H3C E528[E552]以太网交换机 命令参考-Release 1103-6W101
14-DHCP命令
本章节下载  (252.97 KB)
14-DHCP命令
  录
1 DHCP中继配置命令
1.1 DHCP中继配置命令
1.1.1 dhcp relay address-check
1.1.2 dhcp relay information circuit-id format-type
1.1.3 dhcp relay information circuit-id string
1.1.4 dhcp relay information enable
1.1.5 dhcp relay information format
1.1.6 dhcp relay information remote-id format-type
1.1.7 dhcp relay information remote-id string
1.1.8 dhcp relay information strategy
1.1.9 dhcp relay release ip
1.1.10 dhcp relay security static
1.1.11 dhcp relay security refresh enable
1.1.12 dhcp relay security tracker
1.1.13 dhcp relay server-detect
1.1.14 dhcp relay server-group
1.1.15 dhcp relay server-select
1.1.16 dhcp select relay
1.1.17 display dhcp relay
1.1.18 display dhcp relay information
1.1.19 display dhcp relay security
1.1.20 display dhcp relay security statistics
1.1.21 display dhcp relay security tracker
1.1.22 display dhcp relay server-group
1.1.23 display dhcp relay statistics
1.1.24 reset dhcp relay statistics
2 DHCP客户端配置命令
2.1 DHCP客户端配置命令
2.1.1 display dhcp client
2.1.2 ip address dhcp-alloc
3 DHCP Snooping配置命令
3.1 DHCP Snooping配置命令
3.1.1 dhcp-snooping
3.1.2 dhcp-snooping information circuit-id format-type
3.1.3 dhcp-snooping information circuit-id string
3.1.4 dhcp-snooping information enable
3.1.5 dhcp-snooping information format
3.1.6 dhcp-snooping information remote-id format-type
3.1.7 dhcp-snooping information remote-id string
3.1.8 dhcp-snooping information strategy
3.1.9 dhcp-snooping trust
3.1.10 display dhcp-snooping
3.1.11 display dhcp-snooping information
3.1.12 display dhcp-snooping packet statistics
3.1.13 display dhcp-snooping trust
3.1.14 reset dhcp-snooping
3.1.15 reset dhcp-snooping packet statistics
4 BOOTP客户端配置命令
4.1 BOOTP客户端配置命令
4.1.1 display bootp client
4.1.2 ip address bootp-alloc
1 DHCP中继配置命令
1.1  DHCP中继配置命令
dhcp relay address-check { disable | enable }
【缺省级别】
2:系统级
disable:禁止DHCP中继的地址匹配检查功能。
enable:使能DHCP中继的地址匹配检查功能。
【描述】
dhcp relay address-check命令用来配置DHCP中继的地址匹配检查功能。
缺省情况下,禁止DHCP中继的地址匹配检查功能。
接口上使能DHCP中继的地址匹配检查功能后,如果在DHCP中继的用户地址表中(包括DHCP中继动态记录的表项以及手工配置的用户地址表项)没有与主机IP地址和主机MAC地址匹配的表项,则该主机将不能通过DHCP中继访问外部网络。
需要注意的是,执行dhcp relay address-check enable命令后将只检查IP和MAC地址,不检查接口。
# 使能DHCP中继的地址匹配检查功能。
[Sysname-Vlan-interface1] dhcp relay address-check enable
dhcp relay information circuit-id format-type { ascii | hex }
undo dhcp relay information circuit-id format-type
【缺省级别】
2:系统级
ascii:指定以ASCII格式填充Option 82的Circuit ID子选项。
hex:指定以HEX格式填充Option 82的Circuit ID子选项。
【描述】
dhcp relay information circuit-id format-type命令用来配置非用户自定义的Circuit ID子选项的填充格式。undo dhcp relay information circuit-id format-type命令用来恢复缺省情况。
缺省情况下,Circuit ID子选项的填充格式由Option 82的填充模式决定,每个字段的填充格式不同。
需要注意的是,该命令只对非用户自定义的Circuit ID子选项有效,用户通过dhcp relay information circuit-id string命令配置Circuit ID子选项的内容后,将固定采用ASCII格式填充Circuit ID子选项。
相关配置可参考命令display dhcp relay information
# 配置以ASCII格式填充非用户自定义的Circuit ID子选项。
[Sysname-Vlan-interface1] dhcp relay information circuit-id format-type ascii
dhcp relay information circuit-id string circuit-id
undo dhcp relay information circuit-id string
【缺省级别】
2:系统级
circuit-id:用户自定义的Circuit ID子选项内容,为3~63个字符的字符串,区分大小写。
【描述】
dhcp relay information circuit-id string命令用来配置用户自定义的Circuit ID子选项的内容。undo dhcp relay information circuit-id string用来恢复缺省情况。
缺省情况下,Circuit ID子选项的内容由Option 82的填充模式决定。
需要注意的是,通过该命令配置用户自定义的Circuit ID子选项内容后,固定采用ASCII格式填充Circuit ID子选项。
相关配置可参考命令dhcp relay information formatdisplay dhcp relay information
# 配置Option 82的Circuit ID子选项填充内容为company001。
[Sysname-Vlan-interface1] dhcp relay information circuit-id string company001
