04-DPI Configuration Guide
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Configuration Guide(V7)(R9153P39 R9001P39)-6W40104-DPI Configuration Guide
04-URL filtering configuration
04-URL filtering configuration 274.71 KB
Configuring URL filtering· 1
About URL filtering· 1
URL· 1
URL filtering rule· 1
URL category· 2
URL filtering policy· 2
URL filtering whitelist/blacklist rule· 3
URL filtering mechanism·· 3
URL filtering signature library management 4
Restrictions: Hardware compatibility with URL filtering· 5
Restrictions: Licensing requirements for URL filtering· 5
URL filtering tasks at a glance· 5
Configuring a URL category· 6
Configuring URL filtering cloud query· 6
Configuring a URL filtering policy· 7
About URL filtering policy· 7
Configuring a category-based URL filtering policy· 7
Configuring a whitelist-based URL filtering policy· 8
Copying a URL filtering policy or category· 9
Copying a URL filtering policy· 9
Copying a URL filtering category· 9
Applying a URL filtering policy to a DPI application profile· 9
Activating URL filtering policy and rule settings· 10
Applying a DPI application profile to a security policy rule· 10
Applying a DPI application profile to an object policy rule· 11
Managing the URL filtering signature library· 11
Restrictions and guidelines· 11
Scheduling automatic URL filtering signature library update· 11
Triggering an immediate URL filtering signature update· 12
Performing a URL filtering signature manual update· 12
Rolling back the URL filtering signature library· 13
Enabling DPI engine logging· 13
Configuring URL filtering logging for resource access· 13
About URL filtering logging for resource access· 13
Logging access to only resources in the root directories of websites· 14
Disabling logging for access to resources of specific types· 14
Enabling URL fast auditing· 14
Enabling HTTPS URL filtering· 15
Display and maintenance commands for URL filtering· 15
URL filtering configuration examples· 16
Example: Using a URL filtering policy in a security policy· 16
Example: Manually updating the URL filtering signature library· 18
Example: Configuring automatic URL filtering signature library update· 20
About URL filtering
URL filtering controls access to the Web resources by filtering the URLs that the users visit.
URL
A URL is a reference to a resource that specifies the location of the resource on a network and a mechanism for retrieving it. The syntax of a URL is protocol://host [:port]/path/[;parameters][?query]#fragment. Figure 1 shows an example URL.
Figure 1 URL syntax
Table 1 describes the fields in a URL.
Table 1 URL field descriptions
protocol
Transmission protocol, such as HTTP.
host
Domain name or IP address of the server where the indicated resource is located.
[:port]
Optional field that identifies the port number of the transmission protocol. If this field is omitted, the default port number of the protocol is used.
/path/
String that identifies the directory or file where the indicated resource is stored. The path is a sequence of segments separated by zero or multiple forward slashes.
[parameters]
Optional field that contains special parameters.
[?query]
Optional field that contains parameters to be passed to the software for querying dynamic webpages. Each parameter is a <key>=<value> pair. Different parameters are separated by an ampersand (&).
URI
Uniform resource identifier that identifies a resource on a network.
URL filtering rule
A URL filtering rule matches URLs based on the content in the URI or hostname field.
URL filtering rule type
URL filtering provides the following types of URL filtering rules:
·     Predefined URL filtering rules—Signature-based URL filtering rules. The device automatically generates them based on the local URL filtering signatures. In most cases, the predefined rules are sufficient for URL filtering.
·     User-defined URL filtering rules—Regular expression- or text-based URL filtering rules that are manfully configured.
URL filtering rule matching method
A URL filtering rule supports the following URL matching methods:
·     Text-based matching—Matches the hostname and URI fields of a URL against text patterns.
When performing text-based matching for the hostname field of a URL, the device first determines if the text pattern contains the asterisk (*) wildcard character at the beginning or end.
¡     If the text pattern does not contain the asterisk (*) wildcard character at the beginning or end, the hostname matching succeeds if the hostname of the URL matches the text pattern.
¡     If the text pattern contains the asterisk (*) wildcard character at the beginning, the hostname matching succeeds if the hostname of the URL matches or ends with the text pattern without the wildcard character.
¡     If the text pattern contains the asterisk (*) wildcard character at the end, the hostname matching succeeds if the hostname of the URL matches or starts with the text pattern without the wildcard character.
