- 10-Segment Routing Troubleshooting Guide
- 01-EVPN L3VPN over SRv6 Troubleshooting Guide
- 02-EVPN VPLS over SR Troubleshooting Guide
- 03-EVPN VPWS over SRv6 Troubleshooting Guide
- 04-SR-MPLS Troubleshooting Guide
- 05-SRv6 TE Policy Troubleshooting Guide
- 06-SRv6 Troubleshooting Guide
- 07-Public Network IP over SRv6 Troubleshooting Guide
| 07-Public Network IP over SRv6 Troubleshooting Guide | 166.39 KB |
Troubleshooting segment routing
Public network IP over SRv6 issues
Public network IP over SRv6 BE traffic forwarding failure
Symptom
On a public network IP over SRv6 network shown in Figure 1, failure occurs when the PEs use the SRv6 BE mode to forward public network service traffic between CE 1 and CE 2.
The troubleshooting flow is the same for IPv4 and IPv6. The following information uses IPv4 for example to describe the troubleshooting procedure for public network IP over SRv6.
Table 1 shows the key network planning information for the public network IP over SRv6 network.
Table 1 SRv6 locators and major addresses in the address plan
Device |
Interface or locator |
Address |
Device |
Address |
PE 1 |
SRv6 Locator |
100:1::/64 |
PE 2 |
SRv6 Locator |
300:1::/64 |
Loopback0 |
1::1/128 |
Loopback0 |
3::3/128 |
CE 1 |
Loopback0 |
10.10.10.10/32 |
CE 2 |
Loopback0 |
20.20.20.20/32 |
P |
SRv6 Locator |
200:1::/64 |
Loopback0 |
2::2/128 |
Common causes
The following are the common causes of this type of issue:
· The PEs cannot learn public network service routes because of the failure to establish BGP peer relationships.
· Public network IP over SRv6 configuration is incomplete.
· The routes for the SRv6 SIDs are unreachable.
Troubleshooting flow
Figure 2 shows the troubleshooting flowchart.
Figure 2 Flowchart for troubleshooting public network IP over SRv6 BE traffic forwarding failure
Solution
1. Ping the public IP on the remote PE from the local PE to check the connectivity for public network services.
<Sysname> ping 20.20.20.20
Ping 20.20.20.20 (20.20.20.20): 56 data bytes, press CTRL+C to break
56 bytes from 20.20.20.20: icmp_seq=0 ttl=254 time=2.000 ms
56 bytes from 20.20.20.20: icmp_seq=1 ttl=254 time=1.000 ms
56 bytes from 20.20.20.20: icmp_seq=2 ttl=254 time=1.000 ms
56 bytes from 20.20.20.20: icmp_seq=3 ttl=254 time=1.000 ms
56 bytes from 20.20.20.20: icmp_seq=4 ttl=254 time=2.000 ms
--- Ping statistics for 20.20.20.20 ---
round-trip min/avg/max/std-dev = 1.000/1.400/2.000/0.490 ms
If the ping test fails, the public network service is unavailable. Proceed to the next step.
2. Perform the subsequent checks on both the local and remote PEs. This document takes the local PE for example. Execute the display ip routing-table command on the local PE to check the public routing table for routes to the public IP addresses.
<Sysname> display ip routing-table
Destinations : 10 Routes : 10
10.10.10.10/32 BGP 255 0 16.0.0.2 XGE0/0/6
16.0.0.0/30 Direct 0 0 16.0.0.1 XGE0/0/6
16.0.0.1/32 Direct 0 0 127.0.0.1 XGE0/0/6
16.0.0.3/32 Direct 0 0 16.0.0.1 XGE0/0/6
20.20.20.20/32 BGP 255 0 300:1:: XGE0/0/7
27.0.0.0/30 BGP 255 0 300:1:: XGE0/0/7
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
If the device has routes to the public IP addresses, verify that the FIB contains entries for these addresses, with a U flag in the Flag field. The U flag indicates that the IP address is valid.
<Sysname> display fib
Route destination count: 12
Directly-connected host count: 1
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
20.20.20.20/32 FE80::6033:29FF UGHR XGE0/0/7 Null
:FEAE:307
16.0.0.0/30 16.0.0.1 U XGE0/0/6 Null
16.0.0.2/32 16.0.0.2 UH XGE0/0/6 Null
27.0.0.0/30 FE80::6033:29FF UGR XGE0/0/7 Null
:FEAE:307
127.0.0.0/8 127.0.0.1 U InLoop0 Null
10.10.10.10/32 16.0.0.2 UGHR XGE0/0/6 Null
16.0.0.1/32 127.0.0.1 UH XGE0/0/6 Null
127.255.255.255/32 127.0.0.1 UH InLoop0 Null
255.255.255.255/32 127.0.0.1 UH InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
16.0.0.3/32 16.0.0.1 UBH XGE0/0/6 Null
If an IP address does not exist or is invalid in the public routing table or FIB, proceed to check for BGP route learning issues between PEs and verify that a valid tunnel exists between them.
