41-附录
本章节下载 (100.57 KB)
本命令索引包括手册中所出现的全部命令,按字母序排列,左边为命令行,右边为该命令所在的功能模块和页码。
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
aaa nas-id profile |
access-limit |
access-limit enable |
accounting default |
accounting lan-access |
accounting login |
accounting optional |
accounting-on enable |
accounting-on enable interval |
accounting-on enable send |
acl |
acl (User interface view) |
acl copy |
acl name |
activation-key |
active region-configuration |
add-member |
administrator-address |
archive configuration |
archive configuration interval |
archive configuration location |
archive configuration max |
arp anti-attack active-ack enable |
arp anti-attack send-gratuitous-arp |
arp anti-attack source-mac |
arp anti-attack source-mac aging-time |
arp anti-attack source-mac exclude-mac |
arp anti-attack source-mac threshold |
arp check enable |
arp detection enable |
arp detection mode |
arp detection static-bind |
arp detection trust |
arp detection validate |
arp max-learning-num |
arp rate-limit |
arp static |
arp timer aging |
ascii |
attribute |
authentication default |
authentication lan-access |
authentication login |
authentication-mode |
authorization command |
authorization default |
authorization lan-access |
authorization login |
authorization-attribute |
auto-build |
auto-execute command |
backup startup-configuration |
binary |
bind-attribute |
black-list add-mac |
black-list delete-mac |
boot-loader |
bootrom |
bootrom-update security-check enable |
broadcast-suppression |
build |
bye |
bye |
ca identifier |
cd |
cd |
cd |
cdup |
cdup |
certificate request entity |
certificate request from |
certificate request mode |
certificate request polling |
certificate request url |
check region-configuration |
ciphersuite |
classifier behavior |
client-verify enable |
clock datetime |
clock summer-time one-off |
clock summer-time repeating |
clock timezone |
close |
close-mode wait |
cluster |
cluster enable |
cluster switch-to |
cluster-local-user |
cluster-mac |
cluster-mac syn-interval |
cluster-snmp-agent community |
cluster-snmp-agent group v3 |
cluster-snmp-agent mib-view |
cluster-snmp-agent usm-user v3 |
command accounting |
command authorization |
command-privilege |
common-name |
configuration replace file |
copy |
copyright-info enable |
country |
crl check |
crl update-period |
crl url |
cut connection |
databits |
data-flow-format (RADIUS scheme view) |
debugging |
debugging |
delete |
delete |
delete |
delete static-routes all |
delete-member |
description |
description |
description |
description |
description |
dhcp-snooping |
dhcp-snooping information circuit-id format-type |
dhcp-snooping information circuit-id string |
dhcp-snooping information enable |
dhcp-snooping information format |
dhcp-snooping information remote-id format-type |
dhcp-snooping information remote-id string |
dhcp-snooping information strategy |
dhcp-snooping trust |
dir |
dir |
dir |
disconnect |
display acl |
display acl resource |
display archive configuration |
display arp |
display arp anti-attack source-mac |
display arp detection |
display arp detection statistics |
display arp ip-address |
display arp timer aging |
display boot-loader |
display bootp client |
display brief interface |
display channel |
display clipboard |
display clock |
display cluster |
display cluster base-topology |
display cluster black-list |
display cluster candidates |
display cluster current-topology |
display cluster members |
display connection |
display cpu-usage |
display cpu-usage history |
display current-configuration |
display debugging |
display default-configuration |
display device |
display device manuinfo |
display dhcp client |
display dhcp-snooping |
display dhcp-snooping information |
display dhcp-snooping packet statistics |
display dhcp-snooping trust |
display diagnostic-information |
display domain |
display dot1x |
display environment |
display fan |
display fib |
display fib ip-address |
display ftp client configuration |
display ftp-server |
display ftp-user |
display habp |
display habp table |
display habp traffic |
display history-command |
display hotkey |
display icmp statistics |
display igmp-snooping group |
display igmp-snooping statistics |
display info-center |
display interface |
display interface loopback |
display interface null |
display interface vlan-interface |
display ip check source |
display ip http |
