-ip
· static-bind
dhcp server ip-pool命令用来创建DHCP地址池并进入DHCP地址池视图。如果已经创建了DHCP地址池,则直接进入该地址池视图。
undo dhcp server ip-pool命令用来删除指定的地址池。
dhcp server ip-pool pool-name
undo dhcp server ip-pool pool-name
不存在DHCP地址池。
pool-name:DHCP地址池名称,是地址池的唯一标识,为1~63个字符的字符串,不区分大小写。
在DHCP地址池下,可以配置为DHCP客户端分配的IP地址、网关地址等参数。
# 创建名称为pool1的DHCP地址池。
[Sysname] dhcp server ip-pool pool1
[Sysname-dhcp-pool-pool1]
· class ip-pool
· dhcp server apply ip-pool
dhcp server ping packets命令用来配置DHCP服务器发送ICMP回显请求报文的最大数目。
undo dhcp server ping packets命令用来恢复缺省情况。
DHCP服务器发送ICMP回显请求报文的最大数目为1。
number:发送ICMP回显请求报文的最大数目,取值范围为0~10。0表示DHCP服务器将IP地址分配给DHCP客户端之前,不会通过ping操作探测该地址是否冲突。
DHCP服务器的地址探测是通过ping功能实现的,通过检测是否能在指定时间内得到ping响应来判断是否存在地址冲突。DHCP服务器发送目的地址为待分配地址的ICMP回显请求报文。如果在指定时间内收到ICMP回显响应报文,则认为存在地址冲突。DHCP服务器从地址池中选择新的IP地址,并重复上述操作。如果在指定时间内未收到ICMP回显响应报文,则继续发送ICMP回显请求报文,直到发送的ICMP回显请求报文数目达到本命令配置的最大值。如果仍然未收到ICMP回显响应报文,则将地址分配给客户端,从而确保客户端获得的IP地址唯一。
# 配置DHCP服务器最多发送10个ICMP回显请求报文。
[Sysname] dhcp server ping packets 10
· dhcp server ping timeout
· display dhcp server conflict
· reset dhcp server conflict
dhcp server ping timeout命令用来配置DHCP服务器等待ICMP回显响应报文的超时时间。
undo dhcp server ping timeout命令用来恢复缺省情况。
DHCP服务器等待ICMP回显响应报文的超时时间为500毫秒。
milliseconds:等待ICMP回显响应报文的超时时间,取值范围是0~10000,单位为毫秒。0表示DHCP服务器将IP地址分配给DHCP客户端之前,不会通过ping操作探测该地址是否冲突。
DHCP服务器的地址探测是通过ping功能实现的,通过检测是否能在指定时间内得到ping响应来判断是否存在地址冲突。DHCP服务器发送目的地址为待分配地址的ICMP回显请求报文。如果在本命令指定的时间内收到ICMP回显响应报文,则认为存在地址冲突。DHCP服务器从地址池中选择新的IP地址,并重复上述操作。如果在指定时间内未收到ICMP回显响应报文,则继续发送ICMP回显请求报文,直到发送的回显请求报文数目达到最大值。如果仍然未收到ICMP回显响应报文,则将地址分配给客户端,从而确保客户端获取的IP地址唯一。
# 配置DHCP服务器等待ICMP回显响应报文的超时时间为1000毫秒。
[Sysname] dhcp server ping timeout 1000
· dhcp server ping packets
dhcp server relay information enable命令用来配置DHCP服务器处理Option 82。
undo dhcp server relay information enable命令用来配置DHCP服务器忽略Option 82。
DHCP服务器处理Option 82。
当DHCP服务器收到含有Option 82的报文时,如果DHCP服务器处理Option 82,则将请求报文中的Option 82原样复制到应答报文中;如果DHCP服务器忽略Option 82,则不会在应答报文中携带Option 82。
# 配置DHCP服务器忽略Option 82。
[Sysname] undo dhcp server relay information enable
dhcp server reply-exclude-option60命令用来配置DHCP服务器发送DHCP应答报文时不携带Option 60选项。
undo dhcp server reply-exclude-option60命令用来恢复缺省情况。
DHCP服务器发送DHCP应答报文时可以携带Option 60选项。
如果开启不携带Option 60选项功能,则无论收到的DHCP报文中是否携带Option 60选项,也无论地址池中是否配置Option 60选项,DHCP应答报文都不携带Option 60选项。
如果关闭不携带功能,当收到的DHCP报文携带Option 60选项或地址池中已配置Option 60选项,则DHCP应答报文携带Option 60选项,否则DHCP应答报文不携带Option 60选项。
# 配置DHCP服务器发送DHCP应答报文时不携带Option 60选项。
[Sysname] dhcp server reply-exclude-option60
display dhcp server conflict命令用来显示DHCP的地址冲突信息。
display dhcp server conflict [ ip ip-address ] [ vpn-instance vpn-instance-name ]
ip ip-address:显示指定IP地址的地址冲突信息。如果未指定本参数,则显示所有的地址冲突信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的地址冲突信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的地址冲突信息。
DHCP服务器在下列几种情况下会生成地址冲突信息:
· DHCP服务器在为客户端分配IP地址前,通过ping操作检测到网络中已有主机使用该地址。
· DHCP客户端向DHCP服务器发送Decline报文,报告DHCP服务器为其分配的地址存在冲突。
· DHCP服务器检测到地址池内的可供分配的地址是设备自身的地址。
# 显示所有的地址冲突信息。
<Sysname> display dhcp server conflict
IP address Detect time
4.4.4.1 Apr 25 16:57:20 2019
4.4.4.2 Apr 25 17:00:10 2019
表1-1 display dhcp server conflict命令显示信息描述表
IP address |
发生冲突的IP地址 |
Detect time |
检测到冲突的时间 |
display dhcp server database命令用来显示DHCP服务器的表项备份信息。
# 显示DHCP服务器的表项备份信息。
<Sysname> display dhcp server database
File name : database.dhcp
Username :
Password :
Update interval : 600 seconds
Latest write time : Feb 8 16:09:53 2014
Status : Last write succeeded.
表1-2 display dhcp server database命令显示信息描述表
File name |
存储DHCP服务器表项的文件名称 |
Username |
配置远程目标文件时的用户名 |
Password |
配置远程目标文件时的密码,有配置时显示为”******” |
Update interval |
定期刷新表项存储文件的刷新时间间隔,单位为秒 |
Latest write time |
最近一次写文件的时间 |
Status |
写文件的状态,即写文件是否成功 · Writing:正在写文件 · Last write succeeded.:上一次写文件成功 · Last write failed.:上一次写文件失败 |
display dhcp server expired命令用来显示租约过期的地址绑定信息。
display dhcp server expired [ [ ip ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip ip-address:显示指定IP地址的租约过期地址绑定信息。如果未指定本参数,则显示所有IP地址的租约过期地址绑定信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的租约过期的地址绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的租约过期的地址绑定信息。
pool pool-name:显示指定地址池中租约过期的地址绑定信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池中的租约过期地址绑定信息。
在DHCP地址池的可用地址分配完后,租约过期的地址将被分配给DHCP客户端。
# 显示所有租约过期的地址绑定信息。
<Sysname> display dhcp server expired
IP address Client-identifier/Hardware address Lease expiration
4.4.4.6 3030-3066-2e65-3230-302e-3130-3234 Apr 25 17:10:47 2019
-2d45-7468-6572-6e65-7430-2f31
表1-3 display dhcp server expired命令显示信息描述表
IP address |
租约过期的IP地址 |
Client-identifier/Hardware address |
租约过期的客户端ID或MAC地址,类型为ASCII时,type value为00;为MAC address时,type value为01;为Hex时,type value为配置的十六进制数的前两位 |
Lease expiration |
租约过期的时间 |
· reset dhcp server expired
display dhcp server free-ip命令用来显示DHCP地址池的空闲地址信息,即尚未分配给DHCP客户端的IP地址信息。
pool pool-name:显示指定地址池的空闲地址信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池的空闲地址信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的地址池空闲地址信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的地址池空闲地址信息。
# 显示所有DHCP地址池的空闲地址信息。
<Sysname> display dhcp server free-ip
Pool name: 1
Network: 10.0.0.0 mask 255.0.0.0
IP ranges from 10.0.0.10 to 10.0.0.100
IP ranges from 10.0.0.105 to 10.0.0.255
Secondary networks:
10.1.0.0 mask 255.255.0.0
IP ranges from 10.1.0.0 to 10.1.0.255
10.2.0.0 mask 255.255.0.0
IP Ranges from 10.2.0.0 to 10.2.0.255
Pool name: 2
Network: 20.1.1.0 mask 255.255.255.0
IP ranges from 20.1.1.0 to 20.1.1.255
表1-4 display dhcp server free-ip命令显示信息描述表
Pool name |
地址池的名称 |
Network |
可分配的地址网段 |
IP ranges |
可分配的地址范围 |
Secondary networks |
可分配的从地址网段 |
· address range
· network
display dhcp server ip-in-use命令用来显示DHCP地址绑定信息。
display dhcp server ip-in-use [ [ ip ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip ip-address:显示指定IP地址的地址绑定信息。如果未指定本参数,则显示所有IP地址的地址绑定信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCP地址绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的DHCP地址绑定信息。
pool pool-name:显示指定地址池的地址绑定信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池的地址绑定信息。
当DHCP服务器作为DHCP客户端的网关设备时,DHCP服务器上记录的该DHCP客户端的地址绑定信息才会提供给其他安全特性使用。
需要注意的是,如果租约的截止时间超过2100年,则显示为After 2100。
# 显示所有DHCP地址绑定信息。
<Sysname> display dhcp server ip-in-use
IP address Client identifier/ Lease expiration Type
Hardware address
10.1.1.1 4444-4444-4444 Not used Static(F)
10.1.1.2 0030-3030-302e-3030- May 1 14:02:49 2015 Auto(C)
3066-2e30-3030-332d-
4574-6865-726e-6574
10.1.1.3 1111-1111-1111 After 2100 Static(C)
