12-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SR6600[SR6600-X] Routers Configuration Guides(V7)-R8149-6W10212-Security Configuration Guide
19-Object group configuration
19-Object group configuration 90.88 KB
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL, object policy, or object group to identify packets. Object groups are divided into the following types:
·     IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
·     IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
·     Port object group—A group of port objects used to match the protocol port number in a packet.
·     Service object group—A group of service objects used to match the upper-layer service in a packet.
Restrictions and guidelines: Object group configuration
You cannot edit an object group if the group is used by a global static NAT rule.
Address object groups and service object groups for a Yundi network can only use other existing object groups. You cannot create objects for Yundi address or service object groups. Object groups for a Yundi network are configured on a remote controller, and as a best practice, do not configure these object groups on the device manually.
Configuring an IPv4 address object group
2.     Create an IPv4 address object group and enter its view.
object-group ip { address | address-yundi } object-group-name
The system has one default IPv4 address object group named any.
3.     (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4.     (Optional.) Specify an alias and tenant ID for the IPv4 address object group in a Yundi network.
yundi alias alias tenant tenant-id
By default, the alias and tenant ID are not specified.
Typically, the alias and tenant ID are deployed by the remote controller to devices. As a best practice, do not perform this task manually on devices.
5.     Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
6.     Configure a description for the IPv4 address object.
By default, an IPv4 address object does not have a description.
7.     Exclude an IPv4 address or a subnet from the IPv4 address object.
object-id network exclude { ip-address | subnet ip-address { mask-length | mask } }
By default, no IPv4 address in an IPv4 address object is excluded.
8.     Exclude a host name from the IPv4 address object.
object-id network exclude host-name host-name [ vpn-instance vpn-instance-name ]
By default, no host name in an IPv4 address object is excluded.
9.     (Optional.) Specify a security zone for the IPv4 address object group.
security-zone security-zone-name
By default, no security zone is specified for an IPv4 address object group.
Configuring an IPv6 address object group
2.     Create an IPv6 address object group and enter its view.
object-group ipv6 { address | address-yundi } object-group-name
The system has one default IPv6 address object group named any.
3.     (Optional.) Configure a description for the IPv6 address object group.
4.     (Optional.) Specify an alias and tenant ID for the IPv6 address object group in a Yundi network.
5.     Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
6.     Configure a description for the IPv6 address object.
By default, an IPv6 address object does not have a description.
7.     Exclude an IPv6 address or a subnet from the IPv6 address object.
object-id network exclude { ip-address | subnet ipv6-address prefix-length }
By default, no IPv6 address in an IPv6 address object is excluded.
8.     Exclude a host name from the IPv6 address object.
By default, no host name in an IPv6 address object is excluded.
9.     (Optional.) Specify a security zone for the IPv6 address object group.
By default, no security zone is specified for an IPv6 address object group.
Configuring a port object group
2.     Create a port object group and enter its view.
object-group port object-group-name
The system has one default port object group named any.
3.     (Optional.) Configure a description for the port object group.
4.     (Optional.) Specify an alias and tenant ID for the port object group in a Yundi network.
5.     Configure a port object.
[ object-id ] port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
6.     Configure a description for the port object.
By default, a port object does not have a description.
Configuring a service object group
2.     Create a service object group and enter its view.
object-group { service | service-yundi } object-group-name
The system has multiple default service object groups.
3.     (Optional.) Configure a description for the service object group.
4.     (Optional.) Specify an alias and tenant ID for the service object group in a Yundi network.
5.     Configure a service object.
[ object-id ] service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
6.     Configure a description for the service object.
By default, a service object does not have a description.
Renaming an object group
2.     Rename an object group.
object-group rename old-object-group-name new-object-group-name
You can only rename non-default object groups.
Configuring aging of DNS-resolved IP addresses from host names
In load balancing scenarios where one host name maps to several IP addresses, DNS-resolved IP address for a host name changes between these mapping addresses. Upon every change, the object group module notifies relevant policies of the change, which causes policies to submit changes frequently and consumes memory. To resolve this issue, you can enable aging of DNS-resolved IP addresses from host names.
With this feature enabled, the system maintains an IP address group for each host name. If a resolved IP address is not in the group, the system adds the address to the group and notifies relevant policies of the change. If a resolved IP address is in the group, the system does not notify relevant policies.
As a best practice, set the aging time to be longer than the TTL of resolution records on the DNS server.
2.     Enable aging of DNS-resolved IP addresses from host names.
object-group dns-aging [ time aging-time ]
By default, aging of DNS-resolved IP addresses from host names is disabled.
Display and maintenance commands for object groups
Display information about object groups.
display object-group [ { { ip | ipv6 } { address | address-yundi } | port | service | service-yundi } [ default ] [ name object-group-name ] | name object-group-name ]
Display IPv4 or IPv6 addresses for host names.
In standalone mode:
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } * [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
