H3C G6&G7 Servers HDM2&HDM3 Redfish API Reference-6W102
HomeSupportDeveloper DocumentsAPI ReferencesH3C G6&G7 Servers HDM2&HDM3 Redfish API Reference-6W102
Download Book
  • Released At: 14-07-2025
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
New H3C Technologies Co., Ltd.
http://www.h3c.com
Software version: HDM2-1.80 and later, HDM2-2.17 and later, HDM3-1.25 and later, HDM3-2.04 and later
Document version: V1.27
Copyright © 2025, New H3C Technologies Co., Ltd. and its licensors
All rights reserved
Trademarks
Notice
The information in this document is subject to change without notice. All contents in this document, including statements, information, and recommendations, are believed to be accurate, but they are presented without warranty of any kind, express or implied. H3C shall not be liable for technical or editorial errors or omissions contained herein.
Revision records
Version
Revision date
HDM version
Interface name
Interface modification content
May 17, 2021
0.00.11
First version release.
June 10, 2022
0.00.14
Download BMC file
Change "Path" to "Content".
November 29, 2022
Obtain root service information
The ProtocolFeaturesSupported object is added to the return body.
December 1, 2022
Obtain virtual media information
Consolidate the query of virtual CD media resources and the query of virtual HD media resources.
December 1, 2022
Connect to virtual media
Modify the return body of the TASK, unify it into one form.
December 1, 2022
Disconnect from virtual media
Modify the TASK return body to a unified format.
December 1, 2022
Import the BIOS, BMC, and RAID controller settings
The modification of the TASK return body is unified into one format, changing the interface permission from maintenance diagnosis to subscriber provisioning.
December 1, 2022
Export the BIOS, BMC, and RAID controller settings
The return body of the TASK is modified and unified into one form. The interface permissions are changed from maintenance diagnostics to subscriber provisioning.
December 1, 2022
Delete a session
Return the modified body in a unified form.
December 1, 2022
Upgrade firmware
The return format of the TASK response body has been unified due to modifications in the HDM2 upgrade process and significant changes in G5.
December 1, 2022
Delete an event subscription
Unified the body modification into one form.
December 1, 2022
Obtain event log entry collection information
The interface permissions have been changed from the query module to system audit.
December 1, 2022
Obtain event log entry resource information
The interface permissions have been changed from the query module to the system audit.
December 1, 2022
Clear event log entry information
The interface permissions have been changed from regular configuration to maintenance diagnostic.
December 2, 2022
Obtain SMTP information
Add the TLSEnabled field.
December 2, 2022
Configure SMTP settings
Add the 'TLSEnabled' field.
December 6, 2022
Set the physical drive state
The interface control permission has been changed from "remote control" to "remote control | maintenance diagnosis."
December 6, 2022
Configure system resource properties
The interface permission has been changed from "Remote Control" to "Remote Control|General Configuration|Power Control".
December 6, 2022
Create a logical drive
Unified form for body modification {return}.
December 6, 2022
Delete a logical drive
Unified the body modifications to a single form.
December 6, 2022
Edit VNC settings
The interface permission has been changed from "security control" to "remote control".
December 6, 2022
Edit KVM settings
The interface authority has been changed from "security control" to "remote control".
December 8, 2022
Obtain server information by its chassis resource ID
Put the 'nPCIeDevices' field into the 'Links' section.
December 13, 2022
Obtain memory information
Add the fields 'OperatingSpeedMegaTransfersPerSecond' and 'AllowedSpeedsMegaTransfersPerSecond' in the 'Oem.Public' section.
December 13, 2022
Obtain syslog information
Configure syslog settings
Add the fields RootCertificateInstalled, ClientCertificateInstalled, and PrivateKeyCertificateInstalled in Oem.Public.
December 16, 2022
Obtain information about CPU power saving
Configure CPU power saving settings
Add the field CPUPStateValid.
December 16, 2022
Obtain account service information
Add export path for weak password dictionary operation and add import path for weak password dictionary operation, and add field Oem.Public.PasswordRule.WeakPasswordDictionaryEnabled.
December 16, 2022
Edit account service settings
Add field Oem.Public.PasswordRule.WeakPasswordDictionaryEnabled.
December 16, 2022
Import a weak password dictionary
New interface added.
December 16, 2022
Export a weak password dictionary
December 16, 2022
Obtain SNMP information
The SnmpV3EngineID field has been added. sha256, sha384, and sha512 were newly added to the SnmpV3AuthProtocol field. aes192 and aes256 were newly added to the SnmpV3PrivProtocol field.
December 16, 2022
Configure SNMP settings
Added field SnmpV3Enabled.
December 16, 2022
Obtain user account information
The Oem.Public.SnmpEncryptPwdInit and Oem.Public.SnmpV3Password fields were added.
The Oem.Public.SnmpV3AuthProtocol field now includes SHA256, SHA384, and SHA512.
The Oem.Public.SnmpV3PrivProtocol field now includes AES192 and AES256.
December 16, 2022
Add a user account
The Oem.Public.SnmpV3Password field was added. The Oem.Public.SnmpV3AuthProtocol field is expanded to include SHA256, SHA384, and SHA512. The Oem.Public.SnmpV3PrivProtocol field is expanded to include AES192 and AES256.
December 16, 2022
Edit user account settings
Added field Oem.Public.SnmpV3Password. Oem.Public.SnmpV3AuthProtocol now includes SHA256, SHA384, and SHA512. Oem.Public.SnmpV3PrivProtocol now includes AES192 and AES256.
December 30, 2022
Obtain storage controller information
Add field SupportedStripSize.
Added ConfigureAccessPolicy, ConfigureWritePolicy, ConfigureReadPolicy, and ConfigureDriveCachePolicy to SupportedConfigurationOperation.
December 30, 2022
Obtain network port information
Added the following fields:
·     Ipv4StaticAddresses.Address
·     Ipv4StaticAddresses.AddressOrigin
·     Ipv4StaticAddresses.Gateway
·     Ipv4StaticAddresses.SubnetMask
·     Ipv6StaticDefaultGateways.
December 30, 2022
Configure network port settings
January 17, 2023
Obtain system resource information
Added fields ComputeModuleMaxCount and PresentComputeModules.
February 14, 2023
Add field ChassisPartNumber.
February 20, 2023
Obtain physical drive information
Add field PredictedMediaLifeLeftDays.
February 20, 2023
License related interface
Added interface.
February 23, 2023
Obtain physical drive collection information
Added field AlarmThreshold.
February 23, 2023
Obtain thermal properties
Added field InletHistoryTemperature.
February 23, 2023
Obtain update service information
Moved #MirrorPool.DeleteImage as a sub-field of Actions.Oem.Public.
Moved #UpdateService.DumpBIOS as a sub-field of Actions.Oem.Public.
Added #UpdateService.UninstallPackage and InstalledPackages.
February 23, 2023
Bind a user to a client certificate
Changed the URL name from "ClientCertifcate" to "ClientCertificate".
February 23, 2023
Unbind a client certificate from a user
February 23, 2023
Obtain SSH public key list information
Added Accounts object.
February 23, 2023
Obtain user certificate management service information
February 23, 2023
Obtain power information
Added PowerHistoryData object.
February 23, 2023
Obtain event log service collection information
Added object Actions.Oem.Public.#LogServices.ExportEventLog.
February 24, 2023
Deleted the PCIeAddress field.
February 24, 2023
Obtain information of a firmware inventory
Added field Model.
February 24, 2023
Obtain memory collection information
Deleted field MemoryRankSparing.
February 26, 2023
Added option Major+Critical to field AlarmSeverity.
February 26, 2023
February 27, 2023
Obtain processor information
Added fields ChopType and Step.
February 27, 2023
Obtain host status migration information
Added interface.
February 27, 2023
Added field Oem.Public.DisabledCausation.
February 27, 2023
Obtain security dashboard information
Set security dashboard information
Added interface.
February 28, 2023
Obtain PCIe function information
Added field Oem.Public.LinkWidthAbility.
February 28, 2023
Collect SDS log entry information
Added field LogType.
March 1, 2023
Deleted the TransferProtocol@Redfish.AllowableValues field from the UpdateService.DumpBIOSS and UpdateService.SimpleUpdate fields.
March 1, 2023
Upgrade firmware
Add values to UpgradeType.
March 2, 2023
Added object Oem.Public.HostStatus.
March 2, 2023
Obtain emergency diagnostic information
Deleted interface.
March 2, 2023
Modify emergency diagnostic information
Deleted interface.
March 2, 2023
Obtain host resource information
Modify host resource information
Deleted interface.
March 2, 2023
Obtain information about CPU historical usage rate resource
Deleted interface.
March 2, 2023
Obtain information about memory historical usage rate resource
Deleted interface.
March 2, 2023
Obtain information about IO historical usage rate resource
Deleted interface.
March 2, 2023
Added interface.
March 2, 2023
Added interface.
March 2, 2023
Added interface.
March 2, 2023
Obtain information about GPU historical usage rate resource
Added interface.
March 2, 2023
Obtain information about network bandwidth historical send/receive speed resource
Added interface.
March 2, 2023
Obtain information about disk historical usage rate resource
Added interface.
March 2, 2023
Obtain information about disk IO performance historical data
Added interface.
March 2, 2023
Obtain information about disk SCVTM historical data
Added interface.
March 2, 2023
Obtain information about NFS server read/write rate historical data
Added interface.
March 2, 2023
Obtain information about NFS client read/write rate historical data
Added interface.
March 2, 2023
Obtain information about system load historical data
Added interface.
March 2, 2023
Obtain intelligent monitoring service information
Added interface.
March 2, 2023
Configure intelligent monitoring service information
Added interface.
March 2, 2023
Obtain sensor type collection information
Added interface.
March 2, 2023
Obtain information of sensor list for a specified type
Added interface.
March 2, 2023
Obtain sensor information
Added interface.
March 2, 2023
Obtain manager resource information
Added field Oem.Public.IntelligentMonitoringService.
March 7, 2023
Obtain shared network port information
Added HotPlugSupported field.
March 8, 2023
Obtain message registry collection information
Add field @odata.context.
March 8, 2023
Obtain message registry information
Added field @odata.context.
March 8, 2023
Obtain wireless information
Added field IsSameSegment.
March 8, 2023
Obtain manager collection information
Changed the value of field @odata.context.
March 8, 2023
The field "nSDCardState" has been changed to "DSDCardState".
March 8, 2023
Obtain information about host resource monitoring
Changed "TotalCapacityGiB" to "TotalCapacityMB."
Changed "FreeSpaceGiB" to "FreeSpaceMB."
March 8, 2023
Changed "nDriveSCVTMHistoryData" to "DriveSVCTMHistoryData."
March 8, 2023
Obtain information about disk SVCTM historical data
Changed the URL name from DriveSCVTMHistoryData to DriveSVCTMHistoryData.
Change the array name from HistorySCVTM to HistorySVCTM.
March 10, 2023
Added field SystemDiskNumber.
March 13, 2023
Updated the description of the content parameter to "The interface only supports /mnt/sdmmc0p1/sds/bmc/filename."
Special characters @!$^&_+.;[]{}-=~" are supported.
March 14, 2023
Added field InternalBackupFirmwareVersion for the internal release of the backup partition.
March 15, 2023
Deleted field DiagnosticServiceEnabled.
March 15, 2023
Interface for returning task ID
The TaskUniqueID field is added to represent the unique ID of a task.
March 15, 2023
Added an output explanation for the 'name' field.
March 15, 2023
Import SSL certificate
Modified the text certificate sample.
V0.9.1
March 16, 2023
HDM2-1.13
N/A
Synchronized and updated the minor version number
March 17, 2023
Obtain the license activation file
Changed "Trial" to "Temporary" in the License type field.
March 17, 2023
Added field SupportedRAIDMode.
March 17, 2023
Modified the Description and Name fields.
March 17, 2023
Deleted field Oem.Public.RSAEncryptionEnabled.
March 18, 2023
Modified the field explanations for supported cards and strip size operations.
March 18, 2023
Obtain the user collection resource in an AD domain
Changed "LDAP" to "AD" in the function description.
March 20, 2023
Changed "inlet" in the explanation of the InletHistoryTemperature parameter to "inlet air intake."
March 20, 2023
Obtain event collection information
Added description of the "target" and "description" fields to the parameter description.
March 20, 2023
Changed the "EventService resource information description" in the parameter specifications to "Event service resource's return parameter description".
March 20, 2023
Simulate reporting test events
Changed "Severity" to "MessageSeverity" in the parameter description.
March 21, 2023
Example revised.
March 21, 2023
Example revised.
March 22, 2023
Added the 'SpeedGTps' field and explanation to the example.
March 22, 2023
Obtain event log service resource information
Deleted Actions, and the @Redfish.ActionInfo and ClearType@Redfish.AllowableValues fields under #LogService.ClearLog.
V0.9.2
March 24, 2023
HDM2-1.14
N/A
Updated the minor version number synchronously.
March 24, 2023
Configure host resource monitoring information settings
Added fields ProcessorsUsageRate and MemoryUsageRate to the response example, along with explanations for their output.
March 24, 2023
The P460 strip size now supports 16KB and 32KB.
March 28, 2023
Download BMC file
A new path, /mnt/sdmmc0p4/bsod, has been added for downloading screen recordings.
March 29, 2023
Obtain service information
Usage guidelines: The iHDT function is currently not supported by G6 AMD products.
March 29, 2023
Configure service settings
Usage guidelines: G6 AMD products currently do not support iHDT function.
March 29, 2023
Obtain detailed session information for a specified service
Usage guidelines: iHDT function is currently not supported on G6 AMD products.
March 29, 2023
Delete session information for the specified service
Usage guidelines: Function iHDT is currently not supported on G6 AMD products.
April 4, 2023
Create a Redfish session
Added an explanation for the LoginTime field.
April 4, 2023
Obtain Redfish session information
The interface description changes from querying the specified Redfish session resource information to querying the specified session resource information.
Updated the explanation of UserTag and SessionType parameters.
April 4, 2023
Obtain session collection information
The interface description has been changed to query session set resource information instead of querying Redfish session set resource information.
April 4, 2023
Delete a session
The interface specification is changed from deleting a specified Redfish session to deleting a specified session.
April 6, 2023
Other instructions
Additional instructions have been added to provide a unified explanation for Members@odata.nextLink.
V1.0
April 11, 2023
HDM2-1.15
April 11, 2023
Add a user account
Deleted the table in the output instructions and replaced it with "Return field instructions same as [Obtain user account information]".
April 11, 2023
Edit the LDAP service resource
Deleted the extra 'SSLEncryptionEnabled' field in the parameter description.
April 11, 2023
Edit an LDAP domain user group resource
Changed the interface name to "Modify specified LDAP domain user group resource."
April 11, 2023
Delete a user group resource in an LDAP domain
Changed the interface name to " Delete a user group resource in an LDAP domain".
April 11, 2023
Edit a user group resource in an AD domain
Modified the explanation of the "user_id" field to "AD domain user group ID that needs to be modified."
April 11, 2023
Delete a user group resource in an AD domain
Modified the explanation of the "user_id" field to "AD domain user group ID to be deleted."
April 12, 2023
Obtain a single user resource in an LDAP domain
Added field "Name" and modified field "MemberId" to "Id".
April 12, 2023
Obtain a single user resource in an AD domain
Changed field "MemberId" to "Id".
April 12, 2023
Export BIOS firmware
Changed the request body from "Oem.Public.ScriptName" to "ScriptName".
April 14, 2023
Modified stripe size field description: For supported storage controllers, refer to the actual specifications and obtain the supported stripe size through HDM or the BIOS.
V1.0.1
April 15, 2023
HDM2-1.15
HDM2-1.50
N/A
Refreshed the minimum version number.
April 15, 2023
In the function description, a new usage instruction has been added: "When setting the HostName, the HostNameSetupMode field value must be set to 'Manual'". In the usage instance, the HostNameSetupMode field value has been changed to "Manual."
V1.0.2
April 21, 2023
HDM2-1.16
HDM2-1.50
N/A
April 21, 2023
Modified the Step parameter description.
April 21, 2023
Modified the TPMType value in the example.
April 21, 2023
Obtain trusted password module status configuration
Changed the Type value in the example.
V1.1
April 24, 2023
HDM2-1.17
HDM2-1.50
April 24, 2023
Deleted interface.
April 24, 2023
Deleted interface.
April 24, 2023
Deleted interface.
April 24, 2023
Deleted interface.
April 24, 2023
Deleted interface.
April 24, 2023
Deleted the path for querying intelligent monitoring service information.
April 24, 2023
Edit manager resource information
Deleted query path for smart monitoring service information in the response example.
V1.1.1
April 26, 2023
HDM2-1.17
HDM2-1.51
April 26, 2023
Add a user account
Changed the field Id to an optional parameter.
V1.1.2
May 9, 2023
HDM2-1.17
HDM2-1.52
May 9, 2023
Added field ChassisPartNumber.
V1.1.3
May 22, 2023
HDM2-1.19
HDM2-1.53
May 26, 2023
The DSDCardState field has a new state called "NotSupported," and an output explanation for this field has been added.
May 26, 2023
Add a user account
Deleted the character restriction description for independent passwords in SNMPv3.
May 26, 2023
System lockout interface
Added the system lock types.
May 29, 2023
Set a BIOS password
Added details to the complexity instructions for the BIOS password.
May 29, 2023
Added kerberos interfaces added in 4.5.51-4.5.60.
Added interface.
V1.2
June 2, 2023
HDM2-1.20
HDM2-1.53
June 2, 2023
Supplemental explanations have been provided for individual field descriptions regarding NVMe display situations in Trimode configurations.
June 5, 2023
Obtain PCIe module information
Updated the description of the FirmwareVersion field.
V1.3
June 7, 2023
HDM2-1.21
HDM2-1.54
June 9, 2023
Obtain intelligent monitoring drive resource information
Added interface.
June 9, 2023
Obtain intelligent monitoring information of a drive
Added interface.
June 9, 2023
Added field RawValue.
June 9, 2023
Added field IntelligentMonitoringService.
June 9, 2023
Re-enabled this interface.
June 10, 2023
Added the RawCapacity field.
June 15, 2023
Added fields DriveUsageAlarmThreshold, MemoryUsageAlarmThreshold, and ProcessorsUsageAlarmThreshold.
June 15, 2023
Added the DriveUsageAlarmThreshold, MemoryUsageAlarmThreshold, and ProcessorsUsageAlarmThreshold fields to the response example.
June 16, 2023
Modified the description of the Content field.
June 16, 2023
Obtain module information
Revised the example by changing "Baseboard" to "Motherboard."
Deleted the SMC return value in the Oem.Public.DeviceType field.
Changed the explanation of the BMCCard to "management board" in the Oem.Public.DeviceType field.
Added fields Oem.Public.CPLD1Version and Oem.Public.CPLD2Version.
June 20, 2023
Added field Oem.Public.DeviceMaxNum.LiquidCoolerNum.
June 20, 2023
Modified the meaning of the object 'Status' to heat dissipation module overall state information.
Added the 'CoolingMedium' and 'LeakStrategy' fields.
Added the object 'FanSummary.Status' and its sub-fields, the object 'LiquidSummary' and its sub-fields, and the object 'LiquidCoolers' and its sub-fields.
June 20, 2023
Configure the heat dissipation resource information for the specified chassis
The title name is changed to set the heat dissipation resource information for the specified chassis.
The function description is changed to set the heat dissipation resource information for the specified chassis.
Added field Oem.Public.LeakStrategy.
June 20, 2023
Added fields for memory monitoring.
June 20, 2023
This interface must be re-enabled for memory monitoring.
June 20, 2023
Obtain intelligent monitoring memory resource information
Added interface.
June 21, 2023
Unified management: Add managed device resources
Modified device adding of unified management to use the task method for returning.
June 21, 2023
Added description for MemoryPageOfflineEnabled.
June 21, 2023
Added description of MemoryPageOfflineEnabled.
June 21, 2023
Added the following fields: DriveList, HistoryDriveUsageRate, PredictedDriveUsageRate, Name, FreeSpaceMB, UsageRatePercents, Time, and TotalCapacityMB.
June 21, 2023
Added the following fields: DrivesPredictDays, DrivesPredictEnabled, DrivesReportEnabled, and DrivesUsageThreshold.
June 21, 2023
Added the following fields: DrivesPredictDays, DrivesPredictEnabled, DrivesReportEnabled and DrivesUsageThreshold.
V1.3.1
June 27, 2023
HDM2-1.21
HDM2-1.55
June 27, 2023
Revised the response example format.
July 4, 2023
Added fields Storage.ClearConfiguration and Storage.ClearForeignConfiguration to the Actions object.
July 4, 2023
Added displaying of the LicenseService object.
V1.3.2
July 7, 2023
HDM2-1.22
HDM2-1.56
July 7, 2023
Obtain performance advisor recommendation information
Added interface.
July 14, 2023
Obtain task inforamtion
Corrected the string content in Messages.Trigger Condition in the document.
July 18, 2023
Added the following fields: Oem.Public.BMCFirmwareRestoreEnabled, Oem.Public.BIOSFirmwareRestoreEnabled, and Oem.Public.UpgradeTaskRestoreEnabled.
July 18, 2023
Configure update service information
Added interface.
July 18, 2023
Obtain configuration information about fast OS installation
Added interface.
July 18, 2023
Create a fast OS installation configuration service
Added interface.
V1.4
July 22, 2023
HDM2-1.22
HDM2-1.57
July 31, 2023
Redfish introduction
The Redfish specification has been updated to version 1.15.1 and the Schema version has been updated to 2020.3.
V1.5
August 10, 2023
HDM2-1.23
HDM2-1.58
August 17, 2023
Add a Kerberos user group
Added an explanation for the Id field and updated the explanations for the Name and @odata.type fields.
August 17, 2023
Obtain a user group resource from a Kerberos controller
The explanation for the newly added Id field has been provided, and the descriptions for the Name and @odata.type fields have been updated.
August 17, 2023
Added fields Oem.Public.BMCCard.ChipManufacture and Oem.Public.BMCCard.ChipModel.
August 17, 2023
Add fields PowerSupplies.Oem.Public.ManufactureDate and PowerControl.Oem.Public.MinActivePowerCount.
August 17, 2023
Add minimum options for BIOS startup.
Added field Oem.Public.NodeType.
August 17, 2023
Added minimum options for BIOS startup.
August 18, 2023
Added field LDAPCertificateVerification.
Added a new configuration item ID in each configuration.
August 18, 2023
The new field LDAPCertificateVerification has been added.
Add a new configuration item ID in each configuration.
August 18, 2023
Add field LDAPService.ImportLDAPCertificate.
August 18, 2023
Obtain the LDAP service resource
Added fields CertificateVerificationEnabled, CertificateVerificationLevel, and CertificateName.
August 19, 2023
Added fields CertificateVerificationEnabled and CertificateVerificationLevel.
August 19, 2023
Import an LDAP CA certificate
Added interface.
August 19, 2023
Added field Oem.Public.ThermalDesignPower.
August 19, 2023
Added field Oem.Public.CapacityGiB.
August 19, 2023
Added fields StorageControllers.Oem.Public.InternalPortCount and StorageControllers.Oem.Public.ExternalPortCount.
August 19, 2023
The value of the Oem.Public.FirmwareStatus field under Marvell card logic drive status is adjusted: Ready changed to Unconfigured, Online changed to Configured.
August 19, 2023
Obtain logical drive information
The field value of the Oem.Public.FirmwareStatus field under Marvell card logic drive status is adjusted: Optimal changed to Functional.
August 19, 2023
Obtain serial port redirection settings
The value of the ConnectType field is adjusted: Deleted the BMC and RAID values.
August 19, 2023
Set serial port redirection settings
Adjusted the value of the ConnectType field: Deleted the BMC and RAID values.
V1.6
September 11, 2023
HDM2-1.24
HDM2-1.60
September 15, 2023
Added field PowerControl.PowerLimit.PowerLimitEnable.
September 19, 2023
Changed the return value when the sensor threshold is unavailable from 4294967295 to null.
September 19, 2023
Modified the interface description to get performance advisor recommendation information.
September 21, 2023
Alarm report interface
Changed the name to: Fault alarm reporting message example.
V1.6.1
September 27, 2023
HDM2-1.24
HDM2-1.61
The version number is the latest HDM version at the time of manual release. For more information about supported versions, see the relevant interface's revision history.
September 27, 2023
Obtain the collection information of drive Bays
Obtain drive Bay information
Added interface.
V1.7
October 8, 2023
HDM2-1.24
HDM2-1.62
October 8, 2023
Added description of values of the Oem.Public.LeakStrategy field.
October 8, 2023
Edit a user group resource in a Kerberos controller
Deleted the "currently only supports admin users" phrase from the GroupRole field description.
October 8, 2023
Added fields Oem.Public.CPUId and Oem.Public.Slot.
October 8, 2023
Obtain platform firmware resilience configuration
Added field CPLDState.
October 8, 2023
Added field Oem.Public.SoftwareGenerationId.
October 8, 2023
Changed the field PowerControl.Oem.Public.CurrentDiskPowerWats to PowerControl.Oem.Public.CurrentDiskPowerWatts, while still supporting the original field.
October 8, 2023
The following fields are added: Oem.Public.Ipv4.StaticRoutes.Destination, SubnetMask, Gateway, Oem.Public.Ipv6StaticRoutes.Destination, PrefixLength, and Gateway.
October 8, 2023
Unsupported physical drive state added for PMC card.
October 8, 2023
Obtain firmware inventory information
Changed the firmware inventory names from CPLD and SCPLD to CPLD1 and CPLD2, but CPLD and SCPLD remain compatible.
October 8, 2023
Added field Oem.Public.TriMode and deleted the NVME values from the Protocol field.
October 8, 2023
Added field Oem.Public.PowerState.
October 8, 2023
Obtain LLDP service information
The meaning of the LldpEnabled field has been changed from "LLDP message sending enabled" to "LLDP status enabled." The values of the WorkMode field have been modified from "Rx/Tx" to "TxRx" (while still compatible with "Rx/Tx"), and a new value "Tx" has been added.
October 8, 2023
Edit LLDP service settings
The meaning of the "LldpEnabled" field has been changed from "LLDP message transmission enabled" to "LLDP state enabled", and a new "WorkMode" field has been added.
October 8, 2023
Obtain network adapter information
Added field Oem.Public.CardMode.
October 8, 2023
Added field Oem.Public.FatherPortNum
October 8, 2023
Added field WeakPasswordDictionaryName.
V1.8
October 20, 2023
HDM2-1.25
HDM2-1.63
October 20, 2023
Added field Oem.Public.EEPROMPage1.
October 20, 2023
Added fields EnclosureName and EnclosureNodeName.
V1.9
November 16, 2023
HDM2-1.65
HDM2-2.02
November 16, 2023
Report error alarms
Changed the fields description of the Oem.Public.specificProblem, Oem.Public.specificProblemID, Oem.Public.EventAssertedSeverity, and Severity fields
November 22, 2023
The field descriptions of Ipv4Addresses.AddressOrigin and Ipv6Addresses.AddressOrigin are changed from protocol type to address obtaining method.
V1.10
November 24, 2023
HDM2-1.66
HDM2-2.03
November 24, 2023
Deleted memory historical usage rate information in CUPS when FIST SMS was absent.
November 30, 2023
Added support of G6 AMD products for iHDT.
November 30, 2023
Use the restart service.
Added interface.
December 01, 2023
Added an executable operation, restart service.
December 01, 2023
Add a user account
Changed the length of the value for the UserName field from 16 characters to 32 characters.
December 02, 2023
Added Intel On Demand information.
December 02, 2023
Upload and write the Intel On Demand License activation file
Export a CPU status report
Added interface.
December 15, 2023
Added the Oem.Public. IsNVMeM2 field and the description about NVMe display for outsourced MARVELL controller configuration.
December 15, 2023
Added description about interface rates of Marvell vendor in the StorageControllers.Oem.Public.ChipManufacturer field.
Added description for interface rates of outsourced Marvell controllers in the StorageControllers.Oem.Public.SpeedGTps and StorageControllers.SpeedGbps fields.
December 15, 2023
Added the Oem.Public.MCTPEnabled field.
V1.10.1
2023-12-18
HDM2-1.68
HDM2-2.04
2024-01-03
Added the description that AMD server models do not support fields related to intelligent memory repair.
Deleted other fields and retain only the MRT value for the memory repair description field.
2024-01-03
Involves about 60 operational interfaces
Added the error node before Message.ExtendedInfo and added the code and message fields under the error node to the response body.
2024-01-05
Added the MediaErrCount and PredictiveFailureCount fields
2024-01-08
Changed the support state of the NUMAUsageLevel and RecommendedSettings fields to not supported.
2024-01-10
Added the PCIE_AUX value to the Oem.Public.PCIeCardType field.
2024-01-10
Restart CPLD
Modified the interface description to illustrate the supported CPLD types.
2024-01-10
Added the PowerControl.Oem.Public.OtherComponentsPowerWatts field.
2024-01-10
Added the Oem.Public.BackPlane.DrivesCount, Oem.Public.BackPlane.PortCount, and Oem.Public.BackPlane.Type fields.
2024-01-10
Added the Oem.Public.BDF and Oem.Public. RootBDF fields.
2024-01-10
Added the Oem.Public.ExportPasswordEnabled field.
2024-01-10
Deleted the ChangeDefaultPasswordEnabled field and added the DefaultPasswordModifyPolicy field.
2024-01-10
Add a user account
Added the Oem.Public.DefaultPasswordModifyPolicy field.
V1.10.2
2024-02-07
HDM2-1.68
HDM2-2.05
2024-01-20
Added the DiagnosticService field.
2024-01-20
Added the Oem.Public.IsSupportSimulator field.
2024-01-22
Added the Oem.Public.SlotMapping field.
2024-01-23
Added the RebuildProgress field.
2024-01-28
Added the UUID field.
2024-02-03
Obtain system diagnosis information
Configure system diagnosis settings
Added interface.
2024-02-03
Added the EventType field.
2024-02-05
Added the SnmpTrapNotification object.
2024-02-06
Obtain NTP information
Added the MinPollingInterval and MaxPollingInterval fields.
V1.10.3
2024-03-17
HDM2-1.69
HDM2-2.05
HDM3-1.06
2024-03-17
HDM3-1.06
Released for HDM3. API support depends on HDM3. The applicable products are listed.
V1.11
2024-03-19
HDM2-1.69
HDM2-2.06
2024-03-19
Revised the output description for blade server models to exclude redundancy information, the health state field, and fan resource status.
2024-03-19
Obtain drive alarm threshold information
Configure drive alarm threshold settings
Added the Life.MajorAlarmLimit field.
2024-03-20
Added the Oem.Public. RebuildProgress field.
2024-03-21
Updated the description for the MediaErrCount and PredictiveFailureCount fields.
2024-03-21
Modify chassis-related resources
Added the Oem.Public.SlotPowerSupply object.
2024-03-21
Added the FanSummary.MaxRotorCountSupported and FanSummary.RotorCount fields.
2024-03-21
Added the PowerSupplies.Oem.Public.PowerInputWatts field.
2024-03-21
Added the CardManufacturer and CardModel fields.
2024-03-21
Added the StorageControllers.CardManufacturer and StorageControllers.CardModel fields.
2024-03-21
Added the Oem.Public.ConfigurationModel field.
V1.12
2024-04-22
HDM2-1.70
HDM2-2.07
HDM3-1.08
Added the PowerControl.Oem.Public. SuggestedActivePowerCount field.
V1.13
2024-05-18
HDM2-1.71
HDM2-2.08
HDM3-1.09
Added support for LSI 9660 storage controllers and the strip size description for LSI 9660 storage controllers.
Added the Oem.Public.ChipId field.
Configure virtual media settings
Added support for http and https in the Media.ShareType and Oem.Public.ShareType fields.
Added support for http and https for connecting to virtual media.
V1.14
2024-07-23
HDM2-1.73
HDM2-2.10
HDM3-1.14
Added the Manager.NodeSwitch, Oem.Public.CurrentNodeId, and Oem.Public.MasterNodeId fields.
Perform node control on a multi-node device
Added interface.
V1.15
2024-07-25
HDM2-1.73
HDM2-2.11
HDM3-1.15
The version number is the latest HDM version at the time of release. For more information about the versions supported by a product, see the change history for the target interface and "Applicable products" in Redfish API conventions.
HDM3
HDM3 does not support wireless resource information.
HDM3
HDM3
Edit wireless settings
HDM3
Edit logical drive properties
Added the Oem.Public.BootEnable field.
HDM3
Set a BIOS password
The PowerOn option was added to the UserName field.
HDM3
Configure specified event log service resource settings
When the HostName is set, the HostNameSetupMode field is set to Manual by default.
HDM3
Obtain attributes of the specified physical drive
Added description in the change record to indicate that HDM3 supports the mediaerr count and predictive failure count fields.
HDM3
The Phytium platform does not support the Legacy mode.
HDM3
HDM3
Added the Oem.Public.IdleDriveSlots object.
HDM3
Obtain idle slot collection information
Added the interface.
HDM3
Obtain information about the specified idle slot
HDM3
Set the UID LED state of the idle slot
HDM3
V1.16
2024-08-19
HDM2-1.73
HDM2-2.11
HDM3-1.16
HDM2
Added the MemoryPageOfflineState, MemoryPageOfflineSizeKB, and MemoryLevel fields.
HDM2
HDM3
HDM3
Added the Oem.Public.RebuildProgress field to display the rebuild progress of logical drives.
HDM3
Added the Oem.Public.BDF and Oem.Public.RootBDF fields and synchronized them to HDM3.
HDM2
Added the PMR_Failed option to the Oem.Public.FirmwareStatus field for NVMe drives.
HDM3
Added the Connected.Oem.Public.ImageType and NotConnected.Oem.Public.ImageType fields.
HDM2
Obtain the list of services that can create sessions
Deleted the Telnet service field.
HDM3
HDM2
Refreshed the command format example.
HDM2
Modified the description of the Failed option in the Oem.Public.FirmwareStatus field.
HDM2
Added the OneWeekInterval field.
Added a description to the CPUUsageLevel, MemoryBusUsagelevel, and IOBusUsageLevel fields to indicate that the field displays N/A if the obtained data are insufficient.
V1.17
2024-09-11
HDM2-1.73
HDM2-2.12
HDM3-1.17
HDM2
Added the StorageControllers.Oem.Public.PSOCFirmwareVersion field.
HDM2
HDM2
Added the physical drive states supported by the 9300 controller to the Oem.Public.FirmwareStatus field.
HDM2
Added the RebuildProgress, VolumeRaidLevel, and RedundantType fields.
HDM3
Added the Oem.Public.ImageType field.
HDM3
Stop virtual media mounting
HDM3
Obtain virtual media collection information
Added the VirtualMedia.StopMount field.
V1.18
2024-09-20
HDM2-1.75
HDM2-2.12
HDM3-1.18
HDM2
Added description for LSI controllers in the RebuildProgress field.
HDM2
Modify blade model output instructions, hide redundant information and health status fields, and output fan management resource status. More versions are supported simultaneously.
V1.19
2024-10-17
HDM2-1.76
HDM2-2.13
HDM3-1.18
Edited the value for the Id field.
Obtain session information
V1.20
2024-10-28
HDM2-1.76
HDM2-2.13
HDM3-1.19
Obtain KVM information
Revised the description for the response fields.
Obtain screen snapshots
Change the blue screen description to screen description.
Delete screen snapshots
Changed the interface name.
Revised the description for the FileName field.
Manually take screen snapshots
Changed the stripe size, capacity description, physical drive cache policy, and initialization type for 3SNIC storage controller.
Obtain the system software inventory information
Added the OSHostName field.
Edited the description for the VolumeRaidLevel field.
Changed the value for the NumDrivePerSpan field.
V1.21
2024-11-05
HDM2-1.77
HDM2-2.14
HDM3-1.20
Updated the response example
Added the Oem.Public.MaxSpeed field.
Edited the field description
Obtain the detailed progress of configuration clearance
Edited the description for the ClearStatus field.
V1.22
2024-11-26
HDM2-1.77
HDM2-2.15
HDM3-1.21
HDM3-2.01
Obtain GPU information
Added the GPU.PowerCapacityWatts field.
Added the TDPWatts field.
V1.23
2024-12-16
HDM2-1.78
HDM2-2.15
HDM3-1.21
HDM3-2.01
Added the Oem.Public.DNS.IPv4DNS.DNSAutoReg and Oem.Public.DNS.IPv6DNS.DNSAutoReg fields.
Added the Oem.Public.DNS.IPv4DNS. DNSAutoReg and Oem.Public.DNS.IPv6DNS. DNSAutoReg fields. These fields are available only when the DNS mode is set to manual.
V1.24
2024-12-24
HDM2-1.78
HDM2-2.16
HDM3-1.23
HDM3-2.02
Added the description for the ServerPort and TLSEnabled fields.
Added the TopoType field.
V1.25
2025-01-14
HDM2-1.79
HDM2-2.16
HDM3-1.24
HDM3-2.02
Added the remarks.
Added the Oem.Public.BiosCurrentRunningPartition field.
Update firmware
Added the Oem.Public.BiosFlash field in the request body.
V1.26
2025-01-24
HDM2-1.80
HDM2-2.17
HDM3-1.24
HDM3-2.03
Revised the change history.
Deleted the LinkStatus field in response field description.
Revised the example.
Configure network port information
Added the remarks.
Add a user account
Added the NPARPort field.
Added the Retimer field.
Revised the request.
Added the description for the SenderUserName field.
Added the description for the Media.UserName field.
Added the description for the read-only community and write/read community.
V1.27
2025-02-19
HDM2-1.80
HDM2-2.17
HDM3-1.25
HDM3-2.04
Added description for the stripe size value.
Revised the version in the change history.
V1.2x
2025-03-14
HDM2-1.8x
HDM2-2.1x
HDM3-1.2x
HDM3-2.0x
Added the Oem.Public.PUID field.
Revision records· 3
Introduction· 1
Prerequisites· 1
Redfish API conventions· 1
HTTPS methods and URI format 1
OData properties· 1
Status codes· 2
Field status· 2
API privilege modules· 3
Resource description· 5
Description for special field values· 5
Applicable products· 6
Others· 6
Recommended API tools· 6
API operations· 7
Operations on public fixed resources· 7
Obtain Redfish version information· 7
Obtain root service information· 8
Obtain metadata document information· 12
Obtain Schema collection information· 14
Obtain the registry address for a single Schema file· 19
Obtain message registry collection information· 21
Obtain message registry information· 23
Obtain OData service document information· 25
Operations on chassis resources· 27
Obtain the chassis resource ID of the server 27
Obtain server information by its chassis resource ID·· 29
Modify chassis-related resources· 37
Obtain physical drive collection information· 43
Obtain physical drive information· 45
Obtain available logical disks when creating a hot spare drive on specified physical drive· 58
Set the physical drive state· 60
Obtain idle slot collection information· 71
Obtain information about the specified idle slot 73
Set the UID LED state of the idle slot 74
Obtain the collection information of drive Bays· 76
Obtain drive Bay information· 78
Obtain thermal properties· 80
Configure the heat dissipation resource information for the specified chassis· 109
Obtain air inlet temperature history resource information· 114
Obtain power information· 116
Configure power settings· 126
Obtain power recovery policy information· 138
Set power recovery policy· 139
Obtain information about CPU power saving· 141
Configure CPU power saving settings· 143
Obtain information about historical power resource· 145
Obtain sensor type collection information· 147
Obtain information of sensor list for a specified type· 149
Obtain historical information about a single sensor resource· 152
Recalculate highest historical temperature information for sensor 155
Obtain module collection information· 159
Obtain module information· 161
Obtain PCIe module collection information· 172
Obtain PCIe module information· 174
Obtain PCIe function information· 180
Obtain network adapter collection information· 183
Obtain network adapter information· 185
Obtain network port collection information· 198
Obtain network port information· 199
Configure network port settings· 204
Obtain drive alarm threshold information· 206
Configure drive alarm threshold settings· 209
Operations on system resources· 214
Obtain system collection information· 214
Obtain system resource information· 215
Configure system resource properties· 227
Obtain boot self-test order 235
Obtain information about boot self-test code collection resource· 237
Obtain information about specified boot self-test code· 239
Perform a power operation· 240
Restart CPLD·· 243
Obtain processor collection information· 245
Set alarm threshold for processor usage· 247
Obtain processor information· 248
Obtain memory collection information· 254
Obtain memory information· 256
Obtain storage controller collection information· 260
Obtain storage controller information· 262
Modify storage controller information· 270
Clear Foreign status of physical drives in specified storage controller 275
Clear all configurations for a specified storage controller 277
Obtain logical drive collection information· 279
Create a logical drive· 280
Delete a logical drive· 292
Obtain logical drive information· 294
Edit logical drive properties· 303
Obtain BIOS setting collection information· 306
Obtain pending BIOS setting information· 309
Configure a BIOS setting· 310
Set a BIOS password· 312
Restore the default BIOS settings· 315
Obtain BIOS detailed setting rules information· 317
Create a KVM resource· 319
Obtain event log service collection information· 321
Obtain event log service resource information· 322
Configure specified event log service resource settings· 325
Obtain event log entry collection information· 327
Obtain event log entry resource information· 334
Export event log entry information· 337
Clear event log entry information· 339
Obtain GPU information· 341
Configure GPU information· 346
Obtain information about security control panel 349
Set security control panel information· 351
Obtain information about network interface collection resource· 354
Obtain information of the specified network interface resource· 355
Obtain network port collection information· 357
Clear configuration· 359
Download clear configuration reports· 361
Obtain the detailed progress of configuration clearance· 362
Obtain the system software inventory information· 366
Clear inactive BIOS configurations· 368
Obtain host status migration information· 370
Obtain information about host resource monitoring· 375
Configure host resource monitoring information settings· 379
Obtain information about CPU historical usage rate resource· 382
Obtain information about memory historical usage rate resource· 384
Obtain information about GPU historical usage rate resource· 386
Obtain information about network bandwidth historical send/receive speed resource· 388
Obtain information about disk historical usage rate resource· 390
Obtain information about disk IO performance historical data· 392
Obtain information about disk SVCTM historical data· 395
Obtain information about NFS server read/write rate historical data· 397
Obtain information about NFS client read/write rate historical data· 399
Obtain information about system load historical data· 401
Obtain performance advisor recommendation information· 403
Upload and write the Intel On Demand License activation file· 407
Export the CPU status report 409
Operations on manager resources· 411
Obtain manager collection information· 411
Obtain manager resource information· 413
Edit manager resource information· 422
Obtain NTP information· 427
Configure NTP settings· 429
Obtain SNMP information· 431
Configure SNMP settings· 436
Perform SNMP trap testing· 445
Obtain SMTP information· 447
Configure SMTP settings· 451
Perform SMTP testing· 458
Obtain information for SMTP trap testing· 460
Obtain syslog information· 461
Configure syslog settings· 466
Perform SYSLOG trap testing· 472
Import the syslog root certificate· 474
Import a local certificate· 477
Import a private key certificate· 479
Obtain service information· 482
Configure service settings· 493
Use the restart service· 500
Obtain the list of services that can create sessions· 503
Obtain detailed session information for a specified service· 505
Delete session information for the specified service· 507
Obtain energy-saving service information· 509
Configure energy-saving service settings· 511
Restart HDM·· 513
Restore BMC factory settings· 515
Obtain network port collection information· 517
Set the network port mode· 519
Obtain shared network port information· 521
Configure shared network port settings· 524
Obtain network port information· 527
Configure network port settings· 534
Obtain virtual media collection information· 547
Obtain virtual media information· 549
Obtain virtual media connection status· 552
Obtain virtual media configuration· 555
Configure virtual media settings· 557
Connect to virtual media· 562
Disconnect from virtual media· 568
Stop virtual media mounting· 570
Obtain all operation log collection information· 572
Obtain log service collection information· 574
Obtain log service information· 576
Obtain log entry collection information· 578
Obtain log entry information· 580
Export operation log information· 582
Clear operation log information· 585
Collect SDS log entry information· 587
Download BMC file· 590
Obtain VNC information· 591
Edit VNC settings· 592
Obtain KVM information· 594
Edit KVM settings· 596
Obtain serial port collection information· 598
Obtain serial port information· 599
Obtain LLDP service information· 602
Edit LLDP service settings· 604
Obtain wireless information· 606
Edit wireless settings· 609
Import the BIOS, BMC, and RAID controller settings· 613
Export the BIOS, BMC, and RAID controller settings· 615
Obtain trusted password module status configuration· 618
Obtain firewall configuration information· 619
Add firewall rule settings· 623
Edit firewall rule settings· 626
Delete firewall configuration rule· 631
Obtain server security service information· 634
View SSL certificate resource information· 636
Generate SSL certificate· 639
Import SSL certificate· 642
Obtain login security information feature· 645
Set login security information feature· 646
Obtain platform firmware resilience configuration· 648
Configure platform firmware resilience settings· 649
Obtain serial port redirection settings· 651
Set serial port redirection settings· 653
Obtain screen snapshots· 654
Delete screen snapshots· 656
Obtain video playback· 658
Obtain advanced video playback configuration· 660
Set advanced video playback configuration· 661
Play video playback· 663
Export video playback· 665
Delete video playback· 667
Unified management: Obtain managed device collection resources· 669
Unified management: Add managed device resources· 672
Unified management: Delete managed device resources· 674
Unified management: Host power operation· 677
Obtain service USB drive resource information· 679
Set service USB drive resource information· 681
Upload BMC file· 683
Reset the SD card· 685
Obtain security dashboard information· 687
Set security dashboard information· 694
Obtain system lock resource information· 699
Modify system lock resource information· 700
Obtain intelligent monitoring service information· 702
Configure intelligent monitoring service information· 705
Obtain intelligent monitoring drive resource information· 708
Obtain intelligent monitoring information of a drive· 712
Obtain intelligent monitoring memory resource information· 720
Obtain configuration information about fast OS installation· 722
Create a fast OS installation configuration service· 724
Obtain system diagnosis information· 726
Configure system diagnosis settings· 730
Perform node control on a multi-node device· 732
Manually take screen snapshots· 734
Operations on account service resources· 736
Obtain account service information· 736
Edit account service settings· 741
Obtain user account collection information· 745
Obtain user account information· 747
Add a user account 750
Edit user account settings· 754
Delete a user account 758
Obtain role collection information· 760
Obtain role information· 762
Edit role settings· 765
Obtain role names· 767
Edit a role name· 769
Obtain the LDAP service resource· 771
Edit the LDAP service resource· 774
Import an LDAP CA certificate· 776
Obtain LDAP domain controller collection resource· 778
Obtain the user collection resource in an LDAP domain· 780
Obtain a single user resource in an LDAP domain· 781
Add an LDAP domain user group· 783
Edit an LDAP domain user group resource· 785
Delete a user group resource in an LDAP domain· 787
Obtain the AD service resource· 789
Edit the AD service resource· 791
Obtain AD domain controller collection resource· 793
Obtain the user collection resource in an AD domain· 794
Obtain a single user resource in an AD domain· 796
Add an AD domain user group· 798
Edit a user group resource in an AD domain· 800
Delete a user group resource in an AD domain· 802
Obtain user certificate management service information· 804
Set certificate management service information· 806
Obtain user root certificate list 808
Obtain information of a specific root certificate· 809
Import a root certificate file· 812
Delete a root certificate file· 814
Obtain the client certificate list bound to a root certificate· 816
Import a client certificate file· 818
Obtain information of a client certificate· 820
Delete a client certificate· 822
Obtain the user list bindable to a client certificate· 824
Bind a user to a client certificate· 826
Unbind a client certificate from a user 828
Obtain SSH public key list information· 831
Obtain information of an SSH public key· 832
Import SSH public keys· 834
Delete an SSH public key· 836
Obtain the list of SSH public key-bindable users· 838
Bind an SSH public key to a user 840
Unbind an SSH public key from a user 842
Import a weak password dictionary· 844
Export a weak password dictionary· 847
Obtain the Kerberos service resource· 850
Edit the Kerberos service resource· 851
Obtain the Kerberos collection resource· 853
Obtain the user group collection resource in a Kerberos controller 854
Edit the user group collection resource in a Kerberos controller 856
Upload a keytab file· 858
Add a Kerberos user group· 860
Obtain a user group resource from a Kerberos controller 863
Edit a user group resource in a Kerberos controller 865
Delete a Kerberos user group resource· 866
Operations on session service resources· 869
Create a Redfish session· 869
Obtain session collection information· 872
Obtain session information· 874
Delete a session· 876
Obtain Redfish session information· 878
Edit Redfish session settings· 880
Operations on update service resources· 882
Obtain update service information· 882
Configure update service information· 885
Obtain firmware inventory collection information· 888
Obtain firmware inventory information· 890
Obtain image pool list 892
Delete an image in an image pool 894
Update firmware· 896
Obtain firmware inventory information· 899
Obtain information of a firmware inventory· 901
Obtain firmware package collection information· 903
Uninstall a firmware package· 905
Export BIOS firmware· 907
Operations on task service resources· 909
Obtain task service information· 909
Obtain task collection information· 911
Obtain task inforamtion· 914
Delete a task· 916
Obtain server scheduled task list information· 918
Obtain information of a server scheduled task· 920
Edit a server scheduled task· 922
Operations on event service resources· 925
Obtain event collection information· 925
Create an event subscription· 927
Obtain event subscription collection information· 930
Obtain event subscription information· 931
Edit an event subscription· 934
Delete an event subscription· 936
Report error alarms· 937
Simulate reporting test events· 941
Operations on license service resources· 943
Obtain license service information· 943
Obtain license resource collection information· 945
Obtain information of a license resource· 946
Install the license activation file· 948
Export a license file· 951
Uninstall the license activation file· 953
Examples· 955
Use Postman to obtain information about Redfish root service resources· 955
Appendix· 957
Parameters· 957
Perform filtering and pagination ($skip, $top) 958
Expand hyperlinks ($expand) 958
Obtain the list of fields ($select) 959
Introduction
Redfish® is an open industry standard defined by DMTF to provide simple and secure management of modern scalable hardware for converged, hybrid IT and software-defined data centers. It is replacing IPMI as the next-generation server management protocol.
Redfish provides HTTP- and HTTPS-based RESTful APIs for device management. Each HTTP or HTTPS operation submits a resource request or retrieves a resource response encoded in UTF-8 in JSON format.
Hardware device management (HDM) is an H3C-proprietary remote server management system. It supports managing servers through Redfish to streamline server configuration, monitoring, and remote control.
This document is applicable only to H3C server models.
This document was created based on Redfish version 1.15.1 and Schema version 2020.3.
An API operation contains an HTTPS method and a URI path. The available HTTPS methods include:
·     GET—Retrieves data from the server.
·     POST—Creates a resource or invokes an action.
·     PATCHUpdates or modifies an existing resource.
·     DELETERemoves a resource.
The URI path uses the https://device_ip/redfish/v1/path format, where:
·     https://device_ipSpecifies the URI address. The device_ip argument represents the HDM management IP address of the server to access.
·     /redfish/v1/Specifies Redfish service and version. This document was created based on Redfish v1.
·     /pathSpecifies the resource ID.
OData properties
The response displays resource information by using OData properties as shown in Table 1.
Table 1 Available OData properties
OData property
@odata.context
Specifies the context URL.
@odata.id
Specifies the unique identifier of the resource.
@odata.type
Specifies the type of a resource, an absolute URL.
Status codes
Status code
200 OK
The request was successfully completed.
201 Created
A request that created a new resource completed successfully.
202 Accepted
The request has been accepted for processing, but the processing has not been completed.
204 No Content
The request succeeded, but no content is being returned in the body of the response.
400 Bad Request
The request parameter could not be processed because it contains missing or invalid information. An extended error shall be returned in the response.
401 Unauthorized
The authentication credentials included with this request are missing or invalid. (User privileges)
403 Forbidden
The server recognized the credentials in the request, but those credentials do not possess authorization to perform this request. (API privileges)
404 Not Found
The request specified a URI of a resource that does not exist.
405 Method Not Allowed
The HTTP verb specified in the request is not supported for this request URI.
409 Conflict
A creation or update request could not be completed, because it would cause a conflict in the current state of the resources supported by the platform.
412 Precondition Failed
The precondition (such as If-Match headers) check failed.
428 Precondition Missed
The precondition was missing.
500 Internal Server Error
The server encountered an unexpected condition that prevented it from fulfilling the request. For example, a timeout error occurrred.
501 Not Implemented
The server does not (currently) support the functionality required to fulfill the request.
503 Service Unavailable
The server is temporarily overloaded and is unable to process the request.
507 Insufficient Storage
The server cannot store content necessary to complete the request.
Field status
Data type
Value
Status.State
String
Device enabling status. Supported options:
·     Absent—The device does not exist or has not been detected.
·     Enabled.
·     UnavailableOffline—The device has resources, but the resources are not available. For example:
¡     The system cannot obtain the out-of-band information about a present storage controller.
¡     The system cannot obtain storage controller information about a present drive.
¡     The storage overall status is powered off.)
·     DisabledThe device is faulty or disabled. For example the memory is disabled.
·     StartingThe BIOS is being initialized.
·     StandbyOffline—The device is present, but requires external activation.
Status.Health
String
Health status. Supported options:
·     OKThe device is in normal state.
·     WarningA minor alarm occurred on the device.
·     CriticalA major or critical alarm occurred on the device.
This field indicates the health status of the device only when the device is enabled. If the device enabling status is disabled or absent, this field is fixed to OK.
Status.HealthRollup
String
HealthRollup status. Supported options:
Status.Oem.Public.Severity
String
Custom health status levels. Supported options:
·     Informational—The device is in normal state.
·     Minor—A minor alarm occurred on the device.
·     Major—A major alarm occurred on the device.
·     CriticalA critical alarm occurred on the device.
HDM 2.xx.xx provides group-based API access control. The APIs are assigned to groups, with each group called an API privilege module. You can assign API privileges to user roles on a per-module basis.
Table 2 API privilege modules
Module
API privileges
ConfigureUsers
Includes local user configuration, LDAP user configuration, AD user configuration, OTP authentication, certificate authentication, SSH key management, license management, secure erasure, configuration import and export, and unified control.
ConfigureComponents
Includes asset tag configuration, network configuration, LLDP configuration, wireless management, NTP configuration, SNMP configuration, alarm configuration (SMTP, trap, and syslog), event log policy settings, operation log clearing, video playback, and security bezel configuration.
OemKvm
Includes storage management, system resource monitoring settings, BIOS settings, KVM (excluding power control and image mounting), H5 KVM (excluding power control and image mounting), VNC password management, system boot options, UID LED control, SOL serial settings, and MCA policy access.
OemVmm
Includes virtual media configuration, KVM image mounting, and H5 KVM image mounting.
OemSecurityMgmt
Includes service configuration, firewall, SSL certificate, PFR firmware protection, and login security information configuration.
OemPowerControl
Includes power supply management, NMI control, physical power button control, fan configuration, and intelligent energy-saving.
OemDiagnosis
Includes clearing event logs, package management, firmware updates, firmware library management, scheduled task management, restoring HDM configuration, restarting HDM, restarting CPLD, and service USB drive settings.
ConfigureSelf
Includes configuring user passwords (for local users only).
Login
Includes viewing typical HDM information, excluding event logs, operation logs, or SDS log download. Only the Administrator role can view information of other users.
OemSystemAudit
Includes the operation permissions to view or save event logs, operation logs, and one-click collection and download of SDS logs.
ConfigureManager
(Not supported.) Includes configuring manager resources.
Table 3 User role privilege modules
Module
Administrator
Login
ConfigureSelf
ConfigureUsers
ConfigureComponents
OemKvm
OemVmm
OemSecurityMgmt
OemPowerControl
OemDiagnosis
OemSystemAudit
Operator
Login
ConfigureSelf
ConfigureComponents
OemKvm
OemVmm
OemSecurityMgmt
OemPowerControl
OemSystemAudit
User
Login
ConfigureSelf
NoAccess
No access privilege. This indicates that users cannot access or view specific content, files, or systems.
CustomRole1
Login
All privileges can be configured except ConfigureUsers.
CustomRole2
Login
CustomRole3
Login
CustomRole4
Login
CustomRole5
Login
Resources
Chassis
Used to manage physical drives, power supplies, fans, UID LED, PCIe modules, and network adapters.
Systems
Used to manage components such as processors, memory, storage controllers, logical drives, and GPUs, and resources such as BIOS, KVM, and event log.
Managers
Used to manage BMC network settings (NTP, SNMP, LLDP, and syslog for example), security settings (certificate and services), operation log, and virtual media.
AccountService
Used to manage BMC users.
SessionService
Used to manage BMC sessions.
UpdateService
Used to manage firmware update for BMC.
TaskService
Used to manage BMC tasks.
EventService
Used to manage alarm event report for BMC.
The following special field values are supported in responses:
·     ""—Indicates that the value has been successfully obtained and the content is an empty string, which is also displayed normally on the Web interface.
·     N/A—Not available, which indicates that the field is retrievable, but currently unavailable. The Web interface displays N/A normally.
·     NULL—Indicates that the field is not supported. The Web interface does not display the field content or the field name.
·     0xFFFFFFFF—Indicates that the value should have been obtained but was not obtained. The Web interface displays N/A and Redfish displays 4294967295 (=0xFFFFFFFF).
Field values N/A (for the string type) and 0xFFFFFFFF (for the integer type) are used for retrievable fields that cannot be retrieved due to an exception:
·     An API error occurred, but the Redfish API still needs to display the field content.
·     Values agreed upon with the back end to represent exceptions.
For features that are disabled, Redfish API will use the values returned by the back end. For example, when IPv6 is disabled, Redfish API will return an empty string for the subnet mask and 0 for the subnet prefix length.
Applicable products
This document is applicable to all H3C server models. For more information about the applicable products, see H3C Servers HDM2 User Guide.
The Redfish commands for HDM3 are developed based on HDM2-1.65. If no additional revision records are described, the Redfish features after this HDM2 version is not supported by default or is not yet developed in HDM3. Make sure you are aware of the command instructions in subsequent new versions.
Others
The following conventions are used in Redfish API:
·     Oem.Public.CompletionCode: Indicates the CC value returned by this interface.
·     Oem.Public.Description: Indicates the description of the interface execution result. This field is fixed to Success by default.
·     RSAEncryptionEnabled: Indicates that the Web interface uses RSA encryption and the value does not need to be displayed when obtained.
·     Members@odata.nextLink: Indicates the link to the next page when the number of collection resource members exceeds 100 and pagination is required.
·     The time format is 2019-02-14T20:21:36+08:00.
·     The time zone supports only whole hour or half-hour increments.
·     "Content":
¡     File transfer protocols—SFTP, HTTPS, HTTP, NFS, CIFS, and TFTP.
¡     The operation paths do not support Chinese characters.
¡     The field length cannot exceed 1024 characters. Chinese characters are not supported and the following special characters are supported: @!$^&()_+.;[]{}-=~`
¡     Only /tmp/web/ is supported locally.
¡     The maximum total length of the directory and file name for the TFTP protocol is 240 characters.
Use either of the following API tools to make API calls:
·     (Recommended) Postman.
To download Postman, access https://www.getpostman.com/downloads/.
·     HttpRequester for Firefox.
Install the httprequester-2.2-fx.xpi plugin in the Firefox browser. Make sure the browser version is earlier than 56.0b3 (64-bit).
API operations
Obtain Redfish version information from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish
Request header:
N/A
Request body:
N/A
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
Method and URL:
GET https://192.168.18.18/redfish
Request header:
N/A
Request body:
N/A
Response:
    "Oem": {
        "Public": {
            "CompletionCode": 0,
            "Description": "Success"
    "v1": "/redfish/v1/"
Response code: 200
Response field description
Data type
v1
String
Redfish version information.
The server returns status code 200 for a successful operation.
Obtain root service information from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1
Request header:
N/A
Request body:
N/A
Parameter
Value
device_ip
Method and URL:
GET https://192.168.18.18/redfish/v1
Request header:
N/A
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1",
    "@odata.type": "#ServiceRoot.v1_9_0.ServiceRoot",
    "AccountService": {
        "@odata.id": "/redfish/v1/AccountService"
    "Chassis": {
        "@odata.id": "/redfish/v1/Chassis"
    "EventService": {
        "@odata.id": "/redfish/v1/EventService"
    "Id": "RootService",
    "JsonSchemas": {
        "@odata.id": "/redfish/v1/JsonSchemas"
    "LicenseService": {
        "@odata.id": "/redfish/v1/LicenseService"
    "Links": {
        "Sessions": {
            "@odata.id": "/redfish/v1/SessionService/Sessions"
    "Managers": {
        "@odata.id": "/redfish/v1/Managers"
    "Name": "Root Service",
    "Oem": {
        "Public": {
            "Description": "Success",
            "HostName": "HDM222235A022B2B22",
            "Manufacturer": "H3C",
            "Model": "RS32M2C9S",
            "SerialNumber": "222235A022B2B22",
            "SoftwareGenerationId":"2"
    "ProtocolFeaturesSupported": {
        "DeepOperations": {
            "DeepPATCH": false,
            "DeepPOST": false
        "ExcerptQuery": false,
        "ExpandQuery": {
            "ExpandAll": true,
            "Levels": true,
            "Links": true,
            "MaxLevels": 5,
            "NoLinks": true
        "FilterQuery": false,
        "OnlyMemberQuery": false,
        "SelectQuery": true
    "RedfishVersion": "1.15.1",
    "Registries": {
        "@odata.id": "/redfish/v1/Registries"
    "SessionService": {
        "@odata.id": "/redfish/v1/SessionService"
    "Systems": {
        "@odata.id": "/redfish/v1/Systems"
    "Tasks": {
        "@odata.id": "/redfish/v1/TaskService"
    "UUID": "36538512-d02a-1000-02f2-aabbccd24718",
    "UpdateService": {
        "@odata.id": "/redfish/v1/UpdateService"
Response code: 200
Data type
@odata.context
String
OData description of the root service resource model.
@odata.id
String
Link to the root service resource.
@odata.type
String
Type of the root service resource.
Id
String
ID of the root service resource.
Name
String
Name of the root service resource.
RedfishVersion
String
Redfish version.
UUID
String
Universally unique identifier (UUID) of the device.
AccountService
Object
Account service resource.
Chassis
Object
Chassis information resource.
EventService
Object
Event service resource.
LicenseService
Object
License service resource.
Links
Links to resources.
Sessions
Object
Session collection resource.
Managers
Object
Manager collection resource.
Registries
Object
Message registry collection resource.
SessionService
Object
Session service collection resource.
Systems
Object
System collection resource.
Tasks
Object
Task collection resource.
UpdateService
Object
Update service collection resource.
JsonSchemas
Object
Json-Schema file collection resource.
Oem.Public.HostName
String
Host name of a system resource.
Oem.Public.Manufacturer
String
Manufacturer.
Oem.Public.Model
String
Model.
Oem.Public.SerialNumber
String
Product serial number
String
BMC software generation information
@odata.id
String
Link to a resource.
Object
Protocol extension resources.
ProtocolFeaturesSupported.DeepOperations
Object
Deep operations supported by the protocol.
ProtocolFeaturesSupported.DeepOperations.DeepPATCH
Boolean
Whether the protocol supports deep PATCH operations.
ProtocolFeaturesSupported.DeepOperations.DeepPOST
Boolean
Whether the protocol supports deep POST operations.
ProtocolFeaturesSupported.ExcerptQuery
Boolean
Whether the excerpt query parameter is supported.
ProtocolFeaturesSupported.ExpandQuery
Object
Contains information about the protocol using the $expand query parameter.
ProtocolFeaturesSupported.ExpandQuery.ExpandAll
Boolean
Whether asterisks (*) are supported for the $expand query parameter.
ProtocolFeaturesSupported.ExpandQuery.Levels
Boolean
Whether the $levels query parameter is supported for expand query.
ProtocolFeaturesSupported.ExpandQuery.Links
Boolean
Whether tilde signs (~) are supported for the $expand query parameter.
ProtocolFeaturesSupported.ExpandQuery.MaxLevels
Integer
Maximum supported $levels parameter for $expand.
ProtocolFeaturesSupported.ExpandQuery.NoLinks
Boolean
Whether dots (.) are supported for the $expand query parameter.
ProtocolFeaturesSupported.FilterQuery
Boolean
Whether the filter query feature is supported.
ProtocolFeaturesSupported.OnlyMemberQuery
Boolean
Whether the only query feature is supported.
ProtocolFeaturesSupported.SelectQuery
Boolean
Whether the select query feature is supported.
Change history
Version
Change description
HDM2-1.61
Added the Oem.Public.SoftwareGenerationId field.
HDM2-1.55
Added the LicenseService object.
Obtain information about all metadata documents from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip//redfish/v1/$metadata
Request header:
N/A
Request body:
N/A
Parameter
Value
device_ip
Method and URL:
GET https://192.168.18.18/redfish/v1/$metadata
Request header:
Content-Type:application/json
Request body:
N/A
Response:
<?xml version="1.0" encoding="UTF-8"?>
<edmx:Edmx xmlns:edmx="http://docs.oasis-open.org/odata/ns/edmx" Version="4.0">
    <edmx:Reference Uri="/redfish/v1/schema/AccountService_v1.xml">
        <edmx:Include Namespace="AccountService"/>
        <edmx:Include Namespace="AccountService.v1_0_0"/>
        <edmx:Include Namespace="AccountService.v1_0_2"/>
        <edmx:Include Namespace="AccountService.v1_0_3"/>
        <edmx:Include Namespace="AccountService.v1_0_4"/>
        <edmx:Include Namespace="AccountService.v1_0_5"/>
        <edmx:Include Namespace="AccountService.v1_0_6"/>
        <edmx:Include Namespace="AccountService.v1_0_7"/>
        <edmx:Include Namespace="AccountService.v1_0_8"/>
        <edmx:Include Namespace="AccountService.v1_0_9"/>
        <edmx:Include Namespace="AccountService.v1_0_10"/>
        <edmx:Include Namespace="AccountService.v1_0_11"/>
    <edmx:Reference Uri="/redfish/v1/schema/VLanNetworkInterface_v1.xml">
        <edmx:Include Namespace="VLanNetworkInterface"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_0_0"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_0_1"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_0_2"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_0_3"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_0_4"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_0_5"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_0_6"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_0_7"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_0_8"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_0_9"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_1_0"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_1_1"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_1_2"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_1_3"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_1_4"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_1_5"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_2_0"/>
        <edmx:Include Namespace="VLanNetworkInterface.v1_3_0"/>
    </edmx:Reference>
    <edmx:Reference Uri="/redfish/v1/schema/VLanNetworkInterfaceCollection_v1.xml">
        <edmx:Include Namespace="VLanNetworkInterfaceCollection"/>
    </edmx:Reference>
    <edmx:DataServices>
        <Schema xmlns="http://docs.oasis-open.org/odata/ns/edm" Namespace="Service">
            <EntityContainer Name="Service" Extends="ServiceRoot.v1_0_0.ServiceContainer"/>
        </Schema>
    </edmx:DataServices>
    <edmx:Reference Uri="/redfish/v1/schema/OemManager_v1.xml">
        <edmx:Include Namespace="OemManager"/>
    </edmx:Reference>
    <edmx:Reference Uri="/redfish/v1/schema/OemComputerSystem_v1.xml">
        <edmx:Include Namespace="OemComputerSystem"/>
    </edmx:Reference>
    <edmx:Reference Uri="/redfish/v1/schema/OemVirtualMedia_v1.xml">
        <edmx:Include Namespace="OemVirtualMedia"/>
        <edmx:Include Namespace="OemVirtualMedia.v1_0_0"/>
    </edmx:Reference>
    <edmx:Reference Uri="/redfish/v1/schema/OemAccountService_v1.xml">
        <edmx:Include Namespace="OemAccountService"/>
        <edmx:Include Namespace="OemAccountService.v1_0_0"/>
    </edmx:Reference>
    <edmx:Reference Uri="/redfish/v1/schema/OemSession_v1.xml">
        <edmx:Include Namespace="OemSession"/>
        <edmx:Include Namespace="OemSession.v1_0_0"/>
    </edmx:Reference>
</edmx:Edmx>
Response code: 200
Obtain information about Schemas of all resources from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip//redfish/v1/JsonSchemas
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
Method and URL:
GET https://192.168.18.18/redfish/v1/JsonSchemas
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/JsonSchemas",
    "@odata.context": "/redfish/v1/$metadata#JsonSchemaFileCollection.JsonSchemaFileCollection",
    "@odata.type": "#JsonSchemaFileCollection.JsonSchemaFileCollection",
    "Name": "JsonSchemaFile Collection",
    "Description": "Collection of JsonSchemaFiles",
    "Members@odata.count": 58,
    "Members": [
            "@odata.id": "/redfish/v1/JsonSchemas/AccountService"
            "@odata.id": "/redfish/v1/JsonSchemas/ActionInfo"
            "@odata.id": "/redfish/v1/JsonSchemas/Assembly"
            "@odata.id": "/redfish/v1/JsonSchemas/AttributeRegistry"
            "@odata.id": "/redfish/v1/JsonSchemas/Bios"
            "@odata.id": "/redfish/v1/JsonSchemas/Certificate"
            "@odata.id": "/redfish/v1/JsonSchemas/CertificateLocations"
            "@odata.id": "/redfish/v1/JsonSchemas/CertificateService"
            "@odata.id": "/redfish/v1/JsonSchemas/Chassis"
            "@odata.id": "/redfish/v1/JsonSchemas/ComputerSystem"
            "@odata.id": "/redfish/v1/JsonSchemas/Drive"
            "@odata.id": "/redfish/v1/JsonSchemas/EthernetInterface"
            "@odata.id": "/redfish/v1/JsonSchemas/Event"
            "@odata.id": "/redfish/v1/JsonSchemas/EventDestination"
            "@odata.id": "/redfish/v1/JsonSchemas/EventService"
            "@odata.id": "/redfish/v1/JsonSchemas/IPAddresses"
            "@odata.id": "/redfish/v1/JsonSchemas/JsonSchemaFile"
            "@odata.id": "/redfish/v1/JsonSchemas/LogEntry"
            "@odata.id": "/redfish/v1/JsonSchemas/LogService"
            "@odata.id": "/redfish/v1/JsonSchemas/Manager"
            "@odata.id": "/redfish/v1/JsonSchemas/ManagerAccount"
            "@odata.id": "/redfish/v1/JsonSchemas/ManagerNetworkProtocol"
            "@odata.id": "/redfish/v1/JsonSchemas/Memory"
            "@odata.id": "/redfish/v1/JsonSchemas/Message"
            "@odata.id": "/redfish/v1/JsonSchemas/MessageRegistry"
            "@odata.id": "/redfish/v1/JsonSchemas/MessageRegistryFile"
            "@odata.id": "/redfish/v1/JsonSchemas/MetricDefinition"
            "@odata.id": "/redfish/v1/JsonSchemas/MetricReport"
            "@odata.id": "/redfish/v1/JsonSchemas/MetricReportDefinition"
            "@odata.id": "/redfish/v1/JsonSchemas/OperatingConfig"
            "@odata.id": "/redfish/v1/JsonSchemas/PCIeDevice"
            "@odata.id": "/redfish/v1/JsonSchemas/PCIeFunction"
            "@odata.id": "/redfish/v1/JsonSchemas/Power"
            "@odata.id": "/redfish/v1/JsonSchemas/Privileges"
            "@odata.id": "/redfish/v1/JsonSchemas/Processor"
            "@odata.id": "/redfish/v1/JsonSchemas/Resource"
            "@odata.id": "/redfish/v1/JsonSchemas/Role"
            "@odata.id": "/redfish/v1/JsonSchemas/Sensor"
            "@odata.id": "/redfish/v1/JsonSchemas/ServiceRoot"
            "@odata.id": "/redfish/v1/JsonSchemas/Session"
            "@odata.id": "/redfish/v1/JsonSchemas/SessionService"
            "@odata.id": "/redfish/v1/JsonSchemas/Settings"
            "@odata.id": "/redfish/v1/JsonSchemas/SoftwareInventory"
            "@odata.id": "/redfish/v1/JsonSchemas/Storage"
            "@odata.id": "/redfish/v1/JsonSchemas/StorageController"
            "@odata.id": "/redfish/v1/JsonSchemas/Task"
            "@odata.id": "/redfish/v1/JsonSchemas/TaskService"
            "@odata.id": "/redfish/v1/JsonSchemas/TelemetryService"
            "@odata.id": "/redfish/v1/JsonSchemas/Thermal"
            "@odata.id": "/redfish/v1/JsonSchemas/Triggers"
            "@odata.id": "/redfish/v1/JsonSchemas/UpdateService"
            "@odata.id": "/redfish/v1/JsonSchemas/VLanNetworkInterface"
            "@odata.id": "/redfish/v1/JsonSchemas/VirtualMedia"
            "@odata.id": "/redfish/v1/JsonSchemas/odata"
            "@odata.id": "/redfish/v1/JsonSchemas/redfish-error"
            "@odata.id": "/redfish/v1/JsonSchemas/redfish-payload-annotations"
            "@odata.id": "/redfish/v1/JsonSchemas/redfish-schema"
Response code: 200
Data type
@odata.context
String
OData description of the Schema collection resource model.
@odata.id
String
Link to the Schema collection resource.
Name
String
Name of the Schema collection resource.
String
Description of the Schema resource.
@odata.type
String
Type of the Schema collection resource.
Members@odata.count
Integer
Number of Schema resources.
Members
List of Schema resources.
@odata.id
String
Link to a Schema resource.
Change history
Version
Change description
HDM2-1.57
Deleted the path to access the Redundant resource node in Members.
HDM-1.30.09
Added the redfish/v1/JSONSchemas interface.
Obtain the registry address for a single Schema file from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip//redfish/v1/JsonSchemas/schema_name
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
schema_name
Access ID of the Schemas resource node.
You can obtain the ID by obtaining the Schema file of all current resources on the server.
Method and URL:
GET https://192.168.18.18/redfish/v1/JsonSchemas/Chassis
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#JsonSchemaFile.JsonSchemaFile",
    "@odata.id": "/redfish/v1/JsonSchemas/Chassis",
    "@odata.type": "#JsonSchemaFile.v1_0_2.JsonSchemaFile",
    "Name": "Chassis Schema File",
    "Schema": "#Chassis.Chassis",
    "Description": "Chassis Schema File Location",
    "Id": "Chassis",
    "Languages": [
        "en"
    "Languages@odata.count": 1,
    "Location": [
            "Language": "en",
            "PublicationUri": "http://redfish.dmtf.org/schemas/v1/Chassis.json",
            "Uri": "/redfish/v1/JsonSchemas/Chassis/Chassis.json"
    "Location@odata.count": 1
Response code: 200
Data type
@odata.context
String
OData description information for the registry resource model.
@odata.id
String
Link to registry resource nodes.
@odata.type
String
Type of the registry resource.
Id
String
ID of the registry resource.
Name
String
Name of the registry resource.
String
Description of the registry resource.
Schema
String
Name of the registry file.
Languages
String
Language set.
Integer
Number of language sets.
Location
Object array
Language
String
Encoding language of Schema file.
Uri
String
Local accessible URI linked to the Schema.
PublicationUri
String
Public accessible URI linked to Schema.
Integer
Number of location groups.
Obtain information about all message registries from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Registries
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/Registries
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Registries",
    "@odata.id": "/redfish/v1/Registries",
    "@odata.type": "#MessageRegistryFileCollection.MessageRegistryFileCollection",
    "Description": "Collection of MessageRegistryFiles",
    "Members": [
            "@odata.id": "/redfish/v1/Registries/Base"
            "@odata.id": "/redfish/v1/Registries/TaskEvent"
            "@odata.id": "/redfish/v1/Registries/ResourceEvent"
            "@odata.id": "/redfish/v1/Registries/OpenBMC"
    "Members@odata.count": 4,
    "Name": "MessageRegistryFile Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the message registry collection resource model.
@odata.id
String
Link to the message registry collection resource.
Name
String
Name of the message registry collection resource.
@odata.type
String
Type of the message registry collection resource.
Members@odata.count
Integer
Number of message registry resources.
Members
List of message registry resources.
@odata.id
String
Link to a message registry resource.
Obtain information about a specific message registry from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Registries/registries_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
registries_id
Extended resource ID.
You can obtain the resource IDs by obtaining all registry resources.
Method and URL:
GET https://192.168.18.18/redfish/v1/Registries/Base
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Registries/Members/$entity",
    "@odata.id": "/redfish/v1/Registries/Base",
    "@odata.type": "#MessageRegistryFile.v1_1_0.MessageRegistryFile",
    "Description": "DMTF Base Message Registry File Location",
    "Id": "Base",
    "Languages": [
        "en"
    "Location": [
            "Language": "en",
            "PublicationUri": "https://redfish.dmtf.org/registries/Base.1.8.1.json",
            "Uri": "/redfish/v1/Registries/Base/Base"
    "Location@odata.count": 1,
    "Name": "Base Message Registry File",
    "Oem": {
        "Public": {
    "Registry": "Base.1.8.1"
Response code: 200
Data type
@odata.context
String
OData description of the message registry model.
@odata.id
String
Link to the message registry resource.
Id
String
ID of the message registry resource.
Name
String
Name of the message registry resource.
@odata.type
String
Type of the message registry resource.
String
Description of the message registry resource.
Languages
Integer
Language codes for the registries available.
Registry
String
Name of the message registry, primary or secondary version of the registry.
Integer
Location
Array
Language
String
Language code for the file the registry is in.
Uri
String
Link to the locally available URI for the registry.
PublicationUri
String
Link to publicly accessible URI for Schema.
Obtain information about the OData service document from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip//redfish/v1/odata
Request header:
N/A
Request body:
N/A
Parameter
Value
device_ip
Method and URL:
GET https://192.168.18.18/redfish/v1/odata
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata",
    "value": [
            "kind": "Singleton",
            "name": "$metadata",
            "url": "/redfish/v1/$metadata"
            "name": "odata",
            "url": "/redfish/v1/odata"
            "name": "JsonSchemas",
            "url": "/redfish/v1/JsonSchemas"
            "name": "Service",
            "url": "/redfish/v1/"
            "name": "ServiceRoot",
            "url": "/redfish/v1/ServiceRoot"
            "name": "Systems",
            "url": "/redfish/v1/Systems"
            "name": "Chassis",
            "url": "/redfish/v1/Chassis"
            "name": "Managers",
            "url": "/redfish/v1/Managers"
            "name": "SessionService",
            "url": "/redfish/v1/SessionService"
            "name": "AccountService",
            "url": "/redfish/v1/AccountService"
            "name": "UpdateService",
            "url": "/redfish/v1/UpdateService"
Response code: 200
Data type
@odata.context
String
OData description of the OData service document resource model.
value
List of OData service document resources.
name
String
Name of an OData service document resource.
kind
String
Type of an OData service document resource.
url
String
Link to an OData service document resource.
Obtain the chassis ID of the server. This operation returns information about only one server chassis, because HDM manages only the server on which it runs.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/Chassis
Request header:
X-Auth-Token:TOKEN
Content-Type: application/json
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#ChassisCollection.ChassisCollection",
    "@odata.id": "/redfish/v1/Chassis",
    "@odata.type": "#ChassisCollection.ChassisCollection",
    "Members": [
            "@odata.id": "/redfish/v1/Chassis/1"
    "Members@odata.count": 1,
    "Name": "Chassis Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the chassis collection resource model.
@odata.id
String
Link to the chassis collection resource.
@odata.type
String
Type of the chassis collection resource.
Members
List of chassis resources.
@odata.id
String
Link to a chassis resource.
Members@odata.count
Integer
Number of chassis resources.
Name
String
Name of the chassis collection resource.
Obtain information about the server by its chassis resource ID.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
ID of the chassis resource.
Only value 1 is supported.
Method and URL:
GET https://192.168.18.18/redfish/v1/Chassis/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Chassis.Chassis",
    "@odata.id": "/redfish/v1/Chassis/1",
    "@odata.type": "#Chassis.v1_14_0.Chassis",
    "AssetTag": "",
    "BoardsSummary": {
        "Count": 4,
        "MaxCountSupported": null,
        "Status": {
            "Health": "OK",
            "HealthRollup": "OK",
            "Oem": {
                "Public": {
                    "FaultDescription": "",
                    "Severity": "Informational"
            "State": "Enabled"
    "ChassisType": "Rack Mount Chassis",
    "Description": "Computer System Chassis",
    "Drives": {
        "@odata.id": "/redfish/v1/Chassis/1/Drives"
    "Id": "1",
    "IndicatorLED": "Off",
    "IndicatorLED@Redfish.AllowableValues": [
        "Lit",
        "Blinking",
        "Off"
    "InletHistoryTemperature": {
        "@odata.id": "/redfish/v1/Chassis/1/Thermal/InletHistoryTemperature"
    "Links": {
        "ComputerSystems": [
                "@odata.id": "/redfish/v1/Systems/1"
        "ManagedBy": [
                "@odata.id": "/redfish/v1/Managers/1"
        "PCIeDevices": [
                "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/3"
    "Manufacturer": "New H3C Technologies Co., Ltd.",
    "Model": "R4900_G6",
    "Name": "Computer System Chassis",
    "NetworkAdapters": {
        "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters"
    "Oem": {
        "Public": {
            "Boards": {
                "@odata.id": "/redfish/v1/Chassis/1/Boards"
            "CPUEnergyEfficiency": {
                "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/CPUEnergyEfficiency"
            "DeviceMaxNum": {
                "CPUNum": 2,
                "DiskNum": 25,
                "FanNum": 4,
                "LiquidCoolerNum": 1,
                "LogicalDriveNum": 1,
                "MemoryNum": 32,
                "MezzCardNum": null,
                "PCIeNum": 5,
                "PowerSupplyNum": 2,
                "SDCardNum": null,
                "SDContollerNum": null,
                "StorageCardNum": 4
            "IdleDriveSlots": {
                "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots"
            "MCAPolicy": "Restart",
            "Mainboard": {
                "BoardName": "111",
                "ChassisPartNumber": "0235AQ7",
                "PartNumber": "0302A5B8",
                "SerialNumber": "210231A8L0H199BI"
            "PowerOnSettings": {
                "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/PowerOnSettings"
"SlotPowerSupply": [
                    "PowerState": "Off",
                    "SlotNumber": "2"
                    "SlotNumber": "3"
                    "SlotNumber": "5"
    "PCIeSummary": {
        "Count": 1,
        "MaxCountSupported": 5,
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
    "PSUSummary": {
        "Count": 1,
        "MaxCountSupported": 2,
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
    "PartNumber": "1234",
    "Power": {
        "@odata.id": "/redfish/v1/Chassis/1/Power"
    "PowerState": "On",
    "SKU": "",
    "Sensors": {
        "@odata.id": "/redfish/v1/Chassis/1/Sensors"
    "SerialNumber": "123",
    "Status": {
        "Health": "Critical",
        "HealthRollup": "Critical",
        "Oem": {
            "Public": {
                "Severity": "Major"
        "State": "Enabled"
    "TemperatureSummary": {
        "Count": null,
        "MaxCountSupported": 28,
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
    "Thermal": {
        "@odata.id": "/redfish/v1/Chassis/1/Thermal"
Response code: 200
Data type
@odata.context
String
OData description of the chassis resource model.
@odata.id
String
Link to the chassis resource.
@odata.type
String
Type of the chassis resource.
Drives
Object
Link to the physical drive collection resource.
Id
String
ID of the chassis resource, a unique identifier of the chassis in the chassis collection.
Name
String
Name of the chassis resource.
ChassisType
String
Chassis type.
String
Description of the chassis resource.
AssetTag
String
Asset tag.
IndicatorLED
String
UID LED status. Supported options:
·     LitThe LED is steady on.
·     Blinking—The LED is flashing.
·     Off—The LED is off.
Array
Available UID LED status. Supported options:
BoardsSummary/PCIeSummary/
PSUSummary/TemperatureSummary
Module summary information
The X18000 model does not support the PSUSummary module.
Count
Integer
Current quantity.
MaxCountSupported
Integer
Maximum supported quantity in the chassis.
Status
Object
Summary resource status. Includes:
·     Health—Summary resource health status.
·     State—Summary resource enabling status.
·     HealthRollup—Overall health status, which is consistent with Health.
·     Oem.Public.FaultDescription—Overall fault description.
·     Oem.Public.Severity—Custom health status.
The overall fault description is related to component overall faults, which is independent from individual component fault information.
Drives
Object
Drive information resource.
Object
Air inlet historical temperature resource.
Links
Links to service resources.
Links ComputerSystems
Array
Computer system resource.
Links ManagedBy
Array
System manager resource.
Links.PCIeDevices
Array
PCIe device resource.
Power
Object
Power information resource.
PowerState
String
Current power state of the chassis. Supported options:
·     On.
·     Off.
Thermal
Object
Chassis thermal properties.
Manufacturer
String
Manufacturer.
Model
String
Model.
NetworkAdaptersPartNumber
Object
Network adapter resource.
SKU
String
SKU code.
SerialNumber
String
Serial number.
PartNumber
String
Part number.
Sensors
Object
Sensor resource.
PowerOnSettings
Object
Power recovery policy resource.
Status
Object
Resource states:
·     Health—Whether the resource is healthy.
·     State—Whether the resource has been enabled.
·     HealthRollup—Overall health status.
Oem.Public
Custom attribute.
Oem.Public.Boards@odata.id
Object
Expander module resource.
Oem.Public.CPUEnergyEfficiency
Object
CPU power-saving resource.
Oem.Public.DeviceMaxNum.CPUNum
Integer
Maximum number of processors in the chassis.
Oem.Public.DeviceMaxNum.FanNum
Integer
Maximum number of fan modules in the chassis.
Oem.Public.DeviceMaxNum.MemoryNum
Integer
Maximum number of DIMMs in the chassis.
Oem.Public.DeviceMaxNum.PowerSupplyNum
Integer
Maximum number of power supplies in the chassis.
Oem.Public.DeviceMaxNum.PCIeNum
Integer
Maximum number of PCIe modules in the chassis.
Oem.Public.DeviceMaxNum.DiskNum
Integer
Maximum number of drives in the chassis.
Oem.Public.DeviceMaxNum.LiquidCoolerNum
Integer
Maximum number of liquid-cooled devices.
Oem.Public.DeviceMaxNum.LogicalDriveNum
Integer
Maximum number of logical drives in the chassis.
Oem.Public.DeviceMaxNum.MezzCardNum
Integer
Maximum number of Mezz cards in the chassis.
Oem.Public.DeviceMaxNum.SDCardNum
Integer
Maximum number of SD cards in the chassis.
Oem.Public.DeviceMaxNum.SDContollerNum
Integer
Maximum number of SD controllers in the chassis.
Oem.Public.DeviceMaxNum.StorageCardNum
Integer
Maximum number of storage controllers in the chassis.
Object
Empty slots.
Oem.Public.MCAPolicy
String
·     RestartRestart the host upon the occurrence of an MCA failure.
·     NoActionDo not restart the host when MCA failures occur.
Oem.Public.SlotPowerSupply
Object
Power status and slot number for intelligent network adapters that are powered on by slot.
Oem.Public.SlotPowerSupply.PowerState
String
Power status.
Oem.Public.SlotPowerSupply.SlotNumber
String
Slot number.
Oem.Public.Mainboard.BoardName
String
·     For all servers except for the R6900 and R8900: Product name of the system board.
·     For the R6900 and R8900: Product name of the midplane.
Oem.Public.Mainboard.ChassisPartNumber
String
·     For all servers except for the R6900 and R8900: Chassis domain part number of the system board.
Oem.Public.Mainboard.Manufacturer
String
·     For all servers except for the R6900 and R8900: Manufacturer of the system board.
Oem.Public.Mainboard.PartNumber
String
·     For all servers except for the R6900 and R8900: Part number of the system board.
Oem.Public.Mainboard.SerialNumber
String
·     For all servers except for the R6900 and R8900: Serial number of the system board.
·     For the R6900 and R8900: Serial number of the midplane.
Oem.Public.Boards
Object
Links to boards.
Change history
Version
Change description
HDM3-1.15
Added object Oem.Public.IdleDriveSlots.
HDM2-2.04
Added object Oem.Public.SlotPowerSupply and updated the description for the Oem.Public.DeviceMaxNum.FanNum field.
HDM2-1.54
Added the LiquidCoolerNum field.
Set the UID LED on the server, and configure the MCA policy.
Privilege module
OemKvm
Locking type of the associated system
BMC configuration locking (only applicable when you set MCA)
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Chassis/chassis_id
Request header:
X-Auth-Token:TOKEN
If-Match:ifmatch_value
Request body:
"IndicatorLED": ledstate,
"Oem":{
      "Public":{
          "MCAPolicy":policy
                   "SlotNumber": "2"
                   "SlotNumber": "3"
                   "SlotNumber": "5"
Parameter
Value
device_ip
TOKEN
chassis_id
ifmatch_value
Entity tag (ETag) that uniquely represents the requested resource.
To obtain the entity tag value of a resource, send a GET request to it and then obtain the ETag value from the response header.
IndicatorLED
Action on the UID LED.
String. Supported options:
·     Lit—Turn on the LED.
·     Off—Turn off the LED.
·     BlinkingSet the LED status to flashing.
String.
Supported options:
·     RestartAuto restart.
·     NoActionNo auto restart.
Object
String
Power status.
String
Slot number.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Chassis/1
Request header:
X-Auth-Token:TOKEN
If-Match: W/"6e8c96325a9b7c6a6e5e9f23616fbce0"
Request body:
    "IndicatorLED":"Lit",
    "Oem":{
        "Public":{
            "MCAPolicy":"Restart",
                    "SlotNumber": "2"
                    "SlotNumber": "3"
                    "SlotNumber": "5"
Response:
    "AssetTag": "",
    "BoardsSummary": {
        "Count": 4,
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
    "Drives": {
    "Id": "1",
    "IndicatorLED": "Lit",
        "Lit",
        "Blinking",
        "Off"
    "Links": {
        "ManagedBy": [
        "PCIeDevices": [
    "Oem": {
        "Public": {
            "Boards": {
            "DeviceMaxNum": {
                "CPUNum": 2,
                "DiskNum": 25,
                "FanNum": 4,
                "MemoryNum": 32,
                "PCIeNum": 5,
                "SDCardNum": null,
                "StorageCardNum": 4
            "Mainboard": {
                "BoardName": "111",
                    "SlotNumber": "2"
                    "SlotNumber": "3"
                    "SlotNumber": "5"
    "PCIeSummary": {
        "Count": 1,
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
    "PSUSummary": {
        "Count": 1,
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
    "Power": {
    "PowerState": "On",
    "SKU": "",
    "Sensors": {
    "Status": {
        "Oem": {
            "Public": {
                "Severity": "Major"
        "State": "Enabled"
        "Count": null,
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
    "Thermal": {
Response code: 200
For information about the response fields, see "Obtain server information by its chassis resource ID."
Change history
Version
Change description
HDM2-2.04
Added object Oem.Public.SlotPowerSupply.
HDM2-1.53
Added the locking type of the associated system.
Obtain information about all physical drives from the server. Physical drives include NVMe drives and HDDs.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Drives
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
TOKEN
Method and URL:
GET https://172.16.20.162/redfish/v1/Chassis/1/Drives
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#DriveCollection.DriveCollection(*)",
    "@odata.id": "/redfish/v1/Chassis/1/Drives",
"@odata.type": "#DriveCollection.DriveCollection",
"AlarmThreshold": {
    "@odata.id": "/redfish/v1/Chassis/1/Drives/AlarmThreshold"
    "Members": [
            "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront1"
            "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront2"
            "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront3"
    "Members@odata.count": 3,
"Name": "Drives Collection",
"Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the physical drive collection resource model.
@odata.id
String
@odata.type
String
Type of the physical drive collection resource.
AlarmThreshold
Object
Obtain the storage medium alarm threshold.
Members
Array
Links to physical drive resources.
Members@odata.count
Integer
Number of physical drives.
Name
String
Name of the physical drive collection resource.
Obtain information about a specific physical drive from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Drives/driver_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
driver_id
ID of the physical drive resource.
You can obtain available physical drive resource IDs from physical drive collection information.
