- 04-Layer 2 - LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-Spanning tree commands
- 05-Loop detection commands
- 06-VLAN commands
- 07-MVRP commands
- 08-QinQ commands
- 09-VLAN mapping commands
- 10-LLDP commands
- 11-Service loopback group commands
| 02-Ethernet link aggregation commands | 127.11 KB |
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
link-aggregation global load-sharing mode
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode local-first
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
Layer 2 aggregate interface view, Layer 3 aggregate interface view
The expected bandwidth of an interface affects link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth to 10000 kbps for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] bandwidth 10000
default
Use default to restore the default settings for an aggregate interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Layer 2 aggregate interface 1.
[Sysname-Bridge-Aggregation1] default
description
Use description to set a description for an interface.
The description of an interface is the interface-name plus Interface. For example, the default description of Bridge-Aggregation 1 is Bridge-Aggregation1 Interface.
text: Specifies the interface description, a string of 1 to 255 characters.
# Set the description to connect to the lab for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in the down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify the bridge-aggregation and route-aggregation keywords, the command displays information about all interfaces.
If you specify the bridge-aggregation or route-aggregation keyword but do not specify an interface number, the command displays information about all Layer 2 or Layer 3 aggregate interfaces.
If you specify the bridge-aggregation interface-number or route-aggregation interface-number option, the command displays information about the specified aggregate interface.
# Display detailed information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 0kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: access
Tagged Vlan: none
UnTagged Vlan: 1
Last 300 seconds input: 0 packets/sec 0 bytes/sec -%
Last 300 seconds output: 0 packets/sec 0 bytes/sec -%
Input (total): 0 packets, 0 bytes
Input (normal): 0 packets, 0 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, 0 overruns, 0 aborts
0 ignored, 0 parity errors
Output (normal): 0 packets, 0 bytes
Output: 0 output errors, 0 underruns, 0 buffer failures
0 lost carrier, 0 no carrier
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Line protocol state: UP
Description: Route-Aggregation1 Interface
Bandwidth: 1000000kbps
Maximum Transmit Unit: 1500
Internet protocol processing: disabled
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 0000-fc00-2501
IPv6 Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 0000-fc00-2501
Last 300 seconds input rate: 6 bytes/sec, 48 bits/sec, 0 packets/sec
Last 300 seconds output rate: 2 bytes/sec, 16 bits/sec, 0 packets/sec
11 packets input, 800 bytes, 0 drops
1 packets output, 80 bytes, 0 drops
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
Brief information on interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
Interface Link Speed Duplex Type PVID Description
BAGG1 UP auto A A 1
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface Link Protocol Main IP Description
RAGG1 UP UP --
Bridge-Aggregation1 |
Layer 2 aggregate interface name. |
Route-Aggregation1 |
Layer 3 aggregate interface name. |
Current state |
Layer 3 aggregate interface status: · DOWN (Administratively down)—The interface is administratively shut down with the shutdown command. · DOWN—The interface is administratively up but physically down (possibly because no physical link is present or the link has failed). · UP—The Ethernet interface is both administratively and physically up. |
IP Packet Frame Type |
IPv4 packet frame format. The value PKTFMT_ETHNT_2 indicates that packets are encapsulated in Ethernet II format. |
Bandwidth |
Expected bandwidth of the interface. |
Unknown-speed mode, unknown-duplex mode |
The interface speed and duplex mode are unknown. |
PVID |
Port VLAN ID (PVID). |
Port link-type |
Port link type: access, trunk, or hybrid. |
Tagged Vlan |
VLAN whose packets are sent out of this interface with a tag. |
Untagged Vlan |
VLAN whose packets are sent out of this interface without a tag. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. If the reset counters interface command has never been used on the interface since the device startup, this field displays Never. |
Last 300 seconds input/output rate |
Average input/output rate over the last 300 seconds. |
Input/Output (total) |
Statistics of all packets received/sent on the interface. |
Input/Output (normal) |
Statistics of all normal packets received/sent on the interface. |
Line protocol state |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. |
Internet protocol processing |
IP packet processing. Disabled indicates that IP packets cannot be processed. For an interface configured with an IP address, this field changes to Internet Address is. |
Brief information on interface(s) under route mode |
Brief information about Layer 3 interfaces. |
