03-负载均衡命令
本章节下载: 03-负载均衡命令 (540.12 KB)
1.1.1 activate (link group view)
1.1.2 bandwidth busy-protection enable (DNS proxy view)
1.1.3 bandwidth busy-protection enable (virtual server view)
1.1.4 bandwidth busy-rate (link view)
1.1.5 bandwidth interface statistics enable
1.1.8 connection-limit (virtual server view)
1.1.9 connection-limit max (link view)
1.1.12 default dns-server-pool
1.1.16 display loadbalance action
1.1.17 display loadbalance alg
1.1.18 display loadbalance class
1.1.19 display loadbalance dns-proxy
1.1.20 display loadbalance dns-proxy statistics
1.1.21 display loadbalance dns-server
1.1.22 display loadbalance dns-server statistics
1.1.23 display loadbalance dns-server-pool
1.1.24 display loadbalance isp
1.1.25 display loadbalance link
1.1.26 display loadbalance link statistics
1.1.27 display loadbalance link-group
1.1.28 display loadbalance policy
1.1.29 display loadbalance proximity
1.1.30 display loadbalance snat-pool
1.1.31 display parameter-profile
1.1.35 display virtual-server statistics
1.1.36 dns-server-pool (action view)
1.1.37 dns-server-pool (DNS server view)
1.1.38 fail-action (link group view)
1.1.39 fallback-action continue
1.1.42 ip address (DNS proxy view)
1.1.43 ip address (DNS server view)
1.1.46 ip range (snat pool view)
1.1.48 ipv6 address (DNS proxy view)
1.1.49 ipv6 address (DNS server view)
1.1.50 ipv6 address (ISP view)
1.1.53 lb-policy (DNS proxy view)
1.1.54 lb-policy (virtual server view)
1.1.56 link-group (action view)
1.1.60 loadbalance alg all-enable
1.1.64 loadbalance dns-server-pool
1.1.71 loadbalance schedule-test ip
1.1.72 loadbalance schedule-test ipv6
1.1.80 match destination domain-name
1.1.84 max-bandwidth (link view)
1.1.91 port (virtual server view)
1.1.92 predictor (DNS server pool view)
1.1.93 predictor (link group view)
1.1.94 priority (DNS server view)
1.1.96 probe (DNS server pool view)
1.1.97 probe (DNS server view)
1.1.98 probe (link group view)
1.1.100 proximity enable (link group view)
1.1.101 rate-limit bandwidth (link view)
1.1.102 rate-limit bandwidth (virtual server view)
1.1.103 rate-limit connection (link view)
1.1.104 rate-limit connection (virtual server view)
1.1.105 reset loadbalance connections
1.1.106 reset loadbalance dns-proxy statistics
1.1.107 reset loadbalance dns-server statistics
1.1.108 reset loadbalance link statistics
1.1.109 reset loadbalance proximity
1.1.110 reset virtual-server statistics
1.1.115 selected-server (DNS server pool view)
1.1.116 service enable (DNS proxy view)
1.1.117 service enable (virtual server view)
1.1.118 set ip tos (action view)
1.1.119 set ip tos (parameter profile view)
1.1.121 skip current-dns-proxy
1.1.122 slow-online (link group view)
1.1.123 slow-shutdown enable (link view)
1.1.124 snat-pool (link group view)
1.1.125 snmp-agent trap enable loadbalance
1.1.127 success-criteria (DNS server pool view)
1.1.128 success-criteria (DNS server view)
1.1.129 success-criteria (link group view)
1.1.130 success-criteria (link view)
1.1.131 timeout (proximity view)
1.1.132 timeout (sticky group view)
1.1.133 transparent enable (link group view)
1.1.137 virtual-server (system view)
设备各款型对于本节所描述的特性支持情况有所不同,详细差异信息如下:
系列 |
型号 |
产品代码 |
特性 |
WX1800H系列 |
WX1804H |
EWP-WX1804H-PWR-CN |
负载均衡 |
支持 |
WX2500H系列 |
WX2510H WX2510H-F WX2540H WX2540H-F WX2560H |
EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H |
支持 |
WX3000H系列 |
WX3010H WX3010H-X WX3010H-L WX3024H WX3024H-L WX3024H-F |
EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F |
支持 |
WX3500H系列 |
WX3508H WX3510H WX3520H WX3520H-F WX3540H |
EWP-WX3508H EWP-WX3510H EWP-WX3520H EWP-WX3520H-F EWP-WX3540H |
不支持 |
WX5500E系列 |
WX5510E WX5540E |
EWP-WX5510E EWP-WX5540E |
不支持 |
WX5500H系列 |
WX5540H WX5560H WX5580H |
EWP-WX5540H EWP-WX5560H EWP-WX5580H |
不支持 |
AC插卡系列 |
LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F |
不支持 |
activate命令用来配置链路组的可用条件。
undo activate命令用来恢复缺省情况。
activate lower lower-percentage upper upper-percentage
undo activate
链路组中只要有一个链路可用,该链路组就被认为可用。
链路组视图
lower lower-percentage:最小可用百分比,取值范围为1~99。
upper upper-percentage:最大可用百分比,取值范围为1~99,且必须大于等于最小可用百分比。
当主用链路组中可用的链路数量占链路总数量的百分比低于最小可用百分比时,该链路组将被认为不可用,从而切换到备用链路组;当主用链路组中可用的链路数量占链路总数量的百分比高于最大可用百分比时,将从备用链路组切换回主用链路组。
当虚服务器上未配置备用链路组时,本配置无效。
# 配置链路组lg的最小可用百分比为20,最大可用百分比为80。
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] activate lower 20 upper 80
bandwidth busy-protection enable命令用来开启DNS服务器对应链路的带宽繁忙保护功能。
undo bandwidth busy-protection enable命令用来关闭DNS服务器对应链路的带宽繁忙保护功能。
DNS服务器对应链路的带宽繁忙保护功能处于关闭状态。
DNS透明代理视图
开启带宽繁忙保护功能后,DNS透明代理设备从DNS服务器池中选择DNS服务器时,会查看DNS服务器使用的链路的繁忙比例是否超过配置的带宽繁忙比例,如果超出则不选择该DNS服务器。
当DNS服务器池中的所有DNS服务器对应的链路都达到了带宽繁忙比例时,带宽繁忙保护功能自动失效;只要此DNS服务器池中有一个DNS服务器对应链路恢复到配置的带宽繁忙比例以下,则该DNS服务器重新参与调度,带宽繁忙保护功能自动生效。
# 在名称为dns-proxy1的DNS透明代理视图下,开启DNS服务器对应链路的带宽繁忙保护功能。
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] bandwidth busy-protection enable
· bandwidth busy-rate(link view)
bandwidth busy-protection enable命令用来开启链路的带宽繁忙保护功能。
undo bandwidth busy-protection enable命令用来关闭链路的带宽繁忙保护功能。
链路的带宽繁忙保护功能处于关闭状态。
虚服务器视图
带宽繁忙保护功能仅在链路的接口带宽统计功能开启的情况下生效。
# 在Link-IP类型的虚服务器vs3中开启链路带宽繁忙保护功能。
<Sysname>system-view
[Sysname] virtual-server vs3 type link-ip
[Sysname-vs-link-ip-vs3] bandwidth busy-protection enable
相关命令】
· bandwidth interface statistics enable
bandwidth busy-rate命令用来配置链路的带宽繁忙比。
undo bandwidth busy-rate命令用来恢复缺省情况。
bandwidth [ inbound | outbound ] busy-rate busy-rate-number [ recovery recovery-rate-number ]
undo bandwidth [ inbound | outbound ] busy-rate
带宽繁忙比例为70。
链路视图
inbound:表示入方向的带宽繁忙比。
outbound:表示出方向的带宽繁忙比。
busy-rate-number:链路的带宽繁忙比例,取值范围为1~100。
recovery recovery-rate-number:链路带宽繁忙恢复比例,取值范围为1~100。缺省情况下,当带宽繁忙比例大于10时,带宽繁忙恢复比例为带宽繁忙比例减去10;当带宽繁忙比例小于等于10时,带宽繁忙恢复比例等于带宽繁忙比例。
当链路的带宽超过该链路的带宽繁忙比例与最大期望带宽的乘积时,链路进入繁忙状态,不再参与调度。当链路的带宽低于带宽繁忙恢复比例与最大期望带宽的乘积时,链路解除繁忙状态,重新参与调度。
若未指定inbound或outbound关键字,则表示设置链路的总带宽繁忙比例。
带宽繁忙比例为当前链路实际带宽与用户配置最大带宽的百分比值,若最大带宽设置为不受限,则使用其可设置的最大值进行计算。同一链路的带宽繁忙恢复比例必须小于等于带宽繁忙比例。
本命令只在新建会话时生效,对已经存在的会话不生效。
# 配置链路lk1的总带宽繁忙比例为90,带宽繁忙恢复比例为85。
[Sysname] loadbalance link lk1
[Sysname-lb-link-link1] bandwidth busy-rate 90 recovery 85
· display loadbalance link
· max-bandwidth(link view)
bandwidth interface statistics enable命令用来开启链路的接口带宽统计功能。
undo bandwidth interface statistics enable命令用来关闭链路的接口带宽统计功能。
接口带宽统计功能处于关闭状态。
虚服务器视图
# 在Link-IP类型的虚服务器vs3上,并开启链路的接口带宽统计功能。
[Sysname-vs-link-ip-vs3] bandwidth interface statistics enable
bandwidth weight命令用来配置就近性计算的带宽权值。
undo bandwidth weight命令用来恢复缺省情况。
bandwidth { inbound | outbound } weight bandwidth-weight
undo bandwidth { inbound | outbound } weight
就近性计算的出、入方向带宽权值均为100。
就近性视图
inbound:表示入方向的带宽权值。
outbound:表示出方向的带宽权值。
bandwidth-weight:就近性计算的带宽权值,取值范围为0~255,数值越大权重越大。
# 配置就近性计算的入方向带宽权值为200。
[Sysname] loadbalance proximity
[Sysname-lb-proximity] bandwidth inbound weight 200
# 配置就近性计算的出方向带宽权值为200。
[Sysname-lb-proximity] bandwidth outbound weight 200
class命令用来指定负载均衡类对应的负载均衡动作。
undo class命令用来删除指定的负载均衡类。
class class-name [ insert-before before-class-name ] action action-name
undo class class-name
未指定负载均衡类对应的负载均衡动作。
负载均衡策略视图
class-name:负载均衡类的名称,为1~63个字符的字符串,不区分大小写。
insert-before before-class-name:表示插入到指定的负载均衡类之前(该负载均衡类必须已被当前负载均衡策略引用)。before-class-name为1~63个字符的字符串,不区分大小写。
action-name:负载均衡动作的名称,为1~63个字符的字符串,不区分大小写。
通过本命令可以为匹配特定负载均衡类的报文指定其执行的负载均衡动作。
不同的负载均衡类可以与同一负载均衡动作组成匹配规则。
DNS类型的负载均衡策略只能引用DNS类型的负载均衡动作;Link-generic类型的负载均衡策略只能引用Link-generic类型的负载均衡类和负载均衡动作。
# 在DNS类型的负载均衡策略lbp1中,为负载均衡类lbc1指定负载均衡动作为lba1,并将lbc1插入到负载均衡类lbc0之前。
[Sysname] loadbalance policy lbp1 type dns
[Sysname-lbp-dns-lbp1] class lbc1 insert-before lbc0 action lba1
connection-limit命令用来配置虚服务器所允许的最大连接数。
undo connection-limit命令用来恢复缺省情况。
connection-limit max max-number
虚服务器所允许的最大连接数为0,即不受限制。
虚服务器视图
max-number:最大连接数,取值范围为0~4294967295,0表示虚服务器所允许的最大连接数不受限制。
# 配置Link-IP类型的虚服务器vs3所允许的最大连接数为10000。
[Sysname-vs-link-ip-vs3] connection-limit max 10000
connection-limit max命令用来配置链路所允许的最大连接数。
undo connection-limit max命令用来恢复缺省情况。
链路所允许的最大连接数为0,即不受限制。
链路视图
max-number:最大连接数,取值范围为0~4294967295,0表示链路所允许的最大连接数不受限制。
# 配置链路的最大连接数为10000。
[Sysname-lb-link-lk] connection-limit max 10000
cost命令用来配置就近性计算的链路成本。
undo cost命令用来恢复缺省情况。
cost cost-value
undo cost
就近性计算的链路成本为0。
链路视图
cost-value:就近性计算的链路成本,取值范围为0~10240。
# 在链路lk1中配置就近性计算的链路成本为200。
[Sysname-lb-link-lk1] cost 200
cost weight命令用来配置就近性计算的成本权值。
undo cost weight命令用来恢复缺省情况。
cost weight cost-weight
undo cost weight
就近性计算的成本权值为100。
就近性视图
cost-weight:就近性计算的成本权值,取值范围为0~255,数值越大权重越大。
# 配置就近性计算的费用权值为200。
[Sysname-lb-proximity] cost weight 200
default dns-server-pool命令用来指定DNS透明代理引用的缺省DNS服务器池。
undo default dns-server-pool命令用来恢复缺省情况。
default dns-server-pool pool-name [ sticky sticky-name ]
undo default dns-server-pool pool-name
未指定DNS透明代理引用的缺省DNS服务器池。
DNS透明代理视图
pool-name:DNS服务器池名称,为1~63个字符的字符串,不区分大小写。
sticky sticky-name:持续性组的名称,为1~63个字符的字符串,不区分大小写。若未指定该参数,则DNS服务器池不对应持续性组。
多次执行本命令,最后一次执行的命令生效。
# 在名称为dns-proxy1的DNS透明代理视图下,配置DNS透明代理引用的缺省DNS服务器池为dns-pool1,持续性组名称为st1。
[Sysname-lb-dp-udp-dns-proxy1] default dns-server-pool dns-pool1 sticky st1
default link-group命令用来指定缺省链路组。
undo default link-group命令用来恢复缺省情况。
default link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
未指定缺省的链路组。
Link-IP类型的虚服务器视图
link-group-name:主用链路组的名称,为1~63个字符的字符串,不区分大小写。
backup backup-link-group-name:备用链路组的名称,为1~63个字符的字符串,不区分大小写。
当主用链路组可用(该链路组存在且有可用的链路)时,虚服务器通过主用链路组转发报文;当主用链路组不可用而备用链路组可用时,虚服务器通过备用链路组转发报文。
# 为Link-IP类型的虚服务器vs3指定缺省的主用链路组为link1,备用链路组为link2,持续性组名称为sg1。
[Sysname--vs-link-ip-vs3] default link-group link1 backup link2 sticky sg1
default-class action命令用来配置缺省的负载均衡动作。
undo default-class命令用来恢复缺省情况。
default-class action action-name
undo default-class
未配置缺省的负载均衡动作。
负载均衡策略视图
通过本命令可以为未匹配任何负载均衡类的报文指定其执行的缺省动作。
DNS类型的负载均衡策略只能引用DNS类型的负载均衡动作作为其缺省负载均衡动作;通用类型的负载均衡策略只能用通用类型的负载均衡动作作为其缺省的负载均衡动作。
# 在Link-generic类型的负载均衡策略lbp1中,配置缺省的负载均衡动作为lba1。
[Sysname] loadbalance policy lbp1 type link-generic