TOKEN
# Obtain information about a physical drive that has not been used for creating a logical drive.
Method and URL:
GET http://192.168.18.18/redfish/v1/Chassis/1/Drives/DiskFront3
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context":"/redfish/v1/$metadata#Drive.Drive(*)",
    "@odata.id":"/redfish/v1/Chassis/1/Drives/DiskFront3",
    "@odata.type":"#Drive.v1_11_0.Drive",
    "CapableSpeedGbs":12,
    "CapacityBytes":599584145408,
    "HotspareType":"Dedicated",
    "Id":"DiskFront3",
    "Links":{
        "Volumes":[
    "Location":[
            "Info":"Front3",
            "InfoFormat":"DeviceName"
"Manufacturer":"SEAGATE",
    "MediaErrCount": null,
"MediaType":"HDD",
    "Model":"ST600MP0005",
    "Name":"DiskFront3",
    "NegotiatedSpeedGbs":12,
    "Oem":{
        "Public":{
            "CapableSpeedGTs":null,
"CapacityGB":"600GB",
            "CompletionCode":0,
            "ConnectionID":156,
            "Description":"Success",
            "DriveNumberInBios":"3",
            "DriveNumberInOS":"3",
"EEPROMPage1":null,
            "FirmwareStatus":"HotSpare",
            "ForeignState":false,
            "HoursOfPoweredUp":null,
"IsNVMeM2": false,
            "NegotiatedSpeedGTs":null,
            "OwnerNode":null,
            "Panel":"Front3",
"PowerState":null,
"PredictedMediaLifeLeftDays": null,
"RawCapacity":"600GB",
            "RebuildProgress":null,
            "SASAddress":[
                "5764824129363309997",
                "0000000000000000000"
            "SASSmartInformation":null,
            "SATASmartInformation ":[
                    "AttributeName":"RawReadErrorRate",
                    "ID":1,
                    "Thresh":44,
                    "Value":82,
                    "Worst":63,
                    "RawValue":100
            "SpareforLogicalDrives":[
                    "@odata.id":"/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes/LogicalDrive0"
            "SupportedConfigurationOperation":[
                "ClearHotSpare"
"SystemDiskNumber":null,
            "TemperatureCelsius":46,
"TriMode":false,
            "PatrolState":"DoneOrNotPatrolled",
            "RebuildState":"DoneOrNotRebuilt"
"PredictedMediaLifeLeftPercent":null,
    "PredictiveFailureCount":null,
    "Protocol":" SATA",
    "Revision":"N003",
    "SerialNumber":"S7M12N93",
    "Status":{
        "Health":"OK",
        "Oem":{
            "Public":{
                "FaultDescription":"",
                "Severity":"Informational"
        "State":"Enabled"
    "StatusIndicator":"Hotspare"
Response code: 200
# Obtain information about a member drive of a logical drive.
Method and URL:
GET http://192.168.18.18/redfish/v1/Chassis/1/Drives/DiskFront0
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id":"/redfish/v1/Chassis/1/Drives/DiskFront0",
    "@odata.type":"#Drive.v1_4_0.Drive",
    "HotspareType":"None",
    "Id":"DiskFront0",
    "Links":{
        "Volumes":[
                "@odata.id":"/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes/LogicalDrive239"
    "Location":[
            "Info":"Front0",
"Manufacturer":"HGST",
    "MediaType":"HDD",
    "Model":"HUC101860CS4200",
    "Name":"DiskFront0",
    "Oem":{
        "Public":{
            "CompletionCode":0,
            "ConnectionID":155,
            "DriveNumberInBios":"0",
            "DriveNumberInOS":"0",
            "EEPROMPage1":null,
            "FirmwareStatus":"Online",
"IsNVMeM2": false,
            "OwnerNode":null,
            "OwnerVolume":{
                "Name":"",
                "RaidControllerID":0,
                "Status":{
                    "Health":"OK",
                    "State":"Enabled"
                "VolumeRaidLevel":"RAID0",
                "element_num":1
            "Panel":"Front0",
"PowerState":null,
            "SASAddress":[
                "5764832511393723981",
            "SASSmartInformation":{
                "AccumulatedLoadUnloadCycles":52,
                "AccumulatedStartStopCycles":36,
                "CycleCountOverDeviceLifetime":50000,
                "DiskTemperatureCelsius":36,
                "DiskTripTemperatureCelsius":65,
                "ElementsInGrownDefectList":0,
                "LoadUnloadCountOverDeviceLifetime":600000,
                "WeekAndYearOfManufacture":"In week 44 Of Year 2022"
            "SATASmartInformation":null,
            "TemperatureCelsius":36,
"TriMode":false,
    "Protocol":" SAS",
    "Revision":"AD02",
    "SerialNumber":"03H3MEHA",
    "Status":{
        "Health":"OK",
        "Oem":{
            "Public":{
        "State":"Enabled"
    "StatusIndicator":"OK"
Response code: 200
# Obtain information about an NVMe drive.
Method and URL:
GET http://192.168.18.18/redfish/v1/Chassis/1/Drives/DiskFront9
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id":"/redfish/v1/Chassis/1/Drives/DiskFront9",
    "CapableSpeedGbs":null,
    "CapacityBytes":299439751168,
    "Id":"DiskFront9",
    "IndicatorLED":"Off",
    "Location":[
            "Info":"Front Slot 9",
"Manufacturer":"Intel",
    "MediaType":"SSD",
    "Model":"SSDPE2MX450G7",
    "Name":"P3520",
    "NegotiatedSpeedGbs":null,
    "Oem":{
        "Public":{
            "CapableSpeedGTs":8,
            "CapacityGB":null,
            "CompletionCode":0,
            "DriveNumberInBios":"109",
            "DriveNumberInOS":"109",
            "EEPROMPage1":null,
            "FirmwareStatus":"Normal",
"IsNVMeM2": false,
            "NegotiatedSpeedGTs":8,
            "OwnerNode":null,
            "Panel":"Front Slot 9",
"PowerState":null,
            "PredictedMediaLifeLeftDays": 4294967295,
            "RawCapacity":null,
            "SATASmartInformation ":null,
            "TemperatureCelsius":34,
"TriMode":false
"PredictedMediaLifeLeftPercent":95,
    "Protocol":"PCIe",
    "Revision":"MDV10253",
    "SerialNumber":"",
    "Status":{
        "Health":"OK",
        "Oem":{
            "Public":{
        "State":"Enabled"
Response code: 200
Data type
@odata.context
String
OData description of the physical drive resource model.
@odata.id
String
Link to the physical drive resource.
@odata.type
String
Type of the physical drive resource.
CapacityBytes
Integer
Capacity of the physical drive.
Id
String
Location.Info
String
Mark of the physical drive.
Location.InfoFormat
String
Format of the physical drive mark. Supported options include DeviceName.
Manufacturer
String
Manufacturer.
MediaType
String
Drive media type. Supported options:
·     HDD.
·     SSD.
IndicatorLED
String
LED status of the specified driver.
Supported options:
·     LitSteady on.
·     OffOff.
HotspareType
String
Hot spare status of the specified driver. Supported options:
·     None—No hot spare configured.
·     Global—Global hot spare.
·     Dedicated—Local hot spare.
·     AutoReplace—Roaming hot spare.
Model
String
Drive model.
Name
String
Name of the physical drive.
NegotiatedSpeedGbs
Integer
Negotiated speed of the drive interface, in Gbps.
This field is unavailable for NVMe drives.
CapableSpeedGbs
Integer
Maximum speed of the drive interface, in Gbps.
Protocol
String
Protocol used by the drive:
·     SAS.
·     SATA.
·     PCIe.
MediaErrCount
Integer
Number of media errors
This field is not supported by NVMe drives and LSI HBA, PMC, or Marvell cards.
Integer
Number of predicted failures.
This field is supported by physical drives attached to the LSI controllers and LSI HBA 9540 controllers.
Oem.Public.CapacityGB
String
Capacity of the physical drive, in GB.
This field is not supported by physical drives attached to the LSI controllers and LSI HBA 9540 controllers.
Oem.Public.RawCapacity
String
This field is not supported for NVMe drives, but is supported for NVMe M.2 drive in Trimode or outsourced Marvell controller configuration.
Oem.Public.CapableSpeedGTs
Integer
Maximum speed of the drive interface, in GTs.
This field is only available for NVMe drives and not available for NVMe M.2 drive in outsourced Marvell controller configuration.
Oem.Public.NegotiatedSpeedGTs
Integer
Negotiated speed of the drive interface, in GTs.
Oem.Public.DriveNumberInBios
String
Drive number in the BIOS.
For NVMe, when NVMe M.2 drives are installed in non-Trimode or non-outsourced Marvell controller configuration, this field displays the PCIe slot number.
Oem.Public.DriveNumberInOS
String
Drive number in OS.
Oem.Public.SystemDiskNumber
String
System drive number.
Oem.Public.FirmwareStatus
String
Drive state. The supported states vary by storage controller type and drive type.
·     States supported for the LSI-9300 controller:
¡     Ready.
¡     UnconfiguredBad.
¡     Failed.
¡     PFA.
·     States supported for an LSI controller other than the LSI-9300:
¡     Ready.
¡     UnconfiguredGood.
¡     UnconfiguredBad.
¡     HotSpare.
¡     Offline.
¡     Failed.
¡     Rebuilding.
¡     Optimal.
¡     Online.
¡     JBOD.
¡     Unknown.
¡     PFA.
¡     Copyback.
·     States supported for an PMC controller:
¡     Offline.
¡     Failed.
¡     PFA.
¡     Raw.
¡     Hotspare.
¡     Ready.
¡     Optimal.
¡     Unsupported.
¡     Unknown.
·     States supported for a self-developed Marvell controller:
¡     Unconfigured.
¡     Configured.
¡     PFA.
·     States supported for an outsourced Marvell controller:
¡     Idle.
¡     Assigned.
¡     PFA.
¡     Failed.
·     States supported for a 3SNIC controller:
¡     Online.
¡     Offline.
¡     Fault.
¡     Ucfggood.
¡     UcfgfaultUncorrectable error.
¡     Spare.
¡     Foreign.
¡     Diagnosing.
¡     Reconstructing.
¡     Copybacking.
¡     CfgincompatDrive configuration incompatible.
¡     PFA.
·     States supported for an NVMe drive:
¡     Spare_below.
¡     Temp_Anomaly.
¡     Subsys_Degraded.
¡     Read_only.
¡     Cache_Failed.
¡     PMR_Failed.
¡     Normal.
¡     Abnormal.
¡     Predict_Fail.
Oem.Public.Panel
String
Location information..
Oem.Public.ConnectionID
Integer
Physical drive connection ID.
This field is unavailable for NVMe drives but is available for NVMe drives in Trimode configuration.
Oem.Public.PowerState
String
Power status of the physical drive.
·     On.
·     Off.
This field is only supported for X18000G6.
Oem.Public.SASSmartInformation
Object
SAS interface SMART information.
SASSmartInformation. AccumulatedLoadUnloadCycles
Integer
Total drive load-unload count.
SASSmartInformation. AccumulatedStartStopCycles
Integer
Total drive start-stop count.
SASSmartInformation. CycleCountOverDeviceLifetime
Integer
Drive allowable start-stop count within its lifespan.
SASSmartInformation. DiskTemperatureCelsius
Integer
Current drive temperature.
SASSmartInformation. DiskTripTemperatureCelsius
Integer
Drive temperature upper limit.
SASSmartInformation. ElementsInGrownDefectList
Integer
Elements in the growth list
SASSmartInformation. LoadUnloadCountOverDeviceLifetime
Integer
Number of Load-Unloads during device lifetime.
SASSmartInformation. WeekAndYearOfManufacture
String
Manufacturing date.
Oem.Public.SATASmartInformation
Object
SATA interface SMART information.
AttributeName
String
SMART attribute name.
ID
Integer
SMART attribute ID.
Thresh
Integer
SMART attribute threshold.
Value
Integer
SMART attribute current value.
Worst
Integer
SMART attribute worst value.
RawValue
Integer
SMART attribute raw value.
Oem.Public.TemperatureCelsius
String
Drive temperature in Celsius.
Oem.Public.TriMode
Boolean
Whether the physical drive is in Trimode configuration.
Integer
Remaining lifetime of the drive, in percent. This field displays null if the drive does not support this feature.
Revision
String
Drive version.
SerialNumber
String
Drive serial number.
Status.Health
String
Health status.
Status.State
String
Drive enabling state.
Status.State.Oem.Public.Severity
String
Status.State.Oem.Public.FaultDescription
String
Fault description information.
Oem.Public.OwnerVolume.Name
String
Name of the logical drive to which the physical drive belongs.
Oem.Public.OwnerVolume.RaidControllerID
String
ID of the storage controller for the logical drive.
Oem.Public.OwnerVolume.Status.Health
String
Health status of the logical drive to which the physical drive belongs.
Oem.Public.OwnerVolume.Status.State
String
Enabling status of the logical drive to which the physical drive belongs.
Oem.Public.OwnerVolume.VolumeRaidLevel
String
RAID level of the logical drive to which the physical drive belongs.
Oem.Public.OwnerVolume.element_num
String
Number of member drives in the logical drive to which the physical drive belongs.
Oem.Public.ForeignState
Boolean
Physical drive foreign state.
Oem.Public.OwnerNode
String
Hard drive node information. This field displays null if the drive does not have a node.
Oem.Public.SpareforLogicalDrives
Integer
List of logical drives belonging to local hot spare.
Integer
Supported operations list. Supported options:
·     MakeUnconfiguredBad
·     MakeUnconfiguredGood
·     MakeJBOD
·     AssignGlobalHotSpareDrive
·     AssignDedicatedHotSpareDrive
·     AssignAutoReplaceHotSpareDrive
·     ClearHotSpare
This field is for reference only and does not guarantee successful execution.
StatusIndicator
String
Status of the specified driver. Options include:
·     OK.
·     Fail.
·     Rebuild.
·     PredictiveFailureAnalysis.
·     Hotspare.
·     InAFailedArray.
·     InACriticalArray.
Oem.Public.HoursOfPoweredUp
Integer
Uptime of the specified driver.
Oem.Public.SASAddress
Array
SAS address of the specified driver.
The address is invalid when all field values are 0.
NVMe M.2 drives do not support SAS addresses.
Oem.Public.PatrolState
String
Patrolling status of the specified driver. Options include DoneOrNotPatrolled and Patrolling.
Oem.Public.RebuildState
String
Data rebuilding status of the specified driver. Options include DoneOrNotRebuilt and Rebuilding.
Oem.Public.RebuildProgress
String
Data rebuilding progress of the specified driver, in percentage.
Oem.Public.PredictedMediaLifeLeftDays
Integer
Specified drive predicted remaining lifespan in days.
This field is only available for NVMe drives but is not available for NVMe M.2 drives in Trimode or outsourced Marvell controller configuration.
Oem.Public.EEPROMPage1
String
EEPROM data of the Page switched to VPD on the NVMe drive.
This field is only supported on the X18000G6 for the P6530RT0192M00 and P6530RT0384M00 E1.SPB6530 drives.
Oem.Public.IsNVMeM2
Boolean
NVMe M.2 driver identifier.
Change history
Version
Change description
HDM3-1.15
Added physical drive states in the Oem.Public.FirmwareStatus field for 3SNIC controllers.
HDM2-2.10
Added physical drive states in the Oem.Public.FirmwareStatus field for the 9300 module.
HDM2-2.12
Modified the Failed option for the Oem.Public.FirmwareStatus field.
HDM2-2.12
Added the PMR_Failed option to the Oem.Public.FirmwareStatus field for NVMe drives.
HDM3-1.14
Added the MediaErrCount and PredictiveFailureCount fields.
HDM2-2.04
HDM2-2.03
Added the Oem.Public.IsNVMeM2 field and the description about NVMe display for outsourced MARVELL controller configuration.
HDM2-1.60
Added the Oem.Public.EEPROMPage1 field and the Unsupported state for physical drives managed by a PMC storage controller.
HDM2-1.59
Added the Oem.Public.PowerState field.
HDM2-1.58
Added the Oem.Public.TriMode field and deleted the NVME option from the Protocol field.
HDM2-1.58
Added the Predict_Fail option to the Oem.Public.FirmwareStatus field.
HDM2-1.56
Adjusted the field options of the Oem.Public.FirmwareStatus field for physical drives of the Marvell module: Changed the Ready option to Unconfigured and the Online option to Configured.
HDM2-1.54
·     Added the RawCapacity field.
·     Added the RawValue field for Smart information of SATA drives for specific fields.
HDM2-1.53
Added description of the NVMe drives in Trimode configuration for specific fields.
Obtain available logical disks when creating a hot spare drive on specified physical drive
Obtain the list of available logical drives when creating a hot spare drive for a specified physical drive.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Drives/driver_id/Oem/Public/OptionalLogicalDrivesforHotspare
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
driver_id
ID of the physical drive.
TOKEN
·     Local Hot Spare—Add ?$filter=Type eq 2 to the URL to obtain the list of available logical drives for creating a local hot spare.
·     Roaming Hot Spare—Add ?$filter=Type eq 3 to the URL to obtain the list of available logical drives for creating a roaming hot spare.
·     Default—Without adding any parameter, the list of available logical drives for creating a local hot spare is returned.
Method and URL:
GET http://192.168.18.18/redfish/v1/Chassis/1/Drives/DiskFront1/Oem/Public/ OptionalLogicalDrivesforHotspare
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#OptionalLogicalDrivesforHotspare.OptionalLogicalDrivesforHotspare(*)",
    "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront1/Oem/Public/OptionalLogicalDrivesforHotspare",
    "@odata.type": "#OptionalLogicalDrivesforHotspareColletion.OptionalLogicalDrivesforHotspareCollection",
    "Members": [
    "Name": "OptionalLogicalDrivesforHotspare Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description information for the available logical drives resource model when creating a hot spare for a specified physical drive.
@odata.id
String
Link to the available logical drives resource when creating a hot spare for a specified physical drive.
@odata.type
String
Type of the available logical drives resource Link to the available logical drives resource when creating a hot spare for a specified physical drive.
Members
Array
Link to the available logical drives.
Members@odata.count
Integer
Number of available logical drives.
Name
String
Name of the logical drives resource.
Set the physical drive state
Set the state of a physical drive.
Privilege module
OemKvm and OemDiagnosis
Note that setting the LED state belongs to OemDiagnosis, and setting hot spare, physical drive status, and power-on/off status of physical drives belongs to OemKvm.
Hardware configuration lock
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Chassis/chassis_id/Drives/driver_id
Request header:
X-Auth-Token:TOKEN
Request body:
// Set the status of the locator LED:
// Set or cancel the global hot spare disk:
"HotspareType": hotsparetype
// Set the local hot spare disk or roaming hot spare disk:
    "HotspareType": "Dedicated",
    "Oem":{
        "Public":{
                    "@odata.id": volumepath
// Set the disk status:
"Oem":{
       "Public":{
            "FirmwareStatus":diskstate
// Set the drive power status.
"Oem":{
       "Public":{
             "PowerState":powerstate
Parameter
Value
device_ip
chassis_id
driver_id
TOKEN
ifmatch_value
String
Drive state. Supported options:
·     UnconfiguredGood.
·     UnconfiguredBad.
·     JBOD.
The switchover between the Unconfigured_Bad state and the JBOD state is not allowed.
HotspareType
Drive hot spare status.
Supported options:
·     Dedicated—Dedicated hot spare.
LSI controllers support global and dedicated hot spares, and PMC controllers support dedicated and roaming hot spares.
List of logical drives for which the local/roaming hot spare belongs.
Array.
@odata.id
Link to the associated logical drive is provided when the drive is set as a local/roaming hot spare.
You can obtain the list of optional logical drives available for creating a hot spare drive for a specific physical drive.
For example: /redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes/LogicalDrive0.
This field is only available for hot spare disk settings in the target logical drive.
IndicatorLED
String
Locator LED status. Supported options:
·     Off—Off.
·     LitSteady on.
String
·     On.
·     Off.
When setting the location indicator light status, the privilege is for maintenance. When setting the hot spare and physical drive status, it is for remote control.
# Turn on the location LED for the slot containing the specified drive.
Method and URL:
PATCH //192.168.18.18/redfish/v1/Chassis/1/Drives/DiskFront3
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
   "@odata.context": "/redfish/v1/$metadata#Drive.Drive(*)",
    "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront3",
    "@odata.type": "#Drive.v1_11_0.Drive",
    "CapableSpeedGbs": 12,
    "CapacityBytes": 599584145408,
    "HotspareType": "None",
    "Id": "DiskFront3",
    "Links": {
        "Volumes": []
    "Location": [
            "Info": "Front3",
            "InfoFormat": "DeviceName"
"Manufacturer": "SEAGATE",
    "MediaType": "HDD",
    "Model": "ST600MP0005",
    "Name": "DiskFront3",
    "NegotiatedSpeedGbs": 12,
    "Oem": {
        "Public": {
            "CapableSpeedGTs": null,
            "ConnectionID": 156,
            "DriveNumberInBios": "3",
            "DriveNumberInOS": "3",
            "EEPROMPage1":null,
            "FirmwareStatus": "Online",
            "ForeignState": false,
            "HoursOfPoweredUp": null,
            "IsNVMeM2": false,
            "NegotiatedSpeedGTs": null,
            "OwnerNode": null,
            "Panel": "Front3",
            "PowerState":null,
            "RebuildProgress": null,
            "SASAddress": [
                "SASSmartInformation": {
                "AccumulatedLoadUnloadCycles": 52,
                "AccumulatedStartStopCycles": 36,
                "CycleCountOverDeviceLifetime": 50000,
                "DiskTemperatureCelsius": 46,
                "DiskTripTemperatureCelsius": 65,
                "ElementsInGrownDefectList": 0,
                "LoadUnloadCountOverDeviceLifetime": 600000,
                "WeekAndYearOfManufacture": "In week 44 Of Year 2022"
            "SATASmartInformation": null,
            "SpareforLogicalDrives": [],
            "SupportedConfigurationOperation": [],
            "TemperatureCelsius": 46,
"TriMode":false,
            "PatrolState": "DoneOrNotPatrolled",
            "RebuildState": "DoneOrNotRebuilt"
"PredictedMediaLifeLeftPercent": null,
    "Protocol": " SAS",
    "Revision": "N003",
    "SerialNumber": "S7M12N93",
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
    "StatusIndicator": "OK"
Response code: 200
# Modify the status of a physical drive.
Method and URL:
PATCH http://192.168.18.18/redfish/v1/Chassis/1/Drives/DiskFront3
Request header:
X-Auth-Token:TOKEN
Request body:
"Oem":{
       "Public":{
            "FirmwareStatus": "UnconfiguredGood"
Response:
    "Id":"DiskFront3",
    "Links":{
        "Volumes":[
    "Location":[
            "Info":"Front3",
    "MediaType":"HDD",
    "Oem":{
        "Public":{
            "CompletionCode":0,
            "ConnectionID":156,
            "EEPROMPage1":null,
            "FirmwareStatus":"UnconfiguredGood",
            "IsNVMeM2": false,
            "OwnerNode":null,
            "Panel":"Front3",
"PowerState":null,
            "SASAddress":[
                "DiskTemperatureCelsius":46,
                "MakeUnconfiguredBad",
                "MakeJBOD",
                "AssignGlobalHotSpareDrive",
                "AssignDedicatedHotSpareDrive"
"TriMode":false,
    "Protocol":" SAS",
    "Revision":"N003",
    "Status":{
        "Health":"OK",
        "Oem":{
            "Public":{
        "State":"Enabled"
Response code: 200
# Set a dedicated hot spare.
Method and URL:
PATCH http://192.168.18.18/redfish/v1/Chassis/1/Drives/DiskFront2
Request header:
X-Auth-Token:TOKEN
Request body:
    "Oem":{
        "Public":{
Response:
  "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront2",
  "CapableSpeedGbs": 6.0,
  "CapacityBytes": 1919816826880,
  "Id": "DiskFront2",
  "Links": {
    "Volumes": []
  "Location": [
      "Info": "Front2",
  "Manufacturer": "Seagate",
  "MediaType": "SSD",
  "Model": "XA1920LE10063",
  "Name": "DiskFront2",
  "NegotiatedSpeedGbs": 6.0,
  "Oem": {
    "Public": {
      "CapacityGB":"1920GB",
      "CapacityGB": "1.92TB",
      "ConnectionID": 34,
      "DriveNumberInBios": "2",
      "DriveNumberInOS": "2",
      "EEPROMPage1":null,
      "FirmwareStatus": "UnconfiguredGood",
      "HoursOfPoweredUp": 880,
      "IsNVMeM2": false,
      "OwnerNode": null,
      "Panel": "Front2",
"PowerState":null,
      "RawCapacity":"1.92TB",
      "RebuildState": "DoneOrNotRebuilt",
      "SASAddress": [
        "300062B20EC1FB02",
        "0000000000000000"
      "SASSmartInformation": null,
      "SATASmartInformation": [
          "AttributeName": "N/A",
          "ID": 1,
          "Thresh": 0,
          "Value": 100,
          "Worst": 100
          "ID": 243,
          "Thresh": 0,
          "Value": 37,
          "Worst": 23
        "MakeJBOD",
      "TemperatureCelsius": 33,
"TriMode":false
  "PredictedMediaLifeLeftPercent": 100,
  "Protocol": "SATA",
  "Revision": "00ZU",
  "SerialNumber": "HKS015WZ",
  "Status": {
    "Health": "OK",
    "Oem": {
      "Public": {
    "State": "Enabled"
Response code: 200
# Set the power status of the physical drive.
Method and URL:
PATCH http://192.168.18.18/redfish/v1/Chassis/1/Drives/DiskFront10
Request header:
X-Auth-Token:TOKEN
Request body:
 "Oem": {
       "Public": {
       "PowerState": "On"
Response:
   "@odata.id":"/redfish/v1/Chassis/1/Drives/DiskFront10",
    "CapableSpeedGbs": null,
    "CapacityBytes": 1920000000000,
    "Id": "DiskFront10",
    "Location": [
           "Info": "Front Slot 10",
    "Manufacturer": "Samsung",
    "MediaType": "SSD",
    "Model": "MZTL21T9HCJR-00A07",
    "Name": "PM9A3",
    "NegotiatedSpeedGbs": null,
    "Oem": {
        "Public": {
           "CapableSpeedGTs": 16,
           "CapacityGB": null,
           "DriveNumberInBios": "110",
           "DriveNumberInOS": "110",
           "EEPROMPage1":null,
           "FirmwareStatus": "Normal",
           "IsNVMeM2": false,
           "NegotiatedSpeedGTs": 16,
           "OwnerNode": null,
           "Panel": "Front Slot 10",
           "PowerState": "On",
           "RawCapacity": null,
           "SystemDiskNumber": null,
           "TemperatureCelsius": 37,
           "TriMode": false
    "Protocol": "PCIe",
    "Revision": "GDC6102Q",
    "SerialNumber":"S6RCNG0T100136",
    "Status": {
        "Health":"OK",
        "Oem": {
           "Public": {
        "State":"Enabled"
For information about the response fields, see "Obtain physical drive information."
Change history
Version
Change description
HDM2-1.59
HDM2-1.53
Obtain idle slot collection information
Obtain idle slot collection information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Oem/Public/IdleDriveSlots
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
This field is 1 for all current models.
TOKEN
Method and URL:
GET https://172.16.20.162/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#IdleDriveSlotsCollection.IdleDriveSlotsCollection(*)",
    "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots",
"@odata.type": "#IdleDriveSlotsCollection.IdleDriveSlotsCollection ",
    "Members": [
            "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots/Front1"
            "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots/Front2"
            "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots/Front3"
"Name": "Idle Drive Slots Collection ",
"Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the idle slot collection resource model.
@odata.id
String
Link to the collection information of idle slot resources.
@odata.type
String
Type of the collection information of idle slot resources.
Members
Array
Link to the idle slot resource.
Members@odata.count
Integer
Number of idle slots.
Name
String
Name of the idle slot resource.
Change history
Version
Change description
HDM3-1.15
Added the interface.
Obtain information about the specified idle slot
Obtain information about the specified idle slot.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Oem/Public/IdleDriveSlots/IdleDriveSlots_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
Device IP address.
chassis_id
Chassis resource ID.
TOKEN
Method and URL:
GET https://172.16.20.162/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots/Front1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#IdleDriveSlot.IdleDriveSlot(*)",
    "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots/Front1",
"@odata.type": "#IdleDriveSlot.v1_0_0.IdleDriveSlot",
"Id":"Front1",
"Name": "Front1",
"DrivesSizeSupported": "2.5in",
"Module": "4UniBay",
"InterfaceSupported": "SATA/SAS/U.2(NVMe)",
"Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
Name
String
IndicatorLED
String
UID LED state of the idle slot.
·     Off.
·     Lit.
DrivesSizeSupported
String
Drive size supported by the idle slot.
·     2.5in
·     3.5in
·     7.5mm
·     9.5mm
·     80mm
·     110mm
·     80mm/110mm
Module
String
Name of the module connected to the idle slot.
InterfaceSupported
String
Drive interface supported by the idle slot.
·     SATA/SAS
·     SATA/SAS/U.2(NVMe)
·     M.2(SATA)
·     M.2(NVMe)
·     E1.S
·     E3.S
Change history
Version
Change description
HDM3-1.15
Set the UID LED state of the idle slot
Set the UID LED state of the idle slot.
Privilege module
OemDiagnosis
Hardware configuration locking
Request
PATCH https://device_ip/redfish/v1/Chassis/chassis_id/Oem/Public/IdleDriveSlots/IdleDriveSlots_id
Request header:
X-Auth-Token:TOKEN
Request body:
"IndicatorLED": "ledstate",
Parameter
Value
device_ip
chassis_id
IdleDriveSlots_id
ID of the idle slot.
You can obtain the ID from the idle slot collection information.
ifmatch_value
TOKEN
IndicatorLED
String
UID LED state:
·     Off.
·     Lit.
Method and URL:
PATCH
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Id":"Front1",
"Name": "Front1",
"Module": 4UniBay,
"Oem": {
        "Public": {
            "CompletionCode": 0,
Response code: 200
Response field description
The server returns status code 200 for a successful operation.
For information about the response fields, see "Obtain idle slot collection information."
Change history
Version
Change description
HDM3-1.15
Obtain the collection information of drive Bays
Obtain the collection information of drive Bays.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Chassis/chassis_id/Oem/Public/DriveBays
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
chassis_id
TOKEN
Method and URL:
GET https://172.16.20.162/redfish/v1/Chassis/1/Oem/Public/DriveBays
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context":"/redfish/v1/$metadata#DriveBaysCollection.DriveBaysCollection(*)",
    "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/DriveBays",
    "@odata.type": "#DriveBaysCollection.DriveBaysCollection",
    "Members": [
            "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/DriveBays/Bay5"
            "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/DriveBays/Bay14"
    "Members@odata.count": 2,
    "Name": "DriveBays Collection",
    "Oem": {
        "Public": {
            "Description": "Success"
Response code: 200
Data type
@odata.context
String
OData description of the drive Bay collection information.
@odata.id
String
Link to the drive Bay collection information.
@odata.type
String
Type of the drive Bay collection information.
Members
Array
Members@odata.count
Integer
Number of the drive Bay collections.
Name
String
Name of the drive Bay collection information.
Change history
Version
Change description
HDM2-1.59
Added the redfish/v1/Chassis/1/Oem/Public/DriveBays interface.
Obtain drive Bay information
Obtain information about a specific drive Bay from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Oem/Public/DriveBays/bay_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
bay_id
ID of the drive Bay.
You can obtain the drive Bay ID from the collection information of drive Bays.
TOKEN
Method and URL:
GET https://172.16.20.162/redfish/v1/Chassis/1/Oem/Public/DriveBays/Bay5
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#DriveBay.DriveBay(*)",
    "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/DriveBays/Bay5",
    "@odata.type": "#DriveBay.v1_0_0.DriveBay",
    "DrivesCount": "3",
    "DrivesMaxTemperatureCelsius": "36",
    "Id": "Bay5",
    "Name": "DriveBay Instance",
    "Oem": {
        "Public": {
    "SlotNumber": "5",
    "Status": {
        "Oem": {
            "Public": {
                "FaultDescription": "[Bay5_Status]Drive Fault",
                "Severity": "Major"
        "State": "Enabled"
Response code: 200
Data type
@odata.context
String
OData description of the drive Bay information model.
@odata.id
String
Link to the drive Bay information resource.
@odata.type
String
Type of the drive Bay information resource.
Id
String
ID of the DriveBay.
Name
String
Name of the DriveBay resource.
DrivesCount
Integer
Number of drives connected to the DriveBay.
Integer
Highest temperature of the drives connected to the DriveBay.
Status.Health
String
Health status of the DriveBay.
Status.State
String
Enable status of the DriveBay.
String
Custom health status of the DriveBay.
String
Failure description information of the DriveBay.
Change history
Version
Change description
HDM2-1.59
Added the redfish/v1/Chassis/1/Oem/Public/DriveBays/bay_id interface.
Obtain thermal properties
Obtain information about thermal properties from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Thermal
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/Chassis/1/Thermal
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Thermal.Thermal",
    "@odata.id": "/redfish/v1/Chassis/1/Thermal",
    "@odata.type": "#Thermal.v1_6_3.Thermal",
    "FanSummary": {
        "Count": 4,
        "MaxCountSupported": 4,
                  "MaxRotorCountSupported": 16,
        "Redundancy": [
                "Name": "FAN_Redundant",
                "Status": {
                    "Health": "OK",
                    "State": "Enabled"
        "RotorCount": 16,
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
    "Fans": [
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/0",
            "MaxReadingRange": 17300,
            "MemberId": "0",
            "MinReadingRange": 0,
            "Name": "Fan1",
            "Oem": {
                "Public": {
                    "Position": "(up_front)",
                    "SlotNumber": 1,
                    "SpeedRatio": 0
            "PartNumber": "8056",
            "Reading": 0,
            "ReadingUnits": "RPM",
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/1",
            "MemberId": "1",
            "Name": "Fan1",
            "Oem": {
                "Public": {
                    "Position": "(up_rear)",
                    "SlotNumber": 1,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/2",
            "MemberId": "2",
            "Name": "Fan1",
            "Oem": {
                "Public": {
                    "Position": "(down_front)",
                    "SlotNumber": 2,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/3",
            "MemberId": "3",
            "Name": "Fan1",
            "Oem": {
                "Public": {
                    "Position": "(down_rear)",
                    "SlotNumber": 2,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/4",
            "MemberId": "4",
            "Name": "Fan2",
            "Oem": {
                "Public": {
                    "SlotNumber": 3,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/5",
            "MemberId": "5",
            "Name": "Fan2",
            "Oem": {
                "Public": {
                    "SlotNumber": 3,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/6",
            "MemberId": "6",
            "Name": "Fan2",
            "Oem": {
                "Public": {
                    "SlotNumber": 4,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/7",
            "MemberId": "7",
            "Name": "Fan2",
            "Oem": {
                "Public": {
                    "SlotNumber": 4,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/8",
            "MemberId": "8",
            "Name": "Fan3",
            "Oem": {
                "Public": {
                    "SlotNumber": 5,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/9",
            "MemberId": "9",
            "Name": "Fan3",
            "Oem": {
                "Public": {
                    "SlotNumber": 5,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/10",
            "MemberId": "10",
            "Name": "Fan3",
            "Oem": {
                "Public": {
                    "SlotNumber": 6,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/11",
            "MemberId": "11",
            "Name": "Fan3",
            "Oem": {
                "Public": {
                    "SlotNumber": 6,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/12",
            "MemberId": "12",
            "Name": "Fan4",
            "Oem": {
                "Public": {
                    "SlotNumber": 7,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/13",
            "MemberId": "13",
            "Name": "Fan4",
            "Oem": {
                "Public": {
                    "SlotNumber": 7,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/14",
            "MemberId": "14",
            "Name": "Fan4",
            "Oem": {
                "Public": {
                    "SlotNumber": 8,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans/15",
            "MemberId": "15",
            "Name": "Fan4",
            "Oem": {
                "Public": {
                    "SlotNumber": 8,
                    "SpeedRatio": 0
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
    "Id": "Thermal",
    "Name": "Thermal",
    "Oem": {
        "Public": {
            "CoolingMedium": "AirCooled",
            "Description": "Success",
            "FanSpeedAdjustmentMode": "Silent",
            "LeakStrategy": "N/A",
            "LiquidCoolers": [],
            "LiquidSummary": {
                "Count": 0,
                "MaxCountSupported": 0,
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
    "Temperatures": [
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/0",
            "LowerThresholdCritical": null,
            "LowerThresholdFatal": null,
            "LowerThresholdNonCritical": null,
            "MemberId": "0",
            "Name": "Inlet_Temp",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 7,
                    "OceanTemperatureYCoordinate": 0,
                    "OceanTemperatureZCoordinate": 1,
                    "ThresholdMask": 16184
            "PhysicalContext": "Room",
            "ReadingCelsius": 4294967295,
            "SensorNumber":
1,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "UpperThresholdCritical": 42.0,
            "UpperThresholdFatal": 55.0,
            "UpperThresholdNonCritical": 40.0
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/1",
            "MemberId": "1",
            "Name": "CPU1_Temp",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 11,
                    "OceanTemperatureYCoordinate": 8,
                    "ThresholdMask": 16128
            "SensorNumber": 7,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "UpperThresholdCritical": null,
            "UpperThresholdFatal": null,
            "UpperThresholdNonCritical": null
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/2",
            "MemberId": "2",
            "Name": "CPU2_Temp",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 4,
            "SensorNumber": 8,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/3",
            "MemberId": "3",
            "Name": "CPU1_DTS",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 15,
                    "OceanTemperatureYCoordinate": 15,
                    "OceanTemperatureZCoordinate": 0,
                    "ThresholdMask": 16136
            "SensorNumber": 9,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "UpperThresholdNonCritical": -1.0
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/4",
            "MemberId": "4",
            "Name": "CPU2_DTS",
            "Oem": {
                "Public": {
            "SensorNumber": 10,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/5",
            "MemberId": "5",
            "Name": "CPU1_VR_Temp",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 12,
                    "OceanTemperatureYCoordinate": 10,
                    "ThresholdMask": 16152
            "SensorNumber": 11,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "UpperThresholdCritical": 111.0,
            "UpperThresholdNonCritical": 106.0
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/6",
            "MemberId": "6",
            "Name": "CPU2_VR_Temp",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 3,
            "SensorNumber": 12,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/7",
            "MemberId": "7",
            "Name": "PSU1_Temp",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 14,
                    "OceanTemperatureYCoordinate": 12,
            "SensorNumber": 77,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/8",
            "MemberId": "8",
            "Name": "PSU2_Temp",
            "Oem": {
                "Public": {
            "SensorNumber": 78,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/9",
            "MemberId": "9",
            "Name": "PSU3_Temp",
            "Oem": {
                "Public": {
            "SensorNumber": 79,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/10",
            "MemberId": "10",
            "Name": "PSU4_Temp",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 1,
            "SensorNumber": 80,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/11",
            "MemberId": "11",
            "Name": "Front_NVMe_Max",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 8,
                    "OceanTemperatureYCoordinate": 1,
            "SensorNumber": 21,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "UpperThresholdNonCritical": 70.0
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/12",
            "MemberId": "12",
            "Name": "Front_HD_Max",
            "Oem": {
                "Public": {
            "SensorNumber": 20,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "UpperThresholdNonCritical": 60.0
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/13",
            "MemberId": "13",
            "Name": "M.2_Max",
            "Oem": {
                "Public": {
            "SensorNumber": 24,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/14",
            "MemberId": "14",
            "Name": "CPU1_DIMM_Temp",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 13,
            "SensorNumber": 16,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "UpperThresholdCritical": 95.0,
            "UpperThresholdNonCritical": 87.0
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/15",
            "MemberId": "15",
            "Name": "CPU2_DIMM_Temp",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 6,
            "SensorNumber": 17,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/16",
            "MemberId": "16",
            "Name": "M.2_Zone",
            "Oem": {
                "Public": {
                    "OceanTemperatureYCoordinate": 13,
            "SensorNumber": 5,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/17",
            "MemberId": "17",
            "Name": "Busbar1_Zone",
            "Oem": {
                "Public": {
                    "OceanTemperatureYCoordinate": 11,
            "SensorNumber": 85,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/18",
            "MemberId": "18",
            "Name": "Busbar2_Zone",
            "Oem": {
                "Public": {
                    "OceanTemperatureXCoordinate": 2,
            "SensorNumber": 86,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/19",
            "MemberId": "19",
            "Name": "Switch1_Temp",
            "Oem": {
                "Public": {
                    "OceanTemperatureZCoordinate": 2,
            "SensorNumber": 13,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "UpperThresholdCritical": 112.0,
            "UpperThresholdNonCritical": 107.0
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/20",
            "MemberId": "20",
            "Name": "Switch2_Temp",
            "Oem": {
                "Public": {
            "SensorNumber": 14,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Temperatures/21",
            "MemberId": "21",
            "Name": "Outlet_Temp",
            "Oem": {
                "Public": {
            "SensorNumber": 3,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
Response code: 200
Data type
@odata.context
String
OData description of the thermal resource model.
@odata.id
String
Link to the thermal resource.
@odata.type
String
Type of the thermal resource.
Id
String
ID of the thermal resource.
Name
String
Name of the thermal resource.
Object
Obtain information about the air inlet temperature history resource.
Oem.Public.FanSpeedAdjustmentMode
String
Fan speed mode. Supported options:
·     Silent.
·     Balanced.
·     Powerful.
·     Custom.
Oem.Public.FanSpeedLevelPercents
Integer
Fan speed level.
Value range: 1 to 20. A greater value indicates a higher speed.
This field is available only when the FanSpeedAdjustmentMode field is set to Custom.
FanSummary.Count
Integer
Current number of installed fan modules.
FanSummary.MaxCountSupported
Integer
Maximum supported number of fan modules.
FanSummary.MaxRotorCountSupported
Integer
Maximum supported number of fan rotors.
FanSummary.RotorCount
Integer
Current number of present fan rotors.
FanSummary.Redundancy
Object
Fan redundancy information. This field is null for blade servers.
FanSummary.Redundancy.Name
String
Name of the redundant fan sensor.
FanSummary.Redundancy.Status
Object
State of the redundant fan sensor. Supported options:
·     State—Whether the redundant fan sensor has been enabled. A value of Disabled indicates that a redundant fan sensor is not available.
·     Health—Whether the redundant fan sensor is healthy.
FanSummary.Status
Object
Overall fan status information. Supported options:
·     Health—Health status.
·     State—Enabling status..
·     Severity—Custom health status.
·     FaultDescription—Overall fault description.
The overall fault description is associated with the overall fault of the component and is independent of the fault information of individual components. The blade servers can display only the State field normally and displays null for all other fields.
Status
Object
Overall state information of the heat dissipation module. Supported options:
·     HealthRollupOverall health state of the heat dissipation module (same as the Health).
·     HealthHealth state of the heat dissipation module.
·     StateEnabling status of the heat dissipation module.
·     SeverityCustom health state.
·     FaultDescriptionOverall fault description.
Overall fault description refers to the general failure of the associated components, which is independent of individual component failure information. The blade servers can display only the State field normally and displays null for all other fields.
Fans
Fan information.
@odata.id
String
Link to a thermal resource.
Name
String
Fan name.
MaxReadingRange
Integer
Maximum fan rotation speed.
MinReadingRange
Integer
Minimum fan rotation speed.
MemberId
String
Fan ID.
Reading
Integer
Current fan rotation speed.
PartNumber
String
Part number.
ReadingUnits
String
Unit of fan speed read by the fan sensor, in RPM.
Status
Object
Resource status:
·     StateEnabling status.
Oem.Public.SpeedRatio
Integer
Speed ratio.
Oem.Public.Position
String
Container of the fan sensor.
Oem.Public.SlotNumber
Integer
Slot number of the fan sensor.
Temperatures
Temperature sensor properties.
@odata.id
String
Link to a temperature sensor resource.
MemberId
String
Temperature sensor ID.
Name
String
Temperature sensor name.
Integer
Lower major alarm threshold of the temperature sensor.
LowerThresholdFatal
Integer
Lower critical alarm threshold of the temperature sensor.
Integer
Lower minor alarm threshold of the temperature sensor.
Integer
Upper major alarm threshold of the temperature sensor.
UpperThresholdFatal
Integer
Upper critical alarm threshold of the temperature sensor.
Integer
Upper minor alarm threshold of the temperature sensor.
PhysicalContext
String
Area or equipment where the temperature sensor can be used.
SensorNumber
Integer
Temperature sensor number.
ReadingCelsius
Integer
Current reading of the temperature sensor. If the sensor does not have any reading, this field displays N/A.
Status
Object
Resource state information:
·     Health—Health state.
·     State—Enabling state.
·     Severity—Custom health state.
Oem.Public.OceanTemperatureXCoordinateUpperThresholdCritical
Integer
X-coordinate of ocean temperature.
Oem.Public.OceanTemperatureYCoordinateUpperThresholdFatal
Integer
Y-coordinate of ocean temperature.
Oem.Public.OceanTemperatureZCoordinate
Integer
Z-coordinate of ocean temperature.
Oem.Public.ThresholdMaskUpperThresholdNonCritical
Integer
Mask for temperature sensor thresholds.
Oem.Public.CoolingMedium
String
Cooling medium. Supported options:
·     AirCooled
·     LiquidCooled
·     AirAndLiquidCooled
Oem.Public.LeakStrategy
String
Action to take upon liquid leakage on liquid-cooled servers. Supported options:
·     AutoPowerOff.
·     ManualPowerOff.
Oem.Public.LiquidSummary.Count
Integer
Number of present liquid-cooled devices.
Oem.Public.LiquidSummary.MaxCountSupported
Integer
Maximum number of supported liquid-cooled devices.
Oem.Public.LiquidSummary.FaultDescription
String
Overall fault description for liquid-cooled devices.
Oem.Public.LiquidSummary.Severity
String
Overall health status of liquid-cooled devices.
Oem.Public.LiquidCoolers.Status.Health
String
Health status of a single liquid-cooled device.
Oem.Public.LiquidCoolers.Status.State
String
Enabling status of a single liquid-cooled device.
Oem.Public.LiquidCoolers.MemberId
String
Liquid-cooled device ID.
Oem.Public.LiquidCoolers.Name
String
Liquid-cooled device name.
Oem.Public.LiquidCoolers.Severity
String
Custom health status of a single liquid-cooled device.
Oem.Public.LiquidCoolers.FaultDescription
String
Fault description of a single liquid-cooled device.
Change history
Version
Change description
HDM3-1.20
HDM2-2.14
HDM2-1.79
Updated the response example.
HDM2-1.72
HDM2-2.05
Revised the output description for blade server models to exclude redundancy information, the health state field, and fan resource status.
HDM2-2.04
HDM2-1.79
Added the FanSummary.MaxRotorCountSupported and FanSummary.RotorCount fields and updated the description for the FanSummary.Count and FanSummary.MaxCountSupported fields
HDM2-1.57
Changed the return value for sensor threshold unavailability from 4294967295 to null.
HDM2-1.56
Changed the fan redundancy sensor name from FAN_Redundancy to FAN_Redundant in the example.
HDM2-1.54
Edited the overall state information for heat dissipation module in the Status field.
Added the CoolingMedium and LeakStrategy fields, object FanSummary.Status and the corresponding fields, object LiquidSummary and the corresponding fields, and object LiquidCoolers and the corresponding fields.
Configure the heat dissipation resource information for the specified chassis
Configure the heat dissipation resource information for the specified chassis.
Privilege module
OemPowerControl
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Chassis/chassis_id/Thermal
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
Request body:
"Oem":{
            "FanSpeedAdjustmentMode":speedmode,
            "FanSpeedLevelPercents":speedlevel
            "LeakStrategy": leakstrategy
Parameter
Value
device_ip
chassis_id
ID of the chassis resource.
Only value 1 is supported.
ifmatch_value
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
Fan speed mode.
Supported options:
·     Silent.
·     Balanced.
·     Powerful.
·     Custom.
Custom fan speed level.
A higher value represents a faster speed.
Action to take on a liquid-cooled server upon liquid leakage.
·     AutoPowerOff
·     ManualPowerOff
String.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Chassis/1/Thermal
Request header:
X-Auth-Token:TOKEN
If-Match:W/"6e8c96325a9b7c6a6e5e9f23616fbce0"
Request body:
    "Oem":{
        "Public": {
        "FanSpeedAdjustmentMode":"Custom",
        "FanSpeedLevelPercents":18,
        "LeakStrategy":"ManualPowerOff"
Response:
    "FanSummary": {
        "Count": 4,
"MaxRotorCountSupported": 8,
        "Redundancy": [
                "Status": {
                    "Health": "OK",
                    "State": "Enabled"
"RotorCount": 0,
        "Status": {
            "Health": "OK",
            "HealthRollup": "OK",
            "Oem": {
                "Public": {
                    "FaultDescription": "",
                    "Severity": "Informational"
            "State": "Enabled"
    "Fans": [
            "MaxReadingRange": 15000,
            "MemberId": "0",
            "Name": "Fan1",
            "Oem": {
                "Public": {
                    "Position": "chassis",
                    "SlotNumber": 1,
                    "SpeedRatio": 0
            "PartNumber": "8038",
            "Reading": 0,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
    "Id": "Thermal",
    "InletHistoryTemperature": {
        "@odata.id": "/redfish/v1/Chassis/1/Thermal/InletHistoryTemperature"
    "Name": "Thermal",
    "Oem": {
        "Public": {
            "CoolingMedium": "AirAndLiquidCooled",
            "LeakStrategy": "ManualPowerOff",
            "LiquidCoolers": [
                    "MemberId": 0,
                    "Name": "CPU Liquid Cooler1",
                    "Severity": "Informational",
                    "Status": {
                        "Health": "OK",
                        "State": "Enabled"
            "LiquidSummary": {
                "Count": 1,
                "MaxCountSupported": 1,
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
    "Temperatures": [
            "MemberId": "0",
            "Oem": {
                "Public": {
            "SensorNumber": 1,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Disabled"
            "UpperThresholdCritical": 52.0,
            "UpperThresholdNonCritical": 50.0
Response code: 200
For information about the response fields, see "Obtain thermal properties."
Change history
Version
Change description
HDM2-1.62
Added description of the Oem.Public.LeakStrategy field.
HDM2-1.56
HDM2-1.54
Changed the title name from Set the fan speed mode to Configure the heat dissipation resource information for the specified chassis.
HDM2-1.53
Obtain air inlet temperature history resource information
Obtain information about the air inlet temperature history resource from the server.
This interface is not available for blade servers.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Thermal/InletHistoryTemperature
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
Method and URL:
GET http://192.168.18.18/redfish/v1/Chassis/1/Thermal/InletHistoryTemperature
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
  "@odata.context": "/redfish/v1/$metadata#InletHistoryTemperature.InletHistoryTemperature",
  "@odata.id": "/redfish/v1/Chassis/1/Thermal/InletHistoryTemperature",
  "@odata.type": "#InletHistoryTemperature.v1_0_0.InletHistoryTemperature",
  "Description": "Air Inlet Historical Temperature",
  "HistoricalInletTemp": [
    "Description": "Normal",
      "avg": 50,
      "max": 50,
      "min": 50,
      "time": "2021-12-15T10:47:49+08:00"
      "Description": "Unavailable",
      "avg": null,
      "max": null,
      "min": null,
      "time": "2021-12-15T11:33:28+08:00"
      "Description": null,
      "avg": null,
      "max": null,
      "min": null,
      "time": "2021-12-15T11:38:28+08:00"
  "Id": "InletHistoryTemperature",
  "Name": "InletHistoryTemperature",
  "Oem": {
    "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the air inlet temperature history resource model.
@odata.id
String
Link to the air inlet temperature history resource.
@odata.type
String
Type of the air inlet temperature history resource.
String
Description of the air inlet temperature history resource.
Id
String
ID of the air inlet temperature history resource.
Name
String
Name of the air inlet temperature history resource.
HistoricalInletTemp.avg
Integer
Average temperature.
HistoricalInletTemp.max
Integer
Maximum temperature.
HistoricalInletTemp.min
Integer
Minimum temperature.
HistoricalInletTemp.time
String
Sample time.
Format example:
2021-12-15T11:33:28+08:00.
HistoricalInletTemp. Description
String
Description of sampling point data. Supported options:
·     Normal—Normal.
·     Unavailable—Sensor unavailable.
·     null—Not sampled.
Obtain power information
Obtain power information from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Power
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/Chassis/1/Power
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Power.Power(PowerControl,Voltages,Id,Name,PowerSupplies)",
    "@odata.id": "/redfish/v1/Chassis/1/Power",
"@odata.type": "#Power.v1_7_0.Power",
"AllPowerStatus": {
        "Oem": {
            "Public": {
                "HostPowerStatus": "On",
                "JBODPowerStatus": null,
                "JBOGPowerStatus": null,
                "OverallPowerStatus": "On",
                "SmartNICPowerStatus": null
    "Id": "Power",
    "Name": "Power",
    "Oem": {
        "Public": {
"StandbyPowerMonitoringEnabled": true
"PowerHistoryData": {
        "@odata.id": "/redfish/v1/Chassis/1/Power/PowerHistoryData"
    "PowerControl": [
            "@odata.id": "/redfish/v1/Chassis/1/Power#/PowerControl/1",
            "MaxNum": 2,
            "MemberId": 1,
            "Name": "System Power Control 1",
            "Oem": {
                "Public": {
                    "CurrentBoardPowerWatts": 466,
                    "CurrentCPUPowerWatts": 214,
                    "CurrentDiskPowerWatts":29,
                    "CurrentDiskPowerWats": 29,
                    "CurrentFanPowerWatts": 144,
                    "CurrentGPUPowerWatts": null,
                    "CurrentMemoryPowerWatts": 0,
                    "MinActivePowerCount":[1],
                    "PowerGroupCount": 1,
                    "SuggestedActivePowerCount": 2,
                    "OtherComponentsPowerWatts": null
            "PowerAlarmInfo": {
                "MaxPowerAlarm": 10000,
                "Multiple": 4,
                "PowerAlarmEnabled": false,
                "PowerAlarmThreshold": 10000
            "PowerConsumedWatts": 467,
            "PowerLimit": {
                "CorrectionInMs": 1000,
                "LimitException": "NoAction",
                "LimitInWatts": null,
                "PowerLimitEnable":false
            "PowerMetrics": {
                "MaxConsumedWatts": 10000,
                "MinConsumedWatts": 150
            "Status": {
                "Health": "Ok",
                "State": "Enabled"
    "PowerManagementEnabled": true,
    "PowerSupplies": [
            "@odata.id": "/redfish/v1/Chassis/1/Power#/PowerSupplies/2",
            "FirmwareVersion": "1M.0009.0024.002",
            "LineInputVoltage": 232,
            "LineInputVoltageType": "ACandDCWideRange",
            "Manufacturer": "FSP-GROUP",
            "MemberId": "2",
            "Model": "PSR800-12A",
            "Name": "PSU2",
            "Oem": {
                "Public": {
                    "ActiveStandby": "Active",
                    "ActiveStandbySupported": true,
                    "InputAmperage": 2.058,
                    "LineInputCurrent": 2.058,
                    "LineInputVoltageType": "AC",
                    "ManufactureDate":"2023-05-31",
                    "PowerCurrentWatts": 467,
                    "PowerGroupId": "1",
                    "PowerID": "2",
"PowerInputWatts": 156,
                    "PowerMaxWatts": 800,
                    "PowerOutputVoltage": 12.1,
                    "PowerOutputWatts": 442,
                    "ReadingAmperes": 36.375,
                    "SlotNumber": 2
            "PartNumber": null,
            "PowerCapacityWatts": 800,
            "PowerSupplyType": "ACorDC",
            "Redundancy": [],
            "SerialNumber": "8588859",
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
    "Redundancy": [
            "@odata.id": "/redfish/v1/Chassis/1/Power#/Redundancy/1",
            "@odata.type": "#Redundancy.v1_4_1.Redundancy",
            "MaxNumSupported": 2,
            "MemberId": "1",
            "MinNumNeeded": 1,
            "Mode": "Sharing",
            "Name": "PowerSupply Redundancy Group 1",
            "RedundancySet": [
                    "@odata.id": "/redfish/v1/Chassis/1/Power#/PowerSupply/2"
            "RedundancySet@odata.count": 1,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
    "Voltages": [
            "LowerThresholdCritical": 10.752,
            "MaxReadingRange": 255,
            "Name": "SYS_12V",
            "ReadingVolts": 11.968,
            "SensorNumber": 94,
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "UpperThresholdCritical": 13.184,
Response code: 200
Data type
@odata.context
String
OData description of the power resource model.
@odata.id
String
Link to the power resource.
@odata.type
String
Type of the power resource.
Id
String
ID of power supply resource.
Name
String
Name for power supply resource.
Boolean
Whether power management is supported.
PowerHistoryData
Object
Link to historical power resource information.
Oem.Public.StandbyPowerMonitoringEnabled
Boolean
Enabling status.of cold standby power inspection
Redundancy
List of power supply redundancy groups.
Redundancy.@odata.id
Integer
Link to power supply redundancy group.
Redundancy.@odata.type
Integer
Resource type of power supply redundancy group.
Redundancy.MemberId
String
ID of power supply redundancy group.
Redundancy.Name
String
Name of power supply redundancy group.
Redundancy.MaxNumSupported
Integer
Maximum number of power supplies supported in this redundancy group.
Redundancy.MinNumNeeded
Integer
Minimum number of power supplies supported in this redundancy group.
Redundancy.RedundancySet
Object
List of power modules included in the specified power supply redundancy group, including:
·     @odata.id—Link to the specified power module.
Redundancy.Mode
String
Power supply redundancy group mode. Supported options:
·     Sharing—Load balancing.
·     Failover—Primary/backup mode.
Redundancy.Status.Health
String
Health status of power supply redundancy group.
Redundancy.Status.State
String
Enabling status of power supply redundancy group.
Redundancy.Status.Oem.Public.Severity
String
Custom health status of power supply redundancy group.
Redundancy.Status.Oem.Public.FaultDescription
String
Fault description information of power supply redundancy group.
The overall fault information of the power group is associated with the overall component, independent of the fault information of a single component.
PowerControl
Power control information.
PowerControl.PowerAlarmInfo.PowerAlarmEnabled
Boolean
Enabling status of total power alarm.
PowerControl.PowerAlarmInfo.PowerAlarmThreshold
Integer
Threshold of total power alarm.
PowerControl.PowerAlarmInfo.Multiple
Integer
Multiplier.
PowerControl.PowerAlarmInfo.MaxPowerAlarm
Integer
Maximum value of total power alarm.
PowerControl.MaxNum
Integer
Maximum number of power supplies.
This field is unavailable for X18000.
PowerControl.PowerConsumedWatts
Integer
Current power of power supply.
PowerControl.@odata.id
String
Link to power control attributes.
PowerControl.MemberId
Integer
ID of power control attributes.
PowerControl.Name
String
Name of power control attributes.
PowerControl.PowerMetrics.MaxConsumedWatts
Integer
Maximum power consumption.
PowerControl.PowerMetrics.MinConsumedWatts
Integer
Minimum power consumption.
PowerControl.PowerLimit.CorrectionInMs
Integer
Power correction time (in milliseconds).
PowerControl.PowerLimit.LimitException
String
Action to take if the power cannot be maintained below the power cap value. Supported options:
·     NoAction—Take no action when the power cap value is exceeded.
·     HardPowerOff—Turn the power off immediately when the power cap value is exceeded.
PowerControl.PowerLimit.LimitInWatts
Integer or null
Power cap value. This field displays null if power capping is disabled.
For G6 5500 AMD/Intel models, this field indicates the power cap for the CPU node. For other models, it indicates the power cap for the board.
PowerControl.PowerLimit.PowerLimitEnable
Boolean
Power cap enabling state.
This field displays the CPU node power cap value for the G6 R5500 AMD/Intel models. For the other models, this field displays the system board power cap value.
PowerControl.Status.Health
String
Power control health status.
PowerControl.Status.State
String
Power control enabling status.
PowerControl.Oem.Public.PowerGroupCount
Integer
Number of supported power supply units for the current model.
PowerControl.Oem.Public.CurrentCPUPowerWatts
Integer
Current CPU power.
PowerControl.Oem.Public.CurrentMemoryPowerWatts
Integer
Current memory power.
PowerControl.Oem.Public.CurrentFanPowerWatts
Integer
Current fan power.
PowerControl.Oem.Public.CurrentBoardPowerWatts
Integer
Total power consumption of the board.
For G6 5500 AMD/Intel models, this field indicates the power consumption of the CPU node.
PowerControl.Oem.Public.CurrentGPUPowerWatts
Integer
Total power consumption of the GPU node.
This field is available for G6 5500 AMD/Intel models.
PowerControl.Oem.Public.OtherComponentsPowerWatts
Integer
Total power consumption of components, excluding CPUs and GPUs.
This field is supported by G6 5500 AMD/Intel models.
PowerControl.Oem.Public.CurrentDiskPowerWatts
Integer
Current drive power.
The CurrentDiskPowerWats field still exists, which has the same usage as this field and is reserved to maintain field compatibility.
PowerControl.Oem.Public.MinActivePowerCount
Array
Minimum number of primary power supplies supported by each power supply group.
PowerControl.Oem.Public.SuggestedActivePowerCount
Integer
Recommended number of primary power supplies.
This field is available only for the R4500G6.
PowerSupplies
Power supply information.
PowerSupplies.FirmwareVersion
String
Firmware version.
PowerSupplies.LineInputVoltage
Integer
Input voltage.
PowerSupplies.LineInputVoltageType
String
Input voltage type. Supported option is ACandDCWideRange.
PowerSupplies.Manufacturer
String
Manufacturer of the power supply.
PowerSupplies.Model
String
Model of the power supply.
PowerSupplies.Name
String
Name of the power supply.
PowerSupplies.PowerCapacityWatts
Integer
Power capacity of the power supply.
PowerSupplies.Oem.Pubilc.PowerID
String
ID of the power supply.
PowerSupplies.Oem.Pubilc.ActiveStandby
String
Active/standby state.
PowerSupplies.Oem.Pubilc.PowerCurrentWatts
Integer
Current input power of the power supply.
PowerSupplies.Oem.Pubilc.InputAmperage
Integer
Input electrical current of the power supply.
PowerSupplies.Oem.Pubilc.ReadingAmperes
Integer
Current reading of the electrical current sensor.
PowerSupplies.Oem.Public.SlotNumber
Integer
Slot number of the power supply.
PowerSupplies.Oem.Public.LineInputCurrent
Integer
Input current of the power supply.
PowerSupplies.Oem.Public.LineInputVoltageType
String
Custom input voltage types for the power module:
·     AC.
·     HVDC.
·     LVDC.
·     No input.
PowerSupplies.Oem.Public. PowerOutputVoltage
Integer
Output voltage of the power module.
Oem.Public.PowerOutputWatts
Integer
Output power of the power supply.
PowerSupplies.Oem.Public.PowerMaxWatts
Integer
Maximum power of the power supply.
PowerSupplies.Oem.Public.PowerInputWatts
Integer
Power input of the power supply.
PowerSupplies.Oem.Public. ActiveStandbySupported
Boolean
Power cold backup is supported.
PowerSupplies.Oem.Public.PowerGroupId
String
Power supply group to which it belongs.
PowerSupplies.Oem.Public.ManufactureDate
String
Manufacturer date of the power supply.
PowerSupplies.Redundancy
Array
List of power redundancy groups to which the power module actually belongs. Supported options:
·     @odata.id—Link to the power redundancy group.
PowerSupplyType
String
Power supply type. Supported options:
·     Unknown.
·     AC.
·     DC.
·     ACorDC.
PartNumber
String
Part number of the power supply. This field is supported only for some power supplies.
SerialNumber
String
Power supply serial number.
Status.Health
String
Health status of the power supply.
Status.State
String
Enabling status of the power supply.
String
Custom power status.
Status.Oem.Public. FaultDescription
String
Description of the power failure.
MemberId
String
ID of the power supply resource, a unique identifier of the power supply in the power supply collection.
Voltages
Voltage information.
Integer or string
Lower major alarm threshold.
LowerThresholdFatal
Integer or string
Lower critical alarm threshold.
Integer or string
Lower minor alarm threshold.
MaxReadingRange
Integer
Maximum reading.
MinReadingRange
Integer
Minimum reading.
Name
String
Sensor name.
ReadingVolts
Integer or string
·     For linear sensors, the field displays the voltage reading.
·     For non-linear sensors, supported options:
¡     Voltage fault triggerA voltage fault is triggered.
¡     Voltage fault releaseA voltage fault is removed.
SensorNumber
Integer
Sensor number.
Status.Health
String
Voltage sensor health status.
Status.State
String
Voltage sensor enabling status.
Integer
Upper major alarm threshold.
UpperThresholdFatal
Integer
Upper critical alarm threshold.
Integer
Upper minor alarm threshold.
AllPowerStatus
Power status information.
Oem.Public.HostPowerStatus
String
On and Off.
Oem.Public.JBODPowerStatus
String
This field is fixed as null.
Oem.Public.JBOGPowerStatus
String
Oem.Public.OverallPowerStatus
String
On and Off.
Oem.Public.SmartNICPowerStatus
String
Primary power supply status of the intelligent network adapter. In the current software version, this field displays null.
Change history
Version
Change description
HDM2-2.07
Added the PowerControl.Oem.Public. SuggestedActivePowerCount field.
HDM2-2.04
Added the PowerSupplies.Oem.Public.PowerInputWatts field.
HDM2-1.61
Changed the PowerControl.Oem.Public.CurrentDiskPowerWats field to PowerControl.Oem.Public.CurrentDiskPowerWatts, while the original field is still supported.
HDM2-1.58
Added the PowerControl.Oem.Public.MinActivePowerCount field.
HDM2-1.57
Added the PowerSupplies.Oem.Public.ManufactureDate field.
HDM2-1.56
Added the PowerControl.PowerLimit.PowerLimitEnable field.
HDM2-1.55
Added the PowerControl.Oem.Public.OtherComponentsPowerWatts field.
Configure power settings
Perform a power supply active/standby switchover or configure power capping for the server.
Privilege module
OemPowerControl
Locking type of the associated system
BMC configuration locking
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Chassis/chassis_id/Power
Request header:
X-Auth-Token:TOKEN
If-Match:ifmatch_value
Request body 1:
// Perform a power supply active/standby switchover:
    "PowerControl": [
            "Oem": {
                "Public": {
                    "PowerGroupId":power_group_id,
                   "PowerID":power_id,
                   "ActiveStandby":active_standby
            "Oem": {
                "Public": {
                   "PowerID":power_id,
Request body 2:
// Configure power capping state and power capping for the board or CPU node:
  "PowerControl":[
      "PowerLimit":{
        "LimitInWatts":limit_value,
        "LimitException":limit_exception
Request body 3:
// Configure the total power, including alarm status and alarm threshold:
  "PowerControl":[
      "PowerAlarmInfo":{
        "PowerAlarmEnabled":enabled,
        "PowerAlarmThreshold":threshold_value
Request body 4:
// Configure the inspection status of the cold backup power supply:
    "Oem":{
        "Public":{
            "StandbyPowerMonitoringEnabled":enabled
Parameter
Value
device_ip
TOKEN
chassis_id
ifmatch_value
Entity tag (ETag) that uniquely represents the requested resource.
To obtain the entity tag value of a resource, send a GET request to it and then obtain the ETag value from the response header.
PowerControl.Oem.Public.PowerGroupId
Power supply group ID.
String.
PowerControl.Oem.Public.PowerID
Power supply ID.
Integer.
PowerControl.Oem.Public.ActiveStandby
Power supply mode.
String. Supported options:
·     Active.
·     Standby.
Power cap value.
Integer or the null string.
The integer value range is 150 to 10000 W. If you specify a capping value, power capping is also enabled.
To disable power capping, set this field to null.
For G6 5500 AMD/Intel models, this field indicates the CPU node power limit. For the other models, it indicates the board power limit.
Action to take if the power cap value is exceeded.
·     NoActionPerform no action.
·     HardPowerOffPower off the server.
For G6 5500 AMD/Intel models, this field indicates the action to take when CPU node power capping fails. For the other models, it indicates the action to take when board power capping fails.
Total power alarm enabling status.
Boolean.
Total power alarm threshold.
Integer.
Cold backup power supply inspection status.
Boolean.
# Perform a power supply active/standby switchover.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Chassis/1/Power
Request header:
X-Auth-Token:TOKEN
Request body 1:
    "PowerControl": [
            "Oem": {
                "Public": {
                    "PowerGroupId":"1",
                    "PowerID":1,
                    "ActiveStandby":"Active"
            "Oem": {
                "Public": {
                    "PowerGroupId":"1",
                    "PowerID":2,
                    "ActiveStandby":"Standby"
Response:
    "Id": "Power",
    "Name": "Power",
    "Oem": {
        "Public": {
"StandbyPowerMonitoringEnabled":true
    "PowerControl": [
    "PowerSupplies": [
            "@odata.id": "/redfish/v1/Chassis/1/Power#/PowerSupplies/1",
            "LineInputVoltage": 236,
            "MemberId": "1",
            "Name": "PSU1",
            "Oem": {
                "Public": {
                    "InputAmperage": 566,
                    "LineInputCurrent": 566,
                    "ManufactureDate": "2023-05-31",
                    "PowerCurrentWatts": 111,
                    "PowerID": "1",
                    "PowerOutputWatts": 99,
                    "ReadingAmperes": 7929,
                    "SlotNumber": 1
            "PartNumber": "9PA8001704 S7181402841",
            "Redundancy": [
            "SerialNumber": "210213A05PH175000850",
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "LineInputVoltage": 231,
            "MemberId": "2",
            "Name": "PSU2",
            "Oem": {
                "Public": {
                    "ActiveStandby": "Standby",
                    "InputAmperage": 628,
                    "LineInputCurrent": 628,
                    "PowerCurrentWatts": 122,
                    "PowerID": "2",
                    "PowerOutputVoltage": 12.2,
                    "PowerOutputWatts": 107,
                    "ReadingAmperes": 8796,
                    "SlotNumber": 2
            "PartNumber": "9PA8001704 S6361201074",
            "Redundancy": [
            "SerialNumber": "",
            "Status": {
                "Health": "Critical",
                "Oem": {
                    "Public": {
                        "FaultDescription": "[PowerSupply]Power Supply Failure detected",
                        "Severity": "Major"
                "State": "Enabled"
    "Redundancy": [
    "Voltages": [
Response code: 200
# Configure power capping state.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
    "PowerControl": [
            "PowerLimit":{
                "LimitInWatts":766,
                "LimitException":"NoAction"
Response:
"@odata.type": "#Power.v1_5_0.Power",
    "Id": "Power",
    "Name": "Power",
    "Oem": {
        "Public": {
    "PowerControl": [
            "MaxNum": 4,
            "MemberId": 1,
            "Oem": {
                "Public": {
                    "CurrentBoardPowerWatts": 0,
                    "CurrentCPUPowerWatts": 0,
                    "CurrentDiskPowerWatts":0,
                    "CurrentDiskPowerWats": 0,
                    "CurrentFanPowerWatts": 0,
                    "CurrentGPUPowerWatts": 0,
            "PowerAlarmInfo": {
                "Multiple": 1,
                "PowerAlarmThreshold": 1500
            "PowerConsumedWatts": 0,
            "PowerLimit": {
                "LimitInWatts": 766,
                "PowerLimitEnable":true
            "PowerMetrics": {
            "Status": {
                "Health": "Ok",
                "State": "Enabled"
    "PowerSupplies": [
    "Redundancy": [
    "Voltages": [
Response code: 200
# Configure the threshold for total power alarm.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
    "PowerControl": [
            "PowerAlarmInfo": {
                "PowerAlarmEnabled":true,
                "PowerAlarmThreshold":1000
Response:
    "Id": "Power",
    "Name": "Power",
    "Oem": {
        "Public": {
    "PowerControl": [
            "MaxNum": 4,
            "MemberId": 1,
            "Oem": {
                "Public": {
            "PowerAlarmInfo": {
                "MaxPowerAlarm": 2550,
                "Multiple": 10,
                "PowerAlarmEnabled": true,
            "PowerLimit": {
            "PowerMetrics": {
            "Status": {
                "Health": "Ok",
                "State": "Enabled"
    "PowerSupplies": [
    "Redundancy": [
    "Voltages": [
Response code: 200
# Configure the inspection status of the cold backup power supply.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
    "Oem":{
        "Public":{
Response:
    "Id": "Power",
    "Name": "Power",
    "Oem": {
        "Public": {
    "PowerControl": [
            "MaxNum": 4,
            "MemberId": 1,
            "Oem": {
                "Public": {
            "PowerAlarmInfo": {
                "Multiple": 10,
            "PowerLimit": {
            "PowerMetrics": {
            "Status": {
                "Health": "Ok",
                "State": "Enabled"
    "PowerSupplies": [
    "Redundancy": [
    "Voltages": [
Response code: 200
For information about the response fields, see "Obtain power information."
Change history
Version
Change description
HDM2-1.53
Added the locking type of the associated system.
Obtain power recovery policy information
Obtain the resource for power recovery policy information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Oem/Public/PowerOnSettings
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
TOKEN
Method and URL:
GET http://192.168.18.18/redfish/v1/Chassis/1/Oem/Public/PowerOnSettings
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#PowerDefaultSettings",
    "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/PowerOnSettings",
    "@odata.type": "#PowerOnSettings.v1_0_0.PowerOnSettings",
    "Description": "Power On Settings",
    "Id": "PowerOnSettings",
    "MaxRandomDelaySeconds": 120,
    "Name": "PowerOnSettings",
    "Oem": {
        "Public": {
            "BackPlane":null,
    "PowerOnStrategy": "RestorePreviousState",
    "PowerRestoreDelayMode": "FixedDelay",
    "PowerRestoreDelaySeconds": 0
Response code: 200
Data type
@odata.context
String
OData description of the system resource model.
@odata.id
String
Link to the system resource.
@odata.type
String
Type of the system resource.
Id
String
ID of the system resource.
Name
String
Name of the system resource.
PowerOnStrategy
String
Power recovery configuration command. Supported options:
·     TurnOn—Keep power on.
·     RestorePreviousState—Restore to previous state.
·     StayOff—Keep power off.
Integer
Delay time.
String
Type of delay.
·     FixedDelay—Fixed delay time.
·     RandomDelay—Random delay time.
Integer
Maximum time for random delay setting.
Set power recovery policy
Set the resource for power recovery policy information.
Privilege module
OemPowerControl
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Chassis/chassis_id/Oem/Public/PowerOnSettings
Request header:
X-Auth-Token:TOKEN
Request body:
      "PowerOnStrategy":  power_on_strategy,
    "PowerRestoreDelayMode": delay_mode,
    "PowerRestoreDelaySeconds": delay_seconds
Parameter
Value
device_ip
chassis_id
TOKEN
PowerOnStrategy
Delay time.
Integer.
Type of delay.
Method and URL:
PATCH http://192.168.18.18/redfish/v1/Chassis/1/Oem/Public/PowerOnSettings
Request header:
X-Auth-Token:TOKEN
Request body:
      "PowerOnStrategy": "TurnOn",
    "PowerRestoreDelayMode": "RandomDelay",
    "PowerRestoreDelaySeconds": 120
Response:
    "Oem": {
        "Public": {
            "BackPlane":null,
Response code: 200
For information about the response fields, see "Obtain power recovery policy information."
Change history
Version
Change description
HDM2-1.53
Obtain information about CPU power saving
Obtain information about power saving for the CPU.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Oem/Public/CPUEnergyEfficiency
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Chassis/1/Oem/Public/CPUEnergyEfficiency
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#CPUEnergyEfficiency.CPUEnergyEfficiency/$entity",
    "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/CPUEnergyEfficiency",
    "@odata.type": "#CPUEnergyEfficiency.v1_0_0.CPUEnergyEfficiency",
    "CPUPowerAdjustment": {
        "CPUPLimit": 13,
        "CPUPState": 0
    "Description": "Get processors energy efficiency",
    "Id": "CPUEnergyEfficiency",
    "Name": "CPUEnergyEfficiency",
    "Oem": {
        "Public": {
            "BackPlane":null,
"CPUPStateValid": false,
    "ProcessorEPPProfile": "Balanced"
The BIOS offers four CPU power efficiency strategies, while Redfish provides only three. Only three corresponding strategies are available on the webpage.
Including:
·     Performance in BIOS is obtained as Performance in Redfish and displayed as Performance on the page.
·     Balanced Power in BIOS is obtained as Balanced in Redfish and displayed as Balanced on the page.
·     Balanced Performance in BIOS is obtained as Balanced in Redfish and displayed as Balanced on the page.
·     Power in BIOS is obtained as Power in Redfish and displayed as Power on the page.
Data type
@odata.context
String
OData description of the system CPU power saving information resource.
@odata.id
String
Link to the system CPU power saving information resource.
@odata.type
String
Type of CPU power saving information.
Id
String
ID of the CPU power saving information resource.
Name
String
Name of the CPU power saving information resource.
ProcessorEPPProfile
String
CPU power efficiency policy selection.
Supported options:
·     Performance.
·     Balanced.
·     Power.
String
Description of CPU power saving information resource:
CPUPLimit
Integer
Maximum P-State adjustment level supported by the current platform.
CPUPState
Integer
Current P-State level.
CPUPStateValid
Boolean
Validity of the P-State level value.
Configure CPU power saving settings
Configure information about CPU power saving.
Privilege module
OemPowerControl
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Chassis/chassis_id/Oem/Public/CPUEnergyEfficiency
Request header:
X-Auth-Token:TOKEN
Request body:
        "CPUPState": 0
    "ProcessorEPPProfile": "Power"
Parameter
Value
device_ip
TOKEN
chassis_id
ProcessorEPPProfile
·     Performance.
·     Balanced.
·     Power.
CPUPState
Integer.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Chassis/1/Oem/Public/CPUEnergyEfficiency
Request header:
X-Auth-Token:TOKEN
Request body:
        "CPUPState": 0
Response:
        "CPUPLimit": 0,
        "CPUPState": 0
    "Oem": {
        "Public": {
"CPUPStateValid": true,
Response code: 200
For information about the response fields, see "Obtain information about CPU power saving."
Change history
Version
Change description
HDM2-1.53
Obtain information about historical power resource
Obtain information about historical power resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Power/PowerHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/Power/PowerHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#PowerHistoryData.PowerHistoryData",
    "@odata.id": "/redfish/v1/Chassis/1/Power/PowerHistoryData",
    "@odata.type": "#PowerHistoryData.v1_0_0.PowerHistoryData",
    "Description": "Historical Power",
    "HistoricalCPU": [
            "avg": 65,
            "max": 65,
            "min": 65,
            "time": "2017-01-15T10:03:18+08:00"
            "avg": 468,
            "max": 468,
            "min": 468,
            "time": "2022-10-27T17:11:12+08:00"
  "Id": "PowerHistoryData",
  "Name": "PowerHistoryData",
  "Oem": {
    "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the historical power resource model.
@odata.id
String
Link to the historical power resource.
@odata.type
String
Type of the historical power resource.
Id
String
ID of the historical power resource.
Name
String
Name of the historical power resource.
String
Description of the historical power resource.
HistoricalCPU.avg
Integer
Average power value.
HistoricalCPU.max
Integer
Maximum power value.
HistoricalCPU.min
Integer
Minimum power value.
Type of delay.
HistoricalCPU.time
String
Sampling time, example format:
HistoricalCPU.Description
String or null
Description of the sampling point data.
·     Normal.
·     Unavailable.
·     Null.
Obtain sensor type collection information
Obtain the list information about sensor types.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Sensors
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Chassis/1/Sensors
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Sensors.Sensors",
    "@odata.id": "/redfish/v1/Chassis/1/Sensors",
    "@odata.type": "#SensorsCollection.SensorsCollection",
    "Description": "Sensors Collection",
    "Members": [
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Voltage"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Current"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Power"
    "Members@odata.count": 4,
    "Name": "Sensors Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the sensor list model.
@odata.id
String
Link to the sensor list resource.
@odata.type
String
Type of the sensor list resource.
Name
String
Name of the sensor list resource.
String
Description of the sensor list resource.
Members
Array
Link where the sensor member is located.
Members@odata.count
Integer
Number of sensor types.
Obtain information of sensor list for a specified type
Obtain the information of the sensor list for a specified type.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Sensors/Oem/Public/sensors_type
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
sensors_ type
Sensors type
You can obtain available sensor types from the collection information of sensor types.
Method and URL:
GET https://192.168.18.18/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature",
    "Description": "Temperature Sensor Collection",
    "Members": [
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/Inlet_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU1_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU2_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU1_DTS"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU2_DTS"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU1_VR_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU2_VR_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/PCH_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/PSU1_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/PSU2_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU1_DIMM_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU2_DIMM_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU1_PMem_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU2_PMem_Temp"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/Busbar_Zone"
            "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/Outlet_Temp"
    "Members@odata.count": 16,
    "Name": "Temperature Sensor Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
@odata.id
String
Name
String
@odata.type
String
String
Members
Array
Link where the sensor member of is located.
Members@odata.count
Integer
Number of sensor types of a specific type.
Obtain historical information about a single sensor resource
Obtain historical information about a single sensor resource.
Privilege module
Login
Request
Method and URL:
GET
https://device_ip/redfish/v1/Chassis/chassis_id/Sensors/Oem/Public/sensors_type/sensors_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
sensors_ type
Sensors type
You can obtain available sensor types from the sensor types collection.
sensors_id
Sensor ID.
You can obtain available sensor IDs from the specified list of sensor types.
Method and URL:
GET https://192.168.1.18/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU1_Temp
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Sensors_Temperature.Sensors_Temperature",
    "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/CPU1_Temp",
"@odata.type": "#SensorsInstance.v1_0_0.SensorsInstance",
"Actions": {
        "#Sensors.ResetStatistics": {
            "target": "/redfish/v1/Chassis/1/Sensors/Actions/Oem/Public/Temperature/CPU1_Temp/Sensors.ResetStatistics"
    "Description": "Temperature Sensor Instance",
    "HistoricalHigh": 87,
    "HistoryData": [
            "Average": null,
            "Maximum": null,
            "Minimum": null,
            "Time": "2017-01-15T11:40:07+08:00"
            "Average": 46,
            "Maximum": 48,
            "Minimum": 46,
            "Time": "2017-01-15T12:56:07+08:00"
            "Average": null,
            "Maximum": null,
            "Minimum": null,
            "Time": "2017-01-15T14:27:20+08:00"
    "LastDay": {
        "Average": 84,
        "Maximum": 87,
        "Minimum": 45
    "LastWeek": {
        "Average": 84,
        "Maximum": 87,
        "Minimum": 42
    "Oem": {
        "Public": {
    "SpecifiedTime": {
        "Average": 4294967295,
        "EndTime": null,
        "MaxEndTime": "2017-01-15T11:44:19+08:00",
        "Maximum": 4294967295,
        "MinStartTime": "2017-01-15T11:40:07+08:00",
        "Minimum": 4294967295,
        "StartTime": null
    "StartTime": "1970-01-01T08:00:00+08:00",
    "TimeStamp": "2017-01-15T12:33:54+08:00"
Response code: 200
Data type
@odata.context
String
OData description of a single sensor resource model.
@odata.id
String
Link to a single sensor resource
@odata.type
String
Type of a single sensor resource.
Actions
The actions that can be performed on the Sensors resource.
Object
Link to the recalculate operation.
String
Description of a single sensor resource.
HistoricalHigh
Integer
Maximum of historical value.
TimeStamp
String
Maximum time of historical value.
StartTime
String
Start time of the statistical calculation.
LastDay
Object
The sensor information of the most recent day.
LastWeek
Object
The sensor information of the most recent week.
SpecifiedTime
Object
Sensor information for a specified time period.
Average
Integer
Average value.
Maximum
Integer
Maximum value.
Minimum
Integer
Minimum value.
SpecifiedTime.StartTime
String
Start time for statistical calculation of sensor data for a specified time period.
SpecifiedTime.EndTime
String
End time for statistical calculation of sensor data for a specified time period.
SpecifiedTime.MinStartTime
String
The earliest time you can start statistical calculation for the specified time period.
SpecifiedTime.MaxEndTime
String
The latest time by which you must complete statistical calculation for the specified time period.
HistoryData.Description
String or null
·     Normal.
·     Unavailable.
·     Null.
HistoryData
Array
Historical data.
Time
String
Sampling time.
Recalculate highest historical temperature information for sensor
Recalculate the highest historical temperature information for the specified sensor.
Privilege module
OemDiagnosis
Request
Method and URL:
POST
https://device_ip/redfish/v1/Chassis/chassis_id/Sensors/Actions/Oem/Public/sensors_type/sensors_id/Sensors.ResetStatistics
Request header:
X-Auth-Token:TOKEN
Request body:
// Recalculate highest historical temperature information based on current time:
// Calculate highest historical temperature information for a specified time period:
    "SpecifiedTime": {
        "StartTime": "2019-02-14T20:21:36+08:00",
        "EndTime": "2019-03-14T20:21:36+08:00"
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
chassis_id
sensors_ type
Sensors type
Obtained information on a collection of sensor types by querying.
sensors_id
Sensor ID.
Obtained information on a specified list of sensor types by querying.
Start time for the specified time period.
Redfish standard format.
For example:
2019-02-14T20:21:36+08:00.
End time for the specified time period.
For example: 2019-02-14T20:21:36+08:00.
Start and end times must be specified together, otherwise the historical temperature information will be recalculated based on the current time.
# Recalculate the highest historical temperature information based on the current time.
Method and URL:
POST https://192.168.1.18/redfish/v1/Chassis/1/Sensors/Actions/Oem/Public/Temperature/TEST2_Threshold/Sensors.ResetStatistics
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
    "@odata.id": "/redfish/v1/Chassis/1/Sensors/Oem/Public/Temperature/TEST2_Threshold",
    "Description": "Temperature Instance",
    "HistoricalHigh": 100,
    "HistoryData": [
            "Average": null,
            "Maximum": null,
            "Minimum": null,
            "Time": "2017-01-15T15:36:59+08:00"
            "Average": 46,
            "Maximum": 48,
            "Minimum": 46,
            "Time": "2017-01-15T18:04:23+08:00"
            "Average": null,
            "Maximum": null,
            "Minimum": null,
            "Time": "2017-01-15T20:21:41+08:00"
    "LastDay": {
        "Average": 50,
        "Maximum": 100,
        "Minimum": 0
    "LastWeek": {
        "Average": 50,
        "Maximum": 100,
        "Minimum": 0
    "SpecifiedTime": null,
    "Oem": {
        "Public": {
            "CompletionCode": 0,
    "TimeStamp": "2017-01-15T14:03:56+08:00"
Response code: 200
# Calculate the highest historical temperature information for the specified time period.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
    "SpecifiedTime": {
Response:
    "HistoricalHigh": 100.0,
    "HistoryData": [
            "Average": null,
            "Maximum": null,
            "Minimum": null,
            "Average": 46,
            "Maximum": 48,
            "Minimum": 46,
            "Average": null,
            "Maximum": null,
            "Minimum": null,
    "LastDay": {
        "Average": 50.75,
        "Maximum": 100.0,
        "Minimum": 0.0
    "LastWeek": {
        "Average": 50.75,
        "Maximum": 100.0,
        "Minimum": 0.0
    "SpecifiedTime": {
        "Average": 50.75,
        "Maximum": 100.0,
        "Minimum": 0.0
    "Oem": {
        "Public": {
Response code: 200
Response field description
For information about the response fields, see "Obtain historical information about a single sensor resource."
The server returns status code 200 for a successful operation.
Obtain module collection information
Obtain information about all modules in the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Boards
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
TOKEN
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/Boards
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#BoardsCollection.BoardsCollection",
    "@odata.id": "/redfish/v1/Chassis/1/Boards/",
    "@odata.type": "#BoardsCollection.BoardsCollection",
    "Members": [
            "@odata.id": "/redfish/v1/Chassis/1/Boards/Motherboard"
            "@odata.id": "/redfish/v1/Chassis/1/Boards/DSDCard"
            "@odata.id": "/redfish/v1/Chassis/1/Boards/LiquidCooler"
            "@odata.id": "/redfish/v1/Chassis/1/Boards/BMCCard"
            "@odata.id": "/redfish/v1/Chassis/1/Boards/Other"
    "Members@odata.count": 5,
    "Name": "Boards Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the module collection resource model.
@odata.id
String
Link to the module collection resource.
@odata.type
String
Type of the module collection resource.
Members
Array
Links to module resources.
Name
String
Name of the module collection resource.
Members@odata.count
Integer
Number of modules installed on the server.
Obtain module information
Obtain information about a specific module from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Boards/board_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
board_id
ID of the module resource.
You can obtain available module resource IDs from module collection information.
TOKEN
# Obtain the module information for the Motherboard.
Method and URL:
GET https://192.168.46.246/redfish/v1/Chassis/1/Boards/Motherboard
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#BoardsInstance.BoardsInstance",
    "@odata.id": "/redfish/v1/Chassis/1/Boards/Motherboard",
    "@odata.type": "#Boards.v1_0_0.Boards",
    "BoardId": null,
    "DeviceId": null,
    "Id": "Motherboard",
    "ManufactureDate": "2017-01-10T05:14:00+08:00",
    "Manufacturer": "N/A",
    "Model": "RS33M2C9S",
    "Name": "Motherboard",
    "Oem": {
        "Public": {
            "BMCCard": null,
            "CPLDVersion": "V001AD",
            "CPLD1Version": "V001AD",
            "CPLD2Version": "V001AC",
            "DeviceType": "MainBoard",
            "ExpandedBoard": null,
            "MainBoard": null,
            "PCBVersion": "VER.B",
"Retimer": null,
            "SCPLDVersion": "V001AC",
            "SubDeviceType": null,
"TopoType": null,
            "iFIST": null
    "PartNumber": "0231A111",
    "ProductName": "RS33M2C9S",
    "SerialNumber": "210231A1110000000001",
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
    "Version": ""
Response code: 200
# Obtain the module information for Riser2.
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/Boards/Riser2
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/Chassis/1/Boards/Riser2",
    "BoardId": null,
    "DeviceId": null,
    "Id": "Riser2",
    "ManufactureDate": "2017-06-20T23:46:00+08:00",
    "Manufacturer": "H3C",
    "Model": "RS32B12L",
    "Name": "Riser2",
    "Oem": {
        "Public": {
            "BMCCard": null,
            "CPLD1Version": null,
            "CPLD2Version": null,
            "CPLDVersion": null,
            "DeviceType": "PCIeConventor",
            "MainBoard": null,
            "PCBVersion": "VER.A",
"Retimer": null,
            "SCPLDVersion": null,
            "SubDeviceType": "Riser",
"TopoType": null,
            "iFIST": null
    "PartNumber": "0302A2N3",
    "ProductName": "RS32B12L",
    "SerialNumber": "02A2N31234567890",
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
    "Version": ""
Response code: 200
# Obtain the BMC card information.
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/Boards/BMCCard
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/Chassis/1/Boards/BMCCard",
    "BoardId": null,
    "DeviceId": null,
    "Id": "BMCCard",
    "Name": "BMCCard",
    "Oem": {
        "Public": {
            "BMCCard": {
                "BackUpMode": "Golden Image",
                "ChipManufacture":"ASPEED",
                "ChipModel":"AST2600"
                "ECCCount": 0,
                "ImageState": "Normal",
                "ProcessStartupResult": "Successful",
                "RAMState": "Normal",
                "SDCardState": "Enabled",
                "UECCCount": 0,
                "VARMSizeMB": 64
            "CPLD1Version": "V001A5",
            "CPLDVersion": "V001A5",
            "DeviceType": "BMCCard",
            "MainBoard": null,
            "PCBVersion": "",
"Retimer": null,
"TopoType": null,
            "iFIST": {
                "SDCardSizeGB": null,
                "SDCardState": "Absent",
                "Version": null,
                "iFISTState": "Absent"
    "SerialNumber": "210231A8L0H199BING",
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
    "Version": ""
Response code: 200
# Obtain the FrontBackplane1 information.
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/Boards/FrontBackplane1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/Chassis/1/Boards/FrontBackplane1",
    "BoardId": null,
    "DeviceId": null,
    "Id": "FrontBackplane1",
    "ManufactureDate": "2023-01-16T17:12:00+08:00",
    "Model": "RS36B08SUF",
    "Name": "FrontBackplane1",
    "Oem": {
        "Public": {
            "BMCCard": null,
            "BackPlane": {
                "DrivesCount": 1,
                "PortCount": 8,
                "Type": "Unibay"
            "CPLD1Version": "V004",
            "CPLDVersion": "V004",
            "DeviceType": "BackPlane",
            "MainBoard": null,
"Retimer": null,
"TopoType": null,
            "iFIST": null
    "PartNumber": "9803A077",
    "ProductName": "RS36B08SUF",
    "SerialNumber": "219803A0776231V00008",
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
    "Version": ""
Response code: 200
# Obtain the GPU board information.
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/Boards/GPUBoard
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/Chassis/1/Boards/GPUBoard",
    "BoardId": null,
    "DeviceId": null,
    "Id": "GPUBoard",
    "ManufactureDate": "",
    "Manufacturer": "",
    "Model": "",
    "Name": "GPUBoard",
    "Oem": {
       "Public": {
            "BMCCard": null,
            "BackPlane": null,
            "Description": "Success",
            "DeviceType": "BoardAdapter",
            "MainBoard": null,
"Retimer": null,
            "SubDeviceType": "GPUAdapter",
            "TopoType": "Switch_X32",
            "iFIST": null
    "PartNumber": "",
    "ProductName": "",
    "SerialNumber": "",
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
    "Version": ""
Response code: 200
# Obtain the Retimer information.
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/Boards/Retimer1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/Chassis/1/Boards/Retimer1",
    "BoardId": null,
    "DeviceId": null,
    "Id": "Retimer1",
    "ManufactureDate": null,
    "Manufacturer": null,
    "Model": null,
    "Name": "Retimer1",
    "Oem": {
         "Public": {
            "BMCCard": null,
            "BackPlane": null,
            "MainBoard": null,
            "PCBVersion": null,
            "Retimer": {
                "CurrentFirmwareVersion": "0x689A000"
            "SubDeviceType": "Retimer",
            "TopoType": null,
            "iFIST": null
    "PartNumber": null,
    "ProductName": null,
    "SerialNumber": null,
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
    "Version": null
Response code: 200
Data type
@odata.context
String
OData description of the module resource model.
@odata.id
String
Link to the module resource.
@odata.type
String
Type of the module resource.
BoardId
String
Privilege module ID.
DeviceId
String
Device ID.
Id
String
ManufactureDate
String
Date of manufacture.
Manufacturer
String
Manufacturer.
PartNumber
String
Part number.
ProductName
String
Product name.
SerialNumber
String
Serial number.
Model
String
Model.
Status.Health
String
Health status of the module.
Status.State
String
Enabling status of the module.
Status.Oem.Public. Severity
String
Custom health status for the module.
String
Fault description information for the module.
Version
String
Privilege module version.
Name
String
Privilege module resource name.
Oem.Public.DeviceType
String
Type of the primary module.
Supported options:
·     MainBoardMainboard.
·     CalculationModule—computing node.
·     CPUBoard—CPU daughter board.
·     BackPlaneHard drive backplane.
·     PDBPower board.
·     MDBMid-plane backplane.
·     ExpanderExpansion board.
·     PCIeConventor—PCIe adapter card.
·     DiagPanelDiagnostic panel.
·     GPUPanel—GPU panel.
·     SecurityBezelSecurity panel.
·     BMCCardManagement module.
·     BoardAdapterAdapter module.
·     OtherOther components.
Oem.Public.SubDeviceType
String
Type of the secondary module. Supported options:
·     SASSwitch—SAS expansion board.
·     PCIeSwitch—PCIe expansion board.
·     Retimer—Retimer card.
·     Redriver—Redriver card.
·     Riser—Riser card.
·     M2Conventor—M.2 adapter card.
·     OPCconventor—OCP adapter card.
·     LOMConventor—LOM adapter card.
·     MEZZConventor—Mezzanine adapter card.
·     HotPlugRiser— Hot-pluggable riser.
·     ClockCard—Clock card.
·     DeltaNextBoard—GPU module (delta-next module).
Oem.Public.CPLDVersion
String
Single-board CPLD version.
Oem.Public.Retimer.CurrentFirmwareVersion
String
Current firmware version of the Retimer card.
Oem.Public.PCBVersion
String
PCB version.
Oem.Public.SCPLDVersion
String
SCPLD version information, such as auxiliary CPLD for the mainboard or backplane.
Oem.Public.CPLD1Version
String
CPLD 1 version, same as the CPLD version.
Oem.Public.CPLD2Version
String
CPLD 2 version, same as the SCPLD version.
Oem.Public.TopoType
String
GPU topology type.
Oem.Public.ExpandedBoard.CurrentFirmwareVersion
String
Current firmware version of the module chip.
Oem.Public.ExpandedBoard.CurrentConfigurationVersion
String
Current configuration file version of the module chip.
Oem.Public.ExpandedBoard.BootloaderVersion
String
Module chip bootloader version.
Oem.Public.ExpandedBoard.EEPROMVersion
String
Module chip EEPROM version.
Oem.Public.MainBoard.PFRCPLDVersion
String
Mainboard PFRCPLD version.
Oem.Public.BackPlane.DrivesCount
Integer
Number of backplane drives in place.
Oem.Public.BackPlane.PortCount
Integer
Number of backplane ports.
Oem.Public.BackPlane.Type
String
Backplane type.