Brief information on interface(s) under bridge mode |
Brief information about Layer 2 interfaces. |
Link: ADM - administratively down; Stby - standby |
Link status: · ADM—The interface has been administratively shut down. To recover its physical layer state, run the undo shutdown command. · Stby—The interface is operating as a backup interface. |
Speed or Duplex: (a)/A - auto; H - half; F - full |
If the speed of an interface is automatically negotiated, the speed attribute of the interface includes the auto negotiation flag (the letter a in parentheses). If an interface is configured to autonegotiate its speed but the autonegotiation has not started, its speed attribute is displayed as auto. If the duplex mode of an interface is automatically negotiated, the duplex mode attribute of the interface includes the letter a in parentheses. H indicates the half duplex mode. F indicates the full duplex mode. If an interface is configured to autonegotiate its duplex mode but the autonegotiation has not started, its duplex mode attribute is displayed as A. |
Type: A - access; T - trunk; H - hybrid |
Port link type options for interfaces. |
Protocol: (s) - spoofing |
If the data link layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present, its protocol attribute includes the spoofing flag (the letter s in parentheses). |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been administratively shut down. To bring up the interface, use the undo shutdown command. · Stby—The interface is operating as a backup interface. |
Speed |
Interface speed, in bps. |
Data link layer state of the interface: · UP—The data link layer of the interface is up. · DOWN—The data link layer of the interface is down. · UP(s)—The data link layer of the interface is shown as UP, but its link is an on-demand link or not present. |
Cause |
Cause of a DOWN physical link. |
Partial or complete interface description configured by using the description command. · If you do not specify the description keyword in the display interface brief command, this field displays only the first 27 characters of the interface description. · If you specify the description keyword in the display interface brief command, this field displays the complete interface description. |
display lacp system-id
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed as a hexadecimal value in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Actor System ID: 0x8000, 0000-fc00-6504 |
Local system ID, which contains the system LACP priority (0x8000 in this sample output) and the system MAC address (0000-FC00-6504 in this sample output). |
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
If you specify the bridge-aggregation interface-number or route-aggregation interface-number option, the command displays the load sharing mode of the specified aggregation group.
The bridge-aggregation or route-aggregation keyword is available only when Layer 2 or Layer 3 aggregate interfaces exist on the device.
# Display the default global link-aggregation load sharing modes.
<Sysname> display link-aggregation load-sharing mode
Link-Aggregation Load-Sharing Mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the configured global link-aggregation load sharing mode.
destination-mac address source-mac address
# Display the default link-aggregation load sharing modes of Layer 2 aggregation group 10.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 10
Bridge-Aggregation10 Load-Sharing Mode:
# Display the configured link-aggregation load sharing mode of Layer 2 aggregation group 10.
Link-Aggregation Load-Sharing Mode |
Global link-aggregation load sharing mode. By default, this field displays the link-aggregation load sharing modes for Layer 2 traffic and Layer 3 traffic. If you have set the global link-aggregation load sharing mode, this field displays the set mode. |
Bridge-Aggregation10 Load-Sharing Mode |
Link-aggregation load sharing mode of Layer 2 aggregation group 10. By default, this field displays the global link-aggregation load sharing modes. If you have set a link-aggregation load sharing mode for this aggregation group, this field displays the set mode. |
Route-Aggregation10 Load-Sharing Mode |
Link-aggregation load sharing mode of Layer 3 aggregation group 10. By default, this field displays the global link-aggregation load sharing modes. If you have set a link-aggregation load sharing mode for this aggregation group, this field displays the set mode. |
Layer 2 traffic: packet type-based sharing |
Default link-aggregation load sharing mode for Layer 2 traffic. In this sample output, Layer 2 traffic is load shared based on the packet type. |
Layer 3 traffic: packet type-based sharing |
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, Layer 3 traffic is load shared based on the packet type. |
destination-mac address, source-mac address |
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses. |
Use display link-aggregation member-port to display detailed link aggregation information for the specified member ports.
display link-aggregation member-port [ interface-list ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number [ to interface-type interface-number ]. interface-type interface-number specifies an interface by its type and number.