display ip http |
display ip https |
display ip https |
display ip interface |
display ip interface brief |
display ip routing-table |
display ip routing-table acl |
display ip routing-table ip-address |
display ip routing-table protocol |
display ip routing-table statistics |
display ip socket |
display ip statistics |
display link-aggregation member-port |
display link-aggregation summary |
display link-aggregation verbose |
display lldp local-information |
display lldp neighbor-information |
display lldp statistics |
display lldp status |
display lldp tlv-config |
display local-user |
display logbuffer |
display logbuffer summary |
display logfile buffer |
display logfile summary |
display loopback-detection |
display mac-address |
display mac-address aging-time |
display mac-address statistics |
display memory |
display mib-style |
display mirroring-group |
display nandflash badblock-location |
display nandflash file-location |
display nandflash page-data |
display ndp |
display ntdp |
display ntdp device-list |
display ntdp single-device |
display ntp-service sessions |
display ntp-service status |
display ntp-service trace |
display packet-filter |
display pki certificate |
display pki certificate access-control-policy |
display pki certificate attribute-group |
display pki crl domain |
display port |
display port-group manual |
display port-isolate group |
display power |
display public-key local public |
display public-key peer |
display qos lr interface |
display qos map-table |
display qos policy |
display qos policy interface |
display qos trust interface |
display qos wrr interface |
display radius scheme |
display radius statistics |
display reboot-type |
display rmon alarm |
display rmon event |
display rmon eventlog |
display rmon history |
display rmon prialarm |
display rmon statistics |
display saved-configuration |
display schedule job |
display schedule reboot |
display sftp client source |
display snmp-agent community |
display snmp-agent group |
display snmp-agent local-engineid |
display snmp-agent mib-view |
display snmp-agent statistics |
display snmp-agent sys-info |
display snmp-agent trap queue |
display snmp-agent trap-list |
display snmp-agent usm-user |
display ssh client source |
display ssh server |
display ssh server-info |
display ssh user-information |
display ssl client-policy |
display ssl server-policy |
display stack |
display startup |
display stop-accounting-buffer |
display storm-constrain |
display stp |
display stp abnormal-port |
display stp down-port |
display stp history |
display stp ignored-vlan |
display stp region-configuration |
display stp root |
display stp tc |
display system-failure |
display tcp statistics |
display tcp status |
display tftp client configuration |
display this |
display time-range |
display traffic behavior |
display traffic classifier |
display transceiver |
display transceiver alarm |
display transceiver diagnosis |
display transceiver manuinfo |
display trapbuffer |
display udp statistics |
display user-bind |
display user-group |
display user-interface |
display users |
display version |
display vlan |
display voice vlan oui |
display voice vlan state |
display web users |
domain |
domain default enable |
dot1p-priority |
dot1x |
dot1x authentication-method |
dot1x auth-fail vlan |
dot1x guest-vlan |
dot1x handshake |
dot1x mandatory-domain |
dot1x max-user |
dot1x multicast-trigger |
dot1x port-control |
dot1x port-method |
dot1x quiet-period |
dot1x re-authenticate |
dot1x retry |
dot1x timer |
duplex |
enable log updown |
enable snmp trap updown |
escape-key |
execute |
exit |
expiration-date |
fast-leave (IGMP-Snooping view) |
file prompt |
filter |
fixdisk |
flow-control |
flow-control |
flow-interval |
format |
fqdn |
free ftp user |
free user-interface |
free web-users |
ftp |
ftp client source |
ftp server acl |
ftp server enable |
ftp timeout |
ftp update |
ftp-server |
get |
get |
gratuitous-arp-learning enable |
gratuitous-arp-sending enable |
group |
group-member |
group-policy (IGMP-Snooping view) |
habp enable |
habp server vlan |
habp timer |
handshake timeout |
header |
help |
history-command max-size |
holdtime |
host-aging-time (IGMP-Snooping view) |
hotkey |
idle-cut enable |
idle-timeout |
if-match |
igmp-snooping |
igmp-snooping dot1p-priority |
igmp-snooping drop-unknown |
igmp-snooping enable |
igmp-snooping fast-leave |
