03-二层技术-以太网交换命令参考
09-VLAN命令
本章节下载: 09-VLAN命令  (368.81 KB)
09-VLAN命令
1 VLAN
1.1 VLAN配置命令
1.1.1 bandwidth
1.1.2 default
1.1.3 description
1.1.4 display interface vlan-interface
1.1.5 display vlan
1.1.6 display vlan brief
1.1.7 interface vlan-interface
1.1.8 mtu
1.1.9 name
1.1.10 service
1.1.11 shutdown
1.1.12 vlan
1.2 基于端口的VLAN配置命令
1.2.1 display port
1.2.2 port
1.2.3 port access vlan
1.2.4 port hybrid pvid
1.2.5 port hybrid vlan
1.2.6 port link-type
1.2.7 port trunk permit vlan
1.2.8 port trunk pvid
1.3 基于MAC的VLAN配置命令
1.3.1 display mac-vlan
1.3.2 display mac-vlan interface
1.3.3 mac-vlan enable
1.3.4 mac-vlan mac-address
1.3.5 mac-vlan trigger enable
1.3.6 port pvid forbidden
1.3.7 vlan precedence
1.4 基于IP子网的VLAN配置命令
1.4.1 display ip-subnet-vlan interface
1.4.2 display ip-subnet-vlan vlan
1.4.3 ip-subnet-vlan
1.4.4 port hybrid ip-subnet-vlan
1.5 基于协议的VLAN配置命令
1.5.1 display protocol-vlan interface
1.5.2 display protocol-vlan vlan
1.5.3 port hybrid protocol-vlan
1.5.4 protocol-vlan
1.6 VLAN组配置命令
1.6.1 display vlan-group
1.6.2 vlan-group
1.6.3 vlan-list
2 Super VLAN
2.1 Super VLAN配置命令
2.1.1 display supervlan
2.1.2 subvlan
2.1.3 supervlan
3 Private VLAN
3.1 Private VLAN配置命令
3.1.1 display private-vlan
3.1.2 port private-vlan host
3.1.3 port private-vlan promiscuous
3.1.4 port private-vlan trunk promiscuous
3.1.5 port private-vlan trunk secondary
3.1.6 private-vlan(VLAN interface view)
3.1.7 private-vlan(VLAN view)
3.1.8 private-vlan community
3.1.9 private-vlan isolated
3.1.10 private-vlan primary
4 Voice VLAN
4.1 Voice VLAN配置命令
4.1.1 cdp voice-vlan
4.1.2 display voice-vlan mac-address
4.1.3 display voice-vlan state
4.1.4 voice-vlan aging
4.1.5 voice-vlan enable
4.1.6 voice-vlan mac-address
4.1.7 voice-vlan mode auto
4.1.8 voice-vlan qos
4.1.9 voice-vlan qos trust
4.1.10 voice-vlan security enable
4.1.11 voice-vlan track lldp
1 VLAN
1.1  VLAN配置命令
1.1.1  bandwidth
bandwidth命令用来配置VLAN接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
VLAN接口视图
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbps。
接口的期望带宽会对“OSPF”、“OSPFv3”和“IS-IS”的链路开销值有影响。链路开销值的具体介绍请参见“三层技术-IP路由配置指导”中的“OSPF”、“OSPFv3”和“IS-IS”。
# 配置VLAN接口1的期望带宽为10000kbps。
[Sysname-Vlan-interface1] bandwidth 10000
1.1.2  default
default命令用来恢复当前VLAN接口的缺省配置。
default
VLAN接口视图
执行default命令并不能保证接口下的所有命令都能恢复到缺省情况,某些命令可能会由于不满足必备条件而恢复失败。因此,执行default命令后建议通过display this命令确认执行效果。
# 将VLAN接口1恢复为缺省配置。
[Sysname-Vlan-interface1] default
1.1.3  description
description命令用来配置当前VLAN或VLAN接口的描述信息。
undo description命令用来恢复缺省情况。
VLAN的描述信息为“VLAN vlan-id”,其中vlan-id为该VLAN的编号。例如,VLAN 100的描述信息为“VLAN 0100”;VLAN接口的描述信息为该VLAN接口的接口名,如“Vlan-interface1 Interface”。
VLAN视图/VLAN接口视图
text:VLAN或VLAN接口的描述字符串,可以包含字母(区分大小写)、数字、特殊字符(包括~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /)、空格以及符合unicode编码规范的其他文字和符号。VLAN和VLAN接口的描述信息为1~255个字符的字符串。
当设备上配置的VLAN较多时,用户可以根据功能或者连接情况为VLAN或VLAN接口配置特定的描述信息,以便记忆和管理VLAN或VLAN接口。
# 将VLAN 2的描述信息配置为sales-private。
[Sysname] vlan 2
[Sysname-vlan2] description sales-private
# 将VLAN接口2的描述信息配置为linktoPC56。
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Vlan-interface2] description linktoPC56
·     display interface vlan-interface
·     display vlan
display interface vlan-interface命令用来显示VLAN接口的相关信息。
display interface vlan-interface [ brief [ down | description ] ]
display interface vlan-interface [ interface-number ] [ brief [ description ] ]
vlan-interface:显示VLAN接口的相关信息。
interface-number:VLAN接口的编号,显示指定VLAN接口的信息。不指定该参数时,将显示已创建的所有VLAN接口的信息。
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过27个字符,指定brief参数而不指定description参数时,只显示描述信息中的前27个字符,超出部分不显示;指定description参数时,可以显示全部描述信息。
# 显示VLAN-interface 10的相关信息。
<Sysname> display interface vlan-interface 10
Vlan-interface10
Current state: UP
Line protocol state: UP
Description: Vlan-interface10 Interface
Bandwidth: 100000kbps
Maximum Transmit Unit: 1500
Internet Address is 192.168.1.54/24 Primary
IP Packet Frame Type:PKTFMT_ETHNT_2,  Hardware Address: 0023-89b6-d613
IPv6 Packet Frame Type:PKTFMT_ETHNT_2,  Hardware Address: 0023-89b6-d613
# 显示VLAN-interface 2的概要信息。
<Sysname> display interface vlan-interface 2 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Vlan2                DOWN DOWN     --
表1-1 display interface vlan-interface命令显示信息描述表
Vlan-interface2
VLAN接口名
Current state
VLAN接口的物理状态,状态可能为:
·     DOWN ( Administratively ):表示该VLAN接口已经通过shutdown命令被关闭,即管理状态为关闭
·     DOWN:表示该VLAN接口的管理状态为开启,但物理状态为关闭,即该接口对应的VLAN内没有处于UP状态的物理端口(可能因为没有物理连线或者线路故障)
·     UP:该端口的管理状态和物理状态均为开启
Line protocol state
VLAN接口的链路层协议状态,状态可能为:
·     DOWN:该VLAN接口的协议状态为关闭
·     UP:该VLAN接口的协议状态为开启
用户通过description命令给VLAN接口配置的描述信息。使用display interface brief命令,不指定description参数时,该字段最多显示27个字符;指定description参数时,可显示配置的全部描述信息
Bandwidth
VLAN接口的期望带宽
VLAN接口允许通过的最大传输单元
Internet protocol processing : disabled
该接口还不具有处理IP报文的能力(当没有为该接口配置IP地址时会显示该信息)
该接口的主IP地址为192.168.1.54/24(只有为该接口配置主IP地址后才会显示该信息)
IPv4发送帧格式
Hardware Address
VLAN接口对应的MAC地址
IPv6发送帧格式
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复端口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
接口名称缩写
Link
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上是不通的
·     ADM:表示接口被手工关闭了,需要执行undo shutdown命令才能打开接口
·     Stby:表示该接口是一个备份接口
Protocol
接口数据链路层协议状态,取值为:
·     UP:表示接口的数据链路层是连通的
·     DOWN:表示接口的数据链路层不通
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
Main IP
接口主IP地址
1.1.5  display vlan
display vlan命令用来显示VLAN的相关信息。
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ]
vlan-id1:显示指定VLAN的信息。vlan-id1为VLAN的编号,取值范围为1~4094。
vlan-id1 to vlan-id2:显示ID在指定范围内的VLAN的信息。vlan-id1和vlan-id2为指定VLAN的编号,取值范围为1~4094。vlan-id2的值要大于或等于vlan-id1的值。
all:显示除保留VLAN外的其他VLAN的信息。
dynamic:显示系统动态创建的VLAN的数量和编号。动态VLAN是指通过MVRP协议生成的VLAN。
reserved:显示系统保留VLAN的信息。保留VLAN是设备根据功能实现的需要预留的VLAN。保留VLAN由协议模块来指定,为协议模块服务,用户不能对保留VLAN进行任何操作。
static:显示系统静态创建的VLAN的数量和VLAN编号。静态VLAN是指通过命令行手工创建的VLAN。
# 显示VLAN 2的信息。
<Sysname> display vlan 2
 VLAN ID: 2
 VLAN type: Static
 Description: VLAN 0002
 Tagged ports:   None
 Untagged ports:
    FortyGigE1/1/1  FortyGigE1/1/2  FortyGigE1/1/3
# 显示VLAN 3的信息。
<Sysname> display vlan 3
 VLAN ID: 3
 VLAN type: static
 Route interface: Configured
 IPv4 address: 1.1.1.1
 IPv4 subnet mask: 255.255.255.0
 Description: VLAN 0003
 Tagged ports:   None
 Untagged ports: None
表1-2 display vlan命令显示信息描述表
解释
VLAN ID
VLAN的编号
VLAN type
VLAN的类型:
·     Static:静态VLAN
·     Dynamic:动态VLAN
Route interface
设备上是否创建了对应的VLAN接口:
·     Not configured:未创建
·     Configured:已创建
VLAN的描述信息
Name
VLAN的名称
IPv4 address
