A. <Esc>
B. <Space>
C. <Enter>
D. <Tab>
A. System view
B. User view
C. Interface view
D. Routing protocol view
A. [SWA]portlink-typetrunk
B. [SWA-Ethernet1/0/1]portlink-typetrunk
C. [SWA]undoportlink-typeaccess
D. [SWA-Ethernet1/0/1]undoportlink-typeaccess
A. Blocking
B. Listening
C. Learning
D. Forwarding
E. Waiting
F. Disable
A. Colon hexadecimal notation
B. Dotted decimal notation
C. Colon decimal notation
D. Dotted hexadecimal notation
A. Source IP address
B. Flow control
C. Checksum
D. Sequence number
E. Destination port
F. Source port
A. iproute-static
B. route-static
C. ipstatic-route
D. static-route
A. preferentially match the route with cost 120
B. preferentially match the route with cost 10
C. preferentially match the route with preference value 10
D. preferentially match the route with preference value 150
A. Neighbor discovery
B. Synchronization of router LSDB
C. Update of LSA information
D. Maintenance of neighboring relationship
A. Configuring the ACL only on MSR-1 cannot satisfy the requirements.
B. Configuring the ACL only on MSR-2 cannot satisfy the requirements.
C. Configuring the ACL only on MSR-1 can satisfy the requirements.
D. Configuring the ACL only on MSR-2 can satisfy the requirements.
E. When the ping command is executed, ICMP packets are transmitted bidirectionally. Therefore, the requirement for unidirectional communication cannot be satisfied.
