- 06-IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-PIM snooping commands
- 03-Multicast VLAN commands
- 04-Multicast routing and forwarding commands
- 05-IGMP commands
- 06-PIM commands
- 07-MSDP commands
- 08-MLD snooping commands
- 09-IPv6 PIM snooping commands
- 10-IPv6 multicast VLAN commands
- 11-IPv6 multicast routing and forwarding commands
- 12-MLD commands
- 13-IPv6 PIM commands
| 01-IGMP snooping commands | 392.23 KB |
display igmp-snooping host-tracking
display igmp-snooping router-port
display igmp-snooping static-group
display igmp-snooping static-router-port
display igmp-snooping statistics
display l2-multicast fast-forwarding cache
display l2-multicast ip forwarding
display l2-multicast mac forwarding
display mac-address [ multicast ]
dot1p-priority (IGMP-snooping view)
entry-limit (IGMP-snooping view)
fast-leave (IGMP-snooping view)
global-enable (IGMP-snooping view)
group-policy (IGMP-snooping view)
host-aging-time (IGMP-snooping view)
host-tracking (IGMP-snooping view)
igmp-snooping { disable | enable }
igmp-snooping general-query source-ip
igmp-snooping last-member-query-interval
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping querier-election
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping special-query source-ip
last-member-query-interval (IGMP-snooping view)
max-response-time (IGMP-snooping view)
overflow-replace (IGMP-snooping view)
report-aggregation (IGMP-snooping view)
reset igmp-snooping router-port
reset igmp-snooping statistics
reset l2-multicast fast-forwarding cache
router-aging-time (IGMP-snooping view)
source-deny (IGMP-snooping view)
Use display igmp-snooping to display IGMP snooping status.
display igmp-snooping [ global | vlan vlan-id ]
global: Displays the global IGMP snooping status.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094.
If you do not specify any parameters, this command displays the global IGMP snooping status and the IGMP snooping status in all VLANs.
# Display the global IGMP snooping status and the IGMP snooping status for all VLANs.
<Sysname> display igmp-snooping
IGMP snooping information: Global
Global-enable: Enabled
Host-aging-time: 260s
Router-aging-time: 260s
Max-response-time: 10s
Last-member-query-interval: 1s
Report-aggregation: Enabled
Host-tracking: Disabled
Dot1p-priority: --
IGMP snooping information: VLAN 1
IGMP snooping: Enabled
Drop-unknown: Disabled
Version: 2
Querier: Enabled (IP: 1.1.1.1, Expires: 00:02:05)
Querier-election: Enabled
Query-interval: 125s
General-query source IP: 1.1.1.1
Special-query source IP: 2.2.2.2
Report source IP: 3.0.0.3
Leave source IP: 1.0.0.1
Dot1p-priority: 2
Proxy: Disabled
IGMP snooping information: VLAN 10
Drop-unknown: Enabled
Version: 3
Dot1p-priority: --
Proxy: Disabled
Global-enable |
Global IGMP snooping status: · Enabled. · Disabled. |
IGMP snooping |
IGMP snooping status in a VLAN: · Enabled. · Disabled. · Globally enabled. · Inactive—IGMP snooping configuration does not take effect. |
Drop-unknown |
Status of dropping unknown multicast data: · Enabled. · Disabled. |
Version |
IGMP snooping version. |
Host-aging-time |
Aging timer for the dynamic member port. |
Router-aging-time |
Aging timer for the dynamic router port. |
Max-response-time |
Maximum response time for IGMP general queries. |
Last-member-query-interval |
Interval for sending IGMP group-specific queries. |
Report-aggregation |
Status of IGMP report suppression: · Enabled. · Disabled. |
Dot1p-priority |
802.1p priority for IGMP messages. If the priority is not configured, this field displays two hyphens (--). |
Querier |
Status of IGMP snooping querier: · Enabled. · Disabled. |
(IP: 1.1.1.1, Expires: 00:02:05) |
IGMP snooping querier information: · IP—IP address of the IGMP snooping querier. · Expire—Remaining aging time for the IGMP snooping querier. This field is not displayed if IGMP snooping querier election is disabled. |
Querier-election |
Status of IGMP snooping querier election: · Enabled. · Disabled. |
Query-interval |
Interval for sending IGMP general queries. |
General-query source IP |
Source IP address of IGMP general queries. |
Special-query source IP |
Source IP address of IGMP group-specific queries. |
Report source IP |
Source IP address of IGMP reports. |
Leave source IP |
Source IP address of IGMP leave messages. |
Host-tracking |
Status of host tracking: · Enabled · Disabled. · Globally enabled. |
Proxy |
Status of IGMP snooping proxying: · Enabled. · Disabled. |
display igmp-snooping group
Use display igmp-snooping group to display information about dynamic IGMP snooping group entries.
display igmp-snooping group [ group-address | source-address ] * [ vlan vlan-id ] [ interface interface-type interface-number | [ verbose ] [ slot slot-number ] ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about dynamic IGMP snooping group entries for all multicast groups.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays information about dynamic IGMP snooping group entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about dynamic IGMP snooping group entries for all VLANs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays brief information about dynamic IGMP snooping group entries for all interfaces.
verbose: Displays detailed information about dynamic IGMP snooping group entries. If you do not specify this keyword, the command displays brief information about dynamic IGMP snooping group entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about dynamic IGMP snooping group entries for the master device.
# Display brief information about dynamic IGMP snooping group entries for GigabitEthernet 1/0/1.
<Sysname> display igmp-snooping group interface gigabitethernet 1/0/1
Total 1 entries.
GE1/0/1:
VLAN 2: Total 1 entries.
(0.0.0.0, 224.1.1.1) (00:03:23)
# Display detailed information about dynamic IGMP snooping group entries for VLAN 2.
<Sysname> display igmp-snooping group vlan 2 verbose
Total 2 entries.
VLAN 2: Total 2 entries.