undo dhcp relay information enable
【缺省级别】
2:系统级
【描述】
dhcp relay information enable命令用来使能DHCP中继支持Option 82功能。undo dhcp relay information enable命令用来禁止DHCP中继支持Option 82功能。
缺省情况下,禁止DHCP中继支持Option 82功能。
# 使能DHCP中继支持Option 82功能。
[Sysname-Vlan-interface1] dhcp relay information enable
dhcp relay information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
undo dhcp relay information format [ verbose node-identifier ]
【缺省级别】
2:系统级
normal:指定以normal模式进行填充。
verbose:指定以verbose模式进行填充。
node-identifier { mac | sysname | user-defined node-identifier }:接入节点的标识。缺省情况下,以节点的MAC地址作为节点标识。
l              mac:表示以节点的MAC地址作为节点标识;
l              sysname:表示以节点的设备名称作为节点标识;
l              user-defined node-identifier:表示以指定的字符串作为节点标识,node-identifier为1~50个字符的字符串。
【描述】
dhcp relay information format命令用来配置Option 82的填充模式。undo dhcp relay information format命令用来恢复缺省情况。
缺省情况下,Opiton 82的填充模式为normal。
l    在使用undo dhcp relay information format命令时,如果不带verbose node-identifier参数,则恢复为缺省的normal填充模式;如果带verbose node-identifier参数,则恢复为verbose模式中的mac填充方式。
l    DHCP中继对包含Option 82请求报文的处理策略为replace时,需要配置Option 82的填充模式;处理策略为keepdrop时,不需要配置Option 82的填充模式。
l    如果以节点的设备名称(sysname)作为节点标识填充DHCP报文的Option 82,则设备名称中不能包含空格,否则,DHCP中继将丢弃该报文。
# 配置Option 82以verbose模式进行填充。
[Sysname-Vlan-interface1] dhcp relay information strategy replace
[Sysname-Vlan-interface1] dhcp relay information format verbose
dhcp relay information remote-id format-type { ascii | hex }
undo dhcp relay information remote-id format-type
【缺省级别】
2:系统级
ascii:指定以ASCII格式填充Option 82的Remote ID子选项。
hex:指定以HEX格式填充Option 82的Remote ID子选项。
【描述】
dhcp relay information remote-id format-type命令用来配置非用户自定义的Remote ID子选项的填充格式。undo dhcp relay information remote-id format-type命令用来恢复缺省情况。
缺省情况下,采用HEX格式填充Remote ID子选项。
需要注意的是,该命令只对非用户自定义的Remote ID子选项有效,用户通过dhcp relay information remote-id string命令配置Remote ID子选项的内容后,将固定采用ASCII格式填充Remote ID子选项。
# 配置以ASCII格式填充非用户自定义的Remote ID子选项。
[Sysname-Vlan-interface1] dhcp relay information remote-id format-type ascii
dhcp relay information remote-id string { remote-id | sysname }
undo dhcp relay information remote-id string
【缺省级别】
2:系统级
remote-id:用户自定义的Remote ID子选项内容,为1~63个字符的字符串,区分大小写。
sysname:表示以节点的设备名称作为Remote ID子选项内容。
【描述】
dhcp relay information remote-id string命令用来配置用户自定义的Remote ID子选项的内容。undo dhcp relay information remote-id string用来恢复缺省情况。
缺省情况下,Remote ID子选项的内容由Option 82的填充模式决定。
需要注意的是,通过该命令配置用户自定义的Remote ID子选项内容后,固定采用ASCII格式填充Remote ID子选项。
如果用户自定义的Remote ID子选项内容为字符串sysname(任意大小写),则需要用引号将字符串sysname括起来。例如,用户自定义的Remote ID子选项内容为Sysname,则需要通过执行dhcp relay information remote-id string “Sysname”命令的方式配置。
# 配置Option 82的Remote ID子选项填充内容为device001。
[Sysname-Vlan-interface1] dhcp relay information remote-id string device001
undo dhcp relay information strategy
【缺省级别】
2:系统级
drop:如果报文中带有Option 82,则丢弃该报文。
keep:如果报文中带有Option 82,则保持该报文中的Option 82不变并进行转发。
replace:如果报文中带有Option 82,则按照配置的填充格式填充Option 82,用该选项替换报文中原有的Option 82,并进行转发。
【描述】
dhcp relay information strategy命令用来配置DHCP中继对包含Option 82的请求报文的处理策略。undo dhcp relay information strategy命令用来恢复缺省情况。
缺省情况下,DHCP中继对带有Option 82的请求报文的处理策略为replace
# 配置DHCP中继对带有Option 82的请求报文使用keep策略。
[Sysname-Vlan-interface1] dhcp relay information strategy keep
dhcp relay release ip client-ip
【缺省级别】
2:系统级
client-ip:DHCP客户端的IP地址。
【描述】
dhcp relay release ip命令用来配置向DHCP服务器请求释放客户端申请到的IP地址。
# 向DHCP服务器请求释放客户端申请到的IP地址1.1.1.1。
[Sysname] dhcp relay release ip 1.1.1.1
dhcp relay security static ip-address mac-address [ interface interface-type interface-number ]
