02-Virtual Technologies Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9X71)-6W70202-Virtual Technologies Command Reference
03-Context commands
03-Context commands 324.14 KB
Context commands· 1
Context commands for the default context 1
allocate interface· 1
allocate vlan· 2
allocate vxlan· 3
blade-controller-team·· 3
capability object-policy-rule maximum·· 4
capability security-policy-rule maximum·· 5
capability session maximum·· 6
capability session rate· 7
capability sslvpn-user maximum·· 8
capability throughput 8
context 9
context start 10
context-capability inbound broadcast single· 11
context-capability inbound broadcast total 12
context-capability inbound drop-logging enable· 12
context-capability inbound multicast single· 13
context-capability inbound multicast total 14
context-capability inbound unicast total 15
context-capability throughput alarm enable· 15
context-capability throughput drop-logging enable· 16
description· 17
display blade-controller-team·· 18
display context 20
display context capability· 21
display context capability inbound broadcast 23
display context capability inbound multicast 24
display capability inbound unicast 25
display context configuration· 26
display context interface· 28
display context online-users sslvpn· 28
display context reboot 29
display context resource· 30
display context statistics· 31
display context vlan· 33
hardware fast-forwarding vpc enable· 34
limit-resource cpu· 35
limit-resource disk· 35
limit-resource memory· 37
location blade-controller 38
location blade-controller-team·· 39
reset blade-controller-team·· 40
reset context capability inbound broadcast 41
reset context capability inbound multicast 42
reset context reboot 42
snmp-agent trap enable sib· 43
switchto context 43
tar context log· 44
Context commands for non-default contexts· 45
display context interface· 45
display context reboot 45
reset context reboot 46
Context commands
This section describes the context commands that you can use after logging in to the default context (the physical device).
allocate interface
Use allocate interface to assign interfaces to a context.
Use undo allocate interface to reclaim interfaces assigned to a context.
allocate interface { interface-type interface-number }&<1-24> [ share ]
undo allocate interface { interface-type interface-number }&<1-24>
allocate interface interface-type interface-number1 to interface-type interface-number2 [ share ]
undo allocate interface interface-type interface-number1 to interface-type interface-number2
All interfaces on the firewall belong to the default context. A non-default context cannot use any interfaces.
Context view
{ interface-type interface-number }&<1-24>: Assigns 1 to 24 individual interfaces to the context.
interface-type interface-number1 to interface-type interface-number2: Assigns a range of interfaces to the context. The specified interfaces must be the same interface type and must belong to the same interface card.
share: Assigns the interfaces in shared mode. If you do not specify this keyword, the command assigns the interfaces exclusively to the context.
IMPORTANT
IMPORTANT:
·     Do not assign IRF physical interfaces to a non-default context.
·     If a subinterface of a Layer 3 interface is a member interface of a Reth interface, do not assign the Layer 3 interface to a non-default context.
·     Logical interfaces support only shared mode, and physical interfaces support both exclusive mode and shared mode.
You can assign interfaces in exclusive or shared mode.
·     Exclusive mode—You assign an interface exclusively to a context, and only the context can use the interface. The administrator of the context can see the interface and use all commands supported on the interface.
·     Shared mode—You assign an interface to multiple contexts in shared mode, and the system creates a virtual interface for each context. The virtual interfaces use the same name as the physical interface but have different MAC addresses and IP addresses. They forward and receive packets through the physical interface. The shared mode improves interface usage.
You can see the physical interface and perform all commands supported on the interface from the default context. The administrator of a context can only see the context's virtual interface and use the description and network- and security-related commands.
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to context sub1 in shared mode.
[Sysname] context sub1
[Sysname-context-2-sub1] allocate interface gigabitethernet 1/0/1 gigabitethernet 1/0/3 share
allocate vlan
Use allocate vlan to assign VLANs to a context.
Use undo allocate vlan to reclaim VLANs assigned to a context.
allocate vlan vlan-id&<1-24>
undo allocate vlan vlan-id&<1-24>
allocate vlan vlan-id1 to vlan-id2
undo allocate vlan vlan-id1 to vlan-id2
No VLAN is assigned to a context.
Context view
vlan-id&<1-24>: Assigns 1 to 24 individual VLANs to the context.
vlan-id1 to vlan-id2: Assigns a range of VLANs to the context. The vlan-id1 argument represents the start VLAN ID and the vlan-id2 argument represents the end VLAN ID.
You assign static VLANs except for VLAN 1 to contexts without the VLAN-unshared attribute. Before doing so, you must create the VLANs on the default context. A VLAN can be assigned only to one context. After the assignment to a context, you can use only the display commands on the context, but you can use all VLAN commands on the default context.
A context with the VLAN-unshared attribute has its own VLAN resources (VLAN 2 through VLAN 4094). It does not share VLAN resources with any other context. To create VLANs for the context, log in to the context and use the vlan command. VLAN 1 is system defined. You cannot create or delete VLAN 1.
# Assign VLAN 100 to context sub1.
[Sysname-context-2-sub1] allocate vlan 100
allocate vxlan
Use allocate vxlan to assign VXLANs to a context.
Use undo allocate vxlan to reclaim VXLANs assigned to a context.
allocate vxlan vxlan-id&<1-24>
undo allocate vxlan vxlan-id&<1-24>
allocate vxlan vxlan-id1 to vxlan-id2
undo allocate vxlan vxlan-id1 to vxlan-id2
No VXLANs are assigned to a context.
Context view
vxlan-id&<1-24>: Specifies a list of up to 24 VXLAN IDs. The value range for VXLAN IDs is 0 to 16777215.
vxlan-id1 to vxlan-id2: Specifies a range of VXLAN IDs. The value range for VXLAN IDs is 0 to 16777215. The vxlan-id1 argument represents the start VXLAN ID and the vxlan-id2 argument represents the end VXLAN ID.
VXLANs assigned to a context are accessible only to that context. You cannot use or configure them in other contexts.
# Assign VXLAN 100 to context sub1.
[Sysname-context-2-sub1] allocate vxlan 100
The VXLAN will be allocated to context sub1. Continue? [Y/N]:y
Use blade-controller-team to create a security engine group and enter its view, or enter the view of an existing security engine group.
Use undo blade-controller-team to delete a security engine group.
blade-controller-team blade-controller-team-name [ id blade-controller-team-id ]
undo blade-controller-team { blade-controller-team-name | id blade-controller-team-id }
A default security engine group exists. The group name is Default and group ID is 1.
blade-controller-team-name: Specifies the security engine group name, a case-sensitive string of 1 to 31 characters.
id blade-controller-team-id: Specifies the security engine group ID in the range of 2 to 256. If you do not specify this option, the system assigns the lowest ID among the available IDs to the security engine group.
