43-附录
本章节下载 (101.77 KB)
本命令索引包括手册中所出现的全部命令,按字母序排列,左边为命令行,右边为该命令所在的功能模块和页码。
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
access-limit |
17-AAA命令 |
1-1 |
accounting |
17-AAA命令 |
1-1 |
accounting domain |
21-DHCP命令 |
1-1 |
accounting lan-access |
17-AAA命令 |
1-2 |
accounting login |
17-AAA命令 |
1-3 |
accounting optional |
17-AAA命令 |
1-4 |
17-AAA命令 |
1-30 |
accounting start-mode |
17-AAA命令 |
1-31 |
accounting-on enable |
17-AAA命令 |
1-32 |
acl |
01-登录交换机命令 |
2-1 |
acl |
22-ACL命令 |
1-1 |
active region-configuration |
14-MSTP命令 |
1-1 |
add-member |
25-Stack-Cluster命令 |
2-12 |
administrator-address |
2-13 |
adv-factor |
34-HWPing命令 |
1-1 |
am user-bind |
11-端口安全-端口绑定命令 |
2-1 |
apply qos-profile |
23-QoS-QoS Profile命令 |
2-1 |
arp anti-attack valid-check enable |
38-ARP和IP攻击防御命令 |
1 |
arp check enable |
20-ARP命令 |
1-1 |
arp detection enable |
20-ARP命令 |
1-1 |
arp detection trust |
20-ARP命令 |
1-2 |
arp filter binding |
38-ARP和IP攻击防御命令 |
2 |
arp filter source |
38-ARP和IP攻击防御命令 |
1 |
arp max-learning-num |
38-ARP和IP攻击防御命令 |
2 |
arp protective-down recover enable |
20-ARP命令 |
1-2 |
arp protective-down recover interval |
20-ARP命令 |
1-3 |
arp rate-limit |
20-ARP命令 |
1-4 |
arp rate-limit enable |
20-ARP命令 |
1-4 |
arp restricted-forwarding enable |
20-ARP命令 |
1-5 |
arp static |
20-ARP命令 |
1-5 |
arp timer aging |
20-ARP命令 |
1-6 |
ascii |
30-FTP-SFTP-TFTP命令 |
1-5 |
attribute |
17-AAA命令 |
1-5 |
attribute |
40-PKI命令 |
1-1 |
attribute-ignore |
17-AAA命令 |
1-33 |
authentication |
17-AAA命令 |
1-6 |
authentication lan-access |
17-AAA命令 |
1-7 |
authentication login |
17-AAA命令 |
1-7 |
authentication super |
17-AAA命令 |
1-8 |
authentication-mode |
01-登录交换机命令 |
1-1 |
authorization |
17-AAA命令 |
1-9 |
authorization login |
17-AAA命令 |
1-10 |
authorization vlan |
17-AAA命令 |
1-11 |
auto-build |
2-13 |
auto-execute command |
01-登录交换机命令 |
1-2 |
bims-server |
21-DHCP命令 |
1-1 |
binary |
1-5 |
black-list |
2-34 |
boot attribute-switch |
29-文件系统管理命令 |
1-13 |
boot boot-loader |
29-文件系统管理命令 |
1-14 |
boot boot-loader |
32-系统维护与调试命令 |
3-1 |
boot boot-loader backup-attribute |
29-文件系统管理命令 |
1-14 |
boot bootrom |
32-系统维护与调试命令 |
3-1 |
boot web-package |
29-文件系统管理命令 |
1-15 |
bpdu-drop any |
14-MSTP命令 |
1-1 |
broadcast-suppression |
08-端口基本配置命令 |
1-1 |
build |
2-15 |
burst-mode enable |
1-1 |
bye |
1-6 |
bye |
1-19 |
ca identifier |
40-PKI命令 |
1-2 |
calling-station-id mode |
17-AAA命令 |
1-34 |
cd |
29-文件系统管理命令 |
1-1 |
cd |
1-6 |
cd |
1-20 |
cdup |
1-7 |
cdup |
1-20 |
certificate request entity |
40-PKI命令 |
1-2 |
certificate request from |
40-PKI命令 |
1-3 |
certificate request mode |
40-PKI命令 |
1-3 |
certificate request polling |
40-PKI命令 |
1-4 |
certificate request url |
40-PKI命令 |
1-5 |
check region-configuration |
14-MSTP命令 |
1-2 |
ciphersuite |
41-SSL命令 |
1-1 |
client-verify enable |
41-SSL命令 |
1-1 |
clock datetime |
32-系统维护与调试命令 |
1-1 |
clock summer-time |
32-系统维护与调试命令 |
1-1 |
clock timezone |
32-系统维护与调试命令 |
1-2 |
close |
1-7 |
close-mode wait |
41-SSL命令 |
1-2 |
cluster |
2-16 |
cluster enable |
2-17 |
cluster switch-to |
2-18 |
cluster-mac |
2-18 |
cluster-mac syn-interval |
2-19 |
command-alias enable |
32-系统维护与调试命令 |
1-9 |
command-alias mapping |
32-系统维护与调试命令 |
1-10 |
command-privilege level |
01-登录交换机命令 |
3-1 |
common-name |
40-PKI命令 |
1-5 |
copy |
29-文件系统管理命令 |
1-2 |
copy configuration |
08-端口基本配置命令 |
1-2 |
copyright-info enable |
01-登录交换机命令 |
1-3 |
count |
34-HWPing命令 |
1-1 |
country |
40-PKI命令 |
1-6 |
crl check |
40-PKI命令 |
1-6 |
crl update-period |
40-PKI命令 |
1-7 |
crl url |
40-PKI命令 |
1-7 |
cut connection |
17-AAA命令 |
1-11 |
databits |
01-登录交换机命令 |
1-3 |
datafill |
34-HWPing命令 |
1-2 |
data-flow-format |
17-AAA命令 |
1-34 |
data-flow-format |
17-AAA命令 |
1-61 |
datasize |
34-HWPing命令 |
1-3 |
debugging |
32-系统维护与调试命令 |
1-7 |
delete |
29-文件系统管理命令 |
1-2 |
delete |
1-8 |
delete |
1-21 |
delete static-routes all |
04-配置管理VLAN命令 |
1-1 |
delete-member |
2-20 |
description |
03-VLAN命令 |
1-1 |
description |
08-端口基本配置命令 |
1-4 |
description |
22-ACL命令 |
1-2 |
description |
34-HWPing命令 |
1-4 |
destination-ip |
34-HWPing命令 |
1-4 |
destination-port |
34-HWPing命令 |
1-5 |
dhcp enable |
21-DHCP命令 |
1-2 |
dhcp protective-down recover enable |
21-DHCP命令 |
3-1 |
dhcp protective-down recover interval |
21-DHCP命令 |
3-1 |
dhcp rate-limit |
21-DHCP命令 |
3-2 |
dhcp rate-limit enable |
21-DHCP命令 |
3-2 |
dhcp select global |
21-DHCP命令 |
1-3 |
dhcp select interface |
21-DHCP命令 |
1-4 |
dhcp server bims-server |
21-DHCP命令 |
1-5 |
dhcp server detect |
21-DHCP命令 |
1-6 |
dhcp server dns-list |
21-DHCP命令 |
1-7 |
dhcp server domain-name |
21-DHCP命令 |
1-7 |
dhcp server expired |
21-DHCP命令 |
1-8 |
dhcp server forbidden-ip |
21-DHCP命令 |
1-9 |
dhcp server ip-pool |
21-DHCP命令 |
1-10 |
dhcp server nbns-list |
21-DHCP命令 |
1-11 |
dhcp server netbios-type |
21-DHCP命令 |
1-12 |
dhcp server option |
21-DHCP命令 |
1-13 |
dhcp server ping |
21-DHCP命令 |
1-14 |
dhcp server relay information enable |
21-DHCP命令 |
1-14 |
dhcp server static-bind |
21-DHCP命令 |
1-15 |
dhcp server voice-config |
