H3C US500_S_A-CMW710-R6378
Release time:2026-04-01
HomeSupportSMBAolynk SwitchWeb Managed SwitchUS500 S ASoftware DownloadUS500 S A
H3C US500_S_A-CMW710-R6378 Release Notes
H3C_彩色.emf
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version US500_S_A-CMW710-R6378. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Version information
Version number
H3C Comware Software, Version 7.1.070, Release 6378
Note: You can see the version number with the command display version in any view. Please see Note①.
Version history
IMPORTANT
IMPORTANT:
The software feature changes listed in the version history table for each version are not complete. To obtain complete information about all software feature changes in each version, see the Software Feature Changes document for this release notes.
Table 1 Version history
Version number
Last version
Branch version
Release Date
Release type
Remarks
First release
B70D038SP
2025-09-04
Release version
First release
Hardware and software compatibility matrix
CAUTION
CAUTION:
To avoid an upgrade failure, use Table 2 to verify the hardware and software compatibility before performing an upgrade.
Table 2 Hardware and software compatibility matrix
Item
Specifications
Product family
US500_S_A Series
Hardware platform
US500-8G24F4XF-S
Memory
512M
Flash
256M
Boot ROM version
Version 163 or higher (Note: Use the display version command in any view to view the version information. Please see Note②)
Software images and their MD5 checksums
US500_S_A-CMW710-R6378.ipe(See the MD5 file)
Remarks
N/A
Display the system software and Boot ROM versions of US500_S_A:
<H3C>dis version
H3C Comware Software, Version 7.1.070, Release 6378    ---------   注①
Copyright (c) 2004-2025 New H3C Technologies Co., Ltd. All rights reserved.
H3C US500-8G24F4XF-S uptime is 0 weeks, 0 days, 0 hours, 1 minute
Last reboot reason : Cold reboot
Boot image: flash:/us500sa-cmw710-boot-r6378.bin
Boot image version: 7.1.070, Release 6378
  Compiled Aug 20 2025 16:00:00
System image: flash:/us500sa-cmw710-system-r6378.bin
System image version: 7.1.070, Release 6378
Slot 1:
Uptime is 0 weeks,0 days,0 hours,1 minute
US500-8G24F4XF-S with 1 Processor
BOARD TYPE:         US500-8G24F4XF-S
DRAM:               512M bytes
FLASH:              256M bytes
PCB 1 Version:      VER.A
Bootrom Version:    163                         ------  注②
CPLD 1 Version:     001
Release Version:    H3C US500-8G24F4XF-S-6378
Patch Version  :    None
Reboot Cause  :     ColdReboot
[SubSlot 0] 16SFP+8COMBO+4SFP Plus
Upgrade restrictions and guidelines
Before performing a software upgrade, it is important to refer to the Software Feature Changes document for any feature changes in the new version. Also check the most recent version of the related documents (see "Related documentation") available on the H3C website for more information about feature configuration and commands.
Hardware feature updates
First release.
Software feature and command updates
None.
MIB updates
Table 3 MIB updates
Item
MIB file
Module
New
First release
First release
First release
Modified
First release
First release
First release
Operation changes
Operation changes in R6378
First release.
Restrictions and cautions
When you use this version of software, make sure you fully understand the restrictions and cautions described in this section.
Restrictions
Release 6378 must use BootROM 163 or a later version.
If data packets are assigned to queue 7 and the scheduling algorithm is SP, all packets sent from the CPU are affected.
Configure static NAT with caution. After you configure static NAT, the device generates a NAT session if a packet matches a NAT rule and forwards the packet in software. The rate of sending packets to the CPU during software forwarding depends on the CPU usage (the maximum rate is 300 pps). The session traffic might be lost during software forwarding.
To avoid false alarms, make sure the statistics collection and comparison interval for CRC error packets configured in the ifmonitor crc-error command is greater than 15 seconds.
Cautions
None.
Open problems and workarounds
None.
List of resolved problems
Resolved problems in R6378
First release.
Troubleshooting resources
To obtain troubleshooting resources for the product:
1.       Access Technical Documents at http://www.h3c.com/en/Technical_Documents.
2.       Select the device category and model.
3.       Select the Maintain or Maintenance menu.
·         H3C US500 Switch Series Installation Guide
·         H3C US500 Switch Series Hardware Information and Specifications
·         H3C US500 Switch Series Configuration Guides-R63xx
·         H3C US500 Switch Series Command References-R63xx
·         H3C Campus Fixed-Port Switches Web-Based Configuration Guide
Technical support
To obtain technical assistance, contact H3C by using one of the following methods:
·         Email:
h3cts@h3c.com (countries and regions except Hong Kong, China)
service_hk@h3c.com (Hong Kong, China)
·         Technical support hotline number. To obtain your local technical support hotline number, go to the H3C Service Hotlines website: https://www.h3c.com/en/Support/Online_Help/Service_Hotlines/
To access documentation, go to the H3C website at http://www.h3c.com/en/.
