20-High Availability Configuration Guide
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration GuidesH3C MSR5680-X3 Router Configuration Guides-R9141-6W10120-High Availability Configuration Guide
10-BFD configuration
10-BFD configuration 363.50 KB
Configuring BFD·· 1
About BFD·· 1
Mechanism·· 1
Single-hop detection and multihop detection· 2
BFD session modes· 2
Supported features· 3
Protocols and standards· 3
BFD tasks at a glance· 4
Restrictions and guidelines: BFD configuration· 4
Configuring BFD sessions in echo packet mode· 4
About BFD session creation methods· 4
Restrictions and guidelines· 4
Creating a static BFD session· 5
Configuring detection time settings· 6
Configuring BFD sessions in control packet mode· 7
About BFD session creation methods· 7
Restrictions and guidelines· 8
Configuring the session establishment mode· 8
Configuring the detection mode· 8
Configuring a static BFD session· 9
Configuring detection time settings· 10
Configuring the authentication mode· 12
Configuring the destination port number for multihop BFD control packets· 13
Configuring the notification delay timer for session establishment failures· 13
Enabling the echo function· 14
Associating the interface state with BFD·· 14
Configuring the TTL value for BFD packets· 15
Associating two static BFD sessions· 16
Configuring BFD session flapping suppression· 17
Delaying BFD session negotiation· 17
About this task· 17
Delaying BFD session negotiation upon a device reboot 18
Delaying BFD session negotiation for down BFD sessions· 18
Configuring a BFD template· 18
Enabling SNMP notifications for BFD·· 19
Verifying and maintaining BFD·· 19
Configuring SBFD·· 1
About SBFD·· 1
SBFD session modes· 1
Restrictions and guidelines: SBFD configuration· 1
SBFD tasks at a glance· 1
Configuring the initiator 2
Restrictions and guidelines· 2
Configuring the initiator for LDP LSP detection· 2
Configuring the action on received SBFD packets in down state· 3
Configuring the reflector 4
Delaying SBFD session negotiation· 4
About this task· 4
Delaying SBFD session negotiation upon a device reboot 4
Delaying SBFD session negotiation for down SBFD sessions· 5
Configuring a BFD template· 5
Verifying and maintaining SBFD·· 5
Configuring BFD
About BFD
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. It can detect and monitor the connectivity of forwarding paths to detect communication failures quickly so that measures can be taken to ensure service continuity and enhance network availability.
BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols. The hello mechanism used by upper-layer protocols needs seconds to detect a link failure, while BFD can provide detection measured in milliseconds.
Mechanism
BFD establishes a session between two network devices to detect failures on the bidirectional forwarding paths between the devices and provide services for upper-layer protocols. BFD provides no neighbor discovery mechanism. Protocols that BFD services notify BFD of devices to which it needs to establish sessions. After a session is established, if no BFD control packet is received from the peer within the negotiated BFD interval, BFD notifies a failure to the protocol, which then takes appropriate measures.
Figure 1 describes the operation of BFD for OSPF.
1.     OSPF discovers neighbors by sending Hello packets and establishes neighbor relationships.
2.     After establishing neighbor relationships, OSPF notifies BFD of the neighbor information, including destination and source addresses.
3.     BFD uses the information to establish BFD sessions.
Figure 1 BFD session establishment
Figure 2 describes the BFD fault detection process.
1.     BFD detects a link failure and tears down the session.
2.     BFD notifies the neighbor unreachability to OSPF.
3.     OSPF terminates the neighbor relationship on the link.
Figure 2 BFD fault detection
BFD can be used for single-hop and multihop detections.
·     Single-hop detection—Detects the IP connectivity between two directly connected systems, for example, Device A and Device B as shown in Figure 3.
Figure 3 Single-hop detection
·     Multihop detection—Detects any of the paths between two systems, for example, Device A and Device B as shown in Figure 4. These paths have multiple hops, and might overlap.
Figure 4 Multihop detection
BFD session modes
BFD session modes include echo mode (using echo packets) and control mode (using control packets).
Echo mode
Echo packets are encapsulated into UDP packets. The packet contains destination port 3785, a destination IP address (transmitting interface's IP address), and a source IP address (transmitting interface's IP address).