表1-5 display dhcp server ip-in-use命令显示信息描述表
IP address |
分配给DHCP客户端的IP地址 |
Client identifier/Hardware address |
客户端ID或客户端的硬件地址。客户端ID使用指定十六进制字符串,通常前两位代表硬件类型,如00表示无类型使用ASCII字符串;01为以太网;06为令牌环网 |
Lease expiration |
租约到期时间,取值包括: · 具体的时间值(如May 1 14:02:49 2015):表示租约在该时间到期 · Not used:表示静态绑定的地址尚未分配给特定客户端 · Unlimited:表示租约为无限长 · After 2100:表示租约过期时间超过2100年 |
Type |
地址绑定的类型,取值包括: · Static(F):表示尚未分配给客户端的静态绑定,即静态无效绑定 · Static(O):服务器从地址池选择静态绑定的IP地址,并发送DHCP-OFFER报文为客户端提供该IP地址后产生该类型的地址绑定信息,即静态临时绑定 · Static(C):表示已经分配给客户端的静态绑定,即静态正式绑定 · Auto(O):表示动态绑定的临时租约,即从地址池中动态选择IP地址,并发送DHCP-OFFER报文为客户端提供该IP地址后,产生的租约 · Auto(C):表示动态绑定的正式租约,即从地址池中动态选择IP地址,并发送DHCP-ACK报文成功将该IP地址分配给客户端后,产生的租约 |
display dhcp server pool命令用来显示DHCP地址池的信息。
display dhcp server pool [ pool-name | vpn-instance vpn-instance-name ]
pool-name:显示指定地址池的信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池的信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCP地址池信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的DHCP地址池信息。
# 显示所有DHCP地址池的信息。
<Sysname> display dhcp server pool
Pool name: 0 (lock strict)
Network 20.1.1.0 mask 255.255.255.0
class a range 20.1.1.50 20.1.1.60
bootfile-name abc.cfg
dns-list 20.1.1.66 20.1.1.67 20.1.1.68
domain-name www.aabbcc.com
bims-server ip 192.168.0.51 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
option 2 ip-address 1.1.1.1
expired day 1 hour 2 mimute 3 second 0
Pool name: 1
Network 20.1.2.0 mask 255.255.255.0
secondary networks:
20.1.3.0 mask 255.255.255.0
20.1.4.0 mask 255.255.255.0
bims-server ip 192.168.0.51 port 50 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
forbidden-ip 20.1.2.35 20.1.2.36 20.1.2.37
forbidden-ip 20.1.2.22 20.1.2.23 20.1.2.24
forbidden-ip-range 20.1.2.50 20.1.2.55
gateway-list 20.1.2.1 20.1.2.2 20.1.2.4
nbns-list 20.1.2.5 20.1.2.6 20.1.2.7
netbios-type m-node
expired day 1 hour 0 minute 0 second 0
Pool name: 2
Network 20.1.3.0 mask 255.255.255.0
address range 20.1.3.1 to 20.1.3.15
class departmentA range 20.1.3.20 to 20.1.3.29
class departmentB range 20.1.3.30 to 20.1.3.40
next-server 20.1.3.33
tftp-server domain-name www.dian.org.cn
tftp-server ip-address 192.168.0.120
voice-config ncp-ip 20.1.3.2
voice-config as-ip 20.1.3.5
voice-config voice-vlan 3 enable
voice-config fail-over 20.1.3.6 123*
option 2 ip-address 20.1.3.10
Pool name: 3
static bindings:
ip-address 10.10.1.2 mask 255.0.0.0
hardware-address 00e0-00fc-0001 ethernet
description ClientA
ip-address 10.10.1.3 mask 255.0.0.0
client-identifier aaaa-bbbb
description ClientB
expired unlimited
表1-6 display dhcp server pool命令显示信息描述表
Pool name (lock strict) |
DHCP地址池的名称,锁定状态取值包括: · lock:该DHCP地址池被锁定,不会为新的DHCP客户端分配地址,但会应答已在线客户端的地址续约需求 · lock strict:该DHCP地址池被锁定,既不会为新的DHCP客户端分配地址,也不会应答已在线客户端的地址续约需求 若DHCP地址池未锁定,则无锁定状态信息 |
Network |
可分配的地址网段 |
secondary networks |
可分配的从地址网段 |
address range |
可分配的地址范围 |
class class-name range |
为指定DHCP用户类分配的地址范围 |
static bindings |
静态绑定的IP地址、硬件地址或客户端ID |
ip-address mask |
静态绑定的IP地址和掩码长度 |
hardware-address |
静态绑定的硬件地址 |
client-identifier |
静态绑定的客户端ID |
description |
静态绑定的描述信息 |
option |
自定义的DHCP选项 |
expired |
租约期限,其后数值的单位分别为天、小时、分钟和秒 |
bootfile-name |
为DHCP客户端分配的启动文件名 |
dns-list |
为DHCP客户端分配的DNS服务器地址 |
domain-name |
为DHCP客户端分配的域名后缀 |
bims-server |
为DHCP客户端分配的BIMS服务器信息 |
forbidden-ip |
DHCP地址池中不参与自动分配的IP地址 |
forbidden-ip-range |
DHCP地址池中不参与自动分配的IP地址段 |
gateway-list |
为DHCP客户端分配的网关地址 |
nbns-list |
为DHCP客户端分配的WINS服务器地址 |
netbios-type |
为DHCP客户端分配的NetBIOS节点类型 |
next-server |
为DHCP客户端分配的下一个提供服务的服务器IP地址 |
tftp-server domain-name |
为DHCP客户端分配的TFTP服务器名 |
tftp-server ip-address |
为DHCP客户端分配的TFTP服务器地址 |
voice-config ncp-ip |
为DHCP客户端分配的网络呼叫处理器的地址 |
voice-config as-ip |
为DHCP客户端分配的备用服务器的地址 |
voice-config voice-vlan |
为DHCP客户端分配的语音VLAN |
voice-config fail-over |
为DHCP客户端分配的自动故障转移呼叫路由 |
display dhcp server statistics命令用来显示DHCP服务器的统计信息。
pool pool-name:显示指定地址池的统计信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池的统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCP服务器的统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的DHCP服务器的统计信息。
# 显示DHCP服务器的统计信息。
<Sysname> display dhcp server statistics
Pool number: 1
Pool utilization: 0.39%
Bindings:
Automatic: 1
Manual: 0
Expired: 0
Conflict: 1
Messages received: 10
DHCPDISCOVER: 5
DHCPREQUEST: 3
DHCPDECLINE: 0
DHCPRELEASE: 2
DHCPINFORM: 0
BOOTPREQUEST: 0
Messages sent: 6
DHCPOFFER: 3
DHCPACK: 3
DHCPNAK: 0
BOOTPREPLY: 0
Bad Messages: 0
表1-7 display dhcp server statistics命令显示信息描述表
Pool number |
地址池的数目,显示指定地址池的统计信息时无此字段 |
Pool utilization |
地址池利用率 · 显示所有DHCP租约统计信息时,表示所有地址池的总体利用率 · 显示指定地址池的租约统计信息时,表示该地址池的利用率 |
Bindings |
各种状态的地址绑定数,包括: · Automatic:动态分配的IP地址绑定数 · Manual:手工绑定的IP地址绑定数 · Expired:租约过期的IP地址绑定数 |
Conflict |
冲突地址的总数,显示指定地址池的统计信息时无此字段 |
Messages received |
DHCP服务器接收到DHCP客户端发送的报文数,包括: · DHCPDISCOVER · DHCPREQUEST · DHCPDECLINE · DHCPRELEASE · DHCPINFORM · BOOTPREQUEST 显示指定地址池的统计信息时无此类字段 |
Messages sent |
DHCP服务器发给DHCP客户端的报文数,包括: · DHCPOFFER · DHCPACK · DHCPNAK · BOOTPREPLY 显示指定地址池的统计信息时无此类字段 |
Bad Messages |
错误信息数,显示指定地址池的统计信息时无此类字段 |
· reset dhcp server statistics
dns-list命令用来配置DHCP地址池为DHCP客户端分配的DNS服务器地址。
undo dns-list命令用来删除DHCP地址池为DHCP客户端分配的DNS服务器地址。
dns-list ip-address&<1-8>
undo dns-list [ ip-address&<1-8> ]
未配置DHCP地址池为DHCP客户端分配的DNS服务器地址。
DHCP地址池视图
ip-address&<1-8>:DNS服务器的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
多次执行该命令,最后一次执行的命令生效。
执行undo dns-list命令时,如果未指定任何参数,则删除DHCP地址池中的所有DNS服务器地址。
# 配置DHCP地址池0为DHCP客户端分配的DNS服务器地址为10.1.1.254。
[Sysname-dhcp-pool-0] dns-list 10.1.1.254
domain-name命令用来配置DHCP地址池为DHCP客户端分配的域名。
undo domain-name命令用来恢复缺省情况。
domain-name domain-name
undo domain-name
未配置DHCP地址池为DHCP客户端分配的域名。
DHCP地址池视图
domain-name:DHCP客户端的域名,为1~50个字符的字符串,区分大小写。
# 配置DHCP地址池0为DHCP客户端分配的域名为company.com。
[Sysname-dhcp-pool-0] domain-name company.com
expired命令用来配置DHCP地址池中分配的IP地址的租约有效期限。
undo expired命令用来恢复缺省情况。
expired { day day [ hour hour [ minute minute [ second second ] ] ] | unlimited }
undo expired
DHCP地址池中IP地址的租约有效期限为1天。
DHCP地址池视图
day day:指定租约过期的天数,day取值范围为0~365。
hour hour:指定租约过期的小时数,hour取值范围为0~23。如果未指定本参数,则指定过期的小时数为0。
minute minute:指定租约过期的分钟数,minute取值范围为0~59。如果未指定本参数,则指定过期的分钟数为0。
second second:指定租约过期的秒数,second取值范围为0~59。如果未指定本参数,则指定过期的秒数为0。
unlimited:有效期限为无限长(实际上系统限定约为136年)。
DHCP服务器从DHCP地址池中选择IP地址分配给DHCP客户端时,会同时将该地址池中IP地址的租约有效期限通知给DHCP客户端。在租约有效期限到达之前,DHCP客户端需要进行续约申请。如果续约成功,则DHCP客户端可以继续使用该IP地址。否则,租约有效期限到达后,DHCP客户端不能再继续使用该IP地址,并且DHCP服务器会将该地址添加到过期租约信息中。