The default security engine group cannot be modified or deleted, and you cannot enter its view.
To delete a security engine group, first use the undo location blade-controller command to remove all security engines in the security engine group.
# Create a security engine named abc and enter its view.
[Sysname] blade-controller-team abc
[Sysname-blade-controller-team-3-abc]
Use capability object-policy-rule maximum to set the maximum number of object policy rules for a context.
Use undo capability object-policy-rule maximum to restore the default.
capability object-policy-rule maximum max-number
The number of object policy rules is not limited for a context.
Context view
max-number: Specifies the maximum number of object policy rules for the context, in the range of 1 to 4294967295.
A large number of rules occupy too much memory, affecting other features on the context. This command sets the maximum number of object policy rules for a context. When the maximum number is reached, you cannot add new rules.
If the maximum number you set is smaller than the number of existing object policy rules, this setting takes effect. The context does not delete extra existing object policy rules and allows new object policy rules to be created only when the number of object policy rules drops below the maximum number.
The number of object policy rules for a context is counted as per security engine. Each security engine to which the context is assigned can have the specified maximum number of object policy rules.
# Set the maximum number of object policy rules to 1000 for context cnt2.
[Sysname] context cnt2
[Sysname-context-2-cnt2] capability object-policy-rule maximum 1000
display object-policy ip (Security Command Reference)
Use capability security-policy-rule maximum to set the maximum number of security policy rules for a context.
Use undo capability security-policy-rule maximum to restore the default.
capability security-policy-rule maximum max-number
The number of security policy rules is not limited for a context.
Context view
max-number: Specifies the maximum number of security policy rules for the context, in the range of 1 to 4294967295.
A large number of rules occupy too much memory, affecting other features on the context. This command sets the maximum number of security policy rules for a context. When the maximum number is reached, you cannot add new rules.
If the maximum number you set is smaller than the number of existing security policy rules, this setting takes effect. The context does not delete extra existing security policy rules and allows new security policy rules to be created only when the number of security policy rules drops below the maximum number.
The number of security policy rules for a context is counted as per security engine. Each security engine to which the context is assigned can have the specified maximum number of security policy rules.
# Set the maximum number of security policy rules to 1000 for context cnt2.
[Sysname-context-2-cnt2] capability security-policy-rule maximum 1000
display security-policy ip (Security Command Reference)
Use capability session maximum to set the maximum number of concurrent unicast sessions for a context.
Use undo capability session maximum to restore the default.
capability session maximum max-number
The number of concurrent unicast sessions is not limited for a context.
Context view
max-number: Specifies the maximum number of concurrent unicast sessions for the context. The value range is 1 to 4294967295.
A large number of concurrent unicast sessions occupy too much memory, affecting other features on the context. This command sets the maximum number of concurrent unicast sessions for a context. When the maximum number is reached, you cannot establish additional unicast sessions.
If the maximum number you set is smaller than the number of existing concurrent unicast sessions, this setting takes effect. The context does not delete extra existing concurrent unicast sessions and allows new unicast sessions to be created only when the number of concurrent unicast sessions drops below the maximum number.
The number of unicast sessions for a context is counted as per security engine. Each security engine to which the context is assigned can have the specified maximum number of concurrent unicast sessions.
This command does not affect local traffic, such as FTP traffic, Telnet traffic, SSH traffic, HTTP traffic, and HTTP-based load balancing traffic.
# Set the maximum number of concurrent unicast sessions to 1000000 for context cnt2.
[Sysname-context-2-cnt2] capability session maximum 1000000
context
display session statistics (Security Command Reference)
Use capability session rate to set the upper limit of the session establishment rate for a context.
Use undo capability session rate to restore the default.
capability session rate max-value
The session establishment rate is not limited for a context.
Context view
max-value: Specifies the maximum number of sessions that can be established per second.
Establishing sessions too frequently consumes too much CPU resources. If a context establishes sessions too frequently, other contexts in the same security engine will not be able to establish sessions. This command sets the number of sessions that can be established per second for a context. When the limit is reached, no additional sessions can be established.
The session establishment rate is calculated as per security engine. Each security engine to which the context is assigned can establish sessions at the specified rate.
# Configure context cnt2 to establish a maximum of 20000 sessions per second.
[Sysname-context-2-cnt2] capability session rate 20000
context
Use capability sslvpn-user maximum to set the maximum number of SSL VPN users for a context.
Use undo capability sslvpn-user maximum to restore the default.
capability sslvpn-user maximum max-number
The number of SSL VPN users is not limited for a context. The number is determined by the usage of the SSL VPN licenses installed on the device.
Context view
max-number: Specifies the maximum number of SSL VPN users for the context. The value range is 1 to 1048575.
This command limits the number of SSL VPN users that can log in to a context. When the maximum number is reached, the context will reject the login requests of new SSL VPN users.
If the maximum number you set is smaller than the number of SSL VPN users that already have logged in to a context, this setting takes effect. The context does not log out the currently logged-in users and allows new users to log in only when the number of the logged-in users drops below the maximum number.
# Set the maximum number of SSL VPN users to 1000000 for context cnt2.
[Sysname-context-2-cnt2] capability sslvpn-user maximum 1000000
context
Use capability throughput to set the outbound throughput threshold for a context.
Use undo capability throughput to restore the default.
capability throughput { kbps | pps } threshold
The outbound throughput of a context is not limited on a context.
Context view
kbps: Specifies the throughput in kilobits per second.
pps: Specifies the throughput in number of packets per second.
threshold: Specifies the throughput threshold in the range of 1000 to 1000000000.
This command imposes the same outbound throughput threshold on every security engine to which the context is assigned.
# Set the outbound throughput threshold to 100000 kbps for context cnt2.
[Sysname-context-2-cnt2] capability throughput kbps 100000
# Set the outbound throughput threshold to 10000 pps for context cnt3.
[Sysname] context cnt3
[Sysname-context-3-cnt3] capability throughput pps 10000
context
Use context to create a context and enter its view, or enter the view of an existing context.
Use undo context to delete a context.
context context-name [ id context-id ] [ vlan-unshared ]
undo context context-name
A default context exists. The context name is Admin and the context ID is 1.
context-name: Specifies the context name, a case-sensitive string of 1 to 15 characters.
id context-id: Specifies the context ID in the range of 1 to 65279. If you do not specify this option, the system assigns the lowest ID among the available IDs to the context.
vlan-unshared: Configures the context to not share VLAN resources with any contexts. If you do not specify this keyword, the context shares the same VLAN resources with other contexts.
