10-MPLS Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5580X-EI[HI] & S5580S-EI Switch Series Configuration Guides-R1330Pxx-6W10010-MPLS Configuration Guide
04-MPLS L3VPN configuration
04-MPLS L3VPN configuration 2.09 MB
Configuring MPLS L3VPN·· 1
About MPLS L3VPN· 1
Basic MPLS L3VPN architecture· 1
MPLS L3VPN concepts· 1
MPLS L3VPN route advertisement 3
MPLS L3VPN packet forwarding· 4
MPLS L3VPN networking schemes· 5
Inter-AS VPN· 7
Carrier's carrier 12
Nested VPN· 13
Multirole host 14
OSPF VPN extension· 15
BGP AS number substitution and SoO attribute· 17
ECMP VPN route redistribution· 18
Protocols and standards· 19
MPLS L3VPN tasks at a glance· 19
Prerequisites for MPLS L3VPN· 20
Configuring VPN instances· 20
Creating a VPN instance· 20
Associating a VPN instance with a Layer 3 interface· 22
Configuring route related attributes for a VPN instance· 22
Configuring routing between a PE and a CE· 23
Configuring static routing between a PE and a CE· 23
Configuring RIP between a PE and a CE· 23
Configuring OSPF between a PE and a CE· 24
Configuring IS-IS between a PE and a CE· 25
Configuring EBGP between a PE and a CE· 26
Configuring IBGP between a PE and a CE· 27
Configuring routing between PEs· 28
Configuring BGP VPNv4 route control 29
About BGP VPNv4 route control 29
Controlling BGP VPNv4 route advertisement, reception, and saving· 29
Setting a preferred value for received routes· 29
Configuring BGP VPNv4 route reflection· 30
Configuring BGP VPNv4 route attributes· 30
Configuring BGP VPNv4 route filtering· 31
Configuring BGP VPNv4 route dampening· 32
Configuring BGP VPNv4 routes to use private network next hops· 33
Configuring BGP VPNv4 optimal route selection delay· 33
Preferring routes learned from the specified peer or peer group during optimal route selection· 34
Advertising BGP RPKI validation state to a peer or peer group· 34
Configuring inter-AS VPN· 35
Configuring inter-AS option A· 35
Configuring inter-AS option B· 35
Configuring inter-AS option C (method 1) 36
Configuring inter-AS option C (method 2) 39
Configuring nested VPN· 41
Configuring multirole host 42
About configuring multirole host 42
Configuring and applying PBR· 43
Configuring a static route· 43
Specifying the VPN label processing mode on the egress PE· 43
Configuring a TTL processing mode for tunnels associated with a VPN instance· 44
Configuring BGP AS number substitution and SoO attribute· 45
Configuring BGP RT filtering· 45
Restrictions and guidelines for configuring BGP RT filtering· 46
Enabling the device to exchange IPv4 RT filter routing information with a peer or peer group· 46
Controlling IPv4 RT filter route advertisement, reception, and selection· 46
Applying the export routing policy to VPNv4 routes before RT filtering· 47
Configuring the BGP additional path feature· 47
Configuring link bandwidth attributes for BGP VPNv4 routes· 48
Enabling independent routing tables for BGP VPNv4 routes and BGP-VPN instance routes· 51
Configuring the rule for adding BGP routes to the IP routing table and the route advertisement rule for VPN instances  54
Minimizing the priority of BGP routes advertised to peers· 56
Minimizing the priority of BGP routes advertised to peers with a down-to-up state change· 56
Minimizing the priority of BGP routes advertised to peers after a device reboot 59
Restoring the priority of advertised BGP routes· 61
Specifying a local network to be advertised in the public instance or a VPN instance· 61
Configuring route replication· 62
Configuring the public instance· 62
Configuring route replication for public instance and VPN instance· 63
Configuring BGP route replication between public and VPN instances· 64
Configuring route re-origination· 65
Enabling ECMP VPN route redistribution· 66
Enabling prioritized withdrawal of specific routes· 67
Configuring BGP next hop recursion based on a routing policy· 68
Configuring a VPN peer 69
Enabling SNMP notifications for MPLS L3VPN· 69
Enabling logging for BGP route flapping· 70
Verifying and maintaining MPLS L3VPN· 70
Verifying MPLS L3VPN configuration and running status· 70
Displaying and clearing MPLS label forwarding statistics· 73
Displaying and clearing BGP VPNv4 route dampening parameters· 73
Displaying and clearing BGP VPNv4 route flapping statistics· 73
Resetting BGP sessions· 73
MPLS L3VPN configuration examples· 74
Example: Configuring basic MPLS L3VPN· 74
Example: Configuring an MPLS L3VPN over a GRE tunnel 79
Example: Configuring a hub-spoke network· 83
Example: Configuring MPLS L3VPN inter-AS option A· 89
Example: Configuring MPLS L3VPN inter-AS option B· 94
Example: Configuring MPLS L3VPN inter-AS option C (method 1) 99
Example: Configuring MPLS L3VPN inter-AS option C (method 2) 106
Example: Configuring MPLS L3VPN carrier's carrier in the same AS· 112
Example: Configuring MPLS L3VPN carrier's carrier in different ASs· 119
Example: Configuring nested VPN· 126
Example: Configuring multirole host 135
Example: Configuring BGP AS number substitution· 137
Example: Configuring BGP AS number substitution and SoO attribute· 141
About MPLS L3VPN
MPLS L3VPN is a L3VPN technology used to interconnect geographically dispersed VPN sites. MPLS L3VPN uses BGP to advertise VPN routes and uses MPLS to forward VPN packets over a service provider backbone. MPLS L3VPN provides flexible networking modes, excellent scalability, and convenient support for MPLS QoS and MPLS TE.
As shown in Figure 1, a basic MPLS L3VPN architecture has the following types of devices:
·     Customer edge device—A CE device resides on a customer network and has one or more interfaces directly connected to a service provider network. It does not support MPLS.
·     Provider edge device—A PE device resides at the edge of a service provider network and is connected to one or more CEs. All MPLS VPN services are processed on PEs.
·     Provider device—A P device is a core device on a service provider network. It is not directly connected to any CEs. A P device has only basic MPLS forwarding capability and does not handle VPN routing information.
Figure 1 Basic MPLS L3VPN architecture
MPLS L3VPN concepts
Site
A site has the following features:
·     A site is a group of IP systems with IP connectivity that does not rely on any service provider networks.
·     The classification of a site depends on the topology relationship of the devices, rather than the geographical positions. However, the devices at a site are, in most cases, adjacent to each other geographically.
·     The devices at a site can belong to multiple VPNs, which means that a site can belong to multiple VPNs.
·     A site is connected to a provider network through one or more CEs. A site can contain multiple CEs, but a CE can belong to only one site.
Sites connected to the same provider network can be classified into different sets by policies. Only the sites in the same set can access each other through the provider network. Such a set is called a VPN.
VPN instance
VPN instances implement route isolation, data independence, and data security for VPNs.
A VPN instance has the following components:
·     A separate Label Forwarding Information Base (LFIB).
·     An IP routing table.
·     Interfaces bound to the VPN instance.
·     VPN instance administration information, including route distinguishers (RDs), route targets (RTs), and route filtering policies.
To associate a site with a VPN instance, bind the VPN instance to the PE's interface connected to the site. A site can be associated with only one VPN instance, and different sites can be associated with the same VPN instance. A VPN instance contains the VPN membership and routing rules of associated sites.
VPN-IPv4 address
Each VPN independently manages its address space. The address spaces of VPNs might overlap. For example, if both VPN 1 and VPN 2 use the addresses on subnet 10.110.10.0/24, address space overlapping occurs.
BGP cannot process overlapping VPN address spaces. For example, if both VPN 1 and VPN 2 use the subnet 10.110.10.0/24 and each advertise a route destined for the subnet, BGP selects only one of them. This results in the loss of the other route.
Multiprotocol BGP (MP-BGP) can solve this problem by advertising VPN-IPv4 addresses (also called VPNv4 addresses).
Figure 2 VPN-IPv4 address structure
As shown in Figure 2, a VPN-IPv4 address consists of 12 bytes. The first eight bytes represent the RD, followed by a four-byte IPv4 prefix. The RD and the IPv4 prefix form a unique VPN-IPv4 prefix.
An RD can be in one of the following formats:
·     When the Type field is 0, the Administrator subfield occupies two bytes, the Assigned number subfield occupies four bytes, and the RD format is 16-bit AS number:32-bit user-defined number. For example, 100:1.
·     When the Type field is 1, the Administrator subfield occupies four bytes, the Assigned number subfield occupies two bytes, and the RD format is 32-bit IPv4 address:16-bit user-defined number. For example, 172.1.1.1:1.
·     When the Type field is 2, the Administrator subfield occupies four bytes, the Assigned number subfield occupies two bytes, and the RD format is 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
To guarantee global uniqueness for a VPN-IPv4 address, do not set the Administrator subfield to any private AS number or private IP address.
Route target attribute
MPLS L3VPN uses route target (also called VPN target) community attributes to control the advertisement of VPN routing information. A VPN instance on a PE supports the following types of route target attributes:
·     Export target attribute—A PE sets the export target attribute for VPN-IPv4 routes learned from directly connected sites before advertising them to other PEs.
·     Import target attribute—A PE checks the export target attribute of VPN-IPv4 routes received from other PEs. If the export target attribute matches the import target attribute of a VPN instance, the PE adds the routes to the routing table of the VPN instance.
Route target attributes define which sites can receive VPN-IPv4 routes, and from which sites a PE can receive routes.
Like RDs, route target attributes can be one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 100:1.
·     32-bit IPv4 address:16-bit user-defined number. For example, 172.1.1.1:1.
·     32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
MP-BGP
MP-BGP supports multiple address families, including IPv4 multicast and VPN-IPv4 address families.
In MPLS L3VPN, MP-BGP advertises VPN-IPv4 routes for VPN sites between PEs.
In a basic MPLS L3VPN, CEs and PEs are responsible for advertising VPN routing information. P routers maintain only the routes within the backbone. A PE maintains only routing information for directly connected VPNs, rather than for all VPNs.
VPN routing information is advertised through the path local CE—ingress PE—egress PE—remote CE.
Route advertisement from the local CE to the ingress PE
The CE advertises standard IPv4 routing information to the ingress PE over a static route, RIP route, OSPF route, IS-IS route, EBGP route, or IBGP route.
Route advertisement from the ingress PE to the egress PE
The ingress PE performs the following operations:
1.     Adds RDs and route target attributes to these standard IPv4 routes to create VPN-IPv4 routes.
2.     Saves the VPN-IPv4 routes to the routing table of the VPN instance created for the CE.
3.     Advertises the VPN-IPv4 routes to the egress PE through MP-BGP.
Route advertisement from the egress PE to the remote CE
After receiving the VPN-IPv4 routes, the egress PE performs the following operations:
1.     Compares the routes' export target attributes with the local import target attributes.
2.     Adds the routes to the routing table of the VPN instance if the export and local import target attributes match each other.
3.     Restores the VPN-IPv4 routes to the original IPv4 routes.
4.     Advertises those routes to the connected CE over a static route, RIP route, OSPF route, IS-IS route, EBGP route, or IBGP route.
In a basic MPLS L3VPN (within a single AS), a PE adds the following information into VPN packets:
·     Outer tag—Identifies the public tunnel from the local PE to the remote PE. The public tunnel can be an LSP, an MPLS TE tunnel, or a GRE tunnel. Based on the outer tag, a VPN packet can be forwarded along the public tunnel to the remote PE. For a GRE public tunnel, the outer tag is the GRE encapsulation. For an LSP or MPLS TE tunnel, the outer tag is an MPLS label.
In the current software version, the device does not support using GRE/IPv6 tunnels as public tunnels for MPLS L3VPN.
·     Inner label—Identifies the remote VPN site. The remote PE uses the inner label to forward packets to the target VPN site. MP-BGP advertises inner labels for VPN-IPv4 routes among PEs.
Figure 3 VPN packet forwarding
As shown in Figure 3, a VPN packet is forwarded from Site 1 to Site 2 by using the following process:
1.     Site 1 sends an IP packet with the destination address 1.1.1.2. CE 1 transmits the packet to PE 1.
2.     PE 1 performs the following operations:
a.     Finds the matching VPN route based on the inbound interface and destination address of the packet.
b.     Labels the packet with both the inner label and the outer tag.
c.     Forwards the packet to the public tunnel.
3.     P devices forward the packet to PE 2 by the outer tag.
¡     If the outer tag is an MPLS label, the label is removed from the packet at the penultimate hop.
¡     If the outer tag is GRE encapsulation, PE 2 removes the GRE encapsulation.
4.     PE 2 performs the following operations:
a.     Uses the inner label to find the matching VPN instance to which the destination address of the packet belongs.
b.     Looks up the routing table of the VPN instance for the output interface.
c.     Removes the inner label and forwards the packet out of the interface to CE 2.
5.     CE 2 transmits the packet to the destination through IP forwarding.
When two sites of a VPN are connected to the same PE, the PE directly forwards packets between the two sites through the VPN routing table without adding any tag or label.
In MPLS L3VPNs, route target attributes are used to control the advertisement and reception of VPN routes between sites. They work independently and can be configured with multiple values to support flexible VPN access control and implement multiple types of VPN networking schemes.
Basic VPN networking scheme
In the simplest case, all users in a VPN form a closed user group. They can forward traffic to each other but cannot communicate with any user outside the VPN.
For the basic VPN networking scheme, you must assign a route target to each VPN for identifying the export target attribute and import target attribute of the VPN. Moreover, this route target cannot be used by any other VPNs.
Figure 4 Network diagram for basic VPN networking scheme
As shown in Figure 4, the route target for VPN 1 is 100:1, while that for VPN 2 is 200:1. The two VPN 1 sites can communicate with each other, and the two VPN 2 sites can communicate with each other. However, the VPN 1 sites cannot communicate with the VPN 2 sites.
Hub and spoke networking scheme
The hub and spoke networking scheme is suitable for a VPN where all users must communicate with each other through an access control device.
In a hub and spoke network as shown in Figure 5, configure route targets as follows:
·     On spoke PEs (PEs connected to spoke sites), set the export target to Spoke and the import target to Hub.
·     On the hub PE (PE connected to the hub site), use two interfaces that each belong to a different VPN instance to connect the hub CE. One VPN instance receives routes from spoke PEs and has the import target set to Spoke. The other VPN instance advertises routes to spoke PEs and has the export target set to Hub.
These route targets rules produce the following results:
·     The hub PE can receive all VPN-IPv4 routes from spoke PEs.
·     All spoke PEs can receive VPN-IPv4 routes advertised by the hub PE.
·     The hub PE advertises the routes learned from a spoke PE to the other spoke PEs so the spoke sites can communicate with each other through the hub site.
·     The import target attribute of a spoke PE is different from the export target attribute of any other spoke PE. Any two spoke PEs do not directly advertise VPN-IPv4 routes to each other. Therefore, they cannot directly access each other.
Figure 5 Network diagram for hub and spoke network
A route in Site 1 is advertised to Site 2 by using the following process:
1.     Spoke-CE 1 advertises a route in Site 1 to Spoke-PE 1.
2.     Spoke-PE 1 changes the route to a VPN-IPv4 route and advertises the VPN-IPv4 route to Hub-PE through MP-BGP.
3.     Hub-PE adds the VPN-IPv4 route into the routing table of VPN 1-in, changes it to the original IPv4 route, and advertises the IPv4 route to Hub-CE.
4.     Hub-CE advertises the IPv4 route back to Hub-PE.
5.     Hub-PE adds the IPv4 route to the routing table of VPN 1-out, changes it to a VPN-IPv4 route, and advertises the VPN-IPv4 route to Spoke-PE 2 through MP-BGP.
6.     Spoke-PE 2 changes the VPN-IPv4 route to the original IPv4 route, and advertises the IPv4 route to Site 2.
After spoke sites exchange routes through the hub site, they can communicate with each other through the hub site.
Extranet networking scheme
The extranet networking scheme allows specific resources in a VPN to be accessed by users not in the VPN.
In this networking scheme, if a VPN instance needs to access a shared site, the export target attribute and the import target attribute of the VPN instance must be contained in the import target attribute and the export target attribute of the VPN instance of the shared site, respectively.
Figure 6 Network diagram for extranet networking scheme
As shown in Figure 6, route targets configured on PEs produce the following results:
·     PE 3 can receive VPN-IPv4 routes from PE 1 and PE 2.
·     PE 1 and PE 2 can receive VPN-IPv4 routes advertised by PE 3.
·     Site 1 and Site 3 of VPN 1 can communicate with each other, and Site 2 of VPN 2 and Site 3 of VPN 1 can communicate with each other.
·     PE 3 advertises neither the VPN-IPv4 routes received from PE 1 to PE 2 nor the VPN-IPv4 routes received from PE 2 to PE 1 (routes learned from an IBGP neighbor are not advertised to any other IBGP neighbor). Therefore, Site 1 of VPN 1 and Site 2 of VPN 2 cannot communicate with each other.
Inter-AS VPN
In an inter-AS VPN networking scenario, multiple sites of a VPN are connected to multiple ISPs in different ASs, or to multiple ASs of an ISP.
Inter AS-VPN provides the following solutions:
·     VRF-to-VRF connections between ASBRs—This solution is also called inter-AS option A.
·     EBGP redistribution of labeled VPN-IPv4 routes between ASBRs—ASBRs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option B.
·     Multihop EBGP redistribution of labeled VPN-IPv4 routes between PE routers—PEs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option C.
Inter-AS option A
In this solution, PEs of two ASs are directly connected, and each PE is also the ASBR of its AS. Each PE treats the other as a CE and advertises unlabeled IPv4 unicast routes through EBGP. The PEs associate a VPN instance with a minimum of one interface.
Figure 7 Network diagram for inter-AS option A
As shown in Figure 7, in VPN 1, routes are advertised from CE 1 to CE 3 by using the following process:
1.     PE 1 advertises the VPN routes learned from CE 1 to ASBR 1 through MP-IBGP.
2.     ASBR 1 performs the following operations:
a.     Adds the routes to the routing table of the VPN instance whose import target attribute matches the export target attribute of the routes.
b.     Advertises the routes as IPv4 unicast routes to its CE (ASBR 2) through EBGP.
3.     ASBR 2 adds the IPv4 unicast routes to the routing table of the VPN instance that is bound to the receiving interface, and advertises the routes to PE 3 through MP-IBGP.
4.     PE 3 advertises the received routes to CE 3.
Packets forwarded within an AS are VPN packets that carry two labels. Packets forwarded between ASBRs are common IP packets.
Inter-AS option A is easy to carry out because no special configuration is required on the PEs acting as the ASBRs.
However, it has limited scalability because the PEs acting as the ASBRs must manage all the VPN routes and create VPN instances on a per-VPN basis. This leads to excessive VPN-IPv4 routes on the PEs. Associating a separate interface with each VPN also requires additional system resources.
Inter-AS option B
In this solution, two ASBRs use MP-EBGP to exchange VPN-IPv4 routes that they obtain from the PEs in their respective ASs.
Figure 8 Network diagram for inter-AS option B
As shown in Figure 8, in VPN 1, routes are advertised from CE 1 to CE 3 by using the following process:
Assume that the inner label assigned by PE 1 for the routes is L1.
2.     ASBR 1 advertises the VPN-IPv4 routes to ASBR 2 through MP-EBGP.
Before advertising the routes, ASBR 1 modifies the next hop as its own address, assigns a new inner label (L2) to the routes, and associates L1 with L2.
3.     ASBR 2 advertises the VPN-IPv4 routes to PE 3 through MP-IBGP.
Before advertising the routes, ASBR 2 modifies the next hop as its own address, assigns a new inner label (L3) to the routes, and associates L2 with L3.
A packet is forwarded from CE 3 to CE 1 by using the following process:
5.     PE 3 encapsulates the received packet with two labels, and forwards the encapsulated packet to ASBR 2.
One of the labels is L3, and the other is the outer tag for the public tunnel from PE 3 to ASBR 2.
6.     ASBR 2 removes the outer tag, replaces L3 with L2, and forwards the packet to ASBR 1.
Packets between ASBR 1 and ASBR 2 carry only one inner label.
7.     ASBR 1 replaces L2 with L1, adds the outer tag of the public tunnel from ASBR 1 to PE 1, and forwards the packet to PE 1.
8.     PE 1 removes the inner label and outer tag and forwards the packet to CE 1.
In this solution, ASBRs must receive all inter-AS VPN routes. Therefore, ASBRs cannot filter incoming VPN-IPv4 routes by route targets.
Inter-AS option B has better scalability than option A. However, it requires that ASBRs maintain and advertise VPN routes.
Inter-AS option C
The Inter-AS option A and option B solutions require that the ASBRs maintain and advertise VPN-IPv4 routes. When every AS needs to exchange a great amount of VPN routes, the ASBRs might become bottlenecks, which hinders network extension. Inter-AS option C has better scalability because it makes PEs directly exchange VPN-IPv4 routes.
In this solution, PEs exchange VPN-IPv4 routes over a multihop MP-EBGP session. Each PE must have a route to the peer PE and a label for the route so that the inter-AS public tunnel between the PEs can be set up. Inter-AS option C sets up a public tunnel by using the following methods:
·     Method 1:
a.     The PE and the ASBR within an AS establish a public tunnel by using a label distribution protocol such as LDP.
b.     The local and remote ASBRs advertise labeled IPv4 unicast routes through BGP to establish an inter-AS public tunnel.
Labeled IPv4 unicast route advertisement refers to the process of assigning MPLS labels to IPv4 unicast routes and advertising IPv4 unicast routes and their labels.
·     Method 2:
In method 2, the PE and ASBR within an AS do not need to establish an IBGP peer relationship.
a.     The local ASBR redistributes IGP routes to the BGP routing table, assigns labels to the routes, and advertises the labeled routes to the remote ASBR.
b.     The remote ASBR redistributes BGP routes to the IGP routing table.
c.     The local and remote PEs then can learn the route s to reach each other. After the PEs learn the routes to each other, they establish a public tunnel by using a label distribution protocol such as LDP.
The following is an example of configuring inter-AS option C by using method 1.
Figure 9 Network diagram for inter-AS option C (method 1)
As shown in Figure 9, in VPN 1, routes are advertised from CE 1 to CE 3 by using the following process:
1.     PE 1 advertises the VPN routes learned from CE 1 as VPN-IPv4 routes to PE 3 through multihop MP-EBGP.
Assume that the inner label assigned by PE 1 for the routes is Lx.
2.     PE 3 advertises the received routes to CE 3.
Setting up an inter-AS public tunnel is difficult in this solution. A public tunnel, for example, the one from PE 3 to PE 1, is set up by using the following process:
3.     Within AS 100, the public tunnel from ASBR 1 to PE 1 is set up by using a label distribution protocol, for example, LDP.
Assume that the outgoing label for the public tunnel on ASBR 1 is L1.
4.     ASBR 1 advertises labeled IPv4 unicast routes to ASBR 2 through EBGP.
The route destined for PE 1 and the label (L2) assigned by ASBR 1 for the route are advertised from ASBR 1 to ASBR 2. The next hop of the route is ASBR 1. The public tunnel from ASBR 2 to ASBR 1 is set up. The incoming label for the public tunnel on ASBR 1 is L2.
5.     ASBR 2 advertises labeled IPv4 unicast routes to PE 3 through IBGP.
The route destined for PE 1 and the label (L3) assigned by ASBR 2 for the route are advertised from ASBR 2 to PE 3. The next hop for the route is ASBR 2. The public tunnel from PE 3 to ASBR 2 is set up. The incoming label for the public tunnel on ASBR 2 is L3, and the outgoing label is L2.
6.     MPLS packets cannot be forwarded directly from PE 3 to ASBR 2. Within AS 200, the public tunnel from PE 3 to ASBR 2 is required to be set up hop by hop through a label distribution protocol, for example, LDP.
Assume that the outgoing label for the public tunnel on PE 3 is Lv.
After route advertisement and public tunnel setup, a packet is forwarded from CE 3 to CE 1 by using the following process:
7.     PE 3 performs the following routing table lookups for the packet:
a.     Finds a matching route with next hop PE 1 and inner label Lx, and encapsulates the packet with label Lx.
b.     Finds the route to PE 1 with next hop ASBR 2 and label L3, and encapsulates the packet with label L3 as the outer label.
c.     Finds the route to ASBR 2 with outgoing label Lv, and encapsulates the packet with label Lv as the outmost label.
