21-EVPN Configuration Guide
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-X Routers Configuration Guides-R8530Pxx-6W10121-EVPN Configuration Guide
02-EVPN VXLAN configuration
02-EVPN VXLAN configuration 1.45 MB
EVPN VXLAN overview·· 1
EVPN VXLAN network model 1
Configuration automation· 1
Assignment of traffic to VXLANs· 2
Traffic from the local site to a remote site· 2
Traffic from a remote site to the local site· 2
Layer 2 forwarding· 3
MAC learning· 3
Unicast 3
Flood· 4
Centralized EVPN gateway deployment 5
Distributed EVPN gateway deployment 6
About distributed EVPN gateway deployment 6
Symmetric IRB· 6
Asymmetric IRB· 9
EVPN VXLAN multihoming· 11
About EVPN VXLAN multihoming· 11
DF election· 11
Split horizon· 13
Redundancy mode· 14
IP aliasing· 14
ARP and ND flood suppression· 14
MAC mobility· 15
Configuring EVPN VXLAN·· 16
EVPN VXLAN tasks at a glance· 16
Restrictions and guidelines: EVPN VXLAN configuration· 17
Configuring a VXLAN on a VSI 18
Restrictions and guidelines for VXLAN configuration on a VSI 18
Creating a VXLAN on a VSI 18
Configuring VSI parameters· 18
Configuring an EVPN instance· 19
About EVPN instance configuration· 19
Restrictions and guidelines for EVPN instance configuration· 19
Configuring an EVPN instance created in system view· 20
Configuring an EVPN instance created in VSI view· 20
Configuring EVPN VXLAN multihoming· 21
Restrictions and guidelines for EVPN VXLAN multihoming· 21
Configuring an ESI 21
Configuring the DF election algorithm·· 22
Enabling AC state-based DF election· 24
Setting the DF election delay· 24
Enabling non-revertive mode for preference-based DF election· 24
Configuring ES route advertisement delay· 25
Configuring FRR for EVPN VXLAN· 26
Disabling advertisement of EVPN multihoming routes· 27
Enabling the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes· 27
Enabling the device to monitor the BGP peer status of another local edge device· 28
Configuring BGP to advertise BGP EVPN routes· 29
Restrictions and guidelines for BGP EVPN route advertisement 29
Enabling BGP to advertise BGP EVPN routes· 29
Configuring attributes of BGP EVPN routes· 29
Configuring optimal BGP EVPN route selection· 30
Configuring BGP route reflection· 32
Filtering BGP EVPN routes· 32
Advertising BGP RPKI validation state to a peer or peer group· 34
Configuring BGP soft-reset by saving route updates· 34
Enabling the VPN Prefix ORF feature· 35
About VPN Prefix ORF· 35
Restrictions and guidelines· 38
Procedure· 38
Maintaining BGP sessions· 40
Mapping ACs to a VSI 41
Mapping a Layer 3 interface to a VSI 41
Mapping an Ethernet service instance to a VSI 41
Configuring a centralized EVPN gateway· 42
Configuring a distributed EVPN gateway· 42
Restrictions and guidelines for distributed EVPN gateway configuration· 42
Configuring the traffic forwarding mode for EVPN VXLAN· 43
Configuring a VSI interface· 43
Configuring an L3 VXLAN ID for a VSI interface· 44
Configuring IP prefix route advertisement 47
Managing MAC address entries and ARP learning· 49
Disabling remote MAC address learning and remote ARP or ND learning· 49
Disabling MAC address advertisement 49
Enabling MAC mobility event suppression· 50
Disabling learning of MAC addresses from ARP or ND information· 51
Configuring the AC source MAC check feature· 52
Disabling ARP information advertisement 53
Enabling ARP mobility event suppression· 53
Enabling ND mobility event suppression· 55
Configuring BGP EVPN route redistribution and advertisement 57
Redistributing MAC/IP advertisement routes into BGP unicast routing tables· 57
Setting the metric of BGP EVPN routes added to a VPN instance's routing table· 58
Enabling BGP EVPN route advertisement to the local site· 58
Configuring EVPN ORF· 59
Confining floods to the local site· 61
Enabling ARP or ND flood suppression· 62
Interconnecting an EVPN VXLAN network with a VPLS network· 63
About interconnecting an EVPN VXLAN network with a VPLS network· 63
Restrictions and guidelines for interconnecting an EVPN VXLAN network with a VPLS network· 64
Prerequisites for interconnecting an EVPN VXLAN network with a VPLS network· 64
Mapping an LDP PW to VXLAN tunnels· 64
Mapping a static PW to VXLAN tunnels· 65
Interconnecting an EVPN VXLAN network with an EVPN VPLS network· 66
Interconnecting an EVPN VXLAN network with an EVPN VPLS over SRv6· 68
Enabling packet statistics for VXLAN tunnels· 71
Enabling SNMP notifications for EVPN· 71
Display and maintenance commands for EVPN VXLAN· 72
EVPN VXLAN configuration examples· 75
Example: Configuring a centralized IPv4 EVPN gateway· 75
Example: Configuring distributed IPv4 EVPN gateways in symmetric IRB mode· 83
Example: Configuring IPv4 EVPN VXLAN multihoming· 92
Example: Interconnecting an EVPN VXLAN network with a VPLS network· 100
Example: Interconnecting an EVPN VXLAN network with an EVPN VPLS network· 107
Example: Interconnecting an EVPN VXLAN network with an EVPN VPLS over SRv6 network· 114
EVPN VXLAN overview
EVPN VXLAN uses EVPN routes for VXLAN tunnel establishment and assignment and MAC reachability information advertisement in the control plane and uses VXLAN for forwarding in the data plane.
As shown in Figure 1, EVPN uses the VXLAN technology for traffic forwarding in the data plane. The transport edge devices assign VMs to different VXLANs, and then forward traffic between sites for VMs by using VXLAN tunnels. The transport edge devices are VXLAN tunnel endpoints (VTEPs). They can be servers that host VMs or independent network devices. The EVPN network sites and transport network can be IPv4 or IPv6 networks.
A VTEP uses ESs, VSIs, and VXLAN tunnels to provide VXLAN services:
·     Ethernet segment (ES)—An ES is a link that connects a site to a VTEP. Each ES is uniquely identified by an Ethernet segment identifier (ESI).
·     VSI—A virtual switch instance is a virtual Layer 2 switched domain. Each VSI provides switching services only for one VXLAN. VSIs learn MAC addresses and forward frames independently of one another. VMs in different sites have Layer 2 connectivity if they are in the same VXLAN. A VXLAN is identified by a 24-bit VXLAN ID which is also called the virtual network identifier (VNI). A VXLAN corresponds to an EVPN instance.
·     VXLAN tunnel—A VXLAN tunnel is a logical point-to-point tunnel between VTEPs over the transport network. Each VXLAN tunnel can trunk multiple VXLANs.
All VXLAN processing is performed on VTEPs. The ingress VTEP encapsulates VXLAN traffic in the VXLAN, outer UDP, and outer IP headers, and forwards the traffic through VXLAN tunnels. The egress VTEP removes the VXLAN encapsulation and forwards the traffic to the destination. Transport network devices (for example, the P device in Figure 1) forward VXLAN traffic only based on the outer IP header of VXLAN packets.
Figure 1 EVPN VXLAN network model
If EVPN is used for Layer 2 forwarding, VTEPs use the following BGP EVPN routes to discover VTEP neighbors, establish VXLAN tunnels, and assign the tunnels to VXLANs:
·     IMET route—VTEPs advertise their VXLAN IDs through IMET routes. If two VTEPs have the same VXLAN ID, they automatically establish a VXLAN tunnel and assign the tunnel to the VXLAN.
·     MAC/IP advertisement route—VTEPs advertise local MAC addresses and VXLAN IDs through MAC/IP advertisement routes. If two VTEPs have the same VXLAN ID, they automatically establish a VXLAN tunnel and assign the tunnel to the VXLAN.
If EVPN is used for Layer 3 forwarding, VTEPs use the following BGP EVPN routes to discover VTEP neighbors, establish VXLAN tunnels, and assign the tunnels to VXLANs:
·     IMET route—VTEPs advertise the VXLAN IDs they have through IMET routes. If two VTEPs have the same VXLAN ID, they automatically establish a VXLAN tunnel and assign the tunnel to the VXLAN.
·     MAC/IP advertisement route and IP prefix advertisement route—In the EVPN gateway deployment, VTEPs advertise MAC/IP advertisement routes or IP prefix advertisement routes which carry the export targets. When a VTEP receives a route, it compares the export targets of the route with the local import targets. If the route targets match, the VTEP establishes a VXLAN tunnel with the remote VTEP and associates the tunnel with the L3 VXLAN ID of the corresponding VPN instance. For more information about the L3 VXLAN ID, see "Distributed EVPN gateway deployment."
The VTEP uses an Ethernet service instance or Layer 3 interface to match customer traffic on a site-facing interface. The VTEP assigns customer traffic to a VXLAN by mapping the Layer 3 interface or Ethernet service instance to a VSI.
An Ethernet service instance or Layer 3 interface is identical to an attachment circuit (AC) in L2VPN.
An Ethernet service instance matches a list of VLANs on a Layer 2 Ethernet interface by using a frame match criterion. The frame match criterion specifies the characteristics of traffic from the VLANs, such as tagging status and VLAN IDs.
As shown in Figure 2, Ethernet service instance 1 matches VLAN 2 and is mapped to VSI A (VXLAN 10). When a frame from VLAN 2 arrives, the VTEP assigns the frame to VXLAN 10 and looks up VSI A's MAC address table for the outgoing interface.
Figure 2 Identifying traffic from the local site
When a VXLAN packet arrives at a VXLAN tunnel interface, the VTEP uses the VXLAN ID in the packet to identify its VXLAN.
Layer 2 forwarding
MAC learning
The VTEP performs Layer 2 forwarding based on a VSI's MAC address table. The VTEP learns MAC addresses by using the following methods:
·     Local MAC learning—The VTEP automatically learns the source MAC addresses of frames sent from the local site. The outgoing interfaces of local MAC address entries are site-facing interfaces on which the MAC addresses are learned.
·     Remote MAC learning—The VTEP uses MP-BGP to advertise local MAC reachability information to remote sites and learn MAC reachability information from remote sites. The outgoing interfaces of MAC address entries advertised from a remote site are VXLAN tunnel interfaces.
Unicast
As shown in Figure 3, the VTEP performs typical Layer 2 forwarding for known unicast traffic within the local site.
Figure 3 Intra-site unicast
As shown in Figure 4, the following process applies to a known unicast frame between sites:
1.     The source VTEP encapsulates the Ethernet frame in the VXLAN/UDP/IP header.
In the outer IP header, the source IP address is the source VTEP's VXLAN tunnel source IP address. The destination IP address is the VXLAN tunnel destination IP address.
2.     The source VTEP forwards the encapsulated packet out of the outgoing VXLAN tunnel interface found in the VSI's MAC address table.
3.     The intermediate transport devices (P devices) forward the packet to the destination VTEP by using the outer IP header.
4.     The destination VTEP removes the headers on top of the inner Ethernet frame. It then performs MAC address table lookup in the VXLAN's VSI to forward the frame out of the matching outgoing interface.
Figure 4 Inter-site unicast
Flood
As shown in Figure 5, a VTEP floods a broadcast, multicast, or unknown unicast frame to all site-facing interfaces and VXLAN tunnels in the VXLAN, except for the incoming interface. The source VTEP replicates the flood frame, and then sends one replica to the destination IP address of each VXLAN tunnel in the VXLAN. Each destination VTEP floods the inner Ethernet frame to all the site-facing interfaces in the VXLAN. To avoid loops, the destination VTEPs do not flood the frame to VXLAN tunnels.
Figure 5 Forwarding of flood traffic
IMPORTANT
IMPORTANT:
This section uses IPv4 sites as examples to describe the Layer 3 forwarding process of EVPN networks. The Layer 3 forwarding process does not differ between IPv4 and IPv6 sites.
Centralized EVPN gateway deployment uses one VTEP to provide Layer 3 forwarding for VXLANs. The VTEP uses virtual Layer 3 VSI interfaces as gateway interfaces for VXLANs. Typically, the gateway-collocated VTEP connects to other VTEPs and the external network. To use this design, make sure the gateway has sufficient bandwidth and processing capability.
As shown in Figure 6, a VTEP acts as a gateway for VMs in the VXLANs. The VTEP both terminates the VXLANs and performs Layer 3 forwarding for the VMs. The network uses the following process to forward Layer 3 traffic from a VM to the destination:
1.     The VM sends an ARP request to obtain the MAC address of the VSI interface that acts as the gateway, and then sends the Layer 3 traffic to the centralized EVPN gateway.
2.     The local VTEP looks up the matching VSI's MAC address table and forwards the traffic to the centralized EVPN gateway through a VXLAN tunnel.
3.     The centralized EVPN gateway removes the VXLAN encapsulation and forwards the traffic at Layer 3.
4.     The centralized EVPN gateway forwards the replies sent by the destination node to the VM based on the ARP entry for the VM.
Figure 6 Example of centralized EVPN gateway deployment
IMPORTANT
IMPORTANT:
Distributed EVPN gateway deployment deploys one EVPN gateway on each VTEP to provide Layer 3 forwarding for VXLANs at their respective sites. The gateways use virtual Layer 3 VSI interfaces as gateway interfaces for VXLANs. This design distributes the Layer 3 traffic load across VTEPs. However, its configuration is more complex than the centralized EVPN gateway design. A distributed EVPN gateway can provide services for both IPv4 sites and IPv6 sites. This section uses IPv4 sites as examples to describe the Layer 3 forwarding process of EVPN networks.
As shown in Figure 7, each site's VTEP acts as a gateway to perform Layer 3 forwarding for the VXLANs of the local site. A VTEP acts as a border gateway to the Layer 3 network for the VXLANs.
Figure 7 Distributed EVPN gateway placement design
A distributed EVPN gateway supports the following traffic forwarding modes:
·     Asymmetric IRB—The ingress gateway performs Layer 2 and Layer 3 lookups and the egress gateway performs only Layer 2 forwarding.
·     Symmetric IRB—Both the ingress and egress gateways perform Layer 2 and Layer 3 lookups.
Symmetric IRB
Basic concepts
Symmetric IRB introduces the following concepts:
·     L3 VXLAN ID—Also called L3 VNI. An L3 VXLAN ID identifies the traffic of a routing domain where devices have Layer 3 reachability. An L3 VXLAN ID is associated with one VPN instance. Distributed EVPN gateways use VPN instances to isolate traffic of different services on VXLAN tunnel interfaces.
·     Router MAC address—Each distributed EVPN gateway has a unique router MAC address used for inter-gateway forwarding. The MAC addresses in the inner Ethernet header of VXLAN packets are router MAC addresses of distributed EVPN gateways.
VSI interfaces
As shown in Figure 8, each distributed EVPN gateway has the following types of VSI interfaces:
·     VSI interface as a gateway interface of a VXLAN—The VSI interface acts as the gateway interface for VMs in a VXLAN. The VSI interface is associated with a VSI and a VPN instance. On different distributed EVPN gateways, the VSI interface of a VXLAN uses the same IP address to provide services.
·     VSI interface associated with an L3 VXLAN ID—The VSI interface is associated with a VPN instance and assigned an L3 VXLAN ID. VSI interfaces associated with the same VPN instance share an L3 VXLAN ID.
A border gateway only has VSI interfaces that are associated with an L3 VXLAN ID.
Figure 8 Example of distributed EVPN gateway deployment
Layer 3 forwarding entry learning
A distributed EVPN gateway forwards Layer 3 traffic based on FIB entries generated from BGP EVPN routes and ARP information.
A VTEP advertises an external route imported in the EVPN address family through MP-BGP. A remote VTEP adds the route to the FIB table of a VPN instance based on the L3 VXLAN ID carried in the route. In the FIB entry, the outgoing interface is a VXLAN tunnel interface, and the next hop is the peer VTEP address in the NEXT_HOP attribute of the route.
A VTEP has the following types of ARP information:
·     Local ARP information—ARP information of VMs in the local site. The VTEP snoops GARP packets, RARP packets, and ARP requests for the gateway MAC address to learn the ARP information of the senders and generates ARP entries and FIB entries. In an ARP or FIB entry, the outgoing interface is the site-facing interface where the packet is received, and the VPN instance is the instance associated with the corresponding VSI interface.
·     Remote ARP information—ARP information of VMs in remote sites. Each VTEP uses MP-BGP to advertise its local ARP information with L3 VXLAN IDs in routes to remote sites. A VTEP generates only FIB entries for the remote ARP information. A FIB entry contains the following information:
¡     Outgoing interface: VSI interface associated with the L3 VXLAN ID.
¡     Next hop: Peer VTEP address in the NEXT_HOP attribute of the route.
¡     VPN instance: VPN instance associated with the L3 VXLAN ID.
The VTEP then creates an ARP entry for the next hop in the FIB entry.
Traffic forwarding
A distributed EVPN gateway can work in one of the following modes:
·     Switching and routing mode—Forwards Layer 2 traffic based on the MAC address table and forwards Layer 3 traffic based on the FIB table. In this mode, you need to enable ARP or ND flood suppression on the distributed EVPN gateway to reduce flooding.
·     Routing mode— Forwards both Layer 2 and Layer 3 traffic based on the FIB table. In this mode, you need to enable local proxy ARP on the distributed EVPN gateway.
For more information about MAC address table-based Layer 2 forwarding, see "Unicast."
Figure 9 shows the intra-site Layer 3 forwarding process.
1.     The source VM sends an ARP request to obtain the MAC address of the destination VM.
2.     The gateway replies to the source VM with the MAC address of the VSI interface associated with the source VM's VSI.
3.     The source VM sends a Layer 3 packet to the gateway.
4.     The gateway looks up the FIB table of the VPN instance associated with the source VM's VSI and finds the matching outgoing site-facing interface.
5.     The gateway processes the Ethernet header of the Layer 3 packet as follows:
¡     Replaces the destination MAC address with the destination VM's MAC address.
¡     Replaces the source MAC address with the VSI interface's MAC address.
6.     The gateway forwards the Layer 3 packet to the destination VM.
Figure 9 Intra-site Layer 3 forwarding
Figure 10 shows the inter-site Layer 3 forwarding process.
4.     The gateway looks up the FIB table of the VPN instance associated with the source VM's VSI and finds the matching outgoing VSI interface.
¡     Replaces the destination MAC address with the destination gateway's router MAC address.
¡     Replaces the source MAC address with its own router MAC address.
6.     The gateway adds VXLAN encapsulation to the Layer 3 packet and forwards the packet to the destination gateway. The encapsulated VXLAN ID is the L3 VXLAN ID of the corresponding VPN instance.
7.     The destination gateway identifies the VPN instance of the packet based on the L3 VXLAN ID and removes the VXLAN encapsulation. Then the gateway forwards the packet based on the matching ARP entry.
Figure 10 Inter-site Layer 3 forwarding
Communication between private and public networks
A distributed EVPN gateway uses the public instance to perform Layer 3 forwarding for the public network and to enable communication between private and public networks. The public instance is similar to a VPN instance. A distributed EVPN gateway processes traffic of the public instance in the same way it does for a VPN instance. For the public instance to work correctly, you must configure an RD, an L3 VXLAN ID, and route targets for it. If a VSI interface is not associated with any VPN instance, the VSI interface belongs to the public instance.
Asymmetric IRB
VSI interfaces
Asymmetric IRB uses the same distributed EVPN gateway deployment as symmetric IRB.
·     VSI interface as a gateway interface of a VXLAN—The VSI interface is associated with a VSI and a VPN instance. On different distributed EVPN gateways, the VSI interface of a VXLAN must use different IP addresses to provide services.
·     VSI interface associated with an L3 VXLAN ID—The VSI interface acts as the gateway for VMs in a VXLAN to communicate with the external network through the border gateway. The VSI interface is associated with a VPN instance and assigned an L3 VXLAN ID. VSI interfaces associated with the same VPN instance share an L3 VXLAN ID.
Layer 3 forwarding
Asymmetric IRB supports only Layer 3 forwarding in the same VXLAN on distributed EVPN gateways.
After a distributed EVPN gateway learns ARP information about local VMs, it advertises the information to other distributed EVPN gateways through MAC/IP advertisement routes. Other distributed EVPN gateways generate FIB entries based on the advertised ARP information.
As shown in Figure 11, VM 1 and VM 2 belong to VXLAN 10 and they can reach each other at Layer 3 through the distributed EVPN gateways. The distributed EVPN gateways use the following process to perform Layer 3 forwarding in asymmetric IRB mode when VM 1 sends a packet to VM 2:
1.     After GW 1 receives the packet from VM 1, it finds that the destination MAC address is itself. Then, GW 1 removes the Layer 2 frame header and looks up the FIB table for the destination IP address.
2.     GW 1 matches the packet to the FIB entry generated based on the ARP information of VM 2.
3.     GW 1 encapsulates the packet source and destination MAC addresses as the MAC addresses of GW 1 and VM 2, respectively. Then, GW 1 adds VXLAN encapsulation to the packet and forwards the packet to GW 2 through a VXLAN tunnel.
4.     GW 2 removes the VXLAN encapsulation from the packet, and performs Layer 2 forwarding in VXLAN 10 by looking up the MAC address table for the destination MAC address.
5.     GW 2 forwards the packet to VM 2 based on the MAC address table lookup result.
Figure 11 Layer 3 forwarding in the same VXLAN (asymmetric IRB)
IMPORTANT
IMPORTANT:
EVPN multihoming supports only IPv4 underlay networks.
As shown in Figure 12, EVPN supports deploying multiple VTEPs at a site for redundancy and high availability. On the redundant VTEPs, Ethernet links connected to the site form an Ethernet segment (ES) that is uniquely identified by an Ethernet segment identifier (ESI).
Figure 12 EVPN VXLAN multihoming
DF election
To prevent redundant VTEPs from sending duplicate flood traffic to a multihomed site, a designated forwarder (DF) is elected from the VTEPs to forward flood traffic to the site. VTEPs that fail the election are assigned the backup designated forwarder (BDF) role. BDFs do not forward flood traffic to the site.