Attribute: local port
FSM information: dummy
Host slots (0 in total):
Host ports (1 in total):
GE1/0/2 (00:03:23)
(1.1.1.1, 224.1.1.1)
GE1/0/2 (00:04:04)
Total 1 entries |
Total number of dynamic IGMP snooping group entries. |
VLAN 2: Total 1 entries |
Total number of dynamic IGMP snooping group entries in VLAN 2. |
(0.0.0.0, 224.1.1.1) |
(S, G) entry, where 0.0.0.0 in the S position means all multicast sources. |
Attribute |
Entry attribute: · global port—The entry has a global port. · local port—The entry has a port that resides on the member device for which the information is displayed. · slot—The entry has ports that reside on other member devices except the member device for which the information is displayed. |
FSM information |
Finite state machine information of the entry: · delete—The entry attributes have been deleted. · dummy—The entry is a new temporary entry. · no info—No entry exists. |
Member IDs and total number of the member devices that have member ports, except for the specified member device or the master device when no member device is specified. |
Host ports (1 in total) |
Member ports, and the total number of member ports. |
Remaining aging time for the dynamic member port. Global ports include Layer 2 aggregate interfaces. For a global port, this field is displayed when no member device is specified or the master device is specified. For a non-global port, this field is displayed when one of the following conditions exists: · The port is on the specified member device. · The port is on the master device and no member device is specified. |
GE1/0/3 (Link ID 0) |
AC and its link ID. |
reset igmp-snooping group
Use display igmp-snooping host-tracking to display host tracking information.
display igmp-snooping host-tracking vlan vlan-id group group-address [ source source-address ] [ slot slot-number ]
group group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255.
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays host tracking information for all multicast sources.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays host tracking information for the master device.
# Display tracking information for hosts that have joined multicast group 224.1.1.1 in VLAN 2.
<Sysname> display igmp-snooping host-tracking vlan 2 group 224.1.1.1
VLAN 2
Port: GE1/0/1
Host Uptime Expires
1.1.1.1 00:02:20 00:00:40
2.2.2.2 00:02:21 00:00:39
VLAN |
VLAN ID. |
(S, G) entry, where 0.0.0.0 in the S position means any multicast sources. |
Port |
Member port. |
Host |
IP address of the host. |
Uptime |
Length of time elapsed since the host joined the multicast group. |
Expires |
Remaining timeout time for the host. The host timeout time is the same as the aging timer for the port. The timer is reset when the port receives an IGMP report from the host. This field displays timeout if the host times out. |
igmp-snooping enable
Use display igmp-snooping router-port to display dynamic router port information.
display igmp-snooping router-port [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
verbose: Displays detailed information. If you do not specify the keyword, this command displays brief information.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays dynamic router port information for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays dynamic router port information for the master device.
# Display brief information about dynamic router ports for VLAN 2.
<Sysname> display igmp-snooping router-port vlan 2
VLAN 2:
Router ports (2 in total):
GE1/0/1 (00:01:30)
GE1/0/2 (00:00:23)
# Display detailed information about dynamic router ports for VLAN 2.
<Sysname> display igmp-snooping router-port vlan 2 verbose
VLAN 2:
Router slots (0 in total):
GE1/0/1 (00:01:30)
GE1/0/2 (00:00:23)
VLAN 2 |
VLAN ID. |
Router slots (0 in total) |
Member IDs and total number of the member devices that have dynamic router ports, except for the specified member device or the master device when no member device is specified. |
Router ports (2 in total) |
Dynamic router ports and total number of dynamic router ports. |
(00:01:30) |
Remaining aging time for the dynamic router port. Global ports include Layer 2 aggregate interfaces. For a global port, this field is displayed when no member device is specified or the master device is specified. For a non-global port, this field is displayed when one of the following conditions exists: · The port is on the specified member device. · The port is on the master device and no member device is specified. |
GE1/0/3 (Link ID 1) |
Use display igmp-snooping static-group to display information about static IGMP snooping group entries.
display igmp-snooping static-group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about static IGMP snooping group entries for all multicast groups.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays information about static IGMP snooping group entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about static IGMP snooping group entries for all VLANs.
verbose: Displays detailed information about static IGMP snooping group entries. If you do not specify the keyword, this command displays brief information about static IGMP snooping group entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about static IGMP snooping group entries for the master device.
# Display detailed information about static IGMP snooping group entries for VLAN 2.
<Sysname> display igmp-snooping static-group vlan 2 verbose
Total 1 entries.
GE1/0/2
Table 5 Command output
Total 1 entries |
Total number of static IGMP snooping group entries. |
Total number of static IGMP snooping group entries in VLAN 2. |
Attribute |
FSM information |
Host slots (0 in total) |
Member ports and total number of member ports. |
Use display igmp-snooping static-router-port to display static router port information.
display igmp-snooping static-router-port [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
verbose: Displays detailed information about static router ports. If you do not specify this keyword, the command displays brief information about static router ports.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays static router port information for the master device.
# Display brief information about static router ports for VLAN 2.
<Sysname> display igmp-snooping static-router-port vlan 2
VLAN 2:
GE1/0/1
GE1/0/2
# Display detailed information about static router ports for VLAN 2.
<Sysname> display igmp-snooping static-router-port vlan 2 verbose
VLAN 2:
GE1/0/1
GE1/0/2
Table 6 Command output
VLAN 2 |
VLAN ID. |
Member IDs and total number of the member devices that have static router ports, except for the specified member device or the master device when no member device is specified. |
Static router ports and total number of static router ports. |
Use display igmp-snooping statistics to display statistics for the IGMP messages and PIMv2 hello messages learned through IGMP snooping.
