H3C NX54-EUV100R005 Release Notes
Release time:2025-07-12
HomeSupportIntelligent TerminalCatalogH3C Magic NX54 Wireless RouterSoftware DownloadH3C Magic NX54 Wireless Router
Download
Title Size Downloads
H3C NX54-EUV100R005.zip 30.98 MB
H3C BX54-EUV100R005 Release Notes.pdf 713.53 KB
Introduction
Version information
Version number
Version history
Hardware and software compatibility matrix
Upgrade restrictions and guidelines
Hardware feature updates
Software feature and command updates
MIB updates
Operation changes
Restrictions and cautions
Open problems and workarounds
List of resolved problems
V100R005
V100R004
V100R003
V100R002
V100R001
Related documentation
Documentation set
Obtaining documentation
Technical support
Appendix A Feature list
Hardware features
Software features
Appendix B Upgrading software
Upgrade methods
Online upgrade
Local upgrade
List of tables
Table 1 Version history
Table 2 Hardware and software compatibility matrix
Table 3 Hardware feature updates
Table 4 Software feature updates
Table 5 BX54-EU hardware features
Table 6 BX54-EU software features
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version H3C BX54-EUV100R005. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction the documents listed in "Related documentation."
Version information
Version number
BX54-EUV100R005
You can get the device version number from the System Infor Web page of the device.
Version history
Version number
Last version
Release date
Release type
Remarks
BX54-EUV100R005
BX54-EUV100R004
2025-02-08
Release version
Support Pakistan, Uzbekistan,United Kingdom, Canada, United States.
BX54-EUV100R004
BX54-EUV100R003
2024-07-24
Release version
Support the Philippines, Saudi Arabia, Malaysia, UAE, Chile, Vietnam.
BX54-EUV100R003
BX54-EUV100R002
2023-10-16
Release version
Support Vietnam and Vietnamese language.
BX54-EUV100R002
BX54-EUV100R001
2023-09-08
Release version
Resolving issues related to DDNS and the scheduling function.
BX54-EUV100R001
N/A
2023-02-23
Release version
First release.
CAUTION:
To avoid an upgrade failure, use Table 2 to verify the hardware and software compatibility before performing an upgrade.
Item
Specifications
Product model
H3C BX54-EU
Memory
512MB
Flash
128MB
Boot ROM version
1.00 or later
Software images
NX54-EUV100R005.bin
Remarks
N/A
None.
Version number
NX54-EUV100R005.bin
None
NX54-EUV100R004.bin
None
NX54-EUV100R003.bin
None
NX54-EUV100R002.bin
None
NX54-EUV100R001.bin
First release.
Version number
NX54-EUV100R005.bin
None
NX54-EUV100R004.bin
None
NX54-EUV100R003.bin
None
NX54-EUV100R002.bin
None
NX54-EUV100R001.bin
First release.
MIB updates
None.
Operation changes
None.
The device webpage layout or format might differ by browser. Some browsers might not support the webpages, for example, you cannot access the device management page from browsers that do not support cookies. If a browser does not support the webpages, use another browser.
If the device uses the wireless repeater Internet access mode, you are not allowed to configure the Internet access mode, parental control, IP flow restriction, and some of the configured features will become invalid. To configure those features, you must disable wireless repeater Internet access mode.
The wireless SSID cannot contain semicolons (;). SSIDs that contain semicolons (;) cannot be detected in wireless repeater mode.
In wireless repeater mode, only WAP2 or WAP/WAP2 encrypted wireless signals can be repeated.
Environment detection can only detect 2.4G signals and cannot detect 5G signals.
When a repeater is connected to the device, the wireless sleep feature of the device does not take effect, and the device cannot enter the sleep state.
None.
V100R005
Problem ID- 25654
Conditions for problem occurrenceThe device software needs to support the country of Pakistan.
Symptoms of the problemThe device can be used normally in Pakistan.
Problem ID- 25656
Conditions for problem occurrenceThe device software needs to support the country of Uzbekistan.
Symptoms of the problemThe device can be used normally in Uzbekistan.
