03-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath M9000 Configuration Guide(V7)(R9900)-6W10003-Security Configuration Guide
28-IPsec configuration
28-IPsec configuration 2.19 MB
Configuring IPsec· 1
About IPsec· 1
IPsec framework· 1
IPsec security services· 1
Benefits of IPsec· 1
Security protocols· 1
Encapsulation modes· 2
Security association· 3
Authentication and encryption· 4
IPsec-protected traffic· 4
ACL-based IPsec· 5
Tunnel interface-based IPsec· 5
IPv6 routing protocol-based IPsec· 6
IPsec policy and IPsec profile· 7
IPsec RRI 8
IPsec smart link selection· 8
Protocols and standards· 9
vSystem support for features· 9
Restrictions and guidelines: IPsec configuration· 9
Implementing ACL-based IPsec· 9
ACL-based IPsec tasks at a glance· 10
Configuring an ACL· 11
Configuring an IPsec transform set 14
Configuring a manual IPsec policy· 16
Configuring an IKE-based IPsec policy· 17
Applying an IPsec policy to an interface· 21
Enabling ACL checking for de-encapsulated packets· 22
Configuring IPsec anti-replay· 22
Binding a source interface to an IPsec policy· 23
Enabling QoS pre-classify· 23
Configuring IPsec RRI 24
Configuring IPsec smart link selection· 25
Configuring IPsec netmask filtering· 27
Enabling IPsec flow overlap check· 28
Configuring IPsec for IPv6 routing protocols· 28
IPsec protection for IPv6 routing protocols tasks at a glance· 28
Configuring a manual IPsec profile· 29
Applying the IPsec profile to an IPv6 routing protocol 30
Configuring IPsec for tunnel interfaces· 30
IPsec protection for tunnel interfaces tasks at a glance· 30
Configuring an IKE-based IPsec profile· 31
Applying an IKE-based IPsec profile to a tunnel interface· 32
Configuring IPsec for an SDWAN tunnel interface· 32
IPsec protection for SDWAN tunnel interface tasks at a glance· 32
Configuring an SDWAN IPsec profile· 33
Applying an SDWAN IPsec profile to an SDWAN tunnel interface· 33
Configuring IPsec anti-replay redundancy· 34
Configuring the global IPsec SA lifetime and idle timeout 35
Configuring IPsec fragmentation· 35
Configuring the DF bit of IPsec packets· 36
Setting the maximum number of IPsec tunnels· 37
Configuring the device as responder-only for IPsec SA negotiation· 37
Enabling logging for IPsec packets· 38
Enabling logging for IPsec negotiation· 38
Configuring SNMP notifications for IPsec· 38
Enabling logging for creations and deletions of P2MP IPsec tunnel entries· 39
Display and maintenance commands for IPsec· 39
IPsec configuration examples‌· 42
Example: Configuring a manual mode IPsec tunnel for IPv4 packets between gateways· 42
Example: Configuring an IKE-based IPsec tunnel for IPv4 packets between gateways· 47
Example: Configuring an IKE-based IPsec tunnel for IPv4 packets between gateways (RSA signature authentication) 54
Example: Configuring an IKE-based IPsec tunnel for IPv4 packets between gateways (SM2-DE digital envelope authentication) 62
Example: Configuring an IKEv2-based IPsec tunnel for IPv4 packets between gateways (preshared key authentication) 69
Example: Configuring an IKEv2-based IPsec tunnel for IPv4 packets between gateways (RSA signature authentication) 76
Example: Configuring an IKE-based IPsec NAT traversal tunnel for IPv4 packets between gateways· 87
Example: Configuring an IKEv2-based IPsec NAT traversal tunnel for IPv4 packets between gateways  93
Example: Configuring an IKE-based IPsec tunnel for IPv4 packets between a host and a gateway (remote extended authentication) 101
Example: Configuring an IKE-based IPsec tunnel for IPv4 packets between a host and a gateway (local extended authentication and address pool authorization) 105
Example: Configuring an IKE-based IPsec tunnel for IPv6 packets between gateways· 110
Example: Configuring IPsec tunnels for IPv4 packets between headquarters and branches (IPsec policy template mode) 117
Example: Configuring IPsec for RIPng· 126
Example: Configuring IPsec RRI 131
Example: Configuring IPsec smart link selection· 138
Example: Configuring IPsec in multiple VPN instances· 145
Example: Configuring headquarters to use dual links to establish IPsec tunnels with branches· 152
Example: Configuring IPsec tunnel interface-based IPsec for IPv4 packets· 166
Configuring IKE·· 173
About IKE· 173
Benefits of IKE· 173
Relationship between IPsec and IKE· 173
IKE negotiation process· 174
IKE security mechanism·· 176
Protocols and standards· 176
Restrictions: Hardware compatibility with IKE· 176
vSystem support for features· 176
IKE tasks at a glance· 177
Prerequisites for IKE configuration· 177
Configuring an IKE profile· 178
Creating an IKE profile· 178
Configuring peer IDs for the IKE profile· 178
Specifying the IKE keychain or PKI domain· 178
Configuring the IKE phase 1 negotiation mode· 179
Specifying IKE proposals for the IKE profile· 179
Configuring the local ID for the IKE profile· 180
Specifying an inside VPN instance for the IKE profile· 180
Configuring optional features for the IKE profile· 180
Configuring an IKE proposal 182
Configuring an IKE keychain· 183
Configuring the global identity information· 184
Configuring the IKE keepalive feature· 184
Configuring the IKE NAT keepalive feature· 185
Configuring global IKE DPD·· 185
Enabling invalid SPI recovery· 186
Setting the maximum number of IKE SAs· 187
Configuring IKE address pools· 187
Specifying the address assignment scope for the HA group member device· 187
Configuring IKE negotiation compatibility· 188
Configuring SM4-CBC key length compatibility and GM main mode compatibility· 188
Configuring the SM4 algorithm version for IKE GM main mode negotiation· 189
Configuring the IKE version for IKE GM main mode negotiation· 189
Specifying the remote certificate serial number 190
Configuring SNMP notifications and logging for IKE· 190
Configuring SNMP notifications for IKE· 190
Enabling logging for IKE negotiation· 191
Display and maintenance commands for IKE· 191
Troubleshooting IKE· 191
IKE negotiation failed because no matching IKE proposals were found· 191
IKE negotiation failed because no IKE proposals or IKE keychains are specified correctly· 192
IPsec SA negotiation failed because no matching IPsec transform sets were found· 193
IPsec SA negotiation failed due to invalid identity information· 193
Configuring IKEv2· 197
About IKEv2· 197
IKEv2 negotiation process· 197
New features in IKEv2· 198
Protocols and standards· 198
Restrictions: Hardware compatibility with IKEv2· 199
IKEv2 tasks at a glance· 199
Prerequisites for IKEv2 configuration· 199
Configuring an IKEv2 profile· 200
Creating an IKEv2 profile· 200
Specifying the local and remote identity authentication methods· 200
Configuring the IKEv2 keychain or PKI domain· 200
Configuring the local ID for the IKEv2 profile· 201
Configuring peer IDs for the IKEv2 profile· 201
Specifying a VPN instance for the IKEv2 profile· 202
Specifying an inside VPN instance for the IKEv2 profile· 202
Configuring optional features for the IKEv2 profile· 202
Configuring an IKEv2 policy· 204
Configuring an IKEv2 proposal 205
Configuring an IKEv2 keychain· 205
Configure global IKEv2 parameters· 206
Enabling the cookie challenging feature· 206
Configuring the IKEv2 DPD feature· 207
Configuring the IKEv2 NAT keepalive feature· 207
Configuring IKEv2 address pools· 207
Setting a limit to the number of IKEv2 SAs· 208
Display and maintenance commands for IKEv2· 208
Troubleshooting IKEv2· 209
IKEv2 negotiation failed because no matching IKEv2 proposals were found· 209
IPsec SA negotiation failed because no matching IPsec transform sets were found· 209
IPsec tunnel establishment failed· 210
Configuring IPsec
About IPsec
IP Security (IPsec) is defined by the IETF to provide interoperable, high-quality, cryptography-based security for IP communications. It is a Layer 3 VPN technology that transmits data in a secure channel established between two endpoints (such as two security gateways). Such a secure channel is usually called an IPsec tunnel.
IPsec framework
IPsec is a security framework that has the following protocols and algorithms:
·     Authentication Header (AH).
·     Encapsulating Security Payload (ESP).
·     Internet Key Exchange (IKE).
·     Algorithms for authentication and encryption.
AH and ESP are security protocols that provide security services. IKE performs automatic key exchange. For more information about IKE, see Security Configuration Guide. "Configuring IKE." "Configuring IKE." "Configuring IKE."
IPsec provides the following security services for data packets in the IP layer:
·     Confidentiality—The sender encrypts packets before transmitting them over the Internet, protecting the packets from being eavesdropped en route.
·     Data integrity—The receiver verifies the packets received from the sender to make sure they are not tampered with during transmission.
·     Data origin authentication—The receiver verifies the authenticity of the sender.
·     Anti-replay—The receiver examines packets and drops outdated and duplicate packets.
Benefits of IPsec
IPsec delivers the following benefits:
·     Reduced key negotiation overhead and simplified maintenance by supporting the IKE protocol. IKE provides automatic key negotiation and automatic IPsec security association (SA) setup and maintenance.
·     Good compatibility. You can apply IPsec to all IP-based application systems and services without modifying them.
·     Encryption on a per-packet rather than per-flow basis. Per-packet encryption allows for flexibility and greatly enhances IP security.
Security protocols
IPsec comes with two security protocols, AH and ESP. They define how to encapsulate IP packets and the security services that they can provide.
·     AH (protocol 51) defines the encapsulation of the AH header in an IP packet, as shown in Figure 3. AH can provide data origin authentication, data integrity, and anti-replay services to prevent data tampering, but it cannot prevent eavesdropping. Therefore, it is suitable for transmitting non-confidential data. Authentication algorithms supported by AH include HMAC-MD5 and HMAC-SHA1. AH does not support NAT traversal.
·     ESP (protocol 50) defines the encapsulation of the ESP header and trailer in an IP packet, as shown in Figure 3. ESP can provide data encryption, data origin authentication, data integrity, and anti-replay services. Unlike AH, ESP can guarantee data confidentiality because it can encrypt the data before encapsulating the data to IP packets. ESP-supported encryption algorithms include DES, 3DES, and AES, and authentication algorithms include HMAC-MD5 and HMAC-SHA1.
Both AH and ESP provide authentication services, but the authentication service provided by AH is stronger. In practice, you can choose either or both security protocols. When both AH and ESP are used, an IP packet is encapsulated first by ESP and then by AH.
Encapsulation modes
IPsec supports the following encapsulation modes: transport mode and tunnel mode.
Transport mode
The security protocols protect the upper layer data of an IP packet. Only the transport layer data is used to calculate the security protocol headers. The calculated security protocol headers and the encrypted data (only for ESP encapsulation) are placed after the original IP header. You can use the transport mode when end-to-end security protection is required (the secured transmission start and end points are the actual start and end points of the data). The transport mode is typically used for protecting host-to-host communications, as shown in Figure 1.
Figure 1 IPsec protection in transport mode
Tunnel mode
The security protocols protect the entire IP packet. The entire IP packet is used to calculate the security protocol headers. The calculated security protocol headers and the encrypted data (only for ESP encapsulation) are encapsulated in a new IP packet. In this mode, the encapsulated packet has two IP headers. The inner IP header is the original IP header. The outer IP header is added by the network device that provides the IPsec service. You must use the tunnel mode when the secured transmission start and end points are not the actual start and end points of the data packets (for example, when two gateways provide IPsec but the data start and end points are two hosts behind the gateways). The tunnel mode is typically used for protecting gateway-to-gateway communications, as shown in Figure 2.
Figure 2 IPsec protection in tunnel mode
Figure 3 shows how the security protocols encapsulate an IP packet in different encapsulation modes.
Figure 3 Security protocol encapsulations in different modes
A security association (SA) is an agreement negotiated between two communicating parties called IPsec peers. An SA includes the following parameters for data protection:
·     Security protocols (AH, ESP, or both).
·     Encapsulation mode (transport mode or tunnel mode).
·     Authentication algorithm (HMAC-MD5, SM3, or HMAC-SHA1).
·     Encryption algorithm (DES, 3DES, SM, or AES).
·     Shared keys and their lifetimes.
An SA is unidirectional. At least two SAs are needed to protect data flows in a bidirectional communication. If two peers want to use both AH and ESP to protect data flows between them, they construct an independent SA for each protocol in each direction.
An SA is uniquely identified by a triplet, which consists of the security parameter index (SPI), destination IP address, and security protocol identifier. An SPI is a 32-bit number. It is transmitted in the AH/ESP header.
SA setup
An SA can be set up manually or through IKE.
·     Manual mode—Configure all parameters for the SA through commands. This configuration mode is complex and does not support some advanced features (such as periodic key update), but it can implement IPsec without IKE. This mode is mainly used in small and static networks or when the number of IPsec peers in the network is small.
·     IKE negotiation mode—The peers negotiate and maintain the SA through IKE. This configuration mode is simple and has good expansibility. As a best practice, set up SAs through IKE negotiations in medium- and large-scale dynamic networks.
SA aging
A manually configured SA never ages out.
An IKE-created SA has a lifetime and will be deleted when its lifetime timer expires.
Before the SA lifetime timer expires, IKE negotiates a new SA, which takes over immediately after its creation. The interval from the creation of an SA to the negotiation of a new SA is the SA's soft lifetime.
The SA soft lifetime is calculated as follows: SA soft lifetime = SA lifetime – SA soft lifetime buffer. If the SA soft lifetime buffer is not configured, the system calculates a default SA soft lifetime based on the SA lifetime.
The lifetime of an IKE-created SA comes in two types:
·     Time-based lifetime—Defines how long the SA can exist after it is created.
·     Traffic-based lifetime—Defines the maximum traffic that the SA can process.
If both lifetime timers are configured for an SA, the SA is deleted when either of the lifetime timers expires.
IPsec uses hash algorithms to perform authentication. A hash algorithm produces a fixed-length digest for an arbitrary-length message. IPsec peers respectively calculate message digests for each packet. The receiver compares the local digest with that received from the sender. If the digests are identical, the receiver considers the packet intact and the sender's identity valid. IPsec supports the following types of authentication algorithms:
·     Hash-based Message Authentication Code (HMAC) based authentication algorithms, including HMAC-MD5 and HMAC-SHA.
HMAC-MD5 is faster but less secure than HMAC-SHA.
·     SM3 authentication algorithms.
Encryption algorithms
IPsec uses symmetric encryption algorithms, which encrypt and decrypt data by using the same keys. The following encryption algorithms are available for IPsec on the device:
·     DES—Encrypts a 64-bit plaintext block with a 56-bit key. DES is the least secure but the fastest algorithm.
·     3DES—Encrypts plaintext data with three 56-bit DES keys. The key length totals up to 168 bits. It provides moderate security strength and is slower than DES.
·     AES—Encrypts plaintext data with a 128-bit, 192-bit, or 256-bit key. AES provides the highest security strength and is slower than 3DES.
·     SM—Encrypts plaintext data with a 128-bit key. SM provides the same level of security strength as AES.
Crypto engine
The IPsec feature is resource intensive for its complex encryption/decryption and authentication algorithms. To improve processing performance, you can use crypto engine to offload IPsec tasks.
The crypto engine processes all IPsec protected packets and hands the processed packets back to the device for forwarding.
For more information about crypto engines, see "Configuring crypto engines."
IPsec tunnels can protect the following types of traffic:
·     Packets that match specific ACLs.
·     Packets routed to a tunnel interface.
·     Packets of IPv6 routing protocols.
Two peers use security policies (IPsec policies or IPsec profiles) to protect packets between them. A security policy defines the range of packets to be protected by IPsec and the security parameters used for the protection. For more information about IPsec policies and IPsec profiles, see "IPsec policy and IPsec profile."
The following information describes how IPsec protects packets:
·     When an IPsec peer identifies the packets to be protected according to the security policy, it sets up an IPsec tunnel and sends the packet to the remote peer through the tunnel. The IPsec tunnel can be manually configured beforehand, or it can be set up through IKE negotiation triggered by the packet. The IPsec tunnels are actually the IPsec SAs. The inbound packets are protected by the inbound SA, and the outbound packets are protected by the outbound SA.
·     When the remote IPsec peer receives the packet, it drops, de-encapsulates, or directly forwards the packet according to the configured security policy.
ACL-based IPsec
To implement ACL-based IPsec, configure an ACL to define the data flows to be protected, specify the ACL in an IPsec policy, and then apply the IPsec policy to an interface. You can apply an IPsec policy to physical interfaces such as Ethernet interfaces, or virtual interfaces such as tunnel interfaces and virtual template interfaces.
ACL-based IPsec works as follows:
·     When packets sent by the interface match a permit rule of the ACL, the packets are protected by the outbound IPsec SA and encapsulated with IPsec.
·     When the interface receives an IPsec packet destined for the local device, it searches for the inbound IPsec SA according to the SPI in the IPsec packet header for de-encapsulation. If the de-encapsulated packet matches a permit rule of the ACL, the device processes the packet. If the de-encapsulated packet does not match any permit rule of the ACL, the device drops the packet.
The device supports the following data flow protection modes:
·     Standard mode—One IPsec tunnel protects one data flow. The data flow permitted by an ACL rule is protected by one IPsec tunnel that is established solely for it.
·     Aggregation mode—One IPsec tunnel protects all data flows permitted by all the rules of an ACL. This mode is only used to communicate with old-version devices.
·     Per-host mode—One IPsec tunnel protects one host-to-host data flow. One host-to-host data flow is identified by one ACL rule and protected by one IPsec tunnel established solely for it. This mode consumes more system resources when multiple data flows exist between two subnets to be protected.
Tunnel interface-based IPsec is also known as virtual tunnel interface (VTI)-based IPsec.
To implement tunnel interface-based IPsec, configure an IPsec profile and apply the IPsec profile to a tunnel interface. IPsec will protect all traffic routed to the tunnel interface, except the traffic that you specify not to protect. Tunnel interface-based IPsec supports only the tunnel encapsulation mode.
Compared with ACL-based IPsec, tunnel interface-based IPsec has the following advantages:
·     Supports multicast traffic protection.
·     Supports dynamic routing protocol advertisement between the IPsec tunnel peers.
·     Simplifies configuration. Tunnel interface-based IPsec does not require using ACL rules to define the traffic to be protected. The routing table directs the traffic to the tunnel interface for protection.
For tunnel interface-based IPsec, packet encapsulation and decapsulation are performed on the tunnel interfaces.
Figure 4 Tunnel interface encapsulation
As shown in Figure 4, a tunnel interface encapsulates an IP packet as follows:
1.     Upon receiving a clear text packet, the input interface sends the packet to the forwarding module for routing.
2.     If the packet requires IPsec protection, the forwarding module sends the packet to the tunnel interface.
3.     The tunnel interface encapsulates the packet into a new IP packet. The source and destination IP addresses in the new IP header are the source and destination IP addresses of the tunnel interface. Then, the tunnel interface sends the packet back to the forwarding module.
4.     The forwarding module looks up the routing table again and sends the packet out of the physical interface of the tunnel interface.
Figure 5 Tunnel interface de-encapsulation
As shown in Figure 5, a tunnel interface de-encapsulates an IP packet as follows:
5.     Upon receiving an encrypted packet, the inbound interface sends the packet to the forwarding module for routing.
6.     Because the packet is destined for the tunnel interface' source address and the payload protocol is AH or ESP, the forwarding module sends the packet to the tunnel interface.
7.     The tunnel interface de-encapsulates the packet (removes the outer IP header) and sends the de-encapsulated packet back to the forwarding module.
8.     The forwarding module looks up the routing table again and sends the packet out of the output interface.
You can implement IPv6 routing protocol-based IPsec by binding an IPsec profile to an IPv6 routing protocol. All packets of the protocol are encapsulated with IPsec. Supported IPv6 routing protocols include OSPFv3, IPv6 BGP, and RIPng.
All packets of the applications that are not bound to IPsec and the IPsec packets that failed to be de-encapsulated are dropped.
In one-to-many communication scenarios, you must configure the IPsec SAs for an IPv6 routing protocol in manual mode because of the following reasons:
·     The automatic key exchange mechanism protects communications between two points. In one-to-many communication scenarios, automatic key exchange cannot be implemented.
·     One-to-many communication scenarios require that all the devices use the same SA parameters (SPI and key) to receive and send packets. IKE negotiated SAs cannot meet this requirement.
IPsec policies and IPsec profiles define the parameters used to establish IPsec tunnels between two peers and the range of packets to be protected.
IPsec policy
An IPsec policy is a set of IPsec policy entries that have the same name but different sequence numbers.
An IPsec policy contains the following settings:
·     An ACL that defines the range of data flows to be protected.
·     An IPsec transform set that defines the security parameters used for IPsec protection.
·     IPsec SA establishment mode.
Supported IPsec SA establishment modes are manual configuration and IKE negotiation.
·     Local and remote IP addresses that define the start and end points of the IPsec tunnel.
In the same IPsec policy, an IPsec policy entry with a smaller sequence number has a higher priority. When sending a packet, the interface applied with an IPsec policy looks through the IPsec policy's entries in ascending order of sequence numbers. If the packet matches the ACL of an IPsec policy entry, the interface encapsulates the packet according to the IPsec policy entry. If no match is found, the interface sends the packet out without IPsec protection.
When the interface receives an IPsec packet destined for the local device, it searches for the inbound IPsec SA according to the SPI in the IPsec packet header for de-encapsulation. If the de-encapsulated packet matches a permit rule of the ACL, the device processes the packet. If the de-encapsulated packet does not match a permit rule of the ACL, the device drops the packet.
To protect traffic by using IPsec, you must apply an IPsec policy to an interface. The interface can be a physical interface, such as an Ethernet interface. It can also be a virtual interface, such as a tunnel and virtual template interface, to protect applications such as GRE and L2TP.
IPsec profile
An IPsec profile has similar settings as an IPsec policy. It is uniquely identified by a name and does not support ACL configuration.
IPsec profiles can be classified into the following types:
·     Manual IPsec profile—A manual IPsec profile is used to protect IPv6 routing protocols. It specifies the IPsec transform set used for protecting data flows, and the SPIs and keys used by the SAs.
·     IKE-based IPsec profile—An IKE-based IPsec profile is applied to tunnel interfaces to protect tunneled traffic. It specifies the IPsec transform sets used for protecting data flows, and the IKE profile used for IKE negotiation.
IPsec RRI
IPsec Reverse Route Injection (RRI) enables an IPsec tunnel gateway to automatically add and delete static routes destined for the protected private networks. It automatically adds the static routes when the IPsec SAs are established and deletes the static routes when the IPsec SAs are deleted. This greatly reduces the static route configuration work load on the gateway and increases the scalability of the IPsec VPN.
IPsec RRI is applicable to gateways that must provide many IPsec tunnels (for example, a headquarters gateway).
As shown in Figure 6, the traffic between the enterprise center and the branches are protected by IPsec. The gateway at the enterprise center is configured with static routes to route traffic to the IPsec-protected interfaces. It is difficult to add or modify static routes on the gateway at the enterprise center if the IPsec VPN has a large number of branches or if the network structure changes.
Figure 6 IPsec VPN
After you can enable IPsec RRI on the gateway, the gateway automatically adds a static route to the routing table each time an IPsec tunnel is established. The destination IP address is the protected private network. The next hop IP address can be the remote IP address of the IPsec tunnel (default) or a user-defined next hop IP address. Traffic destined for the peer end is routed to the IPsec tunnel interface and thereby protected by IPsec.
You can advertise the static routes created by IPsec RRI in the internal network, and the internal network device can use them to forward traffic in the IPsec VPN.
You can set preferences for the static routes created by IPsec RRI to implement flexible route management. For example, you can set the same preference for multiple routes to the same destination to implement load sharing, or you can set different preferences to implement route backup.
You can also set tags for the static routes created by IPsec RRI to implement flexible route control through routing policies.
To improve network stability and availability, a branch's IPsec gateway typically deploys multiple links to connect to the corporate headquarters. The qualities of these links (in terms of packet loss ratio and delay) are not static but keep changing with time. It is important that the branch gateway can dynamically select a link with desired transmission quality to establish the IPsec tunnel to the headquarters. IPsec smart link selection can meet this requirement.
IPsec smart link selection enables the branch gateway to monitor the real-time packet loss ratio and delay of the active link over which the IPsec tunnel is established. If the packet loss ratio or delay of the link exceeds the specified threshold, IPsec smart link selection reselects a link for the IPsec tunnel. You can also manually activate a link to establish the IPsec tunnel over that link.
·     RFC 2401, Security Architecture for the Internet Protocol
·     RFC 2402, IP Authentication Header
·     RFC 2406, IP Encapsulating Security Payload
·     RFC 4552, Authentication/Confidentiality for OSPFv3
Non-default vSystems do not support the following features:
·     Configuring a quantum-encryption-based IPsec policy.
·     Enabling ACL checking for de-encapsulated packets.
·     Configuring IPsec smart link selection.
·     Configuring IPsec netmask filtering.
·     Enabling IPsec flow overlap check.
·     Configuring IPsec fragmentation.
·     Setting the maximum number of IPsec tunnels.
·     Enabling logging for IPsec packets.
·     Enabling logging for IPsec negotiation.
·     Configuring SNMP negotiations for IPsec.
·     Enabling logging for creations and deletions of P2MP IPsec tunnel entries.
For information about the support of non-default vSystems for the commands, see IPsec command reference. For information about vSystem, see Virtual Technologies Configuration Guide.
Typically, IKE uses UDP port 500 for communication, and AH and ESP use the protocol numbers 51 and 50, respectively. Make sure traffic of these protocols is not denied on the interfaces with IKE or IPsec configured.
An IPsec tunnel established through an IPsec policy cannot protect multicast traffic. To protect multicast traffic, configure tunnel interface-based IPsec.
In transport mode, ACLs for IPsec take effect only on traffic that is generated by the device and traffic that is destined for the device. They do not take effect on traffic forwarded through the device. For example, an ACL-based IPsec tunnel can protect log messages the device sends to a log server, but it does not protect data flows and voice flows that are forwarded by the device.
To configure ACL-based IPsec, perform the following tasks:
1.     Configuring an ACL
2.
3.     Configuring an IPsec transform set
4.     Configuring an IPsec policy
¡     Configuring a manual IPsec policy
¡     Configuring an IKE-based IPsec policy
5.     Applying an IPsec policy to an interface
6.
7.     (Optional.) Configuring accessibility features for ACL-based IPsec
¡     Enabling ACL checking for de-encapsulated packets
¡     Configuring IPsec anti-replay
¡     Configuring IPsec anti-replay redundancy
¡     Binding a source interface to an IPsec policy
¡     Enabling QoS pre-classify
¡     Configuring the DF bit of IPsec packets
¡     Configuring IPsec RRI
¡     Configuring IPsec smart link selection
¡     Configuring IPsec netmask filtering
¡     Enabling IPsec flow overlap check
¡     Configuring the global IPsec SA lifetime and idle timeout
¡     Configuring IPsec fragmentation
¡     Setting the maximum number of IPsec tunnels
¡     Configuring the device as responder-only for IPsec SA negotiation
8.     (Optional.) Configuring logging and SNMP notification for IPsec
¡     Enabling logging for IPsec packets
¡     Enabling logging for IPsec negotiation
¡     Configuring SNMP notifications for IPsec
Configuring an ACL
IPsec uses ACLs to identify the traffic to be protected.
Keywords in ACL rules
An ACL is a collection of ACL rules. Each ACL rule is a deny or permit statement. A permit statement identifies a data flow protected by IPsec, and a deny statement identifies a data flow that is not protected by IPsec. IPsec compares a packet against the ACL rules and processes the packet according to the first rule it matches.
·     Each ACL rule matches both the outbound traffic and the returned inbound traffic. Suppose there is a rule rule 0 permit ip source 1.1.1.0 0.0.0.255 destination 2.2.2.0 0.0.0.255. This rule matches both traffic from 1.1.1.0 to 2.2.2.0 and traffic from 2.2.2.0 to 1.1.1.0.
·     In the outbound direction, if a permit statement is matched, IPsec considers that the packet requires protection and continues to process it. If a deny statement is matched or no match is found, IPsec considers that the packet does not require protection and delivers it to the next module.
·     In the inbound direction:
¡     Non-IPsec packets that match a permit statement are dropped.
¡     IPsec packets destined for the device itself are de-encapsulated. By default, the de-encapsulated packets are compared against the ACL rules. Only those that match a permit statement are processed. Other packets are dropped. If ACL checking for de-encapsulated IPsec packets is disabled, the de-encapsulated packets are not compared against the ACL rules and are directly processed by other modules.
When defining ACL rules for IPsec, follow these guidelines:
·     Permit only data flows that need to be protected and use the any keyword with caution. With the any keyword specified in a permit statement, all outbound traffic matching the permit statement will be protected by IPsec. All inbound IPsec packets matching the permit statement will be received and processed, but all inbound non-IPsec packets will be dropped. This will cause all the inbound traffic that does not need IPsec protection to be dropped.
·     Avoid statement conflicts in the scope of IPsec policy entries. When creating a deny statement, be careful with its match scope and match order relative to permit statements. The policy entries in an IPsec policy have different match priorities. ACL rule conflicts between them are prone to cause mistreatment of packets. For example, when configuring a permit statement for an IPsec policy entry to protect an outbound traffic flow, you must avoid the situation that the traffic flow matches a deny statement in a higher priority IPsec policy entry. Otherwise, the packets will be sent out as normal packets. If they match a permit statement at the receiving end, they will be dropped by IPsec.
The following example shows how an improper statement causes unexpected packet dropping. Only the ACL-related configuration is presented.
Assume Device A is connected to subnet 1.1.2.0/24 and Device B is connected to subnet 3.3.3.0/24, and the IPsec policy configuration on Device A and Device B is as follows:
·     IPsec configuration on Device A:
acl advanced 3000
 rule 1 deny ip
acl advanced 3001
 rule 0 permit ip source 1.1.2.0 0.0.0.255 destination 3.3.3.0 0.0.0.255
 rule 1 deny ip
ipsec policy testa 1 isakmp <---IPsec policy entry with a higher priority
 security acl 3000
 ike-profile aa
 transform-set 1
ipsec policy testa 2 isakmp <---IPsec policy entry with a lower priority
 security acl 3001
 ike-profile bb
 transform-set 1
·     IPsec configuration on Device B:
acl advanced 3001
 rule 0 permit ip source 3.3.3.0 0.0.0.255 destination 1.1.2.0 0.0.0.255
 rule 1 deny ip
ipsec policy testb 1 isakmp
 security acl 3001
 ike-profile aa
 transform-set 1
On Device A, apply the IPsec policy testa to the outbound interface of Device A. The IPsec policy contains two policy entries, testa 1 and testa 2. The ACLs used by the two policy entries each contain a rule that matches traffic from 1.1.2.0/24 to 3.3.3.0/24. The one used in the policy entry testa 1 is a deny statement and the one used in the policy entry testa 2 is a permit statement. Because testa 1 is matched prior to testa 2, traffic from 1.1.2.0/24 to 3.3.3.0/24 will match the deny statement and be sent as normal traffic. When the traffic arrives at Device B, the traffic matches rule 0 (a permit statement) in ACL 3001 used in the applied IPsec policy testb. Because non-IPsec traffic that matches a permit statement must be dropped on the inbound interface, Device B drops the traffic.
To make sure subnet 1.1.2.0/24 can access subnet 3.3.3.0/24, you can delete the deny rule in ACL 3000 on Device A.
Mirror image ACLs
To make sure SAs can be set up and the traffic protected by IPsec can be processed correctly between two IPsec peers, create mirror image ACLs on the IPsec peers. As shown in Figure 7, ACL rules on Device B are mirror images of the rules on Device A. In this way, SAs can be created successfully for the traffic between Host A and Host C and for the traffic between Network 1 and Network 2.
Figure 7 Mirror image ACLs
If the ACL rules on IPsec peers do not form mirror images of each other, SAs can be set up only when both of the following requirements are met:
·     The range specified by an ACL rule on one peer is covered by its counterpart ACL rule on the other peer. As shown in Figure 8, the range specified by the ACL rule configured on Device A is covered by its counterpart on Device B.
·     The peer with the narrower rule initiates SA negotiation. If a wider ACL rule is used by the SA initiator, the negotiation request might be rejected because the matching traffic is beyond the scope of the responder. As shown in Figure 8, the SA negotiation initiated by Host A to Host C is accepted but the SA negotiations from Host C to Host A, from Host C to Host B, and from Host D to Host A are rejected.
Figure 8 Non-mirror image ACLs
ACL for IPsec protection in VPN instances
To use IPsec to protect the data of a VPN instance, you must specify the VPN instance for the protected data in the ACL.
As shown in Figure 9, to protect traffic of VPN1 by using IPsec, you must configure the ACL on Device A as follows:
acl advanced 3400
 rule 0 permit ip vpn-instance vpn1 source 1.1.1.0 0.0.0.255 destination 3.3.3.0 0.0.0.255
In addition, you must specify VPN1 as the inside VPN instance in the IKE profile.
ike profile vpn1
 keychain vpn1
 match remote identity address 8.8.8.1 255.255.255.255
 inside-vpn vpn-instance vpn1
Figure 9 IPsec for VPN instances
An IPsec transform set, part of an IPsec policy, defines the security parameters for IPsec SA negotiation, including the security protocol, encryption algorithms, and authentication algorithms.
Changes to an IPsec transform set affect only SAs negotiated after the changes. To apply the changes to existing SAs, execute the reset ipsec sa command to clear the SAs so that they can be set up by using the updated parameters.
The transport mode applies only when the source and destination IP addresses of data flows match those of the IPsec tunnel. IPsec transform sets used in IPsec profiles for IPv6 routing protocols support only the transport mode.
The tunnel mode typically applies when the source and destination IP addresses of data flows are different from those of the IPsec tunnel. IPsec transform sets used in IPsec profiles for tunnels support only the tunnel mode.
When you configure the Perfect Forward Secrecy (PFS) feature in an IPsec transform set, follow these guidelines:
·     In IKEv1, the security level of the DH group of the initiator must be higher than or equal to that of the responder. This restriction does not apply to IKEv2.
·     The end without the PFS feature performs SA negotiation according to the PFS requirements of the peer end.
You can specify multiple authentication or encryption algorithms for the same security protocol. The algorithm specified earlier has a higher priority.
Some algorithms are available only for IKEv2. See Table 1.
Table 1 Algorithms available only for IKEv2
Algorithms
aes-ctr-128
aes-ctr-192
aes-ctr-256
camellia-cbc-128
camellia-cbc-192
camellia-cbc-256
gmac-128
gmac-192
gmac-256
gcm-128
gcm-192
gcm-256
aes-xcbc-mac
2.     Create an IPsec transform set and enter its view.
ipsec transform-set transform-set-name
3.     Specify the security protocol for the IPsec transform set.
protocol { ah | ah-esp | esp }
By default, the ESP security protocol is used.
4.     Specify the encryption algorithms for ESP. Skip this step if the protocol ah command is configured.
esp encryption-algorithm { 3des-cbc | aes-cbc-128 | aes-cbc-192 | aes-cbc-256 | aes-ctr-128 | aes-ctr-192 | aes-ctr-256 | camellia-cbc-128 | camellia-cbc-192 | camellia-cbc-256 | des-cbc | gmac-128 | gmac-192 | gmac-256 | gcm-128 | gcm-192 | gcm-256 | null | sm1-cbc-128 | sm4-cbc } *
By default, no encryption algorithm is specified for ESP.
5.     Specify the authentication algorithms for ESP. Skip this step if the protocol ah command is configured.
esp authentication-algorithm { aes-xcbc-mac | md5 | sha1 | sha256 | sha384 | sha512 | sm3 } *
By default, no authentication algorithm is specified for ESP.
The aes-xcbc-mac algorithm is available only for IKEv2.
6.     Specify the authentication algorithms for AH. Skip this step if the protocol esp command is configured.
ah authentication-algorithm { aes-xcbc-mac | md5 | sha1 | sha256 | sha384 | sha512 | sm3 } *
By default, no authentication algorithm is specified for AH.
7.     Specify the packet encapsulation mode.
encapsulation-mode { transport | tunnel }
By default, the security protocol encapsulates IP packets in tunnel mode.
8.     (Optional.) Enable the PFS feature.
pfs { dh-group1 | dh-group2 | dh-group5 | dh-group14 | dh-group24 | dh-group19 | dh-group20 }
By default, the PFS feature is disabled.
For more information about PFS, see "Configuring IKE."
9.     (Optional.) Enable the Extended Sequence Number (ESN) feature.
esn enable [ both ]
By default, the ESN feature is disabled.
The ESN feature applies only to IPsec SAs negotiated by IKEv2.
In a manual IPsec policy, the parameters are configured manually, such as the keys, the SPIs, and the IP addresses of the two ends in tunnel mode.
When you configure a manual IPsec policy, make sure the IPsec configuration at both ends of the IPsec tunnel meets the following requirements:
·     The IPsec policies at the two ends must have IPsec transform sets that use the same security protocols, security algorithms, and encapsulation mode.
·     The remote IPv4 address configured on the local end must be the same as the primary IPv4 address of the interface applied with the IPsec policy at the remote end. The remote IPv6 address configured on the local end must be the same as the first IPv6 address of the interface applied with the IPsec policy at the remote end.