VLAN接口的主用IP地址(如果VLAN接口没有配置IP地址,则不显示该字段),如果VLAN接口上还配置了从IP地址,可以使用display interface vlan-interface或者在VLAN接口视图下使用display this命令查看
IPv4 subnet mask
VLAN接口的主用IP地址的子网掩码(如果VLAN接口没有配置IP地址,则不显示该字段)
Tagged ports
该VLAN报文从哪些端口发送时需要携带Tag标记
Untagged ports
该VLAN报文从哪些端口发送时不需要携带Tag标记
·     Vlan
display vlan brief命令用来显示设备上所有已创建VLAN的概要信息。
display vlan brief
# 显示设备上所有已创建VLAN的概要信息。
<Sysname> display vlan brief
Brief information about all VLANs:
Supported Minimum VLAN ID: 1
Supported Maximum VLAN ID: 4094
Default VLAN ID: 1
VLAN ID   Name                             Port
1         VLAN 0001                        FGE1/1/1  FGE1/1/2  FGE1/1/3  FGE1/1/4
                                           FGE1/1/5  FGE1/1/6  FGE1/1/7  FGE1/1/8
2         VLAN 0002
3         VLAN 0003
表1-3 display vlan brief命令显示信息描述表
解释
所有VLAN的概要信息
系统支持的最小VLAN ID
系统支持的最大VLAN ID
Default VLAN ID
缺省VLAN ID
VLAN ID
VLAN的编号
Name
VLAN的名称
Port
允许该VLAN报文通过的端口
interface vlan-interface命令用来创建VLAN接口并进入VLAN接口视图。如果该VLAN接口已经存在,则直接进入VLAN接口视图。
undo interface vlan-interface命令用来删除指定的VLAN接口。
interface vlan-interface vlan-interface-id
undo interface vlan-interface vlan-interface-id
未创建VLAN接口。
vlan-interface-id:VLAN接口的编号,取值范围为1~4094。
·     在创建VLAN接口之前,对应的VLAN必须已经存在,否则将不能创建指定的VLAN接口。
·     Sub VLAN及在Primary VLAN interface下配置了三层互通的Secondary VLAN不能创建对应的VLAN接口。有关Sub VLAN的详细介绍,请参见“二层技术-以太网交换配置指导”中的“Super VLAN”;有关Secondary VLAN的详细介绍,请参见“二层技术-以太网交换配置指导”中的“Private VLAN”。
# 创建VLAN接口2并进入视图。
[Sysname] vlan 2
1.1.8  mtu
mtu命令用来配置VLAN接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
VLAN接口的MTU值为1500字节。
VLAN接口视图
size:表示接口允许通过的MTU(Maximum Transmission Unit,最大传输单元)值的大小,单位为字节。取值范围为128~1500字节。
在当前接口配置的ip mtu值或mtu值仅对接口上报CPU进行软件转发的报文生效(如以本接口为源端或目的端的报文),请合理配置网络中的MTU值,尽量避免报文分片。
如果当前接口同时配置mtu和ip mtu命令,则设备会以ip mtu命令配置的接口MTU值对报文进行分片,不会再按照mtu命令配置的MTU值对报文进行分片。有关ip mtu命令的详细介绍,请参见“三层技术-IP业务命令参考”中的“IP性能优化”。
# 配置VLAN接口1的MTU值为1492字节。
[Sysname-Vlan-interface1] mtu 1492
1.1.9  name
name命令用来指定当前VLAN的名称。
undo name命令用来恢复缺省情况。
name text
undo name
VLAN的名称为“VLAN vlan-id”,其中vlan-id为该VLAN的编号。例如,VLAN 100的名称为“VLAN 0100”。
VLAN视图
text:VLAN名称,为1~32个字符的描述信息,可以包含字母(区分大小写)、数字、特殊字符(包括~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /)、空格以及符合unicode编码规范的其他文字和符号。
当VLAN数量很多的时候,使用名称可以更明确的定位VLAN。
# 指定VLAN 2的名称为“test vlan”。
[Sysname] vlan 2
[Sysname-vlan2] name test vlan
·     display vlan
1.1.10  service
service命令用来指定转发当前接口流量的成员设备。
undo service命令用来恢复缺省情况。
service slot slot-number
undo service slot
没有指定转发当前接口流量的成员设备。
VLAN接口视图
slot slot-number:指定设备在IRF中的成员编号。slot-number表示设备在IRF中的成员编号。
没有通过service命令指定转发当前接口流量的成员设备时,直接在接收报文的成员设备上进行业务处理。而某些业务(如IPsec抗重放检测)要求同一个VLAN接口的流量必须在同一个成员设备上进行处理,此时可以在VLAN接口下通过service命令指定转发当前接口流量的成员设备。
需要注意的是,如果指定的成员设备退出IRF,即使本设备上的接口UP,流量也转发不通;如果该成员设备重新加入IRF,则流量可以恢复在指定的成员设备上正常转发。
# 指定在2号成员设备转发VLAN接口200的流量。
[Sysname] interface vlan-interface 200
[Sysname-Vlan-interface200] service slot 2
1.1.11  shutdown
shutdown命令用来手工关闭VLAN接口。
undo shutdown命令用来取消手工关闭VLAN接口。
shutdown
未手工关闭VLAN接口。此时VLAN接口状态受VLAN中端口状态的影响,即:当VLAN中所有以太网端口状态均为down时,VLAN接口为down状态,即关闭状态;当VLAN中有一个或一个以上的以太网端口处于up状态时,则VLAN接口处于up状态。
VLAN接口视图
·     如果手工关闭VLAN接口,则VLAN接口的状态始终为down(Administratively),不受VLAN中端口状态的影响。
·     配置VLAN接口参数前,为了避免配置过程中对网络造成影响,建议先使用shutdown命令手工关闭接口,之后再配置参数。配置完成后,使用undo shutdown命令取消手工关闭接口,使配置的参数生效。
·     当VLAN接口出现故障时,可以使用shutdown命令手工关闭接口,然后再使用undo shutdown命令取消手工关闭接口,这样有可能使接口恢复正常。
·     关闭和打开VLAN接口对于属于这个VLAN的任何一个以太网端口本身都不起作用,以太网端口的状态不随VLAN接口状态的改变而改变。
# 将VLAN接口2关闭后再重新打开。
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
1.1.12  vlan
vlan vlan-id命令用来创建VLAN并进入VLAN视图。如果指定的VLAN已创建,则直接进入该VLAN的视图。
vlan vlan-id1 to vlan-id2命令用来批量创建vlan-id1~vlan-id2之间的所有VLAN,保留VLAN除外。
vlan all命令用来批量创建VLAN 1~VLAN 4094。
undo vlan命令用来删除VLAN。
vlan { vlan-id1 [ to vlan-id2 ] | all }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
系统只有一个缺省VLAN(VLAN 1)。
vlan-id1:VLAN的编号,取值范围为1~4094。
vlan-id1 to vlan-id2:指定VLAN的编号范围。vlan-id1和vlan-id2为VLAN的编号,取值范围为1~4094。vlan-id2的值要大于或等于vlan-id1的值。
all:除保留VLAN外的其他VLAN
·     VLAN 1为系统缺省VLAN,用户不能创建和删除。
·     保留VLAN是系统为实现特定功能预留的VLAN,用户也不能手工创建和删除。
·     动态学习到的VLAN、配置有QoS策略的VLAN、被其他应用锁定不让删除的VLAN,都不能使用undo vlan命令直接删除。只有将相关配置删除之后,才能删除相应的VLAN。
# 创建VLAN 2,并进入该VLAN视图。
[Sysname] vlan 2
[Sysname-vlan2]
# 批量创建VLAN 4~VLAN 100。
[Sysname] vlan 4 to 100
·     display vlan
1.2  基于端口的VLAN配置命令
1.2.1  display port
display port命令用来显示设备上当前存在的Hybrid或Trunk端口。显示的信息包括端口对应的端口名、缺省VLAN ID和允许通过的VLAN ID。
hybrid:显示系统当前存在的Hybrid端口。
trunk:显示系统当前存在的Trunk端口。
# 显示当前系统存在的Hybrid端口。
<Sysname> display port hybrid
Interface            PVID  VLAN Passing
FGE1/1/4             100   Tagged:  1000, 1002, 1500, 1600-1611, 2000,
                                    2555-2558, 3000, 4000
                           Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
                                    150-160, 200, 255, 286, 300-302
# 显示当前系统存在的Trunk端口。
<Sysname> display port trunk
FGE1/1/8             2     1-4, 6-100, 145, 177, 189-200, 244, 289, 400,
                           555, 600-611, 1000, 2006-2008
表1-4 display port命令显示信息描述表
接口名称
PVID
该端口的缺省VLAN ID
VLAN Passing
表示该端口实际通过的VLAN(该VLAN已经创建,并且接口允许其通过)
Tagged
表示哪些VLAN的报文通过该端口时必须携带VLAN Tag
Untagged
表示哪些VLAN的报文通过该端口时必须去掉VLAN Tag
1.2.2  port
port命令用来向当前VLAN中添加一个或一组Access端口。
undo port命令用来从当前VLAN中删除一个或一组Access端口。
port interface-list
undo port interface-list
系统将所有端口都加入到VLAN 1。
VLAN视图
interface-list:以太网接口列表。表示方式为interface-list = { interface-type interface-number1 [ to interface-type interface-number2 ] }&<1-10>,其中interface-type interface-number为端口类型和端口编号,interface-number2的值要大于或等于interface-number1的值,&<1-10>表示前面的参数最多可以输入10次。
·     通过本命令只能将Access端口加入到VLAN中,不能将Trunk和Hybrid端口加入到VLAN中。
·     设备上的所有端口的缺省链路类型都是Access类型,但用户可以自行切换端口类型,具体配置可参考命令port link-type。
# 向VLAN2中添加端口FortyGigE1/1/1~FortyGigE1/1/3。
[Sysname] vlan 2
[Sysname-vlan2] port fortygige 1/1/1 to fortygige 1/1/3
·     display vlan
port access vlan命令用来将当前Access端口加入到指定的VLAN中。
undo port access vlan命令用来恢复缺省情况。
port access vlan vlan-id
所有Access端口都属于VLAN 1。
二层以太网接口视图/二层聚合接口视图/S通道接口视图
vlan-id:指定的VLAN编号,取值范围为1~4094。该VLAN必须是设备上已创建的VLAN,否则,该命令执行失败。
·     在将Access端口加入到指定VLAN之前,该VLAN必须已经存在。
·     在二层以太网接口视图下执行该命令,则该配置只在当前接口下生效。
·     在二层聚合接口视图下执行该命令,则该配置将在二层聚合接口以及相应的所有成员端口下生效。在配置过程中,如果某个成员端口配置失败,系统会自动跳过该成员端口继续配置其他成员端口;如果二层聚合接口配置失败,则不会再配置成员端口。
·     在S通道接口视图下执行该命令,则该配置只在当前接口下生效。有关S通道接口的详细介绍,请参见“EVB配置指导”中的“EVB”。
# 将FortyGigE1/1/1端口加入到VLAN 3中。
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname] interface fortygige 1/1/1
[Sysname-FortyGigE1/1/1] port access vlan 3
port hybrid pvid命令用来配置Hybrid端口的缺省VLAN。
undo port hybrid pvid命令用来配置Hybrid端口的缺省VLAN为1。
