07-射频资源测量命令
本章节下载: 07-射频资源测量命令 (177.23 KB)
display wlan measure-report命令用来显示客户端的测量报告信息。
display wlan measure-report interface wlan-radio interface-number [ client mac-address mac-address ]
interface-number:显示连接到指定射频接口的客户端信息。
client mac-address mac-address:指定客户端的MAC地址,格式为H-H-H,如果不指定client mac-address参数,将显示所有客户端的测量信息。
# 显示客户端的测量报告信息。
<Sysname> display wlan measure-report interface wlan-radio 1/0/1
Total number of clients: 1
Client MAC address : 0aef-e760-3587
Link measurement:
Link margin : 2dBm
RCPI : -85 dBm
RSNI : 53 dBm
Noise histogram:
Antenna ID : 3
ANPI : -56 dBm
IPI0 to IPI10 density : 5 12 16 13 8 5 5 15 17 1 3
Spectrum measurement:
Transmit power : 20 dBm
BSS : Detected
OFDM preamble : Detected
Radar : Detected
Unidentified signal : Undetected
CCA busy fraction : 60
RPI0 to RPI7 density : 3 7 11 19 15 23 15 7
Frame report entry:
BSSID : a072-2351-e253
PHY type : fhss
Average RCPI : -10 dBm
Last RSNI : 2 dBm
Last RCPI : -20 dBm
Frames : 1
Dot11BSSAverageAccessDelay group:
Average access delay : 32 ms
BestEffort average access delay : 1 ms
Background average access delay : 1 ms
Video average access delay : 1 ms
Voice average access delay : 1 ms
Clients : 32
Channel utilization rate : 11
Transmit stream:
Traffic ID : 0
Sent MSDUs : 60
Discarded MSDUs : 5
Failed MSDUs : 3
MSDUs resent multiple times : 3
Lost QoS CF-Polls : 2
Average queue delay : 2 ms
Average transmit delay : 1 ms
Bin0 range : 0 to 10 ms
Bin0 to Bin5 : 5 10 10 5 10 10
表1-1 display wlan measure-report命令显示信息描述表
客户端的MAC地址 |
Link measurement |
链路测量信息 |
Link margin |
客户端链路冗余数值,为接收客户端报文功率与最低可接受功率的差值 |
RCPI |
客户端接收信道功率 |
RSNI |
客户端接收信噪比值 |
Noise histogram |
噪声柱状图信息 |
Antenna ID |
客户端的天线编号 |
ANPI |
测量期间信道的平均噪声功率 |
IPI0 to IPI10 density |
IPI0~IPI10在测量期间所占用时间与测量所用全部时间的百分比 IPIn(n=0~10)代表了不同的IPI功率区间: · 0: IPI<= –92 dBm · 1: –92 dBm< IPI<= –89 dBm · 2: –89 dBm< IPI<= –86 dBm · 3: –86 dBm< IPI<= –83 dBm · 4: –83 dBm< IPI<= –80 dBm · 5: –80 dBm< IPI<= –75 dBm · 6: –75 dBm< IPI<= –70 dBm · 7: –70 dBm< IPI<= –65 dBm · 8: –65 dBm< IPI<= –60 dBm · 9: –60 dBm< IPI<= –55 dBm · 10: –55 dBm< IPI |
Spectrum measurement |
频谱管理测量信息 |
Transmit power |
客户端的传输功率 |
BSS |
测量期间客户端是否检测到来自其它802.11网络报文 |
OFDM preamble |
测量期间客户端是否检测到OFDM前导码 |
Radar |
测量期间客户端是否检测到雷达信号 |
Unidentified signal |
测量期间客户端是否检测到非802.11网络,非OFDM网络,非雷达的未知信号 |
CCA busy fraction |
测量期间信道忙碌时间所占全部检测时间的百分比 |