# 配置地址池0的IP地址租约有效期为1天2小时3分4秒。
[Sysname-dhcp-pool-0] expired day 1 hour 2 minute 3 second 4
· display dhcp server expired
forbidden-ip命令用来配置地址池中不参与自动分配的IP地址。
undo forbidden-ip命令用来取消地址池中不参与自动分配的IP地址的配置。
forbidden-ip ip-address&<1-8>
undo forbidden-ip [ ip-address&<1-8> ]
未配置地址池中不参与自动分配的IP地址。
DHCP地址池视图
ip-address&<1-8>:地址池中不参与自动分配的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
在DHCP地址池视图下通过forbidden-ip命令配置不参与自动分配的IP地址后,只有当前的地址池不能分配这些IP地址,其他地址池仍然可以分配这些IP地址。
多次执行forbidden-ip命令,可以配置多个不参与自动分配的IP地址。每个地址池最多能配置4096个地址。
执行undo forbidden-ip命令时,如果未指定任何参数,则删除所有不参与自动分配的IP地址。
# 配置DHCP地址池0中不参与自动分配的IP地址为192.168.1.3和192.168.1.10。
[Sysname-dhcp-pool-0] forbidden-ip 192.168.1.3 192.168.1.10
· dhcp server forbidden-ip
forbidden-ip-range命令用来配置DHCP地址池中不参与自动分配的IP地址段。
undo forbidden-ip-range命令用来取消配置的DHCP地址池中不参与自动分配的IP地址段。
forbidden-ip-range start-ip-address [ end-ip-address ]
undo forbidden-ip-range [ start-ip-address [ end-ip-address ] ]
未配置DHCP地址池中不参与自动分配的IP地址段。
DHCP地址池视图
start-ip-address:表示不参与自动分配的起始IP地址。
end-ip-address:表示不参与自动分配的终止IP地址,不能小于start-ip-address。如果未指定本参数,则表示只有一个不参与自动分配的IP地址,即start-ip-address。否则,表示start-ip-address到end-ip-address之间的IP地址段均不参与自动分配。
在DHCP地址池视图下通过forbidden-ip-range命令配置不参与自动分配的IP地址段后,只有当前的地址池不能分配这些IP地址段,其他地址池仍然可以分配这些IP地址段。
多次执行forbidden-ip-range命令,可以配置多个不参与自动分配的IP地址段,多次配置的地址空间可以互相重复。
执行undo forbidden-ip-range命令时,如果未指定任何参数,则删除所有不参与自动分配的IP地址段。
如果执行undo forbidden-ip-range命令指定的地址段范围比forbidden-ip-range现有的地址段范围小,则只取消undo forbidden-ip-range指定的地址段范围的配置。如果执行undo forbidden-ip-range命令指定的地址段范围比forbidden-ip-range指定的地址段范围大,则只取消forbidden-ip-range命令指定的地址段范围。
# 配置DHCP地址池0中不参与自动分配的IP地址段为192.168.1.3到192.168.1.10。
[Sysname-dhcp-pool-0] forbidden-ip-range 192.168.1.3 192.168.1.10
gateway-list命令用来配置DHCP服务器为DHCP客户端分配的网关地址。
undo gateway-list命令用来删除DHCP服务器为DHCP客户端分配的网关地址。
gateway-list ip-address&<1-64> [ export-route ]
undo gateway-list [ ip-address&<1-64> ] [ export-route ]
DHCP地址池、DHCP从网段下均未配置为DHCP客户端分配的网关地址。
DHCP地址池视图
DHCP从网段视图
ip-address&<1-64>:网关的IP地址。&<1-64>表示最多可以输入64个IP地址,每个IP地址之间用空格分隔。网关地址需要和DHCP客户端在同一个网段中。
export-route:将网关列表信息下发给地址管理,通过应答客户端的ARP请求,即可实现对不同类型的业务流量的引导。如果未指定本参数,则不将网关列表信息下发给地址管理。
DHCP地址池视图下执行gateway-list命令,配置的是为地址池中所有DHCP客户端分配的网关地址。如果用户需要为地址池下某个从网段的DHCP客户端分配其它的网关地址,可以在地址池的从网段视图下执行gateway-list命令。如果在地址池视图和从网段视图下都配置了网关地址,则优先将从网段视图下配置的网关地址分配给从网段的DHCP客户端。
执行undo gateway-list命令时,如果未指定任何参数,则删除所有配置的网关地址。
# 配置DHCP地址池0为DHCP客户端分配的网关地址为10.1.1.1。
[Sysname-dhcp-pool-0] gateway-list 10.1.1.1
if-match命令用来配置DHCP用户类的匹配规则。
undo if-match命令用来删除DHCP用户类的匹配规则。
未配置DHCP用户类的匹配规则。
DHCP用户类视图
rule rule-number:匹配规则编号,取值范围为1~128。编号越小,匹配优先级越高。
hardware-address hardware-address:指定匹配规则的硬件地址。hardware-address表示客户端的硬件地址,为4~39个字符的字符串,字符串只能包含十六进制数和“-”,且形式为H-H-H,除最后一个H表示2位或4位十六进制数外,其他均表示4位十六进制数。例如:aabb-ccdd-ee为有效的硬件地址,aabb-c-dddd和aabb-cc-dddd为无效的客户端硬件地址。
mask hardware-address-mask:指定匹配规则的硬件地址掩码。长度需要与hardware-address保持一致。
option option-code:DHCP选项的数值,取值范围为1~254。option-code用于指定匹配DHCP客户端时从DHCP报文中获取哪个选项。
ascii ascii-string:指定用来匹配报文中指定选项的内容。ascii-string为1~128个字符的ACSII字符串。
offset offset:指定匹配DHCP客户端时获取选项内容的起始位置。offset为选项内容偏移量,取值范围为0~254,单位为字节。如果未指定本参数,则表示从选项值第一字节开始匹配整个选项的内容。
partial:指定部分匹配,即只要报文中的选项内容中包含指定的hex-string或ascii-string,即认为匹配通过。
length length:指定匹配DHCP客户端时获取选项内容的长度。length为选项内容的长度,取值范围为1~128,单位为字节。指定的选项内容长度必须和hex-string长度相同。
relay-agent gateway-address:指定匹配报文中的giaddr字段的内容。gateway-address为IP地址,为点分十进制形式。
DHCP服务器通过将DHCP客户端发送的报文与本命令配置的规则匹配,来判断DHCP客户端属于的DHCP用户类。DHCP用户类视图下通过多次执行if-match命令,可以配置多条匹配规则。只要任意一条规则匹配成功,就认为该DHCP客户端属于该用户类。
在同一用户类视图下配置匹配规则时:
· 多次执行相同rule-number的命令,如果规则类型(包括匹配option、relay-agent或hardware address)相同,最后一次执行的命令生效;如果规则类型不同,则新的配置和已有配置会共存。建议不同类型的规则不要使用同一个rule-number。
· 不同rule-number的匹配规则内容不能完全相同。
将报文与某一条if-match hardware-address命令配置的规则匹配的方式为:
· 匹配硬件地址类型,目前只支持以太类型的硬件地址(即MAC地址)匹配,非以太类型的硬件地址均会匹配失败。
· 如果报文中的客户端硬件地址与配置的客户端硬件地址及硬件地址掩码匹配,则认为匹配成功。否则,匹配失败。
· 匹配时报文中的客户端硬件地址长度与配置规则中的硬件地址长度一致时才进行匹配,否则直接认为不匹配。如匹配规则为if-match rule 1 hardware-address 0094-0000 mask ffff-0000,需匹配硬件地址长度为4字节的用户;若报文中客户端硬件地址长度为6字节(比如0094-0000-0010),则认为匹配失败。
· 匹配硬件地址时,可以配置不连续匹配的硬件地址,如匹配规则为if-match rule 1 hardware-address 0094-0000-1100 mask ffff-0000-ff00,则匹配硬件地址为0094-xxxx-11xx(x代表变量)的报文。
· 如果规则中只指定了option-code参数,则只要报文中包括该选项,就认为匹配成功。否则,匹配失败。
· 如果规则中只指定了option-code和hex-string/ascii-string参数,则报文中指定选项的值从第1位开始的部分与hex-string/ascii-string相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、ascii-string和offset参数,则将指定选项的值的第offset+1位到最后一位的内容与acsii-string比较,二者相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、hex-string、offset和length参数,则将指定选项值的第offset+1位到offset+length位的内容与hex-string比较,二者相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、hex-string和mask参数,则将指定选项值的第1位到mask长度位的内容与mask进行与运算,将结果与hex-string与mask与运算的结果比较,二者相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、hex-string/ascii-string和partial参数,则选项内容内包含了指定的hex-string/ascii-string,就认为匹配成功。否则,匹配失败。例如匹配字段为abc,那xabc、xyzabca、xabcyz和abcxyz均认为匹配通过。
将报文与某一条if-match relay-agent命令配置的规则匹配的方式是只要报文中的giaddr字段和指定的gateway-address一致时,认为匹配成功。否则,匹配失败。
# 配置DHCP用户类exam的匹配规则,匹配规则编号1,匹配硬件地址0094-0000-0101,硬件掩码长度为ffff-0000-0000。
<Sysname> syatem-view
[Sysname] dhcp class exam
[Sysname-dhcp-class-exam] if-match rule 1 hardware-address 0094-0000-0101 mask ffff-0000-0000
# 配置DHCP用户类exam的匹配规则,匹配规则编号2,报文中包含Option 82。
[Sysname-dhcp-class-exam] if-match rule 2 option 82
# 配置DHCP用户类exam的匹配规则,匹配规则编号3,报文中包含Option 82,并且该选项的十六进制数第四个字节的最高位为1。
[Sysname-dhcp-class-exam] if-match rule 3 option 82 hex 00000080 mask 00000080
# 配置DHCP用户类exam的匹配规则,匹配规则编号4,报文中包含Option 82,并且该选项的前三个字节为十六进制数13ae92。
[Sysname-dhcp-class-exam] if-match rule 4 option 82 hex 13ae92 offset 0 length 3
# 配置DHCP用户类exam的匹配规则,匹配规则编号5,报文中包含Option 82,并且该选项内容中包含指定的十六进制数13ae。
[Sysname-dhcp-class-exam] if-match rule 5 option 82 hex 13ae partial
# 配置DHCP用户类exam的匹配规则,匹配规则编号6,报文中包含的giaddr字段值为10.1.1.1。
[Sysname-dhcp-class-exam] if-match rule 6 relay-agent 10.1.1.1
· dhcp class
ip-in-use threshold命令用来设置地址池使用率告警门限阈值。
undo ip-in-use threshold命令用来恢复缺省情况。
地址池使用率告警门限阈值为100%。
DHCP地址池视图
threshold-value:地址池使用率告警阈值,为百分比形式,取值范围为1~100。比如若设置为80,表示地址池使用率超过80%时,系统会生成告警信息发送给信息中心。
执行ip-in-use threshold命令设置地址池使用率告警阈值,在地址池中地址使用率超过阈值时,系统会生成告警信息提醒管理员进行地址池规划,避免因为地址池中地址资源耗尽,后续用户不能上线。
在同一个视图下多次执行本命令,最后一次执行的命令生效。
系统将告警信息发送给信息中心,通过设置信息中心的参数,最终决定日志信息的输出规则(即是否允许输出以及输出方向)。有关信息中心参数配置请参见“网络管理和监控配置指导”中的“信息中心”。
# 配置地址池p1使用率告警门限阈值为85%。
[Sysname] dhcp server ip-pool p1
[Sysname-dhcp-pool-p1] ip-in-use threshold 85
lock命令用来锁定DHCP地址池。
undo lock命令用来恢复缺省情况。