undo dhcp relay security { ip-address | all | dynamic | interface interface-type interface-number | static }
【缺省级别】
2:系统级
ip-address:DHCP客户端的IP地址。
mac-address:DHCP客户端的MAC地址,形式为H-H-H。
interface interface-type interface-number:与DHCP客户端相连的三层接口。其中,interface-type interface-number为接口类型和接口编号。
all:删除所有的用户地址表项。
dynamic:删除动态用户地址表项。
static:删除静态用户地址表项。
【描述】
dhcp relay security static命令用来配置DHCP中继的静态用户地址表项,即IP地址,MAC地址和三层接口之间的静态绑定。undo dhcp relay security命令用来删除用户地址表项。
缺省情况下,没有配置DHCP中继的静态用户地址表项。
l              通过dhcp relay security static命令配置静态用户地址表项时,如果静态用户地址表项与接口绑定,配置的接口必须工作在DHCP中继模式,否则可能引起地址表项冲突。
l              undo dhcp relay security interface命令用来删除接口上的所有动态用户地址表项。
相关配置可参考命令display dhcp relay security
# 配置DHCP中继VLAN接口2上的静态用户地址表项:客户端IP地址为10.10.1.1,MAC地址为0005-5d02-f2b3。
[Sysname] dhcp relay security static 10.10.1.1 0005-5d02-f2b3 interface vlan-interface 2
undo dhcp relay security refresh enable
【缺省级别】
2:系统级
【描述】
dhcp relay security refresh enable命令用来开启DHCP中继动态用户地址表项定时刷新功能。undo dhcp relay security refresh enable命令用来关闭DHCP中继动态用户地址表项定时刷新功能。
缺省情况下,DHCP中继动态用户地址表项定时刷新功能处于开启状态。
需要注意的是,关闭DHCP中继动态用户地址表项定时刷新功能时,DHCP中继上记录的用户地址表项不会自动老化。DHCP客户端释放申请到的IP地址后,需要用户手工删除DHCP中继上对应的用户地址表项。
相关配置可参考命令dhcp relay security trackerdhcp relay security static
# 关闭DHCP中继动态用户地址表项定时刷新功能。
[Sysname] undo dhcp relay security refresh enable
dhcp relay security tracker { interval | auto }
undo dhcp relay security tracker [ interval ]
【缺省级别】
2:系统级
interval:刷新时间间隔,取值范围为1~120,单位为秒。
auto:根据表项的数目自动计算刷新时间间隔,计算方式为60秒除以表项个数。表项越多,刷新时间间隔越短,但最短时间间隔不能小于500毫秒。
【描述】
dhcp relay security tracker命令用来配置DHCP中继动态用户地址表项的定时刷新周期。undo dhcp relay security tracker命令用来恢复缺省情况。
缺省情况下,定时刷新周期为auto,即根据表项的数目自动计算刷新时间间隔。
相关配置可参考命令display dhcp relay security tracker
# 配置刷新时间间隔为100秒。
[Sysname] dhcp relay security tracker 100
undo dhcp relay server-detect
【缺省级别】
2:系统级
【描述】
dhcp relay server-detect命令用来使能伪DHCP服务器检测功能。undo dhcp relay server-detect命令用来禁止此功能。
缺省情况下,禁止伪DHCP服务器检测功能。
使能伪DHCP服务器检测功能后,DHCP中继会从接收到的DHCP报文中获取给客户端分配IP地址的服务器IP地址,并记录此IP地址及接收到报文的接口信息,以便管理员及时发现并处理伪DHCP服务器。
l              使能伪DHCP服务器检测功能后,对所有DHCP服务器都会进行记录,包括合法的DHCP服务器,管理员需要从日志信息中查找伪DHCP服务器。
l              使能伪DHCP服务器检测功能后,对每个DHCP服务器只记录一次。记录的DHCP服务器信息被清除后,将重新记录。
# 使能伪DHCP服务器检测功能。
[Sysname] dhcp relay server-detect
dhcp relay server-group group-id ip ip-address
undo dhcp relay server-group group-id [ ip ip-address ]
【缺省级别】
2:系统级
group-id:DHCP服务器组号,取值范围为0~19。
ip ip-address:DHCP服务器的IP地址。
【描述】
dhcp relay server-group命令用来配置DHCP服务器组中DHCP服务器的IP地址。undo dhcp relay server-group命令用来删除DHCP服务器组中服务器的IP地址,如果不指定ip ip-address参数,则删除指定DHCP服务器组及组中所有服务器的IP地址。
缺省情况下,没有配置DHCP服务器组中服务器的IP地址。
l              DHCP服务器组中服务器的IP地址不能与DHCP中继的接口IP地址在同一网段。否则,可能导致客户端无法获得IP地址。
l              如果一个组已经和多个接口建立起了归属关系,要首先取消这些接口和该组的归属关系,才能把这个组删除。
相关配置可参考命令display dhcp relay server-group
# 配置DHCP服务器组1的服务器IP地址为1.1.1.1。
[Sysname] dhcp relay server-group 1 ip 1.1.1.1
dhcp relay server-select group-id
undo dhcp relay server-select
【缺省级别】
2:系统级
【描述】
dhcp relay server-select命令用来配置接口与DHCP服务器组的归属关系。undo dhcp relay server-select命令用来取消这种归属关系。
缺省情况下,接口没有与DHCP服务器组建立归属关系。
l              一个DHCP服务器组可以与多个接口建立归属关系。
l              同一个接口同时只能与一个DHCP服务器组建立归属关系,后面的配置将覆盖已有的配置。但是,如果新指定的DHCP服务器组不存在时,新的归属关系配置不成功,接口还是维持与上一次配置的DHCP服务器组的归属关系。
l              本命令中指定的DHCP服务器组必须事先通过dhcp relay server-group命令创建。
相关配置可参考命令dhcp relay server-groupdisplay dhcp relay
# 配置VLAN接口1与DHCP服务器组1的归属关系。
[Sysname-Vlan-interface1] dhcp relay server-select 1
dhcp select relay
undo dhcp select relay
【缺省级别】
2:系统级
【描述】
dhcp select relay命令用来配置接口工作在DHCP中继模式,即当接口收到DHCP客户端发来的DHCP报文时,将报文转发给外部DHCP服务器,由外部服务器分配地址。undo dhcp select relay命令用来恢复接口对DHCP报文的处理模式为缺省模式。