[Sysname-lbp-link-generic-lbp1] default-class action lba1
description命令用来配置描述信息。
undo description命令用来恢复缺省情况。
未配置描述信息。
ISP视图
负载均衡动作视图
负载均衡类视图
负载均衡策略视图
参数模板视图
持续性组视图
虚服务器视图
链路组视图
链路视图
DNS服务器池视
DNS服务器视图
SNAT地址池视图
text:描述信息,为1~127个字符的字符串,区分大小写。
# 配置Link-generic类型的负载均衡动作lba1的描述信息为“LB action LBA1”。
[Sysname] loadbalance action lba1 type link-generic
[Sysname-lba-link-generic-lba1] description LB action LBA1
display loadbalance action命令用来显示负载均衡动作的信息。
display loadbalance action [ name action-name ]
name action-name:显示指定负载均衡动作的信息。action-name为负载均衡动作的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡动作的信息。
# 显示所有负载均衡动作的信息。
<Sysname> display loadbalance action
LB action: lba3
Description: sina
Type: Link-generic
State: Active
Forward type: link group
Link group: lg1 (in use)
Backup link group: lg2
Sticky:
IP ToS:
Fallback-action: None
LB action: lba4
Description: xx
Type: DNS
State: Active
Forward type: DNS server pool
DNS server pool: dsp1
Sticky: st
IP ToS:
Fallback-action: Disabled
表1-1 display loadbalance action命令显示信息描述表
LB action |
负载均衡动作的名称 |
负载均衡动作的描述信息 |
Type |
负载均衡动作的类型,包括: · DNS:表示DNS类型 · Link-generic:表示链路类型 |
State |
负载均衡动作的状态,包括: · Active:可用 · Inactive:不可用 |
Forward type |
负载均衡动作中的报文转发模式,包括: · Drop:丢弃 · Forward:正常转发 · Link group:链路组(Link-generic类型的负载均衡动作) · DNS server pool:通过DNS服务器池指导转发(DNS类型的负载均衡动作) · Skip current DNS proxy:跳过当前DNS透明代理(DNS类型的负载均衡动作) |
Link group |
缺省的链路组,如果包含(in use)代表链路组是当前正在使用 |
Backup link group |
备份的链路组,如果包含(in use)代表实链路组是当前正在使用 |
Sticky |
指导转发的持续性组名称,只有当报文转发模式为DNS server pool时才会显示本字段 |
IP ToS |
IP报文的ToS字段值 |
Fallback-action |
负载均衡处理失败时进行的操作,包括: · None:不做任何操作 · Continue:继续匹配下一条引用规则 · Response:用指定文件进行代答操作 |
DNS server pool |
指导转发的DNS服务器池名称,只有当报文转发模式为DNS server pool时才会显示本字段 |
display loadbalance alg用来显示所有协议的负载均衡ALG状态。
# 显示所有协议的负载均衡ALG状态。
<Sysname> display loadbalance alg
LB ALG:
DNS : Enable
FTP : Enable
H323 : Enable
ICMP-ERROR : Enable
ILS : Enable
MGCP : Enable
NBT : Enable
PPTP : Enable
RSH : Enable
RTSP : Enable
SCCP : Enable
SIP : Enable
SQLNET : Enable
TFTP : Enable
XDMCP : Enable
display loadbalance class命令用来显示负载均衡类的信息。
display loadbalance class [ name class-name ]
name class-name:显示指定负载均衡类的信息。class-name为负载均衡类的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡类的信息。
# 显示所有负载均衡类的信息。
<Sysname> display loadbalance class
LB class: lbc3
Description:
Type: Link-generic
Match type: Match-any
Match rule:
match 1 class cla3
match 2 source ip address 1.2.3.0 24
match 3 source ipv6 address 1::12
match 4 acl ipv4 number 3002
match 5 acl ipv6 number 3003
match 6 acl ipv4 name ccc
match 7 acl ipv6 name ddd
match 8 isp name isp2
match 9 user u1
match 10 user-group lb-group
match 11 interface GE1/0/1
LB class: lbc4
Description:
Type: DNS
Match rule:
match 1 class cla2
match 8 destination ip address 1.2.3.0 24
match 9 destination ipv6 address 1::12
match 10 domain-name www.h3c.com
表1-2 display loadbalance class命令显示信息描述表
LB class |
负载均衡类的名称 |
负载均衡类的描述信息 |
Type |
负载均衡类的类型,包括: · DNS:表示DNS类型 · Link-generic:表示链路类型 |
Match type |
负载均衡类的匹配类型,包括: · Match-all:表示需要匹配所有规则才算匹配该类 · Match-any:表示只需匹配任一规则就算匹配该类 |
Match rule |
负载均衡类包含的匹配规则 |
display loadbalance dns-proxy命令用来显示DNS透明代理的信息。
display loadbalance dns-proxy [ brief | name dns-proxy-name ]
brief:显示DNS透明代理的简要信息。如果未指定本参数,将显示DNS透明代理的详细信息。
name dns-proxy-name:DNS透明代理名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有DNS透明代理的信息。
# 显示所有DNS透明代理的简要信息。
<Sysname> display loadbalance dns-proxy brief
DNS proxy State Type VPN instance IP address Port
dns-proxy1 Active UDP 1.2.3.0/24 53
dns-proxy2 Inactive UDP -- 5353
# 显示DNS透明代理dns-proxy1的信息
<Sysname> display loadbalance dns-proxy name dns-proxy1
DNS proxy:dns-proxy1
Type: UDP
State: Active
Service state:Enabled
VPN instance:
IPv4 address: 1.2.3.0/24
IPv6 address: --
Port: 53
DNS server pool: dns-pool1
Sticky: st
LB policy: dns-policy1
Connection synchronization: Enabled
Sticky synchronization: Enabled
Bandwidth busy protection: Disabled
表1-3 display loadbalance dns-proxy命令显示信息描述表格内容
DNS proxy |
DNS透明代理名称 |
Type |
DNS透明代理类型,目前仅支持UDP类型 |
State |
DNS透明代理的状态,包括: · Active:可用 · Inactive:不可用(已开启DNS透明代理功能功能,仍不可用) · Inactive (disabled):不可用(由于未开启DNS透明代理功能) |
Service State |
DNS透明代理是否使能: · Enabled:使能 · Disabled:未使能 |
VPN instance |
(暂不支持)DNS透明代理所属的VPN实例名称 |
IPv4 address |
DNS透明代理的IPv4地址 |
IPv6 address |
DNS透明代理的IPv6地址 |
Port |
DNS透明代理的端口号 |
DNS server pool |
DNS透明代理缺省使用的DNS服务器池 |
Sticky |
DNS透明代理引用的持续性组 |
LB policy |
DNS透明代理引用的负载均衡策略 |
Bandwidth busy protection |
链路带宽繁忙保护功能的状态,包括: · Enabled:开启 · Disabled:关闭 |
display loadbalance dns-proxy statistics命令用来显示DNS透明代理的统计信息。
display loadbalance dns-proxy statistics [ name dns-proxy-name ]
name dns-proxy-name:显示指定DNS透明代理的统计信息。dns-proxy-name为DNS透明代理的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有DNS透明代理的统计信息。
# 显示DNS透明代理dns-proxy1的统计信息。
<Sysname> display loadbalance dns-proxy statistics name dns-proxy1
DNS proxy: dns-proxy1
Received requests: 100
Dropped requests: 2
Received responses: 98
Dropped responses: 0
表1-4 display dns-proxy statistic命令显示信息描述表格内容
DNS proxy |
DNS透明代理名称 |
Received requests |
DNS透明代理接受DNS请求报文的数目 |
Dropped requests |
DNS透明代理丢弃DNS请求报文的数目 |
Received responses |
DNS透明代理接受DNS应答报文的数目 |
Dropped responses |
DNS透明代理丢弃DNS应答报文的数目 |
display loadbalance dns-server用来显示DNS服务器的信息。
display loadbalance dns-server [ brief | name dns-server-name ]
brief:显示DNS服务器的简要信息。若未指定本参数,将显示DNS服务器的详细信息。
name dns-server-name:显示指定DNS服务器的详细信息。其中,dns-server-name表示DNS服务器名,为1~63个字符的字符串,不区分大小写。
若不指定任何参数,则显示所有DNS服务器的详细信息。
若设备同时学习到多个DNS服务器的IP地址时,优先选择最小的可用IP。
未配置健康检测方法时,设备认为学习到的所有DNS服务器IP地址均可用;配置健康检测方法时,仅认为健康检测成功的IP地址为可用地址。
# 显示所有DNS服务器的简要信息。
<Sysname> display loadbalance dns-server brief
(*) – Auto-alloc address using
DNS server Address Port Link State DNS server pool
ds1 10.150.100.100(*) 0 link1 Active dns_pool
ds2 20.150.100.100 5353 link2 Probe-failed dns_pool
ds3 -- 0 link3 Inactive dns_pool
ds4 --(*) 0 link3 Inactive dns_pool
# 显示DNS服务器ds1的详细信息。
<Sysname> display loadbalance dns-server name ds1
DNS server: ds1
Description:
State: Active
IPv4 address: 10.150.100.100(*)
10.160.100.1
10.154.60.2
IPv6 address: --
Port: 0
Link: link1
Weight: 100
Priority: 4
Probe information:
Probe success criteria: All
Probe method State
t4 Succeeded
表1-5 display loadbalance dns-server命令显示信息描述表
DNS服务器的名称 |
DNS服务器的IPv4地址,如果该地址的获取方式为动态获取且获取到多个IP地址,则显示所有获取到的IP地址,(*)表示该地址目前正在使用;如果获取到的所有IP地址均不可用,则显示--(*);如果未获取到任何IP地址且用户未手工配置IP地址,则显示-- |
Link |
DNS服务器对应的链路 |
State |
DNS服务器的状态,包括: · Active:可用 · Busy:繁忙(当DNS服务器处于Active状态,且开启繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态) · Inactive:不可用(由于配置不完全、未被引用) · Probe-failed:健康检测失败 |
DNS服务器的描述信息 |
IPv4 address |
DNS服务器的IPv4地址 |
IPv6 address |
DNS服务器的IPv6地址 |
Port |
DNS服务器的端口号 |
DNS服务器的权值 |
Priority |
DNS服务器的优先级 |
Probe information |
DNS服务器健康检测的详细信息 |
Probe success criteria |
DNS服务器健康检测的成功条件: · All:只有全部方法都通过检测才认为健康检测成功 · At least:健康检测成功所需通过检测的最少方法数 |
Probe method |
健康检测方法所使用的NQA模板名称 |
State |
健康检测方法的状态,包括: · Failed:健康检测失败 · In progress:正在进行健康检测 · Invalid:健康检测不可用(因其所使用的NQA模板配置不完全),或者DNS服务器不可用 · Succeeded:健康检测成功 |
display loadbalance dns-server statistics命令用来显示DNS服务器的统计信息。
display loadbalance dns-server statistics [ name dns-server-name ]
name dns-server-name:显示指定DNS服务器的统计信息。dns-server-name为DNS服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有DNS服务器的统计信息。
# 显示指定DNS服务器ds1的统计信息。
<Sysname> display loadbalance dns-server statistics name ds1
DNS server: ds1
Dropped requests: 2
Send responses: 98
表1-6 display loadbalance dns-server statistic命令显示信息描述表
DNS server |
DNS服务器名称 |
Received requests |
DNS服务器接受DNS请求报文的数目 |
Dropped requests |
DNS服务器丢弃DNS请求报文的数目 |
Send responses |
DNS服务器分发DNS应答报文的数目 |
Dropped responses |
DNS服务器丢弃DNS应答报文的数目 |
display loadbalance dns-server-pool命令用来显示DNS服务器池的信息。
display loadbalance dns-server-pool [ brief | name pool-name ]
brief:显示DNS服务器池的简要信息。如果未指定本参数,将显示DNS服务池的详细信息。
name pool-name:显示指定DNS服务器池的详细信息。其中,pool-name为DNS服务器池的名称,为1~63个字符的字符串,不区分大小写。
若不指定任何参数,则显示所有DNS服务器池的详细信息。
# 显示所有DNS服务器池的简要信息。
<Sysname> display loadbalance dns-server-pool brief
Predictor: RR - Round robin, RD - Random,
BW - Bandwidth, MBW - Max bandwidth,
IBW - Inbound bandwidth, OBW - Outbound bandwidth,
MIBW - Max inbound bandwidth, MOBW - Max outbound bandwidth,
HASH(SIP) - Hash address source IP,
HASH(DIP) - Hash address destination IP,
HASH(SIP-PORT) - Hash address source IP-port
DNS server pool Predictor Total Active
dns-pool RR 3 2
dns-pool1 RR 0 0
dns-pool2 RD 3 0
# 显示DNS服务器池dns-pool的详细信息。
<Sysname> display loadbalance dns-server-pool name dns-pool
Description:
Predictor: Round robin
Selected server: Enabled
Min servers: 3
Max servers: 5
Probe information:
Probe success criteria: At-least 2
Probe method: t4
Total DNS servers: 3
Active DNS servers: 0
DNS server list:
Name State Address port Link Weight Priority
ds1 Active 10.150.100.100 0 link1 100 4
ds2 Probe-failed 20.150.100.100 5353 link2 100 4
ds3 Inactive -- 0 link3 100 4
表1-7 display loadbalance dns-server-pool命令显示信息描述表
DNS服务器池的调度算法,包括: · RR:加权轮转算法 · RD:随机算法 · BW:总带宽算法 · IBW:入方向带宽算法 · OBW:出方向带宽算法 · MBW:最大总带宽算法 · MIBW:最大入方向带宽算法 · MOBW:最大出方向带宽算法 · HASH(SIP):根据源IP地址进行的哈希算法 · HASH(DIP):根据目的IP地址进行的哈希算法 · HASH(SIP-PORT):根据源IP地址和端口号进行的哈希算法 |
DNS server pool |
DNS服务器池的名称 |
Total |
包含的DNS服务器总数 |
Active |
活跃的DNS服务器数量 |
DNS服务器池的描述信息 |
Predictor |
DNS服务器池的调度算法,包括: · Round robin:加权轮转算法 · Random:随机算法 · Bandwidth:总带宽算法 · Inbound bandwidth:入方向带宽算法 · Outbound bandwidth:出方向带宽算法 · Max bandwidth:最大总带宽算法 · Max inbound bandwidth:最大入方向带宽算法 · Max outbound bandwidth:最大出方向带宽算法 · Hash address source IP:根据源IP地址进行的哈希算法 · Hash address source IP-port:根据源IP地址和端口号进行的哈希算法 · Hash address destination IP:根据目的IP地址进行的哈希算法 |
DNS服务器池中可被调度算法调用的DNS服务器数量限制功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示: · Min servers:可被调度算法调用的DNS服务器最小数量 · Max servers:可被调度算法调用的DNS服务器最大数量 |