igmp-snooping general-query source-ip |
igmp-snooping group-limit |
igmp-snooping group-policy |
igmp-snooping host-aging-time |
igmp-snooping host-join |
igmp-snooping last-member-query-interval |
igmp-snooping leave source-ip |
igmp-snooping max-response-time |
igmp-snooping overflow-replace |
igmp-snooping proxying enable |
igmp-snooping querier |
igmp-snooping query-interval |
igmp-snooping report source-ip |
igmp-snooping router-aging-time |
igmp-snooping special-query source-ip |
igmp-snooping static-group |
igmp-snooping static-router-port |
igmp-snooping version |
import |
info-center channel name |
info-center console channel |
info-center enable |
info-center logbuffer |
info-center logfile enable |
info-center logfile frequency |
info-center logfile size-quota |
info-center logfile switch-directory |
info-center loghost |
info-center loghost source |
info-center monitor channel |
info-center snmp channel |
info-center source |
info-center synchronous |
info-center syslog channel |
info-center timestamp |
info-center timestamp loghost |
info-center trapbuffer |
instance |
interface |
interface bridge-aggregation |
interface null |
ip (PKI Entity view) |
ip address |
ip address |
ip address bootp-alloc |
ip address dhcp-alloc |
ip check source |
ip forward-broadcast (Interface view) |
ip forward-broadcast (System view) |
ip http acl |
ip http acl |
ip http enable |
ip http enable |
ip http port |
ip http port |
ip https acl |
ip https acl |
ip https certificate access-control-policy |
ip https enable |
ip https enable |
ip https port |
ip https port |
ip https ssl-server-policy |
ip route-static |
ip route-static default-preference |
ip ttl-expires enable |
ip unreachables enable |
ip-pool |
jumboframe enable |
key (RADIUS scheme view) |
last-member-query-interval (IGMP-Snooping view) |
lcd |
ldap-server |
lldp admin-status |
lldp check-change-interval |
lldp compliance admin-status cdp |
lldp compliance cdp |
lldp enable |
lldp encapsulation snap |
lldp fast-count |
lldp hold-multiplier |
lldp management-address-format string |
lldp management-address-tlv |
lldp notification remote-change enable |
lldp timer notification-interval |
lldp timer reinit-delay |
lldp timer tx-delay |
lldp timer tx-interval |
lldp tlv-enable |
locality |
local-user |
local-user password-display-mode |
lock |
logfile save |
logging-host |
loopback |
loopback-detection control enable |
loopback-detection enable |
loopback-detection interval-time |
loopback-detection per-vlan enable |
ls |
ls |
mac-address (Interface view) |
mac-address (system view) |
mac-address max-mac-count (Interface view) |
mac-address timer |
management-vlan |
management-vlan synchronization enable |
max-response-time (IGMP-Snooping view) |
mdi |
mib-style |
mirroring-group |
mirroring-group mirroring-port |
mirroring-group monitor-port |
mirroring-port |
mkdir |
mkdir |
mkdir |
monitor-port |
more |
move |
multicast-suppression |
name |
nas-id bind vlan |
nas-ip (RADIUS scheme view) |
ndp enable |
ndp timer aging |
ndp timer hello |
nm-interface vlan-interface |
ntdp enable |
ntdp explore |
ntdp hop |
ntdp timer |
ntdp timer hop-delay |
ntdp timer port-delay |
ntp-service access |
ntp-service authentication enable |
ntp-service authentication-keyid |
ntp-service broadcast-client |
ntp-service broadcast-server |
ntp-service in-interface disable |
ntp-service max-dynamic-sessions |
ntp-service multicast-client |
ntp-service multicast-server |
ntp-service reliable authentication-keyid |
ntp-service source-interface |
ntp-service unicast-peer |
ntp-service unicast-server |
open |
organization |
organization-unit |
overflow-replace (IGMP-Snooping view) |
packet-filter |
parity |
passive |
password |
peer-public-key end |
ping |
pki delete-certificate |
pki domain |
pki entity |
pki import-certificate |
pki request-certificate domain |
pki retrieval-certificate |
pki retrieval-crl domain |
pki validate-certificate |
pki-domain |
port |
port access vlan |
port auto-power-down |
port bridge enable |
port hybrid pvid |
port hybrid vlan |
port link-aggregation group |
port link-type |
port trunk permit vlan |
port trunk pvid |
port-group manual |
port-isolate enable |
prefer-cipher |
primary accounting (RADIUS scheme view) |
primary authentication (RADIUS scheme view) |
protocol inbound |
public-key local create |
public-key local destroy |
public-key local export dsa |