缺省情况下,使能DHCP服务后,接口工作在DHCP服务器模式,即当接口收到DHCP客户端发来的DHCP报文时,将从DHCP服务器的地址池中分配地址。
需要注意的是,接口从DHCP服务器模式切换到DHCP中继模式时,设备不会删除IP地址租约,也不会删除相应的授权ARP表项。这些表项可能会与DHCP中继新生成的ARP表项冲突。因此,建议接口从DHCP服务器模式切换到DHCP中继模式时,清除已有的IP地址租约。
# 配置VLAN接口1工作在DHCP中继模式。
[Sysname-Vlan-interface1] dhcp select relay
display dhcp relay { all | interface interface-type interface-number }
【缺省级别】
1:监控级
all:显示所有接口对应的DHCP服务器组的信息。
interface interface-type interface-number:显示指定接口对应的DHCP服务器组的信息。interface-type interface-number为接口类型和接口编号。
【描述】
display dhcp relay命令用来显示接口对应的DHCP服务器组的信息。
# 显示所有接口对应的DHCP服务器组的信息。
<Sysname> display dhcp relay all
    Interface name            Server-group
    Vlan-interface 1                 2
表1-1 display dhcp relay命令显示信息描述表
Interface name
接口名
Server-group
接口对应的DHCP服务器组的组号
display dhcp relay information { all | interface interface-type interface-number }
【缺省级别】
1:监控级
all:显示所有接口对应的Option 82配置信息。
interface interface-type interface-number:显示指定接口对应的Option 82配置信息。interface-type interface-number为接口类型和接口编号。
【描述】
display dhcp relay information命令用来显示DHCP中继上Option 82的配置信息。
# 显示所有接口对应的Option 82配置信息。
<Sysname> display dhcp relay information all
Interface: Vlan-interface100
    Status: Enable
    Strategy: Replace
    Format: Verbose
    Circuit ID format-type: HEX
    Remote ID format-type: ASCII
    Node identifier: aabbcc
    User defined:
         Circuit ID: company001
Interface: Vlan-interface200
    Status: Enable
    Strategy: Keep
    Format: Normal
    User defined:
         Remote ID: device001
表1-2 display dhcp relay information命令显示信息描述表
接口名
Status
Option 82的状态,取值为Enable或Disable
Strategy
对包含Option 82的请求报文的处理策略,取值为Drop、Keep或Replace
Format
Option 82的填充模式,取值为Normal或Verbose
非用户自定义的Circuit ID子选项的填充格式,取值为ASCII或HEX
非用户自定义的Remote ID子选项的填充格式,取值为ASCII或HEX
Node identifier
接入节点的标识
User defined
用户自定义的子选项内容
Circuit ID
Remote ID
display dhcp relay security [ ip-address | dynamic | static ]
【缺省级别】
1:监控级
ip-address显示指定IP地址的用户地址表项信息。
dynamic:显示动态用户地址表项信息。
static:显示静态用户地址表项信息。
【描述】
display dhcp relay security命令用来显示DHCP中继的用户地址表项信息。如不指定参数,则显示全部的用户地址表项信息。
# 显示所有的用户地址表项信息。
<Sysname> display dhcp relay security
IP Address      MAC Address     Type       Interface
 10.1.1.1       00e0-0000-0001  Static     Vlan1
 10.1.1.5       00e0-0000-0000  Static     Vlan2
---   2 dhcp-security item(s) found   ---
表1-3 display dhcp relay security命令显示信息描述表
IP Address
DHCP客户端的IP地址
MAC Address
DHCP客户端的MAC地址
用户地址表项的类型,Static表示静态地址表项,Dynamic表示动态地址表项,Temporary表示临时地址表项
与DHCP客户端相连的三层接口。如果用户地址表项中没有记录接口,则显示为”N/A”
【缺省级别】
1:监控级
【描述】
display dhcp relay security statistics命令用来显示DHCP中继用户地址表项的统计信息。
# 显示用户地址表项的统计信息。
<Sysname> display dhcp relay security statistics
Static Items      :1
Dynamic Items     :0
Temporary Items   :0
All Items         :1
表1-4 display dhcp relay security statistics命令显示信息描述表
Static Items
静态用户地址表项数目
Dynamic Items
动态用户地址表项数目
Temporary Items
临时用户地址表项数目
All Items
所有用户地址表项的总数
【缺省级别】
1:监控级
【描述】
display dhcp relay security tracker命令用来显示DHCP中继动态用户地址表项的定时刷新周期。
# 显示DHCP中继动态用户地址表项的定时刷新周期。
<Sysname> display dhcp relay security tracker
 Current tracker interval : 10s
以上信息表示当前定时刷新周期为10s。
display dhcp relay server-group { group-id | all }
【缺省级别】
1:监控级
group-id:显示指定的DHCP服务器组的信息,取值范围为0~19。
all:显示所有的DHCP服务器组的信息。
【描述】
display dhcp relay server-group命令用来显示DHCP服务器组中服务器的IP地址。
# 显示DHCP服务器组1中的服务器IP地址。
<Sysname> display dhcp relay server-group 1
    No.            Group IP
    1              1.1.1.1
    2              1.1.1.2
表1-5 display dhcp relay server-group命令显示信息描述表
No.