Oem.Public.BMCCard.BackUpMode
String
Backup plan.
Oem.Public.BMCCard.ChipManufacture
String
BMC chip manufacturer.
Oem.Public.BMCCard.ChipModel
String
BMC chip model.
Oem.Public.BMCCard.SDCardState
String
SD card status.
Absent/Enabled/PartLose/AccessFailed
Not present/Normal/Partition lost/Access failed.
Oem.Public.BMCCard.ECCCount
Integer
BMC card memory ECC count during abnormal state.
Oem.Public.BMCCard.UECCCount
Integer
BMC card memory UECC count during abnormal state.
Oem.Public.BMCCard.RAMState
String
BMC card memory status: Normal or Error.
Oem.Public.BMCCard.VARMSizeMB
Integer
Video memory size, in MB.
Oem.Public.BMCCard.ProcessStartupResult
String
Whether the key process started successfully.
Supported options:
·     Successful.
·     Failed.
Oem.Public.BMCCard.ImageState
String
Image status. Supported options:
·     Normal.
·     Error.
Oem.Public.iFIST.iFISTState
String
IFIST status. Supported options:
·     Absent.
·     Enabled.
Oem.Public.iFIST.SDCardState
String
Status of the iFIST SD card.
Supported options:
·     Absent.
·     Enabled.
Oem.Public.iFIST.SDCardSizeGB
Integer
Capacity of the iFIST SD card.
Oem.Public.iFIST.Version
String
Information of the iFIST version.
Change history
Version
Change description
HDM2-2.17
Added the Oem.Public.Retimer.CurrentFirmwareVersion field.
HDM2-2.16
HDM2-1.79
HDM3-2.03
Added the Oem.Public.TopoType field.
HDM2-2.04
Added the Oem.Public.BackPlane.DrivesCount, Oem.Public.BackPlane.PortCount, and Oem.Public.BackPlane.Type fields.
HDM2-1.58
Added the Oem.Public.BMCCard.ChipManufacture and Oem.Public.BMCCard.ChipModel fields.
HDM2-1.55
·     Added the BoardAdapter option to the DeviceType field.
·     Added the DeltaNextBoard option to the SubDeviceType field.
HDM2-1.54
·     Changed Baseboard to Motherboard in the example.
·     Deleted the SMC option from the Oem.Public.DeviceType field.
·     Modified the description of the BMCCard option in the Oem.Public.DeviceType to management module.
·     Added the Oem.Public.CPLD1Version and Oem.Public.CPLD2Version fields.
Obtain PCIe module collection information
Obtain information about all PCIe modules in the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/PCIeDevices
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
TOKEN
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/PCIeDevices
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
Response:
    "@odata.context": "/redfish/v1/$metadata#PCIeDevicesCollection.PCIeDevicesCollection(*)",
    "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices",
    "@odata.type": "#PCIeDeviceCollection.PCIeDeviceCollection",
    "Members": [
            "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/3"
    "Members@odata.count": 1,
    "Name": "PCIeDevices Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the PCIe module collection resource model.
@odata.id
String
Link to the PCIe module collection resource.
@odata.type
String
Type of the PCIe module collection resource.
Members
Integer
Links to PCIe module resources.
Members@odata.count
Integer
Number of PCIe modules.
Name
String
Name of the PCIe module collection resource.
Obtain PCIe module information
Obtain information about a specific PCIe module from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/PCIeDevices/pciedevices_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
pciedevices_id
ID of the PCIe module resource.
You can obtain available PCIe module resource IDs from PCIe module collection information.
TOKEN
# For PCIe modules other than GPU modules:
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/PCIeDevices/23
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#PCIeDevice.PCIeDevice",
    "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/23",
"@odata.type": "#PCIeDevice.v1_5_0.PCIeDevice",
"CardManufacturer": null,
"CardModel": null,
    "Description": "OCP-1",
    "FirmwareVersion": "N/A",
    "Id": "PCIeCard23",
    "Links": {
        "Chassis": [
                "@odata.id": "/redfish/v1/Chassis/1"
        "PCIeFunctions": [
                "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/23/Functions/1"
    "Model": "NIC-ETH640F-3S-2P",
    "Name": "NIC-ETH640F-3S-2P",
    "Oem": {
        "Public": {
            "ChipManufacturer": "Mellanox",
            "ChipModel": "ConnectX-4",
            "DeviceLocator": "PCIe Card23",
            "PCIeCardType": "NIC",
            "Position": 23,
            "SlotNumber": 23
    "PCIeInterface": {
        "LanesInUse": 8,
        "MaxLanes": 8
    "PartNumber": "0302A2N4",
    "SerialNumber": "222235A022B2B221A",
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
Response code: 200
# For GPU modules:
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/PCIeDevices/5
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/5",
"@odata.type": "#PCIeDevice.v1_2_0.PCIeDevice",
"CardModel": null,
    "Description": "",
    "FirmwareVersion": "88.00.1A.00.03",
    "Id": "PCIeCard5",
    "Links": {
        "Chassis": [
        "PCIeFunctions": [
                "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/5/Functions/1"
    "Manufacturer": "NVIDIA",
    "Model": "Tesla V100-PCIE-16G",
    "Name": "Tesla V100-PCIE-16G",
    "Oem": {
        "Public": {
            "ChipManufacturer": "NVIDIA",
            "ChipModel": "",
            "DeviceLocator": "PCIe Card5",
"DriverVersion": "N/A",
            "ECCEnable": 1,
            "GCUVoltage": 0.75,
            "GPUDeviceError": 16384,
            "GPUMemoryError": 16384,
            "HBMVoltage": 1.25,
            "MemorySizeMiB": 16384,
"PCIeBusError": 16384,
            "PCIeCardType": "GPU",
            "Position": 5,
            "PowerCapacityWatts": 70,
            "PowerWatts": 70,
"ProductDate": "20240517",
"SlotMapping":"OAM2",
            "SlotNumber": 5
    "PCIeInterface": {
        "LanesInUse": 16,
        "MaxLanes": null
"PartNumber": "0302A2N9",
    "SerialNumber": "0323617020478",
    "Status": {
        "Health": "OK",
         "Oem": {
            "Public": {
        "State": "Enabled"
Response code: 200
Data type
@odata.context
String
OData description of the PCIe module resource model.
@odata.id
String
Link to the PCIe module resource.
@odata.type
String
Type of the PCIe module resource.
CardManufacturer
String
Manufacturer of the PCIe module resource.
CardModel
String
Device model of the PCIe module resource.
String
Description of the PCIe module.
FirmwareVersion
String
Firmware version of the PCIe module.
Id
String
Links.Chassis
Array
Link to a chassis resource.
Links.PCIeFunctions
Array
Link to a PCIe function.
PCIeInterface.LanesInUse
Integer
Number of PCIe lanes currently negotiated by the PCIe module.
PCIeInterface.MaxLanes
Integer
Maximum number of PCIe lanes supported by the PCIe module.
Manufacturer
String
Manufacturer of the PCIe module.
Model
String
PCIe module model.
Name
String
PCIe module resource name.
SerialNumber
String
PCIe module serial number.
PartNumber
String
PCIe module part number.
Oem.Public.ChipManufacturer
String
PCIe module chip manufacturer.
Oem.Public.ChipModel
String
PCIe module chip model.
Oem.Public.DeviceLocator
String
PCIe module silkscreen.
Oem.Public.PCIeCardType
String
Type of the PCIe module. Supported options:
·     GPU.
·     FPGA.
·     NIC.
·     RAID.
·     SAS.
·     FC.
·     IB.
·     OEM.
·     QAT.
·     SWITCH.
·     PCIE_AUX.
Oem.Public.Position
Integer
PCIe module container.
Integer
Slot number of the PCIe module.
Oem.Public.FunctionType
String
Type of the PCIe module. This field is not supported.
Oem.Public.McuFirmwareVersion
String
MCU firmware version of the PCIe module. This field is not supported.
Oem.Public.PowerWatts
Integer
Current power of the specified PCIe module. (GPU)
Note that some NVIDIA GPUs require the installation of drivers and you must execute the nvidia-smi -pm 1 command to obtain the current power information.
Oem.Public.PowerCapacityWatts
Integer
Rated power of the specified PCIe modules. (GPU)
Oem.Public.MemorySizeMiB
Integer
Video memory capacity of the specified PCIe module. (GPU)
Oem.Public.SlotMapping
String
Slot mapping (GPU) with the actual physical slot of a PCIe device.
Oem.Public.DriverVersion
String
Driver version (only supported by the Enflame S60 GPU).
Oem.Public.ECCEnable
String
Enabling status of ECC (only supported by the Enflame S60 GPU).
Oem.Public.GCUVoltage
Value
GCU voltage (only supported by the Enflame S60 GPU). The unit is V.
Oem.Public.HBMVoltage
Value
HBM voltage (only supported by the Enflame S60 GPU). The unit is V.
Oem.Public.GPUDeviceError
Value
GPU device error (only supported by the Enflame S60 GPU). Values include:
·     0: Represents healthy.
·     16384: Represents that a recoverable error has occurred on the acceleration module.
·     32768: Represents that a non-recoverable error has occurred on the acceleration module peripheral.
Oem.Public.PCIeBusError
Integer
PCIe error (only supported by the Enflame S60 GPU). Values include:
·     16384: Represents that a recoverable error has occurred on the acceleration module peripheral.
·     32768: Represents that a non-recoverable error has occurred on the acceleration module.
Oem.Public.GPUMemoryError
Integer
GPU memory error (only supported by the Enflame S60 GPU). Values include:
·     16384: Represents that a recoverable error has occurred on the acceleration module VRAM.
·     32768: Represents that a non-recoverable error has occurred on the acceleration module VRAM.
Oem.Public.ProductDate
String
Product production date (only supported by the Enflame S60 GPU). Values include:
Status.Health
String
PCIe module resource health status rated power.
Status.State
String
PCIe module resource enabled state video memory.
String
Custom health status serial number for PCIe module resources.
String
Fault description information for PCIe module resources.
Change history
Version
Change description
HDM2-2.10
Added the Oem.Public.DriverVersion, Oem.Public.ECCEnable, Oem.Public.GCUVoltage, Oem.Public.HBMVoltage, Oem.Public.GPUDeviceError, Oem.Public.PCIeBusError, Oem.Public.GPUMemoryError, and Oem.Public.ProductDate fields.
HDM2-2.04
Added the CardManufacturer and CardModel fields.
HDM2-2.04
Added the Oem.Public.SlotMapping field.
HDM2-2.04
Added the PCIE_AUX option to the Oem.Public.PCIeCardType field.
HDM2-1.53
Modified description of the FirmwareVersion field.
Obtain PCIe function information
Obtain information about the function of a specific PCIe module from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/PCIeDevices/pciedevices_id/Functions/1
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
Request body:
N/A
Parameter
Value
device_ip
chassis_id
ID of the chassis resource.
Only value 1 is supported.
pciedevices_id
ID of the PCIe module.
You can obtain available PCIe module IDs from PCIe module collection information.
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/PCIeDevices/23/Functions/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#PCIeDevicesFunctionsInstance.PCIeDevicesFunctionsInstance",
    "@odata.id": "/redfish/v1/Chassis/23/PCIeDevices/23/Functions/1",
    "@odata.type": "#PCIeFunction.v1_3_0.PCIeFunction",
    "DeviceId": "0x1015",
    "Id": "1",
    "Name": "Function1",
    "Oem": {
        "Public": {
            "BDF": null,
            "BusNumber": "0x16",
            "CPUId": "1",
            "Datawidth": "x8",
            "DeviceClass": "SignalProcessingController",
            "DeviceNumber": "0",
            "FunctionNumber": "0",
            "MaxDatawidth": "x16",
            "MaxSpeed": "8.0GT/s",
            "MezzSlot": null,
            "MaxProtocol": "Gen 3",
            "Negotiatedspeed": "8.0GT/s",
            "Protocol": "Gen 3",
            "RiserId": "N/A",
            "LinkWidthAbility":"x16"
            "RootBDF": null
    "ProductName": "NIC-ETH640F-3S-2P",
    "Status": {
        "Health": "OK",
        "State": "Enabled"
    "SubsystemId": "0x1083",
    "SubsystemVendorId": "0x193D",
    "VendorId": "0x15B3"
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
DeviceId
String
VendorId
String
Manufacturer ID.
Id
String
ID of the PCIe function resource.
SubsystemId
String
Subsystem ID.
SubsystemVendorId
String
Subsystem manufacturer ID.
Manufacturer
String
Manufacturer.
PartNumber
String
Part number.
ProductName
String
Product name.
SerialNumber
String
Serial number.
Status
Object
PCIe module status:
·     Health—Health status.
·     State—Enabling status.
Oem.Public.BDF
String
Device resource attributes.
Oem.Public.RootBDF
String
Port resource attributes.
Oem.Public.Datawidth
String
Negotiated link width.
Oem.Public.MaxDatawidth
String
Maximum bandwidth.
Oem.Public.MaxSpeed
String
Maximum speed.
Oem.Public.LinkWidthAbility
String
Maximum bandwidth.
Oem.Public.Negotiatedspeed
String
Negotiated speed.
Oem.Public.Protocol
String
Negotiated protocol.
Oem.Public.Slot
String
PCIe slot number.
Oem.Public.RiserId
String
Riser number.
Oem.Public.CPUId
String
Associated CPU.
Oem.Public.MezzSlot
String
Mezz slot.
Oem.Public.BusNumber
String
Bus number of the PCIe module.
Oem.Public.DeviceClass
String
Class of the PCIe module.
Oem.Public.DeviceNumber
String
PCIe module number.
Oem.Public.FunctionNumber
String
PCIe function number.
Oem.Public.MaxProtocol
String
Highest PCIe protocol.
Name
String
PCIe function resource name.
Change history
Version
Change description
HDM3-1.14
Added the Oem.Public.BDF and Oem.Public.RootBDF fields and synchronized them to HDM3.
HDM2-2.04
Added the Oem.Public.BDF and Oem.Public. RootBDF fields.
Obtain network adapter collection information
Obtain information about all network adapters in the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/NetworkAdapters
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
chassis_id
TOKEN
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/NetworkAdapters
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#NetworkAdapterCollection.NetworkAdapterCollection",
    "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters",
    "@odata.type": "#NetworkAdapterCollection.NetworkAdapterCollection",
    "Description": "Collection of ethernet interfaces for this system",
    "Members": [
            "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot1"
    "Name": "NetworkAdapter Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the network adapter collection resource model.
@odata.id
String
Link to the network adapter collection resource.
@odata.type
String
Type of the network adapter collection resource.
String
Description of the network adapter collection resource.
Members
Links to network adapter resources.
@odata.id
String
Link to a network adapter resource.
Members@odata.count
Integer
Number of installed network adapters.
Name
String
Name of the network adapter resource.
Obtain network adapter information
Obtain information about a specific network adapter from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/NetworkAdapters/networkadapter_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
networkadapter_id
ID of the network adapter resource.
You can obtain available network adapter resource IDs from network adapter collection information.
# Obtain information for the specified NIC controller.
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot16
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response 1:
    "@odata.context": "/redfish/v1/$metadata",
    "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot16",
    "@odata.type": "#NetworkAdapter.v1_5_0.NetworkAdapter",
    "Controllers": [
            "ControllerCapabilities": {
                "NetworkPortCount": 2
            "FirmwarePackageVersion": "2.0",
            "Links": {
                "NetworkPorts": [
                        "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot16/NetworkPorts/1"
                        "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot16/NetworkPorts/2"
                "NetworkPorts@odata.count": 2,
                "PCIeDevices": [
                        "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/16"
                "PCIeDevices@odata.count": 1
    "Id": "PCIeSlot16",
    "Manufacturer": "Intel",
    "Model": "NIC-ETH660F-3S-2P",
    "Name": "PCIeSlot16",
    "NetworkPorts": {
        "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot16/NetworkPorts"
    "Oem": {
        "Public": {
            "CapableSpeedGbs": "25",
            "CardManufacturer": "H3C",
"CardMode": "NPAR",
            "CardModel": "2*25GE",
            "ChipModel": "E810",
            "Configuration":{
               "CardTypeCode": "0302A5FQ",
               "DataOrigin": 2,
               "EffectiveLink": 0,
               "MultifunctionMode": "NPAR",
               "NPARLink": 44000,
"NPARPort": [],
               "PortsConfig": [
                       "16GFECConfig": "Disabled",
                       "ConnectionType": "Switch",
                       "PFsInfo": [
                               "FCoEFipMACAddress": "14:58:D0:D3:00:02",
                               "ISCSIAddress": "00:0a:f7:10:d8:71",
                               "PermanentAddress": "14:58:D0:D3:00:02",
                               "Protocol": "ETHERNET",
                               "WWNN": ":14:58:D0:D3:00:02",
                               "WWPN": ":14:58:D0:D3:00:02"
                       "PortId": "0"
            "DeviceLocator": "PCIe Card16",
            "FirmwareVersion": "2.0",
"MCTPEnabled":false,
            "MezzSlot":"Mezz2",
            "NetworkTechnology": [
                "Ethernet"
            "OCPFan": {
                "Status": {
                    "Oem": {
                        "Public": {
                            "FaultDescription": "[PCIe_Card16]Fault Status asserted:---fan error in slot 16",
                            "Severity": "Major"
                    "State": "Absent"
            "PartNumber": "0302A5L9",
            "Position": "PCIe-16",
            "RootBDF": "0000:15:01.0",
            "SerialNumber": "02A5L902110M000G",
            "SlotNumber": 16,
            "TemperatureCelsius": 41
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
                "FaultDescription": "",
                "Severity": "Informational"
        "State": "Enabled"
Response code: 200
# Obtain information for the specified FC controller.
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot6
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response 2:
    "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot6",
    "Controllers": [
            "FirmwarePackageVersion": "12.8.351.47",
            "Links": {
                "NetworkPorts": [
                        "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot6/NetworkPorts/1"
                        "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot6/NetworkPorts/2"
                "PCIeDevices": [
                        "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/6"
    "Id": "PCIeSlot6",
    "Manufacturer": "Emulex",
    "Model": "FC-HBA-LPe35002-LP-32Gb-2P",
    "Name": "PCIeSlot6",
    "NetworkPorts": {
        "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot6/NetworkPorts"
    "Oem": {
        "Public": {
            "CapableSpeedGbs": "32",
            "CardManufacturer": "Emulex",
"CardMode": null,
            "CardModel": "2*32GE",
            "ChipModel": "XE601",
            "Configuration":{
               "DataOrigin": 2,
               "EffectiveLink": 0,
               "NPARLink": 44000,
"NPARPort": [],
               "PortsConfig": [
                       "PFsInfo": [
                       "PortId": "0"
            "DeviceLocator": "PCIe Card6",
            "FirmwareVersion": "12.8.351.47",
            "MezzSlot":"Mezz2",
                "FC"
            "PartNumber": null,
            "Position": "PCIe6",
            "ProductCode": "FC HBA",
            "RootBDF": null,
            "SlotNumber": 6,
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Disabled"
Response code: 200
# Obtain information for the specified eth682i controller.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response 3:
    "Controllers": [
            "Links": {
               "NetworkPorts": [
                "PCIeDevices": [
            "Id": "PCIeSlot5",
            "Manufacturer": "QLogic",
            "Model": "NIC-ETH682i-Mb-2*25G",
            "Name": "PCIeSlot5",
            "NetworkPorts": {
                "@odata.context": "/redfish/v1/$metadata#NetworkPortCollection.NetworkPortCollection(*)",
                "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot5/NetworkPorts",
                "@odata.type": "#NetworkPortCollection.NetworkPortCollection",
                "Members": [
                        "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot5/NetworkPorts/1"
                        "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot5/NetworkPorts/2"
                "Members@odata.count": 2,
                "Name": "Network Port Collection"
            "Oem": {
                "Public": {
                    "CardMode": "Single",
                    "ChipModel": "QL41401 A2",
                    "Configuration": {
                        "CardTypeCode": "0302A5K7",
                        "DataOrigin": 3,
                        "EffectiveLink": 65535,
                        "MultifunctionMode": "QINQ_NPAR",
                        "NPARLink": 0,
                        "NPARPort": [
                                "Port": 0
                                "Port": 1
                                "Port": 2
                                "Port": 3
                                "Port": 4
                                "Port": 5
                                "Port": 6
                                "Port": 7
                                "Port": 8
                                "Port": 9
                                "Port": 10
                                "Port": 11
                                "Port": 12
                                "Port": 13
                                "Port": 14
                                "Port": 15
                            "PortsConfig": [
                                "16GFECConfig": null,
                                "ConnectionType": null,
                                "PFsInfo": [
                                       "FCoEFipMACAddress": "AC:BD:E2:50:28:EC",
                                       "ISCSIAddress": "AC:BD:E2:50:28:EE",
                                       "PermanentAddress": "AC:BD:E2:50:28:EA",
                                       "Protocol": "UNDI",
                                       "WWNN": "10:00:AC:BD:E2:50:28:EC",
                                       "WWPN": "20:00:AC:BD:E2:50:28:EC"
                                "PortId": "0"
                                "PFsInfo": [
                                        "FCoEFipMACAddress": "AC:BD:E2:50:28:ED",
                                        "ISCSIAddress": "AC:BD:E2:50:28:EF",
                                        "PermanentAddress": "AC:BD:E2:50:28:EB",
                                        "Protocol": "UNDI",
                                        "WWNN": "10:00:AC:BD:E2:50:28:ED",
                                        "WWPN": "20:00:AC:BD:E2:50:28:ED"
                                "PortId": "1"
                    "FirmwareVersion": "00.00.00",
                    "MCTPEnabled": true,
                    "MezzSlot": "Mezz1",
                        "Ethernet"
                    "OCPFan": null,
                    "PartNumber": "N/A",
                    "Position": "PCIe-5",
                    "RootBDF": "0000:48:01.0",
                    "SerialNumber": "N/A",
                    "SlotNumber": 5,
                    "TemperatureCelsius": 57.0
            "Status": {
                "Health": "OK",
                "Oem": {
                        "Public": {
                "State": "Enabled"
Response code: 200
Date type
@odata.context
String
OData description of the network adapter resource model.
@odata.id
String
Link to the network adapter resource.
@odata.type
String
Type of the network adapter resource.
Manufacturer
String
Chip manufacturer of the network adapter.
Model
String
Network adapter model.
Name
String
Network adapter name.
Id
String
Network adapter ID.
Oem.Public
Custom properties of the network adapter.
CapableSpeedGbs
String
Speed.
CardManufacturer
String
Manufacturer of the network adapter.
CardMode
String
Mode of the network adapter.
CardModel
String
Interface type on the network adapter.
ChipModel
String
Chip model.
Configuration
Object
Mezzanine card information.
Configuration.CardTypeCode
String
Mezzanine card type.
Configuration.DataOrigin
Integer
Data source:
·     EEPROM
·     OM
Configuration.EffectiveLink
Integer
Port connection effective status, with the value in the range of 0 to 65535.
Each bit represents a port, and the connection status corresponds to bit 1.
Configuration.MultifunctionMode
String
Port multifunction mode:
·     SF
·     NPAR
·     Default
·     QINQ_NPAR
·     QINQ_Default
Configuration.NPARLink
Integer
Port connection status with the value in the range of 0 to 65535 when NPAR is enabled.
Configuration.NPARPort
Array
List of available ports when NPAR is enabled.
Configuration.PortsConfig
Array
Port configuration information.
Configuration.PortsConfig.16GFECConfig
String
Enabling status of current 16G FEC configuration:
·     Enabled
·     Disabled
Configuration.PortsConfig.ConnectionType
String
Port connection type:
·     Switch
·     PTM_32G
·     PTM_16G
Configuration.PortsConfig.PFsInfo
Array
Port physical feature information.
Configuration.PortsConfig.PFsInfo.FCoEFipMACAddress
String
FCoE MAC address.
Configuration.PortsConfig.PFsInfo.ISCSIAddress
String
ISCSI address.
Configuration.PortsConfig.PFsInfo.PermanentAddress
String
Fixed address.
Configuration.PortsConfig.PFsInfo.Protocol
String
Protocol name.
Configuration.PortsConfig.PFsInfo.WWNN
String
Node WWN.
Configuration.PortsConfig.PFsInfo.WWPN
String
Port WWN.
Configuration.PortsConfig.PortId
String
Port ID.
MezzSlot
String
Mezzanine slot number.
DeviceLocator
String
Network adapter silk-screen information.
FirmwareVersion
String
Firmware version.
MCTPEnabled
Boolean
MCTP enabling status.
OCPFan
Object
OCP fan information.
This field is unavailable for FC HBA cards.
OCPFan.Status
Object
Specify OCP fan status, including:
·     Health—OCP fan health status.
·     State—OCP fan enable status.
·     Severity—Custom health status.
·     FaultDescription— Fault description information.
When the OCP fan enable status is Absent, it indicates the OCP fan is missing and will trigger a severe alarm (Critical/Major).
NetworkTechnology
Array
Network protocol used by the network adapter. Supported options:
·     Ethernet.
·     FC.
·     iSCSI.
·     FCoE.
·     OPA.
·     IB.
Support for this field depends on network adapter model.
Position
String
Network adapter location, for example, mLOM, sLOM, and Embedded.
SerialNumber
String
Serial number.
PartNumber
String
Part number.
Model
String
Device model.
SlotNumber
Integer
Slot number of the network adapter.
TemperatureCelsius
Integer
Current temperature.
RootBDF
String
Root port BDF of the network adapter.
ProductCode
String
Product Code
This field is available for FC HBA cards.
Integer
Number of related PCIe module for network adapter.
Integer
Number of related network ports for network adapter.
Controllers
Network adapter properties.
Network adapter controller capability information.
Links
Single object of the network adapter.
NetworkPorts
Collection of network port objects for the network adapter.
PCIeDevices
Collection of PCIe objects for the network adapter.
String
Version of the firmware package.
Status.Health
String
Health status of the network adapter.
Status.State
String
Enabling status of network adapters.
Status.Oem.Public.Severity
String
Status.Oem.Public.FaultDescription
String
Change history
Version
Change description
HDM2-1.79
HDM2-2.17
Added the Configuration.NPARPort field.
HDM2-2.03
Added the Oem.Public.MCTPEnabled field.
HDM2-1.59
Added Mezzanine related fields.
HDM2-1.59
Added the Oem.Public.CardMode field.
Obtain network port collection information
Obtain information about all network ports from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/NetworkAdapters/networkadapters_id/NetworkPorts
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
networkadapters_id
Method and URL:
GET http://172.16.13.176/redfish/v1/Chassis/1/NetworkAdapters/Embedded/NetworkPorts
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
  "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/Embedded/NetworkPorts",
  "Members": [
      "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/Embedded/NetworkPorts/1"
      "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/Embedded/NetworkPorts/2"
  "Name": "Network Port Collection",
"Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the network port collection resource model.
@odata.id
String
Link to the network port collection resource.
@odata.type
String
Type of the network port collection resource.
Name
String
Name of the network port collection resource.
Members
Links to network port resources.
@odata.id
String
Link to a single network port.
Members@odata.count
Integer
Number of network ports.
Obtain network port information
Obtain information about a specific network port from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/NetworkAdapters/networkadapter_id/NetworkPorts/networkport_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
networkadapter_id
networkport_id
ID of the network port resource.
You can obtain available network port resource IDs from network port collection information.
# Obtain port information for the specified NIC controller.
Method and URL:
GET https://192.168.18.18/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot16/NetworkPorts/1
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json n
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#NetworkPort.NetworkPort",
    "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot16/NetworkPorts/1",
    "@odata.type": "#NetworkPort.v1_3_0.NetworkPort",
    "AssociatedNetworkAddresses": [
        "78:AA:82:CB:11:18"
    "CurrentLinkSpeedMbps": null,
    "Id": "1",
    "LinkStatus": "Down",
    "Name": "1",
    "Oem": {
        "Public": {
            "AutoNeg": true,
            "BDF": "0000:16:00.0",
          "CPUId":"CPU2",
          "FatherPortNum": "1",
            "FullDuplex": false,
            "LldpService": {
                "LldpCurrentState": "N/A",
                "LldpEnabled": null,
                "WorkMode": ""
            "PortMaxSpeed": "25000Mb/s",
            "PortType": "OpticalPort",
            "Slot": "Slot24"
    "PhysicalPortNumber": "1"
Response code: 200
# Obtain port information for the specified FC controller.
Method and URL:
GET https://192.168.18.18/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot1/NetworkPorts/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot1/NetworkPorts/1",
    "@odata.type": "#NetworkPort.v1_2_5.NetworkPort",
    "AssociatedNetworkAddresses": [],
    "CurrentLinkSpeedMbps": 0,
    "Id": "1",
    "LinkStatus": "N/A",
    "Name": "1",
    "Oem": {
        "Public": {
            "AutoNeg": null,
            "BDF": "0000:49:00.0",
            "CPUId": null,
            "FatherPortNum": null,
            "FullDuplex": null,
            "LldpService": {
                "LldpCurrentState":null,
                "WorkMode": null
            "PortMaxSpeed": "16000Mb/s",
            "PortType": "ElectricalPort",
            "Slot": null
Response code: 200
Date type
@odata.context
String
OData description of the network port resource model.
@odata.id
String
Link to the network port resource.
@odata.type
String
Type of the network port resource.
Array
Supported options:
·     NIC—MAC addresses of the network port.
·     FC—First is WWPN, second is WWNN.
Id
String
Network port resource ID.
Name
String
Ethernet port resource name.
PhysicalPortNumber
String
Physical port number of the network port.
LinkStatus
String
Port status. Supported options:
·     Up.
·     Down.
·     N/A.
This field displays N/A if the query failed to obtain the port status, for example, because of BIOS reboot, BIOS shutdown, NCSI disablement, or other conditions.
Integer
Negotiated speed of the network port in Mb/s.
Oem.Public
Custom properties of the network port.
PortType
String
Type of the network port. Supported options:
·     OpticalPortFiber port.
·     ElectricalPortCopper port.
·     N/AUnknown port.
BDF
String
BDF of the network port.
CPUId
String
CPU to which the network port belongs.
Only supported by NIC card.
Slot
String
Slot to which the network port belongs.
AutoNeg
Boolean
Autonegotiation of the network port. Supported options:
·     true.
·     false.
FatherPortNum
String
Father port number of the specified port.
FullDuplex
Boolean
Full duplex of the network port. Supported options:
·     true.
·     false.
PortMaxSpeed
String
Maximum speed of the network port, in Mbps. For example, 10000 Mbps.
LldpService.LldpEnabled
Boolean
LLDP enabling status of the network port. Supported options:
·     true.
·     false.
·     null.
If the server does not support the LLDP service, this field displays null.
LldpService.WorkMode
String
LLDP operating mode. The filed value Tx indicates the LLDP transmit mode.
LldpService.LldpCurrentState
String
LLDP status. Supported options:
·     Enabled—On.
·     Disabled—Off.
Change history
Version
Change description
HDM3-1.20
Edited the description for the LinkStatus field.
HDM2-1.61
Added the Oem.Public.CPUId and Oem.Public.Slot field.
HDM2-1.59
Added the Oem.Public.FatherPortNum field.
Configure network port settings
Configure a network port on the server.
This feature is not available for FC controllers.
Privilege module
ConfigureComponents
Locking type of the associated system
BMC configuration locking
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Chassis/chassis_id/NetworkAdapters/networkadapteras_id/NetworkPorts/networkport_id
Request header:
X-Auth-Token:TOKEN
If-Match:ifmatch_value
Request body:
"Oem": {
       "Public": {
"LldpService":{
"LldpEnabled": lldp_enabled
Parameter
Value
device_ip
networkadapters_id
networkport_id
ID of the single network port resource
TOKEN
chassis_id
ifmatch_value
Entity tag (ETag) that uniquely represents the requested resource.
To obtain the entity tag value of a resource, send a GET request to it and then obtain the ETag value from the response header.
Oem.Public.LldpService.LldpEnabled
Boolean
·     true.
·     false.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot17/NetworkPorts/1
Request header:
X-Auth-Token:TOKEN
If-Match:W/"6e8c96325a9b7c6a6e5e9f23616fbce0"
Request body:
    "Oem":{
    "Public":{
         "LldpService":{
             "LldpEnabled":true
Response code: 200
Response:
    "@odata.context":"/redfish/v1/$metadata#NetworkPort.NetworkPort",
    "@odata.id":"/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot17/NetworkPorts/1",
    "@odata.type":"#NetworkPort.v1_3_0.NetworkPort",
    "AssociatedNetworkAddresses":[
        "B8:59:9F:FB:44:32"
    "CurrentLinkSpeedMbps":10000,
    "Id":"1",
    "LinkStatus":"Up",
    "Name":"1",
    "Oem":{
        "Public":{
            "AutoNeg":true,
            "BDF":"0000:81:00.0",
            "CompletionCode":0,
            "CPUId":"CPU2",
            "Description":"Success",
            "FullDuplex":true,
            "LldpService":{
                "LldpCurrentState":"Disabled",
                "LldpEnabled":true,
                "WorkMode":""
            "PortMaxSpeed":"25000Mb/s",
            "PortType":"OpticalPort",
            "Slot": "Slot24"
"PhysicalPortNumber":"1"
Response code: 200
For information about the response fields, see "Obtain network port information."
Change history
Version
Change description
HDM2-1.53
Added the locking type of the associated system.
Obtain drive alarm threshold information
Obtain information about alarm thresholds of drives in the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Chassis/chassis_id/Drives/AlarmThreshold
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
chassis_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Chassis/1/Drives/AlarmThreshold
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#AlarmThreshold.AlarmThreshold",
    "@odata.id": "/redfish/v1/Chassis/1/Drives/AlarmThreshold",
    "@odata.type": "#AlarmThresholdService.v1_0_0.AlarmThresholdService",
    "BadTrack": {
        "AlarmLimit": 24810,
        "EnableFlag": false
"MajorAlarmLimit": 95
    "Life": {
        "AlarmLimit": 95,
        "EnableFlag": false
    "MediaError": {
        "MediaErrorCnt": 24810,
        "MediaErrorEnableFlag": false
    "Oem": {
        "Public": {
    "PredFail": {
        "PredFailCnt": 24810,
        "PredFailEnableFlag": false
    "RevBlock": {
        "AlarmLimit": 10,
        "EnableFlag": false
    "UNC": {
        "AlarmLimit": 240,
        "EnableFlag": false
Date type
@odata.context
String
OData description of the drive alarm threshold resource model.
@odata.id
String
Link to the drive alarm threshold resource.
@odata.type
String
Type of the drive alarm threshold resource.
BadTrack
Bad sector alarming for drives. This feature is available only for HDDs.
AlarmLimit
Integer
Number of bad sector that can trigger an alarm.
Value range: 0 to 65535.
EnableFlag
Boolean
Whether bad sector alarming is enabled. Supported options:
·     trueEnabled.
·     falseDisabled.
Life
Drive life alarming. This feature is available only for SSDs and NVMe drives.
Enabled by default with AlarmLimit as 90 and MajorAlarmLimit as 95.
AlarmLimit
Integer
Remaining drive life that can trigger a minor alarm.
Value range: 0 to 100 in percent.
EnableFlag
Boolean
Enabling status of drive life alarming. Supported options:
·     trueEnabled.
·     falseDisabled.
MajorAlarmLimit
Integer
Remaining drive life that can trigger a major alarm.
MediaError
Media error alarming. This feature is available only for HDDs and SSDs.
MediaErrorCnt
Integer
Number of media errors that can trigger an alarm.
Boolean
Whether media error alarming is enabled. Supported options:
·     trueEnabled.
·     falseDisabled.
PredFail
Predictive failure alarming. This feature is available only for HDDs and SSDs.
PredFailCnt
Integer
Number of predictive failures that can trigger an alarm.
Value range: 0 to 255.
PredFailEnableFlag
Boolean
Whether predictive failure alarming is enabled. Supported options:
·     trueEnabled.
·     falseDisabled.
RevBlock
Reserved block alarming. This feature is available only for SSDs.
AlarmLimit
Integer
Number of reserved blocks that can trigger an alarm.
Value range: 0 to 100.
EnableFlag
Boolean
Whether reserved block alarming is enabled. Supported options:
·     trueEnabled.
·     falseDisabled.
UNC
Uncorrectable error alarming. This feature is available only for HDDs and SSDs using the SATA protocol.
AlarmLimit
Integer
Number of uncorrectable errors that can trigger an alarm.
EnableFlag
Boolean
Whether uncorrectable error alarming is enabled. Supported options:
·     trueEnabled.
·     falseDisabled.
Change history
Version
Change description
HDM2-1.69
HDM2-2.06
Added the Life.MajorAlarmLimit field to indicate the major alarm threshold for drive life.
Configure drive alarm threshold settings
Configure the alarm threshold settings for drives.
Privilege module
OemKvm
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Chassis/chassis_id/Drives/AlarmThreshold
Request header:
X-Auth-Token:TOKEN
Request body:
          "BadTrack": {
        "AlarmLimit": Limit,
        "EnableFlag": Flag
"MajorAlarmLimit":Limit
    "Life": {
        "EnableFlag": Flag
    "MediaError": {
        "MediaErrorCnt": Limit,
        "MediaErrorEnableFlag": Flag
    "PredFail": {
        "PredFailCnt": Limit,
        "PredFailEnableFlag": Flag
    "RevBlock": {
        "EnableFlag": Flag
    "UNC": {
        "EnableFlag": Flag
Parameter
Value
device_ip
chassis_id
TOKEN
ifmatch_value
BadTrack
Bad sector alarming. This feature is available only for HDDs.
BadTrack.AlarmLimit
Number of bad sectors that can trigger an alarm.
Integer. Value range: 0 to 65535.
BadTrack.EnableFlag
Enable or disable bad sector alarming.
Boolean. Supported options:
·     trueEnable.
·     false—Disabled.
Life
Remaining drive life alarming. This feature is available only for SSDs and NVMe drives.
Life.AlarmLimit
Integer.
Life.EnableFlag
Enable or disable remaining drive life alarming.
·     trueEnable.
·     false—Disable.
Integer
MediaError
MediaError.MediaErrorCnt
MediaError.MediaErrorEnableFlag
Enable or disable media error alarming.
·     trueEnable.
·     false—Disable.
PredFail
PredFail.PredFailCnt
Integer. Value range: 0 to 255.
PredFail.PredFailEnableFlagEnableFlag
Enable or disable predictive failure alarming.
·     trueEnable.
·     false—Disable.
RevBlock
RevBlock.AlarmLimit
Integer. Value range: 0 to 100.
RevBlock.EnableFlag
Enable or disable reserved block alarming.
·     trueEnable.
·     false—Disable.
UNC
UNC.AlarmLimit
Integer.
UNC.EnableFlag
Enable or disable uncorrectable error alarming.
·     trueEnable.
·     false—Disable.
Method and URL:
PATCH https://192.168.20.207/redfish/v1/Chassis/1/Drives/AlarmThreshold
Request header:
X-Auth-Token:TOKEN
Request body:
"BadTrack": {
        "AlarmLimit": 32767,
        "EnableFlag": true
    "Life": {
        "AlarmLimit": 20,
        "EnableFlag": true
    "MediaError": {
        "MediaErrorCnt": 32767,
        "MediaErrorEnableFlag": true
    "PredFail": {
        "PredFailCnt": 213,
        "PredFailEnableFlag": true
    "RevBlock": {
        "AlarmLimit": 10,
        "EnableFlag": true
    "UNC": {
        "AlarmLimit": 177,
        "EnableFlag": true
Response:
    "BadTrack": {
        "EnableFlag": true
    "Life": {
        "AlarmLimit": 20,
        "EnableFlag": true
    "MediaError": {
"Oem": {
        "Public": {
    "PredFail": {
        "PredFailCnt": 213,
    "RevBlock": {
        "AlarmLimit": 10,
        "EnableFlag": true
    "UNC": {
        "AlarmLimit": 177,
        "EnableFlag": true
Response code: 200
For information about the response fields, see "Obtain drive alarm threshold information."
Change history
Version
Change description
HDM2-1.69
HDM2-2.06
HDM2-1.53
Operations on system resources
Obtain system collection information
Obtain information about all system resources from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Systems",
    "@odata.id": "/redfish/v1/Systems",
    "@odata.type": "#ComputerSystemCollection.ComputerSystemCollection",
    "Description": "A collection of ComputerSystem resource instances",
    "Members": [
            "@odata.id": "/redfish/v1/Systems/1"
    "Name": "Computer System Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the system collection resource model.
@odata.id
String
Link to the system collection resource.
@odata.type
String
Type of the system collection resource.
Members
List of system resources.
@odata.id
String
Link to a system resource.
String
Description of the system collection resource.
Members@odata.count
Integer
Number of system resources.
Name
String
Name of the system collection resource.
Obtain system resource information
Obtain information about a specific system resource from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
ID of the system resource.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#ComputerSystem.ComputerSystem(*)",
    "@odata.id": "/redfish/v1/Systems/1",
    "@odata.type": "#ComputerSystem.v1_13_0.ComputerSystem",
    "Actions": {
        "#ComputerSystem.Reset": {
            "ResetType@Redfish.AllowableValues": [
                "ForceOff",
                "ForcePowerCycle",
                "ForceRestart",
                "GracefulShutdown",
                "Nmi",
                "On"
            "target": "/redfish/v1/Systems/1/Actions/ComputerSystem.Reset"
        "Oem": {
            "Public": {
                "#ComputerSystem.ClearConfiguration": {
                    "SecureErase@Redfish.AllowableValues": [
                        "BIOS",
                        "Storage",
                        "BMC"
                    "target": "/redfish/v1/Systems/1/Actions/Oem/Public/Systems.ClearConfiguration"
                "#ComputerSystem.ResetCPLD": {
                        "ForceRestart"
                    "target": "/redfish/v1/Systems/1/Actions/Oem/Public/ComputerSystem.ResetCPLD"
                "#Systems.ExportReport": {
                    "@Redfish.AllowableValues": [
                    "target": "/redfish/v1/Systems/1/Actions/Oem/Public/Systems.ExportReport"
    "AssetTag": "test_123",
    "Bios": {
        "@odata.id": "/redfish/v1/Systems/1/Bios"
    "BiosVersion": "6.00.01",
    "Boot": {
        "BootSourceOverrideEnabled": "Once",
        "BootSourceOverrideEnabled@Redfish.AllowableValues": [
            "Continuous",
            "Once"
        "BootSourceOverrideMode": "None",
        "BootSourceOverrideMode@Redfish.AllowableValues": [
            "Legacy",
            "None",
            "UEFI"
        "BootSourceOverrideTarget": "None",
        "BootSourceOverrideTarget@Redfish.AllowableValues": [
            "BiosSetup",
            "Cd",
            "Hdd",
            "None",
            "Pxe"
    "ChassisPartNumber": "0235AQ7",
    "Description": "System 1",
    "Healthstate": {
        "OverallHealth": "Critical",
        "board": "OK",
        "fans": "OK",
        "memory": "OK",
        "pcie": "OK",
        "power": "Critical",
        "processor": "OK",
        "storage": "OK",
        "temperature": "OK"
    "HostName": "HDM",
    "Id": "1",
    "IndicatorLED": "Off",
    "Links": {
        "Chassis": [
        "ManagedBy": [
                "@odata.id": "/redfish/v1/Managers/1"
        "PCIeDevices": [
                "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/7"
        "PCIeFunctions": [
                "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/6/Functions/1"
                "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/7/Functions/1"
    "LogServices": {
        "@odata.id": "/redfish/v1/Systems/1/LogServices"
    "MaintenanceSerialNumber": "",
    "Memory": {
        "@odata.id": "/redfish/v1/Systems/1/Memory"
    "MemorySummary": {
        "Count": 1,
        "MaxCountSupported": 32,
        "Status": {
            "Health": "OK",
            "HealthRollup": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
        "TotalSystemMemoryGiB": 32
    "Name": "Computer System",
    "NetworkInterfaces": {
        "@odata.id": "/redfish/v1/Systems/1/NetworkInterfaces"
    "Oem": {
        "Public": {
            "AlarmEventSummary": {
                "CriticalAlarmCount": 0,
                "MajorAlarmCount": 2,
                "MinorAlarmCount": null
            "BiosVendor": "AMI",
            "ClearConfigurationProgress": {
                "@odata.id": "/redfish/v1/Systems/1/Oem/Public/ClearConfigurationProgress"
"ComputeModuleMaxCount": 1,
"ConfigurationModel":null,
            "FirmwareInformation": {
                "BiosFirmwareBuildDate": "2022-10-13T12:12:52+08:00",
                "BiosInternalFirmwareVersion": "V100R001B01D001_DEBUG",
                "MEFirmwareVersion": "6.0.3.176"
            "GPU": {
                "@odata.id": "/redfish/v1/Systems/1/GPU"
            "HostNameSetupMode": "Auto",
            "HostStatus": {
                "@odata.id": "/redfish/v1/Systems/1/Oem/Public/HostStatus"
            "IndependentPowerSupply": false,
            "NodeType":null,
            "POSTRoutines": {
                "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines"
"PUID": "R3950-G7-ABCD",
            "PanelPowerButtonEnabled": true,
            "PowerOnStrategy": "RestorePreviousState",
"PresentComputeModules": [
                "CM1"
            "SecurityBezel": {
                "@odata.id": "/redfish/v1/Systems/1/Oem/Public/SecurityBezel"
            "SoftwareList": {
                "@odata.id": "/redfish/v1/Systems/1/Oem/Public/SoftwareList"
            "BootSmallOption":{
               "CD/DVD": {
               "Hard Disk": {
                   "BootSmallOption1": "UEFI:KingstonDataTraveler 2.0PMAP, Partition 4,0x0002",
               "Network": {
               "Other Device": {
    "PartNumber": "",
    "PowerState": "On",
    "ProcessorSummary": {
        "Count": 1,
        "MaxCountSupported": 2,
        "Model": "Intel(R) Xeon(R) Platinum 8450H",
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
        "TotalCores": 28,
        "TotalThreads": 56
    "Processors": {
        "@odata.id": "/redfish/v1/Systems/1/Processors"
    "SerialNumber": "",
    "Status": {
        "Health": "Critical",
        "HealthRollup": "Critical",
        "Oem": {
            "Public": {
                "Severity": "Major"
        "State": "Enabled"
    "Storage": {
        "@odata.id": "/redfish/v1/Systems/1/Storages"
    "StorageControllerSummary": {
        "LogicalDriveCount": 0,
        "PhysicalDriveCount": 0,
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Absent"
        "StorageControllerCount": 0
    "SystemType": "Physical",
    "UUID": "98e83cd0-7a2c-1000-02ff-aabbccd24718",
    "Uptime_hours": "7",
    "kvm": {
        "@odata.id": "/redfish/v1/Systems/1/kvm"
Response code: 200
Data type
@odata.context
String
OData description of the system resource model.
@odata.id
String
Link to the system resource.
@odata.type
String
Type of the system resource.
Actions
Available operations for the system resource.
Object
System reset operation.
Array
Available system reset operations. Supported options:
·     On—Power-on.
·     ForceOff—Forced power-off.
·     ForceRestart—Forced restart.
·     GracefulShutdown—Graceful power-off.
·     NmiTriggers a non-maskable interrupt.
·     ForcePowerCycleForced power-cycle.
target
String
Link to the system reset operation.
Actions.Oem.Public
Custom Actions executable operations.
Object
Clear configuration operation.
Array
Allowed types for clearing configuration. Supported options:
·     BIOS.
·     Storage.
·     BMC.
target
String
Link to the clear configuration operation.
ComputerSystem.DownloadReport
Object
Operation of the download clear configuration report.
DownloadReport@Redfish.AllowableValues
Array
Allowed types for clearing configuration are only displayed as "".
target
String
Link to download clear report operation.
Object
Restart CPLD operation.
Array
Restart CPLD parameters include: ForceRestart.
target
String
Link to restart CPLD operation.
AssetTag
String
Asset tag of the system resource.
Value range: 1 to 48.
Bios
Object
Link to the BIOS resource.
BiosVersion
String
BIOS version.
Boot
Boot settings of the system resource.
String
Current enabling status of the boot settings. Supported options:
·     Once—Effective only for the next startup.
·     Continuous—Always effective.
Array
Available enabling status of boot settings. Supported options:
String
Current boot mode. Supported options:
·     None.
·     Legacy—Legacy mode.
·     UEFI—UEFI mode.
The Phytium platform does not support the Legacy mode.
Array
Available boot modes. Supported options:
·     None.
·     UEFI—UEFI mode.
String
Current boot device. Supported options:
·     None.
·     Hdd.
·     Pxe.
·     BiosSetup.
·     Cd.
Array
Available boot devices. Supported options:
·     None.
·     Hdd.
·     Pxe.
·     BiosSetup.
·     Cd.
ChassisPartNumber
String
Part number of the system board chassis domain. R6900 and R8900 are the names of mid planes.
Healthstate
Object
System health status.
Healthstate.OverallHealth
String
Overall health status.
Healthstate.storage
String
Health status of the storage controllers, drives, and NVMe drives.
Healthstate.fans
String
Fan health status.
Healthstate.memory
String
Memory health status.
Healthstate.pcie
String
PCIe module health status.
Healthstate.power
String
Power health status.
Healthstate.processor
String
Processor health status.
Healthstate.temperature
String
Temperature sensor health status.
Healthstate.board
String
Server board health status.
Id
String
IndicatorLED
String
UID LED status. Supported options:
·     LitThe LED is steady on.
·     Off—The LED is off.
·     Blinking—The LED is flashing.
Links
Links to service resources.
Chassis
Object array
Link to chassis resources.
ManagedBy
Object array
Link to manager resources.
PCIeDevices
Object array
Link to PCIe resource node.
PCIeFunctions
Object array
Link to PCIe function resource node.
LogServices
Object
Link to the log service collection resource.
String
Maintenance serial number.
Manufacturer
String
Manufacturer.
Memory
Object
Link to a memory resource.
MemorySummary/StorageControllerSummary/ProcessorSummary
Module summary information.
Count
Integer
Current numbers.
MaxCountSupported
Integer
Maximum supported numbers.
Status
Object
Summary resource status. Supported options:
·     Health—Summary resource health status.
·     State—Summary resource enabling status.
·     HealthRollup—Overall health status.
·     Oem.Public.FaultDescription—Overall fault description.
·     Oem.Public.Severity—Custom health status.
The overall fault description is related to the overall component fault, independent of individual component fault information.
MemorySummary.TotalSystemMemoryGiB
Integer
Capacity of the total memory.
StorageControllerSummary.StorageControllerCount
Integer
Number of storage controllers.
StorageControllerSummary.LogicalDriveCount
Integer
Number of logical drives.
StorageControllerSummary.PhysicalDriveCount
Integer
Number of physical drives.
ProcessorSummary.TotalCores
Integer
Total CPU cores in the system.
ProcessorSummary.TotalThreads
Integer
Total CPU threads in the system.
ProcessorSummary.Model
String
First CPU model in the system.
SerialNumber
String
Product serial number.
Status
Object
Status of the system resource. Supported options:
·     HealthHealth status.
·     StateEnabling status.
Storage
Object
Link to a storage resource node.
Processors
Object
Link to a processor resource node.
Model
String
Product model.
Name
String
System resource name.
NetworkInterfaces
Object
Link to a network interface resource.
PartNumber
String
Product part number.
PowerState
String
Power state. Supported options:
·     On.
·     Off.
Oem.Public
Custom attributes.
AlarmEventSummary
Object
Alarm summary information.
CriticalAlarmCount
Integer
Number of fatal alarms.
MajorAlarmCount
Integer
Number of critical alarms..
MinorAlarmCount
Integer
Number of minor alarms.
Oem.Public.BiosVendor
String
Software vendor of the system resource BIOS.
Oem.Public.PanelPowerButtonEnabled
Boolean
Ear-mounted power button enabled.
Oem.Public.PowerOnStrategy
String
Power on strategy. Supported options:
·     TurnOn—Power on.
·     RestorePreviousState—Restore the power status before the device was powered off.
·     StayOff—Power off.
Oem.Public.PUID
String
Product usage ID.
Oem.Public.ClearConfigurationProgress
Object
Obtain detailed progress of configuration clearance.
Oem.Public.FirmwareInformation.MEFirmwareVersion
String
ME version information
Oem.Public.FirmwareInformation.BiosFirmwareBuildDate
String
BIOS firmware build time.
N/A indicates a failure to obtain this field.
Oem.Public.FirmwareInformation.BiosInternalFirmwareVersion
String
BIOS firmware version.
Oem.Public.GPU
Object
Link to the CPU resource.
Oem.Public.HostNameSetupMode
String
Hostname setting mode. Supported options:
·     Auto—Automatic mode.
·     Manual—Manual mode.
Oem.Public.HostStatus
Object
Obtain host status migration link.
Oem.Public.IndependentPowerSupply
Boolean
Whether independent power supply is supported for the standard PCIe slot.
Oem.Public.POSTRoutines
Object
Link to the power-on self-test code processor resource node.
Oem.Public.SecurityBezel
Object
Link to the security panel.
Oem.Public.SoftwareList
Object
Link to the system software list.
Oem.Public.ComputeModuleMaxCount
Integer
Maximum node count supported by current model.
Oem.Public.PresentComputeModules
Array
Current compute storage resource node.
Oem.Public.NodeType
String
Product package information.
Oem.Public.BootSmallOption
Object
BIOS minimal boot option.
BootSmallOptionX
String
Name of the minimal boot option, where X represents the sequence starting from 1.
SystemType
String
System type. Supported options:
·     Physical.
·     Virtual.
UUID
String
UUID of the server.
Uptime_hours
String
Time elapsed since the server was powered on.
kvm
Object
Link to the KVM resource.
HostName
String
Host name of the system resource.
Change history
Version
Change description
HDM3-2.04
Added the Oem.Public.PUID field.
HDM3-1.07
HDM2-2.04
Added the Oem.Public.ConfigurationModel field.
HDM2-1.58
Added the BIOS minimal boot option.
HDM2-1.57
Added the Oem.Public.NodeType field.
HDM2-1.52
Added the ChassisPartNumber field.
Configure system resource properties
Configure the properties of a specific system resource.
Privilege module
OemKvm, ConfigureComponents, and OemPowerControl
BIOS configuration locking (only applicable when configuring BIOS-related properties), BMC configuration locking (not applicable when configuring BIOS-related properties)
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Systems/system_id
Request header:
X-Auth-Token:TOKEN
Request body:
    "HostName": "123",
    "Boot": {
        "BootSourceOverrideMode": mode,
        "BootSourceOverrideTarget": target,
        "BootSourceOverrideEnabled": enable
    "Oem": {
        "Public": {
            "HostNameSetupMode": "Manual",
            "BootSmallOption": {
               "CD/DVD": {
               "Hard Disk": {
                   "BootSmallOption1":"UEFI: KingstonDataTraveler 2.0PMAP, Partition 4,0x0002",
               "Network": {
               "Other Device": {
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
system_id
ifmatch_value
AssetTag
Asset tag.
String.
The field displays null if no asset tag is configured.
HostName
Host name.
Length of the field string.
·     Mobile CID—1 to 48.
·     Mainline—1 to 63.
Boot.BootSourceOverrideMode
Next boot mode.
Supported options:
·     None.
·     UEFI—UEFI mode.
Boot.BootSourceOverrideTarget
Next boot device.
Supported options:
·     None.
·     Pxe.
·     Hdd.
·     Cd.
·     BiosSetupThis option is available only when the BootSourceOverrideEnabled field is set to Once.
Boot.BootSourceOverrideEnabled
Effective type of the boot settings.
Supported options:
·     Once—Effective only at the next startup.
·     Continuous—Always effective. This option is available only for G5 servers. It is not available on G3 blade servers.
Boolean.
Ear-mounted power button enablement.
Hostname setup mode.
Supported options:
·     ManualManual mode.
Object
BootSmallOptionX
String
The BootSourceOverrideEnabled, BootSourceOverrideMode, and BootSourceOverrideTarget fields are all mandatory in the request.
If the Boot.BootSourceOverrideEnabled field is set to continuous, the BootSourceOverrideMode and BootSourceOverrideTarget fields cannot both be None.
When only the HostName is set, the HostNameSetupMode field is set to Manual by default.
When BMC configuration is locked, parameters within the Boot structure cannot be mixed with other parameters for deployment.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Systems/1
Request header:
X-Auth-Token:TOKEN
Request body:
    "HostName": "HDM12315555777745557765",
    "Boot": {
        "BootSourceOverrideMode": "UEFI",
        "BootSourceOverrideTarget": "Pxe",
    "Oem": {
        "Public": {
               "CD/DVD": {},
               "Hard Disk": {
               "Network": {},
               "Other Device": {}
Response:
    "Actions": {
                "ForceOff",
                "ForcePowerCycle",
                "ForceRestart",
                "GracefulShutdown",
                "Nmi",
                "On"
        "Oem": {
            "Public": {
                        "BIOS",
                        "Storage",
                        "BMC"
                        "ForceRestart"
    "Bios": {
    "BiosVersion": "6.00",
    "Boot": {
            "Continuous",
            "Once"
            "Legacy",
            "None",
            "UEFI"
            "BiosSetup",
            "Cd",
            "Hdd",
            "None",
            "Pxe"
    "Healthstate": {
        "board": "OK",
        "fans": "OK",
        "memory": "OK",
        "pcie": "OK",
        "processor": "OK",
        "storage": "OK",
        "temperature": "OK"
    "Id": "1",
    "IndicatorLED": "Lit",
    "Links": {
        "Chassis": [
        "ManagedBy": [
        "PCIeDevices": [
        "PCIeFunctions": [
                "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/16/Functions/1"
    "LogServices": {
    "Manufacturer": "H3C",
    "Memory": {
    "MemorySummary": {
        "Count": 1,
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
    "Model": "RS33M2C9S",
    "Oem": {
        "Public": {
                "MajorAlarmCount": 1,
            "CompletionCode": 0,
                "BiosInternalFirmwareVersion": "V100R001B06BBIT05",
                "MEFirmwareVersion": "6.0.3.159"
            "GPU": {
            "NodeType":null,
            "POSTRoutines": {
                "CM1"
            "SecurityBezel": {
            "SoftwareList": {
               "CD/DVD": {},
               "Hard Disk": {
               "Network": {},
               "Other Device": {}
    "PartNumber": "",
    "PowerState": "Off",
        "Count": 1,
        "Model": "Genuine Intel(R) CPU 0000%@",
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Enabled"
        "TotalCores": 48,
        "TotalThreads": 96
    "Processors": {
    "SerialNumber": "",
    "Status": {
        "Oem": {
            "Public": {
                "Severity": "Major"
        "State": "Enabled"
    "Storage": {
        "Status": {
            "Health": "OK",
            "Oem": {
                "Public": {
            "State": "Absent"
    "UUID": "ff777238-ec31-1000-03f2-aabbccd24718",
    "Uptime_hours": "0",
    "kvm": {
Response code: 200
Response field description
For information about the response fields, see "Obtain system resource information."
The server returns status code 200 for a successful operation.
Change history
Version
Change description
HDM3-1.07
HDM3-1.12
When the HostName is set, the HostNameSetupMode field is set to Manual by default.
HDM2-1.58
HDM2-1.52
HDM2-1.16
Added the redfish/v1/Systems/system_id interface.
Added Usage guidelines in the Description. If you are setting HostName, also set the HostNameSetupMode field to Manual. At the same time, changed the HostNameSetupMode field in the Examples to Manual.
Obtain boot self-test order
Obtain the boot self-test order.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Bios/Oem/Public/POSTRoutines
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#POSTRoutines.POSTRoutines",
    "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines",
    "@odata.type": "#POSTRoutines.v1_0_0.POSTRoutines",
    "Description": "A Collection of POST routines.",
    "Entries": {
        "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries"
    "Name": "POST Routines Collection",
    "Oem": {
        "Public": {
            "Description": "Success"
    "POSTState": "Post To Setup"
Response code: 200
Data type
@odata.context
String
OData description for boot self-test order collection model.
@odata.id
String
Link to boot self-test order collection.
@odata.type
String
Resource type of boot self-test order collection.
String
Interface function description.
Entries
Object
Boot self-test order resource list.
Name
String
Name of boot self-test order collection resource.
POSTState
String
POSTState description.
Obtain information about boot self-test code collection resource
Obtain information about boot self-test code collection resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Bios/Oem/Public/POSTRoutines/Entries
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#POSTRoutinesEntryCollection.POSTRoutinesEntryCollection",
    "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries",
    "@odata.type": "#POSTRoutinesCollection.POSTRoutinesEntryCollection",
    "Description": "A Collection of Entry routines.",
    "Members": [
            "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries/1"
            "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries/2"
            "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries/3"
            "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries/4"
            "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries/5"
            "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries/315"
            "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries/316"
    "Members@odata.count": 316,
    "Members@odata.nextLink": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries?$skip=100&$top=100",
    "Name": "POST Routines Entries Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description for boot self-test collection resource information model
@odata.id
String
Link to boot self-test collection resource information.
@odata.type
String
Type of boot self-test collection resource information.
Members
Array
Information list of the boot self-test code collection resource.
String
Description of boot self-test collection resource.
Members@odata.count
Integer
Number of boot self-test collection resource information.
Name
String
Name of boot self-test collection resource information.
String
Link to the boot self-test code collection resource on multiple pages.
Obtain information about specified boot self-test code
Obtain information of the specified boot self-test order.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Bios/Oem/Public/POSTRoutines/Entries/entries_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
entries_id
ID of the boot self-test code collection resource.
You can obtain available IDs from the boot self-test collection resource information.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#POSTRoutinesInstance.POSTRoutinesInstance",
    "@odata.id": "/redfish/v1/Systems/1/Bios/Oem/Public/POSTRoutines/Entries/3",
    "@odata.type": "#POSTRoutinesInstance.v1_0_0.POSTRoutinesInstance",
    "Description": "Bios POST Routines Information",
    "Id": "3",
    "Name": "Bios POST Routines Information",
    "Oem": {
        "Public": {
    "POSTCode": "0x0002",
    "POSTCodeDescription": "MICROCODE Initialization",
    "TimeStamp": "2019-02-18T17:51:02+08:00"
Response code: 200
Data type
@odata.context
String
OData description for boot self-test code resource model.
@odata.id
String
Link to boot self-test code resource.
@odata.type
String
Type of boot self-test code information.
Id
String
ID of the boot self-test code resource.
Name
String
Name of the boot self-test code resource.
String
Description of the boot self-test code resource.
POSTCodeDescription
String
Detailed description of current boot self-test stage.
POSTCode
String
Current boot self-test code.
TimeStamp
String
Timestamp.
Perform a power operation
Perform a system power reset operation (power-on, forced power-off, graceful power-off, or forced restart).
Privilege module
OemPowerControl
Power control locking
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/Actions/ComputerSystem.Reset
Request header:
X-Auth-Token:TOKEN
Request body:
"ResetType": state
Parameter
Value
device_ip
TOKEN
system_id
ResetType
Operation type.
Supported options:
·     On—Power-on.
·     PowerCycleForced power-cycle. This action has the same effect as ForcePowerCycle.
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Actions/ComputerSystem.Reset
Request header:
X-Auth-Token:TOKEN
Request body:
"ResetType": "GracefulShutdown"
Response:
"Oem": {
       "Public": {
"error": {
       "@Message.ExtendedInfo": [
               "@odata.type": "#Message.v1_1_1.Message",
               "Message": "Successfully Completed Request",
               "MessageArgs": [],
               "MessageId": "Base.1.8.1.Success",
               "MessageSeverity": "OK",
               "Resolution": "None"
    "code":"Base.1.8.1.Success",
        "message":"Successfully Completed Request"
Response code: 200
Data type
code
String
String of a specific message ID in the message registry.
message
String
Readable error message corresponding to the message in the message registry.
Extended information of the message.
@odata.type
String
OData description of the message resource.
MessageId
String
Message ID.
Message
String
Details of the message.
MessageArgs
Array
Message arguments.
MessageSeverity
String
Severity level. Supported options:
·     OK.
·     Warning.
·     Critical.
Resolution
String
Recommended actions for the error.
Change history
Version
Change description
HDM2-2.04
Added the error node before Message.ExtendedInfo and added the code and message fields under the error node.
HDM2-1.56
Added the PowerCycle field.
HDM2-1.53
Restart CPLD
This feature allows for the CPLD firmware to be restarted after an upgrade or if anomalies occur, without the need to power off the server.
For information about CPLD types that support restarting, see H3C Servers HDM2 User Guide.
Privilege module
OemDiagnosis
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/Actions/Oem/Public/ComputerSystem.ResetCPLD
Request header:
X-Auth-Token:TOKEN
Request body:
"ResetType":type
Parameter
Value
device_ip
TOKEN
system_id
ResetType
ForceRestart: Restart CPLD.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Actions/Oem/Public/ComputerSystem.ResetCPLD
Request header:
X-Auth-Token:TOKEN
Request body:
"ResetType":"ForceRestart"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Recommended action for the error.
Change history
Version
Change description
HDM2-2.04
·     Added the error node before Message.ExtendedInfo and added the code and message fields under the error node.
·     Changed the interface description.
Obtain processor collection information
Obtain information about all processors from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Processors
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Processors
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#ProcessorCollection.ProcessorCollection",
    "@odata.id": "/redfish/v1/Systems/1/Processors",
    "@odata.type": "#ProcessorCollection.ProcessorCollection",
    "Description": "Collection of processors for this system",
    "Members": [
            "@odata.id": "/redfish/v1/Systems/1/Processors/1"
            "@odata.id": "/redfish/v1/Systems/1/Processors/2"
    "Name": "Processors Collection",
    "Oem": {
        "Public": {
            "CpuUsageRatePercent": 60,
            "Description": "Success",
            "UsageAlarmThreshold": 75
Response code: 200
Data type
@odata.context
String
OData description of the processor collection resource model.
@odata.id
String
ID of the processor collection resource.
@odata.type
String
Type of the processor collection resource.
String
Description of the processor collection resource.
Members
Array
List of processor resources.
Members@odata.count
Integer
Number of processor resources.
Name
String
Name of the processor collection resource.
Oem.Public.CpuUsageRatePercent
Integer
Processor usage, in percent. Value range: 0 to 100.
This field is supported only when FIST SMS is installed. This field displays null if the usage failed to be obtained.
Oem.Public. UsageAlarmThreshold
Integer
CPU usage alarm threshold. Value range: 0 to 100. This field displays null if the usage failed to be obtained.
Set alarm threshold for processor usage
Set the alarm threshold for processor usage.
Privilege module
OemKvm
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Systems/system_id/Processors
Request header:
X-Auth-Token:TOKEN
Request body:
    "Oem": {
     "Public": {
            "UsageAlarmThreshold":value
Parameter
Value
device_ip
TOKEN
system_id
Alarm threshold for processor usage.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Systems/1/Processors
Request header:
X-Auth-Token:TOKEN
Request body:
    "Oem": {
     "Public": {
            "UsageAlarmThreshold":75
Response:
    "Members": [
    "Oem": {
        "Public": {
Response code: 200
For information about the response fields, see "Obtain processor collection information."
Obtain processor information
Obtain information about a specific processor from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Processors/cpu_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
cpu_id
ID of the processor resource.
You can obtain available processor IDs from processor collection resource information.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Processors/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response 1:
    "@odata.context": "/redfish/v1/$metadata#Processor.Processor(*)",
    "@odata.id": "/redfish/v1/Systems/1/Processors/1",
"@odata.type": "#Processor.v1_10_0.Processor",
"ChopType": "",
    "Id": "1",
    "InstructionSet": "x86-64",
    "Manufacturer": "Intel(R) Corporation",
    "MaxSpeedMHz": 4000,
    "Name": "CPU1",
"Actions": {
"Oem": {
         "Public":{
             "#Processor.LicenseUpload": {
                  "target":"/redfish/v1/Systems/1/Processors/1/Actions/Oem/Public/Processor.LicenseUpload"
              "#Processor.StateReportExport": {
                  "target":"/redfish/v1/Systems/1/Processors/1/Actions/Oem/Public/Processor.StateReportExport"
    "Oem": {
        "Public": {
            "64BitSupported": true,
            "FrequencyMHz": 1500,
            "ChipId": null,
"CoreEnabledCount": 32,
            "L1CacheKiB": 3840,
            "L2CacheKiB": 34304,
            "L3CacheKiB": 34208,
"MaxSpeed": null,
            "SerialNumber": "07-9A-3E-43-60-E1-C5-50",
            "Temperature": 4294967295,
            "ThermalDesignPower":null,
"ThreadEnabledCount": 32,
"Capability": :[
                   "Name": "CSS4",
                   "State": "Enabled"
                   "Name": "AMS4",
                   "State": "Disabled"
                   "Name": "AMS1",
                   "State": "Disabled"
                   "Name": "CSS2",
                   "State": "Disabled"
                   "Name": "SGX512",
                   "State": "Enabled"
    "Ppin": "07-9A-3E-43-60-E1-C5-50",
    "ProcessorArchitecture": "x86",
    "ProcessorId": {
        "IdentificationRegisters": "F3-06-08-00-FF-FB-EB-BF",
"Step": ""
    "ProcessorType": "CPU",
    "Socket": 1,
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
"TDPWatts":null,
    "TotalCores": 48,
    "TotalThreads": 96
Response code: 200
Response 2 (Phytium):
    "ChopType": "",
    "Id": "1",
    "InstructionSet": "Aarch64",
    "Manufacturer": "Phytium",
    "MaxSpeedMHz": 2100,
    "Model": "S5000C-64",
    "Name": "CPU1",
    "Oem": {
        "Public": {
            "ChipId": "KPA5691504160000",
"CoreEnabledCount": null,
            "FrequencyMHz": 2100,
            "L1CacheKiB": 4096,
            "L2CacheKiB": 32768,
            "L3CacheKiB": 32768,
"MaxSpeed": null,
            "SerialNumber": "KPA5691504160000",
            "ThermalDesignPower": null
"ThreadEnabledCount": null,
    "Ppin": null,
    "ProcessorArchitecture": "ARMv8",
    "ProcessorId": {
        "IdentificationRegisters": "20-86-0F-70-00-00-00-00",
        "Step": ""
    "Socket": 1,
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
"TDPWatts":null,
    "TotalCores": 64,
    "TotalThreads": 64
Response code: 200
Data type
@odata.context
String
OData description of the processor resource model.
@odata.id
String
@odata.type
String
Type of the processor resource.
Id
String
InstructionSet
String
Instruction set of the processor.
Manufacturer
String
Manufacturer of the processor.
MaxSpeedMHz
Integer
Maximum frequency of the processor. For Intel processors, the maximum frequency is Turbo frequency..
Model
String
Model of the processor.
Name
String
Name of the processor.
Actions
Actions allowed by Redfish that can be perform on specific CPU resources.
Actions.Oem.Public
Custom actions that can be performed.
Object
Upload operation of the Intel On Demand License activation file.
target
String
Operation path for uploading the Intel On Demand License activation file.
Object
Export operation of the CPU status report.
target
String
Path for exporting the CPU status report.
ProcessorType
String
Type of the processor. Supported options:
·     CPU.
·     GPU.
·     FPGA.
·     DSP.
·     Accelerator.
·     OEM.
Socket
Integer
Slot number of the processor.
Status.Health
String
Health status of the processor.
Status.State
String
Enabling status of the processor.
TDPWatts
Integer
Power consumption of CPU thermal design.
TotalCores
Integer
Total number of cores in the processor.
TotalThreads
Integer
Maximum number of threads supported by the processor.
ChopType
String
Architecture type.
Oem.Public.ChipId
String
CPU identifier, available only for the Phytium CPU platform.
Oem.Public.CoreEnabledCount
Integer
Actual number of CPU cores.
Oem.Public.ThreadEnabledCount
Integer
Actual number of CPU threads.
Oem.Public.L1CacheKiB
Integer
L1 cache size.
Oem.Public.L2CacheKiB
Integer
L2 cache size.
Oem.Public.L3CacheKiB
Integer
L3 cache size.
Oem.Public.MaxSpeed
String
Maximum PCIe speed.
Oem.Public.SerialNumber
String
Serial number of the processor.
Oem.Public.Temperature
Integer
Processor temperature.
Oem.Public.ThermalDesignPower
Integer
Oem.Public.FrequencyMHz
Integer
Base frequency of the processor.
Oem.Public.64BitSupported
Boolean
Whether it supports 64-bit.
Oem.Public.Capability
Array
Intel On Demand feature and status for a specific CPU.
Oem.Public.Capability.Name
String
Intel On Demand features supported on a specific CPU:
·     CSS4
·     AMS4
·     AMS1
·     CSS2
·     SGX512
Oem.Public.Capability.State
String
Enabling status of Intel On Demand on a specific CPU:
·     Enabled.
·     Disabled.
Ppin
String
Protected Processor Inventory Number (PPIN).
String
Architecture of the processor.
ProcessorId
Object
ID of the processor.
Step
String
Step frequency.
Change history
Version
Change description
HDM2-2.15
Added the TDPWatts field.
HDM3-1.19
Added the Oem.Public.MaxSpeed field.
HDM3-1.18
Added the Oem.Public.CoreEnabledCount and Oem.Public.ThreadEnabledCount fields.
HDM3-1.09
Added the Oem.Public.ChipId field.
HDM2-2.03
Changed the Actions field to Actions.Oem.Public.
HDM2-2.02
Added Intel On Demand information.
HDM2-1.57
Added the Oem.Public.ThermalDesignPower field.
Obtain memory collection information
Obtain information about all memory modules from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Memory
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
system_id
Only value 1 is supported.
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Memory
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#MemoryCollection.MemoryCollection",
    "@odata.id": "/redfish/v1/Systems/1/Memory",
    "@odata.type": "#MemoryCollection.MemoryCollection",
    "Description": "A Collection of memory resource instances.",
    "Members": [
            "@odata.id": "/redfish/v1/Systems/1/Memory/DIMM110"
            "@odata.id": "/redfish/v1/Systems/1/Memory/DIMM210"
    "Name": "Memory Module Collection",
    "Oem": {
        "Public": {
            "PowerWatts": 0,
            "RASConfig": {
                "ADDDCSparing": "Disabled",
                "ECC": "Enabled",
                "MirrorMode": "Partial Mirror Mode",
                "PatrolScrub": "Enable at End of POST",
                "SDDC": null
Response code: 200
Data type
@odata.context
String
OData description of the memory collection resource model.
@odata.id
String
Link to the memory collection resource.
@odata.type
String
Type of the memory collection resource.
String
Description of the interface.
Members
Array
List of memory resources.
Members@odata.count
Integer
Number of memory resources.
Name
String
Name of the memory collection resource.
Oem.Public.PowerWatts
String
Memory power consumption. This field displays null if obtaining the memory power consumption is not supported.
RASConfig
Object
RAS configuration information.
ADDDCSparing
String
ADDDCSparing status. Supported options:
·     Enabled.
·     Disabled.
ECC
String
ECC status. Supported options:
·     Enabled.
·     Disabled.
MirrorMode
String
MirrorMode status. Supported options:
·     Partial Mirror Mode.
·     Full Mirror Mode.
·     Disabled.
PatrolScrub
String
PatrolScrub status. Supported options:
·     Enabled.
·     Disabled.
·     Enable at End of POST.
SDDC
String
SDDC status. Supported options:
·     Enabled.
·     Disabled.
Obtain memory information
Obtain information about a specific memory module from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Memory/memory_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
memory_id
ID of the memory resource.
You can obtain available memory resource IDs from memory collection resource information.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Memory/DIMM110
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
 "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/Memory/Members/$entity",
    "@odata.id": "/redfish/v1/Systems/1/Memory/DIMM110",
    "@odata.type": "#Memory.v1_10_0.Memory",
    "AllowedSpeedsMHz": [
        4800
"BaseModuleType": "RDIMM",
"BusWidthBits": 80,
    "CapacityMiB": 32768,
    "DCPMMType": null,
    "DataWidthBits": 64,
    "DeviceLocator": "CPU1_CH1_D0",
    "ErrorCorrection": "NoECC",
    "FirmwareRevision": null,
    "Id": "DIMM110",
    "IsRankSpareEnabled": false,
    "IsSpareDeviceEnabled": false,
    "Manufacturer": "Micron",
    "MemoryDeviceType": "DDR5",
    "MemoryLocation": {
        "Channel": 1,
        "Controller": 0,
        "Slot": 0,
        "Socket": 1
    "Name": "DIMM110",
    "Oem": {
        "Public": {
            "AccumulatedPowerOnHours": null,
            "Authenticity": "Normal",
            "CapacityGiB":32,
            "ControllerTemperatureCelsius": null,
            "DisabledCausation": null,
            "MediumTemperatureCelsius": null,
            "Model": "MTC20F1045S1RC48BAX",
            "Technology": "RDIMM",
            "VDDQVolt": "1.1V",
            "OperatingSpeedMegaTransfersPerSecond": 4800,
            "AllowedSpeedsMegaTransfersPerSecond": [
                4800
    "OperatingSpeedMhz": 4800,
    "PartNumber": "MTC20F1045S1RC48BAX",
    "PersistentRegionSizeLimitMiB": null,
    "PowerManagementPolicy": {
        "PolicyEnabled": false
    "RankCount": 1,
    "RemainingServiceLifePercent": null,
    "SecurityCapabilities": {
        "PassphraseCapable": false
    "SerialNumber": "2B6BAE3E",
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
                "FaultDescription": "",
                "Severity": "Informational"
        "State": "Enabled"
"VolatileRegionSizeLimitMiB": null
Response code: 200
Data type
@odata.context
String
OData description of the memory resource model.
@odata.id
String
Link to the memory resource.
@odata.type
String
Type of the memory resource.
BaseModuleType
String
Base module type of the memory resource.
DeviceLocator
String
Location of the memory module.
CapacityMiB
Integer
Memory capacity.
ErrorCorrection
String
Error correction method. Supported options:
·     MultiBitECC.
·     NoECC.
·     SingleBitECC.
·     AddressParity.
Id
String
IsRankSpareEnabled
Boolean
This field is not available in the current software version. The field value is fixed to false.
Spare rank enabling status.
Boolean
Spare device enabling status.
MemoryDeviceType
String
Type of the memory module. Options include:
·     DDR3.
·     DDR4.
·     SDRAM.
MemoryLocation.Channel
Integer
Channel number of the memory module.
MemoryLocation.Slot
Integer
Slot number of the memory module (DIMM).
MemoryLocation.Controller
Integer
Controller number of the memory module.
MemoryLocation.Socket
Integer
Socket number of the processor.
Oem.Public.Authenticity
String
Memory authenticity. Supported options:
·     Vendor certified.
·     Normal.
Oem.Public.Model
String
Model of the memory module.
Oem.Public.Technology
String
Memory technology used by the memory module. Supported options:
·     RDIMM.
·     UDIMM.
·     SODIMM.
·     LRDIMM.
·     NVDIMM.
Oem.Public.VDDQVolt
String
Voltage of the memory module.
Oem.Public.MediumTemperatureCelsius
Integer
Memory medium temperature.
Oem.Public.ControllerTemperatureCelsius
Integer
Memory controller temperature.
Oem.Public.AccumulatedPowerOnHours
Integer
Cumulative power-on time (Hour).
Oem.Public.OperatingSpeedMegaTransfersPerSecond
Integer
Current operating speed of the specified memory module.
Oem.Public.AllowedSpeedsMegaTransfersPerSecond
Integer
Maximum memory speed.
Oem.Public.DisabledCausation
String
Description of memory disable reasons.
Oem.Public.CapacityGiB
Integer
Memory capacity, in GiB.
Name
String
Name of the memory module.
OperatingSpeedMhz
Integer
Current operating speed of the memory module.
AllowedSpeedsMHz
Array
PartNumber
String
Part number of the memory module.
PowerManagementPolicy.PolicyEnabled
Boolean
Enabling status of the power management policy for the memory module.
RankCount
Integer
Number of ranks in the memory module.
SecurityCapabilities.PassphraseCapable
Boolean
Security capabilities of the memory module.
SerialNumber
String
Serial number of the memory module.
Status.Health
String
Health status of the memory module.
Supported options:
·     Enabled.
·     Disabled.
·     Absent.
Status.State
String
Enabling status of the memory module.
String
Fault description of specified memory module.
String
Custom health status of specified memory module.
Manufacturer
String
Manufacturer name of the specified memory module.
FirmwareRevision
String
Memory firmware version.
Integer
Volatile capacity of specified memory module (MiB).
Integer
Persistent capacity of specified memory module (MiB).
Integer
Remaining lifespan of specified memory module.
DCPMMType
String
Operating mode:
·     Memory Mode—Memory mode.
·     APP Direct Mode—Application direct access mode.
·     Mixed Mode—Mixed mode.
DataWidthBits
Integer
Memory data width.
BusWidthBits
Integer
Memory bus width.
Change history
Version
Change description
HDM2-1.57
Added the Oem.Public.CapacityGiB field.
Obtain storage controller collection information
Obtain information about all storage controllers from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Storages
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Storages
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#StorageCollection.StorageCollection",
    "@odata.id": "/redfish/v1/Systems/1/Storages",
    "@odata.type": "#StorageCollection.StorageCollection",
    "Members": [],
    "Members@odata.count": 0,
    "Name": "Storage Collection",
    "Oem": {
        "Public": {
            "Status": {
                "Health": "OK",
                "State": "Starting"
Response code: 200
Data type
@odata.context
String
OData description of the storage controller collection resource model.
@odata.id
String
Link to the storage controller collection resource.
@odata.type
String
Type of the storage controller collection resource.
Members
Array
List of storage controller resources.
Members@odata.count
Integer
Number of storage controller resources.
Name
String
Name of the storage controller resource list.
Oem.Public.Status.State
String
Overall storage controller status. Supported options:
·     Starting—BIOS initializing.
·     Disabled—Faulty or disabled.
·     UnavailableOffline—Server powered off.
·     Enabled—Normal.
·     AbsentAbsent.
·     UnKnow—Unknown status.
Oem.Public.Status.Health
String
Health status of the overall storage controller.
Obtain storage controller information
Obtain information about a specific storage controller from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Storages/raid_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
raid_id
ID of the storage controller resource.
You can obtain available storage controller IDs from storage controller collection resource information.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Storages/RAIDStorage0
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Storage.Storage(*)",
    "@odata.id": "/redfish/v1/Systems/1/Storages/RAIDStorage0",
    "@odata.type": "#Storage.v1_9_0.Storage",
    "Actions": {
        "Oem": {
            "Public": {
                "#Storage.ClearConfiguration": {
                    "target": "/redfish/v1/Systems/1/Storages/RAIDStorage0/Actions/Oem/Public/Storage.ClearConfiguration"
                "#Storage.ClearForeignConfiguration": {
                    "target": "/redfish/v1/Systems/1/Storages/RAIDStorage0/Actions/Oem/Public/Storage.ClearForeignConfiguration"
    "Drives": [
            "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront3"
            "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront5"
            "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront6"
    "Drives@odata.count": 3,
    "Id": "RAIDStorage0",
    "Name": "RAIDStorage0",
    "Oem": {
        "Public": {
"IdleDriveSlots": [
                "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots/Front1"
                "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots/Front2"
                "@odata.id": "/redfish/v1/Chassis/1/Oem/Public/IdleDriveSlots/Front6"
"IdleDriveSlots @odata.count": 3
    "StorageControllers": [
            "@odata.id": "/redfish/v1/Systems/1/Storages/RAIDStorage0#/StorageControllers/0",
            "AssetTag": "RAID-LSI-9560-LP-16i-8GB",
"CardManufacturer": "Broadcom",
"CardModel": "HBA-LSI-9500-LP-8i",
            "FirmwareVersion": "5.160.02-3415",
            "Manufacturer": "Broadcom",
            "MemberId": "0",
            "Model": "RAID-LSI-9560-LP-16i-8GB",
            "Name": "RAID-LSI-9560-LP-16i-8GB",
            "Oem": {
                "Public": {
                    "AssociatedCard": {
                        "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/5"
                    "BBUstate": "Miss",
                    "CapacitancePercent": null,
                    "CapacitanceStatus": {
                        "Health": "OK",
                        "Severity": "Informational",
                        "State": "Absent"
                    "ChipManufacturer": "Broadcom",
                    "ChipModel": "LSI3916",
                    "ConfigurationVersion": "5.1600.00-0393",
                    "CopyBackState": true,
                    "DDRECCCount": 0,
                    "ExternalPortCount":null,
                    "FaultforLogicalDrives": [],
                    "FlashState": "Miss",
                    "InternalPortCount":16,
                    "JBODState": null,
                    "MaintainPDFailHistory": true,
                    "MaxStripeSizeBytes": 1048576,
                    "MemorySizeMiB": 8192,
                    "MinStripeSizeBytes": 65536,
                    "Mode": "RAID",
                    "PackageVersion": "52.16.0-3803",
                    "PSOCFirmwareVersion":"0x000C",
                    "SASAddress": "500062B208620140",
                    "SmarterCopyBackState": false,
                    "SpeedGTps": null
                    "SupportedConfigurationOperation": [
                        "ClearForeignConfiguration",
                        "ClearConfiguration",
                        "ModifyProperty",
                        "ManageVolumes",
                        "ModifyMode",
"ConfigureAccessPolicy",
"ConfigureWritePolicy",
"ConfigureReadPolicy",
"ConfigureDriveCachePolicy"
                    "SupportedRAIDLevels": [
                        "RAID0",
                        "RAID1",
                        "RAID5",
                        "RAID6",
                        "RAID10",
                        "RAID50",
                        "RAID60"
"SupportedRAIDMode": [
                        "RAID",
                        "JBOD"
"SupportedStripSize": [
                        "64KB",
                        "128KB",
"256KB",
"512KB",
"1MB"
                    "TemperatureCelsius": 48
            "SerialNumber": "SKB3980100",
            "SpeedGbps": 12,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
            "SupportedDeviceProtocols": [
                "SAS/SATA"
    "StorageControllers@odata.count": 1,
    "Volumes": {
        "@odata.id": "/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes"
Response code: 200
Data type
@odata.context
String
OData description of the storage controller resource model.
@odata.id
String
Link to the storage controller resource.
@odata.type
String
Type of the storage controller resource.
Actions.Oem.Public
Custom actions.
Object
Action for clearing all the configuration for the specified RAID controller.
target
String
Action path for clearing all configurations on the specified RAID controller.
Object
Action for clearing the physical drive Foreign state for the specified RAID controller.
target
String
Action path for clearing the physical drive Foreign state for the specified RAID controller.
Drives
Array
List of physical drive resources.
Drives@odata.count
Integer
Number of physical drive resources.
Id
String
Name
String
Name of the storage controller resource.
Oem.Public
Custom properties.
Oem.Public.IdleDriveSlotsStorageControllers.@odata.id
Array
Link to the resource of an empty slot.
StorageControllers.Model
String
Model of the storage controller.
StorageControllers.AssetTag
String
Asset tag of the storage controller.
StorageControllers.CardManufacturer
String
Manufacturer of the storage controller.
StorageControllers.CardModel
String
Storage controller model.
StorageControllers.FirmwareVersion
String
Firmware version of the storage controller.
StorageControllers.Manufacturer
String
StorageControllers.MemberId
String
StorageControllers.Name
String
Name of the storage controller.
StorageControllers.Oem.Public.BBUstate
String
Supercapacitor status. Supported options:
·     N/A.
·     Learn.
·     LearnFail.
·     Over_temp.
·     Failed.
·     Fatal.
·     ChargeCompleted.
·     Charging.
·     Miss.
·     PresentThis field is supported only by 3SNIC controllers.
StorageControllers.Oem.Public.CapacitanceStatus
Object
Status of the storage controller capacitor (BBU).
Supported options:
·     Health—Capacitor health status.
·     State—Capacitor enable status.
·     Severity—Custom health status.
·     FaultDescription—Fault description information.
StorageControllers.Oem.Public.CapacitancePercent
String
Percentage of the supercapacitor charge.
StorageControllers.Oem.Public.ChipModel
String
Chip model.
StorageControllers.Oem.Public.ChipManufacturer
String
Chip manufacturer.
Supported options:
·     Broadcom—LSI storage controller.
·     Microchip—PMC storage controller.
·     Marvell—Self-developed and outsourced Marvell controller.
·     3SNIC3SNIC controller.
StorageControllers.Oem.Public.ConfigurationVersion
String
Controller card configuration version.
StorageControllers.Oem.Public.CopyBackState
Boolean
Copyback status.
StorageControllers.Oem.Public.DDRECCCount
Integer
Storage controller memory correctable error count.
StorageControllers.Oem.Public.FlashState
String
Flash card status. Supported options:
·     Initializing.
·     Normal.
·     Miss.
·     Failed.
·     Warning.
·     Unknown.
·     N/A.
StorageControllers.Oem.Public.FaultforLogicalDrives
Array
Current storage controller faulty logical drive list.
StorageControllers.Oem.Public.JBODState
Boolean
JBOD status.
StorageControllers.Oem.Public.MaintainPDFailHistory
Boolean
Storage drive fault record feature enable status.
StorageControllers.Oem.Public.MinStripeSizeBytes
Integer
Controller supports minimum stripe value.
StorageControllers.Oem.Public.MaxStripeSizeBytes
Integer
Controller supports maximum stripe value.
StorageControllers.Oem.Public.MemorySizeMiB
Integer
Cache size the storage controller, in MiB.
StorageControllers.Oem.Public.Mode
String
Mode of the storage controller. Supported options:
·     Non-RAID.
·     RAID.
·     HBA.
·     Mixed.
·     JBOD.
·     SimpleVolume.
·     AutoVolume.
StorageControllers.Oem.Public.PackageVersion
String
PackageVersion of the LSI storage controller.
StorageControllers.Oem.Public.PSOCFirmwareVersion
String
PSOC firmware version.
StorageControllers.Oem.Public.SASAddress
String
Address of the storage controller. This field displays null if no address is obtained.
StorageControllers.Oem.Public.SmarterCopyBackState
Boolean
SMART error copyback status.
StorageControllers.Oem.Public. SupportedConfigurationOperation
Array
Capabilities of the specified storage controller.
StorageControllers.Oem.Public.SupportedRAIDLevels
Array
Supported storage controller levels.
StorageControllers.Oem.Public.SupportedStripSize
Array
Supported stripe sizes
StorageControllers.Oem.Public.SupportedRAIDMode
Array
Current supported storage controller mode.
StorageControllers.Oem.Public.TemperatureCelsius
Array
Current temperature.
StorageControllers.Oem.Public.AssociatedCard
Object
Link to the associated storage controller.
StorageControllers.Oem.Public.SpeedGTps
Integer
Interface speed
This field is available only for a self-developed Marvell storage controller.
StorageControllers.SerialNumber
String
Serial number of the storage controller. This field displays null if no serial number is obtained.
StorageControllers.SpeedGbps
Integer
Speed of the storage controller interface.
This field is available only for non-Marvell storage controller.
An outsourced Marvell storage controller does not support displaying interface rates.
StorageControllers.SupportedDeviceProtocols
Integer
Supported protocols by the storage controller.
Integer
Number of drivers managed by the storage controller.
Volumes
Object
List of logical drives.
StorageControllers. Status
Object
Storage controller status. Supported options:
·     Health—Storage controller health status.
·     State—Storage controller enable status.
StorageControllers.Oem.Public.InternalPortCount
Integer
Number of internal ports.
StorageControllers.Oem.Public.ExternalPortCount
Integer
Number of external ports.
Change history
Version
Change description
HDM2-2.10
Added the StorageControllers.Oem.Public.PSOCFirmwareVersion field.
HDM3-1.15
Added custom properties.
Added the Present state option to the StorageControllers.Oem.Public.BBUstate field and added the 3SNIC chip vendor to the StorageControllers.Oem.Public.ChipManufacturer field.
HDM2-2.04
Added the StorageControllers.CardManufacturer and StorageControllers.CardModel fields.
HDM2-2.03
Added description for interface rates of outsourced Marvell controllers in the StorageControllers.Oem.Public.SpeedGTps and StorageControllers.SpeedGbps fields.
Added description about interface rates of Marvell vendor in the StorageControllers.Oem.Public.ChipManufacturer field.
HDM2-1.57
Added the StorageControllers.Oem.Public.InternalPortCount and StorageControllers.Oem.Public.ExternalPortCount fields.
HDM2-1.55
Added the Storage.ClearConfiguration and Storage.ClearForeignConfiguration fields for the Actions object.
HDM2-1.14
Added the StorageControllers.Oem.Public.SupportedRAIDMode field.
Modify storage controller information
Modify information about a specific storage controller from the server.
Privilege module
OemKvm
Locking type of the associated system
Hardware configuration locking
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Systems/system_id/Storages/raid_id
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
Request body:
    "StorageControllers":[
            "Oem":{
                "Public":{
                    "CopyBackState":cb_state,
                    "SmarterCopyBackState":smartcb_state,
                    "JBODState": jbod_state,
                    "Mode":mode
Parameter
Value
device_ip
TOKEN
system_id
raid_id
CopyBackState
Only LSI cards support Copyback enable status.
Supported options:
·     true.
·     false.
Only LSI cards support SMART error copyback enable status.
Supported options:
·     true.
·     false.
JBODState
Only LSI cards support JBOD enable status.
Supported options:
·     true.
·     false.
Mode
Storage controller mode.
Supported options:
·     RAID.
·     HBA.
·     Mixed.
·     JBOD.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Systems/1/Storages/RAIDStorage0
Request header:
X-Auth-Token:TOKEN
Request body:
            "Oem":{
                "Public":{
                    "CopyBackState":true,
                    "SmarterCopyBackState":false,
                     "Mode":"RAID"
Response:
    "Actions": {
        "Oem": {
            "Public": {
    "Drives": [
            "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront1"
            "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront2"
            "@odata.id": "/redfish/v1/Chassis/1/Drives/DiskFront4"
    "Drives@odata.count": 4,
    "Oem": {
        "Public": {
            "FirmwareVersion": "5.150.02-3377",
            "MemberId": "0",
            "Oem": {
                "Public": {
                    "AssociatedCard": {
                        "@odata.id": "/redfish/v1/Chassis/1/PCIeDevices/3"
                    "BBUstate": "Miss",
                        "Health": "OK",
                        "State": "Absent"
                    "ChipModel": "LSI3108",
                    "ConfigurationVersion": "5.1500.00-0399",
                    "DDRECCCount": 0,
"@odata.id":
"/redfish/v1/Chassis/1/Storages/RAIDStorage0/Volumes/LogicalDrive1"
                            "@odata.id":
"/redfish/v1/Chassis/1/Storages/RAIDStorage0/Volumes/LogicalDrive2"
                    "JBODState": null,
                    "Mode": "RAID",
                    "PackageVersion": "52.15.0-3720",
                    "SASAddress": "500062B202508300",
"SpeedGTps": null
                        "ModifyProperty",
                        "ManageVolumes",
                        "ModifyMode",
                        "RAID0",
                        "RAID1",
                        "RAID5",
                        "RAID6",
                        "RAID10",
                        "RAID50",
                        "RAID60"
                        "RAID",
                        "JBOD"
                        "64KB",
                        "128KB",
"256KB",
"512KB",
"1MB"
                    "TemperatureCelsius": 52
            "SerialNumber": "SK00977218",
            "SpeedGbps": 12,
            "Status": {
                "Health": "OK",
                "Oem": {
                    "Public": {
                "State": "Enabled"
                "SAS"
    "Volumes": {
Response code: 200
For information about the response fields, see "Obtain storage controller information."
