Title | Size | Downloads |
00-About the S9800 Configuration Guides-book.pdf | 56.86 KB |
About the H3C S9800 configuration guides
Configuration guide |
Content |
Fundamentals Configuration Guide |
Describes how to use the command line interface of the switch, log in to and set up the switch, and use the basic management functions. This guide includes: · CLI (command line interface overview and how to use the CLI) · Logging in to the switch (log-in methods such as telnet, and user interface configuration and access control) · RBAC · FTP and TFTP · File system management · Configuration file management · Software upgrade · Device management · Python |
IRF Configuration Guide |
Describes the H3C proprietary Intelligent Resilient Framework (IRF) technology, which provides data center class availability and scalability. IRF creates a fabric from multiple switches. The switches that form the IRF fabric work in 1:N redundancy and appear as one unit in the network. IRF improves management efficiency and streamlines network topologies. It is suitable for highly reliable enterprise networks and data centers. |
Layer 2—LAN Switching Configuration Guide |
Covers Layer 2 technologies and features used on a LAN switched network, such as VLAN technology, port isolation, Spanning Tree. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN, and so on. This guide includes: · Ethernet interface · Loopback, null, and inloopback interfaces · Bulk interface configuration · MAC address table and MAC Information · Ethernet link aggregation · Port isolation · Spanning tree protocols · Loop detection · VLAN · LLDP |
Layer 3—IP Services Configuration Guide |
Describes how to configure ARP, IP addressing, IP performance optimization, IP forwarding basics, DHCP, DNS, UDP helper. This guide includes: · ARP (including gratuitous ARP, proxy ARP) · DHCP (DHCP overview, DHCP relay agent, DHCP client, DHCP snooping) · Basic IP forwarding and load sharing · IP performance optimization |
Layer 3—IP Routing Configuration Guide |
Covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering. This guide includes: · IP routing basics · Static routing (including default route configuration) · RIP · OSPF · IS-IS · BGP · Policy-based routing · Routing policy |
IP Multicast Configuration Guide |
Covers Layer 3 IPv4 multicast protocols (IGMP, PIM), Layer 2 IPv4 multicast protocols (IGMP snooping). This guide includes: · Multicast overview · IGMP snooping · Multicast routing and forwarding · IGMP · PIM |
ACL and QoS Configuration Guide |
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. You can use ACLs to help other function modules (such as QoS and IP routing) classify or filter traffic. This configuration guide includes: · ACL · QoS, including the following: ? Traffic policing, GTS, and rate limit ? Congestion management ? Class-based accounting · Appendixes |
Security Configuration Guide |
Covers security features. The major security features available on the switch include: identity authentication, secure management, and attack protection. This guide includes: · AAA · Password control · Public key management · IPsec · IKE · SSH · IP source guard · ARP attack protection · uRPF · FIPS |
High Availability Configuration Guide |
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes: · VRRP · BFD · Track |
Network Management and Monitoring Configuration Guide |
Describes features that help you manage and monitor your network, for example, manage system events, and test network connectivity. This guide includes: · Using ping, tracert, and system debugging · SNTP · Port mirroring · Traffic mirroring |
