Title | Size | Downloads |
00-About the H3C access controller command references-book.rar | 8.21 MB |
book | 8.21 MB |
The H3C access controller (AC) command references describe the commands and command syntax options for H3C ACs and wireless conductor gateways.
Command reference |
Content |
License Management Command Reference |
Covers license types and the commands for applying for, installing, uninstalling, and transferring a license. This command reference includes: · License management · AP license synchronization |
Fundamentals Command Reference |
Covers the commands for logging in to and setting up the device. This command reference includes: · CLI (CLI overview and advanced CLI configuration) · RBAC · Login management (CLI login and user configuration and management) · FTP and TFTP · File system management · Configuration file management · Software upgrade · Automatic configuration · Python · Tcl |
System Management Command Reference |
Covers the commands for managing the device and logs by using device management, information center, NTP and EAA features. This command reference includes: · Device management · Device hardening · Hardware resource management · NTP · Information center · EAA |
Interface Command Reference |
Covers the commands for configuring Ethernet interfaces, PoE, loopback interfaces, null interfaces, inloopback interfaces, and bulk interface settings. This command reference includes: · Loopback, null, and inloopback interface · Ethernet interface · Tunnel interface · Bulk interface configuration |
Network Connectivity Command Reference |
Covers the commands for configuring network connectivity-related Layer 2 and Layer 3 features. This command reference includes: · MAC address table · Ethernet link aggregation · Port isolation · VLAN · Loop detection · Spanning tree · LLDP · Layer 2 forwarding · L2TP · ARP · IP addressing · DHCP · DHCP snooping · DHCPv6 · DHCPv6 snooping · DNS · HTTP · IP forwarding basics · Fast forwarding · Adjacency table · IP performance optimization · IPv6 basics · IPv6 neighbor discovery · IPv6 fast forwarding · NAT · GRE · Basic IP routing · Static routing · OSPF · Policy-based routing · IPv6 static routing · IPv6 policy-based routing · IGMP snooping · MLD snooping |
WLAN Access Command Reference |
Covers the commands for configuring WLAN access. This command reference includes: · WLAN access |
AP Management Command Reference |
Covers the commands for configuring centralized management of fit APs in an AC+fit AP network. This command reference includes: · AP management |
WLAN Security Command Reference |
Covers the commands for configuring WLAN security, and WIPS features. This command reference includes: · WLAN security · WIPS |
Radio Resources Management Command Reference |
Covers the commands for managing radio channel, power, rate, and load balancing, and measuring link quality and WLAN performance. This command reference includes: · Radio management · WLAN radio load balancing · WLAN load balancing · WLAN radio resource measurement · Band navigation · WLAN RRM · Channel scanning · Spectrum management |
WLAN Roaming Command Reference |
Covers the commands for configuring wireless client roaming and fast roaming. This command reference includes: · WLAN roaming · Client roaming center |
WLAN Traffic Optimization Command Reference |
Covers the commands for optimizing WLAN traffic by using multicast optimization and user isolation. This command reference includes: · WLAN multicast optimization · User isolation |
WLAN Advanced Features Command Reference |
Covers the commands for advanced WLAN features, WLAN mesh, AC hierarchy, optimization, and management features. This command reference includes: · WLAN optimization · Hotspot 2.0 · WLAN probe · WSA · Wireless location · WLAN process maintenance · WLAN mesh · Bonjour gateway · WLAN forwarding |
User Access and Authentication Command Reference |
Covers the commands for configuring wired and wireless access and authentication. This command reference includes: · WLAN access authentication · WLAN IP snooping · AAA · 802.1X · MAC authentication · Portal · HTTP redirect · User identification. |
Cloud Connection Command Reference |
Covers the commands for users to manage devices from the cloud platform. This command reference includes: · Cloud connection |
High Availability Command Reference |
Covers the commands for configuring wired and wireless high availability features. This command reference includes: · WLAN high availability · Track · VRRP |
Covers the commands for configuring identity authentication (PKI), secure management (password control, public key management, IPsec, and SSH), and security protection (IP source guard and ARP attack protection). This command reference includes: · ACL · Packet filter · Time range · User profile · Password control · Keychain · Public key management · PKI · IPsec · IKE · IKEv2 · SSH · SSL · SSL VPN · Session management · Connection limit · Attack detection and prevention · IP-based attack prevention · IP source guard · ARP attack protection · ND attack protection · Protocol packet rate limit · Object group |
DPI Command Reference |
Covers the commands for configuring DPI. This command reference includes: · DPI engine · APR · IPS |
Internet Access Behavior Management Command Reference |
Covers the commands for configuring Internet access behavior. This command reference includes: · Bandwidth management · Application audit and management |
QoS Command Reference |
Covers the commands for configuring wired and wireless QoS. This command reference includes: · QoS · WLAN QoS |
Network Management and Monitoring Command Reference |
Covers the commands that help you manage networks, display system information, control network traffic, sample packets, analyze network performance, and debug network connectivity. This command reference includes: · Ping and tracert · System debugging · NQA · SNMP · RMON · NETCONF · Process monitoring and maintenance · Mirroring · Email notification service · UCC · SQA · Packet Capture |
Internet of Things Command Reference |
Covers the commands for configuring and managing IoT APs, and IoT modules. This command reference includes: · IoT AP |