序号
Group IP
DHCP服务器组中服务器的IP地址
display dhcp relay statistics [ server-group { group-id | all } ]
【缺省级别】
1:监控级
group-id:显示指定DHCP服务器组的报文统计信息,取值范围为0~19。
all:显示所有DHCP服务器组的报文统计信息,每个组的信息单独显示。
【描述】
display dhcp relay statistics命令用来显示DHCP中继的相关报文统计信息。
如果不指定server-group参数,则显示所有DHCP服务器组的相关报文统计信息之和。
相关配置可参考命令reset dhcp relay statistics
# 显示所有DHCP服务器组的相关报文统计信息之和。
<Sysname> display dhcp relay statistics
     Bad packets received:                    0
     DHCP packets received from clients:      0
         DHCPDISCOVER packets received:       0
         DHCPREQUEST packets received:        0
         DHCPINFORM packets received:         0
         DHCPRELEASE packets received:        0
         DHCPDECLINE packets received:        0
         BOOTPREQUEST packets received:       0
     DHCP packets received from servers:      0
         DHCPOFFER packets received:          0
         DHCPACK packets received:            0
         DHCPNAK packets received:            0
         BOOTPREPLY packets received:         0
     DHCP packets relayed to servers:         0
         DHCPDISCOVER packets relayed:        0
         DHCPREQUEST packets relayed:         0
         DHCPINFORM packets relayed:          0
         DHCPRELEASE packets relayed:         0
         DHCPDECLINE packets relayed:         0
         BOOTPREQUEST packets relayed:        0
     DHCP packets relayed to clients:         0
         DHCPOFFER packets relayed:           0
         DHCPACK packets relayed:             0
         DHCPNAK packets relayed:             0
         BOOTPREPLY packets relayed:          0
     DHCP packets sent to servers:            0
         DHCPDISCOVER packets sent:           0
         DHCPREQUEST packets sent:            0
         DHCPINFORM packets sent:             0
         DHCPRELEASE packets sent:            0
         DHCPDECLINE packets sent:            0
         BOOTPREQUEST packets sent:           0
     DHCP packets sent to clients:            0
         DHCPOFFER packets sent:              0
         DHCPACK packets sent:                0
         DHCPNAK packets sent:                0
         BOOTPREPLY packets sent:             0
表1-6 display dhcp relay statistics命令显示信息描述表
DHCP中继接收的错误报文数
DHCP中继从客户端接收的DHCP报文数
DHCP中继从服务器接收的DHCP报文数
DHCP中继转发给服务器的报文数
DHCP中继转发给客户端的报文数
DHCP中继主动发送给服务器的DHCP报文数,用于实现动态用户地址表项的定时刷新
DHCP中继主动发送给客户端的DHCP报文数(目前设备作为DHCP中继时,不会主动发送DHCP报文给客户端)
# 分组显示所有DHCP服务器组的相关报文统计信息。
<Sysname> display dhcp relay statistics server-group all
DHCP relay server-group           #0
     Packet type               Packet number
 Client -> Server:
     DHCPDISCOVER                   0
     DHCPREQUEST                    0
     DHCPINFORM                     0
     DHCPRELEASE                    0
     DHCPDECLINE                    0
     BOOTPREQUEST                   0
 Server -> Client:
     DHCPOFFER                      0
     DHCPACK                        0
     DHCPNAK                        0
     BOOTPREPLY                     0
表1-7 display dhcp relay statistics server-group命令显示信息描述表
DHCP服务器组
Packet type
DHCP报文类型
Packet number
DHCP中继接收到的报文数目
Client -> Server
DHCP中继从客户端接收的DHCP报文
Server -> Client
DHCP中继从服务器接收的DHCP报文
reset dhcp relay statistics [ server-group group-id ]
【缺省级别】
1:监控级
server-group group-id:清除指定DHCP服务器组的DHCP中继的统计信息。group-id为DHCP服务器组号,取值范围为0~19。
【描述】
reset dhcp relay statistics命令用来清除DHCP中继的统计信息。
如果不指定server-group参数,则清除所有DHCP服务器组的DHCP中继的统计信息。
相关配置可参考命令display dhcp relay statistics
# 清除所有DHCP服务器组的DHCP中继的统计信息。
<Sysname> reset dhcp relay statistics
2 DHCP客户端配置命令
多个具有相同MAC地址的VLAN接口通过中继以DHCP方式申请IP地址时,不能用Windows 2000 Server和Windows 2003 Server作为DHCP服务器。
2.1  DHCP客户端配置命令
【缺省级别】
1:监控级
verbose:显示DHCP客户端的详细信息。
interface interface-type interface-number:显示指定接口的DHCP客户端相关信息。interface-type interface-number为接口类型和接口编号。
【描述】
display dhcp client命令用来显示DHCP客户端的相关信息。
如果不指定interface interface-type interface-number参数,显示所有接口的DHCP客户端相关信息。
# 显示所有接口的DHCP客户端相关信息。
<Sysname> display dhcp client
Vlan-interface1 DHCP client information:
 Current machine state: BOUND
 Allocated IP: 40.1.1.20 255.255.255.0
 Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
 DHCP server: 40.1.1.2
# 显示所有接口的DHCP客户端详细信息。
<Sysname> display dhcp client verbose
 Lease from 2005.08.13 15:37:59   to   2005.08.16 15:37:59
 Transaction ID: 0x1c09322d
 Default router: 40.1.1.2
 Classless static route:
   Destination: 1.1.0.1, Mask: 255.0.0.0, NextHop: 192.168.40.16
   Destination: 10.198.122.63, Mask: 255.255.255.255, NextHop: 192.168.40.16
 DNS server: 44.1.1.11
 DNS server: 44.1.1.12
 Domain name: ddd.com
 Boot server: 200.200.200.200  1.1.1.1
 Client ID: 3030-3066-2e65-3234-
              392e-3830-3438-2d56-
              6c61-6e2d-696e-7465-
              7266-6163-6531
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
表2-1 display dhcp client命令显示信息描述表
作为DHCP客户端的接口信息
DHCP客户端状态机的当前状态,取值包括:
l      HALT:停止申请IP地址状态;
l      INIT:初始化状态;
l      SELECTING:发送DHCP-DISCOVER报文寻找DHCP服务器后,进入该状态,等待DHCP服务器的响应报文;
l      REQUESTING:发送DHCP-REQUEST报文请求IP地址后,进入该状态,等待DHCP服务器的响应报文;
l      BOUND:接收到DHCP服务器发送的DHCP-ACK报文,成功获取IP地址后,进入该状态;
l      RENEWING:T1定时器超时后,进入该状态;
l      REBOUNDING:T2定时器超时后,进入该状态。
Allocated IP
DHCP服务器为接口分配的IP地址
Allocated lease
租约时长
T1
DHCP客户端的1/2租约时间(以秒为单位)
T2
DHCP客户端的7/8租约时间(以秒为单位)
Lease from….to….
