10-High Availability Command Reference
HomeSupportSwitchesH3C S9800 Switch SeriesReference GuidesCommand ReferencesH3C S9800 Switch Series Command References-Release 215x-6W10110-High Availability Command Reference
Download Book
Title Size Downloads
10-High Availability Command Reference-book.pdf 430.31 KB
Preface
This command reference describes fault detection and fast failover configuration commands. With these commands, you can detect and diagnose your network, and rapidly recover your network when failures occur.
·     Audience
·     Conventions
·     Obtaining documentation
·     Technical support
·     Documentation feedback
Audience
·     Network planners.
·     Network administrators working with the S9800 switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
To access the most up-to-date H3C product documentation, go to the H3C website at
http://www.h3c.com.hk
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
service@h3c.com
We appreciate your comments.
