| 00-Preface | 74.08 KB |
The H3C WX documentation set includes 10 command references, which describe the commands and command syntax options available for the H3C WX Series Access Controllers.
The Network Management and Monitoring Command Reference describes the configuration commands for how to manage the network, view system information, verify the current network connectivity, and enable debugging and to diagnose system faults.
NOTE: Support of the H3C WX series access controllers for commands may vary by device model. For the command matrixes, see About the WX Series Access Controllers Command References. |
This preface includes:
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the WX series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
Documentation feedback
We appreciate your comments.