¡     If the text pattern contains the asterisk (*) wildcard character at both the beginning and the end, the hostname matching succeeds if the hostname of the URL matches or includes the text pattern without the wildcard characters.
Text-based matching for the URI field works in the same way that text-based matching for the hostname field works.
·     Regular expression-based matching—Matches the hostname and URI fields of a URL against regular expressions. For example, if you set the regular expression for hostname matching to sina.*cn, URLs that carry the news.sina.com.cn hostname will be matched.
URL category
URL filtering provides the URL categorization feature to facilitate filtering rule management.
You can classify multiple URL filtering rules to a URL category and specify an action for the category. If a matching rule is in multiple URL categories, the system takes the action for the category with the highest severity level.
URL filtering supports the following types of URL categories:
·     Predefined URL categories.
The predefined URL categories contain the predefined URL filtering rules. Each predefined URL category has a unique severity level in the range of 1 to 999, and a category name that begins Pre-. Predefined URL categories cannot be modified.
The device supports two levels of predefined URL categories: child URL category and parent URL category.
A predefined parent URL category contains only predefined child URL categories.
·     User-defined URL categories.
You can manually create URL categories and configure filtering rules for them. The severity level of a user-defined URL category is in the range of 1000 to 65535. You can edit the filtering rules and change the severity level for a user-defined URL category.
A URL filtering policy can contain multiple URL categories, and each category has an action defined for packets that match a filtering rule in the category. You can also specify the default action for packets that do not match any filtering rules in the policy. URL filtering actions include drop, permit, block source, reset, redirect, and logging.
The device supports using URL-based whitelist and blacklist rules to filter HTTP packets. If the URL in an HTTP packet matches a blacklist rule, the packet is dropped. If the URL matches a whitelist rule, the packet is permitted to pass through.
URL filtering takes effect after you apply a URL filtering policy to a DPI application profile and use the DPI application profile in a security policy rule or object policy rule.
As shown in Figure 2, upon receiving a packet, the device performs the following operations:
1.     The device compares the packet with the object policy rules or security policy rules.
If the packet matches a rule that is associated with a URL filtering policy (through a DPI application profile), the device extracts the URL from the packet.
For more information about security policies and object policies, see Security Configuration Guide.
2.     The device compares the extracted URL with the rules in the URL filtering policy.
¡     If the URL matches a rule, the device determines the actions for the packet as follows:
-     If the matching rule is a whitelist rule, the packet is permitted to pass through.
-     If the matching rule is a blacklist rule, the packet is dropped.
If only URL whitelist-only filtering is enabled, the device compares the packet with the whiltelist only. If a match is found, the packet is passed. If no match is found, the packet is blokcked.
-     If the matching rule is a URL filtering rule, the devices takes the actions specified for the URL category to which the rule belongs.
If the URL filtering rule belongs to multiple URL categories, the actions specified for the URL category with the highest severity level apply.
¡     If the URL does not match any rule in the policy, and cloud query is disabled in the policy, the default action specified for the policy applies. If the default action is not configured, the device permits the packet to pass through.
¡     If the URL does not match any rule in the policy, and cloud query is enabled in the policy, the device performs step 3.
3.     The device forwards the URL to the cloud server for further query.
¡     If a matching rule is found for the URL, the actions specified for the URL category to which the rule belongs apply. If the rule belongs to multiple URL categories, the actions specified for the category with the highest severity level apply.
¡     If no matching rule is found, the device executes the default action of the policy on the packet. If the default action is not configured, the device permits the packet to pass through.
Figure 2 URL filtering mechanism
The device uses the local URL filtering signature library to identify URLs in the HTTP packets.
You can update the device URL filtering signature library to the most up-to-date version or roll back the library to a version.
Updating the URL filtering signature library
The following methods are available for updating the URL filtering signature library on the device:
·     Automatic update.
The device periodically accesses the company's website and automatically downloads the most up-to-date URL filtering signature file to update its local signature library.
·     Triggered update.
The device downloads the most up-to-date URL filtering signature file from the company's website to update its local signature library immediately you trigger the operation.
·     Manual update.
Use this method when the device cannot connect to the company's website.
