- 15-BRAS Services Command Reference
- 01-AAA commands
- 02-ANCP commands
- 03-PPP commands
- 04-DHCP commands
- 05-DHCPv6 commands
- 06-User profile commands
- 07-Connection limit commands
- 08-L2TP commands
- 09-PPPoE commands
- 10-IPoE commands
- 11-802.1X commands (Layer 3)
- 12-UCM commands
- 13-Value-added services commands
| 05-DHCPv6 commands | 1.43 MB |
display ipv6 dhcp flood-protection
display ipv6 dhcp interface-rate-suppression
ipv6 dhcp advertise srv6-locator-route
ipv6 dhcp conflict-ip-address offline
ipv6 dhcp flood-protection aging-time
ipv6 dhcp flood-protection enable
ipv6 dhcp flood-protection global enable
ipv6 dhcp flood-protection threshold
ipv6 dhcp interface-rate-suppression aging-time
ipv6 dhcp interface-rate-suppression enable
ipv6 dhcp interface-rate-suppression global enable
ipv6 dhcp interface-rate-suppression threshold
ipv6 dhcp session-mismatch action
reset ipv6 dhcp flood-protection
reset ipv6 dhcp interface-rate-suppression
display dhcpv6-access packet statistics
display dhcpv6-access user-table
display ipv6 dhcp address offline-record
display ipv6 dhcp pool-group-usage
display ipv6 dhcp prefix offline-record
display ipv6 dhcp option-group
display ipv6 dhcp server conflict
display ipv6 dhcp server database
display ipv6 dhcp server expired-ip
display ipv6 dhcp server expired-pd
display ipv6 dhcp server free-ip
display ipv6 dhcp server free-pd
display ipv6 dhcp server free-srv6-locator
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server packet statistics
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server srv6-locator-in-use
display ipv6 dhcp server statistics
display ipv6 dhcp srv6-locator offline-record
ipv6 dhcp duid-mismatch offline
ipv6 dhcp server database filename
ipv6 dhcp server database update interval
ipv6 dhcp server database update now
ipv6 dhcp server database update stop
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dhcp server multi-ip per-mac enable
ipv6-pool algorithm round-robin
reserve expired-ipv6-address enable
reserve expired-ipv6-address mode
reset dhcpv6-access packet statistics
reset ipv6 dhcp { address | locator | prefix } offline-record
reset ipv6 dhcp pool-usage peak
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired-ip
reset ipv6 dhcp server expired-pd
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server packet statistics
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server srv6-locator-in-use
snmp-agent trap enable ipv6 dhcp server
vpn-instance (IPv6 address pool view)
vpn-instance (IPv6 address pool group view)
Old-style DHCPv6 server commands
display ipv6 dhcp relay client-information address
display ipv6 dhcp relay client-information pd
display ipv6 dhcp relay client-information srv6-locator
display ipv6 dhcp relay packet statistics
display ipv6 dhcp relay remote-server-info
display ipv6 dhcp relay server-address
ipv6 dhcp relay client-link-address enable
ipv6 dhcp relay client-information record
ipv6 dhcp relay non-first-hop enable
ipv6 dhcp relay remote-id duid
ipv6 dhcp relay remote-id enable
ipv6 dhcp relay server-address algorithm
ipv6 dhcp relay subscriber-id enable
ipv6 dhcp relay source-address
reset ipv6 dhcp relay client-information address
reset ipv6 dhcp relay client-information pd
reset ipv6 dhcp relay client-information srv6-locator
reset ipv6 dhcp relay packet statistics
display ipv6 dhcp client statistics
ipv6 dhcp client stateless enable
reset ipv6 dhcp client statistics
display ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
display ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping trust
ipv6 dhcp snooping binding database filename
ipv6 dhcp snooping binding database update interval
ipv6 dhcp snooping binding database update now
ipv6 dhcp snooping binding record
ipv6 dhcp snooping check request-message
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option interface-id string
ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
reset ipv6 dhcp snooping binding
reset ipv6 dhcp snooping packet statistics
DHCPv6 commands
Common DHCPv6 commands
display ipv6 dhcp duid
Use display ipv6 dhcp duid to display the DUID of the local device.
A DHCP unique identifier (DUID) uniquely identifies a DHCPv6 device (DHCPv6 client, server, or relay agent). A DHCPv6 device adds its DUID in a sent packet.
This command displays output only after the DHCPv6 process is running on the device.
# Display the DUID of the local device.
<Sysname> display ipv6 dhcp duid
The DUID of this device: 0003000100e0fc005552.
Use display ipv6 dhcp flood-protection to display information about DHCPv6 flood attack protection entries.
In standalone mode:
display ipv6 dhcp flood-protection slot slot-number [ mac-address mac-address [ interface interface-type interface-number ] | state { check | restrain } [ verbose ] | statistics | verbose ]
In IRF mode:
display ipv6 dhcp flood-protection chassis chassis-number slot slot-number [ mac-address mac-address [ interface interface-type interface-number ] | state { check | restrain } [ verbose ] | statistics | verbose ]
mac-address mac-address: Specifies a MAC address in the format of H-H-H. If you specify this option, the command displays detailed information about the DHCPv6 flood attack protection entries for the specified MAC address. If you do not specify this option, the command displays brief information about DHCPv6 flood attack protection entries.
interface interface-type interface-number: Displays information about the DHCPv6 flood attack protection entries for the specified interface.
state { check | restrain }: Displays information about DHCPv6 flood attack protection entries in the specified state. The check keyword specifies the check state. The restrain keyword specifies the restrain state.
slot slot-number: Specifies a card by its slot number. On this device, the slot-number argument represents the entire device and its value is fixed. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. (In IRF mode.)
statistics: Displays statistics for DHCPv6 flood attack protection entries.
verbose: Displays detailed information about DHCPv6 flood attack protection entries.
If you do not specify any parameters, this command displays brief information about all DHCPv6 flood attack protection entries on the device.
# Display brief information about DHCPv6 flood attack protection entries on a slot.(In standalone mode.)
<Sysname> display ipv6 dhcp flood-protection slot 0
Global DHCPv6 flood protection: Enabled
DHCPv6 flood protection threshold: 100 packets/ 2000 milliseconds
Index MAC address UDP port SVLAN/CVLAN State
0 a036-9f5c-74e4 547 4091/4094 Restrain
1 c434-6b3f-0001 547 4091/4094 Check
Total entries: 2
# Displays statistics for DHCPv6 flood attack protection entries on a slot.
<Sysname> display ipv6 dhcp flood-protection slot 0 statistics
Total entries: 2
Entries in check state: 1
Entries in restrain state: 1
# Display detailed information about DHCPv6 flood attack protection entries for MAC address c434-6b3f-0001 on a slot. (In standalone mode.)
<Sysname> display ipv6 dhcp flood-protection slot 0 mac-address c434-6b3f-0001
Interface: Ten-GigabitEthernet0/0/15
MAC address: c434-6b3f-0001
Hardware status: Succeeded
SVLAN/CVLAN: 4091/4094
State: Check
SRv6 ID: ::
Entry created at: 2018/01/08 16:12:36
Entry aging time: 21 seconds
Total passed packets: 1
Total restrain packets: 0
Total entries: 1
# Display detailed information about DHCPv6 flood attack protection entries on the specified slot. (In standalone mode.)
<Sysname>display ipv6 dhcp flood-protection slot 0 verbose
MAC address: 78a8-3e93-0216
SVLAN/CVLAN: -/-
State: Restrain
SRv6 ID: ::
Entry created at: 2021/06/24 11:23:36
Total restrain packets: 7
Interface: Ten-GigabitEthernet0/0/16
MAC address: 78a8-3e93-0217
SVLAN/CVLAN: -/-
State: Restrain
SRv6 ID: ::
Entry created at: 2021/06/24 11:23:37
Total restrain packets: 6
Interface: Ten-GigabitEthernet0/0/17
MAC address: 78a8-3e93-0218
SVLAN/CVLAN: -/-
State: Restrain
SRv6 ID: ::
Total entries: 3
Global DHCPv6 flood protection |
Whether global DHCPv6 flood attack protection is enabled |
DHCPv6 flood protection threshold: xxx packets/ yyy milliseconds |
The DHCPv6 packet count limit is xxx and the detection duration is yyy milliseconds. |
Index |
Sequence number of the DHCPv6 flood attack protection entry. |
MAC address |
Source MAC address in DHCPv6 packets. |
UDP port |
Destination UDP port number in DHCPv6 packets. |
SVLAN/CVLAN |
Inner VLAN ID and outer VLAN ID in DHCPv6 packets. If a DHCPv6 packet does not belong to any VLAN, this field displays a hyphen (-). |
State |
State of the DHCPv6 flood attack protection entry: · Check. · Restrain. |
Interface that received DHCPv6 packets. |
Hardware status |
Result of issuing the entry to the hardware: · Succeeded—Succeeded in issuing the entry to the hardware. · Failed—Failed to issue the entry to the hardware because of a device failure or insufficient hardware resources. · N/A—The entry was not issued to the hardware because the packet was not an attack packet. · Not support—DHCPv6 attack protection is not supported in hardware. |
SRv6 ID |
SRv6 SID of the interface that received DHCPv6 packets. |
Entry created at |
Time when the DHCPv6 flood attack protection entry was created. The entry is in check state when it is created. |
Entry aging time |
Remaining lifetime of the DHCPv6 flood attack protection entry. |
Total passed packets |
Number of DHCP packets that have been passed through when the DHCPv6 flood attack protection entry is in check state. |
Total restrain packets |
Number of dropped DHCP packets when the DHCPv6 flood attack protection entry is in restrain state. |
Total entries |
Total number of DHCPv6 flood attack protection entries. |
Entries in check state |
Total number of DHCPv6 flood attack protection entries in check state. |
Entries in restrain state |
Total number of DHCPv6 flood attack protection entries in restrain state. |
Use display ipv6 dhcp interface-rate-suppression display information about interface-based DHCPv6 attack suppression entries.
In standalone mode:
display ipv6 dhcp interface-rate-suppression slot slot-number [ interface interface-type interface-number | state { check | restrain } [ verbose ] | statistics | verbose ]
In IRF mode:
display ipv6 dhcp interface-rate-suppression chassis chassis-number slot slot-number [ interface interface-type interface-number | state { check | restrain } [ verbose ] | statistics | verbose ]
interface interface-type interface-number: Displays detailed information about the DHCPv6 attack suppression entry for the specified interface.
state { check | restrain }: Displays information about interface-based DHCPv6 attack suppression entries in the specified state. The check keyword specifies the check state. The restrain keyword specifies the restrain state.
statistics: Displays interface-based DHCPv6 attack suppression statistics.
verbose: Displays detailed information about interface-based DHCPv6 attack suppression entries.
If you do not specify any parameters, this command displays brief information about all interface-based DHCPv6 attack suppression entries on the device.
# Display brief information about interface-based DHCPv6 attack suppression entries.
<Sysname> display ipv6 dhcp interface-rate-suppression
DHCPv6 attack suppression threshold: 100 packets/ 2000 milliseconds
Index Interface State
0 XGE0/0/15 Restrain
1 XGE0/0/16 Check
2 XGE0/0/17 Restrain
Total entries: 3
# Display interface-based DHCPv6 attack suppression statistics.
<Sysname> display ipv6 dhcp interface-rate-suppression statistics
Interfaces enabled with DHCPv6 attack suppression: 3
Entries in check state: 2
# Display detailed information about the DHCPv6 attack suppression entry for Ten-GigabitEthernet 0/0/15.
<Sysname> display ipv6 dhcp interface-rate-suppression interface Ten-GigabitEthernet 0/0/15
State: Restrain
Entry created at: 2018/07/08 15:51:50
Total passed packets: 2
Total restrain packets: 3
# Display brief information about interface-based DHCPv6 attack suppression entries on a slot. (In standalone mode.)
<Sysname> display ipv6 dhcp interface-rate-suppression slot 0
1 XGE0/0/16 Check
Total entries: 3
# Display detailed information about the DHCPv6 attack suppression entry for Ten-GigabitEthernet 0/0/15 on a slot. (In standalone mode.)
<Sysname> display ipv6 dhcp interface-rate-suppression slot 0 interface ten-gigabitethernet 0/0/15
State: Restrain
# Display interface-based DHCPv6 attack suppression statistics on the specified slot.(In standalone mode.)
<Sysname> display ipv6 dhcp interface-rate-suppression slot 0 statistics
# Display detailed information about interface-based DHCPv6 attack suppression entries on the specified slot. (In standalone mode.)
<Sysname>display ipv6 dhcp interface-rate-suppression slot 0 verbose
State: Restrain
Entry created at 2021/06/24 11:23:36
Total passed packets: 7
State: Restrain
Entry created at 2021/06/24 11:23:37
Total passed packets: 6
State: Restrain
Total entries: 3
DHCPv6 attack suppression threshold: xxx packets/ yyy milliseconds |
Index |
Sequence number of the interface-based DHCPv6 attack suppression entry. |
State |
State of the interface-based DHCPv6 attack suppression entry: · Check. · Restrain. |
Hardware status |
Entry created at |
Time when the interface-based DHCPv6 attack suppression entry was created. |
Entry aging time |
Remaining lifetime of the interface-based DHCPv6 attack suppression entry. |
Number of forwarded DHCP packets when the DHCPv6 flood attack suppression entry is in restrain state. |
Number of dropped DHCP packets when the DHCPv6 flood attack suppression entry is in restrain state. |
Total entries |
Total number of interface-based DHCPv6 attack suppression entries. |
Interfaces enabled with DHCPv6 attack suppression |
Total number of interfaces on which DHCPv6 attack suppression is enabled. |
Check state count |
Total number of interface-based DHCPv6 attack suppression entries in check state. |
Restrain state count |
Total number of interface-based DHCPv6 attack suppression entries in restrain state. |
display ipv6 dhcp rate-limit
Use display ipv6 dhcp rate-limit to display packet statistics for the DHCPv6 packet rate-limiting feature.
In standalone mode:
display ipv6 dhcp rate-limit slot slot-number
In IRF mode:
display ipv6 dhcp rate-limit chassis chassis-number slot slot-number
To limit the rate of incoming DHCPv6 SOLICIT packets (including those forwarded from DHCPv6 relay agents), use the ip subscriber dhcpv6 rate-limit command. To display packet statistics for the DHCPv6 packet rate-limiting feature, use the display ipv6 dhcp rate-limit command.
The real DHCPv6 rate limit value and the number of packet drops depend on the following factors:
· CPU usage
When the CPU usage reaches the minor or severe level, the system reduces the DHCPv6 rate limit value according to the adjustment percentage configured by using the access-user adjustment access-rate-limit command:
¡ If a DHCPv6 rate limit value is configured by using the ip subscriber dhcpv6 rate-limit command, the system adjusts the rate limit value according to the configured adjustment percentage.
¡ If no DHCPv6 rate limit value is configured, the system adjusts the predefined backup rate limit value according to the configured adjustment percentage.
¡ If the DHCPv6 rate limit value is smaller than 1 after adjustment, the real rate limit value equals the minimum value of 1.
· Maximum number of concurrent access users
When the number of DHCPv6 access users exceeds the upper limit configured by using the access-user max-connections command, the device directly discards DHCPv6 SOLICIT packets received from users (including those forwarded from DHCPv6 relay agents).
# (In standalone mode.) Display packet statistics for the DHCPv6 packet rate-limiting feature on a slot.
<Sysname> display ipv6 dhcp rate-limit slot 0
DHCPv6 rate-limit packet statistics:
Dropped since last poll:12
Total dropped packets:22
Total passed packets:1000
Adjustment ratelimit ratio: 100%
Ratelimit threshold : 200 (configured)
DHCPv6 forbidden-access packet statistics:
Last dropped out-of-limit packets: 0
Total dropped out-of-limit packets: 0
DHCPv6 rate-limit packet statistics |
Packet statistics for the DHCPv6 packet rate-limiting feature. |
Dropped since last poll |
Number of packets dropped by the DHCPv6 packet rate-limiting feature since the most recent data poll. |
Total dropped packets |
Total number of packets dropped by the DHCPv6 packet rate-limiting feature. |
Total number of packets permitted by the DHCPv6 packet rate-limiting feature. |
Adjustment ratelimit ratio |
DHCPv6 rate limit adjustment ratio for the related CPU usage level. |
Ratelimit threshold |
Real DHCPv6 packet rate limit: · Not configured—No DHCPv6 packet rate limit is configured. · xxx (configured)—The xxx argument equals the rate limit value configured by using the ip subscriber dhcp rate-limit command multiplied by the DHCP rate limit adjustment percentage. · xxx (fallback)—No DHCPv6 packet rate limit is configured. After a CPU usage alarm is generated, the xxx argument equals the predefined backup rate limit value multiplied by the DHCP rate limit adjustment percentage. |
DHCPv6 packet statistics collected for forbidden DHCPv6 access users after the number of concurrent DHCPv6 access users exceeded the upper limit. This field collects DHCPv6 packet drop statistics each time the number of concurrent DHCPv6 access users exceeds the upper limit. |
Last dropped out-of-limit packets |
Total dropped out-of-limit packets |
Number of DHCPv6 user packets (including those forwarded from DHCPv6 relay agents) dropped during the most recent round of DHCPv6 packet drop statistics collection. |
ip subscriber dhcpv6 rate-limit (BRAS Services Command Reference)
reset ipv6 dhcp rate-limit
ipv6 dhcp advertise pd-route
Use ipv6 dhcp advertise pd-route to enable the DHCPv6 server or DHCPv6 relay agent to advertise IPv6 prefixes.
Use undo ipv6 dhcp advertise pd-route to disable the DHCPv6 server or DHCPv6 relay agent from advertising IPv6 prefixes.
The DHCPv6 server or DHCPv6 relay agent does not advertise IPv6 prefixes.
Application scenarios
A DHCPv6 client can obtain an IPv6 prefix through DHCPv6 and use this IPv6 prefix to assign IPv6 addresses to clients in a downstream network. If the IPv6 prefix is in a different subnet than the IPv6 address of the DHCPv6 client's upstream interface, clients in the downstream network cannot access the external network. You can use this command to enable this feature on the DHCPv6 server or DHCPv6 relay agent, whichever is on the same link as the DHCPv6 client.
Operating mechanism
This feature enables the DHCPv6 server or relay agent to generate a routing entry for the IPv6 prefix and advertises this entry to the dynamic routing protocol. When the DHCPv6 client learns this route through the dynamic routing protocol, clients in the downstream network can access the external network.
To use this command on the DHCPv6 relay agent, you must enable the DHCPv6 relay agent to record DHCPv6 relay entries first.
After you enable this feature, the tag value for the advertised prefix routes will be the tag value specified for network routes when you execute the network command. If you do not specify a tag value for network routes when you execute the network command, the tag value for prefix routes is set to 0 by default.
# Enable the DHCPv6 server to advertise IPv6 prefixes.
[Sysname] ipv6 dhcp advertise pd-route
Use ipv6 dhcp advertise srv6-locator-route to enable the DHCPv6 server or relay agent to advertise SRv6 locator routes.
Use undo ipv6 dhcp advertise srv6-locator-route to restore the default.
ipv6 dhcp advertise srv6-locator-route [ preference preference | tag tag ] *
The DHCPv6 server or relay agent does not advertise SRv6 locator routes.
preference preference: Sets a preference for the locator routes to be advertised, in the range of 1 to 255. The default preference is 65.
tag tag: Sets a tag value for the locator routes to be advertised, in the range of 0 to 4294967295. The default tag value is 0. Tags are used by routing policies to filter routes. For more information about routing policies, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
After a DHCPv6 client obtains an SRv6 locator, it uses that locator for SID assignment to VPN services within the downstream network. However, hosts in the downstream network cannot communicate with external networks, because they are not located in the same network segment as the DHCPv6 client. To resolve this issue, enable the DHCPv6 server or relay agent to advertise SRv6 locator routes. The DHCPv6 server or relay agent will then generate a route destined for the SRv6 locator obtained by the DHCPv6 client, and advertise that route to the related routing protocol. Once the DHCPv6 client learns the advertised SRv6 locator route through the routing protocol, hosts running in downstream VPN instances can communicate with external networks.
Before you enable this feature on a DHCPv6 relay agent, you must enable the DHCPv6 relay agent to record DHCPv6 relay entries.
When you enable this feature, follow these restrictions and guidelines:
· If the DHCPv6 server and the DHCPv6 client are in the same subnet, enable this feature on the DHCPv6 server.
· If the DHCPv6 server and the DHCPv6 client are in different subnets, enable this feature on the DHCPv6 relay agent that is in the same subnet as the DHCPv6 client.
# Enable the DHCPv6 server or relay agent to advertise SRv6 locator routes.
[Sysname] ipv6 dhcp advertise srv6-locator-route
Use ipv6 dhcp conflict-ip-address offline to release the IPv6 address obtained by an online DHCPv6 client for a new dynamic allocation.
Use undo ipv6 dhcp conflict-ip-address offline to restore the default.
The DHCPv6 device does not release the IPv6 address obtained by an online DHCPv6 client to allocate it to a new client.
By default, a new DHCPv6 client or authorized user fails to come online in either of the following situations:
· Its IPv6 address allocated by the DHCPv6 server conflicts with the address in a relay entry.
· Its IPv6 address allocated by the authentication module (UCM or AAA) conflicts with the address obtained by an online DHCPv6 client.
This feature works as follows:
· On a DHCPv6 server:
a. The DHCPv6 server releases the IPv6 address obtained by an online DHCPv6 client when an IPv6 address conflict occurs during the dynamic allocation.
b. The server then informs the access module that this IPv6 address is conflicting and cannot be allocated.
· On a DHCPv6 relay agent:
¡ If the IPv6 address allocated by the authentication module conflicts with the address in a relay entry, the relay agent performs the following operations in sequence:
- The relay agent sends a DHCPv6-RELEASE message for the conflicting address to the DHCPv6 server.
- The relay agent then informs the access module that this IPv6 address is conflicting and cannot be allocated.
¡ If the IPv6 address in the DHCPv6-REPLY message conflicts with the address in a relay entry, the relay agent performs the following operations in sequence:
- The relay agent then discards the DHCPv6 reply and the new DHCPv6 client fails to obtain an IPv6 address.
After the conflicting IPv6 address is released, the new DHCPv6 client or authorized user can obtain the address if it requests again.
This feature cannot take effect on a DHCPv6 relay agent without relay entry recording enabled.
# Enable the DHCPv6 server or authorized IPv6 pool to release the IPv6 address obtained by an online DHCPv6 client to allocate it to a new client.
[Sysname] ipv6 dhcp conflict-ip-address offline
ipv6 dhcp dscp
Use ipv6 dhcp dscp to set the DSCP value for the DHCPv6 packets sent by the DHCPv6 server or the DHCPv6 relay agent.
Use undo ipv6 dhcp dscp to restore the default.
ipv6 dhcp dscp dscp-value
undo ipv6 dhcp dscp
The DSCP value is 56 in DHCPv6 packets sent by the DHCPv6 server or the DHCPv6 relay agent.
dscp-value: Specifies the DSCP value for DHCPv6 packets, in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for DHCPv6 packets sent by the DHCPv6 server or the DHCPv6 relay agent.
ipv6 dhcp duid
Use ipv6 dhcp duid duid to set a DUID for the device.
Use undo ipv6 duid to restore the default.
ipv6 dhcp duid duid
undo ipv6 duid
The default DUID generated by the device applies.
duid: Specifies a hexadecimal DUID for the device. The DUID length must be an even integer in the range of 8 to 28.
DHCP Unique Identifier (DUID) is designed for DHCPv6 device identification, including clients, servers, and relay agents.
By default, a DHCPv6 device generates a DUID when it starts.
To view the DUID of a DHCPv6 device, you can execute the display ipv6 dhcp duid command.
# Set the DUID to aabbccdd1122334455 for the device.
[Sysname] ipv6 dhcp duid aabbccdd1122334455
Use ipv6 dhcp flood-protection aging-time to set the aging time of DHCPv6 flood attack protection entries.
Use undo ipv6 dhcp flood-protection aging-time to restore the default.
ipv6 dhcp flood-protection aging-time time
The aging time is 300 seconds for DHCPv6 flood attack protection entries.
time: Specifies the aging time of DHCPv6 flood attack protection entries, in seconds. The value range is 30 to 600.
When the aging time of a DHCPv6 flood attack protection entry for a MAC address is reached, the DHCPv6 device examines the drop rate of DHCPv6 packets sent from the MAC address.
· If the packet drop rate is lower than the DHCPv6 flood attack threshold, the device deletes the entry. If later a DHCPv6 packet from that MAC address arrives, the DHCPv6 device will create a new flood attack protection entry and count the number of incoming DHCPv6 packets for that client again.
· If the packet drop rate is equal to or higher than the DHCPv6 flood attack threshold, the device resets the aging time for the entry.
This command takes effect only you after you execute the ipv6 dhcp flood-protection enable command.
If you execute the command multiple times, the most recent configuration takes effect.
# Set the aging time to 90 seconds for DHCPv6 flood attack protection entries.
[Sysname] ipv6 dhcp flood-protection aging-time 90
Use ipv6 dhcp flood-protection enable to enable DHCPv6 flood attack protection.
Use undo ipv6 dhcp flood-protection enable to disable DHCPv6 flood attack protection.
DHCPv6 flood attack protection is disabled.
Interface view
When the DHCPv6 device receives a DHCPv6 packet from a client (MAC address), it creates a DHCPv6 flood attack protection entry in check state. If the number of incoming DHCPv6 packets from the same MAC address reaches the upper limit in the detection duration, the device determines that the client is launching a DHCPv6 flood attack. The DHCPv6 flood attack protection entry changes to the restrain state, and the device discards the DHCPv6 packets from that client.
# Enable DHCPv6 flood attack protection on Ten-GigabitEthernet 0/0/15.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp flood-protection enable
Use ipv6 dhcp flood-protection global enable to enable global DHCPv6 flood attack protection.
Use undo ipv6 dhcp-flood protection global enable to disable global DHCPv6 flood attack protection.
undo ipv6 dhcp flood-protection global enable
Global DHCPv6 flood attack protection is enabled.
When the device receives a DHCPv6 packet from a client, it creates a DHCP flood attack protection entry in check state for that client. In the entry, the client is identified by its MAC address. If the number of incoming DHCPv6 packets from that client reaches the upper limit in the detection duration, the device determines that the client is launching a DHCPv6 flood attack. The DHCPv6 flood attack protection entry changes to the restrain state, and the device discards the DHCPv6 packets from that client.
You can configure DHCPv6 flood attack protection globally by using the ipv6 dhcp flood-protection global enable command or on a per-interface basis by using the ipv6 dhcp flood-protection enable command.
DHCPv6 flood attack protection takes effect on an interface if it is enabled globally or on that interface. To enable DHCPv6 flood attack protection only on some of the interfaces, disable the feature globally and enable it by using the ipv6 dhcp flood-protection enable command on the desired interfaces.
# Enable global DHCPv6 flood attack protection.
[Sysname] ipv6 dhcp flood protection global enable
Use ipv6 dhcp flood-protection threshold to set the DHCPv6 packet rate threshold for triggering DHCPv6 flood attack protection.
Use undo ipv6 dhcp flood-protection threshold to restore the default.
ipv6 dhcp flood-protection threshold packet-number milliseconds
The device allows a maximum of 10 DHCPv6 packets per 5000 milliseconds from each DHCPv6 client.
packet-number: Specifies the maximum number of DHCPv6 packets in the range of 2 to 200.
milliseconds: Specifies the DHCPv6 flood attack detection duration in milliseconds. The value range is 1000 to 30000.
The DHCPv6 flood attack protection enables the DHCPv6 device to detect DHCPv6 flood attacks according to the DHCPv6 packet rate threshold on a per-MAC basis. If the number of incoming DHCPv6 packets from the same MAC address reaches the upper limit in the detection duration, the client at that MAC address is launching a DHCPv6 flood attack.
# Configure the device to allow a maximum of two DHCPv6 packets per 9000 milliseconds from each DHCPv6 client.
[Sysname] ipv6 dhcp flood-protection threshold 2 9000
Use ipv6 dhcp interface-rate-suppression aging-time to set the aging time of interface-based DHCPv6 attack suppression entries.
Use undo ipv6 dhcp interface-rate-suppression aging-time to restore the default.
ipv6 dhcp interface-rate-suppression aging-time time
The aging time is 300 seconds for interface-based DHCPv6 attack suppression entries.
time: Specifies the aging time of interface-based DHCPv6 attack suppression entries, in seconds. The value range is 30 to 600.
When the aging time of a DHCPv6 attack suppression entry on an interface is reached, the device examines the packet receiving rate on the interface.
· If the packet receiving rate is lower than the suppression threshold, the device deletes the entry. If later a DHCPv6 packet arrives on that interface, the DHCPv6 server will create a new attack suppression entry and count the number of incoming DHCPv6 packets on that interface again.
· If the packet receiving rate reaches or exceeds the suppression threshold, the device resets the aging time.
This command takes effect only after you execute the ipv6 dhcp interface-rate-suppression enable command.
# Set the aging time to 90 seconds for interface-based DHCPv6 attack suppression entries.
[Sysname] ipv6 dhcp interface-rate-suppression aging-time 90
Use ipv6 dhcp interface-rate-suppression enable to enable DHCPv6 attack suppression on an interface.
Use undo ipv6 dhcp interface-rate-suppression enable to disable DHCPv6 attack suppression on an interface.
DHCPv6 attack suppression is disabled on an interface.
Interface view
When an interface enabled with this feature receives a DHCPv6 packet, the device creates a DHCPv6 attack suppression entry in check state for the interface. If the DHCP packet receiving rate on the interface reaches or exceeds the threshold, a DHCPv6 attack occurs on the interface. The suppression entry changes to the restrain state. To protect the CPU against DHCPv6 attack packets, the device limits the DHCPv6 packet receiving rate on the interface before the aging time of the suppression entry is reached.
# Enable DHCPv6 attack suppression on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp interface-rate-suppression enable
Use ipv6 dhcp interface-rate-suppression global enable to enable DHCPv6 attack suppression globally.
Use undo ipv6 dhcp interface-rate-suppression global enable to disable DHCPv6 attack suppression globally.
Global DHCPv6 attack suppression is disabled.
To enable DHCPv6 attack suppression on all interfaces, use this command.
DHCPv6 attack suppression protects an interface from DHCPv6 attacks by limiting the rate of incoming DHCPv6 packets after the specified threshold is crossed.
After you enable DHCPv6 attack suppression globally on all interfaces, the device creates a DHCPv6 attack suppression entry in check state for each interface and counts their incoming DHCPv6 packets. If the incoming DHCPv6 packet rate on an interface reaches or exceeds the threshold, the device determines that the interface is under a DHCPv6 attack. Then, it changes the suppression entry for the interface to the restrain state. To protect the CPU against DHCPv6 attacks, the device limits the incoming DHCPv6 packet rate on the interface until the suppression entry ages out.
You can enable DHCPv6 attack suppression globally by using the ipv6 dhcp interface-rate-suppression global enable command, or on a per-interface basis by using the ipv6 dhcp interface-rate-suppression enable command.
· DHCPv6 attack suppression takes effect on an interface as long as it is enabled globally or on the interface.
· To suppress DHCPv6 attacks only on some of the interfaces, you must disable DHCPv6 attack suppression globally, and then enable the feature on the desired interfaces.
# Enable DHCPv6 attack suppression globally.
[Sysname] ipv6 dhcp interface-rate-suppression global enable
Use ipv6 dhcp interface-rate-suppression threshold to set the DHCP packet rate threshold for triggering interface-based DHCP attack suppression.
Use undo ipv6 dhcp interface-rate-suppression threshold to restore the default.
ipv6 dhcp interface-rate-suppression threshold packet-number milliseconds
The device can receive a maximum of 3000 DHCPv6 packets per 5000 milliseconds on an interface.
packet-number: Specifies the maximum number of DHCP packets received on an interface, in the range of 2 to 6000.
milliseconds: Specifies the interface-based DHCP attack detection duration in milliseconds. The value range is 1000 to 10000.
A DHCP attack occurs on an interface if the DHCP packet receiving rate on the interface reaches or exceeds the threshold.
# Set the DHCP packet rate threshold to 2000 DHCP packets per 9000 milliseconds for triggering interface-based DHCP attack suppression.
[Sysname] ipv6 dhcp interface-rate-suppression threshold 2000 9000
ipv6 dhcp log enable
Use ipv6 dhcp log enable to enable DHCPv6 server logging.
Use undo ipv6 dhcp log enable to disable DHCPv6 server logging.
DHCPv6 server logging is disabled.
This command enables the DHCPv6 server to generate DHCPv6 logs and send them to the information center. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable this feature if the log generation affects the device performance or reduces the address and prefix allocation efficiency. For example, this situation might occur when a large number of clients frequently come online or go offline.
# Enable DHCPv6 server logging.
[Sysname] ipv6 dhcp log enable
ipv6 dhcp select
Use ipv6 dhcp select to enable the DHCPv6 server or DHCPv6 relay agent on an interface.
Use undo ipv6 dhcp select to restore the default.
ipv6 dhcp select { relay | server }
An interface does not work in the DHCPv6 server mode or in the DHCPv6 relay agent mode. It discards DHCPv6 packets from DHCPv6 clients.
Interface view
relay: Enables the DHCPv6 relay agent on the interface.
server: Enables the DHCPv6 server on the interface.
Before changing the DHCPv6 server mode to the DHCPv6 relay agent mode on an interface, use the following commands to remove IPv6 address/prefix bindings:
· reset ipv6 dhcp server ip-in-use
· reset ipv6 dhcp server pd-in-use
Do not configure the DHCPv6 client on the interface that has been configured as the DHCPv6 relay agent or DHCPv6 server.
# Enable the DHCPv6 server on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp select server
# Enable the DHCPv6 relay agent on Ten-GigabitEthernet 0/0/16.
[Sysname] interface ten-gigabitethernet 0/0/16
[Sysname-Ten-GigabitEthernet0/0/16] ipv6 dhcp select relay
Use ipv6 dhcp session-mismatch action to specify a DHCPv6 request processing method for roaming DHCPv6 clients.
Use undo ipv6 dhcp session-mismatch action to restore the default.
ipv6 dhcp session-mismatch action { fast-renew | roam }
The DHCPv6 device discards DHCPv6 address requests sent from roaming DHCPv6 clients.
Interface view
fast-renew: Releases existing IPv6 address or prefix leases for roaming clients and assigns new IPv6 addresses or prefixes to them.
roam: Assigns IPv6 addresses or prefixes to roaming clients based on their existing leases and renews the leases. This keyword is applicable only to IPoE users roaming among the interfaces that belong to the same roaming group.
This command is applicable only to IPoE networks.
When a DHCPv6 client roams in a network, the client sends an offline request to the DHCPv6 device (DHCPv6 server or relay agent) before requesting a new address or prefix. If the DHCPv6 device does not receive the offline request, it will discard the DHCPv6 client's new address or prefix request because it determines that the request is an attack packet.
This feature allows the DHCPv6 device to process address or prefix requests as follows upon receiving them from roaming DHCPv6 clients:
· If the fast-renew keyword is specified:
¡ The DHCPv6 server releases existing address or prefix leases of the roaming clients and assigns them new IP addresses or prefixes.
¡ The DHCPv6 relay agent informs the DHCPv6 server to release existing address or prefix leases of roaming clients and forwards the requests to the DHCPv6 server.
· If the roam keyword is specified:
¡ The DHCPv6 server assigns addresses to the roaming clients based on their existing address or prefix leases and renews the leases.
¡ The DHCPv6 relay agent forwards the requests of the roaming clients to the DHCPv6 server.
The roam keyword allows the clients to use the original IPv6 addresses or prefixes to access the network without another access authentication.
This feature might make online users go offline. Enable this feature for roaming DHCPv6 clients only when no DHCPv6 attacks exist in the network.
This command is mutually exclusive with the ipv6 dhcp server multi-ip per-mac enable command.
# On Ten-GigabitEthernet 0/0/15, configure the DHCPv6 server to use the fast-renew method for roaming clients.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp session-mismatch action fast-renew
ip subscriber roaming enable (BRAS Services Command Reference)
Use reset ipv6 dhcp flood-protection to delete DHCPv6 flood attack protection entries.
In standalone mode:
reset ipv6 dhcp flood-protection slot slot-number [ mac-address mac-address [ interface interface-type interface-number ] ] [ packet-statistics ]
In IRF mode:
reset ipv6 dhcp flood-protection chassis chassis-number slot slot-number [ mac-address mac-address [ interface interface-type interface-number ] ] [ packet-statistics ]
mac-address mac-address: Deletes DHCPv6 flood attack protection entries with the specified MAC address in the format of H-H-H. If you do not specify this option, the command deletes all DHCPv6 flood attack protection entries.
interface interface-type interface-number: Deletes DHCPv6 flood attack protection entries for the specified interface.
packet-statistics: Clears the packet statistics in the specified entries. If you do not specify this keyword, this command deletes the specified DHCPv6 flood attack protection entries.