·     At each end, configure parameters for both the inbound SA and the outbound SA, and make sure the SAs in each direction are unique: For an outbound SA, make sure its triplet (remote IP address, security protocol, and SPI) is unique. For an inbound SA, make sure its SPI is unique.
·     The local inbound SA must use the same SPI and keys as the remote outbound SA. The same is true of the local outbound SA and remote inbound SA.
·     The keys for the IPsec SAs at the two tunnel ends must be configured in the same format. For example, if the local end uses a key in hexadecimal format, the remote end must also use a key in hexadecimal format. If you configure a key in both the character and the hexadecimal formats, only the most recent configuration takes effect.
·     If you configure a key in character format for ESP, the device automatically generates an authentication key and an encryption key for ESP.
2.     Create a manual IPsec policy entry and enter its view.
ipsec { ipv6-policy | policy } policy-name seq-number manual
3.     (Optional.) Configure a description for the IPsec policy.
By default, no description is configured.
4.     Specify an ACL for the IPsec policy.
security acl [ ipv6 ] { acl-number | name acl-name }
By default, no ACL is specified for an IPsec policy.
You can specify only one ACL for an IPsec policy.
5.     Specify an IPsec transform set for the IPsec policy.
By default, no IPsec transform set is specified for an IPsec policy.
You can specify only one IPsec transform set for a manual IPsec policy.
6.     Specify the remote IP address of the IPsec tunnel.
remote-address { ipv4-address | ipv6 ipv6-address }
By default, the remote IP address of the IPsec tunnel is not specified.
7.     Configure an SPI for the inbound IPsec SA.
sa spi inbound { ah | esp } spi-number
By default, no SPI is configured for the inbound IPsec SA.
8.     Configure an SPI for the outbound IPsec SA.
sa spi outbound { ah | esp } spi-number
By default, no SPI is configured for the outbound IPsec SA.
9.     Configure keys for the IPsec SA.
¡     Configure an authentication key in hexadecimal format for AH.
sa hex-key authentication { inbound | outbound } ah { cipher | simple } string
¡     Configure an authentication key in character format for AH.
sa string-key { inbound | outbound } ah { cipher | simple } string
¡     Configure a key in character format for ESP.
sa string-key { inbound | outbound } esp { cipher | simple } string
¡     Configure an authentication key in hexadecimal format for ESP.
sa hex-key authentication { inbound | outbound } esp { cipher | simple }
¡     Configure an encryption key in hexadecimal format for ESP.
sa hex-key encryption { inbound | outbound } esp { cipher | simple } string
By default, no keys are configured for the IPsec SA.
Configure keys correctly for the security protocol (AH, ESP, or both) you have specified in the IPsec transform set used by the IPsec policy.
10.     (Optional.) Configure an alias name for the IPsec policy entry.
policy alias alias-name
By default, the alias name of an IPsec policy entry is the IPsec policy name-IPsec policy entry number.
In an IKE-based IPsec policy, the parameters are automatically negotiated through IKE.
To configure an IKE-based IPsec policy, use one of the following methods:
·     Directly configure it by configuring the parameters in IPsec policy view.
·     Configure it by using an existing IPsec policy template with the parameters to be negotiated configured.
A device using an IPsec policy that is configured in this way cannot initiate an SA negotiation, but it can respond to a negotiation request. The parameters not defined in the template are determined by the initiator. For example, in an IPsec policy template, the ACL is optional. If you do not specify an ACL, the IPsec protection range has no limit. So the device accepts all ACL settings of the negotiation initiator.
When the remote end's information (such as the IP address) is unknown, this method allows the remote end to initiate negotiations with the local end.
The configurable parameters for an IPsec policy template are the same as those when you directly configure an IKE-based IPsec policy. The difference is that more parameters are optional for an IPsec policy template. Except the IPsec transform sets and the IKE profile, all other parameters are optional.
Restrictions and guidelines for IKE-based IPsec policy configuration
The IPsec policies at the two tunnel ends must have IPsec transform sets that use the same security protocols, security algorithms, and encapsulation mode.
The IPsec policies at the two tunnel ends must have the same IKE profile parameters.
An IKE-based IPsec policy can use a maximum of six IPsec transform sets. During an IKE negotiation, IKE searches for a fully matched IPsec transform set at the two ends of the IPsec tunnel. If no match is found, no SA can be set up, and the packets expecting to be protected will be dropped.
The remote IP address of the IPsec tunnel is required on an IKE negotiation initiator and is optional on the responder. The remote IP address specified on the local end must be the same as the local IP address specified on the remote end.
The IPsec SA uses the local lifetime settings or those proposed by the peer, whichever are smaller.
The IPsec SA can have both a time-based lifetime and a traffic-based lifetime. The IPsec SA expires when either lifetime expires.
If you specify both an IKEv1 profile and an IKEv2 profile for an IPsec policy, the IKEv2 profile is used preferentially. For more information about IKEv1 and IKEv2 profiles, see "Configuring IKE" and "Configuring IKEv2."
Directly configuring an IKE-based IPsec policy
2.     Create an IKE-based IPsec policy entry and enter its view.
ipsec { ipv6-policy | policy } policy-name seq-number isakmp
4.     (Optional.) Set the IPsec SA negotiation triggering mode.
sa trigger-mode { auto | traffic-based }
By default, IPsec SA negotiation is triggered when traffic requires IPsec protection.
If the ACL for an IPsec policy or IPsec policy template uses the aggregation or the per-host mode, the IPsec policy or IPsec policy template cannot trigger IPsec SA negotiation in auto mode.
5.     Specify an ACL for the IPsec policy.
security acl [ ipv6 ] { acl-number | name acl-name } [ aggregation | per-host ]
6.     Specify IPsec transform sets for the IPsec policy.
transform-set transform-set-name&<1-6>
By default, no IPsec transform sets are specified for an IPsec policy.
7.     Specify an IKE profile or IKEv2 profile for the IPsec policy.
¡     Specify an IKE profile.
ike-profile profile-name
By default, no IKE profile is specified for an IPsec policy.
¡     Specify an IKEv2 profile.
ikev2-profile profile-name
By default, no IKEv2 profile is specified for an IPsec policy.
8.     Specify the local IP address of the IPsec tunnel.
local-address { ipv4-address | ipv6 ipv6-address }
By default, the local IPv4 address of the IPsec tunnel is the primary IPv4 address of the interface to which the IPsec policy is applied. The local IPv6 address of the IPsec tunnel is the first IPv6 address of the interface to which the IPsec policy is applied.
The local IP address specified by this command must be the same as the IP address used as the local IKE identity.
In a VRRP network, the local IP address must be the virtual IP address of the VRRP group to which the IPsec-applied interface belongs.
The local address cannot be a secondary IP address of the interface where the IPsec policy is applied.
9.     Specify the remote IP address of the IPsec tunnel.
remote-address { [ ipv6 ] host-name | ipv4-address | ipv6 ipv6-address } [ primary ] [ track track-id ]
To enable remote address switchback, you must specify a minimum of two remote IP addresses including a primary IP address, and associate a track entry with each of the addresses.
10.     (Optional.) Enable remote address switchback.
remote-address switch-back enable
By default, remote address switchback is disabled.
To implement this feature, you must also configure the IPsec RRI and IKE DPD and complete the related NQA and Track configurations. For information about NQA, see Network Management and Monitoring Configuration Guide. For information about Track, see High Availability Configuration Guide.
11.     (Optional.) Set the lifetime, soft lifetime buffer, or idle timeout for the IPsec SA.
¡     Set the IPsec SA lifetime.
sa duration { time-based seconds | traffic-based kilobytes }
By default, the global SA lifetime is used.
¡     Set the time-based or traffic-based IPsec SA soft lifetime buffer.
sa soft-duration buffer { time-based seconds | traffic-based kilobytes }
By default, no IPsec SA soft lifetime buffers are configured.
¡     Set the IPsec SA idle timeout.
sa idle-time seconds
By default, the global IPsec SA idle timeout is used.
12.     (Optional.) Enable the Traffic Flow Confidentiality (TFC) padding feature.
tfc enable
By default, the TFC padding feature is disabled.
TFC padding applies only to IPsec SAs negotiated by IKEv2.
13.     (Optional.) Enable the IPsec policy entry.
policy enable
By default, an IPsec policy entry is enabled.
14.     (Optional.) Configure an alias name for the IPsec policy entry.
Configuring an IKE-based IPsec policy by using an IPsec policy template
2.     Create an IPsec policy template and enter its view.
ipsec { ipv6-policy-template | policy-template } template-name seq-number
3.     (Optional.) Configure a description for the IPsec policy template.
4.     (Optional.) Specify an ACL for the IPsec policy template.
By default, no ACL is specified for an IPsec policy template.
You can specify only one ACL for an IPsec policy template.
5.     Specify IPsec transform sets for the IPsec policy template.
By default, no IPsec transform sets are specified for an IPsec policy template.
6.     Specify an IKE profile or IKEv2 profile for the IPsec policy template.
By default, no IKE profile is specified for an IPsec policy template.
Make sure the specified IKE profile is not used by another IPsec policy or IPsec policy template.
By default, no IKEv2 profile is specified for an IPsec policy template.
7.     Specify the local IP address of the IPsec tunnel.
The default local IPv4 address and IPv6 address is the primary IPv4 address and first IPv6 address of the interface where the IPsec policy is applied.
8.     Specify the remote IP address of the IPsec tunnel.
9.     (Optional.) Set the lifetime and idle timeout for the IPsec SA.
10.     (Optional.) Enable the Traffic Flow Confidentiality (TFC) padding feature.
tfc enable
11.     (Optional.) Enable the IPsec policy template entry.
policy enable
by default, an IPsec policy template entry is enabled.
12.     (Optional.) Configure an alias name for the IPsec policy tempalte entry.
By default, the alias name of an IPsec policy template entry is the IPsec policy template name-IPsec policy template entry number.
13.     Return to system view.
14.     Create an IKE-based IPsec policy by using the IPsec policy template.
ipsec { ipv6-policy | policy } policy-name seq-number isakmp template template-name
An IKE-based IPsec policy that is bound to a source interface can be applied to multiple interfaces.
A manual IPsec policy can be applied to only one interface.
To cancel the IPsec protection, remove the application of the IPsec policy.
After an IPsec policy is applied to an interface, you do not need to configure a security policy that permits the IPsec and IKE packets on the interface to pass. The IKE packets for IPsec tunnel establishment and IPsec packets transmitted through IPsec tunnels are permitted to pass automatically. But you need to configure corresponding security policies for IPsec-protected traffic. For more information about security policy configuration, see " Configuring security policies."
2.     Enter interface view.
3.     Apply an IPsec policy to the interface.
ipsec apply { ipv6-policy | policy } policy-name
By default, no IPsec policy is applied to an interface.
On one interface, you can apply a maximum of two IPsec policies: one IPv4 IPsec policy and one IPv6 IPsec policy.
This feature compares the de-encapsulated incoming IPsec packets against the ACL in the IPsec policy and discards those that do not match any permit rule of the ACL. This feature can protect networks against attacks using forged IPsec packets.
This feature applies only to tunnel-mode IPsec.
2.     Enable ACL checking for de-encapsulated packets.
ipsec decrypt-check enable
By default, ACL checking for de-encapsulated packets is enabled.
IPsec anti-replay protects networks against anti-replay attacks by using a sliding window mechanism called anti-replay window. This feature checks the sequence number of each received IPsec packet against the current IPsec packet sequence number range of the sliding window. If the sequence number is not in the current sequence number range, the packet is considered a replayed packet and is discarded.
IPsec packet de-encapsulation involves complicated calculation. De-encapsulation of replayed packets is not required, and the de-encapsulation process consumes large amounts of resources and degrades performance, resulting in DoS. IPsec anti-replay can check and discard replayed packets before de-encapsulation.
In some situations, service data packets are received in a different order than their original order. The IPsec anti-replay feature drops them as replayed packets, which impacts communications. If this happens, disable IPsec anti-replay checking or adjust the size of the anti-replay window as required.
IPsec anti-replay does not affect manually created IPsec SAs. According to the IPsec protocol, only IKE-based IPsec SAs support anti-replay.
Set the anti-replay window size as small as possible to reduce the impact on system performance.
Failure to detect anti-replay attacks might result in denial of services. If you want to disable IPsec anti-replay, make sure you understand the impact of the operation on network security.
2.     Enable IPsec anti-replay.
ipsec anti-replay check
By default, IPsec anti-replay is enabled.
3.     Set the size of the IPsec anti-replay window.
ipsec anti-replay window width
The default size is 64.
For high availability, a core device is usually connected to an ISP through two links, which operate in backup or load sharing mode. The two interfaces negotiate with their peers to establish IPsec SAs respectively. When one interface fails and a link failover occurs, the other interface needs to take some time to renegotiate SAs, resulting in service interruption.
To solve these problems, bind a source interface to an IPsec policy and apply the policy to both interfaces. This enables the two physical interfaces to use the same source interface to negotiate IPsec SAs. As long as the source interface is up, the negotiated IPsec SAs will not be removed and will keep working, regardless of link failover.
Only the IKE-based IPsec policies can be bound to a source interface.
An IPsec policy can be bound to only one source interface.
A source interface can be bound to multiple IPsec policies.
If the source interface bound to an IPsec policy is removed, the IPsec policy becomes a common IPsec policy.
If no local address is specified for an IPsec policy that has been bound to a source interface, the IPsec policy uses the IP address of the bound source interface to perform IKE negotiation. If a local address is specified, the IPsec policy uses the local address to perform IKE negotiation.
2.     Bind a source interface to an IPsec policy.
ipsec { ipv6-policy | policy } policy-name local-address interface-type interface-number
By default, no source interface is bound to an IPsec policy.
When both an IPsec policy and a QoS policy are applied to an interface, QoS classifies packets by using the new headers added by IPsec. If you want QoS to classify packets by using the headers of the original IP packets, enable the QoS pre-classify feature.
If you configure both IPsec and QoS on an interface, make sure the IPsec traffic classification rules match the QoS traffic classification rules. If the rules do not match, QoS might classify the packets of one IPsec SA to different queues, causing packets to be sent out of order. When IPsec anti-replay is enabled, IPsec will drop the incoming packets that are out of the anti-replay window, resulting in packet loss.
IPsec traffic classification rules are determined by the rules of the specified ACL. For more information about QoS policy and classification, see ACL and QoS Configuration Guide.
2.     Enter IPsec policy view or IPsec policy template view.
¡     Enter IPsec policy view.
ipsec { ipv6-policy | policy } policy-name seq-number [ isakmp | manual ]
¡     Enter IPsec policy template view.
3.     Enable QoS pre-classify.
qos pre-classify
By default, QoS pre-classify is disabled.
Enabling IPsec RRI for an IPsec policy deletes all existing IPsec SAs created by this IPsec policy. IPsec RRI creates static routes according to new IPsec SAs.
Disabling IPsec RRI for an IPsec policy deletes all existing IPsec SAs created by this IPsec policy and the associated static routes.
IPsec RRI is supported in both tunnel mode and transport mode.
If you change the preference value or tag value for an IPsec policy, the device deletes all IPsec SAs created by this IPsec policy, and the associated static routes. The change takes effect for future IPsec RRI-created static routes.
IPsec RRI does not generate a static route to a destination address to be protected if the destination address is not defined in the ACL used by an IPsec policy or an IPsec policy template. You must manually configure a static route to the destination address.
In an MPLS L3VPN network, IPsec RRI can add static routes to VPN instances' routing tables.
ipsec { policy | ipv6-policy } policy-name seq-number  isakmp
3.     Enable IPsec RRI.
reverse-route [ next-hop [ ipv6 ]  ip-address ] dynamic
By default, IPsec RRI is disabled.
4.     (Optional.) Set the preference value for the static routes created by IPsec RRI.
reverse-route preference number
The default value is 60.
5.     (Optional.) Set the tag value for the static routes created by IPsec RRI.
reverse-route tag tag-value
The default value is 0.
IPsec smart link selection enables a branch gateway to dynamically select a qualified link among the available links to establish the IPsec tunnel to the headquarters.
To configure IPsec smart link selection on a branch gateway, perform the following tasks:
1.     Configure an IPsec smart link policy.
An IPsec smart link policy defines the following settings:
¡     Link quality probe settings, such as the number of probe packets sent in each probe cycle and the probe packet sending interval.
¡     Links available for smart link selection. A link configured earlier has a higher priority in smart link selection.
¡     Link switchover thresholds, including the packet loss ratio threshold and delay threshold.
2.     Apply the IPsec smart link policy to an IKE-based IPsec policy.
The IPsec smart link selection process is as follows:
3.     When the branch gateway identifies traffic that needs IPsec protection for the first time, it establishes an IPsec tunnel to the headquarters over the link with the highest priority.
After a link is selected for IPsec tunnel establishment, the device applies the IPsec policy that uses the IPsec smart link policy to the local interface of the link.
4.     The device periodically sends probe packets to test the packet loss ratio and delay over the active link.
5.     If the packet loss ratio or delay over the link exceeds the configured threshold, the device starts a cyclic link switchover process, during which a qualified link is selected to transfer traffic.
Cyclic link switchover probes the available links one by one in descending order of the link priority, and uses the first qualified link to transfer traffic. If no links are qualified when the maximum number of link switchover cycles is reached, the device selects a link for traffic as follows:
¡     Selects the link with the lowest packet loss ratio.
¡     Selects the link with the lowest delay if the links have the same packet loss ratio.
¡     Selects the link with the lowest priority if the links have the same packet loss ratio and delay.
After 10 minutes, the device starts link quality probing and cyclic link switchovers again.
IPsec smart link selection is supported only on IPv4 networks.
An IPsec smart link policy takes effect after it is applied to an IKE-based IPsec policy. You cannot apply an IPsec smart link policy to a manual IPsec policy or an IPsec policy created by using an IPsec policy template.
When you configure IPsec smart link selection on the IPsec gateway at a branch, follow these restrictions and guidelines:
·     An IPsec smart link policy can be applied to only one IPsec policy, and an IPsec policy can use only one IPsec smart link policy.
·     In the IPsec policy that uses an IPsec smart link policy, do not use local-address and
·     Make sure the device does not have static routes that use the same destination addresses as the routes automatically generated by smart link selection. If such static routes exist, delete them.
When you configure the IPsec gateway at the headquarters, follow these restrictions and guidelines:
·     The IPsec policy applied to the gateway interface used for communication with the branch gateway must be created by using an IPsec policy template.
·     When you specify the remote IP address in IKE configuration, use 0.0.0.0 0 or specify all the remote IP addresses configured at the branch gateway.
2.     Configure an IPsec smart link policy.
a.     Create an IPsec smart link policy and enter its view.
ipsec smart-link policy policy-name
b.     Configure links for IPsec smart link selection.
link link-id interface interface-type interface-number [ local local-address nexthop nexthop-address ] remote remote-address
By default, an IPsec smart link policy does not contain any links.
c.     Enable IPsec smart link selection.
smart-link enable
By default, IPsec smart link selection is disabled in an IPsec smart link policy.
The device performs link quality probing and cyclic link switchovers only when IPsec smart link selection is enabled in the IPsec smart link policy.
d.     (Optional.) Manually activate a link.
activate link link-id
To establish an IPsec tunnel over a specific link, use this command to activate the link.
If the packet loss ratio or delay over the link exceeds the configured threshold, the first link switchover cycle starts from the manually activated link and ends with the link that has the lowest priority.
e.     (Optional.) Move links to adjust their priorities.
move link link-id1 before link-id2
By default, a link configured earlier has a higher priority in smart link selection.
During link switchover, traffic will be switched over the links in descending order of the link priority.
f.     (Optional.) Set the maximum number of link switchover cycles.
link-switch cycles number
By default, the maximum number of link switchover cycles is 3.
If you set number to 0, the device never stops link quality probing and cyclic link switchovers.
g.     Set the number of link quality probe packets sent in each probe cycle and the probe packet sending interval.
link-probe { interval interval | count number }
By default, the device sends 10 probe packets at 1-second intervals in each probe cycle.
h.     Specify the source and destination IP addresses for the link quality probe packets.
link-probe source source-address destination destination-address
By default, the link quality probe packets use the local and remote IP addresses of the probed link as the source and destination IP addresses.
i.     Set the link switchover thresholds.
link-switch threshold { loss loss-ratio | delay delay }
By default, the packet loss ratio threshold is 30%, and the delay threshold is 500 milliseconds.
3.     Configure the gateway address for the local interface of a link.
a.     Return to system view.
b.     Enter interface view.
c.     Specify the gateway address for the interface.
gateway gateway-address [ no-route ]
By default, an interface with a manually configured IP address does not have a gateway address.
The local interface of a link is the interface specified when you configure the link by using the link command.
This task is required for the local interface of each link that meets the following conditions:
¡     The IP address of the interface is manually configured.
¡     The nexthop nexthop-address option is not specified in the link command.
The gateway command does not take effect if the interface acquires its IP address through DHCP or PPPoE. Such interfaces always use the gateway address assigned by the DHCP or PPPoE server.
4.     Apply the IPsec smart link policy to an IKE-based IPsec policy
b.     Enter the view of an IKE-based IPsec policy.
ipsec policy policy-name seq-number isakmp
c.     Apply the IPsec smart link policy to the IPsec policy.
By default, an IPsec smart link policy is not applied to an IPsec policy.
On a hub-spoke network, if the IPsec data flow range configured on a spoke is too large, traffic of other spokes might be directed to that spoke incorrectly. To avoid incorrect packet forwarding, you can enable IPsec netmask filtering on the hub device. When negotiating an IPsec SA for a data flow, the device checks the mask lengths of the data flow. The IPsec SA negotiation proceeds only if the mask lengths of the source and destination IP addresses of the data flow are greater than or equal to those configured by IPsec netmask filtering. If the data flow fails to pass the netmask filtering, the IPsec SA negotiation fails and the device generates a netmask filtering failure notification. On receiving such notifications, you must reconfigure the ACL settings for IPsec on the spoke devices.
This feature is supported only on IPv4 networks.
This feature takes effect only IPsec SAs negotiated by using IPsec policy templates.
As a best practice, configure this feature on the hub device of a hub-spoke network.
2.     Configure IPsec netmask filtering.
ipsec netmask-filter { destination-mask mask-length | source-mask mask-length } *
By default, IPsec netmask filtering is not configured.
In a hub-spoke network, the hub typically uses an IPsec policy template to negotiate IPsec SAs with spokes. The data flows to be protected by the IPsec SAs might overlap with each other. To avoid IPsec flow overlapping, you can enable IPsec flow overlap check on the hub device. When negotiating an IPsec SA for a data flow, the device checks whether the data flow overlaps with an existing protected data flow. If yes, the new IPsec SA negotiation fails and the device generates an IPsec flow overlap check failure notification. On receiving such notifications, you must reconfigure the ACL settings for IPsec on the spoke devices.
This feature checks the destination IP address of a data flow to be protected with the destination IP addresses of the existing protected data flows. If an overlap exists, the feature determines that the data flow overlaps.
The following applies to the IPsec flow overlap check feature:
·     As a best practice, enable this feature on the hub device of a hub-spoke network.
·     This feature takes effect only on IPsec SAs negotiated by using IPsec policy templates.
·     This feature takes effect only for new IPsec SA negotiations. It does not take effect on existing IPsec SAs.
·     This feature takes effect only on IPsec SAs negotiated on the same interface and in the same VPN instance.
·     This feature does not take effect on renegotiated IPsec SAs.
·     This feature does not check overlaps for source IP addresses of data flows.
·     This feature impacts device performance, enable this feature only when necessary (for example, for network upgrade or expansion) and disable it in time.
2.     Enable IPsec flow overlap check.
ipsec flow-overlap check enable
By default, IPsec flow overlap check is disabled.
Configuring IPsec for IPv6 routing protocols
IPsec protection for IPv6 routing protocols tasks at a glance
To configure IPsec protection for IPv6 routing protocols, perform the following tasks:
1.     Configuring an IPsec transform set
2.     Configuring a manual IPsec profile
3.     Applying the IPsec profile to an IPv6 routing protocol
4.     (Optional.) Configuring IPsec anti-replay redundancy
5.     (Optional.) Configuring IPsec fragmentation
6.     (Optional.) Setting the maximum number of IPsec tunnels
7.     (Optional.) Enabling logging for IPsec packets
8.     (Optional.) Enabling logging for IPsec negotiation
9.     (Optional.) Configuring SNMP notifications for IPsec
A manual IPsec profile specifies the IPsec transform set used for protecting data flows, and the SPIs and keys used by the SAs.
When you configure a manual IPsec profile, make sure the IPsec profile configuration at both tunnel ends meets the following requirements:
·     The IPsec transform set specified in the IPsec profile at the two tunnel ends must have the same security protocol, encryption and authentication algorithms, and packet encapsulation mode.
·     The local inbound and outbound IPsec SAs must have the same SPI and key.
·     The IPsec SAs on the devices in the same scope must have the same key. The scope is defined by protocols. For OSPFv3, the scope consists of OSPFv3 neighbors or an OSPFv3 area. For RIPng, the scope consists of directly-connected neighbors or a RIPng process. For BGP, the scope consists of BGP peers or a BGP peer group.
2.     Create a manual IPsec profile and enter its view.
ipsec profile profile-name manual
The manual keyword is not needed if you enter the view of an existing IPsec profile.
3.     (Optional.) Configure a description for the IPsec profile.
4.     Specify an IPsec transform set.
By default, no IPsec transform set is specified in an IPsec profile.
The specified IPsec transform set must use the transport mode.
5.     Configure an SPI for an SA.
sa spi { inbound | outbound } { ah | esp } spi-number
By default, no SPI is configured for an SA.
6.     Configure keys for the IPsec SA.
Configure a key for the security protocol (AH, ESP, or both) you have specified.
7.     (Optional.) Configure an alias name for the IPsec profile.
profile alias alias-name
By default, the alias name of an IPsec profile is profile-IPsec profile name.
For information about the configuration procedure, see IPv6 BGP, OSPFv3, and RIPng configuration in Layer 3IP Routing Configuration Guide.
Configuring IPsec for tunnel interfaces
IPsec protection for tunnel interfaces tasks at a glance
To configure IPsec protection for tunnel interfaces, perform the following tasks:
2.     Configuring an IKE-based IPsec profile
3.     Applying an IKE-based IPsec profile to a tunnel interface
4.     (Optional.) Configuring advanced features of IPsec protection for tunnel interfaces
5.     (Optional.) Configuring logging and SNMP notification for IPsec
¡     Enabling logging for creations and deletions of P2MP IPsec tunnel entries
An IKE-based IPsec profile specifies the IPsec transform sets used for protecting data flows, and the IKE profile used for IKE negotiation.
The IPsec profiles at the two tunnel ends must have IPsec transform sets that use the same security protocols, security algorithms, and encapsulation mode.
The IPsec profiles at the two tunnel ends must have the same IKE profile parameters.
An IKE-based IPsec profile can use a maximum of six IPsec transform sets. During an IKE negotiation, IKE searches for a fully matched IPsec transform set at the two ends of the IPsec tunnel. If no match is found, no SA can be set up, and the packets expecting to be protected will be dropped.
2.     Create an IKE-based IPsec profile and enter its view.
ipsec profile profile-name isakmp
The isakmp keyword is not needed if you enter the view of an existing IPsec profile.
4.     Specify IPsec transform sets.
By default, no IPsec transform sets are specified in an IPsec profile.
The specified IPsec transform sets must use the tunnel mode.
5.     Specify an IKE profile.
By default, no IKE profile is specified for an IPsec profile, and the device selects an IKE profile configured in system view for negotiation. If no IKE profile is configured in system view, the globally configured IKE settings are used.
You can specify only one IKE profile for an IPsec profile.
For more information about IKE profiles, see "Configuring IKE."
6.     (Optional.) Specify an IKEv2 profile.
By default, no IKEv2 profile is specified for an IPsec profile. If both an IKEv1 profile and an IKEv2 profile are specified for an IPsec profile, the IKEv2 profile is preferred.
You can specify only one IKEv2 profile for an IPsec profile. For more information about IKEv2 profiles, see "Configuring IKEv2."
7.     (Optional.) Set the IPsec SA lifetime.
8.     (Optional.) Set the time-based or traffic-based IPsec SA soft lifetime buffer.
9.     (Optional.) Set the IPsec SA idle timeout.
By default, the global SA idle timeout is used.
10.     (Optional.) Configure an alias name for the IPsec profile.
After an IKE-based IPsec profile is applied to a tunnel interface, the peers negotiate an IPsec tunnel through IKE to protect data transmitted through the tunnel interface. The tunnel interface comes up after the IKE negotiation succeeds.
When you specify the IPsec profile to be applied to a tunnel interface, you can specify an ACL to filter the packets routed to the tunnel interface. Only the ACL-permitted packets can be protected by IPsec.
2.     Create a tunnel interface and enter its view.
interface tunnel number mode gre
3.     Apply an IKE-based IPsec profile to the tunnel interface.
tunnel protection ipsec profile profile-name [ acl [ ipv6 ] { acl-number | name acl-name } ]
By default, no IPsec profile is applied to a tunnel interface.
Configuring IPsec for an SDWAN tunnel interface
IPsec protection for SDWAN tunnel interface tasks at a glance
To configure IPsec protection for an SDWAN tunnel interface, perform the following tasks:
2.     Configuring an SDWAN IPsec profile
3.     Applying an SDWAN IPsec profile to an SDWAN tunnel interface
5.     (Optional.) Configuring the global IPsec SA lifetime and idle timeout
Abou this task
An SDWAN IPsec profile is used to generate IPsec SAs on SDWAN devices. It is applied to an SDWAN tunnel interface to protect all the traffic routed to the interface. You do not need to specify the remote end address or an ACL.
The IPsec profiles at the two tunnel ends can have IPsec transform sets that use different security protocols, authentication and encryption algorithms.
2.     Create an SDWAN IPsec profile and enter its view.
ipsec profile profile-name sdwan
The sdwan keyword is not needed if you enter the view of an existing IPsec profile.
5.     (Optional.) Set the IPsec SA lifetime.
sa duration time-based seconds
6.     (Optional.) Configure an alias name for the IPsec profile.
After an SDWAN IPsec profile is applied to an SDWAN tunnel interface, the SDWAN devices create IPsec SAs to protect data routed to the tunnel interface.
2.     Create a tunnel interface, specify the tunnel mode as SDWAN, and enter tunnel interface view.
interface tunnel number mode sdwan udp
3.     Apply an SDWAN IPsec profile to the tunnel interface.
4.     Specify a traffic processing slot for the interface.
In standalone mode:
service slot slot-number
In IRF mode:
service chassis chassis-number slot slot-number
By default, no traffic processing slot is specified for an interface. Traffic on an interface is processed on the slot at which the traffic arrives.
This feature synchronizes the following information from the active device to the standby device at configurable packet-based intervals:
·     Lower bound values of the IPsec anti-replay window for inbound packets.
·     IPsec anti-replay sequence numbers for outbound packets.
This feature, used together with IPsec redundancy, ensures uninterrupted IPsec traffic forwarding and anti-replay protection when the active device fails.
2.     Enable IPsec redundancy.
ipsec redundancy enable
By default, IPsec redundancy is disabled.
3.     Enter IPsec profile view, IPsec policy view or IPsec policy template view.
¡     Enter IPsec profile view.
ipsec profile profile-name [ isakmp | manual ]
4.     Set the anti-replay window synchronization interval for inbound packets and the sequence number synchronization interval for outbound packets.
redundancy replay-interval inbound inbound-interval outbound outbound-interval
By default, the active device synchronizes the anti-replay window every time it receives 1000 packets and synchronizes the sequence number every time it sends 100000 packets.
If the IPsec SA lifetime and idle timeout are not configured in an IPsec policy, IPsec policy template, or IPsec profile, the global settings are used.
When IKE negotiates IPsec SAs, it uses the local lifetime settings or those proposed by the peer, whichever are smaller.
An IPsec SA can have both a time-based lifetime and a traffic-based lifetime. The IPsec SA expires when either lifetime expires.
2.     Set the global IPsec SA lifetime, soft lifetime buffer, or idle timeout.
¡     Set the global IPsec SA lifetime.
ipsec sa global-duration { time-based seconds | traffic-based kilobytes }
By default, the time-based SA lifetime is 3600 seconds, and the traffic-based SA lifetime is 1843200 kilobytes.
¡     Set the global time-based or traffic-based IPsec SA soft lifetime buffer.
ipsec sa global-soft-duration buffer { time-based seconds | traffic-based kilobytes }
By default, no global IPsec SA soft lifetime buffers are configured.
¡     Set the global SA idle timeout.
ipsec sa idle-time seconds
By default, the global IPsec SA idle timeout feature is disabled.
Perform this task to configure the device to fragment packets before or after IPsec encapsulation.
If you configure the device to fragment packets before IPsec encapsulation, the device predetermines the encapsulated packet size before the actual encapsulation. If the encapsulated packet size exceeds the MTU of the output interface, the device fragments the packets before encapsulation. If a packet's DF bit is set, the device drops the packet and sends an ICMP error message.
If you configure the device to fragment packets after IPsec encapsulation, the device directly encapsulates the packets and fragments the encapsulated packets in subsequent service modules.
This feature takes effect on IPsec protected IPv4 packets.
2.     Configure IPsec fragmentation.
ipsec fragmentation { after-encryption | before-encryption }
By default, the device fragments packets before IPsec encapsulation.
Perform this task to configure the Don't Fragment (DF) bit in the new IP header of IPsec packets in one of the following ways:
·     clear—Clears the DF bit in the new header.
·     set—Sets the DF bit in the new header.
·     copy—Copies the DF bit in the original IP header to the new IP header.
You can configure the DF bit in IPsec policy view, IPsec policy template view, IPsec profile view, interface view, and system view. The DF bit setting in IPsec policy view, IPsec policy template view, or IPsec profile view has the highest priority. If the DF bit setting is not configured in the IPsec policy, IPsec profile, or IPsec policy template, the interface-view DF bit setting is used. If the DF bit setting is not configured in interface view, the global DF bit setting configured in system view is used.
Restrictions and guidelines for DF bit configuration for IPsec packets
The DF bit setting takes effect only in tunnel mode, and it changes the DF bit in the new IP header rather than the original IP header.
Only IKE-based IPsec supports configuring the DF bit.
Configure the same DF bit setting on the interfaces where the same IPsec policy bound to a source interface is applied.
If the DF bit is set, the devices on the path cannot fragment the IPsec packets. To prevent IPsec packets from being discarded, make sure the path MTU is larger than the IPsec packet size. As a best practice, clear the DF bit if you cannot make sure the path MTU is larger than the IPsec packet size.
Configuring the DF bit of IPsec packets in an IPsec profile, IPsec policy or IPsec policy template
2.     Enter IPsec profile, IPsec policy or IPsec policy template view.
ipsec { ipv6-policy-template | policy-template }template-name seq-number
3.     Configure the DF bit of IPsec packets.
sa df-bit { clear | copy | set }
By default, an IPsec profile, IPsec policy or IPsec policy template uses the interface-specific or global DF bit setting.
Configuring the DF bit of IPsec packets on an interface
3.     Configure the DF bit of IPsec packets on the interface.
ipsec df-bit { clear | copy | set }
By default, the interface uses the global DF bit setting.
Configuring the DF bit of IPsec packets globally
2.     Configure the DF bit of IPsec packets globally.
ipsec global-df-bit { clear | copy | set }
By default, IPsec copies the DF bit in the original IP header to the new IP header.
To maximize concurrent performance of IPsec when memory is sufficient, increase the maximum number of IPsec tunnels. To ensure service availability when memory is insufficient, decrease the maximum number of IPsec tunnels.
2.     Set the maximum number of IPsec tunnels.
ipsec limit max-tunnel tunnel-limit
By default, the number of IPsec tunnels is not limited.
By default, two IPsec peers will both initiate the establishment of an IPsec SA when they both use an IKE-based IPsec profile to established IPsec SAs. In this case, the two IPsec peers use two IPsec negotiation processes to establish one IPsec SA, wasting CPU resources.
To resolve this issue, you can enable the responder-only mode. After you configure a device as a responder-only device, the device will not initiate IPsec SAs but respond to negotiations initiated by its peers.
As a best practice, configure this feature on the hub device in a hub-spoke network.
2.     Enter IPsec policy view, IPsec policy template view, or IPsec profile view.
3.     Enable the responder-only mode for IPsec SA negotiation.
responder-only enable
By default, the responder-only mode is disabled.
Perform this task to enable logging for IPsec packets that are discarded for reasons such as IPsec SA lookup failure, AH-ESP authentication failure, and ESP encryption failure. The log information includes the source and destination IP addresses, SPI value, and sequence number of a discarded IPsec packet, and the reason for the discard.
2.     Enable logging for IPsec packets.
ipsec logging packet enable
By default, logging for IPsec packets is disabled.
This feature enables the device to output logs for the IPsec negotiation process.
2.     Enable logging for IPsec negotiation.
ipsec logging negotiation enable
By default, logging for IPsec negotiation is disabled.
After you enable SNMP notifications for IPsec, the IPsec module notifies the NMS of important module events. The notifications are sent to the device's SNMP module. For the notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP notifications, see Network Management and Monitoring Configuration Guide.
To generate and output SNMP notifications for a specific IPsec failure or event type, perform the following tasks:
1.     Enable SNMP notifications for IPsec globally.
2.     Enable SNMP notifications for the failure or event type.
2.     Enable SNMP notifications for IPsec globally.
snmp-agent trap enable ipsec global
By default, SNMP notifications for IPsec are disabled.