port hybrid pvid vlan vlan-id
Hybrid端口的缺省VLAN为该端口在链路类型为Access时的所属VLAN。
vlan-id:指定接口的缺省的VLAN ID,取值范围为1~4094。
·     对Hybrid端口,执行undo vlan命令删除端口的缺省VLAN后,端口的缺省VLAN配置不会改变,即可以使用已经不存在的VLAN作为缺省VLAN。
·     建议本机Hybrid端口的缺省VLAN和相连的对端交换机的Hybrid端口的缺省VLAN保持一致。
·     配置缺省VLAN后,必须使用port hybrid vlan命令配置允许缺省VLAN的报文通过,出接口才能转发缺省VLAN的报文。
# 配置端口FortyGigE1/1/1(Hybrid类型)的缺省VLAN为100,并允许VLAN 100通过。
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-FortyGigE1/1/1] port link-type hybrid
[Sysname-FortyGigE1/1/1] port hybrid pvid vlan 100
[Sysname-FortyGigE1/1/1] port hybrid vlan 100 untagged
·     port hybrid vlan
·     port link-type
port hybrid vlan命令用来允许指定的VLAN通过当前Hybrid端口。
undo port hybrid vlan命令用来禁止指定的VLAN通过当前Hybrid端口。
undo port hybrid vlan vlan-id-list
Hybrid端口只允许该端口在链路类型为Access时的所属VLAN的报文以Untagged方式通过。
vlan-id-list:VLAN列表,Hybrid端口允许通过的VLAN范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。该VLAN必须是设备上已创建的VLAN,否则,该命令执行失败。
untagged:该端口在转发指定的VLAN报文时将去掉VLAN Tag。
·     Hybrid端口允许多个VLAN通过。如果多次使用port hybrid vlan命令,那么Hybrid端口上允许通过的VLAN是这些vlan-id-list的合集。
# 配置端口FortyGigE1/1/1为Hybrid类型,允许VLAN 2、VLAN 4、VLAN 50~VLAN 100通过,并且发送这些VLAN的报文时携带VLAN Tag。
[Sysname-FortyGigE1/1/1] port hybrid vlan 2 4 50 to 100 tagged
·     port link-type
port link-type命令用来配置当前端口的链路类型。
undo port link-type命令用来恢复缺省情况。
undo port link-type
所有端口的链路类型均为Access类型。
access:配置端口的链路类型为Access类型。
hybrid:配置端口的链路类型为Hybrid类型。
trunk:配置端口的链路类型为Trunk类型。
·     Trunk端口和Hybrid端口之间不能直接切换,只能先设为Access端口,再配置为其他类型端口。
# 将端口FortyGigE1/1/1配置为Trunk端口。
[Sysname-FortyGigE1/1/1] port link-type trunk
port trunk permit vlan命令用来允许指定的VLAN通过当前Trunk端口。
undo port trunk permit vlan命令用来禁止指定的VLAN通过当前Trunk端口。
undo port trunk permit vlan { vlan-id-list | all }
Trunk端口只允许VLAN 1的报文通过。
vlan-id-list:VLAN列表,Trunk端口允许通过的VLAN范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
all:表示允许所有VLAN通过该Trunk端口。建议用户谨慎使用port trunk permit vlan all命令,以防止未授权VLAN的用户通过该端口访问受限资源。
·     Trunk端口可以允许多个VLAN通过。如果多次执行port trunk permit vlan命令,那么Trunk端口上允许通过的VLAN是这些vlan-id-list的集合。
·     Trunk端口发送出去的报文,只有缺省VLAN的报文不带VLAN Tag,其他VLAN的报文均会保留VLAN Tag。
# 配置端口FortyGigE1/1/1为Trunk端口,允许VLAN 2、4、50~100通过。
[Sysname-FortyGigE1/1/1] port trunk permit vlan 2 4 50 to 100
·     port link-type
port trunk pvid命令用来配置Trunk端口的缺省VLAN。
undo port trunk pvid命令用来恢复缺省情况。
port trunk pvid vlan vlan-id
Trunk端口的缺省VLAN为VLAN 1。
vlan-id:指定接口的缺省VLAN ID,取值范围为1~4094。
·     对Trunk端口,执行undo vlan命令删除端口的缺省VLAN后,端口的缺省VLAN配置不会改变,即使用已经不存在的VLAN作为缺省VLAN。
·     本端设备Trunk端口的缺省VLAN ID和相连的对端设备的Trunk端口的缺省VLAN ID必须一致,否则报文将不能正确传输。
·     配置缺省VLAN后,必须使用port trunk permit vlan命令配置允许缺省VLAN的报文通过,出接口才能转发缺省VLAN的报文。
# 配置端口FortyGigE1/1/1(Trunk类型)的缺省VLAN为VLAN 100,并允许VLAN 100通过。
[Sysname-FortyGigE1/1/1] port trunk pvid vlan 100
[Sysname-FortyGigE1/1/1] port trunk permit vlan 100
·     port link-type
·     port trunk permit vlan
1.3  基于MAC的VLAN配置命令
display mac-vlan命令用来显示MAC VLAN表项。
display mac-vlan { all | dynamic | mac-address mac-address [ mask mac-mask ] | static | vlan vlan-id }
all:显示所有MAC VLAN表项。
dynamic:显示动态配置的MAC VLAN表项。
mac-address mac-address:按MAC地址显示MAC VLAN表项。
mask mac-mask:显示指定范围的MAC VLAN表项。
static:显示静态配置的MAC VLAN表项。
vlan vlan-id:显示指定VLAN的MAC VLAN表项。
# 显示所有MAC VLAN表项。
<Sysname> display mac-vlan all
The following MAC VLAN entries exist:
State: S - Static, D - Dynamic
MAC address        Mask                VLAN ID   Dot1q      State
0008-0001-0000     FFFF-FF00-0000      5         3           S
0002-0001-0000     FFFF-FFFF-FFFF      5         3           S&D
Total MAC VLAN entries count: 2
表1-5 display mac-vlan命令显示信息描述表
目前设备上存在以下MAC VLAN表项
S - Static
以下显示信息中,S表示静态配置的MAC VLAN
D - Dynamic
以下显示信息中,D表示动态配置的MAC VLAN
MAC address
配置的MAC VLAN的MAC地址
Mask
配置的MAC VLAN的MAC地址对应的掩码
VLAN ID
用户配置的MAC地址所对应的VLAN
Dot1q
用户配置的MAC地址所对应的802.1p优先级
该表项的属性,MAC VLAN表中的表项有三种属性:
·     S:表示该表项是通过用户静态配置生成的
·     D:表示该表项是通过认证功能自动生成的
·     S&D:表示该表项由静态和动态同时配置的
·     mac-vlan mac-address
display mac-vlan interface命令用来显示所有使能了MAC VLAN功能的接口。
# 显示所有使能了MAC VLAN功能的接口。
<Sysname> display mac-vlan interface
MAC VLAN is enabled on following ports:
·     mac-vlan enable
mac-vlan enable命令用来使能接口的MAC VLAN功能。
undo mac-vlan enable命令用来恢复缺省情况。
mac-vlan enable
接口没有使能MAC VLAN功能。
二层以太网接口视图
执行本命令时,需确保当前端口的链路类型为Hybrid。
# 使能接口FortyGigE1/1/1的MAC VLAN功能。
[Sysname–FortyGigE1/1/1] mac-vlan enable
·     display mac-vlan interface
mac-vlan mac-address命令用来配置MAC VLAN表项。
undo mac-vlan命令用来删除指定的MAC VLAN表项。
mac-vlan mac-address mac-address [ mask mac-mask ] vlan vlan-id [ dot1q pri ]
undo mac-vlan { all | mac-address mac-address [ mask mac-mask ] | vlan vlan-id }
未配置MAC VLAN表项。
mac-address mac-address:指定MAC地址。
mask mac-mask:指定MAC地址的掩码,二进制时高位必须为连续1,十六进制时高位必须为连续F。缺省十六进制值为全F。
vlan vlan-id:指定VLAN编号,取值为1~4094。
dot1q pri:指定MAC地址对应VLAN的802.1p优先级,取值为0~7,缺省值为0。
all:删除所有的静态MAC VLAN表项。
设备维护两张MAC VLAN表,一张是通过指定mask参数配置的MAC VLAN表,该表里的表项描述的是一类MAC地址和VLAN、优先级之间的关系;一张是不指定mask参数直接配置的MAC VLAN表,该表里的表项描述的是单个MAC地址和VLAN、优先级之间的关系。根据用户的配置,系统将自动在这两张MAC VLAN表里添加/删除MAC VLAN表项。
# 配置MAC地址0-1-1与VLAN 100的关联,并指定优先级为7。
[Sysname] mac-vlan mac-address 0-1-1 vlan 100 dot1q 7
# 配置前6位为1211-22的MAC地址与VLAN 100关联,优先级为4。
[Sysname] mac-vlan mac-address 1211-2222-3333 mask ffff-ff00-0000 vlan 100 dot1q 4
·     display mac-vlan
mac-vlan trigger enable命令用来使能MAC VLAN的动态触发功能。
undo mac-vlan trigger enable命令用来恢复缺省情况。
未使能MAC VLAN的动态触发功能。
二层以太网接口视图
使能MAC VLAN的动态触发功能后,系统将根据上送的报文的源MAC地址查询MAC VLAN表项来控制是否允许该报文进行转发,如果该报文的源MAC地址和系统中配置的Mask为全F的MAC VLAN表项匹配,则添加MAC地址表项并动态触发报文入接口接口加入对应VLAN,后续的报文可以正常进行转发。如果没有找到匹配表项或者只匹配了Mask非全F的MAC VLAN表项,均不会动态触发报文入接口接口加入对应VLAN。
# 接口FortyGigE1/1/1上配置MAC VLAN的动态触发功能。
[Sysname-FortyGigE1/1/1] mac-vlan trigger enable
·     port pvid forbidden
port pvid forbidden命令用来配置当报文源MAC地址与MAC VLAN表项的MAC地址不精确匹配时,禁止该报文在缺省VLAN内转发。
undo port pvid forbidden命令用来恢复缺省情况。
port pvid forbidden
对于没有精确匹配到MAC VLAN表项的报文会在缺省VLAN内进行转发。
二层以太网接口视图
该功能需要和MAC VLAN的动态触发功能配合使用。
# 在接口FortyGigE1/1/1上配置当报文源MAC地址不匹配MAC VLAN表项时,禁止该报文在缺省VLAN内转发。
[Sysname-FortyGigE1/1/1] port pvid forbidden
·     mac-vlan trigger enable
vlan precedence命令用来配置当前接口的VLAN匹配优先级。
undo vlan precedence命令用来恢复缺省情况。
vlan precedence { mac-vlan | ip-subnet-vlan }
对于基于MAC的VLAN和基于IP子网的VLAN,优先根据MAC地址来匹配VLAN。
二层以太网接口视图
mac-vlan:表示优先根据MAC地址来匹配VLAN。
ip-subnet-vlan:表示优先根据IP子网来匹配VLAN。
本命令只对基于MAC的VLAN和基于IP子网的VLAN有效。如果接口下同时使能了MAC VLAN和IP子网VLAN,则当接口收到报文后,会根据vlan precedence命令的配置情况来决定是优先根据MAC地址来匹配VLAN,还是优先根据IP子网来匹配VLAN。
当使用mac-vlan trigger enable命令使能MAC VLAN的动态触发功能后,建议用户在配置VLAN匹配优先级时,使用vlan precedence mac-vlan命令,使报文优先根据MAC地址来匹配VLAN;建议不要使用vlan precedence ip-subnet-vlan命令,使报文优先根据IP子网来匹配VLAN,该配置不能生效。