A context with the VLAN-unshared attribute has its own VLAN resources (VLAN 1 through VLAN 4094). It does not share VLAN resources with any other contexts. You log in to the context and use the vlan command to create VLANs for the context.
All contexts without the VLAN-unshared attribute share the same VLAN resources (VLAN 1 through VLAN 4094). You create VLANs on the default context and use the allocate vlan command to assign VLANs to the contexts. A VLAN can be assigned only to one context.
# Create a context named test.
[Sysname] context test
[Sysname-context-2-test]
# Create a context named test. Set its ID to 2.
[Sysname] context test id 2
context start
Use context start to start a context.
Use undo context start to stop a context.
context start [ force ]
undo context start [ force ]
A context is not started.
Context view
force: Forcibly starts or stops a context. If you do not specify this keyword, the command starts or stops a context through normal procedures.
CAUTION
CAUTION:
Stop a context with caution. Stopping a context stops all services on the context and logs out all users on the context. To avoid configuration data loss, save the running configuration of a context before you stop the context.
You must use this command to initiate a newly created context. You can configure a context only after it is started.
# Start context cnt2.
[Sysname-context-2-cnt2] context start
Use context-capability inbound broadcast single to set the inbound broadcast rate limit for a context.
Use undo context-capability inbound broadcast single to restore the default.
context-capability inbound broadcast single pps threshold
The inbound broadcast rate limit for a context is the total inbound broadcast rate limit divided by the number of active contexts that share interfaces with other contexts.
Context view
pps threshold: Specifies the inbound broadcast rate limit in pps, in the range of 1000 to 100000.
The rate limit takes effect only on active contexts that share interfaces with other contexts on the device.
If you execute this command in system view, you set the limit for the default context. If you execute this command in context view, you set the limit for the non-default context.
When both a per-context inbound broadcast rate limit and the total inbound broadcast rate limit are reached, the device drops subsequent broadcast packets that arrive at the context. To set the total inbound broadcast rate limit, use the context-capability inbound broadcast total command.
The incoming packet rate of a context is independently calculated on each security engine where the context resides. The inbound broadcast rate limit for the context independently applies to each of the security engines. If broadcast packets of the context are processed by multiple security engines, the actual broadcast packet rate might be greater than the inbound broadcast rate limit you set.
# Set the inbound broadcast rate limit for the default context to 10000 pps for context ctx1.
[Sysname] context ctx1
[Sysname-context-1-ctx1] context-capability inbound broadcast single pps 10000
Use context-capability inbound broadcast total to set the total inbound broadcast rate limit for all contexts.
Use undo context-capability inbound broadcast total to restore the default.
context-capability inbound broadcast total pps threshold
The total inbound broadcast rate limit for all contexts is 20000 pps.
pps threshold: Specifies the total inbound broadcast rate limit in pps. The limit can be 0 or a value, in the range of 1000 to 100000. Setting the limit to 0 disables inbound broadcast rate limiting.
The rate limit takes effect only on active contexts that share interfaces with other contexts.
The total inbound broadcast rate is the sum of the inbound broadcast rates on all active contexts that share interfaces with other contexts.
When both a per-context inbound broadcast rate limit and the total inbound broadcast rate limit are reached, the device drops subsequent broadcast packets that arrive at the context. To set the inbound broadcast rate limit for a context, use the context-capability inbound broadcast single command.
# Set the total inbound broadcast rate limit to 10000 pps.
[Sysname] context-capability inbound broadcast total pps 10000
Use context-capability inbound drop-logging enable to enable logging for incoming packets dropped because of rate limiting on contexts.
Use undo context-capability inbound drop-logging enable to disable logging for incoming packets dropped because of rate limiting on contexts.
Logging is enabled for incoming packets that are dropped because of rate limiting on contexts.
This logging feature generates and sends a log message to the information center when an incoming packet is dropped because of broadcast or multicast rate limiting on contexts. For more information about how the information center manages log messages, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable logging for incoming packets dropped because of rate limiting on contexts.
[Sysname] context-capability inbound drop-logging enable
Use context-capability inbound multicast single to set the inbound multicast rate limit for a context.
Use undo context-capability inbound multicast single to restore the default.
context-capability inbound multicast single pps threshold
The inbound multicast rate limit for a context is the total inbound multicast rate limit divided by the number of active contexts that share interfaces with other contexts.
Context view
pps threshold: Specifies the inbound multicast rate limit in pps, in the range of 1000 to 100000.
When both a per-context inbound multicast rate limit and the total inbound multicast rate limit are reached, the device drops subsequent multicast packets that arrive at the context. To set the total inbound multicast rate limit, use the context-capability inbound multicast total command.
The incoming packet rate of a context is independently calculated on each security engine where the context resides. The inbound multicast rate limit for the context independently applies to each of the security engines. If multicast packets of the context are processed by multiple security engines, the actual multicast packet rate might be greater than the inbound multicast rate limit you set.
# Set the inbound multicast rate limit to 10000 pps for context ctx1.
[Sysname-context-1-ctx1] context-capability inbound multicast single pps 10000
Use context-capability inbound multicast total to set the total inbound multicast rate limit for all contexts.
Use undo context-capability inbound multicast total to restore the default.
context-capability inbound multicast total pps threshold
The total inbound multicast rate limit for all contexts is 30000 pps
pps threshold: Specifies the total inbound multicast rate limit in pps. The limit can be 0 or a value in the range of 1000 to 100000. Setting the limit to 0 disables inbound multicast rate limiting.
The total inbound multicast rate is the sum of the inbound multicast rates on all active contexts that share interfaces with other contexts.
When both a per-context inbound multicast rate limit and the total inbound multicast rate limit are reached, the device drops subsequent multicast packets that arrive at the context. To set the inbound multicast rate limit for a context, use the context-capability inbound multicast single command.
# Set the total inbound multicast rate limit to 10000 pps.
[Sysname] context-capability inbound multicast total pps 10000
Use context-capability inbound unicast total to set the CPU usage threshold per CPU core for all inbound packets from all contexts.
Use undo context-capability inbound unicast total to restore the default.
context-capability inbound unicast total cpu-usage threshold
The CPU usage threshold per CPU core is 95%.
cpu-usage threshold: Specifies the CPU usage threshold per CPU core for inbound packets, in percentage. The value range for the threshold argument is 1 to 100.
The threshold set by using this command applies to all inbound packets, including broadcast, unicast, and multicast packets.