21-DHCP命令 |
1-16 |
dhcp-snooping |
21-DHCP命令 |
2-1 |
dhcp-snooping information enable |
21-DHCP命令 |
2-1 |
dhcp-snooping information format |
21-DHCP命令 |
2-2 |
dhcp-snooping information packet-format |
21-DHCP命令 |
2-2 |
dhcp-snooping information remote-id |
21-DHCP命令 |
2-3 |
dhcp-snooping information strategy |
21-DHCP命令 |
2-3 |
dhcp-snooping information vlan circuit-id |
21-DHCP命令 |
2-4 |
dhcp-snooping information vlan remote-id |
21-DHCP命令 |
2-5 |
dhcp-snooping trust |
21-DHCP命令 |
2-6 |
dir |
29-文件系统管理命令 |
1-4 |
dir |
1-8 |
dir |
1-21 |
disconnect |
1-9 |
display acl |
22-ACL命令 |
1-3 |
display acl remaining entry |
22-ACL命令 |
1-3 |
display am user-bind |
11-端口安全-端口绑定命令 |
2-2 |
display arp |
20-ARP命令 |
1-6 |
display arp | |
20-ARP命令 |
1-8 |
display arp count |
20-ARP命令 |
1-8 |
display arp detection statistics interface |
20-ARP命令 |
1-9 |
display arp timer aging |
20-ARP命令 |
1-10 |
display boot-loader |
29-文件系统管理命令 |
1-15 |
32-系统维护与调试命令 |
3-2 |
display bootp client |
21-DHCP命令 |
4-3 |
display brief interface |
08-端口基本配置命令 |
1-4 |
display channel |
31-信息中心命令 |
1-1 |
display clock |
32-系统维护与调试命令 |
1-5 |
display cluster |
2-21 |
display cluster base-members |
2-35 |
display cluster base-topology |
2-36 |
display cluster black-list |
2-37 |
display cluster candidates |
2-22 |
display cluster current-topology |
2-39 |
display cluster members |
2-23 |
display command-alias |
32-系统维护与调试命令 |
1-11 |
display connection |
17-AAA命令 |
1-12 |
display cpu |
32-系统维护与调试命令 |
3-2 |
display current-configuration |
02-配置文件管理命令 |
1-1 |
display current-configuration vlan |
02-配置文件管理命令 |
1-5 |
display debugging |
32-系统维护与调试命令 |
1-6 |
display device |
32-系统维护与调试命令 |
3-3 |
display dhcp client |
21-DHCP命令 |
4-1 |
display dhcp server conflict |
21-DHCP命令 |
1-17 |
display dhcp server expired |
21-DHCP命令 |
1-18 |
display dhcp server free-ip |
21-DHCP命令 |
1-19 |
display dhcp server ip-in-use |
21-DHCP命令 |
1-19 |
display dhcp server statistics |
21-DHCP命令 |
1-20 |
display dhcp server tree |
21-DHCP命令 |
1-22 |
display dhcp-snooping |
21-DHCP命令 |
2-7 |
display dhcp-snooping trust |
21-DHCP命令 |
2-7 |
display diagnostic-information |
32-系统维护与调试命令 |
1-8 |
display dldp |
12-DLDP命令 |
1-1 |
display dns domain |
36-域名解析命令 |
1-1 |
display dns dynamic-host |
36-域名解析命令 |
1-1 |
display dns ipv6 dynamic-host |
35-IPv6管理命令 |
1-1 |
display dns server |
36-域名解析命令 |
1-2 |
display domain |
17-AAA命令 |
1-14 |
display dot1x |
16-802.1x及System-Guard命令 |
1-1 |
display fib |
05-IP地址-IP性能命令 |
2-1 |
display fib | |
05-IP地址-IP性能命令 |
2-3 |
display fib acl |
05-IP地址-IP性能命令 |
2-3 |
display fib ip-address |
05-IP地址-IP性能命令 |
2-2 |
display fib statistics |
05-IP地址-IP性能命令 |
2-4 |
display ftp-server |
1-1 |
display ftp-user |
1-2 |
display garp statistics |
07-GVRP命令 |
1-1 |
display garp timer |
07-GVRP命令 |
1-2 |
display gvrp statistics |
07-GVRP命令 |
1-5 |
display gvrp status |
07-GVRP命令 |
1-6 |
display habp |
2-1 |
display habp table |
2-1 |
display habp traffic |
2-2 |
display history-command |
01-登录交换机命令 |
3-3 |
display hwping |
34-HWPing命令 |
1-6 |
display hwping statistics |
34-HWPing命令 |
1-11 |
display hwtacacs |
17-AAA命令 |
1-61 |
display icmp statistics |
05-IP地址-IP性能命令 |
2-4 |
display igmp-snooping configuration |
15-组播协议命令 |
1-1 |
display igmp-snooping group |
15-组播协议命令 |
1-1 |
display igmp-snooping statistics |
15-组播协议命令 |
1-3 |
display info-center |
31-信息中心命令 |
1-1 |
display interface |
08-端口基本配置命令 |
1-6 |
display interface Vlan-interface |
03-VLAN命令 |
1-2 |
04-配置管理VLAN命令 |
1-1 |
display ip host |
36-域名解析命令 |
1-3 |
display ip https |
42-HTTPS命令 |
1-1 |
display ip interface |
04-配置管理VLAN命令 |
1-2 |
05-IP地址-IP性能命令 |
1-1 |
display ip interface brief |
04-配置管理VLAN命令 |
1-4 |
05-IP地址-IP性能命令 |
1-2 |
display ip routing-table |
04-配置管理VLAN命令 |
1-5 |
display ip routing-table acl |
04-配置管理VLAN命令 |
1-5 |
display ip routing-table ip-address |
04-配置管理VLAN命令 |
1-7 |
display ip routing-table ip-address1 ip-address2 |
04-配置管理VLAN命令 |
1-8 |
display ip routing-table protocol |
04-配置管理VLAN命令 |
1-9 |
display ip routing-table radix |
04-配置管理VLAN命令 |
1-10 |
display ip routing-table statistics |
04-配置管理VLAN命令 |
1-11 |
display ip routing-table verbose |
04-配置管理VLAN命令 |
1-11 |
display ip socket |
05-IP地址-IP性能命令 |
2-6 |
display ip source static binding |
21-DHCP命令 |
2-8 |
display ip statistics |
05-IP地址-IP性能命令 |
2-7 |
display ipv6 fib |
35-IPv6管理命令 |
1-2 |
display ipv6 host |
35-IPv6管理命令 |
1-3 |
display ipv6 interface |
35-IPv6管理命令 |
1-4 |
display ipv6 neighbors |
35-IPv6管理命令 |
1-6 |
display ipv6 neighbors count |
35-IPv6管理命令 |
1-7 |
display ipv6 route-table |
35-IPv6管理命令 |
1-8 |
display ipv6 socket |
35-IPv6管理命令 |
1-9 |
display ipv6 statistics |
35-IPv6管理命令 |
1-11 |
display isolate port |
10-端口隔离命令 |
1-1 |
display job |
32-系统维护与调试命令 |
17 |
display lacp system-id |
09-端口汇聚命令 |
1-4 |
display link-aggregation interface |
09-端口汇聚命令 |
1-1 |
display link-aggregation summary |
09-端口汇聚命令 |
1-2 |
display link-aggregation verbose |
09-端口汇聚命令 |
1-3 |
display link-delay |
08-端口基本配置命令 |