8.     AS 200 transmits the packet to ASBR 2 by the outmost label.
9.     ASBR 2 removes the outmost label, replaces L3 with L2, and forwards the packet to ASBR 1.
10.     ASBR 1 replaces L2 with L1, and forwards the packet.
11.     AS 100 transmits the packet to PE 1 by the outer label.
12.     PE 1 removes the outer label, and forwards the packet to CE 1 according to the inner label Lx.
As shown in Figure 10, to improve scalability, you can specify a route reflector (RR) in each AS to exchange VPN-IPv4 routes with PEs in the same AS. The RR in each AS maintains all VPN-IPv4 routes. The RRs in two ASs establish a multihop MP-EBGP session to advertise VPN-IPv4 routes.
Figure 10 Network diagram for inter-AS option C using RRs
Carrier's carrier
If a customer of an MPLS L3VPN service provider is also a service provider:
·     The MPLS L3VPN service provider is called the provider carrier or the Level 1 carrier.
·     The customer is called the customer carrier or the Level 2 carrier.
This networking model is referred to as carrier's carrier.
The PEs of the Level 2 carrier directly exchange customer networks over a BGP session. The Level 1 carrier only learns the backbone networks of the Level 2 carrier, without learning customer networks.
For packets between customer networks to travel through the Level 1 carrier, the PE of the Level 1 carrier and the CE of the Level 2 carrier must assign labels to the backbone networks of the Level 2 carrier. The CE of the Level 2 carrier is a PE within the Level 2 carrier network.
Follow these guidelines to assign labels:
·     If the PE and the CE are in the same AS, you must configure IGP and LDP between them. If they are in different ASs, you must configure MP-EBGP to assign labels to IPv4 unicast routes exchanged between them.
·     You must enable MPLS on the CE of the Level 2 carrier regardless of whether the PE and CE are in the same AS.
A Level 2 carrier can be an ordinary ISP or an MPLS L3VPN service provider.
As shown in Figure 11, when the customer carrier is an ordinary ISP, its PEs and CEs run IGP to communicate with each other. The PEs do not need to run MPLS. PE 3 and PE 4 exchange customer network routes (IPv4 unicast routes) through an IBGP session.
Figure 11 Scenario where the Level 2 carrier is an ISP
As shown in Figure 12, when the customer carrier is an MPLS L3VPN service provider, its PEs and CEs must run IGP and LDP to communicate with each other. PE 3 and PE 4 exchange customer network routes (VPN-IPv4 routes) through an MP-IBGP session.
Figure 12 Scenario where the Level 2 carrier is an MPLS L3VPN service provider
As a best practice, establish equal cost LSPs between the Level 1 carrier and the Level 2 carrier if equal cost routes exist between them.
Nested VPN
The nested VPN technology exchanges VPNv4 routes between PEs and CEs of the ISP MPLS L3VPN and allows a customer to manage its own internal VPNs. Figure 13 shows a nested VPN network. On the service provider's MPLS VPN network, there is a customer VPN named VPN A. The customer VPN contains two sub-VPNs, VPN A-1 and VPN A-2.
The service provider PEs consider the customer's network as a common VPN user and do not join any sub-VPNs. The service provider CE devices (CE 1 and CE 2) exchange VPNv4 routes including sub-VPN routing information with the service provider PEs, which implements the propagation of the sub-VPN routing information throughout the customer network.
The nested VPN technology supports both symmetric networking and asymmetric networking. Sites of the same VPN can have the same number or different numbers of internal VPNs. Nested VPN also supports multiple-level nesting of internal VPNs.
Figure 13 Network diagram for nested VPN
In a nested VPN network, routing information is propagated by using the following process:
1.     After receiving VPN routes from customer CEs, a customer PE advertises VPN-IPv4 routes to the provider CEs through MP-BGP.
2.     The provider CEs advertise the VPN-IPv4 routes to a provider PE through MP-BGP.
3.     After receiving a VPN-IPv4 route, the provider PE keeps the customer's internal VPN information, and appends the customer's MPLS VPN attributes on the service provider network. It replaces the RD of the VPN-IPv4 route with the RD of the customer's MPLS VPN on the service provider network. It also adds the export route-target (ERT) attribute of the customer's MPLS VPN on the service provider network to the extended community attribute list of the route. The internal VPN information for the customer is maintained on the provider PE.
4.     The provider PE advertises VPN-IPv4 routes carrying the comprehensive VPN information to the other PEs of the service provider.
5.     After another provider PE receives the VPN-IPv4 routes, it matches the VPN-IPv4 routes to the import targets of its local VPNs. Each local VPN accepts routes of its own and advertises them to provider CEs. If a provider CE (such as CE 7 and CE 8 in Figure 13) is connected to a provider PE through an IPv4 connection, the PE advertises IPv4 routes to the CE. If it is a VPN-IPv4 connection (a customer MPLS VPN network), the PE advertises VPN-IPv4 routes to the CE.
6.     After receiving VPN-IPv4 routes from the provider CE, a customer PE matches those routes to local import targets. Each customer VPN accepts only its own routes and advertises them to connected customer CEs (such as CE 3, CE 4, CE 5, and CE 6 in Figure 13).
Multirole host
Typically, hosts in the same VPN can communicate with each other, and those in different VPNs cannot. However, a host or server in a site might need to access VPNs in addition to the VPN to which the host or server belongs. To simplify configuration, you can use the multirole host feature.
The multirole host feature enables a PE to use PBR to provide multiple VPN access for a host or server. The host or server is called a multirole host.
Figure 14 Network diagram
As shown in Figure 14, the multirole host in site 1 needs to access both VPN 1 and VPN 2. Other hosts in site 1 only need to access VPN 1. To configure the multirole host feature, configure PE 1 as follows:
·     Create VPN instances vpn1 and vpn2 for VPN 1 and VPN 2, respectively.
·     Associate VPN instance vpn1 with the interface connected to CE 1.
·     Configure PBR to route packets from CE 1 first by the routing table of the associated VPN instance (vpn1). Then, if no matching route is found, route the packets according to the routing table of VPN instance vpn2. This configuration ensures that packets from Site 1 can be forwarded in both VPN 1 and VPN 2.
·     Configure a static route for VPN instance vpn2 to reach the multirole host. Specify the next hop of the route as the IP address of CE 1 and specify the VPN instance to which the next hop belongs as VPN 1. This configuration ensures that packets from VPN 2 can be routed to the multirole host.
Configure static routes for all VPN instances that the multirole host needs to access, except the associated VPN instance.
IMPORTANT
IMPORTANT:
IP addresses in all VPNs that the multirole host can access must not overlap.
OSPF VPN extension
This section describes the OSPF VPN extension. For more information about OSPF, see Layer 3—IP Routing Configuration Guide.
OSPF for VPNs on a PE
If OSPF runs between a CE and a PE to exchange VPN routes, the PE must support multiple OSPF instances to create independent routing tables for VPN instances. Each OSPF process is bound to a VPN instance. Routes learned by an OSPF process are added into the routing table of the bound VPN instance.
OSPF area configuration between a PE and a CE
The OSPF area between a PE and a CE can be either a non-backbone area or a backbone area.
In the OSPF VPN extension application, the MPLS VPN backbone is considered the backbone area (area 0). The area 0 of each site must be connected to the MPLS VPN backbone (physically connected or logically connected through a virtual link) because OSPF requires that the backbone area be contiguous.
BGP/OSPF interaction
If OSPF runs between PEs and CEs, each PE redistributes BGP routes to OSPF and advertises the routes to CEs through OSPF. OSPF considers the routes redistributed from BGP as external routes but the OSPF routes actually belong to  the same OSPF domain. This problem can be resolved by configuring the same domain ID for sites in an OSPF domain.
Figure 15 Network diagram for BGP/OSPF interaction
As shown in Figure 15, CE 11, CE 21, and CE 22 belong to the same VPN and the same OSPF domain.
Before domain ID configuration, VPN 1 routes are advertised from CE 11 to CE 21 and CE 22 by using the following process:
1.     PE 1 redistributes OSPF routes from CE 11 into BGP, and advertises the VPN routes to PE 2 through BGP.
2.     PE 2 redistributes the BGP routes to OSPF, and advertises them to CE 21 and CE 22 in AS External LSAs (Type 5) or NSSA External LSAs (Type 7).
After domain ID configuration, VPN 1 routes are advertised from CE 11 to CE 21 and CE 22 by using the following process:
3.     PE 1 redistributes OSPF routes into BGP, adds the domain ID to the redistributed BGP VPNv4 routes as a BGP extended community attribute, and advertises the routes to PE 2.
4.     PE 2 compares the domain ID in the received routes with the locally configured domain ID. If they are the same and the received routes are intra-area or inter-area routes, OSPF advertises these routes in Network Summary LSAs (Type 3). Otherwise, OSPF advertises these routes in AS External LSAs (Type 5) or NSSA External LSAs (Type 7).
Routing loop avoidance
Figure 16 Network diagram for routing loop avoidance
As shown in Figure 16, Site 1 is connected to two PEs. When a PE advertises VPN routes learned from MP-BGP to Site 1 through OSPF, the routes might be received by the other PE. This results in a routing loop.
OSPF VPN extension uses the following tags to avoid routing loops:
·     DN bit (for Type 3 LSAs)—When a PE redistributes BGP routes into OSPF and creates Type 3 LSAs, it sets the DN bit (down bit) for the LSAs. When receiving the Type 3 LSAs advertised by CE 11, the other PE ignores the LSAs whose DN bit is set to avoid routing loops.
·     Route tag (for Type 5 or 7 LSAs)—The two PEs use the same route tag. When a PE redistributes BGP routes into OSPF and creates Type 5 or 7 LSAs, it adds the route tag to the LSAs. When receiving the Type 5 or 7 LSAs advertised by CE 11, the other PE compares the route tag in the LSAs against the local route tag. If they are the same, the PE ignores the LSAs to avoid routing loops.
BGP detects routing loops by examining AS numbers. If EBGP runs between PE and CE, you must assign different AS numbers to geographically different sites or configure the BGP AS number substitution feature to ensure correct transmission of routing information.
The BGP AS number substitution feature allows geographically different CEs to use the same AS number. If the AS_PATH of a route contains the AS number of a CE, the PE replaces the AS number with its own AS number before advertising the route to that CE.
After you enable the BGP AS number substitution feature, the PE performs BGP AS number substitution for all routes and re-advertises them to connected CEs in the peer group.
Figure 17 Application of BGP AS number substitution and SoO attribute
As shown in Figure 17, both Site 1 and Site 2 use the AS number 800. AS number substitution is enabled on PE 2 for CE 2. Before advertising updates received from CE 1 to CE 2, PE 2 substitutes its own AS number 100 for the AS number 800. In this way, CE 2 can correctly receive the routing information from CE 1.
However, the AS number substitution feature also introduces a routing loop in Site 2 because route updates originated from CE 3 can be advertised back to Site 2 through PE 2 and CE 2. To remove the routing loop, you can configure the same SoO attribute on PE 2 for CE 2 and CE 3. PE 2 adds the SoO attribute to route updates received from CE 2 or CE 3, and checks the SoO attribute of route updates to be advertised to CE 2 or CE 3. The SoO attribute of the route updates from CE 3 is the same as the SoO attribute for CE 2, and PE 2 does not advertise route updates to CE 2.
For more information about the SoO attribute, see basic BGP configuration in Layer 3—IP Routing Configuration Guide.
This feature enables a VPN instance to redistribute all routes that have the same prefix and RD into its routing table. Based on the ECMP routes, the device can perform load sharing (as configured by the balance command). For more information about the balance command, see basic BGP configuration in Layer 3—IP Routing Command Reference.
Figure 18 Network diagram
As shown in Figure 18, CE 1 accesses the backbone network through VPN instance VPN1 created on PE 1. The RD of VPN instance VPN1 is 1:1. CE 2 accesses the backbone network through VPN instances created on PE 2 and PE 3. The VPN instances created on PE 2 and PE 3 have the same name VPN2 and the same RD 1:2. VPN instances VPN1 and VPN2 can communicate with each other.
Both PE 2 and PE 3 can advertise routes from CE 2 to PE 1, and the advertised routes have the same RD 1:2. By default, BGP redistributes only the optimal route into the routing table of VPN instance VPN1. After you enable this feature on VPN instance VPN1, BGP redistributes routes from both PE 2 and PE 3 to the routing table of VPN instance VPN1.
·     RFC 3107, Carrying Label Information in BGP-4
·     RFC 4360, BGP Extended Communities Attribute
·     RFC 4364, BGP/MPLS IP Virtual Private Networks (VPNs)
·     RFC 4577, OSPF as the Provider/Customer Edge Protocol for BGP/MPLS IP Virtual Private Networks (VPNs)
Unless otherwise indicated, configure MPLS L3VPN on PEs.
To configure MPLS L3VPN, perform the following tasks:
1.     Configuring MPLS L3VPN basics
a.     Configuring VPN instances
b.     Configuring routing between a PE and a CE
c.     Configuring routing between PEs
d.     (Optional.) Configuring BGP VPNv4 route control
2.     Configuring advanced MPLS L3VPN networks
¡     Configuring inter-AS VPN
Perform this task when sites of a VPN are connected to different ASs of an ISP.
¡     Configuring nested VPN
Deploy the nest VPN when a large number of VPNs exist and you want to hide from the outside of the customer internal VPNs.
¡     Configuring multirole host
Multirole host allows a host or server in a site to access multiple VPNs by configuring PBR on the PE.
3.     (Optional.) Specifying the VPN label processing mode on the egress PE
4.     (Optional.) Configuring a TTL processing mode for tunnels associated with a VPN instance
5.     (Optional.) Controlling route advertisement and reception in an MPLS L3VPN network
¡     Configuring BGP AS number substitution and SoO attribute
¡     Configuring BGP RT filtering
Perform this task to reduce the number of routes advertised in an MPLS L3VPN.
¡     Configuring the BGP additional path feature
Perform this task to enable BGP to advertise multiple routes with the same prefix and different next hops to a peer or peer group.
¡     Configuring link bandwidth attributes for BGP VPNv4 routes
¡     Enabling independent routing tables for BGP VPNv4 routes and BGP-VPN instance routes
¡     Configuring the rule for adding BGP routes to the IP routing table and the route advertisement rule for VPN instances
¡     Minimizing the priority of BGP routes advertised to peers
¡     Specifying a local network to be advertised in the public instance or a VPN instance
¡     Configuring route replication
Perform this task to enable a VPN instance to communicate with the public network or other VPN instances by replicating routes from the public network or other VPN instances.
¡     Enabling ECMP VPN route redistribution
Perform this task to enable a VPN instance to redistribute all routes that have the same prefix and RD into its routing table to perform load sharing.
¡     Enabling prioritized withdrawal of specific routes
Configure BGP to send withdrawal messages of specific routes prior to other routes to ensure fast route switchover and reduce the traffic interruption time for the specific routes.
¡     Configuring BGP next hop recursion based on a routing policy
6.     (Optional.) Configuring a VPN peer
7.     (Optional.) Maintaining MPLS L3VPN networks
¡     Enabling SNMP notifications for MPLS L3VPN
¡     Enabling logging for BGP route flapping
Before you configure basic MPLS L3VPN, perform the following tasks:
1.     Configure an IGP on the PEs and P devices to ensure IP connectivity within the MPLS backbone.
2.     Configure basic MPLS for the MPLS backbone.
3.     Configure MPLS LDP on the PEs and P devices to establish LDP LSPs.
All VPN instance configurations are performed on PEs.
A VPN instance is a collection of the VPN membership and routing rules of its associated site. A VPN instance might correspond to more than one VPN.
You can configure an RD in VPN instance view and each address family view of the VPN instance. The RD configured in address family view takes precedence over the RD configured in VPN instance view. An address family uses the RD configured in VPN instance view only when no RD is configured in the address family view.
Editing an RD will delete some configuration related to the VPN instance from the BGP process. Please be cautious.
Follow these restrictions and guidelines when deleting RDs:
·     When you delete the RD configured in VPN instance view, settings configured in an address family view of the BGP-VPN instance will be deleted if no RD is configured in the address family view. For example, when you delete the RD of VPN instance vpna, settings configured in BGP-VPN IPv4 unicast address family view of VPN instance vpna will be deleted if no RD is configured in VPN instance IPv4 address family view.
·     When you delete an RD configured in an address family view of the VPN instance, settings configured in the address family view of the BGP-VPN instance will be deleted if the RD configured in the address family view is different from the RD configured in VPN instance view.
·     If you configure an RD for an address family that inherits the RD of the VPN instance and the two RDs are different, settings configured in the address family view of the BGP-VPN instance will be deleted.
2.     Specify a label range for all VPN instances.
mpls per-vrf-label range minimum maximum
By default, no label range is specified for VPN instances.
3.     Create a VPN instance and enter VPN instance view.
4.     Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
5.     (Optional.) Configure a description for the VPN instance.
By default, no description is configured for a VPN instance.
6.     (Optional.) Configure a VPN ID for the VPN instance.
vpn-id vpn-id
By default, no VPN ID is configured for a VPN instance.
7.     (Optional.) Configure an SNMP context for the VPN instance.
By default, no SNMP context is configured.
8.     Enter VPN instance IPv4 address family view.
address-family ipv4
9.     (Optional.) Configure an RD.
By default, no RD is configured.
10.     Specify a label allocation mode.
apply-label { per-instance [ static static-label-value ] | per-route }
By default, BGP allocates labels on a per-next-hop basis.
CAUTION
CAUTION:
Executing this command will re-advertise all routes in the VPN instance, which will cause temporary interruption of running services in the VPN instance. Please be cautious.
If an interface is associated with a VSI or cross-connect, the interface (including its subinterfaces) cannot associate with a VPN instance.
If a subinterface is associated with a VSI or cross-connect, the subinterface cannot associate with a VPN instance.
2.     Enter interface view.
3.     Associate a VPN instance with the interface.
By default, an interface is not associated with a VPN instance and belongs to the public network.
CAUTION
CAUTION:
Associating a VPN instance with an interface or disassociating a VPN instance from an interface will clear the IP address and routing protocol settings of the interface.
The ip binding vpn-instance command deletes the IP address of the current interface. You must reconfigure an IP address for the interface after executing the command.
Configurations made in VPN instance view apply to both IPv4 VPN and IPv6 VPN.
IPv4 VPN prefers the configurations in VPN instance IPv4 address family view over the configurations in VPN instance view.
Before you perform this task, create the routing policies to be used by this task. For information about routing policies, see Layer 3—IP Routing Configuration Guide.
2.     Enter VPN instance view or VPN instance IPv4 address family view.
¡     Enter VPN instance view.
¡     Execute the following commands in sequence to enter VPN instance IPv4 address family view:
address-family ipv4
3.     Configure route targets.
By default, no route targets are configured.
4.     Set the maximum number of active routes.
By default, the number of active routes in a VPN instance is not limited.
Setting the maximum number of active routes for a VPN instance can prevent the device from learning too many routes.
5.     Apply an import routing policy.
By default, all routes matching the import target attribute are accepted.
6.     Apply an export routing policy.
By default, routes to be advertised are not filtered.
7.     Apply a tunnel policy to the VPN instance.
tnl-policy tunnel-policy-name
By default, no tunnel policy is applied to a VPN instance.
If the specified tunnel policy does not exist, the default tunnel policy is used.
For information about tunnel policies, see "Configuring tunnel policies."
Perform this configuration on the PE. On the CE, configure a common static route.
For more information about static routing, see Layer 3—IP Routing Configuration Guide.
2.     Configure a static route for a VPN instance.
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] [ track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ track track-entry-number ] } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
Perform this configuration on the PE. On the CE, create a common RIP process.
For more information about RIP, see Layer 3—IP Routing Configuration Guide.
2.     Create a RIP process for a VPN instance and enter RIP view.
rip [ process-id ] vpn-instance vpn-instance-name
A RIP process can belong to only one VPN instance.
3.     Redistribute BGP routes.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | route-policy route-policy-name | tag tag ] *
By default, RIP does not redistribute routes from other routing protocols.
4.     Enable RIP on the interface attached to the specified network.
By default, RIP is disabled on an interface.
Perform this configuration on the PE. On the CE, create a common OSPF process.
2.     Create an OSPF process for a VPN instance and enter the OSPF view.
ospf [ process-id | router-id router-id ] * vpn-instance vpn-instance-name
Parameter
router-id router-id
An OSPF process bound to a VPN instance does not use the public network router ID configured in system view. Therefore, you must specify a router ID when creating a process or configure an IP address for a minimum of one interface in the bound VPN instance.
An OSPF process can belong to only one VPN instance.
If you delete a VPN instance, all OSPF processes of the VPN instance are also deleted.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] *
By default, OSPF does not redistribute routes from other routing protocols.
If the vpn-instance-capability simple command is not configured for the OSPF process, the allow-ibgp keyword is optional to redistribute VPNv4 routes learned from MP-IBGP peers. In any other cases, if you do not specify the allow-ibgp keyword, the OSPF process does not redistribute VPNv4 routes learned from MP-IBGP peers.
4.     (Optional.) Set an OSPF domain ID.
The default domain ID is 0.
The domain ID is carried in the routes of the OSPF process. When redistributing routes from the OSPF process, BGP adds the domain ID as an extended community attribute into BGP route.
An OSPF process can be configured with only one primary domain ID. Domain IDs of different OSPF processes can be the same.
All OSPF processes of a VPN must be configured with the same domain ID.
5.     (Optional.) Configure the type codes of OSPF extended community attributes.
The defaults are as follows:
¡     0x0005 for Domain ID.
¡     0x0107 for Router ID.
¡     0x0306 for Route Type.
6.     Create an OSPF area and enter area view.
area area-id
7.     Enable OSPF on the interface attached to the specified network in the area.
By default, an interface neither belongs to any area nor runs OSPF.
Perform this configuration on the PE. On the CE, configure common IS-IS.
For more information about IS-IS, see Layer 3—IP Routing Configuration Guide.
2.     Create an IS-IS process for a VPN instance and enter IS-IS view.
isis [ process-id ] vpn-instance vpn-instance-name
An IS-IS process can belong to only one VPN instance.
3.     Configure a network entity title for the IS-IS process.
network-entity net
By default, no NET is configured.
4.     Enter IS-IS IPv4 unicast address family view.
address-family ipv4
5.     Redistribute BGP routes.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, IS-IS does not redistribute routes from other routing protocols.
6.     Return to system view.
7.     Enter interface view.
8.     Enable the IS-IS process on the interface.
isis enable [ process-id ]
By default, no IS-IS process is enabled on the interface.
Configuring the PE
2.     Enable a BGP instance and enter BGP instance view.
By default, BGP is not enabled.
3.     Enter BGP-VPN instance view.
Configuration commands in BGP-VPN instance view are the same as those in BGP instance view. For more information, see basic BGP configuration in Layer 3—IP Routing Configuration Guide.
4.     Configure the CE as the VPN EBGP peer.
peer { group-name | ip-address [ mask-length ] } as-number as-number
5.     Create the BGP-VPN IPv4 unicast address family and enter its view.
6.     Enable IPv4 unicast route exchange with the specified peer.
By default, BGP does not exchange IPv4 unicast routes with a peer.
7.     Redistribute the routes of the local CE.
A PE must redistribute the routes of the local CE into its VPN routing table so it can advertise them to the peer PE.
8.     Allow the local AS number to appear in the AS_PATH attribute of a received route, and set the maximum number of repetitions.
By default, BGP discards incoming route updates that contain the local AS number.
Execute this command in a hub-spoke network where EBGP is running between a PE and a CE to enable the PE to receive the route updates from the CE.
Configuring the CE
3.     Configure the PE as a BGP peer.
4.     Create the BGP IPv4 unicast address family and enter its view.
5.     Enable IPv4 unicast route exchange with the specified peer or peer group.
By default, BGP does not exchange IPv4 unicast routes with any peer.
6.     Configure route redistribution.
A CE must redistribute its routes to the PE so the PE can advertise them to the peer CE.
Use IBGP between PE and CE only in a basic MPLS L3VPN network. In networks such as Hub&Spoke, Extranet, inter-AS VPN, carrier's carrier, and nested VPN, you cannot use IBGP between PE and CE.
Configuring the PE
4.     Configure the CE as the VPN IBGP peer.
7.     Configure the CE as a client of the RR to enable the PE to advertise routes learned from the IBGP peer CE to other IBGP peers.