# Display statistics for the IGMP messages and PIMv2 hello messages learned through IGMP snooping.
<Sysname> display igmp-snooping statistics
Received IGMP messages:
IGMP general queries: 19
IGMPv2 specific queries: 10
IGMPv3 specific queries: 0
IGMPv3 specific sg queries: 0
IGMPv1 reports: 0
IGMPv2 reports: 19
IGMPv3 reports: 0
IGMPv3 reports with right and wrong records: 0
IGMP leaves: 5
Error IGMP messages: 1
Sent IGMP messages:
IGMPv2 specific queries: 0
Received PIMv2 hello : 0
Table 7 Command output
general queries |
Number of IGMP general queries. |
specific queries |
Number of IGMP group-specific queries. |
reports |
Number of IGMP reports. |
leaves |
Number of IGMP leave messages. |
reports with right and wrong records |
Number of IGMP reports with correct and incorrect records. |
specific sg queries |
Number of IGMP group-and-source-specific queries. |
error IGMP messages |
Number of IGMP messages with errors. |
Use display l2-multicast fast-forwarding cache to display Layer 2 multicast fast forwarding entries.
display l2-multicast fast-forwarding cache [ vlan vlan-id ] [ source-address | group-address ] * [ slot slot-number ]
source-address: Specifies a multicast source address. If you do not specify a multicast source, this command displays Layer 2 multicast fast forwarding entries for all multicast sources.
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays Layer 2 multicast fast forwarding entries for all multicast groups.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays Layer 2 multicast fast forwarding entries for the master device.
# Display Layer 2 multicast fast forwarding entries.
<Sysname> display l2-multicast fast-forwarding cache
Total 1 entries, 1 matched
(10.1.1.2,225.1.1.1)
Status : Enable VLAN : 1
Source port : 9876 Destination port: 5432
Protocol : 17 Flag : 0x2
Ingress port: GigabitEthernet1/0/2
List of 1 egress ports:
GigabitEthernet1/0/3
Status: Enable Flag: 0x10
Table 8 Command output
Total 1 entries, 1 matched |
Total number of (S, G) entries in the Layer 2 multicast fast forwarding table, and the total number of matching entries. |
(10.1.1.2, 225.1.1.1) |
(S, G) entry in the Layer 2 multicast fast forwarding table. |
Protocol |
Protocol number. |
VLAN |
VLAN ID. |
Flag |
Flag for the (S, G) entry or the outgoing port. This field displays one flag or the sum of multiple flags. In this example, the value 0x2 means that the entry has only one flag 0x2. The following flags are available for an entry: · 0x1—The entry is created because of packets passed through between cards. · 0x2—The entry is added by multicast forwarding. The following flags are available for an outgoing interface: · 0x1—The port is added to the entry because of packets passed through between cards. · 0x2—The port is added to an existing entry. · 0x10—The port is associated with the entry. · 0x20—The port is to be deleted. |
Status |
Status of the (S, G) entry or the outgoing port: · Enabled—Available. · Disabled—Unavailable. |
Ingress port |
Incoming port of the (S, G) entry. |
List of 1 egress ports |
Outgoing port list of the (S, G) entry. |
reset l2-multicast fast-forwarding cache all
Use display l2-multicast ip to display information about Layer 2 IP multicast groups.
display l2-multicast ip [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
group group-address: Specifies a multicast group by its IP address. If you do not specify a multicast group, this command displays information about all Layer 2 IP multicast groups.
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays information about Layer 2 IP multicast groups for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about Layer 2 IP multicast groups for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about Layer 2 IP multicast groups for the master device.
# Display information about Layer 2 IP multicast groups for VLAN 2.
<Sysname> display l2-multicast ip vlan 2
Total 1 entries.
Attribute: static, success
GE1/0/1 (S, SUC)
Table 9 Command output
Total 1 entries |
Total number of Layer 2 IP multicast groups. |
Total number of Layer 2 IP multicast groups in VLAN 2. |
Attribute |
Entry attribute: · dynamic—The entry is created by a dynamic protocol. · static—The entry is created by a static protocol. · pim—The entry is created by PIM. · kernel—The entry is obtained from the kernel. · success—Processing has succeeded. · fail—Processing has failed. |
(S, SUC) |
Port attribute: · D—Dynamic port. · S—Static port. · P—PIM port. · K—Port obtained from the kernel. · R—Port learned from (*, *) entries. · W—Port learned from (*, G) entries. · SUC—Processing has succeeded. · F—Processing has failed. |
GE1/0/1 (Link ID 1) |
Use display l2-multicast ip forwarding to display Layer 2 multicast IP forwarding entries.
display l2-multicast ip forwarding [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
group group-address: Specifies a multicast group by its IP address. If you do not specify a multicast group, this command displays Layer 2 multicast IP forwarding entries for all multicast groups.
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays Layer 2 multicast IP forwarding entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays Layer 2 multicast IP forwarding entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays Layer 2 multicast IP forwarding entries for the master device.
# Display Layer 2 multicast IP forwarding entries for VLAN 2.
<Sysname> display l2-multicast ip forwarding vlan 2
Total 1 entries.
Host ports (3 in total):
GigabitEthernet1/0/1
Table 10 Command output
Total 1 entries |
Total number of Layer 2 multicast IP forwarding entries. |
Total number of Layer 2 multicast IP forwarding entries in VLAN 2. |
Host ports (3 in total) |
GigabitEthernet1/0/3 (Link ID 0) |
Use display l2-multicast mac to display information about Layer 2 MAC multicast groups.
display l2-multicast mac [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
mac-address: Specifies a MAC multicast group by its multicast MAC address. If you do not specify a MAC multicast group, this command displays information about all Layer 2 MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about Layer 2 MAC multicast groups for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about Layer 2 MAC multicast groups for the master device.
# Display information about Layer 2 MAC multicast groups for VLAN 2.
<Sysname> display l2-multicast mac vlan 2
Total 1 entries.
MAC group address: 0100-5e01-0101
Attribute: success
GE1/0/1
Table 11 Command output
Total 1 entries |
Total number of Layer 2 MAC multicast groups. |
Total number of Layer 2 MAC multicast groups in VLAN 2. |
MAC group address |
Address of the MAC multicast group. |
Attribute |
Entry attribute: · success—Processing has succeeded. · fail—Processing has failed. |
Use display l2-multicast mac forwarding to display Layer 2 multicast MAC forwarding entries.
display l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
mac-address: Specifies a MAC multicast group by its MAC address. If you do not specify a MAC multicast group, this command displays Layer 2 multicast MAC forwarding entries for all MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays Layer 2 multicast MAC forwarding entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays Layer 2 multicast MAC group entries for the master device.
