02-MPLS TE命令
本章节下载 (440.41 KB)
1.1.2 debugging isis traffic-eng
1.1.5 debugging mpls te management
1.1.9 display isis traffic-eng advertisements
1.1.10 display isis traffic-eng link
1.1.11 display isis traffic-eng network
1.1.12 display isis traffic-eng statistics
1.1.14 display mpls rsvp-te established
1.1.15 display mpls rsvp-te peer
1.1.16 display mpls rsvp-te psb-content
1.1.17 display mpls rsvp-te request
1.1.18 display mpls rsvp-te reservation
1.1.19 display mpls rsvp-te rsb-content
1.1.20 display mpls rsvp-te sender
1.1.21 display mpls rsvp-te statistics
1.1.22 display mpls static-cr-lsp
1.1.23 display mpls te cspf tedb
1.1.24 display mpls te link-administration admission-control
1.1.25 display mpls te link-administration bandwidth-allocation
1.1.27 display mpls te tunnel path
1.1.28 display mpls te tunnel statistics
1.1.29 display mpls te tunnel-interface
1.1.31 display ospf traffic-adjustment
1.1.33 enable traffic-adjustment
1.1.34 enable traffic-adjustment advertise
1.1.39 mpls rsvp-te authentication
1.1.40 mpls rsvp-te blockade-multiplier
1.1.42 mpls rsvp-te hello-lost
1.1.43 mpls rsvp-te keep-multiplier
1.1.44 mpls rsvp-te reliability
1.1.45 mpls rsvp-te resvconfirm
1.1.47 mpls rsvp-te timer hello
1.1.48 mpls rsvp-te timer refresh
1.1.49 mpls rsvp-te timer retransmission
1.1.51 mpls te affinity property
1.1.53 mpls te backup bandwidth
1.1.55 mpls te bandwidth change thresholds
1.1.58 mpls te cspf timer failed-link
1.1.60 mpls te fast-reroute bypass-tunnel
1.1.64 mpls te link administrative group
1.1.66 mpls te max-link-bandwidth
1.1.67 mpls te max-reservable-bandwidth
1.1.69 mpls te path explicit-path
1.1.70 mpls te path metric-type
1.1.73 mpls te reoptimization (User view)
1.1.74 mpls te reoptimization (Tunnel Interface view)
1.1.78 mpls te signal-protocol
1.1.80 mpls te timer fast-reroute
1.1.86 reset mpls rsvp-te statistics
add hop ip-address1 [ include [ loose | strict ] | exclude ] { after | before } ip-address2
显式路径视图
【缺省级别】
2:系统级
ip-address1:要插入的节点的IP地址或Router ID,点分十进制形式。
include:在显式路径中包含插入的IP地址。
strict:严格下一跳,即,下一跳与本节点必须直接相连。
loose:松散下一跳,即,下一跳与本节点可以不是直接相连。
exclude:在显式路径的指定IP地址前或后插入新的IP地址,并且在计算路径时不包括此地址。
after:在指定节点之后插入新的IP地址。
before:在指定节点之前插入新的IP地址。
ip-address2:插入点前或后的IP地址,点分十进制形式。
【描述】
add hop命令用来向显式路径中插入一个节点。
缺省情况下,显式路径包含指定的节点(include),加入的节点是严格下一跳。
# 在3.3.10.5后面插入3.3.29.3,不包括此IP地址。
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] add hop 3.3.29.3 exclude after 3.3.10.5
debugging isis traffic-eng { advertisement | event } [ process-id | vpn-instance vpn-instance-name ]
undo debugging isis traffic-eng { advertisement | event } [ process-id | vpn-instance vpn-instance-name ]
【缺省级别】
1:监控级
advertisement:IS-IS通告的信息。
event:IS-IS TE事件。
process-id:指定IS-IS进程号。
vpn-instance:对IS-IS的指定VPN实例进行调试开关。
vpn-instance-name:指定VPN实例的名称。
【描述】
debugging isis traffic-eng命令用于打开IS-IS的TE调试信息开关。undo debugging isis traffic-eng命令用于关闭IS-IS的TE调试信息开关。
缺省情况下,IS-IS的TE调试开关是关闭的。
# 打开所有IS-IS的TE事件调试信息开关。
<Sysname> debugging isis traffic-eng event
debugging mpls rsvp-te { all | authentication | bundle | encdec | error | hello | hsb | main | msg-hex | path | perr | ptear | rconf | rerr | resv | rtear | socket | srefresh | timer | tool | traffic-control | tunnel-id { tunnel-id | all } }
undo debugging mpls rsvp-te { all | authentication | bundle | encdec | error | hello | hsb | main | msg-hex | path | perr | ptear | rconf | rerr | resv | rtear | socket | srefresh | timer | tool | traffic-control | tunnel-id { tunnel-id | all } }
【缺省级别】
1:监控级
all:所有的调试功能。
authentication:认证调试功能。
bundle:Bundle调试功能。
encdec:编解码调试功能。
error:错误调试功能。
hello:Hello调试功能。
hsb:热备份调试功能。
main:主调试功能。
msg-hex :详细调试信息开关。
path:路径调试功能。
perr:路径错误调试功能。
ptear:路径拆除调试功能。
rconf:预留确认调试功能。
rerr:预留错误调试功能。
resv:预留消息调试功能。
rtear:预留拆除调试功能。
socket:Socket调试功能。
srefresh:Srefresh调试功能。
timer:定时器调试功能。
tool:工具调试功能。
traffic-control:流量控制调试功能。
tunnel-id:对指定隧道的调试功能。
tunnel-id:指定隧道号。
【描述】
debugging mpls rsvp-te命令用来打开MPLS RSVP-TE调试信息开关。undo debugging mpls rsvp-te命令用来关闭MPLS RSVP-TE调试信息开关。
缺省情况下,关闭MPLS RSVP-TE调试信息开关。
如果需要输出关于隧道创建、删除、刷新的信息,需要使用debugging mpls tunnel-id命令使能对隧道的调试。
# 打开本节点RSVP-TE的所有调试信息开关。
<Sysname> debugging mpls rsvp-te all
# 关闭本节点RSVP-TE的srefresh调试信息开关。
<Sysname> undo debugging mpls rsvp-te srefresh
debugging mpls te cspf { all | computation | errors | events | tedb }
undo debugging mpls te cspf { all | computation | errors | events | tedb }
【缺省级别】
1:监控级
all:所有调试功能。
computation:CSPF计算限制路由时的调试信息。
errors:错误调试功能。
events:事件调试功能。
tedb:TEDB(Traffic Engineering Database,流量工程数据库)调试功能。
【描述】
debugging mpls te cspf命令用来打开CSPF调试信息开关。undo debugging mpls te cspf命令用来关闭CSPF调试开关。
缺省情况下,CSPF调试信息开关是关闭的。
# 在本节点使能所有CSPF调试功能。
<Sysname> debugging mpls te cspf all
debugging mpls te management { all | events | fast-reroute | link-administration | reoptimization | states }
undo debugging mpls te management { all | events | fast-reroute | link-administration | reoptimization | states }
【缺省级别】
2:系统级
all:MPLS TE的所有调试信息开关。
events:MPLS TE的事件调试信息开关。
fast-reroute:MPLS TE快速重路由调试信息开关。
link-administration:MPLS TE链路管理的允许控制(admission control)和带宽分配调试信息开关。
reoptimization:MPLS TE重优化调试信息开关。
states:MPLS TE隧道状态调试信息开关。
【描述】
debugging mpls te management命令用来打开MPLS TE的调试信息开关。undo debugging mpls te management命令用来关闭MPLS TE的调试信息开关。
缺省情况下,MPLS TE的调试信息开关是关闭的。
# 打开MPLS TE的事件调试信息开关。
<Sysname> debugging mpls te management events
# 关闭所有的MPLS TE调试信息开关。
<Sysname> undo debugging mpls te management all
debugging ospf [ process-id ] mpls-te
undo debugging ospf [ process-id ] mpls-te
【缺省级别】
1:监控级
process-id:指定OSPF进程号,范围为1~65535。
【描述】
debugging ospf mpls-te命令用来使能OSPF进程中TE的调试功能,TE LSA的接收、生成和扩散、刷新等事件都将输出调试信息。undo debugging ospf mpls-te命令用来关闭OSPF进程中TE的调试功能。
缺省情况下,OSPF TE的调试功能是关闭的。
# 打开OSPF TE调试信息开关。
<Sysname> debugging ospf mpls-te
delete hop ip-address
显式路径视图
【缺省级别】
2:系统级
ip-address:显示路径的指定节点的IP地址,点分十进制格式。
【描述】
delete hop命令用来在显式路径中删除指定的一个节点。
#在MPLS TE显式路径中删除IP地址10.0.0.120的节点。
[Sysname] explicit-path p1
[Sysname-explicit-path-p1] delete hop 10.0.0.120
display explicit-path [ pathname ]
【缺省级别】
1:监控级
pathname:指定路径名。
【描述】
display explicit-path命令用来显示显式路径信息。
如果不指定路径名,将显示所有显式路径信息。
# 显示所有显式路径信息。
<Sysname> display explicit-path
Path Name : ErHop-Path1 Path Status : Enabled
1 1.1.1.10 Strict Include
2 2.1.1.10 Strict Include
3 1.1.1.20 Strict Include
4 2.1.1.20 Strict Include
5 2.1.1.30 Strict Include
6 1.1.1.30 Strict Include
7 9.4.4.4 Strict Include
Path Name : ErHop-Path2 Path Status : Enabled
3 1.1.1.40 Strict Include
4 2.1.1.40 Strict Include
5 1.1.1.50 Strict Include
6 2.1.1.40 Strict Include
7 2.1.1.30 Strict Include
8 1.1.1.30 Strict Include
9 9.4.4.4 Strict Include
表1-1 display explicit-path命令显示信息描述表
Path Name |
显式路径名称 |
Path Status |
显式路径状态 |
display isis traffic-eng advertisements [ level-1 | level-1-2 | level-2 ] [ lsp-id | local ] [ process-id | vpn-instance vpn-instance-name ]
【缺省级别】
1:监控级
level-1:Level-1设备的TE信息。
level-1-2:Level-1-2设备的TE信息。
level-2:Level-2设备的TE信息。
lsp-id lsp-id:显示指定LSP(Link State PDU,链路状态报文) ID发布的TE信息。有关ISIS的LSP的详细介绍请参见“IP路由分册”中的“ISIS配置”。
local:显示本地发布的TE信息。
vpn-instance vpn-instance-name:指定VPN实例的名称(对于缺省的VPN实例,该参数可选)。
【描述】
display isis traffic-eng advertisements命令用来显示IS-IS TE最近一次发布的TE信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE信息。
# 显示IS-IS TE最近一次发布的TE信息。
<Sysname> display isis traffic-eng advertisements
TE information for ISIS(1)
Level-1 Link State Database
LSPID LSP Seq Num LSP Checksum LSP Holdtime ATT/P/OL
0000.0000.0001.00-00* 0x00000001 0x3f57 534 0/0/0
NLPID : IPV4
AREA ADDR : 00.0005
INTF ADDR : 10.1.1.1
INTF ADDR : 1.1.1.9
INTF ADDR : 30.1.1.1
Level-2 Link State Database
0000.0000.0001.00-00* 0x0000001c 0xf1ec 687 0/0/0
NLPID : IPV4
AREA ADDR : 00.0005
INTF ADDR : 1.1.1.9
Router ID : 1.1.1.9
+NBR : 0000.0000.0002.02 COST: 10
Affinity: 0x00000000
Interface IP Address: 10.1.1.1
Physical BW : 12500 Bytes/sec
Reservable BW: 6250 Bytes/sec
Unreserved BW for Class Type 0:
BW Unresrv[0]: 6250 Bytes/sec BW Unresrv[1]: 6250 Bytes/sec
BW Unresrv[2]: 6250 Bytes/sec BW Unresrv[3]: 6250 Bytes/sec
BW Unresrv[4]: 6250 Bytes/sec BW Unresrv[5]: 6250 Bytes/sec
BW Unresrv[6]: 6250 Bytes/sec BW Unresrv[7]: 6250 Bytes/sec
Unreserved BW for Class Type 1:
BW Unresrv[0]: 0 Bytes/sec BW Unresrv[1]: 0 Bytes/sec
BW Unresrv[2]: 0 Bytes/sec BW Unresrv[3]: 0 Bytes/sec
BW Unresrv[4]: 0 Bytes/sec BW Unresrv[5]: 0 Bytes/sec
BW Unresrv[6]: 0 Bytes/sec BW Unresrv[7]: 0 Bytes/sec
TE Cost : 10
Bandwidth Constraint Model: Russian Doll
Bandwidth Constraints:
BC[0] : 6250 Bytes/sec BC[1] : 0 Bytes/sec
Local Overbooking Multiplier:
LOM[0] : 100 % LOM[1] : 100 %
+NBR : 0000.0000.0004.00 COST: 10
Interface IP Address: 30.1.1.1
Peer IP Address : 30.1.1.2
TE Cost : 10
表1-2 display isis traffic-eng advertisements命令显示信息描述表
LSPID |
LSP ID |
LSP Seq Num |
LSP序列号 |
LSP Checksum |
LSP校验和 |
LSP Holdtime |
LSP保持时长 |
ATT/P/OL |
Attach bit(ATT):连接位 Partition bit(P):分区位 Overload bit(OL):过载位 |
NLPID |
网络协议类型 |
AREA ADDR |
ISIS域地址 |
INTF ADDR |
接口地址 |
Router ID |
路由ID |
+NBR |
邻居 |
COST |
开销 |
Affinity |
亲和属性 |
Interface IP Address |
接口IP地址 |
Physical BW |
物理带宽 |
Reservable BW |
预留带宽 |
BW Unresrv[0]-[7] |
子池中8个级别的可用带宽 |
TE Cost |
TE 开销 |
Bandwidth Constraint Model |
带宽约束模型 |
BC[0] |
全局池 |
BC[1] |
子池 |
Local Overbooking Multiplier |
本地过预订倍数 |
LOM[0] |
本地过预订倍数,数字代表级别 |
LOM[1] |
本地过预订倍数,数字代表级别 |