By default, no RR or RR client is configured.
Configuring an RR does not change the next hop of a route. To change the next hop of a route, configure an inbound policy on the receiving side.
8.     (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
9.     (Optional.) Configure the cluster ID for the RR.
By default, the RR uses its own router ID as the cluster ID.
If multiple RRs exist in a cluster, use this command to configure the same cluster ID for all RRs in the cluster to avoid routing loops.
Configuring the CE
3.     Configure the PE as an IBGP peer.
5.     Enable IPv4 unicast route exchange with the specified peer.
3.     Configure the remote PE as a BGP peer.
4.     (Optional.) Specify the source interface for TCP connections.
peer { group-name | ip-address [ mask-length ] } connect-interface interface-type interface-number
By default, BGP uses the output interface of the optimal route destined for the peer as the source interface.
5.     Create the BGP VPNv4 address family and enter its view.
address-family vpnv4
6.     Enable BGP VPNv4 route exchange with the specified peer.
By default, BGP does not exchange BGP VPNv4 routes with a peer.
BGP VPNv4 route control is configured similarly with BGP route control, except that it is configured in BGP VPNv4 address family view. For more information about BGP route control, see basic BGP configuration and advanced BGP configuration in Layer 3—IP Routing Configuration Guide.
3.     Enter BGP VPNv4 address family view.
4.     Advertise a default VPN route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } default-route-advertise vpn-instance vpn-instance-name
By default, no default VPN route is advertised to a peer or peer group.
5.     Set the maximum number of routes BGP can receive from a peer or peer group.
By default, the number of routes that BGP can receive from a peer or peer group is not limited.
6.     Save all route updates from a peer or peer group.
By default, BGP does not save route updates from a peer.
4.     Set a preferred value for routes received from a peer or peer group.
By default, the preferred value for routes received from a peer or peer group is 0.
To ensure the connectivity of IBGP peers, you must establish full-mesh IBGP connections, which costs massive network and CPU resources.
To reduce IBGP connections in the network, you can configure a router as a route reflector (RR) and configure other routers as its clients. You only need to establish IBGP connections between the RR and its clients to enable the RR to forward routes to the clients.
4.     Configure the device as a route reflector and specify a peer or peer group as its client.
By default, no route reflector or client is configured.
5.     (Optional.) Enable route reflection between clients.
6.     (Optional.) Configure a cluster ID for the RR.
7.     (Optional.) Configure a filtering policy for reflected routes.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, the RR does not filter reflected routes.
8.     (Optional.) Allow the RR to change the attributes of routes to be reflected.
reflect change-path-attribute
By default, RR cannot change the attributes of routes to be reflected.
9.     (Optional.) Specify a peer or peer group as a client of the nearby cluster.
peer { group-name | ipv4-address [ mask-length ] } reflect-nearby-group
By default, the nearby cluster does not have any clients.
The RR does not change the next hop of routes reflected to clients in the nearby cluster.
4.     Configure the NEXT_HOP attribute.
¡     Set the device as the next hop for routes sent to a peer or peer group.
By default, the device uses its address as the next hop for routes advertised to peers.
¡     Configure the device to not change the next hop of routes advertised to a peer or peer group.
On an RR in an inter-AS option C scenario, you must execute this command to not change the next hop of VPNv4 routes advertised to BGP peers and RR clients.
5.     Configure the AS_PATH attribute.
¡     Allow the local AS number to appear in the AS_PATH attribute of a received route and set the maximum number of repetitions.
By default, BGP discards incoming routes that contain the local AS number.
¡     Remove private AS numbers in BGP updates sent to an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
6.     Advertise the COMMUNITY attribute to a peer or peer group.
By default, BGP does not advertise the COMMUNITY attribute to a peer or peer group.
7.     Configure the SoO attribute for a peer for peer group.
By default, the SoO attribute is not configured.
4.     Filter advertised routes.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name } export [ direct | { isis | ospf | rip } process-id | static ]
By default, BGP does not filter advertised routes.
5.     Filter received routes.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name } import
By default, BGP does not filter received routes.
6.     Configure AS_PATH list-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } as-path-acl as-path-acl-number { export | import }
By default, AS_PATH list-based route filtering is not configured.
7.     Configure ACL-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } filter-policy ipv4-acl-number { export | import }
By default, ACL-based route filtering is not configured.
8.     Configure IP prefix list-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } prefix-list prefix-list-name { export | import }
By default, no IP prefix list-based route filtering is configured.
9.     Apply a routing policy to routes advertised to or received from a peer or peer group.
By default, no routing policy is applied for a peer.
10.     Enable route target filtering for received BGP VPNv4 routes.
policy vpn-target
By default, route target filtering is enabled for received VPNv4 routes. Only VPNv4 routes whose export route target attribute matches the local import route target attribute are added to the routing table.
11.     Enable the first AS number check for EBGP route advertisement to EBGP peers.
peer-as-check enable
By default, BGP does not check the first AS number of a received route and advertises the route to other peers.
After you execute this command, BGP checks the first AS number of a received route. If the AS number of an EBGP peer is the first AS number of the EBGP route to be advertised, BGP will not advertise the route to that EBGP peer.
Configuring BGP VPNv4 route dampening
This feature enables BGP to not select unstable routes as optimal routes.
This feature applies only to IBGP routes.
If an IBGP peer goes down after you configure this feature, VPNv4 routes coming from the peer are dampened but not deleted.
4.     Configure BGP VPNv4 route dampening.
dampening ibgp[ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] *
By default, BGP VPNv4 route dampening is not configured.
Configuring BGP VPNv4 routes to use private network next hops
By default, the device does not change the next hop attribute of a received BGP VPNv4 route. The next hop address of a BGP VPNv4 route is a public address. This feature changes the next hop of a BGP VPNv4 route received from a peer or peer group to an IP address in the VPN instance. The outgoing label of the VPNv4 route is also changed to an invalid value. For example, the device received a VPNv4 route and its next hop address is 10.1.1.1, which is a public address by default. After this feature is configured, the next hop address changes to private address 10.1.1.1.
After you configure this feature, the following applies:
·     The device re-establishes the BGP sessions to the specified peer or to all peers in the specified peer group.
·     The device receives a BGP VPNv4 route only when its RD is the same as a local RD.
·     When advertising a BGP VPNv4 route received from the specified peer or peer group, the device does not change the route target attribute of the route.
·     If you delete a VPN instance or its RD, BGP VPNv4 routes received from the specified peer or peer group and in the VPN instance will be deleted.
4.     Change the next hop of a BGP VPNv4 route received from a peer or peer group to a VPN instance address.
peer { group-name | ipv4-address [ mask-length ] } next-hop-vpn
By default, the device does not change the next hop attribute of a received BGP VPNv4 route, and the next hop belongs to the public network.
Configuring BGP VPNv4 optimal route selection delay
4.     Set the BGP VPNv4 optimal route selection delay timer. Choose one or more of the following tasks:
¡     Configure optimal route selection delay for all BGP routes in the address family.
¡     Configure optimal route selection delay only for BGP routes from a peer within the specified time after the peer state changes from down to up.
route-select suppress on-peer-up milliseconds
By default, optimal route selection is not delayed.
Preferring routes learned from the specified peer or peer group during optimal route selection
The VPNv4 address family supports both IPv4 and IPv6 peers, so the device might learn routes with the same prefix from the IPv4 and IPv6 peers. You can perform this task to control the route priorities.
When an MPLS L3VPN supports both IPv4 and IPv6, the VPNv4 address family might learn routes with the same prefix from the IPv4 and IPv6 peers. In this scenario, the route learned from the IPv6 peer might be selected as the optimal route, and the route learned from the IPv4 peer will not be advertised. You can configure this feature on the IPv4 peers in the VPNv4 address family to ensure that routes learned from the IPv4 peers are preferred.
4.     Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] } high-priority
By default, routes learned from a peer or peer group do not take precedence over routes learned from other peers or peer groups.
Advertising BGP RPKI validation state to a peer or peer group
BGP advertises the BGP RPKI validation state to a peer or peer group through the extended community attribute. For more information about BGP RPKI, see BGP configuration in Layer 3—IP Routing Configuration Guide.
4.     Advertise the BGP RPKI validation state to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise origin-as-validation
By default, BGP does not advertise the BGP RPKI validation state.
Configuring inter-AS option A
Inter-AS option A applies to scenarios with a few VPNs.
To configure inter-AS option A, create VPN instances on PEs and ASBRs. The VPN instances on PEs are used to allow CEs to access the network. The VPN instances on ASBRs are used to access the peer ASBRs. An ASBR considers the peer ASBR as a CE.
The route targets configured on the PEs must match those configured on the ASBRs in the same AS to make sure VPN routes sent by the PEs (or ASBRs) can be received by the ASBRs (or PEs). Route targets configured on the PEs in different ASs do not have such requirements.
Configuring inter-AS option B
An ASBR always sets itself as the next hop of VPNv4 routes advertised to an MP-IBGP peer regardless of the peer next-hop-local command.
Configuring a PE
Configure basic MPLS L3VPN, and specify the ASBR in the same AS as an MP-IBGP peer. The route targets for the VPN instances on the PEs in different ASs must match for the same VPN.
Configuring an ASBR
2.     Enable MPLS and LDP on the interface connected to an internal router of the AS:
a.     Configure an LSR ID for the local LSR.
mpls lsr-id lsr-id
By default, no LSR ID is configured.
b.     Enable LDP on the local LSR and enter LDP view.
mpls ldp
By default, LDP is disabled.
c.     Return to system view.
d.     Enter interface view of the interface connected to an internal router of the AS.
e.     Enable MPLS on the interface.
mpls enable
By default, MPLS is disabled on the interface.
f.     Enable MPLS LDP on the interface.
mpls ldp enable
By default, MPLS LDP is disabled on the interface.
g.     Return to system view.
3.     Enable MPLS on the interface connected to the remote ASBR:
a.     Enter interface view of the interface connected to the remote ASBR.
b.     Enable MPLS on the interface.
mpls enable
4.     Enter BGP instance view.
5.     Configure PEs in the same AS as IBGP peers and ASBRs in different ASs as EBGP peers.
6.     Enter BGP VPNv4 address family view.
7.     Enable BGP to exchange VPNv4 routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange VPNv4 routes with a peer.
8.     Disable route target filtering of received VPNv4 routes.
undo policy vpn-target
Configuring inter-AS option C (method 1)
PEs are not directly connected. For the PEs to establish neighbor relationships, execute the peer ebgp-max-hop command to enable the local router to establish an EBGP session to an indirectly-connected peer.
Before you configure inter-AS option C (method 1), perform the following tasks:
·     Configure BGP on PEs or ASBRs to advertise the routes for the PEs. For more information, see basic BGP configuration in Layer 3—IP Routing Configuration Guide.
·     Configure VPN instances on PEs.
·     Configure routing between PEs and CEs.
Configuring a PE
3.     Configure the ASBR in the same AS as an IBGP peer and configure the PE of another AS as an EBGP peer.
5.     Enable BGP to exchange IPv4 unicast routes with the ASBR in the same AS.
6.     Enable BGP to exchange labeled IPv4 routes with the ASBR in the same AS.
peer { group-name | ipv4-address [ mask-length ] } label-route-capability
By default, BGP cannot exchange labeled routes with any IPv4 peer or peer group.
7.     Return to BGP instance view.
8.     Enter BGP VPNv4 address family view.
9.     Enable BGP to exchange VPNv4 routes with the PE in different ASs.
By default, BGP cannot exchange VPNv4 routes with any peer.
10.     (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
By default, the device uses its address as the next hop of routes advertised to peers.
Execute this command on the RR so the RR does not change the next hop of advertised VPNv4 routes.
Configuring an ASBR
2.     Configure a routing policy:
a.     Create a routing policy, and enter routing policy view.
b.     Match IPv4 routes carrying labels.
if-match mpls-label
By default, no MPLS label match criterion is configured.
You can configure if-match clauses in the routing policy to filter routes. Routes surviving the filtering are assigned labels, and all others are advertised as common IPv4 routes.
c.     Set labels for IPv4 routes.
apply mpls-label
By default, no MPLS label is set for IPv4 routes.
d.     Return to system view.
3.     Enable MPLS and LDP on the interface connected to an internal router of the AS:
mpls lsr-id lsr-id
mpls ldp
mpls enable
mpls ldp enable
4.     Enable MPLS on the interface connected to the remote ASBR.
mpls enable
5.     Enter BGP instance view.
6.     Configure PEs in the same AS as IBGP peers and ASBRs in different ASs as EBGP peers.
7.     Create BGP IPv4 unicast address family and enter its view.
8.     Enable BGP to exchange IPv4 unicast routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange IPv4 unicast routes with a peer.
9.     Enable BGP to exchange labeled IPv4 routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange labeled IPv4 routes with a peer.
10.     Specify the device as the next hop of routes sent to a peer or peer group.
By default, the device does not set itself as the next hop for routes sent to a peer or peer group.
11.     Apply a routing policy to routes advertised to or received from a peer or peer group.
By default, no routing policy is applied.
Configuring inter-AS option C (method 2)
Before you configure inter-AS option C (method 2), perform the following tasks:
·     Configure BGP on PEs or ASBRs to advertise the routes for the PEs. For more information, see BGP configuration in Layer 3—IP Routing Configuration Guide.
Configuring a PE
3.     Configure the PE in another AS as an EBGP peer.
4.     Enter BGP VPNv4 address family view.
5.     Enable BGP to exchange VPNv4 routes with the PE in another AS.
6.     (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
Configure this command on the RR so the RR does not change the next hop of advertised VPNv4 routes.
Configuring an ASBR
if-match mpls-label
apply mpls-label
mpls lsr-id lsr-id
mpls ldp
mpls enable
mpls ldp enable
mpls enable
6.     Configure the ASBR in another AS as an EBGP peer.
8.     Enable BGP to exchange IPv4 unicast routes with the ASBR in another AS.
9.     Enable BGP to exchange labeled IPv4 routes with the ASBR in another AS.
By default, the device does not set itself as the next hop for routes sent to an IBGP peer or peer group.
When you configure nested VPN, follow these guidelines:
·     The address spaces of sub-VPNs of a VPN cannot overlap.
·     Do not assign nested VPN peers addresses that public network peers use.
·     Nested VPN does not support multihop EBGP. A provider PE and a provider CE must use the addresses of the directly connected interfaces to establish a neighbor relationship.
1.     Connect the customer CE to the customer PE:
a.     Configure VPN instances on the customer PE.
See "Configuring VPN instances."
b.     Configure route exchange between customer PE and customer CE.
See "Configuring routing between a PE and a CE."
2.     Configure the customer PE to exchange sub-VPN routing information with the provider CE:
a.     Configure BGP VPNv4 route exchange between customer PE and provider CE.
See "Configuring routing between PEs."
b.     Execute the following commands in sequence to configure the provider CE to receive all VPNv4 routes (not filter VPNv4 routes by route targets).
This step is not required in a nested VPN network when no provider CE is deployed and the customer PE is connected directly to the provider PE.
3.     Connect the provider CE to the provider PE:
a.     Configure VPN instances on the provider PE.
b.     Configure route exchange between the provider CE and provider PE.
4.     Configure BGP VPNv4 route exchange between the provider PE and provider CE:
This step contains only configurations on the provider PE. For information about configuring the provider CE, see "Configuring routing between PEs." If the customer PE is directly connected to the provider PE, you must configure provider CE settings on the customer PE because the PE also functions as a provider CE.
a.     Execute the following commands in sequence to enter BGP VPNv4 address family view:
b.     Enable nested VPN.
nesting-vpn
By default, nested VPN is disabled.
c.     Return to BGP instance view.
d.     Enter BGP-VPN instance view.
e.     Configure the provider CE as a BGP peer.
f.     Create BGP-VPN VPNv4 address family and enter BGP-VPN VPNv4 address family view.
g.     Enable BGP VPNv4 route exchange with the peer CE or the peer group of the peer CE.
By default, BGP does not exchange VPNv4 routes with any peer.
h.     (Optional.) Configure the device to not change the next hop of routes advertised to the peer or peer group.
i.     (Optional.) Configure the SoO attribute for the BGP peer or peer group.
j.     (Optional.) Prefer routes learned from the specified peer or peer group during optimal route selection.
5.     Configure BGP VPNv4 route exchange between provider PEs.
About configuring multirole host
To configure the multirole host feature, perform the following tasks on the PE connected to the CE in the site where the multirole host resides:
·     Configure and apply PBR.
·     Configure static routes.
Configuring and applying PBR
2.     Create a policy node and enter policy node view.
policy-based-route policy-name { deny | permit } node node-number
3.     Configure match criteria for the node.
See Layer 3—IP Routing Configuration Guide.
By default, no match criterion is configured. All packets match the criteria for the node.
This step matches packets from the multirole host.
4.     Specify the VPN instances for forwarding the matching packets.
apply access-vpn vpn-instance vpn-instance-name&<1-n>
By default, no VPN instance is specified.
You must specify multiple VPN instances for the node. The first one is the VPN instance to which the multirole host belongs, and others are the VPN instances to be accessed. A matching packet is forwarded according to the routing table of the first VPN instance that has a matching route for that packet.
5.     Return to system view.
6.     Enter the view of the interface connected to the CE.
7.     Apply the policy to the interface.
ip policy-based-route policy-name
By default, no policy is applied to the interface.
Configuring a static route
2.     Configure a static route for a VPN instance to reach the multirole host.
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address[ track track-entry-number ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
The d-vpn-instance-name argument represents the VPN instance to which the multirole host belongs. The next-hop-address argument represents the IP address of the CE in the site where the multirole host resides.
An egress PE can process VPN labels in either POPGO or POP mode:
·     POPGO forwarding—Pops the label and forwards the packet out of the output interface corresponding to the label.
·     POP forwarding—Pops the label and forwards the packet through the FIB table.
The POPGO forwarding mode (vpn popgo) cannot be used in per-VPN instance per-label allocation mode (apply-label per-instance). After the apply-label per-instance command is executed for a VPN instance, the device can only forward packets by looking up the FIB according to labels, and the vpn popgo command does not take effect in the VPN instance.
3.     Specify the VPN label processing mode as POPGO forwarding.
vpn popgo
The default is POP forwarding.
A tunnel associated with a VPN instance supports the following TTL processing modes:
·     Pipe—When an IP or IPv6 packet enters the tunnel of the VPN instance, the ingress node adds a new header to the packet. The ingress node sets the TTL value or hop limit in the new header to 255 or the value specified by the encapsulation source-address ip-ttl command in SRv6 view. When the packet leaves the tunnel of the VPN instance, the egress node does not change the TTL value or the hop limit according to the remaining TTL value in the new header. Therefore, the public network nodes are invisible to user networks, and the tracert facility cannot show the real path in the public network.
·     Uniform—When an IP or IPv6 packet enters the tunnel of the VPN instance, the ingress node adds a new header to the packet. The ingress node copies the TTL value or the hop limit of the original packet to the TTL or hop limit field of the new header. When the packet leaves the tunnel of the VPN instance, the egress node copies the remaining TTL value or hop limit back to the original packet. The TTL value or hop limit can reflect how many hops the packet has traversed in the public network. The tracert facility can show the real path along which the packet has traveled.
In the current software version, you can configure a TTL processing mode for only SRv6 tunnels associated with VPN instances. For more information about associating VPN instances with SRv6 tunnels, see MPLS L3VPN over SRv6 configuration in Segment Routing Configuration Guide.
2.     Enter VPN instance mode.
ip vpn-instance vpn-instance-name [ index vpn-index ]
3.     Configure a TTL processing mode for the tunnel associated with a VPN instance.
ttl-mode { pipe | uniform }
By default, the TTL processing mode for the tunnel associated with a VPN instance is pipe.
When CEs at different sites have the same AS number, configure the BGP AS number substitution feature to avoid route loss.
When a PE uses different interfaces to connect different CEs in a site, the BGP AS number substitution feature introduces a routing loop. To remove the routing loop, configure the SoO attribute on the PE.
For more information about the BGP AS number substitution feature and the SoO attribute, see "BGP AS number substitution and SoO attribute." For more information about the commands in this feature, see advanced BGP commands in Layer 3—IP Routing Command Reference.
4.     Enable the BGP AS number substitution feature.
peer { ipv4-address [ mask-length ] | group-name } substitute-as
By default, BGP AS number substitution is disabled.
5.     Enter BGP-VPN IPv4 unicast address family view.
6.     (Optional.) Configure the SoO attribute for a BGP peer or peer group.
The BGP RT filtering feature reduces the number of routes advertised in an MPLS L3VPN.
After RT filtering is configured, a PE advertises its import target attribute to the peer PEs in the RT filter address family. The peer PEs use the received import target attribute to filter routes and advertise only the routes that match the attribute to the PE.
When a large number of IBGP peers exist, the BGP RT filtering and the route reflection features are used together as a best practice. Route reflection reduces the number of IBGP connections. BGP RT filtering reduces the number of routes advertised in the network.
For more information about the BGP RT filtering commands, see basic BGP commands in Layer 3—IP Routing Command Reference.
Restrictions and guidelines for configuring BGP RT filtering
For detailed information about the commands in this feature, see BGP commands in Layer 3—IP Routing Command Reference. All tasks except for "Enabling the device to exchange IPv4 RT filter routing information with a peer or peer group" are optional.
3.     Enter BGP IPv4 RT filter address family view.
address-family ipv4 rtfilter
4.     Enable the device to exchange routing information with a peer or peer group.
By default, the device cannot exchange routing information with a peer or peer group.
Controlling IPv4 RT filter route advertisement, reception, and selection
4.     Advertise a default route to a peer or peer group.
By default, no default route is advertised.
5.     Set a preferred value for routes received from a peer or peer group.
6.     Prefer routes learned from the specified peer or peer group during optimal route selection.
7.     Configure the device as a route reflector and specify a peer or peer group as its client.
8.     Enable route reflection between clients.
9.     Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
10.     Configure the PE to not change the next hop of routes advertised to the peer or peer group.
By default, the device uses its address as the next hop of routes advertised to the EBGP peer or peer group and does not change the next hop of routes advertised to the IBGP peer or peer group.
11.     Set the optimal route selection delay timer. Choose one or more of the following tasks:
Applying the export routing policy to VPNv4 routes before RT filtering
By default, a device performs RT filtering on VPNv4 routes and then applies the export routing policy to the matching routes before advertisement. In some networks, no route targets are configured in the VPN instance, and the route targets of VPNv4 routes are configured through the export routing policy. If IPv4 RT filter route exchange is enabled for the device and its peer, all VPNv4 routes cannot pass RT filtering, and no VPNv4 routes can be advertised.
To resolve this issue, you can perform this task to configure the device to apply the export routing policy to VPNv4 routes before RT filtering.
4.     Apply the export routing policy to VPNv4 routes before RT filtering.
rtfilter check-after-policy
By default, the device performs RT filtering on VPNv4 routes and then applies the export routing policy to the matching routes before advertisement.
By default, BGP advertises only one optimal route. When the optimal route fails, traffic forwarding will be interrupted until route convergence completes.
The BGP additional path (Add-Path) feature enables BGP to advertise multiple routes with the same prefix and different next hops to a peer or peer group. When the optimal route fails, the suboptimal route becomes the optimal route, which shortens the traffic interruption time.
You can enable the BGP additional path sending, receiving, or both sending and receiving capabilities on a BGP peer. For two BGP peers to successfully negotiate the additional path capabilities, make sure one end has the sending capability and the other end has the receiving capability.
For more information about the BGP additional path configuration commands, see advanced BGP commands in Layer 3—IP Routing Command Reference.
2.     Enter BGP VPNv4 address family view or BGP-VPN VPNv4 address family view.
¡     Execute the following commands in sequence to enter BGP VPNv4 address family view:
¡     Execute the following commands in sequence to enter BGP-VPN VPNv4 address family view:
3.     Configure the BGP additional path capabilities.
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
By default, no BGP additional path capabilities are configured.
4.     Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
By default, a maximum of one Add-Path optimal route can be advertised to a peer or peer group.
5.     Set the maximum total number of Add-Path optimal routes that can be advertised to all peers.
By default, a maximum total number of one Add-Path optimal route can be advertised to all peers.
This command is not supported in BGP-VPN VPNv4 address family view.