3. Execute the display bgp peer ipv4 command on the local PE to verify that it has established a public IPv4 BGP peer relationship with the remote PE.
¡ If the PEs have established a BGP peer relationship successfully, the State field in the command output displays Established. Proceed to step 4.
¡ If the PEs have not established a BGP peer relationship, see the troubleshooting procedure for BGP session unable to enter Established state in the BGP troubleshooting guide.
<Sysname> display bgp peer ipv4
BGP local router ID: 1.1.1.1
Local AS number: 100
Total number of peers: 1 Peers in established state: 1
* - Dynamically created peer
3::3 100 13 10 0 2 00:00:05 Established
4. Execute the display bgp routing-table ipv4 command on the local PE to verify that it has learned the public IPv4 BGP routes from the remote PE. Pay special attention to the PrefixSID field for each route in the command output. In this field, the End.DT4 SID represents the SRv6 SID assigned by the remote PE to the public IP address. When forwarding traffic to that public address in SRv6 BE mode, the local PE uses that End.DT4 SID as the destination address in the IPv6 packets. Also, ensure that the route is both valid and the best. Only valid and optimal BGP routes can be learned into the public routing table.
<Sysname> display bgp routing-table ipv4 20.20.20.20
Paths: 1 available, 1 best
BGP routing table information of 20.20.20.20/32:
Rely nexthop : FE80::6033:29FF:FEAE:307
Original nexthop: ::FFFF:27.0.0.2
Out interface : Ten-GigabitEthernet0/0/7
Route age : 00h01m18s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
PrefixSID : End.DT4 SID <300:1::1:7>
SRv6 Service TLV (37 bytes):
Type: SRV6 L3 Service TLV (5)
Length: 34 bytes, Reserved: 0x0
SRv6 Service Information Sub-TLV (33 bytes):
Type: 1 Length: 30, Rsvdl: 0x0
SID Flags: 0x0 Endpoint behavior: 0x13 Rsvd2: 0x0
SRv6 SID Sub-Sub-TLV:
Type: 1 Len: 6
BL: 64 NL: 0 FL: 64 AL: 0 TL: 0 TO: 0
AS-path : 65420
Origin : incomplete
State : valid, internal, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel policy : NULL
Rely tunnel IDs : N/A
If the local PE has failed to learn a valid and optimal public IPv4 BGP route, or if the PrefixSID attribute is missing from public IPv4 BGP routes, proceed to check for incomplete public network IP over SRv6 configuration. An incomplete configuration might result in failure to allocate SRv6 SIDs or to establish an SRv6 tunnel.
5. Verify that the configuration for public network IP over SRv6 on both PEs is complete. If the configuration is incomplete, add the missing configuration. If the configuration is complete, proceed to step 6.
Execute the display current-configuration command on both PEs to check for the following configuration items. If they are missing, add the missing configuration items.
isis 1
cost-style wide-compatible
address-family ipv6 unicast
segment-routing ipv6 locator aaa //Enable IS-IS to advertise the specified locator and the SRv6 SIDs in the locator.
bgp 100
router-id 1.1.1.1
peer 3::3 as-number 100
peer 3::3 connect-interface LoopBack1
address-family ipv4 unicast
segment-routing ipv6 best-effort //Steer route matching traffic to an SRv6 BE tunnel.
segment-routing ipv6 locator abc //Apply the locator to the BGP process so the device can use the locator to allocate SRv6 SIDs for the public routes advertised by BGP.
peer 3::3 enable
peer 3::3 prefix-sid //Adertise public network routes with the PrefixSID attribute to the peer or peer group.
encapsulation source-address 11::11 //Specify the source address for the outer IPv6 header of SRv6 VPN packets.
locator aaa ipv6-prefix 300:1:: 64 static 8 //Create a Locator segment.
If the SRv6 configuration is complete and correct, proceed to check for unreachable SRv6 SIDs on the forwarding path.
6. Execute the display ipv6 routing-table ipv6-address command on all devices along the forwarding path to check for routes to the SRv6 SIDs on both PEs.
<Sysname> display ipv6 routing-table 300:1::1:7
Summary count : 1
Destination: 300:1::/64 Protocol : IS_L1
NextHop : FE80::6033:29FF:FEAE:307 Preference: 15
Interface : XGE0/0/7 Cost : 20
Execute the ping ipv6 command on all devices to verify the connectivity to the SRv6 SIDs.