Probe information |
DNS服务器池健康检测的详细信息 |
Probe method |
健康检测方法所使用的NQA模板名称 |
Total DNS servers |
包含的DNS服务器数量 |
Active DNS servers |
活跃的DNS服务器数量 |
DNS服务器列表 |
DNS服务器的名称 |
DNS服务器的状态,包括: · Active:可用 · Busy:繁忙(当DNS服务器处于Active或Ramp状态,且开启繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态) · Inactive:不可用(由于配置不完全、未被引用) · Probe-failed:健康检测失败 |
DNS服务器的IP地址,如果该地址的获取方式为动态获取且获取到多个IP地址,则显示所有获取到的IP地址,(*)表示该地址目前正在使用;如果获取到的所有IP地址均不可用,则显示--(*);如果未获取到任何IP地址且用户未手工配置IP地址,则显示-- |
Port |
DNS服务器的端口号 |
Link |
DNS服务器对应的链路的名称 |
Weight |
DNS服务器的权值 |
Priority |
DNS服务器的调用优先级 |
display loadbalance isp命令用来显示ISP的信息。
display loadbalance isp [ ip ipv4-address | ipv6 ipv6-address | name isp-name ]
ip ipv4-address:显示指定IPv4地址所对应ISP的信息。
ipv6 ipv6-address:显示指定IPv6地址所对应ISP的信息。
name isp-name:显示指定名称的ISP的信息,isp-name为1~63个字符的字符串,不区分大小写。
如果未指定任何可选参数,将显示所有ISP的信息。
# 显示所有ISP的信息。
<Sysname> display loadbalance isp
(*) - User-defined object
LB ISP: isp1
Description: ISP1
IPv4 address/Mask length: --
IPv6 address/Prefix length: --
LB ISP: isp2(*)
Description:
1.2.3.0/32(*) 1.2.3.4/32 3.3.3.6/32(*)
192.168.6.131/32(*) 192.168.195.189/32(*)
1::2/128
FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF/128(*)
# 显示IPv4地址1.2.3.0所对应ISP的信息。
<Sysname> display loadbalance isp ip 1.2.3.0
ISP name Source IPv4 address/Mask length
isp2 user-set 1.2.3.0/28
isp2 user-set 1.2.3.0/29
isp2 user-set 1.2.3.0/30
isp2 file-load 1.2.3.0/31
isp2 file-load & user-set 1.2.3.0/32
# 显示IPv6地址1::1234所对应ISP的信息。
<Sysname> display loadbalance isp ipv6 1::1234
ISP name Source IPv6 address/Prefix length
isp2 user-set 1::1234/126
isp2 user-set 1::1234/127
isp2 file-load 1::1234/128
表1-8 display loadbalance isp命令显示信息描述表
(*) - User-defined object |
(*)表示该ISP信息仅由用户手动配置而来。如果ISP信息既是手工配置又是文件导入时,不显示(*) |
LB ISP |
ISP的名称 |
ISP的描述信息 |
IPv4 address/Mask length |
ISP的IPv4地址和掩码长度 |
IPv6 address/Prefix length |
ISP的IPv6地址和前缀长度 |
ISP name |
ISP的名称 |
Source |
ISP的来源,包括: · user-set:表示由用户手工配置 · file-load:表示由文件导入 · file-load & user-set:表示既是手动配置又是文件导入 |
display loadbalance link命令用来显示链路的信息。
display loadbalance link [ brief | name link-name ]
brief:显示所有链路的简要信息。如果未指定本参数,将显示链路的详细信息。
name link-name:显示指定链路的详细信息。link-name为链路的名称,为1~63个字符的字符串,不区分大小写。
如果未指定任何参数,则表示显示所有链路的详细信息。
# 显示所有链路的简要信息。
<Sysname> display loadbalance link brief
Link Router IP State VPN instance Link group
Lk1 192.168.1.1 Busy -- lg
Lk2 192.168.2.1 Active -- lg
Lk3 Dialer0 Inactive -- lg
# 显示链路lk的详细信息。
<Sysname> display loadbalance link name lk
Link: lk
Description: lk
State: Busy
VPN instance: --
Inherit VPN: Disabled
Router IP: 1.2.3.4
Router IPv6: --
Link-group: lg
Weight: 100
Priority: 4
Cost: 0
Slow-shutdown: Disabled
Connection limit: 0
Rate limit:
Connections: 10000
Bandwidth: 10000 Kbytes/s
Inbound bandwidth: 5000 Kbytes/s
Outbound bandwidth: 5000 Kbytes/s
Bandwidth busy:
Max bandwidth: 10000 Kbytes/s
Max inbound bandwidth: 5000 Kbytes/s
Max outbound bandwidth: 5000 Kbytes/s
Busy rate: 80
Inbound busy rate: 70
Outbound busy rate: 60
Busy recovery rate: 60
Inbound busy recovery rate: 60
Outbound busy recovery rate: 60
Probe information:
Probe method State
t4 Inactive
Link: lk2
Description: link2
State: Inactive
VPN instance: --
IPv4 address state: Active
IPv6 address state: Inactive
Router interface:Dialer0
Link group: lg
Weight: 150
Priority: 3
Cost: 100
Slow shutdown: Enabled
Connection limit: 10000
Rate limit:
Connections: 10000
Bandwidth busy:
Busy rate: 80
Probe information:
Probe method State
t4 Inactive
表1-9 display loadbalance link命令显示信息描述表
Link |
链路的名称 |
链路的描述信息 |
State |
链路的状态,包括: · Active:可用 · Busy:繁忙 · Inactive:不可用(由于配置不完全、未被引用或虚服务器尚未开启) · Probe-failed:健康检测失败 · Ramp:温暖上线的爬升阶段 · Shutdown:关闭 · Standby:温暖上线的准备阶段 |
VPN instance |
(暂不支持)链路所属VPN实例的来源,包括 · Config:手动配置 · Inherit:继承 |
Inherit VPN |
(暂不支持)链路所属VPN实例继承功能的状态,包括: · Enabled:开启 · Disabled:关闭 |
IPv4 address state |
链路的IPv4地址状态,包括: · Active:可用,即链路对应的出接口已获取到可用的IPv4地址 · Inactive:不可用,即链路对应的出接口未获取到可用的IPv4地址 仅当配置了链路对应的出接口时,才会显示本字段 |
IPv6 address state |
链路的IPv6地址状态,包括: · Active:可用,即链路对应的出接口已获取到可用的IPv6地址 · Inactive:不可用,即链路对应的出接口未获取到可用的IPv6地址 仅当配置了链路对应的出接口时,才会显示本字段 |
Router IP |
链路的网关IPv4地址 |
Router IPv6 |
链路的网关IPv6地址 |
Router interface |
链路对应的出接口 |
Link group |
链路所属链路组的名称 |
Weight |
链路的权值 |
Priority |
链路在所属链路组内的优先级 |
Cost |
就近性计算的链路成本 |
Slow shutdown |
链路的慢宕的状态,包括: · Disabled:关闭 · Enabled:开启 |
Connection limit |
链路所允许的最大连接数 |
Rate limit |
链路的速率限制 |
Connections |
链路所允许的最大连接速率 |
Bandwidth |
链路所允许的最大总带宽,单位为千字节/秒 |
Inbound bandwidth |
链路所允许的最大入带宽,单位为千字节/秒 |
Outbound bandwidth |
链路所允许的最大出带宽,单位为千字节/秒 |
Bandwidth busy |
带宽繁忙比例 |
Max bandwidth |
带宽繁忙阈值所允许的最大总带宽,单位为千字节/秒 |
Max inbound bandwidth |
带宽繁忙阈值所允许的最大入带宽,单位为千字节/秒 |
Max outbound bandwidth |
带宽繁忙阈值所允许的最大出带宽,单位为千字节/秒 |
Busy rate |
链路的总带宽繁忙比例 |
Inbound busy rate |
链路的入带宽繁忙比例 |
Outbound busy rate |
链路的出带宽繁忙比例 |
Busy recovery rate |
链路的总带宽繁忙恢复比例 |
Inbound busy recovery rate |
入方向链路带宽繁忙恢复比例 |
Outbound busy recovery rate |
出方向链路带宽繁忙恢复比例 |
Probe information |
链路健康检测的详细信息 |
链路健康检测的成功条件: · All:只有全部方法都通过检测才认为健康检测成功 · At-least:健康检测成功所需通过检测的最少方法数 |
Probe method |
健康检测方法所使用的NQA模板名称 |
State |
健康检测方法的状态,包括: · Failed:健康检测失败 · In progress:正在进行健康检测 · Invalid:健康检测不可用(因其所使用的NQA模板配置不完全),或者链路不可用 · Succeeded:健康检测成功 |
display loadbalance link statistics显示链路的统计信息。
display loadbalance link statistics [ name link-name ]
name link-name:显示指定链路的统计信息。link-name为链路名称,长度为1~63个字符的字符串,不区分大小写。
# 显示链路lk1的统计信息
<Sysname> display loadbalance link statistics name lk1
Loadbalance link: lk1
Total connections: 1798
Active connections: 788
Max connections: 803
Connections per second: 157
Max connections per second: 163
Downstream traffic: 333332 bytes
Upstream traffic: 472054 bytes
Throughput: 4396 bytes/s
Inbound throughput: 1214 bytes/s
Outbound throughput: 3128 bytes/s
Max throughput: 4564 bytes/s
Max inbound throughput: 1214 bytes/s
Max outbound throughput: 3320 bytes/s
Received packets: 1798
Sent packets: 0
Dropped packets: 0
表1-10 display loadbalance link statistics命令显示信息描述表
Loadbalance link |
链路的名称 |
Total connections |
总连接数 |
Active connections |
当前活动的连接数 |
Max connections |
最大连接数 |
Connections per second |
每秒连接数 |
Max connections per second |
最大每秒连接数 |
Downstream traffic |
链路的下行流量,LB设备收到的流量,单位为字节 |
Upstream traffic |
链路的上行流量,LB设备发送的流量,单位为字节 |
Throughput |
报文的总吞吐量,单位为字节/秒 |
Inbound throughput |
报文的入吞吐量,单位为字节/秒 |
Outbound throughput |
报文的出吞吐量,单位为字节/秒 |
Max throughput |
报文的最大总吞吐量,单位为字节/秒 |
Max inbound throughput |
报文的最大入吞吐量,单位为字节/秒 |
Max outbound throughput |
报文的最大出吞吐量,单位为字节/秒 |
Received packets |
收到的报文数 |
Sent packets |
发出的报文数 |
Dropped packets |
丢弃的报文数 |
display loadbalance link-group命令用来显示链路组的信息。
display loadbalance link-group [ brief | name link-group-name ]
brief:显示所有链路组的简要信息。如果未指定本参数,将显示链路组的详细信息。
name link-group-name:显示指定链路组的信息。link-group-name为链路组的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有链路组的信息。
如果链路组配置不完整,链路组未被引用或虚服务未开启,则链路状态将显示为不可用,但并不代表该链路本身不可用。
# 显示所有链路组的简要信息。
<Sysname> display loadbalance link-group brief
Predictor: RR - Round robin, RD - Random, LC - Least connection,
BW – Bandwidth, MBW – Max bandwidth,
IBW – Inbound bandwidth, OBW – Outbound bandwidth,
MIBW – Max inbound bandwidth, MOBW – Max outbound bandwidth,
NAT/SNAT: Y - Enabled, N - Disabled
Link group Predictor NAT SNAT Total Active
lg RR Y N 3 3
# 显示所有链路组的详细信息。
Link group: lg1
Description:
Predictor: Hash address
Proximity: Disabled
NAT: Enabled
SNAT pool:
Failed action: Keep
Active threshold: Enabled
Lower: 80
Upper: 90
Slow-online: Enabled
Standby time: 5s
Ramp-up time: 10s
Selected link: Enabled
Min link: 100
Max link: 600
Probe information:
Probe method:
aaa
ddd
Total link: 1
Active link: 1
Link list:
Name State VPN instance Router IP Weight Priority
Link1 Inactive -- 1.2.3.4 4 100
表1-11 display loadbalance link-group命令显示信息描述表
Link group |
链路组的名称 |
链路组的描述信息 |
Predictor |
链路组的调度算法,包括: · Round robin:加权轮转算法 · Random:随机算法 · Least connection:加权最小连接算法 · Bandwidth:总带宽算法 · Inbound bandwidth:入方向带宽算法 · Outbound bandwidth:出方向带宽算法 · Max bandwidth:最大总带宽算法 · Max inbound bandwidth:最大入方向带宽算法 · Max outbound bandwidth:最大出方向带宽算法 · Hash address source IP:根据源IP地址进行的哈希算法 · Hash address source IP-port:根据源IP地址和端口号进行的哈希算法 · Hash address destination IP:根据目的IP地址进行的哈希算法 |
Proximity |
链路组中就近性功能的状态,包括: · Disabled:关闭 · Enabled:开启 |
NAT |
链路组中NAT功能的状态,包括: · Disabled:关闭 · Enabled:开启 |
SNAT pool |
链路组引用的SNAT地址池名称 |
Failed action |
链路组的故障处理方式,包括: · Keep:保持已有连接 · Reschedule:重定向连接 · Reset:断开已有连接 |
Active threshold |
链路组可用条件的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示: · Lower:最小可用百分比 · Upper:最大可用百分比 |
Slow-online |
链路组中链路温暖上线功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示: · Standby time:准备时间 · Ramp-up time:爬升时间 |
Selected link |
链路组中可被调度算法调用的链路数量限制功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示: · Min link:可被调度算法调用的链路最小数量 · Max link:可被调度算法调用的链路最大数量 |
链路组健康检测的成功条件: · All:只有全部方法都通过检测才认为健康检测成功 · At least X:健康检测成功所需通过检测的最少方法数为X |
Probe method |
链路组健康检测方法所使用的NQA模板名称 |
Total link |
包含的链路数量 |
Active link |
活跃的链路数量 |
Link list |
链路列表 |
Name |
链路的名称 |
State |
链路的状态,包括: · Active:可用 · Busy:繁忙(当链路处于Active或Ramp状态,且开启接口获取带宽功能和繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态) · Inactive:不可用(由于配置不完全、未被引用或虚服务器尚未开启) · Probe-failed:健康检测失败 · Ramp:温暖上线的爬升阶段 · Shutdown:关闭 · Standby:温暖上线的准备阶段 |
VPN instance |
(暂不支持)链路所属的VPN实例 |
Router IP |
链路的IPv4和IPv6地址 |
Weight |
链路的权值 |
Priority |
链路的调用优先级 |
display loadbalance policy命令用来显示负载均衡策略的信息。
display loadbalance policy [ name policy-name ]
name policy-name:显示指定负载均衡策略的信息。policy-name为负载均衡策略的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡策略的信息。
# 显示所有负载均衡策略的信息。
<Sysname> display loadbalance policy
LB policy: lbp3
Description:
Type: Link-generic
Class: lbc3
Action: lba3
Default class action: lba3
LB policy: lbp4
Description:
Type: DNS
Class: lbc4
Action: lba4
Default class action: lba4