Redundant VTEPs at a site send Ethernet segment routes to one another to advertise ES and VTEP IP mappings. A VTEP accepts the Ethernet segment routes only when it is configured with an ESI. Then, the VTEPs select a DF for each AC based on the ES and VTEP IP mappings. DF election can be performed by using a VLAN tag-based algorithm or preference-based algorithm.
Figure 13 DF election
VLAN tag-based DF election
VTEPs select a DF for each AC based on the VLAN tag and VTEP IP address as follows:
1.     Arrange source IP addresses in Ethernet segment routes with the same ESI in ascending order and assign a sequence number to each IP address, starting from 0.
2.     Divide the lowest VLAN ID permitted on an AC by the number of the redundant VTEPs, and match the reminder to the sequence numbers of IP addresses.
3.     Assign the DF role to the VTEP that uses the IP address with the matching sequence number.
The following uses AC 1 in Figure 14 as an example to explain the DF election procedure:
1.     VTEP 1 and VTEP 2 send Ethernet segment routes to each other.
2.     The VTEPs assign sequence numbers 0 and 1 to IP addresses 1.1.1.1 and 2.2.2.2 in the Ethernet segment routes, respectively.
3.     The VTEPs divide 4 (the lowest VLAN ID permitted by AC 1) by 2 (the number of redundant VTEPs), and match the reminder 0 to the sequence numbers of the IP addresses.
4.     The DF role is assigned to VTEP 1 at 1.1.1.1.
Figure 14 VLAN tag-based DF election
Preference-based DF election
VTEPs select a DF for each ES based on the DF election preference, the Don't Preempt Me (DP) bit in Ethernet segment routes, and VTEP IP address. The DP bit can be set to one of the following values:
·     1—DF preemption is disabled. A DF retains its role when a new DF is elected.
·     0—DF preemption is enabled.
Preference-based DF election uses the following rules to select a DF for an ES:
·     The VTEP with higher preference becomes the DF.
·     If two VTEPs have the same preference, the VTEP with the DP bit set to 1 becomes the DF. If both of the VTEPs have the DP bit set to 1, the VTEP with a lower IP address becomes the DF.
As shown in Figure 15, VTEP 2 is the DF for ES 1, and VTEP 1 is the DF for ES 2.
Figure 15 Preference-based DF election
Split horizon
In a multihomed site, a VTEP forwards multicast, broadcast, and unknown unicast frames received from ACs out of all site-facing interfaces and VXLAN tunnels in the corresponding VXLAN, except for the incoming interface. As a result, the other VTEPs at the site receive these flood frames and forward them to site-facing interfaces, which causes duplicate floods and loops. EVPN introduces split horizon to resolve this issue. Split horizon disables a VTEP to forward flood traffic received from another local VTEP to site-facing interfaces if an ES on that local VTEP has the same ESI as these interfaces. As shown in Figure 16, both VTEP 1 and VTEP 2 have ES 1. When receiving flood traffic from VTEP 1, VTEP 2 does not forward the traffic to interfaces with ESI 1.
Figure 16 Split horizon
Redundancy mode
This mode allows all redundant VTEPs at a multihomed site to forward broadcast, multicast, and unknown unicast traffic.
·     For flood frames received from remotes sites, a VTEP forwards them to the ACs of which it is the DF.
·     For flood frames received from the local site, a VTEP forwards them out of all site-facing interfaces and VXLAN tunnels in the corresponding VXLAN, except for the incoming interfaces. For flood frames to be sent out of a VXLAN tunnel interface, a VTEP replicates each flood frame and sends one replica to all the other VTEPs in the corresponding VXLAN.
IP aliasing
In all-active redundancy mode, all redundant VTEPs of an ES advertise the ES to remote VTEPs through MP-BGP. IP aliasing allows a remote VTEP to add the IP addresses of all the redundant VTEPs as the next hops for the MAC or ARP information received from one of these VTEPs. This mechanism creates ECMP routes between the remote VTEP and the redundant VTEPs.
ARP or ND flood suppression reduces ARP request broadcasts or ND request multicasts by enabling the VTEP to reply to ARP or ND requests on behalf of VMs.
As shown in Figure 17, this feature snoops ARP or ND requests, ARP or ND responses, and BGP EVPN routes to populate the ARP or ND flood suppression table with local and remote MAC addresses. If an ARP or ND request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found, the VTEP floods the request to both local and remote sites.
Figure 17 ARP and ND flood suppression
The following uses ARP flood suppression as an example to explain the flood suppression workflow:
1.     VM 1 sends an ARP request to obtain the MAC address of VM 7.
2.     VTEP 1 creates a suppression entry for VM 1, floods the ARP request in the VXLAN, and sends the suppression entry to VTEP 2 and VTEP 3 through BGP EVPN.
3.     VTEP 2 and VTEP 3 de-encapsulate the ARP request and broadcast the request in the local site.
4.     VM 7 sends an ARP reply.
5.     VTEP 2 creates a suppression entry for VM 7, forwards the ARP reply to VTEP 1, and sends the suppression entry to VTEP 1 and VTEP 3 through BGP EVPN.
6.     VTEP 1 de-encapsulates the ARP reply and forwards the ARP reply to VM 1.
7.     VM 4 sends an ARP request to obtain the MAC address of VM 1.
8.     VTEP 1 creates a suppression entry for VM 4 and replies to the ARP request.
9.     VM 10 sends an ARP request to obtain the MAC address of VM 1.
10.     VTEP 3 creates a suppression entry for VM 10 and replies to the ARP request.
MAC mobility
MAC mobility refers to the movement of a VM or host from one ES to another. The source VTEP is unaware of the MAC move event. To notify other VTEPs of the change, the destination VTEP advertises a MAC/IP advertisement route for the MAC address. The source VTEP withdraws the old route for the MAC address after receiving the new route. The MAC/IP advertisement route has a sequence number that increases when the MAC address moves. The sequence number identifies the most recent move if the MAC address moves multiple times.
To configure EVPN VXLAN, perform the following tasks:
1.     Configuring a VXLAN on a VSI
a.     Configuring a VXLAN on a VSI
b.     (Optional.) Configuring VSI parameters
2.     Configuring an EVPN instance
3.     (Optional.) Configuring EVPN VXLAN multihoming
a.     Configuring an ESI
b.     (Optional.) Configuring the DF election algorithm
c.     (Optional.) Enabling AC state-based DF election
d.     (Optional.) Setting the DF election delay
e.     (Optional.) Enabling non-revertive mode for preference-based DF election
f.     (Optional.) Configuring ES route advertisement delay
g.     (Optional.) Configuring FRR for EVPN VXLAN
h.     (Optional.) Disabling advertisement of EVPN multihoming routes
i.     (Optional.) Enabling the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes
j.     (Optional.) Enabling the device to monitor the BGP peer status of another local edge device
4.     Configuring BGP to advertise BGP EVPN routes
a.     Enabling BGP to advertise BGP EVPN routes
b.     (Optional.) Configuring attributes of BGP EVPN routes
c.     (Optional.) Configuring optimal BGP EVPN route selection
d.     (Optional.) Configuring BGP route reflection
e.     (Optional.) Filtering BGP EVPN routes
f.     (Optional.) Advertising BGP RPKI validation state to a peer or peer group
g.     (Optional.) Configuring BGP soft-reset by saving route updates
h.     (Optional.) Enabling the VPN Prefix ORF feature
i.     (Optional.) Maintaining BGP sessions
5.     Mapping ACs to a VSI
6.     Configuring an EVPN gateway
¡     Configuring a centralized EVPN gateway
¡     Configuring a distributed EVPN gateway
7.     (Optional.) Managing MAC address entries and ARP learning
8.     (Optional.) Configuring BGP EVPN route redistribution and advertisement
¡     Redistributing MAC/IP advertisement routes into BGP unicast routing tables
¡     Setting the metric of BGP EVPN routes added to a VPN instance's routing table
¡     Enabling BGP EVPN route advertisement to the local site
¡     Configuring EVPN ORF
9.     (Optional.) Interconnecting an EVPN VXLAN network with a heterogeneous network
¡     Interconnecting an EVPN VXLAN network with a VPLS network
¡     Interconnecting an EVPN VXLAN network with an EVPN VPLS network
¡     Interconnecting an EVPN VXLAN network with an EVPN VPLS over SRv6
10.     (Optional.) Maintaining and optimizing an EVPN network
¡     Confining floods to the local site
¡     Enabling ARP or ND flood suppression
¡     Enabling packet statistics for VXLAN tunnels
¡     Enabling SNMP notifications for EVPN
In sdn-wan mode, EVPN VXLAN is supported only on the following cards:
Table 1 Compatible cards
Card type
Card marks
CEPC card
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RX-L, CEPC-CQ8L, CEPC-CQ16L1, CEPC-DQ2L1-G
CSPEX card
CSPEX-1304X, CSPEX-1304S, CSPEX-1404X, CSPEX-1404S, CSPEX-1502X, CSPEX-1504X, CSPEX-1504S, CSPEX-1602X, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1802XB, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-2304X-LG, CSPEX-2612X-E
SPE card
RX-SPE200, RX-SPE200-E
In standard mode, EVPN VXLAN is supported only on the following cards:
Table 2 Compatible cards
Card type
Card marks
CEPC card
CSPEX card
SPE card
RX-SPE200-E
QoS policies and PBR are supported by VSI interfaces. Do not use the if-match command to configure the following match criteria for the QoS policies:
·     Matches an ACL that contains the VPN instance criterion.
·     Matches an authentication user or destination MAC address.
·     Matches a Layer 2 ACL that contains the destination MAC address criterion.
You cannot configure both the gateway interface setting and L3 VXLAN ID association on a VSI interface.
Make sure the following VXLAN tunnels are not associated with the same VXLAN if they have the same tunnel destination IP address:
·     A VXLAN tunnel automatically created by EVPN.
·     A manually created VXLAN tunnel.
For more information about manual tunnel configuration, see VXLAN Configuration Guide.
In an EVPN VXLAN scenario, to configure inter-VPN static routes on VTEPs for seamless traffic between different VPNs or between a VPN and the public network, set the next hop to the address of the VM interface directly connected to the local VTEP. For example, in the network topology of VM1 (interface 1)—(interface 2) VTEP1 (interface 3)—(interface 4) VTEP2 (interface 5)—(interface 6) VM2, for traffic from VTEP1 to VTEP2, to configure an inter-VPN static route on VTEP2, specify the next hop as the IP address of the VM2 (interface6).
As a best practice to ensure correct traffic forwarding, configure the same MAC address for all VSI interfaces on an EVPN gateway.
For more information about the VXLAN commands in this task, see VXLAN Command Reference.
2.     Enable L2VPN.
l2vpn enable
By default, L2VPN is disabled.
3.     Create a VSI and enter VSI view.
vsi vsi-name
4.     Enable the VSI.
By default, a VSI is enabled.
5.     Create a VXLAN and enter VXLAN view.
vxlan vxlan-id
You can create only one VXLAN on a VSI. The VXLAN ID must be unique for each VSI.
2.     Enter VSI view.
vsi vsi-name
3.     Configure a VSI description.
By default, a VSI does not have a description.
4.     Set the MTU for the VSI.
mtu mtu
The default MTU is 1500 bytes for a VSI.
5.     Set the maximum bandwidth for known unicast traffic of the VSI.
bandwidth bandwidth
By default, the maximum bandwidth is not limited for known unicast traffic of a VSI.
6.     Set the broadcast, multicast, or unknown unicast bandwidth restraints for the VSI.
restrain { broadcast | multicast | unknown-unicast } bandwidth
By default, the broadcast, multicast, and unknown unicast bandwidth restraints are 5120 kbps on a VSI.
7.     Configure MAC address learning settings:
a.     Enable MAC address learning for the VSI.
mac-learning enable
By default, MAC address learning is enabled for a VSI.
b.     (Optional.) Set a limit for the VSI's MAC address table.
mac-table limit mac-limit
By default, no limit is set for a VSI's MAC address table.
c.     (Optional.) Enable the VSI to drop source-unknown unicast frames if the MAC address table is full.
mac-table limit drop-unknown
By default, the VSI forwards source-unknown unicast frames without learning the source MAC address if the MAC address table is full.
The mac-table limit drop-unknown command does not take effect on the traffic received from the peer of the EVPN VXLAN tunnel. That is, even when the MAC addresses learnt by the VSI has reached its upper limit, the device will still forward these packets from the peer of the EVPN VXLAN tunnel, regardless of whether the source MAC address is in the MAC address table.
If a VXLAN requires only Layer 2 connectivity, you do not need to associate a VPN instance with it. The BGP EVPN routes advertised by a VTEP carry the RD and route targets configured for the EVPN instance associated with the VXLAN.
Use one of the following methods to create an EVPN instance:
·     Create an EVPN instance in system view—You can bind an EVPN instance created in system view to multiple VSIs to simplify configuration.
·     Create an EVPN instance on a VSI—An EVPN instance created in VSI view is automatically bound with the VSI.
In EVPN instance view, you can configure routing policies to filer the routes redistributed from BGP EVPN to an EVPN instance and vice versa.
If you have created an EVPN instance in VSI view for a VSI, you cannot bind the VSI to an EVPN instance created in system view. If you have bound a VSI to an EVPN instance created in system view, you cannot create an EVPN instance in VSI view for the VSI.
2.     Create an EVPN instance and enter its view.
evpn instance instance-name
3.     Configure an RD for the EVPN instance.
By default, no RD is configured for an EVPN instance.
4.     Configure route targets for the EVPN instance.
By default, an EVPN instance does not have route targets.
Make sure the following requirements are met:
¡     The export targets of the EVPN instance do not match the export targets configured for another EVPN instance in system view, VSI view, VPN instance view, public instance view, or cross-connect group view.
¡     The import targets configure for the EVPN instance in VPN instance view, public instance view, or other views do not match the export targets of a cross-connect group EVPN instance.
For more information about VPN instance configuration and public instance configuration, see "Configuring an L3 VXLAN ID for a VSI interface."
5.     (Optional.) Apply an export routing policy to the EVPN instance.
By default, no export routing policy is applied to an EVPN instance.
6.     (Optional.) Apply an import routing policy to the EVPN instance.
By default, no import routing policy is applied to an EVPN instance.
7.     Return to system view.
8.     Enter VSI view.
vsi vsi-name
9.     Bind the VSI to the EVPN instance.
evpn encapsulation vxlan binding instance instance-name vsi-tag { tag-id | auto-vxlan }
By default, a VSI is not bound to an EVPN instance created in system view.
You can bind a VSI to one or two EVPN instances. If you bind two EVP instances to a VSI, make sure one EVPN instance uses MPLS encapsulation and the other uses VXLAN encapsulation.
2.     Enter VSI view.
vsi vsi-name
3.     Create an EVPN instance and enter VSI EVPN instance view.
4.     Configure an RD for the EVPN instance.
route-distinguisher { route-distinguisher | auto [ router-id ] }
5.     Configure route targets for the EVPN instance.
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
In a multihomed site, AC configuration and VXLAN IDs must be consistent on redundant VTEPs of the same ES. For each VXLAN ID, you must configure unique RDs for the EVPN instance of VSIs on the redundant VTEPs. You must configure different RDs for the VPN instances and the public instance that use the same VXLAN IP gateway.
You can assign ESIs to a main interface and its subinterfaces.
·     If you assign an ESI to a subinterface, the subinterface-specific ESI and ES configuration take precedence over those configured on the main interface. The ES configuration includes the following:
¡     evpn df-election algorithm.
¡     evpn df-election preference.
¡     evpn df-election preference non-revertive.
¡     evpn timer es-delay.
·     If you do not assign an ESI to a subinterface, it inherits the ESI and ES configuration (if configured) of the main interface. In this scenario, the ES configuration on the subinterface does not take effect.
Configuring an ESI
An ESI uniquely identifies an ES. The links on interfaces (or VSIs) with the same ESI belong to the same ES. Traffic of the ES can be distributed among the links for load sharing.
Assigning an ESI to an interface
2.     Enter interface view.
¡     Enter Layer 2 Ethernet interface view.
¡     Enter Layer 2 aggregate interface view.
¡     Enter Layer 3 Ethernet interface view.
¡     Enter Layer 3 aggregate interface view.
¡     Enter FlexE physical interface view.
¡     Enter FlexE interface view.
interface flexe interface-number
3.     Assign an ESI to the interface.
esi esi-id
By default, no ESI is assigned to an interface.
Assigning an ESI to a VSI
2.     Enter VSI view.
vsi vsi-name
3.     Assign an ESI to the VSI.
esi esi-id
By default, no ESI is assigned to a VSI.
At a multihomed EVPN network site, you can modify the DF election algorithm to control the DF election result.
If ambiguous VLAN termination is enabled on a subinterface acting as an AC, do not configure the VLAN tag-based algorithm for DF election on the subinterface. Otherwise, traffic forwarding errors will occur.
You can configure the DF election algorithm in system view and in interface view. The global DF election algorithm takes effect on all ESs, and the interface-specific DF election algorithm takes effect only on the ESs on an interface. The interface-specific DF election algorithm takes precedence over the global DF election algorithm.
Configuring the DF election algorithm globally
2.     Configure the DF election algorithm.
evpn df-election algorithm algorithm
By default, the VLAN tag-based algorithm is used for DF election.
Configuring the DF election algorithm on an interface
3.     Configure the DF election algorithm.
By default, the DF election algorithm specified in system view takes effect.
Configuring preference-based DF election
3.     Set the DF election preference.
evpn df-election preference preference
By default, the DF election preference is 32767.
The larger the value, the higher the preference.
At a multihomed EVPN network site, all VTEPs in an ES participate in DF election by default, regardless of their AC states. If the AC on the VTEP elected as the DF is down, traffic forwarding will fail. You can configure this feature to resolve this issue.
After you configure this feature, a VTEP participates in DF election only when the AC on the VTEP is up. A VTEP determines that the AC on the remote VTEP is up only when it receives AD per ES and AD per EVI routes from the remote VTEP.
This feature takes effect only when you enable this feature on all VTEPs in an ES.
2.     Enable AC state-based DF election.
evpn df-election ac-influence enable
By default, AC state-based DF election is disabled.
The DF election can be triggered by site-facing interface status changes, redundant VTEP membership changes, and interface ESI changes. To prevent frequent DF elections from degrading network performance, set the DF election delay. The DF election delay defines the minimum interval allowed between two DF elections.
2.     Set the DF election delay.
evpn multihoming timer df-delay delay-value
By default, the DF election delay is 3 seconds.
At a multihomed EVPN network site, configuration changes, device restarts, or process restarts will trigger DF re-election, and DF switchover might cause packet loss. You can configure this feature to resolve this issue.
For example, VTEP 1 and VTEP 2 are in the same ES, and VTEP 1 is the DF. When VTEP 1 restarts and VTEP 2 becomes the new DF, non-revertive mode for preference-based DF election works as follows:
·     If VTEP 1 receives Ethernet segment routes from VTEP 2 after the restart, VTEP 1 compares the DF election preference in the Ethernet segment routes with the local DF election preference.
¡     If the local DF election preference is smaller than that in the received Ethernet segment routes, VTEP 1 uses the local DF election preference in the advertised Ethernet segment routes.
¡     If the local DF election preference is equivalent to that in the received Ethernet segment routes, VTEP 1 compares the IP addresses as follows:
-     If VTEP 1's IP address is lower than VTEP 2's IP address, VTEP 1 uses the local DF election preference and the DP value of 0 in the advertised Ethernet segment routes.
-     If VTEP 1's IP address is higher than VTEP 2's IP address, VTEP 1 uses the local DF election preference and the DP value of 1 in the advertised Ethernet segment routes.
¡     If the local DF election preference is larger than that in the received Ethernet segment routes, VTEP 1 uses the DF election preference in the received Ethernet segment routes and the DP value of 0 when advertising Ethernet segment routes.
·     If VTEP 1 does not receive Ethernet segment routes from VTEP 2 after the restart, VTEP 1 uses the local DF election preference in the advertised Ethernet segment routes.
As a best practice, configure this feature when the all-active redundancy mode is used, and do not configure this feature when the single-active redundancy mode is used.
When the DF restarts or the process restarts and a new DF is elected, the original DF will immediately advertise Ethernet segment routes after the restart to become the DF again. However, access-side connections restore slowly and packet loss might occur after DF switchover. To resolve this issue, configure this feature together with the Ethernet segment route advertisement delay feature on all VTEPs in an ES.
3.     Enable non-revertive mode for preference-based DF election.
By default, non-revertive mode is disabled for preference-based DF election.
When the DF restarts or the process restarts and a new DF is elected, the original DF will immediately advertise ES routes after the restart to become the DF again. However, access-side connections restore slowly and packet loss might occur after DF switchover. To resolve this issue, perform this task to configure a VTEP to delay the advertisement of ES routes.
3.     Configure ES route advertisement delay when preference-based DF election is used.
evpn timer es-recovery recovery-time
By default, ES route advertisement delay is disabled when preference-based DF election is used.
Local FRR enables two VTEPs at a multihomed EVPN VXLAN network site to set up a bypass VXLAN tunnel between them. This feature helps reduce the traffic loss caused by AC failure.
On an EVPN instance, EVPN instance-specific local FRR configuration takes precedence over global local FRR configuration.
If you have executed the evpn frr local enable command on an EVPN instance, the undo evpn multihoming vxlan-frr local command cannot disable local FRR on the EVPN instance.
Enabling local FRR globally for EVPN VXLAN
2.     Enable local FRR globally for EVPN VXLAN.
By default, local FRR is disabled globally for EVPN VXLAN.
Configuring local FRR on an EVPN instance created in system view
2.     Enter EVPN instance view.
3.     Configure local FRR.
evpn frr local { disable | enable }
By default, an EVPN instance uses the global local FRR configuration of EVPN VXLAN.
Configuring local FRR on a VSI EVPN instance
2.     Enter VSI view.
vsi vsi-name
3.     Enter VSI EVPN instance view.
4.     Configure local FRR.
By default, a VSI EVPN instance uses the global local FRR configuration of EVPN VXLAN.
EVPN multihoming routes include Ethernet auto-discovery routes and Ethernet segment routes.