<Sysname> ping ipv6 300:1::1:7
Ping6(56 data bytes) 2001::1 --> 300:1::1:7, press CTRL+C to break
56 bytes from 300:1::1:7, icmp_seq=0 hlim=63 time=1.000 ms
56 bytes from 300:1::1:7, icmp_seq=1 hlim=63 time=1.000 ms
56 bytes from 300:1::1:7, icmp_seq=2 hlim=63 time=1.000 ms
56 bytes from 300:1::1:7, icmp_seq=3 hlim=63 time=0.000 ms
56 bytes from 300:1::1:7, icmp_seq=4 hlim=63 time=1.000 ms
--- Ping6 statistics for 300:1::1:7 ---
round-trip min/avg/max/std-dev = 0.000/0.800/1.000/0.400 ms
If a route exists to the SRv6 SID at the remote end and the ping test succeeds, proceed to step 7. If no route exists to the SRv6 SID or the ping test fails, check for the failure of IGP on the PEs to advertise the network segment in the locator for the SID to other devices in the domain. For more information, see the troubleshooting guide of the associated protocol (for example, IS-IS troubleshooting guide).
7. If the issue persists, collect the following information and contact Technical Support:
¡ Results of each step.
¡ The configuration file, log messages, and alarm messages.
Related alarm and log messages
Alarm messages
N/A
Log messages
N/A
Public network IP over SRv6 TE traffic forwarding failure
Symptom
On a public network IP over SRv6 network shown in Figure 3, failure occurs when the PEs use the SRv6 TE mode to forward public network service traffic between CE 1 and CE 2 based on SRv6 TE policies.
The troubleshooting flow is the same for IPv4 and IPv6. The following information uses IPv4 for example to describe the troubleshooting procedure for public IP over SRv6.
Table 2 shows the key network planning information for the public network IP over SRv6 network.
Table 2 SRv6 locators and major addresses in the address plan
Device |
Address |
Device |
Address |
PE 1 |
SRv6 Locator |
100:1::/64 |
PE 2 |
SRv6 Locator |
300:1::/64 |
Loopback0 |
1::1/128 |
Loopback0 |
3::3/128 |
CE 1 |
Loopback0 |
10.10.10.10/32 |
CE 2 |
Loopback0 |
20.20.20.20/32 |
P |
SRv6 Locator |
200:1::/64 |
Loopback0 |
2::2/128 |
Common causes
· The PEs cannot learn public network routes because of the failure to establish BGP peer relationships.
· Recursive routing is not performed in SRv6 TE mode.
· Traffic matching a public network route is steered to a invalid SRv6 TE policy.
Figure 4 shows the troubleshooting flowchart.
Figure 4 Flowchart for troubleshooting public network IP over SRv6 TE traffic forwarding failure
Solution
2. Perform the subsequent checks on both the local and remote PEs. This document takes the local PE for example. Execute the display ip routing-table command on the local PE to check the public routing table for routes to the public IP addresses. Verify that the outgoing interface in the route to the public IP address is the name of the expected SRv6 TE policy.
20.20.20.20/32 BGP 255 0 3::3 p1
27.0.0.0/30 BGP 255 0 3::3 p1
If the device has routes to the public IP addresses, verify that the FIB contains entries for these addresses, with a U flag in the Flag field. The U flag indicates that the IP address is valid. Verify that the outgoing interface in the route to the public IP address contains the token for the expected SRv6 TE policy obtained through the display segment-routing ipv6 te policy command.
Route destination count: 10
Flag:
R:Relay F:FRR
20.20.20.20/32 ::FFFF:27.0.0.2 UGHR 2150629377 Null
27.0.0.0/30 3::3 UGR 2150629377 Null
If the IP address does not exist or is invalid in the public routing table or FIB entry, proceed to check for BGP route learning issues between PEs and verify that a valid tunnel exists between them.
traffic to that public address in SRv6 TE mode, the local PE encapsulates that
End.DT4 SID along with the SID list in the SRv6 TE policy in the SRH expansion
header.
Verify that the route is both valid and the best. Only valid and optimal BGP
Verify that the outgoing interface in this route is the SRv6 TE policy.
Route age : 00h21m42s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
Type: 1 Len: 6
AS-path : 65420
Origin : incomplete
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Rely tunnel IDs : 2150629377
If the local PE has failed to learn a valid and optimal public IPv4 BGP route, or if the PrefixSID attribute is missing from public IPv4 BGP routes, proceed to check for incomplete public network IP over SRv6 configuration. An incomplete configuration might result in failure to allocate SRv6 SIDs or to establish SRv6 TE policy-based paths.