You must manually download the most up-to-date URL filtering signature file from the company's website, and then use the file to update the signature library on the device.
If filtering false alarms or filtering exceptions occur frequently, you can roll back the URL filtering signature library to the previous version or to the factory default version.
Hardware platform
Module type
URL filtering compatibility
M9006
M9010
M9014
Blade IV firewall module
Yes
Blade V firewall module
Yes
NAT module
No
Application delivery engine (ADE) module
Yes
Anomaly flow cleaner (AFC) module
No
M9010-GM
Encryption module
Yes
M9016-V
Yes
M9008-S
M9012-S
Yes
Yes
Intrusion prevention service (IPS) module
Yes
Video network gateway module
Yes
No
M9008-S-6GW
IPv6 module
Yes
M9008-S-V
Yes
M9000-AI-E8
Yes
Yes
M9000-AI-E16
Yes
A license is required for URL filtering signature library update and URL filtering cloud query. If the license expires, the existing URL filtering signature library is still available but you cannot update the library on the device or perform a URL filtering cloud query task. For more information about licenses, see license management in Fundamentals Configuration Guide.
To configure URL filtering:
1.     (Optional.) Configuring a URL category
2.     (Optional.) Configuring URL filtering cloud query
3.     Configuring a URL filtering policy
4.     (Optional.) Copying a URL filtering policy or category
5.     Applying a URL filtering policy to a DPI application profile
6.     (Optional.) Activating URL filtering policy and rule settings
7.     Applying a DPI application profile
¡     Applying a DPI application profile to a security policy rule
¡     Applying a DPI application profile to an object policy rule
8.     Managing the URL filtering signature library
9.     (Optional.) Enabling DPI engine logging
10.     (Optional.) Configuring URL filtering logging for resource access
11.     (Optional.) Enabling URL fast auditing
12.     (Optional.)
Perform this task to create a user-defined URL category and configure filtering rules for it to meet specific URL filtering requirements.
When creating a URL category, you must assign a unique severity level in the range of 1000 to 65535 to the URL category. The larger the value, the higher the severity level.
2.     Create a URL category and enter its view.
url-filter category category-name [ severity severity-level ]
By default, the device provides predefined URL categories with names starting with Pre-.
The name of a user-defined URL category cannot start with Pre-.
3.     (Optional.) Configure a description for the URL category.
4.     Configure URL filtering rules for the URL category. Choose the options to configure as needed:
¡     Configure a URL filtering rule.
rule rule-id host { regex regex | text string } [ uri { regex regex | text string } ]
¡     (Optional.) Add the URL filtering rules of a predefined URL category to the URL category.
include pre-defined category-name
By default, a user-defined URL category does not contain the URL filtering rules of any predefined URL category.
The URL filtering cloud query feature enables the system to send URLs that do not match any local URL filtering rules to the cloud server for further query. This helps improves URL filtering accuracy for HTTP traffic.
The device caches the URL filtering rules returned from the cloud query server in the URL filtering cache. You can set the maximum number of rules that can be cached, and the minimum cache period for the cached rules. For more information about the cloud query server, see "Configuring the DPI engine."
2.     Specify the cloud query server.
inspect cloud-server host-name
By default, cloud query server sec.h3c.com is used.
3.     (Optional.) Set URL filtering cache size.
url-filter cache size cache-size
The URL filtering cache can cache a maximum of 16384 entries.
4.     (Optional.) Set the minimum cache period for URL filtering rules.
url-filter cache-time value
By default, the minimum cache period is 10 seconds.
5.     Enter the view of the URL filtering policy in which you want to enable cloud query.
url-filter policy policy-name
6.     Enable cloud query.
cloud-query enable
By default, cloud query is disabled in a URL filtering policy.
The URL filtering is implemented by URL filtering polices.
To configure a URL filtering policy, perform either of the following tasks:
·     Configuring a category-based URL filtering policy
A category-based URL filtering policy contains the following settings:
¡     URL category-to-action mappings.
¡     Default action.
¡     (Optional.) Whitelist and blacklist rules.
·     Configuring a whitelist-based URL filtering policy
The logging keyword enables the URL filtering module to log URL filtering events and send log messages to the information center.
With the information center, you can set log message filtering and output rules, including output destinations.