租约起止时间
DHCP Server
选择的DHCP服务器的地址
Transaction ID
DHCP客户端发起申请时生成的一个随机数,用来唯一标识一次申请过程
Default router
为DHCP客户端指定的网关地址
为DHCP客户端指定的无分类静态路由
Static route
为DHCP客户端指定的有分类静态路由
DNS server
为DHCP客户端指定的DNS服务器地址
Domain name
为DHCP客户端指定的域名后缀
Boot server
为DHCP客户端指定的PXE引导服务器地址,通过Option 43获取,最多可以获取16个地址
Client ID
DHCP客户端ID
在多少时间后T1定时器(即1/2租约时间)将到期
ip address dhcp-alloc [ client-identifier mac interface-type interface-number ]
undo ip address dhcp-alloc
【缺省级别】
2:系统级
client-identifier mac interface-type interface-number:使用指定接口的MAC地址作为客户端ID来获取IP地址。interface-type interface-number表示接口类型和接口号。
【描述】
ip address dhcp-alloc命令用来配置接口使用DHCP方式获取IP地址。undo ip address dhcp-alloc命令用来取消接口使用DHCP方式获取IP地址。
缺省情况下,接口不使用DHCP方式获取IP地址。
l              如果不指定任何参数,则使用接口的MAC地址和接口名组成的字符串作为客户端ID来获取IP地址。
l              释放接口上以DHCP方式获取的IP地址时,DHCP客户端会发送DHCP-RELEASE报文。如果此时该接口处于down状态,则无法保证报文成功发送。
# 指定VLAN接口1使用DHCP方式获取IP地址。
[Sysname-Vlan-interface1] ip address dhcp-alloc
3 DHCP Snooping配置命令
设备只有位于DHCP客户端与DHCP服务器之间,或DHCP客户端与DHCP中继之间时,DHCP Snooping功能配置后才能正常工作;设备位于DHCP服务器与DHCP中继之间时,DHCP Snooping功能配置后不能正常工作。
3.1.1  dhcp-snooping
dhcp-snooping
undo dhcp-snooping
【缺省级别】
2:系统级
【描述】
dhcp-snooping命令用来使能DHCP Snooping功能。undo dhcp-snooping命令用来关闭此功能。在DHCP Snooping功能关闭后,所有端口都可转发DHCP服务器的响应报文,并且不记录DHCP客户端的IP地址和MAC地址。
缺省情况下,DHCP Snooping功能处于关闭状态。
相关配置可参考命令display dhcp-snooping
# 使能DHCP Snooping功能。
[Sysname] dhcp-snooping
dhcp-snooping information circuit-id format-type { ascii | hex }
undo dhcp-snooping information circuit-id format-type
二层以太网接口视图/二层聚合接口视图
【缺省级别】
2:系统级
【描述】
dhcp-snooping information circuit-id format-type命令用来配置非用户自定义的Circuit ID子选项的填充格式。undo dhcp-snooping information circuit-id format-type命令用来恢复缺省情况。
需要注意的是,该命令只对非用户自定义的Circuit ID子选项有效,用户通过dhcp-snooping information circuit-id string命令配置Circuit ID子选项的内容后,将固定采用ASCII格式填充Circuit ID子选项。
相关配置可参考命令display dhcp-snooping information
[Sysname-GigabitEthernet1/0/1] dhcp-snooping information circuit-id format-type ascii
dhcp-snooping information [ vlan vlan-id ] circuit-id string circuit-id
undo dhcp-snooping information [ vlan vlan-id ] circuit-id string
二层以太网接口视图/二层聚合接口视图
【缺省级别】
2:系统级
vlan vlan-id:指定VLAN中Circuit ID子选项的内容。vlan-id表示VLAN的编号,取值范围为1~4094。
【描述】
dhcp-snooping information circuit-id string命令用来配置用户自定义的Circuit ID子选项的内容。undo dhcp-snooping information circuit-id string用来恢复缺省情况。
l              通过该命令配置用户自定义的Circuit ID子选项内容后,固定采用ASCII格式填充Circuit ID子选项。
l              通过vlan vlan-id参数指定VLAN编号时,配置的Circuit ID子选项内容只在该VLAN内有效;没有指定VLAN编号时,配置的Circuit ID子选项内容在所有VLAN内都有效。前者的优先级高于后者,即优先采用对应VLAN内的Circuit ID子选项内容填充Option 82。
相关配置可参考命令dhcp-snooping information formatdisplay dhcp-snooping information
# 全局配置用户自定义的Circuit ID子选项内容为company001。
[Sysname-GigabitEthernet1/0/1] dhcp-snooping information circuit-id string company001
undo dhcp-snooping information enable
二层以太网接口视图/二层聚合接口视图
【缺省级别】
2:系统级
【描述】
dhcp-snooping information enable命令用来使能DHCP Snooping支持Option 82功能。undo dhcp-snooping information enable命令用来禁止DHCP Snooping支持Option 82功能。
缺省情况下,禁止DHCP Snooping支持Option 82功能。
# 使能DHCP Snooping支持Option 82功能。
[Sysname-GigabitEthernet1/0/1] dhcp-snooping information enable
dhcp-snooping information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
undo dhcp-snooping information format [ verbose node-identifier ]
二层以太网接口视图/二层聚合接口视图