If the shared queue in the driver is full when the total usage of a CPU core reaches the specified threshold, the system determines that an attack risk is present. Then, it takes the attack prevention action configured by using the attack-defense cpu-core action command until the attack risk is eliminated. For more information about the attack-defense cpu-core action command, see attack detection and prevention commands in Security Command Reference.
# Set the CPU usage threshold per CPU core for all inbound packets to 70%.
[Sysname] context-capability inbound unicast total cpu-usage 70
attack-defense cpu-core action (Security Command Reference)
Use context-capability throughput alarm enable to enable the outbound throughput usage alarm and set the throughput usage alarm threshold for contexts.
Use undo context-capability throughput alarm enable to disable the outbound throughput usage alarm for contexts.
context-capability throughput alarm enable alarm-threshold alarm-threshold
Outbound throughput usage alarm is disabled for contexts.
alarm-threshold usage-threshold: Specifies the throughput usage alarm threshold, in percentage. The value range for the usage-threshold argument is 1 to 99.
This command applies to all contexts. To have it take effect on a context, you must also use the capability throughput command to set an outbound throughput threshold for that context.
The system generates a throughput usage alarm for a context when the ratio of its actual outbound throughput to the outbound throughput threshold exceeds the throughput usage alarm threshold. When that ratio decreases below the throughput usage alarm threshold, the system generates a recovery log.
The generated logs are sent to the information center. With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Enable the throughput usage alarm and set the throughput usage alarm threshold to 80% for contexts.
[Sysname] context-capability throughput alarm enable alarm-threshold 80
Use context-capability throughput drop-logging enable to enable throughput-threshold-execeeded packet drop logging for all contexts.
Use undo context-capability throughput drop-logging enable to disable throughput-threshold-execeeded packet drop logging for all contexts.
The system does not log packet drop events that occur on any contexts when the outbound throughput threshold is exceeded.
This command enables the system to log packet drop events that occur on any contexts because the outbound throughput threshold is exceeded.
This command applies to all contexts. To have it take effect on a context, you must also use the capability throughput command to set an outbound throughput threshold for it.
These two commands enable the device to generate a packet drop event log when it starts dropping packets on a context because the outbound throughput of the context is exceeded. When the outbound throughput of the context decreases below the threshold, the device generates a recovery log.
# Enable throughput-threshold-execeeded packet drop logging for all contexts.
[Sysname] context-capability throughput drop-logging enable
description
Use description to configure the description of the default context, or configure a description for a non-default context.
The default context uses the description DefaultContext. A non-default context does not have a description.
Context view
You can configure a description for each context, which is useful when there are a number of contexts.
# Configure a description for context cnt2.
[Sysname-context-2-cnt2] description test
Use display blade-controller-team to display security engine groups.
display blade-controller-team [ blade-controller-team-name | id blade-controller-team-id | all ]
blade-controller-team-name: Specifies the name of the security engine group, a case-sensitive string of 1 to 31 characters.
id blade-controller-team-id: Specifies the ID of the security engine group, in the range of 1 to 256.
all: Displays detailed information about all security engine groups.
If you do not specify any parameters, the command displays brief information about all security engine groups.
# Display brief information about all security engine groups.
<Sysname> display blade-controller-team
ID          Name
1           Default
2           abc
# (In standalone mode.) Display detailed information about security engine group abc.
<Sysname> display blade-controller-team abc
ID: 2     Name: abc
  Slot    CPU    Status        LBGroupID
* 3       1      Normal        2
* : Primary blade controller of the team.
Load balancing group information for the blade controller team:
  LBGroupID   Name              BLAGG
  2           Blade3fw2         Blade-Aggregation258
# (In IRF mode.) Display detailed information about security engine group abc.
ID: 2     Name: abc
  Chassis    Slot    CPU    Status    LBGroupID
* 1          3       1      Normal    2
# (In standalone mode.) Display detailed information about all security engine groups.
<Sysname> display blade-controller-team all
ID: 1     Name: Default
* 4       1      Normal    1
  1           Blade3fw1           Blade-Aggregation257
ID: 2     Name: abc
* 3       1      Normal    2
# (In IRF mode.) Display detailed information about all security engine groups.
ID: 1     Name: Default
* 1          4       1      Normal    1
ID: 2     Name: abc
* 1          3       1      Normal    2
Status
Status of the security engine:
·     Absent—No security engine is installed in the slot.
·     Fault—The security engine is not operating correctly.
·     Normal—The security engine is operating correctly.
LBGroupID
ID of the load balancing group that is associated with the security engine group. The ID is assigned automatically by the system.
Main security engine of the security engine group.
Name (under Load balancing group information for the blade controller team)
Name of the load balancing group that is associated with the security engine group. The name is predefined by the system in the form of security engine type + security engine group ID. For more information, see the link-aggregation blade command in Layer 2—LAN Switching Command Reference.
BLAGG
Name of the Blade aggregate interface for the load balancing group. The interface type is Blade-Aggregation. The interface number equals the LBGroupID plus 256.
display context
Use display context to display contexts.
display context [ name context-name ]
name context-name: Specifies a context by its name, a case-sensitive string of 1 to 15 characters.
On the default context, this command displays the context specified by the name context-name option. Without the option, this command displays all contexts on the device.
# Display all contexts.
<Sysname> display context
ID     Name          Status           Description
1      cnt1          active           context1
2      cnt2          inactive         context2
3      cnt3          inactive         context3
Status
Status of the context:
·     active—The context is operating correctly.
·     inactive—The context is not started.
·     starting—The context is starting up.
·     updating—The context is being assigned to a security engine group.
·     stopping—The context is being stopped.
Use display context capability to display usage of allocable service resources on contexts.
In standalone mode:
display context [ name context-name ] capability [ security-policy | session [ slot slot-number cpu cpu-number ] | sslvpn-user ]
In IRF mode:
display context [ name context-name ] capability [ security-policy | session [ chassis chassis-number slot slot-number cpu cpu-number ] | sslvpn-user ]
name context-name: Specifies a context by its name, a case-sensitive string of 1 to 15 characters. If you do not specify a context, this command displays usage of allocable service resources on all contexts.
security-policy: Displays usage of allocable security policy rule resources.
session: Displays usage of allocable session resources.
sslvpn-user: Displays usage of allocable SSL VPN user resources.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the usage on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the usage on all cards in the IRF fabric. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is supported only if multiple CPUs are available on the specified slot.
This command is supported only on the default context.