If you do not specify any parameters, this command deletes all DHCPv6 flood attack protection entries on the device.
# (In standalone mode.) Delete all DHCPv6 flood attack protection entries on the specified slot.
<Sysname> reset ipv6 dhcp flood-protection slot 0
Use reset ipv6 dhcp interface-rate-suppression to delete interface-based DHCPv6 attack suppression entries.
In standalone mode:
reset ipv6 dhcp interface-rate-suppression slot slot-number [ interface interface-type interface-number ] [ packet-statistics ]
In IRF mode:
reset ipv6 dhcp interface-rate-suppression chassis chassis-number slot slot-number [ interface interface-type interface-number ] [ packet-statistics ]
interface interface-type interface-number: Deletes the DHCPv6 attack suppression entry for the specified interface.
packet-statistics: Clears packet statistics in the specified entries. If you do not specify this keyword, this command deletes the specified interface-based DHCPv6 attack suppression entries.
If you do not specify any parameters, this command deletes all interface-based DHCPv6 attack suppression entries on the device.
# (In standalone mode.) Delete all interface-based DHCPv6 attack suppression entries on the specified slot.
<Sysname> reset ipv6 dhcp interface-rate-suppression slot 0
Use reset ipv6 dhcp rate-limit to clear packet statistics for the DHCPv6 packet rate-limiting feature.
In standalone mode:
reset ipv6 dhcp rate-limit slot slot-number
In IRF mode:
reset ipv6 dhcp rate-limit chassis chassis-number slot slot-number
This command clears the DHCPv6 packet statistics collected for the DHCPv6 packet rate-limiting feature. You can enable that feature by using the ip subscriber dhcpv6 rate-limit command.
# (In standalone mode.) Clear packet statistics for the DHCPv6 packet rate-limiting feature on the specified slot.
<Sysname> reset ipv6 dhcp rate-limit slot 0
address-alloc-mode
Use address-alloc-mode to specify an IPv6 address mode for an IPv6 address pool.
Use undo address-alloc-mode to restore the default.
address-alloc-mode { eui-64 | interface-id }
The DHCPv6 server selects the first usable IPv6 address in the IPv6 address pool according to the IPv6 address allocation sequence.
eui-64: Specifies the EUI-64-based allocation mode.
interface-id: Specifies the interface ID-based allocation mode.
Some DHCPv6 networks require that interface identifiers in IPv6 addresses for users be generated by using the EUI-64 method for security and audit purposes. To meet such requirement, you must set the IPv6 address allocation mode to eui-64. After receiving a request from a client, the DHCPv6 server performs the following operations:
1. Selects the first usable IPv6 address according to the address allocation sequence.
2. Uses the MAC address of the client to generate an interface identifier by using the EUI-64 method.
3. Replaces the interface identifier in the selected address with the new interface identifier.
4. Assigns the IPv6 address to the DHCPv6 client.
A Windows 7 client determines the IPv6 global unicast address assigned by the DHCPv6 server is unusable if this address has a different interface ID than the client's link-local address. The client cannot use the assigned address as the source IP address of outgoing packets. To resolve this issue, set the IPv6 address allocation mode to interface-id. After receiving a request from a client, the DHCPv6 server generates an IPv6 address that has the same interface identifier as the source address of the request. The IPv6 address is then assigned to the client.
The IPv6 address allocation mode of an IPv6 address pool cannot be modified if IPv6 addresses in this address pool have been assigned to clients.
# Specify the EUI-64-based allocation mode for IPv6 address pool pool1.
[Sysname] ipv6 pool pool1
[Sysname-ipv6-pool-pool1] address-alloc-mode eui-64
address range
Use address range to specify a non-temporary IPv6 address range in an IPv6 address pool for dynamic allocation.
Use undo address range to restore the default.
address range start-ipv6-address end-ipv6-address [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
undo address range
No non-temporary IPv6 address range exists.
start-ipv6-address: Specifies the start IPv6 address.
end-ipv6-address: Specifies the end IPv6 address.
preferred-lifetime preferred-lifetime: Specifies the preferred lifetime for the non-temporary IPv6 addresses. The value range is 60 to 4294967295 seconds, and the default is 604800 seconds (7 days).
valid-lifetime valid-lifetime: Specifies the valid lifetime for the non-temporary IPv6 addresses. The value range is 60 to 4294967295 seconds, and the default is 2592000 seconds (30 days). The valid lifetime cannot be shorter than the preferred lifetime.
If you do not specify a non-temporary IPv6 address range, all unicast addresses on the subnet specified by the network command in address pool view are assignable. If you specify a non-temporary IPv6 address range, only the IPv6 addresses in the specified IPv6 address range are assignable.
You can specify only one non-temporary IPv6 address range in an address pool. If you execute this command multiple times, the most recent configuration takes effect.
The non-temporary IPv6 address range specified by the address range command must be on the subnet specified by the network command.
When you configure this command in an IPv6 address pool configured with the forbidden-address command, make sure the specified address range includes the excluded IPv6 addresses.
# Configure a non-temporary IPv6 address range from 3ffe:501:ffff:100::10 through 3ffe:501:ffff:100::31 in address pool 1.
[Sysname] ipv6 pool 1
[Sysname-ipv6-pool-1] network 3ffe:501:ffff:100::/64
[Sysname-ipv6-pool-1] address range 3ffe:501:ffff:100::10 3ffe:501:ffff:100::31
display ipv6 pool
network
temporary address range
aftr-name
Use aftr-name to specify an address family translation router (AFTR) domain name in an IPv6 address pool.
Use undo aftr-name to restore the default.
aftr-name aftr-name
undo aftr-name
No AFTR domain name is specified.
aftr-name: Specifies an AFTR domain name, a case-sensitive string of 1 to 61 characters.
You can specify only one AFTR domain name in an IPv6 address pool. If you execute this command multiple times, the most recent configuration takes effect.
# Specify AFTR domain name example.com in IPv6 address pool 1.
[Sysname-ipv6-pool-1] aftr-name example.com
allocate-new-ip enable
Use allocate-new-ip enable to enable random IPv6 address allocation.
Use undo allocate-new-ip enable to disable random IPv6 address allocation.
Random IPv6 address allocation is disabled.
By default, the DHCPv6 server tries to allocate the same IP address as the previous allocation to the same user.
With this feature enabled, the DHCPv6 server tries to allocate a new IP address to a user every time the user acquires an IP address. This feature is applicable to the scenarios where each user is identified by IP address. In such a network scenario, it is required that a user must obtain different IP addresses for each IP address acquisition.
Enable this feature on the DHCPv6 server with caution when it works in conjunction with a DHCPv6 relay agent that is located on an access device. In this situation, this feature might prevent access users from coming online again after an abnormal offline event.
If you execute both the allocate-new-ip enable and address-alloc-mode commands, the allocate-new-ip enable command does not take effect.
# Enable random IP address allocation.
[Sysname-ipv6-pool-1] allocate-new-ip enable
This command will enable random IPv6 address allocation. Continue? [Y/N]:
class pool
Use class pool to specify an IPv6 address pool for a DHCPv6 user class.
Use undo class pool to restore the default.
class class-name pool pool-name
undo class class-name pool
No IPv6 address pool is specified for a DHCPv6 user class.
DHCPv6 policy view
class-name: Specifies a DHCPv6 user class by its name, a case-insensitive string of 1 to 63 characters.
pool-name: Specifies an IPv6 address pool by its name, a case-insensitive string of 1 to 63 characters.
You can specify only one IPv6 address pool for a DHCPv6 user class in a DHCPv6 policy. If you execute this command multiple times for a user class, the most recent configuration takes effect.
# Specify IPv6 address pool pool1 for DHCPv6 user class test in DHCPv6 policy 1.
[Sysname] ipv6 dhcp policy 1
[Sysname-dhcp6-policy-1] class test pool pool1
default pool
ipv6 dhcp policy
ipv6 pool
default pool
Use default pool to specify the default IPv6 address pool.
Use undo default pool to restore the default.
default pool pool-name
undo default pool
No default IPv6 address pool is specified.
DHCPv6 policy view
In a DHCPv6 policy, the DHCPv6 server uses the default address pool to assign IPv6 address, IPv6 prefix, or other parameters to clients that do not match any user classes. If no default address pool is specified or the default address pool does not have assignable IPv6 addresses or prefixes, the assignment fails.
You can specify only one default address pool in a DHCPv6 policy. If you execute this command multiple times, the most recent configuration takes effect.
# Specify IPv6 address pool pool1 as the default IPv6 address pool in DHCPv6 policy 1.
[Sysname-dhcp6-policy-1] default pool pool1
class pool
ipv6 dhcp policy
display dhcpv6-access count
Use display dhcpv6-access count to display the number of DHCPv6 access users.
To display DHCPv6 access user information, use the display dhcpv6-access user-table command.
# Display the number of DHCPv6 access users on the device.
<Sysname> display dhcpv6-access count
Total access-user count: 20
Total access-user count |
Number of DHCPv6 access users. |
Use display dhcpv6-access packet statistics to display packet statistics for the DHCPv6 access module.
# Display packet statistics for the DHCPv6 access module.
<Sysname> display dhcpv6-access packet statistics
Received packets
Received from clients : 40
Solicit : 8
Request : 11
Renew : 0
Rebind : 14
Confirm : 0
Release : 7
Decline : 0
Info-Request : 0
Received from servers : 0
Advertise : 0
Reply : 0
Received invalid packets : 22
Sent packets
Sent to clients : 18
Advertise : 8
Reply : 10
Sent to servers : 0
Solicit : 0
Request : 0
Renew : 0
Rebind : 0
Confirm : 0
Release : 0
Decline : 0
Info-Request : 0
Table 5 Command output
Received packets |
Statistics about received packets. |
Received from clients |
Number of packets received from DHCPv6 clients. |
Solict |
Number of received Solict packets. |
Request |
Number of received Request packets. |
Renew |
Number of received Renew packets. |
Rebind |
Number of received Rebind packets. |
Confirm |
Number of received Confirm packets. |
Release |
Number of received Release packets. |
Decline |
Number of received Decline packets. |
Info-Request |
Number of received information-Request packets. |
Received from servers |
Number of packets received from DHCPv6 servers. |
Advertise |
Number of received Advertise packets. |
Reply |
Number of received Reply packets. |
Sent packets |
Statistics about sent packets. |
Sent to clients |
Number of packets sent to DHCPv6 clients. |
Advertise packets |
Number of sent Advertise packets. |
Reply |
Number of sent Reply packets. |
Sent to servers |
Number of packets sent to DHCPv6 servers. |
Solicit |
Number of sent Solicit packets. |
Request |
Number of sent Request packets. |
Renew |
Number of sent Renew packets. |
Rebind |
Number of sent Rebind packets. |
Confirm |
Number of sent Confirm packets. |
Release |
Number of sent Release packets. |
Decline |
Number of sent Decline packets. |
Info-Request |
Number of sent Information-Request packets. |
Use display dhcpv6-access user-table to display information about DHCPv6 access users.
display dhcpv6-access user-table [ index index-value | mac-address mac-address | user-id user-id ]
index index-value: Specifies a DHCPv6 user index in the range of 1 to 4294967294.
mac-address mac-address: Specifies the MAC address of a user, in the format of H-H-H.
user-id user-id: Specifies a user ID, in the range of 1 to fffffffe. The user ID is case insensitive.
# Display information about all DHCPv6 access users on the device.
<Sysname> display dhcpv6-access user-table
DHCP-ACCESS-USER-INFO-BRIEF(Total:3)
User ID : 0x40000001
User index : 1
Interface : Ten-GigabitEthernet0/0/15
SVLAN : N/A
CVLAN : N/A
User MAC address : 0002-0101-010C
DUID : 000200000d800001
User state : ONLINE
VPN instance : N/A
User IPv6 address : 1100::1
User IPv6 prefix : 2200::/64
IPv6 pool for address alloc : test_dhcp
IPv6 pool for prefix alloc : test_dhcp
Primary DNS server : 4534::2
Second DNS server : 4534::3
IA Type : IANA and IAPD
User ID : 0x40000002
User index : 2
Interface : Ten-GigabitEthernet0/0/16
SVLAN : N/A
CVLAN : N/A
User MAC address : 0002-0101-010D
DUID : 000200000d800002
User state : ONLINE
VPN instance : N/A
User IPv6 address : 1200::1
User IPv6 prefix : 2300::/64
IPv6 pool for address alloc : test_dhcp2
IPv6 pool for prefix alloc : test_dhcp3
User ID : 0x13
User index : 23
Interface : Ten-GigabitEthernet0/0/17
SVLAN : N/A
CVLAN : N/A
User MAC address : 0010-9400-0005
DUID : 000200000d800003
User state : WAIT_CLIENT_REQ
VPN instance : N/A
User IPv6 address : 220:220::3
User IPv6 prefix : N/A
IPv6 pool for address alloc : ipoe
IPv6 pool for prefix alloc : N/A
Primary DNS server : N/A
Second DNS server : N/A
User entry aging time : Mar 4 15:38:13 2021
Table 6 Command output
DHCP-ACCESS-USER-INFO-BRIEF(Total:x) |
Brief information about a DHCPv6 user, and the number of DHCPv6 users. |
User ID |
DHCPv6 user ID, in hexadecimal notation. |
User index |
DHCPv6 user index, in decimal notation. |
Interface from which the DHCPv6 user comes online. |
SVLAN |
SVLAN to which the DHCPv6 user belongs. If the user does not belong to any SVLAN, this field displays N/A. |
CVLAN |
CVLAN to which the DHCPv6 user belongs. If the user does not belong to any CVLAN, this field displays N/A. |
User MAC address |
MAC address of the DHCPv6 user. |
DUID |
DUID of the DHCPv6 user. |
User state |
Status of the DHCPv6 user: · INIT—Initial state. · WAIT_UCM_REQ_ACK—Expecting an acknowledgment from UCM. · WAIT_SERVER_ADVERTISE—Expecting an Advertise from the DHCPv6 server. · WAIT_CLIENT_REQ—Expecting a Request from the DHCP client. · WAIT_SERVER_REPLY—Expecting a Reply from the DHCPv6 server. · WAIT_UCM_UP_ACK—Expecting a lease acknowledgment from UCM. · ONLINE—Online status. · WAIT_UCM_OFFLINE_COMPLETE—Expecting an acknowledgment for lease release from UCM. · RENEW_WAIT_SERVER_REPLY—Expecting a lease renew reply from the DHCPv6 server. |
VPN instance |
VPN instance to which the DHCPv6 user belongs. If the user is on the public network, this field displays N/A. |
User IPv6 address |
IPv6 address that the DHCPv6 user has obtained. |
User IPv6 prefix |
IPv6 prefix that the DHCPv6 user has obtained. |
IPv6 pool for address alloc |
Name of the IPv6 address pool that assigns the IPv6 address to the user. |
IPv6 pool for prefix alloc |
Name of the IPv6 prefix pool that assigns the IPv6 prefix to the user. |
Primary DNS server |
IPv6 address of the primary DNS server. |
Second DNS server |
IPv6 address of the secondary DNS server. |
IA Type |
Obtained IA information type. · IANA—IA_NA type. · IAPD—IA_PD type. · IANA and IAPD—IA_NA type and IA_PD type. |
User entry aging time |
User entry aging time in the format of MM DD hh:mm:ss YYYY. · MM—Represents the month. · DD—Represents the day. · hh—Represents the hours. · mm—Represents the minutes. · ss—Represents the seconds. · YYYY—Represents the year. When the aging time of a user entry is reached, the DHCPv6 server deletes that user entry. When the DHCPv6 user is online, this field does not appear. |
Use display ipv6 dhcp address offline-record to display IPv6 address user offline records.
display ipv6 dhcp address offline-record [ ipv6-address ipv6-address | mac-address mac-address | start-time start-time start-date end-time end-time end-date | user-id user-id ]
ipv6-address ipv6-address: Specifies a user by its IPv6 address.
mac-address mac-address: Specifies a user by its MAC address.
start-time start-time start-date end-time end-time end-date: Displays the user offline records generated within the specified time range.
· start-time start-time start-date: Specifies the start date and time. The start-time argument represents the start time in HH:MM:SS (hour:minute:second) format, and its value range is 0:0:0 to 23:59:59. The start-date argument represents the start date in MM/DD/YYYY (month/day/year) or YYYY/MM/DD (year/month/day) format.
¡ MM—The value range is 1 to 12.
¡ DD—The value range varies by month.
¡ YYYY—The value range is 2000 to 2035.
· end-time end-time end-date: Specifies the end date and time. The end-time argument represents the end time in HH:MM:SS (hour:minute:second) format, and its value range is 0:0:0 to 23:59:59. The end-date argument represents the end date in MM/DD/YYYY (month/day/year) or YYYY/MM/DD (year/month/day) format.
user-id user-id: Specifies a user by its user ID. The user ID is a case-insensitive string in the range of 1 to fffffffe.
# Display IPv6 address user offline records.
<Sysname> display ipv6 dhcp address offline-record
DHCP-OFFLINE-RECORD-BRIEF(Total: 1)
Entry type: Address (Server Add)
IPv6 address: 1:1::1/128
MAC address: a20e-e7aa-0206
Access type: COMMON
Access interface: Ten-GigabitEthernet0/0/15
VPN instance: N/A
User ID: 0xffffffff
SVLAN: N/A
CVLAN: N/A
Offline time: Feb 28 20:42:04 2024
Online time: Feb 28 20:40:50 2024
Update time: Feb 28 20:40:50 2024
Offline reason: Received DHCPv6 Release message with IANA
Offline code: 46
Table 7 Command output
Entry type |
Type of the DHCPv6 entry: · Address (Relay Add)— Address lease entry on the DHCPv6 relay agent. · Address (Server Add) —Address lease entry on the DHCPv6 server. · Address Cinfo—Address Cinfo entry. · Address Reserve—Address reservation entry. · Address Static—Static address binding entry. |
IPv6 address |
IPv6 address of the user. If the user does not have an IPv6 address, this field displays N/A. |
MAC address |
MAC address of the user. If the user does not have an MAC address, this field displays N/A. |
Access type |
Access type of the user: · COMMON—DHCP user. · IPoE—IPoE user. · PPPoE—PPPoE user. · PPP-AUTH-IP—PPP authorization address user. · PKT-TRIGGER—Unknown-source user. · STATIC—IPoE static user. · SUBNET—IPoE subnet-leased user. |
Access interface |
Access interface to which the user is attached. If the user does not use an access interface, this field displays N/A. |
VPN inatance |
Name of the VPN instance to which the user belongs. If the user belongs to the public network, this field displays N/A. |
User ID |
Unique ID of the user in the UCM module. If the user does not have an ID, this field displays N/A. |
SVLAN |
Outer VLAN to which the DHCPv6 access user belongs. If the user does not belong to a VLAN, this field displays N/A. |
CVLAN |
Inner VLAN to which the DHCPv6 access user belongs. If the user does not belong to a VLAN, this field displays N/A. |
Offline time |
Time when the user went offline. |
Online time |
Time when the lease state of the user changed to Committed. If the time is an invalid value, this field will display N/A. |
Update time |
Time when the lease in Committed state was updated for the user. If the time is an invalid value, this field will display N/A. |
Offline reason |
Reason why the user went offline. |
Offline code |
Code of the reason why the user went offline. |
reset dhcp ipv6 address offline-record
display ipv6 dhcp pool-group-usage
Use display ipv6 dhcp pool-group-usage to display IPv6 resource usage information for an IPv6 pool group.
display ipv6 dhcp pool-group-usage [ pool-group pool-group-name ]
pool-group pool-group-name: Specifies an IPv6 pool group by its name. The pool-group-name argument is a case-insensitive string of 1 to 63 characters. If you do not specify this option, this command displays IPv6 resource usage information for all IPv6 pool groups.
# Display IPv6 resource usage information for all IPv6 pool groups.
<Sysname> display ipv6 dhcp pool-group-usage
Total number of IPv6 pool groups: 2
Pool group name: 1
Resource Type Total Used Utilization(%)
IPv6 address 91 1 39%
IPv6 prefix 245 1 1%
Pool group name: 1
# Display IPv6 resource usage information for IPv6 pool group poolgroup1.
<Sysname> display ipv6 dhcp pool-group-usage pool-roup poolgroup1
Pool group name: poolgroup1
Table 8 Command output
Total number of IPv6 pool groups |
Total number of IPv6 pool groups. |
Pool group name |
Name of the IPv6 pool group. |
Resource Type |
IPv6 resource type: · IPv6 address. · IPv6 prefix. |
Total |
Number of IPv6 addresses or prefixes in the IPv6 pool group. |
Used |
Number of assigned IPv6 addresses or prefixes in the IPv6 pool group. |
Utilization(%) |
Address or prefix usage of the IPv6 pool group, in percentage. |
display ipv6 dhcp pool-usage
Use display ipv6 dhcp pool-usage to display IPv6 resource usage information for an IPv6 pool.
display ipv6 dhcp pool-usage [ peak ] [ pool pool-name ]
peak: Displays peak resource usage information an IPv6 pool. The displayed value is the highest IPv6 resource usage of the pool before you execute this command. If you do not specify this keyword, this command displays the real-time IPv6 resource usage of the pool.
pool pool-name: Specifies an IPv6 pool by its name. The pool-name argument is a case-insensitive string of 1 to 63 characters. If you do not specify this option, this command displays IPv6 resource usage information for all IPv6 pools.
If the peak resource usage of an IPv6 pool appeared multiple times, this command displays the peak IPv6 resource usage that appeared earliest.
# Display resource usage information for all IPv6 pools.
<Sysname> display ipv6 dhcp pool-usage
Total number of IPv6 pools: 2
Pool name: 1
IPv6 address 787 254 32.27%
IPv6 prefix 101 1 1.00%
Srv6 locator 101 1 1.00%
Pool name: 2
IPv6 address 223 23 9.87%
IPv6 prefix 556 2 3.60%
# Display resource usage information for pool pool1.
<Sysname> display ipv6 dhcp pool-usage pool pool1
Pool name: pool1
IPv6 address 91 1 1.10%
IPv6 prefix 245 1 0.41%
# Display peak resource usage information for all IPv6 pools.
<Sysname> display ipv6 dhcp pool-usage peak
Pool name: 1
Resource Type Peak Utilization(%) Time
IPv6 address 32.27% Mar 11 07:22:43 2021
IPv6 prefix 1.00% Mar 12 08:10:23 2021
Srv6 locator 1.00% Mar 13 11:23:56 2021
Pool name: 2
IPv6 address 9.87% Mar 11 11:06:39 2021
IPv6 prefix 3.60% Mar 12 09:14:22 2021
# Display peak resource usage information pool pool1.
<Sysname> display ipv6 dhcp pool-usage peak pool pool1
Pool name: pool1
IPv6 address 1.10% Mar 11 10:33:32 2021
IPv6 prefix 0.41% Mar 12 07:22:20 2021
Table 9 Command output
Total number of IPv6 pools |
Total number of IPv6 pools. |
Pool name |
Name of the IP pool. |
IPv6 resource type: · IPv6 address. · IPv6 prefix. · SRv6 locator. |
Total |
Number of addresses, prefixes, or locators in the IPv6 address pool. |
Used |
Number of assigned addresses, prefixes, or locators in the IPv6 address pool. |
Utilization(%) |
Address, prefix or locator usage of the IPv6 pool, in percentage. |
Peak utilization(%) |
Peak address, prefix or locator usage of the IPv6 pool, in percentage. |
Time |
Date and time when the address, prefix or locator usage of the IPv6 pool reached the peak, in the format of MM DD hh:mm:ss YYYY. · MM—Represents the month. · DD—Represents the day. · hh—Represents the hours. · mm—Represents the minutes. · ss—Represents the seconds. · YYYY—Represents the year. |
reset ipv6 dhcp pool-usage peak
display ipv6 dhcp prefix offline-record
Use display ipv6 dhcp address offline-record to display IPv6 prefix user offline records.
display ipv6 dhcp prefix offline-record [ prefix prefix/prefix-len | mac-address mac-address | start-time start-time start-date end-time end-time end-date | user-id user-id ]
prefix prefix/prefix-len: Specifies a user by its IPv6 prefix and prefix length. The value range for the prefix-len argument is 1 to 128.
# Display IPv6 prefix user offline records.
<Sysname> display ipv6 dhcp prefix offline-record
Entry type: Prefix (Server Add)
IPv6 prefix: 2001:410::/48
Access type: COMMON
VPN instance: N/A
User ID: 0xffffffff
SVLAN: N/A
CVLAN: N/A
Offline time: Feb 28 20:59:22 2024
Online time: Feb 28 20:57:39 2024
Update time: Feb 28 20:57:44 2024
Offline reason: Release message notified to release prefix
Offline code: 453
Table 10 Command output
Type of the DHCPv6 entry: · Prefix (Relay Add)—Prefix lease entry on the DHCPv6 relay agent. · Prefix (Server Add)—Prefix lease entry on the DHCPv6 server. · Prefix Cinfo—Prefix Cinfo entry. · Prefix Reserve—Prefix reservation entry. · Prefix Static—Static prefix binding entry. |
IPv6 prefix |
IPv6 prefix of the user. If the user does not have an IPv6 address, this field displays N/A. |
MAC address |
Access type |
Access interface |
VPN inatance |
User ID |
SVLAN |
CVLAN |
Offline time |
Online time |
Update time |
Offline reason |
Offline code |
reset dhcp ipv6 prefix offline-record
display ipv6 dhcp option-group
Use display ipv6 dhcp option-group to display information about a DHCPv6 option group.
display ipv6 dhcp option-group [ option-group-number ]
option-group-number: Specifies a static or dynamic DHCPv6 option group by its ID. The value range for the option group ID is 1 to 100. If you do not specify an option group, this command displays information about all DHCPv6 option groups.
A static DHCPv6 option group is created by using the ipv6 dhcp option-group command.
A dynamic DHCPv6 option group is created automatically by a DHCPv6 client after it obtains the DHCPv6 configuration parameters. Dynamic option groups cannot be manually modified or deleted.
# Display information about all DHCPv6 option groups.
<Sysname> display ipv6 dhcp option-group
DHCPv6 option group: 1
DNS server addresses:
Type: Static
Interface: N/A
1::1
Type: Dynamic (DHCPv6 address allocation)
Interface: Ten-GigabitEthernet0/0/15
1::1
Domain name:
Type: Static
Interface: N/A
example.com
Domain name:
example.com
Options:
Code: 23
Type: Dynamic (DHCPv6 prefix allocation)
Length: 2 bytes
Hex: ABCD
DHCPv6 option group: 20
Type: Static
Interface: N/A
1::1
1::1
Domain name:
Type: Static
Interface: N/A
example.com
Domain name:
example.com
Options:
Code: 23
Length: 2 bytes
Hex: ABCD
Table 11 Command output
DHCPv6 option group |
ID of the DHCPv6 option group. |
Type |
Types of the DHCPv6 option: · Static—Parameter in a static DHCPv6 option group. · Dynamic (DHCPv6 address allocation)—Parameter in a dynamic DHCPv6 option group created during IPv6 address acquisition. · Dynamic (DHCPv6 prefix allocation)—Parameters in a dynamic DHCPv6 option group created during IPv6 prefix acquisition. · Dynamic (DHCPv6 address and prefix allocation)—Parameters in a dynamic DHCPv6 option group created during IPv6 address and prefix acquisition. |
Interface name. |
DNS server addresses |
IPv6 address of the DNS server. |
Domain name |
Domain name suffix. |
IPv6 address of the SIP server. |
SIP server domain names |
Domain name of the SIP server. |
Options |
Self-defined options. |
Code |
Code of the self-defined option. |
Length |
Self-defined option length in bytes. |
Hex |
Self-defined option content represented by a hexadecimal number. |
display ipv6 dhcp prefix-pool
Use display ipv6 dhcp prefix-pool to display information about a prefix pool.
display ipv6 dhcp prefix-pool [ prefix-pool-number ] [ vpn-instance vpn-instance-name ]
prefix-pool-number: Displays detailed information about a prefix pool specified by its number in the range of 1 to 128. If you do not specify a prefix pool, this command displays brief information about all prefix pools.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about prefix pools for the public network.
# Display brief information about all prefix pools.
<Sysname> display ipv6 dhcp prefix-pool
Prefix-pool Prefix Available In-use Static
1 5::/64 64 0 0
2 Not-available 0 0 0
11 21::/112(Zombie) 0 64 0
# Display detailed information about prefix pool 1.
<Sysname> display ipv6 dhcp prefix-pool 1
Prefix: 5::/64
Assigned length: 70
Total prefix number: 64
Available: 64
In-use: 0
Static: 0
Prefix: Not-available
Assigned length: 70
Total prefix number: 0
Available: 0
In-use: 0
Static: 0
Prefix: 5::/64(Zombie)
Assigned length: 70
Total prefix number: 10
Available: 0
In-use: 10
Static: 0
Table 12 Command output
Prefix-pool |
Prefix pool number. |
Prefix |
Prefix specified in the prefix pool. If the prefix is ineffective, this field displays Not-available. If the prefix becomes ineffective after a configuration recovery (for example, a switchover from the backup to the master), the prefix is marked (Zombie). |
Available |
Number of available prefixes. |
In-use |
Number of assigned prefixes. |
Static |
Number of statically bound prefixes. |
Assigned length |
Length of assigned prefixes. |
Total prefix number |
Number of prefixes. |
display ipv6 dhcp server
Use display ipv6 dhcp server to display DHCPv6 server configuration information.
display ipv6 dhcp server [ interface interface-type interface-number ]
interface interface-type interface-number: Displays DHCPv6 server configuration information for the specified interface. If you do not specify an interface, this command displays DHCPv6 server configuration information for all interfaces.
# Display DHCPv6 server configuration information for all interfaces.
<Sysname> display ipv6 dhcp server
Interface Pool
Ten-GigabitEthernet0/0/15 1
Ten-GigabitEthernet0/0/15 global
# Display DHCPv6 server configuration information for the interface Ten-GigabitEthernet 0/0/15.
<Sysname> display ipv6 dhcp server interface ten-gigabitethernet 0/0/15
Using pool: 1
Preference value: 0
Allow-hint: Enabled
Rapid-commit: Disabled
Table 13 Command output
Interface enabled with DHCPv6 server. |
Pool |
Address pool applied to the interface. If no address pool is applied to the interface, global is displayed. The DHCPv6 server selects a global address pool to assign a prefix, an address, and other configuration parameters to a client. |
Using pool |
Preference value |
Server preference in the DHCPv6 Advertise message. The value range is 0 to 255. The bigger the value is, the higher preference the server has. |
Allow-hint |
Indicates whether desired address/prefix assignment is enabled. |
Rapid-commit |
Indicates whether rapid address/prefix assignment is enabled. |
display ipv6 dhcp server conflict
Use display ipv6 dhcp server conflict to display information about IPv6 address conflicts.
display ipv6 dhcp server conflict [ address ipv6-address | interface interface-type interface-number ] [ vpn-instance vpn-instance-name ]
address ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays information about all IPv6 address conflicts.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 address conflict information for the public network.
The DHCPv6 server creates IP address conflict information in the following situations:
· The DHCPv6 client sends a DECLINE packet to the DHCPv6 server to inform the server of an IPv6 address conflict.
· The DHCPv6 server discovers that the only assignable address in the address pool is its own IPv6 address.
If you do not specify a parameter, this command displays information about all IPv6 address conflicts.
# Display information about all address conflicts.
<Sysname> display ipv6 dhcp server conflict
IPv6 address Detect time
2001::1 Apr 25 16:57:20 2019
1::1:2 Apr 25 17:00:10 2019
Table 14 Command output
IPv6 address |
Conflicting IPv6 address. If the IPv6 address is reusable, the command output displays (*). |
Detect time |
Time when the conflict was discovered. |
reset ipv6 dhcp server conflict
display ipv6 dhcp server database
Use display ipv6 dhcp server database to display information about DHCPv6 binding auto backup.
# Display information about DHCPv6 binding auto backup.
<Sysname> display ipv6 dhcp server database
File name : database.dhcp
Username :
Password :
Update interval : 600 seconds
Latest write time : Feb 8 16:02:23 2014
Status : Last write succeeded.
Table 15 Command output
File name |
Name of the DHCPv6 binding backup file. |
Username |
Username for accessing the URL of the remote backup file. |
Password |
Password for accessing the URL of the remote backup file. This field displays ****** if a password is configured. |
Update interval |
Waiting time in seconds after a DHCPv6 binding change for the DHCPv6 server to update the backup file. |
Latest write time |
Time of the latest update. |
Status |
Update state: · Writing—The backup file is being updated. · Last write succeeded—The backup file was successfully updated. · Last write failed—The backup file failed to be updated. |
display ipv6 dhcp server expired-ip
Use display ipv6 dhcp server expired-ip to display information about lease-expired IPv6 addresses.
display ipv6 dhcp server expired-ip [ [ address ipv6-address | interface interface-type interface-number ] [ vpn-instance vpn-instance-name ] | mac mac-address | pool pool-name ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays lease-expired IPv6 addresses for the public network.
mac mac-address: Specifies the MAC address of a lease.
pool pool-name: Specifies an IPv6 address pool by its name, a case-insensitive string of 1 to 63 characters.
verbose: Displays detailed information about lease-expired IPv6 addresses. If you do not specify this keyword, the command displays brief information about all lease-expired IPv6 addresses.
DHCPv6 assigns the expired IPv6 addresses to DHCPv6 clients when all available addresses have been assigned.
If you do not specify any parameters, this command displays brief information about all lease-expired IPv6 addresses on the public network.
# Display brief information about all lease-expired addresses.
<Sysname> display ipv6 dhcp server expired-ip
IPv6 address DUID Lease expiration
2001:3eff:fe80:4caa: 3030-3066-2e65-3230-302e- Apr 25 17:10:47 2019
37ee:7::1 3130-3234-2d45-7468-6572-
6e65-7430-2f31
# Display detailed information about all lease-expired IPv6 addresses.
<Sysname> display ipv6 dhcp server expired-ip verbose
IPv6 address: 2001:3eff:fe80:4caa:37ee:7::1
Pool name: 1
DUID: 3030-3066-2e65-3230-302e-3130-3234-2d45-7468-6572-6e65-7430-2f31
Hardware address type: Ethernet
Hardware address: 0000-0000-0002
Lease expiration: Apr 25 17:10:47 2019
Remaining reservation time: 136 years 2 months 6 hours 28 minutes 11 seconds
IPv6 address reservation mode: Based on client ID
Table 16 Command output
IPv6 address |
Expired IPv6 address. |
DUID |
Client DUID bound to the expired IPv6 address. |
Lease expiration |
Time when the lease expired. |
Pool name |
Name of the IPv6 address pool. |
Hardware address type |
Hardware address type of the client: · Ethernet. · Token ring. · Unknown. |
Hardware address |
Hardware address of the client. |
Remaining reservation time |
Remaining time for reserving the expired IPv6 address. |
IPv6 address reservation mode: Based on xx |
Expired IPv6 address reservation mode. |
ipv6 dhcp duid-mismatch offline
reset ipv6 dhcp server expired-ip
display ipv6 dhcp server expired-pd
Use display ipv6 dhcp server expired-pd to display information about lease-expired IPv6 prefixes.
display ipv6 dhcp server expired-pd [ [ interface interface-type interface-number | prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ] | mac mac-address | pool pool-name ] [ verbose ]
prefix prefix/prefix-len: Specifies a prefix and a prefix length. The value range for the prefix length is 1 to 128.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays lease-expired IPv6 prefixes for the public network.
verbose: Displays detailed information about lease-expired IPv6 prefixes. If you do not specify this keyword, the command displays brief information about all lease-expired IPv6 prefixes.
DHCPv6 assigns the expired IPv6 prefixes to DHCPv6 clients when all available prefixes have been assigned.
If you do not specify any parameters, this command displays brief information about all lease-expired IPv6 prefixes.
