WHITE PAPER
Wi-Fi 7 Technology White Paper
2025-03-10 5 min read
Topics:
    The first 802.11 standard provides a data rate up to 2 Mbps in the 2.4 GHz frequency band. 802.11b used a new encoding method to increase the rate to 11 Mbps. 802.11a introduced OFDM technology and uses 64-QAM modulation to increase the wireless rate to 54 Mbps at the 5 GHz frequency band. 802.11g applied the technology used in 802.11a to the 2.4 GHz frequency band, increasing the rate of the 2.4 GHz frequency band to 54 Mbps. Until 802.11ax, the data rate had increased by about 10000 times.
    Evolving applications such as VR/AR, 4K/8K video, metaverse, online gaming, and cloud computing have higher throughput, lower latency, more concurrent sessions, higher security, higher availability, and higher energy saving requirements. The current Wi-Fi standards cannot address these requirements. To address these new challenges, the IEEE 802.11be EHT working group was established to develop the Wi-Fi 7 standard to optimize the current standards from network throughput, interference suppression, spectrum efficiency, and latency optimization. Wi-Fi 7, also called IEEE 802.11be, will be released in two versions. Release 1 Draft 1.3 has been completed, and will be released by the end of 2022. Release 2 is expected to be launched in 2022 and will be released by the end of 2024.
    You may also like
    REPORTS
    Beyond Market Leadership: How H3C is Advancing the Agentic AI-Defined Network Era
    2026-08-07
    According to IDC’s latest China Quarterly Network Tracker, H3C maintained its leading position in China’s enterprise networking market in Q1 2026, achieving a 37% market share.
    VIDEOS
    Next-Generation High-Density 800G AI Computing Network Switch
    2026-03-31
    H3C S9828-128EP - Next-Generation High-Density 800G AI Computing Network Switch
    CASES
    H3C × MMMH&MC: Transforming Healthcare with Unified Network Infrastructure
    2025-12-18
    Mariano Marcos Memorial Hospital and Medical Center (MMMH&MC), a leading government healthcare institution in Northern Philippines, continues its mission to provide quality healthcare amid increasing patient demand and expanded bed capacity.
    CASES
    H3C & PLAION: Powering a New Era of Global Game Publishing with Intelligent SD-WAN
    2025-12-18
    "This partnership redefines what's possible. Network is no longer just plumbing – it's a strategic innovation platform. "
    CASES
    IT Supporting Teaching at LifeTech ITS Academy in Trieste
    2025-12-18
    LifeTech ITS Academy in Trieste has recently stood out at the national level for implementing a modern desktop and graphics-workstation virtualization infrastructure, designed to radically innovate the approach to technical and scientific education.