lock [ strict ]
undo lock
DHCP地址池未锁定。
DHCP地址池视图
strict:配置DHCP地址池收到DHCP客户端的续约报文后,直接丢弃该报文,DHCP客户端无法续约。如果未指定本参数,则DHCP地址池会应答地址续约请求,DHCP客户端可以正常续约。
在管理DHCP地址池时,可能会有如下需求:
· 当前DHCP地址池地址空间被规划为维护使用,即只用于维护已在线DHCP客户端的需求,不为新的DHCP客户端分配地址。
· 管理员对地址池中的地址空间进行更新或删除时,如果DHCP地址池已经分配了IP地址,会提示当前有用户在线,无法执行删除或更新操作。
为了解决上述问题,管理员需要配置锁定DHCP地址池:
· 如果未指定strict参数,则DHCP地址池仅应答已在线客户端的地址续约请求,不会为新的DHCP客户端分配地址。这种情况下,DHCP地址池的地址仅用于维护,用来处理在线用户的续租请求。
· 如果指定strict参数,则DHCP地址池既不会应答已在线客户端的地址续约请求,也不会为新的DHCP客户端分配地址。这种情况下,待DHCP地址池中的地址全部回收后,管理员可以对地址空间进行更新或删除操作。
# 锁定DHCP地址池1,只会应答已在线用户的续约请求,不再为新用户分配地址。
[Sysname-dhcp-pool-1] lock
The IP pool will answer only renewal requests of online users but will not assign addresses to new users. Continue? [Y/N]:
# 锁定DHCP地址池1,既不会应答已在线用户的续约请求,也不会为新用户分配地址。
[Sysname-dhcp-pool-1] lock strict
The IP pool will not answer renewal requests of online users or assign addresses to new users. Continue? [Y/N]:
nbns-list命令用来配置DHCP地址池为DHCP客户端分配的WINS服务器地址。
undo nbns-list命令用来删除DHCP地址池为DHCP客户端分配的WINS服务器地址。
nbns-list ip-address&<1-8>
undo nbns-list [ ip-address&<1-8> ]
未配置DHCP地址池为DHCP客户端分配的WINS服务器地址。
DHCP地址池视图
ip-address&<1-8>:WINS服务器的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
执行undo nbns-list命令时,如果未指定任何参数,则删除DHCP地址池中的所有WINS服务器地址。
# 配置DHCP地址池0为DHCP客户端分配WINS服务器地址为10.1.1.1。
[Sysname-dhcp-pool-0] nbns-list 10.1.1.1
· netbios-type
netbios-type命令用来配置DHCP地址池为DHCP客户端分配的NetBIOS节点类型。
undo netbios-type命令用来恢复缺省情况。
undo netbios-type
未配置DHCP地址池为DHCP客户端分配的NetBIOS节点类型。
DHCP地址池视图
b-node:b类节点,“b”代表广播(broadcast),此类节点采用广播方式获取主机名和IP地址之间的映射。源节点通过发送带有目的节点主机名的广播报文来获取目的节点的IP地址,目的节点收到广播报文后,就将自己的IP地址返回给源节点。
h-node:h类节点,“h”代表混合(hybrid),是具备“端到端”通信机制的b类节点。此类节点首先发送单播报文与WINS服务器通信来获取映射关系,如果未获取到,再发送广播报文来获取映射关系。
m-node:m类节点,“m”代表混合(mixed),是具有部分广播特性的p类节点。此类节点首先发送广播报文来获取映射关系,如果未获取到,则再发送单播报文与WINS服务器通信来获取映射关系。
p-node:p类节点,“p”代表端到端(peer-to-peer),即此类节点采用发送单播报文与WINS服务器通信的方式获取映射关系。源节点给WINS服务器发送单播报文,WINS服务器收到单播报文后,返回源节点请求的目的节点名所对应的IP地址。
# 配置DHCP地址池0为DHCP客户端分配的NetBIOS节点类型为p类节点。
[Sysname-dhcp-pool-0] netbios-type p-node
· nbns-list
network命令用来配置DHCP地址池动态分配的IP地址网段。
undo network命令用来删除已经创建的用于动态分配的IP地址网段。
network network-address [ mask-length | mask mask ] [ secondary ] [ export-route ]
undo network network-address [ mask-length | mask mask ] [ secondary ]
未配置动态分配的IP地址网段,即没有可供分配的IP地址。
DHCP地址池视图
network-address:用于动态分配的网段地址。未指定掩码长度和掩码时,表示采用自然掩码。
mask-length:IP地址的网络掩码长度,取值范围为1~30。
mask mask:IP地址的网络掩码,mask为点分十进制形式。
secondary:指定配置的网段为从网段。如果未指定本参数,则表示配置的网段为主网段。主网段中的地址分配完之后,DHCP服务器可以在从网段中选择地址分配给DHCP客户端。
export-route:将网段信息下发给路由管理,由路由管理发布指定网段信息的路由。引导指定网段的下行数据流量。如果未指定本参数,则不会将网段信息下发给路由管理。
执行本命令时如果指定了secondary参数,则会进入从网段视图。用户可以在该视图下通过gateway-list命令配置为从网段的DHCP客户端分配的网关地址。
每个DHCP地址池中只能配置一个主网段,多次执行network命令配置主网段,最后一次执行的命令生效。
每个DHCP地址池中最多可以配置32个从网段。
一个DHCP地址池中各个主、从网段的网络号和掩码不能完全相同。
在地址池下配置了address range或class命令后,不能再在该地址池下配置从网段。
修改或删除network配置,会导致该地址池下现有的已分配地址被删除。
配置network export-route命令可以用来发布网段路由,多次执行本命令,最后一次执行的命令生效。
# 配置DHCP地址池0动态分配的主地址网段为192.168.8.0/24,从地址网段为192.168.10.0/24。
[Sysname-dhcp-pool-0] network 192.168.8.0 mask 255.255.255.0
[Sysname-dhcp-pool-0] network 192.168.10.0 mask 255.255.255.0 secondary
[Sysname-dhcp-pool-0-secondary]
· gateway-list
next-server命令用来配置DHCP地址池为DHCP客户端分配的下一个提供服务的服务器IP地址。
undo next-server命令用来恢复缺省情况。
next-server ip-address
undo next-server
未配置DHCP地址池为DHCP客户端分配的下一个提供服务的服务器IP地址。
DHCP地址池视图
ip-address:下一个提供服务的服务器IP地址。
为DHCP客户端分配的下一个提供服务的服务器IP地址,是在DHCP客户端启动过程中,在获取到IP地址后,用于获取其他启动数据的服务器地址。例如,TFTP服务器地址。
# 配置DHCP地址池0为DHCP客户端分配的下一个提供服务的服务器IP地址为10.1.1.254。
[Sysname-dhcp-pool-0] next-server 10.1.1.254
option命令用来自定义DHCP选项。
undo option命令用来删除自定义的DHCP选项。
undo option code
未自定义DHCP选项。
DHCP地址池视图
DHCP选项组视图
code:选项的数值,取值范围为2~254,不包括50~54、56、58、59、61和82。
ascii ascii-string:指定选项内容为配置的ASCII字符串。ascii-string为1~255个字符的ASCII字符串,区分大小写。
hex hex-string:指定选项内容为配置的十六进制数。hex-string为十六进制数,位数的取值范围为2~256之间的偶数。
ip-address ip-address&<1-8>:指定选项内容为配置的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
通过执行本命令,可以配置编号为code的DHCP选项内容为指定的ASCII字符串、十六进制数或IP地址,即采用指定的内容来填充DHCP应答报文中编号为code的选项,以便将指定的选项内容分配给客户端。
本命令为DHCP服务器提供了灵活的选项配置方式,使得DHCP服务器可以为DHCP客户端提供更加丰富的选项内容。在以下情况下,可以使用本命令自定义DHCP选项:
· 随着DHCP的不断发展,新的DHCP选项会陆续出现。通过自定义DHCP选项,可以方便地添加新的DHCP选项。
· 有些选项的内容,RFC中没有统一规定。厂商可以根据需要定义选项的内容,如Option 43。通过自定义DHCP选项,可以为DHCP客户端提供厂商指定的信息。
· 设备上只提供了有限的选项配置命令(如gateway-list、dns-list命令),对于没有专门命令来配置的DHCP选项,可以通过option命令配置选项内容。例如,可以通过option 4 ip-address 1.1.1.1命令指定为DHCP客户端分配的时间服务器地址为1.1.1.1。
· 扩展已有的DHCP选项。当前已提供的方式无法满足用户需求时(比如通过dns-list命令最多只能配置8个DNS服务器地址,如果用户需要配置的DNS服务器地址数目大于8,则该命令无法满足需求),可以通过自定义DHCP选项的方式进行扩展。
有些DHCP选项既可以通过专门的命令来配置,也可以通过option命令来配置。例如,Option 6(DNS服务器地址选项)既可以通过dns-list命令配置,也可以通过option 6命令配置。如果同时通过上述两种方式配置了这些选项,则在填充DHCP应答报文的选项时,优先选择专门命令的配置。如果未通过专门命令来配置,则采用option命令配置的内容填充选项。
# 日志服务器选项的编号为7。在DHCP地址池0中配置为DHCP客户端分配的日志服务器地址为2.2.2.2。
[Sysname-dhcp-pool-0] option 7 ip-address 2.2.2.2
reset dhcp server conflict命令用来清除DHCP的地址冲突信息。
ip ip-address:清除指定IP地址的冲突信息。如果未指定本参数,则清除所有地址的冲突信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的地址冲突信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的地址冲突信息。
出现冲突地址,一般是由于网络配置不合理,动态分配的地址和网络中静态配置的地址冲突而产生的。在合理调整网络配置,不再存在冲突的情况后,原来的冲突地址可能不再冲突,可以被重新分配。此时,通过本命令,清除检测到的冲突地址,则该地址可以被重新分配。
# 清除全部地址冲突信息。
<Sysname> reset dhcp server conflict
reset dhcp server expired命令用来清除租约过期的地址绑定信息。
reset dhcp server expired [ [ ip ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip ip-address:清除指定IP地址的租约过期地址绑定信息。如果未指定本参数,则清除所有IP地址的租约过期地址绑定信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的租约过期的地址绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的租约过期的地址绑定信息。
pool pool-name:清除指定地址池中租约过期的地址绑定信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则清除所有地址池的租约过期地址绑定信息。
# 清除所有租约过期的地址绑定信息。
<Sysname> reset dhcp server expired
reset dhcp server ip-in-use命令用来清除DHCP的正式绑定和临时绑定信息。
ip ip-address:清除指定IP地址的正式绑定和临时绑定信息。如果未指定本参数,则清除所有IP地址的正式绑定和临时绑定信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的正式绑定和临时绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的正式绑定和临时绑定信息。
pool pool-name:清除指定地址池的正式绑定和临时绑定信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则清除所有地址池的正式绑定和临时绑定信息。
清除静态正式绑定信息时,将使该绑定信息变为静态无效绑定。
# 清除地址10.110.1.1的正式绑定和临时绑定信息。
<Sysname> reset dhcp server ip-in-use ip 10.110.1.1
· display dhcp server ip-in-use
reset dhcp server statistics命令用来清除DHCP服务器的统计信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的DHCP服务器的统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的DHCP服务器的统计信息。
# 清除DHCP服务器的统计信息。
<Sysname> reset dhcp server statistics