3.     Enable SNMP notifications for the specified failure or event types.
snmp-agent trap enable ipsec [ auth-failure | connection-start | connection-stop | decrypt-failure | encrypt-failure | invalid-sa-failure | no-sa-failure | policy-add | policy-attach | policy-delete | policy-detach | tunnel-start | tunnel-stop ] *
By default, SNMP notifications for all failure and event types are disabled.
After this feature is enabled, the system outputs log messages when P2MP IPsec tunnel entries are created or deleted. For more information about logs, see information center in Network Management and Monitoring Configuration Guide.
2.     Enable logging for creations and deletions of P2MP IPsec tunnel entries.
ipsec logging ipsec-p2mp enable
By default, the device does not log creations and deletions of P2MP IPsec tunnel entries.
Display and maintenance commands for IPsec
IMPORTANT
IMPORTANT:
Non-default vSystems do not support some of the display and maintenance commands. For information about vSystem support for these commands, see IPsec command reference.
Display global IPsec information.
display ipsec global-info
Display IPsec policy information.
display ipsec { ipv6-policy | policy } [ policy-name [ seq-number ] ]
Display IPsec policy template information.
display ipsec { ipv6-policy-template | policy-template } [ template-name [ seq-number ] ]
Display dynamic tunnel entries on a P2MP IPsec tunnel interface.
In standalone mode:
display ipsec p2mp tunnel-table interface tunnel tunnel-number [ ipv4 | ipv6 ] [ slot slot-number ]
In IRF mode:
display ipsec p2mp tunnel-table interface tunnel tunnel-number [ ipv4 | ipv6 ] [ chassis chassis-number slot slot-number ]
Display IPsec profile information.
display ipsec profile [ profile-name ]
Display IPsec SA information.
display ipsec sa [ brief | count | interface interface-type interface-number | { ipv6-policy | policy } policy-name [ seq-number ] | profile profile-name | remote [ ipv6 ] ip-address ]
Display information about local SDWAN IPsec SAs.
display ipsec sdwan-sa local [ brief | count | interface tunnel tunnel-number | spi spi-number ]
Display information about remote SDWAN IPsec SAs.
display ipsec sdwan-sa remote [ brief | count ]
Display packet statitics on SDWAN IPsec tunnels.
display ipsec sdwan-statistics [ tunnel-id tunnel-id ]
Display information about SDWAN IPsec tunnels.
display ipsec sdwan-tunnel [ brief | count | remote-site site-id device-id interface-id | tunnel-id tunnel-id ]
Display IPsec smart link policy information.
display ipsec smart-link policy [ brief | name policy-name ]
Display IPsec statistics.
display ipsec statistics [ tunnel-id tunnel-id ]
Display IPsec transform set information.
display ipsec transform-set [ transform-set-name ]
Display IPsec tunnel information.
display ipsec tunnel [ count | tunnel-id tunnel-id ]
Clear IPsec SAs.
reset ipsec sa [ { ipv6-policy | policy } policy-name [ seq-number ] | profile profile-name | remote { ipv4-address | ipv6 ipv6-address } | spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-num ]
Clear SDWAN IPsec SAs.
reset ipsec sdwan-sa [ local [ interface tunnel tunnel-number ] | remote ]
Clear packet statistics on SDWAN IPsec tunnels.
reset ipsec sdwan-statistics [ tunnel-id tunnel-id ]
Clear SDWAN IPsec tunnels.
reset ipsec sdwan-tunnel [ tunnel-id tunnel-id ]
Clear IPsec packet statistics.
reset ipsec statistics [ tunnel-id tunnel-id ]
IPsec configuration examples
Example: Configuring a manual mode IPsec tunnel for IPv4 packets between gateways
As shown in Figure 10, establish an IPsec tunnel between Device A and Device B to protect data flows between subnet 10.1.1.0/24 and subnet 10.1.2.0/24. Configure the tunnel as follows:
·     Specify the encapsulation mode as tunnel, the security protocol as ESP, the encryption algorithm as 128-bit AES, and the authentication algorithm as HMAC-SHA1.
·     Manually set up IPsec SAs.
Figure 10 Network diagram
Configuring Device A
1.     Assign IP addresses to interfaces:
# Assign an IP address to interface GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] ip address 10.1.1.1 255.255.255.0
2.     Configure settings for routing.
This example configures static routes, and the next hop in the routes is 2.2.2.2.
[DeviceA] ip route-static 10.1.2.0 24 2.2.2.2
[DeviceA] ip route-static 2.2.3.1 24 2.2.2.2
3.     Add interfaces to security zones.
[DeviceA] security-zone name trust
[DeviceA-security-zone-Trust] import interface gigabitethernet 1/0/1
[DeviceA-security-zone-Trust] quit
[DeviceA] security-zone name untrust
[DeviceA-security-zone-Untrust] import interface gigabitethernet 1/0/2
[DeviceA-security-zone-Untrust] quit
4.     Configure a security policy:
a.     Configure rules to permit traffic between the Untrust and Local security zones, so the devices can set up an IPsec tunnel:
# Configure a rule named ipseclocalout to allow Device A to send IPsec negotiation packets to Device B.
[DeviceA] security-policy ip
[DeviceA-security-policy-ip] rule name ipseclocalout
[DeviceA-security-policy-ip-1-ipseclocalout] source-zone local
[DeviceA-security-policy-ip-1-ipseclocalout] destination-zone untrust
[DeviceA-security-policy-ip-1-ipseclocalout] source-ip-host 2.2.2.1
[DeviceA-security-policy-ip-1-ipseclocalout] destination-ip-host 2.2.3.1
[DeviceA-security-policy-ip-1-ipseclocalout] action pass
[DeviceA-security-policy-ip-1-ipseclocalout] quit
# Configure a rule named ipseclocalin to allow Device A to receive the IPsec negotiation packets sent from Device B.
[DeviceA-security-policy-ip] rule name ipseclocalin
[DeviceA-security-policy-ip-2-ipseclocalin] source-zone untrust
[DeviceA-security-policy-ip-2-ipseclocalin] destination-zone local
[DeviceA-security-policy-ip-2-ipseclocalin] source-ip-host 2.2.3.1
[DeviceA-security-policy-ip-2-ipseclocalin] destination-ip-host 2.2.2.1
[DeviceA-security-policy-ip-2-ipseclocalin] action pass
[DeviceA-security-policy-ip-2-ipseclocalin] quit
b.     Configure rules to permit the traffic between Host A and Host B:
# Configure a rule named trust-untrust to permit the packets from Host A to Host B.
[DeviceA-security-policy-ip] rule name trust-untrust
[DeviceA-security-policy-ip-3-trust-untrust] source-zone trust
[DeviceA-security-policy-ip-3-trust-untrust] destination-zone untrust
[DeviceA-security-policy-ip-3-trust-untrust] source-ip-subnet 10.1.1.0 24
[DeviceA-security-policy-ip-3-trust-untrust] destination-ip-subnet 10.1.2.0 24
[DeviceA-security-policy-ip-3-trust-untrust] action pass
[DeviceA-security-policy-ip-3-trust-untrust] quit
# Configure a rule named untrust-trust to permit the packets from Host B to Host A.
[DeviceA-security-policy-ip] rule name untrust-trust
[DeviceA-security-policy-ip-4-untrust-trust] source-zone untrust
[DeviceA-security-policy-ip-4-untrust-trust] destination-zone trust
[DeviceA-security-policy-ip-4-untrust-trust] source-ip-subnet 10.1.2.0 24
[DeviceA-security-policy-ip-4-untrust-trust] destination-ip-subnet 10.1.1.0 24
[DeviceA-security-policy-ip-4-untrust-trust] action pass
[DeviceA-security-policy-ip-4-untrust-trust] quit
[DeviceA-security-policy-ip] quit
5.     Define the data flow to be protected:
# Configure an IPv4 advanced ACL to identify the data flow from subnet 10.1.1.0/24 to subnet 10.1.2.0/24.
[DeviceA] acl advanced 3101
[DeviceA-acl-ipv4-adv-3101] rule permit ip source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
[DeviceA-acl-ipv4-adv-3101] quit
6.     Configure an IPsec transform set to specify the packet encapsulation mode, security protocols, and algorithms.
The IPsec transform set settings at both sides of the IPsec tunnel must be the same.
[DeviceA] ipsec transform-set tran1
[DeviceA-ipsec-transform-set-tran1] encapsulation-mode tunnel
[DeviceA-ipsec-transform-set-tran1] protocol esp
[DeviceA-ipsec-transform-set-tran1] esp encryption-algorithm aes-cbc-128
[DeviceA-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[DeviceA-ipsec-transform-set-tran1] quit
7.     Configure an IPsec policy, so as to establish the IPsec tunnel to protect data:
# Create a manual IPsec policy entry, which specifies the ACL for IPsec, the IPsec transform set, and the remote IP address of the IPsec tunnel.
[DeviceA] ipsec policy map1 10 manual
[DeviceA-ipsec-policy-manual-map1-10] security acl 3101
[DeviceA-ipsec-policy-manual-map1-10] transform-set tran1
[DeviceA-ipsec-policy-manual-map1-10] remote-address 2.2.3.1
[DeviceA-ipsec-policy-manual-map1-10] sa spi outbound esp 12345
[DeviceA-ipsec-policy-manual-map1-10] sa spi inbound esp 54321
[DeviceA-ipsec-policy-manual-map1-10] sa string-key outbound esp simple abcdefg
[DeviceA-ipsec-policy-manual-map1-10] sa string-key inbound esp simple gfedcba
[DeviceA-ipsec-policy-manual-map1-10] quit
8.     Apply the IPsec policy to GigabitEthernet 1/0/2 to protect traffic on the interface.
[DeviceA-GigabitEthernet1/0/2] ipsec apply policy map1
Configuring Device B
[DeviceB-GigabitEthernet1/0/1] ip address 10.1.2.1 255.255.255.0
This example configures static routes, and the next hop in the routes is 2.2.3.2.
[DeviceB] ip route-static 10.1.1.0 24 2.2.3.2
[DeviceB] ip route-static 2.2.2.1 24 2.2.3.2
[DeviceB] security-zone name trust
[DeviceB-security-zone-Trust] import interface gigabitethernet 1/0/1
[DeviceB-security-zone-Trust] quit
[DeviceB] security-zone name untrust
[DeviceB-security-zone-Untrust] import interface gigabitethernet 1/0/2
[DeviceB-security-zone-Untrust] quit
# Configure a rule named ipseclocalout to allow Device B to send IPsec negotiation packets to Device A.
[DeviceB] security-policy ip
[DeviceB-security-policy-ip] rule name ipseclocalout
[DeviceB-security-policy-ip-1-ipseclocalout] source-zone local
[DeviceB-security-policy-ip-1-ipseclocalout] destination-zone untrust
[DeviceB-security-policy-ip-1-ipseclocalout] source-ip-host 2.2.3.1
[DeviceB-security-policy-ip-1-ipseclocalout] destination-ip-host 2.2.2.1
[DeviceB-security-policy-ip-1-ipseclocalout] action pass
[DeviceB-security-policy-ip-1-ipseclocalout] quit
# Configure a rule named ipseclocalin to allow Device B to receive the IPsec negotiation packets sent from Device A.
[DeviceB-security-policy-ip] rule name ipseclocalin
[DeviceB-security-policy-ip-2-ipseclocalin] source-zone untrust
[DeviceB-security-policy-ip-2-ipseclocalin] destination-zone local
[DeviceB-security-policy-ip-2-ipseclocalin] source-ip-host 2.2.2.1
[DeviceB-security-policy-ip-2-ipseclocalin] destination-ip-host 2.2.3.1
[DeviceB-security-policy-ip-2-ipseclocalin] action pass
[DeviceB-security-policy-ip-2-ipseclocalin] quit
b.     Configure rules to permit traffic between Host B and Host A:
# Configure a rule named trust-untrust to permit the packets from Host B to Host A.
[DeviceB-security-policy-ip] rule name trust-untrust
[DeviceB-security-policy-ip-3-trust-untrust] source-zone trust
[DeviceB-security-policy-ip-3-trust-untrust] destination-zone untrust
[DeviceB-security-policy-ip-3-trust-untrust] source-ip-subnet 10.1.2.0 24
[DeviceB-security-policy-ip-3-trust-untrust] destination-ip-subnet 10.1.1.0 24
[DeviceB-security-policy-ip-3-trust-untrust] action pass
[DeviceB-security-policy-ip-3-trust-untrust] quit
# Configure a rule named untrust-trust to permit the packets from Host A to Host B.
[DeviceB-security-policy-ip] rule name untrust-trust
[DeviceB-security-policy-ip-4-untrust-trust] source-zone untrust
[DeviceB-security-policy-ip-4-untrust-trust] destination-zone trust
[DeviceB-security-policy-ip-4-untrust-trust] source-ip-subnet 10.1.1.0 24
[DeviceB-security-policy-ip-4-untrust-trust] destination-ip-subnet 10.1.2.0 24
[DeviceB-security-policy-ip-4-untrust-trust] action pass
[DeviceB-security-policy-ip-4-untrust-trust] quit
[DeviceB-security-policy-ip] quit
5.     Define the data flows to be protected:
# Configure an IPv4 advanced ACL to identify data flows from subnet 10.1.2.0/24 to subnet 10.1.1.0/24.
[DeviceB] acl advanced 3101
[DeviceB-acl-ipv4-adv-3101] rule permit ip source 10.1.2.0 0.0.0.255 destination 10.1.1.0 0.0.0.255
[DeviceB-acl-ipv4-adv-3101] quit
[DeviceB] ipsec transform-set tran1
[DeviceB-ipsec-transform-set-tran1] encapsulation-mode tunnel
[DeviceB-ipsec-transform-set-tran1] protocol esp
[DeviceB-ipsec-transform-set-tran1] esp encryption-algorithm aes-cbc-128
[DeviceB-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[DeviceB-ipsec-transform-set-tran1] quit
[DeviceB] ipsec policy use1 10 manual
[DeviceB-ipsec-policy-manual-use1-10] security acl 3101
[DeviceB-ipsec-policy-manual-use1-10] transform-set tran1
[DeviceB-ipsec-policy-manual-use1-10] remote-address 2.2.2.1
[DeviceB-ipsec-policy-manual-use1-10] sa spi outbound esp 54321
[DeviceB-ipsec-policy-manual-use1-10] sa spi inbound esp 12345
[DeviceB-ipsec-policy-manual-use1-10] sa string-key outbound esp simple gfedcba
[DeviceB-ipsec-policy-manual-use1-10] sa string-key inbound esp simple abcdefg
[DeviceB-ipsec-policy-manual-use1-10] quit
[DeviceB-GigabitEthernet1/0/2] ipsec policy use1
After the configuration is completed, an IPsec tunnel between Device A and Device B is established, and the traffic between subnet 10.1.1.0/24 and subnet 10.1.2.0/24 is IPsec-protected. This example uses Device A to verify the configuration.
# Display IPsec SAs on Device A.
[DeviceA] display ipsec sa
Interface: GigabitEthernet 1/0/2
  IPsec policy: map1
  Sequence number: 10
  Alisa: map1-10
  Mode: Manual
    Tunnel id: 549
    Encapsulation mode: tunnel
    Path MTU: 1443
    Tunnel:
        local  address/port: 2.2.2.1/0
        remote address/port: 2.2.3.1/0
    Flow:
        as defined in ACL 3101
    [Inbound ESP SA]
      SPI: 54321 (0x0000d431)
      Connection ID: 1
      Transform set: ESP-ENCRYPT-AES-CBC-128 ESP-AUTH-SHA1
      No duration limit for this SA
    [Outbound ESP SA]
      SPI: 12345 (0x00003039)
      Connection ID: 2
Example: Configuring an IKE-based IPsec tunnel for IPv4 packets between gateways
As shown in Figure 11 establish an IPsec tunnel between Device A and Device B to protect data flows between subnet 10.1.1.0/24 and subnet 10.1.2.0/24. Configure the IPsec tunnel as follows:
·     Set up SAs through IKE negotiation.
Figure 11 Network diagram
# Configure an IPv4 advanced ACL to identify data flows from subnet 10.1.1.0/24 to subnet 10.1.2.0/24.
7.     Configure an IKE keychain to specify the key information used for IKE communication.
The preshared key used by both sides of the communication must be the same.
[DeviceA] ike keychain keychain1
[DeviceA-ike-keychain-keychain1] pre-shared-key address 2.2.3.1 255.255.255.0 key simple 123456TESTplat&!
[DeviceA-ike-keychain-keychain1] quit
8.     Configure an IKE profile to specify the security parameters used for setting up IKE SAs.
[DeviceA] ike profile profile1
[DeviceA-ike-profile-profile1] keychain keychain1
[DeviceA-ike-profile-profile1] match remote identity address 2.2.3.1 255.255.255.0
[DeviceA-ike-profile-profile1] quit
9.     Configure an IPsec policy, so as to establish the IPsec tunnel to protect data:
# Create an IKE-based IPsec policy entry, which specifies the ACL for IPsec, IPsec transform set, local and remote IP addresses, and IKE profile.
[DeviceA] ipsec policy map1 10 isakmp
[DeviceA-ipsec-policy-isakmp-map1-10] security acl 3101
[DeviceA-ipsec-policy-isakmp-map1-10] transform-set tran1
[DeviceA-ipsec-policy-isakmp-map1-10] local-address 2.2.2.1
[DeviceA-ipsec-policy-isakmp-map1-10] remote-address 2.2.3.1
[DeviceA-ipsec-policy-isakmp-map1-10] ike-profile profile1
[DeviceA-ipsec-policy-isakmp-map1-10] quit
10.     Apply the IPsec policy to GigabitEthernet 1/0/2 to protect traffic on the interface.
[DeviceB] ike keychain keychain1
[DeviceB-ike-keychain-keychain1] pre-shared-key address 2.2.2.1 255.255.255.0 key simple 123456TESTplat&!
[DeviceB-ike-keychain-keychain1] quit
[DeviceB] ike profile profile1
[DeviceB-ike-profile-profile1] keychain keychain1
[DeviceB-ike-profile-profile1] match remote identity address 2.2.2.1 255.255.255.0
[DeviceB-ike-profile-profile1] quit
[DeviceB] ipsec policy use1 10 isakmp
[DeviceB-ipsec-policy-isakmp-use1-10] security acl 3101
[DeviceB-ipsec-policy-isakmp-use1-10] transform-set tran1
[DeviceB-ipsec-policy-isakmp-use1-10] local-address 2.2.3.1
[DeviceB-ipsec-policy-isakmp-use1-10] remote-address 2.2.2.1
[DeviceB-ipsec-policy-isakmp-use1-10] ike-profile profile1
[DeviceB-ipsec-policy-isakmp-use1-10] quit
[DeviceB-GigabitEthernet1/0/2] ipsec apply policy use1
# Initiate a connection from subnet 10.1.1.0/24 to subnet 10.1.2.0/24 to trigger IKE negotiation. After IPsec SAs are successfully negotiated by IKE, the traffic between the two subnets is IPsec-protected.
# Display IPsec SAs on Device A and Device B. This example uses Device A to verify the configuration.
  IPsec policy: map1
  Sequence number: 10
  Alisa: map1-10
  Mode: ISAKMP
    Tunnel id: 0
    Perfect Forward Secrecy:
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Transmitting entity: Initiator
    Path MTU: 1443
    Tunnel:
        local  address/port: 2.2.3.1/500
        remote address/port: 2.2.2.1/500
    Flow:
        sour addr: 10.1.1.0/255.255.255.0  port: 0  protocol: ip
        dest addr: 10.1.2.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 3769702703 (0xe0b1192f)
      Connection ID: 90194313219
      SA duration (kilobytes/sec): 3000/28800
      SA remaining duration (kilobytes/sec): 2300/797
      Max received sequence-number: 1
      Anti-replay check enable: N
      Anti-replay window size:
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 3840956402 (0xe4f057f2)
      Connection ID: 64424509441
      SA remaining duration (kilobytes/sec): 2312/797
      Max sent sequence-number: 1
      Status: Active
Example: Configuring an IKE-based IPsec tunnel for IPv4 packets between gateways (RSA signature authentication)
As shown in Figure 12, configure an IKE-based IPsec tunnel between Device A and Device B to secure the communication between subnet 10.1.1.0/24 and subnet 10.1.2.0/24.
Configure Device A and Device B to use aggressive mode for IKE negotiation phase 1 and to use RSA signature authentication. Device A acts as the initiator, and the subnet where Device A resides uses IP addresses dynamically allocated.
Figure 12 Network diagram
Device A has obtained CA certificate ca.cer and local certificate server.pfx.
Device B has obtained CA certificate ca.cer and local certificate server.pfx.
[DeviceA-GigabitEthernet1/0/1] ip address 1.1.1.1 255.255.0.0
This example configures static routes, and the next hop in the routes is 1.1.1.2.
[DeviceA] ip route-static 10.1.2.0 24 1.1.1.2
[DeviceA] ip route-static 2.2.2.2 16 1.1.1.2
[DeviceA-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceA-security-zone-Untrust] import interface gigabitethernet 1/0/1
[DeviceA-security-policy-ip-1-ipseclocalout] source-ip-host 1.1.1.1
[DeviceA-security-policy-ip-1-ipseclocalout] destination-ip-host 2.2.2.2
[DeviceA-security-policy-ip-2-ipseclocalin] source-ip-host 2.2.2.2
[DeviceA-security-policy-ip-2-ipseclocalin] destination-ip-host 1.1.1.1
# Configure IPv4 advanced ACL 3101 to identify traffic from subnet 10.1.1.0/24 to subnet 10.1.2.0/24.
[DeviceA-ipsec-transform-set-tran1] esp encryption-algorithm des-cbc
7.     Configure a PKI entity.
[DeviceA] pki entity entity1
[DeviceA-pki-entity-entity1] common-name devicea
[DeviceA-pki-entity-entity1] quit
8.     Configure a PKI domain for certificate requests.
[DeviceA] pki domain domain1
[DeviceA-pki-domain-domain1] public-key rsa general name rsa1
[DeviceA-pki-domain-domain1] undo crl check enable
[DeviceA-pki-domain-domain1] quit
[DeviceA] pki import domain domain1 der ca filename ca.cer
[DeviceA] pki import domain domain1 p12 local filename server.pfx
9.     Configure a certificate-based access control policy to control user access rights.
A peer certificate is regarded valid only if it contains the specified string (1 in this example) in the DN attribute of the subject name field.
[DeviceA] pki certificate access-control-policy policy1
[DeviceA-pki-cert-acp-policy1] rule 1 permit group1
[DeviceA] pki certificate attribute-group group1
[DeviceA-pki-cert-attribute-group-group1] attribute 1 subject-name dn ctn 1
10.     Configure an IKE profile to specify the security parameters used for setting up IKE SAs.
[DeviceA-ike-profile-profile1] certificate domain domain1
[DeviceA-ike-profile-profile1] exchange-mode aggressive
[DeviceA-ike-profile-profile1] local-identity dn
[DeviceA-ike-profile-profile1] match remote certificate policy1
11.     Configure an IKE proposal to specify the parameters used for IKE negotiation.
[DeviceA] ike proposal 10
[DeviceA-ike-proposal-10] authentication-algorithm md5
[DeviceA-ike-proposal-10] authentication-method rsa-signature
[DeviceA-ike-proposal-10] quit
12.     Configure an IPsec policy to establish an IPsec tunnel to protect the specified data:
[DeviceA-ipsec-policy-isakmp-map1-10] remote-address 2.2.2.2
13.     Apply the IPsec policy to GigabitEthernet 1/0/1 to protect the traffic on the interface.
[DeviceA-GigabitEthernet1/0/1] ipsec apply policy map1
[DeviceB-GigabitEthernet1/0/1] ip address 2.2.2.2 255.255.0.0
This example configures static routes, and the next hop in the routes is 2.2.2.1.
[DeviceB] ip route-static 10.1.1.0 24 2.2.2.1
[DeviceB] ip route-static 1.1.1.1 16 2.2.2.1
[DeviceB-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceB-security-zone-Untrust] import interface gigabitethernet 1/0/1
[DeviceB-security-policy-ip-1-ipseclocalout] source-ip-host 2.2.2.2
[DeviceB-security-policy-ip-1-ipseclocalout] destination-ip-host 1.1.1.1
[DeviceB-security-policy-ip-2-ipseclocalin] source-ip-host 1.1.1.1
[DeviceB-security-policy-ip-2-ipseclocalin] destination-ip-host 2.2.2.2
# Configure IPv4 advanced ACL 3101 to identify traffic from subnet 10.1.2.0/24 to subnet 10.1.1.0/24.
[DeviceB-ipsec-transform-set-tran1] esp encryption-algorithm des-cbc
[DeviceB] pki entity entity2
[DeviceB-pki-entity-entity2] common-name deviceb
[DeviceB-pki-entity-entity2] quit
8.     Configure a PKI domain for certificate request.
[DeviceB] pki domain domain2
[DeviceB-pki-domain-domain2] public-key rsa general name rsa1
[DeviceB-pki-domain-domain2] undo crl check enable
[DeviceB-pki-domain-domain2] quit
[DeviceB] pki import domain domain2 der ca filename ca.cer
[DeviceB] pki import domain domain2 p12 local filename server.pfx
[DeviceB] pki certificate access-control-policy policy1
[DeviceB-pki-cert-acp-policy1] rule 1 permit group1
[DeviceB] pki certificate attribute-group group1
[DeviceB-pki-cert-attribute-group-group1] attribute 1 subject-name dn ctn 1
[DeviceB] ike profile profile2
[DeviceB-ike-profile-profile2] certificate domain domain2
[DeviceB-ike-profile-profile2] exchange-mode aggressive
[DeviceB-ike-profile-profile2] local-identity dn
[DeviceB-ike-profile-profile2] match remote certificate policy1
[DeviceB-ike-profile-profile2] quit
11.     Configure an IKE proposal to specify the security parameters for IKE negotiation.
[DeviceB] ike proposal 10
[DeviceB-ike-proposal-10] authentication-algorithm md5
[DeviceB-ike-proposal-10] authentication-method rsa-signature
[DeviceB-ike-proposal-10] quit
12.     Configure an IPsec policy template, which is used to create an IPsec policy:
# Create an IPsec policy template entry. Specify template1 as the template name and set the sequence number to 1.
[DeviceB] ipsec policy-template template1 1
[DeviceB-ipsec-policy-template-template1-1] transform-set tran1
[DeviceB-ipsec-policy-template-template1-1] ike-profile profile2
[DeviceB-ipsec-policy-template-template1-1] quit
13.     Create an IKE-based IPsec policy entry by using IPsec policy template template1, so as to establish the IPsec tunnel to protect data.
[DeviceB] ipsec policy use1 1 isakmp template template1
14.     Apply the IPsec policy to GigabitEthernet 1/0/1 to protect the traffic on the interface.
[DeviceB-GigabitEthernet1/0/1] ipsec apply policy use1
# Initiate a connection from subnet 10.1.1.0/24 to subnet 10.1.2.0/24 to trigger IKE negotiation. After IPsec SAs are successfully negotiated by IKE, traffic between the two subnets is IPsec-protected.
# Display the IKE SA on Device A.
[DeviceA] display ike sa
    Connection-ID   Remote                Flag         DOI
    13              2.2.2.2/500           RD           IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
[DeviceA] display ike sa verbose
   Connection ID: 13
   Outside VPN:
   Inside VPN:
   Profile: profile1
   Initiator cookie: 1bcf453f0a217259
   Responder cookie: 5e32a74dfa66a0a4
   Local IP/port: 1.1.1.1/500
   Local ID type: FQDN
   Local ID: devicea.example.com
   Remote IP/port: 2.2.2.2/500
   Remote ID type: IPV4_ADDR
   Remote ID: 2.2.2.2
   Authentication-method: PRE-SHARED-KEY
   Authentication-algorithm: SHA1
   Encryption-algorithm: DES-CBC
   Life duration(sec): 86400
   Remaining key duration(sec): 84565
   Exchange-mode: Aggressive
   Diffie-Hellman group: Group 1
   NAT traversal: Detected
   Extend authentication: Disabled
   Assigned IP address:
   Vendor ID index: 0xa1d
   Vendor ID sequence number: 0x0
# Display the IPsec SAs generated on Device A.
  IPsec policy: policy1
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1435
    Tunnel:
        local  address/port: 1.1.1.1/500
        remote address/port: 2.2.2.2/500
    Flow:
    [Inbound ESP SAs]
      SPI: 830667426 (0x3182faa2)
      Transform set: ESP-ENCRYPT-3DES-CBC ESP-AUTH-MD5
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843200/2313
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: Y
      Status: Active
    [Outbound ESP SAs]
      SPI: 3516214669 (0xd1952d8d)
      Status: Active
Example: Configuring an IKE-based IPsec tunnel for IPv4 packets between gateways (SM2-DE digital envelope authentication)
As shown in Figure 13, configure an IKE-based IPsec tunnel between Device A and Device B to secure the communication between subnet 10.1.1.0/24 and subnet 10.1.2.0/24.
Configure Device A and Device B to use GM main mode and SM2-DE digital envelope authentication for the IKE negotiation phase 1.
Figure 13 Network diagram
[DeviceA-ipsec-transform-set-tran1] esp encryption-algorithm sm1-cbc-128
[DeviceA-ipsec-transform-set-tran1] esp authentication-algorithm sm3
[DeviceA-pki-domain-domain1] public-key sm2 general name sm2-1
9.     Configure an IKE proposal to specify the parameters for IKE neogitiation.
[DeviceA-ike-proposal-10] authentication-method sm2-de
[DeviceA-ike-proposal-10] authentication-algorithm sm3
[DeviceA-ike-proposal-10] encryption-algorithm sm1-cbc-128
10.     Configure an IKE profile to specify the security parameters used to establish IKE SAs.
[DeviceA-ike-profile-profile1] exchange-mode gm-main
[DeviceA-ike-profile-profile1] proposal 10
[DeviceA-ike-profile-profile1] local-identity address 1.1.1.1
[DeviceA-ike-profile-profile1] match remote identity address 2.2.2.2 255.255.0.0
11.     Configure an IPsec policy to establish an IPsec tunnel to protect the specified data.
12.     Apply the IPsec policy to GigabitEthernet 1/0/1 to protect the traffic on the interface.
[DeviceB-ipsec-transform-set-tran1] esp encryption-algorithm sm1-cbc-128
[DeviceB-ipsec-transform-set-tran1] esp authentication-algorithm sm3
[DeviceB-pki-domain-domain2] public-key sm2 general name sm2-1
[DeviceB-ike-proposal-10] authentication-method sm2-de
[DeviceB-ike-proposal-10] authentication-algorithm sm3
[DeviceB-ike-proposal-10] encryption-algorithm sm1-cbc-128
[DeviceB-ike-profile-profile1] exchange-mode gm-main
[DeviceB-ike-profile-profile1] certificate domain domain2
[DeviceB-ike-profile-profile1] proposal 10
[DeviceB-ike-profile-profile1] local-identity address 2.2.2.2
[DeviceB-ike-profile-profile1] match remote identity address 1.1.1.1 255.255.0.0
[DeviceB-ipsec-policy-isakmp-use1-10] remote-address 1.1.1.1
# Display the IKE proposal configuration on Device A and Device B.
[DeviceA] display ike proposal
 Priority Authentication Authentication Encryption  Diffie-Hellman Duration
              method       algorithm    algorithm       group      (seconds)
10       SM2-DE             SM3         SM1-CBC-128     Group 1       86400
default  PRE-SHARED-KEY     SHA1        DES-CBC         Group 1       86400
[DeviceB] display ike proposal
    1               2.2.2.2/500           RD           IPsec
Flags:
# Display IPsec SAs generated on Device A.
  IPsec policy: map1
  Sequence number: 10
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1456
    Tunnel:
    Flow:
    [Inbound ESP SAs]
      SPI: 1451246811 (0x568044db)
      Transform set: ESP-ENCRYPT-SM1-CBC-128 ESP-AUTH-SM3
      SA remaining duration (kilobytes/sec): 1843200/3484
      Status: Active
    [Outbound ESP SAs]
      SPI: 2692887942 (0xa0823586)
      Status: Active
# Display the IKE SA and IPsec SAs on Device B. (Details not shown.)
[DeviceB] display ike sa
[DeviceB] display ipsec sa
Example: Configuring an IKEv2-based IPsec tunnel for IPv4 packets between gateways (preshared key authentication)
As shown in Figure 14, configure an IKE-based IPsec tunnel between Device A and Device B to secure the communication between subnet 10.1.1.0/24 and subnet 10.1.2.0/24.
·     Configure Device A and Device B to use the user-defined IKEv2 proposal and the user-defined IKEv2 policy in IKEv2 negotiation to set up IPsec SAs.
·     Configure the two devices to use the preshared key authentication method in IKEv2 negotiation.
Figure 14 Network diagram
[DeviceA] ikev2 keychain keychain1
[DeviceA-ikev2-keychain-keychain1] peer peer1
[DeviceA-ikev2-keychain-keychain1-peer-peer1] address 2.2.2.2 16
[DeviceA-ikev2-keychain-keychain1-peer-peer1] identity address 2.2.2.2
[DeviceA-ikev2-keychain-keychain1-peer-peer1] pre-shared-key plaintext abcde
[DeviceA-ikev2-keychain-keychain1-peer-peer1] quit
[DeviceA-ikev2-keychain-keychain1] quit
8.     Configure an IKEv2 profile to specify the security parameters used for setting up IKE SAs.
[DeviceA] ikev2 profile profile1
[DeviceA-ikev2-profile-profile1] authentication-method local pre-share
[DeviceA-ikev2-profile-profile1] authentication-method remote pre-share
[DeviceA-ikev2-profile-profile1] keychain keychain1
[DeviceA-ikev2-profile-profile1] match remote identity address 2.2.2.2 255.255.0.0
[DeviceA-ikev2-profile-profile1] quit
9.     Configure an IKEv2 proposal to specify the negotiation parameters used for IKE SAs, including the encryption algorithm, integrity protection algorithm, DH group, and PRF algorithm.
[DeviceA] ikev2 proposal proposal1
[DeviceA-ikev2-proposal-proposal1] encryption aes-cbc-128
[DeviceA-ikev2-proposal-proposal1] integrity sha1
[DeviceA-ikev2-proposal-proposal1] dh group5
[DeviceA-ikev2-proposal-proposal1] prf sha1
[DeviceA-ikev2-proposal-proposal1] quit
10.     Configure an IKEv2 policy. Negotiation is performed based on the proprosal in the IKEv2 policy.
[DeviceA] ikev2 policy policy1
[DeviceA-ikev2-policy-policy1] proposal proposal1
[DeviceA-ikev2-policy-policy1] match local address 1.1.1.1
[DeviceA-ikev2-policy-policy1] quit
[DeviceA-ipsec-policy-isakmp-map1-10] ikev2-profile profile1
b.     Configure rules to permit the traffic between Host B and Host A:
[DeviceB] ikev2 keychain keychain1
[DeviceB-ikev2-keychain-keychain1] peer peer1
[DeviceB-ikev2-keychain-keychain1-peer-peer1] address 1.1.1.1 16
[DeviceB-ikev2-keychain-keychain1-peer-peer1] identity address 1.1.1.1
[DeviceB-ikev2-keychain-keychain1-peer-peer1] pre-shared-key plaintext abcde
[DeviceB-ikev2-keychain-keychain1-peer-peer1] quit
[DeviceB-ikev2-keychain-keychain1] quit
[DeviceB] ikev2 profile profile1
[DeviceB-ikev2-profile-profile1] authentication-method local pre-share
[DeviceB-ikev2-profile-profile1] authentication-method remote pre-share
[DeviceB-ikev2-profile-profile1] keychain keychain1
[DeviceA-ikev2-profile-profile1] match remote identity address 1.1.1.1 255.255.0.0
[DeviceB] ikev2 proposal proposal1
[DeviceB-ikev2-proposal-proposal1] encryption aes-cbc-128
[DeviceB-ikev2-proposal-proposal1] integrity sha1
[DeviceB-ikev2-proposal-proposal1] dh group5
[DeviceB-ikev2-proposal-proposal1] prf sha1
[DeviceB-ikev2-proposal-proposal1] quit
[DeviceB] ikev2 policy policy1
[DeviceB-ikev2-policy-policy1] proposal proposal1
[DeviceB-ikev2-policy-policy1] match local address 2.2.2.2
[DeviceB-ikev2-policy-policy1] quit
[DeviceB-ipsec-policy-isakmp-use1-10] ikev2-profile profile1
# Initiate a connection from subnet 10.1.1.0/24 to subnet 10.1.2.0/24 to trigger IKEv2 negotiation. After IPsec SAs are successfully negotiated by IKEv2, traffic between the two subnets is IPsec-protected.