ECMP load balancing equally distributes traffic to the equal-cost links without considering link bandwidth differences. This might cause insufficient usage of high-speed links and traffic congestion on low-speed links. To resolve this issue, you can configure Unequal Cost Multiple Path (UCMP) load balancing based on the link bandwidth attributes of BGP routes.
The link bandwidth attribute of a route indicates the link bandwidth of the outgoing interface of the route. After UCMP load balancing is enabled for an EBGP peer on the device, the device adds the link bandwidth attribute into the route received from the EBGP peer. This attribute carries the AS number of the current BGP process and the interface bandwidth for establishing a direct EBGP session. UCMP BGP routes are formed in the following situation: BGP route load balancing is configured by using the balance command in BGP-VPN IPv4 address family view. All the BGP routes for load balancing carry a link bandwidth attribute. In traffic forwarding, the proportion of the traffic carried on each BGP route is that of the route's link bandwidth to the total link bandwidth of all UCMP routes. As shown in Figure 19, Device A receives routes for the same destination address from three EBGP peers. Assume Device A adds link bandwidth attribute values 500 kbps, 1000 kbps, and 500 kbps for the three BGP routes. The traffic load proportions carried on the three BGP routes are 25%, 50%, and 25%, respectively. For more information the balance command, see BGP commands in Layer 3—IP Routing Command Reference.
Figure 19 UCMP load balancing based on BGP routes with link bandwidth attributes
By default, the BGP routes with link bandwidth attributes are advertised only to IBGP peers and the added link bandwidth attributes are optional non-transitive attributes. You can change the advertisement rule for BGP routes with link bandwidth attributes as needed:
·     To advertise link bandwidth attributes to EBGP peers, execute the peer advertise ebgp bandwidth command.
·     To make BGP peers that cannot identify link bandwidth attributes to carry link bandwidth attributes when they forward BGP routes, execute the peer advertise bandwidth transitive command. This command can convert the link bandwidth attributes carried in BGP routes into optional transitive attributes.
When you configure this feature to add link bandwidth attributes to BGP routes, follow these restrictions and guidelines:
·     This feature applies only to direct EBGP peers or peer groups. If the specified peer or peer group becomes an indirectly connected neighbor, the device no longer adds link bandwidth attributes to the routes received from that neighbor.
·     Only if all BGP routes for the same destination address carry the link bandwidth attributes, can these routes provide UCMP load balancing. Otherwise, the routes can only provide ECMP load balancing.
·     A BGP route can carry a maximum of one link bandwidth attribute. If a received route already has a link bandwidth attribute, the device cannot add a link bandwidth attribute to the route any more.
In advertisement of BGP routes with link bandwidth attributes, the following restrictions apply:
·     If you use the peer route-policy export command to apply a routing policy to a BGP peer/peer group, and the routing policy uses the apply extcommunity command to configure a link bandwidth attribute for BGP routes, that link bandwidth attribute will be carried in the BGP routes advertised to the BGP peer/peer group.
·     When the device receives a BGP route with a link bandwidth attribute, the device deletes the link bandwidth attribute before advertising the route if the next hop address of the route needs to be changed before advertisement. This is because the forwarding link instructed by this route has changed and thus the carried link bandwidth no longer indicates the bandwidth of the actual forwarding link. This restriction does not exist if the device receives a route without a link bandwidth attribute and then adds a link bandwidth attribute to the route.
·     For UCMP routes, if the Add-Path feature is configured to advertise only one optimal route, the optimal route advertised will carry a link bandwidth attribute that is the total link bandwidth of all UCMP routes. If the Add-Path feature is configured to advertise more than one optimal route, the advertised routes carry their respective link bandwidth attributes.
3.     Configure a link bandwidth attribute for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bandwidth [ bandwidth-value ]
By default, no link bandwidth attribute is configured for a peer or peer group.
4.     (Optional.) Configure the device to advertise link bandwidth attributes to EBGP peers.
peer { group-name | ipv4-address [ mask-length ] } advertise ebgp bandwidth
By default, the device does not advertise link bandwidth attributes to EBGP peers.
5.     (Optional.) Convert the link bandwidth attributes to optional transitive attributes in the BGP routes to be advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise bandwidth transitive
By default, the link bandwidth attributes in BGP routes are optional non-transitive attributes.
After the undo policy vpn-target command is executed, VPNv4 routes without matching route targets of the local VPN instance can be received. If the VPNv4 routes have the same RD as the local VPN instance, these routes can be selected in the BGP VPNv4 routing table as optimal routes. However, routes without matching route targets are invisible and unavailable in the BGP-VPN instance routing table and cannot be added to the routing table of the VPN instance. The BGP-VPN instance routing table uses the same optimal route selection result as the BGP VPNv4 routing table. Therefore, if a route without matching route targets is selected as the only optimal route in the BGP VPNv4 routing table, no optimal route can be added to the BGP-VPN instance routing table. Only the optimal route in the BGP-VPN instance routing table can be added to the VPN instance IP routing table. Therefore, the BGP route without matching route targets cannot be added to the VPN instance IP routing table, so packets destined for the destination address of that route cannot be forwarded.
You can configure this feature (the routing-table independent enable command) to resolve this issue. After this feature is enabled, only BGP VPNv4 optimal routes with matching route targets of a VPN instance can be added to the corresponding BGP-VPN instance routing table. These routes can participate in optimal route selection together with other routes in the BGP-VPN instance routing table and the selection result is independent of that in the BGP VPNv4 routing table. This mechanism allows the BGP-VPN instance routing table to contain only the BGP routes with matching route targets of the corresponding VPN instance. So the optimal routes selected in the BGP-VPN instance routing table can always be added to the VPN instance IP routing table.
For example, a PE has learned two routes with the same prefix (10.10.10.10/32) and different next hops through BGP VPNv4 sessions.
<Sysname> display bgp routing-table vpnv4
               s - suppressed, S - stale, i - internal, e - external,
               a - additional-path
 Total number of VPN routes: 2
 Total number of routes from all PEs: 2
 Route distinguisher: 10:1(vpn1)
 Total number of routes: 3
* >i 10.10.10.10/32     1.1.1.1         0          100        0       i
*  i                    3.3.3.3         0          100        0       i
 Route distinguisher: 20:1
 Total number of routes: 1
* >i 10.10.10.10/32     3.3.3.3         0          100        100     i
In the BGP VPNv4 routing table, route entries are listed by RD. In the previous output, the BGP VPNv4 routing table contains two route lists, one for RD 10:1 and the other for RD 20:1.
The route with next hop address 3.3.3.3 has matching route target values of VPN instance vpn1, while the route with next hop address 1.1.1.1 does not. The route with next hop 3.3.3.3 is added to the BGP-VPN instance routing table of vpn1. The BGP VPNv4 of RD 10:1 and the BGP-VPN instance share the same route entries, so the BGP VPNv4 routing table for RD 10:1 also contains the route with next hop 3.3.3.3. In the BGP VPNv4 routing table for RD 10:1, the route with next hop 3.3.3.3 and the route with next hop 1.1.1.1 participate in optimal route selection and the route with next hop 1.1.1.1 is selected as the optimal route. However, the route target attribute of the route with next hop 1.1.1.1 does not match that of vpn1, so this route is not available in the BGP-VPN instance routing table of vpn1. As a result, there is no optimal route destined for 10.10.10.10/32 in the BGP-VPN instance routing table of vpn1.
<Sysname> display bgp routing-table ipv4 vpn-instance vpn1
               a - additional-path
*  i 10.10.10.10/32     3.3.3.3         0          100        100     i
After this feature is configured, the BGP VPNv4 routing table and the BGP-VPN instance routing table no longer share route entries. The BGP VPNv4 routing table is as follows:
               a - additional-path
The route with next hop 1.1.1.1 is selected as the optimal route for RD 10:1. However, the route target attribute of the route with next hop 1.1.1.1 does not match that of vpn1, so this route cannot be added to the BGP-VPN instance routing table of vpn1.
The route with next hop 3.3.3.3 is selected as the optimal route for RD 20:1, and the route target attribute of the route matches that of vpn1. So this route can be added to the BGP-VPN instance routing table of vpn1 and selected as an optimal route and thus added to the IP routing table of vpn1.
               a - additional-path
IP prefix routes can be added to a BGP-VPN instance routing table. When the optimal route for an IP prefix in the VPNv4 address family does not match the route targets of the local VPN instance, this feature also can add the route with the same IP prefix learned from the BGP EVPN address family to the BGP-VPN instance routing table. The IP prefix advertisement route added to the BGP-VPN instance routing table can be selected as an optimal route and added to the IP routing table of the VPN instance.
This feature also provides the following function:
·     Before this feature is enabled, the peer re-originated command cannot modify the route information for received BGP VPNv4 routes that have the same RD as the local VPN instance.
·     After this feature is enabled, the peer re-originated command can modify the route information for all received BGP VPNv4 routes.
The bestroute same-rd command and the routing-table independent enable command can implement similar functions. The differences include the following:
·     The bestroute same-rd command ignores the routes that do not have matching route targets of the local VPN instance, and enables BGP to add other routes that have the same IP prefix and matching route targets (if any in the BGP VPNv4 routing table) to the IP routing table of the VPN instance.
·     The routing-table independent enable command uses the routes learned from other BGP routing tables to implement the function of adding BGP routes to the IP routing table of the VPN instance. In the BGP VPNv4 routing table for an RD, the route without matching route targets still cannot be added to the IP routing table of the VPN instance. This feature applies to the following scenarios:
¡     There are optimal routes with the same IP prefix in the BGP VPNv4 route entries for different RDs.
¡     An IP prefix advertisement route in the BGP EVPN routing table and a VPNv4 route in the BGP VPNv4 routing table have the same IP prefix.
¡     The peer re-originated command is configured to modify the route information for received BGP VPNv4 routes that have the same RD as the local VPN instance.
After the routing-table independent enable command is executed, the bestroute same-rd command no longer takes effect.
3.     Enabling independent routing tables for BGP VPNv4 routes and BGP-VPN instance routes.
By default, BGP VPNv4 routes and BGP-VPN routes share the same route entries. The BGP routes in BGP-VPN instance routing table can also be displayed in the BGP VPNv4 routing table. For the same VPN instance, it has the same optimal route selection result in BGP VPNv4 routing table and in the BGP-VPN instance routing table.
Perform this task to configure the following features:
·     Route adding rule—For multiple BGP routes to the same destination, BGP adds the optimal route with matching route targets of a VPN instance to the IP routing table of the VPN instance.
You can configure this feature to resolve this issue. With this feature configured, for BGP routes to the same destination address, BGP adds the optimal route with the same route targets as a VPN instance to the IP routing table of the VPN instance.
For example, the import target of VPN instance vpna is 10:1. The BGP routing table of VPN instance vpna contains two routes to destination address 1.1.1.1, which are 1.1.1.1 <RT: 10:1> and 1.1.1.1 <RT: 20:1>, and 1.1.1.1 <RT: 20:1> is the optimal route. After you configure this feature, BGP will add 1.1.1.1 <RT: 10:1> to the IP routing table of VPN instance vpna, because this route has the same import target as the VPN instance.
·     Route advertisement rule—When the optimal route to a destination address cannot be advertised to peers, the device advertises the suboptimal route to the destination address from the routes that can be advertised. The device does not advertise any route for a destination address only if no routes to the destination address can be advertised.
The BGP routing table of a VPN instance contains the routes in the IP routing table of the VPN instance, so the routing table of a BGP address family might contain routes that are not learned from that address family. For example, an IP prefix advertisement route learned from the BGP EVPN address family is added to the IP routing table of a VPN instance, and the route also exists in the BGP routing tables of the BGP-VPN IPv4 unicast address family and BGP VPNv4 address family in the VPN instance. BGP cannot advertise the optimal route to peers in an address family if the optimal route is not learned from that address family, making the destination address of the route unreachable.
After you configure this feature, if the optimal route to a destination address cannot be advertised to peers, the device advertises the suboptimal route, and so forth until a route to the destination address is advertised successfully. The device does not advertise any route for a destination address only if no routes to the destination address can be advertised.
For example, the device learns the route with IP prefix 3.3.3.3/32 from both the BGP VPNv4 address family and the BGP EVPN address family. Therefore, there will be two routes to destination address 3.3.3.3 in the BGP routing table of the BGP VPNv4 address family, and the one learned from the BGP EVPN address family is the optimal route. However, this optimal route cannot be advertised to BGP VPNv4 peers, because it was learned from the BGP EVPN address family. As a result, network nodes deployed with only BGP VPNv4 cannot obtain the route with IP prefix 3.3.3.3/32. After you configure this feature, the device will advertise the route with IP prefix 3.3.3.3/32 learned from the BGP VPNv4 address family to BGP VPNv4 peers, although this route is not the optimal route.
The bestroute same-rd command takes effect on BGP routes of all VPN instances. Use caution when you execute this command.
After the routing-table independent enable command is executed, the bestroute same-rd command no longer takes effect. For more information about the differences of the two commands, see "Enabling independent routing tables for BGP VPNv4 routes and BGP-VPN instance routes."
3.     Configure BGP to add the optimal routes with the same route targets as a VPN instance to the IP routing table of the VPN instance, and allow BGP to advertise non-optimal routes in the BGP VPN instance to its peers.
bestroute same-rd
By default, BGP adds the optimal routes in the BGP routing table to the IP routing table of a VPN instance and advertises only the optimal routes to its peers.
Minimizing the priority of BGP routes advertised to peers
Minimizing the priority of BGP routes advertised to peers with a down-to-up state change
By default, the device sends BGP routes immediately to a peer when the peer state changes to up. If the device advertises routes before completing ARP table convergence, the traffic matching these advertised routes might not be forwarded correctly, which causes traffic loss.
To resolve this issue, use this feature to minimize the priority of the routes to be advertised after the state of a peer changes from Down to Up. The peer will not select the routes received from the device as the optimal routes. After the ARP table convergence is completed and the specified wait time elapses, the device restores the priority of the routes advertised to the peer.
After you use this feature, the device performs the following tasks when the state of a peer changes from Down to Up:
·     Sets the local preference value to the minimum (0) and the MED value to the maximum (4294967295) for the routes to be advertised.
·     After the specified wait time elapses, restores the local preference value and the MED value for the advertised routes, and then advertises these routes immediately.
For the device to restore the priority of the advertised routes before the specified wait time elapses, use one of the following commands:
¡     reset bgp advertise lowest-priority on-peer-up
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to the peer. If the state of a peer changes from Down to Up later, the device still minimizes the priority of the routes advertised to that peer.
¡     undo advertise lowest-priority on-peer-up duration
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to the peer. The device does not change the original local preference value and MED value for the subsequent routes advertised to peers.
You can use the advertise lowest-priority on-peer-up duration command multiple times to change the wait time. After you change the wait time, the following rules apply:
·     If the original wait time setting is taking effect, the new wait time setting will immediately take over and the device will update the time to wait for route priority restoration.
For example, you can set the wait time to 10 seconds by using the advertise lowest-priority on-peer-up duration 10 command. Then, you use the advertise lowest-priority on-peer-up duration 6 command to set a new wait time six seconds after the state of a peer changes from Down to Up. The device will still minimize the priority of the routes advertised to the peer during the following six seconds.
·     If the original wait time is not taking effect, the new wait time will take effect after the state of a peer changes from Down to Up.
The following commands can influence each other:
·     advertise lowest-priority on-peer-up duration
·     advertise lowest-priority on-startup duration
·     bgp update-delay on-startup
·     route-update-delay
When you use two of the commands above together, the configuration result varies by command as follows:
Table 1 Configuration results
Command A
Command B
advertise lowest-priority on-startup duration in the view of a BGP address family
In the address family configured with command B, only command B takes effect.
In the address families not configured with command B, command A takes effect.
advertise lowest-priority on-peer-up duration in the view of a BGP address family
Assume that the delay time specified in command A is TA and the wait time specified in command B is TB.
In the address families not configured with command B, only command A takes effect.
In the address family configured with command B, the two commands take effect as follows after the device restarts and the BGP process recovers:
·     If TA ≥ TB, only command A takes effect.
·     If TA < TB, the device performs the following tasks:
¡     The device does not send any BGP routes to peers within TA.
¡     The device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TA).
¡     After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to peers. The device does not minimize the priority of the subsequent routes advertised to peers.
route-update-delay
advertise lowest-priority on-startup duration in BGP VPNv4 or BGP-VPN VPNv4 address family view
In BGP VPNv4 or BGP-VPN VPNv4 address family view, the two commands take effect as follows after the device restarts and the BGP process recovers:
·     If TS ≥ TB, only command A takes effect.
·     If TS < TB, the device performs the following tasks:
a.     The device does not send any BGP routes to peers within TS.
b.     After TS elapses, the device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TS).
c.     After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to peers. The device does not minimize the priority of the subsequent routes advertised to peers.
TB represents the wait time specified in command B.
TS represents the larger interval among the intervals specified in the peer route-update-interval command and command A. If you did not execute the peer route-update-interval command for the peers, the device uses the default value of this command to compare with the interval configured in command A.
advertise lowest-priority on-peer-up duration in BGP VPNv4 or BGP-VPN VPNv4 address family view
In BGP VPNv4 or BGP-VPN VPNv4 address family view, the two commands take effect as follows after the state of a peer changes from Down to Up:
c.     After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to the peer. The device does not minimize the priority of the subsequent routes advertised to the peer.
Command A is mutually exclusive with command B in the same address family.
For more information about the following commands, see basic BGP commands in Layer 3—IP Routing Command Reference:
·     peer route-update-interval
3.     Minimize the priority of the routes advertised to a peer after the peer state changes from Down to Up.
advertise lowest-priority on-peer-up duration seconds
By default, BGP does not change the priority of the routes advertised to its peers.
Minimizing the priority of BGP routes advertised to peers after a device reboot
By default, the device sends BGP routes immediately to peers after the device restarts and the BGP process recovers. If the device advertises routes before completing ARP table convergence, the traffic matching these advertised routes might not be forwarded correctly, which causes traffic loss.
To resolve this issue, use this feature to minimize the priority of the routes to be advertised after the device restarts and the BGP process recovers. Peers will not select the routes received from the device as the optimal routes. After the ARP table convergence is completed and the specified wait time elapses, the device restores the priority of the routes advertised to the peers.
After you use this feature, the device performs the following tasks after the device restarts and the BGP process recovers:
1.     Set the local preference value to the minimum (0) and the MED value to the maximum (4294967295) for the routes to be advertised.
2.     After the specified wait time elapses, restore the local preference value and the MED value for the advertised routes, and then advertise these routes immediately.
¡     reset bgp advertise lowest-priority on-startup
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to peers. The device does not minimize the priority of the subsequent routes advertised to the peers unless the device restarts again.
¡     undo advertise lowest-priority on-startup duration
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to peers. The device does not change the original local preference value and MED value for the subsequent routes advertised to the peers.
The configuration of the advertise lowest-priority on-startup duration command does not take effect immediately. It takes effect only after the device restarts.
The following commands can influence the configuration of each other:
When you use two of the commands above together, the configuration result varies by command. For more information, see Table 1.
3.     Minimize the priority of the routes advertised to peers after the device restarts and the BGP process recovers.
advertise lowest-priority on-startup duration seconds
Restoring the priority of advertised BGP routes
After configuring the device to minimize the priority of BGP routes advertised to peers, you can perform this task to manually restore the priority of BGP routes before the specified wait time expires.
After you perform this task, the device immediately sends BGP routes with the original local preference value and MED value to peers.
·     If the state of a peer changes from Down to Up later, the device still minimizes the priority of the routes advertised to that peer.
·     If the device restarts again later, the device still minimizes the priority of the routes advertised to peers.
Before performing this task, make sure the following conditions exist:
·     The device is ready to advertise routes with original priority.
·     The advertise lowest-priority on-peer-up duration or advertise lowest-priority on-startup duration command still takes effect after a peer comes up or the device restarts.
To restore the priority of advertised BGP routes, execute the following command in user view:
reset bgp [ instance instance-name ] advertise lowest-priority { on-peer-up | on-startup }
Specifying a local network to be advertised in the public instance or a VPN instance
This feature specifies a local network of the public instance or a VPN instance. Then, you can configure BGP to redistribute the network (by using the import-route local-aggregate command) and advertise the network. For more information about the import-route local-aggregate command, see BGP commands in Layer 3—IP Routing Command Reference.
The specified local network route must exist and be active in the routing table of the public instance or VPN instance.
2.     Enter public instance IPv4 address family view or VPN instance IPv4 address family view.
¡     Execute the following commands in sequence to enter public instance IPv4 address family view:
ip public-instance
address-family ipv4
¡     Execute the following commands in sequence to enter VPN instance IPv4 address family view:
address-family ipv4
3.     Specify a local network to be advertised.
network ipv4-address [ mask-length | mask ]
By default, no local network in the public instance or a VPN instance will be advertised.
Configuring route replication
Configuring the public instance
Configure the public instance to enable the mutual access between public network and private network users.
In an MPLS L3VPN network, for the public network and the VPN network to communicate with each other through route target matching, perform the following tasks:
·     Configure matching route targets for the public instance and VPN instance.
·     Use the route-replicate enable command in BGP instance view to enable mutual BGP route replication between the public and VPN instances.
The configuration in public instance IPv4 address family view takes precedence over that in public instance view.
2.     Enter public instance view.
ip public-instance
3.     Configure an RD for the public instance.
By default, no RD is configured for the public instance.
4.     Configure a route target for the public instance.
By default, no route target is configured for the public instance.
5.     Apply an import routing policy to the public instance.
By default, all routes matching the import target attribute are accepted.
6.     Apply an export routing policy to the public instance.
By default, routes to be advertised are not filtered.
7.     Set the maximum number of active route prefixes supported by the public instance.
By default, no limit is set for the number of active route prefixes supported by the public instance.
8.     Enter public instance IPv4 address family view.
address-family ipv4
9.     Configure a route target for the public instance IPv4 address family.
By default, no route target is configured for the public instance IPv4 address family.
10.     Apply an import routing policy to the public instance IPv4 address family.
11.     Apply an export routing policy to the public instance IPv4 address family.
12.     Set the maximum number of active route prefixes supported by the public instance IPv4 address family.
By default, no limit is set for the number of active route prefixes supported by the public instance IPv4 address family.
Configuring route replication for public instance and VPN instance
In a BGP/MPLS L3VPN network, only VPN instances that have matching route targets can communicate with each other.
By configuring the route replication feature, the following functions are available:
·     Enables a VPN instance to communicate with the public network or other VPN instances by replicating routes from the public instance or other VPN instances.
·     Enables the public network to communicate with a VPN instance by replicating routes from the VPN instance to the public instance.
In an intelligent traffic control network, traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network, configure this feature to replicate routes from the public instance to the VPN instances.
VLINK direct routes are generated based on ARP entries learned by interfaces. The route-replicate from vpn-instance protocol direct or route-replicate from public protocol direct command replicates VLINK direct routes, but the routes cannot be added to the FIB, causing traffic forwarding failures. To address this issue, you can specify the vlink-direct keyword to replicate VLINK direct routes and adds the routes to the FIB.
Configuring a VPN instance to replicate routes from the public instance or another VPN instance
2.     Enter VPN instance view.
3.     Enter VPN instance IPv4 address family view.
address-family ipv4
4.     Replicate routes from the public instance or other VPN instances.
route-replicate from { public | vpn-instance vpn-instance-name } protocol { bgp as-number | direct | static | unr | { isis | ospf | rip } process-id | vlink-direct } [ advertise ] [ route-policy route-policy-name ]
route-replicate from { public | vpn-instance vpn-instance-name } protocol eigrp eigrp-as [ advertise ] [ route-policy route-policy-name ]
By default, a VPN instance cannot replicate routes from the public instance or other VPN instances.
Configuring the public instance to replicate routes from a VPN instance
ip public-instance
3.     Enter public instance IPv4 address family view.
address-family ipv4
4.     Replicate routes from a VPN instance to the public instance.
route-replicate from vpn-instance vpn-instance-name protocol { bgp as-number | direct | static | { isis | ospf | rip } process-id | unr | vlink-direct } [ advertise ] [ route-policy route-policy-name ]
By default, the public instance cannot replicate routes from VPN instances.
Configuring BGP route replication between public and VPN instances
In traffic cleaning scenarios, traffic between the public and private networks are filtered by firewalls and traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network under the protection of firewalls, BGP route replication between public and VPN instances is required.