Appendix A Feature list
Hardware features
Please refer to H3C US500 Switch Series Installation Guide.
Software features
Table 4 Software features of the US500_S_A series
Feature
US500_S_A series switch
IRF
·        Ring topology
·        Daisy chain topology
·        LACP MAD
·        ARP MAD
Link aggregation
·        Aggregation of 1-GE ports
·        Aggregation of 10-GE ports
·        Static link aggregation
·        Dynamic link aggregation
·        Inter-device aggregation
·        A maximum of 1 aggregation groups on a device
·        A maximum of 124 inter-device aggregation groups
·        A maximum of 8 ports for each aggregation group
Flow control
·        IEEE 802.3x flow control
Jumbo Frame
·        Supports maximum frame size of 10000
MAC address table
·        16K MAC addresses
·        1K static MAC addresses
·        Blackhole MAC addresses
·        MAC address learning limit on a port
VLAN
·        Port-based VLANs (4094 VLANs)
·        QinQ
·        VLAN mapping
ARP
·        1K entries
·        512 static entries
·        Gratuitous ARP
·        ARP black hole
·        ARP detection (based on DHCP snooping entries/802.1X security entries/static IP-to-MAC bindings)
·        ARP source suppression
ND
·        240 entries
·        128  static entries
VLAN virtual interface
·        32
DHCP
·        DHCP client
·        DHCP snooping
·        DHCP relay
·        DHCP server
·        DHCPv6 Server
·        DHCPv6 relay
·        DHCPv6 snooping
UDP Helper
·        UDP Helper
DNS
·        Static DNS
·        Dynamic DNS
·        IPv4 and IPv6 DNS
unicast route
·        IPv4 and IPv6 static routes
·        RIP/RIPng
·        OSPF/OSPFv3
·        Routing policies
·        Policy-based routing
·        IPv6 policy-based routing
Multicast
·        IGMP snooping
·        PIM Snooping
·        MLD snooping
·        IPv4 and IPv6 multicast VLAN
·        IPv6 PIM Snooping
Broadcast/multicast/unicast storm control
·        Storm control based on port rate percentage
·        PPS-based storm control
·        Bps-based storm control
MSTP
·        STP/RSTP/MSTP protocol
·        STP Root Guard
·        BPDU Guard
·        128 PVST instances
RRPP
·        RRPP
QoS/ACL
·        Remarking of 802.1p and DSCP priorities
·        Packet filtering at L2 (Layer 2) through L4 (Layer 4)
·        Eight output queues for each port
·        SP/WRR/SP+WRR queue scheduling algorithms
·        Port-based rate limiting
·        Flow-based redirection
·        Time range
Mirroring
·        Stream mirroring
·        Port mirroring
Security
·        Hierarchical management and password protection of users
·        AAA authentication
·        RADIUS authentication
·        HWTACACS
·        LDAP
·        SSH 2.0
·        Port isolation
·        802.1X
·        Portal
·        Port security
·        MAC-address-based authentication
·        IP Source Guard
·        HTTPS
·        PKI
·        IPsec
·        EAD
·        Public key management
802.1X
·        Up to 2K users
·        Port-based and MAC address-based authentication
·        Trunk port authentication
·        Dynamic 802.1X-based QoS/ACL/VLAN assignment
Loading and upgrading
·        Loading and upgrading through XModem protocol
·        Loading and upgrading through FTP
·        Loading and upgrading through the trivial file transfer protocol (TFTP)
Management
·        Configuration at the command line interface
·        Remote configuration through Telnet
·        Configuration through Console port
·        Simple network management protocol (SNMP)
·        Remote Monitoring(RMON)
·        IMC NMS
·        System log
·        Hierarchical alarms
·        NTP
·        Power supply alarm function
·        Fan and temperature alarms
Maintenance
·        Debugging information output
·        Ping and Tracert
·        Remote maintenance through Telnet
·        NQA
·        802.1ag
·        802.3ah
·        DLDP
·        Virtual Cable Test
Appendix B Upgrading software
This chapter describes types of software used on the switch and how to upgrade software while the switch is operating normally or when the switch cannot correctly start up.
System software file types
Software required for starting up the switch includes:
·         Boot ROM image—A .bin file that comprises a basic section and an extended section. The basic section is the minimum code that bootstraps the system. The extended section enables hardware initialization and provides system management menus. You can use these menus to load software and the startup configuration file or manage files when the switch cannot correctly start up.
·         Software images—Includes boot images and system images.