In a multihomed EVPN network, perform this task on a redundant VTEP before you reboot it. This operation allows other VTEPs to refresh their EVPN routing table to prevent traffic interruption caused by the reboot.
2.     Disable advertisement of EVPN multihoming routes and withdraw the EVPN multihoming routes that have been advertised to remote sites.
evpn multihoming advertise disable
By default, the device advertises EVPN multihoming routes.
This task enables the device to withdraw the Ethernet auto-discovery routes and MAC/IP advertisement routes that have been advertised, set their Ethernet tag field to 0, and then re-advertise them.
After you configure ESIs for ACs on the redundant edge devices at a dualhomed site, the edge devices advertise Ethernet auto-discovery routes and MAC/IP advertisement routes that carry Ethernet tags. If the remote peers are unable to identify Ethernet tags, you must perform this task on the redundant edge devices to enable communication with the peers.
After you assign an ESI to a Layer 2 Ethernet or aggregate interface, you must map the Ethernet service instances created on the interface to different VSIs. If two interfaces use the same ESI, you must map the Ethernet service instances created on them to different VSIs.
After you assign an ESI to a Layer 3 main interface, its subinterfaces inherit the ESI if they do not have one. In addition, you must map two subinterfaces to different VSIs if the subinterfaces have the same ESI.
2.     Enable the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes.
evpn multihoming advertise ignore-ethernet-tag
By default, the device advertises Ethernet auto-discovery routes and MAC/IP advertisement routes that carry Ethernet tags.
Perform this task on the CE-facing interfaces of the edge devices multihomed to a site to prevent device reboots from causing inter-site forwarding failure.
This task excludes unavailable edge devices from DF election at a multihomed site. After an edge device recovers from failure and brings up its CE-facing interface, it starts the advertisement delay timer for Ethernet segment routes and checks the status of the BGP peer specified in the evpn track peer command. If the BGP peer comes up before the timer expires, the edge device advertises Ethernet segment routes to the peer. If the BGP peer is still down when the timer expires, the edge device does not advertise Ethernet segment routes to the peer. The edge devices then perform DF election based on the Ethernet segment routes they have received.
3.     Enable the device to monitor the BGP peer status of another local edge device.
evpn track peer peer-address
By default, the device does not monitor the BGP peer status of the other edge devices at a multihomed site.
4.     Set the advertisement delay timer for Ethernet segment routes.
evpn timer es-delay delay-time
By default, advertisement of Ethernet segment routes is not delayed.
The device can send the BGP EVPN routes received from an IPv4 peer to an IPv6 peer, and vice versa.
For more information about BGP commands in this task, see Layer 3—IP Routing Command Reference.
2.     Configure a global router ID.
router id router-id
By default, no global router ID is configured.
3.     Enable a BGP instance and enter BGP instance view.
By default, BGP is disabled and no BGP instances exist.
4.     Specify remote VTEPs as BGP peers.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-number as-number
5.     Create the BGP EVPN address family and enter BGP EVPN address family view.
address-family l2vpn evpn
6.     Enable BGP to exchange BGP EVPN routes with a peer or peer group.
By default, BGP does not exchange BGP EVPN routes with peers.
3.     Enter BGP EVPN address family view.
4.     Set a preferred value for routes received from a peer or peer group.
By default, the preferred value is 0 for routes received from a peer or peer group.
5.     Permit the local AS number to appear in routes from a peer or peer group and set the number of appearances.
By default, the local AS number is not allowed in routes from peers.
6.     Configure BGP to remove or replace private AS numbers with the local AS number in BGP updates sent to an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only [ force [ include-peer-as ] ] keep-local-as
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
7.     Configure the device to not change the next hop of routes advertised to an EBGP peer or peer group.
By default, the device uses its address as the next hop of routes advertised to EBGP peers.
8.     Advertise the COMMUNITY attribute to a peer or peer group.
By default, the device does not advertise the COMMUNITY attribute to peers or peer groups.
9.     Advertise the Large attribute to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-large-community
By default, the device does not advertise the Large attribute to peers or peer groups.
10.     Configure the SoO attribute for a peer or peer group.
By default, no SoO attribute is configured for a peer or peer group.
11.     Enable BGP to add the link bandwidth attribute to routes received from a BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bandwidth
By default, BGP does not add the link bandwidth attribute to routes received from a BGP peer or peer group.
4.     Advertise a default route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise { ipv4 | ipv6 } vpn-instance vpn-instance-name
By default, no default route is advertised to any peers or peer groups.
5.     Configure BGP to prefer routes with an IPv6 next hop during optimal route selection.
bestroute ipv6-nexthop
By default, BGP prefers routes with an IPv4 next hop during optimal route selection.
6.     Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority [ preferred ]
By default, BGP does not prefer routes learned from any peers or peer groups during optimal route selection.
This command takes effect only on the current address family. The specified routes are not preferred in optimal route selection after they are redistributed to a BGP routing table.
For the priority order of optimal route selection, see BGP overview in Layer 3—IP Routing Configuration Guide.
7.     Set the BGP next hop priority for optimal route selection.
bestroute nexthop-priority { ipv4 | ipv6 } [ preferred ]
By default, routes with IPv4 next hops are preferred in optimal route selection.
8.     Set the optimal route selection delay timer.
By default, the optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
9.     Configure BGP route dampening:
¡     Configure EBGP route dampening.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
¡     Configure IBGP route dampening.
dampening ibgp [ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] *
For more information about this command, see MPLS L3VPN commands in MPLS Command Reference.
By default, BGP route dampening is not configured.
For more information about route dampening, see BGP configuration in Layer 3—IP Routing Configuration Guide.
10.     Set the delay time for responding to recursive next hop changes.
nexthop recursive-lookup [ non-critical-event ] delay [ delay-value ]
By default, BGP responds to recursive next hop changes immediately.
11.     Limit the number of BGP EVPN routes that can be received from a peer or peer group.
¡     Limit the total number of BGP EVPN routes that can be received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-limit prefix-number [ { alert-only| discard | reconnect reconnect-time } | percentage-value ] *
¡     Limit the number of MAC/IP advertisement routes that can be received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } macip-route-limit route-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ]
By default, the device does not limit the number of BGP EVPN routes that can be received from a peer or peer group.
In BGP EVPN address family view, you cannot execute both the peer macip-route-limit and peer route-limit commands for a peer or peer group.
4.     Configure the device as an RR and specify a peer or peer group as its client.
By default, no RR or client is configured.
5.     (Optional.) Enable BGP EVPN route reflection between clients.
reflect between-clients
By default, BGP EVPN route reflection between clients is enabled.
6.     (Optional.) Configure the cluster ID of the RR.
By default, an RR uses its own router ID as the cluster ID.
7.     (Optional.) Create a reflection policy for the RR to filter reflected BGP EVPN routes.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, an RR does not filter reflected BGP EVPN routes.
8.     (Optional.) Enable the route reflector to change the attributes of routes to be reflected.
reflect change-path-attribute
9.     (Optional.) Add a peer or peer group to the nearby cluster.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } reflect-nearby-group
By default, the nearby cluster does not have any peers or peer groups.
The RR does not change the next hop of routes reflected to peers and peer groups in the nearby cluster.
4.     Enable route target filtering for BGP EVPN routes.
policy vpn-target
By default, route target filtering is enabled for BGP EVPN routes.
5.     Apply a routing policy to routes received from or advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
By default, no routing policies are applied to routes received from or advertised to peers or peer groups.
6.     Specify a routing policy as the existent policy to control route advertisement.
By default, advertisement of BGP EVPN routes is not controlled.
7.     Specify a routing policy as the nonexistent policy to control route advertisement.
8.     Filter routes for a peer or peer group by using a Layer 2 ACL.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { mac-acl-number | name mac-acl-name } { export | import }
By default, Layer 2 ACL-based route filtering is not configured for a peer or peer group.
For a Layer 2 ACL, only the rule [ rule-id ] { deny | permit } dest-mac dest-address dest-mask rule is used to filter MAC/IP advertisement routes that carry the specified MAC addresses. The other rules in a Layer 2 ACL do not take effect in routing filtering.
9.     Reference an IP prefix list to filter advertised BGP EVPN routes.
¡     Reference an IP prefix list to filter advertised IPv4 BGP EVPN routes.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name { export | import }
¡     Reference an IP prefix list to filter advertised IPv6 BGP EVPN routes.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ipv6 prefix-list ipv6-prefix-list-name { export | import }
By default, no IP prefix list is referenced to filter advertised BGP EVPN routes.
You can use an IP prefix list to filter only MAC/IP advertisement routes that carry host routes and IP prefix advertisement routes.
BGP advertises the BGP RPKI validation state to a peer or peer group through the extended community attribute. For more information about BGP RPKI validation, see BGP configuration in Layer 3—IP Routing Configuration Guide.
4.     Advertise the BGP RPKI validation state to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise origin-as-validation
By default, BGP does not advertise the BGP RPKI validation state.
Perform this task if the device does not support route refresh. The device will save all route updates received from peers. After the route selection policy is modified, the device filters routing information by using the new policy to implement BGP soft-reset.
For more information about route refresh and BGP soft-reset, see BGP configuration in Layer 3—IP Routing Configuration Guide.
4.     Save all route updates from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
By default, route updates from peers and peer groups are not saved.
VPN Prefix ORF introduction
By default, in large-scale networks with route reflectors, the BGP EVPN routes reflected by the RR usually include the VPN routes from all BGP-VPN instances on the route originator. The current route limit measures can take effect only on address families. When the number of routes for RR reflection reaches the limit, unwanted BGP-VPN instance routes might occupy most of the receiving end's received routes, resulting in the receiving end not being able to receive the necessary BGP-VPN instance routes.
To resolve this issue, it is required to allow the RR to filter routes based on the BGP-VPN instances of the routes on the originator, implementing router filtering at the granularity of BGP-VPN instances in the BGP VPNv4 address families. Enabling the VPN Prefix Outbound Route Filtering (ORF) feature can resolve the above issue. This feature uses route-refresh messages to send VPN Prefix ORF entries (which contain information for route matching) to peers. Peers will withdraw all previously advertised routes that match the VPN Prefix ORF entries and when sending new routes to the local device, they must filter the routes using both the routing policy on the peer device and the received VPN Prefix ORF entries. Only routes that pass both filters will be sent to the local device. VPN Prefix ORF realizes the advertisement and reception of route control at the BGP-VPN instance granularity. It limits the number of routes at the source of route sending to reduce route exchanges between BGP peers and save network resources.
VPN Prefix ORF operating mechanism
After configuring this feature, the BGP session between the local device and the specified peer/peer group will be disconnected and reestablished for VPN Prefix ORF capability negotiation via Open messages. Negotiation can be successful only if the peer capability-advertise orf vpn-prefix command is configured on both ends of the BGP session. After successful negotiation, the device will be able to parse the route-refresh messages carrying VPN Prefix ORF entries sent by the remote end. A VPN Prefix ORF entry contains a <RD value, source device address> tuple.
If the devices in the BGP session do not support the exchange of route-refresh messages, the VPN Prefix ORF entries will not be successfully sent. Configure the peer capability-advertise route-refresh command on both ends of the BGP session to enable the capability of exchanging route-refresh messages.
For more information the peer capability-advertise route-refresh command, see BGP commands in Layer 3—IP Routing Command Reference.
The VPN Prefix ORF feature uses the following conditions to determine whether to trigger sending VPN Prefix ORF entries:
·     The <RD, source device address> tuple used to match VPN routes and the alarm threshold for the matching VPN routes, which is used to match VPN routes.
·     The maximum number of routes supported by a BGP-VPN instance, which is set by using the route-limit command.
After these conditions are set on the device, when the number of IPv4 or IPv6 unicast routes in a BGP-VPN instance exceeds the route limit, and the percentage of the routes that match the tuple in the BGP-VPN instance exceeds the alarm threshold:
1.     The device checks if there are other BGP-VPN instances configured with the same tuple.
¡     If yes, go to step 2.
¡     If not, go to step 3.
2.     The device checks if the number of routes in these BGP-VPN instances has exceeded the route limit and if the number of routes matching the tuple has exceeded the alarm threshold.
¡     If yes, go to step 3.
¡     If not, the BGP-VPN instance that contains routes exceeding the route limit will continue to receive routes and repeat step 2.
3.     The device sends a route-refresh message with a VPN Prefix ORF entry to the peer/peer group specified by the peer capability-advertise orf vpn-prefix command.
TIP
TIP:
Among the BGP-VPN instances configured with the same tuple, if the number of routes matching the tuple in some BGP-VPN instances has exceeded the alarm threshold, while some BGP-VPN instances have not received any routes matching the tuple, it indicates that these instances cannot receive routes matching the tuple. The device will not consider these BGP-VPN instances when determining whether to trigger sending VPN Prefix ORF entries.
A VPN Prefix ORF entry contains a <RD value, source device address> tuple. The values of RD and source device address are those specified by using the vpn-prefix-quota command.
After receiving a route-refresh message carrying a VPN Prefix ORF entry from the local device, the specified peer/peer group operates as follows:
·     Withdraws all BGP EVPN routes that match both the RD and source device address in the VPN Prefix ORF entry. (The route information matching the source device address in the VPN Prefix ORF entry is the next hop attribute of the route.)
·     No longer sends BGP EVPN routes that match the VPN Prefix ORF entry to the local device.
If the device has previously advertised VPN Prefix ORF entries, the entries will remain effective on the peer to filter route advertisement. You can execute the clear bgp vpn-prefix-orf command to withdraw the previously advertised VPN Prefix ORF entries, so that the peer can re-advertise routes that were withdrawn or filtered due to the VPN Prefix ORF entries.
VPN Prefix ORF application network diagram
As shown in Figure 18, VPN instances are configured on each PE. The RR reflects routes from PE 1, PE 2, and PE 3 within the same AS. Both PE 1 and PE 2 have successfully negotiated the VPN Prefix ORF capabilities with the RR. PE 1 specifies the tuple as <RD31, PE3> and the alarm threshold as 70% in the BGP-VPN instances corresponding to VPN1 and VPN2 by using the vpn-prefix-quota command. PE 2 specifies the tuple as <RD31, PE3> and the alarm threshold as 70% in the BGP-VPN instance corresponding to VPN1 by using the vpn-prefix-quota command.
Figure 18 VPN Prefix ORF application network diagram
PE 3 advertises routes of VPN1 through BGP EVPN. When the advertised routes cause BGP-VPN instances on PE 1 and PE 2 to exceed the route limit, VPN Prefix ORF will function on PE 1 and PE 2 as follows:
·     On PE 1
The number of routes in the BGP-VPN instance for VPN1 exceeded the limit, and the number of routes matching <RD31, PE3> exceeded 70% of the total routes. However, PE 1 would not send route-refresh messages carrying VPN Prefix ORF entries because the BGP-VPN instances for VPN2 and VPN1 have the same tuple <RD31, PE3>, and PE 1 could still receive VPN1 routes carrying RT 1 and RT 2 from PE 3 for the BGP-VPN instance corresponding to VPN2. PE 1 will send a route-refresh message carrying a VPN Prefix ORF entry to the RR only when both the BGP-VPN instances for VPN1 and VPN2 have exceeded the route limit and the VPN routes matching the <RD31, PE3> tuple have also exceeded the alarm threshold. The advertised VPN Prefix ORF entry contains the following information:  <RD31, min (maximum route count supported by BGP-VPN instance for VPN1, maximum route count supported by BGP-VPN instance for VPN2), PE3 address>.
After receiving the route-refresh message with the VPN Prefix ORF entry, the RR will withdraw the advertised routes that meet the following conditions from PE 1 and will no longer advertise the routes that meet the following conditions to PE 1:
¡     The RD carried by the routes is RD31.
¡     The next hop address of the routes is the address of PE 3.
Figure 19 VPN Prefix ORF taking effect
·     On PE 2
When the number of routes in the BGP-VPN instance for VPN1 exceeds the limit, PE 2 will immediately send a route-refresh message carrying a VPN Prefix ORF entry to the RR because no other BGP-VPN instances have specified the same tuple. The advertised VPN Prefix ORF entry contains the following information:  <RD31, maximum route count supported by BGP-VPN instance for VPN1, PE3 address>.
After receiving the route-refresh message carrying the VPN Prefix ORF entry, the RR will withdraw the advertised routes that meet the following conditions from PE 2 and will no longer advertise routes that meet the following conditions to PE 2:
In the current software version, only VPN Prefix ORF within the same AS is supported. VPN Prefix ORF across ASs is not supported.
You must configure the route-limit, vpn-prefix-quota route-distinguisher, and peer capability-advertise orf vpn-prefix commands at the same time for VPN Prefix ORF to operate properly.
The receiving end of VPN Prefix ORF information does not differentiate between IPv4 and IPv6 routes in withdrawing BGP EVPN routes, no matter whether the VPN Prefix ORF information is triggered by either IPv4 private network routes or IPv6 private network routes. All BGP EVPN routes matching the VPN Prefix ORF information will be withdrawn.
Configuring a VPN instance
2.     Create a VPN instance and enter its view.
3.     Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
4.     Configure route targets for the VPN instance.
By default, no route targets are configured for a VPN instance.
Configuring the conditions that trigger the VPN Prefix ORF mechanism
3.     Enter BGP-VPN instance view.
4.     Enter BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view.
¡     Enter BGP-VPN IPv4 unicast address family view.
¡     Enter BGP-VPN IPv6 unicast address family view.
For more information about these commands, see BGP commands in Layer 3—IP Routing Command Reference.
5.     Set the maximum number of routes supported by the BGP-VPN instance.
route-limit limit
By default, the maximum number of routes supported by a BGP-VPN instance is 4294967295.
6.     Set the tuple for routing matching and set the alarm threshold for routes  matching the tuple.
vpn-prefix-quota route-distinguisher route-distinguisher source-address { ipv4-address | ipv6-address } quota threshold evpn
By default, no tuple or alarm threshold is set, and no alarm information will be triggered for tuple-matching routes.
Configuring the VPN Prefix ORF feature
4.     Enable negotiating VPN Prefix ORF capabilities with the specified BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] |ipv6-address [ prefix-length ] } capability-advertise orf vpn-prefix { both | send | receive }
By default, the local end does not negotiate VPN Prefix ORF capabilities with BGP peer/peer group.
5.     (Optional.) Withdraw the advertised VPN Prefix ORF entries.
a.     Execute the following commands in sequence to return to user view:
b.     Withdraw the advertised VPN Prefix ORF entries.
clear bgp [ instance instance-name ] vpn-prefix-orf [ vpn-instance vpn-instance-name | route-distinguisher route-distinguisher source-address { ipv4-address | ipv6-address } ] evpn
Perform the following tasks in user view:
·     Reset BGP sessions of the BGP EVPN address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } l2vpn evpn
·     Soft-reset BGP sessions of the BGP EVPN address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } l2vpn evpn
Mapping a Layer 3 interface to a VSI
To assign the customer traffic on a Layer 3 interface to a VXLAN, map the interface to the VXLAN's VSI. The VSI uses its MAC address table to forward the customer traffic.
2.     Enter Layer 3 interface view.
3.     Map the Layer 3 interface to a VSI.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
By default, a Layer 3 interface is not mapped to any VSI.
Mapping an Ethernet service instance to a VSI
An Ethernet service instance matches a list of VLANs on a site-facing interface by using a frame match criterion. The frame match criterion specifies the characteristics of traffic from the VLANs, such as tagging status and VLAN IDs. The VTEP assigns traffic from the VLANs to a VXLAN by mapping the Ethernet service instance to a VSI. The VSI performs Layer 2 forwarding for the VLANs based on its MAC address table.
An Ethernet service instance can contain only one match criterion. To change the match criterion, you must remove the original criterion first. When you remove the match criterion in an Ethernet service instance, the mapping between the service instance and the VSI is removed automatically.
3.     Create an Ethernet service instance and enter Ethernet service instance view.
service-instance instance-id
4.     Match frames with the specified outer VLAN tag.
encapsulation s-vid vlan-id
By default, an Ethernet service instance does not contain a frame match criterion.
5.     Map the Ethernet service instance to a VSI.
By default, an Ethernet service instance is not mapped to any VSI.
If an EVPN network contains a centralized EVPN gateway, you must enable ARP or ND flood suppression on VTEPs. Typically remote ARP or ND learning is disabled in an EVPN network. When ARP or ND requests for the gateway MAC address are sent to the centralized EVPN gateway through VXLAN tunnels, the gateway does not respond to the requests. If ARP or ND flood suppression is disabled on VTEPs, VMs cannot obtain the MAC address of the gateway.
2.     Create a VSI interface and enter VSI interface view.
interface vsi-interface vsi-interface-id
For more information about this command, see VXLAN Command Reference.
3.     Assign an IP address to the VSI interface.
IPv4:
IPv6:
See IPv6 basics in Layer 3—IP Services Configuration Guide.
By default, no IP address is assigned to a VSI interface.
4.     Return to system view.
5.     Enter VSI view.
vsi vsi-name
6.     Specify the VSI interface as the gateway interface for the VSI.
gateway vsi-interface vsi-interface-id
By default, no gateway interface is specified for a VSI.
Restrictions and guidelines for distributed EVPN gateway configuration
Make sure a VSI interface uses the same MAC address to provide service on distributed EVPN gateways connected to IPv4 sites. Make sure a VSI interface uses different link-local addresses to provide service on distributed EVPN gateways connected to both IPv4 and IPv6 sites.
For a VXLAN to access the external network, specify the VXLAN's VSI interface on the border gateway as the next hop on distributed EVPN gateways by using one of the following methods:
·     Configure a static route.
·     Configure a routing policy and apply the policy by using the apply default-next-hop or apply next-hop command. For more information about configuring routing policies, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
As a best practice, do not use ARP flood suppression and local proxy ARP or ND flood suppression and local ND proxy together on distributed EVPN gateways. If both ARP flood suppression and local proxy ARP are enabled on a distributed EVPN gateway, only local proxy ARP takes effect. If both ND flood suppression and local ND proxy are enabled on a distributed EVPN gateway, only local ND proxy takes effect.
On a distributed EVPN gateway, make sure the VSI interfaces configured with L3 VXLAN IDs use the same MAC address. To modify the MAC address of a VSI interface, use the mac-address command.