By default, only VPN instances that have matching route targets can redistribute BGP routes from each other, while the public instance and VPN instances cannot. After you configure this feature, the public instance and VPN instances that have matching route targets can replicate BGP routes from each other, enabling communication between the public network and VPN users.
This feature also replicates the BGP route attributes, so that the device can select proper forwarding paths according to the route attributes.
After this feature is enabled, the public network and VPNs cannot be isolated. Configure this feature only in specific scenarios, for example, the traffic cleaning scenario.
To use this feature to implement IPv4 or IPv6 route replication between the public instance and a VPN instance, make sure the VPN instance and the BGP IPv4 or IPv6 unicast address family have been created.
3.     Enable BGP route replication between public and VPN instances.
By default, BGP route replication between public and VPN instances is disabled.
Configuring route re-origination
By default, BGP routes in different VPN instances are isolated. In some networks, a device might need to advertise routes across VPN instances or advertise the routes in a VPN instance through other VPN instances to hide the routing information of the VPN instance.
Figure 20 Route re-origination
As shown in Figure 20, PE 1 and PE 2 set up public IBGP sessions with PE 3, and the public instance and VPN instances exchange routes to enable communication between the public network and the VPN sites. PE 1 and PE 2 set up VPNv4 IBGP peer relationships with each other to exchange VPN instance routes. When all links operate correctly, PE 2 receives the public routes advertised by PE 3 and redistributes the routes to the local VPN site. When the link between PE 2 and PE 3 fails, perform the following tasks for PE 1 to reoriginate the public routes in a specified VPN instance and advertise them to PE 2:
1.     Configure route targets for the public instance on PE 1. Make sure the route targets match those of the VPN instance to redistribute public routes.
2.     Execute the route-replicate enable command on PE 1 to redistribute the BGP routes of the public instance to the target VPN instance.
3.     Execute the advertise route-reoriginate command on PE 1 to enable reoriginating the BGP routes of other VPN instances in the target VPN instance. This command enables reoriginating BGP routes based on only the BGP routes that match the route targets of the target VPN instance. The VPN instance does not reoriginate BGP routes based on the redistributed local routes, such as the IGP routes redistributed by using the import-route command.
4.     Execute the peer advertise vpn-reoriginate ibgp command on PE 1 to advertise reoriginated routes to IBGP peer PE 2.
You must use the peer advertise vpn-reoriginate ibgp command in combination with the advertise route-reoriginate command. If you execute only the peer advertise vpn-reoriginate ibgp command, it does not take effect.
3.     (Optional.) Enable BGP route replication between public and VPN instances.
4.     Enter BGP-VPN instance view.
6.     Re-originate BGP unicast routes from other VPN instances.
advertise route-reoriginate [ route-policy route-policy-name ] [ replace-rt ]
By default, a VPN instance cannot re-originate BGP unicast routes from other VPN instances.
This command enables reoriginating BGP routes based on only the BGP routes that match the route targets of the current VPN instance. The VPN instance does not reoriginate BGP routes based on the redistributed local routes.
7.     (Optional.) Enable advertising the BGP routes reoriginated for a VPN instance to an IBGP peer or peer group.
a.     Return to BGP instance view.
b.     Enter BGP VPNv4 address family view.
address-family vpnv4
c.     Enable advertising the BGP routes reoriginated for a VPN instance to an IBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise vpn-reoriginate ibgp
By default, the device does not advertise the BGP routes reoriginated for a VPN instance to IBGP peers or peer groups.
Enabling ECMP VPN route redistribution
For multiple routes that have the same prefix and RD, a VPN instance redistributes only the optimal route into its routing table by default. This feature enables a VPN instance to redistribute all routes that have the same prefix and RD into its routing table to perform load sharing.
2.     Enter a BGP address family view.
¡     Enter BGP instance view.
¡     Execute the following commands in sequence to enter BGP IPv4 unicast address family view.
¡     Execute the following commands in sequence to enter BGP IPv6 unicast address family view.
¡     Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
¡     Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
3.     Enable ECMP VPN route redistribution.
vpn-route cross multipath
By default, ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, a VPN instance redistributes only the optimal route into its routing table.
In BGP IPv4 unicast address family view and BGP IPv6 unicast address family view, this command redistributes ECMP routes to the routing table of the public instance. For more information about the public instance, see EVPN Configuration Guide.
Enabling prioritized withdrawal of specific routes
Configure BGP to send withdrawal messages of specific routes prior to other routes to ensure fast route switchover and reduce the traffic interruption time for the specific routes.
For more information about the commands of this feature, see basic BGP commands in Layer 3—IP Routing Command Reference.
3.     Enter BGP VPNv4 address family view.
4.     Configure BGP to send withdrawal messages of routes matching the specified routing policy prior to other routes.
By default, BGP does not send withdrawal messages of specific routes prior to other routes.
Configuring BGP next hop recursion based on a routing policy
BGP route recursion without any restrictions might recurse a route to an incorrect forwarding path.
To resolve this issue, you can use a routing policy to control the route recursion results. After you configure this feature, the next hop for a BGP route can be recursed only to a route that is permitted by the routing policy. You can configure various conditions in the routing policy to filter out incorrect routes and ensure that the next hop of a BGP route can be recursed to the expected forwarding path.
If none of the recursive next hops for a BGP route is permitted by the routing policy, the BGP route is marked as unreachable. A BGP route is permitted by a routing policy if it passes the filtering of the permit node in the routing policy.
To not use a routing policy to filter the recursive routes for the BGP routes learned from a specific peer or peer group, you can use the peer nexthop-recursive-policy disable command to disable routing policy-based recursive next hop lookup.
The nexthop recursive-lookup route-policy command does not take effect on the routes learned from direct EBGP peers.
In you execute the nexthop recursive-lookup route-policy command in BGP VPNv4 or BGP-VPN VPNv4 address family view and the protocol nexthop recursive-lookup command in RIB IPv4 address family view, the nexthop recursive-lookup route-policy command takes effect on the BGP routes in BGP VPNv4 or BGP-VPN VPNv4 address family view.
If the nexthop recursive-lookup route-policy command is not executed in a BGP address family view but the protocol nexthop recursive-lookup command is executed in RIB IPv4 address family view, the BGP routes in the BGP address family use the protocol nexthop recursive-lookup command settings for recursive next hop lookup.
For more information about the nexthop recursive-lookup route-policy command and the peer nexthop-recursive-policy disable command, see BGP commands in Layer 3—IP Routing Command Reference.
For more information about the protocol nexthop recursive-lookup command, see basic IP routing commands in Layer 3—IP Routing Command Reference.
¡     Execute the following commands in sequence to enter BGP VPNv4 address family view.
¡     Execute the following commands in sequence to enter BGP-VPN VPNv4 address family view.
3.     Configure BGP next hop recursion based on a routing policy.
nexthop recursive-lookup route-policy route-policy-name
By default, BGP does not use a routing policy to filter recursive next hop routes.
CAUTION
CAUTION:
After this command is executed, if no recursive next hops for the BGP routes in the address family are permitted by the routing policy, all the BGP routes become unreachable routes. Before you execute this command, make sure the expected recursive next hop route can pass the filtering of the permit node in the specified routing policy.
4.     (Optional.) Disable routing policy-based recursive next hop lookup:
a.     Return to BGP instance view or BGP-VPN instance view.
b.     Disable routing policy-based recursive next hop lookup for routes learned from the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } nexthop-recursive-policy disable
By default, recursive next hop lookup for routes is controlled by a routing policy.
After you execute this command, the nexthop recursive-lookup route-policy and protocol nexthop recursive-lookup commands do not take effect on the BGP routes learned from the specified peer or peer group.
Configuring a VPN peer
Two virtual private clouds (VPCs) that communicate with each other through MPLS L3VPN are called VPN peers of each other.
You can configure routes to carry a VPN peer ID by using a routing policy. Packets that match the routes will be processed based on the user profile associated with the VPN peer.
For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
For more information about user profiles, see Security Configuration Guide.
2.     Configure a VPN peer.
vpn-peer vpn-peer-name vpn-peer-id vpn-peer-id user-profile profile-name
Enabling SNMP notifications for MPLS L3VPN
To report critical MPLS L3VPN events to an NMS, enable SNMP notifications for MPLS L3VPN. For MPLS L3VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for MPLS L3VPN.
snmp-agent trap enable l3vpn [ vrf-down | vrf-ipv6-down | vrf-ipv6-up | vrf-up ] *
By default, SNMP notifications for MPLS L3VPN are enabled.
Enabling logging for BGP route flapping
This feature enables BGP to generate logs for BGP route flappings that trigger log generation. The generated logs are sent to the information center. For the logs to be output correctly, you must also configure information center on the device. For more information about the information center, see System Management Configuration Guide.
3.     Enable logging for BGP route flapping.
By default, logging for BGP route flapping is disabled.
Verifying and maintaining MPLS L3VPN
Verifying MPLS L3VPN configuration and running status
Verifying BGP route configuration
·     Display BGP peer and route summary information.
display bgp [ instance instance-name ] vpnv4 summary
For more information about the command, see basic BGP commands in Layer 3—IP Routing Command Reference.
·     Display BGP RT filter routing information.
display bgp [ instance instance-name ] routing-table ipv4 rtfilter [ default-rt [ advertise-info | as-path | cluster-list ] | [ origin-as as-number ] [ route-target [ advertise-info | as-path | cluster-list ] ] | peer ipv4-address { advertised-routes | received-routes } [ default-rt | [ origin-as as-number ] [ route-target ] | statistics ] | statistics ]
·     Display BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table vpnv4 [ [ route-distinguisher route-distinguisher ] [ ipv4-address [ mask-length | mask ] [ longest-match ] | ipv4-address [ mask-length | mask ] advertise-info | ipv4-address [ mask-length | mask ] { as-path | cluster-list | community | ext-community } | [ vpn-instance vpn-instance-name ] peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher ] as-path-acl { as-path-acl-number | as-path-acl-name }
display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher ] [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher ] [ statistics ] ext-community [ bandwidth link-bandwidth-value | color color | rt route-target | soo site-of-origin ]&<1-32> [ whole-match ]
display bgp [ instance instance-name ] routing-table vpnv4 [ same-rd-selected ]
·     Display information about dampened BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table dampened vpnv4
For more information about this command, see basic BGP commands in Layer 3—IP Routing Command Reference.
·     Display route targets sourcing from a VPN instance.
display bgp [ instance instance-name ] route-target l3vpn [ ipv4 ] [ vpn-instance vpn-instance-name ]
Verifying BGP peer and peer group configuration
This section only lists the commands for verifying BGP peer and peer group configuration. For more information about the commands, see basic BGP commands in Layer 3—IP Routing Command Reference.
·     Display BGP RT filter peer information.
display bgp [ instance instance-name ] peer ipv4 rtfilter [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
·     Display BGP VPNv4 peer information.
display bgp [ instance instance-name ] peer vpnv4 [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
·     Display BGP RT filter peer group information.
display bgp [ instance instance-name ] group ipv4 rtfilter [ group-name group-name ]
·     Display BGP VPNv4 peer group information.
display bgp [ instance instance-name ] group vpnv4 [ vpn-instance vpn-instance-name ] [ group-name group-name ]
Verifying BGP update group configuration
This section only lists the commands for verifying BGP update group configuration. For more information about the commands, see basic BGP commands in Layer 3—IP Routing Command Reference.
·     Display BGP IPv4 RT filter address family update group information.
display bgp [ instance instance-name ] update-group ipv4 rtfilter [ ipv4-address ]
·     Display BGP VPNc4 address family update group information.
display bgp [ instance instance-name ] update-group vpnv4 [ vpn-instance vpn-instance-name ] [ ipv4-address ]
Verifying incoming label and outgoing label configuration
·     Display incoming labels for BGP IPv4 unicast routes.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] inlabel
·     Display outgoing labels for BGP IPv4 unicast routes.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] outlabel
·     Display incoming labels for BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table vpnv4 inlabel
·     Display outgoing labels for BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table vpnv4 outlabel
Verifying VPN instance configuration
·     Display information about a VPN instance.
display ip vpn-instance [ instance-name vpn-instance-name ]
·     Display the routing table for a VPN instance.
display ip routing-table vpn-instance vpn-instance-name [ statistics | verbose ]
For more information about the command, see IP routing basics commands in Layer 3—IP Routing Command Reference.
·     Display the FIB of a VPN instance.
display fib vpn-instance vpn-instance-name
For more information about the command, see IP forwarding basics commands in Layer 3—IP Services Command Reference.
·     Display FIB entries that match the specified destination IP address in the specified VPN instance.
display fib vpn-instance vpn-instance-name ip-address [ mask-length | mask ]
Verifying VPN peer configuration
To display VPN peer information, execute the following command in any view:
display vpn-peer [ peer-id vpn-peer-id | peer-name vpn-peer-name | verbose ]
Displaying and clearing MPLS label forwarding statistics
To display MPLS label forwarding statistics for a VPN instance, execute the following command in any view:
display ip vpn-instance mpls statistics [ instance-name vpn-instance-name ]
To clear MPLS label forwarding statistics for a VPN instance, execute the following command in user view:
reset ip vpn-instance mpls statistics [ instance-name vpn-instance-name ]
Displaying and clearing BGP VPNv4 route dampening parameters
To display BGP VPNv4 route dampening parameters, execute the following command in any view:
display bgp [ instance instance-name ] dampening parameter vpnv4
To clear BGP VPNv4 route dampening information and release dampened routes, execute the following command in user view:
reset bgp [ instance instance-name ] dampening vpnv4 [ ipv4-address [ mask | mask-length ] ]
Displaying and clearing BGP VPNv4 route flapping statistics
To display BGP VPNv4 route flapping statistics, execute the following command in any view:
To clear BGP VPNv4 route flapping statistics, execute the following command in user view:
reset bgp [ instance instance-name ] flap-info vpnv4 [ ipv4-address [ mask | mask-length ] | as-path-acl as-path-acl-number | peer ipv4-address [ mask-length ] ]
Resetting BGP sessions
You can soft-reset or reset BGP sessions to apply new BGP configurations. A soft reset operation updates BGP routing information without tearing down BGP connections. A reset operation updates BGP routing information by tearing down, and then re-establishing BGP connections. Soft reset requires that BGP peers have route refresh capability.
The following information only lists the commands for resetting BGP sessions. For more information about the commands, see basic BGP commands in Layer 3—IP Routing Command Reference.
Perform refresh or reset tasks in user view:
·     Soft-reset BGP sessions for the BGP IPv4 RT filter address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 rtfilter
·     Soft-reset BGP sessions for the BGP VPNv4 address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } vpnv4 [ vpn-instance vpn-instance-name ]
·     Reset BGP sessions for the BGP IPv4 RT filter address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | internal | group group-name } ipv4 rtfilter
·     Reset BGP sessions for the BGP VPNv4 address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | internal | group group-name } vpnv4 [ vpn-instance vpn-instance-name ]
MPLS L3VPN configuration examples
Example: Configuring basic MPLS L3VPN
CE 1 and CE 3 belong to VPN 1. CE 2 and CE 4 belong to VPN 2.
VPN 1 uses route target attribute 111:1. VPN 2 uses route target attribute 222:2. Users of different VPNs cannot access each other.
EBGP is used to exchange VPN routing information between CE and PE.
PEs use OSPF to communicate with each other and use MP-IBGP to exchange VPN routing information.
Figure 21 Network diagram
Device
IP address
Device
IP address
CE 1
Vlan-int11
10.1.1.1/24
P
Loop0
2.2.2.9/32
PE 1
Loop0
1.1.1.9/32
Vlan-int12
172.2.1.1/24
Vlan-int11
10.1.1.2/24
Vlan-int13
172.1.1.2/24
Vlan-int13
172.1.1.1/24
PE 2
Loop0
3.3.3.9/32
Vlan-int12
10.2.1.2/24
Vlan-int12
172.2.1.2/24
CE 2
Vlan-int12
10.2.1.1/24
Vlan-int11
10.3.1.2/24
CE 3
Vlan-int11
10.3.1.1/24
Vlan-int13
10.4.1.2/24
CE 4
Vlan-int13
10.4.1.1/24
1.     Configure an IGP on the MPLS backbone to ensure IP connectivity within the backbone:
# Configure PE 1.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] interface vlan-interface 13
[PE1-Vlan-interface13] ip address 172.1.1.1 24
[PE1-Vlan-interface13] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure the P device.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface vlan-interface 13
[P-Vlan-interface13] ip address 172.1.1.2 24
[P-Vlan-interface13] quit
[P] interface vlan-interface 12
[P-Vlan-interface12] ip address 172.2.1.1 24
[P-Vlan-interface12] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2-Vlan-interface12] ip address 172.2.1.2 24
[PE2-Vlan-interface12] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
# Execute the display ospf peer command to verify that OSPF adjacencies in Full state have been established between PE 1, P, and PE 2. Execute the display ip routing-table command to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
2.     Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Vlan-interface13] mpls enable
[PE1-Vlan-interface13] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Vlan-interface13] mpls enable
[P-Vlan-interface13] mpls ldp enable
[P-Vlan-interface12] mpls enable
[P-Vlan-interface12] mpls ldp enable
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Vlan-interface12] mpls enable
[PE2-Vlan-interface12] mpls ldp enable
# Execute the display mpls ldp peer command to verify that LDP sessions in Operational state have been established between PE 1, P, and PE 2. Execute the display mpls ldp lsp command to verify that the LSPs have been established by LDP. (Details not shown.)
3.     Configure VPN instances on PEs:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 222:2
[PE1-vpn-instance-vpn2] quit
[PE1] interface vlan-interface 11
[PE1-Vlan-interface11] ip binding vpn-instance vpn1
[PE1-Vlan-interface11] ip address 10.1.1.2 24
[PE1-Vlan-interface11] quit
[PE1-Vlan-interface12] ip binding vpn-instance vpn2
[PE1-Vlan-interface12] ip address 10.2.1.2 24
[PE1-Vlan-interface12] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 200:2
[PE2-vpn-instance-vpn2] vpn-target 222:2
[PE2-vpn-instance-vpn2] quit
[PE2] interface vlan-interface 11
[PE2-Vlan-interface11] ip binding vpn-instance vpn1
[PE2-Vlan-interface11] ip address 10.3.1.2 24
[PE2-Vlan-interface11] quit
[PE2] interface vlan-interface 13
[PE2-Vlan-interface13] ip binding vpn-instance vpn2
[PE2-Vlan-interface13] ip address 10.4.1.2 24
[PE2-Vlan-interface13] quit
# Configure IP addresses for the CEs according to Figure 21. (Details not shown.)
# Execute the display ip vpn-instance command on the PEs to display the configuration of the VPN instance.
# Use the ping command on the PEs to verify that the PEs can ping their attached CEs.
4.     Establish EBGP peer relationships between PEs and CEs, and redistribute VPN routes into BGP:
# Configure CE 1.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp-default] peer 10.1.1.2 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.2 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
# Configure the other three CEs in the same way that CE 1 is configured. (Details not shown.)
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] ip vpn-instance vpn2
[PE1-bgp-default-vpn2] peer 10.2.1.1 as-number 65420
[PE1-bgp-default-vpn2] address-family ipv4 unicast
[PE1-bgp-default-ipv4-vpn2] peer 10.2.1.1 enable
[PE1-bgp-default-ipv4-vpn2] quit
[PE1-bgp-default-vpn2] quit
[PE1-bgp-default] quit
# Configure PE 2 in the same way that PE 1 is configured. (Details not shown.)
# Execute the display bgp peer ipv4 vpn-instance command on the PEs to verify that a BGP peer relationship in Established state has been established between a PE and a CE. (Details not shown.)
5.     Establish an MP-IBGP peer relationship between PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
# Execute the display bgp peer vpnv4 command on the PEs to verify that a BGP peer relationship in Established state has been established between the PEs. (Details not shown.)
# Execute the display ip routing-table vpn-instance command on the PEs.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 13        Routes : 13
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
10.1.1.0/24         Direct 0    0            10.1.1.2        Vlan11
10.1.1.0/32         Direct 0    0            10.1.1.2        Vlan11
10.1.1.2/32         Direct 0    0            127.0.0.1       InLoop0
10.1.1.255/32       Direct 0    0            10.1.1.2        Vlan11
10.3.1.0/24         BGP    255  0            3.3.3.9         Vlan13
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
The output shows that PE 1 has a route to the remote CE. Output on PE 2 is similar.
# Verify that CEs of the same VPN can ping each other, whereas those of different VPNs cannot. For example, CE 1 can ping CE 3 (10.3.1.1) but cannot ping CE 4 (10.4.1.1). (Details not shown.)
Example: Configuring an MPLS L3VPN over a GRE tunnel
CE 1 and CE 2 belong to VPN 1. The PEs support MPLS. The P switch does not support MPLS and provides only IP features.
On the backbone, use a GRE tunnel to encapsulate and forward VPN packets to implement MPLS L3VPN.
Configure tunnel policies on the PEs, and specify the tunnel type for VPN traffic as GRE.
Figure 22 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Vlan-int12
10.1.1.1/24
P
Vlan-int11
172.1.1.2/24
PE 1
Loop0
1.1.1.9/32
Vlan-int12
172.2.1.1/24
Vlan-int12
10.1.1.2/24
PE 2
Loop0
2.2.2.9/32
Vlan-int11
172.1.1.1/24
Vlan-int11
10.2.1.2/24
Tunnel0
20.1.1.1/24
Vlan-int12
172.2.1.2/24
CE 2
Vlan-int12
10.2.1.1/24
Tunnel0
20.1.1.2/24
1.     Configure an IGP on the MPLS backbone to ensure IP connectivity within the backbone.
This example uses OSPF. (Details not shown.)
2.     Configure basic MPLS on the PEs:
# Configure PE 1.
<PE1> system-view
# Configure PE 2.
<PE2> system-view
[PE2] mpls lsr-id 2.2.2.9
3.     Configure VPN instances on PEs, and apply tunnel policies to the VPN instances to use a GRE tunnel for VPN packet forwarding:
# Configure PE 1.
[PE1] tunnel-policy gre1
[PE1-tunnel-policy-gre1] select-seq gre load-balance-number 1
[PE1-tunnel-policy-gre1] quit
[PE1-vpn-instance-vpn1] vpn-target 100:1 both
[PE1-vpn-instance-vpn1] tnl-policy gre1
[PE1-Vlan-interface12] ip binding vpn-instance vpn1
[PE1-Vlan-interface12] ip address 10.1.1.2 24
# Configure PE 2.
[PE2] tunnel-policy gre1
[PE2-tunnel-policy-gre1] select-seq gre load-balance-number 1
[PE2-tunnel-policy-gre1] quit
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2-vpn-instance-vpn1] vpn-target 100:1 both
[PE2-vpn-instance-vpn1] tnl-policy gre1
[PE2-Vlan-interface11] ip address 10.2.1.2 24
# Configure CE 1.
<CE1> system-view
[CE1] interface vlan-interface 12
[CE1-Vlan-interface12] ip address 10.1.1.1 24
[CE1-Vlan-interface12] quit
# Configure CE 2.
<CE2> system-view
[CE2] interface vlan-interface 11
[CE2-Vlan-interface11] ip address 10.2.1.1 24
[CE2-Vlan-interface11] quit
# Configure CE 1.
[CE1] bgp 65410
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 next-hop-local
# Configure CE 2 and PE 2 in the same way that CE 1 and PE 1 are configured. (Details not shown.)
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 2.2.2.9 enable
6.     Configure a GRE tunnel:
# Configure PE 1.
[PE1] interface tunnel 0 mode gre
[PE1-Tunnel0] source loopback 0
[PE1-Tunnel0] destination 2.2.2.9
[PE1-Tunnel0] ip address 20.1.1.1 24
[PE1-Tunnel0] mpls enable
[PE1-Tunnel0] quit
# Configure PE 2.
[PE2] interface tunnel 0 mode gre
[PE2-Tunnel0] source loopback 0
[PE2-Tunnel0] destination 1.1.1.9
[PE2-Tunnel0] ip address 20.1.1.2 24
[PE2-Tunnel0] mpls enable
[PE2-Tunnel0] quit
# Use the following command on CE 1 to verify that the CEs have learned the interface route from each other.
[CE1] display ip routing-table
10.1.1.0/24         Direct 0    0            10.1.1.1        Vlan12
10.1.1.0/32         Direct 0    0            10.1.1.1        Vlan12
10.1.1.1/32         Direct 0    0            127.0.0.1       InLoop0
10.1.1.255/32       Direct 0    0            10.1.1.1        Vlan12
10.2.1.0/24         BGP    255  0            10.1.1.2        Vlan12
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Configuring a hub-spoke network
The Spoke-CEs cannot communicate directly. They can communicate only through Hub-CE.
