02-WLAN命令参考
02-WLAN服务命令
本章节下载 02-WLAN服务命令  (577.82 KB)
02-WLAN服务命令
  录
1 WLAN服务配置命令
1.1 WLAN全局服务控制命令
1.1.1 wlan enable
1.2 802.11 MAC配置命令
1.2.1 a-mpdu enable
1.2.2 a-msdu enable
1.2.3 ani enable
1.2.4 antenna type
1.2.5 beacon-interval
1.2.6 bind wlan-ess
1.2.7 broadcast-probe reply
1.2.8 channel
1.2.9 channel lock
1.2.10 channel band-width
1.2.11 client dot11n-only
1.2.12 client idle-timeout
1.2.13 client forwarding-mode
1.2.14 client max-count(服务模板视图)
1.2.15 client max-count(射频策略视图)
1.2.16 client keep-alive
1.2.17 country-code
1.2.18 display wlan country-code
1.2.19 display wlan client
1.2.20 display wlan radio-policy
1.2.21 display wlan service-template
1.2.22 display wlan statistics ap connect-history
1.2.23 display wlan statistics client
1.2.24 display wlan statistics radio
1.2.25 display wlan statistics service-template
1.2.26 distance
1.2.27 dtim
1.2.28 fast-association enable
1.2.29 fragment-threshold
1.2.30 long-retry threshold
1.2.31 max-power
1.2.32 max-rx-duration
1.2.33 nas-id
1.2.34 nas-port-id
1.2.35 power lock
1.2.36 preamble
1.2.37 protection-mode
1.2.38 radio
1.2.39 radio-policy
1.2.40 radio type
1.2.41 reset wlan statistics
1.2.42 reset wlan client
1.2.43 rts-threshold
1.2.44 service-template (射频视图)
1.2.45 service-template (服务模板视图)
1.2.46 short-gi enable
1.2.47 short-retry threshold
1.2.48 shut-all-led enable
1.2.49 ssid
1.2.50 trap enable
1.2.51 wlan country-code
1.2.52 wlan link-test
1.2.53 wlan radio
1.2.54 wlan radio-policy
1.2.55 wlan radio-policy auto-create
1.2.56 wlan service-template
1.3 AC-AP间隧道配置命令
1.3.1 ac
1.3.2 ap-name
1.3.3 backup-ac
1.3.4 cir
1.3.5 cpu-usage threshold
1.3.6 data-tunnel encryption enable
1.3.7 description
1.3.8 display wlan ap
1.3.9 display wlan ap address
1.3.10 display wlan ap radio
1.3.11 display wlan ap reboot-log
1.3.12 display wlan ap-model
1.3.13 dns domain
1.3.14 dns server
1.3.15 echo-interval
1.3.16 gateway
1.3.17 hybrid-remote-ap enable
1.3.18 ip address
1.3.19 ipv6 address
1.3.20 jumboframe enable
1.3.21 map-configuration
1.3.22 memory-usage threshold
1.3.23 priority level
1.3.24 provision
1.3.25 reset wlan ap
1.3.26 reset wlan ap provision
1.3.27 reset wlan ap reboot-log
1.3.28 save wlan ap provision
1.3.29 serial-id
1.3.30 tunnel encryption ipsec pre-shared-key
1.3.31 vlan tagged
1.3.32 vlan untagged
1.3.33 vlan pvid
1.3.34 wlan ap
1.3.35 wlan ap-provision ac
1.3.36 wlan ap-provision dns domain
1.3.37 wlan ap-provision dns server
1.3.38 wlan ap-execute
1.3.39 wlan apdb
1.3.40 wlan auto-ap enable
1.3.41 wlan auto-ap persistent
1.3.42 wlan backup-ac
1.3.43 wlan lwapp discovery-policy
1.3.44 display user-isolation statistics
1.3.45 reset user-isolation statistics
1.3.46 user-isolation enable
1.3.47 user-isolation permit braodcast
1.3.48 user-isolation vlan enable
1.3.49 user-isolation vlan permit-mac
1.4 AP组接入控制命令
1.4.1 ap
1.4.2 description
1.4.3 display wlan ap-group
1.4.4 wlan ap-group
1.4.5 wlan permit-ap-group
1.5 SSID接入控制命令
1.5.1 wlan permit-ssid
1.6 上行链路检测命令
1.6.1 wlan uplink track
1.7 AC间热备份命令
1.7.1 display hot-backup state
1.7.2 hot-backup enable
1.7.3 hot-backup hellointerval
1.7.4 hot-backup vlan
1.7.5 wlan backup-ac switch-delay
1 WLAN服务配置命令
1.1  WLAN全局服务控制命令
1.1.1  wlan enable
wlan enable
undo wlan enable
【缺省级别】
2:系统级
【描述】
wlan enable命令用来开启WLAN服务。undo wlan enable命令用来关闭WLAN服务。
缺省情况下,WLAN服务处于开启状态。
只有开启了WLAN服务,才能够获得WLAN的所有功能。
# 开启WLAN服务。
[Sysname] wlan enable
1.2  802.11 MAC配置命令
1.2.1  a-mpdu enable
a-mpdu enable
undo a-mpdu enable
射频视图
【缺省级别】
2:系统级
【描述】
a-mpdu enable命令用来开启当前射频接口的A-MPDU功能。undo a-mpdu enable命令用来关闭A-MPDU功能。
缺省情况下,A-MPDU功能处于开启状态。
需要注意的是,该命令仅对802.11n模式的接口有效。在进行接口模式切换的时候,设备会恢复该功能在该模式下的缺省情况。
# 关闭A-MPDU功能。
<sysname> system-view
[sysname] wlan ap ap3 model WA2620-AGN
[sysname-wlan-ap-ap3] radio 1 type dot11an
[sysname-wlan-ap-ap3-radio-1] undo a-mpdu enable
1.2.2  a-msdu enable
a-msdu enable
undo a-msdu enable
射频视图
【缺省级别】
2:系统级
【描述】
a-msdu enable命令用来开启当前射频接口的A-MSDU功能。undo a-msdu enable用来关闭A-MSDU功能。
缺省情况下,A-MSDU功能处于开启状态。
·              该命令仅对802.11n模式的接口有效。在进行接口模式切换的时候,设备会恢复该功能在该模式下的缺省情况。
·              目前,设备只支持接收A-MSDU报文,不支持发送A-MSDU。
# 关闭A-MSDU功能。
[sysname]wlan ap ap3 model WA2620-AGN
[sysname-wlan-ap-ap3-radio-1] undo a-msdu enable
1.2.3  ani enable
ani enable
undo ani enable
射频视图
【缺省级别】
2:系统级
【描述】
ani enable命令用来开启自动抗干扰(Adaptive Noise Immunity)功能。undo ani enable命令用来关闭该功能。
缺省情况下,自动抗干扰功能处于开启状态。
开启自动抗干扰功能后,设备会根据周边信号环境自动调整抗噪等级,来抵消周边射频干扰。
# 关闭自动抗干扰功能。
[Sysname] wlan ap ap1 model WA2100
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] undo ani enable
1.2.4  antenna type
antenna type type
undo antenna type
射频视图
【缺省级别】
2:系统级
type:射频天线类型。
【描述】
antenna type命令用来配置射频的天线类型。undo antenna type命令用来恢复缺省情况。
本命令的缺省情况与设备型号有关,请以设备的实际情况为准。
# 配置射频天线类型。
[Sysname] wlan ap ap1 model wa2620e-agn
[Sysname-wlan-ap-ap1-radio-1] antenna type C5060
beacon ssid-hide
beacon ssid-hide
undo beacon ssid-hide
服务模板视图
【缺省级别】
2:系统级
【描述】
beacon ssid-hide命令用来配置在信标帧中隐藏SSID,即不通告SSID。undo beacon ssid-hide命令用来恢复缺省情况。
缺省情况下,信标帧中不隐藏SSID。
需要注意的是,信标帧中的SSID隐藏后,AP发送的信标帧里面不包含SSID信息,接入的无线客户端必须手动配置该SSID标识才能接入AP。
隐藏SSID对无线安全意义不大。允许广播SSID可以使无线客户端更容易发现AP。
# 配置在信标帧中隐藏SSID。
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] beacon ssid-hide
beacon-interval interval
undo beacon-interval
射频策略视图
【缺省级别】
2:系统级
interval:发送信标帧的时间间隔。取值范围为32~8191,单位TU(Time Unit,1TU=1024微秒)。
【描述】
beacon-interval命令用来设置AP发送Beacon帧(信标帧)的时间间隔。undo beacon-interval命令用来恢复缺省情况。
缺省情况下,发送Beacon帧的时间间隔为100TU。
# 设置发送信标帧的时间间隔为1000TU。
[Sysname] wlan radio-policy radio1
[Sysname-wlan-rp-radio1] beacon-interval 1000
1.2.6  bind wlan-ess
bind wlan-ess interface-index
undo bind wlan-ess
服务模板视图
【缺省级别】
2:系统级
interface-index:指定WLAN-ESS接口的索引,不同型号的设备支持的取值范围不同,无线控制产品各型号的支持情况请参见“命令参考导读”中的“命令行及参数差异情况”部分的介绍。
【描述】
bind wlan-ess命令用来将指定的无线接口绑定到服务模板。undo bind wlan-ess命令用来取消指定无线接口与服务模板的绑定。
缺省情况下,没有接口与服务模板绑定。
# 将WLAN-ESS1接口绑定到服务模板。
[Sysname] interface WLAN-ESS 1
[Sysname-WLAN-ESS1] quit
[Sysname-wlan-st-1] bind wlan-ess 1
undo broadcast-probe reply
AP模板视图
【缺省级别】
2:系统级
【描述】
broadcast-probe reply命令用来配置AP对无线客户端发送的SSID为空的探测请求进行回复。undo broadcast-probe reply命令用来配置AP对无线客户端发送的携带指定SSID的探测请求进行回复,而对SSID为空的探测请求不进行回复。
缺省情况下,AP会对无线客户端发送的SSID为空的探测请求进行回复。
# 配置AP回复无线客户端发送的SSID为空的探测请求。
[Sysname] wlan ap ap3 model WA2100
[Sysname-wlan-ap-ap3] broadcast-probe reply
1.2.8  channel
channel { channel-number | auto }
undo channel
射频视图
【缺省级别】
2:系统级
channel-number:射频的工作信道。射频的工作信道由国家码和射频模式决定。
auto:自动选择信道模式,由设备根据实际环境自动选择最优信道。
【描述】
channel命令用来配置射频的工作信道。undo channel命令用来恢复缺省情况。
缺省情况下,使用自动选择信道模式,即auto模式。
·              配置channel channel-number命令表示一直使用固定信道,这种情况下,不需要配置channel lock命令。如果先配置了channel lock命令,再配置channel channel-number命令,后者的配置会覆盖前者。
·              配置信道调整功能前,请确保AC使用自动选择信道模式,否则信道调整功能无法运行。关于信道调整功能的详细介绍,请参见“WLAN配置指导”中的“WLAN RRM配置”。
相关配置可参考命令channel lock,“WLAN命令参考/WLAN RRM配置命令”中的命令dot11a calibrate-channeldot11bg calibrate-channel
# 设置射频的工作信道为6。
[Sysname-wlan-ap-ap3] radio 1 type dot11b
[Sysname-wlan-ap-ap3-radio-1] channel 6
1.2.9  channel lock
channel lock
undo channel lock
射频视图
【缺省级别】
2:系统级
【描述】
channel lock命令用来锁定信道。undo channel lock命令用来解除信道锁定。
缺省情况下,信道没有被锁定。
·              设备在使用自动选择信道模式(channel auto)的前提下,channel lock命令才能起作用。
·              配置channel lock后再启用Radio(radio enable),设备会自动选择最优信道,然后锁定该信道。
·              一旦在信道上检测到雷达信号,即使配置了channel lock命令,设备也会立即切换信道,切换后新信道仍然会被锁定。
·              如果先配置channel lock命令,后开启信道调整功能,由于信道已经被锁定,信道调整功能不会运行,所以在开启信道调整功能前,请确保信道没有被锁定。如果先开启信道调整功能,后配置channel lock命令,最后一次调整的信道将会被锁定。关于信道调整功能的详细介绍,请参见“WLAN配置指导”中的“WLAN RRM配置”。
相关配置可参考命令channel,“WLAN命令参考/WLAN RRM配置命令”中的命令dot11a calibrate-channeldot11bg calibrate-channel
# 锁定当前的工作信道。
[Sysname-wlan-ap-ap3] radio 1 type dot11g
[Sysname-wlan-ap-ap3-radio-1] channel lock
channel band-width { 20 | 40 }
undo channel band-width
射频视图
【缺省级别】
2:系统级
20:表示802.11n的工作带宽是20MHz。
40:表示802.11n的工作带宽是40MHz。
【描述】
channel band-width命令用来指定当前射频接口的带宽模式。undo channel band-width命令用来恢复缺省情况。
缺省情况下,802.11an类型的射频接口的带宽为40MHz,802.11gn类型的射频接口的带宽为20MHz。
·              该命令仅对802.11n类型的接口有效。在进行接口模式切换的时候,设备恢复在该模式下的缺省值。
·              在指定射频接口的带宽为40MHz情况下,如果找到可以绑定的信道,那么使用40MHz带宽,如果找不到可以绑定的信道,那么实际只能使用20MHz带宽。
# 配置当前接口的带宽模式为20MHz。
[sysname-wlan-ap-ap3-radio-1] channel band-width 20
client dot11n-only
undo client dot11n-only
射频视图
【缺省级别】
2:系统级
【描述】
client dot11n-only命令用来配置仅允许802.11n用户接入功能。undo client dot11n-only用来恢复缺省情况。
缺省情况下,802.11an类型的接口同时允许802.11a和802.11an用户接入;802.11gn类型的接口同时允许802.11b/g和802.11gn用户接入。
802.11n支持2.4GHz和5GHz两个频段,考虑到802.11n设备对802.11a/b/g无线客户端的兼容性,目前的802.11n设备支持802.11a/b/g无线客户端的混合接入。也就是设备工作在802.11n模式时可以同时提供802.11a/b/g无线客户端的接入。
需要注意的是:当执行client dot11n-only命令后,只有802.11n的无线客户端才能接入AP。如果用户需要兼容802.11a/b/g的无线客户端,同时还要接入802.11n的无线客户端,则必须关闭client dot11n-only命令。
相关配置可参考命令“WLAN命令参考/WLAN RRM配置命令”中的命令dot11n mandatory maximum-mcs
# 配置只允许802.11n用户接入功能。
[sysname-wlan-ap-ap3-radio-1] client dot11n-only
client idle-timeout interval
undo client idle-timeout
AP模板视图
【缺省级别】
2:系统级
interval:指定AP和无线客户端(节电状态或清醒状态)之间连接允许的最大空闲时间,取值范围为60~86400,单位秒。
【描述】
client idle-timeout命令用来配置AP和无线客户端之间的连接允许的最大空闲时间。undo client idle-timeout命令用来恢复缺省情况。
缺省情况下,AP和无线客户端之间的连接允许的最大空闲时间为3600秒。
如果空闲时间超过了指定时间,即AP在指定的时间内没有收到从无线客户端发来的数据,那么无线客户端将从网络中被删除。
# 设置无线客户端空闲时间为600秒。
[Sysname-wlan-ap-ap3] client idle-timeout 600
client forwarding-mode local [ vlan vlan-id-list ]
undo client forwarding-mode local
服务模板视图
【缺省级别】
2:系统级
local:本地转发功能。
vlan vlan-id-list:本地转发的VLAN,vlan-id-list为VLAN列表,表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>,vlan-id取值范围为1~4094,&<1-10>表示前面的参数最多可以重复输入10次。如果不指定此参数,则所有的VLAN都启动本地转发。
【描述】
client forwarding-mode local命令用来配置AP的本地转发功能,即AP将BSS(Basic Service Set,基本服务集)的所有无线客户端流量本地转发功能。undo client forwarding-mode local命令用来关闭本地转发功能。
缺省情况下,AP将BSS的所有无线客户端的流量远端转发。
配置本地转发功能后,由AP本身进行数据帧的转发;如未配置本地转发功能,数据帧由AC转发。
本地转发是一种在AP上完成无线客户端之间数据交互的转发模式。在集中式WLAN 架构中,AP会将无线客户端的数据报文透传给AC,由AC集中处理。随着无线客户端速率的不断提高,AC的转发压力也随之增大。采用本地转发后,AP直接转发无线客户端的数据,AC不再参与数据转发,大大减轻了AC的负担。
# 配置本地转发功能。
[Sysname-wlan-st-1] client forwarding-mode local
client max-count max-number
undo client max-count
服务模板视图
【缺省级别】
2:系统级
max-number:在一个射频下,某个SSID下的关联无线客户端的最大个数,取值范围为1~124。
【描述】
client max-count命令用来指定在一个射频下,某个SSID下的关联无线客户端的最大个数。undo client max-count命令用来恢复缺省情况。
缺省情况下,最多可以关联64个无线客户端。
需要注意的是,当某个SSID下关联的无线客户端达到最大个数时,该SSID会自动隐藏。
# 配置名为“service”的SSID下可以关联的最大无线客户端的个数为10。
[Sysname-wlan-st-1] ssid service
[Sysname-wlan-st-1] client max-count 10
射频策略视图
【缺省级别】
2:系统级
max-number:射频策略允许的无线客户端的最大个数,取值范围为1~124。
【描述】
client max-count命令用来设置射频策略允许的无线客户端的最大个数。undo client max-count命令用来恢复缺省情况。
缺省情况下,射频策略中关联客户端的最大个数为64。
# 射频策略radio1上允许的无线客户端的最大个数为10。
[Sysname-wlan-rp-radio1] client max-count 10
client keep-alive interval
undo client keep-alive
AP模板视图