The local end of the link sends echo packets to establish BFD sessions and monitor link status. The peer end does not establish BFD sessions and only forwards the packets back to the originating end. If the local end does not receive echo packets from the peer end within the detection time, it considers the session to be down.
BFD sessions in echo packet mode do not require both ends to support BFD. Upon receiving BFD echo packets, the peer end loops back the packets for detection purposes.
An echo-mode BFD session supports only single-hop detection and is independent of the operating mode.
Control mode
Control packets are encapsulated into UDP packets with port number 3784 for single-hop detection or port number 4784 for multihop detection.
The two ends of the link negotiate the establishment of BFD sessions by using the session parameters carried in control packets. Session parameters include session discriminators, desired minimum packet sending and receiving intervals, and local BFD session state.
Supported features
Table 1 shows the features supported by BFD.
Table 1 Features supported by BFD
Feature
Reference
IPv4 static routing
Static routing in Layer 3IP Routing Configuration Guide
IPv6 static routing
IPv6 static routing in Layer 3IP Routing Configuration Guide
RIP
RIP in Layer 3IP Routing Configuration Guide
OSPF
OSPF in Layer 3IP Routing Configuration Guide
OSPFv3
OSPFv3 in Layer 3IP Routing Configuration Guide
IS-IS
IS-IS in Layer 3IP Routing Configuration Guide
BGP
BGP in Layer 3IP Routing Configuration Guide
PIM
PIM in IP Multicast Configuration Guide
IPv6 PIM
IPv6 PIM in IP Multicast Configuration Guide
MPLS
MPLS OAM in IP Multicast Configuration Guide
RSVP
RSVP in MPLS Configuration Guide
Track
"Configuring Track"
S-Trunk
"Configuring S-Trunk"
·     RFC 5880, Bidirectional Forwarding Detection (BFD)
·     RFC 5881, Bidirectional Forwarding Detection (BFD) for IPv4 and IPv6 (Single Hop)
·     RFC 5882, Generic Application of Bidirectional Forwarding Detection (BFD)
·     RFC 5883, Bidirectional Forwarding Detection (BFD) for Multihop Paths
·     RFC 5884, Bidirectional Forwarding Detection (BFD) for MPLS Label Switched Paths (LSPs)
·     RFC 5885, Bidirectional Forwarding Detection (BFD) for the Pseudowire Virtual Circuit Connectivity Verification (VCCV)
·     RFC 7130, Bidirectional Forwarding Detection (BFD) on Link Aggregation Group (LAG) Interfaces
1.     Configuring BFD sessions in echo packet mode
¡     Creating a static BFD session
¡     Configuring detection time settings
2.     Configuring BFD sessions in control packet mode
¡     Configuring a static BFD session
¡     Configuring the authentication mode
¡     Configuring the destination port number for multihop BFD control packets
¡     Configuring the notification delay timer for session establishment failures
¡     Enabling the echo function
¡     Associating the interface state with BFD
¡     Configuring the TTL value for BFD packets
3.     Associating two static BFD sessions
4.     Configuring BFD session flapping suppression
5.     Delaying BFD session negotiation
6.     Configuring a BFD template
7.     Enabling SNMP notifications for BFD
·     BFD session flapping might occur on an aggregate interface with member ports on different cards. When the card that receives and sends BFD packets is removed or restarted, the backup card might not immediately take over. For example, the backup card will not take over when the card has a short detection time or a large number of BFD sessions.
·     By default, the device runs BFD version 1 and is compatible with BFD version 0. You cannot change the BFD version to 0 through commands. When the peer device runs BFD version 0, the local device automatically switches to BFD version 0.
·     After a BFD session is established, the two ends negotiate BFD parameters, including minimum sending interval, minimum receiving interval, initialization mode, and packet authentication, by exchanging negotiation packets. They use the negotiated parameters without affecting the session status.
A BFD session can be created manually by using the bfd static command or created dynamically when an application module collaborates with BFD.
As a best practice, execute the bfd echo-source-ip or bfd echo-source-ipv6 command only one end, and do not configure the source IPv4 or IPv6 address to be on the same network segment as any local interface's IPv4 or IPv6 address. If you configure such a source IPv4 or IPv6 address, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
A static BFD session in echo packet mode can be used to perform single-hop detection or multihop detection.