Configure EBGP between the Spoke-CEs and Spoke-PEs and between Hub-CE and Hub-PE to exchange VPN routing information.
Configure OSPF between the Spoke-PEs and Hub-PE to implement communication between the PEs, and configure MP-IBGP between them to exchange VPN routing information.
Figure 23 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
Spoke-CE 1
Vlan-int2
10.1.1.1/24
Hub-CE
Vlan-int6
10.3.1.1/24
Spoke-PE 1
Loop0
1.1.1.9/32
Vlan-int7
10.4.1.1/24
Vlan-int2
10.1.1.2/24
Hub-PE
Loop0
2.2.2.9/32
Vlan-int4
172.1.1.1/24
Vlan-int4
172.1.1.2/24
Spoke-CE 2
Vlan-int3
10.2.1.1/24
Vlan-int5
172.2.1.2/24
Spoke-PE 2
Loop0
3.3.3.9/32
Vlan-int6
10.3.1.2/24
Vlan-int3
10.2.1.2/24
Vlan-int7
10.4.1.2/24
Vlan-int5
172.2.1.1/24
# Configure Spoke-PE 1.
<Spoke-PE1> system-view
[Spoke-PE1] interface loopback 0
[Spoke-PE1-LoopBack0] ip address 1.1.1.9 32
[Spoke-PE1-LoopBack0] quit
[Spoke-PE1] interface vlan-interface 4
[Spoke-PE1-Vlan-interface4] ip address 172.1.1.1 24
[Spoke-PE1-Vlan-interface4] quit
[Spoke-PE1] ospf
[Spoke-PE1-ospf-1] area 0
[Spoke-PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Spoke-PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[Spoke-PE1-ospf-1-area-0.0.0.0] quit
[Spoke-PE1-ospf-1] quit
# Configure Spoke-PE 2.
<Spoke-PE2> system-view
[Spoke-PE2] interface loopback 0
[Spoke-PE2-LoopBack0] ip address 3.3.3.9 32
[Spoke-PE2-LoopBack0] quit
[Spoke-PE2] interface vlan-interface 5
[Spoke-PE2-Vlan-interface5] ip address 172.2.1.1 24
[Spoke-PE2-Vlan-interface5] quit
[Spoke-PE2] ospf
[Spoke-PE2-ospf-1] area 0
[Spoke-PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Spoke-PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[Spoke-PE2-ospf-1-area-0.0.0.0] quit
[Spoke-PE2-ospf-1] quit
# Configure Hub-PE.
<Hub-PE> system-view
[Hub-PE] interface loopback 0
[Hub-PE-LoopBack0] ip address 2.2.2.9 32
[Hub-PE-LoopBack0] quit
[Hub-PE] interface vlan-interface 4
[Hub-PE-Vlan-interface4] ip address 172.1.1.2 24
[Hub-PE-Vlan-interface4] quit
[Hub-PE] interface vlan-interface 5
[Hub-PE-Vlan-interface5] ip address 172.2.1.2 24
[Hub-PE-Vlan-interface5] quit
[Hub-PE] ospf
[Hub-PE-ospf-1] area 0
[Hub-PE-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[Hub-PE-ospf-1-area-0.0.0.0] quit
[Hub-PE-ospf-1] quit
# Execute the display ospf peer command on the devices to verify that OSPF adjacencies in Full state have been established between Spoke-PE 1, Spoke-PE 2, and Hub-PE. Execute the display ip routing-table command on the devices to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
[Spoke-PE1] mpls lsr-id 1.1.1.9
[Spoke-PE1] mpls ldp
[Spoke-PE1-ldp] quit
[Spoke-PE1-Vlan-interface4] mpls enable
[Spoke-PE1-Vlan-interface4] mpls ldp enable
[Spoke-PE2] mpls lsr-id 3.3.3.9
[Spoke-PE2] mpls ldp
[Spoke-PE2-ldp] quit
[Spoke-PE2-Vlan-interface5] mpls enable
[Spoke-PE2-Vlan-interface5] mpls ldp enable
# Configure Hub-PE.
[Hub-PE] mpls lsr-id 2.2.2.9
[Hub-PE] mpls ldp
[Hub-PE-ldp] quit
[Hub-PE-Vlan-interface4] mpls enable
[Hub-PE-Vlan-interface4] mpls ldp enable
[Hub-PE-Vlan-interface5] mpls enable
[Hub-PE-Vlan-interface5] mpls ldp enable
# Execute the display mpls ldp peer command on the devices to verify that LDP sessions in Operational state have been established between Spoke-PE 1, Spoke-PE 2, and Hub-PE. Execute the display mpls ldp lsp command on the devices to verify that the LSPs have been established by LDP. (Details not shown.)
3.     Configure VPN instances on the Spoke-PEs and Hub-PE:
[Spoke-PE1] ip vpn-instance vpn1
[Spoke-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[Spoke-PE1-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE1-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE1-vpn-instance-vpn1] quit
[Spoke-PE1] interface vlan-interface 2
[Spoke-PE1-Vlan-interface2] ip binding vpn-instance vpn1
[Spoke-PE1-Vlan-interface2] ip address 10.1.1.2 24
[Spoke-PE1-Vlan-interface2] quit
[Spoke-PE2] ip vpn-instance vpn1
[Spoke-PE2-vpn-instance-vpn1] route-distinguisher 100:2
[Spoke-PE2-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE2-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE2-vpn-instance-vpn1] quit
[Spoke-PE2] interface vlan-interface 3
[Spoke-PE2-Vlan-interface3] ip binding vpn-instance vpn1
[Spoke-PE2-Vlan-interface3] ip address 10.2.1.2 24
[Spoke-PE2-Vlan-interface3] quit
# Configure Hub-PE.
[Hub-PE] ip vpn-instance vpn1-in
[Hub-PE-vpn-instance-vpn1-in] route-distinguisher 100:3
[Hub-PE-vpn-instance-vpn1-in] vpn-target 222:2 import-extcommunity
[Hub-PE-vpn-instance-vpn1-in] quit
[Hub-PE] ip vpn-instance vpn1-out
[Hub-PE-vpn-instance-vpn1-out] route-distinguisher 100:4
[Hub-PE-vpn-instance-vpn1-out] vpn-target 111:1 export-extcommunity
[Hub-PE-vpn-instance-vpn1-out] quit
[Hub-PE] interface vlan-interface 6
[Hub-PE-Vlan-interface6] ip binding vpn-instance vpn1-in
[Hub-PE-Vlan-interface6] ip address 10.3.1.2 24
[Hub-PE-Vlan-interface6] quit
[Hub-PE] interface vlan-interface 7
[Hub-PE-Vlan-interface7] ip binding vpn-instance vpn1-out
[Hub-PE-Vlan-interface7] ip address 10.4.1.2 24
[Hub-PE-Vlan-interface7] quit
# Configure IP addresses for the CEs according to Table 4. (Details not shown.)
4.     Establish EBGP peer relationships between the PEs and CEs, and redistribute VPN routes into BGP:
# Configure Spoke-CE 1.
<Spoke-CE1> system-view
[Spoke-CE1] bgp 65410
[Spoke-CE1-bgp-default] peer 10.1.1.2 as-number 100
[Spoke-CE1-bgp-default] address-family ipv4
[Spoke-CE1-bgp-default-ipv4] peer 10.1.1.2 enable
[Spoke-CE1-bgp-default-ipv4] import-route direct
[Spoke-CE1-bgp-default-ipv4] quit
[Spoke-CE1-bgp-default] quit
# Configure Spoke-CE 2.
<Spoke-CE2> system-view
[Spoke-CE2] bgp 65420
[Spoke-CE2-bgp-default] peer 10.2.1.2 as-number 100
[Spoke-CE2-bgp-default] address-family ipv4
[Spoke-CE2-bgp-default-ipv4] peer 10.2.1.2 enable
[Spoke-CE2-bgp-default-ipv4] import-route direct
[Spoke-CE2-bgp-default-ipv4] quit
[Spoke-CE2-bgp-default] quit
# Configure Hub-CE.
<Hub-CE> system-view
[Hub-CE] bgp 65430
[Hub-CE-bgp-default] peer 10.3.1.2 as-number 100
[Hub-CE-bgp-default] peer 10.4.1.2 as-number 100
[Hub-CE-bgp-default] address-family ipv4
[Hub-CE-bgp-default-ipv4] peer 10.3.1.2 enable
[Hub-CE-bgp-default-ipv4] peer 10.4.1.2 enable
[Hub-CE-bgp-default-ipv4] import-route direct
[Hub-CE-bgp-default-ipv4] quit
[Hub-CE-bgp-default] quit
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] ip vpn-instance vpn1
[Spoke-PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65410
[Spoke-PE1-bgp-default-vpn1] address-family ipv4
[Spoke-PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[Spoke-PE1-bgp-default-ipv4-vpn1] quit
[Spoke-PE1-bgp-default-vpn1] quit
[Spoke-PE1-bgp-default] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] ip vpn-instance vpn1
[Spoke-PE2-bgp-default-vpn1] peer 10.2.1.1 as-number 65420
[Spoke-PE2-bgp-default-vpn1] address-family ipv4
[Spoke-PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
[Spoke-PE2-bgp-default-ipv4-vpn1] quit
[Spoke-PE2-bgp-default-vpn1] quit
[Spoke-PE2-bgp-default] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] ip vpn-instance vpn1-in
[Hub-PE-bgp-default-vpn1-in] peer 10.3.1.1 as-number 65430
[Hub-PE-bgp-default-vpn1-in] address-family ipv4
[Hub-PE-bgp-default-ipv4-vpn1-in] peer 10.3.1.1 enable
[Hub-PE-bgp-default-ipv4-vpn1-in] quit
[Hub-PE-bgp-default-vpn1-in] quit
[Hub-PE-bgp-default] ip vpn-instance vpn1-out
[Hub-PE-bgp-default-vpn1-out] peer 10.4.1.1 as-number 65430
[Hub-PE-bgp-default-vpn1-out] address-family ipv4
[Hub-PE-bgp-default-ipv4-vpn1-out] peer 10.4.1.1 enable
[Hub-PE-bgp-default-ipv4-vpn1-out] peer 10.4.1.1 allow-as-loop 2
[Hub-PE-bgp-default-ipv4-vpn1-out] quit
[Hub-PE-bgp-default-vpn1-out] quit
[Hub-PE-bgp-default] quit
5.     Establish an MP-IBGP peer relationship between the Spoke-PEs and Hub-PE:
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE1-bgp-default] address-family vpnv4
[Spoke-PE1-bgp-default-vpnv4] peer 2.2.2.9 enable
[Spoke-PE1-bgp-default-vpnv4] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE2-bgp-default] address-family vpnv4
[Spoke-PE2-bgp-default-vpnv4] peer 2.2.2.9 enable
[Spoke-PE2-bgp-default-vpnv4] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] peer 1.1.1.9 as-number 100
[Hub-PE-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[Hub-PE-bgp-default] peer 3.3.3.9 as-number 100
[Hub-PE-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[Hub-PE-bgp-default] address-family vpnv4
[Hub-PE-bgp-default-vpnv4] peer 1.1.1.9 enable
[Hub-PE-bgp-default-vpnv4] peer 3.3.3.9 enable
[Hub-PE-bgp-default-vpnv4] quit
# Execute the display ip routing-table vpn-instance command on the PEs to display the routes to the CEs. This example uses Spoke-PE 1 to verify that the next hop of the route from a Spoke-PE to its connected Spoke-CE is Hub-PE.
[Spoke-PE1] display ip routing-table vpn-instance vpn1
Destinations : 15        Routes : 15
Destination/Mask   Proto   Pre Cost        NextHop         Interface
10.1.1.0/24        Direct  0   0           10.1.1.2        Vlan2
10.1.1.0/32        Direct  0   0           10.1.1.2        Vlan2
10.1.1.255/32      Direct  0   0           10.1.1.2        Vlan2
10.2.1.0/24        BGP     255 0           2.2.2.9         Vlan4
10.3.1.0/24        BGP     255 0           2.2.2.9         Vlan4
10.4.1.0/24        BGP     255 0           2.2.2.9         Vlan4
# Verify that Spoke-CE 1 and Spoke-CE 2 can ping each other. The TTL value indicates that traffic from Spoke-CE 1 to Spoke-CE 2 passes six hops (255-250+1) and is forwarded through Hub-CE. This example uses Spoke-CE 1 to verify their connectivity.
[Spoke-CE1] ping 10.2.1.1
Ping 10.2.1.1 (10.2.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.2.1.1: icmp_seq=0 ttl=250 time=1.000 ms
56 bytes from 10.2.1.1: icmp_seq=1 ttl=250 time=2.000 ms
56 bytes from 10.2.1.1: icmp_seq=2 ttl=250 time=0.000 ms
56 bytes from 10.2.1.1: icmp_seq=3 ttl=250 time=1.000 ms
56 bytes from 10.2.1.1: icmp_seq=4 ttl=250 time=0.000 ms
--- Ping statistics for 10.2.1.1 ---
round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms
Example: Configuring MPLS L3VPN inter-AS option A
CE 1 and CE 2 belong to the same VPN. CE 1 accesses the network through PE 1 in AS 100, and CE 2 accesses the network through PE 2 in AS 200.
Configure MPLS L3VPN inter-AS option A, and use the VRF-to-VRF method to manage VPN routes.
Run OSPF on the MPLS backbone in each AS.
Figure 24 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Vlan-int12
10.1.1.1/24
CE 2
Vlan-int12
10.2.1.1/24
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
4.4.4.9/32
Vlan-int12
10.1.1.2/24
Vlan-int12
10.2.1.2/24
Vlan-int11
172.1.1.2/24
Vlan-int11
162.1.1.2/24
ASBR-PE 1
Loop0
2.2.2.9/32
ASBR-PE 2
Loop0
3.3.3.9/32
Vlan-int11
172.1.1.1/24
Vlan-int11
162.1.1.1/24
Vlan-int12
192.1.1.1/24
Vlan-int12
192.1.1.2/24
For the same VPN, the route targets for the VPN instance on the PE must match those for the VPN instance on the ASBR-PE in the same AS. This is not required for PEs in different ASs.
1.     Configure IGP on the MPLS backbone to implement the connectivity in the backbone.
# Execute the display ospf peer command to verify that each ASBR-PE has established an OSPF adjacency in Full state with the PE in the same AS, and that PEs and ASBR-PEs in the same AS have learned the routes to the loopback interfaces of each other. Verify that each ASBR-PE and the PE in the same AS can ping each other. (Details not shown.)
# Configure basic MPLS on PE 1, and enable MPLS LDP on the interface connected to ASBR-PE 1.
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Vlan-interface11] mpls enable
[PE1-Vlan-interface11] mpls ldp enable
# Configure basic MPLS on ASBR-PE 1, and enable MPLS LDP on the interface connected to PE 1.
<ASBR-PE1> system-view
[ASBR-PE1] mpls lsr-id 2.2.2.9
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1] interface vlan-interface 11
[ASBR-PE1-Vlan-interface11] mpls enable
[ASBR-PE1-Vlan-interface11] mpls ldp enable
[ASBR-PE1-Vlan-interface11] quit
# Configure basic MPLS on ASBR-PE 2, and enable MPLS LDP on the interface connected to PE 2.
<ASBR-PE2> system-view
[ASBR-PE2] mpls lsr-id 3.3.3.9
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2] interface vlan-interface 11
[ASBR-PE2-Vlan-interface11] mpls enable
[ASBR-PE2-Vlan-interface11] mpls ldp enable
[ASBR-PE2-Vlan-interface11] quit
# Configure basic MPLS on PE 2, and enable MPLS LDP on the interface connected to ASBR-PE 2.
<PE2> system-view
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Vlan-interface11] mpls enable
[PE2-Vlan-interface11] mpls ldp enable
# Execute the display mpls ldp peer command on the devices to verify that the session status is Operational, and that each PE and the ASBR-PE in the same AS have established a neighbor relationship. (Details not shown.)
# Configure CE 1.
<CE1> system-view
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 100:2
# Configure CE 2.
<CE2> system-view
[CE2] interface vlan-interface 12
[CE2-Vlan-interface12] ip address 10.2.1.1 24
[CE2-Vlan-interface12] quit
# Configure PE 2.
[PE2-vpn-instance] route-distinguisher 200:2
[PE2-vpn-instance] vpn-target 200:1 both
[PE2-vpn-instance] quit
[PE2-Vlan-interface12] ip binding vpn-instance vpn1
[PE2-Vlan-interface12] ip address 10.2.1.2 24
# On ASBR-PE 1, create a VPN instance, and bind the instance to the interface connected to ASBR-PE 2. ASBR-PE 1 considers ASBR-PE 2 to be its CE.
[ASBR-PE1] ip vpn-instance vpn1
[ASBR-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[ASBR-PE1-vpn-instance-vpn1] vpn-target 100:1 both
[ASBR-PE1-vpn-instance-vpn1] quit
[ASBR-PE1] interface vlan-interface 12
[ASBR-PE1-Vlan-interface12] ip binding vpn-instance vpn1
[ASBR-PE1-Vlan-interface12] ip address 192.1.1.1 24
[ASBR-PE1-Vlan-interface12] quit
# On ASBR-PE 2, create a VPN instance, and bind the instance to the interface connected to ASBR-PE 1. ASBR-PE 2 considers ASBR-PE 1 to be its CE.
[ASBR-PE2] ip vpn-instance vpn1
[ASBR-PE2-vpn-instance-vpn1] route-distinguisher 200:1
[ASBR-PE2-vpn-instance-vpn1] vpn-target 200:1 both
[ASBR-PE2-vpn-instance-vpn1] quit
[ASBR-PE2] interface vlan-interface 12
[ASBR-PE2-Vlan-interface12] ip binding vpn-instance vpn1
[ASBR-PE2-Vlan-interface12] ip address 192.1.1.2 24
[ASBR-PE2-Vlan-interface12] quit
# Execute the display ip vpn-instance command to display VPN instance configurations. Verify that the PEs can ping the CEs, and the ASBR-PEs can ping each other. (Details not shown.)
# Configure CE 1.
[CE1] bgp 65001
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65001
# Configure CE 2.
[CE2] bgp 65002
[CE2-bgp-default] peer 10.2.1.2 as-number 200
[CE2-bgp-default-ipv4] peer 10.2.1.2 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default-vpn1] peer 10.2.1.1 as-number 65002
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
[PE2-bgp-default-vpn1] quit
5.     Establish an MP-IBGP peer relationship between each PE and the ASBR-PE in the same AS, and an EBGP peer relationship between the ASBR-PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 2.2.2.9 next-hop-local
# Configure ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] ip vpn-instance vpn1
[ASBR-PE1-bgp-default-vpn1] peer 192.1.1.2 as-number 200
[ASBR-PE1-bgp-default-vpn1] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4-vpn1] peer 192.1.1.2 enable
[ASBR-PE1-bgp-default-ipv4-vpn1] quit
[ASBR-PE1-bgp-default-vpn1] quit
[ASBR-PE1-bgp-default] peer 1.1.1.9 as-number 100
[ASBR-PE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[ASBR-PE1-bgp-default-vpnv4] peer 1.1.1.9 enable
[ASBR-PE1-bgp-default-vpnv4] peer 1.1.1.9 next-hop-local
[ASBR-PE1-bgp-default] quit
# Configure ASBR-PE 2.
[ASBR-PE2] bgp 200
[ASBR-PE2-bgp-default] ip vpn-instance vpn1
[ASBR-PE2-bgp-default-vpn1] peer 192.1.1.1 as-number 100
[ASBR-PE2-bgp-default-vpn1] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4-vpn1] peer 192.1.1.1 enable
[ASBR-PE2-bgp-default-ipv4-vpn1] quit
[ASBR-PE2-bgp-default-vpn1] quit
[ASBR-PE2-bgp-default] peer 4.4.4.9 as-number 200
[ASBR-PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[ASBR-PE2-bgp-default-vpnv4] peer 4.4.4.9 enable
[ASBR-PE2-bgp-default-vpnv4] peer 4.4.4.9 next-hop-local
[ASBR-PE2-bgp-default] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default] peer 3.3.3.9 as-number 200
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 3.3.3.9 enable
[PE2-bgp-default-vpnv4] peer 3.3.3.9 next-hop-local
# Verify that the CEs can learn the interface routes from each other and ping each other. (Details not shown.)
Example: Configuring MPLS L3VPN inter-AS option B
Site 1 and Site 2 belong to the same VPN. CE 1 of Site 1 accesses the network through PE 1 in AS 100. CE 2 of Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange VPNv4 routes through MP-IBGP. PE 2 and ASBR-PE 2 exchange VPNv4 routes through MP-IBGP. ASBR-PE 1 and ASBR-PE 2 exchange VPNv4 routes through MP-EBGP.
ASBRs do not perform route target filtering of received VPN-IPv4 routes.
Figure 25 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
Vlan-int12
30.0.0.1/8
Vlan-int12
20.0.0.1/8
Vlan-int11
1.1.1.2/8
Vlan-int11
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
Vlan-int11
1.1.1.1/8
Vlan-int11
9.1.1.1/8
Vlan-int12
11.0.0.2/8
Vlan-int12
11.0.0.1/8
1.     Configure PE 1:
# Configure IS-IS on PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0001.00
[PE1-isis-1] quit
# Configure the LSR ID, and enable MPLS and LDP.
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls ldp
[PE1-ldp] quit
# Configure VLAN-interface 11, and enable IS-IS, MPLS, and LDP on the interface.
[PE1-Vlan-interface11] ip address 1.1.1.2 255.0.0.0
[PE1-Vlan-interface11] isis enable 1
# Configure Loopback 0, and enable IS-IS on it.
[PE1-LoopBack0] ip address 2.2.2.9 32
[PE1-LoopBack0] isis enable 1
# Create VPN instance vpn1, and configure the RD and route target attributes.
[PE1-vpn-instance-vpn1] vpn-target 1:1 2:2 import-extcommunity
[PE1-vpn-instance-vpn1] vpn-target 1:1 export-extcommunity
# Bind the interface connected to CE 1 to the created VPN instance.
[PE1-Vlan-interface12] ip address 30.0.0.1 8
# Enable BGP on PE 1.
[PE1] bgp 100
# Configure IBGP peer 3.3.3.9 as a VPNv4 peer.
# Redistribute direct routes to the VPN routing table of vpn1.
[PE1-bgp-default-ipv4-vpn1] import-route direct
2.     Configure ASBR-PE 1:
# Enable IS-IS on ASBR-PE 1.
[ASBR-PE1] isis 1
[ASBR-PE1-isis-1] network-entity 10.0000.0000.0000.0002.00
[ASBR-PE1-isis-1] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1] interface vlan-interface11
[ASBR-PE1-Vlan-interface11] ip address 1.1.1.1 255.0.0.0
[ASBR-PE1-Vlan-interface11] isis enable 1
# Configure VLAN-interface 12, and enable MPLS on it.
[ASBR-PE1-Vlan-interface12] ip address 11.0.0.2 255.0.0.0
[ASBR-PE1-Vlan-interface12] mpls enable
[ASBR-PE1-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack0] isis enable 1
[ASBR-PE1-LoopBack0] quit
# Enable BGP on ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[ASBR-PE1-bgp-default] peer 11.0.0.1 connect-interface vlan-interface 12
# Disable route target based filtering of received VPNv4 routes.
# Configure both IBGP peer 2.2.2.0 and EBGP peer 11.0.0.1 as VPNv4 peers.
3.     Configure ASBR-PE 2:
# Enable IS-IS on ASBR-PE 2.
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.0000.0000.0000.0003.00
[ASBR-PE2-isis-1] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2-Vlan-interface11] ip address 9.1.1.1 255.0.0.0
[ASBR-PE2-Vlan-interface11] isis enable 1
[ASBR-PE2-Vlan-interface12] ip address 11.0.0.1 255.0.0.0
[ASBR-PE2-Vlan-interface12] mpls enable
[ASBR-PE2] interface loopback 0
[ASBR-PE2-LoopBack0] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack0] isis enable 1
[ASBR-PE2-LoopBack0] quit
# Enable BGP on ASBR-PE 2.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] peer 11.0.0.2 connect-interface vlan-interface 12
[ASBR-PE2-bgp-default] peer 5.5.5.9 connect-interface loopback 0
# Configure both IBGP peer 5.5.5.9 and EBGP peer 11.0.0.2 as VPNv4 peers.
4.     Configure PE 2:
# Enable IS-IS on PE 2.
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE2-isis-1] quit
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Vlan-interface11] ip address 9.1.1.2 255.0.0.0
[PE2-Vlan-interface11] isis enable 1
[PE2-LoopBack0] ip address 5.5.5.9 32
[PE2-LoopBack0] isis enable 1
[PE2-vpn-instance-vpn1] route-distinguisher 12:12
[PE2-vpn-instance-vpn1] vpn-target 1:1 2:2 import-extcommunity
[PE2-vpn-instance-vpn1] vpn-target 2:2 export-extcommunity
# Bind the interface connected to CE 2 to the created VPN instance.
[PE2] interface vlan-interface12
[PE2-Vlan-interface12] ip address 20.0.0.1 8
# Enable BGP on PE 2.
[PE2] bgp 600
# Configure IBGP peer 4.4.4.9 as a VPNv4 peer.
[PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE2-bgp-default-ipv4-vpn1] import-route direct
# Use the following command on PE 1 to verify its connectivity to PE 2.
[PE1] ping -a 30.0.0.1 -vpn-instance vpn1 20.0.0.1
Ping 20.0.0.1 (20.0.0.1) from 30.0.0.1: 56 data bytes, press CTRL_C to break
56 bytes from 20.0.0.1: icmp_seq=0 ttl=255 time=1.208 ms
56 bytes from 20.0.0.1: icmp_seq=1 ttl=255 time=0.867 ms
56 bytes from 20.0.0.1: icmp_seq=2 ttl=255 time=0.551 ms
56 bytes from 20.0.0.1: icmp_seq=3 ttl=255 time=0.566 ms
56 bytes from 20.0.0.1: icmp_seq=4 ttl=255 time=0.570 ms
--- Ping statistics for 20.0.0.1 ---
round-trip min/avg/max/std-dev = 0.551/0.752/1.208/0.257 ms
Example: Configuring MPLS L3VPN inter-AS option C (method 1)
Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100. Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange labeled IPv4 routes through IBGP. PE 2 and ASBR-PE 2 exchange labeled IPv4 routes through IBGP. PE 1 and PE 2 exchange VPNv4 routes through MP-EBGP.