· display dhcp server statistics
static-bind命令用来在DHCP地址池中配置静态地址绑定,以便实现DHCP服务器为客户端ID或硬件地址为指定值的客户端分配固定的IP地址。
undo static-bind命令用来删除DHCP地址池中的静态地址绑定。
static-bind ip-address ip-address [ mask-length | mask mask ] { client-identifier client-identifier | hardware-address hardware-address [ ethernet | token-ring ] } [ description description-text ]
undo static-bind ip-address ip-address
未在DHCP地址池中配置静态地址绑定。
DHCP地址池视图
ip-address ip-address:指定静态绑定的IP地址。未指定掩码长度和掩码时,表示采用自然掩码。
mask-length:静态绑定IP地址的掩码长度,即掩码中连续“1”的个数,取值范围为1~30。
mask mask:指定静态绑定IP地址的掩码,mask为点分十进制形式。
client-identifier client-identifier:指定静态绑定的客户端ID。client-identifier表示客户端ID,为4~254个字符的字符串,字符串中只能包括十六进制数和“-”,且形式为H-H-H…,除最后一个H表示2位或4位十六进制数外,其他均表示4位十六进制数。例如:aabb-cccc-dd为有效的ID,aabb-c-dddd和aabb-cc-dddd为无效客户端ID。
hardware-address hardware-address:指定静态绑定的客户端硬件地址。hardware-address表示客户端硬件地址,为4~39个字符的字符串,字符串中只能包括十六进制数和“-”,且形式为H-H-H…,除最后一个H表示2位或4位十六进制数外,其他均表示4位十六进制数。例如:aabb-cccc-dd为有效的客户端硬件地址,aabb-c-dddd和aabb-cc-dddd为无效的客户端硬件地址。
ethernet:指定客户端硬件地址类型为以太网,缺省为以太网类型。
token-ring:指定客户端硬件地址类型为令牌环网。
description description-text:指定静态地址绑定的描述信息,description-text为1~255个字符的字符串,区分大小写。
静态绑定的IP地址不能是DHCP服务器的接口IP地址,否则会导致IP地址冲突,被绑定的客户端将无法正常获取到IP地址。
同一地址池下可以配置多个静态地址绑定。所有地址池下配置的静态地址绑定一共不能超过8192个。
同一地址只能绑定给一个客户端。不能通过重复执行本命令修改IP地址与客户端的绑定关系。如需修改IP地址与客户端的绑定关系,请先通过undo static-bind命令删除静态地址绑定,再执行static-bind命令。
# 在DHCP地址池0中配置:为客户端ID为00aa-aabb的客户端,固定分配IP地址10.1.1.1/24。
[Sysname-dhcp-pool-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0 client-identifier 00aa-aabb
tftp-server domain-name命令用来配置DHCP地址池为DHCP客户端分配的TFTP服务器域名。
undo tftp-server domain-name命令用来恢复缺省情况。
未配置DHCP地址池为DHCP客户端分配的TFTP服务器域名。
DHCP地址池视图
domain-name:TFTP服务器域名,为1~63个字符的字符串,区分大小写。
# 配置DHCP地址池0为DHCP客户端分配的TFTP服务器域名为aaa。
[Sysname-dhcp-pool-0] tftp-server domain-name aaa
tftp-server ip-address命令用来配置DHCP地址池为DHCP客户端分配的TFTP服务器地址。undo tftp-server ip-address命令用来恢复缺省情况。
未配置DHCP地址池为DHCP客户端分配的TFTP服务器地址。
DHCP地址池视图
ip-address:TFTP服务器的IP地址。
# 配置DHCP地址池0为DHCP客户端分配的TFTP服务器地址为10.1.1.1。
[Sysname-dhcp-pool-0] tftp-server ip-address 10.1.1.1
valid class命令用来配置DHCP白名单包括的用户类名。
undo valid class命令用来删除DHCP白名单中包括的用户类名。
valid class class-name&<1-8>
undo valid class class-name&<1-8>
未配置DHCP白名单包括的用户类。
DHCP地址池视图
class-name&<1-8>:DHCP白名单包括的用户类名列表。其中class-name为DHCP用户类名,为1~63个字符的字符串,不区分大小写。&<1-8>代表最多可以输入8个用户类名,每个用户类名之间用空格分隔。
在配置了DHCP地址池用户白名单功能后,DHCP服务器才会检查用户是否属于白名单包括的用户类。
# 在DHCP地址池0中配置DHCP白名单包括的用户类名为test1和test2。
[Sysname-dhcp-pool-0] valid class test1 test2
· dhcp class
· verify class
verify class命令用来开启DHCP用户类白名单功能。
undo verify class命令用来关闭DHCP用户类白名单功能。
verify class
undo verify class
DHCP用户类白名单功能处于关闭状态。
DHCP地址池视图
在开启了DHCP用户类白名单功能后,DHCP服务器才会检查用户是否属于白名单包括的用户类。
需要注意的是,DHCP用户类白名单功能对获取静态绑定租约的客户端不生效。
# 在DHCP地址池0中开启DHCP用户类白名单功能。
[Sysname] syatem-view
[Sysname-dhcp-pool-0] verify class
· valid class
voice-config命令用来配置DHCP地址池为DHCP客户端分配的Option 184内容。
undo voice-config命令用来删除DHCP地址池为DHCP客户端分配的Option 184内容。
voice-config { as-ip ip-address | fail-over ip-address dialer-string | ncp-ip ip-address | voice-vlan vlan-id { disable | enable } }
undo voice-config [ as-ip | fail-over | ncp-ip | voice-vlan ]
未配置DHCP地址池为DHCP客户端分配的Option 184内容。
DHCP地址池视图
as-ip ip-address:指定备用服务器的IP地址。
fail-over ip-address dialer-string:指定自动故障转移IP地址及呼叫字符串。dialer-string为1~39个字符的字符串,字符只能是数字0~9及“*”。
ncp-ip ip-address:指定网络呼叫处理器的IP地址。
voice-vlan vlan-id:指定语音VLAN的ID。vlan-id取值范围为2~4094。
· disable:指定VLAN处于禁止状态,即DHCP客户端不会将所指定的VLAN ID作为语音VLAN。
· enable:指定VLAN处于开启状态,即DHCP客户端会将所指定的VLAN ID作为语音VLAN。
# 为DHCP地址池0指定Option 184的内容:网络呼叫处理器的IP地址为10.1.1.1,备用服务器的IP地址为10.2.2.2,语音VLAN的ID为3,为开启状态,自动故障转移IP地址为10.3.3.3,呼叫字符串为99*。
[Sysname-dhcp-pool-0] voice-config ncp-ip 10.1.1.1
[Sysname-dhcp-pool-0] voice-config as-ip 10.2.2.2
[Sysname-dhcp-pool-0] voice-config voice-vlan 3 enable
[Sysname-dhcp-pool-0] voice-config fail-over 10.3.3.3 99*
vpn-instance命令用来为DHCP服务器上的地址池绑定VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
DHCP服务器上的地址池未绑定VPN实例。
DHCP地址池视图
vpn-instance-name:为DHCP地址池绑定的VPN实例名称。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
当地址池绑定了VPN实例后,DHCP服务器可以将网络划分成公网和VPN私网。未配置VPN属性的地址池被划分到公网,配置了VPN属性的地址池被划分到相应的VPN私网,这样,对于处于公网或VPN私网中的客户端,服务器都能够选择合适的地址池来为客户端分配租约并且记录该客户端的状态信息。
DHCP客户端的VPN信息可以从认证模块获取,也可以从DHCP服务器接收报文的接口配置的VPN信息获取。如果以上两种方式都可获取VPN信息,以从认证模块获取的VPN信息为准。
# 为DHCP地址池0绑定的VPN实例编号为abc。
[Sysname-dhcp-pool-0] vpn-instance abc
dhcp relay check mac-address命令用来开启DHCP中继的MAC地址检查功能。
undo dhcp relay check mac-address命令用来关闭DHCP中继的MAC地址检查功能。
DHCP中继的MAC地址检查功能处于关闭状态。
开启该功能后,DHCP中继检查接收到的DHCP请求报文中的chaddr字段和数据帧的源MAC地址字段是否一致。如果一致,则认为该报文合法,将其转发给DHCP服务器;如果不一致,则丢弃该报文。
只有在接口上配置dhcp select relay后,DHCP中继的MAC地址检查功能才会生效。
由于DHCP中继转发DHCP报文时会修改报文的源MAC地址,所以只能在靠近DHCP客户端的第一跳DHCP中继设备上开启MAC地址检查功能。
# 开启DHCP中继的MAC地址检查功能。
[Sysname-GigabitEthernet1/0] dhcp relay check mac-address
· dhcp select relay
dhcp relay check mac-address aging-time命令用来配置DHCP中继的MAC地址检查表项的老化时间。
undo dhcp relay check mac-address aging-time命令用来恢复缺省情况。
MAC地址检查表项的老化时间为30秒。
如果未通过dhcp relay check mac-address命令开启DHCP中继的MAC地址检查功能,则本命令的配置不会生效。
time:DHCP中继的MAC地址检查表项的老化时间,取值范围为30~600,单位为秒。
# 配置DHCP中继的MAC地址检查表项的老化时间为60秒。
[Sysname] dhcp relay check mac-address aging-time 60
dhcp relay client-information record命令用来开启DHCP中继用户地址表项记录功能。
undo dhcp relay client-information record命令用来关闭DHCP中继用户地址表项记录功能。
DHCP中继用户地址表项记录功能处于关闭状态。
当DHCP中继作为DHCP客户端的网关设备时,才会记录此DHCP客户端的地址表项。DHCP中继用户地址表项记录了DHCP客户端的IP地址、MAC地址和用户地址表项类型等信息。
关闭DHCP中继用户地址表项记录功能时,会删除DHCP中继上记录的全部地址表项。
# 开启DHCP中继用户地址表项记录功能。
[Sysname] dhcp relay client-information record
· dhcp relay client-information refresh
· dhcp relay client-information refresh enable
dhcp relay client-information refresh命令用来配置DHCP中继动态用户地址表项的定时刷新周期。
undo dhcp relay client-information refresh命令用来恢复缺省情况。
dhcp relay client-information refresh { auto | interval interval }
定时刷新周期为auto,即根据表项的数目自动计算刷新时间间隔。
auto:指定根据表项的数目自动计算刷新时间间隔。表项越多,刷新时间间隔越短,但最短时间间隔不会小于50毫秒。
interval interval:刷新时间间隔,取值范围为1~120,单位为秒。
# 配置DHCP中继动态用户地址表项的刷新时间间隔为100秒。
[Sysname] dhcp relay client-information refresh interval 100
· dhcp relay client-information record
dhcp relay client-information refresh enable命令用来开启DHCP中继动态用户地址表项定时刷新功能。
undo dhcp relay client-information refresh enable命令用来关闭DHCP中继动态用户地址表项定时刷新功能。
DHCP中继动态用户地址表项定时刷新功能处于开启状态。
DHCP中继动态用户地址表项定时刷新功能开启时,DHCP中继每隔指定时间采用客户端获取到的IP地址向DHCP服务器发送DHCP-REQUEST报文:
· 如果DHCP中继接收到DHCP服务器响应的DHCP-ACK报文或在指定时间内未接收到DHCP服务器的响应报文,则表明这个IP地址已经可以进行分配,DHCP中继会删除动态用户地址表中对应的表项,为了避免地址浪费,DHCP中继收到DHCP-ACK报文后,会发送DHCP-RELEASE报文释放申请到的IP地址。