Configuring the traffic forwarding mode for EVPN VXLAN
The asymmetric IRB mode is supported only on distributed EVPN gateways. The mode takes effect only on Layer 3 traffic forwarded in the same VXLAN. In addition, the same VSI interface on different distributed EVPN gateways must have different IP addresses.
2.     Configure the traffic forwarding mode for EVPN VXLAN. Choose one of the following options:
¡     Enable asymmetric IRB mode.
evpn irb asymmetric
¡     Enable symmetric IRB mode.
undo evpn irb asymmetric
By default, a distributed EVPN gateway forwards EVPN VXLAN traffic in symmetric IRB mode.
Configuring a VSI interface
To save Layer 3 interface resources on a distributed EVPN gateway, multiple VSIs can share one VSI interface. You can assign multiple IP addresses to the VSI interface for the VSIs to use as gateway addresses.
When VSIs share a VSI interface, you must specify the subnet of each VSI for the VSI interface to identify the VSI of a packet. The subnets must be unique.
3.     Assign an IPv4 or IPv6 address to the VSI interface.
IPv4:
IPv6:
By default, no IPv4 or IPv6 address is assigned to a VSI interface.
4.     (Optional.) Assign a MAC address to the VSI interface.
mac-address mac-address
The default MAC address of a VSI interface is the bridge MAC address + 2.
To ensure correct forwarding after VM migration, you must assign the same MAC address to the VSI interfaces of a VXLAN on all distributed gateways.
5.     Specify the VSI interface as a distributed gateway.
distributed-gateway local
By default, a VSI interface is not a distributed gateway.
6.     (Optional.) Enable local proxy ARP or local ND proxy.
IPv4:
local-proxy-arp enable [ ip-range startIP to endIP ]
By default, local proxy ARP is disabled.
For more information about the command, see proxy ARP commands in Layer 3—IP Services Command Reference.
IPv6:
local-proxy-nd enable
By default, local ND proxy is disabled.
For more information about the commands, see IPv6 basic commands Layer 3—IP Services Command Reference.
8.     Enter VSI view.
vsi vsi-name
9.     Specify the VSI interface as the gateway interface for the VSI.
10.     Assign a subnet to the VSI.
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
By default, no subnet exists on a VSI.
Restrictions and guidelines for L3 VXLAN ID configuration
The L3 VXLAN ID of a VSI interface cannot be the same as any VXLAN ID specified by using the mapping vni command. For more information about the mapping vni command, see "Configuring EVPN-DCI."
A distributed EVPN gateway uses the following rules to select the router MAC address:
·     If a VSI interface has been assigned an L3 VXLAN ID and a MAC address, you must also assign the same MAC address to the other VSI interfaces that are assigned L3 VXLAN IDs. That MAC address will be used as the router MAC address by the distributed EVPN gateway interfaces.
·     If no VSI interface has an L3 VXLAN ID or a manually assigned MAC address, the distributed EVPN gateway uses its bridge MAC address as the router MAC address.
If the elected router MAC address takes effect on a distributed EVPN gateway, creation of VSI interfaces does not trigger re-election of the router MAC address.
Configuring an L3 VXLAN ID for the VSI interface of a VPN instance
2.     Configure a VPN instance:
a.     Create a VPN instance and enter VPN instance view.
b.     Configure an RD for the VPN instance.
c.     Configure route targets for the VPN instance.
vpn-target { vpn-target&<1-8> [ both | export-extcommunity | import-extcommunity ] | auto }
By default, a VPN instance does not have route targets.
d.     (Optional.) Apply an export routing policy to the VPN instance.
By default, no export routing policy is applied to a VPN instance.
e.     (Optional.) Apply an import routing policy to the VPN instance.
By default, no import routing policy is applied to a VPN instance.
f.     (Optional.) Enter VPN instance IPv4 or IPv6 address family view.
address-family { ipv4 | ipv6 }
g.     (Optional.) Configure route targets for EVPN.
vpn-target vpn-target&<1-8> [ both | export-extcommunity | import-extcommunity ] evpn
The route targets you configure apply only to BGP EVPN routes. They do not apply to VPNv4 or VPNv6 routes. You can configure different route targets for BGP EVPN routes and VPNv4 and VPNv6 routes.
h.     (Optional.) Return to VPN instance view.
3.     Configure EVPN on the VPN instance:
a.     Enter VPN instance EVPN view.
address-family evpn
b.     Configure route targets for EVPN on the VPN instance.
By default, EVPN does not have route targets on a VPN instance.
-     The import targets of EVPN do not match the export targets of the VPN instance.
-     The export targets of EVPN do not match the import targets of the VPN instance.
c.     (Optional.) Apply an export routing policy to EVPN on the VPN instance.
By default, no export routing policy is applied to EVPN on a VPN instance.
An export routing policy is used to filer the routes redistributed from a VPN instance to BGP EVPN.
d.     (Optional.) Apply an import routing policy to EVPN on the VPN instance.
By default, no import routing policy is applied to EVPN on a VPN instance. The VPN instance accepts a route when the route targets of the route match local import route targets.
An import routing policy is used to filer the routes redistributed from BGP EVPN to a VPN instance.
4.     Execute the following commands in sequence to return to system view.
a.     quit
b.     quit
5.     Create a VSI interface and enter VSI interface view.
6.     Associate the VSI interface with the VPN instance.
By default, a VSI interface is not associated with a VPN instance. The interface is on the public network.
7.     (Optional.) Assign a MAC address to the VSI interface.
8.     Configure an L3 VXLAN ID for the VSI interface.
l3-vni vxlan-id
By default, no L3 VXLAN ID is configured for a VSI interface.
A VPN instance can have only one L3 VXLAN ID. If multiple L3 VXLAN IDs are configured for a VPN instance, the VPN instance uses the lowest one. To view the L3 VXLAN ID of a VPN instance, use the display evpn routing-table command.
Configuring an L3 VXLAN ID for the VSI interface of the public instance
2.     Create the public instance and enter its view.
ip public-instance
3.     Configure an RD for the public instance.
By default, no RD is configured for the public instance.
4.     Configure an L3 VXLAN ID for the public instance.
l3-vni vxlan-id
By default, the public instance does not have an L3 VXLAN ID.
The public instance can have only one L3 VXLAN ID. To modify the L3 VXLAN ID for the public instance, you must first delete the original L3 VXLAN ID.
5.     (Optional.) Configure route targets for the public instance.
By default, the public instance does not have route targets.
6.     Enter IPv4 address family view, IPv6 address family view, or EVPN view.
¡     Enter IPv4 address family view.
address-family ipv4
¡     Enter IPv6 address family view.
address-family ipv6
¡     Enter EVPN view.
address-family evpn
7.     Configure route targets for IPv4 VPN, IPv6 VPN, or EVPN.
By default, IPv4 VPN, IPv6 VPN, and EVPN do not have route targets on the public instance.
¡     The import targets of an EVPN instance do not match the export targets of the public instance.
¡     The export targets of an EVPN instance do not match the import targets of the public instance.
8.     Execute the following commands in sequence to return to system view.
a.     quit
b.     quit
9.     Create a VSI interface and enter its view.
10.     Configure an L3 VXLAN ID for the VSI interface.
l3-vni vxlan-id
Of the VSI interfaces associated with the public instance, a minimum of one VSI interface must use the same L3 VXLAN ID as the public instance.
Configuring IP prefix route advertisement
If IGP routes are imported to the BGP-VPN IPv4 or IPv6 unicast address family and the corresponding VPN instance has an L3 VXLAN ID, the device advertises the imported routes as IP prefix advertisement routes.
If IGP routes are imported to the BGP IPv4 or IPv6 unicast address family and the public instance has an L3 VXLAN ID, the device advertises the imported routes as IP prefix advertisement routes.
A VTEP compares the export route targets of received IP prefix advertisement routes with the import route targets configured for IPv4 VPN or IPv6 VPN on a VPN instance or the public instance. If the route targets match, the VTEP accepts the routes and adds the routes to the routing table of the VPN instance or public instance.
This feature is supported only by distributed EVPN gateway deployment.
For more information about the BGP commands in this task, see Layer 3—IP Routing Command Reference.
2.     Enable a BGP instance and enter BGP instance view.
3.     Enter BGP address family view.
¡     Enter BGP IPv4 unicast address family view.
¡     Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view.
¡     Enter BGP IPv6 unicast address family view.
¡     Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view.
4.     Enable BGP to redistribute routes from an IGP protocol.
By default, BGP does not redistribute IGP routes.
5.     (Optional.) Enable default route redistribution into the BGP routing table.
default-route imported
By default, default route redistribution into the BGP routing table is disabled.
6.     (Optional.) Configure ECMP VPN route redistribution:
a.     Return to BGP instance view.
b.     Enter BGP EVPN address family view.
c.     Enable ECMP VPN route redistribution.
vpn-route cross multipath
By default, ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, BGP only imports the optimal route into the EVPN routing table.
ECMP VPN route redistribution enables BGP to import all routes that have the same prefix and RD into the EVPN routing table.
Disabling remote MAC address learning and remote ARP or ND learning
By default, the device learns MAC information, ARP information, and ND information of remote user terminals from packets received on VXLAN tunnel interfaces. The automatically learned remote MAC, ARP, and ND information might conflict with the remote MAC, ARP, and ND information advertised through BGP. As a best practice to avoid the conflicts, disable remote MAC address learning and remote ARP or ND learning on the device.
2.     Disable remote MAC address learning.
By default, remote MAC address learning is enabled.
3.     Disable remote ARP learning.
vxlan tunnel arp-learning disable
By default, remote ARP learning is enabled.
4.     Disable remote ND learning.
vxlan tunnel nd-learning disable
By default, remote ND learning is enabled.
Disabling MAC address advertisement
The MAC information and ARP or ND information advertised by the VTEP overlap. To avoid duplication, disable MAC address advertisement and withdraw the MAC addresses advertised to remote VTEPs.
Disabling MAC address advertisement in EVPN instance view
3.     Disable MAC address advertisement and withdraw advertised MAC addresses.
mac-advertising disable
By default, MAC address advertisement is enabled.
Disabling MAC address advertisement in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
4.     Disable MAC address advertisement and withdraw advertised MAC addresses.
Enabling MAC mobility event suppression
On an EVPN VXLAN network, misconfiguration of MAC addresses might cause two sites to contain the same MAC address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN MAC entries and determine that MAC mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by MAC entry synchronization traffic. To eliminate loops and suppress those MAC mobility events, enable MAC mobility event suppression on the VTEPs.
The MAC mobility event suppression feature allows a MAC address to move at most the specified number of times (MAC mobility suppression threshold) out of a site within a MAC mobility detection cycle. If the suppression threshold has been reached for a MAC address within a detection cycle, the VTEP at the site suppresses the subsequent move after the MAC address moves back to the site. In addition, the VTEP learns the MAC address but does not advertise it.
After you execute the undo evpn route mac-mobility suppression command or when the MAC mobility suppression time expires, a VTEP acts as follows:
·     Advertises MAC address entries immediately for the suppressed MAC address entries that have not aged out.
·     Relearns the MAC addresses for the suppressed MAC address entries that have aged out and advertises the MAC address entries.
If both MAC address entry conflicts and ARP entry conflicts exist for a MAC address, you must enable both MAC mobility event suppression and ARP mobility event suppression. If you enable only MAC mobility event suppression, the system cannot suppress MAC mobility events for the MAC address.
The MAC mobility event suppression setting configured in system view takes effect on all EVPN instances. The MAC mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The MAC mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The MAC mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The MAC mobility event suppression settings configured in the following views are in descending order of priority:
1.     Layer 3 interface view.
2.     EVPN instance view or VSI EVPN instance view.
3.     System view.
Enabling MAC mobility event suppression in system view
2.     Enable MAC mobility event suppression.
evpn route mac-mobility suppression [ detect-cycle detect-time | detect-threshold  move-times | suppression-time [ suppression-time | permanent ] ] *
By default, MAC mobility event suppression is disabled.
Enabling MAC mobility event suppression in EVPN instance view
3.     Enable MAC mobility event suppression.
Enabling MAC mobility event suppression in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
4.     Enable MAC mobility event suppression.
Enabling MAC mobility event suppression in Layer 3 interface view
Disabling learning of MAC addresses from ARP or ND information
The MAC information and ARP or ND information advertised by a remote VTEP overlap. To avoid duplication, disable the learning of MAC addresses from ARP or ND information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
Disabling learning of MAC addresses from ARP or ND information in EVPN instance view
3.     Disable the EVPN instance from learning MAC addresses from ARP information.
arp mac-learning disable
By default, an EVPN instance learns MAC addresses from ARP information.
4.     Disable the EVPN instance from learning MAC addresses from ND information.
nd mac-learning disable
By default, an EVPN instance learns MAC addresses from ND information.
Disabling learning of MAC addresses from ARP or ND information in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
4.     Disable the EVPN instance from learning MAC addresses from ARP information.
5.     Disable the EVPN instance from learning MAC addresses from ND information.
Configuring the AC source MAC check feature
In an EVPN VXLAN network, devices advertise local MAC addresses to remote sites through BGP EVPN routes. If the device erroneously learns a local MAC address identical to an advertised remote MAC address, it will refresh the related MAC address entry and fail to forward the traffic destined for the remote MAC address.
To prevent the device from learning incorrect local MAC address entries, enable AC source MAC check. This feature disables the device from learning the source MAC address of a packet received from an AC if the source MAC address is in the MAC address list for AC source MAC check.
If you repeat the mac-address source-mac-check ac mac-address mask command to specify different MAC addresses, all the specified MAC addresses are added for AC source MAC check.
If you repeat the mac-address source-mac-check ac mac-address mask command to specify the same MAC address and different MAC address masks, the most recent configuration takes effect.
To view the MAC addresses for AC source MAC check, execute the display this command in VSI view.
2.     Enter VSI view.
vsi vsi-name
3.     Enable AC source MAC check and add MAC address entries for this feature.
By default, AC source MAC check is disabled.
Disabling ARP information advertisement
In an EVPN network with distributed gateways, you can disable ARP information advertisement for a VXLAN to save resources if all its user terminals use the same EVPN gateway device. The EVPN instance of the VXLAN will stop advertising ARP information through MAC/IP advertisement routes and withdraw advertised ARP information. When ARP information advertisement is disabled, user terminals in other VXLANs still can communicate with that VXLAN through IP prefix advertisement routes.
Disabling ARP information advertisement in EVPN instance view
3.     Disable ARP information advertisement for the EVPN instance.
arp-advertising disable
By default, ARP information advertisement is enabled for an EVPN instance.
Disabling ARP information advertisement in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
4.     Disable ARP information advertisement for the EVPN instance.
Enabling ARP mobility event suppression
On an EVPN VXLAN network, misconfiguration of IP addresses might cause two sites to contain the same IP address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN ARP entries and determine that ARP mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by ARP entry synchronization traffic. To eliminate loops and suppress those ARP mobility events, enable ARP mobility event suppression on the VTEPs.
The ARP mobility event suppression feature allows an IP address to move at most the specified number of times (ARP mobility suppression threshold) out of a site within an ARP mobility detection cycle. If the suppression threshold has been reached for an IP address within a detection cycle, the VTEP at the site suppresses the subsequent move after the IP address moves back to the site. In addition, the VTEP learns ARP information for the IP address but does not advertise the ARP information.
ARP mobility event suppression takes effect only on an EVPN VXLAN network configured with distributed VXLAN IP gateways.
After you execute the undo evpn route arp-mobility suppression command or when the ARP mobility suppression time expires, a VTEP acts as follows:
·     Advertises ARP information immediately for the suppressed ARP entries that have not aged out.
·     Relearns ARP information for the suppressed ARP entries that have aged out and advertises the ARP information.
The ARP mobility event suppression setting configured in system view takes effect on all EVPN instances. The ARP mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The ARP mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The ARP mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The ARP mobility event suppression settings configured in the following views are in descending order of priority:
3.     System view.
Enabling ARP mobility event suppression in system view
2.     Enable ARP mobility event suppression.
evpn route arp-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
By default, ARP mobility event suppression is disabled.
Enabling ARP mobility event suppression in EVPN instance view
3.     Enable ARP mobility event suppression.
Enabling ARP mobility event suppression in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
4.     Enable ARP mobility event suppression.
Enabling ARP mobility event suppression in Layer 3 interface view
Enabling ND mobility event suppression
On an EVPN VXLAN network, misconfiguration of IP addresses might cause two sites to contain the same IP address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN ND entries and determine that ND mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by ND entry synchronization traffic. To eliminate loops and suppress those ND mobility events, enable ND mobility event suppression on the VTEPs. This feature allows an IP address to move a specified number of times (the ND mobility suppression threshold) from a site within an ND mobility detection cycle. If an IP address moves more than the ND mobility suppression threshold, the VTEP at the site will suppress the last ND move to the local site and will not advertise ND information for the IP address.
After you execute the undo evpn route nd-mobility suppression command or the suppression time expires, a VTEP acts as follows:
·     Advertises ND information immediately for the suppressed ND entries that have not aged out.
·     Relearns ND information for the suppressed ND entries that have aged out and advertises the ND information.
ND mobility event suppression takes effect only on the following EVPN VXLAN networks:
·     EVPN VXLAN network enabled with ND flood suppression.
·     EVPN VXLAN network configured with distributed VXLAN IP gateways.
If both MAC address entry conflicts and ND entry conflicts exist for a MAC address, you must enable both MAC mobility event suppression and ND mobility event suppression. If you enable only MAC mobility event suppression, the system cannot suppress MAC mobility events for the MAC address.
The ND mobility event suppression setting configured in system view takes effect on all EVPN instances. The ND mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The ND mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The ND mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The ND mobility event suppression settings configured in the following views are in descending order of priority:
3.     System view.
Enabling ND mobility event suppression in system view
2.     Enable ND mobility event suppression.
evpn route nd-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
By default, ND mobility event suppression is disabled.
Enabling ND mobility event suppression in EVPN instance view
evpn instance instance-name
3.     Enable ND mobility event suppression.
Enabling ND mobility event suppression in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
evpn encapsulation vxlan
4.     Enable ND mobility event suppression.
Enabling ND mobility event suppression in Layer 3 interface view
Configuring BGP EVPN route redistribution and advertisement
Redistributing MAC/IP advertisement routes into BGP unicast routing tables
This task enables the device to redistribute received MAC/IP advertisement routes that contain ARP or ND information into a BGP unicast routing table.
·     If you perform this task for the BGP IPv4 or IPv6 unicast address family, the device will redistribute the routes into the BGP IPv4 or IPv6 unicast routing table. In addition, the device will advertise the routes to the local site.
·     If you perform this task for the BGP-VPN IPv4 or IPv6 unicast address family, the device will redistribute the routes into the BGP-VPN IPv4 or IPv6 unicast routing table of the corresponding VPN instance. To advertise the routes to the local site, you must configure the advertise l2vpn evpn command.
Procedure (BGP instance view)
3.     Enter BGP IPv4 or IPv6 unicast address family view.
4.     Redistribute MAC/IP advertisement routes that contain ARP or ND information into the BGP IPv4 or IPv6 unicast routing table.
import evpn mac-ip
By default, MAC/IP advertisement routes that contain ARP or ND information are not redistributed into the BGP IPv4 or IPv6 unicast routing table.
Procedure (BGP-VPN instance view)
4.     Enter BGP-VPN IPv4 or IPv6 unicast address family view.
5.     Redistribute MAC/IP advertisement routes that contain ARP or ND information into the BGP-VPN IPv4 or IPv6 unicast routing table.
import evpn mac-ip
By default, MAC/IP advertisement routes that contain ARP or ND information are not redistributed into the BGP-VPN IPv4 or IPv6 unicast routing table.
Setting the metric of BGP EVPN routes added to a VPN instance's routing table
After you perform this task, the device sets the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
4.     Set the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
igp-metric inherit
By default, the device sets the metric to 0 when adding BGP EVPN routes a VPN instance's routing table.
Enabling BGP EVPN route advertisement to the local site
This feature enables the device to advertise private BGP EVPN routes to the local site after the device adds the routes to the routing table of a VPN instance.
Procedure (IPv4)
4.     Enter BGP-VPN IPv4 unicast address family view.
5.     Enable BGP EVPN route advertisement to the local site.
By default, BGP EVPN route advertisement to the local site is enabled.
Procedure (IPv6)
4.     Enter BGP-VPN IPv6 unicast address family view.
Configuring EVPN ORF
About EVPN ORF based on route targets
EVPN ORF reduces the BGP EVPN routes advertised by BGP EVPN peers in a large EVPN network.
By default, the device advertises BGP EVPN routes to a peer even if no EVPN instance on the peer matches the route targets in the BGP EVPN routes. To reduce resource consumption and save bandwidth, enable EVPN ORF for the device to advertise only BGP EVPN routes of interest to each BGP EVPN peer.
To use EVPN ORF, you must also configure BGP IPv4 RT-Filter route exchange. With EVPN ORF enabled, the device filters all BGP EVPN routes advertised to the BGP EVPN peers with which the device has established BGP EVPN sessions and BGP IPv4 RT-Filter sessions as follows:
·     If the route targets in a BGP EVPN route match a received BGP IPv4 RT-Filter route, the device advertises the BGP EVPN route to the peer that advertises the BGP IPv4 RT-Filter route.
·     If the route targets in a BGP EVPN route do not match any received BGP IPv4 RT-Filter route, the device does not advertise the BGP EVPN route.
With EVPN ORF disabled, the device advertises the route targets configured in public instance IPv4 address family view and VPN instance address family view through BGP IPv4 RT-Filter routes. After you enable EVPN ORF, the device also advertises the following route targets through BGP IPv4 RT-Filter routes:
·     Import targets configured in VPN instance EVPN view and public instance EVPN view.
·     Import targets configured for EVPN in VPN instance IPv4 address family view.
·     Import targets configured in VSI EVPN instance view.
·     ES-Import route targets automatically generated based on the ESIs of interfaces, UPWs, and VSIs.
All the route targets carried by BGP IPv4 RT-Filter routes are used for filtering of BGP EVPN routes.
