02-Virtual Technologies Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9900)-6W10102-Virtual Technologies Command Reference
05-vSystem commands
05-vSystem commands 191.54 KB
vSystem commands
vSystem commands for the default vSystem
allocate interface
Use allocate interface to assign interfaces to a vSystem.
Use undo allocate interface to reclaim interfaces assigned to a vSystem.
allocate interface interface-type interface-number [ share ]
undo allocate interface interface-type interface-number
All interfaces on the device belong to the default vSystem. A non-default vSystem cannot use any interfaces.
vSystem view
context-admin
interface-type: Specifies an interface by its type.
interface-number: Specifies an interface by its number.
share: Allocates the interface to a vSystem in shared mode. To allocate the interface in exclusive mode, do not specify this keyword.
You can allocate an interface to a vSystem in shared mode or exclusive mode.
·     In exclusive mode, the interface can be used only by that vSystem. You can view the interface and execute commands supported by non-default vSystems for the interface after logging in to the vSystem.
·     In shared mode, the interface can be used by multiple vSystems. A virtual interface with the same name as that interface is created and assigned unique MAC and IP addresses in each vSystem. You can view the shared interface and execute supported commands for it after logging in to the default vSystem. In the non-default vSystems sharing the interface, you can view the virtual interfaces and execute the description, network, and security commands for them.
An interface can be assigned to only one vSystem.
To allocate Layer 2 interfaces to a vSystem, execute the allocate vlan command to assign a VLAN to a vSystem and then the Layer 2 interfaces in the VLAN will be assigned to the vSystem automatically.
Do not assign the interfaces that are bound with VPN instances to vSystems. Do not bind the interfaces that are assigned to vSystems with VPN instances.
You can use this command multiple times to assign multiple interfaces to a vSystem.
# Assign GigabitEthernet 1/0/1 to vSystem vsys1.
[Sysname] vsys vsys1
[Sysname-vsys-2-vsys1] allocate interface gigabitethernet 1/0/1
display vsys interface
allocate vlan
Use allocate vlan to assign a VLAN to a vSystem.
Use undo allocate vlan to reclaim a VLAN assigned to a vSystem.
allocate vlan vlan-id
undo allocate vlan vlan-id
All VLANs belong to the default vSystem.
vSystem view
context-admin
vlan-id: Assigns a VLAN to the vSystem. Make sure the VLAN has been created.
A VLAN can be assigned to only one vSystem.
After a VLAN is assigned to a vSystem, the Layer 2 interfaces in the VLAN will be assigned to the vSystem automatically.
You can use this command multiple times to assign multiple VLANs to a vSystem.
# Assign VLAN 100 to vSystem vsys1.
[Sysname-vsys-2-vsys1] allocate vlan 100
display vsys vlan
capability security-policy-rule maximum
Use capability security-policy-rule maximum to set the maximum number of security policy rules for a vSystem.
Use undo capability security-policy-rule maximum to restore the default.
capability security-policy-rule maximum max-number
The number of security policy rules is not limited for a vSystem.
vSystem view
context-admin
max-number: Specifies the maximum number of security policy rules for the vSystem, in the range of 1 to 4294967295.
A large number of security policy rules occupy too much memory, affecting other features on the vSystem. This command sets the maximum number of security policy rules for a vSystem. When the maximum number is reached, you cannot add new security policy rules.
If the setting of this command is greater than the number of existing rules, the device does not delete rules but you cannot add additional security policy rules.
# Set the maximum number of security policy rules to 1000 for vSystem vys1 with vSystem ID 1.
[Sysname] vsys vsys1 id 2
[Sysname-vsys-2-vsys1] capability security-policy-rule maximum 1000
display security-policy ip (Security Command Reference)
capability session maximum
Use capability session maximum to set the maximum number of concurrent sessions for a vSystem.
Use undo capability session maximum to restore the default.
capability session maximum max-number
The number of concurrent sessions is not limited for a vSystem.
vSystem view
context-admin
max-number: Specifies the maximum number of concurrent sessions for the vSystem. The value range is 1 to 4294967295.
A large number of concurrent sessions occupy too much memory, affecting other features on the vSystem. This command sets the maximum number of concurrent sessions for a vSystem. When the maximum number is reached, you cannot establish additional sessions.