# Display brief information about all lease-expired IPv6 prefixes.
<Sysname> display ipv6 dhcp server expired-pd
IPv6 PD DUID Lease expiration
2:1::/24 3030-3066-2e65-3230-302e- Apr 25 17:10:47 2019
6e65-7430-2f31
# Display detailed information about all lease-expired IPv6 prefixes.
<Sysname> display ipv6 dhcp server expired-pd verbose
IPv6 PD: 2:1::/24
Pool name: 1
IPv6 prefix reservation mode: Based on DUID
Table 17 Command output
IPv6 PD |
Expired IPv6 prefix. |
DUID |
DUID of the expired IPv6 prefix. |
Lease expiration |
Pool name |
Name of the IPv6 address pool to which the expired IPv6 prefix belongs. |
Hardware address |
Remaining time for reserving the expired IPv6 prefix. |
IPv6 prefix reservation mode |
IPv6 prefix reservation mode: · Based on DUID. · Based on client MAC. |
reset ipv6 dhcp server expired-pd
display ipv6 dhcp server free-ip
Use display ipv6 dhcp server free-ip to display information about the idle IPv6 addresses in an IPv6 address pool.
display ipv6 dhcp server free-ip [ pool pool-name | vpn-instance vpn-instance-name ]
pool pool-name: Specifies an IPv6 address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool, this command displays information about all idle IPv6 addresses in IPv6 address pools.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about idle IPv6 addresses for the public network.
# Display information about all idle IPv6 addresses in IPv6 address pools.
<Sysname> display ipv6 dhcp server free-ip
Pool name: 1
Network: 2::/60
IPv6 ranges from 2::1 to 2::F:FFFF:FFFF:FFFF:FFFF
Pool name: 2
Network: 2::/125
IPv6 ranges from 2::/126 to 2::4/126
Pool name: 3
Network: 1::/125
IPv6 ranges from 1::/126 to 1::4/126
Table 18 Command output
Pool name |
Network |
Network segment that contains idle IPv6 address ranges. The value behind the forward slash represents the prefix length. |
IPv6 ranges from to |
IPv6 address ranges that contain idle IPv6 addresses. |
ipv6 pool
network
display ipv6 dhcp server free-pd
Use display ipv6 dhcp server free-pd to display information about the idle IPv6 prefixes in an IPv6 address pool.
display ipv6 dhcp server free-pd [ pool pool-name | vpn-instance vpn-instance-name ]
pool pool-name: Specifies an IPv6 address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool, this command displays information about all idle IPv6 prefixes in IPv6 address pools.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about idle IPv6 prefixes for the public network.
# Display information about all idle IPv6 prefixes in IPv6 address pools.
<Sysname> display ipv6 dhcp server free-pd
Prefix-pool: 1
Prefix: 2002::/64
IPv6 Prefix ranges from 2002::/68 to 2002::F000:0:0:0/68
Table 19 Command output
Pool name |
Prefix |
Prefix range that contains idle IPv6 prefixes. |
IPv6 Prefix ranges |
Idle IPv6 prefix sub-ranges. |
ipv6 pool
display ipv6 dhcp server free-srv6-locator
Use display ipv6 dhcp server free-srv6-locator to display information about the idle SRv6 locators in an IPv6 address pool.
display ipv6 dhcp server free-srv6-locator [ pool pool-name | vpn-instance vpn-instance-name ]
pool pool-name: Specifies an IPv6 address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool, this command displays information about all idle SRv6 locators in IPv6 address pools.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about idle SRv6 locators for the public network.
# Display information about all idle SRv6 locators in IPv6 address pools.
<Sysname> display ipv6 dhcp server free-srv6-locator
Pool name: 1
Prefix: 2002::/64
SRv6 Locator ranges from 2002::/68 to 2002::F000:0:0:0/68
Table 20 Command output
Pool name |
Prefix |
Idle SRv6 locator ranges. |
display ipv6 dhcp server ip-in-use
Use display ipv6 dhcp server ip-in-use to display DHCPv6 address bindings.
display ipv6 dhcp server ip-in-use [ [ address ipv6-address | interface interface-type interface-number ] [ vpn-instance vpn-instance-name ] | pool pool-name | pool-group pool-group-name ] [ verbose ]
address ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all DHCPv6 address bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCPv6 address bindings for the public network.
pool pool-name: Specifies an IPv6 address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool, this command displays DHCPv6 address bindings for all IPv6 address pools.
pool-group pool-group-name: Specifies an IPv6 address pool group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool group, this command displays DHCPv6 address bindings for all IPv6 address pool groups.
verbose: Displays detailed information about DHCPv6 address bindings. If you do not specify this keyword, this command displays brief information about DHCPv6 address bindings.
# Display all DHCPv6 address bindings.
<Sysname> display ipv6 dhcp server ip-in-use
Pool: 1
IPv6 address Type Lease expiration DUID
2:1::1 Auto(O) Jul 10 19:45:01 2021 0003000211df605b0300
Pool: 2
1:1::2 Static(F) Not available 0003000176e77e800100
Pool: 3
1:2::1F1 Static(O) Oct 9 09:23:31 2021 0003000154df605b0800
Pool: 4
1:2::2 Auto(Z) Oct 11 09:23:31 2021 0003000131df605b0100
# Display address binding information for IPv6 address pool 1.
<Sysname> display ipv6 dhcp server ip-in-use pool 1
Pool: 1
2:1::1 Auto(O) Jul 10 22:22:22 2021 0003000211df605b0300
3:1::2 Static(C) Jan 1 11:11:11 2021 0003000128df605b0700
# Display binding information for an IPv6 address.
<Sysname> display ipv6 dhcp server ip-in-use address 2:1::3
Pool: 1
Client: FE80::C800:CFF0:FE18:0
Type: Auto(O)
DUID: 03001094000001657468203
MAC : 0010-9400-0001
IAID: 0x00030001
IPv6 address: 2:1::3
Preferred lifetime 400, valid lifetime 500
Expires at Mar 19 09:45:01 2021 (288 seconds left)
Relay: 100::10
Table 21 Command output
Pool |
IPv6 address |
IPv6 address assigned. |
Type |
IPv6 address binding types: · Static(F)—Free static binding whose IPv6 address has not been assigned. · Static(O)—Offered static binding whose IPv6 address has been selected and sent by the DHCPv6 server in a DHCPv6-OFFER packet to the client in response to its Solicit message. · Static(C)—Committed static binding whose IPv6 address has been assigned to the client. · Auto(O)—Offered dynamic binding whose IPv6 address has been dynamically selected by the DHCPv6 server and sent in a DHCPv6-OFFER packet to the DHCPv6 client in response to its Solicit message. · Auto(C)—Committed dynamic binding whose IPv6 address has been dynamically assigned to the DHCPv6 client in response to its Request message or Solicit message that contains the Rapid Commit option. In the latter case, the server must be enabled with rapid address/prefix assignment. · Auto(Z)—Zombie dynamic binding whose IPv6 address has been dynamically assigned to the DHCPv6 client. The binding becomes zombie because the subnet prefix goes invalid for address allocation after a configuration recovery, for example, after a switchover from the backup to the master. |
Lease-expiration |
Time when the lease of the IPv6 address will expire. If the lease expires after the year 2100, this field displays Expires after 2100. For a free static binding, this field displays Not available. |
Client |
IPv6 link-local address of the DHCPv6 client. |
DUID |
Client DUID. |
MAC |
MAC address of the client. |
IAID |
Client IAID. For a free static binding without IAID specified, this field displays N/A. |
Preferred lifetime |
Preferred lifetime in seconds of the IPv6 address. |
valid lifetime |
Valid lifetime in seconds of the IPv6 address. |
Expires at |
Time when the lease of an IPv6 address will expire. If the lease expires after the year 2100, this field displays Expires after 2100. |
Relay |
IPv6 address of the DHCPv6 relay interface. This field displays N/A if no DHCPv6 relay agent exits. |
# Display detailed information about all DHCPv6 address bindings.
<Sysname> display ipv6 dhcp server ip-in-use verbose
Basic information:
Client ID: 0002-0000-0000-0300-01a2-0ee7-aa02-00
Hardware address: a20e-e7aa-0206
Lease expiration: Mar 29 20:40:50 2024
Type: Auto(C)
Pool: 1
Network: 1:1::/64
VPN instance name:
VPN instance index: 0
Primary DNS server: N/A
Secondary DNS server: N/A
IA Type: IANA
Access information:
Access type: CommonV6
User ID: -
Access Interface: Ten-GigabitEthernet0/0/15
Port: N/A
SVLAN/CVLAN: -/-
VSI Index: N/A
Link ID: N/A
UP-ID: N/A
UP-ID for RMDB: N/A
Virtual MAC: N/A
Unr tag: 0
Host name: N/A
Option125: N/A
Interaction information:
Gateway: N/A
Giaddr: -
Server-ID: N/A
Relay gateway: N/A
ODAP information:
Odap Pool group: N/A
Table 22 Command output
IPv6 address |
IPv6 address and prefix length assigned. |
Client ID |
Client ID. Client ID is a string of hexadecimal numbers, in which the first two characters represents the hardware type value. · If an ASCII string is used, the hardware type value is 00, which means no type. · If the hardware type is Ethernet, the type value is 01. · If the hardware type is token ring, the type value is 06. |
Hardware address |
Hardware address of the DHCPv6 client. |
Lease expiration |
Lease expiration time: · Exact time—Time when the lease will expire, for example, May 1 14:02:49 2015. · Not used—The IP address of the static binding has not been assigned to the client. · Unlimited—Infinite lease expiration time. · After 2100—The lease will expire after the year 2100. |
Type |
IPv6 address binding types: · Static(F)—Free static binding whose IPv6 address has not been assigned. · Static(O)—Offered static binding whose IPv6 address has been selected and sent by the DHCPv6 server to the client in response to its Solicit message. · Static(C)—Committed static binding whose IPv6 address has been assigned to the client. · Auto(O)—Offered dynamic binding whose IPv6 address has been dynamically selected by the DHCPv6 server and sent to the DHCPv6 client in response to its Solicit message. · Auto(C)—Committed dynamic binding whose IPv6 address has been dynamically assigned to the DHCPv6 client in response to its Request message or Solicit message that contains the Rapid Commit option. In the latter case, the server must be enabled with rapid address/prefix assignment. · Auto(Z)—Zombie dynamic binding whose IPv6 address has been dynamically assigned to the DHCPv6 client. The binding becomes zombie because the subnet prefix goes invalid for address allocation after a configuration recovery, for example, after a switchover from the backup to the master. |
Pool |
Name of the address pool to which the lease belongs. |
Network |
Network segment to which the lease belongs. |
VPN instance name |
Name of the VPN instance to which the lease belongs. |
VPN instance index |
Index of the VPN instance to which the lease belongs. |
IP address of the primary DNS server. |
Secondary DNS server |
IP address of the secondary DNS server. |
Online time |
Update time |
IA Type |
Obtained IA information type: · IANA—IA_NA type. · IATA—IA_TA type. |
Access type |
Access type of the user: · CommonV6—DHCPv6. · IPoEv6—IPoE. · PPPv6—PPP. |
User ID |
Unique ID of the user. This field displays a hyphen (-) if the user ID does not exist or if this device is the backup device in a VSRP group for node redundancy. |
Access interface |
Access interface to which the user is attached. |
Port |
Incoming port for packets. If packets are not received on a Layer 2 port, this field displays N/A. |
SVLAN/CVLAN |
Outer VLAN tag and inner VLAN tag contained in the client's DHCPv6 requests. If the request does not contain an inner or outer VLAN tag, this field displays a hyphen (-). |
VSI Index |
VSI name. |
UP-ID |
ID of the UP to which the user is attached. |
UP-ID for RMDB |
ID of the UP through which the user went online. The UP ID is stored in the RMDB. |
Virtual MAC |
Virtual MAC address of the user. |
Unr tag |
UNR tag. |
Host name |
Hostname (Option 12). |
Gateway |
Gateway address. |
Giaddr |
IPv6 address that the DHCPv6 relay agent uses for DHCPv6 packet relaying. The IPv6 address is recorded by the DHCPv6 server. |
Server ID |
DHCPv6 server ID. Only DHCPv6 relay agents support this field. |
Relay gateway |
DHCPv6 relay gateway addresses. |
ODAP pool group |
Name of the ODAPv6 address pool group to which the lease belongs. If the lease does not belong an ODAPv6 address pool group, this field displays N/A. |
display ipv6 dhcp server packet statistics
Use display ipv6 dhcp server packet statistics to display packet statistics on the DHCPv6 server.
display ipv6 dhcp server packet statistics [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCPv6 server packet statistics for the public network.
# Display packet statistics on the DHCPv6 server.
<Sysname> display ipv6 dhcp server packet statistics
Packets received: 0
Solicit: 0
Request: 0
Confirm: 0
Renew: 0
Rebind: 0
Release: 0
Decline: 0
Information-request: 0
Relay-forward: 0
Packets (non-ODAP) dropped: 0
ODAP Solicit: 0
ODAP Request: 0
ODAP Advertise: 0
ODAP Reply: 0
ODAP Release: 0
ODAP Renew: 0
ODAP ForceRenew: 0
ODAP Decline: 0
ODAP Rebind: 0
ODAP packets dropped: 0
Packets sent: 0
Advertise: 0
Reconfigure: 0
Reply: 0
Relay-reply: 0
ODAP Recv UpCpAddr: 0
ODAP Solicit: 0
ODAP Request: 0
ODAP Advertise: 0
ODAP Reply: 0
ODAP Release: 0
ODAP Renew: 0
ODAP ForceRenew: 0
ODAP Decline: 0
ODAP Rebind: 0
ODAP Send UpCpAddr: 0
Table 23 Command output
Packets received |
DHCPv6 messages received from clients: · Solicit · Request · Confirm · Renew · Rebind · Release · Decline · Information-request · Relay-forward · Packets (non-ODAP) dropped · ODAP Solicit · ODAP Request · ODAP Advertise · ODAP Reply · ODAP Release · ODAP Renew · ODAP ForceRenew · ODAP Decline · ODAP Rebind · ODAP packets dropped Since this field collects statistics about dropped ODAP packets and dropped non-ODAP packets, and those packets are part of received packets, the total number of received packets does not include that of dropped packets. |
Packets sent |
DHCPv6 messages sent to clients: · Advertise · Reconfigure · Reply · Relay-reply · ODAP Recv UpCpAddr · ODAP Solicit · ODAP Request · ODAP Advertise · ODAP Reply · ODAP Release · ODAP Renew · ODAP ForceRenew · ODAP Decline · ODAP Rebind · ODAP packets dropped · ODAP Send UpCpAddr |
reset ipv6 dhcp server packet statistics
display ipv6 dhcp server pd-in-use
Use display ipv6 dhcp server pd-in-use to display DHCPv6 prefix bindings.
display ipv6 dhcp server pd-in-use [ pool pool-name | pool-group pool-group-name | [ interface interface-type interface-number | prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ] ] [ verbose ]
pool pool-name: Specifies an IPv6 address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool, this command displays all DHCPv6 prefix bindings in IPv6 address pools.
pool-group pool-group-name: Specifies an IPv6 address pool group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool group, this command displays all DHCPv6 prefix bindings in IPv6 address pool groups.
prefix prefix/prefix-len: Specifies an IPv6 prefix. The value range for the prefix-len argument is 1 to 128. If you do not specify an IPv6 prefix, this command displays all DHCPv6 prefix bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCPv6 prefix bindings for the public network.
verbose: Displays detailed information about DHCPv6 prefix bindings. If you do not specify this keyword, this command displays brief information about DHCPv6 prefix bindings.
# Display all DHCPv6 prefix bindings.
<Sysname> display ipv6 dhcp server pd-in-use
Pool: 1
IPv6 prefix Type Lease expiration DUID
2:1::/24 Auto(O) Jul 10 19:45:01 2021 000300019a6ea1730100
Pool: 2
1:1::/64 Static(F) Not available 000300019a6ea1730100
Pool: 3
1:2::/64 Static(O) Oct 9 09:23:31 2021 000300019a6ea1730100
Pool: 4
12::/80 Auto(Z) Oct 17 09:34:59 2021 000300019a6ea1730100
# Display DHCPv6 prefix bindings for IPv6 address pool 1.
<Sysname> display ipv6 dhcp server pd-in-use pool 1
Pool: 1
2:1::/24 Auto(O) Jul 10 22:22:22 2021 000300019a6ea1730100
3:1::/64 Static(C) Jan 1 11:11:11 2021 000300019a6ea1730100
# Display binding information for prefix 2:1::3/24.
<Sysname> display ipv6 dhcp server pd-in-use prefix 2:1::3/24
Pool: 1
Client: FE80::C800:CFF:FE18:0
Type: Auto(O)
DUID: 00030001CA000C180000
MAC : 18d0-7255-0300
IAID: 0x00030001
IPv6 prefix: 2:1::/24
Relay: 100::10
Table 24 Command output
IPv6 prefix |
IPv6 prefix assigned. |
Type |
Prefix binding types: · Static(F)—Free static binding whose IPv6 prefix has not been assigned. · Static(O)—Offered static binding whose IPv6 prefix has been selected and sent by the DHCPv6 server in a DHCPv6-OFFER packet to the client in response to its Solicit message. · Static(C)—Committed static binding whose IPv6 prefix has been assigned to the client. · Auto(O)—Offered dynamic binding whose IPv6 prefix has been dynamically selected by the DHCPv6 server and sent in a DHCPv6-OFFER packet to the DHCPv6 client in response to its Solicit message. · Auto(C)—Committed dynamic binding whose IPv6 prefix has been dynamically assigned to the DHCPv6 client. · Auto(Z)—Zombie dynamic binding whose IPv6 prefix has been dynamically assigned to the DHCPv6 client. The binding becomes zombie because the prefix in the prefix pool goes invalid after a configuration recovery, for example, after a switchover from the backup to the master. |
Pool |
Address pool. |
Lease-expiration |
Time when the lease of the IPv6 prefix will expire. If the lease will expire after the year 2100, this field displays Expires after 2100. For a free static binding, this field displays Not available. |
Client |
DUID |
DUID of the DHCPv6 client. |
MAC |
MAC address of the DHCPv6 client. |
IAID |
Client IAID. For a free static binding without IAID, this field displays N/A. |
Preferred lifetime in seconds of the IPv6 prefix. |
valid lifetime |
Valid lifetime in seconds of the IPv6 prefix. |
Expires at |
Time when the lease of the prefix will expire. If the lease expires after the year 2100, this field displays Expires after 2100. |
Relay |
# Display detailed information about all DHCPv6 prefix bindings.
<Sysname> display ipv6 dhcp server pd-in-use verbose
Basic information:
IPv6 Prefix: 2001:410::/48
Type: Auto(C)
Pool: 1
Network: 1:1::/64
VPN instance name:
NBR ID: 0
IA Type: IAPD
Access information:
User ID: -
Port: N/A
SVLAN/CVLAN: -/-
VSI Index: N/A
Link ID: N/A
UP-ID: N/A
UP-ID for RMDB: N/A
Virtual MAC: N/A
Unr tag: 0
Host name: N/A
Option125: N/A
NBR ID: 0
Gateway: N/A
Giaddr: -
Server-ID: N/A
Relay gateway: N/A
ODAP information:
Table 25 Command output
IPv6 Prefix |
IPv6 prefix and prefix length assigned. |
Client-identifier |
Hardware address |
Lease expiration |
Type |
Prefix binding type: · Static(F)—Free static binding whose IPv6 prefix has not been assigned. · Static(O)—Offered static binding whose IPv6 prefix has been selected and sent by the DHCPv6 server in a DHCPv6-OFFER packet to the client in response to its Solicit message. · Static(C)—Committed static binding whose IPv6 prefix has been assigned to the client. · Auto(O)—Offered dynamic binding whose IPv6 prefix has been dynamically selected by the DHCPv6 server and sent in a DHCPv6-OFFER packet to the DHCPv6 client in response to its Solicit message. · Auto(C)—Committed dynamic binding whose IPv6 prefix has been dynamically assigned to the DHCPv6 client in response to its Request message or Solicit message that contains the Rapid Commit option. In the latter case, the server must be enabled with rapid address/prefix assignment. · Auto(Z)—Zombie dynamic binding whose IPv6 prefix has been dynamically assigned to the DHCPv6 client. The binding becomes zombie because the prefix in the prefix pool goes invalid after a configuration recovery, for example, after a switchover from the backup to the master. |
Pool |
Network |
VPN instance name |
Online time |
Update time |
NBR ID |
Routing neighbor ID. |
IA Type |
Obtained IA information type: · IAPD—IA_PD type. |
Access type |
Access type of the user: · CommonV6—DHCPv6. · IPoEv6—IPoE. · PPPv6—PPP. · NDRA-PD—Prefix assignment through neighbor discovery router advertisement (NDRA). |
User ID |
Access interface |
Port |
SVLAN/CVLAN |
VSI Index |
VSI name. |
UP-ID |
UP-ID for RMDB |
Virtual MAC |
Unr tag |
UNR tag. |
Host name |
Gateway |
Gateway address. |
Giaddr |
Server ID |
Relay gateway |
ODAP pool group |
reset ipv6 dhcp server pd-in-use
display ipv6 dhcp server srv6-locator-in-use
Use display ipv6 dhcp server srv6-locator-in-use to display SRv6 locator bindings.
display ipv6 dhcp server srv6-locator-in-use [ pool pool-name | [ interface interface-type interface-number | locator prefix/prefix-len ] [ vpn-instance vpn-instance-name ] ] [ verbose ]
pool pool-name: Specifies an IPv6 address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool, this command displays all SRv6 locator bindings in IPv6 address pools.
locator prefix/prefix-len: Specifies an SRv6 locator. The prefix argument specifies an IPv6 prefix, and the value range for the prefix-len argument is 1 to 128. If you do not specify an SRv6 locator, this command displays all SRv6 locator bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays SRv6 locator bindings for the public network.
verbose: Displays detailed information about SRv6 locator bindings. If you do not specify this keyword, this command displays brief information about SRv6 locator bindings.
# Display all SRv6 locator bindings.
<Sysname> display ipv6 dhcp server srv6-locator-in-use
Pool: 1
Srv6 locator Type Lease expiration DUID
2001::/96 Auto(C) Dec 26 14:58:02 2024 00010001000000000a00
# Display the SRv6 locator bindings in IPv6 address pool pool1.
<Sysname> display ipv6 dhcp server srv6-locator-in-use pool 1
Pool: 1
# Display binding information for the specified SRv6 locator.
<Sysname> display ipv6 dhcp server srv6-locator-in-use locator 2:1::/24
Pool: 1
Type: Auto(C)
IAID: 0x00030001
SRv6 locator: 2:1::/24
Expires at Dec 26 14:58:02 2024 (2590102 seconds left)
Relay: 100::10
Table 26 Command output
SRv6 locator |
Assigned SRv6 locator. |
Type |
SRv6 locator binding type: · Static(F)—Free static binding whose SRv6 locator has not been assigned. · Static(O)—Offered static binding whose SRv6 locator has been selected and sent by the DHCPv6 server in a DHCPv6-OFFER packet to the client in response to its Solicit message. · Static(C)—Committed static binding whose SRv6 locator has been assigned to the client. · Auto(O)—Offered dynamic binding whose SRv6 locator has been dynamically selected by the DHCPv6 server and sent in a DHCPv6-OFFER packet to the DHCPv6 client in response to its Solicit message. · Auto(C)—Committed dynamic binding whose SRv6 locator has been dynamically assigned to the DHCPv6 client in response to its Request message or Solicit message that contains the Rapid Commit option. In the latter case, the server must be enabled with rapid address/prefix assignment. · Auto(Z)—Zombie dynamic binding whose SRv6 locator has been dynamically assigned to the DHCPv6 client. The binding becomes zombie because the SRv6 locator in the prefix pool goes invalid after a configuration recovery, for example, after a switchover from the backup to the master. |
Pool |
Name of the address pool to which the SRv6 locator belongs. |
Client |
IPv6 link-local address of the DHCPv6 client. This field is blank for free static bindings or for bindings on an ODAP server. |
DUID |
MAC |
IAID |
Preferred lifetime in seconds of the SRv6 locator. |
valid lifetime |
Valid lifetime in seconds of the SRv6 locator. |
Expires at |
Time when the lease of the SRv6 locator will expire. |
Relay |
IPv6 address of the DHCPv6 relay interface. This field displays N/A if no DHCPv6 relay agent exists. |
# Display detailed information about all SRv6 locator bindings.
<Sysname> display ipv6 dhcp server srv6-locator-in-use verbose
Basic information:
SRv6 Locator: 2001:410::/48
Type: Auto(C)
Pool: 1
Network: 1:1::/64
VPN instance name:
NBR ID: 0
IA Type: IALOCATOR
Access information:
User ID: -
Port: N/A
SVLAN/CVLAN: -/-
VSI Index: N/A
Link ID: N/A
UP-ID: N/A
UP-ID for RMDB: N/A
Virtual MAC: N/A
Unr tag: 0
Host name: N/A
Option125: N/A
NBR ID: 0
Gateway: N/A
Giaddr: -
Server-ID: N/A
Relay gateway: N/A
ODAP information:
Table 27 Command output
SRv6 Locator |
Client ID |
Hardware address |
Lease expiration |
Type |
SRv6 locator binding type: · Static(F)—Free static binding whose SRv6 locator has not been assigned. · Static(O)—Offered static binding whose SRv6 locator has been selected and sent by the DHCPv6 server in a DHCPv6-OFFER packet to the client in response to its Solicit message. · Static(C)—Committed static binding whose SRv6 locator has been assigned to the client. · Auto(O)—Offered dynamic binding whose SRv6 locator has been dynamically selected by the DHCPv6 server and sent in a DHCPv6-OFFER packet to the DHCPv6 client in response to its Solicit message. · Auto(C)—Committed dynamic binding whose SRv6 locator has been dynamically assigned to the DHCPv6 client in response to its Request message or Solicit message that contains the Rapid Commit option. In the latter case, the server must be enabled with rapid address/prefix assignment. · Auto(Z)—Zombie dynamic binding whose SRv6 locator has been dynamically assigned to the DHCPv6 client. The binding becomes zombie because the SRv6 locator in the SRv6 locator pool goes invalid after a configuration recovery, for example, after a switchover from the backup to the master. |
Pool |
Network |
VPN instance name |
Online time |
Update time |
NBR ID |
Obtained IA information type: · IALOCATOR—IA_LOCATOR type. |
Access type |
User ID |
Access interface |
Port |
SVLAN/CVLAN |
VSI Index |
VSI name. |
UP-ID |
UP-ID for RMDB |
Virtual MAC |
Unr tag |
UNR tag. |
Host name |
Gateway |
Gateway address. |
Giaddr |
Server-ID |
Relay gateway |
ODAP pool group |
reset ipv6 dhcp server srv6-locator-in-use
display ipv6 dhcp server statistics
Use display ipv6 dhcp server statistics to display statistics on the DHCPv6 server.
display ipv6 dhcp server statistics [ pool pool-name | vpn-instance vpn-instance-name ]
pool pool-name: Displays DHCPv6 packet statistics for the IPv6 address pool specified by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an address pool, this command displays DHCPv6 server statistics for all address pools.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCPv6 server statistics for the public network.
If you do not specify a parameter, this command displays statistics for all IPv6 pools on the DHCPv6 server.
# Display pool statistics on the DHCPv6 server.
<Sysname> display ipv6 dhcp server statistics
Pool number: 3
Bindings:
IP-in-use: 1
PD-in-use: 0
Expired IP: 0
Expired PD: 0
Reserve IP: 0
Reserve PD: 0
SRv6-locator-in-use: 0
Conflicts: 0
# Display statistics for IPv6 address pool pool1.
<Sysname> display ipv6 dhcp server statistics pool pool1
Total IPv6 addresses: 255
Free IPv6 addresses: 235
Used IPv6 addresses: 20
Pool IPv6 address utilization: 7.84%
Total IPv6 prefixes: 0
Free IPv6 prefixes: 0
Used IPv6 prefixes: 0
Pool IPv6 prefix utilization: 0.00%
Total SRv6 locators: 0
Free SRv6 locators: 0
Used SRv6 locators: 0
Pool SRv6 locator utilization: 0.00%
Bindings:
IP-in-use: 0
PD-in-use: 0
Expired IP: 0
Expired PD: 0
Reserve IP: 0
Reserve PD: 0
Conflicts: 0
Table 28 Command output
Pool number |
Total number of IPv6 address pools. |
Total IPv6 addresses |
Total number of IPv6 addresses. |
Free IPv6 addresses |
Number of free IPv6 addresses. |
Used IPv6 addresses |
Number of assigned IPv6 addresses in the address pool. |
Pool IPv6 address utilization |
IPv6 address usage of the address pool. |
Total SRv6 locators |
Total number of SRv6 locators in the IPv6 address pool. |
Free SRv6 locators |
Number of free SRv6 locators in the IPv6 address pool. |
Used SRv6 locators |
Number of assigned SRv6 locators in the IPv6 address pool. |
Pool SRv6 locator utilization |
SRv6 locator usage of the IPv6 address pool. |
Total IPv6 prefixes |
Number of prefixes in the IPv6 address pool. |
Free IPv6 prefixes |
Number of available prefixes in the IPv6 address pool. |
Used IPv6 prefixes |
Number of assigned prefixes in the IPv6 address pool. |
Pool IPv6 prefix utilization |
IPv6 prefix usage of the address pool. |
Bindings |
Number of bindings: · IP-in-use—Total number of IPv6 address bindings. · PD-in-use—Total number of prefix bindings. · Expired IP—Total number of expired IPv6 address bindings. · Expired PD—Total number of expired prefix bindings. · Reserve IP—Total number of reserved IPv6 address bindings. · Reserve PD—Total number of reserved prefix bindings. · SRv6-locator-in-use—Total number of SRv6 locator bindings. |
Conflicts |
Total number of conflicting addresses. |
reset ipv6 dhcp server statistics
display ipv6 dhcp srv6-locator offline-record
Use display ipv6 dhcp srv6-locator offline-record to display SRv6 locator user offline records.
display ipv6 dhcp srv6-locator offline-record [ locator prefix/prefix-len | mac-address mac-address | start-time start-time start-date end-time end-time end-date | user-id user-id ]
locator prefix/prefix-len: Specifies a user by its SRv6 locator. The prefix argument specifies an IPv6 prefix, and the value range for the prefix-len argument is 1 to 128.
# Display SRv6 locator user offline records.
<Sysname> display ipv6 dhcp srv6-locator offline-record
Entry type: SRv6-Locator (Server Add)
Access type: COMMON
VPN instance: N/A
User ID: 0xffffffff
SVLAN: N/A
CVLAN: N/A
Offline code: 453
Table 29 Command output
Entry type |
Type of the DHCPv6 entry: · SRv6-Locator (Relay Add)—SRv6 locator lease entry on the DHCPv6 relay agent. · SRv6-Locator (Server Add)—SRv6 locator lease entry on the DHCPv6 server. |
IPv6 prefix |
SRv6 locator of the user. If the user does not have an IPv6 address, this field displays N/A. |
MAC address |
Access type |
Access type of the user: · COMMON—DHCPv6 user. |
Access interface |
VPN inatance |
User ID |
SVLAN |
CVLAN |
Offline time |
Online time |
Update time |
Offline reason |
Offline code |
reset dhcp ipv6 srv6-locator offline-record
display ipv6 pool
Use display ipv6 pool to display information about IPv6 address pools.
display ipv6 pool [ all | name pool-name | pool-group pool-group-name | vpn-instance vpn-instance-name ] [ verbose ]
all: Displays information about all IPv6 pools in the public network and VPN instances.
name pool-name: Specifies an IPv6 address pool by its name. The pool-name argument is a case-insensitive string of 1 to 63 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 address pools on the public network.
verbose: Displays detailed IPv6 pool information. If you do not specify this keyword, the command displays brief IPv6 pool information.
# Display brief information about IPv6 address pool 1.
<Sysname> display ipv6 pool name 1
DHCPv6 pool: 1 (lock)
Pool index: 1
Pool type: Common
VPN instance:
N/A
Network: 3FFE:501:FFFF:100::/64
Preferred lifetime 604800 seconds, valid lifetime 2592000 seconds
Prefix pool: 1
Preferred lifetime 24000 seconds, valid lifetime 36000 seconds
Gateway list:
3FFE:501:FFFF:100::100/64
Addresses:
Range: from 3FFE:501:FFFF:100::1
to 3FFE:501:FFFF:100::99
Preferred lifetime 70480, valid lifetime 200000
Total address number: 153
Available: 153
In-use: 0
Temporary addresses:
Range: from 3FFE:501:FFFF:100::200
to 3FFE:501:FFFF:100::210
Preferred lifetime 60480, valid lifetime 259200
Total address number: 17
Available: 17
In-use: 0
Static bindings:
DUID: 0003000100e0fc000001
IAID: 0000003f
Prefix: 3FFE:501:FFFF:200::/64
Preferred lifetime 604800, valid lifetime 2592000
DUID: 0003000100e0fc00cff1
IAID: 00000001
Address: 3FFE:501:FFFF:2001::1/64
Forbidden addresses:
1571::1
1571::8 1571::65
Forbidden prefixes:
1800::11/64
1800::22/64 1800::25/64
unr tag 50
unr preference 60
IP-in-use threshold: 50
PD-in-use threshold: 50
option 21 hex 21
2::2
Domain name:
aaa.example.com
AFTR name:
bbb.example.com
SIP server addresses:
5::1
SIP server domain names:
ccc.com
exhaustion log enable
route-log enable
undo exhaustion trap enable
address-alloc-mode interface-id
undo allocate-new-ip enable
# Display brief information about IPv6 address pool 2.
<Sysname> display ipv6 pool name 2
DHCPv6 pool: 2 (lock)
Pool index: 2
Pool type: Common
VPN instance:
N/A
dhcpv6-relay source-address gateway
reserve expired-ipv6-address enable
reserve expired-ipv6-address mode duid time 4294967295 limit 256000
reserve expired-pd disable
reserve expired-pd mode duid time 4294967295 limit 256000
SRv6 locator pool: 2
IP-in-use threshold: 100
PD-in-use threshold: 100
undo exhaustion log enable
route-log enable
# Display brief information about a local BAS IPv6 address pool.
<Sysname> display ipv6 pool name bas6
DHCPv6 pool: bas6
Pool index: 3
Pool type: Bas local
VPN instance:
N/A
undo route-log enable
Table 30 Command output
DHCPv6 pool (lock) |
Name of the IPv6 address pool. The field in parentheses represents the lock state of the IPv6 pool. · lock—Locked in loose mode. The server responds to the lease renewal requests from online DHCPv6 clients for IPv6 addresses in the pool, but it does not assign IPv6 addresses from the pool to new DHCPv6 clients. · lock strict—Locked in strict mode. The server does not respond to the lease renewal requests from online DHCPv6 clients for IPv6 addresses in the pool or assign IPv6 addresses from the pool to new DHCPv6 clients. If you do not lock the IPv6 pool, this command will not display lock state information. |
Pool index |
Index of the IPv6 address pool. |
Pool type |
Type of the IPv6 address pool. |
VPN instance to which the IPv6 address pool belongs. If the IPv6 address pool belongs to the public network, this field displays N/A. |
Network |
IPv6 subnet for dynamic IPv6 address allocation. If the subnet prefix is ineffective, this field displays Not-available. If the subnet prefix becomes ineffective after a configuration recovery (for example, a switchover from the backup to the master), the prefix is marked (Zombie). |
Index of the prefix pool used by the address pool. |
SRv6 locator pool |
Index of the SRv6 locator pool used by the address pool. |
Preferred lifetime in seconds. |
valid lifetime |
Valid lifetime in seconds. |
dhcpv6-relay source-address xxx |
Source IPv6 address for relayed DHCPv6 requests. Supported values for the xxx argument include: · ipv6-address—An IPv6 address is specified as the source IPv6 address. · gateway—The IP address in the Link-address field of DHCPv6 requests is specified as the source IPv6 address. If the Link-address field is empty, the DHCPv6 relay agent uses the default settings to determine the source IPv6 address. · interface interface-type interface-number—The IPv6 address of an interface is specified as the source IPv6 address. |
reserve expired-ipv6-address enable |
Whether IPv6 address reservation is enabled. · reserve expired-ipv6-address enable—IPv6 address reservation is enabled. · reserve expired-ipv6-address disable—IPv6 address reservation is disabled. |
reserve expired-ipv6-address mode duid/mac time 4294967295 limit 256000 |
IPv6 address reservation mode, amount of time for expired IPv6 addresses to be reserved, and the maximum number of IPv6 addresses that can be reserved in the IPv6 pool. In this example, the reservation mode is DUID or MAC address, the amount of reservation time is 4294967295 seconds, and the maximum number of IP addresses is 256000. |
reserve expired-pd disable |
Whether IPv6 prefix reservation is enabled. · reserve expired-pd enable—IPv6 prefix reservation is enabled. · reserve expired-pd disable—IPv6 prefix reservation is disabled. |
reserve expired-pd mode duid/mac time 4294967295 limit 256000 |
IPv6 prefix reservation mode, amount of time for expired IPv6 prefixes to be reserved, and the maximum number of IPv6 prefixes that can be reserved in the IPv6 pool. In this example, the reservation mode is DUID or MAC address, the amount of reservation time is 4294967295 seconds, and the maximum number of IP addresses is 256000. |
Gateway list |
Gateway addresses specified for clients that match the IPv6 address pool. |
Non-temporary IPv6 address range. |
Range |
IPv6 address range for dynamic allocation. |
Total address number |
Available |
Total number of available IPv6 addresses. |
In-use |
Total number of assigned IPv6 addresses. |
Temporary addresses |
Temporary IPv6 address range for dynamic allocation. |
Static bindings |
Static bindings configured in the address pool. |
DUID |
Client DUID. |
IAID |
Client IAID. If no IAID is configured, this field displays Not configured. |
Prefix |
IPv6 address prefix. |
Address |
Static IPv6 address. |
Forbidden addresses |
IPv6 addresses excluded from DHCP allocation. |
Forbidden prefixes |
IPv6 prefixes excluded from DHCP allocation. |
unr tag |
IPv6 UNR tag value for the IPv6 address pool. |
unr preference |
IPv6 UNR preference value for the IPv6 address pool. |
IPv6 address usage threshold for the IPv6 address pool. |
PD-in-use threshold |
IPv6 prefix usage threshold for the IPv6 address pool. |
option |
User-defined DCHPv6 option of the IPv6 address pool. |
DNS server address. |
Domain name |
Domain name. |
AFTR name |
AFTR domain name. |
active remote server |
This field is available only after you create a remote BAS IPv6 pool on the relay agent and use the remote-server command to specify remote DHCPv6 servers for that pool. · If this field displays all, the relay agent uses the poll algorithm for DHCPv6 server selection. It forwards DHCPv6 requests to all DHCPv6 servers at the same time. · If this field displays an IPv6 address, the relay agent uses the master-backup algorithm for DHCPv6 server selection. It forwards DHCPv6 requests to the active DHCPv6 server that uses the displayed IPv6 addresses. For more information about DHCPv6 server selection algorithms, see the remote-server algorithm command. |
remote server pool status |
Status of the remote BAS IPv6 pool. · Available—The pool has assignable IPv6 addresses. · Unavailable—The pool has no assignable IPv6 addresses. |
SIP server addresses |
Addresses of SIP servers. |
Domain names of SIP servers. |
IPv6 resource exhaustion logging is enabled to record IPv6 resource exhaustion events or recoveries from the resource exhaustion state. If this feature is disabled, this field displays undo exhaustion log enable. |
route-log enable |
Route logging is enabled for the IPv6 address pool. If route logging is disabled, this field displays undo route-log enable. |
IPv6 resource exhaustion alarming is enabled. If this feature is disabled, this field displays undo exhaustion trap enable. |
address-alloc-mode |
IPv6 address mode specified for the IPv6 address pool: · eui-64—EUI-64-based allocation. · interface-id—interface ID-based allocation. |
undo allocate-new-ip enable |
Random IPv6 address allocation is disabled. If this feature is enabled, this field displays allocate-new-ip enable. |
# Display detailed information about all pools.
<Sysname> display ipv6 pool verbose
DHCPv6 pool: pool1 (lock)
Pool index: 1
Pool type: Common
VPN instance:
N/A
Network: 3001::/96
SRv6 locator pool: 1
Static bindings:
DUID: 0003000100e0fc005552
IAID: Not configured
Prefix: 10::/64
option 21 hex 21
route-log enable
IPv6 address statistics
Total IPv6 addresses: 0
Free IPv6 addresses: 0
Used IPv6 addresses: 0
Pool IPv6 address utilization: 0.00%
Total SRV6 locators: 4294967295
Free SRV6 locators: 4294967295
Used SRV6 locators: 0
Bindings:
IP-in-use: 0
PD-in-use: 0
Expired IP: 0
Expired PD: 0
Reserve IP: 0
Reserve PD: 0
Conflicts: 0
Pool index |
Pool type |
VPN instance |
Network |
valid lifetime |
Static bindings |
Static bindings configured in the IPv6 pool. |
DUID |
Client DUID. |
IAID |
Prefix |
IPv6 prefix. |
route-log enable |
IPv6 address statistics |
IPv6 address statistics in the IPv6 address pool. |
Total number of IPv6 addresses in the IPv6 address pool. |
Number of free IPv6 addresses in the IPv6 address pool. |
Number of assigned IPv6 addresses in the IPv6 address pool. |
Address usage of the IPv6 address pool. |
Total number of IPv6 prefixes in the IPv6 address pool. |
Number of free IPv6 prefixes in the IPv6 address pool. |
Number of assigned IPv6 prefixes in the IPv6 address pool. |
Prefix usage of the IPv6 address pool. |
Number of bindings by binding type: · IP-in-use—Total number of IPv6 address bindings. · PD-in-use—Total number of prefix bindings. · Expired IP—Total number of expired IPv6 address bindings. · Expired PD—Total number of expired prefix bindings. · Reserve IP—Total number of reserved IPv6 address bindings. · Reserve PD—Total number of reserved prefix bindings. · SRv6-locator-in-use—Total number of SRv6 locator bindings. |
Conflicts |
ipv6 pool
display ipv6 pool-group
Use display ipv6 pool-group to display information about IPv6 pool groups.
display ipv6 pool-group [ all | [ name pool-group-name ] [ vpn-instance vpn-instance-name ] ] [ verbose ]
all: Displays information about all IPv6 pool groups and all IPv6 pools in these groups in the public network and VPN instances.
name pool-group-name: Specifies an IPv6 address pool group name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all IPv6 pool groups.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about IPv6 pool groups on the public network.
verbose: Displays detailed information about IPv6 pool groups and their IPv6 pools. If you do not specify this keyword, the command displays brief information about IPv6 pool groups and their IPv6 pools.