¡  Boot image—A .bin file that contains the operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
¡  System image—A .bin file that contains the minimum modules required for device operation and some basic features, including device management, interface management, configuration management, and routing management.
The software images that have been loaded are called “current software images.” The software images specified to load at next startup are called “startup software images.”
These images might be released separately or as a whole in one .ipe package file. If an .ipe file is used, the system automatically decompresses the file, loads the .bin boot and system images in the file and sets them as startup software images. Typically, the Boot ROM and software images for this switch series are released in an .ipe file named main.ipe.
Boot ROM images are not released along with the boot images and system images. To get a version of Boot ROM image, contact the H3C technical support.
System startup process
Upon power-on, the Boot ROM image runs to initialize hardware and then the software images run to start up the entire system, as shown in Figure 1.
Figure 1 System startup process
Upgrade methods
You can upgrade system software by using one of the following methods:
Upgrading method
Software types
Remarks
Upgrading from the CLI
·        Boot ROM image
·        Software images
·        You must reboot the switch to complete the upgrade.
·        This method can interrupt ongoing network services.
Upgrading from the Boot menu
·        Boot ROM image
·        Software images
Use this method when the switch cannot correctly start up.
CAUTION CAUTION:
Upgrading an IRF fabric from the CLI instead of the Boot menu.
The Boot menu method increases the service downtime, because it requires that you upgrade the member switches one by one.
The output in this document is for illustration only and might vary with software releases. This document uses boot.bin and system.bin to represent boot and system image names. The actual software image name format is chassis-model_Comware-version_image-type_release, for example, US500_S_A-CMW710-BOOT-xxxx.bin and US500_S_A-CMW710-SYSM-xxxx.bin.
Preparing for the upgrade
Verifying device status
1.       Verify that the system state, redundancy state, and state of each slot are stable.
<Sysname> display system stable state
System state     : Stable
Redundancy state : No redundance
  Slot    CPU    Role       State
  1       0      Active     Stable
2.       If the device is unstable, use the following commands to troubleshoot the issue:
¡  Use the display device command to verify that the device is operating correctly.
¡  Use the display ha service-group command to verify that bulk backup has been finished for all modules.
¡  Use the display system internal process state command in probe view to verify that services are running correctly.
3.       If a slot persists in unstable state or there are other unrecoverable issues, contact the technical support.
Setting up the upgrade environment
Before you upgrade system software, complete the following tasks:
·         Set up the upgrade environment as shown in Figure 2.
·         Configure routes to make sure that the router and the file server can reach each other.
·         Run a TFTP or FTP server on the file server.
·         Log in to the CLI of the router through the console port.
·         Copy the upgrade file to the file server and correctly set the working directory on the TFTP or FTP server.
·         Make sure that the upgrade has minimal impact on the network services. During the upgrade, the router cannot provide any services.
Figure 2 Setting up the upgrade environment
Before you upgrade software, complete the following tasks:
1.       Log in to the switch through Telnet or the console port. (Details not shown.)
2.       Verify the switch has sufficient storage space for the upgrade images.
IMPORTANT
IMPORTANT:
The switch must have free storage space that is at least two times the size of the upgrade image file.
<Sysname> dir
Directory of flash:
     0 -rw-      220684 Jan 01 2013 00:17:13   defaultfile.zip
     1 drw-           - Jan 01 2013 00:17:27   diagfile
     2 drw-           - Jan 01 2013 00:17:28   license
     3 drw-           - Jan 01 2013 00:17:27   logfile
     4 drw-           - Jan 01 2013 00:17:41   pki
     5 -rw-     6161408 Jan 01 2013 00:17:27   boot.bin
     6 -rw-    50729984 Jan 01 2013 00:17:27   system.bin
     7 drw-           - Jan 01 2013 00:17:27   seclog
     8 drw-           - Jan 01 2013 00:17:49   versionInfo
251904 KB total (192736 KB free)
3.       Compare the free flash space of the switch with the size of the software file to load. If the space is sufficient, start the upgrade process. If not, go to the next step.
4.       Delete unused files in the flash memory to free space:
CAUTION
CAUTION:
·     To avoid data loss, do not delete the current configuration file. For information about the current configuration file, use the display startup command.
·     The delete /unreserved file-url command deletes a file permanently and the action cannot be undone.
·     The delete file-url command moves a file to the recycle bin and the file still occupies storage space. To free the storage space, first execute the undelete command to restore the file, and then execute the delete /unreserved file-url command.
# Delete unused files from the flash memory of the switch.
<Sysname> delete /unreserved flash:/backup.bin
The file cannot be restored. Delete flash:/backup.bin?[Y/N]:y
Deleting the file permanently will take a long time. Please wait...
