| Title | Size | Downloads |
| NX15-EUV100R007.zip | 14.25 MB | |
| H3C NX15-EUV100R007 Release Notes.pdf | 656.15 KB |
H3C NX15-EUV100R007 Release Notes |
Copyright © 2025 New H3C Intelligence Terminal Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Intelligence Terminal Co., Ltd. The information in this document is subject to change without notice. |
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version H3C NX15-EUV100R007. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction the documents listed in "Related documentation."
Version information
Version number
NX15-EUV100R007
| NOTE: You can get the device version number from the System Infor Web page of the device. |
Version history
Version number | Last version | Release date | Release type | Remarks |
NX15-EUV100R007 | NX15-EUV100R006 | 2025-03-07 | Release version | Supports Pakistan. |
NX15-EUV100R006 | NX15-EUV100R005 | 2024-12-20 | Release version | Supports IGMP Snooping and Fast Leave function. |
NX15-EUV100R005 | NX15-EUV100R004 | 2024-10-20 | Release version | Support configuration of country code. |
NX15-EUV100R004 | NX15-EUV100R003 | 2024-06-28 | Release version | Support countries such as Poland, Malaysia, Laos, Saudi Arabia, and Uzbekistan. Support Polish language. |
NX15-EUV100R003 | NX15-EUV100R002 | 2023-12-14 | Release version | Supports South Korea and Chile. Supports Korean, Arabic, Indonesian, and Vietnamese. |
NX15-EUV100R002 | NX15-EUV100R001 | 2023-09-18 | Release version | Support South Africa, United Arab Emirates and Philippines. |
NX15-EUV100R001 | N/A | 2023-04-27 | Release version | First release. |
Hardware and software compatibility matrix
CAUTION: To avoid an upgrade failure, use Table 2 to verify the hardware and software compatibility before performing an upgrade. |
Table 2 Hardware and software compatibility matrix
Item | Specifications |
Product model | H3C NX15 |
Memory | 128 MB |
Flash | 16 MB |
Boot ROM version | 1.00 or later |
Software images | NX15-EUV100R007.bin |
Remarks | N/A |
Upgrade restrictions and guidelines
None.
Hardware feature updates
Table 3 Hardware feature updates
Version number | Description |
NX15-EUV100R006.bin | None |
NX15-EUV100R005.bin | None |
NX15-EUV100R004.bin | None |
NX15-EUV100R003.bin | None |
NX15-EUV100R002.bin | None |
NX15-EUV100R001.bin | First release. |
Software feature and command updates
Table 4 Software feature updates
MIB updates
None.
Operation changes
Restrictions and cautions
The device webpage layout or format might differ by browser. Some browsers might not support the webpages, for example, you cannot access the device management page from browsers that do not support cookies. If a browser does not support the webpages, use another browser.
If the device uses the wireless repeater Internet access mode, you are not allowed to configure the Internet access mode, parental control, IP flow restriction, and some of the configured features will become invalid. To configure those features, you must disable wireless repeater Internet access mode.
The wireless SSID cannot contain semicolons (;). SSIDs that contain semicolons (;) cannot be detected in wireless repeater mode.
In wireless repeater mode, only WAP2 or WAP/WAP2 encrypted wireless signals can be repeated.
Environment detection can only detect 2.4G signals and cannot detect 5G signals.
When a repeater is connected to the device, the wireless sleep feature of the device does not take effect, and the device cannot enter the sleep state.
Open problems and workarounds
None.
List of resolved problems
V100R007
Problem ID- 23583
Conditions for problem occurrence:The device software needs to support the country of Pakistan.
Symptoms of the problem:The device can be used normally in Pakistan.
V100R006
Problem ID- 36365
Conditions for problem occurrence:The device needs to support IGMP Snooping and Fast Leave functions.
Symptoms of the problem:The device management page supports enabling and disabling IGMP Snooping.
Problem ID- 36458
Conditions for problem occurrence:The device needs to support Russian.
Symptoms of the problem:The device management page can be switched to Russian.
V100R005
Problem ID- 27067
Conditions for problem occurrence:Cascade NX15-EU routers under MSR for MESH networking.