# Display Layer 2 multicast MAC forwarding entries for VLAN 2.
<Sysname> display l2-multicast mac forwarding vlan 2
Total 1 entries.
Table 12 Command output
Total 1 entries |
Total number of Layer 2 multicast MAC forwarding entries. |
Total number of Layer 2 multicast MAC forwarding entries in VLAN 2. |
MAC group address |
Use display mac-address [ multicast ] to display static multicast MAC address entries.
mac-address: Specifies a multicast MAC address. The MAC address can be any legal multicast MAC address except 0100-5Exx-xxxx and 3333-xxxx-xxxx, where "x" represents a hexadecimal number in the range of 0 to F.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays MAC address entries for all VLANs.
multicast: Specifies static multicast MAC address entries.
count: Specifies the number of MAC address entries. If you specify this keyword, the command displays the number of matching MAC address entries. If you do not specify this keyword, the command displays the contents of the matching entries rather than the entry count.
If you do not specify any parameters, this command displays all MAC address table entries, including unicast MAC address entries and static multicast MAC address entries.
# Display static multicast MAC address entries for VLAN 2.
<Sysname> display mac-address multicast vlan 2
MAC Address VLAN ID State Port/NickName Aging
0100-0001-0001 2 Multicast GE1/0/1 N
# Display the number of static multicast MAC address entries.
<Sysname> display mac-address multicast count
1 mac address(es) found.
Table 13 Command output
MAC address |
MAC address of a multicast group. |
VLAN ID |
ID of the VLAN to which the network device identified by the MAC address belongs. |
State |
Status of the MAC address. If the multicast MAC address entry is static, this field displays Multicast. |
Port/NickName |
Outgoing ports. |
Aging |
Aging timer state. If this entry never expires, this field displays N. |
1 mac address(es) found |
One static multicast MAC address entry is found. |
Use dot1p-priority to set the 802.1p priority for IGMP messages globally.
Use undo dot1p-priority to restore the default.
dot1p-priority priority
undo dot1p-priority
The global 802.1p priority is 6 for IGMP messages.
IGMP-snooping view
priority: Specifies an 802.1p priority for IGMP messages, in the range of 0 to 7. The greater the value, the higher the priority.
You can set the 802.1p priority globally for all VLANs in IGMP-snooping view or for a VLAN in VLAN view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# Set the 802.1p priority for IGMP messages to 3 globally.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] dot1p-priority 3
igmp-snooping dot1p-priority
dscp
Use dscp to set the DSCP value for outgoing IGMP protocol packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value is 48 for outgoing IGMP protocol packets.
IGMP-snooping view
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value is carried in the ToS field of an IP packet to determine the transmission priority of the packet. A greater DSCP value represents a higher priority.
# Set the DSCP value to 63 for outgoing IGMP protocol packets.
[Sysname-igmp-snooping] dscp 63
Use enable to enable IGMP snooping for VLANs.
Use undo enable to disable IGMP snooping for VLANs.
enable vlan vlan-list
undo enable vlan vlan-list
IGMP snooping status in a VLAN is consistent with the global IGMP snooping status.
IGMP-snooping view
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094.
You must enable the IGMP snooping feature by using the igmp-snooping command before you enable IGMP snooping for VLANs.
You can enable IGMP snooping for multiple VLANs by using this command in IGMP-snooping view or for a VLAN by using the igmp-snooping enable command in VLAN view. The configuration in IGMP-snooping view has the same priority as the configuration in VLAN view, and the most recent configuration takes effect.
# Enable the IGMP snooping feature, and then enable IGMP snooping for VLAN 2 through VLAN 10.
[Sysname-igmp-snooping] enable vlan 2 to 10
igmp-snooping
Use entry-limit to globally set the maximum number of IGMP snooping forwarding entries, including dynamic entries and static entries.
Use undo entry-limit to restore the default.
entry-limit limit
undo entry-limit
The maximum number of IGMP snooping forwarding entries is 4294967295.
IGMP-snooping view
limit: Specifies the maximum number of IGMP snooping forwarding entries, in the range of 0 to 4294967295.
# Set the global maximum number of IGMP snooping forwarding entries to 512.
[Sysname-igmp-snooping] entry-limit 512
Use fast-leave to enable fast-leave processing globally.
Use undo fast-leave to disable fast-leave processing globally.
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled.
IGMP-snooping view
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you do not specify a VLAN, this command takes effect on all VLANs.
The fast-leave processing feature enables the device to immediately remove a port from the forwarding entry for a multicast group when the port receives a leave message.
You can enable fast-leave processing globally for all ports in IGMP-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Globally enable fast-leave processing for VLAN 2.
[Sysname-igmp-snooping] fast-leave vlan 2
igmp-snooping fast-leave
Use global-enable to enable IGMP snooping globally.
Use undo global-enable to disable IGMP snooping globally.
global-enable
undo global-enable
IGMP snooping is disabled globally.
IGMP-snooping view
To configure other IGMP snooping features for VLANs, you must enable IGMP snooping for the specific VLANs even though IGMP snooping is enabled globally.
# Enable IGMP snooping globally.
[Sysname-igmp-snooping] global-enable
igmp-snooping
igmp-snooping disable
Use group-policy to globally configure a multicast group policy to control the multicast groups that hosts can join.
Use undo group-policy to globally delete multicast group policies.
group-policy ipv4-acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
No multicast group policies exist. Hosts can join any multicast groups.
IGMP-snooping view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts can join only the multicast groups that the ACL permits. If the ACL does not exist or does not have valid rules, hosts cannot join multicast groups.
A multicast group policy filters IGMP reports to control the multicast groups that hosts can join.
This command does not take effect on static member ports, because static member ports do not send IGMP reports.
You can configure a multicast group policy globally for all ports in IGMP-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
When you configure a rule in the IPv4 ACL, follow these restrictions and guidelines:
· An ACL rule containing the vpn-instance vpn-instance option does not take effect.