The information center can output URL filtering logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view URL filtering logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
2.     Create a URL filtering policy and enter its view.
3.     Specify the actions for a URL category.
category category-name action { block-source [ parameter-profile parameter-name ] | drop | permit | redirect parameter-profile parameter-name | reset } [ logging [ parameter-profile parameter-name ] ]
By default, no actions are specified for a URL category.
If a packet matches a rule that is in multiple URL categories, the system uses the actions for the category with the highest severity level.
4.     (Optional.) Specify the default action for packets that do not match any rule in the policy.
default-action { block-source [ parameter-profile parameter-name ] | drop | permit | redirect parameter-profile parameter-name | reset } [ logging [ parameter-profile parameter-name ] ]
5.     (Optional.) Configure a whitelist or blacklist rule in the policy.
add { blacklist | whitelist } [ id ] host { regex host-regex | text host-name } [ uri { regex uri-regex | text uri-name } ]
6.     (Optional.) Enable the referer whitelist.
referer-whitelist enable
By default, the referer whitelist is enabled. It allows an HTTP or HTTPS request to pass through if its referer header matches a whitelist rule.
7.     (Optional.) Rename the URL filtering policy.
rename new-name
About the task
This feature allows only the HTTP or HTTPS requests that match the whitelist rules to pass through. When you do not want to perform any other configurations, such as URL categories, URL filtering actions, and URL filtering policy default action, you can use this feature.
With this feature enabled, the device allows users to access only the Web resources added to the whitelist rules, and other Web resources are not allowed to access.
3.     Configure a whitelist rule in the policy.
add whitelist [ id ] host { regex host-regex | text host-name } [ uri { regex uri-regex | text uri-name } ]
4.     (Optional.) Enable the referer whitelist.
5.     Enable URL whitelist-only filtering.
whitelist-only enable
By default, URL whitelist-only filtering is disabled.
You can create a new URL filtering policy by copying an existing one.
url-filter copy policy old-name new-name
You can create a new URL category by copying an existing one.
When you copy a URL category, be sure to assign a unique severity level to the new URL category.
2.     Copy a URL category.
url-filter copy category old-name new-name severity severity-level
A URL filtering policy must be applied to a DPI application profile to take effect.
A DPI application profile can use only one URL filtering policy. If you apply different URL filtering policies to the same DPI application profile, only the most recent configuration takes effect.
2.     Enter DPI application profile view.
app-profile app-profile-name
For more information about this command, see DPI engine commands in DPI Command Reference.
3.     Assign a URL filtering policy to the DPI application profile.
url-filter apply policy policy-name
By default, no URL filtering policy is applied to the DPI application profile.
By default, when a configuration change to a URL filtering policy occurs, the system detects whether another configuration change occurs at 20-second intervals.
·     If no configuration change occurs during an interval, the system performs an activation operation at the end of the next interval.
·     If another configuration change occurs during an interval, the system continues to detect configuration changes.
To immediately activate a configuration change, execute the inspect activate command.
This task can cause temporary outage for all DPI services. As a best practice, perform the task after all DPI service policy and rule settings are complete.
For more information about activating DPI service module configuration, see "Configuring the DPI engine."
2.     Activate URL filtering policy and rule settings.
inspect activate
By default, the system automatically activates changed URL filtering policy and rule settings for them to take effect.
2.     Enter security policy view.
security-policy { ip | ipv6 }
3.     Enter security policy rule view.
rule { rule-id | name name } *
4.     Set the rule action to pass.
action pass
The default rule action is drop.
5.     Use a DPI application profile in the rule.
By default, no DPI application profile is used in a security policy rule.
2.     Enter object policy view.
object-policy { ip | ipv6 } object-policy-name
3.     Use a DPI application profile in an object policy rule.
rule [ rule-id ] inspect app-profile-name
By default, no DPI application profile is used in an object policy rule.
4.     Return to system view.
5.     Create a zone pair and enter zone pair view.
zone-pair security source source-zone-name destination destination-zone-name
For more information about zone pairs, see security zone configuration in Security Configuration Guide.
6.     Apply the object policy to the zone pair.
object-policy apply { ip | ipv6 } object-policy-name
By default, no object policy is applied to a zone pair.
You can update or roll back the version of the URL filtering signature library on the device.