You need to create a static BFD session in echo packet mode on only the local device to perform detection.
When creating a static BFD session, you must specify a peer IPv4 or IPv6 address. The system checks only the format of the IP address but not its correctness. If the peer IPv4 or IPv6 address is incorrect, the static BFD session cannot be established.
Different static BFD sessions cannot have the same local discriminator.
As a best practice, specify the source IP address for echo packets when creating a static BFD session. If you do not specify the source IP address, the device uses the IP address specified in the bfd echo-source-ip or bfd echo-source-ipv6 command as the source IP address of echo packets. If you do not specify the source IP address by using either method, the device uses the IP address specified in the destination-ip or destination-ipv6 command as the source IP address of echo packets.
Creating a static BFD session for single-hop detection
2.     (Optional.) Configure the source IP address of echo packets.
¡     Configure the source IP address of echo packets.
bfd echo-source-ip ip-address
By default, no source IPv4 address is configured for echo packets.
¡     Configure the source IPv6 address of echo packets.
By default, no source IPv6 address is configured for echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
3.     Create a static BFD session and enter static BFD session view.
IPv4:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator auto ] ]
IPv6:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator auto ] ]
4.     (Optional.) Specify a local discriminator for the static BFD session.
discriminator local local-value
By default, no local discriminator is specified.
You can use this command only if you do not specify a local discriminator when creating a static BFD session.
Creating a static BFD session for multihop detection
¡     Configure the source IPv4 address of echo packets.
IPv4:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator auto ] ]
IPv6:
When creating a BFD session in echo packet mode, you can configure the minimum interval for receiving BFD echo packets and the detection time multiplier for the device.
When the same BFD session (with the same source IP address, destination IP address, interface, VPN, and destination port number) is associated with multiple upper layer applications, BFD selects the detection time settings for the BFD session as follows:
1.     Minimum values of the following settings:
¡     Settings configured in static BFD session view.
¡     Settings configured in the BFD template specified by the upper layer application.
¡     Settings configured by the upper layer application.
2.     Settings configured in interface view or system view.
3.     Default settings.
When a BFD session is associated with only one upper layer application, BFD selects the detection time settings for the BFD session as follows:
1.     BFD selects the detection time settings for the BFD session based on whether the upper layer application supports using a BFD template and configuring detection time settings:
¡     If a BFD template is specified and detection time settings are also configured for the upper layer application, BFD selects the settings configured in the specified BFD template.
¡     If a BFD template is specified for the upper layer application that does not support configuring detection time settings, BFD selects the settings configured in the specified BFD template.
¡     If detection time settings are configured for the upper layer application that does not support using a BFD template, BFD selects the configured settings.
Configure detection time settings for single-hop BFD detection
2.     Enter interface view or static BFD session view.
¡     Enter interface view.
¡     Enter static BFD session view.
The static BFD session must already exist.
To configure parameters for a static BFD session, you must enter its view.
3.     Set the minimum interval for receiving BFD echo packets.
The default setting is 1000 milliseconds.
4.     Set the detection time multiplier.
bfd detect-multiplier value
The default setting is 3.
Configure detection time settings for multihop BFD detection
2.     (Optional.) Enter static BFD session view.
bfd multi-hop min-echo-receive-interval interval
BFD sessions in control packet mode can be created statically or established dynamically.
BFD sessions are distinguished by the local discriminator and remote discriminator in control packets. The main difference between a statically created session and a dynamically established session is that they obtain the local discriminator and remote discriminator in different ways.
·     The local discriminator and remote discriminator of a static BFD session are specified manually in the bfd static command or in the commands that associate specific applications with BFD. For example, to use a static BFD session to detect MPLS LSPs, you must manually specify the local discriminator and remote discriminator. For more information, see MPLS OAM in MPLS Configuration Guide.
·     The local discriminator of a dynamic BFD session is assigned by the device, and the remote discriminator is obtained during BFD session negotiation. A created session without manually specified local and remote discriminators is a dynamic BFD session.
BFD version 0 does not support the following commands:
·     bfd authentication-mode
·     bfd demand enable
·     bfd echo enable
·     bfd session init-mode
BFD can use the following operating modes to establish a session:
·     Active mode—BFD actively sends BFD control packets regardless of whether any BFD control packet is received from the peer.