# Display information about IPv6 address pool group group1.
<Sysname> display ipv6 pool-group name group1
Pool-group: group1
VPN instance name: abc
Current DHCPv6 address pool: N/A
Current DHCPv6 prefix pool: N/A
Ip-in-use threshold: 100
Undo Exhaustion trap enable
Undo Exhaustion log enable
Current DHCPv6 relay IPv6 pool: N/A
Static bindings: 0
Bind pools: 1
pool2 priority 1
# Display information about all IPv6 address pool groups on the public network.
Pool-group: group2
VPN instance name: N/A
Static bindings: 0
Bind pools: 2
Pool3 priority 2
Pool4 priority 3
Pool-group: group3
Static bindings: 0
Bind pools: 3
Pool4 priority 4
Pool5 priority 5
Pool6 priority 6
Table 32 Command output
Pool-group |
Name of the DHCPv6 address pool group. |
VPN instance name |
Name of the VPN instance to which the IPv6 address pool group is applied. This field displays N/A if the IPv6 address pool group is on the public network. |
Number of allocated IPv6 addresses in the address pool group. |
Number of allocated IPv6 prefixes in the IPv6 address pool group. |
Current DHCPv6 address pool |
IPv6 address pool that is currently used for IPv6 address allocation in the pool group. If the pool group does not have any IPv6 address pools, this field displays N/A. |
Current DHCPv6 prefix pool |
IPv6 address pool that is currently used for IPv6 prefix allocation in the pool group. If the pool group does not have any IPv6 address pools, this field displays N/A. |
Address usage threshold for the IPv6 address pool group, in percentage. |
Undo exhaustion trap enable |
IPv6 resource exhaustion alarming is disabled for the IPv6 address pool group. If this feature is enabled, this field displays Exhaustion trap enable. |
Undo exhaustion log enable |
IPv6 resource exhaustion logging is disabled for the IPv6 address pool group. If this feature is enabled, this field displays Exhaustion log enable. |
Current DHCPv6 relay IPv6 pool |
DHCPv6 relay address pool that is currently used in the pool group. If no DHCPv6 relay address pool is in use, this field displays N/A. |
Static bindings |
Number of statically bound IPv6 addresses in the address pool group. |
Bind pools |
Number of bound IPv6 address pools, pool names, and pool priority. Each line displays one pool and its priority. |
# Display detailed information about all IPv6 pool groups and their IPv6 pools on the public network.
<Sysname> display ipv6 pool-group verbose
Pool-group: aaa
Used IPv6 prefixes: 1
Current DHCPv6 address pool: pool1
Current DHCPv6 prefix pool: pool1
IPv6 pool group address usage: 0.00%
IPv6 pool group pd usage: 100.00%
Static bindings: 0
Bind Pools: 1
pool1
DHCPv6 pool: pool1
Pool index: 1
Pool type: Common
VPN instance:
N/A
Pool-group-name:
chris
Static bindings:
Prefix: 10::/64
IPv6 address usage: 7.84%
IPv6 prefix usage: 0.00%
Bindings:
IP-in-use: 0
PD-in-use: 1
Expired IP: 0
Expired PD: 0
Reserve IP: 0
Reserve PD: 0
Conflicts: 0
Table 33 Command output
Pool-group |
Name of the IPv6 address pool group. |
VPN instance name |
Number of allocated IPv6 addresses in the pool group. |
Number of allocated IPv6 prefixes in the pool group. |
Ip-in-use threshold |
IPv6 pool group address usage |
Address usage of the IPv6 pool group. |
IPv6 pool group pd usage |
Prefix usage of the IPv6 pool group. |
Static bindings |
Bind pools |
DHCPv6 pool |
Information about IPv6 pools in the pool group. For more information about IPv6 pool fields, see display ipv6 pool. |
ipv6 pool-group
dns-server
Use dns-server to specify a DNS server in an IPv6 address pool.
Use undo dns-server to remove the specified DNS server from an IPv6 address pool.
dns-server ipv6-address
undo dns-server ipv6-address
No DNS server address is specified.
IPv6 address pool view
DHCPv6 option group view
ipv6-address: Specifies the IPv6 address of a DNS server.
You can use the dns-server command to specify up to eight DNS servers in an address pool. A DNS server specified earlier has a higher preference.
# Specify the DNS server address 2:2::3 in IPv6 address pool 1.
[Sysname] ipv6 pool 1
[Sysname-ipv6-pool-1] dns-server 2:2::3
display ipv6 pool
domain-name
Use domain-name to specify a domain name in an IPv6 address pool.
Use undo domain-name to restore the default.
domain-name domain-name
undo domain-name
No domain name is specified.
domain-name: Specifies a domain name, a case-sensitive string of 1 to 50 characters.
You can configure only one domain name in an address pool. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the domain name example.com in IPv6 address pool 1.
[Sysname-ipv6-pool-1] domain-name example.com
display ipv6 pool
Use exhaustion log enable to enable IPv6 resource exhaustion logging for an IPv6 address pool or pool group.
Use undo exhaustion log enable to restore the default.
IPv6 resource exhaustion logging is disabled for an IPv6 address pool or pool group.
This feature is supported for IPv6 address pools. It enables the DHCPv6 module to send IPv6 resource exhaustion log messages to the information center. For log messages to be sent correctly, configure the information center to set log message filtering and output rules, including output destinations. For information about the information center configuration, see Network Management and Monitoring Configuration Guide.
IPv6 resource exhaustion events include IPv6 resource exhaustion alarms and recoveries from IPv6 resource exhaustion alarm conditions.
An IPv6 resource exhaustion log message is generated when an IPv6 address pool or pool group encounters one of the following events:
· The pool or pool group does not have assignable address resources or prefix resources.
· The IPv6 address usage, subnet usage, prefix usage, or prefix range usage of the pool or pool group drops to or below 90% after exhaustion.
To calculate the IPv6 resource usage of an IPv6 address pool or pool group, use the following formulas:
· IPv6 address usage = (total number of IPv6 addresses – number of assignable IPv6 addresses )/total number of IPv6 addresses
· IPv6 prefix usage = (total number of IPv6 prefixes – number of assignable IPv6 prefixes)/total number of IPv6 prefixes
# Enable IPv6 resource exhaustion logging for IPv6 address pool pool1.
[Sysname] ipv6 pool pool1
[Sysname-ipv6-pool-pool1] exhaustion log enable
# Enable IPv6 resource exhaustion logging for IPv6 address pool group group1.
[Sysname] ipv6 pool-group group1
[Sysname-ipv6-group-group1] exhaustion log enable
display ipv6 pool
Use exhaustion trap enable to enable IPv6 resource exhaustion alarming for an IPv6 address pool or pool group.
Use undo exhaustion trap enable to disable IPv6 resource exhaustion alarming for an IPv6 address pool or pool group.
IPv6 resource exhaustion alarming is enabled for IPv6 address pools.
IPv6 resource exhaustion alarming is disabled for IPv6 address pool groups.
IPv6 address pool group view
This feature enables the device to generate a notification when the IPv6 resource usage of an IPv6 address pool or pool group reaches 100%.
This feature can take effect only after you enable SNMP notifications for the DHCPv6 server by using one of the following commands:
· snmp-agent trap enable ipv6 dhcp server address-exhaust pd-exhaust
This command takes effect on all IPv6 address pools on the DHCPv6 server. The DHCPv6 server might generate too many IPv6 resource exhaustion notifications. To reduce the number of alarm notifications, disable IPv6 resource exhaustion alarming for some IPv6 address pools by using the undo exhaustion trap enable command.
· snmp-agent trap enable ipv6 dhcp server pool-group-exhaust
# Disable IPv6 resource exhaustion alarming for IPv6 address pool pool1.
[Sysname-ipv6-pool-pool1] undo exhaustion trap enable
# Disable IPv6 resource exhaustion alarming for IPv6 address pool group group1.
[Sysname] ipv6 pool-pool group1
[Sysname-ipv6-pool-group-group 1] exhaustion trap enable
display ipv6 pool
export host-route
Use export host-route to enable host route advertisement.
Use undo export host-route to disable host route advertisement.
export host-route [ ipv6-address | nd-prefix | pd-prefix ] *
undo export host-route [ ipv6-address | nd-prefix | pd-prefix ] *
Host route advertisement is disabled.
ipv6-address: Advertises host routes for IPv6 addresses.
nd-prefix: Advertises host routes for ND prefixes.
pd-prefix: Advertises host routes for IPv6 prefixes.
The network export-route command enables the DHCPv6 server to advertise the network route for an assigned IPv6 address/prefix in the pool. If multiple pools share the same network segment, the same network route will be advertised for assigned IPv6 addresses/prefixes in these address pools. This will make the clients using these IPv6 addresses/prefixes become inaccessible to external devices. To resolve this issue, enable host route advertisement for each IPv6 address pool to advertise a host route for each assigned IPv6 address/prefix.
Before you enable host route advertisement for an IPv6 address pool, make sure this pool has not assigned any IPv6 addresses/prefixes.
# Enable host route advertisement for IPv6 address pool 1.
[Sysname-ipv6-pool-1] export host-route
ipv6 pool
forbidden-address
Use forbidden-address to exclude IPv6 addresses from DHCP allocation in an IPv6 address pool.
Use undo forbidden-address to remove the configuration.
forbidden-address start-ipv6-address [ end-ipv6-address ]
undo forbidden-address start-ipv6-address [ end-ipv6-address ]
Except for the DHCPv6 server address, all IPv6 addresses in an IPv6 address pool are assignable.
start-ipv6-address: Specifies the start IPv6 address.
end-ipv6-address: Specifies the end IPv6 address, which cannot be lower than start-ipv6-address. If you do not specify an end IPv6 address, only the start IPv6 address is excluded from DHCP allocation. If you specify an end IPv6 address, the IP addresses from start-ipv6-address through end-ipv6-address are all excluded from DHCP allocation.
You can exclude multiple IPv6 addresses in an IPv6 address pool by executing this command multiple times.
If the undo forbidden-address command contains fewer addresses than an existing excluded address range, the IPv6 address range in the undo command becomes assignable again. If the undo forbidden-address command contains more addresses than an existing excluded address range, the undo command removes the configuration of the excluded address range.
Excluded IPv6 address ranges in one IPv6 address pool can overlap. Excluded IPv6 address ranges in different IPv6 address pools cannot overlap.
# Exclude IPv6 address range 1::1 to 1::2 from DHCP allocation.
[Sysname] ipv6 pool aaa
[Sysname-ipv6-pool-aaa] forbidden-address 1::1 1::2
network
forbidden-prefix
Use forbidden-prefix to exclude IPv6 prefixes from DHCP allocation in an IPv6 address pool.
Use undo forbidden-prefix to remove the configuration.
forbidden-prefix start-prefix/prefix-len [ end-prefix/prefix-len ]
undo forbidden-prefix start-prefix/prefix-len [ end-prefix/prefix-len ]
No IPv6 prefixes are excluded from DHCP allocation in an IPv6 prefix pool.
start-prefix/prefix-len: Specifies the start IPv6 prefix. The prefix-len argument specifies the prefix length in the range of 1 to 128.
end-prefix/prefix-len: Specifies the end IPv6 prefix. The prefix-len argument specifies the prefix length in the range of 1 to 128. The value for end-prefix cannot be lower than that for start-prefix. If you do not specify this argument, only the start-prefix/prefix-len is excluded from DHCP allocation. If you specify this argument, the prefixes from start-prefix/prefix-len to end-prefix/prefix-len are all excluded.
You can exclude multiple IPv6 prefixes in an IPv6 address pool by executing this command multiple times.
If the undo forbidden-prefix command contains fewer prefixes than an existing excluded prefix range, the IPv6 prefix range in the undo command becomes assignable again. If the undo forbidden-prefix command contains more prefixes than an existing excluded prefix range, the undo command removes the configuration of the excluded prefix range.
Excluded IPv6 prefix ranges in one IPv6 address pool can overlap. Excluded IPv6 prefix ranges in different IPv6 address pools cannot overlap.
# Exclude IPv6 prefix range 1:1::/64 to 1:2::/64 from DHCP allocation.
[Sysname-ipv6-pool-aaa] forbidden-prefix 1:1::/64 1:2::/64
ipv6 dhcp prefix-pool
prefix-pool
if-match
Use if-match to configure a match rule for a DHCPv6 user class.
Use undo if-match to delete a match rule for a DHCPv6 user class.
if-match rule rule-number { option option-code [ ascii ascii-string [ offset offset | partial ] | hex hex-string [ mask mask | offset offset length length | partial ] ] | relay-agent gateway-ipv6-address }
No match rules are configured for the DHCPv6 user class.
DHCPv6 user class view
rule rule-number: Assigns the match rule an ID in the range of 1 to 16. A smaller ID represents a higher match priority.
option option-code: Specifies a DHCPv6 option by its number in the range of 1 to 65535.
ascii ascii-string: Specifies an ASCII string of 1 to 128 characters.
offset offset: Specifies the offset in bytes after which the match operation starts. The value range is 0 to 65534. If you specify an ASCII string, a packet matches the rule if the option content after the offset is the same as the ASCII string. If you specify a hexadecimal number, a packet matches the rule if the option content of the specified length after the offset is the same as the hexadecimal number.
partial: Enables partial match. A packet matches the rule if the specified option in the packet contains the ASCII string or hexadecimal number specified in the rule. For example, if you specify abc in the rule, option content xabc, xyzabca, xabcyz, and abcxyz all match the rule.
hex hex-string: Specifies a hexadecimal number. The length of the hexadecimal number must be an even number in the range of 2 to 256.
mask mask: Specifies the mask for the match operation. The mask is a hexadecimal number whose length is an even number in the range of 2 to 256 and must be the same as the hex-string length. The DHCPv6 server selects option content of the mask length from the start and ANDs the selected option content and the specified hexadecimal number with the mask. The packet matches the rule if the two AND operation results are the same.
length length: Specifies the length of the option content to be matched, in the range of 1 to 128 bytes. The length must be the same as the hex-string length.
relay-agent gateway-ipv6-address: Specifies a link-address field value. The value is an IPv6 address. A packet matches the rule if its link-address field value is the same as that in the rule.
If a DHCPv6 request sent by a DHCPv6 client matches a rule in a DHCPv6 user class, the DHCPv6 client matches the user class.
You can configure multiple match rules for a DHCPv6 user class. Each match rule is uniquely identified by a rule ID within its type (option or relay agent address).
· If the rule that you are configuring has the same ID and type as an existing rule, the new rule overwrites the existing rule.
· If the rule that you are configuring has the same ID as an existing rule but a different type, the new rule takes effect and coexists with the existing rule. As a best practice, do not assign the same ID to rules of different types.
· Rules of different IDs cannot have the same rule content.
When you configure an if-match option rule, follow these guidelines:
· To match packets that contain an option, specify only the option-code argument.
· To match a hexadecimal number by AND operations, specify the option option-code hex hex-string mask mask options.
· To match a hexadecimal number directly, specify the option option-code hex hex-string [ offset offset length length | partial ] options. If you do not specify the offset, length, or partial parameter, a packet matches a rule if the option content starts with the hexadecimal number.
· To match an ASCII string, specify the option option-code ascii ascii-string [ offset offset | partial ] options. If you do not specify the offset or partial parameter, a packet matches a rule if the option content starts with the ASCII string.
# Configure match rule 1 for the DHCPv6 user class exam to match DHCPv6 requests that contain Option 16.
[Sysname] ipv6 dhcp class exam
[Sysname-dhcp6-class-exam] if-match rule 1 option 16
# Configure match rule 2 for the DHCPv6 user class exam. The rule matches DHCPv6 requests in which the highest bit of the fourth byte in Option 16 is the hexadecimal number 1.
[Sysname-dhcp6-class-exam] if-match rule 2 option 16 hex 00000080 mask 00000080
# Configure match rule 3 for the DHCPv6 user class exam. The rule matches DHCPv6 requests in which the first three bytes of Option 16 are the hexadecimal number 13ae92.
[Sysname-dhcp6-class-exam] if-match rule 3 option 16 hex 13ae92 offset 0 length 3
# Configure match rule 4 for the DHCPv6 user class exam. The rule matches DHCPv6 requests in which the Option 16 contains the hexadecimal number 13ae.
[Sysname-dhcp6-class-exam] if-match rule 5 option 16 hex 13ae partial
# Configure match rule 5 for the DHCPv6 user class exam to match DHCPv6 requests in which the link-address field is 2001::1.
[Sysname-dhcp6-class-exam] if-match rule 5 relay-agent 2001::1
ipv6 dhcp class
ip-in-use threshold
Use ip-in-use threshold to set the IPv6 address usage threshold for an IPv6 address pool or pool group.
Use undo ip-in-use threshold to restore the default.
The IPv6 address usage threshold for an IPv6 address pool or pool group is 100%.
IPv6 pool view
threshold-value: Specifies the IPv6 address usage threshold, in percentage. The value range for this argument is 0 to 100.
Application scenarios
The DHCPv6 module sends an alarm notification to the SNMP module and a log message to the information center when one of the following events occurs:
· The IPv6 address usage of an IPv6 address pool or pool group reaches or exceeds the threshold.
· The IPv6 address usage of an IPv6 address pool or pool group drops below 90% of the threshold after a threshold violation.
For DHCP notifications to be sent correctly, you must configure the SNMP module on the device. For more information about configuring the SNMP module, see Network Management and Monitoring Configuration Guide.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
You can review and analyze these notifications and log messages to determine the actions to take. For example, you can expand the address pool or pool group to accommodate all users.
If you execute this command multiple times in the same IPv6 pool view, the most recent configuration takes effect.
If the IPv6 address usage threshold for an IPv6 address pool or address pool group is 0 or 100, the device does not generate any related alarm or log messages for that IPv6 address pool or address pool group.
# Set the IPv6 address usage threshold for IPv6 address pool pool1 to 75%.
[Sysname-ipv6-pool-pool1] ip-in-use threshold 75
# Set the IPv6 address usage threshold for IPv6 address pool group group1 to 75%.
[Sysname-ipv6-pool-group-group1] ip-in-use threshold 75
ipv6 dhcp apply-policy
Use ipv6 dhcp apply-policy to apply a DHCPv6 policy to an interface.
Use undo ipv6 dhcp apply-policy to restore the default.
ipv6 dhcp apply-policy policy-name
No DHCPv6 policy is applied to an interface.
Interface view
policy-name: Specifies a DHCPv6 policy by its name, a case-insensitive string of 1 to 63 characters.
You can apply only one DHCPv6 policy to an interface. If you execute this command multiple times, the most recent configuration takes effect.
# Apply the DHCPv6 policy test to Ten-GigabitEthernet 0/0/15.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp apply-policy test
ipv6 dhcp class
ipv6 dhcp class
Use ipv6 dhcp class to create a DHCPv6 user class and enter its view, or enter the view of an existing DHCPv6 user class.
Use undo ipv6 dhcp class to delete the specified DHCPv6 user class.
ipv6 dhcp class class-name
undo ipv6 dhcp class class-name
No DHCPv6 user classes exist.
class-name: Specifies a name for the DHCPv6 user class, a case-insensitive string of 1 to 63 characters.
In the DHCPv6 user class view, you can use the if-match command to configure match rules for user classification.
# Create a DHCPv6 user class test and enter DHCPv6 user class view.
[Sysname] ipv6 dhcp class test
[Sysname-dhcp6-class-test]
class pool
ipv6 dhcp policy
if-match
ipv6 dhcp duid-mismatch offline
Use ipv6 dhcp duid-mismatch offline to allocate existing IPv6 address leases to DHCPv6 clients with different DUIDs.
Use undo ipv6 dhcp duid-mismatch offline to restore the default.
By default, upon receiving a request that contains the same MAC address as an existing lease but a different DUID, the DHCPv6 server reserves the lease and discards the request.
This feature is applicable only to IPoE networks.
A DHCPv6 client might have different DUIDs. One example is that a client runs on a host that installs multiple operating systems. When the client uses a different DUID to request an IPv6 address, the DHCPv6 server drops the request if the request contains the same MAC address as an existing lease. After you enable this feature, the DHCPv6 server releases the existing IPv6 address lease of the client and assigns this IPv6 address to the client.
This feature takes effect on a DHCPv6 client only if it connects to the network through the same interface and in the same VLAN.
# Configure the DHCPv6 server to allocate existing IPv6 address leases to DHCPv6 clients with different DUIDs.
[Sysname] ipv6 dhcp duid-mismatch offline
ipv6 pool
display ipv6 dhcp server expired-ip
ipv6 dhcp option-group
Use ipv6 dhcp option-group to create a static DHCPv6 option group and enter its view.
Use undo ipv6 dhcp option-group to delete the specified static DHCPv6 option group.
ipv6 dhcp option-group option-group-number
undo ipv6 dhcp option-group option-group-number
No static DHCPv6 option groups exist.
option-group-number: Assigns an ID to the static option group, in the range of 1 to 100.
A static DHCPv6 option group can use the same ID as a dynamic DHCPv6 option group. If a static DHCPv6 option group and a dynamic DHCPv6 option group use the same ID, the static one takes precedence over the dynamic one.
# Create static DHCPv6 option group 1 and enter its view.
[Sysname] ipv6 dhcp option-group 1
[Sysname-dhcp6-option-group-1]
display ipv6 dhcp option-group
ipv6 dhcp policy
Use ipv6 dhcp policy to create a DHCPv6 policy and enter its view, or enter the view of an existing DHCPv6 policy.
Use undo ipv6 dhcp policy to delete a DHCPv6 policy.
ipv6 dhcp policy policy-name
undo ipv6 dhcp policy policy-name
No DHCPv6 policies exist.
policy-name: Assigns a name to the DHCPv6 policy. The policy name is a case-insensitive string of 1 to 63 characters.
In DHCPv6 policy view, you can specify IPv6 address pools for different user classes. Clients matching a user class will obtain IPv6 addresses and other parameters from the specified address pool.
For a DHCPv6 policy to take effect, you must apply it to an interface.
# Create DHCPv6 policy test and enter its view.
[Sysname] ipv6 dhcp policy test
[Sysname-dhcp6-policy-test]
class pool
default pool
ipv6 dhcp class
Use ipv6 dhcp prefix-pool to create a prefix pool and specify the prefix and the assigned prefix length for the pool.
Use undo ipv6 dhcp prefix-pool to delete the specified prefix pool.
ipv6 dhcp prefix-pool prefix-pool-number prefix { prefix-number | prefix/prefix-len } assign-len assign-len [ vpn-instance vpn-instance-name ]
undo ipv6 dhcp prefix-pool prefix-pool-number [ vpn-instance vpn-instance-name ]
No prefix pools exist.
prefix-pool-number: Specifies a prefix pool number in the range of 1 to 128.
prefix { prefix-number | prefix/prefix-len }: Specifies a prefix by its ID or in the format of prefix/prefix length. The value range for the prefix-number argument is 1 to 1024. The value range for the prefix-len argument is 1 to 128.
assign-len assign-len: Specifies the assigned prefix length. The value range is 1 to 128, and the value must be greater than or equal to prefix-len. The difference between assign-len and prefix-len must be no more than 32.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To create a prefix pool for the public network, do not specify this option.
Different prefix pools cannot overlap.
To modify a prefix pool, execute the undo ipv6 dhcp prefix-pool command to delete the prefix pool, and then execute the ipv6 dhcp prefix-pool command.
Deleting a prefix pool clears all prefix bindings from the prefix pool.
When you specify a prefix by its ID, follow these restrictions and guidelines:
· This command does not take effect if the prefix does not exist. This command takes effect after the prefix is created.
· Do not specify the same prefix for different prefix pools in a VPN.
· If the prefix that the ID represents is changed, the prefix range in the prefix pool accordingly changes.
· If a BRAS access network uses NDRA for IPv6 prefix assignment, the prefix length specified for the AAA-authorized ND prefix pool must be 64.
# Create IPv6 prefix 88:99::/32 with the ID 3. Configure prefix pool 2 with IPv6 prefix 3 and assigned prefix length 42. Prefix pool 2 contains 1024 prefixes from 88:99::/42 to 88:99:FFC0::/42.
[Sysname] ipv6 prefix 3 88:99::/32
[Sysname] ipv6 dhcp prefix-pool 2 prefix 3 assign-len 42
# Create prefix pool 1, and specify the prefix 2001:0410::/32 with the assigned prefix length 42. Prefix pool 1 contains 1024 prefixes from 2001:0410::/42 to 2001:0410:FFC0::/42.
[Sysname] ipv6 dhcp prefix-pool 1 prefix 2001:0410::/32 assign-len 42
display ipv6 dhcp prefix-pool
forbidden-prefix
prefix-pool
ipv6 dhcp route-log enable
Use ipv6 dhcp route-log enable to enable route logging for all IPv6 address pools.
Use undo ipv6 dhcp route-log enable to disable route logging for all IPv6 address pools.
Route logging is disabled for all IPv6 address pools.
This feature enables the DHCPv6 server to generate log messages for route events that occur in IPv6 address pools. Route events include network route adding or deletion.
To enable route logging for IPv6 address pools, use one of the following commands:
· ipv6 dhcp route-log enable
· This command enables route logging for all types of IPv6 address pools on the DHCPv6 server.
· route-log enable
· This command enables route logging for a single IPv6 address pool on the DHCPv6 server. To enable route logging for only one IPv6 address pool, perform the following task:
a. Verify that route logging is disabled for all IPv6 address pools on the DHCPv6 server.
b. You can use the undo ipv6 dhcp route-log enable command to disable route logging for all IPv6 address pools.
c. Use the route-log enable command in the view of the target IPv6 address pool.
# Enable route logging for all IPv6 address pools on the DHCPv6 server.
[Sysname] ipv6 dhcp route-log enable
route-log enable
ipv6 dhcp server
Use ipv6 dhcp server to configure global address assignment on an interface. The server on the interface uses a global address pool to assign configuration information to a client.
Use undo ipv6 dhcp server to restore the default.
ipv6 dhcp server { allow-hint | preference preference-value | rapid-commit } *
The server supports global address assignment, but does not support desired address/prefix assignment or rapid address/prefix assignment. The server preference is not set.
Interface view
allow-hint: Enables desired address/prefix assignment.
preference preference-value: Specifies the server preference in Advertise messages, in the range of 0 to 255. A greater value represents a higher preference.
rapid-commit: Enables rapid address/prefix assignment involving two messages.
The allow-hint keyword enables the server to assign the desired address or prefix to the requesting client. If the desired address or prefix is not included in any global address pool, or is already assigned to another client, the server assigns the client a free address or a prefix. If the allow-hint keyword is not specified, the server ignores the desired address or prefix, and selects an address or prefix from a global address pool.
If you use the ipv6 dhcp server and ipv6 dhcp server apply pool commands on the same interface, the ipv6 dhcp server apply pool command takes effect.
# Configure global address assignment on the interface Ten-GigabitEthernet 0/0/15. Use the desired address/prefix assignment and rapid address/prefix assignment, and set the server preference to the highest 255.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp server allow-hint preference 255 rapid-commit
ipv6 dhcp select
Use ipv6 dhcp server apply pool to apply an IPv6 address pool to an interface.
Use undo ipv6 dhcp server apply pool to restore the default.
ipv6 dhcp server apply pool pool-name [ allow-hint | preference preference-value | rapid-commit ] *
No IPv6 address pool is applied to an interface.
Interface view
preference preference-value: Specifies the server preference in Advertise messages, in the range of 0 to 255. A greater value represents a higher preference. By default, the server preference is not set.
Operation mechanism
Upon receiving a DHCPv6 request, the DHCPv6 server selects an IPv6 address or prefix from the address pool applied to the receiving interface. If no address pool is applied, the server selects an IPv6 address or prefix from a global address pool that matches the IPv6 address of the receiving interface or the DHCPv6 relay agent.
The allow-hint keyword enables the server to assign the desired address or prefix to the client. If the desired address or prefix does not exist or is already assigned to another client, the server assigns a free address or prefix. If allow-hint is not specified, the server ignores the desired address or prefix, and assigns a free address or prefix.
You can apply only one address pool to an interface. If you execute this command multiple times, the most recent configuration takes effect.
A non-existing address pool can be applied to an interface, but the server cannot assign any prefix, address, or other configuration information from the address pool until the address pool is created.
When you apply an IPv6 address pool to an interface, make sure the pool contains the network segment to which the IPv6 address of the interface belongs. If this requirement is not met, the clients attached to the interface will be unable to obtain an IPv6 address from the pool. This restriction does not apply to IPv6 prefix assignment.
# Apply address pool 1 to Ten-GigabitEthernet 0/0/15, configure the address pool to support desired address/prefix assignment and address/prefix rapid assignment, and set the preference to 255.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp server apply pool 1 allow-hint preference 255 rapid-commit
ipv6 pool
ipv6 dhcp select
ipv6 dhcp server database filename
Use ipv6 dhcp server database filename to configure the DHCPv6 server to back up the DHCPv6 bindings to a file.
Use undo ipv6 dhcp server database filename to restore the default.
ipv6 dhcp server database filename { filename | url url [ username username [ password { cipher | simple } string ] ] }
The DHCPv6 server does not back up the DHCPv6 bindings.
filename: Specifies the name of a local backup file, a case-insensitive string of 1 to 255 characters. For information about the filename argument, see Fundamentals Configuration Guide.
url url: Specifies the URL of a remote backup file. The URL is a case-sensitive string of 1 to 255 characters. Do not include a username or password in the URL.
username username: Specifies the username for accessing the URL of the remote backup file, a case-sensitive string of 1 to 32 characters. Do not specify this option if a username is not required for accessing the URL of the remote backup file.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters. Do not specify this argument if a password is not required for accessing the URL of the remote backup file.
The command automatically creates the file if you specify a nonexistent file.
With this command executed, the DHCPv6 server backs up its bindings immediately and runs auto backup. The server, by default, waits 300 seconds after a binding change to update the backup file. You can use the ipv6 dhcp server database update interval command to change the waiting time. If no DHCPv6 binding changes, the backup file is not updated.
As a best practice, back up the bindings to a remote file. If you use the local storage medium, the frequent erasing and writing might damage the medium and then cause the DHCPv6 server to malfunction.
When the backup file is on a remote device, follow these restrictions and guidelines to specify the URL, username, and password:
· If the file is on an FTP server, enter URL in the format of ftp://server address:port/file path, where the port number is optional.
· If the file is on a TFTP server, enter URL in the format of tftp://server address:port/file path, where the port number is optional.
· The username and password must be the same as those configured on the FTP server. If the server authenticates only the username, the password can be omitted.
· If the IP address of the server is an IPv6 address, enclose the address in a pair of brackets, for example, ftp://[1::1]/database.dhcp.
· You can also specify the DNS domain name for the server address field, for example, ftp://company/database.dhcp.
# Configure the DHCPv6 server to back up its bindings to the file database.dhcp
[Sysname] ipv6 dhcp server database filename database.dhcp
# Configure the DHCPv6 server to back up its bindings to the file database.dhcp in the working directory of the FTP server at 10::1.
[Sysname] ipv6 dhcp server database filename url ftp://[10::1]/database.dhcp username 1 password simple 1
ipv6 dhcp server database update now
ipv6 dhcp server database update stop
Use ipv6 dhcp server database update interval to set the waiting time for the DHCPv6 server to update the backup file after a DHCPv6 binding change.
