H3Care Total Implementation
15-11-2019
  • LinkedIn
  • facebook
  • Twitter
HomeSupportPolicyService and Support PolicyRouters & SwitchProfessional Service
H3C provides the Total Implementation to fulfill network construction, expansion and reconstruction. For the Total Implementation, H3C will designate a project manager and senior engineers to guide the first-line work.
(1)Major contents:
Project management
Hardware installation
>         Human resources management
>         Implementation progress management
>         Project management plan
>         Project coordination meeting
>         Project survey for installation sites
>         Hardware environment check for installation sites
>         Hardware installation scheme
>         Onsite hardware installation
Software debugging
Project document
>         Joint debugging solution making
>         Software version provision
>         Parameter configuration
>         Cutover solution
Project Information Table
H3C Project Quality Check Standard
Technical Implementation Summary Report
H3C Routine Equipment Maintenance Proposal
Project acceptance
>         Acceptance plan making
>         Technical specification provision
>         Project acceptance solution
>         Project acceptance implementation
(2)Implementation process:
Project team setup: Determine a project manager and set up an implementation team.
Project preparation: Hold a kickoff coordination meeting, determine the implementation solution, and guide the customer to make project preparations.
Project implementation: Conduct the unpacking inspection, hardware installation, software debugging and project quality management.
Project test and preliminary acceptance: Work with the customer to implement the project test and preliminary acceptance (if necessary).
Cutover for network access: Work with the customer to accomplish the cutover of network devices.
Project document delivery: Deliver the technical documents to the customer.
Project acceptance: Implement the project acceptance.