# Display usage of allocable service resources on all contexts.
<Sysname> display context capability
Session usage and establishment rate:
 Slot 1 CPU 0:
  ID    Name     Maximum    Used    Free    Total(/s)  Rate(/s)   Usage(%)
  1    Admin     NA         500     NA      NA         1000       NA
  2    context1  10000      300     9700    1000       100        10
  3    context2  2000       1000    1000    2000       1000       50
Security policy rule usage:
  1     Admin           NA             500                  NA
Online SSL VPN users:
  1     Admin           NA             0              NA
  2     conetxt1        10000          3000           7000
  3     context2        2000           0              2000
ID
Context ID.
Name
Context name.
Maximum
Maximum number of allocable resources.
Used
Number of used resources.
Free
Number of available resources.
Total
Maximum session establishment rate, which is the maximum number of sessions that can be established in a second.
Rate
Current session establishment rate.
Usage
Ratio of the current session establishment rate to the maximum session establishment rate, in percentage.
Use display context capability inbound broadcast to display the inbound broadcast rate limit information about a context.
In standalone mode:
display context name context-name capability inbound broadcast slot slot-number cpu cpu-number
In IRF mode:
display context name context-name capability inbound broadcast chassis chassis-number slot slot-number cpu cpu-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
# (In standalone mode.) Display the inbound broadcast rate limit information about context abc on a slot.
<Sysname> display context name abc capability inbound broadcast slot 1 cpu 1
Context name: abc
Context ID: 2
 Drop Rate: 1000 pps
 Inbound throughput limit: 8000 pps
 Total inbound throughput limit: 10000 pps
Drop Rate
Broadcast packet drop rate of the context.
Inbound broadcast rate limit for the context.
Total inbound broadcast rate limit.
Use display context capability inbound multicast to display the inbound multicast rate limit information about a context.
In standalone mode:
display context name context-name capability inbound multicast slot slot-number cpu cpu-number
In IRF mode:
display context name context-name capability inbound multicast chassis chassis-number slot slot-number cpu cpu-number
# (In standalone mode.) Display the inbound multicast rate limit information about context abc on a slot.
<Sysname> display context name abc capability inbound multicast slot 1 cpu 1
Context name: abc
Context ID: 2
 Drop Rate: 1000 pps
Table 5 Command output
Drop Rate
Multicast packet drop rate of the context.
Inbound multicast rate limit for the context.
Total inbound multicast rate limit.
Use display capability inbound unicast to display attack prevention statistics for CPU cores.
In standalone mode:
display capability inbound unicast slot slot-number cpu cpu-number
In IRF mode:
display capability inbound unicast chassis chassis-number slot slot-number cpu cpu-number
Use this command to display the attack situation and packet processing situation on each CPU core and locate the attack cause.
# (In standalone mode.) Display attack prevention statistics for CPU cores on a slot.
<Sysname> display context name abc capability inbound unicast slot 1 cpu 1
CPU usage threshold: 95%
Current attack-defense cpu-core action:
CPU ID          Up rate         Packet rate    CPU usage      Effective percentage
CPU0            0/s             0/s            1%             95%
CPU1            0/s             0/s            2%             95%
CPU2            0/s             0/s            97%            95%
CPU3            0/s             0/s            3%             95%
CPU4            0/s             0/s            1%             95%
CPU5            0/s             0/s            2%             95%
CPU6            50000/s         40000/s        99%            70%
CPU7            0/s             0/s            1%             95%
CPU8            0/s             0/s            1%             95%
CPU9            0/s             0/s            5%             95%
CPU10           0/s             0/s            2%             95%
CPU11           0/s             0/s            1%             95%
CPU12           0/s             0/s            6%             95%
CPU13           0/s             0/s            1%             95%
CPU14           0/s             0/s            3%             95%
CPU15           0/s             0/s            1%             95%
Table 6 Command output
CPU usage threshold
Total CPU usage threshold per CPU core for all inbound broadcast, multicast, and unicast packets from all contexts, in percentage. When this threshold is reached, attack prevention action will be taken on excessive packets to protect the CPU core.
Attack prevention action on excessive packets for CPU core protection.
Options:
·     Bypass—Adds the Bypass flag in the driver.
·     Drop—Drops the packets in the driver.
·     Per-packet-balance—Distributes the packets across CPU cores on a per-packet basis in the driver.
·     Isolate—Puts the packets in the isolation queue in hardware for future processing.
CPUID
CPU core ID.
Pass rate
Number of packets permitted per second when the attack prevention action is drop or isolate.
Drop rate
Number of packets dropped per second when the attack prevention action is drop or isolate.
Up rate
Number of packets sent to the CPU core per second when the attack prevention action is per-packet-balance.
Balance rate
Number of packets sent to other CPU cores per second when the attack prevention action is per-packet-balance.
CPU usage
Current usage of the CPU core, in percentage. When this value reaches the CPU usage threshold per CPU core, the attack prevention action is triggered.
Maximum percentage of CPU time available for packet processing. The CPU core will use all its available processing capability to process packets after the attack prevention action is triggered, in order to minimize the impact of the action and decrease the CPU usage as quickly as possible. The attack prevention action will take on a packet only if it is beyond the maximum available capability of the CPU core.
Use display context configuration to display or save context configuration information.
display context [ name context-name ] configuration [ file filename ]
name context-name: Specifies a context by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this option, the command displays the configurations of all contexts.
file filename: Saves the information to a file. The filename argument specifies the file name, a case-insensitive string of 1 to 255 characters. The file name must use the .tar.gz extension, and cannot be ..tar.gz or …tar.gz. It cannot start with a hyphen (-) or contain any of the following characters: quote marks ("), forward slashes (/), colons (:), backward slashes (\), question marks (?), less than signs (<), greater than signs (>), vertical bars (|), and asterisks (*). If you do not specify this option, the system prompts you to choose whether to display or save the information.
This command does not take effect on contexts that have not started up.
Executing this command is equivalent to executing the display current-configuration command on the specified context or each context.
# Display the configurations of all contexts.
<Sysname> display context configuration
Save or display context configuration(Y=save, N=display)? [Y/N]:n
===========inner configuration of context Admin===========
 version 7.1.064, Feature 9321
sysname Sysname
context Admin id 1
context cnt1 id 2
return
<Sysname>
===========inner configuration of context cnt1===========
sysname Sysname
context Admin id 1
context cnt1 id 2
---- More ----
# Save the configurations of all contexts to a file in interactive mode.
Save or display context configuration (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag.tar.gz]: test.tar.gz
Saving context configuration to flash:/test.tar.gz. Please wait....
# Save the configurations of all contexts to a file by specifying a file name for the command.
<Sysname> display context configuration file test.tar.gz
Use display context interface to display interfaces assigned to contexts.
display context [ name context-name ] interface
On the default context, this command displays the interfaces for the context specified by the name context-name option. Without the option, this command displays the interfaces for all contexts on the device.