Use undo ipv6 dhcp server database update interval to restore the default.
ipv6 dhcp server database update interval interval
The DHCPv6 server waits 300 seconds to update the backup file after a DHCPv6 binding change. If no DHCPv6 binding changes, the backup file is not updated.
interval: Sets the waiting time in the range of 60 to 864000 seconds.
When a DHCPv6 binding is created, updated, or removed, the waiting period starts. The DHCPv6 server updates the backup file when the waiting period is reached. All bindings changed during the period will be saved to the backup file.
The waiting time takes effect only after you configure the DHCPv6 binding auto backup by using the ipv6 dhcp server database filename command.
# Set the waiting time to 600 seconds for the DHCPv6 server to update the backup file.
[Sysname] ipv6 dhcp server database update interval 600
Use ipv6 dhcp server database update now to manually save the DHCPv6 bindings to the backup file.
Each time this command is executed, the DHCPv6 bindings are saved to the backup file.
For this command to take effect, you must configure the DHCPv6 auto backup by using the ipv6 dhcp server database filename command.
# Manually save the DHCPv6 bindings to the backup file.
[Sysname] ipv6 dhcp server database update now
Use ipv6 dhcp server database update stop to terminate the download of DHCPv6 bindings from the backup file.
The DHCPv6 server does not provide services during the binding download process. If the connection breaks up during the process, the waiting timeout timer is 60 minutes. When the timer expires, the DHCPv6 server stops waiting and starts providing address allocation services. You can execute this command to terminate the download immediately.
Manual termination allows the DHCPv6 server to provide services without waiting for the connection to be repaired. The IPv6 addresses and prefixes associated with the undownloaded bindings will be assigned to clients and address conflicts might occur.
# Terminate the download of the backup DHCPv6 bindings.
[Sysname] ipv6 dhcp server database update stop
ipv6 dhcp server forbidden-address
Use ipv6 dhcp server forbidden-address to exclude IPv6 addresses from DHCP allocation globally.
Use undo ipv6 dhcp server forbidden-address to remove the configuration.
ipv6 dhcp server forbidden-address start-ipv6-address [ end-ipv6-address ] [ vpn-instance vpn-instance-name ]
undo ipv6 dhcp server forbidden-address start-ipv6-address [ end-ipv6-address ] [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the excluded IPv6 addresses belong to the public network, do not specify this option.
The IPv6 addresses of some devices such as the gateway and FTP server cannot be assigned to clients. Use this command to exclude such addresses from DHCP allocation.
If an IPv6 address already has a static DHCPv6 binding, you cannot specify that IPv6 address in this command. To configure a static DHCPv6 binding for an IPv6 address, use the static-bind command.
The address range specified in the undo form of the command must be the same as the address range specified in the command. To remove an IP address that has been specified as part of an address range, you must remove the entire address range.
You can execute this command multiple times to exclude multiple IPv6 address ranges from DHCP allocation.
# Exclude IPv6 addresses of 2001:10:110::1 through 2001:10:110::20 from DHCP allocation.
[Sysname] ipv6 dhcp server forbidden-address 2001:10:110::1 2001:10:110::20
ipv6 dhcp server forbidden-prefix
static-bind
Use ipv6 dhcp server forbidden-prefix to exclude IPv6 prefixes from DHCP allocation globally.
Use undo ipv6 dhcp server forbidden-prefix to remove the configuration.
ipv6 dhcp server forbidden-prefix start-prefix/prefix-len [ end-prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
undo ipv6 dhcp server forbidden-prefix start-prefix/prefix-len [ end-prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
No IPv6 prefixes are excluded from DHCP allocation globally.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the excluded IPv6 prefixes belong to the public network, do not specify this option.
If an IPv6 prefix already has a static DHCPv6 binding, you cannot specify that IPv6 prefix in this command. To configure a static DHCPv6 binding for an IPv6 prefix, use the static-bind command.
The prefix range specified in the undo form of the command must be the same as the prefix range specified in the command. To remove a prefix that has been specified as part of a prefix range, you must remove the entire prefix range.
You can execute this command multiple times to exclude multiple IPv6 prefix ranges from DHCP allocation.
# Exclude IPv6 prefixes from 2001:3e11::/32 through 2001:3eff::/32 from DHCP allocation.
[Sysname] ipv6 dhcp server forbidden-prefix 2001:3e11::/32 2001:3eff::/32
static-bind
ipv6 dhcp server multi-ip per-mac enable
Use ipv6 dhcp server multi-ip per-mac enable to enable allocation of different IP addresses to DHCPv6 clients with the same MAC address.
Use undo ipv6 dhcp server multi-ip per-mac enable to disable allocation of different IP addresses to DHCPv6 clients with the same MAC address.
If the DHCPv6 server has assigned IP addresses to DHCPv6 clients, you cannot enable or disable this feature. If you do so, the system displays an error message.
This command is mutually exclusive with the ipv6 dhcp session-mismatch action command.
# Enable different IP address allocation for DHCPv6 clients with the same MAC address.
[Sysname] ipv6 dhcp server multi-ip per-mac enable
ipv6 pool
Use ipv6 pool to create an IPv6 address pool and enter its view, or enter the view of an existing IPv6 address pool.
Use undo ipv6 pool to delete the specified IPv6 address pool.
ipv6 pool pool-name
undo ipv6 pool pool-name
No IPv6 address pools exist.
pool-name: Specifies a name for the IPv6 address pool, a case-insensitive string of 1 to 63 characters.
When you delete an IPv6 address pool, binding information for the assigned IPv6 addresses and prefixes in the address pool is also deleted.
# Create an IPv6 address pool and enter its view.
[Sysname] ipv6 pool p1
[Sysname-ipv6-pool-p1]
display ipv6 pool
ipv6 pool-group
Use ipv6 pool-group to create an IPv6 address pool group and enter its view, or enter the view of an existing IPv6 address pool group.
Use undo ipv6 pool-group to delete the specified IPv6 address pool group.
ipv6 pool-group pool-group-name
undo ipv6 pool-group pool-group-name
No IPv6 address pool groups exist.
For a user that matches an IPv6 address pool group, the DHCPv6 server selects an IPv6 address from an available IPv6 address pool in the IPv6 address pool group.
If both an IPv6 address pool and an IPv6 address pool group exist in AAA authorized user attributes, authenticated users can only obtain IPv6 addresses from the IPv6 address pool. The users cannot obtain IPv6 addresses from the IPv6 address pool group even if the authorized IPv6 address pool has no assignable IPv6 addresses.
If a DHCPv6 client matches a remote IPv6 pool in an IPv6 pool group, the relay agent cannot determine whether the DHCPv6 server in the remote IPv6 pool has assignable IPv6 addresses. To resolve this issue, perform the following tasks for the remote IPv6 pool:
· Execute the network command to specify the IPv6 address resources configured on the remote DHCPv6 server.
· Execute the ipv6 dhcp server forbidden-address command to specify the excluded IPv6 addresses configured on the remote DHCPv6 server.
Upon receiving an IPv6 address from the remote DHCPv6 server, the relay agent considers that IPv6 address as assigned in the remote IPv6 pool. This mechanism ensures that the relay agent and the DHCPv6 server have the same free address information. The relay agent can then determine whether the DHCPv6 server has free addresses by examining free addresses in the remote IPv6 pool.
# Create an IPv6 address pool group named poolgroup1 and enter its view.
[Sysname] ipv6 pool-group poolgroup1
[Sysname-ipv6-pool-group-poolgroup1]
ipv6-pool algorithm round-robin
Use ipv6-pool algorithm round-robin to enable round-robin IPv6 pool selection in an IPv6 pool group for address allocation.
Use undo ipv6-pool algorithm round-robin to restore the default.
ipv6-pool algorithm round-robin { local | remote } *
undo ipv6-pool algorithm round-robin { local | remote} *
The DHCPv6 server moves from one IPv6 pool to the next only when that IPv6 pool does not have assignable IPv6 addresses or prefixes.
local: Selects local IPv6 pools for address allocation in a round-robin manner.
remote: Selects remote IPv6 pools for address allocation in a round-robin manner.
The default pool selection mechanism leads to uneven IPv6 resource distribution among IPv6 pools. To balance resource usage across the IPv6 pools in a pool group, enable the round-robin algorithm on that pool group.
Operating mechanism
The round-robin IPv6 pool selection mechanism operates as follows:
1. On receipt of the first DHCPv6 request, the server selects the first available IPv6 pool for address allocation from the pool group.
2. When a new DHCPv6 request arrives, the server selects the next available IPv6 pool for address allocation.
3. After the server iterates through all the IPv6 pool in the group, the server starts over again from the first IPv6 pool.
When you use this command, follow these guidelines:
· If you specify only the local keyword, this command will take effect only on local IPv6 pools.
· If you specify only the remote keyword, this command will take effect only on remote IPv6 pools.
· If you specify both the local and remote keywords, the server will first select local IPv6 pools in a round-robin manner. It moves to remote IPv6 pools for round-robin selection only if none of the local IP pools has assignable IPv6 addresses or prefixes.
If the DHCPv6 server assigns ND prefixes to access users through NDRA, IPv6 address pool groups on the DHCPv6 server do not support the round-robin IPv6 pool selection mechanism.
# Enable round-robin selection of local IPv6 pools in IPv6 pool group 1.
[Sysname] ipv6 pool-group 1
[Sysname-dhcp6-pool-group-1] ipv6-pool algorithm round-robin local
ipv6 unr
Use ipv6 unr to set an IPv6 user network route (UNR) tag.
Use undo ipv6 unr to restore the default.
ipv6 unr { framed-ipv6-address-tag tag-value | framed-ipv6-prefix-tag tag-value | framed-ipv6-route-tag tag-value | local-pool-tag tag-value | remote-pool-tag tag-value } *
undo ipv6 unr { framed-ipv6-address-tag | framed-ipv6-prefix-tag | framed-ipv6-route-tag | local-pool-tag | remote-pool-tag } *
No IPv4 UNR tag value.
framed-ipv6-address-tag tag-value: Sets a tag value for network routes that are generated based on the Framed-IPv6-Address attribute assigned by the RADIUS server. The tag value range is 1 to 4294967295.
framed-ipv6-prefix-tag tag-value: Sets a tag value for network routes that are generated based on the Framed-IPv6-Prefix attribute assigned by the RADIUS server. The tag value range is 1 to 4294967295.
framed-ipv6-route-tag tag-value: Sets a tag value for network routes that are generated based on the Framed-IPv6-Route attribute assigned by the RADIUS server. The tag value range is 1 to 4294967295.
local-pool-tag tag-value: Sets a UNR tag value for common IPv6 address pools. The tag value range is 1 to 4294967295.
remote-pool-tag tag-value: Sets a UNR tag value for DHCPv6 relay address pools. The tag value range is 1 to 4294967295.
When the DHCPv6 server assigns an IPv6 address, it adds the route for the IPv6 address to the route management module. In a BAS network, you can classify user network routes based on their UNR tag values for route redistribution.
The tag value modification does not affect the tag value for network routes that have been advertised.
You can set a tag value in system view or in IPv6 address pool view. For BAS access users, the value set in IPv6 address pool view has higher priority than the one set in system view.
# Set the UNR tag value to 1 for network routes that are generated based on the Framed-IPv6-Address attribute assigned by the RADIUS server.
[Sysname] ipv6 unr framed-ipv6-address-tag 1
lock
Use lock to lock an IPv6 pool.
Use undo lock to restore the default.
lock [ strict ]
undo lock
IPv6 pools are not locked.
strict: Locks the IPv6 pool in strict mode. If an IPv6 pool is locked in strict mode, the server does not respond to the lease renewal requests from online DHCPv6 clients for IPv6 addresses and prefixes in the pool or assign IPv6 addresses or prefixes from the pool to new DHCPv6 clients. If you do not specify this keyword, the IPv6 pool is locked in loose mode. When the IPv6 pool is locked in loose mode, the server responds to the lease renewal requests from online DHCPv6 clients for IPv6 addresses and prefixes in the pool. However, it does not assign IPv6 addresses or prefixes from the pool to new DHCPv6 clients.
Lock an IPv6 pool in loose mode or strict mode depending on the IPv6 pool management requirements.
· Lock an IPv6 pool in loose mode if you are using that pool only to assign addresses or prefixes to existing DHCPv6 clients on the network.
· Lock an IPv6 pool in strict mode if you are deleting or changing the IPv6 address space or prefix space assigned to the IPv6 pool. You can delete or change the IPv6 address space or prefix space for an IP pool only when the IPv6 pool does not contain assigned IPv6 addresses or prefixes. Locking the IPv6 pool in strict mode ensures that you can perform the delete or change operation as soon as all assigned IPv6 addresses and prefixes in the pool are reclaimed.
Examples:
# Lock IPv6 pool 1 in loose mode.
[Sysname-ipv6-pool-1] lock
The IPv6 pool will answer only renewal requests of online users but will not assign addresses or prefixes to new users. Continue? [Y/N]:
# Lock IPv6 pool 1 in strict mode.
[Sysname-ipv6-pool-1] lock strict
The IPv6 pool will not answer renewal requests of online users or assign addresses or prefixes to new users. Continue? [Y/N]:
display ipv6 pool
network
Use network to specify an IPv6 subnet for dynamic allocation in an IPv6 address pool.
Use undo network to restore the default.
network { prefix/prefix-length | prefix prefix-number [ sub-prefix/sub-prefix-length ] } [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ] [ export-route [ preference preference | tag tag ] * ]
undo network
No IPv6 subnet is specified in an IPv6 address pool.
prefix/prefix-length: Specifies the IPv6 subnet for dynamic allocation. The value range for the prefix-length argument is 1 to 128.
prefix prefix-number: Specifies an IPv6 prefix by its ID in the range of 1 to 1024.
sub-prefix/sub-prefix-length: Specifies an IPv6 sub-prefix and its length. The value range for the sub-prefix-length argument is 1 to 128. If the IPv6 prefix is longer than the IPv6 sub-prefix or if you do not specify an IPv6 sub-prefix, the IPv6 subnet defined by the IPv6 prefix is used for dynamic allocation.
preferred-lifetime preferred-lifetime: Sets the preferred lifetime. The value range is 60 to 4294967295 seconds, and the default is 604800 seconds (7 days).
valid-lifetime valid-lifetime: Sets the valid lifetime. The value range is 60 to 4294967295 seconds, and the default is 2592000 seconds (30 days). The valid lifetime must be longer than or equal to the preferred lifetime.
export-route: Advertises the subnet assigned to DHCPv6 clients. If you do not specify this keyword, the subnet will not be advertised.
preference preference: Sets a preference for the network route to be advertised, in the range of 1 to 255. The default preference is 65.
tag tag: Sets a tag value for the network route to be advertised, in the range of 0 to 4294967295. The default tag value is 0. Tags are route identifications for routing policies to filter routes. For more information about routing policies, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
You can specify only one subnet for an IPv6 address pool. If you execute the network command multiple times, the most recent configuration takes effect.
If the IPv6 address pool has assigned IPv6 addresses, you cannot use the network command to modify or remove the subnet in the address pool.
You can specify a nonexistent IPv6 prefix in this command, but this command takes effect after you create the prefix.
To edit the preference or tag value for the route to a subnet and host routes inside the subnet, execute the network export-route command with the preference or tag keyword specified. If you edit the tag value for host routes, the new tag value takes effect only on the host routes generated after the tag change. The tag value for existing host routes remains unchanged.
The following information is about the use of the network prefix command:
· The network prefix command does not take effect if the specified IPv6 prefix does not exist. This command takes effect after the IPv6 prefix is created by using either of the following methods:
¡ Execute the ipv6 dhcp client pd command on the DHCPv6 server to request the prefix from another DHCPv6 server. In this case, the requesting server acts as a DHCPv6 client.
¡ Use the ipv6 prefix command to create the prefix manually.
· If you specify the sub-prefix/sub-prefix-length arguments, the assignable prefix range is the prefix set that overlaps between the specified prefix and sub-prefix.
· If the specified prefix changes, the IPv6 subnet generated by using this command automatically changes. Upon this change, the device automatically removes the assigned prefix and address bindings.
The subnets specified in different IPv6 address pools cannot overlap.
When the preferred or valid lifetime configured by using this command differs from the one requested in a DHCPv6 message, the smaller of the two takes effect.
# Specify the subnet 3ffe:501:ffff:100::/64 in IPv6 address pool 1.
[Sysname-ipv6-pool-1] network 3ffe:501:ffff:100::/64
# Create IPv6 prefix 88:99::/32 with the prefix ID 3. Create IPv6 address pool 1 and use the IPv6 subnet defined by the IPv6 prefix for dynamic allocation.
[Sysname-ipv6-pool-1] network prefix 3
# Create IPv6 prefix 88:99::/32 with the prefix ID 3. Create IPv6 address pool 1 and use IPv6 subnet 88:99:ffff:100::/64 defined by IPv6 prefix 3 and IPv6 sub-prefix 3ffe:501:ffff:100::/64 for dynamic allocation. The first 32 bits of the IPv6 subnet are determined by IPv6 prefix 3. The bits 33 to 64 of the IPv6 subnet are determined by the IPv6 sub-prefix and its length. The prefix length of the IPv6 subnet is the IPv6 sub-prefix length.
[Sysname-ipv6-pool-1] network prefix 3 3ffe:501:ffff:100::/64
address range
display ipv6 pool
forbidden-address
temporary address range
option
Use option to configure a self-defined DHCPv6 option in an IPv6 address pool.
Use undo option to remove a self-defined DHCPv6 option from an IPv6 address pool.
option code hex hex-string
undo option code
No self-defined DHCPv6 option is configured in an IPv6 address pool.
code: Specifies a number for the self-defined option, in the range of 21 to 65535, excluding 25 through 26, 37 through 40, and 43 through 48.
hex hex-string: Specifies the content of the option, a hexadecimal number whose length is an even number in the range of 2 to 256.
The DHCPv6 server fills the self-defined option with the specified hexadecimal number and sends it in a response to the client.
You can self-define options for the following purposes:
· Add newly released options.
· Add options for which the vendor defines the contents, for example, Option 43.
· Add options for which the CLI does not provide a dedicated configuration command like dns-server. For example, you can use the option 31 hex 02000000000000000000000000000001 command to define the NTP server address 200::1 for DHCPv6 clients.
If a DHCPv6 option is specified by both the dedicated command and the option command, the DHCPv6 server preferentially assigns the content specified by the dedicated command. For example, if a DNS server address is specified by the dns-server command and the option 23 command, the server uses the address specified by dns-server command.
If you execute this command multiple times with the same code specified, the most recent configuration takes effect.
# Configure Option 23 that specifies a DNS server address 2001:f3e0::1 in IPv6 address pool 1.
[Sysname-ipv6-pool-1] option 23 hex 2001f3e0000000000000000000000001
display ipv6 pool
dns-server
domain-name
sip-server
option-group
Use option-group to specify a DHCPv6 option group for an IPv6 address pool.
Use undo option-group to restore the default.
undo option-group
No DHCPv6 option group is specified for an IPv6 address pool.
option-group--number: Specifies a DHCPv6 option group by its number in the range of 1 to 100.
# Specify DHCPv6 option group 1 for IPv6 address pool 1.
[Sysname-ipv6-pool-1] option-group 1
display ipv6 pool
pd-in-use threshold
Use pd-in-use threshold to set the prefix usage threshold for an IPv6 address pool.
Use undo pd-in-use threshold to restore the default.
pd-in-use threshold threshold-value
The prefix usage threshold for an IPv6 address pool is 100%.
threshold-value: Specifies a prefix usage threshold, in percentage. The value range for this argument is 0 to 100.
The messages generated by the DHCPv6 module varies by threshold as follows:
· If you set the prefix usage threshold to a value less than 100%, the DHCPv6 module sends a message to the SNMP module and a log message to the information center when one of the following events occurs:
¡ The prefix usage of the IPv6 pool reaches or exceeds the threshold.
¡ The prefix usage of the IPv6 pool drops below 90% of the threshold after a threshold violation.
· If you set the prefix usage threshold to 0% or 100%, the DHCPv6 module will not generate any alarm notification or log message for a threshold crossing event.
To enable the DHCPv6 module to send alarm notifications about the above events, use the snmp-agent trap enable ipv6 dhcp server command to enable SNMP notifications for the DHCPv6 server.
# Set the prefix usage threshold to 75% for IPv6 address pool pool1.
[Sysname-ipv6-pool-pool1] pd-in-use threshold 75
display ipv6 pool
pool
Use pool to add an IPv6 address pool to the IPv6 address pool group.
Use undo pool to remove an IPv6 address pool from the IPv6 address pool group.
pool pool-name [ priority priority-value ]
undo pool [ pool-name ]
No IPv6 address pools exist in an IPv6 address pool group.
pool-name: Specifies an IPv6 address pool name, a case-insensitive string of 1 to 63 characters. The undo pool command removes all IPv6 address pools from the IPv6 address pool group if you do not specify this argument.
priority priority-value: Specifies the priority of the IPv6 address pool. The value range is 0 to 65535, and the default value is 0. A smaller value represents a higher priority.
For a user that matches an IPv6 address pool group, the DHCPv6 server selects an IPv6 address from an available IPv6 address pool in the IPv6 address pool group according to the descending order of the IPv6 address pool priority. If multiple IPv6 address pools share the same priority, the server selects the pool displayed first in the output from the display ipv6 pool-group command.
An IPv6 address pool supports a maximum of 1024 IPv6 address pools. An IPv6 address pool can be added to multiple address pool groups.
Before you add an IPv6 address pool to an address pool group, make sure the IPv6 address pool is on the public network or in the same VPN instance as the address pool group.
Before you remove an IPv6 address pool from an IPv6 address pool group, make sure the IPv6 address pool has not assigned any IPv6 addresses.
# Create an IPv6 address pool named poolgroup1, and assign IPv6 address pool pool1 to the address pool group.
[Sysname-ipv6-pool-group-poolgroup1] pool pool1
ipv6 pool-group
prefix-pool
Use prefix-pool to apply a prefix pool to an IPv6 address pool, so the DHCPv6 server can dynamically select a prefix from the prefix pool for a client.
Use undo prefix-pool to remove the prefix pool.
prefix-pool prefix-pool-number [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ] [ export-route [ preference preference | tag tag ] * ]
undo prefix-pool prefix-pool-number
No prefix pool is applied to an IPv6 address pool.
prefix-pool-number: Specifies a prefix pool by its number in the range of 1 to 128.
preferred-lifetime preferred-lifetime: Sets the preferred lifetime in the range of 60 to 4294967295 seconds. The default value is 604800 seconds (7 days).
valid-lifetime valid-lifetime: Sets the valid lifetime in the range of 60 to 4294967295 seconds. The default value is 2592000 seconds (30 days). The valid lifetime must be longer than or equal to the preferred lifetime.
export-route: Advertises prefixes assigned to DHCPv6 clients. If you do not specify this keyword, the prefixes will not be advertised.
preference preference: Sets a route preference, in the range of 1 to 255. The default preference is 65.
tag tag: Sets a tag value in the range of 0 to 4294967295. The default tag value is 0. Tags are route identifications for routing policies to filter routes. For more information about routing policies, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
Only one prefix pool can be applied to an address pool.
You can apply a prefix pool that has not been created to an address pool. The setting takes effect after the prefix pool is created.
To modify the prefix pool in an IPv6 address pool, execute the undo prefix-pool command to remove the prefix pool, and then execute the prefix-pool command.
If you configure only the ipv6 dhcp advertise pd-route command without configuring the prefix advertisement, the DHCPv6 server advertises only prefixes matching the assign-len assign-len argument.
If you have configured the prefix advertisement, the routes of the advertised prefixes matching the assign-len assign-len argument carry the default route preference and tag value and cannot be redistributed to other routing protocols. The route of advertised original prefix that match the prefix-number or prefix/prefix-len argument in the prefix pool carries the configured route preference and tag value.
The preference preference and tag tag options take effect only on the prefix routes that are assigned after you execute this command.
If you specify the export-route keyword in both the prefix-pool and network commands, make sure the prefix in the network command is different from the prefix in the prefix pool. Otherwise, the advertised prefix route will be the same as the advertised address route, and users will become unreachable.
# Apply prefix pool 1 to address pool 1, and use the default preferred lifetime and valid lifetime.
[Sysname] ipv6 pool 1
[Sysname-ipv6-pool-1] prefix-pool 1
# Apply prefix pool 2 to address pool 2, and set the preferred lifetime to one day and the valid lifetime to three days.
[Sysname] ipv6 pool 2
[Sysname-ipv6-pool-2] prefix-pool 2 preferred-lifetime 86400 valid-lifetime 259200
# Remove prefix pool 1 from address pool 1.
[Sysname-ipv6-pool-1] undo prefix-pool 1
display ipv6 pool
forbidden-prefix
reserve expired-ipv6-address enable
Use reserve expired-ipv6-address enable to enable IPv6 address reservation in an IPv6 address pool.
Use undo reserve expired-ipv6-address enable to disable IPv6 address reservation in an IPv6 address pool.
IPv6 address reservation is enabled.
This feature enables the DHCPv6 server to reserve IPv6 addresses for clients that are going offline. When a client goes offline, the DHCPv6 server reserves the client IPv6 address as an expired lease. When the client comes online again, the DHCPv6 server assigns the IPv6 address in the reserved lease to the client.
Disable the IPv6 address reservation feature if you want the DHCPv6 server to reclaim IPv6 addresses immediately after clients go offline.
# Disable IPv6 address reservation in IPv6 address pool 0.
[Sysname] ipv6 pool 0
[Sysname-ipv6-pool-0] undo reserve expired-ipv6-address enable
reserve expired-ipv6-address mode
Use reserve expired-ipv6-address mode to configure the IPv6 address reservation mode in an IPv6 address pool.
Use undo reserve expired-ipv6-address mode to restore the default.
reserve expired-ipv6-address mode { duid | mac } [ limit limit-number | time time ] *
With IPv6 address reservation enabled, a DHCPv6 server reserves IPv6 addresses based on DUIDs.
duid: Reserves IPv6 addresses based on DUIDs.
mac: Reserves IPv6 addresses based on client MAC addresses.
limit limit-number: Specifies the maximum number of IPv6 addresses that can be reserved in an IPv6 address pool. The value range is 1 to 2560000, and the default value is 256000.
time time: Specifies the reservation time for expired IPv6 addresses, in the range of 60 to 4294967295 seconds. If you do not specify this option or set the reservation time to 4294967295 seconds, the reservation time equals the valid lifetime specified in the IPv6 address pool.
With IPv6 address reservation enabled, the DHCPv6 server reserves IPv6 addresses for DHCP clients in the following modes:
· Reservation based on DUIDs—The DHCPv6 server records the IP-to-DUID bindings for online clients. When these clients come online again, the server assigns them the IPv6 addresses in the bindings based on their DUIDs.
· Reservation based on client MAC addresses—The DHCPv6 server records the IP-to-MAC bindings for online clients. When these clients come online again, the server assigns them the IPv6 addresses in the bindings based on their MAC addresses.
L2TP users do not support address reservation based on client MAC addresses.
When you change the IPv6 address reservation mode, the device deletes all expired IPv6 address leases that are saved in the old reservation mode.
# Configure the DHCPv6 server to reserve IPv6 addresses based on DUIDs in IPv6 address pool 0.
[Sysname-ipv6-pool-0] reserve expired-ipv6-address enable
[Sysname-ipv6-pool-0] reserve expired-ipv6-address mode duid
reserve expired-pd enable
Use reserve expired-pd enable to enable IPv6 prefix reservation in an IPv6 address pool.
Use undo reserve expired-pd enable to disable IPv6 prefix reservation in an IPv6 address pool.
IPv6 prefix reservation is enabled.
This feature enables the DHCPv6 server to reserve IPv6 prefixes for clients that are going offline. When a client goes offline, the DHCPv6 server reserves the client IPv6 prefix as an expired lease. When the client comes online again, the DHCPv6 server assigns the IP prefix in the reserved lease to the client.
Disable the IPv6 prefix reservation feature if you want the DHCPv6 server to reclaim IPv6 prefix immediately after clients go offline.
# Disable IPv6 prefix reservation in IPv6 address pool 0.
[Sysname-ipv6-pool-0] reserve expired-pd enable
display ipv6 dhcp server expired-pd
reserve expired-pd mode
Use reserve expired-pd mode to configure the IPv6 prefix reservation mode in an IPv6 address pool.
Use undo reserve expired-pd mode to restore the default.
reserve expired-pd mode { duid | mac } [ limit limit-number | time time ] *
With IPv6 prefix reservation enabled, a DHCPv6 server reserves IPv6 prefixes based on DUIDs.
duid: Reserves IPv6 prefixes based on DUIDs.
mac: Reserves IPv6 prefixes based on client MAC addresses.
limit limit-number: Specifies the maximum number of IPv6 prefixes that can be reserved in an IPv6 address pool. The value range is 1 to 2560000, and the default value is 256000.
time time: Specifies the reservation time for expired IPv6 prefixes, in the range of 60 to 4294967295 seconds. If you do not specify this option or set the reservation time to 4294967295 seconds, the reservation time equals the valid lifetime specified in the IPv6 address pool.
With IPv6 prefix reservation enabled, the DHCPv6 server reserves IPv6 prefixes for DHCPv6 clients in the following modes:
· Reservation based on client DUIDs—The DHCPv6 server records the IPv6 prefix-to-DUID bindings for online clients. When these clients come online again, the server assigns them the IPv6 prefixes in the bindings based on their DUIDs.
· Reservation based on client MAC addresses—The DHCPv6 server records the IPv6 prefix-to-MAC bindings for online clients. When these clients come online again, the server assigns them the IPv6 prefixes in the bindings based on their MAC addresses.
L2TP users do not support prefix reservation based on client MAC addresses.
When you change the IPv6 prefix reservation mode, the device deletes all expired IPv6 prefix leases that are saved in the old reservation mode.
# Configure the DHCPv6 server to reserve IPv6 prefixes based on DUIDs in IPv6 address pool 0.
[Sysname-ipv6-pool-0] reserve expired-pd mode duid
reset dhcpv6-access packet statistics
Use reset dhcpv6-access packet statistics to clear packet statistics for the DHCPv6 access module.
# Clear packet statistics for the DHCPv6 access module.
<Sysname> reset dhcpv6-access packet statistics
display dhcpv6-access packet statistics
reset ipv6 dhcp { address | locator | prefix } offline-record
Use reset ipv6 dhcp { address | locator | prefix } offline-record to clear DHCPv6 user offline records.
address: Specifies IPv6 address user offline records.
prefix: Specifies IPv6 prefix user offline records.
locator: Specifies SRv6 locator user offline records.
# Clear DHCPv6 address user offline records.
<Sysname> reset ipv6 dhcp address offline-record
display ipv6 dhcp address offline-record
display ipv6 dhcp prefix offline-record
display ipv6 dhcp srv6-locator offline-record
reset ipv6 dhcp pool-usage peak
Use reset ipv6 dhcp pool-usage peak to clear peak resource usage information for an IPv6 pool.
reset ipv6 dhcp pool-usage peak [ pool pool-name ]
pool pool-name: Specifies an IPv6 pool by its name. The pool-name argument is a case-insensitive string of 1 to 63 characters. If you do not specify this option, this command clears peak resource usage information for all IPv6 pools.
To clear peak resource usage information for all IPv6 pools, execute the reset dhcp pool-usage peak command without specifying an IP pool. Then, if you execute the display ipv6 dhcp pool-usage peak command again, the command displays the new peak resource usage data collected for each IP pool after you executed the reset command.
# Clear peak resource usage information for all IPv6 pools.
<Sysname> reset ipv6 dhcp pool-usage peak
reset ipv6 dhcp server conflict
Use reset ipv6 dhcp server conflict to clear IPv6 address conflict information.
reset ipv6 dhcp server conflict [ address start-ipv6-address [ end-ipv6-address ] ] [ vpn-instance vpn-instance-name ]
address start-ipv6-address [ end-ipv6-address ]: Clears conflict information for addresses in the specified IPv6 address range. If you do not specify an IPv6 address, this command clears all IPv6 address conflict information.
· start-ip-address: Specifies a start IPv6 address.
· end-ip-address: Specifies an end IPv6 address. The end IPv6 address cannot be lower than the start IPv6 address. If you do not specify this argument, this command clears conflict information for the start IPv6 address (if any).
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears conflict information about IPv6 addresses for the public network.
Address conflicts occur when dynamically assigned IPv6 addresses have been statically configured for other hosts. After the conflicts are resolved, you can use the reset ipv6 dhcp server conflict command to clear conflict information so that the conflicting addresses can be assigned to clients.
If you do not specify a keyword, this command clears all public-network IPv6 address conflict information on the device.
# Clear all public-network IPv6 address conflict information on the device.
<Sysname> reset ipv6 dhcp server conflict
display ipv6 dhcp server conflict
reset ipv6 dhcp server expired-ip
Use reset ipv6 dhcp server expired-ip to clear binding information for lease-expired IPv6 addresses.
reset ipv6 dhcp server expired-ip [ [ address start-ipv6-address [ end-ipv6-address ] ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
address start-ipv6-address [ end-ipv6-address ]: Clears binding information for lease-expired addresses in the specified IPv6 address range. If you do not specify an IPv6 address, this command clears binding information for all lease-expired IPv6 address.
· end-ip-address: Specifies an end IPv6 address. The end IPv6 address cannot be lower than the start IPv6 address. If you do not specify this argument, this command clears binding information for the start IPv6 address (if lease-expired).
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears binding information about lease-expired IPv6 addresses for the public network.
pool pool-name: Clears binding information for lease-expired IPv6 addresses in the address pool specified by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an address pool, this command clears binding information for lease-expired IPv6 addresses in all address pools.
If you do not specify a keyword, this command clears all public-network lease-expired IPv6 address bindings on the device.
# Clear binding information for expired IPv6 address 2001:f3e0::1.
<Sysname> reset ipv6 dhcp server expired-ip address 2001:f3e0::1
reset ipv6 dhcp server expired-pd
Use reset ipv6 dhcp server expired-pd to clear binding information for lease-expired IPv6 prefixes.
reset ipv6 dhcp server expired-pd [ pool pool-name | [ prefix start-prefix/prefix-len [ end-prefix/prefix-len ] ] [ vpn-instance vpn-instance-name ] ]
pool pool-name: Clears binding information for lease-expired IPv6 prefixes in the address pool specified by its name, a case-insensitive string of 1 to 63 characters.
prefix start-prefix/prefix-len [ end-prefix/prefix-len ]: Clears binding information for lease-expired prefixes in the specified IPv6 prefix range. The value range for the prefix-len argument is 1 to 128.
· start-prefix/prefix-len: Specifies a start IPv6 prefix.
· end-prefix/prefix-len: Specifies an end IPv6 prefix. The end IPv6 prefix cannot be lower than the start IPv6 prefix. The prefix length for the start IPv6 prefix and the end IPv6 prefix must be the same. If you do not specify this argument, this command clears binding information for the start IPv6 prefix (if lease-expired).
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears binding information about lease-expired IPv6 prefixes for the public network.
When a client goes offline, the client IPv6 prefix lease will become expired. You can use this command to clear binding information for lease-expired IPv6 prefixes.
If you do not specify any parameters, this command clears all public-network lease-expired IPv6 prefix bindings on the device.
# Clear all public-network lease-expired IPv6 prefix bindings.
<Sysname> reset ipv6 dhcp server expired-pd
reset ipv6 dhcp server ip-in-use
Use reset ipv6 dhcp server ip-in-use to clear binding information for assigned IPv6 addresses.
reset ipv6 dhcp server ip-in-use [ [ address start-ipv6-address [ end-ipv6-address ] | relay-address ipv6-address ] [ vpn-instance vpn-instance-name ] | pool pool-name [ relay-address ipv6-address ] ]
address start-ipv6-address [ end-ipv6-address ]: Clears binding information for addresses in the specified IPv6 address range. If you do not specify an IPv6 address, this command clears binding information for all assigned IPv6 addresses.
· end-ip-address: Specifies an end IPv6 address. The end IPv6 address cannot be lower than the start IPv6 address. If you do not specify this argument, this command clears binding information for the start IPv6 address (if any).
relay-address ipv6-address: Specifies the IPv6 address of a relay interface that connects to the DHCPv6 clients. This command clears the bindings that use this address as the gateway address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears binding information about assigned IPv6 addresses for the public network.
pool pool-name: Clears binding information for assigned IPv6 addresses in the IPv6 address pool specified by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool, this command clears binding information for assigned IPv6 addresses in IPv6 all address pools.
relay-address ip-address: Specifies the IPv6 address of a relay interface that connects to the DHCPv6 clients. This command clears the bindings that use this address as the gateway address in the IPv6 address pool.