1-9 |
display lldp local-information |
39-LLDP命令 |
1-1 |
display lldp neighbor-information |
39-LLDP命令 |
1-4 |
display lldp statistics |
39-LLDP命令 |
1-8 |
display lldp status |
39-LLDP命令 |
1-9 |
display lldp tlv-config |
39-LLDP命令 |
1-11 |
display local-server statistics |
17-AAA命令 |
1-35 |
display local-user |
17-AAA命令 |
1-15 |
display logbuffer |
31-信息中心命令 |
1-2 |
display logbuffer summary |
31-信息中心命令 |
1-3 |
display loopback-detection |
08-端口基本配置命令 |
1-10 |
display mac-address |
13-MAC地址转发表管理命令 |
1-1 |
display mac-address aging-time |
13-MAC地址转发表管理命令 |
1-1 |
display mac-address multicast static |
15-组播协议命令 |
2-1 |
display mac-address security |
11-端口安全-端口绑定命令 |
1-1 |
display mac-authentication |
18-MAC地址认证命令 |
1-1 |
display mac-vlan |
03-VLAN命令 |
1-13 |
display mac-vlan interface |
03-VLAN命令 |
1-14 |
display memory |
32-系统维护与调试命令 |
3-4 |
display mirroring-group |
24-镜像命令 |
1-1 |
display monitor-link group |
37-Smart Link-Monitor Link命令 |
2-1 |
display multicast-source-deny |
15-组播协议命令 |
2-2 |
display ndp |
2-1 |
display ntdp |
2-5 |
display ntdp device-list |
2-6 |
display ntdp single-device mac-address |
2-37 |
display ntp-service sessions |
27-NTP命令 |
1-1 |
display ntp-service status |
27-NTP命令 |
1-2 |
display ntp-service trace |
27-NTP命令 |
1-3 |
display packet-filter |
22-ACL命令 |
1-4 |
display pki certificate |
40-PKI命令 |
1-8 |
display pki certificate access-control-policy |
40-PKI命令 |
1-9 |
display pki certificate attribute-group |
40-PKI命令 |
1-10 |
display pki crl domain |
40-PKI命令 |
1-11 |
display port |
03-VLAN命令 |
1-7 |
display port combo |
08-端口基本配置命令 |
1-10 |
display port vlan-vpn |
33-VLAN-VPN命令 |
1-1 |
display port-mac |
13-MAC地址转发表管理命令 |
1-3 |
display port-security |
11-端口安全-端口绑定命令 |
1-2 |
display priority-trust |
1-1 |
display public-key local |
28-SSH命令 |
1-1 |
display public-key peer |
28-SSH命令 |
1-2 |
display qos cos-local-precedence-map |
1-2 |
display qos dscp-local-precedence-map |
1-2 |
display qos-global |
1-4 |
display qos-interface all |
1-5 |
display qos-interface line-rate |
1-6 |
display qos-interface mirrored-to |
1-6 |
display qos-interface traffic-limit |
1-7 |
display qos-interface traffic-priority |
1-8 |
display qos-interface traffic-redirect |
1-8 |
display qos-interface traffic-statistic |
1-9 |
display qos-profile |
2-2 |
display qos-vlan |
1-10 |
display queue-scheduler |
1-11 |
display radius scheme |
17-AAA命令 |
1-36 |
display radius statistics |
17-AAA命令 |
1-38 |
display rmon alarm |
26-SNMP-RMON命令 |
2-1 |
display rmon event |
26-SNMP-RMON命令 |
2-2 |
display rmon eventlog |
26-SNMP-RMON命令 |
2-3 |
display rmon history |
26-SNMP-RMON命令 |
2-4 |
display rmon prialarm |
26-SNMP-RMON命令 |
2-5 |
display rmon statistics |
26-SNMP-RMON命令 |
2-6 |
display rsa local-key-pair public |
28-SSH命令 |
1-4 |
display rsa peer-public-key |
28-SSH命令 |
1-5 |
display saved-configuration |
02-配置文件管理命令 |
1-5 |
display schedule reboot |
32-系统维护与调试命令 |
3-5 |
display smart-link flush |
1-1 |
display smart-link group |
1-2 |
display snmp-agent |
26-SNMP-RMON命令 |
1-1 |
display snmp-agent community |
26-SNMP-RMON命令 |
1-1 |
display snmp-agent group |
26-SNMP-RMON命令 |
1-2 |
display snmp-agent mib-view |
26-SNMP-RMON命令 |
1-3 |
display snmp-agent statistics |
26-SNMP-RMON命令 |
1-5 |
display snmp-agent sys-info |
26-SNMP-RMON命令 |
1-6 |
display snmp-agent trap-list |
26-SNMP-RMON命令 |
1-7 |
display snmp-agent usm-user |
26-SNMP-RMON命令 |
1-8 |
display ssh server |
28-SSH命令 |
1-6 |
display ssh server-info |
28-SSH命令 |
1-7 |
display ssh user-information |
28-SSH命令 |
1-8 |
display ssl client-policy |
41-SSL命令 |
1-3 |
display ssl server-policy |
41-SSL命令 |
1-3 |
display stacking |
1-1 |
display startup |
02-配置文件管理命令 |
1-8 |
display stop-accounting-buffer |
17-AAA命令 |
1-39 |
17-AAA命令 |
1-62 |
display storm-constrain |
08-端口基本配置命令 |
1-11 |
display stp |
14-MSTP命令 |
1-3 |
display stp abnormalport |
14-MSTP命令 |
1-7 |
display stp portdown |
14-MSTP命令 |
1-7 |
display stp region-configuration |
14-MSTP命令 |
1-8 |
display stp root |
14-MSTP命令 |
1-9 |
display system-guard attack-record |
3-1 |
display system-guard state |
3-1 |
display tcp ipv6 statistics |
35-IPv6管理命令 |
1-13 |
display tcp ipv6 status |
35-IPv6管理命令 |
1-16 |
display tcp statistics |
05-IP地址-IP性能命令 |
2-8 |
display tcp status |
05-IP地址-IP性能命令 |
2-11 |
display this |
02-配置文件管理命令 |
1-9 |
display time-range |
22-ACL命令 |
1-5 |
display transceiver alarm interface |
32-系统维护与调试命令 |
3-5 |
display transceiver diagnosis interface |
32-系统维护与调试命令 |
3-8 |
display transceiver interface |
32-系统维护与调试命令 |
3-8 |
display transceiver manuinfo interface |
32-系统维护与调试命令 |
3-10 |
display trapbuffer |
31-信息中心命令 |
1-4 |
display udp ipv6 statistics |
35-IPv6管理命令 |
1-16 |
display udp statistics |
05-IP地址-IP性能命令 |
2-11 |
display unit |
08-端口基本配置命令 |
1-12 |
display user-interface |
01-登录交换机命令 |
1-4 |
display users |
01-登录交换机命令 |
1-6 |
display version |
32-系统维护与调试命令 |
1-6 |
display vlan |
03-VLAN命令 |
1-3 |
display vlan |
06-Voice VLAN命令 |
1-3 |
display voice vlan error-info |