Peer IP Address |
对端邻居的IP地址 |
display isis traffic-eng link [ level-1 | level-1-2 | level-2 ] [ verbose ] [ process-id | vpn-instance vpn-instance-name ]
【缺省级别】
1:监控级
verbose:显示详细信息。
【描述】
display isis traffic-eng link命令用来显示IS-IS TE的链路信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE的链路信息。
# 显示IS-IS TE的链路信息。
<Sysname> display isis traffic-eng link
Level-2 Link Information
0000.0000.0001.00-->0000.0000.0001.01 Type: MULACC LinkID: 10.1.1.1
0000.0000.0002.00-->0000.0000.0001.01 Type: MULACC LinkID: 10.1.1.1
0000.0000.0003.00-->0000.0000.0004.01 Type: MULACC LinkID: 30.1.1.2
0000.0000.0004.00-->0000.0000.0004.01 Type: MULACC LinkID: 30.1.1.2
Total Number of TE Links in Level-2 Area: 6, Num Active: 6
表1-3 display mpls lsp statistics命令显示信息描述表
Total Number of TE Links in Level-2 Area |
Level-2区域中的TE链路数 |
Num Active |
处于激活状态的数目 |
display isis traffic-eng network [ level-1 | level-1-2 | level-2 ] [ process-id | vpn-instance vpn-instance-name ]
【缺省级别】
1:监控级
【描述】
display isis traffic-eng network命令用来显示IS-IS TE的网络信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE的网络信息。
# 显示IS-IS TE的网络信息。
<Sysname> display isis traffic-eng network
Level-1 Network Information
DIS Router ID : 89.1.1.1 DIS's Ip Address : 86.1.1.1
Status In CSPF : ACTIVE Attached Router Count : 2
List of Attached Routers
RouterId : 89.1.1.1 Nbr : 1111.1111.1111.00 Link State : 1
RouterId : 89.2.2.2 Nbr : 1111.1111.1113.00 Link State : 1
Total Number of TE Networks in Level-1 Area: 1, Num Active: 1
Level-2 Network Information
Total Number of TE Networks in Level-2 Area: 1, Num Active: 1
表1-4 display isis traffic-eng network命令显示信息描述表
Level-1 Network Information |
Level-1网络信息 |
DIS Router ID |
DR路由ID |
DIS's Ip Address |
DR路由设备的IP地址 |
Status In CSPF |
CSPF状态 |
Attached Router Count |
相连设备的数目 |
List of Attached Routers |
相连设备列表 |
RouterId |
路由ID |
Nbr |
邻居 |
Link State |
链路状态 |
Total Number of TE Networks in Level-1 Area |
处于Level-1的TE网络数目 |
Num Active |
处于激活状态的数目 |
Level-2 Network Information |
Level-2网络信息 |
Total Number of TE Networks in Level-2 Area |
处于Level-2的TE网络数目 |
display isis traffic-eng statistics [ process-id | vpn-instance vpn-instance-name ]
【缺省级别】
1:监控级
vpn-instance vpn-instance-name:指定VPN实例的名称。
【描述】
display isis traffic-eng statistics命令用来显示IS-IS TE的统计信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE的统计信息。
# 显示IS-IS TE的统计信息。
<Sysname> display isis traffic-eng statistics
TE Statistics Information
IS-IS System Type : Level-1-2
IS-IS Cost Style Status : Wide
IS-IS Level-1 Traffic Engineering Status : Disabled
IS-IS Level-2 Traffic Engineering Status : Enabled
IS-IS Router ID : 1.1.1.9
表1-5 display isis traffic-eng statistics命令显示信息描述表
IS-IS System Type |
系统类型 |
IS-IS Cost Style Status |
设备的开销类型 |
IS-IS Level-1 Traffic Engineering Status |
Level-1设备的TE状态 |
IS-IS Level-2 Traffic Engineering Status |
Level-2设备的TE状态 |
IS-IS Router ID |
IS-IS设备的Router ID |
display mpls rsvp-te [ interface [ interface-type interface-number ] [ | { begin | include | exclude } regular-expression ] ]
【缺省级别】
1:监控级
interface interface-type interface-number:指定接口类型及接口号。
|:对输出的信息进行过滤。
begin:显示以指定字符串开头的信息。
include:显示包含指定字符串的信息。
exclude:显示不含指定字符串的信息。
regular-expression:正则表达式,不包含空格。
【描述】
display mpls rsvp-te interface命令用来显示RSVP-TE的配置信息。
l 如果不使用关键字interface,将显示RSVP-TE的配置信息。
l 如果不指定接口名,将显示所有使能了RSVP-TE的接口的RSVP-TE的配置信息。
# 显示RSVP-TE的配置信息。
<Sysname> display mpls rsvp-te
LSR ID: 4.4.4.4
Resv Confirmation Request: DISABLE
RSVP Hello Extension: ENABLE
Hello interval: 3 sec Max Hello misses: 3
Path and Resv message refresh interval: 30 sec
Path and Resv message refresh retries count: 3
Blockade Multiplier: 4
表1-6 display mpls rsvp-te命令显示信息描述表
LSR ID |
标签交换路由ID,格式为X.X.X.X |
Resv Confirmation Request |
预留确认特性 |
RSVP Hello Extension |
是否使能Hello特性 |
Hello Interval |
Hello定时器时长,单位为秒 |
Max Hello misses |
最多可遗漏的Hello报文 |
Path and Resv message refresh interval |
路径和预留刷新消息的刷新定时器时间,单位为秒 |
Path and Resv message refresh retries count |
路由和预留消息重发的次数 |
Blockade Multiplier |
PSB和RSB的超时倍数 |
# 显示指定接口的RSVP-TE的配置信息。
<Sysname> display mpls rsvp-te interface Vlan-interface 12
Interface Vlan-interface12
Interface state: UP
Total-BW: 80 Used-BW: 20
Hello configured: NO Num of Neighbors: 1
SRefresh feature: ENABLE SRefresh Interval: 30sec
Authentication: DISABLE Reliability configured: NO
Retransmit Interval: 500msec Increment Value: 1
表1-7 display mpls rsvp-te interface命令显示信息描述表
Interface Vlan-interface 12 |
已使能RSVP-TE的接口名称 |
Interface state |
物理接口状态 |
Total-BW |
总带宽(单位:kbit/s) |
Used-BW |
所用带宽(单位:Kbit/s) |
Hello configured |
是否配置了Hello特性 |
Num of Neighbors |
经该接口连接的邻居个数 |
Srefresh feature |
摘要刷新配置 |
Srefresh interval |
摘要刷新定时器时长(单位:秒) |
Authentication |
是否使能验证 |
Reliability |
是否存在可靠性特性 |
Retransmit interval |
重传定时器时长(单位:微秒) |
Increment value |
可重传的次数 |
display mpls rsvp-te established [ interface interface-type interface-number ] [ | { begin | include | exclude } regular-expression ]
【缺省级别】
1:监控级
|:对输出的信息进行过滤。
【描述】
display mpls rsvp-te established命令用来显示全局或接口的RSVP-TE信息。
# 显示指定接口的RSVP-TE的信息。
<Sysname> display mpls rsvp-te established interface Vlan-interface 12
Token Bucket Rate: 0.00 Peak Data Rate: 0.00
Tunnel Dest: 2.2.2.2 Ingress LSR ID: 3.3.3.3
Local LSP ID: 4 Session Tunnel ID: 4
Next Hop Addr: 80.4.1.1
Upstream Label: 1024 Downstream Label: 3
表1-8 display mpls rsvp-te established命令的显示信息描述表
使能RSVP-TE的Vlan接口 |
Token Bucket rate |
流量参数,令牌桶速率 |
Peak Data Rate |
流量参数,峰值速率 |
Tunnel Dest |
隧道地址,格式为X.X.X.X |
Ingress LSR ID |
入口标签交换路由ID,格式为X.X.X.X |
Local LSP ID |
本地LSP ID |
Session Tunnel ID |
隧道ID |
Next Hop Addr |
下一跳地址,格式为X.X.X.X |
Upstream label |
上游标签 |
Downstream Label |
下游标签 |
display mpls rsvp-te peer [ interface interface-type interface-number ] [ | { begin | include | exclude } regular-expression ]
【缺省级别】
1:监控级
|:对输出的信息进行过滤。
regular-expression:正则表达式。
【描述】
display mpls rsvp-te peer命令用来显示RSVP-TE邻居信息。
如果不指定接口,将显示所有接口的RSVP-TE邻居信息。
# 显示所有接口的RSVP-TE邻居信息。
<Sysname> display mpls rsvp-te peer
Neighbor Addr: 80.4.1.1
SrcInstance: 841 NbrSrcInstance: 928
PSB Count: 0 RSB Count: 1
Hello Type Sent: ACK Neighbor Hello Extension: ENABLE
SRefresh Enable: NO Reliability Enable: YES
Interface Vlan-interface14
Neighbor Addr: 80.2.1.1
SrcInstance: 832 NbrSrcInstance: 920
PSB Count: 1 RSB Count: 0
Hello Type Sent: REQ Neighbor Hello Extension: ENABLE
表1-9 display mpls rsvp-te peer 命令的显示信息描述表
使能RSVP-TE的Vlan接口 |
Neighbor Addr: |
邻居地址,格式为 X.X.X.X. |
SrcInstance |
源Message ID的Instance |
NbrSrcInstance |
对端Message ID的Instance |
PSB Count |
路径状态块数量 |
RSB Count |
预留状态块数量 |
Hello Type Sent |
向对端发送Hello类型,取值为REQ/ACK/NONE |
Neighbor Hello Extension |
是否使能邻居的Hello特性 |
SRefresh Enable |
是否使能摘要刷新,取值为YES/NO |
Reliability Enable |
对等体是否使能可靠性,取值为YES/NO |
display mpls rsvp-te psb-content ingress-lsr-id lspid tunnel-id egress-lsr-id [ | { begin | include | exclude } regular-expression ]
【缺省级别】
1:监控级
ingress-lsr-id:入口LSR ID。
lspid:本地LSP ID。
tunnel-id:隧道ID。
egress-lsr-id:出口LSR ID。
|:对输出的信息进行过滤。
【描述】
display mpls rsvp-te psb-content命令用来显示RSVP-TE PSB(Path State Block)信息。
# 显示RSVP-TE PSB信息。
<Sysname> display mpls rsvp-te psb-content 19.19.19.19 1 0 29.29.29.29
The PSB Content:
Tunnel Dest: 29.29.29.29 Session Tunnel ID: 0
Tunnel ExtID: 19.19.19.19
Ingress LSR ID: 19.19.19.19 Local LSP ID: 1
Previous Hop : 101.101.101.1 Next Hop : -----
Incoming / Outgoing Interface: Vlan-interface 12 / -----
InLabel : 3 OutLabel : NULL
Send Message ID : 1 Recv Message ID : 0
Session Attribute-
SetupPrio: 7 HoldPrio: 7
SessionFlag: SE Style desired
ERO Information-
L-Type ERO-IPAddr ERO-PrefixLen
ERHOP_STRICT 101.101.101.2 32
RRO Information-
RRO-CType: IPV4 RRO-IPAddress: 101.101.101.1 RRO-IPPrefixLen: 32
SenderTspec Information-
Token bucket rate: 0.00
Token bucket size: 0.00
Peak data rate: 0.00
Minimum policed unit: 0
Maximum packet size: 4294967295
Path Message arrive on Vlan-interface 12 from PHOP 101.101.101.1
Resource Reservation OK
表1-10 display mpls rsvp-te psb content命令显示信息描述表
Tunnel Dest |
隧道目的地址,格式为 X.X.X.X |
Session Tunnel ID |
会话隧道ID |
Tunnel ExtID |
隧道的扩展ID,格式为X.X.X.X |
Ingress LSR ID |
Local LSP ID |
本地LSP ID |
Next Hop |
下一跳地址,格式为 X.X.X.X |
Previous Hop |
前一跳地址,格式为X.X.X.X |
In Label |
入标签 |
Out Label |
出标签 |
Send message ID |
发送的MessageID的instance |
Resv Message ID |
接收的MessageID的instance |
Setup Prio |
会话建立优先级 |
HoldPrio |
会话保持优先级 |
Session Flag |
会话类型(需要的本地保护、标签、SE风格) |
RRO Information |
记录路由信息 |
RRO-C Type |
记录路由的类型 |
RRO-IP Address |
记录路由的IP地址 (X.X.X.X) |
RRO-IPPrefixLen |
记录路由前缀的长度 |
ERO Information |
显式路由信息 |
L-Type |
显式路由类型(Strict / Loose) |
ERO-IPAddress |
显式路由地址 |
ERO-Prefix Len |
显式路由前缀值 |
Sender Tspec Information |
包括发送方业务规格信息 |
Token Bucket rate |
流量参数,令牌桶速率(单位:kbit/s) |
Token Bucket size |
流量参数,令牌桶大小 |
Peak Data Rate |
流量参数:峰值数据速率(单位:kbit/s) |
Maximum packet size |
流量参数,最大报文长度 |
Minimum policed unit |
流量参数,最小监管单元 |
Path message |
从接口发送到下一跳X.X.X.X的路径消息 |
Resource |
只有配置了资源预留标记时才会有此项显示 |
display mpls rsvp-te request [ interface interface-type interface-number ] [ | { begin | include | exclude } regular-expression ]
【缺省级别】
1:监控级
|:对输出的信息进行过滤。
【描述】
display mpls rsvp-te request命令用来显示RSVP-TE请求消息信息。
如果不指定接口名,将显示所有接口的请求消息信息。
# 显示所有接口的请求消息信息。
<Sysname> display mpls rsvp-te request
Interface Vlan-interface 12:
NextHopAddr: 80.4.1.1
SessionFlag: SE Style desired.