# 配置接口GigabitEthernt1/1/1优先根据MAC地址来匹配VLAN。
[Sysname-FortyGigE1/1/1] vlan precedence mac-vlan
1.4  基于IP子网的VLAN配置命令
display ip-subnet-vlan interface命令用于显示端口关联的子网VLAN的信息。
display ip-subnet-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
interface-type interface-number1:端口的类型和编号。
interface-type interface-number1 to interface-type interface-number2:端口的类型和范围。
all:显示所有端口关联的子网VLAN的信息。
# 显示端口FortyGigE1/1/1关联的子网VLAN的信息。
<Sysname> display ip-subnet-vlan interface fortygige1/1/1
 Interface: FortyGigE1/1/1
  VLAN ID   Subnet index    IP address       Subnet mask       Status
  3         0               192.168.1.0      255.255.255.0     Active
  4         N/A             N/A              N/A               Inactive
  4094      65535           172.16.1.1       255.255.0.0       Inactive
表1-6 display ip-subnet-vlan interface命令显示信息描述表
VLAN ID
子网VLAN的编号
Subnet index
IP子网的索引,N/A表示该VLAN下未配置任何子网VLAN
IP address
IP子网的地址,N/A表示该VLAN下未配置子网地址
Subnet mask
IP子网的掩码,N/A表示该VLAN下未配置子网掩码
Status
该子网VLAN在端口的生效情况:
·     Active:表示生效
·     Inactive:表示未生效(如子网VLAN配置未完成或端口未允许子网VLAN通过)
·     display ip-subnet-vlan vlan
·     ip-subnet-vlan
·     port hybrid ip-subnet-vlan
display ip-subnet-vlan vlan命令用于显示指定的或所有子网VLAN的信息。
display ip-subnet-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
vlan-id1:显示指定的子网VLAN的信息,vlan-id1表示VLAN的编号,取值范围为1~4094。
vlan-id1 to vlan-id2:显示指定VLAN范围内的子网VLAN的信息。vlan-id1和vlan-id2为指定VLAN的编号,取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值。
all:显示所有子网VLAN的信息。
# 显示所有子网VLAN的信息。
<Sysname> display ip-subnet-vlan vlan all
 VLAN ID: 3
表1-7 display ip-subnet-vlan vlan命令显示信息描述表
VLAN ID
子网VLAN的编号
Subnet index
IP子网的索引
IP address
IP子网的地址(可以是IP地址或网络地址)
Subnet mask
IP子网的掩码
·     display ip-subnet-vlan interface
·     ip-subnet-vlan
ip-subnet-vlan命令用来配置当前VLAN与指定的IP子网或IP地址关联。
undo ip-subnet-vlan命令用于取消当前VLAN与IP子网或IP地址的关联。
ip-subnet-vlan [ ip-subnet-index ] ip ip-address [ mask ]
undo ip-subnet-vlan { ip-subnet-index [ to ip-subnet-end ] | all }
VLAN没有与任何IP子网或IP地址关联。
VLAN视图
ip-subnet-index:IP子网索引值,取值范围为0~65535。子网索引可以由用户指定,也可由系统根据IP子网或IP地址与VLAN关联的先后顺序自动编号产生。
ip ip-address [ mask ]:作为子网VLAN划分依据的源IP地址或网络地址,ip-address表示源IP地址或网络地址,采用点分十进制格式;mask表示子网掩码,采用点分十进制格式,缺省值为255.255.255.0。
to ip-subnet-end:用来确定IP子网索引的范围。其中ip-subnet-end表示IP子网索引的终止值,取值范围为0~65535,其值必须大于或等于ip-subnet-index的值。
all:取消VLAN与所有IP子网或IP地址的关联。
VLAN关联的IP网段或IP地址不允许是组播网段或组播地址。
# 将VLAN 3配置为基于IP子网的VLAN,与192.168.1.0/24网段进行关联,使得源地址为该网段的报文可以在VLAN 3中传送。
[Sysname] vlan 3
[Sysname-vlan3] ip-subnet-vlan ip 192.168.1.0 255.255.255.0
·     display protocol-vlan interface
·     display protocol-vlan vlan
·     port hybrid protocol-vlan
port hybrid ip-subnet-vlan命令用来配置当前端口与子网VLAN关联。
undo port hybrid ip-subnet-vlan命令用于取消当前端口与子网VLAN的关联。
port hybrid ip-subnet-vlan vlan vlan-id
undo port hybrid ip-subnet-vlan { vlan vlan-id | all }
端口没有与任何子网VLAN关联。
二层以太网接口视图/二层聚合接口视图
vlan vlan-id:VLAN的编号,取值范围为1~4094。
all:所有VLAN。
执行本命令时,需保证当前端口的链路类型为Hybrid,并允许子网VLAN通过,且子网VLAN下存在与IP子网或IP地址关联的配置,该命令才实际生效。
# 将端口FortyGigE1/1/1与子网VLAN 3关联。
[Sysname] vlan 3
[Sysname-FortyGigE1/1/1] port hybrid vlan 3 untagged
[Sysname-FortyGigE1/1/1] port hybrid ip-subnet-vlan vlan 3
# 将二层聚合接口1与子网VLAN 3关联。
[Sysname] vlan 3
[Sysname-Bridge-Aggregation1] port link-type hybrid
[Sysname-Bridge-Aggregation1] port hybrid vlan 3 untagged
[Sysname-Bridge-Aggregation1] port hybrid ip-subnet-vlan vlan 3
·     ip-subnet-vlan
1.5  基于协议的VLAN配置命令
display protocol-vlan interface命令用于显示端口关联的协议VLAN的信息。
display protocol-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
all:显示所有端口关联的协议VLAN的信息。
# 显示端口FortyGigE1/1/1关联的协议VLAN的信息。
<Sysname> display protocol-vlan interface fortygige 1/1/1
  VLAN ID  Protocol index  Protocol type             Status
  2        0               IPv6                      Active
  2        1               N/A                       Inactive
  4094     65535           IPv4                      Inactive
表1-8 display protocol-vlan interface命令显示信息描述表
VLAN ID
协议VLAN的编号
Protocol index
协议模板索引号
Protocol type
该协议模板指定的协议类型,N/A表示该协议模板未指定协议类型
Status
该协议VLAN在端口的生效情况:
·     Active:表示生效
·     Inactive:表示未生效
·     protocol-vlan
display protocol-vlan vlan命令用于显示指定的或所有协议VLAN的信息。
display protocol-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
vlan-id1:显示指定的协议VLAN的信息,vlan-id1表示VLAN的编号,取值范围为1~4094。
vlan-id1 to vlan-id2:显示指定VLAN范围内的协议VLAN的信息。vlan-id1和vlan-id2为指定VLAN的编号,取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值。
all:显示所有协议VLAN的信息。
# 显示所有协议VLAN的信息。
<Sysname> display protocol-vlan vlan all
 VLAN ID: 2
  0               IPv4
  65535           IPv6
 VLAN ID: 3
  0               IPv4
  65535           LLC DSAP 0x11 SSAP 0x22
表1-9 display protocol-vlan vlan命令显示信息描述表
VLAN ID
协议VLAN的编号
Protocol index
协议模板索引号
Protocol type
该协议模板所指定的协议类型或封装格式
·     protocol-vlan
port hybrid protocol-vlan命令用来配置当前端口与协议VLAN关联。
undo port hybrid protocol-vlan命令用于取消当前端口与协议VLAN的关联。
port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-end ] | all }
undo hybrid protocol-vlan { vlan vlan-id { protocol-index [ to protocol-end ] | all } | all }
端口没有与任何协议VLAN关联。
二层以太网接口视图/二层聚合接口视图
protocol-index:协议模板索引,取值范围为0~65535
to protocol-end:指定协议模板索引的范围。protocol-end为协议模板索引终止值,取值范围为0~65535,其值必须大于或等于protocol-index的值。
all:所有协议模板。
·     执行本命令时,需确保当前端口的链路类型为Hybrid,并允许协议VLAN通过,且协议VLAN下存在与协议模板关联的配置,本命令才实际生效。
·     在执行undo port hybrid protocol-vlan命令时,如果同时指定vlan-id和all,则表示取消当前端口与指定VLAN下绑定的所有协议模板的关联;如果仅指定all,则表示取消当前端口与所有VLAN下绑定的所有协议模板的关联。
# 配置端口FortyGigE1/1/1与协议VLAN 2中的协议模板1关联。
[Sysname] vlan 2
[Sysname-vlan2] protocol-vlan 1 ipv4
[Sysname-FortyGigE1/1/1] port hybrid vlan 2 untagged
[Sysname-FortyGigE1/1/1] port hybrid protocol-vlan vlan 2 1
# 配置二层聚合接口1与协议VLAN 2中的协议模板1关联。
[Sysname] vlan 2
[Sysname-Bridge-Aggregation1] port hybrid vlan 2 untagged
[Sysname-Bridge-Aggregation1] port hybrid protocol-vlan vlan 2 1
1.5.4  protocol-vlan
protocol-vlan命令用来配置当前VLAN与指定的协议模板关联。
undo protocol-vlan命令用于取消当前VLAN与协议模板的关联。
protocol-vlan [ protocol-index ] { at | ipv4 | ipv6 | ipx { ethernetii | llc | snap } | mode { ethernetii etype etype-id | llc { dsap dsap-id [ ssap ssap-id ] | ssap ssap-id } | snap etype etype-id } }
undo protocol-vlan { protocol-index [ to protocol-end ] | all }
VLAN没有与任何协议模板关联。
VLAN视图
at:基于AT(AppleTalk,Apple计算机网络协议)协议的VLAN。
ipv4:基于IPv4协议的VLAN。
ipv6:基于IPv6协议的VLAN。
ipx:基于IPX协议的VLAN,可包括ethernetii、llc和snap三种封装类型。
mode:配置自定义协议模板,可包括ethernetii、llc和snap三种封装类型。
ethernetii etype etype-id:匹配Ethernet II封装格式及相应的协议类型值。其中,etype-id表示入报文的协议类型值,取值范围为0x0600~0xFFFF(不包括0x0800、0x809B、0x8137和0x86DD)。