Deleting file flash:/backup.bin...Done.
Downloading software images to the switch
Before you start upgrading software images packages, make sure you have downloaded the upgrading software files to the root directory in flash memory. This section describes downloading an .ipe software file as an example.
The following are ways to download, upload, or copy files to the switch:
·         FTP download from a server
·         FTP upload from a client
·         TFTP download from a server
If FTP or TFTP is used, the switch and the PC working as the FTP/TFTP server or FTP client can reach each other.
Prepare the FTP server or TFTP server program yourself for the PC. The switch series does not come with these software programs.
You can use the switch as an FTP client to download files from an FTP server.
To download a file from an FTP server, for example, the server at 10.10.110.1:
1.       Run an FTP server program on the server, configure an FTP username and password, specify the working directory and copy the file, for example, newest.ipe, to the directory.
2.       Execute the ftp command in user view on the switch to access the FTP server.
<Sysname> ftp 10.10.110.1
Press CTRL+C to abort
Connected to 10.10.110.1(10.10.110.1).
220 FTP service ready.
User (10.10.110.1:(none)):username
331 Password required for username.
Password:
230 User logged in.
3.       Enable the binary transfer mode.
ftp> binary
  200 Type is Image (Binary)
4.       Execute the get command in FTP client view to download the file from the FTP server.
ftp> get newest.ipe
  227 Entering Passive Mode (10,10,110,1,17,97).
  125 BINARY mode data connection already open, transfer starting for /newest.ipe
  226 Transfer complete.
  32133120 bytes received in 35 seconds (896. 0 kbyte/s)
ftp> bye
221 Server closing.
You can use the switch as an FTP server and upload files from a client to the switch.
To FTP upload a file from a client:
On the switch:
1.       Enable FTP server.
[Sysname] ftp server enable
2.       Configure a local FTP user account:
# Create the user account.
[Sysname] local-user abc
# Set its password and specify the FTP service.
[Sysname-luser-manage-abc] password simple pwd
[Sysname-luser-manage-abc] service-type ftp
# Assign the network-admin user role to the user account for uploading file to the working directory of the server.
[Sysname-luser-manage-abc] authorization-attribute user-role network-admin
[Sysname-luser-manage-abc] quit
[Sysname] quit
On the PC:
3.       Log in to the switch (the FTP server) in FTP mode.
c:\> ftp 1.1.1.1
Connected to 1.1.1.1.
User(1.1.1.1:(none)):abc
331 Password required for abc.
Password:
230 User logged in.
4.       Enable the binary file transfer mode.
ftp> binary
200 TYPE is now 8-bit binary.
5.       Upload the file (for example, newest.ipe) to the root directory of the flash memory on the switch.
ftp> put newest.ipe
200 PORT command successful
150 Connecting to port 10002
226 File successfully transferred
ftp: 32133120 bytes sent in 64.58 secs (497.60 Kbytes/sec).
To download a file from a TFTP server, for example, the server at 10.10.110.1:
1.       Run a TFTP server program on the server, specify the working directory, and copy the file, for example, newest.ipe, to the directory.
2.       On the switch, execute the tftp command in user view to download the file to the root directory of the flash memory on the switch.
<Sysname> tftp 10.10.110.1 get newest.ipe
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 30.6M    0 30.6M    0     0   143k      0 --:--:--  0:03:38 --:--:--  142k
Upgrading the software images
To upgrade the software images:
1.       Specify the upgrade image file (newest.ipe in this example) used at the next startup for the switch, and assign the M attribute to the boot and system images in the file.
<Sysname> boot-loader file flash:/newest.ipe slot 1 main
Verifying the file flash:/newest.ipe on slot 1......Done.
Images in IPE:
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:y
Add images to slot 1.
Decompressing file boot.bin to flash:/boot.bin....................Done.
Decompressing file system.bin to flash:/system.bin................Done.
Verifying the file flash:/boot.bin on slot 1...Done.
Verifying the file flash:/system.bin on slot 1............Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
2.       Save the current configuration in any view to prevent data loss.
<Sysname> save
Validating file. Please wait.................
3.       Reboot the switch to complete the upgrade.
<Sysname> reboot
Start to check configuration with next startup configuration file, please wait.
........DONE!
 Now rebooting, please wait...
The system automatically loads the boot.bin and system.bin images in the newest.ipe file and sets them as the startup software images.
4.       Execute the display version command in any view to verify that the current main software images have been updated (details not shown).
The system automatically checks the compatibility of the Boot ROM image and the boot and system images during the reboot. If you are prompted that the Boot ROM image in the upgrade image file is different than the current Boot ROM image, upgrade both the basic and extended sections of the Boot ROM image for compatibility. If you choose to not upgrade the Boot ROM image, the system will ask for an upgrade at the next reboot performed by powering on the switch or rebooting from the CLI (promptly or as scheduled). If you fail to make any choice in the required time, the system upgrades the entire Boot ROM image.