Token bucket rate: 0.00 Token bucket size: 1000.00
Out Interface: Vlan-interface 14
表1-11 display mpls rsvp-te request 命令的显示信息描述表
使能了RSVP-TE的Vlan接口 |
Tunnel Dest |
隧道目的地址,格式为X.X.X.X |
Ingress LSR ID |
Local LSP ID |
本地LSP ID |
Session Tunnel ID |
会话隧道ID |
Next Hop Address |
下一跳地址,格式为 X.X.X.X |
SessionFlag |
风格 |
Token Bucket rate |
流量参数,令牌桶速率 |
Token Bucket Size |
流量参数,令牌桶大小 |
Out Interface |
消息出接口 |
display mpls rsvp-te reservation [ interface interface-type interface-number ] [ | { begin | include | exclude } regular-expression ]
【缺省级别】
1:监控级
|:对输出的信息进行过滤。
【描述】
display mpls rsvp-te reservation命令用来显示RSVP-TE资源预留消息。
如果不指定接口名,将显示所有接口的资源预留信息。
# 显示指定接口的RSVP-TE预留消息。
<Sysname> display mpls rsvp-te reservation interface Vlan-interface 12
Tunnel Dest: 29.29.29.29 Ingress LSR ID: 19.19.19.19
LSP ID: 1 Session Tunnel ID: 1
Upstream Label: -----
Token bucket rate: 0.00 Token bucket size: 0.00
# 显示所有接口的RSVP-TE预留消息。
Interface: Outgoing-Interface at the Egress
Tunnel Dest: 19.19.19.19 Ingress LSR ID: 29.29.29.29
Upstream Label: 3
表1-12 display mpls rsvp-te reservation命令的显示信息描述表
使能了RSVP-TE的Vlan接口 |
Tunnel Dest |
Ingress LSR ID |
LSP ID |
LSP ID |
Session Tunnel ID |
会话隧道ID |
Upstream Label |
上游标签 |
Token Bucket rate |
流量参数,令牌桶速率 |
Token Bucket Size |
流量参数,令牌桶大小 |
display mpls rsvp-te rsb-content { ingress-lsr-id Ispid tunnel-id egress-lsr-id nexthop-address } [ | { begin | include | exclude } regular-expression ]
【缺省级别】
1:监控级
lspid:本地LSP ID。
tunnel-id:隧道ID。
nexthop-address:下一跳地址。
|:对输出的信息进行过滤。
【描述】
display mpls rsvp-te rsb-content命令用来显示RSVP-TE RSB(Reserve State Block)信息。
# 显示RSVP-TE RSB信息。
<Sysname> display mpls rsvp-te rsb-content 19.19.19.19 1 0 29.29.29.29 101.101.101.2
The RSB Content:
Next Hop: 101.101.101.2 Resevation Style: SE Style
Reservation Incoming Interface: Vlan-interface 12
Reservation Interface: Vlan-interface 12
Message ID : 2
Filter Spec Information-
The filter number: 1
Ingress LSR ID: 19.19.19.19 Local LSP ID: 1 OutLabel: 3
RRO Information-
RRO-Flag is
RRO-CType: IPV4 RRO-IPAddress: 101.101.101.2 RRO-IPPrefixLen: 32
FlowSpec Information-
Token bucket rate: 2500.00
Maximum packet size: 0
Bandwidth guarantees: 0.00
Delay guarantees: 0
Qos Service is Controlled
Resv Message arrive on Vlan-interface 12 from NHOP 101.101.101.2
表1-13 display mpls rsvp-te rsb content命令显示信息描述表
Tunnel Dest |
隧道地址,格式为 X.X.X.X |
Session Tunnel ID |
会话隧道ID |
Tunnel Ext ID |
隧道扩展(入口LSR ID),格式为 X.X.X.X |
Next Hop |
下一跳地址,格式为 X.X.X.X |
Reservation Style |
预留风格,取值为SE/FF |
Reservation Interface |
预留资源的接口名称 |
Reserve Incoming Interface |
预留消息入接口 |
Message ID |
减少刷新的消息的ID |
Filter Spec Information |
过滤规格信息 |
Filter Num |
过滤器总数 |
Ingress LSR ID |
LSP ID |
LSP ID |
Out Label |
出标签 |
RRO Information |
记录路由信息 |
RRO-C Type |
记录路由的类型 |
RRO-IP Address |
RRO-IPPrefixLen |
记录路由前缀的长度 |
Flow Spec information |
包括流规格业务信息 |
Token Bucket rate |
流量参数,令牌桶速率 (单位:kbit/s) |
Token Bucket size |
流量参数,令牌桶大小 |
Peak Data Rate |
流量参数,峰值数据速率(单位:kbit/s) |
流量参数,最大报文长度 |
流量参数,最少监管单位 |
Bandwidth guarantees |
预留规格参数,带宽保证 |
Delay guarantees |
预留规格参数,延迟保证 |
QOS service |
QoS保证/控制 |
Resv Message |
从下一跳地址(X.X.X.X)到Vlan-interface 12的预留消息 |
display mpls rsvp-te sender [ interface interface-type interface-number ] [ | { begin | include | exclude } regular-expression ]
【缺省级别】
1:监控级
|:对输出的信息进行过滤。
【描述】
display mpls rsvp-te sender命令用来显示RSVP-TE发送方消息信息。
# 显示指定接口的RSVP-TE发送方消息信息。
<Sysname> display mpls rsvp-te sender interface Vlan-interface 12
Interface Vlan-interface 12;
Session Name: Tunnel0/0/0
Previous Hop Address: 101.101.101.1
# 显示所有接口的RSVP-TE发送方消息信息。
Previous Hop Address: 101.101.101.2
Interface: Incoming-Interface at the Ingress
Session Name: Tunnel0/0/1
Previous Hop Address: 19.19.19.19
表1-14 display mpls rsvp-te sender命令的显示信息描述表
使能RSVP-TE的Vlan接口 |
Tunnel Dest |
隧道地址,格式为X.X.X.X |
Ingress LSR ID |
LSP ID |
LSP ID |
Tunnel ID |
会话隧道ID |
Session Name: |
会话的名称 |
Previous Hop Address |
前一跳地址,格式为X.X.X.X |
Token Bucket rate |
流量参数,令牌桶速率 |
Token Bucket Size |
流量参数,令牌桶大小 |
display mpls rsvp-te statistics { global | interface [ interface-type interface-number ] }
【缺省级别】
1:监控级
global:全局RSVP-TE。
interface:所有接口。
【描述】
display mpls rsvp-te statistics命令用来显示RSVP-TE的统计信息。
l 如果选择参数global,则显示全局RSVP-TE的统计信息;
l 如果选择参数interface,则显示所有接口RSVP-TE的统计信息;
l 如果选择参数interface interface-type interface-number,则显示指定接口RSVP-TE的统计信息。
# 显示全局RSVP-TE的统计信息。
<Sysname> display mpls rsvp-te statistics global
LSR ID: 1.1.1.1
PSB Count: 1 RSB Count: 1
RFSB Count: 0 TCSB Count: 1
LSP Count: 1
Total Statistics Information:
PSB CleanupTimeOutCounter: 0 RSB CleanupTimeOutCounter: 0
SendPacketCounter: 55 RecPacketCounter: 54
SendPathCounter: 5 RecPathCounter: 0
SendResvCounter: 0 RecResvCounter: 4
SendResvConfCounter: 0 RecResvConfCounter: 0
SendHelloCounter: 2 RecHelloCounter: 48
SendAckCounter: 48 RecAckCounter: 2
SendPathErrCounter: 0 RecPathErrCounter: 0
SendResvErrCounter: 0 RecResvErrCounter: 0
SendPathTearCounter: 0 RecPathTearCounter: 0
SendResvTearCounter: 0 RecResvTearCounter: 0
SendSrefreshCounter: 0 RecSrefreshCounter: 0
SendAckMsgCounter: 0 RecAckMsgCounter: 0
SendErrMsgCounter: 0 RecErrMsgCounter: 0
RecReqFaultCounter: 0
# 显示指定接口Vlan-interface 12的RSVP-TE的统计信息。
<Sysname> display mpls rsvp-te statistics interface
Vlan-interface12:
SendPacketCounter: 69 RecPacketCounter: 68
SendPathCounter: 6 RecPathCounter: 0
SendResvCounter: 0 RecResvCounter: 5
SendHelloCounter: 2 RecHelloCounter: 61
SendAckCounter: 61 RecAckCounter: 2
表1-15 display mpls rsvp-te statistics命令显示信息描述表
LSR ID |
LSR的ID |
PSB Count |
PSB的数量 |
RSB Count |
RSB的数量 |
RFSB Count |
RFSB的数量 |
TCSB Count |
TCSB的数量 |
LSP Count |
LSP的数量 |
PSB CleanupTimeOutCounter |
PSB超时次数 |
RSB CleanupTimeOutCounter |
RSB超时次数 |
SendPacketCounter |
发送的报文数量 |
RecPacketCounter |
接收的报文数量 |
SendPathCounter |
发送的Path消息数量 |
RecPathCounter |
接收的Path消息数量 |
SendResvCounter |
发送的Resv消息数量 |
RecResvCounter |
接收的Path消息数量 |
SendResvConfCounter |
发送的ResvConf消息数量 |
RecResvConfCounter |
接收的ResvConf消息数量 |
SendHelloCounter |
发送的Hello消息数量 |
RecHelloCounter |
接收的Hello消息数量 |
SendAckCounter |
发送的Ack消息数量 |
RecAckCounter |
接收的Ack消息数量 |
SendPathErrCounter |
发送的PathErr消息数量 |
RecPathErrCounter |
接收的PathErr消息数量 |
SendResvErrCounter |
发送的ResvErr消息数量 |
RecResvErrCounter |
接收的ResvErr消息数量 |
SendPathTearCounter |
发送的PathTear消息数量 |
RecPathTearCounter |
接收的PathTear消息数量 |
SendResvTearCounter |
发送的ResvTear消息数量 |
RecResvTearCounter |
接收的ResvTear消息数量 |
SendSrefreshCounter |
发送的Srefresh消息数量 |
RecSrefreshCounter |
接收的Srefresh消息数量 |
SendAckMsgCounter |
发送的AckMsg消息数量 |
RecAckMsgCounter |
接收的AckMsg消息数量 |
SendErrMsgCounter |
发送错误的消息数量 |
RecErrMsgCounter |
接收错误的消息数量 |
RecReqFaultCounter |
请求失败的次数 |
Vlan-interface 12 |
指定的接口名称 |
display mpls static-cr-lsp [ lsp-name lsp-name ] [ { include | exclude } ip-address prefix-length ] [ verbose ]
【缺省级别】
1:监控级
lsp-name lsp-name:标签转发路径的名称。
ip-address:接口IP地址。
prefix-length:地址前缀的长度
include:只显示含有指定字符串的CR-LSP信息。
exclude:只显示不含指定字符串的CR-LSP信息。
verbose:显示详细信息。
【描述】
display mpls static-cr-lsp命令用来显示静态CR-LSP信息。
# 显示静态CR-LSP的简要信息。
<Sysname> display mpls static-cr-lsp
total statics-cr-lsp : 1
Name FEC I/O Label I/O If Stat
abc 3.3.3.9/32 NULL/100 -/Vlan12 Down
表1-16 display mpls static-cr-lsp命令输出信息描述
Name |
静态CR-LSP的名称 |
FEC |
FEC(等价转发类) |
I/O Label |
入/出标签值 |
I/O If |
入/出接口 |
Stat |
静态CR-LSP当前的状态 |
# 显示静态CR-LSP的详细信息。
<Sysname> display mpls static-cr-lsp verbose
No : 1
LSP-Name : abc
LSR-Type : Transit
FEC : -/-
In-Label : 20
Out-Label : 30
In-Interface : Vlan-interface 12
Out-Interface : Vlan-interface 14
NextHop : 3.2.1.2
Lsp Status : Down
表1-17 display mpls static-cr-lsp verbose命令输出信息描述
No |
序号 |
LSP-Name |
静态CR-LSP名称 |
LSR-Type |
静态CR-LSP类型 |
FEC |
FEC(转发等价类) |
In-Label |
入标签值 |
Out-Label |
出标签值 |
In-Interface |
入接口名称 |
Out-Interface |
出接口名称 |
NextHop |
下一跳地址 |
Lsp Status |
LSP状态 |
display mpls te cspf tedb { all | area area-id | interface ip-address | network-lsa | node [ mpls-lsr-id ] } [ | { begin | include | exclude } regular-expression ]
【缺省级别】
1:监控级
area area-id:区域ID。
interface ip-address:接口IP地址。
network-lsa:所有的Network-LSA信息。
node:节点信息。
mpls-lsr-id:MPLS LSR ID。
|:对输出的信息进行过滤。
【描述】
display mpls te cspf tedb命令用来显示满足指定条件的基于CSPF的TEDB信息。
# 显示Network-LSA的TEDB信息。
<Sysname> display mpls te cspf tedb network-lsa
Maximum Network LSA Supported: 500
Current Total Network LSA Number: 7
Id DR MPLS LSR-Id DR-Address IGP Process-Id Area Neighbor
1 8.1.1.2 3.0.0.2 OSPF 100 0 1.1.1.1
2.1.1.1
8.1.1.2
