Title | Size | Downloads |
H3C S3100-52P Ethernet Switch Command Manual-Release 1702-6W100-book(CHM).zip | 1.35 MB | |
H3C S3100-52P Ethernet Switch Command Manual-Release 1702-6W100-book.pdf | 4.92 MB |
- H3C Low-End Ethernet Switches Configuration Guide(V1.01)
- H3C Low-End Ethernet Switches Configuration Examples(V1.04)
- H3C S3100 Series Ethernet Switches Installation Manual-(V1.06)
- H3C S3100 Series Ethernet Switches Quick Start(V1.08)
- H3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
- H3C S3100-52P Ethernet Switch Installation Manual(V1.01)
To read the whole book, click the link on the right side to download the whole book; to read the individual chapters, click the links on the left.
1 About This Guide
The H3C S3100-52P Ethernet Switch Command Manual, Release 1702 describes the commands available in the software release 1702 for the S3100-52P switch.
Audience
This guide is for administrators managing the S3100-52P switch, hereafter referred to as the switch.
Part Organization
Table 1-1 presents the part organization of this guide:
Part | Features |
1 CLI | CLI Configuration commands |
2 Login | l Controlling Logging in Users Commands l Switching User Level Commands |
3 Configuration File Management | |
4 VLAN | |
5 IP Address and Performance | |
6 Voice VLAN | |
7 GVRP | |
8 Port Basic Configuration | |
9 Link Aggregation | |
10 Port Isolation | |
11 Port Security-Port Binding | l Port Security Configuration Commands l Port Binding Configuration Commands |
12 DLDP | DLDP Configuration Commands |
13 MAC Address Table Management | |
14 MSTP | MSTP Configuration Commands |
15 Static Route. | Static route Commands |
16 Multicast | |
17 802.1x and System Guard | l 802.1x Configuration Commands l Quick EAD Deployment Configuration Commands l HABP Configuration Commands l System Guard Configuration Commands |
18 AAA | l AAA Configuration Commands l RADIUS Configuration Commands l HWTACACS Configuration Commands l EAD Configuration Commands |
19 Web Authentication | Web Authentication Configuration Commands |
20 MAC Address Authentication | l MAC Address Authentication Basic Function Configuration Commands l MAC Address Authentication Enhanced Function Configuration Commands |
21 ARP | |
22 DHCP | l DHCP Snooping Configuration Commands l DHCP Rate Limit Configuration Commands l DHCP/BOOTP Client Configuration Commands |
23 ACL | |
24 QoS-QoS Profile | |
25 Mirroring | Mirroring Configuration Commands |
26 Stack-Cluster | l Stack Configuration Commands l Neighbor Discovery Protocol (NDP) Configuration Commands l Neighbor Topology Discovery Protocol (NTDP) Configuration Commands l Cluster Configuration Commands |
27 SNMP-RMON | l SNMP Commands l RMON Commands |
28 NTP | |
29 SSH | SSH Configuration Commands |
30 File System Management | |
31 FTP-SFTP-TFTP | l FTP Server Configuration Commands l FTP Client Configuration Commands l SFTP Server Configuration Commands |
32 Information Center | |
33 System Maintenance and Debugging | l Basic System Configuration Commands |
34 VLAN-VPN | l VLAN VPN Configuration Commands l Selective QinQ Configuration Commands l BPDU Tunnel Configuration Commands |
35 HWPing | |
36 IPv6 Management | |
37 DNS | |
38 Smart Link-Monitor Link | l Smart Link Configuration Commands l Monitor Link Configuration Commands |
39 LLDP | LLDP Configuration Commands |
40 PKI | PKI Configuration Commands |
41 SSL | SSL Configuration Commands |
42 HTTPS | HTTPS Configuration Commands |
Correspondence Between Documentation and Software
H3C S3100-52P Ethernet Switch Operation Manual-Release 1702 and H3C S3100-52P Ethernet Switch Command Manual-Release 1702 are for the software version of Release1702 of the S3100-52P.
Compared with Release 1602, many new commands are added in Release 1702. For details, refer to Table 1-2.