·     Do not delete the /dpi/ folder in the root directory of the storage medium.
·     Do not perform URL filtering signature update and rollback when the device's free memory is below the normal state threshold. For more information about device memory thresholds, see device management in Fundamentals Configuration Guide.
·     For successful automatic and immediate signature update, make sure the device can resolve the domain name of the company's website into an IP address through DNS. For more information about DNS, see DNS configuration in Layer 3—IP Services Configuration Guide.
·     Update only one signature library at a time. Do not perform signature library update until the existing signature library update is completed.
You can schedule automatic URL filtering signature library update if the device can access the signature database services on the company's website. The device periodically obtains the latest signature file from the company's website to update its local signature library according to the update schedule.
2.     Enable automatic URL filtering signature library update and enter automatic URL filtering signature library update configuration view.
url-filter signature auto-update
By default, automatic URL filtering signature library update is disabled.
3.     Schedule the update time.
By default, the device updates the URL filtering signature at a random time between 01:00:00 and 03:00:00 every day.
Anytime you find a release of new signature version on the company's website, you can trigger the device to immediately update the local signature library.
2.     Trigger an automatic URL filtering signature library update.
url-filter signature auto-update-now
If the device cannot access the signature database services on the company's website, use one of the following methods to manually update the URL filtering signature library on the device:
·     Local update—Updates the URL filtering signature library on the device by using the locally stored update URL filtering signature file.
(In standalone mode.) Store the update file on the active MPU for successful signature library update.
(In IRF mode.) Store the update file on the global active MPU for successful signature library update.
·     FTP/TFTP update—Updates the URL filtering signature library on the device by using the file stored on the FTP or TFTP server.
2.     Manually update the URL filtering signature library on the device.
url-filter signature update file-path
If a URL filtering signature library update causes exceptions or a high false alarm rate, you can roll back the URL filtering signature library.
Before rolling back the URL filtering signature library, the device backs up the current signature library as the "previous version." For example, the previous library version is V1 and the current library version is V2. If you perform a rollback to the previous version, library version V1 becomes the current version and library version V2 becomes the previous version. If you perform a rollback to the previous version again, the library rolls back to library version V2.
2.     Roll back the URL filtering signature library to the previous version or to the factory default version.
url-filter signature rollback { factory | last }
You can enable DPI engine logging for audit purposes. Log messages generated by DPI engine are output to the device information center. The information center then sends the messages to designated destinations based on log output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
2.     Enable DPI engine logging.
url-filter log enable
By default, DPI engine logging is disabled.
URL filtering logs user access to resources after you specify the logging action for a URL category or as a default action for a URL filtering policy.
You can use either of the following methods to configure URL filtering to log access to specific types of resources:
·     Configure URL filtering to log access to only resources in the root directories of websites.
·     Enable or disable URL filtering logging for access to resources of specific types.
2.     Configure URL filtering to log only access to resources in the root directories of websites.
url-filter log directory root
By default, URL filtering logs access to Web resources in all directories.
2.     Disable URL filtering logging for access to resources of a specific resource type.
¡     Disable logging for access to resources of a predefined resource type.
url-filter log except pre-defined { css | gif | ico | jpg | js | png | swf | xml }
¡     Disable logging for access to resources of a user-defined resource type.
url-filter log except user-defined text
By default, URL filtering logs access to all resources except for resources of the predefined resource types (including CSS, GIF, ICO, JPG, JS, PNG, SWF, and XML resources).
By default, URL filtering inspects and audits URLs in packets and determines the packet processing actions based on the inspection results in the software forwarding process. However, both software forwarding and URL filtering consume CPU resources and the packet forwarding performance will be degraded if the CPU usage is high.
URL fast auditing enables the device to send copies of HTTP packets to the CPU for audit (logging) by the URL filtering module during the hardware forwarding process. URL filtering only logs HTTP packets that match the logging action. All other URL filtering actions are ignored.
For URL fast auditing to work, you must configure both the URL filtering and hardware fast forwarding features. For information about hardware fast forwarding, see Layer 3IP Services Configuration Guide.
Enable URL fast auditing in the application scenario that requires high device forwarding performance, URL auditing, and low level of security.
URL fast auditing does not take effect if a feature that requires Layer 5 or higher layer processing (such as Layer 7 load balancing or ALG) is enabled on the device.