2 2.1.1.1 3.0.0.3 OSPF 100 0 2.1.1.1
3.1.1.1
2.1.1.2
3 3.1.1.2 3.0.0.4 OSPF 100 0 3.1.1.1
4.1.1.1
3.1.1.2
4 4.1.1.2 3.0.0.5 OSPF 100 0 4.1.1.1
5.1.1.1
4.1.1.2
5 5.1.1.2 3.0.0.6 OSPF 100 0 5.1.1.1
6.1.1.1
5.1.1.2
6 6.1.1.2 3.0.0.9 OSPF 100 0 6.1.1.1
7.1.1.1
6.1.1.2
7 7.1.1.1 12.0.0.7 OSPF 100 0 3.1.1.1
7.1.1.1
7.1.1.2
表1-18 display mpls te cspf tedb命令的显示信息描述表
ID |
序号 |
DR MPLS LSR-Id |
指定路由器(Designated Router)的MPLS LSR ID |
DR-Address |
指定设备(Designated Router)的接口地址 |
IGP |
内部网关协议(OSPF / IS-IS) |
Process-Id |
IGP进程ID |
Area |
设备属于的区域 |
Neighbor |
邻居路由ID |
# 显示所有TEDB信息。
<Sysname> display mpls te cspf tedb all
Maximum Node Supported: 512 Maximum Link Supported: 2048
Current Total Node Number: 3 Current Total Link Number: 44
Id MPLS LSR-Id IGP Process-Id Area Link-Count
1 1.1.1.1 OSPF 100 1001,1002,1003 20
1004,1005,1006
1007,1008,1009
1010,1,2
13,14,15
16,17,18
19,20
2 2.1.1.1 ISIS 100 Level-1,2 20
3 3.1.1.1 OSPF 100 0 4
表1-19 display mpls te cspf tedb all命令显示信息描述
ID |
序号 |
MPLS LSR-Id |
MPLS LSR ID |
IGP |
Process-Id |
IGP 进程ID |
Area |
设备属于的区域 |
Link-count |
设备上连接的指定IGP类型和进程号的链路总数 |
# 显示指定区域的TEDB信息。
<Sysname> display mpls te cspf tedb area 1
Router Node Information for Area 1:
1 2.2.2.2 OSPF 100 1 1
2 3.3.3.3 OSPF 100 1 1
3 2.2.2.2 ISIS 100 Level-1 1
4 3.3.3.3 ISIS 100 Level-1 1
Network LSA Information for Area 1:
1 3.3.3.3 20.1.1.2 OSPF 100 1 2.2.2.2
3.3.3.3
2 3.3.3.3 20.1.1.2 ISIS 100 Level-1 3.3.3.3
2.2.2.2
表1-20 display mpls te cspf tedb area命令输出信息描述
Id |
序号 |
MPLS LSR-Id |
MPLS LSR ID,点分十进制形式 |
IGP |
内部网关协议(OSPF或IS-IS) |
Process-Id |
IGP的进程号 |
Area |
设备所属的区域 |
Link-Count |
DR MPLS LSR-Id |
指定路由器DR的MPLS LSR ID |
DR-Address |
指定DR的接口地址 |
Neighbor |
邻居的MPLS LSR ID |
# 显示本地路由的TEDB信息。
<Sysname> display mpls te cspf tedb node
MPLS LSR-Id: 1.1.1.1
IGP Type: OSPF Process Id: 100
MPLS-TE Link Count: 1
Link[1] :
Interface IP Address: 2.0.0.33, 2.0.0.35, 2.0.0.36,
Neighbor IP Address: 2.0.0.2, 2.0.0.42, 2.0.0.43,
2.0.0.44, 2.0.0.45, 2.0.0.46,
2.0.0.47, 2.0.0.32,
Neighbor MPLS LSR-Id: 1.1.1.2
IGP Area: 1
Link Type: point-to-point Link Status: Inactive
IGP Metric: 100 TE Metric: 100 Color: 0xff
Maximum Bandwidth: 100 (kbps)
Maximum Reservable Bandwidth: 20 (kbps)
Bandwidth Constraints: Local Overbooking Multiplier:
BC[0] : 100 (kbps) LOM[0] : 1
BC[1] : 20 (kbps) LOM[1] : 1
BW Unreserved for Class type 0:
[0] : 10 (kbps), [1] : 10 (kbps)
[2] : 10 (kbps), [3] : 10 (kbps)
[4] : 10 (kbps), [5] : 10 (kbps)
[6] : 10 (kbps), [7] : 10 (kbps)
BW Unreserved for Class type 1:
IGP Type: ISIS Process Id: 100
MPLS-TE Link Count: 2
Link[1] :
2.0.0.47, 2.0.0.32, 2.0.0.33
IGP Area: Level-1
Link Type: point-to-point Link Status: Active
IGP Metric: 10 TE Metric: 10 Color: 0x11
Maximum Reservable Bandwidth: 100 (kbps)
表1-21 display mpls te cspf tedb node命令输出信息描述
MPLS LSR-Id |
设备的名称 |
IGP_Type |
IGP类型 |
Process Id |
IGP进程号 |
MPLS-TE Link Count |
MPLS TE链路数目 |
Link[×] |
链路× |
接口地址 |
DR Address |
指定设备DR地址 |
IGP Area |
IGP区域 |
Link Type |
链路类型 |
Link Status |
链路状态 |
IGP Metric |
IGP度量 |
TE Metric |
TE度量 |
Color |
链路管理属性 |
Maximum Bandwidth |
链路最大带宽 |
Maximum Reservable Bandwidth |
链路最大可预留带宽 |
Bandwidth Constraints |
带宽约束 |
BW Unreserved for Class type0 |
CT0级别的可预留带宽 |
BW Unreserved for Class type1 |
CT1级别的可预留带宽 |
# 显示指定接口地址的TEDB信息
<Sysname> display mpls te cspf tedb interface 20.1.1.1
MPLS LSR-Id: 2.2.2.2
Link[1] :
Interface IP Address: 20.1.1.1
DR Address: 20.1.1.2
IGP Area: Level-1
Link Type: multi-access Link Status: Active
IGP Metric: 10 TE Metric: 0 Color: 0x0
Maximum Bandwidth: 0 (kbps)
Maximum Reservable Bandwidth: 0 (kbps)
BC[0] : 0 (kbps) LOM[0] : 1
BC[1] : 0 (kbps) LOM[1] : 1
[0] : 0 (kbps), [1] : 0 (kbps)
[2] : 0 (kbps), [3] : 0 (kbps)
[4] : 0 (kbps), [5] : 0 (kbps)
[6] : 0 (kbps), [7] : 0 (kbps)
表1-22 display mpls te cspf tedb interface命令输出信息描述
MPLS LSR-Id |
MPLS LSR ID |
IGP_Type |
IGP类型 |
Process Id |
IGP进程号 |
MPLS TE链路数目 |
Link[×] |
链路×, |
接口地址 |
DR Address |
指定交换机DR地址 |
IGP Area |
IGP区域 |
Link Type |
链路类型 |
Link Status |
链路状态 |
IGP Metric |
IGP度量 |
TE Metric |
TE度量 |
Color |
链路管理属性 |
Maximum Bandwidth |
链路最大带宽 |
链路最大可预留带宽 |
带宽约束 |
CT0级别的可预留带宽 |
CT1级别的可预留带宽 |
display mpls te link-administration admission-control [ interface interface-type interface-number ]
【缺省级别】
1:监控级
interface interface-type interface-number:指定接口类型和接口编号。
【描述】
display mpls te link-administration admission-control命令用来显示所有链路接纳的CR-LSP信息。
如果不指定接口,将显示所有接口的所有链路接纳的CR-LSP信息。
# 显示所有链路接纳的CR-LSP信息。
<Sysname> display mpls te link-administration admission-control
LspID In/Out IF S/H Prio CT BW(kbps)
1.1.1.9:1024 --- / Vlan12 7 /7 0 0
1.1.1.9:2048 --- / Vlan16 7 /7 0 0
表1-23 display mpls te link-administration admission-control命令显示信息描述表
LspID |
链路接纳的LSP的ID |
In/Out IF |
入/出接口名称 |
S/H Prio |
建立/保持优先级 |
CT |
服务类型 |
BW(kbps) |
带宽 |
display mpls te link-administration bandwidth-allocation [ interface interface-type interface-number ]
【缺省级别】
1:监控级
【描述】
display mpls te link-administration bandwidth-allocation命令用来显示使能了MPLS TE的接口分配的带宽。
如果不指定接口,将显示所有使能了MPLS TE的接口分配的带宽。
# 显示使能了MPLS TE的接口分配的带宽。
<Sysname> display mpls te link-administration bandwidth-allocation
Link ID: Vlan-interface12
Physical Bandwidth Type0 : 0 kbits/sec
Physical Bandwidth Type1 : 0 kbits/sec
Reservable Bandwidth Type0 : 0 kbits/sec
Reservable Bandwidth Type1 : 0 kbits/sec
Downstream LSP Count : 0
UpStream LSP Count : 0
Downstream Bandwidth : 0 kbits/sec
Upstream Bandwidth : 0 kbits/sec
IPUpdown Link Status : UP
PhysicalUpdown Link Status : UP
TE CLASS CLASS TYPE PRIORITY BW RESERVED(kbps) BW AVAILABLE(kbps)
0 0 0 0 0
1 0 1 0 0
2 0 2 0 0
3 0 3 0 0
4 0 4 0 0
5 0 5 0 0
6 0 6 0 0
7 0 7 0 0
8 1 0 0 0
9 1 1 0 0
10 1 2 0 0
11 1 3 0 0
12 1 4 0 0
13 1 5 0 0
14 1 6 0 0
15 1 7 0 0
表1-24 display mpls te link-administration bandwidth-allocation命令显示信息描述表
Link ID |
链路ID |
Physical Bandwidth Type0 |
CT0型物理链路带宽 |
Physical Bandwidth Type1 |
CT1型物理链路带宽 |
Reservable Bandwidth Type0 |
CT0型预留带宽 |
Reservable Bandwidth Type1 |
CT1型预留带宽 |
Downstream LSP Count |
下游LSP条数 |
UpStream LSP Count |
上游LSP条数 |
IPUpdown Link Status |
协议层链路状态 |
PhysicalUpdown Link Status |
物理层链路状态 |
TE CLASS |
TE类型 |
CLASS TYPE |
服务类型 |
PRIORITY |
优先级 |
BW RESERVED |
预留带宽 |
BW AVAILABLE |
可用带宽 |
display mpls te tunnel [ destination dest-addr ] [ lsp-id lsr-id lsp-id ] [ lsr-role { all | egress | ingress | remote | transit } ] [ name name ] [ { incoming-interface | outgoing-interface | interface } interface-type interface-number ] [ verbose ]
【缺省级别】
1:监控级
destination dest-addr:只显示目的地址为指定IP地址的隧道。
lsp-id lsr-id lsp-id:lsr-id为Ingress节点的LSR-ID,点分十进制格式,lsp-id为LSP标识号。
lsr-role:显示具有指定角色的隧道(所有、入口、中间、出口或远端)。
all:显示所有隧道。
ingress:显示入口位于该设备的隧道。
transit:显示中间节点位于该设备的隧道。
egress:显示出口位于该设备的隧道。
incoming-interface:显示使用指定入接口的所有隧道。
outgoing-interface:显示使用指定出接口的所有隧道。
interface:显示使用指定接口作为出接口或入接口的所有隧道。
verbose:显示详细信息。
【描述】
display mpls te tunnel命令用来显示MPLS TE隧道信息。
# 显示MPLS TE隧道信息。
<Sysname> display mpls te tunnel
LSP-Id Destination In/Out-If Name
1.1.1.9:1024 3.3.3.9 -/Vlan12 Tunnel1/0/1
1.1.1.9:2048 3.3.3.9 -/Vlan14 Tunnel1/0/1
表1-25 display mpls te tunnel命令输出信息描述
LSP-ID |
隧道的LSP ID |
Destination |
目的设备的ID |
In/Out-IF |
入接口/出接口 |
Name |
隧道入口配置的隧道名称 |
# 显示MPLS TE隧道的详细信息。
<Sysname> display mpls te tunnel verbose
No : 1
LSP-Id : 1.1.1.9:1024
Tunnel-Name : Tunnel1/0/1
Destination : 3.3.3.9
In-Interface : -
Out-Interface : Vlan12
Tunnel BW : 0 kbps
Class Type : bc0
Ingress LSR-Id : 1.1.1.9
Egress LSR-Id : 3.3.3.9
Setup-Priority : 7
Hold-Priority : 7
Sign-Protocol : RSVP TE
Resv Style : SE
IncludeAnyAff : 0x0
ExcludeAllAff : 0x0
IncludeAllAff : 0x0
Created Time : 2004/10/18 16:05:17
表1-26 display mpls te tunnel verbose命令显示信息描述表
No |
序号 |
LSP-Id |
隧道的LSP ID |
Tunnel-Name |
隧道入口配置的隧道名称 |
Destination |
目的设备的ID |
In-Interface |
入接口 |
Out-Interface |
出接口 |
Tunnel BW |
隧道带宽 |
Class Type |
服务类别 |
Ingress LSR-Id |
入口标签交换路由的ID |
Setup-Priority |
建立优先级 |
Hold-Priority |
保持优先级 |
Sign-Protocol |
信令协议 |
Resv Style |
预留风格 |
IncludeAnyAff |
需要包含的任一链路属性 |
ExcludeAllAff |
排除的链路属性 |
IncludeAllAff |
需要包含的全部链路属性 |
Created Time |
建立时间 |
display mpls te tunnel path [ tunnel-name tunnel-name ] [ lsp-id lsr-id lsp-id ]
【缺省级别】
1:监控级
tunnel-name tunnel-name:隧道名称,字符串形式。
【描述】
display mpls te tunnel path命令用来显示本地节点的MPLS TE隧道的路径属性信息。
如果不指定隧道名称,将显示所有隧道的路径属性信息。
# 显示所有隧道路径属性信息。
<Sysname> display mpls te tunnel path
Tunnel Interface Name Tunnel0/0/0:
Lsp ID : 1.1.1.9:10
Hop information:
Hop 0: 192.1.1.1
Hop 1: 12.1.1.2
Hop 2: 10.202.2.2.
