| 00-Preface | 29.92 KB |
Preface
This installation guide provides information to help you have a quick installation of a U-Center NTA probe and resolve issues encountered in use of the probe.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