【缺省级别】
2:系统级
interval:保活请求的时间间隔,取值范围为3~1800秒。
【描述】
client keep-alive命令用来设置无线客户端的保活时间间隔。undo client keep-alive命令用来关闭无线客户端的保活功能。
缺省情况下,无线客户端的保活功能处于关闭状态。
保活机制通常用来检测无线客户端是否从系统中被隔离出来,并断开无线客户端同AP的连接,导致无线客户端被隔离的原因有电源故障、系统崩溃等。
# 设置无线客户端的保活时间间隔为60秒。
[Sysname-wlan-ap-ap3] client keep-alive 60
1.2.17  country-code
country-code code
undo country-code
AP模板视图
【缺省级别】
2:系统级
code:设置AP的国家码。国家码和国家的对应关系请参见表1-12
【描述】
country-code命令用来设置AP的国家码。undo country-code命令用来删除已有配置。
缺省情况下,没有配置AP的国家码。在没有配置AP国家码的情况下,缺省使用全局国家码。如果都进行了配置,则优先采用AP模板视图下AP国家码的配置。
相关配置可参考命令wlan country-codedisplay wlan country-code
# 将AP 1的国家码设置为美国。
[Sysname] wlan ap ap1 model WA2620-AGN
[Sysname-wlan-ap-ap1] country-code us
display wlan country-code ap { name ap-name | all } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
name ap-name:指定AP的名字,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,不可以包含空格。
all:显示所有AP的国家码信息。
|:使用正则表达式对显示信息进行过滤。有关正则表达式的详细介绍,请参见“基础配置指导”中的“CLI配置”。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display wlan country-code用来显示AP的国家码信息。
相关配置可参考命令country-code
# 显示所有AP的国家码信息。
<Sysname> display wlan country-code ap all
                            Country Code
 AP                                         Country Code
 ap1                                        CN China
 ap2                                        US United States
表1-1 display wlan country-code命令显示信息描述表
AP
AP名称
Country Code
AP的国家码
display wlan client [ ap ap-name [ radio radio-number ] | mac-address mac-address | service-template service-template-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ap ap-name:显示连接到指定AP的无线客户端信息。
radio radio-number:显示连接到指定射频的无线客户端信息。
mac-address mac-address:无线客户端的MAC地址。
service-template service-template-number:显示基于指定服务模板的无线客户端信息。服务模板取值范围为1~1024。
verbose:显示用户的详细信息。
【描述】
display wlan client命令用来查看指定无线客户端或者所有无线客户端的信息。
# 显示所有无线客户端的信息。
<Sysname> display wlan client
Total Number of Clients           : 3
                               Client Information
 SSID: office
 MAC Address   User Name            APID/RID        IP Address              VLAN
000f-e265-6400 -NA-                    1/1          1.1.1.1                  1
000f-e265-6401 user                 1024/1          3.0.0.3                  3
000f-e265-6402 mac@office.com       103 /1          FE:11:12:03::11:25:13    1
表1-2 display wlan client命令显示信息描述表
SSID
无线客户端关联的SSID
MAC Address
无线客户端的MAC地址
User Name
无线客户端的认证用户名
如果无线客户端采用明文方式或无用户名的加密方式接入,该字段显示为-NA-
需要注意的是,该字段的显示情况和无线客户端是否采用Portal认证无关。也就是说,如果无线客户端采用Portal认证方式,User Name字段不会显示无线客户端的Portal用户名
APID/RID
无线客户端的关联AP的ID以及Radio的ID
IP Address
无线客户端的IP地址
VLAN
无线客户端所在的VLAN
# 显示所有无线客户端的详细信息。
<Sysname> display wlan client verbose
 Total Number of Clients           : 1
                              Client Information
 MAC Address                       : 001e-58f6-01bf
 User Name                         : -NA-
 AID                               : 1
 AP Name                           : 2
Radio Id                           : 2
 SSID                              : office
 BSSID                             : 0026-3e08-1150
 Port                              : WLAN-DBSS0:3
 VLAN                              : 1
 State                             : Running
 Power Save Mode                   : Active
 Wireless Mode                     : 11gn
 Channel Band-width                : 20MHz
 SM Power Save Enable              : Disabled
 Short GI for 20MHz                : Not Supported
 Short GI for 40MHz                : Supported
 Support MCS Set                   : 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
 BLOCK ACK-TID 0                   : IN
 QoS Mode                          : WMM
 Listen Interval (Beacon Interval) : 10
 RSSI                              : 62
 Rx/Tx Rate                        : 130/11
 Client Type                       : PRE-RSNA
 Authentication Method             : Open System
 AKM Method                        : None
 4-Way Handshake State             : -NA-
 Group Key State                   : -NA-
 Encryption Cipher                 : Clear
 Roam Status                       : Normal
 Roam Count                        : 0
 Up Time (hh:mm:ss)                : 00:01:13
表1-3 display wlan client verbose命令显示信息描述表
MAC Address
无线客户端的MAC地址
User Name
无线客户端的认证用户名
AID
无线客户端的关联ID
AP Name
接入点名称
Radio Id
无线客户端关联的Radio口的编号
SSID
无线客户端关联的SSID
BSSID
基本服务集识别码
Port
与无线客户端关联的WLAN-DBSS接口
VLAN
无线客户端所在的VLAN
无线客户端的状态,例如:运行
如果出现Backup信息,表示该无线客户端通过备份链路与AC相连
Power Save Mode
无线客户端节电模式的状态:
·       Active模式(激活)
·       Sleep模式(睡眠)
Wireless Mode
无线模式:802.11a、802.11b、802.11g、802.11gn和802.11an
Channel Band-width
带宽模式:
·       20MHz:工作带宽为20MHz
·       40MHz:工作带宽为40MHz
SM Power Save可以使无线客户端上只有一个天线处于工作状态,其余天线均处于休眠状态,从而达到节省电源的目的
·       Enabled:支持SM Power Save
·       Disabled:不支持SM Power Save
Short GI for 20MHz
无线客户端工作带宽为20MHz时,对于Short GI的支持情况:
·       Not Supported:无线客户端不支持Short GI
·       Supported:无线客户端支持Short GI
Short GI for 40MHz
无线客户端工作带宽为40MHz时,对于Short GI的支持情况:
Support MCS Set
无线客户端支持MCS集
BLOCK ACK-TID 0
按照QoS优先级ID 0协商BLOCK ACK:
·       OUT:下行方向
·       IN:上行方向
·       BOTH:上行方向和下行方向
QoS Mode
QoS模式:
·       None:不支持WMM协议
·       WMM:支持WMM协议
对于WMM的支持情况,AP和Client会进行协商。只有AP和无线客户端同时支持WMM时,才能协商成功
Listen Interval
处于Sleep模式的无线客户端定期醒来接收缓存在AP中的数据帧的时间间隔,单位为Beacon interval(信标发送时间间隔)
RSSI
接收信号强度指示,该值表明了AP检测到Client的信号强度
Rx/Tx Rate
无线客户端接收/发送报文的速率(包括数据、管理和控制报文)。对于AC+Fit AP模式,由于接收/传输速率信息是按照一定的时间间隔周期性的从AP传送到AC,因此会有延时
Client Type
无线客户端类型,例如:WPA2(RSN)、WPA或PRE-RSNA
认证方法,例如:开放系统或共享密钥
AKM Method
AKM套件,如Dot1X,PSK
四次握手状态中的一种:
·       IDLE:初始化状态
·       PTKSTART:四次握手初始化完毕
·       PTKNEGOTIATING:发送第三个有效消息
·       PTKINITDONE:四次握手成功
Group Key State
组密钥状态,包括以下几种:
·       IDLE:初始化状态
·       REKEYNEGOTIATE:无线控制器向用户发送初始化消息
·       REKEYESTABLISHE:密钥更新成功
Encryption Cipher
加密密码:明文或者密文加密的类型
Roam Status
漫游状态:正常或者快速漫游
Roam Count
无线客户端的漫游次数(包括AC内漫游、AC间漫游)
对于AC内漫游:无线客户端离开该AC后,字段计数会清零
对于AC间漫游:无线客户端离开该AC所在的漫游组后,字段计数会清零
Up Time
无线客户端和AP关联的时间
display wlan radio-policy [ radio-policy-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
radio-policy-name:射频策略模板的名称,为1~15个字符的字符串,可以包含字母、数字和下划线,不区分大小写,不可以包含空格。
【描述】
display wlan radio-policy命令用来查看指定射频策略或者所有与射频策略相关的信息。
# 显示射频策略为rp的配置信息。
<Sysname> display wlan radio-policy rp
                             Radio Policy Parameters
 Radio Policy Name               : rp
 Fragmentation Threshold (Bytes) : 2346
 Beacon Interval (TU)            : 100
 RTS Threshold (Bytes)           : 2346
 DTIM Period (Beacon Interval)   : 1
 Long Retry Threshold            : 4
 Short Retry Threshold           : 7
 Maximum Rx Duration (ms)        : 2000
 Maximum clients per Radio       : 64
 QoS Mode                        : WMM
 Admission Control Policy        : Users
 Threshold users count           : 20
 CAC-Free's AC Request Policy    : Response Success
 CAC Unauthed Frame Policy       : Downgrade
 CAC Medium Time Limitation(us)  : 100000
 CAC AC-VO's Max Delay(us)       : 50000
 CAC AC-VI's Max Delay(us)       : 300000
 SVP packet mapped AC number     : Disabled
 Radio's WMM Parameters:
                          AC-BK    AC-BE    AC-VI    AC-VO
       ECWmin                 4        4        3        2
       ECWmax                10        6        4        3
       AIFSN                  7        3        1        1
       TXOPLimit              0        0       94       47
       AckPolicy         Normal   Normal   Normal   Normal
 Client's WMM Parameters:
       ECWmin                 4        4        3        2
       ECWmax                10       10        4        3
       AIFSN                  7        3        2        2
       TXOPLimit              0        0       94       47
       CAC              Disable  Disable  Disable  Disable
# 显示所有射频策略的配置信息。
 Radio Policy Name               : default_rp
 QoS Mode                        : WMM
       ECWmin                 4        4        3        2
       ECWmax                10        6        4        3
       AIFSN                  7        3        1        1
       TXOPLimit              0        0       94       47
       ECWmin                 4        4        3        2
       ECWmax                10       10        4        3
       AIFSN                  7        3        2        2
       TXOPLimit              0        0       94       47
 Radio Policy Name               : radio1
 QoS Mode                        : WMM
 Admission Control Policy        : Channelutilization
 Threshold utilization (%)       : 70
       ECWmin                 4        4        3        2
       ECWmax                10        6        4        3
       AIFSN                  7        3        1        1
       TXOPLimit              0        0       94       47
       ECWmin                 4        4        3        2
       ECWmax                10       10        4        3
       AIFSN                  7        3        2        2
       TXOPLimit              0        0       94       47
表1-4 display wlan radio-policy命令显示信息描述表
Radio Policy Name
射频策略的名称
数据包传输时设置的分片门限值。如果数据包的实际长度超过了这个值,数据包在传输前就会被分片
Beacon Interval
发送信标帧的时间间隔
RTS Threshold
AP上RTS门限值。如果数据包长度大于指定的RTS门限值,那么AP将启用RTS/CTS机制
DTIM Period
DTIM周期,单位为信标帧发送周期
DTIM用于通告是否发送缓存多播报文
帧长大于RTS报文阈值的单播帧的最大重传次数
帧长不大于RTS报文阈值的单播帧的最大重传次数
Maximum Rx Duration
接收到的数据包能够在缓冲区中停留的最长时间
射频可以接入的无线客户端的最大数量
QoS Mode
射频策略中关于WMM的设置:
·       None:WMM功能处于开启状态
·       WMM:WMM功能处于关闭状态
准入控制策略
准入控制策略使用的用户数
准入控制策略使用的门限值
对不支持CAC功能的AC采用的回应策略
对CAC未授权报文的处理策略
CAC策略允许的接入时间上限,单位为微秒
CAC策略允许的语音流延迟上限,单位为微秒
CAC策略允许的视频流延迟上限,单位为微秒
SVP报文映射到的AC的编号
ECWmin
ECWmin的值(Exponent form of CWmin,最小竞争窗口指数形式)
ECWmin和ECWmax的值决定了平均退避时间值,这两个数值越大,用户的平均退避时间越长。关于无线服务质量中EDCA参数的详细介绍请参见“WLAN配置指导”中的“WLAN QoS配置”
ECWmax
ECWmax的值(Exponent form of CWmax,最大竞争窗口指数形式)
AIFSN
AIFSN的值
TXOPLimit
TXOP limit的值
AckPolicy
AC所使用的ACK策略
CAC
表示此队列是否受CAC的限制,Disabled表示不受限制,Enabled表示受限制
display wlan service-template [ service-template-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
service-template-number:服务模板号,取值范围为1~1024,显示指定服务模板的信息。如果未指定服务模板号,将显示所有服务模板的信息。
【描述】
display wlan service-template命令用来显示服务模板的信息。
# 显示服务模板1的配置信息。
<Sysname> display wlan service-template 1
                          Service Template Parameters
 Service Template Number      : 1
 SSID                         : sharedkey
 Binding Interface            : WLAN-ESS1
 Service Template Type        : Crypto
 Security IE                  : Not Configured
 Authentication Method        : Shared Key
 SSID-hide                    : Disable
 Cipher Suite                 : WEP40
 WEP Key Index  1             : WEP40
 WEP Key Mode                 : ASCII
 WEP Key                      : -_'PV5%9O`CQ=^Q`MAF4<1!!