表1-27 display mpls te tunnel path命令显示信息描述表
Tunnel Interface Name Tunnel0/0/0 |
隧道接口名称为Tunnel0/0/0 |
Lsp ID |
LSP ID |
Hop 0 |
第0跳 |
Hop 1 |
第1跳 |
Hop 2 |
第2跳 |
【缺省级别】
1:监控级
无
【描述】
display mpls te tunnel statistics命令用来显示MPLS TE隧道统计信息。
# 显示MPLS TE隧道统计信息。
<Sysname> display mpls te tunnel statistics
Ingress: 0 Tunnels, 0 Tunnels Up, 0 CRLSPs Up
0 Modified, 0 In-Progress, 0 Failed
Transit: 0 Up
Egress : 0 Up
表1-28 display mpls te tunnel statistics命令显示信息描述表
Ingress |
以本设备为隧道入口 |
Transit: |
以本设备为隧道中间结点 |
Egress |
以本设备为隧道出口 |
Modified |
以本设备为入口,处于Modified状态的CRLSP数目 |
In-Progress |
以本设备为入口,处于In-Progress状态的CRLSP数目 |
Failed |
以本设备为入口,处于Failed状态的CRLSP数目 |
display mpls te tunnel-interface [ tunnel number ]
【缺省级别】
1:监控级
number:Tunnel接口号,格式为单板槽位号/子卡槽位号/Tunnel接口号。
【描述】
display mpls te tunnel-interface命令用来显示本地节点的MPLS TE隧道接口信息。
# 显示本地节点的MPLS TE隧道接口信息。
<Sysname> display mpls te tunnel-interface
Tunnel Name : Tunnel5/0/2
Tunnel Desc : Tunnel5/0/2 Interface
Tunnel State Desc : CR-LSP is Up
Tunnel Attributes :
LSP ID : 3.3.3.3:4
Session ID : 1
Admin State : UP Oper State : UP
Ingress LSR ID : 3.3.3.3 Egress LSR ID: 4.4.4.4
Signaling Prot : RSVP Resv Style : SE
Class Type : CLASS 0 Tunnel BW : 0 kbps
Reserved BW : 0 kbps
Setup Priority : 7 Hold Priority: 7
Affinity Prop/Mask : 0x0/0x0
Explicit Path Name : -
Tie-Breaking Policy : None
Metric Type : None
Loop Detection : Disabled
Record Route : Enabled Record Label : Enabled
FRR Flag : Enabled BackUpBW Flag: Not Supported
BackUpBW Type : - BackUpBW : -
Route Pinning : Disabled
Retry Limit : 5 Retry Interval: 10 sec
Reopt : Disabled Reopt Freq : -
Back Up Type : None
Back Up LSPID : -
Auto BW : Disabled Auto BW Freq : -
Min BW : - Max BW : -
Current Collected BW: -
Interfaces Protected: -
VPN Bind Type : NONE
VPN Bind Value : -
Car Policy : Disabled
表1-29 display mpls te tunnel-interface命令显示信息描述表
Tunnel Name |
隧道的名称 |
Tunnel Desc |
隧道的描述信息 |
Tunnel State Desc |
隧道的状态信息 |
LSP ID |
LSP ID |
Session ID |
会话ID |
Admin State |
管理状态 |
Oper State |
运行状态 |
Ingress LSR ID |
入口标签交换路由ID |
Egress LSR ID |
目的标签交换路由ID |
Signaling Prot |
隧道信令协议 |
Resv Style |
预留方式 |
Class Type |
服务类型 |
Tunnel BW |
隧道的带宽 |
Setup Priority |
建立优先级 |
Hold Priority |
保持优先级 |
Affinity Prop/Mask |
亲和属性/掩码 |
Explicit Path Name |
显式路径名称 |
Tie-Breaking Policy |
路由选择策略 |
Metric Type |
度量类型 |
Loop Detection |
环路检测 |
Record Route |
记录路由 |
Record Label |
记录标签 |
FRR Flag |
快速重路由标记 |
BackUpBW Flag |
备份带宽标志 |
BackUpBW Type |
备份带宽类型 |
BackUpBW |
备份带宽 |
Route Pinning |
路由固定 |
Retry Limit |
最少重建次数 |
Retry Interval |
重建间隔 |
Reopt |
重优化 |
Reopt Freq |
重优化频率 |
Back Up Type |
备份路径类型 |
Back Up LSPID |
备份LSP ID |
Auto BW |
自动带宽调整 |
Auto BW Freq |
自动带宽调整频率 |
Min BW |
自动带宽调整的最小带宽 |
Max BW |
自动带宽调整的最大带宽 |
Current Collected BW |
当前收集带宽 |
Interfaces Protected |
快速重路由保护接口 |
VPN Bind Type |
绑定类型,指明是VPN或ACL |
VPN Bind Value |
具体绑定的值,VPN实例名称或ACL号 |
Car Policy |
CAR(Committed Access Rate,承诺访问速率)策略 |
display ospf [ process-id ] mpls-te [ area area-id ] [ self-originated ]
【缺省级别】
1:监控级
process-id:OSPF进程号。
area area-id:OSPF区域号,可以是整数形式,也可以是IPv4地址形式。
self-originated:显示自产生(Self Originated)的TE LSA信息。
【描述】
display ospf mpls-te命令用来显示LSDB(链路状态数据库)中包含的所有TE LSA信息。
# 显示LSDB中包含的所有TE LSA信息。
<Sysname> display ospf mpls-te
Area ID : 0.0.0.0
Traffic Engineering LSA's of the database
LSA [ 1 ]
LSA Type : Opq-Area
Opaque Type : 1
Opaque ID : 4
Advertising Router ID : 4.4.4.4
LSA Age : 208
Length : 200
LSA Options : E O
LS Seq Number : 8000001A
CheckSum : 1EB7
Link Type : MultiAccess
Link ID : 34.1.1.2
Local Interface Address : 34.1.1.2
Remote Interface Address : 0.0.0.0
TE Metric : 1
Maximum Bandwidth : 1250000 bytes/sec
Maximum Reservable BW : 625000 bytes/sec
Admin Group : 0X0
Global Pool:
Unreserved BW [ 0] =625000 bytes/sec
Unreserved BW [ 1] =625000 bytes/sec
Unreserved BW [ 2] =625000 bytes/sec
Unreserved BW [ 3] =625000 bytes/sec
Unreserved BW [ 4] =625000 bytes/sec
Unreserved BW [ 5] =625000 bytes/sec
Unreserved BW [ 6] =625000 bytes/sec
Unreserved BW [ 7] =625000 bytes/sec
Sub Pool :
Unreserved BW [ 8] = 0 bytes/sec
Unreserved BW [ 9] = 0 bytes/sec
Unreserved BW [10] = 0 bytes/sec
Unreserved BW [11] = 0 bytes/sec
Unreserved BW [12] = 0 bytes/sec
Unreserved BW [13] = 0 bytes/sec
Unreserved BW [14] = 0 bytes/sec
Unreserved BW [15] = 0 bytes/sec
BC [ 0] =625000 bytes/sec BC [ 1] = 0 bytes/sec
Local OverBooking Multipliers:
LOM [ 0] = 1 LOM [ 1] = 1
LSA [ 2 ]
LSA Type : Opq-Area
Opaque Type : 1
Opaque ID : 0
LSA Age : 762
Length : 28
LSA Options : E O
LS Seq Number : 800000AF
CheckSum : 73A
MPLS TE Router ID : 4.4.4.4
表1-30 display ospf mpls-te命令显示信息描述表
Area ID |
使能了TE的OSPF区域的区域号 |
LSA Type |
LSA类型,为“Opq-Area”(在Opaque LSA头中携带) |
Opaque Type |
对于TE,这项值为1(在Opaque LSA头中携带) |
Opaque ID |
Opaque ID(在Opaque LSA头中携带) |
Advertising Router ID |
生成这条LSA的路由ID |
LSA Age |
LSA的年龄(在Opaque LSA头中携带) |
Length |
Opaque LSA的长度(在Opaque LSA头中携带) |
LSA Options |
LSA选项(在Opaque LSA头中携带) |
LS Seq Number |
LSA的顺序号(在Opaque LSA头中携带) |
Checksum |
LSA的校验和(在Opaque LSA头中携带) |
Link Type |
链路类型,可能是点到点(Point to Point)、点到多点(Point to Multi Point)、广播(MultiAccess) |
Link ID |
链路ID |
Local Interface Address |
本地的主IP地址 |
Remote Interface Address |
远端接口地址 |
TE Metric |
TE度量 |
Maximum bandwidth |
最大带宽 |
Maximum reservable bandwidth |
最大可预留带宽 |
Admin Group |
管理组 |
Global Pool |
全局池 |
Unreserved BW [0] to [7] |
全局池中8个级别的可用带宽 |
Sub Pool |
子池(对于DS-TE LSA有意义) |
子池中8个级别的可用带宽 |
带宽约束(对于DS-TE LSA有意义) |
BC 0–1 |
2种带宽约束(对于DS-TE LSA有意义) |
Local Overbooking Multipliers |
本地过预订倍数 |
LOM 0-1 |
2个本地过预订倍数(Local Overbooking Multipliers)(对于DS-TE LSA有意义) |
MPLS TE Router ID |
MPLS TE设备的Router ID |
display ospf [ process-id ] traffic-adjustment
【缺省级别】
1:监控级
process-id:OSPF的进程号。
【描述】
display ospf traffic-adjustment命令用来显示与流量调节(IGP shortcut及转发邻接)相关的、OSPF进程的隧道信息。
# 显示所有OSPF进程与流量调节相关的隧道信息。
<Sysname> display ospf traffic-adjustment
Traffic Adjustment
Interface: 8.1.1.1 (Tunnel5/0/2)
Type: Forwarding Adjacency State: Up
Neighbor ID: 100.0.0.2 Cost: 1562
Configuration:
Neighbor Ip Address: 100.0.0.2
Cost : 1562
Cost Type : Relative
Hold time : 10ms
表1-31 display ospf traffic-adjustment命令显示信息描述表
隧道类型接口的接口地址和接口名 |
Type |
该隧道是否用于IGP Shortcut或Forwarding Adjacency |
Neighbor ID |
隧道对端邻居的Router ID |
Cost |
开销 |
State |
状态,取值为up/down |
Neighbor Ip Address |
邻居的IP地址 |
Cost Type |
开销类型 |
Hold time |
保持时间 |
display tunnel-info { tunnel-id | all | statistics }
【缺省级别】
1:监控级
tunnel-id:指定隧道ID号。
all:所有隧道。
statistics:隧道的统计信息。
【描述】
display tunnel-info命令用来显示隧道信息。
# 显示所有隧道信息。
<Sysname> display tunnel-info all
Tunnel ID Type Destination
0x1100002 cr lsp 2.2.2.2
表1-32 display tunnel-info all命令显示信息描述表
Tunnel ID |
隧道ID |
Type |
隧道类型 |
Destination |
隧道目的地址 |
# 显示隧道的统计信息。
<Sysname> display tunnel-info statistics
Tunnel Allocation Method : GLOBAL
Avail Tunnel ID Value : 65535
Total Tunnel ID Allocated : 1
LSP : 1
GRE : 0
CRLSP : 0
LOCAL IFNET : 0
MPLS LOCAL IFNET : 0
表1-33 display tunnel-info statistics命令显示信息描述表
Tunnel Allocation Method |
隧道分配方式 |
Avail Tunnel ID Value |
有效隧道ID值 |
Total Tunnel ID Allocated |
所有已经分配隧道ID的数量 |
LSP |
隧道类型为LSP隧道的数量 |
GRE |
隧道类型为GRE隧道的数量 |
CRLSP |
隧道类型为CRLSP隧道的数量 |
LOCAL IFNET |
MPLS L2VPN中CE侧接口的数量 |
MPLS LOCAL IFNET |
MPLS L2VPN中CCC远程方式出接口的数量 |
undo enable traffic-adjustment
OSPF视图
【缺省级别】
2:系统级
无
【描述】
enable traffic-adjustment命令用来使能IGP Shortcut特性。undo enable traffic-adjustment命令用来禁止IGP Shortcut特性。
缺省情况下,未使能IGP Shortcut特性。
配置后,在进行SPF计算和泛洪(flooding)时,所有静态LSP隧道也被包括在内。
# 使能IGP Shortcut特性。
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment
undo enable traffic-adjustment advertise
OSPF视图
【缺省级别】
2:系统级
无
【描述】
enable traffic-adjustment advertise命令用来使能转发邻接特性。undo enable traffic-adjustment advertise命令用来禁止转发邻接特性。
缺省情况下,未使能转发邻接特性。
# 使能转发邻接特性。
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment advertise
explicit-path pathname [ enable | disable ]
undo explicit-path pathname
【缺省级别】
2:系统级
pathname:隧道的显式路径名称。
enable:使能显式路径。
disable:禁止显式路径。
【描述】
explicit-path命令用来创建隧道的显式路径,并进入显式路径视图。undo explicit-path命令用来删除配置的路径。
# 创建一条名为path1的显式路径,并进入显式路径视图。
list hop [ ip-address ]
显式路径视图
【缺省级别】
2:系统级
ip-address:指定IP地址。
【描述】
list hop命令用来显示显式路径的节点信息。
# 显示MPLS TE显式路径的节点信息。
[Sysname-explicit-path-path1] list hop
Path Name : path1 Path Status : Enabled
1 1.1.1.9 Strict Include
2 2.2.2.9 Strict Exclude
modify hop ip-address1 ip-address2 [ include [ strict | loose ] | exclude ]
显式路径视图
【缺省级别】
2:系统级
ip-address1 ip-address2:将显式路径中的IP地址ip-address1修改为ip-address2。可以指定链路的IP地址或节点的Router ID。
include:在显式路径中包含IP地址。
exclude:不在后续的路径计算中包括此地址。
【描述】
modify hop命令用来修改显式路径中的节点IP地址。
缺省情况下,显式路径包含指定的节点(include),修改的节点是严格下一跳(strict)。
# 将MPLS TE显式路径中的IP地址10.0.0.125修改为10.0.0.200,同时将10.0.0.200的属性设为exclude。
[Sysname-explicit-path-p1] modify hop 10.0.0.125 10.0.0.200 exclude
mpls rsvp-te
undo mpls rsvp-te
MPLS视图/VLAN接口视图/POS接口视图
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te命令用来使能RSVP-TE能力。undo mpls rsvp-te命令用来取消RSVP-TE能力。
缺省情况下,未使能RSVP-TE能力。
l 在配置其他RSVP-TE功能之前,应先使能RSVP-TE。
l 在配置此命令之前,需要分别在系统视图和接口视图下使能MPLS和MPLS TE能力。
当在MPLS视图下取消RSVP-TE能力时,将会同时取消所有接口上配置的RSVP-TE能力。
# 使能RSVP-TE特性。
[Sysname] mpls
Mpls starting, please wait... OK!