Change history
Version
Change description
HDM2-1.53
Added the locking type of the associated system.
Clear Foreign status of physical drives in specified storage controller
Clear Foreign status of physical drives in specified storage controller.
Privilege module
OemKvm
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/Storages/raid_id/Actions/Oem/Public/Storage.ClearForeignConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
system_id
raid_id
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Storages/RAIDStorage0/Actions/Oem/Public/Storage.ClearForeignConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Clear all configurations for a specified storage controller
Clear the default configuration for the specified storage controller.
Privilege module
OemKvm
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/Storages/raid_id/Actions/Oem/Public/Storage.ClearConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
system_id
raid_id
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Storages/RAIDStorage0/Actions/Oem/Public/Storage.ClearConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain logical drive collection information
Obtain information about all logical drives from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Storages/RAIDStorage_id/Volumes
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
RAIDStorage_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#VolumeCollection.VolumeCollection",
    "@odata.id": "/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes",
    "@odata.type": "#VolumeCollection.VolumeCollection",
    "Members": [
            "@odata.id": "/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes/LogicalDrive239"
    "Members@odata.count": 1,
    "Name": "Volume Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the logical drive collection resource model.
@odata.id
String
Link to the logical drive collection resource model.
@odata.type
String
Type of the logical drive collection resource model.
Members
Array
List of logical drive resources.
Members@odata.count
Integer
Number of logical drive resources.
Name
String
Name of the logical drive collection resource.
Create a logical drive
Create a logical drive on the server.
Privilege module
OemKvm
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/Storages/storage_id/Volumes
Request header:
X-Auth-Token:TOKEN
Request body:
// Create a logical drive with ConnectionID:
    "Oem": {
        "Public":{
            "Name":name,
            "InitState": initstate,
            "StripSize":stripsize,
            "Level": raid_level,
            "SpanNum": spanname,
            "NumDrivePerSpan": num_drives,
            "DefaultReadPolicy": read_policy,
            "DefaultWritePolicy": write_policy,
            "DefaultCachePolicy": cache_policy,
            "DriveCache": drive_cache_policy,
            "AccessPolicy": access_policy,
            "Size": size,
            "SizeUnit": unit,
        "AccelerationMethod": acceleration,
            "PhysicalDiskList": [
                    "group_id":group_id,
                    "id":connnection_id
// Create a logical drive with LocationInfo:
    "Oem": {
        "Public":{
            "Name":name,
            "Size": size,
            "SizeUnit": unit,
                    "LocationInfo":location_info
Parameter
Value
device_ip
TOKEN
system_id
Oem.Public
Object
Custom attributes, this feature need to be compatible with B05 without Public situations.
Name
Name of the logical drive.
String
InitState
(Optional.) Initialization type.
For LSI storage controllers, supported options include:
·     No.
·     Fast.
·     Full.
For PMC storage controllers, supported options include:
·     Default.
·     RapidParity.
If you do not specify an option for this field, the default is to not perform initialization.
For 3SNIC storage controllers, supported options include:
·     Fast.
·     BackgroundRAID 0 does not support this type.
·     Front.
The fast type is used by default.
StripSize
Stripe size.
·     Available sizes for the LSI 9540 storage controller: 64KB.
·     Available sizes for the LSI 9560 storage controllers:
¡     64KB.
¡     128KB.
¡     256KB.
¡     512KB.
¡     1MB.
·     Available sizes for the LSI 9660 storage controller: 64KB and 256KB.
·     Available sizes for the P9560 storage controller:
¡     64KB.
¡     128KB.
¡     256KB.
¡     512KB.
¡     1MB.
·     Available sizes for the H460 3254 storage controller:
¡     64KB.
¡     128KB.
¡     256KB.
¡     512KB.
¡     1MB.
·     Available sizes for the PMC P460 storage controller:
¡     16KB.
¡     32KB.
¡     64KB.
¡     128KB.
¡     256KB.
¡     512KB.
¡     1MB.
·     Available sizes for the 3SNIC storage controller:
¡     32KB.
¡     64KB.
¡     128KB.
¡     256KB.
¡     512KB.
¡     1MB.
·     For support of other storage controllers, see the actual specifications. You can obtain supported stripe sizes through HDM or BIOS.
Level
RAID level.
Supported options:
·     RAID 0.
·     RAID 1.
·     RAID 5.
·     RAID 6.
·     RAID 00This option is not available for PMC or 3SNIC storage controllers.
·     RAID 10.
·     RAID 50.
·     RAID 60.
·     RAID 1 ADMThis level supports only three disks.
·     RAID 10 ADM.
For the 3SNIC 3S580, 3S585, and 3S590, supported options include:
·     RAID0.
·     RAID1.
·     RAID5.
·     RAID6.
·     RAID10.
·     RAID50.
·     RAID60.
For the 3SNIC 3S520 and 3S530, supported options include:
·     RAID0.
·     RAID1.
·     RAID10.
SpanNum
Number of spans.
Integer. If not specified, this field is fixed to 0.
The available values vary by RAID level.
For PMC storage controllers:
·     For RAID levels 0, 1, 5, 6, 10, 1 ADM, and 10 ADM, only 0 is available.
·     For RAID levels 50 and 60, the value must be greater than 1.
For LSI storage controllers:
·     For RAID levels 0, 1, 5, and 6, only 1 is available.
·     For RAID levels 00, 10, 50, and 60, the value must be greater than 1.
For 3SNIC storage controllers:
·     For RAID levels 10, 50, and 60, the value must be greater than 1.
·     For RAID level 50, the value must be 2, 3, 4, or 5.
·     For RAID level 60, the value must be 2, 3, or 4.
NumDrivePerSpan
Number of physical drives per span.
For LSI storage controller:
·     For RAID 0, the value must be greater than 0 and less than the number of installed physical drives.
·     For RAID 1, the value must be an even number greater than 0 and less than the number of installed physical drives.
·     For RAID 5 and RAID 6, the value must be greater than 2 and less than the number of installed physical drives.
·     For RAID 00, the value must be greater than 0 and the total number of physical drives in all spans cannot be greater than the number of installed physical drives.
·     For RAID 10, the value must be an even number greater than 0 and the total number of physical drives in all spans cannot be greater than the number of installed physical drives.
·     For RAID 50, the value must be greater than 2 and the total number of physical drives in all spans cannot be greater than the number of installed physical drives.
·     For RAID 60, the value must be greater than 3 and the total number of physical drives in all spans cannot be greater than the number of installed physical drives.
·     For RAID 1, the value must be 2 and less than the number of installed physical drives.
·     For RAID 5, the value must be greater than 2 and less than the number of installed physical drives.
·     For RAID 6, the value must be greater than 3 and less than the number of installed physical drives.
·     For RAID 10, the value must be an even number greater than 3 and less than the number of installed physical drives.
·     For RAID 50, the value must be greater than 2, a multiple of 3, and the total number of physical drives in all spans cannot be greater than the number of installed physical drives.
·     For RAID 60, the value must be greater than 3, a multiple of and the total number of physical drives in all spans cannot be greater than the number of installed physical drives
·     For RAID 1ADM, the value must be 3 and less than the number of installed physical drives.
·     For RAID 10ADM, the value must be greater than 5, a multiple of 6, and less than the number of installed physical drives.
·     For RAID 1, the value can only be 2.
·     For RAID 10, the value must be an even number greater than 0, and the value multiplied by the number of spans must be less than the number of installed physical drives.
·     For RAID 50, the value must be greater than 2, and the value multiplied by the number of spans must be less than the number of installed physical drives.
·     For RAID 60, the value must be greater than 3, and the value multiplied by the number of spans must be less than the number of installed physical drives.
DefaultWritePolicy
Default write policy.
Supported options:
·     Write Through.
·     Write Back.
·     Always Write Back.
This field is not available for PMC or 3SNIC storage controllers.
Optional field. If not specified, the default is WriteBack.
DefaultReadPolicy
Default read policy.
Supported options:
·     NoReadAhead.
·     ReadAhead.
Optional field. If not specified, the default is ReadAhead.
WritePolicy
Write policy.
Supported options:
·     Write Back.
·     Write Through.
·     Write Back Enforce.
This field is available only for 3SNIC storage controllers.
Optional field. If not specified, the default is Write Though.
ReadPolicy
Read policy.
Supported options:
·     No Ahead.
·     Ahead.
Optional field. If not specified, the default is No Ahead.
DefaultCachePolicy
Cache policy.
Supports only DirectIO.
Optional field. If not specified, the default is DirectIO.
DriveCache
Drive cache policy.
For 3SNIC controllers, supported options include:
·     Off.
·     On.
·     Default.
For other controllers, supported options include:
·     Unchanged.
·     Enable.
·     Disable.
This field is not available for PMC storage controllers.
Optional field. If not specified, the default is Unchanged. For the 3SNIC storage controller, the default is Default.
AccessPolicy
Access policy.
Supported options:
·     Read/Write.
·     Read only.
·     Blocked.
Optional field. If not specified, the default is Read/Write.
Size
Capacity of the logical drive.
Integer.
If the value you set is 0, the default maximum capacity is used.
SizeUnit
Unit of the capacity.
Supported options:
·     MiB.
·     GiB.
·     TiB.
The minimum capacity of a LSI storage controller is 100 MiB.
The minimum capacity of a PMC storage controller is 1 GiB.
The capacity of a 3SNIC storage controller is greater than 0 MiB.
AccelerationMethod
Acceleration policy.
String. This field is available only for PMC storage controllers whose firmware supports MCTP.
Supported options:
·     Controller CacheThis option is available only for MCTP PMC storage controllers.
·     None.
·     IO Bypass—This option is available only for SSDs.
·     Optional field, if not specified, the default is ControllerCache.
PhysicalDiskList
List of member physical drives.
group_id
ID of the group to which physical drives belong.
Integer.
This field is not available for PMC or 3SNIC storage controllers. If this field is specified, it will not take effect.
If you create RAID 00, 10, 50, or 60 with physical drives from multiple groups, make sure physical drives are evenly divided in the groups.
id
Connection ID of a physical drive.
You can obtain available physical drive IDs from physical drive information.
LocationInfo
Physical drive silk screen.
Physical drive silk screen can be obtained by querying the specified drive information.
Users can create only through index or silk screen; if both are specified, silk screen takes priority.
This feature is supported on the following storage controllers:
·     The 9560, 9540, and 9660 LSI storage controllers.
·     The H460, 3254, and P460 PMC storage controllers whose firmware supports MCTP.
·     The 3s520, 3S585, and 3S590 3SNIC storage controllers.
# For LSI storage controllers:
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes
Request header:
X-Auth-Token:TOKEN
Request body:
    "Oem": {
        "Public": {
            "Name":"LogicalDisk0",
            "InitState": "No",
            "StripSize":"64KB",
            "Level":"RAID0",
            "SpanNum": 1,
            "NumDrivePerSpan": 1,
            "DefaultReadPolicy": "Read Ahead",
            "DefaultWritePolicy": "Write Through",
            "DefaultCachePolicy": "Direct",
            "DriveCache": "Disable",
            "AccessPolicy": "Blocked",
            "Size": 199,
            "SizeUnit": "GiB",
                    "group_id":0,
                    "id":11
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
# For PMC storage controllers:
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
    "Oem": {
        "Public": {
            "Name":"LogicalDisk1",
            "StripSize":"32KB",
            "Level":"RAID0",
            "SpanNum": 0,
            "Size": 199,
            "SizeUnit": "GiB",
            "AccelerationMethod":"None",
                    "LocationInfo":"DiskFront1"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
# Create a RAID50 logical drive using PMC storage controllers.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
    "Oem": {
        "Public": {
            "StripSize":"32KB",
            "Level":"RAID50",
            "SpanNum": 2,
            "NumDrivePerSpan": 3,
            "Size": 0,
            "SizeUnit": "GiB",
                    "LocationInfo":"DiskFront2"
                    "LocationInfo":"DiskFront3"
                    "LocationInfo":"DiskFront4"
                    "LocationInfo":"DiskFront5"
                    "LocationInfo":"DiskFront6"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@Messgae.ExtendedInfo
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM3-1.20
Changed the value for the NumDrivePerSpan field.
HDM3-1.15
Changed the stripe size, capacity description, physical drive cache policy, and initialization type for 3SNIC storage controller.
HDM3-1.15
Added description for 3SNIC controllers to the InitState, StripSize, Level, SpanNum, NumDrivePerSpan, DefaultWritePolicy, DefaultReadPolicy, DefaultCachePolicy, DriveCache, AccessPolicy, SizeUnit, and group_id fields.
Added the WritePolicy and ReadPolicy fields.
HDM2-2.08
Added support for LSI 9660 storage controllers and the strip size description for LSI 9660 storage controllers.
HDM2-2.04
HDM2-1.53
HDM2-1.15
Changed stripe size field description. More storage controllers are supported, depending on actual specification scans. You can obtain supported stripe sizes through HDM/BIOS..
HDM2-1.14
Changed stripe size field description. Added support for 16/32KB stripe sizes on P460 storage controllers.
HDM2-1.14
Changed supported card description and stripe size field description.
Delete a logical drive
Delete a specific logical drive from the server.
Privilege module
OemKvm
Request
Method and URL:
DELETE https://device_ip/redfish/v1/Systems/system_id/Storages/storage_id/Volumes/volume_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
ID of the system resource.
storage_id
Example: RAIDStorage0.
volume_id
ID of the logical drive resource.
Example: LogicalDrive0.
Method and URL:
DELETE https://192.168.18.18/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes/LogicalDrive0
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain logical drive information
Obtain information about a specific logical drive from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Storages/storage_id/Volumes/logical_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
storage_id
You can obtain available storage controller IDs from storage controller collection information.
logical_id
You can obtain available logical drive IDs from logical drive collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes/LogicalDrive239
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Volume.Volume(*)",
    "@odata.id": "/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes/LogicalDrive239",
    "@odata.type": "#Volume.v1_5_0.Volume",
    "CapacityBytes": 600127266816,
    "Encrypted": false,
    "Id": "LogicalDrive239",
    "Links": {
        "Drives": [
        "Drives@odata.count": 1
    "Name": "",
    "Oem": {
        "Public": {
            "BGIEnable": true,
            "BootEnable": false,
            "ConsistencyCheck": false,
            "CurrentCachePolicy": "DirectIO",
            "CurrentReadPolicy": "ReadAhead",
            "CurrentWritePolicy": "WriteThrough",
            "DefaultCachePolicy": "DirectIO",
            "DefaultReadPolicy": "ReadAhead",
            "DefaultWritePolicy": "WriteThrough",
            "DriveCache": "Disabled",
            "FirmwareStatus": "Optimal",
            "OptimumIOSizeBytes": 65536,
            "RaidControllerID": 0,
            "ReadPolicy": "ReadAhead",
"RebuildProgress":"2",
            "SSDCachecadeVolume": null,
            "SSDCachingEnable": null,
            "SpanNumber": 1,
            "VolumeRaidLevel": "RAID0",
            "WritePolicy": "WriteThrough"
    "RedundantType": "NonRedundant",
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
Response code: 200
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes/LogicalDrive0
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes/LogicalDrive0",
    "@odata.type": "#Volume.v1_0_3.Volume",
    "CapacityBytes": 53686272000,
    "Encrypted": false,
    "Id": "LogicalDrive0",
    "Links": {
        "Drives": [
        "Drives@odata.count": 2
    "Name": "flapper2",
    "Oem": {
        "Public": {
            "AccelerationMethod": "None",
            "OptimumIOSizeBytes": 32768,
            "SpanNumber": 1,
            "NumDrivePerSpan":2,
            "VolumeRaidLevel": "RAID1"
    "RedundantType": "Mirrored ",
    "Status": {
        "Health": "",
        "Oem": {
            "Public": {
        "State": "Enabled"
Response code: 200
Data type
@odata.context
String
OData description of the logical drive resource model.
@odata.id
String
Link to the logical drive resource.
@odata.type
String
Type of the logical drive resource.
CapacityBytes
Integer
Capacity of the logical drive, in bytes.
Encrypted
Boolean
Whether to encrypt data in the logical drive.
Id
String
Links.Drives
Array
Links to member drives of the logical drive.
Links.Drives@odata.count
Integer
Number of physical drives attached to the logical drive.
Name
String
Oem.Public
Custom properties of the logical drive.
AccessPolicy
String
Access policy of the logical drive. Supported options:
·     Read/Write.
·     ReadOnly.
·     Blocked.
This field is not available for PMC or 3SNIC storage controllers or outsourced Marvell storage controllers.
BootEnable
Boolean
Whether the logical drive is a boot device.
DriveCache
String
Cache policy of physical drives in the logical drive.
·     On.
·     Off.
·     Default.
·     Unchanged.
·     Enable.
·     Disable.
This field is not available for PMC storage controllers or outsourced Marvell storage controllers.
DefaultCachePolicy
String
Cache policy. Supported options:
·     DirectIO.
·     CachedIO.
This field is not available for PMC or 3SNIC storage controllers or outsourced Marvell storage controllers. This field is available for Original IOPolicy.
CurrentCachePolicy
String
·     DirectIO.
·     CachedIO.
NumDrivePerSpan
Integer
Number of member drives in each span.
RaidControllerID
Integer
ID of the storage controller that manages the logical drive.
CurrentReadPolicy
String
Current read policy of the logical drive.
·     No Ahead.
·     Ahead.
·     NoReadAhead.
·     Read Ahead.
ReadPolicy
String
Read policy of the logical drive.
·     No Ahead.
·     Ahead.
·     NoReadAhead.
·     Read Ahead.
RebuildProgress
String
Rebuild progress of the logical drive in percentage.
This field is not available for LSI 9500\9300\9311 storage controllers or Marvell storage controllers.
DefaultReadPolicy
String
Default read policy of the logical drive. Supported options:
·     NoReadAhead.
·     Read Ahead.
SpanNumber
Integer
Number of spans contained in the logical drive.
VolumeRaidLevel
String
·     RAID levels supported by the LSI storage controller:
¡     RAID0.
¡     RAID00.
¡     RAID1.
¡     RAID5.
¡     RAID6.
¡     RAID10.
¡     RAID50.
¡     RAID60.
·     RAID levels supported by the PMC storage controller:
¡     RAID0.
¡     RAID1.
¡     RAID5.
¡     RAID6.
¡     RAID10.
¡     RAID50.
¡     RAID60.
¡     RAID1(ADM).
¡     RAID10(ADM).
·     RAID levels supported by outsourced Marvell controllers:
¡     RAID0.
¡     RAID1.
¡     JBOD.
·     RAID levels supported by the 3SNIC storage controller:
¡     RAID0.
¡     RAID1.
¡     RAID5.
¡     RAID6.
¡     RAID10.
¡     RAID50.
¡     RAID60.
·     RAID levels supported by the P9560 storage controller:
¡     RAID0.
¡     RAID00.
¡     RAID1.
¡     RAID5.
¡     RAID6.
¡     RAID10.
¡     RAID50.
¡     RAID60.
·     RAID levels supported by the Marvell controllers:
¡     RAID0.
¡     RAID1.
DefaultWritePolicy
String
Default write policy of the logical drive. Supported options:
·     WriteThrough.
·     Write Back.
·     AlwaysWriteBack.
CurrentWritePolicy
String
Current write policy of the logical drive.
·     Write Back.
·     Write Through.
·     WriteThrough.
·     Write Back.
·     AlwaysWriteBack.
WritePolicy
String
·     Write Back.
·     Write Through.
·     WriteThrough.
·     Write Back.
·     AlwaysWriteBack.
FirmwareStatus
String
Logical drive status.
·     Optimal.
·     Creating.
·     Scrubbing.
·     Zeroing.
·     Rebuilding.
·     Morphing.
·     Verifying.
·     Copying.
·     Suboptimal.
·     Degraded.
·     Offline"No.
·     Fast.
·     Full.
·     Optimal.
·     Offline.
·     Degraded.
·     Rebuilding.
·     UnknownDefault.
For self-developed Marvell storage controllers:
·     Foreign.
·     Functional.
·     Offline.
·     Degraded.
·     Rebuilding.
For outsourced Marvell storage controllers:
·     Functional.
·     Offline.
·     Degraded.
·     Normal.
·     Fault.
·     Degrade.
·     Deleting.
·     Delete_fail.
·     Formatting.
·     Initializing.
·     Initialize_fail.
·     Not_Formatted.
·     Sanitizing.
·     Write_protect.
OptimumIOSizeBytes
Integer
Strip size. Supported options vary by storage controller models.
·     For the LSI 9440 controller:
¡     6553664 KB.
·     For the LSI 9361 and LSI 9460 controllers:
¡     6553664 KB.
¡     131072128 KB.
¡     262144256 KB.
¡     524288512 KB.
¡     10485761 MB.
·     For PMC storage controllers:
¡     1638416 KB.
¡     3276832 KB.
¡     6553664 KB.
¡     131072128 KB.
¡     262144256 KB.
¡     524288512 KB.
¡     10485761 MB.
·     For 3SNIC storage controllers:
¡     3276832 KB.
¡     6553664 KB.
¡     131072128 KB.
¡     262144256 KB.
¡     524288512 KB.
¡     10485761 MB.
AccelerationMethod
String
Acceleration policy, this field is available only for PMC storage controllers. Supported options:
·     ControllerCache.
·     None.
·     IOBypass (only for SSD).
·     MaxCache.
BGIEnable
Boolean
Enabling status of background initialization.
SSDCachecadeVolume
Boolean
Whether the logical drive is a CacheCade logical drive.
ConsistencyCheck
Boolean
Enabling status of consistency check.
SSDCachingEnable
Boolean
Whether a CacheCade logical drive can be used.
RedundantType
String
Redundancy type of the logical drive. The redundancy type is corresponding to the RAID level. Options include:
·     RawDevice.
·     NonRedundant (RAID 0 and RAID 00).
·     Mirrored (RAID 1 and RAID 1E)
·     StripedWithParity (RAID 5 and RAID6).
·     SpannedMirrors (RAID 10).
·     SpannedStripesWithParity (RAID50 and RAID 60).
·     Unknown.
Status.Health
String
Health status of the logical drive.
Status.State
String
Enabling status of the logical drive.
Status.Oem.Public.Severity
String
Status.Oem.Public.FaultDescription
String
Change history
Version
Change description
HDM3-1.21
Edited the description for the VolumeRaidLevel field.
HDM3-1.20
HDM3-1.15
Added description for 3SNIC controllers to the AccessPolicy, DriveCache, DefaultCachePolicy, CurrentCachePolicy, CurrentReadPolicy, ReadPolicy, DefaultReadPolicy, VolumeRaidLevel, DefaultWritePolicy, CurrentWritePolicy, WritePolicy, FirmwareStatus, and OptimumIOSizeBytes fields.
HDM2-2.10
Added description for RebuildProgress, VolumeRaidLevel, and RedundantType.
Added description for LSI storage controllers in the RebuildProgress field.
HDM3-1.15
Added the Oem.Public.RebuildProgress field and synchronized it to HDM3.
HDM2-2.05
Added the Oem.Public. RebuildProgress field.
HDM2-2.03
Added description about outsourced Marvell storage controller in related fields.
HDM2-1.56
Changed the Optimal option to Functional in the Oem.Public.FirmwareStatus field for logical drives of the Marvell module.
Edit logical drive properties
Edit properties of the specified logical drive.
Privilege module
OemKvm
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Systems/system_id/Storages/storage_id/Volumes/logical_id
Request header:
X-Auth-Token:TOKEN
Request body:
    "Oem":{
        "Public":{
"BootEnable":boot_enable,
            "AccessPolicy":access_policy,
            "DriveCache":drive_cache
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
system_id
storage_id
logical_id
BootEnable
Boolean
Whether the logical drive is a boot drive.
This field is not available when the PMC storage controller is in the PBSI channel.
DefaultWritePolicy
·     WriteThrough.
·     WriteBack.
·     AlwaysWriteBack.
DefaultReadPolicy
·     NoReadAhead.
·     ReadAhead.
AccessPolicy
String.
·     Read/Write.
·     ReadOnly.
·     Blocked.
DriveCache
String.
Physical drive cache policy. Supported options:
·     Physical disk cache policy.
·     Enable.
·     Disable.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Systems/1/Storages/RAIDStorage0/Volumes/LogicalDrive239
Request header:
X-Auth-Token:TOKEN
Request body:
    "Oem":{
        "Public":{
"BootEnable":false,
            "AccessPolicy":"Blocked",
            "DriveCache":"Disabled"
Response:
    "Encrypted": false,
    "Links": {
        "Drives": [
    "Name": "",
    "Oem": {
        "Public": {
            "BGIEnable": true,
            "CompletionCode": 0,
            "SpanNumber": 1,
    "Status": {
        "Health": "OK",
        "Oem": {
            "Public": {
        "State": "Enabled"
Response code: 200
Response field description
The server returns status code 200 for a successful operation.
For information about the response fields, see "Obtain logical drive information."
Change history
Version
Change description
HDM3-1.14
Added the Oem.Public.BootEnable field.
HDM2-2.06
HDM2-1.53
Obtain BIOS setting collection information
Obtain information about the BIOS setting collection from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Bios
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Bios
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@Redfish.Settings": {
        "@odata.type": "#Settings.v1_1_2.Settings",
        "SettingsObject": {
            "@odata.id": "/redfish/v1/Systems/1/Bios/Settings"
    "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/Bios/$entity",
    "@odata.id": "/redfish/v1/Systems/1/Bios",
    "@odata.type": "#Bios.v1_1_2.Bios",
    "Actions": {
        "#Bios.ChangePassword": {
            "target": "/redfish/v1/Systems/1/Bios/Actions/Bios.ChangePassword"
        "#Bios.ResetBios": {
            "ResetType@Redfish.AllowableValues": [
                "Reset"
            "target": "/redfish/v1/Systems/1/Bios/Actions/Bios.ResetBios"
        "#Settings.Revoke": {
            "target": "/redfish/v1/Systems/1/Bios/Settings/Actions/Oem/Public/Settings.Revoke"
    "AttributeRegistry": "BiosAttributeRegistry",
    "Attributes": null,
    "BiosRegistry": {
        "@odata.id": "/redfish/v1/Systems/1/Bios/BiosRegistry"
    "BscBootInfo": null,
    "Description": "BIOS Configuration Current Settings",
    "Id": "Bios",
    "Name": "BIOS Configuration Current Settings",
    "Oem": {
        "Public": {
Response code: 200
Data type
SettingsObject
List of BIOS setting objects.
@odata.id
String
Link to a BIOS setting resource.
@odata.context
String
OData description of the BIOS setting collection resource model.
@odata.id
String
Link to the BIOS setting collection resource.
@odata.type
String
Type of the BIOS setting collection resource.
AttributeRegistry
String
Resource ID of the BIOS Attribute Registry.
Actions
Available operations on a BIOS resource.
Bios.ResetBios
Object
Restore default BIOS settings.
Array
Available restoration operations. Options include:
·     Reset.
target
String
Link to the default BIOS setting restoration operation.
Bios.ChangePassword
Object
Change a BIOS password.
target
String
Link to the BIOS password change operation.
Settings.Revoke
Object
Clear inactive BIOS settings.
target
String
Clear link to the inactive BIOS.
Attributes
Object
For more information about configurable BIOS settings, see the BIOS user guides on the official website:
·     Intel platformH3C Server Eagle Stream Platform BIOS User Guide.
·     AMD platformH3C Server AMD EPYC Series Genoa Processor BIOS User Guide.
BscBootInfo.CurrentBootMode
String
Current system boot mode.
BscBootInfo.CurrentFirstBootDevice
String
First boot device in the system.
BiosRegistry
Object
Link to access detailed BIOS configuration rules.
String
Description of the BIOS configuration.
Id
String
ID of the BIOS configuration.
Name
String
Name of the BIOS configuration.
Obtain pending BIOS setting information
Obtain information about pending BIOS settings from the server. Pending BIOS settings refer to BIOS settings that will take effect at the next boot.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Bios/Settings
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Bios/Settings
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/Bios/Settings/$entity",
    "@odata.id": "/redfish/v1/Systems/1/Bios/Settings",
    "AttributeRegistry": "BiosAttributeRegistryP18.5.15",
    "Attributes": {
    "Description": "BIOS Configuration Pending Settings",
    "Id": "Settings",
    "Name": "BIOS Configuration Pending Settings",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the BIOS resource model.
@odata.id
String
Link to the BIOS resource.
@odata.type
String
Type of the BIOS resource.
AttributeRegistry
String
Attributes
Object
Attributes of the pending BIOS configuration.
String
Description of the pending BIOS configuration.
Id
String
ID of the pending BIOS configuration.
Name
String
Name of the pending BIOS configuration.
Configure a BIOS setting
Configure a specific BIOS setting for the server.
Privilege module
OemKvm
BIOS configuration locking
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Systems/system_id/Bios/Settings
Request header:
X-Auth-Token:TOKEN
If-Match:ifmatch_value
Request body:
  "Attributes": {
"BootOrder1": BootOrder1,
    "BootOrder2": BootOrder2,
    "BootOrder3": BootOrder3,
    "BootOrder4": BootOrder4
Parameter
Value
device_ip
TOKEN
system_id
ifmatch_value
Entity tag (ETag) that uniquely represents the requested resource.
To obtain the entity tag value of a resource, send a GET request to it and then obtain the ETag value from the response header.
Attributes
BIOS settings to be configured.
The four boot options are all mandatory in each request and each boot option supports only one value.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Systems/1/Bios/SD
Request header:
X-Auth-Token:TOKEN
Request body:
  "Attributes": {
"BootOrder1": "Hard Disk",
    "BootOrder2": "Network",
    "BootOrder3": "CD/DVD",
    "BootOrder4": "Other Device"
Response:
    "@odata.type": "#Bios.v1_1_1.Bios",
    "Attributes": {
    "Id": "Settings",
    "Oem": {
        "Public": {
            "Description": "Success"
Response code: 200
For information about the response fields, see "Obtain pending BIOS setting information."
Change history
Version
Change description
HDM2-1.53
Set a BIOS password
Set a BIOS password for the server.
After configuring the password, you must reboot the BIOS one to two times for the new password to take effect. To avoid an invalid password, do not perform any operation on the server during the reboot. If password complexity check is enabled, the BIOS performs the check.
Privilege module
OemKvm
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/Bios/Actions/Bios.ChangePassword
Request header:
X-Auth-Token:TOKEN
Request body:
"UserName":name,
"Password":password
Parameter
Value
device_ip
TOKEN
system_id
UserName
User type.
Supported options:
·     Admin.
·     User.
·     PowerOn.
Password
Password string.
The password must be a case-sensitive string of 8 to 20 characters and can contain the letters, digits, spaces, and the following special characters: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
If password complexity check is enabled in the BIOS, the password must meet the following requirements:
·     Contain a minimum two of the following character types: Uppercase letters, lowercase letters, and digits.
·     Contain a minimum of one space or special character.
The interface does not perform password complexity check. After the setting, restart the BIOS and verify if the setting takes effect.
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Bios/Actions/Bios.ChangePassword
Request header:
X-Auth-Token:TOKEN
Request body:
"UserName":"User",
"Password":"Password@_"
Response:
"Oem": {
       "Public": {
"error": {
       "@Message.ExtendedInfo": [
               "@odata.type": "#Message.v1_1_1.Message",
               "Message": "Successfully Completed Request",
               "MessageArgs": [],
               "MessageId": "Base.1.8.1.Success",
               "MessageSeverity": "OK",
               "Resolution": "None"
        "code":"Base.1.8.1.Success",
        "message":"Successfully Completed Request"
Response code: 200
Data type
code
String
String of a specific message ID in the message registry.
message
String
Readable error message corresponding to the message in the message registry.
Extended information of the message.
@odata.type
String
OData description of the message resource.
MessageId
String
Message ID.
Message
String
Details of the message.
MessageArgs
Array
Message arguments.
MessageSeverity
String
Severity level. Supported options:
·     OK.
·     Warning.
·     Critical.
Resolution
String
Recommended actions for the error.
Change history
Version
Change description
HDM3-1.14
Added the PowerOn option to the UserName field.
HDM2-2.04
Added the error node before Message.ExtendedInfo and added the code and message fields under the error node.
HDM2-1.53
·     Added the locking type of the associated system.
·     Added description for BIOS password complexity check.
Restore the default BIOS settings
Restore the default BIOS settings.
Privilege module
OemKvm
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/Bios/Actions/Bios.ResetBios
Request header:
X-Auth-Token:TOKEN
Request body:
"ResetType": "Reset"
Parameter
Value
device_ip
TOKEN
system_id
ResetType
Operation type.
Supported options:
·     Reset.
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Bios/Actions/Bios.ResetBios
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain BIOS detailed setting rules information
Obtain BIOS detailed setting rules information.
Privilege module
Login
BMC configuration locking
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Bios/BiosRegistry
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Bios/BiosRegistry
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#AttributeRegistry.AttributeRegistry",
    "@odata.id": "/redfish/v1/Systems/1/Bios/BiosRegistry",
    "@odata.type": "#AttributeRegistry.v1_3_6.AttributeRegistry",
    "Description": "This registry defines a representation of BIOS Attribute instances",
    "Id": "BiosAttributeRegistry",
    "Language": "en-US",
"Name": "BIOS Attribute Registry",
"Oem": {
    "Public": {
    "OwningEntity": "AMI",
    "RegistryEntries": {
        "Attributes": [
                "AttributeName": "SetupMode",
                "DefaultValue": "Graphic",
                "DisplayName": "SetupMode",
                "Type": "Enumeration",
                "Value": [
                        "ValueDisplayName": "Text",
                        "ValueName": "Text"
                        "ValueDisplayName": "Graphic",
                        "ValueName": "Graphic"
    "RegistryVersion": null
Response code: 200
Data type
@odata.context
String
OData description of the BIOS detailed setting rules model.
@odata.id
String
Link to the BIOS detailed setting rules.
@odata.type
String
Type of the BIOS detailed setting rules resource.
String
Description of the BIOS detailed setting rules.
Id
String
ID of the BIOS detailed setting rules.
RegistryEntries
Object
BIOS setting rule entries.
Attributes
Object
·     For more information about configurable BIOS settings, see the BIOS user guides on the official website:
AttributeName
String
BIOS attribute name.
DisplayName
String
Display name.
DefaultValue
String
Default settings.
Value
Object
Value range.
Change history
Version
Change description
HDM2-1.53
Create a KVM resource
Create a KVM resource.
Privilege module
OemKvm
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/kvm
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Examples 1
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/kvm
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response 1:
    "@odata.context": "/redfish/v1/$metadataSystems/1",
    "@odata.id": "/redfish/v1/Systems/1/kvm",
    "@odata.type": "#ComputerSystemCollection.ComputerSystemCollection",
    "H5_KVM_Authority": {
        "@odata.id": "/redfish/v1/Systems/1/kvm/saxow7fnqUBgRa1"
    "Oem": {
        "Public": {
Response code: 200
Example 2
Purpose:
# Use KVM resource information obtained from Redfish to log in without a password.
Method and URL:
Use the H5 KVM resource link obtained from Response 1 and log in through the browser.
https://192.168.18.18/redfish/v1/Systems/1/kvm/GlPxiEitqy7QM0D
This allows remote control of the server through H5 KVM.
Data type
@odata.context
String
OData description of the KVM resource model.
@odata.id
String
Link to the KVM resource.
@odata.type
String
Type of the KVM resource.
H5_KVM_Authority
Object
Link to the unencrypted KVM resource.
The URL in http://path format indicates that the H5 KVM is unencrypted.
The URL in https://path format indicates that the H5 KVM is encrypted.
You can visit https://192.168.18.18 with the link attached to the end from a browser to access H5 KVM of the server without being authenticated. For example, visit https://192.168.18.18/redfish/v1/Systems/1/kvm/doo64Mgdr3bd6Ph5.
Obtain event log service collection information
Obtain information about all event log service resources from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/LogServices
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
system_id
Only value 1 is supported.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/LogServices
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/LogServices/$entity",
    "@odata.id": "/redfish/v1/Systems/1/LogServices",
    "@odata.type": "#LogServiceCollection.LogServiceCollection",
    "Actions": {
        "Oem": {
            "Public": {
                "#LogServices.ExportEventLog": {
                    "target": "/redfish/v1/Systems/1/LogServices/Actions/Oem/Public/LogServices.ExportEventLog"
    "Description": "Collection of LogServices for this Computer System",
    "Members": [
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1"
    "Name": "System Log Services Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the event log service collection resource model.
@odata.id
String
Link to the event log service collection resource.
@odata.type
String
Type of the event log service collection resource.
Name
String
Name of the event log service collection resource.
String
Description of the event log service collection resource.
Members@odata.count
Integer
Number of event log service resources.
Members
List of event log service resources.
Actions
Executable actions for LogServices.
Oem.Public. LogServices.ExportEventLog
Object
Link to export event log information.
Obtain event log service resource information
Obtain information about a specific event log service resource from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/LogServices/LogService_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
LogService_id
ID of the log service resource.
You can obtain available log service resource IDs from log service collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/LogServices/Log1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/LogServices/Members/$entity",
    "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1",
    "@odata.type": "#LogService.v1_2_0.LogService",
    "Actions": {
        "#LogService.ClearLog": {
            "target": "/redfish/v1/Systems/1/LogServices/Log1/Actions/LogService.ClearLog"
    "DateTime": "2022-02-19T15:30:04+08:00",
    "DateTimeLocalOffset": "UTC+08:00",
    "Description": "System Service Log for this Computer System",
    "Entries": {
        "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries"
    "Id": "Log1",
    "MaxNumberOfRecords": 1500,
    "Name": "System Service Log",
    "Oem": {
        "Public": {
    "OverWritePolicy": "WrapsWhenFull",
    "OverWritePolicy@Redfish.AllowableValues": [
        "WrapsWhenFull",
        "NeverOverWrites"
    "ServiceEnabled": true
Response code: 200
Data type
@odata.context
String
OData description of the event log service resource model.
@odata.id
String
Link to the event log service resource.
@odata.type
String
Type of the event log service resource.
Id
String
ID of the event log service resource.
Name
String
Name of the event log service resource.
String
Description of the event log service resource.
MaxNumberOfRecords
Integer
Maximum number log entries that can be recorded in the event log service resource.
OverWritePolicy
String
Overwrite policy for the event log service resource. Supported options:
·     Unknown.
·     WrapsWhenFull.
·     NeverOverWrite.
Array
List of allowable values for the overwrite policy.
DateTime
String
System time of the event log service resource.
DateTimeLocalOffset
String
Time zone of the event log service resource.
ServiceEnabled
Boolean
Enabling status of the event log service resource. Supported options:
·     true—Enabled.
·     false—Disabled.
Actions.#LogService.ClearLog
Object
Link to clear event logs entries action.
Entries
Object
Link to the event log collection resource.
Configure specified event log service resource settings
Configure specified event log service resource settings from the server.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Systems/system_id/LogServices/LogService_id
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
system_id
ifmatch_value
Matching parameters for request message.
Initiate a GET operation on the corresponding resource and obtain from the response header (corresponding to the "ETag" parameter).
LogService_id
OverWritePolicy
String
Event log service resource overwrite policy. Supported options:
·     WrapsWhenFull.
·     NeverOverWrites.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Systems/1/LogServices/Log1
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
    "Actions": {
    "Entries": {
    "Id": "Log1",
    "Oem": {
        "Public": {
        "WrapsWhenFull",
        "NeverOverWrites"
Response code: 200
For information about the response fields, see "Obtain event log entry resource information."
Obtain event log entry collection information
Obtain information about all event log entries of a log service from the server.
Privilege module
OemSystemAudit
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/LogServices/LogService_id/Entries
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
LogService_id
Example 1
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/LogServices/Log1/Entries
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/LogServices/Log1/Entries/$entity",
    "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries",
    "@odata.type": "#LogEntryCollection.LogEntryCollection",
    "Description": "Collection of System Event Log Entries",
    "Members": [
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/642"
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/543"
    "Members@odata.count": 642,
    "Members@odata.nextLink": "/redfish/v1/Systems/1/LogServices/Log1/Entries?$skip=100&$top=100",
    "Name": "System Event Log Entries",
    "Oem": {
        "Public": {
Response code: 200
Example 2
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/LogServices/Log1/Entries?$skip=10&$top=10&$expand=*
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "Members": [
            "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/LogServices/Log1/Entries/Members/$entity",
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/164",
            "@odata.type": "#LogEntry.v1_6_1.LogEntry",
            "Created": "2022-04-11T11:56:27+08:00",
            "Description": "System Event Log",
            "EntryCode": "Asserted",
            "EntryType": "Event",
            "EventTimestamp": "2022-04-11T11:56:27+08:00",
            "Id": "164",
            "Level": "Info",
            "Message": "Transition to Off Line",
            "MessageArgs": [
                1
            "Name": "Log Entry 164",
            "Oem": {
                "Public": {
                    "EventCode": "0x04400014"
            "SensorName": "FAN7_F_Status",
            "SensorType": "Fan",
            "Severity": "OK"
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/163",
            "Id": "163",
            "Level": "Info",
            "MessageArgs": [
                1
            "Name": "Log Entry 163",
            "Oem": {
                "Public": {
            "SensorName": "FAN6_F_Status",
            "Severity": "OK"
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/162",
            "Id": "162",
            "Level": "Info",
            "MessageArgs": [
                1
            "Name": "Log Entry 162",
            "Oem": {
                "Public": {
            "SensorName": "FAN5_F_Status",
            "Severity": "OK"
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/161",
            "Id": "161",
            "Level": "Info",
            "MessageArgs": [
                1
            "Name": "Log Entry 161",
            "Oem": {
                "Public": {
            "SensorName": "FAN4_F_Status",
            "Severity": "OK"
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/160",
            "Id": "160",
            "Level": "Info",
            "MessageArgs": [
                1
            "Name": "Log Entry 160",
            "Oem": {
                "Public": {
            "SensorName": "FAN3_F_Status",
            "Severity": "OK"
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/159",
            "Id": "159",
            "Level": "Info",
            "MessageArgs": [
                1
            "Name": "Log Entry 159",
            "Oem": {
                "Public": {
            "SensorName": "FAN2_F_Status",
            "Severity": "OK"
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/158",
            "Id": "158",
            "Level": "Info",
            "MessageArgs": [
                1
            "Name": "Log Entry 158",
            "Oem": {
                "Public": {
            "SensorName": "FAN1_F_Status",
            "Severity": "OK"
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/157",
            "Created": "2022-04-11T11:56:15+08:00",
            "EntryCode": "Deasserted",
            "EventTimestamp": "2022-04-11T11:56:15+08:00",
            "Id": "157",
            "Level": "Info",
            "Message": "CPU1 triggered an uncorrectable error",
            "MessageArgs": [
                1
            "Name": "Log Entry 157",
            "Oem": {
                "Public": {
                    "EventCode": "0x07b201df"
            "SensorName": "CPU1_Status",
            "SensorType": "Processor",
            "Severity": "OK"
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/156",
            "Id": "156",
            "Level": "Info",
            "Message": "LPC Reset occurred",
            "MessageArgs": [
                1
            "Name": "Log Entry 156",
            "Oem": {
                "Public": {
                    "EventCode": "0x22d000de"
            "SensorName": "ACPI_State",
            "SensorType": "System ACPI Power State",
            "Severity": "OK"
            "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/155",
            "Created": "2022-04-11T11:56:10+08:00",
            "EventTimestamp": "2022-04-11T11:56:10+08:00",
            "Id": "155",
            "Level": "Info",
            "Message": "Initiated by hard reset",
            "MessageArgs": [
                1
            "Name": "Log Entry 155",
            "Oem": {
                "Public": {
                    "EventCode": "0x1d1000de"
            "SensorName": "BMC_Boot_Up",
            "SensorType": "System Boot / Restart Initiated",
            "Severity": "OK"
"Members@odata.count": 174,
"Members@odata.nextLink": "/redfish/v1/Systems/1/LogServices/Log1/Entries?$skip=20&$top=100",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the event log entry collection resource model.
@odata.id
String
Link to the event log entry collection resource.
@odata.type
String
Type of the event log entry collection resource.
Name
String
Name of the event log entry collection resource.
String
Description of the event log collection resource.
Members@odata.count
Integer
Number of event log entry resources.
String
Link to an event log entry resource on multiple pages.
Members
List of event log entry resources.
Obtain information about a specific event log entry resource.
Privilege module
OemSystemAudit
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/LogServices/LogService_id/Entries/Entries_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
LogService_id
Entry_id
ID of the log entry resource.
You can obtain available log entry resource IDs from log entry collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/LogServices/Log1/Entries/29
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/Systems/1/LogServices/Log1/Entries/1",
    "@odata.type": "#LogEntry.v1_7_0.LogEntry",
    "Created": "2022-02-19T11:40:55+08:00",
"EventTimestamp": "2022-02-19T11:40:55+08:00",
"EventType": "StatusChange",
    "Id": "1",
    "Level": "Info",
    "Message": "Dropped_below_the_lower_major_threshold",
    "MessageArgs": [
        1
    "Name": "Log Entry 1",
    "Oem": {
        "Public": {
            "Description": "Success",
            "EventCode": "0x02200002"
    "SensorName": "Voltage",
"SensorType": "Voltage",
"Severity": "OK"
Response code: 200
Data type
@odata.context
String
OData description of the event log entry resource model.
@odata.id
String
Link to the event log entry resource.
@odata.type
String
Type of the event log entry resource.
Name
String
Name of the event log entry resource.
String
Description of the event log entry resource.
Severity
String
Severity of the log entry. Supported options:
·     OK.
·     Warning.
·     Critical.
Level
String
Security level of the log entry. Supported options:
·     Info.
·     Minor.
·     Major.
·     Critical.
Created
String
Creation time of the event log entry.
EntryType
String
Type of the event log entry. Supported options:
·     Event.
·     SEL.
·     Oem.
EventTimestamp
String
Time at which the event occurred.
EventType
String
Event type:
·     StatusChange
·     ResourceUpdated
·     ResourceAdded
·     ResourceRemoved
·     Alert
Message
String
Description of the event log entry.
Id
String
Event ID.
EntryCode
String
Event code. Supported options:
·     AssertedThe event is triggered
·     DeassertedThe event is cleared.
MessageArgs
Array
Message arguments.
SensorName
String
Sensor name.
SensorType
String
Sensor type.
Oem.Public.EventCode
String
Event code.
Change history
Version
Change description
HDM2-2.04
Added the EventType field.
Export event log entry information
Export the event log entry information.
Privilege module
OemSystemAudit
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/LogServices/Actions/Oem/Public/LogServices.ExportEventLog
Request header:
X-Auth-Token:TOKEN
Request body:
// Local export:
    "Type":"URI",
    "Content": "/tmp/web/dump.csv"
// Remote export:
Cifs or sftp
"Type":"URI",
"Content": "sftp://username:password@10.10.10.191/usr/dump.tar.gz"
//http, tftp, nfs, or https
    "Type":"URI",
"Content": "http://ip/filename",
"Oem": {
"Public": {
     "ScriptName":"1.php"
Parameter
Value
device_ip
TOKEN
system_id
String.
URI
Content
Link to export configuration file.
See "Others."
Oem.Public.ScriptName
Script name.
String.
This field is required if you use HTTP or HTTPS to export the configuration file.
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/LogServices/Actions/Oem/Public/LogServices.ExportEventLog
Request header:
X-Auth-Token:TOKEN
Request body:
    "Type":"URI",
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Clear event log entry information
Delete event log entries for a specific event log service from the server.
Privilege module
OemDiagnosis
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/LogServices/LogService_id/Actions/LogService.ClearLog
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
system_id
LogServices_id
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/LogServices/Log1/Actions/LogService.ClearLog
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Obtain GPU information
Obtain GPU information from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/GPU
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET http://172.16.13.176/redfish/v1/Systems/1/GPU
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata",
"@odata.id": "/redfish/v1/Systems/1/GPU",
"@odata.type": "#GPU.v1_0_0.GPU",
    "Description": "Get GPU info for this system",
    "GPUMaxNum":4,
    "Healthstate":{
    "OverallHealth":"OK"
    "GPU": [
            "FirmwareVersion": "88.00.1A.00.03",
            "ID": "0x1",
            "Manufacture": "NVIDIA",
            "Model": "Tesla V100-PCIE-16GB",
            "Name": "Tesla V100-PCIE-16GB",
"Oem": {
                "Public": {
                    "DriverVersion": "N/A",
                    "ECCEnable": 1,
                    "GCUVoltage": 0.75,
                    "GPUDeviceError": 16384,
                    "GPUMemoryError": 16384,
                    "HBMVoltage": 1.25,
                    "PCIeBusError": 16384,
                    "ProductDate": "20240517"
            "PartNumber": "1DB4-893-A1",
            "PowerConsumedWatts": 0,
"PowerCapacityWatts": 500,
            "SerialNumber": "0323617020478",
            "SlotNum": 2,
            "Status": {
                "Health": "OK",
                "State": "Enable",
                "Oem": {
                    "Public": {
                        "FaultDescription": "",
                        "Severity": "Informational"
            "TemperatureCelsius": 50
"Oem":{
        "Public":{
            "PowerControl": [
                    "PowerLimit": {
                        "CorrectionInMs": 30000,
                        "LimitException": "NoAction",
                        "LimitInWatts": 2000
                    "PowerMetrics": {
                        "MaxConsumedWatts": 10000,
                        "MinConsumedWatts": 1000
            "CompletionCode":0,
            "Description":"Success"
Response code: 200
Data type
@odata.context
String
OData description of the GPU resourcel model.
@odata.id
String
Link to the GPU resource.
@odata.type
String
Type of the GPU resources.
String
Description of the interface.
GPUMaxNum
Integer
Maximum numbers.
Healthstate.OverallHealth
String
Overall health status.
GPU.FirmwareVersion
String
GPU firmware version.
GPU.ID
String
GPU ID.
GPU.Manufacture
String
Manufacturer.
GPU.Model
String
Model.
GPU.Name
String
Product name.
GPU.Oem.Public.DriverVersion
String
Driver version (only supported by the Enflame S60 GPU).
GPU.Oem.Public.ECCEnable
String
Enabling status of ECC (only supported by the Enflame S60 GPU).
GPU.Oem.Public.GCUVoltage
Value
GCU voltage (only supported by the Enflame S60 GPU). The unit is V.
GPU.Oem.Public.HBMVoltage
Value
HBM voltage (only supported by the Enflame S60 GPU). The unit is V.
GPU.Oem.Public.GPUDeviceError
Value
GPU device error (only supported by the Enflame S60 GPU). Values include:
·     0: Represents healthy.
·     16384: Represents that a recoverable error has occurred on the acceleration module.
·     32768: Represents that a non-recoverable error has occurred on the acceleration module peripheral.
GPU.Oem.Public.PCIeBusError
Value
PCIe error (only supported by the Enflame S60 GPU). Values include:
·     16384: Represents that a recoverable error has occurred on the acceleration module peripheral.
·     32768: Represents that a non-recoverable error has occurred on the acceleration module.
GPU.Oem.Public.GPUMemoryError
Value
GPU memory error (only supported by the Enflame S60 GPU). Values include:
·     16384: Represents that a recoverable error has occurred on the acceleration module VRAM.
·     32768: Represents that a non-recoverable error has occurred on the acceleration module VRAM.
GPU.Oem.Public.ProductDate
String
Product production date (only supported by the Enflame S60 GPU). Values include:
GPU.PartNumber
String
Part number.
GPU.PowerConsumedWatts
Integer
Power. If this field is 0, install the GPU driver in the OS.
GPU.PowerCapacityWatts
Integer
Rated power.
GPU.SerialNumber
String
Serial number.
GPU.SlotNum
Integer
Slot number.
GPU.Status.Health
String
GPU health status.
GPU.Status.State
String
Whether the GPU is present.
GPU.Status.Oem.Public.Severity
String
Custom health status.
GPU.Status.Oem.Public.FaultDescription
String
Fault description information.
GPU.TemperatureCelsius
Integer
GPU temperature in Celsius degree.
Members@odata.count
Integer
Number of GPUs.
PowerControl.PowerLimit.CorrectionInMs
Integer
Correction time of GPU node power capping in ms.
PowerControl.PowerLimit.LimitException
String
Action upon GPU node power capping failure. Options include NoAction and HardPowerOff.
The HardPowerOff option is not supported by G6 servers.
PowerControl.PowerLimit.LimitInWatts
Integer
GPU node power cap value. Null indicates power capping is disabled
PowerControl.PowerLimit.PowerLimitEnable
Boolean
Enabling status of power capping.
PowerControl.PowerMetrics.MaxConsumedWatts
Integer
Maximum GPU node power cap value.
PowerControl.PowerMetrics.MinConsumedWatts
Integer
Minimum GPU node power cap value.
This operation is supported only by G6 5500 AMD/Intel models.
Change history
Version
Change description
HDM3-2.01
Added the GPU.PowerCapacityWatts field.
HDM2-2.10
Added the GPU.Oem.Public.DriverVersion, GPU.Oem.Public.ECCEnable, GPU.Oem.Public.GCUVoltage, GPU.Oem.Public.HBMVoltage, GPU.Oem.Public.GPUDeviceError, GPU.Oem.Public.PCIeBusError, GPU.Oem.Public.GPUMemoryError, and GPU.Oem.Public.ProductDate fields.
HDM2-1.58
Added the description, which indicates that G6 servers do not support the HardPowerOff option of the PowerControl.PowerLimit.LimitException field.
Configure GPU information
Configure GPU node power capping. This operation is supported only by G6 5500 AMD/Intel models.
Privilege module
OemKvm
Locking type of the associated system
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Systems/system_id/GPU
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
Request body:
    "Oem":{
        "Public":{
            "PowerControl":[
                    "PowerLimit":{
                        "LimitInWatts":limit_watts,
                        "LimitException":"limit_exception
Parameter
Value
device_ip
TOKEN
system_id
Action upon a power capping failure.
Supported values include NoAction and HardPowerOff.
Power cap value.
The power cap value range is 1000 W to 10000 W. Power capping is enabled automatically when you set a power cap value in the range of 1000 W to 10000 W. When power capping is disabled, this field displays null, and the power cap value and action upon power cap failure retain the values configured last time.
Method and URL:
PATCH http://172.16.13.176/redfish/v1/Systems/1/GPU
Request header:
X-Auth-Token:TOKEN
Request body:
//Enable GPU power capping and configure the power cap value.
    "Oem":{
        "Public":{
            "PowerControl":[
                    "PowerLimit":{
                        "LimitInWatts":2000,
                        "LimitException":"NoAction"
Response:
    "GPUMaxNum":4,
    "Healthstate":{
    "GPU": [
            "ID": "0x1",
            "SlotNum": 2,
            "Status": {
                "Health": "OK",
                "State": "Enable",
                "Oem": {
                    "Public": {
"Oem":{
        "Public":{
            "PowerControl": [
                    "PowerLimit": {
                        "LimitInWatts": 2000,
                        "PowerLimitEnable": true
                    "PowerMetrics": {
            "CompletionCode":0,
Response code: 200
For more information about the response field description, see "Obtain GPU information."
Change history
Version
Change description
HDM2-1.58
HDM2-1.53
Obtain information about security control panel
Obtain information about security control panel. This feature is not available for X18000 products.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/SecurityBezel
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/SecurityBezel
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#SecurityBezel/$entity",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/SecurityBezel",
    "@odata.type": "#SecurityBezel.v1_0_0.SecurityBezel",
    "Description": "Security Bezel Control",
    "Id": "SecurityBezel",
    "Name": "SecurityBezel",
    "Oem": {
        "Public": {
    "SecurityBezelEnabled": true,
    "SecurityBezelSettings": {
        "DecorativeLEDMode": {
            "RelatedOemMode": {
                "Color": "White",
                "LEDFlashingMode": "Breathing"
            "RelatedStatusMode": null
        "DecorativeLEDType": "Bright",
        "LogoLEDEnabled": true
Response code: 200
Data type
@odata.context
String
OData description of the control panel resource model.
@odata.id
String
Link to the control panel resources.
@odata.type
String
Type of the control panel resource.
String
Description of the control panel resource.
Id
String
ID of the control panel resource.
Name
String
Name of the control panel resource.
Boolean
Security panel enabled.
Object
Panel settings.
SecurityBezelSettings.DecorativeLEDType
String
Supported options:
·     Bright: Brightness.
·     Soft: Softness.
·     Off: Disabled.
SecurityBezelSettings.LogoLEDEnabled
Boolean
Logo LED enabled status.
SecurityBezelSettings.DecorativeLEDMode
Object
Ambient LED mode.
SecurityBezelSettings.DecorativeLEDMode.RelatedStatusMode
Object
Ambient LED status-linked mode.
SecurityBezelSettings.DecorativeLEDMode.RelatedStatusMode.RelatedHealthEnabled
Boolean
Health status-linked enabled status.
·     true—status-linked.
·     false—custom.
SecurityBezelSettings.DecorativeLEDMode.RelatedOemMode
Object
Ambient LED custom mode.
SecurityBezelSettings.DecorativeLEDMode.RelatedOemMode. LEDFlashingMode
String
Custom ambient LED effects. Supported options:
·     Breathing—Breathing.
·     Flow—Flowing.
·     Steady On: Always on.
SecurityBezelSettings.DecorativeLEDMode.RelatedOemMode.Color
String
Custom LED colors. Supported options:
·     White—White.
·     Amber—Orange.
·     Red—Red.
Set security control panel information
Set security control panel information. This feature is not available for X18000 products.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Systems/system_id/Oem/Public/SecurityBezel
Request header:
X-Auth-Token:TOKEN
Request body:
            "RelatedOemMode": {
                "Color": "White",
Parameter
Value
device_ip
TOKEN
system_id
Panel Settings.
Object.
Decorative LED setting types.
String. Supported options:
·     Bright:
·     Soft.
·     Off.
Logo LED enable status.
Boolean.
Ambient LED Mode.
Object.
Ambient LED status linked mode.
Object.
SecurityBezelSettings. DecorativeLEDMode. RelatedStatusMode. RelatedHealthEnabled
Health status linked enable status.
Boolean.
Custom Ambient LED mode.
Object.
SecurityBezelSettings.DecorativeLEDMode.RelatedOemMode.LEDFlashingMode
Ambient LED effect.
·     Flow—Flowing.
·     Steady On—Always on.
Light color.
·     White.
·     Amber.
·     Red.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/SecurityBezel
Request header:
X-Auth-Token:TOKEN
Request body:
            "RelatedOemMode": {
                "Color": "White",
Response:
    "Oem": {
        "Public": {
            "RelatedOemMode": {
                "Color": "White",
Response code: 200
For more information about the response field description, see "Obtain information about security control panel."
Change history
Version
Change description
HDM2-1.53
Obtain information about network interface collection resource
Obtain information about network interface collection resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/NetworkInterfaces
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/NetworkInterfaces
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/NetworkInterfaces/$entity",
    "@odata.id": "/redfish/v1/Systems/1/NetworkInterfaces",
    "@odata.type": "#NetworkInterfaceCollection.NetworkInterfaceCollection",
    "Members": [
            "@odata.id": "/redfish/v1/Systems/1/NetworkInterfaces/PCIeSlot3"
    "Members@odata.count": 1,
    "Name": "Network Interface Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of network interface resource model.
@odata.id
String
Link to the network interface resource.
@odata.type
String
Type of the network interface resource.
Name
String
Name of the network interface resource.
Members@odata.count
Integer
Number of network interface resources.
Members
List of the network interface resources.
Obtain information of the specified network interface resource
Obtain information of the specified network interface resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/NetworkInterfaces/networkinterfaces_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
ID of the network interface resource.
You can obtain network interface resource IDs from network interface collection resource.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/NetworkInterfaces/PCIeSlot3
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/NetworkInterfaces/Members/$entity",
    "@odata.id": "/redfish/v1/Systems/1/NetworkInterfaces/PCIeSlot3",
    "@odata.type": "#NetworkInterface.v1_2_1.NetworkInterface",
    "Id": "PCIeSlot3",
    "Links": {
        "NetworkAdapter": {
            "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot3"
    "Name": "PCIeSlot3",
    "NetworkPorts": {
        "@odata.id": "/redfish/v1/Systems/1/NetworkInterfaces/PCIeSlot3/NetworkPorts"
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
Id
String
Name
String
Links.NetworkAdapter
Object
Link to the network adapter resource node.
NetworkPorts
Object
Link to the network port resource node.
Obtain network port collection information
Obtain network port collection information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/NetworkInterfaces/networkinterfaces_id/NetworkPorts
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/NetworkInterfaces/PCIeSlot3/NetworkPorts
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/NetworkInterfaces/Members/mainboardNIC1/NetworkPorts/$entity",
    "@odata.id": "/redfish/v1/Systems/1/NetworkInterfaces/PCIeSlot3/NetworkPorts",
    "@odata.type": "#NetworkPortCollection.NetworkPortCollection",
    "Members": [
            "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot3/NetworkPorts/1"
            "@odata.id": "/redfish/v1/Chassis/1/NetworkAdapters/PCIeSlot3/NetworkPorts/2"
    "Members@odata.count": 2,
    "Name": "Network Port Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the system resource model.
@odata.id
String
Link to the system resource.
@odata.type
String
Type of the system resource.
Members@odata.count
String
Current number of system resources.
Name
Integer
Name of the system resource.
Members
List of network port resources.
@odata.id
String
Link to a single network port resource node.
Clear configuration
Clear BMC, BIOS, and storage configurations.
Privilege module
ConfigureUsers
Hardware configuration locking (when clearing storage configuration), BIOS configuration locking (when clearing BIOS configuration), BMC configuration locking (when clearing BMC configuration)
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/Actions/Oem/Public/Systems.ClearConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
  "SecureErase":[
      "erase_option1",
      "erase_option2",
        "erase_option3"
Parameter
Value
device_ip
TOKEN
system_id
SecureErase
Array.
Optional Fields:
·     BIOS.
·     Storage.
·     BMC.
The Storage field is not available for X18000.
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Actions/Oem/Public/Systems.ClearConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
  "SecureErase":[
      "BIOS",
      "Storage",
        "BMC"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Download clear configuration reports
Download the cleared configuration report.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/Actions/Oem/Public/Systems.ExportReport
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Actions/Oem/Public/Systems.ExportReport
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"@odata.context": "/redfish/v1/$Systems.ClearExportReport",
    "@odata.type": "#Systems.ClearExportReport",
        "@odata.id": "/redfish/v1/Systems/1/Actions/Oem/Public/Systems.ExportReport",
    "Description": "ClearConfigurationDownload",
      "FileName":"/mnt/sdmmc0p4/secure_erase_result.csv"
Response code: 200
Data type
@odata.context
String
OData description information for server upgradable firmware collection resource model.
@odata.id
String
Link to server upgradable firmware collection resource node.
@odata.type
String
Type of the server upgradable firmware collection resource.
FileName
String
Exported file link and name.
String
Description of the server upgradable firmware collection resource.
Obtain the detailed progress of configuration clearance
Obtain the detailed progress of configuration clearance.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/ClearConfigurationProgress
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/ClearConfigurationProgress
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#ClearConfigurationProgress.ClearConfigurationProgress",
  "@odata.id": "/redfish/v1/Systems/1/Oem/Public/ClearConfigurationProgress",
  "@odata.type": "#ClearConfigurationProgress.v1_0_0.ClearConfigurationProgress",
    "TotalProgress": 60,
"ClearStatus": "Waiting",
  "Storage":
      "SD":{
          "Progress": 100,
          "Message": ""
      "NVDIMM":{
          "Progress": 100,
          "Message": ""
      "StorageController":[
              "Model":"RSTe&VROC",
              "Slot":null,
              "Mode":null,
              "Drives":[
                      "DriveType": "SATA",
                      "MediaType": "HDD",
                      "Progress": 99,
                      "Position": "[11:0:0:0]",
                      "Message": ""
                      "MediaType": "HDD",
                      "Progress": 100,
                      "Position": "[12:0:0:0]",
                      "Message": ""
              "Model": "P460-M2",
              "Slot": "1",
              "Mode": "RAID",
              "Drives": [
                      "DriveType": "NVME",
                      "MediaType": "SSD",
                      "Position": "Controller:1, Channel:1, Device:1",
                      "Progress": 10,
                      "Message": ""
   "BIOS":
      "Progress": 10,
      "Message": ""
Response code: 200
Data type
@odata.context
String
OData description for server upgradable firmware collection resource model.
@odata.id
String
Link to the server upgradable firmware collection resource node.
@odata.type
String
Type of the server upgradable firmware collection resource node.
TotalProgress
Integer
Overall progress.
ClearStatus
String
Clear status types. Supported options:
·     Idle.
·     Waiting.
·     In Progress.
·     Completed.
Storage.SD.Progress
Integer
Clearance progress of the storage SD card.
Storage.SD.Message
String
This field records error messages and displays empty when the error information has been successfully cleared.
Storage.NVDIMM.Progress
Integer
·     Storage NVDIMM clearance progress.
Storage.NVDIMM.Message
String
This field records error messages for storage NVDIMM and displays empty when the error information has been successfully cleared.
Storage.StorageController
Array
Storage.StorageController.Model
String
Model of the storage controller.
Storage.StorageController.Slot
Integer
Slot number.
String
Mode.
Storage.StorageController.Drives
Array
Storage.StorageController.Drives.DriveType
String
Type of the storage controller interface.
Storage.StorageController.Drives.MediaType
String
Media type. Options:
·     SSD.
·     HDD.
Storage.StorageController.Drives.Progress
Integer
Progress 0 to 100, in percent.
Storage.StorageController.Drives.Position
String
Location information.
Storage.StorageController.Drives.Message
String
BIOS.Progress
Integer
BIOS.Message
String
Change history
Version
Change description
HDM2-2.15
Edited the description for the ClearStatus field.
Obtain the system software inventory information
Obtain the system software inventory information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/SoftwareList
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
ID of the system resource.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/SoftwareList
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#SoftwareList/$entity",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/SoftwareList",
"@odata.type": "#SoftwareList.v1_0_0.SoftwareList",
"AgentState": "Enabled",
    "Description": "Get software list",
"Id": "SoftwareList",
"Name": "SoftwareList",
"OSHostName": "Not detected",
    "Oem": {
        "Public": {
    "SoftwareInfoList": {
        "Details": [
                "Index": 0,
                "Locations": "/usr/local/sbin",
                "Name": "Test1",
                "UpdateTimes": "2021-02-14T18:15:25+08:00",
                "Version": "5.7.24"
        "TotalNumber": 5
    "SystemType": "Windows",
    "SystemVersion": "CentOS release 6.9 (Final)",
    "Version": "V001"
Response code: 200
Data type
@odata.context
String
OData description for the system software inventory resource model.
@odata.id
String
Link to the system software inventory resource.
@odata.type
String
Type of system software inventory resources.
Id
String
ID of system software inventory resources.
Name
String
Name of the system inventory resource.
OSHostName
String
System host name.
String
Description for the system software inventory resource.
SoftwareInfoList
Object
System software inventory details
SoftwareInfoList.Details
Array
Details of the system software inventory.
Location
SoftwareInfoList.Details.Index
Integer
Software index.
SoftwareInfoList.Details.Locations
String
Software Location
SoftwareInfoList.Details.Name
String
Name of the software.
SoftwareInfoList.Details.UpdateTimes
String
Update time of the software versions.
SoftwareInfoList.Details.Version
String
Software version information.
SoftwareInfoList.TotalNumber
Integer
Number of the software.
SystemType
String
System type.
SystemVersion
String
System version.
Version
String
Version information.
AgentState
Boolean
Whether FIST SMS is present. Supported options:
·     Enabled.
·     Absent.
Change history
Version
Change description
HDM2-2.14
HDM2-1.17
Added the OSHostName field.
Clear inactive BIOS configurations
Clear inactive BIOS configuration properties.
Privilege module
OemKvm
Request
Method and URL:
POST https://device_ip/redfish/v1/Systems/system_id/Bios/Settings/Actions/Oem/Public/Settings.Revoke
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Bios/Settings/Actions/Oem/Public/Settings.Revoke
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain host status migration information
Obtain host status migration information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/HostStatus
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/HostStatus
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#HostStatus.HostStatus",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/HostStatus",
    "@odata.type": "#HostStatus.v1_0_0.HostStatus",
    "AgentState": "Absent",
    "CurrentStartupRecords": {
        "BIOSStage": {
            "BiosVersion": "",
            "ComponentIsolated": false,
            "CurrentStageDurationSeconds": 0,
            "DurationSeconds": 0,
            "EndTime": "",
            "ErrorCount": 0,
            "FaultList": [],
            "MEFirmwareVersion": "",
            "POSTCode": "0x0000",
            "POSTCodeDescription": "",
            "StartTime": "",
            "VersionChanged": false
        "CurrentStage": "PowerDown",
        "OSStage": {
            "ErrorCount": 0,
            "FaultList": [],
            "ReadyTime": "",
            "StartTime": "",
            "UCECount": 0
        "PowerDownStage": {
            "PowerDownCause": "",
            "StartTime": ""
        "PowerUpStage": {
            "PowerUpCause": "",
            "StartTime": ""
    "DSDCardState": "Enabled",
    "HostSummary": {
        "RunningState": "PowerOff"
    "Id": "HostStatus",
    "LastStartupRecords": {
        "BIOSStage": {
            "BiosVersion": "",
            "EndTime": "",
            "ErrorCount": 0,
            "FaultList": [],
            "StartTime": "",
        "CurrentStage": "PowerUp",
        "OSStage": {
            "ErrorCount": 0,
            "FaultList": [],
            "ReadyTime": "",
            "StartTime": "",
            "UCECount": 0
        "PowerDownStage": {
            "StartTime": ""
        "PowerUpStage": {
            "PowerUpCause": "",
            "StartTime": ""
    "Name": "Host Status",
    "Oem": {
        "Public": {
    "SystemVersion": "Not detected",
    "TPMState": "Absent",
    "TPMType": null
Response code: 200
Data type
@odata.context
String
OData description information for host status resource model.
@odata.id
String
Link to the host status resource.
@odata.type
String
Type of host status resource.
Id
String
ID of host status resource.
Name
String
Name of host status resource.
AgentState
String
Agent presence status. Supported options:
·     Enabled.
·     Absent.
DSDCardState
String
·     DSDCard presence status.
·     Supported options:
·     Enabled.
·     Absent.
·     NotSupported.
TPMState
String
TPM status. Supported options:
·     Enabled.
·     Disabled.
·     Absent.
·     NotSupported.
TPMType
String
Name of the trusted password module. Options:
·     TPM.
·     TCM.
SystemVersion
String
System version.
HostSummary
Object
Host summary information.
RunningState
String
Current operating status.
Supported options:
·     PowerOn.
·     PowerOff.
DurationSeconds
Integer
·     Duration of current status.
Integer
Duration of BIOS phase.
LastStartupRecords
Object
·     Data of last boot status record.
Object
Data of current boot status record.
CurrentStage
String
Current host migration status phase.
Supported options:
·     PowerUp.
·     BIOS_Starting.
·     BIOS_Ending.
·     OS.
·     PowerDown.
PowerUpStage
Object
Power-on phase status information.
BIOSStage
Object
BIOS phase status information.
OSStage
Object
PowerDownStage
Object
Power-down phase.
StartTime
String
Start time of current status.
EndTime
String
End time of current status.
PowerUpCause
String
Reason for power-on.
PowerDownCause
String
Reason for power-off.
VersionChanged
Boolean
BIOS version changed.
ComponentIsolated
Boolean
Component isolation present.
POSTCode
String
Current power-on self-test code.
POSTCodeDescription
String
Description of power-on self-test code.
ErrorCount
Integer
Number of failures.
BiosVersion
Integer
BIOS version.
MEFirmwareVersion
Integer
ME version. (Not supported by AMD)
ReadyTime
String
Time for OS system readiness.
UCECount
Integer
Number of UCEs
FaultList
Array
List of fault logs.
Id
String
Log ID.
TimeStamp
String
Timestamp.
EventCode
String
Event code.
Message
String
Log details.
Change history
Version
Change description
HDM2-1.53
Added the NotSupported option to the DSDCardState field.
Obtain information about host resource monitoring
Obtain host resource monitoring information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#PerformanceMonitoring.PerformanceMonitoring",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring",
    "@odata.type": "#PerformanceMonitoring.v1_0_0.PerformanceMonitoring",
    "Description": "The system performance monitoring",
    "DriveHistoryUsageRate": {
        "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/DriveHistoryUsageRate"
    "DriveIOPSHistoryData": {
        "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/DriveIOPSHistoryData"
    "DriveSVCTMHistoryData": {
        "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/DriveSVCTMHistoryData"
"DriveUsageAlarmThreshold": 0,
    "DriveUsageRateAlarmThreshold": 0,
    "ExternalDevice": [
            "FreeSpaceMB": 4868,
            "Model": "Kingston_DataTraveler_2.0_C86000BDB7B8EF306A25DA0C",
            "SpeedMbps": 480.0,
            "TotalCapacityMB": 7792
            "FreeSpaceMB": 1395,
            "Model": "USB_SanDisk_3.2Gen1_010140fc9d2cd08aa332d1f13eed2cb7248bf3bfba8419ddfd79063f84b189dbe33000000000000000000000689ec8130084450091558107a22aad68",
            "SpeedMbps": 480.0,
            "TotalCapacityMB": 1652
    "FullDuplexThroughputHistoryData": {
        "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/FullDuplexThroughputHistoryData"
    "GPUHistoryUsageRate": {
        "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/GPUHistoryUsageRate"
    "Id": "PerformanceMonitoring",
    "MemoryHistoryUsageRate": {
        "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/MemoryHistoryUsageRate"
    "MemoryUsageAlarmThreshold": 0,
    "MemoryUsageRate": 11,
    "MemoryUsageRateAlarmThreshold": 0,
    "NFSClientIOSpeedHistoryData": {
        "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/NFSClientIOSpeedHistoryData"
    "NFSServerIOSpeedHistoryData": {
        "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/NFSServerIOSpeedHistoryData"
    "Name": "PerformanceMonitoring",
    "NetworkUsageRateAlarmThreshold": 0,
    "Oem": {
        "Public": {
    "ProcessorsHistoryUsageRate": {
        "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/ProcessorsHistoryUsageRate"
    "ProcessorsUsageAlarmThreshold": 0,
    "ProcessorsUsageRate": 0,
    "ProcessorsUsageRateAlarmThreshold": 0,
    "SystemLoadHistoryData": {
        "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/SystemLoadHistoryData"
Response code: 200
Data type
@odata.context
String
OData description of host resource monitoring model.
@odata.id
String
Link to host resource monitoring resources.
@odata.type
String
Type of host resource monitoring resources.
AgentState
String
Supported options:
·     Enabled.
·     Absent.
Id
String
Resource ID.
Name
String
Resource name.
String
Description for interface function.
Integer
CPU usage alarm threshold.
Integer
Memory usage alarm threshold.
Integer
Hard drive usage alarm threshold.
Integer
Network usage alarm threshold.
Object
Link to memory history usage resource.
Object
Link to CPU history usage resource.
Object
Link to network history send/receive speed resource.
GPUHistoryUsageRate
Object
Link to GPU history usage resource.
Object
Link to disk history usage resource.
Object
Link to disk IO performance history data.
Object
Link to disk SVCTM performance history data.
Object
Link to NFS server read/write speed history data.
Object
Link to NFS client read/write speed history data.
Object
Link to system load information history data.
ExternalDevice
Array
External device information.
Model
String
Device model.
SpeedMbps
Integer
Device speed.
TotalCapacityMB
Integer
Device total capacity.
FreeSpaceMB
Integer
Device available capacity.
MemoryUsageRate
Integer
Memory usage rate.
ProcessorsUsageRate
Integer
CPU usage rate.
Integer
Drive usage alarm threshold.
Integer
Integer
Change history
Version
Change description
HDM2-1.54
Added the DriveUsageAlarmThreshold, MemoryUsageAlarmThreshold, and ProcessorsUsageAlarmThreshold fields.
HDM2-1.14
Added MemoryUsageRate and ProcessorsUsageRate fields, and included output descriptions.
Configure host resource monitoring information settings
Configure host resource monitoring information settings.
Privilege module
OemKvm
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring
Request header:
X-Auth-Token:TOKEN
Request body:
    "ProcessorsUsageAlarmThreshold": processors_usage_alarm_threshold,
    "MemoryUsageAlarmThreshold": memory_usage_alarm_threshold,
    "NetworkUsageAlarmThreshold": network_usage_alarm_threshold,
    "DriveUsageAlarmThreshold": dirve_usage_alarm_threshold
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
system_id
CPU usage rate alarm threshold.
Integer.
Memory usage rate alarm threshold.
Integer.
Drive usage rate alarm threshold.
Integer.
Network port usage rate alarm threshold.
This field is not supported for configuration.
Integer.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring
Request header:
X-Auth-Token:TOKEN
Request body:
    "ProcessorsUsageAlarmThreshold": 20,
    "MemoryUsageAlarmThreshold": 10,
    "DriveUsageAlarmThreshold": 20
Response:
    "DriveUsageAlarmThreshold": 20,
    "DriveUsageRateAlarmThreshold": 20,
    "ExternalDevice": [
            "SpeedMbps": 480.0,
            "SpeedMbps": 480.0,
    "MemoryUsageRateAlarmThreshold": 10,
    "Oem": {
        "Public": {
            "CompletionCode": 0,
    "ProcessorsUsageRateAlarmThreshold": 20,
Response code: 200
Response field description
The server returns status code 200 for a successful operation.
For information about the response fields, see "Obtain information about host resource monitoring."
Change history
Version
Change description
HDM2-1.54
Added the DriveUsageAlarmThreshold, MemoryUsageAlarmThreshold, and ProcessorsUsageAlarmThreshold fields in the response.
HDM2-1.14
Added MemoryUsageRate and ProcessorsUsageRate fields in the response.
Obtain information about CPU historical usage rate resource
Obtain information about CPU historical usage rate resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring/ProcessorsHistoryUsageRate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/ProcessorsHistoryUsageRate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#ProcessorsHistoryUsageRate.ProcessorsHistoryUsageRate",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/ProcessorsHistoryUsageRate",
    "@odata.type": "#ProcessorsHistoryUsageRate.v1_0_0.ProcessorsHistoryUsageRate",
    "Description": "The historical usage rate of processors",
    "HistoricalUsageRate": [
            "Time": "2023-02-19T02:36:42+08:00",
            "UsageRatePercents": 5.27
            "Time": "2023-02-19T02:41:42+08:00",
            "Time": "2023-02-19T02:46:42+08:00",
            "UsageRatePercents": 5.29
    "Id": "ProcessorsHistoryUsageRate",
    "Name": "Processors History Usage Rate",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description for CPU historical usage rate resource model.
@odata.id
String
Link to CPU historical usage rate resource.
@odata.type
String
Type of CPU historical usage rate resource.
String
Description of CPU historical usage rate resource.
HistoricalUsageRate
Array
Historical data.
UsageRatePercents
Integer
Usage rate upon data generation.
Time
String
Time upon data generation.
Obtain information about memory historical usage rate resource
Obtain information about memory historical usage rate resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring/MemoryHistoryUsageRate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/MemoryHistoryUsageRate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#MemoryHistoryUsageRate.MemoryHistoryUsageRate",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/MemoryHistoryUsageRate",
    "@odata.type": "#MemoryHistoryUsageRate.v1_0_0.MemoryHistoryUsageRate",
    "Description": "The historical usage rate of memory",
            "Time": "2023-05-24T05:55:05+08:00",
            "UsageRatePercents": 9.35
            "Time": "2023-05-24T06:00:05+08:00",
            "UsageRatePercents": 9.36
    "Id": "MemoryHistoryUsageRate",
    "Name": "Memory History Usage Rate",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description for memory historical usage rate resource model.
@odata.id
String
Link to memory historical usage rate resource.
@odata.type
String
Type of memory historical usage rate resource.
String
Description of memory historical usage rate resource.
Name
String
Name of the memory historical usage rate resource.
Id
String
ID of the memory historical usage rate resource.
HistoricalUsageRate
Array
Historical data.
UsageRatePercents
Integer
Time
String
Obtain information about GPU historical usage rate resource
Obtain information about GPU historical usage rate resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring/GPUHistoryUsageRate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/ PerformanceMonitoring/GPUHistoryUsageRate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#GPUHistoryUsageRate.GPUHistoryUsageRate",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/GPUHistoryUsageRate",
    "@odata.type": "#GPUHistoryUsageRate.v1_0_0.GPUHistoryUsageRate",
    "Description": "The historical usage rate of GPU",
    "GPUList": [
                    "Time": "2022-07-29T10:55:00--03:00",
                    "UsageRatePercents": 0.5
                    "UsageRatePercents": 10.5
            "Name": "GeForce GT 720"
    "Id": "GPUHistoryUsageRate",
    "Name": "GPU History Usage Rate",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description for GPU historical usage rate resource model.
@odata.id
String
Link to GPU historical usage rate resource.
@odata.type
String
Type of GPU historical usage rate resource.
String
Description of GPU historical usage rate resource.
Name
String
Name of the GPU historical usage rate resource.
Id
String
ID of the GPU historical usage rate resource.
GPUList
Array
GPU historical data.
Name
String
GPU name.
HistoricalUsageRate
Array
Historical data.
UsageRate
Integer
Time
String
Obtain information about network bandwidth historical send/receive speed resource
Obtain information about network bandwidth historical send/receive speed resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring/FullDuplexThroughputHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/FullDuplexThroughputHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#FullDuplexThroughputHistoryData.FullDuplexThroughputHistoryData",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/FullDuplexThroughputHistoryData",
    "@odata.type": "#FullDuplexThroughputHistoryData.v1_0_0.FullDuplexThroughputHistoryData",
    "Description": "Historical data of full-duplex throughput",
    "Id": "FullDuplexThroughputHistoryData",
    "Name": "Full Duplex Throughput History Data",
    "Oem": {
        "Public": {
    "PortList":[
        "HistoricalData": [
                "ReceiveRate": 0.8,
                "Time": "2021-01-26T04:49:30-03:00",
                "TransmitRate": 0.9
                "ReceiveRate": 0.8,
                "TransmitRate": 0.9
        "PortId": "0",
        "PortName": "60:DA:83:80:3F:37"
        "HistoricalData": [
                "ReceiveRate": 0.8,
                "TransmitRate": 0.9
                "ReceiveRate": 0.8,
                "TransmitRate": 0.9
        "PortId": "1",
        "PortName": "60:DA:83:80:3F:38"
Response code: 200
Data type
@odata.context
String
OData description for network historical send/receive speed resource model.
@odata.id
String
Link to network historical send/receive speed resource model.
@odata.type
String
Type of network historical send/receive speed resource model.
String
Description of network historical send/receive speed resource model.
PortList
String
List of network port information.
PortName
String
Name of network port.
PortId
String
ID of network port.
HistoricalData
Array
Historical data.
TransmitRate
Integer
Network receiving speed upon data generation, in bps.
ReceiveRate
Integer
Network sending speed upon data generation, in bps.
Time
String
Obtain information about disk historical usage rate resource
Obtain information about disk historical usage rate resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring/DriveHistoryUsageRate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/DriveHistoryUsageRate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#DriveHistoryUsageRate.DriveHistoryUsageRate",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/DriveHistoryUsageRate",
    "@odata.type": "#DriveHistoryUsageRate.v1_0_0.DriveHistoryUsageRate",
    "Description": "The historical usage rate of drive",
            "TotalCapacityMB": 47897200,
            "UsageRatePercents": 4.04,
            "UsedCapacityGB": 1934608
    "Id": "DriveHistoryUsageRate",
    "Name": "Drive History Usage Rate",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the disk historical usage rate resource model.
@odata.id
String
Link to the disk historical usage rate resource.
@odata.type
String
Type of the disk historical usage rate resource.
String
Description of disk historical usage rate resource.
HistoricalUsageRate
Array
Historical data.
UsageRatePercents
Integer
TotalCapacityMB
Integer
Total capacity of partition upon data generation.
UsedCapacityGB
Integer
Used capacity of partition upon data generation.
Time
String
Obtain information about disk IO performance historical data
Obtain information about disk IO performance historical data.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring/DriveIOPSHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#DriveIOPSHistoryData.DriveIOPSHistoryData",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/DriveIOPSHistoryData",
    "@odata.type": "#DriveIOPSHistoryData.v1_0_0.DriveIOPSHistoryData",
    "Description": "The historical IOPS of drive",
    "Id": "DriveIOPSHistoryData",
    "Name": "Drive IOPS History Data",
    "Oem": {
        "Public": {
    "PartitionList": [
            "HistoricalInputOperations": [
                    "OperationsPerSecond": 4.1,
                    "Time": "2021-01-26T04:49:35-03:00"
            "HistoricalOutputOperations": [
                    "OperationsPerSecond": 3.1,
            "PartitionId": "1",
            "PartitionName": "sdb"
Response code: 200
Data type
@odata.context
String
OData description of disk IO performance resource model.
@odata.id
String
Link to disk IO performance resource.
@odata.type
String
Type of disk IO performance resource.
String
Description of disk IO performance resource.
PartitionList
Array
List of disk partitions.
PartitionName
String
Name of disk partition.
PartitionId
String
ID of disk partition.
Array
Historical data for write operations.
Array
Historical data for read operations.
OperationsPerSecond
Integer
Read/Write operations per second upon data generation.
Time
String
Obtain information about disk SVCTM historical data
Obtain the historical data information for disk SVCTM (fast and slow disks).
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring/DriveSVCTMHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
system_id
Only value 1 is supported.
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/DriveSVCTMHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
   "@odata.context": "/redfish/v1/$metadata#DriveSVCTMHistoryData.DriveSVCTMHistoryData",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/DriveSVCTMHistoryData",
    "@odata.type": "#DriveSVCTMHistoryData.v1_0_0.DriveSVCTMHistoryData",
    "Description": "The historical SVCTM of drive",
    "Id": "DriveSVCTMHistoryData",
    "Name": "Drive SVCTM History Data",
    "Oem": {
        "Public": {
    "PartitionList": [
            "HistorySVCTM": [
                    "ServiceTimeMs": 0.8,
            "PartitionId": "0",
            "PartitionName": "sda"
            "HistorySVCTM": [
            "PartitionId": "1",
Response code: 200
Data type
@odata.context
String
OData description of the disk SVCTM resource model.
@odata.id
String
Link to disk SVCTM resource.
@odata.type
String
Type of disk SVCTM resource.
String
Description of the disk SVCTM resource.
PartitionList
Array
PartitionName
String
Name of the disk partition.
PartitionId
String
ID of the disk partition.
HistorySVCTM
Array
Historical data for SVCTM.
ServiceTimeMs
Integer
SVCTM value upon data generation.
Time
String
Obtain information about NFS server read/write rate historical data
Obtain the historical data information for NFS server read/write rates.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring/NFSServerIOSpeedHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/NFSServerIOSpeedHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#NFSServerIOSpeedHistoryData.NFSServerIOSpeedHistoryData",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/NFSServerIOSpeedHistoryData",
    "@odata.type": "#NFSServerIOSpeedHistoryData.v1_0_0.NFSServerIOSpeedHistoryData",
    "Description": "The historical IOSpeed of NFS Server",
    "HistoricalReadOperations": [
            "SpeedMbps": 221.1,
            "Time": "2022-07-29T10:55:00-03:00"
            "SpeedMbps": 221.1,
    "HistoricalWriteOperations": [
            "SpeedMbps": 21.1,
            "SpeedMbps": 21.1,
    "Id": "NFSServerIOSpeedHistoryData",
    "Name": "NFS Server IOSpeed History Data",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description for NFS server read/write rate resource model.
@odata.id
String
Link to NFS server read/write rate resource.
@odata.type
String
Type of NFS server read/write rate resource.
String
Description of NFS server read/write rate resource.
Array
Array
SpeedMbps
Integer
Read/Write rate in KB/s upon data generation.
Time
String
Obtain information about NFS client read/write rate historical data
Obtain the historical data information for NFS client read/write rates.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring/NFSClientIOSpeedHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/NFSClientIOSpeedHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#NFSClientIOSpeedHistoryData.NFSClientIOSpeedHistoryData",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/NFSClientIOSpeedHistoryData",
    "@odata.type": "#NFSClientIOSpeedHistoryData.v1_0_0.NFSClientIOSpeedHistoryData",
    "ClientList": [
                    "SpeedMbps": 1.2,
                    "Time": "2022-07-29T10:55:30-03:00"
                    "SpeedMbps": 1.2,
"Name": "/mnt/share2"
                    "SpeedMbps": 21.1,
                    "SpeedMbps": 21.1,
            "Name": "/mnt/share1"
    "Id": "NFSClientIOSpeedHistoryData",
    "Name": "NFS Client IOSpeed History Data",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of for NFS client read/write rate resource model.
@odata.id
String
Link to NFS client read/write rate resource.
@odata.type
String
Type of NFS client read/write rate resource.
String
Description of NFS client read/write rate resource.
Array
Array
Name
String
Client name.
SpeedMbps
Integer
Time
String
Obtain information about system load historical data
Obtain the historical data information for system load.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/PerformanceMonitoring/SystemLoadHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/SystemLoadHistoryData
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#SystemLoadHistoryData.SystemLoadHistoryData",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/PerformanceMonitoring/SystemLoadHistoryData",
    "@odata.type": "#SystemLoadHistoryData.v1_0_0.SystemLoadHistoryData",
    "Description": "The historical system load",
    "HistoricalSystemLoad": [
            "LastFifteenMinutes": 0.12,
            "LastFiveMinutes": 0.07,
            "LastMinute": 0.07,
            "LastMinute": 0.07,
    "Id": "SystemLoadHistoryData",
    "Name": "System Load History Data",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the system load resource model.
@odata.id
String
Link to the system load resource.
@odata.type
String
Type of the system load resource.
String
Description of the system load resource.
Array
Historical data.
LoadRatePercents
Integer
Load percentage upon data generation.
Time
String
LastMinute
Integer
One-minute average system load upon data generation.
LastFifteenMinutes
Integer
Fifteen-minute average system load upon data generation.
LastFiveMinutes
Integer
Five-minute average system load upon data generation.
Obtain performance advisor recommendation information
Obtain performance advisor recommendation information.
This resource is licensed and requires authorization through licensing before use.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Systems/system_id/Oem/Public/WorkloadPerformanceAdvisor
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
system_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Systems/1/Oem/Public/WorkloadPerformanceAdvisor
Request header:
X-Auth-Token:TOKEN
Content-Type: application/json
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#WorkloadPerformanceAdvisor.WorkloadPerformanceAdvisor",
    "@odata.id": "/redfish/v1/Systems/1/Oem/Public/WorkloadPerformanceAdvisor",
    "@odata.type": "#WorkloadPerformanceAdvisor.v1_0_0.WorkloadPerformanceAdvisor",
    "Description": "Get the workload performance advisor information",
    "Id": "WorkloadPerformanceAdvisor",
    "Name": "WorkloadPerformanceAdvisor",
    "WorkloadProfileConfiguration": "Custom",
"TenMinutesInterval": {
    "ResourceUsageLevel": {
            "CPUUsageLevel": "High",
            "MemoryBusUsagelevel": "Low",
            "IOBusUsageLevel": "Low",
            "NUMAUsageLevel": null
    "RecommendedSettings": null
    "OneHourInterval": {
    "OneDayInterval": {
    "OneWeekInterval": {
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description information for performance advisor recommendation.
@odata.id
String
Access directory for performance advisor recommendation information.
@odata.type
String
Type of performance advisor recommendation information.
TenMinutesInterval
Object
10-minute interval.
OneHourInterval
Object
1-hour interval.
OneDayInterval
Object
1-day (24-hour) interval.
OneWeekInterval
Object
1-week interval.
String
Recommended configuration profile for the scenario.
·     High Performance Compute.
·     Custom.
Configuration profile is not recommended if this field is null.
ResourceUsageLevel
Object
Resource usage level.
This field is null if the host is powered off.
CPUUsageLevel
String
CPU usage level.
·     High.
·     Middle.
·     Low.
The field displays N/A if the obtained data are insufficient.
MemoryBusUsagelevel
String
Memory bus usage level.
·     High.
·     Middle.
·     Low.
IOBusUsageLevel
String
IO bus usage level.
·     High.
·     Middle.
·     Low.
NUMAUsageLevel
String
NUMA identification level.
·     High.
·     Middle.
·     Low.
RecommendedSettings
Object
Recommended settings.
This field is null, which represents that no recommended setting exists.
String
Description of the performance advisor recommendation information list resource.
Id
String
ID of the performance advisor recommendation information list resource.
Name
String
Name of the performance advisor recommendation information list resource.
Change history
Version
Change description
HDM2-2.08
Added the OneWeekInterval field.
Added a description to the CPUUsageLevel, MemoryBusUsagelevel, and IOBusUsageLevel fields to indicate that the field displays N/A if the obtained data are insufficient.
HDM2-2.04
Changed the support state for the NUMAUsageLevel and RecommendedSettings fields to not supported.
HDM2-1.60
Changed the interface description from "Obtain performance advisor information" to "Obtain performance advisor recommendation information."
HDM2-1.55
Added the redfish/v1/Systems/1/Oem/Public/WorkloadPerformanceAdvisor interface.
Upload and write the Intel On Demand License activation file
Upload and write the Intel On Demand License activation file.
Privilege module
ConfigureUsers
Request
POST https://device_ip/redfish/v1/Systems/system_id/Processors/cpu_id/Actions/Oem/Public/Processor.LicenseUpload/
Request header:
X-Auth-Token:TOKEN
Request body:
"Type":"URI",
"Content": "license file path"
Parameter
Value
device_ip
TOKEN
String
URI
Content
Link to the license file.
·     Operation path, which does not support Chinese characters.
·     Up to 1024 characters. Chinese characters are not supported and the following special characters are supported: @!$^&()_+.;[]{}-=~`
·     Only the /tmp/web/ directory and its subdirectories are supported locally.
·     Remote import is supported.
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Processors/1/Actions/Oem/Public/Processor.LicenseUpload/
Request header:
X-Auth-Token:TOKEN
Request body:
"Type":"URI",
"Content": "/tmp/web/LAC-B1BFB71B8395F812-00000001-FA8BD7DA7307E6-SGX512.json"
Response:
  "@odata.context": "/redfish/v1/$metadata#TaskCollection.TaskCollection",
  "@odata.type": "#TaskCollection.TaskCollection",
  "Members": [
      "@odata.id": "/redfish/v1/TaskService/Tasks/2"
  "Name": "Task Collection",
  "Oem": {
    "Public": {
      "TaskUniqueID": 1678656297
Response code: 202
Data type
@odata.context
String
OData description information for the task service for uploading and writing Intel On Demand License activation file.