With EVPN ORF enabled, the device filters BGP EVPN routes advertised to all BGP EVPN peers with which the device has established both BGP EVPN sessions and BGP IPv4 RT-Filter sessions. If EVPN ORF is not enabled on a BGP EVPN peer, the BGP EVPN peer might advertise only some local route targets or even does not advertise local route targets. As a result, the device advertises only some BGP EVPN routes or even does not advertise BGP EVPN routes to the BGP EVPN peer. For the device to advertise BGP EVPN routes to the EVPN ORF-incapable BGP EVPN peers that have established BGP IPv4 RT-Filter sessions with the device, disable EVPN ORF for those BGP EVPN peers by using the peer vpn-orf ignore command. The device will skip route filtering when advertising BGP EVPN routes to those BGP EVPN peers.
About EVPN ORF based on the prefix list
EVPN ORF based on the prefix list enables the device to negotiate ORF capabilities with peers through Open messages. After completing the negotiation process, the device and a peer can exchange standard ORF information that contains the prefix list carried in the BGP routes received by the device or peer through route refresh messages. Then, the device and the peer advertise only the BGP route prefixes that match the prefix list in their received standard ORF information.
Follow these guidelines when you configure EVPN ORF based on both route targets and the prefix list:
·     EVPN ORF based on the prefix list enables BGP EVPN route filtering based on the prefix list. EVPN ORF based on route targets enables BGP EVPN route filtering based on route targets. These features are independent of each other.
·     EVPN ORF based on the prefix list takes effect on IPv4 MAC/IP advertisement routes and IP prefix advertisement routes. EVPN ORF based on route targets takes effect on all BGP EVPN routes.
To use EVPN ORF based on route targets, enable it on both ends of a BGP EVPN session. With EVPN ORF enabled, the device does not filter the BGP EVPN routes advertised to peers with which the device has established only BGP EVPN sessions. The device advertises all BGP EVPN routes to those peers.
BGP IPv4 RT-Filter routes do not carry the route targets configured for IPv6 VPN. Therefore, some BGP EVPN routes carrying IPv6 addresses cannot be advertised. For example, if import target 8:8 is configured for EVPN in IPv6 address family view of VPN instance vpn1, BGP IPv4 RT-Filter routes do not carry this route target. As a result, the device cannot receive the IPv6 BGP EVPN routes carrying export target 8:8. To resolve this issue, configure identical route targets for IPv6 VPN and IPv4 VPN.
For more information about BGP IPv4 RT-Filter routes, see MPLS L3VPN configuration in MPLS Configuration Guide.
If nonstandard ORF capabilities negotiation is required by EVPN ORF based on the prefix list, enable it for peers by using the peer capability-advertise orf non-standard command.
To use EVPN ORF based on route targets, you must also configure BGP IPv4 RT-Filter route exchange on the BGP peers with EVPN ORF enabled.
To use EVPN ORF based on the prefix list, use the peer prefix-list command in BGP EVPN address family view to configure a prefix list used for BGP EVPN route filtering. For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
Configuring EVPN ORF based on route targets
3.     Enter BGP IPv4 RT-Filter address family view.
address-family ipv4 rtfilter
4.     Enable the device to exchange BGP IPv4 RT-Filter routes with a peer or peer group.
By default, the device does not exchange BGP IPv4 RT-Filter routes with peers or peer groups.
5.     Return to BGP instance view.
6.     Enter BGP EVPN address family view.
7.     Enable EVPN ORF based on route targets.
vpn-orf enable
By default, EVPN ORF based on route targets is disabled.
8.     (Optional.) Disable EVPN ORF for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } vpn-orf ignore
By default, the device with EVPN ORF enabled filters all BGP EVPN routes advertised to BGP EVPN peers based on route targets.
Configuring EVPN ORF based on the prefix list
4.     Configure a prefix list used for BGP EVPN route filtering.
peer { group-name | ipv4-address [ mask-length ] } capability-advertise orf prefix-list { both | receive | send }
By default, the device does not filter the BGP EVPN routes advertised to peers based on the prefix list.
5.     (Optional.) Enable nonstandard ORF capabilities negotiation for a peer or peer group.
peer { group-name | ip-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf non-standard
By default, nonstandard ORF capabilities negotiation is disabled for a peer or peer group.
Confining floods to the local site
By default, the VTEP floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
·     All site-facing interfaces except for the incoming interface.
·     All VXLAN tunnel interfaces.
To confine a kind of flood traffic to the site-facing interfaces, disable flooding for that kind of flood traffic on the VSI bound to the VXLAN. The VSI will not flood the corresponding frames to VXLAN tunnel interfaces.
For more information about the VXLAN commands in this task, see VXLAN Command Reference.
You cannot enable selective flood for an all-F, all-zero, or multicast MAC address.
2.     Enter VSI view.
vsi vsi-name
3.     Disable flooding for the VSI.
flooding disable all
By default, flooding is enabled for a VSI.
4.     (Optional.) Enable selective flood for a MAC address.
selective-flooding mac-address mac-address
Enabling ARP or ND flood suppression
Use ARP or ND flood suppression to reduce ARP request broadcasts or ND request multicasts.
The aging timer is fixed at 25 minutes for ARP or ND flood suppression entries. If the flooding disable command is configured, set the MAC aging timer to a higher value than the aging timer for ARP or ND flood suppression entries on all VTEPs. This setting prevents the traffic blackhole that occurs when a MAC address entry ages out before its ARP or ND flood suppression entry ages out. To set the MAC aging timer, use the mac-address timer command.
When remote ARP or ND learning is disabled for VXLANs, the device does not use ARP or ND flood suppression entries to respond to ARP or ND requests received on VXLAN tunnels.
When ARP flood suppression is enabled, the subinterfaces of a Layer 3 interface AC do not support QinQ termination or ambiguous Dot1q termination. For more information about QinQ termination and Dot1q termination, see VLAN termination in Layer 2—LAN Switching Configuration Guide.
Enabling ARP flood suppression
2.     Enter VSI view.
vsi vsi-name
3.     Enable ARP flood suppression.
arp suppression enable
By default, ARP flood suppression is disabled.
Enabling ND flood suppression
2.     Enter VSI view.
vsi vsi-name
3.     Enable ND flood suppression.
ipv6 nd suppression enable
By default, ND flood suppression is disabled.
Interconnecting an EVPN VXLAN network with a VPLS network
About interconnecting an EVPN VXLAN network with a VPLS network
This task applies to the following scenarios:
·     A newly deployed EVPN VXLAN network in one data center needs to communicate with an existing VPLS network in another data center.
·     Two data centers with EVPN VXLAN networks deployed need to communicate over a WAN VPLS network.
As shown in Figure 20, for an EVPN VXLAN network and a VPLS network to communicate over a WAN VPLS network, configure the intermediate border devices GW 1 and GW 2 as follows:
·     Configure EVPN VXLAN and VPLS.
·     Interconnect the EVPN VXLAN network with the VPLS network by mapping the LDP PWs or static PWs on the VPLS network to the VXLAN tunnels.
On the intermediate border devices, the LDP PWs or static PWs of VPLS act as ACs of EVPN VXLAN. These PWs are called UPWs. The intermediate border devices can forward traffic between the VXLAN tunnels and the UPWs to enable communication between the EVPN VXLAN network and the VPLS network.
Figure 20 Interconnection between an EVPN VXLAN network and a VPLS network
As shown in Figure 20, the VTEP sets up VXLAN tunnels with GW 1 and GW 2, the gateways set up UPWs over the WAN VPLS network as follows:
·     GW 1 sets up a main UPW and a backup UPW with GW 3 and GW 4, respectively.
·     GW 2 sets up a main UPW and a backup UPW with GW 4 and GW 3, respectively.
When GW 1 or GW 2 receives a packet from a UPW, the gateway performs the following actions:
1.     Removes the MPLS encapsulation.
2.     Looks up the MAC address table for an outgoing VXLAN tunnel interface.
3.     Adds VXLAN encapsulation to the packet.
4.     Forwards the packet to the VTEP over the matching VXLAN tunnel.
When receiving a packet from a VXLAN tunnel, GW 1 or GW 2 uses a similar workflow to forward the packet over a UPW to the VPLS network.
Restrictions and guidelines for interconnecting an EVPN VXLAN network with a VPLS network
On the redundant gateways at a multihomed EVPN VXLAN network site, configure the same redundancy mode for the UPWs established with the same remote VPLS network site.
To use all-active redundancy mode at a multihomed EVPN VXLAN network site, you must execute the protection dual-receive command on the redundant gateways.
Prerequisites for interconnecting an EVPN VXLAN network with a VPLS network
Before you interconnect an EVPN VXLAN network with a VPLS network, perform the following tasks:
·     Configure VPLS and set up LDP PWs or static PWs on the PEs in the VPLS network.
·     Configure EVPN VXLAN and set up VXLAN tunnels on the VTEPs in the EVPN VXLAN network.
Mapping an LDP PW to VXLAN tunnels
2.     Enter VSI view.
vsi vsi-name
3.     Enter VSI EVPN instance view.
4.     Return to VSI view.
5.     Specify LDP signaling for PWs, and enter VSI LDP signaling view.
pwsignaling ldp
By default, no PW signaling protocol is specified for a VSI.
6.     Configure an LDP PW for VPLS, and enter VSI LDP PW view.
peer ip-address [ pw-id pw-id ] { dci | no-split-horizon } [ hub | ignore-standby-state | pw-class class-name | tunnel-policy tunnel-policy-name ] *
This LDP PW is used as a UPW for EVPN VXLAN.
If the WAN network connects to three or more data centers, specify the dci keyword to set up a DCI LDP PW to reduce floods between the data centers.
For more information about this command, see VPLS commands in MPLS Command Reference.
7.     (Optional.) Assign an ESI to the UPW.
esi esi-id
By default, no ESI is assigned to a PW.
Execute this command on the redundant border devices of an EVPN VXLAN network to which a VPLS network is multihomed.
8.     (Optional.) Set the redundancy mode for the UPW.
evpn redundancy-mode { all-active | single-active }
By default, all-active redundancy mode is used.
9.     Create a backup PW for VPLS, and enter VSI LDP backup PW view.
backup-peer ip-address [ pw-id pw-id ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
Execute this command on the redundant gateways at a multihomed EVPN VXLAN network site.
Mapping a static PW to VXLAN tunnels
2.     Enter VSI view.
vsi vsi-name
5.     Specify static signaling for PWs, and enter VSI static view.
pwsignaling static
6.     Configure a static PW for VPLS, and enter VSI static PW view.
peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value { dci | no-split-horizon } [ hub | pw-class class-name | tunnel-policy tunnel-policy-name ] *
This static PW is used as a UPW for EVPN VXLAN.
If the WAN network connects to three or more data centers, specify the dci keyword to set up a DCI static PW to reduce floods between the data centers.
esi esi-id
9.     Create a backup PW for VPLS, and enter VSI static backup PW view.
backup-peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
Interconnecting an EVPN VXLAN network with an EVPN VPLS network
Perform this task to enable an EVPN VXLAN network to communicate with an EVPN VPLS network.
As shown in Figure 21, for two EVPN VXLAN networks to communicate over an EVPN VPLS network, configure the intermediate border devices GW 1 through GW 4 as follows:
·     Configure EVPN VXLAN and EVPN VPLS.
·     Interconnect each EVPN VXLAN network with the EVPN VPLS network by configuring route reorigination between the EVPN VXLAN networks and EVPN VPLS network.
Figure 21 Interconnection between an EVPN VXLAN network and an EVPN VPLS network
As shown in Figure 21, the gateways reoriginate Ethernet auto-discovery, MAC/IP advertisement, ES, and IMET routes between the EVPN VXLAN networks and EVPN VPLS network. The following uses MAC/IP advertisement routes as an example to introduce how routes are reoriginated:
·     After receiving a MAC/IP advertisement route from the attached EVPN VXLAN network, a gateway reoriginates the route as follows:
a.     Adds an MPLS label, changes the encapsulation type to MPLS encapsulation, and modifies the RD and route targets for the route.
b.     Advertises the reoriginated route to the EVPN VPLS network.
·     After receiving a MAC/IP advertisement route from the EVPN VPLS network, a gateway reoriginates the route as follows:
a.     Adds a matching VXLAN ID, changes the encapsulation type to VXLAN encapsulation, and modifies the RD and route targets for the route.
b.     Advertises the reoriginated route to the attached EVPN VXLAN network.
After learning MAC address entries from MAC/IP advertisement routes, a gateway performs VXLAN or MPLS encapsulation for received packets and forwards them to the EVPN VXLAN networks or EVPN VPLS network based on these entries.
A gateway can be multihomed to the redundant gateways at the same remote site. You must configure the ESI and redundancy mode in VSI view on the redundant gateways.
On the redundant gateways at a multihomed EVPN VXLAN network site, configure the same redundancy mode for the same VSI.
After you perform this task and bind two EVPN instances using different encapsulation types to a VSI, the device automatically reoriginates Ethernet auto-discovery, ES, and IMET routes for the VSI.
Before you interconnect an EVPN VXLAN network with an EVPN VPLS network, perform the following tasks:
·     Configure EVPN VPLS and set up EVPN PWs on the PEs in the EVPN VPLS network.
2.     Enter VSI view.
vsi vsi-name
3.     Bind the VSI to an EVPN instance and specifies the VXLAN encapsulation type.
evpn encapsulation vxlan binding instance instance-name vsi-tag { tag-id | auto-vxlan }
4.     Bind the VSI to another EVPN instance and specifies the MPLS encapsulation type.
evpn encapsulation mpls binding instance instance-name vsi-tag tag-id
5.     (Optional.) Assign an ESI to the VSI and enter IESI view.
esi esi-id
By default, no ESI is assigned to a VSI.
Execute this command on the redundant border devices of an EVPN VXLAN network to which an EVPN VPLS network is multihomed.
6.     Return to VSI view.
7.     (Optional.) Set the redundancy mode for the VSI.
8.     Return to system view.
9.     Enter BGP instance view.
10.     Enable reorigination of MAC/IP advertisement routes.
evpn mac re-originated enable
By default, reorigination of MAC/IP advertisement routes is disabled.
11.     Enter BGP EVPN address family view.
address-family l2vpn evpn
12.     Enable the device to reoriginate MAC/IP advertisement routes based on those received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated mac [ replace-rt ]
By default, the device does not reoriginate MAC/IP advertisement routes based on those received from peers or peer groups.
13.     (Optional.) Suppress advertisement of original BGP EVPN routes to a peer or peer group and withdraw advertised original BGP EVPN routes.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress original-route { auto-discovery | es | imet }
By default, the device advertises original BGP EVPN routes to peers and peer groups.
Interconnecting an EVPN VXLAN network with an EVPN VPLS over SRv6
Perform this task to enable an EVPN VXLAN network to communicate with an EVPN VPLS over SRv6 network.
As shown in Figure 22, for two EVPN VXLAN networks to communicate over an EVPN VPLS over SRv6 network, configure the intermediate border devices GW 1 through GW 4 as follows:
·     Configure EVPN VXLAN and EVPN VPLS over SRv6.
·     Interconnect each EVPN VXLAN network with the EVPN VPLS over SRv6 network by configuring route reorigination between the EVPN VXLAN networks and EVPN VPLS over SRv6 network.
Figure 22 Interconnection between an EVPN VXLAN network and an EVPN VPLS over SRv6 network
As shown in Figure 22, the gateways reoriginate MAC/IP advertisement routes between the EVPN VXLAN networks and EVPN VPLS over SRv6 network as follows:
a.     Adds an SRv6 SID, changes the encapsulation type to SRv6 encapsulation, and modifies the RD and route targets for the route.
b.     Advertises the reoriginated route to the EVPN VPLS over SRv6 network.
·     After receiving a MAC/IP advertisement route from the EVPN VPLS over SRv6 network, a gateway reoriginates the route as follows:
c.     Adds a matching VXLAN ID, changes the encapsulation type to VXLAN encapsulation, and modifies the RD and route targets for the route.
d.     Advertises the reoriginated route to the attached EVPN VXLAN network.
After learning MAC address entries from MAC/IP advertisement routes, a gateway performs VXLAN or SRv6 encapsulation for received packets and forwards them to the EVPN VXLAN networks or EVPN VPLS over SRv6 network based on these entries.
A gateway can be multihomed to the redundant gateways at the same remote site. You must configure the ESI and redundancy mode in VSI view on the redundant gateways. ESs used to interconnect different types of networks are referred to as interconnect Ethernet segment (IES).
On the redundant gateways at a multihomed site, configure the same redundancy mode for the same VSI.
After you perform this task and bind two EVPN instances using different encapsulation types to a VSI, you cannot map ACs to the VSI.
Before you interconnect an EVPN VXLAN network with an EVPN VPLS over SRv6 network, perform the following tasks:
·     Configure EVPN VPLS over SRv6 and set up SRv6 PWs on the PEs in the EVPN VPLS over SRv6 network.
Configuring interconnection
2.     Enter VSI view.
vsi vsi-name
4.     Bind the VSI to another EVPN instance and specifies the SRv6 encapsulation type.
evpn encapsulation srv6 binding instance instance-name vsi-tag tag-id
5.     Return to system view.
6.     Enter BGP instance view.
7.     Enable reorigination of MAC/IP advertisement routes.
8.     Enter BGP EVPN address family view.
9.     Enable the device to reoriginate MAC/IP advertisement routes based on those received from a peer or peer group.
Configuring multihoming
2.     Enter VSI view.
vsi vsi-name
3.     (Optional.) Set the redundancy mode for the VSI.
Execute this command on the redundant border devices of an EVPN VXLAN network to which an EVPN VPLS over SRv6 network is multihomed.
4.     Assign an ESI to the VSI and enter IESI view.
esi esi-id
5.     Configure the DF election algorithm.
evpn df-election algorithm algorithm
By default, the global DF election algorithm applies.
6.     Set the DF election preference.
evpn df-election preference preference
By default, the DF election preference is 32767.
The larger the value, the higher the preference.
7.     Enable non-revertive mode for preference-based DF election.
evpn df-election preference non-revertive
By default, non-revertive mode is disabled for preference-based DF election.
8.     Set the advertisement delay timer for Ethernet auto-discovery routes.
evpn timer ad-delay delay-time
By default, advertisement of Ethernet auto-discovery routes is not delayed.
9.     Set the advertisement delay timer for Ethernet segment routes.
evpn timer es-delay delay-time
By default, advertisement of Ethernet segment routes is not delayed.
10.     Configure ES route advertisement delay when preference-based DF election is used.
evpn timer es-recovery recovery-time
By default, ES route advertisement delay is disabled when preference-based DF election is used.
11.     Enable the device to monitor the BGP peer status of another local edge device.
evpn track peer peer-address
By default, the device does not monitor the BGP peer status of the other edge devices at a multihomed site.
12.     Return to VSI view.
Enabling packet statistics for VXLAN tunnels
Perform this task to enable packet statistics globally for automatically created VXLAN tunnels or VXLAN tunnels associated with L3 VXLAN IDs.
If you enable packet statistics for automatically created VXLAN tunnels, follow these guidelines:
·     To display the packet statistics for VXLAN tunnels, use the display interface tunnel command in any view.
·     To clear the packet statistics for VXLAN tunnels, use the reset counters interface tunnel command in user view.
If you enable packet statistics for VXLAN tunnels associated with L3 VXLAN IDs, follow these guidelines:
·     To display the packet statistics for VXLAN tunnels, use the display vxlan tunnel command in any view.
·     To clear the packet statistics for VXLAN tunnels, use the reset l2vpn statistics tunnel command in user view.
2.     Enable packet statistics for VXLAN tunnels.
tunnel statistics vxlan { auto | l3-vni }
By default, the packet statistics feature is disabled for VXLAN tunnels.
Enabling SNMP notifications for EVPN
If SNMP notifications are enabled for EVPN, a MAC mobility suppression notification is sent to SNMP module after the MAC mobility suppression threshold is reached. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for EVPN.
snmp-agent trap enable evpn [ mac-mobility-suppression ]
By default, SNMP notifications are disabled for EVPN.
Display and maintenance commands for EVPN VXLAN
Display BGP peer group information.
display bgp [ instance instance-name ] group l2vpn evpn [ group-name group-name ]
Display BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ { evpn-route route-length | evpn-prefix } [ verbose ] | statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | igmp-js | igmp-ls | imet | ip-prefix | mac-ip | smet } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes } ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ route-type { inter-as | intra-as | leaf | s-pmsi | shared-tree | source-active | source-tree } ] time-range min-time max-time
Display BGP peer or peer group information.
display bgp [ instance instance-name ] peer l2vpn evpn [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
Display information about BGP update groups.
display bgp [ instance instance-name ] update-group l2vpn evpn [ ipv4-address | ipv6-address ]
Display dampened BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn dampened
Display BGP EVPN route dampening parameters.
display bgp [ instance instance-name ] dampening parameter l2vpn evpn
Display flapping statistics about BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn flap-info
Display the route targets sourced from the EVPN process and ES-import route targets for BGP.
display bgp [ instance instance-name ] route-target evpn
Display the route targets sourced from VPN instances for BGP.
display bgp [ instance instance-name ] route-target l3vpn [ ipv4 | ipv6 | evpn ] [ vpn-instance vpn-instance-name ]
Display information about IPv4 peers that are automatically discovered through BGP.
display evpn auto-discovery { { imet | mac-ip } [ mpls | vxlan ] [ peer ip-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
Display EVPN ES information.
display evpn es { local [ count | [ vsi vsi-name ] [ esi esi-id ] [ verbose ] ] | remote [ vsi vsi-name ] [ esi esi-id ] [ nexthop next-hop ] [ verbose ] }
Display information about IPv6 peers that are automatically discovered through BGP.
display evpn ipv6 auto-discovery { { imet | mac-ip } [ vxlan ] [ peer ipv6-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
Display EVPN ARP entries.