# Display the interfaces for all contexts.
<Sysname> display context interface
Context stub1's interfaces:
  GigabitEthernet1/0/2
Context stub2's interfaces:
  GigabitEthernet1/0/3
allocate interface
Use display context online-users sslvpn to display the number of online SSL VPN users on all contexts.
The number of online SSL VPN users collected by this command equals to the number of SSL VPN sessions.
# Display the number of online SSL VPN users on all contexts.
<Sysname> display context online-users sslvpn
Total number of SSL VPN online users: 50
Use display context name reboot to display non-default context reboot information.
display context name context-name reboot show-number [ offset ]
name context-name: Specifies a non-default context by its name, a case-sensitive string of 1 to 15 characters.
show-number: Specifies the number of non-default context reboot records to be displayed, in the range of 1 to 20.
offset: Specifies the offset of the first non-default context reboot record to be displayed, starting from the most recent record. The value range is 0 to 19. The default value is 0, which means starting from the most recent record.
To view the reboot information about the default context, execute the display version command and view the Last reboot reason field. For more information about this command, see Fundamentals Command Reference.
# Display the most recent reboot record of context test.
<Sysname> display context name test reboot 1
----------------- Reboot record 1 -----------------
Recorded at          : 2019-05-01  11:16:00
Reason               : 0x0
Process              : comsh (PID: 120) from Context 3 on slot 1 cpu 0
Table 7 Command output
Reason
Reboot reason.
Process
Process that triggered the reboot, in the format of process-name (PID: process-ID) from Context context-ID on slot slot-number CPU CPU-number.
display version (Fundamentals Command Reference)
reset context name reboot
Use display context resource to display CPU, disk space, and memory usage for contexts.
In standalone mode:
display context [ name context-name ] resource [ cpu | disk | memory ] [ slot slot-number cpu cpu-number ]
In IRF mode:
display context [ name context-name ] resource [ cpu | disk | memory ] [ chassis chassis-number slot slot-number cpu cpu-number ]
name context-name: Specifies a context by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this option, the command displays the usage for all contexts.
cpu: Displays the CPU usage.
disk: Displays the disk space usage.
memory: Displays the memory usage.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays resource usage statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays resource usage statistics for all cards in the IRF fabric. (In IRF mode.)
If you do not specify the cpu, disk, or memory keyword, the command displays the CPU, disk space, and memory space usage.
# (In standalone mode.) Display the CPU usage for the contexts on all cards.
<Sysname> display context resource cpu
CPU usage:
Slot 2 CPU 1:
  ID   Name        Weight       Usage(%)
  1    cnt1        10           24
  2    cnt2        10           0
Table 8 Command output
Memory usage
Memory usage statistics.
CPU usage
CPU usage statistics.
Disk usage
Disk usage statistics.
Used 238.1MB, Free 249.3MB, Total 487.4MB
Memory usage statistics:
·     Used—Used memory space, in MB.
·     Free—Available memory space, in MB.
·     Total—Total memory space, in MB.
The Used field displays 0 if no context has started on the slot.
Cfa0: Used 0MB,  Free 61MB, Total 61MB
Usage statistics for a storage device (Cfa0 in this sample output):
·     Used—Used storage space, in MB.
·     Free—Available storage space, in MB.
·     Total—Total storage space, in MB.
ID
Context ID.
name
Context name.
Weight
The CPU resource usage weight of the context.
Usage(%)
Actual CPU usage of the context, in percentage.
Quota(MB)
The maximum amount of memory or disk space for the context, in MB.
Used(MB)
The amount of memory or disk space that the context has used.
Free(MB)
The amount of memory or disk space that is still available for the context.
limit-resource cpu
limit-resource disk
Use display context statistics to display or save resource statistics for contexts.
display context [ name context-name ] statistics [ file filename ]
name context-name: Specifies a context by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this option, the command displays or saves resource statistics for all contexts.
file filename: Saves the information to a file. The filename argument specifies the file name, a case-insensitive string of 1 to 255 characters. The file name must use the .tar.gz extension, and cannot be ..tar.gz or …tar.gz. It cannot start with a hyphen (-) or contain any of the following characters: quote marks ("), forward slashes (/), colons (:), backward slashes (\), question marks (?), less than signs (<), greater than signs (>), vertical bars (|), and asterisks (*). If you do not specify this argument, the system prompts you to choose whether to display or save the information.
Executing this command is equivalent to executing the following commands:
·     display context capability
·     display counters inbound interface
·     display counters outbound interface
·     display counters rate inbound interface
·     display counters rate outbound interface
·     display interface
·     display ip statistics
·     display ipv6 statistics
·     display nat statistics
·     display session statistics
# Display resource statistics for all contexts.
<Sysname> display context statistics
Save or display context statistics (Y=save, N=display)? [Y/N]:n
    =============== display session statistics =================
Slot 1:
Current sessions: 0
          TCP sessions:                    0
          UDP sessions:                    0
         ICMP sessions:                    0
       ICMPv6 sessions:                    0
     UDP-Lite sessions:                    0
         SCTP sessions:                    0
         DCCP sessions:                    0
        RAWIP sessions:                    0
# Save resource statistics for all contexts to a file in interactive mode.
Save or display context statistics(Y=save, N=display)? [Y/N]:y
Saving context statistics to flash:/test.tar.gz. Please wait....
# Save resource statistics for all contexts to a file by specifying a file name for the command.
<Sysname> display context statistics file test.tar.gz
display counters inbound interface (Interface Command Reference)
display counters outbound interface (Interface Command Reference)
display counters rate inbound interface (Interface Command Reference)
display counters rate outbound interface (Interface Command Reference)
display interface (Interface Command Reference)
display ip statistics (Layer 3—IP Services Command Reference)
display ipv6 statistics (Layer 3—IP Services Command Reference)
display nat statistics (NAT Command Reference)
Use display context vlan to display VLAN lists for contexts.
display context [ name context-name ] vlan
On the default context, if you specify the name context-name option, this command displays the VLAN list for the specified context. If you do not specify the name context-name option, this command displays VLAN lists for all contexts.
# Display VLAN lists for all contexts.
<Sysname> display context vlan
Context stub1's VLAN(s):
Context stub2's VLAN(s):
  2,4094
Context stub3's VLAN(s):
5,6,800-3000,3400
# Display the VLAN list for context sub1.
<Sysname> display context name sub1 vlan
  5,6,11-23,3400
allocate vlan
Use hardware fast-forwarding vpc enable to enable inter-VPC fast forwarding.