Table 1-2 Added commands in Release 1702
Added command in Release 1702 | Manual |
command-alias enable | 01-CLI |
command-alias mapping | |
display command-alias | |
icmp acl-priority | 05-IP Address and Performance |
voice vlan qos trust | 06-Voice VLAN |
voice vlan qos | |
flow-control no-pauseframe-sending | 08-Port Basic Configuration |
loopback-detection shutdown enable | |
loopback-detection interface-list enable | |
port-security guest-vlan | 11-Port Security-Port Binding |
port-security timer guest-vlan-reauth | |
port-security timer autolearn | |
igmp-snooping special-query source-ip | 16-Multicast Protocol |
system-guard cpu-rcv-limit | 17-802.1x and System-Guard |
attribute-ignore | 18-AAA |
web-authentication timer max-online | 19-Web Authentication |
web-authentication protocol | |
ARP attack detection commands | 21-ARP |
ip check dot1x enable | 22-DHCP |
reset dhcp-snooping | |
rule(IPv6 ACL) | 23-ACL |
25-Mirroring | |
cluster-local-user | 26-Stack-Cluster |
cluster-snmp-agent community | |
cluster-snmp-agent group v3 | |
cluster-snmp-agent mib-view included | |
cluster-snmp-agent usm-user v3 | |
display job | 33-System Maintenance and Debugging |
job | |
port auto-power-down | |
time at | |
time delay | |
view | |
34-VLAN-VPN | |
New HWPing commands are added including adv-factor, datafill, description, display hwping statistics, filesize, history keep-time, history-record enable, hwping-agent clear, hwping-agent max-requests, sendpacket passroute, statistics, statistics keep-time, test-time begin and ttl. | 35-HWping |
LLDP commands | 39-LLDP |
PKI commands | 40-PKI |
SSL commands | 41-SSL |
HTTPS commands | 42-HTTPS |
Compared with Release 1602, some commands’ keywords are added or changed in Release 1702. For details, refer to Table 1-3.
Table 1-3 Changed command in Release 1702
Modified command in Release 1702 | Manual |
storm-constrain { broadcast | multicast | unicast } max-packets min-packets { pps | kbps } | 08-Port Basic Configuration |
am user-bind mac-addr mac-address ip-addr ip-address [ interface interface-type interface-number ] | 11-Port Security-Port Binding |
vlan-assignment-mode vlan-list | 18-AAA |
web-authentication customize file web-file | 19-Web Authentication |
ip check source ip-address [ mac-address ] [ qos-profile string ] | 22-DHCP |
cluster switch-to { member-number | mac-address mac-address | administrator | sysname member-sysname } | 26-Stack-Cluster |
Conventions
Command conventions
Convention | Description |
Boldface | The keywords of a command line are in Boldface. |
italic | Command arguments are in italic. |
[ ] | Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } | Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] | Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * | Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * | Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> | The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
# | A line starting with the # sign is comments. |
Command line interface (CLI) commands of H3C products are case insensitive.
GUI conventions
Boldface | Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
> | Multi-level menus are separated by angle brackets. For example, File > Create > Folder. |
Symbols
Means reader be extremely careful. Improper operation may cause bodily injury. | |
Means reader be careful. Improper operation may cause data loss or damage to equipment. | |
Means a complementary description. | |
Means techniques helpful for you to make configuration with ease. |
Obtaining Documentation and Technical Support
Hangzhou H3C Technologies Co., Ltd. (hereafter referred to as H3C) provides various ways for you to obtain product documents and new feature releases in a convenient and timely manner. The documentations are available with:
l CD-ROMs shipped with the devices
l H3C website
l Software release notes
CD-ROM
H3C delivers a CD-ROM together with each device. The CD-ROM contains a complete set of electronic documents of the product, including operation manuals and command manuals. After installing the reader program provided by the CD-ROM, you can search for the desired contents in a convenient way through the reader interface.
The contents in the manual are subject to update on an irregular basis due to product version upgrade or some other reasons. Therefore, the contents in the CD-ROM may not be the latest version. This manual serves the purpose of user guide only. Unless otherwise noted, all the information in the document set does not claim or imply any warranty. For the latest software documentation, go to the H3C website.