ASBR-PE 1 and ASBR-PE 2 use their respective routing policies and label routes received from each other.
ASBR-PE 1 and ASBR-PE 2 use EBGP to exchange labeled IPv4 routes.
Figure 26 Network diagram
Table 7 Interface and IP address assignment
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
Vlan-int11
1.1.1.2/8
Vlan-int11
9.1.1.2/8
Vlan-int12
30.0.0.1/24
Vlan-int12
20.0.0.1/24
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
Vlan-int11
1.1.1.1/8
Vlan-int11
9.1.1.1/8
Vlan-int12
11.0.0.2/8
Vlan-int12
11.0.0.1/8
CE 1
Vlan-int12
30.0.0.2/24
CE 2
Vlan-int12
20.0.0.2/24
1.     Configure CE 1:
# Configure an IP address for VLAN-interface 12.
<CE1> system-view
[CE1-Vlan-interface12] ip address 30.0.0.2 24
# Establish an EBGP peer relationship with PE 1, and redistribute VPN routes.
[CE1] bgp 65001
[CE1-bgp-default] peer 30.0.0.1 as-number 100
[CE1-bgp-default-ipv4] peer 30.0.0.1 enable
2.     Configure PE 1:
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
# Associate VLAN-interface 12 with VPN instance vpn1, and specify the IP address for the interface.
[PE1-Vlan-interface12] ip address 30.0.0.1 24
[PE1] bgp 100
# Enable the capability to advertise labeled routes to IBGP peer 3.3.3.9 and to receive labeled routes from the peer.
[PE1-bgp-default] address-family ipv4 unicast
[PE1-bgp-default-ipv4] peer 3.3.3.9 enable
[PE1-bgp-default-ipv4] peer 3.3.3.9 label-route-capability
[PE1-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp-default] peer 5.5.5.9 as-number 600
[PE1-bgp-default] peer 5.5.5.9 connect-interface loopback 0
[PE1-bgp-default] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv4 peer.
[PE1-bgp-default-vpnv4] peer 5.5.5.9 enable
# Establish an EBGP peer relationship with CE 1, and add the learned BGP routes to the routing table of VPN instance vpn1.
[PE1-bgp-default-vpn1] peer 30.0.0.2 as-number 65001
[PE1-bgp-default-ipv4-vpn1] peer 30.0.0.2 enable
3.     Configure ASBR-PE 1:
[ASBR-PE1] isis 1
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Create routing policies.
[ASBR-PE1] route-policy policy1 permit node 1
[ASBR-PE1-route-policy-policy1-1] apply mpls-label
[ASBR-PE1-route-policy-policy1-1] quit
[ASBR-PE1] route-policy policy2 permit node 1
[ASBR-PE1-route-policy-policy2-1] if-match mpls-label
[ASBR-PE1-route-policy-policy2-1] apply mpls-label
[ASBR-PE1-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 1, and apply the routing policy policy2 to routes advertised to IBGP peer 2.2.2.9.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 enable
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 route-policy policy2 export
# Enable the capability to advertise labeled routes to IBGP peer 2.2.2.9 and to receive labeled routes from the peer.
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 label-route-capability
# Redistribute routes from IS-IS process 1 to BGP.
[ASBR-PE1-bgp-default-ipv4] import-route isis 1
[ASBR-PE1-bgp-default-ipv4] quit
# Apply the routing policy policy1 to routes advertised to EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 route-policy policy1 export
# Enable the capability to advertise labeled routes to EBGP peer 11.0.0.1 and to receive labeled routes from the peer.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 label-route-capability
4.     Configure ASBR-PE 2:
[ASBR-PE2] isis 1
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2] route-policy policy1 permit node 1
[ASBR-PE2-route-policy-policy1-1] apply mpls-label
[ASBR-PE2-route-policy-policy1-1] quit
[ASBR-PE2] route-policy policy2 permit node 1
[ASBR-PE2-route-policy-policy2-1] if-match mpls-label
[ASBR-PE2-route-policy-policy2-1] apply mpls-label
[ASBR-PE2-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 2, and enable the capability to advertise labeled routes to IBGP peer 5.5.5.9 and to receive labeled routes from the peer.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 label-route-capability
# Apply routing policy policy2 to routes advertised to IBGP peer 5.5.5.9.
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 route-policy policy2 export
# Redistribute routes from IS-IS process 1 into BGP.
[ASBR-PE2-bgp-default-ipv4] import-route isis 1
[ASBR-PE2-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 route-policy policy1 export
# Enable the capability to advertise labeled routes to EBGP peer 11.0.0.2 and to receive labeled routes from the peer.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 label-route-capability
5.     Configure PE 2:
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
[PE2-Vlan-interface12] ip address 20.0.0.1 24
[PE2] bgp 600
# Enable the capability to advertise labeled routes to IBGP peer 4.4.4.9 and to receive labeled routes from the peer.
[PE2-bgp-default] address-family ipv4 unicast
[PE2-bgp-default-ipv4] peer 4.4.4.9 enable
[PE2-bgp-default-ipv4] peer 4.4.4.9 label-route-capability
[PE2-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp-default] peer 2.2.2.9 as-number 100
[PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE2-bgp-default] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv4 peer.
[PE2-bgp-default-vpnv4] peer 2.2.2.9 enable
# Establish an EBGP peer relationship with CE 2, and add the learned BGP routes to the routing table of VPN instance vpn1.
[PE2-bgp-default-vpn1] peer 20.0.0.2 as-number 65002
[PE2-bgp-default-ipv4-vpn1] peer 20.0.0.2 enable
6.     Configure CE 2:
<CE2> system-view
[CE2-Vlan-interface12] ip address 20.0.0.2 24
# Establish an EBGP peer relationship with PE 2, and redistribute VPN routes.
[CE2] bgp 65002
[CE2-bgp-default] peer 20.0.0.1 as-number 600
[CE2-bgp-default-ipv4] peer 20.0.0.1 enable
# Execute the display ip routing table command on CE 1 and CE 2 to verify that CE 1 and CE 2 have a route to each other. Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Configuring MPLS L3VPN inter-AS option C (method 2)
Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100, and Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and PE 2 are MP-EBGP peers and exchange VPNv4 routes.
ASBR-PE 1 and ASBR-PE 2 label the routes received from each other, use EBGP to exchange labeled IPv4 routes, and redistribute IGP and BGP routes from each other.
Figure 27 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
Vlan-int11
1.1.1.2/8
Vlan-int11
9.1.1.2/8
Vlan-int12
30.0.0.1/24
Vlan-int12
20.0.0.1/24
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
Vlan-int11
1.1.1.1/8
Vlan-int11
9.1.1.1/8
Vlan-int12
11.0.0.2/8
Vlan-int12
11.0.0.1/8
CE 1
Vlan-int12
30.0.0.2/24
CE 2
Vlan-int12
20.0.0.2/24
1.     Configure CE 1:
<CE1> system-view
[CE1] bgp 65001
2.     Configure PE 1:
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] quit
# Configure an LSR ID, and enable MPLS and LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure interface VLAN-interface 11, and enable IS-IS, MPLS, and LDP on the interface.
# Configure interface Loopback 0, and enable IS-IS on it.
# Associate VLAN-interface 12 with VPN instance vpn1, and specify an IP address for the interface.
[PE1] bgp 100
[ASBR-PE1] isis 1
# Redistribute BGP routes.
[ASBR-PE1-isis-1] address-family ipv4 unicast
[ASBR-PE1-isis-1-ipv4] import-route bgp
[ASBR-PE1-isis-1-ipv4] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Configure interface VLAN-interface 12, and enable MPLS on it.
# Create routing policy policy1.
# Enable BGP on ASBR-PE 1, and redistribute routes from IS-IS process 1.
[ASBR-PE1] bgp 100
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] address-family ipv4 unicast
[ASBR-PE2-isis-1-ipv4] import-route bgp
[ASBR-PE2-isis-1-ipv4] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
# Enable BGP on ASBR-PE 2, and redistribute routes from IS-IS process 1.
[ASBR-PE2] bgp 600
5.     Configure PE 2:
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
# Associate interface VLAN-interface 12 with VPN instance vpn1, and specify an IP address for the interface.
[PE2] bgp 600
6.     Configure CE 2:
# Configure an IP address for interface VLAN-interface 12.
<CE2> system-view
[CE2] bgp 65002
Example: Configuring MPLS L3VPN carrier's carrier in the same AS
Configure carrier's carrier for the scenario shown in Figure 28. In this scenario:
·     PE 1 and PE 2 are the provider carrier's PE switches. They provide VPN services for the customer carrier.
·     CE 1 and CE 2 are the customer carrier's switches. They are connected to the provider carrier's backbone as CE switches.
·     PE 3 and PE 4 are the customer carrier's PE switches. They provide MPLS L3VPN services for the end customers.
·     CE 3 and CE 4 are customers of the customer carrier.
·     The customer carrier and the provider carrier reside in the same AS.
The key to carrier's carrier deployment is to configure exchange of two kinds of routes:
·     Exchange of the customer carrier's internal routes on the provider carrier's backbone.
·     Exchange of the end customers' VPN routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-IBGP peer relationship must be established between PE 3 and PE 4.
Figure 28 Network diagram
Table 8 Interface and IP address assignment
Device
IP address
Device
IP address
CE 3
Vlan-int11
100.1.1.1/24
CE 4
Vlan-int11
120.1.1.1/24
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
Vlan-int11
100.1.1.2/24
Vlan-int11
120.1.1.2/24
Vlan-int12
10.1.1.1/24
Vlan-int12
20.1.1.2/24
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
Vlan-int12
10.1.1.2/24
Vlan-int11
21.1.1.2/24
Vlan-int11
11.1.1.1/24
Vlan-int12
20.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
Vlan-int11
11.1.1.2/24
Vlan-int12
30.1.1.2/24
Vlan-int12
30.1.1.1/24
Vlan-int11
21.1.1.1/24
1.     Configure MPLS L3VPN on the provider carrier backbone. Enable IS-IS as the IGP, enable LDP between PE 1 and PE 2, and establish an MP-IBGP peer relationship between the PEs:
# Configure PE 1.
<PE1> system-view
[PE1-LoopBack0] ip address 3.3.3.9 32
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE1-isis-1] quit
[PE1-Vlan-interface12] ip address 30.1.1.1 24
[PE1-Vlan-interface12] isis enable 1
[PE1-Vlan-interface12] mpls enable
[PE1-Vlan-interface12] mpls ldp enable
[PE1-Vlan-interface12] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.9 as-number 100
[PE1-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 4.4.4.9 enable
# On PE 1 or PE 2, execute the following commands:
¡     Execute the display mpls ldp peer command to verify that an LDP session in Operational state has been established between PE 1 and PE 2. (Details not shown.)
¡     Execute the display bgp peer vpnv4 command to verify that a BGP peer relationship in Established state has been established between PE 1 and PE 2. (Details not shown.)
¡     Execute the display isis peer command to verify that the IS-IS neighbor relationship has been established between PE 1 and PE 2. (Details not shown.)
2.     Configure the customer carrier network. Enable IS-IS as the IGP, and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2:
# Configure PE 3.
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 1.1.1.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 1.1.1.9
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] network-entity 10.0000.0000.0000.0001.00
[PE3-isis-2] quit
[PE3-LoopBack0] isis enable 2
[PE3] interface vlan-interface 12
[PE3-Vlan-interface12] ip address 10.1.1.1 24
[PE3-Vlan-interface12] isis enable 2
[PE3-Vlan-interface12] mpls enable
[PE3-Vlan-interface12] mpls ldp enable
[PE3-Vlan-interface12] mpls ldp transport-address interface
[PE3-Vlan-interface12] quit
# Configure CE 1.
<CE1> system-view
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 2.2.2.9 32
[CE1-LoopBack0] quit
[CE1] mpls lsr-id 2.2.2.9
[CE1] mpls ldp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] network-entity 10.0000.0000.0000.0002.00
[CE1-isis-2] quit
[CE1-LoopBack0] isis enable 2
[CE1-Vlan-interface12] ip address 10.1.1.2 24
[CE1-Vlan-interface12] isis enable 2
[CE1-Vlan-interface12] mpls enable
[CE1-Vlan-interface12] mpls ldp enable
[CE1-Vlan-interface12] mpls ldp transport-address interface
PE 3 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them.
# Configure PE 4 and CE 2 in the same way that PE 3 and CE 1 are configured. (Details not shown.)
3.     Allow CEs of the customer carrier to access PEs of the provider carrier, and redistribute IS-IS routes to BGP and BGP routes to IS-IS on the PEs:
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 200:1
[PE1] mpls ldp
[PE1-ldp] vpn-instance vpn1
[PE1-ldp-vpn-instance-vpn1] quit
[PE1-ldp] quit
[PE1] isis 2 vpn-instance vpn1
[PE1-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE1-isis-2] address-family ipv4
[PE1-isis-2-ipv4] import-route bgp
[PE1-isis-2-ipv4] quit
[PE1-isis-2] quit
[PE1-Vlan-interface11] ip address 11.1.1.2 24
[PE1-Vlan-interface11] isis enable 2
[PE1-Vlan-interface11] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] import isis 2
# Configure CE 1.
[CE1] interface vlan-interface 11
[CE1-Vlan-interface11] ip address 11.1.1.1 24
[CE1-Vlan-interface11] isis enable 2
[CE1-Vlan-interface11] mpls enable
[CE1-Vlan-interface11] mpls ldp enable
[CE1-Vlan-interface11] mpls ldp transport-address interface
[CE1-Vlan-interface11] quit
PE 1 and CE 1 can establish an LDP session and an IS-IS neighbor relationship between them.
# Configure PE 2 and CE 2 in the same way that PE 1 and CE 1 are configured. (Details not shown.)
4.     Connect the CEs of the end customers and the PEs of the customer carrier:
# Configure CE 3.
<CE3> system-view
[CE3] interface vlan-interface11
[CE3-Vlan-interface11] ip address 100.1.1.1 24
[CE3-Vlan-interface11] quit
[CE3] bgp 65410
[CE3-bgp-default] peer 100.1.1.2 as-number 100
[CE3-bgp-default] address-family ipv4 unicast
[CE3-bgp-default-ipv4] peer 100.1.1.2 enable
[CE3-bgp-default-ipv4] import-route direct
[CE3-bgp-default-ipv4] quit
[CE3-bgp-default] quit
# Configure PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 1:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface Vlan-interface 11
[PE3-Vlan-interface11] ip binding vpn-instance vpn1
[PE3-Vlan-interface11] ip address 100.1.1.2 24
[PE3-Vlan-interface11] quit
[PE3] bgp 100
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 100.1.1.1 as-number 65410
[PE3-bgp-default-vpn1] address-family ipv4 unicast
[PE3-bgp-default-ipv4-vpn1] peer 100.1.1.1 enable
[PE3-bgp-default-ipv4-vpn1] quit
[PE3-bgp-default-vpn1] quit
[PE3-bgp-default] quit
# Configure PE 4 and CE 4 in the same way that PE 3 and CE 3 are configured. (Details not shown.)
5.     Configure MP-IBGP peer relationship between the PEs of the customer carrier to exchange the end customers' VPN routes:
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 6.6.6.9 as-number 100
[PE3-bgp-default] peer 6.6.6.9 connect-interface loopback 0
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] peer 6.6.6.9 enable
[PE3-bgp-default-vpnv4] quit
# Configure PE 4 in the same way that PE 3 is configured. (Details not shown.)
1.     Display the public network routing table and VPN routing table on the provider carrier PEs, for example, on PE 1:
# Verify that the public network routing table contains only routes of the provider carrier network.
Destinations : 14        Routes : 14
3.3.3.9/32         Direct  0   0           127.0.0.1       InLoop0
4.4.4.9/32         IS_L1   15  10          30.1.1.2        Vlan12
30.1.1.0/24        Direct  0   0           30.1.1.1        Vlan12
30.1.1.0/32        Direct  0   0           30.1.1.1        Vlan12
30.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
30.1.1.255/32      Direct  0   0           30.1.1.1        Vlan12
# Verify that the VPN routing table contains the internal routes of the customer carrier network, but it does not contain the VPN routes that the customer carrier maintains.
Destinations : 18        Routes : 18
1.1.1.9/32         IS_L1   15  20          11.1.1.1        Vlan11
2.2.2.9/32         IS_L1   15  10          11.1.1.1        Vlan11
5.5.5.9/32         BGP     255 10          4.4.4.9         Vlan12
6.6.6.9/32         BGP     255 20          4.4.4.9         Vlan12
10.1.1.0/24        IS_L1   15  20          11.1.1.1        Vlan11
11.1.1.0/24        Direct  0   0           11.1.1.2        Vlan11
11.1.1.0/32        Direct  0   0           11.1.1.2        Vlan11
11.1.1.2/32        Direct  0   0           127.0.0.1       InLoop0
11.1.1.255/32      Direct  0   0           11.1.1.2        Vlan11
20.1.1.0/24        BGP     255 20          4.4.4.9         Vlan12
2.     Display the routing table on the customer carrier CEs, for example, on CE 1:
# Verify that the routing table contains the internal routes of the customer carrier network, but it does not contain the VPN routes that the customer carrier maintains.
Destinations : 21        Routes : 21
1.1.1.9/32         IS_L1   15  10          10.1.1.1        Vlan12
2.2.2.9/32         Direct  0   0           127.0.0.1       InLoop0
5.5.5.9/32         IS_L2   15  74          11.1.1.2        Vlan11
6.6.6.9/32         IS_L2   15  74          11.1.1.2        Vlan11
10.1.1.0/24        Direct  0   0           10.1.1.2        Vlan12
10.1.1.0/32        Direct  0   0           10.1.1.2        Vlan12
10.1.1.255/32      Direct  0   0           10.1.1.2        Vlan12
11.1.1.0/24        Direct  0   0           11.1.1.1        Vlan11
11.1.1.0/32        Direct  0   0           11.1.1.1        Vlan11
11.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
11.1.1.255/32      Direct  0   0           11.1.1.1        Vlan11
20.1.1.0/24        IS_L2   15  74          11.1.1.2        Vlan11
3.     Display the public network routing table and VPN routing table on the customer carrier PEs, for example, on PE 3:
# Verify that the public network routing table contains the internal routes of the customer carrier network.
[PE3] display ip routing-table
1.1.1.9/32         Direct  0   0           127.0.0.1       InLoop0
2.2.2.9/32         IS_L1   15  10          10.1.1.2        Vlan12
5.5.5.9/32         IS_L2   15  84          10.1.1.2        Vlan12
6.6.6.9/32         IS_L2   15  84          10.1.1.2        Vlan12
11.1.1.0/24        IS_L1   15  20          10.1.1.2        Vlan12
20.1.1.0/24        IS_L2   15  84          10.1.1.2        Vlan12
# Verify that the VPN routing table contains the route to the remote VPN customer.
[PE3] display ip routing-table vpn-instance vpn1
100.1.1.0/24       Direct  0   0           100.1.1.2       Vlan11
100.1.1.0/32       Direct  0   0           100.1.1.2       Vlan11
100.1.1.2/32       Direct  0   0           127.0.0.1       InLoop0
100.1.1.255/32     Direct  0   0           100.1.1.2       Vlan11
120.1.1.0/24       BGP     255 0           6.6.6.9         Vlan12
4.     Verify that PE 3 and PE 4 can ping each other. (Details not shown.)
5.     Verify that CE 3 and CE 4 can ping each other. (Details not shown.)
Example: Configuring MPLS L3VPN carrier's carrier in different ASs
Configure carrier's carrier for the scenario shown in Figure 29. In this scenario:
·     The customer carrier and the provider carrier reside in different ASs.
·     Exchange of the end customers' VPN routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-EBGP peer relationship must be established between PE 3 and PE 4.
Figure 29 Network diagram
Table 9 Interface and IP address assignment
Device
IP address
Device
IP address
CE 3
Vlan-int11
100.1.1.1/24
CE 4
Vlan-int11
120.1.1.1/24
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
Vlan-int11
100.1.1.2/24
Vlan-int11
120.1.1.2/24
Vlan-int12
10.1.1.1/24
Vlan-int12
20.1.1.2/24
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
Vlan-int12
10.1.1.2/24
Vlan-int11
21.1.1.2/24
Vlan-int11
11.1.1.1/24
Vlan-int12
20.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
Vlan-int11
11.1.1.2/24
Vlan-int12
30.1.1.2/24
Vlan-int12
30.1.1.1/24
Vlan-int11
21.1.1.1/24
# Configure PE 1.
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
# Configure PE 3.
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] quit
# Configure CE 1.
<CE1> system-view
[CE1] mpls ldp
[CE1-ldp] import bgp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] address-family ipv4
[CE1-isis-2-ipv4] import-route bgp
[CE1-isis-2-ipv4] quit
[CE1-isis-2] quit
3.     Allow CEs of the customer carrier to access PEs of the provider carrier:
# Configure PE 1.
[PE1] bgp 200
[PE1-bgp-default-vpn1] peer 11.1.1.1 as-number 100
[PE1-bgp-default-ipv4-vpn1] peer 11.1.1.1 enable
[PE1-bgp-default-ipv4-vpn1] peer 11.1.1.1 label-route-capability
[PE1-bgp-default-ipv4-vpn1] peer 11.1.1.1 route-policy csc export
[PE1] route-policy csc permit node 0
[PE1-route-policy-csc-0] apply mpls-label
[PE1-route-policy-csc-0] quit
# Configure CE 1.
[CE1] bgp 100
[CE1-bgp-default] peer 11.1.1.2 as-number 200
[CE1-bgp-default-ipv4] peer 11.1.1.2 enable
[CE1-bgp-default-ipv4] peer 11.1.1.2 label-route-capability
[CE1-bgp-default-ipv4] peer 11.1.1.2 route-policy csc export
[CE1-bgp-default-ipv4] import isis 2
[CE1] route-policy csc permit node 0
[CE1-route-policy-csc-0] apply mpls-label
[CE1-route-policy-csc-0] quit
PE 1 and CE 1 can establish a BGP session and exchange labeled IPv4 unicast routes through BGP.