@odata.type
String
Type of the task service for uploading and writing Intel On Demand License activation file.
Name
String
Name of the Intel On Demand License activation file.
Members@odata.count
Integer
Number of tasks generated by uploading and writing Intel On Demand License activation file.
Members
Array
Task link collection generated by uploading and writing Intel On Demand License activation file.
@odata.id
String
Link to the task service for uploading and writing Intel On Demand License activation file.
Oem.Public.TaskUniqueID
Integer
Unique ID of the task service for uploading and writing Intel On Demand License activation file.
The server returns status code 202 for a successful operation.
Change history
Version
Change description
HDM2-2.02
Added this interface.
Export the CPU status report
Export the CPU status report.
Privilege module
ConfigureUsers
Request
POST https://device_ip/redfish/v1/Systems/system_id/Processors/cpu_id/Actions/Oem/Public/Processor.StateReportExport/
Request header:
X-Auth-Token:TOKEN
Request body:
"Type":"URI",
"Content": "/tmp/web/CPU1_report_20290901T164036+0800.json"
Parameter
Value
device_ip
TOKEN
String
URI
Content
File path of the CPU status report.
·     Only the /tmp/web/ directory and its subdirectories are support.
·     Remote export is supported.
Method and URL:
POST https://192.168.18.18/redfish/v1/Systems/1/Processors/1/Actions/Oem/Public/Processor.StateReportExport/
Request header:
X-Auth-Token:TOKEN
Request body:
"Type":"URI",
Response:
  "Members": [
      "@odata.id": "/redfish/v1/TaskService/Tasks/3"
  "Oem": {
    "Public": {
      "Description": "Success",
      "TaskUniqueID": 1678656299
Response code: 202
Data type
@odata.context
String
OData description information for the task service for exporting the CPU status report.
@odata.type
String
Type of the task service for exporting the CPU status report.
Name
String
Name of the CPU status report.
Members@odata.count
Integer
Number of tasks generated by exporting the CPU status report.
Members
Array
Task link collection generated by exporting the CPU status report.
@odata.id
String
Link to the task service for exporting the CPU status report.
Integer
Unique ID of the task service for exporting the CPU status report.
Change history
Version
Change description
HDM2-2.02
Operations on manager resources
Obtain manager collection information
Obtain information about all managers from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Managers",
    "@odata.id": "/redfish/v1/Managers",
    "@odata.type": "#ManagerCollection.ManagerCollection",
    "Members": [
            "@odata.id": "/redfish/v1/Managers/1"
    "Name": "Manager Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the manager collection resource model.
@odata.id
String
Link to the manager collection resource.
@odata.type
String
Type of the manager collection resource.
Members
List of manager resources.
@odata.id
String
Link to a manager resource.
Members@odata.count
Integer
Number of manager resources.
Name
String
Name of the manager collection resource.
Obtain manager resource information
Obtain information about a specific manager resource from the server.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
ID of the manager resource.
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Manager.Manager(*)",
    "@odata.id": "/redfish/v1/Managers/1",
    "@odata.type": "#Manager.v1_10_0.Manager",
    "Actions": {
        "#LogService.ClearOperationLog": {
            "@Redfish.AllowableValues": [
            "target": "/redfish/v1/Managers/1/LogServices/Actions/LogService.ClearOperationLog"
        "#Manager.Reset": {
            "ResetType@Redfish.AllowableValues": [
                "ForceRestart"
            "target": "/redfish/v1/Managers/1/Actions/Manager.Reset"
        "Oem": {
            "Public": {
                "#Manager.Dump": {
                    "target": "/redfish/v1/Managers/1/Actions/Oem/Public/Manager.Dump"
                "#Manager.ExportConfiguration": {
                    "target": "/redfish/v1/Managers/1/Actions/Oem/Public/Manager.ExportConfiguration"
                "#Manager.GeneralDownload": {
                    "target": "/redfish/v1/Managers/1/Actions/Oem/Public/Manager.GeneralDownload"
                "#Manager.GeneralUpload": {
                    "target": "/redfish/v1/Managers/1/Actions/Oem/Public/Manager.GeneralUpload"
                "#Manager.ImportConfiguration": {
                    "target": "/redfish/v1/Managers/1/Actions/Oem/Public/Manager.ImportConfiguration"
                "#Manager.NodeSwitch": {
                    "target": "/redfish/v1/Managers/1/Actions/Oem/Public/Manager.NodeSwitch"
                "#Manager.ResetSD": {
                    "target": "/redfish/v1/Managers/1/Actions/Oem/Public/Manager.ResetSD"
                "#Manager.RestoreFactory": {
                    "ConfigurationType@Redfish.AllowableValues": [
                        "BMC"
                    "target": "/redfish/v1/Managers/1/Actions/Oem/Public/Manager.RestoreFactory"
    "CommandShell": {
        "ConnectTypesSupported": [
            "SSH"
        "MaxConcurrentSessions": 20,
        "ServiceEnabled": true
    "DateTime": "2017-04-17T08:28:22+08:00",
    "DateTimeLocalOffset": "UTC+08:00",
"Description": "BMC",
"DiagnosticService": {
    "@odata.id": "/redfish/v1/Managers/1/DiagnosticService"
    "EthernetInterfaces": {
        "@odata.id": "/redfish/v1/Managers/1/EthernetInterfaces"
    "FirmwareVersion": "0.00.14",
    "GraphicalConsole": {
            "KVMIP"
    "Id": "1",
    "KvmService": {
        "@odata.id": "/redfish/v1/Managers/1/KvmService"
    "Links": {
        "ManagerForChassis": [
                "@odata.id": "/redfish/v1/Chassis/1"
        "ManagerForServers": [
                "@odata.id": "/redfish/v1/Systems/1"
    "LldpService": {
        "@odata.id": "/redfish/v1/Managers/1/LldpService"
    "LogServices": {
        "@odata.id": "/redfish/v1/Managers/1/LogServices"
    "ManagerType": "BMC",
    "Model": "AST2600",
    "Name": "Manager",
    "NetworkProtocol": {
        "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol"
    "NtpService": {
        "@odata.id": "/redfish/v1/Managers/1/NtpService"
    "Oem": {
        "Public": {
            "BackupFirmwareBuildDate": "",
            "BackupFirmwareVersion": "",
"BiosCurrentRunningPartition": "AlternatePartition",
            "CurrentNodeId": "2",
            "CurrentRunningPartition": "PrimaryPartition",
            "CustomizedConfigurationModel": "",
            "DefaultLanguage": "CN",
"EnclosureName":"Chassis-01",
            "EnclosureNodeName": "SLOT6",
            "FirewallRules": {
                "@odata.id": "/redfish/v1/Managers/1/Oem/Public/FirewallRules"
"EnergySavingService": {
                "@odata.id": "/redfish/v1/Managers/1/Oem/Public/EnergySavingService"
            "FirmwareBuildDate": "2022-07-01T10:02:35+08:00",
            "FirmwareVendor": "BMC",
"IntelligentMonitoringService": {
"@odata.id": "/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService"
            "InternalFirmwareVersion": "V100R001B01BBIT14_RELEASE",
            "InternalBackupFirmwareVersion": "",
"IsSupportSimulator": false,
            "JointManagement": {
                "@odata.id": "/redfish/v1/Managers/1/Oem/Public/JointManagement"
            "LanguageSet": "EN, CN",
            "LoginSecurityInformation": {
                "@odata.id": "/redfish/v1/Managers/1/Oem/Public/LoginSecurityInformation"
            "MaintenanceFunctionEnabled": false,
            "MasterNodeId": "2",
            "OperationLog": {
                "@odata.id": "/redfish/v1/Managers/1/Oem/Public/OperationLog"
            "PFRSettings": {
                "@odata.id": "/redfish/v1/Managers/1/Oem/Public/PFRSettings"
            "RestoreFactorySupported":true,
            "SOLMode": {
                "@odata.id": "/redfish/v1/Managers/1/Oem/Public/SOLMode"
            "TrustedModuleConfiguration": {
                "@odata.id": "/redfish/v1/Managers/1/Oem/Public/TrustedModuleConfiguration"
            "USBDeviceService": {
                "@odata.id": "/redfish/v1/Managers/1/Oem/Public/USBDeviceService"
            "Wireless": {
                "@odata.id": "/redfish/v1/Managers/1/Oem/Public/Wireless"
    "SecurityService": {
        "@odata.id": "/redfish/v1/Managers/1/SecurityService"
    "SerialConsole": {
            "SSH"
    "SerialInterfaces": {
        "@odata.id": "/redfish/v1/Managers/1/SerialInterfaces"
    "ServiceEntryPointUUID": "7f673460-22e7-1000-03fe-aabbccd23552",
    "SmtpService": {
        "@odata.id": "/redfish/v1/Managers/1/SmtpService"
    "SnmpService": {
        "@odata.id": "/redfish/v1/Managers/1/SnmpService"
    "Status": {
        "Health": "Enabled",
        "State": "OK"
    "SyslogService": {
        "@odata.id": "/redfish/v1/Managers/1/SyslogService"
    "UUID": "7f673460-22e7-1000-03fe-aabbccd23552",
    "VirtualMedia": {
        "@odata.id": "/redfish/v1/Managers/1/VirtualMedia"
    "VncService": {
        "@odata.id": "/redfish/v1/Managers/1/VncService"
Response code: 200
Data type
@odata.context
String
OData description of the manager resource model.
@odata.id
String
Link to the manager resource.
@odata.type
String
Type of the manager resource.
Actions
Available actions for the manager resource.
Manager.Reset
Object
HDM restart.
Object
Clear operation logs.
Actions.Oem.Public
Actions specify custom executable operations for management resources.
Manager. Dump
Object
One-click collection of SDS.
Object
Export BIOS, BMC, and RAID controller configuration.
Object
Download BMC file.
Object
Upload BMC file.
Object
Import BIOS, BMC, and RAID controller configuration.
Manager.NodeSwitch
Object
Node control.
Only the E3300 G6 supports this field.
Manager.ResetSD
Object
Reset SD card.
Object
Restoring BMC factory-default settings.
CommandShell
CLI console properties.
Array
Supported link types.
Supported options:
·     SSH.
Integer
Maximum number of links.
ServiceEnabled
Boolean
Service enabling status.
DateTime
String
System date and time of the manager resource.
DateTimeLocalOffset
String
Time zone of the manager resource.
String
Description of the manager resource.
DiagnosticService
Object
Link to system diagnosis information.
EthernetInterfaces
Object
Link to network port information.
FirmwareVersion
String
HDM firmware version.
GraphicalConsole
Graphical console properties.
Array
Supported options:
·     KVMIP.
Integer
ServiceEnabled
Boolean
Id
String
KvmService
String
Link to the KVM service.
Links
Object
Links to manager resources.
LogServices
Object
Link to the log service collection resource.
LldpService
Object
Link to LLDP service resource information.
ManagerType
String
Supported options:
·     BMC.
Model
String
Model of the manager resource.
Supported options:
·     AST2600.
Name
String
Name of the manager resource.
NetworkProtocol
Object
Link to the service.
NtpService
Object
Link to NTP information.
Oem.Public.BackupFirmwareBuildDate
String
Build time of the backup area firmware version.
Oem.Public.BackupFirmwareVersion
String
Backup area firmware version.
Oem.Public.BiosCurrentRunningPartition
String
·     AlternatePartitionThe backup BIOS partition takes effect.
·     PrimaryPartitionThe primary BIOS partition takes effect.
Oem.Public.CurrentRunningPartition
String
Oem.Public.CustomizedConfigurationModel
String
Custom configuration model.
Oem.Public.CurrentNodeId
String
Current node ID.
Oem.Public.RestoreFactorySupported
Boolean
Support or not support factory configuration restoration.
Oem.Public.DefaultLanguage
String
Default languages.
Oem.Public.EnclosureName
String
Enclosure name.
This field is supported on for enclosures.
Oem.Public.EnclosureNodeName
String
Enclosure BMC node name.
Oem.Public.FirewallRules
Object
Link to the firewall resource.
Oem.Public.EnergySavingService
Object
Link to energy-saving service information resource.
Oem.Public.FirmwareVendor
String
Firmware vendor of the manager resource.
Oem.Public.FirmwareBuildDate
String
Firmware compilation time.
Oem.Public.InternalFirmwareVersion
String
Internal firmware version. (Main partition)
Oem.Public.InternalBackupFirmwareVersion
String
Internal firmware version. (Backup partition)
Oem.Public.IsSupportSimulator
Boolean
Simulator tag.
Oem.Public.LanguageSet
String
Supported languages.
Oem.Public.JointManagement
Object
Link to the unified management resource.
Oem.Public.LoginSecurityInformation
Object
Link to secure login information resource.
Oem.Public.MaintenanceFunctionEnabled
Boolean
Enabling status of the maintenance switch.
Oem.Public.MasterNodeId
String
Current node ID.
Oem.Public.IntelligentMonitoringService
String
Path to the intelligent monitoring service resource.
Oem.Public.OperationLog
Object
Links to all operation logs list resources.
Oem.Public.PFRSettings
Object
Link to platform firmware protection recovery (PFR) configuration.
Oem.Public.SOLMode
Object
Link to serial port redirection configuration resource.
Oem.Public.TrustedModuleConfiguration
Object
Link to trusted password module status configuration resource.
Oem.Public.USBDeviceService
Object
Link to service USB drive resource.
Oem.Public.Wireless
Object
Link to the wireless resource.
This field is available only for some G5 servers.
This field is not available for HDM3.
SerialConsole
Serial console properties.
Array
Supported options:
·     SSH.
Integer
ServiceEnabled
Boolean
SecurityService
Object
Link to secure service resource.
SerialInterfaces
Object
Link to serial port information.
String
UUID of the service resource managed by this manager.
SmtpService
Object
Link to SMTP information.
SnmpService
Object
Link to SNMP information.
Status
Object
Resource state fields:
·     Health—Whether the resource is healthy.
·     State—Whether the resource has been enabled.
SyslogService
Object
Link to syslog information.
UUID
String
UUID of the manager resource.
VirtualMedia
Object
Link to virtual media information.
VncService
Object
Link to the VNC service.
Change history
Version
Change description
HDM3-1.06
Added the Oem.Public.BiosCurrentRunningPartition field.
HDM3-1.16
Deleted the Telnet field.
HDM2-2.12
HDM3-1.16
HDM3 does not support Oem.Public.Wireless.
HDM2-2.09
Added the Manager.NodeSwitch, Oem.Public.CurrentNodeId, and Oem.Public.MasterNodeId fields.
HDM2-2.05
Added the DiagnosticService field.
HDM2-2.05
Added the Oem.Public.IsSupportSimulator field.
HDM2-2.04
Updated the description for the Model field.
HDM2-1.59
Added the EnclosureName and EnclosureNodeName fields.
HDM2-1.54
Added the IntelligentMonitoringService field.
Edit manager resource information
Edit information about a specific manager resource (time zone) for the server.
Privilege module
ConfigureComponents
Locking type of the associated system
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
If-Match:ifmatch_value
Request body:
    "DateTimeLocalOffset": local_offset
"UUID": uuid_value
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
Entity tag (ETag) that uniquely represents the requested resource.
To obtain the entity tag value of a resource, send a GET request to it and then obtain the ETag value from the response header.
DateTimeLocalOffset
Time zone information in a string.
N/A.
UUID
Manager resource UUID.
String.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1
Request header:
X-Auth-Token:TOKEN
If-Match:W/"6e8c96325a9b7c6a6e5e9f23616fbce0"
Request body:
"DateTimeLocalOffset": "UTC-04:30"
"UUID":"7f673460-22e7-1000-03fe-aabbccd23552"
Response:
    "@odata.context":"/redfish/v1/$metadata#Manager.Manager(*)",
    "@odata.id":"/redfish/v1/Managers/1",
    "@odata.type":"#Manager.v1_10_0.Manager",
    "Actions":{
        "#LogService.ClearOperationLog":{
            "@Redfish.AllowableValues":[
            "target":"/redfish/v1/Managers/1/LogServices/Actions/LogService.ClearOperationLog"
        "#Manager.Reset":{
            "ResetType@Redfish.AllowableValues":[
                "ForceRestart"
            "target":"/redfish/v1/Managers/1/Actions/Manager.Reset"
        "Oem":{
            "Public":{
                "#Manager.Dump":{
                    "target":"/redfish/v1/Managers/1/Actions/Oem/Public/Manager.Dump"
                "#Manager.ExportConfiguration":{
                    "target":"/redfish/v1/Managers/1/Actions/Oem/Public/Manager.ExportConfiguration"
                "#Manager.GeneralDownload":{
                    "target":"/redfish/v1/Managers/1/Actions/Oem/Public/Manager.GeneralDownload"
                "#Manager.GeneralUpload":{
                    "target":"/redfish/v1/Managers/1/Actions/Oem/Public/Manager.GeneralUpload"
                "#Manager.ImportConfiguration":{
                    "target":"/redfish/v1/Managers/1/Actions/Oem/Public/Manager.ImportConfiguration"
                "#Manager.ResetSD":{
                    "target":"/redfish/v1/Managers/1/Actions/Oem/Public/Manager.ResetSD"
                "#Manager.RestoreFactory":{
                    "ConfigurationType@Redfish.AllowableValues":[
                        "BMC"
                    "target":"/redfish/v1/Managers/1/Actions/Oem/Public/Manager.RestoreFactory"
    "CommandShell":{
        "ConnectTypesSupported":[
            "SSH"
        "MaxConcurrentSessions":20,
        "ServiceEnabled":true
    "DateTime":"2017-04-16T19:59:23-04:30",
    "DateTimeLocalOffset":"UTC-04:30",
"Description":"BMC",
    "EthernetInterfaces":{
        "@odata.id":"/redfish/v1/Managers/1/EthernetInterfaces"
    "FirmwareVersion":"0.00.14",
    "GraphicalConsole":{
            "KVMIP"
    "Id":"1",
    "KvmService":{
        "@odata.id":"/redfish/v1/Managers/1/KvmService"
    "Links":{
        "ManagerForChassis":[
                "@odata.id":"/redfish/v1/Chassis/1"
        "ManagerForServers":[
                "@odata.id":"/redfish/v1/Systems/1"
    "LldpService":{
        "@odata.id":"/redfish/v1/Managers/1/LldpService"
    "LogServices":{
        "@odata.id":"/redfish/v1/Managers/1/LogServices"
    "ManagerType":"BMC",
    "Model":"AST2600",
    "Name":"Manager",
    "NetworkProtocol":{
        "@odata.id":"/redfish/v1/Managers/1/NetworkProtocol"
    "NtpService":{
        "@odata.id":"/redfish/v1/Managers/1/NtpService"
    "Oem":{
        "Public":{
            "BackupFirmwareBuildDate":"",
            "BackupFirmwareVersion":"",
            "CompletionCode":0,
            "CurrentRunningPartition":"PrimaryPartition",
            "CustomizedConfigurationModel":"",
            "DefaultLanguage":"CN",
            "Description":"Success",
            "EnclosureName":null,
            "EnclosureNodeName":null,
            "FirewallRules":{
                "@odata.id":"/redfish/v1/Managers/1/Oem/Public/FirewallRules"
            "EnergySavingService":{
                "@odata.id":"/redfish/v1/Managers/1/Oem/Public/EnergySavingService"
            "FirmwareBuildDate":"2022-06-30T21:32:35-04:30",
            "FirmwareVendor":"BMC",
            "InternalFirmwareVersion":"V100R001B01BBIT14_RELEASE",
            "JointManagement":{
                "@odata.id":"/redfish/v1/Managers/1/Oem/Public/JointManagement"
            "LanguageSet":"EN, CN",
            "LoginSecurityInformation":{
                "@odata.id":"/redfish/v1/Managers/1/Oem/Public/LoginSecurityInformation"
            "MaintenanceFunctionEnabled":false,
            "OperationLog":{
                "@odata.id":"/redfish/v1/Managers/1/Oem/Public/OperationLog"
            "PFRSettings":{
                "@odata.id":"/redfish/v1/Managers/1/Oem/Public/PFRSettings"
            "SOLMode":{
                "@odata.id":"/redfish/v1/Managers/1/Oem/Public/SOLMode"
            "TrustedModuleConfiguration":{
                "@odata.id":"/redfish/v1/Managers/1/Oem/Public/TrustedModuleConfiguration"
            "USBDeviceService":{
                "@odata.id":"/redfish/v1/Managers/1/Oem/Public/USBDeviceService"
            "Wireless":{
                "@odata.id":"/redfish/v1/Managers/1/Oem/Public/Wireless"
    "SecurityService":{
        "@odata.id":"/redfish/v1/Managers/1/SecurityService"
    "SerialConsole":{
            "SSH"
    "SerialInterfaces":{
        "@odata.id":"/redfish/v1/Managers/1/SerialInterfaces"
    "ServiceEntryPointUUID":"7f673460-22e7-1000-03fe-aabbccd23552",
    "SmtpService":{
        "@odata.id":"/redfish/v1/Managers/1/SmtpService"
    "SnmpService":{
        "@odata.id":"/redfish/v1/Managers/1/SnmpService"
    "Status":{
        "Health":"Enabled",
        "State":"OK"
    "SyslogService":{
        "@odata.id":"/redfish/v1/Managers/1/SyslogService"
    "UUID":"7f673460-22e7-1000-03fe-aabbccd23552",
    "VirtualMedia":{
        "@odata.id":"/redfish/v1/Managers/1/VirtualMedia"
    "VncService":{
        "@odata.id":"/redfish/v1/Managers/1/VncService"
Response code: 200
For more information about the response field description, see "Obtain manager resource information."
Change history
Version
Change description
HDM3-1.16
Deleted the Telnet service field.
HDM2-2.12
HDM2-2.05
Added the UUID field.
HDM2-1.53
Added the locking type of the associated system.
Obtain NTP information
Obtain NTP information from the server.
Privilege module
Login
BMC configuration locking
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/NtpService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/NtpService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#NtpService.NtpService",
    "@odata.id": "/redfish/v1/Managers/1/NtpService",
    "@odata.type": "#NtpService.v1_0_0.NtpService",
    "AlternateNtpServer": "2.cn.pool.ntp.org",
"Description": "NtpService Gettings",
"MaxPollingInterval": 2592000,
"MinPollingInterval": 600,
    "NtpAddressOrigin": "Static",
    "Oem": {
        "Public": {
            "DateTime": "2019-02-18T17:51:02+08:00",
            "RefreshInterval": 3600,
"SynchronousResult": "Failed",
            "TertiaryNtpServer": "",
            "TimeZone": "UTC+08:00"
    "PreferredNtpServer": "1.cn.pool.ntp.org",
Response code: 200
Data type
@odata.context
String
OData description of the NTP service resource model.
@odata.id
String
Link to the NTP service resource.
@odata.type
String
Type of the NTP service resource.
AlternateNtpServer
String
Secondary NTP server address.
PreferredNtpServer
String
Primary NTP server address.
String
Description of the NTP service resource.
MaxPollingInterval
Integer
Maximum polling interval, in seconds.
MinPollingInterval
Integer
Minimum polling interval, in seconds.
NtpAddressOrigin
String
NTP server address obtaining method. Supported options:
·     Static.
ServiceEnabled
Boolean
Enabling status of the NTP service.
Oem.Public.TimeZone
String
Time zone.
For example: UTC+08:00
Oem.Public.SynchronousResult
String
Time synchronization result. Supported options:
·     Failed.
·     Successful.
·     Not Synchronized.
Oem.Public.TertiaryNtpServer
String
Tertiary NTP server address.
Oem.Public.RefreshInterval
Integer
Refresh interval of the NTP server, in seconds.
Value range: 600 to 2592000.
Oem.Public.DateTime
String
Timestamp Format.
For Example:
2019-02-14T20:21:36+08:00
Change history
Version
Change description
HDM2-2.04
Added the MaxPollingInterval and MinPollingInterval fields.
Configure NTP settings
Configure NTP settings from the server.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/NtpService
Request header:
X-Auth-Token:TOKEN
Request body:
    "AlternateNtpServer": AlternateNtpServer,
"PreferredNtpServer": PreferredNtpServer,
    "ServiceEnabled": true,
      "Oem":{
     "Public":{
               "TimeZone":"UTC+03:00"",
"TertiaryNtpServer": TertiaryNtpServer,
"RefreshInterval":652
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
PreferredNtpServer
String.
AlternateNtpServer
String.
ServiceEnabled
Boolean.
Oem.Public.TimeZone
Time zone.
Format: UTC+03:00
Compatibility with the original style, UTC+3, is required.
String.
String.
Integer.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/NtpService
Request header:
X-Auth-Token:TOKEN
Request body:
      "Oem":{
     "Public":{
               "TimeZone":"UTC+08:00",
"TertiaryNtpServer": "192.168.1.3",
"RefreshInterval":3600
Response:
    "Oem": {
        "Public": {
Response code: 200
For more information about the response field description, see "Obtain NTP information."
Obtain SNMP information
Obtain SNMP information from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/SnmpService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Response:
GET https://192.168.18.18/redfish/v1/Managers/1/SnmpService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#SnmpService.SnmpService",
    "@odata.id": "/redfish/v1/Managers/1/SnmpService",
    "@odata.type": "#SnmpService.v1_0_0.SnmpService",
    "Actions": {
        "#SnmpService.SubmitTestEvent": {
            "target": "/redfish/v1/Managers/1/SnmpService/Actions/SnmpService.SubmitTestEvent"
    "Description": "SnmpService Gettings",
    "Id": "SnmpService",
    "LongPasswordEnabled": false,
    "Name": "SNMP",
    "Oem": {
        "Public": {
    "ReadOnlyCommunity": "",
    "ReadWriteCommunity": null,
    "SnmpTrapNotification": {
        "AlarmSeverity": "Minor+Major+Critical",
        "CommunityName": "public",
        "Oem": {
            "Public": {
                "SystemContact": "",
                "SystemLocation": ""
        "TrapMode": "NodeMode",
        "TrapServer": [
                "Enabled": true,
                "MemberId": "1",
                "TrapServerAddress": "",
                "TrapServerPort": 162
                "Enabled": true,
                "MemberId": "2",
                "Enabled": true,
                "MemberId": "3",
                "Enabled": true,
                "MemberId": "4",
                "Enabled": true,
                "MemberId": "5",
                "Enabled": true,
                "MemberId": "6",
                "Enabled": true,
                "MemberId": "7",
                "Enabled": true,
                "MemberId": "8",
        "TrapServerIdentity": "HDM",
        "TrapV3User": "",
        "TrapVersion": "v1"
    "SnmpV1Enabled": false,
    "SnmpV2CEnabled": true,
    "SnmpV3AuthProtocol": "",
"SnmpV3Enabled": true,
"SnmpV3EngineID": "80001f8880a933392964005259",
    "SnmpV3PrivProtocol": ""
Response code: 200
Data type
@odata.context
String
OData description of the SNMP service resource model.
@odata.id
String
Link to the SNMP service resource.
@odata.type
String
Type of the SNMP service resource.
Actions
Available operations for the SNMP resource.
Object
Link to the SNMP trap testing.
String
Description of the SNMP resource.
Id
String
SNMP resource ID.
LongPasswordEnabled
Boolean
Whether the long community string feature is enabled.
Name
String
SNMP resource name.
ReadOnlyCommunity
String
The read-only community name must be a string of up to 32 characters and can contain the letters, digits, and the following special characters: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
An empty string indicates that the read-only community name has been deleted.
ReadWriteCommunity
String
The read/write community name must be a string of up to 32 characters and can contain the letters, digits, and the following special characters: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
An empty string indicates that the read/write community name has been deleted.
SnmpTrapNotification.CommunityName
String
Trap community name.
SnmpTrapNotification.ServiceEnabled
Boolean
Enabling status of the SNMP trap service.
SnmpTrapNotification.TrapMode
String
Trap mode. Supported options:
·     NodeMode.
·     EventMode.
·     EventCodeMode.
SnmpTrapNotification.AlarmSeverity
String
Severity level. Supported options:
·     Critical.
·     Major+Critical.
·     Minor+Major+Critical.
·     All.
SnmpTrapNotification.TrapServer
Trap server properties.
TrapServer.Enabled
Boolean
Enabling status of the SNMP trap servers.
TrapServer.MemberId
String
Trap server ID. The trap server ID range is 1 to 8.
TrapServer.TrapServerAddress
String
Trap server address.
TrapServer.TrapServerPort
Integer
Trap server port.
SnmpTrapNotification.TrapServerIdentity
String
Trap server identifier.
SnmpTrapNotification.TrapV3User
String
SNMPv3 user.
SnmpTrapNotification.TrapVersion
String
SNMP trap version.
SnmpTrapNotification.Oem.Public.SystemLocation
String
SNMP Trap node location.
SnmpTrapNotification.Oem.Public.SystemContact
String
SNMP Trap contact information.
SnmpV1Enabled
Boolean
Enabling status of SNMPv1.
SnmpV2CEnabled
Boolean
Enabling status of SNMPv2c.
SnmpV3AuthProtocol
String
SNMPv3 authentication algorithm. Supported options:
·     sha.
·     md5.
·     sha256.
·     sha384.
·     sha512.
SnmpV3Enabled
Boolean
Enabling status of SNMPv3.
SnmpV3EngineID
String
ID of the SNMP engine.
SnmpV3PrivProtocol
String
SNMPv3 encryption algorithm. Supported options:
·     des.
·     aes.
·     aes192.
·     aes256.
Change history
Version
Change description
HDM2-1.53
Configure SNMP settings
Configure SNMP settings from the server. Before configuring SNMPv3 user settings, make sure SNMP extended privileges are enabled for the corresponding users.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/SnmpService
Request header:
X-Auth-Token:TOKEN
Request body:
    "SnmpV1Enabled":v1_enabled,
    "SnmpV2CEnabled":v2c_enabled,
    "SnmpV3Enabled":v3_enabled,
    "LongPasswordEnabled":long_password_enabled,
    "ReadOnlyCommunity":read_only_community,
    "ReadWriteCommunity":read_write_community,
    "CommunityName":community_name,
    "ServiceEnabled":service_enabled,
    "TrapVersion":trap_version,
    "TrapV3User":user_name,
    "AlarmSeverity": alarm_severity,
    "TrapMode": trap_mode,
    "Oem": {
        "Public": {
            "SystemLocation": location,
            "SystemContact": contact
    "TrapServer":[
            "MemberId":"1",
            "Enabled":true,
            "TrapServerPort":TrapServer1_portnumber,
            "TrapServerAddress": TrapServer1_address
Alternatively:
      "Oem": {
          "Public": {
      "TrapServer":[
              "MemberId":"1",
              "Enabled":true,
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
SnmpV1Enabled
Enable or disable SNMPv1.
Boolean.
SnmpV2CEnabled
Enable or disable SNMPv2.
Boolean.
SnmpV3Enabled
Enable or disable SNMPv3.
Boolean.
LongPasswordEnabled
Enable or disable the long community string feature.
Boolean.
ReadOnlyCommunity
Read-only community name.
String, up to 32 characters.
An empty string indicates that the read-only community has been deleted.
ReadWriteCommunity
Read/write community name.
An empty string indicates that the read/write community has been deleted.
SNMP trap notification properties.
String, up to 31 characters.
For SNMPv3 users, setting the community name is successful, but it won't take effect.
Enable or disable the SNMP trap service.
Boolean.
SNMP trap version.
String. Supported options:
·     v1.
·     v2c.
·     v3.
When SNMPv3 is used, the CommunityName field is not required.
SNMPv3 user.
String.
Severity level.
·     Critical.
·     Major+Critical.
·     All.
Trap mode.
·     NodeMode.
·     EventMode.
·     EventCodeMode.
When SNMPv3 is used, you must configure the TrapV3User option.
SnmpTrapNotification.TrapServer.MemberId
Trap server ID.
String. The trap server ID range is 1 to 8.
SnmpTrapNotification.TrapServer.Enabled
Enable or disable the SNMP trap server.
Boolean.
SnmpTrapNotification.TrapServer.TrapServerPort
Trap server port number.
Integer.
SnmpTrapNotification.TrapServer.TrapServerAddress
String. IPv4, IPv6 address, or domain name formats.
System node location.
String.
System contact information.
String.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/SnmpService
Request header:
X-Auth-Token:TOKEN
Request body:
    "ServiceEnabled":true,
  "TrapVersion":"v3",
    "TrapV3User":"User3",
    "AlarmSeverity": "All",
    "Oem": {
        "Public": {
            "SystemLocation": "HangZhou",
            "SystemContact": "www.h3c.com"
    "TrapServer":[
            "MemberId":"1",
            "Enabled":true,
            "TrapServerPort":162,
            "TrapServerAddress": "192.168.30.111"
            "MemberId":"2",
            "Enabled":true,
            "TrapServerAddress": "192.168.30.112"
            "MemberId":"3",
            "Enabled":true,
            "TrapServerAddress": "192.168.30.113"
            "MemberId":"4",
            "Enabled":true,
            "TrapServerAddress": "192.168.30.114"
            "MemberId":"5",
            "Enabled":true,
            "TrapServerAddress": "192.168.30.115"
            "MemberId":"6",
            "Enabled":true,
            "TrapServerAddress": "192.168.30.116"
            "MemberId":"7",
            "Enabled":true,
            "TrapServerAddress": "192.168.30.117"
            "MemberId":"8",
            "Enabled":true,
            "TrapServerAddress": "192.168.30.118"
Alternatively:
  "SnmpTrapNotification":{
      "TrapVersion":"v3",
      "Oem": {
          "Public": {
      "TrapServer":[
              "MemberId":"1",
              "Enabled":true,
              "MemberId":"2",
              "Enabled":true,
              "MemberId":"3",
              "Enabled":true,
              "MemberId":"4",
              "Enabled":true,
              "MemberId":"5",
              "Enabled":true,
              "MemberId":"6",
              "Enabled":true,
              "MemberId":"7",
              "Enabled":true,
              "MemberId":"8",
              "Enabled":true,
Response:
    "Actions": {
    "Name": "SNMP",
    "Oem": {
        "Public": {
    "ReadWriteCommunity": "",
        "Oem": {
            "Public": {
                "SystemContact": "www.h3c.com",
        "TrapServer": [
                "Enabled": true,
                "MemberId": "1",
                "TrapServerAddress": "192.168.30.111",
                "Enabled": true,
                "MemberId": "2",
                "TrapServerAddress": "192.168.30.112",
                "Enabled": true,
                "MemberId": "3",
                "TrapServerAddress": "192.168.30.113",
                "Enabled": true,
                "MemberId": "4",
                "TrapServerAddress": "192.168.30.114",
                "Enabled": true,
                "MemberId": "5",
                "TrapServerAddress": "192.168.30.115",
                "Enabled": true,
                "MemberId": "6",
                "TrapServerAddress": "192.168.30.116",
                "Enabled": true,
                "MemberId": "7",
                "TrapServerAddress": "192.168.30.117",
                "Enabled": true,
                "MemberId": "8",
                "TrapServerAddress": "192.168.30.118",
        "TrapServerIdentity": "HDM123456123456123456123456123456123456123456123456123456123456",
        "TrapV3User": "User3",
        "TrapVersion": "v3"
    "SnmpV3AuthProtocol": "SHA",
    "SnmpV3PrivProtocol": "DES"
Response code: 200
For more information about the response field description, see "Obtain SNMP information."
Change history
Version
Change description
HDM2-2.02
HDM3-1.24
HDM3-1.17
HDM3-1.80
Added the SnmpTrapNotification object, which is optional. The values for the same field that are not under this object take precedence over those under this object.
HDM2-1.53
Perform SNMP trap testing
Perform SNMP trap testing on the server.
Privilege module
ConfigureComponents
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/SnmpService/Actions/SnmpService.SubmitTestEvent
Request header:
X-Auth-Token:TOKEN
Request body:
"MemberId": id
Parameter
Value
device_ip
TOKEN
manager_id
MemberId
Trap member ID.
String. The trap member ID range is 1 to 8.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/SnmpService/Actions/SnmpService.SubmitTestEvent
Request header:
X-Auth-Token:TOKEN
Request body:
"MemberId":"1"
Response:
"Oem": {
       "Public": {
"error": {
       "@Message.ExtendedInfo": [
               "@odata.type": "#Message.v1_1_1.Message",
               "Message": "Successfully Completed Request",
               "MessageArgs": [],
               "MessageId": "Base.1.8.1.Success",
               "MessageSeverity": "OK",
               "Resolution": "None"
        "code":"Base.1.8.1.Success",
        "message":"Successfully Completed Request"
Response code: 200
Data type
code
String
String of a specific message ID in the message registry.
message
String
Readable error message corresponding to the message in the message registry.
Extended information of the message.
@odata.type
String
OData description of the message resource.
MessageId
String
Message ID.
Message
String
Details of the message.
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Recommended actions for the error.
Change history
Version
Change description
HDM2-2.04
Added the error node before Message.ExtendedInfo and added the code and message fields under the error node.
Obtain SMTP information
Obtain SMTP information from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/SmtpService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/SmtpService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
  "@odata.context": "/redfish/v1/$metadata#SmtpService.SmtpService(AnonymousLoginEnabled,ServerPort,Name,ServiceEnabled,Id,RecipientAddresses,TLSEnabled,SenderAddress,Description,AlarmSeverity,Actions,ServerAddress)",
  "@odata.id": "/redfish/v1/Managers/1/SmtpService",
  "@odata.type": "#SmtpService.v1_0_0.SmtpService",
  "Actions": {
    "#SmtpService.SubmitTestEvent": {
      "target": "/redfish/v1/Managers/1/SmtpService/Actions/SmtpService.SubmitTestEvent"
  "AlarmSeverity": "Critical",
  "AnonymousLoginEnabled": false,
  "Description": "Smtpservice Gettings",
  "Id": "Smtp",
  "Name": "Smtp",
  "Oem": {
    "Public": {
      "Subject": [
        "ProductName",
        "HostName",
        "AssetTag",
        "BoardSerialNumber"
  "RecipientAddresses": [
      "EmailAddress": "123@h3c.com",
      "EmailSubject": "111",
      "Enabled": true,
      "MemberId": "1"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "2"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "3"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "4"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "5"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "6"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "7"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "8"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "9"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "10"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "11"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "12"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "13"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "14"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "15"
  "SenderAddress": "",
  "SenderPassword": null,
  "SenderUserName": "",
  "ServerAddress": "",
  "ServerPort": 25,
  "TLSEnabled": true
Response code: 200
Data type
@odata.context
String
OData description of the SMTP information resource model.
@odata.id
String
Link to the SMTP information resource.
@odata.type
String
Type of the SMTP information resource.
Actions
Available operations for the SMTP resource.
Object
Link to SNMP notification testing.
AlarmSeverity
String
·     Critical.
·     Major+Critical.
·     All.
Boolean
Enabling status of anonymous login.
SenderAddress
String
Sender email address.
ServerAddress
String
Server address.
ServerPort
Integer
Server port.
ServiceEnabled
Boolean
Enabling status of the SMTP service.
TLSEnabled
Boolean
Enabling status of TLS.
SenderUserName
String
Username of senders
RecipientAddresses.EmailAddress
String
Recipient email address.
RecipientAddresses.Enabled
Boolean
Enabling status of a recipient.
RecipientAddresses.MemberId
String
ID of a recipient.
RecipientAddresses.EmailSubject
String
Email subject.
Oem.Public.Subject
Array
Customize email subject. Supported options:
·     ProductName.
·     HostName.
·     AssetTag.
·     BoardSerialNumber.
The server returns status code 200 for a successful operation.
Configure SMTP settings
Configure SMTP settings from the server.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/SmtpService
Request header:
X-Auth-Token:TOKEN
Request body:
    "ServerAddress":serveraddress,
    "ServerPort":portnumber,
    "TLSEnabled":true,
    "AnonymousLoginEnabled":false,
    "SenderUserName":username,
    "SenderPassword":password,
"SenderAddress":senderaddress,
"AlarmSeverity": AlarmSeverity_value,
"Oem": {
        "Public": {
             "Subject":[
                 "ProductName",
                  "AssetTag",
                  "BoardSerialNumber",
                  "HostName"
"RSAEncryptionEnabled":true
"RecipientAddresses":[
            "MemberId":"1",
            "Enabled":true,
            "EmailSubject":"1",
"EmailAddress":""
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
manager_id
ifmatch_value
ServiceEnabled
Enable or disable the SMTP service.
Boolean.
ServerAddress
Server address.
String.
ServerPort
Server port.
Integer.
When you enable TLS, the server port must be set to 465.
TLSEnabled
Enable or disable TLS.
Boolean.
Enable or disable anonymous login.
Boolean.
SenderUserName
Sender username.
The username must be a string of up to 64 characters. Only letters, digits, dots (.), hyphens (-), underscores (_), and at signs (@) are allowed.
SenderPassword
Sender password.
String, up to 64 characters.
SenderAddress
Sender address.
Oem.Public.Subject
Array
·     ProductName.
·     HostName.
·     AssetTag.
Oem.Public.RSAEncryptionEnabled
Boolean.
Supports RSA encryption, only for setting sender's password on the web interface.
AlarmSeverity
Severity level.
·     Critical.
·     Major+Critical.
·     All.
RecipientAddresses
Recipient address properties.
Member ID.
String. Value range: 1 to 15.
Enable or disable a recipient.
Boolean.
Alarm email subject.
The maximum length for this field is 32 characters. When setting the Enabled field to false, you cannot set this field.
String.
RecipientAddresses. EmailAdress
Email Address.
The maximum length for this field is 64 characters. When setting the Enabled field to false, you cannot set this field.
String.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/SmtpService
Request header:
X-Auth-Token:TOKEN
Request body:
  "Id": "Smtp",
  "Name": "Smtp",
  "Oem": {
    "Public": {
      "CompletionCode": 0,
      "Subject": [
        "ProductName",
        "AssetTag",
        "HostName"
      "Enabled": true,
      "MemberId": "1"
  "SenderPassword": "",
  "ServerPort": 25,
  "TLSEnabled": true
Response:
  "Actions": {
  "Id": "Smtp",
  "Name": "Smtp",
  "Oem": {
    "Public": {
      "Subject": [
        "ProductName",
        "HostName",
        "AssetTag",
        "BoardSerialNumber"
      "Enabled": true,
      "MemberId": "1"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "2"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "3"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "4"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "5"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "6"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "7"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "8"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "9"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "10"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "11"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "12"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "13"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "14"
      "EmailAddress": "",
      "EmailSubject": "",
      "Enabled": false,
      "MemberId": "15"
  "ServerPort": 25,
  "TLSEnabled": true
Response code: 200
Response field description
For information about the response fields, see "Obtain SMTP information."
Change history
Version
Change description
HDM3-2.02
HDM3-1.24
Added the description to indicate that the server port must be set to 465 when you enable TLS.
HDM2-1.53
Perform SMTP testing
Perform SMTP testing on the server.
Privilege module
ConfigureComponents
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/SmtpService/Actions/SmtpService.SubmitTestEvent
Request header:
X-Auth-Token:TOKEN
Request body:
"MemberId": "id"
Parameter
Value
device_ip
TOKEN
manager_id
MemberId
Recipient ID.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/SmtpService/Actions/SmtpService.SubmitTestEvent
Request header:
X-Auth-Token:TOKEN
Request body:
"MemberId": "1"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageIds
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Change history
Version
Change description
HDM2-2.04
Added the error node before Message.ExtendedInfo and added the code and message fields under the error node..
Obtain information for SMTP trap testing
Obtain SMTP trap test result information from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/SmtpService/Oem/Public/SubmitTestResult/email_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
email_id
ID of receive alarm email address.
N/A
Method and URL:
GET https://device_ip/redfish/v1/Managers/1/SmtpService/Oem/Public/SubmitTestResult/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#SmtpService.TestResult",
"@odata.id":"/redfish/v1/Managers/1/SmtpService/Oem/Public/SubmitTestResult/1",
"@odata.type": "#SmtpTestResult.v1_0_0.SmtpTestResult",
"Oem": {
    "Public": {
"SMTPTestResult":"success"
Response code: 200
Data type
@odata.context
String
OData description of SMTP information resource model.
@odata.id
String
Link to SMTP information resources.
@odata.type
String
Type of SMTP information resources.
SMTPTestResult
String
Whether the SMTP test is successful. Supported options:
·     Fail.
·     Success.
Obtain syslog information
Obtain syslog information from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/SyslogService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/SyslogService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#SyslogService.SyslogService(*)",
    "@odata.id": "/redfish/v1/Managers/1/SyslogService",
    "@odata.type": "#SyslogService.v1_0_0.SyslogService",
    "Actions": {
        "#SyslogService.ImportClientCertificate": {
            "@Redfish.ActionInfo": "/redfish/v1/Managers/1/SyslogService/ImportClientCertificateActionInfo",
            "target": "/redfish/v1/Managers/1/SyslogService/Actions/SyslogService.ImportClientCertificate"
        "#SyslogService.ImportPrivateKeyCertificate": {
            "@Redfish.ActionInfo": "/redfish/v1/Managers/1/SyslogService/ImportPrivateKeyCertificateActionInfo",
            "target": "/redfish/v1/Managers/1/SyslogService/Actions/SyslogService.ImportPrivateKeyCertificate"
        "#SyslogService.ImportRootCertificate": {
            "@Redfish.ActionInfo": "/redfish/v1/Managers/1/SyslogService/ImportRootCertificateActionInfo",
            "target": "/redfish/v1/Managers/1/SyslogService/Actions/SyslogService.ImportRootCertificate"
        "#SyslogService.SubmitTestEvent": {
            "@Redfish.ActionInfo": "/redfish/v1/Managers/1/SyslogService/Actions/SyslogService.SubmitTestEvent",
            "target": "/redfish/v1/Managers/1/SyslogService/Actions/SyslogService.SubmitTestEvent"
    "AuthenticateMode": "TwoWay",
    "CustomOptions": [
        "TimeStamp",
        "HostName",
        "Message"
    "Id": "SyslogService",
    "MessageFormat": "Custom",
    "Name": "Syslog Service",
    "Oem": {
        "Public": {
            "ClientCertificateInstalled": false,
            "PrivateKeyCertificateInstalled": false,
            "RootCertificateInstalled": false
    "ServerIdentitySource": "HostName",
    "SyslogServers": [
            "Address": "192.168.10.11",
            "Enabled": true,
            "LogLevel": "Critical",
            "LogType": [
                "OperationLog",
                "SDRLog"
            "MemberId": "1",
            "Name": "Channel1",
            "Port": 514
            "Address": "0.0.0.0",
            "Enabled": false,
            "LogLevel": "Informational",
            "LogType": [],
            "MemberId": "2",
            "Name": "channel2",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "3",
            "Name": "channel3",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "4",
            "Name": "channel4",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "5",
            "Name": "channel5",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "6",
            "Name": "channel6",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "7",
            "Name": "channel7",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "8",
            "Name": "channel8",
            "Port": 514
    "TimeInterval": 60,
    "TransmissionProtocol": "UDP"
Response code: 200
Data type
@odata.context
String
OData description of the syslog information resource model.
@odata.id
String
Link to the syslog information resource.
@odata.type
String
Type of the syslog information resource.
Id
String
ID of the syslog information resource.
Name
String
Name of the syslog information resource.
ServiceEnabled
Boolean
Enabling status of the syslog service.
String
Protocol used for syslog message transmission. Supported options:
·     UDP.
·     TCP.
·     TLS.
AuthenticateMode
String
Authentication mode. Supported options:
·     OneWay.
·     TwoWay.
String
Syslog server identifier. Supported options:
·     HostName.
·     BoardSNSN of the system board.
·     ProductAssetTag.
·     ProductSN.
TimeInterval
Integer
Time interval: 10 to 2,592,000.
MessageFormat
String
Message format. Supported options:
·     Custom—Custom.
·     RFC3164—RFC3164.
·     RFC5424—RFC5424.
CustomOptions
Array
Custom format. Supported options
·     Message.
·     TimeStamp.
·     HostName.
Custom format options are only valid in Custom format.
SyslogServers.Address
String
Syslog server address.
SyslogServers.Enabled
String
Enabling status of the syslog server.
SyslogServers.MemberId
String
Member ID of the syslog server. The member ID range is 1 to 8.
SyslogServers.Port
Integer
Syslog server port.
SyslogServers.LogType
Array
Log type. Supported options:
·     OperationLog.
·     EventLog.
·     SecurityLog.
·     SerialLog.
·     SDRLog.
SyslogServers.LogLevel
String
Log level. Supported options:
·     Informational.
·     Minor.
·     Major.
·     Critical.
SyslogServers.Name
String
Channel name.
Actions
Actions on the syslog information resource.
Object
Import the syslog root certificate.
target
String
Operation link.
Redfish.ActionInfo
String
Link to obtain action information.
Object
Import the syslog local certificate.
Oem.Public.RootCertificateInstalled
Boolean
Import flag of the Syslog root certificate.
Oem.Public.ClientCertificateInstalled
Boolean
Import flag of the Syslog local certificate.
Oem.Public.PrivateKeyCertificateInstalled
Boolean
Import flag of the Syslog private key.
Configure syslog settings
Configure syslog settings form the server.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/SyslogService
Request header:
X-Auth-Token:TOKEN
Request body:
    "ServerIdentitySource":"HostName",
    "TransmissionProtocol":"UDP",
    "TimeInterval":60,
    "AuthenticateMode":"TwoWay",
    "MessageFormat":"Custom",
    "CustomOptions":[
        "HostName",
        "Message",
        "TimeStamp"
    "SyslogServers": [
            "Enabled": true,
            "LogLevel":"Critical",
            "LogType": [
                "OperationLog",
                "SDRLog"
            "MemberId": "1",
            "Name":"Channel1",
            "Port": 514
Parameter
Value
device_ip
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
manager_id
Only value 1 is supported.
ifmatch_value
ServiceEnabled
Enable or disable the syslog service.
Boolean.
·     UDP.
·     TCP.
·     TLS.
AuthenticateMode
·     OneWay.
·     TwoWay.
·     HostName.
·     BoardSN.
·     ProductAssetTag.
·     ProductSN.
TimeInterval
Time interval.
Integer. The time interval value range is 10 to 2,592,000.
MessageFormat
Message format.
·     Custom—Custom.
·     RFC3164—RFC3164.
·     RFC5424—RFC5424.
CustomOptions
Custom format.
Array. Supported options
·     Message.
·     TimeStamp.
·     HostName.
Custom format options are only valid in Custom format, and Message format option is a required configuration item.
String.
Enable or disable the syslog server.
Boolean.
String. The member ID range is 1 to 8.
SyslogServers.Port
Syslog server port.
Integer.
SyslogServers.Name
Servers name.
Log type.
Array. Supported options:
·     OperationLog.
·     EventLog.
·     SecurityLog.
·     SerialLog.
·     SDRLog.
Log level.
·     Informational.
·     Minor.
·     Major.
·     Critical.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/SyslogService
Request header:
X-Auth-Token:TOKEN
Request body:
    "TimeInterval":60,
    "CustomOptions":[
        "HostName",
        "Message",
        "TimeStamp"
    "SyslogServers": [
            "Enabled": true,
            "LogType": [
                "OperationLog",
                "SDRLog"
            "MemberId": "1",
            "Name":"Channel1",
            "Port": 514
Response:
    "Actions": {
    "CustomOptions": [
        "TimeStamp",
        "HostName",
        "Message"
    "Oem": {
        "Public": {
    "SyslogServers": [
            "Enabled": true,
            "LogType": [
                "OperationLog",
                "SDRLog"
            "MemberId": "1",
            "Name": "Channel1",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "2",
            "Name": "channel2",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "3",
            "Name": "channel3",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "4",
            "Name": "channel4",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "5",
            "Name": "channel5",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "6",
            "Name": "channel6",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "7",
            "Name": "channel7",
            "Port": 514
            "Enabled": false,
            "LogType": [],
            "MemberId": "8",
            "Name": "channel8",
            "Port": 514
    "TimeInterval": 60,
Response code: 200
For more information about the response field description, see "Obtain syslog information."
Change history
Version
Change description
HDM2-1.53
Perform SYSLOG trap testing
Perform SYSLOG trap testing on the server.
Privilege module
ConfigureComponents
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/SyslogService/Actions/SyslogService.SubmitTestEvent
Request header:
X-Auth-Token:TOKEN
Request body:
"MemberId": id
Parameter
Value
device_ip
TOKEN
manager_id
MemberId
Alarm log server ID.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/SyslogService/Actions/SyslogService.SubmitTestEvent
Request header:
X-Auth-Token:TOKEN
Request body:
"MemberId":"1"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Privilege module
OemSecurityMgmt
Request
POST https://device_ip/redfish/v1/Managers/manager_id/SyslogService/Actions/SyslogService.ImportRootCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
Local import
"Type":"URI",
"Content": "/tmp/web/filename"
Remote import
"Type":"URI",
"Content": "sftp://username:password@10.10.10.191/filename"
Text content import
"Type":"text",
"Content":value
Parameter
Value
device_ip
TOKEN
manager_id
type
Content type.
Type of the content in the value field. Supported options:
·     textCertificate content.
·     URILocal or remote certificate URI.
value
Content.
Content or URI of the certificate. Only SFTP is supported for file transmission.
Make sure the specified content matches the content type.
Content
Link to import Syslog root certificate.
See "Others."
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/SyslogService/Actions/SyslogService.ImportRootCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
"Type": "URI",
"Content":"sftp://y17057:y17057@192.168.170.57/cacert.pem"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
Message extended information.
@odata.type
String
MessageId
String
Message ID.
Message
String
Message details.
MessageArgs
Array
Message arguments.
MessageSeverity
String
Message severity level. Supported options:
·     OK.
·     Warning.
·     Critical.
Resolution
String
Recommended solutions.
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Import a local certificate
Import a syslog local certificate.
Privilege module
OemSecurityMgmt
Request
POST https://device_ip/redfish/v1/Managers/manager_id/SyslogService/Actions/SyslogService.ImportClientCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
"Type":type,
"Content":value
Local import
"Type":"URI",
Remote import
"Type":"URI",
Text content import
"Type":"text",
"Content":value
Parameter
Value
device_ip
TOKEN
manager_id
type
Content type.
value
Content.
Content
Link to import a local certificate.
See "Others."
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/SyslogService/Actions/SyslogService.ImportClientCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
"Type": "URI",
"Content":"sftp://y17057:y17057@192.168.170.57/cert.pem"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
Message details.
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Import a private key certificate
Import a private key certificate.
Privilege module
OemSecurityMgmt
Request
POST https://device_ip/redfish/v1/Managers/manager_id/SyslogService/Actions/SyslogService.ImportPrivateKeyCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
·     Local import:
Use this interface after transferring the file to the /tmp/web/ directory. For more information, see "Upload BMC file."
"Type":"URI",
·     Remote import:
¡     CIFS or SFTP:
"Type":"URI",
"Content":"cifs://username:password@ip/filename"
¡     HTTP, TFTP, NFS, or HTTPS:
"Type":"URI",
"Content":"http://ip/filename"
The Request body is the same as the "Import a root certificate file."
Parameter
Value
device_ip
TOKEN
manager_id
type
Content type.
value
Content.
Content
See "Others."
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/SyslogService/Actions/SyslogService.ImportPrivateKeyCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
"Type": "URI",
"Content":"sftp://y17057:y17057@192.168.170.57/key.pem"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
Message details.
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain service information
Obtain information (including port number and enabling status) about HTTPS, IPMI, KVM, SNMP, SSDP, SSH, virtual media, ASDiHDT, and VNC services.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/NetworkProtocol
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/NetworkProtocol
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#ManagerNetworkProtocol.ManagerNetworkProtocol",
    "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol",
    "@odata.type": "#ManagerNetworkProtocol.v1_7_0.ManagerNetworkProtocol",
    "ASD": {
        "Oem": {
            "Public": {
                "MaxSessionCountSupported": 1,
                "NonSecurePort": 6868,
                "NonSecurePortEnabled": true,
                "SecurePort": null,
                "SecurePortEnabled": null,
                "SessionCount": 0,
                "SessionType": "ASD(Remote_XDP)",
                "TimeOut": null
        "Port": 6868,
        "ProtocolEnabled": false
"Actions": {
        "Oem": {
            "Public": {
                "#Manager.RestartService": {
                    "target": "/redfish/v1/Managers/1/NetworkProtocol/Actions/Oem/Public/Manager.RestartService"
    "CD-Media": {
        "Oem": {
            "Public": {
                "MaxSessionCountSupported": 2,
                "NonSecurePort": 5120,
                "NonSecurePortEnabled": false,
                "SecurePort": 5124,
                "SecurePortEnabled": true,
                "SessionCount": 0,
                "SessionType": "CD-Media",
                "TimeOut": null
        "Port": 5124,
        "ProtocolEnabled": true
    "Description": "Network Protocol Details",
    "FD-Media": {
        "Oem": {
            "Public": {
                "NonSecurePort": 5122,
                "SecurePort": 5126,
                "SessionCount": 0,
                "SessionType": "FD-Media",
                "TimeOut": null
        "Port": 5126,
    "FQDN": null,
    "HD-Media": {
        "Oem": {
            "Public": {
                "NonSecurePort": 5123,
                "SecurePort": 5127,
                "SessionCount": 0,
                "SessionType": "HD-Media",
                "TimeOut": null
        "Port": 5127,
    "HTTP": {
        "Oem": {
            "Public": {
                "MaxSessionCountSupported": 20,
                "NonSecurePort": 80,
                "SecurePort": null,
                "SessionCount": 0,
                "SessionType": "HTTP",
                "TimeOut": 30
        "Port": 80,
    "HTTPS": {
        "Oem": {
            "Public": {
                "NonSecurePort": null,
                "NonSecurePortEnabled": null,
                "SecurePort": 443,
                "SessionCount": 0,
                "SessionType": "HTTPS",
                "TimeOut": 30
        "Port": 443,
    "HostName": "HDM",
    "IPMI": {
        "Oem": {
            "Public": {
                "MaxSessionCountSupported": null,
                "NonSecurePort": 624,
                "SecurePort": 623,
                "SecurePortEnabled": false,
                "SessionCount": null,
                "SessionType": "IPMI",
                "TimeOut": null
        "Port": 624,
    "Id": "NetworkProtocol",
    "KVMIP": {
        "Oem": {
            "Public": {
                "MaxSessionCountSupported": 4,
                "NonSecurePort": 7578,
                "SecurePort": 7582,
                "SessionCount": 0,
                "SessionType": "KVM",
                "TimeOut": 30
        "Port": 7582,
    "Name": "Manager Network Protocol",
    "Oem": {
        "Public": {
"Sessions": {
                "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions"
    "SNMP": {
        "Oem": {
            "Public": {
                "NonSecurePort": 161,
                "SecurePort": null,
                "SessionType": "SNMP",
                "TimeOut": null
        "Port": 161,
    "SSDP": {
        "Oem": {
            "Public": {
                "NonSecurePort": 1900,
                "SecurePort": null,
                "SessionType": "SSDP",
                "TimeOut": null
        "Port": 1900,
    "SSH": {
        "Oem": {
            "Public": {
                "MaxSessionCountSupported": 3,
                "SecurePort": 22,
                "SessionCount": 0,
                "SessionType": "SSH",
                "TimeOut": 10
        "Port": 22,
    "Status": {
        "Health": "OK",
        "State": "Enabled"
    "VNC": {
        "Oem": {
            "Public": {
                "NonSecurePort": 5900,
                "SecurePort": null,
                "SessionCount": 0,
                "SessionType": "VNC",
                "TimeOut": 10
        "Port": 5900,
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
Actions.Oem.Public
Operations defined by custom actions.
Object
Restart service.
String
Description of the syslog information resource.
HTTPS.Port
Integer
HTTPS service current port number.
HTTPS.ProtocolEnabled
Boolean
Enabling status of the HTTPS service.
HTTPS.Oem.Public.SecurePort
Integer
HTTPS service secure port number.
HTTPS.Oem.Public.NonSecurePort
Integer
HTTPS service insecure port number.
HTTPS.Oem.Public.SecurePortEnabled
Boolean
Enabling status of the HTTPS service secure port.
HTTPS.Oem.Public.NonSecurePortEnabled
Boolean
Enabling status of the HTTPS service non-secure port.
HTTPS.Oem.Public.MaxSessionCount
Integer
Maximum supported sessions of the HTTPS service.
HTTPS.Oem.Public.SessionCount
Integer
Current session count for HTTPS service.
HTTPS.Oem.Public.TimeOut
Integer
Timeout duration for HTTPS service, in minutes.
HTTPS.Oem.Public.SessionType
String
Session type information for HTTPS service.
HTTP.Port
Integer
HTTP service current port number.
HTTP.ProtocolEnabled
Boolean
Enabling status of the HTTP service.
HTTP.Oem.Public.SecurePort
Integer
HTTP service secure port number.
HTTP.Oem.Public.NonSecurePort
Integer
HTTP service insecure port number.
HTTP.Oem.Public.MaxSessionCount
Integer
Maximum supported sessions of the HTTP service.
HTTP.Oem.Public.SessionCount
Integer
Current session count for HTTP service.
HTTP.Oem.Public.TimeOut
Integer
Timeout duration for HTTP service, in minutes.
HTTP.Oem.Public.SessionType
String
Session type information for HTTP service.
HTTP.Oem.Public.NonSecurePortEnabled
Boolean
Enabling status of the HTTP service non-secure port.
HTTP.Oem.Public.SecurePortEnabled
Boolean
Enabling status of the HTTP service secure port.
IPMI.Port
Integer
IPMI service current port number.
IPMI.ProtocolEnabled
Boolean
Enabling status of the IPMI service.
IPMI.Oem.Public.SecurePort
Integer
IPMI secure port (RMCP+).
IPMI.Oem.Public.NonSecurePort
Integer
IPMI insecure port (RMCP).
IPMI.Oem.Public.MaxSessionCount
Integer
Maximum supported sessions of the IPMI service.
IPMI.Oem.Public.SessionCount
Integer
Current session count for IPMI service.
IPMI.Oem.Public.TimeOut
Integer
Timeout duration for IPMI service, in minutes.
IPMI.Oem.Public.SessionType
String
Session type information for IPMI service.
IPMI.Oem.Public.NonSecurePortEnabled
Boolean
Enabling status of the IPMI service non-secure port.
IPMI.Oem.Public.SecurePortEnabled
Boolean
Enabling status of the IPMI service secure port.
KVMIP.Port
Integer
KVM service current port number.
KVMIP.ProtocolEnabled
Boolean
Enabling status of the KVM service
KVMIP.Oem.Public.SecurePort
Integer
KVMIP secure port number.
KVMIP.Oem.Public.NonSecurePort
Integer
KVMIP insecure port number.
KVMIP.Oem.Public.MaxSessionCount
Integer
Maximum supported sessions of the KVMIP service.
KVMIP.Oem.Public.SessionCount
Integer
Current session count for KVMIP service.
KVMIP.Oem.Public.TimeOut
Integer
Timeout duration for KVMIP service, in minutes.
KVMIP.Oem.Public.SessionType
String
Session type information for KVMIP service.
KVMIP.Oem.Public.NonSecurePortEnabled
Boolean
Enabling status of the KVMIP service insecure port.
KVMIP.Oem.Public.SecurePortEnabled
Boolean
Enabling status of the KVMIP service secure port.
Remote-ASD.Port or iHDT.Port
Integer
ASD service port or iHDT service current port.
This field displays ASD for Intel servers and iHDT for AMD servers.
ASD.ProtocolEnabled or iHDT. ProtocolEnabled
Boolean
Enabling status of the ASD service or the iHDT service.
ASD.Oem.Public.SecurePort or iHDT.Oem.Public.SecurePort
Integer
ASD service port or iHDT service secure port.
ASD.Oem.Public.NonSecurePort or iHDT.Oem.Public.NonSecurePort
Integer
ASD service port or iHDT service insecure port.
ASD.Oem.Public.MaxSessionCount or iHDT.Oem.Public.MaxSessionCount
Integer
Maximum supported sessions for ASD or iHDT service.
ASD.Oem.Public.SessionCount or iHDT.Oem.Public.SessionCount
Integer
Current session count for ASD or iHDT service.
ASD.Oem.Public.TimeOut or iHDT. Oem.Public.TimeOut
Integer
Timeout duration for ASD or iHDT service, in minutes.
ASD.Oem.Public.SessionType or iHDT.Oem.Public.SessionType
String
Session type information of the ASD or iHDT service.
ASD.Oem.Public. NonSecurePortEnabled or iHDT.Oem.Public. NonSecurePortEnabled
Boolean
Enabling status of the ASD or iHDT insecure service port.
ASD.Oem.Public.SecurePortEnabled or
iHDT.Oem.Public.SecurePortEnabled
Boolean
Enabling status of the ASD or iHDT service secure port.
SNMP.Port
Integer
Current enabled port number for SNMP service.
SNMP.ProtocolEnabled
Boolean
Enabling status of the SNMP service.
SNMP.Oem.Public.SecurePort
Integer
SNMP secure port number.
SNMP.Oem.Public.NonSecurePort
Integer
SNMP insecure port number.
SNMP.Oem.Public.MaxSessionCount
Integer
Maximum supported sessions of the SNMP service.
SNMP.Oem.Public.SessionCount
Integer
Current session count of the SNMP service.
SNMP.Oem.Public.TimeOut
Integer
Timeout duration for SNMP service, in minutes.
SNMP.Oem.Public.SessionType
String
Session type information for SNMP service.
SNMP.Oem.Public.NonSecurePortEnabled
Boolean
Enabling status of the SNMP service insecure port.
SNMP.Oem.Public.SecurePortEnabled
Boolean
Enabling status of the SNMP service secure port.
SSDP.Port
Integer
Current enabled port number for SSDP service.
SSDP.ProtocolEnabled
Boolean
Enabling status of the SSDP service.
SSDP.Oem.Public.SecurePort
Integer
Secure SSDP service port number.
SSDP.Oem.Public.NonSecurePort
Integer
Insecure SSDP service port number.
SSDP.Oem.Public.MaxSessionCount
Integer
Maximum supported sessions of the SSDP service.
SSDP.Oem.Public.SessionCount
Integer
Current session count of the SSDP service.
SSDP.Oem.Public.TimeOut
Integer
Timeout duration for SSDP service, in minutes.
SSDP.Oem.Public.SessionType
String
Session type information for SSDP service.
SSDP.Oem.Public.NonSecurePortEnabled
Boolean
Enabling status of the SSDP service insecure port.
SSDP.Oem.Public.SecurePortEnabled
Boolean
Enabling status of the SSDP service secure port.
SSH.Port
Integer
Current enabled port number for SSH service.
SSH.ProtocolEnabled
Boolean
Enabling status of the SSH service.
SSH.Oem.Public.SecurePort
Integer
Secure SSH service port number.
SSH.Oem.Public.NonSecurePort
Integer
Insecure SSH service port number.
SSH.Oem.Public.MaxSessionCount
Integer
Maximum supported sessions of the SSH service.
SSH.Oem.Public.SessionCount
Integer
Current session count of the SSH service.
SSH.Oem.Public.TimeOut
Integer
Timeout duration for SSH service, in minutes.
SSH.Oem.Public.SessionType
String
Session type information for SSH service.
SSH.Oem.Public.NonSecurePortEnabled
Boolean
Enabling status of the SSH service insecure port.
SSH.Oem.Public.SecurePortEnabled
Boolean
Enabling status of the SSH service secure port.
FD-Media.Port
Integer
Current enabled port number for FD media service.
FD-Media.ProtocolEnabled
Boolean
Enabling status of the FD media service.
FD-Media.Oem.Public.SecurePort
Integer
Secure FD media service port number.
FD-Media.Oem.Public.NonSecurePort
Integer
Insecure FD media service port number.
FD-Media.Oem.Public.MaxSessionCount
Integer
Maximum supported sessions of the FD media service.
FD-Media.Oem.Public.SessionCount
Integer
Current session count of the FD media service.
FD-Media.Oem.Public.TimeOut
Integer
FD-Media.Oem.Public.SessionType
String
Session type information for FD media service.
FD-Media.Oem.Public.NonSecurePortEnabled
Boolean
Enabling status of the FD media service insecure port.
FD-Media.Oem.Public.SecurePortEnabled
Boolean
Enabling status of the FD media service secure port.
CD-Media.Port
Integer
Current enabled port number for CD media service.
CD-Media.ProtocolEnabled
Boolean
Enabling status of the CD media service.
CD-Media.Oem.Public.SecurePort
Integer
Secure CD media service port number.
CD-Media.Oem.Public.NonSecurePort
Integer
Insecure CD media service port number.
CD-Media.Oem.Public.MaxSessionCount
Integer
Maximum supported sessions of the CD media service.
CD-Media.Oem.Public.SessionCount
Integer
Current session count of the CD media service.
CD-Media.Oem.Public.TimeOut
Integer
Timeout duration for CD service, in minutes.
CD-Media.Oem.Public.SessionType
String
Session type information for CD media service.
CD -Media.Oem.Public.
Boolean
Enabling status of the CD media service insecure port.
CD -Media.Oem.Public. SecurePortEnabled
Boolean
Enabling status of the CD media service secure port.
HD-Media.Port
Integer
Current enabled port number for HD media service.
HD-Media.ProtocolEnabled
Boolean
Enabling status of the HD media service.
HD-Media.Oem.Public.NonSecurePort
Integer
Insecure HD media service port number.
HD-Media.Oem.Public. MaxSessionCount
Integer
Maximum supported sessions of the HD media service.
HD-Media.Oem.Public. SessionCount
Integer
Current session count of the HD media service.
HD-Media.Oem.Public. TimeOut
Integer
Timeout duration for HD service, in minutes.
HD-Media.Oem.Public. SessionType
String
Session type information for HD media service.
HD-Media.Oem.Public. NonSecurePortEnabled
Boolean
Enabling status of the HD media service insecure port.
HD-Media.Oem.Public. SecurePortEnabled
Boolean
Enabling status of the HD media service secure port.
VNC.Port
Integer
Current enabled port number for VNC service.
VNC.ProtocolEnabled
Boolean
Enabling status of the VNC media service.
VNC.Oem.Public.SecurePort
Integer
Secure VNC media service port number.
VNC.Oem.Public.NonSecurePort
Integer
Insecure VNC media service port number.
VNC.Oem.Public. MaxSessionCount
Integer
Maximum supported sessions of the VNC media service.
VNC.Oem.Public. SessionCount
Integer
Current session count of the VNC media service.
VNC.Oem.Public. TimeOut
Integer
Timeout duration for VNC media, in minutes.
VNC.Oem.Public. SessionType
String
Session type information for VNC media service.
VNC.Oem.Public. NonSecurePortEnabled
Boolean
Enabling status of the VNC media service insecure port.
VNC.Oem.Public. SecurePortEnabled
Boolean
Enabling status of the VNC media service secure port.
HostName
String
Host name.
FQDN
String
Fully qualified domain name for HDM.
This field displays null if no DNS parent domain name is configured.
Id
String
Service ID.
Name
String
Name of the service collection resource.
Status.Health
String
Resource health status.
Status.State
String
Resource enabling status.
Oem.Public.Sessions
Object
Link to the list of services that can create sessions.
Change history
Version
Change description
HDM3-1.16
HDM2-2.12
HDM2-2.02
Added Actions.Oem.Public and object Manager.RestartService.
HDM2-1.62
Added support of G6 AMD products for iHDT.
Configure service settings
Specify the port number or set the enabling status for the HTTPS, IPMI, KVM, SNMP, SSDP, SSH, virtual media, ASDiHDT, and VNC services.
Privilege module
OemSecurityMgmt
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/NetworkProtocol
Request header:
X-Auth-Token:TOKEN
Request body:
    "ServerType": {
        "Oem": {
            "Public": {
                "NonSecurePortEnabled": nonsecure_port_enabled,
                "SecurePortEnabled": port_enabled,
                "TimeOut": time_out
        "Port": port,
        "ProtocolEnabled": protocol_enabled
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
ServerType
Type of the service to be set.
Supported options:
·     IPMI.
·     KVMIP.
·     SNMP.
·     SSDP.
·     SSH.
·     CD-Media.
·     VNC.
·     ASDiHDT.
ServerType.ProtocolEnabled
Enable or disable the service.
Boolean. Supported options:
·     true—Enable.
·     false—Disable.
ServerType.Port
Service enabled port number.
Integer.
ServerType .Oem.Public.SecurePortEnabled
Enable or disable the Secure port.
·     true—Enable.
·     false—Disable.
ServerType .Oem.Public.NonSecurePortEnabled
Enable or disable the Insecure port.
·     true—Enable.
·     false—Disable.
ServerType.Oem.Public.TimeOut
Timeout duration, in minutes.
Integer.
You can configure the settings only for one service at a time. However, disabling the HTTPS service is not supported.
By default, the IPMI service has a secure port enabled. Both secure and insecure ports must be set to the same port number.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/NetworkProtocol
Request header:
X-Auth-Token:TOKEN
Request body:
    "KVMIP":{
        "Oem":{
            "Public":{
                "NonSecurePortEnabled":false,
                "SecurePortEnabled":true,
                "TimeOut":30
        "Port":7582,
        "ProtocolEnabled":true
Response:
    "ASD": {
        "Oem": {
            "Public": {
                "SecurePort": null,
                "SessionCount": 0,
                "TimeOut": null
        "Port": 6868,
"Actions": {
        "Oem": {
            "Public": {
    "CD-Media": {
        "Oem": {
            "Public": {
                "SecurePort": 5124,
                "SessionCount": 0,
                "TimeOut": null
        "Port": 5124,
    "FD-Media": {
        "Oem": {
            "Public": {
                "SecurePort": 5126,
                "SessionCount": 0,
                "TimeOut": null
        "Port": 5126,
    "FQDN": null,
    "HD-Media": {
        "Oem": {
            "Public": {
                "SecurePort": 5127,
                "SessionCount": 0,
                "TimeOut": null
        "Port": 5127,
    "HTTP": {
        "Oem": {
            "Public": {
                "SecurePort": null,
                "SessionCount": 0,
                "TimeOut": 30
        "Port": 80,
    "HTTPS": {
        "Oem": {
            "Public": {
                "SecurePort": 443,
                "SessionCount": 0,
                "TimeOut": 30
        "Port": 443,
    "HostName": "HDM",
    "IPMI": {
        "Oem": {
            "Public": {
                "SecurePort": 623,
                "TimeOut": null
        "Port": 624,
    "KVMIP": {
        "Oem": {
            "Public": {
                "SecurePort": 7582,
                "SessionCount": 0,
                "TimeOut": 30
        "Port": 7582,
    "Oem": {
        "Public": {
            "Description": "Success"
"Sessions": {
    "SNMP": {
        "Oem": {
            "Public": {
                "SecurePort": null,
                "TimeOut": null
        "Port": 161,
    "SSDP": {
        "Oem": {
            "Public": {
                "SecurePort": null,
                "TimeOut": null
        "Port": 1900,
    "SSH": {
        "Oem": {
            "Public": {
                "SecurePort": 22,
                "SessionCount": 0,
                "TimeOut": 10
        "Port": 22,
    "Status": {
        "Health": "OK",
        "State": "Enabled"
    "VNC": {
        "Oem": {
            "Public": {
                "SecurePort": null,
                "SessionCount": 0,
                "TimeOut": 10
        "Port": 5900,
Response code: 200
For information about the response fields, see "Obtain service information."
Change history
Version
Change description
HDM3-1.16
HDM2-2.12
HDM2-1.62
HDM2-1.53
Use the restart service
Use the restart service.
Privilege module
OemSecurityMgmt
Request
POST https://device_ip/redfish/v1/Managers/manager_id/NetworkProtocol/Actions/Oem/Public/Manager.RestartService/
Request header:
X-Auth-Token:TOKEN
Content-Type: application/json
Request body:
"ResetType": "SNMP"
Parameter
Value
device_ip
TOKEN
ResetType
String
Service types to be restarted,
IPMI, KVMIP, SNMP, SSDP, SSH, CD-Media, VNC, and ASD|iHDT.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/NetworkProtocol/Actions/Oem/Public/Manager.RestartService/
Request header:
X-Auth-Token:TOKEN
Request body:
"ResetType": "SNMP"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
Detailed information.
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-2.02
Added this interface.
Obtain the list of services that can create sessions
Obtain the information for the list of services that can create sessions.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/NetworkProtocol/Oem/Public/Sessions
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
ID of the manager resource.
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#NetworkProtocolSessionsCollection.NetworkProtocolSessionsCollection",
    "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions",
    "@odata.type": "#NetworkProtocolSessionsCollection.v1_0_0.NetworkProtocolSessionsCollection",
    "Description": "NetworkProtocol Sessions Collection",
    "Members": [
            "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/HTTP"
            "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/HTTPS"
            "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/KVMIP"
            "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/CD-Media"
            "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/FD-Media"
            "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/HD-Media"
            "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/SSH"
            "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/ASD"
            "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/VNC"
    "Members@odata.count": 10,
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the service session list resource model.
@odata.id
String
Link to the service session list resource.
@odata.type
String
Type of the service session list resource.
String
Description of service session list resource.
Name
String
Name of the service session list resource.
Members
Array
Service session list resources.
Members@odata.count
Integer
Number of service session list resources.
Change history
Version
Change description
HDM3-1.16
HDM2-2.12
Obtain detailed session information for a specified service
Obtain information about HTTPS, KVM, SSH, virtual media, ASD|iHDT, and VNC services.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/NetworkProtocol/Oem/Public/Sessions/protocol_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
protocol_id
Service type.
You can obtain it by querying the interface for the list of services that can create sessions.
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/HTTP
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#NetworkProtocolSessions.NetworkProtocolSessions",
    "@odata.id": "/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/HTTP",
    "@odata.type": "#NetworkProtocolSessions.v1_0_0.NetworkProtocolSessions",
    "Description": "NetworkProtocol Sessions",
    "Name": "HTTP",
    "Oem": {
        "Public": {
    "Sessions": [
            "IPAddress": "192.168.247.19",
            "MySession": true,
            "RoleId": "Administrator",
            "SessionId": "16",
            "UserId": "1",
            "UserName": "admin"
Response code: 200
Data type
@odata.context
String
OData description of the service session detail resource model.
@odata.id
String
Link to the service session detail resource.
@odata.type
String
Type of the service session detail resource.
String
Description of the service session detail resource.
Name
String
Name of the service session detail resource.
Sessions
Array
Detailed information of the service session.
SessionId
String
Session ID.
SessionType
String
Session type.
UserId
String
User ID.
UserName
String
Username.
IPAddress
String
IP address.
RoleId
String
User role.
MySession
Boolean
Whether it is a local session.
Delete session information for the specified service
Delete information for the HTTPS, KVM, SSH, virtual media, ASD|iHDT, and VNC services.
Privilege module
OemSecurityMgmt
Locking type of the associated system
Request
DELETE https://device_ip/redfish/v1/Managers/manager_id/NetworkProtocol/Oem/Public/Sessions/protocol_id/session_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
protocol_id
ID of service type.
You can obtain service type IDs from the interface for the list of services that can create sessions.
session_id
Session ID.
You can obtain available session IDs from the detailed session information of the specified service.
Method and URL:
DELETE https://192.168.18.18/redfish/v1/Managers/1/NetworkProtocol/Oem/Public/Sessions/HTTPS/16
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.62
HDM2-1.53
Added the locking type of the associated system.
Obtain energy-saving service information
Obtain information about energy-saving services.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/ Oem/Public/EnergySavingService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/EnergySavingService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context":"/redfish/v1/$metadata#EnergySavingService.EnergySavingService(*)",
    "@odata.id":"/redfish/v1/Managers/1/Oem/Public/EnergySavingService",
    "@odata.type":"#EnergySavingService.v1_0_0.EnergySavingService",
    "SavingComponents":[
        "PSU"
    "Name":"EnergySavingService",
    "Id":"EnergySavingService",
    "Oem":{
        "Public":{
            "CompletionCode":0,
            "Description":"Success"
Response code: 200
Data type
@odata.context
String
OData description of energy-saving service information.
@odata.id
String
Link to the energy-saving service information resource.
@odata.type
String
Type of the energy-saving service information resource.
ServiceEnabled
Boolean
Enabled status of energy-saving service information.
SavingComponents
Array
Type of the energy-saving component. Supported option:
·     PSU.
Name
String
Name of the energy-saving service information resource.
Id
String
ID of the energy-saving service information resource.
Configure energy-saving service settings
Configure the energy-saving service information.
Privilege module
OemPowerControl
BMC configuration locking
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/EnergySavingService
Request header:
X-Auth-Token:TOKEN
Request body:
"SavingComponents": [
      "PSU"
Parameter
Value
device_ip
TOKEN
manager_id
ServiceEnabled
Enabling status of energy-saving service information..
Boolean.
SavingComponents
Array. Supported option:
·     PSU.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/EnergySavingService
Request header:
X-Auth-Token:TOKEN
Request body:
        "PSU"
Response:
        "PSU"
    "Oem":{
        "Public":{
            "CompletionCode":0,
Response code: 200
For information about the response fields, see "Obtain energy-saving service information."
Change history
Version
Change description
HDM2-1.53
Restart HDM
Restart HDM for the server.
Privilege module
OemDiagnosis
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/Actions/Manager.Reset
Request header:
X-Auth-Token:TOKEN
Request body:
"ResetType":type
Parameter
Value
device_ip
TOKEN
manager_id
ResetType
HDM restart method.
String. Options include:
·     ForceRestart.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/Actions/Manager.Reset
Request header:
X-Auth-Token:TOKEN
Request body:
"ResetType":"ForceRestart"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Restore BMC factory settings
Restore BMC factory settings.
Privilege module
OemDiagnosis
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/Actions/Oem/Public/Manager.RestoreFactory
Request header:
X-Auth-Token:TOKEN
Request body:
    "ConfigurationType": "BMC"
Parameter
Value
device_ip
TOKEN
manager_id
ConfigurationType
Configuration type.
This field is available only for BMC.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/Actions/Oem/Public/Manager.RestoreFactory
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain network port collection information
Obtain information about all network ports from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/EthernetInterfaces
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/EthernetInterfaces
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#EthernetInterfaceCollection.EthernetInterfaceCollection",
    "@odata.id": "/redfish/v1/Managers/1/EthernetInterfaces",
    "@odata.type": "#EthernetInterfaceCollection.EthernetInterfaceCollection",
    "Description": "Collection of Ethernet Interfaces for this Manager",
    "Members": [
            "@odata.id": "/redfish/v1/Managers/1/EthernetInterfaces/eth0"
            "@odata.id": "/redfish/v1/Managers/1/EthernetInterfaces/eth1"
    "Members@odata.count": 2,
    "Name": "Ethernet Network Interface Collection",
    "Oem": {
        "Public": {
            "Description": "Success",
            "NcsiEnabled": true,
            "PortMode": "Normal",
            "SharedNetworkPort": {
                "@odata.id": "/redfish/v1/Managers/1/EthernetInterfaces/Oem/Public/SharedNetworkPort"
Response code: 200
Data type
@odata.context
String
OData description of the network port collection resource.
@odata.id
String
Link to the network port collection resource.
@odata.type
String
Type of the network port collection resource.
String
Description of the network port collection resource.
Name
String
Name of the network port collection resource.
Members
Array
Links to network port resources.
Members@odata.count
Integer
Number of network ports.
Oem.Public.PortMode
String
Network port mode. Supported options:
·     Normal.
·     Bonding.
·     Activestandby.
Oem.Public.NcsiEnabled
Boolean
Enabling status of specified NCSI. Supported options:
·     true
·     false
Oem.Public.SharedNetworkPort
Object
Link to the shared network port resource.
Set the network port mode
Set the network port mode for BMC.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/EthernetInterfaces
Request header:
X-Auth-Token:TOKEN
If-Match:ifmatch_value
Request body:
"Oem":{
"Public":{
"PortMode":value,
"NcsiEnabled":true
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
Entity tag (ETag) that uniquely represents the requested resource.
To obtain the entity tag value of a resource, send a GET request to it and then obtain the ETag value from the response header.
Oem.Public.PortMode
Network port mode.
·     Normal.
·     Bonding.
·     Activestandby—G6 is adaptive mode, B05 is network port adaptive mode.
Boolean.
Whether to enable NCSI. Supported options:
·     true
·     false
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/EthernetInterfaces
Request header:
X-Auth-Token:TOKEN
If-Match:W/"6e8c96325a9b7c6a6e5e9f23616fbce0"
Request body:
"Oem":{
"Public":{
"PortMode": "Activestandby",
"NcsiEnabled": true
Response:
    "Members": [
    "Oem": {
        "Public": {
Response code: 200
For information about the response fields, see "Obtain network port collection information."
Change history
Version
Change description
HDM2-1.53
Obtain shared network port information
Obtain information about a shared network port from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/EthernetInterfaces/Oem/Public/SharedNetworkPort
Request header:
X-Auth-Token:TOKEN
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/EthernetInterfaces/Oem/Public/SharedNetworkPort
Request header:
X-Auth-Token:TOKEN
Response:
  "@odata.context": "/redfish/v1/$metadata#SharedNetworkPort.SharedNetworkPort",
  "@odata.id": "/redfish/v1/Managers/1/EthernetInterfaces/Oem/Public/SharedNetworkPort",
  "@odata.type": "#SharedNetworkPort.v1_0_0.SharedNetworkPort",
  "AdaptiveEnabled": false,
  "CardAdaptiveEnabled": false,
  "CardPriorityList": [
    "OCP1 Nic",
    "OCP2 Nic",
    "OCP3/PCIe Nic"
  "LastSharedPort": 1,
  "ManagementNetworkPort@Redfish.AllowableValues": [
      "OCP1 Nic": {
        "HotPlugSupported": true,
        "PortAllowableValues": [
          "Port1",
          "Port2"
        "State": true
      "OCP2 Nic": {
          "Port1",
          "Port2"
        "State": false
      "OCP3/PCIe Nic": {
        "HotPlugSupported": false,
          "Port1",
          "Port2"
        "State": false
  "NetworkCardType": "OCP1 Nic",
  "Oem": {
    "Public": {
  "SharedPortInUse": 1,
  "SharedPortLinkState": [
      "Port1": "Down"
      "Port2": "Down"
Response code: 200
Data type
SharedPortInUse
Integer
Used shared port.
SharedPortLinkState
String
Link status of all ports on the shared network card. Supported options:
·     Down,
·     Up,
NetworkCardType
String
Type of the network card.
AdaptiveEnabled
Boolean
Port adaptive usage. Supported options:
·     True.
·     False.
Array
String
Presence status.
HotPlugSupported
Boolean
Supports hot-swapping. Supported options:
·     True.
·     False.
PortAllowableValues
String
All ports.
CardAdaptiveEnabled
String
Whether network card adaptive mode is enabled.
LastSharedPort
String
Last share port number.
Change history
Version
Change description
HDM2-2.17
HDM3-1.25
HDM3-2.03
Deleted the LinkStatus field in response field description.
Configure shared network port settings
Obtain the settings information of a shared network port for the server.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/EthernetInterfaces/Oem/Public/SharedNetworkPort
Request header:
X-Auth-Token:TOKEN
Request body:
    "AdaptiveEnabled":true,
    "NetworkCardType":"Onboard Nic",
    "SharedPortInUse":1,
    "CardAdaptiveEnabled":true,
    "CardPriorityList":[
        "OCP3/PCIe Nic",
        "OCP2 Nic",
        "OCP1 Nic"
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
AdaptiveEnabled
Whether port adaptive mode is enabled.
·     True.
·     False.
Auto-selection status. Supported options:
·     true—Enabled.
·     false—Disabled.
NetworkCardType
Network card type.
String.
You can obtain the network adapter type from the CardPriorityList field in shared network port information.
SharedPortInUse
Port number.
Integer.
CardAdaptiveEnabled
Boolean.
CardPriorityList
Network card priority list.
Array.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/EthernetInterfaces/Oem/Public/SharedNetworkPort
Request header:
X-Auth-Token:TOKEN
Request body:
    "SharedPortInUse":2,
        "OCP1 Nic",
        "OCP2 Nic",
        "OCP3/PCIe Nic"
Response:
    "CardAdaptiveEnabled": true,
        "OCP1 Nic",
        "OCP2 Nic",
        "OCP3/PCIe Nic"
    "LastSharedPort": 2,
            "OCP1 Nic": {
                    "Port1",
                    "Port2"
                "State": true
            "OCP2 Nic": {
                    "Port1",
                    "Port2"
                "State": true
            "OCP3/PCIe Nic": {
                    "Port1",
                    "Port2"
                "State": true
    "Oem": {
        "Public": {
    "SharedPortInUse": 2,
            "Port1": "Down"
            "Port2": "Up"
Response code: 200
For information about the response fields, see "Obtain shared network port information."
Change history
Version
Change description
HDM3-1.20
Edited the description for the NetworkCardType field in the request body.
HDM2-1.53
Obtain network port information
Obtain information about a specific network port from the server. The dedicated network port is not available for X18000 products.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/EthernetInterfaces/networkinterface_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
networkinterface_id
ID of the network port resource.
You can obtain available network port resource IDs from network port collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/EthernetInterfaces/eth0
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context":"/redfish/v1/$metadata#EthernetInterface.EthernetInterface",
    "@odata.id":"/redfish/v1/Managers/1/EthernetInterfaces/eth0",
    "@odata.type":"#EthernetInterface.v1_6_0.EthernetInterface",
    "AutoNeg":true,
    "Description":"Ethernet Interface eth0",
    "FQDN":null,
    "FullDuplex":true,
    "HostName":"HDM2019",
    "IPv4Addresses":[
            "Address":"192.168.188.198",
            "AddressOrigin":"Static",
            "Gateway":"",
            "SubnetMask":"255.255.0.0"
    "IPv4StaticAddresses":[
            "Gateway":"",
    "IPv6Addresses":[
            "Address":"fe80::a8bb:ccff:fed2:4718",
            "AddressOrigin":"LinkLocal",
            "AddressState":"Preferred",
            "PrefixLength":64
            "Address":"2015::1",
            "PrefixLength":64
            "Address":"3ffe:501:eeee:2:a8bb:ccff:fed2:4718",
            "AddressOrigin":"SLAAC",
            "PrefixLength":64
    "IPv6DefaultGateway":"2015::123",
    "IPv6StaticAddresses":{
        "PrefixLength":64
    "IPv6StaticDefaultGateways":[
        "2015::123"
    "Id":"eth0",
    "InterfaceEnabled":true,
    "MACAddress":"aa:bb:cc:d2:47:18",
    "MTUSize":1500,
    "MaxIPv6StaticAddresses":16,
    "Name":"eth0",
    "NameServers":[
        null,
        null,
        null,
        null,
        null,
        null
    "Oem":{
        "Public":{
            "AdaptiveFlag":false,
            "ChannelNumber":1,
            "CompletionCode":0,
            "DNS":{
                "IPv4DNS":{
"DNSAutoReg":true,
                    "DNSEnabled":false,
                    "DNSMode":null,
                    "SuperiorDomain":""
                "IPv6DNS":{
"DNSAutoReg":true,
                    "DNSEnabled":true,
                    "DNSMode":"Manual",
                    "SuperiorDomain":""
            "Description":"Success",
            "IPv4": {
               "StaticRoutes": [
                       "Destination": "",
                       "Gateway": "",
                       "SubnetMask": ""
                       "Destination": "",
                       "Gateway": "",
                       "SubnetMask": ""
            "IPv4Enabled":true,
            "IPv6": {
               "StaticRoutes": [
                       "Destination": "",
                       "Gateway": "",
                       "PrefixLength": 0
                       "Destination": "",
                       "Gateway": "",
                       "PrefixLength": 0
            "IPv4Enabled":true,
            "IPv6Enabled":true,
            "ManagementNetworkPort@Redfish.AllowableValues":[
                    "LinkStatus":"Connected",
                    "Location":"mainboard",
                    "Type":"Dedicated"
            "PreferredPortId":"0",
            "SameSegmentCode":0
    "PermanentMACAddress":"aa:bb:cc:d2:47:18",
    "SpeedMbps":1000,
    "Status":{
        "Health":"OK",
        "State":"Enabled"
    "VLAN":{
        "VLANEnable":false,
        "VLANId":0,
        "VLANPriority":0
Response code: 200
Data type
@odata.context
String
OData description of the network port resource model.
@odata.id
String
Link to the network port resource.
@odata.type
String
Type of the network port resource.
String
Description of the network port resource.
AutoNeg
Boolean
Enabling status of auto-negotiation.
FQDN
String
Fully qualified domain name of HDM.
This field displays null If the DNS parent domain name is not configured.
FullDuplex
Boolean
Enabling status of full duplex.
HostName
String
Host name.
IPv4Addresses.Address
String
IPv4 address.
IPv4Addresses.AddressOrigin
String
IPv4 address obtaining method.
IPv4Addresses.Gateway
String
IPv4 gateway.
IPv4Addresses.SubnetMask
String
IPv4 subnet mask.
IPv4StaticAddresses.Address
String
Static IPv4 address.
IPv4StaticAddresses.AddressOrigin
String
Static IPv4 protocol type.
IPv4StaticAddresses.Gateway
String
Static IPv4 gateway.
IPv4StaticAddresses.SubnetMask
String
Static IPv4 subnet mask.
IPv6Addresses.Address
String
IPv6 address.
IPv6Addresses.AddressOrigin
String
IPv6 address obtaining method.
IPv6Addresses.PrefixLength
Integer
IPv6 prefix length.
IPv6Addresses.AddressState
String
IPv6 address status. Supported options:
·     Preferred—Successful.
·     Failed—Failure.
·     Tentative—Pending.
IPv6DefaultGateway
String
Default IPv6 gateway.
IPv6StaticAddresses
Array
Static IPv6 addresses.
Array
Static IPv6 gateways.
Id
String
Network port ID.
Link.Oem.Public.EthernetInterface
Array
Link.Oem.Public.ManagementNetworkPort@Redfish.AllowableValues
Array
Port list and port information.
LinkStatus
String
Network port connection status. Supported options:
·     Connected.
·     Disconnected.
Location
String
Network adapter location. If the network adapter is on the system board, this field displays mainboard. If the network adapter is on a location other than the system board, this field displays PCIeSlot+slot.
PortNumber
Integer
Shared network port number.
String
Network port type. Supported options:
·     Dedicated.
·     Shared.
InterfaceEnabled
Boolean
Enabling status of the network port.
MACAddress
String
MAC address.
MTUSize
String
MTU size.
String
Maximum length of a static IPv6 address.
Name
String
Name of the network port.
NameServers
Array
IP address of the DNS server.
Specify six DNS server IP addresses, the first three are IPv4 addresses, and the last three are IPv6 addresses. If the DNS server IP address is not set, it will be displayed as null.