All DPI functions become invalid after URL fast auditing is enabled.
2.     Enable URL fast auditing.
hardware audit url enable
By default, URL fast auditing is disabled.
About the task
By default, the device supports only the HTTP URL filtering. To enable filtering on HTTPS traffic, use either of the following methods:
·     Use SSL decryption to decrypt the HTTPS traffic and then perform HTTP URL filtering on the decrypted traffic. For more information about SSL decryption, see proxy policy configuration in DPI Configuration Guide.
SSL decryption involves a large number of encryption and decryption operations, which might downgrade device forwarding performance. As a best practice, use this method only when the device must perform URL filtering on HTTPS traffic.
·     Enable HTTPS URL filtering. This feature performs URL filtering on undecrypted HTTPS traffic. The device directly detects the Client Hello message from the client, and extracts the server name from the Sever Name Indication (SNI) extension to match the URL filtering policy.
If SSL decryption is configured, this feature does not take effect.
In HTTPS URL filtering, only the hostname match criterion in a URL filtering rule takes effect. The URI match criterion does not take effect.
This feature takes effect only when the hostname field in the URL is the server's domain name. This feature does not apply to the HTTPS traffic if the hostname field is an IP address.
This feature does not take effect in the following situations:
·     The client browser enables TLS 1.3 downgrade enhancement mechanism, because the SNI extension will be encrypted.
·     The HTTPS packets do not have the SNI extension.
3.     Enable HTTPS URL filtering.
https-filter enable
By default, HTTPS URL filtering is disabled, and the device supports only the HTTP URL filtering.
Display URL filtering cache information.
display url-filter cache
Display URL category information.
display url-filter { category | parent-category } [ verbose ]
Display information about the URL filtering signature library.
display url-filter signature library
Display URL filtering statistics.
display url-filter statistics
Clear URL filtering statistics.
reset url-filter statistics
As shown in Figure 3, the device connects to the LAN and Internet through security zones Trust and Untrust, respectively.
Configure a URL filtering policy on the device so the device performs the following tasks:
·     Permits LAN users in security zone Trust to access website http://www.sina.com on the Web server.
·     Drops and logs packets that match the Pre-Game URL category.
·     Drops and logs packets that do not match any filtering rule in the URL filtering policy.
Figure 3 Network diagram
1.     Assign IP addresses to interfaces:
# Assign an IP address to interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] ip address 192.168.1.1 255.255.255.0
2.     Configure settings for routing.
This example configures static routes, and the next hop in the routes is 2.2.2.2 to the Web server.
[Device] ip route-static 5.5.5.0 24 2.2.2.2
3.     Add interfaces to security zones.
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/1
[Device] security-zone name untrust
[Device-security-zone-Untrust] import interface gigabitethernet 1/0/2
[Device-security-zone-Untrust] quit
4.     Configure URL filtering:
# Create user-defined URL category news, set its severity level to 2000, and create URL filtering rule 1 to match HTTP packets that contain host name www.sina.com in the URL.
[Device] url-filter category news severity 2000
[Device-url-filter-category-news] rule 1 host text www.sina.com
[Device-url-filter-category-news] quit
# Create a URL filtering policy named urlnews. Specify action permit for URL category news and action drop for predefined URL category Pre-Games, enable logging for the matching packets, and set the default actions to drop and logging.
[Device] url-filter policy urlnews
[Device-url-filter-policy-urlnews] category news action permit
[Device-url-filter-policy-urlnews] category Pre-Games action drop logging
[Device-url-filter-policy-urlnews] default-action drop logging
[Device-url-filter-policy-urlnews] quit
5.     Apply URL filtering policy urlnews to a DPI application profile and activate the IPS policy settings:
# Create a DPI application profile named sec, and apply URL filtering policy urlnews to the DPI application profile.
[Device] app-profile sec
[Device-app-profile-sec] url-filter apply policy urlnews
[Device-app-profile-sec] quit
# Activate the URL filtering policy and rule settings.
[Device] inspect activate
6.     Configure a security policy:
# Create a security policy named ip and enter its view. Create a rule named trust-untrust to allow the device to apply the URL filtering policy to the traffic between the internal users and the Internet.
