H3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesS7500 SeriesConfigure & DeployConfiguration GuidesH3C S7500 Series Operation Manual(Release 3100 Series)-(V1.04)
00-1Cover
00-1Cover 87 KB
H3C S7500 Series Ethernet Switches
Operation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08163Y-20070720-C-1.04
Product Version: Release 3100 Series
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd.
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
service@h3c.com
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S7500 Series Ethernet Switches documentation set includes the following:
Manual
H3C S7500 Series Ethernet Switches  Command Manual
It is used for assisting the users in using various commands.
H3C S7500 Series Ethernet Switches  Installation Manual
It provides information for the system installation.
Organization
H3C S7500 Series Ethernet Switches Operation Manual is organized as follows:
Part
0 Overview
Briefly introduces the new features and network application added to the Ethernet switch.
1 CLI
Introduces the command hierarchy, command view and CLI features of the Ethernet switch.
2 Login
Introduces the ways to log into an Ethernet switch.
3 Configuration File Management
Introduces the ways to manage configuration files.
4 VLAN
Introduces VLAN fundamental and the related configuration.
5 Extended VLAN Application
Introduces Voice VLAN, isolate-user-VLAN, super VLAN and the related configuration.
6 IP Address-IP Performance-IPX
Introduces IP address, IP performance, IPX fundamental and the related configuration.
7 GVRP
Introduces GVRP and the related configuration.
8 QinQ
Introduces QinQ, selective QinQ, and the related configuration.
9 Port Basic Configuration
Introduces basic port configuration.
10 Link Aggregation
Introduces link aggregation and the related configuration.
11 Port Isolation
Introduces port isolation and the related configuration.
12 Port Binding
Introduces port binding and the related configuration.
13 DLDP
Introduces DLDP and the related configuration.
14 MAC Address Table
Introduces MAC address forwarding table and the related configuration.
15 MSTP
Introduces STP, VLAN-VPN tunnel and the related configurations.
16 Routing Protocol
Introduces the routing protocol-related configurations.
17 Multicast
Introduces the multicast protocol-related configurations.
18 802.1x
Introduces 802.1x, HABP and the related configurations.
19 AAA-RADIUS-HWTACACS-EAD
Introduces AAA, RADIUS, HWTACACS, EAD, and the related configurations.
20 Traffic Accounting
Introduces flow-based accounting and the related configuration.
21 VRRP-HA
Introduces VRRP, HA, and the related configurations.
22 ARP
Introduces ARP and the related configuration.
23 DHCP
Introduces DHCP and the related configuration.
24 ACL
Introduces ACL and the related configuration.
25 QoS
Introduces QoS and the related configuration.
26 Mirroring
Introduces port mirroring and the related configuration.
27 Cluster
Introduces cluster and the related configuration.
28 PoE
Introduces PoE and the related configuration.
29 UDP-Helper
Introduces UDP Helper and the related configuration.
30 SNMP-RMON
Introduces the configuration to manage network devices through SNMP and RMON.
31 NTP
Introduces NTP and the related configuration.
32 SSH Terminal Service
Introduces SSH, SFTP, and the related configurations.
33 File System Management
Introduces basic configuration for file system management.
34 FTP and TFTP
Introduces basic configuration for FTP and TFTP, and the applications.
35 Information Center
Introduces the configuration to analyze and diagnose networks using the information center.
36 DNS
Introduces DNS and the related configuration.
37 System Maintenance and Debugging
Introduces system maintenance and debugging.
38 HWPing
Introduces HWPing and the related configuration.
39 RRPP
Introduces RRPP and the related configuration.
40 NAT-Netstream-Policy Routing
Introduces NAT, Netstream, policy-based routing, and the related configurations.
41 Telnet Protection
Introduces Telnet securing and the related configuration.
42 Hardware-Dependent Software Configuration
Introduces hardware-dependent software and the related configuration.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