·     Passive mode—BFD does not send control packets until a BFD control packet is received from the peer.
At least one end must operate in active mode for a BFD session to be established.
2.     Configure the BFD session establishment mode.
By default, BFD uses the active mode to establish a session.
After a BFD session is established, the two ends can operate in the following modes:
·     Asynchronous mode—The device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within the detection interval. By default, BFD sessions operate in Asynchronous mode.
·     Demand mode—The Demand mode can be used to reduce the overhead when a large number of BFD sessions exist.
¡     If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets after receiving control packets with the D bit set. In this scenario, BFD detects only the link between the local end and the peer end. The device considers that the session is down if it does not receive any BFD control packets within the detection interval.
¡     If the peer end is operating in Demand mode, both ends stop sending BFD control packets. In this scenario, the system uses features other than BFD, such as Hello packets and hardware CC, to verify the connectivity to another system.
2.     Enter interface view.
3.     Specify the Demand mode for the BFD session.
bfd demand enable
By default, a BFD session is in Asynchronous mode.
A static BFD session can be used for single-hop detection and multihop detection. By working with Track, a static BFD session can provide fast failure detection. For more information about Track association with BFD, see "Configuring Track."
A static BFD session can detect the path types in Table 2. This section describes only static BFD sessions for detecting IP paths.
Table 2 Supported path types
Reference
IP paths.
"Configuring a static BFD session"
MPLS TE tunnels
MPLS PWs
Restrictions and guidelines for static BFD session configuration
If a static BFD session is created on the remote end, the static BFD session must be created on the local end.
Creating a static BFD session for single-hop detection of network layer connectivity
2.     Create a static BFD session and enter static BFD session view.
IPv4:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address ]
For a static BFD session to be established, specify the IPv4 address of the peer interface where the static BFD session resides for the peer-ip ipv4-address option. Specify the IPv4 address of the local interface where the static BFD session resides for the source-ip ipv4-address option.
IPv6:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address ]
For a static BFD session to be established, specify the IPv6 address of the peer interface where the static BFD session resides for the peer-ipv6 ipv6-address option. Specify the IPv6 address of the local interface where the static BFD session resides for the source-ipv6 ipv6-address option.
3.     (Optional.) Specify the local and remote discriminators for the static BFD session.
discriminator { local local-value | remote remote-value }
By default, no local discriminator or remote discriminator is specified for a static BFD session.
Use this command only if you do not specify the local or remote discriminator when creating a static BFD session.
Creating a static BFD session for single-hop detection of data link layer connectivity
bfd static session-name peer-ip default-ip interface interface-type interface-number source-ip ip-address
For a static BFD session to be established, specify the IPv6 address of the local interface where the static BFD session resides for the source-ip ip-address option.
Create a static BFD session for multihop detection
IPv4:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] source-ip ipv4-address [ track-interface interface-type interface-number ] ]
IPv6:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ track-interface interface-type interface-number ] ]
When creating a BFD session in control packet mode, you can configure the minimum interval for receiving and transmitting BFD control packets and the detection time multiplier for the device.
3.     Set the minimum interval for transmitting single-hop BFD control packets.
4.     Set the minimum interval for receiving single-hop BFD control packets.
5.     Set the single-hop detection time multiplier.
3.     Set the multihop detection time multiplier.
4.     Set the minimum interval for receiving multihop BFD control packets.
5.     Set the minimum interval for transmitting multihop BFD control packets.
You can configure authentication settings, including algorithm and key, to enhance BFD session security.
Configure the authentication mode for a single-hop BFD session
3.     Configure the authentication mode for single-hop control packets.
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, no authentication mode is configured for single-hop control packets.
Configure the authentication mode for a multihop BFD session
3.     Configure the authentication mode for multihop BFD control packets.
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, no authentication mode is configured for multihop BFD control packets.
IANA assigned port number 4784 to BFD for multihop BFD detection in control packet mode. By default, H3C devices use 4784 as the destination port number for multihop BFD control packets, while devices from other vendors might use 3784. To avoid BFD session establishment failures, make sure the devices on both ends of the BFD session use the same destination port number for multihop BFD control packets.