TIP
TIP:
Upgrading through the Ethernet port is faster than through the console port.
Make sure the prerequisites are met before you start upgrading software from the Boot menu.
1.       Use a console cable to connect the console terminal (for example, a PC) to the console port on the switch.
2.       Connect the Ethernet port on the switch to the file server.
The file server and the configuration terminal can be co-located.
3.       Run a terminal emulator program on the console terminal and set the following terminal settings:
¡  Bits per second—9,600
¡  Data bits—8
¡  Parity—None
¡  Stop bits—1
¡  Flow control—None
¡  Emulation—VT100
Preparing for the TFTP or FTP transfer
To use TFTP or FTP:
·         Run a TFTP or FTP server program on the file server or the console terminal.
·         Copy the upgrade file to the file server.
·         Correctly set the working directory on the TFTP or FTP server.
·         Make sure the file server and the switch can reach each other.
Verifying that sufficient storage space is available
IMPORTANT
IMPORTANT:
For the switch to start up correctly, do not delete the main startup software images when you free storage space before upgrading Boot ROM. On the Boot menu, the main startup software images are marked with an asterisk (*).
When you upgrade software, make sure each member switch has sufficient free storage space for the upgrade file, as shown in Table 5.
Table 5 Minimum free storage space requirements
Upgraded images
Comware images
Two times the size of the Comware upgrade package file.
Boot ROM
Same size as the Boot ROM upgrade image file.
If no sufficient space is available, delete unused files as described in “Managing files from the Boot menu.”
Scheduling the upgrade time
During the upgrade, the switch cannot provide any services. You must make sure the upgrade has a minimal impact on the network services.
Accessing the Boot menu
Starting......
Press Ctrl+D to access BASIC BOOT MENU
Booting Normal Extend BootWare....
*             H3C US500-8G24F4XF-S Switch BOOTROM, Version 163                 *
Copyright (c) 2004-2023 New H3C Technologies Co., Ltd.
Creation Date       : Jul 11 2023, 14:07:52
CPU Clock Speed     : 800MHz
Memory Size         : 512MB
Flash Size          : 256MB
CPLD Version        : 001
PCB Version         : Ver.A
Mac Address         : aa1122334455
Press Ctrl+B to access EXTENDED BOOT MENU...1
Press one of the shortcut key combinations at prompt.
Table 6 Shortcut keys
Shortcut keys
Prompt message
Function
Remarks
Ctrl+B
Press Ctrl+B to enter Extended Boot menu...
Accesses the extended Boot menu.
Press the keys within 1 second (in fast startup mode) or 5 seconds (in full startup mode) after the message appears.
You can upgrade and manage system software and Boot ROM from this menu.
Accessing the extended Boot menu
Press Ctrl+B within 1 second (in fast startup mode) or 5 seconds (in full startup mode) after the " Press Ctrl+B to access EXTENDED BOOT MENU..." prompt message appears. If you fail to do this, the system starts decompressing the system software.
Alternatively, you can enter 4 in the basic Boot menu to access the extended Boot menu.
The "Password recovery capability is enabled." or "Password recovery capability is disabled." message appears, followed by the extended Boot menu. Availability of some menu options depends on the state of password recovery capability (see Table 7).
   EXTENDED BOOT MENU
1. Download image to flash
2. Select image to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set switch startup mode
0. Reboot
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format file system
Ctrl+P: Change authentication for console login
Ctrl+R: Download image to SDRAM and run
Ctrl+Y: Change Work Mode
Ctrl+C: Display Copyright
Enter your choice(0-8):
Table 7 Extended Boot ROM menu options
Option
Tasks
Download a software image file to the flash.
·        Specify the main and backup software image file for the next startup.
·        Specify the main and backup configuration files for the next startup. This task can be performed only if password recovery capability is enabled.
Display files on the flash.
Delete files to free storage space.
Delete the current next-startup configuration files and restore the factory-default configuration.
This option is available only if password recovery capability is disabled.
Access the Boot ROM upgrade menu.
Start the switch without loading any configuration file.
This is a one-time operation and takes effect only for the first system boot or reboot after you choose this option.
This option is available only if password recovery capability is enabled.
Set the startup mode to fast startup mode or full startup mode.
0. Reboot
Reboot the switch.
Format the current storage medium.
Skip the authentication for console login.
Download a system software image and start the switch with the image.
Access the EXTENDED ASSISTANT MENU.
For options in the menu, see Table 8.
Change Work Mode.
Display the copyright statement.