06-Voice VLAN命令 |
1-1 |
display voice vlan oui |
06-Voice VLAN命令 |
1-1 |
display voice vlan status |
06-Voice VLAN命令 |
1-2 |
display web package |
29-文件系统管理命令 |
1-16 |
display web users |
01-登录交换机命令 |
1-7 |
display web-authentication configuration |
19-Web认证命令 |
1-1 |
display web-authentication connection |
19-Web认证命令 |
1-2 |
dldp |
12-DLDP命令 |
1-2 |
dldp authentication-mode |
12-DLDP命令 |
1-3 |
dldp delaydown-timer |
12-DLDP命令 |
1-7 |
dldp interval |
12-DLDP命令 |
1-4 |
dldp reset |
12-DLDP命令 |
1-5 |
dldp unidirectional-shutdown |
12-DLDP命令 |
1-5 |
dldp work-mode |
12-DLDP命令 |
1-6 |
dns domain |
36-域名解析命令 |
1-4 |
dns resolve |
36-域名解析命令 |
1-4 |
dns resolve-target |
34-HWPing命令 |
1-14 |
dns server |
36-域名解析命令 |
1-5 |
dns server ipv6 |
35-IPv6管理命令 |
1-17 |
dns-list |
21-DHCP命令 |
1-23 |
dns-server |
34-HWPing命令 |
1-13 |
domain |
17-AAA命令 |
1-16 |
domain delimiter |
17-AAA命令 |
1-17 |
domain-name |
21-DHCP命令 |
1-24 |
dot1x |
1-4 |
dot1x authentication-method |
1-5 |
dot1x dhcp-launch |
1-5 |
dot1x guest-vlan |
1-6 |
dot1x handshake |
1-7 |
dot1x handshake secure |
1-8 |
dot1x mandatory-domain |
1-8 |
dot1x max-user |
1-9 |
dot1x port-control |
1-10 |
dot1x port-method |
1-10 |
dot1x quiet-period |
1-11 |
dot1x re-authenticate |
1-13 |
dot1x retry |
1-12 |
dot1x retry-version-max |
1-13 |
dot1x supp-proxy-check |
1-14 |
dot1x timer |
1-15 |
dot1x timer reauth-period |
1-17 |
dot1x version-check |
1-17 |
duplex |
08-端口基本配置命令 |
1-13 |
enable log updown |
08-端口基本配置命令 |
1-14 |
enable snmp trap updown |
26-SNMP-RMON命令 |
1-9 |
execute |
29-文件系统管理命令 |
1-5 |
exit |
1-22 |
expired |
21-DHCP命令 |
1-24 |
file prompt |
29-文件系统管理命令 |
1-6 |
filename |
34-HWPing命令 |
1-15 |
filesize |
34-HWPing命令 |
1-15 |
fixdisk |
29-文件系统管理命令 |
1-6 |
flow-control |
08-端口基本配置命令 |
1-14 |
flow-interval |
08-端口基本配置命令 |
1-15 |
flush enable control-vlan |
1-2 |
format |
29-文件系统管理命令 |
1-7 |
fqdn |
40-PKI命令 |
1-12 |
free user-interface |
01-登录交换机命令 |
1-7 |
free web-users |
01-登录交换机命令 |
2-1 |
frequency |
34-HWPing命令 |
1-16 |
ftp |
1-10 |
ftp cluster |
2-25 |
ftp disconnect |
1-2 |
ftp server enable |
1-3 |
ftp timeout |
1-4 |
ftp-operation |
34-HWPing命令 |
1-17 |
ftp-server |
2-26 |
garp timer |
07-GVRP命令 |
1-3 |
garp timer leaveall |
07-GVRP命令 |
1-4 |
gateway-list |
21-DHCP命令 |
1-25 |
get |
1-10 |
get |
1-23 |
gratuitous-arp-learning enable |
20-ARP命令 |
1-10 |
gvrp |
07-GVRP命令 |
1-6 |
gvrp registration |
07-GVRP命令 |
1-7 |
habp enable |
2-3 |
habp server vlan |
2-3 |
habp timer |
2-4 |
handshake timeout |
41-SSL命令 |
1-4 |
header |
01-登录交换机命令 |
1-8 |
help |
1-23 |
history keep-time |
34-HWPing命令 |
1-17 |
history-command max-size |
01-登录交换机命令 |
1-10 |
history-record enable |
34-HWPing命令 |
1-18 |
history-records |
34-HWPing命令 |
1-18 |
holdtime |
2-27 |
http-operation |
34-HWPing命令 |
1-19 |
http-string |
34-HWPing命令 |
1-19 |
hwping |
34-HWPing命令 |
1-20 |
hwping-agent clear |
34-HWPing命令 |
1-21 |
hwping-agent enable |
34-HWPing命令 |
1-21 |
hwping-agent max-requests |
34-HWPing命令 |
1-22 |
hwping-server enable |
34-HWPing命令 |
1-35 |
hwping-server tcpconnect |
34-HWPing命令 |
1-35 |
hwping-server udpecho |
34-HWPing命令 |
1-36 |
hwtacacs nas-ip |
17-AAA命令 |
1-63 |
hwtacacs scheme |
17-AAA命令 |
1-63 |
icmp redirect send |
05-IP地址-IP性能命令 |
2-12 |
icmp unreach send |
05-IP地址-IP性能命令 |
2-13 |
idle-cut |
17-AAA命令 |
1-18 |
idle-timeout |
01-登录交换机命令 |
1-10 |
igmp host-join |
15-组播协议命令 |
1-14 |
igmp-snooping |
15-组播协议命令 |
1-4 |
igmp-snooping access-policy |
15-组播协议命令 |
1-4 |
igmp-snooping fast-leave |
15-组播协议命令 |
1-5 |
igmp-snooping general-query source-ip |
15-组播协议命令 |
1-6 |
igmp-snooping group-limit |
15-组播协议命令 |
1-7 |
igmp-snooping group-policy |
15-组播协议命令 |
1-7 |
igmp-snooping host-aging-time |
15-组播协议命令 |
1-9 |
igmp-snooping nonflooding-enable |
15-组播协议命令 |
1-9 |
igmp-snooping querier |
15-组播协议命令 |
1-10 |
igmp-snooping query-interval |
15-组播协议命令 |
1-11 |
igmp-snooping router-aging-time |
15-组播协议命令 |
1-11 |
igmp-snooping special-query source-ip |
15-组播协议命令 |
1-12 |
igmp-snooping version |
15-组播协议命令 |
1-13 |
igmp-snooping vlan-mapping |
15-组播协议命令 |
1-13 |
info-center channel name |
31-信息中心命令 |
1-5 |
info-center console channel |
31-信息中心命令 |
1-5 |
info-center enable |
31-信息中心命令 |
1-6 |
info-center logbuffer |
31-信息中心命令 |
1-7 |
info-center loghost |
31-信息中心命令 |
1-7 |
info-center loghost source |
31-信息中心命令 |
1-8 |
info-center monitor channel |
31-信息中心命令 |
1-9 |
info-center snmp channel |
31-信息中心命令 |
1-9 |
info-center source |
31-信息中心命令 |
1-10 |
info-center synchronous |
31-信息中心命令 |
1-12 |
info-center timestamp |
31-信息中心命令 |
1-13 |
info-center timestamp loghost |
31-信息中心命令 |
1-13 |
info-center timestamp utc |
31-信息中心命令 |
1-14 |
info-center trapbuffer |
31-信息中心命令 |
1-15 |
instance |
14-MSTP命令 |
1-10 |
interface |
08-端口基本配置命令 |
1-16 |
03-VLAN命令 |
1-4 |
04-配置管理VLAN命令 |
1-12 |
ip (Pki Entity view) |
40-PKI命令 |
1-13 |
ip address |
04-配置管理VLAN命令 |
1-13 |
ip address |
05-IP地址-IP性能命令 |
1-3 |
ip address bootp-alloc |
21-DHCP命令 |
4-3 |
ip address dhcp-alloc |