public-key local export rsa |
public-key peer |
public-key peer import sshkey |
public-key-code begin |
public-key-code end |
put |
put |
pwd |
pwd |
pwd |
qos apply policy |
qos lr |
qos map-table |
qos policy |
qos priority |
qos trust |
qos wrr |
quit |
quit |
quit |
radius client |
radius nas-ip |
radius scheme |
radius trap |
reboot |
reboot member |
redirect |
region-name |
remotehelp |
remove |
rename |
rename |
report-aggregation (IGMP-Snooping view) |
reset acl counter |
reset arp |
reset arp detection statistics |
reset counters interface |
reset dhcp-snooping |
reset dhcp-snooping packet statistics |
reset dot1x statistics |
reset igmp-snooping group |
reset igmp-snooping statistics |
reset ip routing-table statistics protocol |
reset ip statistics |
reset logbuffer |
reset ndp statistics |
reset radius statistics |
reset recycle-bin |
reset saved-configuration |
reset stop-accounting-buffer |
reset stp |
reset tcp statistics |
reset trapbuffer |
reset udp statistics |
reset unused porttag |
restore startup-configuration |
retry |
retry realtime-accounting |
retry stop-accounting (RADIUS scheme view) |
return |
revision-level |
rmdir |
rmdir |
rmdir |
rmon alarm |
rmon event |
rmon history |
rmon prialarm |
rmon statistics |
root-certificate fingerprint |
router-aging-time (IGMP-Snooping view) |
rule (advanced ACL view) |
rule (basic ACL view) |
rule (Ethernet frame header ACL view) |
rule (PKI Cert access control policy view) |
rule comment |
save |
schedule job |
schedule reboot at |
schedule reboot delay |
screen-length |
screen-length disable |
secondary accounting (RADIUS scheme view) |
secondary authentication (RADIUS scheme view) |
self-service-url enable |
send |
server-type |
service-type |
session |
set authentication password |
sftp |
sftp server enable |
sftp server idle-timeout |
shell |
shutdown |
shutdown |
shutdown |
snmp-agent |
snmp-agent calculate-password |
snmp-agent group |
snmp-agent log |
snmp-agent packet max-size |
snmp-agent target-host |
snmp-agent trap enable |
snmp-agent trap if-mib link extended |
snmp-agent trap life |
snmp-agent trap queue-size |
snmp-agent trap source |
snmp-agent usm-user { v1 | v2c } |
snmp-host |
speed |
speed (User interface view) |
speed auto |
ssh client authentication server |
ssh client first-time enable |
ssh client source |
ssh server authentication-retries |
ssh server authentication-timeout |
ssh server compatible-ssh1x enable |
ssh server enable |
ssh server rekey-interval |
ssh user |
ssh2 |
ssl client-policy |
ssl server-policy |
stack ip-pool |
stack role master |
stack stack-port |
stack switch-to |
startup saved-configuration |
state |
state |
state |
step |
stop-accounting-buffer enable (RADIUS scheme view) |
stopbits |
storm-constrain |
storm-constrain control |
storm-constrain enable log |
storm-constrain enable trap |
storm-constrain interval |
stp bpdu-protection |
stp bridge-diameter |
stp compliance |
stp config-digest-snooping |
stp cost |
stp edged-port |
stp enable |
stp ignored vlan |
stp loop-protection |
stp max-hops |
stp mcheck |
stp mode |
stp no-agreement-check |
stp pathcost-standard |
stp point-to-point |
stp port priority |
stp port-log |
stp priority |
stp root primary |
stp root secondary |
stp root-protection |
stp tc-protection |
stp tc-protection threshold |
stp timer forward-delay |
stp timer hello |
stp timer max-age |
stp timer-factor |
stp transmit-limit |
super |
super password |
sysname |
system-failure |
system-view |
tcp anti-naptha enable |
tcp state |
tcp syn-cookie enable |
tcp timer check-state |
tcp timer fin-timeout |
tcp timer syn-timeout |
tcp window |
telnet |
telnet ipv6 |
telnet server enable |
terminal debugging |
terminal logging |
terminal monitor |
terminal trapping |
terminal type |
tftp |
tftp client source |
tftp-server |
tftp-server acl |
timer |
timer quiet (RADIUS scheme view) |
timer realtime-accounting (RADIUS scheme view) |
timer response-timeout (RADIUS scheme view) |
time-range |
topology accept |
topology restore-from |
topology save-to |
tracert |
traffic behavior |
undelete |
unicast-suppression |
user |
user privilege level |
user-bind |
user-group |
user-interface |
user-name-format (RADIUS scheme view) |
verbose |
version |
virtual-cable-test |
vlan |
vlan-mapping modulo |
voice vlan aging |
voice vlan enable |
voice vlan mac-address |
voice vlan mode auto |
voice vlan security enable |