Oem.Public.AdaptiveFlag
Boolean
·     true—Enabled.
·     false—Disabled.
Oem.Public.ChannelNumber
Integer
Port channel number.
Oem.Public.IPv4Enabled
Boolean
Enabled or disabled IPv4 status.
Oem.Public.IPv4.StaticRoutes.Destination
String
IPv4 destination network address.
Oem.Public.IPv4.StaticRoutes.SubnetMask
String
Subnet mask of the IPv4 address.
Oem.Public.IPv4.StaticRoutes.Gateway
String
IPv4 static routing gateway.
Oem.Public.IPv6.StaticRoutes.Destination
String
IPv6 destination network address.
Oem.Public.IPv6.StaticRoutes.PrefixLength
Integer
Subnet prefix length of the IPv6 address.
Oem.Public.IPv6.StaticRoutes.Gateway
String
IPv6 static routing gateway.
Oem.Public.IPv6Enabled
Boolean
Enabled or disabled IPv6 status.
Oem.Public.IPv6LocalLinkAddress
String
Local IPv6 link address.
Oem.Public.IPv6StatelessAddress
String
IPv6 stateless address.
Oem.Public.DNS.IPv4DNS.DNSMode
String
IPv4 DNS server auto-configuration. Supported options:
·     Manual.
·     Auto.
Oem.Public.DNS.IPv4DNS.DNSEnabled
Boolean
Enabling status of IPv4 DNS.
Oem.Public.DNS.IPv4DNS.DNSAutoReg
Boolean
Enabling status of IPv4 DNS auto-registration.
Oem.Public.DNS.IPv4DNS.SuperiorDomain
String
IPv4 parent domain.
Oem.Public.DNS.IPv6DNS.DNSMode
String
IPv6 DNS server auto-configuration. Supported options:
·     Manual.
·     Auto.
Oem.Public.DNS.IPv6DNS.DNSEnabled
Boolean
Enabling status of IPv6 DNS.
Oem.Public.DNS.IPv6DNS.DNSAutoReg
Boolean
Enabling status of IPv6 DNS auto-registration.
Oem.Public.DNS.IPv6DNS.SuperiorDomain
String
IPv6 parent domain.
Oem.Public.PreferredPortId
String
This field displays 0 for using eth0 and 1 for using eth1.
Oem.Public.SameSegmentCode
Integer
Whether network segments are conflict.
Supported options:
·     0—No conflict
·     1—IPv4 conflict
·     2—IPv6 conflict
·     3— All conflicts
PermanentMACAddress
String
Fixed MAC address.
SpeedMbps
String
Transmission speed, in Mbps.
VLAN.VLANEnable
String
Enabling status of the VLAN service.
VLAN.VLANId
Integer
VLAN ID.
Status.Health
String
Health status.
Status.State
String
Enabling of health status.
Change history
Version
Change description
HDM2-1.78
HDM2-2.16
HDM3-1.24
HDM3-2.02
Added the Oem.Public.DNS.IPv4DNS.DNSAutoReg and Oem.Public.DNS.IPv6DNS.DNSAutoReg fields.
HDM2-1.60
Added the following filed:
·     Oem.Public.IPv4.StaticRoutes.Destination
·     Oem.Public.IPv4.StaticRoutes.SubnetMask
·     Oem.Public.IPv4.StaticRoutes.Gateway
·     Oem.Public.IPv6StaticRoutes.Destination
·     Oem.Public.IPv6.StaticRoutes.Gateway
·     Oem.Public.IPv6StaticRoutes.PrefixLength
Configure network port settings
Configure the settings of a specific network port for the server.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/EthernetInterfaces/networkinterface_id
Request header:
X-Auth-Token:TOKEN
Request body:
    "AutoNeg":false,
    "FullDuplex":true,
    "SpeedMbps":1000,
    "IPv4Addresses":[
            "SubnetMask":"255.255.0.0",
            "Gateway":"192.168.1.2",
            "Gateway":"",
    "IPv6Addresses":[
            "PrefixLength":64,
    "IPv6StaticAddresses":[
            "PrefixLength":64
    "IPv6DefaultGateway":"2015::9",
        "2015::123"
    "VLAN":{
        "VLANEnable":false
    "NameServers":[
        "192.168.1.2",
        "192.168.12.25",
        null,
        "6061::2220:8ff:fe07:1348",
        null,
        null
    "Oem":{
        "Public":{
            "IPv4Enabled":true,
            "IPv6Enabled":true,
            "IPv4": {
               "StaticRoutes": [
                       "Destination": "172.168.0.0",
                       "Gateway": "192.168.2.2",
                       "SubnetMask": "255.255.0.0"
                       "Destination": "",
                       "Gateway": "",
                       "SubnetMask": ""
           "IPv6": {
               "StaticRoutes": [
                       "Destination": "9001::",
                       "Gateway": "3001::123",
                       "PrefixLength": 64
                       "Destination": "",
                       "Gateway": "",
                       "PrefixLength": 0
            "DNS":{
                "IPv4DNS":{
                    "DNSMode":"Manual",
                    "DNSEnabled":true,
"DNSAutoReg":false,
                    "SuperiorDomain":"www.li.com"
                "IPv6DNS":{
                    "DNSMode":"Manual",
                    "DNSEnabled":true,
"DNSAutoReg":false,
                    "SuperiorDomain":"www.hai.com"
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
manager_id
ifmatch_value
AutoNeg
Whether to auto-negotiate.
·     true.
·     false.
FullDuplex
Whether to use full duplex.
·     true.
·     false.
SpeedMbps
Port speed (not supported for shared ports), only configurable for dedicated ports when auto-negotiation is off, with only three speeds: 10/100/1000.
Integer.
networkinterface_id
Network port resource ID
IPv4 address.
String.
IPv4 gateway.
String.
IPv4 subnet mask.
String.
String. Supported options:
·     Static.
·     DHCP.
String.
String.
String.
Obtain static IPv4 address mode. Supported option:
·     Static.
String.
IPv6 address.
String.
IPv6 prefix length.
Integer.
·     Static.
·     DHCPv6.
IPv6StaticAddresses
Array.
IPv6DefaultGateway
String.
Static IPv6 gateway.
Array.
HostName
Host name.
String.
Vlan
VLAN ID.
Integer.
NameServers
IP address of the primary and secondary DNS servers.
Array.
The primary server address is displayed first.
This field is available when the HDM management network uses a dynamic address.
New G6 requirement: simultaneously issue 6 addresses, with the first three being IPv4 and the last three being IPv6. If set to empty, issue null.
Integer.
Enabled or disabled IPv4.
Boolean.
String.
String.
String.
String.
String.
String.
Enabled or disabled IPv6.
Boolean.
Oem.Public.DNS.IPv4DNS.HostConfig
IPv4 host settings parameters.
Integer.
·     Manual.
·     Auto.
Whether to enable IPV4DNS.
·     true—Enable.
·     false—Disable.
Oem.Public.DNS.IPv4DNS. DNSAutoReg
Whether to enable IPv4 DNS auto-registration.
·     true—Enable.
·     false—Disable.
This field is available only when the DNS mode is set to manual.
IPv4 parent domain.
String.
Oem.Public.DNS.IPv6DNS.HostConfig
IPv6 host configuration parameters
Integer.
·     Manual.
·     Auto.
Whether to enable IPV6DNS.
·     true—Enable.
·     false—Disable.
Oem.Public.DNS.IPv6DNS. DNSAutoReg
Whether to enable IPv6 DNS auto-registration.
·     true—Enable.
·     false—Disable.
IPv6 parent domain.
String.
When the IP address obtaining method is set to DHCP or DHCPv6, you cannot configure the other network port settings. IPv4, IPv6, and IPv6 static address array sizes can only fix to 1.
When both the Oem.Public.{IPv4Enabled,IPv6Enabled} fields are set to false, the interface is disabled. Do not disable the shared and dedicated ports at the same time. For G5 servers, you cannot use this method to disable the dedicated network port.
Examples (1)
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/EthernetInterfaces/eth0
Request header:
X-Auth-Token:TOKEN
Request body:
    "IPv4Addresses":[
            "Address":"192.168.77.77",
            "Gateway":"",
    "IPv6Addresses":[
            "PrefixLength":64,
            "PrefixLength":64
        "2015::123"
Response:
    "AutoNeg":true,
    "FQDN":null,
    "FullDuplex":true,
    "IPv4Addresses":[
            "Gateway":"",
            "Gateway":"",
    "IPv6Addresses":[
            "PrefixLength":64
            "PrefixLength":64
            "PrefixLength":64
        "PrefixLength":64
        "2015::123"
    "Id":"eth0",
    "MTUSize":1500,
    "Name":"eth0",
    "NameServers":[
        null,
        null,
        null,
        null,
        null,
        null
    "Oem":{
        "Public":{
            "ChannelNumber":1,
            "CompletionCode":0,
            "DNS":{
                "IPv4DNS":{
                    "DNSEnabled":false,
                    "DNSMode":null,
                    "SuperiorDomain":""
                "IPv6DNS":{
                    "DNSEnabled":true,
                    "DNSMode":"Manual",
                    "SuperiorDomain":""
            "IPv4": {
               "StaticRoutes": [
                       "Destination": "",
                       "Gateway": "",
                       "SubnetMask": ""
                       "Destination": "",
                       "Gateway": "",
                       "SubnetMask": ""
            "IPv4Enabled":true,
            "IPv6": {
               "StaticRoutes": [
                       "Destination": "",
                       "Gateway": "",
                       "PrefixLength": 0
                       "Destination": "",
                       "Gateway": "",
                       "PrefixLength": 0
            "IPv6Enabled":true,
                    "Type":"Dedicated"
            "SameSegmentCode":0
    "SpeedMbps":1000,
    "Status":{
        "Health":"OK",
        "State":"Enabled"
    "VLAN":{
        "VLANEnable":false,
        "VLANId":0,
        "VLANPriority":0
Response code: 200
Examples 2
# Disable the network port.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/EthernetInterfaces/eth1
Request header:
X-Auth-Token:TOKEN
If-Match: W/"6e8c96325a9b7c6a6e5e9f23616fbce0"
Request body:
    "Oem":{
        "Public":{
            "IPv4Enabled":false,
            "IPv6Enabled":false
Response:
    "@odata.context": "/redfish/v1/$metadata#EthernetInterface.EthernetInterface",
    "@odata.id": "/redfish/v1/Managers/1/EthernetInterfaces/eth1",
    "@odata.type": "#EthernetInterface.v1_6_0.EthernetInterface",
    "AutoNeg": true,
    "Description": "Ethernet Interface eth1",
    "FQDN": null,
    "FullDuplex": true,
    "HostName": "HDM",
    "IPv4Addresses": [
            "Address": "",
            "AddressOrigin": "DHCP",
            "Gateway": "",
            "SubnetMask": ""
    "IPv4StaticAddresses": [],
    "IPv6Addresses": [
            "Address": "fe80::2223:5ff:fe24:1147",
            "AddressOrigin": "LinkLocal",
            "AddressState": "Tentative",
            "PrefixLength": 0
            "Address": "",
            "AddressOrigin": "DHCPv6",
            "AddressState": "N/A",
            "PrefixLength": 0
            "Address": "",
            "AddressOrigin": "SLAAC",
            "PrefixLength": 0
    "IPv6DefaultGateway": "",
    "IPv6StaticAddresses": null,
    "IPv6StaticDefaultGateways": [],
    "Id": "eth1",
    "InterfaceEnabled": false,
    "MACAddress": "",
    "MTUSize": 1500,
    "MaxIPv6StaticAddresses": 16,
    "Name": "eth1",
    "NameServers": [
        null,
        null,
        null,
        null,
        null,
        null
    "Oem": {
        "Public": {
                "AdaptiveFlag": false,
                "ChannelNumber": 8,
                "CompletionCode": 0,
                "DNS": {
                "IPv4DNS": {
                    "DNSEnabled": false,
                    "DNSMode": "Auto",
                    "SuperiorDomain": ""
                "IPv6DNS": {
                    "DNSMode": "Auto",
            "IPv4": {
               "StaticRoutes": [
                       "Destination": "",
                       "Gateway": "",
                       "SubnetMask": ""
                       "Destination": "",
                       "Gateway": "",
                       "SubnetMask": ""
            "IPv6": {
               "StaticRoutes": [
                       "Destination": "",
                       "Gateway": "",
                       "PrefixLength": 0
                       "Destination": "",
                       "Gateway": "",
                       "PrefixLength": 0
          "IPv6Enabled": false,
          "ManagementNetworkPort@Redfish.AllowableValues": [],
          "PreferredPortId": "1",
          "SameSegmentCode": 0
    "PermanentMACAddress": "",
    "SpeedMbps": 1000,
    "Status": {
        "Health": "OK",
        "State": "Disabled"
    "VLAN": {
        "VLANEnable": false,
        "VLANId": 0,
        "VLANPriority": 0
Response code: 200
Response field description
The server returns status code 200 for a successful operation.
For information about the response fields, see "Obtain network port information."
Change history
Version
Change description
HDM2-1.78
HDM2-2.16
HDM3-1.24
HDM3-2.02
Added the Oem.Public.DNS.IPv4DNS.DNSAutoReg and Oem.Public.DNS.IPv6DNS.DNSAutoReg fields. These fields are available only when the DNS mode is set to manual.
HDM2-1.60
Added the following field:
HDM2-1.54
Added Examples 2 to illustrate the method of disabling a network port by setting the Oem.Public.{IPv4Enabled,IPv6Enabled} field to false.
HDM2-1.53
Remarks
When you set DNSMode and DNSAutoReg, you must also set the DNSEnabled field to true. If you fail to do so, the settings for DNSMode and DNSAutoReg will become invalid.
If you set the DNSEnabled field to false, the settings for DNSMode, SuperiorDomain, and DNSAutoReg are invalid.
If you change the DNSMode field from Manual to Auto, the settings for SuperiorDomain and DNSAutoReg are invalid.
Obtain virtual media collection information
Obtain information about all virtual media from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/VirtualMedia
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/VirtualMedia
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#VirtualMediaCollection.VirtualMediaCollection",
    "@odata.id": "/redfish/v1/Managers/1/VirtualMedia",
    "@odata.type": "#VirtualMediaCollection.VirtualMediaCollection",
    "Actions": {
        "Oem": {
            "Public": {
                "#VirtualMedia.Config": {
                    "target": "/redfish/v1/Managers/1/VirtualMedia/Oem/Public/Actions/VirtualMedia.Config"
"#VirtualMedia.StopMount": {
                    "target": "/redfish/v1/Managers/1/VirtualMedia/Oem/Public/Actions/VirtualMedia.StopMount"
                "#VirtualMedia.VmmControl": [
                        "target": "/redfish/v1/Managers/1/VirtualMedia/CD/Oem/Public/Actions/VirtualMedia.VmmControl"
                        "target": "/redfish/v1/Managers/1/VirtualMedia/FD/Oem/Public/Actions/VirtualMedia.VmmControl"
                        "target": "/redfish/v1/Managers/1/VirtualMedia/HD/Oem/Public/Actions/VirtualMedia.VmmControl"
    "Description": "Collection of Virtual Media redirected to host via this Manager",
    "Members": [
            "@odata.id": "/redfish/v1/Managers/1/VirtualMedia/CD"
            "@odata.id": "/redfish/v1/Managers/1/VirtualMedia/FD"
            "@odata.id": "/redfish/v1/Managers/1/VirtualMedia/HD"
    "Members@odata.count": 3,
    "Name": "Virtual Media Collection",
    "Oem": {
        "Public": {
            "MountStatus": {
                "@odata.id": "/redfish/v1/Managers/1/VirtualMedia/Oem/Public/MountStatus"
Response code: 200
Date type
@odata.context
String
OData description of the virtual media collection resource model.
@odata.id
String
Link to the virtual media collection resource.
@odata.type
String
Type of the virtual media collection resource.
String
Description of the virtual media collection resource.
Name
String
Name of the virtual media collection resource.
Members
Enabled list of virtual media types.
@odata.id
String
Link to a virtual media node.
Members@odata.count
Integer
Number of virtual media resources.
Actions.Oem.Public.#VirtualMedia.Config
Object
Virtual media configuration.
Actions.Oem.Public.#VirtualMedia.VmmControl
Object
Connect virtual media,
Oem.Public.MountStatus
Object
Check virtual media connection status.
Actions.Oem.Public.#VirtualMedia.StopMount
Object
Stop virtual media mounting.
Obtain virtual media information
Obtain information about the virtual media resource from the server.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/VirtualMedia/Virtualmedia_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
manager_id
Only value 1 is supported.
Virtualmedia_id
Type of the virtual media.
Supported types:
·     CD.
·     HD.
·     FD.
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/VirtualMedia/CD
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#VirtualMedia.VirtualMedia(*)",
    "@odata.id": "/redfish/v1/Managers/1/VirtualMedia/CD",
    "@odata.type": "#VirtualMedia.v1_4_0.VirtualMedia",
    "Connected": [
            "ImageName": "CentOS.iso",
"Oem": {
"Public": {
"ImageType": "ImageFile"
            "MediaIndex": 0,
            "MediaTypes": "CD",
            "SessionIndex": 0
    "Id": "CD",
    "Name": "VirtualMedia",
    "NotConnected": [
            "ImageName": "Test1.iso",
"Oem": {
                "Public": {
            "Index": 0,
            "MediaTypes": "CD"
            "ImageName": "Test2.iso",
"Oem": {
                "Public": {
            "Index": 1,
            "MediaTypes": "CD"
            "ImageName": "ZBC.iso",
            "Index": 2,
"Oem": {
                "Public": {
            "MediaTypes": "CD"
            "ImageName": "Zwe.iso",
            "Index": 3,
"Oem": {
                "Public": {
            "MediaTypes": "CD"
    "Oem": {
        "Public": {
Response code: 200
Date type
@odata.context
String
OData description of the CD-Media resource model.
@odata.id
String
Link to the CD-Media resource.
@odata.type
String
Type of the CD-Media resource.
Id
String
ID of the CD-Media resource.
Name
String
Name of the CD-Media resource.
Connected
Array
Connected images.
Connected.MediaTypes
String
Media image type. Supported options:
·     CD/DVD/FD.
Connected.ImageName
String
Media image name.
Connected.MediaIndex
Integer
Media index.
Connected.SessionIndex
Integer
Session index.
Connected.Oem.Public.ImageType
String
Image type.
NotConnected
Array
Disconnected images.
NotConnected.ImageName
String
Media image name.
NotConnected.Oem.Public.ImageType
String
Image type.
NotConnected.Index
Integer
Disconnected image number,
NotConnected.MediaTypes
String
Media image type.
Change history
Version
Change description
HDM3-1.15
Added the Connected.Oem.Public.ImageType and NotConnected.Oem.Public.ImageType fields. The fields are available only in HDM3 1.15 and later versions and are not available in HDM2.
Obtain virtual media connection status
Obtain information about the virtual media connection status. from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/VirtualMedia/Oem/Public/MountStatus
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/VirtualMedia//Oem/Public/MountStatus
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#VirtualMediaMountStatus.VirtualMediaMountStatus",
    "@odata.id": "/redfish/v1/Managers/1/VirtualMedia/Oem/Public/MountStatus",
    "@odata.type": "#VirtualMediaMountStatus.v1_0_0.VirtualMediaMountStatus",
    "CD": [
            "MediaIndex": 0,
            "Status": "Access permitted"
            "MediaIndex": 1,
            "Status": "Not started"
    "FD": [
            "MediaIndex": 0,
    "HD": [
            "MediaIndex": 0,
            "MediaIndex": 1,
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the virtual media resource connection model.
@odata.id
String
Link to the virtual media resource connection.
@odata.type
String
Type of the virtual media resource connection.
CD.MediaIndex
Integer
Media index..
CD.Status
String
Connection status. Supported options:
·     Not started.
·     Access permitted.
·     Access denied.
·     Login failed.
·     Connection in use.
·     Unauthorized.
·     Unknown error.
·     Access permitted.
·     Max number of login sessions reached.
·     Access error.
·     Invalid image.
·     Installation error.
·     Opening error.
·     Expired license.
·     Connection lost.
·     Mount canceled by user.
·     Device popped open.
·     Session terminated.
Obtain virtual media configuration
Obtain information about the virtual media configuration from the server.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/VirtualMedia/Oem/Public/Actions/VirtualMedia.Config
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/VirtualMedia/Oem/Public/Actions/VirtualMedia.Config
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#VirtualMediaConfig.VirtualMediaConfig",
    "@odata.id": "/redfish/v1/Managers/1/VirtualMedia/Oem/Public/Actions/VirtualMedia.Config",
    "@odata.type": "#VirtualMediaConfig.v1_0_0.VirtualMediaConfig",
    "Media": [
            "DomainName": "",
            "FromPath": "/Share1",
            "MediaType": "CD",
            "ServerAddress": "192.168.27.14",
            "ShareType": "nfs",
            "State": "Enabled",
            "UserName": ""
            "DomainName": "",
            "FromPath": "",
            "MediaType": "FD",
            "ServerAddress": "",
            "ShareType": "",
            "State": "Disabled",
            "UserName": ""
            "DomainName": "",
            "FromPath": "",
            "MediaType": "HD",
            "ShareType": "",
            "UserName": ""
    "MediaSupport": true,
    "Oem": {
        "Public": {
            "DomainName": "",
            "FromPath": "",
            "MediaType": "ALL",
            "ShareType": "",
            "UserName": ""
Response code: 200
Date type
@odata.context
String
Description information of the virtual media configuration.
@odata.id
String
Link to the virtual media configuration.
@odata.type
String
Type of virtual media configuration.
MediaSupport
Boolean
Remote media support.
Media.MediaType
String
Media type.
Media.ShareType
String
Mounting method..
Media.ServerAddress
String
Server address
Media.FromPath
String
Source path.
Media.UserName
String
Username.
Media.State
String
Supported options:
·     Enabled.
·     Disabled.
·     WrongSetting.
·     Mounting.
Media.DomainName
String
Domain name.
Configure virtual media settings
Configure virtual media settings on the server.
Privilege module
OemVmm
Request
PATCH https://device_ip/redfish/v1/Managers/manager_id/VirtualMedia/Oem/Public/Actions/VirtualMedia.Config
Request header:
X-Auth-Token:TOKEN
Request body:
    "MediaSupport":true,
"Media":[
     "MediaType":"CD",
     "State":"Enabled",
"ShareType":sharetype,
           "ServerAddress":ip,
"FromPath":"",
"UserName":"",
"Password":"",
"DomainName":DomainName
     "MediaType":"HD",
     "State":"Enabled",
"ShareType": sharetype,
           "ServerAddress":ip,
"FromPath":"",
"UserName":"",
"Password":"",
     "MediaType":"FD",
     "State":"",
           "ServerAddress": ip,
"FromPath":"",
"UserName":"",
"Password":"",
"Oem":{
"Public":{
     "MediaType":"ALL",
     "State":"",
"ShareType":"",
           "ServerAddress":"",
"FromPath":"",
"UserName":"",
Parameter
Value
device_ip
TOKEN
manager_id
MediaSupport
Remote media support, do not send other parameters when false.
·     Boolean. Options:
·     True.
·     False.
Media.MediaType
Type of the virtual media mounting.
·     CD.
·     HD.
·     FD.
Media.ShareType
Type of virtual media sharing.
·     nfs.
·     cifs.
·     http.
·     https.
Media.ServerAddress
Server address.
String.
Media.FromPath
Source path.
String. Up to 256 characters.
Media.UserName
Username.
When the sharing type is set to CIFS, this field can take effect.
If you set the type of virtual media sharing to CIFS, the username cannot be empty. Only letters, digits, underscores (_), and chinese are allowed.
Media.Password
Password.
String. Up to 32 characters.
Media.State
Virtual media state.
Supported options:
·     Enabled.
·     Disabled.
Media.DomainName
Domain name.
String. Up to 255 characters.
Oem.Public.MediaType
·     ALL.
Oem.Public.State
·     Enabled.
·     Disabled.
Oem.Public.ShareType
Share type.
·     nfs.
·     cifs.
·     http.
·     https.
Oem.Public.ServerAddress
Server address.
String.
Oem.Public.FromPath
Source path.
Oem.Public.UserName
Username.
When the sharing type is set to CIFS, this field can take effect,
Oem.Public.DomainName
Domain name.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/VirtualMedia/Oem/Public/Actions/VirtualMedia.Config
Request header:
X-Auth-Token:TOKEN
Request body:
    "Media": [
        "MediaType":"CD",
        "State":"Enabled",
        "ShareType":"cifs",
        "ServerAddress":"192.168.44.56",
        "FromPath":"/Share1/config/CD",
        "UserName":"admin",
        "Password":"Password@_",
        "DomainName":"www.h3c.com"
        "MediaType":"HD",
        "State":"Enabled",
        "ShareType":"cifs",
        "FromPath":"/Share1/config/HD",
        "UserName":"admin",
        "MediaType":"FD",
        "State":"Enabled",
        "ShareType":"cifs",
        "FromPath":"/Share1/config/FD",
        "UserName":"admin",
    "Oem":{
        "Public":{
            "MediaType":"ALL",
            "State":"Enabled",
            "ShareType":"cifs",
            "UserName":"admin",
Response:
    "Media": [
            "DomainName": "www.h3c.com",
            "FromPath": "/Share1/config/FD",
            "MediaType": "CD",
            "ServerAddress": "192.168.44.56",
            "ShareType": "cifs",
            "State": "Mounting",
            "UserName": "admin"
            "MediaType": "FD",
            "UserName": "admin"
            "MediaType": "HD",
            "UserName": "admin"
    "Oem": {
        "Public": {
            "MediaType": "ALL",
            "UserName": "admin"
Response code: 200
For information about the response fields, see "Obtain virtual media configuration."
Change history
Version
Change description
HDM2-2.12
Refreshed the command format example.
HDM2-2.08
Added support for http and https in the Media.ShareType and Oem.Public.ShareType fields.
Connect to virtual media
Connect the server to the virtual media.
Privilege module
OemVmm
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/VirtualMedia/Virtualmedia_id/Oem/Public/Actions/VirtualMedia.VmmControl
Request header:
X-Auth-Token:TOKEN
Request body:
nfs:
"VmmControlType":"Connect",
    "Image":"nfs://IP/Share/ERP.iso",
"Oem": {
        "Public": {
            "MediaIndex": value,
            "ImageType": image_type
cifs:
    "Image":"cifs://user:password@IP/img/ERP.iso",
"Oem": {
        "Public": {
            "MediaIndex": value
https:
"Image":"https://IP/img/ERP.iso",
"Oem": {
        "Public": {
            "MediaIndex": value
http:
"Image":"http://IP/img/ERP.iso",
"Oem": {
        "Public": {
            "MediaIndex": value
Parameter
Value
device_ip
TOKEN
manager_id
Virtualmedia_id
Supported options:
·     CD.
·     HD.
·     FD.
VmmControlType
Operation on virtual media.
Supported option is Connect.
Virtual media URI.
Supported protocols include:
·     nfs.
·     cifs.
·     http.
·     https.
The image name such as ERP.iso cannot exceed 1024 characters.
For information about the field length, see "Configure virtual media settings."
Oem.Public.MediaIndex
Media index.
Integer.
Image type.
String.
# Connect the server to the virtual media through NFS.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/VirtualMedia/CD/Oem/Public/Actions/VirtualMedia.VmmControl
Request header:
X-Auth-Token:TOKEN
Request body:
  "Image":"nfs://192.168.190.51/Share/image.iso",
"Oem": {
        "Public": {
            "MediaIndex": 1,
Response:
    "@odata.context": "/redfish/v1/$metadata#TaskCollection.TaskCollection",
    "@odata.type": "#TaskCollection.TaskCollection",
    "Members": [
            "@odata.id": "/redfish/v1/TaskService/Tasks/3"
    "Members@odata.count": 1,
    "Name": "Task Collection",
    "Oem": {
        "Public": {
            "TaskUniqueID": 1678656297
Response code: 202
# Connect the server to the virtual media through CIFS.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
"Image":"cifs://user123:pass123@192.168.190.51/img/image.iso",
"Oem": {
        "Public": {
            "MediaIndex": 1,
Response:
    "Members": [
    "Oem": {
        "Public": {
Response code: 202
# Connect the server to the virtual media through HTTP.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
"Image":"http://192.168.190.51/img/image.iso",
"Oem": {
        "Public": {
            "MediaIndex": 1,
Response:
    "Members": [
    "Oem": {
        "Public": {
Response code: 202
# Connect the server to the virtual media through HTTPS.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
"Image":"https://192.168.190.51/img/image.iso",
"Oem": {
        "Public": {
            "MediaIndex": 1,
Response:
    "Members": [
    "Oem": {
        "Public": {
Response code: 202
Data type
@odata.context
String
OData description of the task service resource model.
@odata.type
String
Type of the task service resource.
Name
String
Name of the task collection resource.
Members@odata.count
Integer
Number of currently running tasks.
Members
Task list.
@odata.id
String
Link to the specified task.
Oem.Public.TaskUniqueID
Integer
Unique ID of the specified task.
The server returns status code 202 for a successful operation.
Change history
Version
Change description
HDM3-1.15
The Oem.Public.ImageType field in the request body is available only in HDM3 1.15 and later versions and is not available in HDM2.
HDM2-2.08
Added support for http and https for connecting to virtual media.
Disconnect from virtual media
Disconnect the server from the virtual media.
Privilege module
OemVmm
Request
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
"VmmControlType": value
"Oem": {
        "Public": {
            "MediaIndex": value
Parameter
Value
device_ip
TOKEN
manager_id
Virtualmedia_id
Mount media type.
Supported options:
·     CD.
·     HD.
·     FD.
VmmControlType
Disconnect.
Disconnect: Disconnect virtual media.
Disconnect which virtual media.
This field is optional. The value range is 0 to 1.
By default, the command disables image with MediaIndex 0.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
    "VmmControlType":"Disconnect",
    "Oem":{
        "Public":{
            "MediaIndex":1
Response:
    "Members": [
            "@odata.id": "/redfish/v1/TaskService/Tasks/2"
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
@odata.type
String
Name
String
Members@odata.count
Integer
Members
Task list.
@odata.id
String
Integer
Privilege module
OemVmm
Request
POST https://device_ip/redfish/v1/Managers/manager_id/VirtualMedia/Oem/Public/Actions/VirtualMedia.StopMount
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
manager_id
System resource ID.
This field is 1 for all current models.
POST https://192.168.33.66/redfish/v1/Managers/1/VirtualMedia/Oem/Public/Actions/VirtualMedia.StopMount
Request header:
X-Auth-Token:TOKEN
Response:
  "Oem": {
    "Public": {
  "error": {
    "@Message.ExtendedInfo": [
        "@odata.type": "#Message.v1_1_1.Message",
        "Message": "Successfully Completed Request",
        "MessageArgs": [],
        "MessageId": "Base.1.8.1.Success",
        "MessageSeverity": "OK",
        "Resolution": "None"
    "code": "Base.1.8.1.Success",
    "message": "Successfully Completed Request"
Response code: 200
Format
Error message extension information.
@odata.type
String
OData description information of message resources.
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Information arguments.
MessageSeverity
String
Severity. Options include  OK, Warning, and Critical.
Resolution
String
Recommended actions.
Obtain all operation log collection information
Obtain information about all operation logs from the server.
Privilege module
OemSystemAudit
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/OperationLog
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/OperationLog
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#OperationLogCollection.OperationLogCollection",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/OperationLog",
    "@odata.type": "#OperationLogCollection.OperationLogCollection",
    "Description": "Collection of entries for this operation log",
    "Members": [
            "@odata.id": "/redfish/v1/Managers/1/LogServices/ConfigurationLog/Entries/6"
            "@odata.id": "/redfish/v1/Managers/1/LogServices/AuditLog/Entries/5"
            "@odata.id": "/redfish/v1/Managers/1/LogServices/ConfigurationLog/Entries/4"
            "@odata.id": "/redfish/v1/Managers/1/LogServices/ConfigurationLog/Entries/3"
            "@odata.id": "/redfish/v1/Managers/1/LogServices/ConfigurationLog/Entries/2"
            "@odata.id": "/redfish/v1/Managers/1/LogServices/ConfigurationLog/Entries/1"
    "Members@odata.count": 6,
    "Name": "Operate Log Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of all operation log collection resource models.
@odata.id
String
Link to all operation log collection resource.
@odata.type
String
Type of all operation log collection resource.
Name
String
Name of all operation log collection resource.
Members@odata.count
Integer
Number of all operation log resource.
Members
List of all operation log resource.
@odata.id
String
Link to operation log resource node.
Obtain log service collection information
Obtain information about all current log service resources from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/LogServices
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/LogServices
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Managers/Members/1/LogServices/$entity",
    "@odata.id": "/redfish/v1/Managers/1/LogServices",
    "@odata.type": "#LogServiceCollection.LogServiceCollection",
"Actions": {
"Oem": {
            "Public": {
                    "#LogService.ClearOperationLog": {
                      "target": "/redfish/v1/Managers/1/LogServices/Actions/Oem/Public/LogService.ClearOperationLog"
                "#LogService.ExportOperationLog": {
                    "target": "/redfish/v1/Managers/1/LogServices/Actions/Oem/Public/LogService.ExportOperationLog"
    "Description": "Collection of LogServices resource",
    "Members": [
            "@odata.id": "/redfish/v1/Managers/1/LogServices/AuditLog"
            "@odata.id": "/redfish/v1/Managers/1/LogServices/FirmwareUpdateLog"
            "@odata.id": "/redfish/v1/Managers/1/LogServices/ConfigurationLog"
            "@odata.id": "/redfish/v1/Managers/1/LogServices/HardwareUpdateLog"
    "Members@odata.count": 4,
    "Name": "LogServices Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the log service collection resource model.
@odata.id
String
Link to the log service collection resource.
@odata.type
String
Type of the log service collection resource.
Name
String
Name of the log service collection resource.
Members@odata.count
Integer
Number of log service resources.
Members
List of log service resources.
@odata.id
String
Link to a log service resource.
Actions.Oem.Public.#LogService.ExportOperationLog
Object
Link to export operation logs.
Actions.Oem.Public.#LogService.ClearOperationLog
Object
Link to clear operation logs.
Obtain log service information
Obtain information about a specific log service resource from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/LogServices/LogService_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
LogServices_id
ID of the log service resource.
You can obtain available log service resource IDs from log service collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/LogServices/ConfigurationLog
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Managers/Members/1/LogServices/Members/$entity",
    "@odata.id": "/redfish/v1/Managers/1/LogServices/ConfigurationLog",
    "@odata.type": "#LogService.v1_2_0.LogService",
    "DateTime": "2022-02-19T14:59:34+08:00",
    "DateTimeLocalOffset": "UTC+08:00",
    "Description": "Managers ServiceLog Instance for this Computer System",
    "Entries": {
        "@odata.id": "/redfish/v1/Managers/1/LogServices/ConfigurationLog/Entries"
    "Id": "ConfigurationLog",
    "LogEntryType": "Multiple",
    "MaxNumberOfRecords": 1000,
    "Name": "ConfigurationLog",
    "Oem": {
        "Public": {
    "ServiceEnabled": true,
    "Status": {
        "Health": "OK",
        "State": "Enabled"
Response code: 200
Data type
@odata.context
String
OData description of the log service resource model.
@odata.id
String
Link to the log service resource.
@odata.type
String
Type of the log service resource.
Id
String
Name
String
Name of the log service resource.
String
Description of the log service resource.
MaxNumberOfRecords
Integer
Maximum number log entries that can be recorded in the log service resource.
DateTime
String
System time of the log service resource.
DateTimeLocalOffset
String
Time zone of the log service resource.
ServiceEnabled
String
Enabling status of the log service resource. Supported options:
·     trueEnabled.
·     falseDisabled.
Entries
Object
Link to the log collection resource.
Obtain log entry collection information
Obtain information about all current log entries of a log service from the server.
Privilege module
OemSystemAudit
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/LogServices/LogServices_id/Entries
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
LogServices_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/LogServices/ConfigurationLog/Entries
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#LogEntryCollection.LogEntryCollection",
    "@odata.id": "/redfish/v1/Managers/1/LogServices/ConfigurationLog/Entries",
    "@odata.type": "#LogEntryCollection.LogEntryCollection",
    "Description": "Collection of entries for this log service",
    "Members": [
    "Members@odata.count": 5,
    "Name": "Log Service Entries Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the log entry collection resource model.
@odata.id
String
Link to the log entry collection resource.
@odata.type
String
Type of the log entry collection resource.
Name
String
Name of the log entry collection resource.
Members@odata.count
Integer
Number of log entry resources.
Members
List of log entry resources.
@odata.id
String
Link to a log entry resource.
Obtain log entry information
Obtain information about a specific log entry resource from the server.
Privilege module
OemSystemAudit
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/LogServices/LogServices_id/Entries/Entry_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
LogServices_id
Entry_id
ID of the log entry resource.
You can obtain available log entry resource IDs from log entry collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/LogServices/AuditLog/Entries/3
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Systems/Members/1/LogServices/Log1/Entries/Members/$entity",
    "@odata.id": "/redfish/v1/Managers/1/LogServices/ConfigurationLog/Entries/3",
    "@odata.type": "#LogEntry.v1_7_0.LogEntry",
    "Created": "2022-02-19T12:11:18+08:00",
    "Description": "Instance of entries for this log service",
    "EntryType": "Multiple",
    "Id": 3,
    "Message": "Remote media settings configured successfully. Remote IP: 192.168.17.17, soure path: /Share1, server type: nfs, media type: CD/DVD.",
    "Modified": "2022-02-19T12:11:18+08:00",
    "Oem": {
        "Public": {
            "Address": "192.168.17.17",
            "Hostname": "HDM",
            "Interface": "redfish",
            "User": "admin"
Response code: 200
Data type
@odata.context
String
OData description of the log entry resource model.
@odata.id
String
Link to the log entry resource.
@odata.type
String
Type of the log entry resource.
Name
String
Name of the log entry resource.
Created
String
Creation time of the log entry.
EntryType
String
Type of the log entry.
Message
String
Description of the log entry.
Modified
String
Modification time.
Id
Integer
Log ID.
Oem.Public.Address
String
Host address.
Oem.Public.Hostname
String
Host name.
Oem.Public.Interface
String
Interface type. Supported options:
·     N/AUnknown session type.
·     LAN.
·     SERIAL.
·     SERIAL_TERMINAL.
·     KCS.
·     BT.
·     IPMB.
·     WEB.
·     USB
·     USB_SPECIAL.
·     SSIF.
·     KVM.
·     CLI.
·     SNMP.
Oem.Public.User
String
Username.
Export operation log information
Export operation log information from the server.
Privilege module
OemSystemAudit
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/LogServices/Actions/Oem/Public/LogService.ExportOperationLog
Request header:
X-Auth-Token:TOKEN
Request body:
Local export.
    "Type":"URI",
    "Content": "/tmp/web/dump.tar.gz"
Remote export.
Cifs or sftp
"Type":"URI",
"Content": "sftp://username:password@10.10.10.191/usr/dump.tar.gz"
http, tftp, nfs, or https
    "Type":"URI",
"Content": "http://ip/filename",
"Oem": {
    "Public": {
        "ScriptName":"1.php"
Parameter
Value
device_ip
TOKEN
manager_id
URI.
String.
Content
Export path.
See "Others."
Oem.Public.ScriptName
Script file name.
String.
This field is required if you use the HTTP or HTTPS to export the file.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/LogServices/Actions/Oem/Public/LogService.ExportOperationLog
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
Request body:
Local export.
    "Type":"URI",
    "Content": "/tmp/web/OperateLog.csv"
Remote export.
"Type":"URI",
"Content": "sftp://username:password@10.10.10.191/usr/OperateLog.csv"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
        "code":"Base.1.8.1.Success",
        "message":"Successfully Completed Request"
Response code: 200
Data type
code
String
String of a specific message ID in the message registry.
message
String
Readable error message corresponding to the message in the message registry.
Extended information of the message.
@odata.type
String
OData description of the message resource.
MessageId
String
Message ID.
Message
String
Details of the message.
MessageArgs
Array
Message arguments.
MessageSeverity
String
Severity level. Supported options:
·     OK.
·     Warning.
·     Critical.
Resolution
String
Recommended actions for the error.
Change history
Version
Change description
HDM2-2.04
Added the error node before Message.ExtendedInfo and added the code and message fields under the error node.
Clear operation log information
Clear operation log information from the server.
Privilege module
Login
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/LogServices/Actions/Oem/Public/LogService. ClearOperationLog
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
ID of the manager resource.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/LogServices/Actions/Oem/Public/LogService.ClearOperationLog
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Collect SDS log entry information
Collect and package SDS logs, and place them in the user-specified directory.
Privilege module
OemSystemAudit
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/Actions/Oem/Public/Manager.Dump
Request header:
X-Auth-Token:TOKEN
Request body:
"StartTime":time,
"EndTime": time,
"Name":name,
"Telephone":phone,
"EmailAddress":address
"Type":"URI",
"Content": content,
"LogType":logtype,
"Oem": {
"Public": {
"ScriptName":"xxxxx"
Content:
// Local export, only supports /mnt/sdmmc0p1/sds/bmc/filename:
/mnt/sdmmc0p1/sds/bmc/dump.tar.gz
// Remote export:
sftp://username:password@ip/usr/dump.tar.gz
Parameter
Value
device_ip
TOKEN
manager_id
StartTime
SDS log start time.
String. For example: 2017-04-05.
When StartTime and EndTime are in the request body, collect SDS logs for that time period. If both times are absent, collect all SDS logs.
EndTime
SDS log end time.
String.
Name
Name of the contact person.
(Not provided externally, for page use only).
String.
Telephone
Phone number of the contact person.
String.
EmailAddress
Email address of the contact person.
String.
Export file method.
URI
Content
Link to the SDS log collection.
See "Others." This interface only supports /mnt/sdmmc0p1/sds/bmc/filename,
Special characters except commas (,) will be ignored.
LogType
Download log type.
·     EventLog.
If this parameter is not specified, all logs will be downloaded by default.
Script file name.
String.
This field is required if you use HTTP or HTTPS to export the file.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/Actions/Oem/Public/Manager.Dump
Request header:
X-Auth-Token:TOKEN
Request body:
"StartTime":"2022-04-05",
"EndTime":"2022-04-20",
"Type":"URI",
"Content": "/mnt/sdmmc0p1/sds/bmc/dump.tar.gz"
Response:
    "Members": [
            "@odata.id": "/redfish/v1/TaskService/Tasks/1"
    "Oem": {
        "Public": {
            "FileName": "dump__20220219T082103-0400.tar.gz",
Response code: 200
Data type
@odata.context
String
@odata.type
String
Name
String
Name of the task service resource.
Members@odata.count
String
Members
Task list.
@odata.id
String
Oem.Public.FileName
String
Filename.
Integer
Change history
Version
Change description
HDM2-1.54
Modified description of the Content field.
Download BMC file
Use PostMan to display the content of the specified BMC file. Users can download the file using Postman or in combination with the curl command.
As a best practice, for large SDS files, consider using the remote export method.
Privilege module
ConfigureComponents
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/Actions/Oem/Public/Manager.GeneralDownload
Request header:
X-Auth-Token:TOKEN
Request body:
  "TransferProtocol":value,
"Content":path
Parameter
Value
device_ip
TOKEN
manager_id
ID of the manage resource.
TransferProtocol
Supported protocols.
String. Only includes HTTPS.
Content
File download content.
String. See "Others."
This interface supports file downloads from the following directories:
1.     /conf/secure_erase.
2.     /tmp/web.
3.     /mnt/sdmmc0p1/sds/bmc.
4.     /mnt/sdmmc0p4/bsod.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/Actions/Oem/Public/Manager.GeneralDownload
Request header:
X-Auth-Token:TOKEN
Request body:
Local export.
    "TransferProtocol":"HTTPS",
    "Content":"/tmp/web/web.pem"
Response:
Display file content.
Response code: 200
Obtain VNC information
Obtain information about the VNC service.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/VncService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/VncService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#VncService.VncService(ComplexityCheck,NumberOfActivatedSessions,SessionTimeoutMinutes,MaximumNumberOfSessions)",
    "@odata.id": "/redfish/v1/Managers/1/VncService",
    "@odata.type": "#VncService.v1_0_0.VncService",
    "ComplexityCheck": false,
    "MaximumNumberOfSessions": 2,
    "NumberOfActivatedSessions": 0,
    "Oem": {
        "Public": {
    "Password": null,
    "SessionTimeoutMinutes": 10
Response code: 200
Data type
@odata.context
String
OData description of the VNC information resource model.
@odata.id
String
Link to the VNC information resource.
@odata.type
String
Type of the VNC information resource.
Integer
Maximum number of VNC sessions.
Integer
Number of current VNC sessions.
ComplexityCheck
Boolean
Enabling status of VNC password complexity check.
Integer
Session idle timeout for the VNC service.
Password
null
Password.
This field displays null.
Edit VNC settings
Edit settings of the VNC service for the server.
Privilege module
OemKvm
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/VncService
Request header:
X-Auth-Token:TOKEN
Request body:
    "SessionTimeoutMinutes": 6,
    "Password":"Pass1234"
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
Session idle timeout for the VNC service, in minutes.
Integer.
Value range: 5 to 30.
ComplexityCheck
Enable or disable VNC password complexity check.
·     With VNC password complexity check disabled, the password must be a case-sensitive string of 1 to 8 characters. Only letters, digits, spaces and special characters `~!@#$%^&*()_+-=[]\{}|;':",./<>? are allowed.
·     With VNC password complexity check enabled, the password must be a case-sensitive string of 8 characters. Only letters, digits, spaces and special characters `~!@#$%^&*()_+-=[]\{}|;':",./<>? are allowed. The password must contain at least two of the following categories: Uppercase letters, lowercase letters, and digits. The password must contain at least one space or special character.
Boolean.
Password
Password.
String. Maximum password length allowed is 8 characters.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/VncService
Request header:
X-Auth-Token:TOKEN
Request body:
    "SessionTimeoutMinutes":10,
    "Password":"root"
Response:
    "Oem": {
        "Public": {
    "Password": null,
Response code: 200
Obtain KVM information
Obtain information about the KVM service.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/KvmService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/KvmService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#KvmService.KvmService",
    "@odata.id": "/redfish/v1/Managers/1/KvmService",
"@odata.type": "#KvmService.v1_0_0.KvmService",
"ActivatedSessionsType": "Shared",
"H5ActivatedSessionsType": "Private",
"H5EncryptionEnabled": true,
    "MaximumNumberOfSessions": 4,
"Oem": {
"Public": {
"PersistentUSBConnectionEnabled": false,
"SessionTimeoutMinutes": 13
Response code: 200
Data type
@odata.context
String
OData description of the KVM resource model.
@odata.id
String
Link to the KVM resource.
@odata.type
String
Type of the KVM resource.
String
KVM (JAVA KVM) session type. Supported options:
·     Shared.
·     Private.
String
H5 KVM session type. Supported options:
·     Shared.
·     Private.
H5EncryptionEnabled
Boolean
HDM2: H5 KVM encryption enabled.
HDM3: Reserved field. Whether encryption is enabled depends on KVM settings.
Integer
Maximum number of KVM sessions.
Integer
Number of current KVM sessions.
Boolean
HDM2: Enabling status of continuous connection to the virtual mouse.
HDM3: Fixed at the false option.
Integer
Session idle timeout for the KVM service.
Edit KVM settings
Edit settings of the KVM service for the server.
Privilege module
OemKvm
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/KvmService
Request header:
X-Auth-Token:TOKEN
Request body:
      "SessionTimeoutMinutes": SessionTimeoutMinutes_value,
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
Session idle timeout for the KVM service, in minutes.
Integer.
KVM session type.
·     Shared.
·     Private.
·     Shared.
·     Private.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/KvmService
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
    "H5EncryptionEnabled": false,
    "Oem": {
        "Public": {
            "Description": "Success"
10
Response code: 200
For information about the response fields, see "Obtain KVM information."
Obtain serial port collection information
Obtain information about all serial ports from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/SerialInterfaces
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET http://192.168.25.83/redfish/v1/Managers/1/SerialInterfaces
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#SerialInterfaceCollection.SerialInterfaceCollection",
    "@odata.id": "/redfish/v1/Managers/1/SerialInterfaces",
"@odata.type": "#SerialInterfaceCollection.SerialInterfaceCollection",
"Description": "Collection of Serial Interfaces for this System",
    "Members": [
            "@odata.id": "/redfish/v1/Managers/1/SerialInterfaces/IPMI-SOL"
    "Name": "Serial Interface Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the serial port collection resource model.
@odata.id
String
Link to the serial port collection resource.
@odata.type
String
Type of the serial port collection resource.
String
Description of the serial port collection resource.
Members
Array
Links to serial port resources.
Members@odata.count
Integer
Number of serial port resources.
Name
String
Name of the serial port collection resource.
Obtain serial port information
Obtain information about a specific serial port resource from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/SerialInterfaces/serialinterface_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
serialinterface_id
ID of the serial port resource.
You can obtain available serial port resource IDs from serial port collection information.
Method and URL:
GET http://192.168.18.18/redfish/v1/Managers/1/SerialInterfaces/IPMI-SOL
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#SerialInterface.SerialInterface",
    "@odata.id": "/redfish/v1/Managers/1/SerialInterfaces/IPMI-SOL",
    "@odata.type": "#SerialInterface.v1_1_8.SerialInterface",
    "BitRate": "115200",
    "DataBits": "8",
    "Description": "IPMI Serial over LAN",
    "FlowControl": "Hardware",
    "Id": "IPMI-SOL",
    "InterfaceEnabled": true,
"Name": "IPMI-SOL",
"Oem": {
        "Public": {
    "Parity": "None",
    "StopBits": "1"
Response code: 200
Data type
@odata.context
String
OData description of the serial port resource model.
@odata.id
String
Link to the serial port resource.
@odata.type
String
Type of the serial port resource.
BitRate
String
Baud rate. Supported options:
·     1200.
·     2400.
·     4800.
·     9600.
·     19200.
·     38400.
·     57600.
·     115200.
·     230400.
DataBits
String
Number of data bits. Supported options:
·     5.
·     6.
·     7.
·     8.
String
Description of the serial port.
FlowControl
String
Flow control method. Supported options:
·     None.
·     Software.
·     Hardware.
Id
String
ID of the serial port.
InterfaceEnabled
Boolean
Enabling status of the serial port.
Name
String
Name of the serial port.
Parity
String
Parity bit to be sent with the data bits for transmission error detection. Supported options:
·     None.
·     Even.
·     Odd.
·     Mark.
·     Space.
StopBits
String
Number of stop bits used to indicate the end of a serial data packet. Supported options:
·     1.
·     2.
Obtain LLDP service information
Obtain information about the LLDP service.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/LldpService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/LldpService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context":"/redfish/v1/$metadata#LldpService.LldpService",
    "@odata.id":"/redfish/v1/Managers/1/LldpService",
    "@odata.type":"#LldpService.v1_0_0.LldpService",
    "Description":"Lldp Service",
    "Id":"LldpService",
    "LLDP":[
            "ChassisMac":"N/A",
            "ChassisName":"N/A",
            "EthIndex":"eth0",
            "PortDesc":"N/A",
            "PortIfName":"N/A",
            "VlanId":4294967295
            "ChassisMac":"N/A",
            "EthIndex":"eth1",
            "PortDesc":"N/A",
            "PortIfName":"N/A",
            "VlanId":4294967295
    "LldpEnabled":true,
    "Name":"LldpService",
    "Oem":{
        "Public":{
            "CompletionCode":0,
    "WorkMode":"TxRx"
Response code: 200
Data type
@odata.context
String
OData description of the LLDP service resource model.
@odata.id
String
Link to the LLDP service resource.
@odata.type
String
OData description of the LLDP service resource.
String
Function description of the LLDP service resource interface.
Id
String
ID of the LLDP service.
ChassisMac
String
MAC address of the connected switch.
ChassisName
String
System name of the connected switch.
EthIndex
String
Network port of the server for receiving LLDP frames.
PortDesc
String
Name of the uplink switch port.
PortIfName
String
Number of the uplink switch port.
VlanId
Integer
VLAN ID.
LldpEnabled
Boolean
Enabling status of LLDP frame sending.
WorkMode
String
LLDP operating mode. Supported options:
·     Rx—Receive mode
·     TxTrasmit mode.
·     TxRxTransmit and receive mode.
Name
String
Name of the LLDP service.
Change history
Version
Change description
HDM2-1.59
·     Changed the Rx/Tx option of the WorkMode field to TxRx (compatible with Rx/Tx), and added the Tx option.
·     Changed the description of the LldpEnabled field from Enabling status of LLDP frame sending to Enabling status of LLDP.
Edit LLDP service settings
Edit settings of the LLDP service for the server.
Privilege module
ConfigureComponents
Locking type of the associated system
BMC configuration locking
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/LldpService
Request header:
X-Auth-Token:TOKEN
If-Match:ifmatch_value
Request body:
    "LldpEnabled": true,
    "WorkMode": "TxRx"
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
Entity tag (ETag) that uniquely represents the requested resource.
To obtain the entity tag value of a resource, send a GET request to it and then obtain the ETag value from the response header.
LldpEnabled
Enable or disable LLDP frame sending.
Boolean. Supported options:
·     true.
·     false.
WorkMode
·     Rx—Receive mode.
·     TxTrasmit mode.
String.
Method and URL:
PATCH http://192.168.18.18/redfish/v1/Managers/1/LldpService
Request header:
X-Auth-Token:TOKEN
Request body:
.."LldpEnabled": true,
  "WorkMode": "TxRx"
Response:
    "Id":"LldpService",
    "LLDP":[
            "ChassisMac":"N/A",
            "EthIndex":"eth0",
            "PortDesc":"N/A",
            "PortIfName":"N/A",
            "VlanId":4294967295
            "ChassisMac":"N/A",
            "EthIndex":"eth1",
            "PortDesc":"N/A",
            "PortIfName":"N/A",
            "VlanId":4294967295
    "LldpEnabled":true,
    "Oem":{
        "Public":{
            "CompletionCode":0,
    "WorkMode":"TxRx"
Response code: 200
For information about the response fields, see "Obtain LLDP service information."
Change history
Version
Change description
HDM2-1.59
Changed the description of the LldpEnabled field from Enabling status of LLDP frame sending to Enabling status of LLDP, and added the WorkMode field.
HDM2-1.53
Added the locking type of the associated system.
Obtain wireless information
Obtain information about the wireless resource. This interface is not available for X18000 products. HDM3 does not support this interface.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/Wireless
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.33.120/redfish/v1/Managers/1/Oem/Public/Wireless
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context":"/redfish/v1/$metadata#Wireless.Wireless",
    "@odata.id":"/redfish/v1/Managers/1/Oem/Public/Wireless",
    "@odata.type":"#Wireless.v1_0_0.Wireless",
    "Clients":[
    "DHCPServers":[
            "DHCPAddrEnd":"192.168.199.254",
            "DHCPAddrStart":"192.168.199.2",
            "IPAddress":"192.168.199.1",
            "Id":0
    "IsSameSegment":false,
    "Oem":{
        "Public":{
            "CompletionCode":0,
            "Description":"Success"
    "Ssids":[
            "ClientMaxNum":2,
            "EncryptionMode":"None",
            "Id":0,
            "Name":"BMC_WIFI_162022",
            "Password":""
    "Status":{
        "Health":"OK",
        "State":"Absent"
    "USBDeviceEnabled":true,
    "WlanChannel":11,
    "WlanCurrentState":"Closed",
    "WlanEnabled":false,
    "WlanTimeout":1
Response code: 200
Data type
@odata.context
String
OData description of the wireless resource model.
@odata.id
String
Link to the wireless resource.
@odata.type
String
Type of the wireless resource.
WlanChannel
Integer
Wireless channel.
The default wireless channel is 11.
WlanCurrentState
String
Current state of the wireless service. Supported options:
·     Open.
·     Closed.
WlanEnabled
Boolean
Enable or disable the wireless service.
Supported options:
·     true.
·     false.
WlanTimeout
Integer
Scheduled time when the wireless service will be disabled, in hours.
Value range: 0 to 200. If this field is set to 0, the wireless service will not be disabled.
IsSameSegment
Boolean
Wireless same network segment check.
Clients.ClientId
Integer
ID of the client.
Clients.MacAddress
String
MAC address of the client.
Clients.IPAddress
String
IPv4 address of the client.
Clients.HostName
String
Host name of the client.
DHCPServers.Id
Integer
ID of the DHCP server address pool for the wireless service.
DHCPServers.IPAddress
String
IP addresses of the DHCP servers.
DHCPServers.DHCPAddrStart
String
Start address of the DHCP server address pool.
DHCPServers.DHCPAddrEnd
String
End address of the DHCP server address pool.
Ssids.ClientMaxNum
Integer
Maximum number of clients that can connect to the SSIDs.
Ssids.EncryptionMode
String
Encryption mode of the wireless service. Supported options:
·     None.
·     WPA2-PSK.
Ssids.Id
Integer
ID of the wireless service.
Ssids.Name
String
Name of the wireless service.
Ssids.Password
String
Password of the wireless service.
Status.Health
String
Wireless health status.
Status.State
String
Presence status of the wireless device. Supported options:
·     Enabled—Present.
·     Absent—Not present.
USBDeviceEnabled
Boolean
Enable status of USB physical interface.
Change history
Version
Change description
HDM3-1.14
Edit wireless settings
Edit settings for the wireless service. This interface is not available for X18000 products. HDM3 does not support this interface.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/Wireless
Request header:
X-Auth-Token:TOKEN
Request body:
    "DHCPServers": [
            "DHCPAddrEnd": "192.168.155.189",
            "DHCPAddrStart": "192.168.155.35",
            "IPAddress": "192.168.155.30"
    "Ssids": [
            "EncryptionMode": "WPA2-PSK",
            "Name": "test",
            "Password": "123456789"
"USBDeviceEnabled": true,
    "WlanEnabled": true,
    "WlanTimeout": 0
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
WlanEnabled
Boolean
Enable the wireless service.
WlanTimeout
Integer
String
String
String
String
·     None.
·     WPA2-PSK.
Ssids.Name
String
Name of the wireless service. Default name: BMC_WIFI_BMC dedicated network port MAC address last 6 digits.
A string of 1 to 31 characters. Supporting only letters, numbers, periods (.), hyphens (-), and underscores (_), case-sensitive.
Ssids.Password
String
Password of the wireless service. It is required when the encryption method is encrypted
A string of 8 to 63 characters.
Supporting only letters, numbers, spaces, and special characters `~!@#\$%^&*()_+-=[]\{}|;':,./<>?, case-sensitive.
USBDeviceEnabled
Boolean
USB physical interface enable status.
When false is displayed, it means other parameters are not issued.
Method and URL:
PATCH https://192.168.30.85/redfish/v1/Managers/1/Oem/Public/Wireless
Request header:
X-Auth-Token:TOKEN
If-Match: W/"1043aaa69f0ade5f8a7a7e0d987a274b"
Request body:
    "DHCPServers":[
    "Ssids":[
            "Password":""
    "WlanTimeout":1,
Response:
    "Clients":[
    "DHCPServers":[
            "Id":0
    "Oem":{
        "Public":{
            "CompletionCode":0,
    "Ssids":[
            "ClientMaxNum":2,
            "Id":0,
            "Password":""
    "Status":{
        "Health":"OK",
        "State":"Absent"
    "WlanChannel":11,
    "WlanTimeout":1
Response code: 200
For information about the response fields, see "Obtain wireless information."
Change history
Version
Change description
HDM3-1.14
HDM2-1.53
Import the BIOS, BMC, and RAID controller settings
Import the BIOS, BMC, and RAID controller settings.
Privilege module
ConfigureUsers
BIOS configuration lock (when importing BIOS configuration), BMC configuration lock (when importing BMC configuration), hardware configuration lock (when importing RAID configuration)
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/Actions/Oem/Public/Manager.ImportConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
·     Local import:
Use this interface after transferring the file to the /tmp/web/ directory. For more information, see "Upload BMC file."
"Type":"URI",
"Content": "/tmp/web/filename",
"Oem": {
       "Public": {
           "ConfigType":type
·     Remote import:
¡     CIFS or SFTP:
   "Type":"URI",
"Content":"cifs://username:password@ip/filename",
"Oem": {
       "Public": {
           "ConfigType":type
¡     HTTP, TFTP, NFS, or HTTPS:
   "Type":"URI",
"Content":"http://ip/filename",
"Oem": {
       "Public": {
           "ConfigType":type
Parameter
Value
device_ip
TOKEN
manager_id
Method to import the configuration file.
URI.
Content
Path of the source configuration file.
See "Others."
Oem.Public.ConfigType
Type of the configuration.
·     BMC.
·     BIOS.
·     RAID.
Method and URL:
POST https://192.168.188.188/redfish/v1/Managers/1/Actions/Oem/Public/Manager.ImportConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
    "Type":"URI",
    "Content": "nfs://192.168.20.177/Share1/bios-config.json",
    "Oem": {
        "Public": {
            "ConfigType":"BIOS"
Response:
  "Members": [
  "Oem": {
    "Public": {
      "Description": "Success",
Response code: 202
Data type
@odata.context
String
OData description of the import TaskService.
@odata.type
String
Type of the import TaskService.
Members@odata.id
String
Link to the import TaskService.
String
Unique ID of the import TaskService.
Change history
Version
Change description
HDM2-1.53
Export the BIOS, BMC, and RAID controller settings
Export the BIOS, BMC, and RAID controller settings.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/Actions/Oem/Public/Manager.ExportConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
Local import:
"Type":"URI",
"Oem": {
        "Public": {
            "ConfigType":type,
            "ExportPasswordEnabled":true
Remote import
cifs or sftp:
    "Type":"URI",
"Oem": {
        "Public": {
            "ConfigType":type,
http, tftp, nfs, or https:
    "Type":"URI",
"Oem": {
        "Public": {
            "ConfigType":type,
            "ScriptName":"1.php",
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
manager_id
Method to export the configuration file.
URI.
Content
Destination configuration file path.
See "Others."
·     HDM.
·     BIOS.
·     RAID.
Script file name.
String.
This field is required if you use HTTP or HTTPS to export the configuration file.
Oem.Public.ExportPasswordEnabled
Whether to export the local user passwords.
Boolean.
Method and URL:
POST https://192.168.188.188/redfish/v1/Managers/1/Actions/Oem/Public/Manager.ExportConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
    "Type":"URI",
    "Oem": {
        "Public": {
            "ConfigType":"BIOS"
Response:
  "Members": [
  "Oem": {
    "Public": {
Response code: 202
Data type
@odata.context
String
OData description of the exported TaskService.
@odata.type
String
Type of the exported TaskService.
Members@odata.id
String
Link to the generated Task.
Integer
Unique ID for the exported TaskService.
Change history
Version
Change description
HDM2-2.04
HDM3-2.03
Added the Oem.Public.ExportPasswordEnabled field.
Obtain trusted password module status configuration
Obtain information about TPM/TCM configuration.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/TrustedModuleConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET
https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/TrustedModuleConfiguration
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#TrustedModuleConfiguration.TrustedModuleConfiguration",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/TrustedModuleConfiguration",
    "@odata.type": "#TrustedModuleConfiguration.v1_0_0.TrustedModuleConfiguration",
    "Description": "Get trusted module configuration.",
    "Id": "TrustedModule Configuration",
    "Name": "TrustedModule Configuration",
    "Oem": {
        "Public": {
    "State": "NotSupported",
    "Type": null
Response code: 200
Data type
@odata.context
String
OData description of the trusted password module resource model.
@odata.id
String
Link to the trusted password module resource.
@odata.type
String
Type of the trusted password module resource.
String
Name of the trusted password module. Supported options:
·     TPM.
·     TCM.
String
State of the trusted password module. Supported options:
·     Enabled.
·     Disabled.
·     Absent.
·     NotSupported.
Obtain firewall configuration information
Obtain firewall configuration information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/FirewallRules
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.77.77/redfish/v1/Managers/1/Oem/Public/FirewallRules
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#FirewallRules.FirewallRules",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/FirewallRules",
"@odata.type": "#FirewallRules.v1_0_0.FirewallRules",
"Actions": {
        "#Firewall.AddRules": {
"target":
"redfish/v1/Managers/manager_id/Actions/Oem/Public/Firewall.AddRules"
"#Firewall.DeleteRules": {
"target":
"redfish/v1/Managers/manager_id/Actions/Oem/Public/Firewall.DeleteRules"
    "BlacklistRules": [
            "EndDateTime": "2019-02-15T20:21:36+08:00",
            "EndIPAddress": "10.33.255.255",
            "EndPort":6567,
            "MACAddress": "C4:36:6B:3E:7C:2B",
            "MemberId": "1",
            "StartDateTime": "2019-02-14T20:21:36+08:00",
            "StartIPAddress": "10.33.40.0",
            "StartPort": 5677,
            "Protocol": ["UDP","TCP"]
            "EndIPAddress": "10.99.255.255",
            "EndPort":6567,
            "MACAddress": "C4:36:6B:3E:7A:2B",
            "MemberId": "2",
            "StartIPAddress": "10.99.40.0",
              "StartPort": 5677,
            "EndDateTime": null,
            "EndIPAddress": "11.99.255.255",
            "EndPort":6567,
            "MACAddress": "C6:36:6B:3E:7A:2B",
            "MemberId": "3",
            "StartDateTime": null,
            "StartPort": 5677,
    "BlacklistRules@odata.count": 3,
    "Name": "FirewallConfig Collection",
"Oem": {
    "Public": {
    "WhitelistRules": [
            "EndIPAddress": "192.168.30.255",
            "EndPort":6567,
            "MemberId": "1",
            "StartIPAddress": "192.168.30.40",
            "StartPort": 5677,
            "EndPort":6567,
            "MemberId": "2",
            "StartPort": 5677,
    "WhitelistRules@odata.count": 2
Response code: 200
Data type
@odata.context
String
OData description of the specified role resource model.
@odata.id
String
Link to the specified role resource.
@odata.type
String
Type of the specified role resource.
BlacklistRules
Object or array
List of members on the blacklist.
WhitelistRules
Object or array
List of members on the whitelist.
MemberId
String
ID of the rule.
StartIPAddress
Boolean
Starting IP address for this rule.
EndIPAddress
String
Ending IP address for this rule.
MACAddress
String
MAC address.
StartDateTime
String
Start time of the rule.
EndDateTime
String
End time of the rule.
EndPort
Integer
Ending port number for this rule.
Null indicates this field is not set.
StartPort
Integer
Starting port number for this rule.
Protocol
Array
Supported protocols for this rule.
Supported options:
·     TCP
·     UDP
Add firewall rule settings
Add firewall configuration rule settings.
Privilege module
OemSecurityMgmt
Request
Method and URL:
https://device_ip/redfish/v1/Managers/manager_id/Actions/Oem/Public/Firewall.AddRules
Request header:
X-Auth-Token:TOKEN
Request body:
    "BlacklistRules": [
            "EndPort":6567,
            "StartPort": 5677,
    "WhitelistRules": [
            "EndPort":6567,
            "StartPort": 5677,
Parameter
Value
device_ip
TOKEN
manager_id
BlacklistRules
Object or array.
WhitelistRules
Object or array.
StartIPAddress
Boolean.
EndIPAddress
String.
MACAddress
MAC address.
String.
StartDateTime
String.
EndDateTime
String.
EndPort
Rule end port number.
Integer. 1 to 65535. Null indicates this field is not set.
StartPort
Rule start port number.
Protocol
Array. Supported options:
·     TCP
·     UDP
Method and URL:
POST https://192.168.77.77/redfish/v1/Managers/1/Actions/Oem/Public/Firewall.AddRules
Request header:
X-Auth-Token:TOKEN
Request body:
    "BlacklistRules": [
            "EndDateTime": "2019-02-15T21:21:36+08:00",
            "EndPort":6567,
            "StartPort": 5677,
    "WhitelistRules": [
            "EndPort":6567,
            "StartPort": 5677,
Response:
"Oem": {
       "Public": {
           "CompletionCode": 0,
"error": {
               "MessageArgs": [],
Response code: 200
Response field description
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
The server returns status code 200 for a successful operation.
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Edit firewall rule settings
Edit firewall rule settings.
Privilege module
OemSecurityMgmt
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/Oem/Public//FirewallRules
Request header:
X-Auth-Token:TOKEN
Request body:
    "BlacklistRules": [
            "EndPort":6567,
            "MemberId": "1",
            "StartPort": 5677,
    "WhitelistRules": [
            "EndPort":6567,
            "MemberId": "1",
            "StartPort": 5677,
Parameter
Value
device_ip
TOKEN
manager_id
BlacklistRules
Object or array.
WhitelistRules
Object or array.
MemberId
ID of the rule.
String.
StartIPAddress
Boolean.
EndIPAddress
String.
MACAddress
MAC address.
String.
StartDateTime
String.
EndDateTime
String.
EndPort
StartPort
Protocol
·     TCP
·     UDP
Method and URL:
PATCH https://192.168.77.77/redfish/v1/Managers/1/Oem/Public/FirewallRules
Request header:
X-Auth-Token:TOKEN
Request body:
    "BlacklistRules": [
            "EndDateTime": "2022-04-27T20:21:36+08:00",
            "EndPort":6568,
            "MemberId": "1",
            "StartDateTime": "2022-03-26T12:39:36+08:00",
            "StartIPAddress": "10.33.255.253",
            "StartPort": 5678,
    "WhitelistRules": [
            "EndPort":6567,
            "MemberId": "1",
            "StartPort": 5677,
Response:
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/Manager.FirewallRules",
    "BlacklistRules": [
            "EndPort":6568,
            "MemberId": "1",
            "StartPort": 5678,
            "EndPort":6567,
            "MemberId": "2",
              "StartPort": 5677,
            "EndPort":6567,
            "MemberId": "3",
            "StartIPAddress": "11.99.40.0",
            "StartPort": 5677,
    "Oem": {
    "WhitelistRules": [
            "EndPort":6567,
            "MemberId": "1",
            "StartPort": 5677,
            "EndPort":6567,
            "MemberId": "2",
            "StartPort": 5677,
Response code: 200
For information about the response fields, see "Obtain firewall configuration information."
Change history
Version
Change description
HDM2-1.53
Delete firewall configuration rule
Delete firewall configuration rule.
Privilege module
OemSecurityMgmt
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/ Actions/Oem/Public/Firewall.DeleteRules
Request header:
X-Auth-Token:TOKEN
Request body:
"BlacklistRules": [
"MemberId": "1",
   "MemberId": "2",
"WhitelistRules": [
"MemberId": "1",
   "MemberId": "2",
Parameter
Value
device_ip
TOKEN
manager_id
BlacklistRules
Object or array
WhitelistRules
Object or array
MemberId
String
ID of the rule.
Method and URL:
POST https://192.168.77.77/redfish/v1/Managers/1/Actions/Oem/Public/Firewall.DeleteRules
Request header:
X-Auth-Token:TOKEN
Request body:
    "BlacklistRules":[
            "MemberId":"1"
            "MemberId":"2"
    "WhitelistRules":[
            "MemberId":"1"
            "MemberId":"2"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain server security service information
Obtain server security service information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/SecurityService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
manager_id
Only value 1 is supported.
Method and URL:
GET https://192.168.77.77/redfish/v1/Managers/1/SecurityService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Managers/Members/1/SecurityService/$entity",
    "@odata.id": "/redfish/v1/Managers/1/SecurityService",
    "@odata.type": "#SecurityService.v1_0_0.SecurityService",
    "Actions": {
        "#HttpsCert.GenerateCSR": {
            "@Redfish.ActionInfo": "/redfish/v1/Managers/1/SecurityService/HttpsCert/GenerateCSRActionInfo",
            "target": "/redfish/v1/Managers/1/SecurityService/HttpsCert/Actions/HttpsCert.GenerateCSR"
    "Description": "Security Service",
    "Id": "SecurityService",
    "Links": {
        "HttpsCert": {
            "@odata.id": "/redfish/v1/Managers/1/SecurityService/HttpsCert"
    "Name": "Security Service",
    "Oem": {
        "Public": {
            "PublicKeyExponent": "010001",
            "PublicKeyModulus": "EBAD25A6352D93B7DC9273DDE0C0CB92694E00BCCCE7648F508F21E9A276446E183B9A4F13B95566B7318AD046A4C350B2B5CEB0566733A75A340A040D924EA70FADE5C44D0B1B48F729997A24EDD5D148DF50A49AA98037B00CF353FF3F25D4BFF132A86205D95F1063A050706F3FA7823857250EAD57F0F8725274E376CE7D",
            "RSAIndex": 1
Response code: 200
Data type
@odata.context
String
OData description of the security service resource model.
@odata.id
String
Link to the security service information node.
@odata.type
String
Type of the security service information.
String
Description of the security service resource.
Id
String
ID of the security service information.
Name
String
Name of the security service information.
Links.HttpsCert
Object
Link to the SSL certificate service.
Actions.#HttpsCert.GenerateCSR
Object
Information resource of the generate SSL certificate.
Oem.Public.RSAIndex
Integer
RSA index corresponding to user login, ranging from 1 to 40, needs to be set in the request header.
Oem.Public.PublicKeyExponent
String
RSA public key exponent e.
Oem.Public.PublicKeyModulus
String
RSA public key modulus n.
View SSL certificate resource information
Obtain SSL certificate resource information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/SecurityService/HttpsCert
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.77.77/redfish/v1/Managers/1/SecurityService/HttpsCert
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "#HttpsCert.ImportServerCertificate": {
            "@Redfish.ActionInfo": "/redfish/v1/Managers/1/SecurityService/HttpsCert/ImportServerCertificateActionInfo",
            "target": "/redfish/v1/Managers/1/SecurityService/HttpsCert/Actions/HttpsCert.ImportServerCertificate"
    "@odata.context": "/redfish/v1/$metadata#Managers/Members/1/SecurityService/HttpsCert/$entity",
    "@odata.id": "/redfish/v1/Managers/1/SecurityService/HttpsCert",
    "@odata.type": "#HttpsCert.v1_0_0.HttpsCert",
    "Actions": {
    "CertificateSigningRequest": null,
    "Id": "HttpsCert",
    "Name": "Https cert info",
    "Oem": {
        "Public": {
            "CurrentHttpsCert": {
                "DateOfCertificate": "2023-03-31T18:43:04+08:00",
                "DateOfPrivateKey": "2023-03-31T18:43:04+08:00"
    "Version": "3",
    "X509CertificateInformation": {
        "ServerCert": {
            "CertificateString": null,
            "CertificateType": null,
            "Issuer": {
                "City": "Hangzhou",
                "CommonName": "H3C",
                "Country": "CN",
                "Organization": "New H3C Technologies Co.,Ltd",
                "OrganizationalUnit": "Compute and Storage Product Line",
                "State": "Zhejiang"
            "IssuerAddress": "service@h3c.com",
            "KeyUsage": "Digital Signature, Non Repudiation, Key Encipherment",
            "PublicKey": "",
            "PublicKeyLengthBits": 2048,
            "SerialNumber": "4FF5D2D1B5A683DE8616801FAE92BA0D888DA5F9",
            "SignatureAlgorithm": "sha256WithRSAEncryption",
            "Subject": {
                "City": "Hangzhou",
                "Country": "CN",
                "State": "Zhejiang"
            "SubjectAddress": "service@h3c.com",
            "ValidNotAfter": "2036-04-26T09:49:41+08:00",
            "ValidNotBefore": "2021-04-30T09:49:41+08:00"
Response code: 200
Data type
@odata.context
String
OData description of the SSL certificate resource.
@odata.id
String
Link to the SSL certificate resource.
@odata.type
String
Type of the SSL certificate resource.
Integer
Description of the SSL certificate resource.
Id
String
ID of the SSL certificate resource.
Name
String
Name of the SSL certificate resource.
DateOfCertificate
String
Current certificate of the SSL resource.
DateOfPrivateKey
String
Current private key.
Version
String
Version.
CertificateString
String
Certificate content; this field is not supported.
CertificateType
String
Certificate type; this field is not supported.
IssuerAddress
String
Issuer email address.
KeyUsage
String
Certificate purpose.
PublicKey
String
Public key.
PublicKeyLengthBits
String
Public key length.
SerialNumber
String
Serial number.
SignatureAlgorithm
String
Signature algorithm.
Issuer
Object
Certificate issuer.
Subject
Object
Certificate recipient.
City
String
City or region.
CommonName
String
Common name.
Country
String
Country.
Organization
String
Organization.
OrganizationalUnit
String
Organizational unit.
String
Province (state).
SubjectAddress
String
Recipient email address.
ValidNotAfter
String
Certificate effective date.
ValidNotBefore
String
Certificate expiration date.
Generate SSL certificate
Generate CSR for SSL certificate.
Privilege module
OemSecurityMgmt
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/OSecurityService/HttpsCert/Actions/HttpsCert.GenerateCSR
Request header:
X-Auth-Token:TOKEN
Request body:
"Country":"CN",
"CommonName":"iBMC",
"City":"Shenzhen",
"State":"Guangdong",
"OrgName":"h3c",
"OrgUnit":"IT",
"EmailAddress":"h3c@123.com",
"PublicKeyLengthBits":1024,
"ValidityDays":30
Parameter
Value
device_ip
TOKEN
manager_id
Country
Country.
String. Only allows issuing two characters.
CommonName
Common name.
String. Up to 64 characters.
City
City or region.
String. Up to 128 characters.
Province (state)..
OrgName
Organizational.
OrgUnit
EmailAddress
Email address.
PublicKeyLengthBits
Key length.
Integer. Only supports 1024 and 2048.
ValidityDays
Valid days.
Integer. The value range is 1 to 5475.
Method and URL:
POST https://192.168.188.188/redfish/v1/Managers/1/SecurityService/HttpsCert/Actions/HttpsCert.GenerateCSR
Request header:
X-Auth-Token:TOKEN
Request body:
"Country":"CN",
"City":"Shenzhen",
"OrgName":"h3c",
"OrgUnit":"IT",
"ValidityDays":30
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Import SSL certificate
Import SSL certificate.
Privilege module
OemSecurityMgmt
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/SecurityService/HttpsCert/Actions/HttpsCert.ImportServerCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
·     Local import:
"Certificate": "/tmp/web/server.pem",
"Privatekey": "/tmp/web/privkey.pem"
·     Remote import
¡     CIFS or SFTP:
"Certificate": "sftp://username:password@192.168.170.57/server.pem",
"Privatekey": "sftp://username:password@192.168.170.57/privkey.pem"
¡     http, tftp, nfs, or https:
"Certificate": "tftp://192.168.170.57/server.pem",
"Privatekey": "tftp://192.168.170.57/privkey.pem"
Upload text content directly:
"Certificate":"-----BEGIN CERTIFICATE----- \nMIIDrzCCApegAwIBAgIUC9Bj/YPQNv0SjljzLuEQVVPj83EwDQYJKoZIhvcNAQEL \nBQAwZzELMAkGA1UEBhMCY2QxDDAKBgNVBAgMA2ZkZjEMMAoGA1UEBwwDZmRmMQ4w \nDAYDVQQKDAVkZmRmZDELMAkGA1UECwwCZmQxCzAJBgNVBAMMAmZkMRIwEAYJKoZI \nhvcNAQkBFgNmZGYwHhcNMjIwMTA1MDMyMzAxWhcNMjMwMTA1MDMyMzAxWjBnMQsw \nCQYDVQQGEwJjZDEMMAoGA1UECAwDZmRmMQwwCgYDVQQHDANmZGYxDjAMBgNVBAoM \nBWRmZGZkMQswCQYDVQQLDAJmZDELMAkGA1UEAwwCZmQxEjAQBgkqhkiG9w0BCQEW \nA2ZkZjCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAOkN3vbmceJ1MCdt \nEW3/V8x0Rxc/L4iYFLP2fNZmn4ANrEEyQ0AIuIbCUml1ehK02wREN36cdmoz5xKD \n7swLxNNDHoJr4jASAma4IFX77M7Ro9uFOxOBHdSvY7fuTPRXCC+V0ttU3NQg9XbG \nUvB6ZtV+YEX7x6XD0SAgHPWgesHcxpfwkaBimZ83NaU/Jdjv+fEDk8LqoFeX4OQT \n5Fpz19dqgyAkoxc7LBOAN1UEipIgIQ4v2zsjcF9+7EQevso6oDKPgllZoOQ5SR9o \neHJ1PFTbuz0EzMICfsLL0yZ8gjW/tjjszxAlntpIc9JIhefnmBX7yAo16AtNdb1V \n7DanjlsCAwEAAaNTMFEwHQYDVR0OBBYEFKNIPyVAN+J2fkQX9bFuYtUZQ9Q1MB8G \nA1UdIwQYMBaAFKNIPyVAN+J2fkQX9bFuYtUZQ9Q1MA8GA1UdEwEB/wQFMAMBAf8w \nDQYJKoZIhvcNAQELBQADggEBAC3BIyK5DLzN7f33dw7C0RDFeV/L+bUc4qJXH4Le \npYJmLY2zWKOC4BSuhoJy6f+EfgbI+nOPcISSxzJM/2nr5XsWslyXLon+dO4D8QlZ \nDuaNjgERCCcy99xwiR6JPkQheF5Fs5EF8sLj2BEAFYf3dArXkugRg0jqTA6Q7ZUG \ngQUCH4fHyBd7LyB9XRUp7TXhYh0M3m3JJ4vqWli7KiQMTc9lWOfB1Kp3TxsmFKXw \noUiAb44TSeJBuPv41sc5PXsGnPu0REM2qSsWccstUAXeI1aw/2aWY+a05yDPIOke \nAHR7hdjLURsNAjCCUh/IHv6R4uy1koOt0wrLen3+UT9w1dg= \n-----END CERTIFICATE-----\n",
"Privatekey":"-----BEGIN PRIVATE KEY----- \nMIIEvgIBADANBgkqhkiG9w0BAQEFAASCBKgwggSkAgEAAoIBAQDpDd725nHidTAn \nbRFt/1fMdEcXPy+ImBSz9nzWZp+ADaxBMkNACLiGwlJpdXoStNsERDd+nHZqM+cS \ng+7MC8TTQx6Ca+IwEgJmuCBV++zO0aPbhTsTgR3Ur2O37kz0VwgvldLbVNzUIPV2 \nxlLwembVfmBF+8elw9EgIBz1oHrB3MaX8JGgYpmfNzWlPyXY7/nxA5PC6qBXl+Dk \nE+Rac9fXaoMgJKMXOywTgDdVBIqSICEOL9s7I3BffuxEHr7KOqAyj4JZWaDkOUkf \naHhydTxU27s9BMzCAn7Cy9MmfII1v7Y47M8QJZ7aSHPSSIXn55gV+8gKNegLTXW9 \nVew2p45bAgMBAAECggEALQ8Yf8YYWL9tmwHUb98Bm68Tm6QEzbURs6XBhzZ6Oijq \nmAReyj+lZbCmfGtROdKr0cxaqmkX3/q+/25wuhTAblQ4zuCK795bhn6tCdLWezo/ \nIw9EV8YL/XYXopU5XbiCBalDBlMHCyCANQGtQX946GgxtvYyKJOOmFZ9IuRvN5HY \ncz/elp8kdRi3hS/xEeiq8g8wKFXb74v39s9ZQlDSvUDMg2dY9O6h/5SWC+blKphN \n86eMyW8N8IViF3l3YqyeKhekhfcsK+SWjVQmm04gp925p1wr+BqDjlXBs8vYBZ20 \nOe09Kv7LDSskweZk77dnxSv/9jTiommEphGEImtLQQKBgQD9j5rd/GTJ01HKYQY7 \nWVx8bNg14njxnZ/ChLZguhTRDLkTMcLI5QmiOlMNrm/U1A0TfuhQD59T/FeF9Mf9 \nuZBeluGuCe4HcWfbp4q9mEZEeaq0xt/CImoVWRb04mErjg7gvijJMxkQhbQo6hnS \ns0Lt2ze5zNGC47KW0InA115buwKBgQDrS8SaRm8XfohzIKzCInFZYKYUPoMDAfoR \nbS2hVSGbPxNEkfQZWM+Xvn7vK+0J68kjGPonpbXyFutNPXe1hqdzhFPZpuNNlSYc \nt0+9fV+ZXTGuc+0CngJ81OaMVEdi1BqVMvkOM+zlXksTgf1ONJ25rHTLTRLBaymr \nMR9x0tJd4QKBgHdqd4ROhuUqed23PikbV9xdoqIWC+G223PP7ti1KnKd7Ffm2pak \nj5nwoAbUfWSdjZ796Mkz4lS6hjnXY4zSJPT3WEgP8yNcPI6NZGEQYx+CsWu8McuL \nS6zMLWydZSgPGmCsDidbwlUusv+F6S17MW02DhOaK53aQNSYWBgTFiRbAoGBAMt9 \nXWwm2dCxx4P5kC7c5rZrVXZQkbE6NnB3wWyzWTsQE7PLnhWFrxMG1nQ1wuw/lFXc \nNguvzmit1ZWZQTwmVg8bNAEZyZ7BDJLtHfM8yD60UFEVRLZsvK4E2dYm1Q3tbYf2 \n61mTIp9DKx6V3uGRs45uTRu9bikEaqb49r7TmsdBAoGBAK0bRD8BdrsFKlpsTAW4 \nYCrLTlSQtQ4ggjOVKqh5kaorhpPS8MBXLMYgvdunYcRu9MafIQn8YmClZrvUHula \nNckI0KcibnguWxQ3KFuFTbrYz60HRwNsVMKT4XcQUbfO/WUfOY2T2Q+pmrmQlb6B \nf0O0j3Q0L1ZrLGuinUBj8XvW \n-----END PRIVATE KEY-----\n"
Parameter
Value
device_ip
TOKEN
manager_id
Certificate
Server certificate file or certificate chain file.
String.
Privatekey
Private key certificate file or certificate chain file.
String.
Method and URL:
POST https://192.168.188.188/redfish/v1/Managers/1/SecurityService/HttpsCert/Actions/HttpsCert.ImportServerCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
    "@odata.context": "/redfish/v1/$metadata#TaskCollection.TaskCollection",
    "@odata.type": "#TaskCollection.TaskCollection",
    "Members": [
            "@odata.id": "/redfish/v1/TaskService/Tasks/3"
    "Members@odata.count": 1,
    "Name": "Task Collection",
    "Oem": {
        "Public": {
            "TaskUniqueID": 1678656297
Response code: 200
Data type
@odata.context
String
OData description of the TaskService resource when importing SSL certificate.
@odata.id
String
Link to the TaskService resource when importing SSL certificate.
@odata.type
String
Type of the TaskService resource when importing SSL certificate.
Members@odata.id
String
Task link generated during SSL certificate import.
Oem.Public.TaskUniqueID
Integer
Unique ID of TaskService resource for importing SSL certificate.
Change history
Version
Change description
HDM2-1.53
Obtain login security information feature
Obtain login security information feature details.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/LoginSecurityInformation
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET
https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/LoginSecurityInformation
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#LoginSecurityInformation.LoginSecurityInformation",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/LoginSecurityInformation",
    "@odata.type": "#LoginSecurityInformation.v1_0_0.LoginSecurityInformation",
    "Name": "LoginSecurity Information",
    "Oem": {
        "Public": {
    "SecurityEnabled": false,
    "SecurityInformation": ""
Response code: 200
Data type
@odata.context
String
@odata.id
String
Link to the specified role resource model.
@odata.type
String
Type of the specified role resource model.
SecurityEnabled
Boolean
Enable status. Supported options:
·     false.
·     true.
SecurityInformation
String
Content of login security information.
Set login security information feature
Set login security information feature details.
Privilege module
OemSecurityMgmt
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/Oem/Public//LoginSecurityInformation
Request header:
X-Auth-Token:TOKEN
Request body:
    "SecurityEnabled": security_enabled,
      "SecurityInformation": security_infomation
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
PATCH
Request header:
X-Auth-Token:TOKEN
Request body:
    "SecurityEnabled": true,
      "SecurityInformation": "G6 6900"
Response:
    "Oem": {
        "Public": {
Response code: 200
For information about the response fields, see "Obtain login security information feature."
Obtain platform firmware resilience configuration
Obtain the Platform Firmware Resilience (PFR) configuration.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/PFRSettings
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/PFRSettings
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#PFRFirmwareProtect.PFRFirmwareProtect",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/PFRSettings",
    "@odata.type": "#PFRFirmwareProtect.v1_0_0.PFRFirmwareProtect",
    "BootFromSubareaEnabled": false,
    "CPLDState": "Absent",
    "Enabled": true,
    "FirmwareStatus": "normal",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
CPLDState
String
PRFCPLD statue.
Enabled
Boolean
Status of PFR firmware protection feature switch.
Boolean
Whether to boot from backup partition if verification fails.
FirmwareStatus
String
Display the firmware verification status for the current boot. If PFR firmware protection is disabled, it displays N/A.
Change history
Version
Change description
HDM2-1.61
Added the CPLDState field.
Configure platform firmware resilience settings
Configure the Platform Firmware Resilience (PFR) settings.
Privilege module
OemSecurityMgmt
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/PFRSettings
Request header:
X-Auth-Token:TOKEN
Request body:
    "BootFromSubareaEnabled":true
Parameter
Value
device_ip
TOKEN
manager_id
Check if it is enabled from the backup area after verification fails.
Boolean.
Method and URL:
PATCH
Request header:
X-Auth-Token:TOKEN
Request body:
"BootFromSubareaEnabled": true
Response:
    "BootFromSubareaEnabled": true,
    "Enabled": true,
    "Oem": {
        "Public": {
Response code: 200
For information about the response fields, see "Obtain platform firmware resilience configuration."
Change history
Version
Change description
HDM2-1.53
Obtain serial port redirection settings
Obtain serial port redirection settings. This interface is not available for X18000 products.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/SOLMode
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/SOLMode
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
  "@odata.context": "/redfish/v1/$metadata#SOLMode.SOLMode",
  "@odata.id": "/redfish/v1/Managers/1/Oem/Public/SOLMode",
  "@odata.type": "#SOLMode.v1_0_0.SOLMode",
  "ConnectType": "BIOS",
  "Name": "Serial Over Lan Mode",
  "Oem": {
    "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the serial port redirection settings resource model.
@odata.id
String
Link to the serial port redirection setting resource.
@odata.type
String
Type of the serial port redirection setting resource.
ConnectType
String
Supported options:
·     BIOS
·     IntelligentNIC
BitRate
String
Baud rate.
Only 115200 is supported.
Change history
Version
Change description
HDM2-1.58
Deleted the BMC option from the ConnectType field.
HDM2-1.56
Deleted the RAID option from the ConnectType field.
Set serial port redirection settings
Set serial port redirection settings. This interface is not available for X18000 products.
Privilege module
OemKvm
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/SOLMode
Request header:
X-Auth-Token:TOKEN
Request body:
"ConnectType":mode
Parameter
Value
device_ip
TOKEN
manager_id
ConnectType
Supported options:
·     BIOS
·     IntelligentNIC
String.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/manager_id/Oem/Public/SOLMode
Request header:
X-Auth-Token:TOKEN
Request body:
"ConnectType" : "BIOS"
Response:
  "Oem": {
    "Public": {
Response code: 200
For information about the response fields, see "Obtain serial port redirection settings."
Change history
Version
Change description
HDM2-1.58
HDM2-1.56
Obtain screen snapshots
Obtain screen snapshot information.
Privilege module
Login
Request
Method and URL:
GET
https://device_ip/redfish/v1/Managers/manager_id/Oem/DiagnosticService/ScreenShot
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/DiagnosticService/ScreenShot
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "redfish/v1/$metadata#Managers/Members/1/DiagnosticService/ScreenShot/$entity",
    "@odata.id": "/redfish/v1/Managers/1/DiagnosticService/ScreenShot",
    "@odata.type": "#ScreenShot.v1_0_0.ScreenShot",
    "Members": [
            "FileName": "BSOD_20211111T172700+0800_01.jpeg"
    "Name": "CaptureScreenShot",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the screen snapshot resource model.
@odata.id
String
Link to the screen snapshot resource.
@odata.type
String
Type of the screen snapshot resource.
FileName
String
Screenshot file name.
Delete screen snapshots
Delete screen snapshots.
Privilege module
ConfigureComponents
Request
Method and URL:
POST
https://device_ip/redfish/v1/Managers/manager_id/DiagnosticService/Actions/DiagnosticService.DeleteScreenShot
Request header:
X-Auth-Token:TOKEN
Request body:
"FileName": filename
Parameter
Value
device_ip
TOKEN
manager_id
FileName
Name of the snapshot file to be deleted. If set to deleteAll, all will be deleted.
HDM3 supports only one snapshot.
String. Options include false and true.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/DiagnosticService/Actions/DiagnosticService.DeleteScreenShot
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
       "@Message.ExtendedInfo": [
               "@odata.type": "#Message.v1_1_1.Message",
               "Message": "Successfully Completed Request",
               "MessageArgs": [],
               "MessageId": "Base.1.8.1.Success",
               "MessageSeverity": "OK",
               "Resolution": "None"
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Obtain video playback
Obtain video playback information.
Privilege module
Login
Request
Method and URL:
GET
https://device_ip/redfish/v1/Managers/manager_id/DiagnosticService/Videos
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/DiagnosticService/Videos
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Managers/Members/1/DiagnosticService/Videos/$entity",
    "@odata.id": "/redfish/v1/Managers/1/DiagnosticService/Videos",
    "@odata.type": "#RecordedVideos.v1_0_0.RecordedVideos",
    "Members": [
            "CreateTime": "2022-06-02T23:09:47+08:00",
            "FileName": "pre_shutdown_video_20210918T142531+0800.dat",
            "VideoType": "PoweroffVideo"
    "Name": "RecordedVideos",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the video playback model.
@odata.id
String
Link to the video playback.
@odata.type
String
Type of the video playback.
Members
Object
·     Video information.
FileName
String
Video file name.
VideoType
String
·     Video type.
·     Supported options:
·     CrashVideo.
·     OsresetVideo.
·     PoweroffVideo.
CreateTime
String
·     Video file timestamp.
Members@odata.count
Integer
·     Number of videos.
Name
String
Name of the video resource.
Obtain advanced video playback configuration
Obtain advanced video playback configuration.
Privilege module
Login
Request
Method and URL:
GET
https://device_ip/redfish/v1/Managers/manager_id/DiagnosticService/VideoConfig
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/DiagnosticService/VideoConfig
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Managers/Members/1/DiagnosticService/VideosConfig/$entity",
    "@odata.id": "/redfish/v1/Managers/1/DiagnosticService/VideoConfig",
    "@odata.type": "#RecordedVideosConfig.v1_0_0.RecordedVideosConfig",
    "Name": "RecordedVideos Config",
    "Oem": {
        "Public": {
    "RecordingStrategy": {
        "PreCrashEnabled": false,
        "PreRestartEnabled": false,
        "PreShutdownEnabled": false
    "RecordingTime": 15,
    "VideoRecordingEnabled": true
Response code: 200
Data type
@odata.context
String
OData description of the video playback settings resource model.