 WEP Key Index                : 1
 TKIP Countermeasure Time(s)  : 60
 PTK Life Time(s)             : 43200
 GTK Rekey                    : Enable
 GTK Rekey Method             : Time-based
 GTK Rekey Time(s)            : 86400
 Bridge Mode                  : Remote Forwarding
 Service Template Status      : Enable
 Maximum clients per BSS      : 64
表1-5 display wlan service-template命令各字段的含义描述
当前服务模板号
SSID
无线客户端关联的SSID
Binding Interface
同服务模板绑定的无线接口名称
服务模板类型:Crypto、Clear或WAPI
Security IE
安全IE:WPA或WPA2(RSN)
使用的认证类型:开放系统认证或者共享密钥认证
SSID-hide
·       Disable:启用SSID通告
·       Enable:禁用SSID通告
Cipher Suite
加密套件:AES-CCMP,TKIP,WEP40、WEP104或WEP128
WEP Key Index
加密或解密帧的密钥索引
WEP Key Mode
WEP密钥模式:
·       HEX:WEP密钥为16进制数的形式
·       ASCII:WEP密钥为字符串的形式
WEP Key
WEP密钥
TKIP反制策略中,MIC失败的计时器,单位为秒
PTK Life Time(s)
PTK生存时间,单位为秒
GTK Rekey
GTK密钥更新配置:
·       Disable:GTK密钥功能处于关闭状态
·       Enable:GTK密钥功能处于开启状态
GTK Rekey Method
已配置的GTK密钥更新方法:
·       Packet-based:采用基于数据包的方法更新GTK密钥
·       Time-based:采用基于时间的方法更新GTK密钥
GTK Rekey Time(s)
GTK密钥更新时间,单位为秒
Bridge Mode
转发方式:
·       Local Forwarding:使用本地转发转发方式
·       Remote Forwarding:使用AC远端转发方式
服务模板状态:
·       Disable:服务模板处于关闭状态
·       Enable:服务模板处于开启状态
一个BSS中能够连接的最大无线客户端数
display wlan statistics ap { all | name ap-name } connect-history [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:显示所有AP的连接历史。
name ap-name:指定AP的名称,1~32个字符的字符串,包含字母和数字。
【描述】
display wlan statistics ap{ all | name ap-name } connect-history命令用来显示指定AP或所有AP的无线客户端连接历史。
#  显示ap1的连接历史。
<Sysname> display wlan statistics ap name ap1 connect-history
                            Connection History
 AP Name                    : ap1
 Associations               : 120
 Reassociations             : 16
 Failures                   : 3
 Rejections                 : 23
 Exceptional Deassociations : 2
 Current Associations       : 51
表1-6 display wlan statistics ap connect-history命令显示信息描述表
AP Name
接入点名称
Associations
和AP连接过的无线客户端的总数,包括当前在线的和已经下线的无线客户端
Reassociations
无线客户端重新连接的计数
Failures
无线客户端连接的失败计数
Rejections
无线客户端被拒绝连接的计数
该AP上异常认证计数
当前在线的无线客户端计数
display wlan statistics client { all | mac-address mac-address } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
client:显示指定无线客户端的统计信息。
all:显示所有无线客户端的统计信息。
【描述】
display wlan statistics client命令用来显示指定或所有无线客户端的统计信息。
# 显示所有无线客户端统计信息。
<Sysname> display wlan statistics client all
                                Client Statistics
 AP Name                           : ap1
 Radio Id                          : 1
 SSID                              : office-1
 BSSID                             : 000f-e2ff-7700
 MAC Address                       : 0014-6c8a-43ff
 RSSI                              : 31
 Transmitted Frames:
 Back Ground (Frames/Bytes)        : 0/0
 Best Effort (Frames/Bytes)        : 9/1230
 Video (Frames/Bytes)              : 0/0
 Voice (Frames/Bytes)              : 2/76
 Received Frames:
 Best Effort (Frames/Bytes)        : 18/2437
 Voice (Frames/Bytes)              : 7/468
 Discarded Frames:
 Best Effort (Frames/Bytes)        : 0/0
 Voice (Frames/Bytes)              : 5/389
表1-7 display wlan statistics client命令各字段的含义描述
AP Name
接入点名称
Radio Id
射频ID号
SSID
无线客户端关联的SSID
BSSID
基本服务集标识
MAC Address
无线客户端的MAC地址
RSSI
接收信号强度指示,该值表明AP检测到Client的信号强度
Transmitted Frames
发送的帧的数目
Back Ground
以帧或字节为单位对背景流优先级队列进行统计
Best Effort
以帧或字节为单位对尽力而为流优先级队列进行统计
Video
以帧或字节为单位对视频流优先级队列进行统计
Voice
以帧或字节为单位对语音流优先级队列进行统计
Received Frames
收到的帧的数目
Discarded Frames
丢弃的帧的数目
Back Ground、Best Effort、Video及Voice优先级的统计仅针对QoS客户端。对于非QoS客户端的收发流量,统一统计为Best Effort类型,包括SVP报文,可能与实际物理发送队列不一致。上述优先级统计只能针对Dot11E或者WMM报文携带的用户优先级进行区分,否则会造成接收方向无法统计。
display wlan statistics radio [ ap ap-name ] [ load ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
radio:显示AP的射频的统计信息。
ap ap-name:AP的名称,1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,不可以包含空格。如果不指定此参数,则显示所有AP的射频统计信息。
load:显示负载信息。
【描述】
display wlan statistics radio命令用来显示指定AP或所有AP的射频统计信息。
display wlan statistics radio load命令用来显示指定AP或所有AP的射频负载信息。
# 显示ap1的射频统计信息。
<Sysname> display wlan statistics radio ap1
Radio Statistics
 AP Name: ap1                                   Radio Id: 1
 Transmitted Frames Statistics:
   Total Frames (Frames/Bytes)               : 0/0
   Unicast Frames (Frames/Bytes)             : 0/0
   Broadcast/Multicast Frames (Frames/Bytes) : 0/0
   Discarded Frames                : 0          Failed RTS         : 0
   Retry Count                     : 0          Successful RTS     : 0
   Multiple Retry Count            : 0          Failed ACK         : 0
   Authentication Frames           : 0          Association Frames : 0
   Packet Count Statistics Based on Size:
     128 >= size                   : 0
     128 < size <= 512             : 0
     512 < size <= 1024            : 0
     1024 < size                   : 0
   Packet Count Statistics Based on Rate:
         6 Mbps                    : 0                   9 Mbps    : 0
        12 Mbps                    : 0                  18 Mbps    : 0
        24 Mbps                    : 0                  36 Mbps    : 0
        48 Mbps                    : 0                  54 Mbps    : 0
   Packet Count Statistics Based on MCS Rate:
       6.5 Mbps                    : 0                  13 Mbps    : 0
      13.5 Mbps                    : 0                  15 Mbps    : 0
      19.5 Mbps                    : 0                  26 Mbps    : 0
        27 Mbps                    : 0                  30 Mbps    : 0
        39 Mbps                    : 0                40.5 Mbps    : 0
        45 Mbps                    : 0                  52 Mbps    : 0
        54 Mbps                    : 0                58.5 Mbps    : 0
        60 Mbps                    : 0                  65 Mbps    : 0
        78 Mbps                    : 0                  81 Mbps    : 0
        90 Mbps                    : 0                 104 Mbps    : 0
       108 Mbps                    : 0                 117 Mbps    : 0
       120 Mbps                    : 0               121.5 Mbps    : 0
       130 Mbps                    : 0                 135 Mbps    : 0
       150 Mbps                    : 0                 162 Mbps    : 0
       180 Mbps                    : 0                 216 Mbps    : 0
       240 Mbps                    : 0                 243 Mbps    : 0
       270 Mbps                    : 0                 300 Mbps    : 0
 Received Frames Statistics:
   Fragmented Frames               : 0          Duplicate Frames   : 0
   FCS Failures                    : 0          Decryption Errors  : 0
     128 >= size                   : 0
     1024 < size                   : 0
表1-8 display wlan statistics radio命令各字段的含义描述表
AP Name
接入点名称
Radio Id
射频ID号
传输的帧的统计信息
Total Frames
传输的帧的总数,包括Probe Response帧和Beacon帧
Unicast Frames
传输的单播帧的总数,不包括Probe Response帧
传输的广播/组播帧的总数,不包括Beacon帧
Others(Frames/Bytes)
传输的其它帧的总数
Discarded Frames
丢弃的帧的数目
Retry Count
重传帧的数目
被重传的帧的数目
传输的认证帧的数目
Failed RTS
传输失败的RTS的数目
Successful RTS
传输成功的RTS数目
Failed ACK
未收到ACK消息的已传帧的数目
Association Frames
传输的关联帧的数目
基于报文尺寸统计报文数量,尺寸统计的粒度可以分为四个区间
按照802.11a/b/g无线速率分开统计报文数量
按照MCS无线速率分开统计报文数量,如设备不支持11n则不会显示该统计项
接收的帧的统计信息
Total Frames
接收的帧的总数
Unicast Frames
接收的单播帧的总数
接收的广播/组播帧的总数
Fragmented Frames
接收的分片帧的数目
FCS Failures
接收中发生FCS错误的帧的数目
接收的认证帧的数目
Duplicate Frames
接收的重复帧的数目
Decryption Errors
接收中发生解码错误的帧的数目
Association Frames
接收的关联帧的数目
#  显示所有AP的射频负载信息。
<sysname> display wlan statistics radio load
                            Radio Load
 AP Name                                Radio       Client Number
 ap1                                    1           0
 ap1                                    2           11
 ap2                                    1           20
 ap_chinanet_1                          1           5
 ap_chinanet_2                          2           35
表1-9 display wlan statistics radio load命令显示信息描述表
AP Name
接入点名称
Radio
射频ID
Client Number
关联客户端数
display wlan statistics service-template service-template-number [ connect-history ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
service-template-number:服务模板号,取值范围为1~1024。
connect-history:显示配置了指定服务模板的AP的无线客户端连接历史。
【描述】
display wlan statistics service-template命令用来显示指定服务模板的统计信息。
display wlan statistics service-template service-template-number connect-history命令用来显示指定服务模板的所有AP的连接历史信息。
# 显示服务模板office的统计信息。
<sysname> display wlan statistics service-template office
                        Service Template Statistics
Service Template           : office
AP Name                    : ap1
 Radio                      : 1
 Receive                    :
    Frame Count             : 1713
    Frame Bytes             : 487061
    Data Frame Count        : 1683
    Data Frame Bytes        : 485761
    Associate Frame Count   : 2
 Send                       :
    Frame Count             : 62113
    Frame Bytes             : 25142076
    Data Frame Count        : 55978
    Data Frame Bytes        : 22626600
表1-10 display wlan statistics service-template命令显示信息描述表
Service Template
服务模板编号
AP Name
AP名称
Receive
接收统计:
·       Frame Count:接收帧数
·       Frame Bytes:接收帧字节数
·       Data Frame Count:接收数据帧数
·       Data Frame Bytes:接收数据帧字节数
·       Associate Frame Count:接收连接请求帧数
Send
发送统计:
·       Frame Count:发送帧数
·       Frame Bytes:发送帧字节数
·       Data Frame Count:发送数据帧数
·       Data Frame Bytes:发送数据帧字节数
·       Associate Frame Count:发送连接请求帧数
#  显示所有配置了服务模板office的AP的无线客户端的连接历史。
<sysname> display wlan statistics service-template office connect-history
                            Connect History
 AP Name                    : ap1
 Radio                      : 1
 Associations               : 132
 Failures                   : 3
 Reassociations             : 30
 Rejections                 : 12
 Current Associations       : 57
 AP Name                    : ap1
 Radio                      : 2
 Associations               : 1004
 Failures                   : 35
 Reassociations             : 59
 Rejections                 : 4
 Exceptional Deassociations : 22
 Current Associations       : 300
表1-11 display wlan statistics service-template connect-history命令显示信息描述表
Service Template
服务模板编号
AP Name
AP名称
Radio
射频编号
Associations
累计关联统计
Failures
累计关联失败统计
Reassociations
累计重关联统计
Rejections
累计拒绝无线客户端连接统计
累计异常中断关联统计
当前关联次数统计
1.2.26  distance
distance distance
undo distance
射频视图
【缺省级别】
2:系统级
distance:射频可覆盖的最远距离,单位为公里。取值范围为1~40。
【描述】
distance命令用来配置射频可覆盖的最远距离。undo distance命令用来恢复缺省情况。
缺省情况下,射频可覆盖的最远距离为1公里。
# 配置射频可覆盖的最远距离为5公里。
[Sysname-wlan-ap-ap1-radio-1] distance 5
1.2.27  dtim
dtim counter
undo dtim
射频策略视图
【缺省级别】
2:系统级
counter:DTIM(Delivery Traffic Indication Message,数据待传指示信息)帧间的信标数,取值范围为1~31。例如,配置counter值为1,则每个信标帧中都会携带DTIM信息。