Use undo hardware fast-forwarding vpc enable to disable inter-VPC fast forwarding.
In standalone mode:
hardware fast-forwarding vpc enable [ slot slot-number [ cpu cpu-number ] ]
undo hardware fast-forwarding vpc enable [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
hardware fast-forwarding vpc enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo hardware fast-forwarding vpc enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Inter-VPC fast forwarding is disabled.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command enables inter-VPC fast forwarding on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command enables inter-VPC fast forwarding on all cards. (In IRF mode.)
For this command to take effect, you must enable fast forwarding by using the hardware fast-forwarding enable command. For more information about this command, see fast forwarding commands in Layer 3—IP Services Command Reference.
This command takes effect on all contexts.
# Enable inter-VPC fast forwarding.
[Sysname] hardware fast-forwarding vpc enable
hardware fast-forwarding enable (Layer 3—IP Services Command Reference)
limit-resource cpu
Use limit-resource cpu to set a CPU weight for a context.
Use undo limit-resource cpu to restore the default.
limit-resource cpu weight weight-value
Each context has a CPU weight of 10.
Context view
weight weight-value: Specifies a CPU weight value in the range of 1 to 10.
This command imposes the same CPU weight on every security engine to which the context is assigned.
# Set the CPU weight to 2 for context cnt2.
[Sysname-context-2-cnt2] limit-resource cpu weight 2
limit-resource disk
Use limit-resource disk to set a disk space percentage for a context. A disk space percentage defines the maximum disk space that the context can use.
Use undo limit-resource disk to restore the default.
In standalone mode:
limit-resource disk slot slot-number cpu cpu-number ratio limit-ratio
undo limit-resource disk slot slot-number cpu cpu-number
In IRF mode:
limit-resource disk chassis chassis-number slot slot-number cpu cpu-number ratio limit-ratio
undo limit-resource disk chassis chassis-number slot slot-number cpu cpu-number
All contexts on a security engine share the disk space on the engine. A context can use all free disk space on the engine.
Context view
slot slot-number cpu cpu-number: Specifies a security engine on a card. The slot-number argument represents the slot number of the card. The cpu-number argument represents the CPU number. (In standalone mode.)
chassis chassis-number slot slot-number cpu cpu-number: Specifies a security engine on a card of an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. The cpu-number argument represents the CPU number. (In IRF mode.)
ratio limit-ratio: Specifies the ratio of the disk space that the context can use to the total disk space of the device. The value range is 1 to 100.
When you assign a context to a security engine group, the system automatically assigns disk space resources on the security engines to the context. All contexts residing on the same security engine share and compete for the engine's free disk resources. To prevent one context from occupying too many disk space resources, assign disk space resources to the contexts.
When you assign disk space to a context, follow these guidelines:
·     Use the display context resource command to view the amount of disk space that has been used by the context before assigning disk space to the context.
·     Assign disk space larger than the disk space used by the context to avoid the following problems:
¡     The context cannot apply for more disk space.
¡     The context cannot create, copy, or save additional folders or files.
The disk space percentage setting takes effect on all the storage media.
# (In standalone mode.) Configure context cnt2 to use up to 20% of the disk space on the security engine for CPU 1 in slot 3.
[Sysname-context-2-cnt2] limit-resource disk slot 3 cpu 1 ratio 20
# (In IRF mode.) Configure context cnt2 to use up to 30% of the disk space on the security engine for CPU 1 in slot 2 of member device 1.
[Sysname-context-2-cnt2] limit-resource disk chassis 1 slot 2 cpu 1 ratio 30
Use limit-resource memory to set a memory space percentage for a context. A memory space percentage defines the maximum memory space that the context can use.
Use undo limit-resource memory to restore the default.
In standalone mode:
limit-resource memory slot slot-number cpu cpu-number ratio limit-ratio
undo limit-resource memory slot slot-number cpu cpu-number
In IRF mode:
limit-resource memory chassis chassis-number slot slot-number cpu cpu-number ratio limit-ratio
undo limit-resource memory chassis chassis-number slot slot-number cpu cpu-number
All contexts on a security engine share the memory space on the engine. A context can use all free memory space on the engine.
Context view
ratio limit-ratio: Specifies the ratio of the memory space that the context can use on the specified security engine to the total memory space of the engine. The value range is 1 to 100.
When you assign a context to a security engine group, the system automatically assigns memory space resources on the security engines to the context. All contexts residing on the same security engine share and compete for the engine's free memory resources. To prevent one context from occupying too many memory space resources, assign memory space resources to the contexts. When the limit for a context is reached, the context cannot apply for more memory space.
When you assign memory space to a context, follow these guidelines:
·     Use the display context resource command to view the amount of memory space that has been used by the context before assigning memory space to the context.
·     Assign an amount of memory space that is larger than the memory space used by the context to avoid the following problems:
¡     The context cannot apply for more memory space.
# (In standalone mode.) Configure context cnt2 to use up to 30% of the memory space on the security engine for CPU 1 in slot 3.
[Sysname-context-2-cnt2] limit-resource memory slot 3 cpu 1 ratio 30
# (In IRF mode.) Configure context cnt2 to use up to 30% of the memory space on the security engine for CPU 1 in slot 2 of member device 1.
[Sysname-context-2-cnt2] limit-resource memory chassis 1 slot 2 cpu 1 ratio 30
Use location blade-controller to add a security engine to a security engine group.
Use undo location blade-controller to restore the default.
In standalone mode:
location blade-controller slot slot-number cpu cpu-number
undo location blade-controller slot slot-number cpu cpu-number
In IRF mode:
location blade-controller chassis chassis-number slot slot-number cpu cpu-number
undo location blade-controller chassis chassis-number slot slot-number cpu cpu-number
A security engine joins the default security engine group when it is installed.
Security engine group view
slot slot-number cpu cpu-number: Specifies a security engine by its CPU number and the slot number. (In standalone mode.)
chassis chassis-number slot slot-number cpu cpu-number: Specifies a security engine by its CPU number, the slot number, and the member ID. (In IRF mode.)
CAUTION
CAUTION:
For the device to correctly process services, make sure the default security engine group has a minimum of one security engine.
If the security engine is in position, the location blade-controller command takes effect immediately.
If the security engine is not in position, the location blade-controller command takes effect after the security engine is installed.
You can add security engines to security engine groups before installing the security engines. Make a security engine deployment plan before doing so, and install security engines as planned. If you install a non-security engine card in a slot for a security engine, the system automatically deletes the location blade-controller command from the running configuration.
You can add as many security engines to a security engine group as you like. However, one security engine can be added only to one security engine group.