NOTE: · A formal address binding is a committed binding whose IPv6 address has been assigned to a DHCPv6 client either dynamically or statically. · A temporary address binding is an offered binding whose IPv6 address has been selected and sent by the DHCPv6 server to a DHCPv6 client in response to the Solicit message of that client. |
When this command clears binding information for an assigned IPv6 address, it clears both formal and temporary bindings for that address.
If no parameters are specified, this command clears all public-network address bindings on the device.
If you execute this command to clear information about an assigned static binding, the static binding becomes a free static binding.
# Clear all IPv6 address bindings in the public network.
<Sysname> reset ipv6 dhcp server ip-in-use
This command will reclaim the IPv6 addresses and might make online users offline
. Continue?[Y/N]:
# Clears all IPv6 address bindings for IPv6 address pool 1.
<Sysname> reset ipv6 dhcp server ip-in-use pool 1
. Continue?[Y/N]:
# Clears binding information for IPv6 address 2001:0:0:1::1.
<Sysname> reset ipv6 dhcp server ip-in-use address 2001:0:0:1::1
. Continue?[Y/N]:
display ipv6 dhcp server ip-in-use
reset ipv6 dhcp server packet statistics
Use reset ipv6 dhcp server packet statistics to clear DHCPv6 server packet statistics.
reset ipv6 dhcp server packet statistics [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears DHCPv6 server packet statistics for the public network.
# Clear packet statistics for all DHCPv6 servers.
<Sysname> reset ipv6 dhcp server packet statistics
display ipv6 dhcp server packet statistics
reset ipv6 dhcp server pd-in-use
Use reset ipv6 dhcp server pd-in-use to clear binding information for assigned IPv6 prefixes.
reset ipv6 dhcp server pd-in-use [ pool pool-name [ relay-address ipv6-address ] | [ prefix start-prefix/prefix-len [ end-prefix/prefix-len ] | relay-address ipv6-address ] [ vpn-instance vpn-instance-name ] ]
pool pool-name: Clears binding information for assigned IPv6 prefixes in the IPv6 address pool specified by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool, this command clears binding information for assigned IPv6 prefixes in all IPv6 address pools.
relay-address ipv6-address: Specifies the IPv6 address of a relay interface that connects to the DHCPv6 clients. This command clears the prefix bindings that use this address as the gateway address in the IPv6 address pool.
prefix start-prefix/prefix-len [ end-prefix/prefix-len ]: Clears binding information for prefixes in the specified assigned IPv6 prefix range. The value range for the prefix-len argument is 1 to 128. If you do not specify an IPv6 prefix, this command clears binding information for all assigned IPv6 prefixes.
· start-prefix/prefix-len: Specifies a start IPv6 prefix .
· end-prefix/prefix-len: Specifies an end IPv6 prefix. The end IPv6 prefix cannot be lower than the start IPv6 prefix. The prefix length for the start IPv6 prefix and the end IPv6 prefix must be the same. If you do not specify this argument, this command clears binding information for the start IPv6 prefix (if any).
relay-address ip-address: Specifies the IPv6 address of a relay interface that connects to the DHCPv6 clients. This command clears the prefix bindings that use this address as the gateway address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears binding information about assigned IPv6 prefixes for the public network.
NOTE: · A formal prefix binding is a committed binding whose IPv6 prefix has been assigned to a DHCPv6 client either dynamically or statically. · A temporary prefix binding is an offered binding whose IPv6 prefix has been selected and sent by the DHCPv6 server to a DHCPv6 client in response to the Solicit message of that client. |
When this command clears binding information for an assigned IPv6 prefix, it clears both formal and temporary bindings for that prefix.
If no parameters are specified, this command clears all public-network prefix bindings on the device.
# Clear all IPv6 prefix bindings in the public network.
<Sysname> reset ipv6 dhcp server pd-in-use
This command will reclaim the IPv6 prefixes and might make online users offline.
Continue?[Y/N]:
# Clears all IPv6 prefix bindings for IPv6 address pool 1.
<Sysname> reset ipv6 dhcp server pd-in-use pool 1
Continue?[Y/N]:
# Clears binding information for IPv6 prefix 2001:0:0:1::/64.
<Sysname> reset ipv6 dhcp server pd-in-use prefix 2001:0:0:1::/64
Continue?[Y/N]:
display ipv6 dhcp server pd-in-use
reset ipv6 dhcp server srv6-locator-in-use
Use reset ipv6 dhcp server srv6-locator-in-use to clear binding information for assigned SRv6 locators.
reset ipv6 dhcp server srv6-locator-in-use [ pool pool-name [ relay-address ipv6-address ] | [ locator start-prefix/prefix-len [ end-prefix/prefix-len ] | relay-address ipv6-address ] [ vpn-instance vpn-instance-name ] ]
pool pool-name: Clears binding information for assigned SRv6 locators in the IPv6 address pool specified by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an IPv6 address pool, this command clears binding information for assigned IPv6 SRv6 locators in all IPv6 address pools.
relay-address ipv6-address: Specifies the IPv6 address of a relay interface that connects to the DHCPv6 clients. This command clears the SRv6 locator bindings that use this address as the gateway address in the IPv6 address pool.
locator start-prefix/prefix-len [ end-prefix/prefix-len ]: Clears binding information for SRv6 locators in the specified assigned IPv6 prefix range. The value range for the prefix-len argument is 1 to 128. If you do not specify an IPv6 prefix, this command clears binding information for all assigned SRv6 locators.
relay-address ip-address: Specifies the IPv6 address of a relay interface that connects to the DHCPv6 clients. This command clears the SRv6 locator bindings that use this address as the gateway address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears binding information about assigned SRv6 locators for the public network.
NOTE: · A formal SRv6 locator binding is a committed binding whose SRv6 locator has been assigned to a DHCPv6 client either dynamically or statically. · A temporary SRv6 locator binding is an offered binding whose SRv6 locator has been selected and sent by the DHCPv6 server to a DHCPv6 client in response to the Solicit message of that client. |
When this command clears binding information for an assigned SRv6 locator, it clears both formal and temporary bindings for that locator.
# Clear all SRv6 locator bindings in the public network.
<Sysname> reset ipv6 dhcp server srv6-locator-in-use
This command will reclaim Srv6 locators and might make online users offline.
Continue?[Y/N]:
# Clears all SRv6 locator bindings for IPv6 address pool 1.
<Sysname> reset ipv6 dhcp server srv6-locator-in-use pool 1
Continue?[Y/N]:
# Clears binding information for SRv6 locator 2001:0:0:1::/64.
<Sysname> reset ipv6 dhcp server srv6-locator-in-use prefix 2001:0:0:1::/64
Continue?[Y/N]:
display ipv6 dhcp server srv6-locator-in-use
route-log enable
Use route-log enable to enable route logging for an IPv6 address pool.
Use undo route-log enable to disable route logging for an IPv6 address pool.
route-log enable
Route logging is disabled for an IPv6 address pool.
IPv6 pool view
After you enable this feature for an IPv6 address pool, the DHCPv6 server generates log messages for route events that occur in the IPv6 address pool. Route events include network route adding or deletion.
To enable route logging for IPv6 address pools, use one of the following commands:
· ipv6 dhcp route-log enable
This command enables route logging for all types of IPv6 address pools on the DHCPv6 server.
· route-log enable
This command enables route logging for a single IPv6 address pool on the DHCPv6 server. To enable route logging for only one IPv6 address pool, perform the following task:
a. Verify that route logging is disabled for all IPv6 address pools on the DHCPv6 server.
b. You can use the undo ipv6 dhcp route-log enable command to disable route logging for all IPv6 address pools.
c. Use the route-log enable command in the view of the target IPv6 address pool.
# Enable route logging for IPv6 address pool 1.
[Sysname-ipv6-pool-1] route-log enable
sip-server
Use sip-server to specify the IPv6 address or domain name of a SIP server in the IPv6 address pool.
Use undo sip-server to remove a SIP server.
sip-server { address ipv6-address | domain-name domain-name }
undo sip-server { address ipv6-address | domain-name domain-name }
No SIP server address or domain name is specified.
DHCPv6 option group view
address ipv6-address: Specifies the IPv6 address of a SIP server.
domain-name domain-name: Specifies the domain name of a SIP server, a case-insensitive string of 1 to 50 characters.
You can specify up to eight SIP server addresses and eight SIP server domain names in an address pool. A SIP server that is specified earlier has a higher preference.
# Specify the SIP server address 2:2::4 in IPv6 address pool 1.
[Sysname-ipv6-pool-1] sip-server address 2:2::4
# Specify the SIP server domain name example.com in IPv6 address pool 1.
[Sysname-ipv6-pool-1] sip-server domain-name example.com
display ipv6 pool
Use snmp-agent trap enable ipv6 dhcp server to enable SNMP notifications for the DHCPv6 server.
Use undo snmp-agent trap enable ipv6 dhcp server to disable SNMP notifications for the DHCPv6 server.
snmp-agent trap enable ipv6 dhcp server [ address-exhaust | ip-alloc-failed | ip-in-use | pd-alloc-failed | pd-exhaust | pd-in-use | pool-group-exhaust | pool-group-threshold ] *
undo snmp-agent trap enable ipv6 dhcp server [ address-exhaust | ip-alloc-failed | ip-in-use | pd-alloc-failed | pd-exhaust | pd-in-use | pool-group-exhaust | pool-group-threshold ] *
SNMP notifications are enabled for the DHCPv6 server.
address-exhaust: Generates alarm notifications for IPv6 address exhaustion events. IPv6 address exhaustion events include address exhaustion alarms and recoveries from address exhaustion conditions.
ip-alloc-failed: Generates alarm notifications for IPv6 address allocation failure.
pd-alloc-failed: Generates alarm notifications for IPv6 prefix allocation failure.
ip-in-use: Generates IPv6 address usage notifications. An IPv6 address usage notification is generated when an IPv6 address usage event occurs. IPv6 address usage events include alarms of address usage threshold violation and recoveries from threshold violation conditions. If you specify this keyword, the DHCPv6 server will poll the IPv6 address usage of each IPv6 pool at specific intervals. The IPv6 address usage threshold is set by using the ip-in-use threshold command.
pd-exhaust: Generates alarm notifications for IPv6 prefix exhaustion events. An IPv6 prefix exhaustion notification is generated when all IPv6 prefixes in an IPv6 address pool are used up or when an IPv6 address pool recovers from an IPv6 prefix exhaustion condition.
pd-in-use: Generates prefix usage notifications. A prefix usage notification is generated when an IPv6 prefix usage event occurs. IPv6 prefix usage events include alarms of prefix usage threshold violation and recoveries from threshold violation conditions. If you specify this keyword, the DHCPv6 server will poll the prefix usage of each IPv6 pool at specific intervals. The prefix usage threshold is set by using the pd-in-use threshold command.
pool-group-exhaust: Generates alarm notifications for IPv6 address exhaustion events. IPv6 address exhaustion events include address exhaustion alarms and recoveries from address exhaustion conditions.
pool-group-threshold: Generates IPv6 address usage notifications. An IPv6 address usage notification is generated when an IPv6 address usage event occurs. IPv6 address usage events include alarms of address usage threshold violation and recoveries from threshold violation conditions. The address usage threshold is set by using the ip-in-use threshold command.
If you do not specify any parameters, this command enables SNMP notifications for all types of DHCPv6 server events.
To report critical DHCPv6 server events, enable SNMP notifications for the DHCPv6 server. For DHCPv6 server event notifications to be sent correctly, you must also configure SNMP on the device. For more information about configuring SNMP, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for all types of events.
[Sysname] snmp-agent trap enable ipv6 dhcp server
# Enable SNMP IPv6 address exhaustion notifications.
[Sysname] snmp-agent trap enable ipv6 dhcp server address-exhaust
# Enable SNMP IPv6 address usage alarm notifications.
[Sysname] snmp-agent trap enable ipv6 dhcp server ip-in-use
# Enable SNMP IPv6 prefix exhaustion alarm notifications.
[Sysname] snmp-agent trap enable ipv6 dhcp server pd-exhaust
# Enable SNMP IPv6 prefix usage alarm notifications.
[Sysname] snmp-agent trap enable ipv6 dhcp server pd-in-use
ip-in-use threshold
pd-in-use threshold
snmp-agent target-host (Network Management and Monitoring Command Reference)
srv6-locator-pool
Use srv6-locator-pool to apply a prefix pool to an IPv6 address pool, so the DHCPv6 server can use that prefix pool for dynamic SRv6 locator assignment to DHCPv6 clients.
Use undo srv6-locator-pool to remove the prefix pool.
srv6-locator-pool prefix-pool-number [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ] [ args args-length | locator-block locator-block-length ] * [ export-route [ preference preference | tag tag ] * ]
undo srv6-locator-pool prefix-pool-number
No prefix pool is applied to an IPv6 address pool for dynamic SRv6 locator assignment.
export-route: Advertises the prefix range in specified prefix pool. If you specify this keyword, the DHCPv6 server issues the route destined for the prefix range to the routing management module. The issued route is used to direct downlink traffic. If you do not specify this keyword, the prefix range route will not be advertised.
tag tag: Sets a tag value in the range of 0 to 4294967295. The default tag value is 0. Tags are used by routing policies to filter routes. For more information about routing policies, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
args args-length: Specifies the Args portion length for SRv6 SIDs assigned from the specified prefix pool. The value range for the args-length argument depends on the assign-length value configured in the specified prefix pool. The maximum value for the args-length argument must be smaller than 128 minus the assign-length value. If you do not specify the args-length argument, the Args portion length is set to 0.
locator-block locator-block-length: Specifies the common prefix length for SRv6 locators in the specified prefix pool. The value range for the locator-block-length argument depends on the assign-length value configured in the specified prefix pool. The maximum value for the locator-block-length argument cannot exceed the assign-length value. If you do not specify the locator-block-length argument, the common prefix length is set to 0.
Application scenarios
In SRv6 networks, an SRv6 locator is an IPv6 prefix that identifies the network segment to which an segment routing identifier (SRv6 SID) belongs. For more information about SRv6 locators, see SRv6 configuration in Segment Routing Configuration Guide.
In large-scale networks, manual SRv6 locator assignment is always laborious. To simplify SRv6 locator assignment, you can use this command to apply a prefix pool as SRv6 locator pool. The DHCPv6 server can then use that SRv6 locator pool for dynamic SRv6 locator assignment to DHCPv6 clients, which improves the efficiency of network deployment and management.
Use the ipv6 dhcp prefix-pool command to create the prefix pool that will be used as SRv6 locator pool.
· An IPv6 address pool can have up to one SRv6 locator pool.
· A prefix pool can be applied to an address pool only once. It can act as either a common prefix pool or SRv6 locator pool, but not simultaneously. However, an IPv6 address pool can have both a common prefix pool and an SRv6 locator pool.
· You cannot apply a new SRv6 locator pool to an IPv6 address pool by repeating this command. To change the SRv6 locator pool in an IPv6 address pool:
a. Execute the undo srv6-locator-pool command to remove the prefix pool.
b. Execute the srv6-locator-pool command with the new prefix pool specified.
· When you configure the export-route keyword, follow these restrictions and guidelines:
¡ If you execute the ipv6 dhcp advertise srv6-locator-route command without specifying the export-route keyword, the DHCPv6 server advertises only routes destined for the SRv6 locators matching the assign-len assign-len argument.
¡ If you specify the export-route keyword, routes destined for the SRv6 locators matching the assign-len assign-len argument carry the default route preference and tag value. Those routes cannot be redistributed to other routing protocols. The route destined for the prefix range that matches the prefix-number or prefix/prefix-len argument carries the configured route preference and tag value.
¡ If you specify the export-route keyword in both the srv6-locator-pool and network commands, make sure the prefix specified in the network command is different from that specified in the SRv6 locator pool. If this requirement is not met, the advertised SRv6 locator route will be the same as the advertised address route. As a result, the related SID users or address users will be unreachable.
# Apply prefix pool 1 to address pool 1 for dynamic SRv6 locator assignment, and use the default preferred lifetime and valid lifetime.
[Sysname-ipv6-pool-1] srv6-locator-pool 1
# Apply prefix pool 2 to address pool 2 for dynamic SRv6 locator assignment, and set the preferred lifetime to one day and the valid lifetime to three days.
[Sysname-ipv6-pool-2] srv6-locator-pool 2 preferred-lifetime 86400 valid-lifetime 259200
display ipv6 pool
static-bind
Use static-bind to statically bind an IPv6 address or prefix to a client in the IPv6 address pool.
Use undo static-bind to delete a static binding.
static-bind { address ipv6-address/addr-prefix-length | prefix prefix/prefix-len } duid duid [ iaid iaid ] [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
undo static-bind { address ipv6-address/addr-prefix-length | prefix prefix/prefix-len }
No static binding is configured in an IPv6 address pool.
Common IPv6 address pool view
address ipv6-address/addr-prefix-length: Specifies the IPv6 address and prefix length. The value range for the prefix length is 1 to 128. You can set the prefix length to 128 only for the BRAS network.
prefix prefix/prefix-len: Specifies the prefix and prefix length. The value range for the prefix length is 1 to 128.
duid duid: Specifies a client DUID. The value is an even hexadecimal number in the range of 2 to 256. BRAS users do not support this option.
iaid iaid: Specifies a client IAID. The value is a hexadecimal number in the range of 0 to FFFFFFFF. If you do not specify an IAID, the server does not match the client IAID for prefix assignment.
preferred-lifetime preferred-lifetime: Sets the preferred lifetime of the address or prefix. The value range is 60 to 4294967295 seconds, and the default is 604800 seconds (7 days).
valid-lifetime valid-lifetime: Sets the valid lifetime of the address or prefix. The value range is 60 to 4294967295 seconds, and the default is 2592000 seconds (30 days). The valid lifetime cannot be shorter than the preferred lifetime.
When you configure a static binding in an IPv6 address pool, make sure the IPv6 address or prefix is within an address range or prefix range specified for dynamic address allocation in that address pool.
To avoid unexpected user offline events, do not specify any dynamically assigned IPv6 addresses or prefixes in this command.
If an IPv6 address or prefix is already excluded from dynamic DHCPv6 allocation, you cannot use this command to configure a static DHCPv6 binding for that IPv6 address or prefix. To exclude an IPv6 address from dynamic DHCPv6 address allocation, use the ipv6 dhcp server forbidden-address command. To exclude an IPv6 prefix from dynamic DHCPv6 prefix allocation, use the ipv6 dhcp server forbidden-prefix command.
You can specify multiple static bindings in an IPv6 address pool.
An IPv6 address or prefix can be bound to only one DHCPv6 client.
To modify a static binding, execute the undo static-bind command to delete the binding, and then execute the static-bind command.
This command is not supported in common IPv6 address pools that are configured with the remote-server command and act as DHCPv6 relay address pools.
# In address pool 1, bind IPv6 address 2001:0410::/35 to the client DUID 0003000100e0fc005552 and IAID A1A1A1A1.
[Sysname-ipv6-pool-1] static-bind address 2001:0410::1/35 duid 0003000100e0fc005552 iaid A1A1A1A1
# In address pool 1, bind prefix 2001:0410::/35 to the client DUID 00030001CA0006A400 and IAID A1A1A1A1.
[Sysname-ipv6-pool-1] static-bind prefix 2001:0410::/35 duid 00030001CA0006A400 iaid A1A1A1A1
display ipv6 pool
Use temporary address range to configure a temporary IPv6 address range in an IPv6 address pool for dynamic allocation.
Use undo temporary address range to restore the default.
temporary address range start-ipv6-address end-ipv6-address [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
No temporary IPv6 address range is configured in an IPv6 address pool.
start-ipv6-address: Specifies the start IPv6 address.
end-ipv6-address: Specifies the end IPv6 address.
valid-lifetime valid-lifetime: Sets the valid lifetime. The value range is 60 to 4294967295 seconds, and the default is 2592000 seconds (30 days). The valid lifetime cannot be shorter than the preferred lifetime.
If you do not execute the temporary address range command, the DHCPv6 server does not support temporary address assignment.
You can configure only one temporary IPv6 address range in an address pool. If you execute this command multiple times, the most recent configuration takes effect.
# In IPv6 address pool 1, configure a temporary IPv6 address range from 3ffe:501:ffff:100::50 to 3ffe:501:ffff:100::60.
[Sysname-ipv6-pool-1] temporary address range 3ffe:501:ffff:100::50 3ffe:501:ffff:100::60
display ipv6 pool
address range
network
unr preference
Use unr preference to set an IPv6 UNR preference value for an IPv6 address pool.
Use undo unr preference to restore the default.
unr preference preference-value
undo unr preference
The IPv6 UNR preference value is 65 for an IPv6 address pool.
preference-value: Sets a UNR preference value. The value range for this argument is 1 to 255.
When the DHCPv6 server assigns an IPv6 address, it adds the network route for the IPv6 address to the route management module. A smaller UNR preference value indicates a higher priority.
The preference value modification does not affect the preference value for network routes that have been advertised.
# Set the UNR preference value to 1 for IPv6 address pool p1.
[Sysname] ipv6 pool p1 bas local
[Sysname-ipv6-pool-p1] unr preference 1
unr tag
Use unr tag to set a UNR tag value for an IPv6 address pool.
Use undo unr tag to restore the default.
unr tag tag-value
undo unr
No UNR value is set for an IPv6 address pool.
tag-value: Sets a UNR tag value, in the range of 0 to 4294967294.
When the DHCPv6 server assigns an IP address, it adds the network route for the IP address to the route management module. In a BAS network, you can classify user network routes based on their UNR tag values for route redistribution.
# Set the network route tag value to 1 for IPv6 address pool p1.
[Sysname-ipv6-pool-p1] unr tag 1
vpn-instance (IPv6 address pool view)
Use vpn-instance to apply an IPv6 address pool to a VPN instance.
Use undo vpn-instance to restore the default.
undo vpn-instance
The IPv6 address pool is not applied to any VPN instance.
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the IPv6 address pool belongs to the public network.
If an IPv6 address pool is applied to a VPN instance, the DHCPv6 server assigns IPv6 addresses in this address pool to clients in the specified VPN instance.
The DHCPv6 server identifies the VPN instance to which a DHCPv6 client belongs according to the following information:
· The client's VPN information stored in authentication modules, such as IPoE.
· The VPN information of the DHCPv6 server's interface that receives DHCPv6 packets from the client.
The VPN information from authentication modules takes priority over the VPN information of the receiving interface.
For an IPv6 address pool that has been applied to a VPN instance, the prefix pool specified in the srv6-locator-pool command must belong to that VPN instance. With the srv6-locator-pool command executed, the IPv6 address pool cannot be unbound from the VPN instance unless the public network has a prefix pool with the same name as the specified prefixed pool.
# Apply IPv6 address pool 0 to the VPN instance abc.
[Sysname-ipv6-pool-0] vpn-instance abc
vpn-instance (IPv6 address pool group view)
Use vpn-instance to apply an IPv6 address pool group to a VPN instance.
undo vpn-instance
The IPv6 address pool group is not applied to any VPN instance.
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the VPN instance is not created when you execute this command, the command can be successfully executed, but it does not take effect.
If an IPv6 address pool group is applied to a VPN instance, the address pool group provides DHCPv6 services for DHCPv6 clients in the specified VPN instance. If an IPv6 address pool group is not applied to a VPN instance, the address pool group provides DHCPv6 services for DHCPv6 clients on the public network.
# Apply IPv6 address pool group g1 to VPN instance abc.
[Sysname]ipv6 pool-group g1
[Sysname-ipv6-pool-group-g1] vpn-instance abc
Old-style DHCPv6 server commands
This chapter introduces the old-style commands reserved for network management system (NMS) software compatibility. They are usable when the following conditions exist:
· The NMS software does not support the related new-style commands.
· Users want to use old-style commands for BRAS management purposes.
ipv6 dhcp pool
Use ipv6 dhcp pool to create a DHCPv6 address pool and enter its view, or enter the view of an existing DHCPv6 address pool.
Use undo ipv6 dhcp pool to delete a DHCPv6 address pool.
ipv6 dhcp pool pool-name
undo ipv6 dhcp pool pool-name
No DHCPv6 address pools exist.
pool-name: Specifies a DHCPv6 address pool name, a case-insensitive string of 1 to 63 characters.
A BRAS might require software upgrade to provide support for new features, meeting the needs of business development. After software upgrade, the syntaxes of some configuration commands might change. To manage the upgraded BRAS without upgrading the NMS software, execute the bras compatible old-style-commands enable command to enable compatibility with old-style commands on the BRAS.
If compatibility with old-style commands is enabled on the BRAS, you cannot execute the new-style commands. If compatibility with old-style commands is disabled on the BRAS, you cannot execute the old-style commands.
Operating mechanism
A DHCPv6 address pool supports configuring IPv6 addresses, prefixes, and other network settings. The DHCPv6 server can assign those configurations to DHCPv6 clients.
# Create DHCPv6 address pool pool1 and enter its view.
[Sysname] ipv6 dhcp pool pool1
bras compatible old-style-commands enable (BRAS Services Command Reference)
ipv6 pool (new style)
ipv6 dhcp pool-group
Use ipv6 dhcp pool-group to create a DHCPv6 address pool group and enter its view, or enter the view of an existing DHCPv6 address pool group.
Use undo ipv6 dhcp pool-group to delete a DHCPv6 address pool group.
ipv6 dhcp pool-group pool-group-name
undo ipv6 dhcp pool-group pool-group-name
No DHCPv6 address pool groups exist.
pool-group-name: Specifies a DHCPv6 address pool group name, a case-insensitive string of 1 to 63 characters.
Operating mechanism
For a DHCPv6 client that matches a DHCPv6 address pool group, the DHCPv6 server selects an IP address from an available address pool in the matching address pool group.
# Create DHCPv6 address pool group poolgroup1 and enter its view.
[Sysname] ipv6 dhcp pool-group poolgroup1
ipv6 pool-group (new style)
Use display ipv6 dhcp pool to display DHCPv6 address pool information.
display ipv6 dhcp pool [ all | name pool-name | pool-group pool-group-name | vpn-instance vpn-instance-name ] [ verbose ]
all: Displays information about all DHCPv6 address pools for the public network and VPN instances.
name pool-name: Specifies a DHCPv6 address pool by its name. The pool-name argument is a case-insensitive string of 1 to 63 characters.
pool-group pool-group-name: Specifies a DHCPv6 address pool group by its name. The pool-group-name argument is a case-insensitive string of 1 to 63 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCPv6 address pool information for the public network.
verbose: Displays detailed DHCPv6 address pool information. If you do not specify this keyword, the command displays brief DHCPv6 address pool information.
If you specify none of the name pool-name, pool-group pool-group-name, and vpn-instance vpn-instance-name options, this command displays information about all DHCPv6 address pools on the public network.
If compatibility with old-style commands is enabled on a BRAS by using the bras compatible old-style-commands enable command, the display ipv6 dhcp pool command displays information about DHCPv6 address pools on the BRAS as follows:
· Information supported by both the old and new styles is displayed in old style.
· Information supported by only the new style is displayed in new style.
# Display brief information about DHCPv6 address pool 1.
<Sysname> display ipv6 dhcp pool 1
DHCPv6 pool: 1 (lock strict)
Pool index: 1
Pool type: Common
Network: 3FFE:501:FFFF:100::/64
Preferred lifetime 604800 seconds, valid lifetime 2592000 seconds
reserve expired-ipv6-address mode duid time 4294967295 limit 256000
reserve expired-pd disable
reserve expired-pd mode duid time 4294967295 limit 256000
Prefix pool: 1
Preferred lifetime 24000 seconds, valid lifetime 36000 seconds
Addresses:
Range: from 3FFE:501:FFFF:100::1
to 3FFE:501:FFFF:100::99
Preferred lifetime 70480 seconds, valid lifetime 200000 seconds
Total address number: 153
Available: 153
In-use: 0
Temporary addresses:
Range: from 3FFE:501:FFFF:100::200
to 3FFE:501:FFFF:100::210
Preferred lifetime 60480 seconds, valid lifetime 259200 seconds
Total address number: 17
Available: 17
In-use: 0
Static bindings:
DUID: 0003000100e0fc000001
IAID: 0000003f
Prefix: 3FFE:501:FFFF:200::/64
DUID: 0003000100e0fc00cff1
IAID: 00000001
Address: 3FFE:501:FFFF:2001::1/64
PD-in-use threshold: 100
undo exhaustion log enable
exhaustion trap enable
undo allocate-new-ip enable
DNS server addresses:
2::2
Domain name:
aaa.example.com
AFTR name:
bbb.example.com
SIP server addresses:
5::1
SIP server domain names:
ccc.example.com
# Display detailed information about DHCPv6 address pool 1.
<Sysname> display ipv6 dhcp pool name 1 verbose
DHCPv6 pool: 1
Pool index: 1
Pool type: Common
Network: 1:1::/64
IPv6 address statistics
Total IPv6 addresses: 18446744073709551615
Free IPv6 addresses: 18446744073709551615
Used IPv6 addresses: 0
Total Prefixes: 0
Free Prefixes: 0
Used IPv6 prefixes: 0
IPv6 address usage: 0.00%
IPv6 prefix usage: 0.00%
Bindings:
IP-in-use: 0
PD-in-use: 0
Expired IP: 0
Expired PD: 0
Reserve IP: 0
Reserve PD: 0
Conflicts: 0
DHCPv6 pool (lock strict) |
Name of the DHCPv6 address pool. The field in parentheses represents the lock state of the DHCPv6 address pool. · lock—Locked in loose mode. The server responds to the lease renewal requests from online DHCPv6 clients for IPv6 addresses in the pool, but it does not assign IPv6 addresses from the pool to new DHCPv6 clients. · lock strict—Locked in strict mode. The server does not respond to the lease renewal requests from online DHCPv6 clients for IPv6 addresses in the pool or assign IPv6 addresses from the pool to new DHCPv6 clients. If you do not lock the DHCPv6 address pool, this command will not display lock state information. |
Pool group name |
Name of the DHCPv6 address pool group to which the address pool is added. If the address pool does not belong to any DHCPv6 address pool group, this field is not displayed. If the address pool belongs to multiple DHCPv6 address pool groups, each line displays only one DHCPv6 address pool group name. |
Network |
IPv6 subnet specified in the DHCPv6 address pool for dynamic IPv6 address allocation. If the subnet prefix is ineffective, this field displays Not-available. If the subnet prefix becomes ineffective after a configuration recovery (for example, a switchover from the backup to the master), the prefix is marked (Zombie). |
IPv6 address reservation is enabled for the DHCPv6 address pool. If this feature is disabled, this field displays reserve expired-ipv6-address disable. |
reserve expired-ipv6-address mode duid/mac time 4294967295 limit 256000 |
IPv6 address reservation mode, amount of time for expired IPv6 addresses to be reserved, and the maximum number of IPv6 addresses that can be reserved in the DHCPv6 address pool. In this example, the reservation mode is DUID or MAC address, the amount of reservation time is 4294967295 seconds, and the maximum number of IP addresses is 256000. |
reserve expired-pd disable |
IPv6 prefix reservation is disabled for the DHCPv6 address pool. If this feature is enabled, this field displays reserve expired-pd enable. |
reserve expired-pd mode duid/mac time 4294967295 limit 256000 |
IPv6 prefix reservation mode, amount of time for expired IPv6 prefixes to be reserved, and the maximum number of IPv6 prefixes that can be reserved in the DHCPv6 address pool. In this example, the reservation mode is DUID or MAC address, the amount of reservation time is 4294967295 seconds, and the maximum number of IP addresses is 256000. |
Prefix pool used by the DHCPv6 address pool. |
Preferred lifetime |
Preferred lifetime, in seconds. |
valid lifetime |
Valid lifetime, in seconds. |
Addresses |
Non-temporary IPv6 address range for dynamic allocation. |
Range |
Total address number |
Total number of IPv6 addresses in the DHCPv6 address pool. |
Available |
Total number of free IPv6 addresses in the DHCPv6 address pool. |
In-use |
Total number of assigned IPv6 addresses in the DHCPv6 address pool. |
Temporary addresses |
Temporary IPv6 address range for dynamic allocation. |
Static bindings |
Static IPv6 address or prefix bindings configured in the address pool. |
DUID |
Client DUID. |
IAID |
Client IAID. If no IAID is configured, this field displays Not configured. |
Prefix |
IPv6 address prefix. |
Address |
Static IPv6 address. |
exhaustion log enable |
IPv6 resource exhaustion logging is enabled to record IPv6 resource exhaustion events or recoveries from the resource exhaustion state. If this feature is disabled, this field displays undo exhaustion log enable. |
route-log enable |
Route logging is enabled for the DHCPv6 address pool. If route logging is disabled, this field displays undo route-log enable. |
IPv6 resource exhaustion alarming is enabled. If this feature is disabled, this field displays undo exhaustion trap enable. |
undo allocate-new-ip enable |
Random IPv6 address allocation is disabled. If this feature is enabled, this field displays allocate-new-ip enable. |
IP-in-use threshold |
IPv6 address usage threshold for the DHCPv6 address pool. |
PD-in-use threshold |
IPv6 prefix usage threshold for the DHCPv6 address pool. |
DNS server address to be assigned to DHCPv6 clients. |
Domain name |
Domain name to be assigned to DHCPv6 clients. |
AFTR name |
AFTR domain name to be assigned to DHCPv6 clients. |
IPv6 SIP server address to be assigned to DHCPv6 clients. |
SIP server domain names |
IPv6 SIP server domain name to be assigned to DHCPv6 clients. |
IPv6 address statistics in the DHCPv6 address pool. |
Total IPv6 addresses |
Free IPv6 addresses |
Number of free IPv6 addresses in the DHCPv6 address pool. |
Used IPv6 addresses |
Number of assigned IPv6 addresses in the DHCPv6 address pool. |
Total number of IPv6 prefixes in the DHCPv6 address pool. |
Free Prefixes |
Number of free IPv6 prefixes in the DHCPv6 address pool. |
Used IPv6 prefixes |
Number of assigned IPv6 prefixes in the DHCPv6 address pool. |
IPv6 address usage |
IPv6 address usage of the DHCPv6 address pool. |
IPv6 prefix usage |
IPv6 prefix usage of the DHCPv6 address pool. |
Bindings |
Number of bindings in different states: · IP-in-use—Total number of IPv6 address bindings. · PD-in-use—Total number of prefix bindings. · Expired IP—Total number of expired IPv6 address bindings. · Expired PD—Total number of expired prefix bindings. · Reserve IP—Total number of reserved IPv6 address bindings. · Reserve PD—Total number of reserved prefix bindings. |
Conflicts |
Total number of conflicting IPv6 addresses in the DHCPv6 address pool. |
display ipv6 pool (new style)
display ipv6 dhcp pool-group
Use display ipv6 dhcp pool-group to display information about DHCPv6 address pool groups.
display ipv6 dhcp pool-group [ all | [ name pool-group-name ] [ vpn-instance vpn-instance-name ] ] [ verbose ]
all: Displays information about all DHCPv6 address pool groups and their address pools for the public network and VPN instances.
name pool-group-name: Specifies a DHCPv6 address pool group name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all DHCPv6 address pool groups.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about DHCPv6 address pool groups for the public network.
verbose: Displays detailed information about DHCPv6 address pool groups and their address pools. If you do not specify this keyword, the command displays brief information about DHCPv6 address pool groups and their address pools.
If you specify neither of the name and vpn-instance keywords, this command displays information about all DHCPv6 address pool groups on the public network.