【描述】
dtim命令用来在AP发送缓存的多播帧或广播帧之前,为其设置信标帧的DTIM计数器。undo dtim命令用来恢复缺省情况。
缺省情况下,DTIM计数器为1。
当DTIM计数达到0时,AP才会发送缓存中的多播帧或广播帧。
# 配置DTIM计数器为10。
[Sysname] wlan radio-policy rp
[Sysname-wlan-rp-rp] dtim 10
undo fast-association enable
服务模板视图
【缺省级别】
2:系统级
无。
【描述】
fast-association enable命令用来开启快速关联功能。undo fast-association enable命令用来关闭快速关联功能。
缺省情况下,快速关联功能处于关闭状态。
开启此功能后,设备不会对关联到此SSID的客户端进行频谱导航和负载均衡计算。
# 开启快速关联功能。
[Sysname-wlan-st-1] fast-association enable
fragment-threshold size
undo fragment-threshold
射频策略视图
【缺省级别】
2:系统级
【描述】
fragment-threshold命令用来配置帧的分片门限值,即数据包无分片传输的最大包长。undo fragment-threshold命令用来恢复缺省情况。
缺省情况下,帧的分片门限值为2346字节,即小于2346字节的帧在传输时不分片。
当数据包的实际大小超过指定的分片门限值时,该数据包被分片传输。
# 配置帧的分片门限值为2048字节。
[Sysname-wlan-rp-rp] fragment-threshold 2048
long-retry threshold count
undo long-retry threshold
射频策略视图
【缺省级别】
2:系统级
count:帧长超过RTS(Request to Send,发送请求)门限值的帧的最大重传次数,取值范围为1~15。
【描述】
long-retry threshold命令用来设置帧长超过RTS门限值的帧的最大重传次数。undo long-retry threshold命令用来恢复缺省情况。
缺省情况下,帧长超过RTS门限值的帧的最大重传次数为4。
# 配置帧长超过RTS门限值的帧的最大重传次数为10。
[Sysname-wlan-rp-rp] long-retry threshold 10
1.2.31  max-power
max-power radio-power
undo max-power
射频视图
【缺省级别】
2:系统级
radio-power:射频的最大传输功率,其取值范围由国家码和射频模式决定。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
【描述】
max-power命令用来配置射频的最大传输功率。undo max-power命令用来恢复缺省情况。
缺省情况下,射频的最大功率和国家码、信道、AP型号、射频模式和天线类型相关,如果采用802.11n射频模式,那么射频的最大功率和带宽模式也相关。
相关配置可参考命令wlan country-coderadio type
# 配置射频的最大传输功率为5。
[Sysname-wlan-ap-ap3-radio-1] max-power 5
max-rx-duration interval
undo max-rx-duration
射频策略视图
【缺省级别】
2:系统级
interval:AP接收到的帧可以在缓存区保存的最长时间,取值范围为500~250000,单位为毫秒。
【描述】
max-rx-duration命令用来配置AP接收的帧可以在缓存中保存的最长时间。undo max-rx-duration命令用来恢复缺省情况。
缺省情况下,AP接收的帧可以在缓存中保存的最长时间为2000毫秒。
# 配置AP接收的帧可以在缓存中保存的最长时间为5000毫秒。
[Sysname-wlan-rp-radio1] max-rx-duration 5000
1.2.33  nas-id
nas-id text
undo nas-id
AP模板视图
【缺省级别】
2:系统级
text:设置AP的NAS-ID编号,为1~20个字符的字符串,区分大小写。
【描述】
nas-id命令用来设置AP的NAS-ID编号。undo nas-id命令用来清除AP的NAS-ID编号。
缺省情况下,没有为AP配置NAS-ID编号。
# 将ap1的NAS-ID设置为 0002053110000460。
[Sysname-ap-ap1] nas-id 0002053110000460
1.2.34  nas-port-id
nas-port-id text
undo nas-port-id
AP模板视图
【缺省级别】
2:系统级
text绑定到AP管理实体的NAS-PORT-ID,1~63个字符的字符串,区分大小写。
【描述】
nas-port-id命令用来配置AP的NAS-PORT-ID的内容。undo nas-port-id命令用来删除AP的nas-port-id的内容。
缺省情况下,没有为AP配置NAS-PORT-ID。
# 配置基于AP的NAS-PORT-ID。
[Sysname-ap-ap1] nas-port-id abcd1234
1.2.35  power lock
power lock
undo power lock
射频视图
【缺省级别】
2:系统级
【描述】
power lock命令用来锁定功率,并将RRM自动功率调整的当前功率设置为射频的最大功率(即设置射频的max-power为当前功率。undo power lock命令用来解除功率锁定,并将射频的最大功率max-power设置为当前射频配置下允许的最大功率。
缺省情况下,功率没有被锁定。
需要注意的是,如果先配置power lock命令,后开启功率调整功能,由于功率已经被锁定,功率调整功能不会运行,所以在开启功率调整功能前,请确保功率没有被锁定。如果先开启功率调整功能,后配置power lock命令,最后一次调整的功率将会被锁定。
关于功率调整功能的详细介绍,请参见“WLAN配置指导”中的“WLAN RRM配置”。
相关配置可参考命令max-power、“WLAN命令参考/WLAN RRM配置命令”中的dot11a calibrate-powerdot11bg calibrate-power命令。
# 锁定当前的功率值。
[Sysname-wlan-ap-ap3-radio-1] power lock
1.2.36  preamble
preamble { long | short }
undo preamble
射频视图
【缺省级别】
2:系统级
long:指定只传输有long前导码的帧。
short:指定传输有shortlong前导码的帧。
【描述】
preamble命令用来配置AP支持的前导码类型。undo preamble命令用来恢复缺省情况。
缺省情况下,支持short前导码。
前导码是位于数据包起始处的一组bit位,接收者可以据此同步并准备接收实际的数据。前导码有两种:longshort
802.11a和802.11an不支持此项配置。
# 配置AP支持long前导码。
[Sysname] wlan ap ap2 model WA2100
[Sysname-wlan-ap-ap2] radio 1 type dot11b
[Sysname-wlan-ap-ap2-radio-1] preamble long
protection-mode { cts-to-self | rts-cts }
undo protection-mode
射频策略视图
【缺省级别】
2:系统级
cts-to-self:CTS-to-Self方式。
rts-cts:RTS/CTS方式。
【描述】
protection-mode命令用来配置分片门限保护方式,当AP发送的数据包的实际大小超过分片门限值时,将采用指定的保护方式。undo protection-mode命令用来恢复缺省情况。
缺省情况下,分片门限保护方式为RTS/CTS。
关于CTS-to-Self方式和RTS/CTS方式的介绍请参见“WLAN配置指导”的“WLAN RRM配置”。
# 配置分片门限保护方式为CTS-to-Self。
[Sysname] wlan radio-policy test
[Sysname-wlan-rp-test] protection-mode cts-to-self
1.2.38  radio
radio { disable | enable }
undo radio
射频视图
【缺省级别】
2:系统级
disable:禁用射频。
enable:启用射频。
【描述】
radio命令用来启用或禁用AP的当前射频。undo radio命令用来取消当前配置。
缺省情况下,所有射频都处于禁用状态。
# 启用AP的radio 1。
[Sysname-wlan-ap-ap3-radio-1] radio enable
1.2.39  radio-policy
radio-policy radio-policy-name
undo radio-policy
射频视图
【缺省级别】
2:系统级
radio-policy-name:射频策略模板名称,为1~15个字符的字符串,可以包含字母、数字和下划线,不区分大小写,不可以包含空格。
【描述】
radio-policy命令用来将射频策略映射到射频。undo radio-policy命令用来取消射频策略与射频的映射。
缺省情况下,default_rp射频策略映射到射频。default_rp射频策略包含所有缺省的参数设置。
在映射自定义射频策略前,需要使用wlan radio-policy命令创建自定义的射频策略。
相关配置可参考命令display wlan radio-policywlan radio-policy
# 配置radio1的射频策略为radiorp。
[Sysname-wlan-ap-ap3-radio-1] radio-policy radiorp
1.2.40  radio type
radio radio-number [ type { dot11a | dot11an | dot11b | dot11g | dot11gn } ]
AP模板视图
【缺省级别】
2:系统级
radio-number:AP支持的射频号。实际的取值与AP设备的型号有关,请以设备的实际情况为准。
dot11a指定无线射频类型为802.11a。
dot11an:表示无线接口工作在5GHZ的802.11an模式。
dot11b指定无线射频类型为802.11b。
dot11g指定无线射频类型为802.11g。
dot11gn:表示无线接口工作在2.4GHZ的802.11gn模式。
【描述】
radio type命令用来配置射频使用的射频类型,并进入射频视图。
本命令的缺省情况与AP设备的型号有关,请以设备的实际情况为准。
# 配置射频接口radio1的射频类型为802.11g。
# 配置射频接口radio1的工作模式为工作在5GHz的802.11an。
[sysname] wlan ap ap1 model WA2620-AGN
[sysname-wlan-ap-ap1] radio 1 type dot11an
reset wlan statistics { client { all |  mac-address mac-address } | radio [ ap-name ] }
【缺省级别】
2:系统级
all:重置所有无线客户端的统计信息。
【描述】
reset wlan statistics命令用来清除指定AP、指定无线客户端或全部无线客户端的统计信息。
# 清除AP1射频的统计信息。
<Sysname> reset wlan statistics radio ap1
reset wlan client { all | mac-address mac-address }
【缺省级别】
2:系统级
all:断开所有无线客户端同AP的连接。
mac-address mac-address:设置将要被断开连接的无线客户端的MAC地址。
【描述】
reset wlan client命令用来断开所有或指定的无线客户端同AP的连接。
执行这条命令后,AP将向无线客户端发送解除认证帧,同时停止对无线客户端提供WLAN业务。
# 断开MAC地址为 000f-e2cc-8501的无线客户端同AP的连接。
<Sysname> reset wlan client mac-address 000f-e2cc-8501
rts-threshold size
undo rts-threshold
射频策略视图
【缺省级别】
2:系统级
【描述】
rts-threshold命令用来设置启用RTS机制所要求的帧的长度门限值。undo rts-threshold命令用来恢复缺省情况。
缺省情况下,启用RTS机制所要求的帧长度门限值为2346字节。
当帧的实际长度大于设定的门限值时,则系统启用RTS机制。
RTSRequest To Send,要求发送)用于在无线局域网中避免数据发送冲突。RTS包的发送频率需要合理设置,设置RTS门限时需要进行权衡,如果将这个参数值设得较小,则会增加RTS包的发送频率,消耗更多的带宽。但RTS包发送得越频繁,系统从中断或冲突中恢复得就越快。
# 设置启用RTS机制所要求的帧的最小长度为2046字节。
[Sysname-wlan-rp-rp] rts-threshold 2046
service-template service-template-number [ vlan-id vlan-id1 [vlan-id2] ] [ nas-port-id nas-port-id | nas-id nas-id ] [ ssid-hide ]
undo service-template service-template-number
射频视图
【缺省级别】
2:系统级
service-template-number:设置服务模板号,取值范围为1~1024。
vlan-id vlan-id1 vlanid2:设置绑定到射频接口的VLAN,可以选择设置两个VLAN以支持QinQ应用,取值范围为1~1024。
nas-port-id nas-port-id:设置绑定到射频接口的NAS-PORT-ID编号,为1~63个字符的字符串,不区分大小写,不能包含空格。
nas-id nas-id:设置绑定到射频接口的NAS-ID编号,为1~20个字符的字符串,不区分大小写,不能包含空格。
ssid-hide:设置绑定的无线服务所对应的信标帧隐藏SSID。如果未配置此参数,则以service-template中是否配置在信标帧中隐藏SSID为准,相关命令请参见beacon ssid-hide
【描述】
service-template命令用来将服务模板映射到当前的射频。undo service-template命令用来解除服务模板和当前射频的映射。
缺省情况下,没有服务模板映射到当前射频。
可以将多个服务模板映射到当前射频。
# 将服务模板1映射到射频1。
[Sysname-wlan-ap-ap3-radio-1] service-template 1
service-template { disable | enable }
undo service-template enable
服务模板视图
【缺省级别】
2:系统级
disable:关闭服务模板。
enable:开启服务模板。
【描述】
service-template enable命令用来开启服务模板。service-template disableundo service-template enable命令用来关闭服务模板。
缺省情况下,服务模板处于关闭状态。
# 开启服务模板1。
[Sysname-wlan-st-1] ssid clear
[Sysname-wlan-st-1] authentication-method open-system
[Sysname-wlan-st-1] service-template enable
short-gi enable
undo short-gi enable
射频视图
【缺省级别】
2:系统级
【描述】
short-gi enable用来开启Short GI功能。undo short-gi enable关闭Short GI功能。
缺省情况下,Short GI功能处于开启状态。
需要注意的是,该命令仅在支持802.11n的接口上存在。在进行接口模式切换的时候,设备会恢复该模式下该功能的缺省情况。
无线信号在空间传输时会因多径等因素在接收侧形成时延,如果后面的数据块发送过快,会对前一个数据块形成干扰,Short GI(Guard Interval,保护间隔)可以用来规避这种干扰。
802.11a/g的GI时长为800ns,802.11n可以配置使用Short GI,Short GI时长为400ns。在使用Short GI的情况下,可提高10%的无线吞吐量。
# 禁止Short GI特性。
[sysname-wlan-ap-ap3-radio-1] undo short-gi enable
short-retry threshold count
undo short-retry threshold
射频策略视图
【缺省级别】
2:系统级
count:设置AP在未收到确认的情况下,帧长不大于RTS门限值的单播帧的最大重传次数,取值范围为1~15。
【描述】
short-retry threshold命令用来设置帧长不大于RTS门限值的单播帧的最大重传次数。undo short-retry threshold命令用来恢复为缺省情况。
缺省情况下,帧长不大于RTS门限值的单播帧的最大重传次数为7。
# 设置帧长不大于RTS门限值的单播帧的最大重传次数为10。
[Sysname-wlan-rp-rp] short-retry threshold 10
shut-all-led enable
undo shut-all-led enable
AP模板视图
【缺省级别】
2:系统级
【描述】
shut-all-led enable命令用来关闭当前模板下上线的所有AP设备的所有指示灯。undo shut-all-led enable命令用来恢复缺省情况。
缺省情况下,当前模板下上线的所有AP设备的所有指示灯是按照设备正常工作状态亮灯的。
# 配置ap5模板下所有上线AP关闭所有指示灯。
<Sysname>system-view
[Sysname]wlan ap ap5 model WA2620-AGN
[Sysname-wlan-ap-ap5]shut-all-led enable
1.2.49  ssid
ssid ssid-name
undo ssid
服务模板视图
【缺省级别】
2:系统级
ssid-name:设置SSID的名称。为1~32个字符的字符串,可以包含字母、数字及下划线,区分大小写,可以包含空格。
【描述】
ssid命令用来设置当前服务模板的SSID。undo ssid命令用来删除当前服务模板的SSID。
缺省情况下,没有设置SSID。
SSID的名称应该尽量具有唯一性。从安全方面考虑不应该体现公司名称,也不推荐使用长随机数序列做为SSID,因为长随机数序列只是增加了头域负载,对无线安全没有改进。
# 设置服务模板1的SSID为firstfloor。
[Sysname-wlan-st-1] ssid firstfloor
1.2.50  trap enable
trap enable
undo trap enable
AP模板视图
【缺省级别】
2:系统级
【描述】
trap enable命令用来开启AP告警信息。undo trap enable命令用来关闭AP告警信息。
缺省情况下,AP告警信息开启。
# 开启AP的告警信息。
<AC>system-view
[AC]wlan ap ap2 model WA2610-AGN id 2
[AC-wlan-ap-ap2] trap enable
[AC-wlan-ap-ap2]device-detection enable
[AC-wlan-ap-ap2]
#Nov 19 14:10:30:003 2009 H3C WMAC/4/AP WorkMode Changed: Work mode of AP change
d:1.3.6.1.4.1.2011.10.2.75.2.3.0.1<h3cDot11APMtWorkModeChgTrap> Serial ID:210235
A35XB09B000008 WorkMode: 3
wlan country-code code
undo wlan country-code
【缺省级别】
2:系统级
code:国家码。国家码和国家名的对应关系请参见表1-12
表1-12 国家码对应的国家名
国家名
国家代码
国家名
国家代码
安道尔
AD
肯尼亚
KE
阿拉伯联合酋长国
AE
科威特
KW
阿尔巴尼亚
AL
哈萨克斯坦
KZ
亚美尼亚
AM
黎巴嫩
LB
澳大利亚
AU
列支郭士登
LI
阿根廷
AR
斯里兰卡
LK
奥地利
AT
立陶宛
LT
阿塞拜疆
AZ
卢森堡
LU
波斯尼亚和黑塞哥维那
BA
拉脱维亚
LV
比利时
BE
利比亚
LY
保加利亚
BG
摩洛哥
MA
巴林
BH
摩纳哥
MC
文莱
BN
摩尔多瓦
MD
玻利维亚
BO
马其顿王国
MK
巴西
BR
中国澳门
MO
巴哈马群岛
BS
马提尼克岛
MQ
白俄罗斯
BY
马耳他
MT
伯利兹
BZ
毛里求斯
MU
加拿大
CA
墨西哥
MX
瑞士
CH
马来群岛
MY
科特迪瓦
CI
纳米比亚
NA
智利
CL
尼日利亚
NG
中国
CN
尼加拉瓜
NI
哥伦比亚
CO
荷兰
NL
哥斯达黎加
CR
挪威
NO
塞尔维亚
RS
新西兰
NZ
塞浦路斯
CY
阿曼
OM
捷克斯洛伐克
CZ
巴拿马
PA
德国
DE
秘鲁
PE
丹麦
DK
波兰
PL
多米尼亚共和国
DO
菲律宾
PH
阿尔及利亚
DZ
巴基斯坦
PK
厄瓜多尔
EC
波多黎各
PR
爱沙尼亚
EE
葡萄牙
PT
埃及
EG
巴拉圭
PY
西班牙
ES
卡塔尔
QA
法罗群岛
FO
罗马尼亚
RO
芬兰
FI
俄罗斯
RU
法国
FR
沙特阿拉伯
SA
英国
GB
瑞典
SE
格鲁吉亚
GE
新加坡
SG
直布罗陀
GI
斯洛文尼亚
SI
格陵兰
GL
斯洛伐克
SK
瓜德罗普岛
GP
圣马力诺
SM
希腊
GR
萨尔瓦多
SV
危地马拉
GT
叙利亚共和国
SY
圭亚那
GY
泰国
TH
洪都拉斯
HN
突尼斯
TN
中国香港
HK
土耳其
TR
克罗地亚
HR
特立尼达和多巴哥
TT
匈牙利
HU
中国台湾
TW
冰岛
IS
乌克兰
UA
印度
IN
印度尼西亚
ID
爱尔兰
IE
美国
US
以色列
IL
乌拉圭
UY
伊拉克
IQ
乌兹别克斯坦
UZ
意大利
IT
梵蒂网
VA
伊朗
IR
委内瑞拉
VE
牙买加
JM
处女岛
VI
约旦
JO
越南
VN
日本
JP
也门
YE
朝鲜
KP
南非
ZA
韩国
KR
津巴布韦
ZW
【描述】
wlan country-code命令用来配置全局国家码。undo wlan country-code命令用来恢复缺省情况。
缺省情况下,全局国家码为CN。
·       在配置WLAN设备时,必须正确地设置国家或地区码,以确保不违反当地的管制规定。
·       若在AP模板视图下已经配置AP国家码或AP的国家码已遵照相应国家或地区的管制要求进行了锁定,则修改全局国家码的配置不会影响AP的国家码。
# 配置全局国家码为美国。
[Sysname] wlan country-code us
wlan link-test mac-address
【缺省级别】
1:监控级
mac-address:要进行链路测试的无线客户端的MAC地址,仅允许测试已关联的无线客户端。
【描述】
wlan link-test命令用来对无线客户端进行RFPing操作。
# 对MAC地址为000f-e201-0101的无线客户端进行RFPing操作。
<Sysname> wlan link-test 000f-e201-0101
Testing link to 000f-e201-0101, press CTRL_C to break......