· In a basic ACL, the source source-address source-wildcard option specifies a multicast group address.
· In an advanced ACL, the source source-address source-wildcard option specifies a multicast source address. The destination dest-address dest-wildcard option specifies a multicast group address.
To match the following IGMP reports, set the source source-address source-wildcard option to 0.0.0.0:
¡ IGMPv1 and IGMPv2 reports.
¡ IGMPv3 IS_EX and IGMPv3 TO_EX reports that do not carry multicast source addresses.
· Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
You can configure different ACLs for all ports in different VLANs. If you configure multiple ACLs for all ports in the same VLAN, the most recent configuration takes effect.
# Configure a multicast group policy for VLAN 2 so that hosts in VLAN 2 can join only multicast group 225.1.1.1.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 225.1.1.1 0
[Sysname-igmp-snooping] group-policy 2000 vlan 2
igmp-snooping group-policy
Use host-aging-time to set the aging timer for dynamic member ports globally.
Use undo host-aging-time to restore the default.
host-aging-time seconds
The aging timer for dynamic member ports is 260 seconds.
IGMP-snooping view
seconds: Specifies an aging timer for dynamic member ports, in the range of 1 to 8097894 seconds.
You can set the timer globally for all VLANs in IGMP-snooping view or for a VLAN in VLAN view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
To avoid mistakenly deleting multicast group members, set the aging timer for dynamic member ports to be greater than the value calculated by using the following formula:
[ IGMP general query interval ] + [ maximum response time for IGMP general queries ]
As a best practice, set the aging timer of dynamic member ports to the value calculated by using the following formula:
[ IGMP general query interval ] × 2 + [ maximum response time for IGMP general queries ]
# Set the global aging timer for dynamic member ports to 300 seconds.
[Sysname-igmp-snooping] host-aging-time 300
igmp-snooping host-aging-time
Use host-tracking to enable host tracking globally.
Use undo host-tracking to disable host tracking globally.
host-tracking
undo host-tracking
Host tracking is disabled.
IGMP-snooping view
You can enable host tracking globally for all VLANs in IGMP-snooping view or for a VLAN in VLAN view. For a VLAN, the global configuration has the same priority as the VLAN-specific configuration.
# Enable host tracking globally.
[Sysname-igmp-snooping] host-tracking
igmp-snooping
Use igmp-snooping to enable the IGMP snooping feature and enter IGMP-snooping view.
Use undo igmp-snooping to disable the IGMP snooping feature.
igmp-snooping
undo igmp-snooping
The IGMP snooping feature is disabled.
If you disable the IGMP snooping feature, IGMP snooping is disabled in all VLANs.
# Enable the IGMP snooping feature and enter IGMP-snooping view.
Use igmp-snooping dot1p-priority to set the 802.1p priority for IGMP messages in a VLAN.
Use undo igmp-snooping dot1p-priority to restore the default.
igmp-snooping dot1p-priority priority
The 802.1p priority is 6 for IGMP messages in a VLAN.
VLAN view
You must enable IGMP snooping for a VLAN before you execute this command.
You can set the 802.1p priority for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. The VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable IGMP snooping, and set the 802.1p priority for IGMP messages to 3.
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] igmp-snooping dot1p-priority 3
igmp-snooping drop-unknown
Use igmp-snooping drop-unknown to enable dropping unknown multicast data packets for a VLAN.
Use undo igmp-snooping drop-unknown to disable dropping unknown multicast data packets for a VLAN.
Dropping unknown multicast data packets is disabled. Unknown multicast data packets are flooded.
VLAN view
This feature cannot drop multicast data packets that have inconsistent destination multicast MAC address and destination multicast IPv4 address.
# In VLAN 2, enable IGMP snooping, and enable dropping unknown multicast data packets.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping drop-unknown
drop-unknown (IGMP-snooping view)
Use igmp-snooping enable to enable IGMP snooping for a VLAN.
Use igmp-snooping disable to disable IGMP snooping for a VLAN.
Use undo igmp-snooping to restore the IGMP snooping status in a VLAN to the global IGMP snooping status.
undo igmp-snooping
The IGMP snooping status in a VLAN is consistent with the global IGMP snooping status.
VLAN view
You must enable the IGMP snooping feature by using the igmp-snooping command before you enable IGMP snooping for a VLAN.
You can enable IGMP snooping for a VLAN by using this command in VLAN view or for multiple VLANs by using the enable command in IGMP-snooping view. The configuration in VLAN view has the same priority as the configuration in IGMP-snooping view, and the most recent configuration takes effect.
# Enable the IGMP snooping feature, and then enable IGMP snooping for VLAN 2.
[Sysname] vlan 2
# Disable IGMP snooping for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping disable
igmp-snooping
Use igmp-snooping fast-leave to enable fast-leave processing on a port.
Use undo igmp-snooping fast-leave to disable fast-leave processing on a port.
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled on a port.
You can enable fast-leave processing for a port in interface view or globally for all ports in IGMP-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# Enable fast-leave processing for VLAN 2 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp-snooping fast-leave vlan 2
Use igmp-snooping general-query source-ip to configure the source IP address for IGMP general queries.
Use undo igmp-snooping general-query source-ip to restore the default.
igmp-snooping general-query source-ip ip-address
In a VLAN, the source IP address of IGMP general queries is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
VLAN view
ip-address: Specifies the source IP address for IGMP general queries.
# In VLAN 2, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP general queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip 10.1.1.1
igmp-snooping group-limit
Use igmp-snooping group-limit to set the maximum number of multicast groups that a port can join.
Use undo igmp-snooping group-limit to remove the limit on the maximum number of multicast groups that a port can join.
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
No limit is placed on the maximum number of multicast groups that a port can join.
limit: Specifies the maximum number of multicast groups that a port can join, in the range of 0 to 4294967295.
This command takes effect only on the multicast groups that a port joins dynamically.
