A. A large amount of interfaces are provided for interconnection among computers of end users.
B. Access security control
C. High-speed packet switching
D. Complex routing policy
A. Only packets without tags can pass through the port, and default VLAN tags are added to the packets.
B. Only packets with default VLAN tags can pass through the port and the tags will be removed.
C. For packets without tags, the port adds default VLAN tags to the packets. For packets with tags, the port directly forwards the packets.
D. Only packets with tags can pass through the port.
A. Intranet VPN
B. Internet VPN
C. CPE-Based VPN
D. Network-Based VPN
A. Local LAC, local LAC
B. Peer LNS, peer LNS
C. Local LAC, peer LAC
D. Peer LAC, local LAC
A. Proxy authentication
B. Forced CHAP authentication
C. IPCP renegotiation
D. LCP renegotiation
A. reset ike
B. reset ike tunnel
C. reset ipsec sa
D. reset ike sa
A. GRE over IPSec, IPSec adopts the transmission mode.
B. GRE over IPSec, IPSec adopts the tunnel mode.
C. IPSec over GRE, IPSec adopts the transmission mode.
D. IPSec over GRE, IPSec adopts the tunnel mode.
A. An entity applies for the certificate.
B. RA completes the entity auditing.
C. CA issues the certificate.
D. An entity applies to RA for certificate revocation.
A. Both can provide integrity protection for data.
B. Both can provide data source authentication and optional anti-reply protection.
C. Both can provide confidentiality protection.
D. Both can be used at the same time.
A. An OSPF neighbor relationship must be established between PEs.
B. You must enter the BGP VPNv4 address suite view to enable the MP-BGP neighbor relationship.
C. PEs must use the loopback interface address to establish the BGP neighbor relationship.
A. It is an active traffic adjustment measure and limits the total rate of packets sent from an interface to the downstream interface.
B. The token bucket is used to measure the traffic. When the packets exceeding the committed rate enter the queue again, the general packet loss rate is decreased, the traffic is smoothened, but an extra delay is introduced.
C. It is on the link layer and is valid to all outgoing packets through this port (except for the emergency packets).
D. It does not take effect to non-IP packets.
A. LSR
B. LER
C. LSP
D. LRR
A. Outer MPLS label
B. Inner MPLS label
C. Outer destination IP address
D. Inner destination IP address
A. 80 Mbit/s packets are forwarded normally.
B. Traffic of packets is shaped as 65 Mbit/s for forwarding.
C. Packets with 802.1p priority being 1 are forwarded through egress port GE1/0/9.
D. Packets with 802.1p priority being 2 are forwarded through egress port GE1/0/9.
A. Messages are discarded after port congestion.
B. Messages are not discarded when the average length of the queue is less than Low-Limit Discard.
C. Messages received are discarded randomly when the average length of the queue is greater than Low-Limit Discard and less than High-Limit Discard.
D. Messages received are discarded randomly when the average length of the queue is greater than High-Limit Discard.
E. The higher the message priority, the lower the message discarding probability, i.e. fewer messages discarded.