                                  Link Status
 RTT: Round trip time
 MAC Address: 000f-e201-0101
 No.    Rate(Mbps)  TxCnt   RxCnt   RSSI    Retries     RTT(ms)
 0      1           5       2       62      0           0
 1      2           5       5       10      0           0
 2      5.5         5       5       10      0           1
 3      6           5       5       10      0           0
 4      9           5       5       11      0           0
 5      11          5       5       11      0           0
 6      12          5       5       10      0           0
 7      18          5       5       10      0           0
 8      24          5       5       11      0           0
 9      36          5       5       11      0           0
 10     48          5       5       10      0           0
 11     54          5       5       11      0           0
表1-13 RFPing操作结果
No./MCS
·       对非802.11n客户端进行RFPing操作后,链路测试结果中会显示No.字段,表示非802.11n客户端的速率编号
·       对802.11n客户端进行RFPing操作后,链路测试结果中会显示MCS字段,表示802.11n客户端的MCS索引值
Rate(Mbps)
Radio接口发送无线Ping包的速率
TxCnt
Radio接口发送无线Ping包的个数
RxCnt
Radio接口收到客户端回应无线Ping包的个数
RSSI
接收信号强度指示,该值表明了AP检测到客户端的信号强度
Retries
Radio接口发送无线Ping包失败时的重传总次数
RTT(ms)
从Radio接口发出无线Ping包到收到客户端回应的平均往返时间
1.2.53  wlan radio
wlan radio { disable | enable } { all | dot11a | dot11an | dot11b | dot11g | dot11gn | radio-policy radio-policy-name }
【缺省级别】
2:系统级
disable:禁用一个或全部wlan射频。
enable:开启一个或全部wlan射频。
all:所有wlan射频。
dot11a:无线射频类型为802.11a的射频。
dot11an:无线射频类型为802.11an的射频。
dot11b:无线射频类型为802.11b的射频。
dot11g:无线射频类型为802.11g的射频。
dot11gn:无线射频类型为802.11gn的射频。
radio-policy radio-policy-name:设置射频策略的名称,为1~15个字符的字符串,可以包含字母、数字和下划线,不区分大小写,不可以包含空格。
【描述】
wlan radio enable命令用来开启全部或者指定射频策略的射频。wlan radio disable命令用来禁用全部或者指定射频策略的射频。
缺省情况下,WLAN射频处于禁用状态。
# 开启所有WLAN射频。
[Sysname] wlan radio enable all
# 开启802.11g射频。
[Sysname] wlan radio enable dot11g
wlan radio-policy radio-policy-name
undo wlan radio-policy radio-policy-name
【缺省级别】
2:系统级
【描述】
wlan radio-policy命令用来创建射频策略或进入一个射频策略视图。undo wlan radio-policy命令用来删除射频策略,并清除相关的配置。
缺省情况下,缺省射频策略default_rp映射到WLAN射频。
射频策略用来设置射频信号的属性。如果射频策略映射到射频,则此射频将会拥有所有在射频策略中配置的属性。
WLAN射频策略包括如下属性:
·              射频策略名称
·              分片门限值(字节)
·              信标帧间隔(TU,1024微秒)
·              RTS门限值(字节)
·              DTIM周期(信标帧间隔)
·              长帧(帧长大于RTS门限值的帧)最大重传次数
·              短帧(帧长不大于RTS门限值的帧)最大重传次数
·              AP接收的帧可以在缓存中保存的最大时间(毫秒)
如果射频策略已经映射到WLAN射频,则在解除映射之前,射频策略不能被删除。
# 创建一个名为radio1的射频策略。
undo wlan radio-policy auto-create
【缺省级别】
2:系统级
【描述】
wlan radio-policy auto-create命令用来开启Radio-Policy自动创建功能。
undo wlan radio-policy auto-create命令用来关闭Radio-Policy自动创建功能。
缺省情况下,自动创建Radio-Policy功能关闭。
# 打开自动创建Radio-Policy功能。
[Sysname]wlan radio-policy auto-create
# 关闭自动创建Radio-Policy功能。
[Sysname]undo wlan radio-policy auto-create
wlan service-template service-template-number { clear | crypto | wapi }
undo wlan service-template service-template-number
【缺省级别】
2:系统级
service-template-number:设置服务模板号。取值范围是1~1024。
clear:设置当前服务模板为明文方式,即无线客户端与AP关联后使用明文方式发送数据。
crypto:设置当前服务模板为密文方式,即无线客户端与AP关联后使用密文方式发送数据。
wapi:设置当前服务模板类型为WAPI方式,即无线客户端与AP关联后使用WAPI方式发送数据。
【描述】
wlan service-template命令用来创建服务模板或进入服务模板视图。如果输入的服务模板已经存在,则直接进入该视图。undo wlan service-template命令用来删除一个服务模板并清除相关的配置。如果指定的服务模板映射到射频,则在解除映射之前不能删除此服务模板。
缺省情况下,没有配置任何服务模板。
不能修改已创建的服务模板的类型,只能先删除该服务模板,再重新创建。
# 创建一个新的服务模板,服务模板号为1。
[Sysname] wlan service-template 1 crypto
1.3  AC-AP间隧道配置命令
1.3.1  ac
ac { host-name host-name | ip ip-address | ipv6 ipv6-address }
undo ac { host-name | ip { ip-address | all } | ipv6 { ipv6-address | all } }
AP配置视图
【缺省级别】
2:系统级
host-name host-name:AC的主机名,为1~255个字符的字符串,不区分大小写,字符串中可以包含字母、数字、“-”、“_”或“.”,且必须至少包含一个字母。
ip ip-address:AC的IPv4地址。
ipv6 ipv6-address:AC的IPv6地址。
all:删除AC的所有IPv4/IPv6地址。
【描述】
ac命令用来配置AC的IP地址,使指定AP能够静态发现AC。undo ac命令用来删除已有配置。
缺省情况下,没有配置AC的IP地址。
最多可配置3个AC的IP地址、3个AC的IPv6地址以及1个AC的主机名。
wlan ap-provision ac命令对所有AP生效,AP配置视图下的ac命令只对指定的AP生效,如果都进行了配置,则优先采用AP配置视图下的配置。
相关配置可参考命令wlan ap-provision ac
# 配置AC的IPv4地址为192.168.100.11,使AP 1能够静态发现AC。
[Sysname-wlan-ap-ap1] provision
[Sysname-wlan-ap-ap1-prvs] ac ip 192.168.100.11
1.3.2  ap-name
ap-name name
undo ap-name
AP模板视图
【缺省级别】
2:系统级
【描述】
ap-name命令用于设置当前AP的名称。undo ap-name命令用于删除AP的名称。
缺省情况下,没有设置AP名称。
# 设置AP名称为admin。
[Sysname-ap-ap1] ap-name admin
1.3.3  backup-ac
backup-ac { ip ipv4-address | ipv6 ipv6-address }
undo backup-ac { ip | ipv6 }
AP模版视图
【缺省级别】
2:系统级
ipv4-address:指定备份AC的IPv4地址。
ipv6-address:指定备份AC的IPv6地址。
【描述】
backup-ac命令用来配置备份AC的IP地址。undo backup-ac取消配置的备份AC的IP地址。
缺省情况下,备份AC的IP地址为系统视图下配置的全局备份AC的IP地址。
如果在系统视图和AP模板视图下配置了相同参数,则不论配置先后,AP模板视图下的配置将被优先采用。
# 配置ap1的备份AC的IP地址为192.168.1.2。
[Sysname] wlan backup-ac ip 192.168.1.1
[Sysname-wlan-ap-ap1] backup-ac ip 192.168.1.2
1.3.4  cir
cir committed-information-rate [ cbs committed-burst-size ]
undo cir
AP模板视图
【缺省级别】
2:系统级
cir committed-information-rate:承诺信息速率,取值范围为40~1000000,单位Kbps。
cbs committed-burst-size:承诺突发尺寸,取值范围为2500~62500000,缺省取值为500毫秒以CIR速率通过的流量,单位为Bytes。
【描述】
cir命令用来限制AC向AP发送数据报文的速率。undo cir命令用来恢复缺省情况。
缺省情况下,不限制AC向AP发送数据报文的速率。
相关配置可参考“ACL和QoS命令参考/QoS策略配置命令”中的命令car命令。
# 限制无线控制器向ap_001发出数据报文的速率,承诺速率为60Kbps,承诺突发尺寸为3000 Bytes。
[Sysname] wlan ap ap_001 model wa2100
[Sysname-wlan-ap-ap_001] cir 60 cbs 3000
cpu-usage threshold integer
AP模板视图
【缺省级别】
3:管理级
Integer:取值范围为0~100的整数。
【描述】
cpu-usage threshold命令用来设置AP的CPU利用率阈值,如果AP的CPU利用率超过了设定的阈值,则AP会发出告警。
缺省情况下,AP的默认CPU利用率阈值为90。
# 设置AP的CPU利用率阈值不超过95%。
[Sysname-wlan-ap-ap3] cpu-usage threshold 95
undo data-tunnel encryption enable
AP配置视图
【缺省级别】
2:系统级
【描述】
data-tunnel encryption enable命令用来配置AP使用IPsec密钥加密数据隧道。undo data-tunnel encryption enable命令用来取消AP加密数据隧道。
缺省情况下,AP不对数据隧道进行加密。
相关配置可参考命令tunnel encryption ipsec pre-shared-key
# 配置AP使用IPsec密钥加密数据隧道。
[Sysname-wlan-ap-ap1-prvs] tunnel encryption ipsec pre-shared-key simple 12345
[Sysname-wlan-ap-ap1-prvs] data-tunnel encryption enable
1.3.7  description
AP模板视图
【缺省级别】
2:系统级
text:网络中AP的描述信息。1~64个字符的字符串,可以包含特殊字符及空格,区分大小写。如果空格符位于描述信息的开头或结尾时,则会被丢弃。
【描述】
description命令用来设置AP当前情况的描述信息。undo description命令用来清除AP的描述信息。
缺省情况下,没有设置描述信息。
# 设置管理实体名为ap1的接入点的描述信息。
[Sysname-ap-ap1] description L3-office
display wlan ap { all | name ap-name } [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:所有AP。
verbose:显示指定AP或全部AP的详细信息。
【描述】
display wlan ap命令用来显示指定AP或所有AP的信息。
# 显示ap 1的配置信息。
<Sysname> display wlan ap name ap1
                                  AP Profile
State : I = Idle,   J = Join, JA = JoinAck,   IL = ImageLoad
        C = Config, R = Run,  KU = KeyUpdate, KC = KeyCfm
 AP Name                               State  Model           Serial-ID
 ap                                    R/M   WA2620-AGN       210235A35V0088000005
表1-14 display wlan ap命令显示信息描述表
AP的当前状态:
·       I:空闲状态
·       J:加入状态
·       JA:加入确认
·       IL:下载版本状态
·       C:配置交互状态,该状态为瞬间状态。表示AC正在向Fit AP下发配置文件;Fit AP通过Radio口收集射频信息,然后上报AC
·       R:运行状态。该状态表示AP和AC已经建立连接。如果配置了AC备份功能,该状态会携带AC的主备状态。Run/M表示AC为主用AC,Run/B 表示AC为备份AC
·       KU:密钥更新状态
·       KC:密钥更新确认状态
# 显示ap 1的详细配置信息。
<Sysname> display wlan ap name ap1 verbose
                         AP Profile: ap1
 APID                          : 1
 AP System Name                : Not Configured
 Map Configuration             : Not Configured
 State                         : Run
 Up Time(hh:mm:ss)             : 00:01:04
 Model                         : WA2620-AGN
 Serial-ID                     : 210235A35V0088000005
 IP Address                    : 192.168.100.99
 H/W Version                   : Ver.A
 S/W Version                   : V100R001B96D001
 Boot-Rom Version              : 1.20
 Description                   : Not Configured
 Connection Type               : Master
 Peer AC MAC Address           : -NA-
 Priority Level                : 4
 Echo Interval(s)              : 10
 Statistics report Interval(s) : 50
 Cir(Kbps)                     : -NA-
 Cbs(Bytes)                    : -NA-
 Jumboframe Threshold          : Disable
 Transmitted control packets   : 372
 Received control packets      : 372
 Transmitted data packets      : 104
 Received data packets         : 370
 Configuration Failure Count   : 0
 Last Failure Reason           :
 Last Reboot Reason            : Tunnel Initiated
 Latest IP Address             : 192.168.100.99
 Tunnel Down Reason            : Neighbor Dead Timer Expire
 Connection Count              : 3
 AP Mode                       : Split
 AP operation mode             : Normal
 Portal Service                : Disable
 Device Detection              : Disable
 Maximum Number of Radios      : 2
 Current Number of Radios      : 2
 Client Keep-alive Interval    : Disable
 Client Idle Interval(s)       : 3600
 Broadcast-probe Reply Status  : Enable
 Radio 1:
   Basic BSSID                 : 000f-e233-9000
   Current BSS Count           : 1
   Running Clients Count       : 0
   Wireless Mode               : 11an
   Client Dot11n-only          : Disabled
   Channel Band-width          : 20/40MHz
   Secondary Channel Offset    : SCA
   HT Protection Mode          : no protection
   Short GI for 20MHz          : Not supported
   Mandatory MCS Set           :
   Support MCS Set             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
   A-MSDU                      : Enabled
   A-MPDU                      : Enabled
   Configured Channel          : auto<149>
   Configured Power (dBm)      : 24
   Interference (%)            : -NA-
   Channel Load (%)            : -NA-
   Utilization (%)             : -NA-
   Co-channel Neighbor Count   : -NA-
   Channel Health              : -NA-
   Radio Policy                : 257
   Service Template            : 1
   SSID                      : office
   Port                      : WLAN-DBSS0:6
   Mesh Policy                 : default_mp_plcy
   ANI Support                 : Enable
   Admin State                 : UP
   Physical State              : UP
   Operational Rates (Mbps):
     6                         : mandatory