# Display the IKEv2 proposal and IKEv2 policy on Device A.
[DeviceA] display ikev2 proposal
IKEv2 proposal : proposal1
  Encryption: AES-CBC-128
  Integrity: SHA1
  PRF:  SHA1
  DH Group: MODP1536/Group5
IKEv2 proposal : default
  Encryption: AES-CBC-128 3DES-CBC
  Integrity: SHA1 MD5
  PRF: SHA1 MD5
  DH Group: MODP1536/Group5 MODP1024/Group2
[DeviceA] display ikev2 policy
IKEv2 policy: policy1
  Priority: 100
  Match local address: 1.1.1.1
  Match VRF: public
  Proposal: proposal1
IKEv2 policy : default
  Match VRF : any
  Proposal: default
# Display the IKEv2 SA on Device A.
[DeviceA] display ikev2 sa
Tunnel ID   Local                       Remote                      Status
  1        1.1.1.1/500                  2.2.2.2/500                  EST
Status:
IN-NEGO: Negotiating, EST: Established, DEL:Deleting
# Display the IPsec SAs on Device A.
  IPsec policy: map1
  Sequence number: 10
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1456
    Tunnel:
    Flow:
    [Inbound ESP SAs]
      SPI: 3264152513 (0xc28f03c1)
      Connection ID: 141733920771
      Transform set: ESP-ENCRYPT-DES-CBC ESP-AUTH-SHA1
      Status: Active
    [Outbound ESP SAs]
      SPI: 738451674 (0x2c03e0da)
      Status: Active
# Display the IKEv2 proposal, IKEv2 policy, IKEv2 SA and IPsec SAs on Device B.
[DeviceB] display ikev2 proposal
[DeviceB] display ikev2 policy
[DeviceB] display ikev2 sa
Example: Configuring an IKEv2-based IPsec tunnel for IPv4 packets between gateways (RSA signature authentication)
As shown in Figure 15, configure an IKE-based IPsec tunnel between Device A and Device B to secure the communication between subnet 10.1.1.0/24 and subnet 10.1.2.0/24.
Configure Device A and Device B to use IKEv2 negotiation and RSA signature authentication. Device A acts as the initiator, and the subnet where Device A resides uses IP addresses dynamically allocated.
Figure 15 Network diagram
9.     Configure a certificate-based access control policy to control the user access rights.
10.     Configure an IKEv2 profile to specify the security parameters used for setting up IKEv2 SAs.
[DeviceA-ikev2-profile-profile1] authentication-method local rsa-signature
[DeviceA-ikev2-profile-profile1] authentication-method remote rsa-signature
[DeviceA-ikev2-profile-profile1] certificate domain domain1
[DeviceA-ikev2-profile-profile1] local-identity dn
[DeviceA-ikev2-profile-profile1] match remote certificate policy1
11.     Configure an IKEv2 proposal to specify the negotiation parameters used for IKE SAs, including the encryption algorithm, integrity protection algorithm, DH group, and PRF algorithm.
12.     Configure an IKEv2 policy. Negotiation is performed based on the proprosal in the IKEv2 policy.
13.     Configure an IPsec policy to establish an IPsec tunnel to protect the specified data.
[DeviceB] ikev2 profile profile2
[DeviceB-ikev2-profile-profile2] authentication-method local rsa-signature
[DeviceB-ikev2-profile-profile2] authentication-method remote rsa-signature
[DeviceB-ikev2-profile-profile2] certificate domain domain2
[DeviceB-ikev2-profile-profile2] local-identity dn
[DeviceB-ikev2-profile-profile2] match remote certificate policy1
[DeviceB-ikev2-profile-profile2] quit
[DeviceB-ikev2-proposal-10] quit
13.     Configure an IPsec policy template, which is used to create the IPsec policy.
[DeviceB-ipsec-policy-template-template1-1] remote-address 1.1.1.1
[DeviceB-ipsec-policy-template-template1-1] security acl 3101
[DeviceB-ipsec-policy-template-template1-1] ikev2-profile profile2
14.     Create an IKE-based IPsec policy entry by using IPsec policy template template1, so as to establish the IPsec tunnel to protect the specified data flow.
15.     Apply the IPsec policy to GigabitEthernet 1/0/1 to protect the traffic on the interface.
# Display the IKEv2 proposal and IKEv2 policy configuration on Device A.
  Integrity: SHA1
  PRF:  SHA1
  Integrity: SHA1 MD5
  PRF: SHA1 MD5
  Priority: 100
  Match VRF: public
  Proposal: proposal1
  Match VRF : any
  Proposal: default
# Display the IKEv2 proposal and IKEv2 policy configuration on Device B. (Details not shown.)
# Display the IKEv2 policy configuration Device A and Device B.
[DeviceA] display ikev2 policy 1
IKEv2 policy : 1
  Priority: 100
  Match Local : any
  Match VRF : public
  Proposal : 10
[DeviceB] display ikev2 policy 1
IKEv2 policy : 1
  Priority: 100
  Match Local : any
  Match VRF : public
  Proposal : 10
Status:
# Display information about the CA certificate on Device A.
[DeviceA] display pki certificate domain domain1 ca
Certificate:
    Data:
        Version: 1 (0x0)
        Serial Number:
            b9:14:fb:25:c9:08:2c:9d:f6:94:20:30:37:4e:00:00
        Signature Algorithm: sha1WithRSAEncryption
        Issuer: C=cn, O=rnd, OU=sec, CN=8088
        Validity
            Not Before: Sep  6 01:53:58 2012 GMT
            Not After : Sep  8 01:50:58 2015 GMT
        Subject: C=cn, O=rnd, OU=sec, CN=8088
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (1024 bit)
                Modulus:
                    00:de:81:f4:42:c6:9f:c2:37:7b:21:84:57:d6:42:
                    00:69:1c:4c:34:a4:5e:bb:30:97:45:2b:5e:52:43:
                    c0:49:1f:e1:d8:0f:5c:48:c2:39:69:d1:84:e4:14:
                    70:3d:98:41:28:1c:20:a1:9a:3f:91:67:78:77:27:
                    d9:08:5f:7a:c4:36:45:8b:f9:7b:e7:7d:6a:98:bb:
                    4e:a1:cb:2c:3d:92:66:bd:fb:80:35:16:c6:35:f0:
                    ff:0b:b9:3c:f3:09:94:b7:d3:6f:50:8d:83:f1:66:
                    2f:91:0b:77:a5:98:22:b4:77:ac:84:1d:03:8e:33:
                    1b:31:03:78:4f:77:a0:db:af
                Exponent: 65537 (0x10001)
        9a:6d:8c:46:d3:18:8a:00:ce:12:ee:2b:b0:aa:39:5d:3f:90:
        08:49:b9:a9:8f:0d:6e:7b:e1:00:fb:41:f5:d4:0c:e4:56:d8:
        7a:a7:61:1d:2b:b6:72:e3:09:0b:13:9d:fa:c8:fc:c4:65:a7:
        f9:45:21:05:75:2c:bf:36:7b:48:b4:4a:b9:fe:87:b9:d8:cf:
        55:16:87:ec:07:1d:55:5a:89:74:73:68:5e:f9:1d:30:55:d9:
        8a:8f:c5:d4:20:7e:41:a9:37:57:ed:8e:83:a7:80:2f:b8:31:
        57:3a:f2:1a:28:32:ea:ea:c5:9a:55:61:6a:bc:e5:6b:59:0d:
        82:16
# Display the local certificate on Device A.
[DeviceA]display pki certificate domain domain1 local
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            a1:f4:d4:fd:cc:54:c3:07:c4:9e:15:2d:5f:64:57:77
        Validity
            Not Before: Sep 26 02:06:43 2012 GMT
            Not After : Sep 26 02:06:43 2013 GMT
        Subject: CN=devicea
                Modulus:
                    00:b0:a1:cd:24:6e:1a:1d:51:79:f0:2a:3e:9f:e9:
                    84:07:16:78:49:1b:7d:0b:22:f0:0a:ed:75:91:a4:
                    17:fd:c7:ef:d0:66:5c:aa:e3:2a:d9:71:12:e4:c6:
                    25:77:f0:1d:97:bb:92:a8:bd:66:f8:f8:e8:d5:0d:
                    d2:c8:01:dd:ea:e6:e0:80:ad:db:9d:c8:d9:5f:03:
                    2d:22:07:e3:ed:cc:88:1e:3f:0c:5e:b3:d8:0e:2d:
                    ea:d6:c6:47:23:6a:11:ef:3c:0f:6b:61:f0:ca:a1:
                    79:a0:b1:02:1a:ae:8c:c9:44:e0:cf:d1:30:de:4c:
                    f0:e5:62:e7:d0:81:5d:de:d3
        X509v3 extensions:
            X509v3 CRL Distribution Points:
                Full Name:
                  URI:https://xx.rsa.com:447/8088.crl
        73:ac:66:f9:b8:b5:39:e1:6a:17:e4:d0:72:3e:26:9e:12:61:
        9e:c9:7a:86:6f:27:b0:b9:a3:5d:02:d9:5a:cb:79:0a:12:2e:
        cb:e7:24:57:e6:d9:77:12:6b:7a:cf:ee:d6:17:c5:5f:d2:98:
        30:e0:ef:00:39:4a:da:ff:1c:29:bb:2a:5b:60:e9:33:8f:78:
        f9:15:dc:a5:a3:09:66:32:ce:36:cd:f0:fe:2f:67:e5:72:e5:
        21:62:85:c4:07:92:c8:f1:d3:13:9c:2e:42:c1:5f:0e:8f:ff:
        65:fb:de:7c:ed:53:ab:14:7a:cf:69:f2:42:a4:44:7c:6e:90:
        7e:cd
  IPsec policy: map1
  Sequence number: 10
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1456
    Tunnel:
    Flow:
    [Inbound ESP SAs]
      Status: Active
    [Outbound ESP SAs]
      Connection ID: 141733920770
      Status: Active
# Display the information about the CA certificate, local certificate, IKEv2 SA, and IPsec SA on Device B.
[DeviceB] display pki certificate domain domain2 ca
[DeviceB] display pki certificate domain domain2 local
Example: Configuring an IKE-based IPsec NAT traversal tunnel for IPv4 packets between gateways
Device A is behind the NAT device. Hosts behind Device A use public IP address 3.3.3.1 to access the external network.
Configure an IKE-based IPsec tunnel between Device A and Device B to secure the communication between subnet 10.1.1.0/24 and subnet 10.1.2.0/24.
·     Configure Device A and Device B to use the default IKE proposal for the aggressive IKE negotiation to set up the IPsec SAs.
·     Configure the two devices to use the preshared key authentication method for the IKE negotiation phase 1.
Figure 16 Network diagram
# Configure IPv4 advanced ACL 3000 to identify traffic from subnet 10.1.1.0/24 to subnet 10.1.2.0/24.
[DeviceA] acl advanced 3000
[DeviceA-acl-ipv4-adv-3000] rule 0 permit ip source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
[DeviceA-acl-ipv4-adv-3000] quit
[DeviceA] ipsec transform-set transform1
[DeviceA-ipsec-transform-set-transform1] protocol esp
[DeviceA-ipsec-transform-set-transform1] esp encryption-algorithm 3des-cbc
[DeviceA-ipsec-transform-set-transform1] esp authentication-algorithm md5
[DeviceA-ipsec-transform-set-transform1] quit
[DeviceA-ike-keychain-keychain1] pre-shared-key address 2.2.2.2 255.255.0.0 key simple 12345zxcvb!@#$%ZXCVB
[DeviceA-ike-profile-profile1] local-identity fqdn devicea.example.com
9.     Configure an IPsec policy to establish an IPsec tunnel to protect the specified data.
[DeviceA] ipsec policy policy1 1 isakmp
[DeviceA-ipsec-policy-isakmp-policy1-1] remote-address 2.2.2.2
[DeviceA-ipsec-policy-isakmp-policy1-1] transform-set transform1
[DeviceA-ipsec-policy-isakmp-policy1-1] security acl 3000
[DeviceA-ipsec-policy-isakmp-policy1-1] ike-profile profile1
[DeviceA-ipsec-policy-isakmp-policy1-1] quit
10.     Apply the IPsec policy to GigabitEthernet 1/0/1 to protect the traffic on the interface.
[DeviceA-GigabitEthernet1/0/1] ipsec apply policy policy1
5.     Configure an IPsec transform set to specify the packet encapsulation mode, security protocols, and algorithms.
[DeviceB] ipsec transform-set transform1
[DeviceB-ipsec-transform-set-transform1] protocol esp
[DeviceB-ipsec-transform-set-transform1] esp encryption-algorithm 3des-cbc
[DeviceB-ipsec-transform-set-transform1] esp authentication-algorithm md5
[DeviceB-ipsec-transform-set-transform1] quit
6.     Configure an IKE keychain to specify the key information used for IKE communication.
This example specifies 12345zxcvb!@#$%ZXCVB in plain text as the preshared key to be used with the remote peer at 1.1.1.1. The source address of packets from 1.1.1.1 is translated into 3.3.3.1 by the NAT device, so IP address of the remote peer is specified as 3.3.3.1.
[DeviceB]ike keychain keychain1
[DeviceB-ike-keychain-keychain1] pre-shared-key address 3.3.3.1 255.255.0.0 key simple 12345zxcvb!@#$%ZXCVB
7.     Configure an IKE profile to specify the security parameters used for setting up IKE SAs.
[DeviceB-ike-profile-profile1] exchange-mode aggressive
[DeviceB-ike-profile-profile1] match remote identity fqdn devicea.example.com
8.     Configure an IPsec policy template, which is used to create an IPsec policy.
[DeviceB-ipsec-policy-template-template1-1] transform-set transform1
[DeviceB-ipsec-policy-template-template1-1] local-address 2.2.2.2
[DeviceB-ipsec-policy-template-template1-1] ike-profile profile1
9.     Create an IKE-based IPsec policy entry by using IPsec policy template template1, so as to establish an IPsec tunnel to protect the specified data.
[DeviceB] ipsec policy policy1 1 isakmp template template1
[DeviceB-GigabitEthernet1/0/1] ipsec apply policy policy1
Flags:
   Connection ID: 13
   Outside VPN:
   Inside VPN:
   Profile: profile1
   Output interface index: 2
   Local ID type: FQDN
   Remote ID: 2.2.2.2
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1435
    Tunnel:
    Flow:
    [Inbound ESP SAs]
      Status: Active
    [Outbound ESP SAs]
      Status: Active
Example: Configuring an IKEv2-based IPsec NAT traversal tunnel for IPv4 packets between gateways
As shown in Figure 17, Device A is behind the NAT device. Configure an IKE-based IPsec tunnel between Device A and Device B to secure the communication between subnet 10.1.1.0/24 and subnet 10.1.2.0/24.
·     Configure Device A and Device B to use the default IKEv2 proposal and the default IKEv2 policy in IKEv2 negotiation to set up IPsec SAs.
Figure 17 Network diagram
[DeviceA-acl-ipv4-adv-3101] rule 0 permit ip source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
7.     Configure an IKEv2 keychain to specify the key information used for IKEv2 communication.
[DeviceA-ikev2-keychain-keychain1-peer-peer1] pre-shared-key plaintext 123
[DeviceA-ikev2-profile-profile1] identity local fqdn devicea.example.com
[DeviceA-ipsec-policy-isakmp-policy1-1] security acl 3101
[DeviceA-ipsec-policy-isakmp-policy1-1] ikev2-profile profile1
[DeviceA-acl-ipv4-adv-3101] rule 0 permit ip source 10.1.2.0 0.0.0.255 destination 10.1.1.0 0.0.0.255
7.     Configure an IKEv2 keychain to specify the key information used by both sides of the IKE communication.
[DeviceB]ikev2 keychain keychain1
[DeviceB-ikev2-keychain-keychain1-peer-peer1] address 3.3.3.1 16
[DeviceB-ikev2-keychain-keychain1-peer-peer1] identity address 3.3.3.1
[DeviceB-ikev2-keychain-keychain1-peer-peer1] pre-shared-key plaintext 123
[DeviceB-ikev2-profile-profile1] match remote identity fqdn devicea.example.com
[DeviceB-ikev2-profile-profile1] quit
9.     Configure an IPsec policy template, which is used to create an IPsec policy.
[DeviceB-ipsec-policy-template-template1-1] remote-address 3.3.3.1
[DeviceB-ipsec-policy-template-template1-1] ikev2-profile profile1
10.     Create an IKE-based IPsec policy entry by using IPsec policy template, so as to establish an IPsec tunnel to protect the specified data flow.
11.     Apply the IPsec policy to GigabitEthernet 1/0/1 to protect the traffic on the interface.
  1        1.1.1.1/4500                  2.2.2.2/4500                  EST
Status:
 [DeviceA] display ikev2 sa verbose
  Tunnel ID: 45
  Local IP/Port: 1.1.1.1/4500
  Remote IP/Port: 2.2.2.2/4500
  Outside VRF: -
  Inside VRF: -
  Local SPI: 372228d699a33c63
  Remote SPI: 75c537621b4a7190
  Local ID type: ID_FQDN
  Remote ID type: ID_IPV4_ADDR
  Remote ID: 2.2.2.2
  Auth sign method: Pre-shared key
  Auth verify method: Pre-shared key
  Integrity algorithm: SHA1
  PRF algorithm: SHA1
  Encryption algorithm: AES-CBC-128
  Life duration: 86400 secs
  Remaining key duration: 86177 secs
  Diffie-Hellman group: MODP1536/Group5
  DPD: Interval 0 secs, retry interval 0 secs
  Local window: 1
  Remote window: 1
  Local request message ID: 2
  Remote request message ID: 0
  Local next message ID: 2
  Remote next message ID: 0
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1435
    Tunnel:
    Flow:
        dest addr: 10.2.1.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      Connection ID: 605590388736
      Status: Active
    [Outbound ESP SAs]
      Connection ID: 227633266689
      Status: Active
Example: Configuring an IKE-based IPsec tunnel for IPv4 packets between a host and a gateway (remote extended authentication)
As shown in Figure 18, configure an IPsec tunnel to protect the traffic between the host and the device.
·     Set up IPsec SAs through IKE negotiations.
·     Configure the host and the device to use preshared key for authentication in the phase-1 IKE negotiation.
·     Configure the device to use RADIUS to perform remote extended authentication on the host.
The RADIUS server is configured to allow user login with username test and password 123456TESTplat&!.
Figure 18 Network diagram
Configuring the device
1.     Assign IP addresses to interfaces.
[Device-GigabitEthernet1/0/1] ip address 2.2.2.2 255.255.255.0
[Device] interface GigabitEthernet1/0/2
[Device-GigabitEthernet1/0/2] ip address 3.3.3.3 255.255.255.0
This example configures a static route, and the next hop in the route is 2.2.2.3.
[Device] ip route-static 1.1.1.1 24 2.2.2.3
[Device] security-zone name untrust
[Device-security-zone-Untrust] import interface gigabitethernet 1/0/1
[Device-security-zone-Untrust] quit
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/2
4.     Configure security policy rules to permit the traffic between the Untrust and Local security zones, so the host can access the device:
# Configure a rule named ipseclocalout1 to allow the device to send packets to the host.
[Device] security-policy ip
[Device-security-policy-ip] rule name ipseclocalout1
[Device-security-policy-ip-1-ipseclocalout1] source-zone local
[Device-security-policy-ip-1-ipseclocalout1] destination-zone untrust
[Device-security-policy-ip-1-ipseclocalout1] source-ip-host 2.2.2.2
[Device-security-policy-ip-1-ipseclocalout1] destination-ip-host 1.1.1.1
[Device-security-policy-ip-1-ipseclocalout1] action pass
[Device-security-policy-ip-1-ipseclocalout1] quit
# Configure a rule named ipseclocalin1 to allow the device to receive the packets sent from the host.
[Device-security-policy-ip] rule name ipseclocalin1
[Device-security-policy-ip-2-ipseclocalin1] source-zone untrust
[Device-security-policy-ip-2-ipseclocalin1] destination-zone local
[Device-security-policy-ip-2-ipseclocalin1] source-ip-host 1.1.1.1
[Device-security-policy-ip-2-ipseclocalin1] destination-ip-host 2.2.2.2
[Device-security-policy-ip-2-ipseclocalin1] action pass
[Device-security-policy-ip-2-ipseclocalin1] quit
# Configure a rule named ipseclocalout2 to allow the device to send packets to the RADIUS server.
[Device-security-policy-ip] rule name ipseclocalout2
[Device-security-policy-ip-3-ipseclocalout2] source-zone local
[Device-security-policy-ip-3-ipseclocalout2] destination-zone trust
[Device-security-policy-ip-3-ipseclocalout2] source-ip-host 3.3.3.3
[Device-security-policy-ip-3-ipseclocalout2] destination-ip-host 3.3.3.48
[Device-security-policy-ip-3-ipseclocalout2] action pass
[Device-security-policy-ip-3-ipseclocalout2] quit
# Configure a rule named ipseclocalin2 to allow the device to receive the packets sent from the RADIUS server.
[Device-security-policy-ip] rule name ipseclocalin2
[Device-security-policy-ip-4-ipseclocalin2] source-zone trust
[Device-security-policy-ip-4-ipseclocalin2] destination-zone local
[Device-security-policy-ip-4-ipseclocalin2] source-ip-host 3.3.3.48
[Device-security-policy-ip-4-ipseclocalin2] destination-ip-host 3.3.3.3
[Device-security-policy-ip-4-ipseclocalin2] action pass
[Device-security-policy-ip-4-ipseclocalin2] quit
[Device-security-policy-ip] quit
5.     Configure a RADIUS scheme:
# Create a RADIUS scheme named ike-scheme.
[Device] radius scheme ike-scheme
# Specify the IP address and service port of the primary RADIUS authentication server.
[Device-radius-ike-scheme] primary authentication 3.3.3.48 1645
# Set the shared key for secure RADIUS authentication communication.
[Device-radius-ike-scheme] key authentication simple abc
# Configure the device to send the username without the ISP domain name to the RADIUS server. (The configuration varies with the RADIUS server's requirements for username.)
[Device-radius-ike-scheme] user-name-format without-domain
[Device-radius-ike-scheme] quit
6.     Configure an ISP domain:
# Create an ISP domain named ike and specify the RADIUS scheme used for authenticating the IKE users.
[Device] domain ike
[Device-isp-ike] authentication ike radius-scheme ike-scheme
[Device-isp-ike] quit
7.     Configure an IPv4 advanced ACL to identify the packets to be protected.
[Device] acl advanced 3101
[Device-acl-ipv4-adv-3101] rule permit ip source 2.2.2.2 0.0.0.0 destination 1.1.1.1 0.0.0.0
[Device-acl-ipv4-adv-3101] quit
8.     Configure an IPsec transform set to specify the packet encapsulation mode, security protocols, and algorithms.
[Device] ipsec transform-set tran1
[Device-ipsec-transform-set-tran1] encapsulation-mode transport
[Device-ipsec-transform-set-tran1] protocol esp
[Device-ipsec-transform-set-tran1] esp encryption-algorithm aes-cbc-128
[Device-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[Device-ipsec-transform-set-tran1] quit
9.     Configure an IKE keychain to specify the key information used for IKE communication:
[Device] ike keychain keychain1
[Device-ike-keychain-keychain1] pre-shared-key address 1.1.1.1 255.255.255.255 key simple 123456TESTplat&!
[Device-ike-keychain-keychain1] quit
[Device] ike profile profile1
[Device-ike-profile-profile1] keychain keychain1
[Device-ike-profile-profile1] local-identity address 2.2.2.2
[Device-ike-profile-profile1] match remote identity address 1.1.1.1 255.255.255.255
[Device-ike-profile-profile1] client-authentication xauth
[Device-ike-profile-profile1] quit
[Device] ipsec policy map1 10 isakmp
[Device-ipsec-policy-isakmp-map1-10] remote-address 1.1.1.1
[Device-ipsec-policy-isakmp-map1-10] security acl 3101
[Device-ipsec-policy-isakmp-map1-10] transform-set tran1
[Device-ipsec-policy-isakmp-map1-10] ike-profile profile1
[Device-ipsec-policy-isakmp-map1-10] quit
12.     Apply the IPsec policy to GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] ipsec apply policy map1
Configuring the host
Perform the following tasks on the host and make sure the configuration matches that on the device:
·     Specify the IP address of the remote security gateway.
·     Set the preshared key used for IKE negotiation.
·     Configure the username and password for IKE extended authentication.
·     Specify the security protocol, encryption algorithm, and authentication algorithm.
·     Configure IKE negotiation parameters.
·     Configure the local ID and remote ID.
# Initiate a connection from the host (1.1.1.1) to the device (2.2.2.2) to trigger IKE negotiation. (Details not shown.)
# On the device, verify that an IKE SA to the peer 1.1.1.1 is established and that extended authentication is enabled for remote users.
[Device] display ike sa verbose remote-address 1.1.1.1
   Connection ID: 18
   Outside VPN:
   Inside VPN:
   Profile: profile1
   Local IP/port: 2.2.2.2/500
   Local ID type: IPV4_ADDR
   Local ID: 2.2.2.2
   Remote IP/port: 1.1.1.1/500
   Remote ID: 1.1.1.1
   Extend authentication: Enabled
# On the host, enter the correct username and password for extended authentication. After the authentication succeeds, the IPsec tunnel will be established. (Details not shown.)
# Verify that IPsec SAs have been established on the device.
[Device] display ipsec sa
Example: Configuring an IKE-based IPsec tunnel for IPv4 packets between a host and a gateway (local extended authentication and address pool authorization)
As shown in Figure 19, configure an IPsec tunnel to protect the traffic between the host and the server.
·     Configure the device to use AAA to perform local extended authentication on the host and assign an IPv4 address to the host.
Figure 19 Network diagram
Make sure the host, device, and server can reach each other.
Configure a local user account on the device to provide identity authentication for the host. In this example, the account uses username test and password 123456TESTplat&!.
5.     Configure an ISP domain:
# Create an ISP domain named dm.
[Device] domain dm
# Configure the device to perform IKE local authentication.
[Device-isp-dm] authentication ike local
# Configure the device to perform IKE local authorization.
[Device-isp-dm] authorization ike local
[Device-isp-dm] quit
6.     Create an IKE IPv4 address pool named pool with the address range 20.1.1.1 to 20.1.1.20.
[Device] ike address-group pool 20.1.1.1 20.1.1.20
7.     Configure local users:
# Add a network user named ike.
[Device] local-user ike class network
# Authorize user ike to use the IKE service. Specify IPv4 address pool pool as the authorized IPv4 address pool for user ike.
[Device-luser-network-ike] service-type ike
[Device-luser-network-ike] authorization-attribute ip-pool pool
[Device-luser-network-ike] quit
# Add a network user named test.
[Device] local-user test class network
# Authorize user test to use the IKE service, and configure a password for user test.
[Device-luser-network-test] service-type ike
[Device-luser-network-test] password simple 123456TESTplat&!
[Device-luser-network-test] quit
8.     Configure an IKE keychain to specify the key information used for IKE communication:
9.     Configure an IKE profile to specify the security parameters used for setting up IKE SAs.
[Device-ike-profile-profile1] aaa authorization domain dm username ike
10.     Configure an IPsec transform set to specify the packet encapsulation mode, security protocols, and algorithms.
[Device-ipsec-transform-set-tran1] esp encryption-algorithm aes-cbc-256
11.     Configure an IPsec policy template, which is used to create an IPsec policy.
[Device] ipsec policy-template pt 1
[Device-ipsec-policy-template-pt-1] transform-set tran1
[Device-ipsec-policy-template-pt-1] ike-profile profile1
[Device-ipsec-policy-template-pt-1] reverse-route dynamic
[Device-ipsec-policy-template-pt-1] quit
12.     Use the IPsec policy template to create an IKE-based IPsec policy entry.
[Device] ipsec policy map1 1 isakmp template pt
·     Configure the username and password for IKE client authentication.
# Initiate a connection from the host (1.1.1.1) to the server (3.3.3.48) to trigger IKE negotiation. (Details not shown.)
# On the device, verify that an IKE SA to peer 1.1.1.1 is established and client authentication is enabled.
   Connection ID: 18
   Outside VPN:
   Inside VPN:
   Profile: profile1
   Transmitting entity: Responder
   Local ID: 2.2.2.2
   Remote ID: 1.1.1.1
   Encryption-algorithm: 3DES-CBC
   Exchange-mode: Main
   Diffie-Hellman group: Group 2
   Assigned IP address: 20.1.1.2
# On the host, enter the correct username and password for client authentication. After the authentication succeeds, the IPsec tunnel will be established. (Details not shown.)
# Verify that IPsec SAs are established on the device.
<Device> display ipsec sa
  IPsec policy: map1
  Sequence number: 1
  Mode: Template
    Tunnel id: 2
    Encapsulation mode: transport
    Path MTU: 1427
    Tunnel:
        local  address/port: 2.2.2.2/500
        remote address/port: 1.1.1.1/500
    Flow:
        sour addr: 0.0.0.0/0.0.0.0  port: 0  protocol: ip
        dest addr: 20.1.1.2/255.255.255.255  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 2374047012 (0x8d811524)
      Transform set: ESP-ENCRYPT-AES-CBC-256 ESP-AUTH-SHA1
      SA remaining duration (kilobytes/sec): 1843198/3259
      Max received sequence-number: 24
      Status: Active
    [Outbound ESP SAs]
      SPI: 146589619 (0x08bcc7b3)
      SA remaining duration (kilobytes/sec): 1843200/3259
      Max sent sequence-number: 0
      Status: Active
      SA remaining duration (kilobytes/sec): 1839568/3164
      Max sent sequence-number: 2793
      Status: Active
Example: Configuring an IKE-based IPsec tunnel for IPv6 packets between gateways
As shown in Figure 20, establish an IPsec tunnel between Device A and Device B to protect data flows between subnet 333::/64 and subnet 555::/64. Configure the IPsec tunnel as follows:
Figure 20 Network diagram
[DeviceA-GigabitEthernet1/0/1] ipv6 address 333::1/64
This example configures static routes, and the next hop in the routes is 111::2.
[DeviceA] ipv6 route-static 555::0 64 111::2
[DeviceA] ipv6 route-static 222::0 64 111::2
[DeviceA] security-policy ipv6
[DeviceA-security-policy-ipv6] rule name ipseclocalout
[DeviceA-security-policy-ipv6-1-ipseclocalout] source-zone local
[DeviceA-security-policy-ipv6-1-ipseclocalout] destination-zone untrust
[DeviceA-security-policy-ipv6-1-ipseclocalout] source-ip-host 111::1
[DeviceA-security-policy-ipv6-1-ipseclocalout] destination-ip-host 222::1
[DeviceA-security-policy-ipv6-1-ipseclocalout] action pass
[DeviceA-security-policy-ipv6-1-ipseclocalout] quit
[DeviceA-security-policy-ipv6] rule name ipseclocalin
[DeviceA-security-policy-ipv6-2-ipseclocalin] source-zone untrust
[DeviceA-security-policy-ipv6-2-ipseclocalin] destination-zone local
[DeviceA-security-policy-ipv6-2-ipseclocalin] source-ip-host 222::1
[DeviceA-security-policy-ipv6-2-ipseclocalin] destination-ip-host 111::1
[DeviceA-security-policy-ipv6-2-ipseclocalin] action pass
[DeviceA-security-policy-ipv6-2-ipseclocalin] quit
[DeviceA-security-policy-ipv6] rule name trust-untrust
[DeviceA-security-policy-ipv6-3-trust-untrust] source-zone trust
[DeviceA-security-policy-ipv6-3-trust-untrust] destination-zone untrust
[DeviceA-security-policy-ipv6-3-trust-untrust] source-ip-subnet 333::1 64
[DeviceA-security-policy-ipv6-3-trust-untrust] destination-ip-subnet 555::1 64
[DeviceA-security-policy-ipv6-3-trust-untrust] action pass
[DeviceA-security-policy-ipv6-3-trust-untrust] quit
[DeviceA-security-policy-ipv6] rule name untrust-trust
[DeviceA-security-policy-ipv6-4-untrust-trust] source-zone untrust
[DeviceA-security-policy-ipv6-4-untrust-trust] destination-zone trust
[DeviceA-security-policy-ipv6-4-untrust-trust] source-ip-subnet 555::1 64
[DeviceA-security-policy-ipv6-4-untrust-trust] destination-ip-subnet 333::1 64
[DeviceA-security-policy-ipv6-4-untrust-trust] action pass
[DeviceA-security-policy-ipv6-4-untrust-trust] quit
[DeviceA-security-policy-ipv6] quit
# Configure an IPv6 advanced ACL to identify data flows from subnet 333::/64 to subnet 555::/64.
[DeviceA] acl ipv6 advanced 3101
[DeviceA-acl-ipv6-adv-3101] rule permit ipv6 source 333::0 64 destination 555::0 64
[DeviceA-acl-ipv6-adv-3101] quit
[DeviceA-ike-keychain-keychain1] pre-shared-key address ipv6 222::1 64 key simple 123456TESTplat&!
[DeviceA-ike-profile-profile1] match remote identity address ipv6 222::1 64
[DeviceA] ipsec ipv6-policy map1 10 isakmp
[DeviceA-ipsec-ipv6-policy-isakmp-map1-10] security acl ipv6 3101
[DeviceA-ipsec-ipv6-policy-isakmp-map1-10] transform-set tran1
[DeviceA-ipsec-ipv6-policy-isakmp-map1-10] local-address ipv6 111::1
[DeviceA-ipsec-ipv6-policy-isakmp-map1-10] remote-address ipv6 222::1
[DeviceA-ipsec-ipv6-policy-isakmp-map1-10] ike-profile profile1
[DeviceA-ipsec-ipv6-policy-isakmp-map1-10] quit
[DeviceA-GigabitEthernet1/0/2] ipsec apply ipv6-policy map1
[DeviceB-GigabitEthernet1/0/1] ipv6 address 555::1/64
This example configures static routes, and the next hop in the routes is 222::2.
[DeviceB] ipv6 route-static 333::0 64 222::2
[DeviceB] ipv6 route-static 111::0 64 222::2
[DeviceB] security-policy ipv6
[DeviceB-security-policy-ipv6] rule name ipseclocalout
[DeviceB-security-policy-ipv6-1-ipseclocalout] source-zone local
[DeviceB-security-policy-ipv6-1-ipseclocalout] destination-zone untrust
[DeviceB-security-policy-ipv6-1-ipseclocalout] source-ip-host 222::1
[DeviceB-security-policy-ipv6-1-ipseclocalout] destination-ip-host 111::1
[DeviceB-security-policy-ipv6-1-ipseclocalout] action pass
[DeviceB-security-policy-ipv6-1-ipseclocalout] quit
[DeviceB-security-policy-ipv6] rule name ipseclocalin
[DeviceB-security-policy-ipv6-2-ipseclocalin] source-zone untrust
[DeviceB-security-policy-ipv6-2-ipseclocalin] destination-zone local
[DeviceB-security-policy-ipv6-2-ipseclocalin] source-ip-host 111::1
[DeviceB-security-policy-ipv6-2-ipseclocalin] destination-ip-host 222::1
[DeviceB-security-policy-ipv6-2-ipseclocalin] action pass
[DeviceB-security-policy-ipv6] rule name trust-untrust
[DeviceB-security-policy-ipv6-3-trust-untrust] source-zone trust
[DeviceB-security-policy-ipv6-3-trust-untrust] destination-zone untrust
[DeviceB-security-policy-ipv6-3-trust-untrust] source-ip-subnet 333::1 64
[DeviceB-security-policy-ipv6-3-trust-untrust] destination-ip-subnet 555::1 64
[DeviceB-security-policy-ipv6-3-trust-untrust] action pass
[DeviceB-security-policy-ipv6-3-trust-untrust] quit
[DeviceB-security-policy-ipv6] rule name untrust-trust
[DeviceB-security-policy-ipv6-4-untrust-trust] source-zone untrust
[DeviceB-security-policy-ipv6-4-untrust-trust] destination-zone trust
[DeviceB-security-policy-ipv6-4-untrust-trust] source-ip-subnet 555::1 64
[DeviceB-security-policy-ipv6-4-untrust-trust] destination-ip-subnet 333::1 64
[DeviceB-security-policy-ipv6-4-untrust-trust] action pass
[DeviceB-security-policy-ipv6-4-untrust-trust] quit
[DeviceB-security-policy-ipv6] quit
# Configure an IPv6 advanced ACL to identify data flows from subnet 555::/64 to subnet 333::/64.
[DeviceB] acl ipv6 advanced 3101
[DeviceB-acl-ipv6-adv-3101] rule permit ipv6 source 555::/64 destination 333::/64
[DeviceB-acl-ipv6-adv-3101] quit
[DeviceB-ike-keychain-keychain1] pre-shared-key address ipv6 111::1 64 key simple 123456TESTplat&!
[DeviceB-ike-profile-profile1] match remote identity address ipv6 111::1 64
[DeviceB] ipsec ipv6-policy use1 10 isakmp
[DeviceB-ipsec-ipv6-policy-isakmp-use1-10] security acl ipv6 3101
[DeviceB-ipsec-ipv6-policy-isakmp-use1-10] transform-set tran1
[DeviceB-ipsec-ipv6-policy-isakmp-use1-10] local-address ipv6 222::1
[DeviceB-ipsec-ipv6-policy-isakmp-use1-10] remote-address ipv6 111::1
[DeviceB-ipsec-ipv6-policy-isakmp-use1-10] ike-profile profile1
[DeviceB-ipsec-ipv6-policy-isakmp-use1-10] quit
[DeviceB-GigabitEthernet1/0/2] ipsec apply ipv6-policy use1
# Initiate a connection from subnet 333::/64 to subnet 555::/64 to trigger IKE negotiation. After IPsec SAs are successfully negotiated by IKE, the traffic between the two subnets is IPsec-protected.