[Device] security-policy ip
[Device-security-policy-ip] rule name trust-untrust
[Device-security-policy-ip-10-trust-untrust] source-zone trust
[Device-security-policy-ip-10-trust-untrust] source-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-10-trust-untrust] destination-zone untrust
[Device-security-policy-ip-10-trust-untrust] action pass
[Device-security-policy-ip-10-trust-untrust] profile sec
[Device-security-policy-ip-10-trust-untrust] quit
# Activate rule matching acceleration.
[Device-security-policy-ip] accelerate enhanced enable
[Device-security-policy-ip] quit
# Verify that LAN users in security zone Trust can access website http://www.sina.com on the Web server
# Verify that the device drops and logs LAN users' HTTP requests to game resources.
As shown in Figure 4, LAN users in security zone Trust can access the following resources:
·     Internet resources in security zone Untrust.
·     The FTP server at 192.168.2.4/24 in security zone DMZ. The FTP login username and password are url and 123, respectively.
Manually update the URL filtering signature library on the device by using the latest URL filtering signature file (url-1.0.2-encrypt.dat) stored on the FTP server.
Figure 4 Network diagram
[Device] security-zone name dmz
[Device-security-zone-DMZ] import interface gigabitethernet 1/0/3
[Device-security-zone-DMZ] quit
4.     Configure a security policy:
# Configure a security policy rule to permit the traffic between the Trust and Untrust security zones for the internal users to access external resources.
# Configure a security policy rule to permit traffic between the Trust and DMZ security zones for the internal users to access the FTP server in the DMZ security zone.
[Device-security-policy-ip] rule name trust-dmz
[Device-security-policy-ip-11-trust-dmz] source-zone trust
[Device-security-policy-ip-11-trust-dmz] source-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-11-trust-dmz] destination-zone dmz
[Device-security-policy-ip-11-trust-dmz] action pass
[Device-security-policy-ip-11-trust-dmz] quit
# Configure a security policy rule to permit the traffic between the FTP server and the device so the device can access the FTP server to obtain the signature library file.
[Device-security-policy-ip]rule name downloadlocalout
[Device-security-policy-ip-12-downloadlocalout] source-zone local
[Device-security-policy-ip-12-downloadlocalout] destination-zone dmz
[Device-security-policy-ip-12-downloadlocalout] destination-ip-subnet 192.168.2.0 24
[Device-security-policy-ip-12-downloadlocalout] application ftp
[Device-security-policy-ip-12-downloadlocalout] application ftp-data
[Device-security-policy-ip-12-downloadlocalout] action pass
[Device-security-policy-ip-12-downloadlocalout] quit
5.     Update the URL filtering library on the device by using URL filtering signature file url-1.0.2-encrypt.dat on the FTP server.
[Device] url-filter signature update ftp://url:123@192.168.2.4/url-1.0.2-encrypt.dat
# Verify that the URL filtering signature library on the device is updated successfully.
<Device> display url-filter signature library
As shown in Figure 5, LAN users in security zone Trust can access Internet resources in security zone Untrust.
Configure the device to start automatically updating the local URL filtering signature library at a random time between 08:30 a.m. and 09:30 a.m. every Saturday.
Figure 5 Network diagram
4.     Configure DNS for the device to resolve the domain name of the official website into the correct IP address.
[Device] dns server 10.72.66.36
5.     Configure a security policy:
# Configure a security policy rule to permit the traffic between the Local and Untrust security zones so the device can access the official website to obtain the signature library file.
[Device-security-policy-ip] rule name downloadlocalout
[Device-security-policy-ip-11-downloadlocalout] source-zone local
[Device-security-policy-ip-11-downloadlocalout] destination-zone untrust
[Device-security-policy-ip-11-downloadlocalout] action pass
[Device-security-policy-ip-11-downloadlocalout] quit
6.     Configure automatic URL filtering signature library update:
Enable automatic URL filtering signature library update. Configure the device to perform automatic update at a random time between 08:30 a.m. and 09:30 a.m. every Saturday.
[Device] url-filter signature auto-update
[Device-url-filter-autoupdate] update schedule weekly sat start-time 9:00:00 tingle 60
[Device-url-filter-autoupdate] quit
# Verify that the device URL filtering signature library is updated as scheduled.