表1-12 display loadbalance policy命令显示信息描述表
LB policy |
负载均衡策略的名称 |
负载均衡策略的描述信息 |
Type |
负载均衡策略的类型,包括: · DNS:表示DNS类型 · Link-generic:表示链路类型 |
Class |
负载均衡策略包含的负载均衡类 |
Action |
负载均衡类对应的负载均衡动作 |
Default class action |
缺省的负载均衡动作 |
display loadbalance proximity命令用来显示就近性表项的信息。
display loadbalance proximity [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ]
ip [ ipv4-address ]:显示IPv4就近性表项的信息。如果指定了ipv4-address参数,将显示指定IPv4地址所对应就近性表项的详细信息;如果未指定ipv4-address参数,将显示所有IPv4就近性表项的简要信息。
ipv6 [ ipv6-address ]:显示IPv6就近性表项的信息。如果指定了ipv6-address参数,将显示指定IPv6地址所对应就近性表项的详细信息;如果未指定ipv6-address参数,将显示所有IPv6就近性表项的简要信息。
如果未指定ip和ipv6关键字,将显示所有IPv4和IPv6就近性表项的简要信息。
# 显示公网实例中所有IPv4和IPv6就近性表项的简要信息。
<Sysname> display loadbalance proximity
(*) – Real server object
Slot :1
IPv4 address/Mask length Timeout Best link
1.2.3.0/24 59 lk1
1.2.15.0/24 58 lk2
IPv6 address/Prefix length Timeout Best link
11:22::/96 40 lk1
# 显示公网实例中,IP地址为1.2.3.1的IPv4就近性表项的详细信息。
<Sysname> display loadbalance proximity ip 1.2.3.1
IPv4 address/Mask length: 1.2.3.0/24
Timeout: 40
Link list:
lk1
lk2
表1-13 display loadbalance proximity命令显示信息描述表
(*) – Real server object |
(暂不支持)(*)表示该链路对应对象是实服务器而非链路 |
就近性表项的IPv4地址和掩码长度 |
就近性表项的IPv6地址和前缀长度 |
Timeout |
就近性表项的剩余老化时间,单位为秒 |
Best /link |
就近性表项的最优链路 |
Link list |
就近性表项的所有链路列表,优先级依次降低 |
display loadbalance snat-pool命令用来显示SNAT地址池的信息。
display loadbalance snat-pool [ name pool-name ]
name pool-name:显示指定SNAT地址池的信息。pool-name为SNAT地址池的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有SNAT地址池的信息。
# 显示所有SNAT地址池的信息。
<Sysname> display loadbalance snat-pool
SNAT pool: lbsp1
Description:
IPv4 range:
Start address End address
202.110.10.10 202.110.10.15
IPv6 range:
2002::2 2002::100
ARP/ND interfaces:
GigabitEthernet1/0/1
GigabitEthernet1/0/3
SNAT pool: lbsp2
Description:
IPv4 range:
203.110.10.10 203.110.10.15
IPv6 range:
2003::2 2003::100
表1-14 display loadbalancesnat-pool命令显示信息描述表
SNAT pool |
SNAT地址池的名称 |
SNAT地址池的描述信息 |
IPv4 range |
IPv4地址段 |
IPv6 range |
IPv6地址段 |
Start address |
起始地址 |
End address |
结束地址 |
display parameter-profile命令用来显示参数模板的信息。
display parameter-profile [ name parameter-name ]
name parameter-name:显示指定参数模板的信息。parameter-name为参数模板的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有参数模板的信息。
# 显示所有参数模板的信息。
<Sysname> display parameter-profile
Parameter profile: pp1
Description:
Type: IP
IP ToS: 20
表1-15 display parameter-profile命令显示信息描述表
Parameter profile |
参数模板的名称 |
参数模板的描述信息 |
Type |
参数模板的类型,IP:表示IP类型 |
IP ToS |
发往服务器的IP报文中的ToS字段 |
display sticky命令用来显示持续性表项的信息。
display sticky { dns-proxy [ dns-proxy-name ] | virtual-server [ virtual-server-name ] } [ class class-name | default-class | default-dns-server-pool | default-link-group ]
dns-proxy dns-proxy-name:显示指定DNS透明代理的持续性表项信息。dns-proxy-name为DNS透明代理的名称,为1~63个字符的字符串,不区分大小写。如果未指定dns-proxy-name,将显示所有DNS透明代理的持续性表项信息。
virtual-server virtual-server-name:显示指定虚服务器的持续性表项信息。virtual-server-name为虚服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定virtual-server-name,将显示所有虚服务器的持续性表项信息。
class class-name:显示指定负载均衡类的持续性表项信息。class-name为负载均衡类的名称,为1~63个字符的字符串,不区分大小写。
default-class:显示缺省负载均衡动作的持续性表项信息。
default-dns-server-pool:显示缺省DNS服务器池的持续性表项信息。
default-link-group:显示缺省链路组的持续性表项信息。
# 显示所有虚服务的持续性表项信息。
<Sysname> display sticky virtual-server
Virtual server name: vs4
Sticky zone type: Default link group
Class name:
Sticky group name: sg3
Sticky method: Both IP and port
Timeout: 60
Sticky entry Link Expired time Count
192.168.6.206/2606 Dialer0 57 0
192.168.6.40/80
192.168.6.206/2605 192.168.6.206/0 55 0
192.168.6.40/80
# 显示所有DNS透明代理的持续性表项信息。
<Sysname> display sticky dns-proxy
DNS proxy name: dns-proxy1
Sticky zone type: Default DNS server pool
Sticky group name: st
Sticky method: Source IP
Timeout: 60
Sticky entry DNS server Expired time Count
192.168.6.206/2606 192.168.6.206/0 57 0
DNS proxy name: dns-proxy2
Sticky zone type: Class
Class name: class
Sticky group name: sg2
Sticky method: Destination IP and port
Timeout: 60
DNS proxy name: dns-proxy3
Sticky zone type: Default class
Timeout: 60
表1-16 display sticky命令显示信息描述表
Virtual server name |
虚服务器的名称 |
DNS proxy name |
DNS透明代理的名称 |
Sticky zone type |
持续性表项的来源,包括: · Class:由虚服务所引用策略中的类和动作生成 · Default class:由虚服务所引用策略中的缺省动作生成 · Default DNS server pool:由DNS透明代理缺省的DNS服务器池生成 · Default link group:由虚服务下缺省的主用或备用链路组生成 |
Class name |
如果该持续性由类和动作生成,显示对应负载均衡类的名称;否则显示为空 |
Sticky group name |
生成该持续性表项的持续性组名称 |
Sticky method |
该持续性表项对应的持续性方法,包括: · Source IP:源IPv4地址持续性方法 · Source IPv6:源IPv6地址持续性方法 · Source IP and port:源IPv4地址+源端口持续性方法 · Source IPv6 and port:源IPv6地址+源端口持续性方法 · Destination IP:目的IPv4地址持续性方法 · Destination IPv6:目的IPv6地址持续性方法 · Destination IP and port:目的IPv4地址+目的端口持续性方法 · Destination IPv6 and port:目的IPv6地址+目的端口持续性方法 · Both IP:源IPv4地址+目的IPv4地址持续性方法 · Both IPv6:源IPv6地址+目的IPv6地址持续性方法 · Both IP and port:源IPv4地址+源端口+目的IPv4地址+目的端口持续性方法 · Both IPv6 and port:源IPv6地址+源端口+目的IPv6地址+目的端口持续性方法 |
Timeout |
持续性表项的超时时间,单位为秒 |
Sticky entry |
持续性表项对应的Key值 |
DNS server |
DNS服务器的IP地址和端口号 |
Link |
链路通往外网方向的下一跳IP地址/端口号 |
Expired time |
持续性表项的老化剩余时间,如果引用计数不为0,则显示为配置值 |
Count |
持续性表项的引用计数 |
display sticky-group命令用来显示持续性组的信息。
display sticky-group [ name group-name ]
name group-name:显示指定持续性组的信息。group-name为持续性组的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有持续性组的信息。
# 显示所有持续性组的信息。
<Sysname> display sticky-group
Sticky group: sg1
Description:
Timeout: 60
Override limit: Disabled
Stickiness-over-busyness: Enabled
Sticky group type: Address-port
Method: Both IP and port
Mask: 32
表1-17 display sticky-group命令显示信息描述表
Sticky group |
持续性组的名称 |
持续性组的描述信息 |
Timeout |
持续性表项的超时时间,单位为秒 |
Override limit |
匹配持续性表项的会话不受连接数限制功能的状态,包括: · Disabled:关闭,即匹配持续性表项的会话受连接数限制 · Enabled:开启,即匹配持续性表项的会话不受连接数限制 |
Stickiness-over-busyness |
持续性处理优先于繁忙功能的状态,包括: · Disabled:关闭 · Enabled:开启 |
Sticky group type |
持续性组的类型,Address-port:表示地址端口类型 各类型持续性组的具体内容,请参见表1-18 |
持续性组类型 |
Address-port |
· Method:持续性方法,包括: ¡ Source IP:源IPv4地址持续性方法 ¡ Source IPv6:源IPv6地址持续性方法 ¡ Source IP and port:源IPv4地址+源端口持续性方法 ¡ Source IPv6 and port:源IPv6地址+源端口持续性方法 ¡ Destination IP:目的IPv4地址持续性方法 ¡ Destination IPv6:目的IPv6地址持续性方法 ¡ Destination IP and port:目的IPv4地址+目的端口持续性方法 ¡ Destination IPv6 and port:目的IPv6地址+目的端口持续性方法 ¡ Both IP:源IPv4地址+目的IPv4地址持续性方法 ¡ Both IPv6:源IPv6地址+目的IPv6地址持续性方法 ¡ Both IP and port:源IPv4地址+源端口+目的IPv4地址+目的端口持续性方法 ¡ Both IPv6 and port:源IPv6地址+源端口+目的IPv6地址+目的端口持续性方法 · Mask:持续性方法的掩码长度,只有IPv4持续性方法才会显示本字段 · Prefix:持续性方法的前缀长度,只有IPv6持续性方法才会显示本字段 |
display virtual-server命令用来显示虚服务器的信息。
display virtual-server [ brief | name virtual-server-name ]
brief:显示虚服务器的简要信息。如果未指定本参数,将显示虚服务器的详细信息。
name virtual-server-name:显示指定虚服务器的信息。virtual-server-name为虚服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有虚服务器的信息。
# 显示所有虚服务器的简要信息。
<Sysname> display virtual-server brief
Virtual server State Type VPN instance Virtual address Port
vs3 Active LINK-IP 51.139.4.100/32 0
# 显示虚服务器lk的详细信息。
<Sysname> display virtual-server name lk
Virtual server: lk
Description:
Type: Link-IP
State: Active
VPN instance: --
Virtual IPv4 address: 1.1.1.1/32
Virtual IPv6 address: 1001::1/128
Port: 0
Primary link group: lg1 (in use)
Sticky: sg3
LB policy: lbp2
LB limit-policy:
Rate limit:
Connections: 10000
Connection synchronization: Disabled
Sticky synchronization: Disabled
Interface bandwidth statistics: Disabled
Route advertisement: Disabled
ARP/ND interfaces:
表1-19 display virtual-server命令显示信息描述表
Virtual server |
虚服务器的名称 |
State |
虚服务器的状态,包括: · Active:可用 · Inactive:不可用(已安装License并开启了虚服务器功能,仍不可用) · Inactive (no license):不可用(由于缺少License) · Inactive (disabled):不可用(由于未开启虚服务器功能) |
Type |
虚服务器的类型为Link-IP |
VPN instance |
(暂不支持)虚服务器所属的VPN实例名称 |
Port |
虚服务器的端口号 |
虚服务器的描述信息 |
Virtual IPv4 address |
虚服务器的IPv4地址和掩码 |
Virtual IPv6 address |
虚服务器的IPv6地址和前缀 |
Primary link group |
缺省的主用链路组名称,(in use)表示该链路组正被使用 |
Backup link group |
缺省的备用链路组名称,(in use)表示该链路组正被使用 |
Sticky |
缺省的持续性组名称 |
LB policy |
虚服务器引用的负载均衡策略 |
IP parameter profile |
虚服务器引用的IP类型参数模板,只有配置了IP类型的参数模板才会显示本字段 |
Connection limit |
虚服务器所允许的最大连接数 |
Rate limit |
虚服务器的速率限制 |
Connections |
虚服务器所允许的最大连接速率 |
Bandwidth |
虚服务器所允许的最大总带宽,单位为千字节/秒 |
Inbound bandwidth |
虚服务器所允许的最大入带宽,单位为千字节/秒 |
虚服务器所允许的最大出带宽,单位为千字节/秒 |
链路的带宽繁忙保护功能的状态,包括: · Disabled:关闭 · Enabled:开启 |
虚服务器IP地址下发功能的状态,包括: · Disabled:关闭 · Enabled:开启 |
display virtual-server statistics命令用来显示虚服务器的统计信息。
display virtual-server statistics [ name virtual-server-name ]
name virtual-server-name:显示指定虚服务器的统计信息。virtual-server-name为虚服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有虚服务器的统计信息。
# 显示虚服务器vs的统计信息。
<Sysname> display virtual-server statistics name vs
Virtual server: vs
Total connections: 979
Active connections: 618
Max connections: 661
Connections per second: 146
Max connections per second: 156
Client input: 333332 bytes
Client output: 472054 bytes
Throughput: 4088 bytes/s
Outbound throughput: 2874 bytes/s
Max throughput: 4368 bytes/s
Max outbound throughput: 3154 bytes/s
Received packets: 979
Sent packets: 0
Dropped packets: 0
表1-20 display virtual-server staistics命令显示信息描述表
Virtual server |
虚服务器的名称 |
Total connections |
总连接数 |
当前活动的连接数 |
Max connections |
最大连接数 |
每秒连接数 |
最大每秒连接数 |
Client input |
从客户端收到的流量,单位为字节 |
Client output |
向客户端发出的流量,单位为字节 |
Throughput |
报文的总吞吐量,单位为字节/秒 |
报文的入吞吐量,单位为字节/秒 |
报文的出吞吐量,单位为字节/秒 |
Max throughput |
报文的最大总吞吐量,单位为字节/秒 |
报文的最大入吞吐量,单位为字节/秒 |
Max oubound throughput |
报文的最大出吞吐量,单位为字节/秒 |
Received packets |
收到的报文数 |
Sent packets |
发出的报文数(虚服务器发给客户端的) |
Dropped packets |
丢弃的报文数 |
· reset virtual-server statistics
dns-server-pool命令用来指定指导转发的DNS服务器池。
undo dns-server-pool命令用来恢复缺省情况。
未指定指导转发的DNS服务器池。
DNS类型的负载均衡动作视图
sticky sticky-name:DNS服务器池所对应持续性组的名称,为1~63个字符的字符串,不区分大小写,若未指定该参数,则DNS服务器池不对应持续性组。
本命令与forward all和skip current-dns-proxy命令互斥,当配置了其中一条后,另一条的配置将被自动取消。
# 在DNS类型的负载均衡动作lba1中,指定指导转发的DNS服务器池为dsp,持续性组为st1。
[Sysname] loadbalance action lba1 type dns