     9                         : supported
     12                        : mandatory
     18                        : supported
     24                        : mandatory
     36                        : supported
     48                        : supported
     54                        : supported
   Radar detected Channels     : None
   Antenna Type                : TLB-5000-2HW 2dBi Omni Antenna
   Resource Using Ratio (%)    : 0
   Noise Floor (dBm)           : 0
 Radio 2:
   Basic BSSID                 : 000f-e233-9010
   Running Clients Count       : 1
   Secondary Channel Offset    : SCN
   Short GI for 40MHz          : Not supported
   Mandatory MCS Set           :
   A-MSDU                      : Enabled
   A-MPDU                      : Enabled
   Configured Channel          : auto<11>
   Configured Power (dBm)      : 19
   Preamble Type               : short
   Radio Policy                : 258
     SSID                      : office
     Port                      : WLAN-DBSS0:7
   11g Protection              : Disable
   Admin State                 : UP
   Physical State              : UP
     1                         : mandatory
     2                         : mandatory
     5.5                       : mandatory
     6                         : supported
     9                         : supported
     11                        : mandatory
     12                        : supported
     18                        : supported
     24                        : supported
     36                        : supported
     48                        : supported
     54                        : supported
   Antenna Type                : TLB-2400-2HW 2dBi Omni Antenna
表1-15 display wlan ap命令显示信息描述表
APID
接入点标识
Map Configuration
映射到AP的配置文件
AP System Name
接入点系统名称
AP的当前状态:
(1)    ImageDownload:下载版本状态。如果该字段长时间处于ImageDownload状态,请确认:
·       AC上放置的Fit AP的版本和AC需要配套的版本是否匹配;
·       Fit AP的Flash的空间是否足够
(2)    Idle:空闲状态。如果该字段一直处于Idle状态,可以通过以下方式进行排查:
·       如果“Latest IP Address”和“Tunnel Down Reason”内容为“-NA-”,则说明该AP从来没有成功和AC建立连接。请确认使用的网线是否合格;保证Fit AP设备的供电是否存在问题;如果使用手工输入序列号,请确认输入的AP序列号是否正确。
·       如果“Latest IP Address”和“Tunnel Down Reason”有其他显示内容,则表示AC和Fit AP之间曾经建立过连接,详细的原因可参考Tunnel Down Reason显示信息
(3)    Run:运行状态。该状态表示AP和AC已经建立连接。如果配置了AC备份功能,该状态会携带AC的主备状态。
(4)    Config:配置交互状态,该状态为瞬间状态。表示AC正在向Fit AP下发配置文件;Fit AP通过Radio口收集射频信息,然后上报AC
Up Time(hh:mm:ss)
AP连接到无线控制器的持续时间,NA表示AP没有连接到无线控制器
Model
AP的型号名
Serial-ID
AP的序列ID
IP Address
AP的IP地址
H/W Version
AP的硬件版本
S/W Version
AP的软件版本
Boot-Rom version
AP的BootWare版本
AP的描述信息
Connection Type
连接类型。包括Master和Backup
Peer AC MAC Address
双AC备份环境下,对端AC的MAC地址
Priority Level
无线控制器上AP连接的优先级
Echo Interval(s)
两次回声请求之间的时间间隔,单位为秒
两次统计信息消息的时间间隔,单位为秒
Cir (Kbps)
承诺信息速率
Cbs (Bytes)
承诺突发尺寸
Jumbo帧的门限值
发送的控制报文数量
接收的控制报文数量
发送的数据报文数量
接收的数据报文数量
AP到了Run状态后,下发配置的错误次数
Last Failure Reason
最近一次下发配置失败的原因
Last Reboot Reason
最后一次重启的原因:
·       Normal:表示AP断电重启
·       Crash:AP发生异常Crash
·       Tunnel Initiated:AC上执行了reset wlan ap,此时Tunnel Down Reason原因为reset AP
·       Tunnel Link Failure:Fit AP在尝试和AC建立链接过程中出现错误造成设备重新启动
Latest IP Address
最近一个AP的IP地址
Tunnel Down Reason
CAPWAP链路down的原因。如果AP已经成功和AC建立链接后出现过Tunnel down后,该信息将记录下AC检测到的断开链路的原因:
·       Neighbor Dead Timer Expire:表示AC在三倍的握手时间内没有收到AP的Echo request报文,此时AC认为AP已经断开;
·       Response Timer Expire:表示AC向AP发送了一个需要回应的控制报文后,回应报文在等待时间内没有到达,而造成AC认为AP设备Down;
·       Reset AP:表示AC上通过命令方式将AP设备重新启动而造成隧道down;
·       AP Config Change:表示由于AC设备上由于修改相应的配置而最终导致隧道down;
·       No Reason:其他原因
Connection Count
AP和AC的连接次数。只有在以下情况下连接次数会清零:
·       AC重启
·       删除AP模板后重新配置AP模板
需要注意的是,使用reset wlan ap命令不会造成AP连接次数清零
AP Mode
AP支持的模式类型,当前仅支持分离MAC模式
AP operation mode
AP的运行模式,目前只支持Normal和Monitor模式
Device Detection
提供设备检测的WLAN数据服务
AP支持所支持射频的最大数目
AP正在使用的射频的数目
AP检测无线客户端从系统中被隔离出来的时间间隔,多种原因可以导致无线客户端被隔离,例如电源故障或系统崩溃。检测到隔离后,断开无线客户端同AP的连接。
如果无线客户端的空闲时间超过了指定的时间间隔,即在指定的时间间隔内AP没有从无线客户端处收到任何数据,无线客户端将被从网络中清除
广播探测响应状态:开启或禁用
Basic BSSID
射频的MAC地址
Current BSS Count
当前处在此射频的BSS数目
当前运行的无线客户端数目
Wireless Mode
无线模式:802.11a,802.11b,802.11g,802.11gn,802.11an
Client Dot11n-only
·       Enabled:只有802.11n的无线客户端才能接入AP
·       Disabled:兼容802.11a/b/g的无线客户端,同时还要接入802.11n的无线客户端
Channel Band-width
带宽模式:
·       20MHz:工作带宽为20MHz
·       40MHz:工作带宽为40MHz
802.11n射频模式中的辅信道信息:
·       SCA:Second Channel Above,表示AP当前工作在40MHz带宽模式,并且辅信道高于主信道
·       SCB:Second Channel Below,表示AP当前工作在40MHz带宽模式,并且辅信道低于主信道
SCN:表示AP工作在20MHz带宽模式
HT Protection Mode
802.11n保护的四种模式:
·       no protection mode(0):AP上关联的无线客户端以及周围环境中的无线设备都为802.11n模式,并且在AP上关联的无线客户端都是40MHz带宽的802.11n无线客户端;或者在AP上关联的无线客户端都是20MHz带宽的802.11n无线客户端
·       Non-member mode(1):AP上关联的无线客户端都是802.11n无线客户端,但是周围环境中存在着非802.11n无线设备
·       20 MHz mode(2):AP的射频带宽模式为40MHz,AP上关联的无线客户端以及周围环境中的无线设备都为802.11n模式,并且在该AP的射频上至少关联了一个20MHz带宽的802.11n无线客户端
·       Non-HT mix mode(3):除以上三种之外的其他所有情况都属于此模式
Short GI for 20MHz
AP工作带宽为20MHz时,对于Short GI的支持情况:
·       Not Supported:AP不支持Short GI
·       Supported:AP支持Short GI
Short GI for 40MHz
AP工作带宽为40MHz时,对于Short GI的支持情况:
Mandatory MCS Set
AP支持的基本MCS集
Supported MCS Set
AP支持的支持MCS集
Configured Channel
工作信道:
·       如果信道是用户手工配置的,则直接显示配置的信道号
·       如果使用自动选择信道模式,显示auto(channel),括号中的信道是AC自动选择质量最优的信道作为工作信道
Configured Power(dBm)
射频的发射功率
如果使用固定功率,显示的值为配置的恒定功率值
如果使用自动功率调整方式,显示的值为auto(数字),括号中的数字表示实际的功率值
Interference (%)
信道中观测到的冲突,以百分比的形式表示
Channel Load (%)
信道中观测到的负载,以百分比的形式表示
Utilization (%)
信道使用率。以百分比的形式表示
同信道中的邻居数量
Channel Health
信道状态
Preamble Type
AP支持的前导码类型 :长前导码或短前导码
Radio Policy
使用的射频策略
Service Template
服务模板号
SSID
无线客户端关联的SSID
Port
与服务模板关联的WLAN-DBSS接口
ANI Support
ANI(Adaptive Noise Immunity)的支持情况
Admin State
射频的管理状态
Physical State
射频的物理状态
使用的射频速率
探测到雷达信号的信道
Antenna Type
天线类型
资源利用率
Noise Floor
噪底
display wlan ap { all | name ap-name } address [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:所有AP。
address:显示指定AP的地址信息。
【描述】
display wlan ap address命令用来显示AP的地址信息。
# 显示所有AP的地址信息。
<Sysname> display wlan ap all address
 Total Number of APs configured           : 3
 Total Number of configured APs connected : 3
 Total Number of auto APs connected       : 0
                                  AP Address
 AP Name                          IP Address                     MAC Address
 ap1                              1.1.1.5                    ... 000b-6b8f-fc6a
 ap2                              2001::1                    ... 000f-e000-0052
 ap3                              2.2.2.2                    ... 000f-e200-0000
表1-16 display wlan ap address命令显示信息描述表
所有通过AP模板配置的AP
所有上线的配置AP
所有上线的自动AP
AP Name
AP名称
IP Address
AP的IP地址,AP未上线时,该字段显示为-NA-
MAC Address
AP的MAC地址,AP未上线时,该字段显示为-NA-
display wlan ap { all | name ap-name } radio [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:所有AP。
radio:显示AP的射频信息。
【描述】
display wlan ap address命令用来显示AP的射频信息。
# 显示所有AP的射频信息。
<Sysname> display wlan ap all radio
                                  AP Radio
 AP Name                          Radio ID        Channel        Tx Power (dBm)
 ap1                              2               1              20
 ap2                              2               6              19
 ap3                              2               11             20
表1-17 display wlan ap radio命令显示信息描述表
所有通过AP模板配置的AP
所有上线的配置AP
所有上线的自动AP
AP Name
AP名称
Radio ID
射频的ID号
Channel
射频使用的工作信道
Tx Power (dBm)
射频的最大传输功率
display wlan ap reboot-log name ap-name [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ap-name:指定重启的AP的名字,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,不可以包含空格。
【描述】
display wlan ap reboot-log命令用来显示指定AP的重启日志信息。
如果AP曾发生过系统崩溃,那么可以使用该命令查看相关信息。注意指定的AP必须处于run状态。
# 显示名为ap1的AP的重启日志信息。
<Sysname> display wlan ap reboot-log name ap1
.Debug information is not available on AC
 Do you wish to start debug data downloading from AP [Y/N]:y
 Downloading debug data. Please wait...
 Please enter the same command again to view details
display wlan ap-model { all | name ap-name } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
all:显示全部型号信息。
name ap-name:指定AP型号名字,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,不可以包含空格。
【描述】
display wlan ap-model命令用来显示无线控制器上支持的指定AP或全部AP的型号信息。
# 显示WA2100型号的信息。
<Sysname> display wlan ap-model name WA2100
              AP Model : WA2100
 Alias       : WA2100
 Vendor Name : H3C
 Vendor ID   : -NA-
 Radio Count : 1
 Radio1 :
  Mode         : 802.11a/b/g
  Default Mode : 802.11g
  BSS Count    : 16
 Version Support List :
  Hardware Version Ver.A :
   Software Version : V100R001B96D001
   Image Name       : WA2100.bin
  Hardware Version Ver.B :
  Hardware Version Ver.C :
  Hardware Version Ver.D :
表1-18 display wlan ap-model命令显示信息描述表
Alias
AP型号的别名
Vendor Name
该型号AP的供应商名称
Vendor ID
该型号AP的供应商ID
Radio Count
该型号AP的射频总数
Mode
所支持的射频模式,如802.11a和802.11b
Default Mode
缺省射频模式
BSS Count
所支持的BSS的最大数目
Hardware Version
该型号AP的硬件版本
Software Version
该型号AP的软件版本
Image Name
具有完整文件名的AP镜像文件
1.3.13  dns domain
dns domain domain-name
undo dns domain
AP配置视图
【缺省级别】
2:系统级
domain-name:AP使用的域名服务器的域名后缀,由“.”分隔的字符串组成,包括“.”在内的总长度不超过238个字符。不区分大小写,字符串中可以包含字母、数字、“-”及下划线。
【描述】
dns domain命令用来配置AP使用的域名服务器的域名后缀。undo dns domain命令用来删除AP使用的域名服务器的域名后缀。
缺省情况下,没有配置AP使用的域名服务器的域名后缀。
最多可配置1个AP使用的域名服务器的域名后缀。
wlan ap-provision dns domain命令对所有AP生效,AP配置视图下的dns domain命令只对指定的AP生效,如果都进行了配置,则优先采用AP配置视图下的配置。
相关配置可参考命令wlan ap-provision dns domain
# 配置AP1使用的域名服务器的域名后缀为com。
[Sysname-wlan-ap-ap1-prvs] dns domain com
1.3.14  dns server
dns server { ip ip-address | ipv6 ipv6-address }
undo dns server { ip | ipv6 }
AP配置视图
【缺省级别】
2:系统级
ip ip-address:AP使用的域名服务器的IPv4地址。
ipv6 ipv6-address:AP使用的域名服务器的IPv6地址。
【描述】
dns server命令用来配置AP使用的域名服务器的IP地址。undo dns server命令用来删除AP使用的域名服务器的IP地址。
缺省情况下,没有配置AP使用的域名服务器的IP地址。
最多可分别配置1个IPv4地址的域名服务器和IPv6地址的域名服务器。
wlan ap-provision dns server命令对所有AP生效,AP配置视图下的dns server命令只对指定的AP生效,如果都进行了配置,则优先采用AP配置视图下的配置。
相关配置可参考命令wlan ap-provision dns server
# 配置AP使用的域名服务器的IPv4地址为192.168.100.123。
[Sysname-wlan-ap-ap1-prvs] dns server ip 192.168.100.123