If compatibility with old-style commands is enabled on a BRAS by using the bras compatible old-style-commands enable command, the display ipv6 dhcp pool-group command displays information about DHCPv6 address pool groups on the BRAS as follows:
# Display brief information about DHCPv6 address pool group group1.
<Sysname> display ipv6 dhcp pool-group name group1
Pool-group: 1
VPN instance name: N/A
Current DHCPv6 address pool: 1
Current DHCPv6 prefix pool: 1
Ip-in-use threshold: 100
Undo Exhaustion trap enable
Undo Exhaustion log enable
Current DHCPv6 relay IPv6 pool: N/A
Static bindings: 0
Bind Pools: 1
1
# Display detailed information about all DHCPv6 address pool groups.
<Sysname> display ipv6 dhcp pool-group verbose
Pool-group: 1
IPv6 pool group address usage: 0.00%
IPv6 pool group pd usage: 0.00%
Static bindings: 0
Bind Pools: 1
DHCPv6 pool: 1
Pool index: 1
Pool type: Common
Pool-group-name:
1
Network: 1:1::/64
Total Prefixes: 0
Free Prefixes: 0
Bindings:
IP-in-use: 0
PD-in-use: 0
Expired IP: 0
Expired PD: 0
Reserve IP: 0
Reserve PD: 0
Conflicts: 0
Table 35 Command output
Pool-group |
Name of the DHCPv6 address pool group. |
VPN instance name |
Name of the VPN instance to which the DHCPv6 address pool group is applied. This field displays N/A if the DHCPv6 address pool group is on the public network. |
Number of assigned IPv6 addresses in the DHCPv6 address pool group. |
Number of assigned IPv6 prefixes in the DHCPv6 address pool group. |
Current IPv6 pool for address allocation |
DHCPv6 address pool that is currently used for IPv6 address allocation in the DHCPv6 address pool group. If the pool group does not have any DHCPv6 address pools, this field displays N/A. |
Current IPv6 pool for prefix allocation |
DHCPv6 address pool that is currently used for IPv6 prefix allocation in the pool group. If the pool group does not have any DHCPv6 address pools, this field displays N/A. |
Ip-in-use threshold |
IPv6 address usage threshold for the DHCPv6 address pool group, in percentage. |
Undo exhaustion trap enable |
IPv6 resource exhaustion alarming is disabled for the DHCPv6 address pool group. If this feature is enabled, this field displays Exhaustion trap enable. |
Undo exhaustion log enable |
IPv6 resource exhaustion logging is disabled for the DHCPv6 address pool group. If this feature is enabled, this field displays Exhaustion log enable. |
DHCPv6 relay address pool that is currently used in the pool group. If the pool group does not have any DHCPv6 relay address pools, this field displays N/A. |
Static bindings |
Number of statically bound IPv6 addresses in the DHCPv6 address pool group. |
Bind pools |
Number of bound DHCPv6 address pools and their names. Each line displays only one DHCPv6 address pool name. |
IPv6 prefix usage |
DHCPv6 pool |
Information about the bound DHCPv6 address pool. For more information about the related fields, see display ipv6 dhcp pool. |
display ipv6 pool-group (new style)
DHCPv6 relay agent commands
dhcpv6-relay source-address
Use dhcpv6-relay source-address to specify the source IPv6 address of the DHCPv6 requests that the DHCPv6 relay agent forwards to the DHCPv6 server.
Use undo dhcpv6-relay source-address to restore the default.
dhcpv6-relay source-address { ipv6-address | gateway | interface interface-type interface-number }
The relay agent chooses a source IP address for relayed requests depending on whether its server-side interface and the DHCPv6 server belong to the same VPN instance:
· If they belong to the same VPN instance, the relay agent uses one of the global unicast IP address on the output interface for relayed requests as the source IP address of relayed requests.
· If they belong to different VPN instances, the relay agent uses the lowest IPv6 address that is in the same VPN instance as the DHCPv6 server as the source address of relayed requests.
ipv6-address: Specifies the source IPv6 address for the DHCPv6 requests.
gateway: Uses the IPv6 address in the Link-address field as the source IPv6 address of the DHCPv6 requests. If the Link-address field is empty, the relay agent follows the default rule to specify the source IPv6 address for DHCPv6 requests.
interface interface-type interface-number: Uses the IPv6 address of the specified interface as the source IPv6 address. The interface-type interface-number argument specifies the interface type and the interface number.
This command is required if multiple relay interfaces share the same IPv6 address or if a relay interface does not have routes to DHCPv6 servers. You can use this command to specify the IPv6 address of another interface (typically a loopback interface) on the DHCPv6 relay agent as the source IPv6 address for relayed DHCPv6 requests.
Specify the gateway keyword if the DHCPv6 relay agent has a reachable route to the DHCPv6 address from the address filled in the Link-address field.
If you execute this command multiple times for an IPv6 address pool, the most recent configuration takes effect.
# In IPv6 address pool pool1, specify 2001:501:aabb::1/64 as the source IPv6 address for DHCPv6 requests.
[Sysname] ipv6 pool pool1
[Sysname-ipv6-pool-pool1] dhcpv6-relay source-address 2001:501:aabb::1
display ipv6 dhcp relay client-information address
Use display ipv6 dhcp relay client-information address to display DHCPv6 relay entries that record clients' IPv6 address information.
display ipv6 dhcp relay client-information address [ interface interface-type interface-number | ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays DHCPv6 relay entries that record clients' IPv6 address information on all interfaces enabled with DHCPv6 relay agent. For an IPoE individual roaming user, the command output is available only when this option specifies the access interface through which the roaming user comes online. But the command output displays the access interface where the roaming user is currently on. For more information about roaming for IPoE individual users, see IPoE configuration in BRAS Services Configuration Guide.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays DHCPv6 relay entries for all IPv6 addresses.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCPv6 relay entries that record clients' IPv6 address information for the public network.
The relay entry recording feature operates differently depending on the user type, as follows:
· For non-WAN access users (for example, IPoE or PPPoE users), the DHCPv6 relay agent records DHCPv6 relay entries only after you execute the ipv6 dhcp relay client-information record command.
· For WAN access users, the DHCPv6 relay agent generates relay entries as follows:
¡ Without an authorized IPv6 pool, the DHCPv6 relay agent generates relay entries for WAN access users (for example, IPoE or PPPoE users) automatically, which cannot be manually disabled.
¡ With an authorized IPv6 pool, the relay agent does not generate relay entries for WAN access users (for example, IPoE or PPPoE users). To display the client address information for such users, execute the display ipv6 dhcp server ip-in-use command on the DHCPv6 server.
# Display all DHCPv6 relay entries that record clients' IPv6 address information.
<Sysname> display ipv6 dhcp relay client-information address
1 DHCPv6 relay entries found.
IPv6 address IAID Lease Status Interface
2::1 0x00030001 54 Open XGE0/0/15
# Display the DHCPv6 relay entry for the IPv6 address 2::1.
<Sysname> display ipv6 dhcp relay client-information address ipv6 2::1
IPv6 address: 2::1
DUID: 00030001CA000C180000
IAID: 0x00030001
Port index: N/A
Interface: XGE0/0/15
Outer VLAN: N/A
Inner VLAN: N/A
Status: Open
Access type: CommonV6
PPP index: N/A
Remaining lease time: 54 seconds
Preferred lifetime: 400 seconds
Valid lifetime: 500 seconds
User ID: 0x40000003
Table 36 Command output
x DHCPv6 relay entries found. |
Number of DHCPv6 relay entries that record clients' IPv6 address information. |
IPv6 address |
IPv6 address of the DHCPv6 client. |
DUID |
DUID of the DHCPv6 client. |
IAID |
IAID of the DHCPv6 client. |
Port index |
Layer 2 port that receives the client's request. If the request is not received through a Layer 2 port, this field displays N/A. |
Interface enabled with DHCPv6 relay agent. This field displays N/A if the entry does not contain interface information or if the interface index in the entry loses effect. |
Outer VLAN |
Outer VLAN tag contained in the DHCPv6 relay entry. If the DHCPv6 relay entry does not contain an outer VLAN tag, this field displays N/A. |
Inner VLAN |
Inner VLAN tag contained in the DHCPv6 relay entry. If the DHCPv6 relay entry does not contain an inner VLAN tag, this field displays N/A. |
Status |
State of the DHCPv6 relay entry: · OPEN—The DHCPv6 client has obtained an IPv6 address or renewed the lease. · SOLICIT—The DHCPv6 relay agent received a Solicit message that contains a Rapid Commit option from the DHCPv6 client. · REQUEST—The DHCPv6 relay agent received a Request message from the DHCPv6 client. · RELEASE—The DHCPv6 relay agent received a Release message from the DHCPv6 client. · DECLINE—The DHCPv6 relay agent received a Decline message from the DHCPv6 client. · RENEW—The DHCPv6 relay agent received a Renew message from the DHCPv6 client. · REBIND—The DHCPv6 relay agent received a Rebind message from the DHCPv6 client. |
Access type |
Access type of the DHCPv6 client: · Commonv6—DHCPv6. · IPoEv6—IPoE. · PPPv6—PPP. |
PPP index |
PPP session index. If no PPP session index exists, this field displays N/A. |
Remaining lease time |
Remaining time of the IPv6 address lease, in seconds. |
Preferred lifetime of the IPv6 address, in seconds. |
Valid lifetime |
Valid lifetime of the IPv6 address, in seconds. |
User ID |
ID of the access user, in hexadecimal notation. |
reset ipv6 dhcp relay client-information address
display ipv6 dhcp relay client-information pd
Use display ipv6 dhcp relay client-information pd to display DHCPv6 relay entries that record clients' IPv6 prefix information.
display ipv6 dhcp relay client-information pd [ interface interface-type interface-number | prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays DHCPv6 relay entries that record clients' IPv6 prefix information on all interfaces enabled with DHCPv6 relay agent. For an IPoE individual roaming user, the command output is available only when this option specifies the access interface through which the roaming user comes online. But the command output displays the access interface where the roaming user is currently on. For more information about roaming for IPoE individual users, see IPoE configuration in BRAS Services Configuration Guide.
prefix prefix/prefix-len: Specifies an IPv6 prefix with its length. The value range for the prefix-len argument is 1 to 128. If you do not specify an IPv6 prefix, this command displays DHCPv6 relay entries for all IPv6 prefixes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCPv6 relay entries that record clients' IPv6 prefix information for the public network.
¡ With an authorized IPv6 pool, the relay agent does not generate relay entries for WAN access users (for example, IPoE or PPPoE users). To display the client prefix information for such users, execute the display ipv6 dhcp server pd-in-use command on the DHCPv6 server.
# Display all DHCPv6 relay entries that record clients' IPv6 prefix information.
<Sysname> display ipv6 dhcp relay client-information pd
Prefix IAID Lease Status Interface
2::/64 0x00030001 54 Open XGE0/0/15
# Display the DHCPv6 relay entry for the IPv6 prefix 2::/64.
<Sysname> display ipv6 dhcp relay client-information pd prefix 2::/64
Prefix: 2::/64
IAID: 0x00030001
Port index: N/A
Outer VLAN: N/A
Inner VLAN: N/A
Status: Open
PPP index: N/A
User ID: 0x40000003
Table 37 Command output
Number of DHCPv6 relay entries that record clients' IPv6 prefix information. |
Prefix |
IPv6 prefix of the DHCPv6 client. |
DUID |
IAID |
Port index |
Outer VLAN |
Inner VLAN |
Status |
State of the DHCPv6 relay entry: · OPEN—The DHCPv6 client has obtained an IPv6 prefix or renewed the lease. · SOLICIT—The DHCPv6 relay agent received a Solicit message that contains a Rapid Commit option from the DHCPv6 client. · REQUEST—The DHCPv6 relay agent received a Request message from the DHCPv6 client. · RELEASE—The DHCPv6 relay agent received a Release message from the DHCPv6 client. · DECLINE—The DHCPv6 relay agent received a Decline message from the DHCPv6 client. · RENEW—The DHCPv6 relay agent received a Renew message from the DHCPv6 client. · REBIND—The DHCPv6 relay agent received a Rebind message from the DHCPv6 client. |
Access type |
PPP index |
Remaining time of the IPv6 prefix lease, in seconds. |
Preferred lifetime of the IPv6 prefix, in seconds. |
Valid lifetime |
Valid lifetime of the IPv6 prefix, in seconds. |
User ID |
reset ipv6 dhcp relay client-information pd
display ipv6 dhcp relay client-information srv6-locator
Use display ipv6 dhcp relay client-information srv6-locator to display DHCPv6 relay entries that record clients' SRv6 locator information.
display ipv6 dhcp relay client-information srv6-locator [ interface interface-type interface-number | locator prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
locator prefix/prefix-len: Specifies an SRv6 locator. The prefix argument specifies an IPv6 prefix, and the value range for the prefix-len argument is 1 to 128. If you do not specify an SRv6 locator, this command displays DHCPv6 relay entries for all SRv6 locators.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCPv6 relay entries that record clients' SRv6 locator information for the public network.
# Display all DHCPv6 relay entries that record clients' SRv6 locator information.
<Sysname> display ipv6 dhcp relay client-information srv6-locator
Locator IAID Lease Status Interface
# Display the DHCPv6 relay entry generated for SRv6 locator 2::/64.
<Sysname> display ipv6 dhcp relay client-information srv6-locator locator 2::/64
Locator: 2::/64
IAID: 0x00030001
Port index: N/A
Outer VLAN: N/A
Inner VLAN: N/A
Status: Open
User ID: 0x40000003
NbrID: 704643077
IATYPE: Srv6 Locator
Table 38 Command output
Number of DHCPv6 relay entries that record clients' SRv6 locator information. |
Locator |
SRv6 locator of the DHCPv6 client. |
DUID |
IAID |
Port index |
Interface enabled with DHCPv6 relay agent. This field displays N/A if the entry does not contain interface information or if the interface index in the entry is invalid. |
Outer VLAN |
Inner VLAN |
Status |
State of the DHCPv6 relay entry: · OPEN—The DHCPv6 client has obtained an SRv6 locator or renewed the lease. · SOLICIT—The DHCPv6 relay agent received a Solicit message that contains a Rapid Commit option from the DHCPv6 client. · REQUEST—The DHCPv6 relay agent received a Request message from the DHCPv6 client. · RELEASE—The DHCPv6 relay agent received a Release message from the DHCPv6 client. · DECLINE—The DHCPv6 relay agent received a Decline message from the DHCPv6 client. · RENEW—The DHCPv6 relay agent received a Renew message from the DHCPv6 client. · REBIND—The DHCPv6 relay agent received a Rebind message from the DHCPv6 client. |
Access type |
Access type of the DHCPv6 client: · CommonV6—Portal or DHCPv6. |
Remaining time of the SRv6 locator lease, in seconds. |
Preferred lifetime of the SRv6 locator, in seconds. |
Valid lifetime |
Valid lifetime of the SRv6 locator, in seconds. |
User ID |
NbrID |
ID of the routing neighbor. |
IATYPE |
DHCPv6 relay user type: · Srv6 Locator—SRv6 locator user. · IAPD—Prefix user. |
reset ipv6 dhcp relay client-information srv6-locator
display ipv6 dhcp relay packet statistics
Use display ipv6 dhcp relay packet statistics to display DHCPv6 packet statistics on the DHCPv6 relay agent.
display ipv6 dhcp relay packet statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Displays DHCPv6 packet statistics on the specified interface. If you do not specify an interface, this command displays all DHCPv6 packet statistics on the DHCPv6 relay agent.
# Display all DHCPv6 packet statistics on the DHCPv6 relay agent.
<Sysname> display ipv6 dhcp relay packet statistics
Packets dropped : 4
Packets received : 14
Solicit : 0
Request : 0
Confirm : 0
Renew : 0
Rebind : 0
Release : 0
Decline : 0
Information-request : 7
Relay-forward : 0
Relay-reply : 7
Packets sent : 14
Advertise : 0
Reconfigure : 0
Reply : 7
Relay-forward : 7
Relay-reply : 0
Table 39 Command output
Packets dropped |
Number of DHCPv6 messages dropped by the relay agent. |
Packets received |
Number of DHCPv6 messages received from clients. |
Solicit |
Number of received Solict messages. |
Request |
Number of received Request messages. |
Confirm |
Number of received Confirm messages. |
Renew |
Number of received Renew messages. |
Rebind |
Number of received Rebind messages. |
Release |
Number of received Release messages. |
Decline |
Number of received Decline messages. |
Information-request |
Number of received Information-request messages. |
Relay-forward |
Number of received Relay-forward messages. |
Relay-reply |
Number of received Relay-reply messages. |
Packets sent |
Number of DHCPv6 messages sent by the relay agent. |
Advertise |
Number of sent Advertise messages. |
Reconfigure |
Number of sent Reconfigure messages. |
Reply |
Number of sent Reply messages. |
Relay-forward |
Number of sent Relay-forward messages. |
Relay-reply |
Number of sent Relay-reply messages. |
reset ipv6 dhcp relay statistics
display ipv6 dhcp relay remote-server-info
Use display ipv6 dhcp relay remote-server-info to display the DHCPv6 server configuration and status on the DHCPv6 relay agent.
In standalone mode:
display ipv6 dhcp relay remote-server-info [ vpn-instance vpn-name ] [ slot slot-number ]
In IRF mode:
display ipv6 dhcp relay remote-server-info [ vpn-instance vpn-name ] [ chassis chassis-number slot slot-number ]
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To specify DHCPv6 servers on the public network, do not specify this option.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DHCP server information on the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DHCP server information on the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# Display the DHCPv6 server configuration and status on the DHCPv6 relay agent.
<Sysname> display ipv6 dhcp relay remote-server-info
Remote server count: 2
Remote server: 100::1 * Out interface: Ten-GigabitEthernet0/0/18
RemoteSrvRefCnt: 2 State: Up
CfgTimeOut: 12(s) CfgDeadCount: 10 CfgDeadTime: 10(m)
RunDeadCnt: 0 RunDeadTime: 1968(s)
Recent state changes:
Jun 24 17:45:36 2023 Changed to down, reason: NoResponse
Jun 24 17:45:23 2023 Changed to up, reason: DeadTimeout
Jun 24 17:44:23 2023 Changed to down, reason: NoResponse
Jun 24 17:43:49 2023 Changed to up, reason: DeadTimeout
Jun 24 17:40:49 2023 Changed to down, reason: NoResponse
Remote server: 100::2 Out interface: N/A
RemoteSrvRefCnt: 1 State: Up
CfgTimeOut: 13(s) CfgDeadCount: 10 CfgDeadTime: 10(m)
Jun 24 17:38:52 2023 Changed to down, reason: NoResponse
Jun 24 17:38:49 2023 Changed to up, reason: DeadTimeout
Jun 24 17:38:42 2023 Changed to down, reason: NoResponse
Jun 24 17:38:39 2023 Changed to up, reason: DeadTimeout
Jun 24 17:38:31 2023 Changed to down, reason: NoResponse
Table 40 Command output
Remote server count |
Number of the DHCPv6 servers. |
Remote server |
IPv6 address of the DHCPv6 server. The asterisk * represents the DHCPv6 server liveness detection is configured for the DHCPv6 server. If the detection is not configured, no asterisk is displayed. |
Out interface |
Output interface specified on the DHCPv6 relay agent for the conveyed packets to be sent to the DHCPv6 server. If no output interface is specified, this field displays N/A. |
RemoteSrvRefCnt |
Number of times that the DHCPv6 server is referenced by the address pool on the DHCPv6 relay agent. |
State |
State of the DHCPv6 server: · Up—The server is available. · Down—The server is not available. · Unknown—The server state is not unknown. |
CfgTimeOut |
Communication failure check timer in seconds. |
CfgDeadCount |
Maximum number of consecutive communication failures before the relay agent marks a DHCPv6 server as down. |
CfgDeadTime |
Time period in minutes for the relay agent to wait before communicating with the DHCPv6 server. |
RunDeadCnt |
Number of consecutive communication failures. |
RunDeadTime |
Dead time in seconds of the DHCPv6 server. |
Recent state changes |
Five most recent state changes on the remote DHCPv6 server. |
Reason for the state change: · NoResponse: No response was received from the remote DHCPv6 server, and the number of consecutive communication failures reached the upper limit. · StatusFail: The remote DHCPv6 server was in an abnormal state, for example, it did not have assignable resources. · IfInvalid: Invalid output interface, for example, the output interface did not exist or was a Layer 2 port. · VpnNotExist: The VPN instance did not exist. · AddrOnIf: The server address conflicted with the interface address of the device. · AllocFail: Lease assignment failed. · DeadTimeout: No response was received from the remote DHCPv6 server, and the number of consecutive communication failures did not reach the upper limit. The DHCPv6 relay agent initiated a connection request to the remote DHCPv6 server. · Unknown: Unknown reason. |
ipv6 dhcp remote-server
remote-server algorithm
remote-server
display ipv6 dhcp relay server-address
Use display ipv6 dhcp relay server-address to display DHCPv6 server addresses specified on a DHCPv6 relay interface.
display ipv6 dhcp relay server-address [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays DHCPv6 server addresses on all interfaces enabled with DHCPv6 relay agent.
# Display DHCPv6 server addresses on all interfaces enabled with DHCPv6 relay agent.
<Sysname> display ipv6 dhcp relay server-address
Interface: Ten-GigabitEthernet0/0/15
Server address Outgoing Interface Public/VRF name
2::3
3::4 Ten-GigabitEthernet0/0/17 Y/--
Interface: Ten-GigabitEthernet0/0/16
2::3
# Display DHCPv6 server addresses on Ten-GigabitEthernet 0/0/15.
<Sysname> display ipv6 dhcp relay server-address interface ten-gigabitethernet 0/0/15
2::3
Table 41 Command output
Interface where the DHCPv6 relay agent is enabled. |
Server address |
DHCPv6 server address specified on the DHCPv6 relay agent. |
Outgoing Interface |
Output interface of DHCPv6 packets. If no output interface is specified, the device searches the routing table for the output interface. |
Public/VRF name |
Virtual network on which the DHCPv6 server is located. The displayed value depends on the setting for the ipv6 dhcp relay server-address command. · If you do not specify an MPLS L3VPN instance or the public network, this field displays --/--. · If you specify the public network, this field displays Y/--. · If you specify an MPLS L3VPN instance, this field displays --/VPN-instance-name. |
ipv6 dhcp select
gateway-list
Use gateway-list to specify gateway addresses for DHCPv6 clients in an IPv6 address pool.
Use undo gateway-list to remove gateway addresses from an IPv6 address pool.
gateway-list ipv6-address&<1-8>
undo gateway-list [ ipv6-address&<1-8> ]
No gateway address is specified in an IPv6 address pool.
ipv6-address&<1-8>: Specifies a space-separated list of up to eight addresses.
DHCPv6 clients of the same access type can be classified into different types by their locations. In this case, the relay interface typically has no IPv6 address configured. You can use the gateway-list command to specify gateway addresses for clients matching the same IPv6 address pool.
Upon receiving a DHCPv6 Solicit or Request from a client that matches an IPv6 address pool, the relay agent processes the packet as follows:
· Fills the link-address field of the packet with a specified gateway address.
· Forwards the packet to all DHCPv6 servers in the matching IPv6 address pool.
The DHCPv6 servers select an IPv6 address pool according to the gateway address.
To avoid forwarding failure, do not delete a gateway address from a gateway list if that gateway address is being used by online clients.
# Specify the gateway address 10::1 in the IPv6 address pool p1.
[Sysname-ipv6-pool-p1] gateway-list 10::1
ipv6 dhcp client-detect
Use ipv6 dhcp client-detect to enable client offline detection on the DHCPv6 relay agent.
Use undo ipv6 dhcp client-detect to disable client offline detection on the DHCPv6 relay agent.
Client offline detection is disabled.
Interface view
This command takes effect only after you enable the DHCPv6 relay agent and the recording of DHCPv6 relay entries on the interface.
This feature is not supported in BRAS scenarios.
# Enable client offline detection on Ten-GigabitEthernet 0/0/15.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp select relay
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay client-information record
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp client-detect
ipv6 dhcp relay client-link-address enable
Use ipv6 dhcp relay client-link-address enable to enable the DHCPv6 relay agent to support Option 79.
Use undo ipv6 dhcp relay client-link-address enable to disable Option 79 support.
The DHCPv6 relay agent does not support Option 79.
Interface view
If DHCPv6 relay agents exist in the network, the DHCPv6 server needs the MAC address of the DHCPv6 client for authentication or for IPv6 address or prefix assignment. To meet the requirement, enable the DHCPv6 relay agent that the client's DHCPv6 requests first pass to support Option 79. This feature allows the DHCPv6 relay agent to learn the MAC address in the client request. When the relay agent generates a Relay-Forward packet for the request, it fills the MAC address of the client in Option 79. The Relay-Forward packet is then forwarded to the DHCPv6 server.
# Enable Option 79 support on the relay agent.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay client-link-address enable
Use ipv6 dhcp relay client-information record to enable recording client information in DHCPv6 relay entries.
Use undo ipv6 dhcp relay client-information record to disable recording client information in DHCPv6 relay entries.
The DHCPv6 relay agent does not record client information in DHCPv6 relay entries.
Interface view
Supported DHCPv6 relay entry types include:
· Address—Records address information for DHCPv6 clients.
· Prefix—Records prefix information for DHCPv6 clients.
· Locator—Records SRv6 locator information for DHCPv6 clients.
The undo ipv6 dhcp relay client-information record command disables the recording of DHCPv6 relay entries and deletes all recorded DHCPv6 relay entries.
The following information applies to WAN access users (for example, IPoE or PPPoE users):
· Without an authorized IPv6 pool, the DHCPv6 relay agent generates relay entries for WAN access users automatically, which cannot be manually disabled.
· With an authorized IPv6 pool, the relay agent does not generate relay entries for WAN access users.
# Enable the recording of DHCPv6 relay entries on Ten-GigabitEthernet 0/0/15.
ipv6 dhcp relay gateway
Use ipv6 dhcp relay gateway to specify a gateway address for DHCPv6 clients on the DHCPv6 relay interface.
Use undo ipv6 dhcp relay gateway to restore the default.
ipv6 dhcp relay gateway ipv6-address
The first IPv6 address of the relay interface is used as the gateway address for DHCPv6 clients.
Interface view
ipv6-address: Specifies a gateway address. The IPv6 address must be an IPv6 address of the relay interface.
The DHCPv6 relay agent uses the specified IPv6 address instead of the first IPv6 address of the relay interface as the gateway address for DHCPv6 clients.
# Specify 10::1 as the gateway address for DHCPv6 clients on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay gateway 10::1
gateway-list
ipv6 dhcp relay interface-id
Use ipv6 dhcp relay interface-id to specify a padding mode for the Interface-ID option.
Use undo ipv6 dhcp relay interface-id to restore the default.
ipv6 dhcp relay interface-id { bas [ merge ] | cn-telecom | interface | tr-101 }
The DHCPv6 relay agent fills the Interface-ID option with the interface index of the interface.
Interface view
bas: Specifies the BAS mode. The relay agent in this mode pads the Interface and VLAN information to pad the Interface-ID option. The device encapsulates the information in the format of interface-type slot/subslot/port vxlan_id.vlan_id.subvlan_id_OLT.
merge: Specifies the bas merge mode. Upon receiving a DHCP request, the relay agent obtains the OLT information (including the interface that connects to the OLT and end user MAC address) from the request to fill in the OLT filed. If this keyword is not specified, all 0s are set in the OLT field.
cn-telecom: Specifies the China Telecom mode. This mode pads the Interface-ID option with interface information, numbers of the card and the subcard where the interface resides, and the inner VLAN and outer VLAN of the interface.
interface: Specifies the interface name mode. This mode pads the Interface-ID option in ASCII code with the interface name and VLAN ID of the interface.
tr-101: Specifies the TR-101 mode. This mode pads the Interface-ID option with interface information, number of the card where the interface resides, and the VLAN of the interface.
Enable the DHCPv6 relay agent on the interface before executing this command. Otherwise, the command does not take effect.
In a Telecom network, specify bas merge on the first DHCPv6 relay agent to ensure the DHCPv6 clients passes access authentication and obtain correct IPv6 addresses or prefixes.
# Specify the BAS mode as the padding mode for the Interface-ID option on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay interface-id bas
# Specify the interface name mode as the padding mode for the Interface-ID option on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay interface-id interface
ipv6 dhcp relay non-first-hop enable
Use ipv6 dhcp relay non-first-hop enable to enable the non-first-hop DHCPv6 relay agent feature.
Use undo ipv6 dhcp relay non-first-hop enable to disable the non-first-hop DHCPv6 relay agent feature.
The non-first-hop DHCPv6 relay agent feature is disabled.
Interface view
Multiple DHCPv6 relay agents might exist between a DHCPv6 client and the DHCPv6 server. By default, only the first DHCPv6 relay agent that the DHCPv6 request passes through processes the request and the subsequent DHCPv6 relay agents only forward the request. If access authentication is enabled on a non-first DHCPv6 relay agent, execute this command on this relay agent for the relay agent to deliver the packet to the authentication module for authentication and authorization.
Enable this feature only on the non-first-hop DHCPv6 relay agent where access authentication is enabled.
To have this feature function correctly, you must enable DHCPv6 relay agent on the downstream interface of the device.
# Enable the non-first-hop DHCPv6 relay agent feature on Ten-GigabitEthernet0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay non-first-hop enable
ipv6 dhcp relay release-agent
Use ipv6 dhcp relay release-agent to enable IPv6 release notification.
Use undo ipv6 dhcp relay release-agent to restore the default.
IPv6 release notification is disabled.
Interface view
This command enables the DHCPv6 relay agent to send a Release message to the DHCPv6 server after it deletes a DHCPv6 relay entry. After the DHCPv6 server receives the message, it reclaims the IPv6 address or prefix and marks the lease as expired.
This command takes effect only after you enable the DHCPv6 relay agent on the interface.
# Enable IPv6 release notification on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay release-agent
ipv6 dhcp relay remote-id duid
Use ipv6 dhcp relay remote-id duid to specify the DUID to be set in Option 37.
Use undo ipv6 dhcp relay remote-id duid to restore the default.
ipv6 dhcp relay remote-id duid { ascii ascii-string | hex hex-string }
The DHCPv6 relay agent sets its own DUID in Option 37.
Layer 3 Ethernet interface view/Layer 3 Ethernet subinterface view
Layer 3 aggregate interface view/Layer 3 aggregate subinterface view
VSI interface view/VSI subinterface view
L3VE interface view/L3VE subinterface view
VLAN interface view
ascii ascii-string: Specifies a case-sensitive ASCII string of 1 to 128 characters.
hex hex-string: Specifies a hexadecimal string of 2 to 128 characters. The string length must be an even number.
# Configure the DHCPv6 relay agent to set the DUID in Option 37 to FFFFFFFF on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay remote-id duid hex ffffffff
ipv6 dhcp relay remote-id enable
Use ipv6 dhcp relay remote-id enable to enable the DHCPv6 relay agent to insert Option 37 into Relay-forward messages.
Use undo ipv6 dhcp relay remote-id enable to disable the DHCPv6 relay agent from inserting Option 37 into Relay-forward messages.
The DHCPv6 relay agent does not insert Option 37 into Relay-forward messages.
VLAN interface view
This feature enables the DHCPv6 relay agent to encapsulate Option 37 in the Relay-forward messages sent to DHCPv6 servers. Option 37 provides client location information for DHCPv6 servers to decide the IPv6 address and other settings to be assigned to the requesting client.
The DUID to be set in Option 37 is configurable with the ipv6 dhcp relay remote-id duid command.
For more information about Option 37, see DHCPv6 configuration in Layer 3—IP Services Configuration Guide.
# Enable the DHCPv6 relay agent to insert Option 37 into Relay-forward messages on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay remote-id enable
Use ipv6 dhcp relay server-address to specify a DHCPv6 server on the DHCPv6 relay agent.
Use undo ipv6 dhcp relay server-address to remove DHCPv6 server addresses.
ipv6 dhcp relay server-address ipv6-address [ interface interface-type interface-number | public | vpn-instance vpn-instance-name ]
undo ipv6 dhcp relay server-address [ ipv6-address [ interface interface-type interface-number | public | vpn-instance vpn-instance-name ] ]
No DHCPv6 server address is specified on the DHCPv6 relay agent.
Interface view
ipv6-address: Specifies the IPv6 address of a DHCPv6 server.
interface interface-type interface-number: Specifies an output interface through which the relay agent forwards the DHCPv6 requests to the DHCPv6 server. If you do not specify an output interface, the relay agent looks up the routing table for an output interface.
public: Specifies this option if the specified DHCPv6 server is on the public network.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified DHCPv6 server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 32 characters.
Upon receiving a request from a DHCPv6 client, the interface encapsulates the request into a Relay-forward message and forwards the message to the specified DHCPv6 server.
You can specify a maximum of eight DHCPv6 servers on an interface. The DHCPv6 relay agent forwards DHCPv6 requests to all the specified DHCPv6 servers.
If the DHCPv6 server address is a link-local address or multicast address, you must specify an output interface. If you do not specify an output interface, DHCPv6 packets might fail to reach the DHCPv6 server.
The DHCPv6 relay agent forwards the packets from clients to the specified DHCPv6 server in the specified virtual network (MPLS L3VPN instance or the public network). If you do not specify an MPLS L3VPN instance or the public network, the DHCP relay agent forwards the packets from a client in the same virtual network as the client.
If you do not specify an IPv6 address, the undo ipv6 dhcp relay server-address command removes all DHCPv6 server addresses specified on the interface.
Do not enable the DHCPv6 client and the DHCPv6 relay agent on the same interface.
# Enable the DHCPv6 relay agent on Ten-GigabitEthernet 0/0/15 and specify the DHCPv6 server address 2001:1::3.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay server-address 2001:1::3
ipv6 dhcp select
ipv6 dhcp relay server-address algorithm
Use ipv6 dhcp relay server-address algorithm to specify the DHCPv6 server selection algorithm.
Use undo ipv6 dhcp relay server-address algorithm to restore the default.
ipv6 dhcp relay server-address algorithm { master-backup | polling }
The polling algorithm is used. The DHCPv6 relay agent forwards DHCPv6 requests to all DHCPv6 servers at the same time.
Interface view
master-backup: Forwards DHCPv6 requests to the master DHCPv6 server first. If the master server is not available, the relay agent forwards DHCPv6 requests to backup DHCPv6 servers in the order they were specified.
polling: Forwards DHCPv6 requests to all DHCPv6 servers at the same time.
# Specify master-backup as the DHCPv6 server selection algorithm on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay server-address algorithm master-backup
remote-server
ipv6 dhcp relay subscriber-id enable
Use ipv6 dhcp relay subscriber-id enable to enable the DHCPv6 relay agent to insert the Subscriber ID option into Relay-forward messages.
Use undo ipv6 dhcp relay subscriber-id enable to disable the DHCPv6 relay agent from inserting the Subscriber ID option into Relay-forward messages.
The DHCPv6 relay agent does not insert the Subscriber ID option into Relay-forward messages.
VLAN interface view
Application scenarios
The Subscriber ID option enhances the flexibility of dynamic address allocation. On receipt of a Relay-forward message that carries the Subscriber ID option, the DHCPv6 server can determine the IPv6 address and other settings to be assigned to the requesting client after parsing the Subscriber ID option.
Operating mechanism
After you enable this feature on the incoming interface of the DHCPv6 relay agent, the DHCPv6 relay agent inserts the Subscriber ID option into Relay-forward messages. The content in the Subscriber ID option is configurable with the ipv6 dhcp relay subscriber-id command.
# Enable the DHCPv6 relay agent to insert the Subscriber ID option into Relay-forward messages on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay subscriber-id enable
Use ipv6 dhcp relay subscriber-id to specify the content to be inserted into the Subscriber ID option.
Use undo ipv6 dhcp relay subscriber-id to restore the default.
ipv6 dhcp relay subscriber-id { ascii ascii-string | hex hex-string }
The DHCPv6 relay agent inserts the MAC address of the requesting client into the Subscriber ID option.
VLAN interface view
hex hex-string: Specifies a hexadecimal string of 2 to 256 characters. The string length must be an even number.
Operating mechanism
Upon receiving Relay-forward message that carries the Subscriber ID option, the DHCPv6 server can determine the IPv6 address and other settings to be assigned to the requesting client after parsing the Subscriber ID option.
Execute the ipv6 dhcp relay subscriber-id enable command to enable the DHCPv6 relay agent to insert the Subscriber ID option into Relay-forward messages.
# Configure the DHCPv6 relay agent to insert ASCII string device001 into the Subscriber ID option on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay subscriber-id ascii device001
ipv6 dhcp relay source-address
Use ipv6 dhcp relay source-address to specify the source IPv6 address for relayed DHCPv6 requests.
Use undo ipv6 dhcp relay source-address to restore the default.
ipv6 dhcp relay source-address { ipv6-address | interface interface-type interface-number }
The relay agent chooses the default source IPv6 address for relayed requests depending on whether its server-side interface and the DHCPv6 server belong to the same VPN instance:
· If they belong to the same VPN instance, the relay agent uses one of the global unicast addresses on the output interface for relayed requests.
· If they belong to different VPN instances, the relay agent uses the lowest IPv6 address that is in the same VPN instance as the DHCPv6 server.
Interface view
ipv6-address: Specifies a source IPv6 address.
interface interface-type interface-number: Uses the IPv6 address of an interface as the source IPv6 address. The interface-type interface-number option specifies an interface by its type and number.
This command is required if a relay interface does not have routes to DHCPv6 servers. You can specify a global unicast address or the IPv6 address of another interface (typically the loopback interface) as the source IPv6 address for DHCPv6 requests. The relay interface inserts the source IPv6 address in the source IPv6 address field of DHCPv6 requests.
If the specified interface does not have a global unicast IPv6 address, the relay agent follows the default rule to specify the source IPv6 address for relayed DHCPv6 requests.
# Specify 10::1 as the source IPv6 address for relayed DHCPv6 requests on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp relay source-address 10::1
Use ipv6 dhcp remote-server to configure DHCPv6 server liveness detection.