【缺省级别】
2:系统级
【描述】
dhcp-snooping information format命令用来配置Option 82的填充模式。undo dhcp-snooping information format命令用来恢复缺省情况。
需要注意的是,在使用undo dhcp-snooping information format命令时,如果不带verbose node-identifier参数,则恢复为缺省的normal填充模式;如果带verbose node-identifier参数,则恢复为verbose模式中的mac填充方式。
[Sysname-GigabitEthernet1/0/1] dhcp-snooping information strategy replace
[Sysname-GigabitEthernet1/0/1] dhcp-snooping information format verbose
dhcp-snooping information remote-id format-type { ascii | hex }
undo dhcp-snooping information remote-id format-type
二层以太网接口视图/二层聚合接口视图
【缺省级别】
2:系统级
【描述】
dhcp-snooping information remote-id format-type命令用来配置非用户自定义的Remote ID子选项的填充格式。undo dhcp-snooping information remote-id format-type命令用来恢复缺省情况。
需要注意的是,本命令只对非用户自定义的Remote ID子选项有效,用户通过dhcp-snooping information remote-id string命令配置Remote ID子选项的内容后,将固定采用ASCII格式填充Remote ID子选项。
[Sysname-GigabitEthernet1/0/1] dhcp-snooping information remote-id format-type ascii
dhcp-snooping information [ vlan vlan-id ] remote-id string { remote-id | sysname }
undo dhcp-snooping information [ vlan vlan-id ] remote-id string
二层以太网接口视图/二层聚合接口视图
【缺省级别】
2:系统级
vlan vlan-id:指定VLAN中Remote ID子选项的内容。vlan-id表示VLAN的编号,取值范围为1~4094。
【描述】
dhcp-snooping information remote-id string命令用来配置用户自定义的Remote ID子选项的内容。undo dhcp-snooping information remote-id string用来恢复缺省情况。
l              通过该命令配置用户自定义的Remote ID子选项内容后,固定采用ASCII格式填充Remote ID子选项。
l              通过vlan vlan-id参数指定VLAN编号时,配置的Remote ID子选项内容只在该VLAN内有效;没有指定VLAN编号时,配置的Remote ID子选项内容在所有VLAN内都有效。前者的优先级高于后者,即优先采用对应VLAN内的Remote ID子选项内容填充Option 82。
如果用户自定义的Remote ID子选项内容为字符串sysname(任意大小写),则需要用引号将字符串sysname括起来。例如,用户自定义的Remote ID子选项内容为Sysname,则需要通过执行dhcp-snooping information remote-id string “Sysname”命令的方式配置。
# 全局配置用户自定义的Remote ID子选项内容为device001。
[Sysname-GigabitEthernet1/0/1] dhcp-snooping information remote-id string device001
dhcp-snooping information strategy { drop | keep | replace }
undo dhcp-snooping information strategy
二层以太网接口视图/二层聚合接口视图
【缺省级别】
2:系统级
【描述】
dhcp-snooping information strategy命令用来配置DHCP Snooping对包含Option 82的请求报文的处理策略。undo dhcp-snooping information strategy命令用来恢复缺省情况。
缺省情况下,对带有Option 82的请求报文的处理策略为replace。
# 配置DHCP Snooping对带有Option 82的请求报文使用keep策略。
[Sysname-GigabitEthernet1/0/1] dhcp-snooping information strategy keep
dhcp-snooping trust [ no-user-binding ]
undo dhcp-snooping trust
二层以太网接口视图/二层聚合接口视图
【缺省级别】
2:系统级
no-user-binding:不记录客户端IP地址和MAC地址的绑定关系。如果DHCP客户端发送的请求报文从此类信任端口到达DHCP Snooping设备,DHCP Snooping设备不会记录该客户端IP地址和MAC地址的绑定。不指定该参数时,记录客户端IP地址和MAC地址的绑定关系。
【描述】
dhcp-snooping trust命令用来配置端口为信任端口。undo dhcp-snooping trust命令用来恢复端口为不信任端口。
缺省情况下,在使能DHCP Snooping功能后,设备的所有端口均为不信任端口。
开启DHCP Snooping功能后,为了使DHCP客户端能从合法的DHCP服务器获取IP地址,必须将与合法DHCP服务器相连的端口设置为信任端口。
相关配置可参考命令display dhcp-snooping trust
# 配置以太网端口GigabitEthernet 1/0/1为信任端口,并记录客户端IP地址和MAC地址的绑定关系。
[Sysname-GigabitEthernet1/0/1] dhcp-snooping trust
display dhcp-snooping [ ip ip-address ]
【缺省级别】
1:监控级
ip ip-address:显示指定IP地址对应的DHCP snooping表项。
【描述】
display dhcp-snooping命令用来显示DHCP Snooping表项信息。
相关配置可参考命令dhcp-snoopingreset dhcp-snooping
display dhcp-snooping命令只显示DHCP-ACK和DHCP-REQUEST报文中IP地址与MAC地址绑定关系一致的DHCP Snooping表项。
# 显示DHCP Snooping表项信息。
<Sysname> display dhcp-snooping
 DHCP Snooping is enabled.
 The client binding table for all untrusted ports.