# On GigabitEthernet 1/0/1, set the maximum number of multicast groups the port can join in VLAN 2 to 10.
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-limit 10 vlan 2
Use igmp-snooping group-policy to configure a multicast group policy on a port to control the multicast groups that hosts attached to the port can join.
Use undo igmp-snooping group-policy to delete multicast group policies on a port.
igmp-snooping group-policy ipv4-acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
No multicast group polices exist on a port. Hosts attached to the port can join any multicast groups.
You can configure a multicast group policy for a port in interface view or globally for all ports in IGMP-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
You can configure different ACLs on a port for different VLANs. If you configure multiple ACLs on a port for the same VLAN, the most recent configuration takes effect.
# On GigabitEthernet 1/0/1, configure a multicast group policy for VLAN 2 so that hosts in VLAN 2 can join only multicast group 225.1.1.1.
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-policy 2000 vlan 2
Use igmp-snooping host-aging-time to set the aging timer for dynamic member ports in a VLAN.
Use undo igmp-snooping host-aging-time to restore the default.
igmp-snooping host-aging-time seconds
VLAN view
You can set the timer for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable IGMP snooping, and set the aging timer for dynamic member ports to 300 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
igmp-snooping host-join
Use igmp-snooping host-join to configure a port as a simulated member host for a multicast group.
Use undo igmp-snooping host-join to remove the configuration of a simulated member host for a multicast group.
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join { group-address [ source-ip source-address ] vlan vlan-id | all }
A port is not configured as a simulated member host for multicast groups.
group-address: Specifies a multicast group in the range of 224.0.1.0 to 239.255.255.255.
source-ip source-address: Specifies a multicast source by its IP address. If you specify a multicast source, this command configures the port as a simulated member host for a multicast source and group. If you do not specify a multicast source, this command configures the port as a simulated member host for a multicast group. This option takes effect on IGMPv3 snooping devices.
all: Specifies all multicast groups.
The version of IGMP running on a simulated member host is the same as the version of IGMP snooping running on the port. The port ages out in the same way as a dynamic member port.
# Configure GigabitEthernet 1/0/1 as a simulated member host of the multicast source and group (1.1.1.1, 232.1.1.1) in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-GigabitEthernet1/0/1] igmp-snooping host-join 232.1.1.1 source-ip 1.1.1.1 vlan 2
Use igmp-snooping host-tracking to enable host tracking for a VLAN.
Use undo igmp-snooping host-tracking to disable host tracking for a VLAN.
VLAN view
You must enable IGMP snooping for a VLAN before you execute this command for the VLAN.
You can enable host tracking for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration has the same priority as the global configuration.
# In VLAN 2, enable IGMP snooping, and then enable host tracking.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-tracking
Use igmp-snooping last-member-query-interval to set the IGMP last member query interval for a VLAN.
Use undo igmp-snooping last-member-query-interval to restore the default.
igmp-snooping last-member-query-interval interval
The IGMP last member query interval is 1 second.
VLAN view
interval: Specifies an IGMP last member query interval in the range of 1 to 25 seconds.
You can set the interval for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable IGMP snooping, and set the IGMP last member query interval to 3 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
igmp-snooping leave source-ip
Use igmp-snooping leave source-ip to configure the source IP address for IGMP leave messages.
Use undo igmp-snooping leave source-ip to restore the default.
igmp-snooping leave source-ip ip-address
In a VLAN, the source IP address of IGMP leave messages is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
VLAN view
ip-address: Specifies the source IP address for IGMP leave messages.
# In VLAN 2, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP leave messages.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping leave source-ip 10.1.1.1
Use igmp-snooping max-response-time to set the maximum response time for IGMP general queries in a VLAN.
Use undo igmp-snooping max-response-time to restore the default.
igmp-snooping max-response-time seconds
The maximum response time for IGMP general queries is 10 seconds.
VLAN view
seconds: Specifies the maximum response time for IGMP general queries, in the range of 1 to 3174 seconds.
You can set the time for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
To avoid mistakenly deleting multicast group members, set the maximum response time for IGMP general queries to be less than the IGMP general query interval.
# In VLAN 2, enable IGMP snooping, and set the maximum response time for IGMP general queries to 5 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
igmp-snooping query-interval
Use igmp-snooping overflow-replace to enable multicast group replacement on a port.
Use undo igmp-snooping overflow-replace to disable multicast group replacement on a port.
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
Multicast group replacement is disabled.
You can enable multicast group replacement for a port in interface view or globally for all ports in IGMP-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# On GigabitEthernet 1/0/1, enable multicast group replacement for VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping overflow-replace vlan 2
igmp-snooping proxy enable
Use igmp-snooping proxy enable to enable IGMP snooping proxying for a VLAN.
Use undo igmp-snooping proxy enable to disable IGMP snooping proxying for a VLAN.
IGMP snooping proxying is disabled.
VLAN view
This command does not take effect on a VLAN that is a sub-VLAN of a multicast VLAN.
# In VLAN 2, enable IGMP snooping, and enable IGMP snooping proxying.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping proxy enable
subvlan (multicast-VLAN view)
Use igmp-snooping querier to enable the IGMP snooping querier.
Use undo igmp-snooping querier to disable the IGMP snooping querier.
The IGMP snooping querier is disabled.
VLAN view
For a sub-VLAN of a multicast VLAN, this command takes effect only after you remove the sub-VLAN from the multicast VLAN.
# In VLAN 2, enable IGMP snooping, and enable the IGMP snooping querier.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
subvlan (multicast VLAN view)
Use igmp-snooping querier-election to enable IGMP snooping querier election for a VLAN.
Use undo igmp-snooping querier-election to disable IGMP snooping querier election for a VLAN.
IGMP snooping querier election is disabled for a VLAN.
VLAN view
For IGMP snooping querier election to take effect, you must enable the IGMP snooping querier.
# In VLAN 2, enable IGMP snooping, and enable IGMP snooping querier election.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier-election
Use igmp-snooping query-interval to set the IGMP general query interval for a VLAN.