Table 8 EXTENDED ASSISTANT menu options
Option
1. Display Memory
Display data in the memory.
2. Search Memory
Search the memory for a specific data segment.
0. Return to boot menu
Return to the extended Boot ROM menu.
Upgrading Comware images from the Boot menu
You can use the following methods to upgrade Comware images:
·         Using TFTP to upgrade software images through the Ethernet port
·         Using FTP to upgrade software images through the Ethernet port
·         Using XMODEM to upgrade software through the console port
1.       Enter 1 in the Boot menu to access the file transfer protocol submenu.
1. Set TFTP protocol parameters
2. Set FTP protocol parameters
3. Set XMODEM protocol parameters
Enter your choice(0-3):
2.       Enter 1 to set the TFTP parameters.
Load File Name      :update.ipe
Server IP Address   :192.168.0.3
Local IP Address    :192.168.0.2
Subnet Mask         :255.255.255.0
Gateway IP Address  :0.0.0.0
Table 9 TFTP parameter description
Item
Load File Name
Name of the file to download (for example, update.ipe).
Server IP Address
IP address of the TFTP server (for example, 192.168.0.3).
Local IP Address
IP address of the switch (for example, 192.168.0.2).
Subnet Mask
Subnet mask of the switch (for example, 255.255.255.0).
Gateway IP Address
IP address of the gateway (in this example, no gateway is required because the server and the switch are on the same subnet).
·     To use the default setting for a field, press Enter without entering any value.
·     If the switch and the server are on different subnets, you must specify a gateway address for the switch.
3.       Enter all required parameters, and enter Y to confirm the settings. The following prompt appears:
Are you sure to download file to flash? Yes or No (Y/N):Y
4.       Enter Y to start downloading the image file. To return to the Boot menu without downloading the upgrade file, enter N.
Loading.........................................................................
................................................................Done!
5.       Enter the M (main), B (backup), or N (none) attribute for the images. In this example, assign the main attribute to the images.
Please input the file attribute (Main/Backup/None) M
Image file boot.bin is self-decompressing...
Free space: 534980608 bytes
Writing flash...................................................................
...................................................................Done!
Image file system.bin is self-decompressing...
Free space: 525981696 bytes
.......................................................................Done!
·     The switch always attempts to boot with the main images first. If the attempt fails, for example, because the main images are not available, the switch tries to boot with the backup images. An image with the none attribute is only stored in flash memory for backup. To use it at reboot, you must change its attribute to main or backup.
·     If an image with the same attribute as the image you are loading is already in the flash memory, the attribute of the old image changes to none after the new image becomes valid.
6.       Enter 0 in the Boot menu to reboot the switch with the new software images.
   EXTENDED BOOT MENU
0. Reboot
Enter your choice(0-8): 0
2.       Enter 2 to set the FTP parameters.
FTP User Name       :switch
FTP User Password   :***
Table 10 FTP parameter description
Item
Load File Name
Server IP Address
IP address of the FTP server (for example, 192.168.0.3).
Local IP Address
Subnet Mask
Gateway IP Address
FTP User Name
Username for accessing the FTP server, which must be the same as configured on the FTP server.
FTP User Password
Password for accessing the FTP server, which must be the same as configured on the FTP server.
   EXTENDED BOOT MENU
0. Reboot
Enter your choice(0-8):0
·     The switch always attempts to boot with the main images first. If the attempt fails, for example, because the main images not available, the switch tries to boot with the backup images. An image with the none attribute is only stored in flash memory for backup. To use it at reboot, you must change its attribute to main or backup.
XMODEM download through the console port is slower than TFTP or FTP download through the Ethernet port. To save time, use the Ethernet port as long as possible.
2.       Enter 3 to set the XMODEM download baud rate.
Please select your download baudrate:
1.* 9600
2.  19200
3.  38400
4.  57600
5.  115200
Enter your choice(0-5):5
3.       Select an appropriate download rate, for example, enter 5 to select 115200 bps.
Download baudrate is 115200 bps
Please change the terminal's baudrate to 115200 bps and select XMODEM protocol
Press enter key when ready
4.       Set the serial port on the terminal to use the same baud rate and protocol as the console port. If you select 9600 bps as the download rate for the console port, skip this task.
a.    Select Call > Disconnect in the HyperTerminal window to disconnect the terminal from the switch.
Figure 3 Disconnecting the terminal from the switch
b.    Select File > Properties, and in the Properties dialog box, click Configure.
Figure 4 Properties dialog box
c.    Select 115200 from the Bits per second list and click OK.
Figure 5 Modifying the baud rate
d.    Select Call > Call to reestablish the connection.
