A. JBOD
B. HBA
C. RAID
D. simply volumes
A. Enter "linux dd" at the end of the lunuxefi line, and press F10 or Ctrl + X to start the installation.
B. Input linux diag at the end of the lunuxefi line, and press F10 or Ctrl+X to start the installation.
C. Input linux single at the end of the lunuxefi line, and press F10 or Ctrl+X to start the installation.
D. Input linux driver at the end of the lunuxefi line, and press F10 or Ctrl+X to start the installation.
A. All configurations of the HDM will be overridden.
B. All configurations of the BIOS will be overridden.
C. All configurations of the storage card will be overridden.
D. All users in the OS will be overridden.
A. 24
B. 36
C. 48
D. 52
A. The R4900G3 server does not support Windows 2012R2 Datacenter system.
B. The array card driver may be loaded.
C. The array card may be replaced.
D. The hard disk may be replaced.
A. UEFI
B. legacy
C. PXE
D. DHCP
A. Use the rpm -ivh drivername.rpm command to install the driver.
B. Use the modinfo drivername command to view the current driver in use of the system.
C. Use the apt-get install drivername command to install the driver.
D. Use the rpm -e drivename.rpm command to install the driver.
A. information
B. warning
C. critical
D. caution
A. Pre-read
B. Pre-write
C. Write-back
A. GET
B. POST
C. DELETE
D. PATCH