This command applies to only new multihop BFD sessions in control packet mode.
2.     Configure the destination port number for multihop BFD control packets.
The default setting is 4784.
By default, BFD does not notify upper-layer protocols of session establishment failures. The notification is required in some scenarios. For example, upon a session establishment failure in an aggregate link, the aggregate link can place the associated member port in Unselected state based on the failure notification. You can configure the delay timer for BFD to notify upper-layer protocols of session establishment failures.
This feature does not apply to BFD sessions in echo packet mode.
2.     Set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
bfd init-fail-timer seconds
CAUTION
CAUTION:
For session establishment failures caused by configuration mismatches at the two ends, this command can cause the upper-layer protocol to act incorrectly. Therefore, use this command with caution. BFD status mismatch and BFD authentication configuration mismatch are examples of configuration mismatches.
When you use Asynchronous mode BFD to detect the connectivity between directly connected devices, you can enable the echo function. This function enables the local system to periodically send echo packets to the remote system and reduces the control packet receiving rate to save bandwidth usage. The remote system loops back the echo packets to the local system without processing them. If the local system does not receive echo packets looped back from the remote system in a consecutive number of times, the local system declares the BFD session down.
This function is supported only for single-hop detection.
This function does not take effect on BFD sessions associated with interface states.
3.     Enable the echo function.
By default, the echo function is disabled.
By creating a BFD session for single-hop detection through exchange of BFD control packets, this feature implements fast link detection. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence. The source IP address of control packets is specified manually, and the destination IP address is fixed at 224.0.0.184. As a best practice, specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address.
You can associate the state of the following interfaces with BFD:
·     Layer 3 Ethernet interfaces.
·     Member ports in a Layer 3 aggregation group.
·     Layer 3 Ethernet subinterfaces.
·     Layer 3 aggregate interfaces
·     Layer 3 aggregate subinterfaces
·     Serial interfaces, MP-group interfaces, member ports of an MP-group interface, HDLC link bundle interfaces, and member ports of an HDLC link bundle interface.
If the link layer protocol of an interface is modified by using the link-protocol command, the association between the interface state and BFD is automatically cancelled. When associating the state of a member interface of an MP-group interface or of an HDLC link bundle interface, you must specify the discriminator parameter.
The echo function does not take effect on BFD sessions associated with interface states.
2.     Enter interface view or.
3.     Associate the interface state with BFD.
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ] [ template template-name ]
If the peer device does not support obtaining BFD session discriminators through autonegotiation, you must specify the discriminators on both the local and peer devices. Without the discriminators, the BFD session cannot come up.
4.     (Optional.) Configure the timer that delays reporting the first BFD session establishment failure to the data link layer.
bfd detect-interface first-fail-timer seconds
By default, the first BFD session establishment failure is not reported to the data link layer.
5.     (Optional.) Enable special processing for BFD sessions.
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
By default, all types of special processing are disabled for BFD sessions.
When you connect an H3C device to a device from another vendor, for successful BFD session negotiation, make sure the TTL value settings for BFD packets on both ends of the BFD session are the same. When the device receives a BFD packet in DOWN or INIT state from its peer, it verifies the TTL value of the packet and performs one of the following actions:
·     For a single-hop BFD session, if the device receives a packet that carries a TTL value that is different from the TTL value specified with the bfd ttl command, the device drops the packet.
·     For a multihop BFD session, if the device receives a packet that carries a TTL value that is greater than the TTL value specified with the bfd ttl command, the device drops the packet.
·     If the BFD session is already up, the device sets the BFD session state to AdminDown, which triggers a BFD session renegotiation.
·     The bfd ttl command does not take effect on BFD sessions in echo packet mode.
·     The bfd ttl command does not take effect on SBFD packets,and the device does not verify the TTL value in SBFD packets.
·     For an IPv4 or IPv6 address with different mask lengths or prefix lengths, the device uses the TTL value specified with the longest mask or prefix length.
·     For an IPv4 or IPv6 subnet, the TTL value of single-hop BFD packets must be greater than the TTL value of multihop BFD packets.