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ip ip-address ] [ count | verbose ]
Display ARP flood suppression entries.
display evpn route arp suppression [ vxlan ] [ ip ip-address ] [ local | remote ] [ vsi vsi-name ] [ count | verbose ]
Display EVPN ARP mobility information.
display evpn route arp-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ip ip-address ] [ verbose ]
Display EVPN MAC address entries.
display evpn route mac [ mac-address mac-address | umr [ verbose ] ] [ mpls | vxlan ] [ local | remote ] [ vsi vsi-name ] [ count ]
Display EVPN MAC mobility information.
display evpn route mac-mobility [ evpn-instance instance-name | interface interface-type interface-number | vsi vsi-name ] [ mac-address mac-address ] [ verbose ]
Display EVPN ND entries.
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ count | verbose ]
Display ND flood suppression entries.
display evpn route nd suppression [ local | remote ] [ ipv6 ipv6-address ] [ vsi vsi-name ] [ count | verbose ]
Display EVPN ND mobility information.
display evpn route nd-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ]
Display the routing table for a VPN instance.
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
Display EVPN instance information.
display evpn instance [ name instance-name | vsi vsi-name ]
Display site-facing interfaces excluded from traffic forwarding by split horizon.
In standalone mode:
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | ac interface interface-type interface-number service-instance instance-id | tunnel tunnel-number } slot slot-number [ cpu cpu-number ]
In IRF mode:
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | ac interface interface-type interface-number service-instance instance-id | tunnel tunnel-number } chassis chassis-number slot slot-number [ cpu cpu-number ]
Display the status of the BGP peers attached to the same ES as the local device.
display evpn track peer [ esi esi-id ]
Reset BGP EVPN route dampening information and disable BGP EVPN route dampening.
reset bgp [ instance instance-name ] dampening l2vpn evpn
Reset flapping statistics about BGP EVPN routes.
reset bgp [ instance instance-name ] flap-info l2vpn evpn [ as-path-acl { as-path-acl-number | as-path-acl-name } | peer [ ipv4-address [ mask-length ] | peer ipv6-address [ prefix-length ] ] ]
Advertise ARP information for suppressed IP addresses for one time.
reset evpn route arp-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ip ip-address ] ]
Advertise suppressed MAC addresses for one time.
reset evpn route mac-mobility suppression [ evpn-instance instance-name | interface interface-type interface-number  | vsi vsi-name ] [ mac mac-address ]
Advertise ARP information for suppressed IPv6 addresses for one time.
reset evpn route nd-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ipv6 ipv6-address ] ]
For more information about the display bgp group, display bgp peer, and display bgp update-group commands, see BGP commands in Layer 3—IP Routing Command Reference.
For more information about the display bgp route-target l3vpn command, see MPLS L3VPN commands in MPLS Command Reference.
EVPN VXLAN configuration examples
Example: Configuring a centralized IPv4 EVPN gateway
As shown in Figure 23:
·     Configure VXLAN 10 and VXLAN 20 on Router A, Router B, and Router C to provide connectivity for the VMs in the VXLANs across the network sites.
·     Configure Router C as a centralized EVPN gateway to provide gateway services and access to the connected Layer 3 network.
·     Configure Router D as an RR to reflect BGP EVPN routes between Router A, Router B, and Router C.
Figure 23 Network diagram
1.     On VM 1 and VM 3, specify 10.1.1.1 as the gateway address. On VM 2 and VM 4, specify 10.1.2.1 as the gateway address. (Details not shown.)
2.     Configure IP addresses and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 23. (Details not shown.)
# Configure OSPF on all transport network routers (Routers A through D) for them to reach one another. (Details not shown.)
3.     Configure Router A:
# Enable L2VPN.
[RouterA] l2vpn enable
# Disable remote MAC address learning and remote ARP learning.
[RouterA] vxlan tunnel mac-learning disable
[RouterA] vxlan tunnel arp-learning disable
# Create an EVPN instance on VSI vpna, and configure the router to automatically generate an RD and a route target for the EVPN instance.
[RouterA] vsi vpna
[RouterA-vsi-vpna] arp suppression enable
[RouterA-vsi-vpna] evpn encapsulation vxlan
[RouterA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[RouterA-vsi-vpna-evpn-vxlan] vpn-target auto
[RouterA-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[RouterA-vsi-vpna] vxlan 10
[RouterA-vsi-vpna-vxlan-10] quit
[RouterA-vsi-vpna] quit
# Create an EVPN instance on VSI vpnb, and configure the router to automatically generate an RD and a route target for the EVPN instance.
[RouterA] vsi vpnb
[RouterA-vsi-vpnb] arp suppression enable
[RouterA-vsi-vpnb] evpn encapsulation vxlan
[RouterA-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[RouterA-vsi-vpnb-evpn-vxlan] vpn-target auto
[RouterA-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[RouterA-vsi-vpnb] vxlan 20
[RouterA-vsi-vpnb-vxlan-20] quit
[RouterA-vsi-vpnb] quit
# Configure BGP to advertise BGP EVPN routes.
[RouterA] bgp 200
[RouterA-bgp-default] peer 4.4.4.4 as-number 200
[RouterA-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[RouterA-bgp-default] address-family l2vpn evpn
[RouterA-bgp-default-evpn] peer 4.4.4.4 enable
[RouterA-bgp-default-evpn] quit
[RouterA-bgp-default] quit
# Map Ten-GigabitEthernet 3/1/1 to VSI vpna.
[RouterA] interface ten-gigabitethernet 3/1/1
[RouterA-Ten-GigabitEthernet3/1/1] xconnect vsi vpna
[RouterA-Ten-GigabitEthernet3/1/1] quit
# Map Ten-GigabitEthernet 3/1/2 to VSI vpnb.
[RouterA] interface ten-gigabitethernet 3/1/2
[RouterA-Ten-GigabitEthernet3/1/2] xconnect vsi vpnb
[RouterA-Ten-GigabitEthernet3/1/2] quit
4.     Configure Router B:
# Enable L2VPN.
<RouterB> system-view
[RouterB] l2vpn enable
[RouterB] vxlan tunnel mac-learning disable
[RouterB] vxlan tunnel arp-learning disable
[RouterB] vsi vpna
[RouterB-vsi-vpna] arp suppression enable
[RouterB-vsi-vpna] evpn encapsulation vxlan
[RouterB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[RouterB-vsi-vpna-evpn-vxlan] vpn-target auto
[RouterB-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[RouterB-vsi-vpna] vxlan 10
[RouterB-vsi-vpna-vxlan-10] quit
[RouterB-vsi-vpna] quit
[RouterB] vsi vpnb
[RouterB-vsi-vpnb] arp suppression enable
[RouterB-vsi-vpnb] evpn encapsulation vxlan
[RouterB-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[RouterB-vsi-vpnb-evpn-vxlan] vpn-target auto
[RouterB-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[RouterB-vsi-vpnb] vxlan 20
[RouterB-vsi-vpnb-vxlan-20] quit
[RouterB-vsi-vpnb] quit
[RouterB] bgp 200
[RouterB-bgp-default] peer 4.4.4.4 as-number 200
[RouterB-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[RouterB-bgp-default] address-family l2vpn evpn
[RouterB-bgp-default-evpn] peer 4.4.4.4 enable
[RouterB-bgp-default-evpn] quit
[RouterB-bgp-default] quit
[RouterB] interface ten-gigabitethernet 3/1/1
[RouterB-Ten-GigabitEthernet3/1/1] xconnect vsi vpna
[RouterB-Ten-GigabitEthernet3/1/1] quit
[RouterB] interface ten-gigabitethernet 3/1/2
[RouterB-Ten-GigabitEthernet3/1/2] xconnect vsi vpnb
[RouterB-Ten-GigabitEthernet3/1/2] quit
5.     Configure Router C:
# Enable L2VPN.
<RouterC> system-view
[RouterC] l2vpn enable
[RouterC] vxlan tunnel mac-learning disable
[RouterC] vxlan tunnel arp-learning disable
[RouterC] vsi vpna
[RouterC-vsi-vpna] arp suppression enable
[RouterC-vsi-vpna] evpn encapsulation vxlan
[RouterC-vsi-vpna-evpn-vxlan] route-distinguisher auto
[RouterC-vsi-vpna-evpn-vxlan] vpn-target auto
[RouterC-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[RouterC-vsi-vpna] vxlan 10
[RouterC-vsi-vpna-vxlan-10] quit
[RouterC-vsi-vpna] quit
[RouterC] vsi vpnb
[RouterC-vsi-vpnb] evpn encapsulation vxlan
[RouterC-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[RouterC-vsi-vpnb-evpn-vxlan] vpn-target auto
[RouterC-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[RouterC-vsi-vpnb] vxlan 20
[RouterC-vsi-vpnb-vxlan-20] quit
[RouterC-vsi-vpnb] quit
[RouterC] bgp 200
[RouterC-bgp-default] peer 4.4.4.4 as-number 200
[RouterC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[RouterC-bgp-default] address-family l2vpn evpn
[RouterC-bgp-default-evpn] peer 4.4.4.4 enable
[RouterC-bgp-default-evpn] quit
[RouterC-bgp-default] quit
# Create VSI-interface 1 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 10.
[RouterC] interface vsi-interface 1
[RouterC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[RouterC-Vsi-interface1] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[RouterC] vsi vpna
[RouterC-vsi-vpna] gateway vsi-interface 1
# Create VSI-interface 2 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 20.
[RouterC] interface vsi-interface 2
[RouterC-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[RouterC-Vsi-interface2] quit
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[RouterC] vsi vpnb
[RouterC-vsi-vpnb] gateway vsi-interface 2
6.     Configure Router D:
# Establish BGP connections with other transport network routers.
<RouterD> system-view
[RouterD] bgp 200
[RouterD-bgp-default] group evpn
[RouterD-bgp-default] peer 1.1.1.1 group evpn
[RouterD-bgp-default] peer 2.2.2.2 group evpn
[RouterD-bgp-default] peer 3.3.3.3 group evpn
[RouterD-bgp-default] peer evpn as-number 200
[RouterD-bgp-default] peer evpn connect-interface loopback 0
# Configure BGP to advertise BGP EVPN routes, and disable route target filtering for BGP EVPN routes.
[RouterD-bgp-default] address-family l2vpn evpn
[RouterD-bgp-default-evpn] peer evpn enable
[RouterD-bgp-default-evpn] undo policy vpn-target
# Configure Router D as an RR.
[RouterD-bgp-default-evpn] peer evpn reflect-client
[RouterD-bgp-default-evpn] quit
[RouterD-bgp-default] quit
1.     Verify the EVPN gateway settings on Router C:
# Verify that Router C has advertised MAC/IP advertisement routes and IMET routes for the gateways and received MAC/IP advertisement routes and IMET routes from Router A and Router B. (Details not shown.)
# Verify that the VXLAN tunnel interfaces are up on Router C.
[RouterC] display interface tunnel
Tunnel0
Interface index: 261
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 2.2.2.2
Tunnel1
Interface index: 262
Current state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 1.1.1.1
Input: 277 packets, 20306 bytes, 0 drops
Output: 1099 packets, 0 bytes, 0 drops
# Verify that the VSI interfaces are up on Router C.
[RouterC] display interface vsi-interface
Vsi-interface1
Interface index: 263
Current state: UP
Description: Vsi-interface1 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0003-0003-0003
IPv6 packet frame type: Ethernet II, hardware address: 0003-0003-0003
Vsi-interface2
Interface index: 264
Current state: UP
Description: Vsi-interface2 Interface
# Verify that the VXLAN tunnels have been assigned to the VXLANs, and the VSI interfaces are the gateway interfaces of their respective VXLANs.
[RouterC] display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : Unlimited
  Broadcast Restrain      : 5120 kbps
  Multicast Restrain      : 5120 kbps
  Unknown Unicast Restrain: 5120 kbps
  MAC Table Limit         : Unlimited
  MAC Learning rate       : -
  Local MAC aging time    : 300 sec
  Remote MAC aging time   : 300 sec
  Drop Unknown            : Disabled
  PW Redundancy Mode      : Slave
  DSCP                    : -
  Service Class           : -
  Flooding                : Enabled
  ESI                     : 0000.0000.0000.0000.0000
  Redundancy Mode         : All-active
  Straight-fwd PW-to-AC   : Disabled
  Statistics              : Disabled
  Gateway Interface       : VSI-interface 1
  EVPN MPLS BCR           : -
  EVPN MPLS UCR           : -
  EVPN MPLS MCR           : -
  EVPN SRv6 BCR           : -
  EVPN SRv6 UCR           : -
  EVPN SRv6 MCR           : -
  VXLAN ID                : 10
  Tunnel Statistics       : Disabled
  Tunnels:
    Tunnel Name          Link ID    State    Type        Flood Proxy
    Tunnel0              0x5000000  UP       Auto        Disabled
    Tunnel1              0x5000001  UP       Auto        Disabled
VSI Name: vpnb
  VSI Index               : 1
  VSI State               : Up
  Diffserv Mode           : -
  DSCP                    : -
  Service Class           : -
  Flooding                : Enabled
  Gateway Interface       : VSI-interface 2
  EVPN MPLS BCR           : -
  EVPN MPLS UCR           : -
  EVPN MPLS MCR           : -
  EVPN SRv6 BCR           : -
  EVPN SRv6 UCR           : -
  EVPN SRv6 MCR           : -
  VXLAN ID                : 20
  Tunnels:
# Verify that Router C has created EVPN ARP entries for the VMs.
[RouterC] display evpn route arp
Flags: D - Dynamic   B - BGP      L - Local active
       G - Gateway   S - Static   M - Mapping        I - Invalid
Public instance                               Interface: Vsi-interface1
IP address      MAC address     Router MAC      VSI index   Flags
10.1.1.1        0003-0003-0003  -               0           GL
10.1.1.10       0000-1234-0001  -               0           B
10.1.1.20       0000-1234-0003  -               0           B
Public instance                               Interface: Vsi-interface2
10.1.2.1        0005-0005-0005  -               1           GL
10.1.2.10       0000-1234-0002  -               1           B
10.1.2.20       0000-1234-0004  -               1           B
# Verify that Router C has created FIB entries for the VMs.
[RouterC] display fib 10.1.1.10
Flag:
  U:Usable    G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
10.1.1.10/32       10.1.1.10       UH       Vsi1                     Null
2.     Verify that VM 1, VM 2, VM 3, and VM 4 can communicate with one another. (Details not shown.)
Example: Configuring distributed IPv4 EVPN gateways in symmetric IRB mode
As shown in Figure 24:
·     Configure VXLAN 10 and VXLAN 20 on Router A and Router B to provide connectivity for the VMs in the VXLANs across the network sites.
·     Configure Router A and Router B as distributed EVPN gateways to provide gateway services in symmetric IRB mode. Configure Router C as a border gateway to provide access to the connected Layer 3 network.
Figure 24 Network diagram
# Assign IP addresses to interfaces, as shown in Figure 24. (Details not shown.)
# Enable L2VPN.
[RouterA] vsi vpna
# Create VXLAN 10.
[RouterA] vsi vpnb
# Create VXLAN 20.
[RouterA] bgp 200
# Configure RD and route target settings for VPN instance l3vpna.
[RouterA] ip vpn-instance l3vpna
[RouterA-vpn-instance-l3vpna] route-distinguisher 1:1
[RouterA-vpn-instance-l3vpna] address-family ipv4
[RouterA-vpn-ipv4-l3vpna] vpn-target 2:2
[RouterA-vpn-ipv4-l3vpna] quit
[RouterA-vpn-instance-l3vpna] address-family evpn
[RouterA-vpn-evpn-l3vpna] vpn-target 1:1
[RouterA-vpn-evpn-l3vpna] quit
[RouterA-vpn-instance-l3vpna] quit
# Configure VSI-interface 1.
[RouterA] interface vsi-interface 1
[RouterA-Vsi-interface1] ip binding vpn-instance l3vpna
[RouterA-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[RouterA-Vsi-interface1] mac-address 1-1-1
[RouterA-Vsi-interface1] distributed-gateway local
[RouterA-Vsi-interface1] local-proxy-arp enable
[RouterA-Vsi-interface1] quit
# Configure VSI-interface 2.
[RouterA] interface vsi-interface 2
[RouterA-Vsi-interface2] ip binding vpn-instance l3vpna
[RouterA-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[RouterA-Vsi-interface2] mac-address 2-2-2
[RouterA-Vsi-interface2] distributed-gateway local
[RouterA-Vsi-interface2] local-proxy-arp enable
[RouterA-Vsi-interface2] quit
# Associate VSI-interface 3 with VPN instance l3vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[RouterA] interface vsi-interface 3
[RouterA-Vsi-interface3] ip binding vpn-instance l3vpna
[RouterA-Vsi-interface3] l3-vni 1000
[RouterA-Vsi-interface3] quit
[RouterA] vsi vpna
[RouterA-vsi-vpna] gateway vsi-interface 1
[RouterA] vsi vpnb
[RouterA-vsi-vpnb] gateway vsi-interface 2
# Enable L2VPN.
[RouterB] vsi vpna
# Create VXLAN 10.
[RouterB] vsi vpnb
# Create VXLAN 20.
[RouterB] bgp 200
[RouterB] ip vpn-instance l3vpna
[RouterB-vpn-instance-l3vpna] route-distinguisher 1:1
[RouterB-vpn-instance-l3vpna] address-family ipv4
[RouterB-vpn-ipv4-l3vpna] vpn-target 2:2
[RouterB-vpn-ipv4-l3vpna] quit
[RouterB-vpn-instance-l3vpna] address-family evpn
[RouterB-vpn-evpn-l3vpna] vpn-target 1:1
[RouterB-vpn-evpn-l3vpna] quit
[RouterB-vpn-instance-l3vpna] quit
[RouterB] interface vsi-interface 1
[RouterB-Vsi-interface1] ip binding vpn-instance l3vpna
[RouterB-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[RouterB-Vsi-interface1] mac-address 1-1-1
[RouterB-Vsi-interface1] distributed-gateway local
[RouterB-Vsi-interface1] local-proxy-arp enable
[RouterB-Vsi-interface1] quit
[RouterB] interface vsi-interface 2
[RouterB-Vsi-interface2] ip binding vpn-instance l3vpna
[RouterB-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[RouterB-Vsi-interface2] mac-address 2-2-2
[RouterB-Vsi-interface2] distributed-gateway local
[RouterB-Vsi-interface2] local-proxy-arp enable
[RouterB-Vsi-interface2] quit
[RouterB] interface vsi-interface 3
[RouterB-Vsi-interface3] ip binding vpn-instance l3vpna
[RouterB-Vsi-interface3] l3-vni 1000
[RouterB-Vsi-interface3] quit
[RouterB] vsi vpna
[RouterB-vsi-vpna] gateway vsi-interface 1
[RouterB] vsi vpnb
[RouterB-vsi-vpnb] gateway vsi-interface 2
# Enable L2VPN.
[RouterC] bgp 200
[RouterC] ip vpn-instance l3vpna
[RouterC-vpn-instance-l3vpna] route-distinguisher 1:1
[RouterC-vpn-instance-l3vpna] address-family ipv4
[RouterC-vpn-ipv4-l3vpna] vpn-target 2:2
[RouterC-vpn-ipv4-l3vpna] quit
[RouterC-vpn-instance-l3vpna] address-family evpn
[RouterC-vpn-evpn-l3vpna] vpn-target 1:1
[RouterC-vpn-evpn-l3vpna] quit
[RouterC-vpn-instance-l3vpna] quit
[RouterC] interface vsi-interface 3
[RouterC-Vsi-interface3] ip binding vpn-instance l3vpna
[RouterC-Vsi-interface3] l3-vni 1000
[RouterC-Vsi-interface3] quit
# Configure a default route. The next hop is the IP address of a device in the Layer 3 network.
[RouterC] ip route-static vpn-instance l3vpna 0.0.0.0 0 20.1.1.100
# Import the default route to the BGP IPv4 unicast routing table of VPN instance l3vpna.
[RouterC] bgp 200
[RouterC-bgp-default] ip vpn-instance l3vpna
[RouterC-bgp-default-l3vpna] address-family ipv4 unicast
[RouterC-bgp-default-ipv4-l3vpna] default-route imported
[RouterC-bgp-default-ipv4-l3vpna] import-route static
[RouterC-bgp-default-ipv4-l3vpna] quit
[RouterC-bgp-default-l3vpna] quit
# Associate Ten-GigabitEthernet 3/1/2 with VPN instance l3vpna. Ten-GigabitEthernet 3/1/2 provides access to the Layer 3 network connected to Router C.
[RouterC] interface ten-gigabitethernet 3/1/2
[RouterC-Ten-GigabitEthernet3/1/2] ip binding vpn-instance l3vpna
[RouterC-Ten-GigabitEthernet3/1/2] ip address 20.1.1.3 24
[RouterC-Ten-GigabitEthernet3/1/2] quit
[RouterD] bgp 200
1.     Verify the distributed EVPN gateway settings on Router A:
# Verify that Router A has advertised the IP prefix advertisement routes for the gateways and the MAC/IP advertisement routes and IMET routes for each VSI. Verify that Router A has received the IP prefix advertisement routes for the gateways and the MAC/IP advertisement routes and IMET routes for each VSI from Router B. (Details not shown.)