  IPsec policy: map1
  Sequence number: 10
  Alisa: map1-10
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1423
    Tunnel:
        local  address/port: 111::1/500
        remote address/port: 222::1/500
    Flow:
    sour addr: 111::1/0      port: 0  protocol: ipv6
    dest addr: 222::1/0      port: 0  protocol: ipv6
    [Inbound ESP SAs]
      Connection ID: 1
      Status: Active
    [Outbound ESP SAs]
      Connection ID: 2
      Status: Active
Example: Configuring IPsec tunnels for IPv4 packets between headquarters and branches (IPsec policy template mode)
The branches of an enterprise access the headquarters through IPsec VPN. Device A is the headquarters gateway. Device B and Device C are the branch gateways.
Establish an IPsec tunnel between the headquarters gateway and each branch gateway to protect the data between the headquarters network (4.4.4.0/24) and the branch networks (5.5.5.0/24 and 6.6.6.0/24)
Configure the headquarters gateway Device A to use an IKE-based IPsec policy template and the branch gateways Device B and Device C to use an IKE-based IPsec policy to establish the IPsec tunnels.
Use the ESP security protocol, DES encryption algorithm, and HMAC-SHA-1-96 authentication algorithm to establish IPsec SAs.
Use the preshared key authentication mode, 3DES encryption algorithm, and HMAC-SHA1 authentication algorithm for IKE negotiation.
Figure 21 Network diagram
Configuring Device A
1.     Assign IP addresses to interfaces:
# Assign an IP address to interface GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] ip address 1.1.1.1 255.255.255.0
2.     Configure settings for routing.
[DeviceA] ip route-static 2.2.2.2 24 1.1.1.2
[DeviceA] ip route-static 3.3.3.3 24 1.1.1.2
[DeviceA] ip route-static 5.5.5.0 255.255.255.0 1.1.1.2
[DeviceA] ip route-static 6.6.6.0 255.255.255.0 1.1.1.2
3.     Add interfaces to security zones.
[DeviceA] security-zone name untrust
[DeviceA-security-zone-Untrust] quit
[DeviceA] security-zone name trust
[DeviceA-security-zone-Trust] quit
4.     Configure a security policy:
a.     Configure rules to permit traffic between the Untrust and Local security zones, so the devices can set up an IPsec tunnel:
# Configure a rule named ipseclocalout1 to allow Device A to send IPsec negotiation packets to Device B.
[DeviceA-security-policy-ip] rule name ipseclocalout1
[DeviceA-security-policy-ip-1-ipseclocalout1] source-zone local
[DeviceA-security-policy-ip-1-ipseclocalout1] destination-zone untrust
[DeviceA-security-policy-ip-1-ipseclocalout1] source-ip-host 1.1.1.1
[DeviceA-security-policy-ip-1-ipseclocalout1] destination-ip-host 2.2.2.2
[DeviceA-security-policy-ip-1-ipseclocalout1] action pass
[DeviceA-security-policy-ip-1-ipseclocalout1] quit
# Configure a rule named ipseclocalin1 to allow Device A to receive the IPsec negotiation packets sent from Device B.
[DeviceA-security-policy-ip] rule name ipseclocalin1
[DeviceA-security-policy-ip-2-ipseclocalin1] source-zone untrust
[DeviceA-security-policy-ip-2-ipseclocalin1] destination-zone local
[DeviceA-security-policy-ip-2-ipseclocalin1] source-ip-host 2.2.2.2
[DeviceA-security-policy-ip-2-ipseclocalin1] destination-ip-host 1.1.1.1
[DeviceA-security-policy-ip-2-ipseclocalin1] action pass
[DeviceA-security-policy-ip-2-ipseclocalin1] quit
# Configure a rule named ipseclocalout2 to allow Device A to send IPsec negotiation packets to Device C.
[DeviceA-security-policy-ip] rule name ipseclocalout2
[DeviceA-security-policy-ip-3-ipseclocalout2] source-zone local
[DeviceA-security-policy-ip-3-ipseclocalout2] destination-zone untrust
[DeviceA-security-policy-ip-3-ipseclocalout2] source-ip-host 1.1.1.1
[DeviceA-security-policy-ip-3-ipseclocalout2] destination-ip-host 3.3.3.3
[DeviceA-security-policy-ip-3-ipseclocalout2] action pass
[DeviceA-security-policy-ip-3-ipseclocalout2] quit
# Configure a rule named ipseclocalin2 to allow Device A to receive the IPsec negotiation packets sent from Device C.
[DeviceA-security-policy-ip] rule name ipseclocalin2
[DeviceA-security-policy-ip-4-ipseclocalin2] source-zone untrust
[DeviceA-security-policy-ip-4-ipseclocalin2] destination-zone local
[DeviceA-security-policy-ip-4-ipseclocalin2] source-ip-host 3.3.3.3
[DeviceA-security-policy-ip-4-ipseclocalin2] destination-ip-host 1.1.1.1
[DeviceA-security-policy-ip-4-ipseclocalin2] action pass
[DeviceA-security-policy-ip-4-ipseclocalin2] quit
b.     Configure rules to permit the traffic between Host A and Host B or Host C:
# Configure a rule named trust-untrust to permit the packets from Host A to Host B.
[DeviceA-security-policy-ip] rule name trust-untrust
[DeviceA-security-policy-ip-5-trust-untrust] source-zone trust
[DeviceA-security-policy-ip-5-trust-untrust] destination-zone untrust
[DeviceA-security-policy-ip-5-trust-untrust] source-ip-subnet 4.4.4.0 24
[DeviceA-security-policy-ip-5-trust-untrust] destination-ip-subnet 5.5.5.0 24
[DeviceA-security-policy-ip-5-trust-untrust] action pass
[DeviceA-security-policy-ip-5-trust-untrust] quit
# Configure a rule named untrust-trust to permit the packets from Host B to Host A.
[DeviceA-security-policy-ip] rule name untrust-trust
[DeviceA-security-policy-ip-6-untrust-trust] source-zone untrust
[DeviceA-security-policy-ip-6-untrust-trust] destination-zone trust
[DeviceA-security-policy-ip-6-untrust-trust] source-ip-subnet 5.5.5.0 24
[DeviceA-security-policy-ip-6-untrust-trust] destination-ip-subnet 4.4.4.0 24
[DeviceA-security-policy-ip-6-untrust-trust] action pass
[DeviceA-security-policy-ip-6-untrust-trust] quit
# Configure a rule named trust-untrust to permit the packets from Host A to Host C.
[DeviceA-security-policy-ip-7-trust-untrust] source-zone trust
[DeviceA-security-policy-ip-7-trust-untrust] destination-zone untrust
[DeviceA-security-policy-ip-7-trust-untrust] source-ip-subnet 4.4.4.0 24
[DeviceA-security-policy-ip-7-trust-untrust] destination-ip-subnet 6.6.6.0 24
[DeviceA-security-policy-ip-7-trust-untrust] action pass
[DeviceA-security-policy-ip-7-trust-untrust] quit
# Configure a rule named untrust-trust to permit the packets from Host C to Host A.
[DeviceA-security-policy-ip-8-untrust-trust] source-zone untrust
[DeviceA-security-policy-ip-8-untrust-trust] destination-zone trust
[DeviceA-security-policy-ip-8-untrust-trust] source-ip-subnet 6.6.6.0 24
[DeviceA-security-policy-ip-8-untrust-trust] destination-ip-subnet 4.4.4.0 24
[DeviceA-security-policy-ip-8-untrust-trust] action pass
[DeviceA-security-policy-ip-8-untrust-trust] quit
[DeviceA-security-policy-ip] quit
5.     Configure an IPsec transform set to specify the packet encapsulation mode, security protocols, and algorithms. The IPsec transform set settings at both sides of the IPsec tunnel must be the same.
[DeviceA] ipsec transform-set tran1
[DeviceA-ipsec-transform-set-tran1] encapsulation-mode tunnel
[DeviceA-ipsec-transform-set-tran1] protocol esp
[DeviceA-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[DeviceA-ipsec-transform-set-tran1] quit
6.     Configure IKE keychains to specify the keys information used for IKE communication between peers.
# Create an IKE keychain named key1 to specify the preshared key as 123 for communication with peer 2.2.2.2.
[DeviceA] ike keychain key1
[DeviceA-ike-keychain-key1] pre-shared-key address 2.2.2.2 key simple 123
[DeviceA-ike-keychain-key1] quit
# Create an IKE keychain named key2 to specify the preshared key as 456 for communication with peer 3.3.3.3.
[DeviceA] ike keychain key2
[DeviceA-ike-keychain-key2] pre-shared-key address 3.3.3.3 key simple 456
[DeviceA-ike-keychain-key2] quit
[DeviceA-ike-profile-profile1] keychain key1
[DeviceA-ike-profile-profile1] keychain key2
[DeviceA-ike-profile-profile1] match remote identity address 2.2.2.2 255.255.255.0
[DeviceA-ike-profile-profile1] match remote identity address 3.3.3.3 255.255.255.0
8.     Configure an IPsec policy template, which is used to create an IPsec policy:
# Create an IPsec policy template named temp1. Specify the IPsec transform set tran1 and IKE profile profile1 for the template.
[DeviceA] ipsec policy-template temp1 1
[DeviceA-ipsec-policy-template-temp1-1] transform-set tran1
[DeviceA-ipsec-policy-template-temp1-1] ike-profile profile1
9.     Create an IKE-based IPsec policy entry by using IPsec policy template temp1, so as to establish the IPsec tunnel to protect data.
[DeviceA] ipsec policy map1 10 isakmp template temp1
10.     Configure an IKE proposal to specify the security parameters used for IKE negotiation.
# Create an IKE proposal named 1, which uses the 3DES encryption algorithm, HMAC-SHA1 authentication algorithm, and preshared key authentication method.
[DeviceA-ike-proposal-1] encryption-algorithm 3des-cbc
[DeviceA-ike-proposal-1] authentication-algorithm sha
[DeviceA-ike-proposal-1] authentication-method pre-share
[DeviceA-ike-proposal-1] quit
11.     Apply the IPsec policy to interface GigabitEthernet 1/0/1 to protect traffic on the interface.
Configuring Device B
[DeviceB-GigabitEthernet1/0/1] ip address 2.2.2.2 255.255.255.0
This example configures static routes, and the next hop in the routes is 2.2.2.3.
[DeviceB] ip route-static 4.4.4.0 24 2.2.2.3
[DeviceB] ip route-static 1.1.1.1 24 2.2.2.3
[DeviceB] security-zone name untrust
[DeviceB-security-zone-Untrust] quit
[DeviceB] security-zone name trust
[DeviceB-security-zone-Trust] quit
# Configure a rule named ipseclocalout to allow Device B to send IPsec negotiation packets to Device A.
[DeviceB-security-policy-ip] rule name ipseclocalout
[DeviceB-security-policy-ip-1-ipseclocalout] source-zone local
[DeviceB-security-policy-ip-1-ipseclocalout] destination-zone untrust
[DeviceB-security-policy-ip-1-ipseclocalout] action pass
[DeviceB-security-policy-ip-1-ipseclocalout] quit
# Configure a rule named ipseclocalin to allow Device B to receive the IPsec negotiation packets sent from Device A.
[DeviceB-security-policy-ip] rule name ipseclocalin
[DeviceB-security-policy-ip-2-ipseclocalin] source-zone untrust
[DeviceB-security-policy-ip-2-ipseclocalin] destination-zone local
[DeviceB-security-policy-ip-2-ipseclocalin] action pass
[DeviceB-security-policy-ip-2-ipseclocalin] quit
b.     Configure rules to permit traffic between Host B and Host A:
# Configure a rule named trust-untrust to permit the packets from Host B to Host A.
[DeviceB-security-policy-ip] rule name trust-untrust
[DeviceB-security-policy-ip-3-trust-untrust] source-zone trust
[DeviceB-security-policy-ip-3-trust-untrust] destination-zone untrust
[DeviceB-security-policy-ip-3-trust-untrust] source-ip-subnet 5.5.5.0 24
[DeviceB-security-policy-ip-3-trust-untrust] destination-ip-subnet 4.4.4.0 24
[DeviceB-security-policy-ip-3-trust-untrust] action pass
[DeviceB-security-policy-ip-3-trust-untrust] quit
# Configure a rule named untrust-trust to permit the packets from Host A to Host B.
[DeviceB-security-policy-ip] rule name untrust-trust
[DeviceB-security-policy-ip-4-untrust-trust] source-zone untrust
[DeviceB-security-policy-ip-4-untrust-trust] destination-zone trust
[DeviceB-security-policy-ip-4-untrust-trust] source-ip-subnet 4.4.4.0 24
[DeviceB-security-policy-ip-4-untrust-trust] destination-ip-subnet 5.5.5.0 24
[DeviceB-security-policy-ip-4-untrust-trust] action pass
[DeviceB-security-policy-ip-4-untrust-trust] quit
[DeviceB-security-policy-ip] quit
5.     Define the data flows to be protected:
# Configure an IPv4 advanced ACL to identify data flows from subnet 5.5.5.0/24 to subnet 4.4.4.0/24.
[DeviceB] acl advanced 3000
[DeviceB-acl-ipv4-adv-3000] rule permit ip source 5.5.5.0 0.0.0.255 destination 4.4.4.0 0.0.0.255
[DeviceB-acl-ipv4-adv-3000] quit
6.     Configure an IPsec transform set to specify the packet encapsulation mode, security protocols, and algorithms. The IPsec transform set settings at both sides of the IPsec tunnel must be the same.
[DeviceB] ipsec transform-set tran1
[DeviceB-ipsec-transform-set-tran1] encapsulation-mode tunnel
[DeviceB-ipsec-transform-set-tran1] protocol esp
[DeviceB-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[DeviceB-ipsec-transform-set-tran1] quit
7.     Configure an IKE keychain to specify the key information used for IKE communication.
# Create an IKE keychain named key1 to specify the preshared key as 123 for communication with peer 1.1.1.1.
[DeviceB] ike keychain key1
[DeviceB-ike-keychain-key1] pre-shared-key address 1.1.1.1 key simple 123
[DeviceB-ike-keychain-key1] quit
8.     Configure an IKE profile to specify the security parameters used for setting up IKE SAs.
[DeviceB] ike profile profile1
[DeviceB-ike-profile-profile1] keychain key1
[DeviceB-ike-profile-profile1] match remote identity address 1.1.1.1 255.255.255.0
[DeviceB-ike-profile-profile1] quit
9.     Configure an IPsec policy, so as to establish the IPsec tunnel to protect data:
# Create an IKE-based IPsec policy entry, which specifies the ACL for IPsec, IPsec transform set, local and remote IP addresses, and IKE profile.
[DeviceB] ipsec policy map1 10 isakmp
[DeviceB-ipsec-policy-isakmp-map1-10] transform-set tran1
[DeviceB-ipsec-policy-isakmp-map1-10] security acl 3000
[DeviceB-ipsec-policy-isakmp-map1-10] local-address 2.2.2.2
[DeviceB-ipsec-policy-isakmp-map1-10] remote-address 1.1.1.1
[DeviceB-ipsec-policy-isakmp-map1-10] ike-profile profile1
[DeviceB-ipsec-policy-isakmp-map1-10] quit
[DeviceB-ike-proposal-1] encryption-algorithm 3des-cbc
[DeviceB-ike-proposal-1] authentication-algorithm sha
[DeviceB-ike-proposal-1] authentication-method pre-share
[DeviceB-ike-proposal-1] quit
[DeviceB-GigabitEthernet1/0/1] ipsec apply policy map1
Configuring Device C
<DeviceC> system-view
[DeviceC-GigabitEthernet1/0/1] ip address 3.3.3.3 255.255.255.0
This example configures static routes, and the next hop in the routes is 3.3.3.4
[DeviceC] ip route-static 4.4.4.0 24 3.3.3.4
[DeviceC] ip route-static 1.1.1.1 24 3.3.3.4
[DeviceC] security-zone name untrust
[DeviceC-security-zone-Untrust] import interface gigabitethernet 1/0/1
[DeviceC-security-zone-Untrust] quit
[DeviceC] security-zone name trust
[DeviceC-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceC-security-zone-Trust] quit
# Configure a rule named ipseclocalout to allow Device C to send IPsec negotiation packets to Device A.
[DeviceC] security-policy ip
[DeviceC-security-policy-ip] rule name ipseclocalout
[DeviceC-security-policy-ip-1-ipseclocalout] source-zone local
[DeviceC-security-policy-ip-1-ipseclocalout] destination-zone untrust
[DeviceC-security-policy-ip-1-ipseclocalout] source-ip-host 3.3.3.3
[DeviceC-security-policy-ip-1-ipseclocalout] destination-ip-host 1.1.1.1
[DeviceC-security-policy-ip-1-ipseclocalout] action pass
[DeviceC-security-policy-ip-1-ipseclocalout] quit
# Configure a rule named ipseclocalin to allow Device C to receive the IPsec negotiation packets sent from Device A.
[DeviceC-security-policy-ip] rule name ipseclocalin
[DeviceC-security-policy-ip-2-ipseclocalin] source-zone untrust
[DeviceC-security-policy-ip-2-ipseclocalin] destination-zone local
[DeviceC-security-policy-ip-2-ipseclocalin] source-ip-host 1.1.1.1
[DeviceC-security-policy-ip-2-ipseclocalin] destination-ip-host 3.3.3.3
[DeviceC-security-policy-ip-2-ipseclocalin] action pass
[DeviceC-security-policy-ip-2-ipseclocalin] quit
b.     Configure rules to permit traffic between Host C and Host A:
# Configure a rule named trust-untrust to permit the packets from Host C to Host A.
[DeviceC-security-policy-ip] rule name trust-untrust
[DeviceC-security-policy-ip-3-trust-untrust] source-zone trust
[DeviceC-security-policy-ip-3-trust-untrust] destination-zone untrust
[DeviceC-security-policy-ip-3-trust-untrust] source-ip-subnet 6.6.6.0 24
[DeviceC-security-policy-ip-3-trust-untrust] destination-ip-subnet 4.4.4.0 24
[DeviceC-security-policy-ip-3-trust-untrust] action pass
[DeviceC-security-policy-ip-3-trust-untrust] quit
# Configure a rule named untrust-trust to permit the packets from Host A to Host C.
[DeviceC-security-policy-ip] rule name untrust-trust
[DeviceC-security-policy-ip-4-untrust-trust] source-zone untrust
[DeviceC-security-policy-ip-4-untrust-trust] destination-zone trust
[DeviceC-security-policy-ip-4-untrust-trust] source-ip-subnet 4.4.4.0 24
[DeviceC-security-policy-ip-4-untrust-trust] destination-ip-subnet 6.6.6.0 24
[DeviceC-security-policy-ip-4-untrust-trust] action pass
[DeviceC-security-policy-ip-4-untrust-trust] quit
[DeviceC-security-policy-ip] quit
# Configure an IPv4 advanced ACL to identify data flows from subnet 6.6.6.0/24 to subnet 4.4.4.0/24.
[DeviceC] acl advanced 3000
[DeviceC-acl-ipv4-adv-3000] rule permit ip source 6.6.6.0 0.0.0.255 destination 4.4.4.0 0.0.0.255
[DeviceC-acl-ipv4-adv-3000] quit
[DeviceC] ipsec transform-set tran1
[DeviceC-ipsec-transform-set-tran1] encapsulation-mode tunnel
[DeviceC-ipsec-transform-set-tran1] protocol esp
[DeviceC-ipsec-transform-set-tran1] esp encryption-algorithm des
[DeviceC-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[DeviceC-ipsec-transform-set-tran1] quit
# Create an IKE keychain named key1 to specify the preshared key as 456 for communication with peer 1.1.1.1.
[DeviceC] ike keychain key1
[DeviceC-ike-keychain-key1] pre-shared-key address 1.1.1.1 key simple 456
[DeviceC-ike-keychain-key1] quit
[DeviceC] ike profile profile1
[DeviceC-ike-profile-profile1] keychain key1
[DeviceC-ike-profile-profile1] match remote identity address 1.1.1.1 255.255.255.0
[DeviceC-ike-profile-profile1] quit
[DeviceC] ipsec policy map1 10 isakmp
[DeviceC-ipsec-policy-isakmp-map1-10] transform-set tran1
[DeviceC-ipsec-policy-isakmp-map1-10] security acl 3000
[DeviceC-ipsec-policy-isakmp-map1-10] local-address 3.3.3.3
[DeviceC-ipsec-policy-isakmp-map1-10] remote-address 1.1.1.1
[DeviceC-ipsec-policy-isakmp-map1-10] ike-profile profile1
[DeviceC-ipsec-policy-isakmp-map1-10] quit
10.     Apply the IPsec policy to interface GigabitEthernet 1/0/1 to protect traffic on the interface.
[DeviceC-GigabitEthernet1/0/1] ipsec apply policy map1
# Initiate a connection from headquarters subnet 5.5.5.0/24 to branch subnet 4.4.4.0/24 to trigger IKE negotiation. After IPsec SAs are successfully negotiated by IKE, the traffic between the two subnets is IPsec-protected.
# Display IKE SAs on Device A.
Flags:
# Display IPsec SAs on Device A.
[DeviceA] display ipsec sa
  IPsec policy: map1
  Sequence number: 10
  Mode: Template
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Transmitting entity: Initiator
    Path MTU: 1463
    Tunnel:
    Flow:
    sour addr: 4.4.4.0/255.255.255.0  port: 0  protocol: ip
    dest addr: 5.5.5.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 1014286405 (0x3c74c845)
      Connection ID: 1
      SA remaining duration (kilobytes/sec): 1843199/3590
      Max received sequence-number: 4
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 4011716027 (0xef1dedbb)
      Connection ID: 2
      Max sent sequence-number: 4
      Status: Active
Example: Configuring IPsec for RIPng
As shown in Figure 22, Device A, Device B, and Device C learn IPv6 routes through RIPng.
Establish an IPsec tunnel between the devices to protect the RIPng packets transmitted in between. Specify the security protocol as ESP, the encryption algorithm as 128-bit AES, and the authentication algorithm as HMAC-SHA1 for the IPsec tunnel.
Figure 22 Network diagram
Requirements analysis
To meet the Network configuration, perform the following tasks:
1.     Configure basic RIPng.
For more information about RIPng configuration, see Layer 3—IP Routing Configuration Guide.
2.     Configure an IPsec profile.
¡     The IPsec profiles on all the devices must have IPsec transform sets that use the same security protocol, authentication and encryption algorithms, and encapsulation mode.
¡     The SPI and key configured for the inbound SA and those for the outbound SA must be the same on each device.
¡     The SPI and key configured for the SAs on all the devices must be the same.
3.     Apply the IPsec profile to a RIPng process or to an interface.
1.     Assign an IP address to interface GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] ipv6 address 1::1/64
This example configures a static route, and the next hop in the route is 1::2.
[DeviceA] ipv6 route-static 3::2 64 1::2
3.     Add interface GigabitEthernet 1/0/1 to the Untrust security zone.
[DeviceA-security-zone-Untrust] import interface gigabitethernet 1/0/1
4.     Configure rules to permit traffic between the Untrust and Local security zones, so the devices can set up an IPsec tunnel:
# Configure a rule named ipseclocalout to allow Device A to send IPsec negotiation packets to Device B.
[DeviceA-security-policy-ipv6-1-ipseclocalout] source-ip-host 1::1
[DeviceA-security-policy-ipv6-1-ipseclocalout] destination-ip-host 1::2
# Configure a rule named ipseclocalin to allow Device A to receive the IPsec negotiation packets sent from Device B.
[DeviceA-security-policy-ipv6-2-ipseclocalin] source-ip-host 1::2
[DeviceA-security-policy-ipv6-2-ipseclocalin] destination-ip-host 1::1
5.     Configure basic RIPng.
[DeviceA] ripng 1
[DeviceA-ripng-1] quit
[DeviceA-GigabitEthernet1/0/1] ripng 1 enable
6.     Configure an IPsec profile to establish an IPsec tunnel to protect the specified data:
# Create and configure an IPsec transform set named tran1.
[DeviceA-ipsec-transform-set-tran1] encapsulation-mode transport
[DeviceA-ipsec-transform-set-tran1] esp encryption-algorithm aes-cbc-128
# Create and configure an IPsec profile named profile001.
[DeviceA] ipsec profile profile001 manual
[DeviceA-ipsec-profile-manual-profile001] transform-set tran1
[DeviceA-ipsec-profile-manual-profile001] sa spi outbound esp 123456
[DeviceA-ipsec-profile-manual-profile001] sa spi inbound esp 123456
[DeviceA-ipsec-profile-manual-profile001] sa string-key outbound esp simple abcdefg
[DeviceA-ipsec-profile-manual-profile001] sa string-key inbound esp simple abcdefg
[DeviceA-ipsec-profile-manual-profile001] quit
7.     Apply the IPsec profile to RIPng process 1 to protect RIPng packets with IPsec.
[DeviceA] ripng 1
[DeviceA-ripng-1] enable ipsec-profile profile001
[DeviceB-GigabitEthernet1/0/1] ipv6 address 1::2/64
2.     Configure basic RIPng.
[DeviceB] ripng 1
[DeviceB-ripng-1] quit
[DeviceB-GigabitEthernet1/0/1] ripng 1 enable
[DeviceB-GigabitEthernet1/0/2] ripng 1 enable
3.     Configure an IPsec profile to establish an IPsec tunnel to protect the specified data:
[DeviceB-ipsec-transform-set-tran1] encapsulation-mode transport
[DeviceB-ipsec-transform-set-tran1] esp encryption-algorithm aes-cbc-128
[DeviceB] ipsec profile profile001 manual
[DeviceB-ipsec-profile-manual-profile001] transform-set tran1
[DeviceB-ipsec-profile-manual-profile001] sa spi outbound esp 123456
[DeviceB-ipsec-profile-manual-profile001] sa spi inbound esp 123456
[DeviceB-ipsec-profile-manual-profile001] sa string-key outbound esp simple abcdefg
[DeviceB-ipsec-profile-manual-profile001] sa string-key inbound esp simple abcdefg
[DeviceB-ipsec-profile-manual-profile001] quit
4.     Apply the IPsec profile to RIPng process 1 to protect RIPng packets with IPsec.
[DeviceB] ripng 1
[DeviceB-ripng-1] enable ipsec-profile profile001
[DeviceC-GigabitEthernet1/0/1] ipv6 address 3::2/64
This example configures a static route, and the next hop in the route is 3::1.
[DeviceC] ipv6 route-static 1::1 64 3::1
# Configure a rule named ipseclocalout to allow Device C to send IPsec negotiation packets to Device B.
[DeviceC] security-policy ipv6
[DeviceC-security-policy-ipv6] rule name ipseclocalout
[DeviceC-security-policy-ipv6-1-ipseclocalout] source-zone local
[DeviceC-security-policy-ipv6-1-ipseclocalout] destination-zone untrust
[DeviceC-security-policy-ipv6-1-ipseclocalout] source-ip-host 3::2
[DeviceC-security-policy-ipv6-1-ipseclocalout] destination-ip-host 3::1
[DeviceC-security-policy-ipv6-1-ipseclocalout] action pass
[DeviceC-security-policy-ipv6-1-ipseclocalout] quit
# Configure a rule named ipseclocalin to allow Device C to receive the IPsec negotiation packets sent from Device B.
[DeviceC-security-policy-ipv6] rule name ipseclocalin
[DeviceC-security-policy-ipv6-2-ipseclocalin] source-zone untrust
[DeviceC-security-policy-ipv6-2-ipseclocalin] destination-zone local
[DeviceC-security-policy-ipv6-2-ipseclocalin] source-ip-host 3::1
[DeviceC-security-policy-ipv6-2-ipseclocalin] destination-ip-host 3::2
[DeviceC-security-policy-ipv6-2-ipseclocalin] action pass
[DeviceC-security-policy-ipv6-2-ipseclocalin] quit
[DeviceC] ripng 1
[DeviceC-ripng-1] quit
[DeviceC-GigabitEthernet1/0/1] ripng 1 enable
6.     Configure an IPsec profile, so as to establish the IPsec tunnel to protect data:
[DeviceC-ipsec-transform-set-tran1] encapsulation-mode transport
[DeviceC-ipsec-transform-set-tran1] esp encryption-algorithm aes-cbc-128
[DeviceC] ipsec profile profile001 manual
[DeviceC-ipsec-profile-manual-profile001] transform-set tran1
[DeviceC-ipsec-profile-manual-profile001] sa spi outbound esp 123456
[DeviceC-ipsec-profile-manual-profile001] sa spi inbound esp 123456
[DeviceC-ipsec-profile-manual-profile001] sa string-key outbound esp simple abcdefg
[DeviceC-ipsec-profile-manual-profile001] sa string-key inbound esp simple abcdefg
[DeviceC-ipsec-profile-manual-profile001] quit
[DeviceC] ripng 1
[DeviceC-ripng-1] enable ipsec-profile profile001
After the configuration is completed, Device A, Device B, and Device C learn IPv6 routing information through RIPng. IPsec SAs are set up successfully on the devices to protect RIPng packets. This example uses Device A to verify the configuration.
# Display the RIPng configuration.
[DeviceA] display ripng 1
    RIPng process : 1
       Preference : 100
       Checkzero : Enabled
       Default Cost : 0
       Maximum number of load balanced routes : 8
       Update time   :   30 secs  Timeout time         :  180 secs
       Suppress time :  120 secs  Garbage-Collect time :  120 secs
       Update output delay:   20(ms)  Output count:    3
       Graceful-restart interval:   60 secs
       Triggered Interval : 5 50 200
       Number of periodic updates sent : 186
       Number of triggered updates sent : 1
The output shows that the IPsec profile profile001 has been applied to RIPng process 1.
# Display the established IPsec SAs.
Global IPsec SA
  IPsec profile: profile001
  Alisa: profile-profile001
  Mode: Manual
    [Inbound ESP SA]
      SPI: 123456 (0x3039)
      Connection ID: 1
      Transform set: ESP-ENCRYPT-AES-CBC-128 ESP-AUTH-SHA1
      No duration limit for this SA
    [Outbound ESP SA]
      Connection ID: 2
Example: Configuring IPsec RRI
As shown in Figure 23, branches access the corporate headquarters through an IPsec VPN.
Configure the IPsec VPN as follows:
·     Configure an IPsec tunnel between Device A and each branch gateway (Device B, Device C, and Device D) to protect traffic between subnets 4.4.4.0/24 and 5.5.5.0/24.
·     Configure the tunnels to use the security protocol ESP, the encryption algorithm DES, and the authentication algorithm SHA1-HMAC-96. Use IKE for IPsec SA negotiation.
·     Configure IKE proposal to use the preshared key authentication method, encryption algorithm 3DES, and authentication algorithm HMAC-SHA1.
·     Configure IPsec RRI on Device A to automatically create static routes to the branches based on the established IPsec SAs.
Figure 23 Network diagram
This example configures a static route, and the next hop in the route is 1.1.1.2.
[DeviceA-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceA-security-policy-ip-1-ipseclocalout] source-zone local
[DeviceA-security-policy-ip-1-ipseclocalout] destination-zone untrust
[DeviceA-security-policy-ip-1-ipseclocalout] source-ip-host 1.1.1.1
[DeviceA-security-policy-ip-1-ipseclocalout] destination-ip-host 2.2.2.2
[DeviceA-security-policy-ip-1-ipseclocalout] action pass
[DeviceA-security-policy-ip-1-ipseclocalout] quit
[DeviceA-security-policy-ip-2-ipseclocalin] source-zone untrust
[DeviceA-security-policy-ip-2-ipseclocalin] destination-zone local
[DeviceA-security-policy-ip-2-ipseclocalin] source-ip-host 2.2.2.2
[DeviceA-security-policy-ip-2-ipseclocalin] destination-ip-host 1.1.1.1
[DeviceA-security-policy-ip-2-ipseclocalin] action pass
[DeviceA-security-policy-ip-2-ipseclocalin] quit
b.     Configure rules to permit the traffic between Host A and Host B:
[DeviceA-security-policy-ip-3-trust-untrust] source-zone trust
[DeviceA-security-policy-ip-3-trust-untrust] destination-zone untrust
[DeviceA-security-policy-ip-3-trust-untrust] source-ip-subnet 4.4.4.0 24
[DeviceA-security-policy-ip-3-trust-untrust] destination-ip-subnet 5.5.5.0 24
[DeviceA-security-policy-ip-3-trust-untrust] action pass
[DeviceA-security-policy-ip-3-trust-untrust] quit
[DeviceA-security-policy-ip-4-untrust-trust] source-zone untrust
[DeviceA-security-policy-ip-4-untrust-trust] destination-zone trust
[DeviceA-security-policy-ip-4-untrust-trust] source-ip-subnet 5.5.5.0 24
[DeviceA-security-policy-ip-4-untrust-trust] destination-ip-subnet 4.4.4.0 24
[DeviceA-security-policy-ip-4-untrust-trust] action pass
[DeviceA-security-policy-ip-4-untrust-trust] quit
[DeviceA-ipsec-transform-set-tran1] esp encryption-algorithm des
6.     Configure an IKE keychain to specify the key information used for IKE communication with peer 2.2.2.2.
[DeviceA] ike profile profile1
[DeviceA-ike-profile-profile1] quit
8.     Create an IPsec policy template named temp1. Specify IPsec transform set tran1 and IKE profile profile1 for the IPsec policy template.
9.     Configure IPsec RRI:
# Enable IPsec RRI, and set the preference to 100 and the tag to 1000 for the static routes created by IPsec RRI.
[DeviceA-ipsec-policy-template-temp1-1] reverse-route dynamic
[DeviceA-ipsec-policy-template-temp1-1] reverse-route preference 100
[DeviceA-ipsec-policy-template-temp1-1] reverse-route tag 1000
[DeviceA-ipsec-policy-template-temp1-1] quit
10.     Use IPsec policy template temp1 to create an IKE-based IPsec policy to establish an IPsec tunnel to protect the specified data.
11.     Configure an IKE proposal to specify the security parameters used for IKE negotiation.
# Create an IKE proposal named 1, and specify 3DES as the encryption algorithm, HMAC-SHA1 as the authentication algorithm, and pre-share as the authentication method.
[DeviceA] ike proposal 1
12.     Apply the IPsec policy to GigabitEthernet 1/0/1 to protect traffic on the interface.
[DeviceA-GigabitEthernet1/0/1] ipsec apply policy map1
[DeviceB-security-zone-Untrust] import interface gigabitethernet 1/0/1
[DeviceB-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceB-security-policy-ip-1-ipseclocalout] source-ip-host 1.1.1.1
[DeviceB-security-policy-ip-1-ipseclocalout] destination-ip-host 2.2.2.2
[DeviceB-security-policy-ip-2-ipseclocalin] source-ip-host 2.2.2.2
[DeviceB-security-policy-ip-2-ipseclocalin] destination-ip-host 1.1.1.1
5.     Configure an ACL to define the data flows to be protected by IPsec. IPsec RRI generates routes based on this ACL, too.
# Configure ACL 3000 to protect data from subnet 5.5.5.0/24 to subnet 4.4.4.0/24.
[DeviceB-ipsec-transform-set-tran1] esp encryption-algorithm des
The preshared key used by both sides of a communication must be the same.
9.     Configure an IKE-based IPsec policy to establish an IPsec tunnel to protect the specified data.
# Create an IKE-based IPsec policy entry named map1 and configure the following settings for the policy entry:
¡     Set the sequence number to 10.
¡     Specify transform set tran1 and ACL 3000.
¡     Specify the remote IP address for the tunnel as 1.1.1.1.
¡     Specify IKE profile profile1.
10.     Configure an IKE proposal to specify the security parameters for IKE negotiation.
[DeviceB] ike proposal 1
11.     Apply the IPsec policy to GigabitEthernet 1/0/1 to protect traffic on the interface.
Make sure Device B has a route to the peer private network, with the outgoing interface as GigabitEthernet 1/0/1.
Configuring Device C and Device D
Configure Device C and Device D in the same way Device B is configured.
1.     Verify that IPsec RRI can automatically create a static route from Device A to Device B:
# Initiate a connection from subnet 5.5.5.0/24 to subnet 4.4.4.0/24. IKE negotiation is triggered to establish IPsec SAs between Device A and Device B. (Details not shown.)
# Verify that IPsec SAs are established on Device A.
  IPsec policy: map1
  Sequence number: 10
  Alias: map1-10
  Mode: Template
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1463
    Tunnel:
        local  address/port: 1.1.1.1/500
        remote address/port: 2.2.2.2/500
    Flow:
    [Inbound ESP SAs]
      Connection ID: 1
      Transform set: ESP-ENCRYPT-DES-CBC ESP-AUTH-SHA1
      SA duration (kilobytes/sec): 1843200/3600
      Anti-replay check enable: Y
      Anti-replay window size: 64
      Status: Active
    [Outbound ESP SAs]
      Connection ID: 2
      Status: Active
# Verify that IPsec RRI has created a static route to reach Device B.
[DeviceA] display ip routing-table verbose
2.     Verify that Device A can automatically create static routes to Device C and Device D in the same way that you verify the IPsec RRI feature by using Device A and Device B. (Details not shown.)
Example: Configuring IPsec smart link selection
As shown in Figure 24, Device A acts the IPsec gateway of the branch. Device B is the IPsec gateway of the headquarters. Configure IPsec smart link selection so the branch can establish an IPsec tunnel to the headquarters over link 1 or link 2, whichever has a better link quality.
·     Device A first uses link 1 to establish the IPsec tunnel.
·     When link 1 suffers high packet loss ratio or delay, Device A automatically switches traffic to the IPsec tunnel established based on link 2.
