1 Linux系统
1.1 安装驱动
(1)使用管理员用户登录到系统下,将驱动run包上传到系统下
(2)执行以下命令安装依赖包:
redhat和centos系统:
yum install -y rpm-build gcc-c++ cmake automake elfutils-libelf-devel libdrm libdrm-devel pciutils
yum install -y kernel-devel-`uname -r`
ubuntu系统:
apt install -y gcc g++ cmake automake libelf-dev libdrm-amdgpu1 libtinfo5 pciutils libdrm-dev
apt install mlocate mlocate
apt install -y linux-headers-`uname -r`
(3)上传驱动文件到系统(rock-xxxx.run),并附权
chmod +x rock-xxxx.run
(4)执行以下命令安装驱动,并直接进行vbios更新
./rock-xxxx.run -u 0 -r 0
(5)完成后reboot重启生效,使用命令lsmod |grep -i hydcu,能查询到驱动加载信息,即安装成功
1.2 安装DTK
(1)安装DTK依赖
ubuntu系统:
sudo apt-get update
sudo apt-get install -y cmake
sudo apt-get install -y gcc
sudo apt-get install -y autoconf
sudo apt-get install -y linux-kernel-headers
sudo apt-get install -y kernel-package
sudo apt-get install -y automake
sudo apt-get install -y make gcc g++ cmake git wget gfortran elfutils libdrm-dev
sudo apt-get install -y kmod libtinfo5 sqlite3 libsqlite3-dev libelf-dev
sudo apt-get install -y libnuma-dev libgl1-mesa-dev rpm rsync mesa-common-dev apt-utils
sudo apt-get install -y cmake libpci-dev pciutils libpciaccess-dev libbabeltrace-dev pkg-config
sudo apt-get install -y libfile-which-perl libfile-basedir-perl libfile-copy-recursive-perl libfile-listing-perl
sudo apt-get install -y python3 python3-pip python3-dev python3-wheel
sudo apt-get install -y gettext gettext-base libprotobuf-dev tcl
(2)将DTK-24.04.3-xxx_64.tar.gz上传到系统下,并解压
tar -xvf DTK-24.04.3-xxx_64.tar.gz -C /opt
(3)执行以下命令创建软连接:
ln -s /opt/dtk-24.04.3 /opt/dtk
(4)执行以下命令设置 DTK 环境变量:
echo "source /opt/dtk/env.sh" >> ~/.bashrc
(5)完成后reboot重启生效,验证 DCU 环境,执行hy-smi或rocm-smi回显如下GPU信息,即表示安装成功
(6)将hyflash工具拉入系统,执行./hyflash --version 或 ./hyflash --version |grep 'VBios Version'查看固件版本