# Verify that the VXLAN tunnel interfaces are up on Router A. (This example uses Tunnel 0.)
[RouterA] display interface tunnel 0
Tunnel0
Current state: UP
Bandwidth: 64 kbps
# Verify that the VSI interfaces are up on Router A. (This example uses VSI-interface 1.)
[RouterA] display interface vsi-interface 1
Vsi-interface1
Current state: UP
[RouterA] display l2vpn vsi verbose
VSI Name: Auto_L3VNI1000_3
  VSI Index               : 1
  VSI State               : Down
  MTU                     : 1500
  Diffserv Mode           : -
  DSCP                    : -
  Service Class           : -
  Gateway Interface       : VSI-interface 3
  EVPN MPLS BCR           : -
  EVPN MPLS UCR           : -
  EVPN MPLS MCR           : -
  EVPN SRv6 BCR           : -
  EVPN SRv6 UCR           : -
  EVPN SRv6 MCR           : -
  VXLAN ID                : 1000
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Diffserv Mode           : -
  DSCP                    : -
  Service Class           : -
  EVPN MPLS BCR           : -
  EVPN MPLS UCR           : -
  EVPN MPLS MCR           : -
  EVPN SRv6 BCR           : -
  EVPN SRv6 UCR           : -
  EVPN SRv6 MCR           : -
  VXLAN ID                : 10
  ACs:
    AC                               Link ID    State
    XGE3/1/1                         0x0        Up
VSI Name: vpnb
  VSI Index               : 2
  VSI State               : Up
  Diffserv Mode           : -
  DSCP                    : -
  Service Class           : -
  EVPN MPLS BCR           : -
  EVPN MPLS UCR           : -
  EVPN MPLS MCR           : -
  EVPN SRv6 BCR           : -
  EVPN SRv6 UCR           : -
  EVPN SRv6 MCR           : -
  VXLAN ID                : 20
  ACs:
    AC                                 Link ID    State
    XGE3/1/2                           0x1        Up
# Verify that Router A has created ARP entries for the VMs.
[RouterA] display arp
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP address      MAC address    VLAN/VSI name Interface                Aging Type
10.1.1.10       0000-1234-0001 0             0x0                      20    D
10.1.2.10       0000-1234-0002 0             0x0                      19    D
2.2.2.2         a0ce-5e24-0100 1             Tunnel0                  --    R
# Verify that Router A has created EVPN ARP entries for the local VMs.
[RouterA] display evpn route arp
VPN instance: l3vpna                          Interface:Vsi-interface1
IP address      MAC address     Router MAC      VSI Index   Flags
10.1.1.1        0001-0001-0001  a0ce-7e40-0400  0           GL
10.1.1.10       0000-1234-0001  a0ce-7e40-0400  0           DL
10.1.2.10       0000-1234-0002  a0ce-7e40-0400  0           DL
10.1.1.20       0000-1234-0003  a0ce-7e40-0400  0           B
10.1.2.20       0000-1234-0004  a0ce-7e40-0400  0           B
Example: Configuring IPv4 EVPN VXLAN multihoming
As shown in Figure 25:
·     Configure VXLANs as follows:
¡     Configure VXLAN 10 on Router A, Router B, and Router C. Configure Router A and Router B as redundant VTEPs for Server 2, and configure Router B and Router C as redundant VTEPs for Server 3.
¡     Configure VXLAN 20 on Router C.
·     Configure Router A, Router B, and Router C as distributed EVPN gateways.
Figure 25 Network diagram
1.     On VM 1, VM 2, and VM 3, specify 10.1.1.1 as the gateway address. On VM 4, specify 20.1.1.1 as the gateway address. (Details not shown.)
# Assign IP addresses to the interfaces, as shown in Figure 25. (Details not shown.)
# Enable L2VPN.
[RouterA] vsi vpna
[RouterA-vsi-vpna-evpn-vxlan] route-distinguisher auto router-id
# Create VXLAN 10.
[RouterA] bgp 200
# Assign an ESI to Ten-GigabitEthernet 3/1/2.
[RouterA-Ten-GigabitEthernet3/1/2] esi 0.0.0.0.1
# Map Ten-GigabitEthernet 3/1/2 to VSI vpna.
[RouterA-Ten-GigabitEthernet3/1/2] xconnect vsi vpna
[RouterA] vsi vpna
# Enable L2VPN.
[RouterB] vsi vpna
[RouterB-vsi-vpna-evpn-vxlan] route-distinguisher auto router-id
# Create VXLAN 10.
[RouterB] bgp 200
# Assign an ESI to Ten-GigabitEthernet 3/1/1.
[RouterB-Ten-GigabitEthernet3/1/1] esi 0.0.0.0.1
[RouterB-Ten-GigabitEthernet3/1/2] esi 0.0.0.0.2
[RouterB-Ten-GigabitEthernet3/1/2] xconnect vsi vpna
[RouterB-vpn-instance-l3vpna] route-distinguisher 2:2
[RouterB] vsi vpna
# Enable L2VPN.
[RouterC] vsi vpna
[RouterC-vsi-vpna-evpn-vxlan] route-distinguisher auto router-id
# Create VXLAN 10.
[RouterC] vsi vpnb
[RouterC-vsi-vpnb-evpn-vxlan] route-distinguisher auto router-id
# Create VXLAN 20.
[RouterC] bgp 200
[RouterC] interface ten-gigabitethernet 3/1/1
[RouterC-Ten-GigabitEthernet3/1/1] esi 0.0.0.0.2
[RouterC-Ten-GigabitEthernet3/1/1] xconnect vsi vpna
[RouterC-Ten-GigabitEthernet3/1/1] quit
[RouterC-Ten-GigabitEthernet3/1/2] xconnect vsi vpnb
[RouterC-vpn-instance-l3vpna] route-distinguisher 3:3
[RouterC-Vsi-interface1] ip binding vpn-instance l3vpna
[RouterC-Vsi-interface1] mac-address 1-1-1
[RouterC-Vsi-interface1] distributed-gateway local
[RouterC-Vsi-interface1] local-proxy-arp enable
[RouterC-Vsi-interface2] ip binding vpn-instance l3vpna
[RouterC-Vsi-interface2] ip address 20.1.1.1 255.255.255.0
[RouterC-Vsi-interface2] mac-address 2-2-2
[RouterC-Vsi-interface2] distributed-gateway local
[RouterC-Vsi-interface2] local-proxy-arp enable
[RouterC] vsi vpna
[RouterC] vsi vpnb
[RouterD] bgp 200
1.     Verify the EVPN VXLAN multihoming configuration on Router C. (Details not shown.)
# Verify that Router C has advertised and received the following BGP EVPN routes:
¡     IP prefix advertisement routes for the gateways.
¡     IMET routes for VSIs.
¡     MAC/IP advertisement routes.
¡     Ethernet auto-discovery routes and Ethernet segment routes.
# Verify that Router C has ECMP routes to VM 2.
<RouterC> display evpn routing-table vpn-instance l3vpna
Flags: E - with valid ESI   A - AD ready   L - Local ES exists
VPN instance:l3vpna                          Local L3VNI:1000
IP address       Next hop         Outgoing interface    NibID       Flags
10.1.1.10        1.1.1.1          Vsi-interface3        0x18000001  -
10.1.1.20        2.2.2.2          Vsi-interface3        0x18000000  EA
                 1.1.1.1          Vsi-interface3        0x18000001  EA
# Verify that Router C has equal-cost L2VPN MAC address entries and EVPN MAC address entries for VM 2.
<RouterC> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name/Peer
                                   Aging
0001-0001-0010   EVPN     vpna                            Tunnel0
                                   NotAging
0001-0001-0020   EVPN     vpna                            Tunnel0
                                   NotAging
                                                          Tunnel1
                                   NotAging
0001-0001-0030   Dynamic  vpna                            0x0
                                   NotAging
0002-0001-0010   Dynamic  vpnb                            0x0
                                   NotAging
<RouterC> display evpn route mac
       E – Multihoming ES sync
VSI name: vpna
MAC address     Link ID/Name   Flags   Encap           Next hop
0001-0001-0030  0              DL      VXLAN           -
0001-0001-0010  Tunnel0        B       VXLAN           1.1.1.1
0001-0001-0020  Tunnel0        B       VXLAN           1.1.1.1
                Tunnel1        B       VXLAN           2.2.2.2
VSI name: vpnb
MAC address     Link ID/Name    Flags   Next hop
0002-0001-0010  0               DL      -
# Verify that Router C has information about local and remote ESs.
<RouterC> display evpn es local
Redundancy mode: A - All active, S - Single active
VSI name : vpna
ESI                         Tag ID      DF address      Mode  State ESI label
0000.0000.0000.0000.0002    0           2.2.2.2         A     Up    -
<RouterC> display evpn es remote
Control Flags: P - Primary, B - Backup, C - Control word
VSI name : vpna
  ESI                     : 0000.0000.0000.0000.0001
  A-D per ES routes       :
    Peer IP             Remote Redundancy mode
    1.1.1.1             All-active
    2.2.2.2             All-active
  A-D per EVI routes      :
    Tag ID      Peer IP
    0           1.1.1.1
    0           2.2.2.2
  ESI                     : 0000.0000.0000.0000.0002
  Ethernet segment routes :
    2.2.2.2
  A-D per ES routes       :
    2.2.2.2             All-active
    Tag ID      Peer IP
    0           2.2.2.2
2.     Verify that the VMs can communicate with one another.
Example: Interconnecting an EVPN VXLAN network with a VPLS network
As shown in Figure 26, interconnect the EVPN VXLAN network with the VPLS network as follows:
·     Set up LDP PWs as UPWs by using LDP signaling between the gateways and the PE.
·     Set up VXLAN tunnels between the gateways and the VTEP.
·     Map the UPWs to the VXLAN tunnels on the gateways.
Figure 26 Network diagram
Device
IP address
Device
IP address
GW 1
Loop0
1.1.1.9/32
VTEP
Loop0
3.3.3.9/32
XGE3/1/1
10.1.1.1/24
XGE3/1/1
XGE3/1/2
30.1.1.1/24
XGE3/1/2
30.1.1.3/24
XGE3/1/3
10.1.3.1/24
XGE3/1/3
10.1.2.3/24
GW 2
Loop0
2.2.2.9/32
PE
Loop0
4.4.4.9/32
XGE3/1/1
20.1.1.2/24
XGE3/1/3
XGE3/1/2
10.1.2.2/24
XGE3/1/1
10.1.1.4/24
XGE3/1/3
10.1.3.2/24
XGE3/1/2
20.1.1.4/24
CE 1
XGE3/1/1
100.1.1.1/32
CE 2
XGE3/1/1
100.1.1.2/32
1.     Configure CE 1:
# Assign an IP address to Ten-GigabitEthernet 3/1/1.
<CE1> system-view
[CE1] interface ten-gigabitethernet 3/1/1
[CE1-Ten-GigabitEthernet3/1/1] ip address 100.1.1.1 24
[CE1-Ten-GigabitEthernet3/1/1] quit
2.     Configure the PE:
# Configure basic MPLS capabilities.
<PE> system-view
[PE] interface loopback 0
[PE-LoopBack0] ip address 4.4.4.9 32
[PE-LoopBack0] ospf 1 area 0
[PE-LoopBack0] quit
[PE] mpls lsr-id 4.4.4.9
# Enable LDP globally.
[PE] mpls ldp
[PE-ldp] quit
# Enable L2VPN.
[PE] l2vpn enable
# Configure Ten-GigabitEthernet 3/1/1 that is connected to GW 1.
[PE] interface ten-gigabitethernet 3/1/1
[PE-Ten-GigabitEthernet3/1/1] ip address 10.1.1.4 24
[PE-Ten-GigabitEthernet3/1/1] ospf 1 area 0
[PE-Ten-GigabitEthernet3/1/1] mpls enable
[PE-Ten-GigabitEthernet3/1/1] mpls ldp enable
[PE-Ten-GigabitEthernet3/1/1] undo shutdown
[PE-Ten-GigabitEthernet3/1/1] quit
# Configure Ten-GigabitEthernet 3/1/2 that is connected to GW 2.
[PE] interface ten-gigabitethernet 3/1/2
[PE-Ten-GigabitEthernet3/1/2] ip address 20.1.1.4 24
[PE-Ten-GigabitEthernet3/1/2] ospf 1 area 0
[PE-Ten-GigabitEthernet3/1/2] mpls enable
[PE-Ten-GigabitEthernet3/1/2] mpls ldp enable
[PE-Ten-GigabitEthernet3/1/2] undo shutdown
[PE-Ten-GigabitEthernet3/1/2] quit
# Specify LDP signaling for VSI vpna, set up a main PW to GW 1 and a backup PW to GW 2, and enable the dual receive feature for PW redundancy.
[PE] vsi vpna
[PE-vsi-vpna] protection dual-receive
[PE-vsi-vpna] pwsignaling ldp
[PE-vsi-vpna-ldp] peer 1.1.1.9 pw-id 500
[PE-vsi-vpna-ldp-1.1.1.9-500] backup-peer 2.2.2.9 pw-id 500
[PE-vsi-vpna-ldp-1.1.1.9-500-backup] quit
[PE-vsi-vpna-ldp-1.1.1.9-500] quit
[PE-vsi-vpna-ldp] quit
[PE-vsi-vpna] quit
# Map Ten-GigabitEthernet 3/1/3 to VSI aaa.
[PE] interface ten-gigabitethernet 3/1/3
[PE-Ten-GigabitEthernet3/1/3] xconnect vsi vpna
[PE-Ten-GigabitEthernet3/1/3] quit
3.     Configure the GW 1:
# Configure Loopback 0.
<GW1> system-view
[GW1] interface loopback 0
[GW1-LoopBack1] ip address 1.1.1.9 32
[GW1-LoopBack1] quit
[GW1] mpls lsr-id 1.1.1.9
[GW1] mpls ldp
[GW1-ldp] quit
# Enable L2VPN.
[GW1] l2vpn enable
# Run OSPF for setting up LSPs.
[GW1] ospf
[GW1-ospf-1] area 0
[GW1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[GW1-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[GW1-ospf-1-area-0.0.0.0] network 10.1.3.0 0.0.0.255
[GW1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[GW1-ospf-1] quit
# Configure Ten-GigabitEthernet 3/1/1 that is connected to the PE.
[GW1] interface ten-gigabitethernet 3/1/1
[GW1-Ten-GigabitEthernet3/1/1] ip address 10.1.1.1 24
[GW1-Ten-GigabitEthernet3/1/1] mpls enable
[GW1-Ten-GigabitEthernet3/1/1] mpls ldp enable
[GW1-Ten-GigabitEthernet3/1/1] undo shutdown
[GW1-Ten-GigabitEthernet3/1/1] quit
# Configure Ten-GigabitEthernet 3/1/2 that is connected to the VTEP.
[GW1] interface ten-gigabitethernet 3/1/2
[GW1-Ten-GigabitEthernet3/1/2] ip address 30.1.1.1 24
[GW1-Ten-GigabitEthernet3/1/2] mpls enable
[GW1-Ten-GigabitEthernet3/1/2] mpls ldp enable
[GW1-Ten-GigabitEthernet3/1/2] undo shutdown
[GW1-Ten-GigabitEthernet3/1/2] quit
# Configure Ten-GigabitEthernet 3/1/3 that is connected to GW 2.
[GW1] interface ten-gigabitethernet 3/1/3
[GW1-Ten-GigabitEthernet3/1/3] ip address 10.1.3.1 24
[GW1-Ten-GigabitEthernet3/1/3] mpls enable
[GW1-Ten-GigabitEthernet3/1/3] mpls ldp enable
[GW1-Ten-GigabitEthernet3/1/3] undo shutdown
[GW1-Ten-GigabitEthernet3/1/3] quit
# Set up IBGP connections among GW 1, GW 2, and the VTEP, and enable advertisement of BGP EVPN routes.
[GW1] bgp 100
[GW1-bgp-default] peer 2.2.2.9 as-number 100
[GW1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[GW1-bgp-default] peer 3.3.3.9 as-number 100
[GW1-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[GW1-bgp-default] address-family l2vpn evpn
[GW1-bgp-default-evpn] peer 2.2.2.9 enable
[GW1-bgp-default-evpn] peer 3.3.3.9 enable
[GW1-bgp-default-evpn] quit
[GW1-bgp-default] quit
# Create VSI vpna, and create an EVPN instance on it. Configure the VSI EVPN instance to use VXLAN encapsulation, and configure an RD and route targets for the VSI EVPN instance.
[GW1] vsi vpna
[GW1-vsi-vpna] vxlan 10
[GW1-vsi-vpna] evpn encapsulation vxlan
[GW1-vsi-vpna-evpn-vxlan] route-distinguisher 1:1
[GW1-vsi-vpna-evpn-vxlan] vpn-target 1:1 export-extcommunity
[GW1-vsi-vpna-evpn-vxlan] vpn-target 1:1 import-extcommunity
[GW1-vsi-vpna-evpn-vxlan] quit
# Specify LDP signaling for VSI vpna, set up a UPW to GW 1, and configure the ESI and redundancy mode for the VSI.
[GW1-vsi-vpna] pwsignaling ldp
[GW1-vsi-vpna-ldp] peer 4.4.4.9 pw-id 500 no-split-horizon
[GW1-vsi-vpna-ldp-4.4.4.9-500] esi 1.1.1.1.1
[GW1-vsi-vpna-ldp-4.4.4.9-500] evpn redundancy-mode all-active
[GW1-vsi-vpna-ldp-4.4.4.9-500] quit
[GW1-vsi-vpna-ldp] quit
[GW1-vsi-vpna] quit
4.     Configure the GW 2:
<GW2> system-view
[GW2] interface loopback 0
[GW2-LoopBack0] ip address 2.2.2.9 32
[GW2-LoopBack0] quit
[GW2] mpls lsr-id 2.2.2.9
[GW2] mpls ldp
[GW2-ldp] quit
# Enable L2VPN.
[GW2] l2vpn enable
[GW2] ospf
[GW2-ospf-1] area 0
[GW2-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[GW2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[GW2-ospf-1-area-0.0.0.0] network 10.1.3.0 0.0.0.255
[GW2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[GW2-ospf-1] quit
# Configure Ten-GigabitEthernet 3/1/3 that is connected to GW 1.
[GW2] interface ten-gigabitethernet 3/1/3
[GW2-Ten-GigabitEthernet3/1/3] ip address 10.1.3.2 24
[GW2-Ten-GigabitEthernet3/1/3] mpls enable
[GW2-Ten-GigabitEthernet3/1/3] mpls ldp enable
[GW2-Ten-GigabitEthernet3/1/3] undo shutdown
[GW2-Ten-GigabitEthernet3/1/3] quit
[GW2] interface ten-gigabitethernet 3/1/2
[GW2-Ten-GigabitEthernet3/1/2] ip address 10.1.2.1 24
[GW2-Ten-GigabitEthernet3/1/2] mpls enable
[GW2-Ten-GigabitEthernet3/1/2] mpls ldp enable
[GW2-Ten-GigabitEthernet3/1/2] undo shutdown
[GW2-Ten-GigabitEthernet3/1/2] quit
[GW2] interface ten-gigabitethernet 3/1/1
[GW2-Ten-GigabitEthernet3/1/1] ip address 20.1.1.2 24
[GW2-Ten-GigabitEthernet3/1/1] mpls enable
[GW2-Ten-GigabitEthernet3/1/1] mpls ldp enable
[GW2-Ten-GigabitEthernet3/1/1] undo shutdown
[GW2-Ten-GigabitEthernet3/1/1] quit
[GW2] bgp 100
[GW2-bgp-default] peer 1.1.1.9 as-number 100
[GW2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[GW2-bgp-default] peer 3.3.3.9 as-number 100
[GW2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[GW2-bgp-default] address-family l2vpn evpn
[GW2-bgp-default-evpn] peer 1.1.1.9 enable
[GW2-bgp-default-evpn] peer 3.3.3.9 enable
[GW2-bgp-default-evpn] quit
[GW2-bgp-default] quit
[GW2] vsi vpna
[GW2-vsi-vpna] vxlan 10
[GW2-vsi-vpna] evpn encapsulation vxlan
[GW2-vsi-vpna-evpn-vxlan] route-distinguisher 1:1
[GW2-vsi-vpna-evpn-vxlan] vpn-target 1:1 export-extcommunity
[GW2-vsi-vpna-evpn-vxlan] vpn-target 1:1 import-extcommunity
[GW2-vsi-vpna-evpn-vxlan] quit
# Specify LDP signaling for VSI vpna, set up a UPW to GW 2, and configure the ESI and redundancy mode for the VSI.
[GW2] vsi vpna
[GW2-vsi-vpna] pwsignaling ldp
[GW2-vsi-vpna-ldp] peer 1.1.1.9 pw-id 500 no-split-horizon
[GW2-vsi-vpna-ldp-1.1.1.9-500] esi 1.1.1.1.1
[GW2-vsi-vpna-ldp-1.1.1.9-500] evpn redundancy-mode all-active
[GW2-vsi-vpna-ldp-1.1.1.9-500] quit
[GW2-vsi-vpna-ldp] quit
[GW2-vsi-vpna] quit
5.     Configure the VTEP:
<VTEP> system-view
[VTEP] interface loopback 0
[VTEP-LoopBack0] ip address 3.3.3.9 32
[VTEP-LoopBack0] quit
[VTEP] mpls lsr-id 3.3.3.9
[VTEP] mpls ldp
[VTEP-ldp] quit
# Enable L2VPN.
[VTEP] l2vpn enable
[VTEP] ospf
[VTEP-ospf-1] area 0
[VTEP-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[VTEP-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[VTEP-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[VTEP-ospf-1] quit
# Configure Ten-GigabitEthernet 3/1/2 that is connected to GW 1.
[VTEP] interface ten-gigabitethernet 3/1/2
[VTEP-Ten-GigabitEthernet3/1/2] ip address 30.1.1.3 24
[VTEP-Ten-GigabitEthernet3/1/2] undo shutdown
[VTEP-Ten-GigabitEthernet3/1/2] quit
[VTEP] interface ten-gigabitethernet 3/1/3
[VTEP-Ten-GigabitEthernet3/1/3] ip address 10.1.2.3 24
[VTEP-Ten-GigabitEthernet3/1/3] undo shutdown
[VTEP-Ten-GigabitEthernet3/1/3] quit
[VTEP] bgp 100
[VTEP-bgp-default] peer 1.1.1.9 as-number 100
[VTEP-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[VTEP-bgp-default] peer 2.2.2.9 as-number 100
[VTEP-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[VTEP-bgp-default] address-family l2vpn evpn
[VTEP-bgp-default-evpn] peer 1.1.1.9 enable
[VTEP-bgp-default-evpn] peer 2.2.2.9 enable
[VTEP-bgp-default-evpn] quit
[VTEP-bgp-default] quit
[VTEP] vsi vpna
[VTEP-vsi-vpna] vxlan 10
[VTEP-vsi-vpna] evpn encapsulation vxlan
[VTEP-vsi-vpna-evpn-vxlan] route-distinguisher 1:1
[VTEP-vsi-vpna-evpn-vxlan] vpn-target 1:1 export-extcommunity
[VTEP-vsi-vpna-evpn-vxlan] vpn-target 1:1 import-extcommunity
[VTEP-vsi-vpna-evpn-vxlan] quit
[VTEP] interface ten-gigabitethernet 3/1/1
[VTEP-Ten-GigabitEthernet3/1/1] xconnect vsi vpna
[VTEP-Ten-GigabitEthernet3/1/1] quit
6.     Configure CE 2:
<CE2> system-view
[CE2] interface ten-gigabitethernet 3/1/1
[CE2-Ten-GigabitEthernet3/1/1] ip address 100.1.1.2 24
[CE2-Ten-GigabitEthernet3/1/1] quit
# Verify that GW 1 has established an LDP PW with the PE and VXLAN tunnels with GW 2 and the VTEP.
[GW1] display l2vpn pw
       N - no split horizon, A - administration, ABY - ac-bypass
       PBY - pw-bypass
Total number of PWs: 3
1 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI Name: vpna
Peer            PWID/RmtSite/SrvID In/Out Label   Proto  Flag Link ID  State
4.4.4.9         500                1147/-         LDP    MN   8        Up
[GW1] display vxlan tunnel
Total number of VXLANs: 2
VXLAN ID: 10, VSI name: vpna, Total tunnels: 2 (2 up, 0 down, 0 defect, 0 blocked)
  Tunnel name          Link ID    State  Type      Flood Proxy
# Verify that GW 1 has a UPW (LDP PW) used for multihoming.
[GW1] display evpn es local verbose
VSI name : vpna
  ESI                      : 0001.0001.0001.0001.0001
  Interface                : -
  Redundancy mode          : All-active
  State                    : Up
  UPWs                     :
    Link ID     Service instance ID   Tag ID      DF address        ESI label
    8           -                     0           -                 1146
# Verify that GW 2 has similar configuration to GW 1. (Details not shown.)
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Interconnecting an EVPN VXLAN network with an EVPN VPLS network
As shown in Figure 27, interconnect the EVPN VXLAN network with the EVPN VPLS network as follows:
·     Set up PWs between the gateways and the PE.