· 如果DHCP中继接收到DHCP服务器响应的DHCP-NAK报文,则表示该IP地址的绑定信息仍然存在,DHCP中继不会删除该IP地址对应的表项。
需要注意的是,关闭DHCP中继动态用户地址表项定时刷新功能时,DHCP中继上记录的用户地址表项不会自动老化。DHCP客户端释放申请到的IP地址后,需要用户执行reset dhcp relay client-information命令删除DHCP中继上对应的用户地址表项。
# 关闭DHCP中继动态用户地址表项定时刷新功能。
[Sysname] undo dhcp relay client-information refresh enable
· reset dhcp relay client-information
dhcp relay forward reply by-option82命令用来配置DHCP中继通过Option 82信息转发DHCP应答报文。
undo dhcp relay forward reply by-option82命令用来恢复缺省情况。
DHCP中继不通过Option 82信息转发DHCP应答报文。
本功能需要同时配置dhcp relay information enable和dhcp relay information circuit-id命令才能生效。
# 配置DHCP中继通过Option 82信息转发DHCP应答报文。
[Sysname-GigabitEthernet1/0] dhcp relay forward reply by-option82
· dhcp relay information circuit-id
· dhcp relay information enable
dhcp relay gateway命令用来配置DHCP中继在DHCP报文中填充的中继地址。
undo dhcp relay gateway命令用来恢复缺省情况。
dhcp relay gateway ip-address
DHCP中继在DHCP报文中填充的中继地址是接口下的主IP地址。
ip-address:中继地址。该地址必须属于命令行所在的接口。
在接口视图下配置此命令后,中继会使用此命令配置的地址作为中继地址。
# 在接口GigabitEthernet1/0上配置在DHCP报文中填充的中继地址为10.1.1.1。
[Sysname-GigabitEthernet1/0] dhcp relay gateway 10.1.1.1
· gateway-list
dhcp relay information circuit-id命令用来配置Option 82的Circuit ID子选项的填充模式和填充格式。
undo dhcp relay information circuit-id命令用来恢复缺省情况。
dhcp relay information circuit-id { bas [ sub-interface-vlan ] | string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] [ interface ] } [ sub-interface-vlan ] [ format { ascii | hex } ] }
Option 82的Circuit ID子选项的填充模式为Normal,填充格式为hex。
bas:表示支持使用工信部规范的格式填充Circuit ID子选项。填充内容包括接口信息、VLAN信息,封装格式为:interface-type slot/subslot/port vxlan_id.vlan_id.subvlan_id。
sub-interface-vlan:以L2VE子接口所在的VLAN的VLAN编号来填充Circuit ID子选项。本参数只用于L3VE接口。如果未指定本参数,则表示填充的是配置本命令所在接口的VLAN ID。
string circuit-id:指定以用户配置的字符串填充Circuit ID子选项。circuit-id表示用户配置的用来填充Circuit ID子选项的内容,为3~63个字符的字符串,区分大小写。
normal:指定以Normal模式填充Circuit ID子选项,填充内容为VLAN ID和端口号。
verbose:指定以Verbose模式填充Circuit ID子选项。填充的内容为节点标识、接口信息和接口所在的VLAN编号。节点标识缺省以节点的MAC地址构成;接口信息缺省由以太网类型(取值固定为“eth”)、框号、槽号、子槽号和接口编号组成。
node-identifier { mac | sysname | user-defined node-identifier }:指定接入节点标识。
· mac:表示以节点的MAC地址作为节点标识。
· sysname:表示以节点的设备名称作为节点标识。设备的系统名称可以通过系统视图下的sysname命令配置。不管配置了哪种填充格式,设备的系统名称始终采用ASCII码格式填充。
则系统名称中不能包含空格,否则DHCP中继添加或替换Option 82失败。
· user-defined node-identifier:表示以指定的字符串作为节点标识,node-identifier为1~50个字符的字符串,区分大小写。不管配置了哪种填充格式,指定的字符串始终采用ASCII码格式填充。
interface:表示以接口名构成接口信息,始终采用ASCII码格式填充。
format:指定Circuit ID子选项的填充格式。
ascii:指定以ASCII码格式填充Circuit ID子选项,即将数值转换为对应的ASCII码填充到Circuit ID子选项。
hex:指定以十六进制数值的格式填充Circuit ID子选项。
以不同模式填充Circuit ID子选项时,填充格式有所不同:
· 以用户配置的字符串填充Circuit ID子选项时,填充格式固定为ASCII码格式;
· 以Normal和Verbose模式填充Circuit ID子选项时,填充格式由本命令的配置决定。
如果本命令中未指定填充格式,则对于Normal模式,VLAN ID和端口号均以hex格式填充;对于Verbose模式,节点标识(MAC地址、设备的系统名称或指定的字符串)、以太网类型、框号、槽号、子槽号、接口编号均以ASCII码格式填充,VLAN ID以hex格式填充。
· 如果本命令中指定填充格式为ascii,则所有内容均以ASCII码格式填充。
· 如果本命令中指定填充格式为hex,则对于Normal模式,VLAN ID和端口号均以hex格式填充;对于Verbose模式,设备的节点标识、以太网类型以ASCII码格式填充,其余内容均以hex格式填充。
Option 82的Circuit ID子选项信息中无法携带接口拆分信息或子接口信息,关于“接口拆分”和“子接口”的详细介绍,请参见“接口管理配置指导”中的“以太网接口”。
# 配置以Verbose模式填充Option 82的Circuit ID子选项,节点标识为设备的系统名称,填充格式为ASCII码格式。
[Sysname-GigabitEthernet1/0] dhcp relay information enable
[Sysname-GigabitEthernet1/0] dhcp relay information strategy replace
[Sysname-GigabitEthernet1/0] dhcp relay information circuit-id verbose node-identifier sysname format ascii
· dhcp relay forward reply by-option82
· dhcp relay information strategy
· display dhcp relay information
dhcp relay information enable命令用来开启DHCP中继支持Option 82功能。
undo dhcp relay information enable命令用来关闭DHCP中继支持Option 82功能。
DHCP中继支持Option 82功能处于关闭状态。
开启DHCP中继支持Option 82功能后,DHCP中继将向转发给DHCP服务器的请求报文中增加Option 82选项。选项内容由dhcp relay information circuit-id命令和dhcp relay information remote-id命令决定。如果DHCP中继收到的请求报文中已经包含Option 82选项,则按照dhcp relay information strategy命令配置的策略处理请求报文。
关闭DHCP中继支持Option 82功能后,DHCP中继不会向转发给DHCP服务器的请求报文中增加Option 82选项,也不检查收到的请求报文中是否包含Option 82选项。
# 开启DHCP中继支持Option 82功能。
· dhcp relay information remote-id
dhcp relay information remote-id命令用来配置Option 82的Remote ID子选项的填充模式和填充格式。
undo dhcp relay information remote-id命令用来恢复缺省情况。
Option 82的Remote ID子选项的填充模式为Normal、填充格式为hex。
normal:指定以Normal模式填充Remote ID子选项,填充内容为接收报文接口的MAC地址。
format:指定Remote ID子选项的填充格式。如果未配置本参数,则以hex格式填充。
ascii:指定以ASCII码格式填充Remote ID子选项,即将数值转换为对应的ASCII码填充到Remote ID子选项。
hex:指定以十六进制数值的格式填充Remote ID子选项。
string remote-id:指定以用户配置的字符串填充Remote ID子选项。remote-id表示用户配置的用来填充Remote ID子选项的内容,为1~63个字符的字符串,区分大小写。
sysname:指定以设备的系统名称填充Remote ID子选项。设备的系统名称可以通过系统视图下的sysname命令配置。
使用以用户配置的字符串(string)和设备的系统名称(sysname)填充Remote ID子选项时,填充内容固定为ASCII格式;Normal模式填充Remote ID子选项时,填充内容的格式由本命令配置的填充格式决定。
# 配置采用字符串device001填充Option 82的Remote ID子选项。
[Sysname-GigabitEthernet1/0] dhcp relay information remote-id string device001
dhcp relay information strategy命令用来配置DHCP中继对包含Option 82的请求报文的处理策略。
undo dhcp relay information strategy命令用来恢复缺省情况。
DHCP中继对带有Option 82的请求报文的处理策略为replace。
drop:如果报文中带有Option 82,则丢弃该报文。
keep:如果报文中带有Option 82,则保持该报文中的Option 82不变并进行转发。
replace:如果报文中带有Option 82,则按照配置的填充内容和填充格式填充Option 82,用该选项替换报文中原有的Option 82,并进行转发。
本命令仅对包含Option 82的请求报文有效。
如果开启了DHCP中继支持Option 82功能,则对于接收到的不包含Option 82的请求报文,DHCP中继的处理方式始终为在请求报文中添加Option 82,并转发给DHCP服务器。
DHCP中继对包含Option 82请求报文的处理策略为replace时,需要配置Option 82的填充模式和填充格式;处理策略为keep或drop时,不需要配置Option 82选项的填充模式和填充格式。
# 配置接收到的请求报文中带有Option 82时,DHCP中继保持该报文中的Option 82不变并进行转发。
[Sysname-GigabitEthernet1/0] dhcp relay information strategy keep
dhcp relay release ip命令用来配置向DHCP服务器请求释放客户端申请到的IP地址。
ip-address:请求释放的DHCP客户端IP地址。
vpn-instance vpn-instance-name:指定需要释放的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示释放公网IP地址。
如果DHCP中继上存在客户端IP地址对应的动态用户地址表项,则配置通过DHCP中继释放该客户端IP地址后,DHCP中继会主动向DHCP服务器发送DHCP-RELEASE报文。DHCP服务器收到该报文后,将会释放指定IP地址的绑定信息。DHCP中继也会删除该动态用户地址表项。
# 向DHCP服务器请求释放客户端申请到的IP地址1.1.1.1。
[Sysname] dhcp relay release ip 1.1.1.1
dhcp relay server-address命令用来在DHCP中继上指定DHCP服务器的地址。
undo dhcp relay server-address命令用来在DHCP中继上删除指定DHCP服务器的地址。
dhcp relay server-address ip-address
undo dhcp relay server-address [ ip-address ]
在DHCP中继上未指定DHCP服务器的地址。
ip-address:DHCP服务器的IP地址。DHCP中继将DHCP客户端发送的报文转发到该地址。
指定的DHCP服务器IP地址不能与DHCP中继的接口IP地址在同一网段。否则,可能导致客户端无法获得IP地址。
通过多次执行dhcp relay server-address命令可以指定多个DHCP服务器地址。一个接口上最多可以指定8个DHCP服务器地址。DHCP中继接收到DHCP客户端发送的报文后,将其转发给所有的DHCP服务器。
执行undo dhcp relay server-address命令时,如果未指定ip-address参数,则删除接口上的所有DHCP服务器地址。
# 在接口GigabitEthernet1/0上为DHCP中继指定DHCP服务器的地址为1.1.1.1。
[Sysname-GigabitEthernet1/0] dhcp relay server-address 1.1.1.1