A member port in a static aggregation group is unaware of information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed link aggregation information for GigabitEthernet 1/0/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/1
G -- Defaulted, H -- Expired
GigabitEthernet1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed link aggregation information for RPR 4/0/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port rpr 4/0/1
RPR4/0/1:
Port Number: 1
Oper-Key: 1
# Display detailed link aggregation information for GigabitEthernet 1/0/2, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/2
GigabitEthernet1/0/2:
Aggregate Interface: Bridge-Aggregation10
Local:
Port Number: 2
Oper-Key: 2
Flag: {ACDEF}
Remote:
Port Number: 26
Oper-Key: 2
Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Flags |
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. The letter is present when its bit is 1 and absent when its bit is 0. · A—Indicates whether LACP is enabled. 1 indicates enabled, and 0 indicates disabled. · B—Indicates the LACP short or long timeout. 1 indicates short timeout, and 0 indicates long timeout. · C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes, and 0 indicates no. · D—Indicates whether the sending system considers that the link is synchronized. 1 indicates yes, and 0 indicates no. · E—Indicates whether the sending system considers that the incoming frames are collected. 1 indicates yes, and 0 indicates no. · F—Indicates whether the sending system considers that the outgoing frames are distributed. 1 indicates yes, and 0 indicates no. · G—Indicates whether the sending system receives frames in the default state. 1 indicates yes, and 0 indicates no. · H—Indicates whether the sending system receives frames in the expired state. 1 indicates yes, and 0 indicates no. |
Aggregate Interface |
Aggregate interface to which the member port belongs. |
Local |
Information about the local end. |
Oper-key |
Operational key. |
Flag |
LACP protocol state flag. |
Remote |
Information about the peer end. |
System ID |
Peer system ID, containing the system LACP priority and the system MAC address. |
Received LACP Packets |
Total number of LACP packets received. |
Illegal |
Total number of illegal packets. |
Sent LACP Packets |
Total number of LACP packets sent. |
Use display link-aggregation summary to display brief information about all aggregation groups.
Static link aggregation groups are unaware of information about the peer groups. As a result, the Partner ID field displays None for a static link aggregation group.
# Display brief information for all aggregation groups.
<Sysname> display link-aggregation summary
Aggregation Interface Type:
BAGG -- Bridge-Aggregation, BLAGG -- Blade-Aggregation, RAGG -- Route-Aggregatio
n
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 0000-fc00-2500
AGG AGG Partner ID Selected Unselected Individual Share
Interface Mode Ports Ports Ports Type
BLAGG1 S None 0 0 0 Shar
BAGG1 S None 0 0 0 Shar
RAGG1 S None 1 0 0 Shar
Table 5 Command output
Aggregate Interface Type |
Aggregate interface type: · BAGG—Layer 2. · RAGG—Layer 3. |
Aggregation Mode |
Aggregation group type: · S—Static. · D—Dynamic. |
Loadsharing Type |
Load sharing type: · Shar—Load sharing. · NonS—Non-load sharing. |
Actor System ID |
Local system ID, which contains the local system LACP priority and the local system MAC address. |
AGG Interface |
Type and number of the aggregate interface. |
AGG Mode |
Aggregation group type. |
Partner ID |
System ID of the peer system, which contains the peer system LACP priority and the peer system MAC address. |
Selected Ports |
Total number of Selected ports. |
Unselected Ports |
Total number of Unselected ports. |
Total number of Individual ports. |
Share Type |
Load sharing type. |
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
interface-number: Specifies an existing aggregate interface by its number.
If you specify the bridge-aggregation or route-aggregation keyword but do not specify an interface number, the command displays detailed information about all Layer 2 or Layer 3 aggregation groups.