Figure 6 Reestablishing the connection
5.       Press Enter. The following prompt appears:
6.       Enter Y to start downloading the file. (To return to the Boot menu, enter N.)
Now please start transfer file with XMODEM protocol
If you want to exit, Press <Ctrl+X>
Loading ...CCCCCCCCCCCCCCCCCCCCCCCCC
7.       Select Transfer > Send File in the HyperTerminal window.
Figure 7 Transfer menu
8.       In the dialog box that appears, click Browse to select the source file, and select Xmodem from the Protocol list.
Figure 8 File transmission dialog box
9.       Click Send. The following dialog box appears:
Figure 9 File transfer progress
10.     Enter the M (main), B (backup), or N (none) attribute for the images. In this example, assign the main attribute to the images.
Please input the file attribute (Main/Backup/None) m
The boot.bin image is self-decompressing...
# At the Load File name prompt, enter a name for the boot image to be saved to flash memory.
Load File name  : default_file boot-update.bin       (At the prompt,
Free space: 470519808 bytes
.............Done!
The system-update.bin image is self-decompressing...
# At the Load File name prompt, enter a name for the system image to be saved to flash memory.
Load File name  : default_file system-update.bin
Free space: 461522944 bytes
.............Done!
Your baudrate should be set to 9600 bps again!
·     The switch always attempts to boot with the main images first. If the attempt fails, for example, because the main images not available, the switch tries to boot with the backup images. An image with the none attribute is only stored in the flash memory for backup. To use it at reboot, you must change its attribute to main or backup.
·     If an image with the same attribute as the image you are loading is already in flash memory, the attribute of the old image changes to none after the new image becomes valid.
11.     If the baud rate of the HyperTerminal is not 9600 bps, restore it to 9600 bps as described in step 5.a. If the baud rate is 9600 bps, skip this step.
The console port rate reverts to 9600 bps at a reboot. If you have changed the baud rate, you must perform this step so you can access the switch through the console port after a reboot.
   EXTENDED BOOT MENU
0. Reboot
12.     Enter 0 in the Boot menu to reboot the system with the new software images.
Upgrading Boot ROM from the Boot menu
You can use the following methods to upgrade the Boot ROM image:
·         Using TFTP to upgrade Boot ROM through the Ethernet port
·         Using FTP to upgrade Boot ROM through the Ethernet port
·         Using XMODEM to upgrade Boot ROM through the console port
1.       Enter 6 in the Boot menu to access the Boot ROM update menu.
1. Update full BootRom
2. Update extended BootRom
3. Update basic BootRom
2.       Enter 1 in the Boot ROM update menu to upgrade the full Boot ROM.
The file transfer protocol submenu appears:
3.       Enter 1 to set the TFTP parameters.
Load File Name      :update.btm
Table 11 TFTP parameter description
Item
Load File Name
Name of the file to download (for example, update.btm).
Server IP Address
Local IP Address
Subnet Mask
Gateway IP Address
4.       Enter all required parameters and press Enter to start downloading the file.
Loading.................................................Done!
5.       Enter Y at the prompt to upgrade the basic Boot ROM section.
Will you Update Basic BootRom? (Y/N):Y
Updating Basic BootRom...........Done.
6.       Enter Y at the prompt to upgrade the extended Boot ROM section.
Updating extended BootRom? (Y/N):Y
Updating extended BootRom.........Done.
7.       Enter 0 in the Boot ROM update menu to return to the Boot menu.
8.       Enter 0 in the Boot menu to reboot the switch with the new Boot ROM image.
3.       Enter 2 to set the FTP parameters.
FTP User Password  :123
Table 12 FTP parameter description
Item
Load File Name
Server IP Address
Local IP Address
Subnet Mask
Gateway IP Address
FTP User Name
FTP User Password
3.       Enter 3 to set the XMODEM download baud rate.
1.* 9600
2.  19200
3.  38400
4.  57600
5.  115200
4.       Select an appropriate download rate, for example, enter 5 to select 115200 bps.
5.       Set the serial port on the terminal to use the same baud rate and protocol as the console port. If you select 9600 bps as the download rate for the console port, skip this task.
Figure 10 Disconnecting the terminal from the switch
Figure 11 Properties dialog box
Figure 12 Modifying the baud rate
Figure 13 Reestablishing the connection
6.       Press Enter to start downloading the file.
Figure 14 Transfer menu
Figure 15 File transmission dialog box
Figure 16 File transfer progress
10.     Enter Y at the prompt to upgrade the basic Boot ROM section.
Loading ...CCCCCCCCCCCCCC  ...Done!
11.     Enter Y at the prompt to upgrade the extended Boot ROM section.
12.     If the baud rate of the HyperTerminal is not 9600 bps, restore it to 9600 bps at the prompt, as described in step 4.a. If the baud rate is 9600 bps, skip this step.