2.     Specify the TTL value for BFD packets.
bfd { peer-ip ipv4-address mask-length | peer-ipv6 ipv6-address prefix-length } ttl { single-hop | multi-hop } ttl-value
By default, the TTL value of single-hop BFD packets is 255 and the TTL value of multihop BFD packets is 64.
This task enables the state of a static BFD session to affect the state of another static BFD session.
The device supports the following association types for two static BFD sessions (static BFD session a and static BFD session b are used for illustration):
·     Unidirectional association—Session a is associated with session b in the view of session a, or session b is associated with session a in the view of session b.
·     Bidirectional association—Session a is associated with session b in the view of session a, and session b is associated with session a in the view of session b.
A unidirectional association works as follows (the association configured in the view of session a is taken as an example):
1.     When session a changes to the Down state, session b also changes to the Down state. Before session a comes up, session b is not allowed to perform negotiation.
2.     When session a changes to the Up state, session b starts to perform negotiation. The state of session a is not affected even if session b cannot come up through negotiation.
A bidirectional association works as follows:
¡     If session b comes up through negotiation in the specified time, both sessions are placed in the Up state.
¡     If session b fail to come up through negotiation in the specified time, both sessions are placed in the Down state.
3.     The same rules apply to the state changes of session a if session b first changes to the Down state.
2.     Enter static BFD session view.
3.     Associate the static BFD session with another static BFD session.
associate-static-session session-name [ re-negotiate seconds ]
By default, a static BFD session is not associated with any other static BFD sessions.
When BFD detects a link failure, it tears down the BFD session and notifies the upper-layer protocol of the failure. When the upper-layer protocol re-establishes a neighbor relationship, the BFD session comes up again. BFD session flaps occur when a link fails and recovers repeatedly, which consumes significant system resources and causes network instability.
This feature allows you to suppress BFD session flapping by using the initial-interval, secondary-interval, and maximum-interval arguments.
·     A BFD session is suppressed within the specified interval. The suppression time does not exceed the maximum-interval.
·     After a BFD session goes down for the second time, it cannot be re-established within the initial-interval.
·     After a BFD session goes down for the third time, it cannot be re-established within the secondary-interval.
·     After a BFD session goes down for the fourth time and at any later time, the following rules apply:
¡     If secondary-interval × 2n-3 is smaller than or equal to the maximum-interval, the BFD session cannot be re-established within the secondary-interval × 2n-3.
¡     If secondary-interval × 2n-3 is greater than the maximum-interval, the BFD session cannot be re-established within the maximum-interval.
The letter n, starting from 4, is the number of times the BFD session flaps.
2.     Configure BFD session flapping suppression.
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
By default, BFD sessions are not suppressed.
The value for the initial-interval or secondary-interval argument cannot be greater than or equal to the value for the maximum-interval argument.
If an upper-layer protocol uses BFD to detect the active path, packet loss might occur in the following situations:
·     An active/standby path switchover is triggered upon a device reboot. If the BFD session comes up after a device reboot, the traffic on the standby path will be switched over to the active path. In this case, traffic loss will occur if the active path of the upper-layer protocol has not recovered completely.
·     An active/standby path switchover is triggered after the active path goes down. If the BFD session comes up before the active path recovers, the traffic on the standby path will be switched over to the active path. In this case, traffic loss will occur.
To solve the traffic loss problem, you can delay BFD session negotiation.
This function starts a delay timer when the device reboots successfully. Before this timer expires, the device does not perform session negotiation on BFD sessions in down state and newly created sessions.
2.     Enable BFD session negotiation delay upon a device reboot and set a delay timer.
bfd session-negotiation delay-upon-reboot interval
By default, BFD session negotiation delay is disabled for a device reboot.
This function starts a delay timer for each BFD session from up to down state and each newly created session. Before the timer expires, the device does not perform session negotiation on each BFD session.
2.     Enable session negotiation delay for down BFD sessions and set a delay timer.
bfd session-negotiation delay-upon-down interval
By default, session negotiation delay is disabled for down BFD sessions.
Perform this task to specify BFD parameters in a template for sessions without next hops. You can configure BFD parameters for LSPs and PWs through a BFD template.
2.     Create a BFD template and enter BFD template view.
bfd template template-name
3.     Configure the authentication mode for BFD control packets.
By default, no authentication is performed.