21-DHCP命令 |
4-2 |
ip check dot1x enable |
38-ARP和IP攻击防御命令 |
4 |
ip check source ip-address |
21-DHCP命令 |
2-8 |
ip host |
36-域名解析命令 |
1-5 |
ip http acl |
01-登录交换机命令 |
2-2 |
ip http shutdown |
01-登录交换机命令 |
1-11 |
ip https acl |
42-HTTPS命令 |
1-1 |
ip https certificate access-control-policy |
42-HTTPS命令 |
1-2 |
ip https enable |
42-HTTPS命令 |
1-3 |
ip https ssl-server-policy |
42-HTTPS命令 |
1-3 |
ip route-static |
04-配置管理VLAN命令 |
1-13 |
21-DHCP命令 |
2-9 |
ip source static import dot1x |
38-ARP和IP攻击防御命令 |
3 |
ip-pool |
2-27 |
ipv6 address |
35-IPv6管理命令 |
1-18 |
ipv6 address auto link-local |
35-IPv6管理命令 |
1-18 |
ipv6 address eui-64 |
35-IPv6管理命令 |
1-19 |
ipv6 address link-local |
35-IPv6管理命令 |
1-20 |
ipv6 host |
35-IPv6管理命令 |
1-21 |
ipv6 icmp-error |
35-IPv6管理命令 |
1-21 |
ipv6 nd dad attempts |
35-IPv6管理命令 |
1-22 |
ipv6 nd hop-limit |
35-IPv6管理命令 |
1-22 |
ipv6 nd ns retrans-timer |
35-IPv6管理命令 |
1-23 |
ipv6 nd nud reachable-time |
35-IPv6管理命令 |
1-23 |
ipv6 neighbor |
35-IPv6管理命令 |
1-24 |
ipv6 neighbors max-learning-num |
35-IPv6管理命令 |
1-25 |
ipv6 route-static |
35-IPv6管理命令 |
1-25 |
jitter-interval |
34-HWPing命令 |
1-22 |
jitter-packetnum |
34-HWPing命令 |
1-23 |
job |
32-系统维护与调试命令 |
17 |
key |
17-AAA命令 |
1-40 |
key |
17-AAA命令 |
1-64 |
lacp enable |
09-端口汇聚命令 |
1-4 |
lacp port-priority |
09-端口汇聚命令 |
1-5 |
lacp system-priority |
09-端口汇聚命令 |
1-5 |
lcd |
1-11 |
ldap-server |
40-PKI命令 |
1-13 |
level |
17-AAA命令 |
1-19 |
line-rate |
1-11 |
link-aggregation group |
1-3 |
2-1 |
link-aggregation group description |
09-端口汇聚命令 |
1-6 |
link-aggregation group mode |
09-端口汇聚命令 |
1-7 |
link-delay |
08-端口基本配置命令 |
1-16 |
lldp admin-status |
39-LLDP命令 |
1-13 |
lldp check-change-interval |
39-LLDP命令 |
1-13 |
lldp compliance admin-status cdp |
39-LLDP命令 |
1-14 |
lldp compliance cdp |
39-LLDP命令 |
1-14 |
lldp enable |
39-LLDP命令 |
1-15 |
lldp encapsulation snap |
39-LLDP命令 |
1-15 |
lldp fast-count |
39-LLDP命令 |
1-16 |
lldp hold-multiplier |
39-LLDP命令 |
1-16 |
lldp management-address-tlv |
39-LLDP命令 |
1-17 |
lldp notification remote-change enable |
39-LLDP命令 |
1-18 |
lldp timer notification-interval |
39-LLDP命令 |
1-18 |
lldp timer reinit-delay |
39-LLDP命令 |
1-19 |
lldp timer tx-delay |
39-LLDP命令 |
1-19 |
lldp timer tx-interval |
39-LLDP命令 |
1-20 |
lldp tlv-enable |
39-LLDP命令 |
1-20 |
locality |
40-PKI命令 |
1-14 |
local-server |
17-AAA命令 |
1-41 |
local-server nas-ip |
17-AAA命令 |
1-42 |
local-user |
17-AAA命令 |
1-19 |
local-user password-display-mode |
17-AAA命令 |
1-20 |
lock |
01-登录交换机命令 |
1-12 |
logging-host |
2-28 |
loopback |
08-端口基本配置命令 |
1-17 |
loopback-detection control enable |
08-端口基本配置命令 |
1-17 |
loopback-detection enable |
08-端口基本配置命令 |
1-18 |
loopback-detection interface-list enable |
08-端口基本配置命令 |
1-19 |
loopback-detection interval-time |
08-端口基本配置命令 |
1-20 |
loopback-detection per-vlan enable |
08-端口基本配置命令 |
1-20 |
loopback-detection shutdown enable |
08-端口基本配置命令 |
1-21 |
ls |
1-11 |
ls |
1-24 |
mac-address |
13-MAC地址转发表管理命令 |
1-3 |
mac-address max-mac-count |
13-MAC地址转发表管理命令 |
1-5 |
mac-address multicast interface |
15-组播协议命令 |
2-2 |
mac-address multicast vlan |
15-组播协议命令 |
2-3 |
11-端口安全-端口绑定命令 |
1-5 |
mac-address timer |
13-MAC地址转发表管理命令 |
1-5 |
18-MAC地址认证命令 |
1-3 |
mac-authentication authmode usernameasmacaddress |
18-MAC地址认证命令 |
1-4 |
mac-authentication authmode usernamefixed |
18-MAC地址认证命令 |
1-5 |
mac-authentication authpassword |
18-MAC地址认证命令 |
1-5 |
mac-authentication authusername |
18-MAC地址认证命令 |
1-6 |
mac-authentication domain |
18-MAC地址认证命令 |
1-6 |
mac-authentication guest-vlan |
18-MAC地址认证命令 |
1-9 |
mac-authentication interface |
18-MAC地址认证命令 |
1-3 |
mac-authentication max-auth-num |
18-MAC地址认证命令 |
1-11 |
mac-authentication timer |
18-MAC地址认证命令 |
1-7 |
mac-authentication timer guest-vlan-reauth |
18-MAC地址认证命令 |
1-11 |
mac-authentication timer offline-detect |
18-MAC地址认证命令 |
1-8 |
mac-authenticiaon intrusion-mode block-mac |
18-MAC地址认证命令 |
1-10 |
mac-vlan enable |
03-VLAN命令 |
1-14 |
mac-vlan mac-address |
03-VLAN命令 |
1-15 |
management-vlan |
04-配置管理VLAN命令 |
1-14 |
management-vlan |
2-29 |
mdi |
08-端口基本配置命令 |
1-22 |
messenger |
17-AAA命令 |
1-21 |
mirrored-to |
1-12 |
mirrored-to vlan |
1-13 |
mirroring-group |
24-镜像命令 |
1-2 |
mirroring-group mirroring-port |
24-镜像命令 |
1-3 |
mirroring-group monitor-port |
24-镜像命令 |
1-3 |
mirroring-group reflector-port |
24-镜像命令 |
1-4 |
mirroring-group remote-probe vlan |
24-镜像命令 |
1-5 |
mirroring-port |
24-镜像命令 |
1-5 |
mkdir |
29-文件系统管理命令 |
1-7 |
mkdir |
1-12 |
mkdir |
1-24 |
2-2 |
monitor-port |
24-镜像命令 |
1-6 |
more |
29-文件系统管理命令 |
1-8 |
move |
29-文件系统管理命令 |
1-9 |
multicast static-group interface |
15-组播协议命令 |
1-14 |
multicast static-group vlan |
15-组播协议命令 |
1-15 |
multicast static-router-port |
15-组播协议命令 |
1-16 |
multicast static-router-port vlan |
15-组播协议命令 |
1-16 |
15-组播协议命令 |
2-3 |
multicast-suppression |
08-端口基本配置命令 |
1-22 |
name |
03-VLAN命令 |
1-5 |
name |
17-AAA命令 |
1-22 |
nas-ip |
17-AAA命令 |
1-42 |
nas-ip |
17-AAA命令 |
1-65 |
nbns-list |
21-DHCP命令 |
1-25 |
ndp enable |
2-2 |