·     Configure the gateways to exchange BGP EVPN routes between the EVPN VXLAN network and the EVPN VPLS network.
Figure 27 Network diagram
Device
IP address
Device
IP address
GW 1
Loop0
1.1.1.9/32
PE
Loop0
3.3.3.9/32
XGE3/1/1
10.1.1.1/24
XGE3/1/1
XGE3/1/2
30.1.1.1/24
XGE3/1/2
30.1.1.3/24
XGE3/1/3
10.1.3.1/24
XGE3/1/3
10.1.2.3/24
GW 2
Loop0
2.2.2.9/32
VTEP
Loop0
4.4.4.9/32
XGE3/1/1
20.1.1.2/24
XGE3/1/3
XGE3/1/2
10.1.2.2/24
XGE3/1/1
10.1.1.4/24
XGE3/1/3
10.1.3.2/24
XGE3/1/2
20.1.1.4/24
CE 1
XGE3/1/1
100.1.1.1/32
CE 2
XGE3/1/1
100.1.1.2/32
1.     Configure CE 1:
<CE1> system-view
2.     Configure the VTEP:
<VTEP> system-view
[VTEP-LoopBack0] ip address 4.4.4.9 32
# Enable L2VPN.
[VTEP] l2vpn enable
[VTEP-Ten-GigabitEthernet3/1/1] ip address 10.1.1.4 24
[VTEP-Ten-GigabitEthernet3/1/1] ospf 1 area 0
[VTEP-Ten-GigabitEthernet3/1/1] undo shutdown
[VTEP-Ten-GigabitEthernet3/1/2] ip address 20.1.1.4 24
[VTEP-Ten-GigabitEthernet3/1/2] ospf 1 area 0
# Set up IBGP connections with GW 1 and GW 2, and configure BGP EVPN to advertise routes to the gateways.
[VTEP] bgp 100
# Configure EVPN instance vxlan.
[VTEP] evpn instance vxlan
[VTEP-evpn-instance-vxlan] route-distinguisher 11:2
[VTEP-evpn-instance-vxlan] vpn-target 11:2 export-extcommunity
[VTEP-evpn-instance-vxlan] vpn-target 11:2 import-extcommunity
[VTEP-evpn-instance-vxlan] quit
# Associate VSI vxlan with an EVPN instance that uses VXLAN encapsulation.
[VTEP] vsi vxlan
[VTEP-vsi-vxlan] evpn encapsulation vxlan binding instance vxlan
[VTEP-vsi-vxlan] vxlan 10
[VTEP-vsi-vxlan-vxlan-10] quit
[VTEP-vsi-vxlan] quit
# Map Ten-GigabitEthernet 3/1/3 to VSI vxlan.
[VTEP-Ten-GigabitEthernet3/1/3] xconnect vsi vxlan
<GW1> system-view
[GW1] mpls ldp
[GW1-ldp] quit
# Enable L2VPN.
[GW1] l2vpn enable
[GW1] ospf
[GW1-ospf-1] area 0
[GW1-ospf-1] quit
# Configure Ten-GigabitEthernet 3/1/1 that is connected to the VTEP.
# Configure Ten-GigabitEthernet 3/1/2 that is connected to the PE.
# Set up IBGP connections to GW 2, the VTEP, and the PE. Enable advertisement of BGP EVPN routes, and enable reorigination of MAC/IP advertisement routes.
[GW1] bgp 100
[GW1-bgp-default] evpn mac re-originated enable
[GW1-bgp-default] peer 4.4.4.9 as-number 100
[GW1-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[GW1-bgp-default-evpn] peer 3.3.3.9 advertise encap-type mpls
[GW1-bgp-default-evpn] peer 3.3.3.9 re-originated mac replace-rt
[GW1-bgp-default-evpn] peer 4.4.4.9 enable
[GW1-bgp-default-evpn] peer 4.4.4.9 re-originated mac replace-rt
# Configure EVPN instance evpna and EVPN instance evpnb.
[GW1] evpn instance evpna
[GW1-evpn-instance-evpna] route-distinguisher 11:1
[GW1-evpn-instance-evpna] vpn-target 11:1 export-extcommunity
[GW1-evpn-instance-evpna] vpn-target 11:1 import-extcommunity
[GW1-evpn-instance-evpna] quit
[GW1] evpn instance evpnb
[GW1-evpn-instance-evpnb] route-distinguisher 11:2
[GW1-evpn-instance-evpnb] vpn-target 11:2 export-extcommunity
[GW1-evpn-instance-evpnb] vpn-target 11:2 import-extcommunity
[GW1-evpn-instance-evpnb] quit
# Configure EVPN instance evpna to use MPLS encapsulation and EVPN instance evpnb to use VXLAN encapsulation. Bind the EVPN instances to VSI vpna, and assign an ESI to the VSI.
[GW1] vsi vpna
[GW1-vsi-vpna] evpn encapsulation mpls binding instance evpna
[GW1-vsi-vpna] evpn encapsulation vxlan binding instance evpnb
[GW1-vsi-vpna-vxlan-10] quit
[GW1-vsi-vpna] esi 1.1.1.1.1
[GW1-vsi-vpna] quit
<GW2> system-view
[GW2] mpls ldp
[GW2-ldp] quit
# Enable L2VPN.
[GW2] l2vpn enable
[GW2] ospf
[GW2-ospf-1] area 0
[GW2-ospf-1] quit
# Set up IBGP connections to GW 1, the VTEP, and the PE. Enable advertisement of BGP EVPN routes, and enable reorigination of MAC/IP advertisement routes.
[GW2] bgp 100
[GW2-bgp-default] evpn mac re-originated enable
[GW2-bgp-default] peer 4.4.4.9 as-number 100
[GW2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[GW2-bgp-default-evpn] peer 3.3.3.9 advertise encap-type mpls
[GW2-bgp-default-evpn] peer 3.3.3.9 re-originated mac replace-rt
[GW2-bgp-default-evpn] peer 4.4.4.9 enable
[GW2-bgp-default-evpn] peer 4.4.4.9 re-originated mac replace-rt
[GW2] evpn instance evpna
[GW2-evpn-instance-evpna] route-distinguisher 11:1
[GW2-evpn-instance-evpna] vpn-target 11:1 export-extcommunity
[GW2-evpn-instance-evpna] vpn-target 11:1 import-extcommunity
[GW2-evpn-instance-evpna] quit
[GW2] evpn instance evpnb
[GW2-evpn-instance-evpnb] route-distinguisher 11:2
[GW2-evpn-instance-evpnb] vpn-target 11:2 export-extcommunity
[GW2-evpn-instance-evpnb] vpn-target 11:2 import-extcommunity
[GW2-evpn-instance-evpnb] quit
[GW2] vsi vpna
[GW2-vsi-vpna] evpn encapsulation mpls binding instance evpna
[GW2-vsi-vpna] evpn encapsulation vxlan binding instance evpnb
[GW2-vsi-vpna-vxlan-10] quit
[GW2-vsi-vpna] esi 1.1.1.1.1
[GW2-vsi-vpna] quit
5.     Configure the PE:
<PE> system-view
[PE-LoopBack0] ip address 3.3.3.9 32
[PE-LoopBack0] quit
[PE] mpls lsr-id 3.3.3.9
[PE] mpls ldp
[PE-ldp] quit
# Enable L2VPN.
[PE] l2vpn enable
[PE] ospf
[PE-ospf-1] area 0
[PE-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[PE-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE-ospf-1] quit
[PE-Ten-GigabitEthernet3/1/2] ip address 30.1.1.3 24
[PE-Ten-GigabitEthernet3/1/3] ip address 10.1.2.3 24
[PE-Ten-GigabitEthernet3/1/3] undo shutdown
# Set up IBGP connections to GW 1 and GW 2, and enable advertisement of BGP EVPN routes.
[PE] bgp 100
[PE-bgp-default] peer 1.1.1.9 as-number 100
[PE-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE-bgp-default] peer 2.2.2.9 as-number 100
[PE-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE-bgp-default] address-family l2vpn evpn
[PE-bgp-default-evpn] peer 1.1.1.9 enable
[PE-bgp-default-evpn] peer 1.1.1.9 advertise encap-type mpls
[PE-bgp-default-evpn] peer 2.2.2.9 enable
[PE-bgp-default-evpn] peer 2.2.2.9 advertise encap-type mpls
[PE-bgp-default-evpn] quit
[PE-bgp-default] quit
# Configure EVPN instance mpls.
[PE] evpn instance mpls
[PE-evpn-instance-mpls] route-distinguisher 11:1
[PE-evpn-instance-mpls] vpn-target 11:1 export-extcommunity
[PE-evpn-instance-mpls] vpn-target 11:1 import-extcommunity
[PE-evpn-instance-mpls] quit
# Associate VSI mpls with an EVPN instance that uses MPLS encapsulation.
[PE] vsi mpls
[PE-vsi-mpls] evpn encapsulation mpls binding instance mpls
[PE-vsi-mpls] quit
# Map Ten-GigabitEthernet 3/1/1 to VSI mpls.
[PE-Ten-GigabitEthernet3/1/1] xconnect vsi mpls
6.     Configure CE 2:
<CE2> system-view
# Verify that GW 1 has established an EVPN PW to the PE and VXLAN tunnels to GW 2 and the VTEP.
       PBY - pw-bypass
Total number of PWs: 1
1 up, 0 blocked, 1 down, 0 defect, 0 idle, 0 duplicate
VSI Name: vpna
4.4.4.9         -                  775127/1148    EVPN   M    8        Up
<GW1> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: ldpvxlan, Total tunnels: 2 (2 up, 0 down, 0 defect, 0 blocked)
# Verify that GW 1 has an ES used for multihoming.
Redundancy mode: A - All-active, S - Single-active
VSI name : vpna
EVPN instance: evpna
EVPN instance: evpnb
  VSI ESI                  : 0003.0003.0003.0003.0003
  ES state                 : Up
Example: Interconnecting an EVPN VXLAN network with an EVPN VPLS over SRv6 network
As shown in Figure 28, interconnect the EVPN VXLAN network with the EVPN VPLS over SRv6 network as follows:
·     Set up SRv6 PWs between the gateways and the PE.
·     Configure the gateways to exchange BGP EVPN routes between the EVPN VXLAN network and the EVPN VPLS over SRv6 network.
Figure 28 Network diagram
Device
IP address
Device
IP address
GW 1
Loop0
1::1/128
PE
Loop0
3::3/128
XGE3/1/1
15::1/64
XGE3/1/1
XGE3/1/2
13::1/64
XGE3/1/2
13::1/64
XGE3/1/3
11::1/64
XGE3/1/3
23::2/64
GW 2
Loop0
2::2/128
VTEP
Loop0
4::4/128
XGE3/1/1
26::2/64
XGE3/1/3
XGE3/1/2
23::2/64
XGE3/1/1
15::4/64
XGE3/1/3
11::2/64
XGE3/1/2
26::4/64
CE 1
XGE3/1/1
100::1/64
CE 2
XGE3/1/1
100::2/64
1.     Configure CE 1:
<CE1> system-view
[CE1-Ten-GigabitEthernet3/1/1] ipv6 address 100::1 64
<VTEP> system-view
[VTEP-LoopBack0] ip address 4::4 128
[VTEP-LoopBack0] ospfv3 1 area 0
# Enable L2VPN.
[VTEP] l2vpn enable
[VTEP-Ten-GigabitEthernet3/1/1] ip address 15::4 24
[VTEP-Ten-GigabitEthernet3/1/1] ospfv3 1 area 0
[VTEP-Ten-GigabitEthernet3/1/2] ip address 26::4 24
[VTEP-Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[VTEP] bgp 100
[VTEP-bgp-default] peer 1::1 as-number 100
[VTEP-bgp-default] peer 1::1 connect-interface loopback 0
[VTEP-bgp-default] peer 2::2 as-number 100
[VTEP-bgp-default] peer 2::2 connect-interface loopback 0
[VTEP-bgp-default-evpn] peer 1::1 enable
[VTEP-bgp-default-evpn] peer 2::2 enable
[VTEP] vsi vxlan
3.     Configure GW 1:
# Configure OSPFv3.
<GW1> system-view
[GW1] ospfv3
[GW1-ospfv3-1] router-id 1.1.1.1
[GW1-ospfv3-1] segment-routing ipv6 locator aaa
[GW1-ospfv3-1] area 0
[GW1-ospfv3-1-area-0.0.0.0] quit
[GW1-ospfv3-1] quit
<GW1> system-view
[GW1-LoopBack1] ip address 1::1 128
[GW1-LoopBack1] ospfv3 1 area 0
# Enable L2VPN.
[GW1] l2vpn enable
[GW1-Ten-GigabitEthernet3/1/1] ipv6 address 15::1/64
[GW1-Ten-GigabitEthernet3/1/1] ospfv3 1 area 0
[GW1-Ten-GigabitEthernet3/1/2] ipv6 address 13::1/64
[GW1-Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[GW1-Ten-GigabitEthernet3/1/3] ipv6 address 11::1/64
[GW1-Ten-GigabitEthernet3/1/3] ospfv3 1 area 0
[GW1] bgp 100
[GW1-bgp-default] peer 2::2 as-number 100
[GW1-bgp-default] peer 2::2 connect-interface loopback 0
[GW1-bgp-default] peer 3::3 as-number 100
[GW1-bgp-default] peer 3::3 connect-interface loopback 0
[GW1-bgp-default] peer 4::4 as-number 100
[GW1-bgp-default] peer 4::4 connect-interface loopback 0
[GW1-bgp-default-evpn] peer 2::2 enable
[GW1-bgp-default-evpn] peer 3::3 enable
[GW1-bgp-default-evpn] peer 3::3 advertise encap-type srv6
[GW1-bgp-default-evpn] peer 3::3 re-originated mac replace-rt
[GW1-bgp-default-evpn] peer 4::4 enable
[GW1-bgp-default-evpn] peer 4::4 re-originated mac replace-rt
# Configure a locator or requesting End.DT2U SID and End.DT2M SID.
[GW1] segment-routing ipv6
[GW1-segment-routing-ipv6] encapsulation source-address 1::1
[GW1-segment-routing-ipv6] locator aaa ipv6-prefix 111:: 64 static 32
[GW1-segment-routing-ipv6-locator-aaa] quit
[GW1-segment-routing-ipv6] quit
[GW1-evpn-instance-evpna] segment-routing ipv6 best-effort
[GW1-evpn-instance-evpna] segment-routing ipv6 locator aaa
# Configure EVPN instance evpna to use SRv6 encapsulation and EVPN instance evpnb to use VXLAN encapsulation. Bind the EVPN instances to VSI vpna, and assign an ESI to the VSI.
[GW1] vsi vpna
[GW1-vsi-vpna] evpn encapsulation srv6 binding instance evpna
[GW1-vsi-vpna] quit
4.     Configure GW 2:
# Configure OSPFv3.
<GW2> system-view
[GW2] ospfv3
[GW2-ospfv3-1] router-id 2.2.2.2
[GW2-ospfv3-1] segment-routing ipv6 locator aaa
[GW2-ospfv3-1] area 0.0.0.0
[GW2-ospfv3-1-area-0.0.0.0] quit
[GW2-ospfv3-1] quit
<GW2> system-view
[GW2-LoopBack0] ip address 2::2 128
[GW2-LoopBack1] ospfv3 1 area 0
# Enable L2VPN.
[GW2] l2vpn enable
[GW2-Ten-GigabitEthernet3/1/3] ipv6 address 11::2/64
[GW2-Ten-GigabitEthernet3/1/3] ospfv3 1 area 0
[GW2-Ten-GigabitEthernet3/1/2] ipv6 address 23::1/64
[GW2-Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[GW2-Ten-GigabitEthernet3/1/1] ip address 26::2 24
[GW2-Ten-GigabitEthernet3/1/1] ospfv3 1 area 0
[GW2] bgp 100
[GW2-bgp-default] peer 1::1 as-number 100
[GW2-bgp-default] peer 1::1 connect-interface loopback 0
[GW2-bgp-default] peer 3::3 as-number 100
[GW2-bgp-default] peer 3::3 connect-interface loopback 0
[GW2-bgp-default] peer 4::4 as-number 100
[GW2-bgp-default] peer 4::4 connect-interface loopback 0
[GW2-bgp-default-evpn] peer 1::1 enable
[GW2-bgp-default-evpn] peer 3::3 enable
[GW2-bgp-default-evpn] peer 3::3 advertise encap-type srv6
[GW2-bgp-default-evpn] peer 3::3 re-originated mac replace-rt
[GW2-bgp-default-evpn] peer 4::4 enable
[GW2-bgp-default-evpn] peer 4::4 re-originated mac replace-rt
[GW2] segment-routing ipv6
[GW2-segment-routing-ipv6] encapsulation source-address 2::2
[GW2-segment-routing-ipv6] locator aaa ipv6-prefix 222:: 64 static 32
[GW2-segment-routing-ipv6-locator-aaa] quit
[GW2-segment-routing-ipv6] quit
[GW2-evpn-instance-evpna] segment-routing ipv6 best-effort
[GW2-evpn-instance-evpna] segment-routing ipv6 locator aaa
[GW2] vsi vpna
[GW2-vsi-vpna] evpn encapsulation srv6 binding instance evpna
[GW2-vsi-vpna] quit
# Configure OSPFv3.
<PE> system-view
[PE3] ospfv3
[PE-ospfv3-1] router-id 3.3.3.3
[PE-ospfv3-1] segment-routing ipv6 locator aaa
[PE-ospfv3-1] area 0
[PE-ospfv3-1-area-0.0.0.0] quit
[PE-ospfv3-1] quit
<PE> system-view
[PE-LoopBack0] ip address 3::3 128
[PE-LoopBack1] ospfv3 1 area 0
[PE-LoopBack0] quit
# Enable L2VPN.
[PE] l2vpn enable
[PE-Ten-GigabitEthernet3/1/2] ipv6 address 13::3/64
[PE-Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[PE-Ten-GigabitEthernet3/1/3] ipv6 address 23::3/64
[PE-Ten-GigabitEthernet3/1/3] ospfv3 1 area 0
[PE] bgp 100
[PE-bgp-default] peer 1::1 as-number 100
[PE-bgp-default] peer 1::1 connect-interface loopback 0
[PE-bgp-default] peer 2::2 as-number 100
[PE-bgp-default] peer 2::2 connect-interface loopback 0
[PE-bgp-default-evpn] peer 1::1 enable
[PE-bgp-default-evpn] peer 1::1 advertise encap-type srv6
[PE-bgp-default-evpn] peer 2::2 enable
[PE-bgp-default-evpn] peer 2::2 advertise encap-type srv6
[PE] segment-routing ipv6
[PE-segment-routing-ipv6] encapsulation source-address 3::3
[PE-segment-routing-ipv6] locator aaa ipv6-prefix 333:: 64 static 32
[PE-segment-routing-ipv6-locator-aaa] quit
[PE-segment-routing-ipv6] quit
# Configure EVPN instance srv6a.
[PE] evpn instance srv6a
[PE-evpn-instance-srv6a] route-distinguisher 11:1
[PE-evpn-instance-srv6a] vpn-target 11:1 export-extcommunity
[PE-evpn-instance-srv6a] vpn-target 11:1 import-extcommunity
[PE-evpn-instance-srv6a] segment-routing ipv6 best-effort
[PE-evpn-instance-srv6a] segment-routing ipv6 locator aaa
[PE-evpn-instance-srv6a] quit
# Associate VSI srv6 with EVPN instance srv6a that uses SRv6 encapsulation.
[PE] vsi srv6
[PE-vsi-mpls] evpn encapsulation srv6 binding instance srv6a
[PE-vsi-mpls] quit
# Map Ten-GigabitEthernet 3/1/1 to VSI srv6a.
[PE-Ten-GigabitEthernet3/1/1] xconnect vsi srv6
6.     Configure CE 2:
<CE2> system-view
[CE2-Ten-GigabitEthernet3/1/1] ipv6 address 100::2 64
# Verify that GW 1 has established an SRv6 PW to the PE and VXLAN tunnels to GW 2 and the VTEP.
<GW1> display l2vpn peer srv6
Total number of SRv6 Tunnels: 2
2 up, 0 blocked, 0 down
VSI Name: vpna
   Peer            : 3::3
   Flag            : Main
   State           : Up
<GW1> display evpn es local verbose
VSI name : vpna
  ES state                 : Up