Use undo igmp-snooping query-interval to restore the default.
igmp-snooping query-interval interval
The IGMP general query interval is 125 seconds.
VLAN view
interval: Specifies an IGMP general query interval in the range of 2 to 31744 seconds.
To avoid mistakenly deleting multicast group members, set the IGMP general query interval to be greater than the maximum response time for IGMP general queries.
# In VLAN 2, enable IGMP snooping, and set the IGMP general query interval to 20 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
max-response-time
Use igmp-snooping report source-ip to configure the source IP address for IGMP reports.
Use undo igmp-snooping report source-ip to restore the default.
igmp-snooping report source-ip ip-address
In a VLAN, the source IP address of IGMP reports is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
VLAN view
ip-address: Specifies the source IP address for IGMP reports.
# In VLAN 2, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP reports.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping report source-ip 10.1.1.1
Use igmp-snooping router-aging-time to set the aging timer for dynamic router ports in a VLAN.
Use undo igmp-snooping router-aging-time to restore the default.
igmp-snooping router-aging-time seconds
The aging timer for dynamic router ports is 260 seconds.
VLAN view
seconds: Specifies an aging timer for dynamic router ports, in the range of 1 to 8097894 seconds.
# In VLAN 2, enable IGMP snooping, and set the aging timer for dynamic router ports to 100 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
Use igmp-snooping router-port-deny to disable a port from becoming a dynamic router port.
Use undo igmp-snooping router-port-deny to allow a port to become a dynamic router port.
igmp-snooping router-port-deny [ vlan vlan-list ]
undo igmp-snooping router-port-deny [ vlan vlan-list ]
A port is allowed to become a dynamic router port.
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you specify VLANs, this command takes effect only when the port belongs to the specified VLANs. If you do not specify a VLAN, this command takes effect on all VLANs to which the port belongs.
# Disable GigabitEthernet 1/0/1 from becoming a dynamic router port in VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping router-port-deny vlan 2
igmp-snooping source-deny
Use igmp-snooping source-deny to enable multicast source port filtering on a port to discard all multicast data packets.
Use undo igmp-snooping source-deny to disable multicast source port filtering on a port.
Multicast source port filtering is disabled.
You can enable this feature for a port in interface view or for the specified ports in IGMP-snooping view. For a port, the configuration in interface view has the same priority as the configuration in IGMP-snooping view, and the most recent configuration takes effect.
# Enable source port filtering for multicast data on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp-snooping source-deny
Use igmp-snooping special-query source-ip to configure the source IP address for IGMP group-specific queries.
Use undo igmp-snooping special-query source-ip to restore the default.
igmp-snooping special-query source-ip ip-address
In a VLAN, the source IP address of IGMP group-specific queries is one of the following:
· The source address of IGMP group-specific queries if the IGMP snooping querier of the VLAN has received IGMP general queries.
· The IP address of the current VLAN interface if the IGMP snooping querier does not receive an IGMP general query.
· 0.0.0.0 if the IGMP snooping querier does not receive an IGMP general query and the current VLAN interface does not have an IP address.
VLAN view
ip-address: Specifies the source IP address for IGMP group-specific queries.
# In VLAN 2, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP group-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip 10.1.1.1
Use igmp-snooping static-group to configure a port as a static member port of a multicast group.
Use undo igmp-snooping static-group to remove the configuration of static member ports.
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group { group-address [ source-ip source-address ] vlan vlan-id | all }
A port is not a static member port of a multicast group.
source-ip source-address: Specifies a multicast source by its IP address. If you specify a multicast source, this command configures the port as a static member port for a multicast source and group. If you do not specify a multicast source, this command configures the port as a static member port for a multicast group. This option takes effect on IGMPv3 snooping devices.
# Configure GigabitEthernet 1/0/1 as a static member port of the multicast source and group (1.1.1.1, 225.0.0.1) in VLAN 2.
[Sysname] vlan 2
[Sysname-GigabitEthernet1/0/1] igmp-snooping static-group 225.0.0.1 source-ip 1.1.1.1 vlan 2
Use igmp-snooping static-router-port to configure a port as a static router port.
Use undo igmp-snooping static-router-port to remove the configuration of static router ports.
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port { all | vlan vlan-id }
A port is not a static router port.
all: Specifies all VLANs.
# Configure GigabitEthernet 1/0/1 as a static router port in VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping static-router-port vlan 2
Use igmp-snooping version to specify an IGMP snooping version for a VLAN.
Use undo igmp-snooping version to restore the default.
igmp-snooping version version-number
The IGMP snooping version in a VLAN is 2.
VLAN view
version-number: Specifies an IGMP snooping version, 2 or 3.
You can specify the version for a VLAN in VLAN view or for the specified VLANs in IGMP-snooping view. The VLAN-specific configuration has the same priority as the configuration in IGMP-snooping view, and the most recent configuration takes effect.
# In VLAN 2, enable IGMP snooping, and specify IGMP snooping version 3.
[Sysname] vlan 2
version (IGMP-snooping view)
Use last-member-query-interval to set the IGMP last member query interval globally.
Use undo last-member-query-interval to restore the default.
IGMP-snooping view
# Set the global IGMP last member query interval to 3 seconds.
[Sysname-igmp-snooping] last-member-query-interval 3
Use mac-address multicast to configure a static multicast MAC address entry.
Use undo mac-address multicast to delete a static multicast MAC address entry.
In system view:
undo mac-address [ multicast ] [ [ mac-address [ interface interface-list ] ] vlan vlan-id ]
In Layer 2 aggregate interface view or Layer 2 Ethernet interface view:
undo mac-address [ multicast ] mac-address vlan vlan-id
No static multicast MAC address entries exist.
mac-address: Specifies a static multicast MAC address, in the format of H-H-H. You must specify an unused multicast MAC address. A multicast MAC address is a MAC address in which the least significant bit of the most significant octet is 1.
interface interface-list: Specifies a space-separated list of up to four interface items. Each item specifies an interface or an interface list in the format of start-interface-type interface-number to end-interface-type interface-number. The interface-type interface-number argument specifies an interface by its type and number. The available interface types include Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
vlan vlan-id: Specifies an existing VLAN by its VLAN ID in the range of 1 to 4094. The system gives a prompt if the specified interface does not belong to the VLAN.
