H3C TC01 V4.0.240925
Release Notes
Copyright © 2024 New H3C Technologies Co., Ltd. All rights reserved. Without written permission from this company, no unit or individual may excerpt or copy part or all of the content of this document, and may not propagate it in any form. The information in this document may change without further notice. |
1 Version Information································································································ 1
1.1 Version Number 1
1.2 Version Matching Table 1
1.3 Precautions for Version Upgrade
2 Hardware Feature Change Description······································································· 2
3 Software Features and Command Line Change Instructions·········································· 2
4 Operation Mode Change Explanation········································································· 2
5 Version Usage Restrictions and Precautions
6 Issues and Workaround Measures············································································· 2
6.1 V 4.0.240925 Version Legacy Issues·························································································· 2
7 Resolve Problem List······························································································ 3
7.1 V 4.0.240925 version················································································································· 3
8 Related Resources································································································· 3
8.1 Data Acquisition Method 3
9 Technical Support·································································································· 3
List of tables
Table 1 Historical Version Information Table 1
Table 2 Version Matching Table 1
Table 3 Software Feature Change Description......................................................................... 2
This document describes the features, usage restrictions, known issues, and workarounds for the TC01 wireless display adapter (V4.0.240925) version.
Product | External Version Number | Internal Version Number |
TC01 | TC01 V4.0.24.0925 | H3C ES06T-C_v 4.0.240925_OTA.7z |
表1 Version history
Version number | Base version number | Release date | Version type | Remarks |
TC01-V 2.0.230512 | V 2.0.230512 | 2023-06-08 | TR4A version | 【TR5 version】Production version EShare ES06T-C_v 2.0.230512_OTA.img |
TC01-V 4.0.231019 | V 4.0.231019 | 2023-11-22 | Production version | Production version, TR4A optimization version H3C ES06T-C_v 4.0.231019_OTA.7z |
TC01-V 4.0.240925 | V 4.0.240925 | 2024-10-15 | TR5 version | 【TR5 version】Production version H3C ES06T-C_v 4.0.240925_OTA.7z
To avoid an update failure, use the following table to verify the hardware and software compatibility before performing an update.
表2 Compatibility matrix
attribute | description |
model | TC01 |
remark | none |
The current upgrade tool only supports upgrading on Windows computers and MAC computers. When upgrading, please directly plug the TypeC screen adapter into the computer. Do not plug or unplug the screen adapter during the upgrade process. Plug and unplug the pairing after the upgrade is complete.
N/A
表3 Software feature updates
Version number | Description |
V 2.0.230512 | TR4A version |
V 4.0.231019 | Production version |
V 4.0.240925 | TR5 version |
N/A
1、 Usage Restriction: This software version is compatible with product device model TC01.
2、 Restrictions and guidelines
· Please use a device that supports DP signal output through the TypeC port.
· Symptom: Connection failure between the transmitter and the large screen, projector light does not blink red
· Condition for problem occurrence: When the screen transmitter connection fails
· Workaround: Check if the hotspot on the large screen is open and retransmit the screen, with subsequent optimization.
· Issue Description: When casting, initiating a video conference while using BYOM microphone and speaker, the sound is 1-2 seconds slower than the video (supported on Android)
· Condition: Simultaneously using BYOM microphone and speaker
· Workaround: Switchover computer speaker, manually switch to UDP protocol
· Issue Description: On Windows large screen devices, when casting, the sound is delayed by about 2 seconds compared to the video.
· Condition for the problem to occur: Poor network connection and the use of TCP protocol
· Workaround: Manually switchover to UDP protocol
To obtain the latest documents, go to the H3C website www.h3c.com
(1) Please visit the website:
https://www.h3c.com/en/Support/Resource_Center/Technical_Documents/Intelligent_Terminal/
(2) Select the product category and product model to query and download the manual related to the product.
Email: Support.magic@h3c.com
Website: http://www.h3c.com/en/