Symptoms of the problem:The Vietnam general agent reported that the NX15-EU cascade under the MSR device is experiencing regular offline/online anomalies with sub-routes.
V100R004
Problem ID- 18511
Conditions for problem occurrence:The device software needs to support the country of Saudi Arabia.
Symptoms of the problem:The device can be used normally in Saudi Arabia.
V100R003
Problem ID- 18627
Conditions for problem occurrence:The device supports Korean, Arabic, Indonesian, and Vietnamese.
Symptoms of the problem:The device management page can be switched to Korean, Arabic, Indonesian, and Vietnamese.
Problem ID- 17302
Conditions for problem occurrence:The device software needs to support the country of South Korea.
Symptoms of the problem:The device can be used normally in South Korea.
Problem ID- 20130
Conditions for problem occurrence:The device software needs to support the country of Chile.
Symptoms of the problem:The device can be used normally in Chile.
V100R002
Problem ID- 16733
Conditions for problem occurrence:The device software needs to support the country of South Africa.
Symptoms of the problem:The device can be used normally in South Africa.
Problem ID- 17300
Conditions for problem occurrence:The device software needs to support the country of United Arab Emirates.
Symptoms of the problem:The device can be used normally in United Arab Emirates.
Problem ID- 17301
Conditions for problem occurrence:The device software needs to support the country of Philippines.
Symptoms of the problem:The device can be used normally in Philippines.
V100R001
Documentation set
H3C Magic NX15 Wireless Router Installation Quick Start
Obtaining documentation
To obtain the related documents from the H3C website at :
2.Choose the desired product category and model.
Technical support
To obtain support services, contact technical support at Support.Magic@h3c.com
Table 5 NX15 hardware features
Item | Description |
Ports and buttons | 1 × button( reset + mesh ) 4 × 10/100/1000BASE-T ports |
Antenna | 4 × external 5dBi antennas |
Operating frequency band | 802.11ax/ac/n/a : 5.150GHz-5.350GHz, 5.47GHz-5.725GHz, 5.725GHz -5.850GHz (vary depending on countries) 802.11b/g/n : 2.4GHz-2.483GHz |
LED | System status LED |
Dimensions (H × W × D) | 180 × 195 × 57.3 mm (7.09 × 7.68 × 2.26 in) |
Weight (body) | ≤ 0.25 kg (0.55 lb) |
Operating temperature | 0°C to 40°C (32°F to 104°F) |
Storage humidity | 10% to 90% RH, noncondensing |
Power consumption | ≤ 12 W |
Cooling method | Passive cooling |
Certification | CE CB |
Table 6 NX15 software features
Category | Features |
Wireless | 2.4 GHz 2×2 MIMO & 5 GHz 2×2 MIMO MU-MIMO HT20/HT40/HT80 mode Wi-Fi scheduled shutdown Wi-Fi power adjustment DDNS Parental control at multiple time ranges IP-based traffic control VPN Client |
Unique feature | Packet fast forwarding engine |
Configuration management | User management from the Web page User management from an APP Local upgrade and online upgrade from the Web page |
Fault diagnosis | Internet access diagnosis |
Upgrade methods
You can upgrade the device software by online upgrade or local upgrade.
Online upgrade
With online upgrade, you can obtain the software image from the remote server.
To upgrade device software by online upgrade:
1.Navigate to the System Settings page.
2.Click Upgrade in the Online Upgrade row. The system will check whether a new version is available from the remote server.
3.If a new version is available, the system prompts a dialog box for you to choose whether to upgrade the system.
4.Click Upgrade. The system downloads the new version.
5.After the new version is downloaded, the device automatically upgrades the software version and then reboots.
Local upgrade
CAUTION: Do not power off the device or operate the Web interface during the local software upgrade process. |
To upgrade software by local upgrade:
1.Save the latest software image to the local host.
2.Connect the local host directly to the router.
3.Click Browser in the Local Upgrade row to select the local software image and then click Upgrade.
4.After the upgrade is complete, the device will reboot automatically.