@odata.id
String
Link to the video playback settings resource.
@odata.type
String
Type of the video playback settings resource.
Name
String
Name of the video playback settings resource.
Boolean
Enabling status of the video recording function.
RecordingTime
Integer
Length of video recording time, limited to 15-255s.
RecordingStrategy.PreCrashEnabled
Boolean
·     Whether recording is enabled before a crash.
RecordingStrategy.PreRestartEnabled
Boolean
·     Whether recording is enabled before a reset.
RecordingStrategy.PreShutdownEnabled
Boolean
Whether recording is enabled before shutdown.
Set advanced video playback configuration
Configure video playback parameters.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH
Request header:
X-Auth-Token:TOKEN
Request body:
"VideoRecordingEnabled": true,
"RecordingTime": time_s,
    "PreCrashEnabled": true,
    "PreShutdownEnabled": true
Parameter
Value
device_ip
TOKEN
manager_id
Boolean.
RecordingTime
Length of the video recording time, limited to 15-255s.
Integer.
Boolean.
Boolean.
Boolean.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/DiagnosticService/VideoConfig
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
Request body:
  "RecordingTime": 120,
Response:
    "Oem": {
        "Public": {
Response code: 200
For information about the response fields, see "Obtain advanced video playback configuration."
Play video playback
Play a video playback.
Privilege module
ConfigureComponents
Request
Method and URL:
POST
https://device_ip/redfish/v1/Managers/manager_id/DiagnosticService/Actions/DiagnosticService.PlayVideo
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
manager_id
FileName
Filename of the video to be played.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/DiagnosticService/Actions/DiagnosticService.PlayVideo
Request header:
X-Auth-Token:TOKEN
Request body:
"FileName": "pre_crash_video_20211111T172700+0800.dat"
Response:
    "@odata.context": "/redfish/v1/$metadata#Managers/Members/1/DiagnosticService/Actions/$entity",
    "@odata.id": "/redfish/v1/Managers/1/DiagnosticService/Actions/DiagnosticService.PlayVideo",
    "FilePath":"/usr/local/www/video/HDM/pre_crash_video_20211111T172700+0800.dat",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
FilePath
String
Name of the video playback file.
Export video playback
Export a video playback.
Privilege module
ConfigureComponents
Request
Method and URL:
POST
https://device_ip/redfish/v1/Managers/manager_id/DiagnosticService/Actions/DiagnosticService.ExportVideo
Request header:
X-Auth-Token:TOKEN
Request body:
Local export
    "Type":"URI",
    "Content": "/tmp/web/dump.tar.gz",
"Oem": {
        "Public": {
            "FileName": FileName
Remote export
Cifs or sftp
"Type":"URI",
"Content": "sftp://username:password@10.10.10.191/usr/dump.tar.gz",
"Oem": {
        "Public": {
    "Type":"URI",
"Content": http://ip/filename,
"Oem": {
        "Public": {
            "FileName": FileName,
Parameter
Value
device_ip
TOKEN
manager_id
ID of the manager resource.
Method of exporting video playback.
URI.
Content
Link to export video playback.
See "Others."
Oem.Public.ScriptName
Script file name.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/DiagnosticService/Actions/DiagnosticService.ExportVideo
Request header:
X-Auth-Token:TOKEN
Request body:
    "Type":"URI",
    "Content": "nfs://192.168.20.177/Share1/pre.dat ",
    "Oem": {
        "Public": {
            "FileName":"pre_crash_video_20211111T172700+0800.dat"
Response:
  "Members": [
      "@odata.id": "/redfish/v1/TaskService/Tasks/2"
  "Oem": {
    "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the video export TaskService.
@odata.id
String
Link to the video export TaskService.
@odata.type
String
Type of the video export TaskService.
Members
Array
Link to the video export Task.
Members@odata.count
Integer
Number of links generated by the video export Task.
Integer
Unique ID of the video export TaskService.
Delete video playback
Delete a video playback.
Privilege module
ConfigureComponents
Request
Method and URL:
POST
https://device_ip/redfish/v1/Managers/manager_id/DiagnosticService/Actions/DiagnosticService.DeleteVideo
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
manager_id
FileName
String. If the parameter is deleteAll, all videos will be deleted.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/DiagnosticService/Actions/DiagnosticService.DeleteVideo
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
        "code":"Base.1.8.1.Success",
        "message":"Successfully Completed Request"
Response code: 200
Data type
code
String
String of a specific message ID in the message registry.
message
String
Readable error message corresponding to the message in the message registry.
Extended information of the message.
@odata.type
String
OData description of the message resource.
MessageId
String
Message ID.
Message
String
Details of the message.
MessageArgs
Array
Message arguments.
MessageSeverity
String
Severity level. Supported options:
·     OK.
·     Warning.
·     Critical.
Resolution
String
Recommended actions for the error.
Change history
Version
Change description
HDM2-2.04
Added the error node before Message.ExtendedInfo and added the code and message fields under the error node.
Unified management: Obtain managed device collection resources
Obtain managed device collection information.
Privilege module
Login
Request
Method and URL:
GET
https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/JointManagement
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/JointManagement
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
  "@odata.context": "/redfish/v1/$metadata#JointManagement.JointManagement",
  "@odata.id": "/redfish/v1/Managers/1/Oem/Public/JointManagement",
  "@odata.type": "#JointManagement.v1_0_0.JointManagement",
  "Actions": {
    "Oem": {
      "Public": {
        "#JointManagement.AddDevices": {
          "target": "/redfish/v1/Managers/1/Actions/Oem/Public/JointManagement.AddDevices"
        "#JointManagement.ComputerSystemReset": {
          "target": "/redfish/v1/Managers/1/Actions/Oem/Public/JointManagement.ComputerSystemReset"
        "#JointManagement.RemoveDevices": {
          "target": "/redfish/v1/Managers/1/Actions/Oem/Public/JointManagement.RemoveDevices"
  "Description": "Joint management information",
  "Members": [
      "AssignedPrivileges": [],
      "IPAddress": "192.168.7.23",
      "IndicatorLED": "N/A",
      "MemberId": "0",
      "OemPrivileges": [],
      "OnlineEnabled": false,
      "PowerState": "N/A",
      "ProductName": "N/A",
      "SerialNumber": "N/A",
      "Severity": "N/A"
        "ConfigureUsers",
        "ConfigureComponents",
        "Login",
        "ConfigureSelf"
      "IPAddress": "192.168.188.187",
      "IndicatorLED": "Off",
      "MemberId": "1",
      "OemPrivileges": [
        "OemKvm",
        "OemVmm",
        "OemSecurityMgmt",
        "OemPowerControl",
        "OemDiagnosis",
        "OemSystemAudit"
      "OnlineEnabled": true,
      "PowerState": "On",
      "ProductName": "RS33M2C9S",
      "SerialNumber": "",
      "Severity": "Critical"
  "Members@odata.count": 2,
  "Name": "JointManagement Collection",
  "Oem": {
    "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the managed device collection resource model.
@odata.id
String
Link to the managed device collection resource.
@odata.type
String
Type of the managed device collection resource.
Members
Object
Members.AssignedPrivileges
Array
Members.OemPrivileges
Array
Member list.
Members.MemberId
String
Specified privileges.
Members.OnlineEnabled
Boolean
Server-defined privileges.
Members.IPAddress
String
Device member ID.
Members.ProductName
String
Online status.
Members.Severity
String
Device IP.
Members.PowerState
String
Device name.
Members.IndicatorLED
String
UID LED status.
Members.SerialNumber
String
Serial number.
Members@odata.count
Integer
Current number of managed devices.
Actions.Oem.Public#JointManagement.ComputerSystemReset
Object
Host power operation.
Actions.Oem.Public#JointManagement.RemoveDevices
Object
Delete managed device.
Actions.Oem.Public #JointManagement.AddDevices
Object
Add device management.
Name
String
Name of the managed device collection resource information.
Unified management: Add managed device resources
Add a managed device resource.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/Actions/Oem/Public/JointManagement.AddDevices
Request header:
X-Auth-Token:TOKEN
Request body:
"StartIPAddress": StartIPAddress,
"EndIPAddress": EndIPAddress,
"UserName": UserName,
"Password": Password
Parameter
Value
device_ip
TOKEN
manager_id
StartIPAddress
Starting IP.
String.
EndIPAddress
Ending IP.
String.
UserName
Username for adding devices.
String.
Password
Password for adding devices.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/Actions/Oem/Public/JointManagement.AddDevices
Request header:
X-Auth-Token:TOKEN
Request body:
  "StartIPAddress": "192.168.122.178",
  "EndIPAddress": "192.168.122.178",
  "UserName": "admin",
  "Password": "Password@_"
Response:
    "Members": [
    "Oem": {
        "Public": {
            "TaskUniqueID": 1685303949
Response code: 202
Data type
@odata.context
String
Add OData description information for managing the TaskService management device.
@odata.type
String
Add the type of management device TaskService.
@odata.id
String
Add the access path of management device TaskService.
Members@odata.id
String
Add the task link generated by the management device.
Name
String
Add the name of management device TaskService.
Change history
Version
Change description
HDM2-1.54
Modified the method for adding devices to unified management by using tasks to return.
Unified management: Delete managed device resources
Delete a managed device resource.
Privilege module
ConfigureUsers
Request
Method and URL:
POST
https://device_ip/redfish/v1/Managers/manager_id/Actions/Oem/Public/JointManagement.RemoveDevices
Request header:
X-Auth-Token:TOKEN
Request body:
"ServerList":[
"MemberId": MemberId,
"IPAddress": ip
"IPAddress": ip
Parameter
Value
device_ip
TOKEN
manager_id
ServerList
Device list
Array.
ServerList.MemberId
Device member ID.
String.
ServerList.IPAddress
IP of the device to be deleted.
IP address range cannot exceed 255.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/Actions/Oem/Public/JointManagement.RemoveDevices
Request header:
X-Auth-Token:TOKEN
Request body:
"ServerList":[
"MemberId": "1",
"IPAddress": "192.168.18.20"
"MemberId": "2",
"IPAddress": "192.168.18.21"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Unified management: Host power operation
Perform host power operation.
Privilege module
ConfigureUsers
Request
Method and URL:
POST
https://device_ip/redfish/v1/Managers/manager_id/Actions/Oem/Public/JointManagement.ComputerSystemReset
Request header:
X-Auth-Token:TOKEN
Request body:
"PowerState": PowerState
Parameter
Value
device_ip
TOKEN
manager_id
MemberId
Device ID.
String.
PowerState
Modify power state.
String type. Supported options:
·     On.
·     ForceOff.
·     GracefulShutdown.
·     ForceRestart.
·     ForcePowerCycle.
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/Actions/Oem/Public/JointManagement.ComputerSystemReset
Request header:
X-Auth-Token:TOKEN
Request body:
"MemberId": "1",
"PowerState": "On"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Obtain service USB drive resource information
Obtain service USB drive resource information. This interface is not available for X18000 products.
Privilege module
Login
Request
Method and URL:
GET
https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/USBDeviceService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/USBDeviceService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#USBDeviceService/$entity",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/USBDeviceService",
    "@odata.type": "#USBDeviceService.v1_0_0.USBDeviceService",
    "AutomaticDownloadEnabled": false,
"Description": "USB Device Service",
    "Oem": {
        "Public": {
    "ServiceEnabled": true,
    "State": "Absent"
Response code: 200
Data type
@odata.context
String
OData description of the service USB drive resource model.
@odata.id
String
Link to the service USB drive resource information.
@odata.type
String
Type of the service USB drive resource information.
String
Description of the service USB drive resource information.
Boolean
·     USB Drive Status. Supported options:
·     Enabled.
·     Absent.
·     Starting.
ServiceEnabled
Boolean
Whether the service USB drive is enabled.
Boolean
·     Whether the automatic download SDS function is enabled.
USBDeviceEnabled
Boolean
·     Enabling status USB physical interface.
Set service USB drive resource information
Set service USB drive resource information. This interface is not available for X18000 products.
Privilege module
OemDiagnosis
Request
Method and URL:
PATCH
Request header:
X-Auth-Token:TOKEN
Request body:
"AutomaticDownloadEnabled": true
Parameter
Value
device_ip
TOKEN
manager_id
ServiceEnabled
Enabling status of the service USB drive.
Boolean.
Enabling status of the automatic SDS download function.
Boolean.
USBDeviceEnabled
Enabling status of the USB physical interface.
Boolean.
Method and URL:
Patch https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/USBDeviceService
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
    "AutomaticDownloadEnabled": true,
    "Oem": {
        "Public": {
    "State": "Absent"
Response code: 200
For information about the response fields, see "Obtain service USB drive resource information."
Upload BMC file
Display the specified BMC file content using PostMan. Users can upload files using Postman or in combination with curl command.
Privilege module
ConfigureComponents
Request
Method and URL:
POST
https://device_ip/redfish/v1/Managers/manager_id/ Actions/Oem/Public/Manager.GeneralUpload
Request header:
X-Auth-Token:TOKEN
Request body:
<form enctype="multipart/form-data" action="
https://192.168.188.188/redfish/v1/Managers/1/Actions/Oem/Public/Manager.GeneralUpload" method="POST">
<input name=""file name" type="file">
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/Actions/Oem/Public/Manager.GeneralUpload
Request header:
X-Auth-Token:TOKEN
Request body:
<input name="BIOSConfiguration" type="file">
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Reset the SD card
Reset the SD card.
Privilege module
OemKvm
Request
Method and URL:
POST
https://device_ip/redfish/v1/Managers/manager_id/ Actions/Oem/Public/Manager.ResetSD
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/Actions/Oem/Public/Manager.ResetSD
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Obtain security dashboard information
Obtain the security dashboard information.
Privilege module
Login
Request
Method and URL:
GET
https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/SecurityDashboard
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/SecurityDashboard
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#SecurityDashboard.SecurityDashboard",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/SecurityDashboard",
    "@odata.type": "#SecurityDashboard.v1_0_0.SecurityDashboard",
    "AccountAuthenticationSecurity": {
        "AccountLockoutDuration": {
            "ConfigurationStatus": "OK",
            "ConfigurationValue": "5",
            "Id":"4",
            "IgnoreRiskSupported": "Disabled"
        "AccountLockoutThreshold": {
            "ConfigurationValue": "1",
            "Id":"3",
        "LDAPCertificateVerification":{
           "ConfigurationValue": "Enabled",
           "Id": "7",
        "PasswordComplexityCheck": {
            "Id":"1",
        "PasswordHistoryCount": {
            "ConfigurationStatus": "Risky",
            "ConfigurationValue": "0",
            "Id":"5",
        "PasswordValidityDays": {
            "Id":"6",
        "WeakPasswordVerification": {
            "ConfigurationValue": "Disabled",
            "Id":"2",
    "Description": "SecurityDashboard Gettings",
    "Id": "SecurityDashboard",
    "IgnoreRiskAllocationsCount": 0,
    "Name": "SecurityDashboard",
    "Oem": {
        "Public": {
    "RiskAllocationsCount": 9,
    "ServiceSecurity": {
        "CertificateRemainingTime": {
            "ConfigurationValue": "805",
            "Id":"10",
        "CommunityComplexityCheck": {
            "Id": "1",
        "DefaultCertificateEnabled": {
            "Id":"8",
        "KVMEncryption": {
            "Id":"5",
        "RMCPPlusEnabled": {
            "Id":"3",
        "SMTPTLSEncryption": {
            "Id":"7",
        "SNMPV1V2CEnabled": {
            "Id":"2",
        "SyslogTLSEnabled": {
            "Id":"6",
        "TLSVersion": {
            "ConfigurationValue": "TLSv1.2",
            "Id":"9",
        "VNCPasswordComplexityCheck": {
            "Id":"4",
Response code: 200
Data type
@odata.context
String
OData description of the safety instrument information resource model.
@odata.id
String
Link to the safety instrument information resource.
@odata.type
String
Type of the safety instrument information resource.
String
Description of the safety instrument information resource.
Id
String
ID of the safety instrument information resource.
Name
String
Name of the safety instrument information resource.
Integer
Risk configuration item, displayed as 0 when disabled.
Integer
Ignore risk items, displayed as 0 when disabled.
ServiceEnabled
Boolean
Safety detection function. When this feature is enabled, its status is displayed as true. When the feature is disabled, its status is displayed as false
Account authentication security.
Object
Allowed number of incorrect password attempts.
AccountLockoutThreshold.ConfigurationValue
String
Configuration value.
AccountLockoutThreshold.ConfigurationStatus
String
Status (OK, Risky).
AccountLockoutThreshold.IgnoreRiskSupported
String
Ignore option (Enabled, Disabled).
AccountLockoutThreshold.Id
String
Configuration item ID.
Object
Password complexity check.
PasswordComplexityCheck.ConfigurationValue
String
PasswordComplexityCheck.ConfigurationStatus
String
Status (OK, Risky).
PasswordComplexityCheck.IgnoreRiskSupported
String
PasswordComplexityCheck.Id
String
Object
Duration of user lockout following failed login attempts.
AccountLockoutDuration.ConfigurationValue
String
AccountLockoutDuration.ConfigurationStatus
String
Status (OK, Risky).
AccountLockoutDuration.IgnoreRiskSupported
String
AccountLockoutDuration.Id
String
Object
Weak password validation.
WeakPasswordVerification.ConfigurationValue
String
WeakPasswordVerification.ConfigurationStatus
String
Status (OK, Risky).
WeakPasswordVerification.IgnoreRiskSupported
String
WeakPasswordVerification.Id
String
Object
Password history count.
PasswordHistoryCount.ConfigurationValue
String
PasswordHistoryCount.ConfigurationStatus
String
Status (OK, Risky).
PasswordValidityDays.IgnoreRiskSupported
String
PasswordHistoryCount.Id
String
Object
Password validity period.
PasswordValidityDays.ConfigurationValue
String
PasswordValidityDays.ConfigurationStatus
String
Status (OK, Risky).
String
PasswordValidityDays.Id
String
Object
LDAP certificate verification enabling.
LDAPCertificateVerification.ConfigurationValue
String
LDAPCertificateVerification.ConfigurationStatus
String
State (OK or Risky).
LDAPCertificateVerification.IgnoreRiskSupported
String
Enabling status of ignoring.
LDAPCertificateVerification.Id
String
ServiceSecurity
Application service security.
Object
Community complexity check.
CommunityComplexityCheck.ConfigurationValue
String
CommunityComplexityCheck.ConfigurationStatus
String
Status (OK, Risky).
CommunityComplexityCheck.IgnoreRiskSupported
String
CommunityComplexityCheck.Id
String
SNMPV1V2CEnabled
Object
Enabling status of the V1/V2C.
SNMPV1V2CEnabled.ConfigurationValue
String
SNMPV1V2CEnabled.ConfigurationStatus
String
Status (OK, Risky).
SNMPV1V2CEnabled.IgnoreRiskSupported
String
SNMPV1V2CEnabled.Id
String
RMCPPlusEnabled
Object
IPMI RMCP+ configuration.
RMCPPlusEnabled.ConfigurationValue
String
RMCPPlusEnabled.ConfigurationStatus
String
Status (OK, Risky).
RMCPPlusEnabled.IgnoreRiskSupported
String
RMCPPlusEnabled.Id
String
Object
VNC password complexity check.
VNCPasswordComplexityCheck.ConfigurationValue
String
VNCPasswordComplexityCheck.ConfigurationStatus
String
Status (OK, Risky).
VNCPasswordComplexityCheck.IgnoreRiskSupported
String
VNCPasswordComplexityCheck.Id
String
KVMEncryption
Object
KVM encryption.
KVMEncryption.ConfigurationValue
String
KVMEncryption.ConfigurationStatus
String
Status (OK, Risky).
KVMEncryption.IgnoreRiskSupported
String
KVMEncryption.Id
String
Object
Remaining certificate validity period.
CertificateRemainingTime.ConfigurationValue
String
CertificateRemainingTime.ConfigurationStatus
String
Status (OK, Risky).
CertificateRemainingTime.IgnoreRiskSupported
String
CertificateRemainingTime.Id
String
TLSVersion
Object
TLS version.
TLSVersion.ConfigurationValue
String
TLSVersion.ConfigurationStatus
String
Status (OK, Risky).
TLSVersion.IgnoreRiskSupported
String
TLSVersion.Id
String
Object
Use of default certificate.
DefaultCertificateEnabled.ConfigurationValue
String
DefaultCertificateEnabled.ConfigurationStatus
String
Status (OK, Risky).
DefaultCertificateEnabled.IgnoreRiskSupported
String
DefaultCertificateEnabled.Id
String
SMTPTLSEncryption
Object
SMTP TLS encryption.
SMTPTLSEncryption.ConfigurationValue
String
SMTPTLSEncryption.ConfigurationStatus
String
Status (OK, Risky).
SMTPTLSEncryption.IgnoreRiskSupported
String
SMTPTLSEncryption.Id
String
SyslogTLSEnabled
Object
Syslog TLS enablement.
SyslogTLSEnabled.ConfigurationValue
String
SyslogTLSEnabled.ConfigurationStatus
String
Status (OK or Risky).
SyslogTLSEnabled.IgnoreRiskSupported
String
Ignore option (Enabled or Disabled).
SyslogTLSEnabled.Id
String
Change history
Version
Change description
HDM2-1.57
Added LDAP certificate verification and the LDAPCertificateVerification, LDAPCertificateVerification.ConfigurationValue, LDAPCertificateVerification.ConfigurationStatus, and LDAPCertificateVerification.IgnoreRiskSupported fields and their corresponding configuration item ID fields.
Set security dashboard information
Set the security dashboard information.
Privilege module
OemSecurityMgmt
Locking type of the associated system
BMC configuration locking
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/SecurityDashboard
Request header:
X-Auth-Token:TOKEN
If-Match:ifmatch_value
Request body:
    "ServiceEnabled": false,
    "AccountAuthenticationSecurity":{
    "AccountSecurityType":{
          "IgnoreRiskSupported": "Enabled"}
" ServiceSecurity":{
    "ServiceSecurityType":{
          "IgnoreRiskSupported": "Disabled"}
Parameter
Value
device_ip
TOKEN
manager_id
ServiceEnabled
Security detection feature.
Boolean.
AccountAuthenticationSecurity. AccountSecurityType
Account authentication security type to be set.
Possible account authentication security types include:
·     AccountLockoutDuration.
·     AccountLockoutThreshold.
·     PasswordComplexityCheck.
·     PasswordHistoryCount.
·     PasswordValidityDays.
·     WeakPasswordVerification.
AccountAuthenticationSecurity. AccountSecurityType. IgnoreRiskSupported
Ignore option.
String. Supported options:
·     Enabled.
·     Disabled.
ServiceSecurity. ServiceSecurityType
Application service security type to be set.
Possible application service security types include:
·     CertificateRemainingTime.
·     CommunityComplexityCheck.
·     DefaultCertificateEnabled.
·     KVMEncryption.
·     RMCPPlusEnabled.
·     SMTPTLSEncryption.
·     SNMPV1V2CEnabled.
·     SyslogTLSEnabled.
·     TLSVersion.
·     VNCPasswordComplexityCheck.
ServiceSecurity. ServiceSecurityType. IgnoreRiskSupported
Ignore option.
·     Enabled.
·     Disabled.
Method and URL:
Patch https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/SecurityDashboard
Request header:
X-Auth-Token:TOKEN
Request body:
    "PasswordComplexityCheck":{
Response:
            "Id":"4",
            "Id":"3",
           "Id": "7",
            "Id":"5",
            "Id":"6",
            "Id":"2",
    "IgnoreRiskAllocationsCount": 1,
    "Oem": {
        "Public": {
            "Description": "Success"
            "ConfigurationValue": "4848",
            "Id": "10",
            "Id":"1",
            "Id":"8",
        "KVMEncryption": {
            "Id":"5",
            "Id":"3",
            "Id":"7",
            "Id":"2",
            "Id": "6",
        "TLSVersion": {
            "Id":"9",
            "Id":"4",
Response code: 200
For information about the response fields, see "Obtain security dashboard information."
Change history
Version
Change description
HDM2-1.53
Added the locking type of the associate system.
Obtain system lock resource information
Obtain system lock resource information. This resource is licensed and requires authorization through licensing before use.
For the lock range, see the online help. For detailed information, see the description for each command.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/SystemLockResource
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/SystemLockResource
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#SystemLockState.SystemLockState"
"@odata.id": "/redfish/v1/Managers/1/Oem/Public/SystemLockResource"
"@odata.type": "#SystemLockResource.v1_0_0.SystemLockResource"
"AccessIsolationEnabled": false
"BIOSLockEnabled": false
"BMCLockEnabled": false
"Description": "Resources Locked By The System"
"HardwareLockEnabled": false
"Oem": {
"Public": {
"PowerControlLockEnabled": false
"UpgradeLockEnabled": false
Response code: 200
@odata.context
String
OData description of the system lock resource model.
@odata.id
String
Access path to the system lock resource.
@odata.type
String
Type of the system lock resource.
String
Description of the system lock resource.
ServiceEnabled
Boolean
Enabling state of system lock.
Boolean
Power control lock state.
UpgradeLockEnabled
Boolean
Firmware version lock state.
HardwareLockEnabled
Boolean
Hardware configuration lock state.
BIOSLockEnabled
Boolean
BIOS configuration lock state.
BMCLockEnabled
Boolean
BMC lock state.
Boolean
Isolation state of in-band and out-of-band access.
Modify system lock resource information
Modify system lock resource information. This resource is licensed and requires authorization through licensing before use.
Privilege module
ConfigureUsers
Request
PATCH https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/SystemLockResource
Request header:
X-Auth-Token:TOKEN
Request body:
"PowerControlLockEnabled": true,
"UpgradeLockEnabled":true,
"HardwareLockEnabled": true,
"BIOSLockEnabled": true,
"BMCLockEnabled": true,
"AccessIsolationEnabled": true
Parameter
Value
device_ip
TOKEN
manager_id
ifmatch_value
Matching parameters for the request message.
It can be obtained by sending a GET request to the corresponding resource and retrieving it from the response header (corresponding to the "ETag" parameter).
ServiceEnabled
System lock enabling state.
Boolean
Boolean
UpgradeLockEnabled
Boolean
HardwareLockEnabled
Boolean
BIOSLockEnabled
Boolean
BMCLockEnabled
BMC configuration lock state.
Boolean
Boolean
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/SystemLockResource
Request header:
X-Auth-Token:TOKEN
If-Match: ifmatch_value
Request body:
Response:
"Oem": {
"Public": {
"UpgradeLockEnabled": true
Response code: 200
The response returns status code 200 to indicate operation success.
For more information about the returned fields, see "Obtain system lock resource information."
Obtain intelligent monitoring service information
Obtain intelligent monitoring service information.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/IntelligentMonitoringService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#IntelligentMonitoringService.IntelligentMonitoringService",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService",
    "@odata.type": "#IntelligentMonitoringService.v1_0_0.IntelligentMonitoringService",
    "Description": "Dynamic monitoring of system resources",
    "Drives": {
        "@odata.id": "/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService/Drives"
    "DrivesPredictDays": 4294967295,
    "DrivesPredictEnabled": false,
    "DrivesReportEnabled": false,
    "DrivesUsageThreshold": 4294967295,
    "Id": "IntelligentMonitoringService",
    "Memory": {
        "@odata.id": "/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService/Memory"
    "MemoryAlertReportingEnabled": true,
    "MemoryPageOfflineEnabled": true,
    "MemoryLevel": 2,
    "MemoryPageOfflineSizeKB": 1024,
    "MemoryPageOfflineState": "Enabled",
    "Name": "IntelligentMonitoring Service",
    "Oem": {
        "Public": {
    "Status": {
        "Health": "OK",
        "State": "Enabled"
Response code: 200
@odata.context
String
OData description of the intelligent monitoring service model.
@odata.id
String
Access path to the intelligent monitoring service resource.
@odata.type
String
Type of the intelligent monitoring service resource.
String
Description of the intelligent monitoring service resource.
Id
String
ID of the intelligent monitoring service resource.
Name
String
Name of the intelligent monitoring service resource.
ServiceEnabled
Boolean
Service enabling state.
SensorsPreServiceEnabled
Boolean
Sensor prediction enabling state.
This field is reserved.
Boolean
Enabling state of alarm predictive alarm reporting.
This field is not supported on AMD models and is displayed as null.
Boolean
Enabling status of memory alarm reporting.
This field is available only for Intel models. For non-Intel models, this field displays null.
Boolean
Memory intelligent repair.
String
Memory intelligent repair status.
Integer
Memory isolation page size.
Status.Health
String
Health state of intelligent monitoring service information.
Status.State
String
Enabling state of intelligent monitoring service information.
Memory
Object
Access path to memory resources.
Drives
Object
Access path to disk resources.
This field is not supported by X18000.
Sensors
Object
Access path to sensor resources.
DrivesPredictDays
Integer
Drive prediction days.
Boolean
Drive prediction enabling state.
DrivesReportEnabled
Boolean
Enabling state of drive prediction reporting.
Integer
Drive usage alarm threshold.
Change history
Version
Change description
HDM2-1.72
HDM2-2.11
Added the MemoryPageOfflineState, MemoryPageOfflineSizeKB, and MemoryLevel fields.
HDM2-2.04
Added a description for the MemoryAlertReportingEnabled field.
Changde the description of the MemoryPageOfflineEnabled field from "Memory page isolation state in the OS" to "Memory intelligent repair."
HDM2-1.55
Removed the license control over the interface. To use the interface, license is no longer required.
HDM2-1.54
·     Added the interface.
·     Added memory monitoring related fields.
·     Added description for the MemoryPageOfflineEnabled field.
·     Added fields DrivesPredictDays, DrivesPredictEnabled, DrivesReportEnabled, and DrivesUsageThreshold.
Configure intelligent monitoring service information
Configure intelligent monitoring service information. This interface is licensed and requires authorization through licensing before use.
Privilege module
ConfigureComponents
Request
PATCH https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/IntelligentMonitoringService
Request header:
X-Auth-Token:TOKEN
Request body:
"MemoryAlertReportingEnabled":alert_reporting_enabled,
"MemoryPageOfflineEnabled":page_offline_enabled,
"MemoryLevel": level_value,
"MemoryPageOfflineSizeKB": page_offline_size_value,
"DrivesPredictDays":drives_predictdays_value,
"DrivesPredictEnabled":drives_predict_enabled,
"DrivesReportEnabled":drives_report_enabled,
"DrivesUsageThreshold":drives_usagethreshold_value
Parameter
Value
device_ip
TOKEN
manager_id
Enabling state of memory alarm reporting.
Boolean.
This field is available only for Intel models. For non-Intel models, this field cannot be set.
Enabling state of memory intelligent repair.
Boolean.
Integer.
Setting this field might change the value of the MemoryPageOfflineState field.
MemoryLevel
Memory isolation level.
·     Level 1 (For each additional memory module, the isolation total increases by 10MB)
·     Level 2 (For each additional memory module, the isolation total increases by 15MB)
·     Level 3 (For each additional memory module, the isolation total increases by 30MB)
Integer.
DrivesPredictDays
Integer.
Boolean.
DrivesReportEnabled
Drive prediction reporting state.
Boolean.
Integer.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/Managers/manager_id/Oem/Public/IntelligentMonitoringService
Request header:
X-Auth-Token:TOKEN
Request body:
    "DrivesPredictDays": 7,
    "DrivesPredictEnabled": true,
    "DrivesReportEnabled": true,
    "DrivesUsageThreshold": 30,
    "MemoryLevel": 2,
    "MemoryPageOfflineEnabled": "true",
Response:
    "Drives": {
    "Memory": {
    "MemoryLevel": 2,
    "Oem": {
        "Public": {
            "CompletionCode": 0,
    "Status": {
        "Health": "OK",
        "State": "Enabled"
Response code: 200
Response field description
For more information about the returned fields, see "Obtain intelligent monitoring service information."
Change history
Version
Change description
HDM2-1.72
HDM2-2.11
HDM2-2.04
HDM2-1.54
·     Added support for the interface.
Obtain intelligent monitoring drive resource information
Obtain intelligent monitoring drive resource information. This interface is not supported by X18000 products.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/IntelligentMonitoringService/Drives
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.55.66/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService/Drives/
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Reponse:
    "@odata.context": "/redfish/v1/$metadata#IntelligentMonitoringServiceDrives.IntelligentMonitoringServiceDrives",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService/Drives",
    "@odata.type": "#IntelligentMonitoringServiceDrives.v1_0_0.IntelligentMonitoringServiceDrives",
    "AccumulatedPreWarningCount": 2,
    "AccumulatedRepairedCount": 1,
    "DriveList": [
            "HistoryDriveUsageRate": [
                    "FreeSpaceMB": 0,
                    "Time": "2018-06-22T07:08:00-05:00",
                    "TotalCapacityMB": 1813,
                    "UsageRatePercents": 100.0
            "Name": "/dev/loop0",
            "PredictedDriveUsageRate": [
                    "FreeSpaceMB": 0,
                    "Time": "2018-06-22T07:29:00-05:00",
    "Id": "IntelligentMonitoringServiceDrives",
    "Name": "Intelligent Monitoring Service Drives",
    "Oem": {
        "Public": {
"PredictableDrives": [
"@odata.id": "/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService/Drives/DiskFront7"
"RepairedRecords": [
"CurrentStatus": Early warning,
"Location": "Front12",
"Manufacturer": "Seagate",
"SerialNumber": "S4713TM0",
"TimeStamp": "2018-06-22T07:29:00+00:00"
Response code: 200
@odata.context
String
OData description of the intelligent monitoring drive resource.
@odata.id
String
Access path of the intelligent monitoring drive resource.
@odata.type
String
Type of the intelligent monitoring drive resource.
Id
String
ID of the intelligent monitoring drive resource.
Name
String
Name of the intelligent monitoring drive resource.
RepairedRecords
Array
Drive repairing record.
TimeStamp
String
Time.
Location
String
Physical drive slot number.
SerialNumber
String
Serial number.
Manufacturer
String
Manufacturer.
CurrentStatus
String
Drive prediction state.
·     Repaired.
·     Early warning.
Integer
Number of resolved issues.
Integer
Number of predictive alarms.
PredictableDrives
Array
Drives that support prediction.
DriveList
Array
Drive usage data.
Array
History drive usage data.
Array
Predicted drive usage data.
Name
String
Specified drive name.
FreeSpaceMB
Integer
Available drive capacity.
UsageRatePercents
Integer
Drive usage.
Time
String
Tine at which the data was recorded.
TotalCapacityMB
Integer
Total drive capacity.
Change history
Version
Change description
HDM2-1.57
HDM2-1.54
Added fields DriveList, HistoryDriveUsageRate, PredictedDriveUsageRate, Name, FreeSpaceMB, UsageRatePercents, Time, and TotalCapacityMB.
Modified the response example format.
Obtain intelligent monitoring information of a drive
Obtain intelligent monitoring information of a drive.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/IntelligentMonitoringService/Drives/drive_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
manager_id
Only value 1 is supported.
driver_id
Drive ID.
You can obtain available drive IDs from intelligent monitoring drive resource information.
Method and URL:
GET https://192.168.55.66/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService/Drives/DiskFront0/
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
SATA drive response:
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService/Drives/DiskFront0",
    "Id": "DiskFront0",
    "LoadUnloadCycles": {
        "HistoryDataList": [
                "Time": "2029-07-27T03:31:51+00:00",
                "Value": 30
                "Time": "2029-07-30T21:30:33+00:00",
                "Value": 30
        "PredictedDataList": [
                "Time": "2029-07-31T03:30:33+00:00",
                "Value": 30
                "Time": "2029-07-31T09:30:33+00:00",
                "Value": 30
        "Threshold": 0
    "MediaType": "HDD",
    "Name": "DiskFront0",
    "Oem": {
        "Public": {
    "PowerOnHours": {
                "Value": 8854
                "Value": 8855
                "Value": 8855
                "Value": 8855
        "Threshold": null
    "Protocol": "SATA",
    "ReadErrorRate": {
                "Value": 81
                "Value": 81
                "Value": 81
                "Value": 81
        "Threshold": 44
    "ReadTimes": {
                "Value": 336398914824
        "Threshold": null
    "SerialNumber": "ZAD29G96",
    "StartStopCycles": {
                "Value": 99
                "Value": 99
                "Value": 99
                "Value": 99
        "Threshold": 20
    "Temperature": {
                "Value": 32
                "Value": 33
                "Value": 33
                "Value": 33
        "Threshold": null
    "WriteTimes": {
                "Value": 65391908603
        "Threshold": null
SAS drive response:
    "Id": "DiskFront0",
                "Value": 30
                "Value": 30
                "Value": 30
                "Value": 30
        "Threshold": 300000
    "MediaType": "HDD",
    "Oem": {
        "Public": {
    "PowerOnHours": {
        "HistoryDataList": null,
        "PredictedDataList": null,
        "Threshold": null
    "Protocol": "SAS",
    "ReadErrorRate": {
        "Threshold": null
    "ReadTimes": {
        "Threshold": null
    "SerialNumber": "S7K1LSPS",
                "Value": 99
                "Value": 99
                "Value": 99
                "Value": 99
        "Threshold": 10000
    "Temperature": {
                "Value": 32
                "Value": 33
                "Value": 33
                "Value": 33
        "Threshold": 60
    "WriteTimes": {
        "Threshold": null
Response code: 200
Data type
@odata.context
String
OData description of the intelligent monitoring resource model for the drive.
@odata.id
String
Link to the intelligent monitoring resource for the drive.
@odata.type
String
Type of the intelligent monitoring resource for the drive.
Id
String
ID of the intelligent monitoring resource for the drive.
Name
String
Name of the intelligent monitoring resource for the drive.
MediaType
String
Media type of the physical drive:
·     HDD
Protocol
String
Protocol of the physical drive:
·     SAS
·     SATA
SerialNumber
String
Serial number of the drive.
Manufacturer
String
Drive manufacturer.
PowerOnHours
Object
Power-on duration and predictive data of the drive.
StartStopCycles
Object
Monitoring and predictive data for the number of power-ons of the drive.
LoadUnloadCycles
Object
Monitroing and predictive data for the number of drive loads.
WriteTimes
Object
Monitroing and predictive data for the number of drive writes.
ReadTimes
Object
Monitroing and predictive data for the number of drive reads.
ReadErrorRate
Object
Monitroing and predictive data for drive read error rates.
Temperature
Object
Monitroing and predictive data for drive temperature.
Threshold
Integer
Threshold.
HistoryDataList
Array
Historical monitoring data.
PredictedDataList
Array
Predictive data.
Time
String
Time for recording the specified data.
Value
Integer
Value for the recorded specified data.
Change history
Version
Change description
HDM2-1.55
Modify the interface to be unrestricted by licenses.
HDM2-1.54
Added this interface.
Obtain intelligent monitoring memory resource information
Obtain intelligent monitoring memory resource information.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/IntelligentMonitoringService/Memory
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
GET https://192.168.18.18/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService/ Memory
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#IntelligentMonitoringServiceMemory.IntelligentMonitoringServiceMemory",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/IntelligentMonitoringService/Memory",
    "@odata.type": "#IntelligentMonitoringServiceMemory.v1_0_0.IntelligentMonitoringServiceMemory",
    "Id": "IntelligentMonitoringServiceMemory",
    "Name": "Intelligent Monitoring Service Memory",
  "Description": "Intelligent Monitoring Memory Source Getting",
    "RepairedMemoryCount":7,
    "TotalRepairdCount":132,
            "TimeStamp":"2022-06-08T09:55:43+08:00",
            "RepairedCount":3,
            "DeviceLocator": "CPU1_CH1_D0",
            "SerialNumber": "2B6BAE3E",
            "Manufacturer": "Micron",
            "Description": "MTR"
            "CurrentStatus": "Repaired"
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the intelligent monitoring memory resource.
@odata.id
String
Link to the intelligent monitoring memory resource.
@odata.type
String
Type of the intelligent monitoring memory resource.
String
Description of the intelligent monitoring memory resource.
Id
String
ID of the intelligent monitoring memory resource.
Name
String
Name of the intelligent monitoring memory resource.
RepairedMemoryCount
Integer
Number of repaired memory modules.
This field is not supported by AMD models and is displayed as null.
TotalRepairdCount
Integer
Total number of repairs
RepairedRecords
Array
Memory repair records.
This field is not supported by AMD models and is displayed as [].
TimeStamp
String
Repair time.
RepairedCount
Integer
Number of repairs.
DeviceLocator
String
Memory label.
SerialNumber
String
Serial number.
Manufacturer
String
Memory manufacturer.
String
Repair description:
·     MRT
CurrentStatus
String
Current repair status:
·     Repaired
·     Unrepaired
Change history
Version
Change description
HDM2-2.04
Added explanations for the RepairedMemoryCount, TotalRepairdCount, and RepairedRecords fields.
Retained only the MRT value for the Description field.
HDM2-1.54
Obtain configuration information about fast OS installation
Obtain configuration information about fast OS installation of the server.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/OSInstallService
Request header:
X-Auth-Token:TOKEN
Content-Type: application/json
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.188/redfish/v1/Managers/1/Oem/Public/OSInstallService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#OSInstallService.OSInstallService",
    "@odata.id": "/redfish/v1/Managers/1/Oem/Public/OSInstallService",
    "@odata.type": "#OSInstallService.v1_0_0.OSInstallService",
    "Description": "OS Install Service",
    "Id": "OSInstallService",
    "Image": {
        "ImageName": "CentOS-8.5.2111-x86_64-dvd1.iso",
        "Path": "/data/share",
        "ServerAddress": "172.14.81.158",
        "ServerType": "nfs",
        "UserName": ""
    "Name": "OS Install Service",
    "Oem": {
        "Public": {
    "ServiceStatus": "Pending"
Response code:200
Data type
@odata.context
String
OData description of the resource model for the fast OS installation service.
@odata.id
String
Link to the resource node for the fast OS installation service.
@odata.type
String
Resource type of the fast OS installation service.
String
Resource description of the fast OS installation service.
Id
String
Resource ID of the fast OS installation service.
Name
String
Resource name of the fast OS installation service.
ServiceEnabled
Boolean
Enabling status of the service.
ServiceStatus
String
Current status of the service:
·     InitialImage transfer has not started.
·     CompletedImage transfer is completed.
·     PendingWaiting for image transfer.
·     RunningImage transfer is in progress.
Object
Image.Path
String
Path where the image resides.
Image.ImageName
String
Image name.
Image.ServerAddress
String
Server address.
Image.ServerType
String
Server type, including CIFS and NFS.
Image.UserName
String
Username.
The server returns status code 200 for a successful operation.
Create a fast OS installation configuration service
Create a fast OS installation configuration service.
Privilege module
OemVmm
Request
PATCH https://device_ip/redfish/v1/Managers/manager_id/Oem/Public/OSInstallService
Request header:
X-Auth-Token:TOKEN
Request body:
"Image":{
            "Path": path,
            "ImageName": imagename,
            "ServerAddress": serveraddress,
            "ServerType": servertype,
            "UserName": username,
            "Password": password
Parameter
Value
device_ip
TOKEN
ServiceEnabled
Boolean
Object
Image.Path
String
Image.ImageName
String
Image name.
Image.ServerAddress
String
Server address.
Image.ServerType
String
Image.UserName
String
Username (only supported by CIFS).
Image.Password
String
Password (only supported by CIFS).
Method and URL:
PATCH https://192.168.18.188/redfish/v1/Managers/1/Oem/Public/OSInstallService
Request header:
X-Auth-Token:TOKEN
Request body:
    "ServiceEnabled":true,
    "Image":{
        "Path":"/homes",
        "ImageName":"rhel-baseos-9.0-x86_64-dvd.iso",
        "ServerAddress":"172.14.81.158",
        "ServerType":"cifs",
        "UserName":"gfy",
        "Password":"111111"
Response:
    "Image": {
        "ImageName": "rhel-baseos-9.0-x86_64-dvd.iso",
        "Path": "/homes",
        "ServerType": "cifs",
        "UserName": "gfy"
    "Oem": {
        "Public": {
Response code:200
For information about the response fields, see "Obtain configuration information about fast OS installation."
Obtain system diagnosis information
Obtain system diagnosis configuration information.
Privilege module
Login
Request
GET   https://device_ip/redfish/v1/Managers/manager_id/DiagnosticService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Managers/Members/1/DiagnosticService/$entity",
    "@odata.id": "/redfish/v1/Managers/1/DiagnosticService",
    "@odata.type": "#DiagnosticService.v1_0_0.DiagnosticService",
    "Actions": {
        "#DiagnosticService.DeleteScreenShot": {
            "target": "/redfish/v1/Managers/1/DiagnosticService/Actions/DiagnosticService.DeleteScreenShot"
        "#DiagnosticService.DeleteVideo": {
            "target": "/redfish/v1/Managers/1/DiagnosticService/Actions/DiagnosticService.DeleteVideo"
        "#DiagnosticService.ExportVideo": {
            "target": "/redfish/v1/Managers/1/DiagnosticService/Actions/DiagnosticService.ExportVideo"
        "#DiagnosticService.PlayVideo": {
            "target": "/redfish/v1/Managers/1/DiagnosticService/Actions/DiagnosticService.PlayVideo"
    "DiagnosticDescription": "",
    "DiagnosticDeviceList": {
        "Memory": "Healthy",
        "PCH": "Healthy",
        "PCIe": "Healthy",
        "PCIeUnderPCH": "Healthy",
        "Processor": "Healthy",
        "SATAController": "Healthy",
        "USB": "Healthy",
        "sSATAController": "Healthy",
        "tSATAController": "Healthy"
    "DiagnosticResult": "Failed",
    "FDIStartupMode": "Disabled",
    "Id": "Diagnostic Configuration Information",
    "MiniModeEnabled": true,
    "Name": "Diagnostic Configuration Information",
    "Oem": {
        "Public": {
    "ScreenShot": {
    "VideoConfig": {
    "Videos": {
Response code: 200
Data type
@odata.context
String
OData description of the diagnosis resource model.
@odata.id
String
Link to the diagnosis resource.
@odata.type
String
Type of the diagnosis resource.
MiniModeEnabled
Boolean
Whether minimum configuration startup is enabled. Options:
·     true—Enabled.
·     false—Disabled.
FDIStartupMode
String
Whether diagnosis isolation is enabled. Options:
·     Disabled—Disables diagnosis isolation.
·     DiagnosticModePerforms only diagnosis.
·     FDIPerforms both diagnosis and isolation.
DiagnosticResult
String
Diagnosis result:
·     Success.
·     Failed.
Object
Diagnosis device list.
Processor
String
CPU diagnosis result:
·     Healthy.
·     Unhealthy.
·     nullNo errors are detected.
Memory
String
Memory diagnosis result:
·     Healthy.
·     Unhealthy.
·     null—No errors are detected.
PCIe
String
PCIe device diagnosis result for the CPU root port:
·     Healthy.
·     Unhealthy.
PCH
String
Device diagnosis result for PCH:
·     Healthy.
·     Unhealthy.
SATAController
String
Device diagnosis result for the PCH SATA controller:
·     Healthy.
·     Unhealthy.
sSATAController
String
Device diagnosis result for the PCH sSATA controller:
·     Healthy.
·     Unhealthy.
tSATAController
String
Device diagnosis result for the PCH tSATA controller:
·     Healthy.
·     Unhealthy.
USB
String
USB device diagnosis result:
·     Healthy.
·     Unhealthy.
PCIeUnderPCH
String
PCIe device diagnosis result for the PCH root port:
·     Healthy.
·     Unhealthy.
String
Diagnosis description.
Change history
Version
Change description
HDM2-2.04
Configure system diagnosis settings
Configure system diagnosis settings.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/Managers/manager_id/DiagnosticService
Request header:
X-Auth-Token:TOKEN
Request body:
"MiniModeEnabled":true,
"FDIStartupMode":"Disabled"
Parameter
Value
device_ip
TOKEN
system_id
ID of the system resource.
MiniModeEnabled
Boolean
Minimum configuration startup mode.
FDIStartupMode
String
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
    "Actions": {
        "PCH": "Healthy",
        "PCIe": "Healthy",
        "USB": "Healthy",
    "Oem": {
        "Public": {
    "ScreenShot": {
    "VideoConfig": {
    "Videos": {
Response code: 200
For information about the response fields, see "Obtain system diagnosis information."
Change history
Version
Change description
HDM2-2.04
Perform node control on a multi-node device
Perform node control on a multi-node device. Only the E3300 G6 supports this task.
Privilege module
OemDiagnosis
Request
Method and URL:
POST
https://device_ip/redfish/v1/Managers/manager_id/Actions/Oem/Public/Manager.NodeSwitch
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/<str>/Actions/Oem/<str>/Manager.NodeSwitch/
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
                 "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
Detailed message information.
MessageArgs
Integer
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.09
Added the interface. HDM3 does not support the interface.
Manually take screen snapshots
Descritpion
Manually take screen snapshots.
Privilege module
ConfigureComponents
Request
Method and URL:
POST https://device_ip/redfish/v1/Managers/manager_id/DiagnosticService/Actions/DiagnosticService.CaptureScreenShot
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
manager_id
Method and URL:
POST https://192.168.18.18/redfish/v1/Managers/1/DiagnosticService/Actions/DiagnosticService.CaptureScreenShot
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Integer
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM3-1.18
Added the interface. Only HDM3 supports the interface.
Operations on account service resources
Obtain account service information
Obtain information about the account service from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#AccountService.AccountService",
    "@odata.id": "/redfish/v1/AccountService",
    "@odata.type": "#AccountService.v1_7_0.AccountService",
    "ADService": {
        "@odata.id": "/redfish/v1/AccountService/ADService"
    "AccountLockoutDuration": 5,
    "AccountLockoutThreshold": 5,
    "Accounts": {
        "@odata.id": "/redfish/v1/AccountService/Accounts"
     "Actions": {
        "Oem": {
            "Public": {
                "#CertificateService.ImportRootCertificate": {
"#AccountService.ExportWeakPasswordDictionary": {
                    "target": "/redfish/v1/AccountService/Actions/Oem/Public/AccountService.ExportWeakPasswordDictionary"
                "#AccountService.ImportWeakPasswordDictionary": {
                    "target": "/redfish/v1/AccountService/Actions/Oem/Public/AccountService.ImportWeakPasswordDictionary"
                    "target": "/redfish/v1/AccountService/Actions/Oem/Public/CertificateService.ImportRootCertificate"
                "#SSHCiphers.BindUser": {
                    "target": "/redfish/v1/AccountService/Actions/Oem/Public/SSHCiphers/SSHCiphers.BindUser"
                "#SSHCiphers.DeleteUser": {
                    "target": "/redfish/v1/AccountService/Actions/Oem/Public/SSHCiphers/SSHCiphers.DeleteUser"
                "#SSHCiphers.ImportSSHCiphers": {
                    "target": "/redfish/v1/AccountService/Actions/Oem/Public/SSHCiphers/SSHCiphers.ImportSSHCiphers"
                "#LDAPService.ImportLDAPCertificate":{
                    "target":"/redfish/v1/AccountService/Actions/Oem/Public/LDAPService.ImportLDAPCertificate"
"Description": "BMC User Accounts",
    "Id": "AccountService",
    "LDAPService": {
        "@odata.id": "/redfish/v1/AccountService/LDAPService"
    "MaxPasswordLength": 40,
    "MinPasswordLength": 8,
    "Name": "Account Service",
    "Oem": {
        "Public": {
            "CertificateService": {
                "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService"
            "RoleNames": {
                "@odata.id": "/redfish/v1/AccountService/Roles/Oem/Public/RoleNames"
            "Description": "Success",
            "PasswordRule": {
                "PasswordComplexityCheckEnabled": true,
                "PasswordValidityDays": 0,
                "PreviousPasswordsDisallowedCount": 0,
"WeakPasswordDictionaryEnabled": false
"WeakPasswordDictionaryName":"pw_dict_default.txt",
            "TwoFactorAuthenticationInformation": {
                "OTPServerAddress": "",
                "OTPServerPort": 1812,
                "OTPServerSharedKey": "",
                "TwoFactorAuthenticationStateEnabled": false
    "Roles": {
        "@odata.id": "/redfish/v1/AccountService/Roles"
    "SSHCiphers": {
        "@odata.id": "/redfish/v1/AccountService/Oem/Public/SSHCiphers"
    "Status": {
        "Health": "OK",
        "State": "Enabled"
Response code: 200
Data type
@odata.context
String
OData description of the account service resource model.
@odata.id
String
Link to the account service resource.
@odata.type
String
Type of the account service resource.
String
Description of the account service resource.
Id
String
ID of the account service resource.
Name
String
Name of the account service resource.
LDAPService
Object
Link to the LDAPService resource.
MinPasswordLength
Integer
Minimum password length.
MaxPasswordLength
Integer
Maximum password length.
Integer
Number of consecutive login failures that will cause a user account to be locked.
Integer
Amount of locking time before a locked account can be used again.
ADService
Object
Link to the ADService resource.
Accounts
Object
Link to the account resource.
Actions.Oem.Public
Custom executable actions for the AccountService resource.
Object
Link to the root certificate file import operation.
Object
Link to the operation of binding a user to an SSH public key.
Object
Link to the operation of unbinding SSH public key from a user.
Object
Link to the SSH public key import operation.
Object
Import the LDAP CA certificate file.
Oem.Public
Custom properties of the account service.
CertificateService
Object
Link to the CertificateService resource.
RoleNames
Object
Link to the role configuration resource.
PasswordRule.PasswordComplexityCheckEnabled
Boolean
Enabling status of password complexity check.
PasswordRule.PreviousPasswordsDisallowedCount
Integer
Disable users from changing the password to one of the specified number of most recent historical passwords.
The value range is 0 to 5. 0 indicates no restriction on using historical passwords.
PasswordRule.PasswordValidityDays
Integer
PasswordRule.WeakPasswordDictionaryEnabled
Boolean
Enable weak password dictionary.
String
Name of the weak password dictionary.
Object
This field is not available for blade servers.
Boolean
Whether to enable two-factor authentication.
OTPServerAddress
String
Address of the OTP server.
OTPServerPort
Integer
Service port of the OTP server.
OTPServerSharedKey
String
Shared key of the OTP server. A string of 1 to 64 characters.
Roles
Object
Link to the Roles resource.
SSHCiphers
Object
Link to the SSHCiphers resource.
ServiceEnabled
Boolean
Enabling status of the account service.
Status.Health
String
Health status of the account service.
Status.State
String
Change history
Version
Change description
HDM2-1.59
Added the WeakPasswordDictionaryName field.
HDM2-1.57
Added the #LDAPService.ImportLDAPCertificate field.
Edit account service settings
Edit the settings of the account service for the server.
Privilege module
ConfigureUsers
Request
Method and URL:
PATCH https://device_ip/redfish/v1/AccountService
Request header:
X-Auth-Token:TOKEN
Request body:
    "Oem": {
        "Public": {
            "PasswordRule": {
               "PreviousPasswordsDisallowedCount": 5,
"PasswordValidityDays": 15,
"TwoFactorAuthenticationStateEnabled": false,
"OTPServerAddress": "192.168.1.36",
"OTPServerSharedKey": "admin"
Parameter
Value
device_ip
TOKEN
ifmatch_value
Entity tag (ETag) that uniquely represents the requested resource.
To obtain the entity tag value of a resource, send a GET request to it and then obtain the ETag value from the response header.
Integer
Amount of time before a locked account can be used again.
Integer
Number of consecutive login failures that will cause a user account to be locked. Number of incorrect password attempts. If the specified number is exceeded, the user will be locked out.
PassWordRule
Object
Boolean
Integer
Integer
Boolean
Object
Boolean
OTPServerAddress
String
OTPServerPort
Integer
OTPServerSharedKey
String
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
If-Match: W/"6e8c96325a9b7c6a6e5e9f23616fbce0"
Request body:
    "Oem":{
        "Public":{
            "PassWordRule":{
                "PasswordComplexityCheckEnabled":true
            "TwoFactorAuthenticationInformation":{
                "TwoFactorAuthenticationStateEnabled":false,
                "OTPServerAddress":"192.168.1.36",
                "OTPServerPort":1812,
                "OTPServerSharedKey":"admin"
Response:
    "ADService": {
    "Accounts": {
    "Actions": {
        "Oem": {
            "Public": {
                    "target": "/redfish/v1/AccountService/Actions/Oem/Public/LDAPService.ImportLDAPCertificate"
    "LDAPService": {
    "Oem": {
        "Public": {
            "RoleNames": {
            "PasswordRule": {
                "OTPServerSharedKey": "admin",
    "Roles": {
    "SSHCiphers": {
    "ServiceEnabled
": true,
    "Status": {
        "Health": "OK",
        "State": "Enabled"
Response code: 200
For information about the response fields, see "Obtain account service information."
Change history
Version
Change description
HDM2-1.53
Added the locking type of the associated system.
Obtain user account collection information
Obtain information about all user accounts from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Accounts
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Non-administrator users can obtain only their own account collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Accounts
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
          "@odata.context": "/redfish/v1/$metadata#ManagerAccountCollection.ManagerAccountCollection",
    "@odata.id": "/redfish/v1/AccountService/Accounts",
    "@odata.type": "#ManagerAccountCollection.ManagerAccountCollection",
"Members": [
            "@odata.id": "/redfish/v1/AccountService/Accounts/1"
            "@odata.id": "/redfish/v1/AccountService/Accounts/2"
"Name": "Accounts Collection",
"Oem": {
      "Public": {
Data type
@odata.context
String
OData description of the user account collection resource model.
@odata.id
String
Link to the user account collection resource.
@odata.type
String
Type of the user account collection resource.
Name
String
Name of the user account collection resource.
Members
Integer
Link to the user account.
Members@odata.count
Integer
Number of user accounts.
Members@odata.id
String
Link to a user account resource.
Obtain user account information
Obtain information about a specific user account from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Accounts/user_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
user _id
ID of the user.
You can obtain available user account resource IDs from user account collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Accounts/2
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#ManagerAccount.ManagerAccount",
    "@odata.id": "/redfish/v1/AccountService/Accounts/2",
    "@odata.type": "#ManagerAccount.v1_6_0.ManagerAccount",
    "Description": "Default Account",
    "Enabled": true,
    "Id": "2",
    "Links": {
        "Roles": {
            "@odata.id": "/redfish/v1/AccountService/Roles/Administrator"
    "Locked": false,
    "Name": "Default Account",
    "Oem": {
        "Public": {
            "IPMIEnable": true,
            "SnmpEncryptPwdInit": true,
            "SnmpV3AccessPermission": "read_only",
            "SnmpV3AuthProtocol": "SHA",
            "SnmpV3Enable": false,
            "SnmpV3Password": null,
            "SnmpV3PrivProtocol": "DES",
            "WebEnable": true,
"DefaultPasswordModifyPolicy":"NotModify"
    "Password": null,
    "RoleId": "Administrator",
    "UserName": "admin"
Response code: 200
Date type
@odata.context
String
OData description of the user account service resource model.
@odata.id
String
Link to the user account service resource.
@odata.type
String
Type of the user account service resource.
String
Description of the user account service resource.
Enabled
Boolean
Id
Integer
User ID.
Links.Roles
String
Links to role privileges.
Locked
Boolean
Account lockout status.
Name
String
Name of the user account resource.
Oem.Public.IPMIEnable
Boolean
Enabling status of the IPMI access privilege.
Oem.Public.WebEnable
Boolean
Enabling status of the Web extended privilege.
RoleId
String
Role name. Supported options:
·     Administrator.
·     Operator.
·     User.
·     None.
·     Custom_name_1. By default, the custom role name is CustomRole1.
·     Custom_name_2. By default, the custom role name is CustomRole2.
·     Custom_name_3. By default, the custom role name is CustomRole3.
·     Custom_name_4. By default, the custom role name is CustomRole4.
·     Custom_name_5. By default, the custom role name is CustomRole5.
UserName
String
Username.
Password
null
This field displays null.
Oem.Public.SnmpV3Enable
Boolean
Enabling status of SNMPv3.
Oem.Public.SnmpEncryptPwdInit
Boolean
Specifies whether the SNMP encryption password is set separately. Value true indicates that the encryption password is set separately, and value false indicates that the encryption password is not set separately.
Oem.Public.SnmpV3Password
String
SNMPv3 encryption password.
This field always displays null.
Oem.Public.SnmpV3AccessPermission
String
SNMPv3 access privilege. Supported options:
·     read_only.
·     read_write.
When the Oem.Public.SnmpV3Enable field is set to false, this field returns read_only by default.
Oem.Public.SnmpV3AuthProtocol
String
SNMPv3 authentication algorithm. Supported options:
·     SHA.
·     MD5.
·     SHA256.
·     SHA384.
·     SHA512.
When the Oem.Public.SnmpV3Enable field is set to false, this field returns SHA by default.
Oem.Public.SnmpV3PrivProtocol
String
SNMPv3 encryption algorithm. Supported options:
·     DES.
·     AES.
·     AES192.
·     AES256.
When the Oem.Public.SnmpV3Enable field is set to false, this field returns DES by default.
Oem.Public.DefaultPasswordModifyPolicy
String
Default password change policy. Supported options:
·     NotModify.
·     ForcedModify.
·     Optional.
Non-administrator users can obtain only their own account information.
Change history
Version
Change description
HDM2-2.04
HDM3-2.03
Added the Oem.Public.DefaultPasswordModifyPolicy field.
Add a user account
Add user accounts to the server.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/Accounts
Request header:
X-Auth-Token:TOKEN
Request body:
"Enabled": true,
 "Password": password,
 "UserName": name,
"Id": userid,
"RoleId": role,
 "Locked": false,
    "Oem": {
        "Public": {
            "RSAEncryptionEnabled": true,
"IPMIEnable": true,
            "WebEnable": true,
            "SnmpV3Enable": true,
            "SnmpV3Password": snmpv3password,
Parameter
Value
device_ip
TOKEN
Enabled
Enable or disable the user account.
Boolean.
UserName
Username.
String.
Up to 32 characters are supported.
Id
(Optional.) User sequence number.
The value range is 1 to 16.
The specified ID cannot be the same as an existing ID.
String.
Whether to support RSA encryption. This field is available only when you set a password on the webpage.
Boolean.
Password
Password.
Up to 40 characters.
String.
RoleId
Role name.
·     Administrator.
·     Operator.
·     User.
·     None.
Locked
Boolean. Supported option:
·     false.
Enable or disable the IPMI access privilege.
Boolean.
When the RoleId field is Administrator or Operator, this field can only be set to true.
Enable or disable the Web extended privilege.
Boolean.
Enable or disable SNMPv3
Boolean.
·     read_only.
·     read_write.
Snmpv3 encryption password.
String.
·     SHA.
·     MD5.
·     SHA256.
·     SHA384.
·     SHA512..
·     DES.
·     AES.
·     AES192.
·     AES256..
Encryption algorithms AES192 and AES256 can only be used in combination with authentication algorithms SHA256, SHA384, or SHA512.
String
·     NotModify.
·     ForcedModify.
·     Optional.
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/Accounts
Request header:
X-Auth-Token:TOKEN
Request body:
 "Enabled": true,
 "Password": "test@test123",
 "UserName": "User123",
 "Id":"3",
 "Locked": false,
    "Oem": {
        "Public": {
"IPMIEnable": true,
            "WebEnable": true,
Response:
    "Enabled": true,
    "Id": "3",
    "Links": {
        "Roles": {
    "Locked": false,
    "Oem": {
        "Public": {
            "IPMIEnable": true,
            "SnmpEncryptPwdInit": false,
            "WebEnable": true,
    "Password": null,
Response code: 201
The server returns status code 201 for a successful operation.
For information about the response fields, see "Obtain user account information."
Change history
Version
Change description
HDM2-2.04
HDM3-2.03
HDM2-2.02
The length of the value for the UserName field changes from 16 characters to 32 characters.
HDM2-1.53
HDM2-1.19
Deleted the restrictions of supported characters for an SNMPv3 encryption password.
HDM2-1.18
Changed the Id field to be optional.
HDM2-1.14
Removed the description table for the response fields. For more information, see "Obtain user account information."
Edit user account settings
Edit the settings of a specific user account.
Privilege module
ConfigureUsers/ConfigureSelf
BMC configuration locking (except when users configure passwords)
Request
Method and URL:
PATCH https://device_ip/redfish/v1/AccountService/Accounts/userid
Request header:
X-Auth-Token:TOKEN
Request body:
 "Enabled": true,
 "UserName": name,
 "RoleId": role,
 "Locked": false,
"Oem": {
        "Public": {
"IPMIEnable": true,
            "WebEnable": true,
Parameter
Value
device_ip
userid
ID of the user.
Integer.
TOKEN
ifmatch_value
Enabled
Boolean.
UserName
Username.
Up to 32 characters.
String.
Boolean
Password
Password.
String.
RoleId
Role name.
·     Administrator.
·     Operator.
·     User.
·     None.
Locked
·     false.
Boolean.
Boolean.
Boolean.
·     read_only.
·     read_write.
String.
·     SHA.
·     MD5.
·     SHA256.
·     SHA384.
·     SHA512.
·     DES.
·     AES.
·     AES192.
·     AES256.
String
·     NotModify.
·     ForcedModify.
·     Optional.
Non-administrator users can edit only their own passwords and their modification of other fields will not take effect.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService/Accounts/3
Request header:
X-Auth-Token:TOKEN
Request body:
 "Enabled": true,
 "RoleId": "User",
 "Locked": false,
    "Oem": {
        "Public": {
            "IPMIEnable": true,
            "WebEnable": true,
            "SnmpV3Password": "Password@_",
Response:
    "@odata.id": "/redfish/v1/AccountService/Accounts/1",
    "Enabled": true,
    "Id": "3",
    "Links": {
        "Roles": {
    "Locked": false,
    "Oem": {
        "Public": {
            "IPMIEnable": true,
            "WebEnable": true,
    "Password": null,
    "RoleId": "User",
Response code: 200
Change history
Version
Change description
HDM2-2.04
HDM3-2.03
HDM2-2.02
HDM2-1.53
HDM2-1.19
Delete a user account
Delete a specific user account from the server.
Privilege module
ConfigureUsers
Request
Method and URL:
DELETE https://device_ip/redfish/v1/AccountService/Accounts/user_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
user_id
ID of the user.
Integer.
Method and URL:
DELETE https://192.168.18.18/redfish/v1/AccountService/Accounts/3
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
       "@Message.ExtendedInfo": [
               "@odata.type": "#Message.v1_1_1.Message",
               "Message": "The account was successfully removed.",
               "MessageArgs": [],
               "MessageId": "Base.1.8.1.AccountRemoved",
               "MessageSeverity": "OK",
               "Resolution": "No resolution is required."
        "code":"Base.1.8.1.AccountRemoved",
        "message":"The account was successfully removed."
Response code: 200
Data type
code
String
String of a specific message ID in the message registry.
message
String
Readable error message corresponding to the message in the message registry.
Extended information of the message.
@odata.type
String
OData description of the message resource.
MessageId
String
Message ID.
Message
String
Details of the message.
MessageArgs
Array
Message arguments.
MessageSeverity
String
Severity level. Supported options:
·     OK.
·     Warning.
·     Critical.
Resolution
String
Recommended actions for the error.
Change history
Version
Change description
HDM2-2.04
Added the error node before Message.ExtendedInfo and added the code and message fields under the error node.
HDM2-1.53
Obtain role collection information
Obtain information about all roles from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Roles
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Non-administrator users can obtain only their own role collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Roles
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#RoleCollection.RoleCollection",
    "@odata.id": "/redfish/v1/AccountService/Roles",
    "@odata.type": "#RoleCollection.RoleCollection",
    "Members": [
            "@odata.id": "/redfish/v1/AccountService/Roles/Operator"
            "@odata.id": "/redfish/v1/AccountService/Roles/User"
            "@odata.id": "/redfish/v1/AccountService/Roles/CustomRole1"
            "@odata.id": "/redfish/v1/AccountService/Roles/CustomRole2"
            "@odata.id": "/redfish/v1/AccountService/Roles/CustomRole3"
            "@odata.id": "/redfish/v1/AccountService/Roles/CustomRole4"
            "@odata.id": "/redfish/v1/AccountService/Roles/CustomRole5"
            "@odata.id": "/redfish/v1/AccountService/Roles/None"
    "Members@odata.count": 9,
"Name": "Roles Collection",
"Oem": {
    "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the role collection resource model.
@odata.id
String
Link to the role collection resource.
@odata.type
String
Type of the role collection resource.
Members
Array
Role resources. Supported options:
·     Operator.
·     Administrator.
·     User.
·     None.
Members@odata.count
Integer
Number of role types.
Obtain role information
Obtain information about a specific role from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Roles/role_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
role_id
Role ID.
You can obtain available role names from role collection resource information.
Non-administrator users can obtain only their own role information.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Roles/Operator
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Role.Role(*)",
    "@odata.id": "/redfish/v1/AccountService/Roles/Operator",
    "@odata.type": "#Role.v1_3_0.Role",
    "AssignedPrivileges": [
        "ConfigureComponents",
        "Login",
        "ConfigureSelf"
    "Description": "Operator User Role",
    "Id": "Operator",
    "IsPredefined": true,
    "Name": "User Role",
    "Oem": {
        "Public": {
    "OemPrivileges": [
        "OemKvm",
        "OemVmm",
        "OemSecurityMgmt",
        "OemPowerControl",
        "OemSystemAudit"
Response code: 200
Date type
@odata.context
String
OData description of the role resource model.
@odata.id
String
Link to the role resource.
@odata.type
String
Type of the role resource.
AssignedPrivileges
Array
Privileges assigned to the role. Supported options:
·     ConfigureUsersConfigure the settings of all user accounts.
·     ConfigureComponentsConfigure components managed by the account service.
·     LoginLog in to the Redfish service and read resources.
·     ConfigureSelfConfigure the settings of the current user account.
String
Description of the role resource.
Id
String
Role name.
IsPredefined
Boolean
Whether the role is a predefined role.
Name
String
Role resource name.
OemPrivileges
Array
Custom access privileges for the server. If no custom privileges are specified, [] is displayed.
Supported options:
·     OemKvm.
·     OemVmm.
·     OemSecurityMgmt.
·     OemPowerControl.
·     OemDiagnosis.
·     OemSystemAudit.
Edit role settings
Edit the settings for a specific role.
Privilege module
ConfigureUsers
Request
Method and URL:
PATCH https://device_ip/redfish/v1/AccountService/Roles/role_id
Request header:
X-Auth-Token:TOKEN
Request body:
        "ConfigureSelf"
    "OemPrivileges": [
        "OemKvm",
        "OemVmm",
        "OemSecurityMgmt",
        "OemPowerControl",
        "OemDiagnosis",
        "OemSystemAudit"
Parameter
Value
device_ip
role_id
Role ID.
TOKEN
ifmatch_value
AssignedPrivileges
Array
Supported options:
·     ConfigureSelf.
·     ConfigureComponents.
OemPrivileges.OemKvm
Array
Supported options:
·     OemKvm.
·     OemVmm.
·     OemSecurityMgmt.
·     OemPowerControl.
·     OemDiagnosis.
·     OemSystemAudit.
The role settings are editable only for customized roles.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService/Roles/CustomRole1
Request header:
X-Auth-Token:TOKEN
Request body:
        "ConfigureSelf"
    "OemPrivileges": [
        "OemKvm",
        "OemVmm",
        "OemSecurityMgmt",
        "OemPowerControl",
        "OemDiagnosis",
        "OemSystemAudit"
Response:
    "@odata.id": "/redfish/v1/AccountService/Roles/CustomRole1",
        "Login",
        "ConfigureSelf"
    "Description": "CustomRole1 User Role",
    "Id": "CustomRole1",
    "Oem": {
        "Public": {
    "OemPrivileges": [
        "OemKvm",
        "OemVmm",
        "OemSecurityMgmt",
        "OemPowerControl",
        "OemDiagnosis",
        "OemSystemAudit"
Response code: 200
For information about the response fields, see "Obtain role information."
Change history
Version
Change description
HDM2-1.53
Obtain role names
Obtain role names from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Roles/Oem/Public/RoleNames
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Roles/Oem/Public/RoleNames
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#RoleNames.RoleNames",
    "@odata.id": "/redfish/v1/AccountService/Roles/Oem/Public/RoleNames",
    "@odata.type": "#RoleNames.v1_0_0.RoleNames",
    "Administrator": "Administrator",
    "CustomRole1Name": "CustomRole1",
    "CustomRole2Name": "CustomRole2",
    "CustomRole3Name": "CustomRole3",
    "CustomRole4Name": "CustomRole4",
"CustomRole5Name": "CustomRole5",
"Oem": {
    "Public": {
    "Operator": "Operator",
    "User": "User"
Response code: 200
Date type
@odata.context
String
@odata.id
String
@odata.type
String
CustomRole1Name
String
Name of custom role 1. The name is case-sensitive and must be in the range of 1 to 16 characters. Only letters, digits, dots (.), hyphens (-), underscores (_), and at signs (@) are allowed.
CustomRole2Name
String
Name of custom role 2. The name is case-sensitive and must be in the range of 1 to 16 characters. Only letters, digits, dots (.), hyphens (-), underscores (_), and at signs (@) are allowed.
CustomRole3Name
String
Name of custom role 3. The name is case-sensitive and must be in the range of 1 to 16 characters. Only letters, digits, dots (.), hyphens (-), underscores (_), and at signs (@) are allowed.
CustomRole4Name
String
Name of custom role 4. The name is case-sensitive and must be in the range of 1 to 16 characters. Only letters, digits, dots (.), hyphens (-), underscores (_), and at signs (@) are allowed.
CustomRole5Name
String
Name of custom role 5. The name is case-sensitive and must be in the range of 1 to 16 characters. Only letters, digits, dots (.), hyphens (-), underscores (_), and at signs (@) are allowed.
Administrator
String
Administrator.
Operator
String
Operator.
User
String
User.
Edit a role name
Edit the name of a specific role.
Privilege module
ConfigureUsers
Request
Method and URL:
PATCH https://device_ip/redfish/v1/AccountService/Roles/Oem/Public/RoleNames
Request header:
X-Auth-Token:TOKEN
Request body:
"CustomRole1Name": "CustomRole1name",
"CustomRole2Name": "CustomRole2name",
"CustomRole3Name": "CustomRole3name",
"CustomRole4Name": "CustomRole4name",
"CustomRole5Name": "CustomRole5name"
Parameter
Value
device_ip
TOKEN
ifmatch_value
CustomRole1Name
String
CustomRole2Name
String
CustomRole3Name
String
CustomRole4Name
String
CustomRole5Name
String
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService/Roles/Oem/Public/RoleNames
Request header:
X-Auth-Token:TOKEN
Request body:
    "CustomRole1Name": "abc",
    "CustomRole2Name": "123",
    "CustomRole3Name": "zxc",
    "CustomRole4Name": "h3c",
    "CustomRole5Name": "vbn",
Response:
"Oem": {
    "Public": {
    "User": "User"
Response code: 200
For information about the response fields, see "Obtain role names."
Change history
Version
Change description
HDM2-1.53
Obtain the LDAP service resource
Obtain the LDAP service resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/LDAPService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/LDAPService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#AccountService/LDAPService",
  "@odata.id": "/redfish/v1/AccountService/LDAPService",
  "@odata.type": "#LDAPService.v1_0_0.LDAPService",
  "BindDN": "",
  "BindPassword": null,
  "CertificateName":"",
  "CertificateVerificationEnabled": false,
  "CertificateVerificationLevel":"Demand",
  "CommonNameType": "IP",
  "Id": "LDAPService",
  "LDAPControllers": {
    "@odata.id": "/redfish/v1/AccountService/LDAPService/LDAPControllers"
  "LDAPPort": 389,
  "LDAPServerAddress": "",
  "LDAPServiceEnabled": false,
  "Name": "LDAP Controller Collection",
  "Oem": {
    "Public": {
  "SSLEncryptionEnabled": false,
  "UserDomain": "",
  "UserIdentification": "cn"
Response code: 200
Date type
@odata.context
String
OData description of the LDAP service resource.
@odata.id
String
Link to the LDAP service resource.
@odata.type
String
Type of the LDAP service resource.
LDAPServiceEnabled
Boolean
Enabling status of the LDAP service.
LDAPControllers
Object
Domain controller collection.
@odata.id: Link to domain controller collection.
CommonNameType
String
Common name type.
Only IP and FQDN are supported in the current software version.
LDAPServerAddress
String
Server address.
LDAPPort
Integer
Port number.
BindDN
String
LDAP proxy user identifier.
Up to 255 characters.
BindPassword
String
LDAP proxy user authentication password.
Up to 48 characters.
Boolean
Encryption type.
Value false indicates no encryption, and value true indicates SSL encryption.
UserDomain
String
User domain for the domain controller.
UserIdentification
String
User login attribute.
Currently supports only cn and uid.
Boolean
Whether LDAP certificate authentication is enabled.
String
LDAP certificate authentication level:
·     DemandNot allows login when authentication fails,
·     AllowAllows continuing login when authentication fails.
CertificateName
String
LDAP certificate name.
Change history
Version
Change description
HDM2-1.53
Added the CertificateVerificationEnabled, CertificateVerificationLevel, and CertificateName fields.
Edit the LDAP service resource
Edit the LDAP service resource.
Privilege module
ConfigureUsers
Locking type of the associated system
Request
Method and URL:
PATCH https://device_ip/redfish/v1/AccountService/LDAPService
Request header:
X-Auth-Token:TOKEN
Request body:
"LDAPServiceEnabled": true,
"LDAPServerAddress": "192.168.1.2",
"LDAPPort": 635,
"BindDN": "cn=Manager,dc=example,dc=com",
"BindPassword": "test123",
"UserDomain": "cn=Manager,dc=example,dc=com",
"UserIdentification": "cn",
"CertificateVerificationEnabled":true,
"CertificateVerificationLevel":"Allow",
"Oem":{
   "Public":{
Parameter
Value
device_ip
TOKEN
LDAPServiceEnabled
Boolean.
CommonNameType
Common name type.
String.
LDAPServerAddress
Server address.
String.
LDAPPort
Port number.
Integer.
BindDN
String.
BindPassword
String.
Encryption type.
Boolean.
UserDomain
User domain of the domain controller.
String.
UserIdentification
String.
Boolean.
LDAP certificate authentication level.
String.
Oem.Public.RSAEncryptionEnabled
Support for RSA encryption. This field is available only for setting passwords on the webpage.
Boolean.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService/LDAPService
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
  "BindDN": "",
  "LDAPPort": 389,
  "Oem": {
    "Public": {
  "UserDomain": "",
Response code: 200
For information about the response fields, see "Obtain the LDAP service resource."
Change history
Version
Change description
HDM2-1.57
Added the CertificateVerificationEnabled and CertificateVerificationLevel fields.
HDM2-1.53
HDM2-1.14
Removed the redundant SSLEncryptionEnabled field.
Import an LDAP CA certificate
Import an LDAP CA certificate.
Privilege module
ConfigureUsers
Request
POST https://device_ip/redfish/v1/AccountService/LDAPService/Actions/Oem/Public/LDAPService.ImportLDAPCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
·     Local import:
Use this interface after transferring the file to the /tmp/web/ directory. For more information, see "Upload BMC file."
"Type":"URI",
"Content": "/tmp/web/filename"
·     Remote import:
¡     CIFS or SFTP:
   "Type":"URI",
"Content":"cifs://username:password@ip/filename"
¡     HTTP, TFTP, NFS, or HTTPS:
   "Type":"URI",
"Content":"http://ip/filename"
Parameter
Value
device_ip
TOKEN
type
LDAP CA certificate import method.
URI: Local or remote certificate URI.
Content
Import path.
See "Others."
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/LDAPService/Actions/Oem/Public/LDAPService.ImportLDAPCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
  "@odata.context":"/redfish/v1/$metadata#TaskCollection.TaskCollection",
  "@odata.type": "#TaskCollection.TaskCollection",
  "Members": [
      "@odata.id":"/redfish/v1/TaskService/Tasks/2"
  "Members@odata.count": 1,
  "Name": "Task Collection",
  "Oem": {
    "Public": {
Response code: 202
Data type
@odata.context
String
OData description of the task service for importing the LDAP CA certificate file.
@odata.type
String
Type of the task service for importing the LDAP CA certificate file.
@odata.id
String
Link to the task service for importing the LDAP CA certificate file.
Members@odata.id
String
Task link generated by importing the LDAP CA certificate file.
Members@odata.count
Integer
Number of task links generated by importing LDAP CA certificate files.
Name
String
Name of the task service for importing the LDAP CA certificate file.
The server returns status code 202 for a successful operation.
Change history
Version
Change description
HDM2-1.57
Obtain LDAP domain controller collection resource
Obtain the LDAP domain controller collection resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/LDAPService/LDAPControllers
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/LDAPService/LDAPControllers
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#AccountService/LDAPService/LDAPControllers/$entity",
  "@odata.id": "/redfish/v1/AccountService/LDAPService/LDAPControllers",
  "@odata.type": "#LDAPControllersCollection.LDAPControllersCollection",
  "Members": [
      "@odata.id": "/redfish/v1/AccountService/LDAPService/LDAPControllers/1"
  "Members@odata.count": 3,
  "Oem": {
    "Public": {
Response code: 200
Date type
@odata.context
String
OData description of the LDAP domain controller collection resource.
@odata.id
String
Link to the LDAP domain controller collection resource.
@odata.type
String
Type of the LDAP domain controller collection resource.
Name
String
Name of the LDAP domain controller collection resource.
Members
Array
LDAP domain controller resource list.
Members@odata.count
Integer
Number of LDAP domain controllers.
Obtain the user collection resource in an LDAP domain
Obtain the user collection resource in an LDAP domain.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/LDAPService/LDAPControllers/controllers_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
controllers_id
ID of the LDAP controller.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/LDAPService/LDAPControllers/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#AccountService/LDAPService/LDAPControllers/1/$entity",
  "@odata.id": "/redfish/v1/AccountService/LDAPService/LDAPControllers/1",
  "@odata.type": "#LdapGroupsCollection.LdapGroupsCollection",
  "Id": "1",
  "Members": [
      "@odata.id": "/redfish/v1/AccountService/LDAPService/LDAPControllers/1/1"
  "Name": "LDAP Groups Collection",
  "Oem": {
    "Public": {
Response code: 200
Date type
@odata.context
String
OData description of the user collection resource.
@odata.id
String
Link to the user collection resource in an LDAP domain.
@odata.type
String
Type of the user collection resource in an LDAP domain.
Members
Object
LDAP domain user group.
Members@odata.count
String
Number of LDAP domain users.
Obtain a single user resource in an LDAP domain
Obtain a single user resource in an LDAP domain.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/LDAPService/LDAPControllers/controllers_id/user_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
controllers_id
user_id
User ID.
You can obtain user IDs from an LDAP domain user collection resource.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/LDAPService/LDAPControllers/1/3
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#AccountService/LDAPService/LDAPControllers/1/1$entity",
  "@odata.id": "/redfish/v1/AccountService/LDAPService/LDAPControllers/1/3",
  "@odata.type": "#LDAPControllers.v1_0_0.LDAPControllers",
  "Description": "LDAP Group Instance",
  "GroupName": "test",
  "GroupRole": "Administrator",
  "Id": "3",
"Name":"LDAPGroupInstance",
  "Oem": {
    "Public": {
  "RoleGroupDomain": "cn=Manager,dc=example"
Response code: 200
Date type
@odata.context
String
OData description of the LDAP domain single user resource.
@odata.id
String
Link to the LDAP domain single user resource.
@odata.type
String
Type of the user resource in an LDAP domain.
Name
String
Name of the user resource in an LDAP domain.
String
Description of the user resource in an LDAP domain.
GroupName
String
User group name.
RoleGroupDomain
String
User group domain.
GroupRole
String
User group role.
Id
String
Domain user group ID.
Change history
Version
Change description
HDM2-1.15
Added the Name field and changed field MemberId to Id.
Add an LDAP domain user group
Add a user group in an LDAP domain.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/LDAPService/LDAPControllers/controllers_id
Request header:
X-Auth-Token:TOKEN
Request body:
"Id": "3",
"RoleGroupDomain": "cn=Manager,dc=example",
Parameter
Value
device_ip
TOKEN
controllers_id
Id
User group ID.
String.
GroupName
User group name.
Up to 255 characters are supported.
String.
RoleGroupDomain
User group domain.
String.
GroupRole
User group ID.
Up to 64 characters are supported.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/LDAPService/LDAPControllers/1
Request header:
X-Auth-Token:TOKEN
Request body:
"Id": "1",
Response:
  "@odata.id": "/redfish/v1/AccountService/LDAPService/LDAPControllers/1/1",
  "Id": "1",
  "Oem": {
    "Public": {
Response code: 201
For information about the response fields, see "Obtain a single user resource in an LDAP domain."
Change history
Version
Change description
HDM2-1.53
Edit an LDAP domain user group resource
Edit an LDAP domain user group resource.
Privilege module
ConfigureUsers
Request
Method and URL:
PATCH https://device_ip/redfish/v1/AccountService/LDAPService/LDAPControllers/controllers_id/user_id
Request header:
X-Auth-Token:TOKEN
If-Match:ifmatch_value
Request body:
"GroupRole": "Operator"
Parameter
Value
device_ip
TOKEN
controllers_id
user_id
LDAP domain user group ID to be modified.
Integer.
GroupName
User group name.
String.
RoleGroupDomain
User group domain.
String.
GroupRole
User group role.
String.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService/LDAPService/LDAPControllers/1/1
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
  "Id": "1",
  "Oem": {
    "Public": {
Response code: 200
Change history
Version
Change description
HDM2-1.53
HDM2-1.14
Changed LDAP domain user ID to be modified to LDAP domain user group ID to be modified.
Delete a user group resource in an LDAP domain
Delete a user group resource in an LDAP domain.
Privilege module
ConfigureUsers
Request
Method and URL:
DELETE https://device_ip/redfish/v1/AccountService/LDAPService/LDAPControllers/controllers_id/user_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
controllers_id
user_id
ID of the LDAP domain user group to be deleted.
Integer.
Method and URL:
DELETE https://192.168.18.18/redfish/v1/AccountService/LDAPService/LDAPControllers/1/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
HDM2-1.14
Changed LDAP domain user ID to be deleted to LDAP domain user group ID to be deleted.
Obtain the AD service resource
Obtain the AD service resources.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/ADService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/ADService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#AccountService/ADService",
  "@odata.id": "/redfish/v1/AccountService/ADService",
  "@odata.type": "#ADService.v1_0_0.ADService",
  "ADControllers": {
    "@odata.id": "/redfish/v1/AccountService/ADService/ADControllers"
  "ADServiceEnabled": false,
  "DomainControllerAddress1": "",
  "DomainControllerAddress2": "",
  "DomainControllerAddress3": "",
  "Id": "ADService",
  "Name": "AD Controller Collection",
  "Oem": {
    "Public": {
      "CompletionCode": 0,
  "Password": null,
  "UserDomain": "",
  "UserName": ""
Response code: 200
Response field description
Date type
@odata.context
String
OData description of the AD service resource.
@odata.id
String
Link to the AD service resource.
@odata.type
String
Type of the AD service resource.
ADServiceEnabled
Boolean
Enable status.
UserName
String
Confidential username.
Password
String
Confidential user password.
Up to 96 characters are supported.
UserDomain
String
Confidential user domain name.
String
AD domain controller server address 1.
String
AD domain controller server address 2.
String
AD domain controller server address 3.
ADControllers
Object
AD domain controller collection:
@odata.id: Link to the domain controller collection.
Edit the AD service resource
Edit the AD service resources.
Privilege module
ConfigureUsers
Request
Method and URL:
PATCH https://device_ip/redfish/v1/AccountService/ADService
Request header:
X-Auth-Token:TOKEN
Request body:
"UserName": "test",
"Password": "PassWord@_",
"DomainControllerAddress1": "192.168.1.2",
"DomainControllerAddress2": "192.168.1.3",
"DomainControllerAddress3": "192.168.1.4",
"Oem":{
   "Public":{
Parameter
Value
device_ip
TOKEN
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService/ADService
Request header:
X-Auth-Token:TOKEN
Request body:
"UserName": "test",
Response:
  "ADControllers": {
  "Id": "ADService",
  "Oem": {
    "Public": {
  "Password": null,
  "UserName": "test"
Response code: 200
For information about the response fields, see "Obtain the AD service resource."
Change history
Version
Change description
HDM2-1.53
Obtain AD domain controller collection resource
Obtain the AD domain controller collection resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/ADService/ADControllers
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/ADService/ADControllers
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#AccountService/ADService/ADControllers/$entity",
  "@odata.id": "/redfish/v1/AccountService/ADService/ADControllers",
  "@odata.type": "#ADControllersCollection.ADControllersCollection",
  "Members": [
      "@odata.id": "/redfish/v1/AccountService/ADService/ADControllers/1"
  "Oem": {
    "Public": {
Response code: 200
Date type
@odata.context
String
OData description of the AD domain controller collection resource..
@odata.id
String
Link to the AD domain controller collection resource.
@odata.type
String
Type of the AD domain controller collection resource.
Name
String
Name of the AD domain controller collection resource.
Members
Object
AD domain controller object.
Members@odata.count
Integer
Number of AD domain controllers.
Obtain the user collection resource in an AD domain
Obtain the user collection resource in an AD domain.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/ADService/ADControllers/controllers_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
controllers_id
ID of the AD controller.
Only value 1 is supported.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/ADService/ADControllers/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#AccountService/ADService/ADControllers/1/$entity",
  "@odata.id": "/redfish/v1/AccountService/ADService/ADControllers/1",
  "@odata.type": "#AdGroupsCollection.v1_0_0.AdGroupsCollection",
  "Id": "1",
  "Members": [
      "@odata.id": "/redfish/v1/AccountService/ADService/ADControllers/1/1"
  "Name": "AD Groups Collection",
  "Oem": {
    "Public": {
Response code: 200
Date type
@odata.context
String
OData description of the AD domain user collection resource.
@odata.id
String
Link to the AD domain user collection resource.
@odata.type
String
Type of the AD domain user collection resource.
Members
Array
AD user group.
Members@odata.count
String
Number of AD domain users.
Change history
Version
Change description
HDM2-1.14
Changed LDAP to AD in the response.
Obtain a single user resource in an AD domain
Obtain a single user resource in an AD domain.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/ADService/ADControllers/controllers_id/user_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
controllers_id
user_id
ID of the user in the AD domain.
Integer.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/ADService/ADControllers/1/3
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#AccountService/ADService/ADControllers/1/1$entity",
  "@odata.id": "/redfish/v1/AccountService/ADService/ADControllers/1/3",
  "@odata.type": "#ADControllers.v1_0_0.ADControllers",
  "Description": "AD Group Instance",
  "Id": "3",
  "Name": "ADGroupInstance",
  "Oem": {
    "Public": {
  "RoleGroupDomain": "qwert.cn"
Response code: 200
Date type
@odata.context
String
OData description of the single user resource in the specified AD domain.
@odata.id
String
Link to the single user resource in the specified AD domain.
@odata.type
String
Type of the single user resource in the specified AD domain.
Name
String
Name of the single user resource in the specified AD domain.
String
Description of the single user resource in the specified AD domain.
GroupName
String
User group name.
RoleGroupDomain
String
User group domain.
GroupRole
String
User group role.
Id
String
User group number.
Change history
Version
Change description
HDM2-1.14
Changed MemberId field to Id field.
Add an AD domain user group
Add a user group in an AD domain.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/ADService/ADControllers/controllers_id
Request header:
X-Auth-Token:TOKEN
Request body:
"Id": "3",
"GroupName": "yfq",
"RoleGroupDomain": "qwert.cn",
Parameter
Value
device_ip
TOKEN
controllers_id
Integer. Only value 1 is supported.
Id
User group ID.
String.
GroupName
User group name.
String.
RoleGroupDomain
User group domain.
String.
GroupRole
User group role.
The value range is obtained from the interface for obtaining role names.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/ADService/ADControllers/1
Request header:
X-Auth-Token:TOKEN
Request body:
"Id": "1",
Response:
  "@odata.id": "/redfish/v1/AccountService/ADService/ADControllers/1/1",
  "Id": "1",
  "Oem": {
    "Public": {
Response code: 201
For information about the response fields, see "Obtain a single user resource in an AD domain."
Change history
Version
Change description
HDM2-1.53
Edit a user group resource in an AD domain
Edit the information of a user group resource in an AD domain.
Privilege module
ConfigureUsers
Request
Method and URL:
PATCH https://device_ip/redfish/v1/AccountService/ADService/ADControllers/controllers_id/user_id
Request header:
X-Auth-Token:TOKEN
Request body:
"RoleGroupDomain": "CN=qwert,OU=admin,DC=huawei,DC=com",
Parameter
Value
device_ip
TOKEN
controllers_id
user_id
ID of the AD domain user group to be modified.
Integer.
GroupName
User group name.
String.
RoleGroupDomain
User group domain.
String.
GroupRole
User group role.
String.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService/ADService/ADControllers/1/3
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
  "Id": "3",
  "Oem": {
    "Public": {
Response code: 200
Change history
Version
Change description
HDM2-1.53
HDM2-1.14
Changed the description of the user_id field to ID of the AD domain user group to be modified.
Delete a user group resource in an AD domain
Delete a user group resource in an AD domain.
Privilege module
ConfigureUsers
Request
Method and URL:
DELETE https://device_ip/redfish/v1/AccountService/ADService/ADControllers/controllers_id/user_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
controllers_id
user_id
ID of the AD domain user group to be deleted.
Integer.
Method and URL:
DELETE https://192.168.18.18/redfish/v1/AccountService/ADService/ADControllers/1/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
Extended information of the error message.
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
HDM2-1.14
Changed the user_id field to ID of the AD domain user group to be deleted.
Obtain user certificate management service information
Obtain user certificate management service information.
This interface is not available for X18000 products.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Oem/Public/CertificateService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/CertificateService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#AccountService/Oem/Public/CertificateService",
    "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService",
    "@odata.type": "#CertificateService.v1_0_0.CertificateService",
    "Name": "Account CertificateService",
    "Oem": {
        "Public": {
"Accounts": {
        "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService/Accounts"
    "RevokeCheck": false,
    "RootCertificate": {
        "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate"
    "RootCertificateId": "",
    "ServiceEnabled": false
Response code: 200
Date type
@odata.context
String
OData description of the user certificate management service resource model.
@odata.id
String
Link to the user certificate management service resource.
@odata.type
String
Type of the user certificate management service resource
ServiceEnabled
Boolean
Whether the user certificate management service is enabled. Supported options:
·     falseDisabled.
·     trueEnabled.
RootCertificate
Object
Obtain the list of root certificates.
RevokeCheck
Boolean
Whether certificate revocation check is enabled. Supported options:
·     falseDisabled.
·     trueEnabled.