BFD version 0 does not support this command.
5.     Set the minimum interval for receiving BFD echo packets.
6.     Set the minimum interval for receiving BFD control packets.
7.     Set the minimum interval for transmitting BFD control packets.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for BFD.
snmp-agent trap enable bfd
By default, SNMP notifications are enabled for BFD.
·     To display BFD session information, execute the following commands in any view:
display bfd session [ discriminator local-value | discriminator local local-value | static name session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { admin-down | down | init | up } ] [ discriminator remote remote-value ] [ peer-ip { ipv4-address | default-ip } [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { admin-down | down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ lsp | te | pw ] [ state { admin-down | down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { admin-down | down | init | up } ] [ discriminator remote remote-value ] [ peer-ip { ipv4-address | default-ip } [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { admin-down | down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
·     To display the TTL values for BFD packets., execute the following command in any view:
display bfd ttl
·     To clear BFD session statistics, execute the following command in user view:
reset bfd session statistics
Configuring SBFD
About SBFD
Seamless BFD (SBFD) is a unidirectional failure detection mechanism that simplifies the BFD state machine and shortens the session negotiation time to provide shorter detection time than BFD. SBFD is used in scenarios where only one end of a link requires failure detection.
An SBFD session involves the following roles:
·     Initiator—Initiates and maintains an SBFD session by periodically sends SBFD echo packets or SBFD control packets.
·     Reflector—Listens for incoming SBFD control packets and replies with response SBFD control packets. The reflector does not maintain the SBFD session state.
SBFD session modes
SBFD sessions use echo packets and control packets.
Echo packet mode
The echo packet mode requires configuration only on the initiator. You do not need to configure the reflector.
The SBFD detection mechanism in echo packet mode is as follows:
1.     The initiator sends SBFD echo packets to establish an SBFD session for link detection.
2.     Upon receiving the SBFD packets, the peer end returns the packets to the local end.
The peer end does not require SBFD settings, and it will not establish an SBFD session.
3.     If the initiator receives the SBFD echo packets before the detection time expires, it considers the link available. Otherwise, it considers the link unavailable.
Control packet mode
The SBFD detection mechanism in control packet mode is as follows:
1.     The initiator periodically sends SBFD control packets to the reflector.
2.     After receiving an SBFD control packet, the reflector checks whether the remote discriminator carried in the packet is the same as the locally configured one. If they are the same, the reflector sends a response SBFD control packet to the initiator. If they are different, the reflector drops the SBFD control packet.
3.     If the initiator receives the response SBFD control packet before the detection time expires, it considers the link available. Otherwise, it considers the link unavailable.
A node can act as the initiator of one session and the reflector of another session at the same time.
An SBFD session can only be established statically. You must manually specify the remote discriminator for an SBFD session.
To configure SBFD, perform the following tasks:
1.     Configuring the initiator
¡     Configuring the initiator for LDP LSP detection
¡     Configuring the action on received SBFD packets in down state
2.     Configuring the reflector
3.     (Optional.) Delaying SBFD session negotiation
4.     (Optional.) Configuring a BFD template
For SBFD in control packet mode, the remote discriminator in SBFD control packets sent by the initiator must be specified in the sbfd local-discriminator command on the reflector. If the discriminator is not specified on the reflector, the reflector does not reply with response SBFD control packets.
SBFD detects the connectivity of an LDP LSP in the following process:
1.     The initiator injects SBFD control packets into an LDP LSP. The ingress node of the LDP LSP is used as the initiator.
2.     After receiving an SBFD control packet, the reflector checks whether the remote discriminator carried in the packet is the same as the local discriminator. If they are the same, the reflector sends a response SBFD control packet to the initiator according to the routing table. The egress node of the LDP LSP is used as the reflector.
3.     If the initiator receives the response SBFD control packet before the detection time expires, it considers the LDP LSP available.
For more information about using LDP to dynamically establishing an LSP, see LDP in MPLS Configuration Guide.
When informing SBFD to establish an SBFD session, an LDP LSP sends the source and destination IP addresses of the packet to SBFD. The LDP LSP selects a source IP address in the following order:
1.     The IP address specified by the source-ip keyword in the mpls sbfd command configured for the LDP LSP.
2.     The IP address specified in the mpls lsr-id command.
To configure LDP LSP detection, make sure the reflector has a route to the source IP address in the SBFD packet sent from the initiator.
