A. Network layer
B. Session layer
C. Application layer
D. Infrastructure layer
A. 172.16.0.0/22
B. 172.16.0.0/23
C. 172.16.0.0/24
D. 172.16.0.0/25
A. 10
B. 100
C. 150
D. 255
A. Negotiate the master/slave relationship in the interaction
B. Describe LSA summary information
C. Reply to the LSR packet, and send the complete LSA requested by a neighboring router
D. Maintain the neighbor relationship when the router is in ExStart status.
A. Type 3 LSA
B. Type 4 LSA
C. Type 5 LSA
D. Type 7 LSA
A. 1, 1, and 1
B. 1, 1, and 10
C. 1, 10, and 100
D. 1, 10, and 10
A. ES
B. Level-1 IS
C. Level-2 IS
D. Level-1-2 IS
A. The Router-ID is bound to the System-ID of NET by default to facilitate maintenance.
B. NET is generated from the Router-ID so that it can be easily memorized.
C. Using the globally unique Router-ID can ensure the uniqueness of the IS-IS process NET for all routers on the entire network.
D. If device replacement takes place, both the Router-ID and the System-ID can be flexibly changed.
A. In an IP network, IS-IS is carried in IP packets.
B. IS-IS packets use the NSAPs in CLNP.
C. An NSAP is composed of the IDP and DSP, with a fixed length of 160 bits.
D. An NSAP is length-variable, with the maximum length 160 bits and minimum length 64 bits.
A. [RTA]silent-interface serial2/0
B. [RTA-ospf-1]silent-interface serial2/0
C. [RTA-ospf-1-area-0.0.0.1]silent-interface serial2/0
D. [RTA-Serial2/0]silent-interface
A. Set the packet priority.
B. Set the outbound interface.
C. Set the packet length.
D. Set the next hop of packets.
A. IDLE
B. OPENSENT
C. ACTIVE
D. CONNECT
A. Filter-policy
B. Route-policy
C. AS-Path list
D. ACL
A. BGP aggregation falls into automatic mode and manual mode.
B. Because BGP supports CIDR, the routes in a routing table can be automatically aggregated as a route with natural mask by automatic aggregation of BGP.
C. By manual aggregation of BGP, aggregated routes and specific routes can be advertised at the same time, and aggregated routes can be generated by selecting specific routes.
D. In the manual aggregation mode of BGP, you can modify the origin attribute of an aggregated route by configuring the origin-policy parameter to implement flexible control.
A. Incomplete
B. Reachable
C. Stale
D. Delay
E. Probe