RootCertificateId
String
ID of the root certificate that is enabled.
Accounts
Object
Obtain the list of users that can be bound to the client certificate.
The server returns status code 200 for a successful operation.
Set certificate management service information
Set certificate management service information.
Privilege module
ConfigureUsers
Request
Method and URL:
PATCH https://device_ip/redfish/v1/AccountService/Oem/Public/CertificateService
Request header:
X-Auth-Token:TOKEN
Request body:
"ServiceEnabled": true,
"RevokeCheck":true,
"RootCertificateId":"1"
Parameter
Value
device_ip
TOKEN
ServiceEnabled
Enable or disable the certificate.
Supported options:
·     falseDisabled.
·     trueEnabled.
RevokeCheck
Enable or disable the certificate revocation check.
Supported options:
·     falseDisabled.
·     trueEnabled.
RootCertificateId
String.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService/Oem/Public/CertificateService
Request header:
X-Auth-Token:TOKEN
Request body:
"RevokeCheck":true,
Response:
   "@odata.context":"/redfish/v1/$metadata#AccountService/Oem/Public/CertificateService",
    "@odata.id":"/redfish/v1/AccountService/Oem/Public/CertificateService",
    "@odata.type":"#CertificateService.v1_0_0.CertificateService",
    "Name":"Account CertificateService",
    "Oem":{
        "Public":{
            "CompletionCode":0,
            "Description":"Success"
    "Accounts":{
        "@odata.id":"/redfish/v1/AccountService/Oem/Public/CertificateService/Accounts"
    "RevokeCheck":true,
    "RootCertificate":{
"@odata.id":"/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate"
    "RootCertificateId":"1",
    "ServiceEnabled":true
Response code: 200
For more information about the response field description, see "Obtain user certificate management service information."
Change history
Version
Change description
HDM2-1.53
Obtain user root certificate list
Obtain the user root certificate list.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#AccountService/Oem/Public/CertificateService/RootCertificate",
    "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate",
    "@odata.type": "#RootCertificateCollection.RootCertificateCollection",
    "Members": [
            "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1"
    "Name": "RootCertificate Collection",
    "Oem": {
        "Public": {
Response code: 200
Date type
@odata.context
String
OData description of the user root certificate list resource model.
@odata.id
String
Link to the user root certificate list resource.
@odata.type
String
Type of the user root certificate list resource.
Name
String
Name of the root certificate resource.
Members
Array
Obtain root certificates.
Members@odata.count
Integer
Number of root certificates.
Obtain information of a specific root certificate
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/rootcertificate_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
rootcertificate_id
Root certificate ID.
You can obtain it from the root certificate list.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1",
    "@odata.type": "#Certificate.v1_2_0.Certificate",
    "Actions": {
        "#CertificateService.ImportClientCertificate": {
            "@odata.id": "/redfish/v1/AccountService/Actions/Oem/Public/CertificateService/RootCertificate/1/CertificateService.ImportClientCertificate"
    "CertificateType": "PEM",
    "CertificateUsageType": "Web",
    "ClientCertificate": {
        "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate"
    "FileName": "ca.crt",
    "Issuer": "emailAddress=111@a.com,CN=root,OU=bmc,O=h3c,L=hangzhou,ST=zhejiang,C=CN",
    "Name": "Root Certificate",
    "Oem": {
        "Public": {
    "RootCertificateEnabled": false,
    "RootCertificateId": "1",
    "SerialNumber": "2CE5197635DA354AF219FD4E36130CBE12D0C83F",
    "Subject": "emailAddress=111@a.com,CN=root,OU=bmc,O=h3c,L=hangzhou,ST=zhejiang,C=CN",
    "ValidityDays": "2022-12-24T09:43:13+08:00"
Response code: 200
Date type
@odata.context
String
OData description of the root certificate information resource model.
@odata.id
String
Link to the root certificate information resource.
@odata.type
String
Type of the root certificate information resource.
RootCertificateId
String
Root certificate number.
SerialNumber
String
Root certificate serial number.
Issuer
String
Root certificate user.
ValidityDays
String
Root certificate expiration date.
Subject
String
Root certificate issuer.
FileName
String
Root certificate file name.
Actions#CertificateService.ImportClientCertificate
Object
Link to client certificate import.
Boolean
Enable or disable the root certificate.
Import a root certificate file
Import a root certificate file.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/CertificateService.ImportRootCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
·     Local import:
"Type":"URI",
·     Remote import:
¡     CIFS or SFTP:
"Type":"URI",
"Type":"URI",
Parameter
Value
device_ip
TOKEN
type
Client certificate import method.
Content
Link for the import.
See "Others."
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/Actions/Oem/Public/CertificateService.ImportRootCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
"Type": "URI",
"Content":"sftp://y17057:y17057@192.168.170.57/ca.crt"
Response:
  "@odata.context": "/redfish/v1/$metadata#TaskCollection.TaskCollection",
  "Members": [
      "@odata.id": "/redfish/v1/TaskService/Tasks/2"
  "Oem": {
    "Public": {
      "TaskUniqueID": 1678656297
Response code: 202
Date type
@odata.context
String
OData description of the root certificate file import task service.
@odata.type
String
Type of the root certificate file import task service.
@odata.id
String
Link to the root certificate file import task service.
Members@odata.id
String
Task link generated by importing the root certificate file.
Members@odata.count
Integer
Number of task links generated by importing root certificate files.
Name
String
Name of the root certificate file import task service.
Oem.Public.TaskUniqueID
Integer
Unique ID of the root certificate file import task service.
Change history
Version
Change description
HDM2-1.53
Delete a root certificate file
Delete a root certificate file.
Privilege module
ConfigureUsers
Request
Method and URL:
DELETE https://device_ip/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/rootcertificate_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
rootcertificate_id
ID of the root certificate.
Method and URL:
DELETE https://192.168.18.18/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "Message": "Successfully Completed Request",
               "MessageArgs": [],
               "MessageId": "Base.1.8.1.Success",
               "Resolution": "None"
        "code":"Base.1.8.1.Success",
        "message":"Successfully Completed Request"
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain the client certificate list bound to a root certificate
Obtain the client certificate list information bound to the specified root certificate.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/rootcertificate_id/ClientCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
rootcertificate_id
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#AccountService/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate",
    "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate",
    "@odata.type": "#ClientCertificateCollection.ClientCertificateCollection",
    "Members": [
        "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate/1"
    "Members@odata.count": 2,
"Name": "ClientCertificate Collection",
"Oem": {
    "Public": {
Response code: 200
Date type
@odata.context
String
OData description of client certificate resources bound to the root certificate.
@odata.id
String
Link to the client certificate resources bound to the root certificate.
@odata.type
String
Type of the client certificate resources bound to the root certificate.
Members
Array or object
Link to obtain client certificate information.
Members@odata.count
String
Number of client certificates.
Import a client certificate file
Import a client certificate file.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/CertificateService/RootCertificate/rootcertificate_id/CertificateService.ImportClientCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
·     Local import:
"Type":"URI",
·     Remote import:
¡     CIFS or SFTP:
"Type":"URI",
"Type":"URI",
Parameter
Value
device_ip
TOKEN
rootcertificate_id
type
Content
See "Others."
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/Actions/Oem/Public/CertificateService/RootCertificate/1/CertificateService.ImportClientCertificate
Request header:
X-Auth-Token:TOKEN
Request body:
"Type": "URI",
"Content":"sftp://y17057:y17057@192.168.170.57/client.crt"
Response:
  "Members": [
  "Oem": {
    "Public": {
      "Description": "Success",
Response code: 202
Date type
@odata.context
String
OData description of the client certificate import task service.
@odata.type
String
Type of the client certificate import task service.
@odata.id
String
Link to the client certificate import task service.
Members@odata.id
Array or object
Members@odata.count
String
Number of task links generated by importing client certificates.
Name
String
Name of the client certificate import task service.
Integer
Unique ID of the client certificate import task service.
Change history
Version
Change description
HDM2-1.53
Obtain information of a client certificate
Obtain information of a specific client certificate.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/rootcertificate_id/ClientCertificate/clientcertificate_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
rootcertificate_id
You can obtain it from the user root certificate list.
ID of the client certificate.
You can obtain it from the client certificate list bound to the specified root certificate.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#AccountService/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate/1",
    "@odata.id": "/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate/1",
    "@odata.type": "#ClientCertificateInstance.v1_0_0.ClientCertificateInstance",
    "Actions": {
        "#CertificateService.BindUser": {
            "target": "/redfish/v1/AccountService/Actions/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate/1/CertificateService.BindUser"
        "#CertificateService.DeleteUser": {
            "target": "/redfish/v1/AccountService/Actions/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate/1/CertificateService.DeleteUser"
    "FileName": "client.crt",
    "Fingerprint": "84:53:A3:28:0D:56:83:FC:4A:9F:39:83:73:68:09:7C:E0:70:0C:03",
    "Id": "1",
    "Name": "ClientCertificate 1",
    "Oem": {
        "Public": {
    "UserId": "1",
    "UserName": "anonymous"
Response code: 200
Date type
@odata.context
String
OData description of the specific client certificate information resource.
@odata.type
String
Type of the specific client certificate information resource.
@odata.id
String
Link to the specific client certificate information resource.
FileName
String
Client certificate filename.
FingerPrint
String
Client certificate fingerprint.
UserName
String
Username of the user bound to the client certificate.
RoleId
String
User privilege name of the user bound to the client certificate.
Delete a client certificate
Delete a client certificate.
Privilege module
ConfigureUsers
Request
Method and URL:
DELETE https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/CertificateService/RootCertificate/rootcertificate_id/ ClientCertificate/clientcertificate_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
rootcertificate_id
ID for client certificate.
You can obtain from the client certificate list bound to the specified root certificate.
Method and URL:
DELETE https://192.168.18.18/redfish/v1/AccountService/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate/1
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain the user list bindable to a client certificate
Obtain the user list that can be bound to the client certificate.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Oem/Public/CertificateService/Accounts
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/CertificateService/Accounts
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context":
"/redfish/v1/$metadata#AccountService/Oem/Public/CertificateService/Accounts",
    "@odata.id":"/redfish/v1/AccountService/Oem/Public/CertificateService/Accounts",
"Members":[{
        "Id":"2",
        "UserName":"test1",
        "RoleId":"Administrator",
        "Id":"3",
        "UserName":"test2",
        "RoleId":"User",
"Oem": {
    "Public": {
Response code: 200
Date type
@odata.context
String
OData description of the user list resource bindable to the client certificate.
@odata.type
String
Type of the user list resource bindable to the client certificate.
@odata.id
String
Link to the user list resource bindable to the client certificate.
Members
object
Users bindable to the client certificate.
Members.Id
String
User ID.
Members.UserName
String
Username.
Members.RoleId
String
User role.
Bind a user to a client certificate
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/CertificateService/RootCertificate/rootcertificate_id/ClientCertificate/clientcertificate_id/CertificateService.BindUser
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id":"1"
Parameter
Value
device_ip
TOKEN
rootcertificate_id
String.
Client certificate ID.
String.
Id
User ID.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/Actions/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate/1/CertificateService.BindUser
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id":"2"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Added the locking type of the associated system.
Unbind a client certificate from a user
Unbind a client certificate from a user.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/CertificateService/RootCertificate/rootcertificate_id/ClientCertificate/clientcertificate_id/CertificateService.DeleteUser
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id":"2"
Parameter
Value
device_ip
TOKEN
rootcertificate_id
String.
String.
Id
User ID.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/Actions/Oem/Public/CertificateService/RootCertificate/1/ClientCertificate/1/CertificateService.DeleteUser
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id":"2"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain SSH public key list information
Obtain SSH public key list information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Oem/Public/SSHCiphers
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/SSHCiphers
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Managers/1/Oem/Public/SSHCiphers",
    "@odata.id": "/redfish/v1/AccountService/Oem/Public/SSHCiphers",
"@odata.type": "#SSHCiphersCollection.SSHCiphersCollection",
    "Members": [
            "@odata.id": "/redfish/v1/AccountService/Oem/Public/SSHCiphers/1"
"Accounts": {
    "@odata.id": "/redfish/v1/AccountService/Oem/Public/SSHCiphers/Accounts"
    "Name": "SSHCiphers  Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the SSH public key information resource.
@odata.id
String
Link to the SSH public key information resource.
@odata.type
String
Type of the SSH public key information resource.
Members
Array
Link to the SSH key information resource.
Members@odata.count
Integer
Number of SSH keys.
Accounts
Object
You can obtain the list of users that can be bound to the SSH public key.
Obtain information of an SSH public key
Obtain the information of an SSH public key.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Oem/Public/SSHCiphers/SSHCiphers_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
SSHCiphers_id
SSH public key ID.
You can obtain SSH public key IDs from the interface for obtaining the SSH public key list information.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/SSHCiphers/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Managers/1/Oem/Public/SSHCiphers/1",
    "@odata.id": "/redfish/v1/AccountService/Oem/Public/SSHCiphers/1",
    "@odata.type": "#SSHCiphers.v1_0_0.SSHCiphers",
    "FileName": "pubkey.pem",
    "Fingerprint": "44:b0:0a:86:0d:a6:3b:d8:3c:ca:46:65:6b:ae:55:dd",
    "Id": "1",
"Name": "SSHCiphers Instance",
"Oem": {
        "Public": {
"Users":[
            "Id":"2",
"UserName":"test",
             "RoleId":"User"
        "Id":"3",
            "UserName":"test",
             "RoleId":"User"
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
UserName
String
Username.
Id
String
User ID.
RoleId
String
User permissions.
FileName
String
Public key file name.
Fingerprint
String
Public key fingerprint.
Import SSH public keys
Import SSH public keys.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/SSHCiphers/SSHCiphers.ImportSSHCiphers
Request body:
·     Local import:
{ "Type":"URI", "Content": "/tmp/filename" }
·     Remote import:
{ "Type":"URI", "Content": "sftp://username:password@10.10.10.191/filename"}
Parameter
Value
device_ip
TOKEN
type
value
Import content.
Supported options:
·     Link to the remote certificate. The available file transfer protocols include SFTP, HTTPS, HTTP, NFS, CIFS, and TFTP.
·     Link to the local certificate.
·     The meaning of the value field is indicated by the type field.
Content
See "Others."
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/Actions/Oem/Public/SSHCiphers/SSHCiphers.ImportSSHCiphers
Request header:
X-Auth-Token:TOKEN
Request body:
"Type": "URI",
"Content":"sftp://y17057:y17057@192.168.170.57/cacert.pem"
Response:
    "Members": [
            "@odata.id": "/redfish/v1/TaskService/Tasks/1"
    "Oem": {
        "Public": {
Response code: 202
Data type
@odata.context
String
OData descriptionof the import SSH public key task service.
@odata.type
String
Type of the import SSH public key task service.
@odata.id
String
Link to the import SSH public key task service.
Members@odata.id
String
Task link generated by the SSH public key import.
Name
String
Name of the import SSH public key task service.
Integer
Unique ID for the import SSH public key task service.
Change history
Version
Change description
HDM2-1.53
Delete an SSH public key
Delete an SSH public key.
Privilege module
ConfigureUsers
Request
Method and URL:
DELETE https://device_ip/redfish/v1/AccountService/Oem/Public/SSHCiphers/SSHCiphers_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
SSHCiphers _id
SSH public key ID.
You can obtain SSH public key IDs from the SSH public key list information.
Method and URL:
DELETE https://192.168.18.18/redfish/v1/AccountService/Oem/Public/SSHCiphers/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Obtain the list of SSH public key-bindable users
Obtain the list of users that can be bound to SSH public keys.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/AccountService/Oem/Public/SSHCiphers/Accounts
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/SSHCiphers/Accounts
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#AccountService/Oem/Public/SSHCiphers/Accounts",
    "@odata.id": "/redfish/v1/AccountService/Oem/Public/SSHCiphers/Accounts",
    "Members": [
            "Id": "1",
            "RoleId": "Administrator",
            "Id": "2",
            "UserName": "test"
    "Name": "SSHCiphers Accounts",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the SSH public key-bindable user list resource.
@odata.id
String
Link to the SSH public key-bindable user list resource.
@odata.type
String
Type of the SSH public key-bindable user list resource.
Members
Object
Users that can be bound to the client.
Members.Id
String
User ID.
Members.UserName
String
Username.
Members.RoleId
String
User role.
Bind an SSH public key to a user
Bind an SSH public key to a user.
Privilege module
ConfigureUsers
BMC configuration locking
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/SSHCiphers/SSHCiphers.BindUser
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id":"3",
    "SSHCiphersId":"2"
Parameter
Value
device_ip
TOKEN
Id
User ID.
You can obtain available user IDs from the user list information query.
SSHCiphersId
Public key ID.
You can obtain available public key IDs from the SSH public key list information.
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/Actions/Oem/Public/SSHCiphers/SSHCiphers.BindUser
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id":"3",
"SSHCiphersId":"2"
Response:
"Oem": {
       "Public": {
"error": {
       "@Message.ExtendedInfo": [
               "@odata.type": "#Message.v1_1_1.Message",
               "MessageArgs": [],
               "MessageSeverity": "OK",
Response code: 200
Data type
code
String
String of a specific message ID in the message registry.
message
String
Readable error message corresponding to the message in the message registry.
Extended information of the message.
@odata.type
String
OData description of the message resource.
MessageId
String
Message ID.
Message
String
Details of the message.
MessageArgs
Array
Message arguments.
MessageSeverity
String
Severity level. Supported options:
·     OK.
·     Warning.
·     Critical.
Resolution
String
Recommended actions for the error.
Change history
Version
Change description
HDM2-2.04
Added the error node before Message.ExtendedInfo and added the code and message fields under the error node.
HDM2-1.53
Unbind an SSH public key from a user
Unbind an SSH public key from a user.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/SSHCiphers/SSHCiphers.DeleteUser
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id":"3",
    "SSHCiphersId":"2"
Parameter
Value
device_ip
TOKEN
Id
User ID.
String.
SSHCiphersId
SSH public key ID.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/Actions/Oem/Public/SSHCiphers/SSHCiphers.DeleteUser
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id":"3",
    "SSHCiphersId":"2"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Import a weak password dictionary
Import a weak password dictionary.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/AccountService.ImportWeakPasswordDictionary
Request header:
X-Auth-Token:TOKEN
Request body:
BMC file system import:
"Type":"URI",
Remote import:
·     CIFS or SFTP:
     "Type":"URI",
·     TFTP, NFS, HTTP, or HTTPS:
"Type":"URI",
"Content":"nfs://ip/filename"
Parameter
Value
device_ip
TOKEN
URI.
String.
Content
Link to the file.
·     File transfer protocols: SFTP, HTTPS, HTTP, NFS, CIFS, and TFTP.
·     Link to the operation, not supporting Chinese characters.
·     Up to 1024 characters, not supporting Chinese characters. Supported special characters include @!$^&()_+.;[]{}-=~`
·     Only the /tmp/web/ directory and its subdirectories are supported locally.
·     The total length of the TFTP protocol directory and file name is up to 240 characters.
·     Only the .txt file type is supported.
·     The imported file size cannot exceed 10K. The weak password length of a line cannot exceed 40 characters. The file content supports link breaks, uppercase and lowercase letters, digits, spaces, and special characters `~!@#$%^&*()_+-=[]{}|;':",./<>? Characters that do not comply with the rules or exceed the length limit will be formatted and trimmed. The file content after the format cannot be empty.
·     The file name length cannot exceed 255 characters.
Method and URL:
POST
https://192.168.18.18/redfish/v1/AccountService/Actions/Oem/Public/AccountService.ImportWeakPasswordDictionary
Request header:
X-Auth-Token:TOKEN
Request body:
    "Type":"URI",
    "Content": "nfs://192.168.20.177/Share1/weakpw.txt"
Response:
  "Members": [
  "Oem": {
    "Public": {
Response code: 202
Data type
@odata.context
String
OData description of the weak password dictionary import task service.
@odata.type
String
Type of the weak password dictionary import task service.
@odata.id
String
Link to the weak password dictionary import task service.
Members@odata.id
Object
Task link generated by importing the weak password dictionary.
Name
String
Name of the weak password dictionary import task service.
Integer
Unique ID of the weak password dictionary import task service.
Change history
Version
Change description
HDM2-1.53
Export a weak password dictionary
Export the weak password dictionary.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/AccountService.ExportWeakPasswordDictionary
Request header:
X-Auth-Token:TOKEN
Request body:
BMC file system export:
"Type":"URI",
Remote export:
·     CIFS or SFTP:
     "Type":"URI",
·     TFTP or NFS:
"Type":"URI",
¡     HTTP or HTTPS:
   "Type":"URI",
   "Content":"http://ip/filename",
   "ScriptName":"1.php"
Parameter
Value
device_ip
TOKEN
String.
URI.
Content
Link to the file.
·     The exported file size cannot exceed 10K. The weak password length of a line cannot exceed 40 characters. The file content supports link breaks, uppercase and lowercase letters, digits, spaces, and special characters `~!@#$%^&*()_+-=[]\{}|;':",./<>? Characters that do not comply with the rules or exceed the length limit will be formatted and trimmed. The file content after the format cannot be empty.
ScriptName
Export script file over HTTP/HTTPS.
String.
Method and URL:
POST
https://192.168.18.18/redfish/v1/AccountService/Actions/Oem/Public/AccountService.ExportWeakPasswordDictionary
Request header:
X-Auth-Token:TOKEN
Request body:
    "Type":"URI",
Response:
  "Members": [
  "Oem": {
    "Public": {
Response code: 202
Data type
@odata.context
String
OData description of the weak password dictionary export task service.
@odata.type
String
Type of the weak password dictionary export task service.
@odata.id
String
Link to the weak password dictionary export task service.
Members@odata.id
Object
Task link generated by exporting the weak password dictionary.
String
Unique ID of the weak password dictionary export task service.
Obtain the Kerberos service resource
Obtain the Kerberos service resource.
This resource is licensed and requires authorization through licensing before use.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/AccountService/Oem/Public/KerberosService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/KerberosService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#AccountService/Oem/Public/KerberosService",
    "@odata.id": "/redfish/v1/AccountService/Oem/Public/KerberosService",
    "@odata.type": "#Kerberos.v1_0_0.Kerberos",
    "Id": "KerberosService",
    "KerberosControllers": {
        "@odata.id": "/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers"
    "Name": "Kerberos Service",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the Kerberos service resource.
@odata.id
String
Link to the Kerberos resource node.
@odata.type
String
Type of the Kerberos resource.
Name
String
Name of the Kerberos resource.
Id
String
Kerberos resource ID.
KerberosControllers
Object
Kerberos realm controller collection:
@odata.id: Link to the realm controller collection.
ServiceEnabled
Boolean
Whether the Kerberos service is enabled.
Edit the Kerberos service resource
Edit the Kerberos service resource.
Privilege module
ConfigureUsers
Request
PATCH https://device_ip/redfish/v1/AccountService/Oem/Public/KerberosService
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
ServiceEnabled
Boolean
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService/Oem/Public/KerberosService
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
    "Oem": {
        "Public": {
Response code: 200
For information about the response fields, see "Obtain the Kerberos service resource."
Obtain the Kerberos collection resource
Privilege module
Login
Request
GET https://device_ip/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context":"/redfish/v1/$metadata#AccountService/Oem/Public/KerberosService/KerberosControllers/$entity",
    "@odata.id":"/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers",
    "@odata.type":"#KerberosCollection.KerberosCollection",
    "Members":[
            "@odata.id":"/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/1"
    "Members@odata.count":1,
    "Name":"Kerberos Controller Collection",
    "Oem":{
        "Public":{
            "CompletionCode":0,
Response code: 200
Data type
@odata.context
String
OData description of the Kerberos collection resource.
@odata.id
String
Link to the Kerberos collection resource.
@odata.type
String
Type of the Kerberos collection resource.
Name
String
Name of the Kerberos collection resource.
Members
Object
Kerberos collection object.
Members@odata.count
Integer
Number of Kerberos collection members.
Obtain the user group collection resource in a Kerberos controller
Privilege module
Login
Request
GET https://device_ip/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/controllers_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
controllers_id
Kerberos controller ID.
Method and URL:
GET https://192.168.18.1/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context":"/redfish/v1/$metadata#AccountService/Oem/Public/KerberosService/KerberosControllers/1/$entity",
    "@odata.id":"/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/1",
    "@odata.type":"#KerberosGroupsCollection.v1_0_0.KerberosGroupsCollection",
    "Id":"1",
    "Members":[
            "@odata.id":"/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/1/1"
    "Name":"Kerberos Groups Collection",
    "ServerAddress":"192.168.1.199",
    "Port":88,
    "Realm":"IT.SOFTWARE.COM",
    "Oem":{
        "Public":{
            "CompletionCode":0,
Response code: 200
Data type
@odata.context
String
OData description of the Kerberos user group collection resource.
@odata.id
String
Link to the Kerberos user group collection resource.
@odata.type
String
Type of the Kerberos user group collection resource.
Members
Array
Kerberos user groups.
Members@odata.count
String
Number of Kerberos user groups.
ServerAddress
String
Address of the realm controller, which can be an IPv4 or IPv6 address or a domain name.
Port
Integer
Port number of the realm control, in the range of 1 to 65535.
Default: 88.
Realm
String
Realm of the realm controller.
The realm name must be in uppercase.
Edit the user group collection resource in a Kerberos controller
Privilege module
ConfigureUsers
Request
PATCH https://device_ip/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/controllers_id
Request header:
X-Auth-Token:TOKEN
Request body:
    "ServerAddress":"device_ip",
    "Port": port,
    "Realm": Realm
Parameter
Value
device_ip
TOKEN
controllers_id
ServerAddress
String.
Port
Default: 88.
Integer.
Realm
String.
Content
Path to the keytab file.
String.
Method and URL:
PATCH https://192.168.18.1/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/1
Request header:
X-Auth-Token:TOKEN
Request body:
    "Port":88,
Response:
    "Id":"1",
    "Members":[
    "Port":88,
    "Oem":{
        "Public":{
            "CompletionCode":0,
Response code: 200
For information about the response fields, see "Obtain the user group collection resource in a Kerberos controller."
Upload a keytab file
Upload a keytab file.
Privilege module
ConfigureUsers
Request
POST https://device_ip/redfish/v1/AccountService/Actions/Oem/Public/KerberosService/KerberosControllers/controllers_id/KerberosControllers.ImportKeytab
Request header:
X-Auth-Token:TOKEN
Request body:
·     Local import:
    "Type":"URI",
    "Content":"/tmp/web/Kerberos.keytab"
·     Remote import:
¡     CIFS or SFTP:
    "Type":"URI",
    "Type":"URI",
Parameter
Value
device_ip
TOKEN
controllers_id
Keytab file upload method.
URI
Content
See "Others."
String
Method and URL:
POST https://192.168.18.1/redfish/v1/AccountService/Actions/Oem/Public/KerberosService/KerberosControllers/1/KerberosControllers.ImportKeytab
Request header:
X-Auth-Token:TOKEN
Request body:
    "Type":"URI",
Response:
  "Members": [
      "@odata.id": "/redfish/v1/TaskService/Tasks/3"
  "Oem": {
    "Public": {
      "TaskUniqueID": 1508470554
Response code: 202
Data type
@odata.context
String
OData description of the task service for uploading the keytab file.
@odata.type
String
Type of the task service for uploading the keytab file.
@odata.id
String
Link to the task service for uploading the keytab file.
Members@odata.id
String
Task link generated by uploading the keytab file.
Add a Kerberos user group
Add a user group in a Kerberos controller.
Privilege module
ConfigureUsers
Request
POST  https://device_ip/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/controllers_id
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id":"3",
    "GroupName":"test",
    "GroupSID":SID,
    "GroupRole":"Administrator"
Parameter
Value
device_ip
TOKEN
controllers_id
Id
User group ID.
Integer.
GroupName
User group name.
String.
GroupSID
User group SID.
String.
GroupRole
User group role.
You can obtain the value range for the group role by using the interface for obtaining role names.
String
Method and URL:
POST https://192.168.18.18/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/1
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id":"1",
    "GroupName":"test",
    "GroupSID":"S-1-5-21-174651825-3639122879-2784557100-1105",
Response:
    "@odata.context":"/redfish/v1/$metadata#AccountService/Oem/Public/KerberosService/KerberosControllers/1/1$entity",
    "@odata.id":"/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/1/1",
    "@odata.type":"#KerberosControllers.v1_0_0.KerberosControllers",
    "Description":"Kerberos Groups Instance",
    "GroupName":"test",
    "GroupRole":"Administrator",
    "Id":"1",
    "Oem":{
        "Public":{
            "CompletionCode":0,
Response code: 201
Data type
@odata.context
String
OData description of the Kerberos user group resource.
@odata.id
String
Link to the Kerberos user group resource.
@odata.type
String
Type of the Kerberos user group resource.
Id
String
User group ID.
Name
String
Name of the Kerberos user group resource.
String
Description for the Kerberos user group.
GroupName
String
User group name.
GroupRole
String
User group role.
GroupSID
String
User group SID.
The server returns status code 201 for a successful operation.
Change history
Version
Change description
HDM2-1.62
Deleted the Only admin is supported description in the GroupRole feld.
HDM2-1.58
Added IdDescription and updated Name and @odata.typeDescription.
HDM2-1.57
Deleted the description of not supporting SID.
Obtain a user group resource from a Kerberos controller
Obtain a user group resource in a Kerberos controller.
Privilege module
Login
Request
GET https://device_ip/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/controllers_id/user_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
controllers_id
user_id
ID of the Kerberos user group.
Integer.
Method and URL:
GET https://192.168.18.18/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/1/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "GroupName":"test",
    "Id":"1",
    "Name":"Kerberos Controller Instance",
    "Oem":{
        "Public":{
            "CompletionCode":0,
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
Id
String
User group ID.
Name
String
String
GroupName
String
User group name.
GroupRole
String
User group role.
GroupSID
String
User group SID.
Change history
Version
Change description
HDM2-1.62
HDM2-1.58
Added IdDescription, and updated Name and @odata.typeDescription.
HDM2-1.57
Edit a user group resource in a Kerberos controller
Edit a user group resource in a Kerberos controller.
Privilege module
ConfigureUsers
Request
PATCH https://device_ip/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/controllers_id/user_id
Request header:
X-Auth-Token:TOKEN
Request body:
    "GroupName":"test",
    "GroupSID":SID,
Parameter
Value
device_ip
TOKEN
controllers_id
user_id
ID of the Kerberos user group to be edited.
Integer.
GroupName
User group name.
String.
GroupRole
User group role.
String.
GroupSID
User group SID.
String.
Method and URL:
PATCH https://192.168.18.18/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/1/1
Request header:
X-Auth-Token:TOKEN
If-Match: W/"6e8c96325a9b7c6a6e5e9f23616fbce0"
Request body:
    "GroupName":"test",
Response:
    "GroupName":"test",
    "Id":"1",
    "Oem":{
        "Public":{
            "CompletionCode":0,
Response code: 200
For information about the response fields, see "Obtain a user group resource from a Kerberos controller."
Change history
Version
Change description
HDM2-1.62
HDM2-1.57
Delete a Kerberos user group resource
Delete a Kerberos user group resource.
Privilege module
ConfigureUsers
Request
DELETE https://device_ip/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/controllers_id/user_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
controllers_id
user_id
ID of the Kerberos user group to be deleted.
Integer.
Method and URL:
DELETE https://192.168.18.18/redfish/v1/AccountService/Oem/Public/KerberosService/KerberosControllers/1/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "Message": "The account was successfully removed.",
               "MessageArgs": [],
               "MessageId": "Base.1.8.1.AccountRemoved",
               "Resolution": "No resolution is required."
        "code":"Base.1.8.1.AccountRemoved",
        "message":"The account was successfully removed."
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Operations on session service resources
Create a Redfish session
Create a session on the server.
Privilege module
Login
Request
Method and URL:
POST https://device_ip/redfish/v1/SessionService/Sessions
Request header:
Request body:
"UserName":"name",
"Password":"password"
Parameter
Value
device_ip
UserName
Username for creating the session.
HDM user, in plain text.
password
Password for creating the session.
Password of the HDM user, in plain text.
The password length is 2 to 40 characters.
This operation will generate an X-Auth-Token, which is required in the header of most Redfish operations for authentication. As a best practice, first create a session before you perform other operations.
You can create a maximum of 20 sessions, and only HTTPS is supported. If both HTTP and HTTPS are enabled, POST requests to create sessions via the HTTP port must be redirected to the HTTPS port.
Method and URL:
POST https://192.168.18.18/redfish/v1/SessionService/Sessions
Request header:
Request body:
  "UserName":"name",
Response:
    "@odata.context": "/redfish/v1/$metadataSessionService/Sessions",
    "@odata.id": "/redfish/v1/SessionService/Sessions/tHNeZ7O293bnX0k2XVBOpnlOCmKElCQd",
    "@odata.type": "#Session.v1_3_0.Session",
    "ClientOriginIPAddress": "192.168.44.56",
"Description": "Session Service",
"Id": "tHNeZ7O293bnX0k2XVBOpnlOCmKElCQd",
    "Name": "admin Session",
    "Oem": {
        "Public": {
            "AssignedPrivileges": [
                "ConfigureUsers",
                "ConfigureComponents",
                "Login",
                "ConfigureSelf"
            "DefaultPasswordModifyPolicy":"NotModify",
            "IPMIEnable": true,
            "LockTimeSeconds": 0,
            "LoginTime": "2017-08-31T07:43:23+08:00",
            "OemPrivileges": [
                "OemKvm",
                "OemVmm",
                "OemSecurityMgmt",
                "OemPowerControl",
                "OemDiagnosis",
                "OemSystemAudit"
            "PasswordExpired": false,
            "PasswordModify": true,
            "PasswordRemainingSeconds": 0,
            "PasswordValidityDays": 0,
            "PrivilegeIndex": "1023",
            "SessionId": "4",
            "UserRole": "Administrator",
            "UserType": "LocalUser",
            "WebEnable": true,
            "X-Auth-Token": "kkdVRFYCaYxqNhrSK5uYd9dbEoCO7Wv0"
    "SessionType": "Redfish",
    "UserName": "admin"
Response header:
X-Auth-Token:kkdVRFYCaYxqNhrSK5uYd9dbEoCO7Wv0
Location/redfish/v1/SessionService/Sessions/tHNeZ7O293bnX0k2XVBOpnlOCmKElCQd
Strict-Transport-Security:value
X-Frame-Options: DENY
Pragma: no-cache
Cache-Control: no-Store,no-Cache
X-XSS-Protection: nosniff
X-Content-Type-Options: nosniff
Content-Type-application/json
Response code: 201
Data type
@odata.context
String
OData description of the session resource model.
@odata.id
String
Link to the session resource.
odata.type
String
Type of the session resource.
String
Description of the session.
Id
String
Session ID.
Name
String
Session name.
UserName
String
Username.
String
User IP.
SessionType
String
Session type. Supported options:
·     Redfish
·     USB
Oem.Public
Object
Custom parameters for the session service.
AssignedPrivileges
String or array
User privileges.
String
Default password change policy. Supported options:
·     NotModify.
·     ForcedModify.
·     Optional.
LoginTime
String
Session creation time.
OemPrivileges
String or array
User-defined privileges.
IPMIEnable
Boolean
IPMI enabled.
LockTimeSeconds
Integer
Remaining lockout duration (seconds).
PasswordModify
Boolean
Whether to modify the password.
PasswordExpired
Boolean
Whether the password expired.
Integer
Remaining password validity (seconds).
Integer
Password validity period (days).
PrivilegeIndex
String
Privilege index.
SessionId
String
Session index.
UserRole
String
User role.
UserType
String
User type. Options include:
·     LocalUser.
·     DomainUser.
WebEnable
Boolean
Whether Web is enabled.
X-Auth-Token
String
Token value.
Change history
Version
Change description
HDM3-1.19
Edited the value for the Id field.
HDM2-2.04
HDM3-2.03
Changed the ChangeDefaultPasswordEnabled field to DefaultPasswordModifyPolicy.
Obtain session collection information
Obtain information about all sessions from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/SessionService/Sessions
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/SessionService/Sessions
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#SessionCollection.SessionCollection",
    "@odata.id": "/redfish/v1/SessionService/Sessions/",
    "@odata.type": "#SessionCollection.SessionCollection",
    "Description": "Session Collection",
    "Members": [
            "@odata.id": "/redfish/v1/SessionService/Sessions/afQLANTiaGL6yY4aYtsapJWODotcF1sF"
    "Members@odata.count": 1,
    "Name": "Session Collection",
    "Oem": {
        "Public": {
            "CompletionCode": 0,
Response code: 200
Response field description
Data type
@odata.context
String
OData description of the session collection resource model.
@odata.id
String
Link to the session collection resource.
@odata.type
String
Type of the session collection resource.
Members
Array
List of sessions.
Members@odata.count
Integer
Number of sessions.
Name
String
Session resource name.
Obtain session information
Obtain information about a specific session from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/SessionService/Sessions/session_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
session_id
ID of the session resource.
You can obtain available session resource IDs from session collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/SessionService/Sessions/ rFYBf8FRrmbSXgTXmwEIxAb65AWWlR3q
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#Session.Session",
    "@odata.id": "/redfish/v1/SessionService/Sessions/rFYBf8FRrmbSXgTXmwEIxAb65AWWlR3q",
    "ClientOriginIPAddress": "192.168.170.57",
    "Id": "rFYBf8FRrmbSXgTXmwEIxAb65AWWlR3q",
    "Oem": {
        "Public": {
            "LoginTime": "2019-02-16T20:56:59+08:00",
            "UserID": 1,
            "UserIP": "192.168.170.57",
            "UserRole": "User",
            "UserTag": "Redfish"
    "Password": null,
    "UserName": "admin"
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
Id
String
Name
String
Name of the session service resource.
String
Address of the user using the session service.
UserName
String
Username of the session service resource.
UserID
Integer
ID of the user using the session service.
UserTag
String
Interface for the session service. Supported options:
·     Redfish.
·     USB.
·     WebUI.
·     KVMIP.
LoginTime
String
Creation time of the session service.
UserRole
String
Role name.
SessionType
String
·     Redfish.
·     USB.
·     WebUI.
·     KVMIP.
Change history
Version
Change description
HDM3-1.19
Delete a session
Delete a specific session.
Privilege module
OemSecurityMgmt/ConfigureSelf
Request
Method and URL:
DELETE https://device_ip/redfish/v1/SessionService/Sessions/session_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
session_id
Session ID.
You can obtain available session IDs from session collection information.
Method and URL:
DELETE https://device_ip/redfish/v1/SessionService/Sessions/kkdVRFYCaYxqNhrSK5uYd9dbEoCO7Wv0
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Obtain Redfish session information
Obtain information about the current Redfish session from the server.
Privilege module
Login
Request
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Authentication token.
The token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
N/A.
Method and URL:
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#SessionService.SessionService",
    "@odata.id": "/redfish/v1/SessionService/",
    "@odata.type": "#SessionService.v1_1_8.SessionService",
    "Id": "SessionService",
    "Name": "Session Service",
    "Oem": {
        "Public": {
    "SessionTimeout": 1800,
    "Sessions": {
        "@odata.id": "/redfish/v1/SessionService/Sessions"
    "Status": {
        "Health": "OK",
        "State": "Enabled"
Response code: 200
Data type
@odata.context
String
OData description of the session service resource model.
@odata.id
String
Link to the session service resource.
@odata.type
String
Type of the session service resource.
Id
String
ID of the session service resource.
Name
String
ServiceEnabled
Boolean
Enabling status of the session service.
SessionTimeout
Integer
Session timeout time, in seconds. The default is 1800 seconds.
Sessions
Object
List of sessions,
@odata.id
String
Links to sessions.
Status
Object
Session management states:
·     Health—Whether the session management is healthy.
·     State—Whether the session management has been enabled.
Edit Redfish session settings
Edit Redfish session settings for the server.
Privilege module
OemSecurityMgmt
Locking type of the associated system
Request
Method and URL:
PATCH https://device_ip/redfish/v1/SessionService
Request header:
X-Auth-Token:TOKEN
If-Match:ifmatch_value
Request body:
Parameter
Value
device_ip
TOKEN
ifmatch_value
Entity tag (ETag) that uniquely represents the requested resource.
To obtain the entity tag value of a resource, send a GET request to it and then obtain the ETag value from the response header.
ServiceEnabled
Enable or disable the session service.
Disabling the session service is not supported. If the specified field is false, ignore the specified value.
Boolean
SessionTimeout
Session timeout.
Integer.
Value range: 30 to 86400 seconds
Method and URL:
PATCH https://192.168.18.18/redfish/v1/SessionService
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
    "Oem": {
        "Public": {
    "Sessions": {
    "Status": {
        "Health": "OK",
        "State": "Enabled"
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
Id
String
Name
String
SessionTimeout
Integer
Session timeout.
Sessions
List of sessions.
@odata.id
String
Link to the session list.
Status.Health
String
Health status.
Status.State
String
Enabling status.
Change history
Version
Change description
HDM2-1.53
Operations on update service resources
Obtain update service information
Obtain information about the current update service from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/UpdateService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Configuration management, import/export, SSL certificate upload, firmware updates, and other similar operations require upgrade status query.
Method and URL:
GET https://192.168.18.18/redfish/v1/UpdateService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#UpdateService",
    "@odata.id": "/redfish/v1/UpdateService",
    "@odata.type": "#UpdateService.v1_9_0.UpdateService",
    "Actions": {
        "#UpdateService.SimpleUpdate": {
            "target": "/redfish/v1/UpdateService/Actions/UpdateService.SimpleUpdate"
        "Oem": {
            "Public": {
                "#MirrorPool.DeleteImage": {
                    "target": "/redfish/v1/UpdateService/Actions/Oem/Public/MirrorPool.DeleteImage"
                "#UpdateService.DumpBIOS": {
                    "target": "/redfish/v1/UpdateService/Actions/Oem/Public/UpdateService.DumpBIOS"
                "#UpdateService.UninstallPackage": {
                    "PackageType@Redfish.AllowableValues": [
                        "PATCH",
                        "FEATURE"
                    "target": "/redfish/v1/UpdateService/Actions/Oem/Public/UpdateService.UninstallPackage"
    "Description": "Service for Software Update",
    "FirmwareInventory": {
        "@odata.id": "/redfish/v1/UpdateService/FirmwareInventory"
    "HttpPushUri": "/redfish/v1/UpdateService",
    "Id": "UpdateService",
    "MaxImageSizeBytes": 471859200,
    "Name": "Update Service",
    "Oem": {
        "Public": {
            "BIOSFirmwareRestoreEnabled": true,
            "BMCFirmwareRestoreEnabled": true,
            "FirmwareList": {
                "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList"
            "InstalledPackages": {
                "@odata.id": "/redfish/v1/UpdateService/Oem/Public/InstalledPackages"
            "MirrorPool": {
                "@odata.id": "/redfish/v1/UpdateService/Oem/Public/MirrorPool"
            "UpgradeState": null
            "UpgradeTaskRestoreEnabled": true
    "Status": {
        "Health": "OK",
        "State": "Enabled"
Response code: 200
Data type
@odata.context
String
OData description of the update service resource model.
@odata.id
String
Link to the update service resource.
@odata.type
String
Type of the update service resource.
Actions.UpdateService.SimpleUpdate
Object
Update the firmware.
Actions.Oem.Public.MirrorPool.DeleteImage
Object
Delete an image from the image pool.
Actions.Oem.Public.UpdateService.UninstallPackage
Object
Uninstall a specific firmware package.
Object
Export BIOS firmware.
Name
String
Name of the update service resource.
MaxImageSizeBytes
Integer
Maximum firmware size.
ServiceEnabled
Boolean
Enabling status of the update service.
Status.Health
String
Health status of the update service resource.
Status.State
String
Enabling status of the update service resource.
FirmwareInventory
Object
Links to available firmware resources.
Oem.Public.UpgradeState
String
Current update status. Supported options:
·     UpgradingThe update is in progress.
·     nullThe update is not in progress .
Oem.Public.FirmwareList
Object
Link to the firmware list that can be updated.
Object
Image pool list
Oem.Public.InstalledPackages
Object
Obtain firmware package collection information.
Oem.Public.BMCFirmwareRestoreEnabled
Boolean
Whether BMC firmware restoration is enabled.
Oem.Public.BIOSFirmwareRestoreEnabled
Boolean
Whether BIOS firmware restoration is enabled.
Oem.Public.UpgradeTaskRestoreEnabled
Boolean
Whether update task restoration is enabled.
Change history
Version
Change description
HDM2-1.56
Added the Oem.Public.BMCFirmwareRestoreEnabled, Oem.Public.BIOSFirmwareRestoreEnabled, and Oem.Public.UpgradeTaskRestoreEnabled fields.
Configure update service information
Configure update service information of the server.
Privilege module
OemDiagnosis
Request
PATCH https://device_ip/redfish/v1/UpdateService
Request header:
X-Auth-Token:TOKEN
Request body:
  "Oem": {
      "Public":{
          "BMCFirmwareRestoreEnabled": false,
          "BIOSFirmwareRestoreEnabled": false,
          "UpgradeTaskRestoreEnabled": false
Parameter
Value
device_ip
TOKEN
Boolean
Boolean
Boolean
Method and URL:
PATCH https://192.168.18.18/redfish/v1/UpdateService
Request header:
X-Auth-Token:TOKEN
Request body:
  "Oem": {
      "Public":{
Response:
    "Actions": {
        "Oem": {
            "Public": {
                        "PATCH",
                        "FEATURE"
    "Oem": {
        "Public": {
            "FirmwareList": {
            "MirrorPool": {
            "UpgradeState": null,
    "Status": {
        "Health": "OK",
        "State": "Enabled"
Response code: 200
For information about the response fields, see "Obtain update service information."
Change history
Version
Change description
HDM2-1.56
Added this interface.
Obtain firmware inventory collection information
Obtain information about all firmware inventories from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/UpdateService/FirmwareInventory
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/UpdateService/FirmwareInventory
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#SoftwareInventoryCollection.SoftwareInventoryCollection",
    "@odata.id": "/redfish/v1/UpdateService/FirmwareInventory",
    "@odata.type": "#SoftwareInventoryCollection.SoftwareInventoryCollection",
    "Description": "Collection of Firmware Inventory resources available to the UpdateService",
    "Members": [
            "@odata.id": "/redfish/v1/UpdateService/FirmwareInventory/HDM"
            "@odata.id": "/redfish/v1/UpdateService/FirmwareInventory/BIOS"
    "Name": "Firmware Inventory Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the firmware inventory collection resource model.
@odata.id
String
Link to the firmware inventory collection resource.
@odata.type
String
Type of the firmware inventory collection resource.
String
Description of the firmware inventory collection resource.
Members
Array
List of firmware inventories.
Members@odata.count
Integer
Number of firmware inventories.
Name
String
Name of the firmware inventory collection resource.
The server returns status code 200 for a successful operation.
Obtain firmware inventory information
Obtain information about a specific firmware inventory from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/UpdateService/FirmwareInventory/softid
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
softid
Firmware type.
You can obtain available firmware types.
Method and URL:
GET https://192.168.18.18/redfish/v1/UpdateService/FirmwareInventory/HDM
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#UpdateService/FirmwareInventory/Members/$entity",
    "@odata.id": "/redfish/v1/UpdateService/FirmwareInventory/HDM",
    "@odata.type": "#SoftwareInventory.v1_3_0.SoftwareInventory",
    "BuildDate": "2022-06-08T09:55:43+08:00",
    "Id": "HDM",
    "Name": "HDM",
    "Oem": {
        "Public": {
    "RelatedItem": [
            "@odata.id": "/redfish/v1/Managers/1"
    "SoftwareId": "HDM",
    "Status": {
        "Health": "OK",
        "HealthRollup": "OK",
        "State": "Enabled"
    "Updateable": true,
    "Version": "0.00.10"
Response code: 200
Data type
@odata.context
String
OData description of the firmware inventory resource model.
@odata.id
String
Link to the firmware inventory resource.
@odata.type
String
Type of the firmware inventory resource.
Id
String
Firmware ID.
Name
String
Firmware name.
RelatedItem
Array
ID of resources associated with the firmware.
Status. Health
String
Health status of the firmware.
Status.HealthRollup
String
Overall health status of firmware inventory resources
Status. State
String
Enabling status of the firmware.
SoftwareId
String
Firmware type.
Updateable
Boolean
Firmware validity.
BuildDate
String
Version compilation time.
Version
String
Firmware version.
Obtain image pool list
Obtain the image pool list, including images that already exist on the SD card.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/UpdateService/Oem/Public/MirrorPool
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/UpdateService/Oem/Public/MirrorPool
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#MirrorPool/MirrorPool/Members/$entity",
    "@odata.id": "/redfish/v1/UpdateService/Oem/Public/MirrorPool",
    "@odata.type": "#MirrorPool.v1_0_0.MirrorPool",
    "FreeSpace": 427757568,
    "MirrorPool": [
            "BackupFileName": "BMC_R4900-G6_0.00.02.ima",
            "FileSizeByte": 42678545,
            "ImageType": "BMC",
            "SubImageType": "R4900 G6",
            "Version": "0.00.02"
    "Oem": {
        "Public": {
    "UsedSpace": 42678545
Response code: 200
Data type
@odata.context
String
OData description of the image pool list resource model.
@odata.id
String
Link to the image pool list resource node.
@odata.type
String
Type of the image pool list resource.
MirrorPool
Array
Image pool information.
BackupFileName
String
Backup file name.
ImageType
String
Image type.
FileSizeByte
Integer
Image size.
SubImageType
String
Image subtype. Some firmware has an image subtype. If a firmware does not have a subtype, this field displays null.
Version
String
Firmware version. If no version information is available, this field displays null.
FreeSpace
Integer
Maximum file size that can be uploaded for the image pool.
UsedSpace
Integer
Used space in the image pool.
Delete an image in an image pool
Delete an image in an image pool.
Privilege module
OemDiagnosis
Request
Method and URL:
POST https://device_ip/redfish/v1/UpdateService/Actions/Oem/Public/MirrorPool.DeleteImage
Request header:
X-Auth-Token:TOKEN
Request body:
    "BackupFileName":fliename
Parameter
Value
device_ip
TOKEN
BackupFileName
Backup file name.
You can obtained backup file name from the image pool list
Method and URL:
POST https://192.168.18.18/redfish/v1/UpdateService/Actions/Oem/Public/MirrorPool.DeleteImage
Request header:
X-Auth-Token:TOKEN
Request body:
    "BackupFileName":"BMC_R4900-G6_0.00.02.ima"
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Update firmware
Update the firmware of the server.
Privilege module
OemDiagnosis
Firmware version locking
BIOS configuration locking (for BIOS update except for only ME update)
BMC configuration locking (for BMC update)
Request
Method and URL:
POST https://device_ip/redfish/v1/UpdateService/Actions/UpdateService.SimpleUpdate
Request header:
X-Auth-Token:TOKEN
Request body:
HTTP, TFTP, NFS, or HTTPS:
    "ImageURI":" tftp://IP/image.bin",
    "Oem": {
        "Public": {
            "Preserve": preserve,
            "RebootMode":reboot_mode,
            "Backup":backup,
"BiosFlash": BiosFlash,
            "ImageMd5URI":"tftp://IP/MD5.txt",
            "Date": date,
            "UpgradeType":upgrade_type
CIFS or SFTP:
"ImageURI":"sftp://username:passwd@IP/image.bin",
"Oem": {
        "Public": {
            "Backup":backup,
            "ImageMd5URI":"sftp://username:passwd@IP/MD5.txt",
            "Date": date,
Parameter
Value
device_ip
TOKEN
ImageURI
Link to the update image.
String.
Oem.Public.Preserve
Mode for preserving the existing configuration.
String. Supported options:
·     Retain.
·     Restore.
·     ForceRestore.
Oem.Public.RebootMode
Reboot mode.
·     Auto.
·     Manual.
Oem.Public.Backup
Whether to back up firmware.
Boolean. Supported options:
·     true.
·     false.
Oem.Public.BiosFlash
Both BIOS primary and backup partitions upgrade at the same time.
·     FLash1 ——Upgrade the primary BIOS partition.
·     FLash2 ——Upgrade the backup BIOS partition.
Oem.Public.Reboot
Server reboot status.
·     true—Reboot.
·     false—Not reboot.
Oem.Public.Date
Task delay time.
String.
Oem.Public.UpgradeType
Type of the firmware to update.
BIOS:
·     all—Update the BIOS and ME.
·     bios—Update the BIOS only.
·     me—Update ME only.
SEAMLESS:
·     all—Update the BIOS, ME, and Microcode.
·     microcode—Update Microcode only.
·     bios+me—Update the BIOS and ME only.
·     bios+microcode—Update BIOS and Microcode only.
·     me+microcode—Update ME and Microcode only.
Oem.Public.ImageMd5URI
(Optional.) Path of the MD5 value of the update image package.
N/A.
Method and URL:
POST https://192.168.18.18/redfish/v1/UpdateService/Actions/UpdateService.SimpleUpdate
Request header:
X-Auth-Token:TOKEN
Request body:
"ImageURI":"tftp://192.168.21.21/BMC.bin",
"Oem": {
"Public": {
"Preserve":"Retain",
"RebootMode":"Auto"
Response:
  "@odata.context": "/redfish/v1/$metadata#TaskCollection.TaskCollection",
  "@odata.type": "#TaskCollection.TaskCollection",
  "Members": [
      "@odata.id": "/redfish/v1/TaskService/Tasks/2"
  "Name": "Task Collection",
  "Oem": {
    "Public": {
      "TaskUniqueID": 1678656297
Response code: 202
Data type
@odata.context
String
OData description of the firmware update task service.
@odata.type
String
Type of the firmware update task service.
Name
String
Name of the firmware update .
Members@odata.count
Integer
Number of tasks generated by firmware update.
Members
Array
Task link collection generated by the firmware update.
@odata.id
String
Task link generated by the firmware update.
Oem.Public.TaskUniqueID
Array
Unique ID of the firmware update task service.
The server returns status code 202 for a successful operation.
Change history
Version
Change description
HDM3-1.06
Added the Oem.Public.BiosFlash field in the request body.
HDM2-1.53
Obtain firmware inventory information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/UpdateService/Oem/Public/FirmwareList
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/UpdateService/Oem/Public/FirmwareList
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#FirmwareListCollection.FirmwareListCollection",
    "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList",
    "@odata.type": "#FirmwareListCollection.FirmwareListCollection",
    "Members": [
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/BMCP"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/BMCS"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/BMCCPLD"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/CPLD1"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/CPLD2"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/BIOS"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/RC"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/ME"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/MICROCODE"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/PSU1"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/PSU2"
            "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/PFRCPLD"
    "Members@odata.count": 12,
    "Name": "Firmware List Collection",
    "Oem": {
        "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the server firmware inventory.
@odata.id
String
Link to the server firmware inventory node.
@odata.type
String
Type of the server firmware inventory collection resource.
Members
Array
Firmware inventory name.
Members@odata.count
Integer
Name
String
Name of firmware inventory collection resource.
Change history
Version
Change description
HDM2-1.60
Changed the firmware names CPLD and SCPLD to CPLD1 and CPLD2, respectively. CPLD and SCPLD are still compatible.
Obtain information of a firmware inventory
Obtain information of a firmware inventory.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/UpdateService/Oem/Public/FirmwareList/firmware_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
firmware_id
Firmware name.
You can obtain it from the firmware inventory information.
Method and URL:
GET https://192.168.18.18/redfish/v1/UpdateService/Oem/Public/FirmwareList/BMCP
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#UpdateService/FirmwareList/Members/$entity",
    "@odata.id": "/redfish/v1/UpdateService/Oem/Public/FirmwareList/BMCP",
    "@odata.type": "#FirmwareList.v1_0_0.FirmwareList",
    "FirmwareName": "HDM",
    "Location": "bmc card",
    "Model": "-",
    "Name": "BMCP",
    "Oem": {
        "Public": {
            "Description": "Success"
    "Version": "1.12"
Response code: 200
Data type
@odata.context
String
OData description of the firmware inventory.
@odata.id
String
Link to the firmware inventory node.
@odata.type
String
FirmwareName
String
Firmware name.
Version
String
Firmware version number.
Location
String
Firmware location.
Model
String
Device model.
Name
String
Name of the firmware inventory resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/UpdateService/Oem/Public//InstalledPackages
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/UpdateService/Oem/Public/InstalledPackages
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#InstalledPackages.InstalledPackages",
    "@odata.id": "/redfish/v1/UpdateService/Oem/Public/InstalledPackages",
    "@odata.type": "#InstalledPackages.v1_0_0.InstalledPackages",
    "Name": "Installed Packages Collection",
    "Oem": {
        "Public": {
    "Packages": [
            "ExternalVersion": "0.00.02",
            "Id": "2",
            "InternalVersion": "V100R001B01BBIT02",
            "Name": "Diag",
            "PackageType": "FEATURE"
    "Packages@odata.count": 1
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
Type of the server firmware inventory resource.
Packages
Array
Package details.
Id
String
Package ID.
Name
String
Package name.
PackageType
String
Package type. Supported options:
·     PATCH patch package.
·     FEATURE feature package.
InternalVersion
String
Internal version number.
ExternalVersion
String
External version number.
Integer
Number of packages.
Uninstall a firmware package
Uninstall a firmware package.
Privilege module
OemDiagnosis
Request
Method and URL:
POST https://device_ip/redfish/v1/UpdateService/Actions/Oem/Public/UpdateService.UninstallPackage
Request header:
X-Auth-Token:TOKEN
Request body:
    "Id": id,
    "PackageType":package_type
Parameter
Value
device_ip
TOKEN
Id
Package ID.
You can obtain available package IDs from the firmware package collection interface.
PackageType
Package type.
Supported options:
Method and URL:
POST https://192.168.18.18/redfish/v1/UpdateService/Actions/Oem/Public/UpdateService.UninstallPackage
Request header:
X-Auth-Token:TOKEN
Content-Type:application/json
Request body:
    "Id": "1",
    "PackageType":" PATCH"
Response:
"Oem": {
       "Public": {
"error": {
               "Message": "Successfully Completed Request",
               "MessageArgs": [],
               "MessageId": "Base.1.8.1.Success",
               "Resolution": "None"
        "code":"Base.1.8.1.Success",
        "message":"Successfully Completed Request"
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Privilege module
OemDiagnosis
Request
Method and URL:
POST https://device_ip/redfish/v1/UpdateService/Actions/Oem/Public/UpdateService.DumpBIOS
Request header:
X-Auth-Token:TOKEN
Request body:
·     Remote export:
¡     CIFS or SFTP:
"Type":"URI",
"Content":"cifs://username:password@ip/filename"
¡     HTTP, TFTP, NFS, or HTTPS:
"Type":"URI",
Parameter
Value
device_ip
TOKEN
Method to export the BIOS firmware.
URI. You can obtain it from the firmware package collection interface.
Content
Path to export the BIOS firmware.
See "Others."
ScriptName
Script file name.
String.
This field is required if you use HTTP or HTTPS to export the file.
Method and URL:
POST https://192.168.188.188/redfish/v1/UpdateService/Actions/Oem/Public/UpdateService.DumpBIOS
Request header:
X-Auth-Token:TOKEN
Request body:
    "Type":"URI",
    "Content":"nfs://192.168.8.7/Share1/aaa.bin"
Response:
  "Members": [
  "Oem": {
    "Public": {
      "Description": "Success",
Response code: 202
Data type
@odata.context
String
OData description of the task service resource Model.
@odata.type
String
Type of the task service resource.
Name
String
Name of the task collection resource.
Members@odata.count
Integer
Number of currently running tasks.
Members
Task resource list.
@odata.id
String
Link to the specified task.
Integer
Unique ID of the specified task.
Change history
Version
Change description
HDM2-1.15
Changed request body Oem.Public.ScriptName to ScriptName.
Operations on task service resources
Obtain task service information
Obtain current information about the task service from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/TaskService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/TaskService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#TaskService.TaskService",
    "@odata.id": "/redfish/v1/TaskService",
    "@odata.type": "#TaskService.v1_1_5.TaskService",
    "CompletedTaskOverWritePolicy": "Oldest",
    "DateTime": "2022-02-23T07:19:34+08:00",
    "Description": "Task Service",
    "Id": "TaskService",
    "LifeCycleEventOnTaskStateChange": false,
    "Name": "Task Service",
    "Oem": {
        "Public": {
    "ServiceEnabled": true,
    "Status": {
        "Health": "OK",
        "State": "Enabled"
    "Tasks": {
        "@odata.id": "/redfish/v1/TaskService/Tasks"
Response code: 200
Data type
@odata.context
String
OData description of the task service resource model.
@odata.id
String
Link to the task service resource.
@odata.type
String
Id
String
ID of the task service resource.
Name
String
Name of the task service resource.
DateTime
String
System date and time.
String
Processing policy for completed tasks. Supported options:
·     Oldest—Overwrite the oldest tasks.
Boolean
Whether to report task state changes. Supported options:
·     false—Do not report task state changes.
Status
Object
Resource status:
·     Health—Health status.
·     StateEnabling status.
ServiceEnabled
Boolean
Enabling status of the task service.
Tasks
Object.
@odata.id
String
Link to the task collection resource.
Obtain task collection information
Obtain information about all tasks from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/TaskService/Tasks
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/TaskService/Tasks
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#TaskService/Tasks/$entity",
    "@odata.id": "/redfish/v1/TaskService/Tasks",
    "Members": [
            "@odata.id": "/redfish/v1/TaskService/Tasks/7"
    "Oem": {
        "Public": {
            "CountOfCanceledTask": 0,
            "CountOfCompletedTask": 0,
            "CountOfCurrentTask": 7,
            "CountOfDeletedTask": 0,
            "CountOfFailedTask": 0,
            "DeletedMembers": [
                    "@odata.id": "/redfish/v1/TaskService/Tasks/4"
                    "@odata.id": "/redfish/v1/TaskService/Tasks/5"
                    "@odata.id": "/redfish/v1/TaskService/Tasks/6"
            "DeletedMembers@odata.count": 6,
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
Name
String
Members@odata.count
Integer
Number of current running tasks.
Members
Object.
@odata.id
String
Link to a specific task resource.
Oem.Public.CountOfCanceledTask
Integer
Number of tasks cancelled.
Oem.Public.CountOfCompletedTask
Integer
Number of successful tasks.
Oem.Public.CountOfCurrentTask
Integer
Number of current tasks.
Oem.Public.CountOfDeletedTask
Integer
Number of tasks deleted.
Oem.Public.CountOfFailedTask
Integer
Number of failed tasks.
DeletedMembers
Integer
Tasks to be deleted.
Integer
Number of tasks to be deleted.
Obtain task inforamtion
Obtain information about a specific task from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/TaskService/Tasks/task_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
task_id
Task resource ID.
You can obtain available task resource IDs from task collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/TaskService/Tasks/7
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#TaskService/Tasks/Members/$entity",
    "@odata.id": "/redfish/v1/TaskService/Tasks/7",
    "@odata.type": "#Task.v1_5_0.Task",
    "EndTime": "",
    "Id": "7",
    "Messages": {
        "Message": "",
        "MessageArgs": [
        "MessageId": "",
        "RelatedProperties": [
        "Resolution": "",
        "Severity": "",
        "Trigger Condition": ""
    "Name": "Task 7",
    "Oem": {
        "Public": {
            "Description": "Upgrade management",
            "TaskDescription": "Upgrade management",
            "TaskPercentage": "70%",
    "StartTime": "2022-02-23T07:22:12+08:00",
    "TaskState": "Running",
    "TaskStatus": "OK"
Response code: 200
Data type
@odata.context
String
@odata.id
String
Link to the task resource.
@odata.type
String
Type of the task resource.
Id
String
ID of the task resource.
String
Description of the task resource.
Name
String
Name of the task resource.
TaskState
String
Task state. Supported options:
·     Running.
·     Pending.
·     Completed.
·     Cancelled.
·     Exception.
StartTime
String
Start time of the task.
EndTime
String
End time of the task.
TaskStatus
String
Running status of the task. Supported options:
·     OK.
Messages.MessageId
String
Message ID.
Messages.RelatedProperties
Array
Related properties for the message.
Messages.Message
String
Messages.MessageArgs
Array
Message arguments.
Messages.Resolution
String
Messages.Severity
String
·     OK.
·     Warning.
·     Critical.
Messages.Trigger Condition
String
Trigger condition. Supported options:
·     BMC Reset.
·     OS Reset.
·     OS Power Off.
·     Automatic.
·     Power Cycle.
·     PSU Reset.
·     Take Effect Immediately.
Oem.Public.TaskDescription
String
Task description.
Oem.Public.TaskPercentage
String
Task completion progress, in percent.
Integer
Change history
Version
Change description
HDM2-1.15
Corrected the description for the Messages.Trigger Condition field.
Delete a task
Delete a task resource in pending status.
Privilege module
OemDiagnosis
Request
Method and URL:
DELETE https://device_ip/redfish/v1/TaskService/Tasks/task_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
task_id
Task resource ID.
Method and URL:
DELETE https://192.168.18.18/redfish/v1/TaskService/Tasks/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageId
String
Message ID.
Message
String
MessageArgs
Array
Message arguments.
MessageSeverity
String
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
Obtain server scheduled task list information
Obtain server scheduled task list information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/TaskService/Oem/Public/TimedTasks
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/TaskService/Oem/Public/TimedTasks
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
  "@odata.context": "/redfish/v1/$metadata#TimedTasksCollection.TimedTasksCollection",
  "@odata.id": "/redfish/v1/TaskService/Oem/Public/TimedTasks",
"@odata.type": "#TimedTasksCollection.TimedTasksCollection",
  "Id": "TimedTasksCollection",
"Name": "TimedTasksCollection",
"Members":[
"@odata.id": "/redfish/v1/TaskService/Oem/Public/TimedTasks/1"
"@odata.id": "/redfish/v1/TaskService/Oem/Public/TimedTasks/2"
"Members@odata.count": 2,
"Oem": {
"Public":{
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
Id
String
Name
String
Members
String
Link to scheduled task list information.
Members@odata.count
String
Number of scheduled tasks.
Obtain information of a server scheduled task
Obtain information of a server scheduled task.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/TaskService/Oem/Public/TimedTasks/task_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
task_id
Scheduled task resource ID.
You can obtain available task resource IDs from server scheduled task list information.
Method and URL:
GET https://192.168.18.18/redfish/v1/TaskService/Oem/Public/TimedTasks/2
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
  "@odata.context": "/redfish/v1/$metadata#TaskService.TimedTasks",
  "@odata.id": "/redfish/v1/TaskService/Oem/Public/TimedTask/2",
"@odata.type": "#TimedTasksInstance.v1_0_0.TimedTasksInstance",
  "Id": "2",
"Name": "TimedTasks Instance",
"TaskType":"Firmware Update",
"TaskState":"Executed",
"Clock":{
     "ClockType":"Single",
     "ExecuteTime":{
                    "Year":2023,
"Month":11,
         "Day":18,
         "Hour":16,
         "Minute":44,
         "Week":null
"TaskDescription":"Uploading Version 2.17",
"Oem": {
    "Public": {
Response code: 200
Data type
@odata.context
String
@odata.id
String
@odata.type
String
TaskType
String
Scheduled task type.
TaskState
String
Scheduled task execution status. Supported options:
·     NewCreating a new scheduled task.
·     CompletedThe scheduled task has been executed.
·     ExceptionAn exception occurs on the execution of a scheduled task.
TaskDescription
Boolean
Description of the scheduled task.
Clock
Object
Clock.
Clock.ClockType
String
Clock types. Supported options:
·     Monthly.
·     Weekly.
·     Daily.
·     Hourly.
·     Minutely.
·     Single.
This field only supports setting the one-time clock in the current software version.
Clock.ExecuteTime.Year
Integer
Year.
Clock.ExecuteTime.Month
Integer
Month.
Clock.ExecuteTime.Day
Integer
Day.
Clock.ExecuteTime.Hour
Integer
Hour.
Clock.ExecuteTime.Minute
Integer
Minute.
Clock.ExecuteTime.Week
String
Week.
Edit a server scheduled task
Edit a server scheduled task.
Privilege module
OemDiagnosis
Request
Method and URL:
PATCH https://device_ip/redfish/v1/TaskService/Oem/Public/TimedTasks/task_id
Request header:
X-Auth-Token:TOKEN
Request body:
"Clock":{
     "ExecuteTime":{
                   "Year":2023,
"Month":11,
         "Day":18,
         "Hour":16,
         "Minute":44,
         "Week":"Monday"
Parameter
Value
device_ip
TOKEN
task_id
ifmatch_value
Clock.ClockType
Clock Types.
·     Monthly.
·     Weekly.
·     Daily.
·     Hourly.
·     Minutely.
·     Single.
Year.
Integer
Month.
Integer
Day.
Integer
Hour.
Integer
Minute.
Integer
Week.
String
Method and URL:
patch https://192.168.30.151/redfish/v1/TaskService/Oem/Public/TimedTasks/2
Request header:
X-Auth-Token:TOKEN
Request body:
    "Clock":{
        "ExecuteTime":{
            "Year":2023,
            "Month":11,
            "Day":18,
            "Hour":16,
            "Minute":44,
            "Week":"Monday"
Response:
  "@odata.id": "/redfish/v1/TaskService/TimedTasks",
  "Id": "2",
"Clock":{
        "ExecuteTime":{
            "Year":2023,
"Month":11,
            "Day":18,
            "Hour":16,
            "Minute":44,
            "Week":null
"Description":"Uploading Version 2.17",
"Oem": {
   "Public": {
Response code: 200
For information about the response fields, see "Obtain server scheduled task list information."
Operations on event service resources
Obtain event collection information
Obtain information about all events from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/EventService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/EventService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.context": "/redfish/v1/$metadata#EventService.EventService",
    "@odata.id": "/redfish/v1/EventService/",
    "@odata.type": "#EventService.v1_7_2.EventService",
    "Actions": {
        "#EventService.SubmitTestEvent": {
            "@Redfish.ActionInfo": "/redfish/v1/EventService/SubmitTestEventActionInfo",
            "target": "/redfish/v1/EventService/Actions/EventService.SubmitTestEvent"
    "DeliveryRetryAttempts": 1,
    "DeliveryRetryIntervalSeconds": 3,
    "Description": "Event Service",
    "EventTypesForSubscription": [
        "StatusChange",
        "ResourceUpdated",
        "ResourceAdded",
        "ResourceRemoved",
        "Alert"
    "Id": "EventService",
    "Name": "Event Service",
    "Oem": {
        "Public": {
    "Status": {
        "Health": "OK",
        "State": "Enabled"
    "Subscriptions": {
        "@odata.id": "/redfish/v1/EventService/Subscriptions"
Response code: 200
Data type
@odata.context
String
OData description of the EventService resource model.
@odata.id
String
Link to the EventService resource.
@odata.type
String
Type of the event EventService resource.
Actions
Supported EventService actions.
vent
Object
Send test events.
@Redfish.ActionInfo
String
Send the information obtaining link for test event actions.
target
String
Link to simulate the reporting of test events.
Integer
Maximum retransmission attempts for event subscription messages.
Integer
Event subscription retransmission interval.
String
Description of the event service resources.
Array
Event types available for subscription. Supported options:
·     StatusChange.
·     ResourceUpdated.
·     ResourceAdded.
·     ResourceRemoved.
·     Alert.
ServiceEnabled
Boolean
Event report enabling status.
Id
String
ID of the event subscription resource.
Name
String
Name of the event subscription resource.
Status
Object
Resource status:
Subscriptions
Object
Link to the event subscription collection information.
Create an event subscription
Create an event subscription.
Privilege module
ConfigureComponents
Request
Method and URL:
POST https://device_ip/redfish/v1/EventService/Subscriptions
Request header:
X-Auth-Token:TOKEN
Request body:
    "Destination": "https://172.16.11.95",
    "EventTypes": [
        "StatusChange",
        "ResourceUpdated",
        "ResourceAdded",
        "ResourceRemoved",
        "Alert"
    "HttpHeaders": [{
        "Content-Type": "application/json",
        "OData-Version": "4.0",
        "X-Auth-Token":"2e751b825163447d30d3021c98116221"
    "Context": "event subscription context string",
    "Protocol":"Redfish",
    "MessageIds":[ ],
    "OriginResources":[ ]
Parameter
Value
device_ip
TOKEN
Destination
Event recipient.
String.
EventTypes
Types of events to be subscribed to.
Array.
HttpHeaders
HTTP header carried in messages for event report.
The X-Auth-Token is generated when a session is created by using /redfish/v1/SessionService/Sessions.
Array.
Context
Event subscription context information.
String.
Protocol
Event subscription protocol.
·     Redfish.
MessageIds
Event subscription message ID matching list.
Array.
OriginResources
Event source matching list.
Array.
The subscription will include all events, if an empty value is specified for this field.
Method and URL:
POST https://192.168.18.18/redfish/v1/EventService/Subscriptions
Request header:
X-Auth-Token:TOKEN
Request body:
    "Destination": "https://192.168.25.11",
    "EventTypes": [
        "StatusChange",
        "ResourceUpdated",
        "ResourceAdded",
        "ResourceRemoved",
        "Alert"
    "HttpHeaders": [{
    "MessageIds": [],
        "OriginResources": [{
             "@odata.id": "/redfish/v1/Chassis/1/Thermal#/Fans"
Response:
  "@odata.context": "/redfish/v1/$metadata#EventDestination.EventDestination",
  "@odata.id": "/redfish/v1/EventService/Subscriptions/5",
  "@odata.type": "#EventDestination.v1_9_0.EventDestination",
  "Description": "Event Subscription Instance",
  "EventTypes": [
    "Alert",
    "ResourceUpdated",
    "StatusChange"
  "HttpHeaders": null,
  "Id": "5",
  "MessageIds": [],
  "Name": "Event Destination 5",
  "Oem": {
    "Public": {
  "OriginResources@odata.count": 1,
  "Protocol": "Redfish",
  "SubscriptionType": "RedfishEvent"
Response code: 201
For information about the response fields, see "Obtain event subscription information."
Obtain event subscription collection information
Obtain information about all event subscriptions from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/EventService/Subscriptions
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/EventService/Subscriptions
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"@odata.context": "/redfish/v1/$metadata#EventDestinationCollection.EventDestinationCollection",
  "@odata.id": "/redfish/v1/EventService/Subscriptions",
  "@odata.type": "#EventDestinationCollection.EventDestinationCollection",
  "Description": "Collection for Event Subscriptions",
  "Members": [
            "@odata.id": "/redfish/v1/EventService/Subscriptions/1"
            "@odata.id": "/redfish/v1/EventService/Subscriptions/2"
  "Name": "Event Subscriptions Collection",
  "Oem": {
    "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the event subscription collection resource model.
@odata.id
String
Link to the event subscription collection resource.
@odata.type
String
Type of the event subscription collection resource.
Name
String
Name of the event subscription collection resource.
String
Description of the event subscription collection resource.
Members@odata.count
Integer
Number of event subscription resources.
Members
Event subscription resource list.
@odata.id
String
Link to an event subscription resource.
Obtain information about a specific event subscription from the server.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/EventService/Subscriptions/id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
id
Event subscription resource ID.
You can obtain available event subscription resource IDs from event subscription collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/EventService/Subscriptions/5
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
  "EventTypes": [
    "Alert",
    "ResourceUpdated",
    "StatusChange"
  "Id": "5",
  "MessageIds": [
    "EventLog.1.0.FanEventSufficient"
  "Oem": {
    "Public": {
Response code: 200
Data type
@odata.context
String
OData description of the event subscription resource model.
@odata.id
String
Link to the event subscription resource.
@odata.type
String
Type of the event subscription resource.
String
Description of the event subscription resource.
Id
String
Name
String
Destination
String
URI of the destination event service.
EventTypes
Array
Types of events to be sent. Supported options:
·     ResourceRemoved.
·     ResourceAdded.
·     StatusChange.
·     ResourceUpdated.
·     Alert.
HttpHeaders
Object
Protocol
String
Event subscription protocol. Only Redfish is available.
Context
String
String provided by the client to be stored together with the subscribed event.
MessageIds
Array
OriginResources
Array
Event subscription event source matching list
Integer
Number of the event origin resources.
SubscriptionType
String
Type of the subscribed event.
Edit an event subscription
Edit an event subscription.
Privilege module
ConfigureComponents
Request
Method and URL:
PATCH https://device_ip/redfish/v1/EventService/Subscriptions/id
Request header:
X-Auth-Token:TOKEN
Request body:
   "HttpHeaders": http_headers,
    "Context":"abcdefg"
Parameter
Value
device_ip
TOKEN
id
ifmatch_value
HttpHeaders
HTTP header information.
Object.
Context
String.
Method and URL:
PATCH https://192.168.30.151/redfish/v1/EventService/Subscriptions/1
Request header:
X-Auth-Token:TOKEN
Request body:
   "HttpHeaders": [{
"Context":" Event Subscription Instance 5"
Response:
  "Context": "Event Subscription Instance 5",
  "EventTypes": [
    "Alert",
    "ResourceUpdated",
    "StatusChange"
  "Id": "5",
  "MessageIds": [
  "Oem": {
    "Public": {
Response code: 200
Delete an event subscription
Delete an event subscription.
Privilege module
ConfigureComponents
Request
Method and URL:
DELETE https://device_ip/redfish/v1/EventService/Subscriptions/id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
id
Method and URL:
DELETE https://192.168.30.151/redfish/v1/EventService/Subscriptions/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
"Oem": {
       "Public": {
"error": {
       "@Message.ExtendedInfo": [
               "@odata.type": "#Message.v1_1_1.Message",
               "MessageArgs": [],
               "MessageSeverity": "OK",
Response code: 200
Data type
code
String
String of a specific message ID in the message registry.
message
String
Readable error message corresponding to the message in the message registry.
Message extended information.
@odata.type
String
OData description of the message resource.
MessageId
String
Message ID.
Message
String
Extended human-readable error message.
MessageArgs
Array
Message arguments.
MessageSeverity
String
Severity level of the error. Supported options:
·     OK.
·     Warning.
·     Critical.
Resolution
String
Recommended actions for the error.
Change history
Version
Change description
HDM2-2.04
Added the error node before Message.ExtendedInfo and added the code and message fields under the error node.
Report error alarms
Report error alarms and parse the message.
It is not a Redfish interface.
Example report
headers:
    IOrderedDict([
        ('User-Agent', 'LuaSocket 3.0-rc1'),
        ('TE', 'trailers'),
        ('Content-Length', '800'),
        ('Connection', 'close, TE'),
        ('Content-Type', 'application/json'),
        ('Host', '192.168.25.11')
bodydata:
    "@odata.context":"/redfish/v1/$metadata#Event.Event",
    "@odata.id":"/redfish/v1/EventService/Events/7",
    "@odata.type":"#Event.v1_6_0.Event",
    "Context":"Public",
    "Events":[{
        "EventId":"26",
        "EventTimestamp":"2020-05-08T17:58:05+08:00",
        "EventType":"Alert",
        "MemberId":"26",
        "Message":"Drive(Drive Slot/Bay): Drive fault --- Bay Slot: 0, HDD Slot: 0",
        "MessageArgs":[],
        "MessageId":"EventLog.1.0.0.Alert",
        "Oem":{
            "Public":{
                "AddInfo":"",
                "alarmStatus":"Asserted",
                "locationInfo":"Drive",
                "neName":"(none)",
                "neType":"server",
                "neUID":"210200A00QH17C000001",
                "objectName":"Drive",
                "objectType":"Drive Slot/Bay",
                "objectUID":"",
                "specificProblem":"Drive fault",
                "specificProblemID":"0x0d6f0100",
                "EventAssertedSeverity": "Major"
        "OriginOfCondition":{
            "@odata.id":"/redfish/v1/Chassis/1/Drives"
        "Severity":"Major"
    "Events@odata.count":1,
    "Id":"7",
    "Name":"Event Array"
Field description
Data type
headers
Message header.
User-Agent
String.
User agent.
TE
String.
Encoding type used by the user agent for transmission.
Content-Length
String.
Length of the transmitted HTTP message content.
Connection
String.
Whether a persistent connection is required.
Content-Type
String.
MIME type.
Host
String.
Server domain and port number.
The port number depends on the destination address specified at subscription creation.
bodydata
Body information.
@odata.context
String
OData description of the message registry.
@odata.id
String
Link to the message registry.
The last level in the URL matches the displayed ID on the page.
@odata.type
String
Type of the message registry.
Context
String
Event subscription context.
Events
Array
Event information
EventId
String
Alarm event ID and the serial number of the alarm event. The same component and the same type of event alarms have the same EventId when the alarms are generated continuously. An alarm generation event has the same alarm EventId as the corresponding alarm clearance event.
EventTimestamp
String
Time at which the alarm occurred.
EventType
String
Event type. Supported options:
·     StatusChange.
·     ResourceUpdated.
·     ResourceAdded.
·     ResourceRemoved.
·     Alert.
MemberId
String
Member ID of the alarm message, consistent with the displayed ID on the page.
Message
String
Alarm message or message headline.
MessageArgs
String
Message arguments.
MessageId
String
Message ID.
Oem.Public.AddInfo
String
Alarm addition information or alarm details.
A key and its value are separated with a colon (:) and two key-value pairs are separated with a semicolon (;).
Keys and key values cannot contain colons (:) or semicolons (;).
Oem.Public.alarmStatus
String
Alarm status. Supported options:
·     AssertedActive.
·     DeassertedCleared.
Oem.Public.locationInfo
String
Location information.
Oem.Public.neName
String
Asset number of the server on which the alarm occurred.
Oem.Public.neType
String
Alarm device type. Supported options:
·     server.
Oem.Public.neUID
String
Serial number of the server on which the alarm occurred.
Oem.Public.objectName
String
Name of the component on which the alarm occurred.
Oem.Public.objectType
String
Type of the component on which the alarm occurred.
Oem.Public.objectUID
String
ID of the component on which the alarm occurred.
Oem.Public.specificProblem
String
Alarm description.
Oem.Public.specificProblemID
String
Alarm ID.
Oem.Public.EventAssertedSeverity
String
Alarm severity. Supported options:
·     1—Critical.
·     2—Major.
·     3—Minor.
·     4—Warning.
·     5—Info.
OriginOfCondition
Object
Link to the origin of condition.
Severity
String
·     1—Critical.
·     2—Major.
·     3—Minor.
·     4—Warning.
·     5—Info.
Events@odata.count
Integer
Number of alarms.
Id
String
Alarm ID, consistent with the displayed ID on the page.
Name
String
Name of the alarm report interface.
Change history
Version
Change description
HDM2-2.02
Changed the field description of the EventId, Oem.Public.specificProblem, Oem.Public.specificProblemID, Oem.Public.EventAssertedSeverity, and Severity fields.
Simulate reporting test events
Simulate reporting test events.
Privilege module
ConfigureComponents
Request
Method and URL:
POST https://device_ip/redfish/v1/EventService/Actions/EventService.SubmitTestEvent
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
IP address for logging in to the device.
IPv4 or IPv6 address.
TOKEN
id
Method and URL:
POST https://192.168.18.18/redfish/v1/EventService/Actions/EventService.SubmitTestEvent
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
@odata.type
String
MessageArgs
Array
Message arguments.
MessageId
String
Message ID.
Resolution
String
Severity
String
·     OK.
·     Warning.
·     Critical.
Change history
Version
Change description
HDM2-2.04
Operations on license service resources
Obtain license service information
Obtain license service information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/LicenseService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/LicenseService
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
  "@odata.context": "@odata.type": "#LicenseService.v1_0_0.LicenseService",
    "Name": "License Service",
    "Actions": {
        "#LicenseService.Install": {
            "target": "/redfish/v1/LicenseService/Actions/LicenseService.Install",
            "@Redfish.ActionInfo": "/redfish/v1/LicenseService/InstallActionInfo"
        "Oem": {
            "Public":{
                "#LicenseService.Export": {
                    "target": "/redfish/v1/LicenseService/Actions/Oem/Public/LicenseService.Export",
                    "@Redfish.ActionInfo": "/redfish/v1/LicenseService/Oem/Public/ExportActionInfo"
                "#LicenseService.Uninstall ": {
                    "target": "/redfish/v1/LicenseService/Actions/Oem/Public/LicenseService.Uninstall ",
                    "@Redfish.ActionInfo": "/redfish/v1/LicenseService/Oem/Public/ UninstallActionInfo"
    "LicenseExpirationWarningDays":10,
    "Licenses": {
        "@odata.id": "/redfish/v1/LicenseService/Licenses"
    "Oem": {
        "Public": {
            "DeviceID" :"1B45F9365F95737DBA154EDE3C6C9C9A7BBC94F2",
    "@odata.id": "/redfish/v1/LicenseService"
Response code: 200
Data type
@odata.id
String
Link to the license service resource.
@odata.type
String
Type of the license service resource.
Name
String
Name of the license service resource.
Actions
Executable actions for License service resources.
Object
License certificate uninstallation.
Object
License certificate export.
Integer
Time to send alarm messages before certificate expiration.
Licenses
Object
Link to license certificate collection resource.
ServiceEnabled
Boolean
Enabling status of the license service.
Oem.Public.DeviceID
String
DID code of the specified device.
Obtain license resource collection information
Obtain license resource collection information.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/LicenseService/Licenses
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
Method and URL:
GET https://192.168.18.18/redfish/v1/LicenseService/Licenses
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/LicenseService/Licenses",
    "@odata.type": "#LicenseCollection.LicenseCollection",
    "Name": "License Collection",
    "Members": [
            "@odata.id": "/redfish/v1/LicenseService/Licenses/1"
    "Oem": {
    "Public": {
Response code: 200
Data type
@odata.id
String
Link to the license collection resource.
@odata.type
String
Type of the license collection resource.
Name
String
Name of the license collection resource.
Members@odata.count
Integer
Number of the license collection resource.
Members
Task resource list.
Navigation link to the specified license resource.
Obtain information of a license resource
Obtain information of the specified license resource.
Privilege module
Login
Request
Method and URL:
GET https://device_ip/redfish/v1/LicenseService/Licenses/license_id
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Parameter
Value
device_ip
TOKEN
license_id
License ID.
You can obtain license IDs by license resource collection information.
Method and URL:
GET https://192.168.18.18/redfish/v1/LicenseService/Licenses/1
Request header:
X-Auth-Token:TOKEN
Request body:
N/A
Response:
    "@odata.id": "/redfish/v1/LicenseService/Licenses/1",
    "@odata.type": "#License.v1_0_0.License",
    "Id": "1",
    "Name": "License 1",
    "Status": {
        "State": "Enabled",
        "Health": "OK" ,
        "Oem": {
            "Public": {
                "LicenseStatus":"Using"
    "LicenseType": "Trial",
    "SerialNumber": "1errefde1111",
    "Oem": {
        "Public": {
            "LicenseRemainingHours":null,
            "LicenseTimeType":""
Response code: 200
Data type
@odata.id
String
@odata.type
String
Name
String
Name of the license resource.
Id
String
ID of the license resource.
Status
Object
License resource status. Supported options:
·     HealthHealth state of the license resource
·     StateEnbaling status of the license resource.
·     License status:
¡     Using.
¡     Expired.
¡     Unavailable.
¡     Expiring.
¡     Uninstalled.
LicenseType
String
License type. Supported options:
·     Trial—Temporary.
·     Production—Official.
SerialNumber
String
Serial number.
Oem.Public.LicenseRemainingHours
String
Remaining validity time.
Oem.Public.LicenseTimeType
String
Authorization time type. Supported options:
·     Permanent.
·     Relative.
Change history
Version
Change description
HDM2-1.14
Changed Trial to Production in License Type filed.
Install the license activation file
Install the license activation file.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/LicenseService/Actions/LicenseService.Install
Request header:
X-Auth-Token:TOKEN
Request body:
·     Installation via local import:
"Type":"URI",
"Content": "/tmp/web/Licensefiefile"
·     Installation via remote import:
¡     CIFS or SFTP:
"Type":"URI",
"Content": "sftp://username:password@10.10.10.191/usr/Licensefiefile"
"Type":"URI",
"Content":"http://ip/Licensefiefile "
Parameter
Value
device_ip
TOKEN
URI.
String.
Content
Link to the license file.
·     File transfer protocols: SFTP, HTTPS, HTTP, NFS, CIFS, and TFTP.
·     Operation path, which does not support Chinese characters.
·     Up to 1024 characters. Chinese characters are not supported and the following special characters are supported: @!$^&()_+.;[]{}-=~`
·     Only the /tmp/web/ directory and its subdirectories are supported locally.
·     The total length of the TFTP protocol directory and file name is up to 240 characters.
Method and URL:
POST https://192.168.18.18/redfish/v1/LicenseService/Actions/LicenseService.Install
Request header:
X-Auth-Token:TOKEN
Content-Type: application/json
Request body:
"Type":"URI",
"Content": "sftp://username:password@10.10.10.191/usr/Licensefiefile.xml"
Response:
  "Members": [
  "Oem": {
    "Public": {
Response code: 202
Data type
@odata.context
String
OData Description of the task service for installing the license activation file.
@odata.type
String
Type of the task service for installing the license activation file.
@odata.id
String
Link to the task service for installing the license activation file.
Members@odata.id
Object
Task link generated from license activation file installation.
Integer
Unique ID of the task service for installing the license activation file.
Change history
Version
Change description
HDM2-1.53
Added the locking type of the associated system..
Export a license file
Export a license activation or uninstallation file. This interface needs to be used in conjunction with the interface for downloading the BMC file. Execute this interface before executing the interface for downloading the BMC file in "Upload BMC file."
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/LicenseService/Actions/Oem/Public/LicenseService.Export
Request header:
X-Auth-Token:TOKEN
Request body:
·     Remote export:
¡     CIFS or SFTP:
"Type":"URI",
"Content": "sftp://username:password@10.10.10.191/usr/Licensefile",
"LicenseFileType":"Activation"
¡     NFS or TFTP:
"Type":"URI",
"Content":"http://ip/Licensefile",
¡     HTTP or HTTPS:
"Type":"URI",
"LicenseFileType":"Activation",
"ScriptName":"1.php"
·     Local export:
"Type":"URI",
"Content": "/tmp/web/filename",
Parameter
Value
device_ip
TOKEN
String.
URI.
Content
For local export, make sure this path is consistent with the path for BMC file downloading.
LicenseFileType
File type:
·     Activation—Activation file.
·     Uninstall—Uninstallation file.
String.
ScriptName
Script file name.
String.
Method and URL:
POST https://192.168.18.18/redfish/v1/LicenseService/Actions/Oem/Public/LicenseService.Export
Request header:
X-Auth-Token:TOKEN
Request body:
    "Type":"URI",
    "Content": "nfs://192.168.20.177/Share1/LicenseBackup.xml",
Response:
  "Members": [
  "Members@odata.count": 1,
  "Oem": {
    "Public": {
      "CompletionCode": 0,
Response code: 202
Response field description
Data type
@odata.context
String
OData Description of the task service for exporting the license activation file.
@odata.type
String
Type of the task service for exporting the license activation file.
@odata.id
String
Link to the task service for exporting the license activation file.
Members@odata.id
Object
Task link generated from exporting the license activation file.
Integer
Unique ID of the task service for exporting the license activation file for exporting the license activation file.
Uninstall the license activation file
Uninstall the installed license activation file.
Privilege module
ConfigureUsers
Request
Method and URL:
POST https://device_ip/redfish/v1/LicenseService/Actions/Oem/Public/LicenseService.Uninstall
Request header:
X-Auth-Token:TOKEN
Request body:
Parameter
Value
device_ip
TOKEN
Method and URL:
POST https://192.168.18.18/redfish/v1/LicenseService/Actions/Oem/Public/LicenseService.Uninstall
Request header:
X-Auth-Token:TOKEN
Request body:
Response:
"Oem": {
       "Public": {
"error": {
               "MessageArgs": [],
Response code: 200
Data type
code
String
message
String
Extended information of the message.
@odata.type
String
MessageId
String
Message ID.
Message
String
Details of the message.
MessageArgs
Array
Message arguments.
MessageSeverity
String
Severity level. Supported options:
·     OK.
·     Warning.
·     Critical.
Resolution
String
Change history
Version
Change description
HDM2-2.04
HDM2-1.53
Use Postman to obtain information about Redfish root service resources
1.     Use Postman to create a new request by clicking + in the address bar, and then select GET.
2.     Enter the URL to access the Redfish service.
3.     Select Basic Auth from the Authentication tab.
4.     Enter an HDM username and password.
5.     Click Send.
Appendix
The client can add query parameters during GET operations to quickly obtain target resource information from the server. The supported parameters are shown in Table 4. Unimplemented parameters return status code 501.
Table 4 Parameter list
Parameter
Example
$skip
Integer. Indicates the number of members in the resource collection to skip before obtaining the first resource.
http://resourcecollection?$skip=5
$top
Integer. Indicates the number of members to include in the response, with a minimum of 1. The default is to return all members in the resource collection.
http://resourcecollection?$top=30
$expand
Expands the hyperlinked resources in the current response based on the expand value.
http://resource?$expand=*($levels=1)
$select
List of fields to obtain.
https://resource?$select=Id
Perform filtering and pagination ($skip, $top)
This command is suitable for obtaining collection resources with multiple members. When the GET operation returns too many members, you can use Redfish's filtering and pagination features for convenient searching.
Request
Operation type: GET
URL: https://device_ip/redfish/v1/Managers/1/LogServices/?$skip=skip_num&$top=top_num
or
URL: https://device_ip/redfish/v1/Managers/1/LogServices/?$top=top_num&$skip=skip_num
or
or
Expand hyperlinks ($expand)
This command is suitable for viewing resources containing hyperlinks. When the GET operation returns information with specific hyperlinked resources, you can expand these links, including the linked resource information in the current request. The $expand parameter reduces the number of requests when the resource link is unknown. The special hyperlinks that can be expanded must meet the following conditions:
·     An attribute value is a JSON object containing only one property named @odata_id with a valid hyperlink as its value.
·     An attribute value is a collection of JSON objects, each containing only one property named @odata_id with a valid hyperlink as its value.
This command currently supports expanding only one level of hyperlinks, and does not expand the next level of links within the expanded information. Additionally, the $expand parameter can be used in combination with the $skip and $top parameters from the previous section.
Request
For example: GET
URL: https://device_ip/redfish/v1/Chassis?$expand=*($levels=levels_num)
or
URL: https://device_ip/redfish/v1/Chassis/?$top=top_num&$skip=skip_num&$expand=*($levels=levels_num)
Obtain the list of fields ($select)
This command is suitable for viewing operations and filtering information as needed.
Request
Operation type: GET
The following URL only returns the Id attribute of all obtained information:
https://IP/redfish/v1/Chassis/1/PCIeDevices/2?$select=Id
The following URL only returns the Chassis attribute in the Links field of all obtained information:
https://IP/redfish/v1/Chassis/1/PCIeDevices/2?$select=Links/Chassis