· dhcp select relay
· display dhcp relay interface
dhcp relay source-address命令用来指定DHCP中继向DHCP服务器转发报文的源地址。
undo dhcp relay source-address命令用来恢复缺省情况。
dhcp relay source-address { ip-address | gateway | relay-interface }
当DHCP中继连接服务器的接口和DHCP服务器属于同一个VPN时,DHCP中继向DHCP服务器转发报文出接口的地址作为报文源地址;当DHCP中继连接服务器的接口和DHCP服务器不属于同一个VPN时,DHCP中继会选择一个中继上和DHCP服务器同VPN的最小地址作为报文源地址。
ip-address:DHCP中继向DHCP服务器转发报文的源地址。
gateway:DHCP中继向DHCP服务器转发报文的源地址为报文中giaddr字段地址,如果giaddr字段为空,则继续按照缺省情况填充。
relay-interface:DHCP中继向DHCP服务器转发报文的源地址为DHCP中继连接DHCP客户端的接口主IP地址,如果该接口不存在IP地址,则按照缺省情况继续填充。
在某些组网中,多个DHCP中继接口IP地址相同或者中继接口IP到服务器没有可达路由,用户需要配置本命令选择中继设备上的另一个接口(一般选择的是Loopback口)的IP地址填充到发送到DHCP服务器的DHCP请求报文中的源地址字段和Giaddr中。
当多个DHCP中继接口IP地址相同时,导致DHCP中继转发DHCP应答报文时候无法根据目的IP地址找到唯一的出接口。配置本功能时需要先开启DHCP中继支持Option 82功能,DHCP中继收到DHCP请求报文时在Option 82中的子选项sub-option5填充正确的子网网段,服务器可以根据中继填充的sub-option5 来分配地址,之后DHCP中继处理DHCP应答报文时通过MAC地址表中的接口信息转发DHCP应答报文。
多次执行命令,最后一次执行的命令生效。
# 在接口GigabitEthernet1/0上指定DHCP中继向DHCP服务器转发报文的源地址为1.1.1.1
[Sysname-GigabitEthernet1/0] dhcp relay source-address 1.1.1.1
· dhcp select relay
dhcp smart-relay enable命令用来开启DHCP中继支持smart-relay功能。
undo dhcp smart-relay enable命令用来关闭DHCP中继支持smart-relay功能。
DHCP中继支持smart-relay功能处于关闭状态。
未开启smart-relay功能时,DHCP中继只能使用中继接口的主IP地址填充请求报文的giaddr字段。开启smart-relay功能后,当DHCP中继转发3次DHCP-DISCOVER报文后,若还未收到DHCP服务器的应答报文,则DHCP中继可以使用除中继接口主地址外的其他IP地址来填充giaddr字段。
# 开启DHCP中继支持smart-relay功能。
[Sysname] dhcp smart-relay enable
· dhcp select
· gateway-list
display dhcp relay check mac-address命令用来显示DHCP中继的MAC地址检查表项。
# DHCP中继的MAC地址检查表项。
<Sysname> display dhcp relay check mac-address
Source-MAC Interface Aging-time
23f3-1122-adf1 GE1/0 10
23f3-1122-2230 GE2/0 30
表1-8 display dhcp relay check mac-address命令显示信息描述表
Source MAC |
检测到攻击的源MAC地址 |
攻击来源的接口 |
Aging-time |
DDOS攻击检测表项剩余时间,单位为秒 |
display dhcp relay client-information命令用来显示DHCP中继的用户地址表项信息。
interface interface-type interface-number:显示指定接口上的用户地址表项信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的用户地址表项信息。
ip ip-address:显示指定IP地址的用户地址表项信息。如果未指定本参数,则显示所有IP地址的用户地址表项信息。
vpn-instance vpn-instance-name:显示指定VPN实例内指定IP地址的用户地址表项信息。vpn-instance-name表示MPLS L3VPN的VPN实例名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网中的用户地址表项信息。
只有执行dhcp relay client-information record命令后,DHCP中继才会记录用户地址表项信息。
# 显示所有DHCP中继的用户地址表项信息。
<Sysname> display dhcp relay client-information
Total number of client-information items: 2
Total number of dynamic items: 1
Total number of temporary items: 1
IP address MAC address Type Interface VPN name
10.1.1.1 00e0-0000-0001 Dynamic GE1/0 N/A
10.1.1.5 00e0-0000-0000 Temporary GE1/0 N/A
表1-9 display dhcp relay client-information命令显示信息描述表
Total number of client-information items |
用户地址信息条目总数 |
Total number of dynamic items |
动态用户地址条目总数 |
Total number of temporary items |
临时用户地址条目总数 |
IP address |
DHCP客户端的IP地址 |
MAC address |
DHCP客户端的MAC地址 |
Type |
用户地址表项类型的取值包括: · Dynamic:动态用户地址表项,接收到DHCP服务器对DHCP客户端REQUEST请求的ACK应答后,创建的用户表项 · Temporary:临时用户地址表项,接收DHCP客户端的REQUEST请求,但未收到DHCP服务器ACK应答时,创建的用户表项 |
与DHCP客户端相连的三层接口。如果用户地址表项中未记录接口,则显示为”N/A” |
VPN name |
VPN实例名称,如果表项不属于任何VPN,则显示为”N/A” |
display dhcp relay information命令用来显示DHCP中继上的Option 82配置信息。
interface interface-type interface-number:显示指定接口上的Option 82配置信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的Option 82配置信息。
# 显示所有接口上的Option 82配置信息。
<Sysname> display dhcp relay information
Interface: GigabitEthernet1/0
Status: Enable
Strategy: Replace
Circuit ID Pattern: Verbose
Remote ID Pattern: Sysname
Circuit ID format: Undefined
Remote ID format: ASCII
Node identifier: aabbcc
Interface: GigabitEthernet2/0
Status: Enable
Strategy: Replace
Circuit ID Pattern: User Defined
Remote ID Pattern: User Defined
Circuit ID format: ASCII
User defined:
Circuit ID: vlan100
Remote ID: device001
表1-10 display dhcp relay information命令显示信息描述表
接口名 |
Status |
Option 82的状态,取值包括: · Enable:开启了DHCP中继支持Option 82功能 · Disable:未开启DHCP中继支持Option 82功能 |
Strategy |
对包含Option 82的请求报文的处理策略,取值为Drop、Keep或Replace |
Circuit ID Pattern |
Circuit ID子选项的填充方式,取值为Verbose、Normal或User Defined |
Remote ID Pattern |
Remote ID子选项的填充方式,取值为Sysname、Normal、User Defined |
Circuit ID format |
Circuit ID子选项的填充格式,取值为ASCII、Hex或Undefined |
Remote ID format |
Remote ID子选项的填充格式,取值为ASCII、Hex或Undefined |
Node identifier |
接入节点的标识 |
User defined |
用户自定义的子选项内容 |
Circuit ID |
用户自定义的Circuit ID子选项的内容 |
Remote ID |
用户自定义的Remote ID子选项的内容 |
display dhcp relay server-address命令用来显示接口上指定的DHCP服务器地址信息。
interface interface-type interface-number:显示指定接口上的DHCP服务器地址信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的DHCP服务器地址信息。
# 显示所有接口上指定的DHCP服务器地址信息。
<Sysname> display dhcp relay server-address
Interface name Server IP address
GE1/0 2.2.2.2
GE1/0 2.2.2.3
表1-11 display dhcp relay server-address命令显示信息描述表
Interface name |
接口名 |
Server IP address |
DHCP服务器地址 |
· dhcp relay server-address
display dhcp relay statistics命令用来显示DHCP中继的相关报文统计信息。
interface interface-type interface-number:显示指定接口的DHCP中继相关报文统计信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有的DHCP中继相关报文统计信息。
# 显示所有的DHCP中继相关报文统计信息。
<Sysname> display dhcp relay statistics
DHCP packets dropped: 0
DHCP packets received from clients: 0
DHCPDISCOVER: 0
DHCPREQUEST: 0
DHCPINFORM: 0
DHCPRELEASE: 0
DHCPDECLINE: 0
BOOTPREQUEST: 0
DHCP packets received from servers: 0
DHCPOFFER: 0
DHCPACK: 0
DHCPNAK: 0
BOOTPREPLY: 0
DHCP packets relayed to servers: 0
DHCPDISCOVER: 0
DHCPREQUEST: 0
DHCPINFORM: 0
DHCPRELEASE: 0
DHCPDECLINE: 0
BOOTPREQUEST: 0
DHCP packets relayed to clients: 0
DHCPOFFER: 0
DHCPACK: 0
DHCPNAK: 0
BOOTPREPLY: 0
DHCP packets sent to servers: 0
DHCPDISCOVER: 0
DHCPREQUEST: 0
DHCPINFORM: 0
DHCPRELEASE: 0
DHCPDECLINE: 0
BOOTPREQUEST: 0
DHCP packets sent to clients: 0
DHCPOFFER: 0
DHCPACK: 0
DHCPNAK: 0
BOOTPREPLY: 0
表1-12 display dhcp relay statistics命令显示信息描述表
DHCP packets dropped |
DHCP中继丢掉的报文数 |
DHCP packets received from clients |
DHCP中继从客户端接收的DHCP报文数 |
DHCP packets received from servers |
DHCP中继从服务器接收的DHCP报文数 |
DHCP packets relayed to servers |
DHCP中继转发给服务器的报文数 |
DHCP packets relayed to clients |
DHCP中继转发给客户端的报文数 |
DHCP packets sent to servers |
DHCP中继主动发送给服务器的DHCP报文数,用于实现动态用户地址表项的定时刷新 |
DHCP packets sent to clients |
DHCP中继主动发送给客户端的DHCP报文数(目前设备作为DHCP中继时,不会主动发送DHCP报文给客户端) |
· reset dhcp relay statistics
gateway-list命令用来指定匹配该地址池的DHCP客户端所在的网段的地址。
undo gateway-list命令用来删除指定的匹配该地址池的DHCP客户端所在的网段的地址。
未指定匹配该地址池的DHCP客户端所在的网段地址。
DHCP地址池视图