llc:匹配LLC封装格式。
dsap dsap-id:目的服务接入点,取值范围为0x00~0xFF。
ssap ssap-id:源服务接入点,取值范围为0x00~0xFF。
snap etype etype-id:匹配SNAP封装格式及相应的协议类型值。其中,etype-id表示入报文的以太网类型,取值范围为0x0600~0xFFFF(不包括0x8137)。
protocol-index:协议索引,用来标识与当前VLAN绑定的协议模版,取值范围为0~65535。如果不指定该参数,则系统会自动分配一个索引值。
to protocol-end:用来确定协议索引的范围。其中protocol-end表示协议索引终止值,取值范围为0~65535,其值必须大于或等于protocol-index的值。
all:与当前VLAN绑定的所有协议。
·     由于IPv4协议与ARP协议关系密切,建议用户将IPv4协议和ARP协议绑定到同一VLAN,并且关联到相同的端口,避免因ARP报文与IPv4报文未划分到同一VLAN,而造成无法正常通信的情况。
·     使用mode ethernetii etype关键字进行配置时,不允许将etype-id的值配置为0x0800、0x809B、0x8137或0x86DD,因为上述取值分别与IPv4、AppleTalk、IPX和IPv6协议模板相同。
·     使用mode llc关键字进行配置时,dsap-id和ssap-id的值不允许同时为0xE0(代表IPX报文的LLC封装格式)、0xFF(代表IPX报文的raw封装格式)、0xAA(代表SNAP封装格式),如果只配置了dsap-id和ssap-id中的一个,系统会将另一参数的值自动配置为0xAA。
·     使用mode snap etype关键字进行配置时,不允许将etype-id的值配置为0x8137,因为该值与IPX协议协议模板相同。当etype-id的值取0x0800、0x809B或0x86DD时,其对应的协议模板分别为IPv4、AppleTalk和IPv6。
# 将IPv4报文和采用Ethernet II封装格式的ARP报文(ARP协议的协议代码为0x0806)划分到VLAN 3中传输。
[Sysname] vlan 3
[Sysname-vlan3] protocol-vlan 1 ipv4
[Sysname-vlan3] protocol-vlan 2 mode ethernetii etype 0806
·     port protocol-vlan
1.6  VLAN组配置命令
display vlan-group命令用来显示创建的VLAN组及其VLAN成员列表。
display vlan-group [ group-name ]
group-name:VLAN组的名称,为1~31个字符的字符串,区分大小写,首字符必须为字母。若不指定该参数,则表示显示所有VLAN组的信息。
# 显示指定VLAN组test001的信息。
<Sysname> display vlan-group test001
VLAN group: test001
     VLAN list: 2-4 100 200
# 显示所有VLAN组的信息。
VLAN group: test001
VLAN group: rnd
     VLAN list: Null
表1-10 display vlan-group命令显示信息描述表
VLAN group
VLAN组名称
VLAN list
对应的该VLAN组内的VLAN列表
·     vlan-group
·     vlan-list
1.6.2  vlan-group
vlan-group命令用来创建一个VLAN组,并进入VLAN组视图。
undo vlan-group命令用来删除指定的VLAN组。
vlan-group group-name
undo vlan-group group-name
不存在任何VLAN组。
·     VLAN组是一组VLAN的集合。VLAN组内可以添加多个VLAN列表。
·     认证服务器可以通过下发VLAN组名的方式为通过认证的802.1X用户下发一组授权VLAN。
# 创建一个VLAN组,名称为test001,并进入VLAN组视图。
[Sysname] vlan-group test001
[Sysname-vlan-group-test001]
·     vlan-list
1.6.3  vlan-list
vlan-list命令用来在当前VLAN组内添加VLAN成员。
undo vlan-list命令用来从当前VLAN组内删除VLAN成员。
vlan-list vlan-id-list
undo vlan-list vlan-id-list
当前VLAN组中不存在任何VLAN成员。
VLAN组视图
vlan-id-list:VLAN列表。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
# 向VLAN组test001内添加VLAN成员:VLAN 2~VLAN 4、VLAN 100、VLAN 200。
[Sysname-vlan-group-test001] vlan-list 2 to 4 100 200
·     vlan-group
2 Super VLAN
2.1  Super VLAN配置命令
display supervlan命令用来显示Super VLAN及其关联的Sub VLAN的信息。
display supervlan [ supervlan-id ]
supervlan-id:Super VLAN的编号,取值范围为1~4094。如果未指定该参数,则显示设备上所有的Super VLAN及其关联的Sub VLAN的信息。
# 显示Super VLAN 2及其关联的Sub VLAN的信息。
<Sysname> display supervlan 2
 Super VLAN ID: 2
 Sub-VLAN ID: 3-5
 VLAN ID: 2
 VLAN type: Static
 It is a super VLAN.
 IPv4 address: 10.153.17.41
 IPv4 subnet mask: 255.255.252.0
 IPv6 global unicast addresses:
   2001::1, subnet is 2001::/64 [TENTATIVE]
 Tagged ports:   None
 VLAN ID: 3
 VLAN type: Static
 It is a sub-VLAN.
 Tagged   ports: None
 Untagged ports:
    FortyGigE1/1/3
 VLAN ID: 4
 VLAN type: Static
 It is a sub-VLAN.
 Description: VLAN 0004
 Tagged ports: None
 Untagged ports:
    FortyGigE1/1/4
表2-1 display supervlan命令显示信息描述表
Super VLAN ID
Super VLAN的编号
Sub-VLAN ID
Sub VLAN的编号
VLAN ID
VLAN编号
VLAN type
VLAN类型:
·     Dynamic:动态VLAN
·     Static:静态VLAN
It is a super VLAN
当前VLAN是Super VLAN
It is a sub-VLAN
当前VLAN是Sub VLAN
Route interface
设备上是否创建了对应的VLAN接口:
·     Configured:已创建
IPv4 address
VLAN接口的主用IPv4地址(如果VLAN接口没有配置IPv4地址,则不显示该字段),如果VLAN接口上还配置了从IPv4地址,可以使用display interface vlan-interface或者在VLAN接口视图下使用display this命令查看
IPv4 subnet mask
VLAN接口的主用IPv4地址的子网掩码(如果VLAN接口没有配置IPv4地址,则不显示该字段)
VLAN接口上配置的全球单播IPv6地址(如果VLAN接口没有配置IPv6地址,则不显示该字段)
可能的IPv6地址状态及含义如下:
·     [TENTATIVE]:该状态为地址初始化状态,此时该地址可能正在进行DAD检测或准备进行DAD检测,处于该状态的地址不能作为报文的源地址或者目的地址
·     [DUPLICATE]:该状态表明地址DAD检测已经结束,由于该地址在链路上不唯一,因此不能使用
·     [PREFERRED]:该状态表明地址处于首选生命期以内。该状态的地址可以作为报文的源地址或者目的地址。为该状态时,不显示地址的状态标识
·     [DEPRECATED]:该状态表明地址超过首选生命期,但是在有效生命期以内。该状态地址有效,但不应作为新建连接报文的源地址,目的地址是该地址的报文还可以被正常处理
VLAN的描述信息
Name
VLAN的名称
Tagged ports
该VLAN报文从哪些端口发送需要携带VLAN Tag
Untagged ports
该VLAN报文从哪些端口发送时不需要携带VLAN Tag
·     subvlan
·     supervlan
2.1.2  subvlan
subvlan命令用来建立Super VLAN和Sub VLAN的映射关系。
undo subvlan命令用来解除Super VLAN和Sub VLAN的映射关系。
subvlan vlan-id-list
undo subvlan [ vlan-id-list ]
未建立Super VLAN和Sub VLAN的映射关系。
VLAN视图
vlan-id-list:Sub VLAN列表,表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>。其中,vlan-id表示Sub VLAN的VLAN ID,取值范围为1~4094。&<1-10>表示前面的参数最多可以重复输入10次。
·     建立Super VLAN和Sub VLAN的映射关系前,指定的Sub VLAN必须已经创建。
·     在建立了Super VLAN和Sub VLAN的映射关系后,仍可以向Sub VLAN中添加和删除接口。
·     使用undo subvlan命令时,如果不指定vlan-id-list,则解除当前Super VLAN与所有Sub VLAN的映射关系;如果指定vlan-id-list,则解除当前Super VLAN与指定Sub VLAN的映射关系。
# 建立Super VLAN 10和Sub VLAN 3、4、5、9的映射关系。
[Sysname] vlan 10
[Sysname-vlan10] supervlan
[Sysname-vlan10] subvlan 3 to 5 9
·     display supervlan
·     supervlan
2.1.3  supervlan
supervlan命令用来配置当前VLAN的类型为Super VLAN。
undo supervlan命令用来恢复缺省情况。
supervlan
undo supervlan
VLAN类型不为Super VLAN。
VLAN视图
·     如果某个VLAN被指定为Super VLAN,则该VLAN不能被指定为某个端口的Guest VLAN/Auth-Fail VLAN/Critical VLAN;同样,如果某个VLAN被指定为某个端口的Guest VLAN/Auth-Fail VLAN/Critical VLAN,则该VLAN不能被指定为Super VLAN。关于Guest VLAN/Auth-Fail VLAN/Critical VLAN的相关内容请参见“安全配置指导”中的“802.1X”。
·     在Super VLAN下可以配置二层组播功能,但是由于Super VLAN中没有物理端口,该配置将不会生效。
·     在Super VLAN对应的VLAN接口下配置VRRP功能后,会对网络性能造成影响,建议不要这样配置。
# 配置VLAN 2为Super VLAN。
[Sysname] vlan 2
[Sysname-vlan2] supervlan
·     display supervlan
·     subvlan
3 Private VLAN
display private-vlan命令用来显示Primary VLAN和其包含的Secondary VLAN的信息。
display private-vlan [ primary-vlan-id ]
primary-vlan-id:Primary VLAN的编号,取值范围为1~4094。如果未指定该参数,则显示所有Primary VLAN和其对应的Secondary VLAN的映射信息。
# 显示所有Primary VLAN和其包含的Secondary VLAN的信息。
<Sysname> display private-vlan
 Primary VLAN ID: 2
 Secondary VLAN ID: 3-4
 VLAN ID: 2
 VLAN type: Static
 Private VLAN type: Primary
 Tagged   ports: None
 Untagged ports:
    FortyGigE1/1/2            FortyGigE1/1/3            FortyGigE1/1/4
 VLAN ID: 3
 VLAN type: Static
 Private VLAN type: Secondary
 Tagged   ports: None
 Untagged ports:
 VLAN ID: 4
 VLAN type: Static
 Tagged   ports: None
 Untagged ports:
    FortyGigE1/1/2            FortyGigE1/1/4
表3-1 display private-vlan命令显示信息描述表
Primary VLAN ID
Primary VLAN的编号
Secondary VLAN ID
Secondary VLAN的编号
VLAN ID
VLAN编号
VLAN type
VLAN类型:
·     Dynamic:动态VLAN
·     Static:静态VLAN
Private VLAN type
Private VLAN类型:
·     Primary:表示Primary VLAN
·     Secondary:表示Secondary VLAN
·     Isolated secondary:表示配置了各端口二层隔离的Secondary VLAN
Route interface
设备上是否创建了对应的VLAN接口:
·     Configured:已创建