You do not need to enable IP multicast routing before you execute this command.
You can configure static multicast MAC address entries for the specified interfaces in system view or for the current interface in interface view.
If you do not specify the multicast keyword in the undo mac-address command, all static unicast MAC address entries and static multicast MAC entries are deleted.
# Configure a static multicast MAC address entry. In the entry, the multicast MAC address is 0100-5E00-0003 and the outgoing ports are GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5 in VLAN 2.
[Sysname] mac-address multicast 0100-5e00-0003 interface gigabitethernet 1/0/1 to gigabitethernet 1/0/5 vlan 2
# Configure a static multicast MAC address entry on GigabitEthernet 1/0/1. In the entry, the multicast MAC address is 0100-5E00-0003 and the outgoing port is GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] mac-address multicast 0100-5e00-0003 vlan 2
Use max-response-time to set the maximum response time for IGMP general queries globally.
Use undo max-response-time to restore the default.
IGMP-snooping view
# Set the global maximum response time for IGMP general queries to 5 seconds.
[Sysname-igmp-snooping] max-response-time 5
Use overflow-replace to enable the multicast group replacement feature globally.
Use undo overflow-replace to disable the multicast group replacement feature globally.
undo overflow-replace [ vlan vlan-list ]
The multicast group replacement feature is disabled.
IGMP-snooping view
You can enable the multicast group replacement feature globally for all ports in IGMP-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Globally enable the multicast group replacement feature for VLAN 2.
[Sysname-igmp-snooping] overflow-replace vlan 2
Use report-aggregation to enable IGMP report suppression.
Use undo report-aggregation to disable IGMP report suppression.
report-aggregation
IGMP report suppression is enabled.
IGMP-snooping view
# Disable IGMP report suppression.
[Sysname-igmp-snooping] undo report-aggregation
Use reset igmp-snooping group to clear information about dynamic IGMP snooping group entries.
reset igmp-snooping group { group-address [ source-address ] | all } [ vlan vlan-id ]
source-address: Specifies a multicast source address. If you do not specify a multicast source, this command clears information about dynamic IGMP snooping group entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command clears information about dynamic IGMP snooping group entries for all VLANs.
# Clear information about all dynamic IGMP snooping group entries.
<Sysname> reset igmp-snooping group all
reset igmp-snooping router-port
Use reset igmp-snooping router-port to clear dynamic router port information.
reset igmp-snooping router-port { all | vlan vlan-id }
all: Specifies all dynamic router ports.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command clears dynamic router port information for all VLANs.
# Clear dynamic router port information.
<Sysname> reset igmp-snooping router-port all
reset igmp-snooping statistics
Use reset igmp-snooping statistics to clear statistics for IGMP messages and PIMv2 hello messages learned through IGMP snooping.
# Clear the statistics for all IGMP messages and PIMv2 hello messages learned through IGMP snooping.
<Sysname> reset igmp-snooping statistics
Use reset l2-multicast fast-forwarding cache to clear Layer 2 multicast fast forwarding entries.
reset l2-multicast fast-forwarding cache [ vlan vlan-id ] { { source-address | group-address } * | all } [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears Layer 2 multicast fast forwarding entries for the master device.
all: Specifies all Layer 2 multicast fast forwarding entries.
# Clear all Layer 2 multicast fast forwarding entries.
<Sysname> reset l2-multicast fast-forwarding cache all
# Clear the Layer 2 multicast fast forwarding entry for the multicast source and group (20.0.0.2, 225.0.0.2).
<Sysname> reset l2-multicast fast-forwarding cache 20.0.0.2 225.0.0.2
router-aging-time (IGMP-snooping view)
Use router-aging-time to set the aging timer for dynamic router ports globally.
Use undo router-aging-time to restore the default.
IGMP-snooping view
# Set the global aging timer for dynamic router ports to 100 seconds.
[Sysname-igmp-snooping] router-aging-time 100
send-query enable
Use send-query enable to enable the device to send IGMP general queries upon a path change.
Use undo send-query enable to restore the default.
send-query enable
The device does not send IGMP general queries upon a path change.
IGMP-snooping view
Use this command to enable the device to immediately send an IGMP general query to all ports in the affected VLAN or VSI when the path changes. This feature ensures that the device can update the member port information in multicast forwarding entries and switch multicast traffic to the new path promptly.
# Enable the device to send IGMP general queries upon a path change.
[Sysname-igmp-snooping] send-query enable
igmp-snooping
source-deny (IGMP-snooping view)
Use source-deny to enable multicast source port filtering on ports to discard all multicast data packets.
Use undo source-deny to disable multicast source port filtering on ports.
undo source-deny port interface-list
IGMP-snooping view
port interface-list: Specifies a space-separated list of port items. Each item specifies a port by its port type and number or a range of ports in the form of start-interface-type interface-number to end-interface-type interface-number.
You can enable this feature for the specified ports in IGMP-snooping view or for a port in interface view. For a port, the configuration in IGMP-snooping view has the same priority as the configuration in interface view, and the most recent configuration takes effect.
# Enable multicast source port filtering on ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4.
[Sysname-igmp-snooping] source-deny port gigabitethernet 1/0/1 to gigabitethernet 1/0/4
Use version to specify an IGMP snooping version for VLANs.
Use undo version to restore the default.
undo version vlan vlan-list
IGMP-snooping view
You must enable IGMP snooping for the specified VLANs before you execute this command.
You can specify the version for the specified VLANs in IGMP-snooping view or for a VLAN in VLAN view. The configuration in IGMP-snooping view has the same priority as the VLAN-specific configuration, and the most recent configuration takes effect.
# Enable IGMP snooping for VLAN 2 through VLAN 10, and specify IGMP snooping version 3 for these VLANs.
[Sysname-igmp-snooping] version 3 vlan 2 to 10
enable (IGMP-snooping view)