Figure 24 Network diagram
1.     Configure the IP addresses and gateway addresses for GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2:
# Configure an IP address for GigabitEthernet 1/0/1 and specify the gateway address for the interface. This example uses 1.1.1.3 as the gateway address.
[DeviceA-GigabitEthernet1/0/1] ip address 1.1.1.1 24
[DeviceA-GigabitEthernet1/0/1] gateway 1.1.1.3
# Configure an IP address for GigabitEthernet 1/0/2 and specify the gateway address for the interface. This example uses 2.2.2.3 as the gateway address.
[DeviceA-GigabitEthernet1/0/2] ip address 2.2.2.2 24
[DeviceA-GigabitEthernet1/0/2] gateway 2.2.2.3
2.     Add interfaces to security zones.
[DeviceA-security-zone-Trust] import interface gigabitethernet 1/0/3
[DeviceA-security-zone-Untrust] import interface gigabitethernet 1/0/2
3.     Configure a security policy:
[DeviceA-security-policy-ip-1-ipseclocalout] source-ip-host 2.2.2.2
[DeviceA-security-policy-ip-1-ipseclocalout] destination-ip-host 3.3.3.3
[DeviceA-security-policy-ip-2-ipseclocalin] source-ip-host 3.3.3.3
[DeviceA-security-policy-ip-2-ipseclocalin] destination-ip-host 2.2.2.2
[DeviceA-security-policy-ip-3-trust-untrust] source-ip-subnet 10.1.1.0 24
[DeviceA-security-policy-ip-3-trust-untrust] destination-ip-subnet 10.1.2.0 24
[DeviceA-security-policy-ip-4-untrust-trust] source-ip-subnet 10.1.2.0 24
[DeviceA-security-policy-ip-4-untrust-trust] destination-ip-subnet 10.1.1.0 24
4.     Configure an IPsec smart link policy, so that the device can select a qualified link to establish an IPsec tunnel with the headquarters.
[DeviceA] ipsec smart-link policy policy1
[DeviceA-ipsec-smart-link-policy-policy1] link 1 interface gigabitethernet 1/0/1 remote 3.3.3.3
[DeviceA-ipsec-smart-link-policy-policy1] link 2 interface gigabitethernet 1/0/2 remote 3.3.3.3
[DeviceA-ipsec-smart-link-policy-policy1] link-switch cycles 4
[DeviceA-ipsec-smart-link-policy-policy1] smart-link enable
[DeviceA-ipsec-smart-link-policy-policy1] quit
[DeviceA-acl-ipv4-adv-3000] rule permit ip source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
The preshared key used by both sides of the communication must be the same.
[DeviceA] ike keychain keychain1
[DeviceA-ike-keychain-keychain1] pre-shared-key address 3.3.3.3 24 key simple 123456
[DeviceA-ike-keychain-keychain1] quit
[DeviceA-ike-profile-profile1] keychain keychain1
[DeviceA-ike-profile-profile1] match remote identity address 3.3.3.3 24
9.     Configure an IPsec policy, so as to establish the IPsec tunnel to protect data.
[DeviceA] ipsec policy policy1 10 isakmp
[DeviceA-ipsec-policy-isakmp-policy1-10] security acl 3000
[DeviceA-ipsec-policy-isakmp-policy1-10] transform-set tran1
[DeviceA-ipsec-policy-isakmp-policy1-10] ike-profile profile1
[DeviceA-ipsec-policy-isakmp-policy1-10] smart-link policy policy1
[DeviceA-ipsec-policy-isakmp-policy1-10] quit
1.     Assign an IP address to interface GigabitEthernet 1/0/1, and configure the gateway address. In this example, the gateway address is the direct next hop address 3.3.3.4.
[DeviceB-GigabitEthernet1/0/1] ip address 3.3.3.3 24
[DeviceB-GigabitEthernet1/0/1] gateway 3.3.3.4
[DeviceB-security-policy-ip-1-ipseclocalout] source-ip-host 3.3.3.3
[DeviceB-security-policy-ip-1-ipseclocalout] destination-ip-host 1.1.1.1
[DeviceB-security-policy-ip-2-ipseclocalin] source-ip-host 1.1.1.1
[DeviceB-security-policy-ip-2-ipseclocalin] destination-ip-host 3.3.3.3
[DeviceB-security-policy-ip-3-trust-untrust] source-ip-subnet 10.1.2.0 24
[DeviceB-security-policy-ip-3-trust-untrust] destination-ip-subnet 10.1.1.0 24
[DeviceB-security-policy-ip-4-untrust-trust] source-ip-subnet 10.1.1.0 24
[DeviceB-security-policy-ip-4-untrust-trust] destination-ip-subnet 10.1.2.0 24
4.     Configure an ACL to define the data flows to be protected by IPsec.
[DeviceB-acl-ipv4-adv-3000] rule permit ip source 10.1.2.0 0.0.0.255 destination 10.1.1.0 0.0.0.255
[DeviceB-acl-ipv4-adv-3000] rule permit ip source 3.3.3.0 0.0.0.255 destination 1.1.1.0 0.0.0.255
[DeviceB-acl-ipv4-adv-3000] rule permit ip source 3.3.3.0 0.0.0.255 destination 2.2.2.0 0.0.0.255
6.     Configure an IKE keychain to specify the key information used for IKE communication.
[DeviceB] ike keychain keychain1
[DeviceB-ike-keychain-keychain1] pre-shared-key address 0.0.0.0 0 key simple 123456
[DeviceB-ike-keychain-keychain1] quit
[DeviceB-ike-profile-profile1] keychain keychain1
[DeviceB-ike-profile-profile1] match remote identity address 0.0.0.0 0
8.     Configure an IPsec policy template, which is used to create IPsec policies.
[DeviceB] ipsec policy-template template1 10
[DeviceB-ipsec-policy-template-template1-10] security acl 3000
[DeviceB-ipsec-policy-template-template1-10] transform-set tran1
[DeviceB-ipsec-policy-template-template1-10] local-address 3.3.3.3
[DeviceB-ipsec-policy-template-template1-10] ike-profile profile1
[DeviceB-ipsec-policy-template-template1-10] quit
9.     Create an IKE-based IPsec policy by using IPsec policy template template1, so as to establish the IPsec tunnel to proctect data.
[DeviceB] ipsec policy policy1 10 isakmp template template1
10.     Apply the IPsec policy to GigabitEthernet 1/0/1 to protect traffic on the interface.
[DeviceB-GigabitEthernet1/0/1] ipsec apply policy policy1
# Display IPsec smart link policy information on Device A.
[DeviceA] display ipsec smart-link policy
Policy name                  : policy1
State                        :Enabled
Probe count                  :10
Probe interval               :1 sec
Probe source IP address      :1.1.1.1
Probe destination IP address :3.3.3.3
Max link switch cycles       :4
IPsec policy name            :policy1
Interface                    :GigabitEthernet1/0/1
IPsec policy sequence number :10
Link ID   Local address   Remote address   Loss(%)   Delay(ms)   State
1         1.1.1.1         3.3.3.3          0.0         1.0       Active
2         2.2.2.2         3.3.3.3          25.0        1.0       Inactive(Available)
# Display information about the IPsec policy to which IPsec smart link policy policy1 is applied.
[DeviceA] display ipsec policy
IPsec Policy: policy1
  Sequence number: 10
  Alias: map1-10
  Mode: ISAKMP
  Traffic Flow Confidentiality: Disabled
  Security data flow: 3000
  Selector mode: standard
  Local address: 1.1.1.1
  Remote address: 3.3.3.3
  Transform set:  tran1
  IKE profile: profile1
  IKEv2 profile:
  smart-link policy: policy1
  SA trigger mode: Auto
  SA duration(time based): 3600 seconds
  SA duration(traffic based): 1843200 kilobytes
  SA idle time: 100 seconds
  SA df-bit:
  Responder only: Disabled
# Display the ACL rules in the ACL used by IPsec policy policy1.
[DeviceA] display acl 3000
Advanced IPv4 ACL 3000, 3 rules,
ACL's step is 5
rule 0 permit ip source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
rule 5 permit ip source 1.1.1.0 0.0.0.255 destination 3.3.3.3 0 (Dynamic) (10 times matched)
The command output shows that an ACL rule (rule 5) is automatically added to permit the link quality probe packets.
[DeviceA]display ipsec sa
  IPsec policy: policy1
  Sequence number: 10
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1428
    Tunnel:
        remote address/port: 3.3.3.3/500
    Flow:
        sour addr: 1.1.1.0/255.255.255.0  port: 0  protocol: ip
        dest addr: 3.3.3.3/255.255.255.255  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 2443816215 (0x91a9ad17)
      Connection ID: 38654705665
      SA remaining duration (kilobytes/sec): 1843194/3368
      Max received sequence-number: 64
      Status: Active
    [Outbound ESP SAs]
      SPI: 4220315517 (0xfb8ce77d)
      Connection ID: 38654705664
      Max sent sequence-number: 64
      Status: Active
Example: Configuring IPsec in multiple VPN instances
As shown in Figure 25, establish an IPsec tunnel between Device A and Device B to protect data flows between subnet 10.1.1.0/24 and subnet 10.1.2.0/24. Configure the IPsec tunnel as follows:
·     Specify the encapsulation mode as tunnel, the security protocol as ESP, the encryption algorithm as 128-bit AES, and the authentication algorithm as HMAC-SHA1.
·     Set up SAs through IKE negotiation.
·     The internal port and external port of the devices belong to different VPN instances.
Figure 25 Network diagram
[DeviceA] ip vpn-instance vpn1
[DeviceA-vpn-instance-vpn1] route-distinguisher 100:1
[DeviceA-vpn-instance-vpn1] quit
[DeviceA-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[DeviceA-GigabitEthernet1/0/1] ip address 10.1.1.1 255.255.255.0
[DeviceA] ip vpn-instance vpn2
[DeviceA-vpn-instance-vpn2] route-distinguisher 100:2
[DeviceA-vpn-instance-vpn2] quit
[DeviceA-GigabitEthernet1/0/2] ip binding vpn-instance vpn2
[DeviceA-GigabitEthernet1/0/2] ip address 2.2.2.1 255.255.255.0
This example configures static routes, and the next hop in the routes is 2.2.2.2.
[DeviceA] ip route-static vpn-instance vpn1 10.1.2.0 24 vpn-instance vpn2 2.2.2.2
[DeviceA] ip route-static vpn-instance vpn2 2.2.3.1 24 2.2.2.2
[DeviceA-security-zone-Trust] import interface gigabitethernet 1/0/1
[DeviceA-security-policy-ip-1-ipseclocalout] source-ip-host 2.2.2.1
[DeviceA-security-policy-ip-1-ipseclocalout] destination-ip-host 2.2.3.1
[DeviceA-security-policy-ip-1-ipseclocalout] vrf vpn2
[DeviceA-security-policy-ip-2-ipseclocalin] source-ip-host 2.2.3.1
[DeviceA-security-policy-ip-2-ipseclocalin] destination-ip-host 2.2.2.1
[DeviceA-security-policy-ip-2-ipseclocalout] vrf vpn2
[DeviceA-security-policy-ip-3-ipseclocalout] vrf vpn1
[DeviceA-security-policy-ip-4-ipseclocalout] vrf vpn1
# Configure an IPv4 advanced ACL to identify data flows from subnet 10.1.1.0/24 to subnet 10.1.2.0/24.
[DeviceA] acl advanced 3101
[DeviceA-acl-ipv4-adv-3101] rule permit ip vpn-instance vpn1 source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
[DeviceA-acl-ipv4-adv-3101] quit
[DeviceA] ike keychain keychain1 vpn-instance vpn2
[DeviceA-ike-keychain-keychain1] pre-shared-key address 2.2.3.1 255.255.255.0 key simple 123456TESTplat&!
[DeviceA-ike-profile-profile1] match remote identity address 2.2.3.1 255.255.255.0 vpn-instance vpn2
[DeviceA-ike-profile-profile1] inside-vpn vpn-instance vpn1
[DeviceA-ipsec-policy-isakmp-map1-10] security acl 3101
[DeviceA-ipsec-policy-isakmp-map1-10] transform-set tran1
[DeviceA-ipsec-policy-isakmp-map1-10] local-address 2.2.2.1
[DeviceA-ipsec-policy-isakmp-map1-10] remote-address 2.2.3.1
[DeviceA-ipsec-policy-isakmp-map1-10] ike-profile profile1
[DeviceA-ipsec-policy-isakmp-map1-10] quit
10.     Apply the IPsec policy to GigabitEthernet 1/0/2 to protect traffic on the interface.
[DeviceA-GigabitEthernet1/0/2] ipsec apply policy map1
[DeviceB] ip vpn-instance vpn1
[DeviceB-vpn-instance-vpn1] route-distinguisher 200:1
[DeviceB-vpn-instance-vpn1] quit
[DeviceB-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[DeviceB-GigabitEthernet1/0/1] ip address 10.1.2.1 255.255.255.0
[DeviceB] ip vpn-instance vpn2
[DeviceB-vpn-instance-vpn2] route-distinguisher 200:2
[DeviceB-vpn-instance-vpn2] quit
[DeviceB-GigabitEthernet1/0/2] ip binding vpn-instance vpn2
[DeviceB-GigabitEthernet1/0/2] ip address 2.2.3.1 255.255.255.0
This example configures static routes, and the next hop in the routes is 2.2.3.2.
[DeviceB] ip route-static vpn-instance vpn1 10.1.1.0 24 vpn-instance vpn2 2.2.3.2
[DeviceB] ip route-static vpn-instance vpn2 2.2.2.1 24 2.2.3.2
[DeviceB-security-zone-Trust] import interface gigabitethernet 1/0/1
[DeviceB-security-zone-Untrust] import interface gigabitethernet 1/0/2
[DeviceB-security-policy-ip-1-ipseclocalout] source-ip-host 2.2.3.1
[DeviceB-security-policy-ip-1-ipseclocalout] destination-ip-host 2.2.2.1
[DeviceB-security-policy-ip-1-ipseclocalout] vrf vpn2
[DeviceB-security-policy-ip-2-ipseclocalin] source-ip-host 2.2.2.1
[DeviceB-security-policy-ip-2-ipseclocalin] destination-ip-host 2.2.3.1
[DeviceB-security-policy-ip-2-ipseclocalout] vrf vpn2
[DeviceB-security-policy-ip-3-ipseclocalout] vrf vpn1
[DeviceB-security-policy-ip-4-ipseclocalout] vrf vpn1
# Configure an IPv4 advanced ACL to identify data flows from subnet 10.1.2.0/24 to subnet 10.1.1.0/24.
[DeviceB] acl advanced 3101
[DeviceB-acl-ipv4-adv-3101] rule permit ip vpn-instance vpn1 source 10.1.2.0 0.0.0.255 destination 10.1.1.0 0.0.0.255
[DeviceB-acl-ipv4-adv-3101] quit
[DeviceB] ike keychain keychain1 vpn-instance vpn2
[DeviceB-ike-keychain-keychain1] pre-shared-key address 2.2.2.1 255.255.255.0 key simple 123456TESTplat&!
[DeviceB-ike-profile-profile1] match remote identity address 2.2.2.1 255.255.255.0 vpn-instance vpn2
[DeviceB-ike-profile-profile1] inside-vpn vpn-instance vpn1
[DeviceB] ipsec policy use1 10 isakmp
[DeviceB-ipsec-policy-isakmp-use1-10] security acl 3101
[DeviceB-ipsec-policy-isakmp-use1-10] transform-set tran1
[DeviceB-ipsec-policy-isakmp-use1-10] local-address 2.2.3.1
[DeviceB-ipsec-policy-isakmp-use1-10] remote-address 2.2.2.1
[DeviceB-ipsec-policy-isakmp-use1-10] ike-profile profile1
[DeviceB-ipsec-policy-isakmp-use1-10] quit
[DeviceB-GigabitEthernet1/0/2] ipsec apply policy use1
# Initiate a connection from subnet 10.1.1.0/24 to subnet 10.1.2.0/24 to trigger IKE negotiation. After IPsec SAs are successfully negotiated by IKE, the traffic between the two subnets is IPsec-protected.
# Display IPsec SAs on Device A and Device B. This example uses Device A to verify the configuration.
  IPsec policy: map1
  Sequence number: 10
  Alisa: map1-10
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN: vpn1
    Path MTU: 1443
    Tunnel:
        local  address/port: 2.2.3.1/500
        remote address/port: 2.2.2.1/500
    Flow:
        sour addr: 10.1.1.0/255.255.255.0  port: 0  protocol: ip
        dest addr: 10.1.2.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 3769702703 (0xe0b1192f)
      Connection ID: 90194313219
      SA remaining duration (kilobytes/sec): 2300/797
      Max received sequence-number: 1
      Status: Active
    [Outbound ESP SAs]
      SPI: 3840956402 (0xe4f057f2)
      Connection ID: 64424509441
      SA remaining duration (kilobytes/sec): 2312/797
      Max sent sequence-number: 1
      Status: Active
Example: Configuring headquarters to use dual links to establish IPsec tunnels with branches
As shown in Figure 26, the headquarters gateway device Device A has two links connected to the Internet. Branch gateway devices Device B and Device C each has one link connected to the Internet.
Configure IPsec tunnel interface-based IPsec on the devices protect the traffic between the headquarters and the branches.
The headquarters and the branches select high-quality, low-latency links based on the NQA test results to dynamically establish IPsec tunnels.
Figure 26 Network diagram
2.     Create IPsec tunnel interfaces:
# Create IPsec tunnel interface Tunnel 0.
[DeviceA] interface tunnel 0 mode ipsec
[DeviceA-Tunnel0] ip address 10.0.0.1 255.255.255.0
[DeviceA-Tunnel0] source 1.1.1.1
[DeviceA-Tunnel0] destination 3.3.3.3
[DeviceA-Tunnel0] quit
# Create IPsec tunnel interface Tunnel 1.
[DeviceA] interface tunnel 1 mode ipsec
[DeviceA-Tunnel1] ip address 20.0.0.1 255.255.255.0
[DeviceA-Tunnel1] source 2.2.2.2
[DeviceA-Tunnel1] destination 3.3.3.3
[DeviceA-Tunnel1] quit
# Create IPsec tunnel interface Tunnel 2.
[DeviceA] interface tunnel 2 mode ipsec
[DeviceA-Tunnel2] ip address 30.0.0.1 255.255.255.0
[DeviceA-Tunnel2] source 1.1.1.1
[DeviceA-Tunnel2] destination 4.4.4.4
[DeviceA-Tunnel2] quit
# Create IPsec tunnel interface Tunnel 3.
[DeviceA] interface tunnel 3 mode ipsec
[DeviceA-Tunnel3] ip address 40.0.0.1 255.255.255.0
[DeviceA-Tunnel3] source 2.2.2.2
[DeviceA-Tunnel3] destination 4.4.4.4
[DeviceA-Tunnel3] quit
[DeviceA-security-zone-Untrust] import interface tunnel 0
[DeviceA-security-zone-Untrust] import interface tunnel 1
[DeviceA-security-zone-Untrust] import interface tunnel 2
[DeviceA-security-zone-Untrust] import interface tunnel 3
# Configure a rule named ipseclocalout to allow Device A to send IPsec negotiation packets to Device B and Device C.
[DeviceA-security-policy-ip-1-ipseclocalout] destination-ip-host 4.4.4.4
# Configure a rule named ipseclocalin to allow Device A to receive the IPsec negotiation packets sent from Device B and Device C.
[DeviceA-security-policy-ip-2-ipseclocalin] source-ip-host 4.4.4.4
b.     Configure rules to permit the traffic between Host A and Host B and between Host A and Host C:
# Configure a rule named trust-untrust to permit the packets from Host A to Host B and Host C.
[DeviceA-security-policy-ip-3-trust-untrust] source-ip-subnet 192.168.11.0 24
[DeviceA-security-policy-ip-3-trust-untrust] destination-ip-subnet 192.168.12.0 24
[DeviceA-security-policy-ip-3-trust-untrust] destination-ip-subnet 192.168.13.0 24
# Configure a rule named untrust-trust to permit the packets from Host B and Host C to Host A.
[DeviceA-security-policy-ip-4-untrust-trust] source-ip-subnet 192.168.12.0 24
[DeviceA-security-policy-ip-4-untrust-trust] source-ip-subnet 192.168.13.0 24
[DeviceA-security-policy-ip-4-untrust-trust] destination-ip-subnet 192.168.11.0 24
5.     Configure IPsec profiles to establish IPsec tunnels to protect the specified data:
# Configure IPsec profile t0.
[DeviceA] ike keychain t0
[DeviceA-ike-keychain-t0] pre-shared-key address 3.3.3.3 255.255.255.0 key simple 123456TESTplat&!
[DeviceA-ike-keychain-t0] quit
[DeviceA] ike profile t0
[DeviceA-ike-profile-t0] keychain t0
[DeviceA-ike-profile-t0] match local address Tunnel0
[DeviceA-ike-profile-t0] match remote identity address 3.3.3.3 24
[DeviceA-ike-profile-t0] exchange-mode aggressive
[DeviceA-ike-profile-t0] dpd interval 30 periodic
[DeviceA-ike-profile-t0] quit
[DeviceA] ipsec transform-set t0
[DeviceA-ipsec-transform-set-t0] esp encryption-algorithm aes-cbc-128
[DeviceA-ipsec-transform-set-t0] esp authentication-algorithm sha1
[DeviceA-ipsec-transform-set-t0] quit
[DeviceA] ipsec profile t0 isakmp
[DeviceA-ipsec-profile-isakmp-t0] transform-set t0
[DeviceA-ipsec-profile-isakmp-t0] ike-profile t0
[DeviceA-ipsec-profile-isakmp-t0] quit
# Configure IPsec profile t1.
[DeviceA] ike keychain t1
[DeviceA-ike-keychain-t1] pre-shared-key address 3.3.3.3 255.255.255.0 key simple 123456TESTplat&!
[DeviceA-ike-keychain-t1] quit
[DeviceA] ike profile t1
[DeviceA-ike-profile-t1] keychain t1
[DeviceA-ike-profile-t1] match local address Tunnel1
[DeviceA-ike-profile-t1] match remote identity address 3.3.3.3 24
[DeviceA-ike-profile-t1] exchange-mode aggressive
[DeviceA-ike-profile-t1] dpd interval 30 periodic
[DeviceA-ike-profile-t1] quit
[DeviceA] ipsec transform-set t1
[DeviceA-ipsec-transform-set-t1] esp encryption-algorithm aes-cbc-128
[DeviceA-ipsec-transform-set-t1] esp authentication-algorithm sha1
[DeviceA-ipsec-transform-set-t1] quit
[DeviceA] ipsec profile t1 isakmp
[DeviceA-ipsec-profile-isakmp-t1] transform-set t1
[DeviceA-ipsec-profile-isakmp-t1] ike-profile t1
[DeviceA-ipsec-profile-isakmp-t1] quit
# Configure IPsec profile t2.
[DeviceA] ike keychain t2
[DeviceA-ike-keychain-t2] pre-shared-key address 4.4.4.4 255.255.255.0 key simple 123456TESTplat&!
[DeviceA-ike-keychain-t2] quit
[DeviceA] ike profile t2
[DeviceA-ike-profile-t2] keychain t2
[DeviceA-ike-profile-t2] match local address Tunnel2
[DeviceA-ike-profile-t2] match remote identity address 4.4.4.4 24
[DeviceA-ike-profile-t2] exchange-mode aggressive
[DeviceA-ike-profile-t2] dpd interval 30 periodic
[DeviceA-ike-profile-t2] quit
[DeviceA] ipsec transform-set t2
[DeviceA-ipsec-transform-set-t2] esp encryption-algorithm aes-cbc-128
[DeviceA-ipsec-transform-set-t2] esp authentication-algorithm sha1
[DeviceA-ipsec-transform-set-t2] quit
[DeviceA] ipsec profile t2 isakmp
[DeviceA-ipsec-profile-isakmp-t2] transform-set t2
[DeviceA-ipsec-profile-isakmp-t2] ike-profile t2
[DeviceA-ipsec-profile-isakmp-t2] quit
# Configure IPsec profile t3.
[DeviceA] ike keychain t3
[DeviceA-ike-keychain-t3] pre-shared-key address 4.4.4.4 255.255.255.0 key simple 123456TESTplat&!
[DeviceA-ike-keychain-t3] quit
[DeviceA] ike profile t3
[DeviceA-ike-profile-t3] keychain t3
[DeviceA-ike-profile-t3] match local address Tunnel3
[DeviceA-ike-profile-t3] match remote identity address 4.4.4.4 24
[DeviceA-ike-profile-t3] exchange-mode aggressive
[DeviceA-ike-profile-t3] dpd interval 30 periodic
[DeviceA-ike-profile-t3] quit
[DeviceA] ipsec transform-set t3
[DeviceA-ipsec-transform-set-t3] esp encryption-algorithm aes-cbc-128
[DeviceA-ipsec-transform-set-t3] esp authentication-algorithm sha1
[DeviceA-ipsec-transform-set-t3] quit
[DeviceA] ipsec profile t3 isakmp
[DeviceA-ipsec-profile-isakmp-t3] transform-set t3
[DeviceA-ipsec-profile-isakmp-t3] ike-profile t3
[DeviceA-ipsec-profile-isakmp-t3] quit
6.     Configure IPsec tunnel interfaces, which encapsulate the traffic to be protected with IPsec.
# Configure IPsec tunnel interface Tunnel 0 to use IPsec profile t0 to establish an IPsec tunnel.
[DeviceA-Tunnel0] tunnel protection ipsec profile t0
# Configure IPsec tunnel interface Tunnel 1 to use IPsec profile t1 to establish an IPsec tunnel.
[DeviceA-Tunnel1] tunnel protection ipsec profile t1
# Configure IPsec tunnel interface Tunnel 2 to use IPsec profile t2 to establish an IPsec tunnel.
[DeviceA-Tunnel2] tunnel protection ipsec profile t2
# Configure IPsec tunnel interface Tunnel 3 to use IPsec profile t3 to establish an IPsec tunnel.
[DeviceA-Tunnel3] tunnel protection ipsec profile t3
7.     Configure NQA operation and Track collaboration to probe the status of links:
# Configure NQA operation with administrator name admin and operation tag test1.
[DeviceA] nqa entry admin test1
[DeviceA-nqa-admin-test1] type icmp-echo
[DeviceA-nqa-admin-test1-icmp-echo] destination ip 3.3.3.3
[DeviceA-nqa-admin-test1-icmp-echo] frequency 3000
[DeviceA-nqa-admin-test1-icmp-echo] history-record enable
[DeviceA-nqa-admin-test1-icmp-echo] next-hop ip 1.1.1.2
[DeviceA-nqa-admin-test1-icmp-echo] probe count 5
[DeviceA-nqa-admin-test1-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
[DeviceA-nqa-admin-test1-icmp-echo] quit
[DeviceA] nqa schedule admin test1 start-time now lifetime forever
# Create track entry 110 and associate it with reaction entry 1 of NQA operation admin-test1.
[DeviceA] track 110 nqa entry admin test1 reaction 1
[DeviceA-track-110] quit
# Configure NQA operation with administrator name admin and operation tag test2.
[DeviceA] nqa entry admin test2
[DeviceA-nqa-admin-test2] type icmp-echo
[DeviceA-nqa-admin-test2-icmp-echo] destination ip 3.3.3.3
[DeviceA-nqa-admin-test2-icmp-echo] frequency 3000
[DeviceA-nqa-admin-test2-icmp-echo] history-record enable
[DeviceA-nqa-admin-test2-icmp-echo] probe count 5
[DeviceA-nqa-admin-test2-icmp-echo] next-hop ip 2.2.2.3
[DeviceA-nqa-admin-test2-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
[DeviceA-nqa-admin-test2-icmp-echo] quit
[DeviceA] nqa schedule admin test2 start-time now lifetime forever
# Create track entry 120 and associate it with reaction entry 1 of NQA operation admin-test2.
[DeviceA] track 120 nqa entry admin test2 reaction 1
[DeviceA-track-120] quit
# Configure NQA operation with administrator name admin and operation tag test3.
[DeviceA] nqa entry admin test3
[DeviceA-nqa-admin-test3] type icmp-echo
[DeviceA-nqa-admin-test3-icmp-echo] destination ip 4.4.4.4
[DeviceA-nqa-admin-test3-icmp-echo] frequency 3000
[DeviceA-nqa-admin-test3-icmp-echo] history-record enable
[DeviceA-nqa-admin-test3-icmp-echo] probe count 5
[DeviceA-nqa-admin-test3-icmp-echo] next-hop ip 1.1.1.2
[DeviceA-nqa-admin-test3-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
[DeviceA-nqa-admin-test3-icmp-echo] quit
[DeviceA] nqa schedule admin test3 start-time now lifetime forever
# Create track entry 130 and associate it with reaction entry 1 of NQA operation admin-test3.
[DeviceA] track 130 nqa entry admin test3 reaction 1
[DeviceA-track-130] quit
# Configure NQA operation with administrator name admin and operation tag test4.
[DeviceA] nqa entry admin test4
[DeviceA-nqa-admin-test4] type icmp-echo
[DeviceA-nqa-admin-test4-icmp-echo] destination ip 4.4.4.4
[DeviceA-nqa-admin-test4-icmp-echo] frequency 3000
[DeviceA-nqa-admin-test4-icmp-echo] history-record enable
[DeviceA-nqa-admin-test4-icmp-echo] probe count 5
[DeviceA-nqa-admin-test4-icmp-echo] next-hop ip 2.2.2.3
[DeviceA-nqa-admin-test4-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
[DeviceA-nqa-admin-test4-icmp-echo] quit
[DeviceA] nqa schedule admin test4 start-time now lifetime forever
# Create track entry 140 and associate it with reaction entry 1 of NQA operation admin-test4.
[DeviceA] track 140 nqa entry admin test4 reaction 1
[DeviceA-track-140] quit
8.     Configure settings for routing.
This example configures static routes.
# Configure static routes to direct the traffic to be protected to the IPsec tunnel interfaces. Configure static routes to reach the branches' gateways and the next hops in the routes are 1.1.1.2 and 2.2.2.3.
[DeviceA] ip route-static 192.168.12.0 24 tunnel 0 track 110 preference 100
[DeviceA] ip route-static 192.168.12.0 24 tunnel 1 track 120 preference 110
[DeviceA] ip route-static 192.168.13.0 24 tunnel 2 track 130 preference 100
[DeviceA] ip route-static 192.168.13.0 24 tunnel 3 track 140 preference 110
[DeviceA] ip route-static 3.3.3.3 24 1.1.1.2 track 110 preference 100
[DeviceA] ip route-static 3.3.3.3 24 2.2.2.3 track 120 preference 110
[DeviceA] ip route-static 4.4.4.4 24 1.1.1.2 track 130 preference 100
[DeviceA] ip route-static 4.4.4.4 24 2.2.2.3 track 140 preference 110
[DeviceB-GigabitEthernet1/0/1] ip address 3.3.3.3 255.255.255.0
[DeviceB] interface tunnel 0 mode ipsec
[DeviceB-Tunnel0] ip address 50.0.0.1 255.255.255.0
[DeviceB-Tunnel0] source 3.3.3.3
[DeviceB-Tunnel0] destination 1.1.1.1
[DeviceB-Tunnel0] quit
[DeviceB] interface tunnel 1 mode ipsec
[DeviceB-Tunnel1] ip address 60.0.0.1 255.255.255.0
[DeviceB-Tunnel1] source 3.3.3.3
[DeviceB-Tunnel1] destination 2.2.2.2
[DeviceB-Tunnel1] quit
[DeviceB-security-zone-Untrust] import interface tunnel 0
[DeviceB-security-zone-Untrust] import interface tunnel 1
[DeviceB] security-policy ip
b.     Configure rules to permit the traffic between Host B and Host A:
[DeviceB-security-policy-ip-3-trust-untrust] source-ip-subnet 192.168.12.0 24
[DeviceB-security-policy-ip-3-trust-untrust] destination-ip-subnet 192.168.11.0 24
[DeviceB-security-policy-ip-4-untrust-trust] source-ip-subnet 192.168.11.0 24
[DeviceB-security-policy-ip-4-untrust-trust] destination-ip-subnet 192.168.12.0 24
[DeviceB] ike keychain t0
[DeviceB-ike-keychain-t0] pre-shared-key address 1.1.1.1 255.255.255.0 key simple 123456TESTplat&!
[DeviceB-ike-keychain-t0] quit
[DeviceB] ike profile t0
[DeviceB-ike-profile-t0] keychain t0
[DeviceB-ike-profile-t0] match local address Tunnel0
[DeviceB-ike-profile-t0] match remote identity address 1.1.1.1 24
[DeviceB-ike-profile-t0] exchange-mode aggressive
[DeviceB-ike-profile-t0] dpd interval 30 periodic
[DeviceB-ike-profile-t0] quit
[DeviceB] ipsec transform-set t0
[DeviceB-ipsec-transform-set-t0] esp encryption-algorithm aes-cbc-128
[DeviceB-ipsec-transform-set-t0] esp authentication-algorithm sha1
[DeviceB-ipsec-transform-set-t0] quit
[DeviceB] ipsec profile t0 isakmp
[DeviceB-ipsec-profile-isakmp-t0] transform-set t0
[DeviceB-ipsec-profile-isakmp-t0] ike-profile t0
[DeviceB-ipsec-profile-isakmp-t0] quit
[DeviceB] ike keychain t1
[DeviceB-ike-keychain-t1] pre-shared-key address 2.2.2.2 255.255.255.0 key simple 123456TESTplat&!
[DeviceB-ike-keychain-t1] quit
[DeviceB] ike profile t1
[DeviceB-ike-profile-t1] keychain t1
[DeviceB-ike-profile-t1] match local address Tunnel1
[DeviceB-ike-profile-t1] match remote identity address 2.2.2.2 24
[DeviceB-ike-profile-t1] exchange-mode aggressive
[DeviceB-ike-profile-t1] dpd interval 30 periodic
[DeviceB-ike-profile-t1] quit
[DeviceB] ipsec transform-set t1
[DeviceB-ipsec-transform-set-t1] esp encryption-algorithm aes-cbc-128
[DeviceB-ipsec-transform-set-t1] esp authentication-algorithm sha1
[DeviceB-ipsec-transform-set-t1] quit
[DeviceB] ipsec profile t1 isakmp
[DeviceB-ipsec-profile-isakmp-t1] transform-set t1
[DeviceB-ipsec-profile-isakmp-t1] ike-profile t1
[DeviceB-ipsec-profile-isakmp-t1] quit
[DeviceB-Tunnel0] tunnel protection ipsec profile t0
[DeviceB-Tunnel1] tunnel protection ipsec profile t1
[DeviceB] nqa entry admin test1
[DeviceB-nqa-admin-test1] type icmp-echo
[DeviceB-nqa-admin-test1-icmp-echo] destination ip 1.1.1.1
[DeviceB-nqa-admin-test1-icmp-echo] frequency 3000
[DeviceB-nqa-admin-test1-icmp-echo] history-record enable
[DeviceB-nqa-admin-test1-icmp-echo] probe count 5
[DeviceB-nqa-admin-test1-icmp-echo] next-hop ip 3.3.3.4
[DeviceB-nqa-admin-test1-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
[DeviceB-nqa-admin-test1-icmp-echo] quit
[DeviceB] nqa schedule admin test1 start-time now lifetime forever
[DeviceB] track 110 nqa entry admin test1 reaction 1
[DeviceB-track-110] quit
[DeviceB] nqa entry admin test2
[DeviceB-nqa-admin-test2] type icmp-echo
[DeviceB-nqa-admin-test2-icmp-echo] destination ip 2.2.2.2
[DeviceB-nqa-admin-test2-icmp-echo] frequency 3000
[DeviceB-nqa-admin-test2-icmp-echo] history-record enable
[DeviceB-nqa-admin-test2-icmp-echo] probe count 5
[DeviceB-nqa-admin-test2-icmp-echo] next-hop ip 3.3.3.4
[DeviceB-nqa-admin-test2-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
[DeviceB-nqa-admin-test2-icmp-echo] quit
[DeviceB] nqa schedule admin test2 start-time now lifetime forever
[DeviceB] track 120 nqa entry admin test2 reaction 1
[DeviceB-track-120] quit
# Configure static routes to direct the traffic to be protected to the IPsec tunnel interfaces. Configure static routes to reach the headquarters' gateway and the next hop in the routes is 3.3.3.4.