IPv4 address
IPv4 subnet mask
可能的IPv6地址状态及含义如下:
·     PREFERRED]:该状态表明地址处于首选生命期以内。该状态的地址可以作为报文的源地址或者目的地址。为该状态时,不显示地址的状态标识
VLAN的描述信息
Name
VLAN的名称
Tagged   ports
Untagged ports
·     private-vlan(VLAN view)
·     private-vlan primary
port private-vlan host命令用来配置端口工作在host模式。
undo port private-vlan命令用来恢复缺省情况。
端口不工作在host模式。
二层以太网接口视图/二层聚合接口视图
port private-vlan host命令配置端口工作在host模式时,若端口已经加入了Secondary VLAN,则端口也会同步加入和Secondary VLAN有映射关系的Primary VLAN。
undo port private-vlan命令恢复缺省情况时,端口的VLAN属性(包括端口加入VLAN以及端口的链路类型、端口缺省VLAN)不做改变。
·     在执行port private-vlan host命令时,当端口同步加入Primary VLAN,若此前端口的链路类型为Access类型,则会配置端口的链路类型为Hybrid类型,缺省VLAN为端口加入的Secondary VLAN;若此前端口的链路类型为Trunk/Hybrid类型,则端口的链路类型及缺省VLAN不做改变。
·     在执行port private-vlan host命令时,当端口的链路类型最终为Hybrid类型,端口同步加入Primary VLAN时,若此前端口有以Tagged/Untagged方式加入Primary VLAN的配置,则保持原有配置;否则端口会以Untagged方式加入Primary VLAN。
·     可以在执行完port private-vlan host命令后,再配置端口加入Secondary VLAN,此时,该命令的功能依然生效。
·     port private-vlan host命令与port private-vlan trunk promiscuous及port private-vlan trunk secondary命令互斥。
VLAN 20的类型为Secondary VLAN,且VLAN 20和Primary VLAN 2关联。配置链路类型为Access的端口FortyGigE1/1/1工作在host模式,将端口FortyGigE1/1/1加入VLAN 20。
# 配置链路类型为Access的端口FortyGigE1/1/1工作在host模式。
[Sysname-FortyGigE1/1/1] port private-vlan host
[Sysname-FortyGigE1/1/1] display this
interface FortyGigE1/1/1
 port link-mode bridge
return
# 将端口FortyGigE1/1/1加入VLAN 20。
[Sysname-FortyGigE1/1/1] port access vlan 20
# 显示端口FortyGigE1/1/1当前配置,可以看出当端口FortyGigE1/1/1工作在host模式,且加入Secondary VLAN 20时,该端口会同步加入关联的Primary VLAN 2,同时修改链路类型及缺省VLAN。
 undo port hybrid vlan 1
 port hybrid vlan 2 20 untagged
 port hybrid pvid vlan 20
return
·     port private-vlan promiscuous
·     port private-vlan trunk promiscuous
·     port private-vlan trunk secondary
port private-vlan promiscuous命令用来配置端口在指定VLAN中工作在promiscuous模式。
port private-vlan vlan-id promiscuous
端口在指定VLAN中不工作在promiscuous模式。
二层以太网接口视图/二层聚合接口视图
vlan-id:VLAN的编号,取值范围为1~4094。其中,VLAN 1虽然在取值范围中,但不能配置。
port private-vlan promiscuous命令同时会将端口加入指定VLAN。此时若指定VLAN的类型为Primary VLAN,且存在和指定VLAN有映射关系的Secondary VLAN,则端口也会同步加入这些Secondary VLAN。
undo port private-vlan命令恢复缺省情况时,端口的VLAN属性(包括端口加入Secondary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
·     在执行port private-vlan promiscuous命令时,若此前端口的链路类型为Access类型,则会配置端口的链路类型为Hybrid类型,缺省VLAN为指定VLAN;若此前端口的链路类型为Trunk/Hybrid类型,则端口的链路类型及缺省VLAN不做改变。
·     在执行port private-vlan promiscuous命令时,当端口的链路类型最终为Hybrid类型,端口加入对应VLAN(包括指定VLAN及同步加入的Secondary VLAN)时,若端口此前存在以Tagged/Untagged方式加入某些对应VLAN的配置,则在保持原有配置的基础上,端口会以Untagged方式加入其他对应VLAN;否则端口会以Untagged方式加入所有对应VLAN。即自动产生的以Untagged方式加入VLAN的配置不会覆盖原有以Tagged/Untagged加入VLAN的配置。
·     在执行port private-vlan promiscuous命令时,若端口已配置promiscuous模式,则系统会自动先执行undo port private-vlan命令,再执行port private-vlan promiscuous命令。
·     在执行undo port private-vlan命令时,若端口已配置在某VLAN中工作在promiscuous模式,则取消端口加入该VLAN的配置。
·     可以在执行完port private-vlan promiscuous命令后,再配置指定VLAN的类型为Primary VLAN,此时,该命令的功能依然生效。
·     port private-vlan promiscuous命令与port private-vlan trunk promiscuous及port private-vlan trunk secondary命令互斥。
VLAN 2的类型为Primary VLAN,且VLAN 2和Secondary VLAN 20关联。配置链路类型为Access的端口FortyGigE1/1/1在VLAN 2中工作在promiscuous模式,然后取消该配置。
# 配置链路类型为Access的端口FortyGigE1/1/1在VLAN 2中工作在promiscuous模式。
return
[Sysname-FortyGigE1/1/1] port private-vlan 2 promiscuous
# 显示端口FortyGigE1/1/1当前配置,可以看出当该端口在VLAN 2中工作在promiscuous模式时,该端口会加入Primary VLAN 2及关联的Secondary VLAN 20,同时修改端口的链路类型及缺省VLAN。
return
# 取消端口FortyGigE1/1/1的promiscuous模式配置。
[Sysname-FortyGigE1/1/1] undo port private-vlan
# 显示端口FortyGigE1/1/1当前配置,可以看出该端口退出Primary VLAN 2,但该端口的VLAN属性(包括端口加入Secondary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
 port hybrid vlan 20 untagged
return
port private-vlan trunk promiscuous命令用来配置端口在指定VLAN中工作在trunk promiscuous模式。
undo port private-vlan trunk promiscuous命令用来配置端口在指定VLAN退出trunk promiscuous模式。
port private-vlan vlan-id-list trunk promiscuous
undo port private-vlan vlan-id-list trunk promiscuous
端口在指定VLAN中不工作在trunk promiscuous模式。
二层以太网接口视图/二层聚合接口视图
vlan-id-list:VLAN列表,Primary VLAN的范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。其中,系统缺省VLAN(VLAN 1)虽然在取值范围中,但不能配置。
port private-vlan trunk promiscuous命令用来配置端口在指定VLAN中工作在trunk promiscuous模式(同时将端口加入指定VLAN)。此时若指定VLAN的类型为Primary VLAN,且存在和指定VLAN有映射关系的Secondary VLAN,则端口也会同步加入这些Secondary VLAN。
undo port private-vlan trunk promiscuous命令用来配置端口在指定VLAN中退出trunk promiscuous模式,但端口的VLAN属性(包括端口加入Secondary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
·     在执行port private-vlan trunk promiscuous命令时,若此前端口的链路类型为Access类型,则会配置端口的链路类型为Hybrid类型,缺省VLAN不做改变;若此前端口的链路类型为Trunk/Hybrid类型,则端口的链路类型及缺省VLAN不做改变。
·     在执行port private-vlan trunk promiscuous命令时,当端口的链路类型最终为Hybrid类型,端口加入对应VLAN(包括指定VLAN及同步加入的Secondary VLAN)时,若端口此前存在以Tagged/Untagged方式加入某些对应VLAN的配置,则在保持原有配置的基础上,端口会以Tagged方式加入其他对应VLAN;否则端口会以Tagged方式加入所有对应VLAN。即自动产生的以Tagged方式加入VLAN的配置不会覆盖原有以Tagged/Untagged加入VLAN的配置。
·     在执行undo port private-vlan trunk promiscuous命令时,若已配置端口在vlan-id-list中工作在trunk promiscuous模式,则取消端口加入vlan-id-list的配置。
·     可以在执行完port private-vlan trunk promiscuous命令后,再配置指定VLAN的类型为Primary VLAN,此时,该命令的功能依然生效。
·     port private-vlan trunk promiscuous命令与port private-vlan promiscuous、port private-vlan trunk secondary及port private-vlan host命令互斥。
port private-vlan trunk promiscuous命令适用于需要多个Primary VLAN通过上行端口的情况,配置该命令后多个Primary VLAN携带Tag通过上行端口。port private-vlan promiscuous适用于只有一个Primary VLAN通过上行端口的情况,配置该命令后Primary VLAN不带Tag通过上行端口。
VLAN 2、3的类型为Primary VLAN,且VLAN 2和Secondary VLAN 20关联,VLAN 3和Secondary VLAN 30关联。配置链路类型为Access的端口FortyGigE1/1/1在VLAN 2、3中工作在trunk promiscuous模式,然后取消该配置。
# 配置链路类型为Access的端口FortyGigE1/1/1在VLAN 2、3中工作在trunk promiscuous模式。
return
[Sysname-FortyGigE1/1/1] port private-vlan 2 3 trunk promiscuous
# 显示端口FortyGigE1/1/1当前配置,可以看出当该端口在VLAN 2、3中工作在trunk promiscuous模式时,该端口会加入Primary VLAN 2、3及关联的Secondary VLAN 20、30,同时修改端口的链路类型。
 port hybrid vlan 2 3 20 30 tagged
 port hybrid vlan 1 untagged
return
# 取消端口FortyGigE1/1/1在VLAN 2、3中的trunk promiscuous模式配置。
[Sysname-FortyGigE1/1/1] undo port private-vlan 2 3 trunk promiscuous
# 显示端口FortyGigE1/1/1当前配置,可以看出该端口退出Primary VLAN 2、3,但该端口的VLAN属性(包括端口加入Secondary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
 port hybrid vlan 20 30 tagged
return
port private-vlan trunk secondary命令用来配置端口在指定VLAN中工作在trunk secondary模式。
undo port private-vlan trunk secondary命令用来配置端口在指定VLAN退出trunk secondary模式。
port private-vlan vlan-id-list trunk secondary
undo port private-vlan vlan-id-list trunk secondary
端口在指定VLAN中不工作在trunk secondary模式。
二层以太网接口视图/二层聚合接口视图