If the setting of this command is greater than the number of existing sessions, the device does not close existing sessions but you cannot establish additional sessions.
This command does not affect local traffic, such as FTP traffic, Telnet traffic, SSH traffic, HTTP traffic, and HTTP-based load balancing traffic.
# Set the maximum number of concurrent sessions to 1000000 for vSystem vys1 with vSystem ID 1.
[Sysname-vsys-2-vsys1] capability session maximum 1000000
vsys
display session statistics (Security Command Reference)
capability session maximum threshold
Use capability session maximum threshold to set the alarm threshold for the ratio of the current concurrent unicast sessions to the maximum concurrent unicast sessions on a vSystem.
Use undo capability session maximum threshold to restore the default.
capability session maximum threshold threshold-value
The alarm threshold is 95% for the ratio of the current concurrent unicast sessions to the maximum concurrent unicast sessions on a vSystem.
vSystem view
threshold-value: Sets the alarm threshold, in percentage. The value range for this argument is 1 to 99.
When the ratio of the current concurrent unicast sessions to the maximum concurrent unicast sessions on a vSystem exceeds the specified threshold, the system generates an alarm message to notify the threshold-crossing event. When the ratio of the current concurrent unicast sessions to the maximum concurrent unicast sessions drops to the specified threshold, the system generates an alarm message to notify that the threshold-crossing alarm is cleared.
# Set the alarm threshold to 50% for the ratio of the current concurrent unicast sessions to the maximum concurrent unicast sessions on vSystem vsys1.
[Sysname-vsys-2-vsys1] capability session maximum threshold 50
vsys
capability session rate
Use capability session rate to set the upper limit of the session establishment rate for a vSystem.
Use undo capability session rate to restore the default.
capability session rate max-value
The session establishment rate is not limited for a vSystem.
vSystem view
context-admin
max-value: Specifies the maximum number of sessions that can be established per second.
Establishing sessions too frequently consumes too much CPU resources. If a vSystem establishes sessions too frequently, other vSystems will not be able to establish sessions. This command sets the number of sessions that can be established per second for a vSystem. When the limit is reached, no additional sessions can be established.
# Configure vSystem vys1 with vSystem ID 1 to establish a maximum of 20000 sessions per second.
[Sysname-vsys-2-vsys1] capability session rate 20000
vsys
capability session rate threshold
Use capability session rate threshold to set the alarm threshold for the ratio of the current session establishment rate to the maximum session establishment rate on a vSystem.
Use undo capability session rate threshold to restore the default.
capability session rate threshold threshold-value
The alarm threshold is 95% for the ratio of the current session establishment rate to the maximum session establishment rate on a vSystem.
vSystem view
When the ratio of the current session establishment rate to the maximum session establishment rate on a vSystem exceeds the specified threshold, the system generates an alarm message to notify the threshold-crossing event. When the ratio of the current session establishment rate to the maximum session establishment rate drops to the specified threshold, the system generates an alarm message to notify that the threshold-crossing alarm is cleared.
# Set the alarm threshold to 80% for the ratio of the current session establishment rate to the maximum session establishment rate on vSystem vsys1.
[Sysname-vsys-2-vsys1] capability session rate threshold 80
vsys
capability throughput
Use capability throughput to set the inbound throughput limit for a vSystem.
Use undo capability throughput to restore the default.
capability throughput { kbps | pps } threshold
The inbound throughput of a vSystem is not limited on a vSystem.
vSystem view
context-admin
kbps: Specifies the inbound throughput limit in kilobits per second.
pps: Specifies the inbound throughput limit in packets per second.
threshold: Specifies the inbound throughput limit in the range of 1000 to 100000000.
You can execute this command to specify an inbound throughput limit for a vSystem. With the inbound throughput limit configured, the vSystem can only use a bandwidth lower than or equal to the specified inbound throughput limit to forward the packets.
# Set the inbound throughput limit to 100000 kbps for vSystem vys1 with vSystem ID 1.
[Sysname-vsys-2-vsys1] capability throughput kbps 10000
default
Use default to restore the default settings for an interface.
default
vSystem interface view
context-admin
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for vSystem interface 2.
[Sysname] interface vsys-interface 2
[Sysname-vSys-interface2] default
description (vSystem view)
Use description to configure a description for a vSystem.