2.     (Optional.) Associate the destination IPv4 address of the detected path with the remote discriminator of the SBFD session for the initiator.
sbfd destination ipv4 destination-ipv4-address remote-discriminator { ipv4-address | integer-value }
By default, the destination IPv4 address of the detected path is not associated with the remote discriminator of the SBFD session for the initiator.
Configure this command if you want to specify the remote discriminator for establishing SBFD sessions.
3.     Enable BFD for MPLS.
mpls bfd enable
By default, BFD for MPLS is disabled.
For more information about this command, see MPLS OAM commands in MPLS Command Reference.
4.     (Optional.) Set the detection time multiplier.
5.     (Optional.) Set the minimum interval for sending SBFD control packets.
6.     Configure SBFD to verify LSP connectivity for an FEC.
mpls sbfd dest-addr mask-length [ nexthop nexthop-address ] [ remote remote-id ] [ template template-name ] [ source-ip ipv4-address ]
By default, SBFD is not configured to verify LSP connectivity for an FEC.
Typically, to establish an SBFD session, the initiator first sends a SBFD packet in down state. If the reflector replies with an SBFD packet in down state, the initiator will drop the packet, and the SBFD session cannot be established. To resolve this issue, configure this feature on the initiator. After configuration, when the initiator receives an SBFD packet in down state from the reflector, it sends an SBFD packet in up state for successful session establishment.
During session establishment, upon receiving SBFD packets in down state from the initiator, different reflectors might reply with SBFD packets carrying different session states. As a best practice, configure this feature to ensure successful establishment of SBFD sessions.
2.     Enable the initiator to send SBFD packets in up state upon receiving SBFD packets in down state from the reflector during session establishment.
sbfd initiator accept-down-response
By default, during session establishment, upon receiving an SBFD packet in down state from the reflector, the initiator drops the packet. The SBFD session cannot be established.
If you configure an IPv4 address as the local discriminator, the device automatically converts it to an integer. Configure an IPv4 address local discriminator only when it is required for interoperation with a third-party device.
The reflector replies with a response SBFD control packet only when the remote discriminator in the SBFD control packet sent from the initiator is specified in the sbfd local-discriminator command.
2.     Configure a local discriminator.
sbfd local-discriminator { ipv4-address | integer-value }
By default, no local discriminator is configured.
You can execute this command multiple times to configure multiple local discriminators.
When an upper-layer protocol uses SBFD to detect the active path, packet loss might occur in the following situations:
·     An active/standby path switchover is triggered upon a device reboot. If the SBFD session used to detect the active path comes up after a device reboot, the traffic on the standby path will be switched over to the active path. In this case, traffic loss will occur if the active path of the upper-layer protocol has not recovered completely.
·     An active/standby path switchover is triggered after the active path goes down. If the SBFD session used to detect the active path comes up before the active path recovers, the traffic on the standby path will be switched over to the active path. In this case, traffic loss will occur.
To solve the traffic loss problem, you can delay SBFD session negotiation.
This function starts a delay timer when the device reboots successfully. Before this timer expires, the device does not perform session negotiation on SBFD sessions in down state and newly created sessions.
2.     Enable SBFD session negotiation delay upon a device reboot and set a delay timer.
By default, SBFD session negotiation delay is disabled for a device reboot.
This function starts a delay timer for each SBFD session from up to down state and each newly created session. Before the timer expires, the device does not perform session negotiation on each SBFD session.
2.     Enable SBFD session negotiation delay for down SBFD sessions and set a delay timer.
By default, SBFD session negotiation delay is disabled for down SBFD sessions.
You can configure SBFD parameters for detecting the following paths through a BFD template:
·     LDP LSPs.
·     MPLS TE tunnels.
3.     Set the detection time multiplier.
4.     Set the minimum interval for sending SBFD control packets.
To display SBFD session information, execute the following command in any view:
display sbfd session { initiator [ discriminator value | [ ipv6 [ peer-ipv6 ipv6-address ] ] [ verbose ] | verbose ] | reflector [ discriminator value | verbose ] }