vlan-id-list:VLAN列表,Secondary VLAN的范围。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。其中,系统缺省VLAN(VLAN 1)虽然在取值范围中,但不能配置。
port private-vlan trunk secondary命令用来配置端口在指定VLAN中工作在trunk secondary模式(同时将端口加入指定VLAN)。此时若指定VLAN的类型为Secondary VLAN,且存在和指定VLAN有映射关系的Primary VLAN,则端口也会同步加入这些Primary VLAN。
undo port private-vlan trunk secondary命令将指定VLAN退出trunk secondary模式,但端口的VLAN关系(包括端口加入Primary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
·     工作在trunk secondary模式的端口,对于一个Primary VLAN对应的Secondary VLAN,只能加入其中的一个,但可以分别加入多个Primary VLAN对应的多个Secondary VLAN。
·     在执行port private-vlan trunk secondary命令时,当端口同步加入Primary VLAN,若此前端口的链路类型为Access类型,则会配置端口的链路类型为Hybrid类型,缺省VLAN不做改变;若此前端口的链路类型为Trunk/Hybrid类型,则端口的链路类型及缺省VLAN不做改变。
·     在执行port private-vlan trunk secondary命令时,当端口的链路类型最终为Hybrid类型,端口加入对应VLAN(包括指定VLAN及同步加入的Primary VLAN)时,若端口此前存在以Tagged/Untagged方式加入某些对应VLAN的配置,则在保持原有配置的基础上,端口会以Tagged方式加入其他对应VLAN;否则端口会以Tagged方式加入所有对应VLAN。即自动产生的以Tagged方式加入VLAN的配置不会覆盖原有以Tagged/Untagged加入VLAN的配置。
·     在执行undo port private-vlan trunk secondary命令时,若端口的链路类型为Access类型,则端口加入指定VLAN的配置不做改变;若端口的链路类型为Trunk/Hybrid类型,则取消端口加入指定VLAN的配置。
·     可以在执行完port private-vlan trunk secondary命令后,再配置指定VLAN的类型为Secondary VLAN,此时,该命令的功能依然生效。
·     在执行port private-vlan trunk secondary命令时,若其中vlan-id-list中部分VLAN不满足要求(比如指定VLAN不存在,指定VLAN的类型为除Secondary VLAN外的其他特殊类型VLAN,本端口已经在指定VLAN对应Primary VLAN下的其他Secondary VLAN中工作在trunk secondary模式等),则本命令只在其他满足要求的VLAN中生效。
·     port private-vlan trunk secondary命令与port private-vlan host、port private-vlan promiscuous及port private-vlan trunk promiscuous命令互斥。
port private-vlan trunk secondary命令适用于需要多个Secondary VLAN(分别对应不同的Primary VLAN)通过下行端口的情况,配置该命令后多个Secondary VLAN携带Tag通过下行端口。port private-vlan host命令适用于只有一个Secondary VLAN通过下行端口的情况,配置该命令后Secondary VLAN不带Tag通过下行端口。
VLAN 2、3的类型为Primary VLAN,且VLAN 2和Secondary VLAN 20关联,VLAN 3和Secondary VLAN 30关联,配置VLAN 20、30在链路类型为Access的端口FortyGigE1/1/1工作在trunk secondary模式,然后取消该配置。
# 配置链路类型为Access的端口FortyGigE1/1/1在VLAN 20、30中工作在trunk secondary模式。
return
[Sysname-FortyGigE1/1/1] port private-vlan 20 30 trunk secondary
# 显示端口FortyGigE1/1/1当前配置,可以看出当该端口在VLAN 20、30中工作在trunk secondary模式时,该端口会加入Secondary VLAN 20、30及关联的Primary VLAN 2、3,同时修改链路类型。
return
# 取消端口FortyGigE1/1/1在VLAN 20、30中的trunk secondary模式配置。
[Sysname-FortyGigE1/1/1] undo port private-vlan 20 30 trunk secondary
# 显示端口FortyGigE1/1/1当前配置,可以看出该端口退出Secondary VLAN 20、30,但该端口的VLAN属性(包括端口加入Primary VLAN以及端口的链路类型、缺省VLAN的配置)不做改变。
 port hybrid vlan 2 3 tagged
return
VLAN 10的类型不为Secondary VLAN。配置链路类型为Access的端口FortyGigE1/1/1在VLAN 10中工作在trunk secondary模式,然后取消该配置。
# 配置链路类型为Access的端口FortyGigE1/1/1在VLAN 10中工作在trunk secondary模式。
return
[Sysname-FortyGigE1/1/1] port private-vlan 10 trunk secondary
# 显示端口FortyGigE1/1/1当前配置,可以看出该端口在VLAN 10中工作在trunk secondary模式时,该端口会加入Secondary VLAN 10,同时修改链路类型。
 port hybrid vlan 10 tagged
return
# 取消端口FortyGigE1/1/1在VLAN 10中的trunk secondary模式配置。
[Sysname-FortyGigE1/1/1] undo port private-vlan 10 trunk secondary
# 显示端口FortyGigE1/1/1当前配置,可以看出该端口退出VLAN 10,但该端口的VLAN属性(包括端口的链路类型、缺省VLAN的配置)不做改变。
return
·     private-vlan isolated
private-vlan secondary命令用来配置当前Primary VLAN下指定的Secondary VLAN间三层互通。
undo private-vlan用来取消当前Primary VLAN下指定的或所有的Secondary VLAN间三层互通。
private-vlan secondary vlan-id-list
undo private-vlan [ secondary vlan-id-list ]
Secondary VLAN间三层不互通。
VLAN接口视图
·     该命令只能在Primary VLAN对应的VLAN接口(Primary VLAN interface)视图下执行,且Secondary VLAN必须已经与该对应的Primary VLAN建立了映射关系,同时要求Secondary VLAN不能建立对应的VLAN接口。要使功能生效,还需要在该三层虚接口上配置IP地址和本地代理ARP/ND功能。
·     没有配置三层互通的Secondary VLAN可以创建对应的VLAN接口,配置了三层互通的Secondary VLAN不能创建对应的VLAN接口。
·     在同一Primary VLAN interface下多次执行本命令时,最终生效结果是多次配置的集合。
·     在执行undo private-vlan命令时,如果不带参数secondary vlan-id-list,就解除所有Secondary VLAN间的三层互通;如果带有该参数,就解除指定的Secondary VLAN间的三层互通。
配置Primary VLAN 2下的Secondary VLAN 3、4三层互通(FortyGigE1/1/2为上行端口,FortyGigE1/1/3、FortyGigE1/1/4为下行端口)。
# 建立Primary VLAN 2和Secondary VLAN 3、4的映射关系。
[Sysname] vlan 2
[Sysname-vlan2] private-vlan primary
[Sysname-vlan2] private-vlan secondary 3 to 4
# 配置端口FortyGigE1/1/2在VLAN 2中工作在promiscuous模式。
[Sysname] interface fortygige 1/1/2
[Sysname-FortyGigE1/1/2] port private-vlan 2 promiscuous
[Sysname-FortyGigE1/1/2] quit
# 配置链路类型为Access的端口FortyGigE1/1/3在VLAN 3中工作在host模式,链路类型为Access的端口FortyGigE1/1/4在VLAN 4中工作在host模式。
[Sysname] interface fortygige 1/1/3
[Sysname-FortyGigE1/1/3] port access vlan 3
[Sysname-FortyGigE1/1/3] port private-vlan host
[Sysname-FortyGigE1/1/3] quit
[Sysname] interface fortygige 1/1/4
[Sysname-FortyGigE1/1/4] port access vlan 4
[Sysname-FortyGigE1/1/4] port private-vlan host
[Sysname-FortyGigE1/1/4] quit
# 配置Primary VLAN 2下的Secondary VLAN 3、4三层互通,同时配置Primary VLAN接口的IP地址及开启本地代理ARP功能。
[Sysname-Vlan-interface2] private-vlan secondary 3 to 4
[Sysname-Vlan-interface2] ip address 192.168.1.1 255.255.255.0
[Sysname-Vlan-interface2] local-proxy-arp enable
private-vlan命令用来建立Primary VLAN和Secondary VLAN的映射关系。
undo private-vlan用来解除Primary VLAN和Secondary VLAN的映射关系。
未建立Primary VLAN和Secondary VLAN的映射关系。
VLAN视图
secondary vlan-id-list:表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。其中,系统缺省VLAN(VLAN 1)虽然在取值范围中,但不能配置。
·     Primary VLAN可以与多个Secondary VLAN建立映射关系。在同一VLAN视图下多次执行private-vlan命令时,Primary VLAN对应的Secondary VLAN是多次配置的集合。
·     在执行private-vlan命令时,若已经配置Primary VLAN,且设备上有端口工作在promiscuous模式、trunk promiscuous模式或host模式,则依据接口配置会触发配置同步。具体内容请参见port private-vlan promiscuous、port private-vlan trunk promiscuous和port private-vlan host命令的相关介绍。
·     在执行undo private-vlan命令时,如果不带参数secondary vlan-id-list,就解除所有Secondary VLAN和对应Primary VLAN的映射关系;如果带有该参数,就解除参数指定的Secondary VLAN和对应Primary VLAN的映射关系。
[Sysname] vlan 2
·     primary-vlan primary
private-vlan community命令用来配置同一Secondary VLAN内各端口二层互通。
同一Secondary VLAN内的端口二层互通。
VLAN视图
【支持的缺省用户角色】
private-vlan community命令实现的功能与undo private-vlan isolated命令相同。当用户通过save命令保存配置时,private-vlan community命令的配置不会被存入配置文件。
配置Secondary VLAN 4内各端口二层互通(FortyGigE1/1/1工作为promiscuous模式,FortyGigE1/1/2和FortyGigE1/1/3工作在host模式)。完成下述配置后,Secondary VLAN 4内端口FortyGigE1/1/2和FortyGigE1/1/3二层互通。
# 建立Primary VLAN 2和Secondary VLAN 4的映射关系。
[Sysname] vlan 2
[Sysname-vlan2] private-vlan secondary 4
# 配置端口FortyGigE1/1/1在VLAN 2中工作在promiscuous模式。
[Sysname-FortyGigE1/1/1] quit
# 配置链路类型为Access的端口FortyGigE1/1/2和FortyGigE1/1/3在VLAN 4中工作在host模式。
[Sysname-FortyGigE1/1/2] port access vlan 4
[Sysname-FortyGigE1/1/2] port private-vlan host
[Sysname-FortyGigE1/1/3] port access vlan 4
# 配置Secondary VLAN 4内各端口二层互通。
[Sysname] vlan 4
[Sysname-vlan4] private-vlan community