[Sysname-lba-dns-lba1] dns-server-pool dsp sticky st1
· forward all
dns-server-pool命令用来指定DNS服务器所属的DNS服务器池。
未指定DNS服务器所属的DNS服务器池。
DNS服务器视图
pool-name:DNS服务器池的名称,为1~63个字符的字符串,不区分大小写。
指定DNS服务器池的名称时,可以是尚未创建的DNS服务器池。
# 指定DNS服务器ds1属DNS服务器池为dns-pool1。
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] dns-server-pool dns-pool1
· display loadbalance dns-server
fail-action命令用来配置链路组的故障处理方式。
undo fail-action命令用来恢复缺省情况。
fail-action { keep | reschedule | reset }
undo fail-action
链路组的故障处理方式为保持已有连接。
链路组视图
keep:保持已有连接,即不主动断开与故障链路的连接,连接继续保持还是断开将由协议自身的超时机制决定。
reschedule:重定向连接,即把连接重定向到链路组中其它可用的链路上。
reset:断开已有连接,即主动断开与故障链路的连接。对于TCP报文,将发送RST报文;对于其它类型的报文,将发送ICMP不可达报文。
当处理报文的链路发生故障的时,负载均衡设备根据配置的故障处理方式来决定报文的处理方式。
# 配置链路组lg的故障处理方式为重定向连接。
[Sysname-lb-lgroup-lg] fail-action reschedule
fallback-action continue命令用来配置查找可用服务器失败时继续匹配下一条引用规则。
undo fallback-action continue命令用来恢复缺省情况。
根据当前动作查找可用服务器失败时,不再继续匹配下一条引用规则,直接丢弃报文。
负载均衡动作视图
当配置该命令的动作在负载均衡策略中被引用时,在转发中根据该配置判断当前动作查找可用服务器失败时,可继续顺序匹配策略中的下一条引用规则。
# 在DNS类型的负载均衡动作a2中,开启根据当前动作查找可用DNS服务器失败时继续匹配策略中的下一条规则功能。
[Sysname] loadbalance action a2 type dns
[Sysname-lba-dns-a2] fallback-action continue
forward all命令用来配置报文的转发模式为转发。
undo forward命令用来恢复缺省情况。
forward all
undo forward
报文的转发模式为丢弃。
DNS/Link-generic类型的负载均衡动作视图
在DNS类型的负载均衡动作视图下,本命令与dns-server-pool和skip current-dns-proxy命令互斥;在Link-generic类型的负载均衡动作视图下,本命令与link-group命令互斥。当配置了其中一条后,另一条的配置将被自动取消。
# 在Link-generic类型的负载均衡动作lba1中,配置报文的转发模式为转发。
[Sysname-lba-link-generic-lba1] forward all
· link-group (action view)
· dns-server-pool
ip命令用来配置IPv4持续性方法。
undo ip命令用来恢复缺省情况。
ip [ port ] { both | destination | source } [ mask mask-length ]
undo ip
未配置IPv4持续性方法。
持续性组视图
port:表示持续性方法为IPv4地址+端口。如果未指定本参数,表示持续性方法为IPv4地址。
both:当未指定port参数时,表示持续性方法为源IPv4地址+目的IPv4地址;当指定了port参数时,表示持续性方法为源IPv4地址+源端口+目的IPv4地址+目的端口。
destination:当未指定port参数时,表示持续性方法为目的IPv4地址;当指定了port参数时,表示持续性方法为目的IPv4地址+目的端口。
source:当未指定port参数时,表示持续性方法为源IPv4地址;当指定了port参数时,表示持续性方法为源IPv4地址+源端口。
mask mask-length:持续性方法的掩码长度。
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv4地址。
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] ip source
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv4地址+源端口。
[Sysname-sticky-address-port-sg1] ip port source
· sticky-group
ip address命令用来配置DNS透明代理的IPv4地址。
undo ip address命令用来恢复缺省情况。
ip address ipv4-address [ mask-length | mask ]
undo ip address
未配置DNS透明代理的IPv4地址。
DNS透明代理视图
ipv4-address:DNS透明代理的IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X(如果掩码长度不是32,则可以配置0.X.X.X)。
mask-length:IPv4地址的掩码长度,取值范围为0~32。
mask:IPv4地址的掩码。
只有当DNS请求的目的地址和端口号匹配DNS透明代理的IP地址和端口号时,才会进行DNS透明代理。
在同时配置DNS透明代理功能和服务器负载均衡功能的情况下,为避免影响DNS透明代理功能的正常使用,请避免将DNS透明代理的IP地址和端口号与UDP类型的虚服务器配置为同一地址和端口号。
在同一DNS透明代理视图下,多次执行本命令,最后一次执行的命令生效。
# 配置DNS透明代理dns-proxy1的IPv4地址为1.2.3.4/24。
[Sysname] loadbalance dns-proxy dns_proxy1
[Sysname-lb-dp-udp-dns-proxy1] ip address 1.2.3.4 24
ip address命令用来配置DNS服务器的IPv4地址。
undo ip address
未配置DNS服务器的IPv4地址。
DNS服务器视图
ipv4-address:DNS服务器的IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
在同一DNS服务器视图下,多次执行本命令,最后一次执行的命令生效。
# 配置DNS服务器ds1的IPv4地址为1.2.3.4。
[Sysname-lb-ds-ds1] ip address 1.2.3.4
ip address命令用来为ISP配置IPv4地址信息。
ip address ipv4-address { mask-length | mask }
undo ip address ipv4-address { mask-length | mask }
ISP未配置IPv4地址信息。
ISP视图
ipv4-address:ISP的IPv4地址。
mask:IPv4地址的掩码。
# 为名为isp1的ISP配置IPv4地址信息。
[Sysname] loadbalance isp name isp1
[Sysname-lbisp-isp1] ip address 1.1.1.1 24
ip mask命令用来配置IPv4就近性表项的掩码长度。
undo ip mask命令用来恢复缺省情况。
ip mask { mask-length | mask }
undo ip mask
IPv4就近性表项的掩码长度为24。
就近性视图
mask-length:IPv4就近性表项的掩码长度,取值范围为0~32,其中0表示自然掩码。
mask:IPv4就近性表项的掩码。
# 配置IPv4就近性表项的掩码长度为30。
[Sysname-lb-proximity] ip mask 30
ip range命令用来配置SNAT地址池的IPv4地址范围。
undo ip range命令用来恢复缺省情况。
ip range start start-ipv4-address end end-ipv4-address
undo ip range
未配置SNAT地址池的IPv4地址范围。
SNAT地址池视图
start start-ipv4-address:起始IPv4地址。
end end-ipv4-address:结束IPv4地址,必须大于等于起始IPv4地址。
一个SNAT地址池中最多允许有256个IPv4地址,且不同SNAT地址池中的IPv4地址不允许重叠。
# 配置SNAT地址池lbsp的IPv4地址范围为1.1.1.1~1.1.1.100。
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] ip range start 1.1.1.1 end 1.1.1.100
ipv6命令用来配置IPv6持续性方法。
undo ipv6命令用来恢复缺省情况。
ipv6 [ port ] { both | destination | source } [ prefix prefix-length ]
undo ipv6
未配置IPv6持续性方法。
持续性组视图
port:表示持续性方法为IPv6地址+端口。如果未指定本参数,表示持续性方法为IPv6地址。
both:表示持续性方法为源IPv6地址+目的IPv6地址(未指定port参数时),或源IPv6地址+源端口+目的IPv6地址+目的端口(指定port参数时)。
destination:表示持续性方法为目的IPv6地址(未指定port参数时),或目的IPv6地址+目的端口(指定port参数时)。
source:表示持续性方法为源IPv6地址(未指定port参数时),或源IPv6地址+源端口(指定port参数时)。
prefix prefix-length:持续性方法的前缀长度。
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv6地址。
[Sysname-sticky-address-port-sg1] ipv6 source
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv6地址+源端口。
[Sysname-sticky-address-port-sg1] ipv6 port source
· sticky-group
ipv6 address命令用来配置DNS透明代理的IPv6地址。
undo ipv6 address命令用来恢复缺省情况。
ipv6 address ipv6-address [ prefix-length ]
undo ipv6 address
未配置DNS透明代理的IPv6地址。
DNS透明代理视图
ipv6-address:DNS透明代理的IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址(如果前缀长度为0,则可以配置全0地址)。
prefix-length:IPv6地址的前缀长度,取值范围为0~128。
# 配置DNS透明代理dns-proxy1的IPv6地址为1::2:3/112。
[Sysname-lb-dp-udp-dns-proxy1] ipv6 address 1::2:3 112
ipv6 address命令用来配置DNS服务器的IPv6地址。
undo ipv6 address
未指定DNS服务器的IPv6地址。
DNS服务器视图
ipv6-address:DNS服务器的IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址。
# 配置DNS服务器ds1的IPv6地址为1001::1。
[Sysname-lb-ds-ds1] ipv6 address 1001::1
ipv6 address命令用来为ISP配置IPv6地址信息。
ipv6 address ipv6-address prefix-length
undo ipv6 address ipv6-address prefix-length
ISP未配置IPv6地址信息。
ISP视图
ipv6-address:ISP的IPv6地址。
# 为名为isp1的ISP配置IPv6地址信息。
[Sysname-lbisp-isp1] ipv6 address 200::1 100
ipv6 prefix命令用来配置IPv6就近性表项的前缀长度。
undo ipv6 prefix命令用来恢复缺省情况。
ipv6 prefix prefix-length
undo ipv6 prefix
IPv6就近性表项的前缀长度为96。
就近性视图
prefix-length:IPv6就近性表项的前缀长度,取值范围为0~128。
# 配置IPv6就近性表项的前缀长度为64。
[Sysname-lb-proximity] ipv6 prefix 64
ip range命令用来配置SNAT地址池的IPv6地址范围。
ipv6 range start start-ipv6-address end end-ipv6-address
undo ipv6 range
未配置SNAT地址池的IPv6地址范围。
SNAT地址池视图
start start-ipv6-address:起始IPv6地址。
end end-ipv6-address:结束IPv6地址,必须大于等于起始IPv6地址。
一个SNAT地址池中最多允许有65536个IPv6地址,且不同SNAT地址池中的IPv6地址不允许重叠。
# 配置SNAT地址池lbsp的IPv6地址范围为1001::1~1001::100。
[Sysname-lbsnat-pool-lbsp] ipv6 range start 1001::1 end 1001::100
lb-policy命令用来配置DNS透明代理引用的负载均衡策略。
undo lb-poilcy命令用来恢复缺省情况。
DNS透明代理未引用负载均衡策略。
DNS透明代理视图
policy-name:负载均衡策略的名称,为1~63个字符的字符串,不区分大小写。
通过在DNS透明代理视图下引用负载均衡策略,能够细化DNS请求的粒度。根据策略中的匹配规则,使命中DNS透明代理的报文根据不同的报文内容进行不同的负载均衡处理,从而有效地丰富了负载均衡的负载功能。
DNS透明代理只能引用DNS类型的策略模板。
# 在名称为dns-proxy1的DNS透明代理视图下,配置其引用的负载均衡策略为dns-policy1。
[Sysname-lb-dp-udp-dns-proxy1] lb-policy dns-policy1
lb-policy命令用来指定虚服务器引用的负载均衡策略。
lb-policy policy-name
undo lb-poilcy
虚服务器未引用任何负载均衡策略。
虚服务器视图
虚服务器引用负载均衡策略,能够细化虚服务器负载均衡的粒度。根据策略中的匹配规则,使命中虚服务器的报文根据不同的报文内容进行不同的负载均衡处理,从而有效地丰富了负载均衡的负载功能。
虚服务器只能引用与自身类型相关的策略模板,如:Link-IP类型的虚服务器,只能引用Link-generic类型的策略模板。
# 指定Link-IP类型的虚服务器vs3引用的负载均衡策略为lbp1。
[Sysname-vs-link-ip-vs3] lb-policy lbp1
link命令用来指定与DNS服务器关联的链路。
undo link命令用来恢复缺省情况。
link link-name
undo link
未指定与DNS服务器关联的链路。
DNS服务器视图
link-name:链路名称,为1~63个字符的字符串,不区分大小写。
每台DNS服务器仅支持与一条链路相关联,同一条链路可以关联多台DNS服务器。
# 指定与DNS服务器ds1关联的链路为link1。
[Sysname-lb-ds-ds1] link link1
link-group命令用来指定指导转发的链路组。
undo link-group命令用来恢复缺省情况。
undo link-group
未指定指导转发的链路组。
负载均衡动作视图
sticky sticky-name:链路组所对应持续性组的名称,为1~63个字符的字符串,不区分大小写。
本命令与forward all命令互斥,后配置的生效。
当主用链路组可用(该链路组存在且有可用的链路)时,使用主链路组指导转发;当主用链路组不可用而备用链路组可用时,使用备用链路组指导转发;而当主、备用链路组都不可用时,则丢弃报文。
# 在link-geneirc类型的负载均衡动作lba1中,指定指导转发的主用链路组为lg,备用链路组为lgb,持续性组为sg1。
[Sysname-lba1- link-generic-lba1] link-group lg backup lgb sticky sg1
· forward all
link-group命令用来指定链路所属的链路组。
undo link-group
链路不属于任务链路组。
链路视图
link-group-name:链路组的名称,为1~63个字符的字符串,不区分大小写。
设备对数据流量进行链路负载分担时,会在该流量所匹配的链路组中选定一条最佳链路进行转发。
# 配置链路lk1所属的链路组为lkg1。
[Sysname-lb-link-lk1] link-group lkg1
loadbalance action命令用来创建负载均衡动作,并进入负载均衡动作视图。如果指定的负载均衡动作已经存在,则直接进入负载均衡动作视图。
undo loadbalance action命令用来删除指定的负载均衡动作。
loadbalance action action-name [ type { dns | link-generic } ]
undo loadbalance action action-name
不存在任何负载均衡动作。
type { dns | link-generic }:负载均衡动作的类型,dns表示DNS负载均衡动作类型,link-generic表示链路负载均衡动作类型。
创建负载均衡动作时必须指定类型参数;而在进入已创建的负载均衡动作视图时可以不指定,但若要指定,则必须与创建时的类型一致。
# 创建Link-generic类型的负载均衡动作lba1,并进入负载均衡动作视图。
loadbalance alg命令用来开启指定协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
undo loadbalance alg命令用来关闭指定协议的负载均衡ALG功能。
loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
dns、ftp、pptp、icmp-error和rtsp协议的负载均衡ALG功能均处于开启状态。
dns:DNS协议。
ftp:FTP协议。
h323:H323协议。
icmp-error:ICMP-ERROR协议。
ils:ILS(Internet Locator Service,互联网定位服务)协议。
mgcp:MGCP(Media Gateway Control Protocol,媒体网关控制协议)协议。
nbt:NBT(NetBIOS over TCP/IP,基于TCP/IP的网络基本输入输出系统)协议。
pptp:PPTP(Point-to-Point Tunneling Protocol,点到点隧道协议)协议。
rsh:RSH(Remote Shell,远程外壳)协议。
rtsp:RTSP(Real Time Streaming Protocol,实时流协议)协议。
sccp:SCCP(Skinny Client Control Protocol,瘦小客户端控制协议)协议。
sip:SIP(Session Iniation Protocol,会话初始协议)协议。
sqlnet:SQLNET协议。
tftp:TFTP协议。
xdmcp:XDMCP(X Display Manager Control Protocol,X显示监控)协议。
负载均衡ALG功能用于将父、子会话分发到同一条链路上。
# 开启TFTP协议的负载均衡ALG功能。
[Sysname] loadbalance alg tftp
loadbalance alg all-enable命令用来开启支持的所有协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
loadbalance alg all-disable命令用来关闭支持的所有协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
ftp、dns、pptp、rtsp和icmp-error协议的负载均衡ALG功能均处于开启状态。
# 开启所有协议的负载均衡ALG功能。
[Sysname] loadbalance alg all-enable
loadbalance class命令用来创建负载均衡类,并进入负载均衡类视图。如果指定的负载均衡类已经存在,则直接进入负载均衡类视图。
undo loadbalance class命令用来删除指定的负载均衡类。
loadbalance class class-name [ type { dns | link-generic } [ match-all | match-any ] ]
undo loadbalance class class-name
不存在任何负载均衡类。
type { dns | link-generic }:负载均衡类的类型,dns表示DNS负载均衡类型,link-generic表示链路负载均衡类型。
[ match-all | match-any ]:match-all表示需要匹配所有规则才算匹配该类,match-any表示只需匹配任一规则就算匹配该类。缺省值为match-all。
创建负载均衡类时必须指定类型参数;而在进入已创建的负载均衡类视图时可以不指定,但若要指定,则必须与创建时的类型一致。