The description of the default vSystem is Default. Non-default vSystems do not have a description.
vSystem view
context-admin
You can configure a description for each vSystem, which is useful to maintain vSystems.
# Configure a description for vSystem vsys1.
[Sysname-vsys-2-vsys1] description test
display vsys
description (vSystem interface view)
The description of a vSystem interface is interface name Interface, for example, vSys-interface2 Interface.
context-admin
For interface identification and easy maintenance, you can configure a description for an interface according to its connection and usage.
You can execute the display interface vsys-interface command view the configured description.
# Configure "for RouterID" as the description of vSystem interface 2.
[Sysname-vSys-interface2] description for RouterID
Use display interface vsys-interface to display vSystem interface information.
display interface [ vsys-interface [ interface-number ] ] [ brief [ description ] ]
context-admin
context-operator
vsys-interface [ interface-number ]: Specifies a vSystem interface by its number. Make sure the specified vSystem interface has been created. If you do not specify this option, the command displays information about all interfaces except VA interfaces. If you specify the vsys-interface keyword without specifying a vSystem interface number, this command displays information about all created vSystem interfaces. For more information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
This command is supported only when a vSystem interface exists on the device.
On the default vSystem, you can view information about all vSystem interfaces. On a non-default vSystem, you can view information about the vSystem interface with same vSystem ID.
# Display information about vSystem interface 2.
<Sysname> display interface vsys-interface 2
vSys-interface2
Current state: UP
Line protocol state: UP(spoofing)
Description: vSys-interface2 Interface
Maximum transmission unit: 64000
Physical: vSystem
Last clearing of counters:  Never
Last 300 seconds input rate:  0 bytes/sec, 0 bits/sec, 0 packets/sec
Last 300 seconds output rate:  0 bytes/sec, 0 bits/sec, 0 packets/sec
Current state
Physical link state of the interface:
·     UP—The interface can transmit and receive the packets.
·     DOWN—The interface cannot transmit or receive the packets.
Line protocol state
Data link layer state of the interface. The field value is UP(spoofing), indicating that the data link layer protocol is up but the link is an on-demand link or does not exist.
Description of the interface.
MTU of the interface.
Physical: vSystem
Physical type of the interface. The field value is vSystem.
baudrate
Baudrate in kbps.
Time when the reset counters interface command was most recently used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Average input rate (in Bps, bps, and pps) in the most recent 300 seconds. This field is available only when the interface supports statistics collection.
Average output rate (in Bps, bps, and pps) in the most recent 300 seconds. This field is available only when the interface supports statistics collection.
Statistics about the input packets, including the number of input packets, number of input bytes, and number of dropped packets. This field is available only when the interface supports statistics collection.
Statistics about the output packets, including the number of output packets, number of output bytes, and number of dropped packets. This field is available only when the interface supports statistics collection.
# Display brief information about all vSystem interfaces.
<Sysname> display interface vsys-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
vSys2                 UP   UP(s)    --              forLAN1
Brief information about Layer 3 interfaces.
Data link layer state of the interface. The field value is (s) - spoofing, indicating that the data link layer protocol is up but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
Protocol
Data link layer state of the interface. The field value is UP(s).
Primary IP
Primary IP address of the interface.
reset counters interface vsys-interface
display vsys
Use display vsys to display vSystems.
display vsys [ name vsys-name ]
context-admin
context-operator
name vsys-name: Specifies a vSystem by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this option, this command displays all vSystems.
# Display all vSystems.
<Sysname> display vsys
ID     Name      Status       Description
1      admin     Active       Default
2      aaa       Active       vsys2
3      bbb       Restarting   vsys3
Status
Status of the vSystem:
·     Active—The vSystem is active.
·     Restarting—The vSystem is restarting.
description
vsys
Use display vsys interface to display interfaces assigned to vSystems.
display vsys [ name vsys-name ] interface
context-admin
context-operator
name vsys-name: Specifies a vSystem by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command displays the interfaces for all vSystems.
# Display the interfaces for all vSystems.
<Sysname> display vsys interface
vSystem vsys1's interfaces:
  gigabitethernet 1/0/2
vSystem vsys2's interfaces:
  gigabitethernet 1/0/3
allocate interface
display vsys vlan
Use display vsys vlan to display VLAN lists for vSystems.
display vsys [ name vsys-name ] vlan
context-admin
context-operator
name vsys-name: Specifies a vSystem by its name, a case-sensitive string of 1 to 31 characters. If you do not specify tthis option, this command displays VLAN lists for all vSystems.