[DeviceB] ip route-static 192.168.11.0 24 tunnel 0 track 110 preference 100
[DeviceB] ip route-static 192.168.11.0 24 tunnel 1 track 120 preference 110
[DeviceB] ip route-static 1.1.1.1 24 3.3.3.4
[DeviceB] ip route-static 2.2.2.2 24 3.3.3.4
1.     Assign IP addresses to interfaces:
# Assign an IP address to interface GigabitEthernet 1/0/1.
[DeviceC-GigabitEthernet1/0/1] ip address 4.4.4.4 255.255.255.0
[DeviceC] interface tunnel 0 mode ipsec
[DeviceC-Tunnel0] ip address 70.0.0.1 255.255.255.0
[DeviceC-Tunnel0] source 4.4.4.4
[DeviceC-Tunnel0] destination 1.1.1.1
[DeviceC-Tunnel0] quit
[DeviceC] interface tunnel 1 mode ipsec
[DeviceC-Tunnel1] ip address 80.0.0.1 255.255.255.0
[DeviceC-Tunnel1] source 4.4.4.4
[DeviceC-Tunnel1] destination 2.2.2.2
[DeviceC-Tunnel1] quit
3.     Add interfaces to security zones.
[DeviceC-security-zone-Untrust] import interface tunnel 0
[DeviceC-security-zone-Untrust] import interface tunnel 1
4.     Configure a security policy:
a.     Configure rules to permit traffic between the Untrust and Local security zones, so the devices can set up an IPsec tunnel:
[DeviceC-security-policy-ip-1-ipseclocalout] source-ip-host 4.4.4.4
[DeviceC-security-policy-ip-1-ipseclocalout] destination-ip-host 2.2.2.2
[DeviceC-security-policy-ip-2-ipseclocalin] source-ip-host 2.2.2.2
[DeviceC-security-policy-ip-2-ipseclocalin] destination-ip-host 4.4.4.4
b.     Configure rules to permit the traffic between Host C and Host A:
[DeviceC-security-policy-ip-3-trust-untrust] source-ip-subnet 192.168.13.0 24
[DeviceC-security-policy-ip-3-trust-untrust] destination-ip-subnet 192.168.11.0 24
[DeviceC-security-policy-ip-4-untrust-trust] source-ip-subnet 192.168.11.0 24
[DeviceC-security-policy-ip-4-untrust-trust] destination-ip-subnet 192.168.13.0 24
[DeviceC] ike keychain t0
[DeviceC-ike-keychain-t0] pre-shared-key address 1.1.1.1 255.255.255.0 key simple 123456TESTplat&!
[DeviceC-ike-keychain-t0] quit
[DeviceC] ike profile t0
[DeviceC-ike-profile-t0] keychain t0
[DeviceC-ike-profile-t0] match local address Tunnel0
[DeviceC-ike-profile-t0] match remote identity address 1.1.1.1 24
[DeviceC-ike-profile-t0] exchange-mode aggressive
[DeviceC-ike-profile-t0] dpd interval 30 periodic
[DeviceC-ike-profile-t0] quit
[DeviceC] ipsec transform-set t0
[DeviceC-ipsec-transform-set-t0] esp encryption-algorithm aes-cbc-128
[DeviceC-ipsec-transform-set-t0] esp authentication-algorithm sha1
[DeviceC-ipsec-transform-set-t0] quit
[DeviceC] ipsec profile t0 isakmp
[DeviceC-ipsec-profile-isakmp-t0] transform-set t0
[DeviceC-ipsec-profile-isakmp-t0] ike-profile t0
[DeviceC-ipsec-profile-isakmp-t0] quit
[DeviceC] ike keychain t1
[DeviceC-ike-keychain-t1] pre-shared-key address 2.2.2.2 255.255.255.0 key simple 123456TESTplat&!
[DeviceC-ike-keychain-t1] quit
[DeviceC] ike profile t1
[DeviceC-ike-profile-t1] keychain t1
[DeviceC-ike-profile-t1] match local address Tunnel1
[DeviceC-ike-profile-t1] match remote identity address 2.2.2.2 24
[DeviceC-ike-profile-t1] exchange-mode aggressive
[DeviceC-ike-profile-t1] dpd interval 30 periodic
[DeviceC-ike-profile-t1] quit
[DeviceC] ipsec transform-set t1
[DeviceC-ipsec-transform-set-t1] esp encryption-algorithm aes-cbc-128
[DeviceC-ipsec-transform-set-t1] esp authentication-algorithm sha1
[DeviceC-ipsec-transform-set-t1] quit
[DeviceC] ipsec profile t1 isakmp
[DeviceC-ipsec-profile-isakmp-t1] transform-set t1
[DeviceC-ipsec-profile-isakmp-t1] ike-profile t1
[DeviceC-ipsec-profile-isakmp-t1] quit
[DeviceC-Tunnel0] tunnel protection ipsec profile t0
[DeviceC-Tunnel1] tunnel protection ipsec profile t1
[DeviceC] nqa entry admin test1
[DeviceC-nqa-admin-test1] type icmp-echo
[DeviceC-nqa-admin-test1-icmp-echo] destination ip 1.1.1.1
[DeviceC-nqa-admin-test1-icmp-echo] frequency 3000
[DeviceC-nqa-admin-test1-icmp-echo] history-record enable
[DeviceC-nqa-admin-test1-icmp-echo] probe count 5
[DeviceC-nqa-admin-test1-icmp-echo] next-hop ip 4.4.4.5
[DeviceC-nqa-admin-test1-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
[DeviceC-nqa-admin-test1-icmp-echo] quit
[DeviceC] nqa schedule admin test1 start-time now lifetime forever
[DeviceC] track 110 nqa entry admin test1 reaction 1
[DeviceC-track-110] quit
[DeviceC] nqa entry admin test2
[DeviceC-nqa-admin-test2] type icmp-echo
[DeviceC-nqa-admin-test2-icmp-echo] destination ip 2.2.2.2
[DeviceC-nqa-admin-test2-icmp-echo] frequency 3000
[DeviceC-nqa-admin-test2-icmp-echo] history-record enable
[DeviceC-nqa-admin-test2-icmp-echo] probe count 5
[DeviceC-nqa-admin-test2-icmp-echo] next-hop ip 4.4.4.5
[DeviceC-nqa-admin-test2-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
[DeviceC-nqa-admin-test2-icmp-echo] quit
[DeviceC] nqa schedule admin test2 start-time now lifetime forever
[DeviceC] track 120 nqa entry admin test2 reaction 1
[DeviceC-track-120] quit
# Configure static routes to direct the traffic to be protected to the IPsec tunnel interfaces. Configure static routes to reach the headquarters' gateway and the next hop in the routes is 4.4.4.5.
[DeviceC] ip route-static 192.168.11.0 24 tunnel 0 track 110 preference 100
[DeviceC] ip route-static 192.168.11.0 24 tunnel 1 track 120 preference 110
[DeviceC] ip route-static 1.1.1.1 24 4.4.4.5
[DeviceC] ip route-static 2.2.2.2 24 4.4.4.5
After the configuration is completed, Device A will automatically initiate IKE negotiation with Device B and Device C. After IKE negotiation succeeds, the tunnel interfaces on the devices will come up and traffic between the branch and the headquarters will be IPsec-protected. This example uses Device A to verify the configuration.
# Display brief IP configuration for interfaces on Device A.
<DeviceA> display ip interface brief
*down: administratively down
(s): spoofing  (l): loopback
Interface           Physical Protocol IP address/Mask    VPN instance Description
GE1/0/1             up       up       1.1.1.1/24          --           --
GE1/0/2             up       up       2.2.2.2/24          --           --
GE1/0/3             up       up       192.168.11.1/24     --           --
Tun0                up       up       10.0.0.1/24         --           --
Tun1                up       up       20.0.0.1/24         --           --
Tun2                up       up       30.0.0.1/24         --           --
Tun3                up       up       40.0.0.1/24         --           --
# Display routing information o Device A.
<DeviceA> display ip routing-table
Destinations : 14        Routes : 14
1.1.1.0/24         Direct  0   0           1.1.1.1         GE1/0/1
1.1.1.255/32       Direct  0   0           1.1.1.1         GE1/0/1
2.2.2.0/24         Direct  0   0           2.2.2.2         GE1/0/2
2.2.2.255/32       Direct  0   0           2.2.2.2         GE1/0/2
3.3.3.0/24         Static  100 0           1.1.1.2         GE1/0/1
4.4.4.0/24         Static  100 0           1.1.1.2         GE1/0/1
10.0.0.0/24        Direct  0   0           10.0.0.1        Tun0
10.0.0.255/32      Direct  0   0           10.0.0.1        Tun0
20.0.0.0/24        Direct  0   0           20.0.0.1        Tun1
20.0.0.255/32      Direct  0   0           20.0.0.1        Tun1
192.168.11.0/24    Direct  0   0           192.168.11.1    GE1/0/3
192.168.11.255/32  Direct  0   0           192.168.11.1    GE1/0/3
192.168.12.0/24    Static  100 0           0.0.0.0         Tun0
192.168.13.0/24    Static  100 0           0.0.0.0         Tun2
# Verify that Host A can ping Host B. IPsec traffic is transmitted over the link of Tunnel 0.
C:\Users\hosta> ping 192.168.12.2
# After the link connected to GigabitEthernet 1/0/1 of Device A fails, Host A still can ping Host B. The IPsec traffic transmitted over the link of Tunnel 1.
# Display interface status information on Device A.
GE1/0/1             down     down     1.1.1.1/24          --           --
Tun0                down     down     10.0.0.1/24         --           --
Tun2                down     down     30.0.0.1/24         --           --
# Display routing information on Device A.
Destinations : 10        Routes : 10
3.3.3.0/24         Static  110 0           2.2.2.3         GE1/0/2
4.4.4.0/24         Static  110 0           2.2.2.3         GE1/0/2
192.168.12.0/24    Static  110 0           0.0.0.0         Tun1
192.168.13.0/24    Static  110 0           0.0.0.0         Tun3
# After the link connected to GigabitEthernet 1/0/1 of Device A recovers, IPsec traffic is switched back to the link of Tunnel 0.
Example: Configuring IPsec tunnel interface-based IPsec for IPv4 packets
As shown in Figure 27, both the branch and the headquarters use fixed IP addresses to access the Internet.
Configure IPsec tunnel interface-based IPsec on Device A and Device B to protect the traffic between the branch (10.1.1.0/24) and the headquarters (10.1.2.0/24). This IPsec implementation ensures that the IPsec configuration of the headquarters remains stable despite of changes of the branch subnet.
Figure 27 Network diagram
Configuring Device A
2.     Create IPsec tunnel interface Tunnel1.
[DeviceA-Tunnel1] ip address 3.3.3.1 255.255.255.0
[DeviceA-Tunnel1] source 2.2.2.1
[DeviceA-Tunnel1] destination 2.2.3.1
3.     Configure settings for routing.
# Configure static routes to reach the headquarters' gateway and network. The next hop in the routes is 2.2.2.2.
[DeviceA] ip route-static 10.1.2.0 24 2.2.2.2
[DeviceA] ip route-static 2.2.3.1 24 2.2.2.2
# Configure a static route to direct the traffic to be protected to the IPsec tunnel interface.
[DeviceA] ip route-static 10.1.2.0 255.255.255.0 tunnel 1
4.     Add interfaces to security zones.
[DeviceA] security-zone name trust
[DeviceA-security-zone-Trust] quit
[DeviceA] security-zone name untrust
[DeviceA-security-zone-Untrust] quit
5.     Configure a security policy:
[DeviceA] security-policy ip
[DeviceA-security-policy-ip] rule name ipseclocalout
[DeviceA-security-policy-ip] rule name ipseclocalin
# Configure a rule named trust-untrust to permit the packets from Host A to Host B.
[DeviceA-security-policy-ip] rule name trust-untrust
# Configure a rule named untrust-trust to permit the packets from Host B to Host A.
[DeviceA-security-policy-ip] rule name untrust-trust
[DeviceA-security-policy-ip] quit
6.     Configure an IPsec profile to establish an IPsec tunnel to protect the specified data.
[DeviceA] ike keychain abc
[DeviceA-ike-keychain-abc] pre-shared-key address 2.2.3.1 255.255.255.0 key simple 123456TESTplat&!
[DeviceA-ike-keychain-abc] quit
[DeviceA] ike profile abc
[DeviceA-ike-profile-abc] keychain abc
[DeviceA-ike-profile-abc] local-identity address 2.2.2.1
[DeviceA-ike-profile-abc] match remote identity address 2.2.3.1 24
[DeviceA-ike-profile-abc] exchange-mode aggressive
[DeviceA-ike-profile-abc] quit
[DeviceA] ipsec transform-set abc
[DeviceA-ipsec-transform-set-abc] esp encryption-algorithm aes-cbc-128
[DeviceA-ipsec-transform-set-abc] esp authentication-algorithm sha1
[DeviceA-ipsec-transform-set-abc] quit
[DeviceA] ipsec profile abc isakmp
[DeviceA-ipsec-profile-isakmp-abc] transform-set abc
[DeviceA-ipsec-profile-isakmp-abc] ike-profile abc
[DeviceA-ipsec-profile-isakmp-abc] quit
7.     Use IPsec profile abc to protect the traffic on Tunnel1.
[DeviceA-Tunnel1] tunnel protection ipsec profile abc
Configuring Device B
[DeviceB-Tunnel1] ip address 3.3.3.2 255.255.255.0
[DeviceB-Tunnel1] source 2.2.3.1
[DeviceB-Tunnel1] destination 2.2.2.1
# Configure static routes to reach the branch's gateway and network. The next hop in the routes is 2.2.3.2.
[DeviceB] ip route-static 10.1.1.0 24 2.2.3.2
[DeviceB] ip route-static 2.2.2.1 24 2.2.3.2
[DeviceA] ip route-static 10.1.1.0 255.255.255.0 tunnel 1
[DeviceB] security-zone name trust
[DeviceB-security-zone-Trust] quit
[DeviceB] security-zone name untrust
[DeviceB-security-zone-Untrust] quit
# Configure a rule named ipseclocalout to allow Device B to send IPsec negotiation packets to Device A.
[DeviceB-security-policy-ip] rule name ipseclocalout
[DeviceB-security-policy-ip-1-ipseclocalout] source-zone local
[DeviceB-security-policy-ip-1-ipseclocalout] destination-zone untrust
[DeviceB-security-policy-ip-1-ipseclocalout] action pass
[DeviceB-security-policy-ip-1-ipseclocalout] quit
# Configure a rule named ipseclocalin to allow Device B to receive the IPsec negotiation packets sent from Device A.
[DeviceB-security-policy-ip] rule name ipseclocalin
[DeviceB-security-policy-ip-2-ipseclocalin] source-zone untrust
[DeviceB-security-policy-ip-2-ipseclocalin] destination-zone local
[DeviceB-security-policy-ip-2-ipseclocalin] action pass
[DeviceB-security-policy-ip-2-ipseclocalin] quit
b.     Configure rules to permit traffic between Host B and Host A:
# Configure a rule named trust-untrust to permit the packets from Host B to Host A.
[DeviceB-security-policy-ip] rule name trust-untrust
[DeviceB-security-policy-ip-3-trust-untrust] source-zone trust
[DeviceB-security-policy-ip-3-trust-untrust] destination-zone untrust
[DeviceB-security-policy-ip-3-trust-untrust] action pass
[DeviceB-security-policy-ip-3-trust-untrust] quit
# Configure a rule named untrust-trust to permit the packets from Host A to Host B.
[DeviceB-security-policy-ip] rule name untrust-trust
[DeviceB-security-policy-ip-4-untrust-trust] source-zone untrust
[DeviceB-security-policy-ip-4-untrust-trust] destination-zone trust
[DeviceB-security-policy-ip-4-untrust-trust] action pass
[DeviceB-security-policy-ip-4-untrust-trust] quit
[DeviceB-security-policy-ip] quit
[DeviceB] ike keychain abc
[DeviceB-ike-keychain-abc] pre-shared-key address 2.2.2.1 255.255.255.0 key simple 123456TESTplat&!
[DeviceB-ike-keychain-abc] quit
[DeviceB] ike profile abc
[DeviceB-ike-profile-abc] keychain abc
[DeviceB-ike-profile-abc] local-identity address 2.2.3.1
[DeviceB-ike-profile-abc] match remote identity address 2.2.2.1 24
[DeviceB-ike-profile-abc] exchange-mode aggressive
[DeviceB-ike-profile-abc] quit
[DeviceB] ipsec transform-set abc
[DeviceB-ipsec-transform-set-abc] esp encryption-algorithm aes-cbc-128
[DeviceB-ipsec-transform-set-abc] esp authentication-algorithm sha1
[DeviceB-ipsec-transform-set-abc] quit
[DeviceB] ipsec profile abc isakmp
[DeviceB-ipsec-profile-isakmp-abc] transform-set abc
[DeviceB-ipsec-profile-isakmp-abc] ike-profile abc
[DeviceB-ipsec-profile-isakmp-abc] quit
[DeviceB-Tunnel1] tunnel protection ipsec profile abc
After the configuration is completed, Device A will automatically initiate IKE negotiation with Device B. After IKE negotiation succeeds, the tunnel interface will come up and traffic between the branch and the headquarters will be IPsec-protected. This example uses Device A to verify the configuration.
GE1/0/1             up       up       10.1.1.1/24        --           --
GE1/0/2             up       up       2.2.2.1/24         --           --
Tun1                up       up       3.3.3.1/24         --           --
# Display tunnel interface information on Device A.
<DeviceA> display interface Tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Maximum transmission unit: 1444
Internet address: 3.3.3.1/24 (primary)
Tunnel source 2.2.2.1, destination 2.2.3.1
Tunnel TTL 255
Tunnel protocol/transport IPsec/IP
<DeviceA> display ipsec sa
Interface: Tunnel1
  IPsec profile: abc
  Alias: profile-abc
  Mode: ISAKMP
    Tunnel id: 0
    Path MTU: 1388
    Tunnel:
        local  address/port: 2.2.2.1/500
        remote address/port: 2.2.3.1/500
    Flow:
        sour addr: 0.0.0.0/0.0.0.0  port: 0  protocol: ip
        dest addr: 0.0.0.0/0.0.0.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 2701952073 (0xa10c8449)
      Connection ID: 4294967296
      SA remaining duration (kilobytes/sec): 1843200/3180
      Max received sequence-number: 0
      Status: Active
    [Outbound ESP SAs]
      SPI: 3607077598 (0xd6ffa2de)
      Connection ID: 12884901889
      Max sent sequence-number: 0
      Status: Active
# Verify that a private IP address in the branch subnet can ping a private IP address in the headquarters subnet successfully.
<DeviceA> ping -a 10.1.1.1 10.1.2.1
Ping 10.1.2.1 (10.1.2.1) from 10.1.1.1: 56 data bytes, press CTRL_C to break
56 bytes from 10.1.2.1: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 10.1.2.1: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 10.1.2.1: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 10.1.2.1: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 10.1.2.1: icmp_seq=4 ttl=255 time=0.000 ms
--- Ping statistics for 10.1.2.1 ---
round-trip min/avg/max/std-dev = 0.000/0.600/1.000/0.490 ms
Configuring IKE
Unless otherwise specified, the term "IKE" in this chapter refers to IKEv1.
About IKE
Built on a framework defined by ISAKMP, Internet Key Exchange (IKE) provides automatic key negotiation and SA establishment services for IPsec.
Benefits of IKE
IKE provides the following benefits for IPsec:
·     Automatically negotiates IPsec parameters.
·     Performs DH exchanges to calculate shared keys, making sure each SA has a key that is independent of other keys.
·     Automatically negotiates SAs when the sequence number in the AH or ESP header overflows, making sure IPsec can provide the anti-replay service by using the sequence number.
Relationship between IPsec and IKE
As shown in Figure 28, IKE negotiates SAs for IPsec and transfers the SAs to IPsec, and IPsec uses the SAs to protect IP packets.
Figure 28 Relationship between IKE and IPsec
IKE negotiation process
IKE negotiates keys and SAs for IPsec in two phases:
1.     Phase 1—The two peers establish an IKE SA, a secure, authenticated channel for communication.
2.     Phase 2—Using the IKE SA established in phase 1, the two peers negotiate to establish IPsec SAs.
Phase 1 negotiation can use the main mode, GM main mode, or aggressive mode.
IKE exchange process in main mode
As shown in Figure 29, the main mode of IKE negotiation in phase 1 involves three pairs of messages:
·     SA exchange—Used for negotiating the IKE security policy.
·     Key exchange—Used for exchanging the DH public value and other values, such as the random number. The two peers use the exchanged data to generate key data and use the encryption key and authentication key to ensure the security of IP packets.
·     ID and authentication data exchange—Used for identity authentication.
Figure 29 IKE exchange process in main mode
IKE exchange process in aggressive mode
As shown in Figure 30, the process of phase 1 IKE negotiation in aggressive mode is as follows:
1.     The initiator (peer 1) sends a message containing the local IKE information to peer 2. The message includes parameters used for IKE SA establishment, keying data, and peer 1's identity information.
2.     Peer 2 chooses the IKE establishment parameters to use, generate the key, and authenticate peer 1's identity. Then it sends the IKE data to peer 1.
3.     Peer 1 generates the key, authenticates peer 2's identity, and sends the results to peer 1.
After the preceding process, an IKE SA is established between peer 1 and peer 2.
The aggressive mode is faster than the main mode but it does not provide identity information protection. The main mode provides identity information protection but is slower. Choose the appropriate negotiation mode according to your requirements.
Figure 30 IKE exchange process in aggressive mode
IKE exchange process in GM main mode
If the local end uses the GM main mode, the two IKE peers must use the RSA-DE or SM2-DE digital envelope authentication method.
IKE security mechanism
IKE has a series of self-protection mechanisms and supports secure identity authentication, key distribution, and IPsec SA establishment on insecure networks.
Identity authentication
The IKE identity authentication mechanism is used to authenticate the identity of the communicating peers. The device supports the following identity authentication methods:
·     Preshared key authentication—Two communicating peers use the pre-configured shared key for identity authentication.
·     RSA signature authentication and DSA signature authentication—Two communicating peers use the digital certificates issued by the CA for identity authentication.
The preshared key authentication method does not require certificates and is easy to configure. It is usually deployed in small networks.
The signature authentication methods provide higher security and are usually deployed in networks with the headquarters and some branches. When deployed in a network with many branches, a signature authentication method can simplify the configuration because only one PKI domain is required. If you use the preshared key authentication method, you must configure a preshared key for each branch on the Headquarters node.
DH algorithm
The DH algorithm is a public key algorithm. With this algorithm, two peers can exchange keying material and then use the material to calculate the shared keys. Due to the decryption complexity, a third party cannot decrypt the keys even after intercepting all keying materials.
PFS
The Perfect Forward Secrecy (PFS) feature is a security feature based on the DH algorithm. After PFS is enabled, an additional DH exchange is performed in IKE phase 2 to make sure IPsec keys have no derivative relations with IKE keys and a broken key brings no threats to other keys.
Protocols and standards
·     RFC 2408, Internet Security Association and Key Management Protocol (ISAKMP)
·     RFC 2409, The Internet Key Exchange (IKE)
·     RFC 2412, The OAKLEY Key Determination Protocol
·     Internet Draft, draft-ietf-ipsec-isakmp-xauth-06
Internet Draft, draft-dukes-ike-mode-cfg-02
Restrictions: Hardware compatibility with IKE
The SM1 algorithm is supported only on devices installed with a GM network data encryption module.
vSystem support for features
Non-default vSystems do not support the following features:
·     Setting the maximum number of IKE SAs.
·     Specifying the address assignment scope for the HA group member device.
·     Configuring SNMP notifications and logging for IKE.
·     Specifying an inside VPN instance for an IKE profile.
For information about the support of non-default vSystems for the commands, see IKE command reference. For information about vSystem, see Virtual Technologies Configuration Guide.
IKE tasks at a glance
To configure IKE, perform the following tasks:
1.     (Optional.) Configuring an IKE profile
a.     Creating an IKE profile
b.     Configuring peer IDs for the IKE profile
c.     Specifying the IKE keychain or PKI domain
d.     Configuring the IKE phase 1 negotiation mode
e.     Specifying IKE proposals for the IKE profile
f.     Configuring the local ID for the IKE profile
g.     Specifying an inside VPN instance for the IKE profile
h.     Configuring optional features for the IKE profile
2.     Configuring an IKE proposal
3.     Configuring an IKE keychain
4.     (Optional.) Configuring accessibility features for IKE negotiation
¡     Configuring the global identity information
¡     Configuring the IKE keepalive feature
¡     Configuring the IKE NAT keepalive feature
¡     Configuring global IKE DPD
¡     Enabling invalid SPI recovery
¡     Setting the maximum number of IKE SAs
¡     Configuring IKE address pools
¡     Specifying the address assignment scope for the HA group member device
¡     Configuring IKE negotiation compatibility
¡     Configuring SNMP notifications and logging for IKE
Prerequisites for IKE configuration
Determine the following parameters prior to IKE configuration:
·     The algorithms to be used during IKE negotiation, including the identity authentication method, encryption algorithm, authentication algorithm, and DH group.
¡     Different algorithms provide different levels of protection. A stronger algorithm provides more resistance to decryption but uses more resources.
¡     A DH group that uses more bits provides higher security but needs more time for processing.
·     The preshared key or PKI domain for IKE negotiation. For more information about PKI, see "Configuring PKI."
·     The IKE-based IPsec policies for the communicating peers. If you do not specify an IKE profile in an IPsec policy, the device selects an IKE profile for the IPsec policy. If no IKE profile is configured, the globally configured IKE settings are used. For more information about IPsec, see "Configuring IPsec."
Perform this task to create an IKE profile.
An IKE profile is intended to provide a set of parameters for IKE negotiation.
2.     Create an IKE profile and enter its view.
ike profile profile-name
Perform this task to configure the peer IDs for IKE profile matching. When the device needs to select an IKE profile for IKE negotiation with a peer, it compares the received peer ID with the peer IDs of its local IKE profiles. If a match is found, it uses the IKE profile with the matching peer ID for IKE negotiation.
For an IKE profile, you can configure multiple peer IDs. A peer ID configured earlier has a higher priority.
Two IKE peers must both have or both not have peer IDs configured.
2.     Enter IKE profile view.
3.     Configure a peer ID for the IKE profile.
match remote { certificate policy-name | identity { address { { ipv4-address [ mask | mask-length ] | range low-ipv4-address high-ipv4-address } | ipv6 { ipv6-address [ prefix-length ] | hostname host-name | range low-ipv6-address high-ipv6-address } } [ vpn-instance vpn-instance-name ] | fqdn fqdn-name | user-fqdn user-fqdn-name | domain fqdn-domain-name } }
Configure the IKE keychain or PKI domain for the IKE proposals to use. To use digital signature authentication, configure a PKI domain. To use preshared key authentication, configure an IKE keychain.
3.     Specify the keychain for preshared key authentication or the PKI domain used to request a certificate for digital signature authentication.
¡     Specify the keychain.
keychain keychain-name
¡     Specify the PKI domain.
certificate domain domain-name
By default, no IKE keychain or PKI domain is specified in an IKE profile.
Specify the IKE phase 1 negotiation mode (main or aggressive) that the device uses as the initiator. When the device acts as the responder, it uses the IKE negotiation mode of the initiator.
3.     Specify the IKE negotiation mode for phase 1.
exchange-mode { aggressive | gm-main | main }
By default, IKE negotiation in phase 1 uses the main mode.
Specify the IKE proposals that the device can use as the initiator. An IKE proposal specified earlier has a higher priority. When the device acts as the responder, it uses the IKE proposals configured in system view to match the IKE proposals received from the initiator. If no matching proposal is found, the negotiation fails.
3.     Specify IKE proposals for the IKE profile.
proposal proposal-number&<1-6>
By default, no IKE proposals are specified for an IKE profile and the IKE proposals configured in system view are used for IKE negotiation.
For digital signature authentication, the device can use an ID of any type. If the local ID is an IP address that is different from the IP address in the local certificate, the device uses the FQDN (the device name configured by using the sysname command) instead.
For preshared key authentication, the device can use an ID of any type other than the DN.
3.     Configure the local ID.
local-identity { address { ipv4-address | ipv6 ipv6-address } | dn | fqdn [ fqdn-name ] | user-fqdn [ user-fqdn-name ] }
By default, no local ID is configured for an IKE profile, and an IKE profile uses the local ID configured in system view. If the local ID is not configured in system view, the IKE profile uses the IP address of the interface to which the IPsec policy or IPsec policy template is applied as the local ID.
The inside MPLS L3VPN instance determines where the device should forward received IPsec protected data. If you specify an inside VPN instance, the device looks for a route in the specified VPN instance to forward the data. If you do not specify an inside VPN instance, the device looks for a route in the VPN instance where the receiving interface resides to forward the data.
The inside VPN instance specified in an IKE profile takes effect only on IPsec policies that use the IKE profile. It does not take effect on IPsec profiles that use the IKE profile.
The VPN instances specified in the rules of an ACL for an IPsec policy must be the same. The inside VPN instance of the IKE profile used by the IPsec policy must be the same as the VPN instance specified in the ACL.
3.     Specify an inside VPN instance.
inside-vpn vpn-instance vpn-instance-name
By default, no inside VPN instance is specified for an IKE profile, and the device forwards protected data to the VPN instance where the interface receiving the data resides.
3.     Configure optional features as needed.
¡     Configure IKE DPD.
dpd interval interval [ retry seconds ] { on-demand | periodic }
By default, IKE DPD is not configured for an IKE profile and an IKE profile uses the DPD settings configured in system view. If IKE DPD is not configured in system view either, the device does not perform dead IKE peer detection.
The IKE DPD settings configured in the IKE profile view take precedence over those configured in system view.
¡     Specify the local interface or IP address to which the IKE profile can be applied.
match local address { interface-type interface-number | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
By default, an IKE profile can be applied to any local interface or IP address.
An IKE profile configured with this command has a higher priority over those not configured with this command.
¡     Specify a priority for the IKE profile.
priority priority
By default, the priority of an IKE profile is 100.
The device selects a local IKE profile for IKE negotiation as follows:
-     First, it selects an IKE profile with the match local address command configured.
-     If a tie exists, it selects the IKE profile with a smaller priority number.
-     If a tie still exists, it selects the IKE profile configured earlier.
¡     Configure the peer address for matching the IKE profile.
match remote address { ipv4-address | dynamic | ipv6 ipv6-address }
By default, the peer address for matching an IKE profile is not configured.
For this command to take effect, you must also use the match local address command to configure a local address (or local interface) for the IKE profile.
If two matching IKE profiles are found for a negotiation, the IKE profile with a higher priority is used. If they have the same priority, the IKE profile configured earlier is used.
¡     Enable client authentication.
client-authentication xauth
By default, client authentication is disabled.
Configure this command in the IKE profile used by the IPsec gateway at the enterprise center. This command enables the IPsec gateway to perform extended (XAUTH) authentication on remote users through AAA after IKE phase 1 negotiation. AAA configuration is also required on the IPsec gateway for client authentication.
¡     Specify the user information required for client authentication.
client-authentication xauth { aaa-auth-server | user username password { cipher | simple } string }
By default, the user information required for client authentication is not specified.
Configure this command in the IKE profile used by a branch gateway. The branch gateway can then use the specified user information to perform AAA authentication and establish an IPsec tunnel with the IPsec gateway at the enterprise headquarters.
¡     Enable AAA authorization.
aaa authorization domain domain-name username user-name
By default, AAA authorization is disabled.
The AAA authorization feature enables IKE to request authorization attributes, such as the IKE address pool, from AAA. IKE uses the address pool to assign IP addresses to remote users. For more information about AAA authorization, see "Configuring AAA."
¡     (Optional.) Set the IKE SA soft lifetime buffer time.
sa soft-duration buffer seconds
By default, the IKE SA soft lifetime buffer time is not configured.
Set the IKE SA soft lifetime buffer time to determine the IKE SA soft lifetime. The SA soft lifetime is calculated as follows: SA soft lifetime = SA lifetime – SA soft lifetime buffer. A new IKE SA will be negotiated when the SA soft lifetime timer expires.
¡     Specify the version of the SM4 algorithm used for IKE GM main negotiations.
ike gm-main sm4-version { draft | standard }
By default, the standard SM4 algorithm is used in IKE GM main negotiations.
Specify the SM4 version used by the device to initiate an IKE negotiation with a device from other vendors to make sure the two devices use the same SM4 version in the negotiation.
¡     Configure the initiator to use dynamic source UDP ports for IKE negotiations.
client source-udp-port dynamic
By default, the source UDP port is 500.
In some scenarios, intermediate devices on the network will drop packets with source UDP port 4500, resulting in IKE negotiation failure. To avoid such failure, you can enable the initiator to use dynamic source UDP ports for IKE negotiations.
An IKE proposal defines a set of attributes describing how IKE negotiation in phase 1 should take place. You can create multiple IKE proposals with different priorities. The priority of an IKE proposal is represented by its sequence number. The lower the sequence number, the higher the priority.
Two peers must have at least one matching IKE proposal for successful IKE negotiation. During IKE negotiation:
·     The initiator sends its IKE proposals to the peer.
¡     If the initiator is using an IPsec policy with an IKE profile, the initiator sends all IKE proposals specified in the IKE profile to the peer. An IKE proposal specified earlier for the IKE profile has a higher priority.
¡     If the initiator is using an IPsec policy with no IKE profile, the initiator sends all its IKE proposals to the peer. An IKE proposal with a smaller number has a higher priority.
·     The peer searches its own IKE proposals for a match. The search starts from the IKE proposal with the highest priority and proceeds in descending order of priority until a match is found. The matching IKE proposals are used to establish the IKE SA. If all user-defined IKE proposals are found mismatching, the two peers use their default IKE proposals to establish the IKE SA.
Two matching IKE proposals have the same encryption algorithm, authentication method, authentication algorithm, and DH group. The SA lifetime takes the smaller one of the two proposals' SA lifetime settings.
2.     Create an IKE proposal and enter its view.
ike proposal proposal-number
By default, a default IKE proposal exists.
3.     Configure a description for the IKE proposal.
description
By default, an IKE proposal does not have a description.
4.     Specify an encryption algorithm for the IKE proposal.
encryption-algorithm { 3des-cbc | aes-cbc-128 | aes-cbc-192 | aes-cbc-256 | des-cbc | sm1-cbc-128 | sm4-cbc }
By default, the 56-bit DES encryption algorithm in CBC mode is used.
5.     Specify an authentication method for the IKE proposal.
authentication-method { ecdsa-signature | dsa-signature | pre-share | rsa-de | rsa-signature | sm2-de }
By default, the preshared key authentication method is used.
6.     Specify an authentication algorithm for the IKE proposal.
authentication-algorithm { md5 | sha | sha256 | sha384 | sha512 | sm3 }
By default, the HMAC-SHA1 authentication algorithm is used.
7.     Specify a DH group for key negotiation in phase 1.
dh { group1 | group14 | group19 | group2 | group20 | group24 | group5 }
DH group 1 (the 768-bit DH group) is used by default.
8.     (Optional.) Set the IKE SA lifetime for the IKE proposal.
sa duration seconds
By default, the IKE SA lifetime is 86400 seconds.
If the IPsec SA lifetime is also configured, set the IKE SA lifetime longer than the IPsec SA lifetime as a best practice.
Perform this task when you configure the IKE to use the preshared key for authentication.
Follow these guidelines when you configure an IKE keychain:
·     Two peers must be configured with the same preshared key to pass preshared key authentication.
·     You can specify the local address configured in IPsec policy or IPsec policy template view (using the local-address command) for the IKE keychain to be applied. If no local address is configured, specify the IP address of the interface that uses the IPsec policy.
·     The device determines the priority of an IKE keychain as follows:
a.     The device examines the existence of the match local address command. An IKE keychain with the match local address command configured has a higher priority.
b.     If a tie exists, the device compares the priority numbers. An IKE keychain with a smaller priority number has a higher priority.
c.     If a tie still exists, the device prefers an IKE keychain configured earlier.
2.     Create an IKE keychain and enter its view.
ike keychain keychain-name [ vpn-instance vpn-instance-name ]
3.     Configure a preshared key.
pre-shared-key { address { ipv4-address [ mask | mask-length ] | hostname host-name | ipv6 ipv6-address [ prefix-length ] } | hostname host-name } key { cipher | simple } string
By default, no preshared key is configured.
4.     (Optional.) Specify a local interface or IP address to which the IKE keychain can be applied.
By default, an IKE keychain can be applied to any local interface or IP address.
5.     (Optional.) Specify a priority for the IKE keychain.
priority priority
The default priority is 100.
The global identity can be used by the device for all IKE SA negotiations, and the local identity (set by the local-identity command) can be used only by the device that uses the IKE profile.
When signature authentication is used, you can set any type of the identity information.
When preshared key authentication is used, you cannot set the DN as the identity.
2.     Configure the global identity to be used by the local end.
ike identity { address { ipv4-address | ipv6 ipv6-address }| dn | fqdn [ fqdn-name ] | user-fqdn [ user-fqdn-name ] }
By default, the IP address of the interface to which the IPsec policy or IPsec policy template is applied is used as the IKE identity.
3.     (Optional.) Configure the local device to always obtain the identity information from the local certificate for signature authentication.
ike signature-identity from-certificate
By default, the local end uses the identity information specified by local-identity or ike identity for signature authentication.
Configure this command when the aggressive mode and signature authentication are used and the device interconnects with a Comware 5-based peer device. Comware 5 supports only DN for signature authentication.
IKE sends keepalive packets to query the liveness of the peer. If the peer is configured with the keepalive timeout time, you must configure the keepalive interval on the local device. If the peer receives no keepalive packets during the timeout time, the IKE SA is deleted along with the IPsec SAs it negotiated.
Configure IKE DPD instead of IKE keepalive unless IKE DPD is not supported on the peer. The IKE keepalive feature sends keepalives at regular intervals, which consumes network bandwidth and resources.
The keepalive timeout time configured on the local device must be longer than the keepalive interval configured at the peer. Since it seldom occurs that more than three consecutive packets are lost on a network, you can set the keepalive timeout three times as long as the keepalive interval.
2.     Set the IKE SA keepalive interval.
ike keepalive interval interval
By default, no keepalives are sent to the peer.
3.     Set the IKE SA keepalive timeout time.
ike keepalive timeout seconds
By default, IKE SA keepalive never times out.