H3C Website
To obtain up-to-date documentation and technical support, go to http://www.h3c.com and select your country or region. Depending on your selection, you will be redirected to either of the following websites:
Go to the following columns for different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, configuration, and maintenance.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Software Release Notes
With software upgrade, new software features may be added. You can acquire the information about the newly added software features through software release notes.
Related Documentation
H3C S3100-52P Ethernet Switch Operation Manual describes the principles and configuration procedures of the software features.
Other related documentation and their contents are listed in Table 2-1.
Table 2-1 Related documentation
Document title | Description |
H3C S3100-52P Ethernet Switch Command Manual, Release 1702 | Describes the commands for the S3100-52P Ethernet Switch. A master index of all commands covered by the whole manual is provided for your convenience. |
H3C S3100-52P Ethernet Switch Operation Manual, Release 1702 | Introduces the principles and configuration procedures of the software features for the S3100-52P Ethernet Switch. |
H3C S3100-52P Ethernet Switch Installation Manual | Introduces the appearance, installation, power-on and startup, troubleshooting and maintenance of the H3C S3100-52P Ethernet switch. |
H3C S3100-52P Ethernet Switch Compliance and Safety Manual | Introduces the security-preventive measures that you must comply with when installing and maintaining the H3C S3100-52P Ethernet switch. |
H3C Low-End Ethernet Switches Configuration Guide | Introduces the typical application scenarios of the H3C S3100-52P Ethernet switch, and the related configuration procedures and configuration guidelines. |
Reading Documents of Interest
l To get an idea of the basic principles and configuration procedures of supported software features, read H3C S3100-52P Ethernet Switch Operation Manual at the H3C website.
l To learn about the uses and parameters of commands and the meanings of displayed information, read H3C S3100-52P Ethernet Switch Command Manual at the H3C website.
l To learn about the hardware characteristics, installation, and troubleshooting of available switch models and pluggable hardware components, read H3C S3100-52P Ethernet Switch Installation Manual at the H3C website.
Documentation Feedback
We appreciate your comments.
Product Overview
H3C S3100-52P Ethernet switch is a Layer 2 wire speed Ethernet switch developed by H3C independently. It is the intelligent and manageable switch designed for network environments where high performance, high port density, and ease of installation are required.
Table 3-1 S3100-52P Ethernet switch hardware specifications
Model | Power supply unit (PSU) | Number of service ports | Number of 100 Mbps ports | Number of 1,000 Mbps uplink ports | Console port |
H3C S3100-52P | AC-input | 52 | 48 10/100 Mbps ports(electrical) | 4 Gigabit (SFP) ports | 1 |
Networking Applications
You can deploy S3100-52P Ethernet switch on many types of networks, such as enterprise networks and broadband access networks. Following are several typical networking applications.
Broadband Ethernet Access for Residential Communities
On the broadband access network of a residential community, an S3100-52P Ethernet switch is located in the center. It is downlinked to S3100 series switches to reach the Ethernet users and uplinked to a core Layer 3 switch through a GE port to connect to the MAN backbone.
Figure 3-1 Connecting community Ethernet to MAN using S3100-52P Ethernet switch
Application for Connecting Branches or Small- to Medium-Sized Enterprises
For small-to medium-sized enterprises or branches of a large enterprise, S3100-52P Ethernet switch can serve as a downstream device connected to the backbone switch, and can be connected to the headquarters or other branches through Layer 3 switches or routers. As the enterprise size increases, the network also can expand by subtending the S3100-52P Ethernet switch.
Figure 3-2 S3100-52P Ethernet switch application in branch network of midsize/large enterprise
Application in Large Enterprise and Campus Networks
In a large enterprise or campus network, the S3100-52P Ethernet switch can operate on the access layer. They are uplinked to layer 3 switches, S3600 Series or S5600 Series for example; and uplinked to a layer 3 switch. These switches together provide a network-wide intranet solution that covers Gigabit-to-backbone and 100 Mbps-to-desktop.
Figure 3-3 S3100-52P Ethernet switch application in large enterprise and campus network