RPI0 to RPI7 density |
RPI0~RPI7在测量期间所占用时间与测量所用全部时间的百分比 RPIn(n=0~7)代表了不同的RPI功率区间: · 0: RPI<=–87 dBm · 1: –87 dBm< RPI<= –82 dBm · 2: –82 dBm< RPI<= –77 dBm · 3: –77 dBm< RPI<= –72 dBm · 4: –72 dBm< RPI<= –67 dBm · 5: –67 dBm< RPI<= –62 dBm · 6: –62 dBm< RPI<= –57 dBm · 7: –57 dBm < RPI |
Frame report entry |
帧报告表项信息 |
BSSID |
基本服务集识别码 |
PHY type |
媒介类型: · fhss · dsss · irbaseband · ofdm · hrdsss · erp |
Average RCPI |
平均接收信道功率 |
Last RSNI |
最新测量的信噪比 |
Last RCPI |
最新测量的接收信道功率 |
Frames |
测量期间收到的来自同一MAC地址和BSSID的数据帧与管理帧数目 |
Dot11Counters group |
dot11计数统计组 |
Sent fragments |
客户端发送帧片段的数目 |
Sent multicast frames |
客户端发送组播帧的数目 |
Failed frames |
客户端发送帧失败的次数 |
Received fragments |
客户端接收帧片段的数目 |
Received multicast frames |
客户端接收组播帧的数目 |
FCS errors |
客户端帧序列校验出错的次数 |
Sent frames |
客户端发送帧的数目 |
Dot11MACStatistics group |
dot11媒体访问控制统计组 |
Retries |
客户端重传帧的数目 |
Multiple retries |
客户端多次重传帧的数目 |
Duplicate frames |
客户端复制帧的数目 |
Successful RTS |
客户端RTS操作成功的次数 |
Failed RTS |
客户端RTS操作失败的次数 |
Failed ACK |
客户端ACK操作失败的次数 |
Dot11QosCounters group for UP0~UP7 |
dot11Qos计数统计组 |
QoS sent fragments |
QoS客户端发送帧片段的数目 |
QoS failure |
QoS客户端发送帧失败的数目 |
QoS retries |
QoS客户端重传帧的数目 |
QoS multiple retries |
QoS客户端重传多播帧的数目 |
QoS duplicate frames |
QoS客户端复制帧的数目 |
QoS successful RTS |
QoS客户端RTS操作成功的次数 |
QoS failed RTS |
QoS客户端RTS操作失败的次数 |
QoS failed ACK |
QoS客户端ACK操作失败的次数 |
QoS received fragments |
QoS客户端接收帧片段的数目 |
QoS sent frames |
QoS客户端发送帧的数目 |
QoS discarded frames |
QoS客户端丢弃报文的数目 |
QoS received MPDUs |
QoS客户端接收MPDU的数目 |
QoS received retries |
QoS客户端重试接收的次数 |
Dot11BSSAverageAccessDelay group |
dot11BSS平均访问延时统计组 |
Average access delay |
AP平均访问延时统计 |
BestEffort average access delay |
尽力而为流平均访问延时统计 |
Background average access delay |
背景流平均访问延时统计 |
Video average access delay |
视频流平均访问延时统计 |
Voice average access delay |
语音流平均访问延时统计 |
Clients |
客户端数目统计 |
Channel utilization rate |
信道利用率统计 |
Transmit stream |
传输流测量信息 |
Traffic ID |
传输流ID |
Sent MSDUs |
客户端成功发送的MSDU数目 |
Discarded MSDUs |
客户端丢弃的MSDU数目 |
Failed MSDUs |
客户端发送失败的MSDU数目 |
MSDUs resent multiple times |
客户端多次重传的MSDU数目 |
Lost QoS CF-Polls |
客户端发送QoS CF-POLL帧的丢失数目 |
Average queue delay |
平均队列延时,单位为毫秒 |
Average transmit delay |
平均发送延时,单位为毫秒 |
Bin0 range |
成功发送MSDU的平均延时柱状图中的第一段延时范围,单位为毫秒 |
Bin0 to Bin5 |
成功发送MSDU的数目在平均延时柱状图中的分布 Binx(x=0~5)表示了不同的平均延时范围: · Bin0: Delay< 10ms · Bin1: 10ms<= Delay< 20ms · Bin2: 20ms<= Delay< 40ms · Bin3: 40ms<= Delay< 80ms · Bin4: 80ms<= Delay< 160ms · Bin5: 160ms<= Delay |