[Sysname-mpls] mpls te
Mpls te starting, please wait... OK!
[Sysname-mpls] mpls rsvp-te
# 在VLAN接口上使能RSVP-TE特性。
[Sysname] interface Vlan-interface 12
[Sysname-Vlan-interface12] mpls rsvp-te
# 取消VLAN接口上的RSVP-TE特性。
[Sysname-Vlan-interface12] undo mpls rsvp-te
mpls rsvp-te authentication { cipher | plain } auth-key
undo mpls rsvp-te authentication
【缺省级别】
2:系统级
cipher:表示密文密钥。
plain:表示明文密钥。
auth-key:验证密钥,区分大小写。如果采用明文(plain)形式,为8~16个字符的字符串;如果采用密文(cipher)形式,既可以是8~16个字符的明文,也可以是24个字符的密文。
【描述】
mpls rsvp-te authentication命令用来使能验证功能。undo mpls rsvp-te authentication命令用来禁止验证功能。
RSVP-TE传送由验证密钥和加密哈希算法生成的消息验证摘要。所有从此接口发送的报文将使用此密钥来计算消息摘要,从此接口接收的报文也将使用此密钥来验证。
& 说明:
在设备上,RSVP-TE只支持直连链路上的认证。
# 在接口Vlan-interface1上启动验证功能。
[Sysname-Vlan-interface1] mpls rsvp-te authentication plain hangzhou123
mpls rsvp-te blockade-multiplier number
undo mpls rsvp-te blockade-multiplier
MPLS视图
【缺省级别】
2:系统级
number:阻塞状态倍数。
【描述】
mpls rsvp-te blockade-multiplier命令用来配置阻塞状态超时倍数。undo mpls rsvp-te blockade-multiplier用来恢复缺省配置。
缺省情况下,阻塞状态超时倍数为4。
ResvErr消息在一个节点创建阻塞状态以解决“killer reservation”问题,这样就可以转发或创建更小的请求。
阻塞状态超时时间Blockade_Expired_Time=Kb×refresh-time。执行该命令前应先使能RSVP-TE特性。
相关配置可参考命令mpls rsvp-te timer refresh。
# 设定阻塞状态时间倍数为5。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te blockade-multiplier 5
mpls rsvp-te hello
undo mpls rsvp-te hello
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te hello命令用来使能RSVP的Hello扩展。undo mpls rsvp-te hello命令用来禁止RSVP的Hello扩展。
Hello机制用于检测邻居的存在。
缺省情况下,未使能RSVP的Hello扩展。
在接口视图下使能RSVP的Hello扩展,要先在接口视图下使能RSVP-TE,并在MPLS视图下使能RSVP的Hello扩展。
# 使能RSVP的Hello扩展。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello
# 在接口Vlan-interface1上使能RSVP的Hello扩展。
[Sysname-Vlan-interface1] mpls rsvp-te hello
mpls rsvp-te hello-lost times
undo mpls rsvp-te hello-lost
MPLS视图
【缺省级别】
2:系统级
times:最多可以接受的Hello报文丢失次数。
【描述】
mpls rsvp-te hello-lost命令用来配置允许的连续未收到Hello报文的次数。undo mpls rsvp-te hello-lost命令用来恢复缺省值。
缺省情况下,最多允许连续收不到3个Hello报文。
采用Hello机制时,如果节点连续多次未接收到对端发来的Hello应答消息,则判定链路出现故障。执行该命令之前,应先使能RSVP-TE特性。
相关配置请参考mpls rsvp-te timer hello。
# 设定节点连续未收到Hello应答的次数为5。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello-lost 5
mpls rsvp-te keep-multiplier number
undo mpls rsvp-te keep-multiplier
MPLS视图
【缺省级别】
2:系统级
number:保持倍数。
【描述】
mpls rsvp-te keep-multiplier命令用来配置PSB和RSB的超时倍数。undo mpls rsvp-te keep-multiplier命令用来恢复缺省配置。
缺省情况下,PSB和RSB的超时倍数为3。
超时时间Expired_Time=(keep-multiplier+0.5)×1.5×refresh-time。执行该命令前,应先使能RSVP-TE特性。
相关配置请参考命令mpls rsvp-te timer refresh。
# 配置保持时间倍数为5。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te keep-multiplier 5
undo mpls rsvp-te reliability
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te reliability命令用来使能可靠性功能。undo mpls rsvp-te reliability命令用来禁止可靠性功能。
# 在接口Vlan-interface1上启动可靠性机制。
[Sysname-Vlan-interface1] mpls rsvp-te reliability
undo mpls rsvp-te resvconfirm
MPLS视图
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te resvconfirm命令用来使能节点的预留确认机制。undo mpls rsvp-te resvconfirm命令用来禁止预留确认机制。
缺省情况下,节点上不使能预留确认机制。
预留确认是指对预留请求的确认。
# 在本节点使能预留确认机制。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te resvconfirm
undo mpls rsvp-te srefresh
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te srefresh 命令用来使能Srefresh(Summary Refresh,摘要刷新)功能。undo mpls rsvp-te srefresh命令用来禁止摘要刷新功能。
缺省情况下,未使能摘要刷新功能。
使能Srefresh功能将在当前接口禁用传统的时间驱动刷新。Srefresh消息用于刷新路径Path和预留Resv的状态。
# 在接口Vlan-interface1上启动Srefresh特性。
[Sysname-Vlan-interface1] mpls rsvp-te srefresh
mpls rsvp-te timer hello timevalue
undo mpls rsvp-te timer hello
MPLS视图
【缺省级别】
2:系统级
timevalue:Hello定时器时长,单位为秒。
【描述】
mpls rsvp-te timer hello命令用来配置Hello消息的刷新时间。undo mpls rsvp-te timer hello 命令用来恢复缺省配置。
缺省情况下,Hello消息刷新时间为3秒。
执行此命令前,应先在MPLS视图下启动Hello机制。
相关配置可参考命令mpls rsvp-te hello和mpls rsvp-te hello-lost。
# 配置Hello消息的刷新时间为5秒。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer hello 5
mpls rsvp-te timer refresh timevalue
undo mpls rsvp-te timer refresh
MPLS视图
【缺省级别】
2:系统级
timevalue:刷新定时器时长,单位为秒。
【描述】
mpls rsvp-te timer refresh命令用来配置节点的路径/预留消息的刷新时间。undo mpls rsvp-te timer refresh命令用来恢复缺省配置。
缺省情况下,节点的路径/预留消息的刷新时间为30秒。
执行mpls rsvp-te timer refresh命令时,应先使能RSVP-TE特性。
相关配置可参考mpls rsvp-te keep-multiplier。
# 配置每60秒发送一次路径/预留刷新消息。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer refresh 60
mpls rsvp-te timer retransmission { increment-value [ increment-value ] | retransmit-value [ retrans-timer-value ] } *
undo mpls rsvp-te timer retransmission
【缺省级别】
2:系统级
increment-value increment-value:重传增量,缺省值为1。
retransmit-value retransn-timer-value:重传定时器间隔,单位为毫秒,缺省值为500毫秒。
【描述】
mpls rsvp-te timer retransmission命令用来使能重传功能。undo mpls rsvp-te timer retransmission命令用来关闭重传功能。
缺省情况下,未使能重传功能。
# 在接口Vlan-interface1上启动重传功能,重传增量为2,重传定时器间隔为1000。
[Sysname-Vlan-interface1] mpls rsvp-te timer retransmission increment-value 2 retransmit-value 1000
mpls te
undo mpls te
MPLS视图/接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te用来使能MPLS TE能力。undo mpls te用来禁止MPLS TE能力。
l 在MPLS视图下执行mpls te命令,将使能本节点的MPLS TE能力;undo mpls te删除所有CR-LSP,禁止MPLS TE能力。
l 在接口视图下执行mpls te命令,将使能接口的MPLS TE能力;undo mpls te删除接口上所有CR-LSP,禁止接口的MPLS TE能力。
缺省情况下,未使能MPLS TE能力。
必须先全局使能本节点的MPLS TE能力,才能在接口下使能MPLS TE的能力。
注意:
在接口下使能MPLS TE时,如果用户修改了该接口的MTU,则需要shutdown、undo shutdown该接口,从而刷新TE隧道。
# 使能本节点的MPLS TE能力。
[Sysname] mpls lsr-id 1.1.1.9
[Sysname] mpls
# 使能接口Vlan-interface1的MPLS TE能力。
[Sysname-Vlan-interface1] mpls te
mpls te affinity property properties [ mask mask-value ]
undo mpls te affinity property
Tunnel接口视图
【缺省级别】
2:系统级
properties:承载隧道的链路的属性值,32位整数,每一位代表一种属性,属性值是1或0。缺省值是0x0。
mask-value:需要检查的链路属性位,32位整数,每一位代表一种属性,属性值是1或0。缺省值是0x00000000。
【描述】
mpls te affinity property命令用来配置隧道的亲和(Affinity)属性,也就是隧道使用的链路属性。undo mpls te affinity property命令用来恢复缺省情况。
缺省情况下,隧道的亲和属性为0x00000000,掩码为0x00000000。
亲和属性的掩码决定了设备需要检查哪些链路属性。
相关配置可参考命令mpls te link administrative group。
# 配置隧道的亲和属性。
[Sysname] interface Tunnel 3/0/1
[Sysname-Tunnel3/0/1] mpls te affinity property 101 mask 303
mpls te backup { hot-standby | ordinary }
undo mpls te backup
Tunnel接口视图
【缺省级别】
2:系统级
hot-standby:热备份。
ordinary:普通备份。
【描述】
mpls te backup命令用来配置当前隧道使用的备份模式。undo mpls te backup命令用来恢复缺省配置。
缺省情况下,隧道不进行备份。
& 说明:
l 对隧道使能了备份功能后,记录路由标志将被自动配置为“record reroute”,而不论用户是否配置了命令mpls te record-route。
l 隧道备份功能与以下命令互斥:mpls te reoptimization和mpls te resv-style ff。
# 使能当前隧道使用热备份。
[Sysname-Tunnel3/0/1] mpls te backup hot-standby
mpls te backup bandwidth { bandwidth | { bc0 | bc1 } { bandwidth | un-limited } }
undo mpls te backup bandwidth
Tunnel接口视图
【缺省级别】
2:系统级
bandwidth:保护隧道所能保护的带宽总量,单位为Kbit/s。
bc0:只有使用BC0带宽(全局带宽)的LSP可以使用保护隧道(Bypass Tunnel)。
bc1:只有使用BC1带宽(子池带宽)的LSP可以使用保护隧道。缺省情况下,如果没有指定BC0或BC1,则所有LSP都可以使用保护隧道。
un-limited:不对所能保护的带宽总量进行限制。
【描述】
mpls te backup bandwidth命令用来配置Bypass Tunnel可保护的带宽和LSP类型。undo mpls te backup bandwidth命令用来取消配置。
缺省情况下,Bypass Tunnel不对带宽进行保护。
如果不指定bc0或bc1,则所有LSP都可以使用旁路隧道。
# 隧道Tunnel3/0/1只用于从BC0获得带宽的LSP,并且,此隧道不提供带宽保护。隧道Tunnel3/0/2只用于从BC1获得带宽的LSP,带宽保护数目是1000。
[Sysname-Tunnel3/0/1] mpls te backup bandwidth bc0 un-limited
[Sysname] interface Tunnel 3/0/2
[Sysname-Tunnel3/0/2] mpls te backup bandwidth bc1 1000
mpls te bandwidth [ bc1 | bc0 ] bandwidth
undo mpls te bandwidth
Tunnel接口视图
【缺省级别】
2:系统级
bc1:从BC1获得带宽。
bc0:从BC0获得带宽。
bandwidth:MPLS TE隧道所需的带宽,单位为kbit/s,缺省值为0。
【描述】
mpls te bandwidth命令用来配置MPLS TE隧道所需的带宽。undo mpls te bandwidth命令用来恢复缺省配置。
缺省情况下,未配置MPLS TE隧道所需的带宽,即带宽为0。
配置带宽时,如果不指定bc1或bc0,将使用全局池(bc0)。
# 配置MPLS TE隧道所需带宽为1000kbit/s。
[Sysname-Tunnel3/0/1] mpls te bandwidth 1000
mpls te bandwidth change thresholds { down | up } percent