private-vlan isolated命令用来配置同一Secondary VLAN内各端口二层隔离,即配置该Secondary VLAN为隔离Secondary VLAN。
undo private-vlan isolated命令用来恢复缺省情况。
同一Secondary VLAN内的端口能够二层互通。
VLAN视图
·     添加到该隔离Secondary VLAN的各下行端口二层隔离。
·     当Primary VLAN与Secondary VLAN建立映射关系,并且下行端口配置为trunk secondary模式或host模式后,private-vlan isolated命令才生效。
·     Secondary VLAN隔离与Primary VLAN、Super VLAN和Sub VLAN配置互斥。
配置Secondary VLAN 4内各端口二层隔离(FortyGigE1/1/1工作在promiscuous模式,FortyGigE1/1/2及FortyGigE1/1/3工作在host模式)。完成下述配置后,Secondary VLAN 4内端口FortyGigE1/1/2和FortyGigE1/1/3二层隔离。
[Sysname] vlan 2
# 配置Secondary VLAN 4内各端口二层隔离。
[Sysname] vlan 4
[Sysname-vlan4] private-vlan isolated
·     private-vlan community
private-vlan primary命令用来配置一个VLAN的类型为Primary VLAN。
undo private-vlan primary命令用来恢复缺省情况。
VLAN的类型不是Primary VLAN。
VLAN视图
配置该命令时,若已经配置Primary VLAN和Secondary VLAN的映射关系,且设备上有端口工作在promiscuous模式、trunk promiscuous模式、trunk secondary模式或host模式,则依据接口配置会触发配置同步。具体参见port private-vlan promiscuous、port private-vlan trunk promiscuous、port private-vlan trunk secondary或port private-vlan host命令。
# 配置VLAN 5为Primary VLAN。
[Sysname] vlan 5
[Sysname-vlan5] private-vlan primary
4 Voice VLAN
4.1  Voice VLAN配置命令
cdp voice-vlan命令用来指定端口通过CDP报文发布给IP电话的Voice VLAN ID。
undo cdp voice-vlan命令用来恢复缺省情况。
cdp voice-vlan vlan-id
undo cdp voice-vlan
在设备开启LLDP兼容CDP功能的情况下,设备将端口上配置的Voice VLAN信息通过CDP报文发布给邻居IP电话。
二层以太网端口视图
vlan-id:指定Voice VLAN编号,取值范围为1~4094。
本命令需要配合LLDP兼容CDP功能使用,否则不能生效。
# 配置端口FortyGigE1/1/1通过CDP报文发布的Voice VLAN ID为4094。
[Sysname-FortyGigE1/1/1] cdp voice-vlan 4094
display voice-vlan mac-address命令用来显示Voice VLAN当前支持的OUI地址、OUI地址掩码和描述信息。
# 显示Voice VLAN的OUI地址、OUI地址掩码和描述信息。
<Sysname> display voice-vlan mac-address
OUI Address     Mask            Description
0001-e300-0000  ffff-ff00-0000  Siemens phone
0003-6b00-0000  ffff-ff00-0000  Cisco phone
0004-0d00-0000  ffff-ff00-0000  Avaya phone
000f-e200-0000  ffff-ff00-0000  H3C Aolynk phone
0060-b900-0000  ffff-ff00-0000  Philips/NEC phone
00d0-1e00-0000  ffff-ff00-0000  Pingtel phone
00e0-7500-0000  ffff-ff00-0000  Polycom phone
00e0-bb00-0000  ffff-ff00-0000  3Com phone
表4-1 display voice-vlan mac-address命令显示信息描述表
Oui Address
设备当前允许通过的OUI地址
Mask
设备当前允许通过的OUI地址的掩码
设备当前允许通过的OUI地址的描述
·     voice-vlan mac-address
display voice-vlan state命令用来显示Voice VLAN的配置信息。
# 显示Voice VLAN的配置信息。
<Sysname> display voice-vlan state
 Current voice VLANs: 1
 Voice VLAN security mode: Security
 Voice VLAN aging time: 1440 minutes
 Voice VLAN enabled ports and their modes:
 Port                  VLAN        Mode        CoS        DSCP
 FortyGigE1/1/1        111         Auto        6          46
表4-2 display voice-vlan state命令显示信息描述表
Current Voice VLANs
已创建的Voice VLAN数量
Voice VLAN的安全模式的开启状态:
·     Security:表示当前使用的是安全模式
·     Normal:表示当前使用的是普通模式
Voice VLAN的老化时间
当前使能了Voice VLAN的接口及其工作模式
Port
当前使能了Voice VLAN的接口编号
VLAN
接口使能的Voice VLAN ID
Mode
接口Voice VLAN的工作模式:
·     Auto:表示自动模式
·     Manual:表示手工模式
CoS
服务级别
DSCP
差分服务编码点优先级
·     voice-vlan aging
·     voice-vlan enable
·     voice-vlan mode auto
·     voice-vlan security enable
voice-vlan aging命令用来配置Voice VLAN的老化时间。
undo voice-vlan aging命令用来恢复缺省情况。
voice-vlan aging minutes
Voice VLAN的老化时间为1440分钟。
minutes:Voice VLAN的老化时间,取值范围为5~43200,单位为分钟。
在自动模式下,系统会根据收到的语音报文的源MAC地址,来决定是否把该报文的入接口加入Voice VLAN。在将入接口加入Voice VLAN后,系统会同时启动老化定时器。经过老化时间后,如果设备没有从该接口收到任何语音报文,老化时间到达后系统会自动把该接口从Voice VLAN中删除。该老化时间只对Voice VLAN工作在自动模式的接口有效,对Voice VLAN工作在手工模式的接口无效。
# 将Voice VLAN的老化时间配置为100分钟。
[Sysname] voice-vlan aging 100
·     display voice-vlan state
voice-vlan vlan-id enable命令用来使能接口的Voice VLAN功能。
undo voice-vlan enable命令用来关闭接口的Voice VLAN功能。
undo voice-vlan [ vlan-id ] enable
接口没有使能Voice VLAN功能。
二层以太网接口视图
vlan-id:指定Voice VLAN编号,取值范围为2~4094。
当接口的Voice VLAN工作在自动模式时,只有Trunk或者Hybrid类型接口支持使能Voice VLAN功能。
# 使能接口FortyGigE1/1/1的Voice VLAN功能。
[Sysname-FortyGigE1/1/1] voice-vlan 2 enable
voice-vlan mac-address命令用来配置允许指定OUI地址的报文通过Voice VLAN。
undo voice-vlan mac-address命令用来取消指定OUI地址的报文通过Voice VLAN。
voice-vlan mac-address mac-address mask oui-mask [ description text ]
undo voice-vlan mac-address oui
系统已配置有OUI地址,如下表所示。该地址可以手工删除,删除之后也可再次手工添加。
表4-3 设备缺省的OUI地址
序号
OUI地址
生产厂商
1
0001-E300-0000
Siemens phone
2
0003-6B00-0000
Cisco phone
3
0004-0D00-0000
Avaya phone
4
000F-E200-0000
H3C Aolynk phone
5
0060-B900-0000
Philips/NEC phone
6
00D0-1E00-0000
Pingtel phone
7
00E0-7500-0000
Polycom phone
8
00E0-BB00-0000
3Com phone
mac-address:语音报文的源MAC地址,格式为H-H-H,如:1234-1234-1234。
mask oui-mask:OUI地址的有效长度,用掩码表示,格式为H-H-H。由连续的1和连续的0组成,表示OUI地址的匹配长度。如:FFFF-0000-0000,如果要过滤某个设备厂商的语音设备,可以配置为FFFF-FF00-0000。
description text:OUI地址的描述字符串,长度为1~30,区分大小写。
oui:指定要删除的OUI地址,格式为H-H-H,如1234-1200-0000。OUI地址不能是广播地址或者组播地址,也不能是全0的地址。OUI地址是mac-address和oui-mask参数相与的结果。可以通过display voice-vlan mac-address命令查看当前系统支持的OUI地址的信息。
系统最多支持配置128个OUI地址。
# 配置允许来自IP电话PhoneA(MAC地址为1234-1234-1234)的语音流通过Voice VLAN。
[Sysname] voice-vlan mac-address 1234-1234-1234 mask ffff-ff00-0000 description PhoneA
·     display voice-vlan mac-address
voice-vlan mode auto命令用来配置接口的Voice VLAN的工作模式为自动模式。
undo voice-vlan mode auto命令用来配置接口的Voice VLAN的工作模式为手工模式。
二层以太网接口视图
当接口使能了Voice VLAN并工作在手工模式时,必须手工将接口加入Voice VLAN,才能保证Voice VLAN功能生效。
# 将接口FortyGigE1/1/1的Voice VLAN的工作模式配置为手工模式。
[Sysname-FortyGigE1/1/1] undo voice-vlan mode auto
voice-vlan qos命令用来配置接口将Voice VLAN内语音报文的CoS和DSCP修改为指定值。
undo voice-vlan qos命令用来恢复缺省情况。
voice-vlan qos cos-value dscp-value
undo voice-vlan qos
接口将Voice VLAN内语音报文的CoS值修改为6,DSCP值修改为46。
二层以太接口视图
cos-value:配置语音报文CoS值,取值范围为0~7,缺省值为6。
dscp-value:配置语音报文DSCP值,取值范围为0~63,缺省值为46。
·     在Voice VLAN使能的情况下,不允许配置本命令。必须禁用Voice VLAN后,才能配置本命令。
·     如果对于同一接口多次执行voice-vlan qos和voice-vlan qos trust命令,以最后配置的命令为准。
# 配置接口FortyGigE1/1/1收到Voice VLAN内的语音报文时,将报文的CoS值修改为5,DSCP值修改为45。
[Sysname-FortyGigE1/1/1] voice-vlan qos 5 45
·     voice-vlan qos trust
voice-vlan qos trust命令用来配置接口信任Voice VLAN内语音报文的优先级,即接口不会修改Voice VLAN内语音报文自带的CoS和DSCP值。
undo voice-vlan qos
二层以太接口视图
# 配置接口FortyGigE1/1/1信任语音报文的优先级。接口收到Voice VLAN内语音报文后,报文自带的CoS和DSCP值保持不变。
[Sysname-FortyGigE1/1/1] voice-vlan qos trust
·     voice-vlan qos
voice-vlan security enable命令用来使能Voice VLAN的安全模式。
undo voice-vlan security enable命令用来关闭Voice VLAN的安全模式。
Voice VLAN工作在安全模式。
在安全模式下,Voice VLAN中只能有语音流量。用户使能Voice VLAN的安全模式以后,该VLAN的报文都经过过滤,设备会根据报文的源MAC地址是否匹配OUI地址来过滤所有非语音流量,增加安全性保证语音流的优先级,保证通话质量。在普通模式下,Voice VLAN中允许有业务流量和语音流量并存。
# 关闭Voice VLAN的安全模式。
[Sysname] undo voice-vlan security enable
voice-vlan track lldp命令用来开启通过LLDP自动发现IP电话功能。
undo voice-vlan track lldp命令用来恢复缺省情况。
通过LLDP自动发现IP电话功能处于关闭状态。
# 在设备上开启通过LLDP自动发现IP电话功能。
[Sysname] voice-vlan track lldp