Use undo ipv6 dhcp remote-server to restore the default.
ipv6 dhcp remote-server [ ipv6-address [ vpn-instance vpn-instance-name ] ] { dead-count dead-count-value | dead-time dead-time | timeout timeout } *
undo ipv6 dhcp remote-server [ ipv6-address [ vpn-instance vpn-instance-name ] ] { dead-count | dead-time | timeout } *
If the DHCPv6 relay agent does not receive a reply from a DHCPv6 server within 55 seconds, the DHCPv6 relay agent determines that the DHCPv6 server is down.
Ipv6-address: Specifies an IP address of the DHCPv6 server. If you do not specify this keyword, the criteria apply to all DHCPv6 servers.
vpn-instance vpn-instance name: Specifies an MPLS L3VPN instance to which DHCP servers belongs. The vpn-instance-name argument specifies a VPN instance name, a case-sensitive string of 1 to 31 characters. If you do not specify this keyword, the criteria apply to DHCPv6 servers on the public network.
dead-count dead-count-value: Specifies the maximum number of consecutive communication failures before the relay agent marks a DHCPv6 server as down. The value range for the dead-count-value argument is 1 to 64, and the default value is 0.
dead-time dead-time: Specifies a time period (in minutes) for the relay agent to wait before communicating with the DHCPv6 server. The value range for the dead-time augment is 1 to 65536, and the default value is 3.
timeout timeout: Specifies a communication failure check timer in seconds. The value range for the argument is 1 to 60, and the default value is 25.
This feature is applicable when the relay agent selects a DHCPv6 server from a DHCPv6 address pool.
This feature enables the relay agent to detect the liveness of the DHCPv6 servers.
The DHCPv6 server liveness detection mechanism differs depending on the server selection algorithm.
If the master-backup selection algorithm applies, the relay agent uses the following mechanism to determine whether a DHCPv6 server is available:
1. When relaying the first request to a selected DHCPv6 server, the DHCPv6 relay agent starts the request counter and the timeout timer configured for that server.
2. The relay agent determines the availability of the DHCPv6 server:
¡ On receipt of a reply before the timeout timer expires, the relay agent resets the request counter and stops the timeout timer.
- The agent determines that the DHCPv6 server is not available and places it in down state, if the reply indicates an address or prefix assignment failure.
- The relay agent restarts the timer and the request counter when it relays a new request to the server.
¡ If the relay agent has not received a reply from the server when the timeout timer expires, the relay agent checks the request counter against the dead-count-value setting.
- If the number of requests does not exceed the dead-count-value setting, the relay agent continues to send new requests to the server without resetting the request counter.
- If the number of requests exceeds the dead-count-value setting, the relay agent determines that the DHCPv6 server is not available and places it in down state.
3. On receipt of a new request after it placed the server in down state, the relay agent forwards the new request to the next available server.
4. If none of the servers are available, the relay agent forwards the new request to all servers. In this situation, the relay agent does not start the timeout timer.
If the polling selection algorithm applies, the relay agent uses the following mechanism to determine whether a DHCPv6 server is available:
5. When receiving the first request, the DHCPv6 relay agent forwards that request to all available servers. At the same time, it starts the request counter and the timeout timer. The timeout timer is set to the highest timeout value among all servers.
6. The relay agent determines the availability of the DHCPv6 server:
¡ On receipt of a reply before the timeout timer expires, the relay agent takes one of the following actions depending on the reply content:
- If the reply contains a usable IPv6 address or prefix, the relay agent resets the request counter and stops the timeout timer.
- If the reply indicates an address or prefix assignment failure, the relay agent determines that the reply sender is unavailable and places it in down state. In this situation, the relay agent does not reset the request counter. It continues to wait for replies from other servers until a reply is received or until the timeout timer expires.
¡ If the relay agent has not received a reply from any servers when the timeout timer expires, the relay agent checks the request counter again the dead-count-value setting.
- If the number of requests does not exceed the dead-count-value setting, the relay agent continues to send new requests to all servers without resetting the request counter.
- If the number of requests exceeds the dead-count-value setting, the relay agent determines that none of the DHCPv6 servers is available and places them in down state.
7. When the relay agent receives a new request after it placed all the servers in down state, it forwards the new request to all the servers without restarting the timeout timer.
The relay agent starts the dead-time timer for a DHCPv6 server after it determines that the server is unavailable. The relay agent will not relay requests to that server until after the timer expires.
The liveness detection settings specific to a DHCPv6 server have a higher priority than the shared settings. If no DHCP server-specific settings are configured, the shared ones apply.
You can specify multiple server liveness detection rules for different DHCPv6 server addresses. If you do not specify a DHCPv6 server, you are creating a shared detection rule. The DHCP server-specific detection rule or the shared rule takes effect as follows:
· If you specify the same rule keyword but with different values in each command execution, the most recent configuration takes effect.
· If you specify different rule keywords in each command execution, all configurations take effect.
# Configure DHCPv6 server liveness detection for DHCPv6 server at 1::1. Set the maximum number of consecutive communication failures to 10, set the communication failure check timer to 20 seconds, and set the DHCPv6 server dead period to 3 minutes.
[Sysname] ipv6 dhcp remote-server 1::1 dead-count 10 timeout 20 dead-time 3
remote-server
remote-server
Use remote-server to specify DHCPv6 servers for an IPv6 address pool.
Use undo remote-server to remove DHCPv6 servers from an IPv6 address pool.
remote-server ipv6-address [ interface interface-type interface-number | public | vpn-instance vpn-instance-name ]
undo remote-server [ ipv6-address [ interface interface-type interface-number | public | vpn-instance vpn-instance-name ] ]
No DHCPv6 server is specified for the IPv6 address pool.
IPv6 address pool view
ipv6-address: Specifies a DHCPv6 server address.
interface interface-type interface-number: Specifies the outgoing interface by its type and number for the DHCPv6 relay agent to forward packets to the DHCPv6 server. If you do not specify an outgoing interface, the DHCPv6 relay agent performs a routing table lookup.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified DHCPv6 server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify an MPLS L3VPN instance, the specified DHCPv6 server is on the public network.
You can specify a maximum of eight DHCPv6 servers in one IPv6 address pool.
The undo remote-server command removes all DHCPv6 servers in the IPv6 address pool if you execute it without any parameters.
If a DHCPv6 server address is a multicast or link-local address, you must specify an outgoing interface by using the interface keyword in this command. If you do not specify an outgoing interface, DHCPv6 packets might fail to reach the DHCPv6 server.
If you execute this command with a VPN instance specified, the DHCPv6 relay forwards messages to the DHCPv6 server in that VPN instance. If you execute this command without specifying the public instance or a VPN instance, the DHCPv6 relay forwards the messages from a client to the DHCPv6 server in the same instance as that client.
# Specify DHCPv6 server 10::1 for IPv6 address pool 0.
[Sysname] ipv6 pool 0
[Sysname-ipv6-pool-0] remote-server 10::1
Use remote-server algorithm to specify the DHCPv6 server selection algorithm.
Use undo remote-server algorithm to restore the default.
remote-server algorithm { master-backup | polling }
master-backup: Forwards DHCPv6 requests to the master DHCPv6 server first. If the master server is not available, the relay agent forwards DHCPv6 requests to backup DHCPv6 servers in the order they are specified.
# Specify master-backup as the DHCPv6 server selection algorithm in IPv6 address pool 0.
[Sysname-ipv6-pool-0] remote-server algorithm master-backup
remote-server
Use reset ipv6 dhcp relay client-information address to clear DHCPv6 relay entries that record clients' IPv6 address information.
reset ipv6 dhcp relay client-information address [ interface interface-type interface-number | ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears DHCPv6 relay entries that record clients' IPv6 address information on all interfaces enabled with DHCPv6 relay agent.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command clears DHCPv6 relay entries for all IPv6 addresses.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears DHCPv6 relay entries that record clients' IPv6 address information for the public network.
To enable the DHCPv6 relay agent to send a Release message to the DHCPv6 server after it deletes a DHCPv6 relay entry, execute the ipv6 dhcp relay release-agent command.
# Clear all DHCPv6 relay entries that record clients' IPv6 address information.
<Sysname> reset ipv6 dhcp relay client-information address
Use reset ipv6 dhcp relay client-information pd to clear DHCPv6 relay entries that record clients' IPv6 prefix information.
reset ipv6 dhcp relay client-information pd [ interface interface-type interface-number | prefix prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears DHCPv6 relay entries that record clients' IPv6 prefix information on all interfaces enabled with DHCPv6 relay agent.
prefix prefix/prefix-len: Specifies an IPv6 prefix with its length. The value range for the prefix-len argument is 1 to 128. If you do not specify an IPv6 prefix, this command clears DHCPv6 relay entries for all IPv6 prefixes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears DHCPv6 relay entries that record clients' IPv6 prefix information for the public network.
# Clear all DHCPv6 relay entries that record clients' IPv6 prefix information.
<Sysname> reset ipv6 dhcp relay client-information pd
Use reset ipv6 dhcp relay client-information srv6-locator to clear DHCPv6 relay entries that record clients' SRv6 locator information.
reset ipv6 dhcp relay client-information srv6-locator [ interface interface-type interface-number | locator prefix/prefix-len ] [ vpn-instance vpn-instance-name ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears DHCPv6 relay entries that record clients' SRv6 locator information on all interfaces enabled with DHCPv6 relay agent.
locator prefix/prefix-len: Specifies an SRv6 locator. The prefix argument specifies an IPv6 prefix, and the value range for the prefix-len argument is 1 to 128. If you do not specify an SRv6 locator, this command clears DHCPv6 relay entries for all SRv6 locators.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears DHCPv6 relay entries that record clients' SRv6 locator information for the public network.
# Clear all DHCPv6 relay entries that record clients' SRv6 locator information.
<Sysname> reset ipv6 dhcp relay client-information srv6-locator
reset ipv6 dhcp relay packet statistics
Use reset ipv6 dhcp relay packet statistics to clear packet statistics on the DHCPv6 relay agent.
reset ipv6 dhcp relay packet statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears packet statistics on all DHCPv6 relay agents.
# Clear DHCPv6 relay agent packet statistics.
<Sysname> reset ipv6 dhcp relay packet statistics
display dhcp relay packet statistics
DHCPv6 client commands
display ipv6 dhcp client
Use display ipv6 dhcp client to display DHCPv6 client information.
display ipv6 dhcp client [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about all DHCPv6 clients.
# Display the DHCPv6 client information on Ten-GigabitEthernet 0/0/15.
<Sysname> display ipv6 dhcp client interface ten-gigabitethernet 0/0/15
Ten-GigabitEthernet0/0/15:
Type: Stateful client requesting address and prefix
State: OPEN
Client DUID: 0003000100e002000000
Preferred server
Reachable via address: FE80::2E0:1FF:FE00:18
Server DUID: 0003000100e001000000
IA_NA: IAID 0x00000642, T1 50 sec, T2 80 sec
Address: 1:1::2/128
Preferred lifetime 100 sec, valid lifetime 200 sec
Will expire on Feb 4 2014 at 15:37:20(288 seconds left)
IA_PD: IAID 0x00000642, T1 50 sec, T2 80 sec
Prefix: 12:34::/48
Will expire on Mar 27 2014 at 08:13:24 (199 seconds left)
DNS server addresses:
2:2::3
Domain name:
aaa.example.com
SIP server addresses:
2:2::4
SIP server domain names:
bbb.example.com
Options:
Code: 88
Length: 3 bytes
Hex: AABBCC
Table 42 Command output
Type |
Types of DHCPv6 client: · Stateful client requesting address—A DHCPv6 client that requests an IPv6 address. · Stateful client requesting prefix—A DHCPv6 client that requests an IPv6 prefix. · Stateful client requesting address and prefix—A DHCPv6 client that requests an IPv6 address and prefix. · Stateless client—A DHCPv6 client that requests configuration parameters other than an IPv6 address and prefix through stateless DHCPv6. |
State |
Current state of the DHCPv6 client: · IDLE—The client is in idle state. · SOLICIT—The client is locating a DHCPv6 server. · REQUEST—The client is requesting an IPv6 address or prefix. · OPEN—The client has obtained an IPv6 address or prefix. · RENEW—The client is extending the lease (after T1 and before T2). · REBIND—The client is extending the lease (after T2 and before the lease expires). · RELEASE—The client is releasing an IPv6 address or prefix. · DECLINE—The client is declining an IPv6 address or prefix because of an address or prefix conflict. · INFO-REQUESTING—The client is requesting configuration parameters through stateless DHCPv6. |
Client DUID |
Preferred server |
Information about the DHCPv6 server selected by the DHCPv6 client. |
Reachable via address |
Reachable address for the DHCPv6 client. It is the link local address of the DHCPv6 server or DHCPv6 relay agent. |
Server DUID |
DUID of the DHCPv6 server. |
IA_NA |
IA_NA information. |
IA_PD |
IA_PD information. |
IAID |
IA identifier. |
T1 |
T1 value in seconds. |
T2 |
T2 value in seconds. |
Address |
IPv6 address obtained. This field is displayed only when the DHCPv6 client type is Stateful client requesting address. |
Prefix |
IPv6 prefix obtained. This field is displayed only when the DHCPv6 client type is Stateful client requesting prefix. |
Preferred lifetime |
Preferred lifetime in seconds. |
valid lifetime |
Valid lifetime in seconds. |
Will expire on Feb 4 2014 at 15:37:20 (288 seconds left) |
Time when the lease expires and the remaining time of the lease. If the lease expires after the year 2100, this field displays Will expire after 2100. |
DNS server addresses |
IPv6 address of the DNS server. |
Domain name |
Domain name suffix. |
SIP server addresses |
IPv6 address of the SIP server. |
SIP server domain names |
Domain name of the SIP server. |
Options |
Self-defined options. |
Code |
Code of the self-defined option. |
Length |
Self-defined option length in bytes. |
Hex |
Self-defined option content represented by a hexadecimal number. |
ipv6 address dhcp-alloc
ipv6 dhcp client duid
ipv6 dhcp client pd
display ipv6 dhcp client statistics
Use display ipv6 dhcp client statistics to display DHCPv6 client statistics.
display ipv6 dhcp client statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics for all DHCPv6 clients.
# Display DHCPv6 client statistics on Ten-GigabitEthernet 0/0/15.
<Sysname> display ipv6 dhcp client statistics interface ten-gigabitethernet 0/0/15
Interface : Ten-GigabitEthernet0/0/15
Reply : 1
Advertise : 0
Reconfigure : 0
Invalid : 0
Packets sent : 5
Solicit : 0
Request : 0
Renew : 0
Rebind : 0
Information-request : 5
Release : 0
Decline : 0
Table 43 Command output
Interface that acts as the DHCPv6 client. |
Packets Received |
Number of received packets. |
Reply |
Number of received reply packets. |
Advertise |
Number of received advertise packets. |
Reconfigure |
Number of received reconfigure packets. |
Invalid |
Number of invalid packets. |
Packets sent |
Number of sent packets. |
Solicit |
Number of sent solicit packets. |
Request |
Number of sent request packets. |
Renew |
Number of sent renew packets. |
Rebind |
Number of sent rebind packets. |
Number of sent information request packets. |
Release |
Number of sent release packets. |
Decline |
Number of sent decline packets. |
reset ipv6 dhcp client statistics
Use ipv6 address dhcp-alloc to configure an interface to use DHCPv6 for IPv6 address acquisition.
Use undo ipv6 address dhcp-alloc to cancel an interface from using DHCPv6, and clear the obtained IPv6 address and other configuration parameters.
ipv6 address dhcp-alloc [ option-group option-group-number | rapid-commit ] *
An interface does not use DHCPv6 for IPv6 address acquisition.
VLAN interface view
option-group option-group-number: Enables the DHCPv6 client to create a dynamic DHCPv6 option group for saving the configuration parameters, and assigns an ID to the option group. The value range for the ID is 1 to 100. If you do not specify this option, the DHCPv6 client does not create any dynamic DHCPv6 option groups.
rapid-commit: Supports rapid address or prefix assignment.
# Configure Ten-GigabitEthernet 0/0/15 to use DHCPv6 for IPv6 address acquisition. Configure the DHCPv6 client to support rapid address assignment and create dynamic DHCPv6 option group 1 for the configuration parameters obtained.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 address dhcp-alloc rapid-commit option-group 1
ipv6 dhcp client dscp
Use ipv6 dhcp client dscp to set the DSCP value for DHCPv6 packets sent by the DHCPv6 client.
Use undo ipv6 dhcp client dscp to restore the default.
ipv6 dhcp client dscp dscp-value
The DSCP value in DHCPv6 packets is 56.
dscp-value: Sets the DSCP value for DHCPv6 packets, in the range of 0 to 63.
The DSCP value is carried in the Traffic class field of a DHCPv6 packet. It specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for DHCPv6 packets sent by the DHCPv6 client.
[Sysname] ipv6 dhcp client dscp 30
Use ipv6 dhcp client duid to configure the DHCPv6 client DUID for an interface.
Use undo ipv6 dhcp client duid to restore the default.
ipv6 dhcp client duid { ascii ascii-string | hex hex-string | mac interface-type interface-number }
The interface uses the device bridge MAC address to generate its DHCPv6 client DUID.
VLAN interface view
ascii ascii-string: Specifies a case-sensitive ASCII string of 1 to 130 characters as the DHCPv6 client DUID.
hex hex-string: Specifies a hexadecimal number of 2 to 260 characters as the DHCPv6 client DUID.
mac interface-type interface-number: Specifies the MAC address of the specified interface as the DHCPv6 client DUID. The interface-type interface-number option specifies an interface by its type and number.
A DHCPv6 client pads its DUID into the Option 1 of the DHCPv6 packet that it sends to the DHCPv6 server. The DHCPv6 server can assign specific IPv6 addresses or prefixes to DHCPv6 clients with specific DUIDs.
The DUID of a DHCPv6 client is the globally unique identifier of the client, so make sure the DUID that you configure is unique.
# Specify the MAC address of Ten-GigabitEthernet 0/0/16 as the DHCPv6 client DUID for Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp client duid mac ten-gigabitethernet 0/0/16
ipv6 dhcp client pd
Use ipv6 dhcp client pd to configure an interface to use DHCPv6 for IPv6 prefix acquisition.
Use undo ipv6 dhcp client pd to cancel an interface from using DHCPv6, and clear the obtained IPv6 prefix and other configuration parameters.
ipv6 dhcp client pd prefix-number [ option-group option-group-number | rapid-commit ]*
An interface does not use DHCPv6 for IPv6 prefix acquisition.
VLAN interface view
prefix-number: Specifies an IPv6 prefix ID in the range of 1 to 1024. After obtaining an IPv6 prefix, the client assigns the ID to the IPv6 prefix.
# Configure Ten-GigabitEthernet 0/0/15 to use DHCPv6 for IPv6 prefix acquisition. Specify IDs for the dynamic IPv6 prefix and dynamic DHCPv6 option group, and configure the client to support rapid prefix assignment.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp client pd 1 rapid-commit option-group 1
ipv6 dhcp client stateful
Use ipv6 dhcp client stateful to configure an interface to use DHCPv6 for IPv6 address and prefix acquisition.
Use undo ipv6 dhcp client stateful to cancel an interface from using DHCPv6, and clear the obtained IPv6 address, prefix, and other configuration parameters.
ipv6 dhcp client stateful prefix prefix-number [ option-group option-group-number | rapid-commit ] *
An interface does not use DHCPv6 for IPv6 address and prefix acquisition.
VLAN interface view
prefix prefix-number: Specifies an IPv6 prefix ID in the range of 1 to 1024. After obtaining an IPv6 prefix, the client assigns the ID to the IPv6 prefix.
rapid-commit: Supports rapid address and prefix assignment.
The ipv6 dhcp client stateful command takes effect if it is configured with the ipv6 address dhcp-alloc and ipv6 dhcp client pd commands on an interface. You must execute the undo ipv6 dhcp client stateful command to have the ipv6 address dhcp-alloc and ipv6 dhcp client pd commands take effect.
# Configure Ten-GigabitEthernet 0/0/15 to use DHCPv6 for IPv6 address and prefix acquisition. Specify IDs for the dynamic IPv6 prefix and dynamic DHCPv6 option group, and configure the client to support rapid address and prefix assignment.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp client stateful prefix 1 rapid-commit option-group 1
ipv6 dhcp client pd
ipv6 dhcp client stateless enable
Use ipv6 dhcp client stateless enable to enable stateless DHCPv6.
Use undo ipv6 dhcp client stateless enable to disable stateless DHCPv6.
Stateless DHCPv6 is disabled.
VLAN interface view
Stateless DHCPv6 enables the interface to send an Information-request message to the multicast address of all DHCPv6 servers and DHCPv6 relay agents for configuration parameters.
# Enable stateless DHCPv6 on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp client stateless enable
Use reset ipv6 dhcp client statistics to clear DHCPv6 client statistics.
reset ipv6 dhcp client statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears all DHCPv6 client statistics.
# Clear all DHCPv6 client statistics.
<Sysname> reset ipv6 dhcp client statistics
DHCPv6 snooping commands
DHCPv6 snooping works between the DHCPv6 client and the DHCPv6 server or between the DHCPv6 client and DHCPv6 the relay agent. DHCPv6 snooping does not work between the DHCPv6 server and the DHCPv6 relay agent.
display ipv6 dhcp snooping binding
Use display ipv6 dhcp snooping binding to display DHCPv6 snooping entries.
display ipv6 dhcp snooping binding [ address ipv6-address [ vlan vlan-id ] ]
address ipv6-address: Displays the DHCPv6 snooping entry for the specified IPv6 address. If you do not specify an IPv6 address, this command displays DHCPv6 snooping entries for all IPv6 addresses.
vlan vlan-id: Specifies the ID of the VLAN where the IPv6 address resides. If you do not specify a VLAN, this command displays DHCPv6 snooping entries for the IPv6 address in all VLANs.
# Display all DHCPv6 snooping entries.
<Sysname> display ipv6 dhcp snooping binding
1 DHCPv6 snooping entries found.
IPv6 address MAC address Lease VLAN SVLAN Interface
2::1 00e0-fc00-0006 54 2 N/A Ten-GigabitEthernet0/0/15
Table 44 Command output
IPv6 Address |
IPv6 address assigned to the DHCPv6 client. |
MAC Address |
MAC address of the DHCPv6 client. |
Lease |
Remaining lease duration in seconds. |
VLAN |
When both DHCPv6 snooping and QinQ are enabled or the DHCPv6 packet contains two VLAN tags, this field identifies the outer VLAN tag. Otherwise, it identifies the VLAN where the port connecting the DHCPv6 client resides. |
SVLAN |
When both DHCPv6 snooping and QinQ are enabled or the DHCPv6 packet contains two VLAN tags, this field identifies the inner VLAN tag. Otherwise, it displays N/A. |
Port connecting to the DHCPv6 client. |
ipv6 dhcp snooping binding record
reset ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
Use display ipv6 dhcp snooping binding database to display information about DHCPv6 snooping entry auto backup.
# Display information about DHCPv6 snooping entry auto backup.
<Sysname> display ipv6 dhcp snooping binding database
File name : database.dhcp
Username :
Password :
Update interval : 600 seconds
Latest write time : Feb 27 18:48:04 2012
Status : Last write succeeded.
Table 45 Command output
File name |
Name of the DHCPv6 snooping entry backup file. |
Username |
Username for accessing the URL of the remote backup file. |
Password |
Password for accessing the URL of the remote backup file. This field displays ****** if a password is configured. |
Update interval |
Waiting time in seconds after a DHCPv6 snooping entry change for the DHCPv6 snooping device to update the backup file. |
Latest write time |
Time of the latest update. |
Status |
Update state: · Writing—The backup file is being updated. · Last write succeeded—The backup file was successfully updated. · Last write failed—The backup file failed to be updated. |
display ipv6 dhcp snooping packet statistics
Use display ipv6 dhcp snooping packet statistics to display DHCPv6 packet statistics for DHCPv6 snooping.
In standalone mode:
display ipv6 dhcp snooping packet statistics [ slot slot-number ]
In IRF mode:
display ipv6 dhcp snooping packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DHCPv6 packet statistics for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DHCPv6 packet statistics for the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# Display DHCPv6 packet statistics for DHCPv6 snooping.
<Sysname> display ipv6 dhcp snooping packet statistics
DHCPv6 packets received : 100
DHCPv6 packets sent : 200
Invalid DHCPv6 packets dropped : 0
reset ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping trust
Use display ipv6 dhcp snooping trust to display information about trusted ports.
# Display information about trusted ports.
<Sysname> display ipv6 dhcp snooping trust
DHCPv6 snooping is enabled.
Interface Trusted
Ten-GigabitEthernet0/0/15 Trusted
The output shows that DHCPv6 snooping is enabled and Ten-GigabitEthernet 0/0/15 is the trusted port.
ipv6 dhcp snooping binding database filename
Use ipv6 dhcp snooping binding database filename to configure the DHCPv6 snooping device to back up DHCPv6 snooping entries to a file.
Use undo ipv6 dhcp snooping binding database filename to disable the auto backup and remove the backup file.
ipv6 dhcp snooping binding database filename { filename | url url [ username username [ password { cipher | simple } string ] ] }
The DHCPv6 snooping device does not back up DHCPv6 snooping entries.
filename: Specifies the name of a local backup file. For information about the filename argument, see Fundamentals Configuration Guide.
url url: Specifies the URL of a remote backup file. The URL is a case-sensitive string of 1 to 255 characters. Do not include a username or password in the URL. The supported path format type varies by server.
username username: Specifies the username for accessing the URL of the remote backup file. The username is a case-sensitive string of 1 to 32 characters. Do not specify this option if a username is not required for accessing the URL.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters. Do not specify this argument if a password is not required for accessing the URL of the remote backup file.
This command automatically creates the file if you specify a nonexistent file.
With this command executed, the DHCPv6 snooping device backs up its snooping entries immediately and runs auto backup. The snooping device, by default, waits 300 seconds after a DHCPv6 snooping entry change to update the backup file. You can use the ipv6 dhcp snooping binding database update interval command to change the waiting time. If no DHCPv6 snooping entry changes, the backup file is not updated.
As a best practice, back up the DHCPv6 snooping entries to a remote file. If you use the local storage medium, the frequent erasing and writing might damage the medium and then cause the DHCPv6 snooping device malfunction.
When the file is on a remote device, follow these restrictions and guidelines to specify the URL, username, and password:
· If the file is on an FTP server, enter URL in the format of ftp://server address:port/file path, where the port number is optional.
· If the file is on a TFTP server, enter URL in the format of tftp://server address:port/file path, where the port number is optional.
· The username and password must be the same as those configured on the FTP server. If the server authenticates only the username, the password can be omitted.
· If the IP address of the server is an IPv6 address, enclose the address in a pair of brackets, for example, ftp://[1::1]/database.dhcp.
· You can also specify the DNS domain name for the server address field, for example, ftp://company/database.dhcp.
# Configure the DHCPv6 snooping device to back up DHCPv6 snooping entries to the file database.dhcp.
[Sysname] ipv6 dhcp snooping binding database filename database.dhcp
# Configure the DHCPv6 snooping device to back up DHCPv6 snooping entries to the file database.dhcp in the working directory of the FTP server at 1::1.
[Sysname] ipv6 dhcp snooping binding database filename url ftp://[1::1]/database.dhcp username 1 password simple 1
# Configure the DHCPv6 snooping device to back up DHCPv6 snooping entries to the file database.dhcp in the working directory of the TFTP server at 2::1.
[Sysname] ipv6 dhcp snooping binding database filename url tftp://[2::1]/database.dhcp
Use ipv6 dhcp snooping binding database update interval to set the waiting time for the DHCPv6 snooping device to update the backup file after a DHCPv6 snooping entry change.
Use undo ipv6 dhcp snooping binding database update interval to restore the default.
ipv6 dhcp snooping binding database update interval interval
The DHCPv6 snooping device waits 300 seconds to update the backup file after a DHCPv6 snooping entry change. If no DHCPv6 snooping entry changes, the backup file is not updated.
interval: Sets the waiting time in seconds, in the range of 60 to 864000.
When a DHCPv6 snooping entry is learned, updated, or removed, the waiting period starts. The DHCPv6 snooping device updates the backup file when the waiting period is reached. All snooping entries changed during the period will be saved to the backup file.
The waiting time takes effect only after you configure the DHCPv6 snooping entry auto backup by using the ipv6 dhcp snooping binding database filename command.
# Set the waiting time to 600 seconds for the DHCPv6 snooping device to update the backup file.
[Sysname] ipv6 dhcp snooping binding database update interval 600
ipv6 dhcp snooping binding database update now
Use ipv6 dhcp snooping binding database update now to manually save DHCPv6 snooping entries to the backup file.
Each time this command is executed, the DHCPv6 snooping entries are saved to the backup file.
This command takes effect only after you configure the DHCPv6 snooping entry auto backup by using the ipv6 dhcp snooping binding database filename command.
# Manually save DHCPv6 snooping entries to the backup file.
[Sysname] ipv6 dhcp snooping binding database update now
Use ipv6 dhcp snooping binding record to enable recording of client information in DHCPv6 snooping entries.
Use undo ipv6 dhcp snooping binding record to disable the feature.
DHCPv6 snooping does not record client information.
Layer 2 Ethernet interface/Layer 2 aggregate interface view
This command enables DHCPv6 snooping on the port directly connected to the clients to record client information in DHCPv6 snooping entries.
# Enable recording of client information in DHCPv6 snooping entries on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp snooping binding record
ipv6 dhcp snooping check request-message
Use ipv6 dhcp snooping check request-message to enable the DHCPv6-REQUEST check feature.
Use undo ipv6 dhcp snooping check request-message to disable the DHCPv6-REQUEST check feature.
The DHCPv6-REQUEST check feature is disabled.
Use the DHCPv6-REQUEST check feature to protect the DHCPv6 server against DHCPv6 client spoofing attacks. The feature enables the DHCPv6 snooping device to check every received DHCPv6-RENEW, DHCPv6-DECLINE, or DHCPv6-RELEASE message against DHCPv6 snooping entries.
· If any criterion in an entry is matched, the device compares the entry with the message information.
¡ If they are consistent, the device considers the message valid and forwards it to the DHCPv6 server.
¡ If they are different, the device considers the message forged and discards it.
· If no matching entry is found, the device forwards the message to the DHCPv6 server.
# Enable DHCPv6-REQUEST check.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp snooping check request-message
ipv6 dhcp snooping deny
Use ipv6 dhcp snooping deny to configure a port as DHCPv6 packet blocking port.
Use undo ipv6 dhcp snooping deny to restore the default.
A port does not block DHCPv6 requests.
CAUTION: To avoid IPv6 address and prefix acquisition failure, configure a port to block DHCPv6 packets only if no DHCPv6 clients are connected to it. |
To enable a port on the snooping device to drop all incoming DHCPv6 requests, configure that port as a DHCPv6 packet blocking port.
# Configure Ten-GigabitEthernet 0/0/15 as a DHCPv6 packet blocking port.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp snooping deny
ipv6 dhcp snooping enable
Use ipv6 dhcp snooping enable to enable DHCPv6 snooping.
Use undo ipv6 dhcp snooping enable to disable DHCPv6 snooping.
DHCPv6 snooping is disabled.
The DHCPv6 snooping feature works together with trusted port configuration as follows:
· The device forwards DHCPV6 Request messages to the DHCPv6 server only on trusted ports. If no trusted port is configured, the device discards all DHCPV6 Request messages.
· The device discards DHCPv6 server responses received on untrusted ports.
This mechanism ensures that DHCPv6 clients obtain IPv6 addresses or prefixes from authorized DHCPv6 servers.
When DHCPv6 snooping is disabled, all ports on the device forward responses from DHCPv6 servers.
# Enable DHCPv6 snooping.
[Sysname] ipv6 dhcp snooping enable
ipv6 dhcp snooping log enable
Use ipv6 dhcp snooping log enable to enable DHCPv6 snooping logging.
Use undo ipv6 dhcp snooping log enable to disable DHCPv6 snooping logging.
DHCPv6 snooping logging is disabled.
This command enables the DHCPv6 snooping device to generate DHCPv6 snooping logs and send them to the information center. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable this feature if the log generation affects the device performance.
# Enable DHCPv6 snooping logging.
[Sysname] ipv6 dhcp snooping log enable
ipv6 dhcp snooping max-learning-num
Use ipv6 dhcp snooping max-learning-num to set the maximum number of DHCPv6 snooping entries for an interface to learn.
Use undo ipv6 dhcp snooping max-learning-num to restore the default.
ipv6 dhcp snooping max-learning-num max-number
The number of DHCPv6 snooping entries for an interface to learn is not limited.
max-number: Sets the maximum number of DHCPv6 snooping entries for an interface to learn. The value range is 1 to 4294967295.
When an interface learns the maximum number of DHCPv6 snooping entries, the interface stops learning DHCPv6 snooping entries. This does not affect the operating of the DHCPv6 snooping feature.
# Configure the Layer 2 Ethernet interface Ten-GigabitEthernet 0/0/15 to learn a maximum of 10 DHCPv6 snooping entries.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp snooping max-learning-num 10
ipv6 dhcp snooping option interface-id enable
Use ipv6 dhcp snooping option interface-id enable to enable support for the interface-ID option (also called Option 18).
Use undo ipv6 dhcp snooping option interface-id enable to disable support for the interface-ID option.
Option 18 is not supported.
This command takes effect only when DHCPv6 snooping is globally enabled.
# Enable support for Option 18.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option interface-id string
Use ipv6 dhcp snooping option interface-id string to specify the content as the interface ID for Option 18.
Use undo ipv6 dhcp snooping option interface-id string to restore the default.
ipv6 dhcp snooping option interface-id [ vlan vlan-id ] string interface-id
undo ipv6 dhcp snooping option interface-id [ vlan vlan-id ] string
The DHCPv6 snooping device uses its DUID as the content for Option 18.
vlan vlan-id: Pads the interface ID for packets received from the specified VLAN. If you do not specify a VLAN, the device pads the interface ID for packets received from the default VLAN.
interface-id: Specifies a string of 1 to 128 characters as the interface ID.
# Specify company001 as the interface ID.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp snooping option interface-id string company001
ipv6 dhcp snooping option remote-id enable
Use ipv6 dhcp snooping option remote-id enable to enable support for the remote-ID option (also called Option 37).
Use undo ipv6 dhcp snooping option remote-id enable to disable support for the remote-ID option.
Option 37 is not supported.
# Enable support for Option 37.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
Use ipv6 dhcp snooping option remote-id string to specify the content as the remote ID for Option 37.
Use undo ipv6 dhcp snooping option remote-id string to restore the default.
ipv6 dhcp snooping option remote-id [ vlan vlan-id ] string remote-id
undo ipv6 dhcp snooping option remote-id [ vlan vlan-id ] string
The DHCPv6 snooping device uses its DUID as the content for Option 37.
vlan vlan-id: Pads the remote ID for packets received from the specified VLAN. If you do not specify a VLAN, the device pads the remote ID for packets received from the default VLAN.
remote-id: Specifies the a string of 1 to 128 characters as the remote ID.
# Specify device001 as the remote ID.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp snooping option remote-id string device001
Use ipv6 dhcp snooping trust to configure a port as a trusted port.
Use undo ipv6 dhcp snooping trust to restore the default state of a port.
After you enable DHCPv6 snooping, all ports are untrusted.
Specify the port facing the DHCPv6 server as trusted and specify the other ports as untrusted so DHCPv6 clients can obtain valid IP addresses.
# Specify Ten-GigabitEthernet 0/0/15 as a trusted port.
[Sysname-Ten-GigabitEthernet0/0/15] ipv6 dhcp snooping trust
Use reset ipv6 dhcp snooping binding to clear DHCPv6 snooping entries.
reset ipv6 dhcp snooping binding { all | address ipv6-address [ vlan vlan-id ] }
address ipv6-address: Clears the DHCPv6 snooping entry for the specified IPv6 address.
vlan vlan-id: Clears DHCPv6 snooping entries for the specified VLAN. If you do not specify a VLAN, this command clears DHCPv6 snooping entries for the default VLAN.
all: Clears all DHCPv6 snooping entries.
This command applies to all slots on a distributed device.
# Clear all DHCPv6 snooping entries.
<Sysname> reset ipv6 dhcp snooping binding all
Use reset ipv6 dhcp snooping packet statistics to clear DHCPv6 packet statistics for DHCPv6 snooping.
In standalone mode:
reset ipv6 dhcp snooping packet statistics [ slot slot-number ]
In IRF mode:
reset ipv6 dhcp snooping packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears DHCPv6 packet statistics for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears DHCPv6 packet statistics for the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# Clear DHCPv6 packet statistics for DHCPv6 snooping.
<Sysname> reset ipv6 dhcp snooping packet statistics