Please change the terminal's baudrate to 9600 bps, press ENTER when ready.
13.     Press Enter to access the Boot ROM update menu.
14.     Enter 0 in the Boot ROM update menu to return to the Boot menu.
15.     Enter 0 in the Boot menu to reboot the switch with the new Boot ROM image.
From the Boot menu, you can display files in flash memory to check for obsolete files, incorrect files, or space insufficiency, delete files to release storage space, or change the attributes of software images.
Displaying all files
Enter 3 in the Boot menu to display all files in flash memory and identify the free space size.
   EXTENDED BOOT MENU
0. Reboot
Enter your choice(0-8): 3
The following is a sample output:
Display all file(s) in flash:
File Number    File Size(bytes)     File Name
1              8177                 flash:/testbackup.cfg
2(*)           53555200             flash:/system.bin
3(*)           9959424              flash:/boot.bin
4              3678                 flash:/startup.cfg_backup
5              30033                flash:/default.mdb
6              42424                flash:/startup.mdb
7              18                   flash:/.pathfile
8              232311               flash:/logfile/logfile.log
9              5981                 flash:/startup.cfg_back
10(*)          6098                 flash:/startup.cfg
11             20                   flash:/.snmpboots
Free space: 464298848 bytes
The current image is boot.bin
(*)-with main attribute
(b)-with backup attribute
(*b)-with both main and backup attribute
Deleting files
If storage space is insufficient, delete obsolete files to free up storage space.
To delete files:
1.       Enter 4 in the Boot menu:
Deleting the file in flash:
2.       Enter the number of the file to delete. For example, enter 1 to select the file testbackup.cfg.
Please input the file number to change: 1
3.       Enter Y at the confirmation prompt.
The file you selected is testbackup.cfg,Delete it? (Y/N):Y
Deleting....................................Done!
Changing the attribute of software images
Software image attributes include main (M), backup (B), and none (N). System software and boot software can each have multiple none-attribute images but only one main image and one backup image on the switch. You can assign both the M and B attributes to one image. If the M or B attribute you are assigning has been assigned to another image, the assignment removes the attribute from that image. If the removed attribute is the sole attribute of the image, its attribute changes to N.
For example, the system image system.bin has the M attribute and the system image system-update.bin has the B attribute. After you assign the M attribute to system-update.bin, the attribute of system-update.bin changes to M+B and the attribute of system.bin changes to N.
To change the attribute of a system or boot image:
1.       Enter 2 in the Boot menu.
   EXTENDED BOOT MENU
0. Reboot
Enter your choice(0-8): 2
2.       1 or 2 at the prompt to set the attribute of a software image. (The following output is based on the option 2. To set the attribute of a configuration file, enter 3.)
1. Set image file
2. Set bin file
3. Set configuration file
Enter your choice(0-3): 2
1(*)              53555200              flash:/system.bin
2(*)              9959424               flash:/boot.bin
3                 13105152              flash:/boot-update.bin
4                 91273216              flash:/system-update.bin
Free space: 417177920 bytes
Note:Select .bin files. One but only one boot image and system image must be included.
3.       Enter the number of the file you are working with. For example, enter 3 to select the boot image boot-update.bin. and enter 4 to select the system image system-update.bin.
Enter file No.(Allows multiple selection):3
Enter another file No.(0-Finish choice):4
4.       Enter 0 to finish the selection.
Enter another file No.(0-Finish choice):0
You have selected:
5.       Enter M or B to change its attribute to main or backup. If you change its attribute to M, the attribute of boot.bin changes to none.
Please input the file attribute (Main/Backup) M
This operation may take several minutes. Please wait....
Next time, boot-update.bin will become default boot file!
Next time, system-update.bin will become default boot file!
Set the file attribute success!
Handling software upgrade failures
If a software upgrade fails, the system runs the old software version.
To handle a software upgrade failure:
1.       Verify that the software release is compatible with the switch model and the correct file is used.
2.       Verify that the software release and the Boot ROM release are compatible. For software and Boot ROM compatibility, see the hardware and software compatibility matrix in the correct release notes.
3.       Check the physical ports for a loose or incorrect connection.
4.       If you are using the console port for file transfer, check the HyperTerminal settings (including the baud rate and data bits) for any wrong setting.
5.       Check the file transfer settings:
¡  If XMODEM is used, you must set the same baud rate for the terminal as for the console port.
¡  If TFTP is used, you must enter the same server IP addresses, file name, and working directory as set on the TFTP server.
¡  If FTP is used, you must enter the same FTP server IP address, source file name, working directory, and FTP username and password as set on the FTP server.
6.       Check the FTP or TFTP server for any incorrect setting.
7.       Check that the storage device has sufficient space for the upgrade file.
