Beijing, July 10, 2018— H3C Group (H3C) under Tsinghua Unigroup officially launched H3C Oasis Smart Operation & Maintenance, a brand-new network operation and maintenance product, in Shanghai at the event of "Shaping the Digital Future — 100 Cities Itinerant Exhibition of H3C Digital Navigation 2018". In this way, H3C will help users reduce the cost of network maintenance, simplify network management, and create more efficient network infrastructure by using a leading comprehensive network O&M solution. Christine Sun, Senior Vice President of H3C Group, Tao Jian, Vice President of H3C Group, and Liu Chen, Director of the Wireless Product Department, attended the launch ceremony.
Launch Ceremony of H3C Oasis Smart Operation & Maintenance
Problems such as high cost in network operation and maintenance and complicated management need to be solved urgently
According to the data from Gartner, at present, the cost in network operation and maintenance have accounted for 70% of the IT deployment cost. How to reduce this cost has become an important issue for enterprises' IT deployment. With regards to network construction and operation in campuses and other large parks, the management and maintenance of wireless networks is one of the most complex and problem-prone technical fields. It is impossible to recur and trace faults, network optimization parameters are complex, and it is difficult to collect experience data. In the main scenarios of wireless network deployment and application in small and medium shops and hotels, O&M personnel only have the capacity to deal with primary network operation and maintenance. Faced with more complex network faults, IT service providers need to provide a more easily understood and visual mode of interaction.
Oasis Smart Operation & Maintenance enables easy management, low cost and high efficiency of networks
Based on the actual needs of industry users, H3C launches H3C Oasis Smart Operation & Maintenance to create a comprehensive network operation and maintenance solution for users and realize network status monitoring and smart dynamic optimization anytime and anywhere. In this way, network problems can be solved in a simple and quick manner, and network operation and maintenance can be simple and effective, which greatly saves users' cost in operation and maintenance. At present, Oasis Smart Operation & Maintenance is based on the Oasis Cloud covering a variety of cloud services including public and private clouds. In the future, it will be built into an operation and maintenance tool integrating cloud, network and terminal.
Helping enterprise users of all scales
benefit significantly from network operation and maintenance
H3C Oasis Smart Operation & Maintenance contributes greatly to the maintenance of network systems of large enterprise parks and small and medium-sized enterprises with relatively weak operation and maintenance capabilities, such as shopping malls and hotels. First, it effectively reduces the labor cost through automated and intelligent operation and maintenance technologies. On the other hand, while network inspection and monitoring take up 30% of the time in traditional operation and maintenance, Oasis Smart Operation & Maintenance greatly reduces this resource consumption with a simple and friendly interaction method. In addition, Oasis Smart Operation & Maintenance dynamically adjusts network configuration through automatic network optimization, making the network function well at all times.
So far, the H3C Smart Operation & Maintenance emerged to meet the demands of a wide range of clients has been deployed and applied in many industries. This innovative mode of network operation and maintenance effectively reduces the operation and maintenance cost of clients, improves the reliability and maintainability of networks, and enables industry users to enjoy an efficient user experience without the need to create a large-scale professional operation and maintenance team, thus helping clients explore the value of data and accelerating digital transformation.