# 创建Link-generic类型的负载均衡类lbc1,并进入负载均衡类视图。
[Sysname] loadbalance class lbc1 type link-generic
[Sysname-lbc-link-generic-lbc1]
loadbalance dns-proxy命令用来创建DNS透明代理,并进入DNS透明代理视图。如果指定的DNS透明代理已经存在,则直接进入DNS透明代理视图。
undo loadbalance dns-proxy命令用来删除指定的DNS透明代理。
loadbalance dns-proxy dns-proxy-name type udp
undo loadbalance dns-proxy dns-proxy-name
不存在DNS透明代理。
type udp:DNS透明代理的类型为UDP类型。
# 创建名称为dns-proxy1的DNS透明代理,并进入该DNS透明代理视图。
[Sysname] loadbalance dns-proxy dns-proxy1 type udp
· display loadbalance dns-proxy
loadbalance dns-server命令用来创建DNS服务器,并进入DNS服务器视图。如果指定的DNS服务器已经存在,则直接进入DNS服务器视图。
undo loadbalance dns-server命令用来删除指定的DNS服务器。
loadbalance dns-server dns-server-name
undo loadbalance dns-server dns-server-name
不存在DNS服务器。
dns-server-name:DNS服务器名,为1~63个字符的字符串,不区分大小写。
# 创建名为ds1的DNS服务器,并进入DNS服务器视图。
[Sysname-lb-ds-ds1]
loadbalance dns-server-pool命令用来创建DNS服务器池,并进入DNS服务器池视图。如果指定的DNS服务器池已经存在,则直接进入DNS服务器池视图。
undo loadbalance dns-server-pool命令用来删除指定的DNS服务器池。
loadbalance dns-server-pool pool-name
undo loadbalance dns-server-pool pool-name
不存在DNS服务器池。
# 创建名为dns-pool1的DNS服务器池,并进入DNS服务器池视图。
[Sysname] loadbalance dns-server-pool dns-pool1
[Sysname-lb-dspool-dns-pool1]
loadbalance isp file命令用来导入ISP文件。
undo loadbalance isp file命令用来删除已经导入的ISP文件。
loadbalance isp file isp-file-name
isp-file-name:ISP文件的名称,为1~255个字符的字符串,不区分大小写。
当导入的文件不存在、文件名不合法或文件解密失败时,系统将维持已有的导入内容不变。
当导入文件解析IP地址失败而退出导入操作时,系统将清空上次导入的内容,只保存本次已导入成功的内容。
不允许删除导入的ISP及其IPv4和IPv6地址,但如果手工配置的ISP与导入的ISP重合,则允许删除手工配置的ISP及其IPv4和IPv6地址。
# 导入ISP文件isp2。
[Sysname] loadbalance isp file isp2
loadbalance isp name命令用来创建ISP,并进入ISP视图。如果指定的ISP已经存在,则直接进入ISP视图。
undo loadbalance isp name命令用来删除指定的ISP。
loadbalance isp name isp-name
undo loadbalance isp name isp-name
不存在任何ISP。
isp-name:ISP的名称,为1~63个字符的字符串,不区分大小写。
# 创建名为isp1的ISP,并进入ISP视图。
loadbalance link命令用来创建链路,并进入链路视图。如果指定的链路已经存在,则直接进入链路视图。
undo loadbalance link命令用来删除链路。
loadbalance link link-name
undo loadbalance link link-name
不存在链路。
link-name:链路的名称,为1~63个字符的字符串,不区分大小写。
连接外部网络的每条物理链路对应一个链路。
# 创建链路lk1,并进入该链路视图。
loadbalance link-group命令用来创建链路组,并进入链路组视图。如果指定的链路组已经存在,则直接进入链路组视图。
undo loadbalance link-group命令用来删除指定的链路组。
loadbalance link-group link-group-name
undo loadbalance link-group link-group-name
缺省情况不存在任何链路组。
link-group-name:链路组的名乐,为1~63个字符的字符串,不区分大小写。
为了便于对多条链路进行管理,可以依据这些链路的共有属性划分成不同的组,称为链路组。
# 创建链路组lg,并进入链路组视图。
loadbalance policy命令用来创建负载均衡策略,并进入负载均衡策略视图。如果指定的负载均衡策略已经存在,则直接进入负载均衡策略视图。
undo loadbalance policy命令用来删除指定的负载均衡策略。
loadbalance policy policy-name [ type { dns | link-generic } ]
undo loadbalance policy policy-name
不存在任何负载均衡策略。
type { dns | link-generic }:负载均衡策略的类型,dns表示DNS负载均衡策略类型,link-generic表示链路负载均衡策略类型。
创建负载均衡策略时必须指定类型参数;而在进入已创建的负载均衡策略视图时可以不指定,但若要指定,则必须与创建时的类型一致。
# 创建Link-generic类型的负载均衡策略lbp1,并进入负载均衡策略视图。
loadbalance proximity命令用来创建就近性,并进入就近性视图。如果指定的就近性已经存在,则直接进入就近性视图。
undo loadbalance proximity命令用来删除就近性视图及该视图下的所有配置。
# 创建并进入就近性视图。
loadbalance schedule-test ip命令用来测试IPv4负载均衡的效果。
loadbalance schedule-test ip { protocol { protocol-number | icmp | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port
protocol { protocol-number | icmp | tcp | udp }:测试的协议。protocol-number为协议编号,取值范围为0~255。其中,ICMP(1)、TCP(6)和UDP(17)这三种协议既可输入协议编号,也可输入协议名称。
destination destination-address:目的IPv4地址。
destination-port destination-port:目的端口号,取值范围为0~65535。并非所有协议都支持本参数。
source source-address:源IPv4地址。
source-port source-port:源端口号,取值范围为0~65535。并非所有协议都支持本参数。
# 测试TCP协议IPv4负载均衡的效果。
<Sysname> loadbalance schedule-test ip protocol tcp destination 7.7.7.7 destination-port 4 source 2.2.2.2 source-port 5
Matched virtual server: vs2
Matched default link group: lg
Forward type: Forwarding to link
Selected link: link2
Scheduling algorithm: Predictor
表1-21 loadbalance schedule-test ip命令显示信息描述表
Matched virtual server |
匹配的虚服务器名称 |
No matched virtual servers. |
未匹配任何虚服务器 |
Matched class |
匹配的负载均衡类名称 |
Matched the default class. |
匹配了缺省负载均衡动作 |
Matched default link group |
匹配的缺省链路组名称 |
Forward type |
转发类型,包括: · The destination address is not supported. Load balancing is not performed:不支持此目的地址,不进行负载均衡 · Forward all:转发报文 · Forwarding to link:将报文转发给链路 · Drop:丢弃报文 · Waiting:排队等待 |
Drop reason |
丢弃报文的原因,包括: · Number of connections or bandwidth for the virtual server exceeded the limit:虚服务器连接数或带宽受限 · No class matched and no valid default link group configured:输入的五元组未匹配任何负载均衡类,且未配置有效的缺省链路组 · No valid link in the link group:选择的链路组中没有可用的链路 · Action is drop:负载均衡动作为丢弃报文 · A sticky entry was matched but the number of connections or bandwidth for the link exceeded the limit:匹配的持续性表项所对应的链路连接数或带宽受限 · A class was matched but no valid link group exists in the action of the class:匹配的负载均衡类所对应的负载均衡动作中没有可用的链路组 · Queue overflow:排队等待的队列长度超出限制 |
Selected link |
选择的链路名称 |
Scheduling algorithm |
选择该链路的依据,包括: · Predictor:根据调度算法选择了该链路 · Sticky method:根据持续性方法选择了该链路 · Proximity:根据就近性方法选择了该链路 |
loadbalance schedule-test ipv6命令用来测试IPv6负载均衡效果。
loadbalance schedule-test ipv6 { protocol { protocol-number | icmpv6 | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port
protocol { protocol-number | icmp | tcp | udp }:测试的协议。protocol-number为协议编号,取值范围为0~255。其中,ICMPv6(58)、TCP(6)和UDP(17)这三种协议既可输入协议编号,也可输入协议名称。
destination destination-address:目的IPv6地址。
source source-address:源IPv6地址。
# 测试ICMPv6协议IPv6负载均衡的效果。
<Sysname> loadbalance schedule-test ipv6 protocol icmpv6 destination 10::1 source 12::2
表1-22 loadbalance schedule-test ipv6命令显示信息描述表
匹配的虚服务器名称 |
未匹配任何虚服务器 |
Matched class |
匹配的负载均衡类名称 |
匹配了缺省负载均衡动作 |
匹配的缺省链路组名称 |
Forward type |
Drop reason |
Selected link |
选择的链路名称 |
loadbalance snat-pool命令用来创建SNAT地址池,并进入SNAT地址池视图。如果指定的SNAT地址池已经存在,则直接进入SNAT地址池视图。
undo loadbalance snat-pool命令用来删除指定的SNAT地址池。
loadbalance snat-pool pool-name
undo loadbalance snat-pool pool-name
不存在任何SNAT地址池。
pool-name:SNAT地址池的名称,为1~63个字符的字符串,不区分大小写。
# 创建SNAT地址池lbsp,并进入SNAT地址池视图。
match命令用来为不同类型的报文指定就近性探测方法。
undo match命令用来恢复缺省情况。
match [ match-id ] { tcp } probe nqa-template
undo match match-id
未指定就近性探测方法。
就近性视图
match-id:就近性探测方法的编号,取值范围为1~65535。如果指定编号的就近性探测方法不存在,则创建一个新的就近性探测方法;如果指定编号的就近性探测方法已存在,则对其进行修改。如果未指定本参数,系统将自动分配一个可用的最小编号。
tcp:为TCP类型的报文指定就近性探测方法。
probe nqa-template:使用NQA模板进行探测。nqa-template为NQA模板名称,为1~32个字符的字符串,不区分大小写。
配置本命令后,当流量匹配了指定的报文类型,就使用该报文类型所对应的就近性探测方法进行就近性探测。如果流量未匹配任何报文类型,或者未配置本命令,则使用match default命令所指定的默认就近性探测方法进行就近性探测。
每种报文类型只能指定一种就近性探测方法,最后一次执行的生效。
同一就近性视图下,若同时配置本命令和match命令,则建议均引用NQA模板或均引用负载均衡探测模板,若混合引用则会导致NQA模板引用失效。
# 创建ICMP类型的NQA模板t4,并将其指定为TCP类型报文的就近性探测方法。
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-lb-proximity] match tcp probe t4
· match default
match acl命令用来创建ACL类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
undo match命令用来删除指定的匹配规则。
match [ match-id ] acl [ ipv6 ] { acl-number | name acl-name }
undo match match-id
不存在匹配规则。
负载均衡类视图
match-id:匹配规则的编号,取值范围为1~65535。若未指定本参数,系统将自动分配一个可用的最小编号。
ipv6:表示IPv6 ACL类型。若未指定本参数,表示IPv4 ACL类型。
acl-number:ACL的编号,取值范围为2000~3999。
name acl-name:ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。
如果指定编号或名称的ACL不存在,此匹配规则将不参与匹配。
一个负载均衡类中最多允许创建65535条匹配规则。
# 在Link-generic类型的负载均衡类lbc1中,创建ACL类型的匹配规则。
[Sysname-lbc-link-generic-lbc1] match acl 2000
match app-group命令用来创建应用类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
undo match app-group命令用来删除指定的匹配规则。
match [ match-id ] app-group group-name
undo match match-id
负载均衡类中不存在匹配规则。
Link-Generic类型的负载均衡类视图
app-group group-name:应用组的名称,为1~63个字符的字符串,不区分大小写。
如果匹配规则中指定的应用组不存在,则此规则不生效
# 在链路负载均衡类lbc1中,创建基于应用类型的匹配规则。
[Sysname-lbc-link-generic-lbc1] match app-group http
· app-group(安全命令参考/APR)
match class命令用来创建嵌套类的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
match [ match-id ] class class-name
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
class-name:要嵌套的负载均衡类名称,为1~63个字符的字符串,不区分大小写。不允许嵌套当前的负载均衡类。
在创建嵌套类的匹配规则时,最多只能嵌套一层。即本命令不能引用已嵌套的负载均衡类。
# 在Link-generic类型的负载均衡类lbc1中,创建嵌套类的匹配规则为:嵌套负载均衡类lbc2。
[Sysname-lbc-link-generic-lbc1] match class lbc2
match default命令用来指定缺省就近性探测方法。
undo match default命令用来恢复缺省情况。
match default probe nqa-template
undo match default
未指定缺省就近性探测方法。
就近性视图
配置了match命令后,当流量匹配了指定类型的报文,就使用该类型报文所对应的就近性探测方法进行就近性探测。如果流量未匹配任何类型的报文,或者未配置match命令,则使用本命令所指定的默认就近性探测方法进行就近性探测。
# 创建ICMP类型的NQA模板t4,并将其指定为缺省就近性探测方法。
[Sysname-lb-proximity] match default probe t4
· match
· nqa template(网络管理和监控命令参考/NQA)
match destination命令用来创建目的IP地址类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
DNS/Link-generic类型的负载均衡类视图
ip address ipv4-address:IPv4地址。
mask-lengh:子网掩码长度,取值范围为0~32,缺省值为32。
mask:子网掩码,缺省值为255.255.255.255。
ipv6 address ipv6-address:IPv6地址。
prefix-length:前缀长度,取值范围为0~128,缺省值为128。
# 在DNS类型的负载均衡类lbc1中,创建目的IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname] loadbalance class lbc1 type dns
[Sysname-lbc-dns-lbc1] match destination ip address 1.1.1.1
# 在Link-generic类型的负载均衡类lbc2中,创建目的IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname] loadbalance class lbc2 type link-generic
[Sysname-lbc-link-generic-lbc2] match destination ip address 1.1.1.1
match destination domain-name命令用来创建域名类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] destination domain-name domain-name
undo match match-id
负载均衡类中不存在匹配规则。
domain-name:域名,为1~253个字符的字符串,不区分大小写。域名由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。域名字符串中可以包含字母、数字、“-”、“_”或“.”。域名支持通配符,允许使用的通配字符包括问号“?”和星号“*”,通配符使用规则如下:
· 问号“?”用于代替域名中的单个字符,域名中的点“.”除外,域名中允许使用多个问号“?”;
· 星号“*”用于代替域名中的多个字符,域名中的点“.”除外,域名中允许使用多个星号“*”;
· 域名中允许同时使用问号“?”和星号“*”。
# 在Link-generic类型的负载均衡类lbc1中,创建域名类型的匹配规则:匹配域名www.aaa.com。
[Sysname-lbc-link-generic-lbc1] match destination domain-name www.aaa.com
match domain-name命令用来创建域名类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
undo domain-name命令用来删除指定的匹配规则。
match [ match-id ] domain-name domain-name
DNS类型的负载均衡类视图
domain-name:域名,为1~253个字符的字符串,不区分大小写。由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。字符串中可以包含字母、数字、“-”、“_”或“.”。域名支持通配符配置,允许使用的通配字符包括问号“?”和星号“*”,通配符使用规则如下:
· 问号“? ”用于代替域名中的单个字符,域名中的点“.”除外,域名中允许使用多个问号“?”;