# (In standalone mode.) Add the security engine on CPU 1 in slot 2 to security engine group abc.
<sysname> system-view
[sysname] blade-controller-team abc
[Sysname-blade-controller-team-2-abc] location blade-controller slot 2 cpu 1
This operation will also reboot the blade controller. Continue? [Y/N]:y
# (In IRF mode.) Add the security engine on CPU 1 in slot 2 of member device 2 to security engine group abc.
[Sysname-blade-controller-team-2-abc] location blade-controller chassis 2 slot 2 cpu 1
# (In standalone mode.) Add the security engine on CPU 1 in slot 3 to security engine group abc. The security engine is not in position.
[Sysname-blade-controller-team-2-abc] location blade-controller slot 3 cpu 1
Operation succeeded, but the blade controller is absent.
# (In IRF mode.) Add the security engine on CPU 1 in slot 3 of member device 2 to security engine group abc. The security engine is not in position.
[Sysname-blade-controller-team-2-abc] location blade-controller chassis 2 slot 3 cpu 1
location blade-controller-team
Use location blade-controller-team to assign a context to a security engine group.
Use undo location blade-controller-team to reclaim a context from a security engine group.
location blade-controller-team team-id
undo location blade-controller-team team-id
The default context resides on all security engine groups. A non-default context does not reside on any security engine groups.
Context view
team-id: Specifies a security engine group by its ID. The security engine group must already exist.
To run and provide services, a context must be assigned to a security engine group. After you assign a context to a security engine group, the context can use the CPU, disk space, and memory space resources on the security engines in the group.
A context can be assigned only to one security engine group. To change an assignment, you must reclaim the context before assigning it to the new security engine group.
You can assign multiple contexts to a security engine group.
You can add a security engine to a security engine group before or after assigning a context to the security engine group.
# Assign context cnt2 to security engine group 2.
[Sysname-context-2-cnt2] location blade-controller-team 2
reset blade-controller-team
Use reset blade-controller-team to clear information for an absent security engine in a security engine group.
In standalone mode:
reset blade-controller-team team-id member slot slot-number cpu cpu-number
In IRF mode:
reset blade-controller-team team-id member chassis chassis-number slot slot-number cpu cpu-number
team-id: Specifies a security engine group by its ID. The value range is 1 to 256. To view the engine ID, use the display blade-controller-team command.
# (In standalone mode.) Clear information for an absent security engine (CPU 1 in slot 2) in security engine group abc.
<sysname> reset blade-controller-team 1 member slot 2 cpu 1
# (In IRF mode.) Clear information for an absent security engine (CPU 1 in slot 2 of member device 1) in security engine group abc.
<sysname> reset blade-controller-team 1 member chassis 1 slot 2 cpu 1
reset context capability inbound broadcast
Use reset context capability inbound broadcast to clear the inbound broadcast rate limit statistics for a context.
In standalone mode:
reset context name context-name capability inbound broadcast slot slot-number cpu cpu-number
In IRF mode:
reset context name context-name capability inbound broadcast chassis chassis-number slot slot-number cpu cpu-number
# (In standalone mode.) Clear the inbound broadcast rate limit statistics for context abc on a slot.
<Sysname> reset context name abc capability inbound broadcast slot 1 cpu 1
reset context capability inbound multicast
Use reset context capability inbound multicast to clear the inbound multicast rate limit statistics for a context.
In standalone mode:
reset context name context-name capability inbound multicast slot slot-number cpu cpu-number
In IRF mode:
reset context name context-name capability inbound multicast chassis chassis-number slot slot-number cpu cpu-number
# (In standalone mode.) Clear the inbound multicast rate limit statistics for context abc on a slot.
<Sysname> reset context name abc capability inbound multicast slot 1 cpu 1
reset context reboot
Use reset context name reboot to clear non-default context reboot information.
reset context [ name context-name ] reboot
name context-name: Specifies a non-default context by its name, a case-sensitive string of 1 to 15 characters. If you do not specify a non-default context, this command clears reboot information for all non-default contexts.
# Clear reboot information about non-default context test.
<Sysname> reset context name test reboot
snmp-agent trap enable sib
Use snmp-agent trap enable sib to enable SNMP notifications for context outbound throughput events.
Use undo snmp-agent trap enable sib to disable SNMP notifications for context outbound throughput events.
SNMP notifications for context outbound throughput events is disabled.
This command enables the device to generate SNMP notifications for the events logged by the following logging features:
·     Throughput-threshold-exceeded packet drop event logging, enabled by using the context-capability throughput drop-logging enable command.
·     Outbound throughput usage alarm, enabled by using the context-capability throughput alarm enable command.
For the SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for context outbound throughput events.
[Sysname] snmp-agent trap enable sib
switchto context
Use switchto context to log in to a context.
switchto context context-name
context-name: Specifies a context that has been started.
Use this command to log in to a non-default context from the system view of the default context. The connection uses the internal interfaces between the physical device and the context.
# Log in to context test2.
[Sysname] switchto context test2
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
<H3C>
tar context log
Use tar context log to archive log messages for contexts.
tar context [ name context-name ] log file filename
name context-name: Specifies a context by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this option, the command archives log messages for all contexts.
file filename: Specifies a file name, a case-insensitive string of 1 to 255 characters. The file name must use the .tar.gz extension, and cannot be ..tar.gz or …tar.gz. It cannot start with a hyphen (-) or contain any of the following characters: quote marks ("), forward slashes (/), colons (:), backward slashes (\), question marks (?), less than signs (<), greater than signs (>), vertical bars (|), and asterisks (*).
This command does not take effect on contexts that have never started up.
This command archives all files in the logfile directory and diagfile directory.
# Archive log messages for all contexts to file test.tar.gz.
<Sysname> tar context log file test.tar.gz
Context commands for non-default contexts
This section describes the context commands that you can use after logging in to a non-default context.
Use display context interface to display interfaces assigned to the current context.
# Display the interfaces assigned to the current context.
allocate interface
display context reboot
Use display context reboot to display reboot information about the current context.
display context reboot show-number [ offset ]
context-admin
context-operator
show-number: Specifies the number of context reboot records to be displayed, in the range of 1 to 20.
offset: Specifies the offset of the first context reboot record to be displayed, starting from the most recent record. The value range is 0 to 19. The default value is 0, which means starting from the most recent record.
# Display the most recent reboot record of the current CONTEXT.
<Sysname> display context reboot 1
Reason               : 0x0
For information about the command output fields, see Table 7.
Use reset context reboot to clear reboot information about the current context.
context-admin
# Clear reboot information about the current context.
<Sysname> reset context reboot