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
# Display detailed information about Layer 2 aggregation group 10, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 10
Aggregation Mode: Dynamic
Local:
Port Status Priority Oper-Key Flag
GE1/0/1 S 32768 2 {ACDEF}
GE1/0/2 S 32768 2 {ACDEF}
GE1/0/3 S 32768 2 {AG}
Remote:
Actor Partner Priority Oper-Key SystemID Flag
GE1/0/1 1 32768 2 0x8000, 000f-e267-57ad {ACDEF}
GE1/0/2 2 32768 2 0x8000, 000f-e267-57ad {ACDEF}
GE1/0/3 0 32768 0 0x8000, 0000-0000-0000 {DEF}
# Display detailed information about Layer 2 aggregation group 20, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 20
Aggregate Interface: Bridge-Aggregation20
Aggregation Mode: Static
GE1/0/1 U 32768 1
GE1/0/2 U 32768 1
GE1/0/3 U 32768 1
Table 6 Command output
Loadsharing Type |
Port Status |
Port state: Selected, Unselected, or Individual. |
Flags |
Name of the aggregate interface. |
Aggregation Mode |
System ID |
Local system ID, containing the local system LACP priority and the local system MAC address. |
Local |
Information about the local end: · Port—Port type and number. · Status—Port state, which can be Selected, Unselected, or Individual. · Priority—Port priority. · Oper-Key—Operational key. · Flag—LACP state flag. NOTE: For static aggregation groups, the Flag field is not displayed. |
Remote |
Information about the peer end: · Actor—Type and number of the local port. · Partner—Index of the peer port. · Priority—Priority of the peer port. · Oper-Key—Operational key of the peer port. · System ID—System ID of the peer end. · Flag—LACP state flag of the peer end. |
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter the Layer 2 aggregate interface view.
Use undo interface bridge-aggregation to delete a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
No Layer 2 aggregate interface is created.
interface-number: Specifies a Layer 2 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and enter its view.
Use interface route-aggregation to create a Layer 3 aggregate interface and enter Layer 3 aggregate interface view.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface.
undo interface route-aggregation interface-number
No Layer 3 aggregate interface is created.
interface-number: Specifies a Layer 3 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
[Sysname-Route-Aggregation1]
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface connecting an LACP-enabled device to an LACP-enabled server. This feature enables the aggregation member ports on the device to forward packets from the server (the peer system) during the server reboot process.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 2 aggregate interface Bridge-aggregation 1 as an edge aggregate interface.
<Sysname> System-view
[Sysname-Bridge-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP is operating in active mode on a port.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
This command takes effect only on member ports of dynamic aggregation groups.
# Configure LACP to operate in passive mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lacp mode passive
lacp period short
Use lacp period short to set the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds).
Do not set the LACP timeout interval to the short LACP timeout interval before performing an ISSU. Otherwise, traffic interruption will occur during the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
# Set the short LACP timeout interval (3 seconds) on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lacp period short
Use lacp system-priority to set the system LACP priority.
Use undo lacp system-priority to restore the default.
lacp system-priority system-priority
The system LACP priority is 32768.
system-priority: Specifies the system LACP priority in the range of 0 to 65535. The smaller the value, the higher the system LACP priority.
# Set the system LACP priority to 64.
[Sysname] lacp system-priority 64
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | ingress-port | source-ip | source-mac | source-port } *
The device load shares traffic automatically based on packet types.
destination-ip: Load shares traffic based on destination IP addresses.
destination-mac: Load shares traffic based on destination MAC addresses.
destination-port: Load shares traffic based on destination ports.
ingress-port: Load shares traffic based on ingress ports.
source-ip: Load shares traffic based on source IP addresses.
source-mac: Load shares traffic based on source MAC addresses.
source-port: Load shares traffic based on source ports.
The load sharing mode that you configure overwrites the previous mode.
If an unsupported load sharing mode is configured, an error prompt appears.
In system view, the switch supports the following load sharing modes and combinations:
· Source IP address.
· Destination IP address.
· Source MAC address.
· Destination MAC address.
· Source IP address and destination IP address.
· Source IP address and source port.
· Destination IP address and destination port.
· Source IP address, source port, destination IP address, and destination port.
· Any combination of ingress port, source MAC address, and destination MAC address.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
link-aggregation ignore vlan
Use link-aggregation ignore vlan to configure a Layer 2 aggregate interface to ignore the specified VLANs.