ndp timer aging |
2-3 |
ndp timer hello |
2-4 |
netbios-type |
21-DHCP命令 |
1-26 |
network |
21-DHCP命令 |
1-27 |
nslookup type |
36-域名解析命令 |
1-6 |
ntdp enable |
2-8 |
ntdp explore |
2-9 |
ntdp hop |
2-9 |
ntdp timer |
2-10 |
ntdp timer hop-delay |
2-10 |
ntdp timer port-delay |
2-11 |
ntp-service access |
27-NTP命令 |
1-4 |
ntp-service authentication enable |
27-NTP命令 |
1-5 |
ntp-service authentication-keyid |
27-NTP命令 |
1-5 |
ntp-service broadcast-client |
27-NTP命令 |
1-6 |
ntp-service broadcast-server |
27-NTP命令 |
1-7 |
ntp-service in-interface disable |
27-NTP命令 |
1-7 |
ntp-service max-dynamic-sessions |
27-NTP命令 |
1-8 |
ntp-service multicast-client |
27-NTP命令 |
1-8 |
ntp-service multicast-server |
27-NTP命令 |
1-9 |
ntp-service reliable authentication-keyid |
27-NTP命令 |
1-9 |
ntp-service source-interface |
27-NTP命令 |
1-10 |
ntp-service unicast-peer |
27-NTP命令 |
1-11 |
ntp-service unicast-server |
27-NTP命令 |
1-12 |
open |
1-13 |
option |
21-DHCP命令 |
1-27 |
organization |
40-PKI命令 |
1-14 |
organization-unit |
40-PKI命令 |
1-15 |
packet-filter |
22-ACL命令 |
1-6 |
packet-filter |
2-3 |
packet-filter vlan |
22-ACL命令 |
1-7 |
parity |
01-登录交换机命令 |
1-12 |
passive |
1-14 |
password |
17-AAA命令 |
1-22 |
password |
34-HWPing命令 |
1-24 |
peer-public-key end |
28-SSH命令 |
1-9 |
ping |
32-系统维护与调试命令 |
2-1 |
ping ipv6 |
35-IPv6管理命令 |
2-1 |
40-PKI命令 |
1-15 |
40-PKI命令 |
1-16 |
pki delete-certificate |
40-PKI命令 |
1-16 |
pki domain |
40-PKI命令 |
1-17 |
pki entity |
40-PKI命令 |
1-17 |
pki import-certificate |
40-PKI命令 |
1-18 |
pki request-certificate domain |
40-PKI命令 |
1-19 |
pki retrieval-certificate |
40-PKI命令 |
1-19 |
pki retrieval-crl domain |
40-PKI命令 |
1-20 |
pki validate-certificate |
40-PKI命令 |
1-20 |
pki-domain |
41-SSL命令 |
1-5 |
port |
03-VLAN命令 |
1-8 |
port |
1-4 |
port |
2-3 |
port access vlan |
03-VLAN命令 |
1-8 |
port auto-power-down |
32-系统维护与调试命令 |
3-10 |
port hybrid pvid vlan |
03-VLAN命令 |
1-9 |
port hybrid vlan |
03-VLAN命令 |
1-10 |
port isolate |
10-端口隔离命令 |
1-1 |
port link-aggregation group |
09-端口汇聚命令 |
1-7 |
port link-type |
03-VLAN命令 |
1-10 |
port monitor-link group |
2-4 |
port smart-link group |
1-4 |
port trunk permit vlan |
03-VLAN命令 |
1-11 |
port trunk pvid vlan |
03-VLAN命令 |
1-12 |
port-mac |
13-MAC地址转发表管理命令 |
1-6 |
port-security authorization ignore |
11-端口安全-端口绑定命令 |
1-6 |
port-security enable |
11-端口安全-端口绑定命令 |
1-6 |
port-security guest-vlan |
11-端口安全-端口绑定命令 |
1-7 |
port-security intrusion-mode |
11-端口安全-端口绑定命令 |
1-8 |
port-security max-mac-count |
11-端口安全-端口绑定命令 |
1-10 |
port-security ntk-mode |
11-端口安全-端口绑定命令 |
1-11 |
port-security oui |
11-端口安全-端口绑定命令 |
1-12 |
port-security port-mode |
11-端口安全-端口绑定命令 |
1-13 |
port-security timer autolearn |
11-端口安全-端口绑定命令 |
1-15 |
port-security timer disableport |
11-端口安全-端口绑定命令 |
1-16 |
port-security timer guest-vlan-reauth |
11-端口安全-端口绑定命令 |
1-16 |
port-security trap |
11-端口安全-端口绑定命令 |
1-17 |
prefer-cipher |
41-SSL命令 |
1-6 |
primary accounting |
17-AAA命令 |
1-43 |
17-AAA命令 |
1-65 |
primary authentication |
17-AAA命令 |
1-44 |
17-AAA命令 |
1-66 |
primary authorization |
17-AAA命令 |
1-67 |
priority |
1-14 |
priority trust |
1-15 |
priority-trust |
1-16 |
probe-failtimes |
34-HWPing命令 |
1-24 |
protocol inbound |
01-登录交换机命令 |
1-13 |
protocol inbound |
28-SSH命令 |
1-9 |
public-key local create |
28-SSH命令 |
1-10 |
public-key local destroy |
28-SSH命令 |
1-12 |
public-key local export dsa |
28-SSH命令 |
1-14 |
public-key local export rsa |
28-SSH命令 |
1-13 |
public-key peer |
28-SSH命令 |
1-16 |
public-key peer import sshkey |
28-SSH命令 |
1-16 |
public-key-code begin |
28-SSH命令 |
1-17 |
public-key-code end |
28-SSH命令 |
1-18 |
put |
1-14 |
put |
1-25 |
pwd |
29-文件系统管理命令 |
1-10 |
pwd |
1-15 |
pwd |
1-25 |
1-17 |
1-18 |
qos-profile |
2-4 |
qos-profile port-based |
2-4 |
queue-scheduler |
1-20 |
quit |
1-15 |
quit |
1-26 |
quit |
32-系统维护与调试命令 |
1-3 |
radius client |
17-AAA命令 |
1-45 |
radius nas-ip |
17-AAA命令 |
1-46 |
radius scheme |
17-AAA命令 |
1-47 |
radius trap |
17-AAA命令 |
1-48 |
radius-scheme |
17-AAA命令 |
1-23 |
reboot |
32-系统维护与调试命令 |
3-11 |
reboot member |
2-30 |
region-name |
14-MSTP命令 |
1-10 |
remotehelp |
1-16 |
remote-probe vlan enable |
24-镜像命令 |
1-7 |
remove |
1-26 |
rename |
29-文件系统管理命令 |
1-10 |
rename |
1-16 |
rename |
1-27 |
reset arp |
20-ARP命令 |
1-11 |
reset counters interface |
08-端口基本配置命令 |
1-23 |
reset dhcp server conflict |
21-DHCP命令 |
1-28 |
reset dhcp server ip-in-use |
21-DHCP命令 |
1-28 |
reset dhcp server statistics |
21-DHCP命令 |
1-29 |
reset dhcp-snooping |
21-DHCP命令 |
2-10 |
reset dns dynamic-host |
36-域名解析命令 |
1-7 |
reset dns ipv6 dynamic-host |
35-IPv6管理命令 |
1-26 |
reset dot1x statistics |
1-18 |
reset garp statistics |
07-GVRP命令 |
1-5 |
reset hwtacacs statistics |
17-AAA命令 |
1-68 |
reset igmp-snooping statistics |
15-组播协议命令 |
1-17 |
reset ip routing-table statistics protocol |
04-配置管理VLAN命令 |
1-15 |
reset ip statistics |
05-IP地址-IP性能命令 |
2-13 |
reset ipv6 neighbors |
35-IPv6管理命令 |
1-26 |
reset ipv6 statistics |
35-IPv6管理命令 |
1-27 |
reset lacp statistics |