# 在DNS类型的负载均衡类lbc1中,创建域名类型的匹配规则:匹配域名www.abc.com。
[Sysname-lbc-dns-lbc1] match domain-name www.abc.com
match isp命令用来创建ISP类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] isp isp-name
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
如果指定名称的ISP不存在或未配置IP网段信息,此匹配规则将不参与匹配。
# 在Link-generic类型的负载均衡类lbc1中,创建ISP类型的匹配规则,匹配名为isp1的ISP。
[Sysname-lbc-link-generic-lbc1] match isp isp1
match source命令用来创建源IP地址类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] source { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
# 在Link-generic类型的负载均衡类lbc1中,创建源IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname-lbc-link-generic-lbc1] match source ip address 1.1.1.1
max-bandwidth命令用来配置链路的最大期望带宽。
undo max-bandwidth命令用来恢复缺省情况。
max-bandwidth [ inbound | outbound ] bandwidth-value
undo max-bandwidth [ inbound | outbound ]
链路的最大期望带宽不受限制。
链路视图
inbound:配置最大上行期望带宽,即入方向带宽。
outbound:配置最大下行期望带宽,即出方向带宽。
bandwidth-value:最大带宽值,取值范围为1~4294967295,单位为千字节/秒,0千字节/秒表示最大带宽不受限制。
如果未指定inbound和outbound参数,则最大总期望带宽,总带宽等于入带宽与出带宽之和。
通过本命令配置的最大期望带宽不仅用于带宽繁忙保护功能,还用于带宽算法、最大带宽算法和就近性中剩余带宽的计算。
# 配置链路lk1的最大总期望带宽为1千字节/秒。
[Sysname-lb-link-lk1] max-bandwidth 1
# 配置链路lk1的最大上行期望带宽为1千字节/秒。
[Sysname-lb-link-lk1] max-bandwidth inbound 1
# 配置链路lk1的最大下行期望带宽为1千字节/秒。
[Sysname-lb-link-lk1] max-bandwidth outbound 1
max-number命令用来配置就近性表项的最大个数。
undo max-number命令用来恢复缺省情况。
max-number number
undo max-number
不限制就近性表项的最大个数。
就近性视图
number:就近性表项的最大个数,取值范围为0~10000000,缺省值为0,0表示不限制就近性表项的最大个数。
# 配置就近性表项的最大个数为100。
[Sysname-lb-proximity] max-number 100
override-limit enable命令用来开启匹配持续性表项的会话不受连接数限制。
undo override-limit enable命令用来关闭匹配持续性表项的会话不受连接数限制。
匹配持续性表项的会话受连接数限制配置的影响。
持续性组视图
开启该功能后,如果该连接匹配了已有的持续性表项,将不受链路上带宽和连接参数的影响,不受链路的带宽繁忙比与最大期望带宽的影响,也不受虚服务器上引用的负载均衡策略连接数限制的影响。
# 配置持续性组st使其对匹配了该持续性组生成的持续性表项的会话不受连接数限制影响。
[Sysname] sticky-group st type address-port
[Sysname-sticky-address-port-st] override-limit enable
parameter命令用来指定虚服务器引用的参数模板。
undo parameter命令用来恢复缺省情况。
parameter ip profile-name
undo parameter ip
虚服务器未引用任何参数模板。
虚服务器视图
ip:参数模板的类型为IP类型。
profile-name:参数模板的名称,为1~63个字符的字符串,不区分大小写。
参数模板用来对虚服务器上的流量进行比较深入的解析、处理和优化。虚服务器引用了参数模板后,就要根据该参数模板的配置对匹配流量进行相应的处理。
# 指定IP类型的虚服务器vs3引用IP类型的参数模板pp2。
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] parameter ip pp2
parameter-profile命令用来创建参数模板,并进入参数模板视图。如果指定的参数模板已经存在,则直接进入参数模板视图。
undo parameter-profile命令用来删除指定的参数模板。
parameter-profile profile-name [ type ip ]
undo parameter-profile profile-name
不存在任何参数模板。
type ip:参数模板的类型为IP类型。创建参数模板时必须指定本参数;而在进入已创建的参数模板视图时可以不指定本参数,但若要指定本参数,则必须与创建时的类型一致。
通过配置参数模板可以进行一些高级参数的配置。这样,当参数模板被虚服务器引用之后,可以对虚服务器的业务流量进行更深入的解析、处理和优化。
# 创建IP类型的参数模板pp2,并进入参数模板视图。
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2]
port命令用来配置DNS透明代理的端口号。
undo port命令用来恢复缺省情况。
port port-number
undo port
DNS透明代理的端口号为53。
DNS透明代理视图
port-number:端口号,取值范围1~65535。
只有当用户发送的DNS请求报文的目的地址和端口号匹配DNS透明代理的地址和端口号,设备才进行DNS透明代理。
# 在名称为dns-proxy1的DNS透明代理视图下,配置其端口号为5353。
[Sysname-lb-dp-dns-proxy1] port 5353
port命令用来配置DNS服务器的端口号。
port port-number
undo port
DNS服务器的端口号为0。
DNS服务器视图
port-number:端口号,取值范围0~65535,0表示继续使用原报文携带的端口号。
# 配置DNS服务器的端口号为5353。
[Sysname-lb-ds-ds1] port 5353
port命令用来配置虚服务器的端口号。
port { port-number [ to port-number ] } &<1-n>
undo port
Link-IP类型虚服务器的端口号为0(表示任意端口号)。
虚服务器视图
{ port-number [ to port-number ] } &<1-n>:表示一个或多个端口号。其中,port-number为端口号,对于Link-IP类型的虚服务器,取值范围为0~65535,0表示任意端口号。&<1-n>表示前面的参数最多可以输入n次,对于Link-IP类型的虚服务器,n的取值范围为1~8。
# 配置Link-IP类型的虚服务器vs3的端口号为8080。
[Sysname] virtual-server vs3 type link-ip
[Sysname-vs-link-ip-vs3] port 8080
predictor命令用来配置DNS服务器池的调度算法。
undo predictor命令用来恢复缺省情况。
predictor { random | round-robin | { bandwidth | max-bandwidth } [ inbound | outbound ] }
DNS服务器池的调度算法为加权轮转算法。
DNS服务器池视图
hash address:根据IP地址进行的哈希算法。
destination:根据目的IP地址进行的哈希算法。
source:根据源IP地址进行的哈希算法。
source-ip-port:根据源IP地址和端口号进行的哈希算法。
mask mask-length:哈希算法中IPv4地址的掩码长度,取值范围为0~32,缺省值为32。
prefix prefix-length:哈希算法中IPv6地址的前缀长度,取值范围为0~128,缺省值为128。
random:随机算法,即把DNS请求报文随机分发给每台DNS服务器。
round-robin:加权轮转算法,即根据DNS服务器权值的大小把DNS请求报文依次分发给每台DNS服务器,权值越大,分配的DNS请求报文越多。
bandwidth:带宽算法,即报文根据DNS服务器的权值与剩余带宽比例把DNS请求分发给每台DNS服务器。
max-bandwidth:最大带宽算法,即总是将DNS请求分发给处于空闲状态且剩余带宽最大的链路所对应的DNS服务器。
inbound:根据入方向带宽选择DNS服务器。
outbound:根据出方向带宽选择DNS服务器。
如果未指定inbound和outbound关键字,将根据总带宽来选择DNS服务器。
在带宽算法和最大带宽算法中,剩余带宽为链路的最大期望带宽(max-bandwidth)与当前带宽的差值。若未配置最大期望带宽,剩余带宽为链路所允许的最大带宽(rate-limit bandwidth)与当前带宽的差值。
# 配置DNS服务器池dns-pool的优选调度算法为随机算法。
[Sysname-lb-dspool-dns-pool] predictor random
· max-bandwidth (link view)
· rate-limit bandwidth (link view)
predictor命令用来配置链路组的调度算法。
predictor hash address { destination | source | source-ip-port } [ mask mask-length ] [ prefix prefix-length ]
predictor { least-connection | random | round-robin | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
链路组的调度算法为加权轮转算法。
链路组视图
mask mask-length: IPv4地址的掩码长度,取值范围为0~32,缺省值为32。
prefix prefix-length:IPv6地址的前缀长度,取值范围为0~128,缺省值为128。
least-connection:加权最小连接算法,即总是把新连接分发给加权活动连接数(当前活动连接数/权值)最小的链路。
random:随机算法,即把新连接随机分发给每个链路。
round-robin:加权轮转算法,即根据链路权值的大小把新连接依次分发给每个链路,权值越大,分配的新连接越多。
bandwidth:带宽算法,即报文根据链路的权值与剩余带宽比例分发到各链路上。
max-bandwidth:最大带宽算法,即报文总是分发给处于空闲状态切带宽最大的链路。
inbound:根据入方向带宽选择链路。
outbound:根据出方向带宽选择链路。
如果未指定inbound和outbound关键字,将根据总带宽来选择链路。
多次执行本命令,最后一次执行的命令生效。。
# 配置链路组lg的调度算法为随机算法。
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] predictor random
priority命令用来配置DNS服务器的调用优先级。
undo priority命令用来恢复缺省情况。
priority priority
undo priority
DNS服务器的调用优先级为4。
DNS服务器视图
priority:优先级,取值范围为1~8,数值越大,越被优先调用。
在DNS服务器池范围内,优先级最高的DNS服务器参与调度,如果可用DNS服务器数量未到达预设的最低门限,则将次高优先级的DNS服务器均加入调度,依次类推,直至达到预设的最小参与调度个数或没有可用服务器为止。若将某一个优先级的DNS服务器均加入调度后,超出了预设的最大参与调度个数,则只加入部分此优先级的DNS服务器,此时最终参与调度的可用DNS服务器个数将为预设的最大参与调度个数。
本命令与DNS服务器池视图下的selected-server命令配合使用。
# 配置DNS服务器ds1的调用优先级为3。
[Sysname-lb-ds-ds1] priority 3
· selected-server (DNS server pool view)
priority命令用来配置链路的调用优先级。
priority priority
undo priority
链路的调用优先级为4。
链路视图
priority:优先级。取值范围为1~8,数值越大,优先级越高。
通常使用负载分担时,优先使用高优先级的链路处理流量。如果最高优先级链路的个数少于配置的参与调度的最少个数,则在次高优先级中选择链路,达到配置的最少个数。
# 配置链路lk1的调用优先级为3。
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] priority 3
· selected-link
probe命令用来指定DNS服务器池的健康检测方法。
undo probe命令用来恢复缺省情况。
未指定DNS服务器池的健康检测方法。
DNS服务器池视图
template-name:健康检测方法所使用的NQA模板名称,为1~32个字符的字符串,不区分大小写。
使用nqa template命令创建健康检测方法所使用的NQA模板,通过健康检测可以对DNS服务器进行检测,保证其能够提供有效的服务。
用户既可在DNS服务器池视图下对池内的所有DNS服务器进行配置,也可在DNS服务器视图下只对当前DNS服务器进行配置,后者的配置优先级较高。
# 创建ICMP类型的NQA模板t4,并将其指定为DNS服务器池dns-pool的健康检测方法。
[Sysname-lb-dspool-dns-pool] probe t4
· success-criteria (dns-server-pool view)
probe命令用来指定DNS服务器的健康检测方法。
probe template-name
undo probe template-name
未指定DNS服务器的健康检测方法。
DNS服务器视图
请使用nqa template命令创建健康检测方法所使用的NQA模板。
# 创建ICMP类型的NQA模板t4,并将其指定为DNS服务器ds1的健康检测方法。
[Sysname-lb-ds-ds1] probe t4
· success-criteria (DNS server view)
probe命令用来指定链路组的健康检测方法。
probe template-name
未指定链路组的健康检测方法。
链路组视图
链路组采用所引用的NQA模板中定义的链路检测参数来对当前调用的链路进行检测,保证及时发现链路的可用性。
用户既可在链路组视图下对组内的所有链路进行配置,也可在链路图下只对当前链路进行配置,后者的配置优先级较高。
# 创建ICMP类型的NQA模板t4,并将其指定为链路组lg的健康检测方法。
[Sysname-lb-lgroup-lg] probe t4
· success-criteria(link group view)
probe命令用来指定链路的健康检测方法。
probe template-name
未指定链路的健康检测方法。
链路视图
通过配置健康检测方法可以对链路进行检测,保证其能够提供有效的链路,健康检测方法所使用的NQA模板由nqa template命令配置。
同一个链路视图下,可以配置多个链路健康检测方法。系统缺省情况下,只有全部方法通过检测才认为健康检测成功,可通过success-criteria命令配置链路健康检测的成功条件。
# 创建ICMP类型的NQA模板t4,并将其指定为链路lk1的健康检测方法。
[Sysname-lb-link-lk1] probe t4
· success-criteria((link view)
proximity enable命令用来在链路组中开启就近性功能。
undo proximity enable命令用来在链路组中关闭就近性功能。
proximity enable
链路组中的就近性功能处于关闭状态。
链路组视图
在链路组中开启就近性功能后,负载均衡设备首先按照就近性选择组内的链路,就近性选择失败后再按照调度算法选择链路。
# 在链路组lg中开启就近性功能。
[Sysname-lb-lgroup-lg] proximity enable
rate-limit bandwidth命令用来配置链路所允许的最大带宽。
undo rate-limit bandwidth命令用来恢复缺省情况。
rate-limit bandwidth [ inbound | outbound ] bandwidth-value
undo rate-limit bandwidth [ inbound | outbound ]
链路所允许的最大带宽不受限制。
链路视图
inbound:配置最大入带宽。
outbound:配置最大出带宽。
bandwidth-value:最大带宽值,取值范围为0~4294967295,单位为千字节/秒,0千字节/秒表示最大带宽不受限制。
如果未指定inbound和outbound参数,则配置最大总带宽,总带宽等于入带宽与出带宽之和。
本命令不仅在新建会话时生效,对已经存在的会话也生效。
# 配置链路lk1所允许的最大总带宽为1千字节/秒。
[Sysname-lb-link-lk1] rate-limit bandwidth 1
# 配置链路lk1所允许的最大入带宽为1千字节/秒。
[Sysname-lb-link-lk1] rate-limit bandwidth inbound 1
# 配置链路lk1所允许的最大出带宽为1千字节/秒。
[Sysname-lb-link-lk1] rate-limit bandwidth outbound 1
rate-limit bandwidth命令用来配置虚服务器所允许的最大带宽。
虚服务器所允许的最大带宽不受限制。
虚服务器视图
inbound:最大入带宽。
outbound:最大出带宽。
# 配置Link-IP类型的虚服务器vs3所允许的最大总带宽为1千字节/秒。
[Sysname-vs-link-ip-vs3] rate-limit bandwidth 1
# 配置Link-IP类型的虚服务器vs3所允许的最大入带宽为1千字节/秒。
[Sysname-vs-link-ip-vs3] rate-limit bandwidth inbound 1
# 配置Link-IP类型的虚服务器vs3所允许的最大出带宽为1千字节/秒。
[Sysname-vs-link-ip-vs3] rate-limit bandwidth outbound 1
rate-limit connection命令用来配置链路所允许的最大连接速率。
undo rate-limit connection命令用来恢复缺省情况。
rate-limit connection connection-number
链路视图
connection-number:链路所允许的最大连接速率,取值范围为0~4294967295,0表示链路所允许的最大连接速率不受限制。
本命令只在新建会话时生效,对已经存在的会话不生效。
# 配置链路lk1所允许的最大连接速率为10000。
[Sysname-lb-link-lk1] rate-limit connection 10000
rate-limit connection命令用来配置虚服务器所允许的最大连接速率。
虚服务器所允许的最大连接速率为0。
虚服务器视图
connection-number:虚服务器所允许的最大连接速率,取值范围为0~4294967295,0表示虚服务器所允许的最大连接速率不受限制。
# 配置Link-IP类型的虚服务器vs3所允许的最大连接速率为10000。
[Sysname-vs-link-ip-vs3] rate-limit connection 10000
reset loadbalance connections命令用来清除负载均衡的应用层连接。
此命令会将当前所有负载均衡的应用层连接清除,包括连接复用中的空闲连接。
# 清除负载均衡应用层链接。
<Sysname> reset loadbalance connection
reset loadbalance dns-proxy statistics命令用来清除DNS透明代理的统计信息。
reset loadbalance dns-proxy statistics [ dns-proxy-name ]
dns-proxy-name:DNS透明代理名称,为1~63个字符的字符串,不区分大小写。如果未指定此参数,则清除所有DNS透明代理的统计信息。
# 清除DNS透明代理dns-proxy1的统计信息
<Sysname> reset loadbalance dns-proxy statistics dns-proxy1
· display loadbalance dns-proxy statistics
reset loadbalance dns-server statistics命令用来清除DNS服务器的统计信息。
reset loadbalance dns-server statistics [ dns-server-name ]
dns-server-name:清除指定DNS服务器的统计信息。其中,dns-server-name表示DNS服务器名称,为1~63个字符的字符串,不区分大小写。若未指定本参数,则清除所有DNS服务器的统计信息。
# 清除DNS服务器ds1的统计信息。
<Sysname> reset loadbalance dns-server statistics ds1
· display loadbalance dns-server statistics