undo mpls te bandwidth change thresholds { down | up }
【缺省级别】
2:系统级
down:配置资源减少时IGP进行泛洪的百分比阈值。当链路可用带宽的减少值与链路原有可用带宽的比值大于此百分比阈值时,IGP将进行泛洪,并更新流量工程数据库。
up:配置资源增加时的IGP进行泛洪的百分比阈值。当链路可用带宽的增加值与链路原有可用带宽的比值大于此百分比阈值时,IGP将进行泛洪,并更新流量工程数据库。
percent:配置带宽阈值水平。
【描述】
mpls te bandwidth change thresholds命令用来配置带宽变化IGP泛洪阈值。undo mpls te bandwidth change thresholds命令用来恢复缺省配置。
缺省情况下,带宽变化IGP泛洪阈值为10。
# 在接口Vlan-interface1上配置链路带宽变化阈值,可预留带宽低于100%时进行泛洪。
[Sysname-Vlan-interface1] mpls te bandwidth change thresholds down 100
mpls te commit
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te commit命令用来提交隧道当前配置。
在执行mpls te commit命令之前,对MPLS TE隧道的配置不会生效。
# 配置一条MPLS TE隧道,并提交配置。
[Sysname] interface tunnel 3/0/0
[Sysname-Tunnel3/0/0] tunnel-protocol mpls te
[Sysname-Tunnel3/0/0] destination 2.2.2.9
[Sysname-Tunnel3/0/0] mpls te commit
mpls te cspf
undo mpls te cspf
MPLS视图
【缺省级别】
1:监控级
无
【描述】
mpls te cspf命令用来使能本节点的CSPF功能。undo mpls te cspf命令用来禁止本节点的CSPF功能。
缺省情况下,未使能本节点的CSPF功能。
使能CSPF前,应先在MPLS视图下使能MPLS TE。
CSPF提供了一种在MPLS域中选择路径的方法。必须先使能CSPF,才能配置其他CSPF相关功能。
# 使能CSPF。
[Sysname] mpls
[Sysname-mpls] mpls te cspf
mpls te cspf timer failed-link timer-interval
undo mpls te cspf timer failed-link
MPLS视图
【缺省级别】
1:监控级
timer-interval:失效链路时间间隔,单位为秒。缺省值为10秒。
【描述】
mpls te cspf timer failed-link命令用来配置失效链路定时器值。undo mpls te cspf timer failed-link命令用来恢复缺省配置。
相关配置可参考命令mpls te cspf。
# 配置失效链路定时器的时长为50秒。
[Sysname] mpls
[Sysname-mpls] mpls te cspf timer failed-link 50
undo mpls te fast-reroute
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te fast-reroute命令用来使能快速重路由功能。undo mpls te fast-reroute命令用来禁止快速重路由功能。
缺省情况下,未使能快速重路由功能。
对Tunnel接口使能快速重路由功能后,记录路由标志将自动配置“record reroute with label”,而不论用户是否配置了命令mpls te record-route label。如果用户需要配置mpls te record-route或undo mpls te record-route,必须先禁用快速重路由功能。
& 说明:
快速重路由功能与以下命令互斥:mpls te resv-style ff。
# 当一条链路失效时,使能MPLS TE隧道使用一条已经存在的备份隧道。
[Sysname-Tunnel3/0/1] mpls te fast-reroute
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
undo mpls te fast-reroute bypass-tunnel tunnel tunnel-number
【缺省级别】
2:系统级
tunnel-number:备份隧道的编号。
【描述】
mpls te fast-reroute bypass-tunnel命令用来为被保护的接口指定一条或多条旁路隧道。undo mpls te fast-reroute bypass-tunnel命令用来删除配置的旁路隧道。
如果需要为被保护的接口指定多条旁路隧道,可以多次使用mpls te fast-reroute bypass-tunnel命令。最多可以为被保护的接口指定3条旁路隧道。
为接口指定旁路隧道,需要满足以下条件:
l 旁路隧道必须是up状态的;
l 被保护的接口不是路由的下一跳的出接口。
& 说明:
被指定为Bypass隧道后,该隧道不能做为VPN等业务的隧道使用。
# 使用隧道接口tunnel3/0/2作为备份隧道。
[Sysname-Vlan-interface1] mpls te fast-reroute bypass-tunnel tunnel 3/0/2
mpls te igp advertise [ hold-time value ]
undo mpls te igp advertise
Tunnel接口视图
【缺省级别】
2:系统级
hold-time value:TE隧道状态转为down后到通知网络之前等待的时间,单位为毫秒,缺省值为0毫秒。
【描述】
mpls te igp advertise命令用来将MPLS TE隧道作为链路发布到IGP网络。undo mpls te igp advertise命令用来取消配置。
缺省情况下,MPLS TE隧道不被作为链路发布到IGP网络。
& 说明:
mpls te igp advertise命令与mpls te igp shortcut命令互斥。
# 配置保持时间为10000毫秒。
[Sysname] interface Tunnel 3/0/0
[Sysname-Tunnel3/0/0] mpls te igp advertise hold-time 10000
mpls te igp metric { absolute value | relative value }
undo mpls te igp metric
Tunnel接口视图
【缺省级别】
2:系统级
absolute value:绝对度量模式。value,正整数。
relative value:相对度量模式。可以是正整数、负整数或0,表示相对于隧道IGP度量的差异。缺省值为0。
【描述】
mpls te igp metric命令用来配置MPLS TE隧道的度量值。undo mpls te igp metric命令用来恢复缺省配置。
缺省情况下,TE隧道的度量等于其IGP度量。
# 配置IGP增强的SPF计算使用MPLS TE隧道相对值-1。
[Sysname-Tunnel3/0/0] mpls te igp metric relative -1
mpls te igp shortcut [ is-is | ospf ]
undo mpls te igp shortcut
Tunnel接口视图
【缺省级别】
2:系统级
is-is:IS-IS协议。
ospf:OSPF协议。
【描述】
mpls te igp shortcut命令用来配置IGP在进行增强的SPF计算时,使用处于up状态的MPLS TE隧道。undo mpls te igp shortcut命令用来取消这一功能。
如果不指定IGP类型,则ospf和is-is都支持。
缺省情况下,IGP在进行增强的SPF计算时不使用MPLS TE隧道。
& 说明:
mpls te igp shortcut命令与mpls te igp advertise命令互斥。
# 配置如果Tunnel3/0/0处于Up状态,则OSPF和IS-IS在进行增强的SPF计算时都要使用此隧道。
[Sysname-Tunnel3/0/0] mpls te igp shortcut
mpls te link administrative group value
undo mpls te link administrative group
【缺省级别】
2:系统级
value:链路属性,在选路时将与隧道的affinity位进行比较。表示32个属性,每个属性占一位,属性值为0或1。
【描述】
mpls te link administrative group命令用来配置链路管理组属性值。undo mpls te link administrative group命令用来恢复缺省配置。
缺省情况下,链路管理组属性的值为0x0。
接口属性被全局范围内扩散,从而可以用作隧道源端的路径选择标准。
相关配置可参考命令mpls te affinity property。
# 在接口Vlan-interface1上配置用户相关属性标志为0x0101。
[Sysname-Vlan-interface1] mpls te link administrative group 101
mpls te loop-detection
undo mpls te loop-detection
Tunnel接口视图
无
【缺省级别】
2:系统级
【描述】
mpls te loop-detection命令用来配置隧道建立时进行环路检测。undo mpls te loop-detection命令用来取消环路检测功能。
缺省情况下,不进行环路检测。
# 指定建立MPLS TE隧道时进行环路检测:
[Sysname] interface Tunnel 1/0/0
[Sysname-Tunnel1/0/0] mpls te loop-detection
mpls te max-link-bandwidth bandwidth-value [ bc1 bc1-bandwidth ]
undo mpls te max-link-bandwidth
【缺省级别】
2:系统级
bandwidth-value:RSVP流可分配的最大带宽,单位为Kbit/s。
bc1 bc1-bandwidth:接口上可预留的带宽,单位为Kbit/s。
【描述】
mpls te max-link-bandwidth命令用来配置链路的最大带宽。undo mpls te max-link-bandwidth命令用来取消链路的最大带宽配置。
配置的链路最大带宽既可用于MPLS流量,也可用于普通的Best-Effort流量。
# 配置链路最大带宽为1158kbit/s,但VLAN接口上的任意给定流带宽不超过100kbit/s。BC1的最大链路带宽为200kbit/s。
[Sysname] interface Vlan-interface 3
[Sysname-Vlan-interface3] mpls te max-link-bandwidth 1158 bc1 200
mpls te max-reservable-bandwidth bandwidth-value [ bc1 bc1-bandwidth ]
undo mpls te max-reservable-bandwidth
【缺省级别】
2:系统级
bandwidth-value:RSVP流所能分配的最大带宽,单位为kbit/s。(全局池带宽)
bc1 bc1-bandwidth:总带宽中接口可预留的带宽,单位为kbit/s。(子池带宽)
【描述】
mpls te max-reservable-bandwidth命令用来配置链路最大可预留带宽。undo mpls te max-reservable-bandwidth命令用来取消配置。
配置链路最大可预留带宽只能用于MPLS流量。
# 配置链路上最多允许MPLS-TE预留1158kbit/s的带宽,但VLAN接口上任意给定流的带宽不超过100kbit/s。BC1的最大可预留带宽为200kbit/s。
[Sysname-Vlan-interface1] mpls te max-reservable-bandwidth 1158 bc1 200
mpls te metric value
undo mpls te metric
【缺省级别】
2:系统级
value:链路的TE度量值。
【描述】
mpls te metric命令用来配置链路的TE度量。undo mpls te metric命令用来取消配置。
缺省情况下,链路使用其IGP度量作为TE的度量。
相关配置请参考命令mpls te path metric-type。
# 配置链路的TE度量为20。
[Sysname-Vlan-interface12] mpls te metric 20
mpls te path explicit-path pathname
undo mpls te path
Tunnel接口视图
【缺省级别】
2:系统级
pathname:MPLS-TE显式路径名称。
【描述】
mpls te path explicit-path命令用来配置隧道应用已经存在的显式路径。undo mpls te path命令用来删除配置。
# 配置为Tunnel3/0/1使用显式路径path1。
[Sysname-Tunnel3/0/1] mpls te path explicit-path path1
mpls te path metric-type { igp | te }
undo mpls te path metric-type
MPLS视图/Tunnel接口视图
【缺省级别】
2:系统级
igp:使用IGP度量。
te:使用TE度量。
【描述】
在MPLS视图下,mpls te path metric-type命令用来配置未配置度量类型的隧道选路时使用的链路度量类型。
在Tunnel接口视图下,mpls te path metric-type命令用来配置为当前隧道选路时使用的链路度量类型。
undo mpls te path metric-type命令只用在Tunnel接口视图下,用于恢复缺省配置。
缺省情况下,选路时使用链路的TE度量。
相关配置请参考命令mpls te metric。
# 对所有未指定度量类型的TE隧道,配置其在进行路径计算时使用IGP度量。
[Sysname] mpls
[Sysname-mpls] mpls te path metric-type igp
# 配置为Tunnel3/0/1计算路径时使用IGP度量。
[Sysname-Tunnel3/0/1] mpls te path metric-type igp
mpls te priority setup-priority [ hold-priority ]
undo mpls te priority
Tunnel接口视图
【缺省级别】
2:系统级
setup-priority:建立优先级。
hold-priority:保持优先级,缺省情况下与建立优先级相同。
【描述】
mpls te priority命令用来配置MPLS TE隧道的建立优先级和保持优先级。undo mpls te priority命令用来恢复缺省配置。
缺省情况下,建立优先级和保持优先级的值都为7。
建立优先级不能高于相应的保持优先级,即,其在数值上应大于保持优先级的值。
# 配置建立优先级和保持优先级都为1。
[Sysname-Tunnel3/0/1] mpls te priority 1
mpls te record-route [ label ]
Tunnel接口视图
【缺省级别】
2:系统级
label:使能路由记录特性时包含对标签的记录。
【描述】
mpls te record-route命令用来配置隧道支持路由记录或标签记录。undo mpls te record-route命令用来取消该配置。
缺省情况下,不进行路由记录和标签记录。
# 配置MPLS TE隧道支持路由记录。
[Sysname-Tunnel3/0/1] mpls te record-route
【缺省级别】
2:系统级
无
【描述】
mpls te reoptimization命令用来立即对所有使能了重优化功能的TE隧道进行重优化。
# 立即对所有使能了重优化功能的TE隧道进行重优化。
<Sysname> mpls te reoptimization
mpls te reoptimization [ frequency seconds ]
undo mpls te reoptimization
Tunnel接口视图
【缺省级别】
2:系统级
seconds:重优化频率,单位为秒。缺省值为3600秒,即1小时。
【描述】
