H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesS7500 SeriesReference GuidesCommand ReferencesH3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
00-1Cover
00-1Cover 87 KB
H3C S7500 Series Ethernet Switches
Command Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08193F-20070720-C-1.04
Product Version: Release 3100 Series
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd.
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
service@h3c.com
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S7500 Series Ethernet Switches documentation set includes the following:
Manual
H3C S7500 Series Ethernet Switches  Operation Manual
It is used for assisting the users in data configurations and typical applications.
H3C S7500 Series Ethernet Switches  Installation Manual
It provides information for the system installation.
Organization
H3C S7500 Series Ethernet Switches Command Manual is organized as follows:
Part
1 CLI
Introduces the commands used for switching between the command levels and command level setting.
2 Login
Introduces the commands used for logging into the Ethernet switch.
3 Configuration File Management
Introduces the commands used for configuration file management.
4 VLAN
Introduces the commands used for configuring VLAN.
5 Extended VLAN Application
Introduces the commands used for configuring voice VLAN, isolate-user-VLAN, and super VLAN.
6 IP Address-IP Performance-IPX
Introduces the commands used for IP address configuration, IP performance configuration, and IPX configuration.
7 GVRP
Introduces the commands used for GVRP configuration.
8 QinQ
Introduces the commands used for QinQ and selective QinQ configuration.
9 Port Basic Configuration
Introduces the commands used for basic port configuration.
10 Link Aggregation
Introduces the commands used for link aggregation.
11 Port Isolation
Introduces the commands used for port isolation.
12 Port Binding
Introduces the commands used for port binding.
13 DLDP
Introduces the commands used for DLDP configuration.
14 MAC Address Table
Introduces the commands used for MAC address forwarding table management.
15 MSTP
Introduces the STP-related commands and VLAN-VPN tunnel-related commands.
16 Routing Protocol
Introduces the commands used for routing protocol configuration.
17 Multicast
Introduces the commands used for multicast configuration.
18 802.1x
Introduces the commands used for 802.1x and HABP configuration.
19 AAA-RADIUS-HWTACACS-EAD
Introduces the commands used for AAA, RADIUS, HWTACACS, and EAD configuration.
20 Traffic Accounting
Introduces the commands used for traffic accounting.
21 VRRP-HA
Introduces the commands used for VRRP and HA configuration.
22 ARP
Introduces the ARP-related commands.
23 DHCP
Introduces the DHCP-related commands.
24 ACL
Introduces the ACL-related commands.
25 QoS
Introduces the commands used for QoS configuration.
26 Mirroring
Introduces the commands used for port mirroring.
27 Cluster
Introduces the commands used for cluster management.
28 PoE
Introduces the commands used for PoE configuration.
29 UDP-Helper
Introduces the commands used for UDP Helper configuration.
30 SNMP-RMON
Introduces the commands used for SNMP and RMON configuration.
31 NTP
Introduces the NTP-related commands.
32 SSH Terminal Service
Introduces the commands used for SSH and SFTP configuration.
33 File System Management
Introduces the commands used for file system management.
34 FTP and TFTP
Introduces the FTP-/TFTP-related commands.
35 Information Center
Introduces the commands used for information center configuration.
36 DNS
Introduces the DNS-related commands.
37 System Maintenance and Debugging
Introduces the commands used for system maintenance and debugging.
38 HWPing
Introduces the commands used for HWPing configuration.
39 RRPP
Introduces the RRPP-related commands.
40 NAT-Netstream-Policy Routing
Introduces the commands used for NAT, Netstream, and policy-based routing.
41 Telnet Protection
Introduces the commands used for Telnet securing.
42 Hardware-Dependent Software Configuration
Introduces the commands concerning hardware-dependent software.
43 Appendix
Lists all the commands described in this manual in alphabetic order.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
