As AI computing demands continue to scale, high-speed interconnects in data centers are rapidly transitioning to 224 Gb/s, placing increasingly stringent demands on signal integrity (SI). H3C has recently presented two technical papers at IMPACT-IAAC 2026 (International Microsystems, Packaging, Assembly and Circuits Technology Conference) and IEEE EPEPS 2026 (the 35th Conference on Electrical Performance of Electronic Packaging and Systems). Addressing signal integrity challenges in ultra-high-speed data transmission, the research introduces engineering-ready design optimizations for 224G interconnects. The findings provide verifiable technical guidance for high-speed interconnects in AI computing networks and lay important groundwork for the development of next-generation 448G interconnect technology.
Addressing the Bottlenecks of 224G Data Transmission
Data center switch ASICs are moving from 112G to 224G per lane. This transition, however, is far more than a linear increase in speed. The constraints on channel bandwidth, insertion loss margin and impedance control become substantially tighter. Compared with 112G, 224G PAM4 doubles the symbol rate, causing interconnect losses to rise rapidly at high frequencies and significantly reducing the link margin available to PCB channels. At the same time, the high-density fan-out requirements of advanced chips often call for complex multi-layer HDI PCB structures. Via parasitics, reference-plane integrity and differential-trace losses have consequently become critical bottlenecks to signal integrity.
Achieving stable 224G signal transmission within tight constraints on physical space and cost has become a key challenge for the industry. H3C’s R&D team conducted a systematic investigation of signal-transmission mechanisms, from individual vias to complete channels. The team developed an engineering-oriented approach that reduces reliance on premium, ultra-low-loss PCB materials while balancing performance and cost.
From Individual Vias to End-to-End Channels: A System-Level Design Approach
The two papers establish a comprehensive design methodology for 224G HDI PCBs, addressing two critical dimensions: impedance continuity at the via level and loss performance across the overall transmission channel.
Optimizing Via Design for Consistent Impedance Performance
Presented at IMPACT-IAAC 2026, a conference with a strong focus on industry applications in the Asia-Pacific region, the paper “Design Optimization and Electrical Characterization for 224 Gb/s Vias in High-Density Interconnect (HDI) Printed Circuit Boards (PCBs)” focuses on improving performance at the via level.
Addressing vias—one of the signal-integrity weak points in multi-layer HDI PCBs—the study examines the underlying physical mechanisms of via parasitic inductance and capacitance. It proposes a differentiated optimization strategy based on ranges of inner-layer core thickness. This approach helps maintain impedance continuity and meet return-loss targets across different board-thickness configurations, addressing the industry challenge of inconsistent via performance in multi-layer HDI PCB designs.
Reducing Channel Loss Through Coordinated Reference-Plane Design
The second paper, “Design Optimization for 224 Gb/s Channels in High-Density Interconnect Printed Circuit Boards,” was presented at IEEE EPEPS 2026, a leading conference in the field of signal and power integrity (SI/PI) organized by the IEEE Electronics Packaging Society. Moving from individual vias to the channel as a whole, the paper proposes an innovative reference-plane architecture for multi-layer HDI PCB designs.
The architecture significantly reduces insertion loss per unit length in multi-layer HDI designs while effectively suppressing crosstalk. It accommodates the routing demands of high-density chip fan-out while meeting the stringent channel-loss budget for 224 Gb/s signaling. EPEPS 2026 recognized the work for its contributions to electromagnetic theory, modeling and simulation.
Engineering Validation and Industry Impact
Together, the two studies complete an engineering validation loop, translating simulation-based analysis of the underlying mechanisms into practical design methods. By optimizing the design, the methodology makes better use of the capabilities of existing PCB materials while maintaining signal integrity, reducing excessive dependence on costly ultra-low-loss laminates.
This approach can help mitigate hardware cost pressures and supply-chain risks for 224G data center switches. It also provides reusable SI design guidelines for key challenges in ASIC fan-out channels, helping accelerate the development of 224G data center switch products. As an example of innovation in the foundational technologies behind advanced networking equipment, the work contributes engineering solutions to the global high-speed interconnect community and builds a valuable technology base for the evolution of next-generation 448G AI computing networks.
As AI infrastructure continues to evolve, H3C Group will remain focused on foundational hardware technologies, including high-speed interconnects. The company will continue to strengthen its end-to-end hardware engineering and innovation capabilities, bringing more advanced research into commercially viable, production-ready solutions and helping build a robust hardware foundation for reliable, high-performance intelligent computing networks.