09-端口汇聚命令 |
1-8 |
reset logbuffer |
31-信息中心命令 |
1-15 |
reset mac-authentication |
18-MAC地址认证命令 |
1-8 |
reset ndp statistics |
2-4 |
reset radius statistics |
17-AAA命令 |
1-48 |
reset recycle-bin |
29-文件系统管理命令 |
1-10 |
reset saved-configuration |
02-配置文件管理命令 |
1-10 |
reset smart-link packets counter |
1-5 |
reset stop-accounting-buffer |
17-AAA命令 |
1-49 |
17-AAA命令 |
1-68 |
reset stp |
14-MSTP命令 |
1-11 |
reset tcp ipv6 statistics |
35-IPv6管理命令 |
1-27 |
reset tcp statistics |
05-IP地址-IP性能命令 |
2-14 |
reset traffic-limit |
1-21 |
reset traffic-limit vlan |
1-22 |
reset traffic-statistic |
1-22 |
reset traffic-statistic vlan |
1-23 |
reset trapbuffer |
31-信息中心命令 |
1-16 |
reset udp ipv6 statistics |
35-IPv6管理命令 |
1-28 |
reset udp statistics |
05-IP地址-IP性能命令 |
2-14 |
retry |
17-AAA命令 |
1-49 |
retry realtime-accounting |
17-AAA命令 |
1-50 |
retry stop-accounting |
17-AAA命令 |
1-51 |
17-AAA命令 |
1-69 |
return |
32-系统维护与调试命令 |
1-4 |
revision-level |
14-MSTP命令 |
1-12 |
rmdir |
29-文件系统管理命令 |
1-12 |
rmdir |
1-17 |
rmdir |
1-27 |
rmon alarm |
26-SNMP-RMON命令 |
2-7 |
rmon event |
26-SNMP-RMON命令 |
2-9 |
rmon history |
26-SNMP-RMON命令 |
2-10 |
rmon prialarm |
26-SNMP-RMON命令 |
2-10 |
rmon statistics |
26-SNMP-RMON命令 |
2-12 |
root-certificate fingerprint |
40-PKI命令 |
1-21 |
rsa local-key-pair create |
28-SSH命令 |
1-18 |
rsa local-key-pair destroy |
28-SSH命令 |
1-20 |
28-SSH命令 |
1-21 |
rsa peer-public-key import sshkey |
28-SSH命令 |
1-21 |
rule (Pki Cert Acp view) |
40-PKI命令 |
1-22 |
rule comment |
22-ACL命令 |
1-17 |
rule(二层ACL) |
22-ACL命令 |
1-15 |
rule(高级ACL) |
22-ACL命令 |
1-10 |
rule(基本ACL) |
22-ACL命令 |
1-8 |
save |
02-配置文件管理命令 |
1-10 |
schedule reboot at |
32-系统维护与调试命令 |
3-12 |
schedule reboot delay |
32-系统维护与调试命令 |
3-13 |
schedule reboot regularity |
32-系统维护与调试命令 |
3-14 |
scheme |
17-AAA命令 |
1-24 |
scheme lan-access |
17-AAA命令 |
1-25 |
scheme login |
17-AAA命令 |
1-26 |
screen-length |
01-登录交换机命令 |
1-14 |
secondary accounting |
17-AAA命令 |
1-52 |
17-AAA命令 |
1-69 |
secondary authentication |
17-AAA命令 |
1-53 |
17-AAA命令 |
1-70 |
secondary authorization |
17-AAA命令 |
1-70 |
self-service-url |
17-AAA命令 |
1-27 |
send |
01-登录交换机命令 |
1-14 |
sendpacket passroute |
34-HWPing命令 |
1-25 |
send-trap |
34-HWPing命令 |
1-25 |
server-type |
17-AAA命令 |
1-54 |
service-type |
01-登录交换机命令 |
1-15 |
service-type |
17-AAA命令 |
1-27 |
service-type multicast |
15-组播协议命令 |
1-17 |
session |
41-SSL命令 |
1-6 |
set authentication password |
01-登录交换机命令 |
1-16 |
sftp |
1-28 |
sftp server enable |
1-18 |
sftp timeout |
1-19 |
shell |
01-登录交换机命令 |
1-17 |
shutdown |
03-VLAN命令 |
1-5 |
shutdown |
08-端口基本配置命令 |
1-24 |
smart-link flush enable control-vlan |
1-5 |
smart-link group |
1-6 |
smart-link group |
2-4 |
snmp-agent |
26-SNMP-RMON命令 |
1-10 |
snmp-agent calculate-password |
26-SNMP-RMON命令 |
1-10 |
01-登录交换机命令 |
2-2 |
26-SNMP-RMON命令 |
1-11 |
snmp-agent group |
01-登录交换机命令 |
2-3 |
snmp-agent group |
26-SNMP-RMON命令 |
1-12 |
snmp-agent local-engineid |
26-SNMP-RMON命令 |
1-14 |
snmp-agent log |
26-SNMP-RMON命令 |
1-14 |
26-SNMP-RMON命令 |
1-15 |
snmp-agent packet max-size |
26-SNMP-RMON命令 |
1-17 |
26-SNMP-RMON命令 |
1-17 |
snmp-agent target-host |
26-SNMP-RMON命令 |
1-18 |
snmp-agent trap enable |
26-SNMP-RMON命令 |
1-19 |
snmp-agent trap ifmib |
26-SNMP-RMON命令 |
1-20 |
snmp-agent trap life |
26-SNMP-RMON命令 |
1-21 |
snmp-agent trap queue-size |
26-SNMP-RMON命令 |
1-21 |
snmp-agent trap source |
26-SNMP-RMON命令 |
1-22 |
01-登录交换机命令 |
2-4 |
snmp-agent usm-user { v1 | v2c } |
26-SNMP-RMON命令 |
1-23 |
snmp-agent usm-user v3 |
26-SNMP-RMON命令 |
1-24 |
snmp-host |
2-31 |
source-interface |
34-HWPing命令 |
1-26 |
source-ip |
34-HWPing命令 |
1-27 |
source-port |
34-HWPing命令 |
1-27 |
speed |
01-登录交换机命令 |
1-18 |
speed |
08-端口基本配置命令 |
1-24 |
speed auto |
08-端口基本配置命令 |
1-25 |
ssh authentication-type default |
28-SSH命令 |
1-22 |
ssh client assign |
28-SSH命令 |
1-23 |
ssh client first-time enable |
28-SSH命令 |
1-24 |
ssh server authentication-retries |
28-SSH命令 |
1-25 |
ssh server compatible-ssh1x enable |
28-SSH命令 |
1-25 |
ssh server rekey-interval |
28-SSH命令 |
1-26 |
ssh server timeout |
28-SSH命令 |
1-26 |
ssh user |
28-SSH命令 |
1-27 |
ssh user assign |
28-SSH命令 |
1-28 |
ssh user authentication-type |
28-SSH命令 |
1-29 |
ssh user service-type |
28-SSH命令 |
1-30 |
ssh2 |
28-SSH命令 |
1-31 |
ssl client-policy |
41-SSL命令 |
1-7 |
ssl server-policy |
41-SSL命令 |
1-8 |
stacking |
1-3 |
stacking enable |
1-3 |
stacking ip-pool |
1-4 |
stack-port enable |
1-2 |
startup bootrom-access enable |
29-文件系统管理命令 |
1-16 |
startup saved-configuration |
02-配置文件管理命令 |
1-12 |
state |
17-AAA命令 |
1-28 |
state |
40-PKI命令 |
1-22 |
state primary |
17-AAA命令 |
1-54 |
state secondary |
17-AAA命令 |
1-55 |
static-bind client-identifier |
21-DHCP命令 |
1-29 |
static-bind ip-address |
21-DHCP命令 |
1-30 |
static-bind mac-address |
21-DHCP命令 |
1-31 |
statistics |
34-HWPing命令 |
1-28 |
statistics keep-time |
34-HWPing命令 |
1-29 |
stop-accounting-buffer enable |
17-AAA命令 |
1-56 |
stopbits |
01-登录交换机命令 |
1-18 |
storm-constrain |
08-端口基本配置命令 |
1-25 |