V100R004
Problem ID- 27976
Conditions for problem occurrenceThe device software needs to support the country of United States.
Symptoms of the problemThe device can be used normally in United States.
Problem ID- 39492
Conditions for problem occurrenceThe device software needs to support the country of Canada.
Symptoms of the problemThe device can be used normally in Canada.
Problem ID- 39491
Conditions for problem occurrenceThe device software needs to support the country of United Kingdom.
Symptoms of the problemThe device can be used normally in United Kingdom.
Problem ID- 18523
Conditions for problem occurrenceThe device software needs to support the country of Philippines.
Symptoms of the problemThe device can be used normally in Philippines.
Problem ID- 18514
Conditions for problem occurrenceThe device software needs to support the country of Saudi Arabia.
Symptoms of the problemThe device can be used normally in Saudi Arabia.
Problem ID- 25905
Conditions for problem occurrenceThe device software needs to support the country of Malaysia.
Symptoms of the problemThe device can be used normally in Malaysia.
V100R003
Problem ID- 18037
Conditions for problem occurrence:Switching languages on WEB.
Symptoms of the problem:WEB does not support switching Vietnamese languages.
V100R002
Problem ID- 17110
Conditions for problem occurrenceAfter enabling DDNS, modifying the related DDNS configuration.
Symptoms of the problemThe system log will show another entry indicating the enabling of DDNS.
Problem ID- 10044
Conditions for problem occurrenceAfter enabling the repeater mode on the device, configuring the scheduling function.
Symptoms of the problemThe scheduling function does not take effect.
V100R001
First release.
Documentation set
H3C Magic BX54 Wireless Router Installation Quick Start
To obtain the related documents from the H3C website at https://www.h3c.com/en/:
1.Click https://www.h3c.com/en/Support/Resource_Center/Technical_Documents/.
2.Choose the desired product category and model.
Technical support
To obtain support services, contact technical support at Support.Magic@h3c.com
Hardware features
Item
Ports and buttons
1 × reset button
1 × mesh button
4 × 10/100/1000BASE-T ports
Antenna
4 × internal high-gain Franklin antennas
Wireless protocol
802.11ax/ac/n/a
802.11ax/b/g/n
LED
System status LED
Dimensions (H × W × D)
95mm*95mm*226mm
Weight (body)
≤0.62 kg
Operating temperature
0°C to 40°C (32°F to 104°F)
Storage humidity
10% to 90% RH, noncondensing
Power consumption
 24 W
Cooling method
Passive cooling
Certification
CE
CB
Software features
Category
Features
Wireless
2.4 GHz 2×2 MIMO & 5 GHz 2×2 MIMO
MU-MIMO
HT20/HT40/HT80/HT160 mode
Wi-Fi scheduled shutdown
Wi-Fi power adjustment
Wi-Fi dual-radio roaming
Beamforming directional antenna technology
DDNS
VPN
Parental control at multiple time ranges
IP-based traffic control
Unique feature
Packet fast forwarding engine
Configuration management
User management from the Web page
User management from an APP
Local upgrade and online upgrade from the Web page
Fault diagnosis
Internet access diagnosis
Upgrade methods
You can upgrade the device software by online upgrade or local upgrade.
Online upgrade
With online upgrade, you can obtain the software image from the remote server.
To upgrade device software by online upgrade:
1.Navigate to the System Settings page.
2.Click Upgrade in the Online Upgrade row. The system will check whether a new version is available from the remote server.
3.If a new version is available, the system prompts a dialog box for you to choose whether to upgrade the system.
4.Click Upgrade. The system downloads the new version.
5.After the new version is downloaded, the device automatically upgrades the software version and then reboots.
图片 2
Local upgrade
CAUTION:
Do not power off the device or operate the Web interface during the local software upgrade process.
To upgrade software by local upgrade:
1.Save the latest software image to the local host.
2.Connect the local host directly to the router.
3.Click Browser in the Local Upgrade row to select the local software image and then click Upgrade.
4.After the upgrade is complete, the device will reboot automatically.
图片 3
图片 8