echo-interval interval
undo echo-interval
AP模板视图
【缺省级别】
2:系统级
interval:指定两次回声请求之间的最小时间间隔,取值范围为5~80,单位为秒。
【描述】
echo-interval命令用来设置两次回声请求的时间间隔。undo echo-interval命令用来恢复缺省情况。
缺省情况下,回声间隔为10秒。
在AP和AC之间使用保活机制来确认控制信道是否正常工作。为了保持控制信道处于激活状态,AP周期性地发送回声请求(echo request)给AC;AC收到该请求,发送回声应答(echo response)。
# 设置ap3的回声间隔为15秒。
[Sysname-wlan-ap-ap3] echo-interval 15
1.3.16  gateway
gateway { ip ip- address | ipv6 ipv6-address }
undo gateway { ip | ipv6 | all }
AP配置视图
【缺省级别】
2:系统级
ip ip- address:AP网关的IPv4地址。
ipv6 ipv6-address:AP网关的IPv6地址。
all:删除AP网关的所有地址。
【描述】
gateway命令用来配置AP的网关地址。undo gateway命令用来删除AP的网关地址。
缺省情况下,没有配置AP的网关地址。
最多可分别配置1个IPv4地址的AP网关和IPv6地址的AP网关。
# 配置AP 1的网关地址为192.168.100.1。
[Sysname-wlan-ap-ap1-prvs] gateway ip 192.168.100.1
undo hybrid-remote-ap enable
AP模板视图
【缺省级别】
3:管理级
【描述】
hybrid-remote-ap enable命令用来开启Remote AP功能。Remote AP功能开启后,当AP与AC之间的隧道断开时,AP会自动开启本地转发模式(与AC上是否配置本地转发无关),继续为已接入的客户端提供无线接入服务,但不会允许新的客户端接入;当AP与AC重新建立隧道后,AP会自动切换回原转发模式,并强制Remote AP上所有的客户端下线,所有客户端需要重新接入。undo hybrid-remote-ap enable用来恢复缺省情况。
缺省情况下,Remote AP功能处于关闭状态。
·       开启AP的Remote AP功能时,对于AP上的使用dot1x认证的服务模板,建议关闭在线用户握手功能功能。
·       Remote AP功能不能与Mesh功能同时启用。
# 开启ap1的Remote AP功能。
<Sysname> systerm-view
[Sysname] wlan ap ap1 model wa2100
[Sysname-ap-ap1] hybrid-remote-ap enable
1.3.18  ip address
ip address ip-address { mask | mask-length }
undo ip address
AP配置视图
【缺省级别】
2:系统级
ip-address:AP的管理VLAN接口的IP地址,为点分十进制格式。
mask:子网掩码,为点分十进制格式。
mask-length:子网掩码长度,即掩码中连续“1”的个数,取值范围为0~32。
【描述】
ip address命令用来配置AP的管理VLAN接口的IP地址。undo ip address命令用来删除AP的管理VLAN接口的IP地址。
缺省情况下,没有配置AP的管理VLAN接口的IP地址。
目前,AP的管理VLAN只能配置为VLAN1。
# 配置AP 1的管理VLAN接口的IP地址为192.168.100.100/24。
[Sysname-wlan-ap-ap1-prvs] ip address 192.168.100.100 24
1.3.19  ipv6 address
undo ipv6 address
AP配置视图
【缺省级别】
2:系统级
ipv6-address:IPv6地址。
prefix-length:前缀长度,取值范围为1~128。
【描述】
ipv6 address命令用来配置AP的管理VLAN接口的IPv6地址。undo ipv6 address命令用来删除AP的管理VLAN接口的IPv6地址。
缺省情况下,没有配置AP的管理VLAN接口的IPv6地址。
# 配置AP 1的管理VLAN接口的IPv6地址为2001::1/64。
[Sysname-wlan-ap-ap1-prvs] ipv6 address 2001::1/64
jumboframe enable value
undo jumboframe enable
AP模板视图
【缺省级别】
2:系统级
value:指定Jumbo帧的最大长度,取值范围为1500~1748,单位为字节。
【描述】
jumboframe enable命令用来设置Jumbo帧的最大长度。undo jumboframe enable命令用来恢复缺省情况。
缺省情况下,禁止Jumbo帧的传输。
# 设置Jumbo帧的长度为1500字节。
[Sysname-ap-ap1] jumboframe enable 1500
map-configuration filename
undo map-configuration
AP模板视图
【缺省级别】
2:系统级
filename:指定已有的Buildrun配置文件的文件名,为1~32个字符的字符串。在用户视图下使用dir命令可以显示设备中的文件列表。
【描述】
map-configuration命令用来将指定文件映射到AP。undo map-configuration取消文件与AP的映射关系。
缺省情况下,没有文件被映射到AP。
使用map-configuration命令指定的配置文件,文件中的内容必须是完整的命令行形式。
# 将文件filename1映射到AP1。
[Sysname -wlan-ap-ap1] map-configuration filename1.txt
memory-usage threshold integer
AP模板视图
【缺省级别】
3:管理级
【描述】
memroy-usage threshold命令用来设置AP的内存利用率阈值,如果AP的内存利用率超过了设定的阈值,则AP会发出告警。
缺省情况下,AP的默认内存利用率阈值为90。
# 设置AP的内存利用率阈值不超过30%。
[Sysname-wlan-ap-ap3]memory-usage threshold 30
priority level priority
undo priority level
AP模板视图
priority:AP连接的优先级,取值范围为0~7。取值越大优先级越高。
【描述】
priority level 命令用来配置AC上AP连接的优先级。undo priority level命令用来恢复缺省情况。
缺省情况下,AP连接优先级为4。
# 配置AP连接优先级为1。
[Sysname-wlan-ap-ap3] priority level 1
1.3.24  provision
provision
undo provision
AP模板视图
【缺省级别】
2:系统级
【描述】
provision命令用来创建并进入AP配置视图。undo provision命令用来删除AP配置视图及视图下的所有配置。
缺省情况下,没有创建AP配置视图。
创建AP配置视图后,设备会自动配置vlan untagged 1命令。
# 进入AP 1的AP配置视图。
reset wlan ap { all | name ap-name }
【缺省级别】
1:监控级
all:重启连接到当前无线控制器的全部AP。
ap-name:重启的AP的名字,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,不可以包含空格。
【描述】
reset wlan ap命令用来重启指定或全部AP。
# 重启名字为ap1的AP。
<Sysname> reset wlan ap name ap1
reset wlan ap provision { all | name ap-name }
【缺省级别】
2:系统级
all:所有AP。
name ap-name:指定AP的名称,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,不可以包含空格。
【描述】
reset wlan ap provision命令用来清除指定AP上的私有配置文件。
该命令仅对当前处于Run状态的AP生效。
# AP 1和AC已经建立连接(处于Run状态),清除AP1上的私有配置文件。
<Sysname> reset wlan ap provision name ap1
reset wlan ap reboot-log { all | name ap-name }
【缺省级别】
1:监控级
all:清除所有AP的重启日志信息。
ap-name:重启AP的名字,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,不可以包含空格。
【描述】
reset wlan ap reboot-log命令用来清除指定AP或全部AP的重启日志信息。
# 清除名为ap1的重启日志信息。
<Sysname> reset wlan ap reboot-log name ap1
save wlan ap provision { all | name ap-name }
【缺省级别】
2:系统级
all:所有AP。
【描述】
save wlan ap provision命令用来将AP配置视图下的配置信息保存到指定AP的私有配置文件中。
·              该命令仅对当前处于Run状态的AP生效。也就是说,对于执行save wlan ap-provision操作后才与AC建立CAPWAP隧道连接的AP,本次的save wlan ap-provision操作不能下发到这些AP。
·              在AC上执行save wlan ap-provision操作后,AC下发的配置信息只能在手动重启AP后生效。
·              AP重启后,会依次执行配置文件、私有配置文件和map-configuration命令指定的配置文件,三种配置文件可能覆盖或冲突。因此,请用户保证私有配置文件和map-configuration命令指定配置文件的正确性。
在AC上执行save wlan ap provision命令后,配置信息将会保存到指定AP的私有配置文件。私有配置文件生效后,AP就只能通过指定的管理AC(即使用acwlan ap-provision ac命令指定的AC)修改配置。因此一旦存在配置错误,会导致AP无法被指定的AC管理,此时,用户只能通过登录AP修改配置。
相关配置可参考命令map-configurationreset wlan ap provisionreset wlan ap
# AP 1和AC已经建立连接(处于Run状态),将AP配置视图下的配置信息保存到AP 1的配置文件中。
<Sysname> save wlan ap provision name ap1
1.3.29  serial-id
serial-id { text | auto }
undo serial-id
AP模板视图
【缺省级别】
2:系统级
text:绑定到AP管理实体的AP序列ID,1~32个字符的字符串,可以包含除?外的特殊字符,输入后的字母自动改为大写形式。
auto:设置自动查找AP序列号。
【描述】
serial-id命令用来设置AP的序列号,序列号是每个AP的唯一标识。undo serial-id命令用来恢复缺省情况。
缺省情况下,没有为AP配置序列号。
需要注意的是,如果AP已经连接,此时改变和删除序列号将触发AP隧道的拆除。AP将会重新发现并连接无线控制器。
# 将ap1的序列ID设置为210235A29G007C000020。
[Sysname-ap-ap1] serial-id 210235A29G007C000020
tunnel encryption ipsec pre-shared-key { cipher | simple } key
undo tunnel encryption ipsec pre-shared-key
AP配置视图
【缺省级别】
2:系统级
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥。
key:设置明文密钥或密文密钥,区分大小写。明文密钥的长度范围是1~128;密文密钥的长度范围是1~201。
【描述】
tunnel encryption ipsec pre-shared-key命令用来配置AP使用IPsec密钥加密控制隧道。undo tunnel encryption ipsec pre-shared-key命令用来取消AP加密控制隧道。
缺省情况下,AP不对控制隧道进行加密。
使用该命令配置IPsec密钥后,缺省只能使AP加密控制隧道,如果还需要加密数据隧道,请使用data-tunnel encryption enable命令开启AP加密数据隧道功能。配置undo tunnel encryption ipsec pre-shared-key命令后,AP会同时取消数据隧道和控制隧道加密功能。
相关配置可参考命令data-tunnel encryption enable
# 以明文方式配置AP使用IPsec加密控制隧道的密钥为12345。
1.3.31  vlan tagged
vlan tagged vlan-id-list
undo vlan tagged vlan-id-list
AP配置视图
【缺省级别】
2:系统级
vlan-id-list:在AP以太网接口上标记需要携带TagVLAN列表,表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>vlan-id取值范围为14094&<1-10>表示前面的参数最多可以重复输入10次。
【描述】
vlan tagged命令用来在AP以太网接口上配置需要携带TagVLAN列表。undo vlan tagged命令用来删除已有配置。
缺省情况下,在AP以太网接口上不存在TaggedVLAN
# AP1的以太网接口上将VLAN 6标记为Tagged
[Sysname-wlan-ap-ap1-prvs] vlan tagged 6
vlan untagged vlan-id-list
undo vlan untagged vlan-id-list
AP配置视图
【缺省级别】
2:系统级
vlan-id-list:在AP以太网接口上标记不需要携带Tag的VLAN列表,表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>,vlan-id取值范围为1~4094,&<1-10>表示前面的参数最多可以重复输入10次。
【描述】
vlan untagged命令用来在AP以太网接口上配置不需要携带Tag的VLAN列表。undo vlan untagged命令用来删除已有配置。
缺省情况下,在AP以太网接口上不存在Untagged的VLAN。
# 在AP1的以太网接口上将VLAN 7标记为Untagged。
[Sysname-wlan-ap-ap1-prvs] vlan untagged 7
1.3.33  vlan pvid
vlan pvid vlan-id
undo vlan pvid
AP配置视图
【缺省级别】
2:系统级
vlan-id:指定AP上以太网接口的缺省VLAN ID,取值范围为1~4094。
【描述】
vlan pvid命令用来配置AP上以太网接口的缺省VLAN ID。undo vlan pvid命令用来恢复缺省情况。
缺省情况下,AP上以太网接口的缺省VLAN ID为1。
# 配置AP1上以太网接口的缺省VLAN ID为5。
[Sysname-wlan-ap-ap1-prvs] vlan pvid 5
1.3.34  wlan ap
wlan ap ap-name [ model model-name [ id ap-id ] ]
undo wlan ap ap-name
【缺省级别】
2:系统级
ap-name:AP的名称,为1~32个字符的字符串,可以包含字母、数字及下划线,“[”,“]”,“/”,连接符“-”,不可以包含空格,不区分大小写。
model model-name:AP的型号名称。在创建AP管理模板时,该参数必须配置。
id ap-id:AP的ID,取值范围为1~支持AP的最大数量。如果不配置此参数,AC会自动为AP分配ID。
【描述】
wlan ap命令用来创建并进入AP管理模板视图。如果指定的AP管理模板已创建,则该命令直接用来进入该AP管理模板的视图。undo wlan ap命令用来删除指定的AP管理模板。
如果AP已经连接到AC,使用undo wlan ap命令将会导致连接断开。
# 创建一个AP管理模板,其名称为ap1,型号名称为WA2100。
1.3.35  wlan ap-provision ac
wlan ap-provision ac { host-name host-name | ip ip-address | ipv6 ipv6-address }
undo wlan ap-provision ac { host-name | ip { ip-address | all } | ipv6 { ipv6-address | all } }
【缺省级别】
2:系统级
host-name host-name:AC的全局主机名,为1~255个字符的字符串,不区分大小写,字符串中可以包含字母、数字、“-”、“_”或“.”,且必须至少包含一个字母。
ip ip-address:AC的全局IPv4地址。
ipv6 ipv6-address:AC的全局IPv6地址。
all:删除AC的IPv4/IPv6地址。
【描述】
ac命令用来配置AC的全局IP地址,使所有AP能够静态发现指定的AC。undo ac命令用来删除已有配置。
缺省情况下,没有配置AC的全局IP地址。
相关配置可参考命令ac
# 配置AC的全局IPv4地址为192.168.100.11,使所有AP能够静态发现指定的AC。
[Sysname] wlan ap-provision ac ip 192.168.100.11
1.3.36   wlan ap-provision dns domain
wlan ap-provision dns domain domain-name
undo wlan ap-provision dns domain
【缺省级别】
2:系统级
domain-name:全局域名后缀,由“.”分隔的字符串组成,包括“.”在内的总长度不超过238个字符。不区分大小写,字符串中可以包含字母、数字、“-”及下划线。
【描述】
wlan ap-provision dns domain命令用来配置AP使用的域名服务器的全局域名后缀。undo wlan ap-provision dns domain命令用来删除AP使用的域名服务器的全局域名后缀。
缺省情况下,没有配置AP使用的域名服务器的全局域名后缀。
最多可配置1个全局域名后缀。
相关配置可参考命令dns domain
# 配置AP使用的域名服务器的全局域名后缀为com。
[Sysname] wlan ap-provision dns domain com
1.3.37  wlan ap-provision dns server
wlan ap-provision dns server { ip ip-address | ipv6 ipv6-address }
undo wlan ap-provision dns server { ip | ipv6 }
【缺省级别】
2:系统级
ip ip-address:AP使用的域名服务器的全局IPv4地址。
ipv6 ipv6-address:AP使用的域名服务器的全局IPv6地址。
【描述】
wlan ap-provision dns server命令用来配置AP使用的域名服务器的全局IP地址。undo wlan ap-provision dns server命令用来删除AP使用的域名服务器的全局IP地址。
缺省情况下,没有配置AP使用的域名服务器的全局IP地址。
最多可分别配置1个全局IPv4地址的域名服务器和全局IPv6地址的域名服务器。
相关配置可参考命令dns server
# 配置AP使用的域名服务器的全局IPv4地址为192.168.100.124。
[Sysname] wlan ap-provision dns server ip 192.168.100.124
1.3.38  wlan ap-execute
wlan ap-execute ap-name conversion-to-fatap
【缺省级别】
3:管理级
ap-name:AP的名称,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,不可以包含空格。
conversion-to-fatap:将AP类型改为FAT AP。
【描述】
wlan ap-execute命令用来将AP的类型由FIP AP改为FAT AP。
配置前请将FAT AP版本下载到设备中,否则设备无法进行AP模式切换。
# 将ap1_003的类型设置为FAT AP。
[Sysname] wlan ap-execute ap1_003 conversion-to-fatap
1.3.39  wlan apdb
wlan apdb model-name hardware-version software-version
undo wlan apdb model-name hardware-version
【缺省级别】
2:系统级
model-nameAP名称。
hardware-versionFIT AP硬件版本名称。
software-versionFIT AP软件版本名称。
【描述】
wlan apdb命令用来升级指定AP模块的硬件版本对应的软件版本。undo wlan apdb命令用来恢复缺省情况。
缺省情况下,要求FIT AP设备和AC设备软件版本一致。
# 升级指定AP模块的硬件版本对应的软件版本。
[Sysname] wlan apdb wa2100 Ver.C V100R001B96D001
1.3.40  wlan auto-ap enable
wlan auto-ap enable
undo wlan auto-ap enable
【缺省级别】