# Display VLAN lists for all vSystems.
<Sysname> display vsys vlan
vSystem vsys1's VLANs:
 2,4094
vSystem vsys2's VLANs:
 5,6,3400
allocate vlan
display vsys-capability throughput
Use display vsys-capability throughput to display the inbound throughput usage for vSystems.
In standalone mode:‌
display vsys-capability throughput [ name vsys-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display vsys-capability throughput [ name vsys-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
vsys-name: Specifies a vSystem name, a case-sensitive string of 1 to 31 characters. If you do not specify a vSystem, this command displays the inbound throughput usage for all vSystems.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the inbound throughput usage on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the inbound throughput usage on the global active MPU. (In IRF mode.) ‌
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
# Display the inbound throughput usage for all vSystems.
<Sysname> display vsys-capability throughput
Throughput usage:
 Slot 1 CPU 0:
  ID    Name             Maximum    Used       Free       Usage(%)   Unit
  1     Admin            NA         0          NA         NA         kbps
  2     yao              NA         0          NA         NA         kbps
ID
vSystem ID.
Name
vSystem name.
Maximum
Inbound throughput limit. If the inbound throughput is not limited, this field displays NA.
Used
Current inbound throughput. If the inbound throughput is not limited, this field displays 0.
Free
Available inbound throughout, which is obtained by subtracting the current inbound throughput from the inbound throughput limit. If the inbound throughput is not limited, this field displays NA.
Usage
Ratio of the current inbound throughput to the inbound throughput limit, in percentage. If the inbound throughput is not limited, this field displays 0.
Unit
Unit of throughput. If the inbound throughput is not limited, this field displays NA.
Use interface vsys-interface to enter vSystem interface view.
interface vsys-interface interface-number
undo interface vsys-interface interface-number
context-admin
interface-number: Specifies a vSystem interface by its number. It must be the same as the interface number configured on the non-default system where the interface belongs.
The vSystem interfaces are used for the communication between two non-default vSystems.
A vSystem interface is automatically generated when a default vSystem user creates a non-default vSystem. Each non-default vSystem has only one vSystem interface that cannot be created manually. You can execute the display interface vsys-interface command to view the vSystem interface information.
# Enter the view of vSystem interface 2.
vsys
Use reset counters interface vsys-interface to clear vSystem interface statistics.
reset counters interface [ vsys-interface [ interface-number ] ]
context-admin
vsys-interface [ interface-number ]: Specifies a vSystem interface by its number. If you do not specify this option, the command clears statistics about all interfaces except VA interfaces. If you specify the vsys-interface keyword without specifying a vSystem interface number, this command clears vSystem interface statistics as follows:
·     On the default vSystem, the statistics about all vSystem interfaces will be cleared.
·     On a non-default vSystem, the statistics about the non-default vSystem will be cleared.
To judge whether the specified interface and its link work normally, you can execute this command to clear the existing interface statistics and then the system will start the interface statistics automatically.
# Clear statistics about vSystem interface 2.
<Sysname> reset counters interface vsys-interface 2
save vsys
Use save vsys to save current configuration of a vSystem to a text file.
save vsys vsys-name [ file-url ]
context-admin
file-url: Specifies a file path, a string of up to 255 characters. The file must be a .cfg file.
You can execute this command to save the configuration of a vSystem to the specified text file. If the file specified for this command does not exist, the system creates the file before saving the configuration. If the file already exists, the system overwrite the file with the same name.
If you do not specify a file path or use a file path same as the next-startup configuration file, the specified vSystem configuration will be saved in the next-startup configuration file. After the device reboot, the vSystem will be restored according to the saved configuration.
# Save current configuration of vSystem abc to abcvsys.cfg.
<Sysname> save vsys abc abcvsys.cfg
The configuration of vSystem abc will be saved to flash:/abcvsys.cfg. Continue? [Y/N]:y
Now saving the configuration of vSystem abc to the device.
Saving configuration flash:/abcvsys.cfg. Please wait...