reset loadbalance link statistics命令用来清除链路的统计信息。
reset loadbalance link statistics [ link-name ]
link-name:链路的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将清除所有链路的统计信息。
# 清除所有链路的统计信息
<Sysname> reset loadbalance link statistics
reset loadbalance proximity命令用来清除就近性表项的信息。
reset loadbalance proximity [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ]
ip [ ipv4-address ]:清除IPv4就近性表项的信息。如果指定了ipv4-address参数,将清除指定IPv4地址所对应就近性表项的信息;如果未指定ipv4-address参数,将清除所有IPv4就近性表项的信息。
ipv6 [ ipv6-address ]:清除IPv6就近性表项的信息。如果指定了ipv6-address参数,将清除指定IPv6地址所对应就近性表项的信息;如果未指定ipv6-address参数,将清除所有IPv6就近性表项的信息。
如果未指定ip和ipv6关键字,将清除公网实例中所有IPv4和IPv6就近性表项的信息。
# 清除所有IPv6就近性表项。
<Sysname> reset loadbalance proximity ipv6
reset virtual-server statistics命令用来清除虚服务器的统计信息。
reset virtual-server statistics [ virtual-server-name ]
virtual-server-name:清除指定虚服务器的统计信息。virtual-server-name为虚服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将清除所有虚服务器的统计信息。
# 清除所有虚服务器的统计信息。
<Sysname> reset virtual-server statistics
· display virtual-server statistics
router ip命令用来指定链路通往外网方向的下一跳IPv4地址。
undo router ip命令用来恢复缺省情况。
router ip ipv4-address
undo router ip
未配置链路通往外网方向的下一跳IPv4地址。
链路视图
ipv4-address:IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
一条链路只能配置一个通往外网方向的下一跳IPv4地址。
# 指定链路lk1通往外网方向的下一跳IPv4地址为1.2.3.4。
[Sysname-lb-link-lk1] router ip 1.2.3.4
router ipv6命令用来指定链路通往外网方向的下一跳IPv6地址。
undo router ipv6命令用来恢复缺省情况。
router ipv6 ipv6-address
undo router ipv6
未配置链路通往外网方向的下一跳IPv6地址。
链路视图
ipv6-address:IPv6地址信息,不能配置全零地址,多播地址,环回地址,链路本地地址。
一条链路只能配置一个通往外网方向的下一跳IPv6地址。
# 指定链路lk1通往外网方向的下一跳IPv6地址为8008::8。
[Sysname-lb-link-lk1] router ipv6 8008::8
rtt weight命令用来配置就近性计算的网络延迟权值。
undo rtt weight命令用来恢复缺省情况。
rtt weigt rtt-weight
undo rtt weight
就近性计算的网络延迟权值为100。
就近性视图
rtt-weight:就近性计算的网络延迟权值,取值范围为0~255,数值越大权重越大。
# 配置就近性计算的网络延迟权值为200。
[Sysname] loadbalance proximity
[Sysname-lb-proximity] rtt weight 200
selected-link命令用来配置链路组中可被调度算法调用的链路数量限制。
undo selected-link命令用来恢复缺省情况。
selected-link min min-number max max-number
undo selected-link
链路组中调用优先级最高的链路全部被调度算法调用。
链路组视图
min min-number:可被调度算法调用的链路最小数量,取值范围为1~1000。
max max-number:可被调度算法调用的链路最大数量,取值范围1~1000,且必须大于等于min-number。
缺省情况下,一个链路组中调用优先级最高的链路全部可被调度算法调用。通过本命令可以限制可被调度算法调用的链路数量:
· 如果当前调用优先级最高的可用链路数量大于max-number,则只调用其中的max-number条链路。
· 如果当前调用优先级最高的可用链路数量小于min-number,除了调用全部优先级最高的可用链路外,还会调用优先级次高的可用链路,直至调用的可用链路数量达到min-number,或者没有可用的链路可调用为止。
# 配置链路组lg中可被调度算法调用的链路最小数量为20,最大数量为30。
[Sysname-lb-lgroup-lg] selected-link min 20 max 30
· predictor(link group view)
· priority(link view)
selected-server命令用来配置DNS服务器池中可被调度算法调用的DNS服务器数量限制。
undo selected-server命令用来恢复缺省情况。
selected-server min min-number max max-number
DNS服务器池中调用优先级最高的DNS服务器全部被调度算法调用。
DNS服务器池视图
min min-number:可被调度算法调用的DNS服务器最小数量,取值范围为1~1000。
max max-number:可被调度算法调用的DNS服务器最大数量,取值范围1~1000,且必须大于等于min-number。
用户通过本命令可以限制可被调度算法调用的DNS服务器数量:
· 如果调用优先级最高的可用DNS服务器数量小于min-number时,除了调用全部优先级最高的可用DNS服务器外,还会调用优先级次高的可用DNS服务器,直至调用的可用DNS服务器数量达到min-number,或者没有可用的DNS服务器可调用为止。
· 如果调用某一优先级的可用DNS服务器后数量大于max-number时,则只选用max-number个DNS服务器。
# 配置DNS服务器池dns-pool中可被调度算法调用的DNS服务器最小数量为20,最大数量为30。
[Sysname-lb-dspool-dns-pool] selected-server min 20 max 30
service enable命令用来开启DNS透明代理功能。
undo service enable命令用来关闭DNS透明代理功能。
DNS透明代理功能处于关闭状态。
DNS透明代理视图
# 在名称为dns-proxy1的DNS透明代理视图下,开启DNS透明代理功能
[Sysname-lb-dp-udp-dns-proxy1] service enable
service enable命令用来开启虚服务器。
undo service enable命令用来关闭虚服务器。
service enable
undo service enable
虚服务器处于关闭状态。
虚服务器视图
# 开启Link-IP类型的虚服务器vs3。
[Sysname-vs-link-ip-vs3] service enable
set ip tos命令用来配置发往服务器的IP报文中的ToS字段。
undo set ip tos命令用来恢复缺省情况。
set ip tos tos-number
undo set ip tos
不改变发往服务器的IP报文中的ToS字段。
负载均衡动作视图
tos-number:ToS字段值,取值范围为0~255。
# 在Link-generic类型的负载均衡动作lba1中,配置发往服务器的IP报文中的ToS字段值为20。
[Sysname] loadbalance action lba1 type link-generic
[Sysname-lba-link-generic-lba1] set ip tos 20
set ip tos命令用来配置发往客户端的IP报文中的ToS字段。
undo set ip tos
不改变发往客户端的IP报文中的ToS字段。
参数模板视图
tos-number:ToS字段值,取值范围0~255。
本命令只在IP类型的参数模板视图下支持。
# 在IP类型的参数模板pp2中,配置发往客户端的IP报文中的ToS字段值为20。
[Sysname-para-ip-pp2] set ip tos 20
shutdown命令用来关闭当前链路。
undo shutdown命令用来开启当前链路。
shutdown
链路处于开启状态。
链路视图
# 关闭链路lk1。
[Sysname-lb-link-lk1] shutdown
skip current-dns-proxy命令用来配置报文的转发模式为跳过当前DNS透明代理。
undo skip current-dns-proxy命令用来恢复缺省情况。
DNS类型的负载均衡动作视图
配置报文的转发模式为跳过当前DNS透明代理,可使匹配了DNS透明代理的报文跳过当前DNS透明代理,并重新匹配DNS透明代理或虚服务器。
一个DNS请求最多只能跳过5个不同的DNS透明代理或虚服务器。
本命令与dns-server-pool和forward all命令互斥,当配置了其中一条后,另一条的配置将被自动取消。
# 在DNS类型的负载均衡动作lba1中,配置报文的转发模式为跳过当前DNS透明代理。
[Sysname-lba-dns-lba1] skip current-dns-proxy
slow-online命令用来在链路组中开启链路温暖上线功能。
undo slow-online命令用来在链路组中关闭链路温暖上线功能。
slow-online [ standby-time standby-time ramp-up-time ramp-up-time ]
undo slow-online
链路组中的链路温暖上线功能处于关闭状态。
链路组视图
standby-time standby-time:准备时间,取值范围为0~600,单位为秒,缺省值为5秒。
ramp-up-time ramp-up-time:爬升时间,取值范围为3~600,单位为秒,缺省值为5秒。
可以通过开启温暖上线功能,解决链路组中新增链路无法立即承担大量业务的问题。当链路组中新增一个可用链路后,在准备时间内,负载均衡设备不会向其分配任何业务;准备时间超时后,负载均衡设备在爬升时间内会逐步增加向其分配的业务量;爬升时间超时后,负载均衡设备开始向其正常分配业务。
# 在链路组lg中开启链路温暖上线功能。
[Sysname-lb-lgroup-lg] slow-online
slow-shutdown enable 命令用来开启链路的慢宕功能。
undo slow-shutdown enable 命令用来关闭链路的慢宕功能。
链路的慢宕功能处于关闭状态。
链路视图
通过shutdown命令可以立即中断链路的已有连接,而慢宕则不会立即中断链路的已有连接,而是让其自然老化,并且不再建立新的连接。
本命令需要与shutdown命令配合使用。必须开启了慢宕功能之后再关闭链路,该链路才会开始慢宕。如果先关闭链路,再开启慢宕功能,则慢宕功能不生效,链路处于关闭状态。
# 开启链路lk1的慢宕功能。
[Sysname-lb-link-lk1] slow-shutdown enable
· shutdown(link view)
snat-pool命令用来指定链路组引用的SNAT地址池。
undo snat-pool命令用来恢复缺省情况。
snat-pool pool-name
undo snat-pool
链路组未引用任何SNAT地址池。
链路组视图
SNAT地址池是一个地址范围,它被链路组引用之后,负载均衡设备将把收到报文的源地址修改为SNAT地址池中的地址后再转发出去。
# 配置链路组lg引用的SNAT地址池为lbsp。
[Sysname-lb-lgroup-lg] snat-pool lbsp
snmp-agent trap enable loadbalance命令用来开启负载均衡的告警功能。
undo snmp-agent trap enable loadbalance命令用来关闭负载均衡的告警功能。
负载均衡的告警功能处于开启状态。
开启了负载均衡的告警功能之后,负载均衡会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭负载均衡的告警功能。
[Sysname] undo snmp-agent trap enable loadbalance
sticky-group命令用来创建持续性组,并进入持续性组视图。如果指定的持续性组已经存在,则直接进入持续性组视图。
undo sticky-group命令用来删除指定的持续性组。
sticky-group group-name [ type address-port ]
undo sticky-group group-name
不存在持续性组。
group-name:持续性组的名称,为1~63个字符的字符串,不区分大小写。
type address-port:持续性组的类型为地址端口类型。创建持续性组时必须指定本参数;而在进入已创建的持续性组视图时可以不指定本参数,但若要指定本参数,则必须与创建时的类型一致。
持续性组的作用是根据某种持续性方法将具有一定相关性的会话都分配给同一个链路处理。在一个会话中,当其首包通过持续性方法选择了链路之后,后续包都会沿用这个选择结果。
# 创建地址端口类型的持续性组sg1,并进入持续性组视图。
success-criteria命令用来配置DNS服务器池健康检测的成功条件。
undo success-criteria命令用来恢复缺省情况。
success-criteria { all | at-least min-number }
DNS服务器池视图
all:只有全部方法都通过检测才认为健康检测成功。
at-least min-number:健康检测成功所需通过检测的最少方法数,取值范围为1~4294967295。
当用户指定的最少方法数大于设备上实际存在的方法数时,只要实际存在的方法全部通过检测,设备就认为健康检测成功。
# 配置DNS服务器池dns-pool的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-lb-dspool-dns-pool] success-criteria at-least 2
· success-criteria(DNS server view)
success-criteria命令用来配置DNS服务器健康检测的成功条件。
DNS服务器视图
当用户指定的最少方法数大于设备上实际存在的方法数时,只要实际存在的方法全部通过检测,系统就认为健康检测成功。
# 配置DNS服务器ds1健康检测成功所需通过检测的最少方法数为2个。
[Sysname-lb-ds-ds1] success-criteria at-least 2
· success-criteria(DNS server pool view)
success-criteria命令用来配置链路组健康检测的成功条件。
链路组视图
当用户指定的最少方法数大于设备上实际存在的方法数量时,系统也将认为健康检测成功。
用户既可在链路组视图下对组内的所有链路进行配置,也可在链路视图下只对当前链路进行配置,后者的配置优先级较高。
# 配置链路组lg的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-lb-lgroup-lg] success-criteria at-least 2
· success-criteria(link view)
success-criteria命令用来配置链路健康检测的成功条件。
只有全部方法通过检测才认为健康检测成功。
链路视图
all:要求链路通过所有方式的健康检测。
at-least min-number:要求链路至少通过指定方式数目的健康检测,取值范围为1~4294967295。
当用户指定的最少方法数大于设备上实际存在的方法数量时,只要实际存在的全部方法通过检测,系统就认为健康检测成功。
# 配置链路健康检测的成功条件至少为2个。
[Sysname-lb-link-lk1] success-criteria at-least 2
timeout命令用来配置就近性表项的老化时间。
undo timeout命令用来恢复缺省情况。
timeout timeout-value
undo timeout
就近性表项的老化时间为60秒。
就近性视图
timeout-value:就近性表项的老化时间,取值范围为60~3600,单位为秒。
# 配置就近性表项的老化时间为80秒。
[Sysname-lb-proximity] timeout 80
timeout命令用来配置持续性表项的超时时间。
undo timeout
持续性表项的超时时间为60秒。
持续性组视图
timeout-value:超时时间。取值范围为10~604800,单位为秒。
# 在地址端口类型的持续性组sg1中,配置持续性表项的超时时间为100秒。
[Sysname-sticky-address-port-sg1] timeout 100
transparent enable命令用来在链路组中关闭NAT功能。
undo transparent enable命令用来在链路组中开启NAT功能。
transparent enable
链路组中的NAT功能处于开启状态。
链路组视图
# 在链路组lg中关闭NAT功能。
[Sysname-lb-lgroup-sinalab] transparent enable
ttl weight命令用来配置就近性计算的路由器跳数权值。
undo ttl weight命令用来恢复缺省情况。
ttl weight ttl-weight
undo ttl weight
就近性计算的路由器跳数权值为100。
就近性视图
ttl-weight:就近性计算的路由器跳数权值,取值范围为0~255,数值越大权重越大。
# 配置就近性计算的路由器跳数权值为200。
[Sysname-lb-proximity] ttl weight 200
virtual ip address命令用来配置虚服务器的IPv4地址(即VSIP)。
undo virtual ip address命令用来恢复缺省情况。
virtual ip address ipv4-address [ mask-length | mask ]
未配置虚服务器的IPv4地址。
虚服务器视图
ipv4-address:虚服务器的IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X(如果掩码长度不是32,则可以配置0.X.X.X)。
# 配置Link-IP类型的虚服务器vs3的IP地址为1.1.1.1/24。
[Sysname-vs-link-ip-vs3] virtual ip address 1.1.1.1 24
virtual ipv6 address命令用来配置虚服务器的IPv6地址(即VSIP)。
undo virtual ipv6 address命令用来恢复缺省情况。
virtual ipv6 address ipv6-address [ prefix-length ]
未配置虚服务器的IPv6地址。
虚服务器视图
ipv6-address:虚服务器的IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址(如果前缀长度为0,则可以配置全0地址)。
# 配置Link-IP类型的虚服务器vs3的IPv6地址为1001::1/64。
[Sysname-vs-link-ip-vs3] virtual ipv6 address 1001::1 64
virtual-server命令用来创建虚服务器,并进入虚服务器视图。如果指定的虚服务器已经存在,则直接进入虚服务器视图
undo virtual-server命令用来删除指定的虚服务器。
virtual-server virtual-server-name [ type link-ip ]
undo virtual-server virtual-server-name
不存在任何虚服务器。
virtual-server-name:虚服务器的名称,为1~63个字符的字符串,不区分大小写。
type link-ip:虚服务器的类型为Link-IP类型。创建虚服务器时必须指定本参数;进入已创建的虚服务器视图时可以不指定本参数,若要指定本参数,则必须与创建时的类型一致。
# 创建Link-IP类型的虚服务器vs3,并进入虚服务器视图。
weight命令用来配置DNS服务器的权值,即加权轮转调度算法和带宽调度算法所使用的权值。
undo weight命令用于恢复缺省情况。
weight weight-value
DNS服务器的权值为100。
DNS服务器视图
weight-value:权值,取值范围为1~255。在加权轮转调度和带宽调度时,该数值越大,DNS服务器越被优先调用。
# 配置DNS服务器ds1的权值为150。
[Sysname-lb-ds-ds1] weight 150
weight命令用来配置链路的权值,即加权轮转和加权最小连接这两种调度算法所使用的权值。
undo weight命令用来恢复缺省情况。
weight weight-value
undo weight
链路的权值为100。
链路视图
weight-value:权值,取值范围为1~255。在加权轮转和加权最小连接调度时,该数值越大,链路越被优先调用。
# 配置链路lk1的权值为150。
[Sysname-lb-link-lk1] weight 150