storm-constrain control |
08-端口基本配置命令 |
1-26 |
storm-constrain enable |
08-端口基本配置命令 |
1-27 |
storm-constrain interval |
08-端口基本配置命令 |
1-27 |
stp |
14-MSTP命令 |
1-12 |
stp bpdu-protection |
14-MSTP命令 |
1-14 |
stp bridge-diameter |
14-MSTP命令 |
1-14 |
stp compliance |
14-MSTP命令 |
1-15 |
stp config-digest-snooping |
14-MSTP命令 |
1-16 |
stp cost |
14-MSTP命令 |
1-18 |
stp dot1d-trap |
14-MSTP命令 |
1-19 |
stp edged-port |
14-MSTP命令 |
1-20 |
stp loop-protection |
14-MSTP命令 |
1-22 |
stp max-hops |
14-MSTP命令 |
1-23 |
stp mcheck |
14-MSTP命令 |
1-24 |
stp mode |
14-MSTP命令 |
1-25 |
stp no-agreement-check |
14-MSTP命令 |
1-25 |
stp pathcost-standard |
14-MSTP命令 |
1-27 |
stp point-to-point |
14-MSTP命令 |
1-28 |
stp port priority |
14-MSTP命令 |
1-29 |
stp portlog |
14-MSTP命令 |
1-30 |
stp portlog all |
14-MSTP命令 |
1-31 |
stp priority |
14-MSTP命令 |
1-31 |
14-MSTP命令 |
1-32 |
stp root primary |
14-MSTP命令 |
1-33 |
stp root secondary |
14-MSTP命令 |
1-34 |
stp root-protection |
14-MSTP命令 |
1-35 |
stp tc-protection |
14-MSTP命令 |
1-36 |
stp tc-protection threshold |
14-MSTP命令 |
1-37 |
stp timer forward-delay |
14-MSTP命令 |
1-37 |
stp timer hello |
14-MSTP命令 |
1-38 |
stp timer max-age |
14-MSTP命令 |
1-39 |
stp timer-factor |
14-MSTP命令 |
1-40 |
stp transmit-limit |
14-MSTP命令 |
1-40 |
super |
01-登录交换机命令 |
3-4 |
super authentication-mode |
01-登录交换机命令 |
3-5 |
super password |
01-登录交换机命令 |
3-5 |
sysname |
32-系统维护与调试命令 |
1-4 |
system-guard detect-threshold |
3-2 |
system-guard enable |
3-3 |
system-guard permit |
3-3 |
system-guard timer-interval |
3-4 |
system-monitor enable |
32-系统维护与调试命令 |
3-14 |
system-view |
32-系统维护与调试命令 |
1-5 |
tcp ipv6 timer fin-timeout |
35-IPv6管理命令 |
1-28 |
tcp ipv6 timer syn-timeout |
35-IPv6管理命令 |
1-28 |
tcp ipv6 window |
35-IPv6管理命令 |
1-29 |
tcp timer fin-timeout |
05-IP地址-IP性能命令 |
2-15 |
tcp timer syn-timeout |
05-IP地址-IP性能命令 |
2-15 |
tcp window |
05-IP地址-IP性能命令 |
2-16 |
telnet |
01-登录交换机命令 |
1-19 |
telnet ipv6 |
01-登录交换机命令 |
1-20 |
telnet ipv6 |
35-IPv6管理命令 |
2-2 |
terminal debugging |
31-信息中心命令 |
1-16 |
32-系统维护与调试命令 |
1-9 |
terminal logging |
31-信息中心命令 |
1-17 |
terminal monitor |
31-信息中心命令 |
1-17 |
terminal trapping |
31-信息中心命令 |
1-18 |
test-enable |
34-HWPing命令 |
1-31 |
test-failtimes |
34-HWPing命令 |
1-32 |
test-time begin |
34-HWPing命令 |
1-29 |
test-type |
34-HWPing命令 |
1-30 |
tftp { ascii | binary } |
2-1 |
tftp get |
2-32 |
tftp get |
2-1 |
tftp ipv6 |
35-IPv6管理命令 |
2-3 |
tftp put |
2-32 |
tftp put |
2-2 |
tftp-server |
2-33 |
tftp-server acl |
2-3 |
time at |
32-系统维护与调试命令 |
18 |
time delay |
32-系统维护与调试命令 |
19 |
timeout |
34-HWPing命令 |
1-32 |
timer |
17-AAA命令 |
1-57 |
timer |
2-34 |
timer quiet |
17-AAA命令 |
1-57 |
timer quiet |
17-AAA命令 |
1-71 |
timer realtime-accounting |
17-AAA命令 |
1-58 |
17-AAA命令 |
1-72 |
timer response-timeout |
17-AAA命令 |
1-59 |
17-AAA命令 |
1-73 |
time-range |
22-ACL命令 |
1-18 |
topology accept |
2-40 |
topology restore-from |
2-41 |
topology save-to |
2-41 |
tos |
34-HWPing命令 |
1-33 |
tracemac |
2-29 |
tracert |
32-系统维护与调试命令 |
2-2 |
tracert ipv6 |
35-IPv6管理命令 |
2-4 |
traffic-limit |
1-23 |
traffic-limit |
2-5 |
1-24 |
traffic-priority |
1-25 |
traffic-priority |
2-6 |
traffic-priority vlan |
1-26 |
traffic-redirect |
1-27 |
traffic-redirect vlan |
1-28 |
traffic-statistic |
1-29 |
1-30 |
ttl |
34-HWPing命令 |
1-33 |
undelete |
29-文件系统管理命令 |
1-13 |
unknown-multicast drop enable |
15-组播协议命令 |
2-4 |
user |
1-17 |
user privilege level |
01-登录交换机命令 |
1-21 |
user-interface |
01-登录交换机命令 |
1-20 |
username |
34-HWPing命令 |
1-34 |
user-name-format |
17-AAA命令 |
1-60 |
user-name-format |
17-AAA命令 |
1-73 |
verbose |
1-18 |
version |
41-SSL命令 |
1-8 |
view |
32-系统维护与调试命令 |
20 |
virtual-cable-test |
08-端口基本配置命令 |
1-28 |
vlan |
03-VLAN命令 |
1-6 |
vlan-assignment-mode |
17-AAA命令 |
1-29 |
vlan-mapping modulo |
14-MSTP命令 |
1-41 |
vlan-vpn enable |
33-VLAN-VPN命令 |
1-1 |
vlan-vpn tunnel |
14-MSTP命令 |
1-42 |
voice vlan |
06-Voice VLAN命令 |
1-3 |
voice vlan aging |
06-Voice VLAN命令 |
1-4 |
voice vlan enable |
06-Voice VLAN命令 |
1-5 |
voice vlan legacy |
06-Voice VLAN命令 |
1-6 |
voice vlan mac-address |
06-Voice VLAN命令 |
1-6 |
voice vlan mode |
06-Voice VLAN命令 |
1-7 |
voice vlan security enable |
06-Voice VLAN命令 |
1-8 |
voice-config |
21-DHCP命令 |
1-31 |
web-authentication customize |
19-Web认证命令 |
1-3 |
web-authentication cut connection |
19-Web认证命令 |
1-5 |
web-authentication domain |
19-Web认证命令 |
1-6 |
web-authentication enable |
19-Web认证命令 |
1-6 |
web-authentication free-ip |
19-Web认证命令 |
1-7 |
web-authentication free-user interface |
19-Web认证命令 |
1-8 |
web-authentication max-connection |
19-Web认证命令 |
1-9 |
web-authentication move-mode |
19-Web认证命令 |
1-9 |
web-authentication protocol |
19-Web认证命令 |
1-10 |
web-authentication select method |
19-Web认证命令 |
1-11 |
web-authentication timer idle-cut |
19-Web认证命令 |
1-12 |
web-authentication timer max-online |
19-Web认证命令 |
1-12 |
web-authentication web-proxy port |
19-Web认证命令 |
1-13 |
web-authentication web-server |
19-Web认证命令 |
1-14 |
xmodem get |
32-系统维护与调试命令 |
3-15 |