mpls te reoptimization命令用来使能隧道重优化功能。undo mpls te reoptimization命令用来禁止此功能。
缺省情况下,未使能重优化功能。
& 说明:
隧道重优化功能与以下命令互斥:
mpls te route-pinning,mpls te backup和mpls te resv-style ff。
# 使能重优化功能,并配置每隔43200秒(12小时)重新计算路由。
[Sysname-Tunnel3/0/1] mpls te reoptimization frequency 43200
mpls te resv-style { ff | se }
undo mpls te resv-style
Tunnel接口视图
【缺省级别】
2:系统级
ff:使用FF(Fixed-Filter)样式的资源预留。
se:使用SE(Shared-Explicit)样式的资源预留。
【描述】
mpls te resv-style命令用来配置隧道的资源预留风格。undo mpls te resv-style命令用来恢复缺省情况。
缺省情况下,资源预留样式为se。
只有RSVP-TE协议才存在FF和SE两种资源预留样式。
# 使用FF资源预留样式建立CR-LSP隧道。
[Sysname-Tunnel1/0/0] mpls te signal-protocol rsvp-te
[Sysname-Tunnel1/0/0] mpls te resv-style ff
mpls te retry times
undo mpls te retry
Tunnel接口视图
【缺省级别】
2:系统级
times:重建次数。
【描述】
mpls te retry命令用来配置隧道重建的次数,undo mpls te retry命令用来恢复缺省配置。
缺省情况下,隧道重建的次数为5。
相关配置请参考命令mpls te timer retry。
# 配置隧道重建次数为10次。
[Sysname-Tunnel1/0/0] mpls te retry 10
undo mpls te route-pinning
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te route-pinning命令用来配置路由固定(route pinning)功能。undo mpls te route-pinning命令用来禁止此功能。
缺省情况下,禁止路由固定功能。
& 说明:
mpls te route-pinning命令与mpls te reoptimization命令互斥。
# 使能路由固定功能。
[Sysname-Tunnel3/0/1] mpls te route-pinning
mpls te signal-protocol { rsvp-te | static }
Tunnel接口视图
【缺省级别】
2:系统级
rsvp-te:使用RSVP-TE作为信令协议。
static:使用静态信令协议。
【描述】
mpls te signal-protocol命令用来配置MPLS TE建立隧道使用的信令协议。
缺省情况下,配置MPLS TE建立隧道使用RSVP-TE信令协议。
注意:
如果使用RSVP-TE作为MPLS TE隧道的信令协议,那么必须在隧道经过的路径上,使能接口的MPLS TE能力的同时使能接口的RSVP-TE能力。
# 配置MPLS TE建立隧道使用RSVP-TE信令协议。
[Sysname-Tunnel3/0/1] mpls te signal-protocol rsvp-te
mpls te tie-breaking { least-fill | most-fill | random }
undo mpls te tie-breaking
MPLS视图、Tunnel接口视图
【缺省级别】
2:系统级
least-fill:优先选择带宽使用率(已用带宽/链路最大可预留带宽)最小的路径。
most-fill:优先选择带宽使用率(已用带宽/链路最大可预留带宽)最大的路径。
random:随机选择路径。
【描述】
mpls te tie-breaking命令用来配置CR-LSP仲裁方法。undo mpls te tie-breaking命令用来恢复缺省情况。
缺省情况下,采用随机选择方式(random)。
& 说明:
隧道优先使用本隧道视图下配置的仲裁方式,如果隧道视图下没有配置,将使用MPLS视图下的配置。
# 配置当前隧道接口优选可用带宽最多的路径。
[Sysname-Tunnel3/0/1] mpls te tie-breaking least-fill
# 配置优选可用带宽最多的路径。
[Sysname] mpls
[Sysname-mpls] mpls te tie-breaking least-fill
mpls te timer fast-reroute [ seconds]
undo mpls te timer fast-reroute
MPLS视图
【缺省级别】
2:系统级
seconds:为决定一条LSP是否应使用新的、更好的备份隧道而进行的扫描的间隔,单位为秒,缺省值为300秒(5分钟)。配置为0表示禁止使用更好的LSP。
【描述】
mpls te timer fast-reroute命令用来配置当备份带宽可用时,设备每隔多长时间决定一次是否需要将LSP转移到一条更好的备份隧道。undo mpls te timer fast-reroute命令用来禁止此功能,即,将扫描间隔配置为0。
缺省情况下,扫描间隔为300秒。
# 配置每隔2分钟(120秒),对LSP进行一次扫描,决定是否需要将它们切换到更好的备份隧道。
[Sysname] mpls
[Sysname-mpls] mpls te timer fast-reroute 120
mpls te timer retry second
undo mpls te timer retry
Tunnel接口视图
【缺省级别】
2:系统级
second:隧道重建的时间间隔,单位为秒。
【描述】
mpls te timer retry命令用来配置隧道重建的时间间隔。undo mpls te timer retry命令用来恢复缺省配置。
缺省情况下,隧道重建的时间间隔为10秒。
相关配置请参考命令mpls te retry。
# 配置每隔20秒重建隧道。
[Sysname-Tunnel3/0/1] mpls te timer retry 20
mpls te vpn-binding { acl acl-number | vpn-instance vpn-instance-name }
undo mpls te vpn-binding
Tunnel接口视图
【缺省级别】
2:系统级
acl-number:ACL编号。配置TE隧道只转发满足此ACL过滤条件的流量。
vpn-instance-name:VPN实例的名称。配置TE隧道只转发此VPN实例的流量。
【描述】
mpls te vpn-binding命令用来配置TE隧道转发的流量类型。undo mpls te vpn-binding命令用来恢复缺省配置。
缺省情况下,TE隧道不限制可以转发的流量类型。
# 配置隧道接口只转发名为vpn1的VPN实例的流量。
[Sysname-Tunnel1/0/0] mpls te vpn-binding vpn-instance vpn1
mpls-te enable
undo mpls-te
OSPF区域视图
【缺省级别】
2:系统级
enable:使能MPLS TE特性。
【描述】
mpls-te命令用来在当前OSPF区域下使能MPLS TE能力。undo mpls-te命令用来取消当前OSPF区域的MPLS TE能力。
缺省情况下,OSPF区域不支持TE。
为了在区域上使能MPLS TE,相应的OSPF进程应具备Opaque LSA能力。
相关配置请参考命令opaque-capability。
# 在OSPF区域1使能TE。
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] mpls-te enable
next hop ip-address [ include [ strict | loose ] | exclude ]
显式路径视图
【缺省级别】
2:系统级
ip-address:显式路径中的下一跳IP地址,点分十进制格式。可以是链路的IP地址,也可以是节点的Router ID。对于严格(strict)方式,只能配置链路IP.对于松散(loose)方式,链路地址则认为指明链路对应的Router。
include:在显式路径中包含下一跳IP地址。
strict:严格下一跳,即下一跳与本节点必须直接相连。
loose:松散下一跳,即下一跳与本节点可以不是直接相连。
exclude:在后续的部分路径段中不包括IP地址。
【描述】
next hop命令用来在显式路径中指定下一跳IP地址。
缺省情况下,显式路径中指定的下一跳为严格(strict)下一跳。
相关配置可参考命令delete hop。
# 在MPLS TE显式路径中不包括IP地址10.0.0.125。
[Sysname-explicit-path-p1] next hop 10.0.0.125 exclude
opaque-capability enable
undo opaque-capability
OSPF视图
【缺省级别】
2:系统级
enable:使能Opaque LSA能力。
【描述】
opaque-capability命令用来使能OSPF的Opaque LSA能力。undo opaque-capability命令用来禁止OSPF的Opaque LSA能力。
缺省情况下,未使能OSPF的Opaque LSA能力。
使能OSPF的Opaque LSA能力后,OSPF进程可以生成Opaque LSA,并能从邻居设备接收Opaque LSA。
# 使能OSPF进程的Opaque LSA能力。
[Sysname] ospf 100
[Sysname-ospf-100] opaque-capability enable
reset mpls rsvp-te statistics { global | interface [ interface-type interface-number ]
【缺省级别】
1:监控级
global:全局RSVP-TE。
【描述】
reset mpls rsvp-te statistics命令用来清除RSVP-TE的统计信息。
l 如果选择参数global,则清除全局RSVP-TE的统计信息;
l 如果选择参数interface,则清除所有接口RSVP-TE的统计信息;
l 如果选择参数interface interface-type interface-number,则清除指定接口RSVP-TE的统计信息。
# 清除全局RSVP-TE的统计信息。
<Sysname> reset mpls rsvp-te statistics global
static-cr-lsp egress tunnel-name incoming-interface interface-type interface-number in-label in-label-value
undo static-cr-lsp egress tunnel-name
【缺省级别】
2:系统级
tunnel-name:隧道名称。
in-label-value:入标签。
【描述】
static-cr-lsp egress命令用来在出口节点配置静态CR-LSP。undo static-cr-lsp egress命令用来在出口节点删除配置的静态CR-LSP。
# 在出口节点配置静态CR-LSP,名字为Tunnel4/0/3,入接口是Vlan-interface 12,入口标签是233。
[Sysname] static-cr-lsp egress Tunnel4/0/3 incoming-interface Vlan-interface 12 in-label 233
static-cr-lsp ingress tunnel-name destination dest-addr { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ bc1 | bc0 ] bandwidth-value ]
undo static-cr-lsp ingress tunnel-name
【缺省级别】
2:系统级
tunnel-name:隧道名称,要求与interface tunnel命令创建的接口形式必须保持一致,否则隧道将不能建立。例如建立的隧道接口为“Tunnel2/0/0”,此处的隧道名也必须为“Tunnel2/0/0”。
next-hop-addr:下一跳地址。
outgoing-interface interface-type interface-number:指定接口类型和接口编号。
out-label-value:出标签。
bc1:配置从全局池获取带宽。
bc0:配置从子池获取带宽。
bandwidth-value:CR-LSP所需的带宽,单位为kbit/s。
【描述】
static-cr-lsp ingress命令用来在入口节点配置静态CR-LSP。undo static-cr-lsp ingress命令用来在入口节点删除配置的静态CR-LSP。
& 说明:
l static-cr-lsp ingress命令的参数tunnel-name大小写敏感。假设使用命令interface tunnel 2/0/0创建了一个Tunnel接口,则其静态CR-LSP入节点中的参数应该写作“Tunnel2/0/0”,否则隧道将不能正确建立。中间节点和出节点无此限制。
l 本地公网IP地址不能被指定为下一跳。
# 在入口节点配置静态CR-LSP。名字为Tunnel4/0/1,目的IP地址为202.25.38.1,目的地址掩码长度为24,下一跳IP地址为202.55.25.33,出口标签为237,所需要的带宽为20kbit/s。
[Sysname] static-cr-lsp ingress Tunnel4/0/1 destination 202.25.38.1 nexthop 202.55.25.33 out-label 237 bandwidth 20
static-cr-lsp transit tunnel-name incoming-interface interface-type interface-number in-label in-label-value { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ bc1 | bc0 ] bandwidth-value ]
undo static-cr-lsp transit tunnel-name
【缺省级别】
2:系统级
tunnel-name:隧道名称。
in-label-value:入标签。
bc0:配置从子池获取带宽。
bc1:配置从全局池获取带宽。
【描述】
static-cr-lsp transit命令用来在转发节点配置静态CR-LSP。undo static-cr-lsp transit命令用来在转发节点删除配置的静态CR-LSP。
& 说明:
本地公网IP地址不能被指定为下一跳。
# 在转发节点配置静态CR-LSP,名字为Tunnel4/0/3,入接口为Vlan-interface 12,入口标签为123,下一跳地址为3.2.1.2,出口标签为30。
[Sysname] static-cr-lsp transit Tunnel4/0/3 incoming-interface Vlan-interface 12 in-label 123 nexthop 3.2.1.2 out-label 30
traffic-eng [ level-1 | level-2 | level-1-2 ]
undo traffic-eng [ level-1 | level-2 | level-1-2 ]
IS-IS视图
【缺省级别】
2:系统级
level-1:配置Level-1的IS-IS TE。
level-2:配置Level-2的IS-IS TE。
level-1-2:配置Level-1和Level-2的IS-IS TE。
& 说明:
如果命令中不指定Level,则对Level-1-2有效。
【描述】
traffic-eng命令用来使能IS-IS的TE特性。undo traffic-eng命令用来恢复缺省配置。
如果不指定中间系统IS的级别,将对Level-1-2有效。
缺省情况下,未使能IS-IS TE功能。
& 说明:
为了在IS-IS进程使用TE特性,必须将IS-IS报文的cost类型配置为wide、compatible或wide-compatible,使用的命令是IS-IS视图下的cost-style,这条命令的详细介绍请参考IP路由分册。
# 在IS-IS进程1的Level-2上使能TE特性。
[Sysname] isis 1
[Sysname-isis-1] cost-style compatible
[Sysname-isis-1] traffic-eng level-2