If IPsec traffic passes through a NAT device, you must configure the NAT traversal feature. If no packet travels across an IPsec tunnel in a period of time, the NAT sessions are aged and deleted, disabling the tunnel from transmitting data to the intended end. To prevent NAT sessions from being aged, configure the NAT keepalive feature on the IKE gateway behind the NAT device to send NAT keepalive packets to its peer periodically to keep the NAT session alive.
2.     Set the IKE NAT keepalive interval.
ike nat-keepalive seconds
The default interval is 20 seconds.
DPD detects dead peers. It can operate in periodic mode or on-demand mode.
·     Periodic DPD—Sends a DPD message at regular intervals. It features an earlier detection of dead peers, but consumes more bandwidth and CPU.
·     On-demand DPD—Sends a DPD message based on traffic. When the device has traffic to send and is not aware of the liveness of the peer, it sends a DPD message to query the status of the peer. If the device has no traffic to send, it never sends DPD messages. As a best practice, use the on-demand mode.
The IKE DPD works as follows:
1.     The local device sends a DPD message to the peer, and waits for a response from the peer.
2.     If the peer does not respond within the retry interval specified by the retry seconds parameter, the local device resends the message.
3.     If still no response is received within the retry interval, the local end sends the DPD message again. The system allows a maximum of four retries.
4.     If the local device receives no response after four retries, the device considers the peer to be dead, and deletes the IKE SA along with the IPsec SAs it negotiated.
5.     If the local device receives a response from the peer during the detection process, the peer is considered alive. The local device performs a DPD detection again when the triggering interval is reached or it has traffic to send, depending on the DPD mode.
When DPD settings are configured in both IKE profile view and system view, the DPD settings in IKE profile view apply. If DPD is not configured in IKE profile view, the DPD settings in system view apply.
It is a good practice to set the triggering interval longer than the retry interval so that a DPD detection is not triggered during a DPD retry.
2.     Enable sending IKE DPD messages.
ike dpd interval interval [ retry seconds ] { on-demand | periodic }
By default, IKE DPD is disabled.
An IPsec "black hole" occurs when one IPsec peer fails (for example, a peer can fail if a reboot occurs). One peer fails and loses its SAs with the other peer. When an IPsec peer receives a data packet for which it cannot find an SA, an invalid SPI is encountered. The peer drops the data packet and tries to send an SPI invalid notification to the data originator. This notification is sent by using the IKE SA. Because no IKE SA is available, the notification is not sent. The originating peer continues sending the data by using the IPsec SA that has the invalid SPI, and the receiving peer keeps dropping the traffic.
The invalid SPI recovery feature enables the receiving peer to set up an IKE SA with the originator so that an SPI invalid notification can be sent. Upon receiving the notification, the originating peer deletes the IPsec SA that has the invalid SPI. If the originator has data to send, new SAs will be set up.
This feature is not supported in ADVPN networks. For more information about ADVPN, see Layer 3—IP Services Configuration Guide.
Use caution when you enable the invalid SPI recovery feature because using this feature can result in a DoS attack. Attackers can make a great number of invalid SPI notifications to the same peer.
2.     Enable invalid SPI recovery.
ike invalid-spi-recovery enable
By default, the invalid SPI recovery is disabled.
You can set the maximum number of half-open IKE SAs and the maximum number of established IKE SAs.
·     The supported maximum number of half-open IKE SAs depends on the device's processing capability. Adjust the maximum number of half-open IKE SAs to make full use of the device's processing capability without affecting the IKE SA negotiation efficiency.
·     The supported maximum number of established IKE SAs depends on the device's memory space. Adjust the maximum number of established IKE SAs to make full use of the device's memory space without affecting other applications in the system.
2.     Set the maximum number of half-open IKE SAs and the maximum number of established IKE SAs.
ike limit { max-negotiating-sa negotiation-limit | max-sa sa-limit }
By default, the maximum number of half-open IKE SAs and IPsec SAs is 200, and there is no limit to the maximum number of established IKE SAs.
To perform centralized management on remote users, an IPsec gateway can use an address pool to assign private IP addresses to remote users.
You must use an IKE address pool together with AAA authorization by specifying the IKE address pool as an AAA authorization attribute. For more information about AAA authorization, see "Configuring AAA."
2.     Configure an IKE IPv4 address pool.
ike address-group group-name start-ipv4-address end-ipv4-address [ mask | mask-length ]
3.     Configure an IKE IPv6 address pool.
ike ipv6-address-group group-name prefix prefix/prefix-len assign-len assign-len
On an HA network in dual-active mode, both member devices process services. If both devices use the same IKE address pool to assign IP addresses to the peer device, client IP conflicts will occur.
To resolve this issue, specify the address assignment scope for each member device in the HA group. For example, you can execute the ike dual-active address-alloc primary command on the primary member device to configure the device to use the first half of each IKE address pool, and execute the ike dual-active address-alloc secondary command on the secondary member device to configure the device to use the second half of each IKE address pool. For more information about HA, see RBM-based hot backup configuration in High Availability Configuration Guide.
On an HA network in active/standby mode, only one device processes services and conflicts of IPs assigned from IKE address pools will not occur. Do not configure this feature on an HA network in active/standby mode. If you configure this feature, half IPs in each IKE address pool will not be used.
When you configure this command, for successful IP assignment to the peer device of the device, make sure a minimum of two IP addresses exist in one IKE address pool.
2.     Specify the address assignment scope for the primary or secondary member device in the HA group.
ike dual-active address-alloc { primary | secondary }
By default, the primary and secondary member device in the HA group use each IKE address pool together.
Configuring SM4-CBC key length compatibility and GM main mode compatibility
IKE negotiation between two peers using the SM4-CBC algorithm will fail if the peers use different SM4-CBC key lengths. You can enable SM4-CBC key length compatibility on the device, so the device can successfully negotiate with a remote peer that uses a different SM4-CBC key length.
IKE peers running different software versions might have the GM main mode compatibility issue during IKE negotiation. If the device encounters this issue with its peer, you can enable the GM mode compatibility on the device. Do not enable GM mode compatibility on the device if the device does not have the compatibility issue with its peers.
2.     Enable SM4-CBC key length compatibility.
ike compatible-sm4 enable
By default, SM4-CBC key length compatibility is disabled.
3.     Enable GM main mode compatibility.
ike compatible-gm-main enable
By default, the GM main mode compatibility is disabled.
Configuring the SM4 algorithm version for IKE GM main mode negotiation
Abou this task
The SM4 algorithm has different versions. To initiate an IKE negotiation in GM main mode with another device, perform this task to specify the SM4 algorithm version to ensure the two devices use the same SM4 version for the negotiation.
3.     Specify the SM4 algorithm version to be used for IKE negotiation in GM main mode.
By default, the standard SM4 algorithm is used for IKE negotiation in GM main mode.
Configuring the IKE version for IKE GM main mode negotiation
To initiate an IKE negotiation in GM main mode with another device, perform this task to specify the GM IKE version to ensure the two devices use the same GM IKE version for the negotiation.
You can specify the global GM IKE version for all IKE profiles in system view or for a specific IKE profile in IKE profile view. The profile-specific configuration takes precedence over the global configuration.
This feature takes effect only on new IKE SAs to be negotiated. It does not take effect on existing IKE SAs.
2.     Configure the global GM IKE version for the IKE GM main mode negotiation.
ike gm-main global-ike-version { 1.0 | 1.1 }
By default, the global GM IKE version is 1.1.
3.     Create an IKE profile and enter its view.
4.     Configure the GM IKE version for the IKE profile.
ike gm-main ike-version { 1.0 | 1.1 }
By default, an IKE profile uses the global GM IKE version configuration.
Specifying the remote certificate serial number
When the device initiates a GM main mode IKE negotiation with another device that does not support sending the certificate online for the IKE negotiation, you must import the certificate of the remote device to the local device and specify the serial number of the remote certificate in IKE profile view. To view the serial number of the imported remote certificate, use the display pki certificate domain command. For more information about importing certificates, see the "Configuring PKI."
3.     Specify the serial number of the remote certificate.
remote-certificate serial serial-number
By default, no remote certificate serial number is specified.
Configuring SNMP notifications for IKE
After you enable SNMP notifications for IKE, the IKE module notifies the NMS of important module events. The notifications are sent to the device's SNMP module. For the notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP notifications, see Network Management and Monitoring Configuration Guide.
To generate and output SNMP notifications for a specific IKE failure or event type, perform the following tasks:
1.     Enable SNMP notifications for IKE globally.
2.     Enable SNMP notifications for the failure or event type.
1.     Enter system view
2.     Enable SNMP notifications for IKE globally.
snmp-agent trap enable ike global
By default, SNMP notifications for IKE are disabled.
3.     Enable SNMP notifications for the specified failure or event types.
snmp-agent trap enable ike [ attr-not-support | auth-failure | cert-type-unsupport | cert-unavailable | decrypt-failure | encrypt-failure | invalid-cert-auth | invalid-cookie | invalid-id | invalid-proposal | invalid-protocol | invalid-sign | no-sa-failure | proposal-add | proposal–delete | tunnel-start | tunnel-stop | unsupport-exch-type ] *
By default, SNMP notifications for all failure and event types are disabled.
Enabling logging for IKE negotiation
This feature enables the device to output logs for the IKE negotiation process.
2.     Enable logging for IKE negotiation.
ike logging negotiation enable
By default, logging for IKE negotiation is disabled.
Display and maintenance commands for IKE
Display configuration information about all IKE proposals.
display ike proposal
Display information about the current IKE SAs.
display ike sa [ verbose [ connection-id connection-id | remote-address [ ipv6 ] remote-address [ vpn-instance vpn-instance-name ] ] | count ]
Display IKE statistics.
display ike statistics
Display global IKE information.
display ike global-info
Delete IKE SAs.
reset ike sa [ connection-id connection-id ]
Clear IKE MIB statistics.
reset ike statistics
Troubleshooting IKE
IKE negotiation failed because no matching IKE proposals were found
Symptom
1.     The IKE SA is in Unknown state.
<Sysname> display ike sa
    Connection-ID   Remote                Flag         DOI
    1               192.168.222.5/500     Unknown      IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
2.     When IKE event debugging and packet debugging are enabled, the following messages appear:
IKE event debugging message:
The attributes are unacceptable.
IKE packet debugging message:
Construct notification packet: NO_PROPOSAL_CHOSEN.
Analysis
Certain IKE proposal settings are incorrect.
Solution
1.     Examine the IKE proposal configuration to see whether the two ends have matching IKE proposals.
2.     Modify the IKE proposal configuration to make sure the two ends have matching IKE proposals.
3.     If the problem persists, contact the technical support.
IKE negotiation failed because no IKE proposals or IKE keychains are specified correctly
Symptom
Flags:
2.     The following IKE event debugging or packet debugging message appeared:
Notification PAYLOAD_MALFORMED is received.
Construct notification packet: PAYLOAD_MALFORMED.
Analysis
·     If the following debugging information appeared, the matched IKE profile is not using the matched IKE proposal:
Failed to find proposal 1 in profile profile1.
·     If the following debugging information appeared, the matched IKE profile is not using the matched IKE keychain:
Failed to find keychain keychain1 in profile profile1.
Solution
1.     Verify that the matched IKE proposal (IKE proposal 1 in this debugging message example) is specified for the IKE profile (IKE profile 1 in the example).
2.     Verify that the matched IKE keychain (IKE keychain 1 in this debugging message example) is specified for the IKE profile (IKE profile 1 in the example).
IPsec SA negotiation failed because no matching IPsec transform sets were found
Symptom
1.     The display ike sa command shows that the IKE SA negotiation succeeded and the IKE SA is in RD state, but the display ipsec sa command shows that the expected IPsec SA has not been negotiated yet.
2.     The following IKE debugging message appeared:
Or:
Analysis
Certain IPsec policy settings are incorrect.
Solution
1.     Examine the IPsec configuration to see whether the two ends have matching IPsec transform sets.
2.     Modify the IPsec configuration to make sure the two ends have matching IPsec transform sets.
IPsec SA negotiation failed due to invalid identity information
Symptom
Notification INVALID_ID_INFORMATION is received.
Or:
Failed to get IPsec policy when renegotiating IPsec SA. Delete IPsec SA.
Construct notification packet: INVALID_ID_INFORMATION.
Analysis
Certain IPsec policy settings of the responder are incorrect. Verify the settings as follows:
1.     Verify that matching IKE profiles were found in IKE negotiation phase 1.
If no matching IKE profiles were found, the IPsec policy must not use an IKE profile, so the global IKE settings can be used for IKE negotiation. If no matching IKE profiles were found and the IPsec policy is using an IKE profile, the IPsec SA negotiation fails.
# Identify whether matching IKE profiles were found in IKE negotiation phase 1. The following output shows that no matching IKE profile was found:
<Sysname> display ike sa verbose
   Connection ID: 3
   Outside VPN:
   Inside VPN:
   Profile:
   Transmitting entity: Responder
   Initiator cookie: 1bcf453f0a217259
   Responder cookie: 5e32a74dfa66a0a4
   Output interface index: 2
   Local IP/port: 192.168.222.5/500
   Local ID type: IPV4_ADDR
   Local ID: 192.168.222.5
   Remote IP/port: 192.168.222.71/500
   Remote ID type: IPV4_ADDR
   Remote ID: 192.168.222.71
   Authentication-method: PRE-SHARED-KEY
   Authentication-algorithm: MD5
   Encryption-algorithm: 3DES-CBC
   Life duration(sec): 86400
   Remaining key duration(sec): 85847
   Exchange-mode: Main
   Diffie-Hellman group: Group 1
   NAT traversal: Not detected
   Vendor ID index: 0xa1d
   Vendor ID sequence number: 0x0
# Identify whether the IPsec policy is using an IKE profile. The following output shows that no IKE profile is used by the IPsec policy.
[Sysname] display ipsec policy
IPsec Policy: policy1
  Sequence number: 1
  Mode: ISAKMP
  Description:
  Security data flow: 3000
  Selector mode: aggregation
  Local address: 192.168.222.5
  Remote address: 192.168.222.71
  Transform set:  transform1
  IKE profile: profile1
  smart-link policy:
  SA trigger mode: Auto
  SA duration(time based): 3600 seconds
  SA duration(traffic based): 1843200 kilobytes
  SA soft-duration buffer(time based): 1000 seconds
  SA soft-duration buffer(traffic based): 43200 kilobytes
  SA idle time: 100 seconds
  SA df-bit:
  Responder only: Disabled
2.     Verify that the ACL specified for the IPsec policy is correctly configured. If the flow range defined by the responder's ACL is smaller than that defined by the initiator's ACL, IPsec proposal matching will fail.
For example, if the initiator's ACL defines a flow from one network segment to another but the responder's ACL defines a flow from one host to another host, IPsec proposal matching will fail.
# On the initiator:
[Sysname] display acl 3000
Advanced IPv4 ACL 3000, 1 rule,
ACL's step is 5
 rule 0 permit ip source 192.168.222.0 0.0.0.255 destination 192.168.222.0 0.0.0.255
# On the responder:
ACL's step is 5
 rule 0 permit ip source 192.168.222.71 0 destination 192.168.222.5 0
3.     Verify that the IPsec policy has a remote address and an IPsec transform set configured and that the IPsec transform set has all necessary settings configured.
If, for example, the IPsec policy has no remote address configured, the IPsec SA negotiation will fail:
  Sequence number: 1
  Mode: ISAKMP
  Remote address:
  smart-link policy:
  SA df-bit:
Solution
1.     If the IPsec policy specifies an IKE profile but no matching IKE profiles was found in IKE negotiation, perform one of the following tasks on the responder:
¡     Remove the specified IKE profile from the IPsec policy.
¡     Modify the specified IKE profile to match the IKE profile of the initiator.
2.     If the flow range defined by the responder's ACL is smaller than that defined by the initiator's ACL, modify the responder's ACL so the ACL defines a flow range equal to or greater than that of the initiator's ACL.
For example:
Advanced IPv4 ACL 3000, 2 rules,
ACL's step is 5
3.     Configure the missing settings (for example, the remote address).
4.     If the problem persists, contact the technical support.
Configuring IKEv2
About IKEv2
Internet Key Exchange version 2 (IKEv2) is an enhanced version of IKEv1. The same as IKEv1, IKEv2 has a set of self-protection mechanisms and can be used on insecure networks for reliable identity authentication, key distribution, and IPsec SA negotiation. IKEv2 provides stronger protection against attacks and higher key exchange ability and needs fewer message exchanges than IKEv1.
IKEv2 negotiation process
Compared with IKEv1, IKEv2 simplifies the negotiation process and is much more efficient.
IKEv2 defines three types of exchanges: initial exchanges, CREATE_CHILD_SA exchange, and INFORMATIONAL exchange.
As shown in Figure 31, IKEv2 uses two exchanges during the initial exchange process: IKE_SA_INIT and IKE_AUTH, each with two messages.
·     IKE_SA_INIT exchange—Negotiates IKE SA parameters and exchanges keys.
·     IKE_AUTH exchange—Authenticates the identity of the peer and establishes IPsec SAs.
After the four-message initial exchanges, IKEv2 sets up one IKE SA and one pair of IPsec SAs. For IKEv1 to set up one IKE SA and one pair of IPsec SAs, it must go through two phases that use a minimum of six messages.
To set up one more pair of IPsec SAs within the IKE SA, IKEv2 goes on to perform an additional two-message exchange—the CREATE_CHILD_SA exchange. One CREATE_CHILD_SA exchange creates one pair of IPsec SAs. IKEv2 also uses the CREATE_CHILD_SA exchange to rekey IKE SAs and Child SAs.
IKEv2 uses the INFORMATIONAL exchange to convey control messages about errors and notifications.
Figure 31 IKEv2 Initial exchange process
New features in IKEv2
DH guessing
In the IKE_SA_INIT exchange, the initiator guesses the DH group that the responder is most likely to use and sends it in an IKE_SA_INIT request message. If the initiator's guess is correct, the responder responds with an IKE_SA_INIT response message and the IKE_SA_INIT exchange is finished. If the guess is wrong, the responder responds with an INVALID_KE_PAYLOAD message that contains the DH group that it wants to use. The initiator then uses the DH group selected by the responder to reinitiate the IKE_SA_INIT exchange. The DH guessing mechanism allows for more flexible DH group configuration and enables the initiator to adapt to different responders.
Cookie challenging
Messages for the IKE_SA_INIT exchange are in plain text. An IKEv1 responder cannot confirm the validity of the initiators and must maintain half-open IKE SAs, which makes the responder susceptible to DoS attacks. An attacker can send a large number of IKE_SA_INIT requests with forged source IP addresses to the responder, exhausting the responder's system resources.
IKEv2 introduces the cookie challenging mechanism to prevent such DoS attacks. When an IKEv2 responder maintains a threshold number of half-open IKE SAs, it starts the cookie challenging mechanism. The responder generates a cookie and includes it in the response sent to the initiator. If the initiator initiates a new IKE_SA_INIT request that carries the correct cookie, the responder considers the initiator valid and proceeds with the negotiation. If the carried cookie is incorrect, the responder terminates the negotiation.
The cookie challenging mechanism automatically stops working when the number of half-open IKE SAs drops below the threshold.
IKEv2 SA rekeying
For security purposes, both IKE SAs and IPsec SAs have a lifetime and must be rekeyed when the lifetime expires. An IKEv1 SA lifetime is negotiated. An IKEv2 SA lifetime, in contrast, is configured. If two peers are configured with different lifetimes, the peer with the shorter lifetime always initiates the SA rekeying. This mechanism reduces the possibility that two peers will simultaneously initiate a rekeying. Simultaneous rekeying results in redundant SAs and SA status inconsistency on the two peers.
IKEv2 message retransmission
Unlike IKEv1 messages, IKEv2 messages appear in request/response pairs. IKEv2 uses the Message ID field in the message header to identify the request/response pair. If an initiator sends a request but receives no response with the same Message ID value within a specific period of time, the initiator retransmits the request.
It is always the IKEv2 initiator that initiates the retransmission, and the retransmitted message must use the same Message ID value.
·     RFC 4306, Internet Key Exchange (IKEv2) Protocol
·     RFC 4718, IKEv2 Clarifications and Implementation Guidelines
·     RFC 5996, Internet Key Exchange Protocol Version 2 (IKEv2)
Restrictions: Hardware compatibility with IKEv2
IKEv2 tasks at a glance
To configure IKEv2, perform the following tasks:
1.     Configuring an IKEv2 profile
a.     Creating an IKEv2 profile
b.     Specifying the local and remote identity authentication methods
c.     Configuring the IKEv2 keychain or PKI domain
d.     Configuring the local ID for the IKEv2 profile
e.     Configuring peer IDs for the IKEv2 profile
f.     Specifying a VPN instance for the IKEv2 profile
g.     Specifying an inside VPN instance for the IKEv2 profile
h.     Configuring optional features for the IKEv2 profile
2.     Configuring an IKEv2 policy
3.     Configuring an IKEv2 proposal
If you specify an IKEv2 proposal in an IKEv2 policy, you must configure the IKEv2 proposal.
4.     Configuring an IKEv2 keychain
This task is required when either end or both ends use the preshared key authentication method.
5.     (Optional.) Enabling the cookie challenging feature
The cookie challenging feature takes effect only on IKEv2 responders.
6.     (Optional.) Configuring the IKEv2 DPD feature
7.     (Optional.) Configuring the IKEv2 NAT keepalive feature
8.     (Optional.) Configuring IKEv2 address pools
Prerequisites for IKEv2 configuration
Determine the following parameters prior to IKEv2 configuration:
·     The strength of the algorithms for IKEv2 negotiation, including the encryption algorithms, integrity protection algorithms, PRF algorithms, and DH groups. Different algorithms provide different levels of protection. A stronger algorithm means better resistance to decryption of protected data but requires more resources. Typically, the longer the key, the stronger the algorithm.
·     The local and remote identity authentication methods.
¡     To use the preshared key authentication method, you must determine the preshared key.
¡     To use the RSA digital signature authentication method, you must determine the PKI domain for the local end to use. For information about PKI, see "Configuring PKI."
An IKEv2 profile is intended to provide a set of parameters for IKEv2 negotiation.
2.     Create an IKEv2 profile and enter its view.
ikev2 profile profile-name
The local and remote identity authentication methods must both be specified and they can be different. You can specify only one local identity authentication method and multiple remote identity authentication methods.
2.     Enter IKEv2 profile view.
3.     Specify the local and remote identity authentication methods.
authentication-method { local | remote } { dsa-signature | ecdsa-signature | pre-share | rsa-signature }
By default, no local or remote identity authentication method is configured.
Configure the IKEv2 keychain or PKI domain for the IKEv2 profile to use. To use digital signature authentication, configure a PKI domain. To use preshared key authentication, configure an IKEv2 keychain.
certificate domain domain-name [ sign | verify ]
By default, no IKEv2 keychain or PKI domain is specified for an IKEv2 profile.
For digital signature authentication, the device can use an ID of any type. If the local ID is an IP address that is different from the IP address in the local certificate, the device uses the FQDN as the local ID. The FQDN is the device name configured by using the sysname command.
identity local { address { ipv4-address | ipv6 ipv6-address } | dn | email email-string | fqdn fqdn-name | key-id key-id-string }
By default, no local ID is configured, and the device uses the IP address of the interface where the IPsec policy applies as the local ID.
Perform this task to configure the peer ID for IKEv2 profile matching. When the device needs to select an IKEv2 profile for IKEv2 negotiation with a peer, it compares the received peer ID with the peer IDs of its local IKE profiles. If a match is found, it uses the IKEv2 profile with the matching peer ID for negotiation. IKEv2 profiles will be compared in descending order of their priorities.
3.     Configure a peer ID.
match remote { certificate policy-name | identity { address { { ipv4-address [ mask | mask-length ] | range low-ipv4-address high-ipv4-address } | ipv6 { ipv6-address [ prefix-length ] | range low-ipv6-address high-ipv6-address } } | fqdn fqdn-name | email email-string | key-id key-id-string } }
You must configure a minimum of one peer ID on each of the two peers.
After you specify a VPN instance for an IKEv2 profile, the IKEv2 profile can be used for IKEv2 negotiation only on the interfaces that belong to the VPN instance.
3.     Specify a VPN instance for the IKEv2 profile.
match vrf { name vrf-name | any }
By default, an IKEv2 profile belongs to the public network.
The inside VPN instance determines where the device should forward received IPsec packets after it de-encapsulates the packets. If you specify an inside VPN instance, the device looks for a route in the specified VPN instance to forward the packets. If you do not specify an inside VPN instance, the internal and external networks are in the same VPN instance. The device looks for a route in this VPN instance to forward the packets.
The inside VPN instance specified in an IKEv2 profile takes effect only on IPsec policies that use the IKEv2 profile. It does not take effect on IPsec profiles that use the IKEv2 profile.
The VPN instances specified in the rules of an ACL for an IPsec policy must be the same. The inside VPN instance of the IKEv2 profile used by the IPsec policy must be the same as the VPN instance specified in the ACL.
inside-vrf vrf-name
By default, no inside VPN instance is specified for an IKEv2 profile. The internal and external networks are in the same VPN instance. The device forwards protected data to this VPN instance.
¡     Configure IKEv2 DPD.
By default, IKEv2 DPD is not configured for an IKEv2 profile and an IKEv2 profile uses the DPD settings configured in system view. If IKEv2 DPD is not configured in system view either, the device does not perform dead IKEv2 peer detection.
¡     Specify the local interface or IP address to which the IKEv2 profile can be applied.
match local address { interface-type interface-number | ipv4-address | ipv6 ipv6-address }
By default, an IKEv2 profile can be applied to any local interface or local IP address.
Use this command to specify which address or interface can use the IKEv2 profile for IKEv2 negotiation. Specify the local address configured in IPsec policy or IPsec policy template view (using the local-address command) for this command. If no local address is configured, specify the IP address of the interface that uses the IPsec policy.
¡     Specify a priority for the IKEv2 profile.
priority priority
By default, the priority of an IKEv2 profile is 100.
When the device needs to select an IKEv2 profile for IKEv2 negotiation with a peer, it compares the received peer ID with the peer ID of its local IKEv2 profiles in descending order of their priorities
¡     Set the IKEv2 SA lifetime for the IKEv2 profile.
sa duration seconds
By default, the IKEv2 SA lifetime is 86400 seconds.
The local and remote ends can use different IKEv2 SA lifetimes and they do not negotiate the lifetime. The end with a smaller SA lifetime will initiate an SA negotiation when the lifetime expires.
¡     Set the IKEv2 NAT keepalive interval.
By default, the global IKEv2 NAT keepalive setting is used.
Configure this command when the device is behind a NAT gateway. The device sends NAT keepalive packets regularly to its peer to prevent the NAT session from being aged because of no matching traffic.
¡     Enable the configuration exchange feature.
config-exchange { request | set { accept | send } }
By default, all configuration exchange options are disabled.
This feature applies to scenarios where the headquarters and branches communicate through virtual tunnels. It enables exchanges of IP address request and set messages between the IPsec gateway at a branch and the IPsec gateway at the headquarters.
Table 2 Parameter descriptions
Parameter
request
Enables the IPsec gateway at a branch to submit IP address request messages to the IPsec gateway at the headquarters.
set accept
Enables the IPsec gateway at a branch to accept the IP addresses pushed by the IPsec gateway at the headquarters.
set send
Enables the IPsec gateway at the headquarters to push IP addresses to IPsec gateways at branches.
The AAA authorization feature enables IKEv2 to request authorization attributes, such as the IKEv2 address pool, from AAA. IKEv2 uses the address pool to assign IP addresses to remote users. For more information about AAA authorization, see "Configuring AAA."
During the IKE_SA_INIT exchange, each end tries to find a matching IKEv2 policy, using the IP address of the local security gateway as the matching criterion.
·     If IKEv2 policies are configured, IKEv2 searches for an IKEv2 policy that uses the IP address of the local security gateway. If no IKEv2 policy uses the IP address or the policy is using an incomplete proposal, the IKE_SA_INIT exchange fails.
·     If no IKEv2 policy is configured, IKEv2 uses the system default IKEv2 policy default.
The device matches IKEv2 policies in the descending order of their priorities. To determine the priority of an IKEv2 policy:
1.     First, the device examines the existence of the match local address command. An IKEv2 policy with the match local address command configured has a higher priority.
2.     If a tie exists, the device compares the priority numbers. An IKEv2 policy with a smaller priority number has a higher priority.
3.     If a tie still exists, the device prefers an IKEv2 policy configured earlier.
2.     Create an IKEv2 policy and enter its view.
ikev2 policy policy-name
By default, an IKEv2 policy named default exists.
3.     Specify the local interface or address used for IKEv2 policy matching.
By default, no local interface or address is used for IKEv2 policy matching, and the policy matches any local interface or address.
4.     Specify a VPN instance for IKEv2 policy matching.
By default, no VPN instance is specified for IKEv2 policy matching. The IKEv2 policy matches all local addresses in the public network.
5.     Specify an IKEv2 proposal for the IKEv2 policy.
proposal proposal-name
By default, no IKEv2 proposal is specified for an IKEv2 policy.
6.     Specify a priority for the IKEv2 policy.
priority priority
By default, the priority of an IKEv2 policy is 100.
An IKEv2 proposal contains security parameters used in IKE_SA_INIT exchanges, including the encryption algorithms, integrity protection algorithms, PRF algorithms, and DH groups. An algorithm specified earlier has a higher priority.
A complete IKEv2 proposal must have at least one set of security parameters, including one encryption algorithm, one integrity protection algorithm, one PRF algorithm, and one DH group.
You can specify multiple IKEv2 proposals for an IKEv2 policy. A proposal specified earlier has a higher priority.
2.     Create an IKEv2 proposal and enter its view.
ikev2 proposal proposal-name
By default, an IKEv2 proposal named default exists.
The default proposal uses the following settings:
¡     Encryption algorithms AES-CBC-128 and 3DES.
¡     Integrity protection algorithms HMAC-SHA1 and HMAC-MD5.
¡     PRF algorithms HMAC-SHA1 and HMAC-MD5.
¡     DH groups 2 and 5.
3.     Specify the encryption algorithms.
encryption { 3des-cbc | aes-cbc-128 | aes-cbc-192 | aes-cbc-256 | aes-ctr-128 | aes-ctr-192 | aes-ctr-256 | camellia-cbc-128 | camellia-cbc-192 | camellia-cbc-256 | des-cbc } *
By default, an IKEv2 proposal does not have any encryption algorithms.
4.     Specify the integrity protection algorithms.
integrity { aes-xcbc-mac | md5 | sha1 | sha256 | sha384 | sha512 } *
By default, an IKEv2 proposal does not have any integrity protection algorithms.
5.     Specify the DH groups.
dh { group1 | group14 | group2 | group24 | group5 | group19 | group20 } *
By default, an IKEv2 proposal does not have any DH groups.
6.     Specify the PRF algorithms.
prf { aes-xcbc-mac | md5 | sha1 | sha256 | sha384 | sha512 } *
By default, an IKEv2 proposal uses the integrity protection algorithms as the PRF algorithms.
An IKEv2 keychain specifies the preshared keys used for IKEv2 negotiation.
An IKEv2 keychain can have multiple IKEv2 peers. Each peer has a symmetric preshared key or an asymmetric preshared key pair, and information for identifying the peer (such as the peer's host name, IP address or address range, or ID).
An IKEv2 negotiation initiator uses the peer host name or IP address/address range as the matching criterion to search for a peer. A responder uses the peer host IP address/address range or ID as the matching criterion to search for a peer.
2.     Create an IKEv2 keychain and enter its view.
ikev2 keychain keychain-name
3.     Create an IKEv2 peer and enter its view.
peer name
4.     Configure a host name for the peer:
hostname name
By default, no host name is configured for an IKEv2 peer.
5.     Configure a host IP address or address range for the peer:
address { ipv4-address [ mask | mask-length ] | ipv6 ipv6-address [ prefix-length ] }
By default, no host IP address or address range is configured for an IKEv2 peer.
You must configure different host IP addresses/address ranges for different peers.
6.     Configure an ID for the peer:
identity { address { ipv4-address | ipv6 { ipv6-address } } | fqdn fqdn-name | email email-string | key-id key-id-string }
By default, no identity information is configured for an IKEv2 peer.
7.     Configure a preshared key for the peer.
pre-shared-key [ local | remote ] { ciphertext | plaintext } string
By default, an IKEv2 peer does not have a preshared key.
Configure global IKEv2 parameters
Enable cookie challenging on responders to protect them against DoS attacks that use a large number of source IP addresses to forge IKE_SA_INIT requests.
2.     Enable IKEv2 cookie challenging.
ikev2 cookie-challenge number
By default, IKEv2 cookie challenging is disabled.
IKEv2 DPD detects dead IKEv2 peers in periodic or on-demand mode.
·     Periodic IKEv2 DPD—Verifies the liveness of an IKEv2 peer by sending DPD messages at regular intervals.
·     On-demand IKEv2 DPD—Verifies the liveness of an IKEv2 peer by sending DPD messages before sending data.
¡     Before the device sends data, it identifies the time interval for which the last IPsec packet has been received from the peer. If the time interval exceeds the DPD interval, it sends a DPD message to the peer to detect its liveliness.
¡     If the device has no data to send, it never sends DPD messages.
If you configure IKEv2 DPD in both IKEv2 profile view and system view, the IKEv2 DPD settings in IKEv2 profile view apply. If you do not configure IKEv2 DPD in IKEv2 profile view, the IKEv2 DPD settings in system view apply.
2.     Configure global IKEv2 DPD.
ikev2 dpd interval interval [ retry seconds ] { on-demand | periodic }
By default, global DPD is disabled.
Configure this feature on the IKEv2 gateway behind the NAT device. The gateway then sends NAT keepalive packets regularly to its peer to keep the NAT session alive, so that the peer can access the device.
The NAT keepalive interval must be shorter than the NAT session lifetime.
This feature takes effect after the device detects the NAT device.
2.     Set the IKEv2 NAT keepalive interval.
ikev2 nat-keepalive seconds
By default, the IKEv2 NAT keepalive interval is 10 seconds.
You must use an IKEv2 address pool together with AAA authorization by specifying the IKEv2 address pool as an AAA authorization attribute. For more information about AAA authorization, see "Configuring AAA."
2.     Configure an IKEv2 IPv4 address pool.
ikev2 address-group group-name start-ipv4-address end-ipv4-address [ mask | mask-length ]
3.     Configure an IKEv2 IPv6 address pool.
ikev2 ipv6-address-group group-name prefix prefix/prefix-len assign-len assign-len
Setting a limit to the number of IKEv2 SAs
You can use this feature to limit the maximum number of negotiating IKEv2 SAs.
The supported maximum number of negotiating IKEv2 SAs depends on the device's processing capability. Adjust the maximum number of negotiating IKEv2 SAs to make full use of the device's processing capability without affecting the IKEv2 SA negotiation efficiency.
2.     Set a limit to the number of IKEv2 SAs.
ikev2 limit max-negotiating-sa negotiation-limit
By default, no limit is set to the number of IKEv2 SAs.
Display and maintenance commands for IKEv2
Display the IKEv2 policy configuration.
display ikev2 policy [ policy-name | default ]
Display the IKEv2 profile configuration.
display ikev2 profile [ profile-name ]
Display the IKEv2 proposal configuration.
display ikev2 proposal [ name | default ]
Display the IKEv2 SA information.
display ikev2 sa [ count | [ { local | remote } { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ verbose [ tunnel tunnel-id ] ] ]
Display IKEv2 statistics.
display ikev2 statistics
Delete IKEv2 SAs and the child SAs negotiated through the IKEv2 SAs.
reset ikev2 sa [ [ { local | remote } { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] | tunnel tunnel-id ] [ fast ]
Clear IKEv2 statistics.
reset ikev2 statistics
Troubleshooting IKEv2
IKEv2 negotiation failed because no matching IKEv2 proposals were found
Symptom
The IKEv2 SA is in IN-NEGO status.
<Sysname> display ikev2 sa
Tunnel ID   Local                       Remote                      Status
  5           123.234.234.124/500         123.234.234.123/500         IN-NEGO
Status:
IN-NEGO: Negotiating, EST: Established, DEL:Deleting
Analysis
Certain IKEv2 proposal settings are incorrect.
Solution
1.     Examine the IKEv2 proposal configuration to see whether the two ends have matching IKEv2 proposals.
2.     Modify the IKEv2 proposal configuration to make sure the two ends have matching IKEv2 proposals.
Symptom
The display ikev2 sa command shows that the IKEv2 SA negotiation succeeded and the IKEv2 SA is in EST status. The display ipsec sa command shows that the expected IPsec SAs have not been negotiated yet.
Analysis
Solution
IPsec tunnel establishment failed
Symptom
The ACLs and IKEv2 proposals are correctly configured on both ends. The two ends cannot establish an IPsec tunnel or cannot communicate through the established IPsec tunnel.
Analysis
The IKEv2 SA or IPsec SAs on either end are lost. The reason might be that the network is unstable and the device reboots.
Solution
1.     Use the display ikev2 sa command to examine whether an IKEv2 SA exists on both ends. If the IKEv2 SA on one end is lost, delete the IKEv2 SA on the other end by using the reset ikev2 sa command and trigger new negotiation. If an IKEv2 SA exists on both ends, go to the next step.
2.     Use the display ipsec sa command to examine whether IPsec SAs exist on both ends. If the IPsec SAs on one end are lost, delete the IPsec SAs on the other end by using the reset ipsec sa command and trigger new negotiation.