Use undo link-aggregation ignore vlan to restore the default.
link-aggregation ignore vlan vlan-id-list
undo link-aggregation ignore vlan vlan-id-list
A Layer 2 aggregate interface does not ignore any VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for vlan-id2 must be equal to or greater than the value for vlan-id1.
With this command configured, a Layer 2 aggregate interface ignores the permitted VLAN and VLAN tagging mode configuration of the specified VLANs when choosing Selected ports.
# Configure Layer 2 aggregate interface bridge-aggregation 1 to ignore VLAN 50.
[Sysname-Bridge-Aggregation1] link-aggregation ignore vlan 50
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
When you restart a card that contains Selected ports, this feature redirects traffic of the card to other cards. Zero packet loss is guaranteed for known unicast traffic, but not for unknown unicast traffic. (In standalone mode.)
When you restart either an IRF member device or the device's card that contains Selected ports, this feature redirects traffic of the IRF member device or card to other IRF member devices or cards. Zero packet loss is guaranteed for known unicast traffic, but not for unknown unicast traffic. (In IRF mode.)
Link-aggregation traffic redirection applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
Do not enable both spanning tree and link-aggregation traffic redirection on a device. Otherwise, light packet loss might occur when a card or the device reboots.
To avoid traffic interruption on Layer 2 dynamic aggregate links after link-aggregation traffic redirection is enabled, make sure the corresponding aggregate interfaces do not have static MAC address entries. For information about MAC address entries, see Layer 2—LAN Switching Configuration Guide.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation load-sharing mode to set the link-aggregation load sharing mode.
Use undo link-aggregation load-sharing mode to restore the default.
link-aggregation load-sharing mode { { destination-ip | destination-mac | mpls-label1 | mpls-label2 | source-ip | source-mac } * | flexible }
The load sharing mode is the same as the global load sharing mode.
mpls-label1: Load shares MPLS traffic based on Layer 1 labels.
mpls-label2: Load shares MPLS traffic based on Layer 2 labels.
flexible: Load shares traffic flexibly based on the packet type (for example, Layer 2 protocol packets, IPv4 packets, IPv6 packets, or MPLS packets).
In Layer 2 aggregate interface view, the switch supports the following load sharing modes and combinations:
· Layer 1 MPLS label.
· Destination IP address and source IP address.
· Destination MAC address and source MAC address.
· Layer 1 MPLS label and Layer 2 MPLS label.
# Configure Layer 2 aggregation group 1 to load share packets based on destination MAC addresses.
[Sysname-Bridge-Aggregation1] link-aggregation load-sharing mode destination-mac
Use link-aggregation load-sharing mode local-first to enable local-first load sharing for link aggregation.
Use undo link-aggregation load-sharing mode local-first to disable local-first load sharing for link aggregation.
Local-first load sharing is enabled for link aggregation.
When you disable local-first load sharing, the packets will be load shared among all Selected ports of the aggregate interface on all IRF member devices.
# Disable local-first load sharing for link aggregation.
[Sysname] undo link-aggregation load-sharing mode local-first
link-aggregation mode
Use link-aggregation mode dynamic to configure an aggregation group to operate in dynamic aggregation mode and enable LACP.
Use undo link-aggregation mode to restore the default.
An aggregation group operates in static aggregation mode.
# Configure Layer 2 aggregation group 1 to operate in dynamic aggregation mode.
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
link-aggregation port-priority port-priority
The port priority of an interface is 32768.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view, RPR logical interface view
port-priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 2 Ethernet interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] link-aggregation port-priority 64
# Set the port priority to 64 for Layer 3 Ethernet interface GigabitEthernet 1/0/2.
[Sysname-GigabitEthernet1/0/2] link-aggregation port-priority 64
Use link-aggregation selected-port maximum to configure the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum number
The maximum number of Selected ports allowed in an aggregation group depends on hardware limitation.
number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 32.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
The maximum number of Selected ports allowed in the aggregation groups of the local and peer ends must be consistent.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
· Maximum number configured by using the link-aggregation selected-port maximum command.
· Hardware limitation.
You can configure backup between two ports by performing the following tasks:
· Assigning two ports to an aggregation group.
· Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
Use link-aggregation selected-port minimum to configure the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
link-aggregation selected-port minimum number
The minimum number of Selected ports in an aggregation group is not specified.
number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 32.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups of the local and peer ends must be consistent.
# Set the minimum number of Selected ports to 3 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
mtu
Use mtu to set the MTU for a Layer 3 aggregate interface.
mtu size
undo mtu
The MTU for Layer 3 aggregate interfaces is 1500 bytes.
size: Specifies the MTU in bytes. The value range is 46 to 1560.
# Set the MTU to 1430 bytes for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] mtu 1430
display interface
port link-aggregation group
Use port link-aggregation group to assign an Ethernet interface to an aggregation group.
Use undo port link-aggregation group to remove an Ethernet interface from the aggregation group to which it belongs.
port link-aggregation group number
An Ethernet interface does not belong to any aggregation group.
number: Specifies an aggregation group by its aggregate interface number. The value range for the number argument is 1 to 1024.
RPR logical interfaces cannot be assigned to dynamic aggregation groups.
A Layer 2 Ethernet interface or an RPR logical interface can be assigned to a Layer 2 aggregation group only. A Layer 3 Ethernet interface can be assigned to a Layer 3 aggregation group only.
You cannot assign a Layer 2 Ethernet interface and an RPR logical interface to the same Layer 2 aggregation group.
An interface can belong to only one aggregation group.
An RPR logical interface cannot be assigned to an aggregation group whose corresponding aggregate interface is assigned to an isolation group. For information about isolation groups, see Layer 2—LAN Switching Configuration Guide.
# Assign Layer 2 Ethernet interface GigabitEthernet 1/0/1 to Layer 2 aggregation group 2.
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 2
# Assign RPR logical interface RPR 4/0/1 to Layer 2 aggregation group 20.
[Sysname] interface rpr 4/0/1
[Sysname-RPR4/0/1] port link-aggregation group 20
# Assign Layer 3 Ethernet interface GigabitEthernet 1/0/2 to Layer 3 aggregation group 3.
[Sysname-GigabitEthernet1/0/2] port link-aggregation group 3
Use reset counters interface to clear statistics for the specified aggregate interfaces.
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
interface-number: Specifies an aggregate interface number.
Use this command to clear history statistics before you collect traffic statistics for a time period.
If you do not specify any options, the command clears statistics for all interfaces in the system.
If you specify only the bridge-aggregation or route-aggregation keyword, the command clears statistics for all Layer 2 or Layer 3 aggregate interfaces.
If you specify the bridge-aggregation interface-number or route-aggregation interface-number option, the command clears statistics for the specified Layer 2 or Layer 3 aggregate interface.
# Clear statistics for Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics for the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number [ to interface-type interface-number ]. interface-type interface-number specifies an interface by its type and number. If you do not specify any member ports, the command clears LACP statistics for all member ports.
# Clear LACP statistics for all link aggregation member ports.
<Sysname> reset lacp statistics
rpr reserve-vlan
Use undo rpr reserve-vlan to restore the default.
rpr reserve-vlan vlan vlan-id
No VLAN interface resource is reserved for a Layer 2 aggregate interface.
vlan vlan-id: Specifies a nonexistent VLAN ID in the range of 1 to 4094. VLAN ID 1 is not supported in the current software version.
You must reserve a VLAN interface resource for a Layer 2 aggregate interface after assigning RPR logical interfaces to the corresponding Layer 2 aggregation group. The reserved VLAN interface resource is used for traffic forwarding on the RPR logical interfaces.
After the resource of a VLAN interface is reserved, you cannot use the vlan and undo vlan commands to create and delete the VLAN.
# Reserve the resource of VLAN-interface 4094 for Layer 2 aggregate interface Bridge-Aggregation 1 whose aggregation group uses RPR logical interfaces as member ports.
[Sysname] interface Bridge-Aggregation 1
[Sysname-Bridge-Aggregation1] rpr reserve-vlan vlan 4094
shutdown
Use shutdown to shut down an aggregate interface.
Use undo shutdown to bring up an aggregate interface.
shutdown
An aggregate interface is up.
# Bring up Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo shutdown