5. In BGP IPv4 unicast address family view, execute the display this command to verify that the current configuration includes the segment-routing ipv6 traffic-engineering or segment-routing ipv6 traffic-engineering best-effort command. If a command is not present, add the configuration. If both commands are present, proceed to step 6.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4 unicast
[Sysname-bgp-default-ipv4-vpn1] display this
If the above recursive routing configuration exists, verify that the basic SRv6 configuration and the configuration for steering traffic to SRv6 TE policies are correct. If all settings are correct, proceed to the next step.
6. On each PE, verify that the SRv6 TE policy steered from the public route is valid. Execute the display segment-routing ipv6 te policy command on each PE. Identify the SRv6 TE policy that has a forwarding index value that is the same as the rely tunnel IDs value in the route to the destination IP address displayed by executing the display bgp routing-table ipv4 command. Examine the Status field for the SRv6 TE policy to verify that it is up. If the policy is up, proceed to the next step. If the policy is down, see the SRv6 TE policy down issue troubleshooting procedure to resolve the issue.
<Sysname> display segment-routing ipv6 te policy
Name/ID: p1/0
Color: 10
End-point: 3::3
Name from BGP:
Name from PCE:
BSID:
Mode: Dynamic Type: Type_2 Request state: Succeeded
Current BSID: 100:1::1:3 Explicit BSID: - Dynamic BSID: 100:1::1:3
BSID compress-mode: -
Reference counts: 5
Flags: A/BS/NC
Status: Up
AdminStatus: Up
Up time: 2024-03-14 09:49:36
Down time: 2024-03-14 09:49:05
Hot backup: Disabled
Statistics: Disabled
Statistics by service class: Disabled
Path verification: Not configured
Drop-upon-invalid: Disabled
BFD trigger path-down: Disabled
SBFD: Disabled
BFD Echo: Disabled
BFD no-bypass: Disabled
Forward no-bypass: Disabled
Forwarding index: 2150629377
Execute the ping srv6-te policy command to verify that the SRv6 TE policy has a valid path to reach the destination IP address. If BFD or SBFD is not configured to monitor the connectivity of the SRv6 TE policy, the up state of the policy only indicates that the first hop of the policy is reachable. To verify that all SIDs in the forwarding path are unreachable, you must perform this step.
<Sysname> ping srv6-te policy policy-name p1
Ping SRv6-TE policy (56 data bytes) , press CTRL+C to break
Segment list ID: 1
Preference=10, Path Type=Main, Protocol origin=Local, Originator=0,0.0.0.0, Discriminator=10, End.OP=none
56 bytes from 300:1::1, icmp_seq=0 ttl=63 time=1.000 ms
56 bytes from 300:1::1, icmp_seq=1 ttl=63 time=1.000 ms
56 bytes from 300:1::1, icmp_seq=2 ttl=63 time=1.000 ms
56 bytes from 300:1::1, icmp_seq=3 ttl=63 time=1.000 ms
56 bytes from 300:1::1, icmp_seq=4 ttl=63 time=1.000 ms
--- Ping6 SRv6-TE Policy statistics ---
round-trip min/avg/max/std-dev = 1.000/1.000/1.000/0.000 ms
If the ping srv6-te policy command output shows that the SRv6 TE policy is not reachable, proceed to the next step.
7. Execute the display segment-routing ipv6 te segment-list command to identify the SIDs in the SID list of the best candidate path in the SRv6 TE policy.
<Sysname> display segment-routing ipv6 te segment-list
Total Segment lists: 1
Name/ID: s1/1
Origin: CLI
Status: Up
Nodes : 2
Flags: None
Local BSID: -
Reverse BSID: -
Reference counts: 0
Index : 10 SID: 200:1::1
Status : Up TopoStatus: Nonexistent
Type : Type_2 Flags: None
Coc Type : - Common prefix length: 0
Function length : 255 Args length: 0
Endpoint Behavior : -
Index : 20 SID: 300:1::1
Status : - TopoStatus: -
Execute the display ipv6 routing-table ipv6-address command on each device in the forwarding path to verify that they have a valid route to each SRv6 SID, including the End.DT4 SID.
Summary count : 1
Execute the ping ipv6 command on each device in the forwarding path to verify the connectivity to the SRv6 SID.
If the route to a SID is unreachable, check the SID list configuration for the SRv6 TE policy on the source node for SID list orchestration errors. If the SID list is correct, check the IGP for failure to advertise the locators that contain the SIDs to other devices. For more information, see the troubleshooting guide of the associated protocol (for example, IS-IS troubleshooting guide).
8. If the issue persists, collect the following information and contact Technical Support:
Alarm messages
N/A
Log messages
N/A