ip-address&<1-64>:该地址池的DHCP客户端所在的网段的地址。&<1-64>表示最多可以输入64个IP地址,每个IP地址之间用空格分隔。
# 指定匹配该地址池0的DHCP客户端所在的网段的地址为10.1.1.1。
[Sysname] dhcp server ip-pool 0
· dhcp smart-relay enable
remote-server命令用来指定中继地址池对应的DHCP服务器地址。
undo remote-server命令用来删除为中继地址池指定的DHCP服务器地址。
remote-server ip-address&<1-8>
undo remote-server [ ip-address&<1-8> ]
未指定中继地址池的DHCP服务器的地址。
DHCP地址池视图
ip-address&<1-8>:DHCP服务器的IP地址。&<1-8>表示最多可以输入8个不同的IP地址,每个IP地址之间需要用空格分隔。
执行undo remote-server命令时,如果未指定任何参数,则删除所有配置DHCP服务器地址。
# 配置DHCP地址池0为中继配置的服务器地址为10.1.1.1。
[Sysname-dhcp-pool-0] remote-server 10.1.1.1
reset dhcp relay client-information命令用来清除DHCP中继的用户地址表项信息。
interface interface-type interface-number:清除指定接口上的DHCP中继的用户地址表项信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有接口的DHCP中继的用户地址表项信息。
ip ip-address:清除指定IP地址的用户地址表项信息。如果未指定本参数,则清除所有IP地址的DHCP中继的用户地址表项信息。
vpn-instance vpn-instance-name:清除指定VPN实例内指定IP地址的用户地址表项信息。vpn-name表示MPLS L3VPN的VPN实例名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除公网的用户地址表项信息。
# 清除所有DHCP中继的用户地址表项信息。
<Sysname> reset dhcp relay client-information
· display dhcp relay client-information
reset dhcp relay statistics命令用来清除DHCP中继的相关报文统计信息。
interface interface-type interface-number:清除指定接口的DHCP中继相关报文统计信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有的DHCP中继相关报文统计信息。
# 清除所有的DHCP中继相关报文统计信息。
<Sysname> reset dhcp relay statistics
· display dhcp relay statistics
dhcp client dad enable命令用来开启地址冲突检查功能。
undo dhcp client dad enable命令用来关闭地址冲突检查功能。
地址冲突检查功能处于开启状态。
DHCP客户端通过发送和接收ARP报文,对DHCP服务器分配的IP地址进行地址冲突检测,如果攻击者仿冒地址拥有者进行ARP应答,就可以欺骗DHCP客户端,导致DHCP客户端无法正常使用分配到的IP地址。在网络中存在上述攻击者时,建议在客户端上关闭地址冲突检查功能。
# 关闭地址冲突检查功能。
[Sysname] undo dhcp client dad enable
dhcp client dscp命令用来配置DHCP客户端发送DHCP报文的DSCP优先级。
undo dhcp client dscp命令用来恢复缺省情况。
dhcp client dscp dscp-value
DHCP客户端发送DHCP报文的DSCP优先级为56。
dscp-value:DHCP请求报文的DSCP优先级,取值范围为0~63。
# 配置DHCP客户端发送的DHCP报文的DSCP优先级为30。
[Sysname] dhcp client dscp 30
dhcp client identifier命令用来配置接口使用指定的DHCP客户端ID。
undo dhcp client identifier命令用来恢复缺省情况。
根据本接口的MAC地址生成DHCP客户端ID。如果本接口没有MAC地址,则获取设备第一个以太接口的MAC地址生成DHCP客户端ID。
ascii ascii-string:使用指定的ASCII字符串作为该接口的客户端ID,为1~63个字符的字符串,区分大小写。
hex hex-string:使用指定的十六进制数作为该接口的客户端ID,为4~64个字符的字符串。
mac interface-type interface-number:使用指定接口的MAC地址作为客户端ID。interface-type interface-number表示接口类型和接口编号。
DHCP客户端ID用来填充DHCP报文Option 61,作为识别DHCP客户端的唯一标识。DHCP服务器可以根据客户端ID为特定的客户端分配特定的IP地址。用户可以通过以下三种方法指定DHCP客户端ID:ASCII字符串、十六进制数或使用指定接口的MAC地址作为DHCP客户端ID,以上三种方式都需要由用户保证不同客户端的客户端ID不会相同。
# 配置接口GigabitEthernet1/0使用的客户端ID为接口GigabitEthernet2/0的MAC地址。
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] dhcp client identifier mac gigabitethernet 2/0
display dhcp client命令用来显示DHCP客户端的相关信息。
verbose:显示DHCP客户端的详细信息。如果未指定本参数,则显示DHCP客户端简要信息。
interface interface-type interface-number:显示指定接口的DHCP客户端相关信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口的DHCP客户端信息。
# 显示所有接口的DHCP客户端简要信息。
<Sysname> display dhcp client
GigabitEthernet1/0 DHCP client information:
Current state: BOUND
Allocated IP: 40.1.1.20 255.255.255.0
Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
DHCP server: 40.1.1.2
# 显示所有接口的DHCP客户端详细信息。
<Sysname> display dhcp client verbose
Lease from May 21 19:00:29 2012 to May 31 19:00:29 2012
Transaction ID: 0x1c09322d
Default router: 40.1.1.2
Classless static routes:
Destination: 1.1.0.1, Mask: 255.0.0.0, NextHop: 192.168.40.16
Destination: 10.198.122.63, Mask: 255.255.255.255, NextHop: 192.168.40.16
DNS servers: 44.1.1.11 44.1.1.12
Domain name: ddd.com
Boot servers: 200.200.200.200 1.1.1.1
ACS parameter:
URL: http://192.168.1.1:7547/acs
Username: bims
Password: ******
Client ID value: 000c.29d3.8659-GE1/0
6433-2e38-3635-392d-
4574-6830-2f30-2f32
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
表1-13 display dhcp client命令显示信息描述表
XXXX DHCP client information |
作为DHCP客户端的接口信息 |
Current state |
DHCP客户端状态机的当前状态,取值包括: · HALT:停止申请IP地址状态; · INIT:初始化状态; · SELECTING:发送DHCP-DISCOVER报文寻找DHCP服务器后,进入该状态,等待DHCP服务器的响应报文; · REQUESTING:发送DHCP-REQUEST报文请求IP地址后,进入该状态,等待DHCP服务器的响应报文; · BOUND:接收到DHCP服务器发送的DHCP-ACK报文,成功获取IP地址后,进入该状态; · RENEWING:T1定时器超时后,进入该状态; · REBOUNDING:T2定时器超时后,进入该状态。 |
Allocated IP |
DHCP服务器为接口分配的IP地址 |
Allocated lease |
租约时长 |
T1 |
DHCP客户端的一半左右租约时间(以秒为单位) |
T2 |
DHCP客户端的7/8租约时间(以秒为单位) |
Lease from….to…. |
租约起止时间 |
DHCP server |
选择的DHCP服务器的地址 |
Transaction ID |
DHCP客户端发起申请时生成的一个随机数,用来唯一标识一次申请过程 |
Default router |
为DHCP客户端指定的网关地址 |
Classless static routes |
为DHCP客户端指定的无分类静态路由 |
Static routes |
为DHCP客户端指定的有分类静态路由 |
DNS servers |
为DHCP客户端指定的DNS服务器地址 |
Domain name |
为DHCP客户端指定的域名后缀 |
Boot servers |
为DHCP客户端指定的PXE引导服务器地址,通过Option 43获取,最多可以获取16个地址 |
ACS parameter |
ACS参数 |
URL |
ACS的URL地址 |
Username |
登录ACS设备使用的用户名 |
Password |
登录ACS设备使用的密码,若存在密码,则显示为“******”;若不存在密码,则不显示此项; |
Client ID type |
DHCP客户端ID的类型,type value表示类型值。类型为ASCII时,type value为00;为MAC address时,type value为01;为Hex时,type value为配置的十六进制数的前两位 |
Client ID value |
DHCP客户端ID的取值 |
Client ID (with type) hex |
DHCP客户端ID的十六进制形式(带类型值字段) |
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds. |
在多少时间后T1定时器(即一半左右租约时间)将到期 |
· dhcp client identifier
ip address dhcp-alloc命令用来配置接口通过DHCP协议获取IP地址。
undo ip address dhcp-alloc命令用来取消接口通过DHCP协议获取的IP地址。
接口不通过DHCP协议获取IP地址。
取消接口通过DHCP协议获取IP地址时,DHCP客户端会发送DHCP-RELEASE报文通知DHCP服务器释放租约。如果此时该接口处于down状态,则无法保证报文成功发送。
如果配置子接口通过DHCP协议获取IP地址,在其主接口上执行shutdown命令时,DHCP客户端不会发送请求释放子接口IP地址租约的DHCP-RELEASE报文。
# 在GigabitEthernet1/0接口上配置接口通过DHCP协议获取IP地址。
[Sysname-GigabitEthernet1/0] ip address dhcp-alloc
· display dhcp client
display bootp client命令用来显示BOOTP客户端的相关信息。
interface interface-type interface-number:显示指定接口的BOOTP客户端相关信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的BOOTP客户端的相关信息。
# 显示接口GigabitEthernet1/0的BOOTP客户端相关信息。
<Sysname> display bootp client interface gigabitethernet 1/0
GigabitEthernet1/0 BOOTP client information:
Allocated IP: 169.254.0.2 255.255.0.0
Transaction ID: 0x3d8a7431
MAC Address: 00e0-fc0a-c3ef
表1-14 display bootp client命令显示信息描述表
XXXX BOOTP client information |
作为BOOTP客户端的接口信息 |
Allocated IP |
BOOTP服务器为BOOTP客户端分配的IP地址 |
Transaction ID |
BOOTP报文中XID字段值,即BOOTP客户端发送BOOTP请求报文时选择的随机数,用来与BOOTP服务器的响应报文相匹配。如果响应报文的XID字段值与请求报文的XID字段值不相同,则BOOTP客户端丢弃该响应报文 |
MAC Address |
BOOTP客户端的MAC地址 |
· ip address bootp-alloc
ip address bootp-alloc命令用来配置接口通过BOOTP协议获取IP地址。
undo ip address bootp-alloc命令用来取消接口通过BOOTP协议获取的IP地址。
接口不通过BOOTP协议获取IP地址。
# 在GigabitEthernet1/0接口上配置接口通过BOOTP协议获取IP地址。
[Sysname-GigabitEthernet1/0] ip address bootp-alloc
· display bootp client