2:系统级
【描述】
wlan auto-ap enable命令用来开启自动AP发现功能。undo wlan auto-ap enable命令用来恢复缺省情况。
缺省情况下,自动AP发现功能处于关闭状态。
在AC上配置serial-id auto命令,并开启自动AP发现功能,AP就能够自动连接到AC上。在部署AP数量较多的无线网络时,自动AP发现功能可以简化配置,避免多次配置大量的AP序列号。
相关配置可参考命令serial-idwlan auto-ap persistent
# 开启自动AP发现功能。
[Sysname] wlan auto-ap enable
1.3.41  wlan auto-ap persistent
wlan auto-ap persistent { all | name auto-ap-name [ new-ap-name ] }
【缺省级别】
2:系统级
all:将所有自动AP转换为固定AP,但名称保持不变。
auto-ap-name:自动AP的名称。
new-ap-name:转换以后的AP的名称,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不可以包含空格,不区分大小写。
【描述】
wlan auto-ap persistent命令将自动AP转换为固定AP(persistent AP)。
# 配置自动AP名称为新的AP名称。
[Sysname] wlan auto-ap persistent name auto_apm1_001 ap2
1.3.42  wlan backup-ac
wlan backup-ac { ip ipv4-address | ipv6 ipv6-address }
undo wlan backup-ac { ip | ipv6 }
ip ipv4-address:指定备份无线控制器的IPv4地址。
ipv6 ipv6-address:指定备份无线控制器的IPv6地址。
【描述】
wlan backup-ac命令用来配置备份AC的IP地址。undo wlan backup-ac取消配置的备份AC的IP地址。
缺省情况下,没有配置备份AC的IP地址。
# 配置备份AC的IP地址为192.168.1.1。
1.3.43  wlan lwapp discovery-policy
wlan lwapp discovery-policy unicast
undo wlan lwapp discovery-policy
【缺省级别】
2:系统级
unicast:指定AC仅从AP接收单播的发现请求。
【描述】
wlan lwapp discovery-policy命令用来设置在发现阶段所使用的发现策略类型。undo wlan lwapp discovery-policy命令用来恢复缺省情况。
缺省情况下,LWAPP发现策略类型为广播的方式。
如果将发现策略类型设置为单播方式,那么广播形式的发现报文将被丢弃。
# 设置LWAPP发现策略类型为单播。
[Sysname] wlan lwapp discovery-policy unicast
用户隔离命令
1.3.44  display user-isolation statistics
display user-isolation statistics [ vlan vlan-id ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
vlan-id:显示指定VLAN的用户隔离统计信息,取值范围为1~4094。
【描述】
display user-isolation statistics命令用来显示指定VLAN或所有VLAN的用户隔离统计信息。如果没有指定VLAN,则显示所有VLAN的用户隔离统计信息。
# 显示VLAN 3的用户隔离统计信息。
<Sysname> display user-isolation statistics vlan 3
                  User-Isolation Table
  VLAN      Status       Drops           Permit-MAC
  4         Enabled      0
  6         Disabled     0               0023-89a2-3d4d
 ---- Number of enabled/disabled VLANs: 1/1  ----
表1-19 display user-isolation statistics命令显示信息描述表
VLAN
开启用户隔离的VLAN ID
Status
用户隔离功能状态:
Enabled:VLAN用户隔离功能处于开启状态
Disabled:VLAN的用户隔离功能处于关闭状态
Drops
基于VLAN的丢弃报文个数
Permit-MAC
基于VLAN内的允许的MAC地址列表
1.3.45  reset user-isolation statistics
reset user-isolation statistics [ vlan vlan-id ]
【缺省级别】
1:监控级
vlan vlan-id:用户隔离的VLAN编号,取值范围为1~4094。
【描述】
reset user-isolation statistics 命令用来清除指定VLAN内或所有VLAN的用户隔离统计信息。如果没有指定VLAN,则清除所有VLAN的用户隔离统计信息。
# 清除VLAN 1的用户隔离统计信息。
<Sysname> reset user-isolation statistics vlan 1
1.3.46  user-isolation enable
undo user-isolation enable
服务模板视图
【缺省级别】
2:系统级
【描述】
user-isolation enable命令用来开启基于SSID的用户隔离功能。undo user-isolation enable命令用来恢复缺省情况。
缺省情况下,基于SSID的用户隔离功能处于关闭状态。
# 在服务模板1上开启基于SSID的用户隔离功能。
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] user-isolation enable
1.3.47  user-isolation permit braodcast
user-isolation permit broadcast
undo user-isolation permit broadcast
【缺省级别】
2:系统级
【描述】
user-isolation permit broadcast命令用来配置允许有线用户到无线用户的广播组播报文通过。
undo user-isolation permit broadcast命令用来配置隔离有线用户到无线用户的广播组播报文
缺省情况下,允许有线用户到无线用户的广播组播报文通过,只隔离无线用户到无线用户的广播组播报文。
# 配置隔离有线用户到无线用户的广播组播报文。
[Sysname] user-isolation permit broadcast
1.3.48  user-isolation vlan enable
user-isolation vlan vlan-list enable
undo user-isolation vlan vlan-list enable
【缺省级别】
2:系统级
vlan-listvlan-list为VLAN列表,其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>。其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
user-isolation vlan enable命令用来在指定VLAN上开启用户隔离功能。undo user-isolation vlan enable命令用来关闭指定VLAN的用户隔离功能。
缺省情况下,用户隔离功能处于关闭状态。
# 在VLAN 1上开启用户隔离功能。
[Sysname] user-isolation vlan 1 enable
1.3.49  user-isolation vlan permit-mac
user-isolation vlan vlan-list permit-mac mac-list
undo user-isolation vlan vlan-list permit-mac { mac-list | all }
【缺省级别】
2:系统级
vlan-list:在指定VLAN内配置用户隔离功能。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list={ vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
mac-list:允许的MAC地址列表,格式为H-H-H,在一个VLAN内最多可以配置16个允许的MAC地址,该MAC地址不允许为广播或组播地址。
all:删除指定VLAN的所有允许MAC地址。
【描述】
user-isolation vlan permit-mac命令用来配置指定VLAN的允许MAC地址。undo user-isolation permit-mac命令用来删除VLAN内指定或所有的允许MAC地址。
缺省情况下,没有配置指定VLAN的允许MAC地址。
# 配置VLAN 1的允许MAC地址为00bb-ccdd-eeff和0022-3344-5566。
[Sysname] user-isolation vlan 1 permit-mac 00bb-ccdd-eeff 0022-3344-5566
1.4  AP组接入控制命令
1.4.1  ap
ap template-name-list
undo ap template-name-list
AP-Group视图
【缺省级别】
2:系统级
template-name-list:AP模板的名字列表,表示方式为:template-name-list = { template-name }&<1-10>。其中template-name为AP模板的名字,为1~32个字符的字符串,可以包含字母、数字及下划线,不区分大小写,&<1-10>表示前面的参数最多可以输入10次。
【描述】
ap命令用来配置特定的AP组内允许接入的AP。undo ap命令用来删除AP组内允许接入的AP。如果不输入AP名字,则删除该组内全部AP列表。
缺省情况下,不存在AP名字。
该命令不检查指定的AP是否存在。在同一设备上,一个AP可以配置到多个AP组中。多次执行该命令,会将新的AP直接加入原有配置,直至允许的最大值。
# 在AP组10中配置允许接入ap10和ap101。
<System> system-view
[System] wlan ap-group 10
[System-ap-group10] ap ap10 ap101
1.4.2  description
description string
AP-Group视图
【缺省级别】
2:系统级
string:AP组的描述信息,为1~15个字符的字符串。可以由英文字母 [a-z,A-Z]、数字和下划线构成。
【描述】
description命令用来配置AP组描述信息。undo description命令删除该描述信息。
缺省情况下,没有AP组的描述信息。
# 为AP组10配置描述符marketing。
[System-ap-group10] description marketing
1.4.3  display wlan ap-group
display wlan ap-group [ group-id ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
group-id:显示指定AP组ID的信息。不同型号的设备支持的取值范围不同,无线控制产品各型号的支持情况请参见“命令参考导读”中的“命令行及参数差异情况”部分的介绍。如果不指定具体的AP组ID,则显示当前系统下全部AP组的配置。
【描述】
display wlan ap-group命令用来显示当前系统中AP组的相关配置。
# 显示当前系统中AP组10的相关配置。
<Sysname> display wlan ap-group 10
                        AP Group Information
AP-Group  ID        :10
Description         :market
Access AP Lists     :ap1,                ap2,
                     ap3,                ap4,
                     ap5,                ap6
表1-20 display wlan ap-group命令显示信息描述表
AP-Group ID
AP组的ID
AP组的描述符
Access AP Lists
允许的AP列表
1.4.4  wlan ap-group
wlan ap-group group-id
undo wlan ap-group [ group-id ]
【缺省级别】
2:系统级
group-id:AP组的ID。不同型号的设备支持的取值范围不同,无线控制产品各型号的支持情况请参见“命令参考导读”中的“命令行及参数差异情况”部分的介绍。
【描述】
wlan ap-group命令用来创建一个AP组并进入该组对应的视图。如果该组已经存在,则直接进入该组视图。undo wlan ap-group命令用来删除AP组。如果不输入AP组的ID,则删除系统内已经创建的全部AP组。
# 创建ID为10的AP组。
[Sysname] wlan ap-group 10
[Sysname-ap-group10]
1.4.5  wlan permit-ap-group
wlan permit-ap-group group-id
undo wlan permit-ap-group [ group-id ]
User-Profile视图
【缺省级别】
2:系统级
【描述】
wlan permit-ap-group命令用来在该User Profile下面设置特定的AP组。一个User Profile下可以配置多个AP组。undo wlan permit-ap-group命令用来取消该User Profile下的AP组。如果不输入AP组的名字,则删除该视图下全部AP组。
缺省情况下,没有指定任何AP组。
# 在名字为management的User Profile中,设置AP组10的策略。
[Sysname] user-profile management
[Sysname-user-profile-management] wlan permit-ap-group 10
1.5  SSID接入控制命令
1.5.1  wlan permit-ssid
wlan permit-ssid ssid-name
undo wlan permit-ssid [ ssid-name ]
User-Profile视图
【缺省级别】
2:系统级
ssid-name:允许接入的SSID名称,为1~32个字符的字符串,可以包含字母、数字及下划线,区分大小写,可以包含空格。不同型号的设备最多同时允许创建的SSID数目不同,无线控制产品各型号的支持情况请参见“命令参考导读”中的“特性支持情况”部分的介绍。
【描述】
wlan permit-ssid命令用来指定的User Profile下面设置特定的SSID,作为该User Profile的策略之一,即指定User-Profile允许接入的SSID。undo wlan permit-ssid命令用来取消该已有配置。如果不输入SSID的名字,则删除该视图下全部SSID。
缺省情况下,没有指定任何策略,即没有配置允许接入的SSID,表示用户接入时不限制接入的SSID,可用任意SSID接入无线网络。
# 在名字为management的User Profile中,设置允许接入的SSID名为VIPguest。
[System] user-profile management
[System-user-profile-management] wlan permit-ssid VIPguest
1.6  上行链路检测命令
1.6.1  wlan uplink track
wlan uplink track track-entry-number
undo wlan uplink track
【缺省级别】
2:系统级
track track-entry-number:被监视的Track项序号,track-entry-number取值范围为1~1024。
【描述】
wlan uplink track配置通过Track与上行链路联动,检测上行链路是否可达。undo wlan uplink track用来删除已有配置。
缺省情况下,没有指定与上行链路联动的Track项。
# 配置通过Track与上行链路联动,检测上行链路是否可达。
<Sysname> system
[Sysname] wlan uplink track 1
1.7  AC间热备份命令
1.7.1  display hot-backup state
display hot-backup state [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
|:使用正则表达式对显示信息进行过滤。有关正则表达式的详细介绍,请参见“基础配置指导”中的“CLI配置”。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display hot-backup state命令用来显示AC间热备份状态。
display hot-backup state的支持情况与设备的型号有关,请参见“命令参考导读”中的“命令行及参数差异情况”部分的介绍。
# 显示AC间热备份状态
[Sysname]display hot-backup state
Vlan ID                : 21
Domain ID           : 1
Link State            : Connect
Peer Board MAC : 000f-e212-ff02
Peer Board State : Normal
表1-21 display hot-backup state命令显示信息描述表
Vlan ID
端口所属VLAN ID
Domain ID
本AC所属备份域
Link State
AC间链路状态
·       Close:未连接
·       Init:连接中
·       Connect:已连接
Peer Board MAC
对端AC的MAC地址
Peer Board State
对端AC状态
·       Normal:对端AC状态正常
·       Abnormal:对端AC状态不正常
·       Unknow:未建立连接:
1.7.2  hot-backup enable
hot-backup enable [ domain domain-id ]*
undo hot-backup enable
【缺省级别】
2:系统级
domain domain-id:AC所属备份域,domain-id的取值范围为1~16,默认为1。
【描述】
hot-backup enable命令用来使能AC间热备份功能。undo hot-backup enable命令用来关闭AC间热备份功能。AC可以通过手工配置方式指定所属备份域。
缺省情况下,不使能AC热备份功能。
·       当AC处于热备份使能状态时,如果重复执行hot-backup命令,命令无效。
·       当AC处于热备份去使能状态时,如果重复执行undo hot-backup命令,命令无效。
·       hot-backup enable的支持情况与设备的型号有关,请参见“命令参考导读”中的“命令行及参数差异情况”部分的介绍。
# 使能AC间热备份功能
[Sysname]hot-backup enable
hot-backup enable successfully.
1.7.3  hot-backup hellointerval
hot-backup hellointerval hellointerval
【缺省级别】
2:系统级
hellointerval配置AC间连接的心跳周期,单位为毫秒,缺省为2000毫秒。该参数的支持情况与设备的型号有关,请参见“命令参考导读”中的“命令行及参数差异情况”部分的介绍。
【描述】
hot-backup hellointerval用来配置AC间连接的心跳周期。主、备AC超过3个心跳周期检测不到对端发送的心跳报文,就认为对端设备异常。
hot-backup hellointerval的支持情况与设备的型号有关,请参见“命令参考导读”中的“命令行及参数差异情况”部分的介绍。
# AC间连接的心跳周期设置为100毫秒
[Sysname]hot-backup hellointerval 100
1.7.4  hot-backup vlan
hot-backup vlan vlan-id
【缺省级别】
2:系统级
vlan vlan-id设置AC间用于热备份的本端数据端口的VLAN ID,取值范围为1~4094。
【描述】
hot-backup vlan命令用来配置AC间用于热备份的本端数据端口的VLAN ID。
缺省情况下,AC间用于热备份的本端数据端口的VLAN ID为1。
hot-backup vlan的支持情况与设备的型号有关,请参见“命令参考导读”中的“命令行及参数差异情况”部分的介绍。
# 设置AC间用于热备份的本端数据端口的VLAN ID为5
[Sysname]hot-backup vlan 5
1.7.5  wlan backup-ac switch-delay
wlan backup-ac switch-delay time
undo wlan backup-ac switch-delay
【缺省级别】
2:系统级
time:AP从主用AC切换为备用AC的延时,取值范围0~600,单位为秒。
【描述】
wlan backup-ac switch-delay命令用于配置备份AC切换的延时时间。
undo wlan backup-ac switch-delay命令用于删除备份AC切换的延时时间。
缺省情况下,AP从主用AC切换为备用AC的延时为5秒。
# 配置AP从主用AC切换为备用AC的延时为10秒。
[Sysname] wlan backup-ac switch-delay 10