Configuration is saved to device successfully.
vsys configuration deploy
switchto vsys
Use switchto vsys to log in to a non-default vSystem from the system view of the default vSystem and enter the user view of the non-default vSystem.
switchto vsys vsys-name
context-admin
vsys-name: Specifies a non-default vSystem by its name, a case-sensitive string of 1 to 31 characters.
A default vSystem user can execute this command on the device to log in to any non-default vSystem for configuration and management.
# Log in to vSystem abc from the system view of the default vSystem.
[Sysname] switchto vsys abc
<Sysname-abc>
vsys
Use vsys to create a vSystem and enter its view, or enter the view of an existing vSystem.
Use undo vsys to delete a vSystem.
vsys vsys-name [ id vsys-id ]
undo vsys vsys-name
A default vSystem exists. The vSystem name is Admin and the vSystem ID is 1.
context-admin
vsys-name: Specifies a vSystem by its name, a case-sensitive string of 1 to 31 characters. Valid characters are letters, digits, underscores (_), and hyphens (-). A vSystem name cannot be any form of admin.
id vsys-id: Specifies a vSystem by its ID. If you do not specify this option, the system assigns the lowest ID among the available IDs to the vSystem. The value range for the vsys-id argument is 2 to 2048.
The default vSystem is the root system. You cannot delete it.
When you execute this command to create a vSystem, a VPN instance with the same name will be created and the created vSystem will be bound to the VPN instance automatically. Make sure the vSystem name is not the same as the existing VPN instance name. You can execute the display ip vpn-instance command to view the existing VPN instances in the system.
Delete a vSystem with caution. Deleting a vSystem deletes all settings of the vSystem.
If you execute this command multiple times, you can create multiple non-default vSystems.
# Create a non-default vSystem named vsys1 with vSystem ID 2.
display vsys
display ip vpn-instance (MPLS Command Reference)
vsys-capability throughput alarm enable
Use vsys-capability throughput alarm enable to enable the vSystem inbound throughput alarm and configure the alarm threshold.
Use undo vsys-capability throughput alarm enable to disable the vSystem inbound throughput alarm.
vsys-capability throughput alarm enable alarm-threshold alarm-threshold
The vSystem inbound throughput alarm is disabled.
context-admin
alarm-threshold alarm-threshold: Sets the alarm threshold in percentage, in the range of 1 to 99.
The vSystem inbound throughput alarm takes effect on all vSystems.
For the vSystem inbound throughput alarm to take effect, you must use the capability throughput command to set the vSystem inbound throughput limit.
The vSystem inbound throughput alarm allows the device to send a log message to the information center when the inbound throughput usage ratio of a vSystem exceeds or drops below the alarm threshold. With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Enable the vSystem inbound throughput alarm and set the alarm threshold to 80%.
[Sysname] vsys-capability throughput alarm enable alarm-threshold 80
vsys-capability throughput drop-logging enable
Use vsys-capability throughput drop-logging enable to enable dropped packet logging for vSystem inbound throughput limiting.
Use undo vsys-capability throughput drop-logging enable to disable dropped packet logging for vSystem inbound throughput limiting.
Dropped packet logging is disabled for vSystem inbound throughput limiting.
context-admin
Dropped packet logging takes effect on all vSystems.
For dropped packet logging to take effect, you must use the capability throughput command to set the vSystem inbound throughput limit.
Dropped packet logging enables the device to send log messages to the information center for the following events:
·     A vSystem drops a packet because the vSystem inbound throughput limit is reached.
·     The inbound throughput of a vSystem drops below the vSystem inbound throughput limit.
# Enable dropped packet logging for vSystem inbound throughput limiting.
[Sysname] vsys-capability throughput drop-logging enable
vSystem commands for non-default vSystems
context-admin
vsys-admin
context-admin
context-operator
vsys-admin
vsys-operator
vsys-interface [ interface-number ]: Specifies a vSystem interface by its number. Make sure the specified vSystem interface has been created. If you specify the vsys-interface keyword without specifying a vSystem interface number, this command displays information about all created vSystem interfaces. If you do not specify this option, the command displays information about all interfaces except VA interfaces. For more information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
vSys-interface2
Current state: UP
Physical: vSystem
Table 5 Command output
Current state
Line protocol state
Physical: vSystem
baudrate
Baudrate in kbps.
Table 6 Command output
Link
Protocol
Primary IP
context-admin
vsys-admin
context-admin
vsys-admin