4.     Connect CEs of the end customers and the PEs of the customer carrier:
# Configure CE 3.
<CE3> system-view
[CE3] interface vlan-interface 11
[CE3] bgp 65410
# Configure PE 3.
[PE3] interface vlan-interface 11
[PE3] bgp 100
5.     Configure an MP-EBGP peer relationship between the PEs of the customer carrier to exchange the VPN routes of the end customers:
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 6.6.6.9 as-number 300
[PE3-bgp-default] peer 6.6.6.9 ebgp-max-hop 10
# Verify that the VPN routing table contains the internal routes of the customer carrier, but it does not contain the VPN routes that the customer carrier maintains.
1.1.1.9/32         BGP     255 10          11.1.1.1        Vlan11
6.6.6.9/32         BGP     255 10          4.4.4.9         Vlan12
2.     Display the routing table on the customer carrier CEs, for example, on CE 1.
Destinations : 19        Routes : 19
6.6.6.9/32         BGP     255 0           11.1.1.2        Vlan11
6.6.6.9/32         IS_L2   15  74          10.1.1.2        Vlan12
Example: Configuring nested VPN
The service provider provides nested VPN services for users, as shown in Figure 30.
·     PE 1 and PE 2 are PE devices on the service provider backbone. Both of them support the nested VPN feature.
·     CE 1 and CE 2 are connected to the service provider backbone. Both of them support VPNv4 routes.
·     PE 3 and PE 4 are PE devices of the customer VPN. Both of them support MPLS L3VPN.
·     CE 3 through CE 6 are CE devices of the sub-VPNs for the customer VPN.
The key of nested VPN configuration is to understand the processing of routes of sub-VPNs on the service provider PEs:
·     When receiving a VPNv4 route from a CE (CE 1 or CE 2 in this example), a service provider PE performs the following operations:
a.     Replaces the RD of the VPNv4 route with the RD of the MPLS VPN on the service provider network where the CE resides.
b.     Adds the export target attribute of the MPLS VPN on the service provider network to the extended community attribute list.
c.     Forwards the VPNv4 route.
·     To implement exchange of sub-VPN routes between customer PEs and service provider PEs, MP-EBGP peers must be established between service provider PEs and customer CEs.
Figure 30 Network diagram
Table 10 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
Vlan-int2
10.1.1.2/24
Vlan-int1
21.1.1.2/24
Vlan-int1
11.1.1.1/24
Vlan-int2
20.1.1.1/24
CE 3
Vlan-int1
100.1.1.1/24
CE 4
Vlan-int1
120.1.1.1/24
CE 5
Vlan-int3
110.1.1.1/24
CE 6
Vlan-int3
130.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
Vlan-int1
11.1.1.2/24
Vlan-int1
21.1.1.1/24
Vlan-int2
30.1.1.1/24
Vlan-int2
30.1.1.2/24
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
Vlan-int1
100.1.1.2/24
Vlan-int1
120.1.1.2/24
Vlan-int2
10.1.1.1/24
Vlan-int2
20.1.1.2/24
Vlan-int3
110.1.1.2/24
Vlan-int3
130.1.1.2/24
1.     Configure MPLS L3VPN on the service provider backbone. Use IS-IS as the IGP protocol, enable LDP, and establish an MP-IBGP peer relationship between PE 1 and PE 2:
# Configure PE 1.
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] interface vlan-interface 2
[PE1-Vlan-interface2] ip address 30.1.1.1 24
[PE1-Vlan-interface2] isis enable 1
[PE1-Vlan-interface2] mpls enable
[PE1-Vlan-interface2] mpls ldp enable
[PE1-Vlan-interface2] quit
[PE1] bgp 100
2.     Configure the customer VPN. Use IS-IS as the IGP protocol, and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2:
# Configure PE 3.
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] quit
[PE3] interface vlan-interface 2
[PE3-Vlan-interface2] ip address 10.1.1.1 24
[PE3-Vlan-interface2] isis enable 2
[PE3-Vlan-interface2] mpls enable
[PE3-Vlan-interface2] mpls ldp enable
[PE3-Vlan-interface2] quit
# Configure CE 1.
<CE1> system-view
[CE1] mpls ldp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] quit
[CE1] interface vlan-interface 2
[CE1-Vlan-interface2] ip address 10.1.1.2 24
[CE1-Vlan-interface2] isis enable 2
[CE1-Vlan-interface2] mpls enable
[CE1-Vlan-interface2] mpls ldp enable
[CE1-Vlan-interface2] quit
An LDP session and an IS-IS neighbor relationship can be established between PE 3 and CE 1.
3.     Connect CE 1 and CE 2 to service provider PEs:
# Configure PE 1.
[PE1-Vlan-interface1] ip binding vpn-instance vpn1
[PE1-Vlan-interface1] ip address 11.1.1.2 24
[PE1-Vlan-interface1] mpls enable
[PE1-Vlan-interface1] quit
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 11.1.1.1 as-number 200
# Configure CE 1.
[CE1-Vlan-interface1] ip address 11.1.1.1 24
[CE1-Vlan-interface1] mpls enable
[CE1-Vlan-interface1] quit
[CE1] bgp 200
[CE1-bgp-default] peer 11.1.1.2 as-number 100
4.     Connect sub-VPN CEs to the customer VPN PEs:
# Configure CE 3.
<CE3> system-view
[CE3-Vlan-interface1] ip address 100.1.1.1 24
[CE3-Vlan-interface1] quit
[CE3] bgp 65410
[CE3-bgp-default] peer 100.1.1.2 as-number 200
# Configure CE 5.
<CE5> system-view
[CE5] interface vlan-interface 3
[CE5-Vlan-interface3] ip address 110.1.1.1 24
[CE5-Vlan-interface3] quit
[CE5] bgp 65411
[CE5-bgp-default] peer 110.1.1.2 as-number 200
[CE5-bgp-default] address-family ipv4 unicast
[CE5-bgp-default-ipv4] peer 110.1.1.2 enable
[CE5-bgp-default-ipv4] import-route direct
[CE5-bgp-default-ipv4] quit
[CE5-bgp-default] quit
# Configure PE 3.
[PE3] ip vpn-instance SUB_VPN1
[PE3-vpn-instance-SUB_VPN1] route-distinguisher 100:1
[PE3-vpn-instance-SUB_VPN1] vpn-target 2:1
[PE3-vpn-instance-SUB_VPN1] quit
[PE3-Vlan-interface1] ip binding vpn-instance SUB_VPN1
[PE3-Vlan-interface1] ip address 100.1.1.2 24
[PE3-Vlan-interface1] quit
[PE3] ip vpn-instance SUB_VPN2
[PE3-vpn-instance-SUB_VPN2] route-distinguisher 101:1
[PE3-vpn-instance-SUB_VPN2] vpn-target 2:2
[PE3-vpn-instance-SUB_VPN2] quit
[PE3] interface vlan-interface 3
[PE3-Vlan-interface3] ip binding vpn-instance SUB_VPN2
[PE3-Vlan-interface3] ip address 110.1.1.2 24
[PE3-Vlan-interface3] quit
[PE3] bgp 200
[PE3-bgp-default] ip vpn-instance SUB_VPN1
[PE3-bgp-default-SUB_VPN1] peer 100.1.1.1 as-number 65410
[PE3-bgp-default-SUB_VPN1] address-family ipv4 unicast
[PE3-bgp-default-ipv4-SUB_VPN1] peer 100.1.1.1 enable
[PE3-bgp-default-ipv4-SUB_VPN1] quit
[PE3-bgp-default-SUB_VPN1] quit
[PE3-bgp-default] ip vpn-instance SUB_VPN2
[PE3-bgp-default-SUB_VPN2] peer 100.1.1.1 as-number 65411
[PE3-bgp-default-SUB_VPN2] address-family ipv4 unicast
[PE3-bgp-default-ipv4-SUB_VPN2] peer 110.1.1.1 enable
[PE3-bgp-default-ipv4-SUB_VPN2] quit
[PE3-bgp-default-SUB_VPN2] quit
# Configure PE 4, CE 4, and CE 6 in the same way that PE 3, CE 3, and CE 5 are configured. (Details not shown.)
5.     Establish MP-EBGP peer relationships between service provider PEs and their CEs to exchange user VPNv4 routes:
# On PE 1, enable nested VPN and VPNv4 route exchange with CE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] nesting-vpn
[PE1-bgp-default-vpn1] address-family vpnv4
[PE1-bgp-default-vpnv4-vpn1] peer 11.1.1.1 enable
[PE1-bgp-default-vpnv4-vpn1] quit
# Enable CE 1 to exchange VPNv4 routes with PE 1.
[CE1] bgp 200
[CE1-bgp-default] address-family vpnv4
[CE1-bgp-default-vpnv4] peer 11.1.1.2 enable
# Allow the local AS number to appear in the AS-PATH attribute of the routes received.
[CE1-bgp-default-vpnv4] peer 11.1.1.2 allow-as-loop 2
[CE1-bgp-default-vpnv4] undo policy vpn-target
[CE1-bgp-default-vpnv4] quit
6.     Establish MP-IBGP peer relationships between sub-VPN PEs and CEs of the customer VPN to exchange VPNv4 routes of sub-VPNs:
# Configure PE 3.
[PE3] bgp 200
[PE3-bgp-default] peer 2.2.2.9 as-number 200
[PE3-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE3-bgp-default-vpnv4] peer 2.2.2.9 enable
[PE3-bgp-default-vpnv4] peer 2.2.2.9 allow-as-loop 2
# Configure CE 1.
[CE1] bgp 200
[CE1-bgp-default] peer 1.1.1.9 as-number 200
[CE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[CE1-bgp-default-vpnv4] peer 1.1.1.9 enable
1.     Display the public routing table and VPN routing table on the provider PEs, for example, on PE 1:
# Verify that the public routing table contains only routes on the service provider network.
4.4.4.9/32         IS_L1   15  10          30.1.1.2        Vlan2
30.1.1.0/24        Direct  0   0           30.1.1.1        Vlan2
30.1.1.0/32        Direct  0   0           30.1.1.1        Vlan2
30.1.1.255/32      Direct  0   0           30.1.1.1        Vlan2
# Verify that the VPN routing table contains sub-VPN routes.
Destinations : 17       Routes : 17
100.1.1.0/24       BGP     255 0           11.1.1.1        Vlan1
110.1.1.0/24       BGP     255 0           11.1.1.1        Vlan1
120.1.1.0/24       BGP     255 0           4.4.4.9         Vlan2
130.1.1.0/24       BGP     255 0           4.4.4.9         Vlan2
2.     Display the VPNv4 routing table on the provider CEs, for example, on CE 1.
# Verify that the VPNv4 routing table on the customer VPN contains internal sub-VPN routes.
[CE1] display bgp routing-table vpnv4
 BGP local router ID is 2.2.2.9
               a – additional-path
 Total number of VPN routes: 4
 Total number of routes from all PEs: 4
 Route distinguisher: 100:1
 Total number of routes: 1
* >i 100.1.1.0/24       1.1.1.9         0          100        0       200 65410?
 Route distinguisher: 101:1
* >i 110.1.1.0/24       1.1.1.9         0          100        0       200 65411?
 Route distinguisher: 200:1
* >e 120.1.1.0/24       11.1.1.2                              0       100 200
        65420?
 Route Distinguisher: 201:1
* >e 130.1.1.0/24       11.1.1.2                              0       100 200
        65421?
3.     Display the VPN routing table on the customer PEs, for example, on PE 3:
# Verify that the VPN routing table contains routes sent by the provider PE to the sub-VPN.
[PE3] display ip routing-table vpn-instance SUB_VPN1
Destinations : 11        Routes : 11
120.1.1.0/24       BGP     255 0           2.2.2.9         Vlan2
4.     Display the routing table on the CEs of sub-VPNs in the customer VPN, for example, on CE 3 and CE 5:
# Verify that the routing table contains the route to the remote sub-VPN on CE 3.
[CE3] display ip routing-table
100.1.1.0/24       Direct  0   0           100.1.1.1       Vlan1
100.1.1.0/32       Direct  0   0           100.1.1.1       Vlan1
100.1.1.1/32       Direct  0   0           127.0.0.1       InLoop0
100.1.1.255/32     Direct  0   0           100.1.1.1       Vlan1
120.1.1.0/24       BGP     255 0           100.1.1.2       Vlan1
# Verify that the routing table contains the route to the remote sub-VPN on CE 5.
[CE5] display ip routing-table
110.1.1.0/24       Direct  0   0           110.1.1.1       Vlan1
110.1.1.0/32       Direct  0   0           110.1.1.1       Vlan1
110.1.1.1/32       Direct  0   0           127.0.0.1       InLoop0
110.1.1.255/32     Direct  0   0           110.1.1.1       Vlan1
130.1.1.0/24       BGP     255 0           110.1.1.2       Vlan1
6.     Verify that CE5 and CE 6 can ping each other. (Details not shown.)
7.     Verify that CE 3 and CE 6 cannot ping each other. (Details not shown.)
Example: Configuring multirole host
Configure the multirole host feature to allow Host A to access VPN 1 and VPN 2 and Host B to access only VPN 1.
Figure 31 Network diagram
1.     Configure CE 1:
# Configure IP addresses for interfaces.
<CE1> system-view
[CE1-Vlan-interface11] ip address 100.1.1.1 24
[CE1-Vlan-interface12] ip address 1.1.1.2 24
# Configure a default route to PE 1.
[CE1] ip route-static 0.0.0.0 0 1.1.1.1
2.     Configure PE 1:
# Create VPN instances vpn1 and vpn2 for VPN 1 and VPN 2, respectively, and configure different RDs and route targets for the VPN instances.
<PE1> system-view
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] quit
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 100:2 both
[PE1-vpn-instance-vpn2] quit
# Associate VPN instance vpn1 with VLAN-interface 11 (the interface connected to CE 1).
[PE1] interface vlan-interface 11
[PE1-Vlan-interface11] ip binding vpn-instance vpn1
[PE1-Vlan-interface11] ip address 1.1.1.1 255.255.255.0
[PE1-Vlan-interface11] quit
# Configure a static route for VPN 2 to reach Host A and redistribute the route to BGP. This configuration ensures that packets from VPN 2 to Host A can be forwarded through the correct route in the routing table of VPN instance vpn1.
[PE1] ip route-static vpn-instance vpn2 100.1.1.0 24 vpn-instance vpn1 1.1.1.2
[PE1] bgp 100
[PE1-bgp-default] ip vpn-instance vpn2
[PE1-bgp-default-vpn2] address-family ipv4
[PE1-bgp-default-ipv4-vpn2] import-route static
[PE1-bgp-default-ipv4-vpn2] quit
[PE1-bgp-default-vpn2] quit
[PE1-bgp-default] quit
# Configure PBR to route packets from Host A according to the routing tables of both VPN instances vpn1 and vpn2.
[PE1] acl advanced 3001
[PE1-acl-ipv4-adv-3001] rule 0 permit ip vpn-instance vpn1 source 100.1.1.2 0
[PE1-acl-ipv4-adv-3001] quit
[PE1] policy-based-route policy1 permit node 10
[PE1-policy-based-route] if-match acl 3001
[PE1-policy-based-route] apply access-vpn vpn-instance vpn1 vpn2
[PE1-policy-based-route] quit
# Apply policy policy1 to VLAN-interface 11.
[PE1-Vlan-interface11] ip policy-based-route policy1
3.     Configure basic MPLS L3VPN. (Details not shown.)
# Verify that Host A can ping Host C, and that Host B cannot ping Host C. (Details not shown.)
Example: Configuring BGP AS number substitution
As shown in Figure 32, CE 1 and CE 2 belong to VPN 1, and are connected to PE 1 and PE 2, respectively. The two CEs have the same AS number, 600.
Configure BGP AS number substitution on the PEs to enable the CEs to communicate with each other.
Figure 32 Network diagram
Table 11 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Vlan-int11
10.1.1.1/24
P
Loop0
2.2.2.9/32
Vlan-int12
100.1.1.1/24
Vlan-int11
30.1.1.1/24
PE 1
Loop0
1.1.1.9/32
Vlan-int12
20.1.1.2/24
Vlan-int11
10.1.1.2/24
PE 2
Loop0
3.3.3.9/32
Vlan-int12
20.1.1.1/24
Vlan-int11
30.1.1.2/24
CE 2
Vlan-int12
10.2.1.1/24
Vlan-int12
10.2.1.2/24
Vlan-int13
200.1.1.1/24
1.     Configure basic MPLS L3VPN:
¡     Configure OSPF on the MPLS backbone to allow the PEs and P device to learn the routes of the loopback interfaces from each other.
¡     Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs.
¡     Establish an MP-IBGP peer relationship between the PEs to advertise VPNv4 routes.
¡     Configure the VPN instance of VPN 1 on PE 2 to allow CE 2 to access the network.
¡     Configure the VPN instance of VPN 1 on PE 1 to allow CE 1 to access the network.
¡     Configure BGP as the PE-CE routing protocol, and redistribute routes of the CEs into the PEs.
For more information about basic MPLS L3VPN configurations, see "Example: Configuring basic MPLS L3VPN."
# Execute the display ip routing-table command on CE 2. The output shows that CE 2 has learned the route to network 10.1.1.0/24, where the interface used by CE 1 to access PE 1 resides. However, it has not learned the route to the VPN (100.1.1.0/24) behind CE 1.
<CE2> display ip routing-table
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
10.1.1.0/24         BGP    255  0            10.2.1.2        Vlan12
10.2.1.0/24         Direct 0    0            10.2.1.1        Vlan12
10.2.1.0/32         Direct 0    0            10.2.1.1        Vlan12
10.2.1.1/32         Direct 0    0            127.0.0.1       InLoop0
10.2.1.255/32       Direct 0    0            10.2.1.1        Vlan12
127.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
200.1.1.0/24        Direct 0    0            200.1.1.1       Vlan13
200.1.1.0/32        Direct 0    0            200.1.1.1       Vlan13
200.1.1.1/32        Direct 0    0            127.0.0.1       InLoop0
200.1.1.255/24      Direct 0    0            200.1.1.1       Vlan13
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
# Execute the display ip routing-table command on CE 1 to verify that CE 1 has not learned the route to the VPN behind CE 2. (Details not shown.)
# Execute the display ip routing-table vpn-instance command on the PEs. The output shows the route to the VPN behind the peer CE. This example uses PE 2.
<PE2> display ip routing-table vpn-instance vpn1
10.1.1.0/24         BGP    255  0            1.1.1.9         Vlan11
10.2.1.0/24         Direct 0    0            10.2.1.2        Vlan12
10.2.1.0/32         Direct 0    0            10.2.1.2        Vlan12
10.2.1.2/32         Direct 0    0            127.0.0.1       InLoop0
10.2.1.255/32       Direct 0    0            10.2.1.2        Vlan12
100.1.1.0/24        BGP    255  0            1.1.1.9         Vlan11
200.1.1.0/24        BGP    255  0            10.2.1.1        Vlan12
# Enable BGP update packet debugging on PE 2. The output shows that PE 2 has advertised the route for 100.1.1.1/32, and the AS_PATH is 100 600.
<PE2> terminal monitor
<PE2> terminal logging level 7
<PE2> debugging bgp update vpn-instance vpn1 10.2.1.1 ipv4
<PE2> refresh bgp all export ipv4 vpn-instance vpn1
*Jun 13 16:12:52:096 2012 PE2 BGP/7/DEBUG:
         BGP.vpn1: Send UPDATE to peer 10.2.1.1 for following destinations:
         Origin       : Incomplete
         AS Path      : 100 600
         Next Hop     : 10.2.1.2
         100.1.1.0/24,
# Execute the display bgp routing-table ipv4 peer received-routes command on CE 2 to verify that CE 2 has not received the route to 100.1.1.0/24.
<CE2> display bgp routing-table ipv4 peer 10.2.1.2 received-routes
 Total number of routes: 2
 BGP local router ID is 200.1.1.1
* >e 10.1.1.0/24        10.2.1.2                              0       100?
*  e 10.2.1.0/24        10.2.1.2        0                     0       100?
2.     Configure BGP AS number substitution on PE 2.
<PE2> system-view
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10.2.1.1 substitute-as
[PE2-bgp-default] quit
# The output shows that among the routes advertised by PE 2 to CE 2, the AS_PATH of 100.1.1.0/24 has changed from 100 600 to 100 100.
*Jun 13 16:15:59:456 2012 PE2 BGP/7/DEBUG:
         Origin       : Incomplete
         AS Path      : 100 100
         Next Hop     : 10.2.1.2
         100.1.1.0/24,
# Display again the routing information that CE 2 has received, and the routing table.
 Total number of routes: 3
* >e 100.1.1.0/24       10.2.1.2                              0       100 100?
100.1.1.0/24        BGP    255  0            10.2.1.2        Vlan12
200.1.1.255/32      Direct 0    0            200.1.1.1       Vlan13
# Verify that the VLAN interfaces of CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Configuring BGP AS number substitution and SoO attribute
CE 1, CE 2, and CE 3 belong to VPN 1, and are connected to PE1, PE 2, and PE 3, respectively.
CE 1 and CE 2 reside in the same site. CE1, CE2, and CE 3 all use AS number 600.
·     To avoid route loss, configure BGP AS number substitution on PEs.
·     To avoid routing loops, configure the same SoO attribute on PE 1 and PE 2 for CE 1 and CE 2.
Figure 33 Network diagram
Table 12 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Loop0
100.1.1.1/32
CE 3
Loop0
200.1.1.1/32
Vlan-int2
10.1.1.1/24
Vlan-int7
10.3.1.1/24
CE 2
Vlan-int2
10.2.1.1/24
PE 2
Loop0
2.2.2.9/32
PE 1
Loop0
1.1.1.9/32
Vlan-int2
10.2.1.2/24
Vlan-int2
10.1.1.2/24
Vlan-int4
40.1.1.2/24
Vlan-int3
30.1.1.1/24
Vlan-int5
50.1.1.1/24
Vlan-int4
40.1.1.1/24
P
Loop0
3.3.3.9/32
PE 3
Loop0
4.4.4.9/32
Vlan-int3
30.1.1.2/24
Vlan-int6
60.1.1.2/24
Vlan-int5
50.1.1.2/24
Vlan-int7
10.3.1.2/24
Vlan-int6
60.1.1.1/24
¡     Establish an MP-IBGP peer relationship between the PEs to advertise VPN IPv4 routes.
¡     Configure the VPN instance of VPN 1 on PE 3 to allow CE 3 to access the network.
2.     Configure BGP AS number substitution:
# Configure BGP AS number substitution on PE 1, PE 2, and PE 3. For more information about the configuration, see "Example: Configuring BGP AS number substitution."
# Display routing information on CE 2. The output shows that CE 2 has learned the route for 100.1.1.1/32 from CE 1. A routing loop has occurred because CE1 and CE 2 reside in the same site.
 Total number of routes: 6
 BGP local router ID is 1.1.1.9
*    10.2.1.0/24        10.2.1.2        0                     0       100?
*    10.2.1.1/32        10.2.1.2        0                     0       100?
* >e 10.3.1.0/24        10.2.1.2                              0       100?
* >e 100.1.1.1/32       10.2.1.2                              0       100 100?
* >e 200.1.1.1/32       10.2.1.2                              0       100 100?
3.     Configure BGP SoO attribute:
# On PE 1, configure the SoO attribute as 1:100 for CE 1.
<PE1> system-view
[PE1] bgp 100
[PE1-bgp-default-vpn1] address-family ipv4
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 soo 1:100
# On PE 2, configure the SoO attribute as 1:100 for CE 2.
<PE2> system-view
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 soo 1:100
# PE 2 does not advertise routes received from CE 1 to CE 2 because the same SoO attribute has been configured for the CEs. Display the routing table of CE 2. The output shows that the route 100.1.1.1/32 has been removed.
10.2.1.0/24         Direct 0    0            10.2.1.1        Vlan2
10.2.1.0/32         Direct 0    0            10.2.1.1        Vlan2
10.2.1.1/32         Direct 0    0            127.0.0.1       Inloop0
10.2.1.255/32       Direct 0    0            10.2.1.1        Vlan2
10.3.1.0/24         BGP    255  0            10.2.1.2        Vlan2
200.1.1.1/32        BGP    255  0            10.2.1.2        Vlan2