 Type : D--Dynamic , S--Static
 Type IP Address       MAC Address      Lease      VLAN  Interface
 D    10.1.1.1         00e0-fc00-0006   286           1    GigabitEthernet1/0/1
---   1 dhcp-snooping item(s) found   ---
表3-1 display dhcp snooping命令显示信息描述表
绑定类型,取值包括:
l      D:表示动态生成的IP地址和MAC地址绑定
l      S:表示静态配置的IP地址和MAC地址绑定。目前不支持静态配置
IP Address
DHCP服务器为DHCP客户端分配的IP地址
MAC Address
DHCP客户端的MAC地址
Lease
绑定的租约剩余时间,单位为秒
VLAN
与DHCP客户端连接的设备端口所属的VLAN
与DHCP客户端连接的设备端口
display dhcp-snooping information { all | interface interface-type interface-number }
【缺省级别】
1:监控级
all:显示所有二层以太网接口对应的Option 82配置信息。
【描述】
display dhcp-snooping information命令用来显示DHCP Snooping上Option 82的配置信息。
<Sysname> display dhcp-snooping information all
    Status: Enable
    Strategy: Replace
    Format: Verbose
    User defined:
表3-2 display dhcp-snooping information命令显示信息描述表
接口名
Status
Option 82的状态
Strategy
Format
Option 82的填充模式
Node identifier
接入节点的标识
User defined
用户自定义的子选项内容
Circuit ID
【缺省级别】
1:监控级
【描述】
display dhcp-snooping packet statistics命令用来显示DHCP Snooping设备上的DHCP报文统计信息。
相关配置可参考命令reset dhcp-snooping packet statistics
# 显示DHCP Snooping设备上的DHCP报文统计信息。
<Sysname> display dhcp-snooping packet statistics
 DHCP packets received                  : 100
 DHCP packets sent                      : 200
 Packets dropped due to rate limitation : 20
 Dropped invalid packets                : 0
表3-3 display dhcp-snooping packet statistics命令显示信息描述表
接收的DHCP报文数
DHCP packets sent
发送的DHCP报文数
由于报文限速丢弃的报文数
丢弃的无效报文数
【缺省级别】
1:监控级
【描述】
display dhcp-snooping trust命令用来显示信任端口信息。
相关配置可参考命令dhcp-snooping trust
# 显示信任端口信息。
<Sysname> display dhcp-snooping trust
 DHCP Snooping trust becomes active.
 Interface                                       Trusted
 GigabitEthernet1/0/1                            Trusted
以上显示信息表示DHCP Snooping处于使能状态,DHCP Snooping信任功能生效,信任端口为GigabitEthernet1/0/1。
reset dhcp-snooping { all | ip ip-address }
【缺省级别】
1:监控级
all:清除所有的DHCP Snooping表项。
ip ip-address:清除指定IP地址对应的DHCP Snooping表项。
【描述】
reset dhcp-snooping命令用来清除DHCP Snooping表项。
执行该命令后,将清除所有槽上对应的DHCP Snooping表项。
相关配置可参考display dhcp-snooping
# 清除所有的DHCP Snooping表项。
<Sysname> reset dhcp-snooping all
【缺省级别】
2:系统级
【描述】
reset dhcp-snooping packet statistics命令用来清除DHCP Snooping设备上的DHCP报文统计信息。
相关配置可参考display dhcp-snooping packet statistics
# 清除DHCP Snooping设备上的DHCP报文统计信息。
<Sysname> reset dhcp-snooping packet statistics
4 BOOTP客户端配置命令
多个具有相同MAC地址的VLAN接口通过中继以BOOTP方式申请IP地址时,不能用Windows 2000 Server和Windows 2003 Server作为BOOTP服务器。
4.1  BOOTP客户端配置命令
【缺省级别】
1:监控级
interface interface-type interface-number:显示指定接口的BOOTP客户端相关信息。interface-type interface-number为接口类型和接口编号。
【描述】
display bootp client命令用来显示BOOTP客户端的相关信息。
l              如果不指定interface interface-type interface-number参数,则显示所有接口上的BOOTP客户端的相关信息。
l              如果指定interface interface-type interface-number参数,则显示指定接口上的BOOTP客户端的相关信息。
# 显示VLAN接口1的BOOTP客户端相关信息。
<Sysname> display bootp client interface vlan-interface 1
Vlan-interface1 BOOTP client information:
Allocated IP: 169.254.0.2 255.255.0.0
Transaction ID = 0x3d8a7431
Mac Address  00e0-fc0a-c3ef
表4-1 display bootp client命令显示信息描述表
Ethernet1/1 BOOTP client information或Vlan-interface1 BOOTP client information
作为BOOTP客户端的接口信息
Allocated IP
BOOTP服务器为BOOTP客户端分配的IP地址
Transaction ID
BOOTP报文中XID字段值,即BOOTP客户端发送BOOTP请求报文时选择的随机数,用来与BOOTP服务器的响应报文相匹配。如果响应报文的XID字段值与请求报文的XID字段值不相同,则BOOTP客户端丢弃该响应报文
Mac Address
BOOTP客户端的MAC地址
undo ip address bootp-alloc
【缺省级别】
2:系统级
【描述】
ip address bootp-alloc命令用来配置接口通过BOOTP协议获取IP地址。undo ip address bootp-alloc命令用来取消接口通过BOOTP协议获取IP地址。
缺省情况下,接口不通过BOOTP协议获取IP地址。
相关配置可参考命令display bootp client
# 配置VLAN接口1通过BOOTP协议获取IP地址。
[Sysname-Vlan-interface1] ip address bootp-alloc