measure enable命令用来开启测量功能。
measure disable命令用来关闭测量功能。
undo measure命令用来恢复缺省情况。
measure { all | link | neighbor | radio | spectrum | tpc } { disable | enable }
undo measure
测量功能处于关闭状态。
Radio接口视图
all:所有测量。
link:链路测量,测量针对链路测量请求帧的RCPI、RSNI和链路冗余等信息。
neighbor:邻居测量,测量邻居AP的信道号、BSSID等信息。
radio:射频测量,包括信道负载测量、噪声分布测量、Beacon测量、Frame测量、STA统计测量、位置信息测量和传输流测量。
spectrum:频谱测量,包括Basic测量、CCA测量和RPI测量。
tpc:传输功率控制测量,测量客户端的链路冗余和传输功率。
只有开启射频资源测量功能,link、neighbor、radio测量功能才会生效。
只有开启频谱管理功能,spectrum、tpc测量功能才会生效。有关频谱管理功能相关配置的详细介绍请参见“WLAN配置指导”中的“频谱管理”。
仅5GHz射频支持spectrum和tpc测量功能。
# 开启频谱测量。
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio1/0/1] measure spectrum enable
· measure-duration
· measure-interval
· resource-measure
· spectrum-management
measure-duration命令用来配置测量持续时间。
undo measure-duration命令用来恢复缺省情况。
measure-duration time
测量持续时间为500TU。
Radio接口视图
time:测量持续时间,取值范围1~10000,单位为TU(Time Unit,1TU=1024微秒)。
开启测量功能后,在AP向客户端发送的测量请求报文中携带配置的测量持续时间。
# 配置测量持续时间为512TU。
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] measure-duration 512
· measure
· measure-interval
measure-interval命令用来配置发送测量请求的时间间隔。
undo measure-interval命令用来恢复缺省情况。
measure-interval interval
发送测量请求间隔时间为30秒。
Radio接口视图
interval:发送测量请求的时间间隔,取值范围10~60,单位为秒。
开启测量功能后,AP以配置的时间间隔定时向客户端发送测量请求报文。
# 配置发送测量请求间隔时间为35秒。
[Sysname-WLAN-Radio1/0/2] measure-interval 35
· measure
· measure-duration
resource-measure enable命令用来开启射频资源测量功能。
resource-measure disable命令用来关闭射频资源测量功能。
undo resource-measure命令用来恢复缺省情况。
resource-measure { disable | enable }
射频资源测量功能处于关闭状态。
Radio接口视图
开启射频资源测量功能后:
· AP发送的Beacon、Probe Response和Association Response、Reassociation Response帧中,能力集字段中的Radio Measurement位会被置位,并携带AP支持的射频资源测量能力信息,用于告知客户端,AP支持射频资源测量,以及支持的测量类型。
· AP通过定期发送Measurement Pilot帧协助客户端更快地扫描到AP。Measurement Pilot报文可视为轻量级的Beacon帧,其发送的频率比Beacon帧高,但携带的信息比Beacon帧少。
# 开启射频资源测量功能。
[Sysname-WLAN-Radio1/0/2] resource-measure enable
rm-capability mode命令用来配置对客户端射频测量能力集的检查模式。
undo rm-capability mode命令用来恢复缺省情况。
rm-capability mode { all | none | partial }
不检查客户端射频测量能力集。
Radio接口视图
all:完全匹配模式。客户端的射频测量能力集与AP的能力集全部匹配,才允许客户端上线,否则,不允许客户端上线。
none:不检查模式,即不检查客户端射频测量能力集。
partial:部分匹配模式。客户端的射频测量能力集与设备的能力集只要有一个匹配,则允许客户端上线,否则,不允许客户端上线。
只有开启射频资源测量功能,射频测量能力集检查功能才会生效。
# 配置对客户端射频测量能力集的检查模式为部分匹配模式。
[Sysname-WLAN-Radio1/0/2] rm-capability mode partial
